[GRASS-SVN] r70853 - grass/trunk/imagery/i.ortho.photo/i.ortho.elev
Sun Apr 9 09:37:13 PDT 2017
Author: ychemin
Date: 2017-04-09 09:37:13 -0700 (Sun, 09 Apr 2017)
New Revision: 70853
   grass/trunk/imagery/i.ortho.photo/i.ortho.elev/main.c
More information can be added to the ELEVATION file
Modified: grass/trunk/imagery/i.ortho.photo/i.ortho.elev/main.c
--- grass/trunk/imagery/i.ortho.photo/i.ortho.elev/main.c	2017-04-08 20:05:19 UTC (rev 70852)
+++ grass/trunk/imagery/i.ortho.photo/i.ortho.elev/main.c	2017-04-09 16:37:13 UTC (rev 70853)
@@ -39,7 +39,8 @@
     struct GModule *module;
-    struct Option *group_opt, *elev_opt;
+    struct Option *group_opt, *loc_opt, *mapset_opt, *elev_opt;
+    struct Option *math_opt, *unit_opt, *nd_opt;
     struct Flag *list_flag, *print_flag;
     char location[GMAPSET_MAX];
@@ -48,7 +49,7 @@
     char *elev_layer;
     char *mapset_elev;
-    char *tl;
+    char *location_elev;
     char *math_exp;
     char *units;
     char *nd;
@@ -69,16 +70,37 @@
     group_opt->description =
 	_("Name of imagery group for ortho-rectification");
+    loc_opt = G_define_standard_option(G_OPT_M_LOCATION);
+    loc_opt->required = NO;
+    loc_opt->description =
+	_("Name of the target location");
+    mapset_opt = G_define_standard_option(G_OPT_M_MAPSET);
+    mapset_opt->required = NO;
+    mapset_opt->description =
+	_("Name of the target mapset");
     elev_opt = G_define_standard_option(G_OPT_R_ELEV);
     elev_opt->required = NO;
     elev_opt->description =
 	_("Name of elevation map to use for ortho-rectification");
-    list_flag = G_define_flag();
-    list_flag->key = 'l';
-    list_flag->description =
-	_("List available raster maps in target mapset and exit");
+    math_opt = G_define_standard_option(G_OPT_M_NULL_VALUE);
+    math_opt->key = "math_expression";
+    math_opt->required = NO;
+    math_opt->description =
+	_("Math expression to convert to real elevation");
+    unit_opt = G_define_standard_option(G_OPT_M_UNITS);
+    unit_opt->required = NO;
+    unit_opt->description =
+	_("Unit of the elevation map");
+    nd_opt = G_define_standard_option(G_OPT_M_NULL_VALUE);
+    nd_opt->required = NO;
+    nd_opt->description =
+	_("No data value");
     print_flag = G_define_flag();
     print_flag->key = 'p';
     print_flag->description =
@@ -89,92 +111,108 @@
     elev_layer = (char *)G_malloc(GNAME_MAX * sizeof(char));
     mapset_elev = (char *)G_malloc(GMAPSET_MAX * sizeof(char));
-    tl = (char *)G_malloc(80 * sizeof(char));
+    location_elev = (char *)G_malloc(80 * sizeof(char));
     math_exp = (char *)G_malloc(80 * sizeof(char));
     units = (char *)G_malloc(80 * sizeof(char));
     nd = (char *)G_malloc(80 * sizeof(char));
     *elev_layer = 0;
     *mapset_elev = 0;
-    *tl = 0;
+    *location_elev = 0;
     *math_exp = 0;
     *units = 0;
     *nd = 0;
     strcpy(group, group_opt->answer);
-    G_suppress_warnings(1);
+    if(loc_opt->answer)
+    	strcpy(location_elev, loc_opt->answer);
+    if(mapset_opt->answer)
+    	strcpy(mapset_elev, mapset_opt->answer);
+    if(elev_opt->answer)
+    	strcpy(elev_layer, elev_opt->answer);
+    if(math_opt->answer)
+    	strcpy(math_exp, math_opt->answer);
+    if(unit_opt->answer)
+    	strcpy(units, unit_opt->answer);
+    if(nd_opt->answer)
+    	strcpy(nd, nd_opt->answer);
     if (!I_get_target(group, location, mapset)) {
 	G_fatal_error(_("Please select a target for group [%s] first"), group);
