[GRASS-SVN] r70852 - in grass-addons/grass7/raster/r.pi: . r.pi.corearea r.pi.csr.mw r.pi.energy r.pi.energy.iter r.pi.enn r.pi.enn.iter r.pi.export r.pi.fnn r.pi.graph r.pi.graph.dec r.pi.graph.iter r.pi.graph.red r.pi.import r.pi.index r.pi.library r.pi.neigh r.pi.nlm.stats r.pi.odc r.pi.prob.mw r.pi.prox r.pi.searchtime r.pi.searchtime.iter r.pi.searchtime.mw
Sat Apr 8 13:05:19 PDT 2017
Author: mmetz
Date: 2017-04-08 13:05:19 -0700 (Sat, 08 Apr 2017)
New Revision: 70852
Added:
   grass-addons/grass7/raster/r.pi/r.pi.library/frag.c
Removed:
   grass-addons/grass7/raster/r.pi/r.pi.corearea/frag.c
   grass-addons/grass7/raster/r.pi/r.pi.csr.mw/frag.c
   grass-addons/grass7/raster/r.pi/r.pi.energy.iter/frag.c
   grass-addons/grass7/raster/r.pi/r.pi.energy/frag.c
   grass-addons/grass7/raster/r.pi/r.pi.enn.iter/frag.c
   grass-addons/grass7/raster/r.pi/r.pi.enn/frag.c
   grass-addons/grass7/raster/r.pi/r.pi.fnn/frag.c
   grass-addons/grass7/raster/r.pi/r.pi.graph/frag.c
   grass-addons/grass7/raster/r.pi/r.pi.import/frag.c
   grass-addons/grass7/raster/r.pi/r.pi.index/frag.c
   grass-addons/grass7/raster/r.pi/r.pi.neigh/frag.c
   grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/frag.c
   grass-addons/grass7/raster/r.pi/r.pi.odc/frag.c
   grass-addons/grass7/raster/r.pi/r.pi.prox/frag.c
   grass-addons/grass7/raster/r.pi/r.pi.searchtime.iter/frag.c
   grass-addons/grass7/raster/r.pi/r.pi.searchtime.mw/frag.c
   grass-addons/grass7/raster/r.pi/r.pi.searchtime/frag.c
   grass-addons/grass7/raster/r.pi/TODO.txt
   grass-addons/grass7/raster/r.pi/r.pi.corearea/local_proto.h
   grass-addons/grass7/raster/r.pi/r.pi.corearea/main.c
   grass-addons/grass7/raster/r.pi/r.pi.csr.mw/local_proto.h
   grass-addons/grass7/raster/r.pi/r.pi.energy.iter/local_proto.h
   grass-addons/grass7/raster/r.pi/r.pi.energy.iter/main.c
   grass-addons/grass7/raster/r.pi/r.pi.energy/local_proto.h
   grass-addons/grass7/raster/r.pi/r.pi.energy/main.c
   grass-addons/grass7/raster/r.pi/r.pi.enn.iter/local_proto.h
   grass-addons/grass7/raster/r.pi/r.pi.enn.iter/main.c
   grass-addons/grass7/raster/r.pi/r.pi.enn/local_proto.h
   grass-addons/grass7/raster/r.pi/r.pi.enn/main.c
   grass-addons/grass7/raster/r.pi/r.pi.export/frag.c
   grass-addons/grass7/raster/r.pi/r.pi.export/local_proto.h
   grass-addons/grass7/raster/r.pi/r.pi.export/main.c
   grass-addons/grass7/raster/r.pi/r.pi.fnn/local_proto.h
   grass-addons/grass7/raster/r.pi/r.pi.fnn/main.c
   grass-addons/grass7/raster/r.pi/r.pi.graph.dec/frag.c
   grass-addons/grass7/raster/r.pi/r.pi.graph.dec/local_proto.h
   grass-addons/grass7/raster/r.pi/r.pi.graph.dec/main.c
   grass-addons/grass7/raster/r.pi/r.pi.graph.iter/frag.c
   grass-addons/grass7/raster/r.pi/r.pi.graph.iter/local_proto.h
   grass-addons/grass7/raster/r.pi/r.pi.graph.iter/main.c
   grass-addons/grass7/raster/r.pi/r.pi.graph.red/frag.c
   grass-addons/grass7/raster/r.pi/r.pi.graph.red/local_proto.h
   grass-addons/grass7/raster/r.pi/r.pi.graph.red/main.c
   grass-addons/grass7/raster/r.pi/r.pi.graph/local_proto.h
   grass-addons/grass7/raster/r.pi/r.pi.graph/main.c
   grass-addons/grass7/raster/r.pi/r.pi.import/Makefile
   grass-addons/grass7/raster/r.pi/r.pi.import/local_proto.h
   grass-addons/grass7/raster/r.pi/r.pi.import/main.c
   grass-addons/grass7/raster/r.pi/r.pi.index/local_proto.h
   grass-addons/grass7/raster/r.pi/r.pi.index/main.c
   grass-addons/grass7/raster/r.pi/r.pi.library/r_pi.h
   grass-addons/grass7/raster/r.pi/r.pi.neigh/local_proto.h
   grass-addons/grass7/raster/r.pi/r.pi.neigh/main.c
   grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/local_proto.h
   grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/main.c
   grass-addons/grass7/raster/r.pi/r.pi.odc/local_proto.h
   grass-addons/grass7/raster/r.pi/r.pi.odc/main.c
   grass-addons/grass7/raster/r.pi/r.pi.prob.mw/frag.c
   grass-addons/grass7/raster/r.pi/r.pi.prob.mw/local_proto.h
   grass-addons/grass7/raster/r.pi/r.pi.prob.mw/main.c
   grass-addons/grass7/raster/r.pi/r.pi.prox/local_proto.h
   grass-addons/grass7/raster/r.pi/r.pi.prox/main.c
   grass-addons/grass7/raster/r.pi/r.pi.searchtime.iter/local_proto.h
   grass-addons/grass7/raster/r.pi/r.pi.searchtime.iter/main.c
   grass-addons/grass7/raster/r.pi/r.pi.searchtime.mw/local_proto.h
   grass-addons/grass7/raster/r.pi/r.pi.searchtime.mw/main.c
   grass-addons/grass7/raster/r.pi/r.pi.searchtime/local_proto.h
   grass-addons/grass7/raster/r.pi/r.pi.searchtime/main.c
r.pi: move frag.c to library
Modified: grass-addons/grass7/raster/r.pi/TODO.txt
--- grass-addons/grass7/raster/r.pi/TODO.txt	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/TODO.txt	2017-04-08 20:05:19 UTC (rev 70852)
@@ -1,14 +1,6 @@
 C-code:
-r.pi.corrwin and r.pi.corrwindow seem to be duplicates, the main.c version
-are slightly different, but r.pi.corrwin seems to be newer - correct?
