[GRASS-SVN] r70921 - grass-addons/tools
svn_grass at osgeo.org
Sat Apr 22 07:53:06 PDT 2017
Author: neteler
Date: 2017-04-22 07:53:06 -0700 (Sat, 22 Apr 2017)
New Revision: 70921
grass-addons/tools/transifex_merge.sh
transifex_merge.sh: added keeping of original po file headers
Modified: grass-addons/tools/transifex_merge.sh
--- grass-addons/tools/transifex_merge.sh 2017-04-22 14:08:21 UTC (rev 70920)
+++ grass-addons/tools/transifex_merge.sh 2017-04-22 14:53:06 UTC (rev 70921)
@@ -1,8 +1,8 @@
#!/bin/bash
# GRASS GIS transifex support script: fetches msg from transifex
-# Luca Delucchi 2017
-# based on gettext message merge procedure by Markus Neteler
+# Luca Delucchi 2017, based on gettext message merge procedure by Markus Neteler
+# - keep headers added by Markus Neteler
# Required installation:
# see
@@ -27,10 +27,12 @@
exit 1;
fi
+# fetch updated po from transifex server into local directory under transifex/.tx/
tx pull -a
cd ..
+# merge updated files into existing ones
cd po
NEWPODIR="../transifex/.tx/"
NEWLIBPODIR="${NEWPODIR}grass72.grasslibspot/"
@@ -38,22 +40,40 @@
for fil in `ls $NEWLIBPODIR`;
do
MYLANG=`echo $fil | rev | cut -c 13- | rev`
+ # fix undefined CHARSET in files pulled from transifex (grrr...)
sed "s+charset=CHARSET+charset=UTF-8+g" ${NEWLIBPODIR}${MYLANG}_translation > ${NEWLIBPODIR}${MYLANG}_translation_new
sed "s+charset=CHARSET+charset=UTF-8+g" ${NEWPODIR}grass72.grassmodspot/${MYLANG}_translation > ${NEWPODIR}grass72.grassmodspot/${MYLANG}_translation_new
sed "s+charset=CHARSET+charset=UTF-8+g" ${NEWPODIR}grass72.grasswxpypot/${MYLANG}_translation > ${NEWPODIR}grass72.grasswxpypot/${MYLANG}_translation_new
+ # https://www.gnu.org/software/gettext/manual/html_node/msgmerge-Invocation.html#msgmerge-Invocation
+ # if po file locally present, update it, otherwise copy over new file from transifex
if [ -f grasslibs_${MYLANG}.po ]; then
- $MSGMERGE ${NEWLIBPODIR}${MYLANG}_translation_new grasslibs_${MYLANG}.po -o grasslibs_${MYLANG}.po2 && mv grasslibs_${MYLANG}.po2 grasslibs_${MYLANG}.po
+ POFILE=grasslibs_${MYLANG}.po
+ grep -m1 -B555 '^$' $POFILE > grasslibs_${MYLANG}.header
+ msgcat --use-first --no-wrap grasslibs_${MYLANG}.header ${NEWLIBPODIR}${MYLANG}_translation_new > ${NEWLIBPODIR}${MYLANG}_translation_new.2
+ $MSGMERGE ${NEWLIBPODIR}${MYLANG}_translation_new.2 $POFILE -o $POFILE.2 && mv $POFILE.2 $POFILE && rm -f grasslibs_${MYLANG}.header
else
+ # TODO: new file needs some header description!
cp ${NEWLIBPODIR}${MYLANG}_translation_new grasslibs_${MYLANG}.po
fi
if [ -f grassmods_${MYLANG}.po ]; then
- $MSGMERGE ${NEWPODIR}grass72.grassmodspot/${MYLANG}_translation_new grassmods_${MYLANG}.po -o grassmods_${MYLANG}.po2 && mv grassmods_${MYLANG}.po2 grassmods_${MYLANG}.po
+ POFILE=grassmods_${MYLANG}.po
+ grep -m1 -B555 '^$' $POFILE > grassmods_${MYLANG}.header
+ msgcat --use-first --no-wrap grassmods_${MYLANG}.header ${NEWPODIR}grass72.grassmodspot/${MYLANG}_translation_new > ${NEWPODIR}grass72.grassmodspot/${MYLANG}_translation_new.2
+ $MSGMERGE ${NEWPODIR}grass72.grassmodspot/${MYLANG}_translation_new.2 grassmods_${MYLANG}.po -o grassmods_${MYLANG}.po2 && mv grassmods_${MYLANG}.po2 grassmods_${MYLANG}.po && rm -f grassmods_${MYLANG}.header
else
cp ${NEWPODIR}grass72.grassmodspot/${MYLANG}_translation_new grassmods_${MYLANG}.po
fi
if [ -f grasswxpy_${MYLANG}.po ]; then
- $MSGMERGE ${NEWPODIR}grass72.grasswxpypot/${MYLANG}_translation_new grasswxpy_${MYLANG}.po -o grasswxpy_${MYLANG}.po2 && mv grasswxpy_${MYLANG}.po2 grasswxpy_${MYLANG}.po
+ POFILE=grasswxpy_${MYLANG}.po
+ grep -m1 -B555 '^$' $POFILE > grasswxpy_${MYLANG}.header
+ msgcat --use-first --no-wrap grasswxpy_${MYLANG}.header ${NEWPODIR}grass72.grasswxpypot/${MYLANG}_translation_new > ${NEWPODIR}grass72.grasswxpypot/${MYLANG}_translation_new.2
+ $MSGMERGE ${NEWPODIR}grass72.grasswxpypot/${MYLANG}_translation_new.2 grasswxpy_${MYLANG}.po -o grasswxpy_${MYLANG}.po2 && mv grasswxpy_${MYLANG}.po2 grasswxpy_${MYLANG}.po && rm -f grasswxpy_${MYLANG}.header
else
cp ${NEWPODIR}grass72.grasswxpypot/${MYLANG}_translation_new grasswxpy_${MYLANG}.po
fi
done
