[GRASS-SVN] r71962 - in grass/trunk/raster: . r.path r.path/tests
Wed Dec 20 14:06:06 PST 2017
Author: mmetz
Date: 2017-12-20 14:06:06 -0800 (Wed, 20 Dec 2017)
New Revision: 71962
Added:
   grass/trunk/raster/r.path/
   grass/trunk/raster/r.path/pavlrc.c
   grass/trunk/raster/r.path/pavlrc.h
   grass/trunk/raster/r.path/r.path.html
   grass/trunk/raster/r.path/r_path.png
   grass/trunk/raster/r.path/r_path_with_r_watershed_direction.png
Removed:
   grass/trunk/raster/r.path/README
   grass/trunk/raster/r.path/filldir.c
   grass/trunk/raster/r.path/r.drain.html
   grass/trunk/raster/r.path/r_drain.png
   grass/trunk/raster/r.path/r_drain_with_r_watershed_direction.png
   grass/trunk/raster/r.path/resolve.c
   grass/trunk/raster/r.path/tests/test.r.drain.sh
   grass/trunk/raster/r.path/tests/testascii_nc.asc
   grass/trunk/raster/r.path/tinf.c
   grass/trunk/raster/r.path/tinf.h
   grass/trunk/raster/Makefile
   grass/trunk/raster/r.path/Makefile
   grass/trunk/raster/r.path/local.h
   grass/trunk/raster/r.path/main.c
add r.path
Modified: grass/trunk/raster/Makefile
--- grass/trunk/raster/Makefile	2017-12-19 22:55:14 UTC (rev 71961)
+++ grass/trunk/raster/Makefile	2017-12-20 22:06:06 UTC (rev 71962)
@@ -62,6 +62,7 @@
 	r.out.vtk \
 	r.param.scale \
 	r.patch \
+	r.path \
 	r.profile \
 	r.proj \
 	r.quant \
Modified: grass/trunk/raster/r.path/Makefile
--- grass/trunk/raster/r.drain/Makefile	2017-12-04 15:37:44 UTC (rev 71888)
+++ grass/trunk/raster/r.path/Makefile	2017-12-20 22:06:06 UTC (rev 71962)
@@ -1,6 +1,6 @@
 MODULE_TOPDIR = ../..
-PGM = r.drain
+PGM = r.path
 LIBES = $(VECTORLIB) $(RASTERLIB) $(GISLIB)
 DEPENDENCIES = $(VECTORDEP) $(RASTERDEP) $(GISDEP)
Deleted: grass/trunk/raster/r.path/README
--- grass/trunk/raster/r.drain/README	2017-12-04 15:37:44 UTC (rev 71888)
+++ grass/trunk/raster/r.path/README	2017-12-20 22:06:06 UTC (rev 71962)
@@ -1,42 +0,0 @@
-Date: Sun, 15 Jul 2001 18:26:51 -0600
-X-Mailer: Mozilla 4.76 [en] (X11; U; Linux 2.0.27 i586)
-X-Accept-Language: en
-To: Markus Neteler <neteler at geog.uni-hannover.de>
-Subject: r.drain -- new version
-Markus,
-I worked on the original r.drain for a while and wasn't really able to
-understand what it was doing, much less where the problem was.  I
-figured that I might be able to spend the rest of the weekend figuring
-it out and in the end I would still have a program with unusual behavior
-in flat spots.  I decided instead to finish the version that I started
-based on r.fill.dir.
-My version of r.drain (which I called r.d2) is in the attached zip file.
-r.d2 reproduces most of the behavior of r.drain.  It does not use the
-"null_value" option and it won't read input from a sites file.  It uses
-all of the flags defined for r.drain.  My first draft of the model
-didn't correctly handle the ew,ns and diagonal resolutions (as
-r.fill.dir does not).  I believe that I fixed that problem.  There are
-also some other minor behaviors that differ a little from r.drain.
-r.d2 runs pretty quickly on a small, clean dem, but it can take quite a
-while  to run on a large cell map - particularly one with very many
-areas where the flow directions are ambiguous.  I didn't write anything
-into the program to warn the user about the execution time.
-I tested it on the fcell map that you sent me when this issue first came
-up and on a lat-long cell map.  It worked well in both cases.  The
-version of r.fill.dir that I started with was the version I had archived
-here, which was not updated for all the changes needed to make
-r.fill.dir run on all of our platforms.  I built in the changes that I
-could remember, but there may be a few more that come up when you try to
-compile it on the Cray.
-I hope this meets your needs.
-Roger
Deleted: grass/trunk/raster/r.path/filldir.c
--- grass/trunk/raster/r.drain/filldir.c	2017-12-04 15:37:44 UTC (rev 71888)
+++ grass/trunk/raster/r.path/filldir.c	2017-12-20 22:06:06 UTC (rev 71962)
@@ -1,129 +0,0 @@
-#include <grass/config.h>
-#include <sys/types.h>
-#include <stdlib.h>
-#include <math.h>
-#include <limits.h>
-#include <float.h>
-#include <grass/gis.h>
-#include <grass/raster.h>
-#include "tinf.h"
-#include "local.h"
-/* get the slope between two cells and return a slope direction */
-void check(CELL newdir, CELL * dir, void *center, void *edge, double cnst,
-	   double *oldslope)
-    double newslope;
-    /* never discharge to a null boundary */
-    if (is_null(edge))
-	return;
-    newslope = slope(center, edge, cnst);
-    if (newslope == *oldslope) {
-	*dir += newdir;
-    else if (newslope > *oldslope) {
-	*oldslope = newslope;
-	*dir = newdir;
-    return;
-/* determine the flow direction at each cell on one row */
-void build_one_row(int i, int nl, int ns, struct band3 *bnd, CELL * dir,
-		   struct metrics m)
-    int j, inc;
-    off_t offset;
-    CELL sdir;
-    double slope;
-    char *center;
-    char *edge;
-    inc = bpe();
-    for (j = 0; j < ns; j += 1) {
-	offset = j * bpe();
-	center = bnd->b[1] + offset;
-	if (is_null(center)) {
-	    Rast_set_c_null_value(dir + j, 1);
-	    continue;
-	sdir = 0;
-	/* slope=HUGE; */
-	slope = HUGE_VAL;
-	if (i == 0) {
-	    sdir = 128;
-	else if (i == nl - 1) {
-	    sdir = 8;
-	else if (j == 0) {
-	    sdir = 32;
-	else if (j == ns - 1) {
-	    sdir = 2;
-	else {
-	    /* slope=-HUGE; */
-	    slope = -HUGE_VAL;
-	    /* check one row back */
-	    edge = bnd->b[0] + offset;
-	    check(64, &sdir, center, edge - inc, m.diag_res, &slope);
-	    check(128, &sdir, center, edge, m.ns_res, &slope);
-	    check(1, &sdir, center, edge + inc, m.diag_res, &slope);
-	    /* check this row */
-	    check(32, &sdir, center, center - inc, m.ew_res, &slope);
-	    check(2, &sdir, center, center + inc, m.ew_res, &slope);
-	    /* check one row forward */
-	    edge = bnd->b[2] + offset;
-	    check(16, &sdir, center, edge - inc, m.diag_res, &slope);
-	    check(8, &sdir, center, edge, m.ns_res, &slope);
-	    check(4, &sdir, center, edge + inc, m.diag_res, &slope);
-	if (slope == 0.)
-	    sdir = -sdir;
-	else if (slope < 0.)
-	    sdir = -256;
-	dir[j] = sdir;
-    return;
-void filldir(int fe, int fd, int nl, struct band3 *bnd, struct metrics *m)
-    int i, bufsz;  /* use off_t bufsz for large files ? MM */
-    CELL *dir;
-    /* determine the flow direction in each cell.  On outer rows and columns
-     * the flow direction is always directly out of the map */
-    dir = G_calloc(bnd->ns, sizeof(CELL));
-    bufsz = bnd->ns * sizeof(CELL);
-    lseek(fe, 0, SEEK_SET);
-    lseek(fd, 0, SEEK_SET);
-    advance_band3(fe, bnd);
-    for (i = 0; i < nl; i++) {
-        G_percent(i, nl, 5);
-	build_one_row(i, nl, bnd->ns, bnd, dir, m[i]);
-	write(fd, dir, bufsz);
-    G_percent(1, 1, 1);
-    build_one_row(nl - 1, nl, bnd->ns, bnd, dir, m[nl - 1]);
-    G_free(dir);
-    return;
Modified: grass/trunk/raster/r.path/local.h
--- grass/trunk/raster/r.drain/local.h	2017-12-04 15:37:44 UTC (rev 71888)
+++ grass/trunk/raster/r.path/local.h	2017-12-20 22:06:06 UTC (rev 71962)
@@ -1,3 +1,9 @@
+#define OUT_PID 1
+#define OUT_CNT 2
+#define OUT_CPY 3
+#define OUT_ACC 4
 struct metrics
     double ew_res, ns_res, diag_res;
@@ -2,7 +8 @@
-void filldir(int, int, int, struct band3 *, struct metrics *);
-void resolve(int, int, struct band3 *);
-int dopolys(int, int, int, int);
-void wtrshed(int, int, int, int, int);
-void ppupdate(int, int, int, int, struct band3 *, struct band3 *);
Modified: grass/trunk/raster/r.path/main.c
--- grass/trunk/raster/r.drain/main.c	2017-12-04 15:37:44 UTC (rev 71888)
+++ grass/trunk/raster/r.path/main.c	2017-12-20 22:06:06 UTC (rev 71962)
@@ -1,23 +1,13 @@
- * MODULE:       r.drain
+ * MODULE:       r.path
- * AUTHOR(S):    Kewan Q. Khawaja <kewan techlogix.com>
- *               Update to FP (2000): Pierre de Mouveaux <pmx at audiovu.com> <pmx at free.fr>
- *               bugfix in FCELL, DCELL: Markus Neteler 12/2000
- *               Rewritten by Roger Miller 7/2001 based on subroutines from
- *               r.fill.dir and on the original r.drain.
- *               24 July 2004: WebValley 2004, error checking and vector points added by
- *               Matteo Franchi          Liceo Leonardo Da Vinci Trento
- *               Roberto Flor            ITC-irst
- *               New code added by Colin Nielsen <colin.nielsen at gmail dot com> *
- *               to use movement direction surface from r.walk and r.cost, and to
- *               output vector paths 2/2009
+ * AUTHOR(S):    based on r.drain
+ *               Markus Metz
- * PURPOSE:      This is the main program for tracing out the path that a
- *               drop of water would take if released at a certain location
- *               on an input elevation map.
- * COPYRIGHT:    (C) 2000,2009 by the GRASS Development Team
+ * PURPOSE:      Tracing paths from starting points following
+ *               input directions.