-- r.pi.energy,r.pi.energy.iter,r.pi.searchtime have "overwrite" as default, need to be changed to option "--o"
-- remmove custom 'quiet' flag
-- convert C++ style comments
-- code must conform to C89 (variable declarations)
 - fix all the unused variables
 - fix compiler warnings
 - there are LOTs of cloned files, put them into a r.pi library (example:
@@ -28,7 +20,35 @@
        ls -l */$i
    done
+  frag.c, writeFrag()
+    outside is neighbor
+      r.pi.energy (keep in sync with search.c)
+      r.pi.energy.iter (keep in sync with search.c)
+      r.pi.export
+      r.pi.graph.dec
+      r.pi.graph.iter
+      r.pi.graph.red
+      r.pi.import
+      r.pi.prob.mw
+      r.pi.searchtime (keep in sync with search.c)
+      r.pi.searchtime.iter (keep in sync with search.c)
+      r.pi.searchtime.mw (keep in sync with search.c)
+    outside is NOT neighbor
+      r.pi.corearea
+      r.pi.enn
+      r.pi.enn.iter
+      r.pi.fnn
+      r.pi.graph
+      r.pi.index
+      r.pi.neigh
+      r.pi.nlm.stats
+      r.pi.odc
+      r.pi.prox
+- some modules allow to choose between 4 or 8 neighbors,
+  but hardcode neighbors to 4 (e.g. r.pi.energy)
 - fix SVN propsets with this helper script when uploading to Addons (Markus will do):
    grass-addons/tools/module_svn_propset.sh
Deleted: grass-addons/grass7/raster/r.pi/r.pi.corearea/frag.c
--- grass-addons/grass7/raster/r.pi/r.pi.corearea/frag.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.corearea/frag.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -1,157 +0,0 @@
-#include "local_proto.h"
-Coords *writeFrag(int *flagbuf, Coords * actpos, int row, int col, int nrows,
-		  int ncols, int nbr_cnt);
-int getNeighbors(Position * res, int *flagbuf, int x, int y, int nx, int ny,
-		 int nbr_cnt);
-		 int nbr_cnt)
-    int left, right, top, bottom;
-    int i, j;
-    int cnt = 0;
-    switch (nbr_cnt) {
-    case 4:			/* von Neumann neighborhood */
-	if (x > 0 && flagbuf[y * nx + x - 1] == 1) {
-	    res[cnt].x = x - 1;
-	    res[cnt].y = y;
-	    cnt++;
-	if (y > 0 && flagbuf[(y - 1) * nx + x] == 1) {
-	    res[cnt].x = x;
-	    res[cnt].y = y - 1;
-	    cnt++;
-	if (x < nx - 1 && flagbuf[y * nx + x + 1] == 1) {
-	    res[cnt].x = x + 1;
-	    res[cnt].y = y;
-	    cnt++;
-	if (y < ny - 1 && flagbuf[(y + 1) * nx + x] == 1) {
-	    res[cnt].x = x;
-	    res[cnt].y = y + 1;
-	    cnt++;
-	break;
-    case 8:			/* Moore neighborhood */
-	left = x > 0 ? x - 1 : 0;
-	top = y > 0 ? y - 1 : 0;
-	right = x < nx - 1 ? x + 1 : nx - 1;
-	bottom = y < ny - 1 ? y + 1 : ny - 1;
-	for (i = left; i <= right; i++) {
-	    for (j = top; j <= bottom; j++) {
-		if (!(i == x && j == y) && flagbuf[j * nx + i] == 1) {
-		    res[cnt].x = i;
-		    res[cnt].y = j;
-		    cnt++;
-	break;
-    return cnt;
-    int x, y, i;
-    Position *list = (Position *) G_malloc(nrows * ncols * sizeof(Position));
-    Position *first = list;
-    Position *last = list;
-    Position *nbr_list = (Position *) G_malloc(8 * sizeof(Position));
-    /* count neighbors */
-    int neighbors = 0;
-    if (col > 0 && flagbuf[row * ncols + col - 1] != 0)
-	neighbors++;
-    if (row > 0 && flagbuf[(row - 1) * ncols + col] != 0)
-	neighbors++;
-    if (col < ncols - 1 && flagbuf[row * ncols + col + 1] != 0)
-	neighbors++;
-    if (row < nrows - 1 && flagbuf[(row + 1) * ncols + col] != 0)
-	neighbors++;
-    /* write first cell */
-    actpos->x = col;
-    actpos->y = row;
-    actpos->neighbors = neighbors;
-    actpos++;
-    flagbuf[row * ncols + col] = -1;
-    /* push position on fifo-list */
-    last->x = col;
-    last->y = row;
-    last++;
-    while (first < last) {
-	/* get position from fifo-list */
-	int r = first->y;
-	int c = first->x;
-	/* add neighbors to fifo-list */
-	int cnt =
-	    getNeighbors(nbr_list, flagbuf, c, r, ncols, nrows, nbr_cnt);
-	first++;
-	for (i = 0; i < cnt; i++) {
-	    x = nbr_list[i].x;
-	    y = nbr_list[i].y;
-	    /* add position to fifo-list */
-	    last->x = x;
-	    last->y = y;
-	    last++;
-	    neighbors = 0;
-	    if (x > 0 && flagbuf[y * ncols + x - 1] != 0)
-		neighbors++;
-	    if (y > 0 && flagbuf[(y - 1) * ncols + x] != 0)
-		neighbors++;
-	    if (x < ncols - 1 && flagbuf[y * ncols + x + 1] != 0)
-		neighbors++;
-	    if (y < nrows - 1 && flagbuf[(y + 1) * ncols + x] != 0)
-		neighbors++;
-	    /* set values */
-	    actpos->x = x;
-	    actpos->y = y;
-	    actpos++;
-	    flagbuf[y * ncols + x] = -1;
-    G_free(list);
-    G_free(nbr_list);
-    return actpos;
-int writeFragments(int *flagbuf, int nrows, int ncols, int nbr_cnt)
-    int row, col;
-    int fragcount = 0;
-    /* find fragments */
-    for (row = 0; row < nrows; row++) {
-	for (col = 0; col < ncols; col++) {
-	    if (flagbuf[row * ncols + col] == 1) {
-		fragcount++;
-		fragments[fragcount] =
-		    writeFrag(flagbuf, fragments[fragcount - 1], row, col,
-			      nrows, ncols, nbr_cnt);
-    return fragcount;
Modified: grass-addons/grass7/raster/r.pi/r.pi.corearea/local_proto.h
--- grass-addons/grass7/raster/r.pi/r.pi.corearea/local_proto.h	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.corearea/local_proto.h	2017-04-08 20:05:19 UTC (rev 70852)
@@ -19,11 +19,6 @@
 typedef struct
-    int x, y;
-} Position;
-typedef struct
     double x, y;
 } Vector2;
@@ -37,9 +32,6 @@
 typedef DCELL(f_statmethod) (DCELL *, int);
 typedef DCELL(f_propmethod) (DCELL, DCELL);
-/* frag.c */
-int writeFragments(int *flagbuf, int nrows, int ncols, int nbr_cnt);
 /* func.c */
 void find_borders(int *flagbuf, int nrows, int ncols, int fragcount);
 void init_border_values(double distance, double angle, int buffer,
Modified: grass-addons/grass7/raster/r.pi/r.pi.corearea/main.c
--- grass-addons/grass7/raster/r.pi/r.pi.corearea/main.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.corearea/main.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -352,7 +352,7 @@
-    fragcount = writeFragments(flagbuf, nrows, ncols, nbr_count);
+    fragcount = writeFragments(fragments, flagbuf, nrows, ncols, nbr_count);
     /* create a patch map */
     for (i = 0; i < fragcount; i++) {
Deleted: grass-addons/grass7/raster/r.pi/r.pi.csr.mw/frag.c
--- grass-addons/grass7/raster/r.pi/r.pi.csr.mw/frag.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.csr.mw/frag.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -1,140 +0,0 @@
-		  int ncols, double distance);
-		 double distance);
-		 double distance)
-    int i, j;
-    double dist_q = distance * distance;
-    int cnt = 0;
-    left = x - distance < 0 ? 0 : Round(x - distance);
-    right = x + distance > nx - 1 ? nx - 1 : Round(x + distance);
-    top = y - distance < 0 ? 0 : Round(y - distance);
-    bottom = y + distance > ny - 1 ? ny - 1 : Round(y + distance);
-		int dx = i - x;
-		int dy = j - y;
-		int q_sum = dx * dx + dy * dy;
-		if (q_sum <= dist_q) {
-		    res[cnt].x = i;
-		    res[cnt].y = j;
-		    cnt++;
-    return cnt;
-    int x, y, i;
-    int neighb_max_count = Round(4 * distance * distance);
-	(Position *) G_malloc(neighb_max_count * sizeof(Position));
-    if (col <= 0 || flagbuf[row * ncols + col - 1] != 0)
-	neighbors++;
-    if (row <= 0 || flagbuf[(row - 1) * ncols + col] != 0)
-	neighbors++;
-    if (col >= ncols - 1 || flagbuf[row * ncols + col + 1] != 0)
-	neighbors++;
-    if (row >= nrows - 1 || flagbuf[(row + 1) * ncols + col] != 0)
-	neighbors++;
-    actpos->x = col;
-    actpos->y = row;
-    actpos++;
-    last->x = col;
-    last->y = row;
-    last++;
-	int r = first->y;
-	int c = first->x;
-	int cnt =
-	    getNeighbors(nbr_list, flagbuf, c, r, ncols, nrows, distance);
-	first++;
-	    last->x = x;
-	    last->y = y;
-	    last++;
-	    neighbors = 0;
-	    if (x <= 0 || flagbuf[y * ncols + x - 1] != 0)
-		neighbors++;
-	    if (y <= 0 || flagbuf[(y - 1) * ncols + x] != 0)
-		neighbors++;
-	    if (x >= ncols - 1 || flagbuf[y * ncols + x + 1] != 0)
-		neighbors++;
