[GRASS-SVN] r70977 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Fri Apr 28 03:52:34 PDT 2017
Author: martinl
Date: 2017-04-28 03:52:34 -0700 (Fri, 28 Apr 2017)
New Revision: 70977
grass/trunk/lib/vector/Vlib/copy.c
vlib: fix copying centroids when using PostGIS Topology (see 'v.out.postgis -l')
Modified: grass/trunk/lib/vector/Vlib/copy.c
--- grass/trunk/lib/vector/Vlib/copy.c 2017-04-28 10:36:07 UTC (rev 70976)
+++ grass/trunk/lib/vector/Vlib/copy.c 2017-04-28 10:52:34 UTC (rev 70977)
@@ -94,7 +94,7 @@
/* get type of first feature from input vector map */
Vect_rewind(In);
- Vect_set_constraint_type(In, GV_POINT | GV_LINES);
+ Vect_set_constraint_type(In, GV_POINTS | GV_LINES);
type = Vect_read_next_line(In, NULL, NULL);
/* create feature table with given feature type */
