[GRASS-SVN] r69328 - grass-addons/grass7/vector/v.in.pygbif
svn_grass at osgeo.org
Thu Sep 1 01:10:48 PDT 2016
Author: sbl
Date: 2016-09-01 01:10:48 -0700 (Thu, 01 Sep 2016)
New Revision: 69328
grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py
v.in.gbif: Fixed some issues identified by Helmut
Modified: grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py
--- grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py 2016-09-01 00:40:57 UTC (rev 69327)
+++ grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py 2016-09-01 08:10:48 UTC (rev 69328)
@@ -350,15 +350,16 @@
# Set reprojection parameters
# Set target projection of current LOCATION
- target = osr.SpatialReference()
- target.ImportFromProj4(grass.read_command('g.proj', flags='fj'))
+ target_crs = grass.read_command('g.proj', flags='fj').rstrip('\n')
+ target = osr.SpatialReference(target_crs)
+ target.ImportFromProj4(target_crs)
if target == 'XY location (unprojected)':
grass.fatal("Sorry, XY locations are not supported!")
# Set source projection from GBIF
source = osr.SpatialReference()
source.ImportFromEPSG(4326)
- if target != source:
+ if target_crs != source:
transform = osr.CoordinateTransformation(source, target)
reverse_transform = osr.CoordinateTransformation(target, source)
@@ -385,7 +386,7 @@
else:
# Do not limit import spatially if LOCATION is able to take global data
if no_region_limit:
- if target != latlon:
+ if target_crs != latlon:
grass.fatal('Import of data outside the current region is'
'only supported in an WGS84 location!')
pol = None
@@ -398,7 +399,7 @@
region['n'], region['w'], region['s'])
# Do not reproject in latlon LOCATIONS
pol = ogr.CreateGeometryFromWkt(region_pol)
pol.Transform(reverse_transform)
pol = pol.ExportToWkt()
@@ -466,6 +467,10 @@
elif returns_n <= 0:
grass.warning('No occurrences for current search for taxon {0}...'.format(s))
continue
+ elif returns_n >= 200000:
+ grass.warning('Your search returns {0} records.\n'
+ 'Unfortunately, the GBIF search API is limited to 200,000 records per request.\n'
+ 'The download will be incomplete. Please consider to split up your search.'.format(returns_n, s))
# Get the number of chunks to download
chunks = int(math.ceil(returns_n / float(chunk_size)))
@@ -481,6 +486,13 @@
# Download the data from GBIF
for c in range(chunks):
+ # Define offset
+ offset = c * chunk_size
+ # Adjust chunk_size to the hard limit of 200,000 records in GBIF API
+ # if necessary
+ if offset + chunk_size >= 200000:
+ chunk_size = 200000 - offset
+ # Get the returns for the next chunk
returns = occurrences.search(taxonKey=key,
hasGeospatialIssue=hasGeospatialIssue,
hasCoordinate=hasCoordinate,
@@ -492,7 +504,7 @@
country=country,
geometry=pol,
limit=chunk_size,
- offset=c * chunk_size)
+ offset=offset)
# Write the returned data to map and attribute table
for res in returns['results']:
@@ -509,9 +521,9 @@
for k in dwc_keys:
if k not in res.keys():
- res.update({k: 1})
+ res.update({k: None})
- new.write(point, cat=cat, attrs=(
+ new.write(point, attrs=(
res['key'],
res['taxonRank'],
res['taxonKey'],