-	    if (y >= nrows - 1 || flagbuf[(y + 1) * ncols + x] != 0)
-		neighbors++;
-	    /* set values */
-	    actpos->x = x;
-	    actpos->y = y;
-	    actpos++;
-    G_free(list);
-    G_free(nbr_list);
-    return actpos;
-int writeFragments(int *flagbuf, int nrows, int ncols, double distance)
-    int row, col;
-		fragcount++;
-			      nrows, ncols, distance);
-    return fragcount;
Modified: grass-addons/grass7/raster/r.pi/r.pi.csr.mw/local_proto.h
--- grass-addons/grass7/raster/r.pi/r.pi.csr.mw/local_proto.h	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.csr.mw/local_proto.h	2017-04-08 20:05:19 UTC (rev 70852)
@@ -18,11 +18,6 @@
 #define GLOBAL extern
 #endif
-typedef struct
-    int x, y;
-} Position;
 typedef void (f_method) (DCELL * values, int *map, int *mask, int n,
 			  int size);
Deleted: grass-addons/grass7/raster/r.pi/r.pi.energy/frag.c
--- grass-addons/grass7/raster/r.pi/r.pi.energy/frag.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.energy/frag.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -1,156 +0,0 @@
-		 int nbr_cnt);
-		 int nbr_cnt)
-    int i, j;
-    int cnt = 0;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	break;
-		    res[cnt].x = i;
-		    res[cnt].y = j;
-		    cnt++;
-	break;
-    return cnt;
-    int x, y, i;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-    actpos->x = col;
-    actpos->y = row;
-    actpos++;
-    last->x = col;
-    last->y = row;
-    last++;
-	int r = first->y;
-	int c = first->x;
-	int cnt =
-	first++;
-	    last->x = x;
-	    last->y = y;
-	    last++;
-	    neighbors = 0;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-	    /* set values */
-	    actpos->x = x;
-	    actpos->y = y;
-	    actpos++;
-    G_free(list);
-    G_free(nbr_list);
-    return actpos;
-    int row, col;
-		fragcount++;
-    return fragcount;
Modified: grass-addons/grass7/raster/r.pi/r.pi.energy/local_proto.h
--- grass-addons/grass7/raster/r.pi/r.pi.energy/local_proto.h	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.energy/local_proto.h	2017-04-08 20:05:19 UTC (rev 70852)
@@ -21,11 +21,6 @@
 typedef struct
     int x, y;
-} Position;
-typedef struct
-    int x, y;
     double dir;
     DCELL energy;
     int finished;
@@ -48,9 +43,6 @@
-/* frag.c */
 /* search.c */
 void perform_search(int *map, DCELL * costmap, int n, int fragcount, int sx, int sy);
Modified: grass-addons/grass7/raster/r.pi/r.pi.energy/main.c
--- grass-addons/grass7/raster/r.pi/r.pi.energy/main.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.energy/main.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -449,7 +449,7 @@
        print_d_buffer(costmap, sx, sy); */
-    fragcount = writeFragments(map, sy, sx, neighb_count);
+    fragcount = writeFragments(fragments, map, sy, sx, neighb_count);
     /* test output */
     /*      print_fragments(); */
Deleted: grass-addons/grass7/raster/r.pi/r.pi.energy.iter/frag.c
--- grass-addons/grass7/raster/r.pi/r.pi.energy.iter/frag.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.energy.iter/frag.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -1,156 +0,0 @@
-		 int nbr_cnt);
-		 int nbr_cnt)
-    int i, j;
-    int cnt = 0;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	break;
-		    res[cnt].x = i;
-		    res[cnt].y = j;
-		    cnt++;
-	break;
-    return cnt;
-    int x, y, i;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-    actpos->x = col;
-    actpos->y = row;
-    actpos++;
-    last->x = col;
-    last->y = row;
-    last++;
-	int r = first->y;
-	int c = first->x;
-	int cnt =
-	first++;
-	    last->x = x;
-	    last->y = y;
-	    last++;
-	    neighbors = 0;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-	    /* set values */
-	    actpos->x = x;
-	    actpos->y = y;
-	    actpos++;
-    G_free(list);
-    G_free(nbr_list);
-    return actpos;
-    int row, col;
-		fragcount++;
-    return fragcount;
Modified: grass-addons/grass7/raster/r.pi/r.pi.energy.iter/local_proto.h
--- grass-addons/grass7/raster/r.pi/r.pi.energy.iter/local_proto.h	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.energy.iter/local_proto.h	2017-04-08 20:05:19 UTC (rev 70852)
@@ -20,11 +20,6 @@
 typedef struct
     int x, y;
-} Position;
-typedef struct
-    int x, y;
     double dir;
     DCELL energy;
     int finished;
@@ -47,9 +42,6 @@
-/* frag.c */
 /* search.c */
 void perform_search(int *map, DCELL * costmap, int remove_indi, int n, int fragcount, int sx, int sy);
Modified: grass-addons/grass7/raster/r.pi/r.pi.energy.iter/main.c
--- grass-addons/grass7/raster/r.pi/r.pi.energy.iter/main.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.energy.iter/main.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -479,7 +479,7 @@
     /* test output */
Deleted: grass-addons/grass7/raster/r.pi/r.pi.enn/frag.c
--- grass-addons/grass7/raster/r.pi/r.pi.enn/frag.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.enn/frag.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -1,139 +0,0 @@
-#include <string.h>
-#include <stdlib.h>
-#include <unistd.h>
-#include <grass/gis.h>
-#include <grass/glocale.h>
-#include <grass/stats.h>
-#include <math.h>
-typedef struct
-    int x, y;
-} Position;
-int getNeighbors(Position * res, int x, int y, int nx, int ny, int nbr_cnt)
-    int i, j;
-    int cnt = 0;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	break;
-		    res[cnt].x = i;
-		    res[cnt].y = j;
-		    cnt++;
-	break;
-    return cnt;
-void writeFrag(int row, int col, int nbr_cnt)
-    int x, y, i;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-    actpos->x = col;
-    actpos->y = row;
-    actpos++;
-    last->x = col;
-    last->y = row;
-    last++;
-	int r = first->y;
-	int c = first->x;
-	int cnt = getNeighbors(nbr_list, c, r, ncols, nrows, nbr_cnt);
-	first++;
-	    last->x = x;
-	    last->y = y;
-	    last++;
-	    neighbors = 0;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-	    /* set values */
-	    actpos->x = x;
-	    actpos->y = y;
-	    actpos++;
-    G_free(list);
-    G_free(nbr_list);
-    return;
Modified: grass-addons/grass7/raster/r.pi/r.pi.enn/local_proto.h
--- grass-addons/grass7/raster/r.pi/r.pi.enn/local_proto.h	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.enn/local_proto.h	2017-04-08 20:05:19 UTC (rev 70852)
@@ -20,8 +20,6 @@
 typedef int (f_func) (DCELL *, int, int *, int, f_statmethod);
-void writeFrag(int row, int col, int nbr_cnt);
 DCELL value(DCELL * vals, int count);
 int get_dist_matrix(int count);
Modified: grass-addons/grass7/raster/r.pi/r.pi.enn/main.c
--- grass-addons/grass7/raster/r.pi/r.pi.enn/main.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.enn/main.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -300,7 +300,7 @@
 		fragcount++;
-		writeFrag(row, col, neighb_count);
+		writeFrag(flagbuf, actpos, row, col, nrows, ncols, neighb_count);
 		fragments[fragcount] = actpos;
Deleted: grass-addons/grass7/raster/r.pi/r.pi.enn.iter/frag.c
--- grass-addons/grass7/raster/r.pi/r.pi.enn.iter/frag.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.enn.iter/frag.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -1,157 +0,0 @@
-		 int nbr_cnt);
-		 int nbr_cnt)
-    int i, j;
-    int cnt = 0;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	break;
-		    res[cnt].x = i;
-		    res[cnt].y = j;
-		    cnt++;
-	break;
-    return cnt;
-    int x, y, i;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-    actpos->x = col;
-    actpos->y = row;
-    actpos++;
-    last->x = col;
-    last->y = row;
-    last++;
-	int r = first->y;
-	int c = first->x;
-	int cnt =
-	first++;
-	    last->x = x;
-	    last->y = y;
-	    last++;
-	    neighbors = 0;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-	    /* set values */
-	    actpos->x = x;
-	    actpos->y = y;
-	    actpos++;
-    G_free(list);
-    G_free(nbr_list);
-    return actpos;
-    int row, col;
-    fragments[0] = cells;