+ * COPYRIGHT:    (C) 2017 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -42,66 +32,100 @@
+#include <grass/vector.h>
 #include <grass/glocale.h>
-#include <grass/vector.h>
-#define DEBUG
-#include "tinf.h"
 #include "local.h"
+#include "pavlrc.h"
 /* should probably be updated to a pointer array & malloc/realloc as needed */
 #define POINTS_INCREMENT 1024
-/* define a data structure to hold the point data */
+/* start points */
 struct point
     int row;
     int col;
+    double value;
     struct point *next;
+/* stack points for bitmask directions */
+struct spoint
+    int row;
+    int col;
+    int dir;
     double value;
+    struct spoint *next;
+/* output path points */
+struct ppoint
+    int row;
+    int col;
+    double value;
+/* managed list of output path points */
+struct point_list
+    struct ppoint *p;
+    int n;
+    int nalloc;
+int dir_degree(int dir_fd, int val_fd, struct point *startp, struct Cell_head *window,
+               struct Map_info *Out, struct point_list *pl, int out_mode);
+int dir_bitmask(int dir_fd, int val_fd, struct point *startp, struct Cell_head *window,
+void pl_add(struct point_list *, struct ppoint *);
+/* comparing path points with qsort */
+int cmp_pp(const void *a, const void *b)
+    const struct ppoint *ap = (const struct ppoint *)a;
+    const struct ppoint *bp = (const struct ppoint *)b;
+    /* 1. ascending by row */
+    if (ap->row != bp->row)
+	return (ap->row - bp->row);
+    /* 2. ascending by col */
+    if (ap->col != bp->col)
+	return (ap->col - bp->col);
+    /* 3. descending by value */
+    if (ap->value > bp->value)
+	return -1;
+    return (ap->value < bp->value);
 int main(int argc, char **argv)
-    int fe, fd, dir_fd;
-    int i, have_points = 0;
-    int new_id;
+    int fd, dir_fd, val_fd;
+    int i, j, have_points = 0;
     int nrows, ncols;
-    int *points_row = NULL, *points_col = NULL, npoints;
-    int increment_count;
-    int cell_open(), cell_open_new();
-    int map_id, dir_id;
-    char map_name[GNAME_MAX], new_map_name[GNAME_MAX], dir_name[GNAME_MAX];
-    char *tempfile1, *tempfile2, *tempfile3;
+    int npoints;
+    int out_id, dir_id;
+    char map_name[GNAME_MAX], out_name[GNAME_MAX], dir_name[GNAME_MAX];
+    char *tempfile1, *tempfile2;
     struct History history;
     struct Cell_head window;
     struct Option *opt1, *opt2, *coordopt, *vpointopt, *opt3, *opt4;
     struct Flag *flag1, *flag2, *flag3, *flag4;
     struct GModule *module;
-    int in_type;
-    void *in_buf;
     void *dir_buf;
-    CELL *out_buf;
-    struct band3 bnd, bndC;
-    struct metrics *m = NULL;
-    struct point *list;
-    struct point *thispoint;
-    int ival, start_row, start_col, mode;
-    off_t bsz;
-    int costmode = 0;
-    double east, north, val;
-    struct point *drain(int, struct point *, int, int);
-    struct point *drain_cost(int, struct point *, int, int);
-    int bsort(int, struct point *);
+    struct point *head_start_pt = NULL;
+    struct point *next_start_pt;
+    struct point_list pl, *ppl;
+    int start_row, start_col, out_mode;
+    double east, north;
     struct line_pnts *Points;
     struct line_cats *Cats;
-    struct Map_info vout;
-    int cat;
-    double x, y;
+    struct Map_info vout, *pvout;
     G_gisinit(argv[0]);
@@ -110,28 +134,28 @@
     G_add_keyword(_("hydrology"));
     G_add_keyword(_("cost surface"));
     module->description =
-	_("Traces a flow through an elevation model or cost surface on a raster map.");
+	_("Traces paths from starting points following input directions.");
     opt1 = G_define_standard_option(G_OPT_R_INPUT);
-    opt1->description = _("Name of input elevation or cost surface raster map");
+    opt1->description = _("Name of input direction");
+	_("Direction in degrees CCW from east, or bitmask encoded (-b flag)");
-    opt3 = G_define_standard_option(G_OPT_R_INPUT);
-    opt3->key = "direction";
-    opt3->label =
-	_("Name of input movement direction map associated with the cost surface");
-    opt3->description =
-	_("Direction in degrees CCW from east");
+    opt2 = G_define_standard_option(G_OPT_R_INPUT);
+    opt2->key = "values";
+    opt2->label =
+	_("Name of input raster values to be used for output");
+    opt2->required = NO;
+    opt3 = G_define_standard_option(G_OPT_R_OUTPUT);
+    opt3->key = "raster_path";
     opt3->required = NO;
-    opt3->guisection = _("Cost surface");
-    opt2 = G_define_standard_option(G_OPT_R_OUTPUT);
+    opt3->label = _("Name for output raster path map");
     opt4 = G_define_standard_option(G_OPT_V_OUTPUT);
-    opt4->key = "drain";
+    opt4->key = "vector_path";
     opt4->required = NO;
-    opt4->label =
-        _("Name for output drain vector map");
-    opt4->description = _("Recommended for cost surface made using knight's move");
+    opt4->label = _("Name for output vector path map");
     coordopt = G_define_standard_option(G_OPT_M_COORDS);
     coordopt->key = "start_coordinates";
@@ -161,76 +185,57 @@
     flag3->guisection = _("Path settings");
     flag4 = G_define_flag();
-    flag4->key = 'd';
+    flag4->key = 'b';
     flag4->description =
-	_("The input raster map is a cost surface (direction surface must also be specified)");
-    flag4->guisection = _("Cost surface");
+	_("The input direction map is bitmask encoded");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
-    strcpy(map_name, opt1->answer);
-    strcpy(new_map_name, opt2->answer);
-    if (flag4->answer) {
-	costmode = 1;
-	G_verbose_message(_("Directional drain selected... checking for direction raster map"));
+    /* check args */
+    if (!opt3->answer && !opt4->answer) {
+	G_fatal_error(_("No output requested"));
-    else {
-	G_verbose_message(_("Surface/Hydrology drain selected"));
-    if (costmode == 1) {
-	if (!opt3->answer) {
-	    G_fatal_error(_("Direction raster map <%s> not specified, if direction flag is on, "
-                            "a direction raster must be given"), opt3->key);
-	strcpy(dir_name, opt3->answer);
+    strcpy(dir_name, opt1->answer);
+    *map_name = '\0';
+    *out_name = '\0';
+    if (opt3->answer) {
+	strcpy(out_name, opt3->answer);
+	if (opt2->answer)
+	    strcpy(map_name, opt2->answer);
-    if (costmode == 0) {
-	if (opt3->answer) {
-	    G_fatal_error(_("Direction raster map <%s> should not be specified for Surface/Hydrology drains"),
-			  opt3->answer);
+    pvout = NULL;
     if (opt4->answer) {
 	if (0 > Vect_open_new(&vout, opt4->answer, 0)) {
             G_fatal_error(_("Unable to create vector map <%s>"),
 			  opt4->answer);
 	Vect_hist_command(&vout);
+	pvout = &vout;
-    /*      allocate cell buf for the map layer */
-    in_type = Rast_map_type(map_name, "");
-    /* set the pointers for multi-typed functions */
-    set_func_pointers(in_type);
     if ((flag1->answer + flag2->answer + flag3->answer) > 1)
 	G_fatal_error(_("Specify just one of the -c, -a and -n flags"));
-    mode = 0;
-    if (flag1->answer)
-	mode = 1;
-    if (flag2->answer)
-	mode = 2;
-    if (flag3->answer)
-	mode = 3;
+    out_mode = OUT_PID;
+    if (opt3->answer && opt2->answer) {
+	if (flag1->answer)
+	    out_mode = OUT_CPY;
+	if (flag2->answer)
+	    out_mode = OUT_ACC;
+	if (flag3->answer)
+	    out_mode = OUT_CNT;
     /* get the window information  */
     G_get_window(&window);
     nrows = Rast_window_rows();
     ncols = Rast_window_cols();
-    /* calculate true cell resolution */
-    m = (struct metrics *)G_malloc(nrows * sizeof(struct metrics));
-    points_row = (int*)G_calloc(POINTS_INCREMENT, sizeof(int));
-    points_col = (int*)G_calloc(POINTS_INCREMENT, sizeof(int));
-    increment_count = 1;
     npoints = 0;
+    /* TODO: use r.cost method to create a list of start points */
     if (coordopt->answer) {
 	for (i = 0; coordopt->answers[i] != NULL; i += 2) {
 	    G_scan_easting(coordopt->answers[i], &east, G_projection());
@@ -244,23 +249,24 @@
 			  i + 1);
 		continue;
-	    points_row[npoints] = start_row;
-	    points_col[npoints] = start_col;
 	    npoints++;
-	    if (npoints == POINTS_INCREMENT * increment_count)
-		increment_count++;
-		points_row = (int*)G_realloc(points_row, POINTS_INCREMENT * increment_count * sizeof(int));
-		points_col = (int*)G_realloc(points_col, POINTS_INCREMENT * increment_count * sizeof(int));
 	    have_points = 1;
+	    next_start_pt =
+		(struct point *)(G_malloc(sizeof(struct point)));
+	    next_start_pt->row = start_row;
+	    next_start_pt->col = start_col;
+	    next_start_pt->value = npoints;
+	    next_start_pt->next = head_start_pt;
+	    head_start_pt = next_start_pt;
     if (vpointopt->answers) {
 	for (i = 0; vpointopt->answers[i] != NULL; i++) {
 	    struct Map_info In;
 	    struct bound_box box;
-	    int type;
+	    int cat, type;
 	    Points = Vect_new_line_struct();
 	    Cats = Vect_new_cats_struct();
@@ -276,6 +282,7 @@
 	    Vect_rewind(&In);
 	    Vect_region_box(&window, &box);
+	    box.T = box.B = 0;
 	    while (1) {
 		/* register line */
@@ -300,16 +307,18 @@
 		    start_col > ncols)
 		    continue;
 		npoints++;
 		have_points = 1;
+		next_start_pt =
+		Vect_cat_get(Cats, 1, &cat);
+		next_start_pt->value = cat;
 	    Vect_close(&In);
@@ -323,360 +332,604 @@
     if (have_points == 0)
-	G_fatal_error(_("No start/stop point(s) specified"));
+	G_fatal_error(_("No start point(s) specified"));
     /* determine the drainage paths */
-    /* allocate storage for the first point */
-    thispoint = (struct point *)G_malloc(sizeof(struct point));
-    list = thispoint;
-    thispoint->next = NULL;
+    /* get some temp files */
+    val_fd = -1;
+    tempfile1 = NULL;
+    if (opt2->answer && opt3->answer) {
+	DCELL *map_buf;
-    G_begin_distance_calculations();
-	double e1, n1, e2, n2;
+	tempfile1 = G_tempfile();
+	val_fd = open(tempfile1, O_RDWR | O_CREAT, 0666);
-	e1 = window.east;
-	n1 = window.north;
-	e2 = e1 + window.ew_res;
-	n2 = n1 - window.ns_res;
+	map_buf = Rast_allocate_d_buf();
+	fd = Rast_open_old(map_name, "");
+	/* transfer the values map to a temp file */
 	for (i = 0; i < nrows; i++) {
-	    m[i].ew_res = G_distance(e1, n1, e2, n1);
-	    m[i].ns_res = G_distance(e1, n1, e1, n2);
-	    m[i].diag_res = G_distance(e1, n1, e2, n2);
+	    Rast_get_d_row(fd, map_buf, i);
+	    if (write(val_fd, map_buf, ncols * sizeof(DCELL)) !=
+	        ncols * sizeof(DCELL)) {
+		G_fatal_error(_("Unable to write to tempfile"));
+	Rast_close(fd);
+	G_free(map_buf);
-    /* buffers for internal use */
-    bndC.ns = ncols;
-    bndC.sz = sizeof(CELL) * ncols;
-    bndC.b[0] = G_calloc(ncols, sizeof(CELL));
-    bndC.b[1] = G_calloc(ncols, sizeof(CELL));
-    bndC.b[2] = G_calloc(ncols, sizeof(CELL));
-    /* buffers for external use */
-    bnd.ns = ncols;
-    bnd.sz = ncols * bpe();
-    bnd.b[0] = G_calloc(ncols, bpe());
-    bnd.b[1] = G_calloc(ncols, bpe());
-    bnd.b[2] = G_calloc(ncols, bpe());
-    /* an input buffer */
-    in_buf = get_buf();
-    /* open the original map and get its file id  */
-    map_id = Rast_open_old(map_name, "");
-    /* get some temp files */
-    tempfile1 = G_tempfile();
+    dir_id = Rast_open_old(dir_name, "");
     tempfile2 = G_tempfile();
+    dir_fd = open(tempfile2, O_RDWR | O_CREAT, 0666);
-    fe = open(tempfile1, O_RDWR | O_CREAT, 0666);
-    fd = open(tempfile2, O_RDWR | O_CREAT, 0666);
-    /* transfer the input map to a temp file */
-    for (i = 0; i < nrows; i++) {
-	get_row(map_id, in_buf, i);
-	write(fe, in_buf, bnd.sz);
+    if (flag4->answer) {
+	dir_buf = Rast_allocate_c_buf();
+	for (i = 0; i < nrows; i++) {
+	    Rast_get_c_row(dir_id, dir_buf, i);
+	    if (write(dir_fd, dir_buf, ncols * sizeof(CELL)) !=
+	        ncols * sizeof(CELL)) {
-    Rast_close(map_id);
+    else {
 	dir_buf = Rast_allocate_d_buf();
-	dir_id = Rast_open_old(dir_name, "");
-	tempfile3 = G_tempfile();
-	dir_fd = open(tempfile3, O_RDWR | O_CREAT, 0666);
 	    Rast_get_d_row(dir_id, dir_buf, i);
-	    write(dir_fd, dir_buf, ncols * sizeof(DCELL));
+	    if (write(dir_fd, dir_buf, ncols * sizeof(DCELL)) !=
-	Rast_close(dir_id);
+    Rast_close(dir_id);
+    G_free(dir_buf);
-    /* only necessary for non-dir drain */
-	G_message(_("Calculating flow directions..."));
+    ppl = NULL;
+	/* raster output */
+	pl.p = NULL;
+	pl.n = 0;
+	pl.nalloc = 0;
+	ppl = &pl;
-	/* fill one-cell pits and take a first stab at flow directions */
-	filldir(fe, fd, nrows, &bnd, m);
+    /* determine the drainage paths */
-	/* determine flow directions for more ambiguous cases */
-	resolve(fd, nrows, &bndC);
+    /* repeat for each starting point */
-    /* free the buffers already used */
-    G_free(bndC.b[0]);
-    G_free(bndC.b[1]);
-    G_free(bndC.b[2]);
+    next_start_pt = head_start_pt;
+    while (next_start_pt) {
+	/* follow directions from start points to determine paths */
+	/* path tracing algorithm selection */
+	    struct Map_info Tmp;
-    G_free(bnd.b[0]);
-    G_free(bnd.b[1]);
-    G_free(bnd.b[2]);
+	    if (pvout) {
+		if (Vect_open_tmp_new(&Tmp, NULL, 0) < 0)
+		    G_fatal_error(_("Unable to create temporary vector map"));
+		pvout = &Tmp;
-    /* determine the drainage paths */
-    /* repeat for each starting point */
-    for (i = 0; i < npoints; i++) {
-	/* use the flow directions to determine the drainage path
-	 * results are compiled as a linked list of points in downstream order */
-	thispoint->row = points_row[i];
-	thispoint->col = points_col[i];
-	/* drain algorithm selection (dir or non-dir) */
-	    thispoint = drain(fd, thispoint, nrows, ncols);
+	    if (!dir_bitmask(dir_fd, val_fd, next_start_pt, &window,
+                             pvout, ppl, out_mode)) {
+		G_warning(_("No path at row %d, col %d"),
+		          next_start_pt->row, next_start_pt->col);
+	    if (pvout) {
+		Vect_build_partial(&Tmp, GV_BUILD_BASE);
+		G_message(_("Breaking lines..."));
