[GRASS-SVN] r70854 - grass/trunk/imagery/i.ortho.photo/i.ortho.elev
Sun Apr 9 14:45:48 PDT 2017
Author: ychemin
Date: 2017-04-09 14:45:47 -0700 (Sun, 09 Apr 2017)
New Revision: 70854
   grass/trunk/imagery/i.ortho.photo/i.ortho.elev/main.c
More information can be added to the ELEVATION file, bug fixing
Modified: grass/trunk/imagery/i.ortho.photo/i.ortho.elev/main.c
--- grass/trunk/imagery/i.ortho.photo/i.ortho.elev/main.c	2017-04-09 16:37:13 UTC (rev 70853)
+++ grass/trunk/imagery/i.ortho.photo/i.ortho.elev/main.c	2017-04-09 21:45:47 UTC (rev 70854)
@@ -128,8 +128,8 @@
     	strcpy(location_elev, loc_opt->answer);
     if(mapset_opt->answer)
     	strcpy(mapset_elev, mapset_opt->answer);
-    if(elev_opt->answer)
-    	strcpy(elev_layer, elev_opt->answer);
+    /*if(elev_opt->answer)
+    	strcpy(elev_layer, elev_opt->answer);*/
     if(math_opt->answer)
     	strcpy(math_exp, math_opt->answer);
     if(unit_opt->answer)
@@ -193,16 +193,11 @@
 	    select_current_env();
 	    G_fatal_error(_("Raster map <%s> not found"), elev_opt->answer);
+	/* load information from the ELEVATION file in the GROUP*/
 	I_get_group_elev(group, elev_layer, mapset_elev, location_elev, math_exp, units, nd);
-	overwrite = G_getenv_nofatal("OVERWRITE") != NULL;
-	if (!overwrite && *elev_layer) {
-	G_warning(_("Elevation for group <%s> is already set to <%s>"),
-	          group, elev_layer);
 	/*Modify ELEVATION file in source GROUP */
-	I_put_group_elev(group,elev_layer,mapset_elev,location_elev, math_exp, units, nd);
+	I_put_group_elev(group,elev_opt->answer,mapset_opt->answer,loc_opt->answer,
+			math_opt->answer, unit_opt->answer, nd_opt->answer);
 	/* select current location */