-		fragcount++;
-    return fragcount;
Modified: grass-addons/grass7/raster/r.pi/r.pi.enn.iter/local_proto.h
--- grass-addons/grass7/raster/r.pi/r.pi.enn.iter/local_proto.h	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.enn.iter/local_proto.h	2017-04-08 20:05:19 UTC (rev 70852)
@@ -21,19 +21,11 @@
 typedef struct
     int x, y;
-} Position;
-typedef struct
-    int x, y;
 } Point;
 typedef void (f_func) (DCELL *, Coords **, int, f_statmethod);
-/* frag.c */
 /* func.c */
 void f_distance(DCELL * vals, Coords ** frags, int count,
 		f_statmethod statmethod);
Modified: grass-addons/grass7/raster/r.pi/r.pi.enn.iter/main.c
--- grass-addons/grass7/raster/r.pi/r.pi.enn.iter/main.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.enn.iter/main.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -239,7 +239,7 @@
     Rast_close(in_fd);
-    fragcount = writeFragments(flagbuf, nrows, ncols, neighb_count);
+    fragcount = writeFragments(fragments, flagbuf, nrows, ncols, neighb_count);
     /* perform actual function on the patches */
     values = (DCELL *) G_malloc(3 * fragcount * sizeof(DCELL));
Modified: grass-addons/grass7/raster/r.pi/r.pi.export/frag.c
--- grass-addons/grass7/raster/r.pi/r.pi.export/frag.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.export/frag.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -1,6 +1,6 @@
-Coords *writeFrag(DCELL * flagbuf, Coords * actpos, int row, int col,
+Coords *writeFrag_DCELL(DCELL * flagbuf, Coords * actpos, int row, int col,
 		  int nrows, int ncols, int nbr_cnt, int fragcount);
 int getNeighbors(Position * res, DCELL * flagbuf, int x, int y, int nx,
 		 int ny, int nbr_cnt);
@@ -56,7 +56,7 @@
     return cnt;
     int x, y, i;
@@ -151,7 +151,7 @@
     return actpos;
-int writeFragments(DCELL * flagbuf, int nrows, int ncols, int nbr_cnt)
+int writeFragments_DCELL(DCELL * flagbuf, int nrows, int ncols, int nbr_cnt)
     int row, col;
     int fragcount = 0;
@@ -163,7 +163,7 @@
 		fragcount++;
+		    writeFrag_DCELL(flagbuf, fragments[fragcount - 1], row, col,
 			      nrows, ncols, nbr_cnt, fragcount);
Modified: grass-addons/grass7/raster/r.pi/r.pi.export/local_proto.h
--- grass-addons/grass7/raster/r.pi/r.pi.export/local_proto.h	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.export/local_proto.h	2017-04-08 20:05:19 UTC (rev 70852)
@@ -21,18 +21,13 @@
 typedef struct
     int x, y;
-} Position;
-typedef struct
-    int x, y;
     int patch;
 } PatchPoint;
 /* frag.c */
-int writeFragments(DCELL * flagbuf, int nrows, int ncols, int nbr_cnt);
+int writeFragments_DCELL(DCELL * flagbuf, int nrows, int ncols, int nbr_cnt);
 /* global variables */
 GLOBAL Coords **fragments;
Modified: grass-addons/grass7/raster/r.pi/r.pi.export/main.c
--- grass-addons/grass7/raster/r.pi/r.pi.export/main.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.export/main.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -231,7 +231,7 @@
     Rast_close(in_fd);
+    fragcount = writeFragments_DCELL(map, sy, sx, neighb_count);
     G_message("Writing output...");
Deleted: grass-addons/grass7/raster/r.pi/r.pi.fnn/frag.c
--- grass-addons/grass7/raster/r.pi/r.pi.fnn/frag.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.fnn/frag.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -1,139 +0,0 @@
-#include <math.h>
-typedef struct
-    int x, y;
-} Position;
-    int i, j;
-    int cnt = 0;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	break;
-		    res[cnt].x = i;
-		    res[cnt].y = j;
-		    cnt++;
-	break;
-    return cnt;
-    int x, y, i;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-    actpos->x = col;
-    actpos->y = row;
-    actpos++;
-    last->x = col;
-    last->y = row;
-    last++;
-	int r = first->y;
-	int c = first->x;
-	first++;
-	    last->x = x;
-	    last->y = y;
-	    last++;
-	    neighbors = 0;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-	    /* set values */
-	    actpos->x = x;
-	    actpos->y = y;
-	    actpos++;
-    G_free(list);
-    G_free(nbr_list);
-    return;
Modified: grass-addons/grass7/raster/r.pi/r.pi.fnn/local_proto.h
--- grass-addons/grass7/raster/r.pi/r.pi.fnn/local_proto.h	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.fnn/local_proto.h	2017-04-08 20:05:19 UTC (rev 70852)
@@ -25,7 +25,7 @@
+void writeFrag_local(int row, int col, int nbr_cnt);
Modified: grass-addons/grass7/raster/r.pi/r.pi.fnn/main.c
--- grass-addons/grass7/raster/r.pi/r.pi.fnn/main.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.fnn/main.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -83,7 +83,7 @@
     char *p;
     /* neighbors count */
-    int neighb_count;
+    int nbr_count;
     int row, col, i, j, m;
     int method_count;
@@ -291,7 +291,7 @@
     compute_stat = statmethods[statmethod].method;
     /* get number of cell-neighbors */
-    neighb_count = flag.adjacent->answer ? 8 : 4;
+    nbr_count = flag.adjacent->answer ? 8 : 4;
     /* allocate the cell buffers */
     costmap = (DCELL *) G_malloc(nrows * ncols * sizeof(DCELL));
@@ -330,18 +330,11 @@
 	G_percent(row, nrows, 2);
     Rast_close(in_fd);
-		fragcount++;
-		fragments[fragcount] = actpos;
     G_percent(nrows, nrows, 2);
+    /* find fragments */
     /* generate the distance matrix */
     get_dist_matrix(fragcount);
Deleted: grass-addons/grass7/raster/r.pi/r.pi.graph/frag.c
--- grass-addons/grass7/raster/r.pi/r.pi.graph/frag.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.graph/frag.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -1,156 +0,0 @@
-		 int nbr_cnt);
-		 int nbr_cnt)
-    int i, j;
-    int cnt = 0;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	break;
-		    res[cnt].x = i;
-		    res[cnt].y = j;
-		    cnt++;
-	break;
-    return cnt;
-    int x, y, i;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-    actpos->x = col;
-    actpos->y = row;
-    actpos++;
-    last->x = col;
-    last->y = row;
-    last++;
-	int r = first->y;
-	int c = first->x;
-	int cnt =
-	first++;
-	    last->x = x;
-	    last->y = y;
-	    last++;
-	    neighbors = 0;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-	    /* set values */
-	    actpos->x = x;
-	    actpos->y = y;
-	    actpos++;
-    G_free(list);
-    G_free(nbr_list);
-    return actpos;
-    int row, col;
-		fragcount++;
-    return fragcount;
Modified: grass-addons/grass7/raster/r.pi/r.pi.graph/local_proto.h
--- grass-addons/grass7/raster/r.pi/r.pi.graph/local_proto.h	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.graph/local_proto.h	2017-04-08 20:05:19 UTC (rev 70852)
@@ -16,17 +16,9 @@
 #endif
-typedef struct
-    int x, y;
-} Position;
 typedef void (f_neighborhood) (DCELL max_dist, int fragcount);
 typedef void (f_index) (DCELL * values, int fragcount);
-/* frag.c */
 /* func.c */
 int get_dist_matrix(int fragcount);
 void f_nearest_neighbor(DCELL max_dist, int fragcount);
Modified: grass-addons/grass7/raster/r.pi/r.pi.graph/main.c
--- grass-addons/grass7/raster/r.pi/r.pi.graph/main.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.graph/main.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -269,7 +269,7 @@
     /* allocate distance matrix */
     distmatrix = (DCELL *) G_malloc(fragcount * fragcount * sizeof(DCELL));
Modified: grass-addons/grass7/raster/r.pi/r.pi.graph.dec/frag.c
--- grass-addons/grass7/raster/r.pi/r.pi.graph.dec/frag.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.graph.dec/frag.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -1,11 +1,6 @@
-typedef struct
-    int x, y;
-} Position;
-Coords *writeFrag(int *flagbuf, Coords * curpos, int row, int col, int nrows,
+Coords *writeFrag_local(int *flagbuf, Coords * curpos, int row, int col, int nrows,
 		 int nbr_cnt);
@@ -60,7 +55,7 @@
     return cnt;
     int x, y, i;
@@ -72,13 +67,13 @@
     int neighbors = 0;
+    if (col > 0 && flagbuf[row * ncols + col - 1] != 0)
 	neighbors++;
