[GRASS-SVN] r71420 - grass/trunk/raster3d/r3.null/testsuite
svn_grass at osgeo.org
Sat Aug 19 14:39:59 PDT 2017
Author: wenzeslaus
Date: 2017-08-19 14:39:59 -0700 (Sat, 19 Aug 2017)
New Revision: 71420
Added:
grass/trunk/raster3d/r3.null/testsuite/test_r3_null_ticket_2992_more_nulls.sh
grass/trunk/raster3d/r3.null/testsuite/test_r3_null_ticket_2992_null_by_value.sh
r3.null: two tests for #2992 (fail)
Added: grass/trunk/raster3d/r3.null/testsuite/test_r3_null_ticket_2992_more_nulls.sh
--- grass/trunk/raster3d/r3.null/testsuite/test_r3_null_ticket_2992_more_nulls.sh (rev 0)
+++ grass/trunk/raster3d/r3.null/testsuite/test_r3_null_ticket_2992_more_nulls.sh 2017-08-19 21:39:59 UTC (rev 71420)
@@ -0,0 +1,33 @@
+#!/bin/bash
+# Tests for r3.null, Trac ticket #2992 I
+# replacing values by NULLs creates too many NULLs
+set -e
+set -x
+# setup
+# works in NC SPM
+g.region -3 n=220180 s=219900 w=638360 e=638720 t=153 b=106 res=2 res3=2
+r3.mapcalc expr="test_1 = float(col() + row() + depth())"
+# test
+# cols, rows numbered in rast algebra from 1,
+# so there should be one cell with value 3
+r3.null map=test_1 setnull=3
+eval `r3.univar map=test_1 -g | grep null_cells`
+reference=1
+if (( $null_cells != $reference )) ; then
+ >&2 echo "Wrong number of NULL cells ($null_cells != $reference)"
+ exit 1
+fi
+# cleanup
+g.remove -f type=rast3 name=test_1
Property changes on: grass/trunk/raster3d/r3.null/testsuite/test_r3_null_ticket_2992_more_nulls.sh
___________________________________________________________________
Added: svn:executable
Added: grass/trunk/raster3d/r3.null/testsuite/test_r3_null_ticket_2992_null_by_value.sh
--- grass/trunk/raster3d/r3.null/testsuite/test_r3_null_ticket_2992_null_by_value.sh (rev 0)
+++ grass/trunk/raster3d/r3.null/testsuite/test_r3_null_ticket_2992_null_by_value.sh 2017-08-19 21:39:59 UTC (rev 71420)
@@ -0,0 +1,33 @@
+#!/bin/bash
+# Tests for r3.null, Trac ticket #2992 II
+# replacing (non-existing) NULLs by values creates NULLs
+set -e
+set -x
+# setup
+# works in NC SPM
+# test
+# there were no NULLs to start with,
+# so there should be none afterwards
+r3.null map=test_1 null=10
+reference=0
+ exit 1
+fi
+# cleanup
Property changes on: grass/trunk/raster3d/r3.null/testsuite/test_r3_null_ticket_2992_null_by_value.sh
