[GRASS-SVN] r71461 - in grass/trunk/locale: . po transifex transifex/.tx
Thu Aug 31 13:55:23 PDT 2017
Author: neteler
Date: 2017-08-31 13:55:23 -0700 (Thu, 31 Aug 2017)
New Revision: 71461
Added:
   grass/trunk/locale/transifex/
   grass/trunk/locale/transifex/.tx/
   grass/trunk/locale/transifex/.tx/config
   grass/trunk/locale/po/grasslibs_es.po
   grass/trunk/locale/po/grasslibs_fr.po
   grass/trunk/locale/po/grasslibs_id_ID.po
   grass/trunk/locale/po/grasslibs_pl.po
   grass/trunk/locale/po/grasslibs_si.po
   grass/trunk/locale/po/grasslibs_uk.po
   grass/trunk/locale/po/grasslibs_vi.po
   grass/trunk/locale/po/grassmods_cs.po
   grass/trunk/locale/po/grassmods_de.po
   grass/trunk/locale/po/grassmods_el.po
   grass/trunk/locale/po/grassmods_es.po
   grass/trunk/locale/po/grassmods_fi.po
   grass/trunk/locale/po/grassmods_fr.po
   grass/trunk/locale/po/grassmods_id_ID.po
   grass/trunk/locale/po/grassmods_it.po
   grass/trunk/locale/po/grassmods_ja.po
   grass/trunk/locale/po/grassmods_ko.po
   grass/trunk/locale/po/grassmods_lv.po
   grass/trunk/locale/po/grassmods_ml.po
   grass/trunk/locale/po/grassmods_pl.po
   grass/trunk/locale/po/grassmods_pt.po
   grass/trunk/locale/po/grassmods_pt_BR.po
   grass/trunk/locale/po/grassmods_ro.po
   grass/trunk/locale/po/grassmods_ru.po
   grass/trunk/locale/po/grassmods_si.po
   grass/trunk/locale/po/grassmods_th.po
   grass/trunk/locale/po/grassmods_tr.po
   grass/trunk/locale/po/grassmods_uk.po
   grass/trunk/locale/po/grassmods_vi.po
   grass/trunk/locale/po/grassmods_zh.po
   grass/trunk/locale/po/grasswxpy_es.po
   grass/trunk/locale/po/grasswxpy_id_ID.po
   grass/trunk/locale/po/grasswxpy_it.po
   grass/trunk/locale/po/grasswxpy_ja.po
   grass/trunk/locale/po/grasswxpy_pl.po
   grass/trunk/locale/po/grasswxpy_pt_BR.po
   grass/trunk/locale/po/grasswxpy_si.po
   grass/trunk/locale/po/grasswxpy_uk.po
   grass/trunk/locale/po/grasswxpy_vi.po
i18N: updated from transifex server with grass-addons/tools/transifex_merge.sh
Modified: grass/trunk/locale/po/grasslibs_es.po
--- grass/trunk/locale/po/grasslibs_es.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grasslibs_es.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -146,7 +146,7 @@
 #: ../lib/rst/interp_float/output2d.c:491
 #, c-format
 msgid "Raster map <%s> not found"
-msgstr "No se ha encontrado el mapa raster <%s>"
+msgstr "Mapa ráster <%s> no encontrado"
 #: ../lib/ogsf/gsd_legend.c:246
 #, c-format
@@ -460,7 +460,7 @@
 #: ../lib/raster3d/close.c:79
 msgid "Unable to flush all tiles"
-msgstr ""
+msgstr "Imposible levantar todos los tiles"
 #: ../lib/raster3d/close.c:84
 msgid "Unable to flush index"
@@ -915,7 +915,7 @@
 #: ../lib/python/gunittest/gmodules.py:103
 msgid "input='-' must be used when stdin is specified"
-msgstr ""
+msgstr "input='-' debe ser usado cuando se use la entrada estándar"
 #: ../lib/python/gunittest/gmodules.py:105
 msgid "stdin must be string or buffer, not PIPE"
@@ -923,7 +923,7 @@
 #: ../lib/python/gunittest/gmodules.py:108
 msgid "stdin must be used when input='-'"
-msgstr ""
+msgstr "Se debe usar la entrada estándar (stdin) cuando input='-'"
 #: ../lib/python/gunittest/gmodules.py:110
 msgid "You cannot merge stdout and stderr and not capture them"
@@ -1019,12 +1019,12 @@
 #: ../lib/python/pygrass/vector/__init__.py:806
 #, python-format
 msgid "Unable to read line of feature %i"
-msgstr ""
+msgstr "No se puede leer la línea del elemento %i"
 #: ../lib/python/pygrass/vector/__init__.py:895
 #, python-format
 msgid "Unable to read area with id %i"
-msgstr ""
+msgstr "Imposible leer el área con id %i"
 #: ../lib/python/pygrass/modules/grid/grid.py:553
 msgid "Execution of subprocesses was not successful"
@@ -1274,6 +1274,10 @@
 "Please update your GRASS GIS installation.\n"
 "Current temporal database info:%(info)s"
 msgstr ""
+"Base de datos temporal no soportada: no coinciden las versiones.\n"
+"%(backup)s La versión de base de datos soportada es: %(api)i.\n"
+"Por favor actualice su instalación de GRASS GIS. \n"
+"Información de la base de datos temporal actual:%(info)s"
 #: ../lib/python/temporal/core.py:680
 #, python-format
@@ -1308,23 +1312,23 @@
 #: ../lib/python/temporal/core.py:964
 msgid "Unable to check table. "
-msgstr ""
+msgstr "No se puede controlar la tabla."
 #: ../lib/python/temporal/core.py:980
 msgid "Unable to execute sql statement. "
-msgstr ""
+msgstr "No se puede ejecutar la sentencia sql."
 #: ../lib/python/temporal/core.py:990
 msgid "Unable to fetch one. "
-msgstr ""
+msgstr "No se puede recuperar uno."
 #: ../lib/python/temporal/core.py:1000
 msgid "Unable to fetch all. "
-msgstr ""
+msgstr "No se puede recuperar todo."
 #: ../lib/python/temporal/core.py:1017
 msgid "Unable to execute transaction. "
-msgstr ""
+msgstr "No ha sido posible ejecutar la transacción."
 #: ../lib/python/temporal/core.py:1120
 #, python-format
@@ -1359,7 +1363,7 @@
 #: ../lib/python/temporal/univar_statistics.py:178
 #, python-format
 msgid "Space time %(sp)s dataset <%(i)s> is empty"
-msgstr ""
+msgstr "El conjunto de datos %(sp)s espacio temporales <%(i)s> está vacío"
 #: ../lib/python/temporal/univar_statistics.py:101
 #, python-format
@@ -1397,7 +1401,7 @@
 #: ../lib/python/temporal/temporal_algebra.py:810
 msgid "Spatio-temporal topological operators are not supported in granularity algebra mode"
-msgstr ""
+msgstr "Los operadores topológicos espacio-temporales no están soportados en el álgebra modo granularidad"
 #: ../lib/python/temporal/temporal_algebra.py:848
 msgid "All input space time datasets must have a valid temporal topology."
@@ -1438,23 +1442,23 @@
 #: ../lib/python/temporal/temporal_algebra.py:2319
 msgid "Wrong map type. TMAP only supports single maps that are registered in the temporal GRASS database"
-msgstr ""
+msgstr "Tipo de mapa incorrecto. TMAP sólo soporta mapas que estén registrados en la base de datos temporal"
 #: ../lib/python/temporal/temporal_algebra.py:2347
 msgid "Merging empty map lists"
-msgstr ""
+msgstr "Uniendo listas de mapas vacías"
 #: ../lib/python/temporal/temporal_algebra.py:2350
 msgid "First Map list is empty, can't merge it. Return only last map list"
-msgstr ""
+msgstr "La primera lista de mapas esta vacía, no es posible unirla. Devolver únicamente la última lista de mapas"
 #: ../lib/python/temporal/temporal_algebra.py:2353
 msgid "Second Map list is empty, can't merge it. Return only first map list"
-msgstr ""
+msgstr "La segunda lista de mapas esta vacía, no es posible unirla. Devolver únicamente la primer lista de mapas"
 #: ../lib/python/temporal/temporal_algebra.py:2361
 msgid "Space time datasets to merge must have the same temporal type"
-msgstr ""
+msgstr "Los conjuntos de datos espacio temporales a ser unidos deben ser del mismo tipo de tiempo"
 #: ../lib/python/temporal/register.py:82 ../lib/python/temporal/register.py:85
 #, python-format
@@ -2020,7 +2024,7 @@
 #: ../lib/python/temporal/base.py:462 ../lib/python/temporal/base.py:513
 msgid "Missing identifier"
-msgstr ""
+msgstr "Identificador faltante"
 #: ../lib/python/temporal/base.py:621
 msgid "Wrong identifier, the mapset is missing"
@@ -2058,13 +2062,13 @@
 #: ../lib/python/temporal/aggregation.py:319
 #, python-format
 msgid "The limit of open files (%i) was reached (%i). The module r.series will be run with flag z, to avoid open files limit exceeding."
-msgstr ""
+msgstr "El limite de archivos abierto (%i) ha sido alcanzado (%i). El módulo r.series se ejecutara con el flag z, para evitar exceder el límite de archivos abiertos. "
 #: ../lib/python/temporal/open_stds.py:63
 #: ../lib/python/temporal/open_stds.py:119
 #, python-format
 msgid "Unknown type: %s"
-msgstr ""
+msgstr "Tipo desconocido: %s"
 #: ../lib/python/temporal/open_stds.py:69
 #, python-format
@@ -2088,7 +2092,7 @@
 #: ../lib/python/temporal/open_stds.py:168
 #, python-format
 msgid "Creating a new space time %s dataset"
-msgstr ""
+msgstr "Creando un nuevo conjunto de datos %s espacio temporales"
 #: ../lib/python/temporal/extract.py:60
 msgid "You need to specify the base name of new created maps"
@@ -2200,7 +2204,7 @@
 #: ../lib/python/script/vector.py:350
 #, python-brace-format
 msgid "Number of given vector maps ({m}) differs from number of layers ({l})"
-msgstr ""
+msgstr "Número de mapas vectoriales dado ({m}) difiere del número de capas ({l})"
 #: ../lib/python/script/vector.py:407
@@ -2250,20 +2254,20 @@
 #: ../lib/python/script/db.py:163
 msgid "Fetching data failed"
-msgstr ""
+msgstr "Fallo al recuperar los datos"
 #: ../lib/python/script/array.py:157 ../lib/python/script/array.py:207
 #: ../lib/python/script/array.py:254 ../lib/python/script/array.py:305
 #: ../lib/python/script/array.py:356 ../lib/python/script/array.py:398
 #, python-format
 msgid "Invalid kind <%s>"
-msgstr ""
+msgstr "Clase  no válida <%s>"
 #: ../lib/python/script/array.py:160 ../lib/python/script/array.py:210
 #: ../lib/python/script/array.py:308 ../lib/python/script/array.py:359
 #, python-format
 msgid "Invalid size <%d>"
-msgstr ""
+msgstr "Tamaño no válido <%d>"
 #: ../lib/python/script/array.py:197
 msgid "grass.script.array.read is deprecated and does not work on MS Windows, pass raster name in the constructor"
@@ -2272,12 +2276,12 @@
 #: ../lib/python/script/array.py:247 ../lib/python/script/array.py:392
 #, python-format
 msgid "Invalid FP size <%d>"
-msgstr ""
+msgstr "Tamaño de punto flotante inválido <%d>"
 #: ../lib/python/script/array.py:251 ../lib/python/script/array.py:395
 #, python-format
 msgid "Invalid integer size <%d>"
-msgstr ""
+msgstr "Tamaño de entero no válido <%d>"
 #: ../lib/python/script/array.py:346
 msgid "grass.script.array3d.read is deprecated and does not work on MS Windows, pass 3D raster name in the constructor"
@@ -2313,6 +2317,8 @@
 "\n"
 "Details: %(det)s"
 msgstr ""
+"No se puede recuperar la descripción para el comando '%(cmd)s':\n"
+"Detalles:%(det)s"
 #: ../lib/python/script/task.py:530
@@ -2330,6 +2336,8 @@
 "\n"
 "Process ended with non-zero return code %s"
 msgstr ""
+"\n"
+"El proceso terminó con código de retorno no cero %s"
 #: ../lib/python/exceptions/__init__.py:71
 #, python-format
@@ -2615,7 +2623,7 @@
 #: ../lib/gmath/la.c:220
 msgid "Input matrix is uninitialized"
-msgstr ""
+msgstr "La matriz de entrada no ha sido inicializada"
 #: ../lib/gmath/la.c:285
 msgid "First scalar multiplier must be non-zero"
@@ -3013,7 +3021,7 @@
 #: ../lib/rst/interp_float/vinput2d.c:129
 #, c-format
 msgid "Column <%s> not found"
-msgstr "No ha encontrado la columna <%s>"
+msgstr "Columna <%s> no encontrada"
 #: ../lib/db/dbmi_client/copy_tab.c:294
 #, c-format
@@ -3284,7 +3292,7 @@
 #: ../lib/raster/init.c:109
 #, c-format
 msgid "Unknown compression method <%s>, using default ZLIB"
-msgstr ""
+msgstr "Método de compresión desconocido <%s>, usando ZLIB por defecto"
 #: ../lib/raster/init.c:113
 msgid "No compression is not supported for GRASS raster maps, using default ZLIB"
@@ -3293,12 +3301,12 @@
 #: ../lib/raster/init.c:118
 #, c-format
 msgid "This GRASS version does not support %s compression, using default ZLIB"
-msgstr ""
+msgstr "Esta versión de GRASS no soporta la compresión %s, utilizando ZLIB por defecto"
 #: ../lib/raster/range.c:102
 #, c-format
 msgid "Unable to read fp range file for <%s>"
-msgstr ""
+msgstr "No se puede leer el rango de punto flotante para <%s>"
 #: ../lib/raster/range.c:169
 #, c-format
@@ -3368,7 +3376,7 @@
 #: ../lib/raster/put_row.c:513 ../lib/raster/put_row.c:518
 #, c-format
 msgid "Error writing compressed null data for row %d of <%s>"
-msgstr ""
+msgstr "Error al escribir datos nulos comprimidos para fila %d de <%s>"
 #: ../lib/raster/put_row.c:552 ../lib/raster/put_row.c:555
 #, c-format
@@ -3460,7 +3468,7 @@
 #: ../lib/raster/open.c:198
 #, c-format
 msgid "Error reading reclass file for raster map <%s>"
-msgstr ""
+msgstr "Error al leer el archivo reclass para el mapa ráster <%s>"
 #: ../lib/raster/open.c:209
 #, c-format
@@ -3475,7 +3483,7 @@
 #: ../lib/raster/open.c:236
 #, c-format
 msgid "Compression with %s is not supported"
-msgstr ""
+msgstr "Compresión con %s no soportada"
 #: ../lib/raster/open.c:240
 #, c-format
@@ -3495,7 +3503,7 @@
 #: ../lib/raster/open.c:277
 #, c-format
 msgid "Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
-msgstr ""
+msgstr "El mapa ráster <%s@%s> es una conexión GDAL pero GRASS ha sido compilado sin soporte para GDAL"
 #: ../lib/raster/open.c:285
 #, c-format
@@ -3505,7 +3513,7 @@
 #: ../lib/raster/open.c:322
 #, c-format
 msgid "Error reading format for <%s@%s>"
-msgstr ""
+msgstr "Error al leer el formato para <%s@%s>"
 #: ../lib/raster/open.c:527
 msgid "Unable to create GDAL link"
@@ -3534,7 +3542,7 @@
 #: ../lib/raster/open.c:755
 #, c-format
 msgid "Raster map <%s> does not exist in the current mapset (%s)"
-msgstr ""
+msgstr "Mapa ráster <%s> no se encuentra en el Directorio de mapas actual (%s)"
 #: ../lib/raster/open.c:821
 msgid "Rast_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
@@ -3607,7 +3615,7 @@
 #: ../lib/raster/close.c:461
 #, c-format
 msgid "Unable to rename cell file '%s' to '%s': %s"
-msgstr ""
+msgstr "No se puede renombrar el archivo cell '%s' a '%s': %s"
 #: ../lib/raster/close.c:541
 msgid "unable to write f_format file for CELL maps"
@@ -3652,7 +3660,7 @@
 #: ../lib/raster/gdal.c:491
 #, c-format
 msgid "Unable to create <%s> dataset using <%s> driver"
-msgstr ""
+msgstr "No se puede crear el conjunto de datos <%s> usando el controlador <%s>"
 #: ../lib/raster/gdal.c:499
 #, c-format
@@ -3666,7 +3674,7 @@
 #: ../lib/raster/gdal.c:512
 #, c-format
 msgid "Unable to create <%s> dataset using memory driver"
-msgstr ""
+msgstr "No ha sido posible crear el conjunto de datos <%s> usando el controlador de memoria"
 #: ../lib/raster/gdal.c:516
 #, c-format
@@ -3819,33 +3827,33 @@
 #: ../lib/raster/get_row.c:191
 #, c-format
 msgid "Error reading raster data for row %d of <%s>"
-msgstr ""
+msgstr "Error al leer los datos ráster para la fila %d de <%s>"
 #: ../lib/raster/get_row.c:102 ../lib/raster/get_row.c:168
 #, c-format
 msgid "Error uncompressing raster data for row %d of <%s>"
-msgstr ""
+msgstr "Error al descomprimir los datos ráster para la fila %d de <%s>"
 #: ../lib/raster/get_row.c:227
 #, c-format
 msgid "Error reading raster data via GDAL for row %d of <%s>"
-msgstr ""
+msgstr "Error al leer los datos ráster a través de GDAL para la fila %d de <%s>"
 #: ../lib/raster/get_row.c:827 ../lib/raster/get_row.c:832
 #: ../lib/raster/get_row.c:842
 #, c-format
 msgid "Error reading null data for row %d of <%s>"
-msgstr ""
+msgstr "Error al leer datos nulos para fila %d de <%s>"
 #: ../lib/raster/get_row.c:848
 #, c-format
 msgid "Error uncompressing null data for row %d of <%s>"
-msgstr ""
+msgstr "Error al descomprimir datos nulos para fila %d de <%s>"
 #: ../lib/raster/get_row.c:882 ../lib/raster/get_row.c:885
 #, c-format
 msgid "Error reading null row %d for <%s>"
-msgstr ""
+msgstr "Error al leer fila nula %d de <%s>"
 #: ../lib/raster/window.c:31
 msgid "Internal error: Rast_get_window() called with split window. Use Rast_get_input_window() or Rast_get_output_window() instead."
@@ -3892,7 +3900,7 @@
 #: ../lib/raster/put_cellhd.c:34
 #, c-format
 msgid "Unable to create header file for <%s>"
-msgstr ""
+msgstr "No ha sido posible crear el archivo de cabecera para <%s>"
 #: ../lib/gis/lrand48.c:84
 #, c-format
@@ -4006,11 +4014,11 @@
 #: ../lib/gis/compress.c:131 ../lib/gis/compress.c:193
 #: ../lib/gis/compress.c:209
 msgid "Request for unsupported compressor"
-msgstr ""
+msgstr "Se pidió un compresor no soportado "
 #: ../lib/gis/cmprbzip.c:82 ../lib/gis/cmprbzip.c:142
 msgid "GRASS needs to be compiled with BZIP2 for BZIP2 compression"
-msgstr ""
+msgstr "GRASS necesita ser compilado con BZIP2 para la compresión BZIP2"
 #: ../lib/gis/proj2.c:63
 msgid "Latitude-Longitude"
@@ -4117,7 +4125,7 @@
 #: ../lib/gis/parser_help.c:220
 msgid "Super quiet module output"
-msgstr ""
+msgstr "Salida súper silenciosa del módulo."
 #: ../lib/gis/parser_help.c:221 ../lib/gis/parser_html.c:180
 msgid "Force launching GUI dialog"
@@ -4302,23 +4310,23 @@
 #: ../lib/gis/parser_standard_options.c:334
 msgid "Type of raster map to be created"
-msgstr ""
+msgstr "Tipo de mapa ráster a ser creado"
 #: ../lib/gis/parser_standard_options.c:335
 msgid "Storage type for resultant raster map"
-msgstr ""
+msgstr "Tipo de almacenamiento para el mapa ráster resultante"
 #: ../lib/gis/parser_standard_options.c:339
 msgid "Integer"
-msgstr ""
+msgstr "Entero"
 #: ../lib/gis/parser_standard_options.c:340
 msgid "Single precision floating point"
-msgstr ""
+msgstr "Punto flotante de precisión simple"
 #: ../lib/gis/parser_standard_options.c:341
 msgid "Double precision floating point"
-msgstr ""
+msgstr "Punto flotante de precisión doble"
 #: ../lib/gis/parser_standard_options.c:347
 msgid "Sampling interpolation method"
@@ -4623,12 +4631,12 @@
 #: ../lib/gis/parser_standard_options.c:937
 msgid "Advantageous when handling a large number of points"
-msgstr ""
+msgstr "Ventajoso cuando se maneja un gran número de puntos"
 #: ../lib/gis/get_window.c:118
 #, c-format
 msgid "Unable to open element file <%s> for <%s@%s>"
-msgstr ""
+msgstr "No ha sido posible abrir archivo de elemento %s para <%s@%s>"
 #: ../lib/gis/get_window.c:123
 #, c-format
@@ -4856,7 +4864,7 @@
 #: ../lib/gis/parser.c:554
 msgid "Use either --qq or --verbose flag, not both. Assuming --qq."
-msgstr ""
+msgstr "Utilice --qq o --verbose, no ambas. Asumiendo --qq."
 #: ../lib/gis/parser.c:585
 #, c-format
@@ -5157,11 +5165,11 @@
 #: ../lib/gis/rd_cellhd.c:225
 msgid "Duplicate top field"
-msgstr ""
+msgstr "Duplica el campo de cima"
 #: ../lib/gis/rd_cellhd.c:233
 msgid "Duplicate bottom field"
-msgstr ""
+msgstr "Duplica el campo de fondo"
 #: ../lib/gis/rd_cellhd.c:241
 msgid "Duplicate e-w resolution field"
@@ -5181,7 +5189,7 @@
 #: ../lib/gis/rd_cellhd.c:281
 msgid "Duplicate t-b resolution field"
-msgstr ""
+msgstr "Duplica el campo de resolución cima-fondo"
 #: ../lib/gis/rd_cellhd.c:291
 msgid "Duplicate rows field"
@@ -5397,7 +5405,7 @@
 #: ../lib/gis/paths.c:217
 #, c-format
 msgid "Unable to fetch security info for <%s>"
-msgstr ""
+msgstr "No se puede recuperar la información de seguridad para <%s>"
 #: ../lib/gis/parser_dependencies.c:122
 msgid "Internal error: option or flag not found"
@@ -5532,7 +5540,7 @@
 #: ../lib/htmldriver/graph_set.c:98
 #, c-format
 msgid "html: image size %dx%d"
-msgstr "html: Tamaño de archivo %d x %d."
+msgstr "html: tamaño de imagen %d x %d"
 #: ../lib/htmldriver/graph_set.c:111 ../lib/htmldriver/graph_set.c:115
 #: ../lib/htmldriver/graph_set.c:119
@@ -5584,7 +5592,7 @@
 #: ../lib/display/r_raster.c:98
 #, c-format
 msgid "Both %s and %s are defined. %s will be ignored."
-msgstr ""
+msgstr "Tanto %s como %s están definidos. %s será ignorado."
 #: ../lib/display/r_raster.c:131
 #, c-format
@@ -5683,7 +5691,7 @@
 #: ../lib/init/grass.py:348
 msgid "initial GRASS GIS database directory"
-msgstr ""
+msgstr "directorio inicial para la base de datos de GRASS GIS"
 #: ../lib/init/grass.py:349
 msgid "directory containing Locations"
@@ -5703,7 +5711,7 @@
 #: ../lib/init/grass.py:353
 msgid "fully qualified initial Mapset directory"
-msgstr ""
+msgstr "directorio de mapas inicial completamente cualificado"
 #: ../lib/init/grass.py:354
 msgid "Environment variables relevant for startup"
@@ -5731,7 +5739,7 @@
 #: ../lib/init/grass.py:360
 msgid "set Python interpreter name to override 'python'"
-msgstr ""
+msgstr "defina el nombre del intérprete Python a sobreescribir 'python'"
 #: ../lib/init/grass.py:361
 msgid "execute GRASS module or script"
@@ -5739,7 +5747,7 @@
 #: ../lib/init/grass.py:362
 msgid "provided executable will be executed in GRASS session"
-msgstr ""
+msgstr "el archivo ejecutable será ejecutado en la sesión de GRASS"
 #: ../lib/init/grass.py:363
 msgid "GRASS module, script or any other executable"
@@ -5809,22 +5817,22 @@
 #: ../lib/init/grass.py:843
 #, python-format
 msgid "<%s> is not a valid GRASS Location because PERMANENT Mapset is missing"
-msgstr ""
+msgstr "<%s> no es una localización de GRASS válida porque no contiene el directorio de mapas PERMANENT"
 #: ../lib/init/grass.py:846
 #, python-format
 msgid "<%s> is not a valid GRASS Location because PERMANENT is not a directory"
-msgstr ""
+msgstr "<%s> no es una localización de GRASS válida porque  PERMANENT no es un directorio"
 #: ../lib/init/grass.py:850
 #, python-format
 msgid "<%s> is not a valid GRASS Location because PERMANENT Mapset does not have a DEFAULT_WIND file (default computational region)"
-msgstr ""
+msgstr "<%s> no es una localización de GRASS válida porque el directorio de mapas PERMANENT no contiene el archivo DEFAULT_WIND (región computacional predeterminada)"
 #: ../lib/init/grass.py:854
 msgid "Mapset <{mapset}> doesn't exist in GRASS Location <{loc}>. A new mapset can be created by '-c' switch."
-msgstr ""
+msgstr "No elexiste el Directorio de mapas <{mapset}> en la Localización <{loc}>. Es posible crear un nuevo Direx¿ctorio de mapas usando '-c'"
 #: ../lib/init/grass.py:858
 #, python-format
@@ -5874,6 +5882,8 @@
 "Exit was requested in GUI.\n"
 "GRASS GIS will not start. Bye."
 msgstr ""
+"Salida fue pedida en la GUI.\n"
+"GRASS GIS no iniciará. Adiós."
 #: ../lib/init/grass.py:1004
 msgid ""
@@ -5957,12 +5967,12 @@
 #: ../lib/init/grass.py:1350
 #, python-format
 msgid "Change file permission to 'executable' for <%s>"
-msgstr ""
+msgstr "Cambie los permisos del archivo a 'ejecutable' para <%s>"
 #: ../lib/init/grass.py:1365
 #, python-format
 msgid "Executing <%s> ..."
-msgstr ""
+msgstr "Ejecutando <%s> ..."
 #: ../lib/init/grass.py:1372
@@ -5970,11 +5980,13 @@
 "Execution of <{cmd}> failed:\n"
 "{error}"
 msgstr ""
+"La ejecución de <{cmd}> ha fallado:\n"
+"{error}"
 #: ../lib/init/grass.py:1375
 #, python-format
 msgid "Execution of <%s> finished."
-msgstr ""
+msgstr "La ejecución de <%s> ha terminado."
 #: ../lib/init/grass.py:1406
 #, fuzzy
@@ -6054,7 +6066,7 @@
 #: ../lib/init/grass.py:1801
 msgid "Flag -e requires also flag -c"
-msgstr ""
+msgstr "La bandera -e requiere también de la bandera -c"
 #: ../lib/init/grass.py:1848
@@ -6424,7 +6436,7 @@
 #: ../lib/vector/Vlib/field.c:96
 msgid "Unable to add attribute link, vector map is not opened in WRITE mode"
-msgstr ""
+msgstr "No se puede añadir el enlace del atributo, el mapa vectorial no ha sido abierto en modo ESCRIBIR "
 #: ../lib/vector/Vlib/field.c:103
 msgid "Unable to add attribute link"
@@ -6826,6 +6838,8 @@
 "Execution failed: %s (...)\n"
 "Reason: %s"
 msgstr ""
+"Ha fallado la ejecución: %s (...)\n"
+"Razón: %s"
 #: ../lib/vector/Vlib/read_pg.c:1546
 #, c-format
@@ -7729,7 +7743,7 @@
 #: ../lib/vector/Vlib/close_nat.c:167
 #, c-format
 msgid "Unable to drop table <%s>"
-msgstr ""
+msgstr "No se puede eliminar la tabla <%s>"
 #: ../lib/vector/Vlib/constraint.c:150
 msgid "Layer constraint ignored for non-native vector formats"
@@ -7836,7 +7850,7 @@
 #: ../lib/vector/Vlib/ascii.c:724
 msgid "Unable to fetch data from table"
-msgstr ""
+msgstr "No se pueden recuperar los datos de la tabla"
 #: ../lib/vector/Vlib/ascii.c:756 ../lib/vector/Vlib/net_build.c:216
 #: ../lib/vector/Vlib/net_build.c:501 ../lib/vector/Vlib/net_build.c:519
@@ -8831,7 +8845,7 @@
 #: ../lib/segment/open.c:74
 msgid "Could not write segment file"
-msgstr ""
+msgstr "No ha sido posible escribir el archivo de segmentos"
 #: ../lib/segment/open.c:78
 msgid "Illegal segment configuration parameter(s)"
@@ -8967,7 +8981,7 @@
 #: ../lib/rst/interp_float/resout2d.c:77
 msgid "Temporarily changing the region to desired resolution..."
-msgstr "Cambiando temporalmente la región a la resolución esperada..."
+msgstr "Cambiando temporalmente la región a la resolución deseada..."
 #: ../lib/rst/interp_float/resout2d.c:103
 #, c-format
@@ -8990,7 +9004,7 @@
 #: ../lib/rst/interp_float/vinput2d.c:94
 #, c-format
 msgid "Vector map <%s> is not 3D"
-msgstr "El mapa vectorial <%s> no es 3D."
+msgstr "El mapa vectorial <%s> no es 3D"
 #: ../lib/rst/interp_float/vinput2d.c:97
 msgid "Loading data from attribute table ..."
@@ -9009,7 +9023,7 @@
 #: ../lib/rst/interp_float/vinput2d.c:174
 #, c-format
 msgid "Database record for cat %d not found"
-msgstr "No se ha encontrado el registro de la base de datos de la cat %d."
+msgstr "No se ha encontrado el registro para cat %d en la base de datos"
 #: ../lib/rst/interp_float/vinput2d.c:192
 msgid "Negative value of smoothing detected: sm must be >= 0"
@@ -9036,7 +9050,7 @@
 #: ../lib/rst/interp_float/vinput2d.c:282
 msgid "Zero points in the given region"
-msgstr "Cero puntos en el área dada"
+msgstr "Cero puntos en la región dada"
 #: ../lib/rst/interp_float/vinput2d.c:287
 #, c-format
@@ -9455,3 +9469,98 @@
 #~ msgid "Object <%s> not found in the temporal database"
 #~ msgstr "Objeto <%s> no encontrado en la base de datos temporales"
+#~ msgid "Centroid skipped (output feature type: %s)"
+#~ msgstr "Centroide omitido (tipo de elemento de salida: %s)"
+#~ msgid "Boundary skipped (output feature type: %s)"
+#~ msgstr "Límite omitido (tipo de elemento de salida: %s)"
+#~ msgid "GRASS GUI not found. Please check your installation."
+#~ msgstr "GRASS GUI no hallada. Por favor corrobore su instalación. "
+#~ msgid ""
+#~ "{}\n"
+#~ "Switching to text based interface mode.\n"
+#~ "\n"
+#~ "Hit RETURN to continue.\n"
+#~ msgstr ""
+#~ "{}\n"
+#~ "Cambiando a interfaz modo texto.\n"
+#~ "\n"
+#~ "Presione RETURN para continuar.\n"
+#~ msgid "Unable to close GUI. {0}"
+#~ msgstr "Imposible cerrar la GUI. {0}"
+#~ msgid "<{0}> requested, but not available. Run GRASS in text mode (-text) or install missing package (usually 'grass-gui')."
+#~ msgstr "<[0]> requerido, pero no disponible. Corra GRASS en modo texto (-text) o instale el paquete faltante (usualmente 'grass-gui')"
+#~ msgid "Cannot find the executable {0}"
+#~ msgstr "No se puede encontrar el ejecutable {0}"
+#~ msgid "Data element '%s/%s' was found in more mapsets (also found in <%s>)"
+#~ msgstr "Elemento de datos '%s/%s' encontrado en otros directorios de mapas (también encontrado en <%s>)"
+#~ msgid "Using <%s@%s>..."
+#~ msgstr "Usando <%s@%s>..."
+#~ msgid "Syntax error in cell header, line %d: %s"
+#~ msgstr "Error de sintaxis en el encabezado de celda, línea %d: %s"
+#~ msgid "Invalid projection field: %s"
+#~ msgstr "Campo de proyección no válido: %s"
+#~ msgid "Invalid zone field: %s"
+#~ msgstr "Campo zona no válido: %s"
+#~ msgid "Invalid north field: %s"
+#~ msgstr "Campo norte no válido: %s"
+#~ msgid "Invalid south field: %s"
+#~ msgstr "Campo sur no válido: %s"
+#~ msgid "Invalid east field: %s"
+#~ msgstr "Campo este no válido: %s"
+#~ msgid "Invalid west field: %s"
+#~ msgstr "Campo oeste no válido: %s"
+#~ msgid "Invalid bottom field: %s"
+#~ msgstr "Campo de fondo no válido: %s"
+#~ msgid "Invalid e-w resolution field: %s"
+#~ msgstr "Campo de resolución e-o no válido: %s"
+#~ msgid "Invalid 3D e-w resolution field: %s"
+#~ msgstr "Campo de resolución 3D e-o no válido: %s"
+#~ msgid "Invalid n-s resolution field: %s"
+#~ msgstr "Campo de resolución n-s no válido: %s"
+#~ msgid "Invalid 3D n-s resolution field: %s"
+#~ msgstr "Campo de resolución 3D n-s no válido: %s"
+#~ msgid "Invalid t-b resolution field: %s"
+#~ msgstr "Campo de resolución cima-fondo no válido: %s"
+#~ msgid "Invalid rows field: %s"
+#~ msgstr "Campo de filas no válido: %s"
+#~ msgid "Invalid 3D rows field: %s"
+#~ msgstr "Campo de filas 3D no válido: %s"
+#~ msgid "Invalid cols field: %s"
+#~ msgstr "Campo de columnas no válido: %s"
+#~ msgid "Invalid 3D cols field: %s"
+#~ msgstr "Campo de columnas 3D no válido: %s"
+#~ msgid "Invalid depths field: %s"
+#~ msgstr "Campo de profundidades no válido: %s"
+#~ msgid "Invalid format field: %s"
+#~ msgstr "Campo de formato no válido: %s"
+#~ msgid "Invalid compressed field: %s"
+#~ msgstr "Campo de compresión no válido: %s"
Modified: grass/trunk/locale/po/grasslibs_fr.po
--- grass/trunk/locale/po/grasslibs_fr.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grasslibs_fr.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -8740,7 +8740,7 @@
 #: ../lib/vector/diglib/plus.c:284
 msgid "Unable to write nodes to plus file"
-msgstr "Impossible d'écrire le noeud dans le fichier plus"
+msgstr "Impossible d'écrire les nœuds dans le fichier plus"
 #: ../lib/vector/diglib/plus.c:289
 msgid "Unable to write lines to plus file"
@@ -9196,7 +9196,7 @@
 #: ../lib/rst/interp_float/input2d.c:81
 msgid "Bitmap mask created"
-msgstr "Masque bitmat créé"
+msgstr "Masque bitmap créé"
 #: ../lib/rst/interp_float/output2d.c:117
 #, c-format
Modified: grass/trunk/locale/po/grasslibs_id_ID.po
--- grass/trunk/locale/po/grasslibs_id_ID.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grasslibs_id_ID.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -2,7 +2,7 @@
 # Copyright (C) 2017 GRASS Development Team
 # This file is distributed under the same license as the GRASS GIS package.
 # transifex generated, 2017
 msgid ""
 msgstr ""
 "Project-Id-Version: grasslibs_id_ID\n"
@@ -11,10 +11,10 @@
 "PO-Revision-Date: 2017-05-23 21:08+0200\n"
 "Last-Translator: Firman Hadi <efha94 at gmail.com>, 2017\n"
 "Language-Team: Indonesian (Indonesia) (https://www.transifex.com/grass-gis/teams/45198/id_ID/)\n"
+"Language: id_ID\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
-"Language: id_ID\n"
 "Plural-Forms: nplurals=1; plural=0;\n"
@@ -59,21 +59,15 @@
 #: ../lib/rst/interp_float/resout2d.c:264
 msgid "No color table for input raster map -- will not create color table"
-msgstr ""
-"Tidak ada tabel warna untuk input peta raster -- tidak akan membuat tabel "
-"warna"
+msgstr "Tidak ada tabel warna untuk input peta raster -- tidak akan membuat tabel warna"
 #: ../lib/rst/interp_float/resout2d.c:458
 msgid "Changing the region back to initial..."
 msgstr "Mengembalikan region ke pengaturan awal ..."
 #: ../lib/rst/interp_float/segmen2d.c:135
-msgid ""
-"Taking too long to find points for interpolation - please change the region "
-"to area where your points are. Continuing calculations..."
-msgstr ""
-"Terlalu lama mencari titik-titik untuk interpolasi - silakan ubah region "
-"yang mencakup wilayah dimana titik Anda berada. Melanjutkan penghitungan ..."
+msgid "Taking too long to find points for interpolation - please change the region to area where your points are. Continuing calculations..."
+msgstr "Terlalu lama mencari titik-titik untuk interpolasi - silakan ubah region yang mencakup wilayah dimana titik Anda berada. Melanjutkan penghitungan ..."
 #: ../lib/rst/interp_float/segmen2d.c:199
 #: ../lib/rst/interp_float/segmen2d.c:205
@@ -171,12 +165,8 @@
 #: ../lib/rst/interp_float/vinput2d.c:277
 #, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given "
-"NPMIN=%d"
-msgstr ""
-"%d titik yang digunakan untuk interpolasi (setelah pembersihan) kurang dari "
-"NPMIN=%d yang diberikan"
+msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
+msgstr "%d titik yang digunakan untuk interpolasi (setelah pembersihan) kurang dari NPMIN=%d yang diberikan"
@@ -184,16 +174,12 @@
 #, c-format
-msgid ""
-"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
-"smooth connection of segments, npmin > segmax (see manual)"
+msgid "Segmentation parameters set to invalid values: npmin= %d, segmax= %d for smooth connection of segments, npmin > segmax (see manual)"
 msgstr ""
 #: ../lib/rst/interp_float/vinput2d.c:293
 #, c-format
-msgid ""
-"There are less than %d points for interpolation. No segmentation is "
-"necessary, to run the program faster set segmax=%d (see manual)"
+msgid "There are less than %d points for interpolation. No segmentation is necessary, to run the program faster set segmax=%d (see manual)"
 msgstr ""
 #: ../lib/rst/interp_float/vinput2d.c:297
@@ -251,9 +237,7 @@
 #: ../lib/rst/interp_float/interp2d.c:232
 #, c-format
-msgid ""
-"Overshoot - increase in tension suggested. Overshoot occurs at (%d,%d) cell."
-" Z-value %f, zmin %f, zmax %f."
+msgid "Overshoot - increase in tension suggested. Overshoot occurs at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
 msgstr ""
 #: ../lib/htmldriver/graph_set.c:97
@@ -412,9 +396,7 @@
 #, c-format
-msgid ""
-"Neither %s (managed by d.mon command) nor %s (used for direct rendering) "
-"defined"
+msgid "Neither %s (managed by d.mon command) nor %s (used for direct rendering) defined"
 msgstr ""
 #: ../lib/display/r_raster.c:150
@@ -503,8 +485,7 @@
 #: ../lib/cairodriver/read_ppm.c:56
 #, c-format
-msgid ""
-"Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
+msgid "Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
 msgstr ""
 #: ../lib/cairodriver/read_xid.c:14
@@ -610,9 +591,7 @@
 #: ../lib/vector/diglib/cindex_rw.c:156
 #, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this category index format."
-" Try to rebuild topology or upgrade GRASS to at least version %d."
+msgid "This version of GRASS (%d.%d) is too old to read this category index format. Try to rebuild topology or upgrade GRASS to at least version %d."
 msgstr ""
 #: ../lib/vector/diglib/file.c:159
@@ -742,30 +721,22 @@
 #: ../lib/vector/diglib/plus_node.c:214
 #, c-format
-msgid ""
-"Attempt to read line angle for the line which is not connected to the node: "
-"node %d, line %d"
+msgid "Attempt to read line angle for the line which is not connected to the node: node %d, line %d"
 msgstr ""
 #: ../lib/vector/diglib/plus_struct.c:523
 #, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this topology format. Try "
-"to rebuild topology or upgrade GRASS to at least version %d."
+msgid "This version of GRASS (%d.%d) is too old to read this topology format. Try to rebuild topology or upgrade GRASS to at least version %d."
 msgstr ""
 #: ../lib/vector/diglib/plus_struct.c:529
 #, c-format
-msgid ""
-"Your GRASS version does not fully support topology format %d.%d of the "
-"vector. Consider to rebuild topology or upgrade GRASS."
+msgid "Your GRASS version does not fully support topology format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
 msgstr ""
 #: ../lib/vector/diglib/plus_struct.c:539
 #, c-format
-msgid ""
-"Old topology format version %d.%d is not supported by this release. Try to "
-"rebuild topology using v.build or v.build.all module."
+msgid "Old topology format version %d.%d is not supported by this release. Try to rebuild topology using v.build or v.build.all module."
 msgstr ""
 #: ../lib/vector/diglib/plus_struct.c:563 ../lib/vector/diglib/portable.c:208
@@ -808,23 +779,17 @@
 #: ../lib/vector/diglib/spindex_rw.c:302
 #, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this spatial index format. "
-"Try to rebuild topology or upgrade GRASS to at least version %d."
+msgid "This version of GRASS (%d.%d) is too old to read this spatial index format. Try to rebuild topology or upgrade GRASS to at least version %d."
 msgstr ""
 #: ../lib/vector/diglib/spindex_rw.c:308
 #, c-format
-msgid ""
-"Your GRASS version does not fully support spatial index format %d.%d of the "
+msgid "Your GRASS version does not fully support spatial index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
 msgstr ""
 #: ../lib/vector/diglib/spindex_rw.c:317
 #, c-format
-msgid ""
-"Spatial index format version %d.%d is not supported by this release. Please "
-"rebuild topology."
+msgid "Spatial index format version %d.%d is not supported by this release. Please rebuild topology."
 msgstr ""
 #: ../lib/vector/diglib/test.c:58
@@ -833,28 +798,22 @@
 #: ../lib/vector/diglib/test.c:75
 #, c-format
-msgid ""
-"Error in read/write portable double, byte_order = %d Written: %.16e3E Read: "
-"%.16e3E"
+msgid "Error in read/write portable double, byte_order = %d Written: %.16e3E Read: %.16e3E"
 msgstr ""
 #: ../lib/vector/diglib/test.c:89
 #, c-format
-msgid ""
-"Error in read/write portable float, byte_order = %d Written: %.8e3E Read: "
-"%.8e3E"
+msgid "Error in read/write portable float, byte_order = %d Written: %.8e3E Read: %.8e3E"
 msgstr ""
 #: ../lib/vector/diglib/test.c:104
 #, c-format
-msgid ""
-"Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
+msgid "Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
 msgstr ""
 #: ../lib/vector/diglib/test.c:119
 #, c-format
-msgid ""
-"Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
+msgid "Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
 msgstr ""
 #: ../lib/vector/diglib/test.c:134
@@ -864,14 +823,12 @@
 #: ../lib/vector/diglib/test.c:150
 #, c-format
-msgid ""
-"Error in read/write portable short, byte_order = %d Written: %d Read: %d"
+msgid "Error in read/write portable short, byte_order = %d Written: %d Read: %d"
 msgstr ""
 #: ../lib/vector/diglib/test.c:165
 #, c-format
-msgid ""
-"Error in read/write portable char, byte_order = %d Written: %d Read: %d"
+msgid "Error in read/write portable char, byte_order = %d Written: %d Read: %d"
 msgstr ""
 #: ../lib/vector/rtree/test_suite/test_basics.c:40
@@ -978,9 +935,7 @@
 msgstr ""
 #: ../lib/vector/Vlib/open_pg.c:559
-msgid ""
-"Connection to PostgreSQL database failed. Try to set up username/password by"
-" db.login."
+msgid "Connection to PostgreSQL database failed. Try to set up username/password by db.login."
 msgstr ""
 #: ../lib/vector/Vlib/open_pg.c:566
@@ -1433,8 +1388,7 @@
 #: ../lib/vector/Vlib/build_pg.c:1018
 #, c-format
-msgid ""
-"Unable to build simple features from topogeometry data. Unsupported type %d."
+msgid "Unable to build simple features from topogeometry data. Unsupported type %d."
 msgstr ""
 #: ../lib/vector/Vlib/write_nat.c:398
@@ -1652,9 +1606,7 @@
 #: ../lib/vector/Vlib/ascii.c:889
 #, c-format
-msgid ""
-"%d features without category skipped. To export also features without "
-"category use '%s=-1'."
+msgid "%d features without category skipped. To export also features without category use '%s=-1'."
 msgstr ""
 #: ../lib/vector/Vlib/cindex.c:32
@@ -1695,8 +1647,7 @@
 #: ../lib/vector/Vlib/read_pg.c:365
 #, c-format
-msgid ""
-"Requesting invalid feature from cache (%d). Number of features in cache: %d"
+msgid "Requesting invalid feature from cache (%d). Number of features in cache: %d"
 msgstr ""
 #: ../lib/vector/Vlib/read_pg.c:368
@@ -1851,8 +1802,7 @@
 #: ../lib/vector/Vlib/net_build.c:432
 #, c-format
-msgid ""
-"Database record for turn with cat = %d in not found. (The turn was skipped."
+msgid "Database record for turn with cat = %d in not found. (The turn was skipped."
 msgstr ""
 #: ../lib/vector/Vlib/net_build.c:465
@@ -1876,16 +1826,12 @@
 #: ../lib/vector/Vlib/net_build.c:579
 #, c-format
-msgid ""
-"Database record for line %d (cat = %d, forward/both direction(s)) not found "
-"(cost was set to 0)"
+msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (cost was set to 0)"
 msgstr ""
 #: ../lib/vector/Vlib/net_build.c:596
 #, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not found(cost "
-"was set to 0)"
+msgid "Database record for line %d (cat = %d, backword direction) not found(cost was set to 0)"
 msgstr ""
 #: ../lib/vector/Vlib/net_build.c:658 ../lib/vector/Vlib/net_build.c:1064
@@ -1903,16 +1849,12 @@
 #: ../lib/vector/Vlib/net_build.c:869
 #, c-format
-msgid ""
-"(forward/both direction(s) of line skipped)"
+msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (forward/both direction(s) of line skipped)"
 msgstr ""
 #: ../lib/vector/Vlib/net_build.c:888
 #, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not "
-"found(direction of line skipped)"
+msgid "Database record for line %d (cat = %d, backword direction) not found(direction of line skipped)"
 msgstr ""
 #: ../lib/vector/Vlib/net_build.c:937
@@ -1925,9 +1867,7 @@
 #: ../lib/vector/Vlib/geos.c:55
 #, c-format
-msgid ""
-"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
-"vector map <%s>: %d)"
+msgid "Vect_read_line_geos(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
 msgstr ""
 #: ../lib/vector/Vlib/geos.c:60
@@ -2074,8 +2014,7 @@
 msgstr ""
 #: ../lib/vector/Vlib/open.c:277
-msgid ""
-"Vector map which is not in the current mapset cannot be opened for update"
+msgid "Vector map which is not in the current mapset cannot be opened for update"
 msgstr ""
 #: ../lib/vector/Vlib/open.c:311
@@ -2096,9 +2035,7 @@
 #: ../lib/vector/Vlib/open.c:419
 #, c-format
-msgid ""
-"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
-"with v.build."
+msgid "Unable to open vector map <%s> on level %d. Try to rebuild vector topology with v.build."
 msgstr ""
 #: ../lib/vector/Vlib/open.c:445
@@ -2266,13 +2203,11 @@
 msgstr ""
 #: ../lib/vector/Vlib/buffer2.c:589
-msgid ""
-"Next edge was visited (right) but it is not the first one !!! breaking loop"
+msgid "Next edge was visited (right) but it is not the first one !!! breaking loop"
 msgstr ""
 #: ../lib/vector/Vlib/buffer2.c:600
-msgid ""
-"Next edge was visited (left) but it is not the first one !!! breaking loop"
+msgid "Next edge was visited (left) but it is not the first one !!! breaking loop"
 msgstr ""
 #: ../lib/vector/Vlib/buffer2.c:648
@@ -2445,9 +2380,7 @@
 msgstr ""
 #: ../lib/vector/Vlib/build.c:1210
-msgid ""
-"Unable to build spatial index from topology, vector map is not opened at "
-"topology level 2"
+msgid "Unable to build spatial index from topology, vector map is not opened at topology level 2"
 msgstr ""
 #: ../lib/vector/Vlib/build.c:1233
@@ -2520,9 +2453,7 @@
 msgstr ""
 #: ../lib/vector/Vlib/build_ogr.c:89
-msgid ""
-"Random read is not supported by OGR for this layer. Unable to build "
-"topology."
+msgid "Random read is not supported by OGR for this layer. Unable to build topology."
 msgstr ""
 #: ../lib/vector/Vlib/build_ogr.c:101 ../lib/vector/Vlib/build_ogr.c:176
@@ -2803,9 +2734,7 @@
 msgstr ""
 #: ../lib/vector/Vlib/dgraph.c:432
-msgid ""
-"Trying to add more edges to the planar_graph than the initial allocation "
-"size allows"
+msgid "Trying to add more edges to the planar_graph than the initial allocation size allows"
 msgstr ""
 #: ../lib/vector/Vlib/field.c:91
@@ -2833,9 +2762,7 @@
 msgstr ""
 #: ../lib/vector/Vlib/field.c:185
-msgid ""
-"More DB links defined for input vector map. Using only first DB link for "
-"output."
+msgid "More DB links defined for input vector map. Using only first DB link for output."
 msgstr ""
 #: ../lib/vector/Vlib/field.c:261
@@ -2884,15 +2811,12 @@
 msgstr ""
 #: ../lib/vector/Vlib/field.c:773
-msgid ""
-"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
-"available in OGR DB table"
+msgid "All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' available in OGR DB table"
 msgstr ""
 #: ../lib/vector/Vlib/field.c:840
 #, c-format
-msgid ""
-"Feature table <%s> has no primary key defined. Unable to define DB links."
+msgid "Feature table <%s> has no primary key defined. Unable to define DB links."
 msgstr ""
 #: ../lib/vector/Vlib/field.c:860
@@ -2960,8 +2884,7 @@
 #: ../lib/vector/Vlib/legal_vname.c:65
 #, c-format
-msgid ""
-"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
 msgstr ""
 #: ../lib/vector/Vlib/legal_vname.c:100 ../lib/vector/Vlib/legal_vname.c:104
@@ -3059,16 +2982,12 @@
 #: ../lib/vector/Vlib/open_nat.c:152
 #, c-format
-msgid ""
-"Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
-"excess)"
+msgid "Coor file of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
 msgstr ""
 #: ../lib/vector/Vlib/open_nat.c:156
 #, c-format
-msgid ""
-"Coor file of vector <%s@%s> is shorter than it should be (%ld bytes "
-"missing)."
+msgid "Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
 msgstr ""
 #: ../lib/vector/Vlib/open_ogr.c:60
@@ -3111,16 +3030,12 @@
 #: ../lib/vector/Vlib/open_ogr.c:279
 #, c-format
-msgid ""
-"Feature index format version %d.%d is not supported by this release. Try to "
-"rebuild topology or upgrade GRASS."
+msgid "Feature index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
 msgstr ""
 #: ../lib/vector/Vlib/open_ogr.c:284
 #, c-format
-msgid ""
-"Your GRASS version does not fully support feature index format %d.%d of the "
+msgid "Your GRASS version does not fully support feature index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
 msgstr ""
 #: ../lib/vector/Vlib/overlay.c:72
@@ -3506,9 +3421,7 @@
 #: ../lib/db/dbmi_base/login.c:232
 #, c-format
-msgid ""
-"DB connection <%s/%s> already exists. Re-run '%s' with '--%s' flag to "
-"overwrite existing settings."
+msgid "DB connection <%s/%s> already exists. Re-run '%s' with '--%s' flag to overwrite existing settings."
 msgstr ""
 #: ../lib/db/dbmi_base/test/test_columns.c:37
@@ -3852,9 +3765,7 @@
 msgstr ""
 #: ../lib/imagery/iscatt_core.c:579
-msgid ""
-"Data inconsistent. Value computed for scatter plot is out of initialized "
-"range."
+msgid "Data inconsistent. Value computed for scatter plot is out of initialized range."
 msgstr ""
 #: ../lib/imagery/iscatt_core.c:745
@@ -3888,9 +3799,7 @@
 #: ../lib/imagery/sigsetfile.c:41
 #, c-format
-msgid ""
-"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
-"is not current mapset"
+msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> is not current mapset"
 msgstr ""
 #: ../lib/imagery/sigsetfile.c:57
@@ -3905,8 +3814,7 @@
 #: ../lib/symbol/read.c:260
 #, c-format
-msgid ""
-"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgid "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
 msgstr ""
 #: ../lib/symbol/read.c:284
@@ -4013,8 +3921,7 @@
 msgstr ""
 #: ../lib/init/grass.py:338
-msgid ""
-"force removal of .gislock if exists (use with care!). Only with -text flag"
+msgid "force removal of .gislock if exists (use with care!). Only with -text flag"
 msgstr ""
 #: ../lib/init/grass.py:339
@@ -4059,8 +3966,7 @@
 msgstr ""
 #: ../lib/init/grass.py:351
-msgid ""
-"directory containing Mapsets with one common coordinate system (projection)"
+msgid "directory containing Mapsets with one common coordinate system (projection)"
 msgstr ""
 #: ../lib/init/grass.py:352
@@ -4124,15 +4030,12 @@
 msgstr ""
 #: ../lib/init/grass.py:393
-msgid ""
-"The APPDATA variable points to directory which does not exist, ask your "
-"operating system support"
+msgid "The APPDATA variable points to directory which does not exist, ask your operating system support"
 msgstr ""
 #: ../lib/init/grass.py:440
 #, python-format
-msgid ""
-"Unable to create temporary directory <grass7-%(user)s-%(lock)s>! Exiting."
+msgid "Unable to create temporary directory <grass7-%(user)s-%(lock)s>! Exiting."
 msgstr ""
 #: ../lib/init/grass.py:493
@@ -4190,22 +4093,17 @@
 #: ../lib/init/grass.py:840
 #, python-format
-msgid ""
-"<%s> is not a valid GRASS Location because PERMANENT is not a directory"
+msgid "<%s> is not a valid GRASS Location because PERMANENT is not a directory"
 msgstr ""
 #: ../lib/init/grass.py:844
 #, python-format
-msgid ""
-"<%s> is not a valid GRASS Location because PERMANENT Mapset does not have a "
-"DEFAULT_WIND file (default computational region)"
+msgid "<%s> is not a valid GRASS Location because PERMANENT Mapset does not have a DEFAULT_WIND file (default computational region)"
 msgstr ""
 #: ../lib/init/grass.py:848
-msgid ""
-"Mapset <{mapset}> doesn't exist in GRASS Location <{loc}>. A new mapset can "
-"be created by '-c' switch."
+msgid "Mapset <{mapset}> doesn't exist in GRASS Location <{loc}>. A new mapset can be created by '-c' switch."
 msgstr ""
 #: ../lib/init/grass.py:911
@@ -4225,9 +4123,7 @@
 #: ../lib/init/grass.py:958
 #, python-format
-msgid ""
-"Invalid user interface specified - <%s>. Use the --help option to see valid "
-"interface names."
+msgid "Invalid user interface specified - <%s>. Use the --help option to see valid interface names."
 msgstr ""
 #: ../lib/init/grass.py:977
@@ -4293,9 +4189,7 @@
 #: ../lib/init/grass.py:1224
 #, python-format
-msgid ""
-"%(user)s is currently running GRASS in selected mapset (file %(file)s "
-"found). Forcing to launch GRASS..."
+msgid "%(user)s is currently running GRASS in selected mapset (file %(file)s found). Forcing to launch GRASS..."
 msgstr ""
 #: ../lib/init/grass.py:1228
@@ -4455,9 +4349,7 @@
 #: ../lib/init/grass.py:1891
-msgid ""
-"<{0}> requested, but not available. Run GRASS in text mode (-text) or "
-"install missing package (usually 'grass-gui')."
+msgid "<{0}> requested, but not available. Run GRASS in text mode (-text) or install missing package (usually 'grass-gui')."
 msgstr ""
 #: ../lib/init/grass.py:1945
@@ -4557,9 +4449,7 @@
 #: ../lib/raster/get_cellhd.c:66
 #, c-format
-msgid ""
-"Unable to read header file for raster map <%s@%s>. It is a reclass of raster"
-" map <%s@%s> %s"
+msgid "Unable to read header file for raster map <%s@%s>. It is a reclass of raster map <%s@%s> %s"
 msgstr ""
 #: ../lib/raster/get_cellhd.c:70
@@ -4765,9 +4655,7 @@
 msgstr ""
 #: ../lib/raster/set_window.c:131
-msgid ""
-"Rast_set_read_window(): projection/zone differs from that of currently open "
-"raster maps"
+msgid "Rast_set_read_window(): projection/zone differs from that of currently open raster maps"
 msgstr ""
 #: ../lib/raster/set_window.c:158
@@ -4781,21 +4669,15 @@
 msgstr ""
-msgid ""
-"Internal error: Rast_get_window() called with split window. Use "
-"Rast_get_input_window() or Rast_get_output_window() instead."
+msgid "Internal error: Rast_get_window() called with split window. Use Rast_get_input_window() or Rast_get_output_window() instead."
 msgstr ""
 #: ../lib/raster/window.c:90
-msgid ""
-"Internal error: Rast_window_rows() called with split window. Use "
-"Rast_input_window_rows() or Rast_output_window_rows() instead."
+msgid "Internal error: Rast_window_rows() called with split window. Use Rast_input_window_rows() or Rast_output_window_rows() instead."
 msgstr ""
 #: ../lib/raster/window.c:125
-msgid ""
-"Internal error: Rast_window_cols() called with split window. Use "
-"Rast_input_window_cols() or Rast_output_window_cols() instead."
+msgid "Internal error: Rast_window_cols() called with split window. Use Rast_input_window_cols() or Rast_output_window_cols() instead."
 msgstr ""
 #: ../lib/raster/init.c:61
@@ -4808,8 +4690,7 @@
 msgstr ""
-msgid ""
-"No compression is not supported for GRASS raster maps, using default ZLIB"
+msgid "No compression is not supported for GRASS raster maps, using default ZLIB"
 msgstr ""
@@ -4963,9 +4844,7 @@
 #: ../lib/raster/gdal.c:500
 #, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
 msgstr ""
 #: ../lib/raster/gdal.c:506
@@ -5007,9 +4886,7 @@
 #: ../lib/raster/open.c:193
 #, c-format
-msgid ""
-"Unable to open raster map <%s@%s> since it is a reclass of raster map "
-"<%s@%s> which does not exist"
+msgid "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%s> which does not exist"
 msgstr ""
@@ -5034,9 +4911,7 @@
 #, c-format
-msgid ""
-"Raster map <%s> is in different projection than current region. Found <%s>, "
-"should be <%s>."
+msgid "Raster map <%s> is in different projection than current region. Found <%s>, should be <%s>."
 msgstr ""
 #: ../lib/raster/open.c:247
@@ -5051,8 +4926,7 @@
 #, c-format
-msgid ""
-"Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
+msgid "Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
 msgstr ""
@@ -5119,8 +4993,7 @@
 msgstr ""
 #: ../lib/raster/open.c:1030
-msgid ""
-"Rast_set_quant_rules() can be called only for raster maps opened for reading"
+msgid "Rast_set_quant_rules() can be called only for raster maps opened for reading"
 msgstr ""
 #: ../lib/raster/close.c:77 ../lib/raster/close.c:110
@@ -5212,9 +5085,7 @@
 #: ../lib/ogsf/gp3.c:288
 #, c-format
-msgid ""
-"%d points without category. Unable to determine color rules for features "
-"without category."
+msgid "%d points without category. Unable to determine color rules for features without category."
 msgstr ""
 #: ../lib/ogsf/gs2.c:1211
@@ -5317,9 +5188,7 @@
 #: ../lib/ogsf/gsd_prim.c:630
 #, c-format
-msgid ""
-"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
-"advise GRASS developers of this error"
+msgid "gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please advise GRASS developers of this error"
 msgstr ""
 #: ../lib/ogsf/gsd_surf.c:1742
@@ -5351,9 +5220,7 @@
 #: ../lib/ogsf/gv3.c:414
 #, c-format
-msgid ""
-"%d features without category. Unable to determine color rules for features "
+msgid "%d features without category. Unable to determine color rules for features without category."
 msgstr ""
 #: ../lib/ogsf/gvl2.c:267
@@ -5978,9 +5845,7 @@
 #: ../lib/arraystats/class.c:242
 #, c-format
-msgid ""
-"There are classbreaks outside the range min-max. Number of classes reduced "
-"to %i, but using probabilities for %i classes."
+msgid "There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."
 msgstr ""
 #: ../lib/lidar/raster.c:74 ../lib/lidar/raster.c:89 ../lib/lidar/raster.c:102
@@ -6102,9 +5967,7 @@
 msgstr ""
-msgid ""
-"grass.script.array.read is deprecated and does not work on MS Windows, pass "
-"raster name in the constructor"
+msgid "grass.script.array.read is deprecated and does not work on MS Windows, pass raster name in the constructor"
 msgstr ""
@@ -6118,9 +5981,7 @@
 msgstr ""
-msgid ""
-"grass.script.array3d.read is deprecated and does not work on MS Windows, "
-"pass 3D raster name in the constructor"
+msgid "grass.script.array3d.read is deprecated and does not work on MS Windows, pass 3D raster name in the constructor"
 msgstr ""
 #: ../lib/python/script/core.py:67
@@ -6130,10 +5991,7 @@
 #: ../lib/python/script/core.py:304
 #, python-format
-msgid ""
-"To run the module <%s> add underscore at the end of the option <%s> to avoid"
-" conflict with Python keywords. Underscore at the beginning is depreciated "
-"in GRASS GIS 7.0 and will be removed in version 7.1."
+msgid "To run the module <%s> add underscore at the end of the option <%s> to avoid conflict with Python keywords. Underscore at the beginning is depreciated in GRASS GIS 7.0 and will be removed in version 7.1."
 msgstr ""
 #: ../lib/python/script/core.py:928
@@ -6191,9 +6049,7 @@
 #: ../lib/python/script/raster.py:54
 #, python-format
-msgid ""
-"Unable to write history for <%(map)s>. Raster map <%(map)s> not found in "
-"current mapset."
+msgid "Unable to write history for <%(map)s>. Raster map <%(map)s> not found in current mapset."
 msgstr ""
 #: ../lib/python/script/raster.py:113
@@ -6280,8 +6136,7 @@
 #: ../lib/python/script/db.py:153
 #, python-format
-msgid ""
-"Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
+msgid "Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
 msgstr ""
@@ -6390,9 +6245,7 @@
 msgstr ""
 #: ../lib/python/temporal/core.py:605
-msgid ""
-"Unable to initialize the temporal DBMI interface. Please use t.connect to "
-"specify the driver and the database string"
+msgid "Unable to initialize the temporal DBMI interface. Please use t.connect to specify the driver and the database string"
 msgstr ""
 #: ../lib/python/temporal/core.py:668
@@ -6501,10 +6354,7 @@
 msgstr ""
 #: ../lib/python/temporal/mapcalc.py:151
-msgid ""
-"Found more than a single map in a sample granule. Only the first map is used"
-" for computation. Use t.rast.aggregate.ds to create synchronous raster "
-"datasets."
+msgid "Found more than a single map in a sample granule. Only the first map is used for computation. Use t.rast.aggregate.ds to create synchronous raster datasets."
 msgstr ""
 #: ../lib/python/temporal/mapcalc.py:169
@@ -6518,8 +6368,7 @@
 #: ../lib/python/temporal/mapcalc.py:235 ../lib/python/temporal/extract.py:130
 #: ../lib/python/temporal/open_stds.py:208
 #, python-format
-msgid ""
-"Map <%s> is already in temporal database, use overwrite flag to overwrite"
+msgid "Map <%s> is already in temporal database, use overwrite flag to overwrite"
 msgstr ""
 #: ../lib/python/temporal/mapcalc.py:255
@@ -6655,23 +6504,17 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1599
 #, python-format
-msgid ""
-"Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database. "
-"The mapset of the dataset does not match the current mapset"
+msgid "Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1768
 #, python-format
-msgid ""
-"Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database. "
+msgid "Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1870
 #, python-format
-msgid ""
-"Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database."
-" The mapset of the dataset does not match the current mapset"
+msgid "Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1879
@@ -6686,9 +6529,7 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1950
 #: ../lib/python/temporal/abstract_map_dataset.py:824
 #, python-format
-msgid ""
-"Unable to delete dataset <%(ds)s> of type %(type)s from the temporal "
-"database. The mapset of the dataset does not match the current mapset"
+msgid "Unable to delete dataset <%(ds)s> of type %(type)s from the temporal database. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1963
@@ -6702,15 +6543,11 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2047
 #, python-format
-msgid ""
-"Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of "
-"the dataset does not match the current mapset"
+msgid "Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2056
-msgid ""
-"Only a map that was inserted in the temporal database can be registered in a"
-" space time dataset"
+msgid "Only a map that was inserted in the temporal database can be registered in a space time dataset"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2079
@@ -6725,15 +6562,12 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2101
 #, python-format
-msgid ""
-"Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer "
-"%(l)s are different"
+msgid "Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer %(l)s are different"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2107
 #, python-format
-msgid ""
-"Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
+msgid "Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2122
@@ -6743,16 +6577,12 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2132
 #, python-format
-msgid ""
-"Relative time units of space time dataset <%(id)s> and map <%(map)s> with "
-"layer %(l)s are different"
+msgid "Relative time units of space time dataset <%(id)s> and map <%(map)s> with layer %(l)s are different"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2138
 #, python-format
-msgid ""
-"Relative time units of space time dataset <%(id)s> and map <%(map)s> are "
-"different"
+msgid "Relative time units of space time dataset <%(id)s> and map <%(map)s> are different"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2144
@@ -6771,17 +6601,12 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2201
 #, python-format
-msgid ""
-"Unable to unregister map from dataset <%(ds)s> of type %(type)s in the "
-"temporal database. The mapset of the dataset does not match the current "
-"mapset"
+msgid "Unable to unregister map from dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2214
 #, python-format
-msgid ""
-"Map <%(map)s> with layer %(l)s is not registered in space time dataset "
-"<%(base)s>"
+msgid "Map <%(map)s> with layer %(l)s is not registered in space time dataset <%(base)s>"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2220
@@ -6795,16 +6620,12 @@
 #: ../lib/python/temporal/abstract_dataset.py:428
 #: ../lib/python/temporal/abstract_dataset.py:471
 #, python-format
-msgid ""
-"Unable to update dataset <%(ds)s> of type %(type)s in the temporal database."
+msgid "Unable to update dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2281
 #, python-format
-msgid ""
-"Update metadata, spatial and temporal extent from all registered maps of "
-"<%s>"
+msgid "Update metadata, spatial and temporal extent from all registered maps of <%s>"
 msgstr ""
 #: ../lib/python/temporal/datetime_math.py:256
@@ -6958,9 +6779,7 @@
 #: ../lib/python/temporal/stds_import.py:434
 #, python-format
-msgid ""
-"Space time %(t)s dataset <%(sp)s> is already in the database. Use the "
-"overwrite flag."
+msgid "Space time %(t)s dataset <%(sp)s> is already in the database. Use the overwrite flag."
 msgstr ""
 #: ../lib/python/temporal/stds_import.py:455
@@ -7020,9 +6839,7 @@
 #: ../lib/python/temporal/temporal_vector_algebra.py:372
 #, python-format
-msgid ""
-"Error vector maps with basename %s exist. Use --o flag to overwrite existing"
-" file"
+msgid "Error vector maps with basename %s exist. Use --o flag to overwrite existing file"
 msgstr ""
 #: ../lib/python/temporal/temporal_vector_algebra.py:405
@@ -7040,25 +6857,19 @@
 msgstr ""
 #: ../lib/python/temporal/spatial_extent.py:119
-msgid ""
-"Projections are different. Unable to compute overlapping_2d for spatial "
-"extents"
+msgid "Projections are different. Unable to compute overlapping_2d for spatial extents"
 msgstr ""
 #: ../lib/python/temporal/spatial_extent.py:525
-msgid ""
-"Projections are different. Unable to compute is_in_2d for spatial extents"
+msgid "Projections are different. Unable to compute is_in_2d for spatial extents"
 msgstr ""
 #: ../lib/python/temporal/spatial_extent.py:657
-msgid ""
-"Projections are different. Unable to compute equivalent_2d for spatial "
-"extents"
+msgid "Projections are different. Unable to compute equivalent_2d for spatial extents"
 msgstr ""
 #: ../lib/python/temporal/spatial_extent.py:762
-msgid ""
-"Projections are different. Unable to compute cover_2d for spatial extents"
+msgid "Projections are different. Unable to compute cover_2d for spatial extents"
 msgstr ""
 #: ../lib/python/temporal/spatial_extent.py:834
@@ -7090,15 +6901,12 @@
 #: ../lib/python/temporal/open_stds.py:122
 #, python-format
-msgid ""
-"Space time %(sp)s dataset <%(name)s> is already in the database. Use the "
-"overwrite flag."
+msgid "Space time %(sp)s dataset <%(name)s> is already in the database. Use the overwrite flag."
 msgstr ""
 #: ../lib/python/temporal/open_stds.py:157
 #, python-format
-msgid ""
-"Overwriting space time %(sp)s dataset <%(name)s> and unregistering all maps"
+msgid "Overwriting space time %(sp)s dataset <%(name)s> and unregistering all maps"
 msgstr ""
 #: ../lib/python/temporal/open_stds.py:165
@@ -7107,9 +6915,7 @@
 msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:798
-msgid ""
-"Spatio-temporal topological operators are not supported in granularity "
-"algebra mode"
+msgid "Spatio-temporal topological operators are not supported in granularity algebra mode"
 msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:836
@@ -7133,9 +6939,7 @@
 #: ../lib/python/temporal/temporal_algebra.py:1176
 #: ../lib/python/temporal/temporal_algebra.py:1180
 #, python-format
-msgid ""
-"Wrong temporal type of space time dataset <%s>"
-"                                       <%s> time is required"
+msgid "Wrong temporal type of space time dataset <%s>                                       <%s> time is required"
 msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:1200
@@ -7144,15 +6948,11 @@
 #: ../lib/python/temporal/temporal_algebra.py:2092
 #, python-format
-msgid ""
-"The resulting space time dataset type <%(a)s> is different from the "
-"requested type <%(b)s>"
+msgid "The resulting space time dataset type <%(a)s> is different from the requested type <%(b)s>"
 msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:2098
-msgid ""
-"Maps that should be registered in the resulting space time dataset have "
-"different types."
+msgid "Maps that should be registered in the resulting space time dataset have different types."
 msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:2301
@@ -7162,9 +6962,7 @@
 msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:2307
-msgid ""
-"Wrong map type. TMAP only supports single maps that are registered in the "
-"temporal GRASS database"
+msgid "Wrong map type. TMAP only supports single maps that are registered in the temporal GRASS database"
 msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:2335
@@ -7185,9 +6983,7 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:342
 #, python-format
-msgid ""
-"Start time must be of type datetime for %(type)s map <%(id)s> with layer: "
-"%(l)s"
+msgid "Start time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:349
@@ -7197,9 +6993,7 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:357
 #, python-format
-msgid ""
-"End time must be of type datetime for %(type)s map <%(id)s> with layer: "
-"%(l)s"
+msgid "End time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:364
@@ -7209,9 +7003,7 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:373
 #, python-format
-msgid ""
-"End time must be greater than start time for %(type)s map <%(id)s> with "
-"layer: %(l)s"
+msgid "End time must be greater than start time for %(type)s map <%(id)s> with layer: %(l)s"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:381
@@ -7222,9 +7014,7 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:452
 #, python-format
-msgid ""
-"Unsupported relative time unit type for %(type)s map <%(id)s> with layer "
-"%(l)s: %(u)s"
+msgid "Unsupported relative time unit type for %(type)s map <%(id)s> with layer %(l)s: %(u)s"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:459
@@ -7234,22 +7024,17 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:468
 #, python-format
-msgid ""
-"End time must be greater than start time for %(typ)s map <%(id)s> with layer"
-" %(l)s"
+msgid "End time must be greater than start time for %(typ)s map <%(id)s> with layer %(l)s"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:783
 #, python-format
-msgid ""
-"Map <%(id)s> with layer %(layer)s has incorrect time interval, start time is"
-" greater than end time"
+msgid "Map <%(id)s> with layer %(layer)s has incorrect time interval, start time is greater than end time"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:789
 #, python-format
-msgid ""
-"Map <%s> has incorrect time interval, start time is greater than end time"
+msgid "Map <%s> has incorrect time interval, start time is greater than end time"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:795
@@ -7264,9 +7049,7 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:892
 #, python-format
-msgid ""
-"Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal "
+msgid "Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal database. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/factory.py:47
@@ -7276,9 +7059,7 @@
 #: ../lib/python/temporal/abstract_dataset.py:388
 #, python-format
-msgid ""
-"Unable to insert dataset <%(ds)s> of type %(type)s in the temporal database."
+msgid "Unable to insert dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/temporal_raster_base_algebra.py:615
@@ -7385,14 +7166,11 @@
 #: ../lib/python/temporal/register.py:108
 #, python-format
-msgid ""
-"Space time %(sp)s dataset <%(name)s> with relative time found, but no "
-"relative unit set for %(sp)s maps"
+msgid "Space time %(sp)s dataset <%(name)s> with relative time found, but no relative unit set for %(sp)s maps"
 msgstr ""
 #: ../lib/python/temporal/register.py:169
-msgid ""
-"The increment option will be ignored because of time stamps in input file"
+msgid "The increment option will be ignored because of time stamps in input file"
 msgstr ""
 #: ../lib/python/temporal/register.py:173
@@ -7410,16 +7188,12 @@
 #: ../lib/python/temporal/register.py:209
 #, python-format
-msgid ""
-"Unable to register %(t)s map <%(id)s> with layer %(l)s. The map has "
-"timestamp and the start time is not set."
+msgid "Unable to register %(t)s map <%(id)s> with layer %(l)s. The map has timestamp and the start time is not set."
 msgstr ""
 #: ../lib/python/temporal/register.py:215
 #, python-format
-msgid ""
-"Unable to register %(t)s map <%(id)s>. The map has no timestamp and the "
-"start time is not set."
+msgid "Unable to register %(t)s map <%(id)s>. The map has no timestamp and the start time is not set."
 msgstr ""
 #: ../lib/python/temporal/register.py:223
@@ -7434,23 +7208,17 @@
 #: ../lib/python/temporal/register.py:239
 #, python-format
-msgid ""
-"Map is already registered in temporal database. Unable to update %(t)s map "
-"<%(id)s> with layer %(l)s. Overwrite flag is not set."
+msgid "Map is already registered in temporal database. Unable to update %(t)s map <%(id)s> with layer %(l)s. Overwrite flag is not set."
 msgstr ""
 #: ../lib/python/temporal/register.py:246
 #, python-format
-msgid ""
-"<%(id)s>. Overwrite flag is not set."
+msgid "Map is already registered in temporal database. Unable to update %(t)s map <%(id)s>. Overwrite flag is not set."
 msgstr ""
 #: ../lib/python/temporal/register.py:270
 #, python-format
-msgid ""
-"Unable to update %(t)s map <%(id)s> with layer %(l)s. The temporal types are"
-" different."
+msgid "Unable to update %(t)s map <%(id)s> with layer %(l)s. The temporal types are different."
 msgstr ""
 #: ../lib/python/temporal/register.py:276
@@ -7483,9 +7251,7 @@
 #: ../lib/python/temporal/register.py:416
 #, python-format
-msgid ""
-"Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s -"
-" %(end)s"
+msgid "Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - %(end)s"
 msgstr ""
 #: ../lib/python/temporal/register.py:421
@@ -7495,8 +7261,7 @@
 #: ../lib/python/temporal/register.py:438
 #, python-format
-msgid ""
-"Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
+msgid "Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
 msgstr ""
 #: ../lib/python/temporal/register.py:443
@@ -7511,9 +7276,7 @@
 #: ../lib/python/temporal/aggregation.py:138
 #, python-format
-msgid ""
-"Raster map <%(name)s> is already in temporal database, use overwrite flag to"
-" overwrite"
+msgid "Raster map <%(name)s> is already in temporal database, use overwrite flag to overwrite"
 msgstr ""
 #: ../lib/python/temporal/aggregation.py:143
@@ -7532,16 +7295,12 @@
 #: ../lib/python/temporal/aggregation.py:298
 #, python-format
-msgid ""
-"Unable to perform aggregation. Output raster map <%(name)s> exists and "
-"overwrite flag was not set"
+msgid "Unable to perform aggregation. Output raster map <%(name)s> exists and overwrite flag was not set"
 msgstr ""
 #: ../lib/python/temporal/aggregation.py:316
 #, python-format
-msgid ""
-"The limit of open files (%i) was reached (%i). The module r.series will be "
-"run with flag z, to avoid open files limit exceeding."
+msgid "The limit of open files (%i) was reached (%i). The module r.series will be run with flag z, to avoid open files limit exceeding."
 msgstr ""
 #: ../lib/cluster/c_begin.c:57
@@ -7596,9 +7355,7 @@
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:193
-msgid ""
-"Do not use this option if schemas are not supported by driver/database "
-"server"
+msgid "Do not use this option if schemas are not supported by driver/database server"
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:202
@@ -7734,9 +7491,7 @@
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:433
-msgid ""
-"Number of digits used as mantissa in the internal map storage, 0 -23 for "
-"float, 0 - 52 for double, max or default"
+msgid "Number of digits used as mantissa in the internal map storage, 0 -23 for float, 0 - 52 for double, max or default"
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:443
@@ -7744,9 +7499,7 @@
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:453
-msgid ""
-"The dimensions of the tiles used in the output raster3d map (XxYxZ or "
-"default: 16x16x8)"
+msgid "The dimensions of the tiles used in the output raster3d map (XxYxZ or default: 16x16x8)"
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:463
@@ -7788,10 +7541,7 @@
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:527
-msgid ""
-"Vector features can have category values in different layers. This number "
-"determines which layer to use. When used with direct OGR access this is the "
-"layer name."
+msgid "Vector features can have category values in different layers. This number determines which layer to use. When used with direct OGR access this is the layer name."
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:537
@@ -7799,10 +7549,7 @@
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:539
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use. When used with direct OGR access this "
-"is the layer name."
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use. When used with direct OGR access this is the layer name."
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:548
@@ -7977,9 +7724,7 @@
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:887
-msgid ""
-"WHERE conditions of SQL statement without 'where' keyword used in the "
-"temporal GIS framework"
+msgid "WHERE conditions of SQL statement without 'where' keyword used in the temporal GIS framework"
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:888
@@ -8430,9 +8175,7 @@
 #: ../lib/gis/gisinit.c:53 ../lib/gis/gisinit.c:87
 #, c-format
-msgid ""
-"Module built against version %s but trying to use version %s. You need to "
-"rebuild GRASS GIS or untangle multiple installations."
+msgid "Module built against version %s but trying to use version %s. You need to rebuild GRASS GIS or untangle multiple installations."
 msgstr ""
 #: ../lib/gis/gisinit.c:65
@@ -9229,8 +8972,7 @@
 #: ../lib/proj/convert.c:139
 #, c-format
-msgid ""
-"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
 msgstr ""
 #: ../lib/proj/convert.c:152
@@ -9249,16 +8991,12 @@
 #: ../lib/proj/convert.c:473
 #, c-format
-msgid ""
-"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
-"want to look into this."
+msgid "Datum <%s> apparently recognised by GRASS but no parameters found. You may want to look into this."
 msgstr ""
 #: ../lib/proj/convert.c:477
 #, c-format
-msgid ""
-"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
-"transform parameters unspecified."
+msgid "Invalid transformation number %d; valid range is 1 to %d. Leaving datum transform parameters unspecified."
 msgstr ""
 #: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
Modified: grass/trunk/locale/po/grasslibs_pl.po
--- grass/trunk/locale/po/grasslibs_pl.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grasslibs_pl.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -3098,19 +3098,19 @@
 #: ../lib/manage/do_copy.c:50 ../lib/manage/do_copy.c:67
 #, c-format
 msgid "Unable to copy <%s> to current mapset as <%s>"
-msgstr ""
+msgstr "Nie można skopiować <%s> do bieżącego mapsetu jako <%s>"
 #: ../lib/manage/do_copy.c:61 ../lib/manage/do_remove.c:89
 #: ../lib/manage/do_remove.c:109 ../lib/manage/do_rename.c:87
 #: ../lib/manage/do_rename.c:107
 #, c-format
 msgid "%s is missing"
-msgstr ""
+msgstr "%s brakuje"
 #: ../lib/manage/do_copy.c:72
 #, c-format
 msgid "%s copied"
-msgstr ""
+msgstr "%s skopiowane"
 #: ../lib/manage/do_remove.c:42
 #, c-format
@@ -3129,17 +3129,17 @@
 #: ../lib/manage/do_remove.c:92 ../lib/manage/do_remove.c:112
 #, c-format
 msgid "%s removed"
-msgstr ""
+msgstr "%s usunięte"
 #: ../lib/manage/do_remove.c:105
 #, c-format
 msgid "Unable to remove %s"
-msgstr ""
+msgstr "Nie można usunąć %s"
 #: ../lib/manage/do_remove.c:121
 #, c-format
 msgid "<%s> nothing removed"
-msgstr ""
+msgstr "<%s> niczego nie usunięto"
 #: ../lib/manage/do_list.c:30
 #, c-format
@@ -3149,23 +3149,23 @@
 #: ../lib/manage/option.c:47
 #, c-format
 msgid "%s to be %s"
-msgstr ""
+msgstr "%s na %s"
 #: ../lib/manage/option.c:51
 msgid "Raster"
-msgstr ""
+msgstr "Raster"
 #: ../lib/manage/option.c:53
 msgid "Vector"
-msgstr ""
+msgstr "Wektor"
 #: ../lib/manage/option.c:55
 msgid "Region"
-msgstr ""
+msgstr "Region"
 #: ../lib/manage/option.c:57
 msgid "Group"
-msgstr ""
+msgstr "Grupa"
 #: ../lib/manage/read_list.c:73
 #, c-format
@@ -3180,27 +3180,27 @@
 #: ../lib/manage/do_rename.c:42
 #, c-format
 msgid "Rename %s <%s> to <%s>"
-msgstr ""
+msgstr "Zmień nazwę %s <%s> na <%s>"
 #: ../lib/manage/do_rename.c:62
 #, c-format
 msgid "Unable to rename vector map <%s> to <%s>"
-msgstr ""
+msgstr "Nie można zmienić nazwy mapy wektorowej <%s> na <%s>"
 #: ../lib/manage/do_rename.c:83 ../lib/manage/do_rename.c:103
 #, c-format
 msgid "Unable to rename %s"
-msgstr ""
+msgstr "Nie można zmienić nazwy %s"
 #: ../lib/manage/do_rename.c:90 ../lib/manage/do_rename.c:110
 #, c-format
 msgid "%s renamed"
-msgstr ""
+msgstr "%s zmieniono nazwę"
 #: ../lib/manage/do_rename.c:119
 #, c-format
 msgid "<%s> nothing renamed"
-msgstr ""
+msgstr "<%s>  nie zmieniono nazwy"
 #: ../lib/raster/color_write.c:81 ../lib/vector/Vlib/color_write.c:71
 #, c-format
@@ -4226,7 +4226,7 @@
 #: ../lib/gis/parser_standard_options.c:221
 msgid "Must refer to an integer column"
-msgstr ""
+msgstr "Musi odnosić się do kolumny z liczbami całkowitymi"
 #: ../lib/gis/parser_standard_options.c:233
 msgid "Name of input imagery group"
@@ -4250,15 +4250,15 @@
 #: ../lib/gis/parser_standard_options.c:277
 msgid "Name for output raster map(s)"
-msgstr ""
+msgstr "Nazwa wyjściowej map(y) rastrowej"
 #: ../lib/gis/parser_standard_options.c:285
 msgid "Name of raster map"
-msgstr ""
+msgstr "Nazwa mapy rastrowej"
 #: ../lib/gis/parser_standard_options.c:294
 msgid "Name of raster map(s)"
-msgstr ""
+msgstr "Nazwa map(y) rastrowej"
 #: ../lib/gis/parser_standard_options.c:302
 msgid "Name of base raster map"
@@ -4270,15 +4270,15 @@
 #: ../lib/gis/parser_standard_options.c:318
 msgid "Name of input elevation raster map"
-msgstr ""
+msgstr "Nazwa wejściowej mapy rastrowej wysokości"
 #: ../lib/gis/parser_standard_options.c:327
 msgid "Name of input elevation raster map(s)"
-msgstr ""
+msgstr "Nazwy wejściowych map(y) rastrowych wysokości"
 #: ../lib/gis/parser_standard_options.c:334
 msgid "Type of raster map to be created"
-msgstr ""
+msgstr "Rodzaj mapy rastrowej do utworzenia"
 #: ../lib/gis/parser_standard_options.c:335
 msgid "Storage type for resultant raster map"
@@ -4286,15 +4286,15 @@
 #: ../lib/gis/parser_standard_options.c:339
 msgid "Integer"
-msgstr ""
+msgstr "Liczba całkowita"
 #: ../lib/gis/parser_standard_options.c:340
 msgid "Single precision floating point"
-msgstr ""
+msgstr "Zmiennoprzecinkowa pojedynczej precyzji"
 #: ../lib/gis/parser_standard_options.c:341
 msgid "Double precision floating point"
-msgstr ""
+msgstr "Zmiennoprzecinkowa podwójnej precyzji"
 #: ../lib/gis/parser_standard_options.c:347
 msgid "Sampling interpolation method"
@@ -4302,15 +4302,15 @@
 #: ../lib/gis/parser_standard_options.c:351
 msgid "Nearest-neighbor interpolation"
-msgstr ""
+msgstr "Interpolacja najbliższego sąsiada"
 #: ../lib/gis/parser_standard_options.c:352
 msgid "Bilinear interpolation"
-msgstr ""
+msgstr "Interpolacja dwuliniowa"
 #: ../lib/gis/parser_standard_options.c:353
 msgid "Bicubic interpolation"
-msgstr ""
+msgstr "Interpolacja dwusześcienna"
 #: ../lib/gis/parser_standard_options.c:362
 msgid "Name of input basename raster map(s)"
@@ -4507,7 +4507,7 @@
 #: ../lib/gis/parser_standard_options.c:734
 msgid "Name of saved region"
-msgstr ""
+msgstr "Nazwa zapisanego regionu"
 #: ../lib/gis/parser_standard_options.c:744
 msgid "Name of the input space time dataset"
@@ -5498,13 +5498,13 @@
 #: ../lib/htmldriver/graph_set.c:98
 #, c-format
 msgid "html: image size %dx%d"
-msgstr ""
+msgstr "html: rozmiar obrazu %dx%d"
 #: ../lib/htmldriver/graph_set.c:111 ../lib/htmldriver/graph_set.c:115
 #: ../lib/htmldriver/graph_set.c:119
 #, c-format
 msgid "html: type '%s'"
-msgstr ""
+msgstr "html: rodzaj '%s'"
 #: ../lib/temporal/lib/default_name.c:69
 msgid "Programmer error - only SQLite driver is currently supported"
@@ -5857,18 +5857,18 @@
 #: ../lib/init/grass.py:1205
 #, python-format
 msgid "Path '%s' doesn't exist"
-msgstr ""
+msgstr "Ścieżka '%s' nie istnieje"
 #: ../lib/init/grass.py:1207
 #, python-format
 msgid "Path '%s' not accessible."
-msgstr ""
+msgstr "Ścieżka '%s' jest niedostępna."
 #. GTC %s is mapset's folder path
 #: ../lib/init/grass.py:1212
 #, python-format
 msgid "You are not the owner of '%s'."
-msgstr ""
+msgstr "Nie jesteś właścicielem '%s'."
 #: ../lib/init/grass.py:1220
 #, python-format
@@ -9042,7 +9042,7 @@
 #: ../lib/rst/interp_float/write2d.c:79 ../lib/rst/interp_float/write2d.c:88
 #: ../lib/rst/interp_float/write2d.c:96 ../lib/rst/interp_float/write2d.c:104
 msgid "Cannot write files"
-msgstr ""
+msgstr "Nie można zapisać plików"
 #: ../lib/rst/interp_float/input2d.c:58
 #, c-format
Modified: grass/trunk/locale/po/grasslibs_si.po
--- grass/trunk/locale/po/grasslibs_si.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grasslibs_si.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -2,7 +2,7 @@
 msgid ""
 msgstr ""
 "Project-Id-Version: grasslibs_si\n"
@@ -11,10 +11,10 @@
 "Last-Translator: Niroshan Sanjaya <nsanj88 at gmail.com>, 2017\n"
 "Language-Team: Sinhala (https://www.transifex.com/grass-gis/teams/45198/si/)\n"
+"Language: si\n"
-"Language: si\n"
 "Plural-Forms: nplurals=2; plural=(n != 1);\n"
@@ -66,9 +66,7 @@
 msgstr "ආපසු මුල් කලාපය වෙනස් ..."
-msgid ""
 msgstr ""
@@ -167,9 +165,7 @@
 #, c-format
-msgid ""
-"NPMIN=%d"
 msgstr ""
@@ -178,16 +174,12 @@
 #, c-format
-msgid ""
 msgstr ""
 #, c-format
-msgid ""
 msgstr ""
@@ -245,9 +237,7 @@
 #, c-format
-msgid ""
 msgstr ""
@@ -406,9 +396,7 @@
 #: ../lib/display/r_raster.c:131
 #, c-format
-msgid ""
-"defined"
 msgstr ""
@@ -497,8 +485,7 @@
 #, c-format
-msgid ""
 msgstr ""
@@ -604,9 +591,7 @@
 #, c-format
-msgid ""
 msgstr ""
@@ -736,30 +721,22 @@
 #, c-format
-msgid ""
-"node %d, line %d"
 msgstr ""
 #, c-format
-msgid ""
 msgstr ""
 #, c-format
-msgid ""
 msgstr ""
 #, c-format
-msgid ""
 msgstr ""
@@ -802,23 +779,17 @@
 #, c-format
-msgid ""
 msgstr ""
 #, c-format
-msgid ""
 msgstr ""
 #, c-format
-msgid ""
 msgstr ""
@@ -827,28 +798,22 @@
 #, c-format
-msgid ""
-"%.16e3E"
 msgstr ""
 #, c-format
-msgid ""
-"%.8e3E"
 msgstr ""
 #, c-format
-msgid ""
 msgstr ""
 #, c-format
-msgid ""
 msgstr ""
@@ -858,14 +823,12 @@
 #, c-format
-msgid ""
 msgstr ""
 #, c-format
-msgid ""
 msgstr ""
@@ -972,9 +935,7 @@
 msgstr ""
-msgid ""
-" db.login."
 msgstr ""
@@ -1427,8 +1388,7 @@
 #, c-format
-msgid ""
 msgstr ""
@@ -1646,9 +1606,7 @@
 #, c-format
-msgid ""
 msgstr ""
@@ -1689,8 +1647,7 @@
 #, c-format
-msgid ""
 msgstr ""
@@ -1845,8 +1802,7 @@
 #, c-format
-msgid ""
 msgstr ""
@@ -1870,16 +1826,12 @@
 #, c-format
-msgid ""
 msgstr ""
 #, c-format
-msgid ""
-"was set to 0)"
 msgstr ""
@@ -1897,16 +1849,12 @@
 #, c-format
-msgid ""
 msgstr ""
 #, c-format
-msgid ""
 msgstr ""
@@ -1919,9 +1867,7 @@
 #, c-format
-msgid ""
 msgstr ""
@@ -2068,8 +2014,7 @@
 msgstr ""
-msgid ""
 msgstr ""
@@ -2090,9 +2035,7 @@
 #, c-format
-msgid ""
-"with v.build."
 msgstr ""
@@ -2260,13 +2203,11 @@
 msgstr ""
-msgid ""
 msgstr ""
-msgid ""
 msgstr ""
@@ -2439,9 +2380,7 @@
 msgstr ""
-msgid ""
-"topology level 2"
 msgstr ""
@@ -2518,9 +2457,7 @@
 msgstr ""
-msgid ""
-"topology."
 msgstr ""
@@ -2803,9 +2740,7 @@
 msgstr ""
-msgid ""
-"size allows"
 msgstr ""
@@ -2833,9 +2768,7 @@
 msgstr ""
-msgid ""
-"output."
 msgstr ""
@@ -2884,15 +2817,12 @@
 msgstr ""
-msgid ""
 msgstr ""
 #, c-format
-msgid ""
 msgstr ""
@@ -2960,8 +2890,7 @@
 #, c-format
-msgid ""
 msgstr ""
@@ -3059,16 +2988,12 @@
 #, c-format
-msgid ""
-"excess)"
 msgstr ""
 #, c-format
-msgid ""
-"missing)."
 msgstr ""
@@ -3111,16 +3036,12 @@
 #, c-format
-msgid ""
 msgstr ""
 #, c-format
-msgid ""
 msgstr ""
@@ -3506,9 +3427,7 @@
 #, c-format
-msgid ""
 msgstr ""
@@ -3852,9 +3771,7 @@
 msgstr ""
-msgid ""
-"range."
 msgstr ""
@@ -3888,9 +3805,7 @@
 #, c-format
-msgid ""
 msgstr ""
@@ -3905,8 +3820,7 @@
 #, c-format
-msgid ""
 msgstr ""
@@ -4013,8 +3927,7 @@
 msgstr ""
-msgid ""
 msgstr ""
@@ -4059,8 +3972,7 @@
 msgstr ""
-msgid ""
 msgstr ""
@@ -4124,15 +4036,12 @@
 msgstr ""
-msgid ""
 msgstr ""
 #, python-format
-msgid ""
 msgstr ""
@@ -4190,22 +4099,17 @@
 #, python-format
-msgid ""
 msgstr ""
 #, python-format
-msgid ""
 msgstr ""
 #, python-brace-format
-msgid ""
 msgstr ""
@@ -4225,9 +4129,7 @@
 #, python-format
-msgid ""
-"interface names."
 msgstr ""
@@ -4293,9 +4195,7 @@
 #, python-format
-msgid ""
 msgstr ""
@@ -4455,9 +4355,7 @@
-msgid ""
 msgstr ""
@@ -4557,9 +4455,7 @@
 #, c-format
-msgid ""
-" map <%s@%s> %s"
 msgstr ""
@@ -4765,9 +4661,7 @@
 msgstr ""
-msgid ""
-"raster maps"
 msgstr ""
@@ -4781,21 +4675,15 @@
 msgstr ""
 #: ../lib/raster/window.c:31
-msgid ""
 msgstr ""
-msgid ""
 msgstr ""
-msgid ""
 msgstr ""
@@ -4808,8 +4696,7 @@
 msgstr ""
 #: ../lib/raster/init.c:113
-msgid ""
 msgstr ""
 #: ../lib/raster/init.c:118
@@ -4963,9 +4850,7 @@
 #, c-format
-msgid ""
 msgstr ""
@@ -5007,9 +4892,7 @@
 #, c-format
-msgid ""
 msgstr ""
 #: ../lib/raster/open.c:198
@@ -5034,9 +4917,7 @@
 #: ../lib/raster/open.c:240
 #, c-format
-msgid ""
-"should be <%s>."
 msgstr ""
@@ -5051,8 +4932,7 @@
 #: ../lib/raster/open.c:277
 #, c-format
-msgid ""
 msgstr ""
 #: ../lib/raster/open.c:285
@@ -5119,8 +4999,7 @@
 msgstr ""
-msgid ""
 msgstr ""
@@ -5212,9 +5091,7 @@
 #, c-format
-msgid ""
 msgstr ""
@@ -5317,9 +5194,7 @@
 #, c-format
-msgid ""
 msgstr ""
@@ -5351,9 +5226,7 @@
 #, c-format
-msgid ""
 msgstr ""
@@ -5978,9 +5851,7 @@
 #, c-format
-msgid ""
 msgstr ""
@@ -6102,9 +5973,7 @@
 msgstr ""
 #: ../lib/python/script/array.py:197
-msgid ""
 msgstr ""
 #: ../lib/python/script/array.py:247 ../lib/python/script/array.py:392
@@ -6118,9 +5987,7 @@
 msgstr ""
 #: ../lib/python/script/array.py:346
-msgid ""
 msgstr ""
@@ -6130,10 +5997,7 @@
 #, python-format
-msgid ""
 msgstr ""
@@ -6191,9 +6055,7 @@
 #, python-format
-msgid ""
-"current mapset."
 msgstr ""
@@ -6280,8 +6142,7 @@
 #, python-format
-msgid ""
 msgstr ""
 #: ../lib/python/script/db.py:163
@@ -6390,9 +6251,7 @@
 msgstr ""
-msgid ""
 msgstr ""
@@ -6501,10 +6360,7 @@
 msgstr ""
-msgid ""
-"datasets."
 msgstr ""
@@ -6518,8 +6374,7 @@
 #, python-format
-msgid ""
 msgstr ""
@@ -6655,23 +6510,17 @@
 #, python-format
-msgid ""
 msgstr ""
 #, python-format
-msgid ""
 msgstr ""
 #, python-format
-msgid ""
 msgstr ""
@@ -6686,9 +6535,7 @@
 #, python-format
-msgid ""
 msgstr ""
@@ -6702,15 +6549,11 @@
 #, python-format
-msgid ""
 msgstr ""
-msgid ""
 msgstr ""
@@ -6725,15 +6568,12 @@
 #, python-format
-msgid ""
 msgstr ""
 #, python-format
-msgid ""
 msgstr ""
@@ -6743,16 +6583,12 @@
 #, python-format
-msgid ""
 msgstr ""
 #, python-format
-msgid ""
-"different"
 msgstr ""
@@ -6771,17 +6607,12 @@
 #, python-format
-msgid ""
-"mapset"
 msgstr ""
 #, python-format
-msgid ""
-"<%(base)s>"
 msgstr ""
@@ -6795,16 +6626,12 @@
 #, python-format
-msgid ""
 msgstr ""
 #, python-format
-msgid ""
-"<%s>"
 msgstr ""
@@ -6958,9 +6785,7 @@
 #, python-format
-msgid ""
-"overwrite flag."
 msgstr ""
@@ -7020,9 +6845,7 @@
 #, python-format
-msgid ""
-" file"
 msgstr ""
@@ -7040,25 +6863,19 @@
 msgstr ""
-msgid ""
-"extents"
 msgstr ""
-msgid ""
 msgstr ""
-msgid ""
-"extents"
 msgstr ""
-msgid ""
 msgstr ""
@@ -7090,15 +6907,12 @@
 #, python-format
-msgid ""
-"overwrite flag."
 msgstr ""
 #, python-format
-msgid ""
 msgstr ""
@@ -7107,9 +6921,7 @@
 msgstr ""
-msgid ""
-"algebra mode"
 msgstr ""
@@ -7133,9 +6945,7 @@
 #, python-format
-msgid ""
 msgstr ""
@@ -7144,15 +6954,11 @@
 #, python-format
-msgid ""
 msgstr ""
-msgid ""
-"different types."
 msgstr ""
@@ -7162,9 +6968,7 @@
 msgstr ""
-msgid ""
 msgstr ""
@@ -7185,9 +6989,7 @@
 #, python-format
-msgid ""
-"%(l)s"
 msgstr ""
@@ -7197,9 +6999,7 @@
 #, python-format
-msgid ""
-"%(l)s"
 msgstr ""
@@ -7209,9 +7009,7 @@
 #, python-format
-msgid ""
-"layer: %(l)s"
 msgstr ""
@@ -7222,9 +7020,7 @@
 #, python-format
-msgid ""
-"%(l)s: %(u)s"
 msgstr ""
@@ -7234,22 +7030,17 @@
 #, python-format
-msgid ""
-" %(l)s"
 msgstr ""
 #, python-format
-msgid ""
 msgstr ""
 #, python-format
-msgid ""
 msgstr ""
@@ -7264,9 +7055,7 @@
 #, python-format
-msgid ""
 msgstr ""
@@ -7276,9 +7065,7 @@
 #, python-format
-msgid ""
 msgstr ""
@@ -7385,14 +7172,11 @@
 #, python-format
-msgid ""
 msgstr ""
-msgid ""
 msgstr ""
@@ -7410,16 +7194,12 @@
 #, python-format
-msgid ""
 msgstr ""
 #, python-format
-msgid ""
 msgstr ""
@@ -7434,23 +7214,17 @@
 #, python-format
-msgid ""
 msgstr ""
 #, python-format
-msgid ""
 msgstr ""
 #, python-format
-msgid ""
-" different."
 msgstr ""
@@ -7483,9 +7257,7 @@
 #, python-format
-msgid ""
-" %(end)s"
 msgstr ""
@@ -7495,8 +7267,7 @@
 #, python-format
-msgid ""
 msgstr ""
@@ -7511,9 +7282,7 @@
 #, python-format
-msgid ""
-" overwrite"
 msgstr ""
@@ -7532,16 +7301,12 @@
 #, python-format
-msgid ""
 msgstr ""
 #, python-format
-msgid ""
 msgstr ""
@@ -7596,9 +7361,7 @@
 msgstr ""
-msgid ""
-"server"
 msgstr ""
@@ -7734,9 +7497,7 @@
 msgstr ""
-msgid ""
 msgstr ""
@@ -7744,9 +7505,7 @@
 msgstr ""
-msgid ""
 msgstr ""
@@ -7788,10 +7547,7 @@
 msgstr ""
-msgid ""
-"layer name."
 msgstr ""
@@ -7799,10 +7555,7 @@
 msgstr ""
-msgid ""
 msgstr ""
@@ -7977,9 +7730,7 @@
 msgstr ""
-msgid ""
 msgstr ""
@@ -8430,9 +8181,7 @@
 #, c-format
-msgid ""
 msgstr ""
@@ -9229,8 +8978,7 @@
 #, c-format
-msgid ""
 msgstr ""
@@ -9249,16 +8997,12 @@
 #, c-format
-msgid ""
 msgstr ""
 #, c-format
-msgid ""
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_uk.po
--- grass/trunk/locale/po/grasslibs_uk.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grasslibs_uk.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -2,7 +2,7 @@
 # Copyright (C) 2017 GRASS Development Team
 # This file is distributed under the same license as the GRASS GIS package.
 # transifex generated, 2017
 msgid ""
 msgstr ""
 "Project-Id-Version: grasslibs_uk\n"
@@ -11,10 +11,10 @@
 "PO-Revision-Date: 2017-05-23 21:08+0200\n"
 "Last-Translator: Roman Peresoliak <roman.peresoliak at gmail.com>, 2017\n"
 "Language-Team: Ukrainian (https://www.transifex.com/grass-gis/teams/45198/uk/)\n"
+"Language: uk\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
-"Language: uk\n"
 "Plural-Forms: nplurals=3; plural=(n%10==1 && n%100!=11 ? 0 : n%10>=2 && n%10<=4 && (n%100<10 || n%100>=20) ? 1 : 2);\n"
 #: ../lib/rst/interp_float/resout2d.c:77
@@ -66,9 +66,7 @@
 msgstr ""
 #: ../lib/rst/interp_float/segmen2d.c:135
-msgid ""
-"Taking too long to find points for interpolation - please change the region "
-"to area where your points are. Continuing calculations..."
+msgid "Taking too long to find points for interpolation - please change the region to area where your points are. Continuing calculations..."
 msgstr ""
 #: ../lib/rst/interp_float/segmen2d.c:199
@@ -167,9 +165,7 @@
 #: ../lib/rst/interp_float/vinput2d.c:277
 #, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given "
-"NPMIN=%d"
+msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
 msgstr ""
 #: ../lib/rst/interp_float/vinput2d.c:282
 #: ../lib/rst/interp_float/vinput2d.c:287
 #, c-format
-msgid ""
-"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
-"smooth connection of segments, npmin > segmax (see manual)"
+msgid "Segmentation parameters set to invalid values: npmin= %d, segmax= %d for smooth connection of segments, npmin > segmax (see manual)"
 msgstr ""
 #: ../lib/rst/interp_float/vinput2d.c:293
 #, c-format
-msgid ""
-"There are less than %d points for interpolation. No segmentation is "
-"necessary, to run the program faster set segmax=%d (see manual)"
+msgid "There are less than %d points for interpolation. No segmentation is necessary, to run the program faster set segmax=%d (see manual)"
 msgstr ""
 #: ../lib/rst/interp_float/vinput2d.c:297
@@ -245,9 +237,7 @@
 #: ../lib/rst/interp_float/interp2d.c:232
 #, c-format
-msgid ""
-"Overshoot - increase in tension suggested. Overshoot occurs at (%d,%d) cell."
-" Z-value %f, zmin %f, zmax %f."
+msgid "Overshoot - increase in tension suggested. Overshoot occurs at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
 msgstr ""
 #: ../lib/htmldriver/graph_set.c:97
@@ -406,9 +396,7 @@
 #, c-format
-msgid ""
-"Neither %s (managed by d.mon command) nor %s (used for direct rendering) "
-"defined"
+msgid "Neither %s (managed by d.mon command) nor %s (used for direct rendering) defined"
 msgstr ""
 #: ../lib/display/r_raster.c:150
@@ -497,8 +485,7 @@
 #: ../lib/cairodriver/read_ppm.c:56
 #, c-format
-msgid ""
-"Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
+msgid "Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
 msgstr ""
 #: ../lib/cairodriver/read_xid.c:14
@@ -604,9 +591,7 @@
 #: ../lib/vector/diglib/cindex_rw.c:156
 #, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this category index format."
-" Try to rebuild topology or upgrade GRASS to at least version %d."
+msgid "This version of GRASS (%d.%d) is too old to read this category index format. Try to rebuild topology or upgrade GRASS to at least version %d."
 msgstr ""
 #: ../lib/vector/diglib/file.c:159
 #: ../lib/vector/diglib/plus_node.c:214
 #, c-format
-msgid ""
-"Attempt to read line angle for the line which is not connected to the node: "
-"node %d, line %d"
+msgid "Attempt to read line angle for the line which is not connected to the node: node %d, line %d"
 msgstr ""
 #: ../lib/vector/diglib/plus_struct.c:523
 #, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this topology format. Try "
-"to rebuild topology or upgrade GRASS to at least version %d."
+msgid "This version of GRASS (%d.%d) is too old to read this topology format. Try to rebuild topology or upgrade GRASS to at least version %d."
 msgstr ""
 #: ../lib/vector/diglib/plus_struct.c:529
 #, c-format
-msgid ""
-"Your GRASS version does not fully support topology format %d.%d of the "
-"vector. Consider to rebuild topology or upgrade GRASS."
+msgid "Your GRASS version does not fully support topology format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
 msgstr ""
 #: ../lib/vector/diglib/plus_struct.c:539
 #, c-format
-msgid ""
-"Old topology format version %d.%d is not supported by this release. Try to "
-"rebuild topology using v.build or v.build.all module."
+msgid "Old topology format version %d.%d is not supported by this release. Try to rebuild topology using v.build or v.build.all module."
 msgstr ""
 #: ../lib/vector/diglib/plus_struct.c:563 ../lib/vector/diglib/portable.c:208
 #: ../lib/vector/diglib/spindex_rw.c:302
 #, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this spatial index format. "
-"Try to rebuild topology or upgrade GRASS to at least version %d."
+msgid "This version of GRASS (%d.%d) is too old to read this spatial index format. Try to rebuild topology or upgrade GRASS to at least version %d."
 msgstr ""
 #: ../lib/vector/diglib/spindex_rw.c:308
 #, c-format
-msgid ""
-"Your GRASS version does not fully support spatial index format %d.%d of the "
+msgid "Your GRASS version does not fully support spatial index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
 msgstr ""
 #: ../lib/vector/diglib/spindex_rw.c:317
 #, c-format
-msgid ""
-"Spatial index format version %d.%d is not supported by this release. Please "
-"rebuild topology."
+msgid "Spatial index format version %d.%d is not supported by this release. Please rebuild topology."
 msgstr ""
 #: ../lib/vector/diglib/test.c:58
 #: ../lib/vector/diglib/test.c:75
 #, c-format
-msgid ""
-"Error in read/write portable double, byte_order = %d Written: %.16e3E Read: "
-"%.16e3E"
+msgid "Error in read/write portable double, byte_order = %d Written: %.16e3E Read: %.16e3E"
 msgstr ""
 #: ../lib/vector/diglib/test.c:89
 #, c-format
-msgid ""
-"Error in read/write portable float, byte_order = %d Written: %.8e3E Read: "
-"%.8e3E"
+msgid "Error in read/write portable float, byte_order = %d Written: %.8e3E Read: %.8e3E"
 msgstr ""
 #: ../lib/vector/diglib/test.c:104
 #, c-format
-msgid ""
-"Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
+msgid "Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
 msgstr ""
 #: ../lib/vector/diglib/test.c:119
 #, c-format
-msgid ""
-"Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
+msgid "Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
 msgstr ""
 #: ../lib/vector/diglib/test.c:134
 #: ../lib/vector/diglib/test.c:150
 #, c-format
-msgid ""
-"Error in read/write portable short, byte_order = %d Written: %d Read: %d"
+msgid "Error in read/write portable short, byte_order = %d Written: %d Read: %d"
 msgstr ""
 #: ../lib/vector/diglib/test.c:165
 #, c-format
-msgid ""
-"Error in read/write portable char, byte_order = %d Written: %d Read: %d"
+msgid "Error in read/write portable char, byte_order = %d Written: %d Read: %d"
 msgstr ""
 #: ../lib/vector/rtree/test_suite/test_basics.c:40
@@ -972,9 +935,7 @@
 msgstr ""
 #: ../lib/vector/Vlib/open_pg.c:559
-msgid ""
-"Connection to PostgreSQL database failed. Try to set up username/password by"
-" db.login."
+msgid "Connection to PostgreSQL database failed. Try to set up username/password by db.login."
 msgstr ""
 #: ../lib/vector/Vlib/open_pg.c:566
 #: ../lib/vector/Vlib/build_pg.c:1018
 #, c-format
-msgid ""
-"Unable to build simple features from topogeometry data. Unsupported type %d."
+msgid "Unable to build simple features from topogeometry data. Unsupported type %d."
 msgstr ""
 #: ../lib/vector/Vlib/write_nat.c:398
 #: ../lib/vector/Vlib/ascii.c:889
 #, c-format
-msgid ""
-"%d features without category skipped. To export also features without "
-"category use '%s=-1'."
+msgid "%d features without category skipped. To export also features without category use '%s=-1'."
 msgstr ""
 #: ../lib/vector/Vlib/cindex.c:32
 #: ../lib/vector/Vlib/read_pg.c:365
 #, c-format
-msgid ""
-"Requesting invalid feature from cache (%d). Number of features in cache: %d"
+msgid "Requesting invalid feature from cache (%d). Number of features in cache: %d"
 msgstr ""
 #: ../lib/vector/Vlib/read_pg.c:368
 #: ../lib/vector/Vlib/net_build.c:432
 #, c-format
-msgid ""
-"Database record for turn with cat = %d in not found. (The turn was skipped."
+msgid "Database record for turn with cat = %d in not found. (The turn was skipped."
 msgstr ""
 #: ../lib/vector/Vlib/net_build.c:465
 #: ../lib/vector/Vlib/net_build.c:579
 #, c-format
-msgid ""
-"Database record for line %d (cat = %d, forward/both direction(s)) not found "
-"(cost was set to 0)"
+msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (cost was set to 0)"
 msgstr ""
 #: ../lib/vector/Vlib/net_build.c:596
 #, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not found(cost "
-"was set to 0)"
+msgid "Database record for line %d (cat = %d, backword direction) not found(cost was set to 0)"
 msgstr ""
 #: ../lib/vector/Vlib/net_build.c:658 ../lib/vector/Vlib/net_build.c:1064
 #: ../lib/vector/Vlib/net_build.c:869
 #, c-format
-msgid ""
-"(forward/both direction(s) of line skipped)"
+msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (forward/both direction(s) of line skipped)"
 msgstr ""
 #: ../lib/vector/Vlib/net_build.c:888
 #, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not "
-"found(direction of line skipped)"
+msgid "Database record for line %d (cat = %d, backword direction) not found(direction of line skipped)"
 msgstr ""
 #: ../lib/vector/Vlib/net_build.c:937
 #: ../lib/vector/Vlib/geos.c:55
 #, c-format
-msgid ""
-"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
-"vector map <%s>: %d)"
+msgid "Vect_read_line_geos(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
 msgstr ""
 #: ../lib/vector/Vlib/geos.c:60
 msgstr ""
 #: ../lib/vector/Vlib/open.c:277
-msgid ""
-"Vector map which is not in the current mapset cannot be opened for update"
+msgid "Vector map which is not in the current mapset cannot be opened for update"
 msgstr ""
 #: ../lib/vector/Vlib/open.c:311
 #: ../lib/vector/Vlib/open.c:419
 #, c-format
-msgid ""
-"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
-"with v.build."
+msgid "Unable to open vector map <%s> on level %d. Try to rebuild vector topology with v.build."
 msgstr ""
 #: ../lib/vector/Vlib/open.c:445
 msgstr ""
 #: ../lib/vector/Vlib/buffer2.c:589
-msgid ""
-"Next edge was visited (right) but it is not the first one !!! breaking loop"
+msgid "Next edge was visited (right) but it is not the first one !!! breaking loop"
 msgstr ""
 #: ../lib/vector/Vlib/buffer2.c:600
-msgid ""
-"Next edge was visited (left) but it is not the first one !!! breaking loop"
+msgid "Next edge was visited (left) but it is not the first one !!! breaking loop"
 msgstr ""
 #: ../lib/vector/Vlib/buffer2.c:648
 msgstr ""
 #: ../lib/vector/Vlib/build.c:1210
-msgid ""
-"Unable to build spatial index from topology, vector map is not opened at "
-"topology level 2"
+msgid "Unable to build spatial index from topology, vector map is not opened at topology level 2"
 msgstr ""
 #: ../lib/vector/Vlib/build.c:1233
@@ -2522,9 +2461,7 @@
 msgstr ""
 #: ../lib/vector/Vlib/build_ogr.c:89
-msgid ""
-"Random read is not supported by OGR for this layer. Unable to build "
-"topology."
+msgid "Random read is not supported by OGR for this layer. Unable to build topology."
 msgstr ""
 #: ../lib/vector/Vlib/build_ogr.c:101 ../lib/vector/Vlib/build_ogr.c:176
@@ -2809,9 +2746,7 @@
 msgstr ""
 #: ../lib/vector/Vlib/dgraph.c:432
-msgid ""
-"Trying to add more edges to the planar_graph than the initial allocation "
-"size allows"
+msgid "Trying to add more edges to the planar_graph than the initial allocation size allows"
 msgstr ""
 #: ../lib/vector/Vlib/field.c:91
@@ -2839,9 +2774,7 @@
 msgstr ""
 #: ../lib/vector/Vlib/field.c:185
-msgid ""
-"More DB links defined for input vector map. Using only first DB link for "
-"output."
+msgid "More DB links defined for input vector map. Using only first DB link for output."
 msgstr ""
 #: ../lib/vector/Vlib/field.c:261
@@ -2890,15 +2823,12 @@
 msgstr ""
 #: ../lib/vector/Vlib/field.c:773
-msgid ""
-"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
-"available in OGR DB table"
+msgid "All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' available in OGR DB table"
 msgstr ""
 #: ../lib/vector/Vlib/field.c:840
 #, c-format
-msgid ""
-"Feature table <%s> has no primary key defined. Unable to define DB links."
+msgid "Feature table <%s> has no primary key defined. Unable to define DB links."
 msgstr ""
 #: ../lib/vector/Vlib/field.c:860
@@ -2966,8 +2896,7 @@
 #: ../lib/vector/Vlib/legal_vname.c:65
 #, c-format
-msgid ""
-"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
 msgstr ""
 #: ../lib/vector/Vlib/legal_vname.c:100 ../lib/vector/Vlib/legal_vname.c:104
@@ -3065,16 +2994,12 @@
 #: ../lib/vector/Vlib/open_nat.c:152
 #, c-format
-msgid ""
-"Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
-"excess)"
+msgid "Coor file of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
 msgstr ""
 #: ../lib/vector/Vlib/open_nat.c:156
 #, c-format
-msgid ""
-"Coor file of vector <%s@%s> is shorter than it should be (%ld bytes "
-"missing)."
+msgid "Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
 msgstr ""
 #: ../lib/vector/Vlib/open_ogr.c:60
@@ -3117,16 +3042,12 @@
 #: ../lib/vector/Vlib/open_ogr.c:279
 #, c-format
-msgid ""
-"Feature index format version %d.%d is not supported by this release. Try to "
-"rebuild topology or upgrade GRASS."
+msgid "Feature index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
 msgstr ""
 #: ../lib/vector/Vlib/open_ogr.c:284
 #, c-format
-msgid ""
-"Your GRASS version does not fully support feature index format %d.%d of the "
+msgid "Your GRASS version does not fully support feature index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
 msgstr ""
 #: ../lib/vector/Vlib/overlay.c:72
@@ -3512,9 +3433,7 @@
 #: ../lib/db/dbmi_base/login.c:232
 #, c-format
-msgid ""
-"DB connection <%s/%s> already exists. Re-run '%s' with '--%s' flag to "
-"overwrite existing settings."
+msgid "DB connection <%s/%s> already exists. Re-run '%s' with '--%s' flag to overwrite existing settings."
 msgstr ""
 #: ../lib/db/dbmi_base/test/test_columns.c:37
@@ -3858,9 +3777,7 @@
 msgstr ""
 #: ../lib/imagery/iscatt_core.c:579
-msgid ""
-"Data inconsistent. Value computed for scatter plot is out of initialized "
-"range."
+msgid "Data inconsistent. Value computed for scatter plot is out of initialized range."
 msgstr ""
 #: ../lib/imagery/iscatt_core.c:745
@@ -3894,9 +3811,7 @@
 #: ../lib/imagery/sigsetfile.c:41
 #, c-format
-msgid ""
-"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
-"is not current mapset"
+msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> is not current mapset"
 msgstr ""
 #: ../lib/imagery/sigsetfile.c:57
@@ -3911,8 +3826,7 @@
 #: ../lib/symbol/read.c:260
 #, c-format
-msgid ""
-"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgid "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
 msgstr ""
 #: ../lib/symbol/read.c:284
@@ -4019,8 +3933,7 @@
 msgstr ""
 #: ../lib/init/grass.py:338
-msgid ""
-"force removal of .gislock if exists (use with care!). Only with -text flag"
+msgid "force removal of .gislock if exists (use with care!). Only with -text flag"
 msgstr ""
 #: ../lib/init/grass.py:339
@@ -4065,8 +3978,7 @@
 msgstr ""
 #: ../lib/init/grass.py:351
-msgid ""
-"directory containing Mapsets with one common coordinate system (projection)"
+msgid "directory containing Mapsets with one common coordinate system (projection)"
 msgstr ""
 #: ../lib/init/grass.py:352
@@ -4130,15 +4042,12 @@
 msgstr ""
 #: ../lib/init/grass.py:393
-msgid ""
-"The APPDATA variable points to directory which does not exist, ask your "
-"operating system support"
+msgid "The APPDATA variable points to directory which does not exist, ask your operating system support"
 msgstr ""
 #: ../lib/init/grass.py:440
 #, python-format
-msgid ""
-"Unable to create temporary directory <grass7-%(user)s-%(lock)s>! Exiting."
+msgid "Unable to create temporary directory <grass7-%(user)s-%(lock)s>! Exiting."
 msgstr ""
 #: ../lib/init/grass.py:493
@@ -4196,22 +4105,17 @@
 #: ../lib/init/grass.py:840
 #, python-format
-msgid ""
-"<%s> is not a valid GRASS Location because PERMANENT is not a directory"
+msgid "<%s> is not a valid GRASS Location because PERMANENT is not a directory"
 msgstr ""
 #: ../lib/init/grass.py:844
 #, python-format
-msgid ""
-"<%s> is not a valid GRASS Location because PERMANENT Mapset does not have a "
-"DEFAULT_WIND file (default computational region)"
+msgid "<%s> is not a valid GRASS Location because PERMANENT Mapset does not have a DEFAULT_WIND file (default computational region)"
 msgstr ""
 #: ../lib/init/grass.py:848
-msgid ""
-"Mapset <{mapset}> doesn't exist in GRASS Location <{loc}>. A new mapset can "
-"be created by '-c' switch."
+msgid "Mapset <{mapset}> doesn't exist in GRASS Location <{loc}>. A new mapset can be created by '-c' switch."
 msgstr ""
 #: ../lib/init/grass.py:911
@@ -4231,9 +4135,7 @@
 #: ../lib/init/grass.py:958
 #, python-format
-msgid ""
-"Invalid user interface specified - <%s>. Use the --help option to see valid "
-"interface names."
+msgid "Invalid user interface specified - <%s>. Use the --help option to see valid interface names."
 msgstr ""
 #: ../lib/init/grass.py:977
@@ -4299,9 +4201,7 @@
 #: ../lib/init/grass.py:1224
 #, python-format
-msgid ""
-"%(user)s is currently running GRASS in selected mapset (file %(file)s "
-"found). Forcing to launch GRASS..."
+msgid "%(user)s is currently running GRASS in selected mapset (file %(file)s found). Forcing to launch GRASS..."
 msgstr ""
 #: ../lib/init/grass.py:1228
@@ -4461,9 +4361,7 @@
 #: ../lib/init/grass.py:1891
-msgid ""
-"<{0}> requested, but not available. Run GRASS in text mode (-text) or "
-"install missing package (usually 'grass-gui')."
+msgid "<{0}> requested, but not available. Run GRASS in text mode (-text) or install missing package (usually 'grass-gui')."
 msgstr ""
 #: ../lib/init/grass.py:1945
@@ -4563,9 +4461,7 @@
 #: ../lib/raster/get_cellhd.c:66
 #, c-format
-msgid ""
-"Unable to read header file for raster map <%s@%s>. It is a reclass of raster"
-" map <%s@%s> %s"
+msgid "Unable to read header file for raster map <%s@%s>. It is a reclass of raster map <%s@%s> %s"
 msgstr ""
 #: ../lib/raster/get_cellhd.c:70
@@ -4771,9 +4667,7 @@
 msgstr ""
 #: ../lib/raster/set_window.c:131
-msgid ""
-"Rast_set_read_window(): projection/zone differs from that of currently open "
-"raster maps"
+msgid "Rast_set_read_window(): projection/zone differs from that of currently open raster maps"
 msgstr ""
 #: ../lib/raster/set_window.c:158
@@ -4787,21 +4681,15 @@
 msgstr ""
-msgid ""
-"Internal error: Rast_get_window() called with split window. Use "
-"Rast_get_input_window() or Rast_get_output_window() instead."
+msgid "Internal error: Rast_get_window() called with split window. Use Rast_get_input_window() or Rast_get_output_window() instead."
 msgstr ""
 #: ../lib/raster/window.c:90
-msgid ""
-"Internal error: Rast_window_rows() called with split window. Use "
-"Rast_input_window_rows() or Rast_output_window_rows() instead."
+msgid "Internal error: Rast_window_rows() called with split window. Use Rast_input_window_rows() or Rast_output_window_rows() instead."
 msgstr ""
 #: ../lib/raster/window.c:125
-msgid ""
-"Internal error: Rast_window_cols() called with split window. Use "
-"Rast_input_window_cols() or Rast_output_window_cols() instead."
+msgid "Internal error: Rast_window_cols() called with split window. Use Rast_input_window_cols() or Rast_output_window_cols() instead."
 msgstr ""
 #: ../lib/raster/init.c:61
@@ -4814,8 +4702,7 @@
 msgstr ""
-msgid ""
-"No compression is not supported for GRASS raster maps, using default ZLIB"
+msgid "No compression is not supported for GRASS raster maps, using default ZLIB"
 msgstr ""
@@ -4969,9 +4856,7 @@
 #: ../lib/raster/gdal.c:500
 #, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
 msgstr ""
 #: ../lib/raster/gdal.c:506
@@ -5013,9 +4898,7 @@
 #: ../lib/raster/open.c:193
 #, c-format
-msgid ""
-"Unable to open raster map <%s@%s> since it is a reclass of raster map "
-"<%s@%s> which does not exist"
+msgid "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%s> which does not exist"
 msgstr ""
@@ -5040,9 +4923,7 @@
 #, c-format
-msgid ""
-"Raster map <%s> is in different projection than current region. Found <%s>, "
-"should be <%s>."
+msgid "Raster map <%s> is in different projection than current region. Found <%s>, should be <%s>."
 msgstr ""
 #: ../lib/raster/open.c:247
@@ -5057,8 +4938,7 @@
 #, c-format
-msgid ""
-"Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
+msgid "Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
 msgstr ""
@@ -5125,8 +5005,7 @@
 msgstr ""
 #: ../lib/raster/open.c:1030
-msgid ""
-"Rast_set_quant_rules() can be called only for raster maps opened for reading"
+msgid "Rast_set_quant_rules() can be called only for raster maps opened for reading"
 msgstr ""
 #: ../lib/raster/close.c:77 ../lib/raster/close.c:110
@@ -5218,9 +5097,7 @@
 #: ../lib/ogsf/gp3.c:288
 #, c-format
-msgid ""
-"%d points without category. Unable to determine color rules for features "
-"without category."
+msgid "%d points without category. Unable to determine color rules for features without category."
 msgstr ""
 #: ../lib/ogsf/gs2.c:1211
@@ -5323,9 +5200,7 @@
 #: ../lib/ogsf/gsd_prim.c:630
 #, c-format
-msgid ""
-"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
-"advise GRASS developers of this error"
+msgid "gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please advise GRASS developers of this error"
 msgstr ""
 #: ../lib/ogsf/gsd_surf.c:1742
@@ -5357,9 +5232,7 @@
 #: ../lib/ogsf/gv3.c:414
 #, c-format
-msgid ""
-"%d features without category. Unable to determine color rules for features "
+msgid "%d features without category. Unable to determine color rules for features without category."
 msgstr ""
 #: ../lib/ogsf/gvl2.c:267
@@ -5984,9 +5857,7 @@
 #: ../lib/arraystats/class.c:242
 #, c-format
-msgid ""
-"There are classbreaks outside the range min-max. Number of classes reduced "
-"to %i, but using probabilities for %i classes."
+msgid "There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."
 msgstr ""
 #: ../lib/lidar/raster.c:74 ../lib/lidar/raster.c:89 ../lib/lidar/raster.c:102
@@ -6108,9 +5979,7 @@
 msgstr ""
-msgid ""
-"grass.script.array.read is deprecated and does not work on MS Windows, pass "
-"raster name in the constructor"
+msgid "grass.script.array.read is deprecated and does not work on MS Windows, pass raster name in the constructor"
 msgstr ""
@@ -6124,9 +5993,7 @@
 msgstr ""
-msgid ""
-"grass.script.array3d.read is deprecated and does not work on MS Windows, "
-"pass 3D raster name in the constructor"
+msgid "grass.script.array3d.read is deprecated and does not work on MS Windows, pass 3D raster name in the constructor"
 msgstr ""
 #: ../lib/python/script/core.py:67
@@ -6136,10 +6003,7 @@
 #: ../lib/python/script/core.py:304
 #, python-format
-msgid ""
-"To run the module <%s> add underscore at the end of the option <%s> to avoid"
-" conflict with Python keywords. Underscore at the beginning is depreciated "
-"in GRASS GIS 7.0 and will be removed in version 7.1."
+msgid "To run the module <%s> add underscore at the end of the option <%s> to avoid conflict with Python keywords. Underscore at the beginning is depreciated in GRASS GIS 7.0 and will be removed in version 7.1."
 msgstr ""
 #: ../lib/python/script/core.py:928
@@ -6197,9 +6061,7 @@
 #: ../lib/python/script/raster.py:54
 #, python-format
-msgid ""
-"Unable to write history for <%(map)s>. Raster map <%(map)s> not found in "
-"current mapset."
+msgid "Unable to write history for <%(map)s>. Raster map <%(map)s> not found in current mapset."
 msgstr ""
 #: ../lib/python/script/raster.py:113
@@ -6286,8 +6148,7 @@
 #: ../lib/python/script/db.py:153
 #, python-format
-msgid ""
-"Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
+msgid "Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
 msgstr ""
@@ -6396,9 +6257,7 @@
 msgstr ""
 #: ../lib/python/temporal/core.py:605
-msgid ""
-"Unable to initialize the temporal DBMI interface. Please use t.connect to "
-"specify the driver and the database string"
+msgid "Unable to initialize the temporal DBMI interface. Please use t.connect to specify the driver and the database string"
 msgstr ""
 #: ../lib/python/temporal/core.py:668
@@ -6507,10 +6366,7 @@
 msgstr ""
 #: ../lib/python/temporal/mapcalc.py:151
-msgid ""
-"Found more than a single map in a sample granule. Only the first map is used"
-" for computation. Use t.rast.aggregate.ds to create synchronous raster "
-"datasets."
+msgid "Found more than a single map in a sample granule. Only the first map is used for computation. Use t.rast.aggregate.ds to create synchronous raster datasets."
 msgstr ""
 #: ../lib/python/temporal/mapcalc.py:169
@@ -6524,8 +6380,7 @@
 #: ../lib/python/temporal/mapcalc.py:235 ../lib/python/temporal/extract.py:130
 #: ../lib/python/temporal/open_stds.py:208
 #, python-format
-msgid ""
-"Map <%s> is already in temporal database, use overwrite flag to overwrite"
+msgid "Map <%s> is already in temporal database, use overwrite flag to overwrite"
 msgstr ""
 #: ../lib/python/temporal/mapcalc.py:255
@@ -6661,23 +6516,17 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1599
 #, python-format
-msgid ""
-"Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database. "
-"The mapset of the dataset does not match the current mapset"
+msgid "Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1768
 #, python-format
-msgid ""
-"Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database. "
+msgid "Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1870
 #, python-format
-msgid ""
-"Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database."
-" The mapset of the dataset does not match the current mapset"
+msgid "Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1879
@@ -6692,9 +6541,7 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1950
 #: ../lib/python/temporal/abstract_map_dataset.py:824
 #, python-format
-msgid ""
-"Unable to delete dataset <%(ds)s> of type %(type)s from the temporal "
-"database. The mapset of the dataset does not match the current mapset"
+msgid "Unable to delete dataset <%(ds)s> of type %(type)s from the temporal database. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1963
@@ -6708,15 +6555,11 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2047
 #, python-format
-msgid ""
-"Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of "
-"the dataset does not match the current mapset"
+msgid "Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2056
-msgid ""
-"Only a map that was inserted in the temporal database can be registered in a"
-" space time dataset"
+msgid "Only a map that was inserted in the temporal database can be registered in a space time dataset"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2079
@@ -6731,15 +6574,12 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2101
 #, python-format
-msgid ""
-"Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer "
-"%(l)s are different"
+msgid "Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer %(l)s are different"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2107
 #, python-format
-msgid ""
-"Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
+msgid "Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2122
@@ -6749,16 +6589,12 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2132
 #, python-format
-msgid ""
-"Relative time units of space time dataset <%(id)s> and map <%(map)s> with "
-"layer %(l)s are different"
+msgid "Relative time units of space time dataset <%(id)s> and map <%(map)s> with layer %(l)s are different"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2138
 #, python-format
-msgid ""
-"Relative time units of space time dataset <%(id)s> and map <%(map)s> are "
-"different"
+msgid "Relative time units of space time dataset <%(id)s> and map <%(map)s> are different"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2144
@@ -6777,17 +6613,12 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2201
 #, python-format
-msgid ""
-"Unable to unregister map from dataset <%(ds)s> of type %(type)s in the "
-"temporal database. The mapset of the dataset does not match the current "
-"mapset"
+msgid "Unable to unregister map from dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2214
 #, python-format
-msgid ""
-"Map <%(map)s> with layer %(l)s is not registered in space time dataset "
-"<%(base)s>"
+msgid "Map <%(map)s> with layer %(l)s is not registered in space time dataset <%(base)s>"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2220
@@ -6801,16 +6632,12 @@
 #: ../lib/python/temporal/abstract_dataset.py:428
 #: ../lib/python/temporal/abstract_dataset.py:471
 #, python-format
-msgid ""
-"Unable to update dataset <%(ds)s> of type %(type)s in the temporal database."
+msgid "Unable to update dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2281
 #, python-format
-msgid ""
-"Update metadata, spatial and temporal extent from all registered maps of "
-"<%s>"
+msgid "Update metadata, spatial and temporal extent from all registered maps of <%s>"
 msgstr ""
 #: ../lib/python/temporal/datetime_math.py:256
@@ -6964,9 +6791,7 @@
 #: ../lib/python/temporal/stds_import.py:434
 #, python-format
-msgid ""
-"Space time %(t)s dataset <%(sp)s> is already in the database. Use the "
-"overwrite flag."
+msgid "Space time %(t)s dataset <%(sp)s> is already in the database. Use the overwrite flag."
 msgstr ""
 #: ../lib/python/temporal/stds_import.py:455
@@ -7026,9 +6851,7 @@
 #: ../lib/python/temporal/temporal_vector_algebra.py:372
 #, python-format
-msgid ""
-"Error vector maps with basename %s exist. Use --o flag to overwrite existing"
-" file"
+msgid "Error vector maps with basename %s exist. Use --o flag to overwrite existing file"
 msgstr ""
 #: ../lib/python/temporal/temporal_vector_algebra.py:405
@@ -7046,25 +6869,19 @@
 msgstr ""
 #: ../lib/python/temporal/spatial_extent.py:119
-msgid ""
-"Projections are different. Unable to compute overlapping_2d for spatial "
-"extents"
+msgid "Projections are different. Unable to compute overlapping_2d for spatial extents"
 msgstr ""
 #: ../lib/python/temporal/spatial_extent.py:525
-msgid ""
-"Projections are different. Unable to compute is_in_2d for spatial extents"
+msgid "Projections are different. Unable to compute is_in_2d for spatial extents"
 msgstr ""
 #: ../lib/python/temporal/spatial_extent.py:657
-msgid ""
-"Projections are different. Unable to compute equivalent_2d for spatial "
-"extents"
+msgid "Projections are different. Unable to compute equivalent_2d for spatial extents"
 msgstr ""
 #: ../lib/python/temporal/spatial_extent.py:762
-msgid ""
-"Projections are different. Unable to compute cover_2d for spatial extents"
+msgid "Projections are different. Unable to compute cover_2d for spatial extents"
 msgstr ""
 #: ../lib/python/temporal/spatial_extent.py:834
@@ -7096,15 +6913,12 @@
 #: ../lib/python/temporal/open_stds.py:122
 #, python-format
-msgid ""
-"Space time %(sp)s dataset <%(name)s> is already in the database. Use the "
-"overwrite flag."
+msgid "Space time %(sp)s dataset <%(name)s> is already in the database. Use the overwrite flag."
 msgstr ""
 #: ../lib/python/temporal/open_stds.py:157
 #, python-format
-msgid ""
-"Overwriting space time %(sp)s dataset <%(name)s> and unregistering all maps"
+msgid "Overwriting space time %(sp)s dataset <%(name)s> and unregistering all maps"
 msgstr ""
 #: ../lib/python/temporal/open_stds.py:165
@@ -7113,9 +6927,7 @@
 msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:798
-msgid ""
-"Spatio-temporal topological operators are not supported in granularity "
-"algebra mode"
+msgid "Spatio-temporal topological operators are not supported in granularity algebra mode"
 msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:836
@@ -7139,9 +6951,7 @@
 #: ../lib/python/temporal/temporal_algebra.py:1176
 #: ../lib/python/temporal/temporal_algebra.py:1180
 #, python-format
-msgid ""
-"Wrong temporal type of space time dataset <%s>"
-"                                       <%s> time is required"
+msgid "Wrong temporal type of space time dataset <%s>                                       <%s> time is required"
 msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:1200
@@ -7150,15 +6960,11 @@
 #: ../lib/python/temporal/temporal_algebra.py:2092
 #, python-format
-msgid ""
-"The resulting space time dataset type <%(a)s> is different from the "
-"requested type <%(b)s>"
+msgid "The resulting space time dataset type <%(a)s> is different from the requested type <%(b)s>"
 msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:2098
-msgid ""
-"Maps that should be registered in the resulting space time dataset have "
-"different types."
+msgid "Maps that should be registered in the resulting space time dataset have different types."
 msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:2301
@@ -7168,9 +6974,7 @@
 msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:2307
-msgid ""
-"Wrong map type. TMAP only supports single maps that are registered in the "
-"temporal GRASS database"
+msgid "Wrong map type. TMAP only supports single maps that are registered in the temporal GRASS database"
 msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:2335
@@ -7191,9 +6995,7 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:342
 #, python-format
-msgid ""
-"Start time must be of type datetime for %(type)s map <%(id)s> with layer: "
-"%(l)s"
+msgid "Start time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:349
@@ -7203,9 +7005,7 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:357
 #, python-format
-msgid ""
-"End time must be of type datetime for %(type)s map <%(id)s> with layer: "
-"%(l)s"
+msgid "End time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:364
@@ -7215,9 +7015,7 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:373
 #, python-format
-msgid ""
-"End time must be greater than start time for %(type)s map <%(id)s> with "
-"layer: %(l)s"
+msgid "End time must be greater than start time for %(type)s map <%(id)s> with layer: %(l)s"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:381
@@ -7228,9 +7026,7 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:452
 #, python-format
-msgid ""
-"Unsupported relative time unit type for %(type)s map <%(id)s> with layer "
-"%(l)s: %(u)s"
+msgid "Unsupported relative time unit type for %(type)s map <%(id)s> with layer %(l)s: %(u)s"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:459
@@ -7240,22 +7036,17 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:468
 #, python-format
-msgid ""
-"End time must be greater than start time for %(typ)s map <%(id)s> with layer"
-" %(l)s"
+msgid "End time must be greater than start time for %(typ)s map <%(id)s> with layer %(l)s"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:783
 #, python-format
-msgid ""
-"Map <%(id)s> with layer %(layer)s has incorrect time interval, start time is"
-" greater than end time"
+msgid "Map <%(id)s> with layer %(layer)s has incorrect time interval, start time is greater than end time"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:789
 #, python-format
-msgid ""
-"Map <%s> has incorrect time interval, start time is greater than end time"
+msgid "Map <%s> has incorrect time interval, start time is greater than end time"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:795
@@ -7270,9 +7061,7 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:892
 #, python-format
-msgid ""
-"Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal "
+msgid "Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal database. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/factory.py:47
@@ -7282,9 +7071,7 @@
 #: ../lib/python/temporal/abstract_dataset.py:388
 #, python-format
-msgid ""
-"Unable to insert dataset <%(ds)s> of type %(type)s in the temporal database."
+msgid "Unable to insert dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/temporal_raster_base_algebra.py:615
@@ -7391,14 +7178,11 @@
 #: ../lib/python/temporal/register.py:108
 #, python-format
-msgid ""
-"Space time %(sp)s dataset <%(name)s> with relative time found, but no "
-"relative unit set for %(sp)s maps"
+msgid "Space time %(sp)s dataset <%(name)s> with relative time found, but no relative unit set for %(sp)s maps"
 msgstr ""
 #: ../lib/python/temporal/register.py:169
-msgid ""
-"The increment option will be ignored because of time stamps in input file"
+msgid "The increment option will be ignored because of time stamps in input file"
 msgstr ""
 #: ../lib/python/temporal/register.py:173
@@ -7416,16 +7200,12 @@
 #: ../lib/python/temporal/register.py:209
 #, python-format
-msgid ""
-"Unable to register %(t)s map <%(id)s> with layer %(l)s. The map has "
-"timestamp and the start time is not set."
+msgid "Unable to register %(t)s map <%(id)s> with layer %(l)s. The map has timestamp and the start time is not set."
 msgstr ""
 #: ../lib/python/temporal/register.py:215
 #, python-format
-msgid ""
-"Unable to register %(t)s map <%(id)s>. The map has no timestamp and the "
-"start time is not set."
+msgid "Unable to register %(t)s map <%(id)s>. The map has no timestamp and the start time is not set."
 msgstr ""
 #: ../lib/python/temporal/register.py:223
@@ -7440,23 +7220,17 @@
 #: ../lib/python/temporal/register.py:239
 #, python-format
-msgid ""
-"Map is already registered in temporal database. Unable to update %(t)s map "
-"<%(id)s> with layer %(l)s. Overwrite flag is not set."
+msgid "Map is already registered in temporal database. Unable to update %(t)s map <%(id)s> with layer %(l)s. Overwrite flag is not set."
 msgstr ""
 #: ../lib/python/temporal/register.py:246
 #, python-format
-msgid ""
-"<%(id)s>. Overwrite flag is not set."
+msgid "Map is already registered in temporal database. Unable to update %(t)s map <%(id)s>. Overwrite flag is not set."
 msgstr ""
 #: ../lib/python/temporal/register.py:270
 #, python-format
-msgid ""
-"Unable to update %(t)s map <%(id)s> with layer %(l)s. The temporal types are"
-" different."
+msgid "Unable to update %(t)s map <%(id)s> with layer %(l)s. The temporal types are different."
 msgstr ""
 #: ../lib/python/temporal/register.py:276
@@ -7489,9 +7263,7 @@
 #: ../lib/python/temporal/register.py:416
 #, python-format
-msgid ""
-"Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s -"
-" %(end)s"
+msgid "Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - %(end)s"
 msgstr ""
 #: ../lib/python/temporal/register.py:421
@@ -7501,8 +7273,7 @@
 #: ../lib/python/temporal/register.py:438
 #, python-format
-msgid ""
-"Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
+msgid "Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
 msgstr ""
 #: ../lib/python/temporal/register.py:443
@@ -7517,9 +7288,7 @@
 #: ../lib/python/temporal/aggregation.py:138
 #, python-format
-msgid ""
-"Raster map <%(name)s> is already in temporal database, use overwrite flag to"
-" overwrite"
+msgid "Raster map <%(name)s> is already in temporal database, use overwrite flag to overwrite"
 msgstr ""
 #: ../lib/python/temporal/aggregation.py:143
@@ -7538,16 +7307,12 @@
 #: ../lib/python/temporal/aggregation.py:298
 #, python-format
-msgid ""
-"Unable to perform aggregation. Output raster map <%(name)s> exists and "
-"overwrite flag was not set"
+msgid "Unable to perform aggregation. Output raster map <%(name)s> exists and overwrite flag was not set"
 msgstr ""
 #: ../lib/python/temporal/aggregation.py:316
 #, python-format
-msgid ""
-"The limit of open files (%i) was reached (%i). The module r.series will be "
-"run with flag z, to avoid open files limit exceeding."
+msgid "The limit of open files (%i) was reached (%i). The module r.series will be run with flag z, to avoid open files limit exceeding."
 msgstr ""
 #: ../lib/cluster/c_begin.c:57
@@ -7602,9 +7367,7 @@
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:193
-msgid ""
-"Do not use this option if schemas are not supported by driver/database "
-"server"
+msgid "Do not use this option if schemas are not supported by driver/database server"
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:202
@@ -7740,9 +7503,7 @@
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:433
-msgid ""
-"Number of digits used as mantissa in the internal map storage, 0 -23 for "
-"float, 0 - 52 for double, max or default"
+msgid "Number of digits used as mantissa in the internal map storage, 0 -23 for float, 0 - 52 for double, max or default"
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:443
@@ -7750,9 +7511,7 @@
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:453
-msgid ""
-"The dimensions of the tiles used in the output raster3d map (XxYxZ or "
-"default: 16x16x8)"
+msgid "The dimensions of the tiles used in the output raster3d map (XxYxZ or default: 16x16x8)"
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:463
@@ -7794,10 +7553,7 @@
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:527
-msgid ""
-"Vector features can have category values in different layers. This number "
-"determines which layer to use. When used with direct OGR access this is the "
-"layer name."
+msgid "Vector features can have category values in different layers. This number determines which layer to use. When used with direct OGR access this is the layer name."
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:537
@@ -7805,10 +7561,7 @@
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:539
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use. When used with direct OGR access this "
-"is the layer name."
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use. When used with direct OGR access this is the layer name."
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:548
@@ -7983,9 +7736,7 @@
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:887
-msgid ""
-"WHERE conditions of SQL statement without 'where' keyword used in the "
-"temporal GIS framework"
+msgid "WHERE conditions of SQL statement without 'where' keyword used in the temporal GIS framework"
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:888
@@ -8436,9 +8187,7 @@
 #: ../lib/gis/gisinit.c:53 ../lib/gis/gisinit.c:87
 #, c-format
-msgid ""
-"Module built against version %s but trying to use version %s. You need to "
-"rebuild GRASS GIS or untangle multiple installations."
+msgid "Module built against version %s but trying to use version %s. You need to rebuild GRASS GIS or untangle multiple installations."
 msgstr ""
 #: ../lib/gis/gisinit.c:65
@@ -9235,8 +8984,7 @@
 #: ../lib/proj/convert.c:139
 #, c-format
-msgid ""
-"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
 msgstr ""
 #: ../lib/proj/convert.c:152
@@ -9255,16 +9003,12 @@
 #: ../lib/proj/convert.c:473
 #, c-format
-msgid ""
-"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
-"want to look into this."
+msgid "Datum <%s> apparently recognised by GRASS but no parameters found. You may want to look into this."
 msgstr ""
 #: ../lib/proj/convert.c:477
 #, c-format
-msgid ""
-"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
-"transform parameters unspecified."
+msgid "Invalid transformation number %d; valid range is 1 to %d. Leaving datum transform parameters unspecified."
 msgstr ""
 #: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
Modified: grass/trunk/locale/po/grasslibs_vi.po
--- grass/trunk/locale/po/grasslibs_vi.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grasslibs_vi.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -22,25 +22,23 @@
 #: ../lib/symbol/read.c:211
 #, c-format
 msgid "Cannot read symbol line coordinates: %s"
-msgstr "Không thể đọc các tọa độ dòng của biểu tượng: %s"
+msgstr ""
 #, c-format
-msgid ""
 msgstr ""
-"Tên biểu tượng không đúng: '%s' (phải là: nhóm/tên hoặc nhóm/tên at bộ_bản_đồ)"
 #, c-format
 msgid "Cannot find/open symbol: '%s'"
-msgstr "Không thể tìm/mở biểu tượng: '%s' "
+msgstr ""
 #: ../lib/symbol/read.c:393 ../lib/symbol/read.c:411 ../lib/symbol/read.c:421
 #: ../lib/symbol/read.c:439
 #, c-format
 msgid "Incorrect symbol color: '%s', using default."
-msgstr "Màu biểu tượng không đúng: '%s', dùng mặc định."
+msgstr ""
 #: ../lib/ogsf/gv3.c:60 ../lib/ogsf/gv3.c:333 ../lib/ogsf/gp3.c:56
 #: ../lib/ogsf/gp3.c:191 ../lib/manage/do_remove.c:57
@@ -49,7 +47,7 @@
 #: ../lib/vector/Vlib/open.c:235
 #, c-format
 msgid "Vector map <%s> not found"
-msgstr "Không tìm thấy bản đồ vec-tơ <%s>"
+msgstr "Không tìm thấy bản đồ vector %s"
 #: ../lib/ogsf/gv3.c:66 ../lib/ogsf/gv3.c:338 ../lib/ogsf/gp3.c:62
 #: ../lib/ogsf/gp3.c:196 ../lib/python/temporal/c_libraries_interface.py:747
@@ -58,18 +56,17 @@
 #: ../lib/vector/Vlib/open.c:437
 #, c-format, python-format
 msgid "Unable to open vector map <%s>"
-msgstr "Không thể mở bản đồ vec-tơ <%s>"
+msgstr ""
 #: ../lib/ogsf/gv3.c:269
 #, c-format
 msgid "No features from vector map <%s> fall within current region"
 msgstr ""
-"Không có đối tượng nào trong bản đồ vec-tơ <%s> nằm trong vùng hiện tại"
 #: ../lib/ogsf/gv3.c:274
 #, c-format
 msgid "Vector map <%s> loaded (%d features)"
-msgstr "Bản đồ vec-tơ <%s> được nạp (%d đối tượng)"
+msgstr ""
 #: ../lib/ogsf/gv3.c:344 ../lib/ogsf/gp3.c:202 ../lib/vector/Vlib/map.c:300
 #: ../lib/vector/Vlib/map.c:436 ../lib/vector/Vlib/copy.c:594
@@ -80,7 +77,7 @@
 #: ../lib/vector/Vlib/net_build.c:971 ../lib/rst/interp_float/vinput2d.c:100
 #, c-format
 msgid "Database connection not defined for layer %d"
-msgstr "Kết nối CSDL không được định nghĩa cho lớp %d"
+msgstr "Kết nối đến CSDL không được định nghĩa cho lớp %d"
 #: ../lib/ogsf/gv3.c:350 ../lib/ogsf/gp3.c:208 ../lib/db/dbmi_client/db.c:46
 #: ../lib/db/dbmi_client/copy_tab.c:112 ../lib/db/dbmi_client/copy_tab.c:133
@@ -94,28 +91,26 @@
 #: ../lib/rst/interp_float/vinput2d.c:109
 #, c-format
 msgid "Unable to open database <%s> by driver <%s>"
-msgstr "Không thể mở CSDL <%s> bằng trình điều khiển <%s>"
+msgstr "Không thể mở csdl  <%s> bằng trình điều khiển <%s>"
 #: ../lib/ogsf/gv3.c:353
-#, fuzzy, c-format
+#, c-format
 msgid "Loading thematic vector layer <%s>..."
-msgstr "Đang nạp bản đồ raster <%s>..."
+msgstr ""
 #: ../lib/ogsf/gv3.c:377 ../lib/ogsf/gp3.c:235
-#, fuzzy, c-format
+#, c-format
 msgid "No color rule defined for category %d"
-msgstr "không thể đổi thư mục đến %s"
+msgstr ""
 #: ../lib/ogsf/gv3.c:392 ../lib/ogsf/gp3.c:249
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid color definition (%s)"
-msgstr "Tọa độ không hợp lệ"
+msgstr ""
 #, c-format
-msgid ""
 msgstr ""
 #: ../lib/ogsf/gsd_legend.c:239 ../lib/ogsf/gs3.c:125 ../lib/ogsf/gs3.c:189
@@ -147,67 +142,62 @@
 #: ../lib/ogsf/gsd_legend.c:246
 #, c-format
 msgid "Unable to read color file of raster map <%s>"
-msgstr "Không thể đọc tập tin màu của bản đồ raster <%s>"
+msgstr ""
 #: ../lib/ogsf/gsd_legend.c:252
 #, c-format
 msgid "Unable to read category file of raster map <%s>"
-msgstr "Không thể đọc tập tin phạm trù của bản đồ raster <%s>"
+msgstr ""
 #: ../lib/ogsf/gsd_legend.c:269
 #, c-format
 msgid "Unable to read fp range of raster map <%s>"
-msgstr "Không thể đọc miền fp của bản đồ raster <%s>"
+msgstr ""
 #: ../lib/ogsf/gsd_legend.c:281
 #, c-format
 msgid "Unable to read range of raster map <%s>"
-msgstr "Không thể đọc miền của bản đồ raster <%s>"
+msgstr ""
 #: ../lib/ogsf/gsd_legend.c:295
 msgid "Range request error for legend"
-msgstr "Lỗi yêu cầu miền cho chú giải"
+msgstr ""
 #: ../lib/ogsf/gsd_legend.c:385
-#, fuzzy
 msgid "Unable to show discrete FP range (use list)"
-msgstr "Không thể hiển thị miền FP rời rạc (dùng danh sách"
+msgstr ""
 #: ../lib/ogsf/gsd_legend.c:501
 msgid "Too many categories to show as discrete!"
-msgstr "Quá nhiều phạm trù để có thể hiển thị ở dạng rời rạc!"
+msgstr ""
 #: ../lib/ogsf/gsd_legend.c:503
 msgid "Try using smaller font!"
-msgstr "Hãy thử dùng phông nhỏ hơn!"
+msgstr ""
 #: ../lib/ogsf/gsd_img_ppm.c:52 ../lib/ogsf/gsd_img_ppm.c:95
 #: ../lib/ogsf/gsd_img_tif.c:66 ../lib/ogsf/gk2.c:216
 #, c-format
 msgid "Unable to open file <%s> for writing"
-msgstr "Không thể mở tập tin <%s> để ghi"
+msgstr ""
 #: ../lib/ogsf/trans.c:180
 msgid "Out of matrix stack space"
-msgstr "Hết không gian ngăn xếp ma trận"
+msgstr ""
 #: ../lib/ogsf/trans.c:200
 msgid "Tried to pop an empty stack"
-msgstr "Đã cố xoá một ngăn xếp rỗng"
+msgstr ""
 #: ../lib/ogsf/gsd_prim.c:146
 #, c-format
 msgid "Color Material: %d"
-msgstr "Vật liệu màu: %d"
+msgstr ""
 #, c-format
-msgid ""
 msgstr ""
-"gsd_rot(): %c là chỉ định trục không hợp lệ. Lệnh xoay bị bỏ qua. Vui lòng "
-"báo cho các nhà phát triển GRASS lỗi này."
 #, c-format
@@ -222,77 +212,74 @@
 #: ../lib/ogsf/gs2.c:1655
 #, c-format
 msgid "Raster map <%s> is outside of current region. Load failed."
-msgstr "Bản đồ raster <%s> nằm ngoài vùng hiện tại. Việc nạp thất bại."
+msgstr ""
 #: ../lib/ogsf/gs2.c:1733 ../lib/ogsf/gs2.c:1739 ../lib/ogsf/gs2.c:1747
 #: ../lib/ogsf/gs2.c:1756 ../lib/ogsf/gs2.c:1764 ../lib/ogsf/gs2.c:1774
 #: ../lib/ogsf/gs2.c:1822
 msgid "GS_load_att_map(): Out of memory. Unable to load map"
-msgstr "GS_load_att_map(): Hết bộ nhớ. Không thể nạp bản đồ"
+msgstr ""
 #: ../lib/ogsf/gs2.c:1850
 msgid "Loading failed"
-msgstr "Việc nạp thất bại"
+msgstr ""
 #: ../lib/ogsf/gs2.c:1854
 msgid "Error finding range"
-msgstr "Lỗi khi đang tìm miền"
+msgstr ""
 #: ../lib/ogsf/gs3.c:132 ../lib/ogsf/gs3.c:196 ../lib/ogsf/gs3.c:348
 #: ../lib/ogsf/gs3.c:454 ../lib/ogsf/gs3.c:540
 #, c-format
 msgid "Loading raster map <%s>..."
+msgstr ""
 #: ../lib/ogsf/gs3.c:596
 #, c-format
 msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
-msgstr "Miền bảng màu không khớp với dữ liệu (mincol=%d, maxcol=%d) "
+msgstr ""
 #: ../lib/ogsf/gs3.c:658 ../lib/ogsf/gs3.c:730
 #, c-format
 msgid "Translating colors from raster map <%s>..."
-msgstr "Đang dịch các màu từ bản đồ raster <%s>..."
+msgstr ""
 #: ../lib/ogsf/gs3.c:967
 msgid "View not saved by this program,there may be some inconsistancies"
 msgstr ""
-"Vùng xem không được chương trình này lưu, có thể có một số sự không nhất quán"
 #: ../lib/ogsf/gk.c:320
 msgid "Need at least 3 keyframes for spline"
-msgstr "Cần tối thiểu 3 khung hình chính để dùng cho đường spline"
+msgstr ""
 #: ../lib/ogsf/gk.c:622
 msgid "Need at least 2 keyframes for interpolation"
-msgstr "Cần ít nhất 2 khung chính để dùng cho việc nội suy"
+msgstr ""
 #: ../lib/ogsf/gp3.c:92 ../lib/vector/Vlib/copy.c:168
 #: ../lib/vector/Vlib/copy.c:245
 #, c-format
 msgid "Unable to read vector map <%s>"
-msgstr "Không thể đọc bản đồ vec-tơ <%s>"
+msgstr ""
 #: ../lib/ogsf/gp3.c:148
 #, c-format
 msgid "No points from vector map <%s> fall within current region"
-msgstr "Không có điểm nào trong bản đồ vec-tơ <%s> nằm trong vùng hiện tại"
+msgstr ""
 #: ../lib/ogsf/gp3.c:153
 #, c-format
 msgid "Vector map <%s> loaded (%d points)"
-msgstr "Bản đồ vec-tơ <%s> đã được nạp (%d điểm)"
+msgstr ""
 #: ../lib/ogsf/gp3.c:211
-#, fuzzy, c-format
+#, c-format
 msgid "Loading thematic points layer <%s>..."
+msgstr ""
 #, c-format
-msgid ""
 msgstr ""
 #: ../lib/ogsf/gp2.c:705
@@ -301,17 +288,16 @@
 #: ../lib/ogsf/gsds.c:109
 msgid "Maximum number of datasets exceeded"
-msgstr "Đã vượt quá số lượng bộ dữ liệu lớn nhất"
+msgstr ""
 msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
 msgstr ""
-"Các điểm mặt cắt giữa các mặt không khớp nhau. Kiểm tra lại độ phân giải"
 #, c-format
 msgid "Loading 3d raster map <%s>..."
+msgstr ""
 #: ../lib/ogsf/gvl3.c:40 ../lib/ogsf/gvl_file.c:427
 #: ../lib/manage/do_remove.c:78 ../lib/manage/do_rename.c:76
@@ -322,19 +308,19 @@
 #: ../lib/ogsf/gsd_label.c:58
 msgid "Max. number of labels reached!"
-msgstr "Đã đạt đến số nhãn lớn nhất!"
+msgstr ""
 #: ../lib/ogsf/gsdrape.c:207
 msgid "Unable to process vector map - out of memory"
-msgstr "Không thể xử lý bản đồ vec-tơ - hết bộ nhớ"
+msgstr ""
 #: ../lib/ogsf/gk2.c:272 ../lib/ogsf/gk2.c:285
 msgid "Check no. of frames requested and keyframes marked"
-msgstr "Kiểm tra số khung ảnh cần thiết và số khung chính được đánh dấu"
+msgstr ""
 #: ../lib/ogsf/gvl_file.c:103
 msgid "Maximum number of datafiles exceeded"
-msgstr "Vượt quá số lượng tập tin dữ liệu"
+msgstr ""
 #: ../lib/ogsf/gvl_file.c:436
 #: ../lib/python/temporal/c_libraries_interface.py:676
@@ -346,164 +332,143 @@
 #: ../lib/ogsf/gvl_file.c:442
 #, c-format
 msgid "Unable to read range of 3D raster map <%s>"
-msgstr "Không thể đọc miền của bản đồ raster 3D <%s>"
+msgstr ""
 #: ../lib/ogsf/gvl_file.c:470 ../lib/raster3d/close.c:120
 #: ../lib/raster3d/close.c:130 ../lib/raster3d/close.c:159
 #: ../lib/python/temporal/c_libraries_interface.py:706
 msgid "Unable to close 3D raster map <%s>"
-msgstr "Không thể đóng bản đồ raster 3D <%s>"
+msgstr ""
 #: ../lib/ogsf/gs_bm.c:124
 msgid "Bitmap mismatch"
-msgstr "Bitmap không khớp"
+msgstr ""
 #: ../lib/raster3d/header.c:217 ../lib/raster3d/close.c:99
 #: ../lib/raster3d/close.c:105 ../lib/raster3d/close.c:191
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to write header for 3D raster map <%s>"
+msgstr ""
 #: ../lib/raster3d/range.c:73
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open range file for [%s in %s]"
-msgstr "Không thể tạo ra tập tin header cho [%s ở %s]"
+msgstr ""
 #: ../lib/raster3d/range.c:88
-#, fuzzy, c-format
+#, c-format
 msgid "Error reading range file for [%s in %s]"
-msgstr "Không thể đọc tập tin range cho [%s ở %s]"
+msgstr ""
 #: ../lib/raster3d/range.c:150
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open range file for <%s>"
-msgstr "Không thể mở tập tin lịch sử của vector '%s'"
+msgstr ""
 #: ../lib/raster3d/open.c:20
-#, fuzzy
 msgid "Rast3d_open_cell_old_no_header: error in Rast3d_mask_open_old"
-msgstr "Rast3d_openCellOldNoHeader: lỗi trong Rast3d_maskOpenOld"
+msgstr ""
 #: ../lib/raster3d/open.c:26
-#, fuzzy
 msgid "Rast3d_open_cell_old_no_header: error in Rast3d_malloc"
-msgstr "Rast3d_openCellOldNoHeader: lỗi trong Rast3d_malloc"
+msgstr ""
 #: ../lib/raster3d/open.c:37
-#, fuzzy
 msgid "Rast3d_open_cell_old_no_header: error in G_open_old"
-msgstr "Rast3d_openCellOldNoHeader: lỗi trong G_open_old"
+msgstr ""
 #: ../lib/raster3d/open.c:93
-#, fuzzy
 msgid "Rast3d_open_cell_old: error in Rast3d_open_cell_old_no_header"
-msgstr "Rast3d_openCellOld: lỗi trong Rast3d_openCellOldNoHeader"
+msgstr ""
 #: ../lib/raster3d/open.c:98
-#, fuzzy
 msgid "Rast3d_open_cell_old: can't rewind file"
-msgstr "Rast3d_openCellOld: không thể tua lại tập tin"
+msgstr ""
 #: ../lib/raster3d/open.c:111
-#, fuzzy
 msgid "Rast3d_open_cell_old: error in Rast3d_read_header"
-msgstr "Rast3d_openCellOld: lỗi trong Rast3d_readHeader"
+msgstr ""
 #: ../lib/raster3d/open.c:119
-#, fuzzy
 msgid "Rast3d_open_cell_old: projection does not match window projection"
-msgstr "Rast3d_openCellOld: phép chiếu không khớp với phép chiếu của cửa sổ"
+msgstr ""
 #: ../lib/raster3d/open.c:123
-#, fuzzy
 msgid "Rast3d_open_cell_old: zone does not match window zone"
-msgstr "Rast3d_openCellOld: múi không khớp với múi của cửa sổ"
+msgstr ""
 #: ../lib/raster3d/open.c:135 ../lib/raster3d/open.c:152
-#, fuzzy
 msgid "Rast3d_open_cell_old: can't read header"
-msgstr "Rast3d_openCellOld: không thể đọc header"
+msgstr ""
 #: ../lib/raster3d/open.c:141
-#, fuzzy
 msgid "Rast3d_open_cell_old: index does not fit into long"
-msgstr "Rast3d_openCellOld: chỉ mục không vừa vào định dạng long"
+msgstr ""
 #: ../lib/raster3d/open.c:145
-#, fuzzy
 msgid "Rast3d_open_cell_old: error in Rast3d_malloc"
-msgstr "Rast3d_openCellOld: lỗi trong Rast3d_malloc"
+msgstr ""
 #: ../lib/raster3d/open.c:172
-#, fuzzy
 msgid "Rast3d_open_cell_old: error in Rast3d_fill_header"
-msgstr "Rast3d_openCellOld: lỗi trong Rast3d_fillHeader"
+msgstr ""
 #: ../lib/raster3d/open.c:219
-#, fuzzy
 msgid "Rast3d_open_cell_new: error in Rast3d_mask_open_old"
-msgstr "Rast3d_openCellNew: lỗi trong Rast3d_maskOpenOld"
+msgstr ""
 #: ../lib/raster3d/open.c:228
-#, fuzzy
 msgid "Rast3d_open_cell_new: error in Rast3d_malloc"
-msgstr " Rast3d_openCellNew: lỗi trong Rast3d_malloc"
+msgstr ""
 #: ../lib/raster3d/open.c:233
-#, fuzzy, c-format
+#, c-format
 msgid "map <%s> is not in the current mapset"
-msgstr "'Bọ': cố gắng cập nhật bản đồ không ở trong bộ bản đồ hiện tại."
+msgstr ""
 #: ../lib/raster3d/open.c:243
-#, fuzzy
 msgid "Rast3d_open_cell_new: could not open file"
-msgstr "Rast3d_openCellNew: không thể mở tập tin"
+msgstr ""
 #: ../lib/raster3d/open.c:287 ../lib/raster3d/open.c:292
-#, fuzzy
 msgid "Rast3d_open_cell_new: can't write header"
-msgstr "Rast3d_openCellNew: không thể ghi header"
+msgstr ""
 #: ../lib/raster3d/open.c:314
-#, fuzzy
 msgid "Rast3d_open_cell_new: error in Rast3d_fill_header"
-msgstr "Rast3d_openCellNew: lỗi trong Rast3d_fillHeader"
+msgstr ""
 #: ../lib/raster3d/close.c:47
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to write history for 3D raster map <%s>"
+msgstr ""
 #: ../lib/raster3d/close.c:62
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to move temp raster map <%s> to 3D raster map <%s>"
-msgstr "Không thể sao chép bản đồ vec-tơ <%s> vào <%s>"
+msgstr ""
 #: ../lib/raster3d/close.c:79
-#, fuzzy
 msgid "Unable to flush all tiles"
-msgstr "Không thể khởi động tập tin <%s>"
+msgstr ""
 #: ../lib/raster3d/close.c:84
-#, fuzzy
 msgid "Unable to flush index"
-msgstr "Không thể tìm thấy '%s'"
+msgstr ""
 #: ../lib/raster3d/close.c:94
-#, fuzzy
 msgid "Unable to position file"
-msgstr "Không thể mở tập tin %s trong %s"
+msgstr ""
 #: ../lib/raster3d/close.c:110 ../lib/raster3d/close.c:153
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create 3D raster map <%s>"
-msgstr "Không thể tạo bản đồ raster <%s>"
+msgstr ""
 #: ../lib/raster3d/close.c:169
-#, fuzzy
 msgid "Error in cache"
+msgstr ""
 #: ../lib/raster3d/test/test_main.c:96
 msgid "raster3d"
@@ -517,26 +482,24 @@
 #: ../lib/raster3d/history.c:43
 #, c-format
 msgid "can't get history information for [%s] in mapset [%s]"
-msgstr "không thể lấy thông tin lịch sử cho [%s] trong bộ bản đồ [%s] "
+msgstr ""
 #: ../lib/raster3d/param.c:84
-#, fuzzy
 msgid "Rast3d_get_standard3d_params: precision value invalid"
-msgstr "Rast3d_getStandard3dParams: giá trị độ chính xác không hợp lệ"
+msgstr ""
 #: ../lib/raster3d/param.c:105
-#, fuzzy
 msgid "Rast3d_get_standard3d_params: tile dimension value invalid"
-msgstr "Rast3d_getStandard3dParams: giá trị kích thước 'tile' không hợp lệ"
+msgstr ""
 #: ../lib/raster3d/param.c:129
 msgid "Window replacing the default"
-msgstr "Cửa sổ thay thế cho mặc định"
+msgstr ""
 #: ../lib/raster3d/color.c:354
-#, fuzzy, c-format
+#, c-format
 msgid "mapset <%s> is not the current mapset"
+msgstr ""
 #: ../lib/raster3d/maskfn.c:77
 #, c-format
@@ -544,29 +507,29 @@
 msgstr ""
 #: ../lib/raster3d/maskfn.c:95
-#, fuzzy, c-format
+#, c-format
 msgid "%s: illegal value spec"
-msgstr "%s - ** tên không hợp lệ **"
+msgstr ""
 #: ../lib/imagery/iscatt_core.c:81
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to write header into category raster condition file <%s>."
+msgstr ""
 #: ../lib/imagery/iscatt_core.c:98
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to write into category raster condition file <%s>."
-msgstr "không thể ghi thông tin lịch sử cho [%s]"
+msgstr ""
 #: ../lib/imagery/iscatt_core.c:255
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open category raster condtions file <%s>."
-msgstr "Không thể mở tập tin định nghĩa csdl vec-tơ: '%s'"
+msgstr ""
 #: ../lib/imagery/iscatt_core.c:263
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to find patch raster <%s>."
-msgstr "Không thể mở bản đồ raster <%s>"
+msgstr ""
 #: ../lib/imagery/iscatt_core.c:280
 #, c-format
@@ -579,49 +542,46 @@
 msgstr ""
 #: ../lib/imagery/iscatt_core.c:338
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to write into category raster conditions file <%s>"
+msgstr ""
 #: ../lib/imagery/iscatt_core.c:526
-#, fuzzy
 msgid "Unable to read from category raster condtition file."
+msgstr ""
 #: ../lib/imagery/iscatt_core.c:533
 msgid "Invalid size of category raster conditions file."
 msgstr ""
-msgid ""
-"range."
 msgstr ""
-#, fuzzy, c-format
+#, c-format
 msgid "Unbale to read find raster <%s>"
+msgstr ""
 #: ../lib/imagery/iscatt_core.c:755
-#, fuzzy, c-format
+#, c-format
 msgid "Unbale to open raster <%s>"
-msgstr "Không thể mở lớp <%s>"
+msgstr ""
 #: ../lib/imagery/iscatt_core.c:761
-#, fuzzy, c-format
+#, c-format
 msgid "Raster <%s> type is not <%s>"
-msgstr "Không tìm thấy bản đồ raster <%s> trong bộ bản đồ <%s>"
+msgstr ""
 #: ../lib/imagery/iscatt_core.c:775
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read range of raster <%s>"
+msgstr ""
 #: ../lib/imagery/iscatt_core.c:803
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open category raster condtition file <%s>"
+msgstr ""
 #: ../lib/imagery/iscatt_core.c:817
 msgid "Corrupted category raster conditions file (fseek failed)"
@@ -639,7 +599,7 @@
 #: ../lib/imagery/target.c:38
 #, c-format
 msgid "Unable to read target file for group [%s]"
-msgstr "Không thể đọc tập tin đích cho nhóm [%s]"
+msgstr ""
 #: ../lib/imagery/georef_tps.c:219
 msgid "Calculating forward transformation coefficients"
@@ -652,9 +612,9 @@
 #: ../lib/imagery/georef_tps.c:279 ../lib/imagery/georef_tps.c:282
 #: ../lib/imagery/georef_tps.c:285 ../lib/imagery/georef_tps.c:290
 #: ../lib/imagery/georef_tps.c:293
-#, fuzzy, c-format
+#, c-format
 msgid "%s: out of memory"
-msgstr "Hết bộ nhớ "
+msgstr ""
 #: ../lib/imagery/iclass_perimeter.c:109
 #, c-format
@@ -676,58 +636,57 @@
 #: ../lib/imagery/points.c:124
 #, c-format
 msgid "Unable to open control point file for group [%s in %s]"
-msgstr "Không thể mở tập tin điểm khống chế của nhóm [%s trong %s]"
+msgstr ""
 #: ../lib/imagery/points.c:132
 #, c-format
 msgid "Bad format in control point file for group [%s in %s]"
-msgstr "Định dạng tập tin điểm khống chế của nhóm [%s trong %s] không tốt"
+msgstr ""
 #: ../lib/imagery/points.c:159
 #, c-format
 msgid "Unable to create control point file for group [%s in %s]"
-msgstr "Không thể tạo tập tin điểm khống chế cho nhóm [%s trong %s]"
+msgstr ""
 #: ../lib/imagery/list_gp.c:34
 #, c-format
 msgid "group <%s> is empty\n"
-msgstr "nhóm <%s> rỗng\n"
+msgstr ""
 #: ../lib/imagery/list_gp.c:44
 #, c-format
 msgid "group <%s> references the following raster maps\n"
-msgstr "nhóm <%s> tham chiếu các bản đồ raster sau\n"
+msgstr ""
 #: ../lib/imagery/fopen.c:23
 #, c-format
 msgid "Unable to create file [%s] of group [%s in %s]"
-msgstr "Không thể tạo tập [%s] cho nhóm [%s ở %s]"
+msgstr ""
 #: ../lib/imagery/fopen.c:36 ../lib/imagery/fopen.c:57
 #, c-format
 msgid "Unable to open file [%s] of group [%s in %s]"
-msgstr "Không thể mở tập tin [%s] của nhóm [%s trong %s]"
+msgstr ""
 #: ../lib/imagery/fopen.c:49
 #, c-format
 msgid "Unable to find file [%s] of group [%s in %s]"
-msgstr "Không thể tìm thấy tập tin [%s] của nhóm [%s trong %s]"
+msgstr ""
 #: ../lib/imagery/fopen.c:79
 #, c-format
 msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr "Không thể tạo tập tin [%s] cho nhóm phụ [%s]  của nhóm [%s trong %s]"
+msgstr ""
 #: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
 #, c-format
 msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr "Không thể mở tập tin [%s] cho nhóm phụ [%s] của nhóm [%s trong %s]"
+msgstr ""
 #: ../lib/imagery/fopen.c:116
 #, c-format
 msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
 msgstr ""
-"Không thể tìm thấy tập tin [%s] cho nhóm phụ [%s] trong nhóm [%s trong %s]"
 #: ../lib/imagery/iclass_statistics.c:218
 msgid "prepare_signature: outline has odd number of points."
@@ -747,29 +706,27 @@
 #: ../lib/imagery/iclass_statistics.c:712
 #: ../lib/imagery/iclass_statistics.c:735
 #: ../lib/imagery/iclass_statistics.c:758
-#, fuzzy
 msgid "Band index out of range"
-msgstr "Chỉ mục phạm trù nằm ngoài miền"
+msgstr ""
 #: ../lib/imagery/iclass_statistics.c:684
-#, fuzzy
 msgid "Cell category value out of range"
-msgstr "Lớp hoặc chỉ mục phạm trù nằm ngoài miền"
+msgstr ""
 #: ../lib/imagery/iclass.c:83
-#, fuzzy, c-format
+#, c-format
 msgid "No areas in category %d"
+msgstr ""
 #: ../lib/imagery/iclass.c:127
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map <%s@%s> in subgroup <%s> does not exist"
-msgstr "Bảng <%s> được liên kết vào bản đồ vec-tơ <%s> không tồn tại"
+msgstr ""
 #: ../lib/imagery/iclass.c:131
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map <%s@%s> in group <%s> does not exist"
+msgstr ""
 #: ../lib/imagery/iclass.c:143
 #, c-format
@@ -784,29 +741,27 @@
 #: ../lib/imagery/list_subgp.c:72
 #, c-format
 msgid "subgroup <%s> of group <%s> is empty\n"
-msgstr "nhóm phụ <%s> của nhóm <%s> rỗng\n"
+msgstr ""
 #: ../lib/imagery/list_subgp.c:85
 #, c-format
 msgid "subgroup <%s> of group <%s> references the following raster maps\n"
-msgstr "nhóm phụ <%s> của nhóm <%s> tham chiếu các bản đồ raster sau\n"
+msgstr ""
-#, fuzzy, c-format
-msgid ""
+#, c-format
+msgstr ""
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
+msgstr ""
 #: ../lib/imagery/iclass_signatures.c:120
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open output signature file '%s'"
-msgstr "Không thể mở tập tin bảng mốc tọa độ chuẩn: %s"
+msgstr ""
 #: ../lib/psdriver/graph_set.c:199
 #, c-format
@@ -832,128 +787,122 @@
 msgstr ""
 #: ../lib/cairodriver/text.c:46
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to convert from <%s> to UTF-8"
-msgstr "không thể mở bản đồ raster [%s in %s]"
+msgstr "Không thể chuyển đổi từ <%s> thành UTF-8"
 #: ../lib/cairodriver/text.c:56
 msgid "Some characters could not be converted to UTF-8"
-msgstr ""
+msgstr "Một số ký tự không thể chuyển đổi thành UTF-8"
 #: ../lib/cairodriver/write_ppm.c:27 ../lib/cairodriver/write_bmp.c:72
-#, fuzzy, c-format
+#, c-format
 msgid "Cairo: unable to open output file <%s>"
+msgstr "Cairo: không thể mở tập tin đầu ra <%s>"
 #: ../lib/cairodriver/write_ppm.c:34
-#, fuzzy, c-format
+#, c-format
 msgid "Cairo: unable to open mask file <%s>"
-msgstr "G_spawn: không thể mở tập tin %s"
+msgstr "Cairo: không thể mở tập tin mặt nạ <%s>"
 #: ../lib/cairodriver/read_ppm.c:28 ../lib/cairodriver/read_bmp.c:88
-#, fuzzy, c-format
+#, c-format
 msgid "Cairo: unable to open input file <%s>"
+msgstr "Cairo: không thể mở tập tin đầu vào <%s>"
 #: ../lib/cairodriver/read_ppm.c:32 ../lib/cairodriver/read_bmp.c:92
-#, fuzzy, c-format
+#, c-format
 msgid "Cairo: invalid input file <%s>"
-msgstr "Không thể tìm thấy bản đồ đầu vào '%s'"
+msgstr "Cairo: tập tin đầu vào không hợp lệ <%s>"
 #: ../lib/cairodriver/read_ppm.c:38
 #, c-format
 msgid "Cairo: input file has incorrect dimensions: expected: %dx%d got: %dx%d"
-msgstr ""
+msgstr "Cairo: tập tin đầu vào có kích thước không đúng: mong đợi %d x %d nhưng lại nhận được: %d x %d"
 #: ../lib/cairodriver/read_ppm.c:46
-#, fuzzy, c-format
+#, c-format
 msgid "Cairo: unable to open input mask file <%s>"
+msgstr "Cairo: không thể mở tập tin mặt nạ đầu vào <%s>"
 #: ../lib/cairodriver/read_ppm.c:50
-#, fuzzy, c-format
+#, c-format
 msgid "Cairo: invalid input mask file <%s>"
+msgstr "Cairo: tập tin mặt nạ đầu vào không hợp lệ <%s>"
 #: ../lib/cairodriver/read_ppm.c:56
 #, c-format
-msgid ""
-"Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
-msgstr ""
+msgid "Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
+msgstr "Cairo: tập tin mặt nạ đầu vào có kích thước không đúng: mong đợi %d x %d nhưng nhận được: %d x%d"
 #: ../lib/cairodriver/read_xid.c:14
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open input file <%s>"
+msgstr "Không thể mở tập tin đầu vào <%s>"
 #: ../lib/cairodriver/read_xid.c:17
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read input file <%s>"
+msgstr "Không thể đọc tập tin đầu vào <%s>"
 #: ../lib/cairodriver/read_xid.c:20
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to parse input file <%s>"
+msgstr "Không thể phân tách tập tin đầu vào <%s>"
 #: ../lib/cairodriver/raster.c:109
-#, fuzzy
 msgid "Failed to create cairo surface"
-msgstr "Không thể tạo một quá trình mới"
+msgstr "Thất khi tạo bề mặt cairo"
 #: ../lib/cairodriver/write_xid.c:14 ../lib/pngdriver/read_png.c:71
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open output file <%s>"
+msgstr "Không thể mở tập tin đầu ra <%s>"
 #: ../lib/cairodriver/write_xid.c:19
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to write output file <%s>"
+msgstr "Không thể ghi tập tin đầu ra <%s>"
 #: ../lib/cairodriver/read_bmp.c:96
 #, c-format
 msgid "Cairo: Invalid BMP header for <%s>"
-msgstr ""
+msgstr "Cairo: đầu trang BMP không hợp lệ <%s>"
 #: ../lib/cairodriver/graph.c:67
-#, fuzzy
 msgid "Unable to open display"
-msgstr "không thể mở %s"
+msgstr "Không thể mở hiển thị"
 #: ../lib/cairodriver/graph.c:85
-#, fuzzy
 msgid "Unable to obtain visual"
+msgstr "Không thể thu thập trực quan"
 #: ../lib/cairodriver/graph.c:160
 #, c-format
 msgid "Unknown file extension: %s"
-msgstr ""
+msgstr "Đuôi mở rộng tập tin không rõ: %s"
 #: ../lib/cairodriver/graph.c:190
-#, fuzzy, c-format
+#, c-format
 msgid "cairo: collecting to file '%s'"
-msgstr "Lỗi khi đang đóng tập tin g3d"
+msgstr "cairo: đang thu thập tập tin '%s'"
 #: ../lib/cairodriver/graph.c:192
 #, c-format
 msgid "cairo: image size %dx%d"
-msgstr ""
+msgstr "cairo: kích thước ảnh %d x %d"
 #: ../lib/cairodriver/graph.c:371
-#, fuzzy
 msgid "Unknown Cairo surface type"
-msgstr "kiểu nội suy không hiểu"
+msgstr "Dạng bề mặt kiểu Cairo không rõ"
 #: ../lib/cairodriver/graph.c:376
-#, fuzzy
 msgid "Failed to initialize Cairo surface"
+msgstr "Thất bại khi khởi tạo bề mặt Cairo"
 #: ../lib/cairodriver/draw_bitmap.c:47
 msgid "Cairo_Bitmap: Failed to create source"
-msgstr ""
+msgstr "Bản đồ bitmap kiểu Cairo: Thất bại khi tạo nguồn"
 #: ../lib/python/gunittest/gmodules.py:103
 msgid "input='-' must be used when stdin is specified"
@@ -984,33 +933,31 @@
 msgstr ""
 #: ../lib/python/pygrass/raster/category.py:69
-#, fuzzy, python-brace-format
+#, python-brace-format
 msgid "Raster type: {0} not supported"
-msgstr "Kiểu đối tượng OGR %d không được hỗ trợ"
+msgstr ""
 #: ../lib/python/pygrass/raster/category.py:156
 msgid "Error executing: Rast_get_ith_cat"
 msgstr ""
 #: ../lib/python/pygrass/raster/category.py:184
-#, fuzzy
 msgid "Null value detected"
-msgstr "Tên của cột thuộc tính"
+msgstr ""
 #: ../lib/python/pygrass/raster/category.py:186
-#, fuzzy
 msgid "Error executing: Rast_set_cat"
-msgstr "Trục trặc khi đang đọc bản đồ raster"
+msgstr ""
 #: ../lib/python/pygrass/raster/abstract.py:275
 msgid "Mode type: {0} not supported ('r', 'w')"
+msgstr ""
 #: ../lib/python/pygrass/raster/abstract.py:286
 msgid "Overwrite type: {0} not supported (True/False)"
+msgstr ""
 #: ../lib/python/pygrass/raster/abstract.py:299
 #: ../lib/python/pygrass/vector/abstract.py:97
@@ -1023,14 +970,13 @@
 msgstr ""
 #: ../lib/python/pygrass/raster/__init__.py:214
 msgid "Raster map <{0}> already exists and will be not overwritten"
-msgstr "Bản đồ vec-tơ <%s> đã có và sẽ bị ghi đè"
+msgstr ""
 #: ../lib/python/pygrass/raster/__init__.py:218
-#, fuzzy
 msgid "Raster type not defined"
-msgstr "Đối tượng OGR không có ID bị bỏ qua"
+msgstr ""
 #: ../lib/python/pygrass/raster/__init__.py:321
@@ -1038,19 +984,19 @@
 msgstr ""
 #: ../lib/python/pygrass/raster/__init__.py:341
-#, fuzzy, python-format
+#, python-format
 msgid "Index out of range: %r."
-msgstr "Chỉ mục nằm ngoài miền trong"
+msgstr ""
 #: ../lib/python/pygrass/raster/__init__.py:530
 msgid "Raster map <{0}> already exists. Use overwrite."
+msgstr ""
 #: ../lib/python/pygrass/raster/__init__.py:561
 msgid "Raster map <{0}> does not exist"
+msgstr ""
 #: ../lib/python/pygrass/vector/table.py:1035
 #, python-format
@@ -1062,14 +1008,14 @@
 msgstr ""
 #: ../lib/python/pygrass/vector/__init__.py:806
+#, python-format
 msgid "Unable to read line of feature %i"
-msgstr "Không thể đọc đường %d"
+msgstr ""
 #: ../lib/python/pygrass/vector/__init__.py:895
+#, python-format
 msgid "Unable to read area with id %i"
-msgstr "Không thể ghi lại đối tượng %d"
+msgstr ""
 #: ../lib/python/pygrass/modules/grid/grid.py:553
 msgid "Execution of subprocesses was not successful"
@@ -1084,81 +1030,79 @@
 msgstr ""
 #: ../lib/python/temporal/temporal_raster_base_algebra.py:630
+#, python-format
 msgid "Error computing map <%s>"
-msgstr "Lỗi khi đang mở bản đồ g3d <%s>"
+msgstr ""
 #: ../lib/python/temporal/temporal_raster_base_algebra.py:717
 #: ../lib/python/temporal/temporal_algebra.py:2313
+#, python-format
 msgid "%s map <%s> not found in GRASS spatial database"
-msgstr "Không thể tìm thấy bản đồ vec-tơ <%s> trongg <%s>"
+msgstr ""
 #: ../lib/python/temporal/datetime_math.py:273
+#, python-format
 msgid "Wrong increment format: %s"
-msgstr "  định dạng: %s\n"
+msgstr ""
 #: ../lib/python/temporal/datetime_math.py:451
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1616
+#, python-format
 msgid "Wrong granularity format: %s"
+msgstr ""
 #: ../lib/python/temporal/datetime_math.py:729
 msgid "Time string seems to specify relative time"
 msgstr ""
 #: ../lib/python/temporal/datetime_math.py:741
-#, fuzzy
 msgid "Dates Before Christ (BC) are not supported"
-msgstr "cho định dạng/cấp này không được hỗ trợ"
+msgstr ""
 #: ../lib/python/temporal/datetime_math.py:745
-#, fuzzy
 msgid "Time zones are not supported"
+msgstr ""
 #: ../lib/python/temporal/datetime_math.py:755
+#, python-format
 msgid "Unable to parse time string: %s"
-msgstr "Không thể mở tập tin %s trong <%s>"
+msgstr ""
 #: ../lib/python/temporal/stds_import.py:85
+#, python-format
 msgid "Unable to import/link raster map <%s> from file %s."
+msgstr ""
 #: ../lib/python/temporal/stds_import.py:96
+#, python-format
 msgid "Unable to set the color rules for raster map <%s>."
+msgstr ""
 #: ../lib/python/temporal/stds_import.py:120
+#, python-format
 msgid "Unable to unpack raster map <%s> from file %s."
+msgstr ""
 #: ../lib/python/temporal/stds_import.py:144
+#, python-format
 msgid "Unable to import vector map <%s> from file %s."
-msgstr "Không thể tạo bản đồ vec-tơ <%s>"
+msgstr ""
 #: ../lib/python/temporal/stds_import.py:168
+#, python-format
 msgid "Unable to unpack vector map <%s> from file %s."
+msgstr ""
 #: ../lib/python/temporal/stds_import.py:207
+#, python-format
 msgid "Space time raster dataset archive <%s> not found"
-msgstr "Không tìm thấy bản đồ raster <%s>"
+msgstr ""
 #: ../lib/python/temporal/stds_import.py:210
+#, python-format
 msgid "Extraction directory <%s> not found"
+msgstr ""
 #: ../lib/python/temporal/stds_import.py:216
 #, python-format
@@ -1166,24 +1110,23 @@
 msgstr ""
 #: ../lib/python/temporal/stds_import.py:223
+#, python-format
 msgid "Unable to find init file <%s>"
+msgstr ""
 #: ../lib/python/temporal/stds_import.py:225
+#, python-format
 msgid "Unable to find list file <%s>"
+msgstr ""
 #: ../lib/python/temporal/stds_import.py:227
+#, python-format
 msgid "Unable to find projection file <%s>"
+msgstr ""
 #: ../lib/python/temporal/stds_import.py:229
-#, fuzzy
 msgid "Extracting data..."
-msgstr "Đang xây dựng các vùng..."
+msgstr ""
 #: ../lib/python/temporal/stds_import.py:269
 msgid "Projection information does not match. Proceeding..."
@@ -1201,19 +1144,19 @@
 msgstr ""
 #: ../lib/python/temporal/stds_import.py:293
+#, python-format
 msgid "Unable to create location %(l)s. Reason: %(e)s"
-msgstr "Không thể loại bỏ thư mục '%s'"
+msgstr ""
 #: ../lib/python/temporal/stds_import.py:301
+#, python-format
 msgid "Unable to switch to location %s"
+msgstr ""
 #: ../lib/python/temporal/stds_import.py:306
+#, python-format
 msgid "Unable to create default temporal database in new location %s"
+msgstr ""
 #: ../lib/python/temporal/stds_import.py:380
 #, python-format
@@ -1229,51 +1172,48 @@
 msgstr ""
 #: ../lib/python/temporal/stds_import.py:405
+#, python-format
 msgid "Unable to find GeoTIFF raster file <%s> in archive."
-msgstr "không thể tìm thấy một tập tin null tạm %s"
+msgstr ""
 #: ../lib/python/temporal/stds_import.py:411
+#, python-format
 msgid "Unable to find AAIGrid raster file <%s> in archive."
+msgstr ""
 #: ../lib/python/temporal/stds_import.py:417
+#, python-format
 msgid "Unable to find GML vector file <%s> in archive."
+msgstr ""
 #: ../lib/python/temporal/stds_import.py:426
+#, python-format
 msgid "Unable to find GRASS package file <%s> in archive."
-msgstr "Không thể mở tập tin cidx <%s> để ghi"
+msgstr ""
 #: ../lib/python/temporal/stds_import.py:429
-#, fuzzy
 msgid "Unsupported input format"
-msgstr "Kiểu đối tượng"
+msgstr ""
 #: ../lib/python/temporal/stds_import.py:435
-msgid ""
-"overwrite flag."
+#, python-format
+msgstr ""
 #: ../lib/python/temporal/stds_import.py:456
+#, python-format
 msgid "Overwrite space time %(sp)s dataset <%(id)s> and unregister all maps."
-msgstr "Không thể tạo ra tập tin header cho [%s]"
+msgstr ""
 #: ../lib/python/temporal/stds_import.py:468
+#, python-format
 msgid "Key word %s not found in init file."
+msgstr ""
 #: ../lib/python/temporal/stds_import.py:473
+#, python-format
 msgid "Create space time %s dataset."
+msgstr ""
 #: ../lib/python/temporal/stds_import.py:502
 msgid "Switching to original location failed"
@@ -1281,59 +1221,55 @@
 #: ../lib/python/temporal/temporal_vector_algebra.py:386
 #, python-format
-msgid ""
-"Error vector maps with basename %s exist. Use --o flag to overwrite existing "
-"file"
 msgstr ""
 #: ../lib/python/temporal/temporal_vector_algebra.py:419
+#, python-format
 msgid ""
 "Error starting %s : \n"
 "%s"
-msgstr "Lỗi khi đang ghi vào tập tin tôpô"
+msgstr ""
 #: ../lib/python/temporal/temporal_vector_algebra.py:492
+#, python-format
 msgid ""
 "Error vector map %s exist in temporal database. Use overwrite flag.  : \n"
 "%s"
+msgstr ""
 #: ../lib/python/temporal/core.py:604
-msgid ""
 msgstr ""
 #: ../lib/python/temporal/core.py:667
+#, python-format
 msgid ""
 "Unable to receive temporal database metadata.\n"
 "Current temporal database info:%(info)s"
+msgstr ""
 #: ../lib/python/temporal/core.py:672
+#, python-format
 msgid ""
 "Unsupported temporal database: version mismatch.\n"
 " %(backup)s Supported temporal API version is: %(api)i.\n"
 "Please update your GRASS GIS installation.\n"
+msgstr ""
 #: ../lib/python/temporal/core.py:680
+#, python-format
 msgid ""
 " %(backup)sSupported temporal database version is: %(tdb)i\n"
+msgstr ""
 #: ../lib/python/temporal/core.py:768
+#, python-format
 msgid "Creating temporal database: %s"
-msgstr "Không thể mở CSDL"
+msgstr ""
 #: ../lib/python/temporal/core.py:777
 #, python-format
@@ -1344,34 +1280,28 @@
 msgstr ""
 #: ../lib/python/temporal/core.py:942
-#, fuzzy
 msgid "Unable to mogrify sql statement. "
+msgstr ""
 #: ../lib/python/temporal/core.py:964
-#, fuzzy
 msgid "Unable to check table. "
-msgstr "Không thể tạo bảng <%s>"
+msgstr ""
 #: ../lib/python/temporal/core.py:980
-#, fuzzy
 msgid "Unable to execute sql statement. "
-msgstr "Không thể thực thi lệnh"
+msgstr ""
 #: ../lib/python/temporal/core.py:990
-#, fuzzy
 msgid "Unable to fetch one. "
+msgstr ""
 #: ../lib/python/temporal/core.py:1000
-#, fuzzy
 msgid "Unable to fetch all. "
+msgstr ""
 #: ../lib/python/temporal/core.py:1017
-#, fuzzy
 msgid "Unable to execute transaction. "
+msgstr ""
 #: ../lib/python/temporal/core.py:1120
 #, python-format
@@ -1382,50 +1312,48 @@
 msgstr ""
 #: ../lib/python/temporal/core.py:1277
+#, python-format
 msgid ""
 "Unable to execute :\n"
 " %(sql)s"
+msgstr ""
 #: ../lib/python/temporal/core.py:1321
+#, python-format
 msgid ""
 "Unable to execute transaction:\n"
 " %(sql)s"
+msgstr ""
 #: ../lib/python/temporal/univar_statistics.py:62
 #: ../lib/python/temporal/univar_statistics.py:178
+#, python-format
 msgid "Space time %(sp)s dataset <%(i)s> is empty"
+msgstr ""
 #: ../lib/python/temporal/univar_statistics.py:101
+#, python-format
 msgid "Unable to get statistics for raster map <%s>"
-msgstr "Không thể đọc tập tin header cho bản đồ raster <%s@%s>."
+msgstr ""
 #: ../lib/python/temporal/univar_statistics.py:104
+#, python-format
 msgid "Unable to get statistics for 3d raster map <%s>"
+msgstr ""
 #: ../lib/python/temporal/univar_statistics.py:168
+#, python-format
 msgid "Space time %(sp)s dataset <%(i)s> not found"
+msgstr ""
 #: ../lib/python/temporal/univar_statistics.py:222
+#, python-format
 msgid "Unable to get statistics for vector map <%s>"
+msgstr ""
 #: ../lib/python/temporal/abstract_dataset.py:386
 #, python-format
-msgid ""
-"Unable to insert dataset <%(ds)s> of type %(type)s in the temporal database. "
 msgstr ""
 #: ../lib/python/temporal/abstract_dataset.py:426
@@ -1434,15 +1362,11 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:424
 #: ../lib/python/temporal/abstract_map_dataset.py:520
 #, python-format
-msgid ""
-"Unable to update dataset <%(ds)s> of type %(type)s in the temporal database. "
 msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:810
-msgid ""
-"algebra mode"
 msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:848
@@ -1450,50 +1374,40 @@
 msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:857
-#, fuzzy
 msgid "All input space time datasets must have the same temporal type."
+msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:1105
+#, python-format
 msgid "Removing un-needed or empty %s maps"
-msgstr "Tên của bản đồ raster đầu vào"
+msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:1160
+#, python-format
 msgid "Space time %s dataset <%s> not found"
+msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:1188
 #: ../lib/python/temporal/temporal_algebra.py:1192
 #, python-format
-msgid ""
-"Wrong temporal type of space time dataset <"
-"%s>                                       <%s> time is required"
 msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:1212
-#, fuzzy
 msgid "Wrong type of input "
-msgstr "Không thể đóng bản đồ đầu vào"
+msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:2104
 #, python-format
-msgid ""
 msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:2110
-msgid ""
-"different types."
 msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:2319
-msgid ""
 msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:2347
@@ -1509,9 +1423,8 @@
 msgstr ""
 #: ../lib/python/temporal/temporal_algebra.py:2361
-#, fuzzy
 msgid "Space time datasets to merge must have the same temporal type"
+msgstr ""
 #: ../lib/python/temporal/register.py:82 ../lib/python/temporal/register.py:85
 #, python-format
@@ -1532,29 +1445,22 @@
 msgstr ""
 #: ../lib/python/temporal/register.py:99
+#, python-format
 msgid "Please specify %s= and %s="
 msgstr ""
-"\n"
-"Vui lòng chỉ định tên mốc tọa độ chuẩn\n"
 #: ../lib/python/temporal/register.py:103
+#, python-format
 msgid "Please specify %s= or %s="
 msgstr ""
-"\n"
-"Vui lòng chỉ định tên ellipsoid\n"
 #: ../lib/python/temporal/register.py:114
 #, python-format
-msgid ""
 msgstr ""
 #: ../lib/python/temporal/register.py:175
-msgid ""
 msgstr ""
 #: ../lib/python/temporal/register.py:179
@@ -1566,23 +1472,19 @@
 msgstr ""
 #: ../lib/python/temporal/register.py:197
+#, python-format
 msgid "Unable to update %(t)s map <%(id)s>. The map does not exist."
+msgstr ""
-msgid ""
+#, python-format
+msgstr ""
 #: ../lib/python/temporal/register.py:221
-msgid ""
+#, python-format
+msgstr ""
 #: ../lib/python/temporal/register.py:229
 #, python-format
@@ -1595,45 +1497,36 @@
 msgstr ""
 #: ../lib/python/temporal/register.py:245
-msgid ""
-"Map is already registered in temporal database. Unable to update %(t)s map <"
-"%(id)s> with layer %(l)s. Overwrite flag is not set."
+#, python-format
+msgstr ""
 #: ../lib/python/temporal/register.py:252
-msgid ""
-"%(id)s>. Overwrite flag is not set."
+#, python-format
+msgstr ""
-msgid ""
-"Unable to update %(t)s map <%(id)s> with layer %(l)s. The temporal types are "
-"different."
+#, python-format
+msgstr ""
 #: ../lib/python/temporal/register.py:282
+#, python-format
 msgid "Unable to update %(t)s map <%(id)s>. The temporal types are different."
+msgstr ""
 #: ../lib/python/temporal/register.py:330
-#, fuzzy
 msgid "Registering maps in the temporal database..."
+msgstr ""
 #: ../lib/python/temporal/register.py:337
-#, fuzzy
 msgid "Registering maps in the space time dataset..."
+msgstr ""
 #: ../lib/python/temporal/register.py:346
-#, fuzzy
 msgid "Updating space time dataset..."
-msgstr "Tên của bản đồ raster độ cao"
+msgstr ""
 #: ../lib/python/temporal/register.py:399
 #: ../lib/python/temporal/register.py:406
@@ -1643,32 +1536,28 @@
 #: ../lib/python/temporal/register.py:414
 #: ../lib/python/temporal/register.py:419
-#, fuzzy
 msgid "Error occurred in increment computation"
+msgstr ""
 #: ../lib/python/temporal/register.py:422
-msgid ""
-"Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - "
-"%(end)s"
+#, python-format
+msgstr ""
 #: ../lib/python/temporal/register.py:427
+#, python-format
 msgid "Set absolute valid time for map <%s> to %s - %s"
+msgstr ""
 #: ../lib/python/temporal/register.py:444
-msgid ""
+#, python-format
+msgstr ""
 #: ../lib/python/temporal/register.py:449
+#, python-format
 msgid "Set relative valid time for map <%s> to %i - %s with unit %s"
+msgstr ""
 #: ../lib/python/temporal/mapcalc.py:109
 msgid "Starting spatio-temporal sampling..."
@@ -1683,16 +1572,12 @@
 msgstr ""
 #: ../lib/python/temporal/mapcalc.py:155
-msgid ""
-"Found more than a single map in a sample granule. Only the first map is used "
-"for computation. Use t.rast.aggregate.ds to create synchronous raster "
-"datasets."
+msgid "Found more than a single map in a sample granule. Only the first map is used for computation. Use t.rast.aggregate.ds to create synchronous raster datasets."
 msgstr ""
 #: ../lib/python/temporal/mapcalc.py:173
-#, fuzzy
 msgid "No maps registered in input dataset"
+msgstr ""
 #: ../lib/python/temporal/mapcalc.py:189
 msgid "Starting mapcalc computation..."
@@ -1701,10 +1586,9 @@
 #: ../lib/python/temporal/mapcalc.py:240
 #: ../lib/python/temporal/open_stds.py:211
 #: ../lib/python/temporal/extract.py:131
-msgid ""
-"Map <%s> is already in temporal database, use overwrite flag to overwrite"
+#, python-format
+msgid "Map <%s> is already in temporal database, use overwrite flag to overwrite"
+msgstr ""
 #: ../lib/python/temporal/mapcalc.py:260
 #, python-format
@@ -1716,9 +1600,8 @@
 msgstr ""
 #: ../lib/python/temporal/mapcalc.py:285
-#, fuzzy
 msgid "Starting map registration in temporal database..."
+msgstr ""
 #: ../lib/python/temporal/mapcalc.py:442 ../lib/python/temporal/mapcalc.py:448
 #: ../lib/python/temporal/mapcalc.py:454 ../lib/python/temporal/mapcalc.py:460
@@ -1742,15 +1625,14 @@
 msgstr ""
 #: ../lib/python/temporal/factory.py:51
+#, python-format
 msgid "Unknown dataset type: %s"
-msgstr "Kiểu vec-tơ không biết."
+msgstr ""
-#: ../lib/python/temporal/sampling.py:95
-#: ../lib/python/temporal/sampling.py:100
+#: ../lib/python/temporal/sampling.py:95 ../lib/python/temporal/sampling.py:100
+#, python-format
 msgid "Dataset <%s> not found in temporal database"
+msgstr ""
 #: ../lib/python/temporal/gui_support.py:58 ../lib/python/script/core.py:1233
 #, python-format
@@ -1758,25 +1640,19 @@
 msgstr ""
 #: ../lib/python/temporal/spatial_extent.py:123
-msgid ""
-"extents"
 msgstr ""
 #: ../lib/python/temporal/spatial_extent.py:529
-msgid ""
 msgstr ""
 #: ../lib/python/temporal/spatial_extent.py:661
-msgid ""
-"extents"
 msgstr ""
 #: ../lib/python/temporal/spatial_extent.py:766
-msgid ""
 msgstr ""
 #: ../lib/python/temporal/spatial_extent.py:838
@@ -1792,91 +1668,87 @@
 msgstr ""
 #: ../lib/python/temporal/space_time_datasets.py:250
+#, python-format
 msgid "Unable to read timestamp file for raster map <%s>"
+msgstr ""
 #: ../lib/python/temporal/space_time_datasets.py:274
+#, python-format
 msgid "Unable to create timestamp file for raster map <%s>"
+msgstr ""
 #: ../lib/python/temporal/space_time_datasets.py:279
+#, python-format
 msgid "Invalid datetime in timestamp for raster map <%s>"
 msgstr ""
-"Tập tin đánh dấu thời gian không hợp lệ cho %s bản đồ %s trong bộ bản đồ %s"
 #: ../lib/python/temporal/space_time_datasets.py:284
 #: ../lib/python/temporal/space_time_datasets.py:632
-#, fuzzy
 msgid "Internal error"
-msgstr "lỗi cú pháp"
+msgstr ""
 #: ../lib/python/temporal/space_time_datasets.py:301
 #: ../lib/python/temporal/space_time_datasets.py:646
+#, python-format
 msgid "Unable to remove timestamp for raster map <%s>"
+msgstr ""
 #: ../lib/python/temporal/space_time_datasets.py:598
+#, python-format
 msgid "Unable to read timestamp file for 3D raster map <%s>"
+msgstr ""
 #: ../lib/python/temporal/space_time_datasets.py:622
+#, python-format
 msgid "Unable to create timestamp file for 3D raster map <%s>"
+msgstr ""
 #: ../lib/python/temporal/space_time_datasets.py:627
+#, python-format
 msgid "Invalid datetime in timestamp for 3D raster map <%s>"
 msgstr ""
 #: ../lib/python/temporal/space_time_datasets.py:906
+#, python-format
 msgid "Unable to read timestamp file for vector map <%s>"
+msgstr ""
 #: ../lib/python/temporal/space_time_datasets.py:929
+#, python-format
 msgid "Unable to create timestamp file for vector map <%s>"
+msgstr ""
 #: ../lib/python/temporal/space_time_datasets.py:934
+#, python-format
 msgid "Invalid datetime in timestamp for vector map <%s>"
 msgstr ""
 #: ../lib/python/temporal/space_time_datasets.py:950
+#, python-format
 msgid "Unable to remove timestamp for vector map <%s>"
+msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:167
 #: ../lib/python/temporal/abstract_space_time_dataset.py:301
+#, python-format
 msgid "Unknown temporal type \"%s\""
+msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:294
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1062
+#, python-format
 msgid "Wrong granularity: \"%s\""
+msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:322
+#, python-format
 msgid "Unsupported temporal unit: %s"
+msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:372
+#, python-format
 msgid "Created register table <%s> for space time %s  dataset <%s>"
-msgstr "Không thể ghi các quy tắc lượng tử cho bản đồ %s"
+msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:690
 #: ../lib/python/temporal/abstract_space_time_dataset.py:932
@@ -1889,29 +1761,23 @@
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1499
+#, python-format
 msgid "Unable to get map ids from register table <%s>"
-msgstr "Không thể lấy dữ liệu từ bảng <%s>"
+msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1609
 #, python-format
-msgid ""
-"Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database. "
-"The mapset of the dataset does not match the current mapset"
+msgid "Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1778
 #, python-format
-msgid ""
-"Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database. "
+msgid "Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1880
 #, python-format
-msgid ""
-"Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database. "
+msgid "Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1889
@@ -1919,39 +1785,32 @@
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1954
+#, python-format
 msgid "Delete space time %s  dataset <%s> from temporal database"
+msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1960
 #: ../lib/python/temporal/abstract_map_dataset.py:841
 #, python-format
-msgid ""
-"Unable to delete dataset <%(ds)s> of type %(type)s from the temporal "
-"database. The mapset of the dataset does not match the current mapset"
+msgid "Unable to delete dataset <%(ds)s> of type %(type)s from the temporal database. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1973
+#, python-format
 msgid "Drop map register table: %s"
+msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2028
-#, fuzzy
 msgid "Error in register table request"
+msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2057
-msgid ""
-"Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of "
-"the dataset does not match the current mapset"
+#, python-format
+msgid "Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of the dataset does not match the current mapset"
+msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2066
-msgid ""
-"Only a map that was inserted in the temporal database can be registered in a "
-"space time dataset"
+msgid "Only a map that was inserted in the temporal database can be registered in a space time dataset"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2089
@@ -1965,35 +1824,28 @@
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2111
-msgid ""
-"Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer "
-"%(l)s are different"
+#, python-format
+msgid "Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer %(l)s are different"
+msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2117
-msgid ""
-"Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
+#, python-format
+msgid "Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
+msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2132
+#, python-format
 msgid "Set temporal unit for space time %s dataset <%s> to %s"
+msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2142
 #, python-format
-msgid ""
-"Relative time units of space time dataset <%(id)s> and map <%(map)s> with "
-"layer %(l)s are different"
+msgid "Relative time units of space time dataset <%(id)s> and map <%(map)s> with layer %(l)s are different"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2148
 #, python-format
-msgid ""
-"Relative time units of space time dataset <%(id)s> and map <%(map)s> are "
-"different"
+msgid "Relative time units of space time dataset <%(id)s> and map <%(map)s> are different"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2154
@@ -2001,9 +1853,9 @@
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2159
+#, python-format
 msgid "Map <%(map)s> with layer %(l)s is already registered."
+msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2163
 #, python-format
@@ -2012,101 +1864,78 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2211
 #, python-format
-msgid ""
-"Unable to unregister map from dataset <%(ds)s> of type %(type)s in the "
-"temporal database. The mapset of the dataset does not match the current "
-"mapset"
+msgid "Unable to unregister map from dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2224
-msgid ""
-"Map <%(map)s> with layer %(l)s is not registered in space time dataset <"
-"%(base)s>"
+#, python-format
+msgid "Map <%(map)s> with layer %(l)s is not registered in space time dataset <%(base)s>"
+msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2230
+#, python-format
 msgid "Map <%(map)s> is not registered in space time dataset <%(base)s>"
+msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2291
 #, python-format
-msgid ""
-"Update metadata, spatial and temporal extent from all registered maps of <%s>"
+msgid "Update metadata, spatial and temporal extent from all registered maps of <%s>"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:350
-msgid ""
-"Start time must be of type datetime for %(type)s map <%(id)s> with layer: "
-"%(l)s"
+#, python-format
+msgid "Start time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
 msgstr ""
-"Không thể tạo tập tin đánh dấu thời gian cho %s bản đồ %s trong bộ bản đồ %s"
 #: ../lib/python/temporal/abstract_map_dataset.py:357
+#, python-format
 msgid "Start time must be of type datetime for %(type)s map <%(id)s>"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:365
-msgid ""
-"End time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
+#, python-format
+msgid "End time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:372
+#, python-format
 msgid "End time must be of type datetime for %(type)s map <%(id)s>"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:381
-msgid ""
-"End time must be greater than start time for %(type)s map <%(id)s> with "
-"layer: %(l)s"
-msgstr "Cận Đông phải lớn hơn cận Tây"
+#, python-format
+msgid "End time must be greater than start time for %(type)s map <%(id)s> with layer: %(l)s"
+msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:389
 #: ../lib/python/temporal/abstract_map_dataset.py:482
+#, python-format
 msgid "End time must be greater than start time for %(type)s map <%(id)s>"
+msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:460
-msgid ""
-"Unsupported relative time unit type for %(type)s map <%(id)s> with layer "
-"%(l)s: %(u)s"
+#, python-format
+msgid "Unsupported relative time unit type for %(type)s map <%(id)s> with layer %(l)s: %(u)s"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:467
+#, python-format
 msgid "Unsupported relative time unit type for %(type)s map <%(id)s>: %(u)s"
+msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:476
-msgid ""
-"End time must be greater than start time for %(typ)s map <%(id)s> with layer "
-"%(l)s"
+#, python-format
+msgid "End time must be greater than start time for %(typ)s map <%(id)s> with layer %(l)s"
+msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:800
 #, python-format
-msgid ""
-"Map <%(id)s> with layer %(layer)s has incorrect time interval, start time is "
-"greater than end time"
+msgid "Map <%(id)s> with layer %(layer)s has incorrect time interval, start time is greater than end time"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:806
 #, python-format
-msgid ""
-"Map <%s> has incorrect time interval, start time is greater than end time"
+msgid "Map <%s> has incorrect time interval, start time is greater than end time"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:812
@@ -2115,46 +1944,44 @@
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:859
+#, python-format
 msgid "Delete %s dataset <%s> from temporal database"
+msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:909
 #, python-format
-msgid ""
-"Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal "
+msgid "Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal database. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/stds_export.py:104
+#, python-format
 msgid "Unable to export raster map <%s>"
+msgstr ""
 #: ../lib/python/temporal/stds_export.py:115
+#, python-format
 msgid "Unable to export color rules for raster map <%s> r.out.gdal"
+msgstr ""
 #: ../lib/python/temporal/stds_export.py:139
+#, python-format
 msgid "Unable to export raster map <%s> with r.pack"
+msgstr ""
 #: ../lib/python/temporal/stds_export.py:167
+#, python-format
 msgid "Unable to export vector map <%s> as GML with v.out.ogr"
+msgstr ""
 #: ../lib/python/temporal/stds_export.py:200
+#, python-format
 msgid "Unable to export vector map <%s> with v.pack"
-msgstr "Không thể xoá bản đồ vec-tơ <%s>"
+msgstr ""
 #: ../lib/python/temporal/stds_export.py:226
+#, python-format
 msgid "Unable to export raster map <%s> with r3.pack"
+msgstr ""
 #: ../lib/python/temporal/base.py:380
 #, fuzzy
@@ -2166,21 +1993,18 @@
 msgstr ""
 #: ../lib/python/temporal/base.py:621
-#, fuzzy
 msgid "Wrong identifier, the mapset is missing"
-msgstr "Không thể mở tập tin header của bản đồ raster <%s@%s>"
+msgstr ""
 #: ../lib/python/temporal/aggregation.py:127
+#, python-format
 msgid "Aggregating %s raster maps"
-msgstr "Tên của bản đồ raster gốc"
+msgstr ""
 #: ../lib/python/temporal/aggregation.py:141
-msgid ""
-"Raster map <%(name)s> is already in temporal database, use overwrite flag to "
-"overwrite"
+#, python-format
+msgid "Raster map <%(name)s> is already in temporal database, use overwrite flag to overwrite"
+msgstr ""
 #: ../lib/python/temporal/aggregation.py:146
 #, python-format
@@ -2188,62 +2012,53 @@
 msgstr ""
 #: ../lib/python/temporal/aggregation.py:171
-#, fuzzy
 msgid "Error occurred in r.series computation"
+msgstr ""
 #: ../lib/python/temporal/aggregation.py:280
+#, python-format
 msgid "Aggregating %(len)i raster maps from %(start)s to %(end)s"
+msgstr ""
 #: ../lib/python/temporal/aggregation.py:301
 #, python-format
-msgid ""
-"Unable to perform aggregation. Output raster map <%(name)s> exists and "
-"overwrite flag was not set"
+msgid "Unable to perform aggregation. Output raster map <%(name)s> exists and overwrite flag was not set"
 msgstr ""
 #: ../lib/python/temporal/aggregation.py:319
 #, python-format
-msgid ""
-"The limit of open files (%i) was reached (%i). The module r.series will be "
-"run with flag z, to avoid open files limit exceeding."
+msgid "The limit of open files (%i) was reached (%i). The module r.series will be run with flag z, to avoid open files limit exceeding."
 msgstr ""
 #: ../lib/python/temporal/open_stds.py:63
 #: ../lib/python/temporal/open_stds.py:119
+#, python-format
 msgid "Unknown type: %s"
+msgstr ""
 #: ../lib/python/temporal/open_stds.py:69
+#, python-format
 msgid "Space time %(sp)s dataset <%(name)s> not found"
+msgstr ""
 #: ../lib/python/temporal/open_stds.py:108
-#, fuzzy
 msgid "Space time datasets can only be created in the current mapset"
+msgstr ""
 #: ../lib/python/temporal/open_stds.py:125
-msgid ""
-"Space time %(sp)s dataset <%(name)s> is already in the database. Use the "
-"overwrite flag."
+#, python-format
+msgid "Space time %(sp)s dataset <%(name)s> is already in the database. Use the overwrite flag."
+msgstr ""
 #: ../lib/python/temporal/open_stds.py:160
-msgid ""
-"Overwriting space time %(sp)s dataset <%(name)s> and unregistering all maps"
+#, python-format
+msgid "Overwriting space time %(sp)s dataset <%(name)s> and unregistering all maps"
+msgstr ""
 #: ../lib/python/temporal/open_stds.py:168
+#, python-format
 msgid "Creating a new space time %s dataset"
+msgstr ""
 #: ../lib/python/temporal/extract.py:60
 msgid "You need to specify the base name of new created maps"
@@ -2265,20 +2080,18 @@
 msgstr ""
 #: ../lib/python/temporal/extract.py:176
-#, fuzzy
 msgid "Error in computation process"
+msgstr ""
 #: ../lib/python/temporal/c_libraries_interface.py:596
 #: ../lib/python/temporal/c_libraries_interface.py:613
-#, fuzzy
 msgid "Unable to read range file"
-msgstr "Không thể đọc tập tin đề mục"
+msgstr ""
 #: ../lib/python/temporal/c_libraries_interface.py:691
+#, python-format
 msgid "Unable to load range of 3D raster map <%s>"
+msgstr ""
 #: ../lib/python/script/raster3d.py:92
 #, python-format
@@ -2291,10 +2104,7 @@
 #: ../lib/python/script/core.py:304
 #, python-format
-msgid ""
-"To run the module <%s> add underscore at the end of the option <%s> to avoid "
-"conflict with Python keywords. Underscore at the beginning is depreciated in "
-"GRASS GIS 7.0 and will be removed in version 7.1."
+msgid "To run the module <%s> add underscore at the end of the option <%s> to avoid conflict with Python keywords. Underscore at the beginning is depreciated in GRASS GIS 7.0 and will be removed in version 7.1."
 msgstr ""
 #: ../lib/python/script/core.py:928
@@ -2312,9 +2122,8 @@
 msgstr ""
 #: ../lib/python/script/core.py:1372
-#, fuzzy
 msgid "Unable to list mapsets"
+msgstr ""
 #: ../lib/python/script/core.py:1411
 #, python-format
@@ -2322,9 +2131,9 @@
 msgstr ""
 #: ../lib/python/script/core.py:1414
+#, python-format
 msgid "Location <%s> already exists and will be overwritten"
+msgstr ""
 #: ../lib/python/script/core.py:1538
 msgid "Debug level {}"
@@ -2335,24 +2144,24 @@
 msgstr ""
 #: ../lib/python/script/core.py:1557
+#, python-format
 msgid "Illegal filename <%s>. Cannot be 'NULL' or start with '.'."
-msgstr "Tên tập tin không hợp lệ. Không thể là '.' hay 'NULL'\n"
+msgstr ""
 #: ../lib/python/script/core.py:1566
+#, python-format
 msgid "Illegal filename <%(s)s>. <%(il)s> not allowed.\n"
-msgstr "Tên tập tin không hợp lệ. Ký tự <%c> không được phép.\n"
+msgstr ""
 #: ../lib/python/script/vector.py:88
+#, python-format
 msgid "Database connection not defined for layer %s"
+msgstr ""
 #: ../lib/python/script/vector.py:228
+#, python-format
 msgid "Missing layer %(layer)d in vector map <%(map)s>"
-msgstr "Lỗi khi đang nạp bản đồ vec-tơ <%s>"
+msgstr ""
 #: ../lib/python/script/vector.py:243
 msgid "vector_db_select() failed"
@@ -2371,13 +2180,9 @@
 msgstr ""
 #: ../lib/python/script/raster.py:54
-msgid ""
-"Unable to write history for <%(map)s>. Raster map <%(map)s> not found in "
-"current mapset."
+#, python-format
+msgid "Unable to write history for <%(map)s>. Raster map <%(map)s> not found in current mapset."
 msgstr ""
-"Không thể phục hồi lại đối tượng %d, bản đồ vec-tơ <%s> không được mở ở chế "
-"độ 'write' (ghi)"
 #: ../lib/python/script/raster.py:113
 #, python-format
@@ -2385,9 +2190,8 @@
 msgstr ""
 #: ../lib/python/script/raster.py:192
-#, fuzzy
 msgid "No data"
-msgstr "Tên của bản đồ vec-tơ đầu vào"
+msgstr ""
 #: ../lib/python/script/raster.py:200
 msgid "value"
@@ -2398,9 +2202,8 @@
 msgstr ""
-#, fuzzy
 msgid "color"
-msgstr "Màu"
+msgstr ""
 #: ../lib/python/script/db.py:45 ../lib/db/dbmi_client/column.c:136
 #: ../lib/vector/Vlib/write_pg.c:666 ../lib/vector/Vlib/ascii.c:428
@@ -2410,54 +2213,47 @@
 #: ../lib/python/script/db.py:153
 #, python-format
-msgid ""
-"Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
+msgid "Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
 msgstr ""
 #: ../lib/python/script/db.py:163
-#, fuzzy
 msgid "Fetching data failed"
+msgstr ""
 #: ../lib/python/script/array.py:157 ../lib/python/script/array.py:207
 #: ../lib/python/script/array.py:254 ../lib/python/script/array.py:305
 #: ../lib/python/script/array.py:356 ../lib/python/script/array.py:398
+#, python-format
 msgid "Invalid kind <%s>"
+msgstr ""
 #: ../lib/python/script/array.py:160 ../lib/python/script/array.py:210
 #: ../lib/python/script/array.py:308 ../lib/python/script/array.py:359
+#, python-format
 msgid "Invalid size <%d>"
+msgstr ""
 #: ../lib/python/script/array.py:197
-msgid ""
-"grass.script.array.read is deprecated and does not work on MS Windows, pass "
-"raster name in the constructor"
+msgid "grass.script.array.read is deprecated and does not work on MS Windows, pass raster name in the constructor"
 msgstr ""
 #: ../lib/python/script/array.py:247 ../lib/python/script/array.py:392
+#, python-format
 msgid "Invalid FP size <%d>"
-msgstr "không thể đổi thư mục đến %s"
+msgstr ""
 #: ../lib/python/script/array.py:251 ../lib/python/script/array.py:395
+#, python-format
 msgid "Invalid integer size <%d>"
+msgstr ""
 #: ../lib/python/script/array.py:346
-msgid ""
-"grass.script.array3d.read is deprecated and does not work on MS Windows, "
-"pass 3D raster name in the constructor"
+msgid "grass.script.array3d.read is deprecated and does not work on MS Windows, pass 3D raster name in the constructor"
 msgstr ""
 #: ../lib/python/script/task.py:62
-#, fuzzy
 msgid "unknown"
-msgstr "không biết"
+msgstr ""
 #: ../lib/python/script/task.py:176
 #, python-format
@@ -2465,9 +2261,9 @@
 msgstr ""
 #: ../lib/python/script/task.py:191
+#, python-format
 msgid "Flag not found: %s"
-msgstr "không tìm thấy %s"
+msgstr ""
 #: ../lib/python/script/task.py:210
 #, python-format
@@ -2475,9 +2271,8 @@
 msgstr ""
 #: ../lib/python/script/task.py:243
-#, fuzzy
 msgid "<required>"
-msgstr "cần có: %s\n"
+msgstr ""
 #: ../lib/python/script/task.py:503 ../lib/python/script/task.py:507
 #, python-format
@@ -2505,13 +2300,11 @@
 msgstr ""
 #: ../lib/python/exceptions/__init__.py:71
+#, python-format
 msgid ""
 ". See the following errors:\n"
 "%s"
 msgstr ""
-"\n"
-"CỜ: Thiết lập cờ sau?\n"
 #: ../lib/python/exceptions/__init__.py:75
 msgid ". See errors in the (error) output."
@@ -2520,59 +2313,59 @@
 #: ../lib/driver/parse_ftcap.c:84
 #, c-format
 msgid "%s: Unable to read font definition file; use the default"
-msgstr "%s: Không thể đọc tập tin định nghĩa phông; dùng mặc định"
+msgstr ""
 #: ../lib/driver/parse_ftcap.c:90
 #, c-format
 msgid "%s: No font definition file"
-msgstr "%s: Không có tập tin định nghĩa phông"
+msgstr ""
 #: ../lib/gmath/solvers_krylov.c:254 ../lib/gmath/solvers_krylov.c:482
 #: ../lib/gmath/solvers_krylov.c:646 ../lib/gmath/solvers_direct.c:134
 msgid "Unable to solve the linear equation system"
-msgstr "Không thể giải hệ phương trình tuyến tính"
+msgstr ""
 #: ../lib/gmath/solvers_krylov.c:262
 #, c-format
 msgid "Sparse PCG -- iteration %i error  %g\n"
-msgstr "PCG thưa -- lần lặp %i lỗi %g\n"
+msgstr ""
 #: ../lib/gmath/solvers_krylov.c:264
 #, c-format
 msgid "PCG -- iteration %i error  %g\n"
-msgstr "PCG -- lần lặp %i lỗi %g\n"
+msgstr ""
 #: ../lib/gmath/solvers_krylov.c:490
 #, c-format
 msgid "Sparse CG -- iteration %i error  %g\n"
-msgstr "CG thưa -- lần lặp %i lỗi %g\n"
+msgstr ""
 #: ../lib/gmath/solvers_krylov.c:492
 #, c-format
 msgid "CG -- iteration %i error  %g\n"
-msgstr "CG -- lần lặp %i lỗi %g\n"
+msgstr ""
 #: ../lib/gmath/solvers_krylov.c:695
 #, c-format
 msgid "Sparse BiCGStab -- iteration %i error  %g\n"
-msgstr "BiCGStab thưa -- lần lặp %i lỗi %g\n"
+msgstr ""
 #: ../lib/gmath/solvers_krylov.c:698
 #, c-format
 msgid "BiCGStab -- iteration %i error  %g\n"
-msgstr "BiCGStab -- lần lặp %i lỗi %g\n"
+msgstr ""
 #: ../lib/gmath/solvers_direct.c:45
 msgid "Starting direct gauss elimination solver"
-msgstr "Đang bắt đầu bộ giải phép khử Gauss trực tiếp"
+msgstr ""
 #: ../lib/gmath/solvers_direct.c:73
 msgid "Starting direct lu decomposition solver"
-msgstr "Đang bắt đầu bộ giải khai triển lu trực tiếp"
+msgstr ""
 #: ../lib/gmath/solvers_direct.c:131
 msgid "Starting cholesky decomposition solver"
-msgstr "Đang bắt đầu bộ giải khai triển Cholesky"
+msgstr ""
 #: ../lib/gmath/solvers_direct_cholesky_band.c:33
 #, c-format
@@ -2580,145 +2373,103 @@
 msgstr ""
 #: ../lib/gmath/test/bench_blas2.c:35
-#, fuzzy
 msgid ""
 "\n"
 "++ Running blas level 2 benchmark ++"
 msgstr ""
-"\n"
++ Đang chạy các phép thử đơn vị bộ giải ++"
 #: ../lib/gmath/test/test_blas3.c:38
-#, fuzzy
 msgid ""
 "\n"
 "++ Running blas level 3 unit tests ++"
 msgstr ""
-"\n"
 #: ../lib/gmath/test/test_blas3.c:44
-#, fuzzy
 msgid ""
 "\n"
 "-- blas level 3 unit tests failure --"
 msgstr ""
-"\n"
-- Các thép thử đơn vị bộ giải thất bại --"
 #: ../lib/gmath/test/test_blas3.c:46
-#, fuzzy
 msgid ""
 "\n"
 "-- blas level 3 unit tests finished successfully --"
 msgstr ""
-"\n"
-- Các thép thử đơn vị bộ giải kết thúc thành công --"
 #: ../lib/gmath/test/test_solvers.c:37
 msgid ""
 "\n"
 "++ Running solver unit tests ++"
 msgstr ""
-"\n"
 #: ../lib/gmath/test/test_solvers.c:42
 msgid ""
 "\n"
 "-- Solver unit tests failure --"
 msgstr ""
-"\n"
 #: ../lib/gmath/test/test_solvers.c:44
 msgid ""
 "\n"
 "-- Solver unit tests finished successfully --"
 msgstr ""
-"\n"
 #: ../lib/gmath/test/test_blas1.c:40
-#, fuzzy
 msgid ""
 "\n"
 "++ Running blas level 1 unit tests ++"
 msgstr ""
-"\n"
 #: ../lib/gmath/test/test_blas1.c:47
-#, fuzzy
 msgid ""
 "\n"
 "-- blas level 1 unit tests failure --"
 msgstr ""
-"\n"
 #: ../lib/gmath/test/test_blas1.c:49
-#, fuzzy
 msgid ""
 "\n"
 "-- blas level 1 unit tests finished successfully --"
 msgstr ""
-"\n"
 #: ../lib/gmath/test/bench_solver_direct.c:34
-#, fuzzy
 msgid ""
 "\n"
 "++ Running direct solver benchmark ++"
 msgstr ""
-"\n"
 #: ../lib/gmath/test/bench_blas3.c:34
-#, fuzzy
 msgid ""
 "\n"
 "++ Running blas level 3 benchmark ++"
 msgstr ""
-"\n"
 #: ../lib/gmath/test/test_blas2.c:38
-#, fuzzy
 msgid ""
 "\n"
 "++ Running blas level 2 unit tests ++"
 msgstr ""
-"\n"
 #: ../lib/gmath/test/test_blas2.c:44
-#, fuzzy
 msgid ""
 "\n"
 "-- blas level 2 unit tests failure --"
 msgstr ""
-"\n"
 #: ../lib/gmath/test/test_blas2.c:46
-#, fuzzy
 msgid ""
 "\n"
 "-- blas level 2 unit tests finished successfully --"
 msgstr ""
-"\n"
 #: ../lib/gmath/test/test_main.c:47 ../lib/db/dbmi_base/test/test_main.c:47
 #: ../lib/vector/rtree/test_suite/test_main.c:44
 msgid "Choose the unit tests to run"
-msgstr "Chọn các phép thử đơn vị để chạy"
+msgstr "Chọn các phép thử đơn vị cần chạy"
 #: ../lib/gmath/test/test_main.c:54 ../lib/db/dbmi_base/test/test_main.c:54
 msgid "Choose the integration tests to run"
-msgstr "Chọn các phép thử tích phân để chạy"
+msgstr ""
 #: ../lib/gmath/test/test_main.c:61
 msgid "The size of the matrices and vectors for benchmarking"
@@ -2734,309 +2485,283 @@
 #: ../lib/gmath/test/test_main.c:79 ../lib/db/dbmi_base/test/test_main.c:58
 msgid "Run all unit tests"
-msgstr "Chạy tất cả các phép thử đơn vị"
+msgstr ""
 #: ../lib/gmath/test/test_main.c:83 ../lib/db/dbmi_base/test/test_main.c:62
 msgid "Run all integration tests"
-msgstr "Chạy tất cả các phép thử tích phân"
+msgstr ""
 #: ../lib/gmath/test/test_main.c:87 ../lib/db/dbmi_base/test/test_main.c:66
 msgid "Run all unit and integration tests"
-msgstr "Chạy tất cả các phép thử tích phân và đơn vị"
+msgstr ""
 #: ../lib/gmath/test/test_main.c:106
-#, fuzzy
 msgid "Performs benchmarks, unit and integration tests for the gmath library"
-msgstr "Thực hiện các phép thử tích phân và đơn vị cho thư viện gpde"
+msgstr ""
 #: ../lib/gmath/test/bench_solver_krylov.c:34
-#, fuzzy
 msgid ""
 "\n"
 "++ Running krylov solver benchmark ++"
 msgstr ""
-"\n"
 #: ../lib/gmath/test/test_ccmath_wrapper.c:37
-#, fuzzy
 msgid ""
 "\n"
 "++ Running ccmath wrapper unit tests ++"
 msgstr ""
-"\n"
++ Đang chạy các phép thử đơn vị công cụ toán học +"
 #: ../lib/gmath/test/test_ccmath_wrapper.c:42
-#, fuzzy
 msgid ""
 "\n"
 "-- ccmath wrapper unit tests failure --"
 msgstr ""
-"\n"
-- các phép thử đơn vị công cụ toán học thất bại --"
 #: ../lib/gmath/test/test_ccmath_wrapper.c:44
-#, fuzzy
 msgid ""
 "\n"
 "-- ccmath wrapper unit tests finished successfully --"
 msgstr ""
-"\n"
-- các phép thử đơn vị công cụ toán học kết thúc thành công --"
 #: ../lib/gmath/test/test_matrix_conversion.c:37
-#, fuzzy
 msgid ""
 "\n"
 "++ Running matrix conversion unit tests ++"
 msgstr ""
-"\n"
 #: ../lib/gmath/test/test_matrix_conversion.c:42
-#, fuzzy
 msgid ""
 "\n"
 "-- Matrix conversion unit tests failure --"
 msgstr ""
-"\n"
 #: ../lib/gmath/test/test_matrix_conversion.c:44
-#, fuzzy
 msgid ""
 "\n"
 "-- Matrix conversion unit tests finished successfully --"
 msgstr ""
-"\n"
 #: ../lib/gmath/solvers_classic_iter.c:84
 #, c-format
 msgid "sparse Jacobi -- iteration %5i error %g\n"
-msgstr "Jacobi thưa -- lần lặp %5i lỗi %g\n"
+msgstr ""
 #: ../lib/gmath/solvers_classic_iter.c:156
 #, c-format
 msgid "sparse SOR -- iteration %5i error %g\n"
-msgstr "SOR thưa -- lần lặp %5i lỗi %g\n"
+msgstr ""
 #: ../lib/gmath/solvers_classic_iter.c:218
 #, c-format
 msgid "Jacobi -- iteration %5i error %g\n"
-msgstr "Jacobi -- lần lặp %5i lỗi %g\n"
+msgstr ""
 #: ../lib/gmath/solvers_classic_iter.c:275
 #, c-format
 msgid "SOR -- iteration %5i error %g\n"
-msgstr "SOR -- lần lặp %5i lỗi %g\n"
+msgstr ""
 #: ../lib/gmath/la.c:61 ../lib/gmath/la.c:117
 msgid "Matrix dimensions out of range"
-msgstr "Kích thước ma trận nằm ngoài miền"
+msgstr ""
 #: ../lib/gmath/la.c:150
 msgid "Matrix is not initialised fully."
-msgstr "Ma trận không được khởi tạo đầy đủ."
+msgstr ""
 #: ../lib/gmath/la.c:155
 msgid "Unable to allocate space for matrix copy"
-msgstr "Không thể cấp phát không gian cho việc chép ma trận"
+msgstr ""
 #: ../lib/gmath/la.c:220
-#, fuzzy
 msgid "Input matrix is uninitialized"
-msgstr "Vec-tơ đầu ra không được khởi tạo"
+msgstr ""
 #: ../lib/gmath/la.c:285
 msgid "First scalar multiplier must be non-zero"
-msgstr "Hệ số nhân vô hướng thứ nhất phải khác 0"
+msgstr ""
 #: ../lib/gmath/la.c:291 ../lib/gmath/la.c:299 ../lib/gmath/la.c:364
 msgid "One or both input matrices uninitialised"
-msgstr "Một hoặc cả hai ma trận đầu vào không được khởi tạo"
+msgstr ""
 #: ../lib/gmath/la.c:304 ../lib/gmath/la.c:369
 msgid "Matrix order does not match"
-msgstr "Thứ tự ma trận không khớp"
+msgstr ""
 #: ../lib/gmath/la.c:310
 msgid "Unable to allocate space for matrix sum"
-msgstr "Không thể cấp không gian cho tổng ma trận"
+msgstr ""
 #: ../lib/gmath/la.c:374
 msgid "Unable to allocate space for matrix product"
-msgstr "Không thể cấp phát không gian cho việc tạo ma trận"
+msgstr ""
 #: ../lib/gmath/la.c:486
 msgid "Input: one or both data matrices uninitialised"
-msgstr "Đầu vào: một hoặc cả hai ma trận không được khởi tạo"
+msgstr ""
 #: ../lib/gmath/la.c:491
 msgid "Principal matrix is not properly dimensioned"
-msgstr "Ma trận chính không được khởi tạo đúng đắn"
+msgstr ""
 #: ../lib/gmath/la.c:496
 msgid "Input: you must have at least one array to solve"
-msgstr "Đầu vào: bạn phải có ít nhất một mảng để giải"
+msgstr ""
 #: ../lib/gmath/la.c:502
 msgid "Could not allocate space for solution matrix"
-msgstr "Không thể cấp phát không gian cho ma trận giải"
+msgstr ""
 #: ../lib/gmath/la.c:508 ../lib/gmath/la.c:516
 msgid "Could not allocate space for working matrix"
-msgstr "Không thể cấp phát không gian cho ma trận đang chạy"
+msgstr ""
 #: ../lib/gmath/la.c:569
 msgid "Matrix (or submatrix is singular). Solution undetermined"
 msgstr ""
-"Ma trận (hoặc ma trận con) là loại suy biến. Phép giải không xác định được "
 #: ../lib/gmath/la.c:573
 msgid "Problem in LA routine."
-msgstr "Trục trặc trong chương trình LA."
+msgstr ""
 #: ../lib/gmath/la.c:580
 msgid "Procedure not yet available for selected matrix type"
-msgstr "Thủ tục chưa dùng được cho kiểu ma trận được chọn"
+msgstr ""
 #: ../lib/gmath/la.c:614
 msgid "Matrix is not square. Cannot determine inverse"
-msgstr "Ma trận không vuông. Không thể xác định nghịch đảo"
+msgstr ""
 #: ../lib/gmath/la.c:619
 msgid "Unable to allocate space for matrix"
-msgstr "Không thể cấp phát không gian cho ma trận"
+msgstr ""
 #: ../lib/gmath/la.c:636
 msgid "Matrix is singular"
-msgstr "Ma trận là loại suy biến"
+msgstr ""
 #: ../lib/gmath/la.c:641
 msgid "Problem in LA procedure."
-msgstr "Trục trặc trong thủ tục LA"
+msgstr ""
 #: ../lib/gmath/la.c:729
 msgid "Element array has not been allocated"
-msgstr "Mảng thành phần không được cấp phát"
+msgstr ""
 #: ../lib/gmath/la.c:734
 msgid "Specified element is outside array bounds"
-msgstr "Thành phần được chỉ định nằm ngoài giới hạn mảng"
+msgstr ""
 #: ../lib/gmath/la.c:788
 msgid "Specified matrix column index is outside range"
-msgstr "Chỉ mục cột của ma trận được chỉ định nằm ngoài miền"
+msgstr ""
 #: ../lib/gmath/la.c:793 ../lib/gmath/la.c:834 ../lib/gmath/la.c:1198
 #: ../lib/gmath/la.c:1250 ../lib/gmath/la.c:1325
 msgid "Matrix is not initialised"
-msgstr "Ma trận không được khởi tạo"
+msgstr ""
 #: ../lib/gmath/la.c:798 ../lib/gmath/la.c:839
 msgid "Could not allocate space for vector structure"
-msgstr "Không thể cấp phát không gian cho cấu trúc vec-tơ"
+msgstr ""
 #: ../lib/gmath/la.c:829
 msgid "Specified matrix row index is outside range"
-msgstr "Chỉ mục hàng của ma trận được chỉ định nằm ngoài miền"
+msgstr ""
 #: ../lib/gmath/la.c:869
 msgid "Specified row index is outside range"
-msgstr "Chỉ mục hàng được chỉ định nằm ngoài miền"
+msgstr ""
 #: ../lib/gmath/la.c:874
 msgid "Specified column index is outside range"
-msgstr "Chỉ mục cột được chỉ định nằm ngoài miền"
+msgstr ""
 #: ../lib/gmath/la.c:894
 msgid "Unknown vector type."
+msgstr ""
 #: ../lib/gmath/la.c:949
-#, fuzzy
 msgid "Input matrix and vector have differing dimensions1"
-msgstr "Các vec-tơ có số chiều khác nhau"
+msgstr ""
 #: ../lib/gmath/la.c:955 ../lib/gmath/la.c:1071 ../lib/gmath/la.c:1361
 msgid "Output vector is uninitialized"
+msgstr ""
 #: ../lib/gmath/la.c:1076 ../lib/gmath/la.c:1366
 msgid "Vectors are not of the same type"
-msgstr "Các vec-tơ không có cùng kiểu"
+msgstr ""
 #: ../lib/gmath/la.c:1081
 msgid "Output vector is of incorrect type"
-msgstr "Vec-tơ đầu ra có kiểu không đúng"
+msgstr ""
 #: ../lib/gmath/la.c:1086 ../lib/gmath/la.c:1376
 msgid "Matrices not allowed"
-msgstr "Các ma trận không được chấp nhận"
+msgstr ""
 #: ../lib/gmath/la.c:1092 ../lib/gmath/la.c:1383
 msgid "Vectors have differing dimensions"
+msgstr ""
 #: ../lib/gmath/la.c:1098 ../lib/gmath/la.c:1390
 msgid "Output vector has incorrect dimension"
-msgstr "Vec-tơ đầu ra có chiều không đúng"
+msgstr ""
 #: ../lib/gmath/la.c:1143
 msgid "Vector dimensions out of range"
-msgstr "Chiều vec-tơ nằm ngoài miền"
+msgstr ""
 #: ../lib/gmath/la.c:1148
 msgid "Row/column out of range"
-msgstr "Hàng/cột nằm ngoài miền"
+msgstr ""
 #: ../lib/gmath/la.c:1371
-#, fuzzy
 msgid "Output vector is not the same type as others"
+msgstr ""
 #: ../lib/gmath/la.c:1437
 msgid "Vector structure is not initialised"
-msgstr "Cấu trúc vec-tơ không được khởi tạo"
+msgstr ""
 #: ../lib/gmath/la.c:1558 ../lib/gmath/la.c:1566 ../lib/gmath/la.c:1571
 msgid "Input format error"
-msgstr "Lỗi định dạng đầu vào"
+msgstr ""
 #: ../lib/gmath/del2g.c:50
 msgid "    taking FFT of image..."
-msgstr "   đang lấy FFT của ảnh..."
+msgstr ""
 #: ../lib/gmath/del2g.c:56
 msgid "    computing del**2 g..."
-msgstr "   đang tính del**2 g..."