+    if (row > 0 && flagbuf[(row - 1) * ncols + col] != 0)
 	neighbors++;
+    if (col < ncols - 1 && flagbuf[row * ncols + col + 1] != 0)
 	neighbors++;
+    if (row < nrows - 1 && flagbuf[(row + 1) * ncols + col] != 0)
 	neighbors++;
@@ -115,13 +110,13 @@
 	    neighbors = 0;
+	    if (x > 0 && flagbuf[y * ncols + x - 1] != 0)
 		neighbors++;
+	    if (y > 0 && flagbuf[(y - 1) * ncols + x] != 0)
 		neighbors++;
+	    if (x < ncols - 1 && flagbuf[y * ncols + x + 1] != 0)
 		neighbors++;
+	    if (y < nrows - 1 && flagbuf[(y + 1) * ncols + x] != 0)
 		neighbors++;
 	    /* set values */
@@ -139,7 +134,7 @@
     return curpos;
-int writeFragments(Patch * fragments, int *flagbuf, int nrows, int ncols,
+int writeFragments_local(Patch * fragments, int *flagbuf, int nrows, int ncols,
 		   int nbr_cnt)
     int row, col;
@@ -154,6 +149,7 @@
 		fragments[fragcount].first_cell =
 		    writeFrag(flagbuf, fragments[fragcount - 1].first_cell,
 			      row, col, nrows, ncols, nbr_cnt);
+		/* divide by sizeof(Patch *) ? */
 		fragments[fragcount - 1].count =
 		    fragments[fragcount].first_cell - fragments[fragcount -
 								1].first_cell;
Modified: grass-addons/grass7/raster/r.pi/r.pi.graph.dec/local_proto.h
--- grass-addons/grass7/raster/r.pi/r.pi.graph.dec/local_proto.h	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.graph.dec/local_proto.h	2017-04-08 20:05:19 UTC (rev 70852)
@@ -41,9 +41,8 @@
 			 DCELL * distmatrix);
 /* frag.c */
 		   int nbr_cnt);
 /* func.c */
 int get_dist_matrix(DCELL * distmatrix, Patch * fragments, int fragcount);
Modified: grass-addons/grass7/raster/r.pi/r.pi.graph.dec/main.c
--- grass-addons/grass7/raster/r.pi/r.pi.graph.dec/main.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.graph.dec/main.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -354,7 +354,7 @@
     fragcount =
-	writeFragments(fragments, flagbuf, nrows, ncols, nbr_count);
+	writeFragments_local(fragments, flagbuf, nrows, ncols, nbr_count);
     distmatrix =
Modified: grass-addons/grass7/raster/r.pi/r.pi.graph.iter/frag.c
--- grass-addons/grass7/raster/r.pi/r.pi.graph.iter/frag.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.graph.iter/frag.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -1,11 +1,6 @@
-typedef struct
-    int x, y;
-} Position;
 		 int nbr_cnt);
@@ -60,7 +55,7 @@
     return cnt;
     int x, y, i;
@@ -72,13 +67,13 @@
     int neighbors = 0;
 	neighbors++;
 	neighbors++;
 	neighbors++;
 	neighbors++;
 	    neighbors = 0;
 		neighbors++;
 		neighbors++;
 		neighbors++;
 		neighbors++;
 	    /* set values */
@@ -139,7 +134,7 @@
     return curpos;
 		   int nbr_cnt)
     int row, col;
@@ -154,6 +149,7 @@
 								1].first_cell;
Modified: grass-addons/grass7/raster/r.pi/r.pi.graph.iter/local_proto.h
--- grass-addons/grass7/raster/r.pi/r.pi.graph.iter/local_proto.h	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.graph.iter/local_proto.h	2017-04-08 20:05:19 UTC (rev 70852)
@@ -36,7 +36,7 @@
 /* frag.c */
 		   int nbr_cnt);
 /* func.c */
Modified: grass-addons/grass7/raster/r.pi/r.pi.graph.iter/main.c
--- grass-addons/grass7/raster/r.pi/r.pi.graph.iter/main.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.graph.iter/main.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -288,7 +288,7 @@
     fragcount =
     distmatrix =
Modified: grass-addons/grass7/raster/r.pi/r.pi.graph.red/frag.c
--- grass-addons/grass7/raster/r.pi/r.pi.graph.red/frag.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.graph.red/frag.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -1,11 +1,7 @@
-typedef struct
-    int x, y;
-} Position;
 		 int nbr_cnt);
@@ -60,7 +56,7 @@
     return cnt;
     int x, y, i;
@@ -72,13 +68,13 @@
     int neighbors = 0;
 	neighbors++;
 	neighbors++;
 	neighbors++;
 	neighbors++;
@@ -115,13 +111,13 @@
 	    neighbors = 0;
 		neighbors++;
 		neighbors++;
 		neighbors++;
 		neighbors++;
 	    /* set values */
@@ -139,7 +135,7 @@
     return curpos;
 		   int nbr_cnt)
     int row, col;
@@ -154,6 +150,7 @@
 								1].first_cell;
Modified: grass-addons/grass7/raster/r.pi/r.pi.graph.red/local_proto.h
--- grass-addons/grass7/raster/r.pi/r.pi.graph.red/local_proto.h	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.graph.red/local_proto.h	2017-04-08 20:05:19 UTC (rev 70852)
@@ -38,7 +38,7 @@
 /* frag.c */
 		   int nbr_cnt);
 /* func.c */
Modified: grass-addons/grass7/raster/r.pi/r.pi.graph.red/main.c
--- grass-addons/grass7/raster/r.pi/r.pi.graph.red/main.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.graph.red/main.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -338,7 +338,7 @@
     fragcount =
     distmatrix =
Modified: grass-addons/grass7/raster/r.pi/r.pi.import/Makefile
--- grass-addons/grass7/raster/r.pi/r.pi.import/Makefile	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.import/Makefile	2017-04-08 20:05:19 UTC (rev 70852)
@@ -2,7 +2,10 @@
 PGM = r.pi.import
-LIBES = $(STATSLIB) $(RASTERLIB) $(GISLIB)
+LIB_NAME = grass_rpi
+RPI_LIB  = -l$(LIB_NAME)
+LIBES = $(STATSLIB) $(RASTERLIB) $(GISLIB) $(RPI_LIB)
 DEPENDENCIES = $(STATSDEP) $(RASTERDEP) $(GISDEP)
 include $(MODULE_TOPDIR)/include/Make/Module.make
Deleted: grass-addons/grass7/raster/r.pi/r.pi.import/frag.c
--- grass-addons/grass7/raster/r.pi/r.pi.import/frag.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.import/frag.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -1,156 +0,0 @@
-		 int nbr_cnt);
-		 int nbr_cnt)
-    int i, j;
-    int cnt = 0;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	break;
-		    res[cnt].x = i;
-		    res[cnt].y = j;
-		    cnt++;
-	break;
-    return cnt;
-    int x, y, i;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-    actpos->x = col;
-    actpos->y = row;
-    actpos++;
-    last->x = col;
-    last->y = row;
-    last++;
-	int r = first->y;
-	int c = first->x;
-	int cnt =
-	first++;
-	    last->x = x;
-	    last->y = y;
-	    last++;
-	    neighbors = 0;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-	    /* set values */
-	    actpos->x = x;
-	    actpos->y = y;
-	    actpos++;
-    G_free(list);
-    G_free(nbr_list);
-    return actpos;
-    int row, col;
-		fragcount++;
-    return fragcount;
Modified: grass-addons/grass7/raster/r.pi/r.pi.import/local_proto.h
--- grass-addons/grass7/raster/r.pi/r.pi.import/local_proto.h	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.import/local_proto.h	2017-04-08 20:05:19 UTC (rev 70852)
@@ -22,16 +22,8 @@
 #endif
-typedef struct
-    int x, y;
-} Position;
-/* frag.c */
 /* parse.c */
 void parse(DCELL * values, char *file_name, int id_col, int val_col, int fragcount);
Modified: grass-addons/grass7/raster/r.pi/r.pi.import/main.c
--- grass-addons/grass7/raster/r.pi/r.pi.import/main.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.import/main.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -177,7 +177,7 @@
     Rast_close(in_fd);
     /* find fragment values */
     /* parse input */
     parse(values, parm.input->answer, id_col, val_col, fragcount);
Deleted: grass-addons/grass7/raster/r.pi/r.pi.index/frag.c
--- grass-addons/grass7/raster/r.pi/r.pi.index/frag.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.index/frag.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -1,139 +0,0 @@
-#include <math.h>
-typedef struct
-    int x, y;
-} Position;
-int getNeighbors(Position * res, int *flagbuf, int x, int y, int nx, int ny, int nbr_cnt);
-    int i, j;
-    int cnt = 0;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	break;
-		    res[cnt].x = i;
-		    res[cnt].y = j;
-		    cnt++;
-	break;
-    return cnt;
-void writeFrag(int *flagbuf, int row, int col, int nrows, int ncols, int nbr_cnt)
-    int x, y, i;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-    actpos->x = col;
-    actpos->y = row;
-    actpos++;
-    last->x = col;
-    last->y = row;
-    last++;
-	int r = first->y;
-	int c = first->x;
