[GRASS-SVN] r70825 - in grass-addons/grass7/raster: . r.sun.mp
Sun Apr 2 21:54:36 PDT 2017
Author: jhofier
Date: 2017-04-02 21:54:36 -0700 (Sun, 02 Apr 2017)
New Revision: 70825
Added:
   grass-addons/grass7/raster/r.sun.mp/
   grass-addons/grass7/raster/r.sun.mp/Makefile
   grass-addons/grass7/raster/r.sun.mp/README
   grass-addons/grass7/raster/r.sun.mp/TODO
   grass-addons/grass7/raster/r.sun.mp/dalloc.c
   grass-addons/grass7/raster/r.sun.mp/description-pak
   grass-addons/grass7/raster/r.sun.mp/local_proto.h
   grass-addons/grass7/raster/r.sun.mp/main.c
   grass-addons/grass7/raster/r.sun.mp/r.sun.mp.html
   grass-addons/grass7/raster/r.sun.mp/rsunglobals.h
   grass-addons/grass7/raster/r.sun.mp/rsunlib.c
   grass-addons/grass7/raster/r.sun.mp/sunradstruct.h
r.sun with openmp suppport
Added: grass-addons/grass7/raster/r.sun.mp/Makefile
--- grass-addons/grass7/raster/r.sun.mp/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.sun.mp/Makefile	2017-04-03 04:54:36 UTC (rev 70825)
@@ -0,0 +1,14 @@
+MODULE_TOPDIR = ../..
+PGM = r.sun.mp
+LIBES = $(GPROJLIB) $(RASTERLIB) $(GISLIB) $(MATHLIB) $(PROJLIB)
+DEPENDENCIES = $(GPROJDEP) $(RASTERDEP) $(GISDEP)
+EXTRA_INC = $(PROJINC) $(OCLINCPATH)
+EXTRA_CFLAGS=-fopenmp
+EXTRA_LIBS = $(OCLLIB) $(GISLIB) -lgomp $(MATHLIB)
+#needed?  LIBES += $(OCLLIBPATH)  or  EXTRA_LDFLAGS = $(OCLLIBPATH)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/grass7/raster/r.sun.mp/README
--- grass-addons/grass7/raster/r.sun.mp/README	                        (rev 0)
+++ grass-addons/grass7/raster/r.sun.mp/README	2017-04-03 04:54:36 UTC (rev 70825)
@@ -0,0 +1,81 @@
+From Thomas.Huld jrc.it Thu Jul 26 11:01:44 2007
+To: Markus Neteler <neteler itc.it>
+CC: Jaro Hofierka <hofierka geomodel.sk>, "marcel.suri jrc.it"
+        <marcel.suri jrc.it>, Tomas Cebecauer <tomas.cebecauer jrc.it>
+Date: Thu, 26 Jul 2007 11:01:44 +0200
+Subject: Re: r.horizon source code
+Lines: 1533
+I'm sending the r.sun sources to you here, even though the description is not
+yet up to date. I think it works OK now, though I haven't tried all possible
+combinations of options. For instance, I haven't ever used the incidence
+angle or insolation time outputs. There's no reason why they should have
+stopped working but there are always changes that break something unexpected.
+The main changes  are:
+- possibility to read in horizon rasters to use with the shadow calculation.
+- Calculation of the shadowing effect should now also work in lat/lon
+projection.
+- There was a bug in r.sun whereby the shadowing effect was calculated wrong
+when the left-right and up-down directions in the projection are different
+from east-west and north-south, as is the case in the projection we use
+(Lambert Azimuthal) when moving away from the point of origin. This has been
+fixed now though only checked with Lambert Azimuthal.
+- I'm not sure if this went in already in a previous version, but the
+algorithm now also takes into account the curvature of the earth when
+calculating shadows.
+- new output possibility: glob_rad, which is the sum of the three radiation
+components
+- new input parameter: <i>civiltime</i>. When this parameter is given, the
+single time calculation will calculate the irradiance at the *same* time for
+the entire raster instead of using the local solar time. The value of
+<i>civiltime</i> is the timezone, relative to GMT. (+1 for central Europe)
+- new input parameter <i>numpartitions</i> No change in the calculation
+methods, but the program will read the input rasters and do the calculations
+in a number of chunks, instead of reading in everything at the start. Output
+is still only at the very end. This is only to save memory. It will not work
+if you try to calculate shadows without the horizon information, and the
+program will tell you so.
+- I reorganized the source code quite a lot. In particular, I spun off several
+functions into a separate source file called rsunlib.c. I also organized many
+of the global variables into <i>struct</i>'s for an easier overview. I did
+this because we work here with several derivatives of r.sun:
+	* r.sunyear which calculates the optimum inclination angle for maximum
+insolation
+	* r.pv which calculates the PV output taking into account also temperature
+effects
+	* r.sun.2axis which is r.sun for a moving plane, whose normal always points
+to the sun (two-axis tracking solar energy systems).
+Splitting the source code made it easier to reuse bits for these r.sun
+derivatives. I haven't updated the Makefile to account for these changes yet.
+Look at the little script  "compdebug" in the source directory.
+There may be other changes that I've forgotten about but nothing dramatic.
+Have fun!
+Thomas
+Thomas Huld
+Joint Research Centre of the European Commission
+T.P. 450
+I-21020 Ispra, Italy
+phone: +39 0332785273
+e-mail: Thomas.Huld at jrc.it
Added: grass-addons/grass7/raster/r.sun.mp/TODO
--- grass-addons/grass7/raster/r.sun.mp/TODO	                        (rev 0)
+++ grass-addons/grass7/raster/r.sun.mp/TODO	2017-04-03 04:54:36 UTC (rev 70825)
@@ -0,0 +1,34 @@
+TODO
+Probably the sun position calculation shouldbe replaced
+with
+ G_calc_solar_position()
+currently used in r.sunmask. G_calc_solar_position() is based on
+solpos.c from NREL and very precise.
+MN 4/2001
+Update
+  http://grasswiki.osgeo.org/wiki/R.sun
+Fix http://trac.osgeo.org/grass/ticket/498
+pseudo-data test-case
+http://trac.osgeo.org/grass/ticket/498#comment:22
+#spearfish (further north than NC so more defined shadows)
+g.region -d
+r.mapcalc "undulates = (2 + sin( row() * 2 ) + cos( col() * 2 )) * 500"
+r.colors undulates color=bcyr
+nviz undulates
+DAY=355
+time r.sun elevin=undulates day=$DAY step=0.05 \
+  beam_rad=rad_test.und.355.beam \
+  diff_rad=rad_test.und.355.diff \
+  refl_rad=rad_test.und.355.refl
Added: grass-addons/grass7/raster/r.sun.mp/dalloc.c
--- grass-addons/grass7/raster/r.sun.mp/dalloc.c	                        (rev 0)
+++ grass-addons/grass7/raster/r.sun.mp/dalloc.c	2017-04-03 04:54:36 UTC (rev 70825)
@@ -0,0 +1,197 @@
+ * \file dalloc.c
+ * \brief Matrix memory management functions.
+ * This program is free software; you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License as published by
+ * the Free Software Foundation; either version 2 of the License, or (at
+ * your option) any later version.
+ * This program is distributed in the hope that it will be useful, but
+ * WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+ * General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with this program; if not, write to the Free Software
+ * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+ * \author GRASS GIS Development Team
+ * \date 2004-2006
+#include <stdlib.h>
+#include <grass/gis.h>
+ * \fn double *G_alloc_vector (size_t n)
+ * \brief Vector matrix memory allocation.
+ * Allocate a vector (array) of <b>n</b> doubles initialized to zero.
+ * \param[in] n size of vector to allocate
+ * \return double *
+double *G_alloc_vector(size_t n)
+    return (double *)G_calloc(n, sizeof(double));
+ * \fn double **G_alloc_matrix (int rows,int cols)
+ * \brief Matrix memory allocation.
+ * Allocate a matrix of <b>rows</b> by <b>cols</b> doubles initialized
+ * to zero.
+ * \param[in] rows number of rows in matrix
+ * \param[in] cols number of columns in matrix
+ * \return double **
+double **G_alloc_matrix(int rows, int cols)
+    double **m;
+    int i;
+    m = (double **)G_calloc(rows, sizeof(double *));
+    m[0] = (double *)G_calloc((size_t) rows * cols, sizeof(double));
+    for (i = 1; i < rows; i++)
+	m[i] = m[i - 1] + cols;
+    return m;
+ * \fn float *G_alloc_fvector (size_t n)
+ * \brief Floating point vector memory allocation.
+ * Allocate a vector (array) of <b>n</b> floats initialized to zero.
+ * \return float *
+float *G_alloc_fvector(size_t n)
+    return (float *)G_calloc(n, sizeof(float));
+ * \fn float **G_alloc_fmatrix (int rows, int cols)
+ * \brief Floating point matrix memory allocation.
+ * Allocate a matrix of <b>rows</b> by <b>cols</b> floats initialized
+ * to zero.
+ *  \return float **
+float **G_alloc_fmatrix(int rows, int cols)
+    float **m;
+    int i;
+    m = (float **)G_calloc(rows, sizeof(float *));
+    m[0] = (float *)G_calloc((size_t) rows * cols, sizeof(float));
+    return m;
+ * \fn void G_free_vector (double *v)
+ * \brief Vector memory deallocation.
+ * Deallocate a vector (array) of doubles.
+ *  \param[in,out] v vector to free
+ *  \return void
+void G_free_vector(double *v)
+    G_free(v);
+    v = NULL;
+    return;
+ * \fn void G_free_fvector (float *v)
+ * Deallocate a vector (array) of floats.
+ *  \return void
+void G_free_fvector(float *v)
+    G_free(v);
+    v = NULL;
+    return;
+ * \fn void G_free_matrix (double **m)
+ * \brief Matrix memory deallocation.
+ * Deallocate a matrix of doubles.
+ *  \param[in,out] m matrix to free
+ *  \return void
+void G_free_matrix(double **m)
+    G_free(m[0]);
+    G_free(m);
+    m = NULL;
+    return;
+ * \fn void G_free_fmatrix (float **m)
+ * \brief Floating point matrix memory deallocation.
+ * Deallocate a matrix of floats.
+ *  \return void
+void G_free_fmatrix(float **m)
+    G_free(m[0]);
+    G_free(m);
+    m = NULL;
+    return;
Added: grass-addons/grass7/raster/r.sun.mp/description-pak
--- grass-addons/grass7/raster/r.sun.mp/description-pak	                        (rev 0)
+++ grass-addons/grass7/raster/r.sun.mp/description-pak	2017-04-03 04:54:36 UTC (rev 70825)
@@ -0,0 +1 @@
+Package created with checkinstall 1.6.2
Added: grass-addons/grass7/raster/r.sun.mp/local_proto.h
--- grass-addons/grass7/raster/r.sun.mp/local_proto.h	                        (rev 0)
+++ grass-addons/grass7/raster/r.sun.mp/local_proto.h	2017-04-03 04:54:36 UTC (rev 70825)
@@ -0,0 +1,180 @@
+/* main.c */
+void where_is_point(double *length, struct SunGeometryVarDay *sunVarGeom,
+		    struct GridGeometry *gridGeom);
+void where_is_point_parallel(double *length, double *sunVarGeom_zp,
+                            double *gridGeom_xx0,
+                            double *gridGeom_yy0,
+                            double *gridGeom_xg0,
+                            double *gridGeom_yg0,
+                            double *gridGeom_stepx,
+                            double *gridGeom_stepy);
+int searching(double *length, struct SunGeometryVarDay *sunVarGeom,
+int searching_parallel(double *length,
+                        double *sunVarGeom_z_orig,
+                        double *sunVarGeom_zmax,
+                        double *sunVarGeom_zp,
+                        double *sunVarGeom_tanSolarAltitude,
+                        double *sunVarGeom_stepsinangle,
+                        double *sunVarGeom_stepcosangle,
+                        double *gridGeom_stepy,
+                        double *gridGeom_deltx,
+                        double *gridGeom_delty);
+int useCivilTime();
+void setUseCivilTime(int val);
+int useShadow();
+void setUseShadow(int val);
+int useShadowData();
+void setUseShadowData(int val);
+int useHorizonData();
+void setUseHorizonData(int val);
+double getTimeOffset();
+void setTimeOffset(double val);
+double getHorizonInterval();
+void setHorizonInterval(double val);
+void setAngularLossDenominator();
+void cube(int, int);
+double com_sol_const(int no_of_day);
+double brad(double, double *bh, struct SunGeometryVarDay *sunVarGeom,
+	    struct SunGeometryVarSlope *sunSlopeGeom,
+	    struct SolarRadVar *sunRadVar);
+double brad_parallel(double sh, double *bh,
+                    double *sunVarGeom_solarAltitude,
+                    double *sunVarGeom_sinSolarAltitude,
+                    double *sunSlopeGeom_slope,
+                    double *sunSlopeGeom_aspect,
+                    double *sunRadVar_cbh,
+                    double *sunRadVar_linke,
+                    double *sunRadVar_G_norm_extra);
+double drad(double, double bh, double *rr,
+	    struct SunGeometryVarDay *sunVarGeom,
+double drad_parallel(double sh, double bh, double *rr,
+                    int *sunVarGeom_isShadow,
+                    double *sunVarGeom_solarAzimuth,
+                    double *sunRadVar_cdh,
+                    double *sunRadVar_G_norm_extra,
+                    double *sunRadVar_alb);
+double brad_angle_loss(double, double *bh,
+double drad_angle_loss(double, double bh, double *rr,
+void com_par(struct SunGeometryConstDay *sungeom,
+	     struct GridGeometry *gridGeom,
+	     double latitude, double longitude);
+void com_par_parallel(double *sunGeom_lum_C11,
+                    double *sunGeom_lum_C13,
+                    double *sunGeom_lum_C22,
+                    double *sunGeom_lum_C31,
+                    double *sunGeom_lum_C33,
+                    double *sunGeom_sunrise_time,
+                    double *sunGeom_sunset_time,
+                    double *sunGeom_timeAngle,
+                    double *sunVarGeom_sunAzimuthAngle,
+                    double *gridGeom_stepxy,
+                    double latitude);
+void com_par_const(double longitTime, struct SunGeometryConstDay *sungeom,
+void com_par_const_parallel(double longitTime,
+                    double *sunGeom_lum_C11,
+                    double *sunGeom_sindecl,
+                    double *sunGeom_cosdecl,
+                    double *gridGeom_sinlat,
+                    double *gridGeom_coslat);
+double lumcline2(struct SunGeometryConstDay *sungeom,
+		 unsigned char *horizonpointer);
+double lumcline2_parallel(double *sunGeom_timeAngle,
+                        double *sunSlopeGeom_longit_l,
+                        double *sunSlopeGeom_lum_C31_l,
+                        double *sunSlopeGeom_lum_C33_l,
+                        double *gridGeom_delty,
+typedef double (*BeamRadFunc) (double sh, double *bh,
+			       struct SunGeometryVarDay * sunVarGeom,
+			       struct SunGeometryVarSlope * sunSlopeGeom,
+			       struct SolarRadVar * sunRadVar);
+typedef double (*DiffRadFunc) (double sh, double bh, double *rr,
Added: grass-addons/grass7/raster/r.sun.mp/main.c
--- grass-addons/grass7/raster/r.sun.mp/main.c	                        (rev 0)
+++ grass-addons/grass7/raster/r.sun.mp/main.c	2017-04-03 04:54:36 UTC (rev 70825)
@@ -0,0 +1,2332 @@
+r.sun.mp: This program was writen by Jaro Hofierka in Summer 1993 and re-engineered
+in 1996-1999. In cooperation with Marcel Suri and Thomas Huld from JRC in Ispra
+a new version of r.sun was prepared using ESRA solar radiation formulas.
+See manual pages for details.
+(C) 2002 Copyright Jaro Hofierka, Gresaka 22, 085 01 Bardejov, Slovakia,
+              and GeoModel, s.r.o., Bratislava, Slovakia
+email: hofierka at geomodel.sk,marcel.suri at jrc.it,suri at geomodel.sk Thomas.Huld at jrc.it
+(c) 2003-2013 by The GRASS Development Team
+ * modify it under the terms of the GNU General Public License
+ * as published by the Free Software Foundation; either version 2
+ * of the License, or (at your option) any later version.