+		Vect_break_lines(&Tmp, GV_LINE, NULL);
+		Vect_copy_map_lines(&Tmp, &vout);
+		Vect_set_release_support(&Tmp);
+		Vect_close(&Tmp); /* temporary map is deleted automatically */
+		pvout = &vout;
-	    thispoint = drain_cost(dir_fd, thispoint, nrows, ncols);
+	else {
+	    if (!dir_degree(dir_fd, val_fd, next_start_pt, &window,
+	next_start_pt = next_start_pt->next;
-    /* do the output */
+	int row;
-    if (mode == 0 || mode == 3) {
+	if (pl.n > 1) {
+	    /* sort points */
+	    qsort(pl.p, pl.n, sizeof(struct ppoint), cmp_pp);
-	/* Output will be a cell map */
-	/* open a new file and allocate an output buffer */
-	new_id = Rast_open_c_new(new_map_name);
-	out_buf = Rast_allocate_c_buf();
-	/* mark each cell */
-	thispoint = list;
-	while (thispoint->next != NULL) {
-	    thispoint->value = 1;
-	    thispoint = thispoint->next;
-	if (mode == 3) {
-	    /* number each cell downstream */
-	    thispoint = list;
-	    ival = 0;
-		if (thispoint->row == INT_MAX) {
-		    ival = 0;
-		    continue;
+	    /* remove duplicates */
+	    j = 1;
+	    for (i = 1; i < pl.n; i++) {
+		if (pl.p[j - 1].row != pl.p[i].row ||
+		    pl.p[j - 1].col != pl.p[i].col) {
+		    pl.p[j].row = pl.p[i].row;
+		    pl.p[j].col = pl.p[i].col;
+		    pl.p[j].value = pl.p[i].value;
+		    j++;
-		thispoint->value += ival;
-		ival = thispoint->value;
+	    pl.n = j;
-	/* build the output map */
-	G_message(_("Writing output raster map..."));
-	    G_percent(i, nrows, 2);
-	    Rast_set_c_null_value(out_buf, ncols);
-	    thispoint = list;
-		if (thispoint->row == i)
-		    out_buf[thispoint->col] = (int)thispoint->value;
-	    Rast_put_c_row(new_id, out_buf);
-    else {			/* mode = 1 or 2 */
-	/* Output will be of the same type as input */
-	new_id = Rast_open_new(new_map_name, in_type);
-	out_buf = get_buf();
-	bsz = ncols * bpe();
+	if (out_mode == OUT_PID || out_mode == OUT_CNT) {
+	    CELL *out_buf;
-	/* loop through each point in the list and store the map values */
-	thispoint = list;
-		continue;
+	    /* Output will be a cell map */
+	    /* open a new file and allocate an output buffer */
+	    out_id = Rast_open_c_new(out_name);
+	    out_buf = Rast_allocate_c_buf();
+	    Rast_set_c_null_value(out_buf, window.cols);
+	    row = 0;
+	    /* build the output map */
+	    G_message(_("Writing output raster map..."));
+	    for (i = 0; i < pl.n; i++) {
+		while (row < pl.p[i].row) {
+		    G_percent(row, nrows, 2);
+		    Rast_put_c_row(out_id, out_buf);
+		    row++;
+		out_buf[pl.p[i].col] = pl.p[i].value;
-	    lseek(fe, (off_t) thispoint->row * bsz, SEEK_SET);
-	    read(fe, in_buf, bsz);
-	    memcpy(&thispoint->value, (char *)in_buf + bpe() * thispoint->col,
-		   bpe());
+	    while (row < window.rows) {
+		row++;
+	    G_percent(1, 1, 1);
+	    G_free(out_buf);
+	else {			/* mode = OUT_CPY or OUT_ACC */
+	    DCELL *out_buf;
-	if (mode == 2) {
-	    /* accumulate the input map values downstream */
-	    thispoint = list;
-	    val = 0.;
-		    val = 0.;
-		    continue;
+	    /* Output could be of the same type as input */
+	    out_id = Rast_open_new(out_name, DCELL_TYPE);
+	    out_buf = Rast_allocate_d_buf();
+	    Rast_set_d_null_value(out_buf, window.cols);
+	    row = 0;
+		    Rast_put_d_row(out_id, out_buf);
+		    row++;
-		sum(&thispoint->value, &val);
-		memcpy(&val, &thispoint->value, bpe());
+		row++;
+	    G_free(out_buf);
-	G_message(_("Writing raster map <%s>..."),
-		  new_map_name);
-	    set_null_value(out_buf, ncols);
-	    thispoint = list;
-		    memcpy((char *)out_buf + bpe() * thispoint->col,
-			   &(thispoint->value), bpe());
-	    put_row(new_id, out_buf);
+	Rast_close(out_id);
+	Rast_put_cell_title(out_name, "Path trace");
+	Rast_short_history(out_name, "raster", &history);
+	Rast_command_history(&history);
+	Rast_write_history(out_name, &history);
-    /* Output a vector path */
+    /* vector output */
     if (opt4->answer) {
-	Points = Vect_new_line_struct();
-	Cats = Vect_new_cats_struct();
-	/* Need to modify for multiple paths */
-	thispoint = list;
-	i = 1;
-		Vect_cat_set(Cats, 1, i);
-		Vect_write_line(&vout, GV_LINE, Points, Cats);
-		Vect_reset_line(Points);
-		Vect_reset_cats(Cats);
-		i++;
-		continue;
-	    if (Vect_cat_get(Cats, 1, &cat) == 0) {
-	    /* Need to convert row and col to coordinates
-	     *      y = cell_head.north - ((double) p->row + 0.5) * cell_head.ns_res;
-	     *  x = cell_head.west + ((double) p->col + 0.5) * cell_head.ew_res;
-	    x = window.west + ((double)thispoint->col + 0.5) * window.ew_res;
-	    y = window.north - ((double)thispoint->row + 0.5) * window.ns_res;
-	    Vect_append_point(Points, x, y, 0.0);
-	}			/* End while */
 	Vect_build(&vout);
 	Vect_close(&vout);
     /* close files and free buffers */
-    Rast_close(new_id);
-    Rast_put_cell_title(new_map_name, "Surface flow trace");
-    Rast_short_history(new_map_name, "raster", &history);
-    Rast_command_history(&history);
-    Rast_write_history(new_map_name, &history);
-    close(fe);
-    close(fd);
-    unlink(tempfile1);
+    close(dir_fd);
     unlink(tempfile2);
-    G_free(in_buf);
-    G_free(out_buf);
-    if(points_row)
-	G_free(points_row);
-    if(points_col)
-	G_free(points_col);
-	close(dir_fd);
-	unlink(tempfile3);
-	G_free(dir_buf);
+	close(val_fd);
+	unlink(tempfile1);
     exit(EXIT_SUCCESS);
-struct point *drain(int fd, struct point *list, int nrow, int ncol)
+void pl_add(struct point_list *pl, struct ppoint *p)
-    int go = 1, next_row, next_col;
+    if (pl->n == pl->nalloc) {
+	pl->nalloc += POINTS_INCREMENT;
+	pl->p = (struct ppoint *)G_realloc(pl->p, pl->nalloc * sizeof(struct ppoint));
+	if (!pl->p)
+	    G_fatal_error(_("Unable to increase point list"));
+    pl->p[pl->n] = *p;
+    pl->n++;
+/* Jenson Domingue 1988, r.fill.dir:
+ * bitmask encoded directions CW from North
+ * value    log2(value)   direction
+ *     1	    0		NE
+ *     2	    1		E
+ *     4	    2		SE
+ *     8	    3		S
+ *    16	    4		SW
+ *    32	    5		W
+ *    64	    6		NW
+ *   128	    7		N
+ *   256	    8		NEN
+ *   512	    9		ENE
+ *  1024	   10		ESE
+ *  2048	   11		SES
+ *  4096	   12		SWS
+ *  8192	   13		WSW
+ * 16384	   14		WNW
+ * 32768	   15		NWN
+ * 8 neighbours
+ *  64 128 1
+ *  32  x  2
+ *  16  8  4
+ * log2(value) CW from North starting at NE
+ * expanded for Knight's move
+ *    15     8
+ *  14 6  7  0  9
+ *     5  X  1
+ *  13 4  3  2 10
+ *    12    11
+    int go = 1, next_row, next_col, next_dir;
+    int npoints;
+    int dir_row = -1, val_row = -1;
     CELL direction;
-    CELL *dir;
+    CELL *dir_buf;
+    DCELL *val_buf;
+    struct spoint *stackp, *newp;
+    struct pavlrc_table *visited;
+    struct pavlrc ngbr_rc;
+    struct ppoint pp;
+    int is_stack;
+    int cur_dir, i, npaths;
+    struct line_pnts *Points;
+    struct line_cats *Cats;
+    double x, y;
+    double value;
+    int col_offset[16] = { 1, 1, 1, 0, -1, -1, -1, 0,
+	                   1, 2, 2, 1, -1, -2, -2, -1 };
+    int row_offset[16] = { -1, 0, 1, 1, 1, 0, -1, -1,
+	                   -2, -1, 1, 2, 2, 1, -1, -2 };
-    dir = Rast_allocate_c_buf();
-    next_row = list->row;
-    next_col = list->col;
+    val_buf = NULL;
-    /* begin loop */
-    while (go) {
+    stackp = (struct spoint *)G_malloc(sizeof(struct spoint));
-	/* find flow direction at this point */
-	lseek(fd, (off_t) list->row * ncol * sizeof(CELL), SEEK_SET);
-	read(fd, dir, ncol * sizeof(CELL));
-	direction = *(dir + list->col);
-	go = 0;
+    stackp->row = startp->row;
+    stackp->col = startp->col;
+    stackp->value = startp->value;
+    value = startp->value;
+    stackp->dir = -1;
+    stackp->next = NULL;
-	/* identify next downstream cell */
-	if (direction > 0 && direction < 256) {
+    visited = pavlrc_create(NULL);
+    ngbr_rc.row = stackp->row;
+    ngbr_rc.col = stackp->col;
+    pavlrc_insert(visited, &ngbr_rc);
-	    if (direction == 1 || direction == 2 || direction == 4)
-		next_col += 1;
-	    else if (direction == 16 || direction == 32 || direction == 64)
-		next_col -= 1;
+    if (Out) {
+	Points = Vect_new_line_struct();
+	Cats = Vect_new_cats_struct();
+	Vect_cat_set(Cats, 1, (int)stackp->value);
-	    if (direction == 64 || direction == 128 || direction == 1)
-		next_row -= 1;
-	    else if (direction == 4 || direction == 8 || direction == 16)
-		next_row += 1;
-	    if (next_col >= 0 && next_col < ncol
-		&& next_row >= 0 && next_row < nrow) {
-		/* allocate and fill the next point structure */
-		list->next = (struct point *)G_malloc(sizeof(struct point));
-		list = list->next;
-		list->row = next_row;
-		list->col = next_col;
-		go = 1;
+    if (pl) {
+	if (out_mode == OUT_CNT)
+	    value = 1;
+	else if (out_mode == OUT_CPY || out_mode == OUT_ACC) {
+	    /* read input raster */
+	    val_buf = Rast_allocate_d_buf();
+	    if (val_row != stackp->row) {
+		lseek(val_fd, (off_t) stackp->row * window->cols * sizeof(DCELL),
+		      SEEK_SET);
+		if (read(val_fd, val_buf, window->cols * sizeof(DCELL)) !=
+		    window->cols * sizeof(DCELL)) {
+		    G_fatal_error(_("Unable to read from temp file"));
+		val_row = stackp->row;
+	    value = val_buf[stackp->col];
-    }				/* end while */
+	stackp->value = value;
-    /* allocate and fill the end-of-path flag */
-    list->row = INT_MAX;
+    /* multi-path tracing:
+     * multiple paths from the same starting point */
-    /* return a pointer to an empty structure */
-    list->next = NULL;
+    npoints = 0;
+    while (stackp) {
+	is_stack = 1;
+	stackp->dir++;
+	next_row = stackp->row;
+	next_col = stackp->col;
+	value = stackp->value;
-    G_free(dir);
+	/* begin loop */
+	go = 1;
+	while (go) {
+	    go = 0;
-    return list;
+	    /* find direction from this point */
+	    if (dir_row != next_row) {
+		lseek(dir_fd, (off_t) next_row * window->cols * sizeof(CELL),
+		      SEEK_SET);
+		if (read(dir_fd, dir_buf, window->cols * sizeof(CELL)) !=
+		    window->cols * sizeof(CELL)) {
+		dir_row = next_row;
+	    direction = *(dir_buf + next_col);
+	    if (direction <= 0 || Rast_is_c_null_value(&direction)) {
+		/* end of current path: write out the result */
+		if (Out && Points->n_points > 1) {
+		    Vect_write_line(Out, GV_LINE, Points, Cats);
+		/* leave this loop */
+		break;
+	    /* start direction */
+	    cur_dir = 0;
+	    if (is_stack)
+		cur_dir = stackp->dir;
+	    /* count paths going from current point and
+	     * get next direction as log2(direction) */
+	    next_dir = -1;
+	    npaths = 0;
+	    for (i = cur_dir; i < 16; i++) {
+		if ((direction & (1 << i)) != 0) {
+		    npaths++;
+		    if (next_dir < 0)
+			next_dir = i;
+	    if (is_stack) {
+		if (npaths > 0) {
+		    stackp->dir = next_dir;
+		    /* start a new path */
+		    if (Out) {
+			Vect_reset_line(Points);
+			x = window->west + (next_col + 0.5) * window->ew_res;
+			y = window->north - (next_row + 0.5) * window->ns_res;
+			Vect_append_point(Points, x, y, 0.0);
+		    if (pl) {
+			pp.row = next_row;
+			pp.col = next_col;
+			pp.value = value;
+			pl_add(pl, &pp);
+		    npoints++;
+		else {
+		    /* stack point without path ? */
+		    if (stackp->dir == 0)
+			G_warning(_("No path from row %d, col %d"),
+			          stackp->row, stackp->col);
+		    /* drop this point from the stack */
+		    G_debug(1, "drop point from stack");
+		    newp = stackp->next;
+		    G_free(stackp);
+		    stackp = newp;
+		    break;
+	    else { /* not a stack point */
+		if (npaths == 0) {
+		    /* should not happen */
+		    G_fatal_error(_("Invalid direction %d"), direction);
+		if (npaths > 1) {
+		    /* write out the result */
+		    ngbr_rc.row = next_row;
+		    ngbr_rc.col = next_col;
+		    /* add it to the stack and leave this loop */
+		    G_debug(1, "add point to stack: row %d, col %d, dir %d",
+			    next_row, next_col, next_dir);
+		    newp = (struct spoint *)G_malloc(sizeof(struct spoint));
+		    newp->row = next_row;
+		    newp->col = next_col;
+		    newp->dir = next_dir - 1;
+		    newp->value = value;
+		    newp->next = stackp;
+		    stackp = newp;
+		    break;
+	    is_stack = 0;
+	    /* identify next downstream cell */
+	    next_row += row_offset[next_dir];
+	    next_col += col_offset[next_dir];
+	    G_debug(1, "next cell at row %d, col %d", next_row, next_col);
+	    if (next_col >= 0 && next_col < window->cols
+		&& next_row >= 0 && next_row < window->rows) {
+		/* add point */
+		if (Out) {
+		if (pl) {
+			value += 1;
+			if (val_row != next_row) {
+			    lseek(val_fd, (off_t) next_row * window->cols * sizeof(DCELL),
+			          SEEK_SET);
+			    val_row = next_row;
+			if (out_mode == OUT_CPY)
+			    value = val_buf[next_col];
+			else
+			    value += val_buf[next_col];
+		    pp.value = value;
+		    pl_add(pl, &pp);
+		/* avoid circular paths
+		 * avoid tracing the same path segment several times:
+		 * a path can split and later on merge again,
+		 * then split again, merge again
+		 * path segments are identical from every merge point
+		 * to the next split point */
+		if (!pavlrc_insert(visited, &ngbr_rc)) {
+		    go = 1;
+		    npoints++;
+		else {
+		    /* reached a merge point */
+	    else {
+		G_warning(_("Path is leaving the current region"));
+	}				/* end while */
+    pavlrc_destroy(visited);
+    G_free(dir_buf);
+    if (val_buf)
+	G_free(val_buf);
+    if (Out) {
+	Vect_destroy_line_struct(Points);
+	Vect_destroy_cats_struct(Cats);
+    return (npoints > 1);
-struct point *drain_cost(int dir_fd, struct point *list, int nrow, int ncol)
      * The idea is that each cell of the direction surface has a value representing
      * the direction towards the next cell in the path. The direction is read from
      * the input raster, and a simple case/switch is used to determine which cell to
      * read next. This is repeated via a while loop until a null direction is found.
