[GRASS-SVN] r69379 - grass/trunk/raster3d/r3.in.lidar
Mon Sep 5 17:50:50 PDT 2016
Author: wenzeslaus
Date: 2016-09-05 17:50:49 -0700 (Mon, 05 Sep 2016)
New Revision: 69379
Added:
   grass/trunk/raster3d/r3.in.lidar/info.c
   grass/trunk/raster3d/r3.in.lidar/info.h
   grass/trunk/raster3d/r3.in.lidar/projection.c
   grass/trunk/raster3d/r3.in.lidar/projection.h
   grass/trunk/raster3d/r3.in.lidar/string_list.c
   grass/trunk/raster3d/r3.in.lidar/string_list.h
   grass/trunk/raster3d/r3.in.lidar/filters.c
   grass/trunk/raster3d/r3.in.lidar/filters.h
   grass/trunk/raster3d/r3.in.lidar/main.c
   grass/trunk/raster3d/r3.in.lidar/rast_segment.c
   grass/trunk/raster3d/r3.in.lidar/rast_segment.h
r3.in.lidar: multiple files input, projection check, scan modes, irange, scales (based on r.in.lidar) [news]
Modified: grass/trunk/raster3d/r3.in.lidar/filters.c
--- grass/trunk/raster3d/r3.in.lidar/filters.c	2016-09-05 16:16:36 UTC (rev 69378)
+++ grass/trunk/raster3d/r3.in.lidar/filters.c	2016-09-06 00:50:49 UTC (rev 69379)
@@ -1,11 +1,12 @@
- * v.in.lidar filtering functions
+ * lidar-related filtering functions
- * Copyright 2011-2015 by Markus Metz, and The GRASS Development Team
  * Authors:
  *  Markus Metz (r.in.lidar)
- *  Vaclav Petras (move code to a separate files)
+ *  Vaclav Petras (refactoring and various additions)
+ * Copyright 2011-2016 by Markus Metz, and The GRASS Development Team
  * This program is free software licensed under the GPL (>=v2).
  * Read the COPYING file that comes with GRASS for details.
@@ -19,7 +20,25 @@
 #include <grass/gis.h>
 #include <grass/glocale.h>
+int range_filter_from_option(struct Option *option, double *min, double *max)
+    if (option->answer != NULL) {
+        if (option->answers[0] == NULL || option->answers[1] == NULL)
+            G_fatal_error(_("Invalid range <%s> for option %s"), option->answer, option->key);
+        sscanf(option->answers[0], "%lf", min);
+        sscanf(option->answers[1], "%lf", max);
+        /* for convenience, switch order to make valid input */
+        if (*min > *max) {
+            double tmp = *max;
+            *max = *min;
+            *min = tmp;
+        return TRUE;
+    return FALSE;
 int return_filter_create_from_string(struct ReturnFilter *return_filter,
                                      const char *name)
Modified: grass/trunk/raster3d/r3.in.lidar/filters.h
--- grass/trunk/raster3d/r3.in.lidar/filters.h	2016-09-05 16:16:36 UTC (rev 69378)
+++ grass/trunk/raster3d/r3.in.lidar/filters.h	2016-09-06 00:50:49 UTC (rev 69379)
@@ -1,11 +1,12 @@
  * Authors:
@@ -33,14 +34,8 @@
 struct Option;
-int spatial_filter_from_option(struct Option *option, double *xmin,
-                               double *ymin, double *xmax, double *ymax);
-int spatial_filter_from_current_region(double *xmin, double *ymin,
-                                       double *xmax, double *ymax);
+int range_filter_from_option(struct Option *option, double *min, double *max);
-int zrange_filter_from_option(struct Option *option,
-                              double *zmin, double *zmax);
                                      const char *name);
 int return_filter_is_out(struct ReturnFilter *return_filter, int return_n,
Copied: grass/trunk/raster3d/r3.in.lidar/info.c (from rev 69373, grass/trunk/raster/r.in.lidar/info.c)
--- grass/trunk/raster3d/r3.in.lidar/info.c	                        (rev 0)
+++ grass/trunk/raster3d/r3.in.lidar/info.c	2016-09-06 00:50:49 UTC (rev 69379)
@@ -0,0 +1,180 @@
+ * lidar-related printing and scanning functions
+ * Authors:
+ *  Markus Metz (r.in.lidar)
+ * This program is free software licensed under the GPL (>=v2).
+ * Read the COPYING file that comes with GRASS for details.