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * GNU General Public License for more details.
+ *   Free Software Foundation, Inc.,
+ *   51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+/*v. 2.0 July 2002, NULL data handling, JH */
+/*v. 2.1 January 2003, code optimization by Thomas Huld, JH */
+/*v. 3.0 February 2006, several changes (shadowing algorithm, earth's curvature JH */
+/*v. 4.0 December 2016, OpenMP support Stanislav Zubal, Michal Lacko */
+#define PARALLEL
+#ifdef PARALLEL
+#include <omp.h>
+#define NUM_THREADS "4"
+#endif
+#include <stdio.h>
+#include <math.h>
+#ifdef USE_OPENCL
+  #ifdef __APPLE__
+    #include <OpenCL/opencl.h>
+  #else
+    #include <CL/cl.h>
+  #endif
+#endif
+#include <grass/raster.h>
+#include <grass/gprojects.h>
+#include <grass/glocale.h>
+#include "sunradstruct.h"
+#include "local_proto.h"
+#include "rsunglobals.h"
+/* default values */
+#define NUM_PARTITIONS "1"
+#define SKIP    "1"
+#define BIG      1.e20
+#define LINKE    "3.0"
+#define SLOPE    "0.0"
+#define ASPECT   "270"
+#define ALB      "0.2"
+#define STEP     "0.5"
+#define BSKY      1.0
+#define DSKY      1.0
+#define DIST     "1.0"
+#define SCALING_FACTOR 150.
+const double invScale = 1. / SCALING_FACTOR;
+#define AMAX1(arg1, arg2) ((arg1) >= (arg2) ? (arg1) : (arg2))
+#define AMIN1(arg1, arg2) ((arg1) <= (arg2) ? (arg1) : (arg2))
+#define DISTANCE1(x1, x2, y1, y2) (sqrt((x1 - x2)*(x1 - x2) + (y1 - y2)*(y1 - y2)))
+#define DISTANCE2(x00, y00) ((xx0 - x00)*(xx0 - x00) + (yy0 - y00)*(yy0 - y00))
+const double pihalf = M_PI * 0.5;
+const double pi2 = M_PI * 2.;
+const double deg2rad = M_PI / 180.;
+const double rad2deg = 180. / M_PI;
+FILE *felevin, *faspin, *fslopein, *flinkein, *falbedo, *flatin;
+FILE *fincidout, *fbeam_rad, *finsol_time, *fdiff_rad, *frefl_rad;
+const char *elevin;
+const char *aspin;
+const char *slopein;
+const char *civiltime = NULL;
+const char *linkein = NULL;
+const char *albedo = NULL;
+const char *latin = NULL;
+const char *coefbh = NULL;
+const char *coefdh = NULL;
+const char *incidout = NULL;
+const char *longin = NULL;
+const char *horizon = NULL;
+const char *beam_rad = NULL;
+const char *insol_time = NULL;
+const char *diff_rad = NULL;
+const char *refl_rad = NULL;
+const char *glob_rad = NULL;
+const char *mapset = NULL;
+const char *per;
+size_t decimals;
+char *str_step;
+struct Cell_head cellhd;
+struct pj_info iproj;
+struct pj_info oproj;
+struct History hist;
+int INPUT_part(int offset, double *zmax);
+int OUTGR(void);
+int min(int, int);
+int max(int, int);
+void (*func) (int, int);
+#ifdef PARALLEL
+    int threads;
+time_t timer;
+void printTimeDiff(const char* message)
+	double seconds;
+	time_t timer2;
+	time(&timer2); //or timer2 = time(NULL);
+	seconds = difftime(timer2,timer);
+	timer = timer2;
+/*	G_message(_("TIME_DIFF: <%.0lf>\tmessage <%s>\n"),
+			seconds,
+			message);*/
+#endif
+void joules2(struct SunGeometryConstDay *sunGeom,
+	     struct SolarRadVar *sunRadVar,
+	     unsigned char *horizonpointer, double latitude,
+	     double longitude,
+            double *Pbeam_e,
+            double *Pdiff_e,
+            double *Prefl_e,
+            double *Pinsol_t);
+void calculate(double singleSlope, double singleAspect,
+	       double singleAlbedo, double singleLinke,
+	       struct GridGeometry gridGeom);
+double com_declin(int);
+int n, m, ip, jp;
+int d, day;
+int saveMemory, numPartitions = 1;
+long int shadowoffset = 0;
+int varCount_global = 0;
+int bitCount_global = 0;
+int arrayNumInt = 1;
+float **z = NULL, **o = NULL, **s = NULL, **li = NULL, **a = NULL,
+    **latitudeArray = NULL, **longitudeArray, **cbhr = NULL, **cdhr = NULL;
+double op, dp;
+double invstepx, invstepy;
+double sunrise_min = 24., sunrise_max = 0., sunset_min = 24., sunset_max = 0.;
+float **lumcl, **beam, **insol, **diff, **refl, **globrad;
+unsigned char *horizonarray = NULL;
+double civilTime;
+ * double startTime, endTime;
+double xmin, xmax, ymin, ymax;
+double declin, step, dist;
+double linke_max = 0., linke_min = 100., albedo_max = 0., albedo_min = 1.0,
+    lat_max = -90., lat_min = 90.;
+double offsetx = 0.5, offsety = 0.5;
+char *ttime;
+ * double slope;
+double o_orig, z1;
+ * double lum_C11, lum_C13, lum_C22, lum_C31, lum_C33;
+ * double sinSolarAltitude; */
+/* Sine of the solar altitude (angle above horizon)
+ * double sunrise_time, sunset_time;
+ * double solarAltitude;
+ * double tanSolarAlt, solarAzimuth;
+ * double stepsinangle, stepcosangle;
+ * double angle;
+double horizonStep;
+double ltime, tim, timo;
+double declination;	/* Contains the negative of the declination at the chosen day */
+ * double lum_C31_l, lum_C33_l;
+//double beam_e, diff_e, refl_e, rr, insol_t;
+double cbh, cdh;
+double TOLER;
+/* 1852m/nm * 60nm/degree = 111120 m/deg */
+#define DEGREEINMETERS 111120.
+int ll_correction = FALSE;
+double coslatsq;
+/* why not use G_distance() here which switches to geodesic/great
+  circle distace as needed? */
+double distance(double x1, double x2, double y1, double y2)
+    if (ll_correction) {
+	return DEGREEINMETERS * sqrt(coslatsq * (x1 - x2) * (x1 - x2)
+				     + (y1 - y2) * (y1 - y2));
+    else {
+	return sqrt((x1 - x2) * (x1 - x2) + (y1 - y2) * (y1 - y2));
+int main(int argc, char *argv[])
+    double singleSlope;
+    double singleAspect;
+    double singleAlbedo;
+    double singleLinke;
+#ifdef PARALLEL
+    timer = time(NULL);
+    printTimeDiff("Start");
+    //int threads;
+    struct GModule *module;
+    struct
+	struct Option *elevin, *aspin, *aspect, *slopein, *slope, *linkein,
+	    *lin, *albedo, *longin, *alb, *latin, *coefbh, *coefdh,
+	    *incidout, *beam_rad, *insol_time, *diff_rad, *refl_rad,
+	    *glob_rad, *day, *step, *declin, *ltime, *dist, *horizon,
+	    *horizonstep, *numPartitions, *civilTime, *threads;
+    parm;
+#endif
+#ifndef PARALLEL
+    struct
+	    *horizonstep, *numPartitions, *civilTime;
+    parm;
+#endif
+    struct
+	struct Flag *noshade, *saveMemory;
+    flag;
+    struct GridGeometry gridGeom;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    G_add_keyword(_("raster"));
+    G_add_keyword(_("solar"));
+    G_add_keyword(_("sun energy"));
+    G_add_keyword(_("shadow"));
+    module->label = _("Solar irradiance and irradiation model.");
+    module->description =
+	_("Computes direct (beam), diffuse and reflected solar irradiation raster "
+	 "maps for given day, latitude, surface and atmospheric conditions. Solar "
+	 "parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
+	 "irradiance, daylight length) are saved in the map history file. "
+	 "Alternatively, a local time can be specified to compute solar "
+	 "incidence angle and/or irradiance raster maps. The shadowing effect of "
+	 "the topography is optionally incorporated.");
+    parm.elevin = G_define_option();
+    parm.elevin->key = "elevation";
+    parm.elevin->type = TYPE_STRING;
+    parm.elevin->required = YES;
+    parm.elevin->gisprompt = "old,cell,raster";
+    parm.elevin->description =
+	_("Name of the input elevation raster map [meters]");
+    parm.elevin->guisection = _("Input");
+    parm.aspin = G_define_option();
+    parm.aspin->key = "aspect";
+    parm.aspin->type = TYPE_STRING;
+    parm.aspin->required = NO;
+    parm.aspin->gisprompt = "old,cell,raster";
+    parm.aspin->description =
+	_("Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]");
+    parm.aspin->guisection = _("Input");
+    parm.aspect = G_define_option();
+    parm.aspect->key = "aspect_value";
+    parm.aspect->type = TYPE_DOUBLE;
+    parm.aspect->answer = ASPECT;
+    parm.aspect->required = NO;
+    parm.aspect->description =
+	_("A single value of the orientation (aspect), 270 is south");
+    parm.aspect->guisection = _("Input");
+    parm.slopein = G_define_option();
+    parm.slopein->key = "slope";
+    parm.slopein->type = TYPE_STRING;
+    parm.slopein->required = NO;
+    parm.slopein->gisprompt = "old,cell,raster";
+    parm.slopein->description =
+	_("Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]");
+    parm.slopein->guisection = _("Input");
+    parm.slope = G_define_option();
+    parm.slope->key = "slope_value";
+    parm.slope->type = TYPE_DOUBLE;
+    parm.slope->answer = SLOPE;
+    parm.slope->required = NO;
+    parm.slope->description = _("A single value of inclination (slope)");
+    parm.slope->guisection = _("Input");
+    parm.linkein = G_define_option();
+    parm.linkein->key = "linke";
+    parm.linkein->type = TYPE_STRING;
+    parm.linkein->required = NO;
+    parm.linkein->gisprompt = "old,cell,raster";
+    parm.linkein->description =
+	_("Name of the Linke atmospheric turbidity coefficient input raster map [-]");
+    parm.linkein->guisection = _("Input");
+    parm.lin = G_define_option();
+    parm.lin->key = "linke_value";
+    parm.lin->type = TYPE_DOUBLE;
+    parm.lin->answer = LINKE;
+    parm.lin->required = NO;
+    parm.lin->description =
+      _("A single value of the Linke atmospheric turbidity coefficient [-]");
+    parm.lin->guisection = _("Input");
+    parm.albedo = G_define_option();
+    parm.albedo->key = "albedo";
+    parm.albedo->type = TYPE_STRING;
+    parm.albedo->required = NO;
+    parm.albedo->gisprompt = "old,cell,raster";
+    parm.albedo->description =
+	_("Name of the ground albedo coefficient input raster map [-]");
+    parm.albedo->guisection = _("Input");
+    parm.alb = G_define_option();
+    parm.alb->key = "albedo_value";
+    parm.alb->type = TYPE_DOUBLE;
+    parm.alb->answer = ALB;
+    parm.alb->required = NO;
+    parm.alb->description =
+      _("A single value of the ground albedo coefficient [-]");
+    parm.alb->guisection = _("Input");
+    parm.latin = G_define_option();
+    parm.latin->key = "lat";
+    parm.latin->type = TYPE_STRING;
+    parm.latin->required = NO;
+    parm.latin->gisprompt = "old,cell,raster";
+    parm.latin->description =
+	_("Name of input raster map containing latitudes [decimal degrees]");
+    parm.latin->guisection = _("Input");
+    parm.longin = G_define_option();
+    parm.longin->key = "long";
+    parm.longin->type = TYPE_STRING;
+    parm.longin->required = NO;
+    parm.longin->gisprompt = "old,cell,raster";
+    parm.longin->description =
+	_("Name of input raster map containing longitudes [decimal degrees]");
+    parm.longin->guisection = _("Input");
+    parm.coefbh = G_define_option();
+    parm.coefbh->key = "coeff_bh";
+    parm.coefbh->type = TYPE_STRING;
+    parm.coefbh->required = NO;
+    parm.coefbh->gisprompt = "old,cell,raster";
+    parm.coefbh->description =
+	_("Name of real-sky beam radiation coefficient (thick cloud) input raster map [0-1]");
+    parm.coefbh->guisection = _("Input");
+    parm.coefdh = G_define_option();
+    parm.coefdh->key = "coeff_dh";
+    parm.coefdh->type = TYPE_STRING;
+    parm.coefdh->required = NO;
+    parm.coefdh->gisprompt = "old,cell,raster";
+    parm.coefdh->description =
+	_("Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]");
+    parm.coefdh->guisection = _("Input");
+    parm.horizon = G_define_standard_option(G_OPT_R_BASENAME_INPUT);
+    parm.horizon->key = "horizon_basename";
+    parm.horizon->required = NO;
+    parm.horizon->gisprompt = "old,cell,raster";
+    parm.horizon->description = _("The horizon information input map basename");
+    parm.horizon->guisection = _("Input");
+    parm.horizonstep = G_define_option();
+    parm.horizonstep->key = "horizon_step";
+    parm.horizonstep->type = TYPE_DOUBLE;
+    parm.horizonstep->required = NO;
+    parm.horizonstep->description =
+	_("Angle step size for multidirectional horizon [degrees]");
+    parm.horizonstep->guisection = _("Input");
+    parm.incidout = G_define_option();
+    parm.incidout->key = "incidout";
+    parm.incidout->type = TYPE_STRING;
+    parm.incidout->required = NO;
+    parm.incidout->gisprompt = "new,cell,raster";
+    parm.incidout->description =