+     * directions are degrees CCW from East with East = 360
     int neighbour, next_row, next_col, go = 1;
+    int npoints;
     DCELL direction;
     DCELL *dir_buf;
+    DCELL *val_buf;
+    double x, y;
+    double value;
+    struct ppoint pp;
+    val_buf = NULL;
+    next_row = startp->row;
+    next_col = startp->col;
+    if (Out) {
+	Vect_cat_set(Cats, 1, (int)value);
+    if (pl) {
+	    value = 1;
+		      SEEK_SET);
+	pp.value = value;
+	pl_add(pl, &pp);
+    npoints = 1;
     while (go) {
 	go = 0;
 	/* Directional algorithm
@@ -684,108 +937,142 @@
 	 * 2) shift to cell in that direction
 	/* find the direction recorded at row,col */
-	lseek(dir_fd, (off_t) list->row * ncol * sizeof(DCELL), SEEK_SET);
-	read(dir_fd, dir_buf, ncol * sizeof(DCELL));
-	direction = *(dir_buf + list->col);
-	neighbour = direction * 10;
-	if (G_verbose() > 2)
-	    G_message(_("direction read: %lf, neighbour found: %i"),
-		      direction, neighbour);
+	    lseek(dir_fd, (off_t) next_row * window->cols * sizeof(DCELL),
+	          SEEK_SET);
+	    if (read(dir_fd, dir_buf, window->cols * sizeof(DCELL)) !=
+	neighbour = 0;
+	if (!Rast_is_d_null_value(&direction)) {
+	    neighbour = direction * 10;
+	    G_debug(2, "direction read: %lf, neighbour found: %i",
+			  direction, neighbour);
 	switch (neighbour) {
 	case 225: /* ENE */
-	    next_row = list->row - 1;
-	    next_col = list->col + 2;
+	    next_row -= 1;
+	    next_col += 2;
 	    break;
 	case 450: /* NE */
-	    next_col = list->col + 1;
+	    next_row -= 1;
+	    next_col += 1;
 	    break;
 	case 675: /* NNE */
-	    next_row = list->row - 2;
+	    next_row -= 2;
+	    next_col += 1;
 	    break;
 	case 900: /* N */
+	    next_row -= 1;
 	    break;
 	case 1125: /* NNW */
-	    next_col = list->col - 1;
+	    next_row -= 2;
+	    next_col -= 1;
 	    break;
 	case 1350: /* NW */
+	    next_col -= 1;
+	    next_row -= 1;
 	    break;
 	case 1575: /* WNW */
-	    next_col = list->col - 2;
+	    next_col -= 2;
+	    next_row -= 1;
 	    break;
 	case 1800: /* W*/
+	    next_col -= 1;
 	    break;
 	case 2025: /* WSW */
-	    next_row = list->row + 1;
+	    next_row += 1;
+	    next_col -= 2;
 	    break;
 	case 2250: /* SW */
+	    next_row += 1;
+	    next_col -= 1;
 	    break;
 	case 2475: /* SSW */
-	    next_row = list->row + 2;
+	    next_row += 2;
+	    next_col -= 1;
 	    break;
 	case 2700: /* S */
+	    next_row += 1;
 	    break;
 	case 2925: /* SSE */
+	    next_row += 2;
+	    next_col += 1;
 	    break;
 	case 3150: /* SE */
+	    next_row += 1;
+	    next_col += 1;
 	    break;
 	case 3375: /* ESE */
+	    next_row += 1;
+	    next_col += 2;
 	    break;
 	case 3600: /* E */
+	    next_col += 1;
 	    break;
-	    /* default:
-	       break;
-	       Should probably add something here for the possibility of a non-direction map
-	       G_fatal_error(_("Invalid direction given (possibly not a direction map)")); */
+	default:
+	    /* end of path */
+	    next_row = -1;
+	    next_col = -1;
+            break;
 	}			/* end switch/case */
-	if (next_col >= 0 && next_col < ncol && next_row >= 0 &&
-	    next_row < nrow) {
-	    next_row = -1;
-	    next_col = -1;
+	if (next_col >= 0 && next_col < window->cols && next_row >= 0 &&
+	    next_row < window->rows) {
+	    if (Out) {
+	    if (pl) {
+		    value += 1;
+			      SEEK_SET);
+		    else
+		pp.value = value;
+		pl_add(pl, &pp);
 	    go = 1;
+	    npoints++;
     }				/* end while */
     G_free(dir_buf);
+    if (val_buf)
+	G_free(val_buf);
-    return list;
+    if (Out) {
Added: grass/trunk/raster/r.path/pavlrc.c
--- grass/trunk/raster/r.path/pavlrc.c	                        (rev 0)
+++ grass/trunk/raster/r.path/pavlrc.c	2017-12-20 22:06:06 UTC (rev 71962)
@@ -0,0 +1,843 @@
+/* Produced by texiweb from libavl.w. */
+/* libavl - library for manipulation of binary trees.
+   Copyright (C) 1998, 1999, 2000, 2001, 2002, 2004 Free Software
+   Foundation, Inc.
+   This library is free software; you can redistribute it and/or
+   modify it under the terms of the GNU Lesser General Public
+   License as published by the Free Software Foundation; either
+   version 3 of the License, or (at your option) any later version.
+   This library is distributed in the hope that it will be useful,
+   but WITHOUT ANY WARRANTY; without even the implied warranty of
+   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+   Lesser General Public License for more details.
+   You should have received a copy of the GNU Lesser General Public
+   License along with this library; if not, write to the Free Software
+   Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA
+   02110-1301 USA.
+/* Nov 2016, Markus Metz
+ * from libavl-2.0.3
+ * added safety checks and speed optimizations
+#include <assert.h>
+#include <stdio.h>
+#include <stdlib.h>
+#define CMP_RC(a, b) ((a)->row == (b)->row ? (a)->col - (b)->col : (a)->row - (b)->row)
+/* Creates and returns a new table
+   with comparison function |compare| using parameter |param|
+   and memory allocator |allocator|.
+   Returns |NULL| if memory allocation failed. */
+struct pavlrc_table *pavlrc_create(struct libavl_allocator *allocator)
+    struct pavlrc_table *tree;
+    if (allocator == NULL)
+	allocator = &pavlrc_allocator_default;
+    tree = allocator->libavl_malloc(allocator, sizeof *tree);
+    if (tree == NULL)
+	return NULL;
+    tree->pavl_root = NULL;
+    tree->pavl_alloc = allocator;
+    tree->pavl_count = 0;
+    return tree;
+/* Search |tree| for an item matching |item|, and return it if found.
+   Otherwise return |NULL|. */
+struct pavlrc *pavlrc_find(const struct pavlrc_table *tree, const struct pavlrc *item)
+    struct pavlrc_node *p;
+    assert(tree != NULL && item != NULL);
+    p = tree->pavl_root;
+    while (p != NULL) {
+	int cmp = CMP_RC(item, &p->pavl_data);
+	if (cmp == 0)
+	    return &p->pavl_data;
+	p = p->pavl_link[cmp > 0];
+    return NULL;
+/* Inserts |item| into |tree| and returns a pointer to |item|.
+   If a duplicate item is found in the tree,
+   returns a pointer to the duplicate without inserting |item|.
+   Returns |NULL| in case of memory allocation failure. */
+struct pavlrc *pavlrc_probe(struct pavlrc_table *tree, struct pavlrc *item)
+    struct pavlrc_node *y;	/* Top node to update balance factor, and parent. */
+    struct pavlrc_node *p, *q;	/* Iterator, and parent. */
+    struct pavlrc_node *n;	/* Newly inserted node. */
+    struct pavlrc_node *w;	/* New root of rebalanced subtree. */
+    int dir;			/* Direction to descend. */
+    y = p = tree->pavl_root;
+    q = NULL;
+    dir = 0;
+	if (cmp == 0)
+	dir = cmp > 0;
+	if (p->pavl_balance != 0)
+	    y = p;
+	q = p, p = p->pavl_link[dir];
+    n = tree->pavl_alloc->libavl_malloc(tree->pavl_alloc, sizeof *p);
+    if (n == NULL)
+	return NULL;
+    tree->pavl_count++;
+    n->pavl_link[0] = n->pavl_link[1] = NULL;
+    n->pavl_parent = q;
+    n->pavl_data = *item;
+    n->pavl_balance = 0;
+    if (q == NULL) {
+	tree->pavl_root = n;
+	return item /* &n->pavl_data */;
+    q->pavl_link[dir] = n;
+    p = n;
+    while (p != y) {
+	q = p->pavl_parent;
+	   dir = q->pavl_link[0] != p;
+	   if (dir == 0)
+	   q->pavl_balance--;
+	   else
+	   q->pavl_balance++;
+	if (q->pavl_link[0] != p)
+	else
+	p = q;
+    if (y->pavl_balance == -2) {
+	struct pavlrc_node *x = y->pavl_link[0];
+	if (x->pavl_balance == -1) {
+	    w = x;
+	    y->pavl_link[0] = x->pavl_link[1];
+	    x->pavl_link[1] = y;
+	    x->pavl_balance = y->pavl_balance = 0;
+	    x->pavl_parent = y->pavl_parent;
+	    y->pavl_parent = x;
+	    if (y->pavl_link[0] != NULL)
+		y->pavl_link[0]->pavl_parent = y;
+	else {
+	    assert(x->pavl_balance == +1);
+	    w = x->pavl_link[1];
+	    x->pavl_link[1] = w->pavl_link[0];
+	    w->pavl_link[0] = x;
+	    y->pavl_link[0] = w->pavl_link[1];
+	    w->pavl_link[1] = y;
+	    if (w->pavl_balance == -1)
+		x->pavl_balance = 0, y->pavl_balance = +1;
+	    else if (w->pavl_balance == 0)
+	    else		/* |w->pavl_balance == +1| */
+		x->pavl_balance = -1, y->pavl_balance = 0;
+	    w->pavl_balance = 0;
+	    w->pavl_parent = y->pavl_parent;
+	    x->pavl_parent = y->pavl_parent = w;
+	    if (x->pavl_link[1] != NULL)
+		x->pavl_link[1]->pavl_parent = x;
+    else if (y->pavl_balance == +2) {
+	struct pavlrc_node *x = y->pavl_link[1];
+	if (x->pavl_balance == +1) {
+	    w = x;
+	    y->pavl_link[1] = x->pavl_link[0];
+	    x->pavl_link[0] = y;
+	    if (y->pavl_link[1] != NULL)
+		y->pavl_link[1]->pavl_parent = y;
+	else {
+	    assert(x->pavl_balance == -1);
+	    w = x->pavl_link[0];
+	    x->pavl_link[0] = w->pavl_link[1];
+	    w->pavl_link[1] = x;
+	    y->pavl_link[1] = w->pavl_link[0];
+	    w->pavl_link[0] = y;
+	    if (w->pavl_balance == +1)
+		x->pavl_balance = 0, y->pavl_balance = -1;
+	    else		/* |w->pavl_balance == -1| */
+		x->pavl_balance = +1, y->pavl_balance = 0;
+	    if (x->pavl_link[0] != NULL)
+		x->pavl_link[0]->pavl_parent = x;
+    else
+    if (w->pavl_parent != NULL)
+	w->pavl_parent->pavl_link[y != w->pavl_parent->pavl_link[0]] = w;
+    else
+	tree->pavl_root = w;
+/* Inserts |item| into |table|.
+   Returns |NULL| if |item| was successfully inserted
+   or if a memory allocation error occurred.
+   Otherwise, returns the duplicate item. */
+struct pavlrc *pavlrc_insert(struct pavlrc_table *table, struct pavlrc *item)
+    struct pavlrc *p = pavlrc_probe(table, item);
+    return p == NULL || p == item ? NULL : p;
+/* Inserts |item| into |table|, replacing any duplicate item.
+   Returns |NULL| if |item| was inserted without replacing a duplicate,
+   Otherwise, returns the item that was replaced. */
+struct pavlrc *pavlrc_replace(struct pavlrc_table *table, struct pavlrc *item)
+    if (p == NULL || p == item)
+	return NULL;
+    else {
+	struct pavlrc *r = p;
+	*p = *item;
+	return r;
+/* Deletes from |tree| and returns an item matching |item|.
