[GRASS-SVN] r69546 - grass/trunk/vector/v.out.ogr
Thu Sep 22 05:05:19 PDT 2016
Author: mmetz
Date: 2016-09-22 05:05:19 -0700 (Thu, 22 Sep 2016)
New Revision: 69546
   grass/trunk/vector/v.out.ogr/export_areas.c
v.out.ogr: fix r58447 (#3165)
Modified: grass/trunk/vector/v.out.ogr/export_areas.c
--- grass/trunk/vector/v.out.ogr/export_areas.c	2016-09-21 22:09:34 UTC (rev 69545)
+++ grass/trunk/vector/v.out.ogr/export_areas.c	2016-09-22 12:05:19 UTC (rev 69546)
@@ -43,8 +43,8 @@
                         const char **colname, int doatt, int nocat,
                         int *n_noatt, int *n_nocat)
-    int i, j;
-    int centroid, cat, area, n_areas;
+    int i;
+    int cat, area, n_areas;
     int n_exported;
     struct line_pnts *Points;
@@ -59,28 +59,21 @@
     n_exported = 0;
     n_areas = Vect_get_num_areas(In);
-    for (i = 1; i <= n_areas; i++) {
-        G_percent(i, n_areas, 5);
+    for (area = 1; area <= n_areas; area++) {
+        G_percent(area, n_areas, 5);
-        /* get centroid's category */
-        centroid = Vect_get_area_centroid(In, i);
+        /* get area's category */
+        Vect_get_area_cats(In, area, Cats);
         cat = -1;
-        if (centroid > 0) {
-            Vect_read_line(In, NULL, Cats, centroid);
+        if (Cats->n_cats > 0) {
             Vect_cat_get(Cats, field, &cat);
-        G_debug(3, "area = %d centroid = %d ncats = %d", i, centroid,
-                Cats->n_cats);
+        G_debug(3, "area = %d ncats = %d", area, Cats->n_cats);
         if (cat < 0 && !donocat) {
             (*n_nocat)++;
             continue; /* skip areas without category, do not export
                        * not labeled */
-        /* find corresponding area */
-        area = Vect_get_centroid_area(In, centroid);
-        if (area == 0)
-            continue;
         /* create polygon from area */
         Ogr_geometry = create_polygon(In, area, Points);
@@ -90,15 +83,15 @@
         OGR_F_SetGeometry(Ogr_feature, Ogr_geometry);
         /* output one feature for each category */
-        for (j = -1; j < Cats->n_cats; j++) {
-            if (j == -1) {
+        for (i = -1; i < Cats->n_cats; i++) {
+            if (i == -1) {
                 if (cat >= 0)
                     continue;	/* cat(s) exists */
 		(*n_nocat)++;
             else {
-                if (Cats->field[j] == field)
-                    cat = Cats->cat[j];
+                if (Cats->field[i] == field)
+                    cat = Cats->cat[i];
                 else
                     continue;
@@ -186,7 +179,7 @@
             area = Vect_get_centroid_area(In, line);
-            if (area == 0)
+            if (area <= 0)
                 continue;
@@ -224,6 +217,9 @@
      * one multi-feature */
     Ogr_geometry = OGR_G_CreateGeometry(wkbtype);
+    /* TODO: if donocat, also export areas without centroid
+     * -> loop over areas, not centroids */
     Vect_rewind(In);
     Vect_set_constraint_type(In, GV_CENTROID);
     while(TRUE) {
@@ -244,7 +240,7 @@
 	line = Vect_get_next_line_id(In);
-        if (area == 0)
+        if (area <= 0)
             continue;