+	_("Output incidence angle raster map (mode 1 only)");
+    parm.incidout->guisection = _("Output");
+    parm.beam_rad = G_define_option();
+    parm.beam_rad->key = "beam_rad";
+    parm.beam_rad->type = TYPE_STRING;
+    parm.beam_rad->required = NO;
+    parm.beam_rad->gisprompt = "new,cell,raster";
+    parm.beam_rad->description =
+	_("Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)");
+    parm.beam_rad->guisection = _("Output");
+    parm.diff_rad = G_define_option();
+    parm.diff_rad->key = "diff_rad";
+    parm.diff_rad->type = TYPE_STRING;
+    parm.diff_rad->required = NO;
+    parm.diff_rad->gisprompt = "new,cell,raster";
+    parm.diff_rad->description =
+	_("Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)");
+    parm.diff_rad->guisection = _("Output");
+    parm.refl_rad = G_define_option();
+    parm.refl_rad->key = "refl_rad";
+    parm.refl_rad->type = TYPE_STRING;
+    parm.refl_rad->required = NO;
+    parm.refl_rad->gisprompt = "new,cell,raster";
+    parm.refl_rad->description =
+	_("Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)");
+    parm.refl_rad->guisection = _("Output");
+    parm.glob_rad = G_define_option();
+    parm.glob_rad->key = "glob_rad";
+    parm.glob_rad->type = TYPE_STRING;
+    parm.glob_rad->required = NO;
+    parm.glob_rad->gisprompt = "new,cell,raster";
+    parm.glob_rad->description =
+	_("Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)");
+    parm.glob_rad->guisection = _("Output");
+    parm.insol_time = G_define_option();
+    parm.insol_time->key = "insol_time";
+    parm.insol_time->type = TYPE_STRING;
+    parm.insol_time->required = NO;
+    parm.insol_time->gisprompt = "new,cell,raster";
+    parm.insol_time->description =
+	_("Output insolation time raster map [h] (mode 2 only)");
+    parm.insol_time->guisection = _("Output");
+    parm.day = G_define_option();
+    parm.day->key = "day";
+    parm.day->type = TYPE_INTEGER;
+    parm.day->required = YES;
+    parm.day->description = _("No. of day of the year (1-365)");
+    parm.day->options = "1-365";
+    parm.day->guisection = _("Time");
+    parm.step = G_define_option();
+    parm.step->key = "step";
+    parm.step->type = TYPE_DOUBLE;
+    parm.step->answer = STEP;
+    parm.step->required = NO;
+    parm.step->description =
+	_("Time step when computing all-day radiation sums [decimal hours]");
+    parm.step->guisection = _("Time");
+    parm.declin = G_define_option();
+    parm.declin->key = "declination";
+    parm.declin->type = TYPE_DOUBLE;
+    parm.declin->required = NO;
+    parm.declin->description =
+	_("Declination value (overriding the internally computed value) [radians]");
+    parm.ltime = G_define_option();
+    parm.ltime->key = "time";
+    parm.ltime->type = TYPE_DOUBLE;
+    /*          parm.ltime->answer = TIME; */
+    parm.ltime->required = NO;
+    parm.ltime->description =
+	_("Local (solar) time (to be set for mode 1 only) [decimal hours]");
+    parm.ltime->options = "0-24";
+    parm.ltime->guisection = _("Time");
+#ifdef PARALLEL
+    parm.threads = G_define_option();
+    parm.threads->key = "threads";
+    parm.threads->type = TYPE_INTEGER;
+    parm.threads->answer = NUM_THREADS;
+    parm.threads->required = NO;
+    parm.threads->description =
+	_("Number of threads which will be used for parallel compute");
+    parm.threads->guisection = _("Parameters");
+#endif
+     * parm.startTime = G_define_option();
+     * parm.startTime->key = "start_time";
+     * parm.startTime->type = TYPE_DOUBLE;
+     * parm.startTime->required = NO;
+     * parm.startTime->description = _("Starting time for calculating results for several different times.");
+     * parm.endTime = G_define_option();
+     * parm.endTime->key = "end_time";
+     * parm.endTime->type = TYPE_DOUBLE;
+     * parm.endTime->required = NO;
+     * parm.endTime->description = _("End time for calculating results for several different times.)";
+    parm.dist = G_define_option();
+    parm.dist->key = "distance_step";
+    parm.dist->type = TYPE_DOUBLE;
+    parm.dist->answer = DIST;
+    parm.dist->required = NO;
+    parm.dist->description =
+	_("Sampling distance step coefficient (0.5-1.5)");
+    parm.numPartitions = G_define_option();
+    parm.numPartitions->key = "npartitions";
+    parm.numPartitions->type = TYPE_INTEGER;
+    parm.numPartitions->answer = NUM_PARTITIONS;
+    parm.numPartitions->required = NO;
+    parm.numPartitions->description =
+	_("Read the input files in this number of chunks");
+    parm.civilTime = G_define_option();
+    parm.civilTime->key = "civil_time";
+    parm.civilTime->type = TYPE_DOUBLE;
+    parm.civilTime->required = NO;
+    parm.civilTime->description =
+	_("Civil time zone value, if none, the time will be local solar time");
+    parm.civilTime->guisection = _("Time");
+    flag.noshade = G_define_flag();
+    flag.noshade->key = 'p';
+    flag.noshade->description =
+	_("Do not incorporate the shadowing effect of terrain");
+    flag.saveMemory = G_define_flag();
+    flag.saveMemory->key = 'm';
+    flag.saveMemory->description =
+	_("Use the low-memory version of the program");
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    G_get_set_window(&cellhd);
+    gridGeom.stepx = cellhd.ew_res;
+    gridGeom.stepy = cellhd.ns_res;
+    invstepx = 1. / gridGeom.stepx;
+    invstepy = 1. / gridGeom.stepy;
+    n /*n_cols */  = cellhd.cols;
+    m /*n_rows */  = cellhd.rows;
+    xmin = cellhd.west;
+    ymin = cellhd.south;
+    xmax = cellhd.east;
+    ymax = cellhd.north;
+    gridGeom.deltx = fabs(cellhd.east - cellhd.west);
+    gridGeom.delty = fabs(cellhd.north - cellhd.south);
+    setUseShadow(!flag.noshade->answer);
+    saveMemory = flag.saveMemory->answer;
+    elevin = parm.elevin->answer;
+    aspin = parm.aspin->answer;
+    slopein = parm.slopein->answer;
+    linkein = parm.linkein->answer;
+    albedo = parm.albedo->answer;
+    latin = parm.latin->answer;
+    longin = parm.longin->answer;
+    civiltime = parm.civilTime->answer;
+#ifdef PARALLEL
+    sscanf(parm.threads->answer, "%d", &threads);
+    if (threads < 1)
+      G_warning(_("<%d> is not valid number of threads. Number of threads will be set on <%d>"),
+      threads, abs(threads));
+      threads = abs(threads);
+    omp_set_num_threads(threads);
+    G_message(_("Number of threads <%d>"),threads);
+    int nthreads, tid;
+#endif
+#ifdef PARALLEL
+    printTimeDiff("M1");
+#endif
+    if (civiltime != NULL) {
+	setUseCivilTime(TRUE);
+	if (longin == NULL)
+	    G_fatal_error(
+		_("You must give the longitude raster if you use civil time"));
+	if (sscanf(parm.civilTime->answer, "%lf", &civilTime) != 1)
+	    G_fatal_error(_("Error reading civil time zone value"));
+	if (civilTime < -24. || civilTime > 24.)
+	    G_fatal_error(_("Invalid civil time zone value"));
+	/* Normalize if somebody should be weird enough to give more than +- 12
+	 * hours offset. */
+	if (civilTime < -12.)
+	    civilTime += 24.;
+	else if (civilTime > 12.)
+	    civilTime -= 24;
+    else {
+	setUseCivilTime(FALSE);
+    coefbh = parm.coefbh->answer;
+    coefdh = parm.coefdh->answer;
+    incidout = parm.incidout->answer;
+    horizon = parm.horizon->answer;
+    setUseHorizonData(horizon != NULL);
+    beam_rad = parm.beam_rad->answer;
+    insol_time = parm.insol_time->answer;
+    diff_rad = parm.diff_rad->answer;
+    refl_rad = parm.refl_rad->answer;
+    glob_rad = parm.glob_rad->answer;
+    if ((insol_time != NULL) && (incidout != NULL))
+	G_fatal_error(_("insol_time and incidout are incompatible options"));
+    sscanf(parm.day->answer, "%d", &day);
+    if (sscanf(parm.step->answer, "%lf", &step) != 1)
+	G_fatal_error(_("Error reading time step size"));
+    if (step <= 0.0 || step > 24.0)
+	G_fatal_error(_("Invalid time step size"));
+    if (parm.horizonstep->answer != NULL) {
+	if (sscanf(parm.horizonstep->answer, "%lf", &horizonStep) != 1)
+	    G_fatal_error(_("Error reading horizon step size"));
+        str_step = parm.horizonstep->answer;
+	if (horizonStep > 0.)
+	    setHorizonInterval(deg2rad * horizonStep);
+	else
+	    G_fatal_error(_("The horizon step size must be greater than 0."));
+    else if (useHorizonData()) {
+	G_fatal_error(_("If you use the horizon option you must also set the 'horizonstep' parameter."));
+    ttime = parm.ltime->answer;
+    if (parm.ltime->answer != NULL) {
+	if (insol_time != NULL)
+	    G_fatal_error(_("Time and insol_time are incompatible options"));
+	G_message(_("Mode 1: instantaneous solar incidence angle & irradiance using a set local time"));
+	sscanf(parm.ltime->answer, "%lf", &timo);
+    else {
+	if (incidout != NULL)
+	    G_fatal_error(_("incidout requires time parameter to be set"));
+	G_message(_("Mode 2: integrated daily irradiation for a given day of the year"));
+     * if (parm.startTime->answer != NULL) sscanf(parm.startTime->answer, "%lf", &startTime);
+     * if (parm.endTime->answer != NULL) sscanf(parm.endTime->answer, "%lf", &endTime);
+     * if((parm.startTime->answer != NULL) ||(parm.endTime->answer != NULL))
+    /* The start and end times should only be defined if the single
+     * time is not defined, and if the step size *is* defined. */
+     * if(parm.step->answer==NULL)
+     *    G_fatal_error("If you want to use a time interval you must also define a step size.");
+     * if(parm.ltime->answer!=NULL)
+     *    G_fatal_error("If you want to use a time interval you can't define a single time value.\n");
+     * if((parm.startTime->answer==NULL)||(parm.endTime->answer==NULL))
+     *    G_fatal_error("If you want to use a time interval both the start and end times must be defined.\n");
+    if (parm.linkein->answer == NULL){
+	sscanf(parm.lin->answer, "%lf", &singleLinke);
+        G_message(_("Using Linke constant: %lf"), singleLinke);
+    } else {
+        G_message(_("Using Linke map <%s>"), parm.linkein->answer);
+    if (parm.albedo->answer == NULL){
+	sscanf(parm.alb->answer, "%lf", &singleAlbedo);
+        G_message(_("Using albedo constant: %lf"), singleAlbedo);
+    } else {
+        G_message(_("Using albedo map <%s>"), parm.albedo->answer);
+    if (parm.slopein->answer == NULL){
+	sscanf(parm.slope->answer, "%lf", &singleSlope);
+        G_message(_("Using slope constant: %lf"), singleSlope);
+        singleSlope *= deg2rad;
+    } else {
+        G_message(_("Using slope map <%s>"), parm.slopein->answer);
+    if (parm.aspin->answer == NULL){
+	sscanf(parm.aspect->answer, "%lf", &singleAspect);
+        G_message(_("Using aspect constant: %lf"), singleAspect);
+        singleAspect *= deg2rad;
+    } else {
+        G_message(_("Using aspect map <%s>"), parm.aspin->answer);
+    if (parm.coefbh->answer == NULL)
+	cbh = BSKY;
+    if (parm.coefdh->answer == NULL)
+	cdh = DSKY;
+    sscanf(parm.dist->answer, "%lf", &dist);
+    if (parm.numPartitions->answer != NULL) {
+	sscanf(parm.numPartitions->answer, "%d", &numPartitions);
+	if (useShadow() && (!useHorizonData()) && (numPartitions != 1)) {
+	    /* If you calculate shadows on the fly, the number of partitions
+	     * must be one.
+	    G_fatal_error(_("If you use -s and no horizon rasters, numpartitions must be =1"));
+    gridGeom.stepxy = dist * 0.5 * (gridGeom.stepx + gridGeom.stepy);
+    TOLER = gridGeom.stepxy * EPS;
+    /* The save memory scheme will not work if you want to calculate shadows
+     * on the fly. If you calculate without shadow effects or if you have the
+     * shadows pre-calculated, there is no problem. */
+    if (saveMemory && useShadow() && (!useHorizonData()))
+	G_fatal_error(
+	    _("If you want to save memory and to use shadows, "
+	      "you must use pre-calculated horizons."));
+    if (parm.declin->answer == NULL)
+	declination = com_declin(day);
+    else {
+	sscanf(parm.declin->answer, "%lf", &declin);
+	declination = -declin;
+    if (ttime != 0) {