+#include <string.h>
+#include <grass/glocale.h>
+#include <liblas/capi/liblas.h>
+#include "local_proto.h"
+void print_lasinfo(LASHeaderH LAS_header, LASSRSH LAS_srs)
+    char *las_srs_proj4 = LASSRS_GetProj4(LAS_srs);
+    int las_point_format = LASHeader_GetDataFormatId(LAS_header);
+    fprintf(stdout, "\nUsing LAS Library Version '%s'\n\n",
+            LAS_GetFullVersion());
+    fprintf(stdout, "LAS File Version:                  %d.%d\n",
+            LASHeader_GetVersionMajor(LAS_header),
+            LASHeader_GetVersionMinor(LAS_header));
+    fprintf(stdout, "System ID:                         '%s'\n",
+            LASHeader_GetSystemId(LAS_header));
+    fprintf(stdout, "Generating Software:               '%s'\n",
+            LASHeader_GetSoftwareId(LAS_header));
+    fprintf(stdout, "File Creation Day/Year:            %d/%d\n",
+            LASHeader_GetCreationDOY(LAS_header),
+            LASHeader_GetCreationYear(LAS_header));
+    fprintf(stdout, "Point Data Format:                 %d\n",
+            las_point_format);
+    fprintf(stdout, "Number of Point Records:           %d\n",
+            LASHeader_GetPointRecordsCount(LAS_header));
+    fprintf(stdout, "Number of Points by Return:        %d %d %d %d %d\n",
+            LASHeader_GetPointRecordsByReturnCount(LAS_header, 0),
+            LASHeader_GetPointRecordsByReturnCount(LAS_header, 1),
+            LASHeader_GetPointRecordsByReturnCount(LAS_header, 2),
+            LASHeader_GetPointRecordsByReturnCount(LAS_header, 3),
+            LASHeader_GetPointRecordsByReturnCount(LAS_header, 4));
+    fprintf(stdout, "Scale Factor X Y Z:                %g %g %g\n",
+            LASHeader_GetScaleX(LAS_header),
+            LASHeader_GetScaleY(LAS_header), LASHeader_GetScaleZ(LAS_header));
+    fprintf(stdout, "Offset X Y Z:                      %g %g %g\n",
+            LASHeader_GetOffsetX(LAS_header),
+            LASHeader_GetOffsetY(LAS_header),
+            LASHeader_GetOffsetZ(LAS_header));
+    fprintf(stdout, "Min X Y Z:                         %g %g %g\n",
+            LASHeader_GetMinX(LAS_header),
+            LASHeader_GetMinY(LAS_header), LASHeader_GetMinZ(LAS_header));
+    fprintf(stdout, "Max X Y Z:                         %g %g %g\n",
+            LASHeader_GetMaxX(LAS_header),
+            LASHeader_GetMaxY(LAS_header), LASHeader_GetMaxZ(LAS_header));
+    if (las_srs_proj4 && strlen(las_srs_proj4) > 0) {
+        fprintf(stdout, "Spatial Reference:\n");
+        fprintf(stdout, "%s\n", las_srs_proj4);
+    else {
+        fprintf(stdout, "Spatial Reference:                 None\n");
+    fprintf(stdout, "\nData Fields:\n");
+    fprintf(stdout,
+            "  'X'\n  'Y'\n  'Z'\n  'Intensity'\n  'Return Number'\n");
+    fprintf(stdout, "  'Number of Returns'\n  'Scan Direction'\n");
+    fprintf(stdout,
+            "  'Flighline Edge'\n  'Classification'\n  'Scan Angle Rank'\n");
+    fprintf(stdout, "  'User Data'\n  'Point Source ID'\n");
+    if (las_point_format == 1 || las_point_format == 3 ||
+        las_point_format == 4 || las_point_format == 5) {
+        fprintf(stdout, "  'GPS Time'\n");
+    if (las_point_format == 2 || las_point_format == 3 ||
+        las_point_format == 5) {
+        fprintf(stdout, "  'Red'\n  'Green'\n  'Blue'\n");
+    fprintf(stdout, "\n");
+    fflush(stdout);
+    return;
+int scan_bounds(LASReaderH LAS_reader, int shell_style, int extents, int update,
+                double zscale, struct Cell_head *region)
+    unsigned long line;
+    int first;
+    double min_x, max_x, min_y, max_y, min_z, max_z;
+    double x, y, z;
+    LASPointH LAS_point;
+    line = 0;
+    first = TRUE;
+    /* init to nan in case no points are found */
+    min_x = max_x = min_y = max_y = min_z = max_z = 0.0 / 0.0;
+    G_verbose_message(_("Scanning data ..."));
+    LASReader_Seek(LAS_reader, 0);
+    while ((LAS_point = LASReader_GetNextPoint(LAS_reader)) != NULL) {
+        line++;
+        /* we don't do any filtering here */
+        x = LASPoint_GetX(LAS_point);
+        y = LASPoint_GetY(LAS_point);
+        z = LASPoint_GetZ(LAS_point);
+        if (first) {
+            min_x = x;
+            max_x = x;
+            min_y = y;
+            max_y = y;
+            min_z = z;
+            max_z = z;
+            first = FALSE;
