[GRASS-SVN] r70908 - grass-addons/grass7/vector/v.lfp
svn_grass at osgeo.org
Fri Apr 21 05:18:04 PDT 2017
Author: hcho
Date: 2017-04-21 05:18:04 -0700 (Fri, 21 Apr 2017)
New Revision: 70908
grass-addons/grass7/vector/v.lfp/v.lfp.py
v.lfp: Write history only if it's supported (>=r70740)
Modified: grass-addons/grass7/vector/v.lfp/v.lfp.py
--- grass-addons/grass7/vector/v.lfp/v.lfp.py 2017-04-20 16:43:46 UTC (rev 70907)
+++ grass-addons/grass7/vector/v.lfp/v.lfp.py 2017-04-21 12:18:04 UTC (rev 70908)
@@ -170,9 +170,11 @@
except CalledModuleError:
grass.fatal(_("Cannot flip the longest flow path"))
- # write history
- grass.run_command("v.support", flags="h", map=output,
- cmdhist=os.environ["CMDLINE"])
+ # write history if supported
+ if int(grass.version()["revision"][1:]) >= 70740:
+ # v.support -h added in r70740
+ grass.run_command("v.support", flags="h", map=output,
+ cmdhist=os.environ["CMDLINE"])
if __name__ == "__main__":