+	/* Shadow for just one time during the day */
+	if (horizon == NULL) {
+	    arrayNumInt = 1;
+	    arrayNumInt = (int)(360. / horizonStep);
+    else {
+	if (useHorizonData()) {
+	    /*        Number of bytes holding the horizon information */
+    if (ttime != NULL) {
+	tim = (timo - 12) * 15;
+	/* converting to degrees */
+	/* Jenco (12-timeAngle) * 15 */
+	if (tim < 0)
+	    tim += 360;
+	tim = M_PI * tim / 180;
+	/* conv. to radians */
+    /* Set up parameters for projection to lat/long if necessary */
+    /*  we need to do this even if latin= and longin= were given because
+	rsunlib's com_par() needs iproj and oproj */
+    if ((G_projection() != PROJECTION_LL)) {
+	struct Key_Value *in_proj_info, *in_unit_info;
+	if ((in_proj_info = G_get_projinfo()) == NULL)
+	    G_fatal_error(
+		_("Can't get projection info of current location"));
+	if ((in_unit_info = G_get_projunits()) == NULL)
+	    G_fatal_error(
+		_("Can't get projection units of current location"));
+	if (pj_get_kv(&iproj, in_proj_info, in_unit_info) < 0)
+	    G_fatal_error(
+		_("Can't get projection key values of current location"));
+	G_free_key_value(in_proj_info);
+	G_free_key_value(in_unit_info);
+	/* Set output projection to latlong w/ same ellipsoid */
+	oproj.zone = 0;
+	oproj.meters = 1.;
+	sprintf(oproj.proj, "ll");
+	if ((oproj.pj = pj_latlong_from_proj(iproj.pj)) == NULL)
+	    G_fatal_error(_("Unable to set up lat/long projection parameters"));
+    if ((latin != NULL || longin != NULL) && (G_projection() == PROJECTION_LL))
+	G_warning(_("latin and longin raster maps have no effect when in a Lat/Lon location"));
+	/* true about longin= when civiltime is used? */
+	/* civiltime needs longin= but not latin= for non-LL projections -
+	     better would be it just use pj_proj() if it needs those?? */
+    if (latin != NULL && longin == NULL)
+	G_fatal_error(_("Both latin and longin raster maps must be given, or neither"));
+/**********end of parser - ******************************/
+    if ((G_projection() == PROJECTION_LL))
+	ll_correction = TRUE;
+    G_debug(3, "calculate() starts...");
+    calculate(singleSlope, singleAspect, singleAlbedo, singleLinke, gridGeom);
+    G_debug(3, "OUTGR() starts...");
+    OUTGR();
+#ifdef PARALLEL
+    printTimeDiff("M4");
+#endif
+    exit(EXIT_SUCCESS);
+    int finalRow, rowrevoffset;
+    int numRows;
+    int numDigits;
+    FCELL *cell1 = NULL, *cell2 = NULL;
+    FCELL *cell3 = NULL, *cell4 = NULL, *cell5 = NULL, *cell6 = NULL, *cell7 =
+	NULL;
+    FCELL *rast1 = NULL, *rast2 = NULL;
+    static FCELL **horizonbuf;
+    unsigned char *horizonpointer;
+    int fd1 = -1, fd2 = -1, fd3 = -1, fd4 = -1, fd5 = -1, fd6 = -1,
+	fd7 = -1, row, row_rev;
+    static int *fd_shad;
+    int fr1 = -1, fr2 = -1;
+    int l, i, j;
+    char *shad_filename;
+    char formatString[10];
+    double angle_deg = 0.;
+    finalRow = m - offset - m / numPartitions;
+    if (finalRow < 0) {
+	finalRow = 0;
+    numRows = m / numPartitions;
+    cell1 = Rast_allocate_f_buf();
+    if (z == NULL) {
+	if (!(z = G_alloc_fmatrix(numRows, n)))
+            G_fatal_error(_("Out of memory"));
+            return -1;
+	//z = (float **)G_malloc(sizeof(float *) * (numRows));
+	//for (l = 0; l < numRows; l++) {
+	//    z[l] = (float *)G_malloc(sizeof(float) * (n));
+    fd1 = Rast_open_old(elevin, "");
+    if (slopein != NULL) {
+	cell3 = Rast_allocate_f_buf();
+        if (s == NULL) {
+            if (!(s = G_alloc_fmatrix(numRows, n)))
+                return -1;
+            //s = (float **)G_malloc(sizeof(float *) * (numRows));
+	//	s[l] = (float *)G_malloc(sizeof(float) * (n));
+	fd3 = Rast_open_old(slopein, "");
+    if (aspin != NULL) {
+	cell2 = Rast_allocate_f_buf();
+	if (o == NULL) {
+	    if (!(o = G_alloc_fmatrix(numRows, n)))
+                return -1;
+            //o = (float **)G_malloc(sizeof(float *) * (numRows));
+	//	o[l] = (float *)G_malloc(sizeof(float) * (n));
+	fd2 = Rast_open_old(aspin, "");
+    if (linkein != NULL) {
+	cell4 = Rast_allocate_f_buf();
+	if (li == NULL) {
+            if (!(li = G_alloc_fmatrix(numRows, n)))
+                return -1;
+	    //li = (float **)G_malloc(sizeof(float *) * (numRows));
+	//	li[l] = (float *)G_malloc(sizeof(float) * (n));
+	fd4 = Rast_open_old(linkein, "");
+    if (albedo != NULL) {
+	cell5 = Rast_allocate_f_buf();
+	if (a == NULL) {
+            if (!(a = G_alloc_fmatrix(numRows, n)))
+                return -1;
+	    //a = (float **)G_malloc(sizeof(float *) * (numRows));
+	//	a[l] = (float *)G_malloc(sizeof(float) * (n));
+	fd5 = Rast_open_old(albedo, "");
+    if (latin != NULL) {
+	cell6 = Rast_allocate_f_buf();
+	if (latitudeArray == NULL) {
+            if (!(latitudeArray = G_alloc_fmatrix(numRows, n)))
+                return -1;
+	    //latitudeArray = (float **)G_malloc(sizeof(float *) * (numRows));
+	//	latitudeArray[l] = (float *)G_malloc(sizeof(float) * (n));
+	fd6 = Rast_open_old(latin, "");
+    if (longin != NULL) {
+	cell7 = Rast_allocate_f_buf();
+            if (!(longitudeArray = G_alloc_fmatrix(numRows, n)))
+                return -1;
+	    //longitudeArray = (float **)G_malloc(sizeof(float *) * (numRows));
+	//	longitudeArray[l] = (float *)G_malloc(sizeof(float) * (n));
+	fd7 = Rast_open_old(longin, "");
+    if (coefbh != NULL) {
+	rast1 = Rast_allocate_f_buf();
+	if (cbhr == NULL) {
+            if (!(cbhr = G_alloc_fmatrix(numRows, n)))
+                return -1;
+	    //cbhr = (float **)G_malloc(sizeof(float *) * (numRows));
+	//	cbhr[l] = (float *)G_malloc(sizeof(float) * (n));
+	fr1 = Rast_open_old(coefbh, "");
+    if (coefdh != NULL) {
+	rast2 = Rast_allocate_f_buf();
+	if (cdhr == NULL) {
+            if (!(cdhr = G_alloc_fmatrix(numRows, n)))
+                return -1;
+	    //cdhr = (float **)G_malloc(sizeof(float *) * (numRows));
+	//	cdhr[l] = (float *)G_malloc(sizeof(float) * (n));
+	fr2 = Rast_open_old(coefdh, "");
+	if (horizonarray == NULL) {
+            horizonarray =
+		(unsigned char *)G_calloc(arrayNumInt *
+					  numRows * n, sizeof(char));
+	    horizonbuf = (FCELL **) G_calloc(arrayNumInt, sizeof(FCELL *) );
+	    fd_shad = (int *)G_calloc(arrayNumInt, sizeof(int));
+// 	    horizonarray =
+// 		(unsigned char *)G_malloc(sizeof(char) * arrayNumInt *
+// 					  numRows * n);
+// 	    horizonbuf = (FCELL **) G_malloc(sizeof(FCELL *) * arrayNumInt);
+// 	    fd_shad = (int *)G_malloc(sizeof(int) * arrayNumInt);
+	 * if(ttime != NULL)
+	 * horizonbuf[0]=Rast_allocate_f_buf();
+	 * sprintf(shad_filename, "%s_%02d", horizon, arrayNumInt);
+	 * if((mapset=G_find_raster2(shad_filename,""))==NULL)
+	 * G_message("Horizon file no. %d not found\n", arrayNumInt);
+	 * fd_shad[0] = Rast_open_old(shad_filename,mapset);
+	 * else
+        decimals = G_get_num_decimals(str_step);
+        angle_deg = 0;
+        for (i = 0; i < arrayNumInt; i++) {
+            horizonbuf[i] = Rast_allocate_f_buf();
+            shad_filename = G_generate_basename(horizon, angle_deg,
+                                                3, decimals);
+            fd_shad[i] = Rast_open_old(shad_filename, "");
+            angle_deg += horizonStep;
+            G_free(shad_filename);
+        numDigits = (int)(log10(1. * arrayNumInt)) + 1;
+	sprintf(formatString, "%%s_%%0%dd", numDigits);
+	    sprintf(shad_filename, formatString, horizon, i);
+	    for (row = m - offset - 1; row >= finalRow; row--) {
+		row_rev = m - row - 1;
+		rowrevoffset = row_rev - offset;
+		Rast_get_f_row(fd_shad[i], horizonbuf[i], row);
+		horizonpointer =
+		    horizonarray + (ssize_t) arrayNumInt *n * rowrevoffset;
+		for (j = 0; j < n; j++) {
+		    horizonpointer[i] = (char)(rint(SCALING_FACTOR *
+						    AMIN1(horizonbuf[i][j],
+							  256 * invScale)));
+		    horizonpointer += arrayNumInt;
+	Rast_get_f_row(fd1, cell1, row);
+	    Rast_get_f_row(fd2, cell2, row);
+	    Rast_get_f_row(fd3, cell3, row);
+	    Rast_get_f_row(fd4, cell4, row);
+	    Rast_get_f_row(fd5, cell5, row);
+	    Rast_get_f_row(fd6, cell6, row);
+	    Rast_get_f_row(fd7, cell7, row);
+	    Rast_get_f_row(fr1, rast1, row);
+	    Rast_get_f_row(fr2, rast2, row);
+	    if (!Rast_is_f_null_value(cell1 + j))
+		z[rowrevoffset][j] = (float)cell1[j];
+	    else
+		z[rowrevoffset][j] = UNDEFZ;
+		if (!Rast_is_f_null_value(cell2 + j))
+		    o[rowrevoffset][j] = (float)cell2[j];
+		else
+		    o[rowrevoffset][j] = UNDEFZ;
+		if (!Rast_is_f_null_value(cell3 + j))
+		    s[rowrevoffset][j] = (float)cell3[j];
+		else
+		    s[rowrevoffset][j] = UNDEFZ;
+		if (!Rast_is_f_null_value(cell4 + j))
+		    li[rowrevoffset][j] = (float)cell4[j];
+		else
+		    li[rowrevoffset][j] = UNDEFZ;
+		if (!Rast_is_f_null_value(cell5 + j))
+		    a[rowrevoffset][j] = (float)cell5[j];
+		else
+		    a[rowrevoffset][j] = UNDEFZ;
+		if (!Rast_is_f_null_value(cell6 + j))
+		    latitudeArray[rowrevoffset][j] = (float)cell6[j];
+		else
+		    latitudeArray[rowrevoffset][j] = UNDEFZ;
+		if (!Rast_is_f_null_value(cell7 + j))
+		    longitudeArray[rowrevoffset][j] = (float)cell7[j];
+		else
+		    longitudeArray[rowrevoffset][j] = UNDEFZ;
+		if (!Rast_is_f_null_value(rast1 + j))
+		    cbhr[rowrevoffset][j] = (float)rast1[j];
+		else
+		    cbhr[rowrevoffset][j] = UNDEFZ;
+		if (!Rast_is_f_null_value(rast2 + j))
+		    cdhr[rowrevoffset][j] = (float)rast2[j];
+		else
+		    cdhr[rowrevoffset][j] = UNDEFZ;
+    Rast_close(fd1);
+    G_free(cell1);
+	G_free(cell2);
+	Rast_close(fd2);
+	G_free(cell3);
+	Rast_close(fd3);
+	G_free(cell4);
+	Rast_close(fd4);
+	G_free(cell5);
+	Rast_close(fd5);
+	G_free(cell6);
+	Rast_close(fd6);
+	G_free(cell7);
+	Rast_close(fd7);
+	G_free(rast1);
+	Rast_close(fr1);
+	G_free(rast2);
+	Rast_close(fr2);
+	    Rast_close(fd_shad[i]);
+	    G_free(horizonbuf[i]);
+/*******transformation of angles from 0 to east counterclock
+        to 0 to north clocwise, for ori=0 upslope flowlines
+        turn the orientation 2*M_PI ************/
+    /* needs to be eliminated */
+    /*for (i = 0; i < m; ++i) */
+    for (i = 0; i < numRows; i++) {
+	    *zmax = AMAX1(*zmax, z[i][j]);
+		if (o[i][j] != 0.) {
+		    if (o[i][j] < 90.)
+			o[i][j] = 90. - o[i][j];
+		    else
+			o[i][j] = 450. - o[i][j];
+		/*   G_debug(3,"o,z = %d  %d i,j, %d %d \n", o[i][j],z[i][j],i,j); */
+		if ((aspin != NULL) && o[i][j] == UNDEFZ)
+		    z[i][j] = UNDEFZ;
+		if ((slopein != NULL) && s[i][j] == UNDEFZ)
+		    z[i][j] = UNDEFZ;
+		if (linkein != NULL && li[i][j] == UNDEFZ)
+		    z[i][j] = UNDEFZ;
+		if (albedo != NULL && a[i][j] == UNDEFZ)
+		    z[i][j] = UNDEFZ;
+		if (latin != NULL && latitudeArray[i][j] == UNDEFZ)
+		    z[i][j] = UNDEFZ;
+		if (coefbh != NULL && cbhr[i][j] == UNDEFZ)
+		    z[i][j] = UNDEFZ;
+		if (coefdh != NULL && cdhr[i][j] == UNDEFZ)
+		    z[i][j] = UNDEFZ;
+    return 1;
+int OUTGR(void)
+    FCELL *cell7 = NULL, *cell8 = NULL, *cell9 = NULL, *cell10 =
+	NULL, *cell11 = NULL, *cell12 = NULL;
+    int fd7 = -1, fd8 = -1, fd9 = -1, fd10 = -1, fd11 = -1, fd12 = -1;
+    int i, iarc, j;
+    if (incidout != NULL) {
+	fd7 = Rast_open_fp_new(incidout);
+    if (beam_rad != NULL) {
+	cell8 = Rast_allocate_f_buf();
+	fd8 = Rast_open_fp_new(beam_rad);
+    if (insol_time != NULL) {
+	cell11 = Rast_allocate_f_buf();
+	fd11 = Rast_open_fp_new(insol_time);
+    if (diff_rad != NULL) {
+	cell9 = Rast_allocate_f_buf();
+	fd9 = Rast_open_fp_new(diff_rad);
+    if (refl_rad != NULL) {
+	cell10 = Rast_allocate_f_buf();
+	fd10 = Rast_open_fp_new(refl_rad);
+    if (glob_rad != NULL) {
+	cell12 = Rast_allocate_f_buf();
+	fd12 = Rast_open_fp_new(glob_rad);
+    if (m != Rast_window_rows())
+	G_fatal_error("OOPS: rows changed from %d to %d", m, Rast_window_rows());
+    if (n != Rast_window_cols())
+	G_fatal_error("OOPS: cols changed from %d to %d", n, Rast_window_cols());
+    for (iarc = 0; iarc < m; iarc++) {
+	i = m - iarc - 1;
+		if (lumcl[i][j] == UNDEFZ)
+		    Rast_set_f_null_value(cell7 + j, 1);