+        else {
+            if (x < min_x)
+                min_x = x;
+            if (x > max_x)
+                max_x = x;
+            if (y < min_y)
+                min_y = y;
+            if (y > max_y)
+                max_y = y;
+            if (z < min_z)
+                min_z = z;
+            if (z > max_z)
+                max_z = z;
+    if (!extents) {
+        if (!shell_style) {
+            fprintf(stderr, _("Range:     min         max\n"));
+            fprintf(stdout, "x: %11f %11f\n", min_x, max_x);
+            fprintf(stdout, "y: %11f %11f\n", min_y, max_y);
+            fprintf(stdout, "z: %11f %11f\n", min_z * zscale, max_z * zscale);
+        else
+            fprintf(stdout, "n=%f s=%f e=%f w=%f b=%f t=%f\n",
+                    max_y, min_y, max_x, min_x, min_z * zscale,
+                    max_z * zscale);
+    else if (update) {
+        if (min_x < region->west)
+            region->west = min_x;
+        if (max_x > region->east)
+            region->east = max_x;
+        if (min_y < region->south)
+            region->south = min_y;
+        if (max_y > region->north)
+            region->north = max_y;
+    else {
+    G_debug(1, "Processed %lu points.", line);
+    G_debug(1, "region template: g.region n=%f s=%f e=%f w=%f",
+            max_y, min_y, max_x, min_x);
+    return 0;
Added: grass/trunk/raster3d/r3.in.lidar/info.h
--- grass/trunk/raster3d/r3.in.lidar/info.h	                        (rev 0)
+++ grass/trunk/raster3d/r3.in.lidar/info.h	2016-09-06 00:50:49 UTC (rev 69379)
@@ -0,0 +1,25 @@
+ * Authors:
+ * Copyright 2011-2016 by Vaclav Petras, and The GRASS Development Team
+#ifndef __INFO_H__
+#define __INFO_H__
+#include <grass/gis.h>
+#include <grass/raster.h>
+void print_lasinfo(LASHeaderH, LASSRSH);
+int scan_bounds(LASReaderH, int, int, int, double, struct Cell_head *);
+#endif /* __INFO_H__ */
Property changes on: grass/trunk/raster3d/r3.in.lidar/info.h
___________________________________________________________________
Added: svn:mime-type
   + text/x-chdr
Added: svn:eol-style
   + native
Modified: grass/trunk/raster3d/r3.in.lidar/main.c
--- grass/trunk/raster3d/r3.in.lidar/main.c	2016-09-05 16:16:36 UTC (rev 69378)
+++ grass/trunk/raster3d/r3.in.lidar/main.c	2016-09-06 00:50:49 UTC (rev 69379)
@@ -22,6 +22,9 @@
+#include "info.h"
+#include "string_list.h"
+#include "projection.h"
 #include "rast_segment.h"
 #include "filters.h"
@@ -124,12 +127,18 @@
     struct GModule *module;
     struct Option *input_opt;
+    struct Option *file_list_opt;
     struct Option *count_output_opt, *sum_output_opt, *mean_output_opt;
     struct Option *prop_count_output_opt, *prop_sum_output_opt;
     struct Option *filter_opt, *class_opt;
+    struct Option *zscale_opt;
+    struct Option *iscale_opt;
+    struct Option *irange_opt;
     struct Option *base_raster_opt;
     struct Flag *base_rast_res_flag;
     struct Flag *only_valid_flag;
+    struct Flag *print_flag, *scan_flag, *shell_style;
+    struct Flag *over_flag;
     G_gisinit(argv[0]);
@@ -142,15 +151,22 @@
     G_add_keyword(_("aggregation"));
     G_add_keyword(_("binning"));
     module->description =
-	_("Creates a 3D raster map from LAS LiDAR points using univariate statistics.");
+        _("Creates a 3D raster map from LAS LiDAR points using univariate statistics.");
     input_opt = G_define_standard_option(G_OPT_F_BIN_INPUT);
-    input_opt->required = YES;
+    input_opt->required = NO;
     input_opt->label = _("LAS input file");
     input_opt->description =
         _("LiDAR input file in LAS format (*.las or *.laz)");
     input_opt->guisection = _("Input");
+    file_list_opt = G_define_standard_option(G_OPT_F_INPUT);
+    file_list_opt->key = "file";
+    file_list_opt->label = _("File containing names of LAS input files");
+    file_list_opt->description = _("LiDAR input files in LAS format (*.las or *.laz)");
+    file_list_opt->required = NO;
+    file_list_opt->guisection = _("Input");
     count_output_opt = G_define_standard_option(G_OPT_R3_OUTPUT);
     count_output_opt->key = "n";
     count_output_opt->required = YES;
@@ -223,6 +239,30 @@
     base_rast_res_flag->description =
         _("Use base raster actual resolution instead of computational region");
+    zscale_opt = G_define_option();
