[GRASS-SVN] r69378 - grass-addons/grass7/misc/m.printws
svn_grass at osgeo.org
Mon Sep 5 09:16:36 PDT 2016
Author: kuszinger
Date: 2016-09-05 09:16:36 -0700 (Mon, 05 Sep 2016)
New Revision: 69378
grass-addons/grass7/misc/m.printws/m.printws.html
grass-addons/grass7/misc/m.printws/m.printws.py
Flexi option, find_program for imagemagick, official temp region
Modified: grass-addons/grass7/misc/m.printws/m.printws.html
--- grass-addons/grass7/misc/m.printws/m.printws.html 2016-09-05 13:24:33 UTC (rev 69377)
+++ grass-addons/grass7/misc/m.printws/m.printws.html 2016-09-05 16:16:36 UTC (rev 69378)
@@ -186,6 +186,30 @@
again. After this alignment with the <i>Pan</i> tool the workspace must be saved again
so m.printws could print up to the newly set extents.
+<h3>Illustration with the <i>Flexi</i> page option</h3>
+When creating figures for scientific articles or book illustration purposes maps usually
+don't have elements like titles and others outside the map frame.
+In research papers map content is described in subtitles as <i>Figure nn.:</i>
+and so on.
+In this case page options like A4, or A4 landscape would always have white stripes on
+the top/bottom or left/right even when margin is set to be zero.
+This is because the ratio of the
+edges of the map never exactly follows the ratio of the A4 or other page
+edges. Supporting the creation of publication ready images (especially when
+the target format is tif, png or jpg) the <b>Flexi option is introduced</b>
+as a virtual page size. Using the Flexi page:
+<ul>
+ <li>Titles and other external elements won't be generated even if they would be defined.</li>
+ <li>Page content will be reduced to the map area only.</li>
+ <li>There will be no margin independently of the ratio of the map edges.</li>
+</ul>
+<small><i><b>Background:</b> The Flexi mechanism actually sets up the same layout
+as it is specified with margins and titles on a 300x300mm page and then
+cuts off everything outside the map frame together with cancelling the
+rendering of title elements.</i></small><br><br>
+Using the dpi option of m.printws an ideal resolution could easily be set.
<h2>EXAMPLE</h2>
Modified: grass-addons/grass7/misc/m.printws/m.printws.py
--- grass-addons/grass7/misc/m.printws/m.printws.py 2016-09-05 13:24:33 UTC (rev 69377)
+++ grass-addons/grass7/misc/m.printws/m.printws.py 2016-09-05 16:16:36 UTC (rev 69378)
@@ -48,7 +48,7 @@
#%option
#% key: page
#% type: string
-#% options: A4landscape,A4portrait,LETTERlandscape,LETTERportrait,A3landscape,A3portrait
+#% options: A4landscape,A4portrait,LETTERlandscape,LETTERportrait,A3landscape,A3portrait,Flexi
#% answer: A4landscape
#% description: Output map page size
#% guisection: Output
@@ -56,7 +56,7 @@
#%option
#% key: format
#% type: string
-#% options: jpg,png,bmp,pdf,ppm
+#% options: pdf,png,tiff,bmp,ppm,jpg
#% answer: pdf
#% description: Output file format
@@ -194,9 +194,10 @@
# initialize global vars
TMPFORMAT = 'BMP'
TMPLOC = None
+LAYERCOUNT = 10
+# Following declarations MAY will used in future for sure.
SRCGISRC = None
GISDBASE = None
-LAYERCOUNT = 10
# temp dir
REMOVE_TMPDIR = True
PROXIES = {}
@@ -234,7 +235,9 @@
PAGEDIC['A3landscape'] = (420.0, 297.0, '', 'A3')
PAGEDIC['LETTERportrait'] = (215.9, 297.4, '', 'Letter')
PAGEDIC['LETTERlandscape'] = (297.4, 215.9, '', 'Letter')
+PAGEDIC['Flexi'] = (300, 300, '', 'Flexi')
# HTML DECODE
HTMLDIC = {}
HTMLDIC['>'] = '>'
@@ -565,7 +568,21 @@
def main():
+ # Following declarations MAY will used in future for sure.
global GISDBASE, LAYERCOUNT, LASTFILE
+ # Check if ImageMagick is available since it is essential
+ if os.name == 'nt':
+ if grass.find_program('magick', '-version'):
+ grass.verbose(_('printws: ImageMagick is available: OK!'))
+ else:
+ grass.fatal('ImageMagick is not accessible. See documentation of m.printws module for details.')
