[GRASS-SVN] r69377 - grass/trunk/raster3d/r3.in.lidar
svn_grass at osgeo.org
Mon Sep 5 06:24:33 PDT 2016
Author: wenzeslaus
Date: 2016-09-05 06:24:33 -0700 (Mon, 05 Sep 2016)
New Revision: 69377
grass/trunk/raster3d/r3.in.lidar/main.c
r3.in.lidar: final (done) messages at the very end (closing takes time and gives output)
Modified: grass/trunk/raster3d/r3.in.lidar/main.c
--- grass/trunk/raster3d/r3.in.lidar/main.c 2016-09-05 13:18:29 UTC (rev 69376)
+++ grass/trunk/raster3d/r3.in.lidar/main.c 2016-09-05 13:24:33 UTC (rev 69377)
@@ -448,24 +448,6 @@
raster3d_divide(binning.sum_raster, binning.count_raster,
binning.mean_raster, &binning.region);
- G_message("Number of points inside: %lu", inside);
- if (use_segment)
- G_message
- ("Number of points outside or in base raster NULL cells: %lu",
- outside + in_nulls);
- else
- G_message("Number of points outside: %lu", outside);
- if (n_invalid && only_valid)
- G_message(_("%lu input points were not valid and filtered out"),
- n_invalid);
- if (n_return_filtered)
- G_message(_("%lu input points were filtered out by return number"), n_return_filtered);
- if (n_class_filtered)
- G_message(_("%lu input points were filtered out by class number"), n_class_filtered);
- if (n_invalid && !only_valid)
- G_message(_("%lu input points were not valid, use -%c flag to filter"
- " them out"), n_invalid, only_valid_flag->key);
G_verbose_message(_("Closing the maps..."));
G_percent_reset();
@@ -487,5 +469,23 @@
if (use_segment)
Segment_close(&base_segment);
+ G_message("Number of points inside: %lu", inside);
+ if (use_segment)
+ G_message
+ ("Number of points outside or in base raster NULL cells: %lu",
+ outside + in_nulls);
+ else
+ G_message("Number of points outside: %lu", outside);
+ if (n_invalid && only_valid)
+ G_message(_("%lu input points were not valid and filtered out"),
+ n_invalid);
+ if (n_return_filtered)
+ G_message(_("%lu input points were filtered out by return number"), n_return_filtered);
+ if (n_class_filtered)
+ G_message(_("%lu input points were filtered out by class number"), n_class_filtered);
+ if (n_invalid && !only_valid)
+ G_message(_("%lu input points were not valid, use -%c flag to filter"
+ " them out"), n_invalid, only_valid_flag->key);
exit(EXIT_SUCCESS);