+    zscale_opt->key = "zscale";
+    zscale_opt->type = TYPE_DOUBLE;
+    zscale_opt->required = NO;
+    zscale_opt->answer = "1.0";
+    zscale_opt->description = _("Scale to apply to Z data");
+    zscale_opt->guisection = _("Transform");
+    irange_opt = G_define_option();
+    irange_opt->key = "intensity_range";
+    irange_opt->type = TYPE_DOUBLE;
+    irange_opt->required = NO;
+    irange_opt->key_desc = "min,max";
+    irange_opt->description = _("Filter range for intensity values (min,max)");
+    irange_opt->guisection = _("Selection");
+    iscale_opt = G_define_option();
+    iscale_opt->key = "intensity_scale";
+    iscale_opt->type = TYPE_DOUBLE;
+    iscale_opt->required = NO;
+    iscale_opt->answer = "1.0";
+    iscale_opt->description = _("Scale to apply to intensity values");
+    iscale_opt->guisection = _("Transform");
     only_valid_flag = G_define_flag();
     only_valid_flag->key = 'v';
     only_valid_flag->label = _("Use only valid points");
@@ -231,29 +271,148 @@
           " filtered out");
     only_valid_flag->guisection = _("Selection");
+    over_flag = G_define_flag();
+    over_flag->key = 'o';
+    over_flag->label =
+        _("Override projection check (use current location's projection)");
+    over_flag->description =
+        _("Assume that the dataset has same projection as the current location");
+    print_flag = G_define_flag();
+    print_flag->key = 'p';
+    print_flag->description = _("Print LAS file info and exit");
+    print_flag->suppress_required = YES;
+    scan_flag = G_define_flag();
+    scan_flag->key = 's';
+    scan_flag->description = _("Scan data file for extent then exit");
+    scan_flag->suppress_required = YES;
+    shell_style = G_define_flag();
+    shell_style->key = 'g';
+    shell_style->description = _("In scan mode, print using shell script style");
+    shell_style->suppress_required = YES;
+    G_option_required(input_opt, file_list_opt, NULL);
+    G_option_exclusive(input_opt, file_list_opt, NULL);
     G_option_requires(base_rast_res_flag, base_raster_opt, NULL);
     if (G_parser(argc, argv))
         exit(EXIT_FAILURE);
+    if (shell_style->answer && !scan_flag->answer) {
+        scan_flag->answer = TRUE;
+    /* check intensity range and extent relation */
+    if (scan_flag->answer) {
+        if (irange_opt->answer)
+            G_warning(_("%s will not be taken into account during scan"), irange_opt->key);
     int only_valid = FALSE;
     if (only_valid_flag->answer)
         only_valid = TRUE;
+    struct StringList infiles;
+    if (file_list_opt->answer) {
+        if (access(file_list_opt->answer, F_OK) != 0)
+            G_fatal_error(_("File <%s> does not exist"), file_list_opt->answer);
+        string_list_from_file(&infiles, file_list_opt->answer);
+    else {
+        string_list_from_one_item(&infiles, input_opt->answer);
+    double zscale = 1.0;
+    double iscale = 1.0;
+    if (zscale_opt->answer)
+        zscale = atof(zscale_opt->answer);
+    if (iscale_opt->answer)
+        iscale = atof(iscale_opt->answer);
     LASReaderH LAS_reader;
     LASHeaderH LAS_header;
+    LASSRSH LAS_srs;
+    char *infile;
-    LAS_reader = LASReader_Create(input_opt->answer);
-    if (LAS_reader == NULL)
-        G_fatal_error(_("Unable to open file <%s>"), input_opt->answer);
-    LAS_header = LASReader_GetHeader(LAS_reader);
-    if  (LAS_header == NULL) {
+    /* for the CRS info */
+    const char *projstr;
+    struct Cell_head current_region;
+    struct Cell_head file_region;
+    G_get_set_window(&current_region);
+    /* extent for all data */
+    struct Cell_head data_region;
+    long unsigned header_count = 0;
+    int i;
+    for (i = 0; i < infiles.num_items; i++) {
+        infile = infiles.items[i];
+        /* don't if file not found */
+        if (access(infile, F_OK) != 0)
+            G_fatal_error(_("Input file <%s> does not exist"), infile);
+        /* Open LAS file*/
+        LAS_reader = LASReader_Create(infile);
+        if (LAS_reader == NULL)
+            G_fatal_error(_("Unable to open file <%s>"), infile);
+        LAS_header = LASReader_GetHeader(LAS_reader);
+        if  (LAS_header == NULL) {
             G_fatal_error(_("Input file <%s> is not a LAS LiDAR point cloud"),
-                            input_opt->answer);
