[GRASS-SVN] r69467 - grass-addons/grass7/raster/r.object.geometry
svn_grass at osgeo.org
Tue Sep 13 05:50:15 PDT 2016
Author: mlennert
Date: 2016-09-13 05:50:15 -0700 (Tue, 13 Sep 2016)
New Revision: 69467
grass-addons/grass7/raster/r.object.geometry/r.object.geometry.html
r.object.geometry: explain output to standard output in manual
Modified: grass-addons/grass7/raster/r.object.geometry/r.object.geometry.html
--- grass-addons/grass7/raster/r.object.geometry/r.object.geometry.html 2016-09-13 12:44:08 UTC (rev 69466)
+++ grass-addons/grass7/raster/r.object.geometry/r.object.geometry.html 2016-09-13 12:50:15 UTC (rev 69467)
@@ -2,7 +2,8 @@
<p>
<em>r.object.geometry</em> calculates form statistics of raster objects
-in the <em>input</em> map and writes it to the <em>output</em> text file,
+in the <em>input</em> map and writes it to the <em>output</em> text file
+ (or standard output if no output filename or '-' is given),
with fields separated by the chosen <em>separator</em>. Objects are defined
as clumps of adjacent cells with the same category value (e.g. output of
<a href="r.clump.html">r.clump</a> or <a href="i.segment.html">i.segment</a>).