+msgstr ""
 #: ../lib/gmath/del2g.c:59
 msgid "    taking FFT of del**2 g..."
-msgstr "  đang lấy FFT của del**2 g..."
+msgstr ""
 #: ../lib/gmath/del2g.c:63
 msgid "    multiplying transforms..."
-msgstr "   đang nhân các giá trị chuyển đổi..."
+msgstr ""
 #: ../lib/gmath/del2g.c:66
 msgid "    taking inverse FFT..."
-msgstr "   đang lấy FFT nghịch..."
+msgstr ""
 #: ../lib/lidar/raster.c:74 ../lib/lidar/raster.c:89 ../lib/lidar/raster.c:102
 #: ../lib/lidar/raster.c:119 ../lib/lidar/raster.c:134
 #: ../lib/lidar/raster.c:147 ../lib/lidar/raster.c:162
 #: ../lib/lidar/raster.c:175
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to access table <%s>"
+msgstr ""
 #: ../lib/lidar/zones.c:473 ../lib/lidar/zones.c:510
-#, fuzzy, c-format
+#, c-format
 msgid "<%s> created in database."
-msgstr "Bảng <%s> đã có trong csdl <%s>"
+msgstr ""
 #: ../lib/lidar/zones.c:477 ../lib/lidar/zones.c:514
 #, c-format
@@ -3052,19 +2777,19 @@
 msgstr ""
 #: ../lib/db/dbmi_base/legal_dbname.c:38
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'."
-msgstr "Tên bản đồ bảng không hợp lệ <%s>. Không được có '.' hoặc 'NULL'.\n"
+msgstr ""
 #: ../lib/db/dbmi_base/legal_dbname.c:45
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal table map name <%s>. Must start with a letter."
-msgstr "Tên bản đồ bảng không hợp lệ <%s>. Phải bắt đầu bằng một chữ cái.\n"
+msgstr ""
 #: ../lib/db/dbmi_base/legal_dbname.c:54
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal table map name <%s>. Character <%c> not allowed."
-msgstr "Tên bản đồ bảng không hợp lệ <%s>. Ký tự <%c> không được phép.\n"
+msgstr ""
 #: ../lib/db/dbmi_base/valuefmt.c:52
 msgid "db_convert_Cstring_to_value(): unrecognized sqltype"
@@ -3076,93 +2801,72 @@
 #: ../lib/db/dbmi_base/default_name.c:136
 msgid "Programmer error"
-msgstr "Lỗi của lập trình viên"
+msgstr ""
 #: ../lib/db/dbmi_base/login.c:115
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read file '%s'"
-msgstr "Không thể mở tập tin %s"
+msgstr ""
 #: ../lib/db/dbmi_base/login.c:126
-#, fuzzy, c-format
+#, c-format
 msgid "Login file (%s) corrupted (line: %s)"
-msgstr "Tập tin đăng nhập bị hỏng"
+msgstr ""
 #: ../lib/db/dbmi_base/login.c:164
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to write file '%s'"
-msgstr "Không thể xoá tập tin '%s'"
+msgstr ""
 #: ../lib/db/dbmi_base/login.c:229
-#, fuzzy, c-format
+#, c-format
 msgid "DB connection <%s/%s> already exists and will be overwritten"
+msgstr ""
 #: ../lib/db/dbmi_base/login.c:232
-#, fuzzy, c-format
-msgid ""
-"DB connection <%s/%s> already exists. Re-run '%s' with '--%s' flag to "
-"overwrite existing settings."
+#, c-format
+msgid "DB connection <%s/%s> already exists. Re-run '%s' with '--%s' flag to overwrite existing settings."
+msgstr ""
 #: ../lib/db/dbmi_base/test/test_table.c:38
-#, fuzzy
 msgid ""
 "\n"
 "++ Running table unit tests ++"
 msgstr ""
-"\n"
 #: ../lib/db/dbmi_base/test/test_table.c:43
-#, fuzzy
 msgid ""
 "\n"
 "-- Table unit tests failure --"
 msgstr ""
-"\n"
 #: ../lib/db/dbmi_base/test/test_table.c:45
-#, fuzzy
 msgid ""
 "\n"
 "-- Table unit tests finished successfully --"
 msgstr ""
-"\n"
 #: ../lib/db/dbmi_base/test/test_main.c:83
-#, fuzzy
 msgid "Performs unit and integration tests for the dbmi base library"
+msgstr ""
 #: ../lib/db/dbmi_base/test/test_columns.c:37
-#, fuzzy
 msgid ""
 "\n"
 "++ Running column unit tests ++"
 msgstr ""
-"\n"
 #: ../lib/db/dbmi_base/test/test_columns.c:42
-#, fuzzy
 msgid ""
 "\n"
 "-- column unit tests failure --"
 msgstr ""
-"\n"
 #: ../lib/db/dbmi_base/test/test_columns.c:44
-#, fuzzy
 msgid ""
 "\n"
 "-- column unit tests finished successfully --"
 msgstr ""
-"\n"
 #: ../lib/db/dbmi_base/test/test_columns.c:57
 msgid ""
@@ -3181,23 +2885,21 @@
 msgstr ""
 #: ../lib/db/dbmi_base/error.c:72
-#, fuzzy
 msgid "<NULL error message>"
-msgstr "Thông báo lỗi: %s"
+msgstr ""
 #: ../lib/db/dbmi_base/error.c:91
 msgid "dbmi: Protocol error"
 msgstr ""
 #: ../lib/db/dbmi_base/error.c:136
-#, fuzzy
 msgid "dbmi: Out of Memory"
-msgstr "Hết bộ nhớ "
+msgstr ""
 #: ../lib/db/dbmi_base/error.c:149
-#, fuzzy, c-format
+#, c-format
 msgid "dbmi: %s() not implemented"
-msgstr "chưa được cài đặt"
+msgstr ""
 #: ../lib/db/dbmi_base/error.c:163
 #, c-format
@@ -3213,18 +2915,18 @@
 #: ../lib/vector/Vlib/write_pg.c:2902 ../lib/vector/Vlib/ascii.c:404
 #, c-format
 msgid "Unable to start driver <%s>"
-msgstr "Không thể khởi động trình điều khiển <%s>"
+msgstr ""
 #: ../lib/db/dbmi_client/table.c:46 ../lib/db/dbmi_client/delete_tab.c:40
 #, c-format
 msgid "Unable open database <%s> by driver <%s>"
-msgstr "Không thể mở csdl <%s> bằng trình điều khiển <%s>"
+msgstr ""
 #: ../lib/db/dbmi_client/table.c:110 ../lib/db/dbmi_client/copy_tab.c:242
 #: ../lib/db/dbmi_client/copy_tab.c:319 ../lib/vector/Vlib/write_ogr.c:210
 #, c-format
 msgid "Unable to open select cursor: '%s'"
-msgstr "Không thể mở con trỏ chọn: '%s'"
+msgstr ""
 #: ../lib/db/dbmi_client/copy_tab.c:91
 #, c-format
@@ -3234,22 +2936,22 @@
 #: ../lib/db/dbmi_client/copy_tab.c:151
 #, c-format
 msgid "Unable to get list tables in database <%s>"
-msgstr "không thể lấy các bảng danh sách trong csdl <%s>"
+msgstr ""
 #: ../lib/db/dbmi_client/copy_tab.c:189
-#, fuzzy, c-format
+#, c-format
 msgid "Table <%s> already exists in database and will be overwritten"
+msgstr ""
 #: ../lib/db/dbmi_client/copy_tab.c:194
 #, c-format
 msgid "Table <%s> already exists in database <%s>"
+msgstr ""
 #: ../lib/db/dbmi_client/copy_tab.c:274
 #, c-format
 msgid "Column <%s> is not integer"
-msgstr "Cột <%s> không phải kiểu số nguyên"
+msgstr ""
 #: ../lib/db/dbmi_client/copy_tab.c:291 ../lib/rst/interp_float/vinput2d.c:115
 #: ../lib/rst/interp_float/vinput2d.c:129
@@ -3260,42 +2962,41 @@
 #: ../lib/db/dbmi_client/copy_tab.c:294
 #, c-format
 msgid "Unable to create table <%s>"
+msgstr ""
 #: ../lib/db/dbmi_client/copy_tab.c:338 ../lib/vector/Vlib/write_ogr.c:585
 #: ../lib/vector/Vlib/write_pg.c:2009
 #, c-format
 msgid "Unable to fetch data from table <%s>"
+msgstr ""
 #: ../lib/db/dbmi_client/copy_tab.c:394
 #, c-format
 msgid "Unknown column type (column <%s>)"
-msgstr "Kiểu cột không biết (cột <%s>)"
+msgstr ""
 #: ../lib/db/dbmi_client/delete_tab.c:53
 #, c-format
 msgid "Unable to drop table: '%s'"
-msgstr "Không thể bỏ bảng: '%s'"
+msgstr ""
 #: ../lib/db/dbmi_client/select.c:119 ../lib/db/dbmi_client/select.c:221
 #: ../lib/db/dbmi_client/select.c:288
 msgid "Missing column name"
-msgstr "Thiếu tên cột"
+msgstr ""
 #: ../lib/db/dbmi_client/select.c:216 ../lib/db/dbmi_client/select.c:283
 msgid "Missing key column name"
-msgstr "Thiếu tên cột khoá"
+msgstr ""
 #: ../lib/db/dbmi_client/select.c:317 ../lib/vector/Vlib/cats.c:603
 #, c-format
 msgid "Unable select records from table <%s>"
-msgstr "Không thể chọn các bản ghi từ bảng <%s>"
+msgstr ""
 #: ../lib/db/dbmi_client/select.c:333
-#, fuzzy
 msgid "Key column type is not integer"
+msgstr ""
 #: ../lib/db/dbmi_driver/d_error.c:35
 #, c-format
@@ -3304,231 +3005,225 @@
 #: ../lib/nviz/lights.c:171
 msgid "Unable to define new light"
-msgstr "Không thể định nghĩa nguồn sáng mới"
+msgstr ""
 #: ../lib/nviz/position.c:56
 msgid "Unable to set focus"
-msgstr "Không thể thiết lập tiêu điểm"
+msgstr ""
 #: ../lib/nviz/nviz.c:128
 #, c-format
 msgid "Invalid color (%s), using \"white\" as default"
-msgstr "Màu không hợp lệ (%s), dùng \"white\" (trắng) làm mặc định"
+msgstr ""
 #: ../lib/nviz/render.c:106
 msgid "Bad server connection"
-msgstr "Kết nối với máy chủ kém"
+msgstr ""
 #: ../lib/nviz/render.c:112
-#, fuzzy
 msgid "Unable to get visual info"
-msgstr "Không thể mở tập tin %s trong %s"
+msgstr ""
 #: ../lib/nviz/render.c:119
 msgid "Unable to create rendering context"
-msgstr "Không thể tạo ngữ cảnh kết xuất"
+msgstr ""
 #: ../lib/nviz/map_obj.c:59
 msgid "Maximum surfaces loaded!"
-msgstr "Số bề mặt nhiều nhất đã được nạp!"
+msgstr ""
 #: ../lib/nviz/map_obj.c:88
 msgid "Maximum vector line maps loaded!"
-msgstr "Số bản đồ đường vec-tơ nhiều nhất đã được nạp!"
+msgstr ""
 #: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
 #, c-format
 msgid "Error loading vector map <%s>"
+msgstr ""
 #: ../lib/nviz/map_obj.c:116
 msgid "Maximum vector point maps loaded!"
-msgstr "Số bản đồ vec-tơ kiểu điểm nhiều nhất đã được nạp!"
+msgstr ""
 #: ../lib/nviz/map_obj.c:143
 msgid "Maximum volumes loaded!"
-msgstr "Số thể tích nhiều nhất đã được nạp!"
+msgstr ""
 #: ../lib/nviz/map_obj.c:152
 #, c-format
 msgid "Error loading 3d raster map <%s>"
-msgstr "Lỗi khi đang nạp bản đồ raster 3d <%s>"
+msgstr ""
 #: ../lib/nviz/map_obj.c:160
 msgid "Nviz_new_map_obj(): unsupported data type"
-msgstr "Nviz_new_map_obj(): kiểu dữ liệu không được hỗ trợ"
+msgstr ""
 #: ../lib/manage/do_copy.c:43
-#, fuzzy, c-format
+#, c-format
 msgid "Copy %s <%s> to current mapset as <%s>"
-msgstr "Keine %s Dateien im aktuellen Mapset vorhanden\n"
+msgstr "Chép %s < %s> vào bộ bản độ hiện tại thành <%s>"
 #: ../lib/manage/do_copy.c:50 ../lib/manage/do_copy.c:67
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to copy <%s> to current mapset as <%s>"
+msgstr "Không thể chép <%s> vào bộ bản đồ hiện tại thành <%s>"
 #: ../lib/manage/do_copy.c:61 ../lib/manage/do_remove.c:89
 #: ../lib/manage/do_remove.c:109 ../lib/manage/do_rename.c:87
 #: ../lib/manage/do_rename.c:107
-#, fuzzy, c-format
+#, c-format
 msgid "%s is missing"
-msgstr "bị thiếu"
+msgstr "thiếu %s"
 #: ../lib/manage/do_copy.c:72
 #, c-format
 msgid "%s copied"
-msgstr ""
+msgstr "%s được chép"
 #: ../lib/manage/do_remove.c:42
-#, fuzzy, c-format
+#, c-format
 msgid "Removing %s <%s>"
-msgstr "không thể tìm thấy [%s]"
+msgstr "Đang loại bỏ %s <%s>"
 #: ../lib/manage/do_remove.c:65
-#, fuzzy
 msgid "Unable to delete vector map"
+msgstr "Không thể xóa bản đồ vector"
 #: ../lib/manage/do_remove.c:85
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to remove %s element"
+msgstr "Không thể loại bỏ %s thành phần"
 #: ../lib/manage/do_remove.c:92 ../lib/manage/do_remove.c:112
-#, fuzzy, c-format
+#, c-format
 msgid "%s removed"
-msgstr "Loại bỏ cửa sổ"
+msgstr "%s bị loại bỏ"
 #: ../lib/manage/do_remove.c:105
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to remove %s"
-msgstr "Không thể mở <%s>"
+msgstr "Không thể loại bỏ %s"
 #: ../lib/manage/do_remove.c:121
 #, c-format
 msgid "<%s> nothing removed"
-msgstr ""
+msgstr "<%s> không có gì bị loại bỏ"
 #: ../lib/manage/do_list.c:30
-#, fuzzy, c-format
+#, c-format
 msgid "%s: invalid index %d"
-msgstr ""
-"\n"
-"%s không hợp lệ; Hãy thử lại > "
+msgstr "%s: chỉ mục không hợp lệ %d"
 #: ../lib/manage/option.c:47
-#, fuzzy, c-format
+#, c-format
 msgid "%s to be %s"
-msgstr "%s hoàn tất. %s"
+msgstr "%s trở thành %s"
 #: ../lib/manage/option.c:51
 msgid "Raster"
-msgstr ""
+msgstr "Raster"
 #: ../lib/manage/option.c:53
 msgid "Vector"
-msgstr ""
+msgstr "Vector"
 #: ../lib/manage/option.c:55
 msgid "Region"
-msgstr ""
+msgstr "Vùng"
 #: ../lib/manage/option.c:57
 msgid "Group"
-msgstr ""
+msgstr "Nhóm"
 #: ../lib/manage/read_list.c:73
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open data base element list '%s'"
-msgstr "Không thể mở tập tin định nghĩa csdl vec-tơ: '%s'"
+msgstr "Không thể mở danh sách thành phần csdl '%s'"
 #: ../lib/manage/read_list.c:134
 #, c-format
 msgid "Format error: file ('%s') line (%d) - %s"
-msgstr ""
+msgstr "Lỗi định dạng: tập tin ('%s') dòng (%d) - %s"
 #: ../lib/manage/do_rename.c:42
-#, fuzzy, c-format
+#, c-format
 msgid "Rename %s <%s> to <%s>"
+msgstr "Đặt lại tên %s <%s> thành <%s>"
 #: ../lib/manage/do_rename.c:62
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to rename vector map <%s> to <%s>"
-msgstr "Không thể sao chép bản đồ vec-tơ <%s> vào <%s>"
+msgstr "Không thể đặt lại tên bản đồ vector <%s> thành <%s>"
 #: ../lib/manage/do_rename.c:83 ../lib/manage/do_rename.c:103
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to rename %s"
+msgstr "Không thể đặt lại tên %s"
 #: ../lib/manage/do_rename.c:90 ../lib/manage/do_rename.c:110
 #, c-format
 msgid "%s renamed"
-msgstr ""
+msgstr "%s được đặt lại tên"
 #: ../lib/manage/do_rename.c:119
 #, c-format
 msgid "<%s> nothing renamed"
-msgstr ""
+msgstr "<%s> không có gì bị đặt lại tên"
 #: ../lib/raster/color_write.c:81 ../lib/vector/Vlib/color_write.c:71
-#, fuzzy, c-format
+#, c-format
 msgid "Qualified name <%s> doesn't match mapset <%s>"
-msgstr "G__open(read): bộ bản đồ <%s> không khớp với xmapset <%s>"
+msgstr ""
 #: ../lib/raster/color_write.c:96 ../lib/vector/Vlib/color_write.c:91
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create <%s> file for map <%s>"
-msgstr "Không thể tạo bản đồ raster <%s>"
+msgstr ""
 #: ../lib/raster/mask_info.c:43
 #, c-format
 msgid "<%s> in mapset <%s>"
-msgstr "<%s> trong bộ bản đồ <%s>"
+msgstr ""
 #: ../lib/raster/mask_info.c:46
 msgid "none"
-msgstr "không có"
+msgstr ""
 #: ../lib/raster/mask_info.c:49
 msgid "not known"
+msgstr ""
 #: ../lib/raster/reclass.c:168
-#, fuzzy, c-format
+#, c-format
 msgid "Too many reclass categories for <%s@%s>"
-msgstr "Quá nhiều phạm trù phân loại lại cho [%s trong %s]"
+msgstr ""
 #: ../lib/raster/reclass.c:171
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal reclass format in header file for <%s@%s>"
 msgstr ""
-"Định dạng phân loại lại không hợp lệ trong tập tin header của [%s trong %s] "
 #: ../lib/raster/reclass.c:273
 msgid "Illegal reclass request"
-msgstr "Yêu cầu phân loại lại không hợp lệ"
+msgstr ""
 #: ../lib/raster/reclass.c:278
 msgid "Illegal reclass type"
-msgstr "Kiểu phân loại lại không hợp lệ"
+msgstr ""
 #: ../lib/raster/reclass.c:284
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create header file for <%s@%s>"
+msgstr ""
 #: ../lib/raster/reclass.c:332
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create dependency file in <%s@%s>"
-msgstr "Không thể tạo ra tập tin phụ thuộc cho [%s trong %s]"
+msgstr ""
 #: ../lib/raster/init.c:61
-#, fuzzy
 msgid "Raster library not initialized. Programmer forgot to call Rast_init()."
-msgstr "Hệ thống không được khởi chạy. Lập trình viên quên gọi G_gisinit()."
+msgstr ""
 #: ../lib/raster/init.c:109
 #, c-format
@@ -3536,8 +3231,7 @@
 msgstr ""
 #: ../lib/raster/init.c:113
-msgid ""
-"No compression is not supported for GRASS raster maps, using default ZLIB"
+msgid "No compression is not supported for GRASS raster maps, using default ZLIB"
 msgstr ""
 #: ../lib/raster/init.c:118
@@ -3546,141 +3240,136 @@
 msgstr ""
 #: ../lib/raster/range.c:102
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read fp range file for <%s>"
-msgstr "Không thể mở tập tin lịch sử của vector '%s'"
+msgstr ""
 #: ../lib/raster/range.c:169
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read quant rules for raster map <%s>"
+msgstr ""
 #: ../lib/raster/range.c:206 ../lib/raster/range.c:226
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read range file for <%s>"
+msgstr ""
 #: ../lib/raster/range.c:264 ../lib/raster/range.c:270
 #: ../lib/raster/range.c:300 ../lib/raster/range.c:314
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to write range file for <%s>"
+msgstr ""
 #: ../lib/raster/raster_metadata.c:109
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read <%s> for raster map <%s@%s>"
+msgstr ""
 #: ../lib/raster/raster_metadata.c:119 ../lib/raster/raster_metadata.c:148
-#, fuzzy, c-format
+#, c-format
 msgid "Error closing <%s> metadata file for raster map <%s@%s>"
+msgstr ""
 #: ../lib/raster/raster_metadata.c:142
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create <%s> metadata file for raster map <%s@%s>"
+msgstr ""
 #: ../lib/raster/put_row.c:121
-#, fuzzy, c-format
+#, c-format
 msgid "Error writing uncompressed FP data for row %d of <%s>: %s"
-msgstr "Lỗi khi đang đọc bản đồ nén <%s@%s>, hàng %d"
+msgstr ""
 #: ../lib/raster/put_row.c:131
-#, fuzzy, c-format
+#, c-format
 msgid "Error writing compressed FP data for row %d of <%s>: %s"
+msgstr ""
 #: ../lib/raster/put_row.c:387 ../lib/raster/put_row.c:393
-#, fuzzy, c-format
+#, c-format
 msgid "Error writing compressed data for row %d of <%s>"
+msgstr ""
 #: ../lib/raster/put_row.c:403
-#, fuzzy, c-format
+#, c-format
 msgid "Error writing uncompressed data for row %d of <%s>"
+msgstr ""
 #: ../lib/raster/put_row.c:462
-#, fuzzy, c-format
+#, c-format
 msgid "Error writing data via GDAL for row %d of <%s>"
-msgstr "Lỗi khi đang ghi tập tin chỉ mục phạm trù <%s>"
+msgstr ""
 #: ../lib/raster/put_row.c:486
 msgid "GDAL output doesn't support writing null rows separately"
 msgstr ""
 #: ../lib/raster/put_row.c:489
-#, fuzzy, c-format
+#, c-format
 msgid "No null file for <%s>"
+msgstr ""
 #: ../lib/raster/put_row.c:513 ../lib/raster/put_row.c:518
-#, fuzzy, c-format
+#, c-format
 msgid "Error writing compressed null data for row %d of <%s>"
+msgstr ""
 #: ../lib/raster/put_row.c:552 ../lib/raster/put_row.c:555
-#, fuzzy, c-format
+#, c-format
 msgid "Error writing null row %d of <%s>"
-msgstr "lỗi khi đang ghi hàng null %d"
+msgstr ""
 #: ../lib/raster/put_row.c:680
-#, fuzzy, c-format
+#, c-format
 msgid "put_raster_row: raster map <%s> not open for write - request ignored"
-msgstr "%s: bản đồ [%s] không được mở để ghi - yêu cầu bị bỏ qua"
+msgstr ""
 #: ../lib/raster/put_row.c:687
-#, fuzzy
 msgid "put_raster_row: unopened file descriptor - request ignored"
-msgstr "%s: Mô tả tập tin không được mở - yêu cầu bị bỏ qua"
+msgstr ""
 #: ../lib/raster/get_cellhd.c:66
-#, fuzzy, c-format
-msgid ""
-"Unable to read header file for raster map <%s@%s>. It is a reclass of raster "
-"map <%s@%s> %s"
+#, c-format
+msgid "Unable to read header file for raster map <%s@%s>. It is a reclass of raster map <%s@%s> %s"
 msgstr ""
-"Không thể mở bản đồ raster <%s@%s> vì nó là phân loại lại của bản đồ raster <"
-"%s@%s> không tồn tại"
 #: ../lib/raster/get_cellhd.c:70
 msgid "which is missing."
-msgstr "bị thiếu"
+msgstr ""
 #: ../lib/raster/get_cellhd.c:71
 msgid "whose header file can't be opened."
-msgstr "tập tin header của nó không thể mở được."
+msgstr ""
 #: ../lib/raster/get_cellhd.c:76
 #, c-format
 msgid "Unable to open header file for raster map <%s@%s>"
+msgstr ""
 #: ../lib/raster/quant_io.c:43
-#, fuzzy, c-format
+#, c-format
 msgid "Floating data range for raster map <%s> is empty"
-msgstr "Miền dữ liệu kiểu float cho %s@%s bị rỗng"
+msgstr ""
 #: ../lib/raster/quant_io.c:52
-#, fuzzy, c-format
+#, c-format
 msgid "Integer data range for raster map <%s> is empty"
-msgstr "Miền dữ liệu số kiểu số nguyên cho %s@%s bị rỗng"
+msgstr ""
 #: ../lib/raster/quant_io.c:105
-#, fuzzy, c-format
+#, c-format
 msgid "Attempt to open quantization table for CELL raster map <%s>"
-msgstr "Không thể đọc miền của bản đồ raster <%s>"
+msgstr ""
 #: ../lib/raster/quant_io.c:135
-#, fuzzy, c-format
+#, c-format
 msgid "Quantization file for raster map <%s> is missing"
+msgstr ""
 #: ../lib/raster/quant_io.c:145
-#, fuzzy, c-format
+#, c-format
 msgid "Quantization file for raster map <%s> is empty"
+msgstr ""
 #: ../lib/raster/alloc_cell.c:151
 #, c-format
@@ -3690,156 +3379,139 @@
 #: ../lib/raster/histogram.c:55
 #, c-format
 msgid "Histogram for [%s in %s] missing (run r.support)"
-msgstr "Biểu đồ tần số cho [%s trong %s] bị thiếu (chạy r.support)"
+msgstr ""
 #: ../lib/raster/histogram.c:62
 #, c-format
 msgid "Can't read histogram for [%s in %s]"
-msgstr "Không thể đọc biểu đồ tần số cho [%s trong %s]"
+msgstr ""
 #: ../lib/raster/histogram.c:66 ../lib/raster/histogram.c:73
 #, c-format
 msgid "Invalid histogram file for [%s in %s]"
-msgstr "Tập tin biểu đồ tần số cho [%s trong %s] không hợp lệ"
+msgstr ""
 #: ../lib/raster/histogram.c:331
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create histogram file for <%s>"
-msgstr "Không thể tạo ra tập tin header cho [%s]"
+msgstr ""
 #: ../lib/raster/open.c:193
 #, c-format
-msgid ""
-"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@"
-"%s> which does not exist"
+msgid "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%s> which does not exist"
 msgstr ""
 #: ../lib/raster/open.c:198
-#, fuzzy, c-format
+#, c-format
 msgid "Error reading reclass file for raster map <%s>"
-msgstr "Không thể đọc tập tin range cho [%s ở %s]"
+msgstr ""
 #: ../lib/raster/open.c:209
-#, fuzzy, c-format
+#, c-format
 msgid "Error reading map type for raster map <%s>"
+msgstr ""
 #: ../lib/raster/open.c:217
 #, c-format
 msgid "Raster map <%s@%s>: format field in header file invalid"
 msgstr ""
-"Bản đồ raster <%s@%s>: định dạng trường trong tập tin header không hợp lệ"
 #: ../lib/raster/open.c:236
-#, fuzzy, c-format
+#, c-format
 msgid "Compression with %s is not supported"
-msgstr "Kiểu đối tượng OGR %d không được hỗ trợ"
+msgstr ""
 #: ../lib/raster/open.c:240
-#, fuzzy, c-format
-msgid ""
-"Raster map <%s> is in different projection than current region. Found <%s>, "
-"should be <%s>."
+#, c-format
+msgid "Raster map <%s> is in different projection than current region. Found <%s>, should be <%s>."
 msgstr ""
-"Bản đồ raster <%s@%s> ở phép chiếu khác với vùng hiện hành. Tìm thấy bản đồ <"
-"%s@%s>, lẽ ra phải là <%s>."
 #: ../lib/raster/open.c:247
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map <%s> is in different zone (%d) than current region (%d)"
-msgstr "Bản đồ raster <%s@%s> ở một múi (%d) khác với vùng hiện hành (%d)"
+msgstr ""
 #: ../lib/raster/open.c:252
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map <%s>: bytes per cell (%d) too large"
-msgstr "Bản đồ raster <%s@%s>: số byte trên ô (%d) quá lớn"
+msgstr ""
 #: ../lib/raster/open.c:277
-#, fuzzy, c-format
-msgid ""
-"Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
+#, c-format
+msgid "Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
 msgstr ""
-"bản đồ <%s@%s> là một liên kết GDAL nhưng GRASS được biên dịch không có hỗ "
-"trợ GDAL"
 #: ../lib/raster/open.c:285
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open %s file for raster map <%s@%s>"
+msgstr ""
 #: ../lib/raster/open.c:322
-#, fuzzy, c-format
+#, c-format
 msgid "Error reading format for <%s@%s>"
-msgstr "Lỗi khi đang đọc bản đồ <%s@%s>, hàng %d"
+msgstr ""
 #: ../lib/raster/open.c:527
-#, fuzzy
 msgid "Unable to create GDAL link"
+msgstr ""
 #: ../lib/raster/open.c:599 ../lib/raster/gdal.c:476
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid map type <%d>"
+msgstr ""
 #: ../lib/raster/open.c:604 ../lib/raster/open.c:759
 #, c-format
 msgid "Raster map <%s> is not in the current mapset (%s)"
-msgstr "Bản đồ raster <%s> không ở trong bộ bản đồ hiện tại (%s)"
+msgstr ""
 #: ../lib/raster/open.c:611
 #, c-format
 msgid "<%s> is an illegal file name"
-msgstr "<%s> là một tên tập tin không hợp lệ"
+msgstr ""
 #: ../lib/raster/open.c:626 ../lib/raster/open.c:706 ../lib/raster/open.c:782
-#, fuzzy, c-format
+#, c-format
 msgid "No temp files available: %s"
-msgstr "G__open_raster_new(): không có tập tin tạm nào dùng được"
+msgstr ""
 #: ../lib/raster/open.c:755
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map <%s> does not exist in the current mapset (%s)"
+msgstr ""
 #: ../lib/raster/open.c:821
-#, fuzzy
 msgid "Rast_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
-msgstr "G_set_fp_type(): chỉ có thể được gọi với FCELL_TYPE hoặc DCELL_TYPE"
+msgstr ""
 #: ../lib/raster/open.c:879
 #, c-format
 msgid "Raster map <%s> not found in mapset <%s>"
-msgstr "Không tìm thấy bản đồ raster <%s> trong bộ bản đồ <%s>"
+msgstr ""
 #: ../lib/raster/open.c:940
 #, c-format
 msgid "Unable to find '%s'"
-msgstr "Không thể tìm thấy '%s'"
+msgstr ""
 #: ../lib/raster/open.c:951
 #, c-format
 msgid "Invalid type: field '%s' in file '%s'"
-msgstr "Kiểu không hợp lệ: trường '%s' trong tập tin '%s'"
+msgstr ""
 #: ../lib/raster/open.c:956
-#, fuzzy, c-format
+#, c-format
 msgid "Missing type: field in file '%s'"
+msgstr ""
 #: ../lib/raster/open.c:961
 #, c-format
 msgid "Raster map <%s> is not xdr: byte_order: %s"
-msgstr "Bản đồ raster <%s> không phải là xdr: byte_order: %s"
+msgstr ""
 #: ../lib/raster/open.c:1030
-#, fuzzy
-msgid ""
-"Rast_set_quant_rules() can be called only for raster maps opened for reading"
+msgid "Rast_set_quant_rules() can be called only for raster maps opened for reading"
 msgstr ""
-"G_set_quant_rules() chỉ có thể được gọi cho các bản đồ raster đã mở để đọc"
 #: ../lib/raster/color_rand.c:33
 #, c-format
@@ -3847,106 +3519,98 @@
 msgstr ""
 #: ../lib/raster/quant_rw.c:88
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read fp range for raster map <%s>"
-msgstr "Không thể đọc miền fp của bản đồ raster <%s>"
+msgstr ""
 #: ../lib/raster/quant_rw.c:92
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map <%s> is empty"
-msgstr " Bản đồ raster %s@%s rỗng"
+msgstr ""
 #: ../lib/raster/quant_rw.c:157
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to write quant rules: raster map <%s> is integer"
-msgstr "Không thể ghi các quy tắc lượng tử: bản đồ %s kiểu integer"
+msgstr ""
 #: ../lib/raster/quant_rw.c:166
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to write quant rules for raster map <%s>"
+msgstr ""
 #: ../lib/raster/close.c:77 ../lib/raster/close.c:110
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid descriptor: %d"
+msgstr ""
 #: ../lib/raster/close.c:391 ../lib/raster/close.c:519
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to rename null file '%s' to '%s': %s"
+msgstr ""
 #: ../lib/raster/close.c:461
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to rename cell file '%s' to '%s': %s"
+msgstr ""
 #: ../lib/raster/close.c:541
 msgid "unable to write f_format file for CELL maps"
-msgstr "Không thể ghi tập tin f_format cho các bản đồ CELL"
+msgstr ""
 #: ../lib/raster/interp.c:211
-#, fuzzy, c-format
+#, c-format
 msgid "Unknown interpolation method: %s"
-msgstr "Kiểu nội suy không hiểu"
+msgstr ""
 #: ../lib/raster/color_read.c:103
-#, fuzzy
 msgid "missing"
-msgstr "bị thiếu"
+msgstr ""
 #: ../lib/raster/color_read.c:106
-#, fuzzy
 msgid "invalid"
 msgstr ""
-"không hợp lệ\n"
-"%s"
 #: ../lib/raster/color_read.c:112
-#, fuzzy, c-format
+#, c-format
 msgid "Color support for <%s@%s> %s"
-msgstr "hỗ trợ màu cho [%s] trong bộ bản đồ [%s] %s"
+msgstr ""
 #: ../lib/raster/gdal.c:88
 #, c-format
 msgid "Unable to locate symbol <%s>"
-msgstr "Không thể định vị biểu tượng <%s>"
+msgstr ""
 #: ../lib/raster/gdal.c:142
 msgid "Unable to load GDAL library"
-msgstr "Không thể nạp thư viện GDAL"
+msgstr ""
 #: ../lib/raster/gdal.c:372
-#, fuzzy
 msgid "Unable to open GDAL file"
+msgstr ""
 #: ../lib/raster/gdal.c:482
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to get <%s> driver"
-msgstr "không thể mở %s"
+msgstr ""
 #: ../lib/raster/gdal.c:491
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create <%s> dataset using <%s> driver"
+msgstr ""
 #: ../lib/raster/gdal.c:499
 #, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
 msgstr ""
 #: ../lib/raster/gdal.c:505
-#, fuzzy
 msgid "Unable to get in-memory raster driver"
-msgstr "không thể tập tin quant!"
+msgstr ""
 #: ../lib/raster/gdal.c:512
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create <%s> dataset using memory driver"
-msgstr "Không thể mở CSDL"
+msgstr ""
 #: ../lib/raster/gdal.c:516
 #, c-format
@@ -3954,70 +3618,68 @@
 msgstr ""
 #: ../lib/raster/gdal.c:532
-#, fuzzy
 msgid "Unable to set geo transform"
+msgstr ""
 #: ../lib/raster/gdal.c:536
-#, fuzzy
 msgid "Unable to set projection"
+msgstr ""
 #: ../lib/raster/gdal.c:540
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create cell_misc/%s/gdal file"
-msgstr "Không thể mở tập tin tạm"
+msgstr ""
 #: ../lib/raster/gdal.c:556
-#, fuzzy, c-format
+#, c-format
 msgid "Error writing cell_misc/%s/gdal file"
-msgstr "Lỗi khi đang ghi tập tin chỉ mục không gian.\n"
+msgstr ""
 #: ../lib/raster/gdal.c:604
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create output file <%s> using driver <%s>"
+msgstr ""
 #: ../lib/raster/format.c:162
 #, c-format
 msgid "Fail of initial read of compressed file [%s in %s]"
-msgstr "Thất bại trong việc khởi động đọc tập tin nén [%s trong %s]"
+msgstr ""
 #: ../lib/raster/format.c:176
-#, fuzzy, c-format
+#, c-format
 msgid "Fail of initial read of compressed null file [%s in %s]"
+msgstr ""
 #: ../lib/raster/sample.c:70
 msgid "Unknown interpolation type"
+msgstr ""
 #: ../lib/raster/sample.c:327
 msgid "\"no data\" label found; setting to zero"
-msgstr "tìm thấy nhãn \"no data\"; thiết lập về 0"
+msgstr ""
 #: ../lib/raster/put_title.c:28
 #, c-format
 msgid "category information for [%s] in [%s] missing or invalid"
-msgstr "thông tin phạm trù cho [%s] trong [%s] bị thiếu hoặc không hợp lệ."
+msgstr ""
 #: ../lib/raster/put_title.c:37
 msgid "G_put_title - can't create a temp file"
-msgstr "G_put_title - không thể tạo tập tin tạm"
+msgstr ""
 #: ../lib/raster/put_title.c:53
 #, c-format
 msgid "category information for [%s] in [%s] invalid"
-msgstr "thông tin phạm trù cho [%s] trong [%s] không hợp lệ"
+msgstr ""
 #: ../lib/raster/put_title.c:60
 msgid "G_put_title - can't reopen temp file"
-msgstr "G_put_title - không thể mở lại tập tin tạm"
+msgstr ""
 #: ../lib/raster/put_title.c:67
 #, c-format
 msgid "can't write category information for [%s] in [%s]"
-msgstr "không thể ghi thông tin phạm trù cho [%s] trong [%s]"
+msgstr ""
 #: ../lib/raster/color_rules.c:120
 #, fuzzy
@@ -4031,35 +3693,35 @@
 #: ../lib/raster/color_rules.c:130
 msgid "percentage not in range 0-100"
-msgstr "phần trăm không ở trong miền 0-100"
+msgstr ""
 #: ../lib/raster/color_rules.c:132
 msgid "invalid value"
-msgstr "giá trị không hợp lệ"
+msgstr ""
 #: ../lib/raster/color_rules.c:134
 msgid "unknown error"
-msgstr "lỗi không rõ"
+msgstr ""
 #: ../lib/raster/color_rules.c:180
 #, c-format
 msgid "bad rule (%s): [%s]"
-msgstr "quy tắc tồi (%s): [%s]"
+msgstr ""
 #: ../lib/raster/color_rules.c:327
 #, c-format
 msgid "Unable to load color rules <%s>"
-msgstr "Không thể nạp các quy tắc màu <%s>"
+msgstr ""
 #: ../lib/raster/history.c:115 ../lib/raster/history.c:123
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to get history information for <%s@%s>"
-msgstr "không thể ghi thông tin lịch sử cho [%s]"
+msgstr ""
 #: ../lib/raster/history.c:162
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to write history information for <%s>"
+msgstr ""
 #: ../lib/raster/history.c:235
 #, c-format
@@ -4067,111 +3729,99 @@
 msgstr ""
 #: ../lib/raster/cats.c:109
-#, fuzzy, c-format
+#, c-format
 msgid "Category support for <%s@%s> missing"
-msgstr "hỗ trợ phạm trù cho [%s] trong bộ bản đồ [%s] %s"
+msgstr ""
 #: ../lib/raster/cats.c:112
-#, fuzzy, c-format
+#, c-format
 msgid "Category support for <%s@%s> invalid"
+msgstr ""
 #: ../lib/raster/cats.c:145
-#, fuzzy, c-format
+#, c-format
 msgid "Category support for vector map <%s@%s> missing"
-msgstr "hỗ trợ phạm trù cho bản đồ vec-tơ [%s] trong bộ bản đồ [%s] %s"
+msgstr ""
 #: ../lib/raster/cats.c:149
-#, fuzzy, c-format
+#, c-format
 msgid "Category support for vector map <%s@%s> invalid"
+msgstr ""
 #: ../lib/raster/cats.c:968
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open %s file for map <%s>"
+msgstr ""
 #: ../lib/raster/get_row.c:36 ../lib/raster/get_row.c:898
 #, c-format
 msgid "Reading raster map <%s@%s> request for row %d is outside region"
-msgstr "Đang đọc bản đồ raster <%s@%s> yêu cầu cho hàng %d nằm ngoài vùng"
+msgstr ""
 #: ../lib/raster/get_row.c:95 ../lib/raster/get_row.c:137
 #: ../lib/raster/get_row.c:144 ../lib/raster/get_row.c:187
 #: ../lib/raster/get_row.c:191
-#, fuzzy, c-format
+#, c-format
 msgid "Error reading raster data for row %d of <%s>"
+msgstr ""
 #: ../lib/raster/get_row.c:102 ../lib/raster/get_row.c:168
-#, fuzzy, c-format
+#, c-format
 msgid "Error uncompressing raster data for row %d of <%s>"
+msgstr ""
 #: ../lib/raster/get_row.c:227
-#, fuzzy, c-format
+#, c-format
 msgid "Error reading raster data via GDAL for row %d of <%s>"
+msgstr ""
 #: ../lib/raster/get_row.c:827 ../lib/raster/get_row.c:832
 #: ../lib/raster/get_row.c:842
-#, fuzzy, c-format
+#, c-format
 msgid "Error reading null data for row %d of <%s>"
+msgstr ""
 #: ../lib/raster/get_row.c:848
-#, fuzzy, c-format
+#, c-format
 msgid "Error uncompressing null data for row %d of <%s>"
+msgstr ""
 #: ../lib/raster/get_row.c:882 ../lib/raster/get_row.c:885
-#, fuzzy, c-format
+#, c-format
 msgid "Error reading null row %d for <%s>"
-msgstr "Lỗi khi đang đọc hàng null %d"
+msgstr ""
 #: ../lib/raster/window.c:31
-msgid ""
-"Internal error: Rast_get_window() called with split window. Use "
-"Rast_get_input_window() or Rast_get_output_window() instead."
+msgid "Internal error: Rast_get_window() called with split window. Use Rast_get_input_window() or Rast_get_output_window() instead."
 msgstr ""
 #: ../lib/raster/window.c:90
-msgid ""
-"Internal error: Rast_window_rows() called with split window. Use "
-"Rast_input_window_rows() or Rast_output_window_rows() instead."
+msgid "Internal error: Rast_window_rows() called with split window. Use Rast_input_window_rows() or Rast_output_window_rows() instead."
 msgstr ""
 #: ../lib/raster/window.c:125
-msgid ""
-"Internal error: Rast_window_cols() called with split window. Use "
-"Rast_input_window_cols() or Rast_output_window_cols() instead."
+msgid "Internal error: Rast_window_cols() called with split window. Use Rast_input_window_cols() or Rast_output_window_cols() instead."
 msgstr ""
 #: ../lib/raster/null_val.c:64
-#, fuzzy
 msgid "EmbedGivenNulls: wrong data type"
-msgstr "EmbedGivenNulls: kiểu dữ liệu sai!"
+msgstr ""
 #: ../lib/raster/null_val.c:114
-#, fuzzy
 msgid "Rast_set_null_value: wrong data type!"
-msgstr "G_set_null_value: kiểu dữ liệu sai!"
+msgstr ""
 #: ../lib/raster/auto_mask.c:69
 msgid "Unable to open automatic MASK file"
-msgstr "Không thể mở tập tin MASK tự động"
+msgstr ""
 #: ../lib/raster/set_window.c:48
 msgid "Rast_set_window() called while window split"
 msgstr ""
 #: ../lib/raster/set_window.c:131
-#, fuzzy
-msgid ""
-"Rast_set_read_window(): projection/zone differs from that of currently open "
-"raster maps"
+msgid "Rast_set_read_window(): projection/zone differs from that of currently open raster maps"
 msgstr ""
-"G_set_window(): phép chiếu/múi khác với của các bản đồ raster hiện đang mở"
 #: ../lib/raster/set_window.c:158
 #, c-format
@@ -4184,126 +3834,118 @@
 msgstr ""
 #: ../lib/raster/put_cellhd.c:34
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create header file for <%s>"
+msgstr ""
 #: ../lib/gis/lrand48.c:84
-#, fuzzy, c-format
+#, c-format
 msgid "gettimeofday failed: %s"
-msgstr "Kết nối thất bại."
+msgstr ""
 #: ../lib/gis/lrand48.c:114
 msgid "Pseudo-random number generator not seeded"
 msgstr ""
 #: ../lib/gis/make_mapset.c:66 ../lib/init/grass.py:841
-#, fuzzy, c-format, python-format
+#, c-format, python-format
 msgid "Location <%s> doesn't exist"
-msgstr "%s: Vùng %d không tồn tại"
+msgstr ""
 #: ../lib/gis/timestamp.c:292
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create timestamp file for %s map <%s@%s>"
-msgstr "Không thể đọc tập tin header cho bản đồ raster <%s@%s>."
+msgstr ""
 #: ../lib/gis/timestamp.c:301
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid timestamp specified for %s map <%s@%s>"
 msgstr ""
-"Đánh dấu thời gian được chỉ định cho %s bản đồ %s trong bộ bản đồ %s không "
-"hợp lệ"
 #: ../lib/gis/timestamp.c:331
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open timestamp file for %s map <%s@%s>"
+msgstr ""
 #: ../lib/gis/timestamp.c:340
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid timestamp file for %s map <%s@%s>"
 msgstr ""
-"Tập tin đánh dấu thời gian không hợp lệ cho %s bản đồ %s trong bộ bản đồ %s"
 #: ../lib/gis/timestamp.c:479
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open timestamp file for vector map <%s@%s>"
+msgstr ""
 #: ../lib/gis/timestamp.c:488
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid timestamp file for vector map <%s@%s>"
 msgstr ""
 #: ../lib/gis/timestamp.c:524
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create timestamp file for vector map <%s@%s>"
+msgstr ""
 #: ../lib/gis/timestamp.c:533
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid timestamp specified for vector map <%s@%s>"
 msgstr ""
-"hợp lệ"
 #: ../lib/gis/location.c:61
-#, fuzzy, c-format
+#, c-format
 msgid "LOCATION <%s> not available"
-msgstr "VỊ TRÍ << %s >>  không dùng được"
+msgstr ""
 #: ../lib/gis/distance.c:154
-#, fuzzy, c-format
+#, c-format
 msgid "%s: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
 msgstr ""
-"G_distance_point_to_line_segment: lẽ ra không nên xảy ra: code=%d P=(%f,%f) "
-"S=(%f,%f)(%f,%f)"
 #: ../lib/gis/parser_rest.c:60 ../lib/gis/parser_html.c:57
 msgid "NAME"
-msgstr "TÊN"
+msgstr ""
 #: ../lib/gis/parser_rest.c:73 ../lib/gis/parser_html.c:70
 msgid "KEYWORDS"
-msgstr "CÁC TỪ KHOÁ"
+msgstr ""
 #: ../lib/gis/parser_rest.c:78 ../lib/gis/parser_html.c:75
 msgid "SYNOPSIS"
-msgstr "TÓM TẮT"
+msgstr ""
 #: ../lib/gis/parser_rest.c:146 ../lib/gis/parser_html.c:141
 #: ../lib/init/grass.py:333
 msgid "Flags"
-msgstr "Các cờ"
+msgstr ""
 #: ../lib/gis/parser_rest.c:164 ../lib/gis/parser_interface.c:329
 #: ../lib/gis/parser_help.c:215 ../lib/gis/parser_html.c:167
 msgid "Allow output files to overwrite existing files"
-msgstr "Cho phép các tập tin đầu ra ghi đè các tập tin hiện có"
+msgstr ""
 #: ../lib/gis/parser_rest.c:168 ../lib/gis/parser_interface.c:344
 #: ../lib/gis/parser_help.c:218 ../lib/gis/parser_html.c:174
 msgid "Verbose module output"
-msgstr "Đầu ra mô-đun đầy đủ"
+msgstr ""
 #: ../lib/gis/parser_rest.c:171 ../lib/gis/parser_interface.c:351
 #: ../lib/gis/parser_help.c:219 ../lib/gis/parser_html.c:177
 msgid "Quiet module output"
-msgstr "Đầu ra mô-đun im lặng"
+msgstr ""
 #: ../lib/gis/parser_rest.c:179 ../lib/gis/parser_html.c:189
 #: ../lib/init/grass.py:347
 msgid "Parameters"
-msgstr "Các tham số"
+msgstr ""
 #: ../lib/gis/parser_rest.c:223 ../lib/gis/parser_html.c:233
 msgid "Options"
-msgstr "Tùy chọn"
+msgstr ""
 #: ../lib/gis/parser_rest.c:230 ../lib/gis/parser_html.c:239
 msgid "Default"
-msgstr "Mặc định"
+msgstr ""
 #: ../lib/gis/compress.c:131 ../lib/gis/compress.c:193
 #: ../lib/gis/compress.c:209
@@ -4316,11 +3958,11 @@
 #: ../lib/gis/proj2.c:63
 msgid "Latitude-Longitude"
-msgstr "Vĩ độ - Kinh độ"
+msgstr ""
 #: ../lib/gis/proj2.c:65
 msgid "Other Projection"
-msgstr "Phép chiếu khác"
+msgstr ""
 #: ../lib/gis/parser_wps.c:490
 msgid "Multiple outputs are not supported by WPS 1.0.0"
@@ -4334,31 +3976,29 @@
 #: ../lib/gis/done_msg.c:38
 #, c-format
 msgid "%s complete. %s"
+msgstr ""
 #: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
-#, fuzzy
 msgid "Unable to seek"
+msgstr ""
 #: ../lib/gis/seek.c:56
-#, fuzzy
 msgid "Seek offset out of range"
-msgstr "Chỉ mục phạm trù nằm ngoài miền"
+msgstr ""
 #: ../lib/gis/ls.c:103
 #, c-format
 msgid "Unable to open directory %s"
-msgstr "Không thể mở thư mục %s"
+msgstr ""
 #: ../lib/gis/env.c:311
 msgid "GISRC - variable not set"
-msgstr "GISRC - biến không được thiết lập"
+msgstr ""
 #: ../lib/gis/env.c:343 ../lib/gis/env.c:369
-#, fuzzy, c-format
+#, c-format
 msgid "Variable '%s' not set"
-msgstr "G_getenv(): Biến %s không được thiết lập"
+msgstr ""
 #: ../lib/gis/find_file.c:114
 #, c-format
@@ -4371,143 +4011,127 @@
 msgstr "Dùng <%s@%s>"
 #: ../lib/gis/token.c:169
-#, fuzzy
 msgid "parse error"
-msgstr "lỗi cú pháp"
+msgstr ""
 #: ../lib/gis/get_ellipse.c:263 ../lib/proj/ellipse.c:243
 #, c-format
 msgid "Unable to open ellipsoid table file <%s>"
-msgstr "Không thể mở tập tin bảng ellipsoid <%s>"
+msgstr ""
 #: ../lib/gis/get_ellipse.c:344 ../lib/gis/get_ellipse.c:367
 #, c-format
 msgid "Invalid a: field '%s' in file %s in <%s>"
-msgstr "Giá trị a không hợp lệ: trường '%s' trong tập tin %s trong <%s>"
+msgstr ""
 #: ../lib/gis/get_ellipse.c:356
 #, c-format
 msgid "Invalid ellipsoid '%s' in file %s in <%s>"
-msgstr "Ellipsoid khônng hợp lệ '%s' trong tập tin %s trong <%s>"
+msgstr ""
 #: ../lib/gis/get_ellipse.c:370
 #, c-format
 msgid "Invalid es: field '%s' in file %s in <%s>"
-msgstr "Giá trị es không hợp lệ : trường '%s' trong tập tin %s trong <%s>"
+msgstr ""
 #: ../lib/gis/get_ellipse.c:383
 #, c-format
 msgid "No ellipsoid info given in file %s in <%s>"
-msgstr "Thông tin về ellipsoid không được cung cấp trong tập tin %s trong <%s>"
+msgstr ""
 #: ../lib/gis/parser_help.c:84
-#, fuzzy
 msgid "Description:"
 msgstr ""
-"\n"
-"Mô tả:\n"
 #: ../lib/gis/parser_help.c:103
-#, fuzzy
 msgid "Keywords:"
 msgstr ""
-"\n"
-"Các từ khóa:\n"
 #: ../lib/gis/parser_help.c:111
-#, fuzzy
 msgid "Usage:"
 msgstr ""
-"\n"
-"Cách dùng:\n"
 #: ../lib/gis/parser_help.c:141
-#, fuzzy
 msgid "ERROR: Option key not defined"
-msgstr "Đối tượng OGR không có ID bị bỏ qua"
+msgstr ""
 #: ../lib/gis/parser_help.c:191
-#, fuzzy
 msgid "Flags:"
-msgstr "Các cờ"
+msgstr ""
 #: ../lib/gis/parser_help.c:220
-#, fuzzy
 msgid "Super quiet module output"
+msgstr ""
 #: ../lib/gis/parser_help.c:221 ../lib/gis/parser_html.c:180
 msgid "Force launching GUI dialog"
 msgstr ""
 #: ../lib/gis/parser_help.c:230
-#, fuzzy
 msgid "Parameters:"
+msgstr ""
 #: ../lib/gis/parser_help.c:253
 #, c-format
 msgid "  %*s   default: %s\n"
-msgstr "  %*s    mặc định: %s\n"
+msgstr ""
 #: ../lib/gis/parser_help.c:279
 #, c-format
 msgid "  %*s   options: "
-msgstr "  %*s   tùy chọn: "
+msgstr ""
 #: ../lib/gis/list.c:83
 #, c-format
 msgid "no %s files available in current mapset\n"
-msgstr "không có tập tin %s dùng được trong bộ bản đồ hiện tại\n"
+msgstr ""
 #: ../lib/gis/list.c:86
 #, c-format
 msgid "no %s files available in mapset <%s>\n"
-msgstr "không có tập tin %s dùng được trong bộ bản đồ <%s>\n"
+msgstr ""
 #: ../lib/gis/list.c:132
 #, c-format
 msgid "%s files available in mapset <%s>:\n"
-msgstr "Các tập tin %s dùng được trong bộ bản đồ <%s>:\n"
+msgstr ""
 #: ../lib/gis/list.c:204
 msgid "G_list: Unknown element type"
-msgstr "G_list: kiểu thành phần không hiểu"
+msgstr ""
 #: ../lib/gis/proj3.c:121 ../lib/vector/Vlib/header.c:552
 msgid "Unknown projection"
-msgstr "Phép chiếu không biết"
+msgstr "Phép chiếu không rõ"
 #: ../lib/gis/mapset_msc.c:90
 #, c-format
 msgid "Unable to make mapset element %s (%s): %s"
-msgstr "Không thể tạo thành phần cho bộ bản đồ %s (%s): %s"
+msgstr ""
 #: ../lib/gis/mapset_msc.c:94
 #, c-format
 msgid "Unable to access mapset element %s (%s): %s"
-msgstr "Không thể truy cập thành phần của bộ bản đồ %s (%s): %s"
+msgstr ""
 #: ../lib/gis/home.c:39
-#, fuzzy
 msgid "Unable to determine user's home directory"
-msgstr "không thể xác định thư mục home của người dùng"
+msgstr ""
 #: ../lib/gis/home.c:120
-#, fuzzy, c-format
+#, c-format
 msgid "Failed to create directory [%s]"
-msgstr "Không thể loại bỏ thư mục '%s'"
+msgstr ""
 #: ../lib/gis/open.c:68
 #, c-format
 msgid "G__open(read): mapset <%s> doesn't match xmapset <%s>"
+msgstr ""
 #: ../lib/gis/open.c:89
-#, fuzzy, c-format
+#, c-format
 msgid "G__open(read): Unable to open '%s': %s"
-msgstr "Không thể mở '%s'"
+msgstr ""
 #: ../lib/gis/open.c:98
 #, c-format
@@ -4515,9 +4139,9 @@
 msgstr ""
 #: ../lib/gis/open.c:122
-#, fuzzy, c-format
+#, c-format
 msgid "G__open(write): Unable to open '%s': %s"
-msgstr "G_spawn: không thể mở tập tin %s"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:147
 msgid "SQL SELECT statement"
@@ -4529,7 +4153,7 @@
 #: ../lib/gis/parser_standard_options.c:156
 msgid "WHERE conditions of SQL statement without 'where' keyword"
-msgstr "Các điều kiện WHERE của câu lệnh SQL không có từ khóa 'where'"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:157
 #, fuzzy
@@ -4537,42 +4161,36 @@
 msgstr "Ví dụ : income < 1000 and inhab >= 10000"
 #: ../lib/gis/parser_standard_options.c:165
-#, fuzzy
 msgid "Name of attribute table"
-msgstr "Tên của cột thuộc tính"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:174
-#, fuzzy
 msgid "Name of database driver"
-msgstr "Tên của bản đồ raster gốc"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:183
-#, fuzzy
 msgid "Name of database"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:192
-#, fuzzy
 msgid "Database schema"
-msgstr "Tên csdl"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:193
-msgid ""
-"Do not use this option if schemas are not supported by driver/database server"
+msgid "Do not use this option if schemas are not supported by driver/database server"
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:202
 msgid "Name of attribute column"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:211
 msgid "Name of attribute column(s)"
-msgstr "Tên của (các) cột thuộc tính"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:220
-#, fuzzy
 msgid "Name of key column"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:221
 msgid "Must refer to an integer column"
@@ -4580,66 +4198,59 @@
 #: ../lib/gis/parser_standard_options.c:233
 msgid "Name of input imagery group"
-msgstr "Tên của nhóm ảnh đầu vào"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:241
 msgid "Name of input imagery subgroup"
-msgstr "Tên của nhóm ảnh con đầu vào"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:251
 msgid "Name of input raster map"
-msgstr "Tên của bản đồ raster đầu vào"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:260
 msgid "Name of input raster map(s)"
-msgstr "Tên của (các) bản đồ raster đầu vào"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:268
 msgid "Name for output raster map"
-msgstr "Tên của bản đồ raster đầu ra"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:277
-#, fuzzy
 msgid "Name for output raster map(s)"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:285
-#, fuzzy
 msgid "Name of raster map"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:294
-#, fuzzy
 msgid "Name of raster map(s)"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:302
 msgid "Name of base raster map"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:310
 msgid "Name of cover raster map"
-msgstr "Tên của bản đồ raster lớp phủ"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:318
-#, fuzzy
 msgid "Name of input elevation raster map"
-msgstr "Tên của bản đồ raster độ cao"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:327
-#, fuzzy
 msgid "Name of input elevation raster map(s)"
-msgstr "Tên của (các) bản đồ raster độ cao"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:334
-#, fuzzy
 msgid "Type of raster map to be created"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:335
-#, fuzzy
 msgid "Storage type for resultant raster map"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:339
 msgid "Integer"
@@ -4654,86 +4265,68 @@
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:347
-#, fuzzy
 msgid "Sampling interpolation method"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:351
-#, fuzzy
 msgid "Nearest-neighbor interpolation"
-msgstr "Cần ít nhất 2 khung chính để dùng cho việc nội suy"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:352
-#, fuzzy
 msgid "Bilinear interpolation"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:353
-#, fuzzy
 msgid "Bicubic interpolation"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:362
-#, fuzzy
 msgid "Name of input basename raster map(s)"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:371
-#, fuzzy
 msgid "Name for output basename raster map(s)"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:381
-#, fuzzy
 msgid "Name of input 3D raster map"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:390
-#, fuzzy
 msgid "Name of input 3D raster map(s)"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:398
-#, fuzzy
 msgid "Name for output 3D raster map"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:406
-#, fuzzy
 msgid "Name of 3D raster map"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:415
-#, fuzzy
 msgid "Name of 3D raster map(s)"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:424
-#, fuzzy
 msgid "Data type used in the output raster3d map"
-msgstr "Kiểu dữ liệu được dùng trong tập tin đầu ra"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:433
-msgid ""
-"Number of digits used as mantissa in the internal map storage, 0 -23 for "
-"float, 0 - 52 for double, max or default"
+msgid "Number of digits used as mantissa in the internal map storage, 0 -23 for float, 0 - 52 for double, max or default"
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:443
-#, fuzzy
 msgid "The compression method used in the output raster3d map"
-msgstr "Phương pháp nén được dùng trong tập tin đầu ra"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:453
-#, fuzzy
-msgid ""
-"The dimensions of the tiles used in the output raster3d map (XxYxZ or "
-"default: 16x16x8)"
-msgstr "Kích thước của các 'viên lát' trong tập tin đầu ra"
+msgid "The dimensions of the tiles used in the output raster3d map (XxYxZ or default: 16x16x8)"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:463
 msgid "Name of input vector map"
-msgstr "Tên của bản đồ vec-tơ đầu vào"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:464
 #: ../lib/gis/parser_standard_options.c:491
@@ -4742,7 +4335,7 @@
 #: ../lib/gis/parser_standard_options.c:473
 msgid "Name of input vector map(s)"
-msgstr "Tên của (các) bản đồ vec-tơ đầu vào"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:474
 msgid "Or data source(s) for direct OGR access"
@@ -4750,89 +4343,70 @@
 #: ../lib/gis/parser_standard_options.c:482
 msgid "Name for output vector map"
-msgstr "Tên của bản đồ vec-tơ đầu ra"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:490
-#, fuzzy
 msgid "Name of vector map"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:500
-#, fuzzy
 msgid "Name of vector map(s)"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:509
 #: ../lib/gis/parser_standard_options.c:518
-#, fuzzy
 msgid "Input feature type"
-msgstr "Kiểu đối tượng"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:525
-#, fuzzy
 msgid "Layer number or name"
-msgstr "Lớp số"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:527
-#, fuzzy
-msgid ""
-"Vector features can have category values in different layers. This number "
-"determines which layer to use. When used with direct OGR access this is the "
-"layer name."
+msgid "Vector features can have category values in different layers. This number determines which layer to use. When used with direct OGR access this is the layer name."
 msgstr ""
-"Một bản đồ vec-tơ duy nhất có thể được kết nối với nhiều bảng csdl. Con số "
-"này quyết định sử dụng bảng nào."
 #: ../lib/gis/parser_standard_options.c:537
-#, fuzzy
 msgid "Layer number or name ('-1' for all layers)"
-msgstr "Số lượng lớp %d hoặc tên <%s> đã có"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:539
-#, fuzzy
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use. When used with direct OGR access this "
-"is the layer name."
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use. When used with direct OGR access this is the layer name."
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:548
 msgid "Category value"
-msgstr "Giá trị phạm trù"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:556
 msgid "Category values"
-msgstr "Các giá trị phạm trù"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:557
 #: ../lib/gis/parser_standard_options.c:572
 msgid "Example: 1,3,7-9,13"
-msgstr "Ví dụ: 1,3,7-9,13"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:564
 msgid "Feature id"
-msgstr "id đối tượng"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:571
 msgid "Feature ids"
-msgstr "Các id đối tượng"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:582
 #: ../lib/gis/parser_standard_options.c:590
-#, fuzzy
 msgid "Name of input file"
-msgstr "Tên của tập tin đầu vào"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:598
-#, fuzzy
 msgid "Name for output file"
-msgstr "Tên của tập tin đầu ra"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:607
 msgid "Field separator"
-msgstr "Dấu phân cách trường"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:608
 msgid "Special characters: pipe, comma, space, tab, newline"
@@ -4841,21 +4415,19 @@
 #: ../lib/gis/parser_standard_options.c:619
 #: ../lib/gis/parser_standard_options.c:630
 msgid "Color"
-msgstr "Màu"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:621
 msgid "Either a standard color name or R:G:B triplet"
-msgstr "Hoặc là một màu chuẩn hoặc là bộ ba R:G:B"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:632
-#, fuzzy
 msgid "Either a standard color name, R:G:B triplet, or \"none\""
-msgstr "Hoặc là một màu GRASS chuẩn, bộ ba R:G:B, hoặc \"none\""
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:643
-#, fuzzy
 msgid "Name of input directory"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:653
 msgid "Units"
@@ -4890,115 +4462,92 @@
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:705
-#, fuzzy
 msgid "Coordinates"
-msgstr "Tọa độ không hợp lệ"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:714
-#, fuzzy
 msgid "Name of color table"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:725
 msgid "String representing NULL value"
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:734
-#, fuzzy
 msgid "Name of saved region"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:744
-#, fuzzy
 msgid "Name of the input space time dataset"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:753
-#, fuzzy
 msgid "Name of the input space time datasets"
-msgstr "'Bọ': cố gắng cập nhật bản đồ không ở trong bộ bản đồ hiện tại."
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:761
-#, fuzzy
 msgid "Name of the output space time dataset"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:769
-#, fuzzy
 msgid "Name of the input space time raster dataset"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:778
-#, fuzzy
 msgid "Name of the input space time raster datasets"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:786
-#, fuzzy
 msgid "Name of the output space time raster dataset"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:794
-#, fuzzy
 msgid "Name of the input space time vector dataset"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:803
-#, fuzzy
 msgid "Name of the input space time vector datasets"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:811
-#, fuzzy
 msgid "Name of the output space time vector dataset"
-msgstr "Không đủ không gian trong mảng vec-tơ"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:819
-#, fuzzy
 msgid "Name of the input space time raster3d dataset"
-msgstr "Tên của bản đồ raster 3d đầu vào"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:828
-#, fuzzy
 msgid "Name of the input space time raster3d datasets"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:836
-#, fuzzy
 msgid "Name of the output space time raster3d dataset"
-msgstr "Tên của bản đồ raster 3d đầu ra"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:845
-#, fuzzy
 msgid "Type of the input space time dataset"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:853
-#, fuzzy
 msgid "Name of the input map"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:862
-#, fuzzy
 msgid "Name of the input maps"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:871
-#, fuzzy
 msgid "Type of the input map"
-msgstr "Không thể đóng bản đồ đầu vào"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:880
-#, fuzzy
 msgid "The temporal type of the space time dataset"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:887
-#, fuzzy
-msgid ""
-"WHERE conditions of SQL statement without 'where' keyword used in the "
-"temporal GIS framework"
+msgid "WHERE conditions of SQL statement without 'where' keyword used in the temporal GIS framework"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:888
 msgid "Example: start_time > '2001-01-01 12:30:00'"
@@ -5009,23 +4558,21 @@
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:932
-#, fuzzy
 msgid "Do not create attribute table"
-msgstr "Đang nạp dữ liệu từ bảng thuộc tính..."
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:936
-#, fuzzy
 msgid "Do not build topology"
-msgstr "Đang xây dựng tôpô ...\n"
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:937
 msgid "Advantageous when handling a large number of points"
 msgstr ""
 #: ../lib/gis/get_window.c:118
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open element file <%s> for <%s@%s>"
+msgstr ""
 #: ../lib/gis/get_window.c:123
 #, c-format
@@ -5035,27 +4582,27 @@
 #: ../lib/gis/debug.c:80
 #, c-format
 msgid "Cannot open debug file '%s'"
-msgstr "Không thể mở tập tin gỡ lỗi '%s'"
+msgstr ""
 #: ../lib/gis/alloc.c:44 ../lib/gis/alloc.c:86 ../lib/gis/alloc.c:132
-#, fuzzy, c-format
+#, c-format
 msgid "Current region rows: %d, cols: %d"
-msgstr "Hàng null hiện tại trong bộ nhớ %d"
+msgstr ""
 #: ../lib/gis/alloc.c:47
-#, fuzzy, c-format
+#, c-format
 msgid "G_malloc: unable to allocate %lu bytes of memory at %s:%d"
-msgstr "G_malloc: không thể cấp phát %lu byte tại %s:%d"
+msgstr ""
 #: ../lib/gis/alloc.c:89
-#, fuzzy, c-format
+#, c-format
 msgid "G_calloc: unable to allocate %lu * %lu bytes of memory at %s:%d"
-msgstr "G_malloc: không thể cấp phát %lu* %lu byte tại %s:%d"
+msgstr ""
 #: ../lib/gis/alloc.c:135
-#, fuzzy, c-format
+#, c-format
 msgid "G_realloc: unable to allocate %lu bytes of memory at %s:%d"
-msgstr "G_realloc: không thể cấp phát %lu byte tại %s:%d"
+msgstr ""
 #: ../lib/gis/units.c:208
 msgid "square units"
@@ -5074,24 +4621,20 @@
 msgstr ""
 #: ../lib/gis/units.c:215
-#, fuzzy
 msgid "square meters"
+msgstr ""
-#, fuzzy
 msgid "square meter"
+msgstr ""
 #: ../lib/gis/units.c:217
-#, fuzzy
 msgid "meters"
+msgstr ""
-#, fuzzy
 msgid "meter"
+msgstr ""
 #: ../lib/gis/units.c:222
 msgid "square kilometers"
@@ -5102,9 +4645,8 @@
 msgstr ""
 #: ../lib/gis/units.c:224
-#, fuzzy
 msgid "kilometers"
+msgstr ""
 msgid "kilometer"
@@ -5159,14 +4701,12 @@
 msgstr ""
 #: ../lib/gis/units.c:259
-#, fuzzy
 msgid "square US feet"
+msgstr ""
-#, fuzzy
 msgid "square US foot"
+msgstr ""
 #: ../lib/gis/units.c:261
 msgid "US feet"
@@ -5241,61 +4781,53 @@
 msgstr ""
 #: ../lib/gis/parser.c:355
-#, fuzzy, c-format
+#, c-format
 msgid "BUG in option name, '%s' is not valid"
-msgstr "'BỌ' trong các mô tả, tùy chọn '%s' trong <%s> không tồn tại"
+msgstr ""
 #: ../lib/gis/parser.c:407
 #, c-format
 msgid "BUG in descriptions, option '%s' in <%s> does not exist"
+msgstr ""
 #: ../lib/gis/parser.c:525
 msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
 msgstr ""
-"Dùng cờ --quiet hoặc --verbose, không được dùng cả hai. Giả định dùng --"
-"verbose."
 #: ../lib/gis/parser.c:539
 msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
 msgstr ""
-"quiet."
 #: ../lib/gis/parser.c:554
-#, fuzzy
 msgid "Use either --qq or --verbose flag, not both. Assuming --qq."
 msgstr ""
-"quiet."
 #: ../lib/gis/parser.c:585
-#, fuzzy, c-format
+#, c-format
 msgid "Sorry <%s> is not a valid option"
-msgstr "Xin lỗi <%s> không phải là tùy chọn hợp lệ\n"
+msgstr ""
 #: ../lib/gis/parser.c:598
 msgid "Your installation doesn't include GUI, exiting."
 msgstr ""
 #: ../lib/gis/parser.c:621 ../lib/init/grass.py:187
-#, fuzzy
 msgid "ERROR"
-msgstr "LỖI: "
+msgstr ""
 #: ../lib/gis/parser.c:941
 msgid "Unable to determine program name"
-msgstr "Không thể xác định tên chương trình"
+msgstr ""
 #: ../lib/gis/parser.c:963 ../lib/gis/parser.c:980
-#, fuzzy, c-format
+#, c-format
 msgid "%s: Sorry, <%c> is not a valid flag"
-msgstr "Xin lỗi, <%c> không phải là cờ hợp lệ\n"
+msgstr ""
 #: ../lib/gis/parser.c:1110
-#, fuzzy, c-format
+#, c-format
 msgid "%s: Sorry, <%s=> is ambiguous"
-msgstr "Xin lỗi, <%s=> không rõ ràng\n"
+msgstr ""
 #: ../lib/gis/parser.c:1113
 #, c-format
@@ -5308,14 +4840,14 @@
 msgstr ""
 #: ../lib/gis/parser.c:1144
-#, fuzzy, c-format
+#, c-format
 msgid "%s: Sorry, <%s> is not a valid parameter"
-msgstr "Xin lỗi, <%s> không phải là tham số hợp lệ\n"
+msgstr ""
 #: ../lib/gis/parser.c:1150 ../lib/gis/parser.c:1396
-#, fuzzy, c-format
+#, c-format
 msgid "<%s> is an abbreviation for <%s>"
+msgstr ""
 #: ../lib/gis/parser.c:1155
 #, c-format
@@ -5323,62 +4855,49 @@
 msgstr ""
 #: ../lib/gis/parser.c:1227
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Illegal range syntax for parameter <%s>\n"
 "\tPresented as: %s"
 msgstr ""
-"\n"
LỖI: Cú pháp miền cho tham số <%s> không hợp lệ\n"
 #: ../lib/gis/parser.c:1233
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Value <%s> out of range for parameter <%s>\n"
 "\tLegal range: %s"
 msgstr ""
-"\n"
LỖI: giá trị <%s> nằm ngoài miền đối với tham số <%s>\n"
 #: ../lib/gis/parser.c:1239
-#, fuzzy, c-format
+#, c-format
 msgid "Missing value for parameter <%s>"
 msgstr ""
-"\n"
-"LỖI: Giá trị cho tham số <%s> bị thiếu\n"
 #: ../lib/gis/parser.c:1245
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Value <%s> ambiguous for parameter <%s>\n"
 "\tValid options: %s"
 msgstr ""
-"\n"
-"Lỗi: giá trị <%s> nằm ngoài miền cho tham số <%s>\n"
 #: ../lib/gis/parser.c:1418
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Required parameter <%s> not set:\n"
 "\t(%s)"
 msgstr ""
-"\n"
-"LỖI: Tham số yêu cầu <%s> không được thiết lập:\n"
-"    (%s).\n"
 #: ../lib/gis/parser.c:1510
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Option <%s> must be provided in multiples of %d\n"
 "\tYou provided %d item(s): %s"
 msgstr ""
-"\n"
LỖI: tùy chọn <%s> phải được cung cấp ở dạng bội số của %d\n"
 #: ../lib/gis/parser.c:1584 ../lib/gis/error.c:362
 #, c-format
 msgid "ERROR: "
-msgstr "LỖI: "
+msgstr ""
 #: ../lib/gis/parser.c:1586 ../lib/gis/parser.c:1593
 #, c-format
@@ -5386,139 +4905,135 @@
 msgstr ""
 #: ../lib/gis/parser.c:1703
-#, fuzzy, c-format
+#, c-format
 msgid "%s= is not a separator option"
+msgstr ""
 #: ../lib/gis/parser.c:1706
-#, fuzzy, c-format
+#, c-format
 msgid "No separator given for %s="
+msgstr ""
 #: ../lib/gis/parser.c:1768 ../lib/gis/parser.c:1785
-#, fuzzy, c-format
+#, c-format
 msgid "%s= is not a file option"
+msgstr ""
 #: ../lib/gis/parser.c:1770
-#, fuzzy, c-format
+#, c-format
 msgid "Opening multiple files not supported for %s="
+msgstr ""
 #: ../lib/gis/parser.c:1776
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open %s file <%s>"
+msgstr ""
 #: ../lib/gis/parser.c:1782
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create %s file <%s>"
-msgstr "Không thể tạo bảng <%s>"
+msgstr ""
 #: ../lib/gis/worker.c:84
 msgid "Task already has a worker"
 msgstr ""
 #: ../lib/gis/adj_cellhd.c:42
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal n-s resolution value <%lf>"
-msgstr "Giá trị độ phân giải B-N không hợp lệ"
+msgstr ""
 #: ../lib/gis/adj_cellhd.c:46 ../lib/gis/adj_cellhd.c:197
 msgid "Illegal row value"
-msgstr "Giá trị hàng không hợp lệ"
+msgstr ""
 #: ../lib/gis/adj_cellhd.c:50 ../lib/gis/adj_cellhd.c:203
 msgid "Illegal e-w resolution value"
-msgstr "Giá trị độ phân giải Đ-T không hợp lệ"
+msgstr ""
 #: ../lib/gis/adj_cellhd.c:54 ../lib/gis/adj_cellhd.c:209
 msgid "Illegal col value"
-msgstr "Giá trrị cột không hợp lệ"
+msgstr ""
 #: ../lib/gis/adj_cellhd.c:74 ../lib/gis/adj_cellhd.c:239
 #, c-format
 msgid "Fixing subtle input data rounding error of north boundary (%g>%g)"
 msgstr ""
-"Đang chỉnh sửa sai số làm tròn dữ liệu đầu vào của ranh giới bắc (%g>%g)"
 #: ../lib/gis/adj_cellhd.c:79 ../lib/gis/adj_cellhd.c:244
 msgid "Illegal latitude for North"
-msgstr "Vĩ độ cho cận Bắc không hợp lệ"
+msgstr ""
 #: ../lib/gis/adj_cellhd.c:85 ../lib/gis/adj_cellhd.c:250
 #, c-format
 msgid "Fixing subtle input data rounding error of south boundary (%g>%g)"
 msgstr ""
-"Đang chỉnh sửa sai số làm tròn dữ liệu đầu vào của ranh giới nam (%g>%g)"
 #: ../lib/gis/adj_cellhd.c:90 ../lib/gis/adj_cellhd.c:255
 msgid "Illegal latitude for South"
-msgstr "Vĩ độ cho cận Nam không hợp lệ"
+msgstr ""
 #: ../lib/gis/adj_cellhd.c:102 ../lib/gis/adj_cellhd.c:267
 #, c-format
 msgid "Fixing subtle input data rounding error of west boundary (%g>%g)"
 msgstr ""
-"Đang chỉnh sửa sai số làm tròn dữ liệu đầu vào của ranh giới tây (%g>%g)"
 #: ../lib/gis/adj_cellhd.c:113 ../lib/gis/adj_cellhd.c:278
 #, c-format
 msgid "Fixing subtle input data rounding error of east boundary (%g>%g)"
 msgstr ""
-"Đang chỉnh sửa sai số làm tròn dữ liệu đầu vào của ranh giới đông (%g>%g)"
 #: ../lib/gis/adj_cellhd.c:126 ../lib/gis/adj_cellhd.c:291
 msgid "North must be north of South"
-msgstr "Cận Bắc phải ở phía bắc của cận Nam"
+msgstr ""
 #: ../lib/gis/adj_cellhd.c:128 ../lib/gis/adj_cellhd.c:293
 msgid "North must be larger than South"
-msgstr "Cận Bắc phải lớn hơn cận Nam"
+msgstr ""
 #: ../lib/gis/adj_cellhd.c:131 ../lib/gis/adj_cellhd.c:296
 msgid "East must be larger than West"
-msgstr "Cận Đông phải lớn hơn cận Tây"
+msgstr ""
 #: ../lib/gis/adj_cellhd.c:150 ../lib/gis/adj_cellhd.c:340
 msgid "Invalid coordinates"
+msgstr ""
 #: ../lib/gis/adj_cellhd.c:191
 msgid "Illegal n-s resolution value"
+msgstr ""
 #: ../lib/gis/adj_cellhd.c:193
 msgid "Illegal n-s3 resolution value"
-msgstr "Giá trị độ phân giải bắc-nam 3d không hợp lệ"
+msgstr ""
 #: ../lib/gis/adj_cellhd.c:199
 msgid "Illegal row3 value"
-msgstr "Giá trị hàng 3d không hợp lệ"
+msgstr ""
 #: ../lib/gis/adj_cellhd.c:205
 msgid "Illegal e-w3 resolution value"
-msgstr "Giá trị độ phân giải đông-tây 3d không hợp lệ"
+msgstr ""
 #: ../lib/gis/adj_cellhd.c:211
 msgid "Illegal col3 value"
-msgstr "Giá trị cột 3d không hợp lệ"
+msgstr ""
 #: ../lib/gis/adj_cellhd.c:215
 msgid "Illegal t-b3 resolution value"
-msgstr "Giá trị độ phân giải trên-dưới 3d không hợp lệ"
+msgstr ""
 #: ../lib/gis/adj_cellhd.c:219
 msgid "Illegal depths value"
-msgstr "Giá trị độ sâu không hợp lệ"
+msgstr ""
 #: ../lib/gis/adj_cellhd.c:299
 msgid "Top must be larger than Bottom"
-msgstr "Cận trên phải lớn hơn cận dưới"
+msgstr ""
 #: ../lib/gis/myname.c:46
 msgid "This location has no description."
-msgstr "Location này không có mô tả."
+msgstr ""
 #: ../lib/gis/rd_cellhd.c:141 ../lib/gis/rd_cellhd.c:152
 #: ../lib/gis/rd_cellhd.c:162 ../lib/gis/rd_cellhd.c:179
@@ -5542,14 +5057,12 @@
 #: ../lib/gis/rd_cellhd.c:149
-#, fuzzy
 msgid "Duplicate projection field"
-msgstr "trường phép chiếu bị đúp"
+msgstr ""
 #: ../lib/gis/rd_cellhd.c:159
-#, fuzzy
 msgid "Duplicate zone field"
-msgstr "trường múi bị đúp"
+msgstr ""
 #: ../lib/gis/rd_cellhd.c:169 ../lib/gis/rd_cellhd.c:171
 #: ../lib/gis/rd_cellhd.c:360 ../lib/gis/rd_cellhd.c:362
@@ -5557,115 +5070,96 @@
 #: ../lib/gis/rd_cellhd.c:368 ../lib/gis/rd_cellhd.c:370
 #: ../lib/gis/rd_cellhd.c:381 ../lib/gis/rd_cellhd.c:383
 #: ../lib/gis/rd_cellhd.c:385 ../lib/gis/rd_cellhd.c:387
-#, fuzzy, c-format
+#, c-format
 msgid "Field <%s> missing"
-msgstr "trường múi bị thiếu"
+msgstr ""
 #: ../lib/gis/rd_cellhd.c:193
-#, fuzzy
 msgid "Duplicate north field"
-msgstr "trường bắc bị đúp"
+msgstr ""
 #: ../lib/gis/rd_cellhd.c:201
-#, fuzzy
 msgid "Duplicate south field"
-msgstr "trường nam bị đúp"
+msgstr ""
 #: ../lib/gis/rd_cellhd.c:209
-#, fuzzy
 msgid "Duplicate east field"
-msgstr "trường đông bị đúp"
+msgstr ""
 #: ../lib/gis/rd_cellhd.c:217
-#, fuzzy
 msgid "Duplicate west field"
-msgstr "trường tây bị đúp"
+msgstr ""
 #: ../lib/gis/rd_cellhd.c:225
-#, fuzzy
 msgid "Duplicate top field"
-msgstr "trường trên bị đúp"
+msgstr ""
 #: ../lib/gis/rd_cellhd.c:233
-#, fuzzy
 msgid "Duplicate bottom field"
-msgstr "trường dưới bị đúp"
+msgstr ""
 #: ../lib/gis/rd_cellhd.c:241
-#, fuzzy
 msgid "Duplicate e-w resolution field"
-msgstr "trường độ phân giải đông-tây bị đúp"
+msgstr ""
 #: ../lib/gis/rd_cellhd.c:251
-#, fuzzy
 msgid "Duplicate 3D e-w resolution field"
-msgstr "trường độ phân giải đông-tây 3D bị đúp"
+msgstr ""
 #: ../lib/gis/rd_cellhd.c:261
-#, fuzzy
 msgid "Duplicate n-s resolution field"
-msgstr "trường độ phân giải bắc-nam bị đúp"
+msgstr ""
 #: ../lib/gis/rd_cellhd.c:271
-#, fuzzy
 msgid "Duplicate 3D n-s resolution field"
-msgstr "trường độ phân giải bắc-nam 3D bị đúp"
+msgstr ""
 #: ../lib/gis/rd_cellhd.c:281
-#, fuzzy
 msgid "Duplicate t-b resolution field"
-msgstr "trường độ phân giải trên-dưới bị đúp"
+msgstr ""
 #: ../lib/gis/rd_cellhd.c:291
-#, fuzzy
 msgid "Duplicate rows field"
-msgstr "trường hàng bị đúp"
+msgstr ""
 #: ../lib/gis/rd_cellhd.c:301
-#, fuzzy
 msgid "Duplicate 3D rows field"
-msgstr "trường hàng 3D bị đúp"
+msgstr ""
 #: ../lib/gis/rd_cellhd.c:311
-#, fuzzy
 msgid "Duplicate cols field"
-msgstr "trường cột bị đúp"
+msgstr ""
 #: ../lib/gis/rd_cellhd.c:321
-#, fuzzy
 msgid "Duplicate 3D cols field"
-msgstr "trường cột 3D bị đúp"
+msgstr ""
 #: ../lib/gis/rd_cellhd.c:331
-#, fuzzy
 msgid "Duplicate depths field"
-msgstr "trường độ sâu bị đúp"
+msgstr ""
 #: ../lib/gis/rd_cellhd.c:341
-#, fuzzy
 msgid "Duplicate format field"
-msgstr "trường định dạng bị đúp"
+msgstr ""
 #: ../lib/gis/rd_cellhd.c:349
-#, fuzzy
 msgid "Duplicate compressed field"
-msgstr "trường nén bị đúp"
+msgstr ""
 #: ../lib/gis/datum.c:160
 #, c-format
 msgid "unable to open datum table file: %s"
-msgstr "không thể mở tập tin bảng mốc tọa độ chuẩn: %s"
+msgstr ""
 #: ../lib/gis/datum.c:182
 #, c-format
 msgid "error in datum table file, line %d"
-msgstr "lỗi trong tập tin bảng mốc tọa độ chuẩn, dòng %d"
+msgstr ""
 #: ../lib/gis/open_misc.c:49
 #, c-format
 msgid "G__open_misc(read): mapset <%s> doesn't match xmapset <%s>"
 msgstr ""
-"G__open_misc(read): bộ bản đồ <%s> không khớp với bộ bản đồ xmapset <%s>"
 #: ../lib/gis/open_misc.c:74
 #, c-format
@@ -5674,17 +5168,16 @@
 #: ../lib/gis/mapset.c:38
 msgid "MAPSET is not set"
-msgstr "BỘ BẢN ĐỒ không được thiết lập"
+msgstr ""
 #: ../lib/gis/mapset.c:80
-#, fuzzy, c-format
+#, c-format
 msgid "MAPSET <%s> not available"
+msgstr ""
 #: ../lib/gis/mkstemp.c:132
-#, fuzzy
 msgid "Attempt to create read-only temporary file"
-msgstr "Cố gắng xoá đối tượng chết"
+msgstr ""
 #: ../lib/gis/mkstemp.c:138
 #, c-format
@@ -5694,173 +5187,166 @@
 #: ../lib/gis/get_projinfo.c:37 ../lib/gis/get_projinfo.c:66
 #, c-format
 msgid "<%s> file not found for location <%s>"
-msgstr "Không tìm thấy tập tin <%s> cho vị trí <%s>"
+msgstr ""
 #: ../lib/gis/color_rules.c:88
-#, fuzzy
 msgid "no description"
 msgstr ""
-"\n"
-"Mô tả:\n"
 #: ../lib/gis/spawn.c:386
 #, c-format
 msgid "CreateProcess() failed: error = %d"
-msgstr "CreateProcess() thất bại: lỗi = %d"
+msgstr ""
 #: ../lib/gis/spawn.c:421
 #, c-format
 msgid "G_spawn: unable to redirect descriptor %d"
-msgstr "G_spawn: không thể chuyển hướng trình mô tả %d"
+msgstr ""
 #: ../lib/gis/spawn.c:429 ../lib/gis/spawn.c:619
 #, c-format
 msgid "G_spawn: unable to open file %s"
+msgstr ""
 #: ../lib/gis/spawn.c:503 ../lib/gis/spawn.c:689
 msgid "Unable to execute command"
-msgstr "Không thể thực thi lệnh"
+msgstr ""
 #: ../lib/gis/spawn.c:528 ../lib/gis/spawn.c:536
 #, c-format
 msgid "G_spawn: unable to restore signal %d"
-msgstr "G_spawn: không thể khôi phục tín hiệu %d"
+msgstr ""
 #: ../lib/gis/spawn.c:567
 #, c-format
 msgid "G_spawn: unable to reset signal %d"
-msgstr "G_spawn: không thể thiết lập lại tín hiệu %d"
+msgstr ""
 #: ../lib/gis/spawn.c:576
 #, c-format
 msgid "G_spawn: unable to ignore signal %d"
-msgstr "G_spawn: không thể bỏ qua tín hiệu %d"
+msgstr ""
 #: ../lib/gis/spawn.c:587
 #, c-format
 msgid "G_spawn: unable to block signal %d"
-msgstr "G_spawn: không thể chặn tín hiệu %d"
+msgstr ""
 #: ../lib/gis/spawn.c:595
 #, c-format
 msgid "G_spawn: unable to unblock signal %d"
-msgstr "G_spawn: không thể mở khóa tín hiệu %d"
+msgstr ""
 #: ../lib/gis/spawn.c:624 ../lib/gis/spawn.c:633
 #, c-format
 msgid "G_spawn: unable to duplicate descriptor %d to %d"
-msgstr "G_spawn: không thể sao lặp lại mô tả %d tới %d"
+msgstr ""
 #: ../lib/gis/spawn.c:666
 msgid "Unable to create a new process"
-msgstr "Không thể tạo một quá trình mới"
+msgstr ""
 #: ../lib/gis/spawn.c:681
 #, c-format
 msgid "Unable to change directory to %s"
-msgstr "Không thể đổi thư mục đến %s"
+msgstr ""
 #: ../lib/gis/error.c:361
 msgid "WARNING: "
-msgstr "CẢNH BÁO: "
+msgstr ""
 #: ../lib/gis/key_value3.c:33
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open output file <%s>: %s"
-msgstr "Không thể mở tập tin bảng mốc tọa độ chuẩn: %s"
+msgstr ""
 #: ../lib/gis/key_value3.c:36
-#, fuzzy, c-format
+#, c-format
 msgid "Error writing file <%s>: %s"
-msgstr "Lỗi khi đang ghi vào tập tin tôpô"
+msgstr ""
 #: ../lib/gis/key_value3.c:39
-#, fuzzy, c-format
+#, c-format
 msgid "Error closing output file <%s>: %s"
-msgstr "Lỗi khi đang đóng tập tin g3d"
+msgstr ""
 #: ../lib/gis/key_value3.c:60
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open input file <%s>: %s"
+msgstr ""
 #: ../lib/gis/key_value3.c:64
-#, fuzzy, c-format
+#, c-format
 msgid "Error reading file <%s>: %s"
+msgstr ""
 #: ../lib/gis/key_value3.c:67
-#, fuzzy, c-format
+#, c-format
 msgid "Error closing input file <%s>: %s"
+msgstr ""
 #: ../lib/gis/gisinit.c:53 ../lib/gis/gisinit.c:87
-#, fuzzy, c-format
-msgid ""
-"Module built against version %s but trying to use version %s. You need to "
-"rebuild GRASS GIS or untangle multiple installations."
+#, c-format
+msgid "Module built against version %s but trying to use version %s. You need to rebuild GRASS GIS or untangle multiple installations."
 msgstr ""
-"Phiên bản thư viện cho mô-đun không tương thích. Bạn cần phải xây dựng lại "
-"GRASS hoặc gỡ rối việc cài đặt nhiều lần."
 #: ../lib/gis/gisinit.c:65
 #, c-format
 msgid "MAPSET %s - permission denied"
-msgstr "BỘ BẢN ĐỒ %s - không được phép "
+msgstr ""
 #: ../lib/gis/gisinit.c:68
-#, fuzzy, c-format
+#, c-format
 msgid "MAPSET %s not found at %s"
-msgstr "không tìm thấy BỘ BẢN ĐỒ %s "
+msgstr ""
 #: ../lib/gis/gisinit.c:102
 msgid "System not initialized. Programmer forgot to call G_gisinit()."
+msgstr ""
 #: ../lib/gis/legal_name.c:39
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal filename <%s>. Cannot start with '.' or be 'NULL'."
-msgstr "Tên tập tin không hợp lệ. Không thể là '.' hay 'NULL'\n"
+msgstr ""
 #: ../lib/gis/legal_name.c:46
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal filename <%s>. Character <%c> not allowed.\n"
-msgstr "Tên tập tin không hợp lệ. Ký tự <%c> không được phép.\n"
+msgstr ""
 #: ../lib/gis/legal_name.c:77 ../lib/gis/legal_name.c:81
 #, c-format
 msgid "Output raster map name <%s> is not valid map name"
-msgstr "Tên bản đồ raster đầu ra <%s> không hợp lệ"
+msgstr ""
 #: ../lib/gis/legal_name.c:118 ../lib/gis/legal_name.c:122
 #, c-format
 msgid "Output raster map <%s> is used as input"
-msgstr "Bản đồ raster đầu ra <%s> được sử dụng làm đầu vào"
+msgstr ""
 #: ../lib/gis/paths.c:201
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open file <%s> for reading"
-msgstr "Không thể mở tập tin <%s> để ghi"
+msgstr ""
 #: ../lib/gis/paths.c:217
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to fetch security info for <%s>"
+msgstr ""
 #: ../lib/gis/parser_dependencies.c:122
 msgid "Internal error: option or flag not found"
 msgstr ""
 #: ../lib/gis/parser_dependencies.c:179
-#, fuzzy, c-format
+#, c-format
 msgid "<%s> or <%s>"
+msgstr ""
-#, fuzzy, c-format
+#, c-format
 msgid "<%s> and <%s>"
-msgstr "<%s> trong bộ bản đồ <%s>"
+msgstr ""
 #: ../lib/gis/parser_dependencies.c:212
 #, c-format
@@ -5900,48 +5386,45 @@
 #: ../lib/gis/view.c:176
 #, c-format
 msgid "Unable to open %s for writing"
-msgstr "Không thể mở %s để ghi"
+msgstr ""
 #: ../lib/gis/view.c:262 ../lib/gis/view.c:479
 #, c-format
 msgid "Unable to open %s for reading"
-msgstr "Không thể mở %s để đọc"
+msgstr ""
 #: ../lib/gis/view.c:465
 #, c-format
 msgid "GRASS window when view was saved:\n"
-msgstr "Cửa sổ GRASS khi màn hình đã được lưu:\n"
+msgstr ""
 #: ../lib/gis/view.c:545
 #, c-format
 msgid " Window saved in \"%s\" is completely outside of current GRASS window."
-msgstr "Cửa sổ đã lưu trong \"%s\" hoàn toàn nằm ngoài cửa sổ GRASS hiện hành."
+msgstr ""
 #: ../lib/gis/view.c:549
 #, c-format
-msgid ""
-" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgid " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
 msgstr ""
-"Chỉ có %d%% của cửa sổ được lưu trong \"%s\" trùng với cửa sổ GRASS hiện "
-"tại. "
 #: ../lib/gpde/n_gwflow.c:436 ../lib/gpde/n_gwflow.c:715
 #, c-format
 msgid "The total sum of the water budget: %g\n"
-msgstr ""
+msgstr "Tổng gộp của ngân sách nước: %g\n"
 #: ../lib/gpde/n_gwflow.c:438 ../lib/gpde/n_gwflow.c:717
 #, c-format
 msgid "The total sum of the water budget is significantly larger then 0: %g\n"
-msgstr ""
+msgstr "Tổng gộp của ngân sách nước lớn hơn 0 nhiều: %g\n"
 #: ../lib/gpde/test/test_main.c:88
 msgid "Performs unit and integration tests for gpde library"
-msgstr "Thực hiện các phép thử tích phân và đơn vị cho thư viện gpde"
+msgstr "Thực hiện các phép thử đơn vị và tính tích phân đối với thư viện gpde"
 #: ../lib/gpde/n_parse_options.c:106
 msgid "The calculation time in seconds"
-msgstr "Thời gian tính toán (bằng giây)"
+msgstr "Thời gian tính toán bằng giây"
 #: ../lib/gpde/n_arrays_io.c:93
 #, c-format
@@ -5950,12 +5433,12 @@
 #: ../lib/gpde/n_arrays_io.c:183
 msgid "N_array_2d * array is empty"
-msgstr "N_array_2d * mảng bị rỗng"
+msgstr "Mảng N_array_2d * bị rỗng"
 #: ../lib/gpde/n_arrays_io.c:202
 #, c-format
 msgid "Write 2d array to raster map <%s>"
-msgstr "Ghi mảng 2d vào bản đồ raster <%s>"
+msgstr "Đang ghi mảng 2d vào bản đồ raster <%s>"
 #: ../lib/gpde/n_arrays_io.c:309
 #, c-format
@@ -5964,56 +5447,55 @@
 #: ../lib/gpde/n_arrays_io.c:364 ../lib/gpde/n_arrays_io.c:464
 msgid "Error closing g3d file"
+msgstr "Lỗi khi đóng tập tin g3d"
 #: ../lib/gpde/n_arrays_io.c:420
 #, c-format
 msgid "Error opening g3d map <%s>"
-msgstr "Lỗi khi đang mở bản đồ g3d <%s>"
+msgstr "Lỗi mở bản đồ g3d <%s>"
 #: ../lib/gpde/n_arrays_io.c:422
 #, c-format
 msgid "Write 3d array to g3d map <%s>"
-msgstr "Ghi mảng 3d vào bản đồ g3d <%s>"
+msgstr "Ghi mảng 3d vào bản đồ 3d <%s>"
 #: ../lib/htmldriver/graph_set.c:97
-#, fuzzy, c-format
+#, c-format
 msgid "html: collecting to file '%s'"
-msgstr "Không thể khởi động tập tin %s"
+msgstr "html: đang thu thập vào tập tin '%s'"
 #: ../lib/htmldriver/graph_set.c:98
 #, c-format
 msgid "html: image size %dx%d"
-msgstr ""
+msgstr "html: kích thước ảnh %d x %d"
 #: ../lib/htmldriver/graph_set.c:111 ../lib/htmldriver/graph_set.c:115
 #: ../lib/htmldriver/graph_set.c:119
 #, c-format
 msgid "html: type '%s'"
-msgstr ""
+msgstr "html: kiểu '%s'"
 #: ../lib/temporal/lib/default_name.c:69
 msgid "Programmer error - only SQLite driver is currently supported"
 msgstr ""
 #: ../lib/temporal/lib/connect.c:110
-#, fuzzy, c-format
+#, c-format
 msgid "Mapset <%s> does not exist."
+msgstr ""
 #: ../lib/arraystats/class.c:19
-#, fuzzy, c-format
+#, c-format
 msgid "Unknown algorithm '%s'"
-msgstr "%s: Thuật toán không biết"
+msgstr ""
 #: ../lib/arraystats/class.c:42
 msgid "Discont algorithm currently not available because of bugs"
-msgstr "Thuật toán Discont hiện tại không dùng được do 'bọ'"
+msgstr ""
 #: ../lib/arraystats/class.c:49
-#, fuzzy
 msgid "Classification algorithm failed"
-msgstr "%s: Lỗi trong thuật toán phân loại"
+msgstr ""
 #: ../lib/arraystats/class.c:227
 msgid "Equiprobable classbreaks currently limited to 10 classes"
@@ -6021,44 +5503,38 @@
 #: ../lib/arraystats/class.c:242
 #, c-format
-msgid ""
-"There are classbreaks outside the range min-max. Number of classes reduced "
-"to %i, but using probabilities for %i classes."
+msgid "There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."
 msgstr ""
-"Có các ngắt lớp nằm ngoài miền nhỏ nhất-lớn nhất. Số lượng nhóm bị giảm "
-"xuống còn %i, nhưng dùng các xác suất cho %i lớp."
 #: ../lib/display/icon.c:80
-#, fuzzy, c-format
+#, c-format
 msgid "Unsupported icon %d"
+msgstr "Biểu tượng %d không được hỗ trợ"
 #: ../lib/display/tran_colr.c:107 ../lib/display/tran_colr.c:109
 #, c-format
 msgid "[%s]: No such color"
-msgstr "[%s]: không có màu như vậy"
+msgstr "[%s]: Không có màu này"
 #: ../lib/display/r_raster.c:98
 #, c-format
 msgid "Both %s and %s are defined. %s will be ignored."
-msgstr ""
+msgstr "Cả %s và %s đều được định nghĩa. %s sẽ bị bỏ qua."
 #: ../lib/display/r_raster.c:131
 #, c-format
-msgid ""
-"Neither %s (managed by d.mon command) nor %s (used for direct rendering) "
-"defined"
-msgstr ""
+msgid "Neither %s (managed by d.mon command) nor %s (used for direct rendering) defined"
+msgstr "Cả %s (do lệnh d.mon quản lý) lẫn %s (dùng để điều hướng kết xuất) đều không được định nghĩa"
 #: ../lib/display/r_raster.c:150
-#, fuzzy, c-format
+#, c-format
 msgid "Unknown display driver <%s>"
-msgstr "Không thể khởi động trình điều khiển <%s>"
+msgstr "Trình điều khiển hiển thị không rõ <%s>"
 #: ../lib/display/r_raster.c:151
-#, fuzzy, c-format
+#, c-format
 msgid "Using display driver <%s>..."
+msgstr "Dùng trình điều khiển hiển thị <%s>..."
 #: ../lib/cluster/c_exec.c:44
 #, c-format
@@ -6080,27 +5556,21 @@
 msgstr ""
 #: ../lib/init/lock.c:60
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to write lockfile %s (%s)"
-msgstr "Không thể mở tập tin %s trong %s"
+msgstr ""
 #: ../lib/init/grass.py:123
-#, fuzzy
 msgid "WARNING"
+msgstr ""
 #: ../lib/init/grass.py:188
-#, fuzzy
 msgid "Exiting..."
-msgstr "Đang thiết lập các chi phí nốt..."
+msgstr ""
 #: ../lib/init/grass.py:332
-#, fuzzy
 msgid "Usage"
 msgstr ""
-"\n"
-"Cách dùng:\n"
 #: ../lib/init/grass.py:334
 msgid "print this help message"
@@ -6119,8 +5589,7 @@
 msgstr ""
 #: ../lib/init/grass.py:338
-msgid ""
-"force removal of .gislock if exists (use with care!). Only with -text flag"
+msgid "force removal of .gislock if exists (use with care!). Only with -text flag"
 msgstr ""
 #: ../lib/init/grass.py:339
@@ -6128,9 +5597,8 @@
 msgstr ""
 #: ../lib/init/grass.py:340 ../lib/init/grass.py:342 ../lib/init/grass.py:344
-#, fuzzy
 msgid "and set as default"
-msgstr "để chấp nhận mặc định"
+msgstr ""
 #: ../lib/init/grass.py:341
 msgid "use text based interface (show welcome screen)"
@@ -6157,15 +5625,11 @@
 msgstr ""
 #: ../lib/init/grass.py:350
-#, fuzzy
 msgid "initial GRASS Location"
 msgstr ""
-"\n"
-"phép chiếu không hợp lệ\n"
 #: ../lib/init/grass.py:351
-msgid ""
-"directory containing Mapsets with one common coordinate system (projection)"
+msgid "directory containing Mapsets with one common coordinate system (projection)"
 msgstr ""
 #: ../lib/init/grass.py:352
@@ -6229,16 +5693,13 @@
 msgstr ""
 #: ../lib/init/grass.py:393
-msgid ""
-"The APPDATA variable points to directory which does not exist, ask your "
-"operating system support"
+msgid "The APPDATA variable points to directory which does not exist, ask your operating system support"
 msgstr ""
 #: ../lib/init/grass.py:440
-#, fuzzy, python-format
-msgid ""
-"Unable to create temporary directory <grass7-%(user)s-%(lock)s>! Exiting."
-msgstr "Không thể cấp phát hình ảnh tạm"
+#, python-format
+msgid "Unable to create temporary directory <grass7-%(user)s-%(lock)s>! Exiting."
+msgstr ""
 #: ../lib/init/grass.py:493
 #, python-brace-format
@@ -6246,9 +5707,9 @@
 msgstr ""
 #: ../lib/init/grass.py:547
+#, python-format
 msgid "GUI <%s> not supported in this version"
-msgstr "Định dạng được yêu cầu không được biên dịch trong phiên bản này"
+msgstr ""
 #: ../lib/init/grass.py:704
 msgid "Searched for a web browser, but none found"
@@ -6286,16 +5747,12 @@
 #: ../lib/init/grass.py:850
 #, python-format
-msgid ""
-"<%s> is not a valid GRASS Location because PERMANENT Mapset does not have a "
-"DEFAULT_WIND file (default computational region)"
+msgid "<%s> is not a valid GRASS Location because PERMANENT Mapset does not have a DEFAULT_WIND file (default computational region)"
 msgstr ""
 #: ../lib/init/grass.py:854
-msgid ""
-"Mapset <{mapset}> doesn't exist in GRASS Location <{loc}>. A new mapset can "
-"be created by '-c' switch."
+msgid "Mapset <{mapset}> doesn't exist in GRASS Location <{loc}>. A new mapset can be created by '-c' switch."
 msgstr ""
 #: ../lib/init/grass.py:858
@@ -6325,18 +5782,14 @@
 #: ../lib/init/grass.py:970
 #, python-format
-msgid ""
-"Invalid user interface specified - <%s>. Use the --help option to see valid "
-"interface names."
+msgid "Invalid user interface specified - <%s>. Use the --help option to see valid interface names."
 msgstr ""
 #: ../lib/init/grass.py:989
 msgid ""
-"Error in GUI startup. See messages above (if any) and if necessary, please "
-"report this error to the GRASS developers.\n"
-"On systems with package manager, make sure you have the right GUI package, "
-"probably named grass-gui, installed.\n"
+"Error in GUI startup. See messages above (if any) and if necessary, please report this error to the GRASS developers.\n"
+"On systems with package manager, make sure you have the right GUI package, probably named grass-gui, installed.\n"
 "To run GRASS GIS in text mode use the -text flag.\n"
 "Use '--help' for further options\n"
 "     {cmd_name} --help\n"
@@ -6350,11 +5803,10 @@
 msgstr ""
 #: ../lib/init/grass.py:1004
-#, fuzzy
 msgid ""
 "Invalid return code from GUI startup script.\n"
 "Please advise GRASS developers of this error."
-msgstr "Vui lòng báo cho các nhà phát triển GRASS về lỗi này.\n"
+msgstr ""
 #: ../lib/init/grass.py:1051
@@ -6372,14 +5824,14 @@
 msgstr ""
 #: ../lib/init/grass.py:1205
+#, python-format
 msgid "Path '%s' doesn't exist"
+msgstr ""
 #: ../lib/init/grass.py:1207
+#, python-format
 msgid "Path '%s' not accessible."
+msgstr ""
 #. GTC %s is mapset's folder path
 #: ../lib/init/grass.py:1212
@@ -6390,18 +5842,13 @@
 #: ../lib/init/grass.py:1220
 #, python-format
 msgid ""
-"%(user)s is currently running GRASS in selected mapset (file %(file)s "
-"found). Concurrent use not allowed.\n"
-"You can force launching GRASS using -f flag (note that you need permission "
-"for this operation). Have another look in the processor manager just to be "
-"sure..."
+"%(user)s is currently running GRASS in selected mapset (file %(file)s found). Concurrent use not allowed.\n"
+"You can force launching GRASS using -f flag (note that you need permission for this operation). Have another look in the processor manager just to be sure..."
 msgstr ""
 #: ../lib/init/grass.py:1227
 #, python-format
-msgid ""
-"found). Forcing to launch GRASS..."
+msgid "%(user)s is currently running GRASS in selected mapset (file %(file)s found). Forcing to launch GRASS..."
 msgstr ""
 #: ../lib/init/grass.py:1231
@@ -6412,14 +5859,12 @@
 msgstr ""
 #: ../lib/init/grass.py:1252
-#, fuzzy
 msgid "Building user fontcap..."
-msgstr "Đang xây dựng biểu đồ..."
+msgstr ""
 #: ../lib/init/grass.py:1311
-#, fuzzy
 msgid "The SHELL variable is not set"
+msgstr ""
 #: ../lib/init/grass.py:1327
@@ -6429,8 +5874,7 @@
 #: ../lib/init/grass.py:1343
 #, python-format
 msgid ""
-"Job file <%s> has been defined in the 'GRASS_BATCH_JOB' variable but not "
-"found. Exiting.\n"
+"Job file <%s> has been defined in the 'GRASS_BATCH_JOB' variable but not found. Exiting.\n"
 "\n"
 "Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
 msgstr ""
@@ -6441,21 +5885,21 @@
 msgstr ""
 #: ../lib/init/grass.py:1365
+#, python-format
 msgid "Executing <%s> ..."
+msgstr ""
 #: ../lib/init/grass.py:1372
-#, fuzzy, python-brace-format
+#, python-brace-format
 msgid ""
 "Execution of <{cmd}> failed:\n"
 "{error}"
+msgstr ""
 #: ../lib/init/grass.py:1375
+#, python-format
 msgid "Execution of <%s> finished."
-msgstr "Không thể lấy dữ liệu từ bảng <%s>"
+msgstr ""
 #: ../lib/init/grass.py:1406
 #, fuzzy
@@ -6477,9 +5921,8 @@
 msgstr ""
 #: ../lib/init/grass.py:1459
-#, fuzzy
 msgid "Help is available with the command:"
-msgstr "Không có trợ giúp cho lệnh [%s]\n"
+msgstr ""
 #: ../lib/init/grass.py:1460
 msgid "See the licence terms with:"
@@ -6514,27 +5957,25 @@
 msgstr ""
 #: ../lib/init/grass.py:1598
-#, fuzzy
 msgid "Done."
-msgstr "không có"
+msgstr ""
 #: ../lib/init/grass.py:1600
 msgid "Goodbye from GRASS GIS"
 msgstr ""
 #: ../lib/init/grass.py:1605
-#, fuzzy
 msgid "Cleaning up temporary files..."
+msgstr ""
 #: ../lib/init/grass.py:1625
 msgid "Please install the GRASS GIS development package"
 msgstr ""
 #: ../lib/init/grass.py:1657
+#, python-format
 msgid "Parameter <%s> not supported"
-msgstr "Kiểu đối tượng OGR %d không được hỗ trợ"
+msgstr ""
 #: ../lib/init/grass.py:1801
 msgid "Flag -e requires also flag -c"
@@ -6566,9 +6007,7 @@
 msgstr ""
 #: ../lib/init/grass.py:1894
-msgid ""
-"<{}> requested, but not available. Run GRASS in text mode (-text) or install "
-"missing package (usually 'grass-gui')."
+msgid "<{}> requested, but not available. Run GRASS in text mode (-text) or install missing package (usually 'grass-gui')."
 msgstr ""
 #: ../lib/init/grass.py:1948
@@ -6577,9 +6016,9 @@
 msgstr ""
 #: ../lib/init/grass.py:1970
+#, python-format
 msgid "Failed to start shell '%s'"
+msgstr ""
 #: ../lib/rowio/setup.c:61 ../lib/rowio/setup.c:67
 #: ../lib/vector/neta/spanningtree.c:101 ../lib/vector/neta/flow.c:66
@@ -6600,17 +6039,17 @@
 #: ../lib/rst/interp_float/interp2d.c:139
 #: ../lib/rst/interp_float/interp2d.c:145
 msgid "Out of memory"
-msgstr "Hết bộ nhớ "
+msgstr "Hết bộ nhớ"
 #: ../lib/vector/vedit/delete.c:40
-#, fuzzy, c-format
+#, c-format
 msgid "Attempt to delete dead feature (%d)"
+msgstr ""
 #: ../lib/vector/vedit/delete.c:72
-#, fuzzy, c-format
+#, c-format
 msgid "No area found for centroid %d"
-msgstr "Số vùng không có trọng tâm: %d"
+msgstr ""
 #: ../lib/vector/vedit/delete.c:76
 #, c-format
@@ -6618,54 +6057,51 @@
 msgstr ""
 #: ../lib/vector/vedit/delete.c:105
-#, fuzzy, c-format
+#, c-format
 msgid "Area %d without centroid"
+msgstr ""
 #: ../lib/vector/vedit/delete.c:121
-#, fuzzy, c-format
+#, c-format
 msgid "Area %d has no boundaries"
-msgstr "Đường không bị thắt nút"
+msgstr ""
 #: ../lib/vector/vedit/cats.c:63
 #, c-format
 msgid "Unable to set category %d for (feature id %d)"
-msgstr "Không thể thiết lập phạm trù %d cho (đối tượng có id %d)"
+msgstr ""
 #: ../lib/vector/vedit/select.c:231
 msgid "Unknown query tool"
-msgstr "Công cụ truy vấn không biết"
+msgstr ""
 #: ../lib/vector/rtree/test_suite/test_main.c:61
 msgid "Unit tests for the vector rtree library"
-msgstr ""
+msgstr "Các phép thử đơn vị dùng cho thư viện rtree vector"
 #: ../lib/vector/rtree/test_suite/test_basics.c:40
-#, fuzzy
 msgid ""
 "\n"
 "++ Running basic unit tests ++"
 msgstr ""
 "\n"
++ Đang chạy các phép thử đơn vị bộ giải ++"
+"++ Đang chạy các phép thử đơn vị cơ bản ++"
 #: ../lib/vector/rtree/test_suite/test_basics.c:48
-#, fuzzy
 msgid ""
 "\n"
 "-- Basic rtree unit tests failure --"
 msgstr ""
 "\n"
-- Các thép thử đơn vị bộ giải thất bại --"
+"-- Các phép thử đơn vị rtree cơ bản thất bại --"
 #: ../lib/vector/rtree/test_suite/test_basics.c:50
-#, fuzzy
 msgid ""
 "\n"
 "-- Basic rtree unit tests finished successfully --"
 msgstr ""
 "\n"
-- Các thép thử đơn vị bộ giải kết thúc thành công --"
+"-- Các phép thử đơn vị rtree kết thúc thành công --"
 #: ../lib/vector/neta/spanningtree.c:106
 msgid "Computing minimum spanning tree..."
@@ -6674,18 +6110,18 @@
 #: ../lib/vector/neta/flow.c:331 ../lib/vector/Vlib/net_build.c:661
 #: ../lib/vector/Vlib/net_build.c:1067 ../lib/vector/Vlib/graph.c:105
 msgid "GngFlatten error"
-msgstr "Lỗi GngFlattern"
+msgstr ""
 #: ../lib/vector/neta/timetables.c:46 ../lib/vector/neta/timetables.c:203
 #: ../lib/vector/neta/timetables.c:244 ../lib/vector/neta/timetables.c:286
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open select cursor: %s"
-msgstr "Không thể mở con trỏ chọn: '%s'"
+msgstr ""
 #: ../lib/vector/neta/utils.c:200
-#, fuzzy, c-format
+#, c-format
 msgid "Point %d is not connected!"
+msgstr ""
 #: ../lib/vector/neta/utils.c:235
 #, c-format
@@ -6697,14 +6133,12 @@
 msgstr ""
 #: ../lib/vector/neta/utils.c:247
-#, fuzzy
 msgid "Unable to load data from database"
-msgstr "Không thể thêm liên kết csdl"
+msgstr ""
 #: ../lib/vector/neta/utils.c:254
-#, fuzzy
 msgid "Problem loading category values"
-msgstr "Trục trặc khi đang đọc bản đồ raster"
+msgstr ""
 #: ../lib/vector/Vlib/write_nat.c:182 ../lib/vector/Vlib/write_nat.c:295
 #: ../lib/vector/Vlib/write_nat.c:651 ../lib/vector/Vlib/read_pg.c:331
@@ -6713,38 +6147,37 @@
 #: ../lib/vector/Vlib/read.c:173 ../lib/vector/Vlib/read_nat.c:144
 #: ../lib/vector/Vlib/box.c:249 ../lib/vector/Vlib/write_sfa.c:158
 #: ../lib/vector/Vlib/write_sfa.c:207
-#, fuzzy, c-format
+#, c-format
 msgid "Attempt to access feature with invalid id (%d)"
+msgstr "Cố gắng truy cập đối tượng với số hiệu nhận diện không hợp lệ (%d)"
 #: ../lib/vector/Vlib/write_nat.c:301 ../lib/vector/Vlib/write_nat.c:657
 #: ../lib/vector/Vlib/read_pg.c:337 ../lib/vector/Vlib/read_sfa.c:56
 #: ../lib/vector/Vlib/write_pg.c:242 ../lib/vector/Vlib/write_pg.c:402
 #: ../lib/vector/Vlib/write_pg.c:2584 ../lib/vector/Vlib/write_pg.c:2681
 #: ../lib/vector/Vlib/read_nat.c:150
-#, fuzzy, c-format
+#, c-format
 msgid "Attempt to access dead feature %d"
+msgstr "Cố gắng truy cập đối tượng chết %d"
 #: ../lib/vector/Vlib/write_nat.c:398
-#, fuzzy
 msgid "Attempt to access feature with invalid id (%"
+msgstr ""
 #: ../lib/vector/Vlib/write_nat.c:404
-#, fuzzy, c-format
+#, c-format
 msgid "Attempt to access alive feature %d"
-msgstr "Cố gắng phục hồi lại đối tượng sống"
+msgstr ""
 #: ../lib/vector/Vlib/write_nat.c:566 ../lib/vector/Vlib/write_nat.c:602
 #, c-format
 msgid "%s: Area %d does not exist"
+msgstr ""
 #: ../lib/vector/Vlib/write_nat.c:756
-#, fuzzy, c-format
+#, c-format
 msgid "Attempt to access dead area %d"
+msgstr ""
 #: ../lib/vector/Vlib/write_ogr.c:69 ../lib/vector/Vlib/write_ogr.c:105
 #: ../lib/vector/Vlib/write_ogr.c:145 ../lib/vector/Vlib/field.c:675
@@ -6764,38 +6197,36 @@
 #: ../lib/vector/Vlib/write_ogr.c:96 ../lib/vector/Vlib/write_pg.c:187
 #: ../lib/vector/Vlib/write_pg.c:255 ../lib/vector/Vlib/write_sfa.c:164
-#, fuzzy
 msgid "Unable to rewrite feature (incompatible feature types)"
-msgstr "Không thể ghi đối tượng (độ dịch âm)"
+msgstr "Không thể ghi lại đối tượng (các kiểu đối tượng không tương thích)"
 #: ../lib/vector/Vlib/write_ogr.c:129 ../lib/vector/Vlib/open_ogr.c:65
 msgid "OGR layer not defined"
 msgstr ""
 #: ../lib/vector/Vlib/write_ogr.c:134 ../lib/vector/Vlib/write_pg.c:326
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid offset (%ld)"
-msgstr "không thể đổi thư mục đến %s"
+msgstr "Độ lệch không hợp lệ (%ld)"
 #: ../lib/vector/Vlib/write_ogr.c:140 ../lib/vector/Vlib/write_pg.c:347
-#, fuzzy
 msgid "Unable to delete feature"
-msgstr "Không thể ghi lại đối tượng %d"
+msgstr "Không thể xóa đối tượng"
 #: ../lib/vector/Vlib/write_ogr.c:239
-#, fuzzy, c-format
+#, c-format
 msgid "Creating field <%s> failed"
+msgstr ""
 #: ../lib/vector/Vlib/write_ogr.c:304 ../lib/vector/Vlib/write_pg.c:1104
-#, fuzzy, c-format
+#, c-format
 msgid "Unsupported geometry type (%d)"
+msgstr ""
 #: ../lib/vector/Vlib/write_ogr.c:326
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create OGR layer <%s> in '%s'"
-msgstr "Không thể mở lớp <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/write_ogr.c:338 ../lib/vector/Vlib/write_pg.c:1117
 #, c-format
@@ -6803,15 +6234,14 @@
 msgstr ""
 #: ../lib/vector/Vlib/write_ogr.c:344 ../lib/vector/Vlib/write_pg.c:1122
-#, fuzzy
 msgid "Database connection not defined. Unable to write attributes."
-msgstr "Kết nối CSDL không được định nghĩa cho lớp %d"
+msgstr ""
 #: ../lib/vector/Vlib/write_ogr.c:408 ../lib/vector/Vlib/write_pg.c:1237
 #: ../lib/vector/Vlib/write_pg.c:1396
-#, fuzzy, c-format
+#, c-format
 msgid "No category defined for layer %d"
+msgstr ""
 #: ../lib/vector/Vlib/write_ogr.c:410 ../lib/vector/Vlib/write_pg.c:1239
 #: ../lib/vector/Vlib/write_pg.c:1398
@@ -6836,47 +6266,46 @@
 msgstr ""
 #: ../lib/vector/Vlib/write_ogr.c:452
-#, fuzzy, c-format
+#, c-format
 msgid "Unsupported feature type (%d)"
+msgstr ""
 #: ../lib/vector/Vlib/write_ogr.c:471
 msgid "Boundary is not closed. Feature skipped."
 msgstr ""
 #: ../lib/vector/Vlib/write_ogr.c:500
-#, fuzzy
 msgid "Unable to writes feature attributes"
-msgstr "Không thể ghi các liên kết csdl"
+msgstr ""
 #: ../lib/vector/Vlib/write_ogr.c:565
-#, fuzzy, c-format
+#, c-format
 msgid "Feature without category of layer %d"
-msgstr "Đối tượng %d không có hình học bị bỏ qua"
+msgstr ""
 #: ../lib/vector/Vlib/write_ogr.c:579 ../lib/vector/Vlib/write_pg.c:2005
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to select attributes for category %d"
+msgstr ""
 #: ../lib/vector/Vlib/write_ogr.c:591 ../lib/vector/Vlib/write_pg.c:2014
-#, fuzzy, c-format
+#, c-format
 msgid "No database record for category %d, no attributes will be written"
-msgstr "Không tìm thấy bản ghi CSDL cho phạm trù %d"
+msgstr ""
 #: ../lib/vector/Vlib/write_ogr.c:624
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create field <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/write_ogr.c:653 ../lib/vector/Vlib/write_pg.c:2074
-#, fuzzy, c-format
+#, c-format
 msgid "Unsupported column type %d"
+msgstr ""
 #: ../lib/vector/Vlib/remove_areas.c:107 ../lib/vector/Vlib/remove_areas.c:268
 msgid "Area is composed of dead boundary"
-msgstr "Vùng tạo thành từ ranh giới chết"
+msgstr ""
 #: ../lib/vector/Vlib/remove_areas.c:194 ../lib/vector/Vlib/remove_areas.c:602
 #, c-format
@@ -6884,83 +6313,72 @@
 msgstr ""
 #: ../lib/vector/Vlib/remove_areas.c:395
-#, fuzzy
 msgid "Could not delete line from coor"
-msgstr "Không thể ghi lại đường"
+msgstr ""
 #: ../lib/vector/Vlib/remove_areas.c:458
-#, fuzzy
 msgid "dissolve_neighbour > 0, failed to build new area"
-msgstr "Không thể xây dựng biểu đồ mạng lưới"
+msgstr ""
 #: ../lib/vector/Vlib/remove_areas.c:463 ../lib/vector/Vlib/remove_areas.c:501
 msgid "Dissolve with neighbour area: corrupt topology"
 msgstr ""
 #: ../lib/vector/Vlib/remove_areas.c:497
-#, fuzzy
 msgid "Failed to build new area"
+msgstr ""
 #: ../lib/vector/Vlib/remove_areas.c:544 ../lib/vector/Vlib/remove_areas.c:571
-#, fuzzy
 msgid "Failed to build new isle"
+msgstr ""
 #: ../lib/vector/Vlib/remove_areas.c:549 ../lib/vector/Vlib/remove_areas.c:576
 msgid "Dissolve with outer isle: corrupt topology"
 msgstr ""
 #: ../lib/vector/Vlib/remove_areas.c:581
-#, fuzzy
 msgid "Area merging failed"
-msgstr "Việc nạp thất bại"
+msgstr ""
 #: ../lib/vector/Vlib/rewind.c:29 ../lib/vector/Vlib/write.c:56
 #: ../lib/vector/Vlib/write.c:62 ../lib/vector/Vlib/open.c:59
 #: ../lib/vector/Vlib/close.c:38 ../lib/vector/Vlib/read.c:32
 #: ../lib/vector/Vlib/build.c:37
 msgid "Requested format is not compiled in this version"
+msgstr ""
 #: ../lib/vector/Vlib/field.c:91
 msgid "Layer number must be 1 or greater"
-msgstr "Số lượng lớp phải bằng 1 hoặc lớn hơn"
+msgstr ""
 #: ../lib/vector/Vlib/field.c:96
-#, fuzzy
 msgid "Unable to add attribute link, vector map is not opened in WRITE mode"
-msgstr "Không thể thêm liên kết csdl, bản đồ không được mở ở chế độ GHI"
+msgstr ""
 #: ../lib/vector/Vlib/field.c:103
-#, fuzzy
 msgid "Unable to add attribute link"
+msgstr ""
 #: ../lib/vector/Vlib/field.c:109
-#, fuzzy
 msgid "Unable to write attribute links"
+msgstr ""
 #: ../lib/vector/Vlib/field.c:154
 msgid "Unable to write database links"
+msgstr ""
 #: ../lib/vector/Vlib/field.c:178
-#, fuzzy
 msgid "Database connection not defined. Skipping."
+msgstr ""
 #: ../lib/vector/Vlib/field.c:185
-msgid ""
-"More DB links defined for input vector map. Using only first DB link for "
-"output."
+msgid "More DB links defined for input vector map. Using only first DB link for output."
 msgstr ""
 #: ../lib/vector/Vlib/field.c:261
 #, c-format
 msgid "Layer number %d or name <%s> already exists"
+msgstr ""
 #: ../lib/vector/Vlib/field.c:345
 #, c-format
@@ -6969,54 +6387,46 @@
 "driver: %s\n"
 "database: %s"
 msgstr ""
-"Trình đ.khiển mặc định / csdl được thiết lập vào:\n"
trình đ.khiển: %s\n"
-"csdl: %s"
 #: ../lib/vector/Vlib/field.c:352
 msgid "Default driver is not set"
-msgstr "Trình đ.khiển mặc định không được thiết lập"
+msgstr ""
 #: ../lib/vector/Vlib/field.c:355
 msgid "Default database is not set"
-msgstr "CSDL mặc định không được thiết lập"
+msgstr ""
 #: ../lib/vector/Vlib/field.c:428
 #, c-format
 msgid "Requested dblink %d, maximum link number %d"
-msgstr "Liên kết csdl %d được yêu cầu, số lượng liên kết tối đa %d"
+msgstr ""
 #: ../lib/vector/Vlib/field.c:614 ../lib/vector/Vlib/field.c:622
-#, fuzzy, c-format
+#, c-format
 msgid "Error in rule on row %d in <%s>"
-msgstr "Lỗi trong quy tắc tại dòng %d trong %s"
+msgstr ""
 #: ../lib/vector/Vlib/field.c:690 ../lib/vector/Vlib/open_ogr.c:77
 #, c-format
 msgid "Unable to open OGR data source '%s'"
-msgstr "Không thể mở nguồn dữ liệu OGR '%s'"
+msgstr ""
 #: ../lib/vector/Vlib/field.c:707
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open OGR layer <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/field.c:734
 msgid "Unable to open OGR DBMI driver"
-msgstr "Không thể mở trình đ.khiển OGR DBMI"
+msgstr ""
 #: ../lib/vector/Vlib/field.c:773
-msgid ""
-"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
-"available in OGR DB table"
+msgid "All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' available in OGR DB table"
 msgstr ""
-"Tất cả các kiểm tra FID thất bại. 'FID', 'ogc_fid', 'ogr_fid' lẫn 'gid' đều "
-"không dùng được trong bảng OGR DB"
 #: ../lib/vector/Vlib/field.c:840
 #, c-format
-msgid ""
-"Feature table <%s> has no primary key defined. Unable to define DB links."
+msgid "Feature table <%s> has no primary key defined. Unable to define DB links."
 msgstr ""
 #: ../lib/vector/Vlib/field.c:860
@@ -7024,174 +6434,161 @@
 msgstr ""
 #: ../lib/vector/Vlib/field.c:892
-#, fuzzy
 msgid "Unknown vector map format"
-msgstr "toán tử không hiểu"
+msgstr ""
 #: ../lib/vector/Vlib/field.c:925
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create database definition file for vector map <%s>"
-msgstr "Không thể mở tập tin header của bản đồ vec-tơ <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/field.c:1020
 msgid "Bug: attempt to update map which is not in current mapset"
-msgstr "'Bọ': cố gắng cập nhật bản đồ không ở trong bộ bản đồ hiện tại"
+msgstr ""
 #: ../lib/vector/Vlib/build_nat.c:74 ../lib/vector/Vlib/build_sfa.c:339
 #: ../lib/vector/Vlib/build_sfa.c:629
 msgid "Registering primitives..."
-msgstr "Đang đăng ký các đối tượng nguyên thủy..."
+msgstr ""
 #: ../lib/vector/Vlib/build_nat.c:84
 msgid "Unable to read vector map"
-msgstr "Không thể đọc bản đồ vec-tơ"
+msgstr ""
 #: ../lib/vector/Vlib/build_nat.c:117 ../lib/vector/Vlib/build_sfa.c:385
 #: ../lib/vector/Vlib/build_sfa.c:661
-#, fuzzy, c-format
+#, c-format
 msgid "One primitive registered"
 msgid_plural "%d primitives registered"
-msgstr[0] "%d đối tượng nguyên thủy được đăng ký"
-msgstr[1] "%d đối tượng nguyên thủy được đăng ký"
+msgstr[0] ""
 #: ../lib/vector/Vlib/build_nat.c:118 ../lib/vector/Vlib/build_sfa.c:386
 #: ../lib/vector/Vlib/build_sfa.c:662
-#, fuzzy, c-format
+#, c-format
 msgid "One vertex registered"
 msgid_plural "%d vertices registered"
-msgstr[0] "%d đỉnh được đăng ký"
-msgstr[1] "%d đỉnh được đăng ký"
+msgstr[0] ""
 #: ../lib/vector/Vlib/build_nat.c:129
 msgid "Building areas..."
-msgstr "Đang xây dựng các vùng..."
+msgstr ""
 #: ../lib/vector/Vlib/build_nat.c:153
-#, fuzzy, c-format
+#, c-format
 msgid "One area built"
 msgid_plural "%d areas built"
-msgstr[0] "%d vùng được xây dựng"
-msgstr[1] "%d vùng được xây dựng"
+msgstr[0] ""
 #: ../lib/vector/Vlib/build_nat.c:154
-#, fuzzy, c-format
+#, c-format
 msgid "One isle built"
 msgid_plural "%d isles built"
-msgstr[0] "%d đảo được xây dựng"
-msgstr[1] "%d đảo được xây dựng"
+msgstr[0] ""
 #: ../lib/vector/Vlib/build_nat.c:163
 msgid "Attaching islands..."
-msgstr "Đang gắn các đảo..."
+msgstr ""
 #: ../lib/vector/Vlib/build_nat.c:180
 msgid "Attaching centroids..."
-msgstr "Đang gắn các trọng tâm..."
+msgstr ""
 #: ../lib/vector/Vlib/open_nat.c:56
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open coor file for vector map <%s>"
-msgstr "Không thể mở tập tin lịch sử của bản đồ vec-tơ <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/open_nat.c:152
-#, fuzzy, c-format
-msgid ""
-"Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
-"excess)"
+#, c-format
+msgid "Coor file of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
 msgstr ""
-"Các tập tin coor của bản đồ vec-tơ <%s@%s> lớn hơn cỡ đúng của nó (quá %ld "
-"byte)"
 #: ../lib/vector/Vlib/open_nat.c:156
-#, fuzzy, c-format
-msgid ""
-"Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+#, c-format
+msgid "Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
 msgstr ""
-"Các tập tin coor của bản đồ vec-tơ <%s@%s> nhỏ hơn cỡ đúng của nó (thiếu %ld "
-"byte)."
 #: ../lib/vector/Vlib/write.c:30 ../lib/vector/Vlib/write.c:36
 #: ../lib/vector/Vlib/write.c:42 ../lib/vector/Vlib/write.c:49
 #: ../lib/vector/Vlib/read.c:25
 msgid "for this format/level not supported"
-msgstr "cho định dạng/cấp này không được hỗ trợ"
+msgstr ""
 #: ../lib/vector/Vlib/write.c:194
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to write feature in vector map <%s>"
-msgstr "Không thể phục hồi lại đối tượng %d từ bản đồ vec-tơ <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/write.c:234
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to rewrite feature/offset %lu in vector map <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/write.c:266
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to delete feature/offset %lu from vector map <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/write.c:299
-#, fuzzy
 msgid "Unable to restore feature/offset %"
+msgstr ""
 #: ../lib/vector/Vlib/write.c:308
-#, fuzzy, c-format
+#, c-format
 msgid "Vector map <%s> is not opened"
-msgstr "Bản đồ vec-tơ không được mở"
+msgstr ""
 #: ../lib/vector/Vlib/write.c:313
-#, fuzzy, c-format
+#, c-format
 msgid "Vector map <%s> is not opened in write mode"
-msgstr "Bản đồ vec-tơ <%s> không mở được ở cấp >=2"
+msgstr ""
 #: ../lib/vector/Vlib/clean_nodes.c:248
-#, fuzzy, c-format
+#, c-format
 msgid "Modifications: %d"
-msgstr " tùy chọn: %s\n"
+msgstr ""
 #: ../lib/vector/Vlib/map.c:139 ../lib/vector/Vlib/map.c:245
 msgid "Vector map name is not SQL compliant"
-msgstr "Tên bản đồ vec-tơ không tương thích SQL"
+msgstr ""
 #: ../lib/vector/Vlib/map.c:143
 #, c-format
 msgid "Unable to find vector map <%s> in <%s>"
-msgstr "Không thể tìm thấy bản đồ vec-tơ <%s> trongg <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/map.c:155 ../lib/vector/Vlib/map.c:249
 #: ../lib/vector/Vlib/open.c:821
 #, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
-msgstr "Bản đồ vec-tơ <%s> đã có và sẽ bị ghi đè"
+msgstr ""
 #: ../lib/vector/Vlib/map.c:159 ../lib/vector/Vlib/open.c:813
 #: ../lib/vector/Vlib/open.c:826
 #, c-format
 msgid "Unable to delete vector map <%s>"
-msgstr "Không thể xoá bản đồ vec-tơ <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/map.c:179 ../lib/vector/Vlib/map.c:267
 #, c-format
 msgid "Unable to copy vector map <%s> to <%s>"
-msgstr "Không thể sao chép bản đồ vec-tơ <%s> vào <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/map.c:317 ../lib/vector/Vlib/copy.c:738
 #: ../lib/vector/Vlib/close_nat.c:102
 #, c-format
 msgid "Unable to copy table <%s>"
-msgstr "Không thể sao chép bảng <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/map.c:331 ../lib/vector/Vlib/map.c:462
 #, c-format
 msgid "Unable to delete table <%s>"
-msgstr "Không thể xoá bảng <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/map.c:346
 #, c-format
 msgid "Unable to create index for table <%s>, key <%s>"
-msgstr "Không thể tạo chỉ mục cho bảng <%s>, khoá <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/map.c:402
 #, c-format
@@ -7201,42 +6598,42 @@
 #: ../lib/vector/Vlib/map.c:407
 #, c-format
 msgid "Invalid vector map name <%s>"
-msgstr "Tên bản đồ vec-tơ không hợp lệ <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/map.c:417
 #, c-format
 msgid "Unable to open header file for vector map <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/map.c:449
 #, c-format
 msgid "Unable to find table <%s> linked to vector map <%s>"
-msgstr "Không thể tìm thấy bảng <%s> được liên kết vào bản đồ vec-tơ <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/map.c:472
 #, c-format
 msgid "Table <%s> linked to vector map <%s> does not exist"
-msgstr "Bảng <%s> được liên kết vào bản đồ vec-tơ <%s> không tồn tại"
+msgstr ""
 #: ../lib/vector/Vlib/map.c:485
 #, c-format
 msgid "Unable to open directory '%s'"
-msgstr "Không thể mở thư mục '%s'"
+msgstr ""
 #: ../lib/vector/Vlib/map.c:499
 #, c-format
 msgid "Unable to delete file '%s'"
-msgstr "Không thể xoá tập tin '%s'"
+msgstr ""
 #: ../lib/vector/Vlib/map.c:519
 #, c-format
 msgid "Unable to rename directory '%s' to '%s'"
-msgstr "Không thể đổi tên thư mục '%s' thành '%s'"
+msgstr ""
 #: ../lib/vector/Vlib/map.c:528
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to remove directory '%s': %s"
-msgstr "Không thể loại bỏ thư mục '%s'"
+msgstr ""
 #: ../lib/vector/Vlib/read_pg.c:91 ../lib/vector/Vlib/read_pg.c:214
 #: ../lib/vector/Vlib/read_pg.c:298 ../lib/vector/Vlib/read_pg.c:416
@@ -7254,39 +6651,37 @@
 #: ../lib/vector/Vlib/open_pg.c:143 ../lib/vector/Vlib/open_pg.c:200
 #: ../lib/vector/Vlib/open_pg.c:299 ../lib/vector/Vlib/open_pg.c:349
 msgid "GRASS is not compiled with PostgreSQL support"
-msgstr ""
+msgstr "GRASS không được biên dịch với hỗ trợ cho PostgreSQL"
 #: ../lib/vector/Vlib/read_pg.c:192 ../lib/vector/Vlib/read_sfa.c:117
-#, fuzzy, c-format
+#, c-format
 msgid "Unexpected feature type (%d) - should be (%d)"
+msgstr ""
 #: ../lib/vector/Vlib/read_pg.c:272 ../lib/vector/Vlib/read_pg.c:471
-#, fuzzy, c-format
+#, c-format
 msgid "Feature %ld without geometry skipped"
+msgstr ""
 #: ../lib/vector/Vlib/read_pg.c:365
 #, c-format
-msgid ""
-"Requesting invalid feature from cache (%d). Number of features in cache: %d"
+msgid "Requesting invalid feature from cache (%d). Number of features in cache: %d"
 msgstr ""
 #: ../lib/vector/Vlib/read_pg.c:368
-#, fuzzy, c-format
+#, c-format
 msgid "Feature %d: unexpected type (%d) - should be %d"
+msgstr ""
 #: ../lib/vector/Vlib/read_pg.c:378 ../lib/vector/Vlib/build_sfa.c:354
 #: ../lib/vector/Vlib/build_sfa.c:364
-#, fuzzy, c-format
+#, c-format
 msgid "Feature %d without geometry skipped"
+msgstr ""
 #: ../lib/vector/Vlib/read_pg.c:482 ../lib/vector/Vlib/read_ogr.c:382
-#, fuzzy
 msgid "Feature without geometry. Skipped."
+msgstr ""
 #: ../lib/vector/Vlib/read_pg.c:575
 msgid "No geometry or topo geometry column defined"
@@ -7319,9 +6714,9 @@
 #: ../lib/vector/Vlib/write_pg.c:1278 ../lib/vector/Vlib/write_pg.c:1790
 #: ../lib/vector/Vlib/write_pg.c:1967 ../lib/vector/Vlib/write_pg.c:2325
 #: ../lib/vector/Vlib/copy.c:100
-#, fuzzy, c-format
+#, c-format
 msgid "Unsupported feature type %d"
+msgstr "Kiểu đối tượng không được hỗ trợ %d"
 #: ../lib/vector/Vlib/read_pg.c:996 ../lib/vector/Vlib/read_pg.c:1066
 #: ../lib/vector/Vlib/read_pg.c:1137
@@ -7334,64 +6729,64 @@
 msgstr ""
 #: ../lib/vector/Vlib/read_pg.c:1215
-#, fuzzy, c-format
+#, c-format
 msgid "Corrupted data. %s."
-msgstr "Hàng bị lỗi trong tiêu đề: %s"
+msgstr ""
 #: ../lib/vector/Vlib/read_pg.c:1217
 msgid "Corrupted data"
 msgstr ""
 #: ../lib/vector/Vlib/read_pg.c:1405 ../lib/vector/Vlib/close_pg.c:66
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to close cursor %s"
-msgstr "Không thể thiết lập tiêu điểm"
+msgstr ""
 #: ../lib/vector/Vlib/read_pg.c:1515
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Execution failed: %s (...)\n"
 "Reason: %s"
-msgstr "Kết nối thất bại."
+msgstr ""
 #: ../lib/vector/Vlib/read_pg.c:1546
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Execution failed: %s\n"
 "Reason: %s"
+msgstr ""
 #: ../lib/vector/Vlib/read_pg.c:1675
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Unable to read features. Reason:\n"
 "%s"
+msgstr ""
 #: ../lib/vector/Vlib/header.c:86
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create header file for vector map <%s>"
+msgstr "Không thể tạo tập tin đề mục cho bản đồ vector <%s>"
 #: ../lib/vector/Vlib/header.c:129
 #, c-format
 msgid "Unable to open header file of vector <%s>"
-msgstr "Không thể mở tập tin header của vec-tơ <%s>"
+msgstr "Không thể mở tập tin đề mục của vector <%s>"
 #: ../lib/vector/Vlib/header.c:137
 #, c-format
 msgid "Corrupted row in head: %s"
+msgstr "Hàng bị hỏng ở phần đầu: %s"
 #: ../lib/vector/Vlib/header.c:175
-#, fuzzy, c-format
+#, c-format
 msgid "Unknown keyword '%s' in vector head"
-msgstr "Không hiểu từ khoá %s trong tiêu đề vec-tơ"
+msgstr "Tử khóa '%s' không rõ trong đề mục vector"
 #: ../lib/vector/Vlib/read_sfa.c:90
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to construct centroid for area %d. Skipped."
-msgstr "Không thể tính toán trọng tâm cho vùng %d"
+msgstr ""
 #: ../lib/vector/Vlib/read_sfa.c:95
 #, c-format
@@ -7404,85 +6799,79 @@
 msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:285
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to rewrite feature %d"
 #: ../lib/vector/Vlib/write_pg.c:321 ../lib/vector/Vlib/write_pg.c:811
 #: ../lib/vector/Vlib/write_pg.c:1212 ../lib/vector/Vlib/write_pg.c:1364
 #: ../lib/vector/Vlib/simple_features.c:324
-#, fuzzy
 msgid "No connection defined"
+msgstr "Không có kết nối nào được định nghĩa"
 #: ../lib/vector/Vlib/write_pg.c:452
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to delete feature (%s) %d"
+msgstr "Không thể xóa đối tượng (%s) %d"
 #: ../lib/vector/Vlib/write_pg.c:554 ../lib/vector/Vlib/write_pg.c:1294
 #: ../lib/vector/Vlib/write_sfa.c:349
 msgid "Boundary is not closed. Skipping."
-msgstr ""
+msgstr "Ranh giới không khép kín. Bỏ qua"
 #: ../lib/vector/Vlib/write_pg.c:612 ../lib/vector/Vlib/write_pg.c:880
 #: ../lib/vector/Vlib/open.c:1355 ../lib/vector/Vlib/build_pg.c:411
-#, fuzzy
 msgid "Unable to open PG file"
+msgstr "Không thể mở tập tin PG"
 #: ../lib/vector/Vlib/write_pg.c:773
-#, fuzzy, c-format
+#, c-format
 msgid "Building spatial index on <%s>..."
-msgstr "Đang xây dựng lại tôpô cho bản đồ vec-tơ <%s>..."
+msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:841
-#, fuzzy, c-format
+#, c-format
 msgid "Schema <%s> doesn't exist, created"
-msgstr "%s: Vùng %d không tồn tại"
+msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:920
-#, fuzzy, c-format
+#, c-format
 msgid "Creating topology schema <%s>..."
+msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:934
-#, fuzzy, c-format
+#, c-format
 msgid "Adding new topology column <%s>..."
+msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:1072 ../lib/vector/Vlib/open_pg.c:85
 #: ../lib/vector/Vlib/open_pg.c:232
-#, fuzzy
 msgid "Connection string not defined"
+msgstr "Chuỗi kết nối không được định nghĩa"
 #: ../lib/vector/Vlib/write_pg.c:1077 ../lib/vector/Vlib/write_pg.c:1216
 #: ../lib/vector/Vlib/write_pg.c:1368 ../lib/vector/Vlib/open_pg.c:90
 #: ../lib/vector/Vlib/open_pg.c:237
-#, fuzzy
 msgid "PostGIS feature table not defined"
-msgstr "Đối tượng OGR không có ID bị bỏ qua"
+msgstr "Bảng đối tượng PostGIS không được định nghĩa"
 #: ../lib/vector/Vlib/write_pg.c:1129
-#, fuzzy
 msgid "Unable to create new PostGIS feature table"
+msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:1143
-#, fuzzy
 msgid "Unable to create new PostGIS topology schema"
+msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:1250
-#, fuzzy, c-format
+#, c-format
 msgid "Point skipped (output feature type: %s)"
-msgstr "Kiểu đối tượng"
+msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:1257
-#, fuzzy, c-format
+#, c-format
 msgid "Line skipped (output feature type: %s)"
+msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:1264
 #, c-format
@@ -7490,19 +6879,18 @@
 msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:1272
-#, fuzzy, c-format
+#, c-format
 msgid "Face skipped (output feature type: %s)"
+msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:1358
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid feature type (%d) for nodes"
+msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:1372
-#, fuzzy
 msgid "PostGIS topology schema not defined"
+msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:1872
 msgid "Trying to insert 3D data into feature table which store 2D data only"
@@ -7513,9 +6901,8 @@
 msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:1902
-#, fuzzy
 msgid "Unable to insert topological element into PostGIS Topology schema"
+msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:2040
 #, c-format
@@ -7527,105 +6914,99 @@
 msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:2173
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid feature %d (max: %d)"
+msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:2187
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid feature type (%d) for node"
+msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:2191
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid node %d (%d)"
+msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:2269
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to determine next left/right edge for edge %d"
-msgstr "Không thể định nghĩa nguồn sáng mới"
+msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:2274
-#, fuzzy
 msgid "Unable to insert new edge. Topology not available."
-msgstr "Không thể đọc tôpô cho các đảo"
+msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:2373 ../lib/vector/Vlib/write_pg.c:2380
-#, fuzzy
 msgid "Invalid topology"
+msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:2579 ../lib/vector/Vlib/write_pg.c:2676
-#, fuzzy, c-format
+#, c-format
 msgid "Attempt to access non-existing feature %d"
+msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:2610
-#, fuzzy
 msgid "Unable to determine next left/right edge"
+msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:2696
-#, fuzzy
 msgid "Unable to create new face"
+msgstr ""
 #: ../lib/vector/Vlib/write_pg.c:2834 ../lib/vector/Vlib/write_pg.c:2846
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to delete node %d"
-msgstr "Không thể đọc đường %d"
+msgstr ""
 #: ../lib/vector/Vlib/dangles.c:148
 msgid "Changed"
 msgstr ""
 #: ../lib/vector/Vlib/dangles.c:151
-#, fuzzy
 msgid "Removed"
-msgstr "Loại bỏ cửa sổ"
+msgstr ""
 #: ../lib/vector/Vlib/dangles.c:154
 msgid "Selected"
 msgstr ""
 #: ../lib/vector/Vlib/dangles.c:262
-#, fuzzy, c-format
+#, c-format
 msgid "%s lines: %d"
-msgstr "Số đường: %d"
+msgstr ""
 #: ../lib/vector/Vlib/dangles.c:263
-#, fuzzy, c-format
+#, c-format
 msgid "%s dangles: %d"
+msgstr ""
 #: ../lib/vector/Vlib/build_sfa.c:279 ../lib/vector/Vlib/build_sfa.c:546
 #, c-format
 msgid "Unable to calculate centroid for area %d"
+msgstr ""
 #: ../lib/vector/Vlib/build_sfa.c:305
-#, fuzzy, c-format
+#, c-format
 msgid "Feature type %d not supported"
+msgstr ""
 #: ../lib/vector/Vlib/build_sfa.c:603 ../lib/vector/Vlib/read_ogr.c:344
 #: ../lib/vector/Vlib/read_ogr.c:578
 #, c-format
 msgid "OGR feature type %d not supported"
+msgstr ""
 #: ../lib/vector/Vlib/build_sfa.c:665
-#, fuzzy, c-format
+#, c-format
 msgid "One feature without geometry skipped"
 msgid_plural "%d features without geometry skipped"
-msgstr[0] "Đối tượng %d không có hình học bị bỏ qua"
-msgstr[1] "Đối tượng %d không có hình học bị bỏ qua"
+msgstr[0] ""
 #: ../lib/vector/Vlib/build_sfa.c:722
-#, fuzzy, c-format
+#, c-format
 msgid "%s: Native format unsupported"
+msgstr ""
 #: ../lib/vector/Vlib/build_sfa.c:748
 msgid "Feature index is built only for non-native formats. Nothing to dump."
@@ -7633,7 +7014,7 @@
 #: ../lib/vector/Vlib/buffer2.c:361
 msgid "Line is not looped"
+msgstr ""
 #: ../lib/vector/Vlib/buffer2.c:443
 #, c-format
@@ -7641,113 +7022,94 @@
 msgstr ""
 #: ../lib/vector/Vlib/buffer2.c:589
-#, fuzzy
-msgid ""
-"Next edge was visited (right) but it is not the first one !!! breaking loop"
+msgid "Next edge was visited (right) but it is not the first one !!! breaking loop"
 msgstr ""
-"Gờ tiếp theo đã được kiểm tra nhưng nó không phải là cái đầu tiên!!! Đang "
-"ngắt nút lặp"
 #: ../lib/vector/Vlib/buffer2.c:600
-#, fuzzy
-msgid ""
-"Next edge was visited (left) but it is not the first one !!! breaking loop"
+msgid "Next edge was visited (left) but it is not the first one !!! breaking loop"
 msgstr ""
-"ngắt nút lặp"
 #: ../lib/vector/Vlib/buffer2.c:648
 msgid "side != 0 feature not implemented"
-msgstr "cạnh != 0 kiểu đối tượng chưa được đưa vào chương trình"
+msgstr ""
 #: ../lib/vector/Vlib/buffer2.c:890 ../lib/vector/Vlib/buffer2.c:937
 msgid "zero area size"
 msgstr ""
 #: ../lib/vector/Vlib/buffer2.c:896 ../lib/vector/Vlib/buffer2.c:943
-#, fuzzy
 msgid "Line was not closed"
+msgstr ""
 #: ../lib/vector/Vlib/buffer2.c:909 ../lib/vector/Vlib/buffer2.c:960
 msgid "Vect_get_point_in_poly() failed"
-msgstr "Vect_get_point_in_poly() thất bại"
+msgstr ""
 #: ../lib/vector/Vlib/open_ogr.c:60
-#, fuzzy
 msgid "OGR datasource not defined"
+msgstr ""
 #: ../lib/vector/Vlib/open_ogr.c:97
-#, fuzzy, c-format
+#, c-format
 msgid "OGR layer <%s> not found"
-msgstr "Không tìm thấy bản đồ raster <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/open_ogr.c:145 ../lib/vector/Vlib/open_pg.c:193
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open feature index file for vector map <%s>"
-msgstr "Không thể mở tập tin chỉ mục phạm trù của bản đồ vec-tơ <%s>"
+msgstr "Không thể mở tập tin chỉ mục đối tượng dùng cho bản đồ vector <%s>"
 #: ../lib/vector/Vlib/open_ogr.c:191
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to get OGR driver <%s>"
-msgstr "Không thể mở trình điều khiển <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/open_ogr.c:199
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create OGR data source '%s'"
+msgstr ""
 #: ../lib/vector/Vlib/open_ogr.c:211
-#, fuzzy, c-format
+#, c-format
 msgid "OGR layer <%s> already exists and will be overwritten"
+msgstr ""
 #: ../lib/vector/Vlib/open_ogr.c:215
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to delete OGR layer <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/open_ogr.c:221
-#, fuzzy, c-format
+#, c-format
 msgid "OGR layer <%s> already exists in datasource '%s'"
-msgstr "Bảng <%s> đã có trong csdl <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/open_ogr.c:279
 #, c-format
-msgid ""
-"Feature index format version %d.%d is not supported by this release. Try to "
-"rebuild topology or upgrade GRASS."
+msgid "Feature index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
 msgstr ""
-"Định dạng chỉ mục đối tượng phiên bản %d.%d không được hỗ trợ trong bản phát "
-"hành này. Hãy thử xây dựng lại tôpô hoặc cập nhật GRASS."
 #: ../lib/vector/Vlib/open_ogr.c:284
 #, c-format
-msgid ""
-"Your GRASS version does not fully support feature index format %d.%d of the "
-"vector. Consider to rebuild topology or upgrade GRASS."
+msgid "Your GRASS version does not fully support feature index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
 msgstr ""
-"Phiên bản GRASS hiện tại của bạn không hỗ trợ đầy đủ định dạng chỉ mục đối "
-"tượng %d.%d của dữ liệu vec-tơ. Hãy cân nhắc việc xây dựng lại tôpô hoặc cập "
-"nhật GRASS."
 #: ../lib/vector/Vlib/overlay.c:72
 msgid "unknown operator"
+msgstr ""
 #: ../lib/vector/Vlib/overlay.c:124
 msgid "Overlay: line/boundary types not supported by AND operator"
-msgstr "Chồng: kiều đường/ranh giới chưa được toán tử AND hỗ trợ"
+msgstr ""
 #: ../lib/vector/Vlib/overlay.c:127
 msgid "Overlay: area x area types not supported by AND operator"
-msgstr "Chồng: các kiều vùng x vùng chưa được toán tử AND hỗ trợ"
+msgstr ""
 #: ../lib/vector/Vlib/remove_duplicates.c:199
-#, fuzzy, c-format
+#, c-format
 msgid "Removed duplicates: %d"
+msgstr ""
 #: ../lib/vector/Vlib/break_polygons.c:102
 msgid "Break polygons: Bug in binary tree!"
@@ -7776,40 +7138,37 @@
 #: ../lib/vector/Vlib/legal_vname.c:43
 #, c-format
 msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
-msgstr "Tên bản đồ vec-tơ không hợp lệ <%s>. Không được chứa '.' hoặc 'NULL'."
+msgstr ""
 #: ../lib/vector/Vlib/legal_vname.c:50
 #, c-format
 msgid "Illegal vector map name <%s>. Must start with a letter."
-msgstr "Tên bản đồ vector không hợp lệ <%s>. Phải bắt đầu với một chữ cái."
+msgstr ""
 #: ../lib/vector/Vlib/legal_vname.c:58
 #, c-format
 msgid "Illegal vector map name <%s>. Character '%c' not allowed."
-msgstr "Tên bản đồ vector không hợp lệ <%s>. Ký tự <%c> không được phép dùng."
+msgstr ""
 #: ../lib/vector/Vlib/legal_vname.c:65
 #, c-format
-msgid ""
-"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
 msgstr ""
-"Tên bản đồ vector không hợp lệ <%s>. Từ khoá SQL không thể được dùng làm tên "
-"bản đồ vec-tơ."
 #: ../lib/vector/Vlib/legal_vname.c:100 ../lib/vector/Vlib/legal_vname.c:104
-#, fuzzy, c-format
+#, c-format
 msgid "Output vector map name <%s> is not in the current mapset (%s)"
-msgstr "Bản đồ raster <%s> không ở trong bộ bản đồ hiện tại (%s)"
+msgstr ""
 #: ../lib/vector/Vlib/legal_vname.c:117 ../lib/vector/Vlib/legal_vname.c:121
-#, fuzzy, c-format
+#, c-format
 msgid "Output vector map name <%s> is not SQL compliant"
+msgstr ""
 #: ../lib/vector/Vlib/legal_vname.c:159 ../lib/vector/Vlib/legal_vname.c:163
 #, c-format
 msgid "Output vector map <%s> is used as input"
-msgstr "Bản đồ vec-tơ đầu ra <%s> được dùng làm đầu vào"
+msgstr ""
 #: ../lib/vector/Vlib/intersect2.c:1169 ../lib/vector/Vlib/intersect2.c:1175
 #: ../lib/vector/Vlib/intersect2.c:1177 ../lib/vector/Vlib/intersect2.c:1229
@@ -7819,27 +7178,26 @@
 #: ../lib/vector/Vlib/intersect.c:1219 ../lib/vector/Vlib/intersect.c:1228
 #: ../lib/vector/Vlib/intersect.c:1249 ../lib/vector/Vlib/intersect.c:1266
 msgid "Error while adding point to array. Out of memory"
-msgstr "Lỗi khi đang thêm điểm vào mảng. Hết bộ nhớ"
+msgstr ""
 #: ../lib/vector/Vlib/copy.c:81
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to copy features. Input vector map <%s> is not open"
-msgstr "Không thể ghi đối tượng, bản đồ vec-tơ không được mở"
+msgstr ""
 #: ../lib/vector/Vlib/copy.c:104
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create PostGIS layer <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/copy.c:133
-#, fuzzy, c-format
+#, c-format
 msgid "Vector map <%s> not open on topological level. Areas will be skipped!"
+msgstr ""
 #: ../lib/vector/Vlib/copy.c:229 ../lib/vector/Vlib/copy.c:234
-#, fuzzy
 msgid "Copying features..."
+msgstr ""
 #: ../lib/vector/Vlib/copy.c:231
 #, c-format
@@ -7851,24 +7209,22 @@
 msgstr ""
 #: ../lib/vector/Vlib/copy.c:340
-#, fuzzy, c-format
+#, c-format
 msgid "%d features without category or from different layer skipped"
+msgstr ""
 #: ../lib/vector/Vlib/copy.c:372
-#, fuzzy
 msgid "Exporting nodes..."
+msgstr ""
 #: ../lib/vector/Vlib/copy.c:400
-#, fuzzy, c-format
+#, c-format
 msgid "Writing node %d failed"
+msgstr ""
 #: ../lib/vector/Vlib/copy.c:478
-#, fuzzy
 msgid "Exporting areas..."
+msgstr ""
 #: ../lib/vector/Vlib/copy.c:505
 #, fuzzy, c-format
@@ -7876,121 +7232,112 @@
 #: ../lib/vector/Vlib/copy.c:534 ../lib/vector/Vlib/copy.c:542
-#, fuzzy, c-format
+#, c-format
 msgid "Writing area %d failed"
+msgstr ""
 #: ../lib/vector/Vlib/copy.c:550
-#, fuzzy, c-format
+#, c-format
 msgid "%d areas without category or from different layer skipped"
+msgstr ""
 #: ../lib/vector/Vlib/copy.c:604
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to copy table <%s> for layer %d from <%s> to <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/copy.c:723
 #, c-format
 msgid "Unable to add database link for vector map <%s>"
-msgstr "Không thể thêm liên kết csdl cho bản đồ vec-tơ '%s'"
+msgstr ""
 #: ../lib/vector/Vlib/copy.c:747
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open database <%s> with driver <%s>"
-msgstr "Không thể mở CSDL <%s> bằng trình điều khiển <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/copy.c:754
-#, fuzzy
 msgid "Unable to create index"
+msgstr ""
 #: ../lib/vector/Vlib/copy.c:760
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to grant privileges on table <%s>"
-msgstr "Không thể tạo bảng <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/open.c:138
-#, fuzzy, c-format
+#, c-format
 msgid "Programmer requested unknown access level %d"
-msgstr "Lập trình viên đã yêu cầu mở ở cấp %d không biết"
+msgstr ""
 #: ../lib/vector/Vlib/open.c:232
-#, fuzzy, c-format
+#, c-format
 msgid "Vector map <%s> not found in current mapset"
-msgstr "'Bọ': cố gắng cập nhật bản đồ không ở trong bộ bản đồ hiện tại."
+msgstr ""
 #: ../lib/vector/Vlib/open.c:252
-#, fuzzy
 msgid "Temporary vector maps can be accessed only in the current mapset"
+msgstr ""
 #: ../lib/vector/Vlib/open.c:277
-msgid ""
-"Vector map which is not in the current mapset cannot be opened for update"
+msgid "Vector map which is not in the current mapset cannot be opened for update"
 msgstr ""
-"Bản đồ vec-tơ không ở trong bộ bản đồ hiện tại nên không thể mở để cập nhật "
-"được"
 #: ../lib/vector/Vlib/open.c:311
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read header file of vector map <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/open.c:352
 #, c-format
 msgid "Unable to open topology file for vector map <%s>"
-msgstr "Không thể mở tập tin tôpô của bản đồ vec-tơ <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/open.c:367 ../lib/vector/Vlib/open.c:871
 #: ../lib/vector/Vlib/build.c:865
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open spatial index file for vector map <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/open.c:393 ../lib/vector/Vlib/cindex.c:539
 #, c-format
 msgid "Unable to open category index file for vector map <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/open.c:419
-#, fuzzy, c-format
-msgid ""
-"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
-"with v.build."
+#, c-format
+msgid "Unable to open vector map <%s> on level %d. Try to rebuild vector topology with v.build."
 msgstr ""
-"Không thể mở bản đồ vec-tơ <%s> ở cấp %d. Hãy thử xây dựng lại tôpô bằng v."
-"build."
 #: ../lib/vector/Vlib/open.c:445
-#, fuzzy, c-format
+#, c-format
 msgid "Building topology for OGR layer <%s> from datasource '%s'..."
+msgstr ""
 #: ../lib/vector/Vlib/open.c:453
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open vector map <%s> on level %d"
-msgstr "không thể mở bản đồ raster [%s in %s]"
+msgstr ""
 #: ../lib/vector/Vlib/open.c:507
 #, c-format
 msgid "Unable to open history file for vector map <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/open.c:777
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create vector map: <%s> is not in the current mapset (%s)"
+msgstr ""
 #: ../lib/vector/Vlib/open.c:786
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create vector map: <%s> is not SQL compliant"
+msgstr ""
 #: ../lib/vector/Vlib/open.c:846
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open history file of vector map <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/open.c:887
 #, c-format
@@ -8006,14 +7353,13 @@
 msgstr ""
 #: ../lib/vector/Vlib/open.c:896
-#, fuzzy
 msgid "Using native format"
+msgstr ""
 #: ../lib/vector/Vlib/open.c:985
 #, c-format
 msgid "Unable to stat file <%s>"
-msgstr "Không thể khởi động tập tin <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/open.c:1049
 #, c-format
@@ -8022,46 +7368,43 @@
 #: ../lib/vector/Vlib/open.c:1138
 msgid "Size of 'coor' file differs from value saved in topology file"
-msgstr "Kích thước của tập tin 'coor' khác với giá trị lưu trong tập tin tôpô."
+msgstr ""
 #: ../lib/vector/Vlib/open.c:1149 ../lib/vector/Vlib/open.c:1248
 #, c-format
 msgid "Please rebuild topology for vector map <%s@%s>"
-msgstr "Vui lòng xây dựng lại tôpô cho bản đồ vec-tơ <%s@%s>"
+msgstr ""
 #: ../lib/vector/Vlib/open.c:1237
-#, fuzzy
 msgid "Size of 'coor' file differs from value saved in sidx file"
+msgstr ""
 #: ../lib/vector/Vlib/open.c:1317
-#, fuzzy
 msgid "Unable to open OGR file"
+msgstr ""
 #: ../lib/vector/Vlib/open.c:1343
 msgid "OGR output also detected, using OGR"
 msgstr ""
 #: ../lib/vector/Vlib/close.c:91
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create vector map <%s>"
-msgstr "Không thể đọc bản đồ vec-tơ <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/close.c:108
-#, fuzzy
 msgid "Copying features failed"
+msgstr ""
 #: ../lib/vector/Vlib/close.c:141
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open %s file"
+msgstr ""
 #: ../lib/vector/Vlib/close.c:226
 #, c-format
 msgid "Unable to close vector <%s>"
-msgstr "Không thể đóng vec-tơ <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/close.c:257
 #, c-format
@@ -8069,32 +7412,30 @@
 msgstr ""
 #: ../lib/vector/Vlib/close.c:289
-#, fuzzy, c-format
+#, c-format
 msgid "Link to vector map <%s> created"
+msgstr ""
 #: ../lib/vector/Vlib/cindex.c:32
 msgid "Category index is not up to date"
-msgstr "Chỉ mục phạm trù không cập nhật"
+msgstr ""
 #: ../lib/vector/Vlib/cindex.c:38
 msgid "Layer index out of range"
-msgstr "Chỉ mục phạm trù nằm ngoài miền"
+msgstr ""
 #: ../lib/vector/Vlib/cindex.c:268
-#, fuzzy
 msgid "Category index out of range"
+msgstr ""
 #: ../lib/vector/Vlib/cindex.c:488
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create category index file for vector map <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/cindex.c:497
-#, fuzzy
 msgid "Error writing out category index file"
-msgstr "Lỗi khi đang ghi tập tin chỉ mục phạm trù <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/snap.c:223 ../lib/vector/Vlib/snap.c:582
 msgid "Snap vertices Pass 1: select points"
@@ -8114,19 +7455,17 @@
 msgstr ""
 #: ../lib/vector/Vlib/snap.c:526 ../lib/vector/Vlib/snap.c:888
-#, fuzzy, c-format
+#, c-format
 msgid "New vertices: %d"
-msgstr "Số đối tượng nguyên thủy: %d"
+msgstr ""
 #: ../lib/vector/Vlib/snap.c:915
-#, fuzzy
 msgid "Reading features..."
+msgstr ""
 #: ../lib/vector/Vlib/build_pg.c:88
-#, fuzzy
 msgid "No DB connection"
-msgstr "Kết nối với máy chủ kém"
+msgstr ""
 #: ../lib/vector/Vlib/build_pg.c:93 ../lib/vector/Vlib/build_ogr.c:82
 #, c-format
@@ -8134,11 +7473,8 @@
 msgstr ""
 #: ../lib/vector/Vlib/build_pg.c:95
-#, fuzzy
 msgid "Random read is not supported for this layer. Unable to build topology."
 msgstr ""
-"Việc đọc ngẫu nhiên không được OGR hỗ trợ đối với lớp này, không thể xây "
-"dựng hỗ trợ"
 #: ../lib/vector/Vlib/build_pg.c:101 ../lib/vector/Vlib/build_ogr.c:90
 #, c-format
@@ -8146,34 +7482,30 @@
 msgstr ""
 #: ../lib/vector/Vlib/build_pg.c:105
-#, fuzzy
 msgid "Building pseudo-topology over simple features..."
+msgstr ""
 #: ../lib/vector/Vlib/build_pg.c:107
-#, fuzzy, c-format
+#, c-format
 msgid "Building topology from PostGIS topology schema <%s>..."
+msgstr ""
 #: ../lib/vector/Vlib/build_pg.c:212 ../lib/vector/Vlib/open_pg.c:1485
 #, c-format
 msgid "Inconsistency in topology: number of nodes %d (should be %d)"
-msgstr ""
+msgstr "Không nhất quán về tô-pô: số lượng nốt %d (phải là %d)"
 #: ../lib/vector/Vlib/build_pg.c:237
-#, fuzzy
 msgid "Cleaning-up topology schema..."
+msgstr ""
 #: ../lib/vector/Vlib/build_pg.c:282
-#, fuzzy
 msgid "Updating faces..."
+msgstr ""
 #: ../lib/vector/Vlib/build_pg.c:314
-#, fuzzy
 msgid "Updating edges..."
+msgstr ""
 #: ../lib/vector/Vlib/build_pg.c:323
 msgid "Inconsistency in topology detected. Dead line found."
@@ -8184,39 +7516,36 @@
 msgstr ""
 #: ../lib/vector/Vlib/build_pg.c:462
-#, fuzzy, c-format
+#, c-format
 msgid "Unsupported topo geometry type %d"
+msgstr ""
 #: ../lib/vector/Vlib/build_pg.c:491
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create <%s.%s>"
+msgstr ""
 #: ../lib/vector/Vlib/build_pg.c:642
-#, fuzzy
 msgid "Unable to write nodes, offset array mismatch"
-msgstr "Không thể ghi nốt vào tập tin plus"
+msgstr ""
 #: ../lib/vector/Vlib/build_pg.c:671
-#, fuzzy
 msgid "Unable to write nodes"
+msgstr ""
 #: ../lib/vector/Vlib/build_pg.c:716
-#, fuzzy, c-format
+#, c-format
 msgid "Inconsistency in topology: number of boundaries %d (should be %d)"
+msgstr ""
 #: ../lib/vector/Vlib/build_pg.c:739
-#, fuzzy
 msgid "Unable to write lines"
+msgstr ""
 #: ../lib/vector/Vlib/build_pg.c:790
-#, fuzzy, c-format
+#, c-format
 msgid "Topology for centroid %d not available. Area %d skipped"
+msgstr ""
 #: ../lib/vector/Vlib/build_pg.c:1000
 msgid "Create simple features topology from topogeometry data..."
@@ -8224,62 +7553,51 @@
 #: ../lib/vector/Vlib/build_pg.c:1018
 #, c-format
-msgid ""
-"Unable to build simple features from topogeometry data. Unsupported type %d."
+msgid "Unable to build simple features from topogeometry data. Unsupported type %d."
 msgstr ""
 #: ../lib/vector/Vlib/read.c:93 ../lib/vector/Vlib/read.c:129
 #: ../lib/vector/Vlib/read.c:168
-#, fuzzy
 msgid "Vector map is not open for reading"
+msgstr ""
 #: ../lib/vector/Vlib/read.c:136 ../lib/vector/Vlib/read.c:180
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read feature %d from vector map <%s>"
-msgstr "Không thể đọc đối tượng %d từ bản đồ vec-tơ <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/read.c:200
-#, fuzzy
 msgid "Line index is out of range"
+msgstr ""
 #: ../lib/vector/Vlib/read.c:224
-#, fuzzy
 msgid "Node index is out of range"
+msgstr ""
 #: ../lib/vector/Vlib/read.c:248
-#, fuzzy
 msgid "Area index is out of range"
+msgstr ""
 #: ../lib/vector/Vlib/read.c:272
-#, fuzzy
 msgid "Isle index is out of range"
+msgstr ""
 #: ../lib/vector/Vlib/geos.c:52
 msgid "vector map is not opened"
+msgstr ""
 #: ../lib/vector/Vlib/geos.c:55
-#, fuzzy, c-format
-msgid ""
-"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
-"vector map <%s>: %d)"
+#, c-format
+msgid "Vect_read_line_geos(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
 msgstr ""
-"Vect_read_line(): đối tượng có id %d không hợp lý (số đối tượng nhiều nhất "
-"trong bản đồ vec-tơ <%s>: %d)"
 #: ../lib/vector/Vlib/geos.c:60
-#, fuzzy
 msgid "only native format supported"
+msgstr ""
 #: ../lib/vector/Vlib/geos.c:65 ../lib/vector/Vlib/geos.c:258
 msgid "Attempt to read dead line"
-msgstr "Cố gắng đọc dòng chết"
+msgstr ""
 #: ../lib/vector/Vlib/geos.c:90
 #, c-format
@@ -8292,71 +7610,71 @@
 msgstr ""
 #: ../lib/vector/Vlib/geos.c:205
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read line offset %ld"
+msgstr ""
 #: ../lib/vector/Vlib/geos.c:412
-#, fuzzy, c-format
+#, c-format
 msgid "Attempt to read points of nonexistent area id %d"
-msgstr "Cố gắng đọc các điểm của một vùng không tồn tại"
+msgstr ""
 #: ../lib/vector/Vlib/geos.c:472
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read feature id %d"
+msgstr ""
 #: ../lib/vector/Vlib/line.c:184 ../lib/vector/Vlib/line.c:217
 #: ../lib/vector/Vlib/line.c:250
 msgid "Index out of range in"
-msgstr "Chỉ mục nằm ngoài miền trong"
+msgstr ""
 #: ../lib/vector/Vlib/line.c:550
 msgid "Segment outside line, no segment created"
-msgstr "Phân đoạn nằm ngoài đường, không có phân đoạn nào được tạo ra"
+msgstr ""
 #: ../lib/vector/Vlib/close_nat.c:74
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create '%s': %s"
+msgstr ""
 #: ../lib/vector/Vlib/close_nat.c:81
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to copy '%s': %s"
+msgstr ""
 #: ../lib/vector/Vlib/close_nat.c:167
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to drop table <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/constraint.c:150
 msgid "Layer constraint ignored for non-native vector formats"
 msgstr ""
 #: ../lib/vector/Vlib/ascii.c:84
-#, fuzzy, c-format
+#, c-format
 msgid "Error reading ASCII file: (bad type) [%s]"
-msgstr "Không thể đọc tập tin range cho [%s ở %s]"
+msgstr ""
 #: ../lib/vector/Vlib/ascii.c:123
-#, fuzzy, c-format
+#, c-format
 msgid "Error reading ASCII file: (unknown type) [%s]"
+msgstr ""
 #: ../lib/vector/Vlib/ascii.c:143
 msgid "End of ASCII file reached before end of coordinates"
 msgstr ""
 #: ../lib/vector/Vlib/ascii.c:155
-#, fuzzy, c-format
+#, c-format
 msgid "Error reading ASCII file: (bad point) [%s]"
+msgstr ""
 #: ../lib/vector/Vlib/ascii.c:160
-#, fuzzy, c-format
+#, c-format
 msgid "Unparsable longitude value: [%s]"
-msgstr "Không thể khởi tạo pj nguyên nhân: %s"
+msgstr ""
 #: ../lib/vector/Vlib/ascii.c:165
 #, c-format
@@ -8368,14 +7686,13 @@
 msgstr ""
 #: ../lib/vector/Vlib/ascii.c:212
-#, fuzzy, c-format
+#, c-format
 msgid "Error reading categories: [%s]"
+msgstr ""
 #: ../lib/vector/Vlib/ascii.c:225
-#, fuzzy
 msgid "Unable to copy points"
+msgstr ""
 #: ../lib/vector/Vlib/ascii.c:238
 #, c-format
@@ -8390,14 +7707,14 @@
 msgstr ""
 #: ../lib/vector/Vlib/ascii.c:306
-#, fuzzy, c-format
+#, c-format
 msgid "Unknown keyword <%s> in vector head"
+msgstr ""
 #: ../lib/vector/Vlib/ascii.c:465
-#, fuzzy, c-format
+#, c-format
 msgid "Column <%s> does not exist"
-msgstr "Cột <%s> không phải kiểu số nguyên"
+msgstr ""
 #: ../lib/vector/Vlib/ascii.c:467
 msgid "Available columns:"
@@ -8408,19 +7725,19 @@
 msgstr ""
 #: ../lib/vector/Vlib/ascii.c:505
-#, fuzzy, c-format
+#, c-format
 msgid "Unknown type of column <%s>, export cancelled"
-msgstr "Kiểu cột không biết (cột <%s>)"
+msgstr ""
 #: ../lib/vector/Vlib/ascii.c:539
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to select record from table <%s> (key %s, column %s)"
-msgstr "Không thể chọn bản ghi từ bảng <%s> (khoá %s, tại %s)"
+msgstr ""
 #: ../lib/vector/Vlib/ascii.c:661
-#, fuzzy, c-format
+#, c-format
 msgid "Unknown feature type %d"
-msgstr "Kiểu vec-tơ không biết."
+msgstr ""
 #: ../lib/vector/Vlib/ascii.c:701
 #, c-format
@@ -8428,14 +7745,13 @@
 msgstr ""
 #: ../lib/vector/Vlib/ascii.c:718
-#, fuzzy, c-format
+#, c-format
 msgid "Cannot select attributes for cat = %d"
-msgstr "Không thể chọn các thuộc tính"
+msgstr ""
 #: ../lib/vector/Vlib/ascii.c:724
-#, fuzzy
 msgid "Unable to fetch data from table"
+msgstr ""
 #: ../lib/vector/Vlib/ascii.c:756 ../lib/vector/Vlib/net_build.c:216
 #: ../lib/vector/Vlib/net_build.c:501 ../lib/vector/Vlib/net_build.c:519
@@ -8443,104 +7759,94 @@
 #: ../lib/vector/Vlib/net_build.c:981
 #, c-format
 msgid "Column <%s> not found in table <%s>"
-msgstr "Không tìm thấy cột <%s> trong bảng <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/ascii.c:758
-#, fuzzy, c-format
+#, c-format
 msgid "Column <%s>: unsupported data type"
-msgstr "Nviz_new_map_obj(): kiểu dữ liệu không được hỗ trợ"
+msgstr ""
 #: ../lib/vector/Vlib/ascii.c:840
-#, fuzzy
 msgid "Unknown format"
+msgstr ""
 #: ../lib/vector/Vlib/ascii.c:850
 msgid "Topology not available, unable to process areas"
 msgstr ""
 #: ../lib/vector/Vlib/ascii.c:863
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to get boundary of area id %d"
+msgstr ""
 #: ../lib/vector/Vlib/ascii.c:875
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to get boundary of isle id %d (area id %d)"
+msgstr ""
 #: ../lib/vector/Vlib/ascii.c:889
 #, c-format
-msgid ""
-"%d features without category skipped. To export also features without "
-"category use '%s=-1'."
+msgid "%d features without category skipped. To export also features without category use '%s=-1'."
 msgstr ""
 #: ../lib/vector/Vlib/array.c:96
-#, fuzzy, c-format
+#, c-format
 msgid "%d errors in category string"
-msgstr "%d lỗi trong chuỗi phạm trù."
+msgstr ""
 #: ../lib/vector/Vlib/array.c:142 ../lib/vector/Vlib/array.c:267
 msgid "Mixed area and other type requested for vector array"
-msgstr "Vùng hỗn hợp (mixed) và kiểu khác được yều cầu cho mảng vec-tơ"
+msgstr ""
 #: ../lib/vector/Vlib/array.c:152 ../lib/vector/Vlib/array.c:175
 #: ../lib/vector/Vlib/array.c:304 ../lib/vector/Vlib/array.c:336
 msgid "Not enough space in vector array"
-msgstr "Không đủ không gian trong mảng vec-tơ"
+msgstr ""
 #: ../lib/vector/Vlib/array.c:292
 #, c-format
 msgid "Unable to select record from table <%s> (key %s, where %s)"
+msgstr ""
 #: ../lib/vector/Vlib/close_ogr.c:104 ../lib/vector/Vlib/close_pg.c:139
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to save feature index file for vector map <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/build_ogr.c:71
 msgid "Empty OGR layer, nothing to build"
 msgstr ""
 #: ../lib/vector/Vlib/build_ogr.c:84
-#, fuzzy
-msgid ""
-"Random read is not supported by OGR for this layer. Unable to build topology."
+msgid "Random read is not supported by OGR for this layer. Unable to build topology."
 msgstr ""
-"dựng hỗ trợ"
 #: ../lib/vector/Vlib/build_ogr.c:134
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open fidx file for write <%s>"
-msgstr "Không thể mở tập tin tôpô để ghi <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/dgraph.c:432
-msgid ""
-"Trying to add more edges to the planar_graph than the initial allocation "
-"size allows"
+msgid "Trying to add more edges to the planar_graph than the initial allocation size allows"
 msgstr ""
 #: ../lib/vector/Vlib/cats.c:45
 msgid "Vect_new_cats_struct(): Out of memory"
-msgstr "Vect_new_cats_struct(): Hết bộ nhớ"
+msgstr ""
 #: ../lib/vector/Vlib/cats.c:127
 #, c-format
 msgid "Too many categories (%d), unable to set cat %d (layer %d)"
-msgstr "Quá nhiều phạm trù (%d), không thể thiết lập cat %d (lớp %d)"
+msgstr ""
 #: ../lib/vector/Vlib/cats.c:419
 #, c-format
 msgid "Unable to convert category string '%s' (from '%s') to category range"
-msgstr "Không thể đổi chuỗi phạm trù '%s' (từ '%s') thành miền phạm trù"
+msgstr ""
 #: ../lib/vector/Vlib/cats.c:572 ../lib/vector/Vlib/cats.c:668
-#, fuzzy
 msgid "Layer number must be > 0 for category constraints"
+msgstr ""
 #: ../lib/vector/Vlib/cats.c:585
 #, c-format
@@ -8548,16 +7854,15 @@
 msgstr ""
 #: ../lib/vector/Vlib/cats.c:593
-#, fuzzy, c-format
+#, c-format
 msgid "Loading categories from table <%s>..."
-msgstr "Đang nạp bản đồ raster <%s>..."
+msgstr ""
 #: ../lib/vector/Vlib/cats.c:605
-#, fuzzy, c-format
+#, c-format
 msgid "One category loaded"
 msgid_plural "%d categories loaded"
-msgstr[0] "Giá trị phạm trù"
-msgstr[1] "Giá trị phạm trù"
+msgstr[0] ""
 #: ../lib/vector/Vlib/cats.c:627
 #, c-format
@@ -8565,29 +7870,28 @@
 msgstr ""
 #: ../lib/vector/Vlib/cats.c:637
-#, fuzzy, c-format
+#, c-format
 msgid "%d errors in '%s' option"
+msgstr ""
 #: ../lib/vector/Vlib/area.c:50
 msgid "Attempt to read points of nonexistent area"
+msgstr ""
 #: ../lib/vector/Vlib/area.c:81
-#, fuzzy
 msgid "Attempt to read points of nonexistent isle"
+msgstr ""
 #: ../lib/vector/Vlib/area.c:121 ../lib/vector/Vlib/area.c:153
 #: ../lib/vector/Vlib/area.c:219 ../lib/vector/Vlib/area.c:248
 #, c-format
 msgid "Attempt to read topo for dead area (%d)"
-msgstr "Cố gắng đọc tôpô của vùng chết (%d)"
+msgstr ""
 #: ../lib/vector/Vlib/area.c:189 ../lib/vector/Vlib/area.c:275
 #, c-format
 msgid "Attempt to read topo for dead isle (%d)"
-msgstr "Cố gắng đọc tôpô của đảo chết (%d)"
+msgstr ""
 #: ../lib/vector/Vlib/merge_lines.c:240
 #, c-format
@@ -8600,46 +7904,45 @@
 msgstr ""
 #: ../lib/vector/Vlib/box.c:264
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to determine bbox for feature %d"
+msgstr ""
 #: ../lib/vector/Vlib/box.c:313 ../lib/vector/Vlib/box.c:359
-#, fuzzy, c-format
+#, c-format
 msgid "Attempt to access area with invalid id (%d)"
-msgstr "Cố gắng xoá đối tượng chết"
+msgstr ""
 #: ../lib/vector/Vlib/box.c:325
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to determine bbox for area %d"
+msgstr ""
 #: ../lib/vector/Vlib/box.c:371
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to determine bbox for isle %d"
+msgstr ""
 #: ../lib/vector/Vlib/net_build.c:101 ../lib/vector/Vlib/net_build.c:727
 msgid "Building graph..."
+msgstr ""
 #: ../lib/vector/Vlib/net_build.c:143 ../lib/vector/Vlib/net_build.c:775
 msgid "Unable to build network graph"
+msgstr ""
 #: ../lib/vector/Vlib/net_build.c:149 ../lib/vector/Vlib/net_build.c:781
 msgid "Forward costs column not specified"
-msgstr "Cột chi phí tới không được chỉ định"
+msgstr ""
 #: ../lib/vector/Vlib/net_build.c:156
-#, fuzzy
 msgid "Turntable field < 1"
-msgstr "Trường Arc < 1"
+msgstr ""
 #: ../lib/vector/Vlib/net_build.c:172
-#, fuzzy, c-format
+#, c-format
 msgid "Turntable column <%s> not found in table <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/net_build.c:182 ../lib/vector/Vlib/net_build.c:223
 #: ../lib/vector/Vlib/net_build.c:508 ../lib/vector/Vlib/net_build.c:526
@@ -8647,256 +7950,231 @@
 #: ../lib/vector/Vlib/net_build.c:988
 #, c-format
 msgid "Data type of column <%s> not supported (must be numeric)"
-msgstr "Kiểu dữ liệu của cột <%s> không được hỗ trợ (phải là kiểu số)"
+msgstr ""
 #: ../lib/vector/Vlib/net_build.c:202 ../lib/vector/Vlib/net_build.c:967
 msgid "Setting node costs..."
-msgstr "Đang thiết lập các chi phí nốt..."
+msgstr ""
 #: ../lib/vector/Vlib/net_build.c:277 ../lib/vector/Vlib/net_build.c:1032
 #, c-format
 msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
 msgstr ""
-"Không tìm thấy bản ghi csdl cho nốt %d (cat = %d) (chi phí thiết lập về 0)"
 #: ../lib/vector/Vlib/net_build.c:332 ../lib/vector/Vlib/net_build.c:352
-#, fuzzy
 msgid "Cannot add network arc for virtual node connection."
-msgstr "Không thể thêm cung mạng lưới"
+msgstr ""
 #: ../lib/vector/Vlib/net_build.c:364
 #, c-format
 msgid ""
-"There exists more than one point of node <%d> with unique category field  <"
-"%d>.\n"
-"The unique categories layer is not valid therefore you will probably get "
-"incorrect results."
+"There exists more than one point of node <%d> with unique category field  <%d>.\n"
+"The unique categories layer is not valid therefore you will probably get incorrect results."
 msgstr ""
 #: ../lib/vector/Vlib/net_build.c:393
 #, c-format
 msgid ""
-"Unable to find point representing intersection <%d> in unique categories "
-"field <%d>.\n"
+"Unable to find point representing intersection <%d> in unique categories field <%d>.\n"
 "Cost for the intersection was set to 0.\n"
 msgstr ""
 #: ../lib/vector/Vlib/net_build.c:407
 #, c-format
 msgid ""
-"Unable to find node for point representing intersection <%d> in unique "
-"categories field <%d>.\n"
+"Unable to find node for point representing intersection <%d> in unique categories field <%d>.\n"
 msgstr ""
 #: ../lib/vector/Vlib/net_build.c:432
-#, fuzzy, c-format
-msgid ""
-"Database record for turn with cat = %d in not found. (The turn was skipped."
+#, c-format
+msgid "Database record for turn with cat = %d in not found. (The turn was skipped."
 msgstr ""
 #: ../lib/vector/Vlib/net_build.c:465
-#, fuzzy
 msgid "Cannot add network arc representing turn."
+msgstr ""
 #: ../lib/vector/Vlib/net_build.c:487 ../lib/vector/Vlib/net_build.c:788
 msgid "Arc field < 1"
+msgstr ""
 #: ../lib/vector/Vlib/net_build.c:539 ../lib/vector/Vlib/net_build.c:840
 msgid "Registering arcs..."
-msgstr "Đang đăng ký các cung..."
+msgstr ""
 #: ../lib/vector/Vlib/net_build.c:558
 #, c-format
 msgid ""
 "Line with id <%d> has more unique categories defined in field <%d>.\n"
 msgstr ""
 #: ../lib/vector/Vlib/net_build.c:579
-#, fuzzy, c-format
-msgid ""
-"Database record for line %d (cat = %d, forward/both direction(s)) not found "
-"(cost was set to 0)"
+#, c-format
+msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (cost was set to 0)"
 msgstr ""
-"Không tìm thấy bản ghi csdl cho đường %d (cat = %d, hướng tới/cả hai hướng)
(hướng tới/cả hai hướng của đường bị bỏ qua)"
 #: ../lib/vector/Vlib/net_build.c:596
-#, fuzzy, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not found(cost "
-"was set to 0)"
-msgstr "Không tìm thấy bản ghi cho đường %d (cat = %d, hướng lui)
(hướng của đường bị bỏ qua)"
+#, c-format
+msgid "Database record for line %d (cat = %d, backword direction) not found(cost was set to 0)"
+msgstr ""
 #: ../lib/vector/Vlib/net_build.c:658 ../lib/vector/Vlib/net_build.c:1064
 msgid "Flattening the graph..."
-msgstr "Đang làm phẳng biểu đồ..."
+msgstr ""
 #: ../lib/vector/Vlib/net_build.c:667 ../lib/vector/Vlib/net_build.c:1073
 msgid "Graph was built"
-msgstr "Biểu đồ đã được xây dựng"
+msgstr ""
 #: ../lib/vector/Vlib/net_build.c:869
 #, c-format
-msgid ""
-"(forward/both direction(s) of line skipped)"
+msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (forward/both direction(s) of line skipped)"
 msgstr ""
 #: ../lib/vector/Vlib/net_build.c:888
 #, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not "
-"found(direction of line skipped)"
+msgid "Database record for line %d (cat = %d, backword direction) not found(direction of line skipped)"
+msgstr ""
 #: ../lib/vector/Vlib/net_build.c:937
 msgid "Cannot add network arc"
+msgstr ""
 #: ../lib/vector/Vlib/simple_features.c:225
-#, fuzzy, c-format
+#, c-format
 msgid "Unknown Simple Features type (%d)"
-msgstr "kiểu nội suy không hiểu"
+msgstr ""
 #: ../lib/vector/Vlib/simple_features.c:332
-#, fuzzy
 msgid "Unable to get number of simple features"
-msgstr "Không thể thiết lập phạm trù %d cho (đối tượng có id %d)"
+msgstr ""
 #: ../lib/vector/Vlib/simple_features.c:341
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to report simple features for vector map <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/read_ogr.c:215 ../lib/vector/Vlib/read_ogr.c:224
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to get feature geometry, fid %ld"
-msgstr "Không thể lấy hình học của đối tượng, FID %ld"
+msgstr ""
 #: ../lib/vector/Vlib/read_ogr.c:390
 msgid "OGR feature without ID"
-msgstr "Đối tượng OGR không có ID"
+msgstr ""
 #: ../lib/vector/Vlib/read_ogr.c:514
-#, fuzzy, c-format
+#, c-format
 msgid "OGR feature type '%s' not supported"
-msgstr "Kiểu đối tượng OGR %d không được hỗ trợ"
+msgstr ""
 #: ../lib/vector/Vlib/graph.c:138
 msgid "Unable to add network arc"
+msgstr ""
 #: ../lib/vector/Vlib/graph.c:226 ../lib/vector/Vlib/net_analyze.c:198
 #, c-format
 msgid "dglShortestPath error: %s"
-msgstr "Lỗi dglShortestPath: %s"
+msgstr ""
 #: ../lib/vector/Vlib/level_two.c:23
-#, fuzzy, c-format
+#, c-format
 msgid "Vector map <%s> is not open at topological level"
+msgstr ""
 #: ../lib/vector/Vlib/level_two.c:284
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid node id: %d"
+msgstr ""
 #: ../lib/vector/Vlib/level_two.c:316
-#, fuzzy, c-format
+#, c-format
 msgid "Nodes not available for line %d"
-msgstr "Không có trợ giúp cho lệnh [%s]\n"
+msgstr ""
 #: ../lib/vector/Vlib/level_two.c:357
-#, fuzzy, c-format
+#, c-format
 msgid "Areas not available for line %d"
+msgstr ""
 #: ../lib/vector/Vlib/level_two.c:362
-#, fuzzy, c-format
+#, c-format
 msgid "Line %d is not a boundary"
-msgstr "Đường không bị thắt nút"
+msgstr ""
 #: ../lib/vector/Vlib/level_two.c:445
-#, fuzzy, c-format
+#, c-format
 msgid "Topology info not available for feature %d"
+msgstr ""
 #: ../lib/vector/Vlib/intersect.c:127
 msgid "3D not supported by Vect_segment_intersection()"
-msgstr "3D chưa được Vect_segment_intersection() hỗ trợ"
+msgstr ""
 #: ../lib/vector/Vlib/intersect.c:313
 msgid "Vect_segment_intersection() ERROR (collinear vertical segments)"
-msgstr "Vect_segment_intersection() LỖI (các phân đoạn đứng cộng tuyến)"
+msgstr ""
 #: ../lib/vector/Vlib/intersect.c:407
 msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
+msgstr ""
 #: ../lib/vector/Vlib/break_lines.c:563
-#, fuzzy, c-format
+#, c-format
 msgid "Intersections: %d"
-msgstr "Các giao điểm: %5d"
+msgstr ""
 #: ../lib/vector/Vlib/select.c:116
 #, c-format
 msgid "Unable to delete item %d from spatial index"
-msgstr "Không thể xoá mục %d khỏi chỉ mục không gian"
+msgstr ""
 #: ../lib/vector/Vlib/write_sfa.c:117
-#, fuzzy
 msgid "Unable to calculate centroid for area"
+msgstr ""
 #: ../lib/vector/Vlib/write_sfa.c:219
 msgid "Attempt to delete dead feature"
+msgstr ""
 #: ../lib/vector/Vlib/write_sfa.c:311
-#, fuzzy, c-format
+#, c-format
 msgid "Unsupported vector map format (%d)"
+msgstr ""
 #: ../lib/vector/Vlib/bridges.c:213
-#, fuzzy, c-format
+#, c-format
 msgid "Removed lines: %d"
+msgstr ""
 #: ../lib/vector/Vlib/bridges.c:214
-#, fuzzy, c-format
+#, c-format
 msgid "Removed bridges: %d"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:115
-#, fuzzy
 msgid "Area of size = 0.0 (less than 4 vertices) ignored"
-msgstr "Vùng có kích thước = 0.0  bị bỏ qua"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:131
 msgid "Unable to add area (map closed, topo saved)"
-msgstr "Không thể thêm vùng (bản đồ đã đóng, tôpô đã lưu)"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:139
 msgid "Unable to add isle (map closed, topo saved)"
-msgstr "Không thể thêm đảo (bản đồ đã đóng, tôpô đã lưu)"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:149
 msgid "Area of size = 0.0 ignored"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:200
 msgid "Request to find area outside nonexistent isle"
-msgstr "Yêu cầu tìm kiếm vùng nằm ngoài đảo không tồn tại"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:351
 msgid "Larger bbox but smaller area!!!"
@@ -8907,304 +8185,293 @@
 msgstr ""
 #: ../lib/vector/Vlib/build.c:641
-#, fuzzy, c-format
+#, c-format
 msgid "Number of lines of length zero: %d"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:643
-#, fuzzy, c-format
+#, c-format
 msgid "Number of boundaries of length zero: %d"
-msgstr "Số ranh giới: %d"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:652
-#, fuzzy, c-format
+#, c-format
 msgid "Number of boundary intersections: %d"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:676
-#, fuzzy
 msgid "Skipping further checks because of incorrect boundaries"
-msgstr "Số ranh giới không đúng: %d"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:726
-#, fuzzy, c-format
+#, c-format
 msgid "Number of redundant holes: %d"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:871
 #, c-format
 msgid "Building topology for vector map <%s>..."
+msgstr ""
 #: ../lib/vector/Vlib/build.c:889
 msgid "Topology was built"
-msgstr "Tôpô đã được xây dựng"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:900
 #, c-format
 msgid "Number of nodes: %d"
-msgstr "Số nốt: %d"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:901
 #, c-format
 msgid "Number of primitives: %d"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:902
 #, c-format
 msgid "Number of points: %d"
-msgstr "Số điểm: %d"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:903
 #, c-format
 msgid "Number of lines: %d"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:904
 #, c-format
 msgid "Number of boundaries: %d"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:905
 #, c-format
 msgid "Number of centroids: %d"
-msgstr "Số trọng tâm: %d"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:908
 #, c-format
 msgid "Number of faces: %d"
-msgstr "Số mặt: %d"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:911
 #, c-format
 msgid "Number of kernels: %d"
-msgstr "Số nhân: %d"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:957
 #, c-format
 msgid "Number of areas: %d"
-msgstr "Số vùng: %d"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:958
 #, c-format
 msgid "Number of isles: %d"
-msgstr "Số đảo: %d"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:963
 #, c-format
 msgid "Number of areas without centroid: %d"
-msgstr "Số vùng không có trọng tâm: %d"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:968
-#, fuzzy, c-format
+#, c-format
 msgid "Number of centroids exceeds number of areas: %d > %d"
-msgstr "Số trọng tâm ngoài vùng: %d"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:972
 #, c-format
 msgid "Number of incorrect boundaries: %d"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:976
 #, c-format
 msgid "Number of centroids outside area: %d"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:980
 #, c-format
 msgid "Number of duplicate centroids: %d"
-msgstr "Số trọng tâm bị đúp: %d"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:984
 msgid "Number of areas: -"
-msgstr "Số vùng: -"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:985
 msgid "Number of isles: -"
-msgstr "Số đảo: -"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:1013
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create topo file for vector map <%s>"
-msgstr "Không thể đọc tập tin header cho bản đồ raster <%s@%s>."
+msgstr ""
 #: ../lib/vector/Vlib/build.c:1021
 msgid "Error writing out topo file"
-msgstr "Lỗi khi đang ghi vào tập tin tôpô"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:1210
-#, fuzzy
-msgid ""
-"Unable to build spatial index from topology, vector map is not opened at "
-"topology level 2"
+msgid "Unable to build spatial index from topology, vector map is not opened at topology level 2"
 msgstr ""
-"Không thể xây dựng chỉ mục không gian từ tôpô, bản đồ vec-tơ không được mở ở "
-"tôpô cấp 2"
 #: ../lib/vector/Vlib/build.c:1233
-#, fuzzy, c-format
+#, c-format
 msgid "%s is no longer supported"
-msgstr "LỖI CỦA CHƯƠNG TRÌNH (Vect_build_sidx_from_topo): nốt không tồn tại"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:1256
 msgid "Spatial index not available, can not be saved"
 msgstr ""
 #: ../lib/vector/Vlib/build.c:1268
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create spatial index file for vector map <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/build.c:1277
 msgid "Error writing out spatial index file"
-msgstr "Lỗi khi đang ghi tập tin chỉ mục không gian"
+msgstr ""
 #: ../lib/vector/Vlib/poly.c:268
 msgid "Unable to find point in polygon"
-msgstr "Không thể tìm thấy điểm trong vùng"
+msgstr ""
 #: ../lib/vector/Vlib/poly.c:810
 msgid "conditions failed"
-msgstr "các điều kiện thất bại"
+msgstr ""
 #: ../lib/vector/Vlib/level.c:34
 msgid "Map structure was never initialized"
-msgstr "Cấu trúc bản đồ chưa từng được khởi tạo"
+msgstr ""
 #: ../lib/vector/Vlib/level.c:36
 msgid "Map structure has been closed"
-msgstr "Cấu trúc bản đồ đã được đóng"
+msgstr ""
 #: ../lib/vector/Vlib/open_pg.c:109 ../lib/vector/Vlib/open_pg.c:267
-#, fuzzy
 msgid "No feature tables found in database."
+msgstr "Không tìm thấy các bảng đối tượng trong csdl."
 #: ../lib/vector/Vlib/open_pg.c:133
-#, fuzzy, c-format
+#, c-format
 msgid "Feature table <%s> not found in 'geometry_columns'"
-msgstr "Không tìm thấy bản đồ raster <%s> trong bộ bản đồ <%s>"
+msgstr "Không tìm thấy bảng đối tượng <%s> trong 'geometry_columns'"
 #: ../lib/vector/Vlib/open_pg.c:181
 msgid "Topology schema not found."
-msgstr ""
+msgstr "Không tìm thấy lược đồ tô-pô."
 #: ../lib/vector/Vlib/open_pg.c:273
-#, fuzzy, c-format
+#, c-format
 msgid "PostGIS layer <%s.%s> already exists and will be overwritten"
+msgstr "Lớp PostGIS <%s.%s> đã có và sẽ bị ghi đè"
 #: ../lib/vector/Vlib/open_pg.c:276
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to delete PostGIS layer <%s>"
-msgstr "Không thể mở lớp <%s>"
+msgstr "Không thể xóa lớp PostGIS <%s>"
 #: ../lib/vector/Vlib/open_pg.c:282
-#, fuzzy, c-format
+#, c-format
 msgid "PostGIS layer <%s.%s> already exists in database '%s'"
+msgstr "Lớp PostGIS <%s.%s> đã có trong csdl '%s'"
 #: ../lib/vector/Vlib/open_pg.c:390
-#, fuzzy
 msgid "No key column detected."
-msgstr "Tên của cột thuộc tính"
+msgstr "Không phát hiện ra cột chìa khóa."
 #: ../lib/vector/Vlib/open_pg.c:462 ../lib/vector/Vlib/open_pg.c:474
-#, fuzzy, c-format
+#, c-format
 msgid "Execution failed: %s"
+msgstr "Việc thực thi thất bại: %s"
 #: ../lib/vector/Vlib/open_pg.c:476
 #, c-format
 msgid "PostGIS topology schema <%s> dropped"
-msgstr ""
+msgstr "Lược đồ tô-pô PostGIS <%s> bị bỏ"
 #: ../lib/vector/Vlib/open_pg.c:559
-#, fuzzy
-msgid ""
-"Connection to PostgreSQL database failed. Try to set up username/password by "
-"db.login."
+msgid "Connection to PostgreSQL database failed. Try to set up username/password by db.login."
+msgstr "Kết nối đến csdl PostgreSQL thất bại. Hãy thử thiết lập tên người dùng/mật mã bằng db.login."
 #: ../lib/vector/Vlib/open_pg.c:566
-#, fuzzy
 msgid "Unable to get database name"
-msgstr "Không thể thêm liên kết csdl"
+msgstr "Không thể lấy tên csdl"
 #: ../lib/vector/Vlib/open_pg.c:571
 #, c-format
 msgid "<%s> is not PostGIS database. DB table 'spatial_ref_sys' not found."
-msgstr ""
+msgstr "<%s> không phải là csdl PostGIS. Không tìm thấy bảng DB 'spatial_ref_sys'."
 #: ../lib/vector/Vlib/open_pg.c:580
-#, fuzzy, c-format
+#, c-format
 msgid "PostGIS Topology extension not found in the database <%s>"
+msgstr "Không tìm thấy phần mở rộng tô-pô PostGIS trong csdl <%s>"
 #: ../lib/vector/Vlib/open_pg.c:667
 msgid "Empty bounding box"
-msgstr ""
+msgstr "Ô bao rỗng"
 #: ../lib/vector/Vlib/open_pg.c:768
 #, c-format
 msgid "Inconsistency in topology: unable to read node %d"
-msgstr ""
+msgstr "Sự không nhất quán trong tô-pô: không thể đọc nốt %d"
 #: ../lib/vector/Vlib/open_pg.c:834
-#, fuzzy, c-format
+#, c-format
 msgid "Inconsistency in topology: node %d - unexpected feature type %d"
+msgstr "Sự không nhất quán trong tô-pô: nốt %d - kiểu đối tượng không mong đợi %d"
 #: ../lib/vector/Vlib/open_pg.c:1003
-#, fuzzy, c-format
+#, c-format
 msgid "Area %d without boundary detected"
+msgstr "Phát hiện vùng %d không có ranh giới"
 #: ../lib/vector/Vlib/open_pg.c:1061
 #, c-format
 msgid "Isle %d without boundary detected"
-msgstr ""
+msgstr "Phát hiện đảo %d không có ranh giới"
 #: ../lib/vector/Vlib/open_pg.c:1128
-#, fuzzy
 msgid "Unable to get map bounding box from topology"
-msgstr "Không thể lấy dữ liệu từ bảng <%s>"
+msgstr "Không thể lấy ô bao từ tô-pô"
 #: ../lib/vector/Vlib/open_pg.c:1135
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Unable to parse map bounding box:\n"
 "%s"
-msgstr "Không thể mở tập tin %s trong %s"
+msgstr ""
+"Không thể phân tách ô bao bản đồ:\n"
+"%s"
 #: ../lib/vector/Vlib/open_pg.c:1159
 #, c-format
 msgid "Different number of nodes detected (%d, %d)"
-msgstr ""
+msgstr "Phát hiện số lượng nốt khác nhau (%d, %d)"
 #: ../lib/vector/Vlib/open_pg.c:1187 ../lib/vector/Vlib/open_pg.c:1209
 #, c-format
 msgid "Different number of areas detected (%d, %d)"
-msgstr ""
+msgstr "Phát hiện số lượng vùng khác nhau (%d, %d)"
 #: ../lib/vector/Vlib/open_pg.c:1380
 msgid "To be implemented: isles not attached in Topo-Geo-only mode"
-msgstr ""
+msgstr "Cần làm: các đảo không gắn kết ở chế độ chỉ-dùng-Tôpô-Geo"
 #: ../lib/vector/Vlib/open_pg.c:1569
 #, c-format
 msgid "Inconsistency in topology: number of points %d (should be %d)"
-msgstr ""
+msgstr "Sự không nhất quán trong tô-pô: số điểm %d (phải là %d)"
 #: ../lib/vector/Vlib/open_pg.c:1614
 #, c-format
 msgid "Inconsistency in topology: number of lines %d (should be %d)"
-msgstr ""
+msgstr "Sự không nhất quán trong tô-pô: số đường %d (phải là %d)"
 #: ../lib/vector/Vlib/open_pg.c:1668
 #, c-format
 msgid "Inconsistency in topology: number of centroids %d (should be %d)"
-msgstr ""
+msgstr "Sự không nhất quán trong tô-pô: số trọng tâm %d (phải là %d)"
 #: ../lib/vector/Vlib/net_analyze.c:288 ../lib/vector/Vlib/net_analyze.c:329
 #, c-format
@@ -9214,202 +8481,170 @@
 #: ../lib/vector/Vlib/net_analyze.c:292 ../lib/vector/Vlib/net_analyze.c:333
 #, c-format
 msgid ""
-"There exists more than one point on node <%d> with unique category in field  "
-"<%d>.\n"
+"There exists more than one point on node <%d> with unique category in field  <%d>.\n"
 "The unique category layer may not be valid."
 msgstr ""
 #: ../lib/vector/Vlib/net_analyze.c:449
 msgid "Wrong line direction in Vect_net_get_line_cost()"
-msgstr "Hướng của đường bị sai trong Vect_net_get_line_cost()"
+msgstr ""
 #: ../lib/vector/diglib/frmt.c:45 ../lib/vector/diglib/frmt.c:70
-#, fuzzy, c-format
+#, c-format
 msgid "Vector format not recognized: %s"
+msgstr "Không nhận diện được định dạng vector: %s"
 #: ../lib/vector/diglib/frmt.c:79 ../lib/vector/diglib/frmt.c:88
-#, fuzzy, c-format
+#, c-format
 msgid "Vector format '%s' not supported"
+msgstr "Định dạng vector '%s' không được hỗ trợ"
 #: ../lib/vector/diglib/frmt.c:97
 #, c-format
 msgid "Format definition is not correct: %s"
-msgstr ""
+msgstr "Định nghĩa định dạng không đúng: %s"
 #: ../lib/vector/diglib/portable.c:208 ../lib/vector/diglib/portable.c:241
 #: ../lib/vector/diglib/portable.c:683 ../lib/vector/diglib/plus_struct.c:563
 msgid "Vector exceeds supported file size limit"
-msgstr ""
+msgstr "Vector vượt quá giới hạn kích thước tập tin được hỗ trợ"
 #: ../lib/vector/diglib/plus.c:222
 msgid "Unable read topology for nodes"
-msgstr "Không thể đọc tôpô cho các nốt"
+msgstr "Không thể đọc tô-pô dùng cho các nốt"
 #: ../lib/vector/diglib/plus.c:227
 #, c-format
 msgid "Unable to read topology for node %d"
-msgstr "Không thể đọc tôpô cho nốt %d"
+msgstr "Không thể đọc tô-pô dùng cho nốt %d"
 #: ../lib/vector/diglib/plus.c:232
 msgid "Unable read topology for lines"
-msgstr "Không thể đọc tôpô cho các đường"
+msgstr "Không thể đọc tô-pô dùng cho các đường"
 #: ../lib/vector/diglib/plus.c:237
 #, c-format
 msgid "Unable to read topology for line %d"
-msgstr "Không thể đọc tôpô cho đường %d"
+msgstr "Không thể đọc tô-pô dùng cho đường %d"
 #: ../lib/vector/diglib/plus.c:242
 msgid "Unable to read topo for areas"
-msgstr "Không thể đọc tôpô cho các vùng"
+msgstr "Không thể đọc tô-pô dùng cho các vùng"
 #: ../lib/vector/diglib/plus.c:247
 #, c-format
 msgid "Unable read topology for area %d"
-msgstr "Không thể đọc tôpô cho vùng %d"
 #: ../lib/vector/diglib/plus.c:252
 msgid "Unable to read topology for isles"
+msgstr "Không thể đọc tô-pô dùng cho các đảo"
 #: ../lib/vector/diglib/plus.c:257
 #, c-format
 msgid "Unable to read topology for isle %d"
-msgstr "Không thể đọc tôpô cho đảo %d"
+msgstr "Không thể đọc tô-pô dùng cho đảo %d"
 #: ../lib/vector/diglib/plus.c:279 ../lib/vector/diglib/plus.c:305
 msgid "Unable to write head to plus file"
-msgstr "Không thể ghi tiêu đề vào tập tin plus"
+msgstr "Không thể ghi đề mục vào tập tin cộng"
 #: ../lib/vector/diglib/plus.c:284
 msgid "Unable to write nodes to plus file"
+msgstr "Không thể ghi các nốt vào tập tin cộng"
 #: ../lib/vector/diglib/plus.c:289
 msgid "Unable to write lines to plus file"
-msgstr "Không thể ghi đường vào tập tin plus"
+msgstr "Không thể ghi các đường vào tập tin cộng"
 #: ../lib/vector/diglib/plus.c:294
 msgid "Unable to write areas to plus file"
-msgstr "Không thể ghi vùng vào tập tin plus"
+msgstr "Không thể ghi các vùng vào tập tin cộng"
 #: ../lib/vector/diglib/plus.c:299
 msgid "Unable to write isles to plus file"
-msgstr "Không thể ghi đảo vào tập tin plus"
+msgstr "Không thể ghi các đảo vào tập tin cộng"
 #: ../lib/vector/diglib/spindex_rw.c:98 ../lib/vector/diglib/spindex_rw.c:106
-#, fuzzy
 msgid "Topology file must be written before spatial index file"
+msgstr "Tập tin tô-pô phải được ghi trước tập tin chỉ mục không gian"
 #: ../lib/vector/diglib/spindex_rw.c:302
-#, fuzzy, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this spatial index format. "
-"Try to rebuild topology or upgrade GRASS to at least version %d."
-msgstr ""
+#, c-format
+msgid "This version of GRASS (%d.%d) is too old to read this spatial index format. Try to rebuild topology or upgrade GRASS to at least version %d."
+msgstr "Phiên bản GRASS này (%d.%d) quá cũ để có thể đọc định dạng chỉ mục không gian này. Hãy cố xây dựng lại tô-pô hoặc nâng cấp lên phiên bản GRASS tối thiểu là %d."
 #: ../lib/vector/diglib/spindex_rw.c:308
-#, fuzzy, c-format
-msgid ""
-"Your GRASS version does not fully support spatial index format %d.%d of the "
-msgstr ""
-"nhật GRASS."
+#, c-format
+msgid "Your GRASS version does not fully support spatial index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
+msgstr "Phiên bản GRASS của bạn không hỗ trợ hoàn toàn định dạng chỉ mục không gian %d.%d của vector. Xem xét xây dựng lại tô-pô hoặc nâng cấp GRASS."
 #: ../lib/vector/diglib/spindex_rw.c:317
-#, fuzzy, c-format
-msgid ""
-"Spatial index format version %d.%d is not supported by this release. Please "
-"rebuild topology."
-msgstr ""
+#, c-format
+msgid "Spatial index format version %d.%d is not supported by this release. Please rebuild topology."
+msgstr "Định dạng chỉ mục không gian %d.%d không được phiên bản này hỗ trợ. Hãy thử xây dựng lại tô-pô."
 #: ../lib/vector/diglib/cindex_rw.c:156
-#, fuzzy, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this category index format. "
-msgstr ""
+#, c-format
+msgid "This version of GRASS (%d.%d) is too old to read this category index format. Try to rebuild topology or upgrade GRASS to at least version %d."
+msgstr "Phiên bản GRASS này (%d.%d) quá cũ để có thể đọc định dạng chỉ mục phạm trù này. Hãy cố xây dựng lại tô-pô hoặc nâng cấp lên phiên bản GRASS tối thiểu là %d."
 #: ../lib/vector/diglib/plus_area.c:215 ../lib/vector/diglib/plus_area.c:711
 #, c-format
 msgid "Line %d already has area/isle %d to left"
-msgstr "Đường %d đã có vùng/đảo %d ở phía trái"
+msgstr "Đường %d đã có vùng/đảo %d ở bên trái"
 #: ../lib/vector/diglib/plus_area.c:225 ../lib/vector/diglib/plus_area.c:719
 #, c-format
 msgid "Line %d already has area/isle %d to right"
-msgstr "Đường %d đã có vùng/đảo %d ở phía phải"
+msgstr "Đường %d đã có vùng/đảo %d ở bên phải"
 #: ../lib/vector/diglib/plus_area.c:279
 msgid "Isle already registered in area"
-msgstr ""
+msgstr "Đảo đã được đăng ký trong vùng"
 #: ../lib/vector/diglib/plus_area.c:313
 msgid "Attempt to delete isle from dead area"
-msgstr "Cố gắng xoá đảo khỏi vùng chết"
+msgstr "Nỗ lực xóa đảo khỏi vùng chết"
 #: ../lib/vector/diglib/plus_area.c:330
 #, c-format
 msgid "Attempt to delete not registered isle %d from area %d"
-msgstr "Cố gắng xoá đảo không đăng ký %d khỏi vùng %d"
+msgstr "Nỗ lực xóa đảo chưa đăng ký %d khỏi vùng %d"
 #: ../lib/vector/diglib/plus_area.c:369
 msgid "Attempt to delete dead area"
-msgstr "Cố gắng xoá vùng chết"
+msgstr "Nỗ lực xóa vùng chết"
 #: ../lib/vector/diglib/plus_area.c:408
 #, c-format
 msgid "Dead centroid %d registered for area (bug in the vector library)"
-msgstr "Trọng tâm chết %d được đăng ký cho vùng ('bọ' trong thư viện vec-tơ)"
+msgstr "Trọng tâm chết %d được đăng ký cho vùng (lỗi trong thư viện vector)"
 #: ../lib/vector/diglib/plus_area.c:431
 #, c-format
 msgid "Attempt to delete area %d info from dead isle %d"
-msgstr "Cố gắng xoá thông tin vùng chết %d khỏi đảo chết %d"
+msgstr "Nỗ lực xóa thông tin vùng %d khỏi đảo chết %d"
 #: ../lib/vector/diglib/plus_area.c:777
 #, c-format
 msgid "Attempt to delete isle %d info from dead area %d"
-msgstr "Cố gắng xoá thông tin đảo chết %d khỏi vùng chết %d"
+msgstr "Nỗ lực xóa thông tin đảo %d khỏi vùng chết %d"
 #: ../lib/vector/diglib/plus_struct.c:523
-#, fuzzy, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this topology format. Try "
-"to rebuild topology or upgrade GRASS to at least version %d."
-msgstr ""
+#, c-format
+msgid "This version of GRASS (%d.%d) is too old to read this topology format. Try to rebuild topology or upgrade GRASS to at least version %d."
+msgstr "Phiên bản GRASS này (%d.%d) quá cũ để có thể đọc định dạng tô-pô này. Hãy cố xây dựng lại tô-pô hoặc nâng cấp lên phiên bản GRASS tối thiểu là %d."
 #: ../lib/vector/diglib/plus_struct.c:529
-#, fuzzy, c-format
-msgid ""
-"Your GRASS version does not fully support topology format %d.%d of the "
-msgstr ""
-"nhật GRASS."
+#, c-format
+msgid "Your GRASS version does not fully support topology format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
+msgstr "Phiên bản GRASS của bạn không hỗ trợ hoàn toàn định dạng tô-pô %d.%d của vector. Xem xét xây dựng lại tô-pô hoặc nâng cấp GRASS."
 #: ../lib/vector/diglib/plus_struct.c:539
-#, fuzzy, c-format
-msgid ""
-"Old topology format version %d.%d is not supported by this release. Try to "
-"rebuild topology using v.build or v.build.all module."
-msgstr ""
+#, c-format
+msgid "Old topology format version %d.%d is not supported by this release. Try to rebuild topology using v.build or v.build.all module."
+msgstr "Định dạng tô-pô cũ %d.%d không được phiên bản này hỗ trợ. Hãy thử xây dựng lại tô-pô bằng v.build hoặc mô-đun v.build.all."
 #: ../lib/vector/diglib/file.c:159
 msgid "Writing to file loaded to memory not supported"
@@ -9417,94 +8652,84 @@
 #: ../lib/vector/diglib/file.c:197
 msgid "Unable to load file to memory, file not open"
-msgstr "Không thể nạp tập tin vào bộ nhớ, tập tin không được mở"
+msgstr "Không thể nạp tập tin vào bộ nhớ, tập tin không mở"
 #: ../lib/vector/diglib/file.c:212
 msgid "Vector memory mode not supported, using 'AUTO'"
-msgstr "Chế độ bộ nhớ cho véc-tơ không được hỗ trợ, dùng chế độ 'TỰ ĐỘNG'"
+msgstr "Chế độ bộ nhớ vector không được hỗ trợ, dùng 'TỰ ĐỘNG'"
 #: ../lib/vector/diglib/port_init.c:158
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to find '%x' in %s"
-msgstr "Không thể tìm thấy '%s' trong '%s'"
+msgstr "Không thể tìm thấy '%x' trong %s"
 #: ../lib/vector/diglib/spindex.c:450
 #, c-format
 msgid "Unable to delete node %d from spatial index"
-msgstr "Không thể xoá nốt %d khỏi chỉ mục không gian"
+msgstr "Không thể xóa nốt %d khỏi chỉ mục không gian"
 #: ../lib/vector/diglib/spindex.c:493
 #, c-format
 msgid "Unable to delete line %d from spatial index"
-msgstr "Không thể xoá đường %d khỏi chỉ mục không gian"
+msgstr "Không thể xóa đường %d khỏi chỉ mục không gian"
 #: ../lib/vector/diglib/spindex.c:529
 msgid "Attempt to delete sidx for dead area"
-msgstr "Cố gắng xoá sidx đối với vùng chết"
+msgstr "Nỗ lực xóa sidx khỏi vùng chết"
 #: ../lib/vector/diglib/spindex.c:546
 #, c-format
 msgid "Unable to delete area %d from spatial index"
-msgstr "Không thể xoá vùng chết %d khỏi chỉ mục không gian"
+msgstr "Không thể xóa vùng %d khỏi chỉ mục không gian"
 #: ../lib/vector/diglib/spindex.c:595
 #, c-format
 msgid "Unable to delete isle %d from spatial index"
-msgstr "Không thể xoá đảo %d khỏi chỉ mục không gian"
+msgstr "Không thể xóa đảo %d khỏi chỉ mục không gian"
 #: ../lib/vector/diglib/test.c:58
-#, fuzzy
 msgid "Unable to open test.tmp file"
+msgstr "Không thể mở tập tin test.tmp"
 #: ../lib/vector/diglib/test.c:75
 #, c-format
-msgid ""
-"Error in read/write portable double, byte_order = %d Written: %.16e3E Read: "
-"%.16e3E"
-msgstr ""
+msgid "Error in read/write portable double, byte_order = %d Written: %.16e3E Read: %.16e3E"
+msgstr "Lỗi trong đọc/ghi kép linh động, thứ_tự_byte = %d Ghi: %.16e3E Đọc: %.16e3E"
 #: ../lib/vector/diglib/test.c:89
 #, c-format
-msgid ""
-"Error in read/write portable float, byte_order = %d Written: %.8e3E Read: "
-"%.8e3E"
-msgstr ""
+msgid "Error in read/write portable float, byte_order = %d Written: %.8e3E Read: %.8e3E"
+msgstr "Lỗi trong đọc/ghi float linh động, thứ_tự_byte = %d Ghi: %.8e3E Đọc: %.8e3E"
 #: ../lib/vector/diglib/test.c:104
 #, c-format
-msgid ""
-"Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
-msgstr ""
+msgid "Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
+msgstr "Lỗi đọc/ghi off_t linh động, thứ_tự_byte = %d Ghi: %lu Đọc: %lu"
 #: ../lib/vector/diglib/test.c:119
 #, c-format
-msgid ""
-"Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
-msgstr ""
+msgid "Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
+msgstr "Lỗi đọc/ghi định dạng dài linh động, thứ_tự_byte = %d Ghi: %lu Đọc: %lu"
 #: ../lib/vector/diglib/test.c:134
 #, c-format
 msgid "Error in read/write portable int, byte_order = %d Written: %d Read: %d"
-msgstr ""
+msgstr "Lỗi đọc/ghi định dạng số nguyên linh động, thứ_tự_byte = %d Ghi: %d Đọc: %d"
 #: ../lib/vector/diglib/test.c:150
 #, c-format
-msgid ""
-"Error in read/write portable short, byte_order = %d Written: %d Read: %d"
-msgstr ""
+msgid "Error in read/write portable short, byte_order = %d Written: %d Read: %d"
+msgstr "Lỗi đọc/ghi định dạng ngắn  linh động, thứ_tự_byte = %d Ghi: %d Đọc: %d"
 #: ../lib/vector/diglib/test.c:165
 #, c-format
 msgid "Error in read/write portable char, byte_order = %d Written: %d Read: %d"
-msgstr ""
+msgstr "Lỗi đọc/ghi định dạng ký tự linh động, thứ_tự_byte = %d Ghi: %d Đọc: %d"
 #: ../lib/vector/diglib/plus_node.c:214
 #, c-format
-msgid ""
-"Attempt to read line angle for the line which is not connected to the node: "
-"node %d, line %d"
-msgstr "Cố gắng đọc góc của một đường không được nối vào nốt: nốt %d, đường %d"
+msgid "Attempt to read line angle for the line which is not connected to the node: node %d, line %d"
+msgstr "Nỗ lực đọc góc của đường đối với đường không nối vào nốt: nốt %d, đường %d"
 #: ../lib/segment/open.c:53
 msgid "Segment file name is NULL"
@@ -9515,28 +8740,24 @@
 msgstr ""
 #: ../lib/segment/open.c:66
-#, fuzzy
 msgid "Unable to create segment file"
-msgstr "Không thể đọc tập tin đề mục"
+msgstr ""
 #: ../lib/segment/open.c:74
-#, fuzzy
 msgid "Could not write segment file"
-msgstr "không thể ghi tập tin quant!"
+msgstr ""
 #: ../lib/segment/open.c:78
 msgid "Illegal segment configuration parameter(s)"
 msgstr ""
 #: ../lib/segment/open.c:87
-#, fuzzy
 msgid "Unable to re-open segment file"
+msgstr ""
 #: ../lib/segment/open.c:94
-#, fuzzy
 msgid "Could not read segment file"
-msgstr "Không thể khởi động tập tin %s"
+msgstr ""
 #: ../lib/segment/format.c:143
 msgid "Segment format: file size too large"
@@ -9548,112 +8769,101 @@
 #: ../lib/proj/convert.c:120
 msgid "Unable parse GRASS PROJ_INFO file"
-msgstr "Không thể phân tách tập tin GRASS PROJ_INFO"
+msgstr ""
 #: ../lib/proj/convert.c:125
 msgid "Unable get PROJ.4-style parameter string"
-msgstr "Không thể lấy chuỗi tham số kiểu PROJ.4"
+msgstr ""
 #: ../lib/proj/convert.c:139
 #, c-format
-msgid ""
-"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
 msgstr ""
-"OGR không thể phân tách chuỗi tham số kiểu PROJ.4: %s (Mã lỗi OGR là %d)"
 #: ../lib/proj/convert.c:152
 #, c-format
 msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
-msgstr "OGR không thể lấy chuỗi tham số kiểu WKT (mã lỗi OGR là %d)"
+msgstr ""
 #: ../lib/proj/convert.c:394
 msgid "No projection name! Projection parameters likely to be meaningless."
-msgstr "Không có tên phép chiếu! Các tham số phép chiếu có vẻ như vô nghĩa."
+msgstr ""
 #: ../lib/proj/convert.c:457
 #, c-format
 msgid "Datum <%s> not recognised by GRASS and no parameters found"
 msgstr ""
-"GRASS không nhận ra mốc tọa độ chuẩn <%s> và không tìm thấy tham số nào"
 #: ../lib/proj/convert.c:473
 #, c-format
-msgid ""
-"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
-"want to look into this."
+msgid "Datum <%s> apparently recognised by GRASS but no parameters found. You may want to look into this."
 msgstr ""
-"GRASS không nhận ra mốc tọa độ chuẩn <%s> và không tìm thấy tham số nào. Có "
-"thể bạn cần kiểm tra điều này."
 #: ../lib/proj/convert.c:477
 #, c-format
-msgid ""
-"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
-"transform parameters unspecified."
+msgid "Invalid transformation number %d; valid range is 1 to %d. Leaving datum transform parameters unspecified."
 msgstr ""
-"Số hiệu chuyển đổi không hợp lệ %d; miền hợp lệ là 1 đến %d. Để lại các tham "
-"số chuyển đổi mốc tọa độ chuẩn không được chỉ định."
 #: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
 #, c-format
 msgid "pj_transform() failed: %s"
-msgstr "pj_transform() thất bại: %s"
+msgstr ""
 #: ../lib/proj/ellipse.c:97
 #, c-format
 msgid "Invalid ellipsoid <%s> in file"
-msgstr "Ellipsoid <%s> không hợp lệ trong tập tin"
+msgstr ""
 #: ../lib/proj/ellipse.c:124
 msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
-msgstr "Không có mô tả ellipsoid thứ cấp (rf, es hoặc b) trong tập tin"
+msgstr ""
 #: ../lib/proj/ellipse.c:128
 msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
-msgstr "Các mô tả ellipsoid trong tập tin (a, rf, es hoặc b) không hợp lệ"
+msgstr ""
 #: ../lib/proj/ellipse.c:141
 msgid "No ellipsoid info given in file"
-msgstr "Không có thông tin ellipsoid trong tập tin được cung cấp"
+msgstr ""
 #: ../lib/proj/get_proj.c:148
 #, c-format
 msgid "Invalid zone %s specified"
-msgstr "Múi được chỉ định %s không hợp lệ"
+msgstr ""
 #: ../lib/proj/get_proj.c:228
 msgid "Unable to initialise PROJ.4 with the following parameter list:"
-msgstr "Không thể khởi tạo PROJ.4 với danh sách tham số sau:"
+msgstr ""
 #: ../lib/proj/get_proj.c:236
 #, c-format
 msgid "The error message: %s"
-msgstr "Thông báo lỗi: %s"
+msgstr ""
 #: ../lib/proj/get_proj.c:294
 msgid "Option input overflowed option table"
-msgstr "Tùy chọn đầu vào tràn bộ nhớ tùy chọn bảng"
+msgstr ""
 #: ../lib/proj/get_proj.c:325
 #, c-format
 msgid "Unable to initialize pj cause: %s"
+msgstr ""
 #: ../lib/proj/get_proj.c:401
 msgid "Input Projection Parameters"
-msgstr "Các Tham số Phép chiếu Đầu vào"
+msgstr ""
 #: ../lib/proj/get_proj.c:404
 msgid "Input Unit Factor"
-msgstr "Hệ số Đơn vị đầu vào"
+msgstr ""
 #: ../lib/proj/get_proj.c:414
 msgid "Output Projection Parameters"
-msgstr "Các Tham số Phép chiếu Đầu ra"
+msgstr ""
 #: ../lib/proj/get_proj.c:417
 msgid "Output Unit Factor"
-msgstr "Hệ số Đơn vị Đầu ra"
+msgstr ""
 #: ../lib/proj/datum.c:195
 msgid "Failed to detect nadgrids path, GRASS_PROJSHARE not defined"
@@ -9662,200 +8872,174 @@
 #: ../lib/proj/datum.c:278 ../lib/proj/datum.c:358
 #, c-format
 msgid "Unable to open datum table file <%s>"
-msgstr "Không thể mở tập tin bảng mốc tọa độ chuẩn <%s>"
+msgstr ""
 #: ../lib/proj/datum.c:291 ../lib/proj/datum.c:372
 #, c-format
 msgid "Error in datum table file <%s>, line %d"
-msgstr "Lỗi trong tập tin bảng mốc tọa độ chuẩn <%s>, dòng %d"
+msgstr ""
 #: ../lib/rst/interp_float/resout2d.c:77
 msgid "Temporarily changing the region to desired resolution..."
-msgstr ""
+msgstr "Tạm thời thay đổi vùng về độ phân giải mong muốn..."
 #: ../lib/rst/interp_float/resout2d.c:103
 #, c-format
 msgid "First change your rows number(%d) to %d"
-msgstr ""
+msgstr "Trước tiên hãy thay đổi số hàng của bạn từ (%d) thành %d"
 #: ../lib/rst/interp_float/resout2d.c:110
 #, c-format
 msgid "First change your columns number(%d) to %d"
-msgstr ""
+msgstr "Trước tiên hãy thay đổi số cột của bạn  từ (%d) thành %d"
 #: ../lib/rst/interp_float/resout2d.c:264
 msgid "No color table for input raster map -- will not create color table"
-msgstr ""
+msgstr "Không có bảng màu dùng cho bản đồ raster đầu vào - sẽ không tạo bảng màu"
 #: ../lib/rst/interp_float/resout2d.c:458
 msgid "Changing the region back to initial..."
-msgstr ""
+msgstr "Thay đổi vùng trở về ban đầu..."
 #: ../lib/rst/interp_float/vinput2d.c:94
-#, fuzzy, c-format
+#, c-format
 msgid "Vector map <%s> is not 3D"
-msgstr "Không tìm thấy bản đồ vec-tơ <%s>"
+msgstr "Bản đồ vector <%s> không phải 3D"
 #: ../lib/rst/interp_float/vinput2d.c:97
 msgid "Loading data from attribute table ..."
-msgstr "Đang nạp dữ liệu từ bảng thuộc tính..."
+msgstr "Đang nạp dữ liệu từ bảng thuộc tính ..."
 #: ../lib/rst/interp_float/vinput2d.c:118
 #: ../lib/rst/interp_float/vinput2d.c:131
-#, fuzzy, c-format
+#, c-format
 msgid "Data type of column <%s> must be numeric"
+msgstr "Kiểu dữ liệu của cột <%s> phải là kiểu số"
 #: ../lib/rst/interp_float/vinput2d.c:142
-#, fuzzy
 msgid "Reading features from vector map ..."
-msgstr "Đang đọc các đường từ bản đồ vec-tơ..."
+msgstr "Đang đọc các đối tượng từ bản đồ vector ..."
 #: ../lib/rst/interp_float/vinput2d.c:174
 #, c-format
 msgid "Database record for cat %d not found"
-msgstr "Không tìm thấy bản ghi CSDL cho phạm trù %d"
+msgstr "Không tìm thấy bản ghi csdl dùng cho phạm trù %d"
 #: ../lib/rst/interp_float/vinput2d.c:192
 msgid "Negative value of smoothing detected: sm must be >= 0"
-msgstr ""
+msgstr "Phát hiện giá trị làm trơn là số âm: sm phải >= 0"
 #: ../lib/rst/interp_float/vinput2d.c:256
-#, fuzzy
 msgid "Strip exists with insufficient data"
-msgstr "việc cắt bỏ xảy ra với dữ liệu không đầy đủ"
+msgstr "Dải xuất hiện với dữ liệu không đủ"
 #: ../lib/rst/interp_float/vinput2d.c:270
-#, fuzzy, c-format
+#, c-format
 msgid "There are points outside specified 2D/3D region - %d points ignored"
-msgstr "có các điểm nằm ngoài vùng 2D/3D đã chỉ định--bỏ qua %d điểm"
+msgstr "Có các điểm nằm ngoài vùng 2D/3D được chỉ định - %d điểm bị bỏ qua"
 #: ../lib/rst/interp_float/vinput2d.c:273
-#, fuzzy, c-format
+#, c-format
 msgid "Ignoring %d points (too dense)"
-msgstr "bỏ qua %d điểm--quá dày"
+msgstr "Bỏ qua %d điểm (quá dày)"
 #: ../lib/rst/interp_float/vinput2d.c:277
 #, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given NPMIN="
-"%d"
-msgstr ""
-"%d điểm được cung cấp để nội suy (sau khi làm mảnh) ít hơn NPMIN=%d được "
-"cung cấp"
+msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
+msgstr "%d điểm được cung cấp để nội suy (sau khi làm mảnh) ít hơn NPMIN= %d đã cung cấp"
 #: ../lib/rst/interp_float/vinput2d.c:282
 msgid "Zero points in the given region"
-msgstr ""
+msgstr "Không có điểm nào trong vùng đã cung cấp"
 #: ../lib/rst/interp_float/vinput2d.c:287
 #, c-format
-msgid ""
-"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
-"smooth connection of segments, npmin > segmax (see manual)"
-msgstr ""
+msgid "Segmentation parameters set to invalid values: npmin= %d, segmax= %d for smooth connection of segments, npmin > segmax (see manual)"
+msgstr "Các tham số phân đoạn được thiết lập giá trị không hợp lệ: npmin= %d, segmax= %d dùng cho kết nối làm trơn của các đoạn, npmin > segmax (xem hướng dẫn)"
 #: ../lib/rst/interp_float/vinput2d.c:293
 #, c-format
-msgid ""
-"There are less than %d points for interpolation. No segmentation is "
-"necessary, to run the program faster set segmax=%d (see manual)"
-msgstr ""
-"Có ít hơn %d điểm dùng cho nội suy. Sự phân đoạn không cần thiết, để chạy "
-"chương trình nhanh hơn, thiết lập segmax=%d (xem hướng dẫn sử dụng)"
+msgid "There are less than %d points for interpolation. No segmentation is necessary, to run the program faster set segmax=%d (see manual)"
+msgstr "Có ít hơn %d điểm dùng để nội suy. Không cần phân đoạn, để chạy chương trình nhanh hơn, thiết lập segmax= %d (xem hướng dẫn)"
 #: ../lib/rst/interp_float/vinput2d.c:297
-#, fuzzy, c-format
+#, c-format
 msgid "Number of points from vector map %d"
-msgstr "Tên của bản đồ vec-tơ đầu vào"
+msgstr "Số điểm từ bản đồ vector %d"
 #: ../lib/rst/interp_float/vinput2d.c:298
-#, fuzzy, c-format
+#, c-format
 msgid "Number of points outside of 2D/3D region %d"
+msgstr "Số điểm nằm ngoài vùng 2D/3D %d"
 #: ../lib/rst/interp_float/vinput2d.c:300
-#, fuzzy, c-format
+#, c-format
 msgid "Number of points being used %d"
+msgstr "Số điểm đang được dùng %d"
 #: ../lib/rst/interp_float/vinput2d.c:333
-#, fuzzy
 msgid "Some points outside of region (ignored)"
-msgstr "một số điểm nằm ngoài vùng -- sẽ bỏ qua ..."
+msgstr "Một số điểm nằm ngoài vùng (bỏ qua)"
 #: ../lib/rst/interp_float/vinput2d.c:339
-#, fuzzy
 msgid "Unable to allocate memory"
-msgstr "Không thể cấp phát bộ nhớ\n"
+msgstr "Không thể cấp phát bộ nhớ"
 #: ../lib/rst/interp_float/vinput2d.c:347
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to insert %f,%f,%f a = %d"
-msgstr "Không thể ghi lại đối tượng %d"
+msgstr "Không thể chèn %f,%f,%f a = %d"
 #: ../lib/rst/interp_float/segmen2d.c:135
-#, fuzzy
-msgid ""
-"Taking too long to find points for interpolation - please change the region "
-"to area where your points are. Continuing calculations..."
-msgstr ""
-"mất quá lâu để tìm các điểm dùng cho nội suy--vui lòng thay đổi vùng đến khu "
-"vực có các điểm của bạn. Tiếp tục tính toán..."
+msgid "Taking too long to find points for interpolation - please change the region to area where your points are. Continuing calculations..."
+msgstr "Mất quá lâu để tìm các điểm dùng cho nội suy - vui lòng thay đổi vùng về khu vực chứa các điểm của bạn. Đang tiếp tục tính toán..."
 #: ../lib/rst/interp_float/write2d.c:53 ../lib/rst/interp_float/write2d.c:64
 #: ../lib/rst/interp_float/write2d.c:79 ../lib/rst/interp_float/write2d.c:88
 #: ../lib/rst/interp_float/write2d.c:96 ../lib/rst/interp_float/write2d.c:104
-#, fuzzy
 msgid "Cannot write files"
-msgstr "Không thể ghi lại đường"
+msgstr "Không thể ghi các tập tin"
 #: ../lib/rst/interp_float/input2d.c:58
 #, c-format
 msgid "Mask raster map <%s> not found"
-msgstr "Không tìm thấy bản đồ raster mặt nạ <%s>"
+msgstr "Không thấy bản đồ raster làm mặt nạ <%s>"
 #: ../lib/rst/interp_float/input2d.c:81
 msgid "Bitmap mask created"
-msgstr "Mặt nạ bitmap được tạo ra"
+msgstr "Mặt nạ bitmap được tạo"
 #: ../lib/rst/interp_float/output2d.c:117
 #, c-format
 msgid "First change your rows number to nsizr! %d %d"
-msgstr ""
+msgstr "Trước tiên hãy thay đổi số hàng của bạn thành nsizr! %d %d"
 #: ../lib/rst/interp_float/output2d.c:124
 #, c-format
 msgid "First change your cols number to nsizc %d %d"
-msgstr ""
+msgstr "Trước tiên hãy thay đổi số cột của bạn thành nsizc %d %d"
 #: ../lib/rst/interp_float/interp2d.c:232
 #, c-format
-msgid ""
-"Overshoot - increase in tension suggested. Overshoot occurs at (%d,%d) cell. "
-"Z-value %f, zmin %f, zmax %f."
-msgstr ""
+msgid "Overshoot - increase in tension suggested. Overshoot occurs at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
+msgstr "Đường thừa - đề xuất tăng sức căng. Đường thừa xảy ra tại ô (%d, %d). Giá trị Z %f, zmin %f, zmax %f."
 #: ../lib/pngdriver/read_png.c:42
-#, fuzzy
 msgid "Unable to read PNG"
-msgstr "Không thể mở <%s>"
+msgstr ""
 #: ../lib/pngdriver/read_png.c:60
-#, fuzzy
 msgid "Unable allocate PNG structure"
+msgstr ""
 #: ../lib/pngdriver/read_png.c:64 ../lib/pngdriver/write_png.c:71
 #: ../lib/pngdriver/write_png.c:75
-#, fuzzy
 msgid "Unable to allocate PNG structure"
+msgstr ""
 #: ../lib/pngdriver/read_png.c:67
-#, fuzzy
 msgid "Unable to read PNG file"
+msgstr ""
 #: ../lib/pngdriver/read_png.c:81
 msgid "Input PNG file is not 8-bit"
@@ -9879,19 +9063,17 @@
 msgstr ""
 #: ../lib/pngdriver/write_png.c:39
-#, fuzzy
 msgid "Unable to write PNG"
-msgstr "Không thể đọc đường %d"
+msgstr ""
 #: ../lib/pngdriver/write_png.c:78
-#, fuzzy
 msgid "Unable to write PNG file"
+msgstr ""
 #: ../lib/pngdriver/write_png.c:82
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open output PNG file <%s>"
-msgstr "Không thể mở tập tin bảng mốc tọa độ chuẩn: %s"
+msgstr ""
 #: ../lib/pngdriver/graph_set.c:101
 #, c-format
@@ -9908,108 +9090,89 @@
 msgid "png: image size %dx%d"
 msgstr ""
-#~ msgid "syntax error"
-#~ msgstr "lỗi cú pháp"
-#~ msgid "R/G/B not in range 0-255"
-#~ msgstr "R/G/B không ở trong miền 0-255"
-#~ msgid "invalid color name"
-#~ msgstr "Tên màu không hợp lệ"
 #, fuzzy
-#~ msgid "Unable to restore feature/offset %lu in vector map <%s>"
-#~ msgstr "Không thể phục hồi lại đối tượng %d từ bản đồ vec-tơ <%s>"
+msgid "Unable to restore feature/offset %lu in vector map <%s>"
+msgstr "Không thể phục hồi lại đối tượng %d từ bản đồ vec-tơ <%s>"
 #, fuzzy
-#~ msgid "Out of memmory"
-#~ msgstr "Hết bộ nhớ "
+msgid "Out of memmory"
+msgstr "Hết bộ nhớ "
 #, fuzzy
-#~ msgid ""
-#~ "Unable to check table. There is no temporal database connection defined "
-#~ "for mapset <%(mapset)s>"
-#~ msgstr "Không thể mở tập tin định nghĩa csdl vec-tơ: '%s'"
+msgid "Unable to check table. There is no temporal database connection defined for mapset <%(mapset)s>"
+msgstr "Không thể mở tập tin định nghĩa csdl vec-tơ: '%s'"
 #, fuzzy
-#~ msgid ""
-#~ "Unable to fetch one. There is no temporal database connection defined for "
-#~ "mapset <%(mapset)s>"
-#~ msgstr "Không thể mở tập tin header của bản đồ vec-tơ <%s>"
+msgid "Unable to fetch one. There is no temporal database connection defined for mapset <%(mapset)s>"
+msgstr "Không thể mở tập tin header của bản đồ vec-tơ <%s>"
 #, fuzzy
-#~ msgid ""
-#~ "Unable to fetch all. There is no temporal database connection defined for "
+msgid "Unable to fetch all. There is no temporal database connection defined for mapset <%(mapset)s>"
 #, fuzzy
-#~ msgid "Unable to find a temporary null file <%s>"
-#~ msgstr "không thể tìm thấy một tập tin null tạm %s"
+msgid "Unable to find a temporary null file <%s>"
+msgstr "không thể tìm thấy một tập tin null tạm %s"
 #, fuzzy
-#~ msgid "Unable to open null file <%s>"
-#~ msgstr "G_spawn: không thể mở tập tin %s"
+msgid "Unable to open null file <%s>"
+msgstr "G_spawn: không thể mở tập tin %s"
 #, fuzzy
-#~ msgid "ERROR: <%s> is not a valid GRASS location"
-#~ msgstr "Xin lỗi <%s> không phải là tùy chọn hợp lệ\n"
+msgid "ERROR: <%s> is not a valid GRASS location"
+msgstr "Xin lỗi <%s> không phải là tùy chọn hợp lệ\n"
-#~ msgid "ERROR: option <%s>: <%s> exists.\n"
-#~ msgstr "LỖI: tùy chọn <%s>: <%s> đã có.\n"
+msgid "ERROR: option <%s>: <%s> exists.\n"
+msgstr "LỖI: tùy chọn <%s>: <%s> đã có.\n"
 #, fuzzy
-#~ msgid "Invalid offset (%d)"
-#~ msgstr "không thể đổi thư mục đến %s"
+msgid "Invalid offset (%d)"
+msgstr "không thể đổi thư mục đến %s"
 #, fuzzy
-#~ msgid "Unable to open file '%s'"
-#~ msgstr "Không thể mở tập tin %s"
+msgid "Unable to open file '%s'"
+msgstr "Không thể mở tập tin %s"
 #, fuzzy
-#~ msgid "Hit RETURN to continue"
-#~ msgstr "bấm RETURN để tiếp tục -->"
+msgid "Hit RETURN to continue"
+msgstr "bấm RETURN để tiếp tục -->"
 #, fuzzy
-#~ msgid "Vector map <%s> is not opened on topology level"
-#~ msgstr "Bản đồ vec-tơ <%s> không mở được ở cấp >=2"
+msgid "Vector map <%s> is not opened on topology level"
+msgstr "Bản đồ vec-tơ <%s> không mở được ở cấp >=2"
-#~ msgid "Background color"
-#~ msgstr "Màu nền"
+msgid "Background color"
+msgstr "Màu nền"
 #, fuzzy
-#~ msgid "Removing empty 3D raster maps"
-#~ msgstr "Tên của bản đồ raster đầu vào"
+msgid "Removing empty 3D raster maps"
+msgstr "Tên của bản đồ raster đầu vào"
 #, fuzzy
-#~ msgid "Mode type: {0} not supported."