+                            infile);
+        LAS_srs = LASHeader_GetSRS(LAS_header);
+        /* print info or check projection if we are actually importing */
+        if (print_flag->answer) {
+            /* print filename when there is more than one file */
+            if (infiles.num_items > 1)
+                fprintf(stdout, "File: %s\n", infile);
+            /* Print LAS header */
+            print_lasinfo(LAS_header, LAS_srs);
+        else {
+            /* report that we are checking more files */
+            if (i == 1)
+                G_message(_("First file's projection checked,"
+                            " checking projection of the other files..."));
+            /* Fetch input map projection in GRASS form. */
+            projstr = LASSRS_GetWKT_CompoundOK(LAS_srs);
+            /* we are printing the non-warning messages only for first file */
+            projection_check_wkt(file_region, current_region, projstr,
+                                 over_flag->answer, shell_style->answer || i);
+            /* if there is a problem in some other file, first OK message
+             * is printed but than a warning, this is not ideal but hopefully
+             * not so confusing when importing multiple files */
+            /* we assign to the first one (i==0) but update for the rest */
+            scan_bounds(LAS_reader, shell_style->answer, FALSE, i,
+                        zscale, &data_region);
+        /* number of estimated point across all files */
+        /* TODO: this should be ull which won't work with percent report */
+        header_count += LASHeader_GetPointRecordsCount(LAS_header);
+        /* We are closing all again and we will be opening them later,
+         * so we don't have to worry about limit for open files. */
+        LASSRS_Destroy(LAS_srs);
+        LASHeader_Destroy(LAS_header);
+        LASReader_Destroy(LAS_reader);
+    /* if we are not importing, end */
+    if (print_flag->answer || scan_flag->answer)
+        exit(EXIT_SUCCESS);
     Rast3d_init_defaults();
     Rast3d_set_error_fun(Rast3d_fatal_error_noargs);
+    double irange_min;
+    double irange_max;
+    int use_irange =
+        range_filter_from_option(irange_opt, &irange_min, &irange_max);
     struct ReturnFilter return_filter_struct;
     int use_return_filter =
         return_filter_create_from_string(&return_filter_struct,
@@ -291,6 +450,7 @@
     int type = FCELL_TYPE;
     int max_tile_size = 32;
+    /* TODO: this should probably happen before we change 2D region just to be sure */
     Rast3d_get_window(&binning.region);
     Rast3d_get_window(&binning.flat_region);
     binning.flat_region.depths = 1;
@@ -368,73 +528,88 @@
     long unsigned in_nulls = 0; /* or outside */
     long unsigned n_return_filtered = 0;
     long unsigned n_class_filtered = 0;
+    long unsigned irange_filtered = 0;
     long unsigned n_invalid = 0;
     long unsigned counter = 0;
-    long unsigned header_count = LASHeader_GetPointRecordsCount(LAS_header);
     G_verbose_message(_("Reading points..."));
     G_percent_reset();
-    while ((LAS_point = LASReader_GetNextPoint(LAS_reader)) != NULL) {
-        if (counter == 100000) {        /* report only some for speed */
-            if (inside < header_count)  /* TODO: inside can greatly underestimate */
-                G_percent(inside, header_count, 3);
-            counter = 0;
-        counter++;
-        /* We always count them and report because r.in.lidar behavior
-         * changed in between 7.0 and 7.2 from undefined (but skipping
-         * invalid points) to filtering them out only when requested. */
-        if (!LASPoint_IsValid(LAS_point)) {
-            n_invalid++;
-            if (only_valid)
-                continue;
-        if (use_return_filter) {
-            int return_n = LASPoint_GetReturnNumber(LAS_point);
-            int n_returns = LASPoint_GetNumberOfReturns(LAS_point);
-            if (return_filter_is_out(&return_filter_struct, return_n, n_returns)) {
-                n_return_filtered++;
-                continue;
+    /* loop of input files */
+        /* we already know file is there, so just do basic checks */
+            if (counter == 100000) {        /* report only some for speed */