-	int cnt = getNeighbors(nbr_list, flagbuf, c, r, ncols, nrows, nbr_cnt);
-	first++;
-	    last->x = x;
-	    last->y = y;
-	    last++;
-	    neighbors = 0;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-	    /* set values */
-	    actpos->x = x;
-	    actpos->y = y;
-	    actpos++;
-    G_free(list);
-    G_free(nbr_list);
Modified: grass-addons/grass7/raster/r.pi/r.pi.index/local_proto.h
--- grass-addons/grass7/raster/r.pi/r.pi.index/local_proto.h	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.index/local_proto.h	2017-04-08 20:05:19 UTC (rev 70852)
@@ -9,8 +9,6 @@
 #endif
-extern void writeFrag(int *flagbuf, int row, int col, int nrows, int ncols, int nbr_cnt);
 extern int f_area(DCELL * vals, Coords ** frags, int);
 extern int f_perim(DCELL * vals, Coords ** frags, int);
 extern int f_shapeindex(DCELL *, Coords **, int);
Modified: grass-addons/grass7/raster/r.pi/r.pi.index/main.c
--- grass-addons/grass7/raster/r.pi/r.pi.index/main.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.index/main.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -68,7 +68,7 @@
     f_func *compute_values;
-    int neighb_count;
+    int nbr_count;
     char *p;
@@ -187,7 +187,7 @@
     compute_values = menu[method].method;
     cells = (Coords *) G_malloc(nrows * ncols * sizeof(Coords));
@@ -220,18 +220,11 @@
-		fragcount++;
-		writeFrag(flagbuf, row, col, nrows, ncols, neighb_count);
     G_message("Performing operation...");
     values = (DCELL *) G_malloc(fragcount * sizeof(DCELL));
Copied: grass-addons/grass7/raster/r.pi/r.pi.library/frag.c (from rev 70847, grass-addons/grass7/raster/r.pi/r.pi.corearea/frag.c)
--- grass-addons/grass7/raster/r.pi/r.pi.library/frag.c	                        (rev 0)
+++ grass-addons/grass7/raster/r.pi/r.pi.library/frag.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -0,0 +1,160 @@
+#include "r_pi.h"
+int getNeighbors(Position * res, int *flagbuf, int x, int y, int nx, int ny,
+		 int nbr_cnt);
+		 int nbr_cnt)
+    int left, right, top, bottom;
+    int i, j;
+    int cnt = 0;
+    switch (nbr_cnt) {
+    case 4:			/* von Neumann neighborhood */
+	if (x > 0 && flagbuf[y * nx + x - 1] == 1) {
+	    res[cnt].x = x - 1;
+	    res[cnt].y = y;
+	    cnt++;
+	if (y > 0 && flagbuf[(y - 1) * nx + x] == 1) {
+	    res[cnt].x = x;
+	    res[cnt].y = y - 1;
+	    cnt++;
+	if (x < nx - 1 && flagbuf[y * nx + x + 1] == 1) {
+	    res[cnt].x = x + 1;
+	    res[cnt].y = y;
+	    cnt++;
+	if (y < ny - 1 && flagbuf[(y + 1) * nx + x] == 1) {
+	    res[cnt].x = x;
+	    res[cnt].y = y + 1;
+	    cnt++;
+	break;
+    case 8:			/* Moore neighborhood */
+	left = x > 0 ? x - 1 : 0;
+	top = y > 0 ? y - 1 : 0;
+	right = x < nx - 1 ? x + 1 : nx - 1;
+	bottom = y < ny - 1 ? y + 1 : ny - 1;
+	for (i = left; i <= right; i++) {
+	    for (j = top; j <= bottom; j++) {
+		if (!(i == x && j == y) && flagbuf[j * nx + i] == 1) {
+		    res[cnt].x = i;
+		    res[cnt].y = j;
+		    cnt++;
+	break;
+    return cnt;
+Coords *writeFrag(int *flagbuf, Coords * actpos, int row, int col, int nrows,
+		  int ncols, int nbr_cnt)
+    int x, y, i;
+    Position *list = (Position *) G_malloc(nrows * ncols * sizeof(Position));
+    Position *first = list;
+    Position *last = list;
+    Position *nbr_list = (Position *) G_malloc(8 * sizeof(Position));
+    /* count neighbors */
+    int neighbors = 0;
+    /* cells outside the current region are treated as background,
+     * as in fragstats:
+     * "The distinction among nodata, background, border, and boundary
+     * and how they affect the landscape analysis and the calculations
+     * of various metrics is a source of great confusion and thus
+     * great importance." */
+	neighbors++;
+	neighbors++;
+	neighbors++;
+	neighbors++;
+    /* write first cell */
+    actpos->x = col;
+    actpos->y = row;
+    actpos->neighbors = neighbors;
+    actpos++;
+    flagbuf[row * ncols + col] = -1;
+    /* push position on fifo-list */
+    last->x = col;
+    last->y = row;
+    last++;
+    while (first < last) {
+	/* get position from fifo-list */
+	int r = first->y;
+	int c = first->x;
+	/* add neighbors to fifo-list */
+	int cnt =
+	    getNeighbors(nbr_list, flagbuf, c, r, ncols, nrows, nbr_cnt);
+	first++;
+	for (i = 0; i < cnt; i++) {
+	    x = nbr_list[i].x;
+	    y = nbr_list[i].y;
+	    /* add position to fifo-list */
+	    last->x = x;
+	    last->y = y;
+	    last++;
+	    neighbors = 0;
+		neighbors++;
+		neighbors++;
+		neighbors++;
+		neighbors++;
+	    /* set values */
+	    actpos->x = x;
+	    actpos->y = y;
+	    actpos++;
+	    flagbuf[y * ncols + x] = -1;
+    G_free(list);
+    G_free(nbr_list);
+    return actpos;
+int writeFragments(Coords **fragments, int *flagbuf, int nrows, int ncols, int nbr_cnt)
+    int row, col;
+    int fragcount = 0;
+    for (row = 0; row < nrows; row++) {
+	for (col = 0; col < ncols; col++) {
+	    if (flagbuf[row * ncols + col] == 1) {
+		fragcount++;
+		fragments[fragcount] =
+		    writeFrag(flagbuf, fragments[fragcount - 1], row, col,
+			      nrows, ncols, nbr_cnt);
+    return fragcount;
Modified: grass-addons/grass7/raster/r.pi/r.pi.library/r_pi.h
--- grass-addons/grass7/raster/r.pi/r.pi.library/r_pi.h	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.library/r_pi.h	2017-04-08 20:05:19 UTC (rev 70852)
@@ -22,6 +22,11 @@
 typedef struct
     int x, y;
+} Position;
+typedef struct
+    int x, y;
     int neighbors;
     double value;
 } Coords;
@@ -31,6 +36,11 @@
 void draw_line(int *map, int val, int x1, int y1, int x2, int y2, int sx,
 	       int sy, int width);
+/* frag.c */
+Coords *writeFrag(int *flagbuf, Coords *actpos, int row, int col, int nrows,
+		  int ncols, int nbr_cnt);
+int writeFragments(Coords **fragments, int *flagbuf, int nrows, int ncols, int nbr_cnt);
 /* helpers.c */
 int Round(double d);
 int Random(int max);
Deleted: grass-addons/grass7/raster/r.pi/r.pi.neigh/frag.c
--- grass-addons/grass7/raster/r.pi/r.pi.neigh/frag.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.neigh/frag.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -1,139 +0,0 @@
-#include <math.h>
-typedef struct
-    int x, y;
-} Position;
-    int i, j;
-    int cnt = 0;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	break;
-		    res[cnt].x = i;
-		    res[cnt].y = j;
-		    cnt++;
-	break;
-    return cnt;
-    int x, y, i;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-    actpos->x = col;
-    actpos->y = row;
-    actpos++;
-    last->x = col;
-    last->y = row;
-    last++;
-	int r = first->y;
-	int c = first->x;
-	first++;
-	    last->x = x;
-	    last->y = y;
-	    last++;
-	    neighbors = 0;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-	    /* set values */
-	    actpos->x = x;
-	    actpos->y = y;
-	    actpos++;
-    G_free(list);
-    G_free(nbr_list);
-    return;
Modified: grass-addons/grass7/raster/r.pi/r.pi.neigh/local_proto.h
--- grass-addons/grass7/raster/r.pi/r.pi.neigh/local_proto.h	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.neigh/local_proto.h	2017-04-08 20:05:19 UTC (rev 70852)
@@ -15,9 +15,6 @@
 typedef DCELL(f_func) (DCELL * values, int count);
-/* frag.c */
-void writeFrag(int *flagbuf, int row, int col, int nrows, int ncols, int nbr_cnt);
 /* func.c */
 void compute_values(DCELL * vals, int fragcount, int min, int max, f_func stat_method);
Modified: grass-addons/grass7/raster/r.pi/r.pi.neigh/main.c
--- grass-addons/grass7/raster/r.pi/r.pi.neigh/main.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.neigh/main.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -57,7 +57,7 @@
     char *p;
-    int neighb_count;
+    int nbr_count;
     int nrows, ncols;
     int row, col, i;
@@ -206,7 +206,7 @@
     stat_method = menu[method].method;
@@ -250,22 +250,8 @@
     Rast_close(in_fd);
-    fragcount = 0;
-	/* display progress */
-	G_percent(row, nrows, 2);
-		fragcount++;
-    G_percent(1, 1, 2);
