[GRASS-SVN] r69376 - grass/trunk/raster3d/r3.in.lidar
svn_grass at osgeo.org
Mon Sep 5 06:18:29 PDT 2016
Author: wenzeslaus
Date: 2016-09-05 06:18:29 -0700 (Mon, 05 Sep 2016)
New Revision: 69376
grass/trunk/raster3d/r3.in.lidar/main.c
r3.in.lidar: add verbose messages and percentages
Modified: grass/trunk/raster3d/r3.in.lidar/main.c
--- grass/trunk/raster3d/r3.in.lidar/main.c 2016-09-05 08:22:28 UTC (rev 69375)
+++ grass/trunk/raster3d/r3.in.lidar/main.c 2016-09-05 13:18:29 UTC (rev 69376)
@@ -33,6 +33,7 @@
RASTER3D_Map *prop_count_raster, *prop_sum_raster;
+/* TODO: do this in some more efficient way, perhaps function in the lib */
static void raster3d_set_value_float(RASTER3D_Map * raster,
RASTER3D_Region * region, float value)
@@ -51,8 +52,10 @@
int col, row, depth;
double tmp;
- for (depth = 0; depth < region->depths; depth++)
- for (row = 0; row < region->rows; row++)
+ G_percent_reset();
+ for (depth = 0; depth < region->depths; depth++) {
+ G_percent(depth, region->depths, 5);
+ for (row = 0; row < region->rows; row++) {
for (col = 0; col < region->cols; col++) {
tmp = Rast3d_get_double(b, col, row, 0);
/* TODO: compare to epsilon */
@@ -66,6 +69,9 @@
Rast3d_put_double(c, col, row, depth, tmp);
+ G_percent(1, 1, 1); /* flush */
/* c = a / b where b has depth 1 */
@@ -76,8 +82,10 @@
double tmp;
/* since it is count, using cast to integer to check
@@ -92,6 +100,9 @@
void binning_add_point(struct PointBinning3D binning, int row, int col,
@@ -230,11 +241,16 @@
only_valid = TRUE;
LASReaderH LAS_reader;
+ LASHeaderH LAS_header;
LAS_reader = LASReader_Create(input_opt->answer);
if (LAS_reader == NULL)
G_fatal_error(_("Unable to open file <%s>"), input_opt->answer);
+ LAS_header = LASReader_GetHeader(LAS_reader);
+ if (LAS_header == NULL) {
+ G_fatal_error(_("Input file <%s> is not a LAS LiDAR point cloud"),
+ input_opt->answer);
Rast3d_init_defaults();
Rast3d_set_error_fun(Rast3d_fatal_error_noargs);
@@ -326,12 +342,19 @@
Rast3d_fatal_error(_("Unable to create 3D raster map <%s>"),
prop_sum_output_opt->answer);
+ G_verbose_message(_("Preparing the maps..."));
raster3d_set_value_float(binning.count_raster, &binning.region, 0);
+ G_percent(25, 100, 1);
raster3d_set_value_float(binning.sum_raster, &binning.region, 0);
+ G_percent(50, 100, 1);
raster3d_set_value_float(binning.count_flat_raster, &binning.flat_region,
0);
+ G_percent(75, 100, 1);
raster3d_set_value_float(binning.sum_flat_raster, &binning.flat_region,
0);
LASPointH LAS_point;
double east, north, top;
@@ -346,8 +369,20 @@
long unsigned n_return_filtered = 0;
long unsigned n_class_filtered = 0;
long unsigned n_invalid = 0;
+ long unsigned counter = 0;
+ long unsigned header_count = LASHeader_GetPointRecordsCount(LAS_header);
+ G_verbose_message(_("Reading points..."));
while ((LAS_point = LASReader_GetNextPoint(LAS_reader)) != NULL) {
+ if (counter == 100000) { /* report only some for speed */
+ if (inside < header_count) /* TODO: inside can greatly underestimate */
+ G_percent(inside, header_count, 3);
+ counter = 0;
+ counter++;
/* We always count them and report because r.in.lidar behavior
* changed in between 7.0 and 7.2 from undefined (but skipping
* invalid points) to filtering them out only when requested. */
@@ -401,11 +436,15 @@
inside += 1;
+ G_verbose_message(_("Computing proportional count map..."));
raster3d_divide_by_flat(binning.count_raster, binning.count_flat_raster,
binning.prop_count_raster, &binning.region);
+ G_verbose_message(_("Computing proportional sum map..."));
raster3d_divide_by_flat(binning.sum_raster, binning.sum_flat_raster,
binning.prop_sum_raster, &binning.region);
+ G_verbose_message(_("Computing mean map..."));
raster3d_divide(binning.sum_raster, binning.count_raster,
binning.mean_raster, &binning.region);
@@ -427,13 +466,23 @@
G_message(_("%lu input points were not valid, use -%c flag to filter"
" them out"), n_invalid, only_valid_flag->key);
+ G_verbose_message(_("Closing the maps..."));
Rast3d_close(binning.prop_sum_raster);
+ G_percent(1, 7, 1);
Rast3d_close(binning.prop_count_raster);
+ G_percent(2, 7, 1);
Rast3d_close(binning.sum_flat_raster); /* TODO: delete */
+ G_percent(3, 7, 1);
Rast3d_close(binning.count_flat_raster); /* TODO: delete */
+ G_percent(4, 7, 1);
Rast3d_close(binning.mean_raster);
+ G_percent(5, 7, 1);
Rast3d_close(binning.sum_raster);
+ G_percent(6, 7, 1);
Rast3d_close(binning.count_raster);
if (use_segment)
Segment_close(&base_segment);