-#~ msgstr "Kiểu đối tượng OGR %d không được hỗ trợ"
+msgid "Mode type: {0} not supported."
+msgstr "Kiểu đối tượng OGR %d không được hỗ trợ"
 #, fuzzy
-#~ msgid "Invalid type {0}"
+msgid "Invalid type {0}"
-#~ msgid "Attributes for category %d not found"
-#~ msgstr "Không tìm thấy các thuộc tính cho phạm trù %d"
+msgid "Attributes for category %d not found"
+msgstr "Không tìm thấy các thuộc tính cho phạm trù %d"
-#~ msgid "Category must be integer"
-#~ msgstr "Phạm trù phải là số nguyên"
+msgid "Category must be integer"
+msgstr "Phạm trù phải là số nguyên"
-#~ msgid "Memory error in writing timestamp"
-#~ msgstr "Lõi bộ nhớ khi ghi đánh dấu thời gian"
+msgid "Memory error in writing timestamp"
+msgstr "Lõi bộ nhớ khi ghi đánh dấu thời gian"
-#~ msgid "Illegal TimeStamp string"
-#~ msgstr "Chuỗi đánh dấu thời gian không hợp lệ"
+msgid "Illegal TimeStamp string"
+msgstr "Chuỗi đánh dấu thời gian không hợp lệ"
-#~ msgid ""
-#~ "Dev note: Adapted sites library used for vector points. (module should be "
-#~ "updated to GRASS 6 vector library)"
-#~ msgstr ""
-#~ "Ghi chú cho nhà phát triển: Thư viện sites thích nghi được dùng cho các "
-#~ "điểm vec-tơ. (mô-đun phải được cập nhật vào thư viện vec-tơ của GRASS 6)"
+msgid "Dev note: Adapted sites library used for vector points. (module should be updated to GRASS 6 vector library)"
+msgstr "Ghi chú cho nhà phát triển: Thư viện sites thích nghi được dùng cho các điểm vec-tơ. (mô-đun phải được cập nhật vào thư viện vec-tơ của GRASS 6)"
-#~ msgid "Cannot fetch row"
-#~ msgstr "Không thể lấy hàng"
+msgid "Cannot fetch row"
+msgstr "Không thể lấy hàng"
-#~ msgid "G_oldsite_new_struct: invalid # dims or fields"
-#~ msgstr "G_oldsite_new_struct: # kích thước hoặc trường không hợp lệ"
+msgid "G_oldsite_new_struct: invalid # dims or fields"
+msgstr "G_oldsite_new_struct: # kích thước hoặc trường không hợp lệ"
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grassmods_cs.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -1707,9 +1707,9 @@
 #: ../raster3d/r3.in.lidar/main.c:378 ../raster/r.in.lidar/main.c:401
 #: ../vector/v.in.lidar/main.c:352
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open file <%s> as a LiDAR point cloud"
-msgstr "Nelze otevřít soubor <%s> pro psaní"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:382 ../raster/r.in.lidar/main.c:405
 #: ../vector/v.in.lidar/main.c:356
@@ -36256,13 +36256,13 @@
 #: ../vector/v.lidar.edgedetection/main.c:94 ../vector/v.outlier/main.c:103
 #: ../vector/v.lidar.correction/main.c:101
 msgid "Length of each spline step in the east-west direction"
-msgstr "Hodnota kroku spline ve v-z směru"
+msgstr ""
 #: ../vector/v.surf.bspline/main.c:158
 #: ../vector/v.lidar.edgedetection/main.c:103 ../vector/v.outlier/main.c:112
 #: ../vector/v.lidar.correction/main.c:110
 msgid "Length of each spline step in the north-south direction"
-msgstr "Hodnota kroku spline ve s-j severním směru"
+msgstr ""
 #: ../vector/v.surf.bspline/main.c:207
 msgid "Choose either vector or raster output, not both"
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grassmods_de.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -1701,9 +1701,9 @@
-#, fuzzy, c-format
+#, c-format
-msgstr "Kann Datei <%s> nicht zum Schreiben öffnen."
+msgstr ""
@@ -36178,13 +36178,13 @@
-msgstr "Spline-Interpolations-Schrittweite in Ost-West-Richtung."
+msgstr ""
-msgstr "Spline-Interpolations-Schrittweite in Nord-Süd-Richtung"
+msgstr ""
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grassmods_el.po	2017-08-31 20:55:23 UTC (rev 71461)
-#, fuzzy, c-format
+#, c-format
-msgstr "Αδυναμία ανοίγματος αρχείου <%s> για εγγραφή"
+msgstr ""
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grassmods_es.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -250,11 +250,11 @@
 #: ../raster3d/r3.timestamp/main.c:48
 msgid "Modifies a timestamp for a 3D raster map."
-msgstr ""
+msgstr "Modifica una marca de tiempo para un mapa ráster 3D."
 #: ../raster3d/r3.timestamp/main.c:49
 msgid "Print/add/remove a timestamp for a 3D raster map."
-msgstr ""
+msgstr "Imprimir/añadir/eliminar marca de tiempo para un mapa ráster 3D."
 #: ../raster3d/r3.timestamp/main.c:58
 msgid "Datetime, datetime1/datetime2, or none"
@@ -383,7 +383,7 @@
 #: ../raster3d/r3.to.rast/main.c:100
 msgid "3D raster map(s) to be converted to 2D raster slices"
-msgstr ""
+msgstr "Mapa(s) ráster 3D que serán convertidos a rebanadas ráster 2D"
 #: ../raster3d/r3.to.rast/main.c:106
 msgid "Basename for resultant raster slice maps"
@@ -1094,7 +1094,7 @@
 #: ../raster3d/r3.in.ascii/main.c:86 ../raster/r.in.ascii/main.c:78
 #: ../vector/v.in.ascii/main.c:78
 msgid "Name of input file to be imported"
-msgstr ""
+msgstr "Nombre de los archivos de entrada que serán importados"
 #: ../raster3d/r3.in.ascii/main.c:87 ../db/db.execute/main.c:139
 #: ../db/db.select/main.c:208 ../raster/r.reclass/main.c:66
@@ -1246,7 +1246,7 @@
 #: ../raster3d/r3.support/check.c:20
 #, c-format
 msgid "Updating statistics for <%s>"
-msgstr "Actualizando estaísticas para <%s>"
+msgstr "Actualizando estadísticas para <%s>"
 #: ../raster3d/r3.support/check.c:36
 #, c-format
@@ -1297,7 +1297,7 @@
 #: ../raster/r.in.lidar/string_list.c:34
 #, c-format
 msgid "Cannot open file %s for reading"
-msgstr ""
+msgstr "No se puede abrir el archivo %s para lectura"
 #: ../raster3d/r3.in.lidar/filters.c:27
 #, fuzzy, c-format
@@ -1351,7 +1351,7 @@
 #: ../raster3d/r3.in.lidar/main.c:176
 msgid "LiDAR input file in LAS format (*.las or *.laz)"
-msgstr ""
+msgstr "Archivo de entrada LiDAR en formato LAS (*.las o *.laz)"
 #: ../raster3d/r3.in.lidar/main.c:177 ../raster3d/r3.in.lidar/main.c:184
 #: ../raster3d/r3.flow/main.c:188 ../raster3d/r3.flow/main.c:195
@@ -1421,7 +1421,7 @@
 #: ../raster3d/r3.in.lidar/main.c:189
 msgid "Count of points per cell"
-msgstr ""
+msgstr "Cantidad de puntos por celda"
 #: ../raster3d/r3.in.lidar/main.c:190 ../raster3d/r3.in.lidar/main.c:196
 #: ../raster3d/r3.in.lidar/main.c:202 ../raster3d/r3.flow/main.c:211
@@ -1484,15 +1484,15 @@
 #: ../raster3d/r3.in.lidar/main.c:195
 msgid "Sum of values of point intensities per cell"
-msgstr ""
+msgstr "Suma de valores de intensidades de puntos por celda"
 #: ../raster3d/r3.in.lidar/main.c:201
 msgid "Mean of point intensities per cell"
-msgstr ""
+msgstr "Media de intensidad de puntos por celda"
 #: ../raster3d/r3.in.lidar/main.c:209
 msgid "3D raster map of proportional point count"
-msgstr ""
+msgstr "Mapa ráster 3D de cantidad proporcional de puntos"
 #: ../raster3d/r3.in.lidar/main.c:211
 msgid "Point count per 3D cell divided by point count per vertical column"
@@ -1500,11 +1500,11 @@
 #: ../raster3d/r3.in.lidar/main.c:213 ../raster3d/r3.in.lidar/main.c:223
 msgid "Proportional output"
-msgstr ""
+msgstr "Salida proporcional"
 #: ../raster3d/r3.in.lidar/main.c:219
 msgid "3D raster map of proportional sum of values"
-msgstr ""
+msgstr "Mapa ráster 3D de suma proporcional de valores"
 #: ../raster3d/r3.in.lidar/main.c:221
 msgid "Sum of values per 3D cell divided by sum of values per vertical column"
@@ -1611,21 +1611,21 @@
 #: ../raster3d/r3.in.lidar/main.c:248
 msgid "Subtract raster values from the z coordinates"
-msgstr ""
+msgstr "Sustraer valores ráster de las coordenadas z"
 #: ../raster3d/r3.in.lidar/main.c:250
 msgid "The scale for z is applied beforehand, the filter afterwards"
-msgstr ""
+msgstr "El valor de z es aplicado desde antes, el filtro actua después"
 #: ../raster3d/r3.in.lidar/main.c:251 ../raster3d/r3.in.lidar/main.c:264
 #: ../raster3d/r3.in.lidar/main.c:280 ../raster/r.in.lidar/main.c:184
 #: ../raster/r.in.lidar/main.c:200 ../raster/r.in.lidar/main.c:216
 msgid "Transform"
-msgstr ""
+msgstr "Transformar"
 #: ../raster3d/r3.in.lidar/main.c:256
 msgid "Use base raster actual resolution instead of computational region"
-msgstr ""
+msgstr "Usar resolución de ráster base actual en vez de la resolución de la región computacional"
 #: ../raster3d/r3.in.lidar/main.c:263 ../raster/r.in.lidar/main.c:199
 msgid "Scale to apply to Z data"
@@ -1642,7 +1642,7 @@
 #: ../raster3d/r3.in.lidar/main.c:284 ../raster/r.in.lidar/main.c:335
 #: ../vector/v.in.lidar/main.c:291
 msgid "Use only valid points"
-msgstr ""
+msgstr "Usar solamente puntos válidos"
 #: ../raster3d/r3.in.lidar/main.c:286 ../raster/r.in.lidar/main.c:337
 #: ../vector/v.in.lidar/main.c:293
@@ -1697,7 +1697,7 @@
 #: ../raster3d/r3.in.lidar/main.c:340 ../raster/r.in.lidar/main.c:367
 #, c-format
 msgid "File <%s> does not exist"
-msgstr ""
+msgstr "Archivo <%s> no existe"
 #: ../raster3d/r3.in.lidar/main.c:374 ../raster/r.in.lidar/main.c:397
 #: ../vector/v.in.lidar/main.c:347
-#, fuzzy, c-format
+#, c-format
-msgstr "Archivo de entrada <%s> no es nube de puntos LAS LiDAR"
+msgstr ""
@@ -1904,7 +1904,7 @@
 #: ../raster3d/r3.gradient/main.c:44
 msgid "gradient"
-msgstr ""
+msgstr "gradiente"
 #: ../raster3d/r3.gradient/main.c:47
 msgid "Computes gradient of a 3D raster map and outputs gradient components as three 3D raster maps."
@@ -1912,11 +1912,11 @@
 #: ../raster3d/r3.gradient/main.c:56
 msgid "Name for output 3D raster map(s)"
-msgstr ""
+msgstr "Nombre para mapa(s) ráster 3D de salida"
 #: ../raster3d/r3.gradient/main.c:63
 msgid "Size of blocks"
-msgstr ""
+msgstr "Tamaño de los bloques"
 #: ../raster3d/r3.gradient/main.c:130
 msgid "Failed to allocate memory for blocks"
@@ -2074,7 +2074,7 @@
 #: ../raster3d/r3.flow/test_main.c:45
 msgid "Testing flow lines."
-msgstr ""
+msgstr "Probando lineas de flujo"
 #: ../raster3d/r3.flow/main.c:46 ../ps/ps.map/catval.c:53
 #: ../ps/ps.map/catval.c:115 ../ps/ps.map/catval.c:181
@@ -2159,12 +2159,12 @@
 #: ../raster3d/r3.flow/main.c:91
 msgid "Please provide three 3D raster maps"
-msgstr ""
+msgstr "Por favor provea tres mapas ráster 3D"
 #: ../raster3d/r3.flow/main.c:98
 #, c-format
 msgid "Vector seed map <%s> not found"
-msgstr ""
+msgstr "Mapa vectorial semilla <%s> no encontrado"
 #: ../raster3d/r3.flow/main.c:147
 msgid "init_flowaccum: error in Rast3d_put_float"
@@ -2180,7 +2180,7 @@
 #: ../raster3d/r3.flow/main.c:200
 msgid "If no map is provided, flow lines are generated from each cell of the input 3D raster"
-msgstr ""
+msgstr "Si no se provee ningún mapa, las líneas de flujo son generadas a partir de cada celda del mapa ráster 3D de entrada"
 #: ../raster3d/r3.flow/main.c:203
 msgid "Name of vector map with points from which flow lines are generated"
@@ -2188,7 +2188,7 @@
 #: ../raster3d/r3.flow/main.c:210
 msgid "Name for vector map of flow lines"
-msgstr ""
+msgstr "Nombre para el mapa vectorial de lineas de flujo"
 #: ../raster3d/r3.flow/main.c:217
 msgid "Name for output flowaccumulation 3D raster"
@@ -2220,7 +2220,7 @@
 #: ../raster3d/r3.flow/main.c:244
 msgid "Default unit is cell"
-msgstr ""
+msgstr "La unidad predeterminada es una celda"
 #: ../raster3d/r3.flow/main.c:245 ../raster3d/r3.flow/main.c:254
 #: ../raster3d/r3.flow/main.c:262 ../raster3d/r3.flow/main.c:272
@@ -2241,7 +2241,7 @@
 #: ../raster3d/r3.flow/main.c:269
 msgid "Maximum error of integration"
-msgstr ""
+msgstr "Error mínimo de integración"
 #: ../raster3d/r3.flow/main.c:270
 msgid "Influences step, increase maximum error to allow bigger steps"
@@ -2249,7 +2249,7 @@
 #: ../raster3d/r3.flow/main.c:280
 msgid "Number of cells between flow lines in x, y and z direction"
-msgstr ""
+msgstr "Cantidad de celdas entre lineas de flujo en dirección x, y, z"
 #: ../raster3d/r3.flow/main.c:289
 msgid "Compute flowlines upstream, downstream or in both direction."
@@ -2257,7 +2257,7 @@
 #: ../raster3d/r3.flow/main.c:294
 msgid "Create and fill attribute table"
-msgstr ""
+msgstr "Crear y llenar tabla de atributos"
 #: ../raster3d/r3.flow/main.c:349
 msgid "Please provide 3 integer values for skip option."
@@ -2393,7 +2393,7 @@
 #: ../raster3d/r3.flow/main.c:441
 msgid "Error during reading seed vector map"
-msgstr ""
+msgstr "Error al leer mapa vectorial semilla"
 #: ../raster3d/r3.out.vtk/parameters.c:30
 msgid "3D raster map(s) to be converted to VTK-ASCII data format"
@@ -2413,11 +2413,11 @@
 #: ../raster3d/r3.out.vtk/parameters.c:56
 msgid "Top surface 2D raster map"
-msgstr ""
+msgstr "Mapa ráster 2D de la superficie superior"
 #: ../raster3d/r3.out.vtk/parameters.c:65
 msgid "Bottom surface 2D raster map"
-msgstr ""
+msgstr "Mapa ráster 2D de la superficie inferior"
 #: ../raster3d/r3.out.vtk/parameters.c:71
 msgid "Create 3D elevation output with a top and a bottom surface, both raster maps are required."
@@ -2581,7 +2581,7 @@
 #: ../raster3d/r3.neighbors/main.c:214 ../raster/r.neighbors/main.c:172
 msgid "focal statistics"
-msgstr ""
+msgstr "estadísticas focales"
 #: ../raster3d/r3.neighbors/main.c:215 ../raster/r.mfilter/main.c:59
 #: ../raster/r.resamp.filter/main.c:392 ../raster/r.neighbors/main.c:173
@@ -2939,7 +2939,7 @@
 #: ../imagery/i.evapo.mh/main.c:96
 msgid "Name of precipitation raster map [mm/month]"
-msgstr ""
+msgstr "Nombre del mapa ráster de precipitación [mm/mes]"
 #: ../imagery/i.evapo.mh/main.c:97
 msgid "Disabled for original Hargreaves (1985)"
@@ -3033,7 +3033,7 @@
 #: ../imagery/i.fft/main.c:80 ../imagery/i.ifft/main.c:79
 msgid "Fast Fourier Transform"
-msgstr ""
+msgstr "Tranformadas Rápidas de Fourier"
 #: ../imagery/i.fft/main.c:82
 msgid "Fast Fourier Transform (FFT) for image processing."
@@ -3083,7 +3083,7 @@
 #: ../imagery/i.aster.toar/main.c:98 ../imagery/i.landsat.toar/main.c:71
 msgid "radiometric conversion"
-msgstr ""
+msgstr "conversión radiométrica"
 #: ../imagery/i.aster.toar/main.c:99 ../imagery/i.landsat.toar/main.c:72
 #: ../imagery/i.landsat.toar/main.c:578
@@ -3421,7 +3421,7 @@
 #: ../imagery/i.landsat.toar/main.c:257 ../imagery/i.landsat.toar/main.c:265
 #, c-format
 msgid "Illegal date format: [%s] (yyyy-mm-dd)"
-msgstr ""
+msgstr "Formato ilegal de fecha: [%s] (yyyy-mm-dd)"
 #: ../imagery/i.landsat.toar/main.c:287
 msgid "Please use a metadata keyword with -p"
@@ -3457,7 +3457,7 @@
 #: ../imagery/i.landsat.toar/main.c:411 ../imagery/i.landsat.toar/main.c:560
 #, c-format
 msgid "Unable to read data type of raster map <%s>"
-msgstr ""
+msgstr "No se puede leer el tipo de datos del mapa ráster <%s>"
 #: ../imagery/i.landsat.toar/main.c:535 ../raster/r.topidx/topidx.c:41
 #: ../raster/r.flow/main.c:314
@@ -3474,7 +3474,7 @@
 #: ../imagery/i.landsat.toar/main.c:553
 #, c-format
 msgid "Raster map <%s> exists. Skipping."
-msgstr ""
+msgstr "El mapa ráster <%s> ya existe. Omitiendo."
 #: ../imagery/i.landsat.toar/main.c:564 ../imagery/i.landsat.acca/main.c:188
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:114
@@ -3498,7 +3498,7 @@
 #: ../imagery/i.landsat.toar/main.c:576
 #, c-format
 msgid "Writing %s of <%s> to <%s>..."
-msgstr ""
+msgstr "Escribiendo %s de <%s> en <%s>..."
 #: ../imagery/i.landsat.toar/main.c:580
 msgid "temperature"
@@ -3511,7 +3511,7 @@
 #: ../imagery/i.landsat.toar/landsat_met.c:117
 #, c-format
 msgid "Metadata file <%s> not found"
-msgstr ""
+msgstr "Archivo de Metadatos <%s> no encontrado"
 #: ../imagery/i.rectify/rectify.c:41
 #: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:42
@@ -3875,7 +3875,7 @@
 #: ../imagery/i.group/main.c:55
 msgid "Creates, edits, and lists groups of imagery data."
-msgstr ""
+msgstr "Crea, edita y lista grupos de archivos de imágenes."
 #: ../imagery/i.group/main.c:59
 msgid "Name of imagery group"
@@ -3895,11 +3895,11 @@
 #: ../imagery/i.group/main.c:73
 msgid "Remove selected files from specified group or subgroup"
-msgstr ""
+msgstr "Eliminar archivos seleccionados del grupo o subgrupo especificado"
 #: ../imagery/i.group/main.c:78
 msgid "List files from specified (sub)group"
-msgstr ""
+msgstr "Listar archivos del (sub)grupo especificado"
 #: ../imagery/i.group/main.c:79 ../imagery/i.group/main.c:84
 #: ../imagery/i.group/main.c:89 ../db/db.connect/main.c:53
@@ -3953,7 +3953,7 @@
 #: ../imagery/i.group/main.c:83
 msgid "List subgroups from specified group"
-msgstr ""
+msgstr "Listar subgrupos del grupo especificado"
 #: ../imagery/i.group/main.c:88 ../raster/r.regression.multi/main.c:161
 #: ../raster/r.regression.line/main.c:69
@@ -4012,7 +4012,7 @@
 #: ../imagery/i.group/main.c:219
 msgid "No input raster maps defined"
-msgstr ""
+msgstr "Mapas ráster de entrada no definidos"
 #: ../imagery/i.group/main.c:223 ../imagery/i.group/main.c:265
 #, c-format
@@ -4056,7 +4056,7 @@
 #: ../imagery/i.group/main.c:422
 #, c-format
 msgid "Group <%s> does not contain any subgroup.\n"
-msgstr ""
+msgstr "El grupo <%s> no contiene ningún subgrupo.\n"
 #: ../imagery/i.group/main.c:433
 #, c-format
@@ -4089,7 +4089,7 @@
 #: ../imagery/i.biomass/main.c:73
 msgid "Name of Day of Year raster map [1-366]"
-msgstr ""
+msgstr "Nombre del mapa ráster Día del Año [1-366]"
 #: ../imagery/i.biomass/main.c:78
 msgid "Name of single-way transmissivity raster map [0.0-1.0]"
@@ -4147,7 +4147,7 @@
 #: ../imagery/i.evapo.time/main.c:162 ../imagery/i.evapo.time/main.c:178
 #: ../imagery/i.evapo.time/main.c:200
 msgid "The min specified input map is two"
-msgstr ""
+msgstr "El número mínimo especificado de mapas de entrada es de dos"
 #: ../imagery/i.evapo.time/main.c:167
 #, c-format
@@ -4284,7 +4284,7 @@
 #: ../imagery/i.pca/main.c:75
 msgid "principal components analysis"
-msgstr ""
+msgstr "análisis de componentes principales"
 #: ../imagery/i.pca/main.c:76
 msgid "Principal components analysis (PCA) for image processing."
@@ -4353,12 +4353,12 @@
 #: ../imagery/i.pca/main.c:169
 #, c-format
 msgid "'%s' must be positive"
-msgstr ""
+msgstr "'%s' debe ser positivo"
 #: ../imagery/i.pca/main.c:171
 #, c-format
 msgid "'%s' must be < 100"
-msgstr ""
+msgstr "'%s' debe ser < 100"
 #: ../imagery/i.pca/main.c:197 ../raster/r.covar/main.c:110
 msgid "No non-null values"
@@ -4379,16 +4379,16 @@
 #: ../imagery/i.pca/main.c:343
 msgid "Computing covariance matrix..."
-msgstr ""
+msgstr "Calculando la matriz de covarianza..."
 #: ../imagery/i.pca/main.c:456
 #, c-format
 msgid "Rescaling to range %d,%d..."
-msgstr ""
+msgstr "Reescalando a rango %d,%d..."
 #: ../imagery/i.pca/main.c:464
 msgid "Calculating principal components..."
-msgstr ""
+msgstr "Calculando componentes principales..."
 #: ../imagery/i.pca/support.c:50
 msgid "Eigen values, (vectors), and [percent importance]:"
@@ -4416,7 +4416,7 @@
 #: ../imagery/i.eb.evapfr/main.c:53
 msgid "Computes evaporative fraction and root zone soil moisture."
-msgstr ""
+msgstr "Calcula la fracción evapotranpirativa y zona de humedad del suelo en la zona de raices."
 #: ../imagery/i.eb.evapfr/main.c:58 ../imagery/i.eb.soilheatflux/main.c:71
 msgid "Name of Net Radiation raster map [W/m2]"
@@ -4568,7 +4568,7 @@
 #: ../imagery/i.segment/region_growing.c:1485
 #, c-format
 msgid "Region size is larger than 2: %d"
-msgstr ""
+msgstr "El tamaño de la región es mayor que 2: %d"
 #: ../imagery/i.segment/region_growing.c:1098
 #, c-format
@@ -4596,12 +4596,12 @@
 #: ../imagery/i.segment/open_files.c:39
 #, c-format
 msgid "Group <%s> not found in the current mapset"
-msgstr ""
+msgstr "El grupo <%s> no fue encontrado en el directorio de mapas actual"
 #: ../imagery/i.segment/open_files.c:43
 #, c-format
 msgid "Group <%s> contains no raster maps"
-msgstr ""
+msgstr "El grupo <%s> no contiene mapas ráster"
 #: ../imagery/i.segment/open_files.c:71 ../imagery/i.segment/open_files.c:238
 #: ../imagery/i.segment/open_files.c:246
@@ -4627,7 +4627,7 @@
 #: ../imagery/i.segment/open_files.c:358 ../imagery/i.segment/open_files.c:424
 #: ../imagery/i.segment/open_files.c:480
 msgid "Unable to write to temporary file"
-msgstr ""
+msgstr "No ha sido posible escribir archivos temporales"
 #: ../imagery/i.segment/open_files.c:277
 #, c-format
@@ -4651,7 +4651,7 @@
 #: ../imagery/i.segment/open_files.c:500
 #, c-format
 msgid "Segment %d is already registered!"
-msgstr ""
+msgstr "¡Segmento %d ya está registrado!"
 #: ../imagery/i.segment/open_files.c:554
 #, c-format
@@ -4726,7 +4726,7 @@
 #: ../imagery/i.segment/main.c:51
 msgid "Error in creating segments"
-msgstr ""
+msgstr "Error al crear segmentos"
 #: ../imagery/i.segment/main.c:55
 #, fuzzy
@@ -4996,7 +4996,7 @@
 #: ../imagery/i.segment/parse_args.c:360
 msgid "Invalid number of MB, 300 will be used"
-msgstr ""
+msgstr "La cantidad de MB no es válida, se usarán 300"
 #: ../imagery/i.vi/main.c:90
 msgid "vegetation index"
@@ -5026,11 +5026,11 @@
 #: ../imagery/i.vi/main.c:110
 msgid "Type of vegetation index"
-msgstr ""
+msgstr "Tipo de índice de vegetación"
 #: ../imagery/i.vi/main.c:115
 msgid "Atmospherically Resistant Vegetation Index"
-msgstr ""
+msgstr "Índice de vegetación atmosféricamente resistente"
 #: ../imagery/i.vi/main.c:116
 msgid "Difference Vegetation Index"
@@ -5151,7 +5151,7 @@
 #: ../imagery/i.vi/main.c:225
 #, c-format
 msgid "Calculating %s..."
-msgstr ""
+msgstr "Calculando %s..."
 #: ../imagery/i.vi/main.c:228
 msgid "sr index requires red and nir maps"
@@ -5756,7 +5756,7 @@
 #: ../imagery/i.eb.netrad/main.c:75
 msgid "Name of surface temperature raster map [K]"
-msgstr ""
+msgstr "Nombre del mapa de temperatura de superficie [K]"
 #: ../imagery/i.eb.netrad/main.c:80 ../imagery/i.eb.soilheatflux/main.c:76
 msgid "Name of time of satellite overpass raster map [local time in UTC]"
@@ -5768,7 +5768,7 @@
 #: ../imagery/i.eb.netrad/main.c:89
 msgid "Name of the emissivity map [-]"
-msgstr ""
+msgstr "Nombre del mapa de emisividad [-]"
 #: ../imagery/i.eb.netrad/main.c:94
 msgid "Name of the single-way atmospheric transmissivitymap [-]"
@@ -5776,7 +5776,7 @@
 #: ../imagery/i.eb.netrad/main.c:98
 msgid "Name of the Day Of Year (DOY) map [-]"
-msgstr ""
+msgstr "Nombre del mapa Día del Año (DOY) [-]"
 #: ../imagery/i.eb.netrad/main.c:102
 msgid "Name of the sun zenith angle map [degrees]"
@@ -5832,7 +5832,7 @@
 #: ../imagery/i.albedo/main.c:128
 msgid "Landsat 8 (7 input bands:1,2,3,4,5,6,7)"
-msgstr ""
+msgstr "Landsat 8 (7 bandas de entrada: 1,2,3,4,5,6,7)"
 #: ../imagery/i.albedo/main.c:132
 msgid "ASTER (6 input bands:1,3,5,6,8,9)"
@@ -5852,7 +5852,7 @@
 #: ../imagery/i.albedo/main.c:181
 msgid "At least two raster maps are required"
-msgstr ""
+msgstr "Se necesitan al menos dos mapas ráster"
 #: ../imagery/i.landsat.acca/main.c:70
 #, c-format
@@ -6259,12 +6259,12 @@
 #: ../imagery/i.cluster/main.c:267
 #, c-format
 msgid "  Res:   %12.2f  Res:  %12.2f%s"
-msgstr ""
+msgstr "Res: %12.2f Res: %12.2f%s"
 #: ../imagery/i.cluster/main.c:269
 #, c-format
 msgid "  Rows:  %12d  Cols: %12d  Cells: %d%s"
-msgstr ""
+msgstr "Filas: %12d Columnas: %12d Celdas: %d %s"
 #: ../imagery/i.cluster/main.c:271
 #, c-format
@@ -6289,7 +6289,7 @@
 #: ../imagery/i.cluster/main.c:278
 #, c-format
 msgid " Minimum class size:           %d%s"
-msgstr ""
+msgstr "Tamaño de clase mínimo:           %d %s"
 #: ../imagery/i.cluster/main.c:279
 #, c-format
@@ -6299,12 +6299,12 @@
 #: ../imagery/i.cluster/main.c:280
 #, c-format
 msgid " Percent convergence:          %f%s"
-msgstr ""
+msgstr "Porcentaje de convergencia: %f%s"
 #: ../imagery/i.cluster/main.c:281
 #, c-format
 msgid " Maximum number of iterations: %d%s"
-msgstr ""
+msgstr "Número máximo de iteraciones: %d%s"
 #: ../imagery/i.cluster/main.c:283
 #, c-format
@@ -6371,7 +6371,7 @@
 #: ../imagery/i.cluster/print2.c:18
 #, c-format
 msgid "%sclass means/stddev for each band%s%s"
-msgstr ""
+msgstr "%s medias/desviación estandar (stddev) por clase para cada banda %s %s"
 #: ../imagery/i.cluster/print2.c:23
 #, c-format
@@ -6425,15 +6425,15 @@
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:77
 msgid "X-coordinate standard deviation"
-msgstr ""
+msgstr "Desviación estándar de la coordenadas X"
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:82
 msgid "Y-coordinate standard deviation"
-msgstr ""
+msgstr "Desviación estándar de la coordenadas Y"
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:87
 msgid "Z-coordinate standard deviation"
-msgstr ""
+msgstr "Desviación estándar de la coordenadas Z"
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:92
 msgid "Initial Camera Omega (roll) degrees"
@@ -6465,7 +6465,7 @@
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:125
 msgid "Print initial values"
-msgstr ""
+msgstr "Imprimir valores iniciales"
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:137
 #, c-format
@@ -6612,11 +6612,11 @@
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:75
 msgid "Name of elevation map to use for ortho-rectification"
-msgstr ""
+msgstr "Nombre del mapa de elevación a usar pata la orto-rectificación"
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:80
 msgid "List available raster maps in target mapset and exit"
-msgstr ""
+msgstr "Listar los mapas ráster disponibles en el directorio de mapas blanco y salir"
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:85
 msgid "Print currently selected elevation map and exit"
@@ -6640,12 +6640,12 @@
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:162
 #, c-format
 msgid "Elevation for group <%s> is already set to <%s>"
-msgstr ""
+msgstr "La elevación para el grupo <%s> ya está definida a <%s>"
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:175
 #, c-format
 msgid "Mapset [%s] in target location [%s] - %s "
-msgstr ""
+msgstr "Directorio de mapas [%s] en la Localización objetivo [%s] -  %s"
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:177
 msgid "permission denied\n"
@@ -6665,7 +6665,7 @@
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:77
 msgid "Camera name"
-msgstr ""
+msgstr "Nombre de cámara"
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:83
 msgid "Camera id"
@@ -6859,7 +6859,7 @@
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:428
 #: ../misc/m.transform/main.c:361
 msgid "Local x,y coordinates to target east,north"
-msgstr "La coordenada del centro (Este, Norte)"
+msgstr "Coordenadas x,y locales hacia este,norte de destino"
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:432
 #: ../misc/m.transform/main.c:365
@@ -6909,11 +6909,11 @@
 #: ../imagery/i.topo.corr/main.c:49
 msgid "topographic correction"
-msgstr ""
+msgstr "corrección topográfica"
 #: ../imagery/i.topo.corr/main.c:50
 msgid "Computes topographic correction of reflectance."
-msgstr ""
+msgstr "Calcula la corrección topográfica de la reflectancia."
 #: ../imagery/i.topo.corr/main.c:58
 msgid "Name of reflectance raster maps to be corrected topographically"
@@ -6925,7 +6925,7 @@
 #: ../imagery/i.topo.corr/main.c:66
 msgid "Name of input base raster map (elevation or illumination)"
-msgstr ""
+msgstr "Nombre de mapa ráster base de entrada (elevación o iluminación)"
 #: ../imagery/i.topo.corr/main.c:72
 msgid "Solar zenith in degrees"
@@ -7056,7 +7056,7 @@
 #: ../imagery/i.eb.hsebal01/main.c:210
 msgid "Automatic mode selected"
-msgstr ""
+msgstr "Modo automático seleccionado"
 #: ../imagery/i.eb.hsebal01/main.c:222
 msgid "Manual wet/dry pixels in image coordinates"
@@ -8488,7 +8488,7 @@
 #: ../db/drivers/postgres/table.c:37
 msgid "Unable to execute():"
-msgstr ""
+msgstr "No se ha podido ejecutar(): "
 #: ../db/drivers/postgres/create_table.c:90
 #, c-format
@@ -9196,12 +9196,12 @@
 #: ../raster/r.sim/r.sim.sediment/main.c:276
 #: ../raster/r.sim/r.sim.water/main.c:312
 msgid "Generate random seed"
-msgstr ""
+msgstr "Generar semillas aleatoriass"
 #: ../raster/r.sim/r.sim.sediment/main.c:278
 #: ../raster/r.sim/r.sim.water/main.c:314
 msgid "Automatically generates random seed for random number generator (use when you don't want to provide the seed option)"
-msgstr ""
+msgstr "Genera una semila aleatoria automaticamente para el generador de números aleatorios (usar cuando no quiera proveer la opción semilla)"
 #: ../raster/r.sim/r.sim.sediment/main.c:286
 #: ../raster/r.sim/r.sim.water/main.c:322
@@ -9487,7 +9487,7 @@
 #: ../raster/r.random.cells/main.c:70
 msgid "Maximum number of cells to be created"
-msgstr ""
+msgstr "Máximo número de celdas a ser creadas"
 #: ../raster/r.random.cells/main.c:77
 msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default [random])"
@@ -10145,7 +10145,7 @@
 #: ../raster/r.sun/main.c:656
 #, c-format
 msgid "Using albedo map <%s>"
-msgstr ""
+msgstr "Usando el mapa de albedo <%s>"
 #: ../raster/r.sun/main.c:661
 #, c-format
@@ -10155,7 +10155,7 @@
 #: ../raster/r.sun/main.c:664
 #, c-format
 msgid "Using slope map <%s>"
-msgstr ""
+msgstr "Usando el mapa de pendiente <%s>"
 #: ../raster/r.sun/main.c:669
 #, c-format
@@ -10165,7 +10165,7 @@
 #: ../raster/r.sun/main.c:672
 #, c-format
 msgid "Using aspect map <%s>"
-msgstr ""
+msgstr "Usando el mapa de aspecto <%s>"
 #: ../raster/r.sun/main.c:687
 msgid "If you use -s and no horizon rasters, numpartitions must be =1"
@@ -11326,35 +11326,35 @@
 #: ../raster/r.in.lidar/main.c:158 ../raster/r.in.xyz/main.c:198
 msgid "Number of points in cell"
-msgstr ""
+msgstr "Número de puntos en la celda"
 #: ../raster/r.in.lidar/main.c:159 ../raster/r.in.xyz/main.c:199
 msgid "Minimum value of point values in cell"
-msgstr ""
+msgstr "Valor mínimo de los valores de los puntos en la celda"
 #: ../raster/r.in.lidar/main.c:160 ../raster/r.in.xyz/main.c:200
 msgid "Maximum value of point values in cell"
-msgstr ""
+msgstr "Valor máximo de los valores de los puntos en la celda"
 #: ../raster/r.in.lidar/main.c:161 ../raster/r.in.xyz/main.c:201
 msgid "Range of point values in cell"
-msgstr ""
+msgstr "Rango de los valores de los puntos en la celda"
 #: ../raster/r.in.lidar/main.c:162 ../raster/r.in.xyz/main.c:202
 msgid "Sum of point values in cell"
-msgstr ""
+msgstr "Suma de los valores de los puntos en la celda"
 #: ../raster/r.in.lidar/main.c:163 ../raster/r.in.xyz/main.c:203
 msgid "Mean (average) value of point values in cell"
-msgstr ""
+msgstr "Media (promedio) de los valores de los puntos en la celda"
 #: ../raster/r.in.lidar/main.c:164 ../raster/r.in.xyz/main.c:204
 msgid "Standard deviation of point values in cell"
-msgstr ""
+msgstr "Desviación estándar de los valores de los puntos en la celda"
 #: ../raster/r.in.lidar/main.c:165 ../raster/r.in.xyz/main.c:205
 msgid "Variance of point values in cell"
-msgstr ""
+msgstr "Varianza de los valores de los puntos en la celda"
 #: ../raster/r.in.lidar/main.c:166 ../raster/r.in.xyz/main.c:206
 msgid "Coefficient of variance of point values in cell"
@@ -11362,7 +11362,7 @@
 #: ../raster/r.in.lidar/main.c:167 ../raster/r.in.xyz/main.c:207
 msgid "Median value of point values in cell"
-msgstr ""
+msgstr "Mediana de los valores de los puntos en la celda"
 #: ../raster/r.in.lidar/main.c:168 ../raster/r.in.xyz/main.c:208
 msgid "pth (nth) percentile of point values in cell"
@@ -11421,7 +11421,7 @@
 #: ../raster/r.in.lidar/main.c:290
 msgid "Set computation region to match the new raster map"
-msgstr ""
+msgstr "Establecer la región computacional para que coincida con el nuevo mapa ráster"
 #: ../raster/r.in.lidar/main.c:292
 msgid "Set computation region to match the 2D extent and resolution of the newly created new raster map"
@@ -11441,7 +11441,7 @@
 #: ../raster/r.in.lidar/main.c:328
 msgid "Use base raster resolution instead of computational region"
-msgstr ""
+msgstr "Usar la resolución del ráster base en lugar de la región computacional "
 #: ../raster/r.in.lidar/main.c:330
 msgid "For getting values from base raster, use its actual resolution instead of computational region resolution"
@@ -11468,7 +11468,7 @@
 #: ../raster/r.in.lidar/main.c:491
 #, c-format
 msgid "Invalid %s"
-msgstr ""
+msgstr "No válido %s"
 #: ../raster/r.in.lidar/main.c:523 ../general/g.region/main.c:798
 #, c-format
@@ -11512,12 +11512,12 @@
 #: ../raster/r.in.lidar/main.c:797
 #, c-format
 msgid "Raster map <%s> created. %lu points from %d files found in region."
-msgstr ""
+msgstr "Mapa ráster <%s> creado. %lu puntos de %d archivos encontrados en la región."
 #: ../raster/r.in.lidar/main.c:802
 #, c-format
 msgid "Raster map <%s> created. %lu points found in region."
-msgstr ""
+msgstr "Mapa ráster <%s> creado. %lu puntos encontrados en la región."
 #: ../raster/r.in.lidar/point_binning.c:205 ../raster/r.in.xyz/main.c:474
 msgid "Unable to calculate percentile without the pth option specified!"
@@ -12843,7 +12843,7 @@
 #: ../raster/r.stats/raw_stats.c:118
 msgid "Invalid map type"
-msgstr ""
+msgstr "Tipo de mapa no válido"
 #: ../raster/r.stats/main.c:109
 msgid "Generates area statistics for raster map."
@@ -14000,7 +14000,7 @@
 #: ../raster/r.drain/main.c:123 ../raster/r.drain/main.c:164
 msgid "Cost surface"
-msgstr ""
+msgstr "Superficies de coste"
 #: ../raster/r.drain/main.c:131
 msgid "Name for output drain vector map"
@@ -14012,7 +14012,7 @@
 #: ../raster/r.drain/main.c:142
 msgid "Name of starting vector points map(s)"
-msgstr ""
+msgstr "Nombre del mapa(s) vectorial de puntos de partida"
 #: ../raster/r.drain/main.c:148
 msgid "Copy input cell values on output"
@@ -16142,7 +16142,7 @@
 #: ../raster/r.fill.dir/main.c:90
 msgid "depressions"
-msgstr ""
+msgstr "depresiones"
 #: ../raster/r.fill.dir/main.c:92
 msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
@@ -16269,7 +16269,7 @@
 #: ../raster/r.compress/main.c:120 ../raster/r.compress/main.c:300
 #, c-format
 msgid "Raster map <%s> is not in the current mapset"
-msgstr ""
+msgstr "El mapa ráster <%s> no se encuentra en el Directorio de mapas actual"
 #: ../raster/r.compress/main.c:126
 #, c-format
@@ -16304,7 +16304,7 @@
 #: ../raster/r.compress/main.c:216
 msgid "same size"
-msgstr ""
+msgstr "igual tamaño"
 #: ../raster/r.compress/main.c:232
 #, c-format
@@ -16314,17 +16314,17 @@
 #: ../raster/r.compress/main.c:235
 #, c-format
 msgid "Uncompressing <%s>"
-msgstr ""
+msgstr "Descomprimiendo <%s>"
 #: ../raster/r.compress/main.c:243
 #, c-format
 msgid "Re-compressing <%s>"
-msgstr ""
+msgstr "Re-comprimiendo <%s>"
 #: ../raster/r.compress/main.c:246
 #, c-format
 msgid "Compressing <%s>"
-msgstr ""
+msgstr "Comprimiendo <%s>"
 #: ../raster/r.compress/main.c:304
 #, c-format
@@ -16339,12 +16339,12 @@
 #: ../raster/r.compress/main.c:327
 #, c-format
 msgid "<%s> is uncompressed (method %i: %s). Data type: %s"
-msgstr ""
+msgstr "<%s> está descomprimido (método %i: %s). Tipo de dato: %s"
 #: ../raster/r.compress/main.c:334
 #, c-format
 msgid "<%s> is compressed (method %i: %s). Data type: %s"
-msgstr ""
+msgstr "<%s> está comprimido (método %i: %s). Tipo de dato: %s"
 #: ../raster/r.solute.transport/main.c:59
 msgid "The initial concentration in [kg/m^3]"
@@ -17186,7 +17186,7 @@
 #: ../raster/r.univar/r.univar_main.c:76
 msgid "Use the native resolution and extent of the raster map, instead of the current region"
-msgstr ""
+msgstr "Usar la resolución y extensión original del mapa ráster de entrada, independientemente de la configuración de la región actual"
 #: ../raster/r.univar/r.univar_main.c:106
 #: ../raster/r.univar/r3.univar_main.c:100
@@ -17206,7 +17206,7 @@
 #: ../raster/r.univar/r.univar_main.c:123
 msgid "zones option and region flag -r are mutually exclusive"
-msgstr ""
+msgstr "la opción zonas y la bandera región -r son mutuamente excluyentes"
 #: ../raster/r.univar/r3.univar_main.c:37
 msgid "3D Raster map used for zoning, must be of type CELL"
@@ -17521,7 +17521,7 @@
 #: ../raster/r.lake/main.c:175 ../raster/r.lake/main.c:184
 msgid "Seed"
-msgstr ""
+msgstr "Semilla"
 #: ../raster/r.lake/main.c:180
 msgid "Input raster map with given starting point(s) (at least 1 cell > 0)"
@@ -17859,7 +17859,7 @@
 #: ../raster/r.mapcalc/main.c:99
 msgid "List input and output maps"
-msgstr ""
+msgstr "Listar mapas de entrada y salida"
 #: ../raster/r.mapcalc/main.c:121
 #, c-format
@@ -18876,7 +18876,7 @@
 #: ../raster/r.patch/main.c:86
 msgid "Do not create color and category files"
-msgstr ""
+msgstr "No crear archivos de color y categoría"
 #: ../raster/r.patch/main.c:101
 msgid "The minimum number of input raster maps is two"
@@ -18928,7 +18928,7 @@
 #: ../raster/r.out.gdal/main.c:154
 msgid "Enhances compatibility with other GIS software"
-msgstr ""
+msgstr "Mejora la compatibilidad con otros software SIG"
 #: ../raster/r.out.gdal/main.c:159
 msgid "Write raster attribute table"
@@ -20976,7 +20976,7 @@
 #: ../locale/scriptstrings/t.support_to_translate.c:10
 msgid "Aggregation type of the space time raster or 3D raster dataset"
-msgstr ""
+msgstr "Tipo de agregación del conjunto de datos ráster o ráster 3D espacio temporales"
 #: ../locale/scriptstrings/t.support_to_translate.c:11
 msgid "Update the metadata information and spatial extent of registered maps from the GRASS spatial database"
@@ -21051,11 +21051,11 @@
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:6
 msgid "Comma separated list of coordinates"
-msgstr ""
+msgstr "Lista de coordenadas separadas por coma"
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:7
 msgid "Name for the output file or \"-\" in case stdout should be used"
-msgstr ""
+msgstr "Nombre para el archivo de salida o \"-\" en caso de que se use la salida estándar (stdout)"
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:8
 #: ../locale/scriptstrings/t.rast.series_to_translate.c:8
@@ -21068,11 +21068,11 @@
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:10
 msgid "Number of r.what processes to run in parallel"
-msgstr ""
+msgstr "Número de procesos r.what que correrán en paralelo"
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:12
 msgid "Use stdin as input and ignore coordinates and point option"
-msgstr ""
+msgstr "Usar entrada estándar (stdin) como entrada e ignorar la opción de coordenadas y puntos"
 #: ../locale/scriptstrings/v.build.all_to_translate.c:1
 msgid "Rebuilds topology on all vector maps in the current mapset."
@@ -21200,11 +21200,11 @@
 #: ../locale/scriptstrings/d.frame_to_translate.c:5
 msgid "frame"
-msgstr ""
+msgstr "marco"
 #: ../locale/scriptstrings/d.frame_to_translate.c:6
 msgid "Create a new frame if doesn't exist and select"
-msgstr ""
+msgstr "Crear un nuevo marco si es que no existe y seleccionarlo"
 #: ../locale/scriptstrings/d.frame_to_translate.c:7
 msgid "Remove all frames, erase the screen and exit"
@@ -21212,7 +21212,7 @@
 #: ../locale/scriptstrings/d.frame_to_translate.c:8
 msgid "Print name of current frame and exit"
-msgstr ""
+msgstr "Mostrar nombre del marco actual y salir"
 #: ../locale/scriptstrings/d.frame_to_translate.c:9
 msgid "Print names of all frames including 'at' position and exit"
@@ -21228,7 +21228,7 @@
 #: ../locale/scriptstrings/d.frame_to_translate.c:12
 msgid "Implies only when -c or --overwrite flag is given"
-msgstr ""
+msgstr "Aplica solamente cuando se usan las banderas -c o --overwrite"
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:1
 msgid "Detects accumulation patterns in temporally accumulated space time raster datasets created by t.rast.accumulate."
@@ -21526,11 +21526,11 @@
 #: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:6
 msgid "Name of the new created vector map that stores the sampled values in different layers"
-msgstr ""
+msgstr "Nombre del nuevo mapa vectorial creado que guarda los valores muestreados en diferentes capas"
 #: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:7
 msgid "Names of the vector columns to be created and to store sampled raster values, one name for each STRDS"
-msgstr ""
+msgstr "Nombres de las columnas vectoriales que se crearán y que guardarán los valores ráster muestreados, un nombre para cada STRDS"
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:1
 msgid "Imports space time raster dataset."
@@ -21650,7 +21650,7 @@
 #: ../locale/scriptstrings/i.spectral_to_translate.c:9
 msgid "Name for output image (or text file for -t)"
-msgstr ""
+msgstr "Nombre para imagen de salida (o archivo de texto para -t)"
 #: ../locale/scriptstrings/i.spectral_to_translate.c:11
 msgid "Graphics format for output file"
@@ -21666,7 +21666,7 @@
 #: ../locale/scriptstrings/i.spectral_to_translate.c:15
 msgid "output to text file"
-msgstr ""
+msgstr "salida a archivo de texto"
 #: ../locale/scriptstrings/v.in.lines_to_translate.c:1
 msgid "Imports ASCII x,y[,z] coordinates as a series of lines."
@@ -21785,11 +21785,11 @@
 #: ../locale/scriptstrings/t.rast.algebra_to_translate.c:1
 msgid "Apply temporal and spatial operations on space time raster datasets using temporal raster algebra."
-msgstr ""
+msgstr "Realizar operaciones espaciales y temporales en un conjunto de datos ráster espacio temporales usando álgebra de rásters."
 #: ../locale/scriptstrings/t.rast.algebra_to_translate.c:6
 msgid "r.mapcalc expression for temporal and spatial analysis of space time raster datasets"
-msgstr ""
+msgstr "Expresión de r.mapcalc para análisis espaciales y temporales de conjuntos espacio temporales de datos ráster"
 #: ../locale/scriptstrings/t.rast.algebra_to_translate.c:12
 #: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:13
@@ -21865,11 +21865,11 @@
 msgid "Apply temporal and spatial operations on space time 3D raster datasets using temporal 3D raster algebra."
-msgstr ""
+msgstr "Realizar operaciones temporales y espaciales en un conjunto de datos ráster 3D espacio temporales usando álgebra de rásters 3D."
 #: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:7
 msgid "Algebraic expression for temporal and spatial analysis of space time 3D raster datasets"
-msgstr ""
+msgstr "Expresión algebráica para análisis temporal y espacial de conjuntos de datos ráster 3D espacio temporales"
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
 msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
@@ -22041,13 +22041,13 @@
 #: ../locale/scriptstrings/t.shift_to_translate.c:1
 msgid "Shifts temporally the maps of a space time dataset."
-msgstr ""
+msgstr "Cambia temporalmente los mapas de un conjunto de datos espacio temporales"
 #: ../locale/scriptstrings/t.shift_to_translate.c:3
 #: ../locale/scriptstrings/t.snap_to_translate.c:3
 #: ../locale/scriptstrings/t.merge_to_translate.c:3
 msgid "time management"
-msgstr ""
+msgstr "gestión de tiempo"
 #: ../locale/scriptstrings/t.shift_to_translate.c:4
 msgid "shift"
@@ -22089,7 +22089,7 @@
 #: ../locale/scriptstrings/g.search.modules_to_translate.c:8
 msgid "Invert selection (logical NOT)"
-msgstr ""
+msgstr "Invertir selección (NO lógico)"
 #: ../locale/scriptstrings/g.search.modules_to_translate.c:10
 msgid "Search in manual pages too (can be slow)"
@@ -22097,7 +22097,7 @@
 #: ../locale/scriptstrings/g.search.modules_to_translate.c:12
 msgid "Search only for the exact keyword in module keyword list"
-msgstr ""
+msgstr "Buscar solamente la palabra clave exacta en la lista de palabras clave de módulos"
 #: ../locale/scriptstrings/g.search.modules_to_translate.c:13
 msgid "Instead of full text search, search only in actual keywords"
@@ -22343,11 +22343,11 @@
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:1
 msgid "Produces a space time vector dataset of specified contours from a space time raster dataset."
-msgstr ""
+msgstr "Produce un conjunto de datos vectoriales espacio temporales con los contornos especificados a partir de un conjunto de datos ráster espacio temporales."
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:3
 msgid "contour"
-msgstr ""
+msgstr "contorno"
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:15
 msgid "Number of r.contour processes to run in parallel, more than 1 process works only in conjunction with flag -t"
@@ -22356,12 +22356,12 @@
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:16
 #: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:13
 msgid "Register empty vector maps"
-msgstr ""
+msgstr "Registrar mapas vectoriales vacíos"
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:17
 #: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:14
 msgid "Do not create attribute tables"
-msgstr ""
+msgstr "No crear tablas de atributos"
 #: ../locale/scriptstrings/t.vect.algebra_to_translate.c:1
 msgid "Apply temporal and spatial operations on space time vector datasets using temporal vector algebra."
@@ -22545,15 +22545,15 @@
 #: ../locale/scriptstrings/g.extension_to_translate.c:2
 msgid "Downloads and installs extensions from GRASS Addons repository or other source into the local GRASS installation or removes installed extensions."
-msgstr ""
+msgstr "Descarga e instala extensiones del repositorio de extensiones de GRASS o de otra fuente en la instalación local de GRASS o remueve extensiones instaladas."
 #: ../locale/scriptstrings/g.extension_to_translate.c:6
 msgid "addons"
-msgstr ""
+msgstr "Complementos"
 #: ../locale/scriptstrings/g.extension_to_translate.c:7
 msgid "download"
-msgstr ""
+msgstr "descargar"
 #: ../locale/scriptstrings/g.extension_to_translate.c:8
 msgid "Name of extension to install or remove"
@@ -22565,7 +22565,7 @@
 #: ../locale/scriptstrings/g.extension_to_translate.c:11
 msgid "URL or directory to get the extension from (supported only on Linux and Mac)"
-msgstr ""
+msgstr "URL o directorio del cual obtener las extensiones (soportado solamente en Linux y Mac)"
 #: ../locale/scriptstrings/g.extension_to_translate.c:12
 msgid "The official repository is used by default. User can specify a ZIP file, directory or a repository on common hosting services. If not identified, Subversion repository is assumed. See manual for all options."
@@ -22581,15 +22581,15 @@
 #: ../locale/scriptstrings/g.extension_to_translate.c:15
 msgid "List available extensions in the official GRASS GIS Addons repository"
-msgstr ""
+msgstr "Listar extensiones disponibles en el repositorio oficial de extensiones de  GRASS GIS"
 #: ../locale/scriptstrings/g.extension_to_translate.c:17
 msgid "List available extensions in the official GRASS GIS Addons repository including module description"
-msgstr ""
+msgstr "Listar extensiones disponibles en el repositorio oficial de extensiones de  GRASS GIS incluyendo la descripción del módulo"
 #: ../locale/scriptstrings/g.extension_to_translate.c:19
 msgid "List available extensions in the official GRASS GIS Addons repository (shell script style)"
-msgstr ""
+msgstr "Listar extensiones disponibles en el repositorio oficial de extensiones de GRASS GIS (estilo scipt de consola)"
 #: ../locale/scriptstrings/g.extension_to_translate.c:21
 msgid "List locally installed extensions"
@@ -22787,7 +22787,7 @@
 #: ../locale/scriptstrings/t.rast.export_to_translate.c:12
 msgid "Supported only for GTiff"
-msgstr ""
+msgstr "Soportado solamente para GTiff"
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:1
 msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
@@ -22832,11 +22832,11 @@
 msgid "Converts a space time raster dataset into a space time vector dataset"
-msgstr ""
+msgstr "Convierte un conjunto de datos ráster espacio temporales en un conjunto de datos vectoriales espacio temporales."
 #: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:12
 msgid "Number of r.to.vect processes to run in parallel, more than 1 process works only in conjunction with flag -t"
-msgstr ""
+msgstr "Cantidad de procesos r.to.vect que correrán en paralelo, más de 1 proceso funciona solamente en conjunto con la bandera -t"
 #: ../locale/scriptstrings/t.remove_to_translate.c:1
 msgid "Removes space time datasets from temporal database."
@@ -22874,11 +22874,11 @@
 #: ../locale/scriptstrings/t.topology_to_translate.c:7
 msgid "Print temporal topological relationships and exit"
-msgstr ""
+msgstr "Imprimir relaciones topológicas temporales y salir"
 #: ../locale/scriptstrings/t.topology_to_translate.c:8
 msgid "Print spatio-temporal topological relationships and exit"
-msgstr ""
+msgstr "Imprimir relaciones topológicas espacio-temporales y salir"
 #: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:2
 msgid "This is the low-memory alternative to the classic r.buffer module."
@@ -23126,7 +23126,7 @@
 #: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:7
 msgid "Type of the space time dataset from which aggregation will be copied"
-msgstr ""
+msgstr "Tipo del conjunto de datos espacio temporales desde el cual se copiará la agregación"
 #: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:12
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:11
@@ -23565,7 +23565,7 @@
 #: ../locale/scriptstrings/t.select_to_translate.c:8
 msgid "Check the spatial topology of temporally related maps and select only spatially related maps"
-msgstr ""
+msgstr "Revisar la topología espacial de mapas temporalmente relacionados y seleccionar solamente mapas espacialmente relacionados"
 #: ../locale/scriptstrings/t.create_to_translate.c:1
 msgid "Creates a space time dataset."
@@ -23669,7 +23669,7 @@
 #: ../locale/scriptstrings/t.sample_to_translate.c:12
 msgid "Check for spatial topological overlap"
-msgstr ""
+msgstr "Revisar por solapamientos en la topología espacial"
 #: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
 msgid "Drops a column from the attribute table connected to a given vector map."
@@ -23705,7 +23705,7 @@
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:13
 msgid "The maximum number of open files allowed for each r.series process"
-msgstr ""
+msgstr "El máximo número permitido de archivos abiertos para cada proceso r.series"
 #: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:1
 msgid "Replaces gaps in a space time raster dataset with interpolated raster maps."
@@ -23737,7 +23737,7 @@
 #: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:13
 msgid "Ignore the current region settings and use the raster map regions"
-msgstr ""
+msgstr "Ignorar la configuración de la región actual y usar la región del mapa ráster"
 #: ../locale/scriptstrings/t.vect.univar_to_translate.c:1
 msgid "Calculates univariate statistics of attributes for each registered vector map of a space time vector dataset"
@@ -24104,15 +24104,15 @@
 #: ../display/d.vect.thematic/main.c:214 ../display/d.vect.thematic/main.c:236
 msgid "DEPRECATED"
-msgstr ""
+msgstr "DEPRACTED (fuera de uso)"
 #: ../display/d.vect.thematic/main.c:215
 msgid "Output legend file"
-msgstr ""
+msgstr "Archivo de leyenda de salida"
 #: ../display/d.vect.thematic/main.c:228
 msgid "Do not draw map, only output the legend information"
-msgstr ""
+msgstr "No dibujar mapa, solo guardar la información de la leyenda"
 #: ../display/d.vect.thematic/main.c:237
 msgid "When printing legend info, include extended statistical info from classification algorithm"
@@ -24120,7 +24120,7 @@
 #: ../display/d.vect.thematic/main.c:243 ../display/d.vect/main.c:329
 msgid "Do not show this layer in vector legend"
-msgstr ""
+msgstr "No mostrar esta capa en la leyenda vectorial"
 #: ../display/d.vect.thematic/main.c:255
 msgid "Flag -e is deprecated, set verbose mode with --v to get the extended statistical info."
@@ -24412,7 +24412,7 @@
 #: ../display/d.barscale/main.c:148
 msgid "Number of segments"
-msgstr ""
+msgstr "Número de segmentos"
 #: ../display/d.barscale/main.c:152
 msgid "Bar scale and text color"
@@ -25030,7 +25030,7 @@
 #: ../display/d.vect/main.c:213
 msgid "Line symbol for legend"
-msgstr ""
+msgstr "Símbolo de línea para la leyenda"
 #: ../display/d.vect/main.c:219
 msgid "Label to display after symbol in vector legend"
@@ -25289,7 +25289,7 @@
 #: ../display/d.mon/start.c:46 ../display/d.mon/start.c:74
 #, c-format
 msgid "File <%s> already exists and will be overwritten"
-msgstr ""
+msgstr "El archivo <%s> ya existe y se sobrescribirá"
 #: ../display/d.mon/start.c:67
 #, c-format
@@ -25299,7 +25299,7 @@
 #: ../display/d.mon/start.c:76
 #, c-format
 msgid "Unable to delete <%s>"
-msgstr ""
+msgstr "No ha sido posible eliminar <%s>"
 #: ../display/d.mon/start.c:93
 #, c-format
@@ -25314,7 +25314,7 @@
 #: ../display/d.mon/start.c:151
 #, c-format
 msgid "Starting monitor <%s>..."
-msgstr ""
+msgstr "Iniciando monitor <%s>..."
 #: ../display/d.mon/start.c:169
 msgid "Unable to copy render command file"
@@ -25346,17 +25346,17 @@
 #: ../display/d.mon/stop.c:41
 #, c-format
 msgid "Unable to delete file <%s>"
-msgstr ""
+msgstr "No se puede borrar el archivo <%s>"
 #: ../display/d.mon/stop.c:46
 #, c-format
 msgid "Unable to delete directory <%s>"
-msgstr ""
+msgstr "No se puede borrar el directorio <%s>"
 #: ../display/d.mon/stop.c:75
 #, c-format
 msgid "Unable to read file <%s>"
-msgstr ""
+msgstr "No se puede leer el archivo <%s>"
 #: ../display/d.mon/main.c:41
 msgid "Controls graphics display monitors from the command line."
@@ -25386,7 +25386,7 @@
 #: ../display/d.mon/main.c:67
 msgid "Default value: 720"
-msgstr ""
+msgstr "Valor predeterminado: 720"
 #: ../display/d.mon/main.c:74
 msgid "Height for display monitor if not set by GRASS_RENDER_HEIGHT"
@@ -25659,7 +25659,7 @@
 #: ../display/d.legend.vect/main.c:74
 msgid "Number of legend columns"
-msgstr ""
+msgstr "Número de columnas en la leyenda"
 #: ../display/d.legend.vect/main.c:75 ../display/d.legend.vect/main.c:90
 msgid "Layout"
@@ -25667,12 +25667,12 @@
 #: ../display/d.legend.vect/main.c:81 ../display/d.legend/main.c:99
 msgid "Legend title"
-msgstr ""
+msgstr "Título de la leyenda"
 #: ../display/d.legend.vect/main.c:82 ../display/d.legend.vect/main.c:141
 #: ../display/d.legend/main.c:100 ../display/d.legend/main.c:109
 msgid "Title"
-msgstr ""
+msgstr "Título"
 #: ../display/d.legend.vect/main.c:95 ../display/d.grid/main.c:101
 #: ../display/d.legend/main.c:240 ../vector/v.label.sa/main.c:144
@@ -25685,7 +25685,7 @@
 #: ../display/d.legend/main.c:241 ../display/d.legend/main.c:247
 #: ../display/d.legend/main.c:288
 msgid "Background"
-msgstr ""
+msgstr "Fondo"
 #: ../display/d.legend.vect/main.c:108
 msgid "Background border width"
@@ -25693,35 +25693,35 @@
 #: ../display/d.legend.vect/main.c:124
 msgid "Default: 12"
-msgstr ""
+msgstr "Predeterminado: 12"
 #: ../display/d.legend.vect/main.c:131
 msgid "Title font name"
-msgstr ""
+msgstr "Nombre de fuente para el título"
 #: ../display/d.legend.vect/main.c:139 ../display/d.legend/main.c:107
 msgid "Title font size"
-msgstr ""
+msgstr "Tamaño de fuente para el título"
 #: ../display/d.legend.vect/main.c:140
 msgid "Default: 18"
-msgstr ""
+msgstr "Predeterminado: 18"
 #: ../display/d.legend.vect/main.c:147
 msgid "Subtitle font name"
-msgstr ""
+msgstr "Nombre de fuente para el subtítulo"
 #: ../display/d.legend.vect/main.c:155
 msgid "Subtitle font size"
-msgstr ""
+msgstr "Tamaño de fuente para el subtítulo"
 #: ../display/d.legend.vect/main.c:156
 msgid "Default: 14"
-msgstr ""
+msgstr "Predeterminado: 14"
 #: ../display/d.legend.vect/main.c:162
 msgid "Font color"
-msgstr ""
+msgstr "Color de fuente"
 #: ../display/d.legend.vect/main.c:167
 msgid "Display legend background"
@@ -25730,15 +25730,15 @@
 #: ../display/d.legend.vect/main.c:171 ../display/d.legend.vect/main.c:178
 #: ../display/d.legend.vect/main.c:185
 msgid "In/Out"
-msgstr ""
+msgstr "Dentro/Fuera"
 #: ../display/d.legend.vect/main.c:172
 msgid "Field separator for input file"
-msgstr ""
+msgstr "Separador de campos para archivo de entrada"
 #: ../display/d.legend.vect/main.c:175
 msgid "Input legend file"
-msgstr ""
+msgstr "Archivo de leyenda de entrada"
 #: ../display/d.legend.vect/main.c:176
 msgid "Path to legend file "
@@ -25746,7 +25746,7 @@
 #: ../display/d.legend.vect/main.c:181
 msgid "Output csv file"
-msgstr ""
+msgstr "Archivo csv de salida"
 #: ../display/d.legend.vect/main.c:182
 msgid "Path to output file or '-' for standard output"
@@ -25754,7 +25754,7 @@
 #: ../display/d.legend.vect/draw.c:95 ../display/d.legend.vect/draw.c:183
 msgid "Cannot read symbol"
-msgstr ""
+msgstr "No se puede leer el símbolo"
 #: ../display/d.legend.vect/draw.c:244
 msgid "Invalid value for color type in legend file. Use one of 'lf' or 'ps'."
@@ -25826,19 +25826,19 @@
 #: ../display/d.northarrow/main.c:70
 msgid "Simple arrow"
-msgstr ""
+msgstr "Flecha simple"
 #: ../display/d.northarrow/main.c:71
 msgid "Thin arrow"
-msgstr ""
+msgstr "Flecha delgada"
 msgid "Fat arrow"
-msgstr ""
+msgstr "Flecha gorda"
 msgid "4-point star"
-msgstr ""
+msgstr "Estrella de cuatro puntos"
 #: ../display/d.northarrow/main.c:99
 msgid "Displayed letter on the top of arrow"
@@ -26171,7 +26171,7 @@
 #: ../display/d.legend/main.c:108
 msgid "Default: Same as fontsize"
-msgstr ""
+msgstr "Predeterminado: mismo que el tamaño de fuente"
 #: ../display/d.legend/main.c:117
 msgid "Number of text lines (useful for truncating long legends)"
@@ -26183,7 +26183,7 @@
 #: ../display/d.legend/main.c:135
 msgid "Units to display after labels (e.g. meters)"
-msgstr ""
+msgstr "Unidades a mostrar luego de las etiquetas (ej. metros)"
 #: ../display/d.legend/main.c:144
 msgid "Number of text labels for smooth gradient legend"
@@ -26205,7 +26205,7 @@
 #: ../display/d.legend/main.c:167
 msgid "Number of digits after decimal point"
-msgstr ""
+msgstr "Número de dígitos después del punto decimal"
 #: ../display/d.legend/main.c:179
 msgid "Size and placement as percentage of screen coordinates (0,0 is lower left)"
@@ -26249,11 +26249,11 @@
 #: ../display/d.legend/main.c:287
 msgid "Show background"
-msgstr ""
+msgstr "Mostrar fondo"
 #: ../display/d.legend/main.c:292
 msgid "Use logarithmic scale"
-msgstr ""
+msgstr "Usar escala logarítmica"
 #: ../display/d.legend/draw.c:109
 msgid "Legend box lies outside of frame. Text may not display properly."
@@ -26612,11 +26612,11 @@
 #: ../general/g.version/main.c:87 ../general/g.version/main.c:93
 #: ../general/g.version/main.c:99
 msgid "Additional info"
-msgstr ""
+msgstr "Información adicional"
 #: ../general/g.version/main.c:81
 msgid "Print also the citation options"
-msgstr ""
+msgstr "Mostrar también las opciones para citar"
 #: ../general/g.version/main.c:86
 msgid "Print also the build information"
@@ -26636,7 +26636,7 @@
 #: ../general/g.version/main.c:103
 msgid "Print info in shell script style (including SVN revision number)"
-msgstr ""
+msgstr "Mostrar información en estilo script de consola (incluyendo número de revisión SVN)"
 #: ../general/g.version/main.c:104
 msgid "Shell"
@@ -26999,7 +26999,7 @@
 #: ../general/g.gui/main.c:67
 msgid "This is valid only for wxGUI (wxpython)"
-msgstr ""
+msgstr "Esto es válidos solamente para wxGUI (wxpython)"
 #: ../general/g.gui/main.c:71
 msgid "Start GUI in the foreground"
@@ -27038,7 +27038,7 @@
 #: ../general/g.gui/main.c:111
 #, c-format
 msgid "Launching <%s> GUI, please wait..."
-msgstr ""
+msgstr "Lanzando GUI <%s>, por favor espere..."
 #: ../general/g.gui/main.c:122
 #, c-format
@@ -27184,7 +27184,7 @@
 #: ../general/g.list/main.c:142
 msgid "Print fully-qualified map names (including mapsets)"
-msgstr ""
+msgstr "Mostrar nombres de mapas completos (incluyendo Directorios de mapas)"
 #: ../general/g.list/main.c:147
 msgid "Pretty printing in human readable format"
@@ -27218,12 +27218,12 @@
 #: ../general/g.parser/parse.c:103
 #, c-format
 msgid "Unknown module parameter \"%s\" at line %d\n"
-msgstr ""
+msgstr "Parámetro \"%s\" desconocido para el módulo en la línea %d\n"
 #: ../general/g.parser/parse.c:140
 #, c-format
 msgid "Unknown flag parameter \"%s\" at line %d\n"
-msgstr ""
+msgstr "Flag desconocido \"%s\" en la línea %d\n"
 #: ../general/g.parser/parse.c:155
 #, c-format
@@ -27233,7 +27233,7 @@
 #: ../general/g.parser/parse.c:233
 #, c-format
 msgid "Unknown option parameter \"%s\" at line %d\n"
-msgstr ""
+msgstr "Opción desconocida \"%s\" en la línea %d\n"
 #: ../general/g.parser/revoke.c:63
 msgid "G_spawn() failed"
@@ -27334,12 +27334,12 @@
 #: ../general/g.ppmtopng/main.c:34
 #, c-format
 msgid "Unable to open input file %s"
-msgstr ""
+msgstr "No se puede abrir el archivo de entrada %s"
 #: ../general/g.ppmtopng/main.c:37
 #, c-format
 msgid "Invalid input file %s"
-msgstr ""
+msgstr "Archivo de entrada no válido %s"
 #: ../general/g.ppmtopng/main.c:77
 msgid "Error writing PNG file"
@@ -27387,7 +27387,7 @@
 #: ../general/g.copy/main.c:76
 #, c-format
 msgid "<%s> already exists. File not copied."
-msgstr ""
+msgstr "<%s> ya existe. Archivo no copiado."
 #: ../general/g.remove/check_reclass.c:16
 #, c-format
@@ -29622,17 +29622,17 @@
 #: ../vector/v.out.lidar/main.c:123
 msgid "Double values will be converted to integers"
-msgstr ""
+msgstr "Valores de doble precisión serán convertidos en enteros"
 #: ../vector/v.out.lidar/main.c:184
 #, c-format
 msgid "No record for cat = %d"
-msgstr ""
+msgstr "No hay registro para cat = %d"
 #: ../vector/v.out.lidar/main.c:187
 #, c-format
 msgid "NULL value for cat = %d"
-msgstr ""
+msgstr "Valor nulo para cat = %d"
 #: ../vector/v.out.lidar/main.c:196
 #, c-format
@@ -29647,22 +29647,22 @@
 #: ../vector/v.out.lidar/main.c:475
 msgid "Exports vector points as LAS point cloud"
-msgstr ""
+msgstr "Exportar puntos vectoriales como nube de puntos LAS"
 #: ../vector/v.out.lidar/main.c:476
 msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS"
-msgstr ""
+msgstr "Convierte nubes de punos LAS LiDAR a mapa vectorial GRASS con libLAS"
 #: ../vector/v.out.lidar/main.c:496 ../vector/v.in.lidar/main.c:149
 msgid "Layer number to store generated point ID as category"
-msgstr ""
+msgstr "Número de capa en el que se guardarán las ID de los puntos como categorías"
 #: ../vector/v.out.lidar/main.c:498 ../vector/v.out.lidar/main.c:505
 #: ../vector/v.out.lidar/main.c:512 ../vector/v.out.lidar/main.c:519
 #: ../vector/v.in.lidar/main.c:152 ../vector/v.in.lidar/main.c:160
 #: ../vector/v.in.lidar/main.c:168 ../vector/v.in.lidar/main.c:176
 msgid "Categories"
-msgstr ""
+msgstr "Categorías"
 #: ../vector/v.out.lidar/main.c:503
 msgid "Layer number to store return number as category"
@@ -29670,11 +29670,11 @@
 #: ../vector/v.out.lidar/main.c:510 ../vector/v.in.lidar/main.c:165
 msgid "Layer number to store class number as category"
-msgstr ""
+msgstr "Número de capa en el que se guardarán el número de clase como categoría"
 #: ../vector/v.out.lidar/main.c:517
 msgid "Layer number where RGB color is stored as category"
-msgstr ""
+msgstr "Número de capa en el que se guardará el color RGB como categoría"
 #: ../vector/v.out.lidar/main.c:525 ../vector/v.out.lidar/main.c:531
 #: ../vector/v.out.lidar/main.c:537
@@ -29692,23 +29692,23 @@
 #: ../vector/v.out.lidar/main.c:543
 msgid "RGB color definition column"
-msgstr ""
+msgstr "Nombre de la columna de definición de color RGB"
 #: ../vector/v.out.lidar/main.c:550
 msgid "Column with red color"
-msgstr ""
+msgstr "Columna con el color rojo"
 #: ../vector/v.out.lidar/main.c:556
 msgid "Column with green color"
-msgstr ""
+msgstr "Columna con el color verde"
 #: ../vector/v.out.lidar/main.c:562
 msgid "Column with blue color"
-msgstr ""
+msgstr "Columna con el color azul"
 #: ../vector/v.out.lidar/main.c:571
 msgid "Internal scale to apply to X and Y values"
-msgstr ""
+msgstr "Escala interna a aplicar a los valores X y Y"
 #: ../vector/v.out.lidar/main.c:572 ../vector/v.out.lidar/main.c:582
 msgid "This scale does not change the values itself but only how precisely they are stored, for example 0.01 will preserve two decimal places"
@@ -29716,15 +29716,15 @@
 #: ../vector/v.out.lidar/main.c:581
 msgid "Internal scale to apply to z values"
-msgstr ""
+msgstr "Escala interna a aplicar a los valores z"
 #: ../vector/v.out.lidar/main.c:589
 msgid "Limit export to the current region"
-msgstr ""
+msgstr "Limitar exportación a la región actual"
 #: ../vector/v.out.lidar/main.c:593
 msgid "Ignore color table"
-msgstr ""
+msgstr "Ignorar tabla de colores"
 #: ../vector/v.out.lidar/main.c:595
 msgid "Ignore color table even when set and not other options are present"
@@ -29732,7 +29732,7 @@
 #: ../vector/v.timestamp/main.c:39
 msgid "Modifies a timestamp for a vector map."
-msgstr ""
+msgstr "Modifica un timestamp para una mapa vectorial."
 #: ../vector/v.timestamp/main.c:40
 msgid "Print/add/remove a timestamp for a vector map."
@@ -29797,7 +29797,7 @@
 #: ../vector/v.cluster/main.c:91
 msgid "point cloud"
-msgstr ""
+msgstr "nube de puntos"
 #: ../vector/v.cluster/main.c:92
 msgid "cluster"
@@ -29825,7 +29825,7 @@
 #: ../vector/v.cluster/main.c:123
 msgid "Clustering method"
-msgstr ""
+msgstr "Método de agrupamiento"
 #: ../vector/v.cluster/main.c:127
 msgid "Force 2D clustering"
@@ -29842,7 +29842,7 @@
 #: ../vector/v.cluster/main.c:186
 msgid "Counting input points ..."
-msgstr ""
+msgstr "Contando puntos de entrada..."
 #: ../vector/v.cluster/main.c:192
 #, c-format
@@ -29865,11 +29865,11 @@
 #: ../vector/v.cluster/main.c:260 ../vector/v.cluster/main.c:465
 msgid "Estimating maximum distance ..."
-msgstr ""
+msgstr "Estimando la distancia máxima..."
 #: ../vector/v.cluster/main.c:291 ../vector/v.cluster/main.c:496
 msgid "No neighbors found"
-msgstr ""
+msgstr "No se encontraron vecinos"
 #: ../vector/v.cluster/main.c:301 ../vector/v.cluster/main.c:506
 #, c-format
@@ -29879,22 +29879,22 @@
 #: ../vector/v.cluster/main.c:302 ../vector/v.cluster/main.c:507
 #, c-format
 msgid "Min: %g, max: %g"
-msgstr ""
+msgstr "Mín: %g, máx: %g"
 #: ../vector/v.cluster/main.c:303 ../vector/v.cluster/main.c:508
 #, c-format
 msgid "Mean: %g"
-msgstr ""
+msgstr "Promedio: %g"
 #: ../vector/v.cluster/main.c:304 ../vector/v.cluster/main.c:509
 #, c-format
 msgid "Standard deviation: %g"
-msgstr ""
+msgstr "Desviación estándar: %g"
 #: ../vector/v.cluster/main.c:306 ../vector/v.cluster/main.c:511
 #, c-format
 msgid "Estimated maximum distance: %g"
-msgstr ""
+msgstr "Distancia máxima estimada: %g"
 #: ../vector/v.cluster/main.c:310 ../vector/v.cluster/main.c:515
 #: ../vector/v.cluster/main.c:928 ../vector/v.cluster/main.c:1089
@@ -29919,7 +29919,7 @@
 #: ../vector/v.cluster/main.c:710
 msgid "Loading points ..."
-msgstr ""
+msgstr "Cargando puntos..."
 #: ../vector/v.cluster/main.c:734 ../vector/v.cluster/main.c:878
 msgid "Reachability network ..."
@@ -29929,7 +29929,7 @@
 #: ../vector/v.cluster/main.c:888 ../vector/v.cluster/main.c:1066
 #: ../vector/v.cluster/main.c:1100 ../vector/v.cluster/main.c:1137
 msgid "Not enough points found"
-msgstr ""
+msgstr "No se encontraron suficientes puntos"
 #: ../vector/v.cluster/main.c:807
 msgid "Set cluster ids ..."
@@ -29946,12 +29946,12 @@
 #: ../vector/v.cluster/main.c:1178
 #, c-format
 msgid "%d clusters found"
-msgstr ""
+msgstr "%d grupos encontrados"
 #: ../vector/v.cluster/main.c:1179
 #, c-format
 msgid "%d outliers found"
-msgstr ""
+msgstr "%d discrepantes (outliers) encontrados"
 #: ../vector/v.net.spanningtree/main.c:48
 msgid "spanning tree"
@@ -30783,7 +30783,7 @@
 #: ../vector/v.overlay/main.c:67
 msgid "difference"
-msgstr ""
+msgstr "diferencia"
 #: ../vector/v.overlay/main.c:68
 msgid "intersection"
@@ -31074,7 +31074,7 @@
 #: ../vector/v.decimate/main.c:181 ../vector/v.in.lidar/main.c:253
 msgid "Skip first n points"
-msgstr ""
+msgstr "Obviar los primeros n puntos"
 #: ../vector/v.decimate/main.c:183 ../vector/v.in.lidar/main.c:254
 msgid "Skips the given number of points at the beginning."
@@ -31082,11 +31082,11 @@
 #: ../vector/v.decimate/main.c:191
 msgid "Copy only n points"
-msgstr ""
+msgstr "Copiar solamente n puntos"
 #: ../vector/v.decimate/main.c:192
 msgid "Copies only the given number of points"
-msgstr ""
+msgstr "Copia solamente el número de puntos dado"
 #: ../vector/v.decimate/main.c:199
 msgid "Minimal difference of z values"
@@ -31100,7 +31100,7 @@
 #: ../vector/v.decimate/main.c:217 ../vector/v.decimate/main.c:223
 #: ../vector/v.decimate/main.c:228 ../vector/v.decimate/main.c:233
 msgid "Grid"
-msgstr ""
+msgstr "Grilla"
 #: ../vector/v.decimate/main.c:209
 msgid "Preserve only n points per grid cell"
@@ -31138,7 +31138,7 @@
 #: ../vector/v.in.lidar/main.c:303 ../vector/v.in.lidar/main.c:311
 #: ../vector/v.in.lidar/main.c:314
 msgid "Speed"
-msgstr ""
+msgstr "Velocidad"
 #: ../vector/v.decimate/main.c:274
 #, c-format
@@ -31149,7 +31149,7 @@
 #: ../vector/v.in.lidar/main.c:433
 #, c-format
 msgid "Invalid zrange <%s>"
-msgstr ""
+msgstr "rangoz no válido <%s>"
 #: ../vector/v.decimate/main.c:316
 msgid "Cannot use z for decimation, input is not 3D"
@@ -31282,7 +31282,7 @@
 #: ../vector/v.in.pdal/filters.c:46
 #, c-format
 msgid "4 values required for '%s' option"
-msgstr ""
+msgstr " Se requieren 4 valores para la opción '%s'"
 #: ../vector/v.in.pdal/projection.c:125
 msgid "Overriding projection check"
@@ -31629,7 +31629,7 @@
 #: ../vector/v.colors/main.c:116
 msgid "Name of color column to populate RGB values"
-msgstr ""
+msgstr "Nombre de la columna de color para poblar los valores RGB"
 #: ../vector/v.colors/main.c:117
 msgid "If not given writes color table"
@@ -32020,7 +32020,7 @@
 #: ../vector/v.generalize/main.c:102
 msgid "Lines and boundaries causing errors (collapsed to a point or topology errors)"
-msgstr ""
+msgstr "Líneas y contornos causan errores (colapsado a un punto o errores de topología)"
 #: ../vector/v.generalize/main.c:126
 msgid "Douglas-Peucker Algorithm"
@@ -32705,7 +32705,7 @@
 #: ../vector/v.net.iso/main.c:145 ../vector/v.net.iso/main.c:153
 #: ../vector/v.net.salesman/main.c:188 ../vector/v.net.salesman/main.c:195
 msgid "Relevant only with -t flag"
-msgstr ""
+msgstr "Relevante solamente con la bandera -t"
 #: ../vector/v.net.path/main.c:124 ../vector/v.net.alloc/main.c:143
 #: ../vector/v.net/args.c:114 ../vector/v.net.iso/main.c:151
@@ -32995,7 +32995,7 @@
 #: ../vector/v.in.lidar/vector_mask.c:20
 #, c-format
 msgid "Failed to open vector <%s>"
-msgstr ""
+msgstr "No ha sido posible abrir el vectorial <%s>"
 #: ../vector/v.in.lidar/attributes.c:129
 #, c-format
@@ -33022,7 +33022,7 @@
 #: ../vector/v.in.lidar/main.c:158 ../vector/v.in.lidar/main.c:166
 #: ../vector/v.in.lidar/main.c:174
 msgid "Leave empty to not store it"
-msgstr ""
+msgstr "Dejar vacío para no almacenar"
 #: ../vector/v.in.lidar/main.c:173
 msgid "Layer number where RBG colors are stored as category"
@@ -33038,7 +33038,7 @@
 #: ../vector/v.in.lidar/main.c:219
 msgid "Areas where to import points"
-msgstr ""
+msgstr "Áreas donde importar puntos"
 #: ../vector/v.in.lidar/main.c:220
 msgid "Name of vector map with areas where the points should be imported"
@@ -33046,15 +33046,15 @@
 #: ../vector/v.in.lidar/main.c:225
 msgid "Layer number or name for mask option"
-msgstr ""
+msgstr "Número de capa o nombre para la opción máscara"
 #: ../vector/v.in.lidar/main.c:233
 msgid "Do not import every n-th point"
-msgstr ""
+msgstr "No importar cada n puntos"
 #: ../vector/v.in.lidar/main.c:234
 msgid "For example, 5 will import 80 percent of points. If not specified, all points are imported"
-msgstr ""
+msgstr "Por ejemplo, 5 importará el 80% de los puntos. Si no se especifica, se importarán todos los puntos"
 #: ../vector/v.in.lidar/main.c:236 ../vector/v.in.lidar/main.c:246
 #: ../vector/v.in.lidar/main.c:255 ../vector/v.in.lidar/main.c:264
@@ -33067,15 +33067,15 @@
 #: ../vector/v.in.lidar/main.c:244
 msgid "For example, 4 will import 25 percent of points. If not specified, all points are imported"
-msgstr ""
+msgstr "Por ejemplo, 4 importará 25 porciento de los puntos. Si no se especifica, todos los puntos serán importados"
 #: ../vector/v.in.lidar/main.c:262
 msgid "Import only n points"
-msgstr ""
+msgstr "Importar solamente n puntos"
 #: ../vector/v.in.lidar/main.c:263
 msgid "Imports only the given number of points"
-msgstr ""
+msgstr "Importa solamente el número de puntos dado"
 #: ../vector/v.in.lidar/main.c:282 ../vector/v.in.ogr/main.c:298
 msgid "Limit import to the current region"
@@ -33133,12 +33133,12 @@
 #: ../vector/v.in.lidar/main.c:607
 #, c-format
 msgid "Scanning %llu points..."
-msgstr ""
+msgstr "Escaneando %llu puntos"
 #: ../vector/v.in.lidar/main.c:609
 #, c-format
 msgid "Scanning %lu points..."
-msgstr ""
+msgstr "Escaneando %lu puntos..."
 #: ../vector/v.in.lidar/main.c:744
 msgid "The underlying libLAS library is at its limits. Previously reported counts might have been distorted. However, the import itself should be unaffected."
@@ -33147,27 +33147,27 @@
 #: ../vector/v.in.lidar/main.c:750
 #, c-format
 msgid "%llu points imported (limit was %llu)"
-msgstr ""
+msgstr "%llu puntos importados (el límite era %llu)"
 #: ../vector/v.in.lidar/main.c:755
 #, c-format
 msgid "%llu points imported"
-msgstr ""
+msgstr "%llu puntos importados"
 #: ../vector/v.in.lidar/main.c:758
 #, c-format
 msgid "%llu input points were not valid and filtered out"
-msgstr ""
+msgstr "%llu puntos de entrada no fueron válidos y fueron dejados fuera"
 #: ../vector/v.in.lidar/main.c:760
 #, c-format
 msgid "%llu input points were outside of the selected area"
-msgstr ""
+msgstr "%llu puntos de entrada estuvieron fuera del área seleccionada"
 #: ../vector/v.in.lidar/main.c:762
 #, c-format
 msgid "%llu input points were outside of the area specified by mask"
-msgstr ""
+msgstr "%llu puntos de entrada estuvieron fuera del área especificada por la máscara"
 #: ../vector/v.in.lidar/main.c:764
 #, c-format
@@ -33197,22 +33197,22 @@
 #: ../vector/v.in.lidar/main.c:777
 #, c-format
 msgid "%lu points imported (limit was %d)"
-msgstr ""
+msgstr "%lu puntos importados (el límite era %d)"
 #: ../vector/v.in.lidar/main.c:781
 #, c-format
 msgid "%lu points imported"
-msgstr ""
+msgstr "%lu puntos importados"
 #: ../vector/v.in.lidar/main.c:785
 #, c-format
 msgid "%lu input points were outside of the selected area"
-msgstr ""
+msgstr "%lu puntos de entrada estuvieron fuera del área seleccionada"
 #: ../vector/v.in.lidar/main.c:787
 #, c-format
 msgid "%lu input points were outside of the area specified by mask"
-msgstr ""
+msgstr "%lu puntos de entrada estuvieron fuera del área especificada por la máscara"
 #: ../vector/v.in.lidar/main.c:793
 #, c-format
@@ -33235,7 +33235,7 @@
 #: ../vector/v.in.lidar/main.c:803
 msgid "The rest of points was ignored"
-msgstr ""
+msgstr "El resto de los puntos fue ignorado"
 #: ../vector/v.in.lidar/main.c:807
 #, c-format
@@ -34140,7 +34140,7 @@
 #: ../vector/v.net.alloc/main.c:266
 msgid "Calculating costs to centers ..."
-msgstr ""
+msgstr "Calculando costes a centros ..."
 #: ../vector/v.net.alloc/main.c:394 ../vector/v.net.alloc/main.c:406
 #: ../vector/v.net.iso/main.c:618
@@ -34895,7 +34895,7 @@
 #: ../vector/v.out.ogr/args.c:102
 msgid "Also export features without category (not labeled). Otherwise only features with category are exported."
-msgstr "Exportaar tambien elementos sin categoría (sin leyenda). De otro modo solamente se exportarán elementos con categoría."
+msgstr "Exportar también los elementos sin categoría (sin leyenda). De otro modo solamente se exportarán elementos con categoría."
 #: ../vector/v.out.ogr/args.c:108
 msgid "Use ESRI-style .prj file format (applies to Shapefile output only)"
@@ -35021,7 +35021,7 @@
 #: ../vector/v.mkgrid/main.c:74
 msgid "hexagon"
-msgstr ""
+msgstr "hexágono"
 #: ../vector/v.mkgrid/main.c:75
 msgid "Creates a vector map of a user-defined grid."
@@ -35827,7 +35827,7 @@
 #: ../vector/v.external/main.c:121
 msgid "No layer defined"
-msgstr ""
+msgstr "No hay capas definidas"
 #: ../vector/v.external/main.c:156
 #, c-format
@@ -36205,13 +36205,13 @@
 #: ../vector/v.lidar.edgedetection/main.c:94 ../vector/v.outlier/main.c:103
 #: ../vector/v.lidar.correction/main.c:101
 msgid "Length of each spline step in the east-west direction"
-msgstr "Longitud de cada paso de spline en la dirección este-oeste"
+msgstr ""
 #: ../vector/v.surf.bspline/main.c:158
 #: ../vector/v.lidar.edgedetection/main.c:103 ../vector/v.outlier/main.c:112
 #: ../vector/v.lidar.correction/main.c:110
 msgid "Length of each spline step in the north-south direction"
-msgstr "Longitud de cada paso de spline en la dirección norte-sud"
+msgstr ""
 #: ../vector/v.surf.bspline/main.c:207
 msgid "Choose either vector or raster output, not both"
@@ -36635,7 +36635,7 @@
 #: ../vector/v.random/main.c:102
 msgid "stratified random sampling"
-msgstr ""
+msgstr "muestreo aleatorio estratíficado"
 #: ../vector/v.random/main.c:103
 msgid "Generates random 2D/3D vector points."
@@ -37350,7 +37350,7 @@
 #: ../vector/v.patch/main.c:86
 msgid "Do not expect input with topology"
-msgstr ""
+msgstr "No esperar entrada con topología"
 #: ../vector/v.patch/main.c:88
 msgid "Applicable when input is points without topology"
@@ -37579,7 +37579,7 @@
 #: ../vector/v.net/turntable.c:554
 #, c-format
 msgid "Unable to read line from <%s>."
-msgstr ""
+msgstr "No se puede leer línea de <%s>"
 #: ../vector/v.net/turntable.c:448 ../vector/v.net/turntable.c:523
 msgid "Unable to insert data into turntable."
@@ -37588,12 +37588,12 @@
 #: ../vector/v.net/turntable.c:637
 #, c-format
 msgid "Unable to open vector map <%s>."
-msgstr ""
+msgstr "No se puede abrir el mapa vectorial <%s>."
 #: ../vector/v.net/turntable.c:642
 #, c-format
 msgid "Unable to create vector map <%s>."
-msgstr ""
+msgstr "No se puede crear el mapa vectorial <%s>."
 #: ../vector/v.net/turntable.c:655
 #, c-format
@@ -37617,7 +37617,7 @@
 #: ../vector/v.net/turntable.c:700
 #, c-format
 msgid "Unable to open database <%s> using driver <%s>"
-msgstr ""
+msgstr "No ha sido posible abrir base de datos <%s> usando el controlador <%s>"
 #: ../vector/v.net/turntable.c:715
 #, c-format
@@ -37632,7 +37632,7 @@
 #: ../vector/v.net/turntable.c:727
 #, c-format
 msgid "Unable to create index for column <%s> in table <%s>."
-msgstr ""
+msgstr "No ha sido posible crear índice para columna <%s> en tabla <%s>."
 #: ../vector/v.net/main.c:49
 msgid "network maintenance"
@@ -38013,7 +38013,7 @@
 #: ../vector/v.out.postgis/create.c:77
 #, c-format
 msgid "EPSG code defined for current location (%s) is overridden by %s"
-msgstr ""
+msgstr "Código EPSG definido para la localización actual (%s) es anulado por %s "
 #: ../vector/v.out.postgis/create.c:105
 #, c-format
@@ -38229,7 +38229,7 @@
 #: ../vector/v.to.rast/do_areas.c:84
 msgid "Failed to plot polygon"
-msgstr ""
+msgstr "No se pudo graficar el polígono"
 #: ../vector/v.to.rast/do_areas.c:118
 msgid "Area without centroid (OK for island)"
@@ -38357,7 +38357,7 @@
 #: ../vector/v.to.rast/support.c:392 ../vector/v.to.rast/support.c:433
 msgid "Different labels for the same value are not supported"
-msgstr ""
+msgstr "No está soportado el uso de etiquetas diferentes para el mismo valor"
 #: ../vector/v.build/main.c:39
 msgid "Creates topology for vector map."
@@ -38934,11 +38934,11 @@
 #: ../vector/v.db.select/main.c:61 ../vector/v.db.select/main.c:79
 #: ../vector/v.db.select/main.c:93
 msgid "Main"
-msgstr ""
+msgstr "Principal"
 #: ../vector/v.db.select/main.c:75
 msgid "GROUP BY conditions of SQL statement without 'group by' keyword"
-msgstr ""
+msgstr "Condiciones GROUP BY de sentencias SQL sin las palabras 'group by'"
 #: ../vector/v.db.select/main.c:83
 msgid "Output vertical record separator"
@@ -39389,7 +39389,7 @@
 #: ../vector/v.vol.rst/user1.c:270
 msgid "Strip exists with insufficient data"
-msgstr ""
+msgstr "Existe una franja con datos insuficientes"
 #: ../vector/v.vol.rst/user1.c:280
 msgid "Zero segments!"
@@ -39684,7 +39684,7 @@
 #: ../vector/v.outlier/main.c:95
 msgid "Name for vector map for visualization in QGIS"
-msgstr ""
+msgstr "Nombre de mapa vectorial para visualización en QGIS"
 #: ../vector/v.outlier/main.c:119
 msgid "Tykhonov regularization weight"
@@ -41506,6 +41506,9 @@
 msgid "Cluster identification"
 msgstr "Separación de clúster"
+msgid "Input file <%s> is not a LAS LiDAR point cloud"
+msgstr "Archivo de entrada <%s> no es nube de puntos LAS LiDAR"
 #~ msgid "Path to file location"
 #~ msgstr "Ruta a la localización del archivo"
@@ -41515,8 +41518,98 @@
 #~ msgid "Invalid value detected"
 #~ msgstr "Valor detectado no válido"
-#~ msgid "Input file <%s> is not a LAS LiDAR point cloud"
-#~ msgstr "Archivo de entrada <%s> no es nube de puntos LAS LiDAR"
 #~ msgid "eading the input map -%s- and -%s- and creating some temporary files..."
 #~ msgstr "leyendo mapa de entrada -%s y -%s- y creando algunos archivos temporales..."
+#~ msgid "3D raster"
+#~ msgstr "Ráster 3D"
+#~ msgid "Creates a 3D raster map from LAS LiDAR points"
+#~ msgstr "Crea un mapa ráster 3D a partir de puntos LAS LiDAR"
+#~ msgid "NDVI"
+#~ msgstr "NDVI"
+#~ msgid "SPOT"
+#~ msgstr "SPOT"
+#~ msgid "Include no data values"
+#~ msgstr "Incluir valores sin dato"
+#~ msgid "Assigns timestamps and registers raster, vector and raster3d maps in a space time dataset."
+#~ msgstr "Asigna estampa temporal y registra mapas ráster, vectoriales y ráster 3D en un conjunto de datos espacio temporal."
+#~ msgid "Format for absolute time: \"yyyy-mm-dd HH:MM:SS +HHMM\", relative time is of type integer."
+#~ msgstr "El formato para tiempo absoluto es \"yyyy-mm-dd HH:MM:SS +HHMM\", el tiempo relativo es de tipo entero."
+#~ msgid "Unit must be set in case of relative timestamps"
+#~ msgstr "La unidad debe ser definida en caso de marcas temporales relativas"
+#~ msgid "computational region"
+#~ msgstr "región computacional"
+#~ msgid "resolution"
+#~ msgstr "resolución"
+#~ msgid "level1"
+#~ msgstr "nivel1"
+#~ msgid "Topology not available for vector map <%s>. Registering primitives..."
+#~ msgstr "Topología de mapa vectorial <%s> no disponible. Registrando primitivas..."
+#~ msgid "Estimate point density and distance and quit"
+#~ msgstr "Estimar densidad de puntos y distancia y salir"
+#~ msgid "Estimated point density: %.4g\n"
+#~ msgstr "Densidad de puntos estimada: %.4g\n"
+#~ msgid "Subregion %d of %d"
+#~ msgstr "Subregión %d de %d"
+#~ msgid "Performing mean calculation..."
+#~ msgstr "Realizando el cálculo del promedio..."
+#~ msgid "Feature type '%s' not supported"
+#~ msgstr "Tipo de elemento '%s' no soportado"
+#~ msgid "Performing bilinear interpolation..."
+#~ msgstr "Realizando interpolación bilineal..."
+#~ msgid "Performing bicubic interpolation..."
+#~ msgstr "Realizando interpolación bicúbica..."
+#~ msgid "Point classification..."
+#~ msgstr "Clasificación de puntos..."
+#~ msgid "Name for output vector density map"
+#~ msgstr "Nombre para mapa vectorial de densidad de salida"
+#~ msgid "FFT is now complete"
+#~ msgstr "FFT ha finalizado"
+#~ msgid "Error in writing data"
+#~ msgstr "Error al escribir datos"
+#~ msgid "Invalid number of iterations, 100 will be used"
+#~ msgstr "La cantidad de iteraciones no es válida, se usarán 100"
+#~ msgid "Bands"
+#~ msgstr "Bandas"
+#~ msgid "The distance must be smaller than the size of the moving window"
+#~ msgstr "La distancia debe ser menor que el tamaño de la ventana móvil"
+#~ msgid "Pass #%d (of %d)..."
+#~ msgstr "Paso #%d (de %d)..."
+#~ msgid "%lu points found in input file(s)"
+#~ msgstr "%lu puntos encontrados en archivo(s) de entrada"
+#~ msgid "%lu points found in input file"
+#~ msgstr "%lu puntos encontrados en el archivo de entrada"
+#~ msgid "percentile"
+#~ msgstr "percentil"
+#~ msgid "Converting... "
+#~ msgstr "Convirtiendo..."
Modified: grass/trunk/locale/po/grassmods_fi.po
--- grass/trunk/locale/po/grassmods_fi.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grassmods_fi.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -1696,9 +1696,9 @@
 #: ../raster3d/r3.in.lidar/main.c:378 ../raster/r.in.lidar/main.c:401
 #: ../vector/v.in.lidar/main.c:352
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open file <%s> as a LiDAR point cloud"
-msgstr "Kursoria ei voida avata"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:382 ../raster/r.in.lidar/main.c:405
 #: ../vector/v.in.lidar/main.c:356
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grassmods_fr.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -620,7 +620,7 @@
 #: ../raster3d/r3.in.bin/main.c:154
 #, c-format
 msgid "Loading %s data with %i  bytes ...  (%dx%dx%d)"
-msgstr "Chargement des données %s avec %i octets ... (%dx%dx%dx)"
+msgstr "Chargement des données %d avec %i octets ... (%dx%dx%dx)"
 #: ../raster3d/r3.in.bin/main.c:202 ../raster3d/r3.neighbors/main.c:311
 msgid "Error flushing tiles"
@@ -1702,12 +1702,11 @@
 msgid "Input file <%s> does not exist"
 msgstr ""
-# c-format
-#, fuzzy, c-format
+#, c-format
-msgstr "Impossible d'ouvrir le fichier [%s] en lecture"
+msgstr ""
@@ -11768,7 +11767,7 @@
 #: ../raster/r.stats.quantile/main.c:454
 msgid "Writing output maps"
-msgstr ""
+msgstr "Écriture des cartes de sortie"
 #: ../raster/r.stats.quantile/main.c:518
 msgid "Compute category quantiles using two passes."
@@ -14103,7 +14102,7 @@
 #: ../raster/r.to.vect/main.c:80
 msgid "Converts a raster map into a vector map."
-msgstr ""
+msgstr "Convertit une carte matricielle en carte vectorielle."
 #: ../raster/r.to.vect/main.c:87
 #: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:7
@@ -14183,7 +14182,7 @@
 #: ../raster/r.to.vect/main.c:312
 msgid "Updating attributes..."
-msgstr ""
+msgstr "Mise à jour des attributs..."
 #: ../raster/r.to.vect/main.c:335
 #, c-format
@@ -14192,11 +14191,11 @@
 #: ../raster/r.to.vect/areas.c:122
 msgid "Extracting areas..."
-msgstr ""
+msgstr "Extraction des entités surfaciques..."
 #: ../raster/r.to.vect/lines.c:71
 msgid "Extracting lines..."
-msgstr ""
+msgstr "Extraction des lignes..."
 #: ../raster/r.to.vect/lines.c:504
 #, c-format
@@ -14240,7 +14239,7 @@
 #: ../raster/r.to.vect/areas_io.c:287
 msgid "Writing areas..."
-msgstr ""
+msgstr "Écriture des lignes..."
 #: ../raster/r.quantile/main.c:66
 msgid "Computing histogram"
@@ -16753,7 +16752,7 @@
 #: ../raster/r.in.poly/main.c:83
 msgid "Type doesn't exist"
-msgstr ""
+msgstr "Type n'existe pas"
 #: ../raster/r.out.ppm/main.c:56
 msgid "Converts a GRASS raster map to a PPM image file."
@@ -21177,7 +21176,7 @@
 msgid "Manages display frames on the user's graphics monitor."
-msgstr ""
+msgstr "Gère des cadres d'affichages sur le moniteur d'affichage de l'utilisateur"
 #: ../locale/scriptstrings/d.frame_to_translate.c:4
 #: ../locale/scriptstrings/d.redraw_to_translate.c:4
@@ -21188,31 +21187,31 @@
 msgid "frame"
-msgstr ""
+msgstr "cadre"
-msgstr ""
+msgstr "Créer un nouveau cadre et le sélectionner"
-msgstr ""
+msgstr "Effacer tous les cadres, effacer l'écran et sortir"
-msgstr ""
+msgstr "Afficher le nom du cadre actuel et sortir"
-msgstr ""
+msgstr "Afficher le nom de tous les cadres, y compris les positions 'at', et sortir"
 #: ../locale/scriptstrings/d.frame_to_translate.c:10
 msgid "Frame to be selected or created (if -c flag is given)"
-msgstr ""
+msgstr "Cadre à sélectionner ou à créer (si le drapeau -c est actif)"
 #: ../locale/scriptstrings/d.frame_to_translate.c:11
 msgid "Screen coordinates in percent where to place the frame (0,0 is lower-left)"
-msgstr ""
+msgstr "Coordonnées d'écran en pourcentage où placer le cadre (0,0 est en bas à gauche)"
Modified: grass/trunk/locale/po/grassmods_id_ID.po
--- grass/trunk/locale/po/grassmods_id_ID.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grassmods_id_ID.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -2,7 +2,7 @@
 # Copyright (C) 2017 GRASS Development Team
 # This file is distributed under the same license as the GRASS GIS package.
 # transifex generated, 2017
 msgid ""
 msgstr ""
 "Project-Id-Version: grasslibs_id_ID\n"
@@ -10,10 +10,10 @@
 "POT-Creation-Date: 2017-05-22 23:12-0700\n"
 "PO-Revision-Date: 2017-05-23 21:08+0200\n"
 "Language-Team: Indonesian (Indonesia) (https://www.transifex.com/grass-gis/teams/45198/id_ID/)\n"
+"Language: id_ID\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
-"Language: id_ID\n"
 "Plural-Forms: nplurals=1; plural=0;\n"
 #: ../raster3d/r3.flow/flowline.c:60 ../vector/v.to.points/write.c:52
@@ -272,14 +272,11 @@
 msgstr ""
 #: ../raster3d/r3.flow/main.c:193
-msgid ""
-"Names of three 3D raster maps describing x, y, z components of vector field"
+msgid "Names of three 3D raster maps describing x, y, z components of vector field"
 msgstr ""
 #: ../raster3d/r3.flow/main.c:200
-msgid ""
-"If no map is provided, flow lines are generated from each cell of the input "
-"3D raster"
+msgid "If no map is provided, flow lines are generated from each cell of the input 3D raster"
 msgstr ""
 #: ../raster3d/r3.flow/main.c:203
@@ -358,8 +355,7 @@
 msgstr ""
 #: ../raster3d/r3.flow/main.c:226
-msgid ""
-"Values of this 3D raster will be stored as attributes of flowlines segments"
+msgid "Values of this 3D raster will be stored as attributes of flowlines segments"
 msgstr ""
 #: ../raster3d/r3.flow/main.c:240
@@ -489,16 +485,15 @@
 #: ../vector/v.colors/main.c:262 ../vector/v.info/main.c:61
 #: ../vector/v.surf.rst/main.c:528 ../vector/v.surf.rst/main.c:632
 #: ../vector/v.to.3d/main.c:72 ../vector/v.db.select/main.c:164
-#: ../vector/v.lidar.correction/main.c:156
-#: ../vector/v.lidar.growing/main.c:138 ../vector/v.lidar.growing/main.c:142
-#: ../vector/v.net.allpairs/main.c:130 ../vector/v.net.connectivity/main.c:130
-#: ../vector/v.net.flow/main.c:143 ../vector/v.what.rast/main.c:131
-#: ../vector/v.drape/main.c:143 ../vector/v.build.polylines/main.c:151
-#: ../vector/v.normal/main.c:110 ../vector/v.out.postgis/main.c:100
-#: ../vector/v.out.svg/main.c:139 ../vector/v.delaunay/main.c:120
-#: ../vector/v.reclass/main.c:113 ../vector/v.net.centrality/main.c:209
-#: ../vector/v.select/main.c:108 ../vector/v.support/main.c:130
-#: ../vector/v.lidar.edgedetection/main.c:180
+#: ../vector/v.lidar.correction/main.c:156 ../vector/v.lidar.growing/main.c:138
+#: ../vector/v.lidar.growing/main.c:142 ../vector/v.net.allpairs/main.c:130
+#: ../vector/v.net.connectivity/main.c:130 ../vector/v.net.flow/main.c:143
+#: ../vector/v.what.rast/main.c:131 ../vector/v.drape/main.c:143
+#: ../vector/v.build.polylines/main.c:151 ../vector/v.normal/main.c:110
+#: ../vector/v.out.postgis/main.c:100 ../vector/v.out.svg/main.c:139
+#: ../vector/v.delaunay/main.c:120 ../vector/v.reclass/main.c:113
+#: ../vector/v.net.centrality/main.c:209 ../vector/v.select/main.c:108
+#: ../vector/v.support/main.c:130 ../vector/v.lidar.edgedetection/main.c:180
 #: ../vector/v.lrs/v.lrs.label/main.c:272
 #: ../vector/v.lrs/v.lrs.where/main.c:131
 #: ../vector/v.lrs/v.lrs.where/main.c:140
@@ -538,10 +533,10 @@
 #: ../display/d.vect.chart/main.c:246 ../display/d.extract/main.c:103
 #: ../misc/m.nviz.image/vector.c:280 ../raster/r.walk/main.c:673
 #: ../raster/r.walk/main.c:742 ../raster/r.drain/main.c:268
-#: ../raster/r.sim/simlib/observation_points.c:41
-#: ../raster/r.region/main.c:170 ../raster/r.random/support.c:63
-#: ../raster/r.what/main.c:237 ../raster/r.carve/main.c:162
-#: ../raster/r.cost/main.c:533 ../raster/r.cost/main.c:606
+#: ../raster/r.sim/simlib/observation_points.c:41 ../raster/r.region/main.c:170
+#: ../raster/r.random/support.c:63 ../raster/r.what/main.c:237
+#: ../raster/r.carve/main.c:162 ../raster/r.cost/main.c:533
+#: ../raster/r.cost/main.c:606
 #, c-format
 msgid "Unable to open vector map <%s>"
 msgstr ""
@@ -761,17 +756,16 @@
 #: ../raster3d/r3.timestamp/main.c:44 ../temporal/t.connect/main.c:36
 #: ../locale/scriptstrings/t.support_to_translate.c:3
 #: ../locale/scriptstrings/t.info_to_translate.c:3
-#: ../locale/scriptstrings/t.select_to_translate.c:3
-#: ../vector/v.info/main.c:38 ../vector/v.timestamp/main.c:36
-#: ../vector/v.support/main.c:40 ../raster/r.describe/main.c:55
-#: ../raster/r.info/main.c:71 ../raster/r.region/main.c:52
-#: ../raster/r.support/main.c:55 ../raster/r.timestamp/main.c:36
+#: ../locale/scriptstrings/t.select_to_translate.c:3 ../vector/v.info/main.c:38
+#: ../vector/v.timestamp/main.c:36 ../vector/v.support/main.c:40
+#: ../raster/r.describe/main.c:55 ../raster/r.info/main.c:71
+#: ../raster/r.region/main.c:52 ../raster/r.support/main.c:55
+#: ../raster/r.timestamp/main.c:36
 msgid "metadata"
 msgstr ""
 #: ../raster3d/r3.support/main.c:52
-msgid ""
-"Allows creation and/or modification of 3D raster map layer support files."
+msgid "Allows creation and/or modification of 3D raster map layer support files."
 msgstr ""
 #: ../raster3d/r3.support/main.c:62
@@ -916,9 +910,7 @@
 msgstr ""
 #: ../raster3d/r3.gradient/main.c:47
-msgid ""
-"Computes gradient of a 3D raster map and outputs gradient components as "
-"three 3D raster maps."
+msgid "Computes gradient of a 3D raster map and outputs gradient components as three 3D raster maps."
 msgstr ""
 #: ../raster3d/r3.gradient/main.c:56
@@ -1358,9 +1350,7 @@
 #: ../raster3d/r3.in.lidar/main.c:191 ../vector/v.in.lidar/main.c:214
 #: ../raster/r.in.lidar/main.c:269
-msgid ""
-"Input is comma separated integers. If not specified, all points are "
-"imported."
+msgid "Input is comma separated integers. If not specified, all points are imported."
 msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:199
@@ -1387,8 +1377,7 @@
 #: ../raster3d/r3.in.lidar/main.c:213 ../vector/v.in.lidar/main.c:295
 #: ../raster/r.in.lidar/main.c:339
-msgid ""
-"Points invalid according to APSRS LAS specification will be filtered out"
+msgid "Points invalid according to APSRS LAS specification will be filtered out"
 msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:230 ../general/g.pnmcomp/main.c:242
@@ -1510,9 +1499,7 @@
 msgstr ""
 #: ../raster3d/r3.mkdspf/main.c:83
-msgid ""
-"Creates a display file from an existing 3D raster map according to specified"
-" threshold levels."
+msgid "Creates a display file from an existing 3D raster map according to specified threshold levels."
 msgstr ""
 #: ../raster3d/r3.mkdspf/main.c:91
@@ -1615,9 +1602,7 @@
 msgstr ""
 #: ../raster3d/r3.to.rast/main.c:96
-msgid ""
-"Use the same resolution as the input 3D raster map for the 2D output maps, "
-"independent of the current region settings"
+msgid "Use the same resolution as the input 3D raster map for the 2D output maps, independent of the current region settings"
 msgstr ""
 #: ../raster3d/r3.to.rast/main.c:208 ../raster3d/r3.cross.rast/main.c:230
@@ -1682,9 +1667,8 @@
 #: ../raster/r.proj/main.c:144 ../raster/r.in.gdal/main.c:90
 #: ../raster/r.topmodel/main.c:51 ../raster/r.contour/main.c:87
 #: ../raster/r.sunhours/main.c:72 ../raster/r.quant/main.c:47
-#: ../raster/r.regression.line/main.c:46
-#: ../raster/r.param.scale/interface.c:54 ../raster/r.in.mat/main.c:91
-#: ../raster/r.li/r.li.padrange/padrange.c:53
+#: ../raster/r.regression.line/main.c:46 ../raster/r.param.scale/interface.c:54
+#: ../raster/r.in.mat/main.c:91 ../raster/r.li/r.li.padrange/padrange.c:53
 #: ../raster/r.li/r.li.cwed/cwed.c:54 ../raster/r.li/r.li.simpson/simpson.c:46
 #: ../raster/r.li/r.li.dominance/dominance.c:46
 #: ../raster/r.li/r.li.patchdensity/main.c:51
@@ -1694,26 +1678,26 @@
 #: ../raster/r.li/r.li.padsd/padsd.c:53 ../raster/r.li/r.li.patchnum/main.c:50
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:48
 #: ../raster/r.li/r.li.renyi/renyi.c:47 ../raster/r.li/r.li.mps/mps.c:52
-#: ../raster/r.li/r.li.shannon/shannon.c:46
-#: ../raster/r.resamp.interp/main.c:76 ../raster/r.category/main.c:52
-#: ../raster/r.his/main.c:67 ../raster/r.to.rast3/main.c:197
-#: ../raster/r.resamp.rst/main.c:148 ../raster/r.stats.zonal/main.c:101
-#: ../raster/r.relief/main.c:107 ../raster/r.neighbors/main.c:167
-#: ../raster/r.sunmask/main.c:116 ../raster/r.colors/edit_colors.c:63
-#: ../raster/r.drain/main.c:109 ../raster/r.latlong/main.c:56
-#: ../raster/r.support.stats/main.c:38 ../raster/r.texture/main.c:102
-#: ../raster/r.series/main.c:137 ../raster/r.profile/main.c:53
-#: ../raster/r.out.pov/main.c:121 ../raster/r.covar/main.c:51
-#: ../raster/r.out.vtk/main.c:59 ../raster/r.out.png/main.c:112
-#: ../raster/r.watershed/front/main.c:73 ../raster/r.to.rast3elev/main.c:361
-#: ../raster/r.grow.distance/main.c:152 ../raster/r.recode/main.c:48
-#: ../raster/r.in.ascii/main.c:69 ../raster/r.flow/main.c:421
-#: ../raster/r.regression.multi/main.c:128 ../raster/r.in.lidar/main.c:108
-#: ../raster/r.reclass/main.c:50 ../raster/r.tile/main.c:43
-#: ../raster/r.resamp.bspline/main.c:80 ../raster/r.mapcalc/main.c:69
-#: ../raster/r.in.xyz/main.c:158 ../raster/r.stats/main.c:106
-#: ../raster/r.ros/main.c:212 ../raster/r.info/main.c:70
-#: ../raster/r.volume/main.c:76 ../raster/r.sim/r.sim.water/main.c:113
+#: ../raster/r.li/r.li.shannon/shannon.c:46 ../raster/r.resamp.interp/main.c:76
+#: ../raster/r.category/main.c:52 ../raster/r.his/main.c:67
+#: ../raster/r.to.rast3/main.c:197 ../raster/r.resamp.rst/main.c:148
+#: ../raster/r.stats.zonal/main.c:101 ../raster/r.relief/main.c:107
+#: ../raster/r.neighbors/main.c:167 ../raster/r.sunmask/main.c:116
+#: ../raster/r.colors/edit_colors.c:63 ../raster/r.drain/main.c:109
+#: ../raster/r.latlong/main.c:56 ../raster/r.support.stats/main.c:38
+#: ../raster/r.texture/main.c:102 ../raster/r.series/main.c:137
+#: ../raster/r.profile/main.c:53 ../raster/r.out.pov/main.c:121
+#: ../raster/r.covar/main.c:51 ../raster/r.out.vtk/main.c:59
+#: ../raster/r.out.png/main.c:112 ../raster/r.watershed/front/main.c:73
+#: ../raster/r.to.rast3elev/main.c:361 ../raster/r.grow.distance/main.c:152
+#: ../raster/r.recode/main.c:48 ../raster/r.in.ascii/main.c:69
+#: ../raster/r.flow/main.c:421 ../raster/r.regression.multi/main.c:128
+#: ../raster/r.in.lidar/main.c:108 ../raster/r.reclass/main.c:50
+#: ../raster/r.tile/main.c:43 ../raster/r.resamp.bspline/main.c:80
+#: ../raster/r.mapcalc/main.c:69 ../raster/r.in.xyz/main.c:158
+#: ../raster/r.stats/main.c:106 ../raster/r.ros/main.c:212
+#: ../raster/r.info/main.c:70 ../raster/r.volume/main.c:76
+#: ../raster/r.sim/r.sim.water/main.c:113
 #: ../raster/r.sim/r.sim.sediment/main.c:113
 #: ../raster/r.series.accumulate/main.c:80 ../raster/r.out.gdal/main.c:136
 #: ../raster/r.spread/main.c:105 ../raster/r.out.gridatb/main.c:67
@@ -1755,9 +1739,7 @@
 msgstr ""
 #: ../raster3d/r3.to.rast/main.c:271 ../raster3d/r3.out.vtk/main.c:451
-msgid ""
-"The 2D and 3D region settings are different. Using the 2D window settings to"
-" adjust the 2D part of the 3D region."
+msgid "The 2D and 3D region settings are different. Using the 2D window settings to adjust the 2D part of the 3D region."
 msgstr ""
 #: ../raster3d/r3.to.rast/main.c:295 ../vector/v.generalize/matrix.c:144
@@ -1807,8 +1789,7 @@
 #: ../raster3d/r3.to.rast/main.c:308
 #, c-format
-msgid ""
-"Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
+msgid "Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
 msgstr ""
 #: ../raster3d/r3.neighbors/main.c:94 ../raster/r.neighbors/main.c:102
@@ -1827,9 +1808,7 @@
 msgstr ""
 #: ../raster3d/r3.neighbors/main.c:137
-msgid ""
-"The size of the window in x, y and z direction, values must be odd integer "
-"numbers, eg: 3,3,3"
+msgid "The size of the window in x, y and z direction, values must be odd integer numbers, eg: 3,3,3"
 msgstr ""
 #: ../raster3d/r3.neighbors/main.c:209
@@ -1872,9 +1851,7 @@
 msgstr ""
 #: ../raster3d/r3.neighbors/main.c:218
-msgid ""
-"Makes each voxel value a function of the values assigned to the voxels "
-"around it, and stores new voxel values in an output 3D raster map"
+msgid "Makes each voxel value a function of the values assigned to the voxels around it, and stores new voxel values in an output 3D raster map"
 msgstr ""
 #: ../raster3d/r3.neighbors/main.c:287
@@ -1890,27 +1867,19 @@
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:60
-msgid ""
-"Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - "
-"active, 2 - dirichlet"
+msgid "Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:65
-msgid ""
-"Input 3D raster map with the x-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Input 3D raster map with the x-part of the hydraulic conductivity tensor in [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:70
-msgid ""
-"Input 3D raster map with the y-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Input 3D raster map with the y-part of the hydraulic conductivity tensor in [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:75
-msgid ""
-"Input 3D raster map with the z-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Input 3D raster map with the z-part of the hydraulic conductivity tensor in [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:80
@@ -1926,32 +1895,23 @@
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:93
-msgid ""
-"Output 3D raster map storing the piezometric head result of the numerical "
-"calculation"
+msgid "Output 3D raster map storing the piezometric head result of the numerical calculation"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:99
-msgid ""
-"Output 3D raster map storing the groundwater filter velocity vector part in "
-"x direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in x direction [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:105
-msgid ""
-"y direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in y direction [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:111
-msgid ""
-"z direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in z direction [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:117
-msgid ""
-"Output 3D raster map storing the groundwater budget for each cell [m^3/s]"
+msgid "Output 3D raster map storing the groundwater budget for each cell [m^3/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:127
@@ -1959,9 +1919,7 @@
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:131 ../raster/r.solute.transport/main.c:192
-msgid ""
-"Use a full filled quadratic linear equation system, default is a sparse "
-"linear equation system."
+msgid "Use a full filled quadratic linear equation system, default is a sparse linear equation system."
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:160 ../raster/r.gwflow/main.c:209
@@ -1969,9 +1927,7 @@
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:163
-msgid ""
-"Numerical calculation program for transient, confined groundwater flow in "
-"three dimensions."
+msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions."
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:180
@@ -2021,9 +1977,7 @@
 msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:175
-msgid ""
-"No 3D raster data, RGB or xyz-vector maps are provided! Will only write the "
-"geometry."
+msgid "No 3D raster data, RGB or xyz-vector maps are provided! Will only write the geometry."
 msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:209
@@ -2079,14 +2033,11 @@
 msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:71
-msgid ""
-"Create 3D elevation output with a top and a bottom surface, both raster maps"
-" are required."
+msgid "Create 3D elevation output with a top and a bottom surface, both raster maps are required."
 msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:80
-msgid ""
-"Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
+msgid "Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
 msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:88
@@ -2112,15 +2063,12 @@
 msgid "Scale factor affects the origin"
 msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:123
-#: ../raster/r.out.vtk/parameters.c:128
+#: ../raster3d/r3.out.vtk/parameters.c:123 ../raster/r.out.vtk/parameters.c:128
 msgid "Correct the coordinates to match the VTK-OpenGL precision"
 msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:129
-msgid ""
-"Do not convert the top-bottom resolution in case of lat long projection to "
-"meters"
+msgid "Do not convert the top-bottom resolution in case of lat long projection to meters"
 msgstr ""
 #: ../raster3d/r3.out.vtk/writeVTKData.c:122
@@ -2133,9 +2081,7 @@
 #: ../raster3d/r3.out.vtk/writeVTKData.c:335
 #, c-format
-msgid ""
-"write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
-"ascii file"
+msgid "write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-ascii file"
 msgstr ""
 #: ../raster3d/r3.out.vtk/writeVTKData.c:441
@@ -2171,8 +2117,7 @@
 #: ../raster3d/r3.in.ascii/main.c:281
 #, c-format
-msgid ""
-"Data exists in input file after fully importing expected data.  [%.4f ...]"
+msgid "Data exists in input file after fully importing expected data.  [%.4f ...]"
 msgstr ""
 #: ../raster3d/r3.in.ascii/main.c:319
@@ -2201,15 +2146,11 @@
 msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:233
-msgid ""
-"Creates cross section 2D raster map from 3D raster map based on 2D elevation"
-" map"
+msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map"
 msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:259
-msgid ""
-"The 2D and 3D region settings are different. Using the 3D raster map "
-"settings to adjust the 2D region."
+msgid "The 2D and 3D region settings are different. Using the 3D raster map settings to adjust the 2D region."
 msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:302
@@ -2235,8 +2176,7 @@
 msgstr ""
 #: ../raster3d/r3.retile/main.c:99
-msgid ""
-"Retiles an existing 3D raster map with user defined x, y and z tile size."
+msgid "Retiles an existing 3D raster map with user defined x, y and z tile size."
 msgstr ""
 #: ../raster3d/r3.retile/main.c:135
@@ -2444,8 +2384,7 @@
 msgstr ""
 #: ../temporal/t.connect/main.c:38
-msgid ""
-"Prints/sets general temporal GIS database connection for current mapset."
+msgid "Prints/sets general temporal GIS database connection for current mapset."
 msgstr ""
 #: ../temporal/t.connect/main.c:42 ../db/db.connect/main.c:51
@@ -2589,9 +2528,8 @@
 msgstr ""
-#: ../locale/scriptstrings/d.redraw_to_translate.c:4
-#: ../display/d.mon/main.c:40 ../display/d.erase/main.c:31
-#: ../display/d.info/main.c:36
+#: ../locale/scriptstrings/d.redraw_to_translate.c:4 ../display/d.mon/main.c:40
+#: ../display/d.erase/main.c:31 ../display/d.info/main.c:36
 msgid "monitors"
 msgstr ""
@@ -2620,8 +2558,7 @@
 msgstr ""
-msgid ""
-"Screen coordinates in percent where to place the frame (0,0 is lower-left)"
+msgid "Screen coordinates in percent where to place the frame (0,0 is lower-left)"
 msgstr ""
 #: ../locale/scriptstrings/d.frame_to_translate.c:12
@@ -2812,9 +2749,7 @@
 msgstr ""
 #: ../locale/scriptstrings/d.what.rast_to_translate.c:1
-msgid ""
-"Allows the user to interactively query raster map layers at user-selected "
-"locations."
+msgid "Allows the user to interactively query raster map layers at user-selected locations."
 msgstr ""
 #: ../locale/scriptstrings/d.what.rast_to_translate.c:3
@@ -2879,8 +2814,7 @@
 #: ../vector/v.net.centrality/main.c:96 ../vector/v.select/main.c:48
 #: ../vector/v.support/main.c:39 ../vector/v.in.lidar/main.c:136
 #: ../vector/v.lidar.edgedetection/main.c:75
-#: ../vector/v.lrs/v.lrs.label/main.c:102
-#: ../vector/v.lrs/v.lrs.where/main.c:57
+#: ../vector/v.lrs/v.lrs.label/main.c:102 ../vector/v.lrs/v.lrs.where/main.c:57
 #: ../vector/v.lrs/v.lrs.create/main.c:121
 #: ../vector/v.lrs/v.lrs.segment/main.c:71 ../vector/v.to.db/main.c:36
 #: ../vector/v.out.dxf/main.c:56 ../vector/v.transform/main.c:69
@@ -2918,9 +2852,7 @@
 msgstr ""
 #: ../locale/scriptstrings/d.what.vect_to_translate.c:1
-msgid ""
-"Allows the user to interactively query vector map layers at user-selected "
-"locations."
+msgid "Allows the user to interactively query vector map layers at user-selected locations."
 msgstr ""
 #: ../locale/scriptstrings/db.dropcolumn_to_translate.c:1
@@ -3094,8 +3026,7 @@
 #: ../locale/scriptstrings/db.univar_to_translate.c:5
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:5
-msgid ""
-"Name of attribute column on which to calculate statistics (must be numeric)"
+msgid "Name of attribute column on which to calculate statistics (must be numeric)"
 msgstr ""
 #: ../locale/scriptstrings/db.univar_to_translate.c:6
@@ -3120,9 +3051,7 @@
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:2
-msgid ""
-"Downloads and installs extensions from GRASS Addons repository or other "
-"source into the local GRASS installation or removes installed extensions."
+msgid "Downloads and installs extensions from GRASS Addons repository or other source into the local GRASS installation or removes installed extensions."
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:3
@@ -3177,15 +3106,11 @@
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:11
-msgid ""
-"URL or directory to get the extension from (supported only on Linux and Mac)"
+msgid "URL or directory to get the extension from (supported only on Linux and Mac)"
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:12
-msgid ""
-"The official repository is used by default. User can specify a ZIP file, "
-"directory or a repository on common hosting services. If not identified, "
-"Subversion repository is assumed. See manual for all options."
+msgid "The official repository is used by default. User can specify a ZIP file, directory or a repository on common hosting services. If not identified, Subversion repository is assumed. See manual for all options."
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:13
@@ -3201,15 +3126,11 @@
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:17
-msgid ""
-"List available extensions in the official GRASS GIS Addons repository "
-"including module description"
+msgid "List available extensions in the official GRASS GIS Addons repository including module description"
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:19
-msgid ""
-"List available extensions in the official GRASS GIS Addons repository (shell"
-" script style)"
+msgid "List available extensions in the official GRASS GIS Addons repository (shell script style)"
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:21
@@ -3255,8 +3176,7 @@
 msgstr ""
 #: ../locale/scriptstrings/g.extension.all_to_translate.c:2
-msgid ""
-"By default only extensions built against different GIS Library are rebuilt."
+msgid "By default only extensions built against different GIS Library are rebuilt."
 msgstr ""
 #: ../locale/scriptstrings/g.extension.all_to_translate.c:7
@@ -3292,9 +3212,7 @@
 msgstr ""
 #: ../locale/scriptstrings/g.manual_to_translate.c:9
-msgid ""
-"Use online manuals available at http://grass.osgeo.org website. This flag "
-"has no effect when displaying MAN text pages."
+msgid "Use online manuals available at http://grass.osgeo.org website. This flag has no effect when displaying MAN text pages."
 msgstr ""
 #: ../locale/scriptstrings/g.manual_to_translate.c:10
@@ -3318,8 +3236,7 @@
 msgstr ""
 #: ../locale/scriptstrings/g.search.modules_to_translate.c:6
-msgid ""
-"Display only modules where all keywords are available (AND), default: OR"
+msgid "Display only modules where all keywords are available (AND), default: OR"
 msgstr ""
 #: ../locale/scriptstrings/g.search.modules_to_translate.c:8
@@ -3516,9 +3433,8 @@
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:6
 #: ../vector/v.db.select/main.c:95 ../db/db.select/main.c:241
 #: ../raster/r.stats/main.c:119 ../raster/r.quantile/main.c:297
-#: ../raster/r.univar/r.univar_main.c:41
-#: ../raster/r.univar/r3.univar_main.c:42 ../raster/r.what/main.c:125
-#: ../raster/r.stats.quantile/main.c:555
+#: ../raster/r.univar/r.univar_main.c:41 ../raster/r.univar/r3.univar_main.c:42
+#: ../raster/r.what/main.c:125 ../raster/r.stats.quantile/main.c:555
 msgid "Name for output file (if omitted or \"-\" output to stdout)"
 msgstr ""
@@ -3531,9 +3447,7 @@
 msgstr ""
 #: ../locale/scriptstrings/i.pansharpen_to_translate.c:1
-msgid ""
-"Image fusion algorithms to sharpen multispectral with high-res panchromatic "
-"channels"
+msgid "Image fusion algorithms to sharpen multispectral with high-res panchromatic channels"
 msgstr ""
 #: ../locale/scriptstrings/i.pansharpen_to_translate.c:3
@@ -3590,8 +3504,7 @@
 msgstr ""
 #: ../locale/scriptstrings/i.spectral_to_translate.c:1
-msgid ""
-"Displays spectral response at user specified locations in group or images."
+msgid "Displays spectral response at user specified locations in group or images."
 msgstr ""
 #: ../locale/scriptstrings/i.spectral_to_translate.c:3
@@ -3654,9 +3567,7 @@
 msgstr ""
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:7
-msgid ""
-"For Landsat4-7: bands 1, 2, 3, 4, 5, 7; for Landsat8: bands 2, 3, 4, 5, 6, "
-"7; for MODIS: bands 1, 2, 3, 4, 5, 6, 7"
+msgid "For Landsat4-7: bands 1, 2, 3, 4, 5, 7; for Landsat8: bands 2, 3, 4, 5, 6, 7; for MODIS: bands 1, 2, 3, 4, 5, 6, 7"
 msgstr ""
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:8
@@ -3669,11 +3580,7 @@
 msgstr ""
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:10
-msgid ""
-"landsat4_tm;Use transformation rules for Landsat 4 TM;landsat5_tm;Use "
-"transformation rules for Landsat 5 TM;landsat7_etm;Use transformation rules "
-"for Landsat 7 ETM;landsat8_oli;Use transformation rules for Landsat 8 "
-"OLI;modis;Use transformation rules for MODIS"
+msgid "landsat4_tm;Use transformation rules for Landsat 4 TM;landsat5_tm;Use transformation rules for Landsat 5 TM;landsat7_etm;Use transformation rules for Landsat 7 ETM;landsat8_oli;Use transformation rules for Landsat 8 OLI;modis;Use transformation rules for MODIS"
 msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:1
@@ -3709,12 +3616,12 @@
 msgid "Name of input coordinate file"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:8
-#: ../general/g.proj/main.c:141 ../general/g.proj/main.c:150
-#: ../vector/v.edit/args.c:89 ../vector/v.segment/main.c:80
-#: ../vector/v.what/main.c:76 ../db/db.execute/main.c:139
-#: ../db/db.select/main.c:208 ../raster/r.recode/main.c:61
-#: ../raster/r.in.ascii/main.c:79 ../raster/r.reclass/main.c:66
+#: ../locale/scriptstrings/m.proj_to_translate.c:8 ../general/g.proj/main.c:141
+#: ../general/g.proj/main.c:150 ../vector/v.edit/args.c:89
+#: ../vector/v.segment/main.c:80 ../vector/v.what/main.c:76
+#: ../db/db.execute/main.c:139 ../db/db.select/main.c:208
+#: ../raster/r.recode/main.c:61 ../raster/r.in.ascii/main.c:79
+#: ../raster/r.reclass/main.c:66
 msgid "'-' for standard input"
 msgstr ""
@@ -3750,9 +3657,7 @@
 msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:22
-msgid ""
-"Output long/lat in decimal degrees, or other projections with many decimal "
-"places"
+msgid "Output long/lat in decimal degrees, or other projections with many decimal places"
 msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:24
@@ -3794,9 +3699,7 @@
 #: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:1
 #: ../raster/r.buffer/main.c:69
-msgid ""
-"Creates a raster map showing buffer zones surrounding cells that contain "
-"non-NULL category values."
+msgid "Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values."
 msgstr ""
 #: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:2
@@ -3949,9 +3852,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.import_to_translate.c:1
-msgid ""
-"Imports raster data into a GRASS raster map using GDAL library and "
-"reprojects on the fly."
+msgid "Imports raster data into a GRASS raster map using GDAL library and reprojects on the fly."
 msgstr ""
 #: ../locale/scriptstrings/r.import_to_translate.c:5
@@ -3990,11 +3891,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.import_to_translate.c:14
-msgid ""
-"nearest;nearest neighbor;bilinear;bilinear interpolation;bicubic;bicubic "
-"interpolation;lanczos;lanczos filter;bilinear_f;bilinear interpolation with "
-"fallback;bicubic_f;bicubic interpolation with fallback;lanczos_f;lanczos "
-"filter with fallback"
+msgid "nearest;nearest neighbor;bilinear;bilinear interpolation;bicubic;bicubic interpolation;lanczos;lanczos filter;bilinear_f;bilinear interpolation with fallback;bicubic_f;bicubic interpolation with fallback;lanczos_f;lanczos filter with fallback"
 msgstr ""
 #: ../locale/scriptstrings/r.import_to_translate.c:16
@@ -4010,9 +3907,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.import_to_translate.c:20
-msgid ""
-"estimated;estimated resolution;value;user-specified "
-"resolution;region;current region resolution"
+msgid "estimated;estimated resolution;value;user-specified resolution;region;current region resolution"
 msgstr ""
 #: ../locale/scriptstrings/r.import_to_translate.c:22
@@ -4071,14 +3966,11 @@
 #: ../locale/scriptstrings/r.import_to_translate.c:32
 #: ../locale/scriptstrings/v.import_to_translate.c:28
 #: ../vector/v.in.ogr/main.c:286 ../vector/v.external/args.c:45
-msgid ""
-"Assume that the dataset has the same projection as the current location"
+msgid "Assume that the dataset has the same projection as the current location"
 msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:1
-msgid ""
-"Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
-"using gdalwarp."
+msgid "Georeference, rectify, and import Terra-ASTER imagery and relative DEMs using gdalwarp."
 msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:5
@@ -4095,14 +3987,11 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:9
-msgid ""
-"List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate "
-"all bands"
+msgid "List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate all bands"
 msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:10
-msgid ""
-"Base name for output raster map (band number will be appended to base name)"
+msgid "Base name for output raster map (band number will be appended to base name)"
 msgstr ""
 #: ../locale/scriptstrings/r.in.srtm_to_translate.c:1
@@ -4172,10 +4061,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:15
-msgid ""
-"WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using "
-"native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS "
-"driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;"
+msgid "WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;"
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:17
@@ -4207,8 +4093,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:30
-msgid ""
-"Request data for this named region instead of the current region bounds"
+msgid "Request data for this named region instead of the current region bounds"
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:32
@@ -4226,9 +4111,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:35
-msgid ""
-"Capabilities file to parse (input). It is relevant for WMTS_GRASS and "
-"OnEarth_GRASS drivers"
+msgid "Capabilities file to parse (input). It is relevant for WMTS_GRASS and OnEarth_GRASS drivers"
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:36
@@ -4301,8 +4184,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
-msgid ""
-"Exports a raster map to a text file as x,y,z values based on cell centers."
+msgid "Exports a raster map to a text file as x,y,z values based on cell centers."
 msgstr ""
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
@@ -4339,9 +4221,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.plane_to_translate.c:1
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
+msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
 msgstr ""
 #: ../locale/scriptstrings/r.plane_to_translate.c:4
@@ -4365,9 +4245,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
+msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
 msgstr ""
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
@@ -4425,8 +4303,7 @@
 msgid "Name of shaded raster map"
 msgstr ""
-#: ../locale/scriptstrings/r.shade_to_translate.c:12
-#: ../raster/r.his/main.c:121
+#: ../locale/scriptstrings/r.shade_to_translate.c:12 ../raster/r.his/main.c:121
 msgid "Color to use instead of NULL values"
 msgstr ""
@@ -4434,15 +4311,12 @@
 msgid "Either a standard color name, R:G:B triplet, or \"none\""
 msgstr ""
-#: ../locale/scriptstrings/r.shade_to_translate.c:14
-#: ../raster/r.his/main.c:126
+#: ../locale/scriptstrings/r.shade_to_translate.c:14 ../raster/r.his/main.c:126
 msgid "Use colors from color tables for NULL values"
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:1
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
+msgid "Produces tilings of the source projection for use in the destination region and projection."
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:4
@@ -4454,8 +4328,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:6
-msgid ""
-"Name of region to use instead of current region for bounds and resolution"
+msgid "Name of region to use instead of current region for bounds and resolution"
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:7
@@ -4488,8 +4361,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.unpack_to_translate.c:1
-msgid ""
-"Imports a raster map as GRASS GIS specific archive file (packed with r.pack)"
+msgid "Imports a raster map as GRASS GIS specific archive file (packed with r.pack)"
 msgstr ""
 #: ../locale/scriptstrings/r.unpack_to_translate.c:5
@@ -4526,9 +4398,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:1
-msgid ""
-"Create a 3D raster map from an assemblage of many coordinates using "
-"univariate statistics"
+msgid "Create a 3D raster map from an assemblage of many coordinates using univariate statistics"
 msgstr ""
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:6
@@ -4611,9 +4481,7 @@
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:29
 #: ../raster/r.in.lidar/main.c:243 ../raster/r.in.xyz/main.c:321
-msgid ""
-"Discard <trim> percent of the smallest and <trim> percent of the largest "
-"observations"
+msgid "Discard <trim> percent of the smallest and <trim> percent of the largest observations"
 msgstr ""
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:31
@@ -4663,9 +4531,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
+msgid "Adds one or more columns to the attribute table connected to a given vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
@@ -4679,15 +4545,11 @@
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:11
-msgid ""
-"Types depend on database backend, but all support VARCHAR(), INT, DOUBLE "
-"PRECISION and DATE. Example: 'label varchar(250), value integer'"
+msgid "Types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE. Example: 'label varchar(250), value integer'"
 msgstr ""
-msgid ""
-"Creates and connects a new attribute table to a given layer of an existing "
-"vector map."
+msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
@@ -4748,8 +4610,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
+msgid "Drops a column from the attribute table connected to a given vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
@@ -4757,8 +4618,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.droprow_to_translate.c:1
-msgid ""
-"Removes a vector feature from a vector map through attribute selection."
+msgid "Removes a vector feature from a vector map through attribute selection."
 msgstr ""
 #: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
@@ -4774,8 +4634,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:1
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
+msgid "Renames a column in the attribute table connected to a given vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:5
@@ -4783,9 +4642,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
-msgid ""
-"Reconnects attribute tables for all vector maps from the current mapset to a"
-" new database."
+msgid "Reconnects attribute tables for all vector maps from the current mapset to a new database."
 msgstr ""
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
@@ -4817,9 +4674,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:1
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector"
-" map."
+msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.update_to_translate.c:1
@@ -4835,20 +4690,15 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.update_to_translate.c:7
-msgid ""
-"Name of other attribute column to query, can be combination of columns (e.g."
-" co1+col2)"
+msgid "Name of other attribute column to query, can be combination of columns (e.g. co1+col2)"
 msgstr ""
 #: ../locale/scriptstrings/v.db.update_to_translate.c:8
-msgid ""
-"Name of SQLite extension file for extra functions (SQLite backend only)"
+msgid "Name of SQLite extension file for extra functions (SQLite backend only)"
 msgstr ""
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:1
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number"
-" or attribute."
+msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
 msgstr ""
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:3
@@ -4875,9 +4725,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.import_to_translate.c:1
-msgid ""
-"Imports vector data into a GRASS vector map using OGR library and reprojects"
-" on the fly."
+msgid "Imports vector data into a GRASS vector map using OGR library and reprojects on the fly."
 msgstr ""
 #: ../locale/scriptstrings/v.import_to_translate.c:5
@@ -4905,8 +4753,7 @@
 #: ../locale/scriptstrings/v.import_to_translate.c:15
 #: ../vector/v.in.ogr/main.c:235
-msgid ""
-"Overrides encoding interpretation, useful when importing ESRI Shapefile"
+msgid "Overrides encoding interpretation, useful when importing ESRI Shapefile"
 msgstr ""
 #: ../locale/scriptstrings/v.import_to_translate.c:17
@@ -5029,9 +4876,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:8
-msgid ""
-"The given code must be supported by the server, consult the capabilities "
-"file"
+msgid "The given code must be supported by the server, consult the capabilities file"
 msgstr ""
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:9
@@ -5051,9 +4896,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:13
-msgid ""
-"Download server capabilities to 'wms_capabilities.xml' in the current "
-"directory and exit"
+msgid "Download server capabilities to 'wms_capabilities.xml' in the current directory and exit"
 msgstr ""
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:14
@@ -5061,9 +4904,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
-msgid ""
-"Calculates univariate statistics from a raster map based on a vector map and"
-" uploads statistics to new attribute columns."
+msgid "Calculates univariate statistics from a raster map based on a vector map and uploads statistics to new attribute columns."
 msgstr ""
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
@@ -5147,8 +4988,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.unpack_to_translate.c:1
-msgid ""
-"Imports a vector map as GRASS GIS specific archive file (packed with v.pack)"
+msgid "Imports a vector map as GRASS GIS specific archive file (packed with v.pack)"
 msgstr ""
 #: ../locale/scriptstrings/v.unpack_to_translate.c:6
@@ -5160,9 +5000,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.what.strds_to_translate.c:1
-msgid ""
-"Uploads space time raster dataset values at positions of vector points to "
-"the table."
+msgid "Uploads space time raster dataset values at positions of vector points to the table."
 msgstr ""
 #: ../locale/scriptstrings/v.what.strds_to_translate.c:5
@@ -5178,9 +5016,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.what.strds_to_translate.c:10
-msgid ""
-"Instead of creating a new vector map update the attribute table with "
-"value(s)"
+msgid "Instead of creating a new vector map update the attribute table with value(s)"
 msgstr ""
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:1
@@ -5317,21 +5153,15 @@
 msgstr ""
 #: ../locale/scriptstrings/t.support_to_translate.c:11
-msgid ""
-"Update the metadata information and spatial extent of registered maps from "
-"the GRASS spatial database"
+msgid "Update the metadata information and spatial extent of registered maps from the GRASS spatial database"
 msgstr ""
 #: ../locale/scriptstrings/t.support_to_translate.c:12
-msgid ""
-"Check for removed maps and delete them from the temporal database and all "
-"effected space time datasets"
+msgid "Check for removed maps and delete them from the temporal database and all effected space time datasets"
 msgstr ""
 #: ../locale/scriptstrings/t.support_to_translate.c:13
-msgid ""
-"Update metadata information, temporal and spatial extent from registered "
-"maps based on database entries."
+msgid "Update metadata information, temporal and spatial extent from registered maps based on database entries."
 msgstr ""
 #: ../locale/scriptstrings/t.topology_to_translate.c:1
@@ -5347,8 +5177,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.list_to_translate.c:1
-msgid ""
-"Lists space time datasets and maps registered in the temporal database."
+msgid "Lists space time datasets and maps registered in the temporal database."
 msgstr ""
 #: ../locale/scriptstrings/t.list_to_translate.c:4
@@ -5365,9 +5194,7 @@
 #: ../locale/scriptstrings/t.list_to_translate.c:9
 #: ../locale/scriptstrings/t.list_to_translate.c:12
-msgid ""
-"Columns number_of_maps and granularity only available for space time "
-"datasets"
+msgid "Columns number_of_maps and granularity only available for space time datasets"
 msgstr ""
 #: ../locale/scriptstrings/t.list_to_translate.c:10
@@ -5436,9 +5263,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.info_to_translate.c:10
-msgid ""
-"Print history information in human readable shell style for space time "
-"datasets"
+msgid "Print history information in human readable shell style for space time datasets"
 msgstr ""
 #: ../locale/scriptstrings/t.info_to_translate.c:11
@@ -5455,8 +5280,7 @@
 msgid "time management"
 msgstr ""
-#: ../locale/scriptstrings/t.merge_to_translate.c:4
-#: ../raster/r.patch/main.c:61
+#: ../locale/scriptstrings/t.merge_to_translate.c:4 ../raster/r.patch/main.c:61
 msgid "merge"
 msgstr ""
@@ -5483,9 +5307,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.remove_to_translate.c:12
-msgid ""
-"Remove all registered maps from the temporal and also from the spatial "
-"database"
+msgid "Remove all registered maps from the temporal and also from the spatial database"
 msgstr ""
 #: ../locale/scriptstrings/t.remove_to_translate.c:13
@@ -5493,9 +5315,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.sample_to_translate.c:1
-msgid ""
-"Samples the input space time dataset(s) with a sample space time dataset and"
-" print the result to stdout."
+msgid "Samples the input space time dataset(s) with a sample space time dataset and print the result to stdout."
 msgstr ""
 #: ../locale/scriptstrings/t.sample_to_translate.c:5
@@ -5511,9 +5331,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.sample_to_translate.c:10
-msgid ""
-"Do not use \",\" as this char is reserved to list several map ids in a "
-"sample granule"
+msgid "Do not use \",\" as this char is reserved to list several map ids in a sample granule"
 msgstr ""
 #: ../locale/scriptstrings/t.sample_to_translate.c:12
@@ -5521,9 +5339,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:1
-msgid ""
-"Assigns timestamps and registers raster, vector and raster3d maps in a space"
-" time dataset."
+msgid "Assigns timestamps and registers raster, vector and raster3d maps in a space time dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:4
@@ -5550,9 +5366,7 @@
 #: ../locale/scriptstrings/t.register_to_translate.c:14
 #: ../locale/scriptstrings/t.register_to_translate.c:17
-msgid ""
-"Format for absolute time: \"yyyy-mm-dd HH:MM:SS +HHMM\", relative time is of"
-" type integer."
+msgid "Format for absolute time: \"yyyy-mm-dd HH:MM:SS +HHMM\", relative time is of type integer."
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:15
@@ -5580,10 +5394,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:23
-msgid ""
-"Time increment between maps for creation of valid time intervals (format for"
-" absolute time: NNN seconds, minutes, hours, days, weeks, months, years; "
-"format for relative time is of type integer: 5)"
+msgid "Time increment between maps for creation of valid time intervals (format for absolute time: NNN seconds, minutes, hours, days, weeks, months, years; format for relative time is of type integer: 5)"
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:25
@@ -5591,15 +5402,11 @@
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:27
-msgid ""
-"Create an interval (start and end time) in case an increment and the start "
-"time are provided"
+msgid "Create an interval (start and end time) in case an increment and the start time are provided"
 msgstr ""
 #: ../locale/scriptstrings/t.unregister_to_translate.c:1
-msgid ""
-"Unregisters raster, vector and raster3d maps from the temporal database or a"
-" specific space time dataset."
+msgid "Unregisters raster, vector and raster3d maps from the temporal database or a specific space time dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.unregister_to_translate.c:4
@@ -5621,15 +5428,11 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:6
-msgid ""
-"Input space time raster dataset that defines the lower threshold, values "
-"lower this threshold are excluded from accumulation"
+msgid "Input space time raster dataset that defines the lower threshold, values lower this threshold are excluded from accumulation"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:7
-msgid ""
-"Input space time raster dataset that defines the upper threshold, values "
-"upper this threshold are excluded from accumulation"
+msgid "Input space time raster dataset that defines the upper threshold, values upper this threshold are excluded from accumulation"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:8
@@ -5691,9 +5494,7 @@
 #: ../locale/scriptstrings/t.vect.extract_to_translate.c:7
 #: ../locale/scriptstrings/t.vect.algebra_to_translate.c:8
 #: ../locale/scriptstrings/t.vect.import_to_translate.c:7
-msgid ""
-"A numerical suffix separated by an underscore will be attached to create a "
-"unique identifier"
+msgid "A numerical suffix separated by an underscore will be attached to create a unique identifier"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:15
@@ -5706,16 +5507,11 @@
 #: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:10
 #: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:9
 #: ../locale/scriptstrings/t.vect.extract_to_translate.c:8
-msgid ""
-"Suffix to add at basename: set 'gran' for granularity, 'time' for the full "
-"time format, 'num' for numerical suffix with a specific number of digits "
-"(default %05)"
+msgid "Suffix to add at basename: set 'gran' for granularity, 'time' for the full time format, 'num' for numerical suffix with a specific number of digits (default %05)"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:16
-msgid ""
-"Use these limits in case lower and/or upper input  space time raster "
-"datasets are not defined or contain NULL values"
+msgid "Use these limits in case lower and/or upper input  space time raster datasets are not defined or contain NULL values"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:17
@@ -5727,22 +5523,16 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:19
-msgid ""
-"This method will be applied to compute the accumulative values from the "
-"input maps in a single granule"
+msgid "This method will be applied to compute the accumulative values from the input maps in a single granule"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:20
-msgid ""
-"Growing Degree Days or Winkler indices; Mean: sum(input maps)/(number of "
-"input maps); Biologically Effective Degree Days; Huglin Heliothermal index"
+msgid "Growing Degree Days or Winkler indices; Mean: sum(input maps)/(number of input maps); Biologically Effective Degree Days; Huglin Heliothermal index"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:21
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:19
-msgid ""
-"Register empty maps in the output space time raster dataset, otherwise they "
-"will be deleted"
+msgid "Register empty maps in the output space time raster dataset, otherwise they will be deleted"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:22
@@ -5751,72 +5541,47 @@
 msgstr ""
-msgid ""
-"Detects accumulation patterns in temporally accumulated space time raster "
-"datasets created by t.rast.accumulate."
+msgid "Detects accumulation patterns in temporally accumulated space time raster datasets created by t.rast.accumulate."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:6
-msgid ""
-"Input space time raster dataset that specifies the minimum values to detect "
-"the accumulation pattern"
+msgid "Input space time raster dataset that specifies the minimum values to detect the accumulation pattern"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:7
-msgid ""
-"Input space time raster dataset that specifies the maximum values to detect "
+msgid "Input space time raster dataset that specifies the maximum values to detect the accumulation pattern"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:8
-msgid ""
-"The output space time raster dataset that stores the occurrence of the the "
-"accumulation pattern using the provided data range"
+msgid "The output space time raster dataset that stores the occurrence of the the accumulation pattern using the provided data range"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:9
-msgid ""
-"The output space time raster dataset that stores the indication of the "
-"start, intermediate and end of the specified data range"
+msgid "The output space time raster dataset that stores the indication of the start, intermediate and end of the specified data range"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:16
-msgid ""
-"time format, 'count' for numerical suffix with a specific number of digits "
-"(default %05)"
+msgid "Suffix to add at basename: set 'gran' for granularity, 'time' for the full time format, 'count' for numerical suffix with a specific number of digits (default %05)"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:17
-msgid ""
-"The minimum and maximum value of the occurrence of accumulated values, these"
-" values will be used if the min/max space time raster datasets are not "
-"specified"
+msgid "The minimum and maximum value of the occurrence of accumulated values, these values will be used if the min/max space time raster datasets are not specified"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:18
-msgid ""
-"The user defined values that indicate start, intermediate and end status in "
-"the indicator output space time raster dataset"
+msgid "The user defined values that indicate start, intermediate and end status in the indicator output space time raster dataset"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:1
-msgid ""
-"Aggregates temporally the maps of a space time raster dataset by a user "
-"defined granularity."
+msgid "Aggregates temporally the maps of a space time raster dataset by a user defined granularity."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:7
-msgid ""
-"Either a numerical suffix or the start time (s-flag) separated by an "
-"underscore will be attached to create a unique identifier"
+msgid "Either a numerical suffix or the start time (s-flag) separated by an underscore will be attached to create a unique identifier"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:9
-msgid ""
-"Aggregation granularity, format absolute time \"x years, x months, x weeks, "
-"x days, x hours, x minutes, x seconds\" or an integer value for relative "
-"time"
+msgid "Aggregation granularity, format absolute time \"x years, x months, x weeks, x days, x hours, x minutes, x seconds\" or an integer value for relative time"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:10
@@ -5829,9 +5594,7 @@
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:11
 #: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:12
-msgid ""
-"Offset that is used to create the output map ids, output map id is generated"
-" as: basename_ (count + offset)"
+msgid "Offset that is used to create the output map ids, output map id is generated as: basename_ (count + offset)"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:12
@@ -5855,15 +5618,11 @@
 msgstr ""
-msgid ""
-"Aggregates data of an existing space time raster dataset using the time "
-"intervals of a second space time dataset."
+msgid "Aggregates data of an existing space time raster dataset using the time intervals of a second space time dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:6
-msgid ""
-"Time intervals from this space time dataset (raster, vector or raster3d) are"
-" used for aggregation computation"
+msgid "Time intervals from this space time dataset (raster, vector or raster3d) are used for aggregation computation"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:7
@@ -5878,9 +5637,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.colors_to_translate.c:1
-msgid ""
-"Creates/modifies the color table associated with each raster map of the "
-"space time raster dataset."
+msgid "Creates/modifies the color table associated with each raster map of the space time raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.colors_to_translate.c:6
@@ -5959,9 +5716,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:1
-msgid ""
-"Produces a space time vector dataset of specified contours from a space time"
-" raster dataset."
+msgid "Produces a space time vector dataset of specified contours from a space time raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:3
@@ -5994,9 +5749,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:15
-msgid ""
-"Number of r.contour processes to run in parallel, more than 1 process works "
-"only in conjunction with flag -t"
+msgid "Number of r.contour processes to run in parallel, more than 1 process works only in conjunction with flag -t"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:16
@@ -6014,9 +5767,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.univar_to_translate.c:1
-msgid ""
-"Calculates univariate statistics from the non-null cells for each registered"
-" raster map of a space time raster dataset."
+msgid "Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.univar_to_translate.c:9
@@ -6028,9 +5779,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.univar_to_translate.c:10
-msgid ""
-"Ignore the current region settings and use the raster map regions for univar"
-" statistical calculation"
+msgid "Ignore the current region settings and use the raster map regions for univar statistical calculation"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.univar_to_translate.c:11
@@ -6053,15 +5802,11 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.list_to_translate.c:13
-msgid ""
-"The granule to be used for listing. The granule must be specified as string "
-"eg.: absolute time \"1 months\" or relative time \"1\""
+msgid "The granule to be used for listing. The granule must be specified as string eg.: absolute time \"1 months\" or relative time \"1\""
 msgstr ""
 #: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:1
-msgid ""
-"Performs spatio-temporal mapcalc expressions on temporally sampled maps of "
-"space time raster datasets."
+msgid "Performs spatio-temporal mapcalc expressions on temporally sampled maps of space time raster datasets."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:6
@@ -6078,21 +5823,15 @@
 #: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:12
 #: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:11
 #: ../locale/scriptstrings/t.vect.algebra_to_translate.c:9
-msgid ""
-"Check the spatial topology of temporally related maps and process only "
-"spatially related maps"
+msgid "Check the spatial topology of temporally related maps and process only spatially related maps"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.algebra_to_translate.c:1
-msgid ""
-"Apply temporal and spatial operations on space time raster datasets using "
-"temporal raster algebra."
+msgid "Apply temporal and spatial operations on space time raster datasets using temporal raster algebra."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.algebra_to_translate.c:6
-msgid ""
-"r.mapcalc expression for temporal and spatial analysis of space time raster "
-"datasets"
+msgid "r.mapcalc expression for temporal and spatial analysis of space time raster datasets"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.algebra_to_translate.c:12
@@ -6102,15 +5841,11 @@
 #: ../locale/scriptstrings/t.rast.algebra_to_translate.c:13
 #: ../locale/scriptstrings/t.select_to_translate.c:9
-msgid ""
-"Perform a dry run, compute all dependencies and module calls but don't run "
-"them"
+msgid "Perform a dry run, compute all dependencies and module calls but don't run them"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:1
-msgid ""
-"Performs a neighborhood analysis for each map in a space time raster "
-"dataset."
+msgid "Performs a neighborhood analysis for each map in a space time raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:6
@@ -6127,9 +5862,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.series_to_translate.c:1
-msgid ""
-"Performs different aggregation algorithms from r.series on all or a subset "
-"of raster maps in a space time raster dataset."
+msgid "Performs different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.series_to_translate.c:4
@@ -6144,15 +5877,12 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.series_to_translate.c:9
-msgid ""
-"Do not assign the space time raster dataset start and end time to the output"
-" map"
+msgid "Do not assign the space time raster dataset start and end time to the output map"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.series_to_translate.c:10
 #: ../raster/r.resamp.filter/main.c:431 ../raster/r.series/main.c:187
-#: ../raster/r.series.accumulate/main.c:159
-#: ../raster/r.resamp.stats/main.c:288
+#: ../raster/r.series.accumulate/main.c:159 ../raster/r.resamp.stats/main.c:288
 msgid "Propagate NULLs"
 msgstr ""
@@ -6179,9 +5909,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.export_to_translate.c:10
-msgid ""
-"Supported are GTiff, AAIGrid via r.out.gdal and the GRASS package format of "
-"r.pack"
+msgid "Supported are GTiff, AAIGrid via r.out.gdal and the GRASS package format of r.pack"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.export_to_translate.c:11
@@ -6212,9 +5940,7 @@
 #: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:9
 #: ../raster/r.out.vtk/parameters.c:59
-msgid ""
-"Create VTK point data instead of VTK cell data (if no elevation map is "
-"given)"
+msgid "Create VTK point data instead of VTK cell data (if no elevation map is given)"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:10
@@ -6223,9 +5949,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:11
-msgid ""
-"Export files using the space time dataset granularity for equidistant time "
-"between maps, where statement will be ignored"
+msgid "Export files using the space time dataset granularity for equidistant time between maps, where statement will be ignored"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:1
@@ -6239,9 +5963,7 @@
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:11
 #: ../locale/scriptstrings/t.vect.import_to_translate.c:11
-msgid ""
-"Create a new location and import the data into it. Do not run this module in"
-" parallel or interrupt it when a new location should be created"
+msgid "Create a new location and import the data into it. Do not run this module in parallel or interrupt it when a new location should be created"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:14
@@ -6258,14 +5980,11 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:19
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not"
-" import the space time raster datasets."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the space time raster datasets."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:1
-msgid ""
-"Replaces gaps in a space time raster dataset with interpolated raster maps."
+msgid "Replaces gaps in a space time raster dataset with interpolated raster maps."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:9
@@ -6273,8 +5992,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:10
-msgid ""
-"Assign the space time raster dataset start and end time to the output map"
+msgid "Assign the space time raster dataset start and end time to the output map"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.extract_to_translate.c:1
@@ -6308,9 +6026,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:12
-msgid ""
-"Number of r.to.vect processes to run in parallel, more than 1 process works "
+msgid "Number of r.to.vect processes to run in parallel, more than 1 process works only in conjunction with flag -t"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:15
@@ -6344,9 +6060,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:1
-msgid ""
-"Sample a space time raster dataset at specific vector point coordinates and "
-"write the output to stdout using different layouts"
+msgid "Sample a space time raster dataset at specific vector point coordinates and write the output to stdout using different layouts"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:6
@@ -6358,9 +6072,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:9
-msgid ""
-"The layout of the output. One point per row (row), one point per column "
-"(col), all timsteps in one row (timerow)"
+msgid "The layout of the output. One point per row (row), one point per column (col), all timsteps in one row (timerow)"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:10
@@ -6403,9 +6115,7 @@
 msgstr ""
-msgid ""
-"Performs r3.mapcalc expressions on maps of sampled space time 3D raster "
-"datasets."
+msgid "Performs r3.mapcalc expressions on maps of sampled space time 3D raster datasets."
 msgstr ""
 #: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:7
@@ -6413,21 +6123,15 @@
 msgstr ""
-msgid ""
-"Apply temporal and spatial operations on space time 3D raster datasets using"
-" temporal 3D raster algebra."
+msgid "Apply temporal and spatial operations on space time 3D raster datasets using temporal 3D raster algebra."
 msgstr ""
 #: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:7
-msgid ""
-"Algebraic expression for temporal and spatial analysis of space time 3D "
-"raster datasets"
+msgid "Algebraic expression for temporal and spatial analysis of space time 3D raster datasets"
 msgstr ""
 #: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:1
-msgid ""
-" 3D raster map of a space time 3D raster dataset."
+msgid "Calculates univariate statistics from the non-null cells for each registered 3D raster map of a space time 3D raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rename_to_translate.c:1
@@ -6440,9 +6144,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.select_to_translate.c:1
-msgid ""
-"Select maps from space time datasets by topological relationships to other "
-"space time datasets using temporal algebra."
+msgid "Select maps from space time datasets by topological relationships to other space time datasets using temporal algebra."
 msgstr ""
 #: ../locale/scriptstrings/t.select_to_translate.c:7
@@ -6450,9 +6152,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.select_to_translate.c:8
-msgid ""
-"Check the spatial topology of temporally related maps and select only "
+msgid "Check the spatial topology of temporally related maps and select only spatially related maps"
 msgstr ""
 #: ../locale/scriptstrings/t.snap_to_translate.c:1
@@ -6481,9 +6181,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.shift_to_translate.c:10
-msgid ""
-"Format absolute time: \"x years, x months, x weeks, x days, x hours, x "
-"minutes, x seconds\", relative time is of type integer"
+msgid "Format absolute time: \"x years, x months, x weeks, x days, x hours, x minutes, x seconds\", relative time is of type integer"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.list_to_translate.c:1
@@ -6491,8 +6189,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.vect.db.select_to_translate.c:1
-msgid ""
-"Prints attributes of vector maps registered in a space time vector dataset."
+msgid "Prints attributes of vector maps registered in a space time vector dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.db.select_to_translate.c:6
@@ -6502,8 +6199,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.vect.export_to_translate.c:1
-msgid ""
-"Exports a space time vector dataset as GRASS GIS specific archive file."
+msgid "Exports a space time vector dataset as GRASS GIS specific archive file."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.export_to_translate.c:6
@@ -6523,9 +6219,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.vect.extract_to_translate.c:9
-msgid ""
-"The number of v.extract processes to run in parallel. Use only if database "
-"backend is used which supports concurrent writing"
+msgid "The number of v.extract processes to run in parallel. Use only if database backend is used which supports concurrent writing"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.extract_to_translate.c:10
@@ -6533,62 +6227,43 @@
 msgstr ""
 #: ../locale/scriptstrings/t.vect.algebra_to_translate.c:1
-msgid ""
-"Apply temporal and spatial operations on space time vector datasets using "
-"temporal vector algebra."
+msgid "Apply temporal and spatial operations on space time vector datasets using temporal vector algebra."
 msgstr ""
-msgid ""
-"Imports a space time vector dataset from a GRASS GIS specific archive file."
+msgid "Imports a space time vector dataset from a GRASS GIS specific archive file."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.import_to_translate.c:15
-msgid ""
-" import the space time vector datasets."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the space time vector datasets."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:1
-msgid ""
-"Stores raster map values at spatial and temporal positions of vector points "
-"as vector attributes."
+msgid "Stores raster map values at spatial and temporal positions of vector points as vector attributes."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:6
-msgid ""
-"Name of the vector column to be created and to store sampled raster values"
+msgid "Name of the vector column to be created and to store sampled raster values"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:7
-msgid ""
-"The use of a column name forces t.vect.what.rast to sample only values from "
-"the first map found in an interval. Otherwise the raster map names are used "
-"as column names"
+msgid "The use of a column name forces t.vect.what.rast to sample only values from the first map found in an interval. Otherwise the raster map names are used as column names"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:1
-msgid ""
-"Observes specific locations in a space time raster dataset over a period of "
-"time using vector points."
+msgid "Observes specific locations in a space time raster dataset over a period of time using vector points."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:6
-msgid ""
-"Name of the new created vector map that stores the sampled values in "
-"different layers"
+msgid "Name of the new created vector map that stores the sampled values in different layers"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:7
-msgid ""
-"Names of the vector columns to be created and to store sampled raster "
-"values, one name for each STRDS"
+msgid "Names of the vector columns to be created and to store sampled raster values, one name for each STRDS"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.univar_to_translate.c:1
-msgid ""
-"Calculates univariate statistics of attributes for each registered vector "
-"map of a space time vector dataset"
+msgid "Calculates univariate statistics of attributes for each registered vector map of a space time vector dataset"
 msgstr ""
 #: ../general/g.region/printwindow.c:236 ../general/g.region/printwindow.c:492
@@ -6631,15 +6306,11 @@
 msgstr ""
 #: ../general/g.region/printwindow.c:401
-msgid ""
-"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
-"the -p flag instead."
+msgid "You are in a simple XY location, projection to Lat/Lon is not possible. Use the -p flag instead."
 msgstr ""
 #: ../general/g.region/printwindow.c:626
-msgid ""
-"WGS84 output not possible as this location does not contain datum "
-"transformation parameters. Try running g.setproj."
+msgid "WGS84 output not possible as this location does not contain datum transformation parameters. Try running g.setproj."
 msgstr ""
 #: ../general/g.region/printwindow.c:772
@@ -6723,9 +6394,7 @@
 msgstr ""
 #: ../general/g.region/main.c:129
-msgid ""
-"The difference between the projection's grid north and true north, measured "
-"at the center coordinates of the current region."
+msgid "The difference between the projection's grid north and true north, measured at the center coordinates of the current region."
 msgstr ""
 #: ../general/g.region/main.c:135
@@ -6737,9 +6406,7 @@
 msgstr ""
 #: ../general/g.region/main.c:152
-msgid ""
-"Align region to resolution (default = align to bounds, works only for 2D "
-"resolution)"
+msgid "Align region to resolution (default = align to bounds, works only for 2D resolution)"
 msgstr ""
 #: ../general/g.region/main.c:158
@@ -6848,8 +6515,7 @@
 #: ../general/g.region/main.c:797 ../vector/v.vol.rst/main.c:615
 #: ../vector/v.colors/main.c:312 ../doc/raster/r.example/main.c:105
 #: ../imagery/i.gensigset/parse.c:44 ../imagery/i.gensig/parse.c:38
-#: ../imagery/i.pca/main.c:139
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:155
+#: ../imagery/i.pca/main.c:139 ../imagery/i.ortho.photo/i.ortho.elev/main.c:155
 #: ../misc/m.nviz.image/surface.c:50 ../misc/m.nviz.image/surface.c:107
 #: ../raster/r.walk/main.c:435 ../raster/r.walk/main.c:440
 #: ../raster/r.walk/main.c:801 ../raster/r.category/main.c:119
@@ -6941,8 +6607,7 @@
 msgstr ""
 #: ../general/g.region/main.c:821
-msgid ""
-"Unable to change default region. The current mapset is not <PERMANENT>."
+msgid "Unable to change default region. The current mapset is not <PERMANENT>."
 msgstr ""
 #: ../general/g.region/main.c:838 ../raster/r.in.lidar/main.c:519
@@ -6967,9 +6632,7 @@
 msgstr ""
 #: ../general/g.mapsets/main.c:67
-msgid ""
-"Affects the user's access to data existing under the other mapsets in the "
-"current location."
+msgid "Affects the user's access to data existing under the other mapsets in the current location."
 msgstr ""
 #: ../general/g.mapsets/main.c:73
@@ -7066,9 +6729,7 @@
 msgstr ""
 #: ../general/g.remove/main.c:73
-msgid ""
-"Removes data base element files from the user's current mapset using the "
-"search pattern."
+msgid "Removes data base element files from the user's current mapset using the search pattern."
 msgstr ""
 #: ../general/g.remove/main.c:83 ../general/g.remove/main.c:91
@@ -7134,9 +6795,7 @@
 #: ../general/g.remove/main.c:267
 #, c-format
-msgid ""
-"Nothing removed. You must use the force flag (-%c) to actually remove them. "
-"Exiting."
+msgid "Nothing removed. You must use the force flag (-%c) to actually remove them. Exiting."
 msgstr ""
 #: ../general/g.remove/construct_pattern.c:37
@@ -7170,8 +6829,7 @@
 msgstr ""
 #: ../general/g.message/main.c:37
-msgid ""
-"Prints a message, warning, progress info, or fatal error in the GRASS way."
+msgid "Prints a message, warning, progress info, or fatal error in the GRASS way."
 msgstr ""
 #: ../general/g.message/main.c:39
@@ -7246,9 +6904,7 @@
 msgstr ""
 #: ../general/g.mkfontcap/main.c:73
-msgid ""
-"Generates the font configuration file by scanning various directories for "
-"fonts."
+msgid "Generates the font configuration file by scanning various directories for fonts."
 msgstr ""
 #: ../general/g.mkfontcap/main.c:79
@@ -7256,8 +6912,7 @@
 msgstr ""
 #: ../general/g.mkfontcap/main.c:84
-msgid ""
-"Write font configuration file to standard output instead of $GISBASE/etc"
+msgid "Write font configuration file to standard output instead of $GISBASE/etc"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:91
@@ -7265,21 +6920,16 @@
 msgstr ""
 #: ../general/g.mkfontcap/main.c:93
-msgid ""
-"Comma-separated list of extra directories to scan for Freetype-compatible "
-"fonts as well as the defaults (see documentation)"
+msgid "Comma-separated list of extra directories to scan for Freetype-compatible fonts as well as the defaults (see documentation)"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:110
 #, c-format
-msgid ""
-"Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
+msgid "Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:122
-msgid ""
-"This GRASS installation was compiled without Freetype support, extradirs "
-"parameter ignored"
+msgid "This GRASS installation was compiled without Freetype support, extradirs parameter ignored"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:149
@@ -7317,9 +6967,7 @@
 #: ../general/g.findfile/main.c:97
 #, c-format
-msgid ""
-"Parameter 'file' contains reference to <%s> mapset, but mapset parameter "
-"<%s> does not correspond"
+msgid "Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%s> does not correspond"
 msgstr ""
 #: ../general/g.gisenv/main.c:45
@@ -7721,9 +7369,7 @@
 msgstr ""
 #: ../general/g.list/main.c:69
-msgid ""
-"Lists available GRASS data base files of the user-specified data type "
-"optionally using the search pattern."
+msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
 msgstr ""
 #: ../general/g.list/main.c:85
@@ -7825,10 +7471,7 @@
 msgstr ""
 #: ../general/g.gui/main.c:72
-msgid ""
-"By default the GUI starts in the background and control is immediately "
-"returned to the caller. When GUI runs in foregreound, it blocks the command "
-"line"
+msgid "By default the GUI starts in the background and control is immediately returned to the caller. When GUI runs in foregreound, it blocks the command line"
 msgstr ""
 #: ../general/g.gui/main.c:78
@@ -8014,10 +7657,7 @@
 msgstr ""
 #: ../general/g.setproj/main.c:456
-msgid ""
-"But if you change zone, all the existing data will be interpreted by "
-"projection software. GRASS will not automatically re-project or even change "
-"the headers for existing maps."
+msgid "But if you change zone, all the existing data will be interpreted by projection software. GRASS will not automatically re-project or even change the headers for existing maps."
 msgstr ""
 #: ../general/g.setproj/main.c:461
@@ -8148,9 +7788,7 @@
 msgstr ""
 #: ../general/g.copy/main.c:44
-msgid ""
-"Copies available data files in the current mapset search path to the user's "
-"current mapset."
+msgid "Copies available data files in the current mapset search path to the user's current mapset."
 msgstr ""
 #: ../general/g.copy/main.c:51
@@ -8246,16 +7884,11 @@
 #: ../general/g.proj/create.c:40
 #, c-format
-msgid ""
-"You must select the PERMANENT mapset before updating the current location's "
-"projection (current mapset is <%s>)"
+msgid "You must select the PERMANENT mapset before updating the current location's projection (current mapset is <%s>)"
 msgstr ""
 #: ../general/g.proj/create.c:66
-msgid ""
-"Default region was updated to the new projection, but if you have multiple "
-"mapsets `g.region -d` should be run in each to update the region from the "
-"default"
+msgid "Default region was updated to the new projection, but if you have multiple mapsets `g.region -d` should be run in each to update the region from the default"
 msgstr ""
 #: ../general/g.proj/create.c:70
@@ -8272,9 +7905,7 @@
 msgstr ""
 #: ../general/g.proj/main.c:69
-msgid ""
-"Prints or modifies GRASS projection information files (in various co-"
-"ordinate system descriptions)."
+msgid "Prints or modifies GRASS projection information files (in various co-ordinate system descriptions)."
 msgstr ""
 #: ../general/g.proj/main.c:72
@@ -8302,8 +7933,7 @@
 msgstr ""
 #: ../general/g.proj/main.c:106
-msgid ""
-"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
+msgid "Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
 msgstr ""
 #: ../general/g.proj/main.c:116
@@ -8349,9 +7979,7 @@
 msgstr ""
 #: ../general/g.proj/main.c:188
-msgid ""
-"Force override of datum transformation information in input co-ordinate "
-"system"
+msgid "Force override of datum transformation information in input co-ordinate system"
 msgstr ""
 #: ../general/g.proj/main.c:193 ../raster/r.null/main.c:74
@@ -8427,9 +8055,7 @@
 #: ../general/g.proj/input.c:259
 #, c-format
-msgid ""
-"Read of file %s was successful, but it did not contain projection "
-"information. 'XY (unprojected)' will be used"
+msgid "Read of file %s was successful, but it did not contain projection information. 'XY (unprojected)' will be used"
 msgstr ""
 #: ../general/g.proj/output.c:146
@@ -8505,15 +8131,11 @@
 #: ../general/g.version/main.c:172
 #, c-format
-msgid ""
-"Cannot determine GRASS libgis version and date number. The GRASS build might"
-" be broken. Report this to developers or packagers.\n"
+msgid "Cannot determine GRASS libgis version and date number. The GRASS build might be broken. Report this to developers or packagers.\n"
 msgstr ""
 #: ../general/g.version/main.c:179
-msgid ""
-"GRASS GIS libgis version and date number don't have the expected format. "
-"Trying to print the original strings..."
+msgid "GRASS GIS libgis version and date number don't have the expected format. Trying to print the original strings..."
 msgstr ""
 #: ../general/g.version/main.c:181
@@ -8543,8 +8165,7 @@
 msgstr ""
 #: ../general/g.mapset/main.c:52
-msgid ""
-"Optionally create new mapset or list available mapsets in given location."
+msgid "Optionally create new mapset or list available mapsets in given location."
 msgstr ""
 #: ../general/g.mapset/main.c:56
@@ -8607,8 +8228,7 @@
 msgstr ""
 #: ../general/g.mapset/main.c:205
-msgid ""
-"Mapset switched. Your shell continues to use the history for the old mapset"
+msgid "Mapset switched. Your shell continues to use the history for the old mapset"
 msgstr ""
 #: ../general/g.mapset/main.c:210
@@ -8726,9 +8346,7 @@
 msgstr ""
 #: ../vector/v.extract/extract.c:228
-msgid ""
-"Topology level required for extracting areas for OGR layers. Areas will be "
-"not processed."
+msgid "Topology level required for extracting areas for OGR layers. Areas will be not processed."
 msgstr ""
 #: ../vector/v.extract/main.c:81 ../vector/v.perturb/main.c:65
@@ -8739,9 +8357,7 @@
 msgstr ""
 #: ../vector/v.extract/main.c:83
-msgid ""
-"Selects vector features from an existing vector map and creates a new vector"
-" map containing only the selected features."
+msgid "Selects vector features from an existing vector map and creates a new vector map containing only the selected features."
 msgstr ""
 #: ../vector/v.extract/main.c:88
@@ -8798,9 +8414,7 @@
 #: ../vector/v.extract/main.c:161
 #, c-format
-msgid ""
-"Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only"
-" one of them."
+msgid "Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only one of them."
 msgstr ""
 #: ../vector/v.extract/main.c:208
@@ -8850,9 +8464,7 @@
 msgstr[0] ""
 #: ../vector/v.extract/main.c:286
-msgid ""
-"This map has no categories attached. Use v.category to attach categories to "
-"this vector map."
+msgid "This map has no categories attached. Use v.category to attach categories to this vector map."
 msgstr ""
 #: ../vector/v.extract/main.c:293
@@ -8861,16 +8473,12 @@
 #: ../vector/v.extract/main.c:297
 #, c-format
-msgid ""
-"Random category count must be smaller than feature count. There are only %d "
-"features of type(s): %s"
+msgid "Random category count must be smaller than feature count. There are only %d features of type(s): %s"
 msgstr ""
 #: ../vector/v.extract/main.c:320
 #, c-format
-msgid ""
-"Random category count is larger or equal to uniq <%s> feature category count"
-" %d"
+msgid "Random category count is larger or equal to uniq <%s> feature category count %d"
 msgstr ""
 #: ../vector/v.extract/main.c:354
@@ -8919,10 +8527,10 @@
 msgstr ""
 #: ../vector/v.generalize/network.c:89 ../vector/v.net.spanningtree/main.c:124
-#: ../vector/v.net.timetable/main.c:405
-#: ../vector/v.net.connectivity/main.c:178 ../vector/v.net.flow/main.c:226
-#: ../vector/v.net.centrality/main.c:284 ../vector/v.net.distance/main.c:264
-#: ../vector/v.net.bridge/main.c:134 ../vector/v.net.components/main.c:163
+#: ../vector/v.net.timetable/main.c:405 ../vector/v.net.connectivity/main.c:178
+#: ../vector/v.net.flow/main.c:226 ../vector/v.net.centrality/main.c:284
+#: ../vector/v.net.distance/main.c:264 ../vector/v.net.bridge/main.c:134
+#: ../vector/v.net.components/main.c:163
 #, c-format
 msgid "Unable to build graph for vector map <%s>"
 msgstr ""
@@ -8973,9 +8581,7 @@
 msgstr ""
 #: ../vector/v.generalize/main.c:102
-msgid ""
-"Lines and boundaries causing errors (collapsed to a point or topology "
-"errors)"
+msgid "Lines and boundaries causing errors (collapsed to a point or topology errors)"
 msgstr ""
 #: ../vector/v.generalize/main.c:126
@@ -9043,8 +8649,7 @@
 msgstr ""
 #: ../vector/v.generalize/main.c:164
-msgid ""
-"Percentage of the points in the output of 'douglas_reduction' algorithm"
+msgid "Percentage of the points in the output of 'douglas_reduction' algorithm"
 msgstr ""
 #: ../vector/v.generalize/main.c:173
@@ -9144,8 +8749,7 @@
 #: ../vector/v.generalize/main.c:567
 #, c-format
-msgid ""
-"%d boundaries were not modified because modification would damage topology"
+msgid "%d boundaries were not modified because modification would damage topology"
 msgstr ""
 #: ../vector/v.generalize/main.c:570
@@ -9155,8 +8759,7 @@
 #: ../vector/v.generalize/main.c:591
 #, c-format
-msgid ""
-"Number of vertices for selected features %s from %d to %d (%d%% remaining)"
+msgid "Number of vertices for selected features %s from %d to %d (%d%% remaining)"
 msgstr ""
 #: ../vector/v.generalize/main.c:592
@@ -9217,8 +8820,7 @@
 msgstr ""
 #: ../vector/v.net/args.c:42
-msgid ""
-"connect still unconnected points to vector network by inserting new line(s)"
+msgid "connect still unconnected points to vector network by inserting new line(s)"
 msgstr ""
 #: ../vector/v.net/args.c:44
@@ -9226,14 +8828,11 @@
 msgstr ""
 #: ../vector/v.net/args.c:46
-msgid ""
-"print to standard output {line_category start_point_category "
-"end_point_category}"
+msgid "print to standard output {line_category start_point_category end_point_category}"
 msgstr ""
 #: ../vector/v.net/args.c:48
-msgid ""
-"print to standard output {point_category line_category[,line_category...]}"
+msgid "print to standard output {point_category line_category[,line_category...]}"
 msgstr ""
 #: ../vector/v.net/args.c:50
@@ -9304,9 +8903,7 @@
 msgstr ""
 #: ../vector/v.net/args.c:99
-msgid ""
-"For operation 'connect'. By default, a new line from the point to the "
-"network is created."
+msgid "For operation 'connect'. By default, a new line from the point to the network is created."
 msgstr ""
 #: ../vector/v.net/args.c:103
@@ -9314,9 +8911,7 @@
 msgstr ""
 #: ../vector/v.net/args.c:106
-msgid ""
-"Layer where turntable will be attached. Format: layer number[/layer "
-"name].Required for operation 'turntable'."
+msgid "Layer where turntable will be attached. Format: layer number[/layer name].Required for operation 'turntable'."
 msgstr ""
 #: ../vector/v.net/args.c:114 ../vector/v.net.alloc/main.c:143
@@ -9326,10 +8921,7 @@
 msgstr ""
 #: ../vector/v.net/args.c:117
-msgid ""
-"Layer with unique categories for every line in arc_layer and point on every "
-"node.  The categories are used in turntable. Format: layer number[/layer "
-"name]. Required for operation 'turntable'."
+msgid "Layer with unique categories for every line in arc_layer and point on every node.  The categories are used in turntable. Format: layer number[/layer name]. Required for operation 'turntable'."
 msgstr ""
 #: ../vector/v.net/args.c:146
@@ -9511,9 +9103,7 @@
 msgstr ""
 #: ../vector/v.voronoi/main.c:127
-msgid ""
-"Creates a Voronoi diagram in current region from an input vector map "
-"containing points or centroids."
+msgid "Creates a Voronoi diagram in current region from an input vector map containing points or centroids."
 msgstr ""
 #: ../vector/v.voronoi/main.c:131 ../vector/v.sample/main.c:82
@@ -9526,9 +9116,7 @@
 msgstr ""
 #: ../vector/v.voronoi/main.c:142
-msgid ""
-"Applies to input areas only. Smaller values produce smoother output but can "
-"cause numerical instability."
+msgid "Applies to input areas only. Smaller values produce smoother output but can cause numerical instability."
 msgstr ""
 #: ../vector/v.voronoi/main.c:149
@@ -9536,9 +9124,7 @@
 msgstr ""
 #: ../vector/v.voronoi/main.c:150
-msgid ""
-"Applies only to skeleton extraction. Default = -1 will extract the center "
-"line."
+msgid "Applies only to skeleton extraction. Default = -1 will extract the center line."
 msgstr ""
 #: ../vector/v.voronoi/main.c:156
@@ -9621,9 +9207,7 @@
 msgstr[0] ""
 #: ../vector/v.distance/main.c:95
-msgid ""
-"Finds the nearest element in vector map 'to' for elements in vector map "
-"'from'."
+msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
 msgstr ""
 #: ../vector/v.distance/main.c:99
@@ -9665,8 +9249,7 @@
 msgstr ""
 #: ../vector/v.distance/main.c:134
-msgid ""
-"Name for output vector map containing lines connecting nearest elements"
+msgid "Name for output vector map containing lines connecting nearest elements"
 msgstr ""
 #: ../vector/v.distance/main.c:142
@@ -9698,14 +9281,11 @@
 msgstr ""
 #: ../vector/v.distance/main.c:173
-msgid ""
-"distance to the nearest point on the 'to' feature along that linear feature"
+msgid "distance to the nearest point on the 'to' feature along that linear feature"
 msgstr ""
 #: ../vector/v.distance/main.c:175
-msgid ""
-"angle along the nearest linear feature in the 'to' map, measured CCW from "
-"the +x axis, in radians, between -Pi and Pi inclusive"
+msgid "angle along the nearest linear feature in the 'to' map, measured CCW from the +x axis, in radians, between -Pi and Pi inclusive"
 msgstr ""
 #: ../vector/v.distance/main.c:178
@@ -9713,8 +9293,7 @@
 msgstr ""
 #: ../vector/v.distance/main.c:191
-msgid ""
-"Column name(s) where values specified by 'upload' option will be uploaded"
+msgid "Column name(s) where values specified by 'upload' option will be uploaded"
 msgstr ""
 #: ../vector/v.distance/main.c:197
@@ -9742,9 +9321,7 @@
 msgstr ""
 #: ../vector/v.distance/main.c:220
-msgid ""
-"Output is written to stdout but may be uploaded to a new table created by "
-"this module; multiple 'upload' options may be used."
+msgid "Output is written to stdout but may be uploaded to a new table created by this module; multiple 'upload' options may be used."
 msgstr ""
 #: ../vector/v.distance/main.c:284
@@ -10019,8 +9596,7 @@
 msgstr ""
 #: ../vector/v.edit/args.c:154
-msgid ""
-"For 'shorter' use negative threshold value, positive value for 'longer'"
+msgid "For 'shorter' use negative threshold value, positive value for 'longer'"
 msgstr ""
 #: ../vector/v.edit/args.c:160
@@ -10036,9 +9612,7 @@
 msgstr ""
 #: ../vector/v.edit/args.c:176
-msgid ""
-"Snap added or modified features in the given threshold to the nearest "
-"existing feature"
+msgid "Snap added or modified features in the given threshold to the nearest existing feature"
 msgstr ""
 #: ../vector/v.edit/args.c:182
@@ -10112,9 +9686,7 @@
 msgstr ""
 #: ../vector/v.edit/main.c:63
-msgid ""
-"Edits a vector map, allows adding, deleting and modifying selected vector "
-"features."
+msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
 msgstr ""
 #: ../vector/v.edit/main.c:72
@@ -10134,16 +9706,12 @@
 #: ../vector/v.edit/main.c:140
 #, c-format
-msgid ""
-"Unable to open vector map <%s> on topological level. Try to rebuild vector "
-"topology by v.build."
+msgid "Unable to open vector map <%s> on topological level. Try to rebuild vector topology by v.build."
 msgstr ""
 #: ../vector/v.edit/main.c:160
 #, c-format
-msgid ""
-"Unable to open vector map <%s> as the background map. It is given as vector "
-"map to be edited."
+msgid "Unable to open vector map <%s> as the background map. It is given as vector map to be edited."
 msgstr ""
 #: ../vector/v.edit/main.c:171
@@ -10165,9 +9733,7 @@
 #: ../vector/v.edit/main.c:234
 #, c-format
-msgid ""
-"Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert "
-"the vector map to 3D using e.g. %s."
+msgid "Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert the vector map to 3D using e.g. %s."
 msgstr ""
 #: ../vector/v.edit/main.c:276
@@ -10245,9 +9811,7 @@
 #: ../vector/v.edit/main.c:387
 #, c-format
-msgid ""
-"Multiple background maps were given. Selected features will be copied only "
-"from vector map <%s>."
+msgid "Multiple background maps were given. Selected features will be copied only from vector map <%s>."
 msgstr ""
 #: ../vector/v.edit/main.c:397
@@ -10349,9 +9913,7 @@
 msgstr ""
 #: ../vector/v.vol.rst/main.c:241
-msgid ""
-"Interpolates point data to a 3D raster map using regularized spline with "
-"tension (RST) algorithm."
+msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
 msgstr ""
 #: ../vector/v.vol.rst/main.c:246
@@ -10490,9 +10052,7 @@
 msgstr ""
 #: ../vector/v.vol.rst/main.c:491
-msgid ""
-"Crossvalidation cannot be computed simultanuously with output grids or devi "
-"file"
+msgid "Crossvalidation cannot be computed simultanuously with output grids or devi file"
 msgstr ""
 #: ../vector/v.vol.rst/main.c:507 ../vector/v.vol.rst/main.c:510
@@ -10553,9 +10113,7 @@
 #: ../vector/v.vol.rst/main.c:640
 #, c-format
-msgid ""
-"Unable to create <%s> raster map without cross_input raster map being "
-"specified"
+msgid "Unable to create <%s> raster map without cross_input raster map being specified"
 msgstr ""
 #: ../vector/v.vol.rst/main.c:818
@@ -10616,8 +10174,7 @@
 #: ../vector/v.univar/main.c:366 ../vector/v.sample/main.c:152
 #: ../vector/v.class/main.c:132 ../vector/v.to.rast3/main.c:95
 #: ../vector/v.surf.bspline/main.c:392 ../vector/v.surf.idw/read_sites.c:68
-#: ../ps/ps.map/catval.c:66 ../ps/ps.map/catval.c:131
-#: ../ps/ps.map/catval.c:198
+#: ../ps/ps.map/catval.c:66 ../ps/ps.map/catval.c:131 ../ps/ps.map/catval.c:198
 msgid "Unable to select data from table"
 msgstr ""
@@ -10630,8 +10187,7 @@
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:128
-msgid ""
-"Column type of smooth column is not supported (must be integer or double)"
+msgid "Column type of smooth column is not supported (must be integer or double)"
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:150
@@ -10669,29 +10225,22 @@
 #: ../vector/v.vol.rst/user1.c:311
 #, c-format
-msgid ""
-"There are points outside specified 2D/3D region--ignored %d points (total "
-"points: %d)"
+msgid "There are points outside specified 2D/3D region--ignored %d points (total points: %d)"
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:315
 #, c-format
-msgid ""
-"Points are more dense than specified 'DMIN'--ignored %d points (remain %d)"
+msgid "Points are more dense than specified 'DMIN'--ignored %d points (remain %d)"
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:321
 #, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given "
-"NPMIN=%d"
+msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:341
 #, c-format
-msgid ""
-"There is less than %d points for interpolation, no segmentation is "
-"necessary, to run the program faster, set segmax=%d (see manual)"
+msgid "There is less than %d points for interpolation, no segmentation is necessary, to run the program faster, set segmax=%d (see manual)"
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:368
@@ -10964,9 +10513,7 @@
 msgstr ""
 #: ../vector/v.vect.stats/main.c:187
-msgid ""
-"Column to hold points count, must be of type integer, will be created if not"
-" existing"
+msgid "Column to hold points count, must be of type integer, will be created if not existing"
 msgstr ""
 #: ../vector/v.vect.stats/main.c:194
@@ -10974,9 +10521,7 @@
 msgstr ""
 #: ../vector/v.vect.stats/main.c:196
-msgid ""
-"Column to hold statistics, must be of type double, will be created if not "
-"existing"
+msgid "Column to hold statistics, must be of type double, will be created if not existing"
 msgstr ""
 #: ../vector/v.vect.stats/main.c:203
@@ -11153,9 +10698,7 @@
 msgstr ""
 #: ../vector/v.out.lidar/main.c:572 ../vector/v.out.lidar/main.c:582
-msgid ""
-"This scale does not change the values itself but only how precisely they are"
-" stored, for example 0.01 will preserve two decimal places"
+msgid "This scale does not change the values itself but only how precisely they are stored, for example 0.01 will preserve two decimal places"
 msgstr ""
 #: ../vector/v.out.lidar/main.c:581
@@ -11237,10 +10780,7 @@
 msgstr ""
 #: ../vector/v.perturb/main.c:92
-msgid ""
-"If the distribution is uniform, only one parameter, the maximum, is needed. "
-"For a normal distribution, two parameters, the mean and standard deviation, "
-"are required."
+msgid "If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
 msgstr ""
 #: ../vector/v.perturb/main.c:102
@@ -11280,9 +10820,7 @@
 msgstr ""
 #: ../vector/v.qcount/main.c:72
-msgid ""
-"Name for output quadrat centers map (number of points is written as "
-"category)"
+msgid "Name for output quadrat centers map (number of points is written as category)"
 msgstr ""
 #: ../vector/v.qcount/main.c:78
@@ -11403,9 +10941,7 @@
 msgstr ""
 #: ../vector/v.colors/main.c:234
-msgid ""
-"Reading rules from standard input is not implemented yet, please provide "
-"path to rules file instead."
+msgid "Reading rules from standard input is not implemented yet, please provide path to rules file instead."
 msgstr ""
 #: ../vector/v.colors/main.c:244
@@ -11444,8 +10980,8 @@
 msgstr ""
 #: ../vector/v.colors/main.c:315 ../raster/r.colors/edit_colors.c:396
-#: ../raster/r.grow.distance/main.c:384
-#: ../raster/r.colors.out/raster_main.c:69 ../raster/r.fill.dir/main.c:153
+#: ../raster/r.grow.distance/main.c:384 ../raster/r.colors.out/raster_main.c:69
+#: ../raster/r.fill.dir/main.c:153
 #, c-format
 msgid "Unable to read color table for raster map <%s>"
 msgstr ""
@@ -11619,9 +11155,7 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:224
-msgid ""
-"List of column names to be used instead of original names, first is used for"
-" category column"
+msgid "List of column names to be used instead of original names, first is used for category column"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:243
@@ -11629,9 +11163,7 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:245
-msgid ""
-"If not given, categories are generated as unique values and stored in 'cat' "
-"column"
+msgid "If not given, categories are generated as unique values and stored in 'cat' column"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:250
@@ -11678,9 +11210,7 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:316 ../vector/v.in.lidar/main.c:328
-msgid ""
-" import the vector data."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the vector data."
 msgstr ""
 #: ../vector/v.in.ogr/main.c:334 ../vector/v.external/list.c:94
@@ -11696,16 +11226,12 @@
 #: ../vector/v.in.ogr/main.c:415
 #, c-format
-msgid ""
-"Option <%s> will be ignored. OGR doesn't support it for selected format "
-"(%s)."
+msgid "Option <%s> will be ignored. OGR doesn't support it for selected format (%s)."
 msgstr ""
 #: ../vector/v.in.ogr/main.c:420
 #, c-format
-msgid ""
-"Option <%s> will be ignored. Multiple geometry fields are supported by GDAL "
-">= 1.11"
+msgid "Option <%s> will be ignored. Multiple geometry fields are supported by GDAL >= 1.11"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:433
@@ -11739,9 +11265,7 @@
 #: ../vector/v.in.ogr/main.c:577 ../vector/v.in.lidar/main.c:507
 #: ../raster/r.in.gdal/main.c:437 ../raster/r.in.gdal/main.c:826
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location."
+msgid "Unable to convert input map projection to GRASS format; cannot create new location."
 msgstr ""
 #: ../vector/v.in.ogr/main.c:583 ../vector/v.in.lidar/main.c:513
@@ -11754,9 +11278,7 @@
 #: ../vector/v.external/proj.c:41 ../vector/v.in.pdal/projection.c:110
 #: ../vector/v.in.pdal/projection.c:156 ../vector/v.in.pdal/projection.c:189
 #: ../raster/r.in.lidar/projection.c:113
-msgid ""
-"Unable to convert input map projection information to GRASS format for "
-"checking"
+msgid "Unable to convert input map projection information to GRASS format for checking"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:620 ../vector/v.in.lidar/projection.c:126
@@ -11802,9 +11324,7 @@
 #: ../vector/v.in.ogr/main.c:695 ../vector/v.in.lidar/projection.c:93
 #: ../vector/v.external/proj.c:117 ../vector/v.in.pdal/projection.c:92
 #: ../raster/r.in.lidar/projection.c:95
-msgid ""
-"Consider generating a new location with 'location' parameter from input data"
-" set.\n"
+msgid "Consider generating a new location with 'location' parameter from input data set.\n"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:710 ../vector/v.in.lidar/projection.c:137
@@ -11835,8 +11355,7 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:792
-msgid ""
-"The 'spatial' parameters do not overlap with OGR input. Nothing to import."
+msgid "The 'spatial' parameters do not overlap with OGR input. Nothing to import."
 msgstr ""
 #: ../vector/v.in.ogr/main.c:826
@@ -11890,9 +11409,7 @@
 #: ../vector/v.in.ogr/main.c:1114
 #, c-format
-msgid ""
-"Width for column %s set to 255 (was not specified by OGR), some strings may "
-"be truncated!"
+msgid "Width for column %s set to 255 (was not specified by OGR), some strings may be truncated!"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:1126
@@ -11970,10 +11487,7 @@
 #: ../vector/v.in.ogr/main.c:1537
 #, c-format
-msgid ""
-"%d areas represent more (overlapping) features, because polygons overlap in "
-"input layer(s). Such areas are linked to more than 1 row in attribute table."
-" The number of features for those areas is stored as category in layer %d"
+msgid "%d areas represent more (overlapping) features, because polygons overlap in input layer(s). Such areas are linked to more than 1 row in attribute table. The number of features for those areas is stored as category in layer %d"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:1547
@@ -12084,9 +11598,7 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:1734
-msgid ""
-"Input data contains 3D features. Created vector is 2D only, disable -2 flag "
-"to import 3D vector."
+msgid "Input data contains 3D features. Created vector is 2D only, disable -2 flag to import 3D vector."
 msgstr ""
 #: ../vector/v.in.ogr/geom.c:76 ../vector/v.in.ogr/geom.c:261
@@ -12143,9 +11655,7 @@
 msgstr ""
 #: ../vector/v.info/parse.c:30
-msgid ""
-"Print types/names of table columns for specified layer instead of info and "
-"exit"
+msgid "Print types/names of table columns for specified layer instead of info and exit"
 msgstr ""
 #: ../vector/v.info/parse.c:35
@@ -12372,10 +11882,7 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:147
-msgid ""
-"Spatial approximation and topographic analysis from given point or isoline "
-"data in vector format to floating point raster format using regularized "
-"spline with tension."
+msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
 msgstr ""
 #: ../vector/v.surf.rst/main.c:154
@@ -12419,9 +11926,7 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:179 ../vector/v.surf.idw/main.c:102
-msgid ""
-"If not given and input is 2D vector map then category values are used. If "
-"input is 3D vector map then z-coordinates are used."
+msgid "If not given and input is 2D vector map then category values are used. If input is 3D vector map then z-coordinates are used."
 msgstr ""
 #: ../vector/v.surf.rst/main.c:189
@@ -12465,8 +11970,7 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:308
-msgid ""
-"Maximum distance between points on isoline (to insert additional points)"
+msgid "Maximum distance between points on isoline (to insert additional points)"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:317
@@ -12492,15 +11996,11 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:425
-msgid ""
-"Both cross-validation options (-c flag and cvdev vector output) must be "
-"specified"
+msgid "Both cross-validation options (-c flag and cvdev vector output) must be specified"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:428
-msgid ""
-"The cross-validation cannot be computed simultaneously with output raster or"
-" devi file"
+msgid "The cross-validation cannot be computed simultaneously with output raster or devi file"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:446
@@ -12516,9 +12016,7 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:541 ../vector/v.surf.bspline/main.c:272
-msgid ""
-"Input is 3D: using attribute values instead of z-coordinates for "
-"approximation"
+msgid "Input is 3D: using attribute values instead of z-coordinates for approximation"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:543 ../vector/v.surf.bspline/main.c:274
@@ -12535,9 +12033,7 @@
 #: ../vector/v.surf.rst/main.c:662
 #, c-format
-msgid ""
-"Processing all selected output files will require %d bytes of disk space for"
-" temp files"
+msgid "Processing all selected output files will require %d bytes of disk space for temp files"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:682
@@ -12691,8 +12187,7 @@
 msgstr ""
 #: ../vector/v.in.db/main.c:57
-msgid ""
-"Creates new vector (points) map from database table containing coordinates."
+msgid "Creates new vector (points) map from database table containing coordinates."
 msgstr ""
 #: ../vector/v.in.db/main.c:61
@@ -12735,15 +12230,12 @@
 #: ../vector/v.in.db/main.c:141
 #, c-format
-msgid ""
-"Vector map <%s> cannot be overwritten because input table <%s> is linked to "
-"this map."
+msgid "Vector map <%s> cannot be overwritten because input table <%s> is linked to this map."
 msgstr ""
 #: ../vector/v.in.db/main.c:177
 #, c-format
-msgid ""
-"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
+msgid "Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
 msgstr ""
 #: ../vector/v.in.db/main.c:190 ../vector/v.db.connect/main.c:295
@@ -12757,9 +12249,7 @@
 #: ../vector/v.in.db/main.c:199
 #, c-format
-msgid ""
-"Unable to define key column. This operation is not supported by <%s> driver."
-" You need to define <%s> option."
+msgid "Unable to define key column. This operation is not supported by <%s> driver. You need to define <%s> option."
 msgstr ""
 #: ../vector/v.in.db/main.c:225 ../display/d.vect.chart/plot.c:86
@@ -12822,9 +12312,7 @@
 msgstr ""
 #: ../vector/v.db.select/main.c:100
-msgid ""
-"Print minimal region extent of selected vector features instead of "
-"attributes"
+msgid "Print minimal region extent of selected vector features instead of attributes"
 msgstr ""
 #: ../vector/v.db.select/main.c:101 ../raster/r.in.gdal/main.c:198
@@ -12855,9 +12343,7 @@
 #: ../vector/v.db.select/main.c:157
 #, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Flag '%c' requires "
-"topology level."
+msgid "Unable to open vector map <%s> at topology level. Flag '%c' requires topology level."
 msgstr ""
 #: ../vector/v.db.select/main.c:208
@@ -12905,9 +12391,7 @@
 msgstr ""
 #: ../vector/v.lidar.correction/main.c:74
-msgid ""
-"Corrects the v.lidar.growing output. It is the last of the three algorithms "
-"for LIDAR filtering."
+msgid "Corrects the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
 msgstr ""
 #: ../vector/v.lidar.correction/main.c:78
@@ -12918,9 +12402,7 @@
 #: ../vector/v.lidar.correction/main.c:80
 #: ../vector/v.lidar.edgedetection/main.c:85
 #: ../vector/v.surf.bspline/main.c:107 ../vector/v.outlier/main.c:81
-msgid ""
-"Estimate point density and distance for the input vector points within the "
-"current region extends and quit"
+msgid "Estimate point density and distance for the input vector points within the current region extends and quit"
 msgstr ""
 #: ../vector/v.lidar.correction/main.c:85
@@ -12993,8 +12475,7 @@
 msgstr ""
 #: ../vector/v.lidar.correction/main.c:194
-#: ../vector/v.lidar.correction/main.c:230
-#: ../vector/v.lidar.growing/main.c:163
+#: ../vector/v.lidar.correction/main.c:230 ../vector/v.lidar.growing/main.c:163
 #: ../vector/v.lidar.edgedetection/main.c:221
 #: ../vector/v.lidar.edgedetection/main.c:233
 #: ../vector/v.lidar.edgedetection/main.c:255
@@ -13058,9 +12539,7 @@
 msgstr ""
 #: ../vector/v.lidar.growing/main.c:78
-msgid ""
-"Building contour determination and Region Growing algorithm for determining "
-"the building inside"
+msgid "Building contour determination and Region Growing algorithm for determining the building inside"
 msgstr ""
 #: ../vector/v.lidar.growing/main.c:83
@@ -13262,9 +12741,8 @@
 #: ../vector/v.what.rast/main.c:183 ../vector/v.sample/main.c:240
 #: ../vector/v.class/main.c:129 ../vector/v.to.rast3/main.c:99
-#: ../vector/v.surf.bspline/crosscorr.c:133
-#: ../vector/v.surf.bspline/main.c:389 ../vector/v.surf.idw/read_sites.c:65
-#: ../vector/v.buffer/main.c:434
+#: ../vector/v.surf.bspline/crosscorr.c:133 ../vector/v.surf.bspline/main.c:389
+#: ../vector/v.surf.idw/read_sites.c:65 ../vector/v.buffer/main.c:434
 msgid "Column type not supported"
 msgstr ""
@@ -13346,9 +12824,7 @@
 #: ../vector/v.drape/main.c:150 ../vector/v.random/main.c:208
 #: ../vector/v.buffer/main.c:348
 #, c-format
-msgid ""
-"Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer "
-"'1'."
+msgid "Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer '1'."
 msgstr ""
 #: ../vector/v.drape/main.c:177 ../vector/v.select/select.c:40
@@ -13694,14 +13170,11 @@
 msgstr ""
 #: ../vector/v.out.postgis/args.c:44
-msgid ""
-"Name for output vector map defined as a link to the PostGIS feature table"
+msgid "Name for output vector map defined as a link to the PostGIS feature table"
 msgstr ""
 #: ../vector/v.out.postgis/args.c:46
-msgid ""
-"If not specified, the vector link is not created. The link can be also "
-"manually created by 'v.external' module."
+msgid "If not specified, the vector link is not created. The link can be also manually created by 'v.external' module."
 msgstr ""
 #: ../vector/v.out.postgis/args.c:52 ../vector/v.external.out/args.c:39
@@ -13809,16 +13282,12 @@
 #: ../vector/v.out.postgis/table.c:50
 #, c-format
-msgid ""
-"Invalid FID column (%s). FID column must be integer. Please specify "
-"different FID column by 'options=\"FID=<name>\"'."
+msgid "Invalid FID column (%s). FID column must be integer. Please specify different FID column by 'options=\"FID=<name>\"'."
 msgstr ""
 #: ../vector/v.out.postgis/table.c:57
 #, c-format
-msgid ""
-"Column (%s) already exists in the table. Please specify different geometry "
-"column by 'options=\"GEOMETRY_NAME=<name>\"'."
+msgid "Column (%s) already exists in the table. Please specify different geometry column by 'options=\"GEOMETRY_NAME=<name>\"'."
 msgstr ""
 #: ../vector/v.out.svg/main.c:76
@@ -13909,9 +13378,7 @@
 msgstr ""
 #: ../vector/v.delaunay/main.c:88
-msgid ""
-"Creates a Delaunay triangulation from an input vector map containing points "
-"or centroids."
+msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
 msgstr ""
 #: ../vector/v.delaunay/main.c:103
@@ -14046,9 +13513,7 @@
 msgstr ""
 #: ../vector/v.reclass/main.c:71
-msgid ""
-"Changes vector category values for an existing vector map according to "
-"results of SQL queries or a value in attribute table column."
+msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
 msgstr ""
 #: ../vector/v.reclass/main.c:88
@@ -14147,9 +13612,7 @@
 msgstr ""
 #: ../vector/v.net.centrality/main.c:100
-msgid ""
-"Computes degree, centrality, betweeness, closeness and eigenvector "
-"centrality measures in the network."
+msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
 msgstr ""
 #: ../vector/v.net.centrality/main.c:148
@@ -14215,8 +13678,7 @@
 msgstr ""
 #: ../vector/v.select/main.c:52
-msgid ""
-"Selects features from vector map (A) by features from other vector map (B)."
+msgid "Selects features from vector map (A) by features from other vector map (B)."
 msgstr ""
 #: ../vector/v.select/main.c:85 ../vector/v.overlay/main.c:178
@@ -14275,10 +13737,7 @@
 msgstr ""
 #: ../vector/v.select/args.c:51
-msgid ""
-"A feature is written to output if the result of operation 'ainput operator "
-"binput' is true. An input feature is considered to be true, if category of "
-"given layer is defined."
+msgid "A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined."
 msgstr ""
 #: ../vector/v.select/args.c:59 ../vector/v.select/args.c:75
@@ -14318,9 +13777,7 @@
 msgstr ""
 #: ../vector/v.select/args.c:84
-msgid ""
-"feature A is spatially related to feature B (using GEOS, requires 'relate' "
-"option)"
+msgid "feature A is spatially related to feature B (using GEOS, requires 'relate' option)"
 msgstr ""
 #: ../vector/v.select/args.c:94
@@ -14382,8 +13839,7 @@
 msgstr ""
 #: ../vector/v.support/main.c:118
-msgid ""
-"Command line to store into vector map history file (used for vector scripts)"
+msgid "Command line to store into vector map history file (used for vector scripts)"
 msgstr ""
 #: ../vector/v.support/main.c:122
@@ -14397,9 +13853,7 @@
 #: ../vector/v.in.lidar/main.c:48
 #, c-format
-msgid ""
-"Values of %s and %s are the same. All categories would be stored only in "
-"layer number <%d>"
+msgid "Values of %s and %s are the same. All categories would be stored only in layer number <%d>"
 msgstr ""
 #: ../vector/v.in.lidar/main.c:141
@@ -14450,9 +13904,7 @@
 msgstr ""
 #: ../vector/v.in.lidar/main.c:236
-msgid ""
-"For example, 5 will import 80 percent of points. If not specified, all "
-"points are imported"
+msgid "For example, 5 will import 80 percent of points. If not specified, all points are imported"
 msgstr ""
 #: ../vector/v.in.lidar/main.c:238 ../vector/v.in.lidar/main.c:248
@@ -14465,9 +13917,7 @@
 msgstr ""
 #: ../vector/v.in.lidar/main.c:246
-msgid ""
-"For example, 4 will import 25 percent of points. If not specified, all "
+msgid "For example, 4 will import 25 percent of points. If not specified, all points are imported"
 msgstr ""
 #: ../vector/v.in.lidar/main.c:255 ../vector/v.decimate/main.c:183
@@ -14534,9 +13984,7 @@
 #: ../vector/v.in.lidar/main.c:425
 #, c-format
-msgid ""
-"Storing generated point IDs as categories in the layer <%d>, consequently no"
-" more than %d points can be imported"
+msgid "Storing generated point IDs as categories in the layer <%d>, consequently no more than %d points can be imported"
 msgstr ""
 #: ../vector/v.in.lidar/main.c:435 ../vector/v.decimate/main.c:294
@@ -14565,9 +14013,7 @@
 msgstr ""
 #: ../vector/v.in.lidar/main.c:746
-msgid ""
-"The underlying libLAS library is at its limits. Previously reported counts "
-"might have been distorted. However, the import itself should be unaffected."
+msgid "The underlying libLAS library is at its limits. Previously reported counts might have been distorted. However, the import itself should be unaffected."
 msgstr ""
 #: ../vector/v.in.lidar/main.c:752
@@ -14656,9 +14102,7 @@
 msgstr ""
 #: ../vector/v.in.lidar/main.c:802
-msgid ""
-"Accuracy of the printed point counts might be limited by your computer "
-"architecture."
+msgid "Accuracy of the printed point counts might be limited by your computer architecture."
 msgstr ""
 #: ../vector/v.in.lidar/main.c:805
@@ -14672,9 +14116,7 @@
 #: ../vector/v.in.lidar/main.c:818
 #, c-format
-msgid ""
-"Maximum number of categories reached (%d). Import ended prematurely. Try to "
-"import without using category as an ID."
+msgid "Maximum number of categories reached (%d). Import ended prematurely. Try to import without using category as an ID."
 msgstr ""
 #: ../vector/v.in.lidar/vector_mask.c:20
@@ -14768,8 +14210,7 @@
 msgid "Point classification..."
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:103
-#: ../vector/v.lrs/v.lrs.where/main.c:58
+#: ../vector/v.lrs/v.lrs.label/main.c:103 ../vector/v.lrs/v.lrs.where/main.c:58
 #: ../vector/v.lrs/v.lrs.create/main.c:122
 #: ../vector/v.lrs/v.lrs.segment/main.c:72
 msgid "linear reference system"
@@ -14779,8 +14220,7 @@
 msgid "Creates stationing from input lines, and linear reference system."
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:109
-#: ../vector/v.lrs/v.lrs.where/main.c:66
+#: ../vector/v.lrs/v.lrs.label/main.c:109 ../vector/v.lrs/v.lrs.where/main.c:66
 #: ../vector/v.lrs/v.lrs.create/main.c:128
 #: ../vector/v.lrs/v.lrs.segment/main.c:79
 msgid "Input vector map containing lines"
@@ -14790,22 +14230,19 @@
 msgid "Output vector map where stationing will be written"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:118
-#: ../vector/v.lrs/v.lrs.where/main.c:75
+#: ../vector/v.lrs/v.lrs.label/main.c:118 ../vector/v.lrs/v.lrs.where/main.c:75
 #: ../vector/v.lrs/v.lrs.create/main.c:147
 #: ../vector/v.lrs/v.lrs.segment/main.c:88
 msgid "Line layer"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:124
-#: ../vector/v.lrs/v.lrs.where/main.c:86
+#: ../vector/v.lrs/v.lrs.label/main.c:124 ../vector/v.lrs/v.lrs.where/main.c:86
 #: ../vector/v.lrs/v.lrs.create/main.c:207
 #: ../vector/v.lrs/v.lrs.segment/main.c:94
 msgid "Driver name for reference system table"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:132
-#: ../vector/v.lrs/v.lrs.where/main.c:94
+#: ../vector/v.lrs/v.lrs.label/main.c:132 ../vector/v.lrs/v.lrs.where/main.c:94
 #: ../vector/v.lrs/v.lrs.create/main.c:215
 #: ../vector/v.lrs/v.lrs.segment/main.c:102
 msgid "Database name for reference system table"
@@ -14911,9 +14348,7 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.where/main.c:61
-msgid ""
-"Finds line id and real km+offset for given points in vector map using linear"
-" reference system."
+msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
 msgstr ""
 #: ../vector/v.lrs/v.lrs.where/main.c:70
@@ -14989,8 +14424,7 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:182
-msgid ""
-"Column containing offset from milepost for the beginning of next segment"
+msgid "Column containing offset from milepost for the beginning of next segment"
 msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:191
@@ -15123,9 +14557,7 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.segment/main.c:75
-msgid ""
-"Creates points/segments from input lines, linear reference system and "
-"positions read from stdin or a file."
+msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
 msgstr ""
 #: ../vector/v.lrs/v.lrs.segment/main.c:83
@@ -15268,9 +14700,7 @@
 #: ../vector/v.to.db/main.c:48
 #, c-format
-msgid ""
-"Vector map <%s> not found in the current mapset. Unable to modify vector "
-"maps from different mapsets."
+msgid "Vector map <%s> not found in the current mapset. Unable to modify vector maps from different mapsets."
 msgstr ""
 #: ../vector/v.to.db/main.c:65 ../vector/v.to.db/query.c:83
@@ -15341,15 +14771,11 @@
 msgstr ""
 #: ../vector/v.to.db/parse.c:84
-msgid ""
-"categories of areas on the left and right side of the boundary, "
-"'query_layer' is used for area category"
+msgid "categories of areas on the left and right side of the boundary, 'query_layer' is used for area category"
 msgstr ""
 #: ../vector/v.to.db/parse.c:86
-msgid ""
-"result of a database query for all records of the geometry(or geometries) "
-"from table specified by 'query_layer' option"
+msgid "result of a database query for all records of the geometry(or geometries) from table specified by 'query_layer' option"
 msgstr ""
 #: ../vector/v.to.db/parse.c:88
@@ -15357,14 +14783,11 @@
 msgstr ""
 #: ../vector/v.to.db/parse.c:89
-msgid ""
-"line sinuousity, calculated as line length / distance between end points"
+msgid "line sinuousity, calculated as line length / distance between end points"
 msgstr ""
 #: ../vector/v.to.db/parse.c:90
-msgid ""
-"line azimuth, calculated as angle between North direction and endnode "
-"direction at startnode"
+msgid "line azimuth, calculated as angle between North direction and endnode direction at startnode"
 msgstr ""
 #: ../vector/v.to.db/parse.c:94
@@ -15450,9 +14873,7 @@
 #: ../vector/v.to.db/query.c:109
 #, c-format
-msgid ""
-"Query for category '0' (no category) was not executed because of too many "
-"(%d) query categories. All later reported values for cat 0 are not valid."
+msgid "Query for category '0' (no category) was not executed because of too many (%d) query categories. All later reported values for cat 0 are not valid."
 msgstr ""
 #: ../vector/v.to.db/query.c:146
@@ -15550,8 +14971,7 @@
 msgstr ""
 #: ../vector/v.transform/main.c:74
-msgid ""
-"Performs an affine transformation (shift, scale and rotate) on vector map."
+msgid "Performs an affine transformation (shift, scale and rotate) on vector map."
 msgstr ""
 #: ../vector/v.transform/main.c:79
@@ -15652,9 +15072,7 @@
 #: ../vector/v.transform/trans_digit.c:112
 #, c-format
-msgid ""
-"Unable to select value for category %d from table <%s>, column <%s>. For "
-"category %d using default transformation parameter %.3f."
+msgid "Unable to select value for category %d from table <%s>, column <%s>. For category %d using default transformation parameter %.3f."
 msgstr ""
 #: ../vector/v.transform/trans_digit.c:123
@@ -15666,13 +15084,11 @@
 msgstr ""
 #: ../vector/v.univar/main.c:99
-msgid ""
-"Variance and standard deviation is calculated only for points if specified."
+msgid "Variance and standard deviation is calculated only for points if specified."
 msgstr ""
 #: ../vector/v.univar/main.c:126 ../vector/v.what/main.c:98
-#: ../raster/r.univar/r.univar_main.c:61
-#: ../raster/r.univar/r3.univar_main.c:59
+#: ../raster/r.univar/r.univar_main.c:61 ../raster/r.univar/r3.univar_main.c:59
 msgid "Print the stats in shell script style"
 msgstr ""
@@ -15690,9 +15106,7 @@
 msgstr ""
 #: ../vector/v.univar/main.c:195
-msgid ""
-"Incompatible vector type(s) specified, only number of features, minimum, "
-"maximum and range can be calculated"
+msgid "Incompatible vector type(s) specified, only number of features, minimum, maximum and range can be calculated"
 msgstr ""
 #: ../vector/v.univar/main.c:200
@@ -15783,15 +15197,12 @@
 #: ../vector/v.db.connect/main.c:197
 #, c-format
-msgid ""
-"layer <%d/%s> table <%s> in database <%s> through driver <%s> with key "
-"<%s>\n"
+msgid "layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
 #: ../vector/v.db.connect/main.c:203
 #, c-format
-msgid ""
-"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgid "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
 #: ../vector/v.db.connect/main.c:266
@@ -15806,28 +15217,19 @@
 #: ../vector/v.db.connect/main.c:302 ../vector/v.db.connect/main.c:320
 #, c-format
-msgid ""
-"The table <%s> is now part of vector map <%s> and may be deleted or "
-"overwritten by GRASS modules"
+msgid "The table <%s> is now part of vector map <%s> and may be deleted or overwritten by GRASS modules"
 msgstr ""
 #: ../vector/v.db.connect/main.c:351
-msgid ""
-"For defining a new connection you have to specify these parameters: driver, "
-"database, table [, key [, layer]]"
+msgid "For defining a new connection you have to specify these parameters: driver, database, table [, key [, layer]]"
 msgstr ""
 #: ../vector/v.net.distance/main.c:69
-msgid ""
-"Computes shortest distance via the network between the given sets of "
-"features."
+msgid "Computes shortest distance via the network between the given sets of features."
 msgstr ""
 #: ../vector/v.net.distance/main.c:72
-msgid ""
-"Finds the shortest paths from each 'from' point to the nearest 'to' feature "
-"and various information about this relation are uploaded to the attribute "
-"table."
+msgid "Finds the shortest paths from each 'from' point to the nearest 'to' feature and various information about this relation are uploaded to the attribute table."
 msgstr ""
 #: ../vector/v.net.distance/main.c:100
@@ -15903,9 +15305,7 @@
 msgstr ""
 #: ../vector/v.decimate/main.c:133
-msgid ""
-"Copies points from one vector to another while applying different "
-"decimations"
+msgid "Copies points from one vector to another while applying different decimations"
 msgstr ""
 #: ../vector/v.decimate/main.c:161
@@ -15913,9 +15313,7 @@
 msgstr ""
 #: ../vector/v.decimate/main.c:163
-msgid ""
-"points are copied"
+msgid "For example, 5 will import 80 percent of points. If not specified, all points are copied"
 msgstr ""
 #: ../vector/v.decimate/main.c:165 ../vector/v.decimate/main.c:176
@@ -15928,9 +15326,7 @@
 msgstr ""
 #: ../vector/v.decimate/main.c:174
-msgid ""
+msgid "For example, 4 will import 25 percent of points. If not specified, all points are copied"
 msgstr ""
 #: ../vector/v.decimate/main.c:193
@@ -15960,9 +15356,7 @@
 msgstr ""
 #: ../vector/v.decimate/main.c:213
-msgid ""
-"Preserves only the given number of points per grid cell in grid-based "
-"decimation"
+msgid "Preserves only the given number of points per grid cell in grid-based decimation"
 msgstr ""
 #: ../vector/v.decimate/main.c:218
@@ -15991,9 +15385,7 @@
 #: ../vector/v.decimate/main.c:276
 #, c-format
-msgid ""
-"Input layer must be set to a particular layer, not <%s>, when using <%s> "
-"option or <-%c> flag"
+msgid "Input layer must be set to a particular layer, not <%s>, when using <%s> option or <-%c> flag"
 msgstr ""
 #: ../vector/v.decimate/main.c:318
@@ -16005,9 +15397,7 @@
 msgstr ""
 #: ../vector/v.decimate/main.c:350
-msgid ""
-"Settings for count-based decimation would cause it to do nothing and no "
-"other options has been set."
+msgid "Settings for count-based decimation would cause it to do nothing and no other options has been set."
 msgstr ""
 #: ../vector/v.sample/main.c:79
@@ -16265,8 +15655,7 @@
 msgstr ""
 #: ../vector/v.label/main.c:251
-msgid ""
-"size and space options vary significantly which may lead to crummy output"
+msgid "size and space options vary significantly which may lead to crummy output"
 msgstr ""
 #: ../vector/v.label/main.c:259
@@ -16303,9 +15692,7 @@
 msgstr ""
 #: ../vector/v.out.pov/main.c:75
-msgid ""
-"This string is appended to each z coordinate. Examples: '*10', '+1000', "
-"'*10+100', '*exaggeration'"
+msgid "This string is appended to each z coordinate. Examples: '*10', '+1000', '*10+100', '*exaggeration'"
 msgstr ""
 #: ../vector/v.out.pov/main.c:82
@@ -16361,9 +15748,7 @@
 msgstr ""
 #: ../vector/v.category/main.c:119
-msgid ""
-"copy values from one layer to another (e.g. layer=1,2,3 copies values from "
-"layer 1 to layer 2 and 3)"
+msgid "copy values from one layer to another (e.g. layer=1,2,3 copies values from layer 1 to layer 2 and 3)"
 msgstr ""
 #: ../vector/v.category/main.c:120
@@ -16371,9 +15756,7 @@
 msgstr ""
 #: ../vector/v.category/main.c:121
-msgid ""
-"print category values, layers are separated by '|', more cats in the same "
-"layer are separated by '/'"
+msgid "print category values, layers are separated by '|', more cats in the same layer are separated by '/'"
 msgstr ""
 #: ../vector/v.category/main.c:122
@@ -16393,15 +15776,11 @@
 msgstr ""
 #: ../vector/v.category/main.c:160
-msgid ""
-"Database connection and attribute tables for concerned layers are not "
-"changed"
+msgid "Database connection and attribute tables for concerned layers are not changed"
 msgstr ""
 #: ../vector/v.category/main.c:208
-msgid ""
-"Invalid category number (must be equal to or greater than 0). Normally "
-"category number starts at 1."
+msgid "Invalid category number (must be equal to or greater than 0). Normally category number starts at 1."
 msgstr ""
 #: ../vector/v.category/main.c:217
@@ -16526,8 +15905,7 @@
 msgstr ""
 #: ../vector/v.to.rast/main.c:122
-msgid ""
-"All cells touched by the line will be set, not only those on the render path"
+msgid "All cells touched by the line will be set, not only those on the render path"
 msgstr ""
 #: ../vector/v.to.rast/main.c:132
@@ -16613,9 +15991,7 @@
 msgstr ""
 #: ../vector/v.to.rast/vect2rast.c:137
-msgid ""
-"Area conversion and line densification are mutually exclusive, disabling "
-"line densification."
+msgid "Area conversion and line densification are mutually exclusive, disabling line densification."
 msgstr ""
 #: ../vector/v.to.rast/vect2rast.c:152
@@ -16853,9 +16229,7 @@
 msgstr ""
 #: ../vector/v.net.alloc/main.c:63
-msgid ""
-"center node must be opened (costs >= 0). Costs of center node are used in "
-"calculation"
+msgid "center node must be opened (costs >= 0). Costs of center node are used in calculation"
 msgstr ""
 #: ../vector/v.net.alloc/main.c:76
@@ -16863,9 +16237,7 @@
 msgstr ""
 #: ../vector/v.net.alloc/main.c:83 ../vector/v.net.iso/main.c:89
-msgid ""
-"Categories of centers (points on nodes) to which net will be allocated, "
-"layer for this categories is given by nlayer option"
+msgid "Categories of centers (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
 msgstr ""
 #: ../vector/v.net.alloc/main.c:129 ../vector/v.net.iso/main.c:137
@@ -17082,10 +16454,7 @@
 msgstr ""
 #: ../vector/v.class/main.c:173
-msgid ""
-"The discontinuities algorithm indicates that some class breaks are not "
-"statistically significant at alpha=0.05. You are advised to reduce the "
-"number of classes."
+msgid "The discontinuities algorithm indicates that some class breaks are not statistically significant at alpha=0.05. You are advised to reduce the number of classes."
 msgstr ""
 #: ../vector/v.class/main.c:201
@@ -17180,9 +16549,7 @@
 msgstr ""
 #: ../vector/v.random/main.c:153
-msgid ""
-"The seed to initialize the random generator. If not set the process ID is "
-"used"
+msgid "The seed to initialize the random generator. If not set the process ID is used"
 msgstr ""
 #: ../vector/v.random/main.c:156
@@ -17225,15 +16592,12 @@
 msgstr ""
 #: ../vector/v.random/main.c:286
-msgid ""
-"You have created unsupported column type. This module supports only INTEGER "
-"and DOUBLE PRECISION column types."
+msgid "You have created unsupported column type. This module supports only INTEGER and DOUBLE PRECISION column types."
 msgstr ""
 #: ../vector/v.random/main.c:349
 #, c-format
-msgid ""
-"Selected areas in input vector <%s> do not overlap with the current region"
+msgid "Selected areas in input vector <%s> do not overlap with the current region"
 msgstr ""
 #: ../vector/v.random/main.c:361
@@ -17311,9 +16675,7 @@
 msgstr ""
 #: ../vector/v.out.ascii/main.c:52
-msgid ""
-"By default only features with category are exported. To export all features "
-"use 'layer=-1'."
+msgid "By default only features with category are exported. To export all features use 'layer=-1'."
 msgstr ""
 #: ../vector/v.out.ascii/main.c:60
@@ -17333,9 +16695,7 @@
 #: ../vector/v.out.ascii/main.c:80
 #, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Areas will not be "
-"processed."
+msgid "Unable to open vector map <%s> at topology level. Areas will not be processed."
 msgstr ""
 #: ../vector/v.out.ascii/main.c:107
@@ -17378,9 +16738,7 @@
 msgstr ""
 #: ../vector/v.out.ogr/args.c:20
-msgid ""
-"Combination of types is not supported by all output formats. Default is to "
-"use first type found in input vector map."
+msgid "Combination of types is not supported by all output formats. Default is to use first type found in input vector map."
 msgstr ""
 #: ../vector/v.out.ogr/args.c:25
@@ -17444,9 +16802,7 @@
 msgstr ""
 #: ../vector/v.out.ogr/args.c:100
-msgid ""
-"Also export features without category (not labeled). Otherwise only features"
-" with category are exported."
+msgid "Also export features without category (not labeled). Otherwise only features with category are exported."
 msgstr ""
 #: ../vector/v.out.ogr/args.c:106
@@ -17462,9 +16818,7 @@
 msgstr ""
 #: ../vector/v.out.ogr/args.c:126
-msgid ""
-"Create a new empty layer in defined OGR datasource and exit. Nothing is read"
-" from input."
+msgid "Create a new empty layer in defined OGR datasource and exit. Nothing is read from input."
 msgstr ""
 #: ../vector/v.out.ogr/attrb.c:48 ../vector/v.out.vtk/writeVTK.c:585
@@ -17502,9 +16856,7 @@
 #: ../vector/v.out.ogr/main.c:97 ../vector/v.external.out/link.c:26
 #, c-format
-msgid ""
-"Data source starts with \"PG:\" prefix, expecting \"PostgreSQL\" format "
-"(\"%s\" given)"
+msgid "Data source starts with \"PG:\" prefix, expecting \"PostgreSQL\" format (\"%s\" given)"
 msgstr ""
 #: ../vector/v.out.ogr/main.c:165
@@ -17535,111 +16887,81 @@
 msgstr ""
 #: ../vector/v.out.ogr/main.c:311
-msgid ""
-"The map contains islands. With the -c flag, islands will appear as filled "
-"areas, not holes in the output map."
+msgid "The map contains islands. With the -c flag, islands will appear as filled areas, not holes in the output map."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:317
 #, c-format
-msgid ""
-"%d point found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d points found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d point found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d points found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 #: ../vector/v.out.ogr/main.c:325
 #, c-format
-msgid ""
-"%d line found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d line found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d line(s) found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 #: ../vector/v.out.ogr/main.c:334
 #, c-format
-msgid ""
-"%d boundary found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgid_plural ""
-"%d boundaries found, but not requested to be exported. Verify 'type' "
-"parameter."
+msgid "%d boundary found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d boundaries found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 #: ../vector/v.out.ogr/main.c:343
 #, c-format
-msgid ""
-"%d centroid found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgid_plural ""
-"%d centroids found, but not requested to be exported. Verify 'type' "
-"parameter."
+msgid "%d centroid found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d centroids found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 #: ../vector/v.out.ogr/main.c:351
 #, c-format
-msgid ""
-"%d area found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d areas found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d area found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d areas found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 #: ../vector/v.out.ogr/main.c:359
 #, c-format
-msgid ""
-"%d face found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d faces found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d face found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d faces found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 #: ../vector/v.out.ogr/main.c:367
 #, c-format
-msgid ""
-"%d volume found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d volumes found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d volume found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d volumes found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 #: ../vector/v.out.ogr/main.c:377
-msgid ""
-"No points found, but requested to be exported. Will skip this feature type."
+msgid "No points found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:386
-msgid ""
-"No lines found, but requested to be exported. Will skip this feature type."
+msgid "No lines found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:396
-msgid ""
-"No boundaries found, but requested to be exported. Will skip this feature "
-"type."
+msgid "No boundaries found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:405
-msgid ""
-"No areas found, but requested to be exported. Will skip this feature type."
+msgid "No areas found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:415
-msgid ""
-"No centroids found, but requested to be exported. Will skip this feature "
-"type."
+msgid "No centroids found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:424
-msgid ""
-"No faces found, but requested to be exported. Will skip this feature type."
+msgid "No faces found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:433
-msgid ""
-"No kernels found, but requested to be exported. Will skip this feature type."
+msgid "No kernels found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:442
-msgid ""
-"No volumes found, but requested to be exported. Will skip this feature type."
+msgid "No volumes found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:467
@@ -17673,23 +16995,17 @@
 #: ../vector/v.out.ogr/main.c:562
 #, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options SHPT "
-"(parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
+msgid "Vector map <%s> is 3D. Use format specific layer creation options SHPT (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
 msgstr ""
 #: ../vector/v.out.ogr/main.c:574
 #, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options DIM "
-"(parameter 'lco') to export in 3D rather than 2D (default)."
+msgid "Vector map <%s> is 3D. Use format specific layer creation options DIM (parameter 'lco') to export in 3D rather than 2D (default)."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:581
 #, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options (parameter"
-" 'lco') to export <in 3D rather than 2D (default)."
+msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export <in 3D rather than 2D (default)."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:598 ../db/drivers/ogr/execute.c:56
@@ -17755,12 +17071,8 @@
 #: ../vector/v.out.ogr/main.c:787
 #, c-format
-msgid ""
-"%d feature without category was skipped. Features without category are "
-"written only when -%c flag is given."
-msgid_plural ""
-"%d features without category were skipped. Features without category are "
+msgid "%d feature without category was skipped. Features without category are written only when -%c flag is given."
+msgid_plural "%d features without category were skipped. Features without category are written only when -%c flag is given."
 msgstr[0] ""
 #: ../vector/v.out.ogr/main.c:803
@@ -17786,8 +17098,7 @@
 #: ../vector/v.out.ogr/export_areas.c:176
 #: ../vector/v.out.ogr/export_lines.c:212
 #, c-format
-msgid ""
-"Unable to create multi-feature. Category %d not found in line %d, field %d"
+msgid "Unable to create multi-feature. Category %d not found in line %d, field %d"
 msgstr ""
 #: ../vector/v.out.ogr/export_areas.c:214
@@ -17816,21 +17127,15 @@
 msgstr ""
 #: ../vector/v.external/main.c:57
-msgid ""
-"Creates a new pseudo-vector map as a link to an OGR-supported layer or a "
-"PostGIS feature table."
+msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer or a PostGIS feature table."
 msgstr ""
 #: ../vector/v.external/main.c:76 ../vector/v.external.out/format.c:22
-msgid ""
-"Environment variable GRASS_VECTOR_OGR defined, but GRASS is compiled with "
-"OGR support. Using GRASS-PostGIS data driver instead."
+msgid "Environment variable GRASS_VECTOR_OGR defined, but GRASS is compiled with OGR support. Using GRASS-PostGIS data driver instead."
 msgstr ""
 #: ../vector/v.external/main.c:81 ../vector/v.external.out/format.c:27
-msgid ""
-"GRASS is not compiled with PostgreSQL support. Using OGR-PostgreSQL driver "
-"instead of native GRASS-PostGIS data driver."
+msgid "GRASS is not compiled with PostgreSQL support. Using OGR-PostgreSQL driver instead of native GRASS-PostGIS data driver."
 msgstr ""
 #: ../vector/v.external/main.c:124
@@ -17941,9 +17246,7 @@
 #: ../vector/v.external/list.c:310
 #, c-format
-msgid ""
-"Unable to convert input map projection to GRASS format. Projection check "
-"cannot be provided for OGR layer <%s>"
+msgid "Unable to convert input map projection to GRASS format. Projection check cannot be provided for OGR layer <%s>"
 msgstr ""
 #: ../vector/v.external/list.c:326
@@ -17957,13 +17260,11 @@
 msgstr ""
 #: ../vector/v.extrude/main.c:72
-msgid ""
-"Extrudes flat vector features to 3D vector features with defined height."
+msgid "Extrudes flat vector features to 3D vector features with defined height."
 msgstr ""
 #: ../vector/v.extrude/main.c:74
-msgid ""
-"Optionally the height can be derived from sampling of elevation raster map."
+msgid "Optionally the height can be derived from sampling of elevation raster map."
 msgstr ""
 #: ../vector/v.extrude/main.c:78
@@ -17981,9 +17282,7 @@
 #: ../vector/v.extrude/main.c:202
 #, c-format
-msgid ""
-"Invalid layer number (%d). Parameter '%s', '%s' or '%s' specified, assuming "
-"layer '1'."
+msgid "Invalid layer number (%d). Parameter '%s', '%s' or '%s' specified, assuming layer '1'."
 msgstr ""
 #: ../vector/v.extrude/main.c:234
@@ -18007,8 +17306,7 @@
 #: ../vector/v.extrude/main.c:293
 #, c-format
-msgid ""
-"Unable to fetch height from DB for area %d. Using default fixed height %f."
+msgid "Unable to fetch height from DB for area %d. Using default fixed height %f."
 msgstr ""
 #: ../vector/v.extrude/main.c:319
@@ -18022,8 +17320,7 @@
 #: ../vector/v.extrude/main.c:346
 #, c-format
-msgid ""
-"Unable to fetch height from DB for line %d. Using default fixed height %f."
+msgid "Unable to fetch height from DB for line %d. Using default fixed height %f."
 msgstr ""
 #: ../vector/v.extrude/main.c:364
@@ -18163,8 +17460,7 @@
 msgstr ""
 #: ../vector/v.build/main.c:49
-msgid ""
-"Name for output vector map where erroneous vector features are written to"
+msgid "Name for output vector map where erroneous vector features are written to"
 msgstr ""
 #: ../vector/v.build/main.c:51 ../vector/v.build/main.c:77
@@ -18206,9 +17502,7 @@
 #: ../vector/v.build/main.c:106
 #, c-format
-msgid ""
-"Direct read access to OGR layers is not supported by this module. Run %s to "
-"create a link as GRASS vector map in the current mapset."
+msgid "Direct read access to OGR layers is not supported by this module. Run %s to create a link as GRASS vector map in the current mapset."
 msgstr ""
 #: ../vector/v.build/main.c:111
@@ -18221,9 +17515,7 @@
 msgstr ""
 #: ../vector/v.rectify/main.c:75
-msgid ""
-"Rectifies a vector by computing a coordinate transformation for each object "
-"in the vector based on the control points."
+msgid "Rectifies a vector by computing a coordinate transformation for each object in the vector based on the control points."
 msgstr ""
 #: ../vector/v.rectify/main.c:90
@@ -18231,8 +17523,7 @@
 msgstr ""
 #: ../vector/v.rectify/main.c:95
-msgid ""
-"Name of output file with RMS errors (if omitted or '-' output to stdout"
+msgid "Name of output file with RMS errors (if omitted or '-' output to stdout"
 msgstr ""
 #: ../vector/v.rectify/main.c:104 ../imagery/i.rectify/main.c:124
@@ -18623,9 +17914,7 @@
 msgstr ""
 #: ../vector/v.net.steiner/main.c:352
-msgid ""
-"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
-"is used in this module so the result may be sub optimal."
+msgid "Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal."
 msgstr ""
 #: ../vector/v.net.steiner/main.c:373
@@ -18677,8 +17966,7 @@
 #: ../vector/v.net.steiner/main.c:538
 #, c-format
-msgid ""
-"[%d] (not reachable) nodes removed from list of Steiner point candidates"
+msgid "[%d] (not reachable) nodes removed from list of Steiner point candidates"
 msgstr ""
 #: ../vector/v.net.steiner/main.c:543
@@ -19079,9 +18367,7 @@
 #: ../vector/v.to.points/main.c:232
 #, c-format
-msgid ""
-"%d features without category in layer <%d> skipped. Note that features "
-"without category (usually boundaries) are not skipped when '%s=-1' is given."
+msgid "%d features without category in layer <%d> skipped. Note that features without category (usually boundaries) are not skipped when '%s=-1' is given."
 msgstr ""
 #: ../vector/v.to.points/main.c:282
@@ -19139,9 +18425,7 @@
 msgstr ""
 #: ../vector/v.in.ascii/main.c:128
-msgid ""
-"For example: 'x double precision, y double precision, cat int, name "
-"varchar(10)'"
+msgid "For example: 'x double precision, y double precision, cat int, name varchar(10)'"
 msgstr ""
 #: ../vector/v.in.ascii/main.c:140 ../vector/v.in.ascii/main.c:150
@@ -19165,9 +18449,7 @@
 msgstr ""
 #: ../vector/v.in.ascii/main.c:172
-msgid ""
-"First column is 1. If 0, unique category is assigned to each row and written"
-" to new column 'cat'"
+msgid "First column is 1. If 0, unique category is assigned to each row and written to new column 'cat'"
 msgstr ""
 #: ../vector/v.in.ascii/main.c:181
@@ -19238,9 +18520,7 @@
 #: ../vector/v.in.ascii/main.c:296 ../vector/v.in.ascii/main.c:300
 #: ../vector/v.in.ascii/main.c:305 ../vector/v.in.ascii/main.c:310
 #, c-format
-msgid ""
-"'%s' column number > minimum last column number (incorrect field separator "
-"or format?)"
