[GRASS-SVN] r70907 - grass-addons/grass7/raster/r.learn.ml
svn_grass at osgeo.org
Thu Apr 20 09:43:46 PDT 2017
Author: spawley
Date: 2017-04-20 09:43:46 -0700 (Thu, 20 Apr 2017)
New Revision: 70907
grass-addons/grass7/raster/r.learn.ml/r.learn.ml.py
r.learn.ml reorganized options into separate required, classifier settings, cross validation and options tabs
Modified: grass-addons/grass7/raster/r.learn.ml/r.learn.ml.py
--- grass-addons/grass7/raster/r.learn.ml/r.learn.ml.py 2017-04-20 16:12:27 UTC (rev 70906)
+++ grass-addons/grass7/raster/r.learn.ml/r.learn.ml.py 2017-04-20 16:43:46 UTC (rev 70907)
@@ -22,7 +22,7 @@
#%option G_OPT_I_GROUP
#% key: group
#% label: Imagery group to be classified
-#% description: Series of raster maps to be used in the random forest classification
+#% description: GRASS imagery group of raster maps to be used in the machine learning model
#% required: yes
#% multiple: no
#%end
@@ -46,7 +46,7 @@
#%option G_OPT_DB_COLUMN
#% key: field
#% label: Response attribute column
-#% description: Name of attribute column containing response value
+#% description: Name of attribute column in trainingpoints containing response value
#% required: no
#% guisection: Required
#%end
@@ -65,119 +65,131 @@
#% description: Supervised learning model to use
#% answer: RandomForestClassifier
#% options: LogisticRegression,LinearDiscriminantAnalysis,QuadraticDiscriminantAnalysis,GaussianNB,DecisionTreeClassifier,DecisionTreeRegressor,RandomForestClassifier,RandomForestRegressor,ExtraTreesClassifier,ExtraTreesRegressor,GradientBoostingClassifier,GradientBoostingRegressor,SVC,EarthClassifier,EarthRegressor,XGBClassifier,XGBRegressor
-#% guisection: Required
-#% required: yes
+#% guisection: Classifier settings
+#% required: no
#%end
#%option
#% key: c
#% type: double
-#% description: Inverse of regularization strength
+#% label: Inverse of regularization strength
+#% description: Inverse of regularization strength (LogisticRegression and SVC)
#% answer: 1.0
#% multiple: yes
-#% guisection: Classifier Parameters
#%end
#%option
#% key: max_features
#% type: integer
-#% description: Number of features avaiable during node splitting
+#% label: Number of features avaiable during node splitting
+#% description: Number of features avaiable during node splitting (tree-based classifiers and regressors)
#% answer:0
#% multiple: yes
#%end
#%option
#% key: max_depth
#% type: integer
-#% description: Maximum tree depth; zero uses classifier defaults
+#% label: Maximum tree depth; zero uses classifier defaults
+#% description: Maximum tree depth for tree-based method; zero uses classifier defaults (full-growing for Decision trees and Randomforest, 3 for GBM and XGB)
#% answer:0
#% multiple: yes
#%end
#%option
#% key: min_samples_split
#% type: integer
-#% description: The minimum number of samples required for node splitting
+#% label: The minimum number of samples required for node splitting
+#% description: The minimum number of samples required for node splitting in tree-based classifiers
#% answer: 2
#% multiple: yes
#%end
#%option
#% key: min_samples_leaf
#% type: integer
-#% description: The minimum number of samples required to form a leaf node
+#% label: The minimum number of samples required to form a leaf node
+#% description: The minimum number of samples required to form a leaf node in tree-based classifiers
#% answer: 1
#% multiple: yes
#%end
#%option
#% key: n_estimators
#% type: integer
-#% description: Number of estimators
+#% label: Number of estimators
+#% description: Number of estimators (trees) in ensemble tree-based classifiers
#% answer: 100
#% multiple: yes
#%end
#%option
#% key: learning_rate
#% type: double
-#% description: learning rate
+#% label: learning rate
+#% description: learning rate (also known as shrinkage) for gradient boosting methods
#% answer: 0.1
#% multiple: yes
#%end
#%option
#% key: subsample
#% type: double