+   Returns a null pointer if no matching item found. */
+struct pavlrc *pavlrc_delete(struct pavlrc_table *tree, struct pavlrc *item)
+    struct pavlrc_node *p;	/* Traverses tree to find node to delete. */
+    struct pavlrc_node *q;	/* Parent of |p|. */
+    int dir;			/* Side of |q| on which |p| is linked. */
+    int cmp;			/* Result of comparison between |item| and |p|. */
+    dir = 0;
+	cmp = CMP_RC(item, &p->pavl_data);
+	if (cmp == 0)
+	    break;
+	dir = cmp > 0;
+	p = p->pavl_link[dir];
+    if (p == NULL)
+	return NULL;
+    /* item = p->pavl_data; */
+    if (q == NULL) {
+	q = (struct pavlrc_node *)&tree->pavl_root;
+	dir = 0;
+    if (p->pavl_link[1] == NULL) {
+	q->pavl_link[dir] = p->pavl_link[0];
+	if (q->pavl_link[dir] != NULL)
+	    q->pavl_link[dir]->pavl_parent = p->pavl_parent;
+    else {
+	struct pavlrc_node *r = p->pavl_link[1];
+	if (r->pavl_link[0] == NULL) {
+	    r->pavl_link[0] = p->pavl_link[0];
+	    q->pavl_link[dir] = r;
+	    r->pavl_parent = p->pavl_parent;
+	    if (r->pavl_link[0] != NULL)
+		r->pavl_link[0]->pavl_parent = r;
+	    r->pavl_balance = p->pavl_balance;
+	    q = r;
+	    dir = 1;
+	else {
+	    struct pavlrc_node *s = r->pavl_link[0];
+	    while (s->pavl_link[0] != NULL)
+		s = s->pavl_link[0];
+	    r = s->pavl_parent;
+	    r->pavl_link[0] = s->pavl_link[1];
+	    s->pavl_link[0] = p->pavl_link[0];
+	    s->pavl_link[1] = p->pavl_link[1];
+	    q->pavl_link[dir] = s;
+	    if (s->pavl_link[0] != NULL)
+		s->pavl_link[0]->pavl_parent = s;
+	    s->pavl_link[1]->pavl_parent = s;
+	    s->pavl_parent = p->pavl_parent;
+	    s->pavl_balance = p->pavl_balance;
+	    q = r;
+	    dir = 0;
+    tree->pavl_alloc->libavl_free(tree->pavl_alloc, p);
+    while (q != (struct pavlrc_node *)&tree->pavl_root) {
+	struct pavlrc_node *y = q;
+	if (y->pavl_parent != NULL)
+	    q = y->pavl_parent;
+	else
+	if (dir == 0) {
+	    dir = q->pavl_link[0] != y;
+	    y->pavl_balance++;
+	    if (y->pavl_balance == +1)
+		break;
+		    q->pavl_link[dir] = w;
+		else {
+		    q->pavl_link[dir] = x;
+		    if (x->pavl_balance == 0) {
+			x->pavl_balance = -1;
+			y->pavl_balance = +1;
+			break;
+		    else {
+			y = x;
+	else {
+	    y->pavl_balance--;
+	    if (y->pavl_balance == -1)
+		break;
+	    else if (y->pavl_balance == -2) {
+		else {
+			x->pavl_balance = +1;
+			y->pavl_balance = -1;
+			break;
+		    else {
+			y = x;
+    tree->pavl_count--;
+    return item;
+/* Initializes |trav| for use with |tree|
+   and selects the null node. */
+void pavlrc_t_init(struct pavlrc_traverser *trav, struct pavlrc_table *tree)
+    trav->pavl_table = tree;
+    trav->pavl_node = NULL;
+/* Initializes |trav| for |tree|.
+   Returns data item in |tree| with the least value,
+   or |NULL| if |tree| is empty. */
+struct pavlrc *pavlrc_t_first(struct pavlrc_traverser *trav, struct pavlrc_table *tree)
+    assert(tree != NULL && trav != NULL);
+    trav->pavl_node = tree->pavl_root;
+    if (trav->pavl_node != NULL) {
+	while (trav->pavl_node->pavl_link[0] != NULL)
+	    trav->pavl_node = trav->pavl_node->pavl_link[0];
+	return &trav->pavl_node->pavl_data;
+    else
+	return NULL;
+   Returns data item in |tree| with the greatest value,
+struct pavlrc *pavlrc_t_last(struct pavlrc_traverser *trav, struct pavlrc_table *tree)
+	while (trav->pavl_node->pavl_link[1] != NULL)
+	    trav->pavl_node = trav->pavl_node->pavl_link[1];
+    else
+	return NULL;
+/* Searches for |item| in |tree|.
+   If found, initializes |trav| to the item found and returns the item
+   as well.
+   If there is no matching item, initializes |trav| to the null item
+   and returns |NULL|. */
+struct pavlrc *pavlrc_t_find(struct pavlrc_traverser *trav, struct pavlrc_table *tree,
+		  struct pavlrc *item)
+    assert(trav != NULL && tree != NULL && item != NULL);
+	if (cmp == 0) {
+	    trav->pavl_node = p;
+    return NULL;
+/* Attempts to insert |item| into |tree|.
+   If |item| is inserted successfully, it is returned and |trav| is
+   initialized to its location.
+   If a duplicate is found, it is returned and |trav| is initialized to
+   its location.  No replacement of the item occurs.
+   If a memory allocation failure occurs, |NULL| is returned and |trav|
+   is initialized to the null item. */
+struct pavlrc *pavlrc_t_insert(struct pavlrc_traverser *trav,
+		    struct pavlrc_table *tree, struct pavlrc *item)
+    struct pavlrc *p;
+    p = pavlrc_probe(tree, item);
+    if (p != NULL) {
+	trav->pavl_node = ((struct pavlrc_node *)((char *)p -
+						offsetof(struct pavlrc_node,
+							 pavl_data)));
+	return p;
+    else {
+	pavlrc_t_init(trav, tree);
+	return NULL;
+/* Initializes |trav| to have the same current node as |src|. */
+struct pavlrc *pavlrc_t_copy(struct pavlrc_traverser *trav,
+		  const struct pavlrc_traverser *src)
+    assert(trav != NULL && src != NULL);
+    trav->pavl_table = src->pavl_table;
+    trav->pavl_node = src->pavl_node;
+    return trav->pavl_node != NULL ? &trav->pavl_node->pavl_data : NULL;
+/* Returns the next data item in inorder
+   within the tree being traversed with |trav|,
+   or if there are no more data items returns |NULL|. */
+struct pavlrc *pavlrc_t_next(struct pavlrc_traverser *trav)
+    assert(trav != NULL);
+    if (trav->pavl_node == NULL)
+	return pavlrc_t_first(trav, trav->pavl_table);
+    else if (trav->pavl_node->pavl_link[1] == NULL) {
+	struct pavlrc_node *q, *p;	/* Current node and its child. */
+	for (p = trav->pavl_node, q = p->pavl_parent;;
+	     p = q, q = q->pavl_parent)
+	    if (q == NULL || p == q->pavl_link[0]) {
+		trav->pavl_node = q;
+		    &trav->pavl_node->pavl_data : NULL;
+    else {
+/* Returns the previous data item in inorder
+struct pavlrc *pavlrc_t_prev(struct pavlrc_traverser *trav)
+	return pavlrc_t_last(trav, trav->pavl_table);
+    else if (trav->pavl_node->pavl_link[0] == NULL) {
+	    if (q == NULL || p == q->pavl_link[1]) {
+    else {
+/* Returns |trav|'s current item. */
+struct pavlrc *pavlrc_t_cur(struct pavlrc_traverser *trav)
+/* Replaces the current item in |trav| by |new| and returns the item replaced.
+   |trav| must not have the null item selected.
+   The new item must not upset the ordering of the tree. */
+struct pavlrc *pavlrc_t_replace(struct pavlrc_traverser *trav, struct pavlrc *new)
+    struct pavlrc *old;
+    assert(trav != NULL && trav->pavl_node != NULL && new != NULL);
+    old = &trav->pavl_node->pavl_data;
+    trav->pavl_node->pavl_data = *new;
+    return old;
+/* Destroys |new| with |pavl_destroy (new, destroy)|,
+   first initializing right links in |new| that have
+   not yet been initialized at time of call. */
+static void
+copy_error_recovery(struct pavlrc_node *q,
+		    struct pavlrc_table *new)
+    assert(q != NULL && new != NULL);
+    for (;;) {
+	struct pavlrc_node *p = q;
+	q = q->pavl_parent;
+	if (q == NULL)
+	    break;
+	if (p == q->pavl_link[0])
+	    q->pavl_link[1] = NULL;
+    pavlrc_destroy(new);
+/* Copies |org| to a newly created tree, which is returned.
+   If |copy != NULL|, each data item in |org| is first passed to |copy|,
+   and the return values are inserted into the tree;
+   |NULL| return values are taken as indications of failure.
+   On failure, destroys the partially created new tree,
+   applying |destroy|, if non-null, to each item in the new tree so far,
+   If |allocator != NULL|, it is used for allocation in the new tree.
+   Otherwise, the same allocator used for |org| is used. */
+struct pavlrc_table *pavlrc_copy(const struct pavlrc_table *org,
+			     pavlrc_copy_func * copy,
+			     struct libavl_allocator *allocator)
+    struct pavlrc_table *new;
+    struct pavlrc_node *x;
+    assert(org != NULL);
+    new = pavlrc_create(allocator != NULL ? allocator : org->pavl_alloc);
+    if (new == NULL)
+	return NULL;
+    new->pavl_count = org->pavl_count;
+    if (new->pavl_count == 0)
+	return new;
+    x = (struct pavlrc_node *)&org->pavl_root;
+    y = (struct pavlrc_node *)&new->pavl_root;
+    while (x != NULL) {
+	while (x->pavl_link[0] != NULL) {
+	    y->pavl_link[0] =
+		new->pavl_alloc->libavl_malloc(new->pavl_alloc,
+					       sizeof *y->pavl_link[0]);
+	    if (y->pavl_link[0] == NULL) {
+		if (y != (struct pavlrc_node *)&new->pavl_root) {
+		    /* y->pavl_data = NULL; */
+		    y->pavl_link[1] = NULL;
+		copy_error_recovery(y, new);
+		return NULL;
+	    x = x->pavl_link[0];
+	    y = y->pavl_link[0];
+	y->pavl_link[0] = NULL;
+	for (;;) {
+	    y->pavl_balance = x->pavl_balance;
+	    if (copy == NULL)
+		y->pavl_data = x->pavl_data;
+	    else {
+		y->pavl_data = *(struct pavlrc *)copy(&x->pavl_data);
+		if (y->pavl_data == NULL) {
+		    return NULL;
+	    if (x->pavl_link[1] != NULL) {
+		y->pavl_link[1] =
+						   sizeof *y->pavl_link[1]);
+		if (y->pavl_link[1] == NULL) {
+		    return NULL;
+		x = x->pavl_link[1];
+		y = y->pavl_link[1];
+		break;
+	    else
+	    for (;;) {
+		const struct pavlrc_node *w = x;
+		x = x->pavl_parent;
+		if (x == NULL) {
+		    new->pavl_root->pavl_parent = NULL;
+		    return new;
+		y = y->pavl_parent;
+		if (w == x->pavl_link[0])
+		    break;
+    return new;
+/* Frees storage allocated for |tree|.
+   If |destroy != NULL|, applies it to each data item in inorder. */
+void pavlrc_destroy(struct pavlrc_table *tree)
+    assert(tree != NULL);
+	if (p->pavl_link[0] == NULL) {
+	    q = p->pavl_link[1];
+	else {
+	    q = p->pavl_link[0];
+	    p->pavl_link[0] = q->pavl_link[1];
+	    q->pavl_link[1] = p;
+	p = q;
+    tree->pavl_alloc->libavl_free(tree->pavl_alloc, tree);
+/* Allocates |size| bytes of space using |malloc()|.
+   Returns a null pointer if allocation fails. */
+void *pavlrc_malloc(struct libavl_allocator *allocator, size_t size)
+    assert(allocator != NULL && size > 0);
+    return malloc(size);
+/* Frees |block|. */
+void pavlrc_free(struct libavl_allocator *allocator, void *block)
+    assert(allocator != NULL && block != NULL);
+    free(block);
+/* Default memory allocator that uses |malloc()| and |free()|. */
+struct libavl_allocator pavlrc_allocator_default = {
+    pavlrc_malloc,
+    pavlrc_free
+#undef NDEBUG
+/* Asserts that |pavl_insert()| succeeds at inserting |item| into |table|. */
+void (pavlrc_assert_insert) (struct pavlrc_table * table, struct pavlrc *item)
+    assert(p != NULL && p == item);
+/* Asserts that |pavl_delete()| really removes |item| from |table|,
+   and returns the removed item. */
+struct pavlrc *(pavlrc_assert_delete) (struct pavlrc_table * table, struct pavlrc *item)
+    struct pavlrc *p = pavlrc_delete(table, item);
+    assert(p != NULL);
+    return p;
Property changes on: grass/trunk/raster/r.path/pavlrc.c
___________________________________________________________________
Added: svn:mime-type
   + text/x-csrc
Added: svn:eol-style
   + native
Added: grass/trunk/raster/r.path/pavlrc.h
--- grass/trunk/raster/r.path/pavlrc.h	                        (rev 0)
+++ grass/trunk/raster/r.path/pavlrc.h	2017-12-20 22:06:06 UTC (rev 71962)
@@ -0,0 +1,107 @@
+   Foundation, Inc.
+   02110-1301 USA.
+#ifndef PAVLRC_H
+#define PAVLRC_H 1
+#include <stddef.h>
+struct pavlrc
+    int row, col;
+/* Function types. */
+typedef void *pavlrc_copy_func(void *pavl_item);
+#ifndef LIBAVL_ALLOCATOR
+#define LIBAVL_ALLOCATOR
+/* Memory allocator. */
+    void *(*libavl_malloc) (struct libavl_allocator *, size_t libavl_size);
+    void (*libavl_free) (struct libavl_allocator *, void *libavl_block);
+#endif
+/* Default memory allocator. */
+extern struct libavl_allocator pavlrc_allocator_default;
+void *pavlrc_malloc(struct libavl_allocator *, size_t);
+void pavlrc_free(struct libavl_allocator *, void *);
+/* Maximum PAVL height, unused. */
+#ifndef PAVL_MAX_HEIGHT
+#define PAVL_MAX_HEIGHT 32
+#endif
+/* Tree data structure. */
+    struct pavlrc_node *pavl_root;	/* Tree's root. */
+    struct libavl_allocator *pavl_alloc;	/* Memory allocator. */
+    size_t pavl_count;		/* Number of items in tree. */
+/* An PAVL tree node. */
+struct pavlrc_node
+    struct pavlrc_node *pavl_link[2];	/* Subtrees. */
+    struct pavlrc_node *pavl_parent;	/* Parent node. */
+    struct pavlrc pavl_data;		/* data. */
+    signed char pavl_balance;	/* Balance factor. */
+/* PAVL traverser structure. */
+struct pavlrc_traverser
+    struct pavlrc_table *pavl_table;	/* Tree being traversed. */
+    struct pavlrc_node *pavl_node;	/* Current node in tree. */
+/* Table functions. */
+struct pavlrc_table *pavlrc_create(struct libavl_allocator *);
+struct pavlrc_table *pavlrc_copy(const struct pavlrc_table *, pavlrc_copy_func *,
+			         struct libavl_allocator *);
+void pavlrc_destroy(struct pavlrc_table *);
+struct pavlrc *pavlrc_probe(struct pavlrc_table *, struct pavlrc *);
+struct pavlrc *pavlrc_insert(struct pavlrc_table *, struct pavlrc *);
+struct pavlrc *pavlrc_replace(struct pavlrc_table *, struct pavlrc *);
+struct pavlrc *pavlrc_delete(struct pavlrc_table *, struct pavlrc *);
+struct pavlrc *pavlrc_find(const struct pavlrc_table *, const struct pavlrc *);
+void pavlrc_assert_insert(struct pavlrc_table *, struct pavlrc *);
+struct pavlrc *pavlrc_assert_delete(struct pavlrc_table *, struct pavlrc *);
+#define pavlrc_count(table) ((size_t) (table)->pavlrc_count)
+/* Table traverser functions. */
+void pavlrc_t_init(struct pavlrc_traverser *, struct pavlrc_table *);
+struct pavlrc *pavlrc_t_first(struct pavlrc_traverser *, struct pavlrc_table *);
+struct pavlrc *pavlrc_t_last(struct pavlrc_traverser *, struct pavlrc_table *);
+struct pavlrc *pavlrc_t_find(struct pavlrc_traverser *, struct pavlrc_table *, struct pavlrc *);
+struct pavlrc *pavlrc_t_insert(struct pavlrc_traverser *, struct pavlrc_table *, struct pavlrc *);
+struct pavlrc *pavlrc_t_copy(struct pavlrc_traverser *, const struct pavlrc_traverser *);
+struct pavlrc *pavlrc_t_next(struct pavlrc_traverser *);
+struct pavlrc *pavlrc_t_prev(struct pavlrc_traverser *);
+struct pavlrc *pavlrc_t_cur(struct pavlrc_traverser *);
+struct pavlrc *pavlrc_t_replace(struct pavlrc_traverser *, struct pavlrc *);
+#endif /* pavlrc.h */
Property changes on: grass/trunk/raster/r.path/pavlrc.h
   + text/x-chdr
   + native
Deleted: grass/trunk/raster/r.path/r.drain.html
--- grass/trunk/raster/r.drain/r.drain.html	2017-12-04 15:37:44 UTC (rev 71888)
+++ grass/trunk/raster/r.path/r.drain.html	2017-12-20 22:06:06 UTC (rev 71962)
@@ -1,316 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.drain</em> traces a flow through a least-cost path in an
-elevation model or cost surface. For cost surfaces, a movement
-direction map must be specified with the
-<b>direction</b> option and the <b>-d</b> flag to trace a flow path following
-the given directions. Such a movement direction map can be generated with
-<em><a href="r.walk.html">r.walk</a></em>,
-<em><a href="r.cost.html">r.cost</a></em>,
-<em><a href="r.slope.aspect.html">r.slope.aspect</a></em> or
-<em><a href="r.watershed.html">r.watershed</a></em>
-provided that the direction is in degrees, measured counterclockwise
-from east.