+msgid "'%s' column number > minimum last column number (incorrect field separator or format?)"
 msgstr ""
 #: ../vector/v.in.ascii/main.c:315 ../vector/v.in.ascii/main.c:318
@@ -19255,9 +18535,7 @@
 #: ../vector/v.in.ascii/main.c:441
 #, c-format
-msgid ""
-"Number of columns defined (%d) does not match number of columns (%d) in "
-"input"
+msgid "Number of columns defined (%d) does not match number of columns (%d) in input"
 msgstr ""
 #: ../vector/v.in.ascii/main.c:469
@@ -19300,9 +18578,7 @@
 msgstr ""
 #: ../vector/v.in.ascii/main.c:542
-msgid ""
-"Unable to close attribute table. The DBMI driver did not accept all "
-"attributes"
+msgid "Unable to close attribute table. The DBMI driver did not accept all attributes"
 msgstr ""
 #: ../vector/v.in.ascii/points.c:82
@@ -19355,10 +18631,7 @@
 msgstr ""
 #: ../vector/v.net.iso/main.c:78
-msgid ""
-"Splits net to bands between cost isolines (direction from center). Center "
-"node must be opened (costs >= 0). Costs of center node are used in "
-"calculation."
+msgid "Splits net to bands between cost isolines (direction from center). Center node must be opened (costs >= 0). Costs of center node are used in calculation."
 msgstr ""
 #: ../vector/v.net.iso/main.c:98
@@ -19411,14 +18684,11 @@
 msgstr ""
 #: ../vector/v.net.salesman/main.c:133
-msgid ""
-"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
-"created cycle may be sub optimal"
+msgid "Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
 msgstr ""
 #: ../vector/v.net.salesman/main.c:142
-msgid ""
-"Categories of points ('cities') on nodes (layer is specified by nlayer)"
+msgid "Categories of points ('cities') on nodes (layer is specified by nlayer)"
 msgstr ""
 #: ../vector/v.net.salesman/main.c:162
@@ -19475,9 +18745,7 @@
 msgstr ""
 #: ../vector/v.patch/main.c:84
-msgid ""
-"Name for output vector map where bounding boxes of input vector maps are "
-"written to"
+msgid "Name for output vector map where bounding boxes of input vector maps are written to"
 msgstr ""
 #: ../vector/v.patch/main.c:88
@@ -19505,8 +18773,7 @@
 msgstr ""
 #: ../vector/v.patch/main.c:106
-msgid ""
-"Append files to existing file (overwriting existing files must be activated)"
+msgid "Append files to existing file (overwriting existing files must be activated)"
 msgstr ""
 #: ../vector/v.patch/main.c:216
@@ -19617,9 +18884,7 @@
 msgstr ""
 #: ../vector/v.kernel/main.c:115
-msgid ""
-"Density is computed using a moving kernel. Optionally generates a vector "
-"density map on a vector network."
+msgid "Density is computed using a moving kernel. Optionally generates a vector density map on a vector network."
 msgstr ""
 #: ../vector/v.kernel/main.c:119
@@ -19682,9 +18947,7 @@
 msgstr ""
 #: ../vector/v.kernel/main.c:207
-msgid ""
-"Try to calculate an optimal radius with given 'radius' taken as maximum "
-"(experimental)"
+msgid "Try to calculate an optimal radius with given 'radius' taken as maximum (experimental)"
 msgstr ""
 #: ../vector/v.kernel/main.c:212
@@ -19692,9 +18955,7 @@
 msgstr ""
 #: ../vector/v.kernel/main.c:217
-msgid ""
-"In network mode, normalize values by sum of density multiplied by length of "
-"each segment. Integral over the output map then gives 1.0 * mult"
+msgid "In network mode, normalize values by sum of density multiplied by length of each segment. Integral over the output map then gives 1.0 * mult"
 msgstr ""
 #: ../vector/v.kernel/main.c:223
@@ -19702,9 +18963,7 @@
 msgstr ""
 #: ../vector/v.kernel/main.c:236
-msgid ""
-"Use option net_output if you compute network density. Name provided in "
-"option output will be used for net_output."
+msgid "Use option net_output if you compute network density. Name provided in option output will be used for net_output."
 msgstr ""
 #: ../vector/v.kernel/main.c:255
@@ -19716,15 +18975,11 @@
 msgstr ""
 #: ../vector/v.kernel/main.c:279
-msgid ""
-"Optimal standard deviation calculation is supported only for node method "
-"'none' and kernel function 'gaussian'."
+msgid "Optimal standard deviation calculation is supported only for node method 'none' and kernel function 'gaussian'."
 msgstr ""
 #: ../vector/v.kernel/main.c:283
-msgid ""
-"Optimal standard deviation calculation is supported only for kernel function"
-" 'gaussian'."
+msgid "Optimal standard deviation calculation is supported only for kernel function 'gaussian'."
 msgstr ""
 #: ../vector/v.kernel/main.c:300
@@ -19772,9 +19027,7 @@
 #: ../vector/v.kernel/main.c:379
 #, c-format
-msgid ""
-"Automatic choice of smoothing parameter (radius), maximum possible value of "
-"radius is set to %f"
+msgid "Automatic choice of smoothing parameter (radius), maximum possible value of radius is set to %f"
 msgstr ""
 #: ../vector/v.kernel/main.c:386
@@ -19795,9 +19048,7 @@
 #: ../vector/v.kernel/main.c:406
 #, c-format
-msgid ""
-"Distances between all points are beyond %e (4 * standard deviation), unable "
-"to calculate optimal value."
+msgid "Distances between all points are beyond %e (4 * standard deviation), unable to calculate optimal value."
 msgstr ""
 #: ../vector/v.kernel/main.c:417
@@ -19859,9 +19110,7 @@
 msgstr ""
 #: ../vector/v.clean/main.c:100
-msgid ""
-"change the type of boundary dangle to line, threshold ignored if < 0, input "
-"line type is ignored"
+msgid "change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored"
 msgstr ""
 #: ../vector/v.clean/main.c:102
@@ -19869,9 +19118,7 @@
 msgstr ""
 #: ../vector/v.clean/main.c:103
-msgid ""
-"change the type of bridges connecting area and island or 2 islands from "
-"boundary to line"
+msgid "change the type of bridges connecting area and island or 2 islands from boundary to line"
 msgstr ""
 #: ../vector/v.clean/main.c:105
@@ -19883,17 +19130,11 @@
 msgstr ""
 #: ../vector/v.clean/main.c:107
-msgid ""
-"break (topologically clean) polygons (imported from non topological format, "
-"like ShapeFile). Boundaries are broken on each point shared between 2 and "
-"more polygons where angles of segments are different"
+msgid "break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different"
 msgstr ""
 #: ../vector/v.clean/main.c:110
-msgid ""
-"remove vertices in threshold from lines and boundaries, boundary is pruned "
-"only if topology is not damaged (new intersection, changed attachment of "
-"centroid), first and last segment of the boundary is never changed"
+msgid "remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachment of centroid), first and last segment of the boundary is never changed"
 msgstr ""
 #: ../vector/v.clean/main.c:114
@@ -19933,9 +19174,7 @@
 msgstr ""
 #: ../vector/v.clean/main.c:202
-msgid ""
-"Note: In latitude-longitude coordinate system specify threshold in degree "
-"unit"
+msgid "Note: In latitude-longitude coordinate system specify threshold in degree unit"
 msgstr ""
 #: ../vector/v.clean/main.c:215
@@ -20091,8 +19330,7 @@
 #: ../vector/v.clean/prune.c:216
 #, c-format
-msgid ""
-"%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
+msgid "%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
 msgstr ""
 #: ../vector/v.clean/prune.c:220
@@ -20141,14 +19379,11 @@
 #: ../vector/v.out.vtk/main.c:183
 #, c-format
-msgid ""
-"Export of areas requires topology. Please adjust '%s' option or rebuild "
-"topology."
+msgid "Export of areas requires topology. Please adjust '%s' option or rebuild topology."
 msgstr ""
 #: ../vector/v.out.vtk/writeVTK.c:196
-msgid ""
-"No coordinates to generate the output! Maybe an empty vector type chosen?"
+msgid "No coordinates to generate the output! Maybe an empty vector type chosen?"
 msgstr ""
 #: ../vector/v.out.vtk/writeVTK.c:632
@@ -20233,9 +19468,7 @@
 msgstr ""
 #: ../vector/v.overlay/main.c:70
-msgid ""
-"Overlays two vector maps offering clip, intersection, difference, "
-"symmetrical difference, union operators."
+msgid "Overlays two vector maps offering clip, intersection, difference, symmetrical difference, union operators."
 msgstr ""
 #: ../vector/v.overlay/main.c:73
@@ -20259,10 +19492,7 @@
 msgstr ""
 #: ../vector/v.overlay/main.c:109
-msgid ""
-"Feature is written to output if the result of operation 'ainput operator "
-"binput' is true. Input feature is considered to be true, if category of "
+msgid "Feature is written to output if the result of operation 'ainput operator binput' is true. Input feature is considered to be true, if category of given layer is defined."
 msgstr ""
 #: ../vector/v.overlay/main.c:116
@@ -20274,15 +19504,11 @@
 msgstr ""
 #: ../vector/v.overlay/main.c:118
-msgid ""
-"also known as 'difference' (features from ainput not overlayed by features "
-"from binput)"
+msgid "also known as 'difference' (features from ainput not overlayed by features from binput)"
 msgstr ""
 #: ../vector/v.overlay/main.c:120
-msgid ""
-"also known as 'symmetrical difference' (features from either ainput or "
-"binput but not those from ainput overlayed by binput (only for atype=area)"
+msgid "also known as 'symmetrical difference' (features from either ainput or binput but not those from ainput overlayed by binput (only for atype=area)"
 msgstr ""
 #: ../vector/v.overlay/main.c:131
@@ -20427,8 +19653,7 @@
 #: ../vector/v.net.path/path.c:233
 #, c-format
-msgid ""
-"Point with category [%d] is not reachable from point with category [%d]"
+msgid "Point with category [%d] is not reachable from point with category [%d]"
 msgstr ""
 #: ../vector/v.net.path/path.c:302
@@ -20456,8 +19681,7 @@
 msgstr ""
 #: ../vector/v.net.path/main.c:72
-msgid ""
-"Name of file containing start and end points. If not given, read from stdin"
+msgid "Name of file containing start and end points. If not given, read from stdin"
 msgstr ""
 #: ../vector/v.net.path/main.c:101
@@ -20465,10 +19689,7 @@
 msgstr ""
 #: ../vector/v.net.path/main.c:102
-msgid ""
-"If start/end are given as coordinates. If start/end point is outside this "
-"threshold, the path is not found and error message is printed. To speed up "
-"the process, keep this value as low as possible."
+msgid "If start/end are given as coordinates. If start/end point is outside this threshold, the path is not found and error message is printed. To speed up the process, keep this value as low as possible."
 msgstr ""
 #: ../vector/v.neighbors/main.c:55
@@ -20476,10 +19697,7 @@
 msgstr ""
 #: ../vector/v.neighbors/main.c:56
-msgid ""
-"Makes each cell value a function of the attribute values assigned to the "
-"vector points or centroids around it, and stores new cell values in an "
-"output raster map."
+msgid "Makes each cell value a function of the attribute values assigned to the vector points or centroids around it, and stores new cell values in an output raster map."
 msgstr ""
 #: ../vector/v.neighbors/main.c:72 ../raster/r.neighbors/main.c:204
@@ -20496,9 +19714,7 @@
 #: ../vector/v.neighbors/main.c:103
 #, c-format
-msgid ""
-"The search diameter %g is smaller than cell diagonal %g: some points could "
-"not be detected"
+msgid "The search diameter %g is smaller than cell diagonal %g: some points could not be detected"
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:75
@@ -20512,9 +19728,7 @@
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:88
-msgid ""
-"Maybe it takes too long. It will depend on how many points you are "
-"considering."
+msgid "Maybe it takes too long. It will depend on how many points you are considering."
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:119
@@ -20530,9 +19744,7 @@
 #: ../vector/v.surf.bspline/crosscorr.c:151
 #: ../raster/r.resamp.bspline/crosscorr.c:197
 #, c-format
-msgid ""
-"Too many splines (%d x %d). Consider changing spline steps \"ew_step=\" "
-"\"ns_step=\"."
+msgid "Too many splines (%d x %d). Consider changing spline steps \"ew_step=\" \"ns_step=\"."
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:169
@@ -20561,16 +19773,13 @@
 #: ../vector/v.surf.bspline/crosscorr.c:313
 #: ../raster/r.resamp.bspline/crosscorr.c:324
-msgid ""
-"Different number of splines and lambda_i values have been taken for the "
-"cross correlation"
+msgid "Different number of splines and lambda_i values have been taken for the cross correlation"
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:315
 #: ../raster/r.resamp.bspline/crosscorr.c:326
 #, c-format
-msgid ""
-"The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
+msgid "The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:323
@@ -20590,15 +19799,11 @@
 msgstr ""
 #: ../vector/v.surf.bspline/main.c:96
-msgid ""
-"Performs bicubic or bilinear spline interpolation with Tykhonov "
-"regularization."
+msgid "Performs bicubic or bilinear spline interpolation with Tykhonov regularization."
 msgstr ""
 #: ../vector/v.surf.bspline/main.c:101 ../raster/r.resamp.bspline/main.c:144
-msgid ""
-"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
-"cross validation method"
+msgid "Find the best Tykhonov regularizing parameter using a \"leave-one-out\" cross validation method"
 msgstr ""
 #: ../vector/v.surf.bspline/main.c:105 ../vector/v.outlier/main.c:79
@@ -20687,9 +19892,7 @@
 #: ../vector/v.surf.bspline/main.c:338
 #, c-format
-msgid ""
-"Sorry, the <%s> driver is not compatible with the vector output of this "
-"module. Try with raster output or another driver."
+msgid "Sorry, the <%s> driver is not compatible with the vector output of this module. Try with raster output or another driver."
 msgstr ""
 #: ../vector/v.surf.bspline/main.c:361
@@ -20765,9 +19968,7 @@
 msgstr ""
 #: ../vector/v.surf.idw/main.c:92
-msgid ""
-"Provides surface interpolation from vector point data by Inverse Distance "
-"Squared Weighting."
+msgid "Provides surface interpolation from vector point data by Inverse Distance Squared Weighting."
 msgstr ""
 #: ../vector/v.surf.idw/main.c:101
@@ -20795,9 +19996,7 @@
 msgstr ""
 #: ../vector/v.surf.idw/main.c:129
-msgid ""
-"Slower but uses less memory and includes points from outside region in the "
-"interpolation"
+msgid "Slower but uses less memory and includes points from outside region in the interpolation"
 msgstr ""
 #: ../vector/v.surf.idw/main.c:139
@@ -20873,9 +20072,7 @@
 msgstr ""
 #: ../vector/v.buffer/main.c:293
-msgid ""
-"Maximum distance between theoretical arc and polygon segments as multiple of"
-" buffer"
+msgid "Maximum distance between theoretical arc and polygon segments as multiple of buffer"
 msgstr ""
 #: ../vector/v.buffer/main.c:298
@@ -20891,9 +20088,7 @@
 msgstr ""
 #: ../vector/v.buffer/main.c:326
-msgid ""
-"Note: In latitude-longitude coordinate system specify distances in degree "
-"unit"
+msgid "Note: In latitude-longitude coordinate system specify distances in degree unit"
 msgstr ""
 #: ../vector/v.buffer/main.c:330
@@ -20928,9 +20123,7 @@
 msgstr ""
 #: ../vector/v.buffer/main.c:464
-msgid ""
-"No features available for buffering. Check type option and features "
-"available in the input vector."
+msgid "No features available for buffering. Check type option and features available in the input vector."
 msgstr ""
 #: ../vector/v.buffer/main.c:481
@@ -20939,9 +20132,7 @@
 msgstr ""
 #: ../vector/v.buffer/main.c:486
-msgid ""
-"Negative distances for internal buffers are not supported and converted to "
-"positive values."
+msgid "Negative distances for internal buffers are not supported and converted to positive values."
 msgstr ""
 #: ../vector/v.buffer/main.c:496
@@ -21064,8 +20255,7 @@
 msgstr ""
 #: ../vector/v.outlier/main.c:355
-msgid ""
-"No subregions found! Check values for 'ew_step' and 'ns_step' parameters"
+msgid "No subregions found! Check values for 'ew_step' and 'ns_step' parameters"
 msgstr ""
 #: ../vector/v.outlier/main.c:428
@@ -21184,9 +20374,7 @@
 msgstr ""
 #: ../db/db.copy/main.c:40
-msgid ""
-"Either 'from_table' (optionally with 'where') can be used or 'select' "
-"option, but not 'from_table' and 'select' at the same time."
+msgid "Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
 msgstr ""
 #: ../db/db.copy/main.c:46
@@ -21263,9 +20451,7 @@
 msgstr ""
 #: ../db/db.databases/main.c:53
-msgid ""
-"Unable to list databases. Try to define correct connection settings by "
-"db.login."
+msgid "Unable to list databases. Try to define correct connection settings by db.login."
 msgstr ""
 #: ../db/db.databases/main.c:63
@@ -21358,23 +20544,17 @@
 #: ../db/drivers/postgres/describe.c:130 ../db/drivers/ogr/describe.c:186
 #, c-format
-msgid ""
-"Column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
-"may be damaged"
+msgid "Column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data may be damaged"
 msgstr ""
 #: ../db/drivers/postgres/describe.c:134
 #, c-format
-msgid ""
-"Column '%s' : type character varying is stored as varchar(250) some data may"
-" be lost"
+msgid "Column '%s' : type character varying is stored as varchar(250) some data may be lost"
 msgstr ""
 #: ../db/drivers/postgres/describe.c:140
 #, c-format
-msgid ""
-"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1"
-" (true)"
+msgid "column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 (true)"
 msgstr ""
 #: ../db/drivers/postgres/execute.c:42 ../db/drivers/mysql/execute.c:41
@@ -21701,9 +20881,7 @@
 #: ../db/drivers/mysql/describe.c:127
 #, c-format
-msgid ""
-"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
-"damaged"
+msgid "column '%s' : type BIGINT is stored as integer (4 bytes) some data may be damaged"
 msgstr ""
 #: ../db/drivers/mysql/execute.c:62
@@ -21790,9 +20968,7 @@
 #: ../db/drivers/ogr/describe.c:204
 #, c-format
-msgid ""
-"column '%s', type 'string': unknown width -> stored as varchar(250) some "
-"data may be lost"
+msgid "column '%s', type 'string': unknown width -> stored as varchar(250) some data may be lost"
 msgstr ""
 #: ../db/drivers/ogr/describe.c:212 ../db/drivers/ogr/fetch.c:160
@@ -21887,8 +21063,7 @@
 msgstr ""
 #: ../db/drivers/sqlite/fetch.c:218
-msgid ""
-"SQLite driver: parsing of interval values not implemented; assuming seconds"
+msgid "SQLite driver: parsing of interval values not implemented; assuming seconds"
 msgstr ""
 #: ../db/drivers/sqlite/fetch.c:223
@@ -22045,9 +21220,7 @@
 msgstr ""
 #: ../display/d.rgb/main.c:58
-msgid ""
-"Displays three user-specified raster maps as red, green, and blue overlays "
-"in the active graphics frame."
+msgid "Displays three user-specified raster maps as red, green, and blue overlays in the active graphics frame."
 msgstr ""
 #: ../display/d.rgb/main.c:63 ../display/d.rast/main.c:81
@@ -22077,9 +21250,7 @@
 msgstr ""
 #: ../display/d.linegraph/main.c:126
-msgid ""
-"Generates and displays simple line graphs in the active graphics monitor "
-"display frame."
+msgid "Generates and displays simple line graphs in the active graphics monitor display frame."
 msgstr ""
 #: ../display/d.linegraph/main.c:130
@@ -22386,15 +21557,11 @@
 msgstr ""
 #: ../display/d.graph/main.c:61
-msgid ""
-"Program for generating and displaying simple graphics on the display "
-"monitor."
+msgid "Program for generating and displaying simple graphics on the display monitor."
 msgstr ""
 #: ../display/d.graph/main.c:66
-msgid ""
-"Name of file containing graphics commands, if not given reads from standard "
-"input"
+msgid "Name of file containing graphics commands, if not given reads from standard input"
 msgstr ""
 #: ../display/d.graph/main.c:73
@@ -22474,9 +21641,7 @@
 msgstr ""
 #: ../display/d.grid/main.c:58
-msgid ""
-"Overlays a user-specified grid in the active display frame on the graphics "
-"monitor."
+msgid "Overlays a user-specified grid in the active display frame on the graphics monitor."
 msgstr ""
 #: ../display/d.grid/main.c:66
@@ -22484,9 +21649,7 @@
 msgstr ""
 #: ../display/d.grid/main.c:68
-msgid ""
-"0 for north-south resolution of the current region. In map units or "
-"DDD:MM:SS format. Example: \"1000\" or \"0:10\""
+msgid "0 for north-south resolution of the current region. In map units or DDD:MM:SS format. Example: \"1000\" or \"0:10\""
 msgstr ""
 #: ../display/d.grid/main.c:76
@@ -22628,9 +21791,7 @@
 msgstr ""
 #: ../display/d.text/main.c:142
-msgid ""
-"Draws text in the active display frame on the graphics monitor using the "
-"current font."
+msgid "Draws text in the active display frame on the graphics monitor using the current font."
 msgstr ""
 #: ../display/d.text/main.c:148
@@ -22664,9 +21825,7 @@
 msgstr ""
 #: ../display/d.text/main.c:198
-msgid ""
-"Screen position at which text will begin to be drawn (percentage, [0,0] is "
-"lower left)"
+msgid "Screen position at which text will begin to be drawn (percentage, [0,0] is lower left)"
 msgstr ""
 #: ../display/d.text/main.c:199 ../display/d.text/main.c:208
@@ -22778,14 +21937,12 @@
 #: ../display/d.colortable/main.c:112
 #, c-format
-msgid ""
-"<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
+msgid "<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
 msgstr ""
 #: ../display/d.colortable/main.c:126
 #, c-format
-msgid ""
-"<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
+msgid "<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
 msgstr ""
 #: ../display/d.colortable/main.c:137
@@ -22989,9 +22146,7 @@
 msgstr ""
 #: ../display/d.his/main.c:69
-msgid ""
-"Displays the result obtained by combining hue, intensity, and saturation "
-"(HIS) values from user-specified input raster map layers."
+msgid "Displays the result obtained by combining hue, intensity, and saturation (HIS) values from user-specified input raster map layers."
 msgstr ""
 #: ../display/d.his/main.c:78 ../raster/r.his/main.c:82
@@ -23019,9 +22174,7 @@
 msgstr ""
 #: ../display/d.histogram/main.c:87
-msgid ""
-"Displays a histogram in the form of a pie or bar chart for a user-specified "
-"raster map."
+msgid "Displays a histogram in the form of a pie or bar chart for a user-specified raster map."
 msgstr ""
 #: ../display/d.histogram/main.c:91
@@ -23073,8 +22226,7 @@
 msgstr ""
 #: ../display/d.title/main.c:52
-msgid ""
-"Create a TITLE for a raster map in a form suitable for display with d.text."
+msgid "Create a TITLE for a raster map in a form suitable for display with d.text."
 msgstr ""
 #: ../display/d.title/main.c:63
@@ -23110,8 +22262,7 @@
 msgstr ""
 #: ../display/d.vect.chart/main.c:67
-msgid ""
-"Displays charts of vector data in the active frame on the graphics monitor."
+msgid "Displays charts of vector data in the active frame on the graphics monitor."
 msgstr ""
 #: ../display/d.vect.chart/main.c:86
@@ -23166,9 +22317,7 @@
 msgstr ""
 #: ../display/d.erase/main.c:33
-msgid ""
-"Erases the contents of the active graphics display frame with user defined "
-"color."
+msgid "Erases the contents of the active graphics display frame with user defined color."
 msgstr ""
 #: ../display/d.erase/main.c:42
@@ -23242,9 +22391,7 @@
 msgstr ""
 #: ../display/d.rast.arrow/main.c:101
-msgid ""
-"Draws arrows representing cell aspect direction for a raster map containing "
-"aspect data."
+msgid "Draws arrows representing cell aspect direction for a raster map containing aspect data."
 msgstr ""
 #: ../display/d.rast.arrow/main.c:105
@@ -23345,9 +22492,7 @@
 msgstr ""
 #: ../display/d.labels/main.c:46
-msgid ""
-"Displays text labels (created with v.label) to the active frame on the "
-"graphics monitor."
+msgid "Displays text labels (created with v.label) to the active frame on the graphics monitor."
 msgstr ""
 #: ../display/d.labels/main.c:52
@@ -23470,9 +22615,7 @@
 msgstr ""
 #: ../display/d.vect.thematic/main.c:237
-msgid ""
-"When printing legend info, include extended statistical info from "
-"classification algorithm"
+msgid "When printing legend info, include extended statistical info from classification algorithm"
 msgstr ""
 #: ../display/d.vect.thematic/main.c:243 ../display/d.vect/main.c:330
@@ -23480,16 +22623,11 @@
 msgstr ""
 #: ../display/d.vect.thematic/main.c:255
-msgid ""
-"Flag -e is deprecated, set verbose mode with --v to get the extended "
-"statistical info."
+msgid "Flag -e is deprecated, set verbose mode with --v to get the extended statistical info."
 msgstr ""
 #: ../display/d.vect.thematic/main.c:258
-msgid ""
-"Option legendfile is deprecated, either use flag -l to print legend to "
-"standard output, or set GRASS_LEGEND_FILE environment variable (see "
-"d.legend.vect for details)."
+msgid "Option legendfile is deprecated, either use flag -l to print legend to standard output, or set GRASS_LEGEND_FILE environment variable (see d.legend.vect for details)."
 msgstr ""
 #: ../display/d.vect.thematic/main.c:277
@@ -23506,8 +22644,7 @@
 msgid "Data (%s) not numeric. Column must be numeric."
 msgstr ""
-#: ../display/d.vect.thematic/main.c:316
-#: ../display/d.vect.thematic/plot1.c:135
+#: ../display/d.vect.thematic/main.c:316 ../display/d.vect.thematic/plot1.c:135
 #: ../display/d.vect.thematic/plot1.c:163
 #, c-format
 msgid "Cannot select data (%s) from table"
@@ -23519,9 +22656,7 @@
 msgstr ""
 #: ../display/d.vect.thematic/main.c:390
-msgid ""
-"You gave both manual breaks and a classification algorithm or a number of "
-"classes. The manual breaks have precedence and will thus be used."
+msgid "You gave both manual breaks and a classification algorithm or a number of classes. The manual breaks have precedence and will thus be used."
 msgstr ""
 #: ../display/d.vect.thematic/main.c:427
@@ -23545,8 +22680,7 @@
 msgstr ""
 #: ../display/d.vect.thematic/main.c:469
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn."
+msgid "The bounding box of the map is outside the current region, nothing drawn."
 msgstr ""
 #: ../display/d.vect.thematic/main.c:522
@@ -23572,9 +22706,7 @@
 #: ../display/d.vect.thematic/plot1.c:130
 #, c-format
-msgid ""
-"Color definition column (%s) not a string. Column must be of form "
-"RRR:GGG:BBB where RGB values range 0-255."
+msgid "Color definition column (%s) not a string. Column must be of form RRR:GGG:BBB where RGB values range 0-255."
 msgstr ""
 #: ../display/d.vect.thematic/plot1.c:148
@@ -23595,9 +22727,7 @@
 #: ../display/d.vect.thematic/plot1.c:279
 #, c-format
-msgid ""
-"Error in color definition column (%s), element %d with cat %d: colorstring "
-"[%s]"
+msgid "Error in color definition column (%s), element %d with cat %d: colorstring [%s]"
 msgstr ""
 #: ../display/d.vect.thematic/plot1.c:286
@@ -23607,8 +22737,7 @@
 #: ../display/d.vect.thematic/plot1.c:354
 #, c-format
-msgid ""
-"Error in line width column (%s), element %d with cat %d: line width [%d]"
+msgid "Error in line width column (%s), element %d with cat %d: line width [%d]"
 msgstr ""
 #: ../display/d.vect.thematic/display.c:51 ../display/d.vect/lines.c:107
@@ -23648,9 +22777,7 @@
 msgstr[0] ""
 #: ../display/d.vect/area.c:37
-msgid ""
-"Unable to display areas, topology not available. Please try to rebuild "
-"topology using v.build or v.build.all."
+msgid "Unable to display areas, topology not available. Please try to rebuild topology using v.build or v.build.all."
 msgstr ""
 #: ../display/d.vect/area.c:137
@@ -23678,9 +22805,7 @@
 msgstr ""
 #: ../display/d.vect/lines.c:121
-msgid ""
-"Unable to display features by id, topology not available. Please try to "
-"rebuild topology using v.build or v.build.all."
+msgid "Unable to display features by id, topology not available. Please try to rebuild topology using v.build or v.build.all."
 msgstr ""
 #: ../display/d.vect/lines.c:169
@@ -23827,19 +22952,15 @@
 msgstr ""
 #: ../display/d.vect/main.c:295
-msgid ""
-"Minimum region size (average from height and width) when map is displayed"
+msgid "Minimum region size (average from height and width) when map is displayed"
 msgstr ""
 #: ../display/d.vect/main.c:303
-msgid ""
-"Maximum region size (average from height and width) when map is displayed"
+msgid "Maximum region size (average from height and width) when map is displayed"
 msgstr ""
 #: ../display/d.vect/main.c:311
-msgid ""
-"Random colors according to category number (or layer number if 'layer=-1' is"
-" given)"
+msgid "Random colors according to category number (or layer number if 'layer=-1' is given)"
 msgstr ""
 #: ../display/d.vect/main.c:318
@@ -23851,9 +22972,7 @@
 msgstr ""
 #: ../display/d.vect/main.c:324
-msgid ""
-"This makes circle areas proportionate to the size_column values instead of "
-"circle radius"
+msgid "This makes circle areas proportionate to the size_column values instead of circle radius"
 msgstr ""
 #: ../display/d.vect/main.c:347
@@ -23866,9 +22985,7 @@
 #: ../display/d.vect/main.c:368
 #, c-format
-msgid ""
-"The -%c flag and <%s> option cannot be used together, the -%c flag will be "
-"ignored!"
+msgid "The -%c flag and <%s> option cannot be used together, the -%c flag will be ignored!"
 msgstr ""
 #: ../display/d.vect/main.c:392 ../display/d.vect/main.c:398
@@ -23887,8 +23004,7 @@
 msgstr ""
 #: ../display/d.vect/main.c:426
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn"
+msgid "The bounding box of the map is outside the current region, nothing drawn"
 msgstr ""
 #: ../display/d.vect/main.c:500
@@ -23907,10 +23023,7 @@
 #: ../display/d.vect/shape.c:68
 #, c-format
-msgid ""
-"Color definition column ('%s') not a string. Column must be of form "
-"'RRR:GGG:BBB' where RGB values range 0-255. You can use '%s' module to "
-"define color rules. Unable to colorize features."
+msgid "Color definition column ('%s') not a string. Column must be of form 'RRR:GGG:BBB' where RGB values range 0-255. You can use '%s' module to define color rules. Unable to colorize features."
 msgstr ""
 #: ../display/d.vect/shape.c:77 ../display/d.vect/shape.c:100
@@ -23947,8 +23060,7 @@
 msgstr ""
 #: ../display/d.vect/shape.c:182
-msgid ""
-"Vector map is not 3D. Unable to colorize features based on z-coordinates."
+msgid "Vector map is not 3D. Unable to colorize features based on z-coordinates."
 msgstr ""
 #: ../display/d.vect/shape.c:186
@@ -23962,9 +23074,7 @@
 msgstr ""
 #: ../display/d.vect/topo.c:18
-msgid ""
-"Unable to display topology, not available.Please try to rebuild topology "
-"using v.build or v.build.all."
+msgid "Unable to display topology, not available.Please try to rebuild topology using v.build or v.build.all."
 msgstr ""
 #: ../display/d.vect/zcoor.c:19
@@ -23972,9 +23082,7 @@
 msgstr ""
 #: ../display/d.font/main.c:48
-msgid ""
-"Selects the font in which text will be displayed on the user's graphics "
-"monitor."
+msgid "Selects the font in which text will be displayed on the user's graphics monitor."
 msgstr ""
 #: ../display/d.font/main.c:56
@@ -24009,8 +23117,7 @@
 #: ../display/d.font/main.c:124
 #, c-format
-msgid ""
-"Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
+msgid "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
 msgstr ""
 #: ../display/d.fontlist/main.c:47
@@ -24022,9 +23129,7 @@
 msgstr ""
 #: ../display/d.rast.num/main.c:81
-msgid ""
-"Overlays cell category values on a raster map displayed in the active "
-"graphics frame."
+msgid "Overlays cell category values on a raster map displayed in the active graphics frame."
 msgstr ""
 #: ../display/d.rast.num/main.c:112
@@ -24050,14 +23155,11 @@
 msgstr ""
 #: ../display/d.legend/histogram.c:115
-msgid ""
-"Histogram constrained by range not yet implemented for categorical rasters"
+msgid "Histogram constrained by range not yet implemented for categorical rasters"
 msgstr ""
 #: ../display/d.legend/main.c:82
-msgid ""
-"Displays a legend for a 2D or 3D raster map in the active frame of the "
+msgid "Displays a legend for a 2D or 3D raster map in the active frame of the graphics monitor."
 msgstr ""
 #: ../display/d.legend/main.c:99 ../display/d.legend.vect/main.c:81
@@ -24121,8 +23223,7 @@
 msgstr ""
 #: ../display/d.legend/main.c:179
-msgid ""
-"Size and placement as percentage of screen coordinates (0,0 is lower left)"
+msgid "Size and placement as percentage of screen coordinates (0,0 is lower left)"
 msgstr ""
 #: ../display/d.legend/main.c:189
@@ -24238,9 +23339,7 @@
 msgstr ""
 #: ../display/d.legend/draw.c:1029
-msgid ""
-"Histogram plotting not implemented for categorical legends. Use the '-s' "
-"flag"
+msgid "Histogram plotting not implemented for categorical legends. Use the '-s' flag"
 msgstr ""
 #: ../display/d.legend/draw.c:1286
@@ -24278,9 +23377,7 @@
 msgstr ""
 #: ../display/d.where/main.c:48
-msgid ""
-"Identifies the geographic coordinates associated with point locations given "
-"in display coordinates."
+msgid "Identifies the geographic coordinates associated with point locations given in display coordinates."
 msgstr ""
 #: ../display/d.where/main.c:58
@@ -24300,9 +23397,7 @@
 msgstr ""
 #: ../display/d.where/main.c:77
-msgid ""
-"Output lat/long referenced to WGS84 ellipsoid using datum transformation "
-"parameters defined in current location (if available)"
+msgid "Output lat/long referenced to WGS84 ellipsoid using datum transformation parameters defined in current location (if available)"
 msgstr ""
 #: ../display/d.where/main.c:83
@@ -24443,9 +23538,7 @@
 msgstr ""
 #: ../display/d.geodesic/main.c:51
-msgid ""
-"Displays a geodesic line, tracing the shortest distance between two "
-"geographic points along a great circle, in a longitude/latitude data set."
+msgid "Displays a geodesic line, tracing the shortest distance between two geographic points along a great circle, in a longitude/latitude data set."
 msgstr ""
 #: ../display/d.legend.vect/main.c:55
@@ -24453,8 +23546,7 @@
 msgstr ""
 #: ../display/d.legend.vect/main.c:66
-msgid ""
-"Screen position of legend to be drawn (percentage, [0,0] is lower left)"
+msgid "Screen position of legend to be drawn (percentage, [0,0] is lower left)"
 msgstr ""
 #: ../display/d.legend.vect/main.c:74
@@ -24635,9 +23727,7 @@
 msgstr ""
 #: ../imagery/i.rgb.his/main.c:52
-msgid ""
-"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
-"Intensity-Saturation) color space."
+msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
 msgstr ""
 #: ../imagery/i.rgb.his/main.c:58
@@ -24741,9 +23831,7 @@
 msgstr ""
 #: ../imagery/i.eb.netrad/main.c:85
-msgid ""
-"Name of the difference map of temperature from surface skin to about 2 m "
-"height [K]"
+msgid "Name of the difference map of temperature from surface skin to about 2 m height [K]"
 msgstr ""
 #: ../imagery/i.eb.netrad/main.c:89
@@ -24772,9 +23860,7 @@
 msgstr ""
 #: ../imagery/i.evapo.pm/main.c:61
-msgid ""
-"Computes potential evapotranspiration calculation with hourly Penman-"
-"Monteith."
+msgid "Computes potential evapotranspiration calculation with hourly Penman-Monteith."
 msgstr ""
 #: ../imagery/i.evapo.pm/main.c:65
@@ -24973,9 +24059,7 @@
 msgstr ""
 #: ../imagery/i.maxlik/main.c:68
-msgid ""
-"Classification is based on the spectral signature information generated by "
-"either i.cluster, g.gui.iclass, or i.gensig."
+msgid "Classification is based on the spectral signature information generated by either i.cluster, g.gui.iclass, or i.gensig."
 msgstr ""
 #: ../imagery/i.maxlik/main.c:81 ../imagery/i.smap/parse.c:20
@@ -24996,16 +24080,12 @@
 #: ../imagery/i.maxlik/open.c:27
 #, c-format
-msgid ""
-"Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
-"have at least 2 raster maps."
+msgid "Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must have at least 2 raster maps."
 msgstr ""
 #: ../imagery/i.maxlik/open.c:30
 #, c-format
-msgid ""
-"Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at"
-" least 2 raster maps."
+msgid "Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at least 2 raster maps."
 msgstr ""
 #: ../imagery/i.maxlik/open.c:47
@@ -25059,9 +24139,7 @@
 msgstr ""
 #: ../imagery/i.rectify/main.c:102
-msgid ""
-"Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points."
+msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
 msgstr ""
 #: ../imagery/i.rectify/main.c:116
@@ -25081,9 +24159,7 @@
 #: ../imagery/i.rectify/main.c:153
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:137
-msgid ""
-"Use current region settings in target location (def.=calculate smallest "
-"area)"
+msgid "Use current region settings in target location (def.=calculate smallest area)"
 msgstr ""
 #: ../imagery/i.rectify/main.c:157
@@ -25266,8 +24342,7 @@
 msgstr ""
 #: ../imagery/i.vi/main.c:94
-msgid ""
-"Uses red and nir bands mostly, and some indices require additional bands."
+msgid "Uses red and nir bands mostly, and some indices require additional bands."
 msgstr ""
 #: ../imagery/i.vi/main.c:101
@@ -25394,9 +24469,7 @@
 msgstr ""
 #: ../imagery/i.vi/main.c:202
-msgid ""
-"If data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8"
-" for Landsat -> [0-255])"
+msgid "If data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8 for Landsat -> [0-255])"
 msgstr ""
 #: ../imagery/i.vi/main.c:225 ../raster/r.texture/main.c:327
@@ -25433,8 +24506,7 @@
 msgstr ""
 #: ../imagery/i.vi/main.c:251
-msgid ""
-"msavi index requires red and nir maps, and 3 parameters related to soil line"
+msgid "msavi index requires red and nir maps, and 3 parameters related to soil line"
 msgstr ""
 #: ../imagery/i.vi/main.c:254
@@ -25506,9 +24578,7 @@
 msgstr ""
 #: ../imagery/i.evapo.mh/main.c:72
-msgid ""
-"Computes evapotranspiration calculation modified or original Hargreaves "
-"formulation, 2001."
+msgid "Computes evapotranspiration calculation modified or original Hargreaves formulation, 2001."
 msgstr ""
 #: ../imagery/i.evapo.mh/main.c:78
@@ -25593,9 +24663,7 @@
 msgstr ""
 #: ../imagery/i.smap/main.c:44
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
+msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
 msgstr ""
 #: ../imagery/i.smap/model.c:43
@@ -25703,15 +24771,11 @@
 msgstr ""
 #: ../imagery/i.cluster/main.c:79
-msgid ""
-"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm."
+msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
 msgstr ""
 #: ../imagery/i.cluster/main.c:82
-msgid ""
-"The resulting signature file is used as input for i.maxlik, to generate an "
-"unsupervised image classification."
+msgid "The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
 msgstr ""
 #: ../imagery/i.cluster/main.c:102
@@ -25901,14 +24965,11 @@
 msgstr ""
 #: ../imagery/i.cluster/main.c:312
-msgid ""
-"Not enough sample points. Please run again and choose a larger sample size."
+msgid "Not enough sample points. Please run again and choose a larger sample size."
 msgstr ""
 #: ../imagery/i.cluster/main.c:316
-msgid ""
-"Not enough non-zero sample data points. Check your current region (and "
-"mask)."
+msgid "Not enough non-zero sample data points. Check your current region (and mask)."
 msgstr ""
 #: ../imagery/i.cluster/main.c:329
@@ -26136,9 +25197,7 @@
 msgstr ""
 #: ../imagery/i.aster.toar/main.c:105
-msgid ""
-"Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
-"from ASTER DN."
+msgid "Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature from ASTER DN."
 msgstr ""
 #: ../imagery/i.aster.toar/main.c:109
@@ -26191,9 +25250,7 @@
 msgstr ""
 #: ../imagery/i.his.rgb/main.c:52
-msgid ""
-"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
-"RGB (Red-Green-Blue) color space."
+msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
 msgstr ""
 #: ../imagery/i.his.rgb/main.c:58
@@ -26241,9 +25298,7 @@
 msgstr ""
 #: ../imagery/i.evapo.time/main.c:79
-msgid ""
-"Computes temporal integration of satellite ET actual (ETa) following the "
-"daily ET reference (ETo) from meteorological station(s)."
+msgid "Computes temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)."
 msgstr ""
 #: ../imagery/i.evapo.time/main.c:86
@@ -26340,15 +25395,13 @@
 msgid "Group <%s> not found in the current mapset"
 msgstr ""
-#: ../imagery/i.segment/write_output.c:100
-#: ../imagery/i.segment/open_files.c:44
+#: ../imagery/i.segment/write_output.c:100 ../imagery/i.segment/open_files.c:44
 #, c-format
 msgid "Group <%s> contains no raster maps"
 msgstr ""
-#: ../imagery/i.segment/write_output.c:116
-#: ../imagery/i.segment/open_files.c:69 ../imagery/i.segment/open_files.c:228
-#: ../imagery/i.segment/open_files.c:236
+#: ../imagery/i.segment/write_output.c:116 ../imagery/i.segment/open_files.c:69
+#: ../imagery/i.segment/open_files.c:228 ../imagery/i.segment/open_files.c:236
 #, c-format
 msgid "No min/max found in raster map <%s>"
 msgstr ""
@@ -26456,9 +25509,7 @@
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:122
-msgid ""
-"Must be integer values, each area will be segmented independent of the "
-"others"
+msgid "Must be integer values, each area will be segmented independent of the others"
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:128
@@ -26466,14 +25517,11 @@
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:133
-msgid ""
-"Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for "
-"each pixel"
+msgid "Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for each pixel"
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:139
-msgid ""
-"Weighted input, do not perform the default scaling of input raster maps"
+msgid "Weighted input, do not perform the default scaling of input raster maps"
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:158
@@ -26543,9 +25591,7 @@
 #: ../imagery/i.segment/region_growing.c:445
 #, c-format
-msgid ""
-"Segmentation processes stopped at %d due to reaching max iteration limit, "
-"more merges may be possible"
+msgid "Segmentation processes stopped at %d due to reaching max iteration limit, more merges may be possible"
 msgstr ""
 #: ../imagery/i.segment/region_growing.c:447
@@ -26606,9 +25652,7 @@
 #: ../imagery/i.segment/mean_shift.c:106
 #, c-format
-msgid ""
-"Mean shift stopped at %d due to reaching max iteration limit, more changes "
-"may be possible"
+msgid "Mean shift stopped at %d due to reaching max iteration limit, more changes may be possible"
 msgstr ""
 #: ../imagery/i.segment/mean_shift.c:108
@@ -26680,8 +25724,7 @@
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:153
 #, c-format
-msgid ""
-"Replacing coordinates of principal point '%.17g, %.17g' with '%.17g, %.17g'"
+msgid "Replacing coordinates of principal point '%.17g, %.17g' with '%.17g, %.17g'"
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:164
@@ -26715,9 +25758,7 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:50
-msgid ""
-"Interactively creates or modifies entries in a camera initial exposure "
-"station file for imagery group referenced by a sub-block."
+msgid "Interactively creates or modifies entries in a camera initial exposure station file for imagery group referenced by a sub-block."
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:62
@@ -27048,9 +26089,7 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:91
-msgid ""
-"Orthorectifies an image by using the image to photo coordinate "
-"transformation matrix."
+msgid "Orthorectifies an image by using the image to photo coordinate transformation matrix."
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:132
@@ -27220,9 +26259,7 @@
 msgstr ""
 #: ../imagery/i.albedo/main.c:138 ../imagery/i.albedo/main.c:145
-msgid ""
-"Albedo dry run to calculate some water to beach/sand/desert stretching, a "
-"kind of simple atmospheric correction"
+msgid "Albedo dry run to calculate some water to beach/sand/desert stretching, a kind of simple atmospheric correction"
 msgstr ""
 #: ../imagery/i.albedo/main.c:143
@@ -27234,9 +26271,7 @@
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:69
-msgid ""
-"Calculates top-of-atmosphere radiance or reflectance and temperature for "
-"Landsat MSS/TM/ETM+/OLI"
+msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+/OLI"
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:75
@@ -27409,8 +26444,7 @@
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:227
-msgid ""
-"Input raster maps use as extension the number of the band instead the code"
+msgid "Input raster maps use as extension the number of the band instead the code"
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:231
@@ -27499,16 +26533,11 @@
 msgstr ""
 #: ../imagery/i.landsat.toar/landsat.c:116
-msgid ""
-"The DOS4 method is not applicable here: approximation of atmospheric "
-"transmittance coefficients is unstable. Use another DOS method or use other "
-"sun_elevation parameter"
+msgid "The DOS4 method is not applicable here: approximation of atmospheric transmittance coefficients is unstable. Use another DOS method or use other sun_elevation parameter"
 msgstr ""
 #: ../imagery/i.evapo.pt/main.c:69
-msgid ""
-"Computes evapotranspiration calculation Priestley and Taylor formulation, "
-"1972."
+msgid "Computes evapotranspiration calculation Priestley and Taylor formulation, 1972."
 msgstr ""
 #: ../imagery/i.evapo.pt/main.c:75
@@ -27752,9 +26781,7 @@
 #: ../imagery/i.landsat.acca/main.c:70
 #, c-format
-msgid ""
-"Input raster map <%s> is not floating point (process DN using i.landsat.toar"
-" to radiance first)"
+msgid "Input raster map <%s> is not floating point (process DN using i.landsat.toar to radiance first)"
 msgstr ""
 #: ../imagery/i.landsat.acca/main.c:104
@@ -27799,9 +26826,7 @@
 msgstr ""
 #: ../imagery/i.landsat.acca/main.c:158
-msgid ""
-"Bypass second-pass processing, and merge warm (not ambiguous) and cold "
-"clouds"
+msgid "Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
 msgstr ""
 #: ../imagery/i.landsat.acca/main.c:163
@@ -28242,9 +27267,7 @@
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:342
-msgid ""
-"Band number of MODIS product "
-"(mod09Q1=[1,2],mod09A1=[1-7],m[o/y]d09CMG=[1-7], mcd43B2q=[1-7])"
+msgid "Band number of MODIS product (mod09Q1=[1,2],mod09A1=[1-7],m[o/y]d09CMG=[1-7], mcd43B2q=[1-7])"
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:346
@@ -28447,9 +27470,7 @@
 msgstr ""
 #: ../misc/m.cogo/main.c:228
-msgid ""
-"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa."
+msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
 msgstr ""
 #: ../misc/m.cogo/main.c:230
@@ -28872,9 +27893,7 @@
 msgstr ""
 #: ../misc/m.nviz.image/args.c:903
-msgid ""
-"Place north arrow at given position \t(in screen coordinates from bottom "
-"left corner)"
+msgid "Place north arrow at given position \t(in screen coordinates from bottom left corner)"
 msgstr ""
 #: ../misc/m.nviz.image/args.c:905 ../misc/m.nviz.image/args.c:915
@@ -28942,9 +27961,7 @@
 msgstr ""
 #: ../misc/m.nviz.image/main.c:57
-msgid ""
-"Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
-"data) in 3D."
+msgid "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D."
 msgstr ""
 #: ../misc/m.nviz.image/main.c:83
@@ -29172,9 +28189,7 @@
 msgstr ""
 #: ../misc/m.nviz.script/main.c:439
-msgid ""
-"Skipping this point, selected point is outside region. Perhaps the camera "
-"setback distance puts it beyond the edge?"
+msgid "Skipping this point, selected point is outside region. Perhaps the camera setback distance puts it beyond the edge?"
 msgstr ""
 #: ../raster/r.in.bin/main.c:61 ../raster/r.in.bin/main.c:70
@@ -29297,9 +28312,7 @@
 #: ../raster/r.in.bin/main.c:554
 #, c-format
-msgid ""
-"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
-"significantly. Did you assign %s= and %s= correctly?"
+msgid "East-West (ewres: %f) and North-South (nwres: %f) resolution differ significantly. Did you assign %s= and %s= correctly?"
 msgstr ""
 #: ../raster/r.in.bin/main.c:575
@@ -29375,13 +28388,7 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:186
-msgid ""
-"The module has two different modes of operation: 1. Computes the entire "
-"horizon around a single point whose coordinates are given with the 'coord' "
-"option. The horizon height (in radians). 2. Computes one or more raster maps"
-" of the horizon height in a single direction. The input for this is the "
-"angle (in degrees), which is measured counterclockwise with east=0, north=90"
-" etc. The output is the horizon height in radians."
+msgid "The module has two different modes of operation: 1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction. The input for this is the angle (in degrees), which is measured counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
 msgstr ""
 #: ../raster/r.horizon/main.c:203
@@ -29408,33 +28415,23 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:237
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer around the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer around the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:245
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer eastward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer eastward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:253
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer westward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer westward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:261
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer northward the present"
-" region"
+msgid "For horizon rasters, read from the DEM an extra buffer northward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:269
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer southward the present"
-" region"
+msgid "For horizon rasters, read from the DEM an extra buffer southward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:277
@@ -29466,8 +28463,7 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:355
-msgid ""
-"Note: In latitude-longitude coordinate system specify buffers in degree unit"
+msgid "Note: In latitude-longitude coordinate system specify buffers in degree unit"
 msgstr ""
 #: ../raster/r.horizon/main.c:368
@@ -29556,9 +28552,7 @@
 msgstr ""
 #: ../raster/r.out.ascii/main.c:86
-msgid ""
-"Number of values printed before wrapping a line (only SURFER or MODFLOW "
-"format)"
+msgid "Number of values printed before wrapping a line (only SURFER or MODFLOW format)"
 msgstr ""
 #: ../raster/r.out.ascii/main.c:91
@@ -29660,10 +28654,7 @@
 msgstr ""
 #: ../raster/r.walk/main.c:183
-msgid ""
-"Creates a raster map showing the anisotropic cumulative cost of moving "
-"between different geographic locations on an input raster map whose cell "
-"category values represent cost."
+msgid "Creates a raster map showing the anisotropic cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
 msgstr ""
 #: ../raster/r.walk/main.c:193
@@ -30269,8 +29260,7 @@
 msgstr ""
 #: ../raster/r.proj/main.c:219
-msgid ""
-"Print input map's bounds in the current projection and exit (shell style)"
+msgid "Print input map's bounds in the current projection and exit (shell style)"
 msgstr ""
 #: ../raster/r.proj/main.c:254
@@ -30393,9 +29383,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:126
-msgid ""
-"Name of location to create or to read projection from for GCPs "
-"transformation"
+msgid "Name of location to create or to read projection from for GCPs transformation"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:143
@@ -30407,8 +29395,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:152
-msgid ""
-"Zero-padding of band number by filling with leading zeros up to given number"
+msgid "Zero-padding of band number by filling with leading zeros up to given number"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:153
@@ -30432,9 +29419,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:220
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not"
-" import the raster file."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the raster file."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:225
@@ -30454,8 +29439,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:265
-msgid ""
-"The number of digits for band numbering must be equal or greater than 0"
+msgid "The number of digits for band numbering must be equal or greater than 0"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:284
@@ -30470,9 +29454,7 @@
 #: ../raster/r.in.gdal/main.c:337
 #, c-format
-msgid ""
-"Input seems to be NOAA/AVHRR data which needs to be georeferenced with thin "
-"plate spline transformation (%s or %s)."
+msgid "Input seems to be NOAA/AVHRR data which needs to be georeferenced with thin plate spline transformation (%s or %s)."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:356 ../raster/r.in.gdal/main.c:703
@@ -30482,22 +29464,15 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:376
-msgid ""
-"Input raster map is flipped or rotated - cannot import. You may use "
-"'gdalwarp' to transform the map to North-up."
+msgid "Input raster map is flipped or rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:417
-msgid ""
-"Map bounds have been constrained to geographic coordinates. You will almost "
-"certainly want to check map bounds and resolution with r.info and reset them"
-" with r.region before going any further."
+msgid "Map bounds have been constrained to geographic coordinates. You will almost certainly want to check map bounds and resolution with r.info and reset them with r.region before going any further."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:458 ../raster/r.external/proj.c:18
-msgid ""
-"Unable to convert input raster map projection information to GRASS format "
-"for checking"
+msgid "Unable to convert input raster map projection information to GRASS format for checking"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:491 ../raster/r.external/proj.c:47
@@ -30509,9 +29484,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:560 ../raster/r.external/proj.c:111
-msgid ""
-"Consider generating a new location from the input dataset using the "
-"'location' parameter.\n"
+msgid "Consider generating a new location from the input dataset using the 'location' parameter.\n"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:584
@@ -30563,9 +29536,7 @@
 #: ../raster/r.in.gdal/main.c:859
 #, c-format
-msgid ""
-"The target for the output group <%s> has been set to location <%s>, mapset "
-"<PERMANENT>."
+msgid "The target for the output group <%s> has been set to location <%s>, mapset <PERMANENT>."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:930
@@ -30651,9 +29622,7 @@
 msgstr ""
 #: ../raster/r.topmodel/main.c:94
-msgid ""
-"Must be clipped to the catchment boundary. Used for generating "
-"outtopidxstats"
+msgid "Must be clipped to the catchment boundary. Used for generating outtopidxstats"
 msgstr ""
 #: ../raster/r.topmodel/main.c:96 ../raster/r.topmodel/main.c:106
@@ -30786,10 +29755,7 @@
 msgstr ""
 #: ../raster/r.sunhours/main.c:77
-msgid ""
-"Solar elevation: the angle between the direction of the geometric center of "
-"the sun's apparent disk and the (idealized) horizon. Solar azimuth: the "
-"angle from due north in clockwise direction."
+msgid "Solar elevation: the angle between the direction of the geometric center of the sun's apparent disk and the (idealized) horizon. Solar azimuth: the angle from due north in clockwise direction."
 msgstr ""
 #: ../raster/r.sunhours/main.c:83
@@ -31135,9 +30101,7 @@
 #: ../raster/r.regression.line/main.c:65
 #: ../raster/r.regression.multi/main.c:157
-msgid ""
-"ASCII file for storing regression coefficients (output to screen if file not"
-" specified)."
+msgid "ASCII file for storing regression coefficients (output to screen if file not specified)."
 msgstr ""
 #: ../raster/r.param.scale/main.c:42
@@ -31161,9 +30125,7 @@
 msgstr ""
 #: ../raster/r.param.scale/interface.c:60
-msgid ""
-"Uses a multi-scale approach by taking fitting quadratic parameters to any "
-"size window (via least squares)."
+msgid "Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
 msgstr ""
 #: ../raster/r.param.scale/interface.c:78
@@ -31419,9 +30381,7 @@
 msgstr ""
 #: ../raster/r.li/r.li.patchdensity/main.c:50
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour "
-"algorithm"
+msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../raster/r.li/r.li.pielou/pielou.c:45
@@ -31508,14 +30468,11 @@
 msgstr ""
 #: ../raster/r.li/r.li.patchnum/main.c:49
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour "
-"algorithm."
+msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
 msgstr ""
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:47
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:68
@@ -31523,9 +30480,7 @@
 msgstr ""
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:69
-msgid ""
-"It can be integer, double or float; it will be changed in function of map "
-"type"
+msgid "It can be integer, double or float; it will be changed in function of map type"
 msgstr ""
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:74
@@ -31541,9 +30496,7 @@
 msgstr ""
 #: ../raster/r.li/r.li.mps/mps.c:51
-msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
+msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../raster/r.li/r.li.shannon/shannon.c:45
@@ -31564,9 +30517,7 @@
 msgstr ""
 #: ../raster/r.category/main.c:55
-msgid ""
-"Manages category values and labels associated with user-specified raster map"
-" layers."
+msgid "Manages category values and labels associated with user-specified raster map layers."
 msgstr ""
 #: ../raster/r.category/main.c:69
@@ -31635,10 +30586,7 @@
 msgstr ""
 #: ../raster/r.his/main.c:73
-msgid ""
-"Generates red, green and blue (RGB) raster map layers combining hue, "
-"intensity and saturation (HIS) values from user-specified input raster map "
-"layers."
+msgid "Generates red, green and blue (RGB) raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
 msgstr ""
 #: ../raster/r.his/main.c:103
@@ -31683,9 +30631,7 @@
 msgstr ""
 #: ../raster/r.to.rast3/main.c:230
-msgid ""
-"The 2D and 3D region settings are different. Using the 3D region settings to"
-" adjust the 2D region."
+msgid "The 2D and 3D region settings are different. Using the 3D region settings to adjust the 2D region."
 msgstr ""
 #: ../raster/r.to.rast3/main.c:262
@@ -31710,10 +30656,7 @@
 msgstr ""
 #: ../raster/r.resamp.rst/main.c:151
-msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
+msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
 msgstr ""
 #: ../raster/r.resamp.rst/main.c:162
@@ -31881,9 +30824,7 @@
 msgstr ""
 #: ../raster/r.stats.zonal/main.c:105
-msgid ""
-"Calculates category or object oriented statistics (accumulator-based "
-"statistics)."
+msgid "Calculates category or object oriented statistics (accumulator-based statistics)."
 msgstr ""
 #: ../raster/r.stats.zonal/main.c:115 ../raster/r.statistics/main.c:69
@@ -31989,9 +30930,8 @@
 msgstr ""
 #: ../raster/r.relief/main.c:316 ../raster/r.series/main.c:386
-#: ../raster/r.series.accumulate/main.c:318
-#: ../raster/r.slope.aspect/main.c:544 ../raster/r.patch/main.c:140
-#: ../raster/r.series.interp/main.c:339
+#: ../raster/r.series.accumulate/main.c:318 ../raster/r.slope.aspect/main.c:544
+#: ../raster/r.patch/main.c:140 ../raster/r.series.interp/main.c:339
 msgid "Percent complete..."
 msgstr ""
@@ -32016,15 +30956,11 @@
 msgstr ""
 #: ../raster/r.neighbors/main.c:175
-msgid ""
-"Makes each cell category value a function of the category values assigned to"
-" the cells around it, and stores new cell values in an output raster map "
-"layer."
+msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
 msgstr ""
 #: ../raster/r.neighbors/main.c:185
-msgid ""
-"Name of an input raster map to select the cells which should be processed"
+msgid "Name of an input raster map to select the cells which should be processed"
 msgstr ""
 #: ../raster/r.neighbors/main.c:206 ../raster/r.neighbors/main.c:214
@@ -32068,15 +31004,12 @@
 #: ../raster/r.neighbors/main.c:329
 #, c-format
-msgid ""
-"Method %s not compatible with weighing window, using weight mask instead"
+msgid "Method %s not compatible with weighing window, using weight mask instead"
 msgstr ""
 #: ../raster/r.neighbors/main.c:337
 #, c-format
-msgid ""
-"Method %s not compatible with Gaussian filter, using unweighed version "
-"instead"
+msgid "Method %s not compatible with Gaussian filter, using unweighed version instead"
 msgstr ""
 #: ../raster/r.neighbors/main.c:386
@@ -32085,16 +31018,12 @@
 msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:66
-msgid ""
-"Unable to calculate sun position in un-projected locations. Specify "
-"sunposition directly."
+msgid "Unable to calculate sun position in un-projected locations. Specify sunposition directly."
 msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:88
 #, c-format
-msgid ""
-"Specified point %f, %f outside of current region, is that intended? Anyway, "
-"it will be used."
+msgid "Specified point %f, %f outside of current region, is that intended? Anyway, it will be used."
 msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:98 ../raster/r.latlong/main.c:101
@@ -32114,14 +31043,11 @@
 msgstr ""
 #: ../raster/r.sunmask/main.c:120
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map."
+msgid "Calculates cast shadow areas from sun position and elevation raster map."
 msgstr ""
 #: ../raster/r.sunmask/main.c:121
-msgid ""
-"Either exact sun position (A) is specified, or date/time to calculate the "
-"sun position (B) by r.sunmask itself."
+msgid "Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
 msgstr ""
 #: ../raster/r.sunmask/main.c:135
@@ -32206,9 +31132,7 @@
 msgstr ""
 #: ../raster/r.sunmask/main.c:282
-msgid ""
-"Neither sun position nor east/north, date/time/timezone definition are "
-"complete"
+msgid "Neither sun position nor east/north, date/time/timezone definition are complete"
 msgstr ""
 #: ../raster/r.sunmask/main.c:286
@@ -32217,9 +31141,7 @@
 msgstr ""
 #: ../raster/r.sunmask/main.c:291
-msgid ""
-"Using user defined sun azimuth, altitude settings (ignoring eventual other "
-"values)"
+msgid "Using user defined sun azimuth, altitude settings (ignoring eventual other values)"
 msgstr ""
 #: ../raster/r.sunmask/main.c:399
@@ -32280,9 +31202,7 @@
 msgstr ""
 #: ../raster/r.colors/edit_colors.c:83
-msgid ""
-"Input map names can be defined in an input file in case a large amount of "
-"maps must be specified. This option is mutual exclusive to the map option."
+msgid "Input map names can be defined in an input file in case a large amount of maps must be specified. This option is mutual exclusive to the map option."
 msgstr ""
 #: ../raster/r.colors/edit_colors.c:110
@@ -32425,8 +31345,7 @@
 msgstr ""
 #: ../raster/r.drain/main.c:113
-msgid ""
-"Traces a flow through an elevation model or cost surface on a raster map."
+msgid "Traces a flow through an elevation model or cost surface on a raster map."
 msgstr ""
 #: ../raster/r.drain/main.c:116
@@ -32470,9 +31389,7 @@
 msgstr ""
 #: ../raster/r.drain/main.c:163
-msgid ""
-"The input raster map is a cost surface (direction surface must also be "
-"specified)"
+msgid "The input raster map is a cost surface (direction surface must also be specified)"
 msgstr ""
 #: ../raster/r.drain/main.c:175
@@ -32485,16 +31402,12 @@
 #: ../raster/r.drain/main.c:183
 #, c-format
-msgid ""
-"Direction raster map <%s> not specified, if direction flag is on, a "
-"direction raster must be given"
+msgid "Direction raster map <%s> not specified, if direction flag is on, a direction raster must be given"
 msgstr ""
 #: ../raster/r.drain/main.c:190
 #, c-format
-msgid ""
-"Direction raster map <%s> should not be specified for Surface/Hydrology "
-"drains"
+msgid "Direction raster map <%s> should not be specified for Surface/Hydrology drains"
 msgstr ""
 #: ../raster/r.drain/main.c:209
@@ -32573,9 +31486,7 @@
 #: ../raster/r.texture/h_measure.c:141
 #, c-format
-msgid ""
-"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
-"map"
+msgid "Too many categories (found: %i, max: %i). Try to rescale or reclassify the map"
 msgstr ""
 #: ../raster/r.texture/main.c:68
@@ -32628,9 +31539,7 @@
 msgstr ""
 #: ../raster/r.texture/main.c:172
-msgid ""
-"The distance between two samples must be smaller than the size of the moving"
-" window"
+msgid "The distance between two samples must be smaller than the size of the moving window"
 msgstr ""
 #: ../raster/r.texture/main.c:193
@@ -32644,20 +31553,15 @@
 msgstr[0] ""
 #: ../raster/r.series/main.c:141
-msgid ""
-"Makes each output cell value a function of the values assigned to the "
-"corresponding cells in the input raster map layers."
+msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
 msgstr ""
 #: ../raster/r.series/main.c:150
-msgid ""
-"Input file with one raster map name and optional one weight per line, field "
-"separator between name and weight is |"
+msgid "Input file with one raster map name and optional one weight per line, field separator between name and weight is |"
 msgstr ""
 #: ../raster/r.series/main.c:176
-msgid ""
-"Weighting factor for each input map, default value is 1.0 for each input map"
+msgid "Weighting factor for each input map, default value is 1.0 for each input map"
 msgstr ""
 #: ../raster/r.series/main.c:183 ../raster/r.series.accumulate/main.c:132
@@ -32735,9 +31639,7 @@
 msgstr ""
 #: ../raster/r.profile/main.c:103
-msgid ""
-"If units are not specified, current location units are used. Meters are used"
-" by default in geographic (latlon) locations."
+msgid "If units are not specified, current location units are used. Meters are used by default in geographic (latlon) locations."
 msgstr ""
 #: ../raster/r.profile/main.c:117
@@ -32822,9 +31724,7 @@
 msgstr ""
 #: ../raster/r.covar/main.c:54
-msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map "
-"layer(s)."
+msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
 msgstr ""
 #: ../raster/r.covar/main.c:61
@@ -32841,9 +31741,7 @@
 msgstr ""
 #: ../raster/r.out.vtk/main.c:73
-msgid ""
-"No input maps specified. You need to specify at least one input map or three"
-" vector maps or three rgb maps."
+msgid "No input maps specified. You need to specify at least one input map or three vector maps or three rgb maps."
 msgstr ""
 #: ../raster/r.out.vtk/main.c:131 ../raster/r.out.vtk/main.c:191
@@ -32865,8 +31763,7 @@
 msgstr ""
 #: ../raster/r.out.vtk/main.c:271
-msgid ""
-"Wrong vector maps. Maps should have the same type! Vector output not added!"
+msgid "Wrong vector maps. Maps should have the same type! Vector output not added!"
 msgstr ""
 #: ../raster/r.out.vtk/main.c:283
@@ -32882,8 +31779,7 @@
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:69
-msgid ""
-"Three (r,g,b) raster maps to create RGB values [redmap,greenmap,bluemap]"
+msgid "Three (r,g,b) raster maps to create RGB values [redmap,greenmap,bluemap]"
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:79
@@ -32899,8 +31795,7 @@
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:116
-msgid ""
-"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
+msgid "Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:122
@@ -33151,23 +32046,19 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:83
-msgid ""
-"depression map indicates all the locations in the current map window where"
+msgid "depression map indicates all the locations in the current map window where"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:84
-msgid ""
-"water accumulates and does not leave by the edge of the map. Lakes without"
+msgid "water accumulates and does not leave by the edge of the map. Lakes without"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:85
-msgid ""
-"outlet streams and sinkholes are examples of `depressions'.  If you wish to"
+msgid "outlet streams and sinkholes are examples of `depressions'.  If you wish to"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:86
-msgid ""
-"have a depression map, prepare a map where non-zero values indicate the"
+msgid "have a depression map, prepare a map where non-zero values indicate the"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:87
@@ -33175,8 +32066,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:88
-msgid ""
-"Hit <return> by itself for the next question if there is no depression map."
+msgid "Hit <return> by itself for the next question if there is no depression map."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:99
@@ -33187,14 +32077,11 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:101
-msgid ""
-"watershed basins.  The number of watershed basins is indirectly determined"
+msgid "watershed basins.  The number of watershed basins is indirectly determined"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:102
-msgid ""
-"by the `basin threshold' value.  The basin threshold is the area necessary "
-"for"
+msgid "by the `basin threshold' value.  The basin threshold is the area necessary for"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:103
@@ -33203,18 +32090,15 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:105
-msgid ""
-"`exterior drainage basins'.  An exterior drainage basin does not have any"
+msgid "`exterior drainage basins'.  An exterior drainage basin does not have any"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:106
-msgid ""
-"drainage basins flowing into it.  Interior drainage basin size is determined"
+msgid "drainage basins flowing into it.  Interior drainage basin size is determined"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:107
-msgid ""
-"by the surface flow going into stream segments between stream interceptions."
+msgid "by the surface flow going into stream segments between stream interceptions."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:108
@@ -33227,19 +32111,15 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:111
-msgid ""
-"(i.e., areas with low infiltration capacities will need smaller areas to"
+msgid "(i.e., areas with low infiltration capacities will need smaller areas to"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:112
-msgid ""
-"develop stream channels than neighboring areas with high infiltration "
-"rates)."
+msgid "develop stream channels than neighboring areas with high infiltration rates)."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:113
-msgid ""
-"The user can create a map layer with potential overland flow values, and"
+msgid "The user can create a map layer with potential overland flow values, and"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:114
@@ -33345,8 +32225,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:296
-msgid ""
-"ability to generate several variables in the Revised Universal Soil Loss"
+msgid "ability to generate several variables in the Revised Universal Soil Loss"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:297
@@ -33365,9 +32244,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:351
-msgid ""
-"where the value indicates the percent of disturbed (barren) land in that "
-"cell."
+msgid "where the value indicates the percent of disturbed (barren) land in that cell."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:352
@@ -33408,8 +32285,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:384
-msgid ""
-"that prevents the surface flow distance from getting too long.  Normally,"
+msgid "that prevents the surface flow distance from getting too long.  Normally,"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:385
@@ -33423,8 +32299,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:401
-msgid ""
-"slope length.  You may input a raster map indicating the locations of these"
+msgid "slope length.  You may input a raster map indicating the locations of these"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:402
@@ -33432,8 +32307,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:403
-msgid ""
-"Hit <return> by itself for the next question if there is no blocking map."
+msgid "Hit <return> by itself for the next question if there is no blocking map."
 msgstr ""
 #: ../raster/r.watershed/shed/file_in.c:15
@@ -33524,8 +32398,7 @@
 msgid "Name of input raster map percent of disturbed land"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:97
-#: ../raster/r.watershed/front/main.c:122
+#: ../raster/r.watershed/front/main.c:97 ../raster/r.watershed/front/main.c:122
 msgid "For USLE"
 msgstr ""
@@ -33534,9 +32407,7 @@
 msgstr ""
 #: ../raster/r.watershed/front/main.c:106
-msgid ""
-"For USLE. All non-NULL and non-zero cells are considered as blocking "
-"terrain."
+msgid "For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
 msgstr ""
 #: ../raster/r.watershed/front/main.c:113
@@ -33628,9 +32499,7 @@
 msgstr ""
 #: ../raster/r.watershed/front/main.c:223
-msgid ""
-"Only needed if memory requirements exceed available RAM; see manual on how "
-"to calculate memory requirements"
+msgid "Only needed if memory requirements exceed available RAM; see manual on how to calculate memory requirements"
 msgstr ""
 #: ../raster/r.watershed/front/main.c:228
@@ -33813,8 +32682,7 @@
 #: ../raster/r.watershed/ram/do_cum.c:480
 #, c-format
 msgid "MFD: A * path already processed when distributing flow: %d of %d cell"
-msgid_plural ""
-"MFD: A * path already processed when distributing flow: %d of %d cells"
+msgid_plural "MFD: A * path already processed when distributing flow: %d of %d cells"
 msgstr[0] ""
 #: ../raster/r.watershed/ram/do_astar.c:256
@@ -33930,14 +32798,11 @@
 msgstr ""
 #: ../raster/r.to.rast3elev/main.c:427
-msgid ""
-"The 2D and 3D region settings are different. I will use the 3D region "
-"settings to adjust the 2D region."
+msgid "The 2D and 3D region settings are different. I will use the 3D region settings to adjust the 2D region."
 msgstr ""
 #: ../raster/r.grow.distance/main.c:156
-msgid ""
-"Generates a raster map containing distances to nearest raster features."
+msgid "Generates a raster map containing distances to nearest raster features."
 msgstr ""
 #: ../raster/r.grow.distance/main.c:163
@@ -34247,9 +33112,7 @@
 msgstr ""
 #: ../raster/r.flow/main.c:425
-msgid ""
-"Computes flowlines, flowpath lengths, and flowaccumulation (contributing "
-"areas) from a elevation raster map."
+msgid "Computes flowlines, flowpath lengths, and flowaccumulation (contributing areas) from a elevation raster map."
 msgstr ""
 #: ../raster/r.flow/main.c:435 ../raster/r.flow/main.c:441
@@ -34304,9 +33167,7 @@
 msgstr ""
 #: ../raster/r.flow/main.c:555
-msgid ""
-"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
-"calculating flow accumulation."
+msgid "lat/long projection not supported by r.flow. Please use 'r.watershed' for calculating flow accumulation."
 msgstr ""
 #: ../raster/r.flow/mem.c:40
@@ -34396,8 +33257,7 @@
 msgstr ""
 #: ../raster/r.in.lidar/main.c:116
-msgid ""
-"Creates a raster map from LAS LiDAR points using univariate statistics."
+msgid "Creates a raster map from LAS LiDAR points using univariate statistics."
 msgstr ""
 #: ../raster/r.in.lidar/main.c:130
@@ -34461,8 +33321,7 @@
 msgstr ""
 #: ../raster/r.in.lidar/main.c:182
-msgid ""
-"The scale for Z is applied beforehand, the range filter for Z afterwards"
+msgid "The scale for Z is applied beforehand, the range filter for Z afterwards"
 msgstr ""
 #: ../raster/r.in.lidar/main.c:191
@@ -34502,9 +33361,7 @@
 msgstr ""
 #: ../raster/r.in.lidar/main.c:293
-msgid ""
-"Set computation region to match the 2D extent and resolution of the newly "
-"created new raster map"
+msgid "Set computation region to match the 2D extent and resolution of the newly created new raster map"
 msgstr ""
 #: ../raster/r.in.lidar/main.c:317
@@ -34524,9 +33381,7 @@
 msgstr ""
 #: ../raster/r.in.lidar/main.c:332
-msgid ""
-"For getting values from base raster, use its actual resolution instead of "
-"computational region resolution"
+msgid "For getting values from base raster, use its actual resolution instead of computational region resolution"
 msgstr ""
 #: ../raster/r.in.lidar/main.c:355
@@ -34549,8 +33404,7 @@
 msgstr ""
 #: ../raster/r.in.lidar/main.c:419
-msgid ""
-"First file's projection checked, checking projection of the other files..."
+msgid "First file's projection checked, checking projection of the other files..."
 msgstr ""
 #: ../raster/r.in.lidar/main.c:457
@@ -34574,9 +33428,7 @@
 #: ../raster/r.in.lidar/main.c:590
 #, c-format
-msgid ""
-"Unable to process the hole map at once. Please set the '%s' option to some "
-"value lower than 100."
+msgid "Unable to process the hole map at once. Please set the '%s' option to some value lower than 100."
 msgstr ""
 #: ../raster/r.in.lidar/main.c:610
@@ -34628,9 +33480,7 @@
 msgstr ""
 #: ../raster/r.reclass/main.c:54
-msgid ""
-"Creates a new raster map whose category values are based upon a "
-"reclassification of the categories in an existing raster map."
+msgid "Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
 msgstr ""
 #: ../raster/r.reclass/main.c:59
@@ -34766,9 +33616,7 @@
 #: ../raster/r.resamp.bspline/crosscorr.c:160
 #, c-format
-msgid ""
-"%d are too many cells, recommended are < 100 cells. The cross validation "
-"would take too much time."
+msgid "%d are too many cells, recommended are < 100 cells. The cross validation would take too much time."
 msgstr ""
 #: ../raster/r.resamp.bspline/crosscorr.c:169
@@ -34782,9 +33630,7 @@
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:85
-msgid ""
-"Performs bilinear or bicubic spline interpolation with Tykhonov "
-"regularization."
+msgid "Performs bilinear or bicubic spline interpolation with Tykhonov regularization."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:93
@@ -34796,14 +33642,11 @@
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:107
-msgid ""
-"Length of each spline step in the east-west direction. Default: 1.5 * ewres."
+msgid "Length of each spline step in the east-west direction. Default: 1.5 * ewres."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:115
-msgid ""
-"Length of each spline step in the north-south direction. Default: 1.5 * "
-"nsres."
+msgid "Length of each spline step in the north-south direction. Default: 1.5 * nsres."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:138
@@ -35030,9 +33873,7 @@
 msgstr ""
 #: ../raster/r.in.xyz/main.c:165
-msgid ""
-"Creates a raster map from an assemblage of many coordinates using univariate"
-" statistics."
+msgid "Creates a raster map from an assemblage of many coordinates using univariate statistics."
 msgstr ""
 #: ../raster/r.in.xyz/main.c:169
@@ -35044,9 +33885,7 @@
 msgstr ""
 #: ../raster/r.in.xyz/main.c:237
-msgid ""
-"If a separate value column is given, this option refers to the z-coordinate "
-"column to be filtered by the zrange option"
+msgid "If a separate value column is given, this option refers to the z-coordinate column to be filtered by the zrange option"
 msgstr ""
 #: ../raster/r.in.xyz/main.c:248
@@ -35097,14 +33936,11 @@
 #: ../raster/r.in.xyz/main.c:534
 #, c-format
-msgid ""
-"Unable to process the hole map at once. Please set the %s option to some "
+msgid "Unable to process the hole map at once. Please set the %s option to some value lower than 100."
 msgstr ""
 #: ../raster/r.in.xyz/main.c:587
-msgid ""
-"If input is not from a file it is only possible to perform a single pass."
+msgid "If input is not from a file it is only possible to perform a single pass."
 msgstr ""
 #: ../raster/r.in.xyz/main.c:599
@@ -35274,23 +34110,17 @@
 #: ../raster/r.stats/main.c:303
 #, c-format
-msgid ""
-"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
-"will be ignored."
+msgid "Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option will be ignored."
 msgstr ""
 #: ../raster/r.stats/main.c:319
 #, c-format
-msgid ""
-"Cats for raster map <%s> are either missing or have no explicit labels. "
-"Using %s=%d."
+msgid "Cats for raster map <%s> are either missing or have no explicit labels. Using %s=%d."
 msgstr ""
 #: ../raster/r.stats/main.c:325
 #, c-format
-msgid ""
-"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s'"
-" option"
+msgid "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' option"
 msgstr ""
 #: ../raster/r.stats/raw_stats.c:118
@@ -35320,11 +34150,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:220
-msgid ""
-"Generates three, or four raster map layers showing the base (perpendicular) "
-"rate of spread (ROS), the maximum (forward) ROS, the direction of the "
-"maximum ROS, and optionally the maximum potential spotting distance for fire"
-" spread simulation."
+msgid "Generates three, or four raster map layers showing the base (perpendicular) rate of spread (ROS), the maximum (forward) ROS, the direction of the maximum ROS, and optionally the maximum potential spotting distance for fire spread simulation."
 msgstr ""
 #: ../raster/r.ros/main.c:227
@@ -35332,10 +34158,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:229
-msgid ""
-"Name of an existing raster map layer in the user's current mapset search "
-"path containing the standard fuel models defined by the USDA Forest Service."
-" Valid values are 1-13; other numbers are recognized as barriers by r.ros."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the standard fuel models defined by the USDA Forest Service. Valid values are 1-13; other numbers are recognized as barriers by r.ros."
 msgstr ""
 #: ../raster/r.ros/main.c:238
@@ -35343,10 +34166,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:240 ../raster/r.spread/main.c:205
-msgid ""
-"path containing the 1-hour (<.25\") fuel moisture (percentage content "
-"multiplied by 100)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the 1-hour (<.25\") fuel moisture (percentage content multiplied by 100)."
 msgstr ""
 #: ../raster/r.ros/main.c:248
@@ -35354,10 +34174,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:250
-msgid ""
-"path containing the 10-hour (.25-1\") fuel moisture (percentage content "
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the 10-hour (.25-1\") fuel moisture (percentage content multiplied by 100)."
 msgstr ""
 #: ../raster/r.ros/main.c:258
@@ -35365,10 +34182,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:260
-msgid ""
-"path containing the 100-hour (1-3\") fuel moisture (percentage content "
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the 100-hour (1-3\") fuel moisture (percentage content multiplied by 100)."
 msgstr ""
 #: ../raster/r.ros/main.c:267
@@ -35376,10 +34190,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:269
-msgid ""
-"path containing live (herbaceous) fuel moisture (percentage content "
+msgid "Name of an existing raster map layer in the user's current mapset search path containing live (herbaceous) fuel moisture (percentage content multiplied by 100)."
 msgstr ""
 #: ../raster/r.ros/main.c:277
@@ -35387,10 +34198,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:279 ../raster/r.spread/main.c:193
-msgid ""
-"path containing wind velocities at half of the average flame height "
-"(feet/minute)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing wind velocities at half of the average flame height (feet/minute)."
 msgstr ""
 #: ../raster/r.ros/main.c:287
@@ -35398,9 +34206,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:289
-msgid ""
-"path containing wind direction, clockwise from north (degree)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing wind direction, clockwise from north (degree)."
 msgstr ""
 #: ../raster/r.ros/main.c:297
@@ -35408,9 +34214,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:299
-msgid ""
-"path containing topographic slope (degree)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing topographic slope (degree)."
 msgstr ""
 #: ../raster/r.ros/main.c:307
@@ -35418,10 +34222,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:309
-msgid ""
-"path containing topographic aspect, counterclockwise from east (GRASS "
-"convention) in degrees."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing topographic aspect, counterclockwise from east (GRASS convention) in degrees."
 msgstr ""
 #: ../raster/r.ros/main.c:317
@@ -35429,10 +34230,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:319
-msgid ""
-"path containing elevation (meters). Option is required from spotting "
-"distance computation (when spotting_distance option is provided)"
+msgid "Name of an existing raster map layer in the user's current mapset search path containing elevation (meters). Option is required from spotting distance computation (when spotting_distance option is provided)"
 msgstr ""
 #: ../raster/r.ros/main.c:328
@@ -35464,29 +34262,21 @@
 msgstr ""
 #: ../raster/r.ros/main.c:354
-msgid ""
-"The maximal potential spotting distance (requires elevation raster map to be"
-" provided)."
+msgid "The maximal potential spotting distance (requires elevation raster map to be provided)."
 msgstr ""
 #: ../raster/r.ros/main.c:373
-msgid ""
-"No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h "
-"moisture layers is required."
+msgid "No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h moisture layers is required."
 msgstr ""
 #: ../raster/r.ros/main.c:397
 #, c-format
-msgid ""
-"A wind direction layer should be given if the wind velocity layer <%s> has "
-"been given"
+msgid "A wind direction layer should be given if the wind velocity layer <%s> has been given"
 msgstr ""
 #: ../raster/r.ros/main.c:402
 #, c-format
-msgid ""
-"A wind velocity layer should be given if the wind direction layer <%s> has "
-"been given"
+msgid "A wind velocity layer should be given if the wind direction layer <%s> has been given"
 msgstr ""
 #: ../raster/r.ros/main.c:416
@@ -35546,14 +34336,11 @@
 msgstr ""
 #: ../raster/r.volume/main.c:81
-msgid ""
-"Optionally produces a GRASS vector points map containing the calculated "
-"centroids of these clumps."
+msgid "Optionally produces a GRASS vector points map containing the calculated centroids of these clumps."
 msgstr ""
 #: ../raster/r.volume/main.c:86
-msgid ""
-"Name of input raster map representing data that will be summed within clumps"
+msgid "Name of input raster map representing data that will be summed within clumps"
 msgstr ""
 #: ../raster/r.volume/main.c:92
@@ -35561,9 +34348,7 @@
 msgstr ""
 #: ../raster/r.volume/main.c:93
-msgid ""
-"Preferably the output of r.clump. If no clump map is given than MASK is "
-"used."
+msgid "Preferably the output of r.clump. If no clump map is given than MASK is used."
 msgstr ""
 #: ../raster/r.volume/main.c:99
@@ -35583,9 +34368,7 @@
 msgstr ""
 #: ../raster/r.volume/main.c:143
-msgid ""
-"No MASK found. If no clump map is given than the MASK is required. You need "
-"to define a clump raster map or create a MASK by r.mask command."
+msgid "No MASK found. If no clump map is given than the MASK is required. You need to define a clump raster map or create a MASK by r.mask command."
 msgstr ""
 #: ../raster/r.volume/main.c:145
@@ -35639,8 +34422,7 @@
 msgstr ""
 #: ../raster/r.sim/r.sim.water/main.c:120
-msgid ""
-"Overland flow hydrologic simulation using path sampling method (SIMWE)."
+msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
 msgstr ""
 #: ../raster/r.sim/r.sim.water/main.c:127
@@ -35707,9 +34489,7 @@
 #: ../raster/r.sim/r.sim.water/main.c:222
 #: ../raster/r.sim/r.sim.sediment/main.c:211
-msgid ""
-"Name for sampling points output text file. For each observation vector point"
-" the time series of sediment transport is stored."
+msgid "Name for sampling points output text file. For each observation vector point the time series of sediment transport is stored."
 msgstr ""
 #: ../raster/r.sim/r.sim.water/main.c:230
@@ -35758,9 +34538,7 @@
 #: ../raster/r.sim/r.sim.water/main.c:306
 #: ../raster/r.sim/r.sim.sediment/main.c:270
-msgid ""
-"The same seed can be used to obtain same results or random seed can be "
-"generated by other means."
+msgid "The same seed can be used to obtain same results or random seed can be generated by other means."
 msgstr ""
 #: ../raster/r.sim/r.sim.water/main.c:312
@@ -35770,9 +34548,7 @@
 #: ../raster/r.sim/r.sim.water/main.c:314
 #: ../raster/r.sim/r.sim.sediment/main.c:278
-msgid ""
-"Automatically generates random seed for random number generator (use when "
-"you don't want to provide the seed option)"
+msgid "Automatically generates random seed for random number generator (use when you don't want to provide the seed option)"
 msgstr ""
 #: ../raster/r.sim/r.sim.water/main.c:322
@@ -35822,9 +34598,7 @@
 msgstr ""
 #: ../raster/r.sim/r.sim.sediment/main.c:121
-msgid ""
-"Sediment transport and erosion/deposition simulation using path sampling "
-"method (SIMWE)."
+msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
 msgstr ""
 #: ../raster/r.sim/r.sim.sediment/main.c:128
@@ -35848,8 +34622,7 @@
 msgstr ""
 #: ../raster/r.sim/r.sim.sediment/main.c:184
-msgid ""
-"Name for output transport limited erosion-deposition raster map [kg/m2s]"
+msgid "Name for output transport limited erosion-deposition raster map [kg/m2s]"
 msgstr ""
 #: ../raster/r.sim/r.sim.sediment/main.c:191
@@ -35872,16 +34645,13 @@
 msgid "You are not outputting any raster or site files"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:411
-#: ../raster/r.sim/simlib/hydro.c:465
+#: ../raster/r.sim/r.sim.sediment/main.c:411 ../raster/r.sim/simlib/hydro.c:465
 msgid "Cannot write raster maps"
 msgstr ""
 #: ../raster/r.sim/simlib/input.c:307
 #, c-format
-msgid ""
-"Raster map <%s> not found, and manin_val undefined, choose one to be allowed"
-" to process"
+msgid "Raster map <%s> not found, and manin_val undefined, choose one to be allowed to process"
 msgstr ""
 #: ../raster/r.sim/simlib/input.c:420
@@ -35966,9 +34736,7 @@
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:84
-msgid ""
-"Makes each output cell value a accumulationfunction of the values assigned "
-"to the corresponding cells in the input raster map layers."
+msgid "Makes each output cell value a accumulationfunction of the values assigned to the corresponding cells in the input raster map layers."
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:90
@@ -35988,14 +34756,11 @@
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:121
-msgid ""
-"The raster map specifying the lower accumulation limit, also called baseline"
+msgid "The raster map specifying the lower accumulation limit, also called baseline"
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:126
-msgid ""
-"The raster map specifying the upper accumulation limit, also called cutoff. "
-"Only applied to BEDD computation."
+msgid "The raster map specifying the upper accumulation limit, also called cutoff. Only applied to BEDD computation."
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:139
@@ -36097,9 +34862,7 @@
 msgstr ""
 #: ../raster/r.out.gdal/main.c:220
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
-"Not supported by all output format drivers."
+msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. Not supported by all output format drivers."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:230
@@ -36107,9 +34870,7 @@
 msgstr ""
 #: ../raster/r.out.gdal/main.c:232
-msgid ""
-"If given, the nodata value is always written to metadata even if there are "
-"no NULL cells in the input band (enhances output compatibility)."
+msgid "If given, the nodata value is always written to metadata even if there are no NULL cells in the input band (enhances output compatibility)."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:264
@@ -36129,9 +34890,7 @@
 #: ../raster/r.out.gdal/main.c:288
 #, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:293
@@ -36159,23 +34918,17 @@
 #: ../raster/r.out.gdal/main.c:455
 #, c-format
-msgid ""
-"Precision loss: Raster map <%s> of type %s to be exported as %s. This can be"
-" avoided by using %s."
+msgid "Precision loss: Raster map <%s> of type %s to be exported as %s. This can be avoided by using %s."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:466
 #, c-format
-msgid ""
-"Precision loss: The range of <%s> can not be accurately preserved with GDAL "
-"datatype Float32. This can be avoided by exporting to Int32 or Float64."
+msgid "Precision loss: The range of <%s> can not be accurately preserved with GDAL datatype Float32. This can be avoided by exporting to Int32 or Float64."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:474
 #, c-format
-msgid ""
-"Precision loss: Float32 can not preserve the DCELL precision of raster <%s>."
-" This can be avoided by using Float64"
+msgid "Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. This can be avoided by using Float64"
 msgstr ""
 #: ../raster/r.out.gdal/main.c:483
@@ -36287,10 +35040,7 @@
 #: ../raster/r.out.gdal/main.c:791 ../raster/r.out.gdal/main.c:804
 #: ../raster/r.out.gdal/main.c:819
 #, c-format
-msgid ""
-"Mismatch between metadata nodata value and actual nodata value in exported "
-"raster: specified nodata value %g gets converted to %d by selected GDAL "
-"datatype."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %d by selected GDAL datatype."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:767 ../raster/r.out.gdal/main.c:794
@@ -36306,10 +35056,7 @@
 #: ../raster/r.out.gdal/main.c:833
 #, c-format
-msgid ""
-"raster: specified nodata value %g gets converted to %g by selected GDAL "
-"datatype."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %g by selected GDAL datatype."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:836
@@ -36321,8 +35068,7 @@
 msgid "Failed to set raster attribute table"
 msgstr ""
-#: ../raster/r.out.gdal/export_band.c:52
-#: ../raster/r.out.gdal/export_band.c:344
+#: ../raster/r.out.gdal/export_band.c:52 ../raster/r.out.gdal/export_band.c:344
 msgid "Unable to allocate buffer for reading raster map"
 msgstr ""
@@ -36333,32 +35079,22 @@
 #: ../raster/r.out.gdal/export_band.c:161
 #, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %d will"
-" be used to represent no-data values in the input map. You can specify a "
-"nodata value with the %s option."
+msgid "Input raster map contains cells with NULL-value (no-data). The value %d will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:166
 #, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %g will"
+msgid "Input raster map contains cells with NULL-value (no-data). The value %g will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:176
 #, c-format
-msgid ""
-"The default nodata value is present in rasterband <%s> and would lead to "
-"data loss. Please specify a custom nodata value with the %s parameter."
+msgid "The default nodata value is present in rasterband <%s> and would lead to data loss. Please specify a custom nodata value with the %s parameter."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:183
 #, c-format
-msgid ""
-"The user given nodata value %g is present in rasterband <%s> and would lead "
-"to data loss. Please specify a different nodata value with the %s parameter."
+msgid "The user given nodata value %g is present in rasterband <%s> and would lead to data loss. Please specify a different nodata value with the %s parameter."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:228
@@ -36387,11 +35123,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:113
-msgid ""
-"Generates a raster map of the cumulative time of spread, given raster maps "
-"containing the rates of spread (ROS), the ROS directions and the spread "
-"origins. It optionally produces raster maps to contain backlink UTM "
-"coordinates for tracing spread paths. Usable for fire spread simulations."
+msgid "Generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins. It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths. Usable for fire spread simulations."
 msgstr ""
 #: ../raster/r.spread/main.c:127
@@ -36399,11 +35131,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:129
-msgid ""
-"path containing the ROS values in the directions perpendicular to maximum "
-"ROSes' (cm/minute). These ROSes are also the ones without the effect of "
-"directional factors."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the ROS values in the directions perpendicular to maximum ROSes' (cm/minute). These ROSes are also the ones without the effect of directional factors."
 msgstr ""
 #: ../raster/r.spread/main.c:141
@@ -36411,9 +35139,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:143
-msgid ""
-"path containing the maximum ROS values (cm/minute)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the maximum ROS values (cm/minute)."
 msgstr ""
 #: ../raster/r.spread/main.c:153
@@ -36421,10 +35147,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:155
-msgid ""
-"path containing directions of the maximum ROSes, clockwise from north "
-"(degree)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing directions of the maximum ROSes, clockwise from north (degree)."
 msgstr ""
 #: ../raster/r.spread/main.c:166
@@ -36432,10 +35155,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:168
-msgid ""
-"path containing starting locations of the spread phenomenon. Any positive "
-"integers in this map are recognized as starting sources (seeds)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing starting locations of the spread phenomenon. Any positive integers in this map are recognized as starting sources (seeds)."
 msgstr ""
 #: ../raster/r.spread/main.c:179
@@ -36443,9 +35163,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:181
-msgid ""
-"path containing the maximum potential spotting distances (meters)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the maximum potential spotting distances (meters)."
 msgstr ""
 #: ../raster/r.spread/main.c:191
@@ -36453,9 +35171,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:203
-msgid ""
-"Raster map containing fine fuel moisture of the cell receiving a spotting "
-"firebrand (%, required with -s)"
+msgid "Raster map containing fine fuel moisture of the cell receiving a spotting firebrand (%, required with -s)"
 msgstr ""
 #: ../raster/r.spread/main.c:215
@@ -36463,11 +35179,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:217
-msgid ""
-"An odd integer ranging 3 - 15 indicating the basic sampling window size "
-"within which all cells will be considered to see whether they will be "
-"reached by the current spread cell. The default number is 3 which means a "
-"3x3 window."
+msgid "An odd integer ranging 3 - 15 indicating the basic sampling window size within which all cells will be considered to see whether they will be reached by the current spread cell. The default number is 3 which means a 3x3 window."
 msgstr ""
 #: ../raster/r.spread/main.c:227
@@ -36475,12 +35187,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:229
-msgid ""
-"A decimal number ranging 0.0 - 1.0 indicating additional sampling cells will"
-" be considered to see whether they will be reached by the current spread "
-"cell. The closer to 1.0 the decimal number is, the longer the program will "
-"run and the higher the simulation accuracy will be. The default number is "
-"0.5."
+msgid "A decimal number ranging 0.0 - 1.0 indicating additional sampling cells will be considered to see whether they will be reached by the current spread cell. The closer to 1.0 the decimal number is, the longer the program will run and the higher the simulation accuracy will be. The default number is 0.5."
 msgstr ""
 #: ../raster/r.spread/main.c:241
@@ -36488,10 +35195,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:243
-msgid ""
-"A non-negative number specifying the initial time for the current spread "
-"simulation (minutes). This is useful when multiple phase simulation is "
-"conducted. The default time is 0."
+msgid "A non-negative number specifying the initial time for the current spread simulation (minutes). This is useful when multiple phase simulation is conducted. The default time is 0."
 msgstr ""
 #: ../raster/r.spread/main.c:252
@@ -36499,12 +35203,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:254
-msgid ""
-"A non-negative integer specifying the simulating duration time lag "
-"(minutes). The default is infinite, but the program will terminate when the "
-"current geographic region/mask has been filled. It also controls the "
-"computational time, the shorter the time lag, the faster the program will "
-"run."
+msgid "A non-negative integer specifying the simulating duration time lag (minutes). The default is infinite, but the program will terminate when the current geographic region/mask has been filled. It also controls the computational time, the shorter the time lag, the faster the program will run."
 msgstr ""
 #: ../raster/r.spread/main.c:266
@@ -36512,10 +35211,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:268
-msgid ""
-"path to be used as the background on which the \"live\" movement will be "
-"shown."
+msgid "Name of an existing raster map layer in the user's current mapset search path to be used as the background on which the \"live\" movement will be shown."
 msgstr ""
 #: ../raster/r.spread/main.c:279
@@ -36523,10 +35219,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:281
-msgid ""
-"Name of the new raster map layer to contain the results of the cumulative "
-"spread time needed for a phenomenon to reach each cell from the starting "
-"sources (minutes)."
+msgid "Name of the new raster map layer to contain the results of the cumulative spread time needed for a phenomenon to reach each cell from the starting sources (minutes)."
 msgstr ""
 #: ../raster/r.spread/main.c:291
@@ -36534,9 +35227,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:293
-msgid ""
-"Name of the new raster map layer to contain the results of backlink "
-"information in UTM easting coordinates for each cell."
+msgid "Name of the new raster map layer to contain the results of backlink information in UTM easting coordinates for each cell."
 msgstr ""
 #: ../raster/r.spread/main.c:303
@@ -36544,9 +35235,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:305
-msgid ""
-"information in UTM northing coordinates for each cell."
+msgid "Name of the new raster map layer to contain the results of backlink information in UTM northing coordinates for each cell."
 msgstr ""
 #: ../raster/r.spread/main.c:312
@@ -36554,9 +35243,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:314
-msgid ""
-"Display the 'live' simulation on screen. A graphics window must be opened "
-"and selected before using this option."
+msgid "Display the 'live' simulation on screen. A graphics window must be opened and selected before using this option."
 msgstr ""
 #: ../raster/r.spread/main.c:320
@@ -36568,11 +35255,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:326
-msgid ""
-"Designed to be used with output of previous run of r.spread when computing "
-"spread iteratively. The values in start raster map are considered as time. "
-"Allowed values in raster map are from zero to the value of init_time option."
-" If not enabled, init_time is used in the area of start raster map"
+msgid "Designed to be used with output of previous run of r.spread when computing spread iteratively. The values in start raster map are considered as time. Allowed values in raster map are from zero to the value of init_time option. If not enabled, init_time is used in the area of start raster map"
 msgstr ""
 #: ../raster/r.spread/main.c:502
@@ -36765,8 +35448,7 @@
 msgstr ""
 #: ../raster/r.thin/main.c:60
-msgid ""
-"Thins non-null cells that denote linear features in a raster map layer."
+msgid "Thins non-null cells that denote linear features in a raster map layer."
 msgstr ""
 #: ../raster/r.thin/main.c:72
@@ -36834,9 +35516,7 @@
 msgstr ""
 #: ../raster/r.surf.gauss/main.c:44
-msgid ""
-"Mean and standard deviation of gaussian deviates can be expressed by the "
-"user."
+msgid "Mean and standard deviation of gaussian deviates can be expressed by the user."
 msgstr ""
 #: ../raster/r.surf.gauss/main.c:51
@@ -36950,9 +35630,7 @@
 msgstr ""
 #: ../raster/r.lake/main.c:276
-msgid ""
-"Given water level at seed point is below earth surface. Increase water level"
-" or move seed point."
+msgid "Given water level at seed point is below earth surface. Increase water level or move seed point."
 msgstr ""
 #: ../raster/r.lake/main.c:355
@@ -36975,9 +35653,7 @@
 msgstr ""
 #: ../raster/r.spreadpath/main.c:92
-msgid ""
-"Recursively traces the least cost path backwards to cells from which the "
-"cumulative cost was determined."
+msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
 msgstr ""
 #: ../raster/r.spreadpath/main.c:98
@@ -36994,8 +35670,7 @@
 #: ../raster/r.spreadpath/main.c:161
 #, c-format
-msgid ""
-"eading the input map -%s- and -%s- and creating some temporary files..."
+msgid "eading the input map -%s- and -%s- and creating some temporary files..."
 msgstr ""
 #: ../raster/r.spreadpath/main.c:281
@@ -37049,8 +35724,7 @@
 msgstr ""
 #: ../raster/r.composite/main.c:76
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
+msgid "Combines red, green and blue raster maps into a single composite raster map."
 msgstr ""
 #: ../raster/r.composite/main.c:102
@@ -37084,9 +35758,7 @@
 msgstr ""
 #: ../raster/r.mode/main.c:59
-msgid ""
-"Finds the mode of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
+msgid "Finds the mode of values in a cover map within areas assigned the same category value in a user-specified base map."
 msgstr ""
 #: ../raster/r.mode/main.c:65
@@ -37118,28 +35790,21 @@
 msgid "Extended"
 msgstr ""
-#: ../raster/r.univar/r.univar_main.c:71
-#: ../raster/r.univar/r3.univar_main.c:67
+#: ../raster/r.univar/r.univar_main.c:71 ../raster/r.univar/r3.univar_main.c:67
 msgid "Table output format instead of standard output format"
 msgstr ""
 #: ../raster/r.univar/r.univar_main.c:76
-msgid ""
-"Use the native resolution and extent of the raster map, instead of the "
-"current region"
+msgid "Use the native resolution and extent of the raster map, instead of the current region"
 msgstr ""
 #: ../raster/r.univar/r.univar_main.c:110
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map."
+msgid "Calculates univariate statistics from the non-null cells of a raster map."
 msgstr ""
 #: ../raster/r.univar/r.univar_main.c:112
 #: ../raster/r.univar/r3.univar_main.c:105
-msgid ""
-"Statistics include number of cells counted, minimum and maximum cell values,"
-" range, arithmetic mean, population variance, standard deviation, "
-"coefficient of variation, and sum."
+msgid "Statistics include number of cells counted, minimum and maximum cell values, range, arithmetic mean, population variance, standard deviation, coefficient of variation, and sum."
 msgstr ""
 #: ../raster/r.univar/r.univar_main.c:123
@@ -37151,8 +35816,7 @@
 msgstr ""
 #: ../raster/r.univar/r3.univar_main.c:103
-msgid ""
-"Calculates univariate statistics from the non-null cells of a 3D raster map."
+msgid "Calculates univariate statistics from the non-null cells of a 3D raster map."
 msgstr ""
 #: ../raster/r.out.mpeg/main.c:104
@@ -37214,9 +35878,7 @@
 msgstr ""
 #: ../raster/r.surf.idw/main.c:109
-msgid ""
-"Provides surface interpolation from raster point data by Inverse Distance "
-"Squared Weighting."
+msgid "Provides surface interpolation from raster point data by Inverse Distance Squared Weighting."
 msgstr ""
 #: ../raster/r.surf.idw/main.c:124
@@ -37280,9 +35942,7 @@
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:156
-msgid ""
-"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from an elevation raster map."
+msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from an elevation raster map."
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:158
@@ -37298,13 +35958,11 @@
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:209
-msgid ""
-"Name for output first order partial derivative dx (E-W slope) raster map"
+msgid "Name for output first order partial derivative dx (E-W slope) raster map"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:216
-msgid ""
-"Name for output first order partial derivative dy (N-S slope) raster map"
+msgid "Name for output first order partial derivative dy (N-S slope) raster map"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:223
@@ -37333,9 +35991,7 @@
 #: ../raster/r.slope.aspect/main.c:336
 #, c-format
-msgid ""
-"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, "
-"<%s>, <%s>, <%s>, <%s> or <%s>"
+msgid "You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:358
@@ -37344,9 +36000,7 @@
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:387
-msgid ""
-"r.slope.aspect does not convert horizontal units to meters in this version, "
-"see manual page."
+msgid "r.slope.aspect does not convert horizontal units to meters in this version, see manual page."
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:968
@@ -37414,21 +36068,15 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:62
-msgid ""
-"Name of input raster map providing boundary condition status: 0-inactive, "
-"1-active, 2-dirichlet"
+msgid "Name of input raster map providing boundary condition status: 0-inactive, 1-active, 2-dirichlet"
 msgstr ""
 #: ../raster/r.gwflow/main.c:67
-msgid ""
-"Name of input raster map with x-part of the hydraulic conductivity tensor in"
-" [m/s]"
+msgid "Name of input raster map with x-part of the hydraulic conductivity tensor in [m/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:72
-msgid ""
-"Name of input raster map with y-part of the hydraulic conductivity tensor in"
-" [m/s]"
+msgid "Name of input raster map with y-part of the hydraulic conductivity tensor in [m/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:77
@@ -37436,9 +36084,7 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:81
-msgid ""
-"Name of input raster map with storativity for confined or effective porosity"
-" for unconfined groundwater flow booth in [-] "
+msgid "Name of input raster map with storativity for confined or effective porosity for unconfined groundwater flow booth in [-] "
 msgstr ""
 #: ../raster/r.gwflow/main.c:86
@@ -37450,13 +36096,11 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:92
-msgid ""
-"Name of input raster map describing the top surface of the aquifer in [m]"
+msgid "Name of input raster map describing the top surface of the aquifer in [m]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:96
-msgid ""
-"Name of input raster map describing the bottom surface of the aquifer in [m]"
+msgid "Name of input raster map describing the bottom surface of the aquifer in [m]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:100
@@ -37464,20 +36108,15 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:106
-msgid ""
-"Output raster map to store the groundwater filter velocity vector part in x "
-"direction [m/s]"
+msgid "Output raster map to store the groundwater filter velocity vector part in x direction [m/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:112
-msgid ""
-"Output raster map to store the groundwater filter velocity vector part in y "
-"direction [m/s]"
+msgid "Output raster map to store the groundwater filter velocity vector part in y direction [m/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:118
-msgid ""
-"Output raster map to store the groundwater budget for each cell [m^3/s]"
+msgid "Output raster map to store the groundwater budget for each cell [m^3/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:126
@@ -37489,26 +36128,19 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:140
-msgid ""
-"Name of input raster map providing the water level (head) of the river with "
-"leakage connection in [m]"
+msgid "Name of input raster map providing the water level (head) of the river with leakage connection in [m]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:147
-msgid ""
-"Name of input raster map providing the leakage coefficient of the river bed "
-"in [1/s]."
+msgid "Name of input raster map providing the leakage coefficient of the river bed in [1/s]."
 msgstr ""
 #: ../raster/r.gwflow/main.c:155
-msgid ""
-"Name of input raster map providing the height of the drainage bed in [m]"
+msgid "Name of input raster map providing the height of the drainage bed in [m]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:162
-msgid ""
-"Name of input raster map providing the leakage coefficient of the drainage "
-"bed in [1/s]"
+msgid "Name of input raster map providing the leakage coefficient of the drainage bed in [1/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:167
@@ -37516,15 +36148,11 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:176
-msgid ""
-"Allocate a full quadratic linear equation system, default is a sparse linear"
-" equation system."
+msgid "Allocate a full quadratic linear equation system, default is a sparse linear equation system."
 msgstr ""
 #: ../raster/r.gwflow/main.c:212
-msgid ""
-"Numerical calculation program for transient, confined and unconfined "
-"groundwater flow in two dimensions."
+msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
 msgstr ""
 #: ../raster/r.gwflow/main.c:222 ../raster/r.topidx/main.c:56
@@ -37542,9 +36170,7 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:263
-msgid ""
-"The cholesky solver dos not work with sparse matrices. You may choose a full"
-" filled quadratic matrix, flag -f."
+msgid "The cholesky solver dos not work with sparse matrices. You may choose a full filled quadratic matrix, flag -f."
 msgstr ""
 #: ../raster/r.gwflow/main.c:293
@@ -37567,10 +36193,7 @@
 msgstr ""
 #: ../raster/r.patch/main.c:66
-msgid ""
-"Creates a composite raster map layer by using known category values from one"
-" (or more) map layer(s) to fill in areas of \"no data\" in another map "
-"layer."
+msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
 msgstr ""
 #: ../raster/r.patch/main.c:73
@@ -37659,9 +36282,7 @@
 msgstr ""
 #: ../raster/r.random/main.c:58
-msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
+msgid "Creates a raster map layer and vector point map containing randomly located points."
 msgstr ""
 #: ../raster/r.random/main.c:67
@@ -37762,9 +36383,7 @@
 msgstr ""
 #: ../raster/r.series.interp/main.c:69
-msgid ""
-"Interpolates raster maps located (temporal or spatial) in between input "
-"raster maps at specific sampling positions."
+msgid "Interpolates raster maps located (temporal or spatial) in between input raster maps at specific sampling positions."
 msgstr ""
 #: ../raster/r.series.interp/main.c:79
@@ -37772,9 +36391,7 @@
 msgstr ""
 #: ../raster/r.series.interp/main.c:84
-msgid ""
-"Input file with one input raster map name and data point position per line, "
-"field separator between name and sample point is |"
+msgid "Input file with one input raster map name and data point position per line, field separator between name and sample point is |"
 msgstr ""
 #: ../raster/r.series.interp/main.c:97
@@ -37782,9 +36399,7 @@
 msgstr ""
 #: ../raster/r.series.interp/main.c:101
-msgid ""
-"Input file with one output raster map name and sample point position per "
-"line, field separator between name and sample point is |"
+msgid "Input file with one output raster map name and sample point position per line, field separator between name and sample point is |"
 msgstr ""
 #: ../raster/r.series.interp/main.c:111
@@ -37828,9 +36443,7 @@
 #: ../raster/r.series.interp/main.c:299
 #, c-format
-msgid ""
-"map <%s> at position %g was not interpolated. Check the interpolation "
-"interval."
+msgid "map <%s> at position %g was not interpolated. Check the interpolation interval."
 msgstr ""
 #: ../raster/r.series.interp/main.c:319
@@ -38015,14 +36628,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:245
-msgid ""
-"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
-"for given day, latitude, surface and atmospheric conditions. Solar "
-"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
-"irradiance, daylight length) are saved in the map history file. "
-"Alternatively, a local time can be specified to compute solar incidence "
-"angle and/or irradiance raster maps. The shadowing effect of the topography "
-"is optionally incorporated."
+msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
 msgstr ""
 #: ../raster/r.sun/main.c:259
@@ -38030,9 +36636,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:268
-msgid ""
-"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
-"[decimal degrees]"
+msgid "Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]"
 msgstr ""
 #: ../raster/r.sun/main.c:277
@@ -38040,9 +36644,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:286
-msgid ""
-"Name of the input slope raster map (terrain slope or solar panel "
-"inclination) [decimal degrees]"
+msgid "Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]"
 msgstr ""
 #: ../raster/r.sun/main.c:294
@@ -38050,8 +36652,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:303
-msgid ""
-"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
+msgid "Name of the Linke atmospheric turbidity coefficient input raster map [-]"
 msgstr ""
 #: ../raster/r.sun/main.c:312
@@ -38075,14 +36676,11 @@
 msgstr ""
 #: ../raster/r.sun/main.c:357
-msgid ""
-"Name of real-sky beam radiation coefficient (thick cloud) input raster map "
-"[0-1]"
+msgid "Name of real-sky beam radiation coefficient (thick cloud) input raster map [0-1]"
 msgstr ""
 #: ../raster/r.sun/main.c:366
-msgid ""
-"Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
+msgid "Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
 msgstr ""
 #: ../raster/r.sun/main.c:373
@@ -38094,27 +36692,19 @@
 msgstr ""
 #: ../raster/r.sun/main.c:399
-msgid ""
-"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map "
-"[Wh.m-2.day-1] (mode 2)"
+msgid "Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
 msgstr ""
 #: ../raster/r.sun/main.c:408
-msgid ""
-"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map "
+msgid "Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
 msgstr ""
 #: ../raster/r.sun/main.c:417
-msgid ""
-"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
-"map [Wh.m-2.day-1] (mode 2)"
+msgid "Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
 msgstr ""
 #: ../raster/r.sun/main.c:426
-msgid ""
-"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or "
-"irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgid "Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
 msgstr ""
 #: ../raster/r.sun/main.c:435
@@ -38186,8 +36776,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:609
-msgid ""
-"If you use the horizon option you must also set the 'horizonstep' parameter."
+msgid "If you use the horizon option you must also set the 'horizonstep' parameter."
 msgstr ""
 #: ../raster/r.sun/main.c:615
@@ -38195,9 +36784,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:617
-msgid ""
-"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
-"time"
+msgid "Mode 1: instantaneous solar incidence angle & irradiance using a set local time"
 msgstr ""
 #: ../raster/r.sun/main.c:622
@@ -38253,9 +36840,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:700
-msgid ""
-"If you want to save memory and to use shadows, you must use pre-calculated "
-"horizons."
+msgid "If you want to save memory and to use shadows, you must use pre-calculated horizons."
 msgstr ""
 #: ../raster/r.sun/main.c:767
@@ -38267,9 +36852,7 @@
 msgstr ""
 #: ../raster/r.coin/main.c:69
-msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
+msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
 msgstr ""
 #: ../raster/r.coin/main.c:74
@@ -38285,9 +36868,7 @@
 msgstr ""
 #: ../raster/r.coin/main.c:86
-msgid ""
-"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
-"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
+msgid "c(ells), p(ercent), x(percent of category [column]), y(percent of category [row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
 msgstr ""
 #: ../raster/r.coin/main.c:93
@@ -38326,9 +36907,7 @@
 msgstr ""
 #: ../raster/r.kappa/main.c:72
-msgid ""
-"Calculates error matrix and kappa parameter for accuracy assessment of "
-"classification result."
+msgid "Calculates error matrix and kappa parameter for accuracy assessment of classification result."
 msgstr ""
 #: ../raster/r.kappa/main.c:78
@@ -38490,9 +37069,7 @@
 msgstr ""
 #: ../raster/r.clump/main.c:56
-msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
+msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
 msgstr ""
 #: ../raster/r.clump/main.c:72
@@ -38514,8 +37091,7 @@
 msgstr[0] ""
 #: ../raster/r.surf.random/main.c:40
-msgid ""
-"Produces a raster surface map of uniform random deviates with defined range."
+msgid "Produces a raster surface map of uniform random deviates with defined range."
 msgstr ""
 #: ../raster/r.surf.random/main.c:46
@@ -38532,10 +37108,7 @@
 #: ../raster/r.topidx/file_io.c:35
 #, c-format
-msgid ""
-"The current region resolution [%s x %s] is finer than the input map's "
-"resolution [%s x %s]. The current region resolution must be identical to, or"
-" coarser than, the input map's resolution."
+msgid "The current region resolution [%s x %s] is finer than the input map's resolution [%s x %s]. The current region resolution must be identical to, or coarser than, the input map's resolution."
 msgstr ""
 #: ../raster/r.topidx/file_io.c:42
@@ -38556,9 +37129,7 @@
 msgstr ""
 #: ../raster/r.topidx/main.c:43
-msgid ""
-"Creates a topographic index (wetness index) raster map from an elevation "
-"raster map."
+msgid "Creates a topographic index (wetness index) raster map from an elevation raster map."
 msgstr ""
 #: ../raster/r.topidx/main.c:49
@@ -38582,9 +37153,7 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:79
-msgid ""
-"The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - "
-"dirichlet- and 3 - transfer boundary condition"
+msgid "The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - dirichlet- and 3 - transfer boundary condition"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:85
@@ -38607,14 +37176,11 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:103
-msgid ""
-"Concentration sources and sinks bounded to a water source or sink in [kg/s]"
+msgid "Concentration sources and sinks bounded to a water source or sink in [kg/s]"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:112
-msgid ""
-"Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical "
-"reaction)"
+msgid "Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical reaction)"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:117
@@ -38634,21 +37200,15 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:132
-msgid ""
-"The resulting concentration of the numerical solute transport calculation "
-"will be written to this map. [kg/m^3]"
+msgid "The resulting concentration of the numerical solute transport calculation will be written to this map. [kg/m^3]"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:140
-msgid ""
-"Calculate and store the groundwater filter velocity vector part in x "
-"direction [m/s]\n"
+msgid "Calculate and store the groundwater filter velocity vector part in x direction [m/s]\n"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:147
-msgid ""
-"Calculate and store the groundwater filter velocity vector part in y "
+msgid "Calculate and store the groundwater filter velocity vector part in y direction [m/s]\n"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:161
@@ -38660,9 +37220,7 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:177
-msgid ""
-"Use this number of time loops if the CFL flag is off. The timestep will "
-"become dt/loops."
+msgid "Use this number of time loops if the CFL flag is off. The timestep will become dt/loops."
 msgstr ""
 #: ../raster/r.solute.transport/main.c:187
@@ -38678,9 +37236,7 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:233
-msgid ""
-"Numerical calculation program for transient, confined and unconfined solute "
-"transport in two dimensions"
+msgid "Numerical calculation program for transient, confined and unconfined solute transport in two dimensions"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:258
@@ -38713,8 +37269,7 @@
 #: ../raster/r.solute.transport/main.c:385
 #, c-format
-msgid ""
-"The time step is to large: %gs. The largest time step should be of size %gs."
+msgid "The time step is to large: %gs. The largest time step should be of size %gs."
 msgstr ""
 #: ../raster/r.solute.transport/main.c:397
@@ -38817,9 +37372,7 @@
 msgstr ""
 #: ../raster/r.external/window.c:23
-msgid ""
-"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
-"transform the map to North-up."
+msgid "Input raster map is rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
 msgstr ""
 #: ../raster/r.external/window.c:26
@@ -39130,9 +37683,7 @@
 msgstr ""
 #: ../raster/r.stream.extract/main.c:88
-msgid ""
-"Stream extraction will use provided accumulation instead of calculating it "
-"anew"
+msgid "Stream extraction will use provided accumulation instead of calculating it anew"
 msgstr ""
 #: ../raster/r.stream.extract/main.c:93
@@ -39156,9 +37707,7 @@
 msgstr ""
 #: ../raster/r.stream.extract/main.c:110
-msgid ""
-"If accumulation is larger than d8cut, SFD is used instead of MFD. Applies "
-"only if no accumulation map is given."
+msgid "If accumulation is larger than d8cut, SFD is used instead of MFD. Applies only if no accumulation map is given."
 msgstr ""
 #: ../raster/r.stream.extract/main.c:122
@@ -39166,9 +37715,7 @@
 msgstr ""
 #: ../raster/r.stream.extract/main.c:124
-msgid ""
-"Montgomery: accumulation is multiplied with pow(slope,mexp) and then "
-"compared with threshold"
+msgid "Montgomery: accumulation is multiplied with pow(slope,mexp) and then compared with threshold"
 msgstr ""
 #: ../raster/r.stream.extract/main.c:132
@@ -39308,9 +37855,7 @@
 #: ../raster/r.stream.extract/streams.c:700
 #, c-format
-msgid ""
-"MFD: A * path already processed when setting drainage direction: %lld of "
-"%lld cells"
+msgid "MFD: A * path already processed when setting drainage direction: %lld of %lld cells"
 msgstr ""
 #: ../raster/r.stream.extract/thin.c:83
@@ -39345,9 +37890,7 @@
 msgstr ""
 #: ../raster/r.external.out/main.c:240
-msgid ""
-"Redirects raster output to file utilizing GDAL library rather than storing "
-"in GRASS raster format."
+msgid "Redirects raster output to file utilizing GDAL library rather than storing in GRASS raster format."
 msgstr ""
 #: ../raster/r.external.out/main.c:244
@@ -39440,9 +37983,7 @@
 msgstr ""
 #: ../raster/r.carve/main.c:77
-msgid ""
-"Takes vector stream data, transforms it to raster and subtracts depth from "
-"the output DEM."
+msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
 msgstr ""
 #: ../raster/r.carve/main.c:82
@@ -39488,8 +38029,7 @@
 msgstr ""
 #: ../raster/r.carve/enforce_ds.c:175
-msgid ""
-"Vect runs out of region and re-enters - this case is not yet implemented."
+msgid "Vect runs out of region and re-enters - this case is not yet implemented."
 msgstr ""
 #: ../raster/r.surf.fractal/main.c:40
@@ -39527,10 +38067,7 @@
 msgstr ""
 #: ../raster/r.cost/main.c:145
-msgid ""
-"Creates a raster map showing the cumulative cost of moving between different"
-" geographic locations on an input raster map whose cell category values "
-"represent cost."
+msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
 msgstr ""
 #: ../raster/r.cost/main.c:152
@@ -39548,9 +38085,7 @@
 #: ../raster/r.cost/main.c:489
 #, c-format
-msgid ""
-"Negative cell value found at row %d, col %d. Setting negative value to "
-"null_cost value"
+msgid "Negative cell value found at row %d, col %d. Setting negative value to null_cost value"
 msgstr ""
 #: ../raster/r.cost/main.c:582
@@ -39656,9 +38191,7 @@
 #: ../raster/r.stats.quantile/main.c:632
 #, c-format
-msgid ""
-"Base map <%s> has many categories (%d), computation might be slow and might "
-"need a lot of memory"
+msgid "Base map <%s> has many categories (%d), computation might be slow and might need a lot of memory"
 msgstr ""
 #: ../raster/r.to.vect/main.c:79
@@ -39674,14 +38207,11 @@
 msgstr ""
 #: ../raster/r.to.vect/main.c:142
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
-"table."
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be written to the table."
 msgstr ""
 #: ../raster/r.to.vect/main.c:144
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be z coordinate."
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be z coordinate."
 msgstr ""
 #: ../raster/r.to.vect/main.c:146
@@ -39923,9 +38453,7 @@
 msgstr ""
 #: ../raster/r.cross/main.c:72
-msgid ""
-"Creates a cross product of the category values from multiple raster map "
-"layers."
+msgid "Creates a cross product of the category values from multiple raster map layers."
 msgstr ""
 #: ../raster/r.cross/main.c:81
@@ -40026,8 +38554,7 @@
 msgstr ""
 #: ../raster/r.transect/main.c:106
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
+msgid "Outputs raster map layer values lying along user defined transect line(s)."
 msgstr ""
 #: ../raster/r.transect/main.c:110
@@ -40057,9 +38584,7 @@
 msgstr ""
 #: ../raster/r.rescale.eq/main.c:55
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
+msgid "Rescales histogram equalized the range of category values in a raster map layer."
 msgstr ""
 #: ../raster/r.rescale.eq/main.c:115
@@ -40106,9 +38631,7 @@
 #: ../raster/r.null/main.c:132
 #, c-format
-msgid ""
-"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
-"with r.mapcalc. Exiting."
+msgid "Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy with r.mapcalc. Exiting."
 msgstr ""
 #: ../raster/r.null/main.c:138
@@ -40193,9 +38716,7 @@
 msgstr ""
 #: ../raster/r.fill.dir/main.c:92
-msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation raster map."
+msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
 msgstr ""
 #: ../raster/r.fill.dir/main.c:99
@@ -40203,8 +38724,7 @@
 msgstr ""
 #: ../raster/r.fill.dir/main.c:103
-msgid ""
-"Name for output flow direction map for depressionless elevation raster map"
+msgid "Name for output flow direction map for depressionless elevation raster map"
 msgstr ""
 #: ../raster/r.fill.dir/main.c:108
@@ -40417,9 +38937,7 @@
 msgstr ""
 #: ../ps/ps.map/main.c:118
-msgid ""
-"Describe map-box's position on the page and exit (inches from top-left of "
-"paper)"
+msgid "Describe map-box's position on the page and exit (inches from top-left of paper)"
 msgstr ""
 #: ../ps/ps.map/main.c:123
@@ -40472,10 +38990,7 @@
 msgstr ""
 #: ../ps/ps.map/ps_clrtbl.c:54
-msgid ""
-"Your cats/ file is invalid. A cats/ file with categories and labels is "
-"required for 'colortable' when using categorical legends; see the r.category"
-" help page. Colortable creation has been skipped."
+msgid "Your cats/ file is invalid. A cats/ file with categories and labels is required for 'colortable' when using categorical legends; see the r.category help page. Colortable creation has been skipped."
 msgstr ""
 #: ../ps/ps.map/ps_clrtbl.c:69 ../ps/ps.map/ps_fclrtbl.c:97
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grassmods_it.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -1708,9 +1708,9 @@
 #: ../raster3d/r3.in.lidar/main.c:378 ../raster/r.in.lidar/main.c:401
 #: ../vector/v.in.lidar/main.c:352
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open file <%s> as a LiDAR point cloud"
-msgstr "Impossibile aprire il file per <%s> per la scrittura"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:382 ../raster/r.in.lidar/main.c:405
 #: ../vector/v.in.lidar/main.c:356
@@ -7127,7 +7127,7 @@
 #: ../ps/ps.map/ps_outline.c:100 ../ps/ps.map/r_colortable.c:73
 #: ../ps/ps.map/r_colortable.c:89
 msgid "illegal width request"
-msgstr ""
+msgstr "Interrogazione larghezza non valida"
 #: ../ps/ps.map/ps_outline.c:107
 msgid "illegal outline sub-request"
@@ -7277,11 +7277,11 @@
 #: ../ps/ps.map/r_instructions.c:80
 msgid "no file specified"
-msgstr ""
+msgstr "Nessun file specificato"
 #: ../ps/ps.map/r_instructions.c:84
 msgid "unable to open"
-msgstr ""
+msgstr "Impossibile aprire"
 #: ../ps/ps.map/r_instructions.c:115
 msgid "illegal maploc request"
@@ -7293,7 +7293,7 @@
 #: ../ps/ps.map/r_instructions.c:144 ../ps/ps.map/r_instructions.c:340
 msgid "no raster map selected yet"
-msgstr ""
+msgstr "Mappa raster ancora non selezionata"
 #: ../ps/ps.map/r_instructions.c:160
 msgid "illegal value list"
@@ -7337,7 +7337,7 @@
 #: ../ps/ps.map/r_instructions.c:369
 msgid "group not found"
-msgstr ""
+msgstr "gruppo non trovato"
 #: ../ps/ps.map/r_instructions.c:411
 msgid "illegal grid spacing"
@@ -7521,15 +7521,15 @@
 #: ../ps/ps.map/r_colortable.c:81
 msgid "illegal height request"
-msgstr ""
+msgstr "Interrogazione altezza non valida"
 #: ../ps/ps.map/r_colortable.c:106
 msgid "illegal range request"
-msgstr ""
+msgstr "Interrogazione range non valida"
 #: ../ps/ps.map/r_colortable.c:122
 msgid "illegal columns request"
-msgstr ""
+msgstr "Interrogazione colonne non valida"
 #: ../ps/ps.map/r_colortable.c:141
 msgid "Unsupported color request (colortable)"
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grassmods_ja.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -1704,9 +1704,9 @@
-#, fuzzy, c-format
+#, c-format
-msgstr "ファイル <%s> を開けません"
+msgstr ""
@@ -20245,7 +20245,7 @@
 #: ../raster/r.recode/main.c:49
 msgid "recode categories"
-msgstr ""
+msgstr "カテゴリーの再コード化します"
 #: ../raster/r.recode/main.c:51
 msgid "Recodes categorical raster maps."
@@ -20253,7 +20253,7 @@
 #: ../raster/r.recode/main.c:54
 msgid "Name of raster map to be recoded"
-msgstr "ラスターマップ名が表示されています"
+msgstr "再コード化されるラスターマップ名"
 #: ../raster/r.recode/main.c:60
 msgid "File containing recode rules"
@@ -36036,13 +36036,13 @@
 #: ../vector/v.lidar.edgedetection/main.c:94 ../vector/v.outlier/main.c:103
 #: ../vector/v.lidar.correction/main.c:101
 msgid "Length of each spline step in the east-west direction"
-msgstr "東西方向における各スプラインステップの長さ"
+msgstr ""
 #: ../vector/v.surf.bspline/main.c:158
 #: ../vector/v.lidar.edgedetection/main.c:103 ../vector/v.outlier/main.c:112
 #: ../vector/v.lidar.correction/main.c:110
 msgid "Length of each spline step in the north-south direction"
-msgstr "北南方向における各スプラインステップの長さ: "
+msgstr ""
 #: ../vector/v.surf.bspline/main.c:207
 msgid "Choose either vector or raster output, not both"
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grassmods_ko.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -9035,9 +9035,9 @@
-#, fuzzy, c-format
+#, c-format
-msgstr "출력할 격자지도"
+msgstr ""
Modified: grass/trunk/locale/po/grassmods_lv.po
--- grass/trunk/locale/po/grassmods_lv.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grassmods_lv.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -9076,9 +9076,9 @@
 msgstr ""
-#, fuzzy, c-format
+#, c-format
-msgstr "Neiespējami atvērt šūnu failu[%s]"
+msgstr ""
Modified: grass/trunk/locale/po/grassmods_ml.po
--- grass/trunk/locale/po/grassmods_ml.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grassmods_ml.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -2,7 +2,7 @@
 # Copyright (C) 2017 GRASS Development Team
 # This file is distributed under the same license as the GRASS GIS package.
 # transifex generated, 2017
 msgid ""
 msgstr ""
 "Project-Id-Version: grasslibs_ml\n"
@@ -10,10 +10,10 @@
 "POT-Creation-Date: 2017-05-22 23:12-0700\n"
 "PO-Revision-Date: 2017-05-23 21:08+0200\n"
 "Language-Team: Malayalam (https://www.transifex.com/grass-gis/teams/45198/ml/)\n"
+"Language: ml\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
-"Language: ml\n"
 "Plural-Forms: nplurals=2; plural=(n != 1);\n"
 #: ../raster3d/r3.flow/flowline.c:60 ../vector/v.to.points/write.c:52
@@ -272,14 +272,11 @@
 msgstr ""
 #: ../raster3d/r3.flow/main.c:193
-msgid ""
-"Names of three 3D raster maps describing x, y, z components of vector field"
+msgid "Names of three 3D raster maps describing x, y, z components of vector field"
 msgstr ""
 #: ../raster3d/r3.flow/main.c:200
-msgid ""
-"If no map is provided, flow lines are generated from each cell of the input "
-"3D raster"
+msgid "If no map is provided, flow lines are generated from each cell of the input 3D raster"
 msgstr ""
 #: ../raster3d/r3.flow/main.c:203
@@ -358,8 +355,7 @@
 msgstr ""
 #: ../raster3d/r3.flow/main.c:226
-msgid ""
-"Values of this 3D raster will be stored as attributes of flowlines segments"
+msgid "Values of this 3D raster will be stored as attributes of flowlines segments"
 msgstr ""
 #: ../raster3d/r3.flow/main.c:240
@@ -489,16 +485,15 @@
 #: ../vector/v.colors/main.c:262 ../vector/v.info/main.c:61
 #: ../vector/v.surf.rst/main.c:528 ../vector/v.surf.rst/main.c:632
 #: ../vector/v.to.3d/main.c:72 ../vector/v.db.select/main.c:164
-#: ../vector/v.lidar.correction/main.c:156
-#: ../vector/v.lidar.growing/main.c:138 ../vector/v.lidar.growing/main.c:142
-#: ../vector/v.net.allpairs/main.c:130 ../vector/v.net.connectivity/main.c:130
-#: ../vector/v.net.flow/main.c:143 ../vector/v.what.rast/main.c:131
-#: ../vector/v.drape/main.c:143 ../vector/v.build.polylines/main.c:151
-#: ../vector/v.normal/main.c:110 ../vector/v.out.postgis/main.c:100
-#: ../vector/v.out.svg/main.c:139 ../vector/v.delaunay/main.c:120
-#: ../vector/v.reclass/main.c:113 ../vector/v.net.centrality/main.c:209
-#: ../vector/v.select/main.c:108 ../vector/v.support/main.c:130
-#: ../vector/v.lidar.edgedetection/main.c:180
+#: ../vector/v.lidar.correction/main.c:156 ../vector/v.lidar.growing/main.c:138
+#: ../vector/v.lidar.growing/main.c:142 ../vector/v.net.allpairs/main.c:130
+#: ../vector/v.net.connectivity/main.c:130 ../vector/v.net.flow/main.c:143
+#: ../vector/v.what.rast/main.c:131 ../vector/v.drape/main.c:143
+#: ../vector/v.build.polylines/main.c:151 ../vector/v.normal/main.c:110
+#: ../vector/v.out.postgis/main.c:100 ../vector/v.out.svg/main.c:139
+#: ../vector/v.delaunay/main.c:120 ../vector/v.reclass/main.c:113
+#: ../vector/v.net.centrality/main.c:209 ../vector/v.select/main.c:108
+#: ../vector/v.support/main.c:130 ../vector/v.lidar.edgedetection/main.c:180
 #: ../vector/v.lrs/v.lrs.label/main.c:272
 #: ../vector/v.lrs/v.lrs.where/main.c:131
 #: ../vector/v.lrs/v.lrs.where/main.c:140
@@ -538,10 +533,10 @@
 #: ../display/d.vect.chart/main.c:246 ../display/d.extract/main.c:103
 #: ../misc/m.nviz.image/vector.c:280 ../raster/r.walk/main.c:673
 #: ../raster/r.walk/main.c:742 ../raster/r.drain/main.c:268
-#: ../raster/r.sim/simlib/observation_points.c:41
-#: ../raster/r.region/main.c:170 ../raster/r.random/support.c:63
-#: ../raster/r.what/main.c:237 ../raster/r.carve/main.c:162
-#: ../raster/r.cost/main.c:533 ../raster/r.cost/main.c:606
+#: ../raster/r.sim/simlib/observation_points.c:41 ../raster/r.region/main.c:170
+#: ../raster/r.random/support.c:63 ../raster/r.what/main.c:237
+#: ../raster/r.carve/main.c:162 ../raster/r.cost/main.c:533
+#: ../raster/r.cost/main.c:606
 #, c-format
 msgid "Unable to open vector map <%s>"
 msgstr ""
@@ -761,17 +756,16 @@
 #: ../raster3d/r3.timestamp/main.c:44 ../temporal/t.connect/main.c:36
 #: ../locale/scriptstrings/t.support_to_translate.c:3
 #: ../locale/scriptstrings/t.info_to_translate.c:3
-#: ../locale/scriptstrings/t.select_to_translate.c:3
-#: ../vector/v.info/main.c:38 ../vector/v.timestamp/main.c:36
-#: ../vector/v.support/main.c:40 ../raster/r.describe/main.c:55
-#: ../raster/r.info/main.c:71 ../raster/r.region/main.c:52
-#: ../raster/r.support/main.c:55 ../raster/r.timestamp/main.c:36
+#: ../locale/scriptstrings/t.select_to_translate.c:3 ../vector/v.info/main.c:38
+#: ../vector/v.timestamp/main.c:36 ../vector/v.support/main.c:40
+#: ../raster/r.describe/main.c:55 ../raster/r.info/main.c:71
+#: ../raster/r.region/main.c:52 ../raster/r.support/main.c:55
+#: ../raster/r.timestamp/main.c:36
 msgid "metadata"
 msgstr ""
 #: ../raster3d/r3.support/main.c:52
-msgid ""
-"Allows creation and/or modification of 3D raster map layer support files."
+msgid "Allows creation and/or modification of 3D raster map layer support files."
 msgstr ""
 #: ../raster3d/r3.support/main.c:62
@@ -916,9 +910,7 @@
 msgstr ""
 #: ../raster3d/r3.gradient/main.c:47
-msgid ""
-"Computes gradient of a 3D raster map and outputs gradient components as "
-"three 3D raster maps."
+msgid "Computes gradient of a 3D raster map and outputs gradient components as three 3D raster maps."
 msgstr ""
 #: ../raster3d/r3.gradient/main.c:56
@@ -1358,9 +1350,7 @@
 #: ../raster3d/r3.in.lidar/main.c:191 ../vector/v.in.lidar/main.c:214
 #: ../raster/r.in.lidar/main.c:269
-msgid ""
-"Input is comma separated integers. If not specified, all points are "
-"imported."
+msgid "Input is comma separated integers. If not specified, all points are imported."
 msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:199
@@ -1387,8 +1377,7 @@
 #: ../raster3d/r3.in.lidar/main.c:213 ../vector/v.in.lidar/main.c:295
 #: ../raster/r.in.lidar/main.c:339
-msgid ""
-"Points invalid according to APSRS LAS specification will be filtered out"
+msgid "Points invalid according to APSRS LAS specification will be filtered out"
 msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:230 ../general/g.pnmcomp/main.c:242
@@ -1510,9 +1499,7 @@
 msgstr ""
 #: ../raster3d/r3.mkdspf/main.c:83
-msgid ""
-"Creates a display file from an existing 3D raster map according to specified"
-" threshold levels."
+msgid "Creates a display file from an existing 3D raster map according to specified threshold levels."
 msgstr ""
 #: ../raster3d/r3.mkdspf/main.c:91
@@ -1615,9 +1602,7 @@
 msgstr ""
 #: ../raster3d/r3.to.rast/main.c:96
-msgid ""
-"Use the same resolution as the input 3D raster map for the 2D output maps, "
-"independent of the current region settings"
+msgid "Use the same resolution as the input 3D raster map for the 2D output maps, independent of the current region settings"
 msgstr ""
 #: ../raster3d/r3.to.rast/main.c:208 ../raster3d/r3.cross.rast/main.c:230
@@ -1682,9 +1667,8 @@
 #: ../raster/r.proj/main.c:144 ../raster/r.in.gdal/main.c:90
 #: ../raster/r.topmodel/main.c:51 ../raster/r.contour/main.c:87
 #: ../raster/r.sunhours/main.c:72 ../raster/r.quant/main.c:47
-#: ../raster/r.regression.line/main.c:46
-#: ../raster/r.param.scale/interface.c:54 ../raster/r.in.mat/main.c:91
-#: ../raster/r.li/r.li.padrange/padrange.c:53
+#: ../raster/r.regression.line/main.c:46 ../raster/r.param.scale/interface.c:54
+#: ../raster/r.in.mat/main.c:91 ../raster/r.li/r.li.padrange/padrange.c:53
 #: ../raster/r.li/r.li.cwed/cwed.c:54 ../raster/r.li/r.li.simpson/simpson.c:46
 #: ../raster/r.li/r.li.dominance/dominance.c:46
 #: ../raster/r.li/r.li.patchdensity/main.c:51
@@ -1694,26 +1678,26 @@
 #: ../raster/r.li/r.li.padsd/padsd.c:53 ../raster/r.li/r.li.patchnum/main.c:50
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:48
 #: ../raster/r.li/r.li.renyi/renyi.c:47 ../raster/r.li/r.li.mps/mps.c:52
-#: ../raster/r.li/r.li.shannon/shannon.c:46
-#: ../raster/r.resamp.interp/main.c:76 ../raster/r.category/main.c:52
-#: ../raster/r.his/main.c:67 ../raster/r.to.rast3/main.c:197
-#: ../raster/r.resamp.rst/main.c:148 ../raster/r.stats.zonal/main.c:101
-#: ../raster/r.relief/main.c:107 ../raster/r.neighbors/main.c:167
-#: ../raster/r.sunmask/main.c:116 ../raster/r.colors/edit_colors.c:63
-#: ../raster/r.drain/main.c:109 ../raster/r.latlong/main.c:56
-#: ../raster/r.support.stats/main.c:38 ../raster/r.texture/main.c:102
-#: ../raster/r.series/main.c:137 ../raster/r.profile/main.c:53
-#: ../raster/r.out.pov/main.c:121 ../raster/r.covar/main.c:51
-#: ../raster/r.out.vtk/main.c:59 ../raster/r.out.png/main.c:112
-#: ../raster/r.watershed/front/main.c:73 ../raster/r.to.rast3elev/main.c:361
-#: ../raster/r.grow.distance/main.c:152 ../raster/r.recode/main.c:48
-#: ../raster/r.in.ascii/main.c:69 ../raster/r.flow/main.c:421
-#: ../raster/r.regression.multi/main.c:128 ../raster/r.in.lidar/main.c:108
-#: ../raster/r.reclass/main.c:50 ../raster/r.tile/main.c:43
-#: ../raster/r.resamp.bspline/main.c:80 ../raster/r.mapcalc/main.c:69
-#: ../raster/r.in.xyz/main.c:158 ../raster/r.stats/main.c:106
-#: ../raster/r.ros/main.c:212 ../raster/r.info/main.c:70
-#: ../raster/r.volume/main.c:76 ../raster/r.sim/r.sim.water/main.c:113
+#: ../raster/r.li/r.li.shannon/shannon.c:46 ../raster/r.resamp.interp/main.c:76
+#: ../raster/r.category/main.c:52 ../raster/r.his/main.c:67
+#: ../raster/r.to.rast3/main.c:197 ../raster/r.resamp.rst/main.c:148
+#: ../raster/r.stats.zonal/main.c:101 ../raster/r.relief/main.c:107
+#: ../raster/r.neighbors/main.c:167 ../raster/r.sunmask/main.c:116
+#: ../raster/r.colors/edit_colors.c:63 ../raster/r.drain/main.c:109
+#: ../raster/r.latlong/main.c:56 ../raster/r.support.stats/main.c:38
+#: ../raster/r.texture/main.c:102 ../raster/r.series/main.c:137
+#: ../raster/r.profile/main.c:53 ../raster/r.out.pov/main.c:121
+#: ../raster/r.covar/main.c:51 ../raster/r.out.vtk/main.c:59
+#: ../raster/r.out.png/main.c:112 ../raster/r.watershed/front/main.c:73
+#: ../raster/r.to.rast3elev/main.c:361 ../raster/r.grow.distance/main.c:152
+#: ../raster/r.recode/main.c:48 ../raster/r.in.ascii/main.c:69
+#: ../raster/r.flow/main.c:421 ../raster/r.regression.multi/main.c:128
+#: ../raster/r.in.lidar/main.c:108 ../raster/r.reclass/main.c:50
+#: ../raster/r.tile/main.c:43 ../raster/r.resamp.bspline/main.c:80
+#: ../raster/r.mapcalc/main.c:69 ../raster/r.in.xyz/main.c:158
+#: ../raster/r.stats/main.c:106 ../raster/r.ros/main.c:212
+#: ../raster/r.info/main.c:70 ../raster/r.volume/main.c:76
+#: ../raster/r.sim/r.sim.water/main.c:113
 #: ../raster/r.sim/r.sim.sediment/main.c:113
 #: ../raster/r.series.accumulate/main.c:80 ../raster/r.out.gdal/main.c:136
 #: ../raster/r.spread/main.c:105 ../raster/r.out.gridatb/main.c:67
@@ -1755,9 +1739,7 @@
 msgstr ""
 #: ../raster3d/r3.to.rast/main.c:271 ../raster3d/r3.out.vtk/main.c:451
-msgid ""
-"The 2D and 3D region settings are different. Using the 2D window settings to"
-" adjust the 2D part of the 3D region."
+msgid "The 2D and 3D region settings are different. Using the 2D window settings to adjust the 2D part of the 3D region."
 msgstr ""
 #: ../raster3d/r3.to.rast/main.c:295 ../vector/v.generalize/matrix.c:144
@@ -1807,8 +1789,7 @@
 #: ../raster3d/r3.to.rast/main.c:308
 #, c-format
-msgid ""
-"Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
+msgid "Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
 msgstr ""
 #: ../raster3d/r3.neighbors/main.c:94 ../raster/r.neighbors/main.c:102
@@ -1827,9 +1808,7 @@
 msgstr ""
 #: ../raster3d/r3.neighbors/main.c:137
-msgid ""
-"The size of the window in x, y and z direction, values must be odd integer "
-"numbers, eg: 3,3,3"
+msgid "The size of the window in x, y and z direction, values must be odd integer numbers, eg: 3,3,3"
 msgstr ""
 #: ../raster3d/r3.neighbors/main.c:209
@@ -1872,9 +1851,7 @@
 msgstr ""
 #: ../raster3d/r3.neighbors/main.c:218
-msgid ""
-"Makes each voxel value a function of the values assigned to the voxels "
-"around it, and stores new voxel values in an output 3D raster map"
+msgid "Makes each voxel value a function of the values assigned to the voxels around it, and stores new voxel values in an output 3D raster map"
 msgstr ""
 #: ../raster3d/r3.neighbors/main.c:287
@@ -1890,27 +1867,19 @@
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:60
-msgid ""
-"Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - "
-"active, 2 - dirichlet"
+msgid "Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:65
-msgid ""
-"Input 3D raster map with the x-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Input 3D raster map with the x-part of the hydraulic conductivity tensor in [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:70
-msgid ""
-"Input 3D raster map with the y-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Input 3D raster map with the y-part of the hydraulic conductivity tensor in [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:75
-msgid ""
-"Input 3D raster map with the z-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Input 3D raster map with the z-part of the hydraulic conductivity tensor in [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:80
@@ -1926,32 +1895,23 @@
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:93
-msgid ""
-"Output 3D raster map storing the piezometric head result of the numerical "
-"calculation"
+msgid "Output 3D raster map storing the piezometric head result of the numerical calculation"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:99
-msgid ""
-"Output 3D raster map storing the groundwater filter velocity vector part in "
-"x direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in x direction [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:105
-msgid ""
-"y direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in y direction [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:111
-msgid ""
-"z direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in z direction [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:117
-msgid ""
-"Output 3D raster map storing the groundwater budget for each cell [m^3/s]"
+msgid "Output 3D raster map storing the groundwater budget for each cell [m^3/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:127
@@ -1959,9 +1919,7 @@
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:131 ../raster/r.solute.transport/main.c:192
-msgid ""
-"Use a full filled quadratic linear equation system, default is a sparse "
-"linear equation system."
+msgid "Use a full filled quadratic linear equation system, default is a sparse linear equation system."
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:160 ../raster/r.gwflow/main.c:209
@@ -1969,9 +1927,7 @@
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:163
-msgid ""
-"Numerical calculation program for transient, confined groundwater flow in "
-"three dimensions."
+msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions."
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:180
@@ -2021,9 +1977,7 @@
 msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:175
-msgid ""
-"No 3D raster data, RGB or xyz-vector maps are provided! Will only write the "
-"geometry."
+msgid "No 3D raster data, RGB or xyz-vector maps are provided! Will only write the geometry."
 msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:209
@@ -2079,14 +2033,11 @@
 msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:71
-msgid ""
-"Create 3D elevation output with a top and a bottom surface, both raster maps"
-" are required."
+msgid "Create 3D elevation output with a top and a bottom surface, both raster maps are required."
 msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:80
-msgid ""
-"Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
+msgid "Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
 msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:88
@@ -2112,15 +2063,12 @@
 msgid "Scale factor affects the origin"
 msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:123
-#: ../raster/r.out.vtk/parameters.c:128
+#: ../raster3d/r3.out.vtk/parameters.c:123 ../raster/r.out.vtk/parameters.c:128
 msgid "Correct the coordinates to match the VTK-OpenGL precision"
 msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:129
-msgid ""
-"Do not convert the top-bottom resolution in case of lat long projection to "
-"meters"
+msgid "Do not convert the top-bottom resolution in case of lat long projection to meters"
 msgstr ""
 #: ../raster3d/r3.out.vtk/writeVTKData.c:122
@@ -2133,9 +2081,7 @@
 #: ../raster3d/r3.out.vtk/writeVTKData.c:335
 #, c-format
-msgid ""
-"write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
-"ascii file"
+msgid "write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-ascii file"
 msgstr ""
 #: ../raster3d/r3.out.vtk/writeVTKData.c:441
@@ -2171,8 +2117,7 @@
 #: ../raster3d/r3.in.ascii/main.c:281
 #, c-format
-msgid ""
-"Data exists in input file after fully importing expected data.  [%.4f ...]"
+msgid "Data exists in input file after fully importing expected data.  [%.4f ...]"
 msgstr ""
 #: ../raster3d/r3.in.ascii/main.c:319
@@ -2201,15 +2146,11 @@
 msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:233
-msgid ""
-"Creates cross section 2D raster map from 3D raster map based on 2D elevation"
-" map"
+msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map"
 msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:259
-msgid ""
-"The 2D and 3D region settings are different. Using the 3D raster map "
-"settings to adjust the 2D region."
+msgid "The 2D and 3D region settings are different. Using the 3D raster map settings to adjust the 2D region."
 msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:302
@@ -2235,8 +2176,7 @@
 msgstr ""
 #: ../raster3d/r3.retile/main.c:99
-msgid ""
-"Retiles an existing 3D raster map with user defined x, y and z tile size."
+msgid "Retiles an existing 3D raster map with user defined x, y and z tile size."
 msgstr ""
 #: ../raster3d/r3.retile/main.c:135
@@ -2444,8 +2384,7 @@
 msgstr ""
 #: ../temporal/t.connect/main.c:38
-msgid ""
-"Prints/sets general temporal GIS database connection for current mapset."
+msgid "Prints/sets general temporal GIS database connection for current mapset."
 msgstr ""
 #: ../temporal/t.connect/main.c:42 ../db/db.connect/main.c:51
@@ -2589,9 +2528,8 @@
 msgstr ""
 #: ../locale/scriptstrings/d.frame_to_translate.c:4
-#: ../locale/scriptstrings/d.redraw_to_translate.c:4
-#: ../display/d.mon/main.c:40 ../display/d.erase/main.c:31
-#: ../display/d.info/main.c:36
+#: ../locale/scriptstrings/d.redraw_to_translate.c:4 ../display/d.mon/main.c:40
+#: ../display/d.erase/main.c:31 ../display/d.info/main.c:36
 msgid "monitors"
 msgstr ""
@@ -2620,8 +2558,7 @@
 msgstr ""
 #: ../locale/scriptstrings/d.frame_to_translate.c:11
-msgid ""
-"Screen coordinates in percent where to place the frame (0,0 is lower-left)"
+msgid "Screen coordinates in percent where to place the frame (0,0 is lower-left)"
 msgstr ""
 #: ../locale/scriptstrings/d.frame_to_translate.c:12
@@ -2812,9 +2749,7 @@
 msgstr ""
 #: ../locale/scriptstrings/d.what.rast_to_translate.c:1
-msgid ""
-"Allows the user to interactively query raster map layers at user-selected "
-"locations."
+msgid "Allows the user to interactively query raster map layers at user-selected locations."
 msgstr ""
 #: ../locale/scriptstrings/d.what.rast_to_translate.c:3
@@ -2879,8 +2814,7 @@
 #: ../vector/v.net.centrality/main.c:96 ../vector/v.select/main.c:48
 #: ../vector/v.support/main.c:39 ../vector/v.in.lidar/main.c:136
 #: ../vector/v.lidar.edgedetection/main.c:75
-#: ../vector/v.lrs/v.lrs.label/main.c:102
-#: ../vector/v.lrs/v.lrs.where/main.c:57
+#: ../vector/v.lrs/v.lrs.label/main.c:102 ../vector/v.lrs/v.lrs.where/main.c:57
 #: ../vector/v.lrs/v.lrs.create/main.c:121
 #: ../vector/v.lrs/v.lrs.segment/main.c:71 ../vector/v.to.db/main.c:36
 #: ../vector/v.out.dxf/main.c:56 ../vector/v.transform/main.c:69
@@ -2918,9 +2852,7 @@
 msgstr ""
 #: ../locale/scriptstrings/d.what.vect_to_translate.c:1
-msgid ""
-"Allows the user to interactively query vector map layers at user-selected "
-"locations."
+msgid "Allows the user to interactively query vector map layers at user-selected locations."
 msgstr ""
 #: ../locale/scriptstrings/db.dropcolumn_to_translate.c:1
@@ -3094,8 +3026,7 @@
 #: ../locale/scriptstrings/db.univar_to_translate.c:5
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:5
-msgid ""
-"Name of attribute column on which to calculate statistics (must be numeric)"
+msgid "Name of attribute column on which to calculate statistics (must be numeric)"
 msgstr ""
 #: ../locale/scriptstrings/db.univar_to_translate.c:6
@@ -3120,9 +3051,7 @@
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:2
-msgid ""
-"Downloads and installs extensions from GRASS Addons repository or other "
-"source into the local GRASS installation or removes installed extensions."
+msgid "Downloads and installs extensions from GRASS Addons repository or other source into the local GRASS installation or removes installed extensions."
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:3
@@ -3177,15 +3106,11 @@
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:11
-msgid ""
-"URL or directory to get the extension from (supported only on Linux and Mac)"
+msgid "URL or directory to get the extension from (supported only on Linux and Mac)"
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:12
-msgid ""
-"The official repository is used by default. User can specify a ZIP file, "
-"directory or a repository on common hosting services. If not identified, "
-"Subversion repository is assumed. See manual for all options."
+msgid "The official repository is used by default. User can specify a ZIP file, directory or a repository on common hosting services. If not identified, Subversion repository is assumed. See manual for all options."
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:13
@@ -3201,15 +3126,11 @@
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:17
-msgid ""
-"List available extensions in the official GRASS GIS Addons repository "
-"including module description"
+msgid "List available extensions in the official GRASS GIS Addons repository including module description"
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:19
-msgid ""
-"List available extensions in the official GRASS GIS Addons repository (shell"
-" script style)"
+msgid "List available extensions in the official GRASS GIS Addons repository (shell script style)"
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:21
@@ -3255,8 +3176,7 @@
 msgstr ""
 #: ../locale/scriptstrings/g.extension.all_to_translate.c:2
-msgid ""
-"By default only extensions built against different GIS Library are rebuilt."
+msgid "By default only extensions built against different GIS Library are rebuilt."
 msgstr ""
 #: ../locale/scriptstrings/g.extension.all_to_translate.c:7
@@ -3292,9 +3212,7 @@
 msgstr ""
 #: ../locale/scriptstrings/g.manual_to_translate.c:9
-msgid ""
-"Use online manuals available at http://grass.osgeo.org website. This flag "
-"has no effect when displaying MAN text pages."
+msgid "Use online manuals available at http://grass.osgeo.org website. This flag has no effect when displaying MAN text pages."
 msgstr ""
 #: ../locale/scriptstrings/g.manual_to_translate.c:10
@@ -3318,8 +3236,7 @@
 msgstr ""
 #: ../locale/scriptstrings/g.search.modules_to_translate.c:6
-msgid ""
-"Display only modules where all keywords are available (AND), default: OR"
+msgid "Display only modules where all keywords are available (AND), default: OR"
 msgstr ""
 #: ../locale/scriptstrings/g.search.modules_to_translate.c:8
@@ -3516,9 +3433,8 @@
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:6
 #: ../vector/v.db.select/main.c:95 ../db/db.select/main.c:241
 #: ../raster/r.stats/main.c:119 ../raster/r.quantile/main.c:297
-#: ../raster/r.univar/r.univar_main.c:41
-#: ../raster/r.univar/r3.univar_main.c:42 ../raster/r.what/main.c:125
-#: ../raster/r.stats.quantile/main.c:555
+#: ../raster/r.univar/r.univar_main.c:41 ../raster/r.univar/r3.univar_main.c:42
+#: ../raster/r.what/main.c:125 ../raster/r.stats.quantile/main.c:555
 msgid "Name for output file (if omitted or \"-\" output to stdout)"
 msgstr ""
@@ -3531,9 +3447,7 @@
 msgstr ""
 #: ../locale/scriptstrings/i.pansharpen_to_translate.c:1
-msgid ""
-"Image fusion algorithms to sharpen multispectral with high-res panchromatic "
-"channels"
+msgid "Image fusion algorithms to sharpen multispectral with high-res panchromatic channels"
 msgstr ""
 #: ../locale/scriptstrings/i.pansharpen_to_translate.c:3
@@ -3590,8 +3504,7 @@
 msgstr ""
 #: ../locale/scriptstrings/i.spectral_to_translate.c:1
-msgid ""
-"Displays spectral response at user specified locations in group or images."
+msgid "Displays spectral response at user specified locations in group or images."
 msgstr ""
 #: ../locale/scriptstrings/i.spectral_to_translate.c:3
@@ -3654,9 +3567,7 @@
 msgstr ""
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:7
-msgid ""
-"For Landsat4-7: bands 1, 2, 3, 4, 5, 7; for Landsat8: bands 2, 3, 4, 5, 6, "
-"7; for MODIS: bands 1, 2, 3, 4, 5, 6, 7"
+msgid "For Landsat4-7: bands 1, 2, 3, 4, 5, 7; for Landsat8: bands 2, 3, 4, 5, 6, 7; for MODIS: bands 1, 2, 3, 4, 5, 6, 7"
 msgstr ""
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:8
@@ -3669,11 +3580,7 @@
 msgstr ""
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:10
-msgid ""
-"landsat4_tm;Use transformation rules for Landsat 4 TM;landsat5_tm;Use "
-"transformation rules for Landsat 5 TM;landsat7_etm;Use transformation rules "
-"for Landsat 7 ETM;landsat8_oli;Use transformation rules for Landsat 8 "
-"OLI;modis;Use transformation rules for MODIS"
+msgid "landsat4_tm;Use transformation rules for Landsat 4 TM;landsat5_tm;Use transformation rules for Landsat 5 TM;landsat7_etm;Use transformation rules for Landsat 7 ETM;landsat8_oli;Use transformation rules for Landsat 8 OLI;modis;Use transformation rules for MODIS"
 msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:1
@@ -3709,12 +3616,12 @@
 msgid "Name of input coordinate file"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:8
-#: ../general/g.proj/main.c:141 ../general/g.proj/main.c:150
-#: ../vector/v.edit/args.c:89 ../vector/v.segment/main.c:80
-#: ../vector/v.what/main.c:76 ../db/db.execute/main.c:139
-#: ../db/db.select/main.c:208 ../raster/r.recode/main.c:61
-#: ../raster/r.in.ascii/main.c:79 ../raster/r.reclass/main.c:66
+#: ../locale/scriptstrings/m.proj_to_translate.c:8 ../general/g.proj/main.c:141
+#: ../general/g.proj/main.c:150 ../vector/v.edit/args.c:89
+#: ../vector/v.segment/main.c:80 ../vector/v.what/main.c:76
+#: ../db/db.execute/main.c:139 ../db/db.select/main.c:208
+#: ../raster/r.recode/main.c:61 ../raster/r.in.ascii/main.c:79
+#: ../raster/r.reclass/main.c:66
 msgid "'-' for standard input"
 msgstr ""
@@ -3750,9 +3657,7 @@
 msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:22
-msgid ""
-"Output long/lat in decimal degrees, or other projections with many decimal "
-"places"
+msgid "Output long/lat in decimal degrees, or other projections with many decimal places"
 msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:24
@@ -3794,9 +3699,7 @@
 #: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:1
 #: ../raster/r.buffer/main.c:69
-msgid ""
-"Creates a raster map showing buffer zones surrounding cells that contain "
-"non-NULL category values."
+msgid "Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values."
 msgstr ""
 #: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:2
@@ -3949,9 +3852,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.import_to_translate.c:1
-msgid ""
-"Imports raster data into a GRASS raster map using GDAL library and "
-"reprojects on the fly."
+msgid "Imports raster data into a GRASS raster map using GDAL library and reprojects on the fly."
 msgstr ""
 #: ../locale/scriptstrings/r.import_to_translate.c:5
@@ -3990,11 +3891,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.import_to_translate.c:14
-msgid ""
-"nearest;nearest neighbor;bilinear;bilinear interpolation;bicubic;bicubic "
-"interpolation;lanczos;lanczos filter;bilinear_f;bilinear interpolation with "
-"fallback;bicubic_f;bicubic interpolation with fallback;lanczos_f;lanczos "
-"filter with fallback"
+msgid "nearest;nearest neighbor;bilinear;bilinear interpolation;bicubic;bicubic interpolation;lanczos;lanczos filter;bilinear_f;bilinear interpolation with fallback;bicubic_f;bicubic interpolation with fallback;lanczos_f;lanczos filter with fallback"
 msgstr ""
 #: ../locale/scriptstrings/r.import_to_translate.c:16
@@ -4010,9 +3907,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.import_to_translate.c:20
-msgid ""
-"estimated;estimated resolution;value;user-specified "
-"resolution;region;current region resolution"
+msgid "estimated;estimated resolution;value;user-specified resolution;region;current region resolution"
 msgstr ""
 #: ../locale/scriptstrings/r.import_to_translate.c:22
@@ -4071,14 +3966,11 @@
 #: ../locale/scriptstrings/r.import_to_translate.c:32
 #: ../locale/scriptstrings/v.import_to_translate.c:28
 #: ../vector/v.in.ogr/main.c:286 ../vector/v.external/args.c:45
-msgid ""
-"Assume that the dataset has the same projection as the current location"
+msgid "Assume that the dataset has the same projection as the current location"
 msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:1
-msgid ""
-"Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
-"using gdalwarp."
+msgid "Georeference, rectify, and import Terra-ASTER imagery and relative DEMs using gdalwarp."
 msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:5
@@ -4095,14 +3987,11 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:9
-msgid ""
-"List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate "
-"all bands"
+msgid "List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate all bands"
 msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:10
-msgid ""
-"Base name for output raster map (band number will be appended to base name)"
+msgid "Base name for output raster map (band number will be appended to base name)"
 msgstr ""
 #: ../locale/scriptstrings/r.in.srtm_to_translate.c:1
@@ -4172,10 +4061,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:15
-msgid ""
-"WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using "
-"native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS "
-"driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;"
+msgid "WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;"
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:17
@@ -4207,8 +4093,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:30
-msgid ""
-"Request data for this named region instead of the current region bounds"
+msgid "Request data for this named region instead of the current region bounds"
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:32
@@ -4226,9 +4111,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:35
-msgid ""
-"Capabilities file to parse (input). It is relevant for WMTS_GRASS and "
-"OnEarth_GRASS drivers"
+msgid "Capabilities file to parse (input). It is relevant for WMTS_GRASS and OnEarth_GRASS drivers"
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:36
@@ -4301,8 +4184,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
-msgid ""
-"Exports a raster map to a text file as x,y,z values based on cell centers."
+msgid "Exports a raster map to a text file as x,y,z values based on cell centers."
 msgstr ""
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
@@ -4339,9 +4221,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.plane_to_translate.c:1
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
+msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
 msgstr ""
 #: ../locale/scriptstrings/r.plane_to_translate.c:4
@@ -4365,9 +4245,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
+msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
 msgstr ""
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
@@ -4425,8 +4303,7 @@
 msgid "Name of shaded raster map"
 msgstr ""
-#: ../locale/scriptstrings/r.shade_to_translate.c:12
-#: ../raster/r.his/main.c:121
+#: ../locale/scriptstrings/r.shade_to_translate.c:12 ../raster/r.his/main.c:121
 msgid "Color to use instead of NULL values"
 msgstr ""
@@ -4434,15 +4311,12 @@
 msgid "Either a standard color name, R:G:B triplet, or \"none\""
 msgstr ""
-#: ../locale/scriptstrings/r.shade_to_translate.c:14
-#: ../raster/r.his/main.c:126
+#: ../locale/scriptstrings/r.shade_to_translate.c:14 ../raster/r.his/main.c:126
 msgid "Use colors from color tables for NULL values"
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:1
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
+msgid "Produces tilings of the source projection for use in the destination region and projection."
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:4
@@ -4454,8 +4328,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:6
-msgid ""
-"Name of region to use instead of current region for bounds and resolution"
+msgid "Name of region to use instead of current region for bounds and resolution"
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:7
@@ -4488,8 +4361,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.unpack_to_translate.c:1
-msgid ""
-"Imports a raster map as GRASS GIS specific archive file (packed with r.pack)"
+msgid "Imports a raster map as GRASS GIS specific archive file (packed with r.pack)"
 msgstr ""
 #: ../locale/scriptstrings/r.unpack_to_translate.c:5
@@ -4526,9 +4398,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:1
-msgid ""
-"Create a 3D raster map from an assemblage of many coordinates using "
-"univariate statistics"
+msgid "Create a 3D raster map from an assemblage of many coordinates using univariate statistics"
 msgstr ""
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:6
@@ -4611,9 +4481,7 @@
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:29
 #: ../raster/r.in.lidar/main.c:243 ../raster/r.in.xyz/main.c:321
-msgid ""
-"Discard <trim> percent of the smallest and <trim> percent of the largest "
-"observations"
+msgid "Discard <trim> percent of the smallest and <trim> percent of the largest observations"
 msgstr ""
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:31
@@ -4663,9 +4531,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
+msgid "Adds one or more columns to the attribute table connected to a given vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
@@ -4679,15 +4545,11 @@
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:11
-msgid ""
-"Types depend on database backend, but all support VARCHAR(), INT, DOUBLE "
-"PRECISION and DATE. Example: 'label varchar(250), value integer'"
+msgid "Types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE. Example: 'label varchar(250), value integer'"
 msgstr ""
-msgid ""
-"Creates and connects a new attribute table to a given layer of an existing "
-"vector map."
+msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
@@ -4748,8 +4610,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
+msgid "Drops a column from the attribute table connected to a given vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
@@ -4757,8 +4618,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.droprow_to_translate.c:1
-msgid ""
-"Removes a vector feature from a vector map through attribute selection."
+msgid "Removes a vector feature from a vector map through attribute selection."
 msgstr ""
 #: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
@@ -4774,8 +4634,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:1
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
+msgid "Renames a column in the attribute table connected to a given vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:5
@@ -4783,9 +4642,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
-msgid ""
-"Reconnects attribute tables for all vector maps from the current mapset to a"
-" new database."
+msgid "Reconnects attribute tables for all vector maps from the current mapset to a new database."
 msgstr ""
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
@@ -4817,9 +4674,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:1
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector"
-" map."
+msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.update_to_translate.c:1
@@ -4835,20 +4690,15 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.update_to_translate.c:7
-msgid ""
-"Name of other attribute column to query, can be combination of columns (e.g."
-" co1+col2)"
+msgid "Name of other attribute column to query, can be combination of columns (e.g. co1+col2)"
 msgstr ""
 #: ../locale/scriptstrings/v.db.update_to_translate.c:8
-msgid ""
-"Name of SQLite extension file for extra functions (SQLite backend only)"
+msgid "Name of SQLite extension file for extra functions (SQLite backend only)"
 msgstr ""
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:1
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number"
-" or attribute."
+msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
 msgstr ""
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:3
@@ -4875,9 +4725,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.import_to_translate.c:1
-msgid ""
-"Imports vector data into a GRASS vector map using OGR library and reprojects"
-" on the fly."
+msgid "Imports vector data into a GRASS vector map using OGR library and reprojects on the fly."
 msgstr ""
 #: ../locale/scriptstrings/v.import_to_translate.c:5
@@ -4905,8 +4753,7 @@
 #: ../locale/scriptstrings/v.import_to_translate.c:15
 #: ../vector/v.in.ogr/main.c:235
-msgid ""
-"Overrides encoding interpretation, useful when importing ESRI Shapefile"
+msgid "Overrides encoding interpretation, useful when importing ESRI Shapefile"
 msgstr ""
 #: ../locale/scriptstrings/v.import_to_translate.c:17
@@ -5029,9 +4876,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:8
-msgid ""
-"The given code must be supported by the server, consult the capabilities "
-"file"
+msgid "The given code must be supported by the server, consult the capabilities file"
 msgstr ""
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:9
@@ -5051,9 +4896,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:13
-msgid ""
-"Download server capabilities to 'wms_capabilities.xml' in the current "
-"directory and exit"
+msgid "Download server capabilities to 'wms_capabilities.xml' in the current directory and exit"
 msgstr ""
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:14
@@ -5061,9 +4904,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
-msgid ""
-"Calculates univariate statistics from a raster map based on a vector map and"
-" uploads statistics to new attribute columns."
+msgid "Calculates univariate statistics from a raster map based on a vector map and uploads statistics to new attribute columns."
 msgstr ""
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
@@ -5147,8 +4988,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.unpack_to_translate.c:1
-msgid ""
-"Imports a vector map as GRASS GIS specific archive file (packed with v.pack)"
+msgid "Imports a vector map as GRASS GIS specific archive file (packed with v.pack)"
 msgstr ""
 #: ../locale/scriptstrings/v.unpack_to_translate.c:6
@@ -5160,9 +5000,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.what.strds_to_translate.c:1
-msgid ""
-"Uploads space time raster dataset values at positions of vector points to "
-"the table."
+msgid "Uploads space time raster dataset values at positions of vector points to the table."
 msgstr ""
 #: ../locale/scriptstrings/v.what.strds_to_translate.c:5
@@ -5178,9 +5016,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.what.strds_to_translate.c:10
-msgid ""
-"Instead of creating a new vector map update the attribute table with "
-"value(s)"
+msgid "Instead of creating a new vector map update the attribute table with value(s)"
 msgstr ""
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:1
@@ -5317,21 +5153,15 @@
 msgstr ""
 #: ../locale/scriptstrings/t.support_to_translate.c:11
-msgid ""
-"Update the metadata information and spatial extent of registered maps from "
-"the GRASS spatial database"
+msgid "Update the metadata information and spatial extent of registered maps from the GRASS spatial database"
 msgstr ""
 #: ../locale/scriptstrings/t.support_to_translate.c:12
-msgid ""
-"Check for removed maps and delete them from the temporal database and all "
-"effected space time datasets"
+msgid "Check for removed maps and delete them from the temporal database and all effected space time datasets"
 msgstr ""
 #: ../locale/scriptstrings/t.support_to_translate.c:13
-msgid ""
-"Update metadata information, temporal and spatial extent from registered "
-"maps based on database entries."
+msgid "Update metadata information, temporal and spatial extent from registered maps based on database entries."
 msgstr ""
 #: ../locale/scriptstrings/t.topology_to_translate.c:1
@@ -5347,8 +5177,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.list_to_translate.c:1
-msgid ""
-"Lists space time datasets and maps registered in the temporal database."
+msgid "Lists space time datasets and maps registered in the temporal database."
 msgstr ""
 #: ../locale/scriptstrings/t.list_to_translate.c:4
@@ -5365,9 +5194,7 @@
 #: ../locale/scriptstrings/t.list_to_translate.c:9
 #: ../locale/scriptstrings/t.list_to_translate.c:12
-msgid ""
-"Columns number_of_maps and granularity only available for space time "
-"datasets"
+msgid "Columns number_of_maps and granularity only available for space time datasets"
 msgstr ""
 #: ../locale/scriptstrings/t.list_to_translate.c:10
@@ -5436,9 +5263,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.info_to_translate.c:10
-msgid ""
-"Print history information in human readable shell style for space time "
-"datasets"
+msgid "Print history information in human readable shell style for space time datasets"
 msgstr ""
 #: ../locale/scriptstrings/t.info_to_translate.c:11
@@ -5455,8 +5280,7 @@
 msgid "time management"
 msgstr ""
-#: ../locale/scriptstrings/t.merge_to_translate.c:4
-#: ../raster/r.patch/main.c:61
+#: ../locale/scriptstrings/t.merge_to_translate.c:4 ../raster/r.patch/main.c:61
 msgid "merge"
 msgstr ""
@@ -5483,9 +5307,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.remove_to_translate.c:12
-msgid ""
-"Remove all registered maps from the temporal and also from the spatial "
-"database"
+msgid "Remove all registered maps from the temporal and also from the spatial database"
 msgstr ""
 #: ../locale/scriptstrings/t.remove_to_translate.c:13
@@ -5493,9 +5315,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.sample_to_translate.c:1
-msgid ""
-"Samples the input space time dataset(s) with a sample space time dataset and"
-" print the result to stdout."
+msgid "Samples the input space time dataset(s) with a sample space time dataset and print the result to stdout."
 msgstr ""
 #: ../locale/scriptstrings/t.sample_to_translate.c:5
@@ -5511,9 +5331,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.sample_to_translate.c:10
-msgid ""
-"Do not use \",\" as this char is reserved to list several map ids in a "
-"sample granule"
+msgid "Do not use \",\" as this char is reserved to list several map ids in a sample granule"
 msgstr ""
 #: ../locale/scriptstrings/t.sample_to_translate.c:12
@@ -5521,9 +5339,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:1
-msgid ""
-"Assigns timestamps and registers raster, vector and raster3d maps in a space"
-" time dataset."
+msgid "Assigns timestamps and registers raster, vector and raster3d maps in a space time dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:4
@@ -5550,9 +5366,7 @@
 #: ../locale/scriptstrings/t.register_to_translate.c:14
 #: ../locale/scriptstrings/t.register_to_translate.c:17
-msgid ""
-"Format for absolute time: \"yyyy-mm-dd HH:MM:SS +HHMM\", relative time is of"
-" type integer."
+msgid "Format for absolute time: \"yyyy-mm-dd HH:MM:SS +HHMM\", relative time is of type integer."
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:15
@@ -5580,10 +5394,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:23
-msgid ""
-"Time increment between maps for creation of valid time intervals (format for"
-" absolute time: NNN seconds, minutes, hours, days, weeks, months, years; "
-"format for relative time is of type integer: 5)"
+msgid "Time increment between maps for creation of valid time intervals (format for absolute time: NNN seconds, minutes, hours, days, weeks, months, years; format for relative time is of type integer: 5)"
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:25
@@ -5591,15 +5402,11 @@
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:27
-msgid ""
-"Create an interval (start and end time) in case an increment and the start "
-"time are provided"
+msgid "Create an interval (start and end time) in case an increment and the start time are provided"
 msgstr ""
 #: ../locale/scriptstrings/t.unregister_to_translate.c:1
-msgid ""
-"Unregisters raster, vector and raster3d maps from the temporal database or a"
-" specific space time dataset."
+msgid "Unregisters raster, vector and raster3d maps from the temporal database or a specific space time dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.unregister_to_translate.c:4
@@ -5621,15 +5428,11 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:6
-msgid ""
-"Input space time raster dataset that defines the lower threshold, values "
-"lower this threshold are excluded from accumulation"
+msgid "Input space time raster dataset that defines the lower threshold, values lower this threshold are excluded from accumulation"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:7
-msgid ""
-"Input space time raster dataset that defines the upper threshold, values "
-"upper this threshold are excluded from accumulation"
+msgid "Input space time raster dataset that defines the upper threshold, values upper this threshold are excluded from accumulation"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:8
@@ -5691,9 +5494,7 @@
 #: ../locale/scriptstrings/t.vect.extract_to_translate.c:7
 #: ../locale/scriptstrings/t.vect.algebra_to_translate.c:8
 #: ../locale/scriptstrings/t.vect.import_to_translate.c:7
-msgid ""
-"A numerical suffix separated by an underscore will be attached to create a "
-"unique identifier"
+msgid "A numerical suffix separated by an underscore will be attached to create a unique identifier"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:15
@@ -5706,16 +5507,11 @@
 #: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:10
 #: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:9
 #: ../locale/scriptstrings/t.vect.extract_to_translate.c:8
-msgid ""
-"Suffix to add at basename: set 'gran' for granularity, 'time' for the full "
-"time format, 'num' for numerical suffix with a specific number of digits "
-"(default %05)"
+msgid "Suffix to add at basename: set 'gran' for granularity, 'time' for the full time format, 'num' for numerical suffix with a specific number of digits (default %05)"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:16
-msgid ""
-"Use these limits in case lower and/or upper input  space time raster "
-"datasets are not defined or contain NULL values"
+msgid "Use these limits in case lower and/or upper input  space time raster datasets are not defined or contain NULL values"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:17
@@ -5727,22 +5523,16 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:19
-msgid ""
-"This method will be applied to compute the accumulative values from the "
-"input maps in a single granule"
+msgid "This method will be applied to compute the accumulative values from the input maps in a single granule"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:20
-msgid ""
-"Growing Degree Days or Winkler indices; Mean: sum(input maps)/(number of "
-"input maps); Biologically Effective Degree Days; Huglin Heliothermal index"
+msgid "Growing Degree Days or Winkler indices; Mean: sum(input maps)/(number of input maps); Biologically Effective Degree Days; Huglin Heliothermal index"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:21
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:19
-msgid ""
-"Register empty maps in the output space time raster dataset, otherwise they "
-"will be deleted"
+msgid "Register empty maps in the output space time raster dataset, otherwise they will be deleted"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:22
@@ -5751,72 +5541,47 @@
 msgstr ""
-msgid ""
-"Detects accumulation patterns in temporally accumulated space time raster "
-"datasets created by t.rast.accumulate."
+msgid "Detects accumulation patterns in temporally accumulated space time raster datasets created by t.rast.accumulate."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:6
-msgid ""
-"Input space time raster dataset that specifies the minimum values to detect "
-"the accumulation pattern"
+msgid "Input space time raster dataset that specifies the minimum values to detect the accumulation pattern"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:7
-msgid ""
-"Input space time raster dataset that specifies the maximum values to detect "
+msgid "Input space time raster dataset that specifies the maximum values to detect the accumulation pattern"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:8
-msgid ""
-"The output space time raster dataset that stores the occurrence of the the "
-"accumulation pattern using the provided data range"
+msgid "The output space time raster dataset that stores the occurrence of the the accumulation pattern using the provided data range"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:9
-msgid ""
-"The output space time raster dataset that stores the indication of the "
-"start, intermediate and end of the specified data range"
+msgid "The output space time raster dataset that stores the indication of the start, intermediate and end of the specified data range"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:16
-msgid ""
-"time format, 'count' for numerical suffix with a specific number of digits "
-"(default %05)"
+msgid "Suffix to add at basename: set 'gran' for granularity, 'time' for the full time format, 'count' for numerical suffix with a specific number of digits (default %05)"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:17
-msgid ""
-"The minimum and maximum value of the occurrence of accumulated values, these"
-" values will be used if the min/max space time raster datasets are not "
-"specified"
+msgid "The minimum and maximum value of the occurrence of accumulated values, these values will be used if the min/max space time raster datasets are not specified"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:18
-msgid ""
-"The user defined values that indicate start, intermediate and end status in "
-"the indicator output space time raster dataset"
+msgid "The user defined values that indicate start, intermediate and end status in the indicator output space time raster dataset"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:1
-msgid ""
-"Aggregates temporally the maps of a space time raster dataset by a user "
-"defined granularity."
+msgid "Aggregates temporally the maps of a space time raster dataset by a user defined granularity."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:7
-msgid ""
-"Either a numerical suffix or the start time (s-flag) separated by an "
-"underscore will be attached to create a unique identifier"
+msgid "Either a numerical suffix or the start time (s-flag) separated by an underscore will be attached to create a unique identifier"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:9
-msgid ""
-"Aggregation granularity, format absolute time \"x years, x months, x weeks, "
-"x days, x hours, x minutes, x seconds\" or an integer value for relative "
-"time"
+msgid "Aggregation granularity, format absolute time \"x years, x months, x weeks, x days, x hours, x minutes, x seconds\" or an integer value for relative time"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:10
@@ -5829,9 +5594,7 @@
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:11
 #: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:12
-msgid ""
-"Offset that is used to create the output map ids, output map id is generated"
-" as: basename_ (count + offset)"
+msgid "Offset that is used to create the output map ids, output map id is generated as: basename_ (count + offset)"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:12
@@ -5855,15 +5618,11 @@
 msgstr ""
-msgid ""
-"Aggregates data of an existing space time raster dataset using the time "
-"intervals of a second space time dataset."
+msgid "Aggregates data of an existing space time raster dataset using the time intervals of a second space time dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:6
-msgid ""
-"Time intervals from this space time dataset (raster, vector or raster3d) are"
-" used for aggregation computation"
+msgid "Time intervals from this space time dataset (raster, vector or raster3d) are used for aggregation computation"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:7
@@ -5878,9 +5637,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.colors_to_translate.c:1
-msgid ""
-"Creates/modifies the color table associated with each raster map of the "
-"space time raster dataset."
+msgid "Creates/modifies the color table associated with each raster map of the space time raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.colors_to_translate.c:6
@@ -5959,9 +5716,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:1
-msgid ""
-"Produces a space time vector dataset of specified contours from a space time"
-" raster dataset."
+msgid "Produces a space time vector dataset of specified contours from a space time raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:3
@@ -5994,9 +5749,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:15
-msgid ""
-"Number of r.contour processes to run in parallel, more than 1 process works "
-"only in conjunction with flag -t"
+msgid "Number of r.contour processes to run in parallel, more than 1 process works only in conjunction with flag -t"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:16
@@ -6014,9 +5767,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.univar_to_translate.c:1
-msgid ""
-"Calculates univariate statistics from the non-null cells for each registered"
-" raster map of a space time raster dataset."
+msgid "Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.univar_to_translate.c:9
@@ -6028,9 +5779,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.univar_to_translate.c:10
-msgid ""
-"Ignore the current region settings and use the raster map regions for univar"
-" statistical calculation"
+msgid "Ignore the current region settings and use the raster map regions for univar statistical calculation"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.univar_to_translate.c:11
@@ -6053,15 +5802,11 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.list_to_translate.c:13
-msgid ""
-"The granule to be used for listing. The granule must be specified as string "
-"eg.: absolute time \"1 months\" or relative time \"1\""
+msgid "The granule to be used for listing. The granule must be specified as string eg.: absolute time \"1 months\" or relative time \"1\""
 msgstr ""
 #: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:1
-msgid ""
-"Performs spatio-temporal mapcalc expressions on temporally sampled maps of "
-"space time raster datasets."
+msgid "Performs spatio-temporal mapcalc expressions on temporally sampled maps of space time raster datasets."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:6
@@ -6078,21 +5823,15 @@
 #: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:12
 #: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:11
 #: ../locale/scriptstrings/t.vect.algebra_to_translate.c:9
-msgid ""
-"Check the spatial topology of temporally related maps and process only "
-"spatially related maps"
+msgid "Check the spatial topology of temporally related maps and process only spatially related maps"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.algebra_to_translate.c:1
-msgid ""
-"Apply temporal and spatial operations on space time raster datasets using "
-"temporal raster algebra."
+msgid "Apply temporal and spatial operations on space time raster datasets using temporal raster algebra."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.algebra_to_translate.c:6
-msgid ""
-"r.mapcalc expression for temporal and spatial analysis of space time raster "
-"datasets"
+msgid "r.mapcalc expression for temporal and spatial analysis of space time raster datasets"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.algebra_to_translate.c:12
@@ -6102,15 +5841,11 @@
 #: ../locale/scriptstrings/t.rast.algebra_to_translate.c:13
 #: ../locale/scriptstrings/t.select_to_translate.c:9
-msgid ""
-"Perform a dry run, compute all dependencies and module calls but don't run "
-"them"
+msgid "Perform a dry run, compute all dependencies and module calls but don't run them"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:1
-msgid ""
-"Performs a neighborhood analysis for each map in a space time raster "
-"dataset."
+msgid "Performs a neighborhood analysis for each map in a space time raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:6
@@ -6127,9 +5862,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.series_to_translate.c:1
-msgid ""
-"Performs different aggregation algorithms from r.series on all or a subset "
-"of raster maps in a space time raster dataset."
+msgid "Performs different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.series_to_translate.c:4
@@ -6144,15 +5877,12 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.series_to_translate.c:9
-msgid ""
-"Do not assign the space time raster dataset start and end time to the output"
-" map"
+msgid "Do not assign the space time raster dataset start and end time to the output map"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.series_to_translate.c:10
 #: ../raster/r.resamp.filter/main.c:431 ../raster/r.series/main.c:187
-#: ../raster/r.series.accumulate/main.c:159
-#: ../raster/r.resamp.stats/main.c:288
+#: ../raster/r.series.accumulate/main.c:159 ../raster/r.resamp.stats/main.c:288
 msgid "Propagate NULLs"
 msgstr ""
@@ -6179,9 +5909,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.export_to_translate.c:10
-msgid ""
-"Supported are GTiff, AAIGrid via r.out.gdal and the GRASS package format of "
-"r.pack"
+msgid "Supported are GTiff, AAIGrid via r.out.gdal and the GRASS package format of r.pack"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.export_to_translate.c:11
@@ -6212,9 +5940,7 @@
 #: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:9
 #: ../raster/r.out.vtk/parameters.c:59
-msgid ""
-"Create VTK point data instead of VTK cell data (if no elevation map is "
-"given)"
+msgid "Create VTK point data instead of VTK cell data (if no elevation map is given)"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:10
@@ -6223,9 +5949,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:11
-msgid ""
-"Export files using the space time dataset granularity for equidistant time "
-"between maps, where statement will be ignored"
+msgid "Export files using the space time dataset granularity for equidistant time between maps, where statement will be ignored"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:1
@@ -6239,9 +5963,7 @@
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:11
 #: ../locale/scriptstrings/t.vect.import_to_translate.c:11
-msgid ""
-"Create a new location and import the data into it. Do not run this module in"
-" parallel or interrupt it when a new location should be created"
+msgid "Create a new location and import the data into it. Do not run this module in parallel or interrupt it when a new location should be created"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:14
@@ -6258,14 +5980,11 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:19
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not"
-" import the space time raster datasets."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the space time raster datasets."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:1
-msgid ""
-"Replaces gaps in a space time raster dataset with interpolated raster maps."
+msgid "Replaces gaps in a space time raster dataset with interpolated raster maps."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:9
@@ -6273,8 +5992,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:10
-msgid ""
-"Assign the space time raster dataset start and end time to the output map"
+msgid "Assign the space time raster dataset start and end time to the output map"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.extract_to_translate.c:1
@@ -6308,9 +6026,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:12
-msgid ""
-"Number of r.to.vect processes to run in parallel, more than 1 process works "
+msgid "Number of r.to.vect processes to run in parallel, more than 1 process works only in conjunction with flag -t"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:15
@@ -6344,9 +6060,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:1
-msgid ""
-"Sample a space time raster dataset at specific vector point coordinates and "
-"write the output to stdout using different layouts"
+msgid "Sample a space time raster dataset at specific vector point coordinates and write the output to stdout using different layouts"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:6
@@ -6358,9 +6072,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:9
-msgid ""
-"The layout of the output. One point per row (row), one point per column "
-"(col), all timsteps in one row (timerow)"
+msgid "The layout of the output. One point per row (row), one point per column (col), all timsteps in one row (timerow)"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:10
@@ -6403,9 +6115,7 @@
 msgstr ""
-msgid ""
-"Performs r3.mapcalc expressions on maps of sampled space time 3D raster "
-"datasets."
+msgid "Performs r3.mapcalc expressions on maps of sampled space time 3D raster datasets."
 msgstr ""
 #: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:7
@@ -6413,21 +6123,15 @@
 msgstr ""
-msgid ""
-"Apply temporal and spatial operations on space time 3D raster datasets using"
-" temporal 3D raster algebra."
+msgid "Apply temporal and spatial operations on space time 3D raster datasets using temporal 3D raster algebra."
 msgstr ""
 #: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:7
-msgid ""
-"Algebraic expression for temporal and spatial analysis of space time 3D "
-"raster datasets"
+msgid "Algebraic expression for temporal and spatial analysis of space time 3D raster datasets"
 msgstr ""
 #: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:1
-msgid ""
-" 3D raster map of a space time 3D raster dataset."
+msgid "Calculates univariate statistics from the non-null cells for each registered 3D raster map of a space time 3D raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rename_to_translate.c:1
@@ -6440,9 +6144,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.select_to_translate.c:1
-msgid ""
-"Select maps from space time datasets by topological relationships to other "
-"space time datasets using temporal algebra."
+msgid "Select maps from space time datasets by topological relationships to other space time datasets using temporal algebra."
 msgstr ""
 #: ../locale/scriptstrings/t.select_to_translate.c:7
@@ -6450,9 +6152,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.select_to_translate.c:8
-msgid ""
-"Check the spatial topology of temporally related maps and select only "
+msgid "Check the spatial topology of temporally related maps and select only spatially related maps"
 msgstr ""
 #: ../locale/scriptstrings/t.snap_to_translate.c:1
@@ -6481,9 +6181,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.shift_to_translate.c:10
-msgid ""
-"Format absolute time: \"x years, x months, x weeks, x days, x hours, x "
-"minutes, x seconds\", relative time is of type integer"
+msgid "Format absolute time: \"x years, x months, x weeks, x days, x hours, x minutes, x seconds\", relative time is of type integer"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.list_to_translate.c:1
@@ -6491,8 +6189,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.vect.db.select_to_translate.c:1
-msgid ""
-"Prints attributes of vector maps registered in a space time vector dataset."
+msgid "Prints attributes of vector maps registered in a space time vector dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.db.select_to_translate.c:6
@@ -6502,8 +6199,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.vect.export_to_translate.c:1
-msgid ""
-"Exports a space time vector dataset as GRASS GIS specific archive file."
+msgid "Exports a space time vector dataset as GRASS GIS specific archive file."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.export_to_translate.c:6
@@ -6523,9 +6219,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.vect.extract_to_translate.c:9
-msgid ""
-"The number of v.extract processes to run in parallel. Use only if database "
-"backend is used which supports concurrent writing"
+msgid "The number of v.extract processes to run in parallel. Use only if database backend is used which supports concurrent writing"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.extract_to_translate.c:10
@@ -6533,62 +6227,43 @@
 msgstr ""
 #: ../locale/scriptstrings/t.vect.algebra_to_translate.c:1
-msgid ""
-"Apply temporal and spatial operations on space time vector datasets using "
-"temporal vector algebra."
+msgid "Apply temporal and spatial operations on space time vector datasets using temporal vector algebra."
 msgstr ""
-msgid ""
-"Imports a space time vector dataset from a GRASS GIS specific archive file."
+msgid "Imports a space time vector dataset from a GRASS GIS specific archive file."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.import_to_translate.c:15
-msgid ""
-" import the space time vector datasets."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the space time vector datasets."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:1
-msgid ""
-"Stores raster map values at spatial and temporal positions of vector points "
-"as vector attributes."
+msgid "Stores raster map values at spatial and temporal positions of vector points as vector attributes."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:6
-msgid ""
-"Name of the vector column to be created and to store sampled raster values"
+msgid "Name of the vector column to be created and to store sampled raster values"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:7
-msgid ""
-"The use of a column name forces t.vect.what.rast to sample only values from "
-"the first map found in an interval. Otherwise the raster map names are used "
-"as column names"
+msgid "The use of a column name forces t.vect.what.rast to sample only values from the first map found in an interval. Otherwise the raster map names are used as column names"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:1
-msgid ""
-"Observes specific locations in a space time raster dataset over a period of "
-"time using vector points."
+msgid "Observes specific locations in a space time raster dataset over a period of time using vector points."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:6
-msgid ""
-"Name of the new created vector map that stores the sampled values in "
-"different layers"
+msgid "Name of the new created vector map that stores the sampled values in different layers"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:7
-msgid ""
-"Names of the vector columns to be created and to store sampled raster "
-"values, one name for each STRDS"
+msgid "Names of the vector columns to be created and to store sampled raster values, one name for each STRDS"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.univar_to_translate.c:1
-msgid ""
-"Calculates univariate statistics of attributes for each registered vector "
-"map of a space time vector dataset"
+msgid "Calculates univariate statistics of attributes for each registered vector map of a space time vector dataset"
 msgstr ""
 #: ../general/g.region/printwindow.c:236 ../general/g.region/printwindow.c:492
@@ -6631,15 +6306,11 @@
 msgstr ""
 #: ../general/g.region/printwindow.c:401
-msgid ""
-"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
-"the -p flag instead."
+msgid "You are in a simple XY location, projection to Lat/Lon is not possible. Use the -p flag instead."
 msgstr ""
 #: ../general/g.region/printwindow.c:626
-msgid ""
-"WGS84 output not possible as this location does not contain datum "
-"transformation parameters. Try running g.setproj."
+msgid "WGS84 output not possible as this location does not contain datum transformation parameters. Try running g.setproj."
 msgstr ""
 #: ../general/g.region/printwindow.c:772
@@ -6723,9 +6394,7 @@
 msgstr ""
 #: ../general/g.region/main.c:129
-msgid ""
-"The difference between the projection's grid north and true north, measured "
-"at the center coordinates of the current region."
+msgid "The difference between the projection's grid north and true north, measured at the center coordinates of the current region."
 msgstr ""
 #: ../general/g.region/main.c:135
@@ -6737,9 +6406,7 @@
 msgstr ""
 #: ../general/g.region/main.c:152
-msgid ""
-"Align region to resolution (default = align to bounds, works only for 2D "
-"resolution)"
+msgid "Align region to resolution (default = align to bounds, works only for 2D resolution)"
 msgstr ""
 #: ../general/g.region/main.c:158
@@ -6848,8 +6515,7 @@
 #: ../general/g.region/main.c:797 ../vector/v.vol.rst/main.c:615
 #: ../vector/v.colors/main.c:312 ../doc/raster/r.example/main.c:105
 #: ../imagery/i.gensigset/parse.c:44 ../imagery/i.gensig/parse.c:38
-#: ../imagery/i.pca/main.c:139
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:155
+#: ../imagery/i.pca/main.c:139 ../imagery/i.ortho.photo/i.ortho.elev/main.c:155
 #: ../misc/m.nviz.image/surface.c:50 ../misc/m.nviz.image/surface.c:107
 #: ../raster/r.walk/main.c:435 ../raster/r.walk/main.c:440
 #: ../raster/r.walk/main.c:801 ../raster/r.category/main.c:119
@@ -6941,8 +6607,7 @@
 msgstr ""
 #: ../general/g.region/main.c:821
-msgid ""
-"Unable to change default region. The current mapset is not <PERMANENT>."
+msgid "Unable to change default region. The current mapset is not <PERMANENT>."
 msgstr ""
 #: ../general/g.region/main.c:838 ../raster/r.in.lidar/main.c:519
@@ -6967,9 +6632,7 @@
 msgstr ""
 #: ../general/g.mapsets/main.c:67
-msgid ""
-"Affects the user's access to data existing under the other mapsets in the "
-"current location."
+msgid "Affects the user's access to data existing under the other mapsets in the current location."
 msgstr ""
 #: ../general/g.mapsets/main.c:73
@@ -7066,9 +6729,7 @@
 msgstr ""
 #: ../general/g.remove/main.c:73
-msgid ""
-"Removes data base element files from the user's current mapset using the "
-"search pattern."
+msgid "Removes data base element files from the user's current mapset using the search pattern."
 msgstr ""
 #: ../general/g.remove/main.c:83 ../general/g.remove/main.c:91
@@ -7134,9 +6795,7 @@
 #: ../general/g.remove/main.c:267
 #, c-format
-msgid ""
-"Nothing removed. You must use the force flag (-%c) to actually remove them. "
-"Exiting."
+msgid "Nothing removed. You must use the force flag (-%c) to actually remove them. Exiting."
 msgstr ""
 #: ../general/g.remove/construct_pattern.c:37
@@ -7170,8 +6829,7 @@
 msgstr ""
 #: ../general/g.message/main.c:37
-msgid ""
-"Prints a message, warning, progress info, or fatal error in the GRASS way."
+msgid "Prints a message, warning, progress info, or fatal error in the GRASS way."
 msgstr ""
 #: ../general/g.message/main.c:39
@@ -7246,9 +6904,7 @@
 msgstr ""
 #: ../general/g.mkfontcap/main.c:73
-msgid ""
-"Generates the font configuration file by scanning various directories for "
-"fonts."
+msgid "Generates the font configuration file by scanning various directories for fonts."
 msgstr ""
 #: ../general/g.mkfontcap/main.c:79
@@ -7256,8 +6912,7 @@
 msgstr ""
 #: ../general/g.mkfontcap/main.c:84
-msgid ""
-"Write font configuration file to standard output instead of $GISBASE/etc"
+msgid "Write font configuration file to standard output instead of $GISBASE/etc"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:91
@@ -7265,21 +6920,16 @@
 msgstr ""
 #: ../general/g.mkfontcap/main.c:93
-msgid ""
-"Comma-separated list of extra directories to scan for Freetype-compatible "
-"fonts as well as the defaults (see documentation)"
+msgid "Comma-separated list of extra directories to scan for Freetype-compatible fonts as well as the defaults (see documentation)"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:110
 #, c-format
-msgid ""
-"Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
+msgid "Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:122
-msgid ""
-"This GRASS installation was compiled without Freetype support, extradirs "
-"parameter ignored"
+msgid "This GRASS installation was compiled without Freetype support, extradirs parameter ignored"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:149
@@ -7317,9 +6967,7 @@
 #: ../general/g.findfile/main.c:97
 #, c-format
-msgid ""
-"Parameter 'file' contains reference to <%s> mapset, but mapset parameter "
-"<%s> does not correspond"
+msgid "Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%s> does not correspond"
 msgstr ""
 #: ../general/g.gisenv/main.c:45
@@ -7721,9 +7369,7 @@
 msgstr ""
 #: ../general/g.list/main.c:69
-msgid ""
-"Lists available GRASS data base files of the user-specified data type "
-"optionally using the search pattern."
+msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
 msgstr ""
 #: ../general/g.list/main.c:85
@@ -7825,10 +7471,7 @@
 msgstr ""
 #: ../general/g.gui/main.c:72
-msgid ""
-"By default the GUI starts in the background and control is immediately "
-"returned to the caller. When GUI runs in foregreound, it blocks the command "
-"line"
+msgid "By default the GUI starts in the background and control is immediately returned to the caller. When GUI runs in foregreound, it blocks the command line"
 msgstr ""
 #: ../general/g.gui/main.c:78
@@ -8014,10 +7657,7 @@
 msgstr ""
 #: ../general/g.setproj/main.c:456
-msgid ""
-"But if you change zone, all the existing data will be interpreted by "
-"projection software. GRASS will not automatically re-project or even change "
-"the headers for existing maps."
+msgid "But if you change zone, all the existing data will be interpreted by projection software. GRASS will not automatically re-project or even change the headers for existing maps."
 msgstr ""
 #: ../general/g.setproj/main.c:461
@@ -8148,9 +7788,7 @@
 msgstr ""
 #: ../general/g.copy/main.c:44
-msgid ""
-"Copies available data files in the current mapset search path to the user's "
-"current mapset."
+msgid "Copies available data files in the current mapset search path to the user's current mapset."
 msgstr ""
 #: ../general/g.copy/main.c:51
@@ -8246,16 +7884,11 @@
 #: ../general/g.proj/create.c:40
 #, c-format
-msgid ""
-"You must select the PERMANENT mapset before updating the current location's "
-"projection (current mapset is <%s>)"
+msgid "You must select the PERMANENT mapset before updating the current location's projection (current mapset is <%s>)"
 msgstr ""
 #: ../general/g.proj/create.c:66
-msgid ""
-"Default region was updated to the new projection, but if you have multiple "
-"mapsets `g.region -d` should be run in each to update the region from the "
-"default"
+msgid "Default region was updated to the new projection, but if you have multiple mapsets `g.region -d` should be run in each to update the region from the default"
 msgstr ""
 #: ../general/g.proj/create.c:70
@@ -8272,9 +7905,7 @@
 msgstr ""
 #: ../general/g.proj/main.c:69
-msgid ""
-"Prints or modifies GRASS projection information files (in various co-"
-"ordinate system descriptions)."
+msgid "Prints or modifies GRASS projection information files (in various co-ordinate system descriptions)."
 msgstr ""
 #: ../general/g.proj/main.c:72
@@ -8302,8 +7933,7 @@
 msgstr ""
 #: ../general/g.proj/main.c:106
-msgid ""
-"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
+msgid "Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
 msgstr ""
 #: ../general/g.proj/main.c:116
@@ -8349,9 +7979,7 @@
 msgstr ""
 #: ../general/g.proj/main.c:188
-msgid ""
-"Force override of datum transformation information in input co-ordinate "
-"system"
+msgid "Force override of datum transformation information in input co-ordinate system"
 msgstr ""
 #: ../general/g.proj/main.c:193 ../raster/r.null/main.c:74
@@ -8427,9 +8055,7 @@
 #: ../general/g.proj/input.c:259
 #, c-format
-msgid ""
-"Read of file %s was successful, but it did not contain projection "
-"information. 'XY (unprojected)' will be used"
+msgid "Read of file %s was successful, but it did not contain projection information. 'XY (unprojected)' will be used"
 msgstr ""
 #: ../general/g.proj/output.c:146
@@ -8505,15 +8131,11 @@
 #: ../general/g.version/main.c:172
 #, c-format
-msgid ""
-"Cannot determine GRASS libgis version and date number. The GRASS build might"
-" be broken. Report this to developers or packagers.\n"
+msgid "Cannot determine GRASS libgis version and date number. The GRASS build might be broken. Report this to developers or packagers.\n"
 msgstr ""
 #: ../general/g.version/main.c:179
-msgid ""
-"GRASS GIS libgis version and date number don't have the expected format. "
-"Trying to print the original strings..."
+msgid "GRASS GIS libgis version and date number don't have the expected format. Trying to print the original strings..."
 msgstr ""
 #: ../general/g.version/main.c:181
@@ -8543,8 +8165,7 @@
 msgstr ""
 #: ../general/g.mapset/main.c:52
-msgid ""
-"Optionally create new mapset or list available mapsets in given location."
+msgid "Optionally create new mapset or list available mapsets in given location."
 msgstr ""
 #: ../general/g.mapset/main.c:56
@@ -8607,8 +8228,7 @@
 msgstr ""
 #: ../general/g.mapset/main.c:205
-msgid ""
-"Mapset switched. Your shell continues to use the history for the old mapset"
+msgid "Mapset switched. Your shell continues to use the history for the old mapset"
 msgstr ""
 #: ../general/g.mapset/main.c:210
@@ -8726,9 +8346,7 @@
 msgstr ""
 #: ../vector/v.extract/extract.c:228
-msgid ""
-"Topology level required for extracting areas for OGR layers. Areas will be "
-"not processed."
+msgid "Topology level required for extracting areas for OGR layers. Areas will be not processed."
 msgstr ""
 #: ../vector/v.extract/main.c:81 ../vector/v.perturb/main.c:65
@@ -8739,9 +8357,7 @@
 msgstr ""
 #: ../vector/v.extract/main.c:83
-msgid ""
-"Selects vector features from an existing vector map and creates a new vector"
-" map containing only the selected features."
+msgid "Selects vector features from an existing vector map and creates a new vector map containing only the selected features."
 msgstr ""
 #: ../vector/v.extract/main.c:88
@@ -8798,9 +8414,7 @@
 #: ../vector/v.extract/main.c:161
 #, c-format
-msgid ""
-"Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only"
-" one of them."
+msgid "Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only one of them."
 msgstr ""
 #: ../vector/v.extract/main.c:208
@@ -8851,9 +8465,7 @@
 msgstr[1] ""
 #: ../vector/v.extract/main.c:286
-msgid ""
-"This map has no categories attached. Use v.category to attach categories to "
-"this vector map."
+msgid "This map has no categories attached. Use v.category to attach categories to this vector map."
 msgstr ""
 #: ../vector/v.extract/main.c:293
@@ -8862,16 +8474,12 @@
 #: ../vector/v.extract/main.c:297
 #, c-format
-msgid ""
-"Random category count must be smaller than feature count. There are only %d "
-"features of type(s): %s"
+msgid "Random category count must be smaller than feature count. There are only %d features of type(s): %s"
 msgstr ""
 #: ../vector/v.extract/main.c:320
 #, c-format
-msgid ""
-"Random category count is larger or equal to uniq <%s> feature category count"
-" %d"
+msgid "Random category count is larger or equal to uniq <%s> feature category count %d"
 msgstr ""
 #: ../vector/v.extract/main.c:354
@@ -8920,10 +8528,10 @@
 msgstr ""
 #: ../vector/v.generalize/network.c:89 ../vector/v.net.spanningtree/main.c:124
-#: ../vector/v.net.timetable/main.c:405
-#: ../vector/v.net.connectivity/main.c:178 ../vector/v.net.flow/main.c:226
-#: ../vector/v.net.centrality/main.c:284 ../vector/v.net.distance/main.c:264
-#: ../vector/v.net.bridge/main.c:134 ../vector/v.net.components/main.c:163
+#: ../vector/v.net.timetable/main.c:405 ../vector/v.net.connectivity/main.c:178
+#: ../vector/v.net.flow/main.c:226 ../vector/v.net.centrality/main.c:284
+#: ../vector/v.net.distance/main.c:264 ../vector/v.net.bridge/main.c:134
+#: ../vector/v.net.components/main.c:163
 #, c-format
 msgid "Unable to build graph for vector map <%s>"
 msgstr ""
@@ -8974,9 +8582,7 @@
 msgstr ""
 #: ../vector/v.generalize/main.c:102
-msgid ""
-"Lines and boundaries causing errors (collapsed to a point or topology "
-"errors)"
+msgid "Lines and boundaries causing errors (collapsed to a point or topology errors)"
 msgstr ""
 #: ../vector/v.generalize/main.c:126
@@ -9044,8 +8650,7 @@
 msgstr ""
 #: ../vector/v.generalize/main.c:164
-msgid ""
-"Percentage of the points in the output of 'douglas_reduction' algorithm"
+msgid "Percentage of the points in the output of 'douglas_reduction' algorithm"
 msgstr ""
 #: ../vector/v.generalize/main.c:173
@@ -9145,8 +8750,7 @@
 #: ../vector/v.generalize/main.c:567
 #, c-format
-msgid ""
-"%d boundaries were not modified because modification would damage topology"
+msgid "%d boundaries were not modified because modification would damage topology"
 msgstr ""
 #: ../vector/v.generalize/main.c:570
@@ -9156,8 +8760,7 @@
 #: ../vector/v.generalize/main.c:591
 #, c-format
-msgid ""
-"Number of vertices for selected features %s from %d to %d (%d%% remaining)"
+msgid "Number of vertices for selected features %s from %d to %d (%d%% remaining)"
 msgstr ""
 #: ../vector/v.generalize/main.c:592
@@ -9218,8 +8821,7 @@
 msgstr ""
 #: ../vector/v.net/args.c:42
-msgid ""
-"connect still unconnected points to vector network by inserting new line(s)"
+msgid "connect still unconnected points to vector network by inserting new line(s)"
 msgstr ""
 #: ../vector/v.net/args.c:44
@@ -9227,14 +8829,11 @@
 msgstr ""
 #: ../vector/v.net/args.c:46
-msgid ""
-"print to standard output {line_category start_point_category "
-"end_point_category}"
+msgid "print to standard output {line_category start_point_category end_point_category}"
 msgstr ""
 #: ../vector/v.net/args.c:48
-msgid ""
-"print to standard output {point_category line_category[,line_category...]}"
+msgid "print to standard output {point_category line_category[,line_category...]}"
 msgstr ""
 #: ../vector/v.net/args.c:50
@@ -9305,9 +8904,7 @@
 msgstr ""
 #: ../vector/v.net/args.c:99
-msgid ""
-"For operation 'connect'. By default, a new line from the point to the "
-"network is created."
+msgid "For operation 'connect'. By default, a new line from the point to the network is created."
 msgstr ""
 #: ../vector/v.net/args.c:103
@@ -9315,9 +8912,7 @@
 msgstr ""
 #: ../vector/v.net/args.c:106
-msgid ""
-"Layer where turntable will be attached. Format: layer number[/layer "
-"name].Required for operation 'turntable'."
+msgid "Layer where turntable will be attached. Format: layer number[/layer name].Required for operation 'turntable'."
 msgstr ""
 #: ../vector/v.net/args.c:114 ../vector/v.net.alloc/main.c:143
@@ -9327,10 +8922,7 @@
 msgstr ""
 #: ../vector/v.net/args.c:117
-msgid ""
-"Layer with unique categories for every line in arc_layer and point on every "
-"node.  The categories are used in turntable. Format: layer number[/layer "
-"name]. Required for operation 'turntable'."
+msgid "Layer with unique categories for every line in arc_layer and point on every node.  The categories are used in turntable. Format: layer number[/layer name]. Required for operation 'turntable'."
 msgstr ""
 #: ../vector/v.net/args.c:146
@@ -9512,9 +9104,7 @@
 msgstr ""
 #: ../vector/v.voronoi/main.c:127
-msgid ""
-"Creates a Voronoi diagram in current region from an input vector map "
-"containing points or centroids."
+msgid "Creates a Voronoi diagram in current region from an input vector map containing points or centroids."
 msgstr ""
 #: ../vector/v.voronoi/main.c:131 ../vector/v.sample/main.c:82
@@ -9527,9 +9117,7 @@
 msgstr ""
 #: ../vector/v.voronoi/main.c:142
-msgid ""
-"Applies to input areas only. Smaller values produce smoother output but can "
-"cause numerical instability."
+msgid "Applies to input areas only. Smaller values produce smoother output but can cause numerical instability."
 msgstr ""
 #: ../vector/v.voronoi/main.c:149
@@ -9537,9 +9125,7 @@
 msgstr ""
 #: ../vector/v.voronoi/main.c:150
-msgid ""
-"Applies only to skeleton extraction. Default = -1 will extract the center "
-"line."
+msgid "Applies only to skeleton extraction. Default = -1 will extract the center line."
 msgstr ""
 #: ../vector/v.voronoi/main.c:156
@@ -9625,9 +9211,7 @@
 msgstr[1] ""
 #: ../vector/v.distance/main.c:95
-msgid ""
-"Finds the nearest element in vector map 'to' for elements in vector map "
-"'from'."
+msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
 msgstr ""
 #: ../vector/v.distance/main.c:99
@@ -9669,8 +9253,7 @@
 msgstr ""
 #: ../vector/v.distance/main.c:134
-msgid ""
-"Name for output vector map containing lines connecting nearest elements"
+msgid "Name for output vector map containing lines connecting nearest elements"
 msgstr ""
 #: ../vector/v.distance/main.c:142
@@ -9702,14 +9285,11 @@
 msgstr ""
 #: ../vector/v.distance/main.c:173
-msgid ""
-"distance to the nearest point on the 'to' feature along that linear feature"
+msgid "distance to the nearest point on the 'to' feature along that linear feature"
 msgstr ""
 #: ../vector/v.distance/main.c:175
-msgid ""
-"angle along the nearest linear feature in the 'to' map, measured CCW from "
-"the +x axis, in radians, between -Pi and Pi inclusive"
+msgid "angle along the nearest linear feature in the 'to' map, measured CCW from the +x axis, in radians, between -Pi and Pi inclusive"
 msgstr ""
 #: ../vector/v.distance/main.c:178
@@ -9717,8 +9297,7 @@
 msgstr ""
 #: ../vector/v.distance/main.c:191
-msgid ""
-"Column name(s) where values specified by 'upload' option will be uploaded"
+msgid "Column name(s) where values specified by 'upload' option will be uploaded"
 msgstr ""
 #: ../vector/v.distance/main.c:197
@@ -9746,9 +9325,7 @@
 msgstr ""
 #: ../vector/v.distance/main.c:220
-msgid ""
-"Output is written to stdout but may be uploaded to a new table created by "
-"this module; multiple 'upload' options may be used."
+msgid "Output is written to stdout but may be uploaded to a new table created by this module; multiple 'upload' options may be used."
 msgstr ""
 #: ../vector/v.distance/main.c:284
@@ -10023,8 +9600,7 @@
 msgstr ""
 #: ../vector/v.edit/args.c:154
-msgid ""
-"For 'shorter' use negative threshold value, positive value for 'longer'"
+msgid "For 'shorter' use negative threshold value, positive value for 'longer'"
 msgstr ""
 #: ../vector/v.edit/args.c:160
@@ -10040,9 +9616,7 @@
 msgstr ""
 #: ../vector/v.edit/args.c:176
-msgid ""
-"Snap added or modified features in the given threshold to the nearest "
-"existing feature"
+msgid "Snap added or modified features in the given threshold to the nearest existing feature"
 msgstr ""
 #: ../vector/v.edit/args.c:182
@@ -10116,9 +9690,7 @@
 msgstr ""
 #: ../vector/v.edit/main.c:63
-msgid ""
-"Edits a vector map, allows adding, deleting and modifying selected vector "
-"features."
+msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
 msgstr ""
 #: ../vector/v.edit/main.c:72
@@ -10138,16 +9710,12 @@
 #: ../vector/v.edit/main.c:140
 #, c-format
-msgid ""
-"Unable to open vector map <%s> on topological level. Try to rebuild vector "
-"topology by v.build."
+msgid "Unable to open vector map <%s> on topological level. Try to rebuild vector topology by v.build."
 msgstr ""
 #: ../vector/v.edit/main.c:160
 #, c-format
-msgid ""
-"Unable to open vector map <%s> as the background map. It is given as vector "
-"map to be edited."
+msgid "Unable to open vector map <%s> as the background map. It is given as vector map to be edited."
 msgstr ""
 #: ../vector/v.edit/main.c:171
@@ -10169,9 +9737,7 @@
 #: ../vector/v.edit/main.c:234
 #, c-format
-msgid ""
-"Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert "
-"the vector map to 3D using e.g. %s."
+msgid "Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert the vector map to 3D using e.g. %s."
 msgstr ""
 #: ../vector/v.edit/main.c:276
@@ -10260,9 +9826,7 @@
 #: ../vector/v.edit/main.c:387
 #, c-format
-msgid ""
-"Multiple background maps were given. Selected features will be copied only "
-"from vector map <%s>."
+msgid "Multiple background maps were given. Selected features will be copied only from vector map <%s>."
 msgstr ""
 #: ../vector/v.edit/main.c:397
@@ -10370,9 +9934,7 @@
 msgstr ""
 #: ../vector/v.vol.rst/main.c:241
-msgid ""
-"Interpolates point data to a 3D raster map using regularized spline with "
-"tension (RST) algorithm."
+msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
 msgstr ""
 #: ../vector/v.vol.rst/main.c:246
@@ -10511,9 +10073,7 @@
 msgstr ""
 #: ../vector/v.vol.rst/main.c:491
-msgid ""
-"Crossvalidation cannot be computed simultanuously with output grids or devi "
-"file"
+msgid "Crossvalidation cannot be computed simultanuously with output grids or devi file"
 msgstr ""
 #: ../vector/v.vol.rst/main.c:507 ../vector/v.vol.rst/main.c:510
@@ -10574,9 +10134,7 @@
 #: ../vector/v.vol.rst/main.c:640
 #, c-format
-msgid ""
-"Unable to create <%s> raster map without cross_input raster map being "
-"specified"
+msgid "Unable to create <%s> raster map without cross_input raster map being specified"
 msgstr ""
 #: ../vector/v.vol.rst/main.c:818
@@ -10637,8 +10195,7 @@
 #: ../vector/v.univar/main.c:366 ../vector/v.sample/main.c:152
 #: ../vector/v.class/main.c:132 ../vector/v.to.rast3/main.c:95
 #: ../vector/v.surf.bspline/main.c:392 ../vector/v.surf.idw/read_sites.c:68
-#: ../ps/ps.map/catval.c:66 ../ps/ps.map/catval.c:131
-#: ../ps/ps.map/catval.c:198
+#: ../ps/ps.map/catval.c:66 ../ps/ps.map/catval.c:131 ../ps/ps.map/catval.c:198
 msgid "Unable to select data from table"
 msgstr ""
@@ -10651,8 +10208,7 @@
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:128
-msgid ""
-"Column type of smooth column is not supported (must be integer or double)"
+msgid "Column type of smooth column is not supported (must be integer or double)"
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:150
@@ -10690,29 +10246,22 @@
 #: ../vector/v.vol.rst/user1.c:311
 #, c-format
-msgid ""
-"There are points outside specified 2D/3D region--ignored %d points (total "
-"points: %d)"
+msgid "There are points outside specified 2D/3D region--ignored %d points (total points: %d)"
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:315
 #, c-format
-msgid ""
-"Points are more dense than specified 'DMIN'--ignored %d points (remain %d)"
+msgid "Points are more dense than specified 'DMIN'--ignored %d points (remain %d)"
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:321
 #, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given "
-"NPMIN=%d"
+msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:341
 #, c-format
-msgid ""
-"There is less than %d points for interpolation, no segmentation is "
-"necessary, to run the program faster, set segmax=%d (see manual)"
+msgid "There is less than %d points for interpolation, no segmentation is necessary, to run the program faster, set segmax=%d (see manual)"
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:368
@@ -10985,9 +10534,7 @@
 msgstr ""
 #: ../vector/v.vect.stats/main.c:187
-msgid ""
-"Column to hold points count, must be of type integer, will be created if not"
-" existing"
+msgid "Column to hold points count, must be of type integer, will be created if not existing"
 msgstr ""
 #: ../vector/v.vect.stats/main.c:194
@@ -10995,9 +10542,7 @@
 msgstr ""
 #: ../vector/v.vect.stats/main.c:196
-msgid ""
-"Column to hold statistics, must be of type double, will be created if not "
-"existing"
+msgid "Column to hold statistics, must be of type double, will be created if not existing"
 msgstr ""
 #: ../vector/v.vect.stats/main.c:203
@@ -11174,9 +10719,7 @@
 msgstr ""
 #: ../vector/v.out.lidar/main.c:572 ../vector/v.out.lidar/main.c:582
-msgid ""
-"This scale does not change the values itself but only how precisely they are"
-" stored, for example 0.01 will preserve two decimal places"
+msgid "This scale does not change the values itself but only how precisely they are stored, for example 0.01 will preserve two decimal places"
 msgstr ""
 #: ../vector/v.out.lidar/main.c:581
@@ -11258,10 +10801,7 @@
 msgstr ""
 #: ../vector/v.perturb/main.c:92
-msgid ""
-"If the distribution is uniform, only one parameter, the maximum, is needed. "
-"For a normal distribution, two parameters, the mean and standard deviation, "
-"are required."
+msgid "If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
 msgstr ""
 #: ../vector/v.perturb/main.c:102
@@ -11301,9 +10841,7 @@
 msgstr ""
 #: ../vector/v.qcount/main.c:72
-msgid ""
-"Name for output quadrat centers map (number of points is written as "
-"category)"
+msgid "Name for output quadrat centers map (number of points is written as category)"
 msgstr ""
 #: ../vector/v.qcount/main.c:78
@@ -11424,9 +10962,7 @@
 msgstr ""
 #: ../vector/v.colors/main.c:234
-msgid ""
-"Reading rules from standard input is not implemented yet, please provide "
-"path to rules file instead."
+msgid "Reading rules from standard input is not implemented yet, please provide path to rules file instead."
 msgstr ""
 #: ../vector/v.colors/main.c:244
@@ -11465,8 +11001,8 @@
 msgstr ""
 #: ../vector/v.colors/main.c:315 ../raster/r.colors/edit_colors.c:396
-#: ../raster/r.grow.distance/main.c:384
-#: ../raster/r.colors.out/raster_main.c:69 ../raster/r.fill.dir/main.c:153
+#: ../raster/r.grow.distance/main.c:384 ../raster/r.colors.out/raster_main.c:69
+#: ../raster/r.fill.dir/main.c:153
 #, c-format
 msgid "Unable to read color table for raster map <%s>"
 msgstr ""
@@ -11640,9 +11176,7 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:224
-msgid ""
-"List of column names to be used instead of original names, first is used for"
-" category column"
+msgid "List of column names to be used instead of original names, first is used for category column"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:243
@@ -11650,9 +11184,7 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:245
-msgid ""
-"If not given, categories are generated as unique values and stored in 'cat' "
-"column"
+msgid "If not given, categories are generated as unique values and stored in 'cat' column"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:250
@@ -11699,9 +11231,7 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:316 ../vector/v.in.lidar/main.c:328
-msgid ""
-" import the vector data."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the vector data."
 msgstr ""
 #: ../vector/v.in.ogr/main.c:334 ../vector/v.external/list.c:94
@@ -11717,16 +11247,12 @@
 #: ../vector/v.in.ogr/main.c:415
 #, c-format
-msgid ""
-"Option <%s> will be ignored. OGR doesn't support it for selected format "
-"(%s)."
+msgid "Option <%s> will be ignored. OGR doesn't support it for selected format (%s)."
 msgstr ""
 #: ../vector/v.in.ogr/main.c:420
 #, c-format
-msgid ""
-"Option <%s> will be ignored. Multiple geometry fields are supported by GDAL "
-">= 1.11"
+msgid "Option <%s> will be ignored. Multiple geometry fields are supported by GDAL >= 1.11"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:433
@@ -11760,9 +11286,7 @@
 #: ../vector/v.in.ogr/main.c:577 ../vector/v.in.lidar/main.c:507
 #: ../raster/r.in.gdal/main.c:437 ../raster/r.in.gdal/main.c:826
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location."
+msgid "Unable to convert input map projection to GRASS format; cannot create new location."
 msgstr ""
 #: ../vector/v.in.ogr/main.c:583 ../vector/v.in.lidar/main.c:513
@@ -11775,9 +11299,7 @@
 #: ../vector/v.external/proj.c:41 ../vector/v.in.pdal/projection.c:110
 #: ../vector/v.in.pdal/projection.c:156 ../vector/v.in.pdal/projection.c:189
 #: ../raster/r.in.lidar/projection.c:113
-msgid ""
-"Unable to convert input map projection information to GRASS format for "
-"checking"
+msgid "Unable to convert input map projection information to GRASS format for checking"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:620 ../vector/v.in.lidar/projection.c:126
@@ -11823,9 +11345,7 @@
 #: ../vector/v.in.ogr/main.c:695 ../vector/v.in.lidar/projection.c:93
 #: ../vector/v.external/proj.c:117 ../vector/v.in.pdal/projection.c:92
 #: ../raster/r.in.lidar/projection.c:95
-msgid ""
-"Consider generating a new location with 'location' parameter from input data"
-" set.\n"
+msgid "Consider generating a new location with 'location' parameter from input data set.\n"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:710 ../vector/v.in.lidar/projection.c:137
@@ -11856,8 +11376,7 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:792
-msgid ""
-"The 'spatial' parameters do not overlap with OGR input. Nothing to import."
+msgid "The 'spatial' parameters do not overlap with OGR input. Nothing to import."
 msgstr ""
 #: ../vector/v.in.ogr/main.c:826
@@ -11911,9 +11430,7 @@
 #: ../vector/v.in.ogr/main.c:1114
 #, c-format
-msgid ""
-"Width for column %s set to 255 (was not specified by OGR), some strings may "
-"be truncated!"
+msgid "Width for column %s set to 255 (was not specified by OGR), some strings may be truncated!"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:1126
@@ -11991,10 +11508,7 @@
 #: ../vector/v.in.ogr/main.c:1537
 #, c-format
-msgid ""
-"%d areas represent more (overlapping) features, because polygons overlap in "
-"input layer(s). Such areas are linked to more than 1 row in attribute table."
-" The number of features for those areas is stored as category in layer %d"
+msgid "%d areas represent more (overlapping) features, because polygons overlap in input layer(s). Such areas are linked to more than 1 row in attribute table. The number of features for those areas is stored as category in layer %d"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:1547
@@ -12105,9 +11619,7 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:1734
-msgid ""
-"Input data contains 3D features. Created vector is 2D only, disable -2 flag "
-"to import 3D vector."
+msgid "Input data contains 3D features. Created vector is 2D only, disable -2 flag to import 3D vector."
 msgstr ""
 #: ../vector/v.in.ogr/geom.c:76 ../vector/v.in.ogr/geom.c:261
@@ -12164,9 +11676,7 @@
 msgstr ""
 #: ../vector/v.info/parse.c:30
-msgid ""
-"Print types/names of table columns for specified layer instead of info and "
-"exit"
+msgid "Print types/names of table columns for specified layer instead of info and exit"
 msgstr ""
 #: ../vector/v.info/parse.c:35
@@ -12393,10 +11903,7 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:147
-msgid ""
-"Spatial approximation and topographic analysis from given point or isoline "
-"data in vector format to floating point raster format using regularized "
-"spline with tension."
+msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
 msgstr ""
 #: ../vector/v.surf.rst/main.c:154
@@ -12440,9 +11947,7 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:179 ../vector/v.surf.idw/main.c:102
-msgid ""
-"If not given and input is 2D vector map then category values are used. If "
-"input is 3D vector map then z-coordinates are used."
+msgid "If not given and input is 2D vector map then category values are used. If input is 3D vector map then z-coordinates are used."
 msgstr ""
 #: ../vector/v.surf.rst/main.c:189
@@ -12486,8 +11991,7 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:308
-msgid ""
-"Maximum distance between points on isoline (to insert additional points)"
+msgid "Maximum distance between points on isoline (to insert additional points)"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:317
@@ -12513,15 +12017,11 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:425
-msgid ""
-"Both cross-validation options (-c flag and cvdev vector output) must be "
-"specified"
+msgid "Both cross-validation options (-c flag and cvdev vector output) must be specified"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:428
-msgid ""
-"The cross-validation cannot be computed simultaneously with output raster or"
-" devi file"
+msgid "The cross-validation cannot be computed simultaneously with output raster or devi file"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:446
@@ -12537,9 +12037,7 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:541 ../vector/v.surf.bspline/main.c:272
-msgid ""
-"Input is 3D: using attribute values instead of z-coordinates for "
-"approximation"
+msgid "Input is 3D: using attribute values instead of z-coordinates for approximation"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:543 ../vector/v.surf.bspline/main.c:274
@@ -12556,9 +12054,7 @@
 #: ../vector/v.surf.rst/main.c:662
 #, c-format
-msgid ""
-"Processing all selected output files will require %d bytes of disk space for"
-" temp files"
+msgid "Processing all selected output files will require %d bytes of disk space for temp files"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:682
@@ -12712,8 +12208,7 @@
 msgstr ""
 #: ../vector/v.in.db/main.c:57
-msgid ""
-"Creates new vector (points) map from database table containing coordinates."
+msgid "Creates new vector (points) map from database table containing coordinates."
 msgstr ""
 #: ../vector/v.in.db/main.c:61
@@ -12756,15 +12251,12 @@
 #: ../vector/v.in.db/main.c:141
 #, c-format
-msgid ""
-"Vector map <%s> cannot be overwritten because input table <%s> is linked to "
-"this map."
+msgid "Vector map <%s> cannot be overwritten because input table <%s> is linked to this map."
 msgstr ""
 #: ../vector/v.in.db/main.c:177
 #, c-format
-msgid ""
-"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
+msgid "Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
 msgstr ""
 #: ../vector/v.in.db/main.c:190 ../vector/v.db.connect/main.c:295
@@ -12778,9 +12270,7 @@
 #: ../vector/v.in.db/main.c:199
 #, c-format
-msgid ""
-"Unable to define key column. This operation is not supported by <%s> driver."
-" You need to define <%s> option."
+msgid "Unable to define key column. This operation is not supported by <%s> driver. You need to define <%s> option."
 msgstr ""
 #: ../vector/v.in.db/main.c:225 ../display/d.vect.chart/plot.c:86
@@ -12844,9 +12334,7 @@
 msgstr ""
 #: ../vector/v.db.select/main.c:100
-msgid ""
-"Print minimal region extent of selected vector features instead of "
-"attributes"
+msgid "Print minimal region extent of selected vector features instead of attributes"
 msgstr ""
 #: ../vector/v.db.select/main.c:101 ../raster/r.in.gdal/main.c:198
@@ -12877,9 +12365,7 @@
 #: ../vector/v.db.select/main.c:157
 #, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Flag '%c' requires "
-"topology level."
+msgid "Unable to open vector map <%s> at topology level. Flag '%c' requires topology level."
 msgstr ""
 #: ../vector/v.db.select/main.c:208
@@ -12927,9 +12413,7 @@
 msgstr ""
 #: ../vector/v.lidar.correction/main.c:74
-msgid ""
-"Corrects the v.lidar.growing output. It is the last of the three algorithms "
-"for LIDAR filtering."
+msgid "Corrects the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
 msgstr ""
 #: ../vector/v.lidar.correction/main.c:78
@@ -12940,9 +12424,7 @@
 #: ../vector/v.lidar.correction/main.c:80
 #: ../vector/v.lidar.edgedetection/main.c:85
 #: ../vector/v.surf.bspline/main.c:107 ../vector/v.outlier/main.c:81
-msgid ""
-"Estimate point density and distance for the input vector points within the "
-"current region extends and quit"
+msgid "Estimate point density and distance for the input vector points within the current region extends and quit"
 msgstr ""
 #: ../vector/v.lidar.correction/main.c:85
@@ -13015,8 +12497,7 @@
 msgstr ""
 #: ../vector/v.lidar.correction/main.c:194
-#: ../vector/v.lidar.correction/main.c:230
-#: ../vector/v.lidar.growing/main.c:163
+#: ../vector/v.lidar.correction/main.c:230 ../vector/v.lidar.growing/main.c:163
 #: ../vector/v.lidar.edgedetection/main.c:221
 #: ../vector/v.lidar.edgedetection/main.c:233
 #: ../vector/v.lidar.edgedetection/main.c:255
@@ -13082,9 +12563,7 @@
 msgstr ""
 #: ../vector/v.lidar.growing/main.c:78
-msgid ""
-"Building contour determination and Region Growing algorithm for determining "
-"the building inside"
+msgid "Building contour determination and Region Growing algorithm for determining the building inside"
 msgstr ""
 #: ../vector/v.lidar.growing/main.c:83
@@ -13286,9 +12765,8 @@
 #: ../vector/v.what.rast/main.c:183 ../vector/v.sample/main.c:240
 #: ../vector/v.class/main.c:129 ../vector/v.to.rast3/main.c:99
-#: ../vector/v.surf.bspline/crosscorr.c:133
-#: ../vector/v.surf.bspline/main.c:389 ../vector/v.surf.idw/read_sites.c:65
-#: ../vector/v.buffer/main.c:434
+#: ../vector/v.surf.bspline/crosscorr.c:133 ../vector/v.surf.bspline/main.c:389
+#: ../vector/v.surf.idw/read_sites.c:65 ../vector/v.buffer/main.c:434
 msgid "Column type not supported"
 msgstr ""
@@ -13370,9 +12848,7 @@
 #: ../vector/v.drape/main.c:150 ../vector/v.random/main.c:208
 #: ../vector/v.buffer/main.c:348
 #, c-format
-msgid ""
-"Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer "
-"'1'."
+msgid "Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer '1'."
 msgstr ""
 #: ../vector/v.drape/main.c:177 ../vector/v.select/select.c:40
@@ -13720,14 +13196,11 @@
 msgstr ""
 #: ../vector/v.out.postgis/args.c:44
-msgid ""
-"Name for output vector map defined as a link to the PostGIS feature table"
+msgid "Name for output vector map defined as a link to the PostGIS feature table"
 msgstr ""
 #: ../vector/v.out.postgis/args.c:46
-msgid ""
-"If not specified, the vector link is not created. The link can be also "
-"manually created by 'v.external' module."
+msgid "If not specified, the vector link is not created. The link can be also manually created by 'v.external' module."
 msgstr ""
 #: ../vector/v.out.postgis/args.c:52 ../vector/v.external.out/args.c:39
@@ -13837,16 +13310,12 @@
 #: ../vector/v.out.postgis/table.c:50
 #, c-format
-msgid ""
-"Invalid FID column (%s). FID column must be integer. Please specify "
-"different FID column by 'options=\"FID=<name>\"'."
+msgid "Invalid FID column (%s). FID column must be integer. Please specify different FID column by 'options=\"FID=<name>\"'."
 msgstr ""
 #: ../vector/v.out.postgis/table.c:57
 #, c-format
-msgid ""
-"Column (%s) already exists in the table. Please specify different geometry "
-"column by 'options=\"GEOMETRY_NAME=<name>\"'."
+msgid "Column (%s) already exists in the table. Please specify different geometry column by 'options=\"GEOMETRY_NAME=<name>\"'."
 msgstr ""
 #: ../vector/v.out.svg/main.c:76
@@ -13937,9 +13406,7 @@
 msgstr ""
 #: ../vector/v.delaunay/main.c:88
-msgid ""
-"Creates a Delaunay triangulation from an input vector map containing points "
-"or centroids."
+msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
 msgstr ""
 #: ../vector/v.delaunay/main.c:103
@@ -14074,9 +13541,7 @@
 msgstr ""
 #: ../vector/v.reclass/main.c:71
-msgid ""
-"Changes vector category values for an existing vector map according to "
-"results of SQL queries or a value in attribute table column."
+msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
 msgstr ""
 #: ../vector/v.reclass/main.c:88
@@ -14175,9 +13640,7 @@
 msgstr ""
 #: ../vector/v.net.centrality/main.c:100
-msgid ""
-"Computes degree, centrality, betweeness, closeness and eigenvector "
-"centrality measures in the network."
+msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
 msgstr ""
 #: ../vector/v.net.centrality/main.c:148
@@ -14243,8 +13706,7 @@
 msgstr ""
 #: ../vector/v.select/main.c:52
-msgid ""
-"Selects features from vector map (A) by features from other vector map (B)."
+msgid "Selects features from vector map (A) by features from other vector map (B)."
 msgstr ""
 #: ../vector/v.select/main.c:85 ../vector/v.overlay/main.c:178
@@ -14303,10 +13765,7 @@
 msgstr ""
 #: ../vector/v.select/args.c:51
-msgid ""
-"A feature is written to output if the result of operation 'ainput operator "
-"binput' is true. An input feature is considered to be true, if category of "
-"given layer is defined."
+msgid "A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined."
 msgstr ""
 #: ../vector/v.select/args.c:59 ../vector/v.select/args.c:75
@@ -14346,9 +13805,7 @@
 msgstr ""
 #: ../vector/v.select/args.c:84
-msgid ""
-"feature A is spatially related to feature B (using GEOS, requires 'relate' "
-"option)"
+msgid "feature A is spatially related to feature B (using GEOS, requires 'relate' option)"
 msgstr ""
 #: ../vector/v.select/args.c:94
@@ -14410,8 +13867,7 @@
 msgstr ""
 #: ../vector/v.support/main.c:118
-msgid ""
-"Command line to store into vector map history file (used for vector scripts)"
+msgid "Command line to store into vector map history file (used for vector scripts)"
 msgstr ""
 #: ../vector/v.support/main.c:122
@@ -14425,9 +13881,7 @@
 #: ../vector/v.in.lidar/main.c:48
 #, c-format
-msgid ""
-"Values of %s and %s are the same. All categories would be stored only in "
-"layer number <%d>"
+msgid "Values of %s and %s are the same. All categories would be stored only in layer number <%d>"
 msgstr ""
 #: ../vector/v.in.lidar/main.c:141
@@ -14478,9 +13932,7 @@
 msgstr ""
 #: ../vector/v.in.lidar/main.c:236
-msgid ""
-"For example, 5 will import 80 percent of points. If not specified, all "
-"points are imported"
+msgid "For example, 5 will import 80 percent of points. If not specified, all points are imported"
 msgstr ""
 #: ../vector/v.in.lidar/main.c:238 ../vector/v.in.lidar/main.c:248
@@ -14493,9 +13945,7 @@
 msgstr ""
 #: ../vector/v.in.lidar/main.c:246
-msgid ""
-"For example, 4 will import 25 percent of points. If not specified, all "
+msgid "For example, 4 will import 25 percent of points. If not specified, all points are imported"
 msgstr ""
 #: ../vector/v.in.lidar/main.c:255 ../vector/v.decimate/main.c:183
@@ -14562,9 +14012,7 @@
 #: ../vector/v.in.lidar/main.c:425
 #, c-format
-msgid ""
-"Storing generated point IDs as categories in the layer <%d>, consequently no"
-" more than %d points can be imported"
+msgid "Storing generated point IDs as categories in the layer <%d>, consequently no more than %d points can be imported"
 msgstr ""
 #: ../vector/v.in.lidar/main.c:435 ../vector/v.decimate/main.c:294
@@ -14593,9 +14041,7 @@
 msgstr ""
 #: ../vector/v.in.lidar/main.c:746
-msgid ""
-"The underlying libLAS library is at its limits. Previously reported counts "
-"might have been distorted. However, the import itself should be unaffected."
+msgid "The underlying libLAS library is at its limits. Previously reported counts might have been distorted. However, the import itself should be unaffected."
 msgstr ""
 #: ../vector/v.in.lidar/main.c:752
@@ -14684,9 +14130,7 @@
 msgstr ""
 #: ../vector/v.in.lidar/main.c:802
-msgid ""
-"Accuracy of the printed point counts might be limited by your computer "
-"architecture."
+msgid "Accuracy of the printed point counts might be limited by your computer architecture."
 msgstr ""
 #: ../vector/v.in.lidar/main.c:805
@@ -14700,9 +14144,7 @@
 #: ../vector/v.in.lidar/main.c:818
 #, c-format
-msgid ""
-"Maximum number of categories reached (%d). Import ended prematurely. Try to "
-"import without using category as an ID."
+msgid "Maximum number of categories reached (%d). Import ended prematurely. Try to import without using category as an ID."
 msgstr ""
 #: ../vector/v.in.lidar/vector_mask.c:20
@@ -14796,8 +14238,7 @@
 msgid "Point classification..."
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:103
-#: ../vector/v.lrs/v.lrs.where/main.c:58
+#: ../vector/v.lrs/v.lrs.label/main.c:103 ../vector/v.lrs/v.lrs.where/main.c:58
 #: ../vector/v.lrs/v.lrs.create/main.c:122
 #: ../vector/v.lrs/v.lrs.segment/main.c:72
 msgid "linear reference system"
@@ -14807,8 +14248,7 @@
 msgid "Creates stationing from input lines, and linear reference system."
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:109
-#: ../vector/v.lrs/v.lrs.where/main.c:66
+#: ../vector/v.lrs/v.lrs.label/main.c:109 ../vector/v.lrs/v.lrs.where/main.c:66
 #: ../vector/v.lrs/v.lrs.create/main.c:128
 #: ../vector/v.lrs/v.lrs.segment/main.c:79
 msgid "Input vector map containing lines"
@@ -14818,22 +14258,19 @@
 msgid "Output vector map where stationing will be written"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:118
-#: ../vector/v.lrs/v.lrs.where/main.c:75
+#: ../vector/v.lrs/v.lrs.label/main.c:118 ../vector/v.lrs/v.lrs.where/main.c:75
 #: ../vector/v.lrs/v.lrs.create/main.c:147
 #: ../vector/v.lrs/v.lrs.segment/main.c:88
 msgid "Line layer"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:124
-#: ../vector/v.lrs/v.lrs.where/main.c:86
+#: ../vector/v.lrs/v.lrs.label/main.c:124 ../vector/v.lrs/v.lrs.where/main.c:86
 #: ../vector/v.lrs/v.lrs.create/main.c:207
 #: ../vector/v.lrs/v.lrs.segment/main.c:94
 msgid "Driver name for reference system table"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:132
-#: ../vector/v.lrs/v.lrs.where/main.c:94
+#: ../vector/v.lrs/v.lrs.label/main.c:132 ../vector/v.lrs/v.lrs.where/main.c:94
 #: ../vector/v.lrs/v.lrs.create/main.c:215
 #: ../vector/v.lrs/v.lrs.segment/main.c:102
 msgid "Database name for reference system table"
@@ -14939,9 +14376,7 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.where/main.c:61
-msgid ""
-"Finds line id and real km+offset for given points in vector map using linear"
-" reference system."
+msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
 msgstr ""
 #: ../vector/v.lrs/v.lrs.where/main.c:70
@@ -15022,8 +14457,7 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:182
-msgid ""
-"Column containing offset from milepost for the beginning of next segment"
+msgid "Column containing offset from milepost for the beginning of next segment"
 msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:191
@@ -15156,9 +14590,7 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.segment/main.c:75
-msgid ""
-"Creates points/segments from input lines, linear reference system and "
-"positions read from stdin or a file."
+msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
 msgstr ""
 #: ../vector/v.lrs/v.lrs.segment/main.c:83
@@ -15305,9 +14737,7 @@
 #: ../vector/v.to.db/main.c:48
 #, c-format
-msgid ""
-"Vector map <%s> not found in the current mapset. Unable to modify vector "
-"maps from different mapsets."
+msgid "Vector map <%s> not found in the current mapset. Unable to modify vector maps from different mapsets."
 msgstr ""
 #: ../vector/v.to.db/main.c:65 ../vector/v.to.db/query.c:83
@@ -15378,15 +14808,11 @@
 msgstr ""
 #: ../vector/v.to.db/parse.c:84
-msgid ""
-"categories of areas on the left and right side of the boundary, "
-"'query_layer' is used for area category"
+msgid "categories of areas on the left and right side of the boundary, 'query_layer' is used for area category"
 msgstr ""
 #: ../vector/v.to.db/parse.c:86
-msgid ""
-"result of a database query for all records of the geometry(or geometries) "
-"from table specified by 'query_layer' option"
+msgid "result of a database query for all records of the geometry(or geometries) from table specified by 'query_layer' option"
 msgstr ""
 #: ../vector/v.to.db/parse.c:88
@@ -15394,14 +14820,11 @@
 msgstr ""
 #: ../vector/v.to.db/parse.c:89
-msgid ""
-"line sinuousity, calculated as line length / distance between end points"
+msgid "line sinuousity, calculated as line length / distance between end points"
 msgstr ""
 #: ../vector/v.to.db/parse.c:90
-msgid ""
-"line azimuth, calculated as angle between North direction and endnode "
-"direction at startnode"
+msgid "line azimuth, calculated as angle between North direction and endnode direction at startnode"
 msgstr ""
 #: ../vector/v.to.db/parse.c:94
@@ -15487,9 +14910,7 @@
 #: ../vector/v.to.db/query.c:109
 #, c-format
-msgid ""
-"Query for category '0' (no category) was not executed because of too many "
-"(%d) query categories. All later reported values for cat 0 are not valid."
