[GRASS-SVN] r69547 - grass/branches/releasebranch_7_2/vector/v.out.ogr
svn_grass at osgeo.org
Thu Sep 22 05:05:57 PDT 2016
Author: mmetz
Date: 2016-09-22 05:05:57 -0700 (Thu, 22 Sep 2016)
New Revision: 69547
grass/branches/releasebranch_7_2/vector/v.out.ogr/export_areas.c
v.out.ogr: fix r58447 (#3165), backport form trunk r69546
Modified: grass/branches/releasebranch_7_2/vector/v.out.ogr/export_areas.c
--- grass/branches/releasebranch_7_2/vector/v.out.ogr/export_areas.c 2016-09-22 12:05:19 UTC (rev 69546)
+++ grass/branches/releasebranch_7_2/vector/v.out.ogr/export_areas.c 2016-09-22 12:05:57 UTC (rev 69547)
@@ -43,8 +43,8 @@
const char **colname, int doatt, int nocat,
int *n_noatt, int *n_nocat)
- int i, j;
- int centroid, cat, area, n_areas;
+ int i;
+ int cat, area, n_areas;
int n_exported;
struct line_pnts *Points;
@@ -59,28 +59,21 @@
n_exported = 0;
n_areas = Vect_get_num_areas(In);
- for (i = 1; i <= n_areas; i++) {
- G_percent(i, n_areas, 5);
+ for (area = 1; area <= n_areas; area++) {
+ G_percent(area, n_areas, 5);
- /* get centroid's category */
- centroid = Vect_get_area_centroid(In, i);
+ /* get area's category */
+ Vect_get_area_cats(In, area, Cats);
cat = -1;
- if (centroid > 0) {
- Vect_read_line(In, NULL, Cats, centroid);
+ if (Cats->n_cats > 0) {
Vect_cat_get(Cats, field, &cat);
- G_debug(3, "area = %d centroid = %d ncats = %d", i, centroid,
- Cats->n_cats);
+ G_debug(3, "area = %d ncats = %d", area, Cats->n_cats);
if (cat < 0 && !donocat) {
(*n_nocat)++;
continue; /* skip areas without category, do not export
* not labeled */
- /* find corresponding area */
- area = Vect_get_centroid_area(In, centroid);
- if (area == 0)
- continue;
/* create polygon from area */
Ogr_geometry = create_polygon(In, area, Points);
@@ -90,15 +83,15 @@
OGR_F_SetGeometry(Ogr_feature, Ogr_geometry);
/* output one feature for each category */
- for (j = -1; j < Cats->n_cats; j++) {
- if (j == -1) {
+ for (i = -1; i < Cats->n_cats; i++) {
+ if (i == -1) {
if (cat >= 0)
continue; /* cat(s) exists */
(*n_nocat)++;
else {
- if (Cats->field[j] == field)
- cat = Cats->cat[j];
+ if (Cats->field[i] == field)
+ cat = Cats->cat[i];
else
continue;
@@ -186,7 +179,7 @@
area = Vect_get_centroid_area(In, line);
- if (area == 0)
+ if (area <= 0)
continue;
@@ -224,6 +217,9 @@
* one multi-feature */
Ogr_geometry = OGR_G_CreateGeometry(wkbtype);
+ /* TODO: if donocat, also export areas without centroid
+ * -> loop over areas, not centroids */
Vect_rewind(In);
Vect_set_constraint_type(In, GV_CENTROID);
while(TRUE) {
@@ -244,7 +240,7 @@
line = Vect_get_next_line_id(In);
- if (area == 0)
+ if (area <= 0)
continue;