+		else
+		    cell7[j] = (FCELL) lumcl[i][j];
+	    Rast_put_f_row(fd7, cell7);
+		if (beam[i][j] == UNDEFZ)
+		    Rast_set_f_null_value(cell8 + j, 1);
+		else
+		    cell8[j] = (FCELL) beam[i][j];
+	    Rast_put_f_row(fd8, cell8);
+		if (globrad[i][j] == UNDEFZ)
+		    Rast_set_f_null_value(cell12 + j, 1);
+		else
+		    cell12[j] = (FCELL) globrad[i][j];
+	    Rast_put_f_row(fd12, cell12);
+		if (insol[i][j] == UNDEFZ)
+		    Rast_set_f_null_value(cell11 + j, 1);
+		else
+		    cell11[j] = (FCELL) insol[i][j];
+	    Rast_put_f_row(fd11, cell11);
+		if (diff[i][j] == UNDEFZ)
+		    Rast_set_f_null_value(cell9 + j, 1);
+		else
+		    cell9[j] = (FCELL) diff[i][j];
+	    Rast_put_f_row(fd9, cell9);
+		if (refl[i][j] == UNDEFZ)
+		    Rast_set_f_null_value(cell10 + j, 1);
+		else
+		    cell10[j] = (FCELL) refl[i][j];
+	    Rast_put_f_row(fd10, cell10);
+	Rast_close(fd7);
+	Rast_write_history(incidout, &hist);
+	Rast_close(fd8);
+	Rast_write_history(beam_rad, &hist);
+	Rast_close(fd9);
+	Rast_write_history(diff_rad, &hist);
+	Rast_close(fd10);
+	Rast_write_history(refl_rad, &hist);
+	Rast_close(fd11);
+	Rast_write_history(insol_time, &hist);
+	Rast_close(fd12);
+	Rast_write_history(glob_rad, &hist);
+    return 1;
+	     struct GridGeometry *gridGeom, unsigned char *horizonpointer,
+	     double latitude, double longitude,
+            double *Pbeam_e,
+            double *Pdiff_e,
+            double *Prefl_e,
+            double *Pinsol_t)
+    double s0, dfr, dfr_rad;
+    double ra, dra;
+    int ss = 1;
+    double firstTime;
+    double firstAngle, lastAngle;
+    int srStepNo;
+    double bh;
+    double rr;
+    beam_e = 0.;
+    diff_e = 0.;
+    refl_e = 0.;
+    insol_t = 0.;*/
+    com_par(sunGeom, sunVarGeom, gridGeom, latitude, longitude);
+    if (ttime != NULL) {		/*irradiance */
+	s0 = lumcline2(sunGeom, sunVarGeom, sunSlopeGeom, gridGeom,
+		       horizonpointer);
+	if (sunVarGeom->solarAltitude > 0.) {
+	    if ((!sunVarGeom->isShadow) && (s0 > 0.)) {
+		ra = brad(s0, &bh, sunVarGeom, sunSlopeGeom, sunRadVar);	/* beam radiation */
+		*Pbeam_e += ra;
+	    else {
+		*Pbeam_e = 0.;
+		bh = 0.;
+	    if ((diff_rad != NULL) || (glob_rad != NULL)) {
+		dra = drad(s0, bh, &rr, sunVarGeom, sunSlopeGeom, sunRadVar);	/* diffuse rad. */
+		*Pdiff_e += dra;
+	    if ((refl_rad != NULL) || (glob_rad != NULL)) {
+		if ((diff_rad == NULL) && (glob_rad == NULL))
+		    drad(s0, bh, &rr, sunVarGeom, sunSlopeGeom, sunRadVar);
+		*Prefl_e += rr;	/* reflected rad. */
+	}			/* solarAltitude */
+    else {
+	/* all-day radiation */
+	srStepNo = (int)(sunGeom->sunrise_time / step);
+	if ((sunGeom->sunrise_time - srStepNo * step) > 0.5 * step) {
+	    firstTime = (srStepNo + 1.5) * step;
+	else {
+	    firstTime = (srStepNo + 0.5) * step;
+	firstAngle = (firstTime - 12) * HOURANGLE;
+	lastAngle = (sunGeom->sunset_time - 12) * HOURANGLE;
+	dfr_rad = step * HOURANGLE;
+	sunGeom->timeAngle = firstAngle;
+	varCount_global = 0;
+	dfr = step;
+	while (ss == 1) {
+			   horizonpointer);
+		    *Pinsol_t += dfr;
+		    *Pbeam_e += dfr * ra;
+		    ra = 0.;
+		else {
+		    bh = 0.;
+		    dra =
+			     sunRadVar);
+		    *Pdiff_e += dfr * dra;
+		    dra = 0.;
+		    if ((diff_rad == NULL) && (glob_rad == NULL)) {
+			     sunRadVar);
+		    *Prefl_e += dfr * rr;
+		    rr = 0.;
+	    }			/* illuminated */
+	    sunGeom->timeAngle = sunGeom->timeAngle + dfr_rad;
+	    if (sunGeom->timeAngle > lastAngle) {
+		ss = 0;		/* we've got the sunset */
+	}			/* end of while */
+    }				/* all-day radiation */
+ * void where_is_point(void)
+ * double sx, sy;
+ * double dx, dy;
+ * double adx, ady;
+ * int i, j;
+ * sx = xx0 * invstepx + TOLER;
+ * sy = yy0 * invstepy + TOLER;
+ * i = (int)sx;
+ * j = (int)sy;
+ * if (i < n - 1 && j < m - 1) {
+ * dx = xx0 - (double)i *stepx;
+ * dy = yy0 - (double)j *stepy;
+ * adx = fabs(dx);
+ * ady = fabs(dy);
+ * if ((adx > TOLER) && (ady > TOLER)) {
+ * cube(j, i);
+ * return;
+ * else if ((adx > TOLER) && (ady < TOLER)) {
+ * line_x(j, i);
+ * return;
+ * else if ((adx < TOLER) && (ady > TOLER)) {
+ * line_y(j, i);
+ * return;
+ * else if ((adx < TOLER) && (ady < TOLER)) {
+ * vertex(j, i);
+ * return;
+ * else {
+ * func = NULL;
+    double sx, sy;
+    double dx, dy;
+    /*              double adx, ady; */
+    int i, j;
+    sx = gridGeom->xx0 * invstepx + offsetx;	/* offset 0.5 cell size to get the right cell i, j */
+    sy = gridGeom->yy0 * invstepy + offsety;
+    i = (int)sx;
+    j = (int)sy;
+    /*      if (i < n-1  && j < m-1) {    to include last row/col */
+    if (i <= n - 1 && j <= m - 1) {
+	dx = (double)i *gridGeom->stepx;
+	dy = (double)j *gridGeom->stepy;
+	*length = distance(gridGeom->xg0, dx, gridGeom->yg0, dy);	/* dist from orig. grid point to the current grid point */
+	sunVarGeom->zp = z[j][i];
+	 * cube(j, i);
+ * void vertex(jmin, imin)
+ * int jmin, imin;
+ * zp = z[jmin][imin];
+ * if ((zp == UNDEFZ))
+ * func = NULL;
+ * void line_x(jmin, imin)
+ * int jmin, imin;
+ * double c1, c2;
+ * double d1, d2, e1, e2;
+ * e1 = (double)imin *stepx;
+ * e2 = (double)(imin + 1) * stepx;
+ * c1 = z[jmin][imin];
+ * c2 = z[jmin][imin + 1];
+ * if (!((c1 == UNDEFZ) || (c2 == UNDEFZ))) {
+ * if (dist <= 1.0) {
+ * d1 = (xx0 - e1) / (e2 - e1);
+ * d2 = 1 - d1;
+ * if (d1 < d2)
+ * zp = c1;
+ * else
+ * zp = c2;
+ * if (dist > 1.0)
+ * zp = AMAX1(c1, c2);
+ * else
+ * func = NULL;
+ * void line_y(jmin, imin)
+ * int jmin, imin;
+ * double c1, c2;
+ * e1 = (double)jmin *stepy;
+ * e2 = (double)(jmin + 1) * stepy;
+ * c2 = z[jmin + 1][imin];
+ * d1 = (yy0 - e1) / (e2 - e1);
+ * d2 = 1 - d1;
+ * if (d1 < d2)
+ * zp = c1;
+ * else
+ * zp = c2;
+ * if (dist > 1.0)
+ * else
+ * func = NULL;
+ * void cube(jmin, imin)
+ * int jmin, imin;
+ * int i, ig = 0;
+ * double x1, x2, y1, y2;
+ * double v[4], vmin = BIG;
+ * double c[4], cmax = -BIG;
+ * x1 = (double)imin *stepx;
+ * x2 = x1 + stepx;
+ * y1 = (double)jmin *stepy;
+ * y2 = y1 + stepy;
+ * v[0] = DISTANCE2(x1, y1);
+ * if (v[0] < vmin) {
+ * ig = 0;
+ * vmin = v[0];
+ * v[1] = DISTANCE2(x2, y1);
+ * if (v[1] < vmin) {
+ * ig = 1;
+ * vmin = v[1];
+ * v[2] = DISTANCE2(x2, y2);
+ * if (v[2] < vmin) {
+ * ig = 2;
+ * vmin = v[2];
+ * v[3] = DISTANCE2(x1, y2);
+ * if (v[3] < vmin) {
+ * ig = 3;
+ * vmin = v[3];
+ * c[0] = z[jmin][imin];
+ * c[1] = z[jmin][imin + 1];
+ * c[2] = z[jmin + 1][imin + 1];
+ * c[3] = z[jmin + 1][imin];
+ * if (c[ig] != UNDEFZ)
+ * zp = c[ig];
+ * else
+ * func = NULL;
+ * return;
+ * if (dist > 1.0) {
+ * for (i = 0; i < 4; i++) {
+ * if (c[i] != UNDEFZ) {
+ * cmax = AMAX1(cmax, c[i]);
+ * zp = cmax;
+ * else
+ * func = NULL;
+ * int jmin, imin;
+void cube(jmin, imin)
+void calculate(double singleSlope, double singleAspect, double singleAlbedo,
+	       double singleLinke, struct GridGeometry gridGeom)
+    int i, j, l;
+    /*                      double energy; */
+    int someRadiation;
+    int numRows;
+    int arrayOffset;
+    double lum, q1;
+    double dayRad;
+    double latid_l, cos_u, cos_v, sin_u, sin_v;
+    double sin_phi_l, tan_lam_l;
+    double zmax;
+    double longitTime = 0.;
+    double locTimeOffset;
+    double latitude, longitude;
+    double coslat;
+    struct SunGeometryConstDay sunGeom;
+    struct SunGeometryVarDay sunVarGeom;
+    struct SunGeometryVarSlope sunSlopeGeom;
+    struct SolarRadVar sunRadVar;
+    sunSlopeGeom.slope = singleSlope;
+    sunSlopeGeom.aspect = singleAspect;
+    sunRadVar.alb = singleAlbedo;
+    sunRadVar.linke = singleLinke;
+    sunRadVar.cbh = 1.0;
+    sunRadVar.cdh = 1.0;
+    sunGeom.sindecl = sin(declination);
+    sunGeom.cosdecl = cos(declination);
+    someRadiation = (beam_rad != NULL) || (insol_time != NULL) ||
+	(diff_rad != NULL) || (refl_rad != NULL) || (glob_rad != NULL);
+//     if (incidout != NULL) {
+// 	lumcl = (float **)G_malloc(sizeof(float *) * (m));
+// 	for (l = 0; l < m; l++) {
+// 	    lumcl[l] = (float *)G_malloc(sizeof(float) * (n));
+// 	for (j = 0; j < m; j++) {
+// 	    for (i = 0; i < n; i++)
+// 		lumcl[j][i] = UNDEFZ;
+//     if (beam_rad != NULL) {
+// 	beam = (float **)G_malloc(sizeof(float *) * (m));
+// 	    beam[l] = (float *)G_malloc(sizeof(float) * (n));
+// 		beam[j][i] = UNDEFZ;
+//     if (insol_time != NULL) {
+// 	insol = (float **)G_malloc(sizeof(float *) * (m));
+// 	    insol[l] = (float *)G_malloc(sizeof(float) * (n));
+// 		insol[j][i] = UNDEFZ;
+//     if (diff_rad != NULL) {
+// 	diff = (float **)G_malloc(sizeof(float *) * (m));
+// 	    diff[l] = (float *)G_malloc(sizeof(float) * (n));
+// 		diff[j][i] = UNDEFZ;
+//     if (refl_rad != NULL) {
+// 	refl = (float **)G_malloc(sizeof(float *) * (m));
+// 	    refl[l] = (float *)G_malloc(sizeof(float) * (n));
+// 		refl[j][i] = UNDEFZ;
+//     if (glob_rad != NULL) {
+// 	globrad = (float **)G_malloc(sizeof(float *) * (m));
+// 	    globrad[l] = (float *)G_malloc(sizeof(float) * (n));
+// 		globrad[j][i] = UNDEFZ;
+	lumcl = (float **)G_calloc((m), sizeof(float *));
+	for (l = 0; l < m; l++) {
+	    lumcl[l] = (float *)G_calloc((n), sizeof(float *));
+	for (j = 0; j < m; j++) {
+	    for (i = 0; i < n; i++)
+		lumcl[j][i] = UNDEFZ;
+	beam = (float **)G_calloc((m), sizeof(float *));
+	    beam[l] = (float *)G_calloc((n), sizeof(float *));
+		beam[j][i] = UNDEFZ;
+	insol = (float **)G_calloc((m), sizeof(float *));
+	    insol[l] = (float *)G_calloc((n), sizeof(float *));
+		insol[j][i] = UNDEFZ;
+	diff = (float **)G_calloc((m), sizeof(float *));
+	    diff[l] = (float *)G_calloc((n), sizeof(float *));
+		diff[j][i] = UNDEFZ;
+	refl = (float **)G_calloc((m), sizeof(float *));
+	    refl[l] = (float *)G_calloc((n), sizeof(float *));
+		refl[j][i] = UNDEFZ;
+	globrad = (float **)G_calloc((m), sizeof(float *));
+	    globrad[l] = (float *)G_calloc((n), sizeof(float *));
+		globrad[j][i] = UNDEFZ;
+    sunRadVar.G_norm_extra = com_sol_const(day);
+    if (useCivilTime()) {
+	/* We need to calculate the deviation of the local solar time from the
+	 * "local clock time". */
+	dayRad = 2. * M_PI * day / 365.25;
+	locTimeOffset =
+	    +0.128 * sin(dayRad - 0.04887) + 0.165 * sin(2 * dayRad +
+							 0.34383);
+	/* Time offset due to timezone as input by user */
+	locTimeOffset += civilTime;
+	setTimeOffset(locTimeOffset);
+    else {
+	setTimeOffset(0.);
+#ifdef PARALLEL
+    printTimeDiff("M2");
+#endif
+    int shadowoffset_base = shadowoffset;
+	G_percent(j, m - 1, 2);
+	if (j % (numRows) == 0) {
+	    INPUT_part(j, &zmax);
+	    arrayOffset = 0;
+	    shadowoffset = 0;
+	sunVarGeom.zmax = zmax;
+        shadowoffset_base = (j % (numRows)) * n * arrayNumInt;
+  #pragma omp parallel firstprivate(q1,tan_lam_l,z1,i,shadowoffset,longitTime,coslat,coslatsq,func,latitude,longitude,sin_phi_l,latid_l,sin_u,cos_u,sin_v,cos_v,lum, gridGeom,sunGeom,sunVarGeom,sunSlopeGeom,sunRadVar, elevin,aspin,slopein,civiltime,linkein,albedo,latin,coefbh,coefdh,incidout,longin,horizon,beam_rad,insol_time,diff_rad,refl_rad,glob_rad,mapset,per,decimals,str_step )
+      #pragma omp for schedule(dynamic)
+	for (i = 0; i < n; i++) {
+            shadowoffset = shadowoffset_base + (arrayNumInt * i);
+    //G_message("\n tid: %d", omp_get_thread_num());
+		/* sun travels 15deg per hour, so 1 TZ every 15 deg and 15 TZs * 24hrs = 360deg */
+		longitTime = -longitudeArray[arrayOffset][i] / 15.;
+	    gridGeom.xg0 = gridGeom.xx0 = (double)i *gridGeom.stepx;
+	    gridGeom.yg0 = gridGeom.yy0 = (double)j *gridGeom.stepy;
+	    gridGeom.xp = xmin + gridGeom.xx0;
+	    gridGeom.yp = ymin + gridGeom.yy0;
+		coslat = cos(deg2rad * gridGeom.yp);
+		coslatsq = coslat * coslat;
+	    func = NULL;
+if (i >= n || arrayOffset >= m)
+    G_message("i: %d, n: %d, arrayOffset: %d, m: %d", i,n,arrayOffset,m);
+	    sunVarGeom.z_orig = z1 = sunVarGeom.zp = z[arrayOffset][i];
+ 	    if (sunVarGeom.z_orig != UNDEFZ) {
+ 		    o_orig = o[arrayOffset][i];
+ 		    if (o[arrayOffset][i] != 0.)