+msgid "Query for category '0' (no category) was not executed because of too many (%d) query categories. All later reported values for cat 0 are not valid."
 msgstr ""
 #: ../vector/v.to.db/query.c:146
@@ -15587,8 +15008,7 @@
 msgstr ""
 #: ../vector/v.transform/main.c:74
-msgid ""
-"Performs an affine transformation (shift, scale and rotate) on vector map."
+msgid "Performs an affine transformation (shift, scale and rotate) on vector map."
 msgstr ""
 #: ../vector/v.transform/main.c:79
@@ -15689,9 +15109,7 @@
 #: ../vector/v.transform/trans_digit.c:112
 #, c-format
-msgid ""
-"Unable to select value for category %d from table <%s>, column <%s>. For "
-"category %d using default transformation parameter %.3f."
+msgid "Unable to select value for category %d from table <%s>, column <%s>. For category %d using default transformation parameter %.3f."
 msgstr ""
 #: ../vector/v.transform/trans_digit.c:123
@@ -15703,13 +15121,11 @@
 msgstr ""
 #: ../vector/v.univar/main.c:99
-msgid ""
-"Variance and standard deviation is calculated only for points if specified."
+msgid "Variance and standard deviation is calculated only for points if specified."
 msgstr ""
 #: ../vector/v.univar/main.c:126 ../vector/v.what/main.c:98
-#: ../raster/r.univar/r.univar_main.c:61
-#: ../raster/r.univar/r3.univar_main.c:59
+#: ../raster/r.univar/r.univar_main.c:61 ../raster/r.univar/r3.univar_main.c:59
 msgid "Print the stats in shell script style"
 msgstr ""
@@ -15727,9 +15143,7 @@
 msgstr ""
 #: ../vector/v.univar/main.c:195
-msgid ""
-"Incompatible vector type(s) specified, only number of features, minimum, "
-"maximum and range can be calculated"
+msgid "Incompatible vector type(s) specified, only number of features, minimum, maximum and range can be calculated"
 msgstr ""
 #: ../vector/v.univar/main.c:200
@@ -15820,15 +15234,12 @@
 #: ../vector/v.db.connect/main.c:197
 #, c-format
-msgid ""
-"layer <%d/%s> table <%s> in database <%s> through driver <%s> with key "
-"<%s>\n"
+msgid "layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
 #: ../vector/v.db.connect/main.c:203
 #, c-format
-msgid ""
-"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgid "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
 #: ../vector/v.db.connect/main.c:266
@@ -15843,28 +15254,19 @@
 #: ../vector/v.db.connect/main.c:302 ../vector/v.db.connect/main.c:320
 #, c-format
-msgid ""
-"The table <%s> is now part of vector map <%s> and may be deleted or "
-"overwritten by GRASS modules"
+msgid "The table <%s> is now part of vector map <%s> and may be deleted or overwritten by GRASS modules"
 msgstr ""
 #: ../vector/v.db.connect/main.c:351
-msgid ""
-"For defining a new connection you have to specify these parameters: driver, "
-"database, table [, key [, layer]]"
+msgid "For defining a new connection you have to specify these parameters: driver, database, table [, key [, layer]]"
 msgstr ""
 #: ../vector/v.net.distance/main.c:69
-msgid ""
-"Computes shortest distance via the network between the given sets of "
-"features."
+msgid "Computes shortest distance via the network between the given sets of features."
 msgstr ""
 #: ../vector/v.net.distance/main.c:72
-msgid ""
-"Finds the shortest paths from each 'from' point to the nearest 'to' feature "
-"and various information about this relation are uploaded to the attribute "
-"table."
+msgid "Finds the shortest paths from each 'from' point to the nearest 'to' feature and various information about this relation are uploaded to the attribute table."
 msgstr ""
 #: ../vector/v.net.distance/main.c:100
@@ -15941,9 +15343,7 @@
 msgstr ""
 #: ../vector/v.decimate/main.c:133
-msgid ""
-"Copies points from one vector to another while applying different "
-"decimations"
+msgid "Copies points from one vector to another while applying different decimations"
 msgstr ""
 #: ../vector/v.decimate/main.c:161
@@ -15951,9 +15351,7 @@
 msgstr ""
 #: ../vector/v.decimate/main.c:163
-msgid ""
-"points are copied"
+msgid "For example, 5 will import 80 percent of points. If not specified, all points are copied"
 msgstr ""
 #: ../vector/v.decimate/main.c:165 ../vector/v.decimate/main.c:176
@@ -15966,9 +15364,7 @@
 msgstr ""
 #: ../vector/v.decimate/main.c:174
-msgid ""
+msgid "For example, 4 will import 25 percent of points. If not specified, all points are copied"
 msgstr ""
 #: ../vector/v.decimate/main.c:193
@@ -15998,9 +15394,7 @@
 msgstr ""
 #: ../vector/v.decimate/main.c:213
-msgid ""
-"Preserves only the given number of points per grid cell in grid-based "
-"decimation"
+msgid "Preserves only the given number of points per grid cell in grid-based decimation"
 msgstr ""
 #: ../vector/v.decimate/main.c:218
@@ -16029,9 +15423,7 @@
 #: ../vector/v.decimate/main.c:276
 #, c-format
-msgid ""
-"Input layer must be set to a particular layer, not <%s>, when using <%s> "
-"option or <-%c> flag"
+msgid "Input layer must be set to a particular layer, not <%s>, when using <%s> option or <-%c> flag"
 msgstr ""
 #: ../vector/v.decimate/main.c:318
@@ -16043,9 +15435,7 @@
 msgstr ""
 #: ../vector/v.decimate/main.c:350
-msgid ""
-"Settings for count-based decimation would cause it to do nothing and no "
-"other options has been set."
+msgid "Settings for count-based decimation would cause it to do nothing and no other options has been set."
 msgstr ""
 #: ../vector/v.sample/main.c:79
@@ -16304,8 +15694,7 @@
 msgstr ""
 #: ../vector/v.label/main.c:251
-msgid ""
-"size and space options vary significantly which may lead to crummy output"
+msgid "size and space options vary significantly which may lead to crummy output"
 msgstr ""
 #: ../vector/v.label/main.c:259
@@ -16342,9 +15731,7 @@
 msgstr ""
 #: ../vector/v.out.pov/main.c:75
-msgid ""
-"This string is appended to each z coordinate. Examples: '*10', '+1000', "
-"'*10+100', '*exaggeration'"
+msgid "This string is appended to each z coordinate. Examples: '*10', '+1000', '*10+100', '*exaggeration'"
 msgstr ""
 #: ../vector/v.out.pov/main.c:82
@@ -16401,9 +15788,7 @@
 msgstr ""
 #: ../vector/v.category/main.c:119
-msgid ""
-"copy values from one layer to another (e.g. layer=1,2,3 copies values from "
-"layer 1 to layer 2 and 3)"
+msgid "copy values from one layer to another (e.g. layer=1,2,3 copies values from layer 1 to layer 2 and 3)"
 msgstr ""
 #: ../vector/v.category/main.c:120
@@ -16411,9 +15796,7 @@
 msgstr ""
 #: ../vector/v.category/main.c:121
-msgid ""
-"print category values, layers are separated by '|', more cats in the same "
-"layer are separated by '/'"
+msgid "print category values, layers are separated by '|', more cats in the same layer are separated by '/'"
 msgstr ""
 #: ../vector/v.category/main.c:122
@@ -16433,15 +15816,11 @@
 msgstr ""
 #: ../vector/v.category/main.c:160
-msgid ""
-"Database connection and attribute tables for concerned layers are not "
-"changed"
+msgid "Database connection and attribute tables for concerned layers are not changed"
 msgstr ""
 #: ../vector/v.category/main.c:208
-msgid ""
-"Invalid category number (must be equal to or greater than 0). Normally "
-"category number starts at 1."
+msgid "Invalid category number (must be equal to or greater than 0). Normally category number starts at 1."
 msgstr ""
 #: ../vector/v.category/main.c:217
@@ -16569,8 +15948,7 @@
 msgstr ""
 #: ../vector/v.to.rast/main.c:122
-msgid ""
-"All cells touched by the line will be set, not only those on the render path"
+msgid "All cells touched by the line will be set, not only those on the render path"
 msgstr ""
 #: ../vector/v.to.rast/main.c:132
@@ -16656,9 +16034,7 @@
 msgstr ""
 #: ../vector/v.to.rast/vect2rast.c:137
-msgid ""
-"Area conversion and line densification are mutually exclusive, disabling "
-"line densification."
+msgid "Area conversion and line densification are mutually exclusive, disabling line densification."
 msgstr ""
 #: ../vector/v.to.rast/vect2rast.c:152
@@ -16896,9 +16272,7 @@
 msgstr ""
 #: ../vector/v.net.alloc/main.c:63
-msgid ""
-"center node must be opened (costs >= 0). Costs of center node are used in "
-"calculation"
+msgid "center node must be opened (costs >= 0). Costs of center node are used in calculation"
 msgstr ""
 #: ../vector/v.net.alloc/main.c:76
@@ -16906,9 +16280,7 @@
 msgstr ""
 #: ../vector/v.net.alloc/main.c:83 ../vector/v.net.iso/main.c:89
-msgid ""
-"Categories of centers (points on nodes) to which net will be allocated, "
-"layer for this categories is given by nlayer option"
+msgid "Categories of centers (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
 msgstr ""
 #: ../vector/v.net.alloc/main.c:129 ../vector/v.net.iso/main.c:137
@@ -17125,10 +16497,7 @@
 msgstr ""
 #: ../vector/v.class/main.c:173
-msgid ""
-"The discontinuities algorithm indicates that some class breaks are not "
-"statistically significant at alpha=0.05. You are advised to reduce the "
-"number of classes."
+msgid "The discontinuities algorithm indicates that some class breaks are not statistically significant at alpha=0.05. You are advised to reduce the number of classes."
 msgstr ""
 #: ../vector/v.class/main.c:201
@@ -17223,9 +16592,7 @@
 msgstr ""
 #: ../vector/v.random/main.c:153
-msgid ""
-"The seed to initialize the random generator. If not set the process ID is "
-"used"
+msgid "The seed to initialize the random generator. If not set the process ID is used"
 msgstr ""
 #: ../vector/v.random/main.c:156
@@ -17268,15 +16635,12 @@
 msgstr ""
 #: ../vector/v.random/main.c:286
-msgid ""
-"You have created unsupported column type. This module supports only INTEGER "
-"and DOUBLE PRECISION column types."
+msgid "You have created unsupported column type. This module supports only INTEGER and DOUBLE PRECISION column types."
 msgstr ""
 #: ../vector/v.random/main.c:349
 #, c-format
-msgid ""
-"Selected areas in input vector <%s> do not overlap with the current region"
+msgid "Selected areas in input vector <%s> do not overlap with the current region"
 msgstr ""
 #: ../vector/v.random/main.c:361
@@ -17354,9 +16718,7 @@
 msgstr ""
 #: ../vector/v.out.ascii/main.c:52
-msgid ""
-"By default only features with category are exported. To export all features "
-"use 'layer=-1'."
+msgid "By default only features with category are exported. To export all features use 'layer=-1'."
 msgstr ""
 #: ../vector/v.out.ascii/main.c:60
@@ -17376,9 +16738,7 @@
 #: ../vector/v.out.ascii/main.c:80
 #, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Areas will not be "
-"processed."
+msgid "Unable to open vector map <%s> at topology level. Areas will not be processed."
 msgstr ""
 #: ../vector/v.out.ascii/main.c:107
@@ -17422,9 +16782,7 @@
 msgstr ""
 #: ../vector/v.out.ogr/args.c:20
-msgid ""
-"Combination of types is not supported by all output formats. Default is to "
-"use first type found in input vector map."
+msgid "Combination of types is not supported by all output formats. Default is to use first type found in input vector map."
 msgstr ""
 #: ../vector/v.out.ogr/args.c:25
@@ -17488,9 +16846,7 @@
 msgstr ""
 #: ../vector/v.out.ogr/args.c:100
-msgid ""
-"Also export features without category (not labeled). Otherwise only features"
-" with category are exported."
+msgid "Also export features without category (not labeled). Otherwise only features with category are exported."
 msgstr ""
 #: ../vector/v.out.ogr/args.c:106
@@ -17506,9 +16862,7 @@
 msgstr ""
 #: ../vector/v.out.ogr/args.c:126
-msgid ""
-"Create a new empty layer in defined OGR datasource and exit. Nothing is read"
-" from input."
+msgid "Create a new empty layer in defined OGR datasource and exit. Nothing is read from input."
 msgstr ""
 #: ../vector/v.out.ogr/attrb.c:48 ../vector/v.out.vtk/writeVTK.c:585
@@ -17546,9 +16900,7 @@
 #: ../vector/v.out.ogr/main.c:97 ../vector/v.external.out/link.c:26
 #, c-format
-msgid ""
-"Data source starts with \"PG:\" prefix, expecting \"PostgreSQL\" format "
-"(\"%s\" given)"
+msgid "Data source starts with \"PG:\" prefix, expecting \"PostgreSQL\" format (\"%s\" given)"
 msgstr ""
 #: ../vector/v.out.ogr/main.c:165
@@ -17579,118 +16931,88 @@
 msgstr ""
 #: ../vector/v.out.ogr/main.c:311
-msgid ""
-"The map contains islands. With the -c flag, islands will appear as filled "
-"areas, not holes in the output map."
+msgid "The map contains islands. With the -c flag, islands will appear as filled areas, not holes in the output map."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:317
 #, c-format
-msgid ""
-"%d point found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d points found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d point found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d points found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 msgstr[1] ""
 #: ../vector/v.out.ogr/main.c:325
 #, c-format
-msgid ""
-"%d line found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d line found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d line(s) found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 msgstr[1] ""
 #: ../vector/v.out.ogr/main.c:334
 #, c-format
-msgid ""
-"%d boundary found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgid_plural ""
-"%d boundaries found, but not requested to be exported. Verify 'type' "
-"parameter."
+msgid "%d boundary found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d boundaries found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 msgstr[1] ""
 #: ../vector/v.out.ogr/main.c:343
 #, c-format
-msgid ""
-"%d centroid found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgid_plural ""
-"%d centroids found, but not requested to be exported. Verify 'type' "
-"parameter."
+msgid "%d centroid found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d centroids found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 msgstr[1] ""
 #: ../vector/v.out.ogr/main.c:351
 #, c-format
-msgid ""
-"%d area found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d areas found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d area found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d areas found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 msgstr[1] ""
 #: ../vector/v.out.ogr/main.c:359
 #, c-format
-msgid ""
-"%d face found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d faces found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d face found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d faces found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 msgstr[1] ""
 #: ../vector/v.out.ogr/main.c:367
 #, c-format
-msgid ""
-"%d volume found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d volumes found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d volume found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d volumes found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 msgstr[1] ""
 #: ../vector/v.out.ogr/main.c:377
-msgid ""
-"No points found, but requested to be exported. Will skip this feature type."
+msgid "No points found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:386
-msgid ""
-"No lines found, but requested to be exported. Will skip this feature type."
+msgid "No lines found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:396
-msgid ""
-"No boundaries found, but requested to be exported. Will skip this feature "
-"type."
+msgid "No boundaries found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:405
-msgid ""
-"No areas found, but requested to be exported. Will skip this feature type."
+msgid "No areas found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:415
-msgid ""
-"No centroids found, but requested to be exported. Will skip this feature "
-"type."
+msgid "No centroids found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:424
-msgid ""
-"No faces found, but requested to be exported. Will skip this feature type."
+msgid "No faces found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:433
-msgid ""
-"No kernels found, but requested to be exported. Will skip this feature type."
+msgid "No kernels found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:442
-msgid ""
-"No volumes found, but requested to be exported. Will skip this feature type."
+msgid "No volumes found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:467
@@ -17724,23 +17046,17 @@
 #: ../vector/v.out.ogr/main.c:562
 #, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options SHPT "
-"(parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
+msgid "Vector map <%s> is 3D. Use format specific layer creation options SHPT (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
 msgstr ""
 #: ../vector/v.out.ogr/main.c:574
 #, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options DIM "
-"(parameter 'lco') to export in 3D rather than 2D (default)."
+msgid "Vector map <%s> is 3D. Use format specific layer creation options DIM (parameter 'lco') to export in 3D rather than 2D (default)."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:581
 #, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options (parameter"
-" 'lco') to export <in 3D rather than 2D (default)."
+msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export <in 3D rather than 2D (default)."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:598 ../db/drivers/ogr/execute.c:56
@@ -17811,12 +17127,8 @@
 #: ../vector/v.out.ogr/main.c:787
 #, c-format
-msgid ""
-"%d feature without category was skipped. Features without category are "
-"written only when -%c flag is given."
-msgid_plural ""
-"%d features without category were skipped. Features without category are "
+msgid "%d feature without category was skipped. Features without category are written only when -%c flag is given."
+msgid_plural "%d features without category were skipped. Features without category are written only when -%c flag is given."
 msgstr[0] ""
 msgstr[1] ""
@@ -17844,8 +17156,7 @@
 #: ../vector/v.out.ogr/export_areas.c:176
 #: ../vector/v.out.ogr/export_lines.c:212
 #, c-format
-msgid ""
-"Unable to create multi-feature. Category %d not found in line %d, field %d"
+msgid "Unable to create multi-feature. Category %d not found in line %d, field %d"
 msgstr ""
 #: ../vector/v.out.ogr/export_areas.c:214
@@ -17874,21 +17185,15 @@
 msgstr ""
 #: ../vector/v.external/main.c:57
-msgid ""
-"Creates a new pseudo-vector map as a link to an OGR-supported layer or a "
-"PostGIS feature table."
+msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer or a PostGIS feature table."
 msgstr ""
 #: ../vector/v.external/main.c:76 ../vector/v.external.out/format.c:22
-msgid ""
-"Environment variable GRASS_VECTOR_OGR defined, but GRASS is compiled with "
-"OGR support. Using GRASS-PostGIS data driver instead."
+msgid "Environment variable GRASS_VECTOR_OGR defined, but GRASS is compiled with OGR support. Using GRASS-PostGIS data driver instead."
 msgstr ""
 #: ../vector/v.external/main.c:81 ../vector/v.external.out/format.c:27
-msgid ""
-"GRASS is not compiled with PostgreSQL support. Using OGR-PostgreSQL driver "
-"instead of native GRASS-PostGIS data driver."
+msgid "GRASS is not compiled with PostgreSQL support. Using OGR-PostgreSQL driver instead of native GRASS-PostGIS data driver."
 msgstr ""
 #: ../vector/v.external/main.c:124
@@ -18001,9 +17306,7 @@
 #: ../vector/v.external/list.c:310
 #, c-format
-msgid ""
-"Unable to convert input map projection to GRASS format. Projection check "
-"cannot be provided for OGR layer <%s>"
+msgid "Unable to convert input map projection to GRASS format. Projection check cannot be provided for OGR layer <%s>"
 msgstr ""
 #: ../vector/v.external/list.c:326
@@ -18017,13 +17320,11 @@
 msgstr ""
 #: ../vector/v.extrude/main.c:72
-msgid ""
-"Extrudes flat vector features to 3D vector features with defined height."
+msgid "Extrudes flat vector features to 3D vector features with defined height."
 msgstr ""
 #: ../vector/v.extrude/main.c:74
-msgid ""
-"Optionally the height can be derived from sampling of elevation raster map."
+msgid "Optionally the height can be derived from sampling of elevation raster map."
 msgstr ""
 #: ../vector/v.extrude/main.c:78
@@ -18041,9 +17342,7 @@
 #: ../vector/v.extrude/main.c:202
 #, c-format
-msgid ""
-"Invalid layer number (%d). Parameter '%s', '%s' or '%s' specified, assuming "
-"layer '1'."
+msgid "Invalid layer number (%d). Parameter '%s', '%s' or '%s' specified, assuming layer '1'."
 msgstr ""
 #: ../vector/v.extrude/main.c:234
@@ -18067,8 +17366,7 @@
 #: ../vector/v.extrude/main.c:293
 #, c-format
-msgid ""
-"Unable to fetch height from DB for area %d. Using default fixed height %f."
+msgid "Unable to fetch height from DB for area %d. Using default fixed height %f."
 msgstr ""
 #: ../vector/v.extrude/main.c:319
@@ -18082,8 +17380,7 @@
 #: ../vector/v.extrude/main.c:346
 #, c-format
-msgid ""
-"Unable to fetch height from DB for line %d. Using default fixed height %f."
+msgid "Unable to fetch height from DB for line %d. Using default fixed height %f."
 msgstr ""
 #: ../vector/v.extrude/main.c:364
@@ -18223,8 +17520,7 @@
 msgstr ""
 #: ../vector/v.build/main.c:49
-msgid ""
-"Name for output vector map where erroneous vector features are written to"
+msgid "Name for output vector map where erroneous vector features are written to"
 msgstr ""
 #: ../vector/v.build/main.c:51 ../vector/v.build/main.c:77
@@ -18266,9 +17562,7 @@
 #: ../vector/v.build/main.c:106
 #, c-format
-msgid ""
-"Direct read access to OGR layers is not supported by this module. Run %s to "
-"create a link as GRASS vector map in the current mapset."
+msgid "Direct read access to OGR layers is not supported by this module. Run %s to create a link as GRASS vector map in the current mapset."
 msgstr ""
 #: ../vector/v.build/main.c:111
@@ -18281,9 +17575,7 @@
 msgstr ""
 #: ../vector/v.rectify/main.c:75
-msgid ""
-"Rectifies a vector by computing a coordinate transformation for each object "
-"in the vector based on the control points."
+msgid "Rectifies a vector by computing a coordinate transformation for each object in the vector based on the control points."
 msgstr ""
 #: ../vector/v.rectify/main.c:90
@@ -18291,8 +17583,7 @@
 msgstr ""
 #: ../vector/v.rectify/main.c:95
-msgid ""
-"Name of output file with RMS errors (if omitted or '-' output to stdout"
+msgid "Name of output file with RMS errors (if omitted or '-' output to stdout"
 msgstr ""
 #: ../vector/v.rectify/main.c:104 ../imagery/i.rectify/main.c:124
@@ -18687,9 +17978,7 @@
 msgstr ""
 #: ../vector/v.net.steiner/main.c:352
-msgid ""
-"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
-"is used in this module so the result may be sub optimal."
+msgid "Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal."
 msgstr ""
 #: ../vector/v.net.steiner/main.c:373
@@ -18741,8 +18030,7 @@
 #: ../vector/v.net.steiner/main.c:538
 #, c-format
-msgid ""
-"[%d] (not reachable) nodes removed from list of Steiner point candidates"
+msgid "[%d] (not reachable) nodes removed from list of Steiner point candidates"
 msgstr ""
 #: ../vector/v.net.steiner/main.c:543
@@ -19144,9 +18432,7 @@
 #: ../vector/v.to.points/main.c:232
 #, c-format
-msgid ""
-"%d features without category in layer <%d> skipped. Note that features "
-"without category (usually boundaries) are not skipped when '%s=-1' is given."
+msgid "%d features without category in layer <%d> skipped. Note that features without category (usually boundaries) are not skipped when '%s=-1' is given."
 msgstr ""
 #: ../vector/v.to.points/main.c:282
@@ -19204,9 +18490,7 @@
 msgstr ""
 #: ../vector/v.in.ascii/main.c:128
-msgid ""
-"For example: 'x double precision, y double precision, cat int, name "
-"varchar(10)'"
+msgid "For example: 'x double precision, y double precision, cat int, name varchar(10)'"
 msgstr ""
 #: ../vector/v.in.ascii/main.c:140 ../vector/v.in.ascii/main.c:150
@@ -19230,9 +18514,7 @@
 msgstr ""
 #: ../vector/v.in.ascii/main.c:172
-msgid ""
-"First column is 1. If 0, unique category is assigned to each row and written"
-" to new column 'cat'"
+msgid "First column is 1. If 0, unique category is assigned to each row and written to new column 'cat'"
 msgstr ""
 #: ../vector/v.in.ascii/main.c:181
@@ -19303,9 +18585,7 @@
 #: ../vector/v.in.ascii/main.c:296 ../vector/v.in.ascii/main.c:300
 #: ../vector/v.in.ascii/main.c:305 ../vector/v.in.ascii/main.c:310
 #, c-format
-msgid ""
-"'%s' column number > minimum last column number (incorrect field separator "
-"or format?)"
+msgid "'%s' column number > minimum last column number (incorrect field separator or format?)"
 msgstr ""
 #: ../vector/v.in.ascii/main.c:315 ../vector/v.in.ascii/main.c:318
@@ -19320,9 +18600,7 @@
 #: ../vector/v.in.ascii/main.c:441
 #, c-format
-msgid ""
-"Number of columns defined (%d) does not match number of columns (%d) in "
-"input"
+msgid "Number of columns defined (%d) does not match number of columns (%d) in input"
 msgstr ""
 #: ../vector/v.in.ascii/main.c:469
@@ -19365,9 +18643,7 @@
 msgstr ""
 #: ../vector/v.in.ascii/main.c:542
-msgid ""
-"Unable to close attribute table. The DBMI driver did not accept all "
-"attributes"
+msgid "Unable to close attribute table. The DBMI driver did not accept all attributes"
 msgstr ""
 #: ../vector/v.in.ascii/points.c:82
@@ -19421,10 +18697,7 @@
 msgstr ""
 #: ../vector/v.net.iso/main.c:78
-msgid ""
-"Splits net to bands between cost isolines (direction from center). Center "
-"node must be opened (costs >= 0). Costs of center node are used in "
-"calculation."
+msgid "Splits net to bands between cost isolines (direction from center). Center node must be opened (costs >= 0). Costs of center node are used in calculation."
 msgstr ""
 #: ../vector/v.net.iso/main.c:98
@@ -19477,14 +18750,11 @@
 msgstr ""
 #: ../vector/v.net.salesman/main.c:133
-msgid ""
-"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
-"created cycle may be sub optimal"
+msgid "Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
 msgstr ""
 #: ../vector/v.net.salesman/main.c:142
-msgid ""
-"Categories of points ('cities') on nodes (layer is specified by nlayer)"
+msgid "Categories of points ('cities') on nodes (layer is specified by nlayer)"
 msgstr ""
 #: ../vector/v.net.salesman/main.c:162
@@ -19541,9 +18811,7 @@
 msgstr ""
 #: ../vector/v.patch/main.c:84
-msgid ""
-"Name for output vector map where bounding boxes of input vector maps are "
-"written to"
+msgid "Name for output vector map where bounding boxes of input vector maps are written to"
 msgstr ""
 #: ../vector/v.patch/main.c:88
@@ -19571,8 +18839,7 @@
 msgstr ""
 #: ../vector/v.patch/main.c:106
-msgid ""
-"Append files to existing file (overwriting existing files must be activated)"
+msgid "Append files to existing file (overwriting existing files must be activated)"
 msgstr ""
 #: ../vector/v.patch/main.c:216
@@ -19683,9 +18950,7 @@
 msgstr ""
 #: ../vector/v.kernel/main.c:115
-msgid ""
-"Density is computed using a moving kernel. Optionally generates a vector "
-"density map on a vector network."
+msgid "Density is computed using a moving kernel. Optionally generates a vector density map on a vector network."
 msgstr ""
 #: ../vector/v.kernel/main.c:119
@@ -19748,9 +19013,7 @@
 msgstr ""
 #: ../vector/v.kernel/main.c:207
-msgid ""
-"Try to calculate an optimal radius with given 'radius' taken as maximum "
-"(experimental)"
+msgid "Try to calculate an optimal radius with given 'radius' taken as maximum (experimental)"
 msgstr ""
 #: ../vector/v.kernel/main.c:212
@@ -19758,9 +19021,7 @@
 msgstr ""
 #: ../vector/v.kernel/main.c:217
-msgid ""
-"In network mode, normalize values by sum of density multiplied by length of "
-"each segment. Integral over the output map then gives 1.0 * mult"
+msgid "In network mode, normalize values by sum of density multiplied by length of each segment. Integral over the output map then gives 1.0 * mult"
 msgstr ""
 #: ../vector/v.kernel/main.c:223
@@ -19768,9 +19029,7 @@
 msgstr ""
 #: ../vector/v.kernel/main.c:236
-msgid ""
-"Use option net_output if you compute network density. Name provided in "
-"option output will be used for net_output."
+msgid "Use option net_output if you compute network density. Name provided in option output will be used for net_output."
 msgstr ""
 #: ../vector/v.kernel/main.c:255
@@ -19782,15 +19041,11 @@
 msgstr ""
 #: ../vector/v.kernel/main.c:279
-msgid ""
-"Optimal standard deviation calculation is supported only for node method "
-"'none' and kernel function 'gaussian'."
+msgid "Optimal standard deviation calculation is supported only for node method 'none' and kernel function 'gaussian'."
 msgstr ""
 #: ../vector/v.kernel/main.c:283
-msgid ""
-"Optimal standard deviation calculation is supported only for kernel function"
-" 'gaussian'."
+msgid "Optimal standard deviation calculation is supported only for kernel function 'gaussian'."
 msgstr ""
 #: ../vector/v.kernel/main.c:300
@@ -19841,9 +19096,7 @@
 #: ../vector/v.kernel/main.c:379
 #, c-format
-msgid ""
-"Automatic choice of smoothing parameter (radius), maximum possible value of "
-"radius is set to %f"
+msgid "Automatic choice of smoothing parameter (radius), maximum possible value of radius is set to %f"
 msgstr ""
 #: ../vector/v.kernel/main.c:386
@@ -19865,9 +19118,7 @@
 #: ../vector/v.kernel/main.c:406
 #, c-format
-msgid ""
-"Distances between all points are beyond %e (4 * standard deviation), unable "
-"to calculate optimal value."
+msgid "Distances between all points are beyond %e (4 * standard deviation), unable to calculate optimal value."
 msgstr ""
 #: ../vector/v.kernel/main.c:417
@@ -19929,9 +19180,7 @@
 msgstr ""
 #: ../vector/v.clean/main.c:100
-msgid ""
-"change the type of boundary dangle to line, threshold ignored if < 0, input "
-"line type is ignored"
+msgid "change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored"
 msgstr ""
 #: ../vector/v.clean/main.c:102
@@ -19939,9 +19188,7 @@
 msgstr ""
 #: ../vector/v.clean/main.c:103
-msgid ""
-"change the type of bridges connecting area and island or 2 islands from "
-"boundary to line"
+msgid "change the type of bridges connecting area and island or 2 islands from boundary to line"
 msgstr ""
 #: ../vector/v.clean/main.c:105
@@ -19953,17 +19200,11 @@
 msgstr ""
 #: ../vector/v.clean/main.c:107
-msgid ""
-"break (topologically clean) polygons (imported from non topological format, "
-"like ShapeFile). Boundaries are broken on each point shared between 2 and "
-"more polygons where angles of segments are different"
+msgid "break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different"
 msgstr ""
 #: ../vector/v.clean/main.c:110
-msgid ""
-"remove vertices in threshold from lines and boundaries, boundary is pruned "
-"only if topology is not damaged (new intersection, changed attachment of "
-"centroid), first and last segment of the boundary is never changed"
+msgid "remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachment of centroid), first and last segment of the boundary is never changed"
 msgstr ""
 #: ../vector/v.clean/main.c:114
@@ -20003,9 +19244,7 @@
 msgstr ""
 #: ../vector/v.clean/main.c:202
-msgid ""
-"Note: In latitude-longitude coordinate system specify threshold in degree "
-"unit"
+msgid "Note: In latitude-longitude coordinate system specify threshold in degree unit"
 msgstr ""
 #: ../vector/v.clean/main.c:215
@@ -20161,8 +19400,7 @@
 #: ../vector/v.clean/prune.c:216
 #, c-format
-msgid ""
-"%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
+msgid "%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
 msgstr ""
 #: ../vector/v.clean/prune.c:220
@@ -20211,14 +19449,11 @@
 #: ../vector/v.out.vtk/main.c:183
 #, c-format
-msgid ""
-"Export of areas requires topology. Please adjust '%s' option or rebuild "
-"topology."
+msgid "Export of areas requires topology. Please adjust '%s' option or rebuild topology."
 msgstr ""
 #: ../vector/v.out.vtk/writeVTK.c:196
-msgid ""
-"No coordinates to generate the output! Maybe an empty vector type chosen?"
+msgid "No coordinates to generate the output! Maybe an empty vector type chosen?"
 msgstr ""
 #: ../vector/v.out.vtk/writeVTK.c:632
@@ -20304,9 +19539,7 @@
 msgstr ""
 #: ../vector/v.overlay/main.c:70
-msgid ""
-"Overlays two vector maps offering clip, intersection, difference, "
-"symmetrical difference, union operators."
+msgid "Overlays two vector maps offering clip, intersection, difference, symmetrical difference, union operators."
 msgstr ""
 #: ../vector/v.overlay/main.c:73
@@ -20330,10 +19563,7 @@
 msgstr ""
 #: ../vector/v.overlay/main.c:109
-msgid ""
-"Feature is written to output if the result of operation 'ainput operator "
-"binput' is true. Input feature is considered to be true, if category of "
+msgid "Feature is written to output if the result of operation 'ainput operator binput' is true. Input feature is considered to be true, if category of given layer is defined."
 msgstr ""
 #: ../vector/v.overlay/main.c:116
@@ -20345,15 +19575,11 @@
 msgstr ""
 #: ../vector/v.overlay/main.c:118
-msgid ""
-"also known as 'difference' (features from ainput not overlayed by features "
-"from binput)"
+msgid "also known as 'difference' (features from ainput not overlayed by features from binput)"
 msgstr ""
 #: ../vector/v.overlay/main.c:120
-msgid ""
-"also known as 'symmetrical difference' (features from either ainput or "
-"binput but not those from ainput overlayed by binput (only for atype=area)"
+msgid "also known as 'symmetrical difference' (features from either ainput or binput but not those from ainput overlayed by binput (only for atype=area)"
 msgstr ""
 #: ../vector/v.overlay/main.c:131
@@ -20506,8 +19732,7 @@
 #: ../vector/v.net.path/path.c:233
 #, c-format
-msgid ""
-"Point with category [%d] is not reachable from point with category [%d]"
+msgid "Point with category [%d] is not reachable from point with category [%d]"
 msgstr ""
 #: ../vector/v.net.path/path.c:302
@@ -20535,8 +19760,7 @@
 msgstr ""
 #: ../vector/v.net.path/main.c:72
-msgid ""
-"Name of file containing start and end points. If not given, read from stdin"
+msgid "Name of file containing start and end points. If not given, read from stdin"
 msgstr ""
 #: ../vector/v.net.path/main.c:101
@@ -20544,10 +19768,7 @@
 msgstr ""
 #: ../vector/v.net.path/main.c:102
-msgid ""
-"If start/end are given as coordinates. If start/end point is outside this "
-"threshold, the path is not found and error message is printed. To speed up "
-"the process, keep this value as low as possible."
+msgid "If start/end are given as coordinates. If start/end point is outside this threshold, the path is not found and error message is printed. To speed up the process, keep this value as low as possible."
 msgstr ""
 #: ../vector/v.neighbors/main.c:55
@@ -20555,10 +19776,7 @@
 msgstr ""
 #: ../vector/v.neighbors/main.c:56
-msgid ""
-"Makes each cell value a function of the attribute values assigned to the "
-"vector points or centroids around it, and stores new cell values in an "
-"output raster map."
+msgid "Makes each cell value a function of the attribute values assigned to the vector points or centroids around it, and stores new cell values in an output raster map."
 msgstr ""
 #: ../vector/v.neighbors/main.c:72 ../raster/r.neighbors/main.c:204
@@ -20575,9 +19793,7 @@
 #: ../vector/v.neighbors/main.c:103
 #, c-format
-msgid ""
-"The search diameter %g is smaller than cell diagonal %g: some points could "
-"not be detected"
+msgid "The search diameter %g is smaller than cell diagonal %g: some points could not be detected"
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:75
@@ -20591,9 +19807,7 @@
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:88
-msgid ""
-"Maybe it takes too long. It will depend on how many points you are "
-"considering."
+msgid "Maybe it takes too long. It will depend on how many points you are considering."
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:119
@@ -20609,9 +19823,7 @@
 #: ../vector/v.surf.bspline/crosscorr.c:151
 #: ../raster/r.resamp.bspline/crosscorr.c:197
 #, c-format
-msgid ""
-"Too many splines (%d x %d). Consider changing spline steps \"ew_step=\" "
-"\"ns_step=\"."
+msgid "Too many splines (%d x %d). Consider changing spline steps \"ew_step=\" \"ns_step=\"."
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:169
@@ -20640,16 +19852,13 @@
 #: ../vector/v.surf.bspline/crosscorr.c:313
 #: ../raster/r.resamp.bspline/crosscorr.c:324
-msgid ""
-"Different number of splines and lambda_i values have been taken for the "
-"cross correlation"
+msgid "Different number of splines and lambda_i values have been taken for the cross correlation"
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:315
 #: ../raster/r.resamp.bspline/crosscorr.c:326
 #, c-format
-msgid ""
-"The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
+msgid "The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:323
@@ -20669,15 +19878,11 @@
 msgstr ""
 #: ../vector/v.surf.bspline/main.c:96
-msgid ""
-"Performs bicubic or bilinear spline interpolation with Tykhonov "
-"regularization."
+msgid "Performs bicubic or bilinear spline interpolation with Tykhonov regularization."
 msgstr ""
 #: ../vector/v.surf.bspline/main.c:101 ../raster/r.resamp.bspline/main.c:144
-msgid ""
-"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
-"cross validation method"
+msgid "Find the best Tykhonov regularizing parameter using a \"leave-one-out\" cross validation method"
 msgstr ""
 #: ../vector/v.surf.bspline/main.c:105 ../vector/v.outlier/main.c:79
@@ -20766,9 +19971,7 @@
 #: ../vector/v.surf.bspline/main.c:338
 #, c-format
-msgid ""
-"Sorry, the <%s> driver is not compatible with the vector output of this "
-"module. Try with raster output or another driver."
+msgid "Sorry, the <%s> driver is not compatible with the vector output of this module. Try with raster output or another driver."
 msgstr ""
 #: ../vector/v.surf.bspline/main.c:361
@@ -20844,9 +20047,7 @@
 msgstr ""
 #: ../vector/v.surf.idw/main.c:92
-msgid ""
-"Provides surface interpolation from vector point data by Inverse Distance "
-"Squared Weighting."
+msgid "Provides surface interpolation from vector point data by Inverse Distance Squared Weighting."
 msgstr ""
 #: ../vector/v.surf.idw/main.c:101
@@ -20874,9 +20075,7 @@
 msgstr ""
 #: ../vector/v.surf.idw/main.c:129
-msgid ""
-"Slower but uses less memory and includes points from outside region in the "
-"interpolation"
+msgid "Slower but uses less memory and includes points from outside region in the interpolation"
 msgstr ""
 #: ../vector/v.surf.idw/main.c:139
@@ -20954,9 +20153,7 @@
 msgstr ""
 #: ../vector/v.buffer/main.c:293
-msgid ""
-"Maximum distance between theoretical arc and polygon segments as multiple of"
-" buffer"
+msgid "Maximum distance between theoretical arc and polygon segments as multiple of buffer"
 msgstr ""
 #: ../vector/v.buffer/main.c:298
@@ -20972,9 +20169,7 @@
 msgstr ""
 #: ../vector/v.buffer/main.c:326
-msgid ""
-"Note: In latitude-longitude coordinate system specify distances in degree "
-"unit"
+msgid "Note: In latitude-longitude coordinate system specify distances in degree unit"
 msgstr ""
 #: ../vector/v.buffer/main.c:330
@@ -21009,9 +20204,7 @@
 msgstr ""
 #: ../vector/v.buffer/main.c:464
-msgid ""
-"No features available for buffering. Check type option and features "
-"available in the input vector."
+msgid "No features available for buffering. Check type option and features available in the input vector."
 msgstr ""
 #: ../vector/v.buffer/main.c:481
@@ -21020,9 +20213,7 @@
 msgstr ""
 #: ../vector/v.buffer/main.c:486
-msgid ""
-"Negative distances for internal buffers are not supported and converted to "
-"positive values."
+msgid "Negative distances for internal buffers are not supported and converted to positive values."
 msgstr ""
 #: ../vector/v.buffer/main.c:496
@@ -21145,8 +20336,7 @@
 msgstr ""
 #: ../vector/v.outlier/main.c:355
-msgid ""
-"No subregions found! Check values for 'ew_step' and 'ns_step' parameters"
+msgid "No subregions found! Check values for 'ew_step' and 'ns_step' parameters"
 msgstr ""
 #: ../vector/v.outlier/main.c:428
@@ -21265,9 +20455,7 @@
 msgstr ""
 #: ../db/db.copy/main.c:40
-msgid ""
-"Either 'from_table' (optionally with 'where') can be used or 'select' "
-"option, but not 'from_table' and 'select' at the same time."
+msgid "Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
 msgstr ""
 #: ../db/db.copy/main.c:46
@@ -21344,9 +20532,7 @@
 msgstr ""
 #: ../db/db.databases/main.c:53
-msgid ""
-"Unable to list databases. Try to define correct connection settings by "
-"db.login."
+msgid "Unable to list databases. Try to define correct connection settings by db.login."
 msgstr ""
 #: ../db/db.databases/main.c:63
@@ -21439,23 +20625,17 @@
 #: ../db/drivers/postgres/describe.c:130 ../db/drivers/ogr/describe.c:186
 #, c-format
-msgid ""
-"Column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
-"may be damaged"
+msgid "Column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data may be damaged"
 msgstr ""
 #: ../db/drivers/postgres/describe.c:134
 #, c-format
-msgid ""
-"Column '%s' : type character varying is stored as varchar(250) some data may"
-" be lost"
+msgid "Column '%s' : type character varying is stored as varchar(250) some data may be lost"
 msgstr ""
 #: ../db/drivers/postgres/describe.c:140
 #, c-format
-msgid ""
-"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1"
-" (true)"
+msgid "column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 (true)"
 msgstr ""
 #: ../db/drivers/postgres/execute.c:42 ../db/drivers/mysql/execute.c:41
@@ -21782,9 +20962,7 @@
 #: ../db/drivers/mysql/describe.c:127
 #, c-format
-msgid ""
-"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
-"damaged"
+msgid "column '%s' : type BIGINT is stored as integer (4 bytes) some data may be damaged"
 msgstr ""
 #: ../db/drivers/mysql/execute.c:62
@@ -21871,9 +21049,7 @@
 #: ../db/drivers/ogr/describe.c:204
 #, c-format
-msgid ""
-"column '%s', type 'string': unknown width -> stored as varchar(250) some "
-"data may be lost"
+msgid "column '%s', type 'string': unknown width -> stored as varchar(250) some data may be lost"
 msgstr ""
 #: ../db/drivers/ogr/describe.c:212 ../db/drivers/ogr/fetch.c:160
@@ -21968,8 +21144,7 @@
 msgstr ""
 #: ../db/drivers/sqlite/fetch.c:218
-msgid ""
-"SQLite driver: parsing of interval values not implemented; assuming seconds"
+msgid "SQLite driver: parsing of interval values not implemented; assuming seconds"
 msgstr ""
 #: ../db/drivers/sqlite/fetch.c:223
@@ -22126,9 +21301,7 @@
 msgstr ""
 #: ../display/d.rgb/main.c:58
-msgid ""
-"Displays three user-specified raster maps as red, green, and blue overlays "
-"in the active graphics frame."
+msgid "Displays three user-specified raster maps as red, green, and blue overlays in the active graphics frame."
 msgstr ""
 #: ../display/d.rgb/main.c:63 ../display/d.rast/main.c:81
@@ -22158,9 +21331,7 @@
 msgstr ""
 #: ../display/d.linegraph/main.c:126
-msgid ""
-"Generates and displays simple line graphs in the active graphics monitor "
-"display frame."
+msgid "Generates and displays simple line graphs in the active graphics monitor display frame."
 msgstr ""
 #: ../display/d.linegraph/main.c:130
@@ -22468,15 +21639,11 @@
 msgstr ""
 #: ../display/d.graph/main.c:61
-msgid ""
-"Program for generating and displaying simple graphics on the display "
-"monitor."
+msgid "Program for generating and displaying simple graphics on the display monitor."
 msgstr ""
 #: ../display/d.graph/main.c:66
-msgid ""
-"Name of file containing graphics commands, if not given reads from standard "
-"input"
+msgid "Name of file containing graphics commands, if not given reads from standard input"
 msgstr ""
 #: ../display/d.graph/main.c:73
@@ -22556,9 +21723,7 @@
 msgstr ""
 #: ../display/d.grid/main.c:58
-msgid ""
-"Overlays a user-specified grid in the active display frame on the graphics "
-"monitor."
+msgid "Overlays a user-specified grid in the active display frame on the graphics monitor."
 msgstr ""
 #: ../display/d.grid/main.c:66
@@ -22566,9 +21731,7 @@
 msgstr ""
 #: ../display/d.grid/main.c:68
-msgid ""
-"0 for north-south resolution of the current region. In map units or "
-"DDD:MM:SS format. Example: \"1000\" or \"0:10\""
+msgid "0 for north-south resolution of the current region. In map units or DDD:MM:SS format. Example: \"1000\" or \"0:10\""
 msgstr ""
 #: ../display/d.grid/main.c:76
@@ -22710,9 +21873,7 @@
 msgstr ""
 #: ../display/d.text/main.c:142
-msgid ""
-"Draws text in the active display frame on the graphics monitor using the "
-"current font."
+msgid "Draws text in the active display frame on the graphics monitor using the current font."
 msgstr ""
 #: ../display/d.text/main.c:148
@@ -22746,9 +21907,7 @@
 msgstr ""
 #: ../display/d.text/main.c:198
-msgid ""
-"Screen position at which text will begin to be drawn (percentage, [0,0] is "
-"lower left)"
+msgid "Screen position at which text will begin to be drawn (percentage, [0,0] is lower left)"
 msgstr ""
 #: ../display/d.text/main.c:199 ../display/d.text/main.c:208
@@ -22860,14 +22019,12 @@
 #: ../display/d.colortable/main.c:112
 #, c-format
-msgid ""
-"<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
+msgid "<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
 msgstr ""
 #: ../display/d.colortable/main.c:126
 #, c-format
-msgid ""
-"<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
+msgid "<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
 msgstr ""
 #: ../display/d.colortable/main.c:137
@@ -23071,9 +22228,7 @@
 msgstr ""
 #: ../display/d.his/main.c:69
-msgid ""
-"Displays the result obtained by combining hue, intensity, and saturation "
-"(HIS) values from user-specified input raster map layers."
+msgid "Displays the result obtained by combining hue, intensity, and saturation (HIS) values from user-specified input raster map layers."
 msgstr ""
 #: ../display/d.his/main.c:78 ../raster/r.his/main.c:82
@@ -23101,9 +22256,7 @@
 msgstr ""
 #: ../display/d.histogram/main.c:87
-msgid ""
-"Displays a histogram in the form of a pie or bar chart for a user-specified "
-"raster map."
+msgid "Displays a histogram in the form of a pie or bar chart for a user-specified raster map."
 msgstr ""
 #: ../display/d.histogram/main.c:91
@@ -23155,8 +22308,7 @@
 msgstr ""
 #: ../display/d.title/main.c:52
-msgid ""
-"Create a TITLE for a raster map in a form suitable for display with d.text."
+msgid "Create a TITLE for a raster map in a form suitable for display with d.text."
 msgstr ""
 #: ../display/d.title/main.c:63
@@ -23192,8 +22344,7 @@
 msgstr ""
 #: ../display/d.vect.chart/main.c:67
-msgid ""
-"Displays charts of vector data in the active frame on the graphics monitor."
+msgid "Displays charts of vector data in the active frame on the graphics monitor."
 msgstr ""
 #: ../display/d.vect.chart/main.c:86
@@ -23248,9 +22399,7 @@
 msgstr ""
 #: ../display/d.erase/main.c:33
-msgid ""
-"Erases the contents of the active graphics display frame with user defined "
-"color."
+msgid "Erases the contents of the active graphics display frame with user defined color."
 msgstr ""
 #: ../display/d.erase/main.c:42
@@ -23324,9 +22473,7 @@
 msgstr ""
 #: ../display/d.rast.arrow/main.c:101
-msgid ""
-"Draws arrows representing cell aspect direction for a raster map containing "
-"aspect data."
+msgid "Draws arrows representing cell aspect direction for a raster map containing aspect data."
 msgstr ""
 #: ../display/d.rast.arrow/main.c:105
@@ -23427,9 +22574,7 @@
 msgstr ""
 #: ../display/d.labels/main.c:46
-msgid ""
-"Displays text labels (created with v.label) to the active frame on the "
-"graphics monitor."
+msgid "Displays text labels (created with v.label) to the active frame on the graphics monitor."
 msgstr ""
 #: ../display/d.labels/main.c:52
@@ -23552,9 +22697,7 @@
 msgstr ""
 #: ../display/d.vect.thematic/main.c:237
-msgid ""
-"When printing legend info, include extended statistical info from "
-"classification algorithm"
+msgid "When printing legend info, include extended statistical info from classification algorithm"
 msgstr ""
 #: ../display/d.vect.thematic/main.c:243 ../display/d.vect/main.c:330
@@ -23562,16 +22705,11 @@
 msgstr ""
 #: ../display/d.vect.thematic/main.c:255
-msgid ""
-"Flag -e is deprecated, set verbose mode with --v to get the extended "
-"statistical info."
+msgid "Flag -e is deprecated, set verbose mode with --v to get the extended statistical info."
 msgstr ""
 #: ../display/d.vect.thematic/main.c:258
-msgid ""
-"Option legendfile is deprecated, either use flag -l to print legend to "
-"standard output, or set GRASS_LEGEND_FILE environment variable (see "
-"d.legend.vect for details)."
+msgid "Option legendfile is deprecated, either use flag -l to print legend to standard output, or set GRASS_LEGEND_FILE environment variable (see d.legend.vect for details)."
 msgstr ""
 #: ../display/d.vect.thematic/main.c:277
@@ -23588,8 +22726,7 @@
 msgid "Data (%s) not numeric. Column must be numeric."
 msgstr ""
-#: ../display/d.vect.thematic/main.c:316
-#: ../display/d.vect.thematic/plot1.c:135
+#: ../display/d.vect.thematic/main.c:316 ../display/d.vect.thematic/plot1.c:135
 #: ../display/d.vect.thematic/plot1.c:163
 #, c-format
 msgid "Cannot select data (%s) from table"
@@ -23601,9 +22738,7 @@
 msgstr ""
 #: ../display/d.vect.thematic/main.c:390
-msgid ""
-"You gave both manual breaks and a classification algorithm or a number of "
-"classes. The manual breaks have precedence and will thus be used."
+msgid "You gave both manual breaks and a classification algorithm or a number of classes. The manual breaks have precedence and will thus be used."
 msgstr ""
 #: ../display/d.vect.thematic/main.c:427
@@ -23627,8 +22762,7 @@
 msgstr ""
 #: ../display/d.vect.thematic/main.c:469
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn."
+msgid "The bounding box of the map is outside the current region, nothing drawn."
 msgstr ""
 #: ../display/d.vect.thematic/main.c:522
@@ -23654,9 +22788,7 @@
 #: ../display/d.vect.thematic/plot1.c:130
 #, c-format
-msgid ""
-"Color definition column (%s) not a string. Column must be of form "
-"RRR:GGG:BBB where RGB values range 0-255."
+msgid "Color definition column (%s) not a string. Column must be of form RRR:GGG:BBB where RGB values range 0-255."
 msgstr ""
 #: ../display/d.vect.thematic/plot1.c:148
@@ -23677,9 +22809,7 @@
 #: ../display/d.vect.thematic/plot1.c:279
 #, c-format
-msgid ""
-"Error in color definition column (%s), element %d with cat %d: colorstring "
-"[%s]"
+msgid "Error in color definition column (%s), element %d with cat %d: colorstring [%s]"
 msgstr ""
 #: ../display/d.vect.thematic/plot1.c:286
@@ -23689,8 +22819,7 @@
 #: ../display/d.vect.thematic/plot1.c:354
 #, c-format
-msgid ""
-"Error in line width column (%s), element %d with cat %d: line width [%d]"
+msgid "Error in line width column (%s), element %d with cat %d: line width [%d]"
 msgstr ""
 #: ../display/d.vect.thematic/display.c:51 ../display/d.vect/lines.c:107
@@ -23735,9 +22864,7 @@
 msgstr[1] ""
 #: ../display/d.vect/area.c:37
-msgid ""
-"Unable to display areas, topology not available. Please try to rebuild "
-"topology using v.build or v.build.all."
+msgid "Unable to display areas, topology not available. Please try to rebuild topology using v.build or v.build.all."
 msgstr ""
 #: ../display/d.vect/area.c:137
@@ -23766,9 +22893,7 @@
 msgstr ""
 #: ../display/d.vect/lines.c:121
-msgid ""
-"Unable to display features by id, topology not available. Please try to "
-"rebuild topology using v.build or v.build.all."
+msgid "Unable to display features by id, topology not available. Please try to rebuild topology using v.build or v.build.all."
 msgstr ""
 #: ../display/d.vect/lines.c:169
@@ -23916,19 +23041,15 @@
 msgstr ""
 #: ../display/d.vect/main.c:295
-msgid ""
-"Minimum region size (average from height and width) when map is displayed"
+msgid "Minimum region size (average from height and width) when map is displayed"
 msgstr ""
 #: ../display/d.vect/main.c:303
-msgid ""
-"Maximum region size (average from height and width) when map is displayed"
+msgid "Maximum region size (average from height and width) when map is displayed"
 msgstr ""
 #: ../display/d.vect/main.c:311
-msgid ""
-"Random colors according to category number (or layer number if 'layer=-1' is"
-" given)"
+msgid "Random colors according to category number (or layer number if 'layer=-1' is given)"
 msgstr ""
 #: ../display/d.vect/main.c:318
@@ -23940,9 +23061,7 @@
 msgstr ""
 #: ../display/d.vect/main.c:324
-msgid ""
-"This makes circle areas proportionate to the size_column values instead of "
-"circle radius"
+msgid "This makes circle areas proportionate to the size_column values instead of circle radius"
 msgstr ""
 #: ../display/d.vect/main.c:347
@@ -23955,9 +23074,7 @@
 #: ../display/d.vect/main.c:368
 #, c-format
-msgid ""
-"The -%c flag and <%s> option cannot be used together, the -%c flag will be "
-"ignored!"
+msgid "The -%c flag and <%s> option cannot be used together, the -%c flag will be ignored!"
 msgstr ""
 #: ../display/d.vect/main.c:392 ../display/d.vect/main.c:398
@@ -23977,8 +23094,7 @@
 msgstr ""
 #: ../display/d.vect/main.c:426
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn"
+msgid "The bounding box of the map is outside the current region, nothing drawn"
 msgstr ""
 #: ../display/d.vect/main.c:500
@@ -23997,10 +23113,7 @@
 #: ../display/d.vect/shape.c:68
 #, c-format
-msgid ""
-"Color definition column ('%s') not a string. Column must be of form "
-"'RRR:GGG:BBB' where RGB values range 0-255. You can use '%s' module to "
-"define color rules. Unable to colorize features."
+msgid "Color definition column ('%s') not a string. Column must be of form 'RRR:GGG:BBB' where RGB values range 0-255. You can use '%s' module to define color rules. Unable to colorize features."
 msgstr ""
 #: ../display/d.vect/shape.c:77 ../display/d.vect/shape.c:100
@@ -24037,8 +23150,7 @@
 msgstr ""
 #: ../display/d.vect/shape.c:182
-msgid ""
-"Vector map is not 3D. Unable to colorize features based on z-coordinates."
+msgid "Vector map is not 3D. Unable to colorize features based on z-coordinates."
 msgstr ""
 #: ../display/d.vect/shape.c:186
@@ -24052,9 +23164,7 @@
 msgstr ""
 #: ../display/d.vect/topo.c:18
-msgid ""
-"Unable to display topology, not available.Please try to rebuild topology "
-"using v.build or v.build.all."
+msgid "Unable to display topology, not available.Please try to rebuild topology using v.build or v.build.all."
 msgstr ""
 #: ../display/d.vect/zcoor.c:19
@@ -24062,9 +23172,7 @@
 msgstr ""
 #: ../display/d.font/main.c:48
-msgid ""
-"Selects the font in which text will be displayed on the user's graphics "
-"monitor."
+msgid "Selects the font in which text will be displayed on the user's graphics monitor."
 msgstr ""
 #: ../display/d.font/main.c:56
@@ -24099,8 +23207,7 @@
 #: ../display/d.font/main.c:124
 #, c-format
-msgid ""
-"Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
+msgid "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
 msgstr ""
 #: ../display/d.fontlist/main.c:47
@@ -24112,9 +23219,7 @@
 msgstr ""
 #: ../display/d.rast.num/main.c:81
-msgid ""
-"Overlays cell category values on a raster map displayed in the active "
-"graphics frame."
+msgid "Overlays cell category values on a raster map displayed in the active graphics frame."
 msgstr ""
 #: ../display/d.rast.num/main.c:112
@@ -24141,14 +23246,11 @@
 msgstr ""
 #: ../display/d.legend/histogram.c:115
-msgid ""
-"Histogram constrained by range not yet implemented for categorical rasters"
+msgid "Histogram constrained by range not yet implemented for categorical rasters"
 msgstr ""
 #: ../display/d.legend/main.c:82
-msgid ""
-"Displays a legend for a 2D or 3D raster map in the active frame of the "
+msgid "Displays a legend for a 2D or 3D raster map in the active frame of the graphics monitor."
 msgstr ""
 #: ../display/d.legend/main.c:99 ../display/d.legend.vect/main.c:81
@@ -24212,8 +23314,7 @@
 msgstr ""
 #: ../display/d.legend/main.c:179
-msgid ""
-"Size and placement as percentage of screen coordinates (0,0 is lower left)"
+msgid "Size and placement as percentage of screen coordinates (0,0 is lower left)"
 msgstr ""
 #: ../display/d.legend/main.c:189
@@ -24329,9 +23430,7 @@
 msgstr ""
 #: ../display/d.legend/draw.c:1029
-msgid ""
-"Histogram plotting not implemented for categorical legends. Use the '-s' "
-"flag"
+msgid "Histogram plotting not implemented for categorical legends. Use the '-s' flag"
 msgstr ""
 #: ../display/d.legend/draw.c:1286
@@ -24369,9 +23468,7 @@
 msgstr ""
 #: ../display/d.where/main.c:48
-msgid ""
-"Identifies the geographic coordinates associated with point locations given "
-"in display coordinates."
+msgid "Identifies the geographic coordinates associated with point locations given in display coordinates."
 msgstr ""
 #: ../display/d.where/main.c:58
@@ -24391,9 +23488,7 @@
 msgstr ""
 #: ../display/d.where/main.c:77
-msgid ""
-"Output lat/long referenced to WGS84 ellipsoid using datum transformation "
-"parameters defined in current location (if available)"
+msgid "Output lat/long referenced to WGS84 ellipsoid using datum transformation parameters defined in current location (if available)"
 msgstr ""
 #: ../display/d.where/main.c:83
@@ -24534,9 +23629,7 @@
 msgstr ""
 #: ../display/d.geodesic/main.c:51
-msgid ""
-"Displays a geodesic line, tracing the shortest distance between two "
-"geographic points along a great circle, in a longitude/latitude data set."
+msgid "Displays a geodesic line, tracing the shortest distance between two geographic points along a great circle, in a longitude/latitude data set."
 msgstr ""
 #: ../display/d.legend.vect/main.c:55
@@ -24544,8 +23637,7 @@
 msgstr ""
 #: ../display/d.legend.vect/main.c:66
-msgid ""
-"Screen position of legend to be drawn (percentage, [0,0] is lower left)"
+msgid "Screen position of legend to be drawn (percentage, [0,0] is lower left)"
 msgstr ""
 #: ../display/d.legend.vect/main.c:74
@@ -24726,9 +23818,7 @@
 msgstr ""
 #: ../imagery/i.rgb.his/main.c:52
-msgid ""
-"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
-"Intensity-Saturation) color space."
+msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
 msgstr ""
 #: ../imagery/i.rgb.his/main.c:58
@@ -24832,9 +23922,7 @@
 msgstr ""
 #: ../imagery/i.eb.netrad/main.c:85
-msgid ""
-"Name of the difference map of temperature from surface skin to about 2 m "
-"height [K]"
+msgid "Name of the difference map of temperature from surface skin to about 2 m height [K]"
 msgstr ""
 #: ../imagery/i.eb.netrad/main.c:89
@@ -24863,9 +23951,7 @@
 msgstr ""
 #: ../imagery/i.evapo.pm/main.c:61
-msgid ""
-"Computes potential evapotranspiration calculation with hourly Penman-"
-"Monteith."
+msgid "Computes potential evapotranspiration calculation with hourly Penman-Monteith."
 msgstr ""
 #: ../imagery/i.evapo.pm/main.c:65
@@ -25064,9 +24150,7 @@
 msgstr ""
 #: ../imagery/i.maxlik/main.c:68
-msgid ""
-"Classification is based on the spectral signature information generated by "
-"either i.cluster, g.gui.iclass, or i.gensig."
+msgid "Classification is based on the spectral signature information generated by either i.cluster, g.gui.iclass, or i.gensig."
 msgstr ""
 #: ../imagery/i.maxlik/main.c:81 ../imagery/i.smap/parse.c:20
@@ -25087,16 +24171,12 @@
 #: ../imagery/i.maxlik/open.c:27
 #, c-format
-msgid ""
-"Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
-"have at least 2 raster maps."
+msgid "Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must have at least 2 raster maps."
 msgstr ""
 #: ../imagery/i.maxlik/open.c:30
 #, c-format
-msgid ""
-"Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at"
-" least 2 raster maps."
+msgid "Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at least 2 raster maps."
 msgstr ""
 #: ../imagery/i.maxlik/open.c:47
@@ -25150,9 +24230,7 @@
 msgstr ""
 #: ../imagery/i.rectify/main.c:102
-msgid ""
-"Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points."
+msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
 msgstr ""
 #: ../imagery/i.rectify/main.c:116
@@ -25172,9 +24250,7 @@
 #: ../imagery/i.rectify/main.c:153
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:137
-msgid ""
-"Use current region settings in target location (def.=calculate smallest "
-"area)"
+msgid "Use current region settings in target location (def.=calculate smallest area)"
 msgstr ""
 #: ../imagery/i.rectify/main.c:157
@@ -25357,8 +24433,7 @@
 msgstr ""
 #: ../imagery/i.vi/main.c:94
-msgid ""
-"Uses red and nir bands mostly, and some indices require additional bands."
+msgid "Uses red and nir bands mostly, and some indices require additional bands."
 msgstr ""
 #: ../imagery/i.vi/main.c:101
@@ -25485,9 +24560,7 @@
 msgstr ""
 #: ../imagery/i.vi/main.c:202
-msgid ""
-"If data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8"
-" for Landsat -> [0-255])"
+msgid "If data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8 for Landsat -> [0-255])"
 msgstr ""
 #: ../imagery/i.vi/main.c:225 ../raster/r.texture/main.c:327
@@ -25524,8 +24597,7 @@
 msgstr ""
 #: ../imagery/i.vi/main.c:251
-msgid ""
-"msavi index requires red and nir maps, and 3 parameters related to soil line"
+msgid "msavi index requires red and nir maps, and 3 parameters related to soil line"
 msgstr ""
 #: ../imagery/i.vi/main.c:254
@@ -25597,9 +24669,7 @@
 msgstr ""
 #: ../imagery/i.evapo.mh/main.c:72
-msgid ""
-"Computes evapotranspiration calculation modified or original Hargreaves "
-"formulation, 2001."
+msgid "Computes evapotranspiration calculation modified or original Hargreaves formulation, 2001."
 msgstr ""
 #: ../imagery/i.evapo.mh/main.c:78
@@ -25684,9 +24754,7 @@
 msgstr ""
 #: ../imagery/i.smap/main.c:44
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
+msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
 msgstr ""
 #: ../imagery/i.smap/model.c:43
@@ -25794,15 +24862,11 @@
 msgstr ""
 #: ../imagery/i.cluster/main.c:79
-msgid ""
-"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm."
+msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
 msgstr ""
 #: ../imagery/i.cluster/main.c:82
-msgid ""
-"The resulting signature file is used as input for i.maxlik, to generate an "
-"unsupervised image classification."
+msgid "The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
 msgstr ""
 #: ../imagery/i.cluster/main.c:102
@@ -25992,14 +25056,11 @@
 msgstr ""
 #: ../imagery/i.cluster/main.c:312
-msgid ""
-"Not enough sample points. Please run again and choose a larger sample size."
+msgid "Not enough sample points. Please run again and choose a larger sample size."
 msgstr ""
 #: ../imagery/i.cluster/main.c:316
-msgid ""
-"Not enough non-zero sample data points. Check your current region (and "
-"mask)."
+msgid "Not enough non-zero sample data points. Check your current region (and mask)."
 msgstr ""
 #: ../imagery/i.cluster/main.c:329
@@ -26227,9 +25288,7 @@
 msgstr ""
 #: ../imagery/i.aster.toar/main.c:105
-msgid ""
-"Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
-"from ASTER DN."
+msgid "Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature from ASTER DN."
 msgstr ""
 #: ../imagery/i.aster.toar/main.c:109
@@ -26282,9 +25341,7 @@
 msgstr ""
 #: ../imagery/i.his.rgb/main.c:52
-msgid ""
-"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
-"RGB (Red-Green-Blue) color space."
+msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
 msgstr ""
 #: ../imagery/i.his.rgb/main.c:58
@@ -26332,9 +25389,7 @@
 msgstr ""
 #: ../imagery/i.evapo.time/main.c:79
-msgid ""
-"Computes temporal integration of satellite ET actual (ETa) following the "
-"daily ET reference (ETo) from meteorological station(s)."
+msgid "Computes temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)."
 msgstr ""
 #: ../imagery/i.evapo.time/main.c:86
@@ -26431,15 +25486,13 @@
 msgid "Group <%s> not found in the current mapset"
 msgstr ""
-#: ../imagery/i.segment/write_output.c:100
-#: ../imagery/i.segment/open_files.c:44
+#: ../imagery/i.segment/write_output.c:100 ../imagery/i.segment/open_files.c:44
 #, c-format
 msgid "Group <%s> contains no raster maps"
 msgstr ""
-#: ../imagery/i.segment/write_output.c:116
-#: ../imagery/i.segment/open_files.c:69 ../imagery/i.segment/open_files.c:228
-#: ../imagery/i.segment/open_files.c:236
+#: ../imagery/i.segment/write_output.c:116 ../imagery/i.segment/open_files.c:69
+#: ../imagery/i.segment/open_files.c:228 ../imagery/i.segment/open_files.c:236
 #, c-format
 msgid "No min/max found in raster map <%s>"
 msgstr ""
@@ -26547,9 +25600,7 @@
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:122
-msgid ""
-"Must be integer values, each area will be segmented independent of the "
-"others"
+msgid "Must be integer values, each area will be segmented independent of the others"
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:128
@@ -26557,14 +25608,11 @@
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:133
-msgid ""
-"Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for "
-"each pixel"
+msgid "Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for each pixel"
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:139
-msgid ""
-"Weighted input, do not perform the default scaling of input raster maps"
+msgid "Weighted input, do not perform the default scaling of input raster maps"
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:158
@@ -26634,9 +25682,7 @@
 #: ../imagery/i.segment/region_growing.c:445
 #, c-format
-msgid ""
-"Segmentation processes stopped at %d due to reaching max iteration limit, "
-"more merges may be possible"
+msgid "Segmentation processes stopped at %d due to reaching max iteration limit, more merges may be possible"
 msgstr ""
 #: ../imagery/i.segment/region_growing.c:447
@@ -26697,9 +25743,7 @@
 #: ../imagery/i.segment/mean_shift.c:106
 #, c-format
-msgid ""
-"Mean shift stopped at %d due to reaching max iteration limit, more changes "
-"may be possible"
+msgid "Mean shift stopped at %d due to reaching max iteration limit, more changes may be possible"
 msgstr ""
 #: ../imagery/i.segment/mean_shift.c:108
@@ -26771,8 +25815,7 @@
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:153
 #, c-format
-msgid ""
-"Replacing coordinates of principal point '%.17g, %.17g' with '%.17g, %.17g'"
+msgid "Replacing coordinates of principal point '%.17g, %.17g' with '%.17g, %.17g'"
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:164
@@ -26806,9 +25849,7 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:50
-msgid ""
-"Interactively creates or modifies entries in a camera initial exposure "
-"station file for imagery group referenced by a sub-block."
+msgid "Interactively creates or modifies entries in a camera initial exposure station file for imagery group referenced by a sub-block."
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:62
@@ -27139,9 +26180,7 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:91
-msgid ""
-"Orthorectifies an image by using the image to photo coordinate "
-"transformation matrix."
+msgid "Orthorectifies an image by using the image to photo coordinate transformation matrix."
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:132
@@ -27311,9 +26350,7 @@
 msgstr ""
 #: ../imagery/i.albedo/main.c:138 ../imagery/i.albedo/main.c:145
-msgid ""
-"Albedo dry run to calculate some water to beach/sand/desert stretching, a "
-"kind of simple atmospheric correction"
+msgid "Albedo dry run to calculate some water to beach/sand/desert stretching, a kind of simple atmospheric correction"
 msgstr ""
 #: ../imagery/i.albedo/main.c:143
@@ -27325,9 +26362,7 @@
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:69
-msgid ""
-"Calculates top-of-atmosphere radiance or reflectance and temperature for "
-"Landsat MSS/TM/ETM+/OLI"
+msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+/OLI"
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:75
@@ -27500,8 +26535,7 @@
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:227
-msgid ""
-"Input raster maps use as extension the number of the band instead the code"
+msgid "Input raster maps use as extension the number of the band instead the code"
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:231
@@ -27590,16 +26624,11 @@
 msgstr ""
 #: ../imagery/i.landsat.toar/landsat.c:116
-msgid ""
-"The DOS4 method is not applicable here: approximation of atmospheric "
-"transmittance coefficients is unstable. Use another DOS method or use other "
-"sun_elevation parameter"
+msgid "The DOS4 method is not applicable here: approximation of atmospheric transmittance coefficients is unstable. Use another DOS method or use other sun_elevation parameter"
 msgstr ""
 #: ../imagery/i.evapo.pt/main.c:69
-msgid ""
-"Computes evapotranspiration calculation Priestley and Taylor formulation, "
-"1972."
+msgid "Computes evapotranspiration calculation Priestley and Taylor formulation, 1972."
 msgstr ""
 #: ../imagery/i.evapo.pt/main.c:75
@@ -27843,9 +26872,7 @@
 #: ../imagery/i.landsat.acca/main.c:70
 #, c-format
-msgid ""
-"Input raster map <%s> is not floating point (process DN using i.landsat.toar"
-" to radiance first)"
+msgid "Input raster map <%s> is not floating point (process DN using i.landsat.toar to radiance first)"
 msgstr ""
 #: ../imagery/i.landsat.acca/main.c:104
@@ -27890,9 +26917,7 @@
 msgstr ""
 #: ../imagery/i.landsat.acca/main.c:158
-msgid ""
-"Bypass second-pass processing, and merge warm (not ambiguous) and cold "
-"clouds"
+msgid "Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
 msgstr ""
 #: ../imagery/i.landsat.acca/main.c:163
@@ -28333,9 +27358,7 @@
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:342
-msgid ""
-"Band number of MODIS product "
-"(mod09Q1=[1,2],mod09A1=[1-7],m[o/y]d09CMG=[1-7], mcd43B2q=[1-7])"
+msgid "Band number of MODIS product (mod09Q1=[1,2],mod09A1=[1-7],m[o/y]d09CMG=[1-7], mcd43B2q=[1-7])"
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:346
@@ -28538,9 +27561,7 @@
 msgstr ""
 #: ../misc/m.cogo/main.c:228
-msgid ""
-"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa."
+msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
 msgstr ""
 #: ../misc/m.cogo/main.c:230
@@ -28963,9 +27984,7 @@
 msgstr ""
 #: ../misc/m.nviz.image/args.c:903
-msgid ""
-"Place north arrow at given position \t(in screen coordinates from bottom "
-"left corner)"
+msgid "Place north arrow at given position \t(in screen coordinates from bottom left corner)"
 msgstr ""
 #: ../misc/m.nviz.image/args.c:905 ../misc/m.nviz.image/args.c:915
@@ -29033,9 +28052,7 @@
 msgstr ""
 #: ../misc/m.nviz.image/main.c:57
-msgid ""
-"Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
-"data) in 3D."
+msgid "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D."
 msgstr ""
 #: ../misc/m.nviz.image/main.c:83
@@ -29263,9 +28280,7 @@
 msgstr ""
 #: ../misc/m.nviz.script/main.c:439
-msgid ""
-"Skipping this point, selected point is outside region. Perhaps the camera "
-"setback distance puts it beyond the edge?"
+msgid "Skipping this point, selected point is outside region. Perhaps the camera setback distance puts it beyond the edge?"
 msgstr ""
 #: ../raster/r.in.bin/main.c:61 ../raster/r.in.bin/main.c:70
@@ -29388,9 +28403,7 @@
 #: ../raster/r.in.bin/main.c:554
 #, c-format
-msgid ""
-"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
-"significantly. Did you assign %s= and %s= correctly?"
+msgid "East-West (ewres: %f) and North-South (nwres: %f) resolution differ significantly. Did you assign %s= and %s= correctly?"
 msgstr ""
 #: ../raster/r.in.bin/main.c:575
@@ -29466,13 +28479,7 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:186
-msgid ""
-"The module has two different modes of operation: 1. Computes the entire "
-"horizon around a single point whose coordinates are given with the 'coord' "
-"option. The horizon height (in radians). 2. Computes one or more raster maps"
-" of the horizon height in a single direction. The input for this is the "
-"angle (in degrees), which is measured counterclockwise with east=0, north=90"
-" etc. The output is the horizon height in radians."
+msgid "The module has two different modes of operation: 1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction. The input for this is the angle (in degrees), which is measured counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
 msgstr ""
 #: ../raster/r.horizon/main.c:203
@@ -29499,33 +28506,23 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:237
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer around the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer around the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:245
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer eastward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer eastward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:253
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer westward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer westward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:261
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer northward the present"
-" region"
+msgid "For horizon rasters, read from the DEM an extra buffer northward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:269
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer southward the present"
-" region"
+msgid "For horizon rasters, read from the DEM an extra buffer southward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:277
@@ -29557,8 +28554,7 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:355
-msgid ""
-"Note: In latitude-longitude coordinate system specify buffers in degree unit"
+msgid "Note: In latitude-longitude coordinate system specify buffers in degree unit"
 msgstr ""
 #: ../raster/r.horizon/main.c:368
@@ -29647,9 +28643,7 @@
 msgstr ""
 #: ../raster/r.out.ascii/main.c:86
-msgid ""
-"Number of values printed before wrapping a line (only SURFER or MODFLOW "
-"format)"
+msgid "Number of values printed before wrapping a line (only SURFER or MODFLOW format)"
 msgstr ""
 #: ../raster/r.out.ascii/main.c:91
@@ -29751,10 +28745,7 @@
 msgstr ""
 #: ../raster/r.walk/main.c:183
-msgid ""
-"Creates a raster map showing the anisotropic cumulative cost of moving "
-"between different geographic locations on an input raster map whose cell "
-"category values represent cost."
+msgid "Creates a raster map showing the anisotropic cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
 msgstr ""
 #: ../raster/r.walk/main.c:193
@@ -30360,8 +29351,7 @@
 msgstr ""
 #: ../raster/r.proj/main.c:219
-msgid ""
-"Print input map's bounds in the current projection and exit (shell style)"
+msgid "Print input map's bounds in the current projection and exit (shell style)"
 msgstr ""
 #: ../raster/r.proj/main.c:254
@@ -30484,9 +29474,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:126
-msgid ""
-"Name of location to create or to read projection from for GCPs "
-"transformation"
+msgid "Name of location to create or to read projection from for GCPs transformation"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:143
@@ -30498,8 +29486,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:152
-msgid ""
-"Zero-padding of band number by filling with leading zeros up to given number"
+msgid "Zero-padding of band number by filling with leading zeros up to given number"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:153
@@ -30523,9 +29510,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:220
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not"
-" import the raster file."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the raster file."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:225
@@ -30545,8 +29530,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:265
-msgid ""
-"The number of digits for band numbering must be equal or greater than 0"
+msgid "The number of digits for band numbering must be equal or greater than 0"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:284
@@ -30561,9 +29545,7 @@
 #: ../raster/r.in.gdal/main.c:337
 #, c-format
-msgid ""
-"Input seems to be NOAA/AVHRR data which needs to be georeferenced with thin "
-"plate spline transformation (%s or %s)."
+msgid "Input seems to be NOAA/AVHRR data which needs to be georeferenced with thin plate spline transformation (%s or %s)."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:356 ../raster/r.in.gdal/main.c:703
@@ -30573,22 +29555,15 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:376
-msgid ""
-"Input raster map is flipped or rotated - cannot import. You may use "
-"'gdalwarp' to transform the map to North-up."
+msgid "Input raster map is flipped or rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:417
-msgid ""
-"Map bounds have been constrained to geographic coordinates. You will almost "
-"certainly want to check map bounds and resolution with r.info and reset them"
-" with r.region before going any further."
+msgid "Map bounds have been constrained to geographic coordinates. You will almost certainly want to check map bounds and resolution with r.info and reset them with r.region before going any further."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:458 ../raster/r.external/proj.c:18
-msgid ""
-"Unable to convert input raster map projection information to GRASS format "
-"for checking"
+msgid "Unable to convert input raster map projection information to GRASS format for checking"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:491 ../raster/r.external/proj.c:47
@@ -30600,9 +29575,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:560 ../raster/r.external/proj.c:111
-msgid ""
-"Consider generating a new location from the input dataset using the "
-"'location' parameter.\n"
+msgid "Consider generating a new location from the input dataset using the 'location' parameter.\n"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:584
@@ -30654,9 +29627,7 @@
 #: ../raster/r.in.gdal/main.c:859
 #, c-format
-msgid ""
-"The target for the output group <%s> has been set to location <%s>, mapset "
-"<PERMANENT>."
+msgid "The target for the output group <%s> has been set to location <%s>, mapset <PERMANENT>."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:930
@@ -30742,9 +29713,7 @@
 msgstr ""
 #: ../raster/r.topmodel/main.c:94
-msgid ""
-"Must be clipped to the catchment boundary. Used for generating "
-"outtopidxstats"
+msgid "Must be clipped to the catchment boundary. Used for generating outtopidxstats"
 msgstr ""
 #: ../raster/r.topmodel/main.c:96 ../raster/r.topmodel/main.c:106
@@ -30879,10 +29848,7 @@
 msgstr ""
 #: ../raster/r.sunhours/main.c:77
-msgid ""
-"Solar elevation: the angle between the direction of the geometric center of "
-"the sun's apparent disk and the (idealized) horizon. Solar azimuth: the "
-"angle from due north in clockwise direction."
+msgid "Solar elevation: the angle between the direction of the geometric center of the sun's apparent disk and the (idealized) horizon. Solar azimuth: the angle from due north in clockwise direction."
 msgstr ""
 #: ../raster/r.sunhours/main.c:83
@@ -31228,9 +30194,7 @@
 #: ../raster/r.regression.line/main.c:65
 #: ../raster/r.regression.multi/main.c:157
-msgid ""
-"ASCII file for storing regression coefficients (output to screen if file not"
-" specified)."
+msgid "ASCII file for storing regression coefficients (output to screen if file not specified)."
 msgstr ""
 #: ../raster/r.param.scale/main.c:42
@@ -31254,9 +30218,7 @@
 msgstr ""
 #: ../raster/r.param.scale/interface.c:60
-msgid ""
-"Uses a multi-scale approach by taking fitting quadratic parameters to any "
-"size window (via least squares)."
+msgid "Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
 msgstr ""
 #: ../raster/r.param.scale/interface.c:78
@@ -31512,9 +30474,7 @@
 msgstr ""
 #: ../raster/r.li/r.li.patchdensity/main.c:50
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour "
-"algorithm"
+msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../raster/r.li/r.li.pielou/pielou.c:45
@@ -31601,14 +30561,11 @@
 msgstr ""
 #: ../raster/r.li/r.li.patchnum/main.c:49
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour "
-"algorithm."
+msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
 msgstr ""
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:47
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:68
@@ -31616,9 +30573,7 @@
 msgstr ""
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:69
-msgid ""
-"It can be integer, double or float; it will be changed in function of map "
-"type"
+msgid "It can be integer, double or float; it will be changed in function of map type"
 msgstr ""
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:74
@@ -31634,9 +30589,7 @@
 msgstr ""
 #: ../raster/r.li/r.li.mps/mps.c:51
-msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
+msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../raster/r.li/r.li.shannon/shannon.c:45
@@ -31657,9 +30610,7 @@
 msgstr ""
 #: ../raster/r.category/main.c:55
-msgid ""
-"Manages category values and labels associated with user-specified raster map"
-" layers."
+msgid "Manages category values and labels associated with user-specified raster map layers."
 msgstr ""
 #: ../raster/r.category/main.c:69
@@ -31728,10 +30679,7 @@
 msgstr ""
 #: ../raster/r.his/main.c:73
-msgid ""
-"Generates red, green and blue (RGB) raster map layers combining hue, "
-"intensity and saturation (HIS) values from user-specified input raster map "
-"layers."
+msgid "Generates red, green and blue (RGB) raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
 msgstr ""
 #: ../raster/r.his/main.c:103
@@ -31776,9 +30724,7 @@
 msgstr ""
 #: ../raster/r.to.rast3/main.c:230
-msgid ""
-"The 2D and 3D region settings are different. Using the 3D region settings to"
-" adjust the 2D region."
+msgid "The 2D and 3D region settings are different. Using the 3D region settings to adjust the 2D region."
 msgstr ""
 #: ../raster/r.to.rast3/main.c:262
@@ -31803,10 +30749,7 @@
 msgstr ""
 #: ../raster/r.resamp.rst/main.c:151
-msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
+msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
 msgstr ""
 #: ../raster/r.resamp.rst/main.c:162
@@ -31975,9 +30918,7 @@
 msgstr ""
 #: ../raster/r.stats.zonal/main.c:105
-msgid ""
-"Calculates category or object oriented statistics (accumulator-based "
-"statistics)."
+msgid "Calculates category or object oriented statistics (accumulator-based statistics)."
 msgstr ""
 #: ../raster/r.stats.zonal/main.c:115 ../raster/r.statistics/main.c:69
@@ -32083,9 +31024,8 @@
 msgstr ""
 #: ../raster/r.relief/main.c:316 ../raster/r.series/main.c:386
-#: ../raster/r.series.accumulate/main.c:318
-#: ../raster/r.slope.aspect/main.c:544 ../raster/r.patch/main.c:140
-#: ../raster/r.series.interp/main.c:339
+#: ../raster/r.series.accumulate/main.c:318 ../raster/r.slope.aspect/main.c:544
+#: ../raster/r.patch/main.c:140 ../raster/r.series.interp/main.c:339
 msgid "Percent complete..."
 msgstr ""
@@ -32110,15 +31050,11 @@
 msgstr ""
 #: ../raster/r.neighbors/main.c:175
-msgid ""
-"Makes each cell category value a function of the category values assigned to"
-" the cells around it, and stores new cell values in an output raster map "
-"layer."
+msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
 msgstr ""
 #: ../raster/r.neighbors/main.c:185
-msgid ""
-"Name of an input raster map to select the cells which should be processed"
+msgid "Name of an input raster map to select the cells which should be processed"
 msgstr ""
 #: ../raster/r.neighbors/main.c:206 ../raster/r.neighbors/main.c:214
@@ -32162,15 +31098,12 @@
 #: ../raster/r.neighbors/main.c:329
 #, c-format
-msgid ""
-"Method %s not compatible with weighing window, using weight mask instead"
+msgid "Method %s not compatible with weighing window, using weight mask instead"
 msgstr ""
 #: ../raster/r.neighbors/main.c:337
 #, c-format
-msgid ""
-"Method %s not compatible with Gaussian filter, using unweighed version "
-"instead"
+msgid "Method %s not compatible with Gaussian filter, using unweighed version instead"
 msgstr ""
 #: ../raster/r.neighbors/main.c:386
@@ -32179,16 +31112,12 @@
 msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:66
-msgid ""
-"Unable to calculate sun position in un-projected locations. Specify "
-"sunposition directly."
+msgid "Unable to calculate sun position in un-projected locations. Specify sunposition directly."
 msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:88
 #, c-format
-msgid ""
-"Specified point %f, %f outside of current region, is that intended? Anyway, "
-"it will be used."
+msgid "Specified point %f, %f outside of current region, is that intended? Anyway, it will be used."
 msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:98 ../raster/r.latlong/main.c:101
@@ -32208,14 +31137,11 @@
 msgstr ""
 #: ../raster/r.sunmask/main.c:120
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map."
+msgid "Calculates cast shadow areas from sun position and elevation raster map."
 msgstr ""
 #: ../raster/r.sunmask/main.c:121
-msgid ""
-"Either exact sun position (A) is specified, or date/time to calculate the "
-"sun position (B) by r.sunmask itself."
+msgid "Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
 msgstr ""
 #: ../raster/r.sunmask/main.c:135
@@ -32300,9 +31226,7 @@
 msgstr ""
 #: ../raster/r.sunmask/main.c:282
-msgid ""
-"Neither sun position nor east/north, date/time/timezone definition are "
-"complete"
+msgid "Neither sun position nor east/north, date/time/timezone definition are complete"
 msgstr ""
 #: ../raster/r.sunmask/main.c:286
@@ -32311,9 +31235,7 @@
 msgstr ""
 #: ../raster/r.sunmask/main.c:291
-msgid ""
-"Using user defined sun azimuth, altitude settings (ignoring eventual other "
-"values)"
+msgid "Using user defined sun azimuth, altitude settings (ignoring eventual other values)"
 msgstr ""
 #: ../raster/r.sunmask/main.c:399
@@ -32374,9 +31296,7 @@
 msgstr ""
 #: ../raster/r.colors/edit_colors.c:83
-msgid ""
-"Input map names can be defined in an input file in case a large amount of "
-"maps must be specified. This option is mutual exclusive to the map option."
+msgid "Input map names can be defined in an input file in case a large amount of maps must be specified. This option is mutual exclusive to the map option."
 msgstr ""
 #: ../raster/r.colors/edit_colors.c:110
@@ -32519,8 +31439,7 @@
 msgstr ""
 #: ../raster/r.drain/main.c:113
-msgid ""
-"Traces a flow through an elevation model or cost surface on a raster map."
+msgid "Traces a flow through an elevation model or cost surface on a raster map."
 msgstr ""
 #: ../raster/r.drain/main.c:116
@@ -32564,9 +31483,7 @@
 msgstr ""
 #: ../raster/r.drain/main.c:163
-msgid ""
-"The input raster map is a cost surface (direction surface must also be "
-"specified)"
+msgid "The input raster map is a cost surface (direction surface must also be specified)"
 msgstr ""
 #: ../raster/r.drain/main.c:175
@@ -32579,16 +31496,12 @@
 #: ../raster/r.drain/main.c:183
 #, c-format
-msgid ""
-"Direction raster map <%s> not specified, if direction flag is on, a "
-"direction raster must be given"
+msgid "Direction raster map <%s> not specified, if direction flag is on, a direction raster must be given"
 msgstr ""
 #: ../raster/r.drain/main.c:190
 #, c-format
-msgid ""
-"Direction raster map <%s> should not be specified for Surface/Hydrology "
-"drains"
+msgid "Direction raster map <%s> should not be specified for Surface/Hydrology drains"
 msgstr ""
 #: ../raster/r.drain/main.c:209
@@ -32667,9 +31580,7 @@
 #: ../raster/r.texture/h_measure.c:141
 #, c-format
-msgid ""
-"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
-"map"
+msgid "Too many categories (found: %i, max: %i). Try to rescale or reclassify the map"
 msgstr ""
 #: ../raster/r.texture/main.c:68
@@ -32722,9 +31633,7 @@
 msgstr ""
 #: ../raster/r.texture/main.c:172
-msgid ""
-"The distance between two samples must be smaller than the size of the moving"
-" window"
+msgid "The distance between two samples must be smaller than the size of the moving window"
 msgstr ""
 #: ../raster/r.texture/main.c:193
@@ -32739,20 +31648,15 @@
 msgstr[1] ""
 #: ../raster/r.series/main.c:141
-msgid ""
-"Makes each output cell value a function of the values assigned to the "
-"corresponding cells in the input raster map layers."
+msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
 msgstr ""
 #: ../raster/r.series/main.c:150
-msgid ""
-"Input file with one raster map name and optional one weight per line, field "
-"separator between name and weight is |"
+msgid "Input file with one raster map name and optional one weight per line, field separator between name and weight is |"
 msgstr ""
 #: ../raster/r.series/main.c:176
-msgid ""
-"Weighting factor for each input map, default value is 1.0 for each input map"
+msgid "Weighting factor for each input map, default value is 1.0 for each input map"
 msgstr ""
 #: ../raster/r.series/main.c:183 ../raster/r.series.accumulate/main.c:132
@@ -32830,9 +31734,7 @@
 msgstr ""
 #: ../raster/r.profile/main.c:103
-msgid ""
-"If units are not specified, current location units are used. Meters are used"
-" by default in geographic (latlon) locations."
+msgid "If units are not specified, current location units are used. Meters are used by default in geographic (latlon) locations."
 msgstr ""
 #: ../raster/r.profile/main.c:117
@@ -32917,9 +31819,7 @@
 msgstr ""
 #: ../raster/r.covar/main.c:54
-msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map "
-"layer(s)."
+msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
 msgstr ""
 #: ../raster/r.covar/main.c:61
@@ -32936,9 +31836,7 @@
 msgstr ""
 #: ../raster/r.out.vtk/main.c:73
-msgid ""
-"No input maps specified. You need to specify at least one input map or three"
-" vector maps or three rgb maps."
+msgid "No input maps specified. You need to specify at least one input map or three vector maps or three rgb maps."
 msgstr ""
 #: ../raster/r.out.vtk/main.c:131 ../raster/r.out.vtk/main.c:191
@@ -32960,8 +31858,7 @@
 msgstr ""
 #: ../raster/r.out.vtk/main.c:271
-msgid ""
-"Wrong vector maps. Maps should have the same type! Vector output not added!"
+msgid "Wrong vector maps. Maps should have the same type! Vector output not added!"
 msgstr ""
 #: ../raster/r.out.vtk/main.c:283
@@ -32977,8 +31874,7 @@
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:69
-msgid ""
-"Three (r,g,b) raster maps to create RGB values [redmap,greenmap,bluemap]"
+msgid "Three (r,g,b) raster maps to create RGB values [redmap,greenmap,bluemap]"
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:79
@@ -32994,8 +31890,7 @@
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:116
-msgid ""
-"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
+msgid "Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:122
@@ -33246,23 +32141,19 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:83
-msgid ""
-"depression map indicates all the locations in the current map window where"
+msgid "depression map indicates all the locations in the current map window where"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:84
-msgid ""
-"water accumulates and does not leave by the edge of the map. Lakes without"
+msgid "water accumulates and does not leave by the edge of the map. Lakes without"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:85
-msgid ""
-"outlet streams and sinkholes are examples of `depressions'.  If you wish to"
+msgid "outlet streams and sinkholes are examples of `depressions'.  If you wish to"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:86
-msgid ""
-"have a depression map, prepare a map where non-zero values indicate the"
+msgid "have a depression map, prepare a map where non-zero values indicate the"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:87
@@ -33270,8 +32161,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:88
-msgid ""
-"Hit <return> by itself for the next question if there is no depression map."
+msgid "Hit <return> by itself for the next question if there is no depression map."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:99
@@ -33282,14 +32172,11 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:101
-msgid ""
-"watershed basins.  The number of watershed basins is indirectly determined"
+msgid "watershed basins.  The number of watershed basins is indirectly determined"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:102
-msgid ""
-"by the `basin threshold' value.  The basin threshold is the area necessary "
-"for"
+msgid "by the `basin threshold' value.  The basin threshold is the area necessary for"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:103
@@ -33298,18 +32185,15 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:105
-msgid ""
-"`exterior drainage basins'.  An exterior drainage basin does not have any"
+msgid "`exterior drainage basins'.  An exterior drainage basin does not have any"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:106
-msgid ""
-"drainage basins flowing into it.  Interior drainage basin size is determined"
+msgid "drainage basins flowing into it.  Interior drainage basin size is determined"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:107
-msgid ""
-"by the surface flow going into stream segments between stream interceptions."
+msgid "by the surface flow going into stream segments between stream interceptions."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:108
@@ -33322,19 +32206,15 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:111
-msgid ""
-"(i.e., areas with low infiltration capacities will need smaller areas to"
+msgid "(i.e., areas with low infiltration capacities will need smaller areas to"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:112
-msgid ""
-"develop stream channels than neighboring areas with high infiltration "
-"rates)."
+msgid "develop stream channels than neighboring areas with high infiltration rates)."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:113
-msgid ""
-"The user can create a map layer with potential overland flow values, and"
+msgid "The user can create a map layer with potential overland flow values, and"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:114
@@ -33440,8 +32320,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:296
-msgid ""
-"ability to generate several variables in the Revised Universal Soil Loss"
+msgid "ability to generate several variables in the Revised Universal Soil Loss"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:297
@@ -33460,9 +32339,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:351
-msgid ""
-"where the value indicates the percent of disturbed (barren) land in that "
-"cell."
+msgid "where the value indicates the percent of disturbed (barren) land in that cell."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:352
@@ -33503,8 +32380,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:384
-msgid ""
-"that prevents the surface flow distance from getting too long.  Normally,"
+msgid "that prevents the surface flow distance from getting too long.  Normally,"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:385
@@ -33518,8 +32394,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:401
-msgid ""
-"slope length.  You may input a raster map indicating the locations of these"
+msgid "slope length.  You may input a raster map indicating the locations of these"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:402
@@ -33527,8 +32402,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:403
-msgid ""
-"Hit <return> by itself for the next question if there is no blocking map."
+msgid "Hit <return> by itself for the next question if there is no blocking map."
 msgstr ""
 #: ../raster/r.watershed/shed/file_in.c:15
@@ -33619,8 +32493,7 @@
 msgid "Name of input raster map percent of disturbed land"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:97
-#: ../raster/r.watershed/front/main.c:122
+#: ../raster/r.watershed/front/main.c:97 ../raster/r.watershed/front/main.c:122
 msgid "For USLE"
 msgstr ""
@@ -33629,9 +32502,7 @@
 msgstr ""
 #: ../raster/r.watershed/front/main.c:106
-msgid ""
-"For USLE. All non-NULL and non-zero cells are considered as blocking "
-"terrain."
+msgid "For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
 msgstr ""
 #: ../raster/r.watershed/front/main.c:113
@@ -33723,9 +32594,7 @@
 msgstr ""
 #: ../raster/r.watershed/front/main.c:223
-msgid ""
-"Only needed if memory requirements exceed available RAM; see manual on how "
-"to calculate memory requirements"
+msgid "Only needed if memory requirements exceed available RAM; see manual on how to calculate memory requirements"
 msgstr ""
 #: ../raster/r.watershed/front/main.c:228
@@ -33909,8 +32778,7 @@
 #: ../raster/r.watershed/ram/do_cum.c:480
 #, c-format
 msgid "MFD: A * path already processed when distributing flow: %d of %d cell"
-msgid_plural ""
-"MFD: A * path already processed when distributing flow: %d of %d cells"
+msgid_plural "MFD: A * path already processed when distributing flow: %d of %d cells"
 msgstr[0] ""
 msgstr[1] ""
@@ -34027,14 +32895,11 @@
 msgstr ""
 #: ../raster/r.to.rast3elev/main.c:427
-msgid ""
-"The 2D and 3D region settings are different. I will use the 3D region "
-"settings to adjust the 2D region."
+msgid "The 2D and 3D region settings are different. I will use the 3D region settings to adjust the 2D region."
 msgstr ""
 #: ../raster/r.grow.distance/main.c:156
-msgid ""
-"Generates a raster map containing distances to nearest raster features."
+msgid "Generates a raster map containing distances to nearest raster features."
 msgstr ""
 #: ../raster/r.grow.distance/main.c:163
@@ -34344,9 +33209,7 @@
 msgstr ""
 #: ../raster/r.flow/main.c:425
-msgid ""
-"Computes flowlines, flowpath lengths, and flowaccumulation (contributing "
-"areas) from a elevation raster map."
+msgid "Computes flowlines, flowpath lengths, and flowaccumulation (contributing areas) from a elevation raster map."
 msgstr ""
 #: ../raster/r.flow/main.c:435 ../raster/r.flow/main.c:441
@@ -34401,9 +33264,7 @@
 msgstr ""
 #: ../raster/r.flow/main.c:555
-msgid ""
-"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
-"calculating flow accumulation."
+msgid "lat/long projection not supported by r.flow. Please use 'r.watershed' for calculating flow accumulation."
 msgstr ""
 #: ../raster/r.flow/mem.c:40
@@ -34493,8 +33354,7 @@
 msgstr ""
 #: ../raster/r.in.lidar/main.c:116
-msgid ""
-"Creates a raster map from LAS LiDAR points using univariate statistics."
+msgid "Creates a raster map from LAS LiDAR points using univariate statistics."
 msgstr ""
 #: ../raster/r.in.lidar/main.c:130
@@ -34558,8 +33418,7 @@
 msgstr ""
 #: ../raster/r.in.lidar/main.c:182
-msgid ""
-"The scale for Z is applied beforehand, the range filter for Z afterwards"
+msgid "The scale for Z is applied beforehand, the range filter for Z afterwards"
 msgstr ""
 #: ../raster/r.in.lidar/main.c:191
@@ -34599,9 +33458,7 @@
 msgstr ""
 #: ../raster/r.in.lidar/main.c:293
-msgid ""
-"Set computation region to match the 2D extent and resolution of the newly "
-"created new raster map"
+msgid "Set computation region to match the 2D extent and resolution of the newly created new raster map"
 msgstr ""
 #: ../raster/r.in.lidar/main.c:317
@@ -34621,9 +33478,7 @@
 msgstr ""
 #: ../raster/r.in.lidar/main.c:332
-msgid ""
-"For getting values from base raster, use its actual resolution instead of "
-"computational region resolution"
+msgid "For getting values from base raster, use its actual resolution instead of computational region resolution"
 msgstr ""
 #: ../raster/r.in.lidar/main.c:355
@@ -34646,8 +33501,7 @@
 msgstr ""
 #: ../raster/r.in.lidar/main.c:419
-msgid ""
-"First file's projection checked, checking projection of the other files..."
+msgid "First file's projection checked, checking projection of the other files..."
 msgstr ""
 #: ../raster/r.in.lidar/main.c:457
@@ -34671,9 +33525,7 @@
 #: ../raster/r.in.lidar/main.c:590
 #, c-format
-msgid ""
-"Unable to process the hole map at once. Please set the '%s' option to some "
-"value lower than 100."
+msgid "Unable to process the hole map at once. Please set the '%s' option to some value lower than 100."
 msgstr ""
 #: ../raster/r.in.lidar/main.c:610
@@ -34725,9 +33577,7 @@
 msgstr ""
 #: ../raster/r.reclass/main.c:54
-msgid ""
-"Creates a new raster map whose category values are based upon a "
-"reclassification of the categories in an existing raster map."
+msgid "Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
 msgstr ""
 #: ../raster/r.reclass/main.c:59
@@ -34863,9 +33713,7 @@
 #: ../raster/r.resamp.bspline/crosscorr.c:160
 #, c-format
-msgid ""
-"%d are too many cells, recommended are < 100 cells. The cross validation "
-"would take too much time."
+msgid "%d are too many cells, recommended are < 100 cells. The cross validation would take too much time."
 msgstr ""
 #: ../raster/r.resamp.bspline/crosscorr.c:169
@@ -34880,9 +33728,7 @@
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:85
-msgid ""
-"Performs bilinear or bicubic spline interpolation with Tykhonov "
-"regularization."
+msgid "Performs bilinear or bicubic spline interpolation with Tykhonov regularization."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:93
@@ -34894,14 +33740,11 @@
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:107
-msgid ""
-"Length of each spline step in the east-west direction. Default: 1.5 * ewres."
+msgid "Length of each spline step in the east-west direction. Default: 1.5 * ewres."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:115
-msgid ""
-"Length of each spline step in the north-south direction. Default: 1.5 * "
-"nsres."
+msgid "Length of each spline step in the north-south direction. Default: 1.5 * nsres."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:138
@@ -35128,9 +33971,7 @@
 msgstr ""
 #: ../raster/r.in.xyz/main.c:165
-msgid ""
-"Creates a raster map from an assemblage of many coordinates using univariate"
-" statistics."
+msgid "Creates a raster map from an assemblage of many coordinates using univariate statistics."
 msgstr ""
 #: ../raster/r.in.xyz/main.c:169
@@ -35142,9 +33983,7 @@
 msgstr ""
 #: ../raster/r.in.xyz/main.c:237
-msgid ""
-"If a separate value column is given, this option refers to the z-coordinate "
-"column to be filtered by the zrange option"
+msgid "If a separate value column is given, this option refers to the z-coordinate column to be filtered by the zrange option"
 msgstr ""
 #: ../raster/r.in.xyz/main.c:248
@@ -35195,14 +34034,11 @@
 #: ../raster/r.in.xyz/main.c:534
 #, c-format
-msgid ""
-"Unable to process the hole map at once. Please set the %s option to some "
+msgid "Unable to process the hole map at once. Please set the %s option to some value lower than 100."
 msgstr ""
 #: ../raster/r.in.xyz/main.c:587
-msgid ""
-"If input is not from a file it is only possible to perform a single pass."
+msgid "If input is not from a file it is only possible to perform a single pass."
 msgstr ""
 #: ../raster/r.in.xyz/main.c:599
@@ -35372,23 +34208,17 @@
 #: ../raster/r.stats/main.c:303
 #, c-format
-msgid ""
-"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
-"will be ignored."
+msgid "Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option will be ignored."
 msgstr ""
 #: ../raster/r.stats/main.c:319
 #, c-format
-msgid ""
-"Cats for raster map <%s> are either missing or have no explicit labels. "
-"Using %s=%d."
+msgid "Cats for raster map <%s> are either missing or have no explicit labels. Using %s=%d."
 msgstr ""
 #: ../raster/r.stats/main.c:325
 #, c-format
-msgid ""
-"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s'"
-" option"
+msgid "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' option"
 msgstr ""
 #: ../raster/r.stats/raw_stats.c:118
@@ -35418,11 +34248,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:220
-msgid ""
-"Generates three, or four raster map layers showing the base (perpendicular) "
-"rate of spread (ROS), the maximum (forward) ROS, the direction of the "
-"maximum ROS, and optionally the maximum potential spotting distance for fire"
-" spread simulation."
+msgid "Generates three, or four raster map layers showing the base (perpendicular) rate of spread (ROS), the maximum (forward) ROS, the direction of the maximum ROS, and optionally the maximum potential spotting distance for fire spread simulation."
 msgstr ""
 #: ../raster/r.ros/main.c:227
@@ -35430,10 +34256,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:229
-msgid ""
-"Name of an existing raster map layer in the user's current mapset search "
-"path containing the standard fuel models defined by the USDA Forest Service."
-" Valid values are 1-13; other numbers are recognized as barriers by r.ros."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the standard fuel models defined by the USDA Forest Service. Valid values are 1-13; other numbers are recognized as barriers by r.ros."
 msgstr ""
 #: ../raster/r.ros/main.c:238
@@ -35441,10 +34264,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:240 ../raster/r.spread/main.c:205
-msgid ""
-"path containing the 1-hour (<.25\") fuel moisture (percentage content "
-"multiplied by 100)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the 1-hour (<.25\") fuel moisture (percentage content multiplied by 100)."
 msgstr ""
 #: ../raster/r.ros/main.c:248
@@ -35452,10 +34272,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:250
-msgid ""
-"path containing the 10-hour (.25-1\") fuel moisture (percentage content "
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the 10-hour (.25-1\") fuel moisture (percentage content multiplied by 100)."
 msgstr ""
 #: ../raster/r.ros/main.c:258
@@ -35463,10 +34280,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:260
-msgid ""
-"path containing the 100-hour (1-3\") fuel moisture (percentage content "
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the 100-hour (1-3\") fuel moisture (percentage content multiplied by 100)."
 msgstr ""
 #: ../raster/r.ros/main.c:267
@@ -35474,10 +34288,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:269
-msgid ""
-"path containing live (herbaceous) fuel moisture (percentage content "
+msgid "Name of an existing raster map layer in the user's current mapset search path containing live (herbaceous) fuel moisture (percentage content multiplied by 100)."
 msgstr ""
 #: ../raster/r.ros/main.c:277
@@ -35485,10 +34296,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:279 ../raster/r.spread/main.c:193
-msgid ""
-"path containing wind velocities at half of the average flame height "
-"(feet/minute)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing wind velocities at half of the average flame height (feet/minute)."
 msgstr ""
 #: ../raster/r.ros/main.c:287
@@ -35496,9 +34304,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:289
-msgid ""
-"path containing wind direction, clockwise from north (degree)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing wind direction, clockwise from north (degree)."
 msgstr ""
 #: ../raster/r.ros/main.c:297
@@ -35506,9 +34312,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:299
-msgid ""
-"path containing topographic slope (degree)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing topographic slope (degree)."
 msgstr ""
 #: ../raster/r.ros/main.c:307
@@ -35516,10 +34320,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:309
-msgid ""
-"path containing topographic aspect, counterclockwise from east (GRASS "
-"convention) in degrees."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing topographic aspect, counterclockwise from east (GRASS convention) in degrees."
 msgstr ""
 #: ../raster/r.ros/main.c:317
@@ -35527,10 +34328,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:319
-msgid ""
-"path containing elevation (meters). Option is required from spotting "
-"distance computation (when spotting_distance option is provided)"
+msgid "Name of an existing raster map layer in the user's current mapset search path containing elevation (meters). Option is required from spotting distance computation (when spotting_distance option is provided)"
 msgstr ""
 #: ../raster/r.ros/main.c:328
@@ -35562,29 +34360,21 @@
 msgstr ""
 #: ../raster/r.ros/main.c:354
-msgid ""
-"The maximal potential spotting distance (requires elevation raster map to be"
-" provided)."
+msgid "The maximal potential spotting distance (requires elevation raster map to be provided)."
 msgstr ""
 #: ../raster/r.ros/main.c:373
-msgid ""
-"No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h "
-"moisture layers is required."
+msgid "No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h moisture layers is required."
 msgstr ""
 #: ../raster/r.ros/main.c:397
 #, c-format
-msgid ""
-"A wind direction layer should be given if the wind velocity layer <%s> has "
-"been given"
+msgid "A wind direction layer should be given if the wind velocity layer <%s> has been given"
 msgstr ""
 #: ../raster/r.ros/main.c:402
 #, c-format
-msgid ""
-"A wind velocity layer should be given if the wind direction layer <%s> has "
-"been given"
+msgid "A wind velocity layer should be given if the wind direction layer <%s> has been given"
 msgstr ""
 #: ../raster/r.ros/main.c:416
@@ -35644,14 +34434,11 @@
 msgstr ""
 #: ../raster/r.volume/main.c:81
-msgid ""
-"Optionally produces a GRASS vector points map containing the calculated "
-"centroids of these clumps."
+msgid "Optionally produces a GRASS vector points map containing the calculated centroids of these clumps."
 msgstr ""
 #: ../raster/r.volume/main.c:86
-msgid ""
-"Name of input raster map representing data that will be summed within clumps"
+msgid "Name of input raster map representing data that will be summed within clumps"
 msgstr ""
 #: ../raster/r.volume/main.c:92
@@ -35659,9 +34446,7 @@
 msgstr ""
 #: ../raster/r.volume/main.c:93
-msgid ""
-"Preferably the output of r.clump. If no clump map is given than MASK is "
-"used."
+msgid "Preferably the output of r.clump. If no clump map is given than MASK is used."
 msgstr ""
 #: ../raster/r.volume/main.c:99
@@ -35681,9 +34466,7 @@
 msgstr ""
 #: ../raster/r.volume/main.c:143
-msgid ""
-"No MASK found. If no clump map is given than the MASK is required. You need "
-"to define a clump raster map or create a MASK by r.mask command."
+msgid "No MASK found. If no clump map is given than the MASK is required. You need to define a clump raster map or create a MASK by r.mask command."
 msgstr ""
 #: ../raster/r.volume/main.c:145
@@ -35737,8 +34520,7 @@
 msgstr ""
 #: ../raster/r.sim/r.sim.water/main.c:120
-msgid ""
-"Overland flow hydrologic simulation using path sampling method (SIMWE)."
+msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
 msgstr ""
 #: ../raster/r.sim/r.sim.water/main.c:127
@@ -35805,9 +34587,7 @@
 #: ../raster/r.sim/r.sim.water/main.c:222
 #: ../raster/r.sim/r.sim.sediment/main.c:211
-msgid ""
-"Name for sampling points output text file. For each observation vector point"
-" the time series of sediment transport is stored."
+msgid "Name for sampling points output text file. For each observation vector point the time series of sediment transport is stored."
 msgstr ""
 #: ../raster/r.sim/r.sim.water/main.c:230
@@ -35856,9 +34636,7 @@
 #: ../raster/r.sim/r.sim.water/main.c:306
 #: ../raster/r.sim/r.sim.sediment/main.c:270
-msgid ""
-"The same seed can be used to obtain same results or random seed can be "
-"generated by other means."
+msgid "The same seed can be used to obtain same results or random seed can be generated by other means."
 msgstr ""
 #: ../raster/r.sim/r.sim.water/main.c:312
@@ -35868,9 +34646,7 @@
 #: ../raster/r.sim/r.sim.water/main.c:314
 #: ../raster/r.sim/r.sim.sediment/main.c:278
-msgid ""
-"Automatically generates random seed for random number generator (use when "
-"you don't want to provide the seed option)"
+msgid "Automatically generates random seed for random number generator (use when you don't want to provide the seed option)"
 msgstr ""
 #: ../raster/r.sim/r.sim.water/main.c:322
@@ -35920,9 +34696,7 @@
 msgstr ""
 #: ../raster/r.sim/r.sim.sediment/main.c:121
-msgid ""
-"Sediment transport and erosion/deposition simulation using path sampling "
-"method (SIMWE)."
+msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
 msgstr ""
 #: ../raster/r.sim/r.sim.sediment/main.c:128
@@ -35946,8 +34720,7 @@
 msgstr ""
 #: ../raster/r.sim/r.sim.sediment/main.c:184
-msgid ""
-"Name for output transport limited erosion-deposition raster map [kg/m2s]"
+msgid "Name for output transport limited erosion-deposition raster map [kg/m2s]"
 msgstr ""
 #: ../raster/r.sim/r.sim.sediment/main.c:191
@@ -35970,16 +34743,13 @@
 msgid "You are not outputting any raster or site files"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:411
-#: ../raster/r.sim/simlib/hydro.c:465
+#: ../raster/r.sim/r.sim.sediment/main.c:411 ../raster/r.sim/simlib/hydro.c:465
 msgid "Cannot write raster maps"
 msgstr ""
 #: ../raster/r.sim/simlib/input.c:307
 #, c-format
-msgid ""
-"Raster map <%s> not found, and manin_val undefined, choose one to be allowed"
-" to process"
+msgid "Raster map <%s> not found, and manin_val undefined, choose one to be allowed to process"
 msgstr ""
 #: ../raster/r.sim/simlib/input.c:420
@@ -36065,9 +34835,7 @@
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:84
-msgid ""
-"Makes each output cell value a accumulationfunction of the values assigned "
-"to the corresponding cells in the input raster map layers."
+msgid "Makes each output cell value a accumulationfunction of the values assigned to the corresponding cells in the input raster map layers."
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:90
@@ -36087,14 +34855,11 @@
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:121
-msgid ""
-"The raster map specifying the lower accumulation limit, also called baseline"
+msgid "The raster map specifying the lower accumulation limit, also called baseline"
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:126
-msgid ""
-"The raster map specifying the upper accumulation limit, also called cutoff. "
-"Only applied to BEDD computation."
+msgid "The raster map specifying the upper accumulation limit, also called cutoff. Only applied to BEDD computation."
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:139
@@ -36196,9 +34961,7 @@
 msgstr ""
 #: ../raster/r.out.gdal/main.c:220
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
-"Not supported by all output format drivers."
+msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. Not supported by all output format drivers."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:230
@@ -36206,9 +34969,7 @@
 msgstr ""
 #: ../raster/r.out.gdal/main.c:232
-msgid ""
-"If given, the nodata value is always written to metadata even if there are "
-"no NULL cells in the input band (enhances output compatibility)."
+msgid "If given, the nodata value is always written to metadata even if there are no NULL cells in the input band (enhances output compatibility)."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:264
@@ -36228,9 +34989,7 @@
 #: ../raster/r.out.gdal/main.c:288
 #, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:293
@@ -36258,23 +35017,17 @@
 #: ../raster/r.out.gdal/main.c:455
 #, c-format
-msgid ""
-"Precision loss: Raster map <%s> of type %s to be exported as %s. This can be"
-" avoided by using %s."
+msgid "Precision loss: Raster map <%s> of type %s to be exported as %s. This can be avoided by using %s."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:466
 #, c-format
-msgid ""
-"Precision loss: The range of <%s> can not be accurately preserved with GDAL "
-"datatype Float32. This can be avoided by exporting to Int32 or Float64."
+msgid "Precision loss: The range of <%s> can not be accurately preserved with GDAL datatype Float32. This can be avoided by exporting to Int32 or Float64."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:474
 #, c-format
-msgid ""
-"Precision loss: Float32 can not preserve the DCELL precision of raster <%s>."
-" This can be avoided by using Float64"
+msgid "Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. This can be avoided by using Float64"
 msgstr ""
 #: ../raster/r.out.gdal/main.c:483
@@ -36386,10 +35139,7 @@
 #: ../raster/r.out.gdal/main.c:791 ../raster/r.out.gdal/main.c:804
 #: ../raster/r.out.gdal/main.c:819
 #, c-format
-msgid ""
-"Mismatch between metadata nodata value and actual nodata value in exported "
-"raster: specified nodata value %g gets converted to %d by selected GDAL "
-"datatype."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %d by selected GDAL datatype."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:767 ../raster/r.out.gdal/main.c:794
@@ -36405,10 +35155,7 @@
 #: ../raster/r.out.gdal/main.c:833
 #, c-format
-msgid ""
-"raster: specified nodata value %g gets converted to %g by selected GDAL "
-"datatype."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %g by selected GDAL datatype."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:836
@@ -36420,8 +35167,7 @@
 msgid "Failed to set raster attribute table"
 msgstr ""
-#: ../raster/r.out.gdal/export_band.c:52
-#: ../raster/r.out.gdal/export_band.c:344
+#: ../raster/r.out.gdal/export_band.c:52 ../raster/r.out.gdal/export_band.c:344
 msgid "Unable to allocate buffer for reading raster map"
 msgstr ""
@@ -36432,32 +35178,22 @@
 #: ../raster/r.out.gdal/export_band.c:161
 #, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %d will"
-" be used to represent no-data values in the input map. You can specify a "
-"nodata value with the %s option."
+msgid "Input raster map contains cells with NULL-value (no-data). The value %d will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:166
 #, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %g will"
+msgid "Input raster map contains cells with NULL-value (no-data). The value %g will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:176
 #, c-format
-msgid ""
-"The default nodata value is present in rasterband <%s> and would lead to "
-"data loss. Please specify a custom nodata value with the %s parameter."
+msgid "The default nodata value is present in rasterband <%s> and would lead to data loss. Please specify a custom nodata value with the %s parameter."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:183
 #, c-format
-msgid ""
-"The user given nodata value %g is present in rasterband <%s> and would lead "
-"to data loss. Please specify a different nodata value with the %s parameter."
+msgid "The user given nodata value %g is present in rasterband <%s> and would lead to data loss. Please specify a different nodata value with the %s parameter."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:228
@@ -36486,11 +35222,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:113
-msgid ""
-"Generates a raster map of the cumulative time of spread, given raster maps "
-"containing the rates of spread (ROS), the ROS directions and the spread "
-"origins. It optionally produces raster maps to contain backlink UTM "
-"coordinates for tracing spread paths. Usable for fire spread simulations."
+msgid "Generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins. It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths. Usable for fire spread simulations."
 msgstr ""
 #: ../raster/r.spread/main.c:127
@@ -36498,11 +35230,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:129
-msgid ""
-"path containing the ROS values in the directions perpendicular to maximum "
-"ROSes' (cm/minute). These ROSes are also the ones without the effect of "
-"directional factors."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the ROS values in the directions perpendicular to maximum ROSes' (cm/minute). These ROSes are also the ones without the effect of directional factors."
 msgstr ""
 #: ../raster/r.spread/main.c:141
@@ -36510,9 +35238,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:143
-msgid ""
-"path containing the maximum ROS values (cm/minute)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the maximum ROS values (cm/minute)."
 msgstr ""
 #: ../raster/r.spread/main.c:153
@@ -36520,10 +35246,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:155
-msgid ""
-"path containing directions of the maximum ROSes, clockwise from north "
-"(degree)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing directions of the maximum ROSes, clockwise from north (degree)."
 msgstr ""
 #: ../raster/r.spread/main.c:166
@@ -36531,10 +35254,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:168
-msgid ""
-"path containing starting locations of the spread phenomenon. Any positive "
-"integers in this map are recognized as starting sources (seeds)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing starting locations of the spread phenomenon. Any positive integers in this map are recognized as starting sources (seeds)."
 msgstr ""
 #: ../raster/r.spread/main.c:179
@@ -36542,9 +35262,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:181
-msgid ""
-"path containing the maximum potential spotting distances (meters)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the maximum potential spotting distances (meters)."
 msgstr ""
 #: ../raster/r.spread/main.c:191
@@ -36552,9 +35270,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:203
-msgid ""
-"Raster map containing fine fuel moisture of the cell receiving a spotting "
-"firebrand (%, required with -s)"
+msgid "Raster map containing fine fuel moisture of the cell receiving a spotting firebrand (%, required with -s)"
 msgstr ""
 #: ../raster/r.spread/main.c:215
@@ -36562,11 +35278,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:217
-msgid ""
-"An odd integer ranging 3 - 15 indicating the basic sampling window size "
-"within which all cells will be considered to see whether they will be "
-"reached by the current spread cell. The default number is 3 which means a "
-"3x3 window."
+msgid "An odd integer ranging 3 - 15 indicating the basic sampling window size within which all cells will be considered to see whether they will be reached by the current spread cell. The default number is 3 which means a 3x3 window."
 msgstr ""
 #: ../raster/r.spread/main.c:227
@@ -36574,12 +35286,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:229
-msgid ""
-"A decimal number ranging 0.0 - 1.0 indicating additional sampling cells will"
-" be considered to see whether they will be reached by the current spread "
-"cell. The closer to 1.0 the decimal number is, the longer the program will "
-"run and the higher the simulation accuracy will be. The default number is "
-"0.5."
+msgid "A decimal number ranging 0.0 - 1.0 indicating additional sampling cells will be considered to see whether they will be reached by the current spread cell. The closer to 1.0 the decimal number is, the longer the program will run and the higher the simulation accuracy will be. The default number is 0.5."
 msgstr ""
 #: ../raster/r.spread/main.c:241
@@ -36587,10 +35294,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:243
-msgid ""
-"A non-negative number specifying the initial time for the current spread "
-"simulation (minutes). This is useful when multiple phase simulation is "
-"conducted. The default time is 0."
+msgid "A non-negative number specifying the initial time for the current spread simulation (minutes). This is useful when multiple phase simulation is conducted. The default time is 0."
 msgstr ""
 #: ../raster/r.spread/main.c:252
@@ -36598,12 +35302,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:254
-msgid ""
-"A non-negative integer specifying the simulating duration time lag "
-"(minutes). The default is infinite, but the program will terminate when the "
-"current geographic region/mask has been filled. It also controls the "
-"computational time, the shorter the time lag, the faster the program will "
-"run."
+msgid "A non-negative integer specifying the simulating duration time lag (minutes). The default is infinite, but the program will terminate when the current geographic region/mask has been filled. It also controls the computational time, the shorter the time lag, the faster the program will run."
 msgstr ""
 #: ../raster/r.spread/main.c:266
@@ -36611,10 +35310,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:268
-msgid ""
-"path to be used as the background on which the \"live\" movement will be "
-"shown."
+msgid "Name of an existing raster map layer in the user's current mapset search path to be used as the background on which the \"live\" movement will be shown."
 msgstr ""
 #: ../raster/r.spread/main.c:279
@@ -36622,10 +35318,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:281
-msgid ""
-"Name of the new raster map layer to contain the results of the cumulative "
-"spread time needed for a phenomenon to reach each cell from the starting "
-"sources (minutes)."
+msgid "Name of the new raster map layer to contain the results of the cumulative spread time needed for a phenomenon to reach each cell from the starting sources (minutes)."
 msgstr ""
 #: ../raster/r.spread/main.c:291
@@ -36633,9 +35326,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:293
-msgid ""
-"Name of the new raster map layer to contain the results of backlink "
-"information in UTM easting coordinates for each cell."
+msgid "Name of the new raster map layer to contain the results of backlink information in UTM easting coordinates for each cell."
 msgstr ""
 #: ../raster/r.spread/main.c:303
@@ -36643,9 +35334,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:305
-msgid ""
-"information in UTM northing coordinates for each cell."
+msgid "Name of the new raster map layer to contain the results of backlink information in UTM northing coordinates for each cell."
 msgstr ""
 #: ../raster/r.spread/main.c:312
@@ -36653,9 +35342,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:314
-msgid ""
-"Display the 'live' simulation on screen. A graphics window must be opened "
-"and selected before using this option."
+msgid "Display the 'live' simulation on screen. A graphics window must be opened and selected before using this option."
 msgstr ""
 #: ../raster/r.spread/main.c:320
@@ -36667,11 +35354,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:326
-msgid ""
-"Designed to be used with output of previous run of r.spread when computing "
-"spread iteratively. The values in start raster map are considered as time. "
-"Allowed values in raster map are from zero to the value of init_time option."
-" If not enabled, init_time is used in the area of start raster map"
+msgid "Designed to be used with output of previous run of r.spread when computing spread iteratively. The values in start raster map are considered as time. Allowed values in raster map are from zero to the value of init_time option. If not enabled, init_time is used in the area of start raster map"
 msgstr ""
 #: ../raster/r.spread/main.c:502
@@ -36864,8 +35547,7 @@
 msgstr ""
 #: ../raster/r.thin/main.c:60
-msgid ""
-"Thins non-null cells that denote linear features in a raster map layer."
+msgid "Thins non-null cells that denote linear features in a raster map layer."
 msgstr ""
 #: ../raster/r.thin/main.c:72
@@ -36934,9 +35616,7 @@
 msgstr ""
 #: ../raster/r.surf.gauss/main.c:44
-msgid ""
-"Mean and standard deviation of gaussian deviates can be expressed by the "
-"user."
+msgid "Mean and standard deviation of gaussian deviates can be expressed by the user."
 msgstr ""
 #: ../raster/r.surf.gauss/main.c:51
@@ -37050,9 +35730,7 @@
 msgstr ""
 #: ../raster/r.lake/main.c:276
-msgid ""
-"Given water level at seed point is below earth surface. Increase water level"
-" or move seed point."
+msgid "Given water level at seed point is below earth surface. Increase water level or move seed point."
 msgstr ""
 #: ../raster/r.lake/main.c:355
@@ -37075,9 +35753,7 @@
 msgstr ""
 #: ../raster/r.spreadpath/main.c:92
-msgid ""
-"Recursively traces the least cost path backwards to cells from which the "
-"cumulative cost was determined."
+msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
 msgstr ""
 #: ../raster/r.spreadpath/main.c:98
@@ -37094,8 +35770,7 @@
 #: ../raster/r.spreadpath/main.c:161
 #, c-format
-msgid ""
-"eading the input map -%s- and -%s- and creating some temporary files..."
+msgid "eading the input map -%s- and -%s- and creating some temporary files..."
 msgstr ""
 #: ../raster/r.spreadpath/main.c:281
@@ -37151,8 +35826,7 @@
 msgstr ""
 #: ../raster/r.composite/main.c:76
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
+msgid "Combines red, green and blue raster maps into a single composite raster map."
 msgstr ""
 #: ../raster/r.composite/main.c:102
@@ -37186,9 +35860,7 @@
 msgstr ""
 #: ../raster/r.mode/main.c:59
-msgid ""
-"Finds the mode of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
+msgid "Finds the mode of values in a cover map within areas assigned the same category value in a user-specified base map."
 msgstr ""
 #: ../raster/r.mode/main.c:65
@@ -37220,28 +35892,21 @@
 msgid "Extended"
 msgstr ""
-#: ../raster/r.univar/r.univar_main.c:71
-#: ../raster/r.univar/r3.univar_main.c:67
+#: ../raster/r.univar/r.univar_main.c:71 ../raster/r.univar/r3.univar_main.c:67
 msgid "Table output format instead of standard output format"
 msgstr ""
 #: ../raster/r.univar/r.univar_main.c:76
-msgid ""
-"Use the native resolution and extent of the raster map, instead of the "
-"current region"
+msgid "Use the native resolution and extent of the raster map, instead of the current region"
 msgstr ""
 #: ../raster/r.univar/r.univar_main.c:110
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map."
+msgid "Calculates univariate statistics from the non-null cells of a raster map."
 msgstr ""
 #: ../raster/r.univar/r.univar_main.c:112
 #: ../raster/r.univar/r3.univar_main.c:105
-msgid ""
-"Statistics include number of cells counted, minimum and maximum cell values,"
-" range, arithmetic mean, population variance, standard deviation, "
-"coefficient of variation, and sum."
+msgid "Statistics include number of cells counted, minimum and maximum cell values, range, arithmetic mean, population variance, standard deviation, coefficient of variation, and sum."
 msgstr ""
 #: ../raster/r.univar/r.univar_main.c:123
@@ -37253,8 +35918,7 @@
 msgstr ""
 #: ../raster/r.univar/r3.univar_main.c:103
-msgid ""
-"Calculates univariate statistics from the non-null cells of a 3D raster map."
+msgid "Calculates univariate statistics from the non-null cells of a 3D raster map."
 msgstr ""
 #: ../raster/r.out.mpeg/main.c:104
@@ -37316,9 +35980,7 @@
 msgstr ""
 #: ../raster/r.surf.idw/main.c:109
-msgid ""
-"Provides surface interpolation from raster point data by Inverse Distance "
-"Squared Weighting."
+msgid "Provides surface interpolation from raster point data by Inverse Distance Squared Weighting."
 msgstr ""
 #: ../raster/r.surf.idw/main.c:124
@@ -37383,9 +36045,7 @@
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:156
-msgid ""
-"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from an elevation raster map."
+msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from an elevation raster map."
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:158
@@ -37401,13 +36061,11 @@
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:209
-msgid ""
-"Name for output first order partial derivative dx (E-W slope) raster map"
+msgid "Name for output first order partial derivative dx (E-W slope) raster map"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:216
-msgid ""
-"Name for output first order partial derivative dy (N-S slope) raster map"
+msgid "Name for output first order partial derivative dy (N-S slope) raster map"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:223
@@ -37436,9 +36094,7 @@
 #: ../raster/r.slope.aspect/main.c:336
 #, c-format
-msgid ""
-"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, "
-"<%s>, <%s>, <%s>, <%s> or <%s>"
+msgid "You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:358
@@ -37447,9 +36103,7 @@
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:387
-msgid ""
-"r.slope.aspect does not convert horizontal units to meters in this version, "
-"see manual page."
+msgid "r.slope.aspect does not convert horizontal units to meters in this version, see manual page."
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:968
@@ -37517,21 +36171,15 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:62
-msgid ""
-"Name of input raster map providing boundary condition status: 0-inactive, "
-"1-active, 2-dirichlet"
+msgid "Name of input raster map providing boundary condition status: 0-inactive, 1-active, 2-dirichlet"
 msgstr ""
 #: ../raster/r.gwflow/main.c:67
-msgid ""
-"Name of input raster map with x-part of the hydraulic conductivity tensor in"
-" [m/s]"
+msgid "Name of input raster map with x-part of the hydraulic conductivity tensor in [m/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:72
-msgid ""
-"Name of input raster map with y-part of the hydraulic conductivity tensor in"
-" [m/s]"
+msgid "Name of input raster map with y-part of the hydraulic conductivity tensor in [m/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:77
@@ -37539,9 +36187,7 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:81
-msgid ""
-"Name of input raster map with storativity for confined or effective porosity"
-" for unconfined groundwater flow booth in [-] "
+msgid "Name of input raster map with storativity for confined or effective porosity for unconfined groundwater flow booth in [-] "
 msgstr ""
 #: ../raster/r.gwflow/main.c:86
@@ -37553,13 +36199,11 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:92
-msgid ""
-"Name of input raster map describing the top surface of the aquifer in [m]"
+msgid "Name of input raster map describing the top surface of the aquifer in [m]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:96
-msgid ""
-"Name of input raster map describing the bottom surface of the aquifer in [m]"
+msgid "Name of input raster map describing the bottom surface of the aquifer in [m]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:100
@@ -37567,20 +36211,15 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:106
-msgid ""
-"Output raster map to store the groundwater filter velocity vector part in x "
-"direction [m/s]"
+msgid "Output raster map to store the groundwater filter velocity vector part in x direction [m/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:112
-msgid ""
-"Output raster map to store the groundwater filter velocity vector part in y "
-"direction [m/s]"
+msgid "Output raster map to store the groundwater filter velocity vector part in y direction [m/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:118
-msgid ""
-"Output raster map to store the groundwater budget for each cell [m^3/s]"
+msgid "Output raster map to store the groundwater budget for each cell [m^3/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:126
@@ -37592,26 +36231,19 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:140
-msgid ""
-"Name of input raster map providing the water level (head) of the river with "
-"leakage connection in [m]"
+msgid "Name of input raster map providing the water level (head) of the river with leakage connection in [m]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:147
-msgid ""
-"Name of input raster map providing the leakage coefficient of the river bed "
-"in [1/s]."
+msgid "Name of input raster map providing the leakage coefficient of the river bed in [1/s]."
 msgstr ""
 #: ../raster/r.gwflow/main.c:155
-msgid ""
-"Name of input raster map providing the height of the drainage bed in [m]"
+msgid "Name of input raster map providing the height of the drainage bed in [m]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:162
-msgid ""
-"Name of input raster map providing the leakage coefficient of the drainage "
-"bed in [1/s]"
+msgid "Name of input raster map providing the leakage coefficient of the drainage bed in [1/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:167
@@ -37619,15 +36251,11 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:176
-msgid ""
-"Allocate a full quadratic linear equation system, default is a sparse linear"
-" equation system."
+msgid "Allocate a full quadratic linear equation system, default is a sparse linear equation system."
 msgstr ""
 #: ../raster/r.gwflow/main.c:212
-msgid ""
-"Numerical calculation program for transient, confined and unconfined "
-"groundwater flow in two dimensions."
+msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
 msgstr ""
 #: ../raster/r.gwflow/main.c:222 ../raster/r.topidx/main.c:56
@@ -37645,9 +36273,7 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:263
-msgid ""
-"The cholesky solver dos not work with sparse matrices. You may choose a full"
-" filled quadratic matrix, flag -f."
+msgid "The cholesky solver dos not work with sparse matrices. You may choose a full filled quadratic matrix, flag -f."
 msgstr ""
 #: ../raster/r.gwflow/main.c:293
@@ -37670,10 +36296,7 @@
 msgstr ""
 #: ../raster/r.patch/main.c:66
-msgid ""
-"Creates a composite raster map layer by using known category values from one"
-" (or more) map layer(s) to fill in areas of \"no data\" in another map "
-"layer."
+msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
 msgstr ""
 #: ../raster/r.patch/main.c:73
@@ -37762,9 +36385,7 @@
 msgstr ""
 #: ../raster/r.random/main.c:58
-msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
+msgid "Creates a raster map layer and vector point map containing randomly located points."
 msgstr ""
 #: ../raster/r.random/main.c:67
@@ -37865,9 +36486,7 @@
 msgstr ""
 #: ../raster/r.series.interp/main.c:69
-msgid ""
-"Interpolates raster maps located (temporal or spatial) in between input "
-"raster maps at specific sampling positions."
+msgid "Interpolates raster maps located (temporal or spatial) in between input raster maps at specific sampling positions."
 msgstr ""
 #: ../raster/r.series.interp/main.c:79
@@ -37875,9 +36494,7 @@
 msgstr ""
 #: ../raster/r.series.interp/main.c:84
-msgid ""
-"Input file with one input raster map name and data point position per line, "
-"field separator between name and sample point is |"
+msgid "Input file with one input raster map name and data point position per line, field separator between name and sample point is |"
 msgstr ""
 #: ../raster/r.series.interp/main.c:97
@@ -37885,9 +36502,7 @@
 msgstr ""
 #: ../raster/r.series.interp/main.c:101
-msgid ""
-"Input file with one output raster map name and sample point position per "
-"line, field separator between name and sample point is |"
+msgid "Input file with one output raster map name and sample point position per line, field separator between name and sample point is |"
 msgstr ""
 #: ../raster/r.series.interp/main.c:111
@@ -37931,9 +36546,7 @@
 #: ../raster/r.series.interp/main.c:299
 #, c-format
-msgid ""
-"map <%s> at position %g was not interpolated. Check the interpolation "
-"interval."
+msgid "map <%s> at position %g was not interpolated. Check the interpolation interval."
 msgstr ""
 #: ../raster/r.series.interp/main.c:319
@@ -38118,14 +36731,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:245
-msgid ""
-"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
-"for given day, latitude, surface and atmospheric conditions. Solar "
-"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
-"irradiance, daylight length) are saved in the map history file. "
-"Alternatively, a local time can be specified to compute solar incidence "
-"angle and/or irradiance raster maps. The shadowing effect of the topography "
-"is optionally incorporated."
+msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
 msgstr ""
 #: ../raster/r.sun/main.c:259
@@ -38133,9 +36739,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:268
-msgid ""
-"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
-"[decimal degrees]"
+msgid "Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]"
 msgstr ""
 #: ../raster/r.sun/main.c:277
@@ -38143,9 +36747,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:286
-msgid ""
-"Name of the input slope raster map (terrain slope or solar panel "
-"inclination) [decimal degrees]"
+msgid "Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]"
 msgstr ""
 #: ../raster/r.sun/main.c:294
@@ -38153,8 +36755,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:303
-msgid ""
-"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
+msgid "Name of the Linke atmospheric turbidity coefficient input raster map [-]"
 msgstr ""
 #: ../raster/r.sun/main.c:312
@@ -38178,14 +36779,11 @@
 msgstr ""
 #: ../raster/r.sun/main.c:357
-msgid ""
-"Name of real-sky beam radiation coefficient (thick cloud) input raster map "
-"[0-1]"
+msgid "Name of real-sky beam radiation coefficient (thick cloud) input raster map [0-1]"
 msgstr ""
 #: ../raster/r.sun/main.c:366
-msgid ""
-"Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
+msgid "Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
 msgstr ""
 #: ../raster/r.sun/main.c:373
@@ -38197,27 +36795,19 @@
 msgstr ""
 #: ../raster/r.sun/main.c:399
-msgid ""
-"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map "
-"[Wh.m-2.day-1] (mode 2)"
+msgid "Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
 msgstr ""
 #: ../raster/r.sun/main.c:408
-msgid ""
-"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map "
+msgid "Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
 msgstr ""
 #: ../raster/r.sun/main.c:417
-msgid ""
-"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
-"map [Wh.m-2.day-1] (mode 2)"
+msgid "Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
 msgstr ""
 #: ../raster/r.sun/main.c:426
-msgid ""
-"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or "
-"irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgid "Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
 msgstr ""
 #: ../raster/r.sun/main.c:435
@@ -38289,8 +36879,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:609
-msgid ""
-"If you use the horizon option you must also set the 'horizonstep' parameter."
+msgid "If you use the horizon option you must also set the 'horizonstep' parameter."
 msgstr ""
 #: ../raster/r.sun/main.c:615
@@ -38298,9 +36887,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:617
-msgid ""
-"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
-"time"
+msgid "Mode 1: instantaneous solar incidence angle & irradiance using a set local time"
 msgstr ""
 #: ../raster/r.sun/main.c:622
@@ -38356,9 +36943,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:700
-msgid ""
-"If you want to save memory and to use shadows, you must use pre-calculated "
-"horizons."
+msgid "If you want to save memory and to use shadows, you must use pre-calculated horizons."
 msgstr ""
 #: ../raster/r.sun/main.c:767
@@ -38370,9 +36955,7 @@
 msgstr ""
 #: ../raster/r.coin/main.c:69
-msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
+msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
 msgstr ""
 #: ../raster/r.coin/main.c:74
@@ -38388,9 +36971,7 @@
 msgstr ""
 #: ../raster/r.coin/main.c:86
-msgid ""
-"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
-"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
+msgid "c(ells), p(ercent), x(percent of category [column]), y(percent of category [row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
 msgstr ""
 #: ../raster/r.coin/main.c:93
@@ -38429,9 +37010,7 @@
 msgstr ""
 #: ../raster/r.kappa/main.c:72
-msgid ""
-"Calculates error matrix and kappa parameter for accuracy assessment of "
-"classification result."
+msgid "Calculates error matrix and kappa parameter for accuracy assessment of classification result."
 msgstr ""
 #: ../raster/r.kappa/main.c:78
@@ -38593,9 +37172,7 @@
 msgstr ""
 #: ../raster/r.clump/main.c:56
-msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
+msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
 msgstr ""
 #: ../raster/r.clump/main.c:72
@@ -38618,8 +37195,7 @@
 msgstr[1] ""
 #: ../raster/r.surf.random/main.c:40
-msgid ""
-"Produces a raster surface map of uniform random deviates with defined range."
+msgid "Produces a raster surface map of uniform random deviates with defined range."
 msgstr ""
 #: ../raster/r.surf.random/main.c:46
@@ -38636,10 +37212,7 @@
 #: ../raster/r.topidx/file_io.c:35
 #, c-format
-msgid ""
-"The current region resolution [%s x %s] is finer than the input map's "
-"resolution [%s x %s]. The current region resolution must be identical to, or"
-" coarser than, the input map's resolution."
+msgid "The current region resolution [%s x %s] is finer than the input map's resolution [%s x %s]. The current region resolution must be identical to, or coarser than, the input map's resolution."
 msgstr ""
 #: ../raster/r.topidx/file_io.c:42
@@ -38660,9 +37233,7 @@
 msgstr ""
 #: ../raster/r.topidx/main.c:43
-msgid ""
-"Creates a topographic index (wetness index) raster map from an elevation "
-"raster map."
+msgid "Creates a topographic index (wetness index) raster map from an elevation raster map."
 msgstr ""
 #: ../raster/r.topidx/main.c:49
@@ -38686,9 +37257,7 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:79
-msgid ""
-"The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - "
-"dirichlet- and 3 - transfer boundary condition"
+msgid "The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - dirichlet- and 3 - transfer boundary condition"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:85
@@ -38711,14 +37280,11 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:103
-msgid ""
-"Concentration sources and sinks bounded to a water source or sink in [kg/s]"
+msgid "Concentration sources and sinks bounded to a water source or sink in [kg/s]"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:112
-msgid ""
-"Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical "
-"reaction)"
+msgid "Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical reaction)"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:117
@@ -38738,21 +37304,15 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:132
-msgid ""
-"The resulting concentration of the numerical solute transport calculation "
-"will be written to this map. [kg/m^3]"
+msgid "The resulting concentration of the numerical solute transport calculation will be written to this map. [kg/m^3]"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:140
-msgid ""
-"Calculate and store the groundwater filter velocity vector part in x "
-"direction [m/s]\n"
+msgid "Calculate and store the groundwater filter velocity vector part in x direction [m/s]\n"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:147
-msgid ""
-"Calculate and store the groundwater filter velocity vector part in y "
+msgid "Calculate and store the groundwater filter velocity vector part in y direction [m/s]\n"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:161
@@ -38764,9 +37324,7 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:177
-msgid ""
-"Use this number of time loops if the CFL flag is off. The timestep will "
-"become dt/loops."
+msgid "Use this number of time loops if the CFL flag is off. The timestep will become dt/loops."
 msgstr ""
 #: ../raster/r.solute.transport/main.c:187
@@ -38782,9 +37340,7 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:233
-msgid ""
-"Numerical calculation program for transient, confined and unconfined solute "
-"transport in two dimensions"
+msgid "Numerical calculation program for transient, confined and unconfined solute transport in two dimensions"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:258
@@ -38817,8 +37373,7 @@
 #: ../raster/r.solute.transport/main.c:385
 #, c-format
-msgid ""
-"The time step is to large: %gs. The largest time step should be of size %gs."
+msgid "The time step is to large: %gs. The largest time step should be of size %gs."
 msgstr ""
 #: ../raster/r.solute.transport/main.c:397
@@ -38921,9 +37476,7 @@
 msgstr ""
 #: ../raster/r.external/window.c:23
-msgid ""
-"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
-"transform the map to North-up."
+msgid "Input raster map is rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
 msgstr ""
 #: ../raster/r.external/window.c:26
@@ -39236,9 +37789,7 @@
 msgstr ""
 #: ../raster/r.stream.extract/main.c:88
-msgid ""
-"Stream extraction will use provided accumulation instead of calculating it "
-"anew"
+msgid "Stream extraction will use provided accumulation instead of calculating it anew"
 msgstr ""
 #: ../raster/r.stream.extract/main.c:93
@@ -39262,9 +37813,7 @@
 msgstr ""
 #: ../raster/r.stream.extract/main.c:110
-msgid ""
-"If accumulation is larger than d8cut, SFD is used instead of MFD. Applies "
-"only if no accumulation map is given."
+msgid "If accumulation is larger than d8cut, SFD is used instead of MFD. Applies only if no accumulation map is given."
 msgstr ""
 #: ../raster/r.stream.extract/main.c:122
@@ -39272,9 +37821,7 @@
 msgstr ""
 #: ../raster/r.stream.extract/main.c:124
-msgid ""
-"Montgomery: accumulation is multiplied with pow(slope,mexp) and then "
-"compared with threshold"
+msgid "Montgomery: accumulation is multiplied with pow(slope,mexp) and then compared with threshold"
 msgstr ""
 #: ../raster/r.stream.extract/main.c:132
@@ -39414,9 +37961,7 @@
 #: ../raster/r.stream.extract/streams.c:700
 #, c-format
-msgid ""
-"MFD: A * path already processed when setting drainage direction: %lld of "
-"%lld cells"
+msgid "MFD: A * path already processed when setting drainage direction: %lld of %lld cells"
 msgstr ""
 #: ../raster/r.stream.extract/thin.c:83
@@ -39451,9 +37996,7 @@
 msgstr ""
 #: ../raster/r.external.out/main.c:240
-msgid ""
-"Redirects raster output to file utilizing GDAL library rather than storing "
-"in GRASS raster format."
+msgid "Redirects raster output to file utilizing GDAL library rather than storing in GRASS raster format."
 msgstr ""
 #: ../raster/r.external.out/main.c:244
@@ -39546,9 +38089,7 @@
 msgstr ""
 #: ../raster/r.carve/main.c:77
-msgid ""
-"Takes vector stream data, transforms it to raster and subtracts depth from "
-"the output DEM."
+msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
 msgstr ""
 #: ../raster/r.carve/main.c:82
@@ -39594,8 +38135,7 @@
 msgstr ""
 #: ../raster/r.carve/enforce_ds.c:175
-msgid ""
-"Vect runs out of region and re-enters - this case is not yet implemented."
+msgid "Vect runs out of region and re-enters - this case is not yet implemented."
 msgstr ""
 #: ../raster/r.surf.fractal/main.c:40
@@ -39633,10 +38173,7 @@
 msgstr ""
 #: ../raster/r.cost/main.c:145
-msgid ""
-"Creates a raster map showing the cumulative cost of moving between different"
-" geographic locations on an input raster map whose cell category values "
-"represent cost."
+msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
 msgstr ""
 #: ../raster/r.cost/main.c:152
@@ -39654,9 +38191,7 @@
 #: ../raster/r.cost/main.c:489
 #, c-format
-msgid ""
-"Negative cell value found at row %d, col %d. Setting negative value to "
-"null_cost value"
+msgid "Negative cell value found at row %d, col %d. Setting negative value to null_cost value"
 msgstr ""
 #: ../raster/r.cost/main.c:582
@@ -39763,9 +38298,7 @@
 #: ../raster/r.stats.quantile/main.c:632
 #, c-format
-msgid ""
-"Base map <%s> has many categories (%d), computation might be slow and might "
-"need a lot of memory"
+msgid "Base map <%s> has many categories (%d), computation might be slow and might need a lot of memory"
 msgstr ""
 #: ../raster/r.to.vect/main.c:79
@@ -39781,14 +38314,11 @@
 msgstr ""
 #: ../raster/r.to.vect/main.c:142
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
-"table."
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be written to the table."
 msgstr ""
 #: ../raster/r.to.vect/main.c:144
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be z coordinate."
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be z coordinate."
 msgstr ""
 #: ../raster/r.to.vect/main.c:146
@@ -40030,9 +38560,7 @@
 msgstr ""
 #: ../raster/r.cross/main.c:72
-msgid ""
-"Creates a cross product of the category values from multiple raster map "
-"layers."
+msgid "Creates a cross product of the category values from multiple raster map layers."
 msgstr ""
 #: ../raster/r.cross/main.c:81
@@ -40133,8 +38661,7 @@
 msgstr ""
 #: ../raster/r.transect/main.c:106
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
+msgid "Outputs raster map layer values lying along user defined transect line(s)."
 msgstr ""
 #: ../raster/r.transect/main.c:110
@@ -40164,9 +38691,7 @@
 msgstr ""
 #: ../raster/r.rescale.eq/main.c:55
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
+msgid "Rescales histogram equalized the range of category values in a raster map layer."
 msgstr ""
 #: ../raster/r.rescale.eq/main.c:115
@@ -40213,9 +38738,7 @@
 #: ../raster/r.null/main.c:132
 #, c-format
-msgid ""
-"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
-"with r.mapcalc. Exiting."
+msgid "Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy with r.mapcalc. Exiting."
 msgstr ""
 #: ../raster/r.null/main.c:138
@@ -40300,9 +38823,7 @@
 msgstr ""
 #: ../raster/r.fill.dir/main.c:92
-msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation raster map."
+msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
 msgstr ""
 #: ../raster/r.fill.dir/main.c:99
@@ -40310,8 +38831,7 @@
 msgstr ""
 #: ../raster/r.fill.dir/main.c:103
-msgid ""
-"Name for output flow direction map for depressionless elevation raster map"
+msgid "Name for output flow direction map for depressionless elevation raster map"
 msgstr ""
 #: ../raster/r.fill.dir/main.c:108
@@ -40525,9 +39045,7 @@
 msgstr ""
 #: ../ps/ps.map/main.c:118
-msgid ""
-"Describe map-box's position on the page and exit (inches from top-left of "
-"paper)"
+msgid "Describe map-box's position on the page and exit (inches from top-left of paper)"
 msgstr ""
 #: ../ps/ps.map/main.c:123
@@ -40580,10 +39098,7 @@
 msgstr ""
 #: ../ps/ps.map/ps_clrtbl.c:54
-msgid ""
-"Your cats/ file is invalid. A cats/ file with categories and labels is "
-"required for 'colortable' when using categorical legends; see the r.category"
-" help page. Colortable creation has been skipped."
+msgid "Your cats/ file is invalid. A cats/ file with categories and labels is required for 'colortable' when using categorical legends; see the r.category help page. Colortable creation has been skipped."
 msgstr ""
 #: ../ps/ps.map/ps_clrtbl.c:69 ../ps/ps.map/ps_fclrtbl.c:97
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grassmods_pl.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -67,7 +67,7 @@
 #: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:4
 #: ../misc/m.nviz.script/main.c:72 ../misc/m.nviz.image/main.c:55
 msgid "raster3d"
-msgstr ""
+msgstr "raster 3D"
 #: ../raster3d/r3.out.netcdf/main.c:587 ../raster3d/r3.out.v5d/main.c:285
 #: ../raster3d/r3.out.ascii/main.c:303 ../raster3d/r3.out.bin/main.c:206
@@ -122,7 +122,7 @@
 #: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:5
 #: ../vector/v.to.rast3/main.c:50 ../vector/v.vol.rst/main.c:236
 msgid "voxel"
-msgstr ""
+msgstr "voxel"
 #: ../raster3d/r3.out.netcdf/main.c:590
 msgid "Export a 3D raster map as netCDF file."
@@ -877,7 +877,7 @@
 #: ../raster/r.lake/main.c:151 ../raster/r.watershed/front/main.c:74
 #: ../raster/r.flow/main.c:422 ../raster/r.water.outlet/main.c:58
 msgid "hydrology"
-msgstr ""
+msgstr "hydrologia"
 #: ../raster3d/r3.gwflow/main.c:163
 msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions."
@@ -1196,7 +1196,7 @@
 #: ../raster3d/r3.support/main.c:121 ../raster/r.support/main.c:125
 msgid "Text file in which to save history"
-msgstr ""
+msgstr "Plik tekstowy w którym zapisać historię"
 #: ../raster3d/r3.support/main.c:125
 msgid "Update range"
@@ -1701,9 +1701,9 @@
 #: ../raster3d/r3.in.lidar/main.c:378 ../raster/r.in.lidar/main.c:401
 #: ../vector/v.in.lidar/main.c:352
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open file <%s> as a LiDAR point cloud"
-msgstr "Nie można otworzyć pliku <%s> do zapisu"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:382 ../raster/r.in.lidar/main.c:405
 #: ../vector/v.in.lidar/main.c:356
@@ -2149,12 +2149,12 @@
 #: ../raster3d/r3.flow/main.c:91
 msgid "Please provide three 3D raster maps"
-msgstr ""
+msgstr "Podaj 3 mapy rastrowe 3D"
 #: ../raster3d/r3.flow/main.c:98
 #, c-format
 msgid "Vector seed map <%s> not found"
-msgstr ""
+msgstr "Nie znaleziono mapy wektorowej <%s> z próbkami"
 #: ../raster3d/r3.flow/main.c:147
 msgid "init_flowaccum: error in Rast3d_put_float"
@@ -2202,7 +2202,7 @@
 #: ../raster3d/r3.flow/main.c:241
 msgid "length in cells (voxels)"
-msgstr ""
+msgstr "długość - w komórkach (voxelach)"
 #: ../raster3d/r3.flow/main.c:243
 msgid "Unit of integration step"
@@ -2581,7 +2581,7 @@
 #: ../raster3d/r3.neighbors/main.c:218
 msgid "Makes each voxel value a function of the values assigned to the voxels around it, and stores new voxel values in an output 3D raster map"
-msgstr ""
+msgstr "Czyni wartość każdej komórki voxela funkcją wartości przypisanych do voxeli dookoła niej, i przechowuje nowe wartości voxela w wyjściowej mapie rastrowej 3D"
 #: ../raster3d/r3.neighbors/main.c:287
 msgid "Unable to allocate buffer"
@@ -21816,7 +21816,7 @@
 #: ../locale/scriptstrings/d.to.rast_to_translate.c:1
 msgid "Saves the contents of the active display monitor to a raster map."
-msgstr ""
+msgstr "Zapisuje zawartość aktywnego okna mapy do pliku mapy rastrowej."
 #: ../locale/scriptstrings/d.redraw_to_translate.c:1
 msgid "Redraws the content of currently selected monitor."
@@ -22341,7 +22341,7 @@
 #: ../locale/scriptstrings/d.out.file_to_translate.c:1
 msgid "Saves the contents of the active display monitor to a graphics file."
-msgstr ""
+msgstr "Zapisuje zawartość aktywnego okna mapy do pliku graficznego."
 #: ../locale/scriptstrings/d.out.file_to_translate.c:5
 #: ../misc/m.nviz.image/args.c:105
@@ -27977,7 +27977,7 @@
 #: ../general/g.region/main.c:341
 msgid "Save current region settings in named region file"
-msgstr ""
+msgstr "Zapisz bieżące ustawienia regionu do nazwanego pliku regionu"
 #: ../general/g.region/main.c:410
 #, c-format
@@ -37348,7 +37348,7 @@
 #: ../vector/v.external.out/args.c:58
 msgid "Name for output file where to save current settings"
-msgstr ""
+msgstr "Nazwa pliku wyjściowego do zapisu bieżących ustawień"
 #: ../vector/v.external.out/args.c:68
 msgid "Cease using OGR/PostGIS, revert to native output and exit"
Modified: grass/trunk/locale/po/grassmods_pt.po
--- grass/trunk/locale/po/grassmods_pt.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grassmods_pt.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -1702,9 +1702,9 @@
-#, fuzzy, c-format
+#, c-format
-msgstr "Não consegui abrir o arquivo de células [%s]"
+msgstr ""
Modified: grass/trunk/locale/po/grassmods_pt_BR.po
--- grass/trunk/locale/po/grassmods_pt_BR.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grassmods_pt_BR.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -1698,9 +1698,9 @@
-#, fuzzy, c-format
+#, c-format
-msgstr "Não consegui abrir o arquivo de células <%s>"
+msgstr ""
Modified: grass/trunk/locale/po/grassmods_ro.po
--- grass/trunk/locale/po/grassmods_ro.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grassmods_ro.po	2017-08-31 20:55:23 UTC (rev 71461)
-#, fuzzy, c-format
+#, c-format
-msgstr "Imposbil de deschis fișierul <%s> pentru scriere"
+msgstr ""
@@ -39715,6 +39715,7 @@
 msgid_plural "adjusted EW splines %d"
 msgstr[0] ""
 msgstr[1] ""
+msgstr[2] ""
 #: ../vector/v.lidar.correction/main.c:276
 #, c-format
@@ -39722,6 +39723,7 @@
 msgid_plural "adjusted NS splines %d"
 msgstr[0] ""
 msgstr[1] ""
+msgstr[2] ""
 #: ../vector/v.lidar.correction/main.c:324
 #, c-format
Modified: grass/trunk/locale/po/grassmods_ru.po
--- grass/trunk/locale/po/grassmods_ru.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grassmods_ru.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -1697,9 +1697,9 @@
-#, fuzzy, c-format
+#, c-format
-msgstr "Невозможно открыть файл <%s> для записи "
+msgstr ""
@@ -36209,16 +36209,14 @@
 #: ../vector/v.surf.bspline/main.c:149
 #: ../vector/v.lidar.edgedetection/main.c:94 ../vector/v.outlier/main.c:103
 #: ../vector/v.lidar.correction/main.c:101
-#, fuzzy
 msgid "Length of each spline step in the east-west direction"
-msgstr "Значение шага интерполяции сплайна в восточном направлении"
+msgstr ""
 #: ../vector/v.surf.bspline/main.c:158
 #: ../vector/v.lidar.edgedetection/main.c:103 ../vector/v.outlier/main.c:112
 #: ../vector/v.lidar.correction/main.c:110
-#, fuzzy
 msgid "Length of each spline step in the north-south direction"
-msgstr "Значение шага интерполяции сплайна в северном направлении"
+msgstr ""
 #: ../vector/v.surf.bspline/main.c:207
 msgid "Choose either vector or raster output, not both"
Modified: grass/trunk/locale/po/grassmods_si.po
--- grass/trunk/locale/po/grassmods_si.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grassmods_si.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -2,7 +2,7 @@
 # Copyright (C) 2017 GRASS Development Team
 # This file is distributed under the same license as the GRASS GIS package.
 # transifex generated, 2017
 msgid ""
 msgstr ""
 "Project-Id-Version: grasslibs_si\n"
@@ -10,10 +10,10 @@
 "POT-Creation-Date: 2017-05-22 23:12-0700\n"
 "PO-Revision-Date: 2017-05-23 21:08+0200\n"
 "Language-Team: Sinhala (https://www.transifex.com/grass-gis/teams/45198/si/)\n"
+"Language: si\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
-"Language: si\n"
 "Plural-Forms: nplurals=2; plural=(n != 1);\n"
 #: ../raster3d/r3.flow/flowline.c:60 ../vector/v.to.points/write.c:52
@@ -272,14 +272,11 @@
 msgstr ""
 #: ../raster3d/r3.flow/main.c:193
-msgid ""
-"Names of three 3D raster maps describing x, y, z components of vector field"
+msgid "Names of three 3D raster maps describing x, y, z components of vector field"
 msgstr ""
 #: ../raster3d/r3.flow/main.c:200
-msgid ""
-"If no map is provided, flow lines are generated from each cell of the input "
-"3D raster"
+msgid "If no map is provided, flow lines are generated from each cell of the input 3D raster"
 msgstr ""
 #: ../raster3d/r3.flow/main.c:203
@@ -358,8 +355,7 @@
 msgstr ""
 #: ../raster3d/r3.flow/main.c:226
-msgid ""
-"Values of this 3D raster will be stored as attributes of flowlines segments"
+msgid "Values of this 3D raster will be stored as attributes of flowlines segments"
 msgstr ""
 #: ../raster3d/r3.flow/main.c:240
@@ -489,16 +485,15 @@
 #: ../vector/v.colors/main.c:262 ../vector/v.info/main.c:61
 #: ../vector/v.surf.rst/main.c:528 ../vector/v.surf.rst/main.c:632
 #: ../vector/v.to.3d/main.c:72 ../vector/v.db.select/main.c:164
-#: ../vector/v.lidar.correction/main.c:156
-#: ../vector/v.lidar.growing/main.c:138 ../vector/v.lidar.growing/main.c:142
-#: ../vector/v.net.allpairs/main.c:130 ../vector/v.net.connectivity/main.c:130
-#: ../vector/v.net.flow/main.c:143 ../vector/v.what.rast/main.c:131
-#: ../vector/v.drape/main.c:143 ../vector/v.build.polylines/main.c:151
-#: ../vector/v.normal/main.c:110 ../vector/v.out.postgis/main.c:100
-#: ../vector/v.out.svg/main.c:139 ../vector/v.delaunay/main.c:120
-#: ../vector/v.reclass/main.c:113 ../vector/v.net.centrality/main.c:209
-#: ../vector/v.select/main.c:108 ../vector/v.support/main.c:130
-#: ../vector/v.lidar.edgedetection/main.c:180
+#: ../vector/v.lidar.correction/main.c:156 ../vector/v.lidar.growing/main.c:138
+#: ../vector/v.lidar.growing/main.c:142 ../vector/v.net.allpairs/main.c:130
+#: ../vector/v.net.connectivity/main.c:130 ../vector/v.net.flow/main.c:143
+#: ../vector/v.what.rast/main.c:131 ../vector/v.drape/main.c:143
+#: ../vector/v.build.polylines/main.c:151 ../vector/v.normal/main.c:110
+#: ../vector/v.out.postgis/main.c:100 ../vector/v.out.svg/main.c:139
+#: ../vector/v.delaunay/main.c:120 ../vector/v.reclass/main.c:113
+#: ../vector/v.net.centrality/main.c:209 ../vector/v.select/main.c:108
+#: ../vector/v.support/main.c:130 ../vector/v.lidar.edgedetection/main.c:180
 #: ../vector/v.lrs/v.lrs.label/main.c:272
 #: ../vector/v.lrs/v.lrs.where/main.c:131
 #: ../vector/v.lrs/v.lrs.where/main.c:140
@@ -538,10 +533,10 @@
 #: ../display/d.vect.chart/main.c:246 ../display/d.extract/main.c:103
 #: ../misc/m.nviz.image/vector.c:280 ../raster/r.walk/main.c:673
 #: ../raster/r.walk/main.c:742 ../raster/r.drain/main.c:268
-#: ../raster/r.sim/simlib/observation_points.c:41
-#: ../raster/r.region/main.c:170 ../raster/r.random/support.c:63
-#: ../raster/r.what/main.c:237 ../raster/r.carve/main.c:162
-#: ../raster/r.cost/main.c:533 ../raster/r.cost/main.c:606
+#: ../raster/r.sim/simlib/observation_points.c:41 ../raster/r.region/main.c:170
+#: ../raster/r.random/support.c:63 ../raster/r.what/main.c:237
+#: ../raster/r.carve/main.c:162 ../raster/r.cost/main.c:533
+#: ../raster/r.cost/main.c:606
 #, c-format
 msgid "Unable to open vector map <%s>"
 msgstr ""
@@ -761,17 +756,16 @@
 #: ../raster3d/r3.timestamp/main.c:44 ../temporal/t.connect/main.c:36
 #: ../locale/scriptstrings/t.support_to_translate.c:3
 #: ../locale/scriptstrings/t.info_to_translate.c:3
-#: ../locale/scriptstrings/t.select_to_translate.c:3
-#: ../vector/v.info/main.c:38 ../vector/v.timestamp/main.c:36
-#: ../vector/v.support/main.c:40 ../raster/r.describe/main.c:55
-#: ../raster/r.info/main.c:71 ../raster/r.region/main.c:52
-#: ../raster/r.support/main.c:55 ../raster/r.timestamp/main.c:36
+#: ../locale/scriptstrings/t.select_to_translate.c:3 ../vector/v.info/main.c:38
+#: ../vector/v.timestamp/main.c:36 ../vector/v.support/main.c:40
+#: ../raster/r.describe/main.c:55 ../raster/r.info/main.c:71
+#: ../raster/r.region/main.c:52 ../raster/r.support/main.c:55
+#: ../raster/r.timestamp/main.c:36
 msgid "metadata"
 msgstr ""
 #: ../raster3d/r3.support/main.c:52
-msgid ""
-"Allows creation and/or modification of 3D raster map layer support files."
+msgid "Allows creation and/or modification of 3D raster map layer support files."
 msgstr ""
 #: ../raster3d/r3.support/main.c:62
@@ -916,9 +910,7 @@
 msgstr ""
 #: ../raster3d/r3.gradient/main.c:47
-msgid ""
-"Computes gradient of a 3D raster map and outputs gradient components as "
-"three 3D raster maps."
+msgid "Computes gradient of a 3D raster map and outputs gradient components as three 3D raster maps."
 msgstr ""
 #: ../raster3d/r3.gradient/main.c:56
@@ -1358,9 +1350,7 @@
 #: ../raster3d/r3.in.lidar/main.c:191 ../vector/v.in.lidar/main.c:214
 #: ../raster/r.in.lidar/main.c:269
-msgid ""
-"Input is comma separated integers. If not specified, all points are "
-"imported."
+msgid "Input is comma separated integers. If not specified, all points are imported."
 msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:199
@@ -1387,8 +1377,7 @@
 #: ../raster3d/r3.in.lidar/main.c:213 ../vector/v.in.lidar/main.c:295
 #: ../raster/r.in.lidar/main.c:339
-msgid ""
-"Points invalid according to APSRS LAS specification will be filtered out"
+msgid "Points invalid according to APSRS LAS specification will be filtered out"
 msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:230 ../general/g.pnmcomp/main.c:242
@@ -1510,9 +1499,7 @@
 msgstr ""
 #: ../raster3d/r3.mkdspf/main.c:83
-msgid ""
-"Creates a display file from an existing 3D raster map according to specified"
-" threshold levels."
+msgid "Creates a display file from an existing 3D raster map according to specified threshold levels."
 msgstr ""
 #: ../raster3d/r3.mkdspf/main.c:91
@@ -1615,9 +1602,7 @@
 msgstr ""
 #: ../raster3d/r3.to.rast/main.c:96
-msgid ""
-"Use the same resolution as the input 3D raster map for the 2D output maps, "
-"independent of the current region settings"
+msgid "Use the same resolution as the input 3D raster map for the 2D output maps, independent of the current region settings"
 msgstr ""
 #: ../raster3d/r3.to.rast/main.c:208 ../raster3d/r3.cross.rast/main.c:230
@@ -1682,9 +1667,8 @@
 #: ../raster/r.proj/main.c:144 ../raster/r.in.gdal/main.c:90
 #: ../raster/r.topmodel/main.c:51 ../raster/r.contour/main.c:87
 #: ../raster/r.sunhours/main.c:72 ../raster/r.quant/main.c:47
-#: ../raster/r.regression.line/main.c:46
-#: ../raster/r.param.scale/interface.c:54 ../raster/r.in.mat/main.c:91
-#: ../raster/r.li/r.li.padrange/padrange.c:53
+#: ../raster/r.regression.line/main.c:46 ../raster/r.param.scale/interface.c:54
+#: ../raster/r.in.mat/main.c:91 ../raster/r.li/r.li.padrange/padrange.c:53
 #: ../raster/r.li/r.li.cwed/cwed.c:54 ../raster/r.li/r.li.simpson/simpson.c:46
 #: ../raster/r.li/r.li.dominance/dominance.c:46
 #: ../raster/r.li/r.li.patchdensity/main.c:51
@@ -1694,26 +1678,26 @@
 #: ../raster/r.li/r.li.padsd/padsd.c:53 ../raster/r.li/r.li.patchnum/main.c:50
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:48
 #: ../raster/r.li/r.li.renyi/renyi.c:47 ../raster/r.li/r.li.mps/mps.c:52
-#: ../raster/r.li/r.li.shannon/shannon.c:46
-#: ../raster/r.resamp.interp/main.c:76 ../raster/r.category/main.c:52
-#: ../raster/r.his/main.c:67 ../raster/r.to.rast3/main.c:197
-#: ../raster/r.resamp.rst/main.c:148 ../raster/r.stats.zonal/main.c:101
-#: ../raster/r.relief/main.c:107 ../raster/r.neighbors/main.c:167
-#: ../raster/r.sunmask/main.c:116 ../raster/r.colors/edit_colors.c:63
-#: ../raster/r.drain/main.c:109 ../raster/r.latlong/main.c:56
-#: ../raster/r.support.stats/main.c:38 ../raster/r.texture/main.c:102
-#: ../raster/r.series/main.c:137 ../raster/r.profile/main.c:53
-#: ../raster/r.out.pov/main.c:121 ../raster/r.covar/main.c:51
-#: ../raster/r.out.vtk/main.c:59 ../raster/r.out.png/main.c:112
-#: ../raster/r.watershed/front/main.c:73 ../raster/r.to.rast3elev/main.c:361
-#: ../raster/r.grow.distance/main.c:152 ../raster/r.recode/main.c:48
-#: ../raster/r.in.ascii/main.c:69 ../raster/r.flow/main.c:421
-#: ../raster/r.regression.multi/main.c:128 ../raster/r.in.lidar/main.c:108
-#: ../raster/r.reclass/main.c:50 ../raster/r.tile/main.c:43
-#: ../raster/r.resamp.bspline/main.c:80 ../raster/r.mapcalc/main.c:69
-#: ../raster/r.in.xyz/main.c:158 ../raster/r.stats/main.c:106
-#: ../raster/r.ros/main.c:212 ../raster/r.info/main.c:70
-#: ../raster/r.volume/main.c:76 ../raster/r.sim/r.sim.water/main.c:113
+#: ../raster/r.li/r.li.shannon/shannon.c:46 ../raster/r.resamp.interp/main.c:76
+#: ../raster/r.category/main.c:52 ../raster/r.his/main.c:67
+#: ../raster/r.to.rast3/main.c:197 ../raster/r.resamp.rst/main.c:148
+#: ../raster/r.stats.zonal/main.c:101 ../raster/r.relief/main.c:107
+#: ../raster/r.neighbors/main.c:167 ../raster/r.sunmask/main.c:116
+#: ../raster/r.colors/edit_colors.c:63 ../raster/r.drain/main.c:109
+#: ../raster/r.latlong/main.c:56 ../raster/r.support.stats/main.c:38
+#: ../raster/r.texture/main.c:102 ../raster/r.series/main.c:137
+#: ../raster/r.profile/main.c:53 ../raster/r.out.pov/main.c:121
+#: ../raster/r.covar/main.c:51 ../raster/r.out.vtk/main.c:59
+#: ../raster/r.out.png/main.c:112 ../raster/r.watershed/front/main.c:73
+#: ../raster/r.to.rast3elev/main.c:361 ../raster/r.grow.distance/main.c:152
+#: ../raster/r.recode/main.c:48 ../raster/r.in.ascii/main.c:69
+#: ../raster/r.flow/main.c:421 ../raster/r.regression.multi/main.c:128
+#: ../raster/r.in.lidar/main.c:108 ../raster/r.reclass/main.c:50
+#: ../raster/r.tile/main.c:43 ../raster/r.resamp.bspline/main.c:80
+#: ../raster/r.mapcalc/main.c:69 ../raster/r.in.xyz/main.c:158
+#: ../raster/r.stats/main.c:106 ../raster/r.ros/main.c:212
+#: ../raster/r.info/main.c:70 ../raster/r.volume/main.c:76
+#: ../raster/r.sim/r.sim.water/main.c:113
 #: ../raster/r.sim/r.sim.sediment/main.c:113
 #: ../raster/r.series.accumulate/main.c:80 ../raster/r.out.gdal/main.c:136
 #: ../raster/r.spread/main.c:105 ../raster/r.out.gridatb/main.c:67
@@ -1755,9 +1739,7 @@
 msgstr ""
 #: ../raster3d/r3.to.rast/main.c:271 ../raster3d/r3.out.vtk/main.c:451
-msgid ""
-"The 2D and 3D region settings are different. Using the 2D window settings to"
-" adjust the 2D part of the 3D region."
+msgid "The 2D and 3D region settings are different. Using the 2D window settings to adjust the 2D part of the 3D region."
 msgstr ""
 #: ../raster3d/r3.to.rast/main.c:295 ../vector/v.generalize/matrix.c:144
@@ -1807,8 +1789,7 @@
 #: ../raster3d/r3.to.rast/main.c:308
 #, c-format
-msgid ""
-"Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
+msgid "Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
 msgstr ""
 #: ../raster3d/r3.neighbors/main.c:94 ../raster/r.neighbors/main.c:102
@@ -1827,9 +1808,7 @@
 msgstr ""
 #: ../raster3d/r3.neighbors/main.c:137
-msgid ""
-"The size of the window in x, y and z direction, values must be odd integer "
-"numbers, eg: 3,3,3"
+msgid "The size of the window in x, y and z direction, values must be odd integer numbers, eg: 3,3,3"
 msgstr ""
 #: ../raster3d/r3.neighbors/main.c:209
@@ -1872,9 +1851,7 @@
 msgstr ""
-msgid ""
-"Makes each voxel value a function of the values assigned to the voxels "
-"around it, and stores new voxel values in an output 3D raster map"
+msgid "Makes each voxel value a function of the values assigned to the voxels around it, and stores new voxel values in an output 3D raster map"
 msgstr ""
@@ -1890,27 +1867,19 @@
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:60
-msgid ""
-"Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - "
-"active, 2 - dirichlet"
+msgid "Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:65
-msgid ""
-"Input 3D raster map with the x-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Input 3D raster map with the x-part of the hydraulic conductivity tensor in [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:70
-msgid ""
-"Input 3D raster map with the y-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Input 3D raster map with the y-part of the hydraulic conductivity tensor in [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:75
-msgid ""
-"Input 3D raster map with the z-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Input 3D raster map with the z-part of the hydraulic conductivity tensor in [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:80
@@ -1926,32 +1895,23 @@
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:93
-msgid ""
-"Output 3D raster map storing the piezometric head result of the numerical "
-"calculation"
+msgid "Output 3D raster map storing the piezometric head result of the numerical calculation"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:99
-msgid ""
-"Output 3D raster map storing the groundwater filter velocity vector part in "
-"x direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in x direction [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:105
-msgid ""
-"y direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in y direction [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:111
-msgid ""
-"z direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in z direction [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:117
-msgid ""
-"Output 3D raster map storing the groundwater budget for each cell [m^3/s]"
+msgid "Output 3D raster map storing the groundwater budget for each cell [m^3/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:127
@@ -1959,9 +1919,7 @@
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:131 ../raster/r.solute.transport/main.c:192
-msgid ""
-"Use a full filled quadratic linear equation system, default is a sparse "
-"linear equation system."
+msgid "Use a full filled quadratic linear equation system, default is a sparse linear equation system."
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:160 ../raster/r.gwflow/main.c:209
@@ -1969,9 +1927,7 @@
 msgstr ""
-msgid ""
-"Numerical calculation program for transient, confined groundwater flow in "
-"three dimensions."
+msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions."
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:180
@@ -2021,9 +1977,7 @@
 msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:175
-msgid ""
-"No 3D raster data, RGB or xyz-vector maps are provided! Will only write the "
-"geometry."
+msgid "No 3D raster data, RGB or xyz-vector maps are provided! Will only write the geometry."
 msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:209
@@ -2079,14 +2033,11 @@
 msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:71
-msgid ""
-"Create 3D elevation output with a top and a bottom surface, both raster maps"
-" are required."
+msgid "Create 3D elevation output with a top and a bottom surface, both raster maps are required."
 msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:80
-msgid ""
-"Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
+msgid "Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
 msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:88
@@ -2112,15 +2063,12 @@
 msgid "Scale factor affects the origin"
 msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:123
-#: ../raster/r.out.vtk/parameters.c:128
+#: ../raster3d/r3.out.vtk/parameters.c:123 ../raster/r.out.vtk/parameters.c:128
 msgid "Correct the coordinates to match the VTK-OpenGL precision"
 msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:129
-msgid ""
-"Do not convert the top-bottom resolution in case of lat long projection to "
-"meters"
+msgid "Do not convert the top-bottom resolution in case of lat long projection to meters"
 msgstr ""
 #: ../raster3d/r3.out.vtk/writeVTKData.c:122
@@ -2133,9 +2081,7 @@
 #: ../raster3d/r3.out.vtk/writeVTKData.c:335
 #, c-format
-msgid ""
-"write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
-"ascii file"
+msgid "write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-ascii file"
 msgstr ""
 #: ../raster3d/r3.out.vtk/writeVTKData.c:441
@@ -2171,8 +2117,7 @@
 #: ../raster3d/r3.in.ascii/main.c:281
 #, c-format
-msgid ""
-"Data exists in input file after fully importing expected data.  [%.4f ...]"
+msgid "Data exists in input file after fully importing expected data.  [%.4f ...]"
 msgstr ""
 #: ../raster3d/r3.in.ascii/main.c:319
@@ -2201,15 +2146,11 @@
 msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:233
-msgid ""
-"Creates cross section 2D raster map from 3D raster map based on 2D elevation"
-" map"
+msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map"
 msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:259
-msgid ""
-"The 2D and 3D region settings are different. Using the 3D raster map "
-"settings to adjust the 2D region."
+msgid "The 2D and 3D region settings are different. Using the 3D raster map settings to adjust the 2D region."
 msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:302
@@ -2235,8 +2176,7 @@
 msgstr ""
 #: ../raster3d/r3.retile/main.c:99
-msgid ""
-"Retiles an existing 3D raster map with user defined x, y and z tile size."
+msgid "Retiles an existing 3D raster map with user defined x, y and z tile size."
 msgstr ""
 #: ../raster3d/r3.retile/main.c:135
@@ -2444,8 +2384,7 @@
 msgstr ""
 #: ../temporal/t.connect/main.c:38
-msgid ""
-"Prints/sets general temporal GIS database connection for current mapset."
+msgid "Prints/sets general temporal GIS database connection for current mapset."
 msgstr ""
 #: ../temporal/t.connect/main.c:42 ../db/db.connect/main.c:51
@@ -2589,9 +2528,8 @@
 msgstr ""
 #: ../locale/scriptstrings/d.frame_to_translate.c:4
-#: ../locale/scriptstrings/d.redraw_to_translate.c:4
-#: ../display/d.mon/main.c:40 ../display/d.erase/main.c:31
-#: ../display/d.info/main.c:36
+#: ../locale/scriptstrings/d.redraw_to_translate.c:4 ../display/d.mon/main.c:40
+#: ../display/d.erase/main.c:31 ../display/d.info/main.c:36
 msgid "monitors"
 msgstr ""
@@ -2620,8 +2558,7 @@
 msgstr ""
 #: ../locale/scriptstrings/d.frame_to_translate.c:11
-msgid ""
-"Screen coordinates in percent where to place the frame (0,0 is lower-left)"
+msgid "Screen coordinates in percent where to place the frame (0,0 is lower-left)"
 msgstr ""
 #: ../locale/scriptstrings/d.frame_to_translate.c:12
@@ -2812,9 +2749,7 @@
 msgstr ""
 #: ../locale/scriptstrings/d.what.rast_to_translate.c:1
-msgid ""
-"Allows the user to interactively query raster map layers at user-selected "
-"locations."
+msgid "Allows the user to interactively query raster map layers at user-selected locations."
 msgstr ""
 #: ../locale/scriptstrings/d.what.rast_to_translate.c:3
@@ -2879,8 +2814,7 @@
 #: ../vector/v.net.centrality/main.c:96 ../vector/v.select/main.c:48
 #: ../vector/v.support/main.c:39 ../vector/v.in.lidar/main.c:136
 #: ../vector/v.lidar.edgedetection/main.c:75
-#: ../vector/v.lrs/v.lrs.label/main.c:102
-#: ../vector/v.lrs/v.lrs.where/main.c:57
+#: ../vector/v.lrs/v.lrs.label/main.c:102 ../vector/v.lrs/v.lrs.where/main.c:57
 #: ../vector/v.lrs/v.lrs.create/main.c:121
 #: ../vector/v.lrs/v.lrs.segment/main.c:71 ../vector/v.to.db/main.c:36
 #: ../vector/v.out.dxf/main.c:56 ../vector/v.transform/main.c:69
@@ -2918,9 +2852,7 @@
 msgstr ""
 #: ../locale/scriptstrings/d.what.vect_to_translate.c:1
-msgid ""
-"Allows the user to interactively query vector map layers at user-selected "
-"locations."
+msgid "Allows the user to interactively query vector map layers at user-selected locations."
 msgstr ""
 #: ../locale/scriptstrings/db.dropcolumn_to_translate.c:1
@@ -3094,8 +3026,7 @@
 #: ../locale/scriptstrings/db.univar_to_translate.c:5
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:5
-msgid ""
-"Name of attribute column on which to calculate statistics (must be numeric)"
+msgid "Name of attribute column on which to calculate statistics (must be numeric)"
 msgstr ""
 #: ../locale/scriptstrings/db.univar_to_translate.c:6
@@ -3120,9 +3051,7 @@
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:2
-msgid ""
-"Downloads and installs extensions from GRASS Addons repository or other "
-"source into the local GRASS installation or removes installed extensions."
+msgid "Downloads and installs extensions from GRASS Addons repository or other source into the local GRASS installation or removes installed extensions."
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:3
@@ -3177,15 +3106,11 @@
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:11
-msgid ""
-"URL or directory to get the extension from (supported only on Linux and Mac)"
+msgid "URL or directory to get the extension from (supported only on Linux and Mac)"
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:12
-msgid ""
-"The official repository is used by default. User can specify a ZIP file, "
-"directory or a repository on common hosting services. If not identified, "
-"Subversion repository is assumed. See manual for all options."
+msgid "The official repository is used by default. User can specify a ZIP file, directory or a repository on common hosting services. If not identified, Subversion repository is assumed. See manual for all options."
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:13
@@ -3201,15 +3126,11 @@
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:17
-msgid ""
-"List available extensions in the official GRASS GIS Addons repository "
-"including module description"
+msgid "List available extensions in the official GRASS GIS Addons repository including module description"
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:19
-msgid ""
-"List available extensions in the official GRASS GIS Addons repository (shell"
-" script style)"
+msgid "List available extensions in the official GRASS GIS Addons repository (shell script style)"
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:21
@@ -3255,8 +3176,7 @@
 msgstr ""
 #: ../locale/scriptstrings/g.extension.all_to_translate.c:2
-msgid ""
-"By default only extensions built against different GIS Library are rebuilt."
+msgid "By default only extensions built against different GIS Library are rebuilt."
 msgstr ""
 #: ../locale/scriptstrings/g.extension.all_to_translate.c:7
@@ -3292,9 +3212,7 @@
 msgstr ""
 #: ../locale/scriptstrings/g.manual_to_translate.c:9
-msgid ""
-"Use online manuals available at http://grass.osgeo.org website. This flag "
-"has no effect when displaying MAN text pages."
+msgid "Use online manuals available at http://grass.osgeo.org website. This flag has no effect when displaying MAN text pages."
 msgstr ""
 #: ../locale/scriptstrings/g.manual_to_translate.c:10
@@ -3318,8 +3236,7 @@
 msgstr ""
 #: ../locale/scriptstrings/g.search.modules_to_translate.c:6
-msgid ""
-"Display only modules where all keywords are available (AND), default: OR"
+msgid "Display only modules where all keywords are available (AND), default: OR"
 msgstr ""
 #: ../locale/scriptstrings/g.search.modules_to_translate.c:8
@@ -3516,9 +3433,8 @@
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:6
 #: ../vector/v.db.select/main.c:95 ../db/db.select/main.c:241
 #: ../raster/r.stats/main.c:119 ../raster/r.quantile/main.c:297
-#: ../raster/r.univar/r.univar_main.c:41
-#: ../raster/r.univar/r3.univar_main.c:42 ../raster/r.what/main.c:125
-#: ../raster/r.stats.quantile/main.c:555
+#: ../raster/r.univar/r.univar_main.c:41 ../raster/r.univar/r3.univar_main.c:42
+#: ../raster/r.what/main.c:125 ../raster/r.stats.quantile/main.c:555
 msgid "Name for output file (if omitted or \"-\" output to stdout)"
 msgstr ""
@@ -3531,9 +3447,7 @@
 msgstr ""
 #: ../locale/scriptstrings/i.pansharpen_to_translate.c:1
-msgid ""
-"Image fusion algorithms to sharpen multispectral with high-res panchromatic "
-"channels"
+msgid "Image fusion algorithms to sharpen multispectral with high-res panchromatic channels"
 msgstr ""
 #: ../locale/scriptstrings/i.pansharpen_to_translate.c:3
@@ -3590,8 +3504,7 @@
 msgstr ""
 #: ../locale/scriptstrings/i.spectral_to_translate.c:1
-msgid ""
-"Displays spectral response at user specified locations in group or images."
+msgid "Displays spectral response at user specified locations in group or images."
 msgstr ""
 #: ../locale/scriptstrings/i.spectral_to_translate.c:3
@@ -3654,9 +3567,7 @@
 msgstr ""
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:7
-msgid ""
-"For Landsat4-7: bands 1, 2, 3, 4, 5, 7; for Landsat8: bands 2, 3, 4, 5, 6, "
-"7; for MODIS: bands 1, 2, 3, 4, 5, 6, 7"
+msgid "For Landsat4-7: bands 1, 2, 3, 4, 5, 7; for Landsat8: bands 2, 3, 4, 5, 6, 7; for MODIS: bands 1, 2, 3, 4, 5, 6, 7"
 msgstr ""
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:8
@@ -3669,11 +3580,7 @@
 msgstr ""
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:10
-msgid ""
-"landsat4_tm;Use transformation rules for Landsat 4 TM;landsat5_tm;Use "
-"transformation rules for Landsat 5 TM;landsat7_etm;Use transformation rules "
-"for Landsat 7 ETM;landsat8_oli;Use transformation rules for Landsat 8 "
-"OLI;modis;Use transformation rules for MODIS"
+msgid "landsat4_tm;Use transformation rules for Landsat 4 TM;landsat5_tm;Use transformation rules for Landsat 5 TM;landsat7_etm;Use transformation rules for Landsat 7 ETM;landsat8_oli;Use transformation rules for Landsat 8 OLI;modis;Use transformation rules for MODIS"
 msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:1
@@ -3709,12 +3616,12 @@
 msgid "Name of input coordinate file"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:8
-#: ../general/g.proj/main.c:141 ../general/g.proj/main.c:150
-#: ../vector/v.edit/args.c:89 ../vector/v.segment/main.c:80
-#: ../vector/v.what/main.c:76 ../db/db.execute/main.c:139
-#: ../db/db.select/main.c:208 ../raster/r.recode/main.c:61
-#: ../raster/r.in.ascii/main.c:79 ../raster/r.reclass/main.c:66
+#: ../locale/scriptstrings/m.proj_to_translate.c:8 ../general/g.proj/main.c:141
+#: ../general/g.proj/main.c:150 ../vector/v.edit/args.c:89
+#: ../vector/v.segment/main.c:80 ../vector/v.what/main.c:76
+#: ../db/db.execute/main.c:139 ../db/db.select/main.c:208
+#: ../raster/r.recode/main.c:61 ../raster/r.in.ascii/main.c:79
+#: ../raster/r.reclass/main.c:66
 msgid "'-' for standard input"
 msgstr ""
@@ -3750,9 +3657,7 @@
 msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:22
-msgid ""
-"Output long/lat in decimal degrees, or other projections with many decimal "
-"places"
+msgid "Output long/lat in decimal degrees, or other projections with many decimal places"
 msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:24
@@ -3794,9 +3699,7 @@
 #: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:1
 #: ../raster/r.buffer/main.c:69
-msgid ""
-"Creates a raster map showing buffer zones surrounding cells that contain "
-"non-NULL category values."
+msgid "Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values."
 msgstr ""
 #: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:2
@@ -3949,9 +3852,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.import_to_translate.c:1
-msgid ""
-"Imports raster data into a GRASS raster map using GDAL library and "
-"reprojects on the fly."
+msgid "Imports raster data into a GRASS raster map using GDAL library and reprojects on the fly."
 msgstr ""
 #: ../locale/scriptstrings/r.import_to_translate.c:5
@@ -3990,11 +3891,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.import_to_translate.c:14
-msgid ""
-"nearest;nearest neighbor;bilinear;bilinear interpolation;bicubic;bicubic "
-"interpolation;lanczos;lanczos filter;bilinear_f;bilinear interpolation with "
-"fallback;bicubic_f;bicubic interpolation with fallback;lanczos_f;lanczos "
-"filter with fallback"
+msgid "nearest;nearest neighbor;bilinear;bilinear interpolation;bicubic;bicubic interpolation;lanczos;lanczos filter;bilinear_f;bilinear interpolation with fallback;bicubic_f;bicubic interpolation with fallback;lanczos_f;lanczos filter with fallback"
 msgstr ""
 #: ../locale/scriptstrings/r.import_to_translate.c:16
@@ -4010,9 +3907,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.import_to_translate.c:20
-msgid ""
-"estimated;estimated resolution;value;user-specified "
-"resolution;region;current region resolution"
+msgid "estimated;estimated resolution;value;user-specified resolution;region;current region resolution"
 msgstr ""
 #: ../locale/scriptstrings/r.import_to_translate.c:22
@@ -4071,14 +3966,11 @@
 #: ../locale/scriptstrings/r.import_to_translate.c:32
 #: ../locale/scriptstrings/v.import_to_translate.c:28
 #: ../vector/v.in.ogr/main.c:286 ../vector/v.external/args.c:45
-msgid ""
-"Assume that the dataset has the same projection as the current location"
+msgid "Assume that the dataset has the same projection as the current location"
 msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:1
-msgid ""
-"Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
-"using gdalwarp."
+msgid "Georeference, rectify, and import Terra-ASTER imagery and relative DEMs using gdalwarp."
 msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:5
@@ -4095,14 +3987,11 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:9
-msgid ""
-"List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate "
-"all bands"
+msgid "List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate all bands"
 msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:10
-msgid ""
-"Base name for output raster map (band number will be appended to base name)"
+msgid "Base name for output raster map (band number will be appended to base name)"
 msgstr ""
 #: ../locale/scriptstrings/r.in.srtm_to_translate.c:1
@@ -4172,10 +4061,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:15
-msgid ""
-"WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using "
-"native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS "
-"driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;"
+msgid "WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;"
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:17
@@ -4207,8 +4093,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:30
-msgid ""
-"Request data for this named region instead of the current region bounds"
+msgid "Request data for this named region instead of the current region bounds"
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:32
@@ -4226,9 +4111,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:35
-msgid ""
-"Capabilities file to parse (input). It is relevant for WMTS_GRASS and "
-"OnEarth_GRASS drivers"
+msgid "Capabilities file to parse (input). It is relevant for WMTS_GRASS and OnEarth_GRASS drivers"
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:36
@@ -4301,8 +4184,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
-msgid ""
-"Exports a raster map to a text file as x,y,z values based on cell centers."
+msgid "Exports a raster map to a text file as x,y,z values based on cell centers."
 msgstr ""
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
@@ -4339,9 +4221,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.plane_to_translate.c:1
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
+msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
 msgstr ""
 #: ../locale/scriptstrings/r.plane_to_translate.c:4
@@ -4365,9 +4245,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
+msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
 msgstr ""
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
@@ -4425,8 +4303,7 @@
 msgid "Name of shaded raster map"
 msgstr ""
-#: ../locale/scriptstrings/r.shade_to_translate.c:12
-#: ../raster/r.his/main.c:121
+#: ../locale/scriptstrings/r.shade_to_translate.c:12 ../raster/r.his/main.c:121
 msgid "Color to use instead of NULL values"
 msgstr ""
@@ -4434,15 +4311,12 @@
 msgid "Either a standard color name, R:G:B triplet, or \"none\""
 msgstr ""
-#: ../locale/scriptstrings/r.shade_to_translate.c:14
-#: ../raster/r.his/main.c:126
+#: ../locale/scriptstrings/r.shade_to_translate.c:14 ../raster/r.his/main.c:126
 msgid "Use colors from color tables for NULL values"
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:1
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
+msgid "Produces tilings of the source projection for use in the destination region and projection."
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:4
@@ -4454,8 +4328,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:6
-msgid ""
-"Name of region to use instead of current region for bounds and resolution"
+msgid "Name of region to use instead of current region for bounds and resolution"
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:7
@@ -4488,8 +4361,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.unpack_to_translate.c:1
-msgid ""
-"Imports a raster map as GRASS GIS specific archive file (packed with r.pack)"
+msgid "Imports a raster map as GRASS GIS specific archive file (packed with r.pack)"
 msgstr ""
 #: ../locale/scriptstrings/r.unpack_to_translate.c:5
@@ -4526,9 +4398,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:1
-msgid ""
-"Create a 3D raster map from an assemblage of many coordinates using "
-"univariate statistics"
+msgid "Create a 3D raster map from an assemblage of many coordinates using univariate statistics"
 msgstr ""
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:6
@@ -4611,9 +4481,7 @@
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:29
 #: ../raster/r.in.lidar/main.c:243 ../raster/r.in.xyz/main.c:321
-msgid ""
-"Discard <trim> percent of the smallest and <trim> percent of the largest "
-"observations"
+msgid "Discard <trim> percent of the smallest and <trim> percent of the largest observations"
 msgstr ""
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:31
@@ -4663,9 +4531,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
+msgid "Adds one or more columns to the attribute table connected to a given vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
@@ -4679,15 +4545,11 @@
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:11
-msgid ""
-"Types depend on database backend, but all support VARCHAR(), INT, DOUBLE "
-"PRECISION and DATE. Example: 'label varchar(250), value integer'"
+msgid "Types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE. Example: 'label varchar(250), value integer'"
 msgstr ""
-msgid ""
-"Creates and connects a new attribute table to a given layer of an existing "
-"vector map."
+msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
@@ -4748,8 +4610,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
+msgid "Drops a column from the attribute table connected to a given vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
@@ -4757,8 +4618,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.droprow_to_translate.c:1
-msgid ""
-"Removes a vector feature from a vector map through attribute selection."
+msgid "Removes a vector feature from a vector map through attribute selection."
 msgstr ""
 #: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
@@ -4774,8 +4634,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:1
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
+msgid "Renames a column in the attribute table connected to a given vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:5
@@ -4783,9 +4642,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
-msgid ""
-"Reconnects attribute tables for all vector maps from the current mapset to a"
-" new database."
+msgid "Reconnects attribute tables for all vector maps from the current mapset to a new database."
 msgstr ""
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
@@ -4817,9 +4674,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:1
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector"
-" map."
+msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.update_to_translate.c:1
@@ -4835,20 +4690,15 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.update_to_translate.c:7
-msgid ""
-"Name of other attribute column to query, can be combination of columns (e.g."
-" co1+col2)"
+msgid "Name of other attribute column to query, can be combination of columns (e.g. co1+col2)"
 msgstr ""
 #: ../locale/scriptstrings/v.db.update_to_translate.c:8
-msgid ""
-"Name of SQLite extension file for extra functions (SQLite backend only)"
+msgid "Name of SQLite extension file for extra functions (SQLite backend only)"
 msgstr ""
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:1
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number"
-" or attribute."
+msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
 msgstr ""
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:3
@@ -4875,9 +4725,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.import_to_translate.c:1
-msgid ""
-"Imports vector data into a GRASS vector map using OGR library and reprojects"
-" on the fly."
+msgid "Imports vector data into a GRASS vector map using OGR library and reprojects on the fly."
 msgstr ""
 #: ../locale/scriptstrings/v.import_to_translate.c:5
@@ -4905,8 +4753,7 @@
 #: ../locale/scriptstrings/v.import_to_translate.c:15
 #: ../vector/v.in.ogr/main.c:235
-msgid ""
-"Overrides encoding interpretation, useful when importing ESRI Shapefile"
+msgid "Overrides encoding interpretation, useful when importing ESRI Shapefile"
 msgstr ""
 #: ../locale/scriptstrings/v.import_to_translate.c:17
@@ -5029,9 +4876,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:8
-msgid ""
-"The given code must be supported by the server, consult the capabilities "
-"file"
+msgid "The given code must be supported by the server, consult the capabilities file"
 msgstr ""
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:9
@@ -5051,9 +4896,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:13
-msgid ""
-"Download server capabilities to 'wms_capabilities.xml' in the current "
-"directory and exit"
+msgid "Download server capabilities to 'wms_capabilities.xml' in the current directory and exit"
 msgstr ""
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:14
@@ -5061,9 +4904,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
-msgid ""
-"Calculates univariate statistics from a raster map based on a vector map and"
-" uploads statistics to new attribute columns."
+msgid "Calculates univariate statistics from a raster map based on a vector map and uploads statistics to new attribute columns."
 msgstr ""
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
@@ -5147,8 +4988,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.unpack_to_translate.c:1
-msgid ""
-"Imports a vector map as GRASS GIS specific archive file (packed with v.pack)"
+msgid "Imports a vector map as GRASS GIS specific archive file (packed with v.pack)"
 msgstr ""
 #: ../locale/scriptstrings/v.unpack_to_translate.c:6
@@ -5160,9 +5000,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.what.strds_to_translate.c:1
-msgid ""
-"Uploads space time raster dataset values at positions of vector points to "
-"the table."
+msgid "Uploads space time raster dataset values at positions of vector points to the table."
 msgstr ""
 #: ../locale/scriptstrings/v.what.strds_to_translate.c:5
@@ -5178,9 +5016,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.what.strds_to_translate.c:10
-msgid ""
-"Instead of creating a new vector map update the attribute table with "
-"value(s)"
+msgid "Instead of creating a new vector map update the attribute table with value(s)"
 msgstr ""
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:1
@@ -5317,21 +5153,15 @@
 msgstr ""
 #: ../locale/scriptstrings/t.support_to_translate.c:11
-msgid ""
-"Update the metadata information and spatial extent of registered maps from "
-"the GRASS spatial database"
+msgid "Update the metadata information and spatial extent of registered maps from the GRASS spatial database"
 msgstr ""
 #: ../locale/scriptstrings/t.support_to_translate.c:12
-msgid ""
-"Check for removed maps and delete them from the temporal database and all "
-"effected space time datasets"
+msgid "Check for removed maps and delete them from the temporal database and all effected space time datasets"
 msgstr ""
 #: ../locale/scriptstrings/t.support_to_translate.c:13
-msgid ""
-"Update metadata information, temporal and spatial extent from registered "
-"maps based on database entries."
+msgid "Update metadata information, temporal and spatial extent from registered maps based on database entries."
 msgstr ""
 #: ../locale/scriptstrings/t.topology_to_translate.c:1
@@ -5347,8 +5177,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.list_to_translate.c:1
-msgid ""
-"Lists space time datasets and maps registered in the temporal database."
+msgid "Lists space time datasets and maps registered in the temporal database."
 msgstr ""
 #: ../locale/scriptstrings/t.list_to_translate.c:4
@@ -5365,9 +5194,7 @@
 #: ../locale/scriptstrings/t.list_to_translate.c:9
 #: ../locale/scriptstrings/t.list_to_translate.c:12
-msgid ""
-"Columns number_of_maps and granularity only available for space time "
-"datasets"
+msgid "Columns number_of_maps and granularity only available for space time datasets"
 msgstr ""
 #: ../locale/scriptstrings/t.list_to_translate.c:10
@@ -5436,9 +5263,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.info_to_translate.c:10
-msgid ""
-"Print history information in human readable shell style for space time "
-"datasets"
+msgid "Print history information in human readable shell style for space time datasets"
 msgstr ""
 #: ../locale/scriptstrings/t.info_to_translate.c:11
@@ -5455,8 +5280,7 @@
 msgid "time management"
 msgstr ""
-#: ../locale/scriptstrings/t.merge_to_translate.c:4
-#: ../raster/r.patch/main.c:61
+#: ../locale/scriptstrings/t.merge_to_translate.c:4 ../raster/r.patch/main.c:61
 msgid "merge"
 msgstr ""
@@ -5483,9 +5307,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.remove_to_translate.c:12
-msgid ""
-"Remove all registered maps from the temporal and also from the spatial "
-"database"
+msgid "Remove all registered maps from the temporal and also from the spatial database"
 msgstr ""
 #: ../locale/scriptstrings/t.remove_to_translate.c:13
@@ -5493,9 +5315,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.sample_to_translate.c:1
-msgid ""
-"Samples the input space time dataset(s) with a sample space time dataset and"
-" print the result to stdout."
+msgid "Samples the input space time dataset(s) with a sample space time dataset and print the result to stdout."
 msgstr ""
 #: ../locale/scriptstrings/t.sample_to_translate.c:5
@@ -5511,9 +5331,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.sample_to_translate.c:10
-msgid ""
-"Do not use \",\" as this char is reserved to list several map ids in a "
-"sample granule"
+msgid "Do not use \",\" as this char is reserved to list several map ids in a sample granule"
 msgstr ""
 #: ../locale/scriptstrings/t.sample_to_translate.c:12
@@ -5521,9 +5339,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:1
-msgid ""
-"Assigns timestamps and registers raster, vector and raster3d maps in a space"
-" time dataset."
+msgid "Assigns timestamps and registers raster, vector and raster3d maps in a space time dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:4
@@ -5550,9 +5366,7 @@
 #: ../locale/scriptstrings/t.register_to_translate.c:14
 #: ../locale/scriptstrings/t.register_to_translate.c:17
-msgid ""
-"Format for absolute time: \"yyyy-mm-dd HH:MM:SS +HHMM\", relative time is of"
-" type integer."
+msgid "Format for absolute time: \"yyyy-mm-dd HH:MM:SS +HHMM\", relative time is of type integer."
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:15
@@ -5580,10 +5394,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:23
-msgid ""
-"Time increment between maps for creation of valid time intervals (format for"
-" absolute time: NNN seconds, minutes, hours, days, weeks, months, years; "
-"format for relative time is of type integer: 5)"
+msgid "Time increment between maps for creation of valid time intervals (format for absolute time: NNN seconds, minutes, hours, days, weeks, months, years; format for relative time is of type integer: 5)"
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:25
@@ -5591,15 +5402,11 @@
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:27
-msgid ""
-"Create an interval (start and end time) in case an increment and the start "
-"time are provided"
+msgid "Create an interval (start and end time) in case an increment and the start time are provided"
 msgstr ""
 #: ../locale/scriptstrings/t.unregister_to_translate.c:1
-msgid ""
-"Unregisters raster, vector and raster3d maps from the temporal database or a"
-" specific space time dataset."
+msgid "Unregisters raster, vector and raster3d maps from the temporal database or a specific space time dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.unregister_to_translate.c:4
@@ -5621,15 +5428,11 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:6
-msgid ""
-"Input space time raster dataset that defines the lower threshold, values "
-"lower this threshold are excluded from accumulation"
+msgid "Input space time raster dataset that defines the lower threshold, values lower this threshold are excluded from accumulation"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:7
-msgid ""
-"Input space time raster dataset that defines the upper threshold, values "
-"upper this threshold are excluded from accumulation"
+msgid "Input space time raster dataset that defines the upper threshold, values upper this threshold are excluded from accumulation"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:8
@@ -5691,9 +5494,7 @@
 #: ../locale/scriptstrings/t.vect.extract_to_translate.c:7
 #: ../locale/scriptstrings/t.vect.algebra_to_translate.c:8
 #: ../locale/scriptstrings/t.vect.import_to_translate.c:7
-msgid ""
-"A numerical suffix separated by an underscore will be attached to create a "
-"unique identifier"
+msgid "A numerical suffix separated by an underscore will be attached to create a unique identifier"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:15
@@ -5706,16 +5507,11 @@
 #: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:10
 #: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:9
 #: ../locale/scriptstrings/t.vect.extract_to_translate.c:8
-msgid ""
-"Suffix to add at basename: set 'gran' for granularity, 'time' for the full "
-"time format, 'num' for numerical suffix with a specific number of digits "
-"(default %05)"
+msgid "Suffix to add at basename: set 'gran' for granularity, 'time' for the full time format, 'num' for numerical suffix with a specific number of digits (default %05)"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:16
-msgid ""
-"Use these limits in case lower and/or upper input  space time raster "
-"datasets are not defined or contain NULL values"
+msgid "Use these limits in case lower and/or upper input  space time raster datasets are not defined or contain NULL values"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:17
@@ -5727,22 +5523,16 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:19
-msgid ""
-"This method will be applied to compute the accumulative values from the "
-"input maps in a single granule"
+msgid "This method will be applied to compute the accumulative values from the input maps in a single granule"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:20
-msgid ""
-"Growing Degree Days or Winkler indices; Mean: sum(input maps)/(number of "
-"input maps); Biologically Effective Degree Days; Huglin Heliothermal index"
+msgid "Growing Degree Days or Winkler indices; Mean: sum(input maps)/(number of input maps); Biologically Effective Degree Days; Huglin Heliothermal index"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:21
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:19
-msgid ""
-"Register empty maps in the output space time raster dataset, otherwise they "
-"will be deleted"
+msgid "Register empty maps in the output space time raster dataset, otherwise they will be deleted"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:22
@@ -5751,72 +5541,47 @@
 msgstr ""
-msgid ""
-"Detects accumulation patterns in temporally accumulated space time raster "
-"datasets created by t.rast.accumulate."
+msgid "Detects accumulation patterns in temporally accumulated space time raster datasets created by t.rast.accumulate."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:6
-msgid ""
-"Input space time raster dataset that specifies the minimum values to detect "
-"the accumulation pattern"
+msgid "Input space time raster dataset that specifies the minimum values to detect the accumulation pattern"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:7
-msgid ""
-"Input space time raster dataset that specifies the maximum values to detect "
+msgid "Input space time raster dataset that specifies the maximum values to detect the accumulation pattern"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:8
-msgid ""
-"The output space time raster dataset that stores the occurrence of the the "
-"accumulation pattern using the provided data range"
+msgid "The output space time raster dataset that stores the occurrence of the the accumulation pattern using the provided data range"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:9
-msgid ""
-"The output space time raster dataset that stores the indication of the "
-"start, intermediate and end of the specified data range"
+msgid "The output space time raster dataset that stores the indication of the start, intermediate and end of the specified data range"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:16
-msgid ""
-"time format, 'count' for numerical suffix with a specific number of digits "
-"(default %05)"
+msgid "Suffix to add at basename: set 'gran' for granularity, 'time' for the full time format, 'count' for numerical suffix with a specific number of digits (default %05)"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:17
-msgid ""
-"The minimum and maximum value of the occurrence of accumulated values, these"
-" values will be used if the min/max space time raster datasets are not "
-"specified"
+msgid "The minimum and maximum value of the occurrence of accumulated values, these values will be used if the min/max space time raster datasets are not specified"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:18
-msgid ""
-"The user defined values that indicate start, intermediate and end status in "
-"the indicator output space time raster dataset"
+msgid "The user defined values that indicate start, intermediate and end status in the indicator output space time raster dataset"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:1
-msgid ""
-"Aggregates temporally the maps of a space time raster dataset by a user "
-"defined granularity."
+msgid "Aggregates temporally the maps of a space time raster dataset by a user defined granularity."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:7
-msgid ""
-"Either a numerical suffix or the start time (s-flag) separated by an "
-"underscore will be attached to create a unique identifier"
+msgid "Either a numerical suffix or the start time (s-flag) separated by an underscore will be attached to create a unique identifier"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:9
-msgid ""
-"Aggregation granularity, format absolute time \"x years, x months, x weeks, "
-"x days, x hours, x minutes, x seconds\" or an integer value for relative "
-"time"
+msgid "Aggregation granularity, format absolute time \"x years, x months, x weeks, x days, x hours, x minutes, x seconds\" or an integer value for relative time"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:10
@@ -5829,9 +5594,7 @@
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:11
 #: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:12
-msgid ""
-"Offset that is used to create the output map ids, output map id is generated"
-" as: basename_ (count + offset)"
+msgid "Offset that is used to create the output map ids, output map id is generated as: basename_ (count + offset)"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:12
@@ -5855,15 +5618,11 @@
 msgstr ""
-msgid ""
-"Aggregates data of an existing space time raster dataset using the time "
-"intervals of a second space time dataset."
+msgid "Aggregates data of an existing space time raster dataset using the time intervals of a second space time dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:6
-msgid ""
-"Time intervals from this space time dataset (raster, vector or raster3d) are"
-" used for aggregation computation"
+msgid "Time intervals from this space time dataset (raster, vector or raster3d) are used for aggregation computation"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:7
@@ -5878,9 +5637,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.colors_to_translate.c:1
-msgid ""
-"Creates/modifies the color table associated with each raster map of the "
-"space time raster dataset."
+msgid "Creates/modifies the color table associated with each raster map of the space time raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.colors_to_translate.c:6
@@ -5959,9 +5716,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:1
-msgid ""
-"Produces a space time vector dataset of specified contours from a space time"
-" raster dataset."
+msgid "Produces a space time vector dataset of specified contours from a space time raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:3
@@ -5994,9 +5749,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:15
-msgid ""
-"Number of r.contour processes to run in parallel, more than 1 process works "
-"only in conjunction with flag -t"
+msgid "Number of r.contour processes to run in parallel, more than 1 process works only in conjunction with flag -t"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:16
@@ -6014,9 +5767,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.univar_to_translate.c:1
-msgid ""
-"Calculates univariate statistics from the non-null cells for each registered"
-" raster map of a space time raster dataset."
+msgid "Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.univar_to_translate.c:9
@@ -6028,9 +5779,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.univar_to_translate.c:10
-msgid ""
-"Ignore the current region settings and use the raster map regions for univar"
-" statistical calculation"
+msgid "Ignore the current region settings and use the raster map regions for univar statistical calculation"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.univar_to_translate.c:11
@@ -6053,15 +5802,11 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.list_to_translate.c:13
-msgid ""
-"The granule to be used for listing. The granule must be specified as string "
-"eg.: absolute time \"1 months\" or relative time \"1\""
+msgid "The granule to be used for listing. The granule must be specified as string eg.: absolute time \"1 months\" or relative time \"1\""
 msgstr ""
 #: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:1
-msgid ""
-"Performs spatio-temporal mapcalc expressions on temporally sampled maps of "
-"space time raster datasets."
+msgid "Performs spatio-temporal mapcalc expressions on temporally sampled maps of space time raster datasets."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:6
@@ -6078,21 +5823,15 @@
 #: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:12
 #: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:11
 #: ../locale/scriptstrings/t.vect.algebra_to_translate.c:9
-msgid ""
-"Check the spatial topology of temporally related maps and process only "
-"spatially related maps"
+msgid "Check the spatial topology of temporally related maps and process only spatially related maps"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.algebra_to_translate.c:1
-msgid ""
-"Apply temporal and spatial operations on space time raster datasets using "
-"temporal raster algebra."
+msgid "Apply temporal and spatial operations on space time raster datasets using temporal raster algebra."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.algebra_to_translate.c:6
-msgid ""
-"r.mapcalc expression for temporal and spatial analysis of space time raster "
-"datasets"
+msgid "r.mapcalc expression for temporal and spatial analysis of space time raster datasets"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.algebra_to_translate.c:12
@@ -6102,15 +5841,11 @@
 #: ../locale/scriptstrings/t.rast.algebra_to_translate.c:13
 #: ../locale/scriptstrings/t.select_to_translate.c:9
-msgid ""
-"Perform a dry run, compute all dependencies and module calls but don't run "
-"them"
+msgid "Perform a dry run, compute all dependencies and module calls but don't run them"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:1
-msgid ""
-"Performs a neighborhood analysis for each map in a space time raster "
-"dataset."
+msgid "Performs a neighborhood analysis for each map in a space time raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:6
@@ -6127,9 +5862,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.series_to_translate.c:1
-msgid ""
-"Performs different aggregation algorithms from r.series on all or a subset "
-"of raster maps in a space time raster dataset."
+msgid "Performs different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.series_to_translate.c:4
@@ -6144,15 +5877,12 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.series_to_translate.c:9
-msgid ""
-"Do not assign the space time raster dataset start and end time to the output"
-" map"
+msgid "Do not assign the space time raster dataset start and end time to the output map"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.series_to_translate.c:10
 #: ../raster/r.resamp.filter/main.c:431 ../raster/r.series/main.c:187
-#: ../raster/r.series.accumulate/main.c:159
-#: ../raster/r.resamp.stats/main.c:288
+#: ../raster/r.series.accumulate/main.c:159 ../raster/r.resamp.stats/main.c:288
 msgid "Propagate NULLs"
 msgstr ""
@@ -6179,9 +5909,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.export_to_translate.c:10
-msgid ""
-"Supported are GTiff, AAIGrid via r.out.gdal and the GRASS package format of "
-"r.pack"
+msgid "Supported are GTiff, AAIGrid via r.out.gdal and the GRASS package format of r.pack"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.export_to_translate.c:11
@@ -6212,9 +5940,7 @@
 #: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:9
 #: ../raster/r.out.vtk/parameters.c:59
-msgid ""
-"Create VTK point data instead of VTK cell data (if no elevation map is "
-"given)"
+msgid "Create VTK point data instead of VTK cell data (if no elevation map is given)"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:10
@@ -6223,9 +5949,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:11
-msgid ""
-"Export files using the space time dataset granularity for equidistant time "
-"between maps, where statement will be ignored"
+msgid "Export files using the space time dataset granularity for equidistant time between maps, where statement will be ignored"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:1
@@ -6239,9 +5963,7 @@
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:11
 #: ../locale/scriptstrings/t.vect.import_to_translate.c:11
-msgid ""
-"Create a new location and import the data into it. Do not run this module in"
-" parallel or interrupt it when a new location should be created"
+msgid "Create a new location and import the data into it. Do not run this module in parallel or interrupt it when a new location should be created"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:14
@@ -6258,14 +5980,11 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:19
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not"
-" import the space time raster datasets."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the space time raster datasets."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:1
-msgid ""
-"Replaces gaps in a space time raster dataset with interpolated raster maps."
+msgid "Replaces gaps in a space time raster dataset with interpolated raster maps."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:9
@@ -6273,8 +5992,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:10
-msgid ""
-"Assign the space time raster dataset start and end time to the output map"
+msgid "Assign the space time raster dataset start and end time to the output map"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.extract_to_translate.c:1
@@ -6308,9 +6026,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:12
-msgid ""
-"Number of r.to.vect processes to run in parallel, more than 1 process works "
+msgid "Number of r.to.vect processes to run in parallel, more than 1 process works only in conjunction with flag -t"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:15
@@ -6344,9 +6060,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:1
-msgid ""
-"Sample a space time raster dataset at specific vector point coordinates and "
-"write the output to stdout using different layouts"
+msgid "Sample a space time raster dataset at specific vector point coordinates and write the output to stdout using different layouts"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:6
@@ -6358,9 +6072,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:9
-msgid ""
-"The layout of the output. One point per row (row), one point per column "
-"(col), all timsteps in one row (timerow)"
+msgid "The layout of the output. One point per row (row), one point per column (col), all timsteps in one row (timerow)"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:10
@@ -6403,9 +6115,7 @@
 msgstr ""
-msgid ""
-"Performs r3.mapcalc expressions on maps of sampled space time 3D raster "
-"datasets."
+msgid "Performs r3.mapcalc expressions on maps of sampled space time 3D raster datasets."
 msgstr ""
 #: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:7
@@ -6413,21 +6123,15 @@
 msgstr ""
-msgid ""
-"Apply temporal and spatial operations on space time 3D raster datasets using"
-" temporal 3D raster algebra."
+msgid "Apply temporal and spatial operations on space time 3D raster datasets using temporal 3D raster algebra."
 msgstr ""
 #: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:7
-msgid ""
-"Algebraic expression for temporal and spatial analysis of space time 3D "
-"raster datasets"
+msgid "Algebraic expression for temporal and spatial analysis of space time 3D raster datasets"
 msgstr ""
 #: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:1
-msgid ""
-" 3D raster map of a space time 3D raster dataset."
+msgid "Calculates univariate statistics from the non-null cells for each registered 3D raster map of a space time 3D raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rename_to_translate.c:1
@@ -6440,9 +6144,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.select_to_translate.c:1
-msgid ""
-"Select maps from space time datasets by topological relationships to other "
-"space time datasets using temporal algebra."
+msgid "Select maps from space time datasets by topological relationships to other space time datasets using temporal algebra."
 msgstr ""
 #: ../locale/scriptstrings/t.select_to_translate.c:7
@@ -6450,9 +6152,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.select_to_translate.c:8
-msgid ""
-"Check the spatial topology of temporally related maps and select only "
+msgid "Check the spatial topology of temporally related maps and select only spatially related maps"
 msgstr ""
 #: ../locale/scriptstrings/t.snap_to_translate.c:1
@@ -6481,9 +6181,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.shift_to_translate.c:10
-msgid ""
-"Format absolute time: \"x years, x months, x weeks, x days, x hours, x "
-"minutes, x seconds\", relative time is of type integer"
+msgid "Format absolute time: \"x years, x months, x weeks, x days, x hours, x minutes, x seconds\", relative time is of type integer"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.list_to_translate.c:1
@@ -6491,8 +6189,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.vect.db.select_to_translate.c:1
-msgid ""
-"Prints attributes of vector maps registered in a space time vector dataset."
+msgid "Prints attributes of vector maps registered in a space time vector dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.db.select_to_translate.c:6
@@ -6502,8 +6199,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.vect.export_to_translate.c:1
-msgid ""
-"Exports a space time vector dataset as GRASS GIS specific archive file."
+msgid "Exports a space time vector dataset as GRASS GIS specific archive file."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.export_to_translate.c:6
@@ -6523,9 +6219,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.vect.extract_to_translate.c:9
-msgid ""
-"The number of v.extract processes to run in parallel. Use only if database "
-"backend is used which supports concurrent writing"
+msgid "The number of v.extract processes to run in parallel. Use only if database backend is used which supports concurrent writing"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.extract_to_translate.c:10
@@ -6533,62 +6227,43 @@
 msgstr ""
 #: ../locale/scriptstrings/t.vect.algebra_to_translate.c:1
-msgid ""
-"Apply temporal and spatial operations on space time vector datasets using "
-"temporal vector algebra."
+msgid "Apply temporal and spatial operations on space time vector datasets using temporal vector algebra."
 msgstr ""
-msgid ""
-"Imports a space time vector dataset from a GRASS GIS specific archive file."
+msgid "Imports a space time vector dataset from a GRASS GIS specific archive file."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.import_to_translate.c:15
-msgid ""
-" import the space time vector datasets."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the space time vector datasets."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:1
-msgid ""
-"Stores raster map values at spatial and temporal positions of vector points "
-"as vector attributes."
+msgid "Stores raster map values at spatial and temporal positions of vector points as vector attributes."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:6
-msgid ""
-"Name of the vector column to be created and to store sampled raster values"
+msgid "Name of the vector column to be created and to store sampled raster values"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:7
-msgid ""
-"The use of a column name forces t.vect.what.rast to sample only values from "
-"the first map found in an interval. Otherwise the raster map names are used "
-"as column names"
+msgid "The use of a column name forces t.vect.what.rast to sample only values from the first map found in an interval. Otherwise the raster map names are used as column names"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:1
-msgid ""
-"Observes specific locations in a space time raster dataset over a period of "
-"time using vector points."
+msgid "Observes specific locations in a space time raster dataset over a period of time using vector points."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:6
-msgid ""
-"Name of the new created vector map that stores the sampled values in "
-"different layers"
+msgid "Name of the new created vector map that stores the sampled values in different layers"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:7
-msgid ""
-"Names of the vector columns to be created and to store sampled raster "
-"values, one name for each STRDS"
+msgid "Names of the vector columns to be created and to store sampled raster values, one name for each STRDS"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.univar_to_translate.c:1
-msgid ""
-"Calculates univariate statistics of attributes for each registered vector "
-"map of a space time vector dataset"
+msgid "Calculates univariate statistics of attributes for each registered vector map of a space time vector dataset"
 msgstr ""
 #: ../general/g.region/printwindow.c:236 ../general/g.region/printwindow.c:492
@@ -6631,15 +6306,11 @@
 msgstr ""
 #: ../general/g.region/printwindow.c:401
-msgid ""
-"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
-"the -p flag instead."
+msgid "You are in a simple XY location, projection to Lat/Lon is not possible. Use the -p flag instead."
 msgstr ""
 #: ../general/g.region/printwindow.c:626
-msgid ""
-"WGS84 output not possible as this location does not contain datum "
-"transformation parameters. Try running g.setproj."
+msgid "WGS84 output not possible as this location does not contain datum transformation parameters. Try running g.setproj."
 msgstr ""
 #: ../general/g.region/printwindow.c:772
@@ -6723,9 +6394,7 @@
 msgstr ""
 #: ../general/g.region/main.c:129
-msgid ""
-"The difference between the projection's grid north and true north, measured "
-"at the center coordinates of the current region."
+msgid "The difference between the projection's grid north and true north, measured at the center coordinates of the current region."
 msgstr ""
 #: ../general/g.region/main.c:135
@@ -6737,9 +6406,7 @@
 msgstr ""
 #: ../general/g.region/main.c:152
-msgid ""
-"Align region to resolution (default = align to bounds, works only for 2D "
-"resolution)"
+msgid "Align region to resolution (default = align to bounds, works only for 2D resolution)"
 msgstr ""
 #: ../general/g.region/main.c:158
@@ -6848,8 +6515,7 @@
 #: ../general/g.region/main.c:797 ../vector/v.vol.rst/main.c:615
 #: ../vector/v.colors/main.c:312 ../doc/raster/r.example/main.c:105
 #: ../imagery/i.gensigset/parse.c:44 ../imagery/i.gensig/parse.c:38
-#: ../imagery/i.pca/main.c:139
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:155
+#: ../imagery/i.pca/main.c:139 ../imagery/i.ortho.photo/i.ortho.elev/main.c:155
 #: ../misc/m.nviz.image/surface.c:50 ../misc/m.nviz.image/surface.c:107
 #: ../raster/r.walk/main.c:435 ../raster/r.walk/main.c:440
 #: ../raster/r.walk/main.c:801 ../raster/r.category/main.c:119
@@ -6941,8 +6607,7 @@
 msgstr ""
 #: ../general/g.region/main.c:821
-msgid ""
-"Unable to change default region. The current mapset is not <PERMANENT>."
+msgid "Unable to change default region. The current mapset is not <PERMANENT>."
 msgstr ""
 #: ../general/g.region/main.c:838 ../raster/r.in.lidar/main.c:519
@@ -6967,9 +6632,7 @@
 msgstr ""
 #: ../general/g.mapsets/main.c:67
-msgid ""
-"Affects the user's access to data existing under the other mapsets in the "
-"current location."
+msgid "Affects the user's access to data existing under the other mapsets in the current location."
 msgstr ""
 #: ../general/g.mapsets/main.c:73
@@ -7066,9 +6729,7 @@
 msgstr ""
 #: ../general/g.remove/main.c:73
-msgid ""
-"Removes data base element files from the user's current mapset using the "
-"search pattern."
+msgid "Removes data base element files from the user's current mapset using the search pattern."
 msgstr ""
 #: ../general/g.remove/main.c:83 ../general/g.remove/main.c:91
@@ -7134,9 +6795,7 @@
 #: ../general/g.remove/main.c:267
 #, c-format
-msgid ""
-"Nothing removed. You must use the force flag (-%c) to actually remove them. "
-"Exiting."
+msgid "Nothing removed. You must use the force flag (-%c) to actually remove them. Exiting."
 msgstr ""
 #: ../general/g.remove/construct_pattern.c:37
@@ -7170,8 +6829,7 @@
 msgstr ""
 #: ../general/g.message/main.c:37
-msgid ""
-"Prints a message, warning, progress info, or fatal error in the GRASS way."
+msgid "Prints a message, warning, progress info, or fatal error in the GRASS way."
 msgstr ""
 #: ../general/g.message/main.c:39
@@ -7246,9 +6904,7 @@
 msgstr ""
 #: ../general/g.mkfontcap/main.c:73
-msgid ""
-"Generates the font configuration file by scanning various directories for "
-"fonts."
+msgid "Generates the font configuration file by scanning various directories for fonts."
 msgstr ""
 #: ../general/g.mkfontcap/main.c:79
@@ -7256,8 +6912,7 @@
 msgstr ""
 #: ../general/g.mkfontcap/main.c:84
-msgid ""
-"Write font configuration file to standard output instead of $GISBASE/etc"
+msgid "Write font configuration file to standard output instead of $GISBASE/etc"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:91
@@ -7265,21 +6920,16 @@
 msgstr ""
 #: ../general/g.mkfontcap/main.c:93
-msgid ""
-"Comma-separated list of extra directories to scan for Freetype-compatible "
-"fonts as well as the defaults (see documentation)"
+msgid "Comma-separated list of extra directories to scan for Freetype-compatible fonts as well as the defaults (see documentation)"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:110
 #, c-format
-msgid ""
-"Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
+msgid "Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:122
-msgid ""
-"This GRASS installation was compiled without Freetype support, extradirs "
-"parameter ignored"
+msgid "This GRASS installation was compiled without Freetype support, extradirs parameter ignored"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:149
@@ -7317,9 +6967,7 @@
 #: ../general/g.findfile/main.c:97
 #, c-format
-msgid ""
-"Parameter 'file' contains reference to <%s> mapset, but mapset parameter "
-"<%s> does not correspond"
+msgid "Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%s> does not correspond"
 msgstr ""
 #: ../general/g.gisenv/main.c:45
@@ -7721,9 +7369,7 @@
 msgstr ""
 #: ../general/g.list/main.c:69
-msgid ""
-"Lists available GRASS data base files of the user-specified data type "
-"optionally using the search pattern."
+msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
 msgstr ""
 #: ../general/g.list/main.c:85
@@ -7825,10 +7471,7 @@
 msgstr ""
 #: ../general/g.gui/main.c:72
-msgid ""
-"By default the GUI starts in the background and control is immediately "
-"returned to the caller. When GUI runs in foregreound, it blocks the command "
-"line"
+msgid "By default the GUI starts in the background and control is immediately returned to the caller. When GUI runs in foregreound, it blocks the command line"
 msgstr ""
 #: ../general/g.gui/main.c:78
@@ -8014,10 +7657,7 @@
 msgstr ""
 #: ../general/g.setproj/main.c:456
-msgid ""
-"But if you change zone, all the existing data will be interpreted by "
-"projection software. GRASS will not automatically re-project or even change "
-"the headers for existing maps."
+msgid "But if you change zone, all the existing data will be interpreted by projection software. GRASS will not automatically re-project or even change the headers for existing maps."
 msgstr ""
 #: ../general/g.setproj/main.c:461
@@ -8148,9 +7788,7 @@
 msgstr ""
 #: ../general/g.copy/main.c:44
-msgid ""
-"Copies available data files in the current mapset search path to the user's "
-"current mapset."
+msgid "Copies available data files in the current mapset search path to the user's current mapset."
 msgstr ""
 #: ../general/g.copy/main.c:51
@@ -8246,16 +7884,11 @@
 #: ../general/g.proj/create.c:40
 #, c-format
-msgid ""
-"You must select the PERMANENT mapset before updating the current location's "
-"projection (current mapset is <%s>)"
+msgid "You must select the PERMANENT mapset before updating the current location's projection (current mapset is <%s>)"
 msgstr ""
 #: ../general/g.proj/create.c:66
-msgid ""
-"Default region was updated to the new projection, but if you have multiple "
-"mapsets `g.region -d` should be run in each to update the region from the "
-"default"
+msgid "Default region was updated to the new projection, but if you have multiple mapsets `g.region -d` should be run in each to update the region from the default"
 msgstr ""
 #: ../general/g.proj/create.c:70
@@ -8272,9 +7905,7 @@
 msgstr ""
 #: ../general/g.proj/main.c:69
-msgid ""
-"Prints or modifies GRASS projection information files (in various co-"
-"ordinate system descriptions)."
+msgid "Prints or modifies GRASS projection information files (in various co-ordinate system descriptions)."
 msgstr ""
 #: ../general/g.proj/main.c:72
@@ -8302,8 +7933,7 @@
 msgstr ""
 #: ../general/g.proj/main.c:106
-msgid ""
-"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
+msgid "Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
 msgstr ""
 #: ../general/g.proj/main.c:116
@@ -8349,9 +7979,7 @@
 msgstr ""
 #: ../general/g.proj/main.c:188
-msgid ""
-"Force override of datum transformation information in input co-ordinate "
-"system"
+msgid "Force override of datum transformation information in input co-ordinate system"
 msgstr ""
 #: ../general/g.proj/main.c:193 ../raster/r.null/main.c:74
@@ -8427,9 +8055,7 @@
 #: ../general/g.proj/input.c:259
 #, c-format
-msgid ""
-"Read of file %s was successful, but it did not contain projection "
-"information. 'XY (unprojected)' will be used"
+msgid "Read of file %s was successful, but it did not contain projection information. 'XY (unprojected)' will be used"
 msgstr ""
 #: ../general/g.proj/output.c:146
@@ -8505,15 +8131,11 @@
 #: ../general/g.version/main.c:172
 #, c-format
-msgid ""
-"Cannot determine GRASS libgis version and date number. The GRASS build might"
-" be broken. Report this to developers or packagers.\n"
+msgid "Cannot determine GRASS libgis version and date number. The GRASS build might be broken. Report this to developers or packagers.\n"
 msgstr ""
 #: ../general/g.version/main.c:179
-msgid ""
-"GRASS GIS libgis version and date number don't have the expected format. "
-"Trying to print the original strings..."
+msgid "GRASS GIS libgis version and date number don't have the expected format. Trying to print the original strings..."
 msgstr ""
 #: ../general/g.version/main.c:181
@@ -8543,8 +8165,7 @@
 msgstr ""
 #: ../general/g.mapset/main.c:52
-msgid ""
-"Optionally create new mapset or list available mapsets in given location."
+msgid "Optionally create new mapset or list available mapsets in given location."
 msgstr ""
 #: ../general/g.mapset/main.c:56
@@ -8607,8 +8228,7 @@
 msgstr ""
 #: ../general/g.mapset/main.c:205
-msgid ""
-"Mapset switched. Your shell continues to use the history for the old mapset"
+msgid "Mapset switched. Your shell continues to use the history for the old mapset"
 msgstr ""
 #: ../general/g.mapset/main.c:210
@@ -8726,9 +8346,7 @@
 msgstr ""
 #: ../vector/v.extract/extract.c:228
-msgid ""
-"Topology level required for extracting areas for OGR layers. Areas will be "
-"not processed."
+msgid "Topology level required for extracting areas for OGR layers. Areas will be not processed."
 msgstr ""
 #: ../vector/v.extract/main.c:81 ../vector/v.perturb/main.c:65
@@ -8739,9 +8357,7 @@
 msgstr ""
 #: ../vector/v.extract/main.c:83
-msgid ""
-"Selects vector features from an existing vector map and creates a new vector"
-" map containing only the selected features."
+msgid "Selects vector features from an existing vector map and creates a new vector map containing only the selected features."
 msgstr ""
 #: ../vector/v.extract/main.c:88
@@ -8798,9 +8414,7 @@
 #: ../vector/v.extract/main.c:161
 #, c-format
-msgid ""
-"Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only"
-" one of them."
+msgid "Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only one of them."
 msgstr ""
 #: ../vector/v.extract/main.c:208
@@ -8851,9 +8465,7 @@
 msgstr[1] ""
 #: ../vector/v.extract/main.c:286
-msgid ""
-"This map has no categories attached. Use v.category to attach categories to "
-"this vector map."
+msgid "This map has no categories attached. Use v.category to attach categories to this vector map."
 msgstr ""
 #: ../vector/v.extract/main.c:293
@@ -8862,16 +8474,12 @@
 #: ../vector/v.extract/main.c:297
 #, c-format
-msgid ""
-"Random category count must be smaller than feature count. There are only %d "
-"features of type(s): %s"
+msgid "Random category count must be smaller than feature count. There are only %d features of type(s): %s"
 msgstr ""
 #: ../vector/v.extract/main.c:320
 #, c-format
-msgid ""
-"Random category count is larger or equal to uniq <%s> feature category count"
-" %d"
+msgid "Random category count is larger or equal to uniq <%s> feature category count %d"
 msgstr ""
 #: ../vector/v.extract/main.c:354
@@ -8920,10 +8528,10 @@
 msgstr ""
 #: ../vector/v.generalize/network.c:89 ../vector/v.net.spanningtree/main.c:124
-#: ../vector/v.net.timetable/main.c:405
-#: ../vector/v.net.connectivity/main.c:178 ../vector/v.net.flow/main.c:226
-#: ../vector/v.net.centrality/main.c:284 ../vector/v.net.distance/main.c:264
-#: ../vector/v.net.bridge/main.c:134 ../vector/v.net.components/main.c:163
+#: ../vector/v.net.timetable/main.c:405 ../vector/v.net.connectivity/main.c:178
+#: ../vector/v.net.flow/main.c:226 ../vector/v.net.centrality/main.c:284
+#: ../vector/v.net.distance/main.c:264 ../vector/v.net.bridge/main.c:134
+#: ../vector/v.net.components/main.c:163
 #, c-format
 msgid "Unable to build graph for vector map <%s>"
 msgstr ""
@@ -8974,9 +8582,7 @@
 msgstr ""
 #: ../vector/v.generalize/main.c:102
-msgid ""
-"Lines and boundaries causing errors (collapsed to a point or topology "
-"errors)"
+msgid "Lines and boundaries causing errors (collapsed to a point or topology errors)"
 msgstr ""
 #: ../vector/v.generalize/main.c:126
@@ -9044,8 +8650,7 @@
 msgstr ""
 #: ../vector/v.generalize/main.c:164
-msgid ""
-"Percentage of the points in the output of 'douglas_reduction' algorithm"
+msgid "Percentage of the points in the output of 'douglas_reduction' algorithm"
 msgstr ""
 #: ../vector/v.generalize/main.c:173
@@ -9145,8 +8750,7 @@
 #: ../vector/v.generalize/main.c:567
 #, c-format
-msgid ""
-"%d boundaries were not modified because modification would damage topology"
+msgid "%d boundaries were not modified because modification would damage topology"
 msgstr ""
 #: ../vector/v.generalize/main.c:570
@@ -9156,8 +8760,7 @@
 #: ../vector/v.generalize/main.c:591
 #, c-format
-msgid ""
-"Number of vertices for selected features %s from %d to %d (%d%% remaining)"
+msgid "Number of vertices for selected features %s from %d to %d (%d%% remaining)"
 msgstr ""
 #: ../vector/v.generalize/main.c:592
@@ -9218,8 +8821,7 @@
 msgstr ""
 #: ../vector/v.net/args.c:42
-msgid ""
-"connect still unconnected points to vector network by inserting new line(s)"
+msgid "connect still unconnected points to vector network by inserting new line(s)"
 msgstr ""
 #: ../vector/v.net/args.c:44
@@ -9227,14 +8829,11 @@
 msgstr ""
 #: ../vector/v.net/args.c:46
-msgid ""
-"print to standard output {line_category start_point_category "
-"end_point_category}"
+msgid "print to standard output {line_category start_point_category end_point_category}"
 msgstr ""
 #: ../vector/v.net/args.c:48
-msgid ""
-"print to standard output {point_category line_category[,line_category...]}"
+msgid "print to standard output {point_category line_category[,line_category...]}"
 msgstr ""
 #: ../vector/v.net/args.c:50
@@ -9305,9 +8904,7 @@
 msgstr ""
 #: ../vector/v.net/args.c:99
-msgid ""
-"For operation 'connect'. By default, a new line from the point to the "
-"network is created."
+msgid "For operation 'connect'. By default, a new line from the point to the network is created."
 msgstr ""
 #: ../vector/v.net/args.c:103
@@ -9315,9 +8912,7 @@
 msgstr ""
 #: ../vector/v.net/args.c:106
-msgid ""
-"Layer where turntable will be attached. Format: layer number[/layer "
-"name].Required for operation 'turntable'."
+msgid "Layer where turntable will be attached. Format: layer number[/layer name].Required for operation 'turntable'."
 msgstr ""
 #: ../vector/v.net/args.c:114 ../vector/v.net.alloc/main.c:143
@@ -9327,10 +8922,7 @@
 msgstr ""
 #: ../vector/v.net/args.c:117
-msgid ""
-"Layer with unique categories for every line in arc_layer and point on every "
-"node.  The categories are used in turntable. Format: layer number[/layer "
-"name]. Required for operation 'turntable'."
+msgid "Layer with unique categories for every line in arc_layer and point on every node.  The categories are used in turntable. Format: layer number[/layer name]. Required for operation 'turntable'."
 msgstr ""
 #: ../vector/v.net/args.c:146
@@ -9512,9 +9104,7 @@
 msgstr ""
 #: ../vector/v.voronoi/main.c:127
-msgid ""
-"Creates a Voronoi diagram in current region from an input vector map "
-"containing points or centroids."
+msgid "Creates a Voronoi diagram in current region from an input vector map containing points or centroids."
 msgstr ""
 #: ../vector/v.voronoi/main.c:131 ../vector/v.sample/main.c:82
@@ -9527,9 +9117,7 @@
 msgstr ""
 #: ../vector/v.voronoi/main.c:142
-msgid ""
-"Applies to input areas only. Smaller values produce smoother output but can "
-"cause numerical instability."
+msgid "Applies to input areas only. Smaller values produce smoother output but can cause numerical instability."
 msgstr ""
 #: ../vector/v.voronoi/main.c:149
@@ -9537,9 +9125,7 @@
 msgstr ""
 #: ../vector/v.voronoi/main.c:150
-msgid ""
-"Applies only to skeleton extraction. Default = -1 will extract the center "
-"line."
+msgid "Applies only to skeleton extraction. Default = -1 will extract the center line."
 msgstr ""
 #: ../vector/v.voronoi/main.c:156
@@ -9625,9 +9211,7 @@
 msgstr[1] ""
 #: ../vector/v.distance/main.c:95
-msgid ""
-"Finds the nearest element in vector map 'to' for elements in vector map "
-"'from'."
+msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
 msgstr ""
 #: ../vector/v.distance/main.c:99
@@ -9669,8 +9253,7 @@
 msgstr ""
 #: ../vector/v.distance/main.c:134
-msgid ""
-"Name for output vector map containing lines connecting nearest elements"
+msgid "Name for output vector map containing lines connecting nearest elements"
 msgstr ""
 #: ../vector/v.distance/main.c:142
@@ -9702,14 +9285,11 @@
 msgstr ""
 #: ../vector/v.distance/main.c:173
-msgid ""
-"distance to the nearest point on the 'to' feature along that linear feature"
+msgid "distance to the nearest point on the 'to' feature along that linear feature"
 msgstr ""
 #: ../vector/v.distance/main.c:175
-msgid ""
-"angle along the nearest linear feature in the 'to' map, measured CCW from "
-"the +x axis, in radians, between -Pi and Pi inclusive"
+msgid "angle along the nearest linear feature in the 'to' map, measured CCW from the +x axis, in radians, between -Pi and Pi inclusive"
 msgstr ""
 #: ../vector/v.distance/main.c:178
@@ -9717,8 +9297,7 @@
 msgstr ""
 #: ../vector/v.distance/main.c:191
-msgid ""
-"Column name(s) where values specified by 'upload' option will be uploaded"
+msgid "Column name(s) where values specified by 'upload' option will be uploaded"
 msgstr ""
 #: ../vector/v.distance/main.c:197
@@ -9746,9 +9325,7 @@
 msgstr ""
 #: ../vector/v.distance/main.c:220
-msgid ""
-"Output is written to stdout but may be uploaded to a new table created by "
-"this module; multiple 'upload' options may be used."
+msgid "Output is written to stdout but may be uploaded to a new table created by this module; multiple 'upload' options may be used."
 msgstr ""
 #: ../vector/v.distance/main.c:284
@@ -10023,8 +9600,7 @@
 msgstr ""
 #: ../vector/v.edit/args.c:154
-msgid ""
-"For 'shorter' use negative threshold value, positive value for 'longer'"
+msgid "For 'shorter' use negative threshold value, positive value for 'longer'"
 msgstr ""
 #: ../vector/v.edit/args.c:160
@@ -10040,9 +9616,7 @@
 msgstr ""
 #: ../vector/v.edit/args.c:176
-msgid ""
-"Snap added or modified features in the given threshold to the nearest "
-"existing feature"
+msgid "Snap added or modified features in the given threshold to the nearest existing feature"
 msgstr ""
 #: ../vector/v.edit/args.c:182
@@ -10116,9 +9690,7 @@
 msgstr ""
 #: ../vector/v.edit/main.c:63
-msgid ""
-"Edits a vector map, allows adding, deleting and modifying selected vector "
-"features."
+msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
 msgstr ""
 #: ../vector/v.edit/main.c:72
@@ -10138,16 +9710,12 @@
 #: ../vector/v.edit/main.c:140
 #, c-format
-msgid ""
-"Unable to open vector map <%s> on topological level. Try to rebuild vector "
-"topology by v.build."
+msgid "Unable to open vector map <%s> on topological level. Try to rebuild vector topology by v.build."
 msgstr ""
 #: ../vector/v.edit/main.c:160
 #, c-format
-msgid ""
-"Unable to open vector map <%s> as the background map. It is given as vector "
-"map to be edited."
+msgid "Unable to open vector map <%s> as the background map. It is given as vector map to be edited."
 msgstr ""
 #: ../vector/v.edit/main.c:171
@@ -10169,9 +9737,7 @@
 #: ../vector/v.edit/main.c:234
 #, c-format
-msgid ""
-"Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert "
-"the vector map to 3D using e.g. %s."
+msgid "Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert the vector map to 3D using e.g. %s."
 msgstr ""
 #: ../vector/v.edit/main.c:276
@@ -10260,9 +9826,7 @@
 #: ../vector/v.edit/main.c:387
 #, c-format
-msgid ""
-"Multiple background maps were given. Selected features will be copied only "
-"from vector map <%s>."
+msgid "Multiple background maps were given. Selected features will be copied only from vector map <%s>."
 msgstr ""
 #: ../vector/v.edit/main.c:397
@@ -10370,9 +9934,7 @@
 msgstr ""
 #: ../vector/v.vol.rst/main.c:241
-msgid ""
-"Interpolates point data to a 3D raster map using regularized spline with "
-"tension (RST) algorithm."
+msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
 msgstr ""
 #: ../vector/v.vol.rst/main.c:246
@@ -10511,9 +10073,7 @@
 msgstr ""
 #: ../vector/v.vol.rst/main.c:491
-msgid ""
-"Crossvalidation cannot be computed simultanuously with output grids or devi "
-"file"
+msgid "Crossvalidation cannot be computed simultanuously with output grids or devi file"
 msgstr ""
 #: ../vector/v.vol.rst/main.c:507 ../vector/v.vol.rst/main.c:510
@@ -10574,9 +10134,7 @@
 #: ../vector/v.vol.rst/main.c:640
 #, c-format
-msgid ""
-"Unable to create <%s> raster map without cross_input raster map being "
-"specified"
+msgid "Unable to create <%s> raster map without cross_input raster map being specified"
 msgstr ""
 #: ../vector/v.vol.rst/main.c:818
@@ -10637,8 +10195,7 @@
 #: ../vector/v.univar/main.c:366 ../vector/v.sample/main.c:152
 #: ../vector/v.class/main.c:132 ../vector/v.to.rast3/main.c:95
 #: ../vector/v.surf.bspline/main.c:392 ../vector/v.surf.idw/read_sites.c:68
-#: ../ps/ps.map/catval.c:66 ../ps/ps.map/catval.c:131
-#: ../ps/ps.map/catval.c:198
+#: ../ps/ps.map/catval.c:66 ../ps/ps.map/catval.c:131 ../ps/ps.map/catval.c:198
 msgid "Unable to select data from table"
 msgstr ""
@@ -10651,8 +10208,7 @@
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:128
-msgid ""
-"Column type of smooth column is not supported (must be integer or double)"
+msgid "Column type of smooth column is not supported (must be integer or double)"
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:150
@@ -10690,29 +10246,22 @@
 #: ../vector/v.vol.rst/user1.c:311
 #, c-format
-msgid ""
-"There are points outside specified 2D/3D region--ignored %d points (total "
-"points: %d)"
+msgid "There are points outside specified 2D/3D region--ignored %d points (total points: %d)"
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:315
 #, c-format
-msgid ""
-"Points are more dense than specified 'DMIN'--ignored %d points (remain %d)"
+msgid "Points are more dense than specified 'DMIN'--ignored %d points (remain %d)"
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:321
 #, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given "
-"NPMIN=%d"
+msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:341
 #, c-format
-msgid ""
-"There is less than %d points for interpolation, no segmentation is "
-"necessary, to run the program faster, set segmax=%d (see manual)"
+msgid "There is less than %d points for interpolation, no segmentation is necessary, to run the program faster, set segmax=%d (see manual)"
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:368
@@ -10985,9 +10534,7 @@
 msgstr ""
 #: ../vector/v.vect.stats/main.c:187
-msgid ""
-"Column to hold points count, must be of type integer, will be created if not"
-" existing"
+msgid "Column to hold points count, must be of type integer, will be created if not existing"
 msgstr ""
 #: ../vector/v.vect.stats/main.c:194
@@ -10995,9 +10542,7 @@
 msgstr ""
 #: ../vector/v.vect.stats/main.c:196
-msgid ""
-"Column to hold statistics, must be of type double, will be created if not "
-"existing"
+msgid "Column to hold statistics, must be of type double, will be created if not existing"
 msgstr ""
 #: ../vector/v.vect.stats/main.c:203
@@ -11174,9 +10719,7 @@
 msgstr ""
 #: ../vector/v.out.lidar/main.c:572 ../vector/v.out.lidar/main.c:582
-msgid ""
-"This scale does not change the values itself but only how precisely they are"
-" stored, for example 0.01 will preserve two decimal places"
+msgid "This scale does not change the values itself but only how precisely they are stored, for example 0.01 will preserve two decimal places"
 msgstr ""
 #: ../vector/v.out.lidar/main.c:581
@@ -11258,10 +10801,7 @@
 msgstr ""
 #: ../vector/v.perturb/main.c:92
-msgid ""
-"If the distribution is uniform, only one parameter, the maximum, is needed. "
-"For a normal distribution, two parameters, the mean and standard deviation, "
-"are required."
+msgid "If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
 msgstr ""
 #: ../vector/v.perturb/main.c:102
@@ -11301,9 +10841,7 @@
 msgstr ""
 #: ../vector/v.qcount/main.c:72
-msgid ""
-"Name for output quadrat centers map (number of points is written as "
-"category)"
+msgid "Name for output quadrat centers map (number of points is written as category)"
 msgstr ""
 #: ../vector/v.qcount/main.c:78
@@ -11424,9 +10962,7 @@
 msgstr ""
 #: ../vector/v.colors/main.c:234
-msgid ""
-"Reading rules from standard input is not implemented yet, please provide "
-"path to rules file instead."
+msgid "Reading rules from standard input is not implemented yet, please provide path to rules file instead."
 msgstr ""
 #: ../vector/v.colors/main.c:244
@@ -11465,8 +11001,8 @@
 msgstr ""
 #: ../vector/v.colors/main.c:315 ../raster/r.colors/edit_colors.c:396
-#: ../raster/r.grow.distance/main.c:384
-#: ../raster/r.colors.out/raster_main.c:69 ../raster/r.fill.dir/main.c:153
+#: ../raster/r.grow.distance/main.c:384 ../raster/r.colors.out/raster_main.c:69
+#: ../raster/r.fill.dir/main.c:153
 #, c-format
 msgid "Unable to read color table for raster map <%s>"
 msgstr ""
@@ -11640,9 +11176,7 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:224
-msgid ""
-"List of column names to be used instead of original names, first is used for"
-" category column"
+msgid "List of column names to be used instead of original names, first is used for category column"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:243
@@ -11650,9 +11184,7 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:245
-msgid ""
-"If not given, categories are generated as unique values and stored in 'cat' "
-"column"
+msgid "If not given, categories are generated as unique values and stored in 'cat' column"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:250
@@ -11699,9 +11231,7 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:316 ../vector/v.in.lidar/main.c:328
-msgid ""
-" import the vector data."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the vector data."
 msgstr ""
 #: ../vector/v.in.ogr/main.c:334 ../vector/v.external/list.c:94
@@ -11717,16 +11247,12 @@
 #: ../vector/v.in.ogr/main.c:415
 #, c-format
-msgid ""
-"Option <%s> will be ignored. OGR doesn't support it for selected format "
-"(%s)."
+msgid "Option <%s> will be ignored. OGR doesn't support it for selected format (%s)."
 msgstr ""
 #: ../vector/v.in.ogr/main.c:420
 #, c-format
-msgid ""
-"Option <%s> will be ignored. Multiple geometry fields are supported by GDAL "
-">= 1.11"
+msgid "Option <%s> will be ignored. Multiple geometry fields are supported by GDAL >= 1.11"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:433
@@ -11760,9 +11286,7 @@
 #: ../vector/v.in.ogr/main.c:577 ../vector/v.in.lidar/main.c:507
 #: ../raster/r.in.gdal/main.c:437 ../raster/r.in.gdal/main.c:826
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location."
+msgid "Unable to convert input map projection to GRASS format; cannot create new location."
 msgstr ""
 #: ../vector/v.in.ogr/main.c:583 ../vector/v.in.lidar/main.c:513
@@ -11775,9 +11299,7 @@
 #: ../vector/v.external/proj.c:41 ../vector/v.in.pdal/projection.c:110
 #: ../vector/v.in.pdal/projection.c:156 ../vector/v.in.pdal/projection.c:189
 #: ../raster/r.in.lidar/projection.c:113
-msgid ""
-"Unable to convert input map projection information to GRASS format for "
-"checking"
+msgid "Unable to convert input map projection information to GRASS format for checking"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:620 ../vector/v.in.lidar/projection.c:126
@@ -11823,9 +11345,7 @@
 #: ../vector/v.in.ogr/main.c:695 ../vector/v.in.lidar/projection.c:93
 #: ../vector/v.external/proj.c:117 ../vector/v.in.pdal/projection.c:92
 #: ../raster/r.in.lidar/projection.c:95
-msgid ""
-"Consider generating a new location with 'location' parameter from input data"
-" set.\n"
+msgid "Consider generating a new location with 'location' parameter from input data set.\n"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:710 ../vector/v.in.lidar/projection.c:137
@@ -11856,8 +11376,7 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:792
-msgid ""
-"The 'spatial' parameters do not overlap with OGR input. Nothing to import."
+msgid "The 'spatial' parameters do not overlap with OGR input. Nothing to import."
 msgstr ""
 #: ../vector/v.in.ogr/main.c:826
@@ -11911,9 +11430,7 @@
 #: ../vector/v.in.ogr/main.c:1114
 #, c-format
-msgid ""
-"Width for column %s set to 255 (was not specified by OGR), some strings may "
-"be truncated!"
+msgid "Width for column %s set to 255 (was not specified by OGR), some strings may be truncated!"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:1126
@@ -11991,10 +11508,7 @@
 #: ../vector/v.in.ogr/main.c:1537
 #, c-format
-msgid ""
-"%d areas represent more (overlapping) features, because polygons overlap in "
-"input layer(s). Such areas are linked to more than 1 row in attribute table."
-" The number of features for those areas is stored as category in layer %d"
+msgid "%d areas represent more (overlapping) features, because polygons overlap in input layer(s). Such areas are linked to more than 1 row in attribute table. The number of features for those areas is stored as category in layer %d"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:1547
@@ -12105,9 +11619,7 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:1734
-msgid ""
-"Input data contains 3D features. Created vector is 2D only, disable -2 flag "
-"to import 3D vector."
+msgid "Input data contains 3D features. Created vector is 2D only, disable -2 flag to import 3D vector."
 msgstr ""
 #: ../vector/v.in.ogr/geom.c:76 ../vector/v.in.ogr/geom.c:261
@@ -12164,9 +11676,7 @@
 msgstr ""
 #: ../vector/v.info/parse.c:30
-msgid ""
-"Print types/names of table columns for specified layer instead of info and "
-"exit"
+msgid "Print types/names of table columns for specified layer instead of info and exit"
 msgstr ""
 #: ../vector/v.info/parse.c:35
@@ -12393,10 +11903,7 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:147
-msgid ""
-"Spatial approximation and topographic analysis from given point or isoline "
-"data in vector format to floating point raster format using regularized "
-"spline with tension."
+msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
 msgstr ""
 #: ../vector/v.surf.rst/main.c:154
@@ -12440,9 +11947,7 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:179 ../vector/v.surf.idw/main.c:102
-msgid ""
-"If not given and input is 2D vector map then category values are used. If "
-"input is 3D vector map then z-coordinates are used."
+msgid "If not given and input is 2D vector map then category values are used. If input is 3D vector map then z-coordinates are used."
 msgstr ""
 #: ../vector/v.surf.rst/main.c:189
@@ -12486,8 +11991,7 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:308
-msgid ""
-"Maximum distance between points on isoline (to insert additional points)"
+msgid "Maximum distance between points on isoline (to insert additional points)"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:317
@@ -12513,15 +12017,11 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:425
-msgid ""
-"Both cross-validation options (-c flag and cvdev vector output) must be "
-"specified"
+msgid "Both cross-validation options (-c flag and cvdev vector output) must be specified"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:428
-msgid ""
-"The cross-validation cannot be computed simultaneously with output raster or"
-" devi file"
+msgid "The cross-validation cannot be computed simultaneously with output raster or devi file"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:446
@@ -12537,9 +12037,7 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:541 ../vector/v.surf.bspline/main.c:272
-msgid ""
-"Input is 3D: using attribute values instead of z-coordinates for "
-"approximation"
+msgid "Input is 3D: using attribute values instead of z-coordinates for approximation"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:543 ../vector/v.surf.bspline/main.c:274
@@ -12556,9 +12054,7 @@
 #: ../vector/v.surf.rst/main.c:662
 #, c-format
-msgid ""
-"Processing all selected output files will require %d bytes of disk space for"
-" temp files"
+msgid "Processing all selected output files will require %d bytes of disk space for temp files"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:682
@@ -12712,8 +12208,7 @@
 msgstr ""
 #: ../vector/v.in.db/main.c:57
-msgid ""
-"Creates new vector (points) map from database table containing coordinates."
+msgid "Creates new vector (points) map from database table containing coordinates."
 msgstr ""
 #: ../vector/v.in.db/main.c:61
@@ -12756,15 +12251,12 @@
 #: ../vector/v.in.db/main.c:141
 #, c-format
-msgid ""
-"Vector map <%s> cannot be overwritten because input table <%s> is linked to "
-"this map."
+msgid "Vector map <%s> cannot be overwritten because input table <%s> is linked to this map."
 msgstr ""
 #: ../vector/v.in.db/main.c:177
 #, c-format
-msgid ""
-"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
+msgid "Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
 msgstr ""
 #: ../vector/v.in.db/main.c:190 ../vector/v.db.connect/main.c:295
@@ -12778,9 +12270,7 @@
 #: ../vector/v.in.db/main.c:199
 #, c-format
-msgid ""
-"Unable to define key column. This operation is not supported by <%s> driver."
-" You need to define <%s> option."
+msgid "Unable to define key column. This operation is not supported by <%s> driver. You need to define <%s> option."
 msgstr ""
 #: ../vector/v.in.db/main.c:225 ../display/d.vect.chart/plot.c:86
@@ -12844,9 +12334,7 @@
 msgstr ""
 #: ../vector/v.db.select/main.c:100
-msgid ""
-"Print minimal region extent of selected vector features instead of "
-"attributes"
+msgid "Print minimal region extent of selected vector features instead of attributes"
 msgstr ""
 #: ../vector/v.db.select/main.c:101 ../raster/r.in.gdal/main.c:198
@@ -12877,9 +12365,7 @@
 #: ../vector/v.db.select/main.c:157
 #, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Flag '%c' requires "
-"topology level."
+msgid "Unable to open vector map <%s> at topology level. Flag '%c' requires topology level."
 msgstr ""
 #: ../vector/v.db.select/main.c:208
@@ -12927,9 +12413,7 @@
 msgstr ""
 #: ../vector/v.lidar.correction/main.c:74
-msgid ""
-"Corrects the v.lidar.growing output. It is the last of the three algorithms "
-"for LIDAR filtering."
+msgid "Corrects the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
 msgstr ""
 #: ../vector/v.lidar.correction/main.c:78
@@ -12940,9 +12424,7 @@
 #: ../vector/v.lidar.correction/main.c:80
 #: ../vector/v.lidar.edgedetection/main.c:85
 #: ../vector/v.surf.bspline/main.c:107 ../vector/v.outlier/main.c:81
-msgid ""
-"Estimate point density and distance for the input vector points within the "
-"current region extends and quit"
+msgid "Estimate point density and distance for the input vector points within the current region extends and quit"
 msgstr ""
 #: ../vector/v.lidar.correction/main.c:85
@@ -13015,8 +12497,7 @@
 msgstr ""
 #: ../vector/v.lidar.correction/main.c:194
-#: ../vector/v.lidar.correction/main.c:230
-#: ../vector/v.lidar.growing/main.c:163
+#: ../vector/v.lidar.correction/main.c:230 ../vector/v.lidar.growing/main.c:163
 #: ../vector/v.lidar.edgedetection/main.c:221
 #: ../vector/v.lidar.edgedetection/main.c:233
 #: ../vector/v.lidar.edgedetection/main.c:255
@@ -13082,9 +12563,7 @@
 msgstr ""
 #: ../vector/v.lidar.growing/main.c:78
-msgid ""
-"Building contour determination and Region Growing algorithm for determining "
-"the building inside"
+msgid "Building contour determination and Region Growing algorithm for determining the building inside"
 msgstr ""
 #: ../vector/v.lidar.growing/main.c:83
@@ -13286,9 +12765,8 @@
 #: ../vector/v.what.rast/main.c:183 ../vector/v.sample/main.c:240
 #: ../vector/v.class/main.c:129 ../vector/v.to.rast3/main.c:99
-#: ../vector/v.surf.bspline/crosscorr.c:133
-#: ../vector/v.surf.bspline/main.c:389 ../vector/v.surf.idw/read_sites.c:65
-#: ../vector/v.buffer/main.c:434
+#: ../vector/v.surf.bspline/crosscorr.c:133 ../vector/v.surf.bspline/main.c:389
+#: ../vector/v.surf.idw/read_sites.c:65 ../vector/v.buffer/main.c:434
 msgid "Column type not supported"
 msgstr ""
@@ -13370,9 +12848,7 @@
 #: ../vector/v.drape/main.c:150 ../vector/v.random/main.c:208
 #: ../vector/v.buffer/main.c:348
 #, c-format
-msgid ""
-"Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer "
-"'1'."
+msgid "Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer '1'."
 msgstr ""
 #: ../vector/v.drape/main.c:177 ../vector/v.select/select.c:40
@@ -13720,14 +13196,11 @@
 msgstr ""
 #: ../vector/v.out.postgis/args.c:44
-msgid ""
-"Name for output vector map defined as a link to the PostGIS feature table"
+msgid "Name for output vector map defined as a link to the PostGIS feature table"
 msgstr ""
 #: ../vector/v.out.postgis/args.c:46
-msgid ""
-"If not specified, the vector link is not created. The link can be also "
-"manually created by 'v.external' module."
+msgid "If not specified, the vector link is not created. The link can be also manually created by 'v.external' module."
 msgstr ""
 #: ../vector/v.out.postgis/args.c:52 ../vector/v.external.out/args.c:39
@@ -13837,16 +13310,12 @@
 #: ../vector/v.out.postgis/table.c:50
 #, c-format
-msgid ""
-"Invalid FID column (%s). FID column must be integer. Please specify "
-"different FID column by 'options=\"FID=<name>\"'."
+msgid "Invalid FID column (%s). FID column must be integer. Please specify different FID column by 'options=\"FID=<name>\"'."
 msgstr ""
 #: ../vector/v.out.postgis/table.c:57
 #, c-format
-msgid ""
-"Column (%s) already exists in the table. Please specify different geometry "
-"column by 'options=\"GEOMETRY_NAME=<name>\"'."
+msgid "Column (%s) already exists in the table. Please specify different geometry column by 'options=\"GEOMETRY_NAME=<name>\"'."
 msgstr ""
 #: ../vector/v.out.svg/main.c:76
@@ -13937,9 +13406,7 @@
 msgstr ""
 #: ../vector/v.delaunay/main.c:88
-msgid ""
-"Creates a Delaunay triangulation from an input vector map containing points "
-"or centroids."
+msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
 msgstr ""
 #: ../vector/v.delaunay/main.c:103
@@ -14074,9 +13541,7 @@
 msgstr ""
 #: ../vector/v.reclass/main.c:71
-msgid ""
-"Changes vector category values for an existing vector map according to "
-"results of SQL queries or a value in attribute table column."
+msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
 msgstr ""
 #: ../vector/v.reclass/main.c:88
@@ -14175,9 +13640,7 @@
 msgstr ""
 #: ../vector/v.net.centrality/main.c:100
-msgid ""
-"Computes degree, centrality, betweeness, closeness and eigenvector "
-"centrality measures in the network."
+msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
 msgstr ""
 #: ../vector/v.net.centrality/main.c:148
@@ -14243,8 +13706,7 @@
 msgstr ""
 #: ../vector/v.select/main.c:52
-msgid ""
-"Selects features from vector map (A) by features from other vector map (B)."
+msgid "Selects features from vector map (A) by features from other vector map (B)."
 msgstr ""
 #: ../vector/v.select/main.c:85 ../vector/v.overlay/main.c:178
@@ -14303,10 +13765,7 @@
 msgstr ""
 #: ../vector/v.select/args.c:51
-msgid ""
-"A feature is written to output if the result of operation 'ainput operator "
-"binput' is true. An input feature is considered to be true, if category of "
-"given layer is defined."
+msgid "A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined."
 msgstr ""
 #: ../vector/v.select/args.c:59 ../vector/v.select/args.c:75
@@ -14346,9 +13805,7 @@
 msgstr ""
 #: ../vector/v.select/args.c:84
-msgid ""
-"feature A is spatially related to feature B (using GEOS, requires 'relate' "
-"option)"
+msgid "feature A is spatially related to feature B (using GEOS, requires 'relate' option)"
 msgstr ""
 #: ../vector/v.select/args.c:94
@@ -14410,8 +13867,7 @@
 msgstr ""
 #: ../vector/v.support/main.c:118
-msgid ""
-"Command line to store into vector map history file (used for vector scripts)"
+msgid "Command line to store into vector map history file (used for vector scripts)"
 msgstr ""
 #: ../vector/v.support/main.c:122
@@ -14425,9 +13881,7 @@
 #: ../vector/v.in.lidar/main.c:48
 #, c-format
-msgid ""
-"Values of %s and %s are the same. All categories would be stored only in "
-"layer number <%d>"
+msgid "Values of %s and %s are the same. All categories would be stored only in layer number <%d>"
 msgstr ""
 #: ../vector/v.in.lidar/main.c:141
@@ -14478,9 +13932,7 @@
 msgstr ""
 #: ../vector/v.in.lidar/main.c:236
-msgid ""
-"For example, 5 will import 80 percent of points. If not specified, all "
-"points are imported"
+msgid "For example, 5 will import 80 percent of points. If not specified, all points are imported"
 msgstr ""
 #: ../vector/v.in.lidar/main.c:238 ../vector/v.in.lidar/main.c:248
@@ -14493,9 +13945,7 @@
 msgstr ""
 #: ../vector/v.in.lidar/main.c:246
-msgid ""
-"For example, 4 will import 25 percent of points. If not specified, all "
+msgid "For example, 4 will import 25 percent of points. If not specified, all points are imported"
 msgstr ""
 #: ../vector/v.in.lidar/main.c:255 ../vector/v.decimate/main.c:183
@@ -14562,9 +14012,7 @@
 #: ../vector/v.in.lidar/main.c:425
 #, c-format
-msgid ""
-"Storing generated point IDs as categories in the layer <%d>, consequently no"
-" more than %d points can be imported"
+msgid "Storing generated point IDs as categories in the layer <%d>, consequently no more than %d points can be imported"
 msgstr ""
 #: ../vector/v.in.lidar/main.c:435 ../vector/v.decimate/main.c:294
@@ -14593,9 +14041,7 @@
 msgstr ""
 #: ../vector/v.in.lidar/main.c:746
-msgid ""
-"The underlying libLAS library is at its limits. Previously reported counts "
-"might have been distorted. However, the import itself should be unaffected."
+msgid "The underlying libLAS library is at its limits. Previously reported counts might have been distorted. However, the import itself should be unaffected."
 msgstr ""
 #: ../vector/v.in.lidar/main.c:752
@@ -14684,9 +14130,7 @@
 msgstr ""
 #: ../vector/v.in.lidar/main.c:802
-msgid ""
-"Accuracy of the printed point counts might be limited by your computer "
-"architecture."
+msgid "Accuracy of the printed point counts might be limited by your computer architecture."
 msgstr ""
 #: ../vector/v.in.lidar/main.c:805
@@ -14700,9 +14144,7 @@
 #: ../vector/v.in.lidar/main.c:818
 #, c-format
-msgid ""
-"Maximum number of categories reached (%d). Import ended prematurely. Try to "
-"import without using category as an ID."
+msgid "Maximum number of categories reached (%d). Import ended prematurely. Try to import without using category as an ID."
 msgstr ""
 #: ../vector/v.in.lidar/vector_mask.c:20
@@ -14796,8 +14238,7 @@
 msgid "Point classification..."
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:103
-#: ../vector/v.lrs/v.lrs.where/main.c:58
+#: ../vector/v.lrs/v.lrs.label/main.c:103 ../vector/v.lrs/v.lrs.where/main.c:58
 #: ../vector/v.lrs/v.lrs.create/main.c:122
 #: ../vector/v.lrs/v.lrs.segment/main.c:72
 msgid "linear reference system"
@@ -14807,8 +14248,7 @@
 msgid "Creates stationing from input lines, and linear reference system."
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:109
-#: ../vector/v.lrs/v.lrs.where/main.c:66
+#: ../vector/v.lrs/v.lrs.label/main.c:109 ../vector/v.lrs/v.lrs.where/main.c:66
 #: ../vector/v.lrs/v.lrs.create/main.c:128
 #: ../vector/v.lrs/v.lrs.segment/main.c:79
 msgid "Input vector map containing lines"
@@ -14818,22 +14258,19 @@
 msgid "Output vector map where stationing will be written"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:118
-#: ../vector/v.lrs/v.lrs.where/main.c:75
+#: ../vector/v.lrs/v.lrs.label/main.c:118 ../vector/v.lrs/v.lrs.where/main.c:75
 #: ../vector/v.lrs/v.lrs.create/main.c:147
 #: ../vector/v.lrs/v.lrs.segment/main.c:88
 msgid "Line layer"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:124
-#: ../vector/v.lrs/v.lrs.where/main.c:86
+#: ../vector/v.lrs/v.lrs.label/main.c:124 ../vector/v.lrs/v.lrs.where/main.c:86
 #: ../vector/v.lrs/v.lrs.create/main.c:207
 #: ../vector/v.lrs/v.lrs.segment/main.c:94
 msgid "Driver name for reference system table"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:132
-#: ../vector/v.lrs/v.lrs.where/main.c:94
+#: ../vector/v.lrs/v.lrs.label/main.c:132 ../vector/v.lrs/v.lrs.where/main.c:94
 #: ../vector/v.lrs/v.lrs.create/main.c:215
 #: ../vector/v.lrs/v.lrs.segment/main.c:102
 msgid "Database name for reference system table"
@@ -14939,9 +14376,7 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.where/main.c:61
-msgid ""
-"Finds line id and real km+offset for given points in vector map using linear"
-" reference system."
+msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
 msgstr ""
 #: ../vector/v.lrs/v.lrs.where/main.c:70
@@ -15022,8 +14457,7 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:182
-msgid ""
-"Column containing offset from milepost for the beginning of next segment"
+msgid "Column containing offset from milepost for the beginning of next segment"
 msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:191
@@ -15156,9 +14590,7 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.segment/main.c:75
-msgid ""
-"Creates points/segments from input lines, linear reference system and "
-"positions read from stdin or a file."
+msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
 msgstr ""
 #: ../vector/v.lrs/v.lrs.segment/main.c:83
@@ -15305,9 +14737,7 @@
 #: ../vector/v.to.db/main.c:48
 #, c-format
-msgid ""
-"Vector map <%s> not found in the current mapset. Unable to modify vector "
-"maps from different mapsets."
+msgid "Vector map <%s> not found in the current mapset. Unable to modify vector maps from different mapsets."
 msgstr ""
 #: ../vector/v.to.db/main.c:65 ../vector/v.to.db/query.c:83
@@ -15378,15 +14808,11 @@
 msgstr ""
 #: ../vector/v.to.db/parse.c:84
-msgid ""
-"categories of areas on the left and right side of the boundary, "
-"'query_layer' is used for area category"
+msgid "categories of areas on the left and right side of the boundary, 'query_layer' is used for area category"
 msgstr ""
 #: ../vector/v.to.db/parse.c:86
-msgid ""
-"result of a database query for all records of the geometry(or geometries) "
-"from table specified by 'query_layer' option"
+msgid "result of a database query for all records of the geometry(or geometries) from table specified by 'query_layer' option"
 msgstr ""
 #: ../vector/v.to.db/parse.c:88
@@ -15394,14 +14820,11 @@
 msgstr ""
 #: ../vector/v.to.db/parse.c:89
-msgid ""
-"line sinuousity, calculated as line length / distance between end points"
+msgid "line sinuousity, calculated as line length / distance between end points"
 msgstr ""
 #: ../vector/v.to.db/parse.c:90
-msgid ""
-"line azimuth, calculated as angle between North direction and endnode "
-"direction at startnode"
+msgid "line azimuth, calculated as angle between North direction and endnode direction at startnode"
 msgstr ""
 #: ../vector/v.to.db/parse.c:94
@@ -15487,9 +14910,7 @@
 #: ../vector/v.to.db/query.c:109
 #, c-format
-msgid ""
-"Query for category '0' (no category) was not executed because of too many "
-"(%d) query categories. All later reported values for cat 0 are not valid."
+msgid "Query for category '0' (no category) was not executed because of too many (%d) query categories. All later reported values for cat 0 are not valid."
 msgstr ""
 #: ../vector/v.to.db/query.c:146
@@ -15587,8 +15008,7 @@
 msgstr ""
 #: ../vector/v.transform/main.c:74
-msgid ""
-"Performs an affine transformation (shift, scale and rotate) on vector map."
+msgid "Performs an affine transformation (shift, scale and rotate) on vector map."
 msgstr ""
 #: ../vector/v.transform/main.c:79
@@ -15689,9 +15109,7 @@
 #: ../vector/v.transform/trans_digit.c:112
 #, c-format
-msgid ""
-"Unable to select value for category %d from table <%s>, column <%s>. For "
-"category %d using default transformation parameter %.3f."
+msgid "Unable to select value for category %d from table <%s>, column <%s>. For category %d using default transformation parameter %.3f."
 msgstr ""
 #: ../vector/v.transform/trans_digit.c:123
@@ -15703,13 +15121,11 @@
 msgstr ""
 #: ../vector/v.univar/main.c:99
-msgid ""
-"Variance and standard deviation is calculated only for points if specified."
+msgid "Variance and standard deviation is calculated only for points if specified."
 msgstr ""
 #: ../vector/v.univar/main.c:126 ../vector/v.what/main.c:98
-#: ../raster/r.univar/r.univar_main.c:61
-#: ../raster/r.univar/r3.univar_main.c:59
+#: ../raster/r.univar/r.univar_main.c:61 ../raster/r.univar/r3.univar_main.c:59
 msgid "Print the stats in shell script style"
 msgstr ""
@@ -15727,9 +15143,7 @@
 msgstr ""
 #: ../vector/v.univar/main.c:195
-msgid ""
-"Incompatible vector type(s) specified, only number of features, minimum, "
-"maximum and range can be calculated"
+msgid "Incompatible vector type(s) specified, only number of features, minimum, maximum and range can be calculated"
 msgstr ""
 #: ../vector/v.univar/main.c:200
@@ -15820,15 +15234,12 @@
 #: ../vector/v.db.connect/main.c:197
 #, c-format
-msgid ""
-"layer <%d/%s> table <%s> in database <%s> through driver <%s> with key "
-"<%s>\n"
+msgid "layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
 #: ../vector/v.db.connect/main.c:203
 #, c-format
-msgid ""
-"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgid "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
 #: ../vector/v.db.connect/main.c:266
@@ -15843,28 +15254,19 @@
 #: ../vector/v.db.connect/main.c:302 ../vector/v.db.connect/main.c:320
 #, c-format
-msgid ""
-"The table <%s> is now part of vector map <%s> and may be deleted or "
-"overwritten by GRASS modules"
+msgid "The table <%s> is now part of vector map <%s> and may be deleted or overwritten by GRASS modules"
 msgstr ""
 #: ../vector/v.db.connect/main.c:351
-msgid ""
-"For defining a new connection you have to specify these parameters: driver, "
-"database, table [, key [, layer]]"
+msgid "For defining a new connection you have to specify these parameters: driver, database, table [, key [, layer]]"
 msgstr ""
 #: ../vector/v.net.distance/main.c:69
-msgid ""
-"Computes shortest distance via the network between the given sets of "
-"features."
+msgid "Computes shortest distance via the network between the given sets of features."
 msgstr ""
 #: ../vector/v.net.distance/main.c:72
-msgid ""
-"Finds the shortest paths from each 'from' point to the nearest 'to' feature "
-"and various information about this relation are uploaded to the attribute "
-"table."
+msgid "Finds the shortest paths from each 'from' point to the nearest 'to' feature and various information about this relation are uploaded to the attribute table."
 msgstr ""
 #: ../vector/v.net.distance/main.c:100
@@ -15941,9 +15343,7 @@
 msgstr ""
 #: ../vector/v.decimate/main.c:133
-msgid ""
-"Copies points from one vector to another while applying different "
-"decimations"
+msgid "Copies points from one vector to another while applying different decimations"
 msgstr ""
 #: ../vector/v.decimate/main.c:161
@@ -15951,9 +15351,7 @@
 msgstr ""
 #: ../vector/v.decimate/main.c:163
-msgid ""
-"points are copied"
+msgid "For example, 5 will import 80 percent of points. If not specified, all points are copied"
 msgstr ""
 #: ../vector/v.decimate/main.c:165 ../vector/v.decimate/main.c:176
@@ -15966,9 +15364,7 @@
 msgstr ""
 #: ../vector/v.decimate/main.c:174
-msgid ""
+msgid "For example, 4 will import 25 percent of points. If not specified, all points are copied"
 msgstr ""
 #: ../vector/v.decimate/main.c:193
@@ -15998,9 +15394,7 @@
 msgstr ""
 #: ../vector/v.decimate/main.c:213
-msgid ""
-"Preserves only the given number of points per grid cell in grid-based "
-"decimation"
+msgid "Preserves only the given number of points per grid cell in grid-based decimation"
 msgstr ""
 #: ../vector/v.decimate/main.c:218
@@ -16029,9 +15423,7 @@
 #: ../vector/v.decimate/main.c:276
 #, c-format
-msgid ""
-"Input layer must be set to a particular layer, not <%s>, when using <%s> "
-"option or <-%c> flag"
+msgid "Input layer must be set to a particular layer, not <%s>, when using <%s> option or <-%c> flag"
 msgstr ""
 #: ../vector/v.decimate/main.c:318
@@ -16043,9 +15435,7 @@
 msgstr ""
 #: ../vector/v.decimate/main.c:350
-msgid ""
-"Settings for count-based decimation would cause it to do nothing and no "
-"other options has been set."
+msgid "Settings for count-based decimation would cause it to do nothing and no other options has been set."
 msgstr ""
 #: ../vector/v.sample/main.c:79
@@ -16304,8 +15694,7 @@
 msgstr ""
 #: ../vector/v.label/main.c:251
-msgid ""
-"size and space options vary significantly which may lead to crummy output"
+msgid "size and space options vary significantly which may lead to crummy output"
 msgstr ""
 #: ../vector/v.label/main.c:259
@@ -16342,9 +15731,7 @@
 msgstr ""
 #: ../vector/v.out.pov/main.c:75
-msgid ""
-"This string is appended to each z coordinate. Examples: '*10', '+1000', "
-"'*10+100', '*exaggeration'"
+msgid "This string is appended to each z coordinate. Examples: '*10', '+1000', '*10+100', '*exaggeration'"
 msgstr ""
 #: ../vector/v.out.pov/main.c:82
@@ -16401,9 +15788,7 @@
 msgstr ""
 #: ../vector/v.category/main.c:119
-msgid ""
-"copy values from one layer to another (e.g. layer=1,2,3 copies values from "
-"layer 1 to layer 2 and 3)"
+msgid "copy values from one layer to another (e.g. layer=1,2,3 copies values from layer 1 to layer 2 and 3)"
 msgstr ""
 #: ../vector/v.category/main.c:120
@@ -16411,9 +15796,7 @@
 msgstr ""
 #: ../vector/v.category/main.c:121
-msgid ""
-"print category values, layers are separated by '|', more cats in the same "
-"layer are separated by '/'"
+msgid "print category values, layers are separated by '|', more cats in the same layer are separated by '/'"
 msgstr ""
 #: ../vector/v.category/main.c:122
@@ -16433,15 +15816,11 @@
 msgstr ""
 #: ../vector/v.category/main.c:160
-msgid ""
-"Database connection and attribute tables for concerned layers are not "
-"changed"
+msgid "Database connection and attribute tables for concerned layers are not changed"
 msgstr ""
 #: ../vector/v.category/main.c:208
-msgid ""
-"Invalid category number (must be equal to or greater than 0). Normally "
-"category number starts at 1."
+msgid "Invalid category number (must be equal to or greater than 0). Normally category number starts at 1."
 msgstr ""
 #: ../vector/v.category/main.c:217
@@ -16569,8 +15948,7 @@
 msgstr ""
 #: ../vector/v.to.rast/main.c:122
-msgid ""
-"All cells touched by the line will be set, not only those on the render path"
+msgid "All cells touched by the line will be set, not only those on the render path"
 msgstr ""
 #: ../vector/v.to.rast/main.c:132
@@ -16656,9 +16034,7 @@
 msgstr ""
 #: ../vector/v.to.rast/vect2rast.c:137
-msgid ""
-"Area conversion and line densification are mutually exclusive, disabling "
-"line densification."
+msgid "Area conversion and line densification are mutually exclusive, disabling line densification."
 msgstr ""
 #: ../vector/v.to.rast/vect2rast.c:152
@@ -16896,9 +16272,7 @@
 msgstr ""
 #: ../vector/v.net.alloc/main.c:63
-msgid ""
-"center node must be opened (costs >= 0). Costs of center node are used in "
-"calculation"
+msgid "center node must be opened (costs >= 0). Costs of center node are used in calculation"
 msgstr ""
 #: ../vector/v.net.alloc/main.c:76
@@ -16906,9 +16280,7 @@
 msgstr ""
 #: ../vector/v.net.alloc/main.c:83 ../vector/v.net.iso/main.c:89
-msgid ""
-"Categories of centers (points on nodes) to which net will be allocated, "
-"layer for this categories is given by nlayer option"
+msgid "Categories of centers (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
 msgstr ""
 #: ../vector/v.net.alloc/main.c:129 ../vector/v.net.iso/main.c:137
@@ -17125,10 +16497,7 @@
 msgstr ""
 #: ../vector/v.class/main.c:173
-msgid ""
-"The discontinuities algorithm indicates that some class breaks are not "
-"statistically significant at alpha=0.05. You are advised to reduce the "
-"number of classes."
+msgid "The discontinuities algorithm indicates that some class breaks are not statistically significant at alpha=0.05. You are advised to reduce the number of classes."
 msgstr ""
 #: ../vector/v.class/main.c:201
@@ -17223,9 +16592,7 @@
 msgstr ""
 #: ../vector/v.random/main.c:153
-msgid ""
-"The seed to initialize the random generator. If not set the process ID is "
-"used"
+msgid "The seed to initialize the random generator. If not set the process ID is used"
 msgstr ""
 #: ../vector/v.random/main.c:156
@@ -17268,15 +16635,12 @@
 msgstr ""
 #: ../vector/v.random/main.c:286
-msgid ""
-"You have created unsupported column type. This module supports only INTEGER "
-"and DOUBLE PRECISION column types."
+msgid "You have created unsupported column type. This module supports only INTEGER and DOUBLE PRECISION column types."
 msgstr ""
 #: ../vector/v.random/main.c:349
 #, c-format
-msgid ""
-"Selected areas in input vector <%s> do not overlap with the current region"
+msgid "Selected areas in input vector <%s> do not overlap with the current region"
 msgstr ""
 #: ../vector/v.random/main.c:361
@@ -17354,9 +16718,7 @@
 msgstr ""
 #: ../vector/v.out.ascii/main.c:52
-msgid ""
-"By default only features with category are exported. To export all features "
-"use 'layer=-1'."
+msgid "By default only features with category are exported. To export all features use 'layer=-1'."
 msgstr ""
 #: ../vector/v.out.ascii/main.c:60
@@ -17376,9 +16738,7 @@
 #: ../vector/v.out.ascii/main.c:80
 #, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Areas will not be "
-"processed."
+msgid "Unable to open vector map <%s> at topology level. Areas will not be processed."
 msgstr ""
 #: ../vector/v.out.ascii/main.c:107
@@ -17422,9 +16782,7 @@
 msgstr ""
 #: ../vector/v.out.ogr/args.c:20
-msgid ""
-"Combination of types is not supported by all output formats. Default is to "
-"use first type found in input vector map."
+msgid "Combination of types is not supported by all output formats. Default is to use first type found in input vector map."
 msgstr ""
 #: ../vector/v.out.ogr/args.c:25
@@ -17488,9 +16846,7 @@
 msgstr ""
 #: ../vector/v.out.ogr/args.c:100
-msgid ""
-"Also export features without category (not labeled). Otherwise only features"
-" with category are exported."
+msgid "Also export features without category (not labeled). Otherwise only features with category are exported."
 msgstr ""
 #: ../vector/v.out.ogr/args.c:106
@@ -17506,9 +16862,7 @@
 msgstr ""
 #: ../vector/v.out.ogr/args.c:126
-msgid ""
-"Create a new empty layer in defined OGR datasource and exit. Nothing is read"
-" from input."
+msgid "Create a new empty layer in defined OGR datasource and exit. Nothing is read from input."
 msgstr ""
 #: ../vector/v.out.ogr/attrb.c:48 ../vector/v.out.vtk/writeVTK.c:585
@@ -17546,9 +16900,7 @@
 #: ../vector/v.out.ogr/main.c:97 ../vector/v.external.out/link.c:26
 #, c-format
-msgid ""
-"Data source starts with \"PG:\" prefix, expecting \"PostgreSQL\" format "
-"(\"%s\" given)"
+msgid "Data source starts with \"PG:\" prefix, expecting \"PostgreSQL\" format (\"%s\" given)"
 msgstr ""
 #: ../vector/v.out.ogr/main.c:165
@@ -17579,118 +16931,88 @@
 msgstr ""
 #: ../vector/v.out.ogr/main.c:311
-msgid ""
-"The map contains islands. With the -c flag, islands will appear as filled "
-"areas, not holes in the output map."
+msgid "The map contains islands. With the -c flag, islands will appear as filled areas, not holes in the output map."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:317
 #, c-format
-msgid ""
-"%d point found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d points found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d point found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d points found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 msgstr[1] ""
 #: ../vector/v.out.ogr/main.c:325
 #, c-format
-msgid ""
-"%d line found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d line found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d line(s) found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 msgstr[1] ""
 #: ../vector/v.out.ogr/main.c:334
 #, c-format
-msgid ""
-"%d boundary found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgid_plural ""
-"%d boundaries found, but not requested to be exported. Verify 'type' "
-"parameter."
+msgid "%d boundary found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d boundaries found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 msgstr[1] ""
 #: ../vector/v.out.ogr/main.c:343
 #, c-format
-msgid ""
-"%d centroid found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgid_plural ""
-"%d centroids found, but not requested to be exported. Verify 'type' "
-"parameter."
+msgid "%d centroid found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d centroids found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 msgstr[1] ""
 #: ../vector/v.out.ogr/main.c:351
 #, c-format
-msgid ""
-"%d area found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d areas found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d area found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d areas found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 msgstr[1] ""
 #: ../vector/v.out.ogr/main.c:359
 #, c-format
-msgid ""
-"%d face found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d faces found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d face found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d faces found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 msgstr[1] ""
 #: ../vector/v.out.ogr/main.c:367
 #, c-format
-msgid ""
-"%d volume found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d volumes found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d volume found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d volumes found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 msgstr[1] ""
 #: ../vector/v.out.ogr/main.c:377
-msgid ""
-"No points found, but requested to be exported. Will skip this feature type."
+msgid "No points found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:386
-msgid ""
-"No lines found, but requested to be exported. Will skip this feature type."
+msgid "No lines found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:396
-msgid ""
-"No boundaries found, but requested to be exported. Will skip this feature "
-"type."
+msgid "No boundaries found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:405
-msgid ""
-"No areas found, but requested to be exported. Will skip this feature type."
+msgid "No areas found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:415
-msgid ""
-"No centroids found, but requested to be exported. Will skip this feature "
-"type."
+msgid "No centroids found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:424
-msgid ""
-"No faces found, but requested to be exported. Will skip this feature type."
+msgid "No faces found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:433
-msgid ""
-"No kernels found, but requested to be exported. Will skip this feature type."
+msgid "No kernels found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:442
-msgid ""
-"No volumes found, but requested to be exported. Will skip this feature type."
+msgid "No volumes found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:467
@@ -17724,23 +17046,17 @@
 #: ../vector/v.out.ogr/main.c:562
 #, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options SHPT "
-"(parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
+msgid "Vector map <%s> is 3D. Use format specific layer creation options SHPT (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
 msgstr ""
 #: ../vector/v.out.ogr/main.c:574
 #, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options DIM "
-"(parameter 'lco') to export in 3D rather than 2D (default)."
+msgid "Vector map <%s> is 3D. Use format specific layer creation options DIM (parameter 'lco') to export in 3D rather than 2D (default)."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:581
 #, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options (parameter"
-" 'lco') to export <in 3D rather than 2D (default)."
+msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export <in 3D rather than 2D (default)."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:598 ../db/drivers/ogr/execute.c:56
@@ -17811,12 +17127,8 @@
 #: ../vector/v.out.ogr/main.c:787
 #, c-format
-msgid ""
-"%d feature without category was skipped. Features without category are "
-"written only when -%c flag is given."
-msgid_plural ""
-"%d features without category were skipped. Features without category are "
+msgid "%d feature without category was skipped. Features without category are written only when -%c flag is given."
+msgid_plural "%d features without category were skipped. Features without category are written only when -%c flag is given."
 msgstr[0] ""
 msgstr[1] ""
@@ -17844,8 +17156,7 @@
 #: ../vector/v.out.ogr/export_areas.c:176
 #: ../vector/v.out.ogr/export_lines.c:212
 #, c-format
-msgid ""
-"Unable to create multi-feature. Category %d not found in line %d, field %d"
+msgid "Unable to create multi-feature. Category %d not found in line %d, field %d"
 msgstr ""
 #: ../vector/v.out.ogr/export_areas.c:214
@@ -17874,21 +17185,15 @@
 msgstr ""
 #: ../vector/v.external/main.c:57
-msgid ""
-"Creates a new pseudo-vector map as a link to an OGR-supported layer or a "
-"PostGIS feature table."
+msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer or a PostGIS feature table."
 msgstr ""
 #: ../vector/v.external/main.c:76 ../vector/v.external.out/format.c:22
-msgid ""
-"Environment variable GRASS_VECTOR_OGR defined, but GRASS is compiled with "
-"OGR support. Using GRASS-PostGIS data driver instead."
+msgid "Environment variable GRASS_VECTOR_OGR defined, but GRASS is compiled with OGR support. Using GRASS-PostGIS data driver instead."
 msgstr ""
 #: ../vector/v.external/main.c:81 ../vector/v.external.out/format.c:27
-msgid ""
-"GRASS is not compiled with PostgreSQL support. Using OGR-PostgreSQL driver "
-"instead of native GRASS-PostGIS data driver."
+msgid "GRASS is not compiled with PostgreSQL support. Using OGR-PostgreSQL driver instead of native GRASS-PostGIS data driver."
 msgstr ""
 #: ../vector/v.external/main.c:124
@@ -18001,9 +17306,7 @@
 #: ../vector/v.external/list.c:310
 #, c-format
-msgid ""
-"Unable to convert input map projection to GRASS format. Projection check "
-"cannot be provided for OGR layer <%s>"
+msgid "Unable to convert input map projection to GRASS format. Projection check cannot be provided for OGR layer <%s>"
 msgstr ""
 #: ../vector/v.external/list.c:326
@@ -18017,13 +17320,11 @@
 msgstr ""
 #: ../vector/v.extrude/main.c:72
-msgid ""
-"Extrudes flat vector features to 3D vector features with defined height."
+msgid "Extrudes flat vector features to 3D vector features with defined height."
 msgstr ""
 #: ../vector/v.extrude/main.c:74
-msgid ""
-"Optionally the height can be derived from sampling of elevation raster map."
+msgid "Optionally the height can be derived from sampling of elevation raster map."
 msgstr ""
 #: ../vector/v.extrude/main.c:78
@@ -18041,9 +17342,7 @@
 #: ../vector/v.extrude/main.c:202
 #, c-format
-msgid ""
-"Invalid layer number (%d). Parameter '%s', '%s' or '%s' specified, assuming "
-"layer '1'."
+msgid "Invalid layer number (%d). Parameter '%s', '%s' or '%s' specified, assuming layer '1'."
 msgstr ""
 #: ../vector/v.extrude/main.c:234
@@ -18067,8 +17366,7 @@
 #: ../vector/v.extrude/main.c:293
 #, c-format
-msgid ""
-"Unable to fetch height from DB for area %d. Using default fixed height %f."
+msgid "Unable to fetch height from DB for area %d. Using default fixed height %f."
 msgstr ""
 #: ../vector/v.extrude/main.c:319
@@ -18082,8 +17380,7 @@
 #: ../vector/v.extrude/main.c:346
 #, c-format
-msgid ""
-"Unable to fetch height from DB for line %d. Using default fixed height %f."
+msgid "Unable to fetch height from DB for line %d. Using default fixed height %f."
 msgstr ""
 #: ../vector/v.extrude/main.c:364
@@ -18223,8 +17520,7 @@
 msgstr ""
 #: ../vector/v.build/main.c:49
-msgid ""
-"Name for output vector map where erroneous vector features are written to"
+msgid "Name for output vector map where erroneous vector features are written to"
 msgstr ""
 #: ../vector/v.build/main.c:51 ../vector/v.build/main.c:77
@@ -18266,9 +17562,7 @@
 #: ../vector/v.build/main.c:106
 #, c-format
-msgid ""
-"Direct read access to OGR layers is not supported by this module. Run %s to "
-"create a link as GRASS vector map in the current mapset."
+msgid "Direct read access to OGR layers is not supported by this module. Run %s to create a link as GRASS vector map in the current mapset."
 msgstr ""
 #: ../vector/v.build/main.c:111
@@ -18281,9 +17575,7 @@
 msgstr ""
 #: ../vector/v.rectify/main.c:75
-msgid ""
-"Rectifies a vector by computing a coordinate transformation for each object "
-"in the vector based on the control points."
+msgid "Rectifies a vector by computing a coordinate transformation for each object in the vector based on the control points."
 msgstr ""
 #: ../vector/v.rectify/main.c:90
@@ -18291,8 +17583,7 @@
 msgstr ""
 #: ../vector/v.rectify/main.c:95
-msgid ""
-"Name of output file with RMS errors (if omitted or '-' output to stdout"
+msgid "Name of output file with RMS errors (if omitted or '-' output to stdout"
 msgstr ""
 #: ../vector/v.rectify/main.c:104 ../imagery/i.rectify/main.c:124
@@ -18687,9 +17978,7 @@
 msgstr ""
 #: ../vector/v.net.steiner/main.c:352
-msgid ""
-"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
-"is used in this module so the result may be sub optimal."
+msgid "Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal."
 msgstr ""
 #: ../vector/v.net.steiner/main.c:373
@@ -18741,8 +18030,7 @@
 #: ../vector/v.net.steiner/main.c:538
 #, c-format
-msgid ""
-"[%d] (not reachable) nodes removed from list of Steiner point candidates"
+msgid "[%d] (not reachable) nodes removed from list of Steiner point candidates"
 msgstr ""
 #: ../vector/v.net.steiner/main.c:543
@@ -19144,9 +18432,7 @@
 #: ../vector/v.to.points/main.c:232
 #, c-format
-msgid ""
-"%d features without category in layer <%d> skipped. Note that features "
-"without category (usually boundaries) are not skipped when '%s=-1' is given."
+msgid "%d features without category in layer <%d> skipped. Note that features without category (usually boundaries) are not skipped when '%s=-1' is given."
 msgstr ""
 #: ../vector/v.to.points/main.c:282
@@ -19204,9 +18490,7 @@
 msgstr ""
 #: ../vector/v.in.ascii/main.c:128
-msgid ""
-"For example: 'x double precision, y double precision, cat int, name "
-"varchar(10)'"
+msgid "For example: 'x double precision, y double precision, cat int, name varchar(10)'"
 msgstr ""
 #: ../vector/v.in.ascii/main.c:140 ../vector/v.in.ascii/main.c:150
@@ -19230,9 +18514,7 @@
 msgstr ""
 #: ../vector/v.in.ascii/main.c:172
-msgid ""
-"First column is 1. If 0, unique category is assigned to each row and written"
-" to new column 'cat'"
+msgid "First column is 1. If 0, unique category is assigned to each row and written to new column 'cat'"
 msgstr ""
 #: ../vector/v.in.ascii/main.c:181
@@ -19303,9 +18585,7 @@
 #: ../vector/v.in.ascii/main.c:296 ../vector/v.in.ascii/main.c:300
 #: ../vector/v.in.ascii/main.c:305 ../vector/v.in.ascii/main.c:310
 #, c-format
-msgid ""
-"'%s' column number > minimum last column number (incorrect field separator "
-"or format?)"
+msgid "'%s' column number > minimum last column number (incorrect field separator or format?)"
 msgstr ""
 #: ../vector/v.in.ascii/main.c:315 ../vector/v.in.ascii/main.c:318
@@ -19320,9 +18600,7 @@
 #: ../vector/v.in.ascii/main.c:441
 #, c-format
-msgid ""
-"Number of columns defined (%d) does not match number of columns (%d) in "
-"input"
+msgid "Number of columns defined (%d) does not match number of columns (%d) in input"
 msgstr ""
 #: ../vector/v.in.ascii/main.c:469
@@ -19365,9 +18643,7 @@
 msgstr ""
 #: ../vector/v.in.ascii/main.c:542
-msgid ""
-"Unable to close attribute table. The DBMI driver did not accept all "
-"attributes"
+msgid "Unable to close attribute table. The DBMI driver did not accept all attributes"
 msgstr ""
 #: ../vector/v.in.ascii/points.c:82
@@ -19421,10 +18697,7 @@
 msgstr ""
 #: ../vector/v.net.iso/main.c:78
-msgid ""
-"Splits net to bands between cost isolines (direction from center). Center "
-"node must be opened (costs >= 0). Costs of center node are used in "
-"calculation."
+msgid "Splits net to bands between cost isolines (direction from center). Center node must be opened (costs >= 0). Costs of center node are used in calculation."
 msgstr ""
 #: ../vector/v.net.iso/main.c:98
@@ -19477,14 +18750,11 @@
 msgstr ""
 #: ../vector/v.net.salesman/main.c:133
-msgid ""
-"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
-"created cycle may be sub optimal"
+msgid "Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
 msgstr ""
 #: ../vector/v.net.salesman/main.c:142
-msgid ""
-"Categories of points ('cities') on nodes (layer is specified by nlayer)"
+msgid "Categories of points ('cities') on nodes (layer is specified by nlayer)"
 msgstr ""
 #: ../vector/v.net.salesman/main.c:162
@@ -19541,9 +18811,7 @@
 msgstr ""
 #: ../vector/v.patch/main.c:84
-msgid ""
-"Name for output vector map where bounding boxes of input vector maps are "
-"written to"
+msgid "Name for output vector map where bounding boxes of input vector maps are written to"
 msgstr ""
 #: ../vector/v.patch/main.c:88
@@ -19571,8 +18839,7 @@
 msgstr ""
 #: ../vector/v.patch/main.c:106
-msgid ""
-"Append files to existing file (overwriting existing files must be activated)"
+msgid "Append files to existing file (overwriting existing files must be activated)"
 msgstr ""
 #: ../vector/v.patch/main.c:216
@@ -19683,9 +18950,7 @@
 msgstr ""
 #: ../vector/v.kernel/main.c:115
-msgid ""
-"Density is computed using a moving kernel. Optionally generates a vector "
-"density map on a vector network."
+msgid "Density is computed using a moving kernel. Optionally generates a vector density map on a vector network."
 msgstr ""
 #: ../vector/v.kernel/main.c:119
@@ -19748,9 +19013,7 @@
 msgstr ""
 #: ../vector/v.kernel/main.c:207
-msgid ""
-"Try to calculate an optimal radius with given 'radius' taken as maximum "
-"(experimental)"
+msgid "Try to calculate an optimal radius with given 'radius' taken as maximum (experimental)"
 msgstr ""
 #: ../vector/v.kernel/main.c:212
@@ -19758,9 +19021,7 @@
 msgstr ""
 #: ../vector/v.kernel/main.c:217
-msgid ""
-"In network mode, normalize values by sum of density multiplied by length of "
-"each segment. Integral over the output map then gives 1.0 * mult"
+msgid "In network mode, normalize values by sum of density multiplied by length of each segment. Integral over the output map then gives 1.0 * mult"
 msgstr ""
 #: ../vector/v.kernel/main.c:223
@@ -19768,9 +19029,7 @@
 msgstr ""
 #: ../vector/v.kernel/main.c:236
-msgid ""
-"Use option net_output if you compute network density. Name provided in "
-"option output will be used for net_output."
+msgid "Use option net_output if you compute network density. Name provided in option output will be used for net_output."
 msgstr ""
 #: ../vector/v.kernel/main.c:255
@@ -19782,15 +19041,11 @@
 msgstr ""
 #: ../vector/v.kernel/main.c:279
-msgid ""
-"Optimal standard deviation calculation is supported only for node method "
-"'none' and kernel function 'gaussian'."
+msgid "Optimal standard deviation calculation is supported only for node method 'none' and kernel function 'gaussian'."
 msgstr ""
 #: ../vector/v.kernel/main.c:283
-msgid ""
-"Optimal standard deviation calculation is supported only for kernel function"
-" 'gaussian'."
+msgid "Optimal standard deviation calculation is supported only for kernel function 'gaussian'."
 msgstr ""
 #: ../vector/v.kernel/main.c:300
@@ -19841,9 +19096,7 @@
 #: ../vector/v.kernel/main.c:379
 #, c-format
-msgid ""
-"Automatic choice of smoothing parameter (radius), maximum possible value of "
-"radius is set to %f"
+msgid "Automatic choice of smoothing parameter (radius), maximum possible value of radius is set to %f"
 msgstr ""
 #: ../vector/v.kernel/main.c:386
@@ -19865,9 +19118,7 @@
 #: ../vector/v.kernel/main.c:406
 #, c-format
-msgid ""
-"Distances between all points are beyond %e (4 * standard deviation), unable "
-"to calculate optimal value."
+msgid "Distances between all points are beyond %e (4 * standard deviation), unable to calculate optimal value."
 msgstr ""
 #: ../vector/v.kernel/main.c:417
@@ -19929,9 +19180,7 @@
 msgstr ""
 #: ../vector/v.clean/main.c:100
-msgid ""
-"change the type of boundary dangle to line, threshold ignored if < 0, input "
-"line type is ignored"
+msgid "change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored"
 msgstr ""
 #: ../vector/v.clean/main.c:102
@@ -19939,9 +19188,7 @@
 msgstr ""
 #: ../vector/v.clean/main.c:103
-msgid ""
-"change the type of bridges connecting area and island or 2 islands from "
-"boundary to line"
+msgid "change the type of bridges connecting area and island or 2 islands from boundary to line"
 msgstr ""
 #: ../vector/v.clean/main.c:105
@@ -19953,17 +19200,11 @@
 msgstr ""
 #: ../vector/v.clean/main.c:107
-msgid ""
-"break (topologically clean) polygons (imported from non topological format, "
-"like ShapeFile). Boundaries are broken on each point shared between 2 and "
-"more polygons where angles of segments are different"
+msgid "break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different"
 msgstr ""
 #: ../vector/v.clean/main.c:110
-msgid ""
-"remove vertices in threshold from lines and boundaries, boundary is pruned "
-"only if topology is not damaged (new intersection, changed attachment of "
-"centroid), first and last segment of the boundary is never changed"
+msgid "remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachment of centroid), first and last segment of the boundary is never changed"
 msgstr ""
 #: ../vector/v.clean/main.c:114
@@ -20003,9 +19244,7 @@
 msgstr ""
 #: ../vector/v.clean/main.c:202
-msgid ""
-"Note: In latitude-longitude coordinate system specify threshold in degree "
-"unit"
+msgid "Note: In latitude-longitude coordinate system specify threshold in degree unit"
 msgstr ""
 #: ../vector/v.clean/main.c:215
@@ -20161,8 +19400,7 @@
 #: ../vector/v.clean/prune.c:216
 #, c-format
-msgid ""
-"%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
+msgid "%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
 msgstr ""
 #: ../vector/v.clean/prune.c:220
@@ -20211,14 +19449,11 @@
 #: ../vector/v.out.vtk/main.c:183
 #, c-format
-msgid ""
-"Export of areas requires topology. Please adjust '%s' option or rebuild "
-"topology."
+msgid "Export of areas requires topology. Please adjust '%s' option or rebuild topology."
 msgstr ""
 #: ../vector/v.out.vtk/writeVTK.c:196
-msgid ""
-"No coordinates to generate the output! Maybe an empty vector type chosen?"
+msgid "No coordinates to generate the output! Maybe an empty vector type chosen?"
 msgstr ""
 #: ../vector/v.out.vtk/writeVTK.c:632
@@ -20304,9 +19539,7 @@
 msgstr ""
 #: ../vector/v.overlay/main.c:70
-msgid ""
-"Overlays two vector maps offering clip, intersection, difference, "
-"symmetrical difference, union operators."
+msgid "Overlays two vector maps offering clip, intersection, difference, symmetrical difference, union operators."
 msgstr ""
 #: ../vector/v.overlay/main.c:73
@@ -20330,10 +19563,7 @@
 msgstr ""
 #: ../vector/v.overlay/main.c:109
-msgid ""
-"Feature is written to output if the result of operation 'ainput operator "
-"binput' is true. Input feature is considered to be true, if category of "
+msgid "Feature is written to output if the result of operation 'ainput operator binput' is true. Input feature is considered to be true, if category of given layer is defined."
 msgstr ""
 #: ../vector/v.overlay/main.c:116
@@ -20345,15 +19575,11 @@
 msgstr ""
 #: ../vector/v.overlay/main.c:118
-msgid ""
-"also known as 'difference' (features from ainput not overlayed by features "
-"from binput)"
+msgid "also known as 'difference' (features from ainput not overlayed by features from binput)"
 msgstr ""
 #: ../vector/v.overlay/main.c:120
-msgid ""
-"also known as 'symmetrical difference' (features from either ainput or "
-"binput but not those from ainput overlayed by binput (only for atype=area)"
+msgid "also known as 'symmetrical difference' (features from either ainput or binput but not those from ainput overlayed by binput (only for atype=area)"
 msgstr ""
 #: ../vector/v.overlay/main.c:131
@@ -20506,8 +19732,7 @@
 #: ../vector/v.net.path/path.c:233
 #, c-format
-msgid ""
-"Point with category [%d] is not reachable from point with category [%d]"
+msgid "Point with category [%d] is not reachable from point with category [%d]"
 msgstr ""
 #: ../vector/v.net.path/path.c:302
@@ -20535,8 +19760,7 @@
 msgstr ""
 #: ../vector/v.net.path/main.c:72
-msgid ""
-"Name of file containing start and end points. If not given, read from stdin"
+msgid "Name of file containing start and end points. If not given, read from stdin"
 msgstr ""
 #: ../vector/v.net.path/main.c:101
@@ -20544,10 +19768,7 @@
 msgstr ""
 #: ../vector/v.net.path/main.c:102
-msgid ""
-"If start/end are given as coordinates. If start/end point is outside this "
-"threshold, the path is not found and error message is printed. To speed up "
-"the process, keep this value as low as possible."
+msgid "If start/end are given as coordinates. If start/end point is outside this threshold, the path is not found and error message is printed. To speed up the process, keep this value as low as possible."
 msgstr ""
 #: ../vector/v.neighbors/main.c:55
@@ -20555,10 +19776,7 @@
 msgstr ""
 #: ../vector/v.neighbors/main.c:56
-msgid ""
-"Makes each cell value a function of the attribute values assigned to the "
-"vector points or centroids around it, and stores new cell values in an "
-"output raster map."
+msgid "Makes each cell value a function of the attribute values assigned to the vector points or centroids around it, and stores new cell values in an output raster map."
 msgstr ""
 #: ../vector/v.neighbors/main.c:72 ../raster/r.neighbors/main.c:204
@@ -20575,9 +19793,7 @@
 #: ../vector/v.neighbors/main.c:103
 #, c-format
-msgid ""
-"The search diameter %g is smaller than cell diagonal %g: some points could "
-"not be detected"
+msgid "The search diameter %g is smaller than cell diagonal %g: some points could not be detected"
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:75
@@ -20591,9 +19807,7 @@
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:88
-msgid ""
-"Maybe it takes too long. It will depend on how many points you are "
-"considering."
+msgid "Maybe it takes too long. It will depend on how many points you are considering."
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:119
@@ -20609,9 +19823,7 @@
 #: ../vector/v.surf.bspline/crosscorr.c:151
 #: ../raster/r.resamp.bspline/crosscorr.c:197
 #, c-format
-msgid ""
-"Too many splines (%d x %d). Consider changing spline steps \"ew_step=\" "
-"\"ns_step=\"."
+msgid "Too many splines (%d x %d). Consider changing spline steps \"ew_step=\" \"ns_step=\"."
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:169
@@ -20640,16 +19852,13 @@
 #: ../vector/v.surf.bspline/crosscorr.c:313
 #: ../raster/r.resamp.bspline/crosscorr.c:324
-msgid ""
-"Different number of splines and lambda_i values have been taken for the "
-"cross correlation"
+msgid "Different number of splines and lambda_i values have been taken for the cross correlation"
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:315
 #: ../raster/r.resamp.bspline/crosscorr.c:326
 #, c-format
-msgid ""
-"The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
+msgid "The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:323
@@ -20669,15 +19878,11 @@
 msgstr ""
 #: ../vector/v.surf.bspline/main.c:96
-msgid ""
-"Performs bicubic or bilinear spline interpolation with Tykhonov "
-"regularization."
+msgid "Performs bicubic or bilinear spline interpolation with Tykhonov regularization."
 msgstr ""
 #: ../vector/v.surf.bspline/main.c:101 ../raster/r.resamp.bspline/main.c:144
-msgid ""
-"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
-"cross validation method"
+msgid "Find the best Tykhonov regularizing parameter using a \"leave-one-out\" cross validation method"
 msgstr ""
 #: ../vector/v.surf.bspline/main.c:105 ../vector/v.outlier/main.c:79
@@ -20766,9 +19971,7 @@
 #: ../vector/v.surf.bspline/main.c:338
 #, c-format
-msgid ""
-"Sorry, the <%s> driver is not compatible with the vector output of this "
-"module. Try with raster output or another driver."
+msgid "Sorry, the <%s> driver is not compatible with the vector output of this module. Try with raster output or another driver."
 msgstr ""
 #: ../vector/v.surf.bspline/main.c:361
@@ -20844,9 +20047,7 @@
 msgstr ""
 #: ../vector/v.surf.idw/main.c:92
-msgid ""
-"Provides surface interpolation from vector point data by Inverse Distance "
-"Squared Weighting."
+msgid "Provides surface interpolation from vector point data by Inverse Distance Squared Weighting."
 msgstr ""
 #: ../vector/v.surf.idw/main.c:101
@@ -20874,9 +20075,7 @@
 msgstr ""
 #: ../vector/v.surf.idw/main.c:129
-msgid ""
-"Slower but uses less memory and includes points from outside region in the "
-"interpolation"
+msgid "Slower but uses less memory and includes points from outside region in the interpolation"
 msgstr ""
 #: ../vector/v.surf.idw/main.c:139
@@ -20954,9 +20153,7 @@
 msgstr ""
 #: ../vector/v.buffer/main.c:293
-msgid ""
-"Maximum distance between theoretical arc and polygon segments as multiple of"
-" buffer"
+msgid "Maximum distance between theoretical arc and polygon segments as multiple of buffer"
 msgstr ""
 #: ../vector/v.buffer/main.c:298
@@ -20972,9 +20169,7 @@
 msgstr ""
 #: ../vector/v.buffer/main.c:326
-msgid ""
-"Note: In latitude-longitude coordinate system specify distances in degree "
-"unit"
+msgid "Note: In latitude-longitude coordinate system specify distances in degree unit"
 msgstr ""
 #: ../vector/v.buffer/main.c:330
@@ -21009,9 +20204,7 @@
 msgstr ""
 #: ../vector/v.buffer/main.c:464
-msgid ""
-"No features available for buffering. Check type option and features "
-"available in the input vector."
+msgid "No features available for buffering. Check type option and features available in the input vector."
 msgstr ""
 #: ../vector/v.buffer/main.c:481
@@ -21020,9 +20213,7 @@
 msgstr ""
 #: ../vector/v.buffer/main.c:486
-msgid ""
-"Negative distances for internal buffers are not supported and converted to "
-"positive values."
+msgid "Negative distances for internal buffers are not supported and converted to positive values."
 msgstr ""
 #: ../vector/v.buffer/main.c:496
@@ -21145,8 +20336,7 @@
 msgstr ""
 #: ../vector/v.outlier/main.c:355
-msgid ""
-"No subregions found! Check values for 'ew_step' and 'ns_step' parameters"
+msgid "No subregions found! Check values for 'ew_step' and 'ns_step' parameters"
 msgstr ""
 #: ../vector/v.outlier/main.c:428
@@ -21265,9 +20455,7 @@
 msgstr ""
 #: ../db/db.copy/main.c:40
-msgid ""
-"Either 'from_table' (optionally with 'where') can be used or 'select' "
-"option, but not 'from_table' and 'select' at the same time."
+msgid "Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
 msgstr ""
 #: ../db/db.copy/main.c:46
@@ -21344,9 +20532,7 @@
 msgstr ""
 #: ../db/db.databases/main.c:53
-msgid ""
-"Unable to list databases. Try to define correct connection settings by "
-"db.login."
+msgid "Unable to list databases. Try to define correct connection settings by db.login."
 msgstr ""
 #: ../db/db.databases/main.c:63
@@ -21439,23 +20625,17 @@
 #: ../db/drivers/postgres/describe.c:130 ../db/drivers/ogr/describe.c:186
 #, c-format
-msgid ""
-"Column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
-"may be damaged"
+msgid "Column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data may be damaged"
 msgstr ""
 #: ../db/drivers/postgres/describe.c:134
 #, c-format
-msgid ""
-"Column '%s' : type character varying is stored as varchar(250) some data may"
-" be lost"
+msgid "Column '%s' : type character varying is stored as varchar(250) some data may be lost"
 msgstr ""
 #: ../db/drivers/postgres/describe.c:140
 #, c-format
-msgid ""
-"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1"
-" (true)"
+msgid "column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 (true)"
 msgstr ""
 #: ../db/drivers/postgres/execute.c:42 ../db/drivers/mysql/execute.c:41
@@ -21782,9 +20962,7 @@
 #: ../db/drivers/mysql/describe.c:127
 #, c-format
-msgid ""
-"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
-"damaged"
+msgid "column '%s' : type BIGINT is stored as integer (4 bytes) some data may be damaged"
 msgstr ""
 #: ../db/drivers/mysql/execute.c:62
@@ -21871,9 +21049,7 @@
 #: ../db/drivers/ogr/describe.c:204
 #, c-format
-msgid ""
-"column '%s', type 'string': unknown width -> stored as varchar(250) some "
-"data may be lost"
+msgid "column '%s', type 'string': unknown width -> stored as varchar(250) some data may be lost"
 msgstr ""
 #: ../db/drivers/ogr/describe.c:212 ../db/drivers/ogr/fetch.c:160
@@ -21968,8 +21144,7 @@
 msgstr ""
 #: ../db/drivers/sqlite/fetch.c:218
-msgid ""
-"SQLite driver: parsing of interval values not implemented; assuming seconds"
+msgid "SQLite driver: parsing of interval values not implemented; assuming seconds"
 msgstr ""
 #: ../db/drivers/sqlite/fetch.c:223
@@ -22126,9 +21301,7 @@
 msgstr ""
 #: ../display/d.rgb/main.c:58
-msgid ""
-"Displays three user-specified raster maps as red, green, and blue overlays "
-"in the active graphics frame."
+msgid "Displays three user-specified raster maps as red, green, and blue overlays in the active graphics frame."
 msgstr ""
 #: ../display/d.rgb/main.c:63 ../display/d.rast/main.c:81
@@ -22158,9 +21331,7 @@
 msgstr ""
 #: ../display/d.linegraph/main.c:126
-msgid ""
-"Generates and displays simple line graphs in the active graphics monitor "
-"display frame."
+msgid "Generates and displays simple line graphs in the active graphics monitor display frame."
 msgstr ""
 #: ../display/d.linegraph/main.c:130
@@ -22468,15 +21639,11 @@
 msgstr ""
 #: ../display/d.graph/main.c:61
-msgid ""
-"Program for generating and displaying simple graphics on the display "
-"monitor."
+msgid "Program for generating and displaying simple graphics on the display monitor."
 msgstr ""
 #: ../display/d.graph/main.c:66
-msgid ""
-"Name of file containing graphics commands, if not given reads from standard "
-"input"
+msgid "Name of file containing graphics commands, if not given reads from standard input"
 msgstr ""
 #: ../display/d.graph/main.c:73
@@ -22556,9 +21723,7 @@
 msgstr ""
 #: ../display/d.grid/main.c:58
-msgid ""
-"Overlays a user-specified grid in the active display frame on the graphics "
-"monitor."
+msgid "Overlays a user-specified grid in the active display frame on the graphics monitor."
 msgstr ""
 #: ../display/d.grid/main.c:66
@@ -22566,9 +21731,7 @@
 msgstr ""
 #: ../display/d.grid/main.c:68
-msgid ""
-"0 for north-south resolution of the current region. In map units or "
-"DDD:MM:SS format. Example: \"1000\" or \"0:10\""
+msgid "0 for north-south resolution of the current region. In map units or DDD:MM:SS format. Example: \"1000\" or \"0:10\""
 msgstr ""
 #: ../display/d.grid/main.c:76
@@ -22710,9 +21873,7 @@
 msgstr ""
 #: ../display/d.text/main.c:142
-msgid ""
-"Draws text in the active display frame on the graphics monitor using the "
-"current font."
+msgid "Draws text in the active display frame on the graphics monitor using the current font."
 msgstr ""
 #: ../display/d.text/main.c:148
@@ -22746,9 +21907,7 @@
 msgstr ""
 #: ../display/d.text/main.c:198
-msgid ""
-"Screen position at which text will begin to be drawn (percentage, [0,0] is "
-"lower left)"
+msgid "Screen position at which text will begin to be drawn (percentage, [0,0] is lower left)"
 msgstr ""
 #: ../display/d.text/main.c:199 ../display/d.text/main.c:208
@@ -22860,14 +22019,12 @@
 #: ../display/d.colortable/main.c:112
 #, c-format
-msgid ""
-"<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
+msgid "<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
 msgstr ""
 #: ../display/d.colortable/main.c:126
 #, c-format
-msgid ""
-"<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
+msgid "<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
 msgstr ""
 #: ../display/d.colortable/main.c:137
@@ -23071,9 +22228,7 @@
 msgstr ""
 #: ../display/d.his/main.c:69
-msgid ""
-"Displays the result obtained by combining hue, intensity, and saturation "
-"(HIS) values from user-specified input raster map layers."
+msgid "Displays the result obtained by combining hue, intensity, and saturation (HIS) values from user-specified input raster map layers."
 msgstr ""
 #: ../display/d.his/main.c:78 ../raster/r.his/main.c:82
@@ -23101,9 +22256,7 @@
 msgstr ""
 #: ../display/d.histogram/main.c:87
-msgid ""
-"Displays a histogram in the form of a pie or bar chart for a user-specified "
-"raster map."
+msgid "Displays a histogram in the form of a pie or bar chart for a user-specified raster map."
 msgstr ""
 #: ../display/d.histogram/main.c:91
@@ -23155,8 +22308,7 @@
 msgstr ""
 #: ../display/d.title/main.c:52
-msgid ""
-"Create a TITLE for a raster map in a form suitable for display with d.text."
+msgid "Create a TITLE for a raster map in a form suitable for display with d.text."
 msgstr ""
 #: ../display/d.title/main.c:63
@@ -23192,8 +22344,7 @@
 msgstr ""
 #: ../display/d.vect.chart/main.c:67
-msgid ""
-"Displays charts of vector data in the active frame on the graphics monitor."
+msgid "Displays charts of vector data in the active frame on the graphics monitor."
 msgstr ""
 #: ../display/d.vect.chart/main.c:86
@@ -23248,9 +22399,7 @@
 msgstr ""
 #: ../display/d.erase/main.c:33
-msgid ""
-"Erases the contents of the active graphics display frame with user defined "
-"color."
+msgid "Erases the contents of the active graphics display frame with user defined color."
 msgstr ""
 #: ../display/d.erase/main.c:42
@@ -23324,9 +22473,7 @@
 msgstr ""
 #: ../display/d.rast.arrow/main.c:101
-msgid ""
-"Draws arrows representing cell aspect direction for a raster map containing "
-"aspect data."
+msgid "Draws arrows representing cell aspect direction for a raster map containing aspect data."
 msgstr ""
 #: ../display/d.rast.arrow/main.c:105
@@ -23427,9 +22574,7 @@
 msgstr ""
 #: ../display/d.labels/main.c:46
-msgid ""
-"Displays text labels (created with v.label) to the active frame on the "
-"graphics monitor."
+msgid "Displays text labels (created with v.label) to the active frame on the graphics monitor."
 msgstr ""
 #: ../display/d.labels/main.c:52
@@ -23552,9 +22697,7 @@
 msgstr ""
 #: ../display/d.vect.thematic/main.c:237
-msgid ""
-"When printing legend info, include extended statistical info from "
-"classification algorithm"
+msgid "When printing legend info, include extended statistical info from classification algorithm"
 msgstr ""
 #: ../display/d.vect.thematic/main.c:243 ../display/d.vect/main.c:330
@@ -23562,16 +22705,11 @@
 msgstr ""
 #: ../display/d.vect.thematic/main.c:255
-msgid ""
-"Flag -e is deprecated, set verbose mode with --v to get the extended "
-"statistical info."
+msgid "Flag -e is deprecated, set verbose mode with --v to get the extended statistical info."
 msgstr ""
 #: ../display/d.vect.thematic/main.c:258
-msgid ""
-"Option legendfile is deprecated, either use flag -l to print legend to "
-"standard output, or set GRASS_LEGEND_FILE environment variable (see "
-"d.legend.vect for details)."
+msgid "Option legendfile is deprecated, either use flag -l to print legend to standard output, or set GRASS_LEGEND_FILE environment variable (see d.legend.vect for details)."
 msgstr ""
 #: ../display/d.vect.thematic/main.c:277
@@ -23588,8 +22726,7 @@
 msgid "Data (%s) not numeric. Column must be numeric."
 msgstr ""
-#: ../display/d.vect.thematic/main.c:316
-#: ../display/d.vect.thematic/plot1.c:135
+#: ../display/d.vect.thematic/main.c:316 ../display/d.vect.thematic/plot1.c:135
 #: ../display/d.vect.thematic/plot1.c:163
 #, c-format
 msgid "Cannot select data (%s) from table"
@@ -23601,9 +22738,7 @@
 msgstr ""
 #: ../display/d.vect.thematic/main.c:390
-msgid ""
-"You gave both manual breaks and a classification algorithm or a number of "
-"classes. The manual breaks have precedence and will thus be used."
+msgid "You gave both manual breaks and a classification algorithm or a number of classes. The manual breaks have precedence and will thus be used."
 msgstr ""
 #: ../display/d.vect.thematic/main.c:427
@@ -23627,8 +22762,7 @@
 msgstr ""
 #: ../display/d.vect.thematic/main.c:469
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn."
+msgid "The bounding box of the map is outside the current region, nothing drawn."
 msgstr ""
 #: ../display/d.vect.thematic/main.c:522
@@ -23654,9 +22788,7 @@
 #: ../display/d.vect.thematic/plot1.c:130
 #, c-format
-msgid ""
-"Color definition column (%s) not a string. Column must be of form "
-"RRR:GGG:BBB where RGB values range 0-255."
+msgid "Color definition column (%s) not a string. Column must be of form RRR:GGG:BBB where RGB values range 0-255."
 msgstr ""
 #: ../display/d.vect.thematic/plot1.c:148
@@ -23677,9 +22809,7 @@
 #: ../display/d.vect.thematic/plot1.c:279
 #, c-format
-msgid ""
-"Error in color definition column (%s), element %d with cat %d: colorstring "
-"[%s]"
+msgid "Error in color definition column (%s), element %d with cat %d: colorstring [%s]"
 msgstr ""
 #: ../display/d.vect.thematic/plot1.c:286
@@ -23689,8 +22819,7 @@
 #: ../display/d.vect.thematic/plot1.c:354
 #, c-format
-msgid ""
-"Error in line width column (%s), element %d with cat %d: line width [%d]"
+msgid "Error in line width column (%s), element %d with cat %d: line width [%d]"
 msgstr ""
 #: ../display/d.vect.thematic/display.c:51 ../display/d.vect/lines.c:107
@@ -23735,9 +22864,7 @@
 msgstr[1] ""
 #: ../display/d.vect/area.c:37
-msgid ""
-"Unable to display areas, topology not available. Please try to rebuild "
-"topology using v.build or v.build.all."
+msgid "Unable to display areas, topology not available. Please try to rebuild topology using v.build or v.build.all."
 msgstr ""
 #: ../display/d.vect/area.c:137
@@ -23766,9 +22893,7 @@
 msgstr ""
 #: ../display/d.vect/lines.c:121
-msgid ""
-"Unable to display features by id, topology not available. Please try to "
-"rebuild topology using v.build or v.build.all."
+msgid "Unable to display features by id, topology not available. Please try to rebuild topology using v.build or v.build.all."
 msgstr ""
 #: ../display/d.vect/lines.c:169
@@ -23916,19 +23041,15 @@
 msgstr ""
 #: ../display/d.vect/main.c:295
-msgid ""
-"Minimum region size (average from height and width) when map is displayed"
+msgid "Minimum region size (average from height and width) when map is displayed"
 msgstr ""
 #: ../display/d.vect/main.c:303
-msgid ""
-"Maximum region size (average from height and width) when map is displayed"
+msgid "Maximum region size (average from height and width) when map is displayed"
 msgstr ""
 #: ../display/d.vect/main.c:311
-msgid ""
-"Random colors according to category number (or layer number if 'layer=-1' is"
-" given)"
+msgid "Random colors according to category number (or layer number if 'layer=-1' is given)"
 msgstr ""
 #: ../display/d.vect/main.c:318
@@ -23940,9 +23061,7 @@
 msgstr ""
 #: ../display/d.vect/main.c:324
-msgid ""
-"This makes circle areas proportionate to the size_column values instead of "
-"circle radius"
+msgid "This makes circle areas proportionate to the size_column values instead of circle radius"
 msgstr ""
 #: ../display/d.vect/main.c:347
@@ -23955,9 +23074,7 @@
 #: ../display/d.vect/main.c:368
 #, c-format
-msgid ""
-"The -%c flag and <%s> option cannot be used together, the -%c flag will be "
-"ignored!"
+msgid "The -%c flag and <%s> option cannot be used together, the -%c flag will be ignored!"
 msgstr ""
 #: ../display/d.vect/main.c:392 ../display/d.vect/main.c:398
@@ -23977,8 +23094,7 @@
 msgstr ""
 #: ../display/d.vect/main.c:426
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn"
+msgid "The bounding box of the map is outside the current region, nothing drawn"
 msgstr ""
 #: ../display/d.vect/main.c:500
@@ -23997,10 +23113,7 @@
 #: ../display/d.vect/shape.c:68
 #, c-format
-msgid ""
-"Color definition column ('%s') not a string. Column must be of form "
-"'RRR:GGG:BBB' where RGB values range 0-255. You can use '%s' module to "
-"define color rules. Unable to colorize features."
+msgid "Color definition column ('%s') not a string. Column must be of form 'RRR:GGG:BBB' where RGB values range 0-255. You can use '%s' module to define color rules. Unable to colorize features."
 msgstr ""
 #: ../display/d.vect/shape.c:77 ../display/d.vect/shape.c:100
@@ -24037,8 +23150,7 @@
 msgstr ""
 #: ../display/d.vect/shape.c:182
-msgid ""
-"Vector map is not 3D. Unable to colorize features based on z-coordinates."
+msgid "Vector map is not 3D. Unable to colorize features based on z-coordinates."
 msgstr ""
 #: ../display/d.vect/shape.c:186
@@ -24052,9 +23164,7 @@
 msgstr ""
 #: ../display/d.vect/topo.c:18
-msgid ""
-"Unable to display topology, not available.Please try to rebuild topology "
-"using v.build or v.build.all."
+msgid "Unable to display topology, not available.Please try to rebuild topology using v.build or v.build.all."
 msgstr ""
 #: ../display/d.vect/zcoor.c:19
@@ -24062,9 +23172,7 @@
 msgstr ""
 #: ../display/d.font/main.c:48
-msgid ""
-"Selects the font in which text will be displayed on the user's graphics "
-"monitor."
+msgid "Selects the font in which text will be displayed on the user's graphics monitor."
 msgstr ""
 #: ../display/d.font/main.c:56
@@ -24099,8 +23207,7 @@
 #: ../display/d.font/main.c:124
 #, c-format
-msgid ""
-"Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
+msgid "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
 msgstr ""
 #: ../display/d.fontlist/main.c:47
@@ -24112,9 +23219,7 @@
 msgstr ""
 #: ../display/d.rast.num/main.c:81
-msgid ""
-"Overlays cell category values on a raster map displayed in the active "
-"graphics frame."
+msgid "Overlays cell category values on a raster map displayed in the active graphics frame."
 msgstr ""
 #: ../display/d.rast.num/main.c:112
@@ -24141,14 +23246,11 @@
 msgstr ""
 #: ../display/d.legend/histogram.c:115
-msgid ""
-"Histogram constrained by range not yet implemented for categorical rasters"
+msgid "Histogram constrained by range not yet implemented for categorical rasters"
 msgstr ""
 #: ../display/d.legend/main.c:82
-msgid ""
-"Displays a legend for a 2D or 3D raster map in the active frame of the "
+msgid "Displays a legend for a 2D or 3D raster map in the active frame of the graphics monitor."
 msgstr ""
 #: ../display/d.legend/main.c:99 ../display/d.legend.vect/main.c:81
@@ -24212,8 +23314,7 @@
 msgstr ""
 #: ../display/d.legend/main.c:179
-msgid ""
-"Size and placement as percentage of screen coordinates (0,0 is lower left)"
+msgid "Size and placement as percentage of screen coordinates (0,0 is lower left)"
 msgstr ""
 #: ../display/d.legend/main.c:189
@@ -24329,9 +23430,7 @@
 msgstr ""
 #: ../display/d.legend/draw.c:1029
-msgid ""
-"Histogram plotting not implemented for categorical legends. Use the '-s' "
-"flag"
+msgid "Histogram plotting not implemented for categorical legends. Use the '-s' flag"
 msgstr ""
 #: ../display/d.legend/draw.c:1286
@@ -24369,9 +23468,7 @@
 msgstr ""
 #: ../display/d.where/main.c:48
-msgid ""
-"Identifies the geographic coordinates associated with point locations given "
-"in display coordinates."
+msgid "Identifies the geographic coordinates associated with point locations given in display coordinates."
 msgstr ""
 #: ../display/d.where/main.c:58
@@ -24391,9 +23488,7 @@
 msgstr ""
 #: ../display/d.where/main.c:77
-msgid ""
-"Output lat/long referenced to WGS84 ellipsoid using datum transformation "
-"parameters defined in current location (if available)"
+msgid "Output lat/long referenced to WGS84 ellipsoid using datum transformation parameters defined in current location (if available)"
 msgstr ""
 #: ../display/d.where/main.c:83
@@ -24534,9 +23629,7 @@
 msgstr ""
 #: ../display/d.geodesic/main.c:51
-msgid ""
-"Displays a geodesic line, tracing the shortest distance between two "
-"geographic points along a great circle, in a longitude/latitude data set."
+msgid "Displays a geodesic line, tracing the shortest distance between two geographic points along a great circle, in a longitude/latitude data set."
 msgstr ""
 #: ../display/d.legend.vect/main.c:55
@@ -24544,8 +23637,7 @@
 msgstr ""
 #: ../display/d.legend.vect/main.c:66
-msgid ""
-"Screen position of legend to be drawn (percentage, [0,0] is lower left)"
+msgid "Screen position of legend to be drawn (percentage, [0,0] is lower left)"
 msgstr ""
 #: ../display/d.legend.vect/main.c:74
@@ -24726,9 +23818,7 @@
 msgstr ""
 #: ../imagery/i.rgb.his/main.c:52
-msgid ""
-"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
-"Intensity-Saturation) color space."
+msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
 msgstr ""
 #: ../imagery/i.rgb.his/main.c:58
@@ -24832,9 +23922,7 @@
 msgstr ""
 #: ../imagery/i.eb.netrad/main.c:85
-msgid ""
-"Name of the difference map of temperature from surface skin to about 2 m "
-"height [K]"
+msgid "Name of the difference map of temperature from surface skin to about 2 m height [K]"
 msgstr ""
 #: ../imagery/i.eb.netrad/main.c:89
@@ -24863,9 +23951,7 @@
 msgstr ""
 #: ../imagery/i.evapo.pm/main.c:61
-msgid ""
-"Computes potential evapotranspiration calculation with hourly Penman-"
-"Monteith."
+msgid "Computes potential evapotranspiration calculation with hourly Penman-Monteith."
 msgstr ""
 #: ../imagery/i.evapo.pm/main.c:65
@@ -25064,9 +24150,7 @@
 msgstr ""
 #: ../imagery/i.maxlik/main.c:68
-msgid ""
-"Classification is based on the spectral signature information generated by "
-"either i.cluster, g.gui.iclass, or i.gensig."
+msgid "Classification is based on the spectral signature information generated by either i.cluster, g.gui.iclass, or i.gensig."
 msgstr ""
 #: ../imagery/i.maxlik/main.c:81 ../imagery/i.smap/parse.c:20
@@ -25087,16 +24171,12 @@
 #: ../imagery/i.maxlik/open.c:27
 #, c-format
-msgid ""
-"Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
-"have at least 2 raster maps."
+msgid "Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must have at least 2 raster maps."
 msgstr ""
 #: ../imagery/i.maxlik/open.c:30
 #, c-format
-msgid ""
-"Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at"
-" least 2 raster maps."
+msgid "Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at least 2 raster maps."
 msgstr ""
 #: ../imagery/i.maxlik/open.c:47
@@ -25150,9 +24230,7 @@
 msgstr ""
 #: ../imagery/i.rectify/main.c:102
-msgid ""
-"Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points."
+msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
 msgstr ""
 #: ../imagery/i.rectify/main.c:116
@@ -25172,9 +24250,7 @@
 #: ../imagery/i.rectify/main.c:153
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:137
-msgid ""
-"Use current region settings in target location (def.=calculate smallest "
-"area)"
+msgid "Use current region settings in target location (def.=calculate smallest area)"
 msgstr ""
 #: ../imagery/i.rectify/main.c:157
@@ -25357,8 +24433,7 @@
 msgstr ""
 #: ../imagery/i.vi/main.c:94
-msgid ""
-"Uses red and nir bands mostly, and some indices require additional bands."
+msgid "Uses red and nir bands mostly, and some indices require additional bands."
 msgstr ""
 #: ../imagery/i.vi/main.c:101
@@ -25485,9 +24560,7 @@
 msgstr ""
 #: ../imagery/i.vi/main.c:202
-msgid ""
-"If data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8"
-" for Landsat -> [0-255])"
+msgid "If data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8 for Landsat -> [0-255])"
 msgstr ""
 #: ../imagery/i.vi/main.c:225 ../raster/r.texture/main.c:327
@@ -25524,8 +24597,7 @@
 msgstr ""
 #: ../imagery/i.vi/main.c:251
-msgid ""
-"msavi index requires red and nir maps, and 3 parameters related to soil line"
+msgid "msavi index requires red and nir maps, and 3 parameters related to soil line"
 msgstr ""
 #: ../imagery/i.vi/main.c:254
@@ -25597,9 +24669,7 @@
 msgstr ""
 #: ../imagery/i.evapo.mh/main.c:72
-msgid ""
-"Computes evapotranspiration calculation modified or original Hargreaves "
-"formulation, 2001."
+msgid "Computes evapotranspiration calculation modified or original Hargreaves formulation, 2001."
 msgstr ""
 #: ../imagery/i.evapo.mh/main.c:78
@@ -25684,9 +24754,7 @@
 msgstr ""
 #: ../imagery/i.smap/main.c:44
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
+msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
 msgstr ""
 #: ../imagery/i.smap/model.c:43
@@ -25794,15 +24862,11 @@
 msgstr ""
 #: ../imagery/i.cluster/main.c:79
-msgid ""
-"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm."
+msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
 msgstr ""
 #: ../imagery/i.cluster/main.c:82
-msgid ""
-"The resulting signature file is used as input for i.maxlik, to generate an "
-"unsupervised image classification."
+msgid "The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
 msgstr ""
 #: ../imagery/i.cluster/main.c:102
@@ -25992,14 +25056,11 @@
 msgstr ""
 #: ../imagery/i.cluster/main.c:312
-msgid ""
-"Not enough sample points. Please run again and choose a larger sample size."
+msgid "Not enough sample points. Please run again and choose a larger sample size."
 msgstr ""
 #: ../imagery/i.cluster/main.c:316
-msgid ""
-"Not enough non-zero sample data points. Check your current region (and "
-"mask)."
+msgid "Not enough non-zero sample data points. Check your current region (and mask)."
 msgstr ""
 #: ../imagery/i.cluster/main.c:329
@@ -26227,9 +25288,7 @@
 msgstr ""
 #: ../imagery/i.aster.toar/main.c:105
-msgid ""
-"Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
-"from ASTER DN."
+msgid "Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature from ASTER DN."
 msgstr ""
 #: ../imagery/i.aster.toar/main.c:109
@@ -26282,9 +25341,7 @@
 msgstr ""
 #: ../imagery/i.his.rgb/main.c:52
-msgid ""
-"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
-"RGB (Red-Green-Blue) color space."
+msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
 msgstr ""
 #: ../imagery/i.his.rgb/main.c:58
@@ -26332,9 +25389,7 @@
 msgstr ""
 #: ../imagery/i.evapo.time/main.c:79
-msgid ""
-"Computes temporal integration of satellite ET actual (ETa) following the "
-"daily ET reference (ETo) from meteorological station(s)."
+msgid "Computes temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)."
 msgstr ""
 #: ../imagery/i.evapo.time/main.c:86
@@ -26431,15 +25486,13 @@
 msgid "Group <%s> not found in the current mapset"
 msgstr ""
-#: ../imagery/i.segment/write_output.c:100
-#: ../imagery/i.segment/open_files.c:44
+#: ../imagery/i.segment/write_output.c:100 ../imagery/i.segment/open_files.c:44
 #, c-format
 msgid "Group <%s> contains no raster maps"
 msgstr ""
-#: ../imagery/i.segment/write_output.c:116
-#: ../imagery/i.segment/open_files.c:69 ../imagery/i.segment/open_files.c:228
-#: ../imagery/i.segment/open_files.c:236
+#: ../imagery/i.segment/write_output.c:116 ../imagery/i.segment/open_files.c:69
+#: ../imagery/i.segment/open_files.c:228 ../imagery/i.segment/open_files.c:236
 #, c-format
 msgid "No min/max found in raster map <%s>"
 msgstr ""
@@ -26547,9 +25600,7 @@
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:122
-msgid ""
-"Must be integer values, each area will be segmented independent of the "
-"others"
+msgid "Must be integer values, each area will be segmented independent of the others"
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:128
@@ -26557,14 +25608,11 @@
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:133
-msgid ""
-"Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for "
-"each pixel"
+msgid "Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for each pixel"
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:139
-msgid ""
-"Weighted input, do not perform the default scaling of input raster maps"
+msgid "Weighted input, do not perform the default scaling of input raster maps"
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:158
@@ -26634,9 +25682,7 @@
 #: ../imagery/i.segment/region_growing.c:445
 #, c-format
-msgid ""
-"Segmentation processes stopped at %d due to reaching max iteration limit, "
-"more merges may be possible"
+msgid "Segmentation processes stopped at %d due to reaching max iteration limit, more merges may be possible"
 msgstr ""
 #: ../imagery/i.segment/region_growing.c:447
@@ -26697,9 +25743,7 @@
 #: ../imagery/i.segment/mean_shift.c:106
 #, c-format
-msgid ""
-"Mean shift stopped at %d due to reaching max iteration limit, more changes "
-"may be possible"
+msgid "Mean shift stopped at %d due to reaching max iteration limit, more changes may be possible"
 msgstr ""
 #: ../imagery/i.segment/mean_shift.c:108
@@ -26771,8 +25815,7 @@
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:153
 #, c-format
-msgid ""
-"Replacing coordinates of principal point '%.17g, %.17g' with '%.17g, %.17g'"
+msgid "Replacing coordinates of principal point '%.17g, %.17g' with '%.17g, %.17g'"
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:164
@@ -26806,9 +25849,7 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:50
-msgid ""
-"Interactively creates or modifies entries in a camera initial exposure "
-"station file for imagery group referenced by a sub-block."
+msgid "Interactively creates or modifies entries in a camera initial exposure station file for imagery group referenced by a sub-block."
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:62
@@ -27139,9 +26180,7 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:91
-msgid ""
-"Orthorectifies an image by using the image to photo coordinate "
-"transformation matrix."
+msgid "Orthorectifies an image by using the image to photo coordinate transformation matrix."
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:132
@@ -27311,9 +26350,7 @@
 msgstr ""
 #: ../imagery/i.albedo/main.c:138 ../imagery/i.albedo/main.c:145
-msgid ""
-"Albedo dry run to calculate some water to beach/sand/desert stretching, a "
-"kind of simple atmospheric correction"
+msgid "Albedo dry run to calculate some water to beach/sand/desert stretching, a kind of simple atmospheric correction"
 msgstr ""
 #: ../imagery/i.albedo/main.c:143
@@ -27325,9 +26362,7 @@
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:69
-msgid ""
-"Calculates top-of-atmosphere radiance or reflectance and temperature for "
-"Landsat MSS/TM/ETM+/OLI"
+msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+/OLI"
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:75
@@ -27500,8 +26535,7 @@
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:227
-msgid ""
-"Input raster maps use as extension the number of the band instead the code"
+msgid "Input raster maps use as extension the number of the band instead the code"
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:231
@@ -27590,16 +26624,11 @@
 msgstr ""
 #: ../imagery/i.landsat.toar/landsat.c:116
-msgid ""
-"The DOS4 method is not applicable here: approximation of atmospheric "
-"transmittance coefficients is unstable. Use another DOS method or use other "
-"sun_elevation parameter"
+msgid "The DOS4 method is not applicable here: approximation of atmospheric transmittance coefficients is unstable. Use another DOS method or use other sun_elevation parameter"
 msgstr ""
 #: ../imagery/i.evapo.pt/main.c:69
-msgid ""
-"Computes evapotranspiration calculation Priestley and Taylor formulation, "
-"1972."
+msgid "Computes evapotranspiration calculation Priestley and Taylor formulation, 1972."
 msgstr ""
 #: ../imagery/i.evapo.pt/main.c:75
@@ -27843,9 +26872,7 @@
 #: ../imagery/i.landsat.acca/main.c:70
 #, c-format
-msgid ""
-"Input raster map <%s> is not floating point (process DN using i.landsat.toar"
-" to radiance first)"
+msgid "Input raster map <%s> is not floating point (process DN using i.landsat.toar to radiance first)"
 msgstr ""
 #: ../imagery/i.landsat.acca/main.c:104
@@ -27890,9 +26917,7 @@
 msgstr ""
 #: ../imagery/i.landsat.acca/main.c:158
-msgid ""
-"Bypass second-pass processing, and merge warm (not ambiguous) and cold "
-"clouds"
+msgid "Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
 msgstr ""
 #: ../imagery/i.landsat.acca/main.c:163
@@ -28333,9 +27358,7 @@
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:342
-msgid ""
-"Band number of MODIS product "
-"(mod09Q1=[1,2],mod09A1=[1-7],m[o/y]d09CMG=[1-7], mcd43B2q=[1-7])"
+msgid "Band number of MODIS product (mod09Q1=[1,2],mod09A1=[1-7],m[o/y]d09CMG=[1-7], mcd43B2q=[1-7])"
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:346
@@ -28538,9 +27561,7 @@
 msgstr ""
 #: ../misc/m.cogo/main.c:228
-msgid ""
-"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa."
+msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
 msgstr ""
 #: ../misc/m.cogo/main.c:230
@@ -28963,9 +27984,7 @@
 msgstr ""
 #: ../misc/m.nviz.image/args.c:903
-msgid ""
-"Place north arrow at given position \t(in screen coordinates from bottom "
-"left corner)"
+msgid "Place north arrow at given position \t(in screen coordinates from bottom left corner)"
 msgstr ""
 #: ../misc/m.nviz.image/args.c:905 ../misc/m.nviz.image/args.c:915
@@ -29033,9 +28052,7 @@
 msgstr ""
 #: ../misc/m.nviz.image/main.c:57
-msgid ""
-"Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
-"data) in 3D."
+msgid "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D."
 msgstr ""
 #: ../misc/m.nviz.image/main.c:83
@@ -29263,9 +28280,7 @@
 msgstr ""
 #: ../misc/m.nviz.script/main.c:439
-msgid ""
-"Skipping this point, selected point is outside region. Perhaps the camera "
-"setback distance puts it beyond the edge?"
+msgid "Skipping this point, selected point is outside region. Perhaps the camera setback distance puts it beyond the edge?"
 msgstr ""
 #: ../raster/r.in.bin/main.c:61 ../raster/r.in.bin/main.c:70
@@ -29388,9 +28403,7 @@
 #: ../raster/r.in.bin/main.c:554
 #, c-format
-msgid ""
-"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
-"significantly. Did you assign %s= and %s= correctly?"
+msgid "East-West (ewres: %f) and North-South (nwres: %f) resolution differ significantly. Did you assign %s= and %s= correctly?"
 msgstr ""
 #: ../raster/r.in.bin/main.c:575
@@ -29466,13 +28479,7 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:186
-msgid ""
-"The module has two different modes of operation: 1. Computes the entire "
-"horizon around a single point whose coordinates are given with the 'coord' "
-"option. The horizon height (in radians). 2. Computes one or more raster maps"
-" of the horizon height in a single direction. The input for this is the "
-"angle (in degrees), which is measured counterclockwise with east=0, north=90"
-" etc. The output is the horizon height in radians."
+msgid "The module has two different modes of operation: 1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction. The input for this is the angle (in degrees), which is measured counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
 msgstr ""
 #: ../raster/r.horizon/main.c:203
@@ -29499,33 +28506,23 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:237
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer around the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer around the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:245
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer eastward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer eastward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:253
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer westward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer westward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:261
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer northward the present"
-" region"
+msgid "For horizon rasters, read from the DEM an extra buffer northward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:269
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer southward the present"
-" region"
+msgid "For horizon rasters, read from the DEM an extra buffer southward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:277
@@ -29557,8 +28554,7 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:355
-msgid ""
-"Note: In latitude-longitude coordinate system specify buffers in degree unit"
+msgid "Note: In latitude-longitude coordinate system specify buffers in degree unit"
 msgstr ""
 #: ../raster/r.horizon/main.c:368
@@ -29647,9 +28643,7 @@
 msgstr ""
 #: ../raster/r.out.ascii/main.c:86
-msgid ""
-"Number of values printed before wrapping a line (only SURFER or MODFLOW "
-"format)"
+msgid "Number of values printed before wrapping a line (only SURFER or MODFLOW format)"
 msgstr ""
 #: ../raster/r.out.ascii/main.c:91
@@ -29751,10 +28745,7 @@
 msgstr ""
 #: ../raster/r.walk/main.c:183
-msgid ""
-"Creates a raster map showing the anisotropic cumulative cost of moving "
-"between different geographic locations on an input raster map whose cell "
-"category values represent cost."
+msgid "Creates a raster map showing the anisotropic cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
 msgstr ""
 #: ../raster/r.walk/main.c:193
@@ -30360,8 +29351,7 @@
 msgstr ""
 #: ../raster/r.proj/main.c:219
-msgid ""
-"Print input map's bounds in the current projection and exit (shell style)"
+msgid "Print input map's bounds in the current projection and exit (shell style)"
 msgstr ""
 #: ../raster/r.proj/main.c:254
@@ -30484,9 +29474,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:126
-msgid ""
-"Name of location to create or to read projection from for GCPs "
-"transformation"
+msgid "Name of location to create or to read projection from for GCPs transformation"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:143
@@ -30498,8 +29486,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:152
-msgid ""
-"Zero-padding of band number by filling with leading zeros up to given number"
+msgid "Zero-padding of band number by filling with leading zeros up to given number"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:153
@@ -30523,9 +29510,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:220
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not"
-" import the raster file."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the raster file."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:225
@@ -30545,8 +29530,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:265
-msgid ""
-"The number of digits for band numbering must be equal or greater than 0"
+msgid "The number of digits for band numbering must be equal or greater than 0"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:284
@@ -30561,9 +29545,7 @@
 #: ../raster/r.in.gdal/main.c:337
 #, c-format
-msgid ""
-"Input seems to be NOAA/AVHRR data which needs to be georeferenced with thin "
-"plate spline transformation (%s or %s)."
+msgid "Input seems to be NOAA/AVHRR data which needs to be georeferenced with thin plate spline transformation (%s or %s)."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:356 ../raster/r.in.gdal/main.c:703
@@ -30573,22 +29555,15 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:376
-msgid ""
-"Input raster map is flipped or rotated - cannot import. You may use "
-"'gdalwarp' to transform the map to North-up."
+msgid "Input raster map is flipped or rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:417
-msgid ""
-"Map bounds have been constrained to geographic coordinates. You will almost "
-"certainly want to check map bounds and resolution with r.info and reset them"
-" with r.region before going any further."
+msgid "Map bounds have been constrained to geographic coordinates. You will almost certainly want to check map bounds and resolution with r.info and reset them with r.region before going any further."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:458 ../raster/r.external/proj.c:18
-msgid ""
-"Unable to convert input raster map projection information to GRASS format "
-"for checking"
+msgid "Unable to convert input raster map projection information to GRASS format for checking"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:491 ../raster/r.external/proj.c:47
@@ -30600,9 +29575,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:560 ../raster/r.external/proj.c:111
-msgid ""
-"Consider generating a new location from the input dataset using the "
-"'location' parameter.\n"
+msgid "Consider generating a new location from the input dataset using the 'location' parameter.\n"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:584
@@ -30654,9 +29627,7 @@
 #: ../raster/r.in.gdal/main.c:859
 #, c-format
-msgid ""
-"The target for the output group <%s> has been set to location <%s>, mapset "
-"<PERMANENT>."
+msgid "The target for the output group <%s> has been set to location <%s>, mapset <PERMANENT>."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:930
@@ -30742,9 +29713,7 @@
 msgstr ""
 #: ../raster/r.topmodel/main.c:94
-msgid ""
-"Must be clipped to the catchment boundary. Used for generating "
-"outtopidxstats"
+msgid "Must be clipped to the catchment boundary. Used for generating outtopidxstats"
 msgstr ""
 #: ../raster/r.topmodel/main.c:96 ../raster/r.topmodel/main.c:106
@@ -30879,10 +29848,7 @@
 msgstr ""
 #: ../raster/r.sunhours/main.c:77
-msgid ""
-"Solar elevation: the angle between the direction of the geometric center of "
-"the sun's apparent disk and the (idealized) horizon. Solar azimuth: the "
-"angle from due north in clockwise direction."
+msgid "Solar elevation: the angle between the direction of the geometric center of the sun's apparent disk and the (idealized) horizon. Solar azimuth: the angle from due north in clockwise direction."
 msgstr ""
 #: ../raster/r.sunhours/main.c:83
@@ -31228,9 +30194,7 @@
 #: ../raster/r.regression.line/main.c:65
 #: ../raster/r.regression.multi/main.c:157
-msgid ""
-"ASCII file for storing regression coefficients (output to screen if file not"
-" specified)."
+msgid "ASCII file for storing regression coefficients (output to screen if file not specified)."
 msgstr ""
 #: ../raster/r.param.scale/main.c:42
@@ -31254,9 +30218,7 @@
 msgstr ""
 #: ../raster/r.param.scale/interface.c:60
-msgid ""
-"Uses a multi-scale approach by taking fitting quadratic parameters to any "
-"size window (via least squares)."
+msgid "Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
 msgstr ""
 #: ../raster/r.param.scale/interface.c:78
@@ -31512,9 +30474,7 @@
 msgstr ""
 #: ../raster/r.li/r.li.patchdensity/main.c:50
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour "
-"algorithm"
+msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../raster/r.li/r.li.pielou/pielou.c:45
@@ -31601,14 +30561,11 @@
 msgstr ""
 #: ../raster/r.li/r.li.patchnum/main.c:49
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour "
-"algorithm."
+msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
 msgstr ""
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:47
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:68
@@ -31616,9 +30573,7 @@
 msgstr ""
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:69
-msgid ""
-"It can be integer, double or float; it will be changed in function of map "
-"type"
+msgid "It can be integer, double or float; it will be changed in function of map type"
 msgstr ""
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:74
@@ -31634,9 +30589,7 @@
 msgstr ""
 #: ../raster/r.li/r.li.mps/mps.c:51
-msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
+msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../raster/r.li/r.li.shannon/shannon.c:45
@@ -31657,9 +30610,7 @@
 msgstr ""
 #: ../raster/r.category/main.c:55
-msgid ""
-"Manages category values and labels associated with user-specified raster map"
-" layers."
+msgid "Manages category values and labels associated with user-specified raster map layers."
 msgstr ""
 #: ../raster/r.category/main.c:69
@@ -31728,10 +30679,7 @@
 msgstr ""
 #: ../raster/r.his/main.c:73
-msgid ""
-"Generates red, green and blue (RGB) raster map layers combining hue, "
-"intensity and saturation (HIS) values from user-specified input raster map "
-"layers."
+msgid "Generates red, green and blue (RGB) raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
 msgstr ""
 #: ../raster/r.his/main.c:103
@@ -31776,9 +30724,7 @@
 msgstr ""
 #: ../raster/r.to.rast3/main.c:230
-msgid ""
-"The 2D and 3D region settings are different. Using the 3D region settings to"
-" adjust the 2D region."
+msgid "The 2D and 3D region settings are different. Using the 3D region settings to adjust the 2D region."
 msgstr ""
 #: ../raster/r.to.rast3/main.c:262
@@ -31803,10 +30749,7 @@
 msgstr ""
 #: ../raster/r.resamp.rst/main.c:151
-msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
+msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
 msgstr ""
 #: ../raster/r.resamp.rst/main.c:162
@@ -31975,9 +30918,7 @@
 msgstr ""
 #: ../raster/r.stats.zonal/main.c:105
-msgid ""
-"Calculates category or object oriented statistics (accumulator-based "
-"statistics)."
+msgid "Calculates category or object oriented statistics (accumulator-based statistics)."
 msgstr ""
 #: ../raster/r.stats.zonal/main.c:115 ../raster/r.statistics/main.c:69
@@ -32083,9 +31024,8 @@
 msgstr ""
 #: ../raster/r.relief/main.c:316 ../raster/r.series/main.c:386
-#: ../raster/r.series.accumulate/main.c:318
-#: ../raster/r.slope.aspect/main.c:544 ../raster/r.patch/main.c:140
-#: ../raster/r.series.interp/main.c:339
+#: ../raster/r.series.accumulate/main.c:318 ../raster/r.slope.aspect/main.c:544
+#: ../raster/r.patch/main.c:140 ../raster/r.series.interp/main.c:339
 msgid "Percent complete..."
 msgstr ""
@@ -32110,15 +31050,11 @@
 msgstr ""
 #: ../raster/r.neighbors/main.c:175
-msgid ""
-"Makes each cell category value a function of the category values assigned to"
-" the cells around it, and stores new cell values in an output raster map "
-"layer."
+msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
 msgstr ""
 #: ../raster/r.neighbors/main.c:185
-msgid ""
-"Name of an input raster map to select the cells which should be processed"
+msgid "Name of an input raster map to select the cells which should be processed"
 msgstr ""
 #: ../raster/r.neighbors/main.c:206 ../raster/r.neighbors/main.c:214
@@ -32162,15 +31098,12 @@
 #: ../raster/r.neighbors/main.c:329
 #, c-format
-msgid ""
-"Method %s not compatible with weighing window, using weight mask instead"
+msgid "Method %s not compatible with weighing window, using weight mask instead"
 msgstr ""
 #: ../raster/r.neighbors/main.c:337
 #, c-format
-msgid ""
-"Method %s not compatible with Gaussian filter, using unweighed version "
-"instead"
+msgid "Method %s not compatible with Gaussian filter, using unweighed version instead"
 msgstr ""
 #: ../raster/r.neighbors/main.c:386
@@ -32179,16 +31112,12 @@
 msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:66
-msgid ""
-"Unable to calculate sun position in un-projected locations. Specify "
-"sunposition directly."
+msgid "Unable to calculate sun position in un-projected locations. Specify sunposition directly."
 msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:88
 #, c-format
-msgid ""
-"Specified point %f, %f outside of current region, is that intended? Anyway, "
-"it will be used."
+msgid "Specified point %f, %f outside of current region, is that intended? Anyway, it will be used."
 msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:98 ../raster/r.latlong/main.c:101
@@ -32208,14 +31137,11 @@
 msgstr ""
 #: ../raster/r.sunmask/main.c:120
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map."
+msgid "Calculates cast shadow areas from sun position and elevation raster map."
 msgstr ""
 #: ../raster/r.sunmask/main.c:121
-msgid ""
-"Either exact sun position (A) is specified, or date/time to calculate the "
-"sun position (B) by r.sunmask itself."
+msgid "Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
 msgstr ""
 #: ../raster/r.sunmask/main.c:135
@@ -32300,9 +31226,7 @@
 msgstr ""
 #: ../raster/r.sunmask/main.c:282
-msgid ""
-"Neither sun position nor east/north, date/time/timezone definition are "
-"complete"
+msgid "Neither sun position nor east/north, date/time/timezone definition are complete"
 msgstr ""
 #: ../raster/r.sunmask/main.c:286
@@ -32311,9 +31235,7 @@
 msgstr ""
 #: ../raster/r.sunmask/main.c:291
-msgid ""
-"Using user defined sun azimuth, altitude settings (ignoring eventual other "
-"values)"
+msgid "Using user defined sun azimuth, altitude settings (ignoring eventual other values)"
 msgstr ""
 #: ../raster/r.sunmask/main.c:399
@@ -32374,9 +31296,7 @@
 msgstr ""
 #: ../raster/r.colors/edit_colors.c:83
-msgid ""
-"Input map names can be defined in an input file in case a large amount of "
-"maps must be specified. This option is mutual exclusive to the map option."
+msgid "Input map names can be defined in an input file in case a large amount of maps must be specified. This option is mutual exclusive to the map option."
 msgstr ""
 #: ../raster/r.colors/edit_colors.c:110
@@ -32519,8 +31439,7 @@
 msgstr ""
 #: ../raster/r.drain/main.c:113
-msgid ""
-"Traces a flow through an elevation model or cost surface on a raster map."
+msgid "Traces a flow through an elevation model or cost surface on a raster map."
 msgstr ""
 #: ../raster/r.drain/main.c:116
@@ -32564,9 +31483,7 @@
 msgstr ""
 #: ../raster/r.drain/main.c:163
-msgid ""
-"The input raster map is a cost surface (direction surface must also be "
-"specified)"
+msgid "The input raster map is a cost surface (direction surface must also be specified)"
 msgstr ""
 #: ../raster/r.drain/main.c:175
@@ -32579,16 +31496,12 @@
 #: ../raster/r.drain/main.c:183
 #, c-format
-msgid ""
-"Direction raster map <%s> not specified, if direction flag is on, a "
-"direction raster must be given"
+msgid "Direction raster map <%s> not specified, if direction flag is on, a direction raster must be given"
 msgstr ""
 #: ../raster/r.drain/main.c:190
 #, c-format
-msgid ""
-"Direction raster map <%s> should not be specified for Surface/Hydrology "
-"drains"
+msgid "Direction raster map <%s> should not be specified for Surface/Hydrology drains"
 msgstr ""
 #: ../raster/r.drain/main.c:209
@@ -32667,9 +31580,7 @@
 #: ../raster/r.texture/h_measure.c:141
 #, c-format
-msgid ""
-"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
-"map"
+msgid "Too many categories (found: %i, max: %i). Try to rescale or reclassify the map"
 msgstr ""
 #: ../raster/r.texture/main.c:68
@@ -32722,9 +31633,7 @@
 msgstr ""
 #: ../raster/r.texture/main.c:172
-msgid ""
-"The distance between two samples must be smaller than the size of the moving"
-" window"
+msgid "The distance between two samples must be smaller than the size of the moving window"
 msgstr ""
 #: ../raster/r.texture/main.c:193
@@ -32739,20 +31648,15 @@
 msgstr[1] ""
 #: ../raster/r.series/main.c:141
-msgid ""
-"Makes each output cell value a function of the values assigned to the "
-"corresponding cells in the input raster map layers."
+msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
 msgstr ""
 #: ../raster/r.series/main.c:150
-msgid ""
-"Input file with one raster map name and optional one weight per line, field "
-"separator between name and weight is |"
+msgid "Input file with one raster map name and optional one weight per line, field separator between name and weight is |"
 msgstr ""
 #: ../raster/r.series/main.c:176
-msgid ""
-"Weighting factor for each input map, default value is 1.0 for each input map"
+msgid "Weighting factor for each input map, default value is 1.0 for each input map"
 msgstr ""
 #: ../raster/r.series/main.c:183 ../raster/r.series.accumulate/main.c:132
@@ -32830,9 +31734,7 @@
 msgstr ""
 #: ../raster/r.profile/main.c:103
-msgid ""
-"If units are not specified, current location units are used. Meters are used"
-" by default in geographic (latlon) locations."
+msgid "If units are not specified, current location units are used. Meters are used by default in geographic (latlon) locations."
 msgstr ""
 #: ../raster/r.profile/main.c:117
@@ -32917,9 +31819,7 @@
 msgstr ""
 #: ../raster/r.covar/main.c:54
-msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map "
-"layer(s)."
+msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
 msgstr ""
 #: ../raster/r.covar/main.c:61
@@ -32936,9 +31836,7 @@
 msgstr ""
 #: ../raster/r.out.vtk/main.c:73
-msgid ""
-"No input maps specified. You need to specify at least one input map or three"
-" vector maps or three rgb maps."
+msgid "No input maps specified. You need to specify at least one input map or three vector maps or three rgb maps."
 msgstr ""
 #: ../raster/r.out.vtk/main.c:131 ../raster/r.out.vtk/main.c:191
@@ -32960,8 +31858,7 @@
 msgstr ""
 #: ../raster/r.out.vtk/main.c:271
-msgid ""
-"Wrong vector maps. Maps should have the same type! Vector output not added!"
+msgid "Wrong vector maps. Maps should have the same type! Vector output not added!"
 msgstr ""
 #: ../raster/r.out.vtk/main.c:283
@@ -32977,8 +31874,7 @@
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:69
-msgid ""
-"Three (r,g,b) raster maps to create RGB values [redmap,greenmap,bluemap]"
+msgid "Three (r,g,b) raster maps to create RGB values [redmap,greenmap,bluemap]"
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:79
@@ -32994,8 +31890,7 @@
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:116
-msgid ""
-"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
+msgid "Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:122
@@ -33246,23 +32141,19 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:83
-msgid ""
-"depression map indicates all the locations in the current map window where"
+msgid "depression map indicates all the locations in the current map window where"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:84
-msgid ""
-"water accumulates and does not leave by the edge of the map. Lakes without"
+msgid "water accumulates and does not leave by the edge of the map. Lakes without"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:85
-msgid ""
-"outlet streams and sinkholes are examples of `depressions'.  If you wish to"
+msgid "outlet streams and sinkholes are examples of `depressions'.  If you wish to"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:86
-msgid ""
-"have a depression map, prepare a map where non-zero values indicate the"
+msgid "have a depression map, prepare a map where non-zero values indicate the"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:87
@@ -33270,8 +32161,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:88
-msgid ""
-"Hit <return> by itself for the next question if there is no depression map."
+msgid "Hit <return> by itself for the next question if there is no depression map."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:99
@@ -33282,14 +32172,11 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:101
-msgid ""
-"watershed basins.  The number of watershed basins is indirectly determined"
+msgid "watershed basins.  The number of watershed basins is indirectly determined"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:102
-msgid ""
-"by the `basin threshold' value.  The basin threshold is the area necessary "
-"for"
+msgid "by the `basin threshold' value.  The basin threshold is the area necessary for"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:103
@@ -33298,18 +32185,15 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:105
-msgid ""
-"`exterior drainage basins'.  An exterior drainage basin does not have any"
+msgid "`exterior drainage basins'.  An exterior drainage basin does not have any"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:106
-msgid ""
-"drainage basins flowing into it.  Interior drainage basin size is determined"
+msgid "drainage basins flowing into it.  Interior drainage basin size is determined"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:107
-msgid ""
-"by the surface flow going into stream segments between stream interceptions."
+msgid "by the surface flow going into stream segments between stream interceptions."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:108
@@ -33322,19 +32206,15 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:111
-msgid ""
-"(i.e., areas with low infiltration capacities will need smaller areas to"
+msgid "(i.e., areas with low infiltration capacities will need smaller areas to"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:112
-msgid ""
-"develop stream channels than neighboring areas with high infiltration "
-"rates)."
+msgid "develop stream channels than neighboring areas with high infiltration rates)."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:113
-msgid ""
-"The user can create a map layer with potential overland flow values, and"
+msgid "The user can create a map layer with potential overland flow values, and"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:114
@@ -33440,8 +32320,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:296
-msgid ""
-"ability to generate several variables in the Revised Universal Soil Loss"
+msgid "ability to generate several variables in the Revised Universal Soil Loss"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:297
@@ -33460,9 +32339,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:351
-msgid ""
-"where the value indicates the percent of disturbed (barren) land in that "
-"cell."
+msgid "where the value indicates the percent of disturbed (barren) land in that cell."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:352
@@ -33503,8 +32380,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:384
-msgid ""
-"that prevents the surface flow distance from getting too long.  Normally,"
+msgid "that prevents the surface flow distance from getting too long.  Normally,"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:385
@@ -33518,8 +32394,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:401
-msgid ""
-"slope length.  You may input a raster map indicating the locations of these"
+msgid "slope length.  You may input a raster map indicating the locations of these"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:402
@@ -33527,8 +32402,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:403
-msgid ""
-"Hit <return> by itself for the next question if there is no blocking map."
+msgid "Hit <return> by itself for the next question if there is no blocking map."
 msgstr ""
 #: ../raster/r.watershed/shed/file_in.c:15
@@ -33619,8 +32493,7 @@
 msgid "Name of input raster map percent of disturbed land"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:97
-#: ../raster/r.watershed/front/main.c:122
+#: ../raster/r.watershed/front/main.c:97 ../raster/r.watershed/front/main.c:122
 msgid "For USLE"
 msgstr ""
@@ -33629,9 +32502,7 @@
 msgstr ""
 #: ../raster/r.watershed/front/main.c:106
-msgid ""
-"For USLE. All non-NULL and non-zero cells are considered as blocking "
-"terrain."
+msgid "For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
 msgstr ""
 #: ../raster/r.watershed/front/main.c:113
@@ -33723,9 +32594,7 @@
 msgstr ""
 #: ../raster/r.watershed/front/main.c:223
-msgid ""
-"Only needed if memory requirements exceed available RAM; see manual on how "
-"to calculate memory requirements"
+msgid "Only needed if memory requirements exceed available RAM; see manual on how to calculate memory requirements"
 msgstr ""
 #: ../raster/r.watershed/front/main.c:228
@@ -33909,8 +32778,7 @@
 #: ../raster/r.watershed/ram/do_cum.c:480
 #, c-format
 msgid "MFD: A * path already processed when distributing flow: %d of %d cell"
-msgid_plural ""
-"MFD: A * path already processed when distributing flow: %d of %d cells"
+msgid_plural "MFD: A * path already processed when distributing flow: %d of %d cells"
 msgstr[0] ""
 msgstr[1] ""
@@ -34027,14 +32895,11 @@
 msgstr ""
 #: ../raster/r.to.rast3elev/main.c:427
-msgid ""
-"The 2D and 3D region settings are different. I will use the 3D region "
-"settings to adjust the 2D region."
+msgid "The 2D and 3D region settings are different. I will use the 3D region settings to adjust the 2D region."
 msgstr ""
 #: ../raster/r.grow.distance/main.c:156
-msgid ""
-"Generates a raster map containing distances to nearest raster features."
+msgid "Generates a raster map containing distances to nearest raster features."
 msgstr ""
 #: ../raster/r.grow.distance/main.c:163
@@ -34344,9 +33209,7 @@
 msgstr ""
 #: ../raster/r.flow/main.c:425
-msgid ""
-"Computes flowlines, flowpath lengths, and flowaccumulation (contributing "
-"areas) from a elevation raster map."
+msgid "Computes flowlines, flowpath lengths, and flowaccumulation (contributing areas) from a elevation raster map."
 msgstr ""
 #: ../raster/r.flow/main.c:435 ../raster/r.flow/main.c:441
@@ -34401,9 +33264,7 @@
 msgstr ""
 #: ../raster/r.flow/main.c:555
-msgid ""
-"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
-"calculating flow accumulation."
+msgid "lat/long projection not supported by r.flow. Please use 'r.watershed' for calculating flow accumulation."
 msgstr ""
 #: ../raster/r.flow/mem.c:40
@@ -34493,8 +33354,7 @@
 msgstr ""
 #: ../raster/r.in.lidar/main.c:116
-msgid ""
-"Creates a raster map from LAS LiDAR points using univariate statistics."
+msgid "Creates a raster map from LAS LiDAR points using univariate statistics."
 msgstr ""
 #: ../raster/r.in.lidar/main.c:130
@@ -34558,8 +33418,7 @@
 msgstr ""
 #: ../raster/r.in.lidar/main.c:182
-msgid ""
-"The scale for Z is applied beforehand, the range filter for Z afterwards"
+msgid "The scale for Z is applied beforehand, the range filter for Z afterwards"
 msgstr ""
 #: ../raster/r.in.lidar/main.c:191
@@ -34599,9 +33458,7 @@
 msgstr ""
 #: ../raster/r.in.lidar/main.c:293
-msgid ""
-"Set computation region to match the 2D extent and resolution of the newly "
-"created new raster map"
+msgid "Set computation region to match the 2D extent and resolution of the newly created new raster map"
 msgstr ""
 #: ../raster/r.in.lidar/main.c:317
@@ -34621,9 +33478,7 @@
 msgstr ""
 #: ../raster/r.in.lidar/main.c:332
-msgid ""
-"For getting values from base raster, use its actual resolution instead of "
-"computational region resolution"
+msgid "For getting values from base raster, use its actual resolution instead of computational region resolution"
 msgstr ""
 #: ../raster/r.in.lidar/main.c:355
@@ -34646,8 +33501,7 @@
 msgstr ""
 #: ../raster/r.in.lidar/main.c:419
-msgid ""
-"First file's projection checked, checking projection of the other files..."
+msgid "First file's projection checked, checking projection of the other files..."
 msgstr ""
 #: ../raster/r.in.lidar/main.c:457
@@ -34671,9 +33525,7 @@
 #: ../raster/r.in.lidar/main.c:590
 #, c-format
-msgid ""
-"Unable to process the hole map at once. Please set the '%s' option to some "
-"value lower than 100."
+msgid "Unable to process the hole map at once. Please set the '%s' option to some value lower than 100."
 msgstr ""
 #: ../raster/r.in.lidar/main.c:610
@@ -34725,9 +33577,7 @@
 msgstr ""
 #: ../raster/r.reclass/main.c:54
-msgid ""
-"Creates a new raster map whose category values are based upon a "
-"reclassification of the categories in an existing raster map."
+msgid "Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
 msgstr ""
 #: ../raster/r.reclass/main.c:59
@@ -34863,9 +33713,7 @@
 #: ../raster/r.resamp.bspline/crosscorr.c:160
 #, c-format
-msgid ""
-"%d are too many cells, recommended are < 100 cells. The cross validation "
-"would take too much time."
+msgid "%d are too many cells, recommended are < 100 cells. The cross validation would take too much time."
 msgstr ""
 #: ../raster/r.resamp.bspline/crosscorr.c:169
@@ -34880,9 +33728,7 @@
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:85
-msgid ""
-"Performs bilinear or bicubic spline interpolation with Tykhonov "
-"regularization."
+msgid "Performs bilinear or bicubic spline interpolation with Tykhonov regularization."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:93
@@ -34894,14 +33740,11 @@
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:107
-msgid ""
-"Length of each spline step in the east-west direction. Default: 1.5 * ewres."
+msgid "Length of each spline step in the east-west direction. Default: 1.5 * ewres."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:115
-msgid ""
-"Length of each spline step in the north-south direction. Default: 1.5 * "
-"nsres."
+msgid "Length of each spline step in the north-south direction. Default: 1.5 * nsres."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:138
@@ -35128,9 +33971,7 @@
 msgstr ""
 #: ../raster/r.in.xyz/main.c:165
-msgid ""
-"Creates a raster map from an assemblage of many coordinates using univariate"
-" statistics."
+msgid "Creates a raster map from an assemblage of many coordinates using univariate statistics."
 msgstr ""
 #: ../raster/r.in.xyz/main.c:169
@@ -35142,9 +33983,7 @@
 msgstr ""
 #: ../raster/r.in.xyz/main.c:237
-msgid ""
-"If a separate value column is given, this option refers to the z-coordinate "
-"column to be filtered by the zrange option"
+msgid "If a separate value column is given, this option refers to the z-coordinate column to be filtered by the zrange option"
 msgstr ""
 #: ../raster/r.in.xyz/main.c:248
@@ -35195,14 +34034,11 @@
 #: ../raster/r.in.xyz/main.c:534
 #, c-format
-msgid ""
-"Unable to process the hole map at once. Please set the %s option to some "
+msgid "Unable to process the hole map at once. Please set the %s option to some value lower than 100."
 msgstr ""
 #: ../raster/r.in.xyz/main.c:587
-msgid ""
-"If input is not from a file it is only possible to perform a single pass."
+msgid "If input is not from a file it is only possible to perform a single pass."
 msgstr ""
 #: ../raster/r.in.xyz/main.c:599
@@ -35372,23 +34208,17 @@
 #: ../raster/r.stats/main.c:303
 #, c-format
-msgid ""
-"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
-"will be ignored."
+msgid "Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option will be ignored."
 msgstr ""
 #: ../raster/r.stats/main.c:319
 #, c-format
-msgid ""
-"Cats for raster map <%s> are either missing or have no explicit labels. "
-"Using %s=%d."
+msgid "Cats for raster map <%s> are either missing or have no explicit labels. Using %s=%d."
 msgstr ""
 #: ../raster/r.stats/main.c:325
 #, c-format
-msgid ""
-"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s'"
-" option"
+msgid "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' option"
 msgstr ""
 #: ../raster/r.stats/raw_stats.c:118
@@ -35418,11 +34248,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:220
-msgid ""
-"Generates three, or four raster map layers showing the base (perpendicular) "
-"rate of spread (ROS), the maximum (forward) ROS, the direction of the "
-"maximum ROS, and optionally the maximum potential spotting distance for fire"
-" spread simulation."
+msgid "Generates three, or four raster map layers showing the base (perpendicular) rate of spread (ROS), the maximum (forward) ROS, the direction of the maximum ROS, and optionally the maximum potential spotting distance for fire spread simulation."
 msgstr ""
 #: ../raster/r.ros/main.c:227
@@ -35430,10 +34256,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:229
-msgid ""
-"Name of an existing raster map layer in the user's current mapset search "
-"path containing the standard fuel models defined by the USDA Forest Service."
-" Valid values are 1-13; other numbers are recognized as barriers by r.ros."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the standard fuel models defined by the USDA Forest Service. Valid values are 1-13; other numbers are recognized as barriers by r.ros."
 msgstr ""
 #: ../raster/r.ros/main.c:238
@@ -35441,10 +34264,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:240 ../raster/r.spread/main.c:205
-msgid ""
-"path containing the 1-hour (<.25\") fuel moisture (percentage content "
-"multiplied by 100)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the 1-hour (<.25\") fuel moisture (percentage content multiplied by 100)."
 msgstr ""
 #: ../raster/r.ros/main.c:248
@@ -35452,10 +34272,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:250
-msgid ""
-"path containing the 10-hour (.25-1\") fuel moisture (percentage content "
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the 10-hour (.25-1\") fuel moisture (percentage content multiplied by 100)."
 msgstr ""
 #: ../raster/r.ros/main.c:258
@@ -35463,10 +34280,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:260
-msgid ""
-"path containing the 100-hour (1-3\") fuel moisture (percentage content "
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the 100-hour (1-3\") fuel moisture (percentage content multiplied by 100)."
 msgstr ""
 #: ../raster/r.ros/main.c:267
@@ -35474,10 +34288,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:269
-msgid ""
-"path containing live (herbaceous) fuel moisture (percentage content "
+msgid "Name of an existing raster map layer in the user's current mapset search path containing live (herbaceous) fuel moisture (percentage content multiplied by 100)."
 msgstr ""
 #: ../raster/r.ros/main.c:277
@@ -35485,10 +34296,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:279 ../raster/r.spread/main.c:193
-msgid ""
-"path containing wind velocities at half of the average flame height "
-"(feet/minute)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing wind velocities at half of the average flame height (feet/minute)."
 msgstr ""
 #: ../raster/r.ros/main.c:287
@@ -35496,9 +34304,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:289
-msgid ""
-"path containing wind direction, clockwise from north (degree)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing wind direction, clockwise from north (degree)."
 msgstr ""
 #: ../raster/r.ros/main.c:297
@@ -35506,9 +34312,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:299
-msgid ""
-"path containing topographic slope (degree)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing topographic slope (degree)."
 msgstr ""
 #: ../raster/r.ros/main.c:307
@@ -35516,10 +34320,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:309
-msgid ""
-"path containing topographic aspect, counterclockwise from east (GRASS "
-"convention) in degrees."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing topographic aspect, counterclockwise from east (GRASS convention) in degrees."
 msgstr ""
 #: ../raster/r.ros/main.c:317
@@ -35527,10 +34328,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:319
-msgid ""
-"path containing elevation (meters). Option is required from spotting "
-"distance computation (when spotting_distance option is provided)"
+msgid "Name of an existing raster map layer in the user's current mapset search path containing elevation (meters). Option is required from spotting distance computation (when spotting_distance option is provided)"
 msgstr ""
 #: ../raster/r.ros/main.c:328
@@ -35562,29 +34360,21 @@
 msgstr ""
 #: ../raster/r.ros/main.c:354
-msgid ""
-"The maximal potential spotting distance (requires elevation raster map to be"
-" provided)."
+msgid "The maximal potential spotting distance (requires elevation raster map to be provided)."
 msgstr ""
 #: ../raster/r.ros/main.c:373
-msgid ""
-"No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h "
-"moisture layers is required."
+msgid "No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h moisture layers is required."
 msgstr ""
 #: ../raster/r.ros/main.c:397
 #, c-format
-msgid ""
-"A wind direction layer should be given if the wind velocity layer <%s> has "
-"been given"
+msgid "A wind direction layer should be given if the wind velocity layer <%s> has been given"
 msgstr ""
 #: ../raster/r.ros/main.c:402
 #, c-format
-msgid ""
-"A wind velocity layer should be given if the wind direction layer <%s> has "
-"been given"
+msgid "A wind velocity layer should be given if the wind direction layer <%s> has been given"
 msgstr ""
 #: ../raster/r.ros/main.c:416
@@ -35644,14 +34434,11 @@
 msgstr ""
 #: ../raster/r.volume/main.c:81
-msgid ""
-"Optionally produces a GRASS vector points map containing the calculated "
-"centroids of these clumps."
+msgid "Optionally produces a GRASS vector points map containing the calculated centroids of these clumps."
 msgstr ""
 #: ../raster/r.volume/main.c:86
-msgid ""
-"Name of input raster map representing data that will be summed within clumps"
+msgid "Name of input raster map representing data that will be summed within clumps"
 msgstr ""
 #: ../raster/r.volume/main.c:92
@@ -35659,9 +34446,7 @@
 msgstr ""
 #: ../raster/r.volume/main.c:93
-msgid ""
-"Preferably the output of r.clump. If no clump map is given than MASK is "
-"used."
+msgid "Preferably the output of r.clump. If no clump map is given than MASK is used."
 msgstr ""
 #: ../raster/r.volume/main.c:99
@@ -35681,9 +34466,7 @@
 msgstr ""
 #: ../raster/r.volume/main.c:143
-msgid ""
-"No MASK found. If no clump map is given than the MASK is required. You need "
-"to define a clump raster map or create a MASK by r.mask command."
+msgid "No MASK found. If no clump map is given than the MASK is required. You need to define a clump raster map or create a MASK by r.mask command."
 msgstr ""
 #: ../raster/r.volume/main.c:145
@@ -35737,8 +34520,7 @@
 msgstr ""
 #: ../raster/r.sim/r.sim.water/main.c:120
-msgid ""
-"Overland flow hydrologic simulation using path sampling method (SIMWE)."
+msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
 msgstr ""
 #: ../raster/r.sim/r.sim.water/main.c:127
@@ -35805,9 +34587,7 @@
 #: ../raster/r.sim/r.sim.water/main.c:222
 #: ../raster/r.sim/r.sim.sediment/main.c:211
-msgid ""
-"Name for sampling points output text file. For each observation vector point"
-" the time series of sediment transport is stored."
+msgid "Name for sampling points output text file. For each observation vector point the time series of sediment transport is stored."
 msgstr ""
 #: ../raster/r.sim/r.sim.water/main.c:230
@@ -35856,9 +34636,7 @@
 #: ../raster/r.sim/r.sim.water/main.c:306
 #: ../raster/r.sim/r.sim.sediment/main.c:270
-msgid ""
-"The same seed can be used to obtain same results or random seed can be "
-"generated by other means."
+msgid "The same seed can be used to obtain same results or random seed can be generated by other means."
 msgstr ""
 #: ../raster/r.sim/r.sim.water/main.c:312
@@ -35868,9 +34646,7 @@
 #: ../raster/r.sim/r.sim.water/main.c:314
 #: ../raster/r.sim/r.sim.sediment/main.c:278
-msgid ""
-"Automatically generates random seed for random number generator (use when "
-"you don't want to provide the seed option)"
+msgid "Automatically generates random seed for random number generator (use when you don't want to provide the seed option)"
 msgstr ""
 #: ../raster/r.sim/r.sim.water/main.c:322
@@ -35920,9 +34696,7 @@
 msgstr ""
 #: ../raster/r.sim/r.sim.sediment/main.c:121
-msgid ""
-"Sediment transport and erosion/deposition simulation using path sampling "
-"method (SIMWE)."
+msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
 msgstr ""
 #: ../raster/r.sim/r.sim.sediment/main.c:128
@@ -35946,8 +34720,7 @@
 msgstr ""
 #: ../raster/r.sim/r.sim.sediment/main.c:184
-msgid ""
-"Name for output transport limited erosion-deposition raster map [kg/m2s]"
+msgid "Name for output transport limited erosion-deposition raster map [kg/m2s]"
 msgstr ""
 #: ../raster/r.sim/r.sim.sediment/main.c:191
@@ -35970,16 +34743,13 @@
 msgid "You are not outputting any raster or site files"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:411
-#: ../raster/r.sim/simlib/hydro.c:465
+#: ../raster/r.sim/r.sim.sediment/main.c:411 ../raster/r.sim/simlib/hydro.c:465
 msgid "Cannot write raster maps"
 msgstr ""
 #: ../raster/r.sim/simlib/input.c:307
 #, c-format
-msgid ""
-"Raster map <%s> not found, and manin_val undefined, choose one to be allowed"
-" to process"
+msgid "Raster map <%s> not found, and manin_val undefined, choose one to be allowed to process"
 msgstr ""
 #: ../raster/r.sim/simlib/input.c:420
@@ -36065,9 +34835,7 @@
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:84
-msgid ""
-"Makes each output cell value a accumulationfunction of the values assigned "
-"to the corresponding cells in the input raster map layers."
+msgid "Makes each output cell value a accumulationfunction of the values assigned to the corresponding cells in the input raster map layers."
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:90
@@ -36087,14 +34855,11 @@
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:121
-msgid ""
-"The raster map specifying the lower accumulation limit, also called baseline"
+msgid "The raster map specifying the lower accumulation limit, also called baseline"
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:126
-msgid ""
-"The raster map specifying the upper accumulation limit, also called cutoff. "
-"Only applied to BEDD computation."
+msgid "The raster map specifying the upper accumulation limit, also called cutoff. Only applied to BEDD computation."
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:139
@@ -36196,9 +34961,7 @@
 msgstr ""
 #: ../raster/r.out.gdal/main.c:220
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
-"Not supported by all output format drivers."
+msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. Not supported by all output format drivers."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:230
@@ -36206,9 +34969,7 @@
 msgstr ""
 #: ../raster/r.out.gdal/main.c:232
-msgid ""
-"If given, the nodata value is always written to metadata even if there are "
-"no NULL cells in the input band (enhances output compatibility)."
+msgid "If given, the nodata value is always written to metadata even if there are no NULL cells in the input band (enhances output compatibility)."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:264
@@ -36228,9 +34989,7 @@
 #: ../raster/r.out.gdal/main.c:288
 #, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:293
@@ -36258,23 +35017,17 @@
 #: ../raster/r.out.gdal/main.c:455
 #, c-format
-msgid ""
-"Precision loss: Raster map <%s> of type %s to be exported as %s. This can be"
-" avoided by using %s."
+msgid "Precision loss: Raster map <%s> of type %s to be exported as %s. This can be avoided by using %s."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:466
 #, c-format
-msgid ""
-"Precision loss: The range of <%s> can not be accurately preserved with GDAL "
-"datatype Float32. This can be avoided by exporting to Int32 or Float64."
+msgid "Precision loss: The range of <%s> can not be accurately preserved with GDAL datatype Float32. This can be avoided by exporting to Int32 or Float64."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:474
 #, c-format
-msgid ""
-"Precision loss: Float32 can not preserve the DCELL precision of raster <%s>."
-" This can be avoided by using Float64"
+msgid "Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. This can be avoided by using Float64"
 msgstr ""
 #: ../raster/r.out.gdal/main.c:483
@@ -36386,10 +35139,7 @@
 #: ../raster/r.out.gdal/main.c:791 ../raster/r.out.gdal/main.c:804
 #: ../raster/r.out.gdal/main.c:819
 #, c-format
-msgid ""
-"Mismatch between metadata nodata value and actual nodata value in exported "
-"raster: specified nodata value %g gets converted to %d by selected GDAL "
-"datatype."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %d by selected GDAL datatype."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:767 ../raster/r.out.gdal/main.c:794
@@ -36405,10 +35155,7 @@
 #: ../raster/r.out.gdal/main.c:833
 #, c-format
-msgid ""
-"raster: specified nodata value %g gets converted to %g by selected GDAL "
-"datatype."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %g by selected GDAL datatype."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:836
@@ -36420,8 +35167,7 @@
 msgid "Failed to set raster attribute table"
 msgstr ""
-#: ../raster/r.out.gdal/export_band.c:52
-#: ../raster/r.out.gdal/export_band.c:344
+#: ../raster/r.out.gdal/export_band.c:52 ../raster/r.out.gdal/export_band.c:344
 msgid "Unable to allocate buffer for reading raster map"
 msgstr ""
@@ -36432,32 +35178,22 @@
 #: ../raster/r.out.gdal/export_band.c:161
 #, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %d will"
-" be used to represent no-data values in the input map. You can specify a "
-"nodata value with the %s option."
+msgid "Input raster map contains cells with NULL-value (no-data). The value %d will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:166
 #, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %g will"
+msgid "Input raster map contains cells with NULL-value (no-data). The value %g will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:176
 #, c-format
-msgid ""
-"The default nodata value is present in rasterband <%s> and would lead to "
-"data loss. Please specify a custom nodata value with the %s parameter."
+msgid "The default nodata value is present in rasterband <%s> and would lead to data loss. Please specify a custom nodata value with the %s parameter."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:183
 #, c-format
-msgid ""
-"The user given nodata value %g is present in rasterband <%s> and would lead "
-"to data loss. Please specify a different nodata value with the %s parameter."
+msgid "The user given nodata value %g is present in rasterband <%s> and would lead to data loss. Please specify a different nodata value with the %s parameter."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:228
@@ -36486,11 +35222,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:113
-msgid ""
-"Generates a raster map of the cumulative time of spread, given raster maps "
-"containing the rates of spread (ROS), the ROS directions and the spread "
-"origins. It optionally produces raster maps to contain backlink UTM "
-"coordinates for tracing spread paths. Usable for fire spread simulations."
+msgid "Generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins. It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths. Usable for fire spread simulations."
 msgstr ""
 #: ../raster/r.spread/main.c:127
@@ -36498,11 +35230,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:129
-msgid ""
-"path containing the ROS values in the directions perpendicular to maximum "
-"ROSes' (cm/minute). These ROSes are also the ones without the effect of "
-"directional factors."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the ROS values in the directions perpendicular to maximum ROSes' (cm/minute). These ROSes are also the ones without the effect of directional factors."
 msgstr ""
 #: ../raster/r.spread/main.c:141
@@ -36510,9 +35238,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:143
-msgid ""
-"path containing the maximum ROS values (cm/minute)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the maximum ROS values (cm/minute)."
 msgstr ""
 #: ../raster/r.spread/main.c:153
@@ -36520,10 +35246,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:155
-msgid ""
-"path containing directions of the maximum ROSes, clockwise from north "
-"(degree)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing directions of the maximum ROSes, clockwise from north (degree)."
 msgstr ""
 #: ../raster/r.spread/main.c:166
@@ -36531,10 +35254,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:168
-msgid ""
-"path containing starting locations of the spread phenomenon. Any positive "
-"integers in this map are recognized as starting sources (seeds)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing starting locations of the spread phenomenon. Any positive integers in this map are recognized as starting sources (seeds)."
 msgstr ""
 #: ../raster/r.spread/main.c:179
@@ -36542,9 +35262,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:181
-msgid ""
-"path containing the maximum potential spotting distances (meters)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the maximum potential spotting distances (meters)."
 msgstr ""
 #: ../raster/r.spread/main.c:191
@@ -36552,9 +35270,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:203
-msgid ""
-"Raster map containing fine fuel moisture of the cell receiving a spotting "
-"firebrand (%, required with -s)"
+msgid "Raster map containing fine fuel moisture of the cell receiving a spotting firebrand (%, required with -s)"
 msgstr ""
 #: ../raster/r.spread/main.c:215
@@ -36562,11 +35278,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:217
-msgid ""
-"An odd integer ranging 3 - 15 indicating the basic sampling window size "
-"within which all cells will be considered to see whether they will be "
-"reached by the current spread cell. The default number is 3 which means a "
-"3x3 window."
+msgid "An odd integer ranging 3 - 15 indicating the basic sampling window size within which all cells will be considered to see whether they will be reached by the current spread cell. The default number is 3 which means a 3x3 window."
 msgstr ""
 #: ../raster/r.spread/main.c:227
@@ -36574,12 +35286,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:229
-msgid ""
-"A decimal number ranging 0.0 - 1.0 indicating additional sampling cells will"
-" be considered to see whether they will be reached by the current spread "
-"cell. The closer to 1.0 the decimal number is, the longer the program will "
-"run and the higher the simulation accuracy will be. The default number is "
-"0.5."
+msgid "A decimal number ranging 0.0 - 1.0 indicating additional sampling cells will be considered to see whether they will be reached by the current spread cell. The closer to 1.0 the decimal number is, the longer the program will run and the higher the simulation accuracy will be. The default number is 0.5."
 msgstr ""
 #: ../raster/r.spread/main.c:241
@@ -36587,10 +35294,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:243
-msgid ""
-"A non-negative number specifying the initial time for the current spread "
-"simulation (minutes). This is useful when multiple phase simulation is "
-"conducted. The default time is 0."
+msgid "A non-negative number specifying the initial time for the current spread simulation (minutes). This is useful when multiple phase simulation is conducted. The default time is 0."
 msgstr ""
 #: ../raster/r.spread/main.c:252
@@ -36598,12 +35302,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:254
-msgid ""
-"A non-negative integer specifying the simulating duration time lag "
-"(minutes). The default is infinite, but the program will terminate when the "
-"current geographic region/mask has been filled. It also controls the "
-"computational time, the shorter the time lag, the faster the program will "
-"run."
+msgid "A non-negative integer specifying the simulating duration time lag (minutes). The default is infinite, but the program will terminate when the current geographic region/mask has been filled. It also controls the computational time, the shorter the time lag, the faster the program will run."
 msgstr ""
 #: ../raster/r.spread/main.c:266
@@ -36611,10 +35310,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:268
-msgid ""
-"path to be used as the background on which the \"live\" movement will be "
-"shown."
+msgid "Name of an existing raster map layer in the user's current mapset search path to be used as the background on which the \"live\" movement will be shown."
 msgstr ""
 #: ../raster/r.spread/main.c:279
@@ -36622,10 +35318,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:281
-msgid ""
-"Name of the new raster map layer to contain the results of the cumulative "
-"spread time needed for a phenomenon to reach each cell from the starting "
-"sources (minutes)."
+msgid "Name of the new raster map layer to contain the results of the cumulative spread time needed for a phenomenon to reach each cell from the starting sources (minutes)."
 msgstr ""
 #: ../raster/r.spread/main.c:291
@@ -36633,9 +35326,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:293
-msgid ""
-"Name of the new raster map layer to contain the results of backlink "
-"information in UTM easting coordinates for each cell."
+msgid "Name of the new raster map layer to contain the results of backlink information in UTM easting coordinates for each cell."
 msgstr ""
 #: ../raster/r.spread/main.c:303
@@ -36643,9 +35334,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:305
-msgid ""
-"information in UTM northing coordinates for each cell."
+msgid "Name of the new raster map layer to contain the results of backlink information in UTM northing coordinates for each cell."
 msgstr ""
 #: ../raster/r.spread/main.c:312
@@ -36653,9 +35342,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:314
-msgid ""
-"Display the 'live' simulation on screen. A graphics window must be opened "
-"and selected before using this option."
+msgid "Display the 'live' simulation on screen. A graphics window must be opened and selected before using this option."
 msgstr ""
 #: ../raster/r.spread/main.c:320
@@ -36667,11 +35354,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:326
-msgid ""
-"Designed to be used with output of previous run of r.spread when computing "
-"spread iteratively. The values in start raster map are considered as time. "
-"Allowed values in raster map are from zero to the value of init_time option."
-" If not enabled, init_time is used in the area of start raster map"
+msgid "Designed to be used with output of previous run of r.spread when computing spread iteratively. The values in start raster map are considered as time. Allowed values in raster map are from zero to the value of init_time option. If not enabled, init_time is used in the area of start raster map"
 msgstr ""
 #: ../raster/r.spread/main.c:502
@@ -36864,8 +35547,7 @@
 msgstr ""
 #: ../raster/r.thin/main.c:60
-msgid ""
-"Thins non-null cells that denote linear features in a raster map layer."
+msgid "Thins non-null cells that denote linear features in a raster map layer."
 msgstr ""
 #: ../raster/r.thin/main.c:72
@@ -36934,9 +35616,7 @@
 msgstr ""
 #: ../raster/r.surf.gauss/main.c:44
-msgid ""
-"Mean and standard deviation of gaussian deviates can be expressed by the "
-"user."
+msgid "Mean and standard deviation of gaussian deviates can be expressed by the user."
 msgstr ""
 #: ../raster/r.surf.gauss/main.c:51
@@ -37050,9 +35730,7 @@
 msgstr ""
 #: ../raster/r.lake/main.c:276
-msgid ""
-"Given water level at seed point is below earth surface. Increase water level"
-" or move seed point."
+msgid "Given water level at seed point is below earth surface. Increase water level or move seed point."
 msgstr ""
 #: ../raster/r.lake/main.c:355
@@ -37075,9 +35753,7 @@
 msgstr ""
 #: ../raster/r.spreadpath/main.c:92
-msgid ""
-"Recursively traces the least cost path backwards to cells from which the "
-"cumulative cost was determined."
+msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
 msgstr ""
 #: ../raster/r.spreadpath/main.c:98
@@ -37094,8 +35770,7 @@
 #: ../raster/r.spreadpath/main.c:161
 #, c-format
-msgid ""
-"eading the input map -%s- and -%s- and creating some temporary files..."
+msgid "eading the input map -%s- and -%s- and creating some temporary files..."
 msgstr ""
 #: ../raster/r.spreadpath/main.c:281
@@ -37151,8 +35826,7 @@
 msgstr ""
 #: ../raster/r.composite/main.c:76
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
+msgid "Combines red, green and blue raster maps into a single composite raster map."
 msgstr ""
 #: ../raster/r.composite/main.c:102
@@ -37186,9 +35860,7 @@
 msgstr ""
 #: ../raster/r.mode/main.c:59
-msgid ""
-"Finds the mode of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
+msgid "Finds the mode of values in a cover map within areas assigned the same category value in a user-specified base map."
 msgstr ""
 #: ../raster/r.mode/main.c:65
@@ -37220,28 +35892,21 @@
 msgid "Extended"
 msgstr ""
-#: ../raster/r.univar/r.univar_main.c:71
-#: ../raster/r.univar/r3.univar_main.c:67
+#: ../raster/r.univar/r.univar_main.c:71 ../raster/r.univar/r3.univar_main.c:67
 msgid "Table output format instead of standard output format"
 msgstr ""
 #: ../raster/r.univar/r.univar_main.c:76
-msgid ""
-"Use the native resolution and extent of the raster map, instead of the "
-"current region"
+msgid "Use the native resolution and extent of the raster map, instead of the current region"
 msgstr ""
 #: ../raster/r.univar/r.univar_main.c:110
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map."
+msgid "Calculates univariate statistics from the non-null cells of a raster map."
 msgstr ""
 #: ../raster/r.univar/r.univar_main.c:112
 #: ../raster/r.univar/r3.univar_main.c:105
-msgid ""
-"Statistics include number of cells counted, minimum and maximum cell values,"
-" range, arithmetic mean, population variance, standard deviation, "
-"coefficient of variation, and sum."
+msgid "Statistics include number of cells counted, minimum and maximum cell values, range, arithmetic mean, population variance, standard deviation, coefficient of variation, and sum."
 msgstr ""
 #: ../raster/r.univar/r.univar_main.c:123
@@ -37253,8 +35918,7 @@
 msgstr ""
 #: ../raster/r.univar/r3.univar_main.c:103
-msgid ""
-"Calculates univariate statistics from the non-null cells of a 3D raster map."
+msgid "Calculates univariate statistics from the non-null cells of a 3D raster map."
 msgstr ""
 #: ../raster/r.out.mpeg/main.c:104
@@ -37316,9 +35980,7 @@
 msgstr ""
 #: ../raster/r.surf.idw/main.c:109
-msgid ""
-"Provides surface interpolation from raster point data by Inverse Distance "
-"Squared Weighting."
+msgid "Provides surface interpolation from raster point data by Inverse Distance Squared Weighting."
 msgstr ""
 #: ../raster/r.surf.idw/main.c:124
@@ -37383,9 +36045,7 @@
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:156
-msgid ""
-"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from an elevation raster map."
+msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from an elevation raster map."
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:158
@@ -37401,13 +36061,11 @@
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:209
-msgid ""
-"Name for output first order partial derivative dx (E-W slope) raster map"
+msgid "Name for output first order partial derivative dx (E-W slope) raster map"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:216
-msgid ""
-"Name for output first order partial derivative dy (N-S slope) raster map"
+msgid "Name for output first order partial derivative dy (N-S slope) raster map"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:223
@@ -37436,9 +36094,7 @@
 #: ../raster/r.slope.aspect/main.c:336
 #, c-format
-msgid ""
-"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, "
-"<%s>, <%s>, <%s>, <%s> or <%s>"
+msgid "You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:358
@@ -37447,9 +36103,7 @@
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:387
-msgid ""
-"r.slope.aspect does not convert horizontal units to meters in this version, "
-"see manual page."
+msgid "r.slope.aspect does not convert horizontal units to meters in this version, see manual page."
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:968
@@ -37517,21 +36171,15 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:62
-msgid ""
-"Name of input raster map providing boundary condition status: 0-inactive, "
-"1-active, 2-dirichlet"
+msgid "Name of input raster map providing boundary condition status: 0-inactive, 1-active, 2-dirichlet"
 msgstr ""
 #: ../raster/r.gwflow/main.c:67
-msgid ""
-"Name of input raster map with x-part of the hydraulic conductivity tensor in"
-" [m/s]"
+msgid "Name of input raster map with x-part of the hydraulic conductivity tensor in [m/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:72
-msgid ""
-"Name of input raster map with y-part of the hydraulic conductivity tensor in"
-" [m/s]"
+msgid "Name of input raster map with y-part of the hydraulic conductivity tensor in [m/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:77
@@ -37539,9 +36187,7 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:81
-msgid ""
-"Name of input raster map with storativity for confined or effective porosity"
-" for unconfined groundwater flow booth in [-] "
+msgid "Name of input raster map with storativity for confined or effective porosity for unconfined groundwater flow booth in [-] "
 msgstr ""
 #: ../raster/r.gwflow/main.c:86
@@ -37553,13 +36199,11 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:92
-msgid ""
-"Name of input raster map describing the top surface of the aquifer in [m]"
+msgid "Name of input raster map describing the top surface of the aquifer in [m]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:96
-msgid ""
-"Name of input raster map describing the bottom surface of the aquifer in [m]"
+msgid "Name of input raster map describing the bottom surface of the aquifer in [m]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:100
@@ -37567,20 +36211,15 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:106
-msgid ""
-"Output raster map to store the groundwater filter velocity vector part in x "
-"direction [m/s]"
+msgid "Output raster map to store the groundwater filter velocity vector part in x direction [m/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:112
-msgid ""
-"Output raster map to store the groundwater filter velocity vector part in y "
-"direction [m/s]"
+msgid "Output raster map to store the groundwater filter velocity vector part in y direction [m/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:118
-msgid ""
-"Output raster map to store the groundwater budget for each cell [m^3/s]"
+msgid "Output raster map to store the groundwater budget for each cell [m^3/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:126
@@ -37592,26 +36231,19 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:140
-msgid ""
-"Name of input raster map providing the water level (head) of the river with "
-"leakage connection in [m]"
+msgid "Name of input raster map providing the water level (head) of the river with leakage connection in [m]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:147
-msgid ""
-"Name of input raster map providing the leakage coefficient of the river bed "
-"in [1/s]."
+msgid "Name of input raster map providing the leakage coefficient of the river bed in [1/s]."
 msgstr ""
 #: ../raster/r.gwflow/main.c:155
-msgid ""
-"Name of input raster map providing the height of the drainage bed in [m]"
+msgid "Name of input raster map providing the height of the drainage bed in [m]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:162
-msgid ""
-"Name of input raster map providing the leakage coefficient of the drainage "
-"bed in [1/s]"
+msgid "Name of input raster map providing the leakage coefficient of the drainage bed in [1/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:167
@@ -37619,15 +36251,11 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:176
-msgid ""
-"Allocate a full quadratic linear equation system, default is a sparse linear"
-" equation system."
+msgid "Allocate a full quadratic linear equation system, default is a sparse linear equation system."
 msgstr ""
 #: ../raster/r.gwflow/main.c:212
-msgid ""
-"Numerical calculation program for transient, confined and unconfined "
-"groundwater flow in two dimensions."
+msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
 msgstr ""
 #: ../raster/r.gwflow/main.c:222 ../raster/r.topidx/main.c:56
@@ -37645,9 +36273,7 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:263
-msgid ""
-"The cholesky solver dos not work with sparse matrices. You may choose a full"
-" filled quadratic matrix, flag -f."
+msgid "The cholesky solver dos not work with sparse matrices. You may choose a full filled quadratic matrix, flag -f."
 msgstr ""
 #: ../raster/r.gwflow/main.c:293
@@ -37670,10 +36296,7 @@
 msgstr ""
 #: ../raster/r.patch/main.c:66
-msgid ""
-"Creates a composite raster map layer by using known category values from one"
-" (or more) map layer(s) to fill in areas of \"no data\" in another map "
-"layer."
+msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
 msgstr ""
 #: ../raster/r.patch/main.c:73
@@ -37762,9 +36385,7 @@
 msgstr ""
 #: ../raster/r.random/main.c:58
-msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
+msgid "Creates a raster map layer and vector point map containing randomly located points."
 msgstr ""
 #: ../raster/r.random/main.c:67
@@ -37865,9 +36486,7 @@
 msgstr ""
 #: ../raster/r.series.interp/main.c:69
-msgid ""
-"Interpolates raster maps located (temporal or spatial) in between input "
-"raster maps at specific sampling positions."
+msgid "Interpolates raster maps located (temporal or spatial) in between input raster maps at specific sampling positions."
 msgstr ""
 #: ../raster/r.series.interp/main.c:79
@@ -37875,9 +36494,7 @@
 msgstr ""
 #: ../raster/r.series.interp/main.c:84
-msgid ""
-"Input file with one input raster map name and data point position per line, "
-"field separator between name and sample point is |"
+msgid "Input file with one input raster map name and data point position per line, field separator between name and sample point is |"
 msgstr ""
 #: ../raster/r.series.interp/main.c:97
@@ -37885,9 +36502,7 @@
 msgstr ""
 #: ../raster/r.series.interp/main.c:101
-msgid ""
-"Input file with one output raster map name and sample point position per "
-"line, field separator between name and sample point is |"
+msgid "Input file with one output raster map name and sample point position per line, field separator between name and sample point is |"
 msgstr ""
 #: ../raster/r.series.interp/main.c:111
@@ -37931,9 +36546,7 @@
 #: ../raster/r.series.interp/main.c:299
 #, c-format
-msgid ""
-"map <%s> at position %g was not interpolated. Check the interpolation "
-"interval."
+msgid "map <%s> at position %g was not interpolated. Check the interpolation interval."
 msgstr ""
 #: ../raster/r.series.interp/main.c:319
@@ -38118,14 +36731,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:245
-msgid ""
-"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
-"for given day, latitude, surface and atmospheric conditions. Solar "
-"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
-"irradiance, daylight length) are saved in the map history file. "
-"Alternatively, a local time can be specified to compute solar incidence "
-"angle and/or irradiance raster maps. The shadowing effect of the topography "
-"is optionally incorporated."
+msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
 msgstr ""
 #: ../raster/r.sun/main.c:259
@@ -38133,9 +36739,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:268
-msgid ""
-"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
-"[decimal degrees]"
+msgid "Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]"
 msgstr ""
 #: ../raster/r.sun/main.c:277
@@ -38143,9 +36747,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:286
-msgid ""
-"Name of the input slope raster map (terrain slope or solar panel "
-"inclination) [decimal degrees]"
+msgid "Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]"
 msgstr ""
 #: ../raster/r.sun/main.c:294
@@ -38153,8 +36755,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:303
-msgid ""
-"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
+msgid "Name of the Linke atmospheric turbidity coefficient input raster map [-]"
 msgstr ""
 #: ../raster/r.sun/main.c:312
@@ -38178,14 +36779,11 @@
 msgstr ""
 #: ../raster/r.sun/main.c:357
-msgid ""
-"Name of real-sky beam radiation coefficient (thick cloud) input raster map "
-"[0-1]"
+msgid "Name of real-sky beam radiation coefficient (thick cloud) input raster map [0-1]"
 msgstr ""
 #: ../raster/r.sun/main.c:366
-msgid ""
-"Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
+msgid "Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
 msgstr ""
 #: ../raster/r.sun/main.c:373
@@ -38197,27 +36795,19 @@
 msgstr ""
 #: ../raster/r.sun/main.c:399
-msgid ""
-"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map "
-"[Wh.m-2.day-1] (mode 2)"
+msgid "Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
 msgstr ""
 #: ../raster/r.sun/main.c:408
-msgid ""
-"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map "
+msgid "Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
 msgstr ""
 #: ../raster/r.sun/main.c:417
-msgid ""
-"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
-"map [Wh.m-2.day-1] (mode 2)"
+msgid "Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
 msgstr ""
 #: ../raster/r.sun/main.c:426
-msgid ""
-"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or "
-"irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgid "Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
 msgstr ""
 #: ../raster/r.sun/main.c:435
@@ -38289,8 +36879,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:609
-msgid ""
-"If you use the horizon option you must also set the 'horizonstep' parameter."
+msgid "If you use the horizon option you must also set the 'horizonstep' parameter."
 msgstr ""
 #: ../raster/r.sun/main.c:615
@@ -38298,9 +36887,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:617
-msgid ""
-"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
-"time"
+msgid "Mode 1: instantaneous solar incidence angle & irradiance using a set local time"
 msgstr ""
 #: ../raster/r.sun/main.c:622
@@ -38356,9 +36943,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:700
-msgid ""
-"If you want to save memory and to use shadows, you must use pre-calculated "
-"horizons."
+msgid "If you want to save memory and to use shadows, you must use pre-calculated horizons."
 msgstr ""
 #: ../raster/r.sun/main.c:767
@@ -38370,9 +36955,7 @@
 msgstr ""
 #: ../raster/r.coin/main.c:69
-msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
+msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
 msgstr ""
 #: ../raster/r.coin/main.c:74
@@ -38388,9 +36971,7 @@
 msgstr ""
 #: ../raster/r.coin/main.c:86
-msgid ""
-"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
-"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
+msgid "c(ells), p(ercent), x(percent of category [column]), y(percent of category [row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
 msgstr ""
 #: ../raster/r.coin/main.c:93
@@ -38429,9 +37010,7 @@
 msgstr ""
 #: ../raster/r.kappa/main.c:72
-msgid ""
-"Calculates error matrix and kappa parameter for accuracy assessment of "
-"classification result."
+msgid "Calculates error matrix and kappa parameter for accuracy assessment of classification result."
 msgstr ""
 #: ../raster/r.kappa/main.c:78
@@ -38593,9 +37172,7 @@
 msgstr ""
 #: ../raster/r.clump/main.c:56
-msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
+msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
 msgstr ""
 #: ../raster/r.clump/main.c:72
@@ -38618,8 +37195,7 @@
 msgstr[1] ""
 #: ../raster/r.surf.random/main.c:40
-msgid ""
-"Produces a raster surface map of uniform random deviates with defined range."
+msgid "Produces a raster surface map of uniform random deviates with defined range."
 msgstr ""
 #: ../raster/r.surf.random/main.c:46
@@ -38636,10 +37212,7 @@
 #: ../raster/r.topidx/file_io.c:35
 #, c-format
-msgid ""
-"The current region resolution [%s x %s] is finer than the input map's "
-"resolution [%s x %s]. The current region resolution must be identical to, or"
-" coarser than, the input map's resolution."
+msgid "The current region resolution [%s x %s] is finer than the input map's resolution [%s x %s]. The current region resolution must be identical to, or coarser than, the input map's resolution."
 msgstr ""
 #: ../raster/r.topidx/file_io.c:42
@@ -38660,9 +37233,7 @@
 msgstr ""
 #: ../raster/r.topidx/main.c:43
-msgid ""
-"Creates a topographic index (wetness index) raster map from an elevation "
-"raster map."
+msgid "Creates a topographic index (wetness index) raster map from an elevation raster map."
 msgstr ""
 #: ../raster/r.topidx/main.c:49
@@ -38686,9 +37257,7 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:79
-msgid ""
-"The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - "
-"dirichlet- and 3 - transfer boundary condition"
+msgid "The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - dirichlet- and 3 - transfer boundary condition"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:85
@@ -38711,14 +37280,11 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:103
-msgid ""
-"Concentration sources and sinks bounded to a water source or sink in [kg/s]"
+msgid "Concentration sources and sinks bounded to a water source or sink in [kg/s]"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:112
-msgid ""
-"Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical "
-"reaction)"
+msgid "Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical reaction)"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:117
@@ -38738,21 +37304,15 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:132
-msgid ""
-"The resulting concentration of the numerical solute transport calculation "
-"will be written to this map. [kg/m^3]"
+msgid "The resulting concentration of the numerical solute transport calculation will be written to this map. [kg/m^3]"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:140
-msgid ""
-"Calculate and store the groundwater filter velocity vector part in x "
-"direction [m/s]\n"
+msgid "Calculate and store the groundwater filter velocity vector part in x direction [m/s]\n"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:147
-msgid ""
-"Calculate and store the groundwater filter velocity vector part in y "
+msgid "Calculate and store the groundwater filter velocity vector part in y direction [m/s]\n"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:161
@@ -38764,9 +37324,7 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:177
-msgid ""
-"Use this number of time loops if the CFL flag is off. The timestep will "
-"become dt/loops."
+msgid "Use this number of time loops if the CFL flag is off. The timestep will become dt/loops."
 msgstr ""
 #: ../raster/r.solute.transport/main.c:187
@@ -38782,9 +37340,7 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:233
-msgid ""
-"Numerical calculation program for transient, confined and unconfined solute "
-"transport in two dimensions"
+msgid "Numerical calculation program for transient, confined and unconfined solute transport in two dimensions"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:258
@@ -38817,8 +37373,7 @@
 #: ../raster/r.solute.transport/main.c:385
 #, c-format
-msgid ""
-"The time step is to large: %gs. The largest time step should be of size %gs."
+msgid "The time step is to large: %gs. The largest time step should be of size %gs."
 msgstr ""
 #: ../raster/r.solute.transport/main.c:397
@@ -38921,9 +37476,7 @@
 msgstr ""
 #: ../raster/r.external/window.c:23
-msgid ""
-"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
-"transform the map to North-up."
+msgid "Input raster map is rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
 msgstr ""
 #: ../raster/r.external/window.c:26
@@ -39236,9 +37789,7 @@
 msgstr ""
 #: ../raster/r.stream.extract/main.c:88
-msgid ""
-"Stream extraction will use provided accumulation instead of calculating it "
-"anew"
+msgid "Stream extraction will use provided accumulation instead of calculating it anew"
 msgstr ""
 #: ../raster/r.stream.extract/main.c:93
@@ -39262,9 +37813,7 @@
 msgstr ""
 #: ../raster/r.stream.extract/main.c:110
-msgid ""
-"If accumulation is larger than d8cut, SFD is used instead of MFD. Applies "
-"only if no accumulation map is given."
+msgid "If accumulation is larger than d8cut, SFD is used instead of MFD. Applies only if no accumulation map is given."
 msgstr ""
 #: ../raster/r.stream.extract/main.c:122
@@ -39272,9 +37821,7 @@
 msgstr ""
 #: ../raster/r.stream.extract/main.c:124
-msgid ""
-"Montgomery: accumulation is multiplied with pow(slope,mexp) and then "
-"compared with threshold"
+msgid "Montgomery: accumulation is multiplied with pow(slope,mexp) and then compared with threshold"
 msgstr ""
 #: ../raster/r.stream.extract/main.c:132
@@ -39414,9 +37961,7 @@
 #: ../raster/r.stream.extract/streams.c:700
 #, c-format
-msgid ""
-"MFD: A * path already processed when setting drainage direction: %lld of "
-"%lld cells"
+msgid "MFD: A * path already processed when setting drainage direction: %lld of %lld cells"
 msgstr ""
 #: ../raster/r.stream.extract/thin.c:83
@@ -39451,9 +37996,7 @@
 msgstr ""
 #: ../raster/r.external.out/main.c:240
-msgid ""
-"Redirects raster output to file utilizing GDAL library rather than storing "
-"in GRASS raster format."
+msgid "Redirects raster output to file utilizing GDAL library rather than storing in GRASS raster format."
 msgstr ""
 #: ../raster/r.external.out/main.c:244
@@ -39546,9 +38089,7 @@
 msgstr ""
 #: ../raster/r.carve/main.c:77
-msgid ""
-"Takes vector stream data, transforms it to raster and subtracts depth from "
-"the output DEM."
+msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
 msgstr ""
 #: ../raster/r.carve/main.c:82
@@ -39594,8 +38135,7 @@
 msgstr ""
 #: ../raster/r.carve/enforce_ds.c:175
-msgid ""
-"Vect runs out of region and re-enters - this case is not yet implemented."
+msgid "Vect runs out of region and re-enters - this case is not yet implemented."
 msgstr ""
 #: ../raster/r.surf.fractal/main.c:40
@@ -39633,10 +38173,7 @@
 msgstr ""
 #: ../raster/r.cost/main.c:145
-msgid ""
-"Creates a raster map showing the cumulative cost of moving between different"
-" geographic locations on an input raster map whose cell category values "
-"represent cost."
+msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
 msgstr ""
 #: ../raster/r.cost/main.c:152
@@ -39654,9 +38191,7 @@
 #: ../raster/r.cost/main.c:489
 #, c-format
-msgid ""
-"Negative cell value found at row %d, col %d. Setting negative value to "
-"null_cost value"
+msgid "Negative cell value found at row %d, col %d. Setting negative value to null_cost value"
 msgstr ""
 #: ../raster/r.cost/main.c:582
@@ -39763,9 +38298,7 @@
 #: ../raster/r.stats.quantile/main.c:632
 #, c-format
-msgid ""
-"Base map <%s> has many categories (%d), computation might be slow and might "
-"need a lot of memory"
+msgid "Base map <%s> has many categories (%d), computation might be slow and might need a lot of memory"
 msgstr ""
 #: ../raster/r.to.vect/main.c:79
@@ -39781,14 +38314,11 @@
 msgstr ""
 #: ../raster/r.to.vect/main.c:142
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
-"table."
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be written to the table."
 msgstr ""
 #: ../raster/r.to.vect/main.c:144
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be z coordinate."
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be z coordinate."
 msgstr ""
 #: ../raster/r.to.vect/main.c:146
@@ -40030,9 +38560,7 @@
 msgstr ""
 #: ../raster/r.cross/main.c:72
-msgid ""
-"Creates a cross product of the category values from multiple raster map "
-"layers."
+msgid "Creates a cross product of the category values from multiple raster map layers."
 msgstr ""
 #: ../raster/r.cross/main.c:81
@@ -40133,8 +38661,7 @@
 msgstr ""
 #: ../raster/r.transect/main.c:106
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
+msgid "Outputs raster map layer values lying along user defined transect line(s)."
 msgstr ""
 #: ../raster/r.transect/main.c:110
@@ -40164,9 +38691,7 @@
 msgstr ""
 #: ../raster/r.rescale.eq/main.c:55
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
+msgid "Rescales histogram equalized the range of category values in a raster map layer."
 msgstr ""
 #: ../raster/r.rescale.eq/main.c:115
@@ -40213,9 +38738,7 @@
 #: ../raster/r.null/main.c:132
 #, c-format
-msgid ""
-"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
-"with r.mapcalc. Exiting."
+msgid "Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy with r.mapcalc. Exiting."
 msgstr ""
 #: ../raster/r.null/main.c:138
@@ -40300,9 +38823,7 @@
 msgstr ""
 #: ../raster/r.fill.dir/main.c:92
-msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation raster map."
+msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
 msgstr ""
 #: ../raster/r.fill.dir/main.c:99
@@ -40310,8 +38831,7 @@
 msgstr ""
 #: ../raster/r.fill.dir/main.c:103
-msgid ""
-"Name for output flow direction map for depressionless elevation raster map"
+msgid "Name for output flow direction map for depressionless elevation raster map"
 msgstr ""
 #: ../raster/r.fill.dir/main.c:108
@@ -40525,9 +39045,7 @@
 msgstr ""
 #: ../ps/ps.map/main.c:118
-msgid ""
-"Describe map-box's position on the page and exit (inches from top-left of "
-"paper)"
+msgid "Describe map-box's position on the page and exit (inches from top-left of paper)"
 msgstr ""
 #: ../ps/ps.map/main.c:123
@@ -40580,10 +39098,7 @@
 msgstr ""
 #: ../ps/ps.map/ps_clrtbl.c:54
-msgid ""
-"Your cats/ file is invalid. A cats/ file with categories and labels is "
-"required for 'colortable' when using categorical legends; see the r.category"
-" help page. Colortable creation has been skipped."
+msgid "Your cats/ file is invalid. A cats/ file with categories and labels is required for 'colortable' when using categorical legends; see the r.category help page. Colortable creation has been skipped."
 msgstr ""
 #: ../ps/ps.map/ps_clrtbl.c:69 ../ps/ps.map/ps_fclrtbl.c:97
Modified: grass/trunk/locale/po/grassmods_th.po
--- grass/trunk/locale/po/grassmods_th.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grassmods_th.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -1700,9 +1700,9 @@
 #: ../raster3d/r3.in.lidar/main.c:378 ../raster/r.in.lidar/main.c:401
 #: ../vector/v.in.lidar/main.c:352
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open file <%s> as a LiDAR point cloud"
-msgstr "ไม่สามารถเปิดไฟล์ <%s> เพื่อเขียน"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:382 ../raster/r.in.lidar/main.c:405
 #: ../vector/v.in.lidar/main.c:356
@@ -35909,16 +35909,14 @@
 #: ../vector/v.surf.bspline/main.c:149
 #: ../vector/v.lidar.edgedetection/main.c:94 ../vector/v.outlier/main.c:103
 #: ../vector/v.lidar.correction/main.c:101
-#, fuzzy
 msgid "Length of each spline step in the east-west direction"
-msgstr "ค่าขั้น ของ Interpolation spline ใน east direction"
+msgstr ""
 #: ../vector/v.surf.bspline/main.c:158
 #: ../vector/v.lidar.edgedetection/main.c:103 ../vector/v.outlier/main.c:112
 #: ../vector/v.lidar.correction/main.c:110
-#, fuzzy
 msgid "Length of each spline step in the north-south direction"
-msgstr "ค่าขั้น ของ Interpolation spline ใน north direction"
+msgstr ""
 #: ../vector/v.surf.bspline/main.c:207
 msgid "Choose either vector or raster output, not both"
Modified: grass/trunk/locale/po/grassmods_tr.po
--- grass/trunk/locale/po/grassmods_tr.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grassmods_tr.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -1702,9 +1702,9 @@
-#, fuzzy, c-format
+#, c-format
-msgstr "<%s> dosyası yazma için açılamıyor"
+msgstr ""
Modified: grass/trunk/locale/po/grassmods_uk.po
--- grass/trunk/locale/po/grassmods_uk.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grassmods_uk.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -2,7 +2,7 @@
 # Copyright (C) 2017 GRASS Development Team
 # This file is distributed under the same license as the GRASS GIS package.
 # transifex generated, 2017
 msgid ""
 msgstr ""
 "Project-Id-Version: grasslibs_uk\n"
@@ -10,10 +10,10 @@
 "POT-Creation-Date: 2017-05-22 23:12-0700\n"
 "PO-Revision-Date: 2017-05-23 21:08+0200\n"
 "Language-Team: Ukrainian (https://www.transifex.com/grass-gis/teams/45198/uk/)\n"
+"Language: uk\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
-"Language: uk\n"
 "Plural-Forms: nplurals=3; plural=(n%10==1 && n%100!=11 ? 0 : n%10>=2 && n%10<=4 && (n%100<10 || n%100>=20) ? 1 : 2);\n"
 #: ../raster3d/r3.flow/flowline.c:60 ../vector/v.to.points/write.c:52
@@ -272,14 +272,11 @@
 msgstr ""
 #: ../raster3d/r3.flow/main.c:193
-msgid ""
-"Names of three 3D raster maps describing x, y, z components of vector field"
+msgid "Names of three 3D raster maps describing x, y, z components of vector field"
 msgstr ""
 #: ../raster3d/r3.flow/main.c:200
-msgid ""
-"If no map is provided, flow lines are generated from each cell of the input "
-"3D raster"
+msgid "If no map is provided, flow lines are generated from each cell of the input 3D raster"
 msgstr ""
 #: ../raster3d/r3.flow/main.c:203
@@ -358,8 +355,7 @@
 msgstr ""
 #: ../raster3d/r3.flow/main.c:226
-msgid ""
-"Values of this 3D raster will be stored as attributes of flowlines segments"
+msgid "Values of this 3D raster will be stored as attributes of flowlines segments"
 msgstr ""
 #: ../raster3d/r3.flow/main.c:240
@@ -489,16 +485,15 @@
 #: ../vector/v.colors/main.c:262 ../vector/v.info/main.c:61
 #: ../vector/v.surf.rst/main.c:528 ../vector/v.surf.rst/main.c:632
 #: ../vector/v.to.3d/main.c:72 ../vector/v.db.select/main.c:164
-#: ../vector/v.lidar.correction/main.c:156
-#: ../vector/v.lidar.growing/main.c:138 ../vector/v.lidar.growing/main.c:142
-#: ../vector/v.net.allpairs/main.c:130 ../vector/v.net.connectivity/main.c:130
-#: ../vector/v.net.flow/main.c:143 ../vector/v.what.rast/main.c:131
-#: ../vector/v.drape/main.c:143 ../vector/v.build.polylines/main.c:151
-#: ../vector/v.normal/main.c:110 ../vector/v.out.postgis/main.c:100
-#: ../vector/v.out.svg/main.c:139 ../vector/v.delaunay/main.c:120
-#: ../vector/v.reclass/main.c:113 ../vector/v.net.centrality/main.c:209
-#: ../vector/v.select/main.c:108 ../vector/v.support/main.c:130
-#: ../vector/v.lidar.edgedetection/main.c:180
+#: ../vector/v.lidar.correction/main.c:156 ../vector/v.lidar.growing/main.c:138
+#: ../vector/v.lidar.growing/main.c:142 ../vector/v.net.allpairs/main.c:130
+#: ../vector/v.net.connectivity/main.c:130 ../vector/v.net.flow/main.c:143
+#: ../vector/v.what.rast/main.c:131 ../vector/v.drape/main.c:143
+#: ../vector/v.build.polylines/main.c:151 ../vector/v.normal/main.c:110
+#: ../vector/v.out.postgis/main.c:100 ../vector/v.out.svg/main.c:139
+#: ../vector/v.delaunay/main.c:120 ../vector/v.reclass/main.c:113
+#: ../vector/v.net.centrality/main.c:209 ../vector/v.select/main.c:108
+#: ../vector/v.support/main.c:130 ../vector/v.lidar.edgedetection/main.c:180
 #: ../vector/v.lrs/v.lrs.label/main.c:272
 #: ../vector/v.lrs/v.lrs.where/main.c:131
 #: ../vector/v.lrs/v.lrs.where/main.c:140
@@ -538,10 +533,10 @@
 #: ../display/d.vect.chart/main.c:246 ../display/d.extract/main.c:103
 #: ../misc/m.nviz.image/vector.c:280 ../raster/r.walk/main.c:673
 #: ../raster/r.walk/main.c:742 ../raster/r.drain/main.c:268
-#: ../raster/r.sim/simlib/observation_points.c:41
-#: ../raster/r.region/main.c:170 ../raster/r.random/support.c:63
-#: ../raster/r.what/main.c:237 ../raster/r.carve/main.c:162
-#: ../raster/r.cost/main.c:533 ../raster/r.cost/main.c:606
+#: ../raster/r.sim/simlib/observation_points.c:41 ../raster/r.region/main.c:170
+#: ../raster/r.random/support.c:63 ../raster/r.what/main.c:237
+#: ../raster/r.carve/main.c:162 ../raster/r.cost/main.c:533
+#: ../raster/r.cost/main.c:606
 #, c-format
 msgid "Unable to open vector map <%s>"
 msgstr ""
@@ -761,17 +756,16 @@
 #: ../raster3d/r3.timestamp/main.c:44 ../temporal/t.connect/main.c:36
 #: ../locale/scriptstrings/t.support_to_translate.c:3
 #: ../locale/scriptstrings/t.info_to_translate.c:3
-#: ../locale/scriptstrings/t.select_to_translate.c:3
-#: ../vector/v.info/main.c:38 ../vector/v.timestamp/main.c:36
-#: ../vector/v.support/main.c:40 ../raster/r.describe/main.c:55
-#: ../raster/r.info/main.c:71 ../raster/r.region/main.c:52
-#: ../raster/r.support/main.c:55 ../raster/r.timestamp/main.c:36
+#: ../locale/scriptstrings/t.select_to_translate.c:3 ../vector/v.info/main.c:38
+#: ../vector/v.timestamp/main.c:36 ../vector/v.support/main.c:40
+#: ../raster/r.describe/main.c:55 ../raster/r.info/main.c:71
+#: ../raster/r.region/main.c:52 ../raster/r.support/main.c:55
+#: ../raster/r.timestamp/main.c:36
 msgid "metadata"
 msgstr ""
 #: ../raster3d/r3.support/main.c:52
-msgid ""
-"Allows creation and/or modification of 3D raster map layer support files."
+msgid "Allows creation and/or modification of 3D raster map layer support files."
 msgstr ""
 #: ../raster3d/r3.support/main.c:62
@@ -916,9 +910,7 @@
 msgstr ""
 #: ../raster3d/r3.gradient/main.c:47
-msgid ""
-"Computes gradient of a 3D raster map and outputs gradient components as "
-"three 3D raster maps."
+msgid "Computes gradient of a 3D raster map and outputs gradient components as three 3D raster maps."
 msgstr ""
 #: ../raster3d/r3.gradient/main.c:56
@@ -1358,9 +1350,7 @@
 #: ../raster3d/r3.in.lidar/main.c:191 ../vector/v.in.lidar/main.c:214
 #: ../raster/r.in.lidar/main.c:269
-msgid ""
-"Input is comma separated integers. If not specified, all points are "
-"imported."
+msgid "Input is comma separated integers. If not specified, all points are imported."
 msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:199
@@ -1387,8 +1377,7 @@
 #: ../raster3d/r3.in.lidar/main.c:213 ../vector/v.in.lidar/main.c:295
 #: ../raster/r.in.lidar/main.c:339
-msgid ""
-"Points invalid according to APSRS LAS specification will be filtered out"
+msgid "Points invalid according to APSRS LAS specification will be filtered out"
 msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:230 ../general/g.pnmcomp/main.c:242
@@ -1510,9 +1499,7 @@
 msgstr ""
 #: ../raster3d/r3.mkdspf/main.c:83
-msgid ""
-"Creates a display file from an existing 3D raster map according to specified"
-" threshold levels."
+msgid "Creates a display file from an existing 3D raster map according to specified threshold levels."
 msgstr ""
 #: ../raster3d/r3.mkdspf/main.c:91
@@ -1615,9 +1602,7 @@
 msgstr ""
 #: ../raster3d/r3.to.rast/main.c:96
-msgid ""
-"Use the same resolution as the input 3D raster map for the 2D output maps, "
-"independent of the current region settings"
+msgid "Use the same resolution as the input 3D raster map for the 2D output maps, independent of the current region settings"
 msgstr ""
 #: ../raster3d/r3.to.rast/main.c:208 ../raster3d/r3.cross.rast/main.c:230
@@ -1682,9 +1667,8 @@
 #: ../raster/r.proj/main.c:144 ../raster/r.in.gdal/main.c:90
 #: ../raster/r.topmodel/main.c:51 ../raster/r.contour/main.c:87
 #: ../raster/r.sunhours/main.c:72 ../raster/r.quant/main.c:47
-#: ../raster/r.regression.line/main.c:46
-#: ../raster/r.param.scale/interface.c:54 ../raster/r.in.mat/main.c:91
-#: ../raster/r.li/r.li.padrange/padrange.c:53
+#: ../raster/r.regression.line/main.c:46 ../raster/r.param.scale/interface.c:54
+#: ../raster/r.in.mat/main.c:91 ../raster/r.li/r.li.padrange/padrange.c:53
 #: ../raster/r.li/r.li.cwed/cwed.c:54 ../raster/r.li/r.li.simpson/simpson.c:46
 #: ../raster/r.li/r.li.dominance/dominance.c:46
 #: ../raster/r.li/r.li.patchdensity/main.c:51
@@ -1694,26 +1678,26 @@
 #: ../raster/r.li/r.li.padsd/padsd.c:53 ../raster/r.li/r.li.patchnum/main.c:50
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:48
 #: ../raster/r.li/r.li.renyi/renyi.c:47 ../raster/r.li/r.li.mps/mps.c:52
-#: ../raster/r.li/r.li.shannon/shannon.c:46
-#: ../raster/r.resamp.interp/main.c:76 ../raster/r.category/main.c:52
-#: ../raster/r.his/main.c:67 ../raster/r.to.rast3/main.c:197
-#: ../raster/r.resamp.rst/main.c:148 ../raster/r.stats.zonal/main.c:101
-#: ../raster/r.relief/main.c:107 ../raster/r.neighbors/main.c:167
-#: ../raster/r.sunmask/main.c:116 ../raster/r.colors/edit_colors.c:63
-#: ../raster/r.drain/main.c:109 ../raster/r.latlong/main.c:56
-#: ../raster/r.support.stats/main.c:38 ../raster/r.texture/main.c:102
-#: ../raster/r.series/main.c:137 ../raster/r.profile/main.c:53
-#: ../raster/r.out.pov/main.c:121 ../raster/r.covar/main.c:51
-#: ../raster/r.out.vtk/main.c:59 ../raster/r.out.png/main.c:112
-#: ../raster/r.watershed/front/main.c:73 ../raster/r.to.rast3elev/main.c:361
-#: ../raster/r.grow.distance/main.c:152 ../raster/r.recode/main.c:48
-#: ../raster/r.in.ascii/main.c:69 ../raster/r.flow/main.c:421
-#: ../raster/r.regression.multi/main.c:128 ../raster/r.in.lidar/main.c:108
-#: ../raster/r.reclass/main.c:50 ../raster/r.tile/main.c:43
-#: ../raster/r.resamp.bspline/main.c:80 ../raster/r.mapcalc/main.c:69
-#: ../raster/r.in.xyz/main.c:158 ../raster/r.stats/main.c:106
-#: ../raster/r.ros/main.c:212 ../raster/r.info/main.c:70
-#: ../raster/r.volume/main.c:76 ../raster/r.sim/r.sim.water/main.c:113
+#: ../raster/r.li/r.li.shannon/shannon.c:46 ../raster/r.resamp.interp/main.c:76
+#: ../raster/r.category/main.c:52 ../raster/r.his/main.c:67
+#: ../raster/r.to.rast3/main.c:197 ../raster/r.resamp.rst/main.c:148
+#: ../raster/r.stats.zonal/main.c:101 ../raster/r.relief/main.c:107
+#: ../raster/r.neighbors/main.c:167 ../raster/r.sunmask/main.c:116
+#: ../raster/r.colors/edit_colors.c:63 ../raster/r.drain/main.c:109
+#: ../raster/r.latlong/main.c:56 ../raster/r.support.stats/main.c:38
+#: ../raster/r.texture/main.c:102 ../raster/r.series/main.c:137
+#: ../raster/r.profile/main.c:53 ../raster/r.out.pov/main.c:121
+#: ../raster/r.covar/main.c:51 ../raster/r.out.vtk/main.c:59
+#: ../raster/r.out.png/main.c:112 ../raster/r.watershed/front/main.c:73
+#: ../raster/r.to.rast3elev/main.c:361 ../raster/r.grow.distance/main.c:152
+#: ../raster/r.recode/main.c:48 ../raster/r.in.ascii/main.c:69
+#: ../raster/r.flow/main.c:421 ../raster/r.regression.multi/main.c:128
+#: ../raster/r.in.lidar/main.c:108 ../raster/r.reclass/main.c:50
+#: ../raster/r.tile/main.c:43 ../raster/r.resamp.bspline/main.c:80
+#: ../raster/r.mapcalc/main.c:69 ../raster/r.in.xyz/main.c:158
+#: ../raster/r.stats/main.c:106 ../raster/r.ros/main.c:212
+#: ../raster/r.info/main.c:70 ../raster/r.volume/main.c:76
+#: ../raster/r.sim/r.sim.water/main.c:113
 #: ../raster/r.sim/r.sim.sediment/main.c:113
 #: ../raster/r.series.accumulate/main.c:80 ../raster/r.out.gdal/main.c:136
 #: ../raster/r.spread/main.c:105 ../raster/r.out.gridatb/main.c:67
@@ -1755,9 +1739,7 @@
 msgstr ""
 #: ../raster3d/r3.to.rast/main.c:271 ../raster3d/r3.out.vtk/main.c:451
-msgid ""
-"The 2D and 3D region settings are different. Using the 2D window settings to"
-" adjust the 2D part of the 3D region."
+msgid "The 2D and 3D region settings are different. Using the 2D window settings to adjust the 2D part of the 3D region."
 msgstr ""
 #: ../raster3d/r3.to.rast/main.c:295 ../vector/v.generalize/matrix.c:144
@@ -1807,8 +1789,7 @@
 #: ../raster3d/r3.to.rast/main.c:308
 #, c-format
-msgid ""
-"Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
+msgid "Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
 msgstr ""
 #: ../raster3d/r3.neighbors/main.c:94 ../raster/r.neighbors/main.c:102
@@ -1827,9 +1808,7 @@
 msgstr ""
 #: ../raster3d/r3.neighbors/main.c:137
-msgid ""
-"The size of the window in x, y and z direction, values must be odd integer "
-"numbers, eg: 3,3,3"
+msgid "The size of the window in x, y and z direction, values must be odd integer numbers, eg: 3,3,3"
 msgstr ""
 #: ../raster3d/r3.neighbors/main.c:209
@@ -1872,9 +1851,7 @@
 msgstr ""
 #: ../raster3d/r3.neighbors/main.c:218
-msgid ""
-"Makes each voxel value a function of the values assigned to the voxels "
-"around it, and stores new voxel values in an output 3D raster map"
+msgid "Makes each voxel value a function of the values assigned to the voxels around it, and stores new voxel values in an output 3D raster map"
 msgstr ""
 #: ../raster3d/r3.neighbors/main.c:287
@@ -1890,27 +1867,19 @@
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:60
-msgid ""
-"Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - "
-"active, 2 - dirichlet"
+msgid "Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:65
-msgid ""
-"Input 3D raster map with the x-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Input 3D raster map with the x-part of the hydraulic conductivity tensor in [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:70
-msgid ""
-"Input 3D raster map with the y-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Input 3D raster map with the y-part of the hydraulic conductivity tensor in [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:75
-msgid ""
-"Input 3D raster map with the z-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Input 3D raster map with the z-part of the hydraulic conductivity tensor in [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:80
@@ -1926,32 +1895,23 @@
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:93
-msgid ""
-"Output 3D raster map storing the piezometric head result of the numerical "
-"calculation"
+msgid "Output 3D raster map storing the piezometric head result of the numerical calculation"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:99
-msgid ""
-"Output 3D raster map storing the groundwater filter velocity vector part in "
-"x direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in x direction [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:105
-msgid ""
-"y direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in y direction [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:111
-msgid ""
-"z direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in z direction [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:117
-msgid ""
-"Output 3D raster map storing the groundwater budget for each cell [m^3/s]"
+msgid "Output 3D raster map storing the groundwater budget for each cell [m^3/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:127
@@ -1959,9 +1919,7 @@
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:131 ../raster/r.solute.transport/main.c:192
-msgid ""
-"Use a full filled quadratic linear equation system, default is a sparse "
-"linear equation system."
+msgid "Use a full filled quadratic linear equation system, default is a sparse linear equation system."
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:160 ../raster/r.gwflow/main.c:209
@@ -1969,9 +1927,7 @@
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:163
-msgid ""
-"Numerical calculation program for transient, confined groundwater flow in "
-"three dimensions."
+msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions."
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:180
@@ -2021,9 +1977,7 @@
 msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:175
-msgid ""
-"No 3D raster data, RGB or xyz-vector maps are provided! Will only write the "
-"geometry."
+msgid "No 3D raster data, RGB or xyz-vector maps are provided! Will only write the geometry."
 msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:209
@@ -2079,14 +2033,11 @@
 msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:71
-msgid ""
-"Create 3D elevation output with a top and a bottom surface, both raster maps"
-" are required."
+msgid "Create 3D elevation output with a top and a bottom surface, both raster maps are required."
 msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:80
-msgid ""
-"Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
+msgid "Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
 msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:88
@@ -2112,15 +2063,12 @@
 msgid "Scale factor affects the origin"
 msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:123
-#: ../raster/r.out.vtk/parameters.c:128
+#: ../raster3d/r3.out.vtk/parameters.c:123 ../raster/r.out.vtk/parameters.c:128
 msgid "Correct the coordinates to match the VTK-OpenGL precision"
 msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:129
-msgid ""
-"Do not convert the top-bottom resolution in case of lat long projection to "
-"meters"
+msgid "Do not convert the top-bottom resolution in case of lat long projection to meters"
 msgstr ""
 #: ../raster3d/r3.out.vtk/writeVTKData.c:122
@@ -2133,9 +2081,7 @@
 #: ../raster3d/r3.out.vtk/writeVTKData.c:335
 #, c-format
-msgid ""
-"write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
-"ascii file"
+msgid "write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-ascii file"
 msgstr ""
 #: ../raster3d/r3.out.vtk/writeVTKData.c:441
@@ -2171,8 +2117,7 @@
 #: ../raster3d/r3.in.ascii/main.c:281
 #, c-format
-msgid ""
-"Data exists in input file after fully importing expected data.  [%.4f ...]"
+msgid "Data exists in input file after fully importing expected data.  [%.4f ...]"
 msgstr ""
 #: ../raster3d/r3.in.ascii/main.c:319
@@ -2201,15 +2146,11 @@
 msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:233
-msgid ""
-"Creates cross section 2D raster map from 3D raster map based on 2D elevation"
-" map"
+msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map"
 msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:259
-msgid ""
-"The 2D and 3D region settings are different. Using the 3D raster map "
-"settings to adjust the 2D region."
+msgid "The 2D and 3D region settings are different. Using the 3D raster map settings to adjust the 2D region."
 msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:302
@@ -2235,8 +2176,7 @@
 msgstr ""
 #: ../raster3d/r3.retile/main.c:99
-msgid ""
-"Retiles an existing 3D raster map with user defined x, y and z tile size."
+msgid "Retiles an existing 3D raster map with user defined x, y and z tile size."
 msgstr ""
 #: ../raster3d/r3.retile/main.c:135
@@ -2444,8 +2384,7 @@
 msgstr ""
 #: ../temporal/t.connect/main.c:38
-msgid ""
-"Prints/sets general temporal GIS database connection for current mapset."
+msgid "Prints/sets general temporal GIS database connection for current mapset."
 msgstr ""
 #: ../temporal/t.connect/main.c:42 ../db/db.connect/main.c:51
@@ -2589,9 +2528,8 @@
 msgstr ""
 #: ../locale/scriptstrings/d.frame_to_translate.c:4
-#: ../locale/scriptstrings/d.redraw_to_translate.c:4
-#: ../display/d.mon/main.c:40 ../display/d.erase/main.c:31
-#: ../display/d.info/main.c:36
+#: ../locale/scriptstrings/d.redraw_to_translate.c:4 ../display/d.mon/main.c:40
+#: ../display/d.erase/main.c:31 ../display/d.info/main.c:36
 msgid "monitors"
 msgstr ""
@@ -2620,8 +2558,7 @@
 msgstr ""
 #: ../locale/scriptstrings/d.frame_to_translate.c:11
-msgid ""
-"Screen coordinates in percent where to place the frame (0,0 is lower-left)"
+msgid "Screen coordinates in percent where to place the frame (0,0 is lower-left)"
 msgstr ""
 #: ../locale/scriptstrings/d.frame_to_translate.c:12
@@ -2812,9 +2749,7 @@
 msgstr ""
 #: ../locale/scriptstrings/d.what.rast_to_translate.c:1
-msgid ""
-"Allows the user to interactively query raster map layers at user-selected "
-"locations."
+msgid "Allows the user to interactively query raster map layers at user-selected locations."
 msgstr ""
 #: ../locale/scriptstrings/d.what.rast_to_translate.c:3
@@ -2879,8 +2814,7 @@
 #: ../vector/v.net.centrality/main.c:96 ../vector/v.select/main.c:48
 #: ../vector/v.support/main.c:39 ../vector/v.in.lidar/main.c:136
 #: ../vector/v.lidar.edgedetection/main.c:75
-#: ../vector/v.lrs/v.lrs.label/main.c:102
-#: ../vector/v.lrs/v.lrs.where/main.c:57
+#: ../vector/v.lrs/v.lrs.label/main.c:102 ../vector/v.lrs/v.lrs.where/main.c:57
 #: ../vector/v.lrs/v.lrs.create/main.c:121
 #: ../vector/v.lrs/v.lrs.segment/main.c:71 ../vector/v.to.db/main.c:36
 #: ../vector/v.out.dxf/main.c:56 ../vector/v.transform/main.c:69
@@ -2918,9 +2852,7 @@
 msgstr ""
 #: ../locale/scriptstrings/d.what.vect_to_translate.c:1
-msgid ""
-"Allows the user to interactively query vector map layers at user-selected "
-"locations."
+msgid "Allows the user to interactively query vector map layers at user-selected locations."
 msgstr ""
 #: ../locale/scriptstrings/db.dropcolumn_to_translate.c:1
@@ -3094,8 +3026,7 @@
 #: ../locale/scriptstrings/db.univar_to_translate.c:5
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:5
-msgid ""
-"Name of attribute column on which to calculate statistics (must be numeric)"
+msgid "Name of attribute column on which to calculate statistics (must be numeric)"
 msgstr ""
 #: ../locale/scriptstrings/db.univar_to_translate.c:6
@@ -3120,9 +3051,7 @@
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:2
-msgid ""
-"Downloads and installs extensions from GRASS Addons repository or other "
-"source into the local GRASS installation or removes installed extensions."
+msgid "Downloads and installs extensions from GRASS Addons repository or other source into the local GRASS installation or removes installed extensions."
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:3
@@ -3177,15 +3106,11 @@
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:11
-msgid ""
-"URL or directory to get the extension from (supported only on Linux and Mac)"
+msgid "URL or directory to get the extension from (supported only on Linux and Mac)"
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:12
-msgid ""
-"The official repository is used by default. User can specify a ZIP file, "
-"directory or a repository on common hosting services. If not identified, "
-"Subversion repository is assumed. See manual for all options."
+msgid "The official repository is used by default. User can specify a ZIP file, directory or a repository on common hosting services. If not identified, Subversion repository is assumed. See manual for all options."
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:13
@@ -3201,15 +3126,11 @@
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:17
-msgid ""
-"List available extensions in the official GRASS GIS Addons repository "
-"including module description"
+msgid "List available extensions in the official GRASS GIS Addons repository including module description"
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:19
-msgid ""
-"List available extensions in the official GRASS GIS Addons repository (shell"
-" script style)"
+msgid "List available extensions in the official GRASS GIS Addons repository (shell script style)"
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:21
@@ -3255,8 +3176,7 @@
 msgstr ""
 #: ../locale/scriptstrings/g.extension.all_to_translate.c:2
-msgid ""
-"By default only extensions built against different GIS Library are rebuilt."
+msgid "By default only extensions built against different GIS Library are rebuilt."
 msgstr ""
 #: ../locale/scriptstrings/g.extension.all_to_translate.c:7
@@ -3292,9 +3212,7 @@
 msgstr ""
 #: ../locale/scriptstrings/g.manual_to_translate.c:9
-msgid ""
-"Use online manuals available at http://grass.osgeo.org website. This flag "
-"has no effect when displaying MAN text pages."
+msgid "Use online manuals available at http://grass.osgeo.org website. This flag has no effect when displaying MAN text pages."
 msgstr ""
 #: ../locale/scriptstrings/g.manual_to_translate.c:10
@@ -3318,8 +3236,7 @@
 msgstr ""
 #: ../locale/scriptstrings/g.search.modules_to_translate.c:6
-msgid ""
-"Display only modules where all keywords are available (AND), default: OR"
+msgid "Display only modules where all keywords are available (AND), default: OR"
 msgstr ""
 #: ../locale/scriptstrings/g.search.modules_to_translate.c:8
@@ -3516,9 +3433,8 @@
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:6
 #: ../vector/v.db.select/main.c:95 ../db/db.select/main.c:241
 #: ../raster/r.stats/main.c:119 ../raster/r.quantile/main.c:297
-#: ../raster/r.univar/r.univar_main.c:41
-#: ../raster/r.univar/r3.univar_main.c:42 ../raster/r.what/main.c:125
-#: ../raster/r.stats.quantile/main.c:555
+#: ../raster/r.univar/r.univar_main.c:41 ../raster/r.univar/r3.univar_main.c:42
+#: ../raster/r.what/main.c:125 ../raster/r.stats.quantile/main.c:555
 msgid "Name for output file (if omitted or \"-\" output to stdout)"
 msgstr ""
@@ -3531,9 +3447,7 @@
 msgstr ""
 #: ../locale/scriptstrings/i.pansharpen_to_translate.c:1
-msgid ""
-"Image fusion algorithms to sharpen multispectral with high-res panchromatic "
-"channels"
+msgid "Image fusion algorithms to sharpen multispectral with high-res panchromatic channels"
 msgstr ""
 #: ../locale/scriptstrings/i.pansharpen_to_translate.c:3
@@ -3590,8 +3504,7 @@
 msgstr ""
 #: ../locale/scriptstrings/i.spectral_to_translate.c:1
-msgid ""
-"Displays spectral response at user specified locations in group or images."
+msgid "Displays spectral response at user specified locations in group or images."
 msgstr ""
 #: ../locale/scriptstrings/i.spectral_to_translate.c:3
@@ -3654,9 +3567,7 @@
 msgstr ""
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:7
-msgid ""
-"For Landsat4-7: bands 1, 2, 3, 4, 5, 7; for Landsat8: bands 2, 3, 4, 5, 6, "
-"7; for MODIS: bands 1, 2, 3, 4, 5, 6, 7"
+msgid "For Landsat4-7: bands 1, 2, 3, 4, 5, 7; for Landsat8: bands 2, 3, 4, 5, 6, 7; for MODIS: bands 1, 2, 3, 4, 5, 6, 7"
 msgstr ""
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:8
@@ -3669,11 +3580,7 @@
 msgstr ""
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:10
-msgid ""
-"landsat4_tm;Use transformation rules for Landsat 4 TM;landsat5_tm;Use "
-"transformation rules for Landsat 5 TM;landsat7_etm;Use transformation rules "
-"for Landsat 7 ETM;landsat8_oli;Use transformation rules for Landsat 8 "
-"OLI;modis;Use transformation rules for MODIS"
+msgid "landsat4_tm;Use transformation rules for Landsat 4 TM;landsat5_tm;Use transformation rules for Landsat 5 TM;landsat7_etm;Use transformation rules for Landsat 7 ETM;landsat8_oli;Use transformation rules for Landsat 8 OLI;modis;Use transformation rules for MODIS"
 msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:1
@@ -3709,12 +3616,12 @@
 msgid "Name of input coordinate file"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:8
-#: ../general/g.proj/main.c:141 ../general/g.proj/main.c:150
-#: ../vector/v.edit/args.c:89 ../vector/v.segment/main.c:80
-#: ../vector/v.what/main.c:76 ../db/db.execute/main.c:139
-#: ../db/db.select/main.c:208 ../raster/r.recode/main.c:61
-#: ../raster/r.in.ascii/main.c:79 ../raster/r.reclass/main.c:66
+#: ../locale/scriptstrings/m.proj_to_translate.c:8 ../general/g.proj/main.c:141
+#: ../general/g.proj/main.c:150 ../vector/v.edit/args.c:89
+#: ../vector/v.segment/main.c:80 ../vector/v.what/main.c:76
+#: ../db/db.execute/main.c:139 ../db/db.select/main.c:208
+#: ../raster/r.recode/main.c:61 ../raster/r.in.ascii/main.c:79
+#: ../raster/r.reclass/main.c:66
 msgid "'-' for standard input"
 msgstr ""
@@ -3750,9 +3657,7 @@
 msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:22
-msgid ""
-"Output long/lat in decimal degrees, or other projections with many decimal "
-"places"
+msgid "Output long/lat in decimal degrees, or other projections with many decimal places"
 msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:24
@@ -3794,9 +3699,7 @@
 #: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:1
 #: ../raster/r.buffer/main.c:69
-msgid ""
-"Creates a raster map showing buffer zones surrounding cells that contain "
-"non-NULL category values."
+msgid "Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values."
 msgstr ""
 #: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:2
@@ -3949,9 +3852,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.import_to_translate.c:1
-msgid ""
-"Imports raster data into a GRASS raster map using GDAL library and "
-"reprojects on the fly."
+msgid "Imports raster data into a GRASS raster map using GDAL library and reprojects on the fly."
 msgstr ""
 #: ../locale/scriptstrings/r.import_to_translate.c:5
@@ -3990,11 +3891,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.import_to_translate.c:14
-msgid ""
-"nearest;nearest neighbor;bilinear;bilinear interpolation;bicubic;bicubic "
-"interpolation;lanczos;lanczos filter;bilinear_f;bilinear interpolation with "
-"fallback;bicubic_f;bicubic interpolation with fallback;lanczos_f;lanczos "
-"filter with fallback"
+msgid "nearest;nearest neighbor;bilinear;bilinear interpolation;bicubic;bicubic interpolation;lanczos;lanczos filter;bilinear_f;bilinear interpolation with fallback;bicubic_f;bicubic interpolation with fallback;lanczos_f;lanczos filter with fallback"
 msgstr ""
 #: ../locale/scriptstrings/r.import_to_translate.c:16
@@ -4010,9 +3907,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.import_to_translate.c:20
-msgid ""
-"estimated;estimated resolution;value;user-specified "
-"resolution;region;current region resolution"
+msgid "estimated;estimated resolution;value;user-specified resolution;region;current region resolution"
 msgstr ""
 #: ../locale/scriptstrings/r.import_to_translate.c:22
@@ -4071,14 +3966,11 @@
 #: ../locale/scriptstrings/r.import_to_translate.c:32
 #: ../locale/scriptstrings/v.import_to_translate.c:28
 #: ../vector/v.in.ogr/main.c:286 ../vector/v.external/args.c:45
-msgid ""
-"Assume that the dataset has the same projection as the current location"
+msgid "Assume that the dataset has the same projection as the current location"
 msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:1
-msgid ""
-"Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
-"using gdalwarp."
+msgid "Georeference, rectify, and import Terra-ASTER imagery and relative DEMs using gdalwarp."
 msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:5
@@ -4095,14 +3987,11 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:9
-msgid ""
-"List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate "
-"all bands"
+msgid "List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate all bands"
 msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:10
-msgid ""
-"Base name for output raster map (band number will be appended to base name)"
+msgid "Base name for output raster map (band number will be appended to base name)"
 msgstr ""
 #: ../locale/scriptstrings/r.in.srtm_to_translate.c:1
@@ -4172,10 +4061,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:15
-msgid ""
-"WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using "
-"native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS "
-"driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;"
+msgid "WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;"
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:17
@@ -4207,8 +4093,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:30
-msgid ""
-"Request data for this named region instead of the current region bounds"
+msgid "Request data for this named region instead of the current region bounds"
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:32
@@ -4226,9 +4111,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:35
-msgid ""
-"Capabilities file to parse (input). It is relevant for WMTS_GRASS and "
-"OnEarth_GRASS drivers"
+msgid "Capabilities file to parse (input). It is relevant for WMTS_GRASS and OnEarth_GRASS drivers"
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:36
@@ -4301,8 +4184,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
-msgid ""
-"Exports a raster map to a text file as x,y,z values based on cell centers."
+msgid "Exports a raster map to a text file as x,y,z values based on cell centers."
 msgstr ""
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
@@ -4339,9 +4221,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.plane_to_translate.c:1
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
+msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
 msgstr ""
 #: ../locale/scriptstrings/r.plane_to_translate.c:4
@@ -4365,9 +4245,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
+msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
 msgstr ""
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
@@ -4425,8 +4303,7 @@
 msgid "Name of shaded raster map"
 msgstr ""
-#: ../locale/scriptstrings/r.shade_to_translate.c:12
-#: ../raster/r.his/main.c:121
+#: ../locale/scriptstrings/r.shade_to_translate.c:12 ../raster/r.his/main.c:121
 msgid "Color to use instead of NULL values"
 msgstr ""
@@ -4434,15 +4311,12 @@
 msgid "Either a standard color name, R:G:B triplet, or \"none\""
 msgstr ""
-#: ../locale/scriptstrings/r.shade_to_translate.c:14
-#: ../raster/r.his/main.c:126
+#: ../locale/scriptstrings/r.shade_to_translate.c:14 ../raster/r.his/main.c:126
 msgid "Use colors from color tables for NULL values"
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:1
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
+msgid "Produces tilings of the source projection for use in the destination region and projection."
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:4
@@ -4454,8 +4328,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:6
-msgid ""
-"Name of region to use instead of current region for bounds and resolution"
+msgid "Name of region to use instead of current region for bounds and resolution"
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:7
@@ -4488,8 +4361,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.unpack_to_translate.c:1
-msgid ""
-"Imports a raster map as GRASS GIS specific archive file (packed with r.pack)"
+msgid "Imports a raster map as GRASS GIS specific archive file (packed with r.pack)"
 msgstr ""
 #: ../locale/scriptstrings/r.unpack_to_translate.c:5
@@ -4526,9 +4398,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:1
-msgid ""
-"Create a 3D raster map from an assemblage of many coordinates using "
-"univariate statistics"
+msgid "Create a 3D raster map from an assemblage of many coordinates using univariate statistics"
 msgstr ""
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:6
@@ -4611,9 +4481,7 @@
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:29
 #: ../raster/r.in.lidar/main.c:243 ../raster/r.in.xyz/main.c:321
-msgid ""
-"Discard <trim> percent of the smallest and <trim> percent of the largest "
-"observations"
+msgid "Discard <trim> percent of the smallest and <trim> percent of the largest observations"
 msgstr ""
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:31
@@ -4663,9 +4531,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
+msgid "Adds one or more columns to the attribute table connected to a given vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
@@ -4679,15 +4545,11 @@
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:11
-msgid ""
-"Types depend on database backend, but all support VARCHAR(), INT, DOUBLE "
-"PRECISION and DATE. Example: 'label varchar(250), value integer'"
+msgid "Types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE. Example: 'label varchar(250), value integer'"
 msgstr ""
-msgid ""
-"Creates and connects a new attribute table to a given layer of an existing "
-"vector map."
+msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
@@ -4748,8 +4610,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
+msgid "Drops a column from the attribute table connected to a given vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
@@ -4757,8 +4618,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.droprow_to_translate.c:1
-msgid ""
-"Removes a vector feature from a vector map through attribute selection."
+msgid "Removes a vector feature from a vector map through attribute selection."
 msgstr ""
 #: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
@@ -4774,8 +4634,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:1
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
+msgid "Renames a column in the attribute table connected to a given vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:5
@@ -4783,9 +4642,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
-msgid ""
-"Reconnects attribute tables for all vector maps from the current mapset to a"
-" new database."
+msgid "Reconnects attribute tables for all vector maps from the current mapset to a new database."
 msgstr ""
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
@@ -4817,9 +4674,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:1
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector"
-" map."
+msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.update_to_translate.c:1
@@ -4835,20 +4690,15 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.update_to_translate.c:7
-msgid ""
-"Name of other attribute column to query, can be combination of columns (e.g."
-" co1+col2)"
+msgid "Name of other attribute column to query, can be combination of columns (e.g. co1+col2)"
 msgstr ""
 #: ../locale/scriptstrings/v.db.update_to_translate.c:8
-msgid ""
-"Name of SQLite extension file for extra functions (SQLite backend only)"
+msgid "Name of SQLite extension file for extra functions (SQLite backend only)"
 msgstr ""
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:1
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number"
-" or attribute."
+msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
 msgstr ""
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:3
@@ -4875,9 +4725,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.import_to_translate.c:1
-msgid ""
-"Imports vector data into a GRASS vector map using OGR library and reprojects"
-" on the fly."
+msgid "Imports vector data into a GRASS vector map using OGR library and reprojects on the fly."
 msgstr ""
 #: ../locale/scriptstrings/v.import_to_translate.c:5
@@ -4905,8 +4753,7 @@
 #: ../locale/scriptstrings/v.import_to_translate.c:15
 #: ../vector/v.in.ogr/main.c:235
-msgid ""
-"Overrides encoding interpretation, useful when importing ESRI Shapefile"
+msgid "Overrides encoding interpretation, useful when importing ESRI Shapefile"
 msgstr ""
 #: ../locale/scriptstrings/v.import_to_translate.c:17
@@ -5029,9 +4876,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:8
-msgid ""
-"The given code must be supported by the server, consult the capabilities "
-"file"
+msgid "The given code must be supported by the server, consult the capabilities file"
 msgstr ""
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:9
@@ -5051,9 +4896,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:13
-msgid ""
-"Download server capabilities to 'wms_capabilities.xml' in the current "
-"directory and exit"
+msgid "Download server capabilities to 'wms_capabilities.xml' in the current directory and exit"
 msgstr ""
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:14
@@ -5061,9 +4904,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
-msgid ""
-"Calculates univariate statistics from a raster map based on a vector map and"
-" uploads statistics to new attribute columns."
+msgid "Calculates univariate statistics from a raster map based on a vector map and uploads statistics to new attribute columns."
 msgstr ""
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
@@ -5147,8 +4988,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.unpack_to_translate.c:1
-msgid ""
-"Imports a vector map as GRASS GIS specific archive file (packed with v.pack)"
+msgid "Imports a vector map as GRASS GIS specific archive file (packed with v.pack)"
 msgstr ""
 #: ../locale/scriptstrings/v.unpack_to_translate.c:6
@@ -5160,9 +5000,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.what.strds_to_translate.c:1
-msgid ""
-"Uploads space time raster dataset values at positions of vector points to "
-"the table."
+msgid "Uploads space time raster dataset values at positions of vector points to the table."
 msgstr ""
 #: ../locale/scriptstrings/v.what.strds_to_translate.c:5
@@ -5178,9 +5016,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.what.strds_to_translate.c:10
-msgid ""
-"Instead of creating a new vector map update the attribute table with "
-"value(s)"
+msgid "Instead of creating a new vector map update the attribute table with value(s)"
 msgstr ""
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:1
@@ -5317,21 +5153,15 @@
 msgstr ""
 #: ../locale/scriptstrings/t.support_to_translate.c:11
-msgid ""
-"Update the metadata information and spatial extent of registered maps from "
-"the GRASS spatial database"
+msgid "Update the metadata information and spatial extent of registered maps from the GRASS spatial database"
 msgstr ""
 #: ../locale/scriptstrings/t.support_to_translate.c:12
-msgid ""
-"Check for removed maps and delete them from the temporal database and all "
-"effected space time datasets"
+msgid "Check for removed maps and delete them from the temporal database and all effected space time datasets"
 msgstr ""
 #: ../locale/scriptstrings/t.support_to_translate.c:13
-msgid ""
-"Update metadata information, temporal and spatial extent from registered "
-"maps based on database entries."
+msgid "Update metadata information, temporal and spatial extent from registered maps based on database entries."
 msgstr ""
 #: ../locale/scriptstrings/t.topology_to_translate.c:1
@@ -5347,8 +5177,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.list_to_translate.c:1
-msgid ""
-"Lists space time datasets and maps registered in the temporal database."
+msgid "Lists space time datasets and maps registered in the temporal database."
 msgstr ""
 #: ../locale/scriptstrings/t.list_to_translate.c:4
@@ -5365,9 +5194,7 @@
 #: ../locale/scriptstrings/t.list_to_translate.c:9
 #: ../locale/scriptstrings/t.list_to_translate.c:12
-msgid ""
-"Columns number_of_maps and granularity only available for space time "
-"datasets"
+msgid "Columns number_of_maps and granularity only available for space time datasets"
 msgstr ""
 #: ../locale/scriptstrings/t.list_to_translate.c:10
@@ -5436,9 +5263,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.info_to_translate.c:10
-msgid ""
-"Print history information in human readable shell style for space time "
-"datasets"
+msgid "Print history information in human readable shell style for space time datasets"
 msgstr ""
 #: ../locale/scriptstrings/t.info_to_translate.c:11
@@ -5455,8 +5280,7 @@
 msgid "time management"
 msgstr ""
-#: ../locale/scriptstrings/t.merge_to_translate.c:4
-#: ../raster/r.patch/main.c:61
+#: ../locale/scriptstrings/t.merge_to_translate.c:4 ../raster/r.patch/main.c:61
 msgid "merge"
 msgstr ""
@@ -5483,9 +5307,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.remove_to_translate.c:12
-msgid ""
-"Remove all registered maps from the temporal and also from the spatial "
-"database"
+msgid "Remove all registered maps from the temporal and also from the spatial database"
 msgstr ""
 #: ../locale/scriptstrings/t.remove_to_translate.c:13
@@ -5493,9 +5315,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.sample_to_translate.c:1
-msgid ""
-"Samples the input space time dataset(s) with a sample space time dataset and"
-" print the result to stdout."
+msgid "Samples the input space time dataset(s) with a sample space time dataset and print the result to stdout."
 msgstr ""
 #: ../locale/scriptstrings/t.sample_to_translate.c:5
@@ -5511,9 +5331,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.sample_to_translate.c:10
-msgid ""
-"Do not use \",\" as this char is reserved to list several map ids in a "
-"sample granule"
+msgid "Do not use \",\" as this char is reserved to list several map ids in a sample granule"
 msgstr ""
 #: ../locale/scriptstrings/t.sample_to_translate.c:12
@@ -5521,9 +5339,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:1
-msgid ""
-"Assigns timestamps and registers raster, vector and raster3d maps in a space"
-" time dataset."
+msgid "Assigns timestamps and registers raster, vector and raster3d maps in a space time dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:4
@@ -5550,9 +5366,7 @@
 #: ../locale/scriptstrings/t.register_to_translate.c:14
 #: ../locale/scriptstrings/t.register_to_translate.c:17
-msgid ""
-"Format for absolute time: \"yyyy-mm-dd HH:MM:SS +HHMM\", relative time is of"
-" type integer."
+msgid "Format for absolute time: \"yyyy-mm-dd HH:MM:SS +HHMM\", relative time is of type integer."
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:15
@@ -5580,10 +5394,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:23
-msgid ""
-"Time increment between maps for creation of valid time intervals (format for"
-" absolute time: NNN seconds, minutes, hours, days, weeks, months, years; "
-"format for relative time is of type integer: 5)"
+msgid "Time increment between maps for creation of valid time intervals (format for absolute time: NNN seconds, minutes, hours, days, weeks, months, years; format for relative time is of type integer: 5)"
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:25
@@ -5591,15 +5402,11 @@
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:27
-msgid ""
-"Create an interval (start and end time) in case an increment and the start "
-"time are provided"
+msgid "Create an interval (start and end time) in case an increment and the start time are provided"
 msgstr ""
 #: ../locale/scriptstrings/t.unregister_to_translate.c:1
-msgid ""
-"Unregisters raster, vector and raster3d maps from the temporal database or a"
-" specific space time dataset."
+msgid "Unregisters raster, vector and raster3d maps from the temporal database or a specific space time dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.unregister_to_translate.c:4
@@ -5621,15 +5428,11 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:6
-msgid ""
-"Input space time raster dataset that defines the lower threshold, values "
-"lower this threshold are excluded from accumulation"
+msgid "Input space time raster dataset that defines the lower threshold, values lower this threshold are excluded from accumulation"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:7
-msgid ""
-"Input space time raster dataset that defines the upper threshold, values "
-"upper this threshold are excluded from accumulation"
+msgid "Input space time raster dataset that defines the upper threshold, values upper this threshold are excluded from accumulation"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:8
@@ -5691,9 +5494,7 @@
 #: ../locale/scriptstrings/t.vect.extract_to_translate.c:7
 #: ../locale/scriptstrings/t.vect.algebra_to_translate.c:8
 #: ../locale/scriptstrings/t.vect.import_to_translate.c:7
-msgid ""
-"A numerical suffix separated by an underscore will be attached to create a "
-"unique identifier"
+msgid "A numerical suffix separated by an underscore will be attached to create a unique identifier"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:15
@@ -5706,16 +5507,11 @@
 #: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:10
 #: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:9
 #: ../locale/scriptstrings/t.vect.extract_to_translate.c:8
-msgid ""
-"Suffix to add at basename: set 'gran' for granularity, 'time' for the full "
-"time format, 'num' for numerical suffix with a specific number of digits "
-"(default %05)"
+msgid "Suffix to add at basename: set 'gran' for granularity, 'time' for the full time format, 'num' for numerical suffix with a specific number of digits (default %05)"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:16
-msgid ""
-"Use these limits in case lower and/or upper input  space time raster "
-"datasets are not defined or contain NULL values"
+msgid "Use these limits in case lower and/or upper input  space time raster datasets are not defined or contain NULL values"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:17
@@ -5727,22 +5523,16 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:19
-msgid ""
-"This method will be applied to compute the accumulative values from the "
-"input maps in a single granule"
+msgid "This method will be applied to compute the accumulative values from the input maps in a single granule"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:20
-msgid ""
-"Growing Degree Days or Winkler indices; Mean: sum(input maps)/(number of "
-"input maps); Biologically Effective Degree Days; Huglin Heliothermal index"
+msgid "Growing Degree Days or Winkler indices; Mean: sum(input maps)/(number of input maps); Biologically Effective Degree Days; Huglin Heliothermal index"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:21
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:19
-msgid ""
-"Register empty maps in the output space time raster dataset, otherwise they "
-"will be deleted"
+msgid "Register empty maps in the output space time raster dataset, otherwise they will be deleted"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:22
@@ -5751,72 +5541,47 @@
 msgstr ""
-msgid ""
-"Detects accumulation patterns in temporally accumulated space time raster "
-"datasets created by t.rast.accumulate."
+msgid "Detects accumulation patterns in temporally accumulated space time raster datasets created by t.rast.accumulate."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:6
-msgid ""
-"Input space time raster dataset that specifies the minimum values to detect "
-"the accumulation pattern"
+msgid "Input space time raster dataset that specifies the minimum values to detect the accumulation pattern"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:7
-msgid ""
-"Input space time raster dataset that specifies the maximum values to detect "
+msgid "Input space time raster dataset that specifies the maximum values to detect the accumulation pattern"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:8
-msgid ""
-"The output space time raster dataset that stores the occurrence of the the "
-"accumulation pattern using the provided data range"
+msgid "The output space time raster dataset that stores the occurrence of the the accumulation pattern using the provided data range"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:9
-msgid ""
-"The output space time raster dataset that stores the indication of the "
-"start, intermediate and end of the specified data range"
+msgid "The output space time raster dataset that stores the indication of the start, intermediate and end of the specified data range"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:16
-msgid ""
-"time format, 'count' for numerical suffix with a specific number of digits "
-"(default %05)"
+msgid "Suffix to add at basename: set 'gran' for granularity, 'time' for the full time format, 'count' for numerical suffix with a specific number of digits (default %05)"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:17
-msgid ""
-"The minimum and maximum value of the occurrence of accumulated values, these"
-" values will be used if the min/max space time raster datasets are not "
-"specified"
+msgid "The minimum and maximum value of the occurrence of accumulated values, these values will be used if the min/max space time raster datasets are not specified"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:18
-msgid ""
-"The user defined values that indicate start, intermediate and end status in "
-"the indicator output space time raster dataset"
+msgid "The user defined values that indicate start, intermediate and end status in the indicator output space time raster dataset"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:1
-msgid ""
-"Aggregates temporally the maps of a space time raster dataset by a user "
-"defined granularity."
+msgid "Aggregates temporally the maps of a space time raster dataset by a user defined granularity."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:7
-msgid ""
-"Either a numerical suffix or the start time (s-flag) separated by an "
-"underscore will be attached to create a unique identifier"
+msgid "Either a numerical suffix or the start time (s-flag) separated by an underscore will be attached to create a unique identifier"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:9
-msgid ""
-"Aggregation granularity, format absolute time \"x years, x months, x weeks, "
-"x days, x hours, x minutes, x seconds\" or an integer value for relative "
-"time"
+msgid "Aggregation granularity, format absolute time \"x years, x months, x weeks, x days, x hours, x minutes, x seconds\" or an integer value for relative time"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:10
@@ -5829,9 +5594,7 @@
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:11
 #: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:12
-msgid ""
-"Offset that is used to create the output map ids, output map id is generated"
-" as: basename_ (count + offset)"
+msgid "Offset that is used to create the output map ids, output map id is generated as: basename_ (count + offset)"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:12
@@ -5855,15 +5618,11 @@
 msgstr ""
-msgid ""
-"Aggregates data of an existing space time raster dataset using the time "
-"intervals of a second space time dataset."
+msgid "Aggregates data of an existing space time raster dataset using the time intervals of a second space time dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:6
-msgid ""
-"Time intervals from this space time dataset (raster, vector or raster3d) are"
-" used for aggregation computation"
+msgid "Time intervals from this space time dataset (raster, vector or raster3d) are used for aggregation computation"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:7
@@ -5878,9 +5637,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.colors_to_translate.c:1
-msgid ""
-"Creates/modifies the color table associated with each raster map of the "
-"space time raster dataset."
+msgid "Creates/modifies the color table associated with each raster map of the space time raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.colors_to_translate.c:6
@@ -5959,9 +5716,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:1
-msgid ""
-"Produces a space time vector dataset of specified contours from a space time"
-" raster dataset."
+msgid "Produces a space time vector dataset of specified contours from a space time raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:3
@@ -5994,9 +5749,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:15
-msgid ""
-"Number of r.contour processes to run in parallel, more than 1 process works "
-"only in conjunction with flag -t"
+msgid "Number of r.contour processes to run in parallel, more than 1 process works only in conjunction with flag -t"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:16
@@ -6014,9 +5767,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.univar_to_translate.c:1
-msgid ""
-"Calculates univariate statistics from the non-null cells for each registered"
-" raster map of a space time raster dataset."
+msgid "Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.univar_to_translate.c:9
@@ -6028,9 +5779,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.univar_to_translate.c:10
-msgid ""
-"Ignore the current region settings and use the raster map regions for univar"
-" statistical calculation"
+msgid "Ignore the current region settings and use the raster map regions for univar statistical calculation"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.univar_to_translate.c:11
@@ -6053,15 +5802,11 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.list_to_translate.c:13
-msgid ""
-"The granule to be used for listing. The granule must be specified as string "
-"eg.: absolute time \"1 months\" or relative time \"1\""
+msgid "The granule to be used for listing. The granule must be specified as string eg.: absolute time \"1 months\" or relative time \"1\""
 msgstr ""
 #: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:1
-msgid ""
-"Performs spatio-temporal mapcalc expressions on temporally sampled maps of "
-"space time raster datasets."
+msgid "Performs spatio-temporal mapcalc expressions on temporally sampled maps of space time raster datasets."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:6
@@ -6078,21 +5823,15 @@
 #: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:12
 #: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:11
 #: ../locale/scriptstrings/t.vect.algebra_to_translate.c:9
-msgid ""
-"Check the spatial topology of temporally related maps and process only "
-"spatially related maps"
+msgid "Check the spatial topology of temporally related maps and process only spatially related maps"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.algebra_to_translate.c:1
-msgid ""
-"Apply temporal and spatial operations on space time raster datasets using "
-"temporal raster algebra."
+msgid "Apply temporal and spatial operations on space time raster datasets using temporal raster algebra."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.algebra_to_translate.c:6
-msgid ""
-"r.mapcalc expression for temporal and spatial analysis of space time raster "
-"datasets"
+msgid "r.mapcalc expression for temporal and spatial analysis of space time raster datasets"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.algebra_to_translate.c:12
@@ -6102,15 +5841,11 @@
 #: ../locale/scriptstrings/t.rast.algebra_to_translate.c:13
 #: ../locale/scriptstrings/t.select_to_translate.c:9
-msgid ""
-"Perform a dry run, compute all dependencies and module calls but don't run "
-"them"
+msgid "Perform a dry run, compute all dependencies and module calls but don't run them"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:1
-msgid ""
-"Performs a neighborhood analysis for each map in a space time raster "
-"dataset."
+msgid "Performs a neighborhood analysis for each map in a space time raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:6
@@ -6127,9 +5862,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.series_to_translate.c:1
-msgid ""
-"Performs different aggregation algorithms from r.series on all or a subset "
-"of raster maps in a space time raster dataset."
+msgid "Performs different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.series_to_translate.c:4
@@ -6144,15 +5877,12 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.series_to_translate.c:9
-msgid ""
-"Do not assign the space time raster dataset start and end time to the output"
-" map"
+msgid "Do not assign the space time raster dataset start and end time to the output map"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.series_to_translate.c:10
 #: ../raster/r.resamp.filter/main.c:431 ../raster/r.series/main.c:187
-#: ../raster/r.series.accumulate/main.c:159
-#: ../raster/r.resamp.stats/main.c:288
+#: ../raster/r.series.accumulate/main.c:159 ../raster/r.resamp.stats/main.c:288
 msgid "Propagate NULLs"
 msgstr ""
@@ -6179,9 +5909,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.export_to_translate.c:10
-msgid ""
-"Supported are GTiff, AAIGrid via r.out.gdal and the GRASS package format of "
-"r.pack"
+msgid "Supported are GTiff, AAIGrid via r.out.gdal and the GRASS package format of r.pack"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.export_to_translate.c:11
@@ -6212,9 +5940,7 @@
 #: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:9
 #: ../raster/r.out.vtk/parameters.c:59
-msgid ""
-"Create VTK point data instead of VTK cell data (if no elevation map is "
-"given)"
+msgid "Create VTK point data instead of VTK cell data (if no elevation map is given)"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:10
@@ -6223,9 +5949,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:11
-msgid ""
-"Export files using the space time dataset granularity for equidistant time "
-"between maps, where statement will be ignored"
+msgid "Export files using the space time dataset granularity for equidistant time between maps, where statement will be ignored"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:1
@@ -6239,9 +5963,7 @@
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:11
 #: ../locale/scriptstrings/t.vect.import_to_translate.c:11
-msgid ""
-"Create a new location and import the data into it. Do not run this module in"
-" parallel or interrupt it when a new location should be created"
+msgid "Create a new location and import the data into it. Do not run this module in parallel or interrupt it when a new location should be created"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:14
@@ -6258,14 +5980,11 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:19
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not"
-" import the space time raster datasets."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the space time raster datasets."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:1
-msgid ""
-"Replaces gaps in a space time raster dataset with interpolated raster maps."
+msgid "Replaces gaps in a space time raster dataset with interpolated raster maps."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:9
@@ -6273,8 +5992,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:10
-msgid ""
-"Assign the space time raster dataset start and end time to the output map"
+msgid "Assign the space time raster dataset start and end time to the output map"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.extract_to_translate.c:1
@@ -6308,9 +6026,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:12
-msgid ""
-"Number of r.to.vect processes to run in parallel, more than 1 process works "
+msgid "Number of r.to.vect processes to run in parallel, more than 1 process works only in conjunction with flag -t"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:15
@@ -6344,9 +6060,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:1
-msgid ""
-"Sample a space time raster dataset at specific vector point coordinates and "
-"write the output to stdout using different layouts"
+msgid "Sample a space time raster dataset at specific vector point coordinates and write the output to stdout using different layouts"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:6
@@ -6358,9 +6072,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:9
-msgid ""
-"The layout of the output. One point per row (row), one point per column "
-"(col), all timsteps in one row (timerow)"
+msgid "The layout of the output. One point per row (row), one point per column (col), all timsteps in one row (timerow)"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:10
@@ -6403,9 +6115,7 @@
 msgstr ""
-msgid ""
-"Performs r3.mapcalc expressions on maps of sampled space time 3D raster "
-"datasets."
+msgid "Performs r3.mapcalc expressions on maps of sampled space time 3D raster datasets."
 msgstr ""
 #: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:7
@@ -6413,21 +6123,15 @@
 msgstr ""
-msgid ""
-"Apply temporal and spatial operations on space time 3D raster datasets using"
-" temporal 3D raster algebra."
+msgid "Apply temporal and spatial operations on space time 3D raster datasets using temporal 3D raster algebra."
 msgstr ""
 #: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:7
-msgid ""
-"Algebraic expression for temporal and spatial analysis of space time 3D "
-"raster datasets"
+msgid "Algebraic expression for temporal and spatial analysis of space time 3D raster datasets"
 msgstr ""
 #: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:1
-msgid ""
-" 3D raster map of a space time 3D raster dataset."
+msgid "Calculates univariate statistics from the non-null cells for each registered 3D raster map of a space time 3D raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rename_to_translate.c:1
@@ -6440,9 +6144,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.select_to_translate.c:1
-msgid ""
-"Select maps from space time datasets by topological relationships to other "
-"space time datasets using temporal algebra."
+msgid "Select maps from space time datasets by topological relationships to other space time datasets using temporal algebra."
 msgstr ""
 #: ../locale/scriptstrings/t.select_to_translate.c:7
@@ -6450,9 +6152,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.select_to_translate.c:8
-msgid ""
-"Check the spatial topology of temporally related maps and select only "
+msgid "Check the spatial topology of temporally related maps and select only spatially related maps"
 msgstr ""
 #: ../locale/scriptstrings/t.snap_to_translate.c:1
@@ -6481,9 +6181,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.shift_to_translate.c:10
-msgid ""
-"Format absolute time: \"x years, x months, x weeks, x days, x hours, x "
-"minutes, x seconds\", relative time is of type integer"
+msgid "Format absolute time: \"x years, x months, x weeks, x days, x hours, x minutes, x seconds\", relative time is of type integer"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.list_to_translate.c:1
@@ -6491,8 +6189,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.vect.db.select_to_translate.c:1
-msgid ""
-"Prints attributes of vector maps registered in a space time vector dataset."
+msgid "Prints attributes of vector maps registered in a space time vector dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.db.select_to_translate.c:6
@@ -6502,8 +6199,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.vect.export_to_translate.c:1
-msgid ""
-"Exports a space time vector dataset as GRASS GIS specific archive file."
+msgid "Exports a space time vector dataset as GRASS GIS specific archive file."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.export_to_translate.c:6
@@ -6523,9 +6219,7 @@
 msgstr ""
 #: ../locale/scriptstrings/t.vect.extract_to_translate.c:9
-msgid ""
-"The number of v.extract processes to run in parallel. Use only if database "
-"backend is used which supports concurrent writing"
+msgid "The number of v.extract processes to run in parallel. Use only if database backend is used which supports concurrent writing"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.extract_to_translate.c:10
@@ -6533,62 +6227,43 @@
 msgstr ""
 #: ../locale/scriptstrings/t.vect.algebra_to_translate.c:1
-msgid ""
-"Apply temporal and spatial operations on space time vector datasets using "
-"temporal vector algebra."
+msgid "Apply temporal and spatial operations on space time vector datasets using temporal vector algebra."
 msgstr ""
-msgid ""
-"Imports a space time vector dataset from a GRASS GIS specific archive file."
+msgid "Imports a space time vector dataset from a GRASS GIS specific archive file."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.import_to_translate.c:15
-msgid ""
-" import the space time vector datasets."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the space time vector datasets."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:1
-msgid ""
-"Stores raster map values at spatial and temporal positions of vector points "
-"as vector attributes."
+msgid "Stores raster map values at spatial and temporal positions of vector points as vector attributes."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:6
-msgid ""
-"Name of the vector column to be created and to store sampled raster values"
+msgid "Name of the vector column to be created and to store sampled raster values"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:7
-msgid ""
-"The use of a column name forces t.vect.what.rast to sample only values from "
-"the first map found in an interval. Otherwise the raster map names are used "
-"as column names"
+msgid "The use of a column name forces t.vect.what.rast to sample only values from the first map found in an interval. Otherwise the raster map names are used as column names"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:1
-msgid ""
-"Observes specific locations in a space time raster dataset over a period of "
-"time using vector points."
+msgid "Observes specific locations in a space time raster dataset over a period of time using vector points."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:6
-msgid ""
-"Name of the new created vector map that stores the sampled values in "
-"different layers"
+msgid "Name of the new created vector map that stores the sampled values in different layers"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:7
-msgid ""
-"Names of the vector columns to be created and to store sampled raster "
-"values, one name for each STRDS"
+msgid "Names of the vector columns to be created and to store sampled raster values, one name for each STRDS"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.univar_to_translate.c:1
-msgid ""
-"Calculates univariate statistics of attributes for each registered vector "
-"map of a space time vector dataset"
+msgid "Calculates univariate statistics of attributes for each registered vector map of a space time vector dataset"
 msgstr ""
 #: ../general/g.region/printwindow.c:236 ../general/g.region/printwindow.c:492
@@ -6631,15 +6306,11 @@
 msgstr ""
 #: ../general/g.region/printwindow.c:401
-msgid ""
-"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
-"the -p flag instead."
+msgid "You are in a simple XY location, projection to Lat/Lon is not possible. Use the -p flag instead."
 msgstr ""
 #: ../general/g.region/printwindow.c:626
-msgid ""
-"WGS84 output not possible as this location does not contain datum "
-"transformation parameters. Try running g.setproj."
+msgid "WGS84 output not possible as this location does not contain datum transformation parameters. Try running g.setproj."
 msgstr ""
 #: ../general/g.region/printwindow.c:772
@@ -6723,9 +6394,7 @@
 msgstr ""
 #: ../general/g.region/main.c:129
-msgid ""
-"The difference between the projection's grid north and true north, measured "
-"at the center coordinates of the current region."