+ else:
+ if grass.find_program('convert', '-version'):
+ else:
textmacros = {}
# %nam% macros are kept for backward compatibility
textmacros['%TIME24%'] = time.strftime("%H:%M:%S")
@@ -582,13 +599,12 @@
textmacros['\$DATEMDY'] = textmacros['%DATEMDY%']
textmacros['\$USERNAME'] = textmacros['%USERNAME%']
- textmacros['\$SPC'] = u'\u00A0' #?? d.text won't display at string end hmmm
+ textmacros['\$SPC'] = u'\u00A0' #?? d.text won't display this at string end hmmm
# saves region for restoring at end
- savedregionname = "tmp.%s.%d" % (
- os.path.basename(sys.argv[0]), os.getpid())
- grass.run_command("g.region", save=savedregionname, overwrite=True)
+ # doing with official method:
+ grass.use_temp_region()
# getting/setting screen/print dpi ratio
@@ -659,8 +675,8 @@
pageoption = options['page']
else:
pageoption = 'A4landscape'
# parsing titles, etc.
if len(options['titlefont']) > 0:
isAsterisk = options['titlefont'].find('*')
if isAsterisk > 0:
@@ -811,6 +827,17 @@
pagemarginsindotstitles, pagesizesindots)
mpfd = getmapframeindots(mapulindots, mapsizesindots, mxfdtitles)
+ if pageoption == 'Flexi':
+ # For 'Flexi' page we modify the setup to create
+ # a page containing only the map without margins
+ grass.verbose(_("printws: pre Flexi mapframe: " + str(mpfd)))
+ mpfd['b'] = mpfd['b'] - mpfd['t']
+ mpfd['t'] = 0
+ mpfd['r'] = mpfd['r'] - mpfd['l']
+ mpfd['l'] = 0
+ os.environ['GRASS_RENDER_WIDTH'] = str(mpfd['r'])
+ os.environ['GRASS_RENDER_HEIGHT'] = str(mpfd['b'])
+ grass.verbose(_("printws: post Flexi mapframe: " + str(mpfd)))
mapframe = str(mpfd['t']) + ',' + str(mpfd['b']) + \
',' + str(mpfd['l']) + ',' + str(mpfd['r'])
@@ -831,7 +858,9 @@
# ------------------- INMAP -------------------
- imcommand = 'convert -limit memory 720000000 -limit map 720000000 -units PixelsPerInch -density ' + \
+ # Do not limit -map. It was: -limit map 720000000 before...
+ # So we can grow on disk as long as it lasts
+ imcommand = 'convert -limit memory 720000000 -units PixelsPerInch -density ' + \
str(int(dpioption)) + ' '
if os.name == 'nt':
@@ -871,47 +900,50 @@
grass.run_command("g.region", ewres=str(newewres), nsres=str(newnsres))
# ------------------- OUTSIDE MAP texts, etc -------------------
- os.environ['GRASS_RENDER_FRAME'] = maxframe
+ if pageoption =='Flexi':
+ grass.verbose(_('m.printws: WARNING! Felxi mode, will not create titles, etc...'))
+ else:
+ os.environ['GRASS_RENDER_FRAME'] = maxframe
- dict = {}
- dict['task'] = "d.text"
- dict['color'] = titlecolor
- dict['font'] = titlefont
- dict['charset'] = "UTF-8"
+ dict = {}
+ dict['task'] = "d.text"
+ dict['color'] = titlecolor
+ dict['font'] = titlefont
+ dict['charset'] = "UTF-8"
- if len(options['maintitle']) > 1:
- dict['text'] = decodetextmacros(options['maintitle'], textmacros)
- dict['at'] = "50," + str(titletoppercent)
- dict['align'] = "uc"
- dict['size'] = str(maintitlesize)
- render(str(dict), dict, {})
+ if len(options['maintitle']) > 1:
+ dict['text'] = decodetextmacros(options['maintitle'], textmacros)
+ dict['at'] = "50," + str(titletoppercent)
+ dict['align'] = "uc"
+ dict['size'] = str(maintitlesize)
+ render(str(dict), dict, {})
- if len(options['subtitle']) > 1:
- dict['text'] = decodetextmacros(options['subtitle'], textmacros)
- dict['at'] = "50," + str(subtitletoppercent)
- dict['size'] = str(subtitlesize)
+ if len(options['subtitle']) > 1:
+ dict['text'] = decodetextmacros(options['subtitle'], textmacros)
+ dict['at'] = "50," + str(subtitletoppercent)
+ dict['size'] = str(subtitlesize)
- dict['size'] = str(pssize)
+ dict['size'] = str(pssize)
- if len(options['psundercentral']) > 1:
- options['psundercentral'], textmacros)
- dict['at'] = "50,1"
- dict['align'] = "lc"
- if len(options['psunderleft']) > 1:
- dict['text'] = decodetextmacros(options['psunderleft'], textmacros)
- dict['at'] = "0,1"
- dict['align'] = "ll"
- if len(options['psunderright']) > 1:
- options['psunderright'], textmacros)
- dict['at'] = "100,1"
- dict['align'] = "lr"
+ if len(options['psundercentral']) > 1:
+ options['psundercentral'], textmacros)
+ dict['at'] = "50,1"
+ dict['align'] = "lc"
+ if len(options['psunderleft']) > 1:
+ dict['text'] = decodetextmacros(options['psunderleft'], textmacros)
+ dict['at'] = "0,1"
+ dict['align'] = "ll"
+ if len(options['psunderright']) > 1:
+ options['psunderright'], textmacros)
+ dict['at'] = "100,1"
+ dict['align'] = "lr"
# ------------------- GENERATING OUTPUT FILE -------------------
@@ -957,9 +989,7 @@
sys.stderr.write('%s\n' % TMPDIR % ' <---- this')
# restoring pre-script region
- grass.run_command("g.region", region=savedregionname, overwrite=True)
- grass.run_command('g.remove', flags="f", type="region",
- pattern=savedregionname)
+ # - not necessary as we are using grass.use_temp_region() in the future
return 0