+                if (inside < header_count)  /* TODO: inside can greatly underestimate */
+                    G_percent(inside, header_count, 3);
+                counter = 0;
-        if (use_class_filter) {
-            int point_class = (int) LASPoint_GetClassification(LAS_point);
-            if (class_filter_is_out(&class_filter, point_class)) {
-                n_class_filtered++;
+            counter++;
+            /* We always count them and report because r.in.lidar behavior
+             * changed in between 7.0 and 7.2 from undefined (but skipping
+             * invalid points) to filtering them out only when requested. */
+            if (!LASPoint_IsValid(LAS_point)) {
+                n_invalid++;
+                if (only_valid)
+                    continue;
+            if (use_return_filter) {
+                int return_n = LASPoint_GetReturnNumber(LAS_point);
+                int n_returns = LASPoint_GetNumberOfReturns(LAS_point);
+                if (return_filter_is_out(&return_filter_struct, return_n, n_returns)) {
+                    n_return_filtered++;
+                    continue;
+            if (use_class_filter) {
+                int point_class = (int) LASPoint_GetClassification(LAS_point);
+                if (class_filter_is_out(&class_filter, point_class)) {
+                    n_class_filtered++;
+                    continue;
+            value = LASPoint_GetIntensity(LAS_point);
+            value *= iscale;
+            if (use_irange && (value < irange_min || value > irange_max)) {
+                irange_filtered++;
                 continue;
-        east = LASPoint_GetX(LAS_point);
-        north = LASPoint_GetY(LAS_point);
-        top = LASPoint_GetZ(LAS_point);
+            east = LASPoint_GetX(LAS_point);
+            north = LASPoint_GetY(LAS_point);
+            top = LASPoint_GetZ(LAS_point);
+            top *= zscale;
-        if (use_segment) {
-            if (rast_segment_get_value_xy(&base_segment, &input_region,
-                                          base_raster_data_type, east, north,
-                                          &base_z)) {
-                top -= base_z;
+            if (use_segment) {
+                if (rast_segment_get_value_xy(&base_segment, &input_region,
+                                              base_raster_data_type, east, north,
+                                              &base_z)) {
+                    top -= base_z;
+                else {
+                    /* TODO: separate message for this */
+                    in_nulls += 1;
+                    continue;
-            else {
-                in_nulls += 1;
+            Rast3d_location2coord(&binning.region, north, east, top, &col, &row,
+                                  &depth);
+            if (col >= binning.region.cols || row >= binning.region.rows ||
+                depth >= binning.region.depths || col < 0 || row < 0 ||
+                depth < 0) {
+                outside += 1;
                 continue;
+            binning_add_point(binning, row, col, depth, value);
+            inside += 1;
-        Rast3d_location2coord(&binning.region, north, east, top, &col, &row,
-                              &depth);
-        if (col >= binning.region.cols || row >= binning.region.rows ||
-            depth >= binning.region.depths || col < 0 || row < 0 ||
-            depth < 0) {
-            outside += 1;
-            continue;
-        value = LASPoint_GetIntensity(LAS_point);
-        binning_add_point(binning, row, col, depth, value);
-        inside += 1;
+        /* close input LAS file */
+    /* end of loop for all input files */
     G_percent(1, 1, 1);    /* flush */
@@ -483,6 +658,8 @@
         G_message(_("%lu input points were filtered out by return number"), n_return_filtered);
     if (n_class_filtered)
         G_message(_("%lu input points were filtered out by class number"), n_class_filtered);
+    if (irange_filtered)
+        G_message(_("%lu input points had intensity out of range"), irange_filtered);
     if (n_invalid && !only_valid)
         G_message(_("%lu input points were not valid, use -%c flag to filter"
                     " them out"), n_invalid, only_valid_flag->key);
Copied: grass/trunk/raster3d/r3.in.lidar/projection.c (from rev 69373, grass/trunk/raster/r.in.lidar/projection.c)