+msgid "The difference between the projection's grid north and true north, measured at the center coordinates of the current region."
 msgstr ""
 #: ../general/g.region/main.c:135
@@ -6737,9 +6406,7 @@
 msgstr ""
 #: ../general/g.region/main.c:152
-msgid ""
-"Align region to resolution (default = align to bounds, works only for 2D "
-"resolution)"
+msgid "Align region to resolution (default = align to bounds, works only for 2D resolution)"
 msgstr ""
 #: ../general/g.region/main.c:158
@@ -6848,8 +6515,7 @@
 #: ../general/g.region/main.c:797 ../vector/v.vol.rst/main.c:615
 #: ../vector/v.colors/main.c:312 ../doc/raster/r.example/main.c:105
 #: ../imagery/i.gensigset/parse.c:44 ../imagery/i.gensig/parse.c:38
-#: ../imagery/i.pca/main.c:139
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:155
+#: ../imagery/i.pca/main.c:139 ../imagery/i.ortho.photo/i.ortho.elev/main.c:155
 #: ../misc/m.nviz.image/surface.c:50 ../misc/m.nviz.image/surface.c:107
 #: ../raster/r.walk/main.c:435 ../raster/r.walk/main.c:440
 #: ../raster/r.walk/main.c:801 ../raster/r.category/main.c:119
@@ -6941,8 +6607,7 @@
 msgstr ""
 #: ../general/g.region/main.c:821
-msgid ""
-"Unable to change default region. The current mapset is not <PERMANENT>."
+msgid "Unable to change default region. The current mapset is not <PERMANENT>."
 msgstr ""
 #: ../general/g.region/main.c:838 ../raster/r.in.lidar/main.c:519
@@ -6967,9 +6632,7 @@
 msgstr ""
 #: ../general/g.mapsets/main.c:67
-msgid ""
-"Affects the user's access to data existing under the other mapsets in the "
-"current location."
+msgid "Affects the user's access to data existing under the other mapsets in the current location."
 msgstr ""
 #: ../general/g.mapsets/main.c:73
@@ -7066,9 +6729,7 @@
 msgstr ""
 #: ../general/g.remove/main.c:73
-msgid ""
-"Removes data base element files from the user's current mapset using the "
-"search pattern."
+msgid "Removes data base element files from the user's current mapset using the search pattern."
 msgstr ""
 #: ../general/g.remove/main.c:83 ../general/g.remove/main.c:91
@@ -7134,9 +6795,7 @@
 #: ../general/g.remove/main.c:267
 #, c-format
-msgid ""
-"Nothing removed. You must use the force flag (-%c) to actually remove them. "
-"Exiting."
+msgid "Nothing removed. You must use the force flag (-%c) to actually remove them. Exiting."
 msgstr ""
 #: ../general/g.remove/construct_pattern.c:37
@@ -7170,8 +6829,7 @@
 msgstr ""
 #: ../general/g.message/main.c:37
-msgid ""
-"Prints a message, warning, progress info, or fatal error in the GRASS way."
+msgid "Prints a message, warning, progress info, or fatal error in the GRASS way."
 msgstr ""
 #: ../general/g.message/main.c:39
@@ -7246,9 +6904,7 @@
 msgstr ""
 #: ../general/g.mkfontcap/main.c:73
-msgid ""
-"Generates the font configuration file by scanning various directories for "
-"fonts."
+msgid "Generates the font configuration file by scanning various directories for fonts."
 msgstr ""
 #: ../general/g.mkfontcap/main.c:79
@@ -7256,8 +6912,7 @@
 msgstr ""
 #: ../general/g.mkfontcap/main.c:84
-msgid ""
-"Write font configuration file to standard output instead of $GISBASE/etc"
+msgid "Write font configuration file to standard output instead of $GISBASE/etc"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:91
@@ -7265,21 +6920,16 @@
 msgstr ""
 #: ../general/g.mkfontcap/main.c:93
-msgid ""
-"Comma-separated list of extra directories to scan for Freetype-compatible "
-"fonts as well as the defaults (see documentation)"
+msgid "Comma-separated list of extra directories to scan for Freetype-compatible fonts as well as the defaults (see documentation)"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:110
 #, c-format
-msgid ""
-"Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
+msgid "Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:122
-msgid ""
-"This GRASS installation was compiled without Freetype support, extradirs "
-"parameter ignored"
+msgid "This GRASS installation was compiled without Freetype support, extradirs parameter ignored"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:149
@@ -7317,9 +6967,7 @@
 #: ../general/g.findfile/main.c:97
 #, c-format
-msgid ""
-"Parameter 'file' contains reference to <%s> mapset, but mapset parameter "
-"<%s> does not correspond"
+msgid "Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%s> does not correspond"
 msgstr ""
 #: ../general/g.gisenv/main.c:45
@@ -7721,9 +7369,7 @@
 msgstr ""
 #: ../general/g.list/main.c:69
-msgid ""
-"Lists available GRASS data base files of the user-specified data type "
-"optionally using the search pattern."
+msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
 msgstr ""
 #: ../general/g.list/main.c:85
@@ -7825,10 +7471,7 @@
 msgstr ""
 #: ../general/g.gui/main.c:72
-msgid ""
-"By default the GUI starts in the background and control is immediately "
-"returned to the caller. When GUI runs in foregreound, it blocks the command "
-"line"
+msgid "By default the GUI starts in the background and control is immediately returned to the caller. When GUI runs in foregreound, it blocks the command line"
 msgstr ""
 #: ../general/g.gui/main.c:78
@@ -8014,10 +7657,7 @@
 msgstr ""
 #: ../general/g.setproj/main.c:456
-msgid ""
-"But if you change zone, all the existing data will be interpreted by "
-"projection software. GRASS will not automatically re-project or even change "
-"the headers for existing maps."
+msgid "But if you change zone, all the existing data will be interpreted by projection software. GRASS will not automatically re-project or even change the headers for existing maps."
 msgstr ""
 #: ../general/g.setproj/main.c:461
@@ -8148,9 +7788,7 @@
 msgstr ""
 #: ../general/g.copy/main.c:44
-msgid ""
-"Copies available data files in the current mapset search path to the user's "
-"current mapset."
+msgid "Copies available data files in the current mapset search path to the user's current mapset."
 msgstr ""
 #: ../general/g.copy/main.c:51
@@ -8246,16 +7884,11 @@
 #: ../general/g.proj/create.c:40
 #, c-format
-msgid ""
-"You must select the PERMANENT mapset before updating the current location's "
-"projection (current mapset is <%s>)"
+msgid "You must select the PERMANENT mapset before updating the current location's projection (current mapset is <%s>)"
 msgstr ""
 #: ../general/g.proj/create.c:66
-msgid ""
-"Default region was updated to the new projection, but if you have multiple "
-"mapsets `g.region -d` should be run in each to update the region from the "
-"default"
+msgid "Default region was updated to the new projection, but if you have multiple mapsets `g.region -d` should be run in each to update the region from the default"
 msgstr ""
 #: ../general/g.proj/create.c:70
@@ -8272,9 +7905,7 @@
 msgstr ""
 #: ../general/g.proj/main.c:69
-msgid ""
-"Prints or modifies GRASS projection information files (in various co-"
-"ordinate system descriptions)."
+msgid "Prints or modifies GRASS projection information files (in various co-ordinate system descriptions)."
 msgstr ""
 #: ../general/g.proj/main.c:72
@@ -8302,8 +7933,7 @@
 msgstr ""
 #: ../general/g.proj/main.c:106
-msgid ""
-"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
+msgid "Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
 msgstr ""
 #: ../general/g.proj/main.c:116
@@ -8349,9 +7979,7 @@
 msgstr ""
 #: ../general/g.proj/main.c:188
-msgid ""
-"Force override of datum transformation information in input co-ordinate "
-"system"
+msgid "Force override of datum transformation information in input co-ordinate system"
 msgstr ""
 #: ../general/g.proj/main.c:193 ../raster/r.null/main.c:74
@@ -8427,9 +8055,7 @@
 #: ../general/g.proj/input.c:259
 #, c-format
-msgid ""
-"Read of file %s was successful, but it did not contain projection "
-"information. 'XY (unprojected)' will be used"
+msgid "Read of file %s was successful, but it did not contain projection information. 'XY (unprojected)' will be used"
 msgstr ""
 #: ../general/g.proj/output.c:146
@@ -8505,15 +8131,11 @@
 #: ../general/g.version/main.c:172
 #, c-format
-msgid ""
-"Cannot determine GRASS libgis version and date number. The GRASS build might"
-" be broken. Report this to developers or packagers.\n"
+msgid "Cannot determine GRASS libgis version and date number. The GRASS build might be broken. Report this to developers or packagers.\n"
 msgstr ""
 #: ../general/g.version/main.c:179
-msgid ""
-"GRASS GIS libgis version and date number don't have the expected format. "
-"Trying to print the original strings..."
+msgid "GRASS GIS libgis version and date number don't have the expected format. Trying to print the original strings..."
 msgstr ""
 #: ../general/g.version/main.c:181
@@ -8543,8 +8165,7 @@
 msgstr ""
 #: ../general/g.mapset/main.c:52
-msgid ""
-"Optionally create new mapset or list available mapsets in given location."
+msgid "Optionally create new mapset or list available mapsets in given location."
 msgstr ""
 #: ../general/g.mapset/main.c:56
@@ -8607,8 +8228,7 @@
 msgstr ""
 #: ../general/g.mapset/main.c:205
-msgid ""
-"Mapset switched. Your shell continues to use the history for the old mapset"
+msgid "Mapset switched. Your shell continues to use the history for the old mapset"
 msgstr ""
 #: ../general/g.mapset/main.c:210
@@ -8726,9 +8346,7 @@
 msgstr ""
 #: ../vector/v.extract/extract.c:228
-msgid ""
-"Topology level required for extracting areas for OGR layers. Areas will be "
-"not processed."
+msgid "Topology level required for extracting areas for OGR layers. Areas will be not processed."
 msgstr ""
 #: ../vector/v.extract/main.c:81 ../vector/v.perturb/main.c:65
@@ -8739,9 +8357,7 @@
 msgstr ""
 #: ../vector/v.extract/main.c:83
-msgid ""
-"Selects vector features from an existing vector map and creates a new vector"
-" map containing only the selected features."
+msgid "Selects vector features from an existing vector map and creates a new vector map containing only the selected features."
 msgstr ""
 #: ../vector/v.extract/main.c:88
@@ -8798,9 +8414,7 @@
 #: ../vector/v.extract/main.c:161
 #, c-format
-msgid ""
-"Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only"
-" one of them."
+msgid "Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only one of them."
 msgstr ""
 #: ../vector/v.extract/main.c:208
@@ -8852,9 +8466,7 @@
 msgstr[2] ""
 #: ../vector/v.extract/main.c:286
-msgid ""
-"This map has no categories attached. Use v.category to attach categories to "
-"this vector map."
+msgid "This map has no categories attached. Use v.category to attach categories to this vector map."
 msgstr ""
 #: ../vector/v.extract/main.c:293
@@ -8863,16 +8475,12 @@
 #: ../vector/v.extract/main.c:297
 #, c-format
-msgid ""
-"Random category count must be smaller than feature count. There are only %d "
-"features of type(s): %s"
+msgid "Random category count must be smaller than feature count. There are only %d features of type(s): %s"
 msgstr ""
 #: ../vector/v.extract/main.c:320
 #, c-format
-msgid ""
-"Random category count is larger or equal to uniq <%s> feature category count"
-" %d"
+msgid "Random category count is larger or equal to uniq <%s> feature category count %d"
 msgstr ""
 #: ../vector/v.extract/main.c:354
@@ -8921,10 +8529,10 @@
 msgstr ""
 #: ../vector/v.generalize/network.c:89 ../vector/v.net.spanningtree/main.c:124
-#: ../vector/v.net.timetable/main.c:405
-#: ../vector/v.net.connectivity/main.c:178 ../vector/v.net.flow/main.c:226
-#: ../vector/v.net.centrality/main.c:284 ../vector/v.net.distance/main.c:264
-#: ../vector/v.net.bridge/main.c:134 ../vector/v.net.components/main.c:163
+#: ../vector/v.net.timetable/main.c:405 ../vector/v.net.connectivity/main.c:178
+#: ../vector/v.net.flow/main.c:226 ../vector/v.net.centrality/main.c:284
+#: ../vector/v.net.distance/main.c:264 ../vector/v.net.bridge/main.c:134
+#: ../vector/v.net.components/main.c:163
 #, c-format
 msgid "Unable to build graph for vector map <%s>"
 msgstr ""
@@ -8975,9 +8583,7 @@
 msgstr ""
 #: ../vector/v.generalize/main.c:102
-msgid ""
-"Lines and boundaries causing errors (collapsed to a point or topology "
-"errors)"
+msgid "Lines and boundaries causing errors (collapsed to a point or topology errors)"
 msgstr ""
 #: ../vector/v.generalize/main.c:126
@@ -9045,8 +8651,7 @@
 msgstr ""
 #: ../vector/v.generalize/main.c:164
-msgid ""
-"Percentage of the points in the output of 'douglas_reduction' algorithm"
+msgid "Percentage of the points in the output of 'douglas_reduction' algorithm"
 msgstr ""
 #: ../vector/v.generalize/main.c:173
@@ -9146,8 +8751,7 @@
 #: ../vector/v.generalize/main.c:567
 #, c-format
-msgid ""
-"%d boundaries were not modified because modification would damage topology"
+msgid "%d boundaries were not modified because modification would damage topology"
 msgstr ""
 #: ../vector/v.generalize/main.c:570
@@ -9157,8 +8761,7 @@
 #: ../vector/v.generalize/main.c:591
 #, c-format
-msgid ""
-"Number of vertices for selected features %s from %d to %d (%d%% remaining)"
+msgid "Number of vertices for selected features %s from %d to %d (%d%% remaining)"
 msgstr ""
 #: ../vector/v.generalize/main.c:592
@@ -9219,8 +8822,7 @@
 msgstr ""
 #: ../vector/v.net/args.c:42
-msgid ""
-"connect still unconnected points to vector network by inserting new line(s)"
+msgid "connect still unconnected points to vector network by inserting new line(s)"
 msgstr ""
 #: ../vector/v.net/args.c:44
@@ -9228,14 +8830,11 @@
 msgstr ""
 #: ../vector/v.net/args.c:46
-msgid ""
-"print to standard output {line_category start_point_category "
-"end_point_category}"
+msgid "print to standard output {line_category start_point_category end_point_category}"
 msgstr ""
 #: ../vector/v.net/args.c:48
-msgid ""
-"print to standard output {point_category line_category[,line_category...]}"
+msgid "print to standard output {point_category line_category[,line_category...]}"
 msgstr ""
 #: ../vector/v.net/args.c:50
@@ -9306,9 +8905,7 @@
 msgstr ""
 #: ../vector/v.net/args.c:99
-msgid ""
-"For operation 'connect'. By default, a new line from the point to the "
-"network is created."
+msgid "For operation 'connect'. By default, a new line from the point to the network is created."
 msgstr ""
 #: ../vector/v.net/args.c:103
@@ -9316,9 +8913,7 @@
 msgstr ""
 #: ../vector/v.net/args.c:106
-msgid ""
-"Layer where turntable will be attached. Format: layer number[/layer "
-"name].Required for operation 'turntable'."
+msgid "Layer where turntable will be attached. Format: layer number[/layer name].Required for operation 'turntable'."
 msgstr ""
 #: ../vector/v.net/args.c:114 ../vector/v.net.alloc/main.c:143
@@ -9328,10 +8923,7 @@
 msgstr ""
 #: ../vector/v.net/args.c:117
-msgid ""
-"Layer with unique categories for every line in arc_layer and point on every "
-"node.  The categories are used in turntable. Format: layer number[/layer "
-"name]. Required for operation 'turntable'."
+msgid "Layer with unique categories for every line in arc_layer and point on every node.  The categories are used in turntable. Format: layer number[/layer name]. Required for operation 'turntable'."
 msgstr ""
 #: ../vector/v.net/args.c:146
@@ -9513,9 +9105,7 @@
 msgstr ""
 #: ../vector/v.voronoi/main.c:127
-msgid ""
-"Creates a Voronoi diagram in current region from an input vector map "
-"containing points or centroids."
+msgid "Creates a Voronoi diagram in current region from an input vector map containing points or centroids."
 msgstr ""
 #: ../vector/v.voronoi/main.c:131 ../vector/v.sample/main.c:82
@@ -9528,9 +9118,7 @@
 msgstr ""
 #: ../vector/v.voronoi/main.c:142
-msgid ""
-"Applies to input areas only. Smaller values produce smoother output but can "
-"cause numerical instability."
+msgid "Applies to input areas only. Smaller values produce smoother output but can cause numerical instability."
 msgstr ""
 #: ../vector/v.voronoi/main.c:149
@@ -9538,9 +9126,7 @@
 msgstr ""
 #: ../vector/v.voronoi/main.c:150
-msgid ""
-"Applies only to skeleton extraction. Default = -1 will extract the center "
-"line."
+msgid "Applies only to skeleton extraction. Default = -1 will extract the center line."
 msgstr ""
 #: ../vector/v.voronoi/main.c:156
@@ -9629,9 +9215,7 @@
 msgstr[2] ""
 #: ../vector/v.distance/main.c:95
-msgid ""
-"Finds the nearest element in vector map 'to' for elements in vector map "
-"'from'."
+msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
 msgstr ""
 #: ../vector/v.distance/main.c:99
@@ -9673,8 +9257,7 @@
 msgstr ""
 #: ../vector/v.distance/main.c:134
-msgid ""
-"Name for output vector map containing lines connecting nearest elements"
+msgid "Name for output vector map containing lines connecting nearest elements"
 msgstr ""
 #: ../vector/v.distance/main.c:142
@@ -9706,14 +9289,11 @@
 msgstr ""
 #: ../vector/v.distance/main.c:173
-msgid ""
-"distance to the nearest point on the 'to' feature along that linear feature"
+msgid "distance to the nearest point on the 'to' feature along that linear feature"
 msgstr ""
 #: ../vector/v.distance/main.c:175
-msgid ""
-"angle along the nearest linear feature in the 'to' map, measured CCW from "
-"the +x axis, in radians, between -Pi and Pi inclusive"
+msgid "angle along the nearest linear feature in the 'to' map, measured CCW from the +x axis, in radians, between -Pi and Pi inclusive"
 msgstr ""
 #: ../vector/v.distance/main.c:178
@@ -9721,8 +9301,7 @@
 msgstr ""
 #: ../vector/v.distance/main.c:191
-msgid ""
-"Column name(s) where values specified by 'upload' option will be uploaded"
+msgid "Column name(s) where values specified by 'upload' option will be uploaded"
 msgstr ""
 #: ../vector/v.distance/main.c:197
@@ -9750,9 +9329,7 @@
 msgstr ""
 #: ../vector/v.distance/main.c:220
-msgid ""
-"Output is written to stdout but may be uploaded to a new table created by "
-"this module; multiple 'upload' options may be used."
+msgid "Output is written to stdout but may be uploaded to a new table created by this module; multiple 'upload' options may be used."
 msgstr ""
 #: ../vector/v.distance/main.c:284
@@ -10027,8 +9604,7 @@
 msgstr ""
 #: ../vector/v.edit/args.c:154
-msgid ""
-"For 'shorter' use negative threshold value, positive value for 'longer'"
+msgid "For 'shorter' use negative threshold value, positive value for 'longer'"
 msgstr ""
 #: ../vector/v.edit/args.c:160
@@ -10044,9 +9620,7 @@
 msgstr ""
 #: ../vector/v.edit/args.c:176
-msgid ""
-"Snap added or modified features in the given threshold to the nearest "
-"existing feature"
+msgid "Snap added or modified features in the given threshold to the nearest existing feature"
 msgstr ""
 #: ../vector/v.edit/args.c:182
@@ -10120,9 +9694,7 @@
 msgstr ""
 #: ../vector/v.edit/main.c:63
-msgid ""
-"Edits a vector map, allows adding, deleting and modifying selected vector "
-"features."
+msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
 msgstr ""
 #: ../vector/v.edit/main.c:72
@@ -10142,16 +9714,12 @@
 #: ../vector/v.edit/main.c:140
 #, c-format
-msgid ""
-"Unable to open vector map <%s> on topological level. Try to rebuild vector "
-"topology by v.build."
+msgid "Unable to open vector map <%s> on topological level. Try to rebuild vector topology by v.build."
 msgstr ""
 #: ../vector/v.edit/main.c:160
 #, c-format
-msgid ""
-"Unable to open vector map <%s> as the background map. It is given as vector "
-"map to be edited."
+msgid "Unable to open vector map <%s> as the background map. It is given as vector map to be edited."
 msgstr ""
 #: ../vector/v.edit/main.c:171
@@ -10173,9 +9741,7 @@
 #: ../vector/v.edit/main.c:234
 #, c-format
-msgid ""
-"Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert "
-"the vector map to 3D using e.g. %s."
+msgid "Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert the vector map to 3D using e.g. %s."
 msgstr ""
 #: ../vector/v.edit/main.c:276
@@ -10275,9 +9841,7 @@
 #: ../vector/v.edit/main.c:387
 #, c-format
-msgid ""
-"Multiple background maps were given. Selected features will be copied only "
-"from vector map <%s>."
+msgid "Multiple background maps were given. Selected features will be copied only from vector map <%s>."
 msgstr ""
 #: ../vector/v.edit/main.c:397
@@ -10391,9 +9955,7 @@
 msgstr ""
 #: ../vector/v.vol.rst/main.c:241
-msgid ""
-"Interpolates point data to a 3D raster map using regularized spline with "
-"tension (RST) algorithm."
+msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
 msgstr ""
 #: ../vector/v.vol.rst/main.c:246
@@ -10532,9 +10094,7 @@
 msgstr ""
 #: ../vector/v.vol.rst/main.c:491
-msgid ""
-"Crossvalidation cannot be computed simultanuously with output grids or devi "
-"file"
+msgid "Crossvalidation cannot be computed simultanuously with output grids or devi file"
 msgstr ""
 #: ../vector/v.vol.rst/main.c:507 ../vector/v.vol.rst/main.c:510
@@ -10595,9 +10155,7 @@
 #: ../vector/v.vol.rst/main.c:640
 #, c-format
-msgid ""
-"Unable to create <%s> raster map without cross_input raster map being "
-"specified"
+msgid "Unable to create <%s> raster map without cross_input raster map being specified"
 msgstr ""
 #: ../vector/v.vol.rst/main.c:818
@@ -10658,8 +10216,7 @@
 #: ../vector/v.univar/main.c:366 ../vector/v.sample/main.c:152
 #: ../vector/v.class/main.c:132 ../vector/v.to.rast3/main.c:95
 #: ../vector/v.surf.bspline/main.c:392 ../vector/v.surf.idw/read_sites.c:68
-#: ../ps/ps.map/catval.c:66 ../ps/ps.map/catval.c:131
-#: ../ps/ps.map/catval.c:198
+#: ../ps/ps.map/catval.c:66 ../ps/ps.map/catval.c:131 ../ps/ps.map/catval.c:198
 msgid "Unable to select data from table"
 msgstr ""
@@ -10672,8 +10229,7 @@
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:128
-msgid ""
-"Column type of smooth column is not supported (must be integer or double)"
+msgid "Column type of smooth column is not supported (must be integer or double)"
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:150
@@ -10711,29 +10267,22 @@
 #: ../vector/v.vol.rst/user1.c:311
 #, c-format
-msgid ""
-"There are points outside specified 2D/3D region--ignored %d points (total "
-"points: %d)"
+msgid "There are points outside specified 2D/3D region--ignored %d points (total points: %d)"
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:315
 #, c-format
-msgid ""
-"Points are more dense than specified 'DMIN'--ignored %d points (remain %d)"
+msgid "Points are more dense than specified 'DMIN'--ignored %d points (remain %d)"
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:321
 #, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given "
-"NPMIN=%d"
+msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:341
 #, c-format
-msgid ""
-"There is less than %d points for interpolation, no segmentation is "
-"necessary, to run the program faster, set segmax=%d (see manual)"
+msgid "There is less than %d points for interpolation, no segmentation is necessary, to run the program faster, set segmax=%d (see manual)"
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:368
@@ -11006,9 +10555,7 @@
 msgstr ""
 #: ../vector/v.vect.stats/main.c:187
-msgid ""
-"Column to hold points count, must be of type integer, will be created if not"
-" existing"
+msgid "Column to hold points count, must be of type integer, will be created if not existing"
 msgstr ""
 #: ../vector/v.vect.stats/main.c:194
@@ -11016,9 +10563,7 @@
 msgstr ""
 #: ../vector/v.vect.stats/main.c:196
-msgid ""
-"Column to hold statistics, must be of type double, will be created if not "
-"existing"
+msgid "Column to hold statistics, must be of type double, will be created if not existing"
 msgstr ""
 #: ../vector/v.vect.stats/main.c:203
@@ -11195,9 +10740,7 @@
 msgstr ""
 #: ../vector/v.out.lidar/main.c:572 ../vector/v.out.lidar/main.c:582
-msgid ""
-"This scale does not change the values itself but only how precisely they are"
-" stored, for example 0.01 will preserve two decimal places"
+msgid "This scale does not change the values itself but only how precisely they are stored, for example 0.01 will preserve two decimal places"
 msgstr ""
 #: ../vector/v.out.lidar/main.c:581
@@ -11279,10 +10822,7 @@
 msgstr ""
 #: ../vector/v.perturb/main.c:92
-msgid ""
-"If the distribution is uniform, only one parameter, the maximum, is needed. "
-"For a normal distribution, two parameters, the mean and standard deviation, "
-"are required."
+msgid "If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
 msgstr ""
 #: ../vector/v.perturb/main.c:102
@@ -11322,9 +10862,7 @@
 msgstr ""
 #: ../vector/v.qcount/main.c:72
-msgid ""
-"Name for output quadrat centers map (number of points is written as "
-"category)"
+msgid "Name for output quadrat centers map (number of points is written as category)"
 msgstr ""
 #: ../vector/v.qcount/main.c:78
@@ -11445,9 +10983,7 @@
 msgstr ""
 #: ../vector/v.colors/main.c:234
-msgid ""
-"Reading rules from standard input is not implemented yet, please provide "
-"path to rules file instead."
+msgid "Reading rules from standard input is not implemented yet, please provide path to rules file instead."
 msgstr ""
 #: ../vector/v.colors/main.c:244
@@ -11486,8 +11022,8 @@
 msgstr ""
 #: ../vector/v.colors/main.c:315 ../raster/r.colors/edit_colors.c:396
-#: ../raster/r.grow.distance/main.c:384
-#: ../raster/r.colors.out/raster_main.c:69 ../raster/r.fill.dir/main.c:153
+#: ../raster/r.grow.distance/main.c:384 ../raster/r.colors.out/raster_main.c:69
+#: ../raster/r.fill.dir/main.c:153
 #, c-format
 msgid "Unable to read color table for raster map <%s>"
 msgstr ""
@@ -11661,9 +11197,7 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:224
-msgid ""
-"List of column names to be used instead of original names, first is used for"
-" category column"
+msgid "List of column names to be used instead of original names, first is used for category column"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:243
@@ -11671,9 +11205,7 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:245
-msgid ""
-"If not given, categories are generated as unique values and stored in 'cat' "
-"column"
+msgid "If not given, categories are generated as unique values and stored in 'cat' column"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:250
@@ -11720,9 +11252,7 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:316 ../vector/v.in.lidar/main.c:328
-msgid ""
-" import the vector data."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the vector data."
 msgstr ""
 #: ../vector/v.in.ogr/main.c:334 ../vector/v.external/list.c:94
@@ -11738,16 +11268,12 @@
 #: ../vector/v.in.ogr/main.c:415
 #, c-format
-msgid ""
-"Option <%s> will be ignored. OGR doesn't support it for selected format "
-"(%s)."
+msgid "Option <%s> will be ignored. OGR doesn't support it for selected format (%s)."
 msgstr ""
 #: ../vector/v.in.ogr/main.c:420
 #, c-format
-msgid ""
-"Option <%s> will be ignored. Multiple geometry fields are supported by GDAL "
-">= 1.11"
+msgid "Option <%s> will be ignored. Multiple geometry fields are supported by GDAL >= 1.11"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:433
@@ -11781,9 +11307,7 @@
 #: ../vector/v.in.ogr/main.c:577 ../vector/v.in.lidar/main.c:507
 #: ../raster/r.in.gdal/main.c:437 ../raster/r.in.gdal/main.c:826
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location."
+msgid "Unable to convert input map projection to GRASS format; cannot create new location."
 msgstr ""
 #: ../vector/v.in.ogr/main.c:583 ../vector/v.in.lidar/main.c:513
@@ -11796,9 +11320,7 @@
 #: ../vector/v.external/proj.c:41 ../vector/v.in.pdal/projection.c:110
 #: ../vector/v.in.pdal/projection.c:156 ../vector/v.in.pdal/projection.c:189
 #: ../raster/r.in.lidar/projection.c:113
-msgid ""
-"Unable to convert input map projection information to GRASS format for "
-"checking"
+msgid "Unable to convert input map projection information to GRASS format for checking"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:620 ../vector/v.in.lidar/projection.c:126
@@ -11844,9 +11366,7 @@
 #: ../vector/v.in.ogr/main.c:695 ../vector/v.in.lidar/projection.c:93
 #: ../vector/v.external/proj.c:117 ../vector/v.in.pdal/projection.c:92
 #: ../raster/r.in.lidar/projection.c:95
-msgid ""
-"Consider generating a new location with 'location' parameter from input data"
-" set.\n"
+msgid "Consider generating a new location with 'location' parameter from input data set.\n"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:710 ../vector/v.in.lidar/projection.c:137
@@ -11877,8 +11397,7 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:792
-msgid ""
-"The 'spatial' parameters do not overlap with OGR input. Nothing to import."
+msgid "The 'spatial' parameters do not overlap with OGR input. Nothing to import."
 msgstr ""
 #: ../vector/v.in.ogr/main.c:826
@@ -11932,9 +11451,7 @@
 #: ../vector/v.in.ogr/main.c:1114
 #, c-format
-msgid ""
-"Width for column %s set to 255 (was not specified by OGR), some strings may "
-"be truncated!"
+msgid "Width for column %s set to 255 (was not specified by OGR), some strings may be truncated!"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:1126
@@ -12012,10 +11529,7 @@
 #: ../vector/v.in.ogr/main.c:1537
 #, c-format
-msgid ""
-"%d areas represent more (overlapping) features, because polygons overlap in "
-"input layer(s). Such areas are linked to more than 1 row in attribute table."
-" The number of features for those areas is stored as category in layer %d"
+msgid "%d areas represent more (overlapping) features, because polygons overlap in input layer(s). Such areas are linked to more than 1 row in attribute table. The number of features for those areas is stored as category in layer %d"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:1547
@@ -12126,9 +11640,7 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:1734
-msgid ""
-"Input data contains 3D features. Created vector is 2D only, disable -2 flag "
-"to import 3D vector."
+msgid "Input data contains 3D features. Created vector is 2D only, disable -2 flag to import 3D vector."
 msgstr ""
 #: ../vector/v.in.ogr/geom.c:76 ../vector/v.in.ogr/geom.c:261
@@ -12185,9 +11697,7 @@
 msgstr ""
 #: ../vector/v.info/parse.c:30
-msgid ""
-"Print types/names of table columns for specified layer instead of info and "
-"exit"
+msgid "Print types/names of table columns for specified layer instead of info and exit"
 msgstr ""
 #: ../vector/v.info/parse.c:35
@@ -12414,10 +11924,7 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:147
-msgid ""
-"Spatial approximation and topographic analysis from given point or isoline "
-"data in vector format to floating point raster format using regularized "
-"spline with tension."
+msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
 msgstr ""
 #: ../vector/v.surf.rst/main.c:154
@@ -12461,9 +11968,7 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:179 ../vector/v.surf.idw/main.c:102
-msgid ""
-"If not given and input is 2D vector map then category values are used. If "
-"input is 3D vector map then z-coordinates are used."
+msgid "If not given and input is 2D vector map then category values are used. If input is 3D vector map then z-coordinates are used."
 msgstr ""
 #: ../vector/v.surf.rst/main.c:189
@@ -12507,8 +12012,7 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:308
-msgid ""
-"Maximum distance between points on isoline (to insert additional points)"
+msgid "Maximum distance between points on isoline (to insert additional points)"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:317
@@ -12534,15 +12038,11 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:425
-msgid ""
-"Both cross-validation options (-c flag and cvdev vector output) must be "
-"specified"
+msgid "Both cross-validation options (-c flag and cvdev vector output) must be specified"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:428
-msgid ""
-"The cross-validation cannot be computed simultaneously with output raster or"
-" devi file"
+msgid "The cross-validation cannot be computed simultaneously with output raster or devi file"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:446
@@ -12558,9 +12058,7 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:541 ../vector/v.surf.bspline/main.c:272
-msgid ""
-"Input is 3D: using attribute values instead of z-coordinates for "
-"approximation"
+msgid "Input is 3D: using attribute values instead of z-coordinates for approximation"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:543 ../vector/v.surf.bspline/main.c:274
@@ -12577,9 +12075,7 @@
 #: ../vector/v.surf.rst/main.c:662
 #, c-format
-msgid ""
-"Processing all selected output files will require %d bytes of disk space for"
-" temp files"
+msgid "Processing all selected output files will require %d bytes of disk space for temp files"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:682
@@ -12733,8 +12229,7 @@
 msgstr ""
 #: ../vector/v.in.db/main.c:57
-msgid ""
-"Creates new vector (points) map from database table containing coordinates."
+msgid "Creates new vector (points) map from database table containing coordinates."
 msgstr ""
 #: ../vector/v.in.db/main.c:61
@@ -12777,15 +12272,12 @@
 #: ../vector/v.in.db/main.c:141
 #, c-format
-msgid ""
-"Vector map <%s> cannot be overwritten because input table <%s> is linked to "
-"this map."
+msgid "Vector map <%s> cannot be overwritten because input table <%s> is linked to this map."
 msgstr ""
 #: ../vector/v.in.db/main.c:177
 #, c-format
-msgid ""
-"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
+msgid "Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
 msgstr ""
 #: ../vector/v.in.db/main.c:190 ../vector/v.db.connect/main.c:295
@@ -12799,9 +12291,7 @@
 #: ../vector/v.in.db/main.c:199
 #, c-format
-msgid ""
-"Unable to define key column. This operation is not supported by <%s> driver."
-" You need to define <%s> option."
+msgid "Unable to define key column. This operation is not supported by <%s> driver. You need to define <%s> option."
 msgstr ""
 #: ../vector/v.in.db/main.c:225 ../display/d.vect.chart/plot.c:86
@@ -12866,9 +12356,7 @@
 msgstr ""
 #: ../vector/v.db.select/main.c:100
-msgid ""
-"Print minimal region extent of selected vector features instead of "
-"attributes"
+msgid "Print minimal region extent of selected vector features instead of attributes"
 msgstr ""
 #: ../vector/v.db.select/main.c:101 ../raster/r.in.gdal/main.c:198
@@ -12899,9 +12387,7 @@
 #: ../vector/v.db.select/main.c:157
 #, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Flag '%c' requires "
-"topology level."
+msgid "Unable to open vector map <%s> at topology level. Flag '%c' requires topology level."
 msgstr ""
 #: ../vector/v.db.select/main.c:208
@@ -12949,9 +12435,7 @@
 msgstr ""
 #: ../vector/v.lidar.correction/main.c:74
-msgid ""
-"Corrects the v.lidar.growing output. It is the last of the three algorithms "
-"for LIDAR filtering."
+msgid "Corrects the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
 msgstr ""
 #: ../vector/v.lidar.correction/main.c:78
@@ -12962,9 +12446,7 @@
 #: ../vector/v.lidar.correction/main.c:80
 #: ../vector/v.lidar.edgedetection/main.c:85
 #: ../vector/v.surf.bspline/main.c:107 ../vector/v.outlier/main.c:81
-msgid ""
-"Estimate point density and distance for the input vector points within the "
-"current region extends and quit"
+msgid "Estimate point density and distance for the input vector points within the current region extends and quit"
 msgstr ""
 #: ../vector/v.lidar.correction/main.c:85
@@ -13037,8 +12519,7 @@
 msgstr ""
 #: ../vector/v.lidar.correction/main.c:194
-#: ../vector/v.lidar.correction/main.c:230
-#: ../vector/v.lidar.growing/main.c:163
+#: ../vector/v.lidar.correction/main.c:230 ../vector/v.lidar.growing/main.c:163
 #: ../vector/v.lidar.edgedetection/main.c:221
 #: ../vector/v.lidar.edgedetection/main.c:233
 #: ../vector/v.lidar.edgedetection/main.c:255
@@ -13106,9 +12587,7 @@
 msgstr ""
 #: ../vector/v.lidar.growing/main.c:78
-msgid ""
-"Building contour determination and Region Growing algorithm for determining "
-"the building inside"
+msgid "Building contour determination and Region Growing algorithm for determining the building inside"
 msgstr ""
 #: ../vector/v.lidar.growing/main.c:83
@@ -13310,9 +12789,8 @@
 #: ../vector/v.what.rast/main.c:183 ../vector/v.sample/main.c:240
 #: ../vector/v.class/main.c:129 ../vector/v.to.rast3/main.c:99
-#: ../vector/v.surf.bspline/crosscorr.c:133
-#: ../vector/v.surf.bspline/main.c:389 ../vector/v.surf.idw/read_sites.c:65
-#: ../vector/v.buffer/main.c:434
+#: ../vector/v.surf.bspline/crosscorr.c:133 ../vector/v.surf.bspline/main.c:389
+#: ../vector/v.surf.idw/read_sites.c:65 ../vector/v.buffer/main.c:434
 msgid "Column type not supported"
 msgstr ""
@@ -13394,9 +12872,7 @@
 #: ../vector/v.drape/main.c:150 ../vector/v.random/main.c:208
 #: ../vector/v.buffer/main.c:348
 #, c-format
-msgid ""
-"Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer "
-"'1'."
+msgid "Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer '1'."
 msgstr ""
 #: ../vector/v.drape/main.c:177 ../vector/v.select/select.c:40
@@ -13746,14 +13222,11 @@
 msgstr ""
 #: ../vector/v.out.postgis/args.c:44
-msgid ""
-"Name for output vector map defined as a link to the PostGIS feature table"
+msgid "Name for output vector map defined as a link to the PostGIS feature table"
 msgstr ""
 #: ../vector/v.out.postgis/args.c:46
-msgid ""
-"If not specified, the vector link is not created. The link can be also "
-"manually created by 'v.external' module."
+msgid "If not specified, the vector link is not created. The link can be also manually created by 'v.external' module."
 msgstr ""
 #: ../vector/v.out.postgis/args.c:52 ../vector/v.external.out/args.c:39
@@ -13865,16 +13338,12 @@
 #: ../vector/v.out.postgis/table.c:50
 #, c-format
-msgid ""
-"Invalid FID column (%s). FID column must be integer. Please specify "
-"different FID column by 'options=\"FID=<name>\"'."
+msgid "Invalid FID column (%s). FID column must be integer. Please specify different FID column by 'options=\"FID=<name>\"'."
 msgstr ""
 #: ../vector/v.out.postgis/table.c:57
 #, c-format
-msgid ""
-"Column (%s) already exists in the table. Please specify different geometry "
-"column by 'options=\"GEOMETRY_NAME=<name>\"'."
+msgid "Column (%s) already exists in the table. Please specify different geometry column by 'options=\"GEOMETRY_NAME=<name>\"'."
 msgstr ""
 #: ../vector/v.out.svg/main.c:76
@@ -13965,9 +13434,7 @@
 msgstr ""
 #: ../vector/v.delaunay/main.c:88
-msgid ""
-"Creates a Delaunay triangulation from an input vector map containing points "
-"or centroids."
+msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
 msgstr ""
 #: ../vector/v.delaunay/main.c:103
@@ -14102,9 +13569,7 @@
 msgstr ""
 #: ../vector/v.reclass/main.c:71
-msgid ""
-"Changes vector category values for an existing vector map according to "
-"results of SQL queries or a value in attribute table column."
+msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
 msgstr ""
 #: ../vector/v.reclass/main.c:88
@@ -14203,9 +13668,7 @@
 msgstr ""
 #: ../vector/v.net.centrality/main.c:100
-msgid ""
-"Computes degree, centrality, betweeness, closeness and eigenvector "
-"centrality measures in the network."
+msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
 msgstr ""
 #: ../vector/v.net.centrality/main.c:148
@@ -14271,8 +13734,7 @@
 msgstr ""
 #: ../vector/v.select/main.c:52
-msgid ""
-"Selects features from vector map (A) by features from other vector map (B)."
+msgid "Selects features from vector map (A) by features from other vector map (B)."
 msgstr ""
 #: ../vector/v.select/main.c:85 ../vector/v.overlay/main.c:178
@@ -14331,10 +13793,7 @@
 msgstr ""
 #: ../vector/v.select/args.c:51
-msgid ""
-"A feature is written to output if the result of operation 'ainput operator "
-"binput' is true. An input feature is considered to be true, if category of "
-"given layer is defined."
+msgid "A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined."
 msgstr ""
 #: ../vector/v.select/args.c:59 ../vector/v.select/args.c:75
@@ -14374,9 +13833,7 @@
 msgstr ""
 #: ../vector/v.select/args.c:84
-msgid ""
-"feature A is spatially related to feature B (using GEOS, requires 'relate' "
-"option)"
+msgid "feature A is spatially related to feature B (using GEOS, requires 'relate' option)"
 msgstr ""
 #: ../vector/v.select/args.c:94
@@ -14438,8 +13895,7 @@
 msgstr ""
 #: ../vector/v.support/main.c:118
-msgid ""
-"Command line to store into vector map history file (used for vector scripts)"
+msgid "Command line to store into vector map history file (used for vector scripts)"
 msgstr ""
 #: ../vector/v.support/main.c:122
@@ -14453,9 +13909,7 @@
 #: ../vector/v.in.lidar/main.c:48
 #, c-format
-msgid ""
-"Values of %s and %s are the same. All categories would be stored only in "
-"layer number <%d>"
+msgid "Values of %s and %s are the same. All categories would be stored only in layer number <%d>"
 msgstr ""
 #: ../vector/v.in.lidar/main.c:141
@@ -14506,9 +13960,7 @@
 msgstr ""
 #: ../vector/v.in.lidar/main.c:236
-msgid ""
-"For example, 5 will import 80 percent of points. If not specified, all "
-"points are imported"
+msgid "For example, 5 will import 80 percent of points. If not specified, all points are imported"
 msgstr ""
 #: ../vector/v.in.lidar/main.c:238 ../vector/v.in.lidar/main.c:248
@@ -14521,9 +13973,7 @@
 msgstr ""
 #: ../vector/v.in.lidar/main.c:246
-msgid ""
-"For example, 4 will import 25 percent of points. If not specified, all "
+msgid "For example, 4 will import 25 percent of points. If not specified, all points are imported"
 msgstr ""
 #: ../vector/v.in.lidar/main.c:255 ../vector/v.decimate/main.c:183
@@ -14590,9 +14040,7 @@
 #: ../vector/v.in.lidar/main.c:425
 #, c-format
-msgid ""
-"Storing generated point IDs as categories in the layer <%d>, consequently no"
-" more than %d points can be imported"
+msgid "Storing generated point IDs as categories in the layer <%d>, consequently no more than %d points can be imported"
 msgstr ""
 #: ../vector/v.in.lidar/main.c:435 ../vector/v.decimate/main.c:294
@@ -14621,9 +14069,7 @@
 msgstr ""
 #: ../vector/v.in.lidar/main.c:746
-msgid ""
-"The underlying libLAS library is at its limits. Previously reported counts "
-"might have been distorted. However, the import itself should be unaffected."
+msgid "The underlying libLAS library is at its limits. Previously reported counts might have been distorted. However, the import itself should be unaffected."
 msgstr ""
 #: ../vector/v.in.lidar/main.c:752
@@ -14712,9 +14158,7 @@
 msgstr ""
 #: ../vector/v.in.lidar/main.c:802
-msgid ""
-"Accuracy of the printed point counts might be limited by your computer "
-"architecture."
+msgid "Accuracy of the printed point counts might be limited by your computer architecture."
 msgstr ""
 #: ../vector/v.in.lidar/main.c:805
@@ -14728,9 +14172,7 @@
 #: ../vector/v.in.lidar/main.c:818
 #, c-format
-msgid ""
-"Maximum number of categories reached (%d). Import ended prematurely. Try to "
-"import without using category as an ID."
+msgid "Maximum number of categories reached (%d). Import ended prematurely. Try to import without using category as an ID."
 msgstr ""
 #: ../vector/v.in.lidar/vector_mask.c:20
@@ -14824,8 +14266,7 @@
 msgid "Point classification..."
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:103
-#: ../vector/v.lrs/v.lrs.where/main.c:58
+#: ../vector/v.lrs/v.lrs.label/main.c:103 ../vector/v.lrs/v.lrs.where/main.c:58
 #: ../vector/v.lrs/v.lrs.create/main.c:122
 #: ../vector/v.lrs/v.lrs.segment/main.c:72
 msgid "linear reference system"
@@ -14835,8 +14276,7 @@
 msgid "Creates stationing from input lines, and linear reference system."
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:109
-#: ../vector/v.lrs/v.lrs.where/main.c:66
+#: ../vector/v.lrs/v.lrs.label/main.c:109 ../vector/v.lrs/v.lrs.where/main.c:66
 #: ../vector/v.lrs/v.lrs.create/main.c:128
 #: ../vector/v.lrs/v.lrs.segment/main.c:79
 msgid "Input vector map containing lines"
@@ -14846,22 +14286,19 @@
 msgid "Output vector map where stationing will be written"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:118
-#: ../vector/v.lrs/v.lrs.where/main.c:75
+#: ../vector/v.lrs/v.lrs.label/main.c:118 ../vector/v.lrs/v.lrs.where/main.c:75
 #: ../vector/v.lrs/v.lrs.create/main.c:147
 #: ../vector/v.lrs/v.lrs.segment/main.c:88
 msgid "Line layer"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:124
-#: ../vector/v.lrs/v.lrs.where/main.c:86
+#: ../vector/v.lrs/v.lrs.label/main.c:124 ../vector/v.lrs/v.lrs.where/main.c:86
 #: ../vector/v.lrs/v.lrs.create/main.c:207
 #: ../vector/v.lrs/v.lrs.segment/main.c:94
 msgid "Driver name for reference system table"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:132
-#: ../vector/v.lrs/v.lrs.where/main.c:94
+#: ../vector/v.lrs/v.lrs.label/main.c:132 ../vector/v.lrs/v.lrs.where/main.c:94
 #: ../vector/v.lrs/v.lrs.create/main.c:215
 #: ../vector/v.lrs/v.lrs.segment/main.c:102
 msgid "Database name for reference system table"
@@ -14967,9 +14404,7 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.where/main.c:61
-msgid ""
-"Finds line id and real km+offset for given points in vector map using linear"
-" reference system."
+msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
 msgstr ""
 #: ../vector/v.lrs/v.lrs.where/main.c:70
@@ -15055,8 +14490,7 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:182
-msgid ""
-"Column containing offset from milepost for the beginning of next segment"
+msgid "Column containing offset from milepost for the beginning of next segment"
 msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:191
@@ -15189,9 +14623,7 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.segment/main.c:75
-msgid ""
-"Creates points/segments from input lines, linear reference system and "
-"positions read from stdin or a file."
+msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
 msgstr ""
 #: ../vector/v.lrs/v.lrs.segment/main.c:83
@@ -15342,9 +14774,7 @@
 #: ../vector/v.to.db/main.c:48
 #, c-format
-msgid ""
-"Vector map <%s> not found in the current mapset. Unable to modify vector "
-"maps from different mapsets."
+msgid "Vector map <%s> not found in the current mapset. Unable to modify vector maps from different mapsets."
 msgstr ""
 #: ../vector/v.to.db/main.c:65 ../vector/v.to.db/query.c:83
@@ -15415,15 +14845,11 @@
 msgstr ""
 #: ../vector/v.to.db/parse.c:84
-msgid ""
-"categories of areas on the left and right side of the boundary, "
-"'query_layer' is used for area category"
+msgid "categories of areas on the left and right side of the boundary, 'query_layer' is used for area category"
 msgstr ""
 #: ../vector/v.to.db/parse.c:86
-msgid ""
-"result of a database query for all records of the geometry(or geometries) "
-"from table specified by 'query_layer' option"
+msgid "result of a database query for all records of the geometry(or geometries) from table specified by 'query_layer' option"
 msgstr ""
 #: ../vector/v.to.db/parse.c:88
@@ -15431,14 +14857,11 @@
 msgstr ""
 #: ../vector/v.to.db/parse.c:89
-msgid ""
-"line sinuousity, calculated as line length / distance between end points"
+msgid "line sinuousity, calculated as line length / distance between end points"
 msgstr ""
 #: ../vector/v.to.db/parse.c:90
-msgid ""
-"line azimuth, calculated as angle between North direction and endnode "
-"direction at startnode"
+msgid "line azimuth, calculated as angle between North direction and endnode direction at startnode"
 msgstr ""
 #: ../vector/v.to.db/parse.c:94
@@ -15524,9 +14947,7 @@
 #: ../vector/v.to.db/query.c:109
 #, c-format
-msgid ""
-"Query for category '0' (no category) was not executed because of too many "
-"(%d) query categories. All later reported values for cat 0 are not valid."
+msgid "Query for category '0' (no category) was not executed because of too many (%d) query categories. All later reported values for cat 0 are not valid."
 msgstr ""
 #: ../vector/v.to.db/query.c:146
@@ -15624,8 +15045,7 @@
 msgstr ""
 #: ../vector/v.transform/main.c:74
-msgid ""
-"Performs an affine transformation (shift, scale and rotate) on vector map."
+msgid "Performs an affine transformation (shift, scale and rotate) on vector map."
 msgstr ""
 #: ../vector/v.transform/main.c:79
@@ -15726,9 +15146,7 @@
 #: ../vector/v.transform/trans_digit.c:112
 #, c-format
-msgid ""
-"Unable to select value for category %d from table <%s>, column <%s>. For "
-"category %d using default transformation parameter %.3f."
+msgid "Unable to select value for category %d from table <%s>, column <%s>. For category %d using default transformation parameter %.3f."
 msgstr ""
 #: ../vector/v.transform/trans_digit.c:123
@@ -15740,13 +15158,11 @@
 msgstr ""
 #: ../vector/v.univar/main.c:99
-msgid ""
-"Variance and standard deviation is calculated only for points if specified."
+msgid "Variance and standard deviation is calculated only for points if specified."
 msgstr ""
 #: ../vector/v.univar/main.c:126 ../vector/v.what/main.c:98
-#: ../raster/r.univar/r.univar_main.c:61
-#: ../raster/r.univar/r3.univar_main.c:59
+#: ../raster/r.univar/r.univar_main.c:61 ../raster/r.univar/r3.univar_main.c:59
 msgid "Print the stats in shell script style"
 msgstr ""
@@ -15764,9 +15180,7 @@
 msgstr ""
 #: ../vector/v.univar/main.c:195
-msgid ""
-"Incompatible vector type(s) specified, only number of features, minimum, "
-"maximum and range can be calculated"
+msgid "Incompatible vector type(s) specified, only number of features, minimum, maximum and range can be calculated"
 msgstr ""
 #: ../vector/v.univar/main.c:200
@@ -15857,15 +15271,12 @@
 #: ../vector/v.db.connect/main.c:197
 #, c-format
-msgid ""
-"layer <%d/%s> table <%s> in database <%s> through driver <%s> with key "
-"<%s>\n"
+msgid "layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
 #: ../vector/v.db.connect/main.c:203
 #, c-format
-msgid ""
-"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgid "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
 #: ../vector/v.db.connect/main.c:266
@@ -15880,28 +15291,19 @@
 #: ../vector/v.db.connect/main.c:302 ../vector/v.db.connect/main.c:320
 #, c-format
-msgid ""
-"The table <%s> is now part of vector map <%s> and may be deleted or "
-"overwritten by GRASS modules"
+msgid "The table <%s> is now part of vector map <%s> and may be deleted or overwritten by GRASS modules"
 msgstr ""
 #: ../vector/v.db.connect/main.c:351
-msgid ""
-"For defining a new connection you have to specify these parameters: driver, "
-"database, table [, key [, layer]]"
+msgid "For defining a new connection you have to specify these parameters: driver, database, table [, key [, layer]]"
 msgstr ""
 #: ../vector/v.net.distance/main.c:69
-msgid ""
-"Computes shortest distance via the network between the given sets of "
-"features."
+msgid "Computes shortest distance via the network between the given sets of features."
 msgstr ""
 #: ../vector/v.net.distance/main.c:72
-msgid ""
-"Finds the shortest paths from each 'from' point to the nearest 'to' feature "
-"and various information about this relation are uploaded to the attribute "
-"table."
+msgid "Finds the shortest paths from each 'from' point to the nearest 'to' feature and various information about this relation are uploaded to the attribute table."
 msgstr ""
 #: ../vector/v.net.distance/main.c:100
@@ -15979,9 +15381,7 @@
 msgstr ""
 #: ../vector/v.decimate/main.c:133
-msgid ""
-"Copies points from one vector to another while applying different "
-"decimations"
+msgid "Copies points from one vector to another while applying different decimations"
 msgstr ""
 #: ../vector/v.decimate/main.c:161
@@ -15989,9 +15389,7 @@
 msgstr ""
 #: ../vector/v.decimate/main.c:163
-msgid ""
-"points are copied"
+msgid "For example, 5 will import 80 percent of points. If not specified, all points are copied"
 msgstr ""
 #: ../vector/v.decimate/main.c:165 ../vector/v.decimate/main.c:176
@@ -16004,9 +15402,7 @@
 msgstr ""
 #: ../vector/v.decimate/main.c:174
-msgid ""
+msgid "For example, 4 will import 25 percent of points. If not specified, all points are copied"
 msgstr ""
 #: ../vector/v.decimate/main.c:193
@@ -16036,9 +15432,7 @@
 msgstr ""
 #: ../vector/v.decimate/main.c:213
-msgid ""
-"Preserves only the given number of points per grid cell in grid-based "
-"decimation"
+msgid "Preserves only the given number of points per grid cell in grid-based decimation"
 msgstr ""
 #: ../vector/v.decimate/main.c:218
@@ -16067,9 +15461,7 @@
 #: ../vector/v.decimate/main.c:276
 #, c-format
-msgid ""
-"Input layer must be set to a particular layer, not <%s>, when using <%s> "
-"option or <-%c> flag"
+msgid "Input layer must be set to a particular layer, not <%s>, when using <%s> option or <-%c> flag"
 msgstr ""
 #: ../vector/v.decimate/main.c:318
@@ -16081,9 +15473,7 @@
 msgstr ""
 #: ../vector/v.decimate/main.c:350
-msgid ""
-"Settings for count-based decimation would cause it to do nothing and no "
-"other options has been set."
+msgid "Settings for count-based decimation would cause it to do nothing and no other options has been set."
 msgstr ""
 #: ../vector/v.sample/main.c:79
@@ -16343,8 +15733,7 @@
 msgstr ""
 #: ../vector/v.label/main.c:251
-msgid ""
-"size and space options vary significantly which may lead to crummy output"
+msgid "size and space options vary significantly which may lead to crummy output"
 msgstr ""
 #: ../vector/v.label/main.c:259
@@ -16381,9 +15770,7 @@
 msgstr ""
 #: ../vector/v.out.pov/main.c:75
-msgid ""
-"This string is appended to each z coordinate. Examples: '*10', '+1000', "
-"'*10+100', '*exaggeration'"
+msgid "This string is appended to each z coordinate. Examples: '*10', '+1000', '*10+100', '*exaggeration'"
 msgstr ""
 #: ../vector/v.out.pov/main.c:82
@@ -16441,9 +15828,7 @@
 msgstr ""
 #: ../vector/v.category/main.c:119
-msgid ""
-"copy values from one layer to another (e.g. layer=1,2,3 copies values from "
-"layer 1 to layer 2 and 3)"
+msgid "copy values from one layer to another (e.g. layer=1,2,3 copies values from layer 1 to layer 2 and 3)"
 msgstr ""
 #: ../vector/v.category/main.c:120
@@ -16451,9 +15836,7 @@
 msgstr ""
 #: ../vector/v.category/main.c:121
-msgid ""
-"print category values, layers are separated by '|', more cats in the same "
-"layer are separated by '/'"
+msgid "print category values, layers are separated by '|', more cats in the same layer are separated by '/'"
 msgstr ""
 #: ../vector/v.category/main.c:122
@@ -16473,15 +15856,11 @@
 msgstr ""
 #: ../vector/v.category/main.c:160
-msgid ""
-"Database connection and attribute tables for concerned layers are not "
-"changed"
+msgid "Database connection and attribute tables for concerned layers are not changed"
 msgstr ""
 #: ../vector/v.category/main.c:208
-msgid ""
-"Invalid category number (must be equal to or greater than 0). Normally "
-"category number starts at 1."
+msgid "Invalid category number (must be equal to or greater than 0). Normally category number starts at 1."
 msgstr ""
 #: ../vector/v.category/main.c:217
@@ -16612,8 +15991,7 @@
 msgstr ""
 #: ../vector/v.to.rast/main.c:122
-msgid ""
-"All cells touched by the line will be set, not only those on the render path"
+msgid "All cells touched by the line will be set, not only those on the render path"
 msgstr ""
 #: ../vector/v.to.rast/main.c:132
@@ -16699,9 +16077,7 @@
 msgstr ""
 #: ../vector/v.to.rast/vect2rast.c:137
-msgid ""
-"Area conversion and line densification are mutually exclusive, disabling "
-"line densification."
+msgid "Area conversion and line densification are mutually exclusive, disabling line densification."
 msgstr ""
 #: ../vector/v.to.rast/vect2rast.c:152
@@ -16939,9 +16315,7 @@
 msgstr ""
 #: ../vector/v.net.alloc/main.c:63
-msgid ""
-"center node must be opened (costs >= 0). Costs of center node are used in "
-"calculation"
+msgid "center node must be opened (costs >= 0). Costs of center node are used in calculation"
 msgstr ""
 #: ../vector/v.net.alloc/main.c:76
@@ -16949,9 +16323,7 @@
 msgstr ""
 #: ../vector/v.net.alloc/main.c:83 ../vector/v.net.iso/main.c:89
-msgid ""
-"Categories of centers (points on nodes) to which net will be allocated, "
-"layer for this categories is given by nlayer option"
+msgid "Categories of centers (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
 msgstr ""
 #: ../vector/v.net.alloc/main.c:129 ../vector/v.net.iso/main.c:137
@@ -17168,10 +16540,7 @@
 msgstr ""
 #: ../vector/v.class/main.c:173
-msgid ""
-"The discontinuities algorithm indicates that some class breaks are not "
-"statistically significant at alpha=0.05. You are advised to reduce the "
-"number of classes."
+msgid "The discontinuities algorithm indicates that some class breaks are not statistically significant at alpha=0.05. You are advised to reduce the number of classes."
 msgstr ""
 #: ../vector/v.class/main.c:201
@@ -17266,9 +16635,7 @@
 msgstr ""
 #: ../vector/v.random/main.c:153
-msgid ""
-"The seed to initialize the random generator. If not set the process ID is "
-"used"
+msgid "The seed to initialize the random generator. If not set the process ID is used"
 msgstr ""
 #: ../vector/v.random/main.c:156
@@ -17311,15 +16678,12 @@
 msgstr ""
 #: ../vector/v.random/main.c:286
-msgid ""
-"You have created unsupported column type. This module supports only INTEGER "
-"and DOUBLE PRECISION column types."
+msgid "You have created unsupported column type. This module supports only INTEGER and DOUBLE PRECISION column types."
 msgstr ""
 #: ../vector/v.random/main.c:349
 #, c-format
-msgid ""
-"Selected areas in input vector <%s> do not overlap with the current region"
+msgid "Selected areas in input vector <%s> do not overlap with the current region"
 msgstr ""
 #: ../vector/v.random/main.c:361
@@ -17397,9 +16761,7 @@
 msgstr ""
 #: ../vector/v.out.ascii/main.c:52
-msgid ""
-"By default only features with category are exported. To export all features "
-"use 'layer=-1'."
+msgid "By default only features with category are exported. To export all features use 'layer=-1'."
 msgstr ""
 #: ../vector/v.out.ascii/main.c:60
@@ -17419,9 +16781,7 @@
 #: ../vector/v.out.ascii/main.c:80
 #, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Areas will not be "
-"processed."
+msgid "Unable to open vector map <%s> at topology level. Areas will not be processed."
 msgstr ""
 #: ../vector/v.out.ascii/main.c:107
@@ -17466,9 +16826,7 @@
 msgstr ""
 #: ../vector/v.out.ogr/args.c:20
-msgid ""
-"Combination of types is not supported by all output formats. Default is to "
-"use first type found in input vector map."
+msgid "Combination of types is not supported by all output formats. Default is to use first type found in input vector map."
 msgstr ""
 #: ../vector/v.out.ogr/args.c:25
@@ -17532,9 +16890,7 @@
 msgstr ""
 #: ../vector/v.out.ogr/args.c:100
-msgid ""
-"Also export features without category (not labeled). Otherwise only features"
-" with category are exported."
+msgid "Also export features without category (not labeled). Otherwise only features with category are exported."
 msgstr ""
 #: ../vector/v.out.ogr/args.c:106
@@ -17550,9 +16906,7 @@
 msgstr ""
 #: ../vector/v.out.ogr/args.c:126
-msgid ""
-"Create a new empty layer in defined OGR datasource and exit. Nothing is read"
-" from input."
+msgid "Create a new empty layer in defined OGR datasource and exit. Nothing is read from input."
 msgstr ""
 #: ../vector/v.out.ogr/attrb.c:48 ../vector/v.out.vtk/writeVTK.c:585
@@ -17590,9 +16944,7 @@
 #: ../vector/v.out.ogr/main.c:97 ../vector/v.external.out/link.c:26
 #, c-format
-msgid ""
-"Data source starts with \"PG:\" prefix, expecting \"PostgreSQL\" format "
-"(\"%s\" given)"
+msgid "Data source starts with \"PG:\" prefix, expecting \"PostgreSQL\" format (\"%s\" given)"
 msgstr ""
 #: ../vector/v.out.ogr/main.c:165
@@ -17623,125 +16975,95 @@
 msgstr ""
 #: ../vector/v.out.ogr/main.c:311
-msgid ""
-"The map contains islands. With the -c flag, islands will appear as filled "
-"areas, not holes in the output map."
+msgid "The map contains islands. With the -c flag, islands will appear as filled areas, not holes in the output map."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:317
 #, c-format
-msgid ""
-"%d point found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d points found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d point found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d points found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 msgstr[1] ""
 msgstr[2] ""
 #: ../vector/v.out.ogr/main.c:325
 #, c-format
-msgid ""
-"%d line found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d line found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d line(s) found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 msgstr[1] ""
 msgstr[2] ""
 #: ../vector/v.out.ogr/main.c:334
 #, c-format
-msgid ""
-"%d boundary found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgid_plural ""
-"%d boundaries found, but not requested to be exported. Verify 'type' "
-"parameter."
+msgid "%d boundary found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d boundaries found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 msgstr[1] ""
 msgstr[2] ""
 #: ../vector/v.out.ogr/main.c:343
 #, c-format
-msgid ""
-"%d centroid found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgid_plural ""
-"%d centroids found, but not requested to be exported. Verify 'type' "
-"parameter."
+msgid "%d centroid found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d centroids found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 msgstr[1] ""
 msgstr[2] ""
 #: ../vector/v.out.ogr/main.c:351
 #, c-format
-msgid ""
-"%d area found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d areas found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d area found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d areas found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 msgstr[1] ""
 msgstr[2] ""
 #: ../vector/v.out.ogr/main.c:359
 #, c-format
-msgid ""
-"%d face found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d faces found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d face found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d faces found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 msgstr[1] ""
 msgstr[2] ""
 #: ../vector/v.out.ogr/main.c:367
 #, c-format
-msgid ""
-"%d volume found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d volumes found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d volume found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d volumes found, but not requested to be exported. Verify 'type' parameter."
 msgstr[0] ""
 msgstr[1] ""
 msgstr[2] ""
 #: ../vector/v.out.ogr/main.c:377
-msgid ""
-"No points found, but requested to be exported. Will skip this feature type."
+msgid "No points found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:386
-msgid ""
-"No lines found, but requested to be exported. Will skip this feature type."
+msgid "No lines found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:396
-msgid ""
-"No boundaries found, but requested to be exported. Will skip this feature "
-"type."
+msgid "No boundaries found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:405
-msgid ""
-"No areas found, but requested to be exported. Will skip this feature type."
+msgid "No areas found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:415
-msgid ""
-"No centroids found, but requested to be exported. Will skip this feature "
-"type."
+msgid "No centroids found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:424
-msgid ""
-"No faces found, but requested to be exported. Will skip this feature type."
+msgid "No faces found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:433
-msgid ""
-"No kernels found, but requested to be exported. Will skip this feature type."
+msgid "No kernels found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:442
-msgid ""
-"No volumes found, but requested to be exported. Will skip this feature type."
+msgid "No volumes found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:467
@@ -17775,23 +17097,17 @@
 #: ../vector/v.out.ogr/main.c:562
 #, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options SHPT "
-"(parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
+msgid "Vector map <%s> is 3D. Use format specific layer creation options SHPT (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
 msgstr ""
 #: ../vector/v.out.ogr/main.c:574
 #, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options DIM "
-"(parameter 'lco') to export in 3D rather than 2D (default)."
+msgid "Vector map <%s> is 3D. Use format specific layer creation options DIM (parameter 'lco') to export in 3D rather than 2D (default)."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:581
 #, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options (parameter"
-" 'lco') to export <in 3D rather than 2D (default)."
+msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export <in 3D rather than 2D (default)."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:598 ../db/drivers/ogr/execute.c:56
@@ -17867,12 +17183,8 @@
 #: ../vector/v.out.ogr/main.c:787
 #, c-format
-msgid ""
-"%d feature without category was skipped. Features without category are "
-"written only when -%c flag is given."
-msgid_plural ""
-"%d features without category were skipped. Features without category are "
+msgid "%d feature without category was skipped. Features without category are written only when -%c flag is given."
+msgid_plural "%d features without category were skipped. Features without category are written only when -%c flag is given."
 msgstr[0] ""
 msgstr[1] ""
 msgstr[2] ""
@@ -17902,8 +17214,7 @@
 #: ../vector/v.out.ogr/export_areas.c:176
 #: ../vector/v.out.ogr/export_lines.c:212
 #, c-format
-msgid ""
-"Unable to create multi-feature. Category %d not found in line %d, field %d"
+msgid "Unable to create multi-feature. Category %d not found in line %d, field %d"
 msgstr ""
 #: ../vector/v.out.ogr/export_areas.c:214
@@ -17932,21 +17243,15 @@
 msgstr ""
 #: ../vector/v.external/main.c:57
-msgid ""
-"Creates a new pseudo-vector map as a link to an OGR-supported layer or a "
-"PostGIS feature table."
+msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer or a PostGIS feature table."
 msgstr ""
 #: ../vector/v.external/main.c:76 ../vector/v.external.out/format.c:22
-msgid ""
-"Environment variable GRASS_VECTOR_OGR defined, but GRASS is compiled with "
-"OGR support. Using GRASS-PostGIS data driver instead."
+msgid "Environment variable GRASS_VECTOR_OGR defined, but GRASS is compiled with OGR support. Using GRASS-PostGIS data driver instead."
 msgstr ""
 #: ../vector/v.external/main.c:81 ../vector/v.external.out/format.c:27
-msgid ""
-"GRASS is not compiled with PostgreSQL support. Using OGR-PostgreSQL driver "
-"instead of native GRASS-PostGIS data driver."
+msgid "GRASS is not compiled with PostgreSQL support. Using OGR-PostgreSQL driver instead of native GRASS-PostGIS data driver."
 msgstr ""
 #: ../vector/v.external/main.c:124
@@ -18061,9 +17366,7 @@
 #: ../vector/v.external/list.c:310
 #, c-format
-msgid ""
-"Unable to convert input map projection to GRASS format. Projection check "
-"cannot be provided for OGR layer <%s>"
+msgid "Unable to convert input map projection to GRASS format. Projection check cannot be provided for OGR layer <%s>"
 msgstr ""
 #: ../vector/v.external/list.c:326
@@ -18077,13 +17380,11 @@
 msgstr ""
 #: ../vector/v.extrude/main.c:72
-msgid ""
-"Extrudes flat vector features to 3D vector features with defined height."
+msgid "Extrudes flat vector features to 3D vector features with defined height."
 msgstr ""
 #: ../vector/v.extrude/main.c:74
-msgid ""
-"Optionally the height can be derived from sampling of elevation raster map."
+msgid "Optionally the height can be derived from sampling of elevation raster map."
 msgstr ""
 #: ../vector/v.extrude/main.c:78
@@ -18101,9 +17402,7 @@
 #: ../vector/v.extrude/main.c:202
 #, c-format
-msgid ""
-"Invalid layer number (%d). Parameter '%s', '%s' or '%s' specified, assuming "
-"layer '1'."
+msgid "Invalid layer number (%d). Parameter '%s', '%s' or '%s' specified, assuming layer '1'."
 msgstr ""
 #: ../vector/v.extrude/main.c:234
@@ -18127,8 +17426,7 @@
 #: ../vector/v.extrude/main.c:293
 #, c-format
-msgid ""
-"Unable to fetch height from DB for area %d. Using default fixed height %f."
+msgid "Unable to fetch height from DB for area %d. Using default fixed height %f."
 msgstr ""
 #: ../vector/v.extrude/main.c:319
@@ -18142,8 +17440,7 @@
 #: ../vector/v.extrude/main.c:346
 #, c-format
-msgid ""
-"Unable to fetch height from DB for line %d. Using default fixed height %f."
+msgid "Unable to fetch height from DB for line %d. Using default fixed height %f."
 msgstr ""
 #: ../vector/v.extrude/main.c:364
@@ -18283,8 +17580,7 @@
 msgstr ""
 #: ../vector/v.build/main.c:49
-msgid ""
-"Name for output vector map where erroneous vector features are written to"
+msgid "Name for output vector map where erroneous vector features are written to"
 msgstr ""
 #: ../vector/v.build/main.c:51 ../vector/v.build/main.c:77
@@ -18326,9 +17622,7 @@
 #: ../vector/v.build/main.c:106
 #, c-format
-msgid ""
-"Direct read access to OGR layers is not supported by this module. Run %s to "
-"create a link as GRASS vector map in the current mapset."
+msgid "Direct read access to OGR layers is not supported by this module. Run %s to create a link as GRASS vector map in the current mapset."
 msgstr ""
 #: ../vector/v.build/main.c:111
@@ -18341,9 +17635,7 @@
 msgstr ""
 #: ../vector/v.rectify/main.c:75
-msgid ""
-"Rectifies a vector by computing a coordinate transformation for each object "
-"in the vector based on the control points."
+msgid "Rectifies a vector by computing a coordinate transformation for each object in the vector based on the control points."
 msgstr ""
 #: ../vector/v.rectify/main.c:90
@@ -18351,8 +17643,7 @@
 msgstr ""
 #: ../vector/v.rectify/main.c:95
-msgid ""
-"Name of output file with RMS errors (if omitted or '-' output to stdout"
+msgid "Name of output file with RMS errors (if omitted or '-' output to stdout"
 msgstr ""
 #: ../vector/v.rectify/main.c:104 ../imagery/i.rectify/main.c:124
@@ -18751,9 +18042,7 @@
 msgstr ""
 #: ../vector/v.net.steiner/main.c:352
-msgid ""
-"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
-"is used in this module so the result may be sub optimal."
+msgid "Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal."
 msgstr ""
 #: ../vector/v.net.steiner/main.c:373
@@ -18805,8 +18094,7 @@
 #: ../vector/v.net.steiner/main.c:538
 #, c-format
-msgid ""
-"[%d] (not reachable) nodes removed from list of Steiner point candidates"
+msgid "[%d] (not reachable) nodes removed from list of Steiner point candidates"
 msgstr ""
 #: ../vector/v.net.steiner/main.c:543
@@ -19209,9 +18497,7 @@
 #: ../vector/v.to.points/main.c:232
 #, c-format
-msgid ""
-"%d features without category in layer <%d> skipped. Note that features "
-"without category (usually boundaries) are not skipped when '%s=-1' is given."
+msgid "%d features without category in layer <%d> skipped. Note that features without category (usually boundaries) are not skipped when '%s=-1' is given."
 msgstr ""
 #: ../vector/v.to.points/main.c:282
@@ -19269,9 +18555,7 @@
 msgstr ""
 #: ../vector/v.in.ascii/main.c:128
-msgid ""
-"For example: 'x double precision, y double precision, cat int, name "
-"varchar(10)'"
+msgid "For example: 'x double precision, y double precision, cat int, name varchar(10)'"
 msgstr ""
 #: ../vector/v.in.ascii/main.c:140 ../vector/v.in.ascii/main.c:150
@@ -19295,9 +18579,7 @@
 msgstr ""
 #: ../vector/v.in.ascii/main.c:172
-msgid ""
-"First column is 1. If 0, unique category is assigned to each row and written"
-" to new column 'cat'"
+msgid "First column is 1. If 0, unique category is assigned to each row and written to new column 'cat'"
 msgstr ""
 #: ../vector/v.in.ascii/main.c:181
@@ -19368,9 +18650,7 @@
 #: ../vector/v.in.ascii/main.c:296 ../vector/v.in.ascii/main.c:300
 #: ../vector/v.in.ascii/main.c:305 ../vector/v.in.ascii/main.c:310
 #, c-format
-msgid ""
-"'%s' column number > minimum last column number (incorrect field separator "
-"or format?)"
+msgid "'%s' column number > minimum last column number (incorrect field separator or format?)"
 msgstr ""
 #: ../vector/v.in.ascii/main.c:315 ../vector/v.in.ascii/main.c:318
@@ -19385,9 +18665,7 @@
 #: ../vector/v.in.ascii/main.c:441
 #, c-format
-msgid ""
-"Number of columns defined (%d) does not match number of columns (%d) in "
-"input"
+msgid "Number of columns defined (%d) does not match number of columns (%d) in input"
 msgstr ""
 #: ../vector/v.in.ascii/main.c:469
@@ -19430,9 +18708,7 @@
 msgstr ""
 #: ../vector/v.in.ascii/main.c:542
-msgid ""
-"Unable to close attribute table. The DBMI driver did not accept all "
-"attributes"
+msgid "Unable to close attribute table. The DBMI driver did not accept all attributes"
 msgstr ""
 #: ../vector/v.in.ascii/points.c:82
@@ -19487,10 +18763,7 @@
 msgstr ""
 #: ../vector/v.net.iso/main.c:78
-msgid ""
-"Splits net to bands between cost isolines (direction from center). Center "
-"node must be opened (costs >= 0). Costs of center node are used in "
-"calculation."
+msgid "Splits net to bands between cost isolines (direction from center). Center node must be opened (costs >= 0). Costs of center node are used in calculation."
 msgstr ""
 #: ../vector/v.net.iso/main.c:98
@@ -19543,14 +18816,11 @@
 msgstr ""
 #: ../vector/v.net.salesman/main.c:133
-msgid ""
-"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
-"created cycle may be sub optimal"
+msgid "Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
 msgstr ""
 #: ../vector/v.net.salesman/main.c:142
-msgid ""
-"Categories of points ('cities') on nodes (layer is specified by nlayer)"
+msgid "Categories of points ('cities') on nodes (layer is specified by nlayer)"
 msgstr ""
 #: ../vector/v.net.salesman/main.c:162
@@ -19607,9 +18877,7 @@
 msgstr ""
 #: ../vector/v.patch/main.c:84
-msgid ""
-"Name for output vector map where bounding boxes of input vector maps are "
-"written to"
+msgid "Name for output vector map where bounding boxes of input vector maps are written to"
 msgstr ""
 #: ../vector/v.patch/main.c:88
@@ -19637,8 +18905,7 @@
 msgstr ""
 #: ../vector/v.patch/main.c:106
-msgid ""
-"Append files to existing file (overwriting existing files must be activated)"
+msgid "Append files to existing file (overwriting existing files must be activated)"
 msgstr ""
 #: ../vector/v.patch/main.c:216
@@ -19749,9 +19016,7 @@
 msgstr ""
 #: ../vector/v.kernel/main.c:115
-msgid ""
-"Density is computed using a moving kernel. Optionally generates a vector "
-"density map on a vector network."
+msgid "Density is computed using a moving kernel. Optionally generates a vector density map on a vector network."
 msgstr ""
 #: ../vector/v.kernel/main.c:119
@@ -19814,9 +19079,7 @@
 msgstr ""
 #: ../vector/v.kernel/main.c:207
-msgid ""
-"Try to calculate an optimal radius with given 'radius' taken as maximum "
-"(experimental)"
+msgid "Try to calculate an optimal radius with given 'radius' taken as maximum (experimental)"
 msgstr ""
 #: ../vector/v.kernel/main.c:212
@@ -19824,9 +19087,7 @@
 msgstr ""
 #: ../vector/v.kernel/main.c:217
-msgid ""
-"In network mode, normalize values by sum of density multiplied by length of "
-"each segment. Integral over the output map then gives 1.0 * mult"
+msgid "In network mode, normalize values by sum of density multiplied by length of each segment. Integral over the output map then gives 1.0 * mult"
 msgstr ""
 #: ../vector/v.kernel/main.c:223
@@ -19834,9 +19095,7 @@
 msgstr ""
 #: ../vector/v.kernel/main.c:236
-msgid ""
-"Use option net_output if you compute network density. Name provided in "
-"option output will be used for net_output."
+msgid "Use option net_output if you compute network density. Name provided in option output will be used for net_output."
 msgstr ""
 #: ../vector/v.kernel/main.c:255
@@ -19848,15 +19107,11 @@
 msgstr ""
 #: ../vector/v.kernel/main.c:279
-msgid ""
-"Optimal standard deviation calculation is supported only for node method "
-"'none' and kernel function 'gaussian'."
+msgid "Optimal standard deviation calculation is supported only for node method 'none' and kernel function 'gaussian'."
 msgstr ""
 #: ../vector/v.kernel/main.c:283
-msgid ""
-"Optimal standard deviation calculation is supported only for kernel function"
-" 'gaussian'."
+msgid "Optimal standard deviation calculation is supported only for kernel function 'gaussian'."
 msgstr ""
 #: ../vector/v.kernel/main.c:300
@@ -19910,9 +19165,7 @@
 #: ../vector/v.kernel/main.c:379
 #, c-format
-msgid ""
-"Automatic choice of smoothing parameter (radius), maximum possible value of "
-"radius is set to %f"
+msgid "Automatic choice of smoothing parameter (radius), maximum possible value of radius is set to %f"
 msgstr ""
 #: ../vector/v.kernel/main.c:386
@@ -19935,9 +19188,7 @@
 #: ../vector/v.kernel/main.c:406
 #, c-format
-msgid ""
-"Distances between all points are beyond %e (4 * standard deviation), unable "
-"to calculate optimal value."
+msgid "Distances between all points are beyond %e (4 * standard deviation), unable to calculate optimal value."
 msgstr ""
 #: ../vector/v.kernel/main.c:417
@@ -19999,9 +19250,7 @@
 msgstr ""
 #: ../vector/v.clean/main.c:100
-msgid ""
-"change the type of boundary dangle to line, threshold ignored if < 0, input "
-"line type is ignored"
+msgid "change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored"
 msgstr ""
 #: ../vector/v.clean/main.c:102
@@ -20009,9 +19258,7 @@
 msgstr ""
 #: ../vector/v.clean/main.c:103
-msgid ""
-"change the type of bridges connecting area and island or 2 islands from "
-"boundary to line"
+msgid "change the type of bridges connecting area and island or 2 islands from boundary to line"
 msgstr ""
 #: ../vector/v.clean/main.c:105
@@ -20023,17 +19270,11 @@
 msgstr ""
 #: ../vector/v.clean/main.c:107
-msgid ""
-"break (topologically clean) polygons (imported from non topological format, "
-"like ShapeFile). Boundaries are broken on each point shared between 2 and "
-"more polygons where angles of segments are different"
+msgid "break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different"
 msgstr ""
 #: ../vector/v.clean/main.c:110
-msgid ""
-"remove vertices in threshold from lines and boundaries, boundary is pruned "
-"only if topology is not damaged (new intersection, changed attachment of "
-"centroid), first and last segment of the boundary is never changed"
+msgid "remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachment of centroid), first and last segment of the boundary is never changed"
 msgstr ""
 #: ../vector/v.clean/main.c:114
@@ -20073,9 +19314,7 @@
 msgstr ""
 #: ../vector/v.clean/main.c:202
-msgid ""
-"Note: In latitude-longitude coordinate system specify threshold in degree "
-"unit"
+msgid "Note: In latitude-longitude coordinate system specify threshold in degree unit"
 msgstr ""
 #: ../vector/v.clean/main.c:215
@@ -20231,8 +19470,7 @@
 #: ../vector/v.clean/prune.c:216
 #, c-format
-msgid ""
-"%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
+msgid "%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
 msgstr ""
 #: ../vector/v.clean/prune.c:220
@@ -20281,14 +19519,11 @@
 #: ../vector/v.out.vtk/main.c:183
 #, c-format
-msgid ""
-"Export of areas requires topology. Please adjust '%s' option or rebuild "
-"topology."
+msgid "Export of areas requires topology. Please adjust '%s' option or rebuild topology."
 msgstr ""
 #: ../vector/v.out.vtk/writeVTK.c:196
-msgid ""
-"No coordinates to generate the output! Maybe an empty vector type chosen?"
+msgid "No coordinates to generate the output! Maybe an empty vector type chosen?"
 msgstr ""
 #: ../vector/v.out.vtk/writeVTK.c:632
@@ -20375,9 +19610,7 @@
 msgstr ""
 #: ../vector/v.overlay/main.c:70
-msgid ""
-"Overlays two vector maps offering clip, intersection, difference, "
-"symmetrical difference, union operators."
+msgid "Overlays two vector maps offering clip, intersection, difference, symmetrical difference, union operators."
 msgstr ""
 #: ../vector/v.overlay/main.c:73
@@ -20401,10 +19634,7 @@
 msgstr ""
 #: ../vector/v.overlay/main.c:109
-msgid ""
-"Feature is written to output if the result of operation 'ainput operator "
-"binput' is true. Input feature is considered to be true, if category of "
+msgid "Feature is written to output if the result of operation 'ainput operator binput' is true. Input feature is considered to be true, if category of given layer is defined."
 msgstr ""
 #: ../vector/v.overlay/main.c:116
@@ -20416,15 +19646,11 @@
 msgstr ""
 #: ../vector/v.overlay/main.c:118
-msgid ""
-"also known as 'difference' (features from ainput not overlayed by features "
-"from binput)"
+msgid "also known as 'difference' (features from ainput not overlayed by features from binput)"
 msgstr ""
 #: ../vector/v.overlay/main.c:120
-msgid ""
-"also known as 'symmetrical difference' (features from either ainput or "
-"binput but not those from ainput overlayed by binput (only for atype=area)"
+msgid "also known as 'symmetrical difference' (features from either ainput or binput but not those from ainput overlayed by binput (only for atype=area)"
 msgstr ""
 #: ../vector/v.overlay/main.c:131
@@ -20585,8 +19811,7 @@
 #: ../vector/v.net.path/path.c:233
 #, c-format
-msgid ""
-"Point with category [%d] is not reachable from point with category [%d]"
+msgid "Point with category [%d] is not reachable from point with category [%d]"
 msgstr ""
 #: ../vector/v.net.path/path.c:302
@@ -20614,8 +19839,7 @@
 msgstr ""
 #: ../vector/v.net.path/main.c:72
-msgid ""
-"Name of file containing start and end points. If not given, read from stdin"
+msgid "Name of file containing start and end points. If not given, read from stdin"
 msgstr ""
 #: ../vector/v.net.path/main.c:101
@@ -20623,10 +19847,7 @@
 msgstr ""
 #: ../vector/v.net.path/main.c:102
-msgid ""
-"If start/end are given as coordinates. If start/end point is outside this "
-"threshold, the path is not found and error message is printed. To speed up "
-"the process, keep this value as low as possible."
+msgid "If start/end are given as coordinates. If start/end point is outside this threshold, the path is not found and error message is printed. To speed up the process, keep this value as low as possible."
 msgstr ""
 #: ../vector/v.neighbors/main.c:55
@@ -20634,10 +19855,7 @@
 msgstr ""
 #: ../vector/v.neighbors/main.c:56
-msgid ""
-"Makes each cell value a function of the attribute values assigned to the "
-"vector points or centroids around it, and stores new cell values in an "
-"output raster map."
+msgid "Makes each cell value a function of the attribute values assigned to the vector points or centroids around it, and stores new cell values in an output raster map."
 msgstr ""
 #: ../vector/v.neighbors/main.c:72 ../raster/r.neighbors/main.c:204
@@ -20654,9 +19872,7 @@
 #: ../vector/v.neighbors/main.c:103
 #, c-format
-msgid ""
-"The search diameter %g is smaller than cell diagonal %g: some points could "
-"not be detected"
+msgid "The search diameter %g is smaller than cell diagonal %g: some points could not be detected"
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:75
@@ -20670,9 +19886,7 @@
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:88
-msgid ""
-"Maybe it takes too long. It will depend on how many points you are "
-"considering."
+msgid "Maybe it takes too long. It will depend on how many points you are considering."
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:119
@@ -20688,9 +19902,7 @@
 #: ../vector/v.surf.bspline/crosscorr.c:151
 #: ../raster/r.resamp.bspline/crosscorr.c:197
 #, c-format
-msgid ""
-"Too many splines (%d x %d). Consider changing spline steps \"ew_step=\" "
-"\"ns_step=\"."
+msgid "Too many splines (%d x %d). Consider changing spline steps \"ew_step=\" \"ns_step=\"."
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:169
@@ -20719,16 +19931,13 @@
 #: ../vector/v.surf.bspline/crosscorr.c:313
 #: ../raster/r.resamp.bspline/crosscorr.c:324
-msgid ""
-"Different number of splines and lambda_i values have been taken for the "
-"cross correlation"
+msgid "Different number of splines and lambda_i values have been taken for the cross correlation"
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:315
 #: ../raster/r.resamp.bspline/crosscorr.c:326
 #, c-format
-msgid ""
-"The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
+msgid "The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:323
@@ -20748,15 +19957,11 @@
 msgstr ""
 #: ../vector/v.surf.bspline/main.c:96
-msgid ""
-"Performs bicubic or bilinear spline interpolation with Tykhonov "
-"regularization."
+msgid "Performs bicubic or bilinear spline interpolation with Tykhonov regularization."
 msgstr ""
 #: ../vector/v.surf.bspline/main.c:101 ../raster/r.resamp.bspline/main.c:144
-msgid ""
-"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
-"cross validation method"
+msgid "Find the best Tykhonov regularizing parameter using a \"leave-one-out\" cross validation method"
 msgstr ""
 #: ../vector/v.surf.bspline/main.c:105 ../vector/v.outlier/main.c:79
@@ -20845,9 +20050,7 @@
 #: ../vector/v.surf.bspline/main.c:338
 #, c-format
-msgid ""
-"Sorry, the <%s> driver is not compatible with the vector output of this "
-"module. Try with raster output or another driver."
+msgid "Sorry, the <%s> driver is not compatible with the vector output of this module. Try with raster output or another driver."
 msgstr ""
 #: ../vector/v.surf.bspline/main.c:361
@@ -20923,9 +20126,7 @@
 msgstr ""
 #: ../vector/v.surf.idw/main.c:92
-msgid ""
-"Provides surface interpolation from vector point data by Inverse Distance "
-"Squared Weighting."
+msgid "Provides surface interpolation from vector point data by Inverse Distance Squared Weighting."
 msgstr ""
 #: ../vector/v.surf.idw/main.c:101
@@ -20953,9 +20154,7 @@
 msgstr ""
 #: ../vector/v.surf.idw/main.c:129
-msgid ""
-"Slower but uses less memory and includes points from outside region in the "
-"interpolation"
+msgid "Slower but uses less memory and includes points from outside region in the interpolation"
 msgstr ""
 #: ../vector/v.surf.idw/main.c:139
@@ -21035,9 +20234,7 @@
 msgstr ""
 #: ../vector/v.buffer/main.c:293
-msgid ""
-"Maximum distance between theoretical arc and polygon segments as multiple of"
-" buffer"
+msgid "Maximum distance between theoretical arc and polygon segments as multiple of buffer"
 msgstr ""
 #: ../vector/v.buffer/main.c:298
@@ -21053,9 +20250,7 @@
 msgstr ""
 #: ../vector/v.buffer/main.c:326
-msgid ""
-"Note: In latitude-longitude coordinate system specify distances in degree "
-"unit"
+msgid "Note: In latitude-longitude coordinate system specify distances in degree unit"
 msgstr ""
 #: ../vector/v.buffer/main.c:330
@@ -21090,9 +20285,7 @@
 msgstr ""
 #: ../vector/v.buffer/main.c:464
-msgid ""
-"No features available for buffering. Check type option and features "
-"available in the input vector."
+msgid "No features available for buffering. Check type option and features available in the input vector."
 msgstr ""
 #: ../vector/v.buffer/main.c:481
@@ -21101,9 +20294,7 @@
 msgstr ""
 #: ../vector/v.buffer/main.c:486
-msgid ""
-"Negative distances for internal buffers are not supported and converted to "
-"positive values."
+msgid "Negative distances for internal buffers are not supported and converted to positive values."
 msgstr ""
 #: ../vector/v.buffer/main.c:496
@@ -21226,8 +20417,7 @@
 msgstr ""
 #: ../vector/v.outlier/main.c:355
-msgid ""
-"No subregions found! Check values for 'ew_step' and 'ns_step' parameters"
+msgid "No subregions found! Check values for 'ew_step' and 'ns_step' parameters"
 msgstr ""
 #: ../vector/v.outlier/main.c:428
@@ -21346,9 +20536,7 @@
 msgstr ""
 #: ../db/db.copy/main.c:40
-msgid ""
-"Either 'from_table' (optionally with 'where') can be used or 'select' "
-"option, but not 'from_table' and 'select' at the same time."
+msgid "Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
 msgstr ""
 #: ../db/db.copy/main.c:46
@@ -21425,9 +20613,7 @@
 msgstr ""
 #: ../db/db.databases/main.c:53
-msgid ""
-"Unable to list databases. Try to define correct connection settings by "
-"db.login."
+msgid "Unable to list databases. Try to define correct connection settings by db.login."
 msgstr ""
 #: ../db/db.databases/main.c:63
@@ -21520,23 +20706,17 @@
 #: ../db/drivers/postgres/describe.c:130 ../db/drivers/ogr/describe.c:186
 #, c-format
-msgid ""
-"Column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
-"may be damaged"
+msgid "Column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data may be damaged"
 msgstr ""
 #: ../db/drivers/postgres/describe.c:134
 #, c-format
-msgid ""
-"Column '%s' : type character varying is stored as varchar(250) some data may"
-" be lost"
+msgid "Column '%s' : type character varying is stored as varchar(250) some data may be lost"
 msgstr ""
 #: ../db/drivers/postgres/describe.c:140
 #, c-format
-msgid ""
-"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1"
-" (true)"
+msgid "column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 (true)"
 msgstr ""
 #: ../db/drivers/postgres/execute.c:42 ../db/drivers/mysql/execute.c:41
@@ -21863,9 +21043,7 @@
 #: ../db/drivers/mysql/describe.c:127
 #, c-format
-msgid ""
-"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
-"damaged"
+msgid "column '%s' : type BIGINT is stored as integer (4 bytes) some data may be damaged"
 msgstr ""
 #: ../db/drivers/mysql/execute.c:62
@@ -21952,9 +21130,7 @@
 #: ../db/drivers/ogr/describe.c:204
 #, c-format
-msgid ""
-"column '%s', type 'string': unknown width -> stored as varchar(250) some "
-"data may be lost"
+msgid "column '%s', type 'string': unknown width -> stored as varchar(250) some data may be lost"
 msgstr ""
 #: ../db/drivers/ogr/describe.c:212 ../db/drivers/ogr/fetch.c:160
@@ -22049,8 +21225,7 @@
 msgstr ""
 #: ../db/drivers/sqlite/fetch.c:218
-msgid ""
-"SQLite driver: parsing of interval values not implemented; assuming seconds"
+msgid "SQLite driver: parsing of interval values not implemented; assuming seconds"
 msgstr ""
 #: ../db/drivers/sqlite/fetch.c:223
@@ -22207,9 +21382,7 @@
 msgstr ""
 #: ../display/d.rgb/main.c:58
-msgid ""
-"Displays three user-specified raster maps as red, green, and blue overlays "
-"in the active graphics frame."
+msgid "Displays three user-specified raster maps as red, green, and blue overlays in the active graphics frame."
 msgstr ""
 #: ../display/d.rgb/main.c:63 ../display/d.rast/main.c:81
@@ -22239,9 +21412,7 @@
 msgstr ""
 #: ../display/d.linegraph/main.c:126
-msgid ""
-"Generates and displays simple line graphs in the active graphics monitor "
-"display frame."
+msgid "Generates and displays simple line graphs in the active graphics monitor display frame."
 msgstr ""
 #: ../display/d.linegraph/main.c:130
@@ -22550,15 +21721,11 @@
 msgstr ""
 #: ../display/d.graph/main.c:61
-msgid ""
-"Program for generating and displaying simple graphics on the display "
-"monitor."
+msgid "Program for generating and displaying simple graphics on the display monitor."
 msgstr ""
 #: ../display/d.graph/main.c:66
-msgid ""
-"Name of file containing graphics commands, if not given reads from standard "
-"input"
+msgid "Name of file containing graphics commands, if not given reads from standard input"
 msgstr ""
 #: ../display/d.graph/main.c:73
@@ -22638,9 +21805,7 @@
 msgstr ""
 #: ../display/d.grid/main.c:58
-msgid ""
-"Overlays a user-specified grid in the active display frame on the graphics "
-"monitor."
+msgid "Overlays a user-specified grid in the active display frame on the graphics monitor."
 msgstr ""
 #: ../display/d.grid/main.c:66
@@ -22648,9 +21813,7 @@
 msgstr ""
 #: ../display/d.grid/main.c:68
-msgid ""
-"0 for north-south resolution of the current region. In map units or "
-"DDD:MM:SS format. Example: \"1000\" or \"0:10\""
+msgid "0 for north-south resolution of the current region. In map units or DDD:MM:SS format. Example: \"1000\" or \"0:10\""
 msgstr ""
 #: ../display/d.grid/main.c:76
@@ -22792,9 +21955,7 @@
 msgstr ""
 #: ../display/d.text/main.c:142
-msgid ""
-"Draws text in the active display frame on the graphics monitor using the "
-"current font."
+msgid "Draws text in the active display frame on the graphics monitor using the current font."
 msgstr ""
 #: ../display/d.text/main.c:148
@@ -22828,9 +21989,7 @@
 msgstr ""
 #: ../display/d.text/main.c:198
-msgid ""
-"Screen position at which text will begin to be drawn (percentage, [0,0] is "
-"lower left)"
+msgid "Screen position at which text will begin to be drawn (percentage, [0,0] is lower left)"
 msgstr ""
 #: ../display/d.text/main.c:199 ../display/d.text/main.c:208
@@ -22942,14 +22101,12 @@
 #: ../display/d.colortable/main.c:112
 #, c-format
-msgid ""
-"<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
+msgid "<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
 msgstr ""
 #: ../display/d.colortable/main.c:126
 #, c-format
-msgid ""
-"<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
+msgid "<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
 msgstr ""
 #: ../display/d.colortable/main.c:137
@@ -23153,9 +22310,7 @@
 msgstr ""
 #: ../display/d.his/main.c:69
-msgid ""
-"Displays the result obtained by combining hue, intensity, and saturation "
-"(HIS) values from user-specified input raster map layers."
+msgid "Displays the result obtained by combining hue, intensity, and saturation (HIS) values from user-specified input raster map layers."
 msgstr ""
 #: ../display/d.his/main.c:78 ../raster/r.his/main.c:82
@@ -23183,9 +22338,7 @@
 msgstr ""
 #: ../display/d.histogram/main.c:87
-msgid ""
-"Displays a histogram in the form of a pie or bar chart for a user-specified "
-"raster map."
+msgid "Displays a histogram in the form of a pie or bar chart for a user-specified raster map."
 msgstr ""
 #: ../display/d.histogram/main.c:91
@@ -23237,8 +22390,7 @@
 msgstr ""
 #: ../display/d.title/main.c:52
-msgid ""
-"Create a TITLE for a raster map in a form suitable for display with d.text."
+msgid "Create a TITLE for a raster map in a form suitable for display with d.text."
 msgstr ""
 #: ../display/d.title/main.c:63
@@ -23274,8 +22426,7 @@
 msgstr ""
 #: ../display/d.vect.chart/main.c:67
-msgid ""
-"Displays charts of vector data in the active frame on the graphics monitor."
+msgid "Displays charts of vector data in the active frame on the graphics monitor."
 msgstr ""
 #: ../display/d.vect.chart/main.c:86
@@ -23330,9 +22481,7 @@
 msgstr ""
 #: ../display/d.erase/main.c:33
-msgid ""
-"Erases the contents of the active graphics display frame with user defined "
-"color."
+msgid "Erases the contents of the active graphics display frame with user defined color."
 msgstr ""
 #: ../display/d.erase/main.c:42
@@ -23406,9 +22555,7 @@
 msgstr ""
 #: ../display/d.rast.arrow/main.c:101
-msgid ""
-"Draws arrows representing cell aspect direction for a raster map containing "
-"aspect data."
+msgid "Draws arrows representing cell aspect direction for a raster map containing aspect data."
 msgstr ""
 #: ../display/d.rast.arrow/main.c:105
@@ -23509,9 +22656,7 @@
 msgstr ""
 #: ../display/d.labels/main.c:46
-msgid ""
-"Displays text labels (created with v.label) to the active frame on the "
-"graphics monitor."
+msgid "Displays text labels (created with v.label) to the active frame on the graphics monitor."
 msgstr ""
 #: ../display/d.labels/main.c:52
@@ -23634,9 +22779,7 @@
 msgstr ""
 #: ../display/d.vect.thematic/main.c:237
-msgid ""
-"When printing legend info, include extended statistical info from "
-"classification algorithm"
+msgid "When printing legend info, include extended statistical info from classification algorithm"
 msgstr ""
 #: ../display/d.vect.thematic/main.c:243 ../display/d.vect/main.c:330
@@ -23644,16 +22787,11 @@
 msgstr ""
 #: ../display/d.vect.thematic/main.c:255
-msgid ""
-"Flag -e is deprecated, set verbose mode with --v to get the extended "
-"statistical info."
+msgid "Flag -e is deprecated, set verbose mode with --v to get the extended statistical info."
 msgstr ""
 #: ../display/d.vect.thematic/main.c:258
-msgid ""
-"Option legendfile is deprecated, either use flag -l to print legend to "
-"standard output, or set GRASS_LEGEND_FILE environment variable (see "
-"d.legend.vect for details)."
+msgid "Option legendfile is deprecated, either use flag -l to print legend to standard output, or set GRASS_LEGEND_FILE environment variable (see d.legend.vect for details)."
 msgstr ""
 #: ../display/d.vect.thematic/main.c:277
@@ -23670,8 +22808,7 @@
 msgid "Data (%s) not numeric. Column must be numeric."
 msgstr ""
-#: ../display/d.vect.thematic/main.c:316
-#: ../display/d.vect.thematic/plot1.c:135
+#: ../display/d.vect.thematic/main.c:316 ../display/d.vect.thematic/plot1.c:135
 #: ../display/d.vect.thematic/plot1.c:163
 #, c-format
 msgid "Cannot select data (%s) from table"
@@ -23683,9 +22820,7 @@
 msgstr ""
 #: ../display/d.vect.thematic/main.c:390
-msgid ""
-"You gave both manual breaks and a classification algorithm or a number of "
-"classes. The manual breaks have precedence and will thus be used."
+msgid "You gave both manual breaks and a classification algorithm or a number of classes. The manual breaks have precedence and will thus be used."
 msgstr ""
 #: ../display/d.vect.thematic/main.c:427
@@ -23709,8 +22844,7 @@
 msgstr ""
 #: ../display/d.vect.thematic/main.c:469
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn."
+msgid "The bounding box of the map is outside the current region, nothing drawn."
 msgstr ""
 #: ../display/d.vect.thematic/main.c:522
@@ -23736,9 +22870,7 @@
 #: ../display/d.vect.thematic/plot1.c:130
 #, c-format
-msgid ""
-"Color definition column (%s) not a string. Column must be of form "
-"RRR:GGG:BBB where RGB values range 0-255."
+msgid "Color definition column (%s) not a string. Column must be of form RRR:GGG:BBB where RGB values range 0-255."
 msgstr ""
 #: ../display/d.vect.thematic/plot1.c:148
@@ -23759,9 +22891,7 @@
 #: ../display/d.vect.thematic/plot1.c:279
 #, c-format
-msgid ""
-"Error in color definition column (%s), element %d with cat %d: colorstring "
-"[%s]"
+msgid "Error in color definition column (%s), element %d with cat %d: colorstring [%s]"
 msgstr ""
 #: ../display/d.vect.thematic/plot1.c:286
@@ -23771,8 +22901,7 @@
 #: ../display/d.vect.thematic/plot1.c:354
 #, c-format
-msgid ""
-"Error in line width column (%s), element %d with cat %d: line width [%d]"
+msgid "Error in line width column (%s), element %d with cat %d: line width [%d]"
 msgstr ""
 #: ../display/d.vect.thematic/display.c:51 ../display/d.vect/lines.c:107
@@ -23822,9 +22951,7 @@
 msgstr[2] ""
 #: ../display/d.vect/area.c:37
-msgid ""
-"Unable to display areas, topology not available. Please try to rebuild "
-"topology using v.build or v.build.all."
+msgid "Unable to display areas, topology not available. Please try to rebuild topology using v.build or v.build.all."
 msgstr ""
 #: ../display/d.vect/area.c:137
@@ -23854,9 +22981,7 @@
 msgstr ""
 #: ../display/d.vect/lines.c:121
-msgid ""
-"Unable to display features by id, topology not available. Please try to "
-"rebuild topology using v.build or v.build.all."
+msgid "Unable to display features by id, topology not available. Please try to rebuild topology using v.build or v.build.all."
 msgstr ""
 #: ../display/d.vect/lines.c:169
@@ -24005,19 +23130,15 @@
 msgstr ""
 #: ../display/d.vect/main.c:295
-msgid ""
-"Minimum region size (average from height and width) when map is displayed"
+msgid "Minimum region size (average from height and width) when map is displayed"
 msgstr ""
 #: ../display/d.vect/main.c:303
-msgid ""
-"Maximum region size (average from height and width) when map is displayed"
+msgid "Maximum region size (average from height and width) when map is displayed"
 msgstr ""
 #: ../display/d.vect/main.c:311
-msgid ""
-"Random colors according to category number (or layer number if 'layer=-1' is"
-" given)"
+msgid "Random colors according to category number (or layer number if 'layer=-1' is given)"
 msgstr ""
 #: ../display/d.vect/main.c:318
@@ -24029,9 +23150,7 @@
 msgstr ""
 #: ../display/d.vect/main.c:324
-msgid ""
-"This makes circle areas proportionate to the size_column values instead of "
-"circle radius"
+msgid "This makes circle areas proportionate to the size_column values instead of circle radius"
 msgstr ""
 #: ../display/d.vect/main.c:347
@@ -24044,9 +23163,7 @@
 #: ../display/d.vect/main.c:368
 #, c-format
-msgid ""
-"The -%c flag and <%s> option cannot be used together, the -%c flag will be "
-"ignored!"
+msgid "The -%c flag and <%s> option cannot be used together, the -%c flag will be ignored!"
 msgstr ""
 #: ../display/d.vect/main.c:392 ../display/d.vect/main.c:398
@@ -24067,8 +23184,7 @@
 msgstr ""
 #: ../display/d.vect/main.c:426
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn"
+msgid "The bounding box of the map is outside the current region, nothing drawn"
 msgstr ""
 #: ../display/d.vect/main.c:500
@@ -24087,10 +23203,7 @@
 #: ../display/d.vect/shape.c:68
 #, c-format
-msgid ""
-"Color definition column ('%s') not a string. Column must be of form "
-"'RRR:GGG:BBB' where RGB values range 0-255. You can use '%s' module to "
-"define color rules. Unable to colorize features."
+msgid "Color definition column ('%s') not a string. Column must be of form 'RRR:GGG:BBB' where RGB values range 0-255. You can use '%s' module to define color rules. Unable to colorize features."
 msgstr ""
 #: ../display/d.vect/shape.c:77 ../display/d.vect/shape.c:100
@@ -24127,8 +23240,7 @@
 msgstr ""
 #: ../display/d.vect/shape.c:182
-msgid ""
-"Vector map is not 3D. Unable to colorize features based on z-coordinates."
+msgid "Vector map is not 3D. Unable to colorize features based on z-coordinates."
 msgstr ""
 #: ../display/d.vect/shape.c:186
@@ -24142,9 +23254,7 @@
 msgstr ""
 #: ../display/d.vect/topo.c:18
-msgid ""
-"Unable to display topology, not available.Please try to rebuild topology "
-"using v.build or v.build.all."
+msgid "Unable to display topology, not available.Please try to rebuild topology using v.build or v.build.all."
 msgstr ""
 #: ../display/d.vect/zcoor.c:19
@@ -24152,9 +23262,7 @@
 msgstr ""
 #: ../display/d.font/main.c:48
-msgid ""
-"Selects the font in which text will be displayed on the user's graphics "
-"monitor."
+msgid "Selects the font in which text will be displayed on the user's graphics monitor."
 msgstr ""
 #: ../display/d.font/main.c:56
@@ -24189,8 +23297,7 @@
 #: ../display/d.font/main.c:124
 #, c-format
-msgid ""
-"Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
+msgid "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
 msgstr ""
 #: ../display/d.fontlist/main.c:47
@@ -24202,9 +23309,7 @@
 msgstr ""
 #: ../display/d.rast.num/main.c:81
-msgid ""
-"Overlays cell category values on a raster map displayed in the active "
-"graphics frame."
+msgid "Overlays cell category values on a raster map displayed in the active graphics frame."
 msgstr ""
 #: ../display/d.rast.num/main.c:112
@@ -24232,14 +23337,11 @@
 msgstr ""
 #: ../display/d.legend/histogram.c:115
-msgid ""
-"Histogram constrained by range not yet implemented for categorical rasters"
+msgid "Histogram constrained by range not yet implemented for categorical rasters"
 msgstr ""
 #: ../display/d.legend/main.c:82
-msgid ""
-"Displays a legend for a 2D or 3D raster map in the active frame of the "
+msgid "Displays a legend for a 2D or 3D raster map in the active frame of the graphics monitor."
 msgstr ""
 #: ../display/d.legend/main.c:99 ../display/d.legend.vect/main.c:81
@@ -24303,8 +23405,7 @@
 msgstr ""
 #: ../display/d.legend/main.c:179
-msgid ""
-"Size and placement as percentage of screen coordinates (0,0 is lower left)"
+msgid "Size and placement as percentage of screen coordinates (0,0 is lower left)"
 msgstr ""
 #: ../display/d.legend/main.c:189
@@ -24420,9 +23521,7 @@
 msgstr ""
 #: ../display/d.legend/draw.c:1029
-msgid ""
-"Histogram plotting not implemented for categorical legends. Use the '-s' "
-"flag"
+msgid "Histogram plotting not implemented for categorical legends. Use the '-s' flag"
 msgstr ""
 #: ../display/d.legend/draw.c:1286
@@ -24460,9 +23559,7 @@
 msgstr ""
 #: ../display/d.where/main.c:48
-msgid ""
-"Identifies the geographic coordinates associated with point locations given "
-"in display coordinates."
+msgid "Identifies the geographic coordinates associated with point locations given in display coordinates."
 msgstr ""
 #: ../display/d.where/main.c:58
@@ -24482,9 +23579,7 @@
 msgstr ""
 #: ../display/d.where/main.c:77
-msgid ""
-"Output lat/long referenced to WGS84 ellipsoid using datum transformation "
-"parameters defined in current location (if available)"
+msgid "Output lat/long referenced to WGS84 ellipsoid using datum transformation parameters defined in current location (if available)"
 msgstr ""
 #: ../display/d.where/main.c:83
@@ -24625,9 +23720,7 @@
 msgstr ""
 #: ../display/d.geodesic/main.c:51
-msgid ""
-"Displays a geodesic line, tracing the shortest distance between two "
-"geographic points along a great circle, in a longitude/latitude data set."
+msgid "Displays a geodesic line, tracing the shortest distance between two geographic points along a great circle, in a longitude/latitude data set."
 msgstr ""
 #: ../display/d.legend.vect/main.c:55
@@ -24635,8 +23728,7 @@
 msgstr ""
 #: ../display/d.legend.vect/main.c:66
-msgid ""
-"Screen position of legend to be drawn (percentage, [0,0] is lower left)"
+msgid "Screen position of legend to be drawn (percentage, [0,0] is lower left)"
 msgstr ""
 #: ../display/d.legend.vect/main.c:74
@@ -24817,9 +23909,7 @@
 msgstr ""
 #: ../imagery/i.rgb.his/main.c:52
-msgid ""
-"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
-"Intensity-Saturation) color space."
+msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
 msgstr ""
 #: ../imagery/i.rgb.his/main.c:58
@@ -24923,9 +24013,7 @@
 msgstr ""
 #: ../imagery/i.eb.netrad/main.c:85
-msgid ""
-"Name of the difference map of temperature from surface skin to about 2 m "
-"height [K]"
+msgid "Name of the difference map of temperature from surface skin to about 2 m height [K]"
 msgstr ""
 #: ../imagery/i.eb.netrad/main.c:89
@@ -24954,9 +24042,7 @@
 msgstr ""
 #: ../imagery/i.evapo.pm/main.c:61
-msgid ""
-"Computes potential evapotranspiration calculation with hourly Penman-"
-"Monteith."
+msgid "Computes potential evapotranspiration calculation with hourly Penman-Monteith."
 msgstr ""
 #: ../imagery/i.evapo.pm/main.c:65
@@ -25155,9 +24241,7 @@
 msgstr ""
 #: ../imagery/i.maxlik/main.c:68
-msgid ""
-"Classification is based on the spectral signature information generated by "
-"either i.cluster, g.gui.iclass, or i.gensig."
+msgid "Classification is based on the spectral signature information generated by either i.cluster, g.gui.iclass, or i.gensig."
 msgstr ""
 #: ../imagery/i.maxlik/main.c:81 ../imagery/i.smap/parse.c:20
@@ -25178,16 +24262,12 @@
 #: ../imagery/i.maxlik/open.c:27
 #, c-format
-msgid ""
-"Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
-"have at least 2 raster maps."
+msgid "Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must have at least 2 raster maps."
 msgstr ""
 #: ../imagery/i.maxlik/open.c:30
 #, c-format
-msgid ""
-"Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at"
-" least 2 raster maps."
+msgid "Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at least 2 raster maps."
 msgstr ""
 #: ../imagery/i.maxlik/open.c:47
@@ -25241,9 +24321,7 @@
 msgstr ""
 #: ../imagery/i.rectify/main.c:102
-msgid ""
-"Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points."
+msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
 msgstr ""
 #: ../imagery/i.rectify/main.c:116
@@ -25263,9 +24341,7 @@
 #: ../imagery/i.rectify/main.c:153
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:137
-msgid ""
-"Use current region settings in target location (def.=calculate smallest "
-"area)"
+msgid "Use current region settings in target location (def.=calculate smallest area)"
 msgstr ""
 #: ../imagery/i.rectify/main.c:157
@@ -25448,8 +24524,7 @@
 msgstr ""
 #: ../imagery/i.vi/main.c:94
-msgid ""
-"Uses red and nir bands mostly, and some indices require additional bands."
+msgid "Uses red and nir bands mostly, and some indices require additional bands."
 msgstr ""
 #: ../imagery/i.vi/main.c:101
@@ -25576,9 +24651,7 @@
 msgstr ""
 #: ../imagery/i.vi/main.c:202
-msgid ""
-"If data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8"
-" for Landsat -> [0-255])"
+msgid "If data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8 for Landsat -> [0-255])"
 msgstr ""
 #: ../imagery/i.vi/main.c:225 ../raster/r.texture/main.c:327
@@ -25615,8 +24688,7 @@
 msgstr ""
 #: ../imagery/i.vi/main.c:251
-msgid ""
-"msavi index requires red and nir maps, and 3 parameters related to soil line"
+msgid "msavi index requires red and nir maps, and 3 parameters related to soil line"
 msgstr ""
 #: ../imagery/i.vi/main.c:254
@@ -25688,9 +24760,7 @@
 msgstr ""
 #: ../imagery/i.evapo.mh/main.c:72
-msgid ""
-"Computes evapotranspiration calculation modified or original Hargreaves "
-"formulation, 2001."
+msgid "Computes evapotranspiration calculation modified or original Hargreaves formulation, 2001."
 msgstr ""
 #: ../imagery/i.evapo.mh/main.c:78
@@ -25775,9 +24845,7 @@
 msgstr ""
 #: ../imagery/i.smap/main.c:44
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
+msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
 msgstr ""
 #: ../imagery/i.smap/model.c:43
@@ -25885,15 +24953,11 @@
 msgstr ""
 #: ../imagery/i.cluster/main.c:79
-msgid ""
-"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm."
+msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
 msgstr ""
 #: ../imagery/i.cluster/main.c:82
-msgid ""
-"The resulting signature file is used as input for i.maxlik, to generate an "
-"unsupervised image classification."
+msgid "The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
 msgstr ""
 #: ../imagery/i.cluster/main.c:102
@@ -26083,14 +25147,11 @@
 msgstr ""
 #: ../imagery/i.cluster/main.c:312
-msgid ""
-"Not enough sample points. Please run again and choose a larger sample size."
+msgid "Not enough sample points. Please run again and choose a larger sample size."
 msgstr ""
 #: ../imagery/i.cluster/main.c:316
-msgid ""
-"Not enough non-zero sample data points. Check your current region (and "
-"mask)."
+msgid "Not enough non-zero sample data points. Check your current region (and mask)."
 msgstr ""
 #: ../imagery/i.cluster/main.c:329
@@ -26318,9 +25379,7 @@
 msgstr ""
 #: ../imagery/i.aster.toar/main.c:105
-msgid ""
-"Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
-"from ASTER DN."
+msgid "Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature from ASTER DN."
 msgstr ""
 #: ../imagery/i.aster.toar/main.c:109
@@ -26373,9 +25432,7 @@
 msgstr ""
 #: ../imagery/i.his.rgb/main.c:52
-msgid ""
-"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
-"RGB (Red-Green-Blue) color space."
+msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
 msgstr ""
 #: ../imagery/i.his.rgb/main.c:58
@@ -26423,9 +25480,7 @@
 msgstr ""
 #: ../imagery/i.evapo.time/main.c:79
-msgid ""
-"Computes temporal integration of satellite ET actual (ETa) following the "
-"daily ET reference (ETo) from meteorological station(s)."
+msgid "Computes temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)."
 msgstr ""
 #: ../imagery/i.evapo.time/main.c:86
@@ -26522,15 +25577,13 @@
 msgid "Group <%s> not found in the current mapset"
 msgstr ""
-#: ../imagery/i.segment/write_output.c:100
-#: ../imagery/i.segment/open_files.c:44
+#: ../imagery/i.segment/write_output.c:100 ../imagery/i.segment/open_files.c:44
 #, c-format
 msgid "Group <%s> contains no raster maps"
 msgstr ""
-#: ../imagery/i.segment/write_output.c:116
-#: ../imagery/i.segment/open_files.c:69 ../imagery/i.segment/open_files.c:228
-#: ../imagery/i.segment/open_files.c:236
+#: ../imagery/i.segment/write_output.c:116 ../imagery/i.segment/open_files.c:69
+#: ../imagery/i.segment/open_files.c:228 ../imagery/i.segment/open_files.c:236
 #, c-format
 msgid "No min/max found in raster map <%s>"
 msgstr ""
@@ -26638,9 +25691,7 @@
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:122
-msgid ""
-"Must be integer values, each area will be segmented independent of the "
-"others"
+msgid "Must be integer values, each area will be segmented independent of the others"
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:128
@@ -26648,14 +25699,11 @@
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:133
-msgid ""
-"Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for "
-"each pixel"
+msgid "Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for each pixel"
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:139
-msgid ""
-"Weighted input, do not perform the default scaling of input raster maps"
+msgid "Weighted input, do not perform the default scaling of input raster maps"
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:158
@@ -26725,9 +25773,7 @@
 #: ../imagery/i.segment/region_growing.c:445
 #, c-format
-msgid ""
-"Segmentation processes stopped at %d due to reaching max iteration limit, "
-"more merges may be possible"
+msgid "Segmentation processes stopped at %d due to reaching max iteration limit, more merges may be possible"
 msgstr ""
 #: ../imagery/i.segment/region_growing.c:447
@@ -26788,9 +25834,7 @@
 #: ../imagery/i.segment/mean_shift.c:106
 #, c-format
-msgid ""
-"Mean shift stopped at %d due to reaching max iteration limit, more changes "
-"may be possible"
+msgid "Mean shift stopped at %d due to reaching max iteration limit, more changes may be possible"
 msgstr ""
 #: ../imagery/i.segment/mean_shift.c:108
@@ -26862,8 +25906,7 @@
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:153
 #, c-format
-msgid ""
-"Replacing coordinates of principal point '%.17g, %.17g' with '%.17g, %.17g'"
+msgid "Replacing coordinates of principal point '%.17g, %.17g' with '%.17g, %.17g'"
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:164
@@ -26897,9 +25940,7 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:50
-msgid ""
-"Interactively creates or modifies entries in a camera initial exposure "
-"station file for imagery group referenced by a sub-block."
+msgid "Interactively creates or modifies entries in a camera initial exposure station file for imagery group referenced by a sub-block."
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:62
@@ -27230,9 +26271,7 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:91
-msgid ""
-"Orthorectifies an image by using the image to photo coordinate "
-"transformation matrix."
+msgid "Orthorectifies an image by using the image to photo coordinate transformation matrix."
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:132
@@ -27402,9 +26441,7 @@
 msgstr ""
 #: ../imagery/i.albedo/main.c:138 ../imagery/i.albedo/main.c:145
-msgid ""
-"Albedo dry run to calculate some water to beach/sand/desert stretching, a "
-"kind of simple atmospheric correction"
+msgid "Albedo dry run to calculate some water to beach/sand/desert stretching, a kind of simple atmospheric correction"
 msgstr ""
 #: ../imagery/i.albedo/main.c:143
@@ -27416,9 +26453,7 @@
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:69
-msgid ""
-"Calculates top-of-atmosphere radiance or reflectance and temperature for "
-"Landsat MSS/TM/ETM+/OLI"
+msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+/OLI"
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:75
@@ -27591,8 +26626,7 @@
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:227
-msgid ""
-"Input raster maps use as extension the number of the band instead the code"
+msgid "Input raster maps use as extension the number of the band instead the code"
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:231
@@ -27681,16 +26715,11 @@
 msgstr ""
 #: ../imagery/i.landsat.toar/landsat.c:116
-msgid ""
-"The DOS4 method is not applicable here: approximation of atmospheric "
-"transmittance coefficients is unstable. Use another DOS method or use other "
-"sun_elevation parameter"
+msgid "The DOS4 method is not applicable here: approximation of atmospheric transmittance coefficients is unstable. Use another DOS method or use other sun_elevation parameter"
 msgstr ""
 #: ../imagery/i.evapo.pt/main.c:69
-msgid ""
-"Computes evapotranspiration calculation Priestley and Taylor formulation, "
-"1972."
+msgid "Computes evapotranspiration calculation Priestley and Taylor formulation, 1972."
 msgstr ""
 #: ../imagery/i.evapo.pt/main.c:75
@@ -27934,9 +26963,7 @@
 #: ../imagery/i.landsat.acca/main.c:70
 #, c-format
-msgid ""
-"Input raster map <%s> is not floating point (process DN using i.landsat.toar"
-" to radiance first)"
+msgid "Input raster map <%s> is not floating point (process DN using i.landsat.toar to radiance first)"
 msgstr ""
 #: ../imagery/i.landsat.acca/main.c:104
@@ -27981,9 +27008,7 @@
 msgstr ""
 #: ../imagery/i.landsat.acca/main.c:158
-msgid ""
-"Bypass second-pass processing, and merge warm (not ambiguous) and cold "
-"clouds"
+msgid "Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
 msgstr ""
 #: ../imagery/i.landsat.acca/main.c:163
@@ -28424,9 +27449,7 @@
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:342
-msgid ""
-"Band number of MODIS product "
-"(mod09Q1=[1,2],mod09A1=[1-7],m[o/y]d09CMG=[1-7], mcd43B2q=[1-7])"
+msgid "Band number of MODIS product (mod09Q1=[1,2],mod09A1=[1-7],m[o/y]d09CMG=[1-7], mcd43B2q=[1-7])"
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:346
@@ -28629,9 +27652,7 @@
 msgstr ""
 #: ../misc/m.cogo/main.c:228
-msgid ""
-"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa."
+msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
 msgstr ""
 #: ../misc/m.cogo/main.c:230
@@ -29054,9 +28075,7 @@
 msgstr ""
 #: ../misc/m.nviz.image/args.c:903
-msgid ""
-"Place north arrow at given position \t(in screen coordinates from bottom "
-"left corner)"
+msgid "Place north arrow at given position \t(in screen coordinates from bottom left corner)"
 msgstr ""
 #: ../misc/m.nviz.image/args.c:905 ../misc/m.nviz.image/args.c:915
@@ -29124,9 +28143,7 @@
 msgstr ""
 #: ../misc/m.nviz.image/main.c:57
-msgid ""
-"Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
-"data) in 3D."
+msgid "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D."
 msgstr ""
 #: ../misc/m.nviz.image/main.c:83
@@ -29354,9 +28371,7 @@
 msgstr ""
 #: ../misc/m.nviz.script/main.c:439
-msgid ""
-"Skipping this point, selected point is outside region. Perhaps the camera "
-"setback distance puts it beyond the edge?"
+msgid "Skipping this point, selected point is outside region. Perhaps the camera setback distance puts it beyond the edge?"
 msgstr ""
 #: ../raster/r.in.bin/main.c:61 ../raster/r.in.bin/main.c:70
@@ -29479,9 +28494,7 @@
 #: ../raster/r.in.bin/main.c:554
 #, c-format
-msgid ""
-"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
-"significantly. Did you assign %s= and %s= correctly?"
+msgid "East-West (ewres: %f) and North-South (nwres: %f) resolution differ significantly. Did you assign %s= and %s= correctly?"
 msgstr ""
 #: ../raster/r.in.bin/main.c:575
@@ -29557,13 +28570,7 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:186
-msgid ""
-"The module has two different modes of operation: 1. Computes the entire "
-"horizon around a single point whose coordinates are given with the 'coord' "
-"option. The horizon height (in radians). 2. Computes one or more raster maps"
-" of the horizon height in a single direction. The input for this is the "
-"angle (in degrees), which is measured counterclockwise with east=0, north=90"
-" etc. The output is the horizon height in radians."
+msgid "The module has two different modes of operation: 1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction. The input for this is the angle (in degrees), which is measured counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
 msgstr ""
 #: ../raster/r.horizon/main.c:203
@@ -29590,33 +28597,23 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:237
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer around the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer around the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:245
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer eastward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer eastward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:253
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer westward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer westward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:261
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer northward the present"
-" region"
+msgid "For horizon rasters, read from the DEM an extra buffer northward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:269
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer southward the present"
-" region"
+msgid "For horizon rasters, read from the DEM an extra buffer southward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:277
@@ -29648,8 +28645,7 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:355
-msgid ""
-"Note: In latitude-longitude coordinate system specify buffers in degree unit"
+msgid "Note: In latitude-longitude coordinate system specify buffers in degree unit"
 msgstr ""
 #: ../raster/r.horizon/main.c:368
@@ -29738,9 +28734,7 @@
 msgstr ""
 #: ../raster/r.out.ascii/main.c:86
-msgid ""
-"Number of values printed before wrapping a line (only SURFER or MODFLOW "
-"format)"
+msgid "Number of values printed before wrapping a line (only SURFER or MODFLOW format)"
 msgstr ""
 #: ../raster/r.out.ascii/main.c:91
@@ -29842,10 +28836,7 @@
 msgstr ""
 #: ../raster/r.walk/main.c:183
-msgid ""
-"Creates a raster map showing the anisotropic cumulative cost of moving "
-"between different geographic locations on an input raster map whose cell "
-"category values represent cost."
+msgid "Creates a raster map showing the anisotropic cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
 msgstr ""
 #: ../raster/r.walk/main.c:193
@@ -30451,8 +29442,7 @@
 msgstr ""
 #: ../raster/r.proj/main.c:219
-msgid ""
-"Print input map's bounds in the current projection and exit (shell style)"
+msgid "Print input map's bounds in the current projection and exit (shell style)"
 msgstr ""
 #: ../raster/r.proj/main.c:254
@@ -30575,9 +29565,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:126
-msgid ""
-"Name of location to create or to read projection from for GCPs "
-"transformation"
+msgid "Name of location to create or to read projection from for GCPs transformation"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:143
@@ -30589,8 +29577,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:152
-msgid ""
-"Zero-padding of band number by filling with leading zeros up to given number"
+msgid "Zero-padding of band number by filling with leading zeros up to given number"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:153
@@ -30614,9 +29601,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:220
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not"
-" import the raster file."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the raster file."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:225
@@ -30636,8 +29621,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:265
-msgid ""
-"The number of digits for band numbering must be equal or greater than 0"
+msgid "The number of digits for band numbering must be equal or greater than 0"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:284
@@ -30652,9 +29636,7 @@
 #: ../raster/r.in.gdal/main.c:337
 #, c-format
-msgid ""
-"Input seems to be NOAA/AVHRR data which needs to be georeferenced with thin "
-"plate spline transformation (%s or %s)."
+msgid "Input seems to be NOAA/AVHRR data which needs to be georeferenced with thin plate spline transformation (%s or %s)."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:356 ../raster/r.in.gdal/main.c:703
@@ -30664,22 +29646,15 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:376
-msgid ""
-"Input raster map is flipped or rotated - cannot import. You may use "
-"'gdalwarp' to transform the map to North-up."
+msgid "Input raster map is flipped or rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:417
-msgid ""
-"Map bounds have been constrained to geographic coordinates. You will almost "
-"certainly want to check map bounds and resolution with r.info and reset them"
-" with r.region before going any further."
+msgid "Map bounds have been constrained to geographic coordinates. You will almost certainly want to check map bounds and resolution with r.info and reset them with r.region before going any further."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:458 ../raster/r.external/proj.c:18
-msgid ""
-"Unable to convert input raster map projection information to GRASS format "
-"for checking"
+msgid "Unable to convert input raster map projection information to GRASS format for checking"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:491 ../raster/r.external/proj.c:47
@@ -30691,9 +29666,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:560 ../raster/r.external/proj.c:111
-msgid ""
-"Consider generating a new location from the input dataset using the "
-"'location' parameter.\n"
+msgid "Consider generating a new location from the input dataset using the 'location' parameter.\n"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:584
@@ -30745,9 +29718,7 @@
 #: ../raster/r.in.gdal/main.c:859
 #, c-format
-msgid ""
-"The target for the output group <%s> has been set to location <%s>, mapset "
-"<PERMANENT>."
+msgid "The target for the output group <%s> has been set to location <%s>, mapset <PERMANENT>."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:930
@@ -30833,9 +29804,7 @@
 msgstr ""
 #: ../raster/r.topmodel/main.c:94
-msgid ""
-"Must be clipped to the catchment boundary. Used for generating "
-"outtopidxstats"
+msgid "Must be clipped to the catchment boundary. Used for generating outtopidxstats"
 msgstr ""
 #: ../raster/r.topmodel/main.c:96 ../raster/r.topmodel/main.c:106
@@ -30972,10 +29941,7 @@
 msgstr ""
 #: ../raster/r.sunhours/main.c:77
-msgid ""
-"Solar elevation: the angle between the direction of the geometric center of "
-"the sun's apparent disk and the (idealized) horizon. Solar azimuth: the "
-"angle from due north in clockwise direction."
+msgid "Solar elevation: the angle between the direction of the geometric center of the sun's apparent disk and the (idealized) horizon. Solar azimuth: the angle from due north in clockwise direction."
 msgstr ""
 #: ../raster/r.sunhours/main.c:83
@@ -31321,9 +30287,7 @@
 #: ../raster/r.regression.line/main.c:65
 #: ../raster/r.regression.multi/main.c:157
-msgid ""
-"ASCII file for storing regression coefficients (output to screen if file not"
-" specified)."
+msgid "ASCII file for storing regression coefficients (output to screen if file not specified)."
 msgstr ""
 #: ../raster/r.param.scale/main.c:42
@@ -31347,9 +30311,7 @@
 msgstr ""
 #: ../raster/r.param.scale/interface.c:60
-msgid ""
-"Uses a multi-scale approach by taking fitting quadratic parameters to any "
-"size window (via least squares)."
+msgid "Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
 msgstr ""
 #: ../raster/r.param.scale/interface.c:78
@@ -31605,9 +30567,7 @@
 msgstr ""
 #: ../raster/r.li/r.li.patchdensity/main.c:50
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour "
-"algorithm"
+msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../raster/r.li/r.li.pielou/pielou.c:45
@@ -31694,14 +30654,11 @@
 msgstr ""
 #: ../raster/r.li/r.li.patchnum/main.c:49
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour "
-"algorithm."
+msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
 msgstr ""
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:47
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:68
@@ -31709,9 +30666,7 @@
 msgstr ""
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:69
-msgid ""
-"It can be integer, double or float; it will be changed in function of map "
-"type"
+msgid "It can be integer, double or float; it will be changed in function of map type"
 msgstr ""
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:74
@@ -31727,9 +30682,7 @@
 msgstr ""
 #: ../raster/r.li/r.li.mps/mps.c:51
-msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
+msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../raster/r.li/r.li.shannon/shannon.c:45
@@ -31750,9 +30703,7 @@
 msgstr ""
 #: ../raster/r.category/main.c:55
-msgid ""
-"Manages category values and labels associated with user-specified raster map"
-" layers."
+msgid "Manages category values and labels associated with user-specified raster map layers."
 msgstr ""
 #: ../raster/r.category/main.c:69
@@ -31821,10 +30772,7 @@
 msgstr ""
 #: ../raster/r.his/main.c:73
-msgid ""
-"Generates red, green and blue (RGB) raster map layers combining hue, "
-"intensity and saturation (HIS) values from user-specified input raster map "
-"layers."
+msgid "Generates red, green and blue (RGB) raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
 msgstr ""
 #: ../raster/r.his/main.c:103
@@ -31869,9 +30817,7 @@
 msgstr ""
 #: ../raster/r.to.rast3/main.c:230
-msgid ""
-"The 2D and 3D region settings are different. Using the 3D region settings to"
-" adjust the 2D region."
+msgid "The 2D and 3D region settings are different. Using the 3D region settings to adjust the 2D region."
 msgstr ""
 #: ../raster/r.to.rast3/main.c:262
@@ -31896,10 +30842,7 @@
 msgstr ""
 #: ../raster/r.resamp.rst/main.c:151
-msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
+msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
 msgstr ""
 #: ../raster/r.resamp.rst/main.c:162
@@ -32069,9 +31012,7 @@
 msgstr ""
 #: ../raster/r.stats.zonal/main.c:105
-msgid ""
-"Calculates category or object oriented statistics (accumulator-based "
-"statistics)."
+msgid "Calculates category or object oriented statistics (accumulator-based statistics)."
 msgstr ""
 #: ../raster/r.stats.zonal/main.c:115 ../raster/r.statistics/main.c:69
@@ -32177,9 +31118,8 @@
 msgstr ""
 #: ../raster/r.relief/main.c:316 ../raster/r.series/main.c:386
-#: ../raster/r.series.accumulate/main.c:318
-#: ../raster/r.slope.aspect/main.c:544 ../raster/r.patch/main.c:140
-#: ../raster/r.series.interp/main.c:339
+#: ../raster/r.series.accumulate/main.c:318 ../raster/r.slope.aspect/main.c:544
+#: ../raster/r.patch/main.c:140 ../raster/r.series.interp/main.c:339
 msgid "Percent complete..."
 msgstr ""
@@ -32204,15 +31144,11 @@
 msgstr ""
 #: ../raster/r.neighbors/main.c:175
-msgid ""
-"Makes each cell category value a function of the category values assigned to"
-" the cells around it, and stores new cell values in an output raster map "
-"layer."
+msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
 msgstr ""
 #: ../raster/r.neighbors/main.c:185
-msgid ""
-"Name of an input raster map to select the cells which should be processed"
+msgid "Name of an input raster map to select the cells which should be processed"
 msgstr ""
 #: ../raster/r.neighbors/main.c:206 ../raster/r.neighbors/main.c:214
@@ -32256,15 +31192,12 @@
 #: ../raster/r.neighbors/main.c:329
 #, c-format
-msgid ""
-"Method %s not compatible with weighing window, using weight mask instead"
+msgid "Method %s not compatible with weighing window, using weight mask instead"
 msgstr ""
 #: ../raster/r.neighbors/main.c:337
 #, c-format
-msgid ""
-"Method %s not compatible with Gaussian filter, using unweighed version "
-"instead"
+msgid "Method %s not compatible with Gaussian filter, using unweighed version instead"
 msgstr ""
 #: ../raster/r.neighbors/main.c:386
@@ -32273,16 +31206,12 @@
 msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:66
-msgid ""
-"Unable to calculate sun position in un-projected locations. Specify "
-"sunposition directly."
+msgid "Unable to calculate sun position in un-projected locations. Specify sunposition directly."
 msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:88
 #, c-format
-msgid ""
-"Specified point %f, %f outside of current region, is that intended? Anyway, "
-"it will be used."
+msgid "Specified point %f, %f outside of current region, is that intended? Anyway, it will be used."
 msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:98 ../raster/r.latlong/main.c:101
@@ -32302,14 +31231,11 @@
 msgstr ""
 #: ../raster/r.sunmask/main.c:120
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map."
+msgid "Calculates cast shadow areas from sun position and elevation raster map."
 msgstr ""
 #: ../raster/r.sunmask/main.c:121
-msgid ""
-"Either exact sun position (A) is specified, or date/time to calculate the "
-"sun position (B) by r.sunmask itself."
+msgid "Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
 msgstr ""
 #: ../raster/r.sunmask/main.c:135
@@ -32394,9 +31320,7 @@
 msgstr ""
 #: ../raster/r.sunmask/main.c:282
-msgid ""
-"Neither sun position nor east/north, date/time/timezone definition are "
-"complete"
+msgid "Neither sun position nor east/north, date/time/timezone definition are complete"
 msgstr ""
 #: ../raster/r.sunmask/main.c:286
@@ -32405,9 +31329,7 @@
 msgstr ""
 #: ../raster/r.sunmask/main.c:291
-msgid ""
-"Using user defined sun azimuth, altitude settings (ignoring eventual other "
-"values)"
+msgid "Using user defined sun azimuth, altitude settings (ignoring eventual other values)"
 msgstr ""
 #: ../raster/r.sunmask/main.c:399
@@ -32468,9 +31390,7 @@
 msgstr ""
 #: ../raster/r.colors/edit_colors.c:83
-msgid ""
-"Input map names can be defined in an input file in case a large amount of "
-"maps must be specified. This option is mutual exclusive to the map option."
+msgid "Input map names can be defined in an input file in case a large amount of maps must be specified. This option is mutual exclusive to the map option."
 msgstr ""
 #: ../raster/r.colors/edit_colors.c:110
@@ -32613,8 +31533,7 @@
 msgstr ""
 #: ../raster/r.drain/main.c:113
-msgid ""
-"Traces a flow through an elevation model or cost surface on a raster map."
+msgid "Traces a flow through an elevation model or cost surface on a raster map."
 msgstr ""
 #: ../raster/r.drain/main.c:116
@@ -32658,9 +31577,7 @@
 msgstr ""
 #: ../raster/r.drain/main.c:163
-msgid ""
-"The input raster map is a cost surface (direction surface must also be "
-"specified)"
+msgid "The input raster map is a cost surface (direction surface must also be specified)"
 msgstr ""
 #: ../raster/r.drain/main.c:175
@@ -32673,16 +31590,12 @@
 #: ../raster/r.drain/main.c:183
 #, c-format
-msgid ""
-"Direction raster map <%s> not specified, if direction flag is on, a "
-"direction raster must be given"
+msgid "Direction raster map <%s> not specified, if direction flag is on, a direction raster must be given"
 msgstr ""
 #: ../raster/r.drain/main.c:190
 #, c-format
-msgid ""
-"Direction raster map <%s> should not be specified for Surface/Hydrology "
-"drains"
+msgid "Direction raster map <%s> should not be specified for Surface/Hydrology drains"
 msgstr ""
 #: ../raster/r.drain/main.c:209
@@ -32761,9 +31674,7 @@
 #: ../raster/r.texture/h_measure.c:141
 #, c-format
-msgid ""
-"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
-"map"
+msgid "Too many categories (found: %i, max: %i). Try to rescale or reclassify the map"
 msgstr ""
 #: ../raster/r.texture/main.c:68
@@ -32816,9 +31727,7 @@
 msgstr ""
 #: ../raster/r.texture/main.c:172
-msgid ""
-"The distance between two samples must be smaller than the size of the moving"
-" window"
+msgid "The distance between two samples must be smaller than the size of the moving window"
 msgstr ""
 #: ../raster/r.texture/main.c:193
@@ -32834,20 +31743,15 @@
 msgstr[2] ""
 #: ../raster/r.series/main.c:141
-msgid ""
-"Makes each output cell value a function of the values assigned to the "
-"corresponding cells in the input raster map layers."
+msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
 msgstr ""
 #: ../raster/r.series/main.c:150
-msgid ""
-"Input file with one raster map name and optional one weight per line, field "
-"separator between name and weight is |"
+msgid "Input file with one raster map name and optional one weight per line, field separator between name and weight is |"
 msgstr ""
 #: ../raster/r.series/main.c:176
-msgid ""
-"Weighting factor for each input map, default value is 1.0 for each input map"
+msgid "Weighting factor for each input map, default value is 1.0 for each input map"
 msgstr ""
 #: ../raster/r.series/main.c:183 ../raster/r.series.accumulate/main.c:132
@@ -32925,9 +31829,7 @@
 msgstr ""
 #: ../raster/r.profile/main.c:103
-msgid ""
-"If units are not specified, current location units are used. Meters are used"
-" by default in geographic (latlon) locations."
+msgid "If units are not specified, current location units are used. Meters are used by default in geographic (latlon) locations."
 msgstr ""
 #: ../raster/r.profile/main.c:117
@@ -33012,9 +31914,7 @@
 msgstr ""
 #: ../raster/r.covar/main.c:54
-msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map "
-"layer(s)."
+msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
 msgstr ""
 #: ../raster/r.covar/main.c:61
@@ -33031,9 +31931,7 @@
 msgstr ""
 #: ../raster/r.out.vtk/main.c:73
-msgid ""
-"No input maps specified. You need to specify at least one input map or three"
-" vector maps or three rgb maps."
+msgid "No input maps specified. You need to specify at least one input map or three vector maps or three rgb maps."
 msgstr ""
 #: ../raster/r.out.vtk/main.c:131 ../raster/r.out.vtk/main.c:191
@@ -33055,8 +31953,7 @@
 msgstr ""
 #: ../raster/r.out.vtk/main.c:271
-msgid ""
-"Wrong vector maps. Maps should have the same type! Vector output not added!"
+msgid "Wrong vector maps. Maps should have the same type! Vector output not added!"
 msgstr ""
 #: ../raster/r.out.vtk/main.c:283
@@ -33072,8 +31969,7 @@
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:69
-msgid ""
-"Three (r,g,b) raster maps to create RGB values [redmap,greenmap,bluemap]"
+msgid "Three (r,g,b) raster maps to create RGB values [redmap,greenmap,bluemap]"
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:79
@@ -33089,8 +31985,7 @@
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:116
-msgid ""
-"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
+msgid "Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:122
@@ -33341,23 +32236,19 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:83
-msgid ""
-"depression map indicates all the locations in the current map window where"
+msgid "depression map indicates all the locations in the current map window where"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:84
-msgid ""
-"water accumulates and does not leave by the edge of the map. Lakes without"
+msgid "water accumulates and does not leave by the edge of the map. Lakes without"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:85
-msgid ""
-"outlet streams and sinkholes are examples of `depressions'.  If you wish to"
+msgid "outlet streams and sinkholes are examples of `depressions'.  If you wish to"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:86
-msgid ""
-"have a depression map, prepare a map where non-zero values indicate the"
+msgid "have a depression map, prepare a map where non-zero values indicate the"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:87
@@ -33365,8 +32256,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:88
-msgid ""
-"Hit <return> by itself for the next question if there is no depression map."
+msgid "Hit <return> by itself for the next question if there is no depression map."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:99
@@ -33377,14 +32267,11 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:101
-msgid ""
-"watershed basins.  The number of watershed basins is indirectly determined"
+msgid "watershed basins.  The number of watershed basins is indirectly determined"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:102
-msgid ""
-"by the `basin threshold' value.  The basin threshold is the area necessary "
-"for"
+msgid "by the `basin threshold' value.  The basin threshold is the area necessary for"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:103
@@ -33393,18 +32280,15 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:105
-msgid ""
-"`exterior drainage basins'.  An exterior drainage basin does not have any"
+msgid "`exterior drainage basins'.  An exterior drainage basin does not have any"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:106
-msgid ""
-"drainage basins flowing into it.  Interior drainage basin size is determined"
+msgid "drainage basins flowing into it.  Interior drainage basin size is determined"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:107
-msgid ""
-"by the surface flow going into stream segments between stream interceptions."
+msgid "by the surface flow going into stream segments between stream interceptions."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:108
@@ -33417,19 +32301,15 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:111
-msgid ""
-"(i.e., areas with low infiltration capacities will need smaller areas to"
+msgid "(i.e., areas with low infiltration capacities will need smaller areas to"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:112
-msgid ""
-"develop stream channels than neighboring areas with high infiltration "
-"rates)."
+msgid "develop stream channels than neighboring areas with high infiltration rates)."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:113
-msgid ""
-"The user can create a map layer with potential overland flow values, and"
+msgid "The user can create a map layer with potential overland flow values, and"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:114
@@ -33535,8 +32415,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:296
-msgid ""
-"ability to generate several variables in the Revised Universal Soil Loss"
+msgid "ability to generate several variables in the Revised Universal Soil Loss"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:297
@@ -33555,9 +32434,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:351
-msgid ""
-"where the value indicates the percent of disturbed (barren) land in that "
-"cell."
+msgid "where the value indicates the percent of disturbed (barren) land in that cell."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:352
@@ -33598,8 +32475,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:384
-msgid ""
-"that prevents the surface flow distance from getting too long.  Normally,"
+msgid "that prevents the surface flow distance from getting too long.  Normally,"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:385
@@ -33613,8 +32489,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:401
-msgid ""
-"slope length.  You may input a raster map indicating the locations of these"
+msgid "slope length.  You may input a raster map indicating the locations of these"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:402
@@ -33622,8 +32497,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:403
-msgid ""
-"Hit <return> by itself for the next question if there is no blocking map."
+msgid "Hit <return> by itself for the next question if there is no blocking map."
 msgstr ""
 #: ../raster/r.watershed/shed/file_in.c:15
@@ -33714,8 +32588,7 @@
 msgid "Name of input raster map percent of disturbed land"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:97
-#: ../raster/r.watershed/front/main.c:122
+#: ../raster/r.watershed/front/main.c:97 ../raster/r.watershed/front/main.c:122
 msgid "For USLE"
 msgstr ""
@@ -33724,9 +32597,7 @@
 msgstr ""
 #: ../raster/r.watershed/front/main.c:106
-msgid ""
-"For USLE. All non-NULL and non-zero cells are considered as blocking "
-"terrain."
+msgid "For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
 msgstr ""
 #: ../raster/r.watershed/front/main.c:113
@@ -33818,9 +32689,7 @@
 msgstr ""
 #: ../raster/r.watershed/front/main.c:223
-msgid ""
-"Only needed if memory requirements exceed available RAM; see manual on how "
-"to calculate memory requirements"
+msgid "Only needed if memory requirements exceed available RAM; see manual on how to calculate memory requirements"
 msgstr ""
 #: ../raster/r.watershed/front/main.c:228
@@ -34005,8 +32874,7 @@
 #: ../raster/r.watershed/ram/do_cum.c:480
 #, c-format
 msgid "MFD: A * path already processed when distributing flow: %d of %d cell"
-msgid_plural ""
-"MFD: A * path already processed when distributing flow: %d of %d cells"
+msgid_plural "MFD: A * path already processed when distributing flow: %d of %d cells"
 msgstr[0] ""
 msgstr[1] ""
 msgstr[2] ""
@@ -34124,14 +32992,11 @@
 msgstr ""
 #: ../raster/r.to.rast3elev/main.c:427
-msgid ""
-"The 2D and 3D region settings are different. I will use the 3D region "
-"settings to adjust the 2D region."
+msgid "The 2D and 3D region settings are different. I will use the 3D region settings to adjust the 2D region."
 msgstr ""
 #: ../raster/r.grow.distance/main.c:156
-msgid ""
-"Generates a raster map containing distances to nearest raster features."
+msgid "Generates a raster map containing distances to nearest raster features."
 msgstr ""
 #: ../raster/r.grow.distance/main.c:163
@@ -34441,9 +33306,7 @@
 msgstr ""
 #: ../raster/r.flow/main.c:425
-msgid ""
-"Computes flowlines, flowpath lengths, and flowaccumulation (contributing "
-"areas) from a elevation raster map."
+msgid "Computes flowlines, flowpath lengths, and flowaccumulation (contributing areas) from a elevation raster map."
 msgstr ""
 #: ../raster/r.flow/main.c:435 ../raster/r.flow/main.c:441
@@ -34498,9 +33361,7 @@
 msgstr ""
 #: ../raster/r.flow/main.c:555
-msgid ""
-"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
-"calculating flow accumulation."
+msgid "lat/long projection not supported by r.flow. Please use 'r.watershed' for calculating flow accumulation."
 msgstr ""
 #: ../raster/r.flow/mem.c:40
@@ -34590,8 +33451,7 @@
 msgstr ""
 #: ../raster/r.in.lidar/main.c:116
-msgid ""
-"Creates a raster map from LAS LiDAR points using univariate statistics."
+msgid "Creates a raster map from LAS LiDAR points using univariate statistics."
 msgstr ""
 #: ../raster/r.in.lidar/main.c:130
@@ -34655,8 +33515,7 @@
 msgstr ""
 #: ../raster/r.in.lidar/main.c:182
-msgid ""
-"The scale for Z is applied beforehand, the range filter for Z afterwards"
+msgid "The scale for Z is applied beforehand, the range filter for Z afterwards"
 msgstr ""
 #: ../raster/r.in.lidar/main.c:191
@@ -34696,9 +33555,7 @@
 msgstr ""
 #: ../raster/r.in.lidar/main.c:293
-msgid ""
-"Set computation region to match the 2D extent and resolution of the newly "
-"created new raster map"
+msgid "Set computation region to match the 2D extent and resolution of the newly created new raster map"
 msgstr ""
 #: ../raster/r.in.lidar/main.c:317
@@ -34718,9 +33575,7 @@
 msgstr ""
 #: ../raster/r.in.lidar/main.c:332
-msgid ""
-"For getting values from base raster, use its actual resolution instead of "
-"computational region resolution"
+msgid "For getting values from base raster, use its actual resolution instead of computational region resolution"
 msgstr ""
 #: ../raster/r.in.lidar/main.c:355
@@ -34743,8 +33598,7 @@
 msgstr ""
 #: ../raster/r.in.lidar/main.c:419
-msgid ""
-"First file's projection checked, checking projection of the other files..."
+msgid "First file's projection checked, checking projection of the other files..."
 msgstr ""
 #: ../raster/r.in.lidar/main.c:457
@@ -34768,9 +33622,7 @@
 #: ../raster/r.in.lidar/main.c:590
 #, c-format
-msgid ""
-"Unable to process the hole map at once. Please set the '%s' option to some "
-"value lower than 100."
+msgid "Unable to process the hole map at once. Please set the '%s' option to some value lower than 100."
 msgstr ""
 #: ../raster/r.in.lidar/main.c:610
@@ -34822,9 +33674,7 @@
 msgstr ""
 #: ../raster/r.reclass/main.c:54
-msgid ""
-"Creates a new raster map whose category values are based upon a "
-"reclassification of the categories in an existing raster map."
+msgid "Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
 msgstr ""
 #: ../raster/r.reclass/main.c:59
@@ -34960,9 +33810,7 @@
 #: ../raster/r.resamp.bspline/crosscorr.c:160
 #, c-format
-msgid ""
-"%d are too many cells, recommended are < 100 cells. The cross validation "
-"would take too much time."
+msgid "%d are too many cells, recommended are < 100 cells. The cross validation would take too much time."
 msgstr ""
 #: ../raster/r.resamp.bspline/crosscorr.c:169
@@ -34978,9 +33826,7 @@
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:85
-msgid ""
-"Performs bilinear or bicubic spline interpolation with Tykhonov "
-"regularization."
+msgid "Performs bilinear or bicubic spline interpolation with Tykhonov regularization."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:93
@@ -34992,14 +33838,11 @@
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:107
-msgid ""
-"Length of each spline step in the east-west direction. Default: 1.5 * ewres."
+msgid "Length of each spline step in the east-west direction. Default: 1.5 * ewres."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:115
-msgid ""
-"Length of each spline step in the north-south direction. Default: 1.5 * "
-"nsres."
+msgid "Length of each spline step in the north-south direction. Default: 1.5 * nsres."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:138
@@ -35226,9 +34069,7 @@
 msgstr ""
 #: ../raster/r.in.xyz/main.c:165
-msgid ""
-"Creates a raster map from an assemblage of many coordinates using univariate"
-" statistics."
+msgid "Creates a raster map from an assemblage of many coordinates using univariate statistics."
 msgstr ""
 #: ../raster/r.in.xyz/main.c:169
@@ -35240,9 +34081,7 @@
 msgstr ""
 #: ../raster/r.in.xyz/main.c:237
-msgid ""
-"If a separate value column is given, this option refers to the z-coordinate "
-"column to be filtered by the zrange option"
+msgid "If a separate value column is given, this option refers to the z-coordinate column to be filtered by the zrange option"
 msgstr ""
 #: ../raster/r.in.xyz/main.c:248
@@ -35293,14 +34132,11 @@
 #: ../raster/r.in.xyz/main.c:534
 #, c-format
-msgid ""
-"Unable to process the hole map at once. Please set the %s option to some "
+msgid "Unable to process the hole map at once. Please set the %s option to some value lower than 100."
 msgstr ""
 #: ../raster/r.in.xyz/main.c:587
-msgid ""
-"If input is not from a file it is only possible to perform a single pass."
+msgid "If input is not from a file it is only possible to perform a single pass."
 msgstr ""
 #: ../raster/r.in.xyz/main.c:599
@@ -35470,23 +34306,17 @@
 #: ../raster/r.stats/main.c:303
 #, c-format
-msgid ""
-"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
-"will be ignored."
+msgid "Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option will be ignored."
 msgstr ""
 #: ../raster/r.stats/main.c:319
 #, c-format
-msgid ""
-"Cats for raster map <%s> are either missing or have no explicit labels. "
-"Using %s=%d."
+msgid "Cats for raster map <%s> are either missing or have no explicit labels. Using %s=%d."
 msgstr ""
 #: ../raster/r.stats/main.c:325
 #, c-format
-msgid ""
-"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s'"
-" option"
+msgid "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' option"
 msgstr ""
 #: ../raster/r.stats/raw_stats.c:118
@@ -35516,11 +34346,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:220
-msgid ""
-"Generates three, or four raster map layers showing the base (perpendicular) "
-"rate of spread (ROS), the maximum (forward) ROS, the direction of the "
-"maximum ROS, and optionally the maximum potential spotting distance for fire"
-" spread simulation."
+msgid "Generates three, or four raster map layers showing the base (perpendicular) rate of spread (ROS), the maximum (forward) ROS, the direction of the maximum ROS, and optionally the maximum potential spotting distance for fire spread simulation."
 msgstr ""
 #: ../raster/r.ros/main.c:227
@@ -35528,10 +34354,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:229
-msgid ""
-"Name of an existing raster map layer in the user's current mapset search "
-"path containing the standard fuel models defined by the USDA Forest Service."
-" Valid values are 1-13; other numbers are recognized as barriers by r.ros."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the standard fuel models defined by the USDA Forest Service. Valid values are 1-13; other numbers are recognized as barriers by r.ros."
 msgstr ""
 #: ../raster/r.ros/main.c:238
@@ -35539,10 +34362,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:240 ../raster/r.spread/main.c:205
-msgid ""
-"path containing the 1-hour (<.25\") fuel moisture (percentage content "
-"multiplied by 100)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the 1-hour (<.25\") fuel moisture (percentage content multiplied by 100)."
 msgstr ""
 #: ../raster/r.ros/main.c:248
@@ -35550,10 +34370,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:250
-msgid ""
-"path containing the 10-hour (.25-1\") fuel moisture (percentage content "
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the 10-hour (.25-1\") fuel moisture (percentage content multiplied by 100)."
 msgstr ""
 #: ../raster/r.ros/main.c:258
@@ -35561,10 +34378,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:260
-msgid ""
-"path containing the 100-hour (1-3\") fuel moisture (percentage content "
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the 100-hour (1-3\") fuel moisture (percentage content multiplied by 100)."
 msgstr ""
 #: ../raster/r.ros/main.c:267
@@ -35572,10 +34386,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:269
-msgid ""
-"path containing live (herbaceous) fuel moisture (percentage content "
+msgid "Name of an existing raster map layer in the user's current mapset search path containing live (herbaceous) fuel moisture (percentage content multiplied by 100)."
 msgstr ""
 #: ../raster/r.ros/main.c:277
@@ -35583,10 +34394,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:279 ../raster/r.spread/main.c:193
-msgid ""
-"path containing wind velocities at half of the average flame height "
-"(feet/minute)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing wind velocities at half of the average flame height (feet/minute)."
 msgstr ""
 #: ../raster/r.ros/main.c:287
@@ -35594,9 +34402,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:289
-msgid ""
-"path containing wind direction, clockwise from north (degree)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing wind direction, clockwise from north (degree)."
 msgstr ""
 #: ../raster/r.ros/main.c:297
@@ -35604,9 +34410,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:299
-msgid ""
-"path containing topographic slope (degree)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing topographic slope (degree)."
 msgstr ""
 #: ../raster/r.ros/main.c:307
@@ -35614,10 +34418,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:309
-msgid ""
-"path containing topographic aspect, counterclockwise from east (GRASS "
-"convention) in degrees."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing topographic aspect, counterclockwise from east (GRASS convention) in degrees."
 msgstr ""
 #: ../raster/r.ros/main.c:317
@@ -35625,10 +34426,7 @@
 msgstr ""
 #: ../raster/r.ros/main.c:319
-msgid ""
-"path containing elevation (meters). Option is required from spotting "
-"distance computation (when spotting_distance option is provided)"
+msgid "Name of an existing raster map layer in the user's current mapset search path containing elevation (meters). Option is required from spotting distance computation (when spotting_distance option is provided)"
 msgstr ""
 #: ../raster/r.ros/main.c:328
@@ -35660,29 +34458,21 @@
 msgstr ""
 #: ../raster/r.ros/main.c:354
-msgid ""
-"The maximal potential spotting distance (requires elevation raster map to be"
-" provided)."
+msgid "The maximal potential spotting distance (requires elevation raster map to be provided)."
 msgstr ""
 #: ../raster/r.ros/main.c:373
-msgid ""
-"No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h "
-"moisture layers is required."
+msgid "No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h moisture layers is required."
 msgstr ""
 #: ../raster/r.ros/main.c:397
 #, c-format
-msgid ""
-"A wind direction layer should be given if the wind velocity layer <%s> has "
-"been given"
+msgid "A wind direction layer should be given if the wind velocity layer <%s> has been given"
 msgstr ""
 #: ../raster/r.ros/main.c:402
 #, c-format
-msgid ""
-"A wind velocity layer should be given if the wind direction layer <%s> has "
-"been given"
+msgid "A wind velocity layer should be given if the wind direction layer <%s> has been given"
 msgstr ""
 #: ../raster/r.ros/main.c:416
@@ -35742,14 +34532,11 @@
 msgstr ""
 #: ../raster/r.volume/main.c:81
-msgid ""
-"Optionally produces a GRASS vector points map containing the calculated "
-"centroids of these clumps."
+msgid "Optionally produces a GRASS vector points map containing the calculated centroids of these clumps."
 msgstr ""
 #: ../raster/r.volume/main.c:86
-msgid ""
-"Name of input raster map representing data that will be summed within clumps"
+msgid "Name of input raster map representing data that will be summed within clumps"
 msgstr ""
 #: ../raster/r.volume/main.c:92
@@ -35757,9 +34544,7 @@
 msgstr ""
 #: ../raster/r.volume/main.c:93
-msgid ""
-"Preferably the output of r.clump. If no clump map is given than MASK is "
-"used."
+msgid "Preferably the output of r.clump. If no clump map is given than MASK is used."
 msgstr ""
 #: ../raster/r.volume/main.c:99
@@ -35779,9 +34564,7 @@
 msgstr ""
 #: ../raster/r.volume/main.c:143
-msgid ""
-"No MASK found. If no clump map is given than the MASK is required. You need "
-"to define a clump raster map or create a MASK by r.mask command."
+msgid "No MASK found. If no clump map is given than the MASK is required. You need to define a clump raster map or create a MASK by r.mask command."
 msgstr ""
 #: ../raster/r.volume/main.c:145
@@ -35835,8 +34618,7 @@
 msgstr ""
 #: ../raster/r.sim/r.sim.water/main.c:120
-msgid ""
-"Overland flow hydrologic simulation using path sampling method (SIMWE)."
+msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
 msgstr ""
 #: ../raster/r.sim/r.sim.water/main.c:127
@@ -35903,9 +34685,7 @@
 #: ../raster/r.sim/r.sim.water/main.c:222
 #: ../raster/r.sim/r.sim.sediment/main.c:211
-msgid ""
-"Name for sampling points output text file. For each observation vector point"
-" the time series of sediment transport is stored."
+msgid "Name for sampling points output text file. For each observation vector point the time series of sediment transport is stored."
 msgstr ""
 #: ../raster/r.sim/r.sim.water/main.c:230
@@ -35954,9 +34734,7 @@
 #: ../raster/r.sim/r.sim.water/main.c:306
 #: ../raster/r.sim/r.sim.sediment/main.c:270
-msgid ""
-"The same seed can be used to obtain same results or random seed can be "
-"generated by other means."
+msgid "The same seed can be used to obtain same results or random seed can be generated by other means."
 msgstr ""
 #: ../raster/r.sim/r.sim.water/main.c:312
@@ -35966,9 +34744,7 @@
 #: ../raster/r.sim/r.sim.water/main.c:314
 #: ../raster/r.sim/r.sim.sediment/main.c:278
-msgid ""
-"Automatically generates random seed for random number generator (use when "
-"you don't want to provide the seed option)"
+msgid "Automatically generates random seed for random number generator (use when you don't want to provide the seed option)"
 msgstr ""
 #: ../raster/r.sim/r.sim.water/main.c:322
@@ -36018,9 +34794,7 @@
 msgstr ""
 #: ../raster/r.sim/r.sim.sediment/main.c:121
-msgid ""
-"Sediment transport and erosion/deposition simulation using path sampling "
-"method (SIMWE)."
+msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
 msgstr ""
 #: ../raster/r.sim/r.sim.sediment/main.c:128
@@ -36044,8 +34818,7 @@
 msgstr ""
 #: ../raster/r.sim/r.sim.sediment/main.c:184
-msgid ""
-"Name for output transport limited erosion-deposition raster map [kg/m2s]"
+msgid "Name for output transport limited erosion-deposition raster map [kg/m2s]"
 msgstr ""
 #: ../raster/r.sim/r.sim.sediment/main.c:191
@@ -36068,16 +34841,13 @@
 msgid "You are not outputting any raster or site files"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:411
-#: ../raster/r.sim/simlib/hydro.c:465
+#: ../raster/r.sim/r.sim.sediment/main.c:411 ../raster/r.sim/simlib/hydro.c:465
 msgid "Cannot write raster maps"
 msgstr ""
 #: ../raster/r.sim/simlib/input.c:307
 #, c-format
-msgid ""
-"Raster map <%s> not found, and manin_val undefined, choose one to be allowed"
-" to process"
+msgid "Raster map <%s> not found, and manin_val undefined, choose one to be allowed to process"
 msgstr ""
 #: ../raster/r.sim/simlib/input.c:420
@@ -36164,9 +34934,7 @@
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:84
-msgid ""
-"Makes each output cell value a accumulationfunction of the values assigned "
-"to the corresponding cells in the input raster map layers."
+msgid "Makes each output cell value a accumulationfunction of the values assigned to the corresponding cells in the input raster map layers."
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:90
@@ -36186,14 +34954,11 @@
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:121
-msgid ""
-"The raster map specifying the lower accumulation limit, also called baseline"
+msgid "The raster map specifying the lower accumulation limit, also called baseline"
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:126
-msgid ""
-"The raster map specifying the upper accumulation limit, also called cutoff. "
-"Only applied to BEDD computation."
+msgid "The raster map specifying the upper accumulation limit, also called cutoff. Only applied to BEDD computation."
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:139
@@ -36295,9 +35060,7 @@
 msgstr ""
 #: ../raster/r.out.gdal/main.c:220
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
-"Not supported by all output format drivers."
+msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. Not supported by all output format drivers."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:230
@@ -36305,9 +35068,7 @@
 msgstr ""
 #: ../raster/r.out.gdal/main.c:232
-msgid ""
-"If given, the nodata value is always written to metadata even if there are "
-"no NULL cells in the input band (enhances output compatibility)."
+msgid "If given, the nodata value is always written to metadata even if there are no NULL cells in the input band (enhances output compatibility)."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:264
@@ -36327,9 +35088,7 @@
 #: ../raster/r.out.gdal/main.c:288
 #, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:293
@@ -36357,23 +35116,17 @@
 #: ../raster/r.out.gdal/main.c:455
 #, c-format
-msgid ""
-"Precision loss: Raster map <%s> of type %s to be exported as %s. This can be"
-" avoided by using %s."
+msgid "Precision loss: Raster map <%s> of type %s to be exported as %s. This can be avoided by using %s."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:466
 #, c-format
-msgid ""
-"Precision loss: The range of <%s> can not be accurately preserved with GDAL "
-"datatype Float32. This can be avoided by exporting to Int32 or Float64."
+msgid "Precision loss: The range of <%s> can not be accurately preserved with GDAL datatype Float32. This can be avoided by exporting to Int32 or Float64."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:474
 #, c-format
-msgid ""
-"Precision loss: Float32 can not preserve the DCELL precision of raster <%s>."
-" This can be avoided by using Float64"
+msgid "Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. This can be avoided by using Float64"
 msgstr ""
 #: ../raster/r.out.gdal/main.c:483
@@ -36485,10 +35238,7 @@
 #: ../raster/r.out.gdal/main.c:791 ../raster/r.out.gdal/main.c:804
 #: ../raster/r.out.gdal/main.c:819
 #, c-format
-msgid ""
-"Mismatch between metadata nodata value and actual nodata value in exported "
-"raster: specified nodata value %g gets converted to %d by selected GDAL "
-"datatype."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %d by selected GDAL datatype."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:767 ../raster/r.out.gdal/main.c:794
@@ -36504,10 +35254,7 @@
 #: ../raster/r.out.gdal/main.c:833
 #, c-format
-msgid ""
-"raster: specified nodata value %g gets converted to %g by selected GDAL "
-"datatype."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %g by selected GDAL datatype."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:836
@@ -36519,8 +35266,7 @@
 msgid "Failed to set raster attribute table"
 msgstr ""
-#: ../raster/r.out.gdal/export_band.c:52
-#: ../raster/r.out.gdal/export_band.c:344
+#: ../raster/r.out.gdal/export_band.c:52 ../raster/r.out.gdal/export_band.c:344
 msgid "Unable to allocate buffer for reading raster map"
 msgstr ""
@@ -36531,32 +35277,22 @@
 #: ../raster/r.out.gdal/export_band.c:161
 #, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %d will"
-" be used to represent no-data values in the input map. You can specify a "
-"nodata value with the %s option."
+msgid "Input raster map contains cells with NULL-value (no-data). The value %d will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:166
 #, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %g will"
+msgid "Input raster map contains cells with NULL-value (no-data). The value %g will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:176
 #, c-format
-msgid ""
-"The default nodata value is present in rasterband <%s> and would lead to "
-"data loss. Please specify a custom nodata value with the %s parameter."
+msgid "The default nodata value is present in rasterband <%s> and would lead to data loss. Please specify a custom nodata value with the %s parameter."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:183
 #, c-format
-msgid ""
-"The user given nodata value %g is present in rasterband <%s> and would lead "
-"to data loss. Please specify a different nodata value with the %s parameter."
+msgid "The user given nodata value %g is present in rasterband <%s> and would lead to data loss. Please specify a different nodata value with the %s parameter."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:228
@@ -36585,11 +35321,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:113
-msgid ""
-"Generates a raster map of the cumulative time of spread, given raster maps "
-"containing the rates of spread (ROS), the ROS directions and the spread "
-"origins. It optionally produces raster maps to contain backlink UTM "
-"coordinates for tracing spread paths. Usable for fire spread simulations."
+msgid "Generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins. It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths. Usable for fire spread simulations."
 msgstr ""
 #: ../raster/r.spread/main.c:127
@@ -36597,11 +35329,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:129
-msgid ""
-"path containing the ROS values in the directions perpendicular to maximum "
-"ROSes' (cm/minute). These ROSes are also the ones without the effect of "
-"directional factors."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the ROS values in the directions perpendicular to maximum ROSes' (cm/minute). These ROSes are also the ones without the effect of directional factors."
 msgstr ""
 #: ../raster/r.spread/main.c:141
@@ -36609,9 +35337,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:143
-msgid ""
-"path containing the maximum ROS values (cm/minute)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the maximum ROS values (cm/minute)."
 msgstr ""
 #: ../raster/r.spread/main.c:153
@@ -36619,10 +35345,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:155
-msgid ""
-"path containing directions of the maximum ROSes, clockwise from north "
-"(degree)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing directions of the maximum ROSes, clockwise from north (degree)."
 msgstr ""
 #: ../raster/r.spread/main.c:166
@@ -36630,10 +35353,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:168
-msgid ""
-"path containing starting locations of the spread phenomenon. Any positive "
-"integers in this map are recognized as starting sources (seeds)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing starting locations of the spread phenomenon. Any positive integers in this map are recognized as starting sources (seeds)."
 msgstr ""
 #: ../raster/r.spread/main.c:179
@@ -36641,9 +35361,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:181
-msgid ""
-"path containing the maximum potential spotting distances (meters)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the maximum potential spotting distances (meters)."
 msgstr ""
 #: ../raster/r.spread/main.c:191
@@ -36651,9 +35369,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:203
-msgid ""
-"Raster map containing fine fuel moisture of the cell receiving a spotting "
-"firebrand (%, required with -s)"
+msgid "Raster map containing fine fuel moisture of the cell receiving a spotting firebrand (%, required with -s)"
 msgstr ""
 #: ../raster/r.spread/main.c:215
@@ -36661,11 +35377,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:217
-msgid ""
-"An odd integer ranging 3 - 15 indicating the basic sampling window size "
-"within which all cells will be considered to see whether they will be "
-"reached by the current spread cell. The default number is 3 which means a "
-"3x3 window."
+msgid "An odd integer ranging 3 - 15 indicating the basic sampling window size within which all cells will be considered to see whether they will be reached by the current spread cell. The default number is 3 which means a 3x3 window."
 msgstr ""
 #: ../raster/r.spread/main.c:227
@@ -36673,12 +35385,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:229
-msgid ""
-"A decimal number ranging 0.0 - 1.0 indicating additional sampling cells will"
-" be considered to see whether they will be reached by the current spread "
-"cell. The closer to 1.0 the decimal number is, the longer the program will "
-"run and the higher the simulation accuracy will be. The default number is "
-"0.5."
+msgid "A decimal number ranging 0.0 - 1.0 indicating additional sampling cells will be considered to see whether they will be reached by the current spread cell. The closer to 1.0 the decimal number is, the longer the program will run and the higher the simulation accuracy will be. The default number is 0.5."
 msgstr ""
 #: ../raster/r.spread/main.c:241
@@ -36686,10 +35393,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:243
-msgid ""
-"A non-negative number specifying the initial time for the current spread "
-"simulation (minutes). This is useful when multiple phase simulation is "
-"conducted. The default time is 0."
+msgid "A non-negative number specifying the initial time for the current spread simulation (minutes). This is useful when multiple phase simulation is conducted. The default time is 0."
 msgstr ""
 #: ../raster/r.spread/main.c:252
@@ -36697,12 +35401,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:254
-msgid ""
-"A non-negative integer specifying the simulating duration time lag "
-"(minutes). The default is infinite, but the program will terminate when the "
-"current geographic region/mask has been filled. It also controls the "
-"computational time, the shorter the time lag, the faster the program will "
-"run."
+msgid "A non-negative integer specifying the simulating duration time lag (minutes). The default is infinite, but the program will terminate when the current geographic region/mask has been filled. It also controls the computational time, the shorter the time lag, the faster the program will run."
 msgstr ""
 #: ../raster/r.spread/main.c:266
@@ -36710,10 +35409,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:268
-msgid ""
-"path to be used as the background on which the \"live\" movement will be "
-"shown."
+msgid "Name of an existing raster map layer in the user's current mapset search path to be used as the background on which the \"live\" movement will be shown."
 msgstr ""
 #: ../raster/r.spread/main.c:279
@@ -36721,10 +35417,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:281
-msgid ""
-"Name of the new raster map layer to contain the results of the cumulative "
-"spread time needed for a phenomenon to reach each cell from the starting "
-"sources (minutes)."
+msgid "Name of the new raster map layer to contain the results of the cumulative spread time needed for a phenomenon to reach each cell from the starting sources (minutes)."
 msgstr ""
 #: ../raster/r.spread/main.c:291
@@ -36732,9 +35425,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:293
-msgid ""
-"Name of the new raster map layer to contain the results of backlink "
-"information in UTM easting coordinates for each cell."
+msgid "Name of the new raster map layer to contain the results of backlink information in UTM easting coordinates for each cell."
 msgstr ""
 #: ../raster/r.spread/main.c:303
@@ -36742,9 +35433,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:305
-msgid ""
-"information in UTM northing coordinates for each cell."
+msgid "Name of the new raster map layer to contain the results of backlink information in UTM northing coordinates for each cell."
 msgstr ""
 #: ../raster/r.spread/main.c:312
@@ -36752,9 +35441,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:314
-msgid ""
-"Display the 'live' simulation on screen. A graphics window must be opened "
-"and selected before using this option."
+msgid "Display the 'live' simulation on screen. A graphics window must be opened and selected before using this option."
 msgstr ""
 #: ../raster/r.spread/main.c:320
@@ -36766,11 +35453,7 @@
 msgstr ""
 #: ../raster/r.spread/main.c:326
-msgid ""
-"Designed to be used with output of previous run of r.spread when computing "
-"spread iteratively. The values in start raster map are considered as time. "
-"Allowed values in raster map are from zero to the value of init_time option."
-" If not enabled, init_time is used in the area of start raster map"
+msgid "Designed to be used with output of previous run of r.spread when computing spread iteratively. The values in start raster map are considered as time. Allowed values in raster map are from zero to the value of init_time option. If not enabled, init_time is used in the area of start raster map"
 msgstr ""
 #: ../raster/r.spread/main.c:502
@@ -36963,8 +35646,7 @@
 msgstr ""
 #: ../raster/r.thin/main.c:60
-msgid ""
-"Thins non-null cells that denote linear features in a raster map layer."
+msgid "Thins non-null cells that denote linear features in a raster map layer."
 msgstr ""
 #: ../raster/r.thin/main.c:72
@@ -37034,9 +35716,7 @@
 msgstr ""
 #: ../raster/r.surf.gauss/main.c:44
-msgid ""
-"Mean and standard deviation of gaussian deviates can be expressed by the "
-"user."
+msgid "Mean and standard deviation of gaussian deviates can be expressed by the user."
 msgstr ""
 #: ../raster/r.surf.gauss/main.c:51
@@ -37150,9 +35830,7 @@
 msgstr ""
 #: ../raster/r.lake/main.c:276
-msgid ""
-"Given water level at seed point is below earth surface. Increase water level"
-" or move seed point."
+msgid "Given water level at seed point is below earth surface. Increase water level or move seed point."
 msgstr ""
 #: ../raster/r.lake/main.c:355
@@ -37175,9 +35853,7 @@
 msgstr ""
 #: ../raster/r.spreadpath/main.c:92
-msgid ""
-"Recursively traces the least cost path backwards to cells from which the "
-"cumulative cost was determined."
+msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
 msgstr ""
 #: ../raster/r.spreadpath/main.c:98
@@ -37194,8 +35870,7 @@
 #: ../raster/r.spreadpath/main.c:161
 #, c-format
-msgid ""
-"eading the input map -%s- and -%s- and creating some temporary files..."
+msgid "eading the input map -%s- and -%s- and creating some temporary files..."
 msgstr ""
 #: ../raster/r.spreadpath/main.c:281
@@ -37253,8 +35928,7 @@
 msgstr ""
 #: ../raster/r.composite/main.c:76
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
+msgid "Combines red, green and blue raster maps into a single composite raster map."
 msgstr ""
 #: ../raster/r.composite/main.c:102
@@ -37288,9 +35962,7 @@
 msgstr ""
 #: ../raster/r.mode/main.c:59
-msgid ""
-"Finds the mode of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
+msgid "Finds the mode of values in a cover map within areas assigned the same category value in a user-specified base map."
 msgstr ""
 #: ../raster/r.mode/main.c:65
@@ -37322,28 +35994,21 @@
 msgid "Extended"
 msgstr ""
-#: ../raster/r.univar/r.univar_main.c:71
-#: ../raster/r.univar/r3.univar_main.c:67
+#: ../raster/r.univar/r.univar_main.c:71 ../raster/r.univar/r3.univar_main.c:67
 msgid "Table output format instead of standard output format"
 msgstr ""
 #: ../raster/r.univar/r.univar_main.c:76
-msgid ""
-"Use the native resolution and extent of the raster map, instead of the "
-"current region"
+msgid "Use the native resolution and extent of the raster map, instead of the current region"
 msgstr ""
 #: ../raster/r.univar/r.univar_main.c:110
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map."
+msgid "Calculates univariate statistics from the non-null cells of a raster map."
 msgstr ""
 #: ../raster/r.univar/r.univar_main.c:112
 #: ../raster/r.univar/r3.univar_main.c:105
-msgid ""
-"Statistics include number of cells counted, minimum and maximum cell values,"
-" range, arithmetic mean, population variance, standard deviation, "
-"coefficient of variation, and sum."
+msgid "Statistics include number of cells counted, minimum and maximum cell values, range, arithmetic mean, population variance, standard deviation, coefficient of variation, and sum."
 msgstr ""
 #: ../raster/r.univar/r.univar_main.c:123
@@ -37355,8 +36020,7 @@
 msgstr ""
 #: ../raster/r.univar/r3.univar_main.c:103
-msgid ""
-"Calculates univariate statistics from the non-null cells of a 3D raster map."
+msgid "Calculates univariate statistics from the non-null cells of a 3D raster map."
 msgstr ""
 #: ../raster/r.out.mpeg/main.c:104
@@ -37418,9 +36082,7 @@
 msgstr ""
 #: ../raster/r.surf.idw/main.c:109
-msgid ""
-"Provides surface interpolation from raster point data by Inverse Distance "
-"Squared Weighting."
+msgid "Provides surface interpolation from raster point data by Inverse Distance Squared Weighting."
 msgstr ""
 #: ../raster/r.surf.idw/main.c:124
@@ -37486,9 +36148,7 @@
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:156
-msgid ""
-"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from an elevation raster map."
+msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from an elevation raster map."
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:158
@@ -37504,13 +36164,11 @@
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:209
-msgid ""
-"Name for output first order partial derivative dx (E-W slope) raster map"
+msgid "Name for output first order partial derivative dx (E-W slope) raster map"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:216
-msgid ""
-"Name for output first order partial derivative dy (N-S slope) raster map"
+msgid "Name for output first order partial derivative dy (N-S slope) raster map"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:223
@@ -37539,9 +36197,7 @@
 #: ../raster/r.slope.aspect/main.c:336
 #, c-format
-msgid ""
-"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, "
-"<%s>, <%s>, <%s>, <%s> or <%s>"
+msgid "You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:358
@@ -37550,9 +36206,7 @@
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:387
-msgid ""
-"r.slope.aspect does not convert horizontal units to meters in this version, "
-"see manual page."
+msgid "r.slope.aspect does not convert horizontal units to meters in this version, see manual page."
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:968
@@ -37620,21 +36274,15 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:62
-msgid ""
-"Name of input raster map providing boundary condition status: 0-inactive, "
-"1-active, 2-dirichlet"
+msgid "Name of input raster map providing boundary condition status: 0-inactive, 1-active, 2-dirichlet"
 msgstr ""
 #: ../raster/r.gwflow/main.c:67
-msgid ""
-"Name of input raster map with x-part of the hydraulic conductivity tensor in"
-" [m/s]"
+msgid "Name of input raster map with x-part of the hydraulic conductivity tensor in [m/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:72
-msgid ""
-"Name of input raster map with y-part of the hydraulic conductivity tensor in"
-" [m/s]"
+msgid "Name of input raster map with y-part of the hydraulic conductivity tensor in [m/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:77
@@ -37642,9 +36290,7 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:81
-msgid ""
-"Name of input raster map with storativity for confined or effective porosity"
-" for unconfined groundwater flow booth in [-] "
+msgid "Name of input raster map with storativity for confined or effective porosity for unconfined groundwater flow booth in [-] "
 msgstr ""
 #: ../raster/r.gwflow/main.c:86
@@ -37656,13 +36302,11 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:92
-msgid ""
-"Name of input raster map describing the top surface of the aquifer in [m]"
+msgid "Name of input raster map describing the top surface of the aquifer in [m]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:96
-msgid ""
-"Name of input raster map describing the bottom surface of the aquifer in [m]"
+msgid "Name of input raster map describing the bottom surface of the aquifer in [m]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:100
@@ -37670,20 +36314,15 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:106
-msgid ""
-"Output raster map to store the groundwater filter velocity vector part in x "
-"direction [m/s]"
+msgid "Output raster map to store the groundwater filter velocity vector part in x direction [m/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:112
-msgid ""
-"Output raster map to store the groundwater filter velocity vector part in y "
-"direction [m/s]"
+msgid "Output raster map to store the groundwater filter velocity vector part in y direction [m/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:118
-msgid ""
-"Output raster map to store the groundwater budget for each cell [m^3/s]"
+msgid "Output raster map to store the groundwater budget for each cell [m^3/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:126
@@ -37695,26 +36334,19 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:140
-msgid ""
-"Name of input raster map providing the water level (head) of the river with "
-"leakage connection in [m]"
+msgid "Name of input raster map providing the water level (head) of the river with leakage connection in [m]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:147
-msgid ""
-"Name of input raster map providing the leakage coefficient of the river bed "
-"in [1/s]."
+msgid "Name of input raster map providing the leakage coefficient of the river bed in [1/s]."
 msgstr ""
 #: ../raster/r.gwflow/main.c:155
-msgid ""
-"Name of input raster map providing the height of the drainage bed in [m]"
+msgid "Name of input raster map providing the height of the drainage bed in [m]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:162
-msgid ""
-"Name of input raster map providing the leakage coefficient of the drainage "
-"bed in [1/s]"
+msgid "Name of input raster map providing the leakage coefficient of the drainage bed in [1/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:167
@@ -37722,15 +36354,11 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:176
-msgid ""
-"Allocate a full quadratic linear equation system, default is a sparse linear"
-" equation system."
+msgid "Allocate a full quadratic linear equation system, default is a sparse linear equation system."
 msgstr ""
 #: ../raster/r.gwflow/main.c:212
-msgid ""
-"Numerical calculation program for transient, confined and unconfined "
-"groundwater flow in two dimensions."
+msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
 msgstr ""
 #: ../raster/r.gwflow/main.c:222 ../raster/r.topidx/main.c:56
@@ -37748,9 +36376,7 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:263
-msgid ""
-"The cholesky solver dos not work with sparse matrices. You may choose a full"
-" filled quadratic matrix, flag -f."
+msgid "The cholesky solver dos not work with sparse matrices. You may choose a full filled quadratic matrix, flag -f."
 msgstr ""
 #: ../raster/r.gwflow/main.c:293
@@ -37773,10 +36399,7 @@
 msgstr ""
 #: ../raster/r.patch/main.c:66
-msgid ""
-"Creates a composite raster map layer by using known category values from one"
-" (or more) map layer(s) to fill in areas of \"no data\" in another map "
-"layer."
+msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
 msgstr ""
 #: ../raster/r.patch/main.c:73
@@ -37865,9 +36488,7 @@
 msgstr ""
 #: ../raster/r.random/main.c:58
-msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
+msgid "Creates a raster map layer and vector point map containing randomly located points."
 msgstr ""
 #: ../raster/r.random/main.c:67
@@ -37968,9 +36589,7 @@
 msgstr ""
 #: ../raster/r.series.interp/main.c:69
-msgid ""
-"Interpolates raster maps located (temporal or spatial) in between input "
-"raster maps at specific sampling positions."
+msgid "Interpolates raster maps located (temporal or spatial) in between input raster maps at specific sampling positions."
 msgstr ""
 #: ../raster/r.series.interp/main.c:79
@@ -37978,9 +36597,7 @@
 msgstr ""
 #: ../raster/r.series.interp/main.c:84
-msgid ""
-"Input file with one input raster map name and data point position per line, "
-"field separator between name and sample point is |"
+msgid "Input file with one input raster map name and data point position per line, field separator between name and sample point is |"
 msgstr ""
 #: ../raster/r.series.interp/main.c:97
@@ -37988,9 +36605,7 @@
 msgstr ""
 #: ../raster/r.series.interp/main.c:101
-msgid ""
-"Input file with one output raster map name and sample point position per "
-"line, field separator between name and sample point is |"
+msgid "Input file with one output raster map name and sample point position per line, field separator between name and sample point is |"
 msgstr ""
 #: ../raster/r.series.interp/main.c:111
@@ -38034,9 +36649,7 @@
 #: ../raster/r.series.interp/main.c:299
 #, c-format
-msgid ""
-"map <%s> at position %g was not interpolated. Check the interpolation "
-"interval."
+msgid "map <%s> at position %g was not interpolated. Check the interpolation interval."
 msgstr ""
 #: ../raster/r.series.interp/main.c:319
@@ -38221,14 +36834,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:245
-msgid ""
-"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
-"for given day, latitude, surface and atmospheric conditions. Solar "
-"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
-"irradiance, daylight length) are saved in the map history file. "
-"Alternatively, a local time can be specified to compute solar incidence "
-"angle and/or irradiance raster maps. The shadowing effect of the topography "
-"is optionally incorporated."
+msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
 msgstr ""
 #: ../raster/r.sun/main.c:259
@@ -38236,9 +36842,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:268
-msgid ""
-"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
-"[decimal degrees]"
+msgid "Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]"
 msgstr ""
 #: ../raster/r.sun/main.c:277
@@ -38246,9 +36850,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:286
-msgid ""
-"Name of the input slope raster map (terrain slope or solar panel "
-"inclination) [decimal degrees]"
+msgid "Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]"
 msgstr ""
 #: ../raster/r.sun/main.c:294
@@ -38256,8 +36858,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:303
-msgid ""
-"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
+msgid "Name of the Linke atmospheric turbidity coefficient input raster map [-]"
 msgstr ""
 #: ../raster/r.sun/main.c:312
@@ -38281,14 +36882,11 @@
 msgstr ""
 #: ../raster/r.sun/main.c:357
-msgid ""
-"Name of real-sky beam radiation coefficient (thick cloud) input raster map "
-"[0-1]"
+msgid "Name of real-sky beam radiation coefficient (thick cloud) input raster map [0-1]"
 msgstr ""
 #: ../raster/r.sun/main.c:366
-msgid ""
-"Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
+msgid "Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
 msgstr ""
 #: ../raster/r.sun/main.c:373
@@ -38300,27 +36898,19 @@
 msgstr ""
 #: ../raster/r.sun/main.c:399
-msgid ""
-"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map "
-"[Wh.m-2.day-1] (mode 2)"
+msgid "Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
 msgstr ""
 #: ../raster/r.sun/main.c:408
-msgid ""
-"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map "
+msgid "Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
 msgstr ""
 #: ../raster/r.sun/main.c:417
-msgid ""
-"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
-"map [Wh.m-2.day-1] (mode 2)"
+msgid "Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
 msgstr ""
 #: ../raster/r.sun/main.c:426
-msgid ""
-"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or "
-"irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgid "Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
 msgstr ""
 #: ../raster/r.sun/main.c:435
@@ -38392,8 +36982,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:609
-msgid ""
-"If you use the horizon option you must also set the 'horizonstep' parameter."
+msgid "If you use the horizon option you must also set the 'horizonstep' parameter."
 msgstr ""
 #: ../raster/r.sun/main.c:615
@@ -38401,9 +36990,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:617
-msgid ""
-"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
-"time"
+msgid "Mode 1: instantaneous solar incidence angle & irradiance using a set local time"
 msgstr ""
 #: ../raster/r.sun/main.c:622
@@ -38459,9 +37046,7 @@
 msgstr ""
 #: ../raster/r.sun/main.c:700
-msgid ""
-"If you want to save memory and to use shadows, you must use pre-calculated "
-"horizons."
+msgid "If you want to save memory and to use shadows, you must use pre-calculated horizons."
 msgstr ""
 #: ../raster/r.sun/main.c:767
@@ -38473,9 +37058,7 @@
 msgstr ""
 #: ../raster/r.coin/main.c:69
-msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
+msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
 msgstr ""
 #: ../raster/r.coin/main.c:74
@@ -38491,9 +37074,7 @@
 msgstr ""
 #: ../raster/r.coin/main.c:86
-msgid ""
-"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
-"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
+msgid "c(ells), p(ercent), x(percent of category [column]), y(percent of category [row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
 msgstr ""
 #: ../raster/r.coin/main.c:93
@@ -38532,9 +37113,7 @@
 msgstr ""
 #: ../raster/r.kappa/main.c:72
-msgid ""
-"Calculates error matrix and kappa parameter for accuracy assessment of "
-"classification result."
+msgid "Calculates error matrix and kappa parameter for accuracy assessment of classification result."
 msgstr ""
 #: ../raster/r.kappa/main.c:78
@@ -38696,9 +37275,7 @@
 msgstr ""
 #: ../raster/r.clump/main.c:56
-msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
+msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
 msgstr ""
 #: ../raster/r.clump/main.c:72
@@ -38722,8 +37299,7 @@
 msgstr[2] ""
 #: ../raster/r.surf.random/main.c:40
-msgid ""
-"Produces a raster surface map of uniform random deviates with defined range."
+msgid "Produces a raster surface map of uniform random deviates with defined range."
 msgstr ""
 #: ../raster/r.surf.random/main.c:46
@@ -38740,10 +37316,7 @@
 #: ../raster/r.topidx/file_io.c:35
 #, c-format
-msgid ""
-"The current region resolution [%s x %s] is finer than the input map's "
-"resolution [%s x %s]. The current region resolution must be identical to, or"
-" coarser than, the input map's resolution."
+msgid "The current region resolution [%s x %s] is finer than the input map's resolution [%s x %s]. The current region resolution must be identical to, or coarser than, the input map's resolution."
 msgstr ""
 #: ../raster/r.topidx/file_io.c:42
@@ -38764,9 +37337,7 @@
 msgstr ""
 #: ../raster/r.topidx/main.c:43
-msgid ""
-"Creates a topographic index (wetness index) raster map from an elevation "
-"raster map."
+msgid "Creates a topographic index (wetness index) raster map from an elevation raster map."
 msgstr ""
 #: ../raster/r.topidx/main.c:49
@@ -38790,9 +37361,7 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:79
-msgid ""
-"The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - "
-"dirichlet- and 3 - transfer boundary condition"
+msgid "The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - dirichlet- and 3 - transfer boundary condition"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:85
@@ -38815,14 +37384,11 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:103
-msgid ""
-"Concentration sources and sinks bounded to a water source or sink in [kg/s]"
+msgid "Concentration sources and sinks bounded to a water source or sink in [kg/s]"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:112
-msgid ""
-"Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical "
-"reaction)"
+msgid "Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical reaction)"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:117
@@ -38842,21 +37408,15 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:132
-msgid ""
-"The resulting concentration of the numerical solute transport calculation "
-"will be written to this map. [kg/m^3]"
+msgid "The resulting concentration of the numerical solute transport calculation will be written to this map. [kg/m^3]"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:140
-msgid ""
-"Calculate and store the groundwater filter velocity vector part in x "
-"direction [m/s]\n"
+msgid "Calculate and store the groundwater filter velocity vector part in x direction [m/s]\n"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:147
-msgid ""
-"Calculate and store the groundwater filter velocity vector part in y "
+msgid "Calculate and store the groundwater filter velocity vector part in y direction [m/s]\n"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:161
@@ -38868,9 +37428,7 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:177
-msgid ""
-"Use this number of time loops if the CFL flag is off. The timestep will "
-"become dt/loops."
+msgid "Use this number of time loops if the CFL flag is off. The timestep will become dt/loops."
 msgstr ""
 #: ../raster/r.solute.transport/main.c:187
@@ -38886,9 +37444,7 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:233
-msgid ""
-"Numerical calculation program for transient, confined and unconfined solute "
-"transport in two dimensions"
+msgid "Numerical calculation program for transient, confined and unconfined solute transport in two dimensions"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:258
@@ -38921,8 +37477,7 @@
 #: ../raster/r.solute.transport/main.c:385
 #, c-format
-msgid ""
-"The time step is to large: %gs. The largest time step should be of size %gs."
+msgid "The time step is to large: %gs. The largest time step should be of size %gs."
 msgstr ""
 #: ../raster/r.solute.transport/main.c:397
@@ -39025,9 +37580,7 @@
 msgstr ""
 #: ../raster/r.external/window.c:23
-msgid ""
-"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
-"transform the map to North-up."
+msgid "Input raster map is rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
 msgstr ""
 #: ../raster/r.external/window.c:26
@@ -39342,9 +37895,7 @@
 msgstr ""
 #: ../raster/r.stream.extract/main.c:88
-msgid ""
-"Stream extraction will use provided accumulation instead of calculating it "
-"anew"
+msgid "Stream extraction will use provided accumulation instead of calculating it anew"
 msgstr ""
 #: ../raster/r.stream.extract/main.c:93
@@ -39368,9 +37919,7 @@
 msgstr ""
 #: ../raster/r.stream.extract/main.c:110
-msgid ""
-"If accumulation is larger than d8cut, SFD is used instead of MFD. Applies "
-"only if no accumulation map is given."
+msgid "If accumulation is larger than d8cut, SFD is used instead of MFD. Applies only if no accumulation map is given."
 msgstr ""
 #: ../raster/r.stream.extract/main.c:122
@@ -39378,9 +37927,7 @@
 msgstr ""
 #: ../raster/r.stream.extract/main.c:124
-msgid ""
-"Montgomery: accumulation is multiplied with pow(slope,mexp) and then "
-"compared with threshold"
+msgid "Montgomery: accumulation is multiplied with pow(slope,mexp) and then compared with threshold"
 msgstr ""
 #: ../raster/r.stream.extract/main.c:132
@@ -39520,9 +38067,7 @@
 #: ../raster/r.stream.extract/streams.c:700
 #, c-format
-msgid ""
-"MFD: A * path already processed when setting drainage direction: %lld of "
-"%lld cells"
+msgid "MFD: A * path already processed when setting drainage direction: %lld of %lld cells"
 msgstr ""
 #: ../raster/r.stream.extract/thin.c:83
@@ -39557,9 +38102,7 @@
 msgstr ""
 #: ../raster/r.external.out/main.c:240
-msgid ""
-"Redirects raster output to file utilizing GDAL library rather than storing "
-"in GRASS raster format."
+msgid "Redirects raster output to file utilizing GDAL library rather than storing in GRASS raster format."
 msgstr ""
 #: ../raster/r.external.out/main.c:244
@@ -39652,9 +38195,7 @@
 msgstr ""
 #: ../raster/r.carve/main.c:77
-msgid ""
-"Takes vector stream data, transforms it to raster and subtracts depth from "
-"the output DEM."
+msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
 msgstr ""
 #: ../raster/r.carve/main.c:82
@@ -39700,8 +38241,7 @@
 msgstr ""
 #: ../raster/r.carve/enforce_ds.c:175
-msgid ""
-"Vect runs out of region and re-enters - this case is not yet implemented."
+msgid "Vect runs out of region and re-enters - this case is not yet implemented."
 msgstr ""
 #: ../raster/r.surf.fractal/main.c:40
@@ -39739,10 +38279,7 @@
 msgstr ""
 #: ../raster/r.cost/main.c:145
-msgid ""
-"Creates a raster map showing the cumulative cost of moving between different"
-" geographic locations on an input raster map whose cell category values "
-"represent cost."
+msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
 msgstr ""
 #: ../raster/r.cost/main.c:152
@@ -39760,9 +38297,7 @@
 #: ../raster/r.cost/main.c:489
 #, c-format
-msgid ""
-"Negative cell value found at row %d, col %d. Setting negative value to "
-"null_cost value"
+msgid "Negative cell value found at row %d, col %d. Setting negative value to null_cost value"
 msgstr ""
 #: ../raster/r.cost/main.c:582
@@ -39870,9 +38405,7 @@
 #: ../raster/r.stats.quantile/main.c:632
 #, c-format
-msgid ""
-"Base map <%s> has many categories (%d), computation might be slow and might "
-"need a lot of memory"
+msgid "Base map <%s> has many categories (%d), computation might be slow and might need a lot of memory"
 msgstr ""
 #: ../raster/r.to.vect/main.c:79
@@ -39888,14 +38421,11 @@
 msgstr ""
 #: ../raster/r.to.vect/main.c:142
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
-"table."
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be written to the table."
 msgstr ""
 #: ../raster/r.to.vect/main.c:144
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be z coordinate."
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be z coordinate."
 msgstr ""
 #: ../raster/r.to.vect/main.c:146
@@ -40137,9 +38667,7 @@
 msgstr ""
 #: ../raster/r.cross/main.c:72
-msgid ""
-"Creates a cross product of the category values from multiple raster map "
-"layers."
+msgid "Creates a cross product of the category values from multiple raster map layers."
 msgstr ""
 #: ../raster/r.cross/main.c:81
@@ -40240,8 +38768,7 @@
 msgstr ""
 #: ../raster/r.transect/main.c:106
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
+msgid "Outputs raster map layer values lying along user defined transect line(s)."
 msgstr ""
 #: ../raster/r.transect/main.c:110
@@ -40271,9 +38798,7 @@
 msgstr ""
 #: ../raster/r.rescale.eq/main.c:55
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
+msgid "Rescales histogram equalized the range of category values in a raster map layer."
 msgstr ""
 #: ../raster/r.rescale.eq/main.c:115
@@ -40320,9 +38845,7 @@
 #: ../raster/r.null/main.c:132
 #, c-format
-msgid ""
-"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
-"with r.mapcalc. Exiting."
+msgid "Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy with r.mapcalc. Exiting."
 msgstr ""
 #: ../raster/r.null/main.c:138
@@ -40407,9 +38930,7 @@
 msgstr ""
 #: ../raster/r.fill.dir/main.c:92
-msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation raster map."
+msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
 msgstr ""
 #: ../raster/r.fill.dir/main.c:99
@@ -40417,8 +38938,7 @@
 msgstr ""
 #: ../raster/r.fill.dir/main.c:103
-msgid ""
-"Name for output flow direction map for depressionless elevation raster map"
+msgid "Name for output flow direction map for depressionless elevation raster map"
 msgstr ""
 #: ../raster/r.fill.dir/main.c:108
@@ -40633,9 +39153,7 @@
 msgstr ""
 #: ../ps/ps.map/main.c:118
-msgid ""
-"Describe map-box's position on the page and exit (inches from top-left of "
-"paper)"
+msgid "Describe map-box's position on the page and exit (inches from top-left of paper)"
 msgstr ""
 #: ../ps/ps.map/main.c:123
@@ -40688,10 +39206,7 @@
 msgstr ""
 #: ../ps/ps.map/ps_clrtbl.c:54
-msgid ""
-"Your cats/ file is invalid. A cats/ file with categories and labels is "
-"required for 'colortable' when using categorical legends; see the r.category"
-" help page. Colortable creation has been skipped."
+msgid "Your cats/ file is invalid. A cats/ file with categories and labels is required for 'colortable' when using categorical legends; see the r.category help page. Colortable creation has been skipped."
 msgstr ""
 #: ../ps/ps.map/ps_clrtbl.c:69 ../ps/ps.map/ps_fclrtbl.c:97
Modified: grass/trunk/locale/po/grassmods_vi.po
--- grass/trunk/locale/po/grassmods_vi.po	2017-08-31 19:49:01 UTC (rev 71460)
+++ grass/trunk/locale/po/grassmods_vi.po	2017-08-31 20:55:23 UTC (rev 71461)
@@ -20,31 +20,27 @@
 "Plural-Forms: nplurals=2; plural=(n != 1);\n"
 #: ../raster3d/r3.out.netcdf/main.c:81
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to close 3D raster map while catching error: %s"
-msgstr "Không thể đóng bản đồ raster <%s@%s>"
+msgstr ""
 #: ../raster3d/r3.out.netcdf/main.c:97
-#, fuzzy
 msgid "Name for netCDF output file"
-msgstr "Tên cho tập tin đầu ra"
+msgstr ""
 #: ../raster3d/r3.out.netcdf/main.c:106
-#, fuzzy
 msgid "The value to be used for null values, default is the netCDF standard"
-msgstr "Giá trị để lấp đầy các ô trên (upper cell), mặc định là null"
+msgstr ""
 #: ../raster3d/r3.out.netcdf/main.c:111
-#, fuzzy
 msgid "Export projection information as wkt and proj4 parameter"
-msgstr "In ra thông tin phép chiếu theo định dạng PROJ.4"
+msgstr ""
 #: ../raster3d/r3.out.netcdf/main.c:116 ../raster3d/r3.to.rast/main.c:128
 #: ../raster3d/r3.out.ascii/main.c:118 ../raster3d/r3.cross.rast/main.c:109
 #: ../raster/r.to.rast3elev/main.c:194
-#, fuzzy
 msgid "Use 3D raster mask (if exists) with input map"
-msgstr "Dùng mặt nạ G3D (nếu có) với bản đồ đầu vào"
+msgstr ""
 #: ../raster3d/r3.out.netcdf/main.c:586 ../raster3d/r3.timestamp/main.c:43
 #: ../raster3d/r3.out.v5d/main.c:284 ../raster3d/r3.retile/main.c:96
@@ -69,9 +65,8 @@
 #: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:5
 #: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:4
 #: ../misc/m.nviz.script/main.c:72 ../misc/m.nviz.image/main.c:55
-#, fuzzy
 msgid "raster3d"
-msgstr "raster"
+msgstr ""
 #: ../raster3d/r3.out.netcdf/main.c:587 ../raster3d/r3.out.v5d/main.c:285
 #: ../raster3d/r3.out.ascii/main.c:303 ../raster3d/r3.out.bin/main.c:206
@@ -98,9 +93,8 @@
 #: ../vector/v.out.pov/main.c:47 ../vector/v.out.ascii/main.c:48
 #: ../vector/v.external.out/main.c:44 ../vector/v.out.postgis/main.c:45
 #: ../vector/v.colors.out/main.c:51 ../vector/v.out.vtk/main.c:48
-#, fuzzy
 msgid "export"
-msgstr "Nhập"
+msgstr ""
 #: ../raster3d/r3.out.netcdf/main.c:588
 msgid "netCDF"
@@ -130,9 +124,8 @@
 msgstr ""
 #: ../raster3d/r3.out.netcdf/main.c:590
-#, fuzzy
 msgid "Export a 3D raster map as netCDF file."
-msgstr "Đổi lớp bản đồ raster 3D thành tập tin văn bản ASCII"
+msgstr ""
 #: ../raster3d/r3.out.netcdf/main.c:600 ../raster3d/r3.timestamp/main.c:73
 #: ../raster3d/r3.out.v5d/main.c:307 ../raster3d/r3.retile/main.c:113
@@ -147,7 +140,7 @@
 #: ../vector/v.colors/main.c:319
 #, c-format
 msgid "3D raster map <%s> not found"
-msgstr "Không tìm thấy bản đồ raster 3D <%s>"
+msgstr ""
 #: ../raster3d/r3.out.netcdf/main.c:617 ../raster3d/r3.out.v5d/main.c:312
 #: ../raster3d/r3.retile/main.c:127 ../raster3d/r3.stats/main.c:103
@@ -163,9 +156,9 @@
 #: ../raster3d/r3.out.vtk/main.c:513 ../raster3d/r3.neighbors/main.c:266
 #: ../raster3d/r3.neighbors/main.c:275 ../raster/r.univar/r3.univar_main.c:151
 #: ../raster/r.univar/r3.univar_main.c:189
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open 3D raster map <%s>"
-msgstr "Không thể mở bản đồ raster <%s>"
+msgstr ""
 #: ../raster3d/r3.out.netcdf/main.c:649 ../raster3d/r3.out.v5d/main.c:55
 #: ../raster3d/r3.out.v5d/main.c:326 ../raster3d/r3.to.rast/main.c:75
@@ -174,9 +167,8 @@
 #: ../raster3d/r3.out.ascii/main.c:367 ../raster3d/r3.in.ascii/main.c:393
 #: ../raster3d/r3.in.v5d/main.c:206 ../raster3d/r3.cross.rast/main.c:55
 #: ../raster3d/r3.out.vtk/main.c:252 ../raster3d/r3.out.vtk/main.c:338
-#, fuzzy
 msgid "Unable to close 3D raster map"
-msgstr "Không thể đóng bản đồ raster"
+msgstr ""
 #: ../raster3d/r3.timestamp/main.c:44 ../raster3d/r3.info/main.c:76
 #: ../raster3d/r3.support/main.c:50 ../raster/r.support/main.c:55
@@ -187,15 +179,13 @@
 #: ../locale/scriptstrings/t.select_to_translate.c:3
 #: ../temporal/t.connect/main.c:36 ../vector/v.info/main.c:38
 #: ../vector/v.timestamp/main.c:36 ../vector/v.support/main.c:40
-#, fuzzy
 msgid "metadata"
-msgstr "Mô tả dữ liệu"
+msgstr ""
 #: ../raster3d/r3.timestamp/main.c:45 ../raster/r.timestamp/main.c:37
 #: ../vector/v.timestamp/main.c:37
-#, fuzzy
 msgid "timestamp"
-msgstr "Đánh dấu thời gian không hợp lệ"
+msgstr ""
 #: ../raster3d/r3.timestamp/main.c:46 ../raster/r.timestamp/main.c:38
 #: ../locale/scriptstrings/t.support_to_translate.c:4
@@ -248,87 +238,75 @@
 #: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:5
 #: ../locale/scriptstrings/t.vect.univar_to_translate.c:5
 #: ../vector/v.timestamp/main.c:38
-#, fuzzy
 msgid "time"
+msgstr ""
 #: ../raster3d/r3.timestamp/main.c:48
-#, fuzzy
 msgid "Modifies a timestamp for a 3D raster map."
-msgstr "In/thêm/loại bỏ đánh dấu thời gian cho một bản đồ raster."
+msgstr ""
 #: ../raster3d/r3.timestamp/main.c:49
-#, fuzzy
 msgid "Print/add/remove a timestamp for a 3D raster map."
-msgstr "In/thêm/loại bỏ đánh dấu thời gian của một bản đồ raster 3D."
+msgstr ""
 #: ../raster3d/r3.timestamp/main.c:58
 msgid "Datetime, datetime1/datetime2, or none"
-msgstr "Ngày_giờ, ngày_giờ_1/ngày_giờ_2, hoặc none"
+msgstr ""
 #: ../raster3d/r3.timestamp/main.c:91
-#, fuzzy
 msgid "Timestamp format is invalid"
-msgstr "Định dạng đánh dấu thời gian không biết: "
+msgstr ""
 #: ../raster3d/r3.out.v5d/main.c:73
-#, fuzzy
 msgid "3D raster map to be converted to Vis5D (V5D) file"
-msgstr "Bản đồ raster 3d cần đổi thành tập tin Vis5d (v5d)"
+msgstr ""
 #: ../raster3d/r3.out.v5d/main.c:77
-#, fuzzy
 msgid "Name for V5D output file"
-msgstr "Tên của tập tin đầu ra v5d"
+msgstr ""
 #: ../raster3d/r3.out.v5d/main.c:147
-#, fuzzy, c-format
+#, c-format
 msgid "Vis5D allows %d columns, %d columns found"
-msgstr "Viz5D cho phép %d cột, bạn có %d cột"
+msgstr ""
 #: ../raster3d/r3.out.v5d/main.c:150
-#, fuzzy, c-format
+#, c-format
 msgid "Vis5D allows %d rows, %d rows found"
-msgstr "Viz5D cho phép %d hàng, bạn có %d hàng"
+msgstr ""
 #: ../raster3d/r3.out.v5d/main.c:257
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create V5D file <%s>"
-msgstr "Không thể tạo tập tin <%s>"
+msgstr ""
 #: ../raster3d/r3.out.v5d/main.c:262
-#, fuzzy
 msgid "Failed writing V5D file"
-msgstr "Thất bại khi chép tập tin"
+msgstr ""
 #: ../raster3d/r3.out.v5d/main.c:288
-#, fuzzy
 msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
-msgstr "Xuất tập tin raster 3D GRASS thành tập tin Vis5D ba chiều."
+msgstr ""
 #: ../raster3d/r3.out.v5d/main.c:295
 msgid "Use map coordinates instead of xyz coordinates"
-msgstr "Dùng tọa độ bản đồ thay vì tọa độ xyz"
+msgstr ""
 #: ../raster3d/r3.retile/main.c:49
-#, fuzzy
 msgid "Unable to close the 3D raster map"
-msgstr "Không thể đóng bản đồ raster 3d"
+msgstr ""
 #: ../raster3d/r3.retile/main.c:71
-#, fuzzy
 msgid "Name of the retiled 3D raster map"
-msgstr "Tên của bản đồ raster 3D đầu vào"
+msgstr ""
 #: ../raster3d/r3.retile/main.c:97 ../raster/r.tile/main.c:44
 #: ../locale/scriptstrings/r.tileset_to_translate.c:3
-#, fuzzy
 msgid "tiling"
-msgstr "raster, xếp chồng"
+msgstr ""
 #: ../raster3d/r3.retile/main.c:99
-msgid ""
-"Retiles an existing 3D raster map with user defined x, y and z tile size."
+msgid "Retiles an existing 3D raster map with user defined x, y and z tile size."
 msgstr ""
 #: ../raster3d/r3.retile/main.c:135
@@ -336,9 +314,8 @@
 msgstr ""
 #: ../raster3d/r3.retile/main.c:148
-#, fuzzy
 msgid "Error closing 3D raster map"
-msgstr "Lỗi đóng bản đồ raster 3d"
+msgstr ""
 #: ../raster3d/r3.stats/main.c:49 ../raster3d/r3.in.lidar/main.c:165
 #: ../raster3d/r3.neighbors/main.c:211 ../imagery/i.cca/main.c:85
@@ -370,45 +347,40 @@
 #: ../vector/v.neighbors/main.c:52 ../vector/v.random/main.c:99
 #: ../vector/v.kcv/main.c:56 ../vector/v.qcount/main.c:61
 #: ../vector/v.univar/main.c:93 ../vector/v.outlier/main.c:70
-#, fuzzy
 msgid "statistics"
-msgstr "Thống kê"
+msgstr ""
 #: ../raster3d/r3.stats/main.c:51
-#, fuzzy
 msgid "Generates volume statistics for 3D raster maps."
-msgstr "Tạo thống kê diện tích cho các bản đồ raster 3d."
+msgstr ""
 #: ../raster3d/r3.stats/main.c:62
-#, fuzzy
 msgid "Number of subranges to collect stats from"
-msgstr "Số lượng miền phụ để thu thập các thống kê từ đó"
+msgstr ""
 #: ../raster3d/r3.stats/main.c:67
 msgid "Calculate statistics based on equal value groups"
-msgstr "Tính toán thống kê dựa trên các nhóm giá trị ngang bằng nhau"
+msgstr ""
 #: ../raster3d/r3.stats/main.c:71
-#, fuzzy
 msgid "Only print cell counts"
-msgstr "In ra các phép đếm ô"
+msgstr ""
 #: ../raster3d/r3.stats/main.c:91
 msgid "The number of subranges has to be equal or greater than 1"
-msgstr "Số lượng miền phụ phải bằng hoặc lớn hơn 1"
+msgstr ""
 #: ../raster3d/r3.stats/main.c:150
 msgid "Sort non-null values"
-msgstr "Xếp thứ tự các giá trị không rỗng"
+msgstr ""
 #: ../raster3d/r3.to.rast/main.c:100
-#, fuzzy
 msgid "3D raster map(s) to be converted to 2D raster slices"
-msgstr "(Các) bản đồ raster 3d cần đổi thành các phiến (slice) raster 2D"
+msgstr ""
 #: ../raster3d/r3.to.rast/main.c:106
 msgid "Basename for resultant raster slice maps"
-msgstr "Tên gốc cho các bản đồ phiến raster tạo thành"
+msgstr ""
 #: ../raster3d/r3.to.rast/main.c:116
 #, fuzzy
@@ -429,13 +401,8 @@
 msgstr ""
 #: ../raster3d/r3.to.rast/main.c:133
-#, fuzzy
-msgid ""
-"Use the same resolution as the input 3D raster map for the 2D output maps, "
-"independent of the current region settings"
+msgid "Use the same resolution as the input 3D raster map for the 2D output maps, independent of the current region settings"
 msgstr ""
-"Dùng cùng độ phân giải với bản đồ RASTER3D đầu vào cho các bản đồ 2D đầu ra, "
-"không phụ thuộc vào thiết lập vùng hiện tại."
 #: ../raster3d/r3.to.rast/main.c:174
 #, fuzzy, c-format
@@ -452,9 +419,8 @@
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:5
 #: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:3
 #: ../vector/v.to.rast3/main.c:49 ../vector/v.to.rast/main.c:45
-#, fuzzy
 msgid "conversion"
-msgstr "Lỗi chuyển đổi chữ"
+msgstr ""
 #: ../raster3d/r3.to.rast/main.c:261 ../raster3d/r3.cross.rast/main.c:230
 #: ../visualization/ximgview/main.c:292 ../doc/raster/r.example/main.c:83
@@ -584,20 +550,15 @@
 #: ../vector/v.what.rast/main.c:73 ../vector/v.sample/main.c:77
 #: ../vector/v.to.rast/main.c:46
 msgid "raster"
-msgstr "raster"
+msgstr ""
 #: ../raster3d/r3.to.rast/main.c:263
 msgid "Converts 3D raster maps to 2D raster maps"
-msgstr "Đổi bản đồ raster 3D thành bản đồ raster 2D"
+msgstr ""
 #: ../raster3d/r3.to.rast/main.c:332 ../raster3d/r3.out.vtk/main.c:451
-#, fuzzy
-msgid ""
-"The 2D and 3D region settings are different. Using the 2D window settings to "
-"adjust the 2D part of the 3D region."
+msgid "The 2D and 3D region settings are different. Using the 2D window settings to adjust the 2D part of the 3D region."
 msgstr ""
-"Các thiết lập vùng 2d và 3d khác nhau. Dùng thiết lập cửa sổ 2d để điều "
-"chỉnh phần 2d của vùng 3d."
 #: ../raster3d/r3.to.rast/main.c:360 ../imagery/i.smap/multialloc.c:115
 #: ../db/drivers/postgres/listtab.c:92 ../db/drivers/postgres/listdb.c:88
@@ -632,38 +593,35 @@
 #: ../vector/v.vol.rst/user1.c:423 ../vector/v.net.connectivity/main.c:186
 #: ../vector/v.net.connectivity/main.c:202
 msgid "Out of memory"
-msgstr "Hết bộ nhớ"
+msgstr ""
 #: ../raster3d/r3.to.rast/main.c:362
 #, c-format
 msgid "Creating %i raster maps"
-msgstr "Đang tạo %i bản đồ raster"
+msgstr ""
 #: ../raster3d/r3.to.rast/main.c:368
 #, c-format
 msgid "Raster map %i Filename: %s"
-msgstr "Bản đồ raster %i Tên tập tin: %s"
+msgstr ""
 #: ../raster3d/r3.to.rast/main.c:373
-#, fuzzy, c-format
-msgid ""
-"Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
-msgstr "Bản đồ raster %d Filename: %s đã có. Sẽ bị ghi đè!"
+#, c-format
+msgid "Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:73
-#, fuzzy
 msgid "Error reading binary data"
-msgstr "Lỗi khi đọc dữ liệu 'hue' (màu sắc)"
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:154
-#, fuzzy, c-format
+#, c-format
 msgid "Loading %s data with %i  bytes ...  (%dx%dx%d)"
-msgstr "Đang nạp dữ liệu ... (%dx%dx%d)"
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:202 ../raster3d/r3.neighbors/main.c:311
-#, fuzzy
 msgid "Error flushing tiles"
-msgstr "Lỗi khi đang đóng tập tin g3d"
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:253 ../raster3d/r3.in.ascii/main.c:355
 #: ../raster3d/r3.in.lidar/main.c:163 ../raster3d/r3.in.v5d/main.c:179
@@ -694,25 +652,20 @@
 #: ../vector/v.in.ogr/main.c:136 ../vector/v.external/main.c:51
 #: ../vector/v.in.dwg/main.c:83 ../vector/v.in.dxf/main.c:65
 #: ../vector/v.in.ascii/main.c:71 ../vector/v.proj/main.c:70
-#, fuzzy
 msgid "import"
-msgstr "Nhập"
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:256
-#, fuzzy
 msgid "Imports a binary raster file into a GRASS 3D raster map."
 msgstr ""
-"Nhập một tập tin raster nhị phân vào thành một lớp bản đồ raster GRASS."
 #: ../raster3d/r3.in.bin/main.c:259
-#, fuzzy
 msgid "Name of binary 3D raster file to be imported"
-msgstr "Tập tin raster cần nhập"
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:268 ../raster3d/r3.out.bin/main.c:228
-#, fuzzy
 msgid "Number of bytes per cell in binary file"
-msgstr "Số byte/ô tồi"
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:275
 msgid "Byte order in binary file"
@@ -720,7 +673,7 @@
 #: ../raster3d/r3.in.bin/main.c:283 ../raster/r.in.bin/main.c:338
 msgid "Northern limit of geographic region (outer edge)"
-msgstr "Cận phía bắc của vùng địa lý (mép ngoài cùng)"
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:284 ../raster3d/r3.in.bin/main.c:292
 #: ../raster3d/r3.in.bin/main.c:300 ../raster3d/r3.in.bin/main.c:308
@@ -738,46 +691,43 @@
 #: ../general/g.region/main.c:245 ../general/g.region/main.c:321
 #: ../general/g.region/main.c:332
 msgid "Bounds"
-msgstr "Các ranh giới"
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:291 ../raster/r.in.bin/main.c:346
 msgid "Southern limit of geographic region (outer edge)"
-msgstr "Cận phía nam của vùng địa lý (mép ngoài cùng)"
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:299 ../raster/r.in.bin/main.c:354
 msgid "Eastern limit of geographic region (outer edge)"
-msgstr "Cận phía đông của vùng địa lý (mép ngoài cùng)"
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:307 ../raster/r.in.bin/main.c:362
 msgid "Western limit of geographic region (outer edge)"
-msgstr "Cận phía tây của vùng địa lý (mép ngoài cùng)"
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:315
-#, fuzzy
 msgid "Bottom limit of geographic region (outer edge)"
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:322
-#, fuzzy
 msgid "Top limit of geographic region (outer edge)"
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:329 ../raster/r.in.bin/main.c:369
 msgid "Number of rows"
-msgstr "Số hàng"
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:336 ../raster/r.in.bin/main.c:376
 msgid "Number of columns"
-msgstr "Số cột"
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:343
-#, fuzzy
 msgid "Number of depths"
-msgstr "Số hàng"
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:350 ../raster/r.in.bin/main.c:383
 msgid "Set Value to NULL"
-msgstr "Thiết lập giá trị thành NULL"
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:354 ../raster3d/r3.out.ascii/main.c:106
 #: ../raster3d/r3.out.bin/main.c:240
@@ -790,9 +740,8 @@
 msgstr ""
 #: ../raster3d/r3.in.bin/main.c:365
-#, fuzzy
 msgid "Binary data is of type integer"
-msgstr "Cột key phải là số nguyên"
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:369 ../raster/r.in.bin/main.c:274
 msgid "Signed data (two's complement)"
@@ -815,28 +764,28 @@
 #: ../display/d.grid/main.c:266
 #, c-format
 msgid "Illegal north coordinate <%s>"
-msgstr "Tọa độ bắc không hợp lệ <%s>"
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:426 ../raster/r.in.bin/main.c:523
 #, c-format
 msgid "Illegal south coordinate <%s>"
-msgstr "Tọa độ nam không hợp lệ <%s>"
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:428 ../raster/r.in.bin/main.c:525
 #: ../display/d.grid/main.c:259
 #, c-format
 msgid "Illegal east coordinate <%s>"
-msgstr "Tọa độ đông không hợp lệ <%s>"
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:430 ../raster/r.in.bin/main.c:527
 #, c-format
 msgid "Illegal west coordinate <%s>"
-msgstr "Tọa độ tây không hợp lệ <%s>"
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:438 ../raster/r.in.bin/main.c:533
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open <%s>"
-msgstr "Không thể mở tập tin <%s>"
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:446
 #, c-format
@@ -844,122 +793,77 @@
 msgstr ""
 #: ../raster3d/r3.in.bin/main.c:448 ../raster/r.in.bin/main.c:577
-#, fuzzy
 msgid "Bytes do not match file size"
-msgstr "Số byte không khớp với kích thước tập tin"
+msgstr ""
 #: ../raster3d/r3.in.bin/main.c:463 ../raster3d/r3.in.ascii/main.c:387
 #: ../raster3d/r3.in.v5d/main.c:201
-#, fuzzy
 msgid "Unable to open 3D raster map"
+msgstr ""
 #: ../raster3d/r3.gwflow/main.c:54
-#, fuzzy
 msgid "Input 3D raster map with initial piezometric heads in [m]"
-msgstr "Đầu đo áp suất ban đầu tính bằng [m]"
+msgstr ""
 #: ../raster3d/r3.gwflow/main.c:60
-#, fuzzy
-msgid ""
-"Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - "
-"active, 2 - dirichlet"
+msgid "Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
 msgstr ""
-"Trạng thái của mỗi ô, =0 - không kích hoạt, 1 - kích hoạt, 2 - dirichlet"
 #: ../raster3d/r3.gwflow/main.c:65
-#, fuzzy
-msgid ""
-"Input 3D raster map with the x-part of the hydraulic conductivity tensor in "
-"[m/s]"
-msgstr "Phần x của sức căng độ dẫn thủy lực tính bằng [m/s]"
+msgid "Input 3D raster map with the x-part of the hydraulic conductivity tensor in [m/s]"
+msgstr ""
 #: ../raster3d/r3.gwflow/main.c:70
-#, fuzzy
-msgid ""
-"Input 3D raster map with the y-part of the hydraulic conductivity tensor in "
-"[m/s]"
-msgstr "Phần y của sức căng độ dẫn thủy lực tính bằng [m/s]"
+msgid "Input 3D raster map with the y-part of the hydraulic conductivity tensor in [m/s]"
+msgstr ""
 #: ../raster3d/r3.gwflow/main.c:75
-#, fuzzy
-msgid ""
-"Input 3D raster map with the z-part of the hydraulic conductivity tensor in "
-"[m/s]"
-msgstr "Phần z của sức căng độ dẫn thủy lực tính bằng [m/s]"
+msgid "Input 3D raster map with the z-part of the hydraulic conductivity tensor in [m/s]"
+msgstr ""
 #: ../raster3d/r3.gwflow/main.c:80
-#, fuzzy
 msgid "Input 3D raster map with sources and sinks in [m^3/s]"
-msgstr "Các nguồn nước và các chỗ lún tính bằng [m^3/gi]"
+msgstr ""
 #: ../raster3d/r3.gwflow/main.c:84
-#, fuzzy
 msgid "Specific yield [1/m] input 3D raster map"
-msgstr "Lưu lượng riêng tính bằng [1/m]"
+msgstr ""
 #: ../raster3d/r3.gwflow/main.c:89
-#, fuzzy
 msgid "Recharge input 3D raster map in m^3/s"
-msgstr "Bản đồ raster nạp tính theo m^3/s"
+msgstr ""
 #: ../raster3d/r3.gwflow/main.c:93
-#, fuzzy
-msgid ""
-"Output 3D raster map storing the piezometric head result of the numerical "
-"calculation"
-msgstr "Kết quả đầu đo áp suât của tính toán số liệu sẽ được ghi ra bản đồ này"
+msgid "Output 3D raster map storing the piezometric head result of the numerical calculation"
+msgstr ""
 #: ../raster3d/r3.gwflow/main.c:99
-#, fuzzy
-msgid ""
-"Output 3D raster map storing the groundwater filter velocity vector part in "
-"x direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in x direction [m/s]"
 msgstr ""
-"Tính toán trường vec-tơ tốc độ lọc nước ngầm [m/gi]\n"
và ghi các thành phần x và y ra các bản đồ được đặt tên là tên_[xy]"
 #: ../raster3d/r3.gwflow/main.c:105
-#, fuzzy
-msgid ""
-"y direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in y direction [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:111
-#, fuzzy
-msgid ""
-"z direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in z direction [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:117
-#, fuzzy
-msgid ""
-"Output 3D raster map storing the groundwater budget for each cell [m^3/s]"
+msgid "Output 3D raster map storing the groundwater budget for each cell [m^3/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:127
-#, fuzzy
 msgid "Use 3D raster mask (if exists)"
+msgstr ""
 #: ../raster3d/r3.gwflow/main.c:131 ../raster/r.solute.transport/main.c:192
-msgid ""
-"Use a full filled quadratic linear equation system, default is a sparse "
-"linear equation system."
+msgid "Use a full filled quadratic linear equation system, default is a sparse linear equation system."
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:160 ../raster/r.gwflow/main.c:209
-#, fuzzy
 msgid "groundwater flow"
-msgstr "Kiểu dòng chảy nước ngầm"
+msgstr ""
 #: ../raster3d/r3.gwflow/main.c:162 ../raster3d/r3.flow/main.c:180
 #: ../raster/r.sim/r.sim.sediment/main.c:114
@@ -975,94 +879,82 @@
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:163
-#, fuzzy
-msgid ""
-"Numerical calculation program for transient, confined groundwater flow in "
-"three dimensions."
+msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions."
 msgstr ""
-"Chương trình tính toán số cho dòng chảy nước ngầm tạm thời, giới hạn theo ba "
-"chiều"
 #: ../raster3d/r3.gwflow/main.c:180
-#, fuzzy
 msgid ""
 "The cholesky solver does not work with sparse matrices.\n"
 "Consider to choose a full filled quadratic matrix with flag -f "
-msgstr "Trình giải Cholesky trực tiếp không làm việc với các ma trận rời rạc"
+msgstr ""
 #: ../raster3d/r3.gwflow/main.c:279 ../raster/r.gwflow/main.c:546
 msgid "Unable to create and solve the linear equation system"
-msgstr "Không thể tạo và giải hệ phương trình tuyến tính"
+msgstr ""
 #: ../raster3d/r3.gwflow/main.c:365 ../raster3d/r3.in.lidar/main.c:484
 #: ../raster3d/r3.in.lidar/main.c:493 ../raster3d/r3.in.lidar/main.c:501
 #: ../raster3d/r3.in.lidar/main.c:509 ../raster3d/r3.in.lidar/main.c:517
 #: ../raster3d/r3.in.lidar/main.c:527 ../raster3d/r3.in.lidar/main.c:536
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create 3D raster map <%s>"
-msgstr "Không thể tạo bản đồ raster <%s>"
+msgstr ""
 #: ../raster3d/r3.out.ascii/main.c:82
-#, fuzzy
 msgid "3D raster map to be converted to ASCII"
-msgstr "Bản đồ raster 3d cần đổi thành ASCII"
+msgstr ""
 #: ../raster3d/r3.out.ascii/main.c:86
 msgid "Name for ASCII output file"
-msgstr "Tên tập tin ASCII đầu ra"
+msgstr ""
 #: ../raster3d/r3.out.ascii/main.c:95
 msgid "Number of decimal places for floats"
-msgstr "Số chữ số thập phân cho giá trị float "
+msgstr ""
 #: ../raster3d/r3.out.ascii/main.c:102 ../raster/r.out.ascii/main.c:95
 msgid "Suppress printing of header information"
-msgstr "Chặn in ra thông tin header"
+msgstr ""
 #: ../raster3d/r3.out.ascii/main.c:114
 msgid "Print grass6 compatible format. Flags -d and -r are ignored."
 msgstr ""
 #: ../raster3d/r3.out.ascii/main.c:308
-#, fuzzy
 msgid "Converts a 3D raster map layer into a ASCII text file."
+msgstr ""
 #: ../raster3d/r3.out.ascii/main.c:371
-#, fuzzy
 msgid "Unable to close new ASCII file"
-msgstr "Không thể mở tập tin ASCII <%s>"
+msgstr ""
 #: ../raster3d/r3.out.bin/main.c:113 ../raster/r.out.bin/main.c:53
 #: ../raster/r.out.bin/main.c:62 ../raster/r.out.bin/main.c:470
 #: ../raster/r.mapcalc/map3.c:128 ../raster/r.mapcalc/map3.c:142
 #: ../raster/r.mapcalc/map3.c:156
 msgid "Error writing data"
-msgstr "Lỗi khi đang ghi dữ liệu"
+msgstr ""
 #: ../raster3d/r3.out.bin/main.c:208
-#, fuzzy
 msgid "Exports a GRASS 3D raster map to a binary array."
-msgstr "Xuất dữ liệu raster GRASS thành một mảng nhị phân."
+msgstr ""
 #: ../raster3d/r3.out.bin/main.c:221 ../raster/r.out.bin/main.c:304
 msgid "Value to write out for null"
-msgstr "Giá trị để ghi vào các ô rỗng"
+msgstr ""
 #: ../raster3d/r3.out.bin/main.c:235 ../raster/r.in.bin/main.c:330
 #: ../raster/r.out.bin/main.c:318
-#, fuzzy
 msgid "Output byte order"
-msgstr "Xuất ra tập tin world TIFF"
+msgstr ""
 #: ../raster3d/r3.out.bin/main.c:250
-#, fuzzy
 msgid "Write data as integer"
-msgstr "Đọc bản đồ fp (dấu chấm động) ở dạng số nguyên"
+msgstr ""
 #: ../raster3d/r3.out.bin/main.c:256 ../raster/r.out.bin/main.c:347
 msgid "Invalid value for null (integers only)"
-msgstr "Giá trị cho null không hợp lệ (chỉ được các giá trị nguyên)"
+msgstr ""
 #: ../raster3d/r3.out.bin/main.c:269
 msgid "Floating-point output requires bytes=4 or bytes=8"
@@ -1077,31 +969,31 @@
 #: ../display/d.mon/start.c:181 ../display/d.mon/start.c:224
 #, c-format
 msgid "Unable to create file <%s>"
+msgstr ""
 #: ../raster3d/r3.out.bin/main.c:323 ../raster/r.out.bin/main.c:454
 msgid "Using the current region settings..."
-msgstr "Đang dùng các thiết lập vùng hiện tại..."
+msgstr ""
 #: ../raster3d/r3.out.bin/main.c:324 ../raster/r.out.bin/main.c:455
 #, c-format
 msgid "north=%f"
-msgstr "bắc=%f"
+msgstr ""
 #: ../raster3d/r3.out.bin/main.c:325 ../raster/r.out.bin/main.c:456
 #, c-format
 msgid "south=%f"
-msgstr "nam=%f"
+msgstr ""
 #: ../raster3d/r3.out.bin/main.c:326 ../raster/r.out.bin/main.c:457
 #, c-format
 msgid "east=%f"
-msgstr "đông=%f"
+msgstr ""
 #: ../raster3d/r3.out.bin/main.c:327 ../raster/r.out.bin/main.c:458
 #, c-format
 msgid "west=%f"
-msgstr "tây=%f"
+msgstr ""
 #: ../raster3d/r3.out.bin/main.c:328
 #, c-format
@@ -1117,13 +1009,13 @@
 #: ../raster/r.out.mat/main.c:180
 #, c-format
 msgid "rows=%d"
-msgstr "hàng=%d"
+msgstr ""
 #: ../raster3d/r3.out.bin/main.c:331 ../raster/r.in.mat/main.c:399
 #: ../raster/r.out.mat/main.c:181
 #, c-format
 msgid "cols=%d"
-msgstr "cột=%d"
+msgstr ""
 #: ../raster3d/r3.out.bin/main.c:332
 #, c-format
@@ -1132,33 +1024,29 @@
 #: ../raster3d/r3.info/main.c:78 ../raster/r.info/main.c:72
 #: ../locale/scriptstrings/t.info_to_translate.c:4 ../vector/v.info/main.c:40
-#, fuzzy
 msgid "extent"
-msgstr "tổng quát"
+msgstr ""
 #: ../raster3d/r3.info/main.c:80
 msgid "Outputs basic information about a user-specified 3D raster map layer."
 msgstr ""
-"Xuất ra thông tin cơ bản về một lớp bản đồ raster 3D do người dùng chỉ định."
 #: ../raster3d/r3.info/main.c:86
-#, fuzzy
 msgid "Print raster3d information in shell style"
-msgstr "In ra ở dạng tập lệnh shell"
+msgstr ""
 #: ../raster3d/r3.info/main.c:90
-#, fuzzy
 msgid "Print range in shell style only"
+msgstr ""
 #: ../raster3d/r3.info/main.c:94 ../raster/r.info/main.c:93
 msgid "Print raster history instead of info"
-msgstr "Chỉ in ra lịch sử thay vì thông tin"
+msgstr ""
 #: ../raster3d/r3.info/main.c:103
-#, fuzzy, c-format
+#, c-format
 msgid "3D Raster map <%s> not found"
+msgstr ""
 #: ../raster3d/r3.info/main.c:138 ../raster3d/r3.info/main.c:145
 #: ../raster3d/r3.info/main.c:151 ../raster3d/r3.info/main.c:156
@@ -1177,51 +1065,46 @@
 #: ../raster3d/r3.info/main.c:369 ../raster3d/r3.info/main.c:382
 #: ../raster/r.info/main.c:303 ../raster/r.info/main.c:445
 msgid "Cannot allocate memory for string"
-msgstr "Không thể cấp phát bộ nhớ cho chuỗi "
+msgstr ""
 #: ../raster3d/r3.info/main.c:328 ../raster3d/r3.info/main.c:448
 #: ../raster3d/r3.mkdspf/main.c:171
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read range of 3D raster map <%s>"
-msgstr "Không thể đọc miền của bản đồ raster <%s>"
+msgstr ""
 #: ../raster3d/r3.info/main.c:492
 msgid "Error while reading history file"
-msgstr "Lỗi khi đang đọc tập tin lịch sử"
+msgstr ""
 #: ../raster3d/r3.info/main.c:499 ../raster3d/r3.null/main.c:169
 #: ../raster3d/r3.cross.rast/main.c:343
 #: ../raster3d/r3.out.vtk/errorHandling.c:65
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to close 3D raster map <%s>"
+msgstr ""
 #: ../raster3d/r3.in.ascii/main.c:86 ../raster/r.in.ascii/main.c:78
 #: ../vector/v.in.ascii/main.c:78
-#, fuzzy
 msgid "Name of input file to be imported"
+msgstr ""
 #: ../raster3d/r3.in.ascii/main.c:87 ../db/db.execute/main.c:139
 #: ../db/db.select/main.c:208 ../raster/r.reclass/main.c:66
 #: ../raster/r.in.ascii/main.c:79 ../raster/r.recode/main.c:61
-#: ../locale/scriptstrings/m.proj_to_translate.c:8
-#: ../general/g.proj/main.c:141 ../general/g.proj/main.c:150
-#: ../vector/v.segment/main.c:80 ../vector/v.edit/args.c:89
-#: ../vector/v.what/main.c:76
-#, fuzzy
+#: ../locale/scriptstrings/m.proj_to_translate.c:8 ../general/g.proj/main.c:141
+#: ../general/g.proj/main.c:150 ../vector/v.segment/main.c:80
+#: ../vector/v.edit/args.c:89 ../vector/v.what/main.c:76
 msgid "'-' for standard input"
-msgstr "Nếu là '-' thì đọc từ đầu vào tiêu chuẩn"
+msgstr ""
 #: ../raster3d/r3.in.ascii/main.c:94
 msgid "String representing NULL value data cell (use 'none' if no such value)"
 msgstr ""
-"Chuỗi biểu thị ô dữ liệu có giá trị NULL (dùng 'none' nếu không có giá trị "
-"như vậy)"
 #: ../raster3d/r3.in.ascii/main.c:130 ../raster/r.in.ascii/main.c:275
 msgid "Unable to write to file"
-msgstr "Không thể ghi vào tập tin"
+msgstr ""
 #: ../raster3d/r3.in.ascii/main.c:169 ../raster/r.resamp.rst/main.c:542
 #: ../raster/r.in.ascii/main.c:120 ../raster/r.in.ascii/main.c:150
@@ -1231,25 +1114,25 @@
 #: ../vector/v.in.ascii/main.c:273
 #, c-format
 msgid "Unable to open temporary file <%s>"
-msgstr "Không thể mở tập tin tạm <%s>"
+msgstr ""
 #: ../raster3d/r3.in.ascii/main.c:172 ../raster/r.in.ascii/main.c:153
 msgid "Unable to read input from stdin"
-msgstr "Không thể đọc đầu vào từ đầu vào tiêu chuẩn"
+msgstr ""
 #: ../raster3d/r3.in.ascii/main.c:221
-#, fuzzy, c-format
+#, c-format
 msgid "Unsupported GRASS version %s"
-msgstr "Kiểu cột của <%s> không được hỗ trợ"
+msgstr ""
 #: ../raster3d/r3.in.ascii/main.c:265
 #, c-format
 msgid "Loading data ...  (%dx%dx%d)"
+msgstr ""
 #: ../raster3d/r3.in.ascii/main.c:298
 msgid "End of file reached while still loading data."
-msgstr "Đến cuối tập tin khi vẫn đang nạp dữ liệu."
+msgstr ""
 #: ../raster3d/r3.in.ascii/main.c:310
 #, c-format
@@ -1258,43 +1141,32 @@
 #: ../raster3d/r3.in.ascii/main.c:322
 #, c-format
-msgid ""
-"Data exists in input file after fully importing expected data.  [%.4f ...]"
+msgid "Data exists in input file after fully importing expected data.  [%.4f ...]"
 msgstr ""
-"Dữ liệu tồn tại trong tập tin đầu vào sau khi nhập toàn bộ dữ liệu mong "
-"đợi.  [%.4f ...]"
 #: ../raster3d/r3.in.ascii/main.c:360
-#, fuzzy
 msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
 msgstr ""
-"Đổi một tập tin văn bản raster ASCII 3D thành một lớp bản đồ raster 3D (nhị "
-"phân)"
 #: ../raster3d/r3.in.ascii/main.c:403
-#, fuzzy
 msgid "Unable to close ASCII file"
+msgstr ""
 #: ../raster3d/r3.support/main.c:52
-#, fuzzy
-msgid ""
-"Allows creation and/or modification of 3D raster map layer support files."
+msgid "Allows creation and/or modification of 3D raster map layer support files."
 msgstr ""
-"Cho phép tạo và/hoặc thay đổi các tập tin hỗ trợ của lớp bản đồ raster."
 #: ../raster3d/r3.support/main.c:62
 msgid "Text to use for map title"
-msgstr "Nội dung dùng làm tiêu đề bản đồ"
+msgstr ""
 #: ../raster3d/r3.support/main.c:70 ../raster/r.support/main.c:74
 msgid "Text to append to the next line of the map's metadata file"
-msgstr "Nội dung đính vào dòng kế tiếp trong tập tin mô tả dữ liệu của bản đồ"
+msgstr ""
 #: ../raster3d/r3.support/main.c:76
-#, fuzzy
 msgid "The map data unit"
-msgstr "Nội dung dùng cho đơn vị dữ liệu của bản đồ"
+msgstr ""
 #: ../raster3d/r3.support/main.c:82
 msgid "The vertical unit of the map"
@@ -1302,20 +1174,20 @@
 #: ../raster3d/r3.support/main.c:89 ../raster/r.support/main.c:93
 msgid "Text to use for data source, line 1"
-msgstr "Nội dung dùng cho nguồn dữ liệu, dòng 1"
+msgstr ""
 #: ../raster3d/r3.support/main.c:96 ../raster/r.support/main.c:100
 msgid "Text to use for data source, line 2"
-msgstr "Nội dung dùng cho nguồn dữ liệu, dòng 2"
+msgstr ""
 #: ../raster3d/r3.support/main.c:104 ../raster/r.support/main.c:108
 msgid "Text to use for data description or keyword(s)"
-msgstr "Nội dung dùng cho mô tả dữ liệu hoặc (các) từ khoá"
+msgstr ""
 #: ../raster3d/r3.support/main.c:111 ../raster/r.support/main.c:115
 #: ../raster/r.category/main.c:80
 msgid "Raster map from which to copy category table"
-msgstr "Bản đồ raster để sao chép bảng phạm trù từ đó"
+msgstr ""
 #: ../raster3d/r3.support/main.c:116 ../raster/r.support/main.c:120
 msgid "Text file from which to load history"
@@ -1326,9 +1198,8 @@
 msgstr ""
 #: ../raster3d/r3.support/main.c:125
-#, fuzzy
 msgid "Update range"
-msgstr "Miền dữ liệu đầu ra"
+msgstr ""
 #: ../raster3d/r3.support/main.c:153 ../raster/r.support/main.c:162
 #: ../raster/r.out.png/main.c:205 ../raster/r.out.pov/main.c:173
@@ -1337,7 +1208,7 @@
 #: ../general/g.cairocomp/main.c:66 ../vector/v.colors.out/main.c:103
 #, c-format
 msgid "Unable to open output file <%s>"
-msgstr "Không thể mở tập tin đầu ra <%s>"
+msgstr ""
 #: ../raster3d/r3.support/main.c:167 ../raster/r.support/main.c:176
 #: ../raster/r.in.mat/main.c:125 ../raster/r.series.accumulate/main.c:221
@@ -1352,79 +1223,74 @@
 #: ../vector/v.segment/main.c:98 ../vector/v.net.path/path.c:49
 #, c-format
 msgid "Unable to open input file <%s>"
-msgstr "Không thể mở tập tin đầu vào <%s>"
+msgstr ""
 #: ../raster3d/r3.support/main.c:248 ../raster/r.support/main.c:245
 #: ../raster/r.statistics/main.c:110 ../display/d.title/main.c:110
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read category file of raster map <%s>"
-msgstr "không thể ghi tập tin phạm trù cho <%s>"
+msgstr ""
 #: ../raster3d/r3.support/main.c:252 ../raster/r.support/main.c:249
 #, c-format
 msgid "cats table for [%s] set to %s"
-msgstr "Bảng phạm trù cho [%s] được thiết lập thành %s"
+msgstr ""
 #: ../raster3d/r3.support/check.c:20
-#, fuzzy, c-format
+#, c-format
 msgid "Updating statistics for <%s>"
 msgstr ""
-"\n"
-"  Đang cập nhật thống kê cho [%s]"
 #: ../raster3d/r3.support/check.c:36
-#, fuzzy, c-format
+#, c-format
 msgid "Updating the number of categories for <%s>"
-msgstr "Đang cập nhật số lượng phạm trù cho [%s]..."
