[GRASS-SVN] r70909 - grass-addons/grass7/raster/r.learn.ml
svn_grass at osgeo.org
Fri Apr 21 20:20:38 PDT 2017
Author: spawley
Date: 2017-04-21 20:20:36 -0700 (Fri, 21 Apr 2017)
New Revision: 70909
grass-addons/grass7/raster/r.learn.ml/r.learn.ml.py
grass-addons/grass7/raster/r.learn.ml/raster_learning.py
r.learn.ml minor additions of descriptions and labels
Modified: grass-addons/grass7/raster/r.learn.ml/r.learn.ml.py
--- grass-addons/grass7/raster/r.learn.ml/r.learn.ml.py 2017-04-21 12:18:04 UTC (rev 70908)
+++ grass-addons/grass7/raster/r.learn.ml/r.learn.ml.py 2017-04-22 03:20:36 UTC (rev 70909)
@@ -1,4 +1,6 @@
#!/usr/bin/env python
+# -- coding: utf-8 --
# MODULE: r.learn.ml
# AUTHOR: Steven Pawley
@@ -409,6 +411,7 @@
n_partitions = int(options['n_partitions'])
modelonly = flags['m']
probability = flags['p']
+ prob_only = flags['z']
tuneonly = flags['t']
rowincr = int(options['lines'])
random_state = int(options['random_state'])
@@ -428,7 +431,6 @@
n_jobs = int(options['n_jobs'])
lowmem = flags['l']
impute = flags['i']
- prob_only = flags['z']
errors_file = options['errors_file']
fimp_file = options['fimp_file']
param_file = options['param_file']
@@ -439,8 +441,19 @@
if ',' in categorymaps:
categorymaps = [int(i) for i in categorymaps.split(',')]
else: categorymaps = None
+ # error checking
+ # feature importances selected by no cross-validation scheme used
if importances is True and cv == 1:
grass.fatal('Feature importances require cross-validation cv > 1')
+ # output map has not been entered and modelonly is not set to True
+ if output == '' and modelonly is True:
+ grass.fatal('No output map specified')
+ # perform prediction only for class probabilities but probability flag is not set to True
+ if prob_only is True:
+ probability = True
# make dicts for hyperparameters, datatypes and parameters for tuning
hyperparams = {'C': options['c'],
Modified: grass-addons/grass7/raster/r.learn.ml/raster_learning.py
--- grass-addons/grass7/raster/r.learn.ml/raster_learning.py 2017-04-21 12:18:04 UTC (rev 70908)
+++ grass-addons/grass7/raster/r.learn.ml/raster_learning.py 2017-04-22 03:20:36 UTC (rev 70909)
@@ -1,3 +1,5 @@
+# -*- coding: utf-8 -*-
import os
import numpy as np
from numpy.random import RandomState
@@ -161,9 +163,9 @@
'neg_mean_squared_error': metrics.mean_squared_error}
byclass_methods = {'f1': metrics.f1_score,
- 'fbeta': metrics.fbeta_score,
- 'precision': metrics.precision_score,
- 'recall': metrics.recall_score}
+ 'fbeta': metrics.fbeta_score,
+ 'precision': metrics.precision_score,
+ 'recall': metrics.recall_score}
# create diction to store byclass metrics results
n_classes = len(np.unique(y))