-    G_suppress_warnings(0);
     sprintf(buf, "%s/%s", G_gisdbase(), location);
     if (access(buf, 0) != 0) {
 	G_fatal_error(_("Target location [%s] not found\n"), location);
     if (print_flag->answer) {
-	I_get_group_elev(group, elev_layer, mapset_elev, tl, math_exp, units, nd);
-	exit(EXIT_SUCCESS);
+	if(!I_get_group_elev(group, elev_layer, mapset_elev, location_elev, math_exp, units, nd)){
+		G_fatal_error(_("Cannot find default elevation map for target in group [%s]"),group);
+	} else {
+		G_message("map:\t\t\t%s",elev_layer);
+		G_message("mapset:\t\t\t%s",mapset_elev);
+		G_message("location:\t\t%s",location_elev);
+		G_message("math expression:\t%s",math_exp);
+		G_message("units:\t\t\t%s",units);
+		G_message("nodata value:\t\t%s",nd);
+		exit(EXIT_SUCCESS);
+    /*Creating a Target environment*/
     G_create_alt_env();
+    /*Set an alternate Location */
     G_setenv_nogisrc("LOCATION_NAME", location);
+    /*Check for permissions in mapset */
     stat = G_mapset_permissions(mapset);
+    /*We have permissions on the mapset */
     if (stat > 0) {
+	/*Set the alternate mapset */
 	G_setenv_nogisrc("MAPSET", mapset);
+	/*Make an alternate search path */
 	G_create_alt_search_path();
+	/*Switch from current to alternate environment */
 	G_switch_env();
+	/*Switch to alternate search path */
 	G_switch_search_path();
 	which_env = 0;
+        /*Select the target environment */
 	select_target_env();
-	if (list_flag->answer) {
-	    /* list raster maps in target location */
+	/*Start working on the Target mapset */
+        if (!elev_opt->answer) {
 	    /* select current location */
 	    select_current_env();
+	    G_fatal_error(_("Elevation map name is missing. Please set '%s' option"),
+	        elev_opt->key);
-	else {
-	    if (!elev_opt->answer) {
-		/* select current location */
-		select_current_env();
-		G_fatal_error(_("Elevation map name is missing. Please set '%s' option"),
-		    elev_opt->key);
-	    /* elevation map exists in target ? */
-	    if (G_find_raster2(elev_opt->answer, mapset) == NULL) {
-		G_fatal_error(_("Raster map <%s> not found"), elev_opt->answer);
+	/* elevation map exists in target ? */
+	if (G_find_raster2(elev_opt->answer, mapset) == NULL) {
+            /* select current location */
+	    select_current_env();
+	    G_fatal_error(_("Raster map <%s> not found"), elev_opt->answer);
-	    overwrite = G_getenv_nofatal("OVERWRITE") != NULL;
+	I_get_group_elev(group, elev_layer, mapset_elev, location_elev, math_exp, units, nd);
+	overwrite = G_getenv_nofatal("OVERWRITE") != NULL;
-	    if (!overwrite && *elev_layer) {
-		G_warning(_("Elevation for group <%s> is already set to <%s>"),
-		          group, elev_layer);
-	    I_put_group_elev(group, elev_opt->answer, mapset_elev, tl,
-			     math_exp, units, nd);
+	if (!overwrite && *elev_layer) {
+	G_warning(_("Elevation for group <%s> is already set to <%s>"),
+	          group, elev_layer);
+	/*Modify ELEVATION file in source GROUP */
+	I_put_group_elev(group,elev_layer,mapset_elev,location_elev, math_exp, units, nd);
+    }else{
+	G_fatal_error(_("Mapset [%s] in target location [%s] - %s "),
+                  mapset, location,
+		  stat == 0 ? _("permission denied\n") : _("not found\n"));
-    G_fatal_error(_("Mapset [%s] in target location [%s] - %s "),
-                  mapset, location,
-		  stat == 0 ? _("permission denied\n") : _("not found\n"));
+    return(EXIT_SUCCESS);