-<p>
-The <b>output</b> raster map will show one or more least-cost paths
-between each user-provided location(s) and the minima (low category
-values) in the raster <b>input</b> map. If the <b>-d</b> flag is used
-the output least-cost paths will be found using the direction raster
-map.  By default, the <b>output</b> will be an integer CELL map with
-category 1 along the least cost path, and null cells elsewhere.
-<p>With the <b>-c</b> (<em>copy</em>) flag, the input raster map cell values are
-copied verbatim along the path. With the <b>-a</b> (<em>accumulate</em>)
-flag, the accumulated cell value from the starting point up to the current
-cell is written on output. With either the <b>-c</b> or the <b>-a</b> flags, the
-<b>output</b> map is created with the same cell type as
-the <b>input</b> raster map (integer, float or double).  With
-the <b>-n</b> (<em>number</em>) flag, the cells are numbered
-consecutively from the starting point to the final point.
-The <b>-c</b>, <b>-a</b>, and <b>-n</b> flags are mutually
-incompatible.
-<p>For an elevation surface, the path is calculated by choosing the
-steeper "slope" between adjacent cells. The slope calculation
-accurately acounts for the variable scale in lat-lon projections. For
-a cost surface, the path is calculated by following the movement
-direction surface back to the start point given
-in <em><a href="r.walk.html">r.walk</a></em> or
-<em><a href="r.cost.html">r.cost</a></em>. The path search stops
-as soon as a region border or a neighboring NULL cell is encountered,
-because in these cases the direction can not be determined (the path
-could continue outside the current region).
-<p>The <b>start_coordinates</b> parameter consists of map E and N grid coordinates of
-a starting point. Each x,y pair is the easting and northing (respectively) of
-a starting point from which a least-cost corridor will be developed.
-The <b>start_points</b> parameter can take multiple vector maps containing
-additional starting points.
-Up to 1024 starting points can be input from a combination of the
-<b>start_coordinates</b> and <b>start_points</b> parameters.
-<h3>Explanation of output values</h3>
-Consider the following example:
-<div class="code"><pre>
-Input:                          Output:
-  ELEVATION SURFACE               LEAST COST PATH
-. 19. 20. 18. 19. 16. 15. 15.    .   .   .   .   .   .   .   .
-. 20| 19| 17. 16. 17. 16. 16.    .   . 1 . 1 . 1 .   .   .   .
-. 18. 18. 24. 18. 15. 12. 11.    .   .   .   .   . 1 .   .   .
-. 22. 16. 16. 18. 10. 10. 10.    .   .   .   .   . 1 .   .   .
-. 17. 15. 15. 15. 10. 8 . 8 .    .   .   .   .   .   . 1 .   .
-. 24. 16. 8 . 7 . 8 . 0 . 12.    .   .   .   .   .   . 1 .   .
-. 17. 9 . 8 . 7 . 8 . 6 . 12.    .   .   .   .   .   .   .   .
-</pre></div>
-<p>
-The user-provided starting location in the above example is
-the boxed <b>19</b> in the left-hand map. The path in the output
-shows the least-cost corridor for moving from the starting
-box to the lowest (smallest) possible point. This is the path a raindrop
-would take in this landscape.
-<p>
-With the <b>-c</b> <em>(copy)</em> flag, you get the following result:
-Input:                          Output:
-. 20| 19| 17. 16. 17. 16. 16.    .   . 19. 17. 16.   .   .   .
-. 18. 18. 24. 18. 15. 12. 11.    .   .   .   .   . 15.   .   .
-. 22. 16. 16. 18. 10. 10. 10.    .   .   .   .   . 10.   .   .
-. 17. 15. 15. 15. 10. 8 . 8 .    .   .   .   .   .   . 8 .   .
-. 24. 16. 8 . 7 . 8 . 0 .12 .    .   .   .   .   .   . 0 .   .
-. 17. 9 . 8 . 7 . 8 . 6 .12 .    .   .   .   .   .   .   .   .
-Note that the last <em>0</em> will not be put in the null values map.
-</pre></div>
-<p>
-With the <b>-a</b> <em>(accumulate)</em> flag, you get the following result:
-Input:                          Output:
-. 20| 19| 17. 16. 17. 16. 16.    .   . 19. 36. 52.   .   .   .
-. 18. 18. 24. 18. 15. 12. 11.    .   .   .   .   . 67.   .   .
-. 22. 16. 16. 18. 10. 10. 10.    .   .   .   .   . 77.   .   .
-. 17. 15. 15. 15. 10. 8 . 8 .    .   .   .   .   .   . 85.   .
-. 24. 16. 8 . 7 . 8 . 0 .12 .    .   .   .   .   .   . 85.   .
-</pre></div>
-<p>
-With the <b>-n</b> <em>(number)</em> flag, you get the following result:
-Input:                          Output:
-. 20| 19| 17. 16. 17. 16. 16.    .   . 1 . 2 . 3 .   .   .   .
-. 18. 18. 24. 18. 15. 12. 11.    .   .   .   .   . 4 .   .   .
-. 22. 16. 16. 18. 10. 10. 10.    .   .   .   .   . 5 .   .   .
-. 17. 15. 15. 15. 10. 8 . 8 .    .   .   .   .   .   . 6 .   .
-. 24. 16. 8 . 7 . 8 . 0 .12 .    .   .   .   .   .   . 7 .   .
-</pre></div>
-With the <b>-d</b> <em>(direction)</em> flag, the direction raster is used
-for the input, rather than the elevation surface. The output is then created
-according to one of the <b>-can</b> flags.
-The directions are recorded as degrees CCW from East:
-       112.5     67.5         i.e. a cell with the value 135
-157.5  135   90  45   22.5    means the next cell is to the North-West
-       180   x   0
-202.5  225  270  315  337.5
-       247.5     292.5
-</pre></div>
-<h2>NOTES</h2>
-If no direction input map is given, <em>r.drain</em> currently finds
-only the lowest point (the cell having the smallest category value) in
-the input file that can be reached through directly adjacent cells
-that are less than or equal in value to the cell reached immediately
-prior to it; therefore, it will not necessarily reach the lowest point
-in the input file. It currently finds <em>pits</em> in the data,
-rather than the lowest point in the entire input
-map. The <em><a href="r.fill.dir.html">r.fill.dir</a></em>,
-<em><a href="r.terraflow.html">r.terraflow</a></em>,
-and <em><a href="r.basins.fill.html">r.basins.fill</a></em> modules
-can be used to fill in subbasins prior to processing
-with <em>r.drain</em>.
-<p>
-<em>r.drain</em> will not give sane results at the region boundary. On outer rows
-and columns bordering the edge of the region, the flow direction is always directly out
-of the map. In this case, the user could try adjusting the region extents slightly with
-<em>g.region</em> to allow additional outlet paths for <em>r.drain</em>.
-<h2>EXAMPLES</h2>
-<h3>Path to the lowest point</h3>
-In this example we compute drainage paths from two given points
-following decreasing elevation values to the lowest point.
-We are using the full North Carolina sample dataset.
-First we create the two points from a text file using
-<em><a href="v.in.ascii.html">v.in.ascii</a></em> module
-(here the text file is CSV and we are using unix here-file syntax
-with EOF, in GUI just enter the values directly for the parameter input):
-v.in.ascii input=- output=start format=point separator=comma <<EOF
-638667.15686275,220610.29411765
-638610.78431373,220223.03921569
-EOF
-</pre></div>
-Now we compute the drainage path:
-r.drain input=elev_lid792_1m output=drain_path drain=drain start_points=start
-</pre></div>
-Before we visualize the result, we set a color table for the elevation
-we are using and we create a shaded relief map:
-r.colors map=elev_lid792_1m color=elevation
-r.relief input=elev_lid792_1m output=relief
-</pre></div>
-Finally we visualize all the input and output data:
-d.shade shade=relief color=elev_lid792_1m
-d.vect map=drain_path color=0:0:61 width=4 legend_label="drainage paths"
-d.vect map=start color=none fill_color=224:0:0 icon=basic/circle size=15 legend_label=origins
-d.legend.vect -b
-</pre></div>
-<div align="center">
-<a href="r_drain.png"><img src="r_drain.png" alt="drainage using r.watershed" width="300" height="280"></a>
-<br>
-<i>Figure: Drainage paths from two points flowing into the points with
-lowest values</i>
-</div>
-<h3>Path following directions</h3>
-To continue flow even after it hits a depression, we need to supply a
-direction raster map which will tell the <em>r.drain</em> module how to
-continue from the depression. To get these directions, we use the
-<em><a href="r.watershed.html">r.watershed</a></em> module:
-r.watershed elevation=elev_lid792_1m accumulation=accum drainage=drain_dir
-</pre></div>
-The directions are categorical and we convert them to degrees using
-raster algebra:
-r.mapcalc "drain_deg = if(drain_dir != 0, 45. * abs(drain_dir), null())"
-</pre></div>
-Together with directions, we need to provide the <em>r.drain</em> module
-with cost values. We don't have any cost to assign to specific cells,
-so we create a constant surface:
-r.mapcalc "const1 = 1"
-</pre></div>
-Now we are ready to compute the drainage paths.
-We are using the two points from the previous example.
-r.drain -d input=const1 direction=drain_deg output=drain_path_2 drain=drain_2 start_points=start
-</pre></div>
-We visualize the result in the same way as in the previous example.
-<a href="r_drain_with_r_watershed_direction.png"><img src="r_drain_with_r_watershed_direction.png" alt="drainage using r.watershed" width="300" height="280"></a>
-<br>
-<i>Figure: Drainage paths from two points where directions from
-r.watershed were used</i>
-</div>
-<h2>KNOWN ISSUES</h2>
-<p>Sometimes, when the differences among integer cell category values in the
-<em><a href="r.cost.html">r.cost</a></em> cumulative cost surface output are
-small, this cumulative cost output cannot accurately be used as input to
-<em>r.drain</em> (<em>r.drain</em> will output bad results).
-This problem can be circumvented by making the differences
-between cell category values in the cumulative cost output bigger. It
-is recommended that if the output from <em>r.cost</em> is to be used
-as input to <em>r.drain</em>, the user multiply the <em>r.cost</em>
-input cost surface map by the value of the map's cell resolution,
-before running <em>r.cost</em>. This can be done using
-<em><a href="r.mapcalc.html">r.mapcalc</a></em>. The map resolution can be
-found using <em><a href="g.region.html">g.region</a></em>.
-This problem doesn't arise with floating point maps.
-<h2>SEE ALSO</h2>
-<em>
-<a href="g.region.html">g.region</a>,
-<a href="r.cost.html">r.cost</a>,
-<a href="r.fill.dir.html">r.fill.dir</a>,
-<a href="r.basins.fill.html">r.basins.fill</a>,
-<a href="r.watershed.html">r.watershed</a>,
-<a href="r.terraflow.html">r.terraflow</a>,
-<a href="r.mapcalc.html">r.mapcalc</a>,
-<a href="r.walk.html">r.walk</a>
-</em>
-<h2>AUTHORS</h2>
-Completely rewritten by Roger S. Miller, 2001<br>
-July 2004 at WebValley 2004, error checking and vector points added by
-Matteo Franchi (Liceo Leonardo Da Vinci, Trento) and
-Roberto Flor (ITC-irst, Trento, Italy)
-<p>
-<i>Last changed: $Date$</i>
Copied: grass/trunk/raster/r.path/r.path.html (from rev 71888, grass/trunk/raster/r.drain/r.drain.html)
--- grass/trunk/raster/r.path/r.path.html	                        (rev 0)
+++ grass/trunk/raster/r.path/r.path.html	2017-12-20 22:06:06 UTC (rev 71962)
@@ -0,0 +1,192 @@
+<h2>DESCRIPTION</h2>
+<em>r.path</em> traces a path from starting points following input
+directions. Such a movement direction map can be generated with
+<em><a href="r.walk.html">r.walk</a></em>,
+<em><a href="r.cost.html">r.cost</a></em>,
+<em><a href="r.slope.aspect.html">r.slope.aspect</a></em>,
+<em><a href="r.watershed.html">r.watershed</a></em>, or
+<em><a href="r.fill.dir.html">r.fill.dir</a></em>,
+provided that the direction is in degrees, measured counterclockwise
+from east.
