[GRASS-SVN] r71419 - in grass/trunk/raster/r.sim: r.sim.sediment r.sim.water simlib
svn_grass at osgeo.org
Sat Aug 19 13:54:53 PDT 2017
Author: annakrat
Date: 2017-08-19 13:54:53 -0700 (Sat, 19 Aug 2017)
New Revision: 71419
grass/trunk/raster/r.sim/r.sim.sediment/main.c
grass/trunk/raster/r.sim/r.sim.water/main.c
grass/trunk/raster/r.sim/simlib/hydro.c
r.sim: fix when openmp is not available
Modified: grass/trunk/raster/r.sim/r.sim.sediment/main.c
--- grass/trunk/raster/r.sim/r.sim.sediment/main.c 2017-08-19 20:46:08 UTC (rev 71418)
+++ grass/trunk/raster/r.sim/r.sim.sediment/main.c 2017-08-19 20:54:53 UTC (rev 71419)
@@ -375,7 +375,11 @@
threads, abs(threads));
threads = abs(threads);
+#if defined(_OPENMP)
omp_set_num_threads(threads);
+#else
+ threads = 1;
+#endif
G_message(_("Number of threads: %d"), threads);
/* sscanf(parm.nwalk->answer, "%d", &wp.maxwa); */
Modified: grass/trunk/raster/r.sim/r.sim.water/main.c
--- grass/trunk/raster/r.sim/r.sim.water/main.c 2017-08-19 20:46:08 UTC (rev 71418)
+++ grass/trunk/raster/r.sim/r.sim.water/main.c 2017-08-19 20:54:53 UTC (rev 71419)
@@ -403,7 +403,11 @@
+#else
+ threads = 1;
+#endif
/* if no rain map input, then: */
Modified: grass/trunk/raster/r.sim/simlib/hydro.c
--- grass/trunk/raster/r.sim/simlib/hydro.c 2017-08-19 20:46:08 UTC (rev 71418)
+++ grass/trunk/raster/r.sim/simlib/hydro.c 2017-08-19 20:54:53 UTC (rev 71419)
@@ -25,7 +25,6 @@
#include <grass/waterglobs.h>
#include <grass/simlib.h>
* Soeren 8. Mar 2011 TODO:
* Put all these global variables into several meaningful structures and
@@ -270,12 +269,16 @@
#pragma omp parallel firstprivate(l,lw,k,decr,d1,hhc,velx,vely,eff,gaux,gauy)//nwalka
int steps = (int)((((double)nwalk) / ((double) omp_get_num_threads())) + 0.5);
int tid = omp_get_thread_num();
int min_loop = tid * steps;
int max_loop = ((tid + 1) * steps) > nwalk ? nwalk : (tid + 1) * steps;
for (lw = min_loop; lw < max_loop; lw++) {
+#else
+ for (lw = 0; lw < nwalk; lw++) {
+#endif
if (w[lw][2] > EPS) { /* check the walker weight */
++nwalka;
l = (int)((w[lw][0] + stxm) / stepx) - mx - 1;
@@ -312,7 +315,12 @@
gama[k][l] += (addac * w[lw][2]); /* add walker weigh to water depth or conc. */
d1 = gama[k][l] * conn;
gasdev_for_paralel(&gaux, &gauy);
+#else
+ gaux = gasdev();
+ gauy = gasdev();
+#endif
hhc = pow(d1, 3. / 5.);
if (hhc > hhmax && wdepth == NULL) { /* increased diffusion if w.depth > hhmax */