     /* open patch-values file */
     in_fd = Rast_open_old(vals_name, vals_mapset);
     if (in_fd < 0)
Deleted: grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/frag.c
--- grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/frag.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/frag.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -1,156 +0,0 @@
-		 int nbr_cnt);
-		 int nbr_cnt)
-    int i, j;
-    int cnt = 0;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	break;
-		    res[cnt].x = i;
-		    res[cnt].y = j;
-		    cnt++;
-	break;
-    return cnt;
-    int x, y, i;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-    actpos->x = col;
-    actpos->y = row;
-    actpos++;
-    last->x = col;
-    last->y = row;
-    last++;
-	int r = first->y;
-	int c = first->x;
-	int cnt =
-	first++;
-	    last->x = x;
-	    last->y = y;
-	    last++;
-	    neighbors = 0;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-	    /* set values */
-	    actpos->x = x;
-	    actpos->y = y;
-	    actpos++;
-    G_free(list);
-    G_free(nbr_list);
-    return actpos;
-    int row, col;
-		fragcount++;
-    return fragcount;
Modified: grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/local_proto.h
--- grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/local_proto.h	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/local_proto.h	2017-04-08 20:05:19 UTC (rev 70852)
@@ -20,11 +20,6 @@
 typedef struct
     int x, y;
-} Position;
-typedef struct
-    int x, y;
 } Point;
@@ -52,9 +47,6 @@
 /* fractal.c */
 void create_map(int *res, int size);
-/* frag.c */
 /* global parameters */
 GLOBAL int *buffer;
 GLOBAL double *bigbuf;
Modified: grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/main.c
--- grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/main.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/main.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -70,7 +70,7 @@
     int rand_seed;
     int methods[GNAME_MAX];
     int statmethods[GNAME_MAX];
-    int neighb_count;
+    int nbr_count;
     /* helper variables */
     int i, j;
@@ -270,7 +270,7 @@
     /* scan all method answers */
     for (method_count = 0; parm.method->answers[method_count] != NULL;
@@ -389,7 +389,7 @@
 	/* apply methods to real landscape */
-	fragcount = writeFragments(real_landscape, sy, sx, neighb_count);
+	fragcount = writeFragments(fragments, real_landscape, sy, sx, nbr_count);
 	/* allocate memory for result */
 	res = (DCELL *) G_malloc(fragcount * sizeof(DCELL));
@@ -431,7 +431,7 @@
 	create_map(resmap, size);
-	fragcount = writeFragments(resmap, sy, sx, neighb_count);
+	fragcount = writeFragments(fragments, resmap, sy, sx, nbr_count);
 	/* save fragcount */
 	fragcounts[i] = fragcount;
Deleted: grass-addons/grass7/raster/r.pi/r.pi.odc/frag.c
--- grass-addons/grass7/raster/r.pi/r.pi.odc/frag.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.odc/frag.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -1,157 +0,0 @@
-		 int nbr_cnt);
-		 int nbr_cnt)
-    int i, j;
-    int cnt = 0;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	break;
-		    res[cnt].x = i;
-		    res[cnt].y = j;
-		    cnt++;
-	break;
-    return cnt;
-    int x, y, i;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-    actpos->x = col;
-    actpos->y = row;
-    actpos++;
-    last->x = col;
-    last->y = row;
-    last++;
-	int r = first->y;
-	int c = first->x;
-	int cnt =
-	first++;
-	    last->x = x;
-	    last->y = y;
-	    last++;
-	    neighbors = 0;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-	    /* set values */
-	    actpos->x = x;
-	    actpos->y = y;
-	    actpos++;
-    G_free(list);
-    G_free(nbr_list);
-    return actpos;
-    int row, col;
-		fragcount++;
-    return fragcount;
Modified: grass-addons/grass7/raster/r.pi/r.pi.odc/local_proto.h
--- grass-addons/grass7/raster/r.pi/r.pi.odc/local_proto.h	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.odc/local_proto.h	2017-04-08 20:05:19 UTC (rev 70852)
@@ -20,11 +20,6 @@
 typedef struct
     int x, y;
-} Position;
-typedef struct
-    int x, y;
 } Point;
 typedef struct
@@ -42,9 +37,6 @@
 void print_array(DCELL * buffer, int size);
 void print_fragments();
-/* frag.c */
 /* voronoi.c */
 void voronoi(DCELL * values, int *map, int sx, int sy, int diag_move, int fragcount);
 void calc_neighbors(DCELL * res, DCELL * focals, f_statmethod **methods,
Modified: grass-addons/grass7/raster/r.pi/r.pi.odc/main.c
--- grass-addons/grass7/raster/r.pi/r.pi.odc/main.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.odc/main.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -85,7 +85,7 @@
     DCELL *d_res;
     DCELL *values;
     DCELL *neighb_values;
-    int neighb_count;
+    int nbr_count;
     int i, n;
     int x, y;
     int sx, sy;
@@ -220,7 +220,7 @@
     sscanf(parm.keyval->answer, "%d", &keyval);
     /* get neighbor level */
     if (parm.neighbor_level->answer) {
@@ -314,7 +314,7 @@
     Rast_close(in_fd);
+    fragcount = writeFragments(fragments, map, sy, sx, nbr_count);
     G_message("Found %d patches", fragcount);
Modified: grass-addons/grass7/raster/r.pi/r.pi.prob.mw/frag.c
--- grass-addons/grass7/raster/r.pi/r.pi.prob.mw/frag.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.prob.mw/frag.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -1,6 +1,6 @@
+Coords *writeFrag_dist(int *flagbuf, Coords * actpos, int row, int col, int nrows,
 		 double distance);
@@ -37,7 +37,7 @@
     return cnt;
     int x, y, i;
@@ -51,13 +51,13 @@
     int neighbors = 0;
 	neighbors++;
 	neighbors++;
 	neighbors++;
 	neighbors++;
@@ -94,13 +94,13 @@
 	    neighbors = 0;
 		neighbors++;
 		neighbors++;
 		neighbors++;
 		neighbors++;
 	    /* set values */
@@ -119,7 +119,7 @@
     return actpos;
+int writeFragments_dist(int *flagbuf, int nrows, int ncols, double distance)
     int row, col;
     int fragcount = 0;
@@ -131,7 +131,7 @@
 		fragcount++;
+		    writeFrag_dist(flagbuf, fragments[fragcount - 1], row, col,
Modified: grass-addons/grass7/raster/r.pi/r.pi.prob.mw/local_proto.h
--- grass-addons/grass7/raster/r.pi/r.pi.prob.mw/local_proto.h	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.prob.mw/local_proto.h	2017-04-08 20:05:19 UTC (rev 70852)
@@ -17,11 +17,6 @@
 #endif
-typedef struct
-    int x, y;
-} Position;
 void print_buffer(int *buffer, int sx, int sy);
@@ -33,8 +28,8 @@
 /* analysis.c */
 void perform_analysis(DCELL * values, int *map, int *mask, int n, int size, int patch_only, int sx, int sy);
-/* frag.c */
-int writeFragments(int *flagbuf, int nrows, int ncols, double distance);
+/* frag.c*/
+int writeFragments_dist(int *flagbuf, int nrows, int ncols, double distance);
Modified: grass-addons/grass7/raster/r.pi/r.pi.prob.mw/main.c
--- grass-addons/grass7/raster/r.pi/r.pi.prob.mw/main.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.prob.mw/main.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -266,7 +266,7 @@
-    fragcount = writeFragments(map, sy, sx, distance);
+    fragcount = writeFragments_dist(map, sy, sx, distance);
     /* test output */
     /*      G_message("fragcount = %d", fragcount);
Deleted: grass-addons/grass7/raster/r.pi/r.pi.prox/frag.c
--- grass-addons/grass7/raster/r.pi/r.pi.prox/frag.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.prox/frag.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -1,139 +0,0 @@
-#include <math.h>
-typedef struct
-    int x, y;
-} Position;
-int getNeighbors(int *flagbuf, Position * res, int x, int y, int nx, int ny, int nbr_cnt)
-    int i, j;
-    int cnt = 0;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	break;
-		    res[cnt].x = i;
-		    res[cnt].y = j;
-		    cnt++;
-	break;
-    return cnt;
-void writeFrag(int *flagbuf, int row, int col, int nrows, int ncols,int nbr_cnt)
-    int x, y, i;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-    actpos->x = col;
-    actpos->y = row;