+<p>
+Alternatively, bitmask-encoded directions can be provided where each
+bit position corresponds to a specific neighbour. A path will continue
+to all neighbours with their bit set. This means a path can split and
+merge. Such bitmasked directions can be created with the <b>-b</b>
+flag of <em><a href="r.cost.html">r.cost</a></em> and
+<em><a href="r.walk.html">r.walk</a></em>. The corresponding <b>-b</b>
+flag must then be set for <em>r.path</em>.
+<div class="code"><pre>
+Direction encoding for neighbors of x
+  135  90  45          7 8 1
+  180  x  360          6 x 2
+  225 270 315          5 4 3
+  degrees           bit positions
+  CCW from East
+</pre></div>
+A path stops when the direction is zero or negative, indicating a stop
+point or outlet.
+<p>
+The <b>output</b> raster map will show one or more least-cost paths
+between each user-provided location(s) and the target points (direction
+≤ 0). By default, the <b>output</b> will be an integer CELL map with
+the id of the start points along the least cost path, and null cells elsewhere.
+<p>
+With the <b>-c</b> (<em>copy</em>) flag, the values raster map cell values are
+copied verbatim along the path. With the <b>-a</b> (<em>accumulate</em>)
+flag, the accumulated cell value from the starting point up to the current
+cell is written on output. With either the <b>-c</b> or the <b>-a</b> flags, the
+<b>raster_path</b> map is created with the same cell type as
+the <b>values</b> raster map (integer, float or double).  With
+the <b>-n</b> (<em>number</em>) flag, the cells are numbered
+consecutively from the starting point to the final point.
+The <b>-c</b>, <b>-a</b>, and <b>-n</b> flags are mutually
+incompatible.
+<p>
+The <b>start_coordinates</b> parameter consists of map E and N grid
+coordinates of a starting point. Each x,y pair is the easting and
+northing (respectively) of a starting point from which a path will be
+traced following <b>input</b> directions. The <b>start_points</b>
+parameter can take multiple vector maps containing additional starting
+points.
+<h2>NOTES</h2>
+The directions are recorded as degrees CCW from East, the Knight's move
+of r.cost and r.walk is considered:
+       112.5     67.5
+157.5  135   90  45   22.5
+       180   x   0
+202.5  225  270  315  337.5
+       247.5     292.5
+</pre></div>
+i.e. a cell with the value 135 means the next cell is to the North-West,
+and a cell with the value 157.5 means that the next cell is to the
+West-North-West-
+<h2>EXAMPLES</h2>
+<h3>Hydrological path</h3>
+We are using the full North Carolina sample dataset.
+First we create the two points from a text file using
+<em><a href="v.in.ascii.html">v.in.ascii</a></em> module
+(here the text file is CSV and we are using unix here-file syntax
+with EOF, in GUI just enter the values directly for the parameter input):
+v.in.ascii input=- output=start format=point separator=comma <<EOF
+638667.15686275,220610.29411765
+638610.78431373,220223.03921569
+EOF
+</pre></div>
+We need to supply a direction raster map to the <em>r.path</em> module.
+To get these directions, we use the
+<em><a href="r.watershed.html">r.watershed</a></em> module:
+r.watershed elevation=elev_lid792_1m accumulation=accum drainage=drain_dir
+</pre></div>
+The directions are categorical and we convert them to degrees using
+raster algebra:
+r.mapcalc "drain_deg = if(drain_dir != 0, 45. * abs(drain_dir), null())"
+</pre></div>
+Now we are ready to extract the drainage paths starting at the two points.
+r.path input=drain_deg raster_path=drain_path vector_path=drain_path start_points=start
+</pre></div>
+Before we visualize the result, we set a color table for the elevation
+we are using and create a shaded relief map:
+r.colors map=elev_lid792_1m color=elevation
+r.relief input=elev_lid792_1m output=relief
+</pre></div>
+We visualize the input and output data:
+d.shade shade=relief color=elev_lid792_1m
+d.vect map=drain_path color=0:0:61 width=4 legend_label="drainage paths"
+d.vect map=start color=none fill_color=224:0:0 icon=basic/circle size=15 legend_label=origins
+d.legend.vect -b
+</pre></div>
+<div align="center">
+<a href="r_drain_with_r_watershed_direction.png"><img src="r_drain_with_r_watershed_direction.png" alt="drainage using r.watershed" width="300" height="280"></a>
+<br>
+<i>Figure: Drainage paths from two points where directions from
+r.watershed were used</i>
+</div>
+<h3>Least-cost path</h3>
+We compute bitmask encoded movement directions using <em>r.walk:</em>
+g.region swwake_30m -p
+# create friction map based on land cover
+r.recode landclass96 out=friction << EOF
+1:3:0.1:0.1
+4:5:10.:10.
+6:6:1000.0:1000.0
+7:7:0.3:0.3
+EOF
+# without Knight's move
+r.walk -b elevation=elev_ned_30m friction=friction output=walkcost \
+    outdir=walkdir start_coordinates=635576,216485
+r.path -b input=walkdir start_coordinates=640206,222795 \
+    raster_path=walkpath vector_path=walkpath
+# with Knight's move
+r.walk -b -k elevation=elev_ned_30m friction=friction output=walkcost_k \
+    outdir=walkdir_k start_coordinates=635576,216485
+r.path -b input=walkdir_k start_coordinates=640206,222795 \
+    raster_path=walkpath_k vector_path=walkpath_k
+</pre></div>
+The extracted least-cost path splits and merges on the way from
+the start point to the stop point (start point for r.walk). Note the
+gaps in the raster path when using the Knight's move.
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="g.region.html">g.region</a>,
+<a href="r.cost.html">r.cost</a>,
+<a href="r.walk.html">r.walk</a>,
+<a href="r.watershed.html">r.watershed</a>,
+<a href="r.fill.dir.html">r.fill.dir</a>,
+<a href="r.basins.fill.html">r.basins.fill</a>,
+<a href="r.terraflow.html">r.terraflow</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>,
+</em>
+<h2>AUTHORS</h2>
+Markus Metz
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass/trunk/raster/r.path/r_drain.png
(Binary files differ)
Deleted: grass/trunk/raster/r.path/r_drain_with_r_watershed_direction.png
Copied: grass/trunk/raster/r.path/r_path.png (from rev 71888, grass/trunk/raster/r.drain/r_drain.png)
Copied: grass/trunk/raster/r.path/r_path_with_r_watershed_direction.png (from rev 71888, grass/trunk/raster/r.drain/r_drain_with_r_watershed_direction.png)
Deleted: grass/trunk/raster/r.path/resolve.c
--- grass/trunk/raster/r.drain/resolve.c	2017-12-04 15:37:44 UTC (rev 71888)
+++ grass/trunk/raster/r.path/resolve.c	2017-12-20 22:06:06 UTC (rev 71962)
@@ -1,209 +0,0 @@
-#include <grass/config.h>
-#include <stdlib.h>
-#include <string.h>
-#include <grass/gis.h>
-#include <grass/raster.h>
-#include "tinf.h"
-CELL select_dir(CELL i)
-    CELL dir[256] = { 0, 1, 2, 2, 4, 1, 2, 2, 8, 1,
-	8, 2, 8, 4, 4, 2, 16, 16, 16, 2, 16, 4, 4,
-	2, 8, 8, 8, 8, 8, 8, 8, 4, 32, 1, 2, 2,
-	4, 4, 2, 2, 32, 8, 8, 2, 8, 8, 4, 4, 32,
-	32, 32, 32, 16, 32, 4, 2, 16, 16, 16, 16, 8, 16,
-	8, 8, 64, 64, 64, 1, 64, 1, 2, 2, 64, 64, 8,
-	2, 8, 8, 4, 2, 16, 64, 64, 2, 16, 64, 2, 2,
-	16, 8, 8, 8, 8, 8, 8, 4, 32, 64, 32, 1, 32,
-	32, 32, 2, 32, 32, 32, 2, 32, 8, 4, 4, 32, 32,
-	32, 32, 32, 32, 32, 32, 32, 32, 16, 16, 16, 16, 8,
-	8, 128, 128, 128, 1, 4, 1, 2, 2, 128, 128, 2, 1,
-	8, 4, 4, 2, 16, 128, 2, 1, 4, 128, 2, 1, 8,
-	128, 8, 1, 8, 8, 4, 2, 32, 128, 1, 1, 128, 128,
-	2, 1, 32, 128, 32, 1, 8, 128, 4, 2, 32, 32, 32,
-	1, 32, 128, 32, 1, 16, 16, 16, 1, 16, 16, 8, 4,
-	128, 128, 128, 128, 128, 128, 2, 1, 128, 128, 128, 1, 128,
-	128, 4, 2, 64, 128, 128, 1, 128, 128, 128, 1, 8, 128,
-	8, 1, 8, 8, 8, 2, 64, 128, 64, 128, 64, 128, 64,
-	128, 32, 64, 64, 128, 64, 64, 64, 1, 32, 64, 64, 128,
-	64, 64, 64, 128, 32, 32, 32, 64, 32, 32, 16, 128
-    return dir[i];
-void flink(int i, int j, int nl, int ns, CELL * p1, CELL * p2, CELL * p3,
-	   int *active, int *goagain)
-    CELL bitmask[8] = { 1, 2, 4, 8, 16, 32, 64, 128 };
-    CELL outflow, cwork, c[8];
-    int k;
-    cwork = p2[j];
-    if (Rast_is_c_null_value(p2 + j) || cwork >= 0 || cwork == -256)
-	return;
-    cwork = -cwork;
-    for (k = 7; k >= 0; k--) {
-	c[k] = 0;
-	if (cwork >= bitmask[k]) {
-	    c[k] = 1;
-	    cwork -= bitmask[k];
-    outflow = 0;
-    /* There's no need to resolve directions at cells adjacent to null cells,
-     * as those directions will be resolved before we get here */
-    /* look one row back */
-    cwork = p1[j - 1];
-    if (cwork > 0 && cwork != 4 && c[6])
-	outflow += 64;
-    cwork = p1[j];
-    if (cwork > 0 && cwork != 8 && c[7])
-	outflow += 128;
-    cwork = p1[j + 1];
-    if (cwork > 0 && cwork != 16 && c[0])
-	outflow += 1;
-    /* look at this row */
-    cwork = p2[j - 1];
-    if (cwork > 0 && cwork != 2 && c[5])
-	outflow += 32;
-    cwork = p2[j + 1];
-    if (cwork > 0 && cwork != 32 && c[1])
-	outflow += 2;
-    /* look one row forward */
-    cwork = p3[j - 1];
-    if (cwork > 0 && cwork != 1 && c[4])
-	outflow += 16;
-    cwork = p3[j];
-    if (cwork > 0 && cwork != 128 && c[3])
-	outflow += 8;
-    cwork = p3[j + 1];
-    if (cwork > 0 && cwork != 64 && c[2])
-	outflow += 4;
-    if (outflow == 0) {
-	*active = 1;
-    else {
-	*goagain = 1;
-	p2[j] = select_dir(outflow);
-    return;
-void resolve(int fd, int nl, struct band3 *bnd)
-    CELL cvalue;
-    int *active;
-    int offset, isz, i, j, pass, activity, goagain, done;
-    active = (int *)G_calloc(nl, sizeof(int));
-    isz = sizeof(CELL);
-    /* select a direction when there are multiple non-flat links */
-    lseek(fd, bnd->sz, SEEK_SET);
-    for (i = 1; i < nl - 1; i += 1) {
-	read(fd, bnd->b[0], bnd->sz);
-	for (j = 1; j < bnd->ns - 1; j += 1) {
-	    offset = j * isz;
-	    if (Rast_is_c_null_value((void *)(bnd->b[0] + offset)))
-		continue;
-	    memcpy(&cvalue, bnd->b[0] + offset, isz);
-	    if (cvalue > 0)
-		cvalue = select_dir(cvalue);
-	    memcpy(bnd->b[0] + offset, &cvalue, isz);
-	lseek(fd, -bnd->sz, SEEK_CUR);
-	write(fd, bnd->b[0], bnd->sz);
-    pass = 0;
-	active[i] = 1;
-    /* select a direction when there are multiple flat links */
-    do {
-	done = 1;
-	pass += 1;
-	activity = 0;
-	lseek(fd, 0, SEEK_SET);
-	advance_band3(fd, bnd);
-	for (i = 1; i < nl - 1; i++) {
-	    lseek(fd, (off_t) (i + 1) * bnd->sz, SEEK_SET);
-	    if (!active[i])
-		continue;
-	    done = 0;
-	    active[i] = 0;
-	    do {
-		goagain = 0;
-		    flink(i, j, nl, bnd->ns,
-			  (void *)bnd->b[0], (void *)bnd->b[1],
-			  (void *)bnd->b[2], &active[i], &goagain);
-		    if (goagain)
-			activity = 1;
-	    } while (goagain);
-	    lseek(fd, (off_t) i * bnd->sz, SEEK_SET);
-	    write(fd, bnd->b[1], bnd->sz);
-	if (!activity) {
-	    done = 1;
-	    continue;
-	activity = 0;
-	lseek(fd, (off_t) (nl - 1) * bnd->sz, SEEK_SET);
-	retreat_band3(fd, bnd);
-	for (i = nl - 2; i >= 1; i -= 1) {
-	    lseek(fd, (off_t) (i - 1) * bnd->sz, SEEK_SET);
-	    if (!active[i])
-		continue;
-	    done = 0;
-	    active[i] = 0;
-	    do {
-		goagain = 0;
-		for (j = 1; j < bnd->ns - 1; j++) {
-		    if (goagain)
-			activity = 1;
-	if (!activity) {
-	    done = 1;
-    } while (!done);
-    G_free(active);
-    return;
Deleted: grass/trunk/raster/r.path/tests/test.r.drain.sh
--- grass/trunk/raster/r.drain/tests/test.r.drain.sh	2017-12-04 15:37:44 UTC (rev 71888)
+++ grass/trunk/raster/r.path/tests/test.r.drain.sh	2017-12-20 22:06:06 UTC (rev 71962)
@@ -1,24 +0,0 @@
-#!/bin/sh
-# to be run in the North Carolina location
-export GRASS_OVERWRITE=1
-r.in.ascii testascii_nc.asc out=testascii
-g.region raster=testascii -p
-d.mon wx0
-sleep 2
-d.rast.num testascii
-r.drain input=testascii output=drain coord=638442.5,220548.5
-d.rast drain
-d.erase
-r.mapcalc "testascii_float = float(testascii)"
-r.drain input=testascii_float output=drain coord=638442.5,220548.5
-d.rast drain
-# for statistical test results:
-# - verify number of resulting pixels (r.univar -g)
-# - verify minimum and maximum of result (r.univar -g)
Deleted: grass/trunk/raster/r.path/tests/testascii_nc.asc
--- grass/trunk/raster/r.drain/tests/testascii_nc.asc	2017-12-04 15:37:44 UTC (rev 71888)
+++ grass/trunk/raster/r.path/tests/testascii_nc.asc	2017-12-20 22:06:06 UTC (rev 71962)
@@ -1,13 +0,0 @@
-north:      220600
-south:      220000
-west:       638300
-east:       639000
-rows:       6
-cols:       7
-null:       -9999
-20 19 17 16 17 16 16
-18 18 24 18 15 12 11
-22 16 16 18 10 10 10
-17 15 15 15 10 8  8
-24 16 8 7 8 0 12
-17 9 8 7 8 6 12
Deleted: grass/trunk/raster/r.path/tinf.c
--- grass/trunk/raster/r.drain/tinf.c	2017-12-04 15:37:44 UTC (rev 71888)
+++ grass/trunk/raster/r.path/tinf.c	2017-12-20 22:06:06 UTC (rev 71962)
@@ -1,409 +0,0 @@
-/* #include <limits.h> */
-#include <float.h>
-#include <math.h>
-#include "tinf.h"
-int (*is_null) (void *);
-void (*set_null_value) (void *, int);
-int (*bpe) ();
-void *(*get_max) (void *, void *);
-void *(*get_min) (void *, void *);
-void (*get_row) (int, void *, int);
-void *(*get_buf) ();
-void (*put_row) (int, void *);
-double (*slope) (void *, void *, double);
-void (*set_min) (void *);
-void (*set_max) (void *);
-void (*diff) (void *, void *);
-void (*sum) (void *, void *);
-void (*quot) (void *, void *);
-void (*prod) (void *, void *);
-/* To add a new multitype function, use the function below to initialize
- * the function pointer to each of the three typed functions.  The function
- * pointers and the function prototypes are defined in a header file.