--- grass/trunk/raster3d/r3.in.lidar/projection.c	                        (rev 0)
+++ grass/trunk/raster3d/r3.in.lidar/projection.c	2016-09-06 00:50:49 UTC (rev 69379)
@@ -0,0 +1,144 @@
+ * lidar-related projection functions
+ * Authors:
+#include <grass/gprojects.h>
+void projection_mismatch_report(struct Cell_head cellhd,
+                                struct Cell_head loc_wind,
+                                struct Key_Value *loc_proj_info,
+                                struct Key_Value *loc_proj_units,
+                                struct Key_Value *proj_info,
+                                struct Key_Value *proj_units, int err)
+    int i_value;
+    char error_msg[8192];
+    strcpy(error_msg,
+           _("Projection of dataset does not"
+             " appear to match current location.\n\n"));
+    /* TODO: output this info sorted by key: */
+    if (loc_wind.proj != cellhd.proj || err != -2) {
+        if (loc_proj_info != NULL) {
+            strcat(error_msg, _("GRASS LOCATION PROJ_INFO is:\n"));
+            for (i_value = 0; i_value < loc_proj_info->nitems; i_value++)
+                sprintf(error_msg + strlen(error_msg), "%s: %s\n",
+                        loc_proj_info->key[i_value],
+                        loc_proj_info->value[i_value]);
+            strcat(error_msg, "\n");
+        if (proj_info != NULL) {
+            strcat(error_msg, _("Import dataset PROJ_INFO is:\n"));
+            for (i_value = 0; i_value < proj_info->nitems; i_value++)
+                        proj_info->key[i_value], proj_info->value[i_value]);
+        else {
+            if (cellhd.proj == PROJECTION_XY)
+                        "Dataset proj = %d (unreferenced/unknown)\n",
+                        cellhd.proj);
+            else if (cellhd.proj == PROJECTION_LL)
+                        "Dataset proj = %d (lat/long)\n", cellhd.proj);
+            else if (cellhd.proj == PROJECTION_UTM)
+                        "Dataset proj = %d (UTM), zone = %d\n",
+                        cellhd.proj, cellhd.zone);
+            else
+                        "Dataset proj = %d (unknown), zone = %d\n",
+    else {
+        if (loc_proj_units != NULL) {
+            strcat(error_msg, "GRASS LOCATION PROJ_UNITS is:\n");
+            for (i_value = 0; i_value < loc_proj_units->nitems; i_value++)
+                        loc_proj_units->key[i_value],
+                        loc_proj_units->value[i_value]);
+        if (proj_units != NULL) {
+            strcat(error_msg, "Import dataset PROJ_UNITS is:\n");
+            for (i_value = 0; i_value < proj_units->nitems; i_value++)
+                        proj_units->key[i_value], proj_units->value[i_value]);
+            _("\nIn case of no significant differences in the projection definitions,"
+             " use the -o flag to ignore them and use"
+             " current location definition.\n"));
+    strcat(error_msg,
+           _("Consider generating a new location with 'location' parameter"
+             " from input data set.\n"));
+    G_fatal_error("%s", error_msg);
+void projection_check_wkt(struct Cell_head cellhd,
+                          const char *projstr, int override, int verbose)
+    struct Key_Value *loc_proj_info = NULL, *loc_proj_units = NULL;
+    struct Key_Value *proj_info, *proj_units;
+    int err = 0;
+    proj_info = NULL;
+    proj_units = NULL;
+    /* Projection only required for checking so convert non-interactively */
+    if (GPJ_wkt_to_grass(&cellhd, &proj_info, &proj_units, projstr, 0) < 0)
+        G_warning(_("Unable to convert input map projection information to "
+                    "GRASS format for checking"));
+    /* Does the projection of the current location match the dataset? */
+    /* fetch LOCATION PROJ info */
+    if (loc_wind.proj != PROJECTION_XY) {
+        loc_proj_info = G_get_projinfo();
+        loc_proj_units = G_get_projunits();
+    if (override) {
+        cellhd.proj = loc_wind.proj;
+        cellhd.zone = loc_wind.zone;
+        if (verbose)
+            G_message(_("Over-riding projection check"));
+    else if (loc_wind.proj != cellhd.proj
+             || (err =
+                 G_compare_projections(loc_proj_info, loc_proj_units,
+                                       proj_info, proj_units)) != TRUE) {