-#% description: The fraction of samples to be used for fitting
+#% label: The fraction of samples to be used for fitting
+#% description: The fraction of samples to be used for fitting, controls stochastic behaviour of gradient boosting methods
#% answer: 1.0
#% multiple: yes
#%end
#%option integer
#% key: max_degree
-#% description: The maximum degree of terms in forward pass
+#% label: The maximum degree of terms in forward pass
+#% description: The maximum degree of terms in forward pass for Py-earth
#% answer: 1
#% multiple: yes
#%end
#%option integer
#% key: categorymaps
#% multiple: yes
#% label: Indices of categorical rasters within the imagery group (0..n)
-#% description: Indices of categorical rasters within the imagery group (0..n)
+#% description: Indices of categorical rasters within the imagery group (0..n) that will be one-hot encoded
+#% guisection: Optional
#%end
#%option string
#% key: cvtype
#% label: Non-spatial or spatial cross-validation
-#% description: Non-spatial, clumped or clustered k-fold cross-validation
+#% description: Perform non-spatial, clumped or clustered k-fold cross-validation
#% answer: Non-spatial
#% options: non-spatial,clumped,kmeans
+#% guisection: Cross validation
#%end
#%option
#% key: n_partitions
#% type: integer
-#% description: Number of kmeans spatial partitions
+#% label: Number of kmeans spatial partitions
+#% description: Number of kmeans spatial partitions for kmeans clustered cross-validation
#% answer: 10
-#% guisection: Optional
#%end
#%option G_OPT_R_INPUT
#% key: group_raster
-#% label: Custom group ids for labelled pixels from GRASS raster
-#% description: GRASS raster containing group ids for labelled pixels
+#% label: Custom group ids for training samples from GRASS raster
+#% description: GRASS raster containing group ids for training samples. Samples with the same group id will not be split between training and test cross-validation folds
#% required: no
#%end
#%option
@@ -185,10 +197,51 @@
#% type: integer
#% description: Number of cross-validation folds
#% answer: 1
#%end
#%option
+#% key: n_permutations
+#% type: integer
+#% description: Number of permutations to perform for feature importances
+#% answer: 50
+#%end
+#%flag
+#% key: t
+#% description: Perform hyperparameter tuning only
+#%end
+#%flag
+#% key: f
+#% description: Calculate permutation importances during cross validation
+#%end
+#%option G_OPT_F_OUTPUT
+#% key: errors_file
+#% label: Save cross-validation global accuracy results to csv
+#% required: no
+#%end
+#% key: fimp_file
+#% label: Save feature importances to csv
+#% required: no
+#%end
+#% key: param_file
+#% label: Save hyperparameter search scores to csv
+#% required: no
+#%end
+#%option
#% key: random_state
#% type: integer
#% description: Seed to use for random state
@@ -214,14 +267,6 @@
#%end
#%option
-#% key: n_permutations
-#% type: integer
-#% description: Number of permutations to perform for feature importances
-#% answer: 50
-#%end
-#%option
#% key: n_jobs
#% type: integer
#% description: Number of cores for multiprocessing, -2 is n_cores-1
@@ -237,7 +282,7 @@
#%flag
#% key: i
-#% label: Impute missing values in training data
+#% label: Impute training data preprocessing
#%end
@@ -260,18 +305,6 @@
#%end
#%flag
-#% key: t
-#% description: Perform hyperparameter tuning only
-#%end
-#%flag
-#% key: f
-#% description: Calculate feature importances using permutation
-#%end
-#%flag
#% key: b
#% description: Balance training data using class weights
@@ -284,27 +317,6 @@
#%end
-#% key: errors_file
-#% label: Save cross-validation global accuracy results to csv
-#% required: no
-#%end
-#%option G_OPT_F_OUTPUT
-#% key: fimp_file
-#% label: Save feature importances to csv
-#% required: no
-#%end
-#% key: param_file
-#% label: Save hyperparameter search scores to csv
-#% required: no
-#%end
#% key: save_training
#% label: Save training data to csv
#% required: no
