[GRASS-SVN] r69468 - grass-promo/grassflyer/flyer_2016
svn_grass at osgeo.org
Tue Sep 13 08:25:01 PDT 2016
Author: neteler
Date: 2016-09-13 08:25:01 -0700 (Tue, 13 Sep 2016)
New Revision: 69468
grass-promo/grassflyer/flyer_2016/README
grassflyer 2016 README: restore font info (deleted in r69463)
Modified: grass-promo/grassflyer/flyer_2016/README
--- grass-promo/grassflyer/flyer_2016/README 2016-09-13 12:50:15 UTC (rev 69467)
+++ grass-promo/grassflyer/flyer_2016/README 2016-09-13 15:25:01 UTC (rev 69468)
@@ -1,12 +1,37 @@
-Note to translators:
-this is a new version of the GRASS GIS flyer. The format is svg, you can view the file with a graphics editor like Inkscape.
+Font: Fira Sans
+---> mozilla-fira-sans-fonts
-English, french, and partially italian versions are already achieved. You are very welcome to add your translator's contributions !
+Font installation
+- Fedora:
+ dnf install mozilla-fira-sans-fonts
-Dealing with graphics files is not as easy to handle as editing classical localization files. Fortunately SVG is an application of XML, supporting its formalism and the UTF-8 character set, thus quite well adapted to textual editing.
+- Ubuntu:
+ cd /tmp
+ wget https://github.com/mozilla/Fira/archive/master.zip # 102 MB
+ unzip master.zip
+ sudo mkdir -p /usr/share/fonts/truetype/fira
+ sudo cp Fira-master/ttf/* /usr/share/fonts/truetype/fira/
+ rm -rf /tmp/master.zip /tmp/Fira-master
-In order to preserve the original document settings, I think it would be better to avoid editing the file from within e.g. Inkscape, but rather add translated chains through a text editor, or better via a dedicated solution like OmegaT[1]. It provides a rather convenient/intuitive GUI to access strings to translate.
-The two-sided document is given a certain page layout. Text blocks are not much expandable : please when translating keep in mind this constraint and try to be as concise as english (I know it's a bit challenging).
+Note to translators
-[1]www.omegat.org/
\ No newline at end of file
+by Vincent Bain
+This is a new version of the GRASS GIS flyer. The format is svg, you can view the file with a graphics editor like Inkscape.
+English, French, and partially Italian versions are already achieved. You are very welcome to add your translator's contributions !
+Dealing with graphics files is not as easy to handle as editing classical localization files. Fortunately SVG is an application
+of XML, supporting its formalism and the UTF-8 character set, thus quite well adapted to textual editing.
+In order to preserve the original document settings, I think it would be better to avoid editing the file from within e.g. Inkscape, but
+rather add translated chains through a text editor, or better via a dedicated solution like OmegaT[1].
+It provides a rather convenient/intuitive GUI to access strings to translate.
+The two-sided document is given a certain page layout. Text blocks are not much expandable : please when translating keep in mind
+this constraint and try to be as concise as English (I know it's a bit challenging).
+[1] http://www.omegat.org/