- * The actual functions follow. */
-void set_func_pointers(int in_type)
-    switch (in_type) {
-    case CELL_TYPE:
-	is_null = is_null_c;
-	bpe = bpe_c;
-	get_max = get_max_c;
-	get_min = get_min_c;
-	get_row = get_row_c;
-	get_buf = get_buf_c;
-	put_row = put_row_c;
-	slope = slope_c;
-	set_min = set_min_c;
-	set_max = set_max_c;
-	diff = diff_c;
-	sum = sum_c;
-	quot = quot_c;
-	prod = prod_c;
-	set_null_value = set_null_value_c;
-	break;
-    case FCELL_TYPE:
-	is_null = is_null_f;
-	bpe = bpe_f;
-	get_max = get_max_f;
-	get_min = get_min_f;
-	get_row = get_row_f;
-	get_buf = get_buf_f;
-	put_row = put_row_f;
-	slope = slope_f;
-	set_min = set_min_f;
-	set_max = set_max_f;
-	diff = diff_f;
-	sum = sum_f;
-	quot = quot_f;
-	prod = prod_f;
-	set_null_value = set_null_value_f;
-	break;
-    case DCELL_TYPE:
-	is_null = is_null_d;
-	bpe = bpe_d;
-	get_max = get_max_d;
-	get_min = get_min_d;
-	get_row = get_row_d;
-	get_buf = get_buf_d;
-	put_row = put_row_d;
-	slope = slope_d;
-	set_min = set_min_d;
-	set_max = set_max_d;
-	diff = diff_d;
-	sum = sum_d;
-	quot = quot_d;
-	prod = prod_d;
-	set_null_value = set_null_value_d;
-    return;
-/* check for null values */
-int is_null_c(void *value)
-    return Rast_is_c_null_value((CELL *) value);
-int is_null_f(void *value)
-    return Rast_is_f_null_value((FCELL *) value);
-int is_null_d(void *value)
-    return Rast_is_d_null_value((DCELL *) value);
-/* set null values in buffer */
-void set_null_value_c(void *value, int num)
-    Rast_set_c_null_value((CELL *) value, num);
-void set_null_value_f(void *value, int num)
-    Rast_set_f_null_value((FCELL *) value, num);
-void set_null_value_d(void *value, int num)
-    Rast_set_d_null_value((DCELL *) value, num);
-/* return the size of the current type */
-int bpe_c()
-    return sizeof(CELL);
-int bpe_f()
-    return sizeof(FCELL);
-int bpe_d()
-    return sizeof(DCELL);
-/* return the pointer that points to the smaller of two value */
-void *get_min_c(void *v1, void *v2)
-    void *rc;
-    rc = v2;
-    if (*(CELL *) v1 < *(CELL *) v2)
-	rc = v1;
-    return rc;
-void *get_min_f(void *v1, void *v2)
-    void *rc;
-    rc = v2;
-    if (*(FCELL *) v1 < *(FCELL *) v2)
-	rc = v1;
-    return rc;
-void *get_min_d(void *v1, void *v2)
-    void *rc;
-    rc = v2;
-    if (*(DCELL *) v1 < *(DCELL *) v2)
-	rc = v1;
-    return rc;
-/* return the pointer that points to the larger value */
-void *get_max_c(void *v1, void *v2)
-    void *rc;
-    rc = v2;
-    if (*(CELL *) v1 > *(CELL *) v2)
-	rc = v1;
-    return rc;
-void *get_max_f(void *v1, void *v2)
-    void *rc;
-    rc = v2;
-    if (*(FCELL *) v1 > *(FCELL *) v2)
-	rc = v1;
-    return rc;
-void *get_max_d(void *v1, void *v2)
-    void *rc;
-    rc = v2;
-    if (*(DCELL *) v1 > *(DCELL *) v2)
-	rc = v1;
-    return rc;
-/* Read one line from a raster map */
-void get_row_c(int fd, void *row, int n)
-    Rast_get_c_row(fd, (CELL *) row, n);
-void get_row_f(int fd, void *row, int n)
-    Rast_get_f_row(fd, (FCELL *) row, n);
-void get_row_d(int fd, void *row, int n)
-    Rast_get_d_row(fd, (DCELL *) row, n);
-/* Write one row to a raster map */
-void put_row_c(int fd, void *row)
-    Rast_put_c_row(fd, (CELL *) row);
-void put_row_f(int fd, void *row)
-    Rast_put_f_row(fd, (FCELL *) row);
-void put_row_d(int fd, void *row)
-    Rast_put_d_row(fd, (DCELL *) row);
-/* Allocate memory for one line of data */
-void *get_buf_c(void)
-    return (void *)Rast_allocate_c_buf();
-void *get_buf_f(void)
-    return (void *)Rast_allocate_f_buf();
-void *get_buf_d(void)
-    return (void *)Rast_allocate_d_buf();
-/* initialize memory to a minimum value */
-void set_min_c(void *v)
-    *(CELL *) v = INT_MIN;
-void set_min_f(void *v)
-    *(FCELL *) v = FLT_MIN;
-void set_min_d(void *v)
-    *(DCELL *) v = DBL_MIN;
-/* initialize memory to a maximum value */
-void set_max_c(void *v)
-    *(CELL *) v = INT_MAX;
-void set_max_f(void *v)
-    *(FCELL *) v = FLT_MAX;
-void set_max_d(void *v)
-    *(DCELL *) v = DBL_MAX;
-/* get the difference between two values, returned in the first pointer */
-void diff_c(void *v1, void *v2)
-    *(CELL *) v1 -= *(CELL *) v2;
-void diff_f(void *v1, void *v2)
-    *(FCELL *) v1 -= *(FCELL *) v2;
-void diff_d(void *v1, void *v2)
-    *(DCELL *) v1 -= *(DCELL *) v2;
-/* get the sum of two values, returned in the first pointer */
-void sum_c(void *v1, void *v2)
-    *(CELL *) v1 += *(CELL *) v2;
-void sum_f(void *v1, void *v2)
-    *(FCELL *) v1 += *(FCELL *) v2;
-void sum_d(void *v1, void *v2)
-    *(DCELL *) v1 += *(DCELL *) v2;
-/* get the quotient of two values, returned in the first pointer */
-void quot_c(void *v1, void *v2)
-    *(CELL *) v1 /= *(CELL *) v2;
-void quot_f(void *v1, void *v2)
-    *(FCELL *) v1 /= *(FCELL *) v2;
-void quot_d(void *v1, void *v2)
-    *(DCELL *) v1 /= *(DCELL *) v2;
-/* get the product of two values, returned in the first pointer */
-void prod_c(void *v1, void *v2)
-    *(CELL *) v1 *= *(CELL *) v2;
-void prod_f(void *v1, void *v2)
-    *(FCELL *) v1 *= *(FCELL *) v2;
-void prod_d(void *v1, void *v2)
-    *(DCELL *) v1 *= *(DCELL *) v2;
-/* probably not a function of general interest */
-/* calculate the slope between two cells, returned as a double  */
-double slope_c(void *line1, void *line2, double cnst)
-    double rc;
-    CELL *pedge;
-    rc = -HUGE_VAL;
-    pedge = (CELL *) line2;
-    if (!Rast_is_c_null_value(pedge)) {
-	rc = (*(CELL *) line1 - *pedge) / cnst;
-    return rc;
-double slope_f(void *line1, void *line2, double cnst)
-    double rc;
-    FCELL *pedge;
-    rc = -HUGE_VAL;
-    pedge = (FCELL *) line2;
-    if (!Rast_is_f_null_value(pedge)) {
-	rc = (*(FCELL *) line1 - *pedge) / cnst;
-    return rc;
-double slope_d(void *line1, void *line2, double cnst)
-    double rc;
-    DCELL *pedge;
-    rc = -HUGE_VAL;
-    pedge = (DCELL *) line2;
-    if (!Rast_is_d_null_value(pedge)) {
-	rc = (*(DCELL *) line1 - *pedge) / cnst;
-    return rc;
-/* read a line and update a three-line buffer */
-/* moving forward through a file */
-int advance_band3(int fh, struct band3 *bnd)
-    int rc;
-    void *hold;
-    hold = bnd->b[0];
-    bnd->b[0] = bnd->b[1];
-    bnd->b[1] = bnd->b[2];
-    bnd->b[2] = hold;
-    if (fh == 0)
-	rc = 0;
-    else
-	rc = read(fh, bnd->b[2], bnd->sz);
-    return rc;
-/* moving backward through a file */
-int retreat_band3(int fh, struct band3 *bnd)
-    int rc;
-    void *hold;
-    hold = bnd->b[2];
-    bnd->b[2] = bnd->b[1];
-    bnd->b[1] = bnd->b[0];
-    bnd->b[0] = hold;
-    if (fh == 0)
-	rc = 0;
-    else {
-	rc = read(fh, bnd->b[0], bnd->sz);
-	lseek(fh, (off_t) - 2 * bnd->sz, SEEK_CUR);
-    return rc;
Deleted: grass/trunk/raster/r.path/tinf.h
--- grass/trunk/raster/r.drain/tinf.h	2017-12-04 15:37:44 UTC (rev 71888)
+++ grass/trunk/raster/r.path/tinf.h	2017-12-20 22:06:06 UTC (rev 71962)
@@ -1,102 +0,0 @@
-#include <limits.h>
-#include <math.h>
-#include <unistd.h>
-#include <sys/types.h>
-/* #include <values.h> */
-/* to add a new multiple-type function first add three prototypes
- * (one for each type).  The functions themselves must be defined
- * elsewhere */
-void set_func_pointers(int);
-int is_null_c(void *);
-int is_null_f(void *);
-int is_null_d(void *);
-void set_null_value_c(void *, int);
-void set_null_value_f(void *, int);
-void set_null_value_d(void *, int);
-int bpe_c();
-int bpe_f();
-int bpe_d();
-void *get_min_c(void *, void *);
-void *get_min_f(void *, void *);
-void *get_min_d(void *, void *);
-void *get_max_c(void *, void *);
-void *get_max_f(void *, void *);
-void *get_max_d(void *, void *);
-void get_row_c(int, void *, int);
-void get_row_f(int, void *, int);
-void get_row_d(int, void *, int);
-void put_row_c(int, void *);
-void put_row_f(int, void *);
-void put_row_d(int, void *);
-void *get_buf_c(void);
-void *get_buf_f(void);
-void *get_buf_d(void);
-void set_min_c(void *);
-void set_min_f(void *);
-void set_min_d(void *);
-void set_max_c(void *);
-void set_max_f(void *);
-void set_max_d(void *);
-void diff_c(void *, void *);
-void diff_f(void *, void *);
-void diff_d(void *, void *);
-void sum_c(void *, void *);
-void sum_f(void *, void *);
-void sum_d(void *, void *);
-void quot_c(void *, void *);
-void quot_f(void *, void *);
-void quot_d(void *, void *);
-void prod_c(void *, void *);
-void prod_f(void *, void *);
-void prod_d(void *, void *);
-/* to add a new multitype function, add a pointer for the function and
- * its argument list to the list below */
-extern int (*is_null) (void *);
-extern void (*set_null_value) (void *, int);
-extern int (*bpe) ();
-extern void *(*get_max) (void *, void *);
-extern void *(*get_min) (void *, void *);
-extern void (*get_row) (int, void *, int);
-extern void *(*get_buf) ();
-extern void (*put_row) (int, void *);
-extern double (*slope) (void *, void *, double);
-extern void (*set_min) (void *);
-extern void (*set_max) (void *);
-extern void (*diff) (void *, void *);
-extern void (*sum) (void *, void *);
-extern void (*quot) (void *, void *);
-extern void (*prod) (void *, void *);
-/* probably not something of general interest */
-double slope_c(void *, void *, double);
-double slope_f(void *, void *, double);
-double slope_d(void *, void *, double);
-struct band3
-    int ns;			/* samples per line */
-    off_t sz;			/* bytes per line */
-    char *b[3];			/* pointers to start of each line */
-int advance_band3(int, struct band3 *);
-int retreat_band3(int, struct band3 *);
