[GRASS-SVN] r70974 - in grass/trunk/scripts: r.unpack v.unpack
svn_grass at osgeo.org
Fri Apr 28 02:19:12 PDT 2017
Author: martinl
Date: 2017-04-28 02:19:12 -0700 (Fri, 28 Apr 2017)
New Revision: 70974
grass/trunk/scripts/r.unpack/r.unpack.py
grass/trunk/scripts/v.unpack/v.unpack.py
[NEWS] r.|v.unpack: new flag (-p) added to print projection info and exit
Modified: grass/trunk/scripts/r.unpack/r.unpack.py
--- grass/trunk/scripts/r.unpack/r.unpack.py 2017-04-28 04:43:41 UTC (rev 70973)
+++ grass/trunk/scripts/r.unpack/r.unpack.py 2017-04-28 09:19:12 UTC (rev 70974)
@@ -5,7 +5,7 @@
# AUTHOR(S): Hamish Bowman, Otago University, New Zealand
# Converted to Python by Martin Landa <landa.martin gmail.com>
# PURPOSE: Unpack up a raster map packed with r.pack
-# COPYRIGHT: (C) 2004-2008, 2010-2012 by the GRASS Development Team
+# COPYRIGHT: (C) 2010-2017 by the GRASS Development Team
# This program is free software under the GNU General
# Public License (>=v2). Read the file COPYING that
@@ -34,6 +34,11 @@
#% description: Assume that the dataset has same projection as the current location
#% guisection: Output settings
#%end
+#%flag
+#% key: p
+#% label: Print projection information of input pack file and exit
+#% guisection: Print
+#%end
import os
import sys
@@ -76,6 +81,18 @@
except:
grass.fatal(_("Pack file unreadable"))
+ if flags['p']:
+ # print proj info and exit
+ try:
+ for fname in ['PROJ_INFO', 'PROJ_UNITS']:
+ f = tar.extractfile('{}/{}'.format(data_name, fname))
+ sys.stdout.write(f.read())
+ except KeyError:
+ grass.fatal(_("Pack file unreadable: file '{}' missing".format(fname)))
+ tar.close()
+ return 0
if options['output']:
map_name = options['output']
else:
@@ -91,6 +108,7 @@
# extract data
tar.extractall()
+ tar.close()
os.chdir(data_name)
if os.path.exists('cell'):
Modified: grass/trunk/scripts/v.unpack/v.unpack.py
--- grass/trunk/scripts/v.unpack/v.unpack.py 2017-04-28 04:43:41 UTC (rev 70973)
+++ grass/trunk/scripts/v.unpack/v.unpack.py 2017-04-28 09:19:12 UTC (rev 70974)
@@ -6,7 +6,7 @@
# AUTHOR(S): Luca Delucchi
# PURPOSE: Unpack up a vector map packed with v.pack
-# COPYRIGHT: (C) 2010-2013 by the GRASS Development Team
@@ -36,7 +36,13 @@
#%end
+#%flag
+#% key: p
+#%end
import os
import sys
import shutil
@@ -79,6 +85,18 @@
except:
+ if flags['p']:
+ try:
+ f = tar.extractfile(fname)
+ except KeyError:
+ tar.close()
+ return 0
# set the output name
@@ -105,6 +123,7 @@
# extract data
tar.extractall()
+ tar.close()
if os.path.exists(os.path.join(data_name, 'coor')):
pass
elif os.path.exists(os.path.join(data_name, 'cell')):