+        projection_mismatch_report(cellhd, loc_wind, loc_proj_info,
+                                   loc_proj_units,
+                                   proj_info, proj_units, err);
+    else if (verbose) {
+        G_message(_("Projection of input dataset and current location "
+                    "appear to match"));
Added: grass/trunk/raster3d/r3.in.lidar/projection.h
--- grass/trunk/raster3d/r3.in.lidar/projection.h	                        (rev 0)
+++ grass/trunk/raster3d/r3.in.lidar/projection.h	2016-09-06 00:50:49 UTC (rev 69379)
@@ -0,0 +1,34 @@
+ * Authors:
+#ifndef __PROJECTION_H__
+#define __PROJECTION_H__
+                                int err);
+                          int override,
+                          int verbose);
+#endif /* __PROJECTION_H__ */
Property changes on: grass/trunk/raster3d/r3.in.lidar/projection.h
   + text/x-chdr
   + native
Modified: grass/trunk/raster3d/r3.in.lidar/rast_segment.c
--- grass/trunk/raster3d/r3.in.lidar/rast_segment.c	2016-09-05 16:16:36 UTC (rev 69378)
+++ grass/trunk/raster3d/r3.in.lidar/rast_segment.c	2016-09-06 00:50:49 UTC (rev 69379)
@@ -1,4 +1,17 @@
+ * segment library convenient wrapper functions
+ * Authors:
+ *  Vaclav Petras
+ * Copyright 2015 by Vaclav Petras, and the GRASS Development Team
Modified: grass/trunk/raster3d/r3.in.lidar/rast_segment.h
--- grass/trunk/raster3d/r3.in.lidar/rast_segment.h	2016-09-05 16:16:36 UTC (rev 69378)
+++ grass/trunk/raster3d/r3.in.lidar/rast_segment.h	2016-09-06 00:50:49 UTC (rev 69379)
@@ -1,3 +1,17 @@
+ * Authors:
+ *  Vaclav Petras
 #ifndef GRASS_RAST_SEGMENT_H
 #define GRASS_RAST_SEGMENT_H
Copied: grass/trunk/raster3d/r3.in.lidar/string_list.c (from rev 69373, grass/trunk/raster/r.in.lidar/string_list.c)
--- grass/trunk/raster3d/r3.in.lidar/string_list.c	                        (rev 0)
+++ grass/trunk/raster3d/r3.in.lidar/string_list.c	2016-09-06 00:50:49 UTC (rev 69379)
@@ -0,0 +1,78 @@
+ * Functionality to handle list of strings
+ * Authors:
+ *  Vaclav Petras
+#include <stdio.h>
+#define SIZE_INCREMENT 10
+static int string_list_add_item(struct StringList *string_list, char *item)
+    int n = string_list->num_items++;
+    if (string_list->num_items >= string_list->max_items) {
+        string_list->max_items += SIZE_INCREMENT;
+        string_list->items = G_realloc(string_list->items,
+                                       (size_t) string_list->max_items *
+                                       sizeof(char *));
+    /* n contains the index */
+    string_list->items[n] = item;
+    return n;
+void string_list_from_file(struct StringList *string_list, char *filename)
+    string_list->num_items = 0;
+    string_list->max_items = 0;
+    string_list->items = NULL;
+    FILE *file = fopen(filename, "r");  /* should check the result */
+    if (!file)
+        G_fatal_error(_("Cannot open file %s for reading"), filename);
+    char *line = G_malloc(GPATH_MAX * sizeof(char));
+    while (G_getl2(line, GPATH_MAX * sizeof(char), file)) {
+        G_debug(5, "line content from file %s: %s\n", filename, line);
+        string_list_add_item(string_list, line);
+        line = G_malloc(GPATH_MAX);
+    /* last allocation was not necessary */
+    G_free(line);
+    fclose(file);
+void string_list_from_one_item(struct StringList *string_list, char *item)
+    string_list_add_item(string_list, strdup(item));
+void string_list_free(struct StringList *string_list)
+    int i;
+    for (i = 0; i < string_list->num_items; i++)
+        G_free(string_list->items[i]);
+    G_free(string_list->items);
Added: grass/trunk/raster3d/r3.in.lidar/string_list.h
--- grass/trunk/raster3d/r3.in.lidar/string_list.h	                        (rev 0)
+++ grass/trunk/raster3d/r3.in.lidar/string_list.h	2016-09-06 00:50:49 UTC (rev 69379)
@@ -0,0 +1,31 @@
+ * Authors:
+ *  Vaclav Petras
+#ifndef __STRING_LIST_H__
+#define __STRING_LIST_H__
+/* multiple files */
+struct StringList
+    int num_items;
+    int max_items;
+    char **items;
+void string_list_from_file(struct StringList *string_list, char *filename);
+void string_list_from_one_item(struct StringList *string_list, char *item);
+void string_list_free(struct StringList *string_list);
+#endif /* __STRING_LIST_H__ */
Property changes on: grass/trunk/raster3d/r3.in.lidar/string_list.h
   + text/x-chdr
   + native
