[GRASS-SVN] r70976 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Fri Apr 28 03:36:07 PDT 2017
Author: martinl
Date: 2017-04-28 03:36:07 -0700 (Fri, 28 Apr 2017)
New Revision: 70976
grass/trunk/lib/vector/Vlib/build.c
grass/trunk/lib/vector/Vlib/copy.c
vlib: skip build message when using PostGIS Topology (cosmetics)
Modified: grass/trunk/lib/vector/Vlib/build.c
--- grass/trunk/lib/vector/Vlib/build.c 2017-04-28 10:34:31 UTC (rev 70975)
+++ grass/trunk/lib/vector/Vlib/build.c 2017-04-28 10:36:07 UTC (rev 70976)
@@ -867,7 +867,7 @@
plus = &(Map->plus);
- if (build > GV_BUILD_NONE && !Map->temporary) {
+ if (build > GV_BUILD_NONE && !Map->temporary && Map->format != GV_FORMAT_POSTGIS) {
G_message(_("Building topology for vector map <%s>..."),
Vect_get_full_name(Map));
Modified: grass/trunk/lib/vector/Vlib/copy.c
--- grass/trunk/lib/vector/Vlib/copy.c 2017-04-28 10:34:31 UTC (rev 70975)
+++ grass/trunk/lib/vector/Vlib/copy.c 2017-04-28 10:36:07 UTC (rev 70976)
@@ -96,8 +96,6 @@
Vect_rewind(In);
Vect_set_constraint_type(In, GV_POINT | GV_LINES);
type = Vect_read_next_line(In, NULL, NULL);
- if (!(type & (GV_POINTS | GV_LINES)))
- G_fatal_error(_("Unsupported feature type %d"), type);
/* create feature table with given feature type */
if (0 > Vect_write_line(Out, type, NULL, NULL)) {