+msgstr ""
 #: ../raster3d/r3.null/main.c:55
-#, fuzzy
 msgid "3D raster map for which to modify null values"
-msgstr "bản đồ raster 3d để thay đổi các giá trị rỗng"
+msgstr ""
 #: ../raster3d/r3.null/main.c:63 ../raster/r.null/main.c:73
 msgid "List of cell values to be set to NULL"
-msgstr "Danh sách các giá trị ô cần được thiết lập thành NULL"
+msgstr ""
 #: ../raster3d/r3.null/main.c:70 ../raster/r.null/main.c:81
 msgid "The value to replace the null value by"
-msgstr "Giá trị dùng để thay thế cho giá trị rỗng theo"
+msgstr ""
 #: ../raster3d/r3.null/main.c:85
 msgid "Illegal value for null"
-msgstr "giá trị cho null không hợp lệ"
+msgstr ""
 #: ../raster3d/r3.null/main.c:122
 msgid "modifyNull: error opening tmp file"
-msgstr "modifyNull: lỗi khi đang mở tập tin tạm"
+msgstr ""
 #: ../raster3d/r3.null/main.c:156
 msgid "modifyNull: error flushing tiles in cube"
-msgstr "modifyNull: lỗi khi đang đổ các chồng xếp vào khối"
+msgstr ""
 #: ../raster3d/r3.null/main.c:161
 msgid "modifyNull: error flushing all tiles"
-msgstr "modifyNull: lỗi khi đang đổ tất cả các chồng xếp"
+msgstr ""
 #: ../raster3d/r3.null/main.c:171
-#, fuzzy
 msgid "modifyNull: Unable to close tmp file"
-msgstr "modifyNull: lỗi khi đang đóng tập tin tạm"
+msgstr ""
 #: ../raster3d/r3.null/main.c:187 ../raster/r.null/main.c:61
-#, fuzzy
 msgid "null data"
-msgstr "raster, dữ liệu rỗng"
+msgstr ""
 #: ../raster3d/r3.null/main.c:190
 msgid "Explicitly create the 3D NULL-value bitmap file."
-msgstr "Tạo ra rõ rệt tập tin bitmap có giá trị NULL kiểu 3D"
+msgstr ""
 #: ../raster3d/r3.in.lidar/string_list.c:47
 #: ../raster/r.in.lidar/string_list.c:34
-#, fuzzy, c-format
+#, c-format
 msgid "Cannot open file %s for reading"
-msgstr "Không thể mở tập tin [%s] để đọc"
+msgstr ""
 #: ../raster3d/r3.in.lidar/filters.c:27
 #, fuzzy, c-format
@@ -1433,18 +1299,17 @@
 #: ../raster3d/r3.in.lidar/filters.c:54 ../vector/v.in.pdal/filters.c:95
 #: ../vector/v.in.lidar/filters.c:36
-#, fuzzy, c-format
+#, c-format
 msgid "Unknown return filter value <%s>"
-msgstr "Không hiểu tùy chọn quy tắc: '%s'"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:164 ../raster/r.in.lidar/main.c:110
 #: ../raster/r.in.xyz/main.c:165
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:5
 #: ../vector/v.out.lidar/main.c:473 ../vector/v.decimate/main.c:124
 #: ../vector/v.lidar.growing/main.c:76 ../vector/v.in.lidar/main.c:138
-#: ../vector/v.surf.bspline/main.c:94
-#: ../vector/v.lidar.edgedetection/main.c:73 ../vector/v.outlier/main.c:74
-#: ../vector/v.lidar.correction/main.c:69
+#: ../vector/v.surf.bspline/main.c:94 ../vector/v.lidar.edgedetection/main.c:73
+#: ../vector/v.outlier/main.c:74 ../vector/v.lidar.correction/main.c:69
 msgid "LIDAR"
 msgstr ""
@@ -1458,30 +1323,24 @@
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:3
 #: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:3
 #: ../vector/v.neighbors/main.c:54
-#, fuzzy
 msgid "aggregation"
-msgstr "Tạo"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:168 ../raster/r.in.lidar/main.c:114
 #: ../raster/r.in.xyz/main.c:163
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:9
-#, fuzzy
 msgid "binning"
-msgstr "Đang tạo hộc dữ liệu"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:170
 #, fuzzy
-msgid ""
-"Creates a 3D raster map from LAS LiDAR points using univariate statistics."
-msgstr ""
-"Tạo một bản đồ raster từ sự tập hợp nhiều tọa độ bằng các dùng thống kê một "
-"biến."
+msgid "Creates a 3D raster map from LAS LiDAR points using univariate statistics."
+msgstr "Tạo một bản đồ raster từ sự tập hợp nhiều tọa độ bằng các dùng thống kê một biến."
 #: ../raster3d/r3.in.lidar/main.c:174 ../raster/r.in.lidar/main.c:120
 #: ../vector/v.in.lidar/main.c:142
-#, fuzzy
 msgid "LAS input file"
-msgstr "Tập tin đầu vào"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:176
 msgid "LiDAR input file in LAS format (*.las or *.laz)"
@@ -1542,12 +1401,11 @@
 #: ../vector/v.edit/args.c:90 ../vector/v.edit/args.c:209
 #: ../vector/v.in.ogr/main.c:160
 msgid "Input"
-msgstr "Đầu vào"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:181 ../raster/r.in.lidar/main.c:130
-#, fuzzy
 msgid "File containing names of LAS input files"
-msgstr "Tập tin chứa các quy tắc mã hoá"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:182 ../raster/r.in.lidar/main.c:121
 #: ../raster/r.in.lidar/main.c:131 ../vector/v.in.lidar/main.c:143
@@ -1555,9 +1413,8 @@
 msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:189
-#, fuzzy
 msgid "Count of points per cell"
-msgstr "Không đánh chỉ mục các điểm theo ô raster"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:190 ../raster3d/r3.in.lidar/main.c:196
 #: ../raster3d/r3.in.lidar/main.c:202 ../raster3d/r3.flow/main.c:211
@@ -1615,37 +1472,32 @@
 #: ../vector/v.in.ogr/main.c:270 ../vector/v.in.ogr/main.c:276
 #: ../vector/v.in.ogr/main.c:318 ../vector/v.out.ascii/args.c:35
 #: ../vector/v.out.ascii/args.c:81
-#, fuzzy
 msgid "Output"
-msgstr "Đầu ra"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:195
-#, fuzzy
 msgid "Sum of values of point intensities per cell"
-msgstr "Số lượng lần chạy lặp \t= %d ô\n"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:201
 msgid "Mean of point intensities per cell"
 msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:209
-#, fuzzy
 msgid "3D raster map of proportional point count"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:211
 msgid "Point count per 3D cell divided by point count per vertical column"
 msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:213 ../raster3d/r3.in.lidar/main.c:223
-#, fuzzy
 msgid "Proportional output"
-msgstr "Đang ghi bản đồ..."
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:219
-#, fuzzy
 msgid "3D raster map of proportional sum of values"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:221
 msgid "Sum of values per 3D cell divided by sum of values per vertical column"
@@ -1658,9 +1510,8 @@
 #: ../raster3d/r3.in.lidar/main.c:230 ../raster/r.in.lidar/main.c:259
 #: ../vector/v.in.lidar/main.c:202
-#, fuzzy
 msgid "If not specified, all points are imported"
-msgstr "Các giá trị số nguyên được nhập vào"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:232 ../raster3d/r3.in.lidar/main.c:242
 #: ../raster3d/r3.in.lidar/main.c:272 ../raster3d/r3.in.lidar/main.c:288
@@ -1739,7 +1590,7 @@
 #: ../vector/v.extrude/main.c:84 ../vector/v.extrude/main.c:87
 #: ../vector/v.extrude/main.c:90 ../vector/v.extrude/main.c:95
 msgid "Selection"
-msgstr "Phép chọn"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:239 ../raster/r.in.lidar/main.c:268
 #: ../vector/v.in.lidar/main.c:211
@@ -1748,15 +1599,12 @@
 #: ../raster3d/r3.in.lidar/main.c:240 ../raster/r.in.lidar/main.c:269
 #: ../vector/v.in.lidar/main.c:212
-#, fuzzy
-msgid ""
-"Input is comma separated integers. If not specified, all points are imported."
+msgid "Input is comma separated integers. If not specified, all points are imported."
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:248
-#, fuzzy
 msgid "Subtract raster values from the z coordinates"
-msgstr "Giá trị dịch chuyển đối với các tọa độ z"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:250
 msgid "The scale for z is applied beforehand, the filter afterwards"
@@ -1765,39 +1613,33 @@
 #: ../raster3d/r3.in.lidar/main.c:251 ../raster3d/r3.in.lidar/main.c:264
 #: ../raster3d/r3.in.lidar/main.c:280 ../raster/r.in.lidar/main.c:184
 #: ../raster/r.in.lidar/main.c:200 ../raster/r.in.lidar/main.c:216
-#, fuzzy
 msgid "Transform"
-msgstr "vector, chuyển đổi"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:256
 msgid "Use base raster actual resolution instead of computational region"
 msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:263 ../raster/r.in.lidar/main.c:199
-#, fuzzy
 msgid "Scale to apply to Z data"
-msgstr "Tỷ lệ áp dụng cho dữ liệu z"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:271 ../raster/r.in.lidar/main.c:207
-#, fuzzy
 msgid "Filter range for intensity values (min,max)"
-msgstr "Miền giá trị lọc cho dữ liệu z (min,max)"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:279 ../raster/r.in.lidar/main.c:215
-#, fuzzy
 msgid "Scale to apply to intensity values"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:284 ../raster/r.in.lidar/main.c:335
 #: ../vector/v.in.lidar/main.c:291
-#, fuzzy
 msgid "Use only valid points"
-msgstr "Đang nhập các điểm..."
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:286 ../raster/r.in.lidar/main.c:337
 #: ../vector/v.in.lidar/main.c:293
-msgid ""
-"Points invalid according to APSRS LAS specification will be filtered out"
+msgid "Points invalid according to APSRS LAS specification will be filtered out"
 msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:293 ../raster/r.in.lidar/main.c:299
@@ -1810,9 +1652,8 @@
 #: ../locale/scriptstrings/t.vect.import_to_translate.c:13
 #: ../vector/v.in.lidar/main.c:319 ../vector/v.in.ogr/main.c:284
 #: ../vector/v.external/args.c:43
-#, fuzzy
 msgid "Override projection check (use current location's projection)"
-msgstr "Ghi đè phép chiếu (dùng phép chiếu của vị trí)"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:295 ../raster/r.in.lidar/main.c:301
 #: ../raster/r.external/main.c:104 ../raster/r.in.gdal/main.c:180
@@ -1821,27 +1662,25 @@
 #: ../locale/scriptstrings/r.unpack_to_translate.c:9
 #: ../locale/scriptstrings/t.vect.import_to_translate.c:14
 #: ../vector/v.in.lidar/main.c:321
-#, fuzzy
 msgid "Assume that the dataset has same projection as the current location"
-msgstr "Không thể lấy đơn vị phép chiếu của vị trí hiện tại"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:299 ../raster/r.in.lidar/main.c:276
 #: ../vector/v.in.lidar/main.c:276
-#, fuzzy
 msgid "Print LAS file info and exit"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:303 ../raster/r.in.lidar/main.c:305
 #: ../raster/r.in.xyz/main.c:327
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:10
 msgid "Scan data file for extent then exit"
-msgstr "Quét tập tin dữ liệu để lấy phạm vi và thoát"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:307 ../raster/r.in.lidar/main.c:310
 #: ../raster/r.in.xyz/main.c:332
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:11
 msgid "In scan mode, print using shell script style"
-msgstr "Ở chế độ quét, in bằng cách dùng dạng tập lệnh shell"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:329
 #, fuzzy, c-format
@@ -1849,31 +1688,30 @@
 msgstr "miền giá trị z (zrange) sẽ không được xem xét trong quá trình quét"
 #: ../raster3d/r3.in.lidar/main.c:340 ../raster/r.in.lidar/main.c:367
-#, fuzzy, c-format
+#, c-format
 msgid "File <%s> does not exist"
-msgstr "Nhóm <%s> không tồn tại"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:374 ../raster/r.in.lidar/main.c:397
 #: ../vector/v.in.lidar/main.c:347
-#, fuzzy, c-format
+#, c-format
 msgid "Input file <%s> does not exist"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:378 ../raster/r.in.lidar/main.c:401
 #: ../vector/v.in.lidar/main.c:352
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open file <%s> as a LiDAR point cloud"
-msgstr "Không thể mở tập tin <%s> để ghi"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:382 ../raster/r.in.lidar/main.c:405
 #: ../vector/v.in.lidar/main.c:356
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read LAS header of <%s>"
-msgstr "Không thể đọc miền fp cho <%s>"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:398 ../raster/r.in.lidar/main.c:421
-msgid ""
-"First file's projection checked, checking projection of the other files..."
+msgid "First file's projection checked, checking projection of the other files..."
 msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:540
@@ -1882,9 +1720,8 @@
 msgstr "Đang đọc các bản raster... "
 #: ../raster3d/r3.in.lidar/main.c:574 ../vector/v.sample/main.c:200
-#, fuzzy
 msgid "Reading points..."
-msgstr "Đang đọc các đầu vào..."
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:656
 #, fuzzy
@@ -1907,19 +1744,19 @@
 msgstr "Đang che mặt nạ các bản đồ raster..."
 #: ../raster3d/r3.in.lidar/main.c:707 ../vector/v.in.lidar/main.c:783
-#, fuzzy, c-format
+#, c-format
 msgid "%lu input points were not valid and filtered out"
-msgstr "%d điểm nằm ngoài ngưỡng"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:710 ../vector/v.in.lidar/main.c:789
-#, fuzzy, c-format
+#, c-format
 msgid "%lu input points were filtered out by return number"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:712 ../vector/v.in.lidar/main.c:791
-#, fuzzy, c-format
+#, c-format
 msgid "%lu input points were filtered out by class number"
+msgstr ""
 #: ../raster3d/r3.in.lidar/main.c:714
 #, fuzzy, c-format
@@ -1927,80 +1764,66 @@
 #: ../raster3d/r3.in.lidar/main.c:716 ../vector/v.in.lidar/main.c:811
-#, fuzzy, c-format
+#, c-format
 msgid "%lu input points were not valid, use -%c flag to filter them out"
+msgstr ""
-#: ../raster3d/r3.in.lidar/projection.c:36
-#: ../raster/r.in.lidar/projection.c:34 ../raster/r.external/proj.c:42
-#: ../raster/r.in.gdal/main.c:479 ../vector/v.in.pdal/projection.c:31
-#: ../vector/v.in.lidar/projection.c:32 ../vector/v.in.ogr/main.c:627
-#: ../vector/v.external/proj.c:51
+#: ../raster3d/r3.in.lidar/projection.c:36 ../raster/r.in.lidar/projection.c:34
+#: ../raster/r.external/proj.c:42 ../raster/r.in.gdal/main.c:479
+#: ../vector/v.in.pdal/projection.c:31 ../vector/v.in.lidar/projection.c:32
+#: ../vector/v.in.ogr/main.c:627 ../vector/v.external/proj.c:51
 msgid ""
 "Projection of dataset does not appear to match current location.\n"
 "\n"
 msgstr ""
-"Phép chiếu của bộ dữ liệu và vị trí hiện tại không khớp nhau.\n"
\n"
-#: ../raster3d/r3.in.lidar/projection.c:42
-#: ../raster/r.in.lidar/projection.c:40 ../vector/v.in.pdal/projection.c:37
-#: ../vector/v.in.lidar/projection.c:38 ../vector/v.in.ogr/main.c:633
-#: ../vector/v.external/proj.c:57
+#: ../raster3d/r3.in.lidar/projection.c:42 ../raster/r.in.lidar/projection.c:40
+#: ../vector/v.in.pdal/projection.c:37 ../vector/v.in.lidar/projection.c:38
+#: ../vector/v.in.ogr/main.c:633 ../vector/v.external/proj.c:57
 msgid "GRASS LOCATION PROJ_INFO is:\n"
-msgstr "GRASS LOCATION PROJ_INFO là:\n"
+msgstr ""
 #: ../raster3d/r3.in.lidar/projection.c:51
-#: ../raster3d/r3.in.lidar/projection.c:57
-#: ../raster/r.in.lidar/projection.c:49 ../raster/r.in.lidar/projection.c:55
-#: ../raster/r.external/proj.c:85 ../raster/r.in.gdal/main.c:531
-#: ../vector/v.in.pdal/projection.c:46 ../vector/v.in.pdal/projection.c:52
-#: ../vector/v.in.lidar/projection.c:47 ../vector/v.in.lidar/projection.c:53
-#: ../vector/v.in.ogr/main.c:643 ../vector/v.in.ogr/main.c:650
-#: ../vector/v.external/proj.c:67 ../vector/v.external/proj.c:74
+#: ../raster3d/r3.in.lidar/projection.c:57 ../raster/r.in.lidar/projection.c:49
+#: ../raster/r.in.lidar/projection.c:55 ../raster/r.external/proj.c:85
+#: ../raster/r.in.gdal/main.c:531 ../vector/v.in.pdal/projection.c:46
+#: ../vector/v.in.pdal/projection.c:52 ../vector/v.in.lidar/projection.c:47
+#: ../vector/v.in.lidar/projection.c:53 ../vector/v.in.ogr/main.c:643
+#: ../vector/v.in.ogr/main.c:650 ../vector/v.external/proj.c:67
+#: ../vector/v.external/proj.c:74
 msgid "Import dataset PROJ_INFO is:\n"
-msgstr "PROJ_INFO của dữ liệu nhập vào là:\n"
+msgstr ""
-#: ../raster3d/r3.in.lidar/projection.c:93
-#: ../raster/r.in.lidar/projection.c:91 ../raster/r.external/proj.c:107
-#: ../raster/r.in.gdal/main.c:549 ../vector/v.in.pdal/projection.c:88
-#: ../vector/v.in.lidar/projection.c:89 ../vector/v.in.ogr/main.c:689
-#: ../vector/v.external/proj.c:113
+#: ../raster3d/r3.in.lidar/projection.c:93 ../raster/r.in.lidar/projection.c:91
+#: ../raster/r.external/proj.c:107 ../raster/r.in.gdal/main.c:549
+#: ../vector/v.in.pdal/projection.c:88 ../vector/v.in.lidar/projection.c:89
+#: ../vector/v.in.ogr/main.c:689 ../vector/v.external/proj.c:113
 #, c-format
 msgid ""
 "\n"
-"In case of no significant differences in the projection definitions, use the "
-"-o flag to ignore them and use current location definition.\n"
+"In case of no significant differences in the projection definitions, use the -o flag to ignore them and use current location definition.\n"
 msgstr ""
-#: ../raster3d/r3.in.lidar/projection.c:97
-#: ../raster/r.in.lidar/projection.c:95 ../vector/v.in.pdal/projection.c:92
-#: ../vector/v.in.lidar/projection.c:93 ../vector/v.in.ogr/main.c:693
-#: ../vector/v.external/proj.c:117
-msgid ""
-"Consider generating a new location with 'location' parameter from input data "
-"set.\n"
+#: ../raster3d/r3.in.lidar/projection.c:97 ../raster/r.in.lidar/projection.c:95
+#: ../vector/v.in.pdal/projection.c:92 ../vector/v.in.lidar/projection.c:93
+#: ../vector/v.in.ogr/main.c:693 ../vector/v.external/proj.c:117
+msgid "Consider generating a new location with 'location' parameter from input data set.\n"
 msgstr ""
-"Hãy cân nhắc việc tạo vị trí mới với tham số 'location' từ bộ dữ liệu đầu "
-"vào.\n"
 #: ../raster3d/r3.in.lidar/projection.c:115
 #: ../raster/r.in.lidar/projection.c:113 ../vector/v.in.pdal/projection.c:110
 #: ../vector/v.in.pdal/projection.c:156 ../vector/v.in.pdal/projection.c:189
 #: ../vector/v.in.lidar/projection.c:111 ../vector/v.in.ogr/main.c:603
 #: ../vector/v.external/proj.c:41
-msgid ""
-"Unable to convert input map projection information to GRASS format for "
-"checking"
+msgid "Unable to convert input map projection information to GRASS format for checking"
 msgstr ""
-"Không thể đổi phép chiếu của bản đồ đầu vào thành định dạng GRASS để kiểm tra"
 #: ../raster3d/r3.in.lidar/projection.c:130
 #: ../raster/r.in.lidar/projection.c:128 ../raster/r.external/proj.c:34
 #: ../raster/r.in.gdal/main.c:469 ../vector/v.in.lidar/projection.c:126
 #: ../vector/v.in.ogr/main.c:618
 msgid "Over-riding projection check"
-msgstr "Kiểm tra ghi đè phép chiếu"
+msgstr ""
 #: ../raster3d/r3.in.lidar/projection.c:141
 #: ../raster/r.in.lidar/projection.c:139 ../raster/r.external/proj.c:116
@@ -2008,116 +1831,97 @@
 #: ../vector/v.in.lidar/projection.c:137 ../vector/v.in.ogr/main.c:708
 #: ../vector/v.external/proj.c:122
 msgid "Projection of input dataset and current location appear to match"
-msgstr "Phép chiếu của bộ dữ liệu đầu vào và location hiện tại khớp nhau"
+msgstr ""
 #: ../raster3d/r3.in.lidar/rast_segment.c:53
 #: ../raster/r.in.lidar/rast_segment.c:40
-#, fuzzy
 msgid "Cannot create temporary file with segments of a raster map"
-msgstr "Không thể tạo tập tin tạm"
+msgstr ""
 #: ../raster3d/r3.in.lidar/info.c:109 ../raster/r.in.lidar/info.c:108
 #: ../raster/r.in.xyz/main.c:1198
 msgid "Scanning data ..."
-msgstr "Đang quét dữ liệu..."
+msgstr ""
 #: ../raster3d/r3.in.lidar/info.c:149 ../raster/r.in.lidar/info.c:148
 #: ../raster/r.in.xyz/main.c:1304
 #, c-format
 msgid "Range:     min         max\n"
-msgstr "Miền:     tối thiểu       tối đa\n"
+msgstr ""
 #: ../raster3d/r3.mask/main.c:75
-#, fuzzy
 msgid "Unable to open 3D raster mask file"
+msgstr ""
 #: ../raster3d/r3.mask/main.c:104
 msgid "makeMask: error flushing tiles in cube"
-msgstr "makeMask: lỗi khi đang đổ các chồng xếp vào khối"
+msgstr ""
 #: ../raster3d/r3.mask/main.c:109
 msgid "makeMask: error flushing all tiles"
-msgstr "makeMask: lỗi đổ tất cả các chồng xếp"
+msgstr ""
 #: ../raster3d/r3.mask/main.c:117
-#, fuzzy
 msgid "Unable to close 3D raster mask file"
+msgstr ""
 #: ../raster3d/r3.mask/main.c:119
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to close raster map <%s>"
+msgstr ""
 #: ../raster3d/r3.mask/main.c:134
 #: ../locale/scriptstrings/r.mask_to_translate.c:3
-#, fuzzy
 msgid "mask"
-msgstr "Nhóm phụ các tập tin ảnh"
+msgstr ""
 #: ../raster3d/r3.mask/main.c:137
 msgid "Establishes the current working 3D raster mask."
-msgstr "Thành lập mặt nạ raster 3D cho vùng làm việc hiện tại"
+msgstr ""
 #: ../raster3d/r3.mask/main.c:145
-#, fuzzy
 msgid "3D raster map with reference values"
-msgstr "bản đồ raster 3d với các giá trị tham chiếu"
+msgstr ""
 #: ../raster3d/r3.mask/main.c:153
 msgid "List of cell values to be masked out"
-msgstr "Liệt kê các giá trị ô bị loại bỏ bởi mặt nạ"
+msgstr ""
 #: ../raster3d/r3.mask/main.c:159
-#, fuzzy
 msgid "Cannot create mask file: RASTER3D_MASK already exists"
 msgstr ""
-"Không thể tạo tập tin mặt nạ: RASTER3D_MASK đã tồn tại!\n"
-" Dùng 'g.remove rast3d=RASTER3D_MASK' để loại bỏ mặt nạ hiện có."
 #: ../raster3d/r3.gradient/main.c:44
-#, fuzzy
 msgid "gradient"
-msgstr "Phương sai "
+msgstr ""
 #: ../raster3d/r3.gradient/main.c:47
-#, fuzzy
-msgid ""
-"Computes gradient of a 3D raster map and outputs gradient components as "
-"three 3D raster maps."
+msgid "Computes gradient of a 3D raster map and outputs gradient components as three 3D raster maps."
 msgstr ""
-"Kết hợp các bản đồ raster đỏ, lục, và xanh thành một bản đồ tổ hợp duy nhất."
 #: ../raster3d/r3.gradient/main.c:56
-#, fuzzy
 msgid "Name for output 3D raster map(s)"
-msgstr "Tên của bản đồ raster đầu ra"
+msgstr ""
 #: ../raster3d/r3.gradient/main.c:63
-#, fuzzy
 msgid "Size of blocks"
-msgstr "Kích thước của bộ nhớ đệm kiểu điểm (point cache)"
+msgstr ""
 #: ../raster3d/r3.gradient/main.c:130
-#, fuzzy
 msgid "Failed to allocate memory for blocks"
-msgstr "Không thể cấp phát bộ nhớ"
+msgstr ""
 #: ../raster3d/r3.gradient/main.c:292
-#, fuzzy
 msgid "Writing gradient 3D raster maps..."
-msgstr "Đang ghi bản đồ raster mới..."
+msgstr ""
 #: ../raster3d/r3.in.v5d/main.c:66
-#, fuzzy
 msgid "Name of V5D raster file to be imported"
+msgstr ""
 #: ../raster3d/r3.in.v5d/main.c:182
-#, fuzzy
 msgid "Import 3-dimensional Vis5D files."
+msgstr ""
 #: ../raster3d/r3.mkdspf/main.c:80 ../visualization/ximgview/main.c:290
 #: ../locale/scriptstrings/d.frame_to_translate.c:2
@@ -2151,136 +1955,115 @@
 #: ../general/g.cairocomp/main.c:197 ../general/g.pnmcomp/main.c:283
 #: ../general/g.ppmtopng/main.c:118
 msgid "display"
-msgstr "trình bày"
+msgstr ""
 #: ../raster3d/r3.mkdspf/main.c:83
-#, fuzzy
-msgid ""
-"Creates a display file from an existing 3D raster map according to specified "
-"threshold levels."
+msgid "Creates a display file from an existing 3D raster map according to specified threshold levels."
 msgstr ""
-"Tạo một tập tin trình bày từ một tập tin grid3 hiện có theo các mức ngưỡng "
-"được chỉ định."
 #: ../raster3d/r3.mkdspf/main.c:91
-#, fuzzy
 msgid "Name of an existing 3D raster map"
-msgstr "Tên bản đồ raster 3d hiện có"
+msgstr ""
 #: ../raster3d/r3.mkdspf/main.c:96
-#, fuzzy
 msgid "Name for output display file"
-msgstr "Tên tập tin trình bày đầu ra"
+msgstr ""
 #: ../raster3d/r3.mkdspf/main.c:103
 msgid "List of thresholds for isosurfaces"
-msgstr "Danh sách ngưỡng dùng cho các mặt cùng giá trị"
+msgstr ""
 #: ../raster3d/r3.mkdspf/main.c:109
 msgid "Minimum isosurface level"
-msgstr "Cấp mặt cùng giá trị nhỏ nhất"
+msgstr ""
 #: ../raster3d/r3.mkdspf/main.c:115
 msgid "Maximum isosurface level"
-msgstr "Cấp mặt cùng giá trị lớn nhất"
+msgstr ""
 #: ../raster3d/r3.mkdspf/main.c:121
 msgid "Positive increment between isosurface levels"
-msgstr "Giá trị tăng dương giữa các mức mặt cùng giá trị"
+msgstr ""
 #: ../raster3d/r3.mkdspf/main.c:128
 msgid "Number of isosurface threshold levels"
-msgstr "Số cấp ngưỡng của mặt cùng giá trị"
+msgstr ""
 #: ../raster3d/r3.mkdspf/main.c:132
 msgid "Suppress progress report & min/max information"
-msgstr "Chặn báo cáo tiến trình thông tin & nhỏ nhất/lớn nhất"
+msgstr ""
 #: ../raster3d/r3.mkdspf/main.c:136
 msgid "Use flat shading rather than gradient"
-msgstr "Dùng đổ bóng phẳng chứ không dùng gradient"
+msgstr ""
 #: ../raster3d/r3.mkdspf/main.c:144
 #, c-format
 msgid "Region from getWindow: %d %d %d"
-msgstr "Vùng từ getWindow: %d %d %d"
+msgstr ""
 #: ../raster3d/r3.mkdspf/main.c:156
 #, c-format
 msgid "Not able to find grid3 file for [%s]"
-msgstr "Không thể tìm thấy tập tin grid3 cho [%s]"
+msgstr ""
 #: ../raster3d/r3.mkdspf/main.c:200
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open display file <%s>"
+msgstr ""
 #: ../raster3d/r3.mkdspf/main.c:221
 #, c-format
 msgid "Writing %s from %s..."
-msgstr "Đang ghi %s từ %s..."
+msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:90
-#, fuzzy
 msgid "Input 3D raster map for cross section"
-msgstr "Bản đồ raster 3D đầu vào dùng cho mặt cắt."
+msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:97
 msgid "2D elevation map used to create the cross section map"
-msgstr "Bản đồ độ cao 2D được dùng để tạo ra bản đồ mặt cắt"
+msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:104
 msgid "Resulting cross section 2D raster map"
-msgstr "Bản đồ mặt cắt raster 2D tạo thành"
+msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:229 ../raster/r.profile/main.c:54
 #: ../display/d.profile/main.c:192
-#, fuzzy
 msgid "profile"
-msgstr "thất bại"
+msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:233
-#, fuzzy
-msgid ""
-"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
-"map"
+msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map"
 msgstr ""
-"Tạo bản đồ raster mặt cắt 2D từ bản đồ raster thể tích g3d dựa trên bản đồ "
-"độ cao 2D"
 #: ../raster3d/r3.cross.rast/main.c:259
-#, fuzzy
-msgid ""
-"The 2D and 3D region settings are different. Using the 3D raster map "
-"settings to adjust the 2D region."
+msgid "The 2D and 3D region settings are different. Using the 3D raster map settings to adjust the 2D region."
 msgstr ""
-"Các thiết lập vùng 2d và 3d khác nhau. Sẽ dùng các thiết lập g3d để điều "
-"chỉnh vùng 2d"
 #: ../raster3d/r3.cross.rast/main.c:302
 msgid "Output map already exists. Will be overwritten!"
-msgstr "Bản đồ đầu ra đã có. Sẽ bị ghi đè!"
+msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:338
-#, fuzzy
 msgid "Wrong 3D raster datatype! Cannot create raster map"
-msgstr "Kiểu dữ liệu RASTER3D bị sai! Không thể tạo bản đồ raster."
+msgstr ""
 #: ../raster3d/r3.flow/flowline.c:60 ../raster/r.contour/main.c:216
 #: ../vector/v.overlay/line_area.c:410 ../vector/v.overlay/area_area.c:345
 #: ../vector/v.to.points/write.c:52
 #, c-format
 msgid "Unable to insert new record: '%s'"
-msgstr "Không thể chèn bản ghi mới: '%s'"
+msgstr ""
 #: ../raster3d/r3.flow/test_main.c:44
 msgid "unit test"
 msgstr ""
 #: ../raster3d/r3.flow/test_main.c:45
-#, fuzzy
 msgid "Testing flow lines."
-msgstr "Chi phí cho các đường cùng giá trị"
+msgstr ""
 #: ../raster3d/r3.flow/main.c:46 ../ps/ps.map/catval.c:53
 #: ../ps/ps.map/catval.c:115 ../ps/ps.map/catval.c:181
@@ -2310,25 +2093,25 @@
 #: ../vector/v.in.db/main.c:302 ../vector/v.edit/select.c:516
 #: ../vector/v.out.ogr/main.c:635 ../vector/v.mkgrid/main.c:278
 #: ../vector/v.net.components/main.c:180 ../vector/v.in.ogr/main.c:1143
-#: ../vector/v.surf.bspline/main.c:378
-#: ../vector/v.surf.bspline/crosscorr.c:123 ../vector/v.in.dwg/main.c:213
-#: ../vector/v.to.points/main.c:167 ../vector/v.buffer/main.c:417
-#: ../vector/v.random/main.c:238 ../vector/v.kcv/main.c:126
-#: ../vector/v.in.dxf/write_vect.c:211 ../vector/v.what.rast/main.c:144
-#: ../vector/v.sample/main.c:179 ../vector/v.select/copy_tabs.c:77
-#: ../vector/v.patch/main.c:154 ../vector/v.patch/main.c:186
-#: ../vector/v.patch/main.c:307 ../vector/v.patch/main.c:389
-#: ../vector/v.in.ascii/main.c:346 ../vector/v.out.postgis/table.c:34
-#: ../vector/v.to.rast/vect2rast.c:60 ../vector/v.to.rast/support.c:109
-#: ../vector/v.to.rast/support.c:284 ../vector/v.to.rast/support.c:523
-#: ../vector/v.colors.out/make_colors.c:36 ../vector/v.to.db/query.c:89
-#: ../vector/v.to.db/update.c:46 ../vector/v.out.vtk/writeVTK.c:649
-#: ../vector/v.db.select/main.c:177 ../vector/v.to.3d/trans2.c:55
-#: ../vector/v.to.3d/trans3.c:57 ../vector/v.extrude/main.c:229
-#: ../vector/v.vol.rst/user1.c:99 ../vector/v.vol.rst/main.c:600
+#: ../vector/v.surf.bspline/main.c:378 ../vector/v.surf.bspline/crosscorr.c:123
+#: ../vector/v.in.dwg/main.c:213 ../vector/v.to.points/main.c:167
+#: ../vector/v.buffer/main.c:417 ../vector/v.random/main.c:238
+#: ../vector/v.kcv/main.c:126 ../vector/v.in.dxf/write_vect.c:211
+#: ../vector/v.what.rast/main.c:144 ../vector/v.sample/main.c:179
+#: ../vector/v.select/copy_tabs.c:77 ../vector/v.patch/main.c:154
+#: ../vector/v.patch/main.c:186 ../vector/v.patch/main.c:307
+#: ../vector/v.patch/main.c:389 ../vector/v.in.ascii/main.c:346
+#: ../vector/v.out.postgis/table.c:34 ../vector/v.to.rast/vect2rast.c:60
+#: ../vector/v.to.rast/support.c:109 ../vector/v.to.rast/support.c:284
+#: ../vector/v.to.rast/support.c:523 ../vector/v.colors.out/make_colors.c:36
+#: ../vector/v.to.db/query.c:89 ../vector/v.to.db/update.c:46
+#: ../vector/v.out.vtk/writeVTK.c:649 ../vector/v.db.select/main.c:177
+#: ../vector/v.to.3d/trans2.c:55 ../vector/v.to.3d/trans3.c:57
+#: ../vector/v.extrude/main.c:229 ../vector/v.vol.rst/user1.c:99
+#: ../vector/v.vol.rst/main.c:600
 #, c-format
 msgid "Unable to open database <%s> by driver <%s>"
-msgstr "Không thể mở CSDL <%s> bằng trình điều khiển <%s>"
+msgstr ""
 #: ../raster3d/r3.flow/main.c:64 ../raster/r.to.vect/main.c:229
 #: ../raster/r.volume/main.c:260 ../vector/v.lrs/v.lrs.create/main.c:338
@@ -2337,7 +2120,7 @@
 #: ../vector/v.in.ascii/main.c:413
 #, c-format
 msgid "Unable to create table: %s"
-msgstr "Không thể tạo bảng: %s"
+msgstr ""
 #: ../raster3d/r3.flow/main.c:67 ../raster/r.contour/main.c:188
 #: ../vector/v.reclass/main.c:322 ../vector/v.in.lidar/attributes.c:139
@@ -2346,7 +2129,7 @@
 #: ../vector/v.in.ascii/main.c:521
 #, c-format
 msgid "Unable to create index for table <%s>, key <%s>"
-msgstr "Không thể tạo chỉ mục cho bảng <%s>, khoá <%s>"
+msgstr ""
 #: ../raster3d/r3.flow/main.c:72 ../raster/r.stream.extract/close.c:196
 #: ../raster/r.to.vect/main.c:238 ../raster/r.random/random.c:257
@@ -2361,61 +2144,51 @@
 #: ../vector/v.in.ascii/main.c:421
 #, c-format
 msgid "Unable to grant privileges on table <%s>"
-msgstr "Không thể cấp các quyền ưu tiên cho bảng <%s>"
+msgstr ""
 #: ../raster3d/r3.flow/main.c:91
-#, fuzzy
 msgid "Please provide three 3D raster maps"
-msgstr "Vui lòng cung cấp ba bản đồ g3d RGB"
+msgstr ""
 #: ../raster3d/r3.flow/main.c:98
-#, fuzzy, c-format
+#, c-format
 msgid "Vector seed map <%s> not found"
-msgstr "Không tìm thấy bản đồ vector <%s>"
+msgstr ""
 #: ../raster3d/r3.flow/main.c:147
 msgid "init_flowaccum: error in Rast3d_put_float"
 msgstr ""
 #: ../raster3d/r3.flow/main.c:183
-#, fuzzy
 msgid "Computes 3D flow lines and 3D flow accumulation."
-msgstr "Đang tính hướng dòng chảy..."
+msgstr ""
 #: ../raster3d/r3.flow/main.c:193
-msgid ""
-"Names of three 3D raster maps describing x, y, z components of vector field"
+msgid "Names of three 3D raster maps describing x, y, z components of vector field"
 msgstr ""
 #: ../raster3d/r3.flow/main.c:200
-msgid ""
-"If no map is provided, flow lines are generated from each cell of the input "
-"3D raster"
+msgid "If no map is provided, flow lines are generated from each cell of the input 3D raster"
 msgstr ""
 #: ../raster3d/r3.flow/main.c:203
-#, fuzzy
 msgid "Name of vector map with points from which flow lines are generated"
-msgstr "Tên của bản đồ điểm vec-tơ đầu vào để biên tập bảng thuộc tính"
+msgstr ""
 #: ../raster3d/r3.flow/main.c:210
-#, fuzzy
 msgid "Name for vector map of flow lines"
-msgstr "Tên của bản đồ vec-tơ cần chỉnh sửa"
+msgstr ""
 #: ../raster3d/r3.flow/main.c:217
-#, fuzzy
 msgid "Name for output flowaccumulation 3D raster"
-msgstr "Tên của bản đồ raster hướng đầu ra"
+msgstr ""
 #: ../raster3d/r3.flow/main.c:224
-#, fuzzy
 msgid "Name for 3D raster sampled by flowlines"
-msgstr "Tên của các bản đồ raster dùng cho độ bóng"
+msgstr ""
 #: ../raster3d/r3.flow/main.c:226
-msgid ""
-"Values of this 3D raster will be stored as attributes of flowlines segments"
+msgid "Values of this 3D raster will be stored as attributes of flowlines segments"
 msgstr ""
 #: ../raster3d/r3.flow/main.c:240
@@ -2423,67 +2196,57 @@
 msgstr ""
 #: ../raster3d/r3.flow/main.c:241
-#, fuzzy
 msgid "length in map units"
-msgstr "%s trong %s: %s"
+msgstr ""
 msgid "length in cells (voxels)"
 msgstr ""
 #: ../raster3d/r3.flow/main.c:243
-#, fuzzy
 msgid "Unit of integration step"
-msgstr "Số lần chạy lặp"
+msgstr ""
 #: ../raster3d/r3.flow/main.c:244
-#, fuzzy
 msgid "Default unit is cell"
-msgstr "Chiều rộng của suối (theo mét). Mặc định là chiều rộng của ô raster"
+msgstr ""
 #: ../raster3d/r3.flow/main.c:245 ../raster3d/r3.flow/main.c:254
 #: ../raster3d/r3.flow/main.c:262 ../raster3d/r3.flow/main.c:272
-#, fuzzy
 msgid "Integration"
-msgstr "Phương pháp nội suy"
+msgstr ""
 #: ../raster3d/r3.flow/main.c:252
-#, fuzzy
 msgid "Integration step in selected unit"
-msgstr "Không có bản đồ raster nào được chỉ định"
+msgstr ""
 #: ../raster3d/r3.flow/main.c:253
-#, fuzzy
 msgid "Default step is 0.25 cell"
-msgstr "CSDL mặc định không được thiết lập"
+msgstr ""
 #: ../raster3d/r3.flow/main.c:261
-#, fuzzy
 msgid "Maximum number of steps"
-msgstr "Số lần chạy lặp tối đa"
+msgstr ""
 #: ../raster3d/r3.flow/main.c:269
-#, fuzzy
 msgid "Maximum error of integration"
+msgstr ""
 #: ../raster3d/r3.flow/main.c:270
 msgid "Influences step, increase maximum error to allow bigger steps"
 msgstr ""
 #: ../raster3d/r3.flow/main.c:280
-#, fuzzy
 msgid "Number of cells between flow lines in x, y and z direction"
-msgstr "Số lượng ô giữa các đường dòng chảy"
+msgstr ""
 #: ../raster3d/r3.flow/main.c:289
 msgid "Compute flowlines upstream, downstream or in both direction."
 msgstr ""
 #: ../raster3d/r3.flow/main.c:294
-#, fuzzy
 msgid "Create and fill attribute table"
-msgstr "Không thể mô tả bảng <%s >"
+msgstr ""
 #: ../raster3d/r3.flow/main.c:349
 msgid "Please provide 3 integer values for skip option."
@@ -2534,13 +2297,12 @@
 #: ../vector/v.extrude/main.c:196 ../vector/v.vol.rst/main.c:580
 #: ../vector/v.vol.rst/main.c:583 ../vector/v.outlier/main.c:224
 #: ../vector/v.outlier/main.c:229 ../vector/v.outlier/main.c:235
-#: ../vector/v.net.visibility/main.c:77
-#: ../vector/v.lidar.correction/main.c:209
+#: ../vector/v.net.visibility/main.c:77 ../vector/v.lidar.correction/main.c:209
 #: ../vector/v.lidar.correction/main.c:215
 #: ../vector/v.net.connectivity/main.c:136
 #, c-format
 msgid "Unable to create vector map <%s>"
-msgstr "Không thể tạo bản đồ vec-tơ <%s>"
+msgstr ""
 #: ../raster3d/r3.flow/main.c:411 ../doc/vector/v.example/main.c:87
 #: ../raster/r.sim/simlib/observation_points.c:41 ../raster/r.what/main.c:236
@@ -2606,229 +2368,187 @@
 #: ../vector/v.net.salesman/main.c:250 ../vector/v.to.3d/main.c:72
 #: ../vector/v.extrude/main.c:190 ../vector/v.vol.rst/main.c:560
 #: ../vector/v.univar/main.c:158 ../vector/v.net.visibility/main.c:73
-#: ../vector/v.net.visibility/main.c:82
-#: ../vector/v.lidar.correction/main.c:186
+#: ../vector/v.net.visibility/main.c:82 ../vector/v.lidar.correction/main.c:186
 #: ../vector/v.net.connectivity/main.c:130
 #, c-format
 msgid "Unable to open vector map <%s>"
-msgstr "Không thể mở bản đồ vector <%s>"
+msgstr ""
 #: ../raster3d/r3.flow/main.c:414 ../vector/v.colors/main.c:266
 #: ../vector/v.to.rast/vect2rast.c:48
 #, c-format
 msgid "Vector map <%s> is not 3D"
-msgstr "Bản đồ vec-tơ <%s> không phải kiểu 3D"
+msgstr ""
 #: ../raster3d/r3.flow/main.c:441
-#, fuzzy
 msgid "Error during reading seed vector map"
+msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:30
-#, fuzzy
 msgid "3D raster map(s) to be converted to VTK-ASCII data format"
-msgstr "Bản đồ RASTER3D cần được đổi thành định dạng dữ liệu VTK-ASCII"
+msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:34 ../raster/r.out.vtk/parameters.c:36
 msgid "Name for VTK-ASCII output file"
-msgstr "Tên của tập tin VTK-ASCII đầu ra"
+msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:41
 msgid "Float value to represent no data cell/points"
-msgstr "Giá trị float để biểu diễn các điểm/ô không có dữ liệu"
+msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:47
 msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
-msgstr "Tạo dữ liệu điểm VTK thay vì dữ liệu ô VTK (mặc định là dữ liệu ô)"
+msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:56
-#, fuzzy
 msgid "Top surface 2D raster map"
-msgstr "Bản đồ raster 2D bề mặt trên cùng"
+msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:65
-#, fuzzy
 msgid "Bottom surface 2D raster map"
-msgstr "Bản đồ raster 2D mặt dưới cùng"
+msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:71
-#, fuzzy
-msgid ""
-"Create 3D elevation output with a top and a bottom surface, both raster maps "
-"are required."
+msgid "Create 3D elevation output with a top and a bottom surface, both raster maps are required."
 msgstr ""
-"Tạo một đầu ra độ cao 3d với một mặt trên cùng và mặt dưới cùng, cả hai bản "
-"đồ raster này đều cần phải có."
 #: ../raster3d/r3.out.vtk/parameters.c:80
-#, fuzzy
-msgid ""
-"Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
+msgid "Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
 msgstr ""
-"Ba (r,g,b) bản đồ raster g3d dùng để tạo các giá trị rgb [redmap,greenmap,"
-"bluemap]"
 #: ../raster3d/r3.out.vtk/parameters.c:88
-#, fuzzy
 msgid "Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]"
 msgstr ""
-"Ba (x,y,z) bản đồ raster g3d dùng để tạo các giá trị vector [xmap,ymap,zmap]"
 #: ../raster3d/r3.out.vtk/parameters.c:94 ../raster/r.out.vtk/parameters.c:85
 #: ../vector/v.out.vtk/main.c:76
 msgid "Scale factor for elevation"
-msgstr "Hệ số tỷ lệ cho độ cao"
+msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:107 ../raster/r.out.vtk/parameters.c:98
 #: ../raster/r.out.ascii/main.c:79 ../display/d.rast.num/main.c:104
 #: ../vector/v.out.ascii/args.c:75 ../vector/v.out.vtk/main.c:70
 msgid "Number of significant digits (floating point only)"
-msgstr "Số chữ số có ý nghĩa (chỉ áp dụng cho dấu chấm động)"
+msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:112
-#, fuzzy
 msgid "Use 3D raster mask (if exists) with input maps"
-msgstr "Dùng mặt nạ G3D (nếu có) với bản đồ đầu vào"
+msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:117
-#, fuzzy
 msgid "Scale factor affects the origin"
-msgstr "Hệ số tỷ lệ tác động đến gốc"
+msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:123
-#: ../raster/r.out.vtk/parameters.c:128
-#, fuzzy
+#: ../raster3d/r3.out.vtk/parameters.c:123 ../raster/r.out.vtk/parameters.c:128
 msgid "Correct the coordinates to match the VTK-OpenGL precision"
-msgstr "Hiệu chỉnh tọa độ cho khớp với độ chính xác VTK-OpenGL"
+msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:129
-msgid ""
-"Do not convert the top-bottom resolution in case of lat long projection to "
-"meters"
+msgid "Do not convert the top-bottom resolution in case of lat long projection to meters"
 msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:117
-#, fuzzy
 msgid "Specify top and bottom map"
-msgstr "Bạn phải chỉ định bản đồ trên cùng và dưới cùng"
+msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:124
 #, c-format
 msgid "Top cell map <%s> not found"
-msgstr "Không tìm thấy bản đồ ô trên cùng <%s>"
+msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:133
 #, c-format
 msgid "Bottom cell map <%s> not found"
-msgstr "Không tìm thấy bản đồ ô dưới cùng <%s>"
+msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:152
-#, fuzzy, c-format
+#, c-format
 msgid "3D raster map RGB map <%s> not found"
-msgstr "Không tìm thấy bản đồ raster 3D <%s>"
+msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:155
-#, fuzzy
 msgid "Please provide three RGB 3D raster maps"
+msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:165
-#, fuzzy, c-format
+#, c-format
 msgid "3D vector map <%s> not found"
+msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:168
-#, fuzzy
 msgid "Please provide three 3D raster maps for the xyz-vector maps [x,y,z]"
-msgstr "Vui lòng cung cấp ba bản đồ vector g3d [x,y,z]"
+msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:175
-#, fuzzy
-msgid ""
-"No 3D raster data, RGB or xyz-vector maps are provided! Will only write the "
-"geometry."
+msgid "No 3D raster data, RGB or xyz-vector maps are provided! Will only write the geometry."
 msgstr ""
-"Không có dữ liệu g3d, RGB hay vector-x,y,z được cung cấp! Sẽ chỉ ghi lại "
-"hình học."
 #: ../raster3d/r3.out.vtk/main.c:209
 msgid "No RGB Data will be created."
-msgstr "Dữ liệu RGB sẽ không được tạo ra."
+msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:294
 msgid "No vector data will be created."
-msgstr "Dữ liệu vector sẽ không được tạo thành."
+msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:381
-#, fuzzy
 msgid "Converts 3D raster maps into the VTK-ASCII format."
-msgstr "Đổi các bản đồ raster thành định dạng ASCII VTK"
+msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:392
 msgid "failed to interpret dp as an integer"
-msgstr "thất bại trong việc diễn giải dp ở dạng số nguyên"
+msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:394 ../raster/r.out.ascii/main.c:116
 msgid "dp has to be from 0 to 20"
-msgstr "dp phải trong khoảng 0 đến 20"
+msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:542
-#, fuzzy
 msgid "Unable to close 3D raster map, the VTK file may be incomplete"
-msgstr "Lỗi đóng bản đồ raster g3d, tập tin VTK có thể không hoàn chỉnh."
+msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:557
-#, fuzzy
 msgid "Unable to close VTK-ASCII file"
+msgstr ""
 #: ../raster3d/r3.out.vtk/writeVTKData.c:122
 msgid "write_vtk_points: Writing point coordinates"
-msgstr "write_vtk_points: Đang ghi tọa độ điểm"
+msgstr ""
 #: ../raster3d/r3.out.vtk/writeVTKData.c:256
 msgid "write_vtk_unstructured_grid_cells: Writing the cells"
-msgstr "write_vtk_unstructured_grid_cells: Đang ghi các ô"
+msgstr ""
 #: ../raster3d/r3.out.vtk/writeVTKData.c:335
 #, c-format
-msgid ""
-"write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
-"ascii file"
+msgid "write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-ascii file"
 msgstr ""
-"write_vtk_data: Đang ghi Celldata %s với hàng %i cột %i chiều sâu %i vào tập "
-"tin vtk-ascii"
 #: ../raster3d/r3.out.vtk/writeVTKData.c:441
-#, fuzzy
 msgid "Wrong 3D raster map values! Values should in between 0 and 255!"
-msgstr "Các giá trị bản đồ 3d sai! Phải ở trong khoảng 0 đến 255!\n"
+msgstr ""
 #: ../raster3d/r3.out.vtk/errorHandling.c:105
-#, fuzzy
 msgid "Unable to close input raster maps"
-msgstr "không thể đóng bản đồ raster đầu vào"
+msgstr ""
 #: ../raster3d/r3.neighbors/main.c:94 ../raster/r.resamp.stats/main.c:298
 #: ../raster/r.series/main.c:104 ../raster/r.neighbors/main.c:102
 #, c-format
 msgid "Unknown method <%s>"
-msgstr "Phương pháp không biết <%s>"
+msgstr ""
 #: ../raster3d/r3.neighbors/main.c:119 ../raster/r.series/main.c:161
 msgid "Aggregate operation"
-msgstr "Phép toán tổ hợp"
+msgstr ""
 #: ../raster3d/r3.neighbors/main.c:127 ../raster/r.resamp.stats/main.c:279
 #: ../raster/r.series/main.c:168 ../raster/r.neighbors/main.c:239
-#, fuzzy
 msgid "Quantile to calculate for method=quantile"
-msgstr "Không thể tính toán trọng tâm vùng"
+msgstr ""
 #: ../raster3d/r3.neighbors/main.c:137
-msgid ""
-"The size of the window in x, y and z direction, values must be odd integer "
-"numbers, eg: 3,3,3"
+msgid "The size of the window in x, y and z direction, values must be odd integer numbers, eg: 3,3,3"
 msgstr ""
 #: ../raster3d/r3.neighbors/main.c:209 ../raster/r.mfilter/main.c:57
@@ -2841,54 +2561,43 @@
 #: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:3
 #: ../locale/scriptstrings/t.vect.algebra_to_translate.c:3
 #: ../vector/v.neighbors/main.c:51
-#, fuzzy
 msgid "algebra"
-msgstr "raster, đại số bản đồ"
+msgstr ""
 #: ../raster3d/r3.neighbors/main.c:213 ../raster/r.neighbors/main.c:171
-#, fuzzy
 msgid "neighbor"
-msgstr "Vùng lân cận"
+msgstr ""
 #: ../raster3d/r3.neighbors/main.c:214 ../raster/r.neighbors/main.c:172
-#, fuzzy
 msgid "focal statistics"
-msgstr "Thống kê"
+msgstr ""
 #: ../raster3d/r3.neighbors/main.c:215 ../raster/r.mfilter/main.c:59
 #: ../raster/r.resamp.filter/main.c:392 ../raster/r.neighbors/main.c:173
 #: ../vector/v.outlier/main.c:73
-#, fuzzy
 msgid "filter"
-msgstr "địa điểm"
+msgstr ""
 #: ../raster3d/r3.neighbors/main.c:218
-#, fuzzy
-msgid ""
-"Makes each voxel value a function of the values assigned to the voxels "
-"around it, and stores new voxel values in an output 3D raster map"
+msgid "Makes each voxel value a function of the values assigned to the voxels around it, and stores new voxel values in an output 3D raster map"
 msgstr ""
-"Làm cho mỗi giá trị phạm trù ô trở thành một hàm số của các giá trị phạm trù "
-"được gán vào các ô xung quanh nó, là lưu trữ các giá trị ô mới trong một lớp "
-"bản đồ raster đầu ra."
 #: ../raster3d/r3.neighbors/main.c:287
-#, fuzzy
 msgid "Unable to allocate buffer"
-msgstr "Không thể cấp phát các vùng đệm cell."
+msgstr ""
 #: ../imagery/i.gensigset/parse.c:13 ../imagery/i.gensig/parse.c:14
 msgid "Ground truth training map"
-msgstr "Bản đồ hướng dẫn kiểm chứng ngoài thực tế"
+msgstr ""
 #: ../imagery/i.gensigset/parse.c:25 ../imagery/i.gensig/parse.c:26
 #: ../imagery/i.cluster/main.c:95
 msgid "Name for output file containing result signatures"
-msgstr "Tên tập tin đầu ra chứa chữ ký kết quả"
+msgstr ""
 #: ../imagery/i.gensigset/parse.c:29
 msgid "Maximum number of sub-signatures in any class"
-msgstr "Số chữ ký phụ lớn nhất trong bất kỳ lớp nào"
+msgstr ""
 #: ../imagery/i.gensigset/parse.c:44 ../imagery/i.pca/main.c:139
 #: ../imagery/i.gensig/parse.c:38
@@ -2928,21 +2637,21 @@
 #: ../vector/v.colors/main.c:312 ../vector/v.vol.rst/main.c:615
 #, c-format
 msgid "Raster map <%s> not found"
-msgstr "Không tìm thấy bản đồ raster <%s>"
+msgstr ""
 #: ../imagery/i.gensigset/parse.c:47 ../imagery/i.smap/parse.c:61
 #: ../imagery/i.gensig/parse.c:41 ../imagery/i.maxlik/open.c:17
 #: ../imagery/i.cluster/main.c:169
-#, fuzzy, c-format
+#, c-format
 msgid "Group <%s> not found in current mapset"
-msgstr "Không tìm thấy bản đồ raster <%s> trong bộ bản đồ hiện tại"
+msgstr ""
 #: ../imagery/i.gensigset/parse.c:50 ../imagery/i.smap/parse.c:64
 #: ../imagery/i.gensig/parse.c:44 ../imagery/i.maxlik/open.c:20
 #: ../imagery/i.cluster/main.c:172
 #, c-format
 msgid "Subgroup <%s> in group <%s> not found"
-msgstr "Không tìm thấy nhóm phụ <%s> thuộc nhóm <%s>"
+msgstr ""
 #: ../imagery/i.gensigset/parse.c:57 ../imagery/i.gensig/parse.c:50
 #: ../imagery/i.cluster/main.c:179 ../raster/r.proj/main.c:245
@@ -2955,57 +2664,55 @@
 #: ../imagery/i.gensigset/parse.c:63
 #, c-format
 msgid "Illegal number of sub-signatures (%s)"
-msgstr "Số lượng chữ ký phụ không hợp lệ (%s)"
+msgstr ""
 #: ../imagery/i.gensigset/subcluster.c:76
 #, c-format
 msgid "Not enough pixels in class %d"
-msgstr "Không đủ số điểm ảnh trong lớp %d"
+msgstr ""
 #: ../imagery/i.gensigset/subcluster.c:86
 #, c-format
 msgid "Too many subclasses for class index %d"
-msgstr "Quá nhiều lớp phụ trong chỉ mục lớp %d"
+msgstr ""
 #: ../imagery/i.gensigset/subcluster.c:88
 #, c-format
 msgid "Number of subclasses set to %d"
-msgstr "Số lượng lớp phụ được thiết lập thành %d"
+msgstr ""
 #: ../imagery/i.gensigset/subcluster.c:106
 #, c-format
 msgid "Combining subclasses (%d,%d)..."
-msgstr "Đang tổ hợp các lớp phụ (%d,%d)..."
+msgstr ""
 #: ../imagery/i.gensigset/subcluster.c:318
-#, fuzzy, c-format
+#, c-format
 msgid "Subsignature %d only contains %.0f pixels"
-msgstr "Chữ ký phụ %d chỉ có %f điểm ảnh"
+msgstr ""
 #: ../imagery/i.gensigset/subcluster.c:552
 msgid "Unreliable clustering. Try a smaller initial number of clusters"
 msgstr ""
-"Việc gộp nhóm không đáng tin cậy. Hãy thử với số lượng nhóm gộp khởi tạo ít "
-"hơn"
 #: ../imagery/i.gensigset/subcluster.c:561
 #, c-format
 msgid "Removed a singular subsignature number %d (%d remain)"
-msgstr "Loại bỏ một chữ ký phụ đơn số lượng %d (còn lại %d)"
+msgstr ""
 #: ../imagery/i.gensigset/read_data.c:22 ../imagery/i.ifft/main.c:141
 #: ../imagery/i.cluster/main.c:293
 msgid "Reading raster maps..."
-msgstr "Đang đọc các bản raster... "
+msgstr ""
 #: ../imagery/i.gensigset/write_sig.c:13 ../imagery/i.gensig/write_sig.c:15
 #, c-format
 msgid "Unable to create signature file <%s>"
-msgstr "Không thể tạo tập tin chữ ký <%s>"
+msgstr ""
 #: ../imagery/i.gensigset/write_sig.c:16 ../imagery/i.gensig/write_sig.c:18
 msgid "Writing signatures..."
-msgstr "Đang ghi chữ ký..."
+msgstr ""
 #: ../imagery/i.gensigset/main.c:40 ../imagery/i.evapo.pt/main.c:66
 #: ../imagery/i.cca/main.c:84 ../imagery/i.evapo.mh/main.c:69
@@ -3039,21 +2746,19 @@
 #: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
 #: ../locale/scriptstrings/i.oif_to_translate.c:2
 msgid "imagery"
-msgstr "ảnh"
+msgstr ""
 #: ../imagery/i.gensigset/main.c:41 ../imagery/i.smap/main.c:39
 #: ../imagery/i.gensig/main.c:40 ../imagery/i.segment/main.c:38
 #: ../imagery/i.maxlik/main.c:62 ../imagery/i.cluster/main.c:76
 #: ../raster/r.kappa/main.c:70 ../vector/v.class/main.c:46
-#, fuzzy
 msgid "classification"
-msgstr "Phép phân loại điểm"
+msgstr ""
 #: ../imagery/i.gensigset/main.c:42 ../imagery/i.smap/main.c:40
 #: ../imagery/i.gensig/main.c:41
-#, fuzzy
 msgid "supervised classification"
+msgstr ""
 #: ../imagery/i.gensigset/main.c:43 ../imagery/i.smap/main.c:42
 msgid "SMAP"
@@ -3061,98 +2766,88 @@
 #: ../imagery/i.gensigset/main.c:44 ../imagery/i.gensig/main.c:44
 #: ../imagery/i.cluster/main.c:77
-#, fuzzy
 msgid "signatures"
-msgstr "địa điểm"
+msgstr ""
 #: ../imagery/i.gensigset/main.c:46
 msgid "Generates statistics for i.smap from raster map."
-msgstr "Tạo thống kê cho i.smap từ bản đồ raster."
+msgstr ""
 #: ../imagery/i.gensigset/main.c:56
 #, c-format
 msgid "Clustering class %d (%d pixels)..."
-msgstr "Đang gộp nhóm lớp %d (%d điểm ảnh)..."
+msgstr ""
 #: ../imagery/i.gensigset/main.c:59
 #, c-format
 msgid "Number of subclasses is %d"
-msgstr "Số lượng lớp phụ là %d"
+msgstr ""
 #: ../imagery/i.gensigset/openfiles.c:18 ../imagery/i.smap/openfiles.c:18
 #: ../imagery/i.smap/read_sig.c:13 ../imagery/i.gensig/openfiles.c:19
 #, c-format
 msgid "Unable to read REF file for subgroup <%s> in group <%s>"
-msgstr "Không thể đọc tập tin REF của nhóm phụ <%s> trong nhóm <%s>"
+msgstr ""
 #: ../imagery/i.gensigset/openfiles.c:22 ../imagery/i.gensig/openfiles.c:23
 #, c-format
 msgid "Subgroup <%s> in group <%s> contains no raster maps."
-msgstr "Nhóm phụ <%s> trong nhóm <%s> không có bản đồ raster nào."
+msgstr ""
 #: ../imagery/i.gensigset/get_train.c:35 ../imagery/i.gensig/get_train.c:32
 msgid "Finding training classes..."
-msgstr "Đang tìm các lớp tập huấn..."
+msgstr ""
 #: ../imagery/i.gensigset/get_train.c:58 ../imagery/i.gensig/get_train.c:55
 #, c-format
 msgid "Training class %d only has one cell - this class will be ignored"
-msgstr "Lớp tập huấn %d chỉ có một ô - lớp này sẽ bị bỏ qua."
+msgstr ""
 #: ../imagery/i.gensigset/get_train.c:63 ../imagery/i.gensig/get_train.c:60
 msgid "Training map has no classes"
-msgstr "Bản đồ hướng dẫn không có nhóm nào"
+msgstr ""
 #: ../imagery/i.gensigset/get_train.c:79 ../imagery/i.gensig/get_train.c:75
 msgid "1 class found"
-msgstr "tìm thấy 1 lớp"
+msgstr ""
 #: ../imagery/i.gensigset/get_train.c:81 ../imagery/i.gensig/get_train.c:77
 #, c-format
 msgid "%d classes found"
-msgstr "tìm thấy %d lớp"
+msgstr ""
 #: ../imagery/i.evapo.pt/main.c:67 ../imagery/i.evapo.mh/main.c:70
 #: ../imagery/i.evapo.time/main.c:78 ../imagery/i.evapo.pm/main.c:59
-#, fuzzy
 msgid "evapotranspiration"
+msgstr ""
 #: ../imagery/i.evapo.pt/main.c:69
-msgid ""
-"Computes evapotranspiration calculation Priestley and Taylor formulation, "
-"1972."
+msgid "Computes evapotranspiration calculation Priestley and Taylor formulation, 1972."
 msgstr ""
 #: ../imagery/i.evapo.pt/main.c:75
-#, fuzzy
 msgid "Name of input net radiation raster map [W/m2]"
-msgstr "Tên của bản đồ raster độ cao [m]"
+msgstr ""
 #: ../imagery/i.evapo.pt/main.c:79
-#, fuzzy
 msgid "Name of input soil heat flux raster map [W/m2]"
-msgstr "Tên của bản đồ raster độ sâu nước [m]"
+msgstr ""
 #: ../imagery/i.evapo.pt/main.c:83
-#, fuzzy
 msgid "Name of input air temperature raster map [K]"
-msgstr "Tên của bản đồ raster"
+msgstr ""
 #: ../imagery/i.evapo.pt/main.c:87
-#, fuzzy
 msgid "Name of input atmospheric pressure raster map [millibars]"
-msgstr "Tên của bản đồ raster độ nét đứt gãy nghiêm trọng [Pa]"
+msgstr ""
 #: ../imagery/i.evapo.pt/main.c:93
-#, fuzzy
 msgid "Priestley-Taylor coefficient"
-msgstr "Bản đồ dùng làm hệ số x"
+msgstr ""
 #: ../imagery/i.evapo.pt/main.c:97
-#, fuzzy
 msgid "Name of output evapotranspiration raster map [mm/d]"
-msgstr "Tên tập tin địa điểm đi chuyển (walker site) đầu ra"
+msgstr ""
 #: ../imagery/i.evapo.pt/main.c:102 ../imagery/i.evapo.mh/main.c:105
 msgid "Set negative ETa to zero"
@@ -3160,98 +2855,88 @@
 #: ../imagery/i.cca/transform.c:24
 msgid "Unable to allocate cell buffers."
+msgstr ""
 #: ../imagery/i.cca/transform.c:58
 msgid "Transform completed.\n"
-msgstr "Việc chuyển đổi hoàn tất.\n"
+msgstr ""
 #: ../imagery/i.cca/main.c:87
 msgid "canonical components analysis"
 msgstr ""
 #: ../imagery/i.cca/main.c:89
-#, fuzzy
 msgid "Canonical components analysis (CCA) program for image processing."
-msgstr "Chương trình phân tích thành phần chính tắc (cca) dùng trong xử lý ảnh"
+msgstr ""
 #: ../imagery/i.cca/main.c:96
 msgid "Name of input imagery subgroup"
-msgstr "Tên của nhóm ảnh phụ đầu vào"
+msgstr ""
 #: ../imagery/i.cca/main.c:103
-#, fuzzy
 msgid "File containing spectral signatures"
-msgstr "Tập tin ascii chứa các chữ ký phổ"
+msgstr ""
 #: ../imagery/i.cca/main.c:106
 msgid "Output raster map prefix name"
-msgstr "Tên tiền tố của bản đồ raster đầu ra"
+msgstr ""
 #: ../imagery/i.cca/main.c:114
 msgid "Unknown imagery group."
-msgstr "Nhóm ảnh không biết."
+msgstr ""
 #: ../imagery/i.cca/main.c:117
 msgid "Unable to find subgroup reference information."
-msgstr "Không thể tìm thấy thông tin tham chiếu của nhóm phụ."
+msgstr ""
 #: ../imagery/i.cca/main.c:123
 msgid "Unable to open the signature file"
-msgstr "Không thể mở tập tin chữ ký"
+msgstr ""
 #: ../imagery/i.cca/main.c:127
 msgid "Error while reading the signatures file."
-msgstr "Lỗi khi đang đọc tập tin chữ ký."
+msgstr ""
 #: ../imagery/i.cca/main.c:132
 msgid "Need at least two signatures in signature file."
-msgstr "Cần ít nhất hai chữ ký trong tập tin chữ ký."
+msgstr ""
 #: ../imagery/i.cca/main.c:226
 #, c-format
 msgid "The output cell map <%s.%d> has values outside the 0-255 range."
-msgstr "Bản đồ cell đầu ra <%s.%d> có giá trị nằm ngoài miền 0-255."
+msgstr ""
 #: ../imagery/i.evapo.mh/main.c:72
-msgid ""
-"Computes evapotranspiration calculation modified or original Hargreaves "
-"formulation, 2001."
+msgid "Computes evapotranspiration calculation modified or original Hargreaves formulation, 2001."
 msgstr ""
 #: ../imagery/i.evapo.mh/main.c:78
-#, fuzzy
 msgid "Name of input diurnal net radiation raster map [W/m2/d]"
-msgstr "Tên của bản đồ raster độ cao đầu vào [mét]"
+msgstr ""
 #: ../imagery/i.evapo.mh/main.c:82
-#, fuzzy
 msgid "Name of input average air temperature raster map [C]"
+msgstr ""
 #: ../imagery/i.evapo.mh/main.c:86
-#, fuzzy
 msgid "Name of input minimum air temperature raster map [C]"
+msgstr ""
 #: ../imagery/i.evapo.mh/main.c:90
-#, fuzzy
 msgid "Name of input maximum air temperature raster map [C]"
+msgstr ""
 #: ../imagery/i.evapo.mh/main.c:96
-#, fuzzy
 msgid "Name of precipitation raster map [mm/month]"
+msgstr ""
 #: ../imagery/i.evapo.mh/main.c:97
 msgid "Disabled for original Hargreaves (1985)"
 msgstr ""
 #: ../imagery/i.evapo.mh/main.c:100
-#, fuzzy
 msgid "Name for output raster map [mm/d]"
+msgstr ""
 #: ../imagery/i.evapo.mh/main.c:109
 msgid "Use original Hargreaves (1985)"
@@ -3267,62 +2952,62 @@
 #: ../imagery/i.zc/main.c:55
 msgid "Zero-crossing \"edge detection\" raster function for image processing."
-msgstr "Chức năng phát \"hiện gờ\" cắt 0 raster dùng cho xử lý ảnh."
+msgstr ""
 #: ../imagery/i.zc/main.c:65 ../raster/r.random/main.c:60
 #: ../raster/r.out.bin/main.c:290
 msgid "Name of input raster map"
-msgstr "Tên bản đồ raster đầu vào"
+msgstr ""
 #: ../imagery/i.zc/main.c:73
 msgid "Zero crossing raster map"
-msgstr "Bản đồ raster cắt 0"
+msgstr ""
 #: ../imagery/i.zc/main.c:80
 msgid "x-y extent of the Gaussian filter"
-msgstr "Phạm vi x-y của bộ lọc Gauss"
+msgstr ""
 #: ../imagery/i.zc/main.c:88
 msgid "Sensitivity of Gaussian filter"
-msgstr "Độ nhạy của bộ lọc Gauss"
+msgstr ""
 #: ../imagery/i.zc/main.c:96
 msgid "Number of azimuth directions categorized"
-msgstr "Số hướng phương vị được phân loại"
+msgstr ""
 #: ../imagery/i.zc/main.c:108
 msgid "Threshold less than or equal to zero not allowed"
-msgstr "Ngưỡng nhỏ hơn hoặc bằng 0 không được chấp nhận"
+msgstr ""
 #: ../imagery/i.zc/main.c:114
 msgid "Width less than or equal to zero not allowed"
-msgstr "Chiều rộng nhỏ hơn hoặc bằng 0 không được chấp nhận"
+msgstr ""
 #: ../imagery/i.zc/main.c:118
 msgid "Fewer than 1 orientation classes not allowed"
-msgstr "Ít hơn 1 nhóm hướng không được chấp nhận"
+msgstr ""
 #: ../imagery/i.zc/main.c:132
 #, c-format
 msgid "Power 2 values : %d rows %d columns"
-msgstr "Các giá trị bậc 2 :  %d hàng %d cột"
+msgstr ""
 #: ../imagery/i.zc/main.c:142
 msgid "Initializing data..."
-msgstr "Đang khởi tạo dữ liệu..."
+msgstr ""
 #: ../imagery/i.zc/main.c:152 ../raster/r.carve/raster.c:13
 #: ../raster/r.texture/main.c:288
 msgid "Reading raster map..."
-msgstr "Đang đọc tập tin raster... "
+msgstr ""
 #: ../imagery/i.zc/main.c:172
 msgid "Writing transformed data to file..."
-msgstr "Đang ghi dữ liệu đã chuyển đổi vào tập tin..."
+msgstr ""
 #: ../imagery/i.zc/main.c:192
 msgid "Transform successful"
-msgstr "Chuyển đổi thành công"
+msgstr ""
 #: ../imagery/i.fft/main.c:79 ../imagery/i.pca/main.c:73
 #: ../imagery/i.ifft/main.c:78
@@ -3332,48 +3017,45 @@
 #: ../locale/scriptstrings/m.proj_to_translate.c:4
 #: ../misc/m.transform/main.c:317 ../vector/v.transform/main.c:70
 #: ../vector/v.proj/main.c:69
-#, fuzzy
 msgid "transformation"
+msgstr ""
 #: ../imagery/i.fft/main.c:80 ../imagery/i.ifft/main.c:79
-#, fuzzy
 msgid "Fast Fourier Transform"
-msgstr "Phép chuyển đổi Fast Fourier (FFT) trong xử lý ảnh."
+msgstr ""
 #: ../imagery/i.fft/main.c:82
 msgid "Fast Fourier Transform (FFT) for image processing."
+msgstr ""
 #: ../imagery/i.fft/main.c:90
 msgid "Name for output real part arrays stored as raster map"
-msgstr "Tên của các mảng phần-thực đầu ra được lưu ở dạng bản đồ raster"
+msgstr ""
 #: ../imagery/i.fft/main.c:94
 msgid "Name for output imaginary part arrays stored as raster map"
-msgstr "Tên của các mảng phần-ảo đầu ra được lưu ở dạng bản đồ raster"
+msgstr ""
 #: ../imagery/i.fft/main.c:106
 msgid "Raster MASK found, consider to remove (see man-page). Will continue..."
 msgstr ""
-"Tìm thấy MẶT NẠ, xem xét việc loại bỏ (xem trang trợ giúp). Sẽ tiếp tục..."
 #: ../imagery/i.fft/main.c:129
 #, c-format
 msgid "Reading the raster map <%s>..."
-msgstr "Đang đọc bản đồ raster <%s>... "
+msgstr ""
 #: ../imagery/i.fft/main.c:145
 msgid "Starting FFT..."
-msgstr "Đang khởi động FFT..."
+msgstr ""
 #: ../imagery/i.fft/main.c:166 ../imagery/i.ifft/main.c:191
 msgid "Rotating data..."
-msgstr "Đang xoay dữ liệu..."
+msgstr ""
 #: ../imagery/i.fft/main.c:174
 msgid "Writing transformed data..."
-msgstr "Đang ghi dữ liệu đã được chuyển đổi..."
+msgstr ""
 #: ../imagery/i.fft/main.c:200
 msgid " "
@@ -3382,29 +3064,26 @@
 #: ../imagery/i.find/main.c:63
 #, c-format
 msgid "usage: %s location mapset element file."
-msgstr "cách dùng: tập tin thành phần của bộ bản đồ trong location %s"
+msgstr ""
 #: ../imagery/i.find/main.c:83
 msgid "Unable to open temp file."
-msgstr "Không thể mở tập tin tạm"
+msgstr ""
 #: ../imagery/i.aster.toar/main.c:98 ../imagery/i.landsat.toar/main.c:71
-#, fuzzy
 msgid "radiometric conversion"
-msgstr "Lỗi chuyển đổi chữ"
+msgstr ""
 #: ../imagery/i.aster.toar/main.c:99 ../imagery/i.landsat.toar/main.c:72
 #: ../imagery/i.landsat.toar/main.c:578
-#, fuzzy
 msgid "radiance"
+msgstr ""
 #: ../imagery/i.aster.toar/main.c:100 ../imagery/i.landsat.toar/main.c:73
 #: ../imagery/i.landsat.toar/main.c:580 ../imagery/i.modis.qc/main.c:151
 #: ../imagery/i.albedo/main.c:97
-#, fuzzy
 msgid "reflectance"
-msgstr "Phép chọn"
+msgstr ""
 #: ../imagery/i.aster.toar/main.c:101 ../imagery/i.landsat.toar/main.c:74
 msgid "brightness temperature"
@@ -3422,9 +3101,7 @@
 msgstr ""
 #: ../imagery/i.aster.toar/main.c:105
-msgid ""
-"Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
-"from ASTER DN."
+msgid "Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature from ASTER DN."
 msgstr ""
 #: ../imagery/i.aster.toar/main.c:109
@@ -3432,18 +3109,16 @@
 msgstr ""
 #: ../imagery/i.aster.toar/main.c:116
-#, fuzzy
 msgid "Day of Year of satellite overpass [0-366]"
+msgstr ""
 #: ../imagery/i.aster.toar/main.c:123
 msgid "Sun elevation angle (degrees, < 90.0)"
 msgstr ""
 #: ../imagery/i.aster.toar/main.c:126
-#, fuzzy
 msgid "Base name of the output layers (will add .x)"
+msgstr ""
 #: ../imagery/i.aster.toar/main.c:131
 msgid "Output is radiance (W/m2)"
@@ -3470,45 +3145,39 @@
 msgstr ""
 #: ../imagery/i.aster.toar/main.c:231 ../imagery/i.albedo/main.c:167
-#, fuzzy, c-format
+#, c-format
 msgid "Too many input maps. Only %d allowed."
-msgstr "%s - quá nhiều tập tin 'vá'. Chỉ được phép %d tập tin"
+msgstr ""
 #: ../imagery/i.aster.toar/main.c:246
 msgid "The input band number should be 15"
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:69
-msgid ""
-"Calculates top-of-atmosphere radiance or reflectance and temperature for "
-"Landsat MSS/TM/ETM+/OLI"
+msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+/OLI"
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:75
-#, fuzzy
 msgid "atmospheric correction"
-msgstr "Bản đồ raster hướng đầu ra"
+msgstr ""
 #: ../imagery/i.landsat.toar/main.c:77 ../imagery/i.albedo/main.c:99
 #: ../imagery/i.landsat.acca/main.c:109
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:4
-#, fuzzy
 msgid "Landsat"
-msgstr "Lớp số"
+msgstr ""
 #: ../imagery/i.landsat.toar/main.c:82 ../imagery/i.landsat.acca/main.c:112
-#, fuzzy
 msgid "Base name of input raster bands"
+msgstr ""
 #: ../imagery/i.landsat.toar/main.c:83 ../imagery/i.landsat.acca/main.c:113
 msgid "Example: 'B.' for B.1, B.2, ..."
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:86
-#, fuzzy
 msgid "Prefix for output raster maps"
-msgstr "Tiền tố dùng cho (các) bản đồ raster đầu ra"
+msgstr ""
 #: ../imagery/i.landsat.toar/main.c:88
 msgid "Example: 'B.toar.' generates B.toar.1, B.toar.2, ..."
@@ -3526,7 +3195,7 @@
 #: ../raster/r.in.gdal/main.c:158
 #: ../locale/scriptstrings/r.import_to_translate.c:25
 msgid "Metadata"
-msgstr "Mô tả dữ liệu"
+msgstr ""
 #: ../imagery/i.landsat.toar/main.c:99
 msgid "Spacecraft sensor"
@@ -3573,9 +3242,8 @@
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:123 ../imagery/i.landsat.toar/main.c:124
-#, fuzzy
 msgid "Atmospheric correction method"
+msgstr ""
 #: ../imagery/i.landsat.toar/main.c:133
 msgid "Image acquisition date (yyyy-mm-dd)"
@@ -3587,9 +3255,8 @@
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:141
-#, fuzzy
 msgid "Sun elevation in degrees"
-msgstr "Tên tập tin độ cao raster"
+msgstr ""
 #: ../imagery/i.landsat.toar/main.c:150
 msgid "Image creation date (yyyy-mm-dd)"
@@ -3654,7 +3321,7 @@
 #: ../vector/v.outlier/main.c:121 ../vector/v.lidar.correction/main.c:102
 #: ../vector/v.lidar.correction/main.c:111
 msgid "Settings"
-msgstr "Các thiết lập"
+msgstr ""
 #: ../imagery/i.landsat.toar/main.c:166
 msgid "Percent of solar radiance in path radiance"
@@ -3677,42 +3344,36 @@
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:195
-#, fuzzy
 msgid "return value stored for a given metadata"
-msgstr "Liệt kê tất cả các bảng trong một CSDL cho trước."
+msgstr ""
 #: ../imagery/i.landsat.toar/main.c:196
 msgid "Required only if 'metfile' and -p given"
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:202
-#, fuzzy
 msgid "Landsat Number"
-msgstr "Lớp số"
+msgstr ""
 #: ../imagery/i.landsat.toar/main.c:203
-#, fuzzy
 msgid "Creation timestamp"
-msgstr "Tương quan"
+msgstr ""
 #: ../imagery/i.landsat.toar/main.c:204
 msgid "Date"
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:205
-#, fuzzy
 msgid "Sun Elevation"
-msgstr "Phép chọn"
+msgstr ""
 #: ../imagery/i.landsat.toar/main.c:206
-#, fuzzy
 msgid "Sensor"
-msgstr "Kênh đỏ LANDSAT"
+msgstr ""
 #: ../imagery/i.landsat.toar/main.c:207
-#, fuzzy
 msgid "Bands count"
-msgstr "băng %d"
+msgstr ""
 msgid "Sun Azimuth Angle"
@@ -3731,28 +3392,25 @@
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:216
-#, fuzzy
 msgid "Scale factor for output"
+msgstr ""
 #: ../imagery/i.landsat.toar/main.c:222
 msgid "Output at-sensor radiance instead of reflectance for all bands"
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:227
-msgid ""
-"Input raster maps use as extension the number of the band instead the code"
+msgid "Input raster maps use as extension the number of the band instead the code"
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:231
-#, fuzzy
 msgid "Print output metadata info"
-msgstr "Chỉ in ra vùng của bản đồ raster 3D"
+msgstr ""
 #: ../imagery/i.landsat.toar/main.c:257 ../imagery/i.landsat.toar/main.c:265
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal date format: [%s] (yyyy-mm-dd)"
-msgstr "Giá trị cho '%s' không hợp lệ (%s)"
+msgstr ""
 #: ../imagery/i.landsat.toar/main.c:287
 msgid "Please use a metadata keyword with -p"
@@ -3772,9 +3430,9 @@
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:364
-#, fuzzy, c-format
+#, c-format
 msgid "Unknown satellite type (defined by '%s')"
-msgstr "Kiểu mục trong pad không biết: %s"
+msgstr ""
 #: ../imagery/i.landsat.toar/main.c:407 ../imagery/i.landsat.toar/main.c:545
 #: ../imagery/i.landsat.acca/main.c:57
@@ -3783,30 +3441,29 @@
 #: ../raster/r.random/random.c:47 ../raster/r.mapcalc/map3.c:517
 #, c-format
 msgid "Unable to open raster map <%s>"
-msgstr "Không thể mở bản đồ raster <%s>"
+msgstr ""
 #: ../imagery/i.landsat.toar/main.c:411 ../imagery/i.landsat.toar/main.c:560
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read data type of raster map <%s>"
-msgstr "Không thể đọc miền fp của bản đồ raster <%s>"
+msgstr ""
 #: ../imagery/i.landsat.toar/main.c:535 ../raster/r.topidx/topidx.c:41
 #: ../raster/r.flow/main.c:314
-#, fuzzy
 msgid "Calculating..."
-msgstr "Đang tính toán các bản đồ ..."
+msgstr ""
 #: ../imagery/i.landsat.toar/main.c:549 ../raster/r.relief/main.c:194
 #: ../raster/r.in.gdal/main.c:346 ../raster/r.in.gdal/main.c:693
 #: ../vector/v.kernel/main.c:236
 #, c-format
 msgid "Raster map <%s> already exists and will be overwritten"
-msgstr "Bản đồ raster <%s> đã có và sẽ bị ghi đè"
+msgstr ""
 #: ../imagery/i.landsat.toar/main.c:553
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map <%s> exists. Skipping."
-msgstr "Bản đồ raster <%s> đã có trong nhóm. Bỏ qua..."
+msgstr ""
 #: ../imagery/i.landsat.toar/main.c:564 ../imagery/i.landsat.acca/main.c:188
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:114
@@ -3815,7 +3472,7 @@
 #: ../general/g.rename/main.c:85
 #, c-format
 msgid "<%s> is an illegal file name"
-msgstr "<%s> là tên không hợp lệ"
+msgstr ""
 #: ../imagery/i.landsat.toar/main.c:567
 #: ../imagery/i.landsat.acca/algorithm.c:234
@@ -3825,80 +3482,76 @@
 #: ../raster/r.mapcalc/map3.c:606
 #, c-format
 msgid "Unable to create raster map <%s>"
-msgstr "Không thể tạo bản đồ raster <%s>"
+msgstr ""
 #: ../imagery/i.landsat.toar/main.c:576
-#, fuzzy, c-format
+#, c-format
 msgid "Writing %s of <%s> to <%s>..."
+msgstr ""
-#, fuzzy
 msgid "temperature"
-msgstr "Các đối tượng"
+msgstr ""
 #: ../imagery/i.landsat.toar/landsat.c:116
-msgid ""
-"The DOS4 method is not applicable here: approximation of atmospheric "
-"transmittance coefficients is unstable. Use another DOS method or use other "
-"sun_elevation parameter"
+msgid "The DOS4 method is not applicable here: approximation of atmospheric transmittance coefficients is unstable. Use another DOS method or use other sun_elevation parameter"
 msgstr ""
 #: ../imagery/i.landsat.toar/landsat_met.c:117
-#, fuzzy, c-format
+#, c-format
 msgid "Metadata file <%s> not found"
-msgstr "Không tìm thấy tập tin địa điểm <%s>"
+msgstr ""
 #: ../imagery/i.rectify/rectify.c:41
 #: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:42
 #, c-format
 msgid "Rectify <%s@%s> (location <%s>)"
-msgstr "Nắn chỉnh <%s@%s> (vị trí <%s>)"
+msgstr ""
 #: ../imagery/i.rectify/rectify.c:44
 #: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:46
-#, fuzzy, c-format
+#, c-format
 msgid "into  <%s@%s> (location <%s>) ..."
-msgstr "vào <%s@%s> (vị trí <%s>) ... %s"
+msgstr ""
 #: ../imagery/i.rectify/rectify.c:108
 #: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:126
 #, c-format
 msgid "Raster map <%s@%s>: projection don't match current settings"
-msgstr "Bản đồ raster <%s@%s>: phép chiếu không khớp với thiết lập hiện tại"
+msgstr ""
 #: ../imagery/i.rectify/rectify.c:114
 #: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:132
 #, c-format
 msgid "Raster map <%s@%s>: zone don't match current settings"
-msgstr "Bản đồ raster <%s@%s>: múi không khớp với thiết lập hiện tại"
+msgstr ""
 #: ../imagery/i.rectify/get_wind.c:124
 #, c-format
 msgid "Region N=%f S=%f E=%f W=%f"
-msgstr "Vùng B=%f N=%f Đ=%f T=%f"
+msgstr ""
 #: ../imagery/i.rectify/get_wind.c:126
 #, c-format
 msgid "Resolution EW=%f NS=%f"
-msgstr "Độ phân giải ĐT=%f BN=%f"
+msgstr ""
 #: ../imagery/i.rectify/report.c:10
 #: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:10
 msgid "complete"
-msgstr "hoàn tất"
+msgstr ""
 #: ../db/db.select/main.c:105
 msgid "failed"
-msgstr "thất bại"
+msgstr ""
 #: ../imagery/i.rectify/report.c:20
 #: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:20
 #, c-format
 msgid "%d rows, %d cols (%ld cells) completed in"
-msgstr "%d hàng, %d cột (%ld ô) hoàn tất trong"
+msgstr ""
 #: ../imagery/i.rectify/report.c:23
 #: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:23
@@ -3916,107 +3569,98 @@
 #: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:27
 #, c-format
 msgid "%.1f cells per minute"
-msgstr "%.1f ô trên phút"
+msgstr ""
 #: ../imagery/i.rectify/target.c:14
 #: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:13
 #: ../vector/v.rectify/target.c:18
 #, c-format
 msgid "Target information for group <%s> missing"
-msgstr "Thông tin đích cho nhóm <%s> bị thiếu"
+msgstr ""
 #: ../imagery/i.rectify/target.c:20
 #: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:19
 #: ../vector/v.rectify/target.c:29
 #, c-format
 msgid "Target location <%s> not found"
-msgstr "Không tìm thấy vị trí đích <%s>"
+msgstr ""
 #: ../imagery/i.rectify/target.c:32
 #: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:31
 #: ../raster/r.in.gdal/main.c:947 ../vector/v.rectify/target.c:40
 #, c-format
 msgid "Mapset <%s> in target location <%s> - "
-msgstr "Bộ bản đồ <%s> trong vị trí đích <%s> - "
+msgstr ""
 #: ../imagery/i.rectify/target.c:33
 #: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:32
 #: ../raster/r.proj/main.c:281 ../raster/r.in.gdal/main.c:949
 #: ../vector/v.rectify/target.c:41
 msgid "permission denied"
-msgstr "quyền bị từ chối"
+msgstr ""
 #: ../raster/r.proj/main.c:282 ../raster/r.in.gdal/main.c:950
 msgid "not found"
-msgstr "không tìm thấy"
+msgstr ""
 #: ../imagery/i.rectify/target.c:36
-#, fuzzy
 msgid "Please run i.target for group "
-msgstr "Vui lòng chạy i.target cho nhóm."
+msgstr ""
 #: ../imagery/i.rectify/cp.c:14 ../vector/v.rectify/cp.c:350
 #, c-format
 msgid "Control Point file for group <%s@%s> - "
-msgstr "Tập tin điểm khống chế dùng cho nhóm <%s@%s> - "
+msgstr ""
 #: ../imagery/i.rectify/cp.c:21
-#, fuzzy, c-format
+#, c-format
 msgid "Not enough active control points for thin plate spline."
 msgstr ""
-"Không đủ số lượng điểm khống chế được kích hoạt cần cho bậc hiện tại, cần %d."
 #: ../imagery/i.rectify/cp.c:24 ../imagery/i.rectify/cp.c:51
 #: ../vector/v.rectify/cp.c:363
 msgid "Poorly placed control points."
-msgstr "Các điểm không chế có vị trí không tốt."
+msgstr ""
 #: ../imagery/i.rectify/cp.c:25 ../imagery/i.rectify/cp.c:52
 #: ../vector/v.rectify/cp.c:364
 msgid " Can not generate the transformation equation."
-msgstr "Không thể tạo phương trình chuyển đổi."
+msgstr ""
 #: ../imagery/i.rectify/cp.c:28 ../imagery/i.rectify/cp.c:55
 #: ../vector/v.rectify/cp.c:367
 msgid "Not enough memory to solve for transformation equation"
-msgstr "Không đủ bộ nhớ để giải phương trình chuyển đổi"
+msgstr ""
 #: ../imagery/i.rectify/cp.c:31 ../imagery/i.rectify/cp.c:58
 #: ../vector/v.rectify/cp.c:370
 msgid "Invalid order"
-msgstr "Bậc không hợp lệ"
+msgstr ""
 #: ../imagery/i.rectify/cp.c:47 ../vector/v.rectify/cp.c:359
 #, c-format
 msgid "Not enough active control points for current order, %d are required."
 msgstr ""
 #: ../imagery/i.rectify/main.c:100 ../vector/v.rectify/main.c:71
-#, fuzzy
 msgid "rectify"
-msgstr "ảnh, nắn chỉnh"
+msgstr ""
 #: ../imagery/i.rectify/main.c:102
-msgid ""
-"Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points."
+msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
 msgstr ""
-"Nắn chỉnh một ảnh bằng cách tính toán phép chuyển đổi tọa độ cho từng điểm "
-"ảnh trong ảnh dựa trên các điểm khống chế."
 #: ../imagery/i.rectify/main.c:116
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:103
 msgid "Output raster map(s) suffix"
-msgstr "Tên đuôi cho (các) bản đồ raster đầu ra"
+msgstr ""
 #: ../imagery/i.rectify/main.c:124 ../vector/v.rectify/main.c:102
-#, fuzzy
 msgid "Rectification polynomial order (1-3)"
-msgstr "Bậc đa thức nắn chỉnh (1-3)"
+msgstr ""
 #: ../imagery/i.rectify/main.c:130
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:109
@@ -4025,29 +3669,25 @@
 #: ../imagery/i.rectify/main.c:138
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:117
-#, fuzzy
 msgid "Amount of memory to use in MB"
-msgstr "hết bộ nhớ!"
+msgstr ""
 #: ../imagery/i.rectify/main.c:148
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:127
 #: ../raster/r.proj/main.c:182
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
 msgid "Interpolation method to use"
-msgstr "Phương pháp nội suy sử dụng"
+msgstr ""
 #: ../imagery/i.rectify/main.c:153
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:137
-msgid ""
-"Use current region settings in target location (def.=calculate smallest area)"
+msgid "Use current region settings in target location (def.=calculate smallest area)"
 msgstr ""
-"Dùng các thiết lập vùng hiện tại trong vị trí đích (mặc định=tính diện tích "
-"nhỏ nhất)"
 #: ../imagery/i.rectify/main.c:157
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:141
 msgid "Rectify all raster maps in group"
-msgstr "Nắn chỉnh tất cả các ảnh trong nhóm"
+msgstr ""
 #: ../imagery/i.rectify/main.c:161
 msgid "Use thin plate spline"
@@ -4059,46 +3699,45 @@
 #: ../raster/r.statistics/main.c:118 ../vector/v.vect.stats/main.c:263
 #, c-format
 msgid "<%s=%s> unknown %s"
-msgstr "<%s=%s> %s không biết"
+msgstr ""
 #: ../imagery/i.rectify/main.c:199 ../vector/v.rectify/main.c:143
 #, c-format
 msgid "Invalid order (%d); please enter 1 to %d"
-msgstr "Bậc không hợp lệ (%d); vui lòng nhập 1 vào %d"
+msgstr ""
 #: ../imagery/i.rectify/main.c:206
-#, fuzzy, c-format
+#, c-format
 msgid "Location: %s"
-msgstr "Vị trí: %s\n"
+msgstr ""
 #: ../imagery/i.rectify/main.c:207
-#, fuzzy, c-format
+#, c-format
 msgid "Mapset: %s"
-msgstr "Bộ bản đồ:   %s\n"
+msgstr ""
 #: ../imagery/i.rectify/main.c:208
 #, c-format
 msgid "Group <%s> does not exist"
-msgstr "Nhóm <%s> không tồn tại"
+msgstr ""
 #: ../imagery/i.rectify/main.c:212
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:187
 #, c-format
 msgid "Group <%s> contains no raster maps; run i.group"
-msgstr "Nhóm <%s> không có bản đồ bản đồ raster; hãy chạy i.group"
+msgstr ""
 #: ../imagery/i.rectify/main.c:287
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:281
-#, fuzzy, c-format
+#, c-format
 msgid "Extension <%s> is illegal"
-msgstr "[%s] là tên không hợp lệ"
+msgstr ""
 #: ../imagery/i.rectify/main.c:290
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:284
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:293
-#, fuzzy
 msgid "The following raster map already exists in"
-msgstr "Bản đồ raster <%s> đã có"
+msgstr ""
 #: ../imagery/i.rectify/main.c:291
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:285
@@ -4123,15 +3762,13 @@
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:319
 #, c-format
 msgid "Using region: N=%f S=%f, E=%f W=%f"
-msgstr "Sử dụng vùng B=%f N=%f, Đ=%f T=%f"
+msgstr ""
 #: ../imagery/i.rectify/main.c:335
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:386
-#, fuzzy, c-format
+#, c-format
 msgid "Input raster map <%s> does not exist in group <%s>."
 msgstr ""
-"Bản đồ raster đầu vào <%s> không có trong nhóm <%s>.\n"
Hãy thử:\n"
 #: ../imagery/i.rectify/main.c:337
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:388
@@ -4141,75 +3778,70 @@
 #: ../imagery/i.rectify/main.c:342
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:393
 msgid "Exit!"
-msgstr "Thoát!"
+msgstr ""
 #: ../imagery/i.rectify/readcell.c:58
 #: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:64
 #: ../raster/r.stats.quantile/main.c:427 ../raster/r.proj/readcell.c:59
 #: ../raster/r.proj/readcell.c:129 ../raster/r.stats.zonal/main.c:482
 msgid "Unable to open temporary file"
+msgstr ""
 #: ../imagery/i.rectify/readcell.c:64
 #: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:72
 msgid "Allocating memory and reading input map..."
-msgstr "Đang cấp phát bộ nhớ và đọc bản đồ đầu vào..."
+msgstr ""
 #: ../imagery/i.rectify/readcell.c:90 ../imagery/i.rectify/readcell.c:129
 #: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:100
 #: ../raster/r.proj/readcell.c:92
 msgid "Error writing segment file"
-msgstr "Lỗi ghi tập tin phân đoạn (segment)"
+msgstr ""
 #: ../imagery/i.rectify/readcell.c:117
 #: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:130
 #: ../raster/r.proj/readcell.c:125
 msgid "Internal error: cache miss on fully-cached map"
-msgstr "Lỗi nội tại: thiếu bộ nhớ đệm cache trong bản đồ được đệm hoàn chỉnh"
+msgstr ""
 #: ../imagery/i.rectify/readcell.c:126
 #: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:139
 #: ../raster/r.proj/readcell.c:138
 msgid "Error seeking on segment file"
-msgstr "Lỗi khi tìm tập tin phân đoạn"
+msgstr ""
 #: ../imagery/i.his.rgb/main.c:47 ../imagery/i.rgb.his/main.c:47
 #: ../raster/r.his/main.c:68 ../display/d.his/main.c:64
-#, fuzzy
 msgid "color transformation"
-msgstr "vector, chuyển đổi"
+msgstr ""
 #: ../imagery/i.his.rgb/main.c:52
-msgid ""
-"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
-"RGB (Red-Green-Blue) color space."
+msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
 msgstr ""
-"Chuyển đổi các bản đồ raster từ không gian màu HIS (Màu sắc-Cường độ-Độ bão "
-"hoà) thành RGB (Đỏ-Lục-Xanh)."
 #: ../imagery/i.his.rgb/main.c:58
 msgid "Name of input raster map (hue)"
-msgstr "Tên của bản đồ raster đầu vào (màu sắc)"
+msgstr ""
 #: ../imagery/i.his.rgb/main.c:62
 msgid "Name of input raster map (intensity)"
-msgstr "Tên của bản đồ raster đầu vào (cường độ)"
+msgstr ""
 #: ../imagery/i.his.rgb/main.c:66
 msgid "Name of input raster map (saturation)"
-msgstr "Tên của bản đồ raster đầu vào (độ bão hoà)"
+msgstr ""
 #: ../imagery/i.his.rgb/main.c:70
 msgid "Name for output raster map (red)"
-msgstr "Tên của bản đồ raster đầu ra (đỏ)"
+msgstr ""
 #: ../imagery/i.his.rgb/main.c:74
 msgid "Name for output raster map (green)"
-msgstr "Tên của bản đồ raster đầu ra (lục)"
+msgstr ""
 #: ../imagery/i.his.rgb/main.c:78
 msgid "Name for output raster map (blue)"
-msgstr "Tên của bản đồ raster đầu ra (xanh)"
+msgstr ""
 #: ../imagery/i.group/main.c:53 ../imagery/i.target/main.c:46
 #: ../raster/r.compress/main.c:65
@@ -4227,41 +3859,36 @@
 #: ../general/g.remove/main.c:70 ../general/g.findfile/main.c:39
 #: ../general/g.findetc/main.c:29 ../general/g.filename/main.c:40
 #: ../general/g.rename/main.c:46
-#, fuzzy
 msgid "map management"
-msgstr "tổng quát, quản lý bản đồ"
+msgstr ""
 #: ../imagery/i.group/main.c:55
-#, fuzzy
 msgid "Creates, edits, and lists groups of imagery data."
-msgstr "Tạo, chỉnh sửa và liệt kê các nhóm và nhóm phụ của các tập tin ảnh."
+msgstr ""
 #: ../imagery/i.group/main.c:59
 msgid "Name of imagery group"
-msgstr "Tên nhóm ảnh"
+msgstr ""
 #: ../imagery/i.group/main.c:63
-#, fuzzy
 msgid "Name of imagery subgroup"
-msgstr "Tên của nhóm ảnh phụ"
+msgstr ""
 #: ../imagery/i.group/main.c:67
 msgid "Name of raster map(s) to include in group"
-msgstr "Tên của (các) bản đồ raster đưa vào nhóm"
+msgstr ""
 #: ../imagery/i.group/main.c:68 ../imagery/i.group/main.c:74
 msgid "Maps"
 msgstr ""
 #: ../imagery/i.group/main.c:73
-#, fuzzy
 msgid "Remove selected files from specified group or subgroup"
-msgstr "Loại bỏ các tập tin chọn ra khỏi nhóm được chỉ định"
+msgstr ""
 #: ../imagery/i.group/main.c:78
-#, fuzzy
 msgid "List files from specified (sub)group"
-msgstr "Liệt kê các tập tin trong nhóm (phụ) được chỉ định (fancy)"
+msgstr ""
 #: ../imagery/i.group/main.c:79 ../imagery/i.group/main.c:84
 #: ../imagery/i.group/main.c:89 ../db/db.connect/main.c:53
@@ -4311,12 +3938,11 @@
 #: ../vector/v.to.db/parse.c:116 ../vector/v.to.db/parse.c:121
 #: ../vector/v.to.db/parse.c:127 ../vector/v.to.db/parse.c:133
 msgid "Print"
-msgstr "In"
+msgstr ""
 #: ../imagery/i.group/main.c:83
-#, fuzzy
 msgid "List subgroups from specified group"
+msgstr ""
 #: ../imagery/i.group/main.c:88 ../raster/r.regression.multi/main.c:161
 #: ../raster/r.regression.line/main.c:69
@@ -4324,108 +3950,107 @@
 #: ../locale/scriptstrings/i.oif_to_translate.c:6
 #: ../general/g.region/main.c:143
 msgid "Print in shell script style"
-msgstr "In ra ở dạng tập lệnh shell"
+msgstr ""
 #: ../imagery/i.group/main.c:109
 msgid "No input raster map(s) specified"
-msgstr "(các) Bản đồ raster đầu vào không được chỉ định."
+msgstr ""
 #: ../imagery/i.group/main.c:117 ../imagery/i.target/main.c:80
 msgid "Group must exist in the current mapset"
-msgstr "Nhóm phải có trong bộ bản đồ hiện tại"
+msgstr ""
 #: ../imagery/i.group/main.c:128 ../imagery/i.group/main.c:150
 msgid "Specified group does not exist in current mapset"
-msgstr "Nhóm được chỉ định không có trong bộ bản đồ hiện tại"
+msgstr ""
 #: ../imagery/i.group/main.c:132
 #, c-format
 msgid "Removing raster maps from subgroup <%s>..."
-msgstr "Đang loại bỏ các bản đồ raster khỏi nhóm phụ <%s>... "
+msgstr ""
 #: ../imagery/i.group/main.c:137
 #, c-format
 msgid "Removing raster maps from group <%s>..."
-msgstr "Đang loại bỏ các bản đồ raster khỏi nhóm <%s>... "
+msgstr ""
 #: ../imagery/i.group/main.c:158
-#, fuzzy, c-format
+#, c-format
 msgid "Subgroup <%s> of group <%s> references the following raster maps:"
-msgstr "Nhóm phụ <%s> trong nhóm <%s> không có bản đồ raster nào"
+msgstr ""
 #: ../imagery/i.group/main.c:173
-#, fuzzy, c-format
+#, c-format
 msgid "Group <%s> references the following raster maps:"
-msgstr "Nhóm phụ <%s> không có bản đồ raster nào"
+msgstr ""
 #: ../imagery/i.group/main.c:185
 #, c-format
 msgid "Group <%s> does not yet exist. Creating..."
-msgstr "Nhóm <%s> chưa có. Đang tạo..."
+msgstr ""
 #: ../imagery/i.group/main.c:189 ../imagery/i.group/main.c:198
 #, c-format
 msgid "Adding raster maps to group <%s>..."
-msgstr "Đang thêm các bản đồ raster vào nhóm <%s>..."
+msgstr ""
 #: ../imagery/i.group/main.c:193
 #, c-format
 msgid "Adding raster maps to subgroup <%s>..."
-msgstr "Đang thêm các bản đồ raster vào nhóm phụ <%s>..."
+msgstr ""
 #: ../imagery/i.group/main.c:219
-#, fuzzy
 msgid "No input raster maps defined"
+msgstr ""
 #: ../imagery/i.group/main.c:223 ../imagery/i.group/main.c:265
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map <%s> not found. Skipped."
+msgstr ""
 #: ../imagery/i.group/main.c:228
 #, c-format
 msgid "Adding raster map <%s> to group"
-msgstr "Đang thêm bản đồ raster <%s> vào nhóm"
+msgstr ""
 #: ../imagery/i.group/main.c:234
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map <%s> exists in group. Skipped."
+msgstr ""
 #: ../imagery/i.group/main.c:271
 #, c-format
 msgid "Adding raster map <%s> to subgroup"
-msgstr "Đang thêm bản đồ raster <%s> vào nhóm phụ"
+msgstr ""
 #: ../imagery/i.group/main.c:278
 #, c-format
 msgid "Raster map <%s> exists in subgroup. Skipping..."
+msgstr ""
 #: ../imagery/i.group/main.c:327
 #, c-format
 msgid "Removing raster map <%s> from group"
-msgstr "Đang loại bỏ bản đồ raster <%s> ra khỏi nhóm"
+msgstr ""
 #: ../imagery/i.group/main.c:344 ../imagery/i.group/main.c:403
 msgid "No raster map removed"
-msgstr "Không có bản đồ raster nào bị loại bỏ"
+msgstr ""
 #: ../imagery/i.group/main.c:386
 #, c-format
 msgid "Removing raster map <%s> from subgroup"
-msgstr "Đang loại bỏ bản đồ raster <%s> ra khỏi nhóm phụ"
+msgstr ""
 #: ../imagery/i.group/main.c:422
-#, fuzzy, c-format
+#, c-format
 msgid "Group <%s> does not contain any subgroup.\n"
+msgstr ""
 #: ../imagery/i.group/main.c:433
-#, fuzzy, c-format
+#, c-format
 msgid "group <%s> references the following subgroups\n"
+msgstr ""
 #: ../imagery/i.biomass/main.c:51
 msgid "biomass"
@@ -4440,59 +4065,48 @@
 msgstr ""
 #: ../imagery/i.biomass/main.c:60
-#, fuzzy
 msgid "Name of fPAR raster map"
+msgstr ""
 #: ../imagery/i.biomass/main.c:65
-#, fuzzy
 msgid "Name of light use efficiency raster map (UZB:cotton=1.9)"
+msgstr ""
 #: ../imagery/i.biomass/main.c:69
-#, fuzzy
 msgid "Name of degree latitude raster map [dd.ddd]"
+msgstr ""
 #: ../imagery/i.biomass/main.c:73
-#, fuzzy
 msgid "Name of Day of Year raster map [1-366]"
-msgstr "Tên của bản đồ raster lớp phủ"
+msgstr ""
 #: ../imagery/i.biomass/main.c:78
-#, fuzzy
 msgid "Name of single-way transmissivity raster map [0.0-1.0]"
-msgstr "Tên tập tin raster độ cao"
+msgstr ""
 #: ../imagery/i.biomass/main.c:83
-#, fuzzy
 msgid "Value of water availability raster map [0.0-1.0]"
+msgstr ""
 #: ../imagery/i.biomass/main.c:87
-#, fuzzy
 msgid "Name for output daily biomass growth raster map [kg/ha/d]"
+msgstr ""
 #: ../imagery/i.evapo.time/main.c:79
-msgid ""
-"Computes temporal integration of satellite ET actual (ETa) following the "
-"daily ET reference (ETo) from meteorological station(s)."
+msgid "Computes temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)."
 msgstr ""
 #: ../imagery/i.evapo.time/main.c:86
-#, fuzzy
 msgid "Names of satellite ETa raster maps [mm/d or cm/d]"
-msgstr "Tên của tập tin raster đạo hàm x"
+msgstr ""
 #: ../imagery/i.evapo.time/main.c:91
 msgid "Names of satellite ETa Day of Year (DOY) raster maps [0-400] [-]"
 msgstr ""
 #: ../imagery/i.evapo.time/main.c:96
-#, fuzzy
 msgid "Names of meteorological station ETo raster maps [0-400] [mm/d or cm/d]"
-msgstr "Tên của bản đồ raster tốc độ xâm nhập chảy tràn [mm/giờ]"
+msgstr ""
 #: ../imagery/i.evapo.time/main.c:102
 msgid "Value of DOY for ETo first day"
@@ -4515,158 +4129,142 @@
 msgstr ""
 #: ../imagery/i.evapo.time/main.c:151
-#, fuzzy, c-format
+#, c-format
 msgid "Too many ETa files. Only %d allowed."
+msgstr ""
 #: ../imagery/i.evapo.time/main.c:162 ../imagery/i.evapo.time/main.c:178
 #: ../imagery/i.evapo.time/main.c:200
-#, fuzzy
 msgid "The min specified input map is two"
-msgstr "Số lượng các bản đồ đầu vào ít nhất là 2"
+msgstr ""
 #: ../imagery/i.evapo.time/main.c:167
-#, fuzzy, c-format
+#, c-format
 msgid "Too many ETa_doy files. Only %d allowed."
+msgstr ""
 #: ../imagery/i.evapo.time/main.c:183
 msgid "ETa and ETa_DOY file numbers are not equal!"
 msgstr ""
 #: ../imagery/i.evapo.time/main.c:189
-#, fuzzy, c-format
+#, c-format
 msgid "Too many ETo files. Only %d allowed."
+msgstr ""
 #: ../imagery/i.smap/parse.c:20 ../imagery/i.maxlik/main.c:81
-#, fuzzy
 msgid "Name of input file containing signatures"
-msgstr "Tên củ tập tin chứa các chữ ký"
+msgstr ""
 #: ../imagery/i.smap/parse.c:21
 msgid "Generated by i.gensigset"
-msgstr "Do i.gensigset tạo ra"
+msgstr ""
 #: ../imagery/i.smap/parse.c:28 ../imagery/i.maxlik/main.c:86
-#, fuzzy
 msgid "Name for output raster map holding classification results"
-msgstr "Tên bản đồ raster chứa các kết quả phân loại"
+msgstr ""
 #: ../imagery/i.smap/parse.c:33
-#, fuzzy
 msgid "Name for output raster map holding goodness of fit (lower is better)"
 msgstr ""
-"Tên của bản đồ vec-tơ đầu ra nơi các khung bao của các bản đồ vec-tơ đầu vào "
-"được ghi vào đó"
 #: ../imagery/i.smap/parse.c:37
 msgid "Size of submatrix to process at one time"
-msgstr "Kích thước của ma trận con để xử lý mỗi lần"
+msgstr ""
 #: ../imagery/i.smap/parse.c:45
 msgid "Use maximum likelihood estimation (instead of smap)"
-msgstr "Sử dụng phép ước lượng giống nhau tối đa (thay vì dùng SMAP)"
+msgstr ""
 #: ../imagery/i.smap/segment.c:67
 msgid "Number of classes must be < 256"
-msgstr "Số lớp phải < 256"
+msgstr ""
 #: ../imagery/i.smap/segment.c:102
 #, c-format
 msgid "Processing rows %d-%d (of %d)..."
-msgstr "Đang xử lý các hàng %d-%d (của %d)..."
+msgstr ""
 #: ../imagery/i.smap/main.c:41 ../imagery/i.segment/main.c:37
-#, fuzzy
 msgid "segmentation"
-msgstr "Phép chọn"
+msgstr ""
 #: ../imagery/i.smap/main.c:44
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
+msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
 msgstr ""
-"Thực hiện phép phân loại ảnh theo ngữ cảnh bằng cách dùng phép ước lượng "
-"sequential maximum a posterioi  (SMAP)."
 #: ../imagery/i.smap/write_img.c:15
-#, fuzzy
 msgid "Writing output raster map(s)..."
-msgstr "Đang ghi bản đồ raster đầu ra %s..."
+msgstr ""
 #: ../imagery/i.smap/interp.c:68 ../raster/r.cost/main.c:673
 #: ../raster/r.stream.extract/load.c:44 ../raster/r.stream.extract/load.c:53
 #: ../raster/r.texture/h_measure.c:594 ../raster/r.walk/main.c:808
 msgid "Unable to allocate memory"
-msgstr "Không thể cấp phát bộ nhớ"
+msgstr ""
 #: ../imagery/i.smap/interp.c:233
 msgid "Invalid parameter values"
-msgstr "Các giá trị tham số không hợp lệ"
+msgstr ""
 #: ../imagery/i.smap/model.c:43
 #, c-format
 msgid "Nonsymetric covariance for class %d subclass %d"
-msgstr "Hiệp phương sai bất đối xứng cho lớp %d lớp phụ %d"
+msgstr ""
 #: ../imagery/i.smap/model.c:55
 #, c-format
 msgid "Nonpositive eigenvalues for class %d subclass %d"
-msgstr "Các giá trị eigen không dương cho lớp %d lớp phụ %d"
+msgstr ""
 #: ../imagery/i.smap/openfiles.c:22 ../imagery/i.smap/read_sig.c:17
 #, c-format
 msgid "Subgroup <%s> in group <%s> contains no raster maps"
+msgstr ""
 #: ../imagery/i.smap/read_sig.c:23 ../imagery/i.maxlik/open.c:53
 #: ../imagery/i.cluster/open_files.c:60
 #, c-format
 msgid "Unable to read signature file <%s>"
-msgstr "Không thể đọc tập tin chữ ký <%s>"
+msgstr ""
 #: ../imagery/i.smap/read_sig.c:27
 #, c-format
 msgid "Signature file <%s> is invalid"
-msgstr "Tập tin chữ ký <%s> không hợp lệ."
+msgstr ""
 #: ../imagery/i.smap/read_sig.c:30
-#, fuzzy, c-format
+#, c-format
 msgid "Signature file <%s> is empty"
+msgstr ""
 #: ../imagery/i.rgb.his/main.c:52
-msgid ""
-"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
-"Intensity-Saturation) color space."
+msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
 msgstr ""
-"Chuyển đổi các bản đồ raster từ không gian màu RGB (Đỏ-Lục-Xanh) thành HIS "
-"(Màu sắc-Cường độ-Độ bão hoà)."
 #: ../imagery/i.rgb.his/main.c:58
 msgid "Name of input raster map (red)"
-msgstr "Tên của bản đồ raster đầu vào (đỏ)"
+msgstr ""
 #: ../imagery/i.rgb.his/main.c:62
 msgid "Name of input raster map (green)"
-msgstr "Tên của bản đồ raster đầu vào (lục)"
+msgstr ""
 #: ../imagery/i.rgb.his/main.c:66
 msgid "Name of input raster map (blue)"
-msgstr "Tên của bản đồ raster đầu vào (xanh)"
+msgstr ""
 #: ../imagery/i.rgb.his/main.c:70
 msgid "Name for output raster map (hue)"
-msgstr "Tên của bản đồ raster đầu ra (màu sắc)"
+msgstr ""
 #: ../imagery/i.rgb.his/main.c:74
 msgid "Name for output raster map (intensity)"
-msgstr "Tên của bản đồ raster đầu ra (cường độ)"
+msgstr ""
 #: ../imagery/i.rgb.his/main.c:78
 msgid "Name for output raster map (saturation)"
-msgstr "Tên của bản đồ raster đầu ra (độ bão hoà)"
+msgstr ""
 #: ../imagery/i.pca/main.c:74
 #: ../locale/scriptstrings/i.pansharpen_to_translate.c:8
@@ -4674,48 +4272,37 @@
 msgstr ""
 #: ../imagery/i.pca/main.c:75
-#, fuzzy
 msgid "principal components analysis"
-msgstr "Chương trình phân tích thành phần chính tắc (pca) dùng trong xử lý ảnh"
+msgstr ""
 #: ../imagery/i.pca/main.c:76
-#, fuzzy
 msgid "Principal components analysis (PCA) for image processing."
+msgstr ""
 #: ../imagery/i.pca/main.c:82
-#, fuzzy
 msgid "Name of two or more input raster maps or imagery group"
 msgstr ""
-"#-#-#-#-#  grassmods_vi.po (grassmods_vi)  #-#-#-#-#\n"
-"Tên của tập tin raster đầu vào\n"
-"Tên bản đồ raster đầu vào"
 #: ../imagery/i.pca/main.c:85
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:8
-#, fuzzy
 msgid "Name for output basename raster map(s)"
-msgstr "Tên của bản đồ raster đầu ra"
+msgstr ""
 #: ../imagery/i.pca/main.c:87
-#, fuzzy
 msgid "A numerical suffix will be added for each component map"
-msgstr "Số cấp cần dùng cho từng thành phần"
+msgstr ""
 #: ../imagery/i.pca/main.c:96
-#, fuzzy
 msgid "Rescaling range for output maps"
-msgstr "Độ phân giải cuủa bản đồ đầu ra"
+msgstr ""
 #: ../imagery/i.pca/main.c:98
 msgid "For no rescaling use 0,0"
 msgstr ""
 #: ../imagery/i.pca/main.c:99
-#, fuzzy
 msgid "Rescale"
-msgstr "Nạp lại"
+msgstr ""
 #: ../imagery/i.pca/main.c:108
 msgid "Cumulative percent importance for filtering"
@@ -4723,9 +4310,8 @@
 #: ../imagery/i.pca/main.c:109 ../imagery/i.pca/main.c:120
 #: ../raster/r.mfilter/main.c:80 ../raster/r.mfilter/main.c:99
-#, fuzzy
 msgid "Filter"
-msgstr "địa điểm"
+msgstr ""
 #: ../imagery/i.pca/main.c:113
 msgid "Normalize (center and scale) input maps"
@@ -4736,9 +4322,8 @@
 msgstr ""
 #: ../imagery/i.pca/main.c:118
-#, fuzzy
 msgid "Output will be filtered input bands"
-msgstr "Chỉ xuất ra dạng mét"
+msgstr ""
 #: ../imagery/i.pca/main.c:119
 msgid "Apply inverse PCA after PCA"
@@ -4748,25 +4333,25 @@
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:180
 #, c-format
 msgid "Group <%s> not found"
-msgstr "Không tìm thấy nhóm <%s>"
+msgstr ""
 #: ../imagery/i.pca/main.c:154
 msgid "Sorry, at least 2 input bands must be provided"
-msgstr "Xin lỗi, tối thiểu phải cung cấp 2 băng đầu vào"
+msgstr ""
 #: ../imagery/i.pca/main.c:169
-#, fuzzy, c-format
+#, c-format
 msgid "'%s' must be positive"
-msgstr "Kích thước vùng lân cận phải dương"
+msgstr ""
 #: ../imagery/i.pca/main.c:171
-#, fuzzy, c-format
+#, c-format
 msgid "'%s' must be < 100"
-msgstr "'layer' phải > 0"
+msgstr ""
 #: ../imagery/i.pca/main.c:197 ../raster/r.covar/main.c:110
 msgid "No non-null values"
-msgstr "Không có các giá trị khác rỗng"
+msgstr ""
 #: ../imagery/i.pca/main.c:233
 msgid "Not enough principal components left for filtering"
@@ -4779,22 +4364,20 @@
 #: ../imagery/i.pca/main.c:297
 msgid "Scale range length should be > 0. Using default values: 0,255."
-msgstr "Chiều dài miền tỷ lệ phải >0. Dùng các giá trị mặc định: 0,255."
+msgstr ""
 #: ../imagery/i.pca/main.c:343
-#, fuzzy
 msgid "Computing covariance matrix..."
-msgstr "Đang tính ma trận hiệp phương sai..."
+msgstr ""
 #: ../imagery/i.pca/main.c:456
-#, fuzzy, c-format
+#, c-format
 msgid "Rescaling to range %d,%d..."
-msgstr "Đang lấy lại tỷ lệ dữ liệu <%s> thành miền %d,%d..."
+msgstr ""
 #: ../imagery/i.pca/main.c:464
-#, fuzzy
 msgid "Calculating principal components..."
-msgstr "Đang tính các giá trị trung bình lớp ..."
+msgstr ""
 #: ../imagery/i.pca/support.c:50
 msgid "Eigen values, (vectors), and [percent importance]:"
@@ -4821,34 +4404,28 @@
 msgstr ""
 #: ../imagery/i.eb.evapfr/main.c:53
-#, fuzzy
 msgid "Computes evaporative fraction and root zone soil moisture."
-msgstr "Tính toán việc chuyển đổi tọa độ dựa trên các điểm khống chế."
+msgstr ""
 #: ../imagery/i.eb.evapfr/main.c:58 ../imagery/i.eb.soilheatflux/main.c:71
-#, fuzzy
 msgid "Name of Net Radiation raster map [W/m2]"
+msgstr ""
 #: ../imagery/i.eb.evapfr/main.c:62
-#, fuzzy
 msgid "Name of soil heat flux raster map [W/m2]"
+msgstr ""
 #: ../imagery/i.eb.evapfr/main.c:66
-#, fuzzy
 msgid "Name of sensible heat flux raster map [W/m2]"
+msgstr ""
 #: ../imagery/i.eb.evapfr/main.c:71
-#, fuzzy
 msgid "Name for output evaporative fraction raster map"
-msgstr "Tên của bản đồ raster hướng đầu ra"
+msgstr ""
 #: ../imagery/i.eb.evapfr/main.c:77
-#, fuzzy
 msgid "Name for output root zone soil moisture raster map"
-msgstr "Tên của bản đồ raster độ cong mặt cắt đầu ra"
+msgstr ""
 #: ../imagery/i.eb.evapfr/main.c:82
 msgid "Root zone soil moisture output (Makin, Molden and Bastiaanssen, 2001)"
@@ -4856,45 +4433,45 @@
 #: ../imagery/i.ifft/main.c:81
 msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
-msgstr "Phép chuyển đổi Fast Fourier Nghịch  (ifft) dùng cho xử lý ảnh."
+msgstr ""
 #: ../imagery/i.ifft/main.c:86
 msgid "Name of input raster map (image fft, real part)"
-msgstr "Tên của bản đồ raster đầu vào (ảnh fft, phần-thực)"
+msgstr ""
 #: ../imagery/i.ifft/main.c:90
 msgid "Name of input raster map (image fft, imaginary part"
-msgstr "Tên của bản đồ raster đầu vào (ảnh fft, phần ảnh)"
+msgstr ""
 #: ../imagery/i.ifft/main.c:93
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:14
 #: ../locale/scriptstrings/r.import_to_translate.c:11
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:6
 msgid "Name for output raster map"
+msgstr ""
 #: ../imagery/i.ifft/main.c:115
 msgid "The real and imaginary original windows did not match"
-msgstr "Các cửa sổ nguyên thủy của phần-thực và phần-ảnh không khớp nhau"
+msgstr ""
 #: ../imagery/i.ifft/main.c:157
 msgid "Masking raster maps..."
-msgstr "Đang che mặt nạ các bản đồ raster..."
+msgstr ""
 #: ../imagery/i.ifft/main.c:200
 msgid "Starting Inverse FFT..."
-msgstr "Đang khởi động IFFT..."
+msgstr ""
 #: ../imagery/i.ifft/main.c:207 ../raster/r.random.cells/indep.c:139
 #: ../raster/r.random.surface/save.c:98 ../raster/r.drain/main.c:519
 #: ../raster/r.composite/main.c:191
 #, c-format
 msgid "Writing raster map <%s>..."
-msgstr "Đang ghi bản đồ raster <%s>..."
+msgstr ""
 #: ../imagery/i.gensig/means.c:26
 msgid "Calculating class means..."
+msgstr ""
 #: ../imagery/i.gensig/main.c:42 ../imagery/i.maxlik/main.c:63
 msgid "Maximum Likelihood Classification"
@@ -4902,31 +4479,30 @@
 #: ../imagery/i.gensig/main.c:46
 msgid "Generates statistics for i.maxlik from raster map."
-msgstr "Tạo thống kê cho i.maxlik từ bản đồ raster."
+msgstr ""
 #: ../imagery/i.gensig/covariance.c:30
 msgid "Calculating class covariance matrices..."
-msgstr "Đang tính các ma trận hiệp phương sai lớp..."
+msgstr ""
 #: ../imagery/i.gensig/check.c:21
 #, c-format
 msgid "Signature %d not invertible"
-msgstr "Chữ ký %d không thể đảo ngược"
+msgstr ""
 #: ../imagery/i.gensig/check.c:27
 #, c-format
 msgid "Signature %d unable to get eigen values"
-msgstr "Chữ ký %d không thể lấy các giá trị eigen"
+msgstr ""
 #: ../imagery/i.gensig/check.c:33
 #, c-format
 msgid "Signature %d not positive definite"
-msgstr "Chữ ký %d không được xác định dương"
+msgstr ""
 #: ../imagery/i.segment/rclist.c:17 ../raster/r.clump/rclist.c:17
-#, fuzzy
 msgid "rclist out of memory"
-msgstr "Hết bộ nhớ"
+msgstr ""
 #: ../imagery/i.segment/region_growing.c:93 ../imagery/i.segment/cluster.c:342
 #: ../imagery/i.segment/cluster.c:412
@@ -4935,15 +4511,13 @@
 #: ../imagery/i.segment/region_growing.c:251
 #: ../imagery/i.segment/mean_shift.c:220
-#, fuzzy, c-format
+#, c-format
 msgid "Processing pass %d..."
-msgstr "Đang xử lý các vùng..."
+msgstr ""
 #: ../imagery/i.segment/region_growing.c:529
 #, c-format
-msgid ""
-"Segmentation processes stopped at %d due to reaching max iteration limit, "
-"more merges may be possible"
+msgid "Segmentation processes stopped at %d due to reaching max iteration limit, more merges may be possible"
 msgstr ""
 #: ../imagery/i.segment/region_growing.c:531
@@ -4981,9 +4555,9 @@
 #: ../imagery/i.segment/region_growing.c:1031
 #: ../imagery/i.segment/region_growing.c:1485
-#, fuzzy, c-format
+#, c-format
 msgid "Region size is larger than 2: %d"
-msgstr "Kích thước vùng nhỏ hơn minreg, không có gì được trình bày."
+msgstr ""
 #: ../imagery/i.segment/region_growing.c:1098
 #, c-format
@@ -4991,14 +4565,13 @@
 msgstr ""
 #: ../imagery/i.segment/region_growing.c:1340
-#, fuzzy, c-format
+#, c-format
 msgid "Candidate flag is already %s"
-msgstr "tập tin dig_att đã có"
+msgstr ""
-#, fuzzy
 msgid "set"
-msgstr "Phép chọn"
+msgstr ""
 msgid "unset"
@@ -5010,44 +4583,40 @@
 msgstr ""
 #: ../imagery/i.segment/open_files.c:39
-#, fuzzy, c-format
+#, c-format
 msgid "Group <%s> not found in the current mapset"
+msgstr ""
 #: ../imagery/i.segment/open_files.c:43
-#, fuzzy, c-format
+#, c-format
 msgid "Group <%s> contains no raster maps"
+msgstr ""
 #: ../imagery/i.segment/open_files.c:71 ../imagery/i.segment/open_files.c:238
 #: ../imagery/i.segment/open_files.c:246
 #: ../imagery/i.segment/write_output.c:112 ../raster/r.clump/clump.c:449
-#, fuzzy, c-format
+#, c-format
 msgid "No min/max found in raster map <%s>"
-msgstr "Không tìm thấy cột <%s> trong bảng <%s>"
+msgstr ""
 #: ../imagery/i.segment/open_files.c:120
-#, fuzzy
 msgid "Insufficient number of non-NULL cells in current region"
-msgstr "Không có [%ld] ô không NULL trong vùng hiện tại"
+msgstr ""
 #: ../imagery/i.segment/open_files.c:151
-#, fuzzy
 msgid "Loading input bands..."
-msgstr "Đang đọc các đầu vào..."
+msgstr ""
 #: ../imagery/i.segment/open_files.c:153
-#, fuzzy
 msgid "Loading input band..."
+msgstr ""
 #: ../imagery/i.segment/open_files.c:185 ../imagery/i.segment/open_files.c:190
 #: ../imagery/i.segment/open_files.c:212 ../imagery/i.segment/open_files.c:270
 #: ../imagery/i.segment/open_files.c:358 ../imagery/i.segment/open_files.c:424
 #: ../imagery/i.segment/open_files.c:480
-#, fuzzy
 msgid "Unable to write to temporary file"
-msgstr "Không thể tạo tập tin tạm"
+msgstr ""
 #: ../imagery/i.segment/open_files.c:277
 #, c-format
@@ -5055,23 +4624,23 @@
 msgstr ""
 #: ../imagery/i.segment/open_files.c:333
-#, fuzzy, c-format
+#, c-format
 msgid "Loading seeds from raster map <%s>..."
+msgstr ""
 #: ../imagery/i.segment/open_files.c:363
-#, fuzzy, c-format
+#, c-format
 msgid "No seeds found in '%s'!"
-msgstr "Tìm thấy %d đường hoặc ranh giới trong bản đồ vec-tơ <%s@%s>"
+msgstr ""
 #: ../imagery/i.segment/open_files.c:383
 msgid "Too many seeds: integer overflow"
 msgstr ""
 #: ../imagery/i.segment/open_files.c:500
-#, fuzzy, c-format
+#, c-format
 msgid "Segment %d is already registered!"
-msgstr "Bản đồ vec-tơ <%s> đã có"
+msgstr ""
 #: ../imagery/i.segment/open_files.c:554
 #, c-format
@@ -5119,9 +4688,7 @@
 #: ../imagery/i.segment/mean_shift.c:398
 #, c-format
-msgid ""
-"Mean shift stopped at %d due to reaching max iteration limit, more changes "
-"may be possible"
+msgid "Mean shift stopped at %d due to reaching max iteration limit, more changes may be possible"
 msgstr ""
 #: ../imagery/i.segment/mean_shift.c:400
@@ -5143,14 +4710,12 @@
 msgstr ""
 #: ../imagery/i.segment/main.c:47
-#, fuzzy
 msgid "Error in reading data"
-msgstr "Lỗi khi đọc dữ liệu 'hue' (màu sắc)"
+msgstr ""
 #: ../imagery/i.segment/main.c:51
-#, fuzzy
 msgid "Error in creating segments"
+msgstr ""
 #: ../imagery/i.segment/main.c:55
 #, fuzzy
@@ -5168,14 +4733,13 @@
 msgstr "Lỗi khi đang ghi dữ liệu"
 #: ../imagery/i.segment/main.c:70
-#, fuzzy, c-format
+#, c-format
 msgid "Number of segments created: %d"
-msgstr "Số lượng điểm cần tạo"
+msgstr ""
 #: ../imagery/i.segment/write_output.c:24
-#, fuzzy
 msgid "Writing out segment IDs..."
-msgstr "Đang ghi bản đồ..."
+msgstr ""
 #: ../imagery/i.segment/write_output.c:120
 msgid "Writing out goodness of fit"
@@ -5193,9 +4757,8 @@
 #: ../imagery/i.segment/cluster.c:121 ../raster/r.clump/minsize.c:373
 #: ../raster/r.clump/clump.c:211 ../raster/r.clump/clump.c:475
-#, fuzzy
 msgid "Unable to open temp file"
+msgstr ""
 #: ../imagery/i.segment/cluster.c:135
 msgid "Assigning initial region IDs..."
@@ -5206,16 +4769,14 @@
 #: ../raster/r.clump/clump.c:113 ../raster/r.clump/clump.c:345
 #: ../raster/r.clump/clump.c:359 ../raster/r.clump/clump.c:646
 #: ../raster/r.clump/clump.c:660
-#, fuzzy
 msgid "Unable to write to temp file"
+msgstr ""
 #: ../imagery/i.segment/cluster.c:386 ../raster/r.clump/clump.c:51
 #: ../vector/v.cluster/main.c:404 ../vector/v.cluster/main.c:613
 #: ../vector/v.cluster/main.c:970
-#, fuzzy
 msgid "Generating renumbering scheme..."
-msgstr "Đang tạo các điểm..."
+msgstr ""
 #: ../imagery/i.segment/cluster.c:425
 msgid "Assigning final region IDs..."
@@ -5226,9 +4787,8 @@
 #: ../raster/r.clump/minsize.c:293 ../raster/r.clump/minsize.c:424
 #: ../raster/r.clump/minsize.c:447 ../raster/r.clump/minsize.c:518
 #: ../raster/r.clump/clump.c:97 ../raster/r.clump/clump.c:149
-#, fuzzy
 msgid "Unable to read from temp file"
-msgstr "Không thể đọc tập tin miền"
+msgstr ""
 #: ../imagery/i.segment/cluster.c:455
 #, fuzzy, c-format
@@ -5238,14 +4798,12 @@
 #: ../imagery/i.segment/flag.c:21 ../imagery/i.segment/flag.c:28
 #: ../vector/v.distance/main.c:748 ../vector/v.distance/main.c:825
 #: ../vector/v.distance/main.c:1033
-#, fuzzy
 msgid "Out of memory!"
+msgstr ""
 #: ../imagery/i.segment/watershed.c:19
-#, fuzzy
 msgid "Watershed is not yet implemented"
-msgstr "Lệnh không được thực hiện"
+msgstr ""
 #: ../imagery/i.segment/parse_args.c:30
 msgid "Suffix for output bands with modified band values"
@@ -5265,9 +4823,7 @@
 msgstr "Số khung ảnh"
 #: ../imagery/i.segment/parse_args.c:47
-msgid ""
-"Must be >= 1, only cells within spatial bandwidth are considered for mean "
-"shift"
+msgid "Must be >= 1, only cells within spatial bandwidth are considered for mean shift"
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:53
@@ -5275,24 +4831,20 @@
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:54
-msgid ""
-"Only cells within range (spectral) bandwidth are considered for mean shift. "
-"Range bandwidth is used as conductance parameter for adaptive bandwidth"
+msgid "Only cells within range (spectral) bandwidth are considered for mean shift. Range bandwidth is used as conductance parameter for adaptive bandwidth"
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:67
-#, fuzzy
 msgid "Segmentation method"
-msgstr "Phương pháp gộp"
+msgstr ""
 #: ../imagery/i.segment/parse_args.c:76
 msgid "Similarity calculation method"
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:85
-#, fuzzy
 msgid "Minimum number of cells in a segment"
-msgstr "Số lượng điểm tối đa trong một đoạn"
+msgstr ""
 #: ../imagery/i.segment/parse_args.c:87
 msgid "The final step will merge small segments with their best neighbor"
@@ -5312,32 +4864,26 @@
 #: ../imagery/i.segment/parse_args.c:126 ../imagery/i.cluster/main.c:126
 msgid "Maximum number of iterations"
-msgstr "Số lần chạy lặp tối đa"
+msgstr ""
 #: ../imagery/i.segment/parse_args.c:134
-#, fuzzy
 msgid "Name for input raster map with starting seeds"
+msgstr ""
 #: ../imagery/i.segment/parse_args.c:141
-#, fuzzy
 msgid "Name of input bounding/constraining raster map"
+msgstr ""
 #: ../imagery/i.segment/parse_args.c:143
-msgid ""
-"Must be integer values, each area will be segmented independent of the others"
+msgid "Must be integer values, each area will be segmented independent of the others"
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:150
-#, fuzzy
 msgid "Name for output goodness of fit estimate map"
+msgstr ""
 #: ../imagery/i.segment/parse_args.c:156
-msgid ""
-"Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for "
-"each pixel"
+msgid "Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for each pixel"
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:162
@@ -5357,15 +4903,12 @@
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:175
-msgid ""
-"Spatial bandwidth is increased, range (spectral) bandwidth is decreased in "
-"each iteration"
+msgid "Spatial bandwidth is increased, range (spectral) bandwidth is decreased in each iteration"
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:194
-#, fuzzy
 msgid "Threshold should be > 0 and < 1"
-msgstr "Giá trị ngưỡng phải >=0"
+msgstr ""
 #: ../imagery/i.segment/parse_args.c:200
 #, fuzzy, c-format
@@ -5383,44 +4926,39 @@
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:235
-#, fuzzy
 msgid "Unable to assign segmentation method"
-msgstr "Không thể ghi tập tin phân đoạn cho %s"
+msgstr ""
 #: ../imagery/i.segment/parse_args.c:245
-#, fuzzy
 msgid "Invalid similarity method"
-msgstr "Phương pháp không hợp lệ: %s"
+msgstr ""
 #: ../imagery/i.segment/parse_args.c:251
-#, fuzzy, c-format
+#, c-format
 msgid "Option '%s' must be > 0"
-msgstr "Vị trí <%s> được tạo ra"
+msgstr ""
 #: ../imagery/i.segment/parse_args.c:253 ../imagery/i.segment/parse_args.c:258
-#, fuzzy, c-format
+#, c-format
 msgid "Option '%s' must be <= 1"
+msgstr ""
 #: ../imagery/i.segment/parse_args.c:256
-#, fuzzy, c-format
+#, c-format
 msgid "Option '%s' must be >= 0"
+msgstr ""
 #: ../imagery/i.segment/parse_args.c:284
-#, fuzzy
 msgid "Seeds raster map not found"
-msgstr "Không tìm thấy bản đồ raster"
+msgstr ""
 #: ../imagery/i.segment/parse_args.c:288
-#, fuzzy
 msgid "Seeeds raster map must be CELL type (integers)"
-msgstr "Đang tạo các bản đồ raster %i\n"
+msgstr ""
 #: ../imagery/i.segment/parse_args.c:298
-#, fuzzy
 msgid "Segmentation constraint/boundary raster map not found"
+msgstr ""
 #: ../imagery/i.segment/parse_args.c:302
 msgid "Segmentation constraint raster map must be CELL type (integers)"
@@ -5446,33 +4984,28 @@
 msgstr "Số bước không hợp lệ: %s"
 #: ../imagery/i.segment/parse_args.c:360
-#, fuzzy
 msgid "Invalid number of MB, 300 will be used"
-msgstr "Số bước không hợp lệ: %s"
+msgstr ""
 #: ../imagery/i.vi/main.c:90
-#, fuzzy
 msgid "vegetation index"
-msgstr "Tên của bản đồ raster độ cao"
+msgstr ""
 #: ../imagery/i.vi/main.c:91
-#, fuzzy
 msgid "biophysical parameters"
-msgstr "Tham số làm trơn"
+msgstr ""
 #: ../imagery/i.vi/main.c:93
 msgid "Calculates different types of vegetation indices."
 msgstr ""
 #: ../imagery/i.vi/main.c:94
-msgid ""
-"Uses red and nir bands mostly, and some indices require additional bands."
+msgid "Uses red and nir bands mostly, and some indices require additional bands."
 msgstr ""
 #: ../imagery/i.vi/main.c:101
-#, fuzzy
 msgid "Name of input red channel surface reflectance map"
-msgstr "Tên bản đồ kết quả"
+msgstr ""
 #: ../imagery/i.vi/main.c:102 ../imagery/i.vi/main.c:141
 #: ../imagery/i.vi/main.c:149 ../imagery/i.vi/main.c:157
@@ -5481,48 +5014,40 @@
 msgstr ""
 #: ../imagery/i.vi/main.c:110
-#, fuzzy
 msgid "Type of vegetation index"
+msgstr ""
 #: ../imagery/i.vi/main.c:115
-#, fuzzy
 msgid "Atmospherically Resistant Vegetation Index"
+msgstr ""
 #: ../imagery/i.vi/main.c:116
-#, fuzzy
 msgid "Difference Vegetation Index"
+msgstr ""
 #: ../imagery/i.vi/main.c:117
-#, fuzzy
 msgid "Enhanced Vegetation Index"
+msgstr ""
 #: ../imagery/i.vi/main.c:118
-#, fuzzy
 msgid "Enhanced Vegetation Index 2"
+msgstr ""
 #: ../imagery/i.vi/main.c:119
-#, fuzzy
 msgid "Green Vegetation Index"
+msgstr ""
 #: ../imagery/i.vi/main.c:120
-#, fuzzy
 msgid "Green Atmospherically Resistant Vegetation Index"
+msgstr ""
 #: ../imagery/i.vi/main.c:121
 msgid "Global Environmental Monitoring Index"
 msgstr ""
 #: ../imagery/i.vi/main.c:122
-#, fuzzy
 msgid "Infrared Percentage Vegetation Index"
+msgstr ""
 #: ../imagery/i.vi/main.c:123
 msgid "Modified Soil Adjusted Vegetation Index"
@@ -5533,71 +5058,59 @@
 msgstr ""
 #: ../imagery/i.vi/main.c:125
-#, fuzzy
 msgid "Normalized Difference Vegetation Index"
+msgstr ""
 #: ../imagery/i.vi/main.c:126
-#, fuzzy
 msgid "Perpendicular Vegetation Index"
+msgstr ""
 #: ../imagery/i.vi/main.c:127
-#, fuzzy
 msgid "Soil Adjusted Vegetation Index"
+msgstr ""
 #: ../imagery/i.vi/main.c:128
-#, fuzzy
 msgid "Simple Ratio"
-msgstr "Phép phân loại điểm"
+msgstr ""
 #: ../imagery/i.vi/main.c:129
 msgid "Visible Atmospherically Resistant Index"
 msgstr ""
 #: ../imagery/i.vi/main.c:130
-#, fuzzy
 msgid "Weighted Difference Vegetation Index"
+msgstr ""
 #: ../imagery/i.vi/main.c:134
-#, fuzzy
 msgid "type"
-msgstr "Kiểu cung (arc)"
+msgstr ""
 #: ../imagery/i.vi/main.c:140
-#, fuzzy
 msgid "Name of input nir channel surface reflectance map"
+msgstr ""
 #: ../imagery/i.vi/main.c:142 ../imagery/i.vi/main.c:150
 #: ../imagery/i.vi/main.c:158 ../imagery/i.vi/main.c:166
 #: ../imagery/i.vi/main.c:174 ../vector/v.vol.rst/main.c:254
 #: ../vector/v.vol.rst/main.c:303
-#, fuzzy
 msgid "Optional inputs"
-msgstr "Tên tập tin đầu ra không hợp lệ <%s>"
+msgstr ""
 #: ../imagery/i.vi/main.c:148
-#, fuzzy
 msgid "Name of input green channel surface reflectance map"
+msgstr ""
 #: ../imagery/i.vi/main.c:156
-#, fuzzy
 msgid "Name of input blue channel surface reflectance map"
+msgstr ""
 #: ../imagery/i.vi/main.c:164
-#, fuzzy
 msgid "Name of input 5th channel surface reflectance map"
+msgstr ""
 #: ../imagery/i.vi/main.c:172
-#, fuzzy
 msgid "Name of input 7th channel surface reflectance map"
+msgstr ""
 #: ../imagery/i.vi/main.c:180
 msgid "Value of the slope of the soil line (MSAVI only)"
@@ -5605,9 +5118,8 @@
 #: ../imagery/i.vi/main.c:181 ../imagery/i.vi/main.c:188
 #: ../imagery/i.vi/main.c:195
-#, fuzzy
 msgid "MSAVI settings"
+msgstr ""
 #: ../imagery/i.vi/main.c:187
 msgid "Value of the intercept of the soil line (MSAVI only)"
@@ -5618,20 +5130,17 @@
 msgstr ""
 #: ../imagery/i.vi/main.c:201
-#, fuzzy
 msgid "Maximum bits for digital numbers"
-msgstr "Bán kính lớn nhất dùng cho bản đồ vòng/đường tròn (mét)"
+msgstr ""
 #: ../imagery/i.vi/main.c:202
-msgid ""
-"If data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8 "
-"for Landsat -> [0-255])"
+msgid "If data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8 for Landsat -> [0-255])"
 msgstr ""
 #: ../imagery/i.vi/main.c:225
-#, fuzzy, c-format
+#, c-format
 msgid "Calculating %s..."
+msgstr ""
 #: ../imagery/i.vi/main.c:228
 msgid "sr index requires red and nir maps"
@@ -5662,8 +5171,7 @@
 msgstr ""
 #: ../imagery/i.vi/main.c:251
-msgid ""
-"msavi index requires red and nir maps, and 3 parameters related to soil line"
+msgid "msavi index requires red and nir maps, and 3 parameters related to soil line"
 msgstr ""
 #: ../imagery/i.vi/main.c:254
@@ -5701,95 +5209,80 @@
 #: ../imagery/i.vi/main.c:544 ../raster/r.colors/edit_colors.c:376
 #, c-format
 msgid "Unknown color request '%s'"
-msgstr "Yêu cầu màu không biết '%s'"
+msgstr ""
 #: ../imagery/i.maxlik/open.c:27
 #, c-format
-msgid ""
-"Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
-"have at least 2 raster maps."
+msgid "Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must have at least 2 raster maps."
 msgstr ""
-"Nhóm phụ <%s> của nhóm <%s> không có bản đồ raster nào. Nhóm phụ phải có ít "
-"nhất 2 bản đồ raster."
 #: ../imagery/i.maxlik/open.c:30
 #, c-format
-msgid ""
-"Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at "
-"least 2 raster maps."
+msgid "Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at least 2 raster maps."
 msgstr ""
-"Nhóm phụ <%s> của nhóm <%s> chỉ có 1 bản đồ raster. Nhóm phụ phải có ít nhất "
-"2 bản đồ raster."
 #: ../imagery/i.maxlik/open.c:47
 #, c-format
 msgid "Unable to open signature file <%s>"
-msgstr "Không thể mở tập tin chữ ký <%s>"
+msgstr ""
 #: ../imagery/i.maxlik/open.c:57 ../imagery/i.cluster/open_files.c:64
 #, c-format
 msgid "<%s> has too many signatures (limit is 255)"
-msgstr "<%s> có quá nhiều chữ ký (giới hạn là 255)"
+msgstr ""
 #: ../imagery/i.maxlik/main.c:66
 msgid "Classifies the cell spectral reflectances in imagery data."
-msgstr "Phân loại các hệ số phản xạ phổ của ô trong dữ liệu ảnh."
+msgstr ""
 #: ../imagery/i.maxlik/main.c:68
-#, fuzzy
-msgid ""
-"Classification is based on the spectral signature information generated by "
-"either i.cluster, g.gui.iclass, or i.gensig."
+msgid "Classification is based on the spectral signature information generated by either i.cluster, g.gui.iclass, or i.gensig."
 msgstr ""
-"Phép phân lại dựa trên thông tin chữ ký phổ được tạo ra bởi mô-đun i."
-"cluster, i.class, hoặc i.gensig."
 #: ../imagery/i.maxlik/main.c:82
-#, fuzzy
 msgid "Generated by either i.cluster, g.gui.iclass, or i.gensig"
-msgstr "Được tạo ra bởi i.cluster, i.class, hoặc i.gensig"
+msgstr ""
 #: ../imagery/i.maxlik/main.c:92
-#, fuzzy
 msgid "Name for output raster map holding reject threshold results"
-msgstr "Tên của bản đồ raster chứa các kết quả ngưỡng bi từ chối"
+msgstr ""
 #: ../imagery/i.maxlik/invert.c:28
 #, c-format
 msgid "Signature %d is not valid (ill-conditioned) - ignored"
-msgstr "Chữ ký %d không hợp lệ (đặt đ.kiện kém) - bỏ qua"
+msgstr ""
 #: ../imagery/i.maxlik/invert.c:31
 #, c-format
 msgid "Signature %d is not valid (singular) - ignored"
-msgstr "Chữ ký %d không hợp lệ (số ít) - bỏ qua."
+msgstr ""
 #: ../imagery/i.target/main.c:48
 msgid "Targets an imagery group to a GRASS location and mapset."
-msgstr "Xác định đích một nhóm ảnh vào một vị trí và bộ bản đồ của GRASS."
+msgstr ""
 #: ../imagery/i.target/main.c:57
 msgid "Name of imagery target location"
-msgstr "Tên của vị trí đích cho ảnh"
+msgstr ""
 #: ../imagery/i.target/main.c:63
 msgid "Name of target mapset"
-msgstr "Tên của bộ bản đồ đích"
+msgstr ""
 #: ../imagery/i.target/main.c:68
 msgid "Set current location and mapset as target for imagery group"
-msgstr "Thiết lập vị trí và bộ bản đồ hiện tại làm đích cho nhóm ảnh"
+msgstr ""
 #: ../imagery/i.target/main.c:90 ../imagery/i.target/main.c:107
 #: ../imagery/i.target/main.c:116
 #, c-format
 msgid "Group <%s> targeted for location [%s], mapset [%s]"
-msgstr "Nhóm <%s> được xác định đích vào vị trí <%s>, bộ bản đồ <%s>"
+msgstr ""
 #: ../imagery/i.target/main.c:93
 #, c-format
 msgid "Group <%s> has no target"
-msgstr "Nhóm <%s> không có đích"
+msgstr ""
 #: ../imagery/i.target/main.c:101
 msgid ""
@@ -5797,23 +5290,18 @@
 " OR\n"
 " manually enter the variables"
 msgstr ""
-"Hoặc là bạn phải dùng Cờ Bộ bản đồ và Vị trí Hiện tại (-c)\n"
 HOẶC\n"
-" nhập thủ công các biến vào"
 #: ../imagery/i.modis.qc/main.c:150
 msgid "imagery quality assessment"
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:152
-#, fuzzy
 msgid "land surface temperature"
-msgstr "Tên của bề mặt ngẫu nhiên cần tạo"
+msgstr ""
 #: ../imagery/i.modis.qc/main.c:153
-#, fuzzy
 msgid "vegetation"
-msgstr "Phép chọn"
+msgstr ""
 #: ../imagery/i.modis.qc/main.c:155 ../imagery/i.albedo/main.c:102
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:5
@@ -5821,24 +5309,20 @@
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:157
-#, fuzzy
 msgid "Extracts quality control parameters from MODIS QC layers."
-msgstr "Bản đồ raster địa hình (DEM)"
+msgstr ""
 #: ../imagery/i.modis.qc/main.c:162
-#, fuzzy
 msgid "Name of input surface reflectance QC layer [bit array]"
-msgstr "Tên của lớp raster mặt phân dạng"
+msgstr ""
 #: ../imagery/i.modis.qc/main.c:167
-#, fuzzy
 msgid "Name for output QC type classification layer"
-msgstr "Tên tập tin địa điểm đi chuyển (walker site) đầu ra"
+msgstr ""
 #: ../imagery/i.modis.qc/main.c:173
-#, fuzzy
 msgid "Name of MODIS product type"
-msgstr "Tên của lớp đầu vào"
+msgstr ""
 #: ../imagery/i.modis.qc/main.c:188
 msgid "surf. refl. 250m 8-days"
@@ -5889,18 +5373,16 @@
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:208
-#, fuzzy
 msgid "Name of QC type to extract"
-msgstr "Tên của bản đồ mặt (plane) raster cần tạo."
+msgstr ""
 #: ../imagery/i.modis.qc/main.c:272
 msgid "mod09: Adjacency Correction"
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:273
-#, fuzzy
 msgid "mod09: Atmospheric Correction"
+msgstr ""
 #: ../imagery/i.modis.qc/main.c:274
 msgid "mod09: Cloud State"
@@ -6132,9 +5614,7 @@
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:342
-msgid ""
-"Band number of MODIS product (mod09Q1=[1,2],mod09A1=[1-7],m[o/"
-"y]d09CMG=[1-7], mcd43B2q=[1-7])"
+msgid "Band number of MODIS product (mod09Q1=[1,2],mod09A1=[1-7],m[o/y]d09CMG=[1-7], mcd43B2q=[1-7])"
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:346
@@ -6170,17 +5650,15 @@
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:375
-#, fuzzy
 msgid "Band number out of allowed range [1-2]"
-msgstr "Số gờ nằm ngoài miền"
+msgstr ""
 #: ../imagery/i.modis.qc/main.c:377 ../imagery/i.modis.qc/main.c:379
 #: ../imagery/i.modis.qc/main.c:381 ../imagery/i.modis.qc/main.c:383
 #: ../imagery/i.modis.qc/main.c:385 ../imagery/i.modis.qc/main.c:387
 #: ../imagery/i.modis.qc/main.c:442
-#, fuzzy
 msgid "Band number out of allowed range [1-7]"
+msgstr ""
 #: ../imagery/i.modis.qc/main.c:389
 msgid "mod09Q1 product only has 2 bands"
@@ -6207,114 +5685,92 @@
 msgstr ""
 #: ../imagery/i.evapo.pm/main.c:61
-msgid ""
-"Computes potential evapotranspiration calculation with hourly Penman-"
-"Monteith."
+msgid "Computes potential evapotranspiration calculation with hourly Penman-Monteith."
 msgstr ""
 #: ../imagery/i.evapo.pm/main.c:65
-#, fuzzy
 msgid "Name of input elevation raster map [m a.s.l.]"
-msgstr "Tên của bản đồ raster độ cao đầu vào [mét]"
+msgstr ""
 #: ../imagery/i.evapo.pm/main.c:69
-#, fuzzy
 msgid "Name of input temperature raster map [C]"
-msgstr "Tên của bản đồ raster"
+msgstr ""
 #: ../imagery/i.evapo.pm/main.c:73
-#, fuzzy
 msgid "Name of input relative humidity raster map [%]"
+msgstr ""
 #: ../imagery/i.evapo.pm/main.c:77
-#, fuzzy
 msgid "Name of input wind speed raster map [m/s]"
+msgstr ""
 #: ../imagery/i.evapo.pm/main.c:82
-#, fuzzy
 msgid "Name of input net solar radiation raster map [MJ/m2/h]"
-msgstr "Tên của bản đồ raster độ cao [m]"
+msgstr ""
 #: ../imagery/i.evapo.pm/main.c:86
-#, fuzzy
 msgid "Name of input crop height raster map [m]"
+msgstr ""
 #: ../imagery/i.evapo.pm/main.c:89
-#, fuzzy
 msgid "Name for output raster map [mm/h]"
+msgstr ""
 #: ../imagery/i.evapo.pm/main.c:93
-#, fuzzy
 msgid "Set negative evapotranspiration to zero"
+msgstr ""
 #: ../imagery/i.evapo.pm/main.c:97
 msgid "Use Night-time"
 msgstr ""
 #: ../imagery/i.eb.netrad/main.c:58
-#, fuzzy
 msgid "net radiation"
-msgstr "Tổng quát hoá (%s) ..."
+msgstr ""
 #: ../imagery/i.eb.netrad/main.c:61
 msgid "Net radiation approximation (Bastiaanssen, 1995)."
 msgstr ""
 #: ../imagery/i.eb.netrad/main.c:66 ../imagery/i.eb.soilheatflux/main.c:58
-#, fuzzy
 msgid "Name of albedo raster map [0.0;1.0]"
+msgstr ""
 #: ../imagery/i.eb.netrad/main.c:70 ../imagery/i.eb.soilheatflux/main.c:62
-#, fuzzy
 msgid "Name of NDVI raster map [-1.0;+1.0]"
+msgstr ""
 #: ../imagery/i.eb.netrad/main.c:75
-#, fuzzy
 msgid "Name of surface temperature raster map [K]"
+msgstr ""
 #: ../imagery/i.eb.netrad/main.c:80 ../imagery/i.eb.soilheatflux/main.c:76
-#, fuzzy
 msgid "Name of time of satellite overpass raster map [local time in UTC]"
-msgstr "Tên của bản đồ raster độ sâu nước [m]"
+msgstr ""
 #: ../imagery/i.eb.netrad/main.c:85
-msgid ""
-"Name of the difference map of temperature from surface skin to about 2 m "
-"height [K]"
+msgid "Name of the difference map of temperature from surface skin to about 2 m height [K]"
 msgstr ""
 #: ../imagery/i.eb.netrad/main.c:89
-#, fuzzy
 msgid "Name of the emissivity map [-]"
+msgstr ""
 #: ../imagery/i.eb.netrad/main.c:94
-#, fuzzy
 msgid "Name of the single-way atmospheric transmissivitymap [-]"
+msgstr ""
 #: ../imagery/i.eb.netrad/main.c:98
-#, fuzzy
 msgid "Name of the Day Of Year (DOY) map [-]"
+msgstr ""
 #: ../imagery/i.eb.netrad/main.c:102
-#, fuzzy
 msgid "Name of the sun zenith angle map [degrees]"
-msgstr "Tên của bản đồ raster đầu vào chứa vĩ độ [độ thập phân]"
+msgstr ""
 #: ../imagery/i.eb.netrad/main.c:105
-#, fuzzy
 msgid "Name of the output net radiation layer"
+msgstr ""
 #: ../imagery/i.emissivity/main.c:45
 msgid "emissivity"
@@ -6329,28 +5785,24 @@
 msgstr ""
 #: ../imagery/i.emissivity/main.c:53
-#, fuzzy
 msgid "Name of the NDVI map [-]"
+msgstr ""
 #: ../imagery/i.emissivity/main.c:56
-#, fuzzy
 msgid "Name of the output emissivity layer"
+msgstr ""
 #: ../imagery/i.albedo/main.c:96
-#, fuzzy
 msgid "albedo"
-msgstr "thất bại"
+msgstr ""
 #: ../imagery/i.albedo/main.c:101
 msgid "AVHRR"
 msgstr ""
 #: ../imagery/i.albedo/main.c:103
-#, fuzzy
 msgid "Computes broad band albedo from surface reflectance."
+msgstr ""
 #: ../imagery/i.albedo/main.c:116
 msgid "MODIS (7 input bands:1,2,3,4,5,6,7)"
@@ -6377,9 +5829,7 @@
 msgstr ""
 #: ../imagery/i.albedo/main.c:138 ../imagery/i.albedo/main.c:145
-msgid ""
-"Albedo dry run to calculate some water to beach/sand/desert stretching, a "
-"kind of simple atmospheric correction"
+msgid "Albedo dry run to calculate some water to beach/sand/desert stretching, a kind of simple atmospheric correction"
 msgstr ""
 #: ../imagery/i.albedo/main.c:143
@@ -6387,15 +5837,12 @@
 msgstr ""
 #: ../imagery/i.albedo/main.c:181
-#, fuzzy
 msgid "At least two raster maps are required"
-msgstr "Tiêu đề của tập tin raster đầu ra"
+msgstr ""
 #: ../imagery/i.landsat.acca/main.c:70
 #, c-format
-msgid ""
-"Input raster map <%s> is not floating point (process DN using i.landsat.toar "
-"to radiance first)"
+msgid "Input raster map <%s> is not floating point (process DN using i.landsat.toar to radiance first)"
 msgstr ""
 #: ../imagery/i.landsat.acca/main.c:104
@@ -6403,9 +5850,8 @@
 msgstr ""
 #: ../imagery/i.landsat.acca/main.c:107
-#, fuzzy
 msgid "cloud detection"
-msgstr "Tùy_chọn_Đầu_ra"
+msgstr ""
 #: ../imagery/i.landsat.acca/main.c:121
 msgid "B56composite (step 6)"
@@ -6416,15 +5862,13 @@
 msgstr ""
 #: ../imagery/i.landsat.acca/main.c:136
-#, fuzzy
 msgid "Number of classes in the cloud temperature histogram"
-msgstr "Số nhóm giá trị cho chủ đề (số nguyên)"
+msgstr ""
 #: ../imagery/i.landsat.acca/main.c:138 ../imagery/i.landsat.acca/main.c:153
 #: ../imagery/i.landsat.acca/main.c:159 ../imagery/i.landsat.acca/main.c:164
-#, fuzzy
 msgid "Cloud settings"
+msgstr ""
 #: ../imagery/i.landsat.acca/main.c:142
 msgid "Data is Landsat-5 TM"
@@ -6443,8 +5887,7 @@
 msgstr ""
 #: ../imagery/i.landsat.acca/main.c:158
-msgid ""
-"Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
+msgid "Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
 msgstr ""
 #: ../imagery/i.landsat.acca/main.c:163
@@ -6452,9 +5895,8 @@
 msgstr ""
 #: ../imagery/i.landsat.acca/algorithm.c:124
-#, fuzzy
 msgid "Preliminary scene analysis:"
-msgstr "Các tính toán bề mặt sơ bộ..."
+msgstr ""
 #: ../imagery/i.landsat.acca/algorithm.c:125
 #, c-format
@@ -6500,9 +5942,9 @@
 msgstr ""
 #: ../imagery/i.landsat.acca/algorithm.c:149
-#, fuzzy, c-format
+#, c-format
 msgid "* Standard deviation: %.2lf"
-msgstr "Độ lệch chuẩn"
+msgstr ""
 #: ../imagery/i.landsat.acca/algorithm.c:150
 #, c-format
@@ -6530,9 +5972,8 @@
 msgstr ""
 #: ../imagery/i.landsat.acca/algorithm.c:186
-#, fuzzy
 msgid "Maximum temperature:"
+msgstr ""
 #: ../imagery/i.landsat.acca/algorithm.c:187
 #, c-format
@@ -6553,24 +5994,20 @@
 msgstr ""
 #: ../imagery/i.landsat.acca/algorithm.c:237
-#, fuzzy
 msgid "Processing first pass..."
+msgstr ""
 #: ../imagery/i.landsat.acca/algorithm.c:391
-#, fuzzy
 msgid "Removing ambiguous pixels..."
-msgstr "Loại bỏ các đối tượng lặp..."
+msgstr ""
 #: ../imagery/i.landsat.acca/algorithm.c:393
-#, fuzzy
 msgid "Pass two processing..."
-msgstr "Đang xử lý..."
+msgstr ""
 #: ../imagery/i.landsat.acca/tools.c:138
-#, fuzzy
 msgid "Filling small holes in clouds..."
-msgstr "Đang lấp các chỗ trũng..."
+msgstr ""
 #: ../imagery/i.eb.eta/main.c:44
 msgid "actual evapotranspiration"
@@ -6581,228 +6018,204 @@
 msgstr ""
 #: ../imagery/i.eb.eta/main.c:52
-#, fuzzy
 msgid "Name of the diurnal net radiation map [W/m2]"
+msgstr ""
 #: ../imagery/i.eb.eta/main.c:57
-#, fuzzy
 msgid "Name of the evaporative fraction map [-]"
+msgstr ""
 #: ../imagery/i.eb.eta/main.c:62
-#, fuzzy
 msgid "Name of the surface skin temperature [K]"
+msgstr ""
 #: ../imagery/i.eb.eta/main.c:67
-#, fuzzy
 msgid "Name of the output actual evapotranspiration layer [mm/d]"
+msgstr ""
 #: ../imagery/i.cluster/print5.c:15
-#, fuzzy, c-format
+#, c-format
 msgid "%sclass separability matrix%s%s"
 msgstr ""
-"\n"
-"ma trận tách biệt lớp\n"
\n"
 #: ../imagery/i.cluster/print3.c:16
-#, fuzzy, c-format
+#, c-format
 msgid "%sinitial means for each band%s%s"
 msgstr ""
-"\n"
-"các trị tr.bình khởi tạo cho từng băng\n"
-"\n"
 #: ../imagery/i.cluster/print3.c:20
 #, c-format
 msgid "class %-3d "
-msgstr "lớp %-3d"
+msgstr ""
 #: ../imagery/i.cluster/open_files.c:24
 #, c-format
 msgid "Raster map <%s> do not exists in subgroup <%s>"
-msgstr "Bản đồ raster <%s> không có trong nhóm phụ <%s>"
+msgstr ""
 #: ../imagery/i.cluster/open_files.c:29
 msgid "No raster maps found"
-msgstr "Không tìm thấy các bản đồ raster"
+msgstr ""
 #: ../imagery/i.cluster/open_files.c:33
 #, c-format
 msgid "Subgroup <%s> doesn't have any raster maps"
+msgstr ""
 #: ../imagery/i.cluster/open_files.c:36
 #, c-format
 msgid "Subgroup <%s> only has 1 raster map"
-msgstr "Nhóm phụ <%s> chỉ có 1 bản đồ raster"
+msgstr ""
 #: ../imagery/i.cluster/open_files.c:37
 msgid "Subgroup must have at least 2 raster maps"
-msgstr "Nhóm phụ phải có ít nhất 2 bản đồ raster"
+msgstr ""
 #: ../imagery/i.cluster/open_files.c:54
 #, c-format
 msgid "Unable to open seed signature file <%s>"
-msgstr "Không thể mở tập tin chữ ký gieo hạt <%s>"
+msgstr ""
 #: ../imagery/i.cluster/checkpt.c:16
-#, fuzzy, c-format
+#, c-format
 msgid "using seed means (%d files)%s"
-msgstr "dùng các trị tr.bình gieo hạt (%d tập tin)\n"
+msgstr ""
 #: ../imagery/i.cluster/checkpt.c:29
-#, fuzzy, c-format
+#, c-format
 msgid "%s######## iteration %d ###########%s"
 msgstr ""
-"\n"
-"######## lần lặp %d ###########\n"
 #: ../imagery/i.cluster/checkpt.c:31
-#, fuzzy, c-format
+#, c-format
 msgid "%d classes, %.2f%% points stable%s"
-msgstr "%d lớp, %.2f%% điểm ổn định\n"
+msgstr ""
 #: ../imagery/i.cluster/checkpt.c:42
 #, c-format
 msgid "Iteration %.2d: convergence %.2f%% (%s elapsed, %s left)"
-msgstr "Lần lặp %d: %% Hội tụ: %.2f (%s đã chạy, %s còn lại)"
+msgstr ""
 #: ../imagery/i.cluster/print4.c:16
-#, fuzzy, c-format
+#, c-format
 msgid "class centroids (sum/count=mean)%s"
-msgstr "các trọng tâm của lớp (tổng/đếm=tr.bình)\n"
+msgstr ""
 #: ../imagery/i.cluster/print4.c:18
 #, c-format
 msgid "band %d"
-msgstr "băng %d"
+msgstr ""
 #: ../imagery/i.cluster/print1.c:12
-#, fuzzy, c-format
+#, c-format
 msgid "means and standard deviations for %d band%s%s%s"
 msgstr ""
-"các trị tr.bình và độ lệch chuẩn cho %d băng%s\n"
-"\n"
 #: ../imagery/i.cluster/print1.c:14
 #, c-format
 msgid " means  "
-msgstr " trị tr.bình  "
+msgstr ""
 #: ../imagery/i.cluster/print1.c:18
 #, c-format
 msgid " stddev "
-msgstr "độ lệch chuẩn"
+msgstr ""
 #: ../imagery/i.cluster/main.c:79
-msgid ""
-"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm."
+msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
 msgstr ""
-"Tạo các chữ ký phổ dùng cho các kiểu lớp lớp mặt đất trong một ảnh có dùng "
-"một thuật toán gộp nhóm."
 #: ../imagery/i.cluster/main.c:82
-msgid ""
-"The resulting signature file is used as input for i.maxlik, to generate an "
-"unsupervised image classification."
+msgid "The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
 msgstr ""
-"Tập tin chữ ký tạo thành được sử dụng làm đầu vào cho i.maxlik, để thực hiện "
-"phép phân loại ảnh không có hướng dẫn."
 #: ../imagery/i.cluster/main.c:102
 msgid "Initial number of classes"
-msgstr "Số nhóm khởi tạo"
+msgstr ""
 #: ../imagery/i.cluster/main.c:111
 msgid "Name of file containing initial signatures"
-msgstr "Tên tập tin chứa các chữ ký khởi tạo"
+msgstr ""
 #: ../imagery/i.cluster/main.c:119
 msgid "Sampling intervals (by row and col); default: ~10,000 pixels"
-msgstr "Khoảng thu mẫu (theo hàng và cột); mặc định: ~10,000 điểm ảnh"
+msgstr ""
 #: ../imagery/i.cluster/main.c:135
 msgid "Percent convergence"
-msgstr "Phần trăm hội tụ"
+msgstr ""
 #: ../imagery/i.cluster/main.c:143
 msgid "Cluster separation"
-msgstr "Sự phân biệt nhóm"
+msgstr ""
 #: ../imagery/i.cluster/main.c:151
 msgid "Minimum number of pixels in a class"
-msgstr "Số điểm ảnh tối thiểu trong một lớp"
+msgstr ""
 #: ../imagery/i.cluster/main.c:158
 msgid "Name for output file containing final report"
-msgstr "Tên tập tin đầu ra chứa báo cáo cuối cùng"
+msgstr ""
 #: ../imagery/i.cluster/main.c:192
 #, c-format
 msgid "Illegal number of initial classes (%s)"
-msgstr "Số nhóm khởi tạo không hợp lệ (%s)"
+msgstr ""
 #: ../imagery/i.cluster/main.c:203
 #, c-format
 msgid "Illegal value(s) of sample intervals (%s)"
-msgstr "(Các) giá trị của các khoảng thu mẫu không hợp lệ (%s)"
+msgstr ""
 #: ../imagery/i.cluster/main.c:217
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal value of iterations (%s)"
-msgstr "Giá trị các lần lặp không hợp lệ (%s)"
+msgstr ""
 #: ../imagery/i.cluster/main.c:223
 #, c-format
 msgid "Illegal value of convergence (%s)"
-msgstr "Giá trị hội tụ không hợp lệ (%s)"
+msgstr ""
 #: ../imagery/i.cluster/main.c:228
 #, c-format
 msgid "Illegal value of separation (%s)"
-msgstr "Giá trị tách không hợp lệ (%s)"
+msgstr ""
 #: ../imagery/i.cluster/main.c:233
 #, c-format
 msgid "Illegal value of min_size (%s)"
-msgstr "Giá trị min_size không hợp lệ (%s)"
+msgstr ""
 #: ../imagery/i.cluster/main.c:242
 #, c-format
 msgid "Unable to create report file <%s>"
-msgstr "Không thể tạo tập tin báo cáo <%s>"
+msgstr ""
 #: ../imagery/i.cluster/main.c:250
-#, fuzzy, c-format
+#, c-format
 msgid "#################### CLUSTER (%s) ####################%s%s"
 msgstr ""
-"#################### GỘP NHÓM (%s) ###################\n"
-"\n"
 #: ../imagery/i.cluster/main.c:252
-#, fuzzy, c-format
+#, c-format
 msgid "Location: %s%s"
+msgstr ""
 #: ../imagery/i.cluster/main.c:253
-#, fuzzy, c-format
+#, c-format
 msgid "Mapset:   %s%s"
+msgstr ""
 #: ../imagery/i.cluster/main.c:254
-#, fuzzy, c-format
+#, c-format
 msgid "Group:    %s%s"
-msgstr "Nhóm:    %s\n"
+msgstr ""
 #: ../imagery/i.cluster/main.c:255
-#, fuzzy, c-format
+#, c-format
 msgid "Subgroup: %s%s"
-msgstr "Nhóm phụ: %s\n"
+msgstr ""
 #: ../imagery/i.cluster/main.c:257
 #, c-format
@@ -6810,226 +6223,203 @@
 msgstr ""
 #: ../imagery/i.cluster/main.c:260
-#, fuzzy, c-format
+#, c-format
 msgid "Result signature file: %s%s"
-msgstr "Tập tin chữ ký kết quả: %s\n"
+msgstr ""
 #: ../imagery/i.cluster/main.c:262
-#, fuzzy, c-format
+#, c-format
 msgid "Region%s"
-msgstr "Vùng\n"
+msgstr ""
 #: ../imagery/i.cluster/main.c:263
-#, fuzzy, c-format
+#, c-format
 msgid "  North: %12.2f  East: %12.2f%s"
-msgstr "  Bắc: %12.2f  Đông: %12.2f\n"
+msgstr ""
 #: ../imagery/i.cluster/main.c:265
-#, fuzzy, c-format
+#, c-format
 msgid "  South: %12.2f  West: %12.2f%s"
-msgstr "  Nam: %12.2f  Tây: %12.2f\n"
+msgstr ""
 #: ../imagery/i.cluster/main.c:267
-#, fuzzy, c-format
+#, c-format
 msgid "  Res:   %12.2f  Res:  %12.2f%s"
-msgstr "  Độ ph.giải:   %12.2f  Độ ph.giải:  %12.2f\n"
+msgstr ""
 #: ../imagery/i.cluster/main.c:269
-#, fuzzy, c-format
+#, c-format
 msgid "  Rows:  %12d  Cols: %12d  Cells: %d%s"
-msgstr "  Hàng:  %12d  Cột: %12d  ô: %d\n"
+msgstr ""
 #: ../imagery/i.cluster/main.c:271
-#, fuzzy, c-format
+#, c-format
 msgid "Mask: %s%s"
-msgstr "Mặt nạ: %s\n"
+msgstr ""
 #: ../imagery/i.cluster/main.c:273
-#, fuzzy, c-format
+#, c-format
 msgid "Cluster parameters%s"
-msgstr "Các tham số gộp nhóm\n"
+msgstr ""
 #: ../imagery/i.cluster/main.c:274
 #, c-format
 msgid " Number of initial classes:    %d"
-msgstr " Số lớp khởi tạo:    %d"
+msgstr ""
 #: ../imagery/i.cluster/main.c:276
 #, c-format
 msgid " [from signature file %s]"
-msgstr " [từ tập tin chữ ký %s]"
+msgstr ""
 #: ../imagery/i.cluster/main.c:278
-#, fuzzy, c-format
+#, c-format
 msgid " Minimum class size:           %d%s"
-msgstr "K.thước lớp nhỏ nhất:           %d\n"
+msgstr ""
 #: ../imagery/i.cluster/main.c:279
-#, fuzzy, c-format
+#, c-format
 msgid " Minimum class separation:     %f%s"
-msgstr "Sự phân tách lớp nhỏ nhất:     %f\n"
+msgstr ""
 #: ../imagery/i.cluster/main.c:280
-#, fuzzy, c-format
+#, c-format
 msgid " Percent convergence:          %f%s"
-msgstr "Phần trăm hội tụ:          %f\n"
+msgstr ""
 #: ../imagery/i.cluster/main.c:281
-#, fuzzy, c-format
+#, c-format
 msgid " Maximum number of iterations: %d%s"
-msgstr "Số lần lặp lớn nhất: %d\n"
+msgstr ""
 #: ../imagery/i.cluster/main.c:283
-#, fuzzy, c-format
+#, c-format
 msgid " Row sampling interval:        %d%s"
-msgstr "Khoảng thu mẫu theo hàng:        %d\n"
+msgstr ""
 #: ../imagery/i.cluster/main.c:284
-#, fuzzy, c-format
+#, c-format
 msgid " Col sampling interval:        %d%s"
-msgstr "Khoảng thu mẫu theo cột:        %d\n"
+msgstr ""
 #: ../imagery/i.cluster/main.c:303
 msgid "Out of Memory. Please run again and choose a smaller sample size."
-msgstr "Hết bộ nhớ. Vui lòng chạy lại và chọn kích thước mẫu nhỏ hơn."
+msgstr ""
 #: ../imagery/i.cluster/main.c:309
-#, fuzzy, c-format
+#, c-format
 msgid "Sample size: %d points%s"
-msgstr "K.thước mẫu: %d điểm\n"
+msgstr ""
 #: ../imagery/i.cluster/main.c:312
-msgid ""
-"Not enough sample points. Please run again and choose a larger sample size."
-msgstr "Không đủ điểm mẫu. Vui lòng chạy lại và chọn k.thước mẫu lớn hơn."
+msgid "Not enough sample points. Please run again and choose a larger sample size."
+msgstr ""
 #: ../imagery/i.cluster/main.c:316
-msgid ""
-"Not enough non-zero sample data points. Check your current region (and mask)."
+msgid "Not enough non-zero sample data points. Check your current region (and mask)."
 msgstr ""
-"Không đủ các điểm dữ liệu khác 0. Kiểm tra vùng hiện tại (và cả mặt nạ)."
 #: ../imagery/i.cluster/main.c:329
-#, fuzzy, c-format
+#, c-format
 msgid "%s########## final results #############%s"
 msgstr ""
-"\n"
-"########## kết quả sau cùng ############\n"
 #: ../imagery/i.cluster/main.c:330
-#, fuzzy, c-format
+#, c-format
 msgid "%d classes (convergence=%.1f%%)%s"
-msgstr "%d nhóm (hội tụ=%.1f%%)\n"
+msgstr ""
 #: ../imagery/i.cluster/main.c:341
 #, c-format
 msgid "Unable to create signature file <%s> for group <%s>, subsgroup <%s>"
-msgstr "Không thể tạo tập tin chữ ký <%s> cho nhóm <%s>, nhóm phụ <%s>"
+msgstr ""
 #: ../imagery/i.cluster/main.c:346
-#, fuzzy, c-format
+#, c-format
 msgid "%s%s#################### CLASSES ####################%s"
 msgstr ""
-"\n"
-"\n"
-"#################### CÁC LỚP####################\n"
 #: ../imagery/i.cluster/main.c:348
-#, fuzzy, c-format
+#, c-format
 msgid "%s%d classes, %.2f%% points stable%s"
+msgstr ""
 #: ../imagery/i.cluster/main.c:350
-#, fuzzy, c-format
+#, c-format
 msgid "%s######## CLUSTER END (%s) ########%s"
 msgstr ""
-"\n"
-"######## KẾT THÚC GỘP NHÓM (%s) ########\n"
 #: ../imagery/i.cluster/main.c:354 ../misc/m.nviz.image/main.c:242
 #, c-format
 msgid "File <%s> created."
-msgstr "Tập tin <%s> được tạo ra!"
+msgstr ""
 #: ../imagery/i.cluster/print2.c:18
-#, fuzzy, c-format
+#, c-format
 msgid "%sclass means/stddev for each band%s%s"
 msgstr ""
-"\n"
-"trị tr.bình nhóm/độ lệch chuẩn cho từng băng\n"
-"\n"
 #: ../imagery/i.cluster/print2.c:23
-#, fuzzy, c-format
+#, c-format
 msgid "class %d (%d)%s"
-msgstr "lớp %d (%d)\n"
+msgstr ""
 #: ../imagery/i.cluster/print2.c:24
 #, c-format
 msgid "  means "
-msgstr "trị tr.bình"
+msgstr ""
 #: ../imagery/i.cluster/print2.c:29
 #, c-format
 msgid "  stddev"
+msgstr ""
 #: ../imagery/i.cluster/print6.c:11
 #, c-format
 msgid "class distribution"
-msgstr "phân bố lớp"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:48
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:89
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:64
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:57
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:389
-#, fuzzy
 msgid "orthorectify"
-msgstr "ảnh, nắn chỉnh"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:50
-msgid ""
-"Interactively creates or modifies entries in a camera initial exposure "
-"station file for imagery group referenced by a sub-block."
+msgid "Interactively creates or modifies entries in a camera initial exposure station file for imagery group referenced by a sub-block."
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:57
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:70
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:64
-#, fuzzy
 msgid "Name of imagery group for ortho-rectification"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:62
-#, fuzzy
 msgid "Initial Camera Exposure X-coordinate"
-msgstr "Một hoặc nhiều tọa độ"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:67
-#, fuzzy
 msgid "Initial Camera Exposure Y-coordinate"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:72
-#, fuzzy
 msgid "Initial Camera Exposure Z-coordinate"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:77
-#, fuzzy
 msgid "X-coordinate standard deviation"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:82
-#, fuzzy
 msgid "Y-coordinate standard deviation"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:87
-#, fuzzy
 msgid "Z-coordinate standard deviation"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:92
 msgid "Initial Camera Omega (roll) degrees"
@@ -7044,33 +6434,29 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:107
-#, fuzzy
 msgid "Omega (roll) standard deviation"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:112
-#, fuzzy
 msgid "Phi (pitch) standard deviation"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:117
-#, fuzzy
 msgid "Kappa (yaw) standard deviation"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:121
 msgid "Use initial values at run time"
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:125
-#, fuzzy
 msgid "Print initial values"
-msgstr "Đang sao chép bảng..."
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:137
-#, fuzzy, c-format
+#, c-format
 msgid "Group [%s] not found"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:150
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:154
@@ -7084,98 +6470,88 @@
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:186
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:190
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:194
-#, fuzzy, c-format
+#, c-format
 msgid "Option '%s' is required for new exposure info"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:80
-#, fuzzy, c-format
+#, c-format
 msgid "No elevation available at row = %d, col = %d"
-msgstr "Việc chuyển đổi dữ liệu thất bại tại hàng %d, cột %d"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/angle.c:36
-#, fuzzy
 msgid "Calculating camera angle to local surface..."
-msgstr "Đang tính các số đo độ trung tâm..."
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/angle.c:50
 #: ../imagery/i.ortho.photo/i.ortho.rectify/exec.c:43
-#, fuzzy
 msgid "Could not open elevation raster"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/angle.c:66
 #, c-format
 msgid "Converting units to meters, factor=%.6f"
-msgstr "Đang chuyển đổi đơn vị thành mét, hệ số=%.6f"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:13
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Control Z Point file for group [%s] in [%s] \n"
 " \n"
-msgstr "Tập tin điểm khống chế dùng cho nhóm <%s@%s> - "
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:16
-#, fuzzy
 msgid "Computing equations..."
-msgstr "Đang các điểm phân vị"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:22
-#, fuzzy
 msgid "Poorly placed Control Points!\n"
-msgstr "Các điểm khống chế có tọa độ không tốt"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:23
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:28
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:52
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:58
-#, fuzzy
 msgid "Can not generate the transformation equation.\n"
-msgstr "Không thể tạo phương trình chuyển đổi."
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:24
 msgid "Run OPTION 7 of i.ortho.photo again!\n"
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:27
-#, fuzzy
 msgid "No active Control Points!\n"
-msgstr "Không có các điểm khống chế được kích hoạt"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:29
 msgid "Run OPTION 7 of i.ortho.photo!\n"
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:45
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Reference Point file for group [%s] in [%s] \n"
 " \n"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:51
-#, fuzzy
 msgid "Poorly placed Reference Points!\n"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:53
 msgid "Run OPTION 5 of i.ortho.photo again!\n"
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:57
-#, fuzzy
 msgid "No active Reference Points!\n"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:59
 msgid "Run OPTION 5 of i.ortho.photo!\n"
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:91
-msgid ""
-"Orthorectifies an image by using the image to photo coordinate "
-"transformation matrix."
+msgid "Orthorectifies an image by using the image to photo coordinate transformation matrix."
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:132
@@ -7183,9 +6559,9 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:184
-#, fuzzy, c-format
+#, c-format
 msgid "Could not read REF file for group <%s>"
-msgstr "Không thể đọc tập tin REF của nhóm phụ <%s> trong nhóm <%s>"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:241
 #, c-format
@@ -7193,14 +6569,14 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:245
-#, fuzzy, c-format
+#, c-format
 msgid "Bad format in camera file for group <%s>"
-msgstr "Không thể tạo thống kê của tập tin cấu hình %s"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:251
-#, fuzzy, c-format
+#, c-format
 msgid "Bad format in initial exposure station file for group <%s>"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:327
 #, c-format
@@ -7209,38 +6585,34 @@
 #: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:142
 #: ../raster/r.proj/readcell.c:141
-#, fuzzy
 msgid "Error reading segment file"
-msgstr "Lỗi ghi tập tin phân đoạn (segment)"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:66
 msgid "Select or modify the target elevation model."
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:75
-#, fuzzy
 msgid "Name of elevation map to use for ortho-rectification"
-msgstr "Tên bản đồ raster dùng làm mặt nạ"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:80
-#, fuzzy
 msgid "List available raster maps in target mapset and exit"
-msgstr "Liệt kê các lớp hiện có trong nguồn dữ liệu và thoát"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:85
-#, fuzzy
 msgid "Print currently selected elevation map and exit"
-msgstr "In ra các tham số kết nối hiện hành và thoát"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:108
-#, fuzzy, c-format
+#, c-format
 msgid "Please select a target for group [%s] first"
-msgstr "Vui lòng chạy i.target cho nhóm."
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:114
-#, fuzzy, c-format
+#, c-format
 msgid "Target location [%s] not found\n"
-msgstr "Không tìm thấy vị trí đích <%s>"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:147
 #, c-format
@@ -7248,62 +6620,55 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:162
-#, fuzzy, c-format
+#, c-format
 msgid "Elevation for group <%s> is already set to <%s>"
-msgstr "<%s> đã có trong bộ bản đồ <%s>"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:175
-#, fuzzy, c-format
+#, c-format
 msgid "Mapset [%s] in target location [%s] - %s "
-msgstr "Bộ bản đồ <%s> trong vị trí đích <%s> - "
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:177
-#, fuzzy
 msgid "permission denied\n"
-msgstr "quyền bị từ chối"
+msgstr ""
-#, fuzzy
 msgid "not found\n"
-msgstr "không tìm thấy"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:59
 msgid "Select and modify the imagery group camera reference file."
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:71
-#, fuzzy
 msgid "Name of camera reference file"
-msgstr "Tên của bảng hệ tham chiếu"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:77
-#, fuzzy
 msgid "Camera name"
-msgstr "Tên_người_dùng"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:83
 msgid "Camera id"
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:89
-#, fuzzy
 msgid "Calibrated focal length"
-msgstr "Chỉ vẽ thước tỷ lệ"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:94
-#, fuzzy
 msgid "Principal point coordinates"
-msgstr "Tọa độ điểm 'gieo'"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:100
-#, fuzzy
 msgid "Fiducial coordinates"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:129
-#, fuzzy, c-format
+#, c-format
 msgid "Can not read camera file '%s'"
-msgstr "Không thể mở tập tin lọc '%s'"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:132
 #, c-format
@@ -7322,8 +6687,7 @@
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:153
 #, c-format
-msgid ""
-"Replacing coordinates of principal point '%.17g, %.17g' with '%.17g, %.17g'"
+msgid "Replacing coordinates of principal point '%.17g, %.17g' with '%.17g, %.17g'"
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:164
@@ -7343,51 +6707,48 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:190
-#, fuzzy
 msgid "Too many fiducials!"
-msgstr "Quá nhiều phạm trù"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:212
-#, fuzzy, c-format
+#, c-format
 msgid "No group '%s' in current mapset"
-msgstr "Nhóm phải có trong bộ bản đồ hiện tại"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:217
-#, fuzzy, c-format
+#, c-format
 msgid "Group [%s] in location [%s] mapset [%s] now uses camera file [%s]"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:93
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:136
 #: ../misc/m.transform/main.c:96
-#, fuzzy, c-format
+#, c-format
 msgid "Error conducting transform (%d)"
-msgstr "Lỗi tạo phép chuyển đổi"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:251
-#, fuzzy
 msgid "Poorly placed image to photo control points"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:253
-#, fuzzy
 msgid "Poorly placed image to target control points"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:255
 #: ../misc/m.transform/main.c:196
 msgid "Insufficient memory"
-msgstr "Không đủ bộ nhớ"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:257
 #: ../misc/m.transform/main.c:198
 msgid "Parameter error"
-msgstr "Lỗi tham số"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:259
 #: ../misc/m.transform/main.c:200
 msgid "No active control points"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:348
 #: ../raster/r.in.lidar/main.c:644 ../raster/r.profile/main.c:175
@@ -7400,13 +6761,13 @@
 #: ../vector/v.net/main.c:100 ../vector/v.out.vtk/main.c:173
 #, c-format
 msgid "Unable to open file <%s>"
-msgstr "Không thể mở tập tin <%s>"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:367
 #: ../misc/m.transform/main.c:295
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid coordinates: [%s]"
-msgstr "Các tọa độ không hợp lệ %s %s"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:391
 msgid "GCP"
@@ -7415,37 +6776,32 @@
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:393
 #: ../misc/m.transform/main.c:320
 msgid "Computes a coordinate transformation based on the control points."
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:406
 #: ../misc/m.transform/main.c:340
-#, fuzzy
 msgid "point index"
-msgstr "trình bày chỉ mục"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:407
 #: ../misc/m.transform/main.c:341
-#, fuzzy
 msgid "source coordinates"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:408
 #: ../misc/m.transform/main.c:342
-#, fuzzy
 msgid "destination coordinates"
-msgstr "Các tọa độ lưới Đ của bản đồ"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:409
 #: ../misc/m.transform/main.c:343
-#, fuzzy
 msgid "forward coordinates (destination)"
-msgstr "Các tọa độ lộ trình (đông,bắc)"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:410
 #: ../misc/m.transform/main.c:344
-#, fuzzy
 msgid "reverse coordinates (source)"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:411
 #: ../misc/m.transform/main.c:345
@@ -7454,15 +6810,13 @@
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:412
 #: ../misc/m.transform/main.c:346
-#, fuzzy
 msgid "reverse coordinates difference (source)"
-msgstr "Tọa độ của tâm (đông, bắc)"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:413
 #: ../misc/m.transform/main.c:347
-#, fuzzy
 msgid "forward error (destination)"
-msgstr "raster, độ cao"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:414
 #: ../misc/m.transform/main.c:348
@@ -7472,54 +6826,47 @@
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:417
 #: ../misc/m.transform/main.c:351 ../vector/v.out.ascii/args.c:55
 msgid "Output format"
-msgstr "Định dạng đầu ra"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:421
 #: ../misc/m.transform/main.c:355
 msgid "Display summary information"
-msgstr "Trình bày thông tin tóm tắt"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:427
 #: ../misc/m.transform/main.c:360
-#, fuzzy
 msgid "File containing coordinates to transform (\"-\" to read from stdin)"
 msgstr ""
-"Tập tin chứa các quy tắc nhãn phạm trù (hoặc dùng \"-\" để đọc từ đầu vào "
-"tiêu chuẩn)"
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:428
 #: ../misc/m.transform/main.c:361
-#, fuzzy
 msgid "Local x,y coordinates to target east,north"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:432
 #: ../misc/m.transform/main.c:365
-#, fuzzy
 msgid "Reverse transform of coords file or coeff. dump"
-msgstr "Chuyển đổi ngược; các đối tượng vec-tơ 3D thành 2D"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:433
 #: ../misc/m.transform/main.c:366
-#, fuzzy
 msgid "Target east,north coordinates to local x,y"
-msgstr "Tọa độ easting và northing cho góc dưới trái của bản đồ"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:437
 #: ../misc/m.transform/main.c:370
-#, fuzzy
 msgid "Display transform matrix coefficients"
-msgstr "Bản đồ dùng làm hệ số x"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:452
-#, fuzzy, c-format
+#, c-format
 msgid "Can not read reference points for group <%s>"
-msgstr "Không thể đọc tập tin header của <%s@%s>"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:456
-#, fuzzy, c-format
+#, c-format
 msgid "Can not read control points for group <%s>"
+msgstr ""
 #: ../imagery/i.eb.soilheatflux/main.c:51
 msgid "soil heat flux"
@@ -7530,9 +6877,8 @@
 msgstr ""
 #: ../imagery/i.eb.soilheatflux/main.c:67
-#, fuzzy
 msgid "Name of Surface temperature raster map [K]"
-msgstr "Tên của bản đồ raster đầu ra (lục)"
+msgstr ""
 #: ../imagery/i.eb.soilheatflux/main.c:83
 msgid "HAPEX-Sahel empirical correction (Roerink, 1995)"
@@ -7540,53 +6886,44 @@
 #: ../imagery/i.topo.corr/main.c:48 ../raster/r.slope.aspect/main.c:152
 #: ../raster/r.relief/main.c:110 ../raster/r.param.scale/interface.c:56
-#, fuzzy
 msgid "terrain"
-msgstr "Phương pháp nội suy"
+msgstr ""
 #: ../imagery/i.topo.corr/main.c:49
-#, fuzzy
 msgid "topographic correction"
-msgstr "Bản đồ raster hướng đầu ra"
+msgstr ""
 #: ../imagery/i.topo.corr/main.c:50
-#, fuzzy
 msgid "Computes topographic correction of reflectance."
+msgstr ""
 #: ../imagery/i.topo.corr/main.c:58
-#, fuzzy
 msgid "Name of reflectance raster maps to be corrected topographically"
-msgstr "Tên các bản đồ raster được 'vá' với nhau"
+msgstr ""
 #: ../imagery/i.topo.corr/main.c:62
-#, fuzzy
 msgid "Name (flag -i) or prefix for output raster maps"
-msgstr "Tiền tố dùng cho (các) bản đồ raster đầu ra"
+msgstr ""
 #: ../imagery/i.topo.corr/main.c:66
-#, fuzzy
 msgid "Name of input base raster map (elevation or illumination)"
-msgstr "Tên của bản đồ raster đầu vào (độ bão hoà)"
+msgstr ""
 #: ../imagery/i.topo.corr/main.c:72
-#, fuzzy
 msgid "Solar zenith in degrees"
-msgstr "Tên tập tin độ cao raster"
+msgstr ""
 #: ../imagery/i.topo.corr/main.c:78
 msgid "Solar azimuth in degrees (only if flag -i)"
 msgstr ""
 #: ../imagery/i.topo.corr/main.c:85
-#, fuzzy
 msgid "Topographic correction method"
+msgstr ""
 #: ../imagery/i.topo.corr/main.c:90
-#, fuzzy
 msgid "Output sun illumination terrain model"
-msgstr "Đầu ra là lỗi nội suy"
+msgstr ""
 #: ../imagery/i.topo.corr/main.c:94
 msgid "Scale output to input and copy color rules"
@@ -7603,16 +6940,16 @@
 #: ../imagery/i.topo.corr/main.c:158 ../raster/r.resamp.interp/main.c:102
 #, c-format
 msgid "Invalid method: %s"
+msgstr ""
 #: ../imagery/i.topo.corr/main.c:164
 msgid "Illumination model is of CELL type"
 msgstr ""
 #: ../imagery/i.topo.corr/main.c:167
-#, fuzzy, c-format
+#, c-format
 msgid "Band %s: "
-msgstr "băng %d"
+msgstr ""
 #: ../imagery/i.topo.corr/main.c:175
 #, c-format
@@ -7624,24 +6961,20 @@
 msgstr ""
 #: ../imagery/i.eb.hsebal01/main.c:116
-#, fuzzy
 msgid "Name of instantaneous net radiation raster map [W/m2]"
+msgstr ""
 #: ../imagery/i.eb.hsebal01/main.c:121
-#, fuzzy
 msgid "Name of instantaneous soil heat flux raster map [W/m2]"
+msgstr ""
 #: ../imagery/i.eb.hsebal01/main.c:126
-#, fuzzy
 msgid "Name of aerodynamic resistance to heat momentum raster map [s/m]"
-msgstr "Tên của bản đồ raster chứa hệ số khả năng tách rời [s/m]"
+msgstr ""
 #: ../imagery/i.eb.hsebal01/main.c:131
-#, fuzzy
 msgid "Name of altitude corrected surface temperature raster map [K]"
+msgstr ""
 #: ../imagery/i.eb.hsebal01/main.c:140
 msgid "Value of the height independent friction velocity (u*) [m/s]"
@@ -7669,36 +7002,31 @@
 #: ../vector/v.surf.rst/main.c:318 ../vector/v.surf.rst/main.c:326
 #: ../vector/v.surf.rst/main.c:333
 msgid "Parameters"
-msgstr "Các tham số"
+msgstr ""
 #: ../imagery/i.eb.hsebal01/main.c:149
-#, fuzzy
 msgid "Value of the actual vapour pressure (e_act) [KPa]"
-msgstr "Tên của bản đồ raster độ nét đứt gãy nghiêm trọng [Pa]"
+msgstr ""
 #: ../imagery/i.eb.hsebal01/main.c:156
-#, fuzzy
 msgid "Row value of the wet pixel"
-msgstr "Giá trị cho cạnh tây"
+msgstr ""
 #: ../imagery/i.eb.hsebal01/main.c:163
-#, fuzzy
 msgid "Column value of the wet pixel"
-msgstr "Cột dùng chỉ định kích thước biểu đồ quạt"
+msgstr ""
 #: ../imagery/i.eb.hsebal01/main.c:170
 msgid "Row value of the dry pixel"
 msgstr ""
 #: ../imagery/i.eb.hsebal01/main.c:177
-#, fuzzy
 msgid "Column value of the dry pixel"
+msgstr ""
 #: ../imagery/i.eb.hsebal01/main.c:182
-#, fuzzy
 msgid "Name for output sensible heat flux raster map [W/m2]"
-msgstr "Tên của bản đồ raster độ dốc đầu ra"
+msgstr ""
 #: ../imagery/i.eb.hsebal01/main.c:187
 msgid "Automatic wet/dry pixel (careful!)"
@@ -7709,9 +7037,8 @@
 msgstr ""
 #: ../imagery/i.eb.hsebal01/main.c:210
-#, fuzzy
 msgid "Automatic mode selected"
-msgstr "Thiết bị đồ họa chưa được chọn"
+msgstr ""
 #: ../imagery/i.eb.hsebal01/main.c:222
 msgid "Manual wet/dry pixels in image coordinates"
@@ -7732,18 +7059,18 @@
 msgstr ""
 #: ../imagery/i.eb.hsebal01/main.c:233
-#, fuzzy, c-format
+#, c-format
 msgid "<%s> is an illegal name"
-msgstr "[%s] là tên không hợp lệ"
+msgstr ""
 #: ../ps/ps.map/ps_vpoints.c:71 ../ps/ps.map/ps_vareas.c:161
 #: ../ps/ps.map/ps_vlines.c:56
 msgid "Cannot load data from table"
-msgstr "Không thể nạp dữ liệu từ bảng"
+msgstr ""
 #: ../ps/ps.map/ps_vpoints.c:87 ../ps/ps.map/do_plt.c:169
 msgid "Cannot read symbol, using default icon"
-msgstr "Không thể đọc biểu tượng, dùng biểu tượng mặc định"
+msgstr ""
 #: ../ps/ps.map/ps_vpoints.c:160 ../ps/ps.map/ps_vpoints.c:171
 #: ../ps/ps.map/ps_vpoints.c:195 ../ps/ps.map/ps_vpoints.c:236
@@ -7751,380 +7078,327 @@
 #: ../ps/ps.map/ps_vlines.c:119
 #, c-format
 msgid "No record for category [%d]"
-msgstr "Không có bản ghi cho phạm trù [%d]"
+msgstr ""
 #: ../ps/ps.map/ps_vpoints.c:177
 #, c-format
 msgid "Attribute is of invalid size [%.3f] for category [%d]"
-msgstr "Thuộc tính có kích cỡ không hợp lệ [%.3f] đối với phạm trù [%d]"
+msgstr ""
 #: ../ps/ps.map/ps_vpoints.c:201 ../ps/ps.map/ps_vareas.c:108
 #: ../ps/ps.map/ps_vlines.c:125
 #, c-format
 msgid "Invalid RGB color definition in column <%s> for category [%d]"
-msgstr "Cột định nghĩa màu RGB không hợp lệ <%s> đối với phạm trù [%d]"
+msgstr ""
 #: ../ps/ps.map/ps_outline.c:43
 #, c-format
 msgid "Outlining areas in raster map <%s in %s> ..."
-msgstr "Đang phác thảo các vùng trong bản đồ raster <%s trong %s> ... "
+msgstr ""
 #: ../ps/ps.map/ps_outline.c:87 ../ps/ps.map/getgrid.c:61
 #: ../ps/ps.map/getgrid.c:85 ../ps/ps.map/getgrid.c:171
 #: ../ps/ps.map/getgrid.c:195 ../ps/ps.map/r_info.c:67
 #: ../ps/ps.map/r_header.c:65
-#, fuzzy
 msgid "Unsupported color request"
+msgstr ""
 #: ../ps/ps.map/ps_outline.c:89 ../ps/ps.map/getgrid.c:63
 #: ../ps/ps.map/getgrid.c:87 ../ps/ps.map/getgrid.c:173
 #: ../ps/ps.map/getgrid.c:197 ../ps/ps.map/r_info.c:69
 #: ../ps/ps.map/r_instructions.c:149 ../ps/ps.map/r_instructions.c:464
 #: ../ps/ps.map/r_header.c:67
-#, fuzzy
 msgid "illegal color request"
-msgstr "Yêu cầu xoá không hợp lệ"
+msgstr ""
 #: ../ps/ps.map/ps_outline.c:100 ../ps/ps.map/r_colortable.c:73
 #: ../ps/ps.map/r_colortable.c:89
-#, fuzzy
 msgid "illegal width request"
+msgstr ""
 #: ../ps/ps.map/ps_outline.c:107
-#, fuzzy
 msgid "illegal outline sub-request"
+msgstr ""
 #: ../ps/ps.map/ps_vareas.c:67 ../ps/ps.map/ps_vareas.c:78
 #: ../ps/ps.map/ps_vlines.c:84
 msgid "Read error in vector map"
-msgstr "Lỗi đọc trong tập tin vec-tơ"
+msgstr ""
 #: ../ps/ps.map/ps_fclrtbl.c:46 ../ps/ps.map/ps_clrtbl.c:35
 #, c-format
 msgid "Creating color table for <%s in %s>..."
-msgstr "Đang tạo bảng màu cho <%s trong %s>..."
+msgstr ""
 #: ../ps/ps.map/ps_fclrtbl.c:51
 msgid "Range information not available (run r.support)"
-msgstr "Thông tin miền không có (chạy r.support)"
+msgstr ""
 #: ../ps/ps.map/ps_fclrtbl.c:64
 msgid "A floating point colortable must contain a range of values"
-msgstr "Một bảng màu kiểu dấu chấm động phải chứa một miền giá trị"
+msgstr ""
 #: ../ps/ps.map/ps_fclrtbl.c:69 ../ps/ps.map/ps_clrtbl.c:44
 msgid "Unable to read colors for colorbar"
-msgstr "Không thể đọc màu cho colorbar (cột màu)"
+msgstr ""
 #: ../ps/ps.map/ps_fclrtbl.c:97 ../ps/ps.map/ps_fclrtbl.c:102
 #: ../ps/ps.map/ps_clrtbl.c:69
 msgid "Colorbar y location beyond page margins. Adjusting."
-msgstr "Vị trí y của colorbar (cột màu) ở ngoài mép trang. Đang điều chỉnh."
+msgstr ""
 #: ../ps/ps.map/ps_fclrtbl.c:108 ../ps/ps.map/ps_fclrtbl.c:113
 #: ../ps/ps.map/ps_clrtbl.c:75
 msgid "Colorbar x location beyond page margins. Adjusting."
-msgstr "Vị trí x của colorbar (cột màu) ở ngoài mép trang. Đang điều chỉnh."
+msgstr ""
 #: ../ps/ps.map/do_labels.c:44
 #, c-format
 msgid "Can't open label file <%s> in mapset <%s>"
-msgstr "Không thể mở tập tin nhãn <%s> trong bộ bản đồ <%s>"
+msgstr ""
 #: ../ps/ps.map/do_labels.c:48
 #, c-format
 msgid "Reading labels file <%s in %s> ..."
-msgstr "Đang đọc tập tin nhãn <%s trong %s> ..."
+msgstr ""
 #: ../ps/ps.map/do_labels.c:66
 #, c-format
 msgid "Can't open temporary label file <%s>"
-msgstr "Không thể mở tập tin nhãn tạm thời <%s>"
+msgstr ""
 #: ../ps/ps.map/do_labels.c:69
 msgid "Reading text file ..."
-msgstr "Đang đọc tập tin nội dung..."
+msgstr ""
 #: ../ps/ps.map/do_labels.c:162
 msgid "Text labels: 'fontsize' given so ignoring 'size'"
 msgstr ""
-"Nhãn văn bản: 'fontsize' (cỡ chữ) được cung cấp do vậy bỏ qua 'size' (kích "
-"thước)"
 #: ../ps/ps.map/do_scalebar.c:192
-#, fuzzy
 msgid "meters"
+msgstr ""
 #: ../ps/ps.map/do_scalebar.c:194
-#, fuzzy
 msgid "kilometers"
-msgstr "địa điểm"
+msgstr ""
 #: ../ps/ps.map/do_scalebar.c:196
 msgid "feet"
 msgstr ""
 #: ../ps/ps.map/do_scalebar.c:198
-#, fuzzy
 msgid "miles"
-msgstr "địa điểm"
+msgstr ""
 #: ../ps/ps.map/do_scalebar.c:200
 msgid "nautical miles"
 msgstr ""
 #: ../ps/ps.map/r_plt.c:173
-#, fuzzy
 msgid "Can't open eps file"
-msgstr "Không thể mở tập tin tạm [%s]"
+msgstr ""
 #: ../ps/ps.map/map_setup.c:82
-#, fuzzy, c-format
+#, c-format
 msgid "Scale set to %s"
-msgstr "Tỷ lệ được thiết lập thành %s."
+msgstr ""
 #: ../ps/ps.map/do_masking.c:23
 msgid "Can't open temporary PostScript mask file."
-msgstr "Không thể mở tập tin mặt nạ PostScript tạm thời."
+msgstr ""
 #: ../ps/ps.map/do_plt.c:38
 msgid "Reading point/line file ..."
-msgstr "Đang đọc tập tin điểm/đường ..."
+msgstr ""
 #: ../ps/ps.map/getgrid.c:95 ../ps/ps.map/getgrid.c:206
-#, fuzzy
 msgid "illegal numbers request"
+msgstr ""
 #: ../ps/ps.map/getgrid.c:126 ../ps/ps.map/getgrid.c:234
-#, fuzzy
 msgid "illegal grid width request"
+msgstr ""
 #: ../ps/ps.map/getgrid.c:132
-#, fuzzy
 msgid "illegal request (grid)"
+msgstr ""
 #: ../ps/ps.map/getgrid.c:240
-#, fuzzy
 msgid "illegal request (geogrid)"
+msgstr ""
 #: ../ps/ps.map/r_info.c:48 ../ps/ps.map/r_vlegend.c:49
 #: ../ps/ps.map/r_colortable.c:65
-#, fuzzy
 msgid "illegal where request"
+msgstr ""
 #: ../ps/ps.map/r_info.c:81
-#, fuzzy
 msgid "illegal bgcolor request"
+msgstr ""
 #: ../ps/ps.map/r_info.c:93 ../ps/ps.map/r_vlegend.c:86
-#, fuzzy
 msgid "illegal border color request"
+msgstr ""
 #: ../ps/ps.map/r_info.c:103
-#, fuzzy
 msgid "illegal mapinfo sub-request"
+msgstr ""
 #: ../ps/ps.map/ps_clrtbl.c:39 ../display/d.histogram/main.c:174
 #, c-format
 msgid "Category file for <%s> not available"
-msgstr "Tập tin phạm trù của <%s> không dùng được"
+msgstr ""
 #: ../ps/ps.map/ps_clrtbl.c:54
-#, fuzzy
-msgid ""
-"Your cats/ file is invalid. A cats/ file with categories and labels is "
-"required for 'colortable' when using categorical legends; see the r.category "
-"help page. Colortable creation has been skipped."
+msgid "Your cats/ file is invalid. A cats/ file with categories and labels is required for 'colortable' when using categorical legends; see the r.category help page. Colortable creation has been skipped."
 msgstr ""
-"Tập tin cats/ của bạn không hợp lệ. Một tập tin cats/ với các phạm trù và "
-"nhãn cần thiết cho 'colortable' (bảng màu) khi dùng dữ liệu raster CELL. Sẽ "
-"không có bảng màu được gán cho tập tin postscipt đầu ra này."
 #: ../ps/ps.map/r_vlegend.c:97
-#, fuzzy
 msgid "illegal vlegend sub-request"
+msgstr ""
 #: ../ps/ps.map/r_instructions.c:62
-#, fuzzy
 msgid "Data exist after final 'end' instruction!"
-msgstr "Dữ liệu vẫn còn sau hướng dẫn 'end' cuối cùng!"
+msgstr ""
 #: ../ps/ps.map/r_instructions.c:80
-#, fuzzy
 msgid "no file specified"
-msgstr "Bản đồ không được chỉ định"
+msgstr ""
 #: ../ps/ps.map/r_instructions.c:84
-#, fuzzy
 msgid "unable to open"
-msgstr "không thể mở MẶT NẠ"
+msgstr ""
 #: ../ps/ps.map/r_instructions.c:115
-#, fuzzy
 msgid "illegal maploc request"
+msgstr ""
 #: ../ps/ps.map/r_instructions.c:129 ../ps/ps.map/main.c:220
-#, fuzzy
 msgid "illegal copies request"
+msgstr ""
 #: ../ps/ps.map/r_instructions.c:144 ../ps/ps.map/r_instructions.c:340
-#, fuzzy
 msgid "no raster map selected yet"
-msgstr "Không có bản đồ raster nào được chỉ định"
+msgstr ""
 #: ../ps/ps.map/r_instructions.c:160
-#, fuzzy
 msgid "illegal value list"
-msgstr "%s: giá trị chỉ định không hợp lệ"
+msgstr ""
 #: ../ps/ps.map/r_instructions.c:196
-#, fuzzy
 msgid "scalebar is not appropriate for this projection"
-msgstr "Tùy chọn Geo-Grid không dùng được đối với phép chiếu kinh/vĩ"
+msgstr ""
 #: ../ps/ps.map/r_instructions.c:204
-#, fuzzy
 msgid "Bad scalebar length"
+msgstr ""
 #: ../ps/ps.map/r_instructions.c:220
-#, fuzzy
 msgid "illegal text request"
+msgstr ""
 #: ../ps/ps.map/r_instructions.c:234
-#, fuzzy
 msgid "illegal point request"
+msgstr ""
 #: ../ps/ps.map/r_instructions.c:248
-#, fuzzy
 msgid "illegal eps request"
+msgstr ""
 #: ../ps/ps.map/r_instructions.c:265
-#, fuzzy
 msgid "illegal line request"
+msgstr ""
 #: ../ps/ps.map/r_instructions.c:282
-#, fuzzy
 msgid "illegal rectangle request"
+msgstr ""
 #: ../ps/ps.map/r_instructions.c:293
-#, fuzzy
 msgid "illegal comments request"
+msgstr ""
 #: ../ps/ps.map/r_instructions.c:309
-#, fuzzy
 msgid "illegal scale request"
+msgstr ""
 #: ../ps/ps.map/r_instructions.c:369
-#, fuzzy
 msgid "group not found"
 msgstr ""
-"\n"
-" không tìm thấy nhóm <%s>"
 #: ../ps/ps.map/r_instructions.c:411
-#, fuzzy
 msgid "illegal grid spacing"
-msgstr "Tắt việc vẽ lưới"
+msgstr ""
 #: ../ps/ps.map/r_instructions.c:422
-#, fuzzy
 msgid "geogrid is not available for this projection"
+msgstr ""
 #: ../ps/ps.map/r_instructions.c:432
 msgid "illegal geo-grid spacing"
 msgstr ""
 #: ../ps/ps.map/r_instructions.c:469
-#, fuzzy
 msgid "illegal request"
+msgstr ""
-#: ../ps/ps.map/catval.c:48 ../ps/ps.map/catval.c:110
-#: ../ps/ps.map/catval.c:176 ../vector/v.label.sa/labels.c:75
-#: ../vector/v.class/main.c:111 ../vector/v.label/main.c:274
-#: ../vector/v.vol.rst/user1.c:95
+#: ../ps/ps.map/catval.c:48 ../ps/ps.map/catval.c:110 ../ps/ps.map/catval.c:176
+#: ../vector/v.label.sa/labels.c:75 ../vector/v.class/main.c:111
+#: ../vector/v.label/main.c:274 ../vector/v.vol.rst/user1.c:95
 msgid "Unable to get layer info for vector map"
-msgstr "Không thể lấy thông tin lớp của bản đồ vec-tơ"
+msgstr ""
 #: ../ps/ps.map/catval.c:63
 msgid "Column type not supported (must be string)"
-msgstr "Kiểu cột không được hỗ trợ (phải là kiểu chuỗi)"
+msgstr ""
-#: ../ps/ps.map/catval.c:66 ../ps/ps.map/catval.c:131
-#: ../ps/ps.map/catval.c:198 ../vector/v.out.lidar/main.c:132
-#: ../vector/v.out.lidar/main.c:167 ../vector/v.class/main.c:132
-#: ../vector/v.to.rast3/main.c:95 ../vector/v.surf.idw/read_sites.c:68
-#: ../vector/v.normal/main.c:134 ../vector/v.surf.bspline/main.c:392
-#: ../vector/v.sample/main.c:152 ../vector/v.vol.rst/user1.c:112
-#: ../vector/v.univar/main.c:366
+#: ../ps/ps.map/catval.c:66 ../ps/ps.map/catval.c:131 ../ps/ps.map/catval.c:198
+#: ../vector/v.out.lidar/main.c:132 ../vector/v.out.lidar/main.c:167
+#: ../vector/v.class/main.c:132 ../vector/v.to.rast3/main.c:95
+#: ../vector/v.surf.idw/read_sites.c:68 ../vector/v.normal/main.c:134
+#: ../vector/v.surf.bspline/main.c:392 ../vector/v.sample/main.c:152
+#: ../vector/v.vol.rst/user1.c:112 ../vector/v.univar/main.c:366
 msgid "Unable to select data from table"
-msgstr "Không thể chọn dữ liệu từ bảng"
+msgstr ""
 #: ../ps/ps.map/catval.c:128
 msgid "Size column type must be numeric"
-msgstr "Kiểu của cột kích thước phải là kiểu số"
+msgstr ""
 #: ../ps/ps.map/catval.c:195
 msgid "Rotation column type must be numeric"
-msgstr "Kiểu của cột góc xoay phải là kiểu số"
+msgstr ""
 #: ../ps/ps.map/do_vectors.c:33
 #, c-format
 msgid "Reading vector map <%s in %s> ..."
-msgstr "Đang đọc bản đồ vec-tơ <%s trong %s>..."
+msgstr ""
 #: ../ps/ps.map/do_vectors.c:136
 #, c-format
 msgid "Reading vector points file <%s in %s> ..."
-msgstr "Đang đọc tập tin điểm vec-tơ <%s trong %s> ..."
+msgstr ""
 #: ../ps/ps.map/do_psfiles.c:20
 #, c-format
 msgid "Reading PostScript include file <%s> ..."
-msgstr "Đang đọc tập tin chứa PostScript <%s> ..."
+msgstr ""
 #: ../ps/ps.map/main.c:93
-#, fuzzy
 msgid "postscript"
-msgstr "Tập tin đầu ra PostScript"
+msgstr ""
 #: ../ps/ps.map/main.c:94
-#, fuzzy
 msgid "printing"
-msgstr "Đang ghi %s..."
+msgstr ""
 #: ../ps/ps.map/main.c:95
-#, fuzzy
 msgid "Produces hardcopy PostScript map output."
-msgstr "Tiện ích tạo đầu ra bản đồ PostScript bản in."
+msgstr ""
 #: ../ps/ps.map/main.c:99
 msgid "Rotate plot 90 degrees"
-msgstr "Quay bản vẽ 90 độ"
+msgstr ""
 #: ../ps/ps.map/main.c:100 ../ps/ps.map/main.c:113 ../ps/ps.map/main.c:135
 #: ../raster/r.kappa/main.c:90 ../raster/r.kappa/main.c:98
@@ -8133,14 +7407,12 @@
 #: ../locale/scriptstrings/v.unpack_to_translate.c:11
 #: ../locale/scriptstrings/r.unpack_to_translate.c:7
 #: ../locale/scriptstrings/r.unpack_to_translate.c:10
-#, fuzzy
 msgid "Output settings"
+msgstr ""
 #: ../ps/ps.map/main.c:105
-#, fuzzy
 msgid "List paper formats (name width height left right top bottom(margin))"
-msgstr "Liệt kệ các định dạng giấy (tên rộng cao trái phải trên dưới(mép) )"
+msgstr ""
 #: ../ps/ps.map/main.c:107 ../ps/ps.map/main.c:120
 msgid "Utility"
@@ -8148,77 +7420,73 @@
 #: ../ps/ps.map/main.c:112
 msgid "Create EPS (Encapsulated PostScript) instead of PostScript file"
-msgstr "Tạo EPS (Encapsulated PostScript) thay vì tập tin PostScript"
+msgstr ""
 #: ../ps/ps.map/main.c:118
-msgid ""
-"Describe map-box's position on the page and exit (inches from top-left of "
-"paper)"
+msgid "Describe map-box's position on the page and exit (inches from top-left of paper)"
 msgstr ""
 #: ../ps/ps.map/main.c:123
-#, fuzzy
 msgid "File containing mapping instructions"
-msgstr "Tập tin chứa các chữ ký khởi tạo"
+msgstr ""
 #: ../ps/ps.map/main.c:124
 msgid "Use '-' to enter instructions from keyboard)"
 msgstr ""
 #: ../ps/ps.map/main.c:127
-#, fuzzy
 msgid "Name for PostScript output file"
+msgstr ""
 #: ../ps/ps.map/main.c:133
 msgid "Number of copies to print"
-msgstr "Số lượng bản in"
+msgstr ""
 #: ../ps/ps.map/main.c:205
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open file '%s': %s"
-msgstr "Không thể mở tập tin cell [%s]."
+msgstr ""
 #: ../ps/ps.map/main.c:213 ../ps/ps.map/main.c:232
 #: ../vector/v.to.db/parse.c:141 ../vector/v.to.db/parse.c:144
 #: ../vector/v.univar/main.c:147
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Required parameter <%s> not set:\n"
 "\t(%s)"
-msgstr "Tham số cần thiết <%s> không được thiết lập"
+msgstr ""
 #: ../ps/ps.map/main.c:273
-#, fuzzy, c-format
+#, c-format
 msgid "PostScript file '%s' successfully written."
-msgstr "Tập tin PostScript [%s] được ghi thành công."
+msgstr ""
 #: ../ps/ps.map/scale.c:136
 msgid "PSmap: do_scale(): shouldn't happen"
-msgstr "PSmap: do_scale(): lẽ ra không nên có"
+msgstr ""
 #: ../ps/ps.map/eps.c:18
-#, fuzzy, c-format
+#, c-format
 msgid "Can't open eps file <%s>"
+msgstr ""
 #: ../ps/ps.map/eps.c:37
-#, fuzzy, c-format
+#, c-format
 msgid "Bounding box in eps file <%s> was not found"
-msgstr "Không tìm thấy tập tin 3dview <%s>"
+msgstr ""
 #: ../ps/ps.map/makeprocs.c:29
 #, c-format
 msgid "Unable to open prolog <%s>"
-msgstr "Không thể mở prolog <%s>"
+msgstr ""
 #: ../ps/ps.map/r_group.c:29
 msgid "Can't get group information"
-msgstr "Không thể lấy thông tin nhóm"
+msgstr ""
 #: ../ps/ps.map/ps_raster.c:42
 msgid "Can't create temporary PostScript mask file."
-msgstr "Không thể tạo tập tin mặt nạ PostScript tạm."
+msgstr ""
 #: ../ps/ps.map/ps_raster.c:102 ../raster/r.grow.distance/main.c:276
 #: ../raster/r.series.accumulate/main.c:248
@@ -8229,46 +7497,40 @@
 #: ../raster/r.surf.idw/main.c:713
 #, c-format
 msgid "Reading raster map <%s>..."
-msgstr "Đang đọc bản đồ raster <%s>... "
+msgstr ""
 #: ../ps/ps.map/ps_raster.c:105
-#, fuzzy, c-format
+#, c-format
 msgid "Reading raster maps in group <%s>..."
-msgstr "Đang đọc bản đồ raster trong nhóm <%s>... "
+msgstr ""
 #: ../ps/ps.map/r_colortable.c:81
-#, fuzzy
 msgid "illegal height request"
+msgstr ""
 #: ../ps/ps.map/r_colortable.c:106
-#, fuzzy
 msgid "illegal range request"
+msgstr ""
 #: ../ps/ps.map/r_colortable.c:122
-#, fuzzy
 msgid "illegal columns request"
+msgstr ""
 #: ../ps/ps.map/r_colortable.c:141
-#, fuzzy
 msgid "Unsupported color request (colortable)"
-msgstr "Định dạng đầu ra không được hỗ trợ"
+msgstr ""
 #: ../ps/ps.map/r_colortable.c:143
 msgid "illegal color request (colortable)"
 msgstr ""
 #: ../ps/ps.map/r_colortable.c:170
-#, fuzzy
 msgid "illegal colortable sub-request"
+msgstr ""
 #: ../ps/ps.map/r_colortable.c:181
-#, fuzzy
 msgid "No raster selected for colortable!"
-msgstr "Không có bản ghi nào được chọn từ bảng <%s>"
+msgstr ""
 #: ../ps/ps.map/do_geogrid.c:86 ../ps/ps.map/do_geogrid.c:91
 #: ../ps/ps.map/do_geogrid.c:115 ../ps/ps.map/do_geogrid.c:120
@@ -8286,39 +7548,37 @@
 #: ../display/d.grid/plot.c:635 ../display/d.grid/plot.c:651
 #: ../display/d.grid/plot.c:668 ../display/d.grid/plot.c:685
 msgid "Error in pj_do_proj"
-msgstr "Lỗi trong pj_do-proj"
+msgstr ""
 #: ../ps/ps.map/do_geogrid.c:272 ../raster/r.sun/main.c:753
 #: ../raster/r.horizon/main.c:538 ../display/d.where/main.c:113
 #: ../display/d.grid/plot.c:554 ../general/g.region/printwindow.c:247
 #: ../general/g.region/printwindow.c:503 ../general/g.region/printwindow.c:622
 msgid "Can't get projection key values of current location"
-msgstr "Không thể lấy các giá trị chính về phép chiếu  của vị trí hiện tại"
+msgstr ""
 #: ../ps/ps.map/do_geogrid.c:278 ../raster/r.sun/main.c:763
 #: ../raster/r.horizon/main.c:548 ../raster/r.latlong/main.c:114
 #: ../display/d.where/main.c:120 ../display/d.where/main.c:146
 #: ../display/d.grid/plot.c:561 ../display/d.grid/plot.c:588
 msgid "Unable to set up lat/long projection parameters"
-msgstr "Không thể thiết lập các tham số phép chiếu vĩ/kinh độ"
+msgstr ""
 #: ../ps/ps.map/read_cfg.c:64
 #, c-format
 msgid "Paper '%s' not found, using defaults"
-msgstr "Không thấy loại giấy '%s', dùng giá trị mặc định"
+msgstr ""
 #: ../ps/ps.map/r_header.c:77
-#, fuzzy
 msgid "illegal header sub-request"
+msgstr ""
 #: ../db/db.connect/main.c:43 ../db/db.databases/main.c:95
-#: ../db/db.copy/main.c:35 ../db/db.execute/main.c:125
-#: ../db/db.login/main.c:40 ../db/db.select/main.c:265
-#: ../db/db.columns/main.c:99 ../db/db.dropdb/main.c:71
-#: ../db/db.drivers/main.c:71 ../db/db.describe/main.c:129
-#: ../db/db.createdb/main.c:71 ../db/db.tables/main.c:97
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:2
+#: ../db/db.copy/main.c:35 ../db/db.execute/main.c:125 ../db/db.login/main.c:40
+#: ../db/db.select/main.c:265 ../db/db.columns/main.c:99
+#: ../db/db.dropdb/main.c:71 ../db/db.drivers/main.c:71
+#: ../db/db.describe/main.c:129 ../db/db.createdb/main.c:71
+#: ../db/db.tables/main.c:97 ../locale/scriptstrings/db.in.ogr_to_translate.c:2
 #: ../locale/scriptstrings/db.test_to_translate.c:2
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
 #: ../locale/scriptstrings/v.db.update_to_translate.c:4
@@ -8338,9 +7598,8 @@
 #: ../vector/v.db.connect/main.c:54 ../vector/v.vect.stats/main.c:126
 #: ../vector/v.distance/main.c:92 ../vector/v.in.db/main.c:54
 #: ../vector/v.to.db/main.c:38 ../vector/v.db.select/main.c:56
-#, fuzzy
 msgid "database"
-msgstr "CSDL, SQL"
+msgstr ""
 #: ../db/db.connect/main.c:44 ../db/db.databases/main.c:96
 #: ../db/db.copy/main.c:36 ../db/db.execute/main.c:126
@@ -8371,39 +7630,33 @@
 #: ../vector/v.distance/main.c:93 ../vector/v.what.rast/main.c:76
 #: ../vector/v.to.db/main.c:37 ../vector/v.db.select/main.c:55
 #: ../vector/v.univar/main.c:95
-#, fuzzy
 msgid "attribute table"
-msgstr "vecotr, bảng thuộc tính"
+msgstr ""
 #: ../db/db.connect/main.c:45 ../db/db.login/main.c:41
 #: ../db/db.drivers/main.c:72
-#, fuzzy
 msgid "connection settings"
-msgstr "Vui lòng chỉnh các thiết lập cho đúng"
+msgstr ""
 #: ../db/db.connect/main.c:47
-#, fuzzy
 msgid "Prints/sets general DB connection for current mapset."
-msgstr "In/Thiết lập kết nối CSDL tổng quát cho bộ bản đồ hiện tại và thoát."
+msgstr ""
 #: ../db/db.connect/main.c:51 ../temporal/t.connect/main.c:42
 msgid "Print current connection parameters and exit"
+msgstr ""
 #: ../db/db.connect/main.c:52
 msgid "Substitute variables in database settings"
 msgstr ""
 #: ../db/db.connect/main.c:57
-#, fuzzy
 msgid "Print current connection parameters using shell style and exit"
+msgstr ""
 #: ../db/db.connect/main.c:63 ../temporal/t.connect/main.c:48
 msgid "Check connection parameters, set if uninitialized, and exit"
 msgstr ""
-"Kiểm tra các tham số kết nối hiện hành, thiết lập nếu chưa được khởi tạo, và "
-"thoát"
 #: ../db/db.connect/main.c:64 ../db/db.connect/main.c:70
 #: ../db/db.connect/main.c:75 ../db/db.connect/main.c:79
@@ -8416,22 +7669,20 @@
 msgstr ""
 #: ../db/db.connect/main.c:68 ../temporal/t.connect/main.c:53
-#, fuzzy
 msgid "Set from default settings and exit"
-msgstr "Thiết lập từ vùng mặc định"
+msgstr ""
 #: ../db/db.connect/main.c:69
-#, fuzzy
 msgid "Overwrite current settings if already initialized"
-msgstr "Ghi đè  MẶT NẠ hiện có"
+msgstr ""
 #: ../db/db.connect/main.c:91
 msgid "Default group of database users to which select privilege is granted"
-msgstr "Nhóm người dùng CSDL mặc định để cấp quyền ưu tiên chọn"
+msgstr ""
 #: ../db/db.connect/main.c:141 ../db/db.tables/main.c:41
 msgid "Database connection not defined. Run db.connect."
-msgstr "Kết nối CSDL không được định nghĩa. Hãy chạy db.connect."
+msgstr ""
 #: ../db/db.connect/main.c:161 ../db/db.connect/main.c:188
 #: ../temporal/t.connect/main.c:133
@@ -8441,9 +7692,6 @@
 "driver: %s\n"
 "database: %s"
 msgstr ""
-"trình điều khiển/csdl mặc định được thiết lập thành:\n"
trình điều khiển: %s\n"
csdl: %s"
 #: ../db/db.connect/main.c:166
 msgid "DB settings already defined, nothing to do"
@@ -8451,11 +7699,11 @@
 #: ../db/db.connect/main.c:172
 msgid "Default driver is not set"
-msgstr "Trình điều khiển mặc định không được thiết lập"
+msgstr ""
 #: ../db/db.connect/main.c:175
 msgid "Default database is not set"
-msgstr "CSDL mặc định không được thiết lập"
+msgstr ""
 #: ../db/db.databases/main.c:48 ../db/db.execute/main.c:70
 #: ../db/db.select/main.c:75 ../db/db.columns/main.c:51
@@ -8468,18 +7716,15 @@
 #: ../vector/v.out.vtk/writeVTK.c:644
 #, c-format
 msgid "Unable to start driver <%s>"
-msgstr "Không thể khởi động trình điều khiển <%s>"
+msgstr ""
 #: ../db/db.databases/main.c:53
-msgid ""
-"Unable to list databases. Try to define correct connection settings by db."
-"login."
+msgid "Unable to list databases. Try to define correct connection settings by db.login."
 msgstr ""
 #: ../db/db.databases/main.c:63
-#, fuzzy
 msgid "No databases found"
+msgstr ""
 #: ../db/db.databases/main.c:80 ../db/db.databases/main.c:91
 #: ../db/db.execute/main.c:144 ../db/db.execute/main.c:149
@@ -8491,12 +7736,11 @@
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:26
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:28
 msgid "Connection"
-msgstr "Kết nối"
+msgstr ""
 #: ../db/db.databases/main.c:87
-#, fuzzy
 msgid "Location"
-msgstr "Vị trí: %s\n"
+msgstr ""
 #: ../db/db.databases/main.c:88
 msgid "Path for SQLite driver, or connection string for PostgreSQL driver"
@@ -8511,81 +7755,75 @@
 msgstr ""
 #: ../db/db.databases/main.c:99
-#, fuzzy
 msgid "Lists all databases for a given driver and location."
 msgstr ""
-"Liệt kê tất cả các CSDL của một trình điều khiển và một vị trí cho trước."
 #: ../db/db.copy/main.c:38
 msgid "Copy a table."
-msgstr "Sao chép một bảng."
+msgstr ""
 #: ../db/db.copy/main.c:40
-msgid ""
-"Either 'from_table' (optionally with 'where') can be used or 'select' "
-"option, but not 'from_table' and 'select' at the same time."
+msgid "Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
 msgstr ""
-"Có thể dùng 'from_table' (cùng với 'where', tùy chọn), hoặc dùng tùy chọn "
-"'select', không được dùng đồng thời 'from_table' và 'select'."
 #: ../db/db.copy/main.c:46
 msgid "Input driver name"
-msgstr "Tên trình điều khiển đầu vào"
+msgstr ""
 #: ../db/db.copy/main.c:52
 msgid "Input database name"
-msgstr "Tên csdl đầu vào"
+msgstr ""
 #: ../db/db.copy/main.c:59
 msgid "Input table name (only, if 'select' is not used)"
-msgstr "Tên bảng đầu vào (chỉ khi không dùng 'select')"
+msgstr ""
 #: ../db/db.copy/main.c:65
 msgid "Output driver name"
-msgstr "Tên trình điều khiển đầu ra"
+msgstr ""
 #: ../db/db.copy/main.c:71
 msgid "Output database name"
-msgstr "Tên csdl đầu ra"
+msgstr ""
 #: ../db/db.copy/main.c:78
 msgid "Output table name"
-msgstr "Tên bảng đầu ra"
+msgstr ""
 #: ../db/db.copy/main.c:87
 msgid "Full select statement (only, if 'from_table' and 'where' is not used)"
-msgstr "Câu lệnh chọn đầy đủ (chỉ khi 'from_table' và 'where' không được dùng)"
+msgstr ""
 #: ../db/db.copy/main.c:88
 msgid "E.g.: SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
-msgstr "Ví dụ: SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
+msgstr ""
 #: ../db/db.copy/main.c:96
 msgid "Cannot combine 'from_table' and 'select' options"
-msgstr "Không thể phối hợp các tùy chọn 'from_table' và 'select' "
+msgstr ""
 #: ../db/db.copy/main.c:100 ../db/db.select/main.c:53
 #: ../db/db.columns/main.c:44 ../db/db.describe/main.c:50
-#, fuzzy, c-format
+#, c-format
 msgid "Table <%s> not found in database <%s> using driver <%s>"
-msgstr "Không thể mở CSDL <%s> bằng trình điều khiển <%s>"
+msgstr ""
 #: ../db/db.copy/main.c:122
 msgid "Either 'from_table' or 'select' option must be given."
-msgstr "Tùy chọn 'from_table' hoặc 'select' phải được cung cấp."
+msgstr ""
 #: ../db/db.copy/main.c:125
 msgid "Cannot combine 'select' and 'where' options"
-msgstr "Không thể phối hợp các tùy chọn 'select' và 'where'"
+msgstr ""
 #: ../db/db.copy/main.c:135
 msgid "Copy table failed"
-msgstr "Sao chép bảng thất bại"
+msgstr ""
 #: ../db/db.execute/main.c:57 ../db/db.select/main.c:63
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open file <%s>: %s"
+msgstr ""
 #: ../db/db.execute/main.c:76 ../db/db.select/main.c:81
 #: ../db/db.columns/main.c:56 ../db/db.describe/main.c:61
@@ -8593,69 +7831,62 @@
 #: ../display/d.vect/opt.c:152
 #, c-format
 msgid "Unable to open database <%s>"
-msgstr "Không thể mở CSDL <%s>"
+msgstr ""
 #: ../db/db.execute/main.c:94 ../db/db.execute/main.c:99
 #, c-format
 msgid "Error while executing: '%s'"
-msgstr "Lỗi khi đang thực thi: '%s'"
+msgstr ""
 #: ../db/db.execute/main.c:128
 msgid "Executes any SQL statement."
-msgstr "Thực thi bất kỳ câu lệnh SQL nào."
+msgstr ""
 #: ../db/db.execute/main.c:129
 msgid "For SELECT statements use 'db.select'."
 msgstr ""
 #: ../db/db.execute/main.c:132
-#, fuzzy
 msgid "SQL statement"
-msgstr "Câu lệnh chọn SQL"
+msgstr ""
 #: ../db/db.execute/main.c:133
 msgid "Example: update rybniky set kapri = 'hodne' where kapri = 'malo'"
 msgstr ""
 #: ../db/db.execute/main.c:138
-#, fuzzy
 msgid "Name of file containing SQL statement(s)"
-msgstr "Tên tập tin chứa các câu lệnh SQL"
+msgstr ""
 #: ../db/db.execute/main.c:160
 msgid "Ignore SQL errors and continue"
-msgstr "Bỏ qua các lỗi SQL và tiếp tục"
+msgstr ""
 #: ../db/db.execute/main.c:161 ../vector/v.build/main.c:51
 #: ../vector/v.build/main.c:77
-#, fuzzy
 msgid "Errors"
-msgstr "Lỗi: %s"
+msgstr ""
 #: ../db/db.execute/main.c:167
-#, fuzzy, c-format
+#, c-format
 msgid "You must provide <%s> or <%s> option"
-msgstr "Bạn phải cung cấp ít nhất bốn điểm %d"
+msgstr ""
 #: ../db/db.login/main.c:42
-#, fuzzy
 msgid "Sets user/password for DB driver/database."
-msgstr "Thiết lập người dùng/mật mã cho trình điều khiển/csdl."
+msgstr ""
 #: ../db/db.login/main.c:59
-#, fuzzy
 msgid "Username"
-msgstr "tên"
+msgstr ""
 #: ../db/db.login/main.c:67
-#, fuzzy
 msgid "Password"
-msgstr "Số lần chạy qua %d..."
+msgstr ""
 #: ../db/db.login/main.c:75
-#, fuzzy
 msgid "Hostname"
-msgstr "Kiểm tra tên"
+msgstr ""
 #: ../db/db.login/main.c:76 ../db/db.login/main.c:85
 msgid "Relevant only for pg and mysql driver"
@@ -8666,28 +7897,26 @@
 msgstr ""
 #: ../db/db.login/main.c:90
-#, fuzzy
 msgid "Print connection settings and exit"
+msgstr ""
 #: ../db/db.login/main.c:105
 msgid "Unable to set user/password"
-msgstr "Không thể thiết lập người dùng/mật mã"
+msgstr ""
 #: ../db/db.login/main.c:109
-#, fuzzy, c-format
+#, c-format
 msgid "The password was stored in file (%s%cdblogin)"
-msgstr "Mật mã được lưu trong tập tin"
+msgstr ""
 #: ../db/db.select/main.c:105
-#, fuzzy, c-format
+#, c-format
 msgid "Test %s."
-msgstr "Kiểu: %s"
+msgstr ""
-#, fuzzy
 msgid "succeeded"
-msgstr "... thành công."
+msgstr ""
 #: ../db/db.select/main.c:142 ../raster/r.what/main.c:170
 #: ../raster/r.stats.quantile/main.c:319 ../raster/r.stats/main.c:227
@@ -8697,7 +7926,7 @@
 #: ../raster/r.regression.line/main.c:77 ../vector/v.db.select/main.c:126
 #, c-format
 msgid "Unable to open file <%s> for writing"
-msgstr "Không thể mở tập tin <%s> để ghi"
+msgstr ""
 #: ../db/db.select/main.c:203 ../db/db.select/main.c:209
 #: ../db/db.select/main.c:213 ../db/db.select/main.c:251
@@ -8705,17 +7934,15 @@
 #: ../raster/r.what/main.c:116 ../vector/v.to.db/parse.c:104
 #: ../vector/v.to.db/parse.c:112
 msgid "Query"
-msgstr "Truy vấn"
+msgstr ""
 #: ../db/db.select/main.c:207
-#, fuzzy
 msgid "Name of file containing SQL select statement(s)"
+msgstr ""
 #: ../db/db.select/main.c:212
-#, fuzzy
 msgid "Name of table to query"
-msgstr "Tên của cột thuộc tính được dùng cho tùy chọn 'query'"
+msgstr ""
 #: ../db/db.select/main.c:227 ../db/db.select/main.c:233
 #: ../db/db.select/main.c:236 ../db/db.select/main.c:246
@@ -8724,44 +7951,40 @@
 #: ../vector/v.db.select/main.c:88 ../vector/v.db.select/main.c:106
 #: ../vector/v.db.select/main.c:111
 msgid "Format"
-msgstr "Định dạng"
+msgstr ""
 #: ../db/db.select/main.c:231
-#, fuzzy
 msgid "Vertical record separator (requires -v flag)"
-msgstr "Dấu phân cách bản ghi theo chiều đứng ở đầu ra"
+msgstr ""
 #: ../db/db.select/main.c:241 ../raster/r.what/main.c:125
 #: ../raster/r.stats.quantile/main.c:553 ../raster/r.stats/main.c:119
-#: ../raster/r.univar/r.univar_main.c:41
-#: ../raster/r.univar/r3.univar_main.c:42
+#: ../raster/r.univar/r.univar_main.c:41 ../raster/r.univar/r3.univar_main.c:42
 #: ../locale/scriptstrings/i.oif_to_translate.c:5
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:6
 #: ../vector/v.db.select/main.c:95
 msgid "Name for output file (if omitted or \"-\" output to stdout)"
 msgstr ""
-"Tên tập tin đầu ra (nếu bỏ qua hoặc \"-\" thì xuất ra đầu ra tiêu chuẩn)"
 #: ../db/db.select/main.c:245 ../vector/v.db.select/main.c:105
 msgid "Do not include column names in output"
-msgstr "Không đưa  tên cột vào đầu ra"
+msgstr ""
 #: ../db/db.select/main.c:250
 msgid "Describe query only (don't run it)"
-msgstr "Chỉ mô tả truy vấn (không chạy nó)"
+msgstr ""
 #: ../db/db.select/main.c:255 ../vector/v.db.select/main.c:110
 msgid "Vertical output (instead of horizontal)"
-msgstr "Đầu ra theo chiều đứng (thay vì ngang)"
+msgstr ""
 #: ../db/db.select/main.c:260
 msgid "Only test query, do not execute"
-msgstr "Chỉ thử phép truy vấn, đừng thực thi"
+msgstr ""
 #: ../db/db.select/main.c:268
-#, fuzzy
 msgid "Selects data from attribute table."
-msgstr "CSDL, bảng thuộc tính"
+msgstr ""
 #: ../db/db.select/main.c:269
 msgid "Performs SQL query statement(s)."
@@ -8781,66 +8004,62 @@
 #: ../vector/v.out.postgis/table.c:41 ../vector/v.out.vtk/writeVTK.c:655
 #, c-format
 msgid "Unable to describe table <%s>"
-msgstr "Không thể mô tả bảng <%s >"
+msgstr ""
 #: ../db/db.columns/main.c:101
 msgid "List all columns for a given table."
-msgstr "Liệt kê tất cả các cột của một bảng cho trước."
+msgstr ""
 #: ../db/db.dropdb/main.c:74
-#, fuzzy
 msgid "Removes an existing database."
-msgstr "Loại bỏ một CSDL."
+msgstr ""
 #: ../db/db.drivers/main.c:39
-#, fuzzy
 msgid "Unable to read dbmscap file"
-msgstr "Không thể đọc tập tin miền"
+msgstr ""
 #: ../db/db.drivers/main.c:63
 msgid "Full output"
-msgstr "Đầu ra đầy đủ"
+msgstr ""
 #: ../db/db.drivers/main.c:67
-#, fuzzy
 msgid "Print drivers and exit"
-msgstr "In ra các trình điều khiển và thoát"
+msgstr ""
 #: ../db/db.drivers/main.c:73
-#, fuzzy
 msgid "Lists all database drivers."
-msgstr "Liệt kê tất cả các trình điều khiển CSDL."
+msgstr ""
 #: ../db/db.describe/main.c:108
 msgid "Print column names only instead of full column descriptions"
-msgstr "Chỉ in ra tên cột thay vì in mô tả đầy đủ cột"
+msgstr ""
 #: ../db/db.describe/main.c:113
 msgid "Print table structure"
-msgstr "In ra cấu trúc bảng"
+msgstr ""
 #: ../db/db.describe/main.c:131
 msgid "Describes a table in detail."
-msgstr "Mô tả chi tiết một bảng"
+msgstr ""
 #: ../db/db.createdb/main.c:74
 msgid "Creates an empty database."
-msgstr "Tạo một CSDL rỗng."
+msgstr ""
 #: ../db/drivers/dbf/db.c:94