+ 			sunSlopeGeom.aspect = o[arrayOffset][i] * deg2rad;
+ 		    else
+ 			sunSlopeGeom.aspect = UNDEF;
+ 		    sunSlopeGeom.slope = s[arrayOffset][i] * deg2rad;
+ 		    sunRadVar.linke = li[arrayOffset][i];
+ 		    linke_max = AMAX1(linke_max, sunRadVar.linke);
+ 		    linke_min = AMIN1(linke_min, sunRadVar.linke);
+ 		    sunRadVar.alb = a[arrayOffset][i];
+ 		    albedo_max = AMAX1(albedo_max, sunRadVar.alb);
+ 		    albedo_min = AMIN1(albedo_min, sunRadVar.alb);
+ 		    latitude = latitudeArray[arrayOffset][i];
+ 		    lat_max = AMAX1(lat_max, latitude);
+ 		    lat_min = AMIN1(lat_min, latitude);
+ 		    latitude *= deg2rad;
+ 		    longitude = longitudeArray[arrayOffset][i];
+ 		    /* lon_max = AMAX1(lon_max, longitude); */
+ 		    /* lon_min = AMIN1(lon_min, longitude); */
+ 		    longitude *= deg2rad;
+ 		    if (latin == NULL || longin == NULL) {
+ 			/* if either is missing we have to calc both from current projection */
+ 			longitude = gridGeom.xp;
+ 			latitude = gridGeom.yp;
+ 			if (pj_do_proj(&longitude, &latitude, &iproj, &oproj) < 0) {
+ 			    G_fatal_error("Error in pj_do_proj");
+ 		else {		/* ll projection */
+ 		    sunRadVar.cbh = cbhr[arrayOffset][i];
+ 		    sunRadVar.cdh = cdhr[arrayOffset][i];
+ 		cos_u = cos(M_PI / 2 - sunSlopeGeom.slope);	/* = sin(slope) */
+ 		sin_u = sin(M_PI / 2 - sunSlopeGeom.slope);	/* = cos(slope) */
+ 		cos_v = cos(M_PI / 2 + sunSlopeGeom.aspect);
+ 		sin_v = sin(M_PI / 2 + sunSlopeGeom.aspect);
+ 		    sunGeom.timeAngle = tim;
+ 		gridGeom.sinlat = sin(-latitude);
+ 		gridGeom.coslat = cos(-latitude);
+ 		sin_phi_l =
+ 		    -gridGeom.coslat * cos_u * sin_v +
+ 		    gridGeom.sinlat * sin_u;
+ 		latid_l = asin(sin_phi_l);
+ 		q1 = gridGeom.sinlat * cos_u * sin_v +
+ 		    gridGeom.coslat * sin_u;
+ 		tan_lam_l = -cos_u * cos_v / q1;
+ 		sunSlopeGeom.longit_l = atan(tan_lam_l);
+ 		sunSlopeGeom.lum_C31_l = cos(latid_l) * sunGeom.cosdecl;
+ 		sunSlopeGeom.lum_C33_l = sin_phi_l * sunGeom.sindecl;
+ 		if ((incidout != NULL) || someRadiation) {
+  		    com_par_const(longitTime, &sunGeom, &gridGeom);
+ 		    sunrise_min = AMIN1(sunrise_min, sunGeom.sunrise_time);
+ 		    sunrise_max = AMAX1(sunrise_max, sunGeom.sunrise_time);
+ 		    sunset_min = AMIN1(sunset_min, sunGeom.sunset_time);
+ 		    sunset_max = AMAX1(sunset_max, sunGeom.sunset_time);
+  		    com_par(&sunGeom, &sunVarGeom, &gridGeom, latitude,
+  			    longitude);
+  		    lum =
+  			lumcline2(&sunGeom, &sunVarGeom, &sunSlopeGeom,
+  				  &gridGeom, horizonarray + shadowoffset);
+ 		    if (lum > 0.) {
+ 			lum = rad2deg * asin(lum);
+ 			lumcl[j][i] = (float)lum;
+ 		    else lumcl[j][i] = UNDEFZ;
+ 		double Pbeam_e = 0.;
+                 double Pdiff_e = 0.;
+                 double Prefl_e = 0.;
+                 double Pinsol_t = 0.;
+ 		if (someRadiation) {
+  		    joules2(&sunGeom, &sunVarGeom, &sunSlopeGeom, &sunRadVar,
+  			    &gridGeom, horizonarray + shadowoffset, latitude,
+  			    longitude,
+                          &Pbeam_e,
+                          &Pdiff_e,
+                          &Prefl_e,
+                          &Pinsol_t
+ 			beam[j][i] = (float)Pbeam_e;
+ 			insol[j][i] = (float)Pinsol_t;
+ 		    /*  G_debug(3,"\n %f",insol[j][i]); */
+ 			diff[j][i] = (float)Pdiff_e;
+ 			refl[j][i] = (float)Prefl_e;
+ 			globrad[j][i] = (float)(Pbeam_e + Pdiff_e + Prefl_e);
+ 	    }			/* undefs */
+ 	    //shadowoffset += arrayNumInt;
+        arrayOffset++;
+#ifdef PARALLEL
+    printTimeDiff("M3");
+#endif
+    /* re-use &hist, but try all to initiate it for any case */
+    /*   note this will result in incorrect map titles       */
+	Rast_short_history(incidout, "raster", &hist);
+    else if (beam_rad != NULL) {
+	Rast_short_history(beam_rad, "raster", &hist);
+    else if (diff_rad != NULL) {
+	Rast_short_history(diff_rad, "raster", &hist);
+    else if (refl_rad != NULL) {
+	Rast_short_history(refl_rad, "raster", &hist);
+    else if (insol_time != NULL) {
+	Rast_short_history(insol_time, "raster", &hist);
+    else if (glob_rad != NULL) {
+	Rast_short_history(glob_rad, "raster", &hist);
+    else
+	G_fatal_error
+	    ("Failed to init map history: no output maps requested!");
+    Rast_append_format_history(
+	&hist,
+	&hist,
+	" Day [1-365]:                              %d",
+	day);
+	    &hist,
+	    " Local (solar) time (decimal hr.):         %.4f", timo);
+	&hist,
+	" Solar constant (W/m^2):                   1367");
+	&hist,
+	" Extraterrestrial irradiance (W/m^2):      %f",
+	sunRadVar.G_norm_extra);
+	&hist,
+	" Declination (rad):                        %f", -declination);
+	&hist,
+	" Latitude min-max(deg):                    %.4f - %.4f",
+	lat_min, lat_max);
+	    &hist,
+	    " Sunrise time (hr.):                       %.2f",
+	    sunGeom.sunrise_time);
+	    &hist,
+	    " Sunset time (hr.):                        %.2f",
+	    sunGeom.sunset_time);
+	    &hist,
+	    " Daylight time (hr.):                      %.2f",
+	    sunGeom.sunset_time - sunGeom.sunrise_time);
+    else {
+	    &hist,
+	    " Sunrise time min-max (hr.):               %.2f - %.2f",
+	    sunrise_min, sunrise_max);
+	    &hist,
+	    " Sunset time min-max (hr.):                %.2f - %.2f",
+	    sunset_min, sunset_max);
+	    &hist,
+	    " Time step (hr.):                          %.4f", step);
+    if (incidout != NULL || ttime != NULL) {
+	    &hist,
+	    " Solar altitude (deg):                     %.4f",
+	    sunVarGeom.solarAltitude * rad2deg);
+	    &hist,
+	    " Solar azimuth (deg):                      %.4f",
+	    sunVarGeom.solarAzimuth * rad2deg);
+    if (linkein == NULL)
+	    &hist,
+	    " Linke turbidity factor:                   %.1f",
+	    sunRadVar.linke);
+    else
+	    &hist,
+	    " Linke turbidity factor min-max:           %.1f-%.1f",
+	    linke_min, linke_max);
+    if (albedo == NULL)
+	    &hist,
+	    " Ground albedo:                            %.3f",
+	    sunRadVar.alb);
+    else
+	    &hist,
+	    " Ground albedo min-max:                    %.3f-%.3f",
+	    albedo_min, albedo_max);
+	&hist,
+    Rast_command_history(&hist);
+    /* don't call Rast_write_history() until after Rast_close() or it just gets overwritten */
+}				/* End of ) function */
+double com_declin(int no_of_day)
+    double d1, decl;
+    /* stretch day number in the following calculation for siderial effect? */
+    /*   ? double siderial_day = no_of_day + ((no_of_day * 0.25) / 365.) ? */
+    /* or just change d1 to : d1 = pi2 * no_of_day / 365.0;  ? */
+    d1 = pi2 * no_of_day / 365.25;
+    decl = asin(0.3978 * sin(d1 - 1.4 + 0.0355 * sin(d1 - 0.0489)));
+    decl = -decl;
+    /*      G_debug(3," declination : %lf\n", decl); */
+    return (decl);
+int test(void)
+    /* not finshed yet */
+    int dej;
+    G_message("\n ddd: %f", declin);
+    dej = asin(-declin / 0.4093) * 365. / pi2 + 81;
+    /*        dej = asin(-declin/23.35 * deg2rad) / 0.9856 - 284; */
+    /*      dej = dej - 365; */
+    G_message("\n d: %d ", dej);
+    if (dej < day - 5 || dej > day + 5)
+	return 0;
+    else
+	return 1;
Added: grass-addons/grass7/raster/r.sun.mp/r.sun.mp.html
--- grass-addons/grass7/raster/r.sun.mp/r.sun.mp.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.sun.mp/r.sun.mp.html	2017-04-03 04:54:36 UTC (rev 70825)
@@ -0,0 +1,384 @@
+<h2>DESCRIPTION</h2>
+<b>r.sun</b> computes beam (direct), diffuse and ground reflected solar
+irradiation raster maps for given day, latitude, surface and atmospheric
+conditions. Solar parameters (e.g. time of sunrise and sunset, declination,
+extraterrestrial irradiance, daylight length) are stored in the resultant maps'
+history files. Alternatively, the local time can be specified to compute solar
+incidence angle and/or irradiance raster maps. The shadowing effect of the
+topography is incorporated by default. This can be done either internally by
+calculatoion of the shadowing effect directly from the digital elevation model
+or by specifying raster maps of the horizon height which is much faster. These
+horizon raster maps can be calculated using <a href="r.horizon.html">r.horizon</a>.
+<p>For latitude-longitude coordinates it requires that the elevation map is in meters.
+The rules are:
+<ul>
+<li> lat/lon coordinates: elevation in meters;
+<li> Other coordinates: elevation in the same unit as the easting-northing coordinates.
+</ul>
+The solar geometry of the model is based on the works of Krcho (1990), later
+improved by Jenco (1992). The equations describing Sun -- Earth position as
+well as an interaction of the solar radiation with atmosphere were originally
+based on the formulas suggested by Kitler and Mikler (1986). This component
+was considerably updated by the results and suggestions of the working group
+co-ordinated by Scharmer and Greif (2000) (this algorithm might be replaced
+by SOLPOS algorithm-library included in GRASS within <a href="r.sunmask.html">
+r.sunmask</a>
+ command). The model computes all three components of global radiation (beam,
+diffuse and reflected) for the clear sky conditions, i.e. not taking into
+consideration the spatial and temporal variation of clouds. The extent and
+spatial resolution of the modelled area, as well as integration over time,
+are limited only by the memory and data storage resources. The model is built
+to fulfil user needs in various fields of science (hydrology, climatology,
+ecology and environmental sciences, photovoltaics, engineering, etc.) for
+continental, regional up to the landscape scales.
+<p>The model considers a shadowing effect of the local topography unless switched
+off with the <em>-p</em> flag.
+<b>r.sun</b> works in two modes: In the first mode it calculates for the set
+local time a solar incidence angle [degrees] and solar irradiance values [W.m-2].
+In the second mode daily sums of solar radiation [Wh.m-2.day-1] are computed
+within a set day. By a scripting the two modes can be used separately or
+in a combination to provide estimates for any desired time interval. The
+model accounts for sky obstruction by local relief features. Several solar
+parameters are saved in the resultant maps' history files, which may be viewed
+with the <a href="r.info.html">r.info</a> command.
+<p>
+The solar incidence angle raster map <i>incidout</i> is computed specifying
+elevation raster map <i>elevation</i>, aspect raster map <i>aspect</i>, slope
+steepness raster map <i>slope,</i> given the day <i>day</i> and local time
+<i>time</i>. There is no need to define latitude for locations with known
+and defined projection/coordinate system (check it with the <a href="g.proj.html">
+g.proj</a>
+ command). If you have undefined projection, (x,y) system, etc. then the latitude
+can be defined explicitly for large areas by input raster map <i>lat_in</i>
+ with interpolated latitude values. All input raster maps must
+be floating point (FCELL) raster maps. Null data in maps are excluded from
+the computation (and also speeding-up the computation), so each output raster
+map will contain null data in cells according to all input raster maps. The
+user can use <a href="r.null.html">r.null</a>
+ command to create/reset null file for your input raster maps. <br>
+The specified day <i>day</i> is the number of the day of the general year
+where January 1 is day no.1 and December 31 is 365. Time <i>time</i> must
+be a local (solar) time (i.e. NOT a zone time, e.g. GMT, CET) in decimal system,
+e.g. 7.5 (= 7h 30m A.M.), 16.1 = 4h 6m P.M..
+<p>
+The solar <i>declination</i> parameter is an option to override
+the value computed by the internal routine for the day of the year. The value
+of geographical latitude can be set as a constant for the whole computed
+region or, as an option, a grid representing spatially distributed values
+over a large region. The geographical latitude must be also in decimal system
+with positive values for northern hemisphere and negative for southern one.
+In similar principle the Linke turbidity factor (<i>linke</i>, <i>lin</i>
+) and ground albedo (<i>albedo</i>, <i>alb</i>) can be set.
+<p>Besides clear-sky radiations, the user can compute a real-sky radiation (beam,
+diffuse) using <i>coeff_bh</i> and <i>coeff_dh</i> input raster maps defining
+the fraction of the respective clear-sky radiations reduced by atmospheric
+factors (e.g. cloudiness). The value is between 0-1. Usually these
+coefficients can be obtained from a long-terms meteorological measurements
+provided as raster maps with spatial distribution of these coefficients separately
+for beam and diffuse radiation (see Suri and Hofierka, 2004, section 3.2).
+<p>
+The solar irradiation or irradiance raster maps <i>beam_rad</i>, <i>diff_rad</i>,
+<i>refl_rad</i> are computed for a given day <i>day,</i> latitude <i>lat_in</i>,
+elevation <i>elevation</i>, slope <i>slope</i> and aspect <i>aspect</i> raster maps.
+For convenience, the output raster given as <i>glob_rad</i>
+will output the sum of the three radiation components. The program uses
+the Linke atmosphere turbidity factor and ground albedo coefficient.
+A default, single value of Linke factor is <i>lin</i>=3.0 and
+is near the annual average for rural-city areas. The Linke
+factor for an absolutely clear atmosphere is <i>lin</i>=1.0. See notes below
+to learn more about this factor. The incidence solar angle is the angle between
+horizon and solar beam vector.
+<p>
+The solar radiation maps for a given day are computed by integrating the
+relevant irradiance between sunrise and sunset times for that day. The
+user can set a finer or coarser time step used for all-day radiation
+calculations with the <i>step</i> option. The default value of <i>step</i> is
+0.5 hour. Larger steps (e.g. 1.0-2.0) can speed-up calculations but produce
+less reliable (and more jagged) results. As the sun moves through approx.
+15° of the sky in an hour, the default <i>step</i> of half an hour will
+produce 7.5° steps in the data. For relatively smooth output with the
+sun placed for every degree of movement in the sky you should set the
+<i>step</i> to 4 minutes or less. <i>step</i><tt>=0.05</tt> is equivalent
+to every 3 minutes. Of course setting the time step to be very fine
+proportionally increases the module's running time.
+<p>The output units are in Wh per squared meter per given
+day [Wh/(m*m)/day]. The incidence angle and irradiance/irradiation maps are
+computed with the shadowing influence of relief by default. It is also possible
+for them to be computed without this influence using the planar flag (<i>-p</i>).
+In mountainous areas this can lead to very different results! The user should be
+aware that taking into account the shadowing effect of relief can slow
+down the speed of computation, especially when the sun altitude is low.
+<p>
+When considering the shadowing effect, speed and precision of computation
+can be controlled by the <i>distance_step</i> parameter, which defines the sampling density
+at which the visibility of a grid cell is computed in the direction of a
+path of the solar flow. It also defines the method by which the obstacle's
+altitude is computed. When choosing a <i>distance_step</i> less than 1.0 (i.e. sampling
+points will be computed at <i>distance_step</i> * cellsize distance), <em>r.sun</em> takes
+the altitude from the nearest grid point. Values above 1.0 will use the maximum
+altitude value found in the nearest 4 surrounding grid points. The default
+value <i>distance_step</i>=1.0 should give reasonable results for most cases (e.g.
+on DEM). The <i>distance_step</i> value defines a multiplying coefficient for sampling
+distance. This basic sampling distance equals to the arithmetic average of
+both cell sizes. The reasonable values are in the range 0.5-1.5.  The values
+below 0.5 will decrease and values above 1.0 will increase the computing
+speed. Values greater than 2.0 may produce estimates with lower accuracy
+in highly dissected relief. The fully shadowed areas are written to the output
+maps as zero values. Areas with NULL data are considered as no barrier with
+shadowing effect.
+<p>
+The maps' history files are generated containing the following listed
+parameters used in the computation: <br>
+- Solar constant 1367 W.m-2 <br>
+- Extraterrestrial irradiance on a plane perpendicular to the solar beam [W.m-2] <br>
+- Day of the year <br>
+- Declination [radians] <br>
+- Decimal hour (Alternative 1 only) <br>
+- Sunrise and sunset (min-max) over a horizontal plane <br>
+- Daylight lengths <br>
+- Geographical latitude (min-max) <br>
+- Linke turbidity factor (min-max) <br>
+- Ground albedo (min-max)
+<p>The user can use a nice shellcript with variable
+day to compute radiation for some time interval within the year (e.g. vegetation
+or winter period). Elevation, aspect and slope input values should not be
+reclassified into coarser categories. This could lead to incorrect results.
+<h2> OPTIONS</h2>
+<p>Currently, there are two modes of r.sun.
+In the first mode it calculates solar incidence angle and solar irradiance
+raster maps using the set local time. In the second mode daily sums of solar
+irradiation [Wh.m-2.day-1] are computed for a specified day.
+<h2>NOTES</h2>
+Solar energy is an important input parameter in different models concerning
+energy industry, landscape, vegetation, evapotranspiration, snowmelt or remote
+sensing. Solar rays incidence angle maps can be effectively used in radiometric
+and topographic corrections in mountainous and hilly terrain where very accurate
+investigations should be performed.
+<p>
+The clear-sky solar radiation model applied in the r.sun is based on the
+work undertaken for development of European Solar Radiation Atlas (Scharmer
+and Greif 2000, Page et al. 2001, Rigollier 2001). The clear sky model estimates
+the global radiation from the sum of its beam, diffuse and reflected components.
+The main difference between solar radiation models for inclined surfaces
+in Europe is the treatment of the diffuse component. In the European climate
+this component is often the largest source of estimation error. Taking into
+consideration the existing models and their limitation the European Solar
+Radiation Atlas team selected the Muneer (1990) model as it has a sound theoretical
+basis and thus more potential for later improvement.
+<p>
+Details of underlying equations used in this program can be found in the
+reference literature cited below or book published by Neteler and Mitasova:
+Open Source GIS: A GRASS GIS Approach (published in Kluwer Academic Publishers
+in 2002).
+<p>
+Average monthly values of the Linke turbidity coefficient for a mild climate
+in the northern hemisphere (see reference literature for your study area):
+<table border="1">
+<tr><th>Month</th><th>Jan</th><th>Feb</th><th>Mar</th><th>Apr</th><th>May</th><th>Jun</th><th>Jul</th><th>Aug</th><th>Sep</th><th>Oct</th><th>Nov</th><th>Dec</th><th>annual</th></tr>
+<tr><td>mountains</td><td>1.5</td><td>1.6</td><td>1.8</td><td>1.9</td><td>2.0</td><td>2.3</td><td>2.3</td><td>2.3</td><td>2.1</td><td>1.8</td><td>1.6</td><td>1.5</td><td>1.90</td></tr>
+<tr><td>rural</td><td>2.1</td><td>2.2</td><td>2.5</td><td>2.9</td><td>3.2</td><td>3.4</td><td>3.5</td><td>3.3</td><td>2.9</td><td>2.6</td><td>2.3</td><td>2.2</td><td>2.75</td></tr>
+<tr><td>city</td><td>3.1</td><td>3.2</td><td>3.5</td><td>4.0</td><td>4.2</td><td>4.3</td><td>4.4</td><td>4.3</td><td>4.0</td><td>3.6</td><td>3.3</td><td>3.1</td><td>3.75</td></tr>
+<tr><td>industrial</td><td>4.1</td><td>4.3</td><td>4.7</td><td>5.3</td><td>5.5</td><td>5.7</td><td>5.8</td><td>5.7</td><td>5.3</td><td>4.9</td><td>4.5</td><td>4.2</td><td>5.00</td></tr>
+</table>
+<p>Planned improvements include the use of the SOLPOS algorithm for solar
+geometry calculations and internal computation of aspect and slope.
