[GRASS-SVN] r69329 - grass-addons/grass7/vector/v.in.pygbif
Thu Sep 1 01:11:18 PDT 2016
Author: sbl
Date: 2016-09-01 01:11:18 -0700 (Thu, 01 Sep 2016)
New Revision: 69329
   grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html
v.in.gbif: Updated documentation
Modified: grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html
--- grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html	2016-09-01 08:10:48 UTC (rev 69328)
+++ grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html	2016-09-01 08:11:18 UTC (rev 69329)
@@ -8,10 +8,17 @@
 import is limited to the current computational region in order to avoid
 possible projection errors, e.g. when projecting global data into UTM locations.
 However, in lat/lon location this limitation can be skiped using the <b><em>-r</em></b>
-flag.</p>
+flag.<br>
+Providing a mask overrides the limitation of the search to the current computational region.</p>
 <p>Terminology in v.in.pygbif is oriented on the <em>Darwin Core</em> standard:
 <a href=http://rs.tdwg.org/dwc/> http://rs.tdwg.org/dwc/</a>.</p>
+<p>Please note that the GBIF Search API has a hard limit of 200,000 occurrences
+per request. If you want to fetch more records, either subivide your area of
+interest or split up your search by using different search criteria.<br>
+When a list of taxa is given as input, v.in.pygbif issues a search for each species individually. Thus, in order to slpit up a search it is recommended to either use different filters on time or space.</p>
 <div id="examples">
 <h2>EXAMPLES:</h2>