-    actpos++;
-    last->x = col;
-    last->y = row;
-    last++;
-	int r = first->y;
-	int c = first->x;
-	int cnt = getNeighbors(flagbuf, nbr_list, c, r, ncols, nrows, nbr_cnt);
-	first++;
-	    last->x = x;
-	    last->y = y;
-	    last++;
-	    neighbors = 0;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-	    /* set values */
-	    actpos->x = x;
-	    actpos->y = y;
-	    actpos++;
-    G_free(list);
-    G_free(nbr_list);
-    return;
Modified: grass-addons/grass7/raster/r.pi/r.pi.prox/local_proto.h
--- grass-addons/grass7/raster/r.pi/r.pi.prox/local_proto.h	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.prox/local_proto.h	2017-04-08 20:05:19 UTC (rev 70852)
@@ -17,9 +17,6 @@
 #endif
-/* frag.c */
-void writeFrag(int *flagbuf, int row, int col, int nrows, int ncols,int nbr_cnt);
 /* func.c */
 int f_proximity(DCELL *, Coords **, int, int, int);
 int f_modified_prox(DCELL * vals, Coords ** frags, int count, int min,
Modified: grass-addons/grass7/raster/r.pi/r.pi.prox/main.c
--- grass-addons/grass7/raster/r.pi/r.pi.prox/main.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.prox/main.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -68,7 +68,7 @@
     char *p;
-    int neighb_count;
+    int nbr_count;
     int row, col, i;
     int nrows, ncols;
@@ -206,7 +206,7 @@
@@ -245,21 +245,11 @@
 		flagbuf[row * ncols + col] = 1;
-		fragcount++;
     Rast_close(in_fd);
     compute_values(values, fragments, fragcount, min, max);
Deleted: grass-addons/grass7/raster/r.pi/r.pi.searchtime/frag.c
--- grass-addons/grass7/raster/r.pi/r.pi.searchtime/frag.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.searchtime/frag.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -1,156 +0,0 @@
-		 int nbr_cnt);
-		 int nbr_cnt)
-    int i, j;
-    int cnt = 0;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	break;
-		    res[cnt].x = i;
-		    res[cnt].y = j;
-		    cnt++;
-	break;
-    return cnt;
-    int x, y, i;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-    actpos->x = col;
-    actpos->y = row;
-    actpos++;
-    last->x = col;
-    last->y = row;
-    last++;
-	int r = first->y;
-	int c = first->x;
-	int cnt =
-	first++;
-	    last->x = x;
-	    last->y = y;
-	    last++;
-	    neighbors = 0;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-	    /* set values */
-	    actpos->x = x;
-	    actpos->y = y;
-	    actpos++;
-    G_free(list);
-    G_free(nbr_list);
-    return actpos;
-    int row, col;
-		fragcount++;
-    return fragcount;
Modified: grass-addons/grass7/raster/r.pi/r.pi.searchtime/local_proto.h
--- grass-addons/grass7/raster/r.pi/r.pi.searchtime/local_proto.h	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.searchtime/local_proto.h	2017-04-08 20:05:19 UTC (rev 70852)
@@ -21,11 +21,6 @@
 typedef struct
     int x, y;
-} Position;
-typedef struct
-    int x, y;
     double dir;
     DCELL path;
     int finished;
@@ -51,9 +46,6 @@
-/* frag.c */
 /* search.c */
 void perform_search(DCELL * values, int *map, DCELL * costmap,
 		    f_statmethod **stats, int stat_count, int n, int fragcount, int sx, int sy);
Modified: grass-addons/grass7/raster/r.pi/r.pi.searchtime/main.c
--- grass-addons/grass7/raster/r.pi/r.pi.searchtime/main.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.searchtime/main.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -66,7 +66,7 @@
     CELL *result;
     DCELL *d_res;
     DCELL *values;
-    int neighb_count;
+    int nbr_count;
     int i, j;
     Coords *p;
     char *str;
@@ -325,7 +325,7 @@
     /* get include_cost */
     include_cost = flag.cost->answer;
@@ -464,7 +464,7 @@
     /* test output */
Deleted: grass-addons/grass7/raster/r.pi/r.pi.searchtime.iter/frag.c
--- grass-addons/grass7/raster/r.pi/r.pi.searchtime.iter/frag.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.searchtime.iter/frag.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -1,156 +0,0 @@
-		 int nbr_cnt);
-		 int nbr_cnt)
-    int i, j;
-    int cnt = 0;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	break;
-		    res[cnt].x = i;
-		    res[cnt].y = j;
-		    cnt++;
-	break;
-    return cnt;
-    int x, y, i;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-    actpos->x = col;
-    actpos->y = row;
-    actpos++;
-    last->x = col;
-    last->y = row;
-    last++;
-	int r = first->y;
-	int c = first->x;
-	int cnt =
-	first++;
-	    last->x = x;
-	    last->y = y;
-	    last++;
-	    neighbors = 0;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-	    /* set values */
-	    actpos->x = x;
-	    actpos->y = y;
-	    actpos++;
-    G_free(list);
-    G_free(nbr_list);
-    return actpos;
-    int row, col;
-		fragcount++;
-    return fragcount;
Modified: grass-addons/grass7/raster/r.pi/r.pi.searchtime.iter/local_proto.h
--- grass-addons/grass7/raster/r.pi/r.pi.searchtime.iter/local_proto.h	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.searchtime.iter/local_proto.h	2017-04-08 20:05:19 UTC (rev 70852)
@@ -20,11 +20,6 @@
 typedef struct
     int x, y;
-} Position;
-typedef struct
-    int x, y;
     double dir;
     DCELL path;
     int finished;
@@ -50,9 +45,6 @@
-/* frag.c */
 /* search.c */
Modified: grass-addons/grass7/raster/r.pi/r.pi.searchtime.iter/main.c
--- grass-addons/grass7/raster/r.pi/r.pi.searchtime.iter/main.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.searchtime.iter/main.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -70,7 +70,7 @@
     DCELL *values;
     DCELL *output_values;
     DCELL *dummy;
-    int neighb_count;
+    int nbr_count;
     int i, j;
     Coords *p;
     char *str;
@@ -288,7 +288,7 @@
     sscanf(parm.percent->answer, "%lf", &percent);
@@ -451,7 +451,7 @@
     /* test output */
Deleted: grass-addons/grass7/raster/r.pi/r.pi.searchtime.mw/frag.c
--- grass-addons/grass7/raster/r.pi/r.pi.searchtime.mw/frag.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.searchtime.mw/frag.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -1,155 +0,0 @@
-		 int nbr_cnt);
-		 int nbr_cnt)
-    int i, j;
-    int cnt = 0;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	    res[cnt].y = y;
-	    cnt++;
-	    res[cnt].x = x;
-	    cnt++;
-	break;
-		    res[cnt].x = i;
-		    res[cnt].y = j;
-		    cnt++;
-	break;
-    return cnt;
-    int x, y, i;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-	neighbors++;
-    actpos->x = col;
-    actpos->y = row;
-    actpos++;
-    last->x = col;
-    last->y = row;
-    last++;
-	int r = first->y;
-	int c = first->x;
-	int cnt =
-	first++;
-	    last->x = x;
-	    last->y = y;
-	    last++;
-	    neighbors = 0;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-		neighbors++;
-	    /* set values */
-	    actpos->x = x;
-	    actpos->y = y;
-	    actpos++;
-    G_free(list);
-    G_free(nbr_list);
-    return actpos;
-    int row, col;
-		fragcount++;
-    return fragcount;
Modified: grass-addons/grass7/raster/r.pi/r.pi.searchtime.mw/local_proto.h
--- grass-addons/grass7/raster/r.pi/r.pi.searchtime.mw/local_proto.h	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.searchtime.mw/local_proto.h	2017-04-08 20:05:19 UTC (rev 70852)
@@ -20,11 +20,6 @@
 typedef struct
     int x, y;
-} Position;
-typedef struct
-    int x, y;
     double dir;
     DCELL path;
     int finished;
@@ -44,9 +39,6 @@
-/* frag.c */
 /* search.c */
 void perform_search(DCELL * values, int *map, DCELL * costmap, int size,
Modified: grass-addons/grass7/raster/r.pi/r.pi.searchtime.mw/main.c
--- grass-addons/grass7/raster/r.pi/r.pi.searchtime.mw/main.c	2017-04-07 16:41:10 UTC (rev 70851)
+++ grass-addons/grass7/raster/r.pi/r.pi.searchtime.mw/main.c	2017-04-08 20:05:19 UTC (rev 70852)
@@ -71,7 +71,7 @@
     CELL *result;
     DCELL *d_res;
     DCELL *values;
-    int neighb_count;
+    int nbr_count;
     int i;
     Coords *p;
     char *str;
@@ -278,7 +278,7 @@
@@ -412,7 +412,7 @@
     /* test output */