+<h3>Solar time</h3>
+By default r.sun calculates times as true solar time, whereby solar noon is
+always exactly 12 o'clock everywhere in the current region. Depending on where
+the zone of interest is located in the related time zone, this may cause
+differences of up to an hour, in some cases (like Western Spain) even more.
+On top of this, the offset varies during the year according to the Equation
+of Time.
+<p>
+To overcome this problem, the user can use the option <em>civil_time=<timezone_offset></em>
+in r.sun to make it use real-world (wall clock) time. For example, for Central
+Europe the timezone offset is +1, +2 when daylight saving time is in effect.
+<p>
+<!-- WE DON'T KNOW, check source code:
+If the user use the <em>civil_time</em> parameter, also the longitude needs to
+be supplied as a raster map with the <em>long_in</em> parameter. Within a
+latlon location, such a map can be easily made with:
+<div class="code"><pre>
+r.mapcalc "lon_raster = x()"
+</pre></div>
+END OF WE DON'T KNOW
+<h3>Extraction of shadow maps</h3>
+A map of shadows can be extracted from the solar incidence angle map
+(incidout). Areas with zero values are shadowed. This will not work
+if the <em>-p</em> flag has been used.
+<h3>Large maps and out of memory problems</h3>
+With a large number or columns and rows, <b>r.sun</b> can consume
+significant amount of memory. While output raster maps are not
+partitionable, the input raster maps are using the <em>npartitions</em>
+parameter.
+In case of out of memory error (<tt>ERROR: G_malloc: out of memory</tt>), the
+<em>npartitions</em> parameter can be used to run a segmented calculation
+which consumes less memory during the computations.
+The amount of memory by <b>r.sun</b> is estimated as follows:
+# without input raster map partitioning:
+#  memory requirements: 4 bytes per raster cell
+#  rows,cols: rows and columns of current region (find out with g.region)
+#  IR: number of input raster maps without horizon maps
+#  OR: number of output raster maps
+memory_bytes = rows*cols*(IR*4 + horizon_steps + OR*4)
+# with input raster map partitioning:
+memory_bytes = rows*cols*((IR*4+horizon_steps)/npartitions  + OR*4)
+</pre></div>
+<h2>EXAMPLES</h2>
+North Carolina example (considering also cast shadows):
+g.region raster=elevation -p
+# calculate horizon angles (to speed up the subsequent r.sun calculation)
+r.horizon elevation=elevation step=30 bufferzone=200 basename=horangle \
+    maxdistance=5000
+# slope + aspect
+r.slope.aspect elevation=elevation aspect=aspect.dem slope=slope.dem
+# calculate global radiation for day 180 at 2p.m., using r.horizon output
+r.sun elevation=elevation horizon_basename=horangle horizon_step=30 \
+      aspect=aspect.dem slope=slope.dem glob_rad=global_rad day=180 time=14
+# result: output global (total) irradiance/irradiation [W.m-2] for given day/time
+r.univar global_rad
+</pre></div>
+<p>
+Calculation of the integrated daily irradiation for a region in North-Carolina
+for a given day of the year at 30m resolution. Here day 172 (i.e., 21 June
+in non-leap years):
+g.region raster=elev_ned_30m -p
+# considering cast shadows
+r.sun elevation=elev_ned_30m linke_value=2.5 albedo_value=0.2 day=172 \
+      beam_rad=b172 diff_rad=d172 \
+      refl_rad=r172 insol_time=it172
+d.mon wx0
+# show irradiation raster map [Wh.m-2.day-1]
+d.rast.leg b172
+# show insolation time raster map [h]
+d.rast.leg it172
+</pre></div>
+We can compute the day of year from a specific date in Python:
+>>> import datetime
+>>> datetime.datetime(2014, 6, 21).timetuple().tm_yday
+172
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.horizon.html">r.horizon</a>,
+<a href="r.slope.aspect.html">r.slope.aspect</a>,
+<a href="r.sunhours.html">r.sunhours</a>,
+<a href="r.sunmask.html">r.sunmask</a>,
+<a href="g.proj.html">g.proj</a>,
+<a href="r.null.html">r.null</a>,
+<a href="v.surf.rst.html">v.surf.rst</a>
+</em>
+<h2>REFERENCES</h2>
+<ul>
+<li> Hofierka, J., Suri, M. (2002): The solar radiation model for Open source
+GIS: implementation and applications. International
+GRASS users conference in Trento, Italy, September 2002.
+(<a href="http://skagit.meas.ncsu.edu/~jaroslav/trento/Hofierka_Jaroslav.pdf">PDF</a>)
+<li>
+Hofierka, J. (1997). Direct solar radiation modelling within an open GIS
+environment. Proceedings of JEC-GI'97 conference in Vienna, Austria, IOS
+Press Amsterdam, 575-584.
+<li>
+Jenco, M. (1992). Distribution of direct solar radiation on georelief and
+its modelling by means of complex digital model of terrain (in Slovak). Geograficky
+casopis, 44, 342-355.
+<li>
+Kasten, F. (1996). The Linke turbidity factor based on improved values of
+the integral Rayleigh optical thickness. Solar Energy, 56 (3), 239-244.
+<li>
+Kasten, F., Young, A. T. (1989). Revised optical air mass tables and approximation
+formula. Applied Optics, 28, 4735-4738.
+<li>
+Kittler, R., Mikler, J. (1986): Basis of the utilization of solar radiation
+(in Slovak). VEDA, Bratislava, p. 150.
+<li>
+Krcho, J. (1990). Morfometrická analza a digitálne modely georeliéfu
+(Morphometric analysis and digital models of georelief, in Slovak).
+VEDA, Bratislava.
+<li>
+Muneer, T. (1990). Solar radiation model for Europe. Building services engineering
+research and technology, 11, 4, 153-163.
+<li>
+Neteler, M., Mitasova, H. (2002): Open Source GIS: A GRASS GIS Approach, Kluwer
+Academic Publishers. (Appendix explains formula;
+<a href="http://www.grassbook.org/">r.sun script download</a>)
+<li>
+Page, J. ed. (1986). Prediction of solar radiation on inclined surfaces. Solar
+energy R&D in the European Community, series F - Solar radiation data,
+Dordrecht (D. Reidel), 3, 71, 81-83.
+<li>
+Page, J., Albuisson, M., Wald, L. (2001). The European solar radiation atlas:
+a valuable digital tool. Solar Energy, 71, 81-83.
+<li>
+Rigollier, Ch., Bauer, O., Wald, L. (2000). On the clear sky model of the
+ESRA - European Solar radiation Atlas - with respect to the Heliosat method.
+Solar energy, 68, 33-48.
+<li>
+Scharmer, K., Greif, J., eds., (2000). The European solar radiation atlas,
+Vol. 2: Database and exploitation software. Paris (Les Presses de l'École
+des Mines).
+<li>
+Joint Research Centre: <a href="http://re.jrc.ec.europa.eu/pvgis/">GIS solar radiation database for Europe</a> and
+<a href="http://re.jrc.ec.europa.eu/pvgis/solres/solmod3.htm">Solar radiation and GIS</a>
+</ul>
+<h2>AUTHORS</h2>
+Jaroslav Hofierka, GeoModel, s.r.o. Bratislava, Slovakia <br>
+Marcel Suri, GeoModel, s.r.o. Bratislava, Slovakia <br>
+Thomas Huld, JRC, Italy <br>
+© 2007, Jaroslav Hofierka, Marcel Suri. This program is free software under the GNU General Public License (>=v2)
+<address>
+<a href="MAILTO:hofierka at geomodel.sk">hofierka at geomodel.sk</a>
+<a href="MAILTO:suri at geomodel.sk">suri at geomodel.sk</a>
+</address>
+<p>
+<i>Last changed: $Date: 2016-02-19 02:42:11 +0100 (Pá, 19 úno 2016) $</i>
Added: grass-addons/grass7/raster/r.sun.mp/rsunglobals.h
--- grass-addons/grass7/raster/r.sun.mp/rsunglobals.h	                        (rev 0)
+++ grass-addons/grass7/raster/r.sun.mp/rsunglobals.h	2017-04-03 04:54:36 UTC (rev 70825)
@@ -0,0 +1,61 @@
+r.sun: rsunglobals.h. This program was writen by Jaro Hofierka in Summer 1993 and re-engineered
+in 1996-1999. In cooperation with Marcel Suri and Thomas Huld from JRC in Ispra
+a new version of r.sun was prepared using ESRA solar radiation formulas.
+See manual pages for details.
+(C) 2002 Copyright Jaro Hofierka, Gresaka 22, 085 01 Bardejov, Slovakia,
+              and GeoModel, s.r.o., Bratislava, Slovakia
+email: hofierka at geomodel.sk,marcel.suri at jrc.it,suri at geomodel.sk
+ * This program is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU General Public License
+ * as published by the Free Software Foundation; either version 2
+ * of the License, or (at your option) any later version.
+ * This program is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with this program; if not, write to the
+ *   Free Software Foundation, Inc.,
+ *   51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+/*v. 2.0 July 2002, NULL data handling, JH */
+/*v. 2.1 January 2003, code optimization by Thomas Huld, JH */
+#define EARTHRADIUS 6371000.
+/* undefined value for terrain aspect */
+#define UNDEF    0.
+/* internal undefined value for NULL */
+#define UNDEFZ   -9999.
+/* Constant for calculating angular loss */
+#define a_r 0.155
+extern int varCount_global;
+extern int bitCount_global;
+extern int arrayNumInt;
+   extern double xp;
+   extern double yp;
+extern double angular_loss_denom;
+extern const double invScale;
+extern const double pihalf;
+extern const double pi2;
+extern const double deg2rad;
+extern const double rad2deg;
+extern struct pj_info iproj;
+extern struct pj_info oproj;
+extern void (*func) (int, int);
Added: grass-addons/grass7/raster/r.sun.mp/rsunlib.c
--- grass-addons/grass7/raster/r.sun.mp/rsunlib.c	                        (rev 0)
+++ grass-addons/grass7/raster/r.sun.mp/rsunlib.c	2017-04-03 04:54:36 UTC (rev 70825)
@@ -0,0 +1,697 @@
+ r.sun: rsunlib.c. This program was writen by Jaro Hofierka in Summer 1993
+   and re-engineered in 1996-1999. In cooperation with Marcel Suri and
+   Thomas Huld from JRC in Ispra a new version of r.sun was prepared using
+   ESRA solar radiation formulas.  See the manual page for details.
+  (C) 2002 Copyright Jaro Hofierka, Gresaka 22, 085 01 Bardejov, Slovakia,
+  email: hofierka at geomodel.sk, marcel.suri at jrc.it, suri at geomodel.sk
+  (C) 2011 by Hamish Bowman, and the GRASS Development Team
+#include <stdio.h>
+#include <math.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include "sunradstruct.h"
+#include "local_proto.h"
+#include "rsunglobals.h"
+int civilTimeFlag;
+int useCivilTime()
+    return civilTimeFlag;
+void setUseCivilTime(int val)
+    civilTimeFlag = val;
+double angular_loss_denom;
+void setAngularLossDenominator()
+    angular_loss_denom = 1. / (1 - exp(-1. / a_r));
+int useShadowFlag;
+int useShadow()
+    return useShadowFlag;
+void setUseShadow(int val)
+    useShadowFlag = val;
+int useHorizonDataFlag;
+int useHorizonData()
+    return useHorizonDataFlag;
+void setUseHorizonData(int val)
+    useHorizonDataFlag = val;
+double timeOffset;
+double getTimeOffset()
+    return timeOffset;
+void setTimeOffset(double val)
+    timeOffset = val;
+double horizonInterval;
+double getHorizonInterval()
+    return horizonInterval;
+void setHorizonInterval(double val)
+    horizonInterval = val;
+/* com_sol_const(): compute the Solar Constant corrected for the day of the
+   year. The Earth is closest to the Sun (Perigee) on about January 3rd,
+   it is furthest from the sun (Apogee) about July 6th. The 1367 W/m^2 solar
+   constant is at the average 1AU distance, but on Jan 3 it gets up to
+   around 1412.71 W/m^2 and on July 6 it gets down to around 1321 W/m^2.
+   This value is for what hits the top of the atmosphere before any energy
+   is attenuated. */
+double com_sol_const(int no_of_day)
+    double I0, d1;
+    /* Solar constant: 1367.0 W/m^2.
+       Perigee offset: here we call Jan 2 at 8:18pm the Perigee, so day
+	number 2.8408. In angular units that's (2*pi * 2.8408 / 365.25) = 0.048869.
+       Orbital eccentricity: For Earth this is currently about 0.01672,
+	and so the distance to the sun varies by +/- 0.01672 from the
+	mean distance (1AU), so over the year the amplitude of the
+	function is 2*ecc = 0.03344.
+       And 365.25 is of course the number of days in a year.
