[GRASS-SVN] r70975 - grass/trunk/vector/v.out.postgis
Fri Apr 28 03:34:31 PDT 2017
Author: martinl
Date: 2017-04-28 03:34:31 -0700 (Fri, 28 Apr 2017)
New Revision: 70975
   grass/trunk/vector/v.out.postgis/main.c
v.out.postgis: do not print build info when exporting simple features
Modified: grass/trunk/vector/v.out.postgis/main.c
--- grass/trunk/vector/v.out.postgis/main.c	2017-04-28 09:19:12 UTC (rev 70974)
+++ grass/trunk/vector/v.out.postgis/main.c	2017-04-28 10:34:31 UTC (rev 70975)
@@ -32,7 +32,7 @@
     struct params params;
     struct flags flags;
-    int ret, field, otype;
+    int ret, field, otype, verbose;
     char *schema, *olayer, *pg_file;
     char *fid_column, *geom_column;
@@ -170,12 +170,18 @@
     /* close input map */
     Vect_close(&In);
-    /* build topology for output map */
+    /* build topology for output map -> write output to DB */
+    G_message(_("Writing output..."));
+    verbose = G_verbose();
+    if (!flags.topo->answer)
+        G_set_verbose(0); /* do not print build info when writing simple features */
     Vect_build_partial(&Out, GV_BUILD_NONE);
     if (Vect_build(&Out) != 1)
         G_fatal_error(_("Building %s topology failed"),
                       flags.topo->answer ? "PostGIS" : "pseudo");
+    G_set_verbose(verbose);
     if (Vect_get_num_lines(&Out) < 1)
         G_fatal_error(_("No features exported. PostGIS layer <%s> not created."),
                       Vect_get_name(&Out));