+    /*  v W/(m*m) */
+    I0 = 1367. * (1 + 0.03344 * cos(d1 - 0.048869));
+    return I0;
+void com_par_const(double longitTime, struct SunGeometryConstDay *sungeom,
+		   struct GridGeometry *gridGeom)
+    double pom;
+    double totOffsetTime;
+    sungeom->lum_C11 = gridGeom->sinlat * sungeom->cosdecl;
+    sungeom->lum_C13 = -gridGeom->coslat * sungeom->sindecl;
+    sungeom->lum_C22 = sungeom->cosdecl;
+    sungeom->lum_C31 = gridGeom->coslat * sungeom->cosdecl;
+    sungeom->lum_C33 = gridGeom->sinlat * sungeom->sindecl;
+    if (fabs(sungeom->lum_C31) >= EPS) {
+	totOffsetTime = timeOffset + longitTime;
+	    sungeom->timeAngle -= totOffsetTime * HOURANGLE;
+	pom = -sungeom->lum_C33 / sungeom->lum_C31;
+	if (fabs(pom) <= 1) {
+	    pom = acos(pom);
+	    pom = (pom * 180) / M_PI;
+	    sungeom->sunrise_time = (90 - pom) / 15 + 6;
+	    sungeom->sunset_time = (pom - 90) / 15 + 18;
+	else {
+	    if (pom < 0) {
+		/* G_debug(3,"\n Sun is ABOVE the surface during the whole day"); */
+		sungeom->sunrise_time = 0;
+		sungeom->sunset_time = 24;
+	    else {
+		/* G_debug(3,"\n The sun is BELOW the surface during the whole day"); */
+		if (fabs(pom) - 1 <= EPS) {
+		    sungeom->sunrise_time = 12;
+		    sungeom->sunset_time = 12;
+void com_par(struct SunGeometryConstDay *sungeom,
+	     struct SunGeometryVarDay *sunVarGeom,
+	     struct GridGeometry *gridGeom, double latitude, double longitude)
+    double pom, xpom, ypom;
+    double costimeAngle;
+    double lum_Lx, lum_Ly;
+    double inputAngle;
+    double delt_lat, delt_lon;
+    double delt_lat_m, delt_lon_m;
+    double delt_dist;
+    costimeAngle = cos(sungeom->timeAngle);
+    lum_Lx = -sungeom->lum_C22 * sin(sungeom->timeAngle);
+    lum_Ly = sungeom->lum_C11 * costimeAngle + sungeom->lum_C13;
+    sunVarGeom->sinSolarAltitude =
+	sungeom->lum_C31 * costimeAngle + sungeom->lum_C33;
+    if (fabs(sungeom->lum_C31) < EPS) {
+	if (fabs(sunVarGeom->sinSolarAltitude) >= EPS) {
+	    if (sunVarGeom->sinSolarAltitude > 0) {
+		/* G_debug(3,"\tSun is ABOVE area during the whole day"); */
+	    else {
+		sunVarGeom->solarAltitude = 0.;
+		sunVarGeom->solarAzimuth = UNDEF;
+		return;
+	else {
+	    /* G_debug(3,"\tThe Sun is ON HORIZON during the whole day"); */
+    sunVarGeom->solarAltitude = asin(sunVarGeom->sinSolarAltitude);	/* vertical angle of the sun */
+    /* sinSolarAltitude is sin(solarAltitude) */
+    xpom = lum_Lx * lum_Lx;
+    ypom = lum_Ly * lum_Ly;
+    pom = sqrt(xpom + ypom);
+    if (fabs(pom) > EPS) {
+	sunVarGeom->solarAzimuth = lum_Ly / pom;
+	sunVarGeom->solarAzimuth = acos(sunVarGeom->solarAzimuth);	/* horiz. angle of the Sun */
+	/* solarAzimuth *= RAD; */
+	if (lum_Lx < 0)
+	    sunVarGeom->solarAzimuth = pi2 - sunVarGeom->solarAzimuth;
+    else {
+    if (sunVarGeom->solarAzimuth < 0.5 * M_PI)
+	sunVarGeom->sunAzimuthAngle = 0.5 * M_PI - sunVarGeom->solarAzimuth;
+    else
+	sunVarGeom->sunAzimuthAngle = 2.5 * M_PI - sunVarGeom->solarAzimuth;
+    inputAngle = sunVarGeom->sunAzimuthAngle + pihalf;
+    inputAngle = (inputAngle >= pi2) ? inputAngle - pi2 : inputAngle;
+    /* 1852m * 60 * 0.0001rad * 180/pi= 636.67m */
+    delt_lat = -0.0001 * cos(inputAngle);  /* Arbitrary small distance in latitude */
+    delt_lon = 0.0001 * sin(inputAngle) / cos(latitude);
+    delt_lat_m = delt_lat * (180/M_PI) * 1852*60;
+    delt_lon_m = delt_lon * (180/M_PI) * 1852*60 * cos(latitude);
+    delt_dist = sqrt(delt_lat_m * delt_lat_m  +  delt_lon_m * delt_lon_m);
+    sunVarGeom->stepsinangle = gridGeom->stepxy * sin(sunVarGeom->sunAzimuthAngle);
+    sunVarGeom->stepcosangle = gridGeom->stepxy * cos(sunVarGeom->sunAzimuthAngle);
+    sunVarGeom->stepsinangle = gridGeom->stepxy * delt_lat_m / delt_dist;
+    sunVarGeom->stepcosangle = gridGeom->stepxy * delt_lon_m / delt_dist;
+    sunVarGeom->tanSolarAltitude = tan(sunVarGeom->solarAltitude);
+    return;
+int searching(double *length, struct SunGeometryVarDay *sunVarGeom,
+    double z2;
+    double curvature_diff;
+    int succes = 0;
+    if (sunVarGeom->zp == UNDEFZ)
+	return 0;
+    gridGeom->yy0 += sunVarGeom->stepsinangle;
+    gridGeom->xx0 += sunVarGeom->stepcosangle;
+    if (((gridGeom->xx0 + (0.5 * gridGeom->stepx)) < 0)
+	|| ((gridGeom->xx0 + (0.5 * gridGeom->stepx)) > gridGeom->deltx)
+	|| ((gridGeom->yy0 + (0.5 * gridGeom->stepy)) < 0)
+	|| ((gridGeom->yy0 + (0.5 * gridGeom->stepy)) > gridGeom->delty))
+	succes = 3;
+    else
+	succes = 1;
+    if (succes == 1) {
+	where_is_point(length, sunVarGeom, gridGeom);
+	if (func == NULL) {
+	    gridGeom->xx0 = gridGeom->xg0;
+	    gridGeom->yy0 = gridGeom->yg0;
+	    return (3);
+	curvature_diff = EARTHRADIUS * (1. - cos(*length / EARTHRADIUS));
+	z2 = sunVarGeom->z_orig + curvature_diff +
+	    *length * sunVarGeom->tanSolarAltitude;
+	if (z2 < sunVarGeom->zp)
+	    succes = 2;		/* shadow */
+	if (z2 > sunVarGeom->zmax)
+	    succes = 3;		/* no test needed all visible */
+    if (succes != 1) {
+    return (succes);
+double lumcline2(struct SunGeometryConstDay *sungeom,
+		 struct SunGeometryVarSlope *sunSlopeGeom,
+		 struct GridGeometry *gridGeom, unsigned char *horizonpointer)
+    double s = 0;
+    double length;
+    int r = 0;
+    int lowPos, highPos;
+    double timeoffset, horizPos;
+    double horizonHeight;
+    func = cube;
+    sunVarGeom->isShadow = 0;
+    if (useShadow()) {
+	length = 0;
+	    /* Start is due east, sungeom->timeangle = -pi/2 */
+	    /* timeoffset = sungeom->timeAngle+pihalf; */
+	    timeoffset = sunVarGeom->sunAzimuthAngle;
+	       if(timeoffset<0.)
+		  timeoffset+=pi2;
+	       else if(timeoffset>pi2)
+		  timeoffset-=pi2;
+	       horizPos = arrayNumInt - timeoffset/horizonInterval;
+	    horizPos = timeoffset / getHorizonInterval();
+	    lowPos = (int)horizPos;
+	    highPos = lowPos + 1;
+	    if (highPos == arrayNumInt) {
+		highPos = 0;
+	    horizonHeight = invScale * ((1. -
+					 (horizPos -
+					  lowPos)) * horizonpointer[lowPos]
+					+ (horizPos - lowPos)
+					* horizonpointer[highPos]);
+		(horizonHeight > sunVarGeom->solarAltitude);
+	    if (!sunVarGeom->isShadow) {
+		/* if (z_orig != UNDEFZ) {
+		      s = sunSlopeGeom->lum_C31_l
+			* cos(-sungeom->timeAngle - sunSlopeGeom->longit_l)
+			+ sunSlopeGeom->lum_C33_l;
+		   } else {
+		     s = sunVarGeom->sinSolarAltitude;
+			+ sunSlopeGeom->lum_C33_l;	/* Jenco */
+	}			/*  End if useHorizonData() */
+	else {
+	    while ((r = searching(&length, sunVarGeom, gridGeom)) == 1) {
+		if (r == 3)
+		    break;	/* no test is needed */
+	    if (r == 2) {
+		sunVarGeom->isShadow = 1;	/* shadow */
+	    else {
+		   } else {
+    else {
+	   } else {
+    /* if (s <= 0) return UNDEFZ; ?? */
+    if (s < 0)
+	return 0.;
+    return (s);
+double brad(double sh, double *bh, struct SunGeometryVarDay *sunVarGeom,
+	    struct SolarRadVar *sunRadVar)
+    double opticalAirMass, airMass2Linke, rayl, br;
+    double drefract, temp1, temp2, h0refract;
+    double elevationCorr;
+    double locSolarAltitude;
+    locSolarAltitude = sunVarGeom->solarAltitude;
+/* FIXME: please document all coefficients */
+    elevationCorr = exp(-sunVarGeom->z_orig / 8434.5);
+    temp1 = 0.1594 + locSolarAltitude * (1.123 + 0.065656 * locSolarAltitude);
+    temp2 = 1. + locSolarAltitude * (28.9344 + 277.3971 * locSolarAltitude);
+    drefract = 0.061359 * temp1 / temp2;	/* in radians */
+    h0refract = locSolarAltitude + drefract;
+    opticalAirMass = elevationCorr / (sin(h0refract) +
+				      0.50572 * pow(h0refract * rad2deg +
+						    6.07995, -1.6364));
+    airMass2Linke = 0.8662 * sunRadVar->linke;
+    if (opticalAirMass <= 20.) {
+	rayl = 1. / (6.6296 +
+		     opticalAirMass * (1.7513 +
+				       opticalAirMass * (-0.1202 +
+							 opticalAirMass *
+							 (0.0065 -
+							  opticalAirMass *
+							  0.00013))));
+    else {
+	rayl = 1. / (10.4 + 0.718 * opticalAirMass);
+    *bh =
+	sunRadVar->cbh * sunRadVar->G_norm_extra *
+	sunVarGeom->sinSolarAltitude * exp(-rayl * opticalAirMass *
+					   airMass2Linke);
+    if (sunSlopeGeom->aspect != UNDEF && sunSlopeGeom->slope != 0.)
+	br = *bh * sh / sunVarGeom->sinSolarAltitude;
+    else
+	br = *bh;
+    return (br);
+double brad_angle_loss(double sh, double *bh,
+    double p, opticalAirMass, airMass2Linke, rayl, br;
+    p = exp(-sunVarGeom->z_orig / 8434.5);
+    opticalAirMass = p / (sin(h0refract) +
+			  0.50572 * pow(h0refract * rad2deg + 6.07995,
+					-1.6364));
+	rayl =
+	    1. / (6.6296 +
+		  opticalAirMass *
+		   (1.7513 + opticalAirMass *
+		    (-0.1202 + opticalAirMass *
+		     (0.0065 - opticalAirMass * 0.00013))));
+    else
+    *bh =
+					   airMass2Linke);
+    else
+	br = *bh;
+    br *= (1 - exp(-sh / a_r)) * angular_loss_denom;
+    return (br);
+double drad(double sh, double bh, double *rr,
+    double tn, fd, fx = 0., A1, A2, A3, A1b;
+    double r_sky, kb, dr, gh, a_ln, ln, fg;
+    double dh;
+    double cosslope, sinslope;
+    double locSinSolarAltitude;
+    double locLinke;
+    locLinke = sunRadVar->linke;
+    locSinSolarAltitude = sunVarGeom->sinSolarAltitude;
+    cosslope = cos(sunSlopeGeom->slope);
+    sinslope = sin(sunSlopeGeom->slope);
+    tn = -0.015843 + locLinke * (0.030543 + 0.0003797 * locLinke);
+    A1b = 0.26463 + locLinke * (-0.061581 + 0.0031408 * locLinke);
+    if (A1b * tn < 0.0022)
+	A1 = 0.0022 / tn;
+    else
+	A1 = A1b;
+    A2 = 2.04020 + locLinke * (0.018945 - 0.011161 * locLinke);
+    A3 = -1.3025 + locLinke * (0.039231 + 0.0085079 * locLinke);
+    fd = A1 + A2 * locSinSolarAltitude +
+	A3 * locSinSolarAltitude * locSinSolarAltitude;
+    dh = sunRadVar->cdh * sunRadVar->G_norm_extra * fd * tn;
+    gh = bh + dh;
+    if (sunSlopeGeom->aspect != UNDEF && sunSlopeGeom->slope != 0.) {
+	kb = bh / (sunRadVar->G_norm_extra * locSinSolarAltitude);
+	r_sky = (1. + cosslope) / 2.;
+	a_ln = sunVarGeom->solarAzimuth - sunSlopeGeom->aspect;
+	ln = a_ln;
+	if (a_ln > M_PI)
+	    ln = a_ln - pi2;
+	else if (a_ln < -M_PI)
+	    ln = a_ln + pi2;
+	a_ln = ln;
+	fg = sinslope - sunSlopeGeom->slope * cosslope -
+	    M_PI * sin(0.5 * sunSlopeGeom->slope) * sin(0.5 *
+							sunSlopeGeom->slope);
+	if ((sunVarGeom->isShadow == 1) || sh <= 0.)
+	    fx = r_sky + fg * 0.252271;
+	else if (sunVarGeom->solarAltitude >= 0.1) {
+	    fx = ((0.00263 - kb * (0.712 + 0.6883 * kb)) * fg + r_sky) *
+		  (1. - kb) + kb * sh / locSinSolarAltitude;
+	else if (sunVarGeom->solarAltitude < 0.1)
+	    fx = ((0.00263 - 0.712 * kb - 0.6883 * kb * kb) * fg +
+		  r_sky) * (1. - kb) + kb *
+		  sinslope * cos(a_ln) /
+		  (0.1 - 0.008 * sunVarGeom->solarAltitude);
+	dr = dh * fx;
+	/* refl. rad */
+	*rr = sunRadVar->alb * gh * (1 - cosslope) / 2.;
+    else {	/* plane */
+	dr = dh;
+	*rr = 0.;
+    return (dr);
+#define c2 -0.074
+double drad_angle_loss(double sh, double bh, double *rr,
+    double dh;
+    double diff_coeff_angleloss;
+    double refl_coeff_angleloss;
+    double c1;
+    double diff_loss_factor, refl_loss_factor;
+    double locLinke;
+	A1 = 0.0022 / tn;
+    else
+	A1 = A1b;
+    gh = bh + dh;
+	ln = a_ln;
+	if (a_ln > M_PI)
+	    ln = a_ln - pi2;
+	    ln = a_ln + pi2;
+	a_ln = ln;
+	    M_PI * sin(sunSlopeGeom->slope / 2.) * sin(sunSlopeGeom->slope /
+						       2.);
+	if ((sunVarGeom->isShadow) || (sh <= 0.))
+	    fx = ((0.00263 - kb * (0.712 + 0.6883 * kb)) * fg + r_sky) * (1. -
+									  kb)
+		+ kb * sh / locSinSolarAltitude;
+		  r_sky) * (1. - kb) + kb * sinslope * cos(a_ln) /
+	dr = dh * fx;
+	/* refl. rad */
+	dr = dh;
+	*rr = 0.;
+    c1 = 4. / (3. * M_PI);
+    diff_coeff_angleloss = sinslope
+	+ (M_PI - sunSlopeGeom->slope - sinslope) / (1 + cosslope);
+    refl_coeff_angleloss = sinslope
+	+ (sunSlopeGeom->slope - sinslope) / (1 - cosslope);
+    diff_loss_factor
+	= 1. - exp(-(c1 * diff_coeff_angleloss
+		     + c2 * diff_coeff_angleloss * diff_coeff_angleloss)
+		   / a_r);
+    refl_loss_factor
+	= 1. - exp(-(c1 * refl_coeff_angleloss
+		     + c2 * refl_coeff_angleloss * refl_coeff_angleloss)
+		   / a_r);
+    dr *= diff_loss_factor;
+    *rr *= refl_loss_factor;
+    return (dr);
Added: grass-addons/grass7/raster/r.sun.mp/sunradstruct.h
--- grass-addons/grass7/raster/r.sun.mp/sunradstruct.h	                        (rev 0)
+++ grass-addons/grass7/raster/r.sun.mp/sunradstruct.h	2017-04-03 04:54:36 UTC (rev 70825)
@@ -0,0 +1,109 @@
+r.sun: sunradstruct.h. This program was writen by Jaro Hofierka in Summer 1993 and re-engineered
+#define EPS      1.e-4
+#define HOURANGLE M_PI/12.
+struct SunGeometryConstDay
+    double lum_C11;
+    double lum_C13;
+    double lum_C22;
+    double lum_C31;
+    double lum_C33;
+    double sunrise_time;
+    double sunset_time;
+    double timeAngle;
+    double sindecl;
+    double cosdecl;
+struct SunGeometryVarDay
+    int isShadow;
+    double z_orig;
+    double zmax;
+    double zp;
+    double solarAltitude;
+    double sinSolarAltitude;
+    double tanSolarAltitude;
+    double solarAzimuth;
+    double sunAzimuthAngle;
+    double stepsinangle;
+    double stepcosangle;
+struct SunGeometryVarSlope
+    double longit_l;		/* The "longitude" difference between the inclined */
+    /* and orientated plane and the instantaneous solar position */
+    double lum_C31_l;
+    double lum_C33_l;
+    double slope;
+    double aspect;
+struct SolarRadVar
+    double cbh;
+    double cdh;
+    double linke;
+    double G_norm_extra;
+    double alb;
+struct GridGeometry
+    double xp;
+    double yp;
+    double xx0;
+    double yy0;
+    double xg0;
+    double yg0;
+    double stepx;
+    double stepy;
+    double deltx;
+    double delty;
+    double stepxy;
+    double sinlat;
+    double coslat;
