[GRASS-SVN] r71963 - in grass/trunk/raster: r.cost r.walk
svn_grass at osgeo.org
Wed Dec 20 14:09:39 PST 2017
Author: mmetz
Date: 2017-12-20 14:09:39 -0800 (Wed, 20 Dec 2017)
New Revision: 71963
grass/trunk/raster/r.cost/main.c
grass/trunk/raster/r.cost/r.cost.html
grass/trunk/raster/r.cost/stash.h
grass/trunk/raster/r.walk/main.c
grass/trunk/raster/r.walk/r.walk.html
grass/trunk/raster/r.walk/stash.h
r.cost/r.walk: add bitmask encoded directions, use r.path instead of r.drain
Modified: grass/trunk/raster/r.cost/main.c
--- grass/trunk/raster/r.cost/main.c 2017-12-20 22:06:06 UTC (rev 71962)
+++ grass/trunk/raster/r.cost/main.c 2017-12-20 22:09:39 UTC (rev 71963)
@@ -79,8 +79,6 @@
struct Cell_head window;
-struct start_pt *head_start_pt = NULL;
struct rc
int r;
@@ -132,11 +130,12 @@
long n_processed = 0;
long total_cells;
struct GModule *module;
- struct Flag *flag2, *flag3, *flag4, *flag5;
+ struct Flag *flag2, *flag3, *flag4, *flag5, *flag6;
struct Option *opt1, *opt2, *opt3, *opt4, *opt5, *opt6, *opt7, *opt8;
struct Option *opt9, *opt10, *opt11, *opt12;
struct cost *pres_cell;
- struct start_pt *pres_start_pt = NULL;
+ struct start_pt *head_start_pt = NULL;
+ struct start_pt *next_start_pt;
struct cc {
double cost_in, cost_out, nearest;
} costs;
@@ -150,6 +149,7 @@
double peak = 0.0;
int dsize, nearest_size;
double disk_mb, mem_mb, pq_mb;
+ int dir_bin;
G_gisinit(argv[0]);
@@ -263,6 +263,11 @@
flag5->key = 'i';
flag5->description = _("Print info about disk space and memory requirements and exit");
+ flag6 = G_define_flag();
+ flag6->key = 'b';
+ flag6->description = _("Create bitmask encoded directions");
+ flag6->guisection = _("Optional outputs");
/* Parse options */
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -300,6 +305,8 @@
start_with_raster_vals = flag4->answer;
+ dir_bin = flag6->answer;
int count = 0;
@@ -315,7 +322,8 @@
if (opt3->answers) {
- if (!process_start_coords(opt3->answers, &head_start_pt, &pres_start_pt))
+ head_start_pt = process_start_coords(opt3->answers, head_start_pt);
+ if (!head_start_pt)
G_fatal_error(_("No start points"));
@@ -520,11 +528,14 @@
if (dir == 1) {
+ FCELL fnullval;
G_message(_("Initializing directional output..."));
+ Rast_set_f_null_value(&fnullval, 1);
for (row = 0; row < nrows; row++) {
G_percent(row, nrows, 2);
for (col = 0; col < ncols; col++) {
- Segment_put(&dir_seg, &dnullval, row, col);
+ Segment_put(&dir_seg, &fnullval, row, col);
G_percent(1, 1, 1);
@@ -540,7 +551,6 @@
struct line_pnts *Points;
struct line_cats *Cats;
struct bound_box box;
- struct start_pt *new_start_pt;
int cat, type, npoints = 0;
Points = Vect_new_line_struct();
@@ -577,24 +587,15 @@
col = (int)Rast_easting_to_col(Points->x[0], &window);
row = (int)Rast_northing_to_row(Points->y[0], &window);
- new_start_pt =
+ next_start_pt =
(struct start_pt *)(G_malloc(sizeof(struct start_pt)));
- new_start_pt->row = row;
- new_start_pt->col = col;
+ next_start_pt->row = row;
+ next_start_pt->col = col;
Vect_cat_get(Cats, 1, &cat);
- new_start_pt->value = cat;
- new_start_pt->next = NULL;
- if (head_start_pt == NULL) {
- head_start_pt = new_start_pt;
- pres_start_pt = new_start_pt;
- else {
- pres_start_pt->next = new_start_pt;
+ next_start_pt->value = cat;
+ next_start_pt->next = head_start_pt;
+ head_start_pt = next_start_pt;
if (npoints < 1)
@@ -714,26 +715,24 @@
- /* Insert start points into min heap
+ /* Insert start points into min heap */
if (head_start_pt) {
- struct start_pt *top_start_pt = NULL;
- top_start_pt = head_start_pt;
- while (top_start_pt != NULL) {
+ next_start_pt = head_start_pt;
+ while (next_start_pt != NULL) {
value = &zero;
- if (top_start_pt->row < 0 || top_start_pt->row >= nrows
- || top_start_pt->col < 0 || top_start_pt->col >= ncols)
+ if (next_start_pt->row < 0 || next_start_pt->row >= nrows
+ || next_start_pt->col < 0 || next_start_pt->col >= ncols)
G_fatal_error(_("Specified starting location outside database window"));
- insert(zero, top_start_pt->row, top_start_pt->col);
- Segment_get(&cost_seg, &costs, top_start_pt->row,
- top_start_pt->col);
+ insert(zero, next_start_pt->row, next_start_pt->col);
+ Segment_get(&cost_seg, &costs, next_start_pt->row,
+ next_start_pt->col);
costs.cost_out = *value;
- costs.nearest = top_start_pt->value;
+ costs.nearest = next_start_pt->value;
- Segment_put(&cost_seg, &costs, top_start_pt->row,
- top_start_pt = top_start_pt->next;
+ Segment_put(&cost_seg, &costs, next_start_pt->row,
+ next_start_pt = next_start_pt->next;
@@ -819,7 +818,7 @@
* 202.5 225 270 315 337.5
* 247.5 292.5
- * X = present cell, directions for neighbors:
+ * X = current cell:
* 292.5 247.5
* 337.5 315 270 225 202.5
@@ -828,75 +827,134 @@
* 67.5 112.5
+ /* drainage directions bitmask encoded CW from North
+ * drainage directions are set for each neighbor and must be
+ * read as from neighbor to current cell
+ * bit positions, zero-based, from neighbor to current cell
+ * X = neighbor X = current cell
+ * 15 8 11 12
+ * 14 6 7 0 9 10 2 3 4 13
+ * 5 X 1 1 X 5
+ * 13 4 3 2 10 9 0 7 6 14
+ * 12 11 8 15
for (neighbor = 1; neighbor <= total_reviewed; neighbor++) {
switch (neighbor) {
case 1:
+ row = pres_cell->row;
col = pres_cell->col - 1;
cur_dir = 360.0;
+ if (dir_bin)
+ cur_dir = 1;
break;
case 2:
col = pres_cell->col + 1;
cur_dir = 180.0;
+ if (dir_bin)
+ cur_dir = 5;
break;
case 3:
row = pres_cell->row - 1;
col = pres_cell->col;
cur_dir = 270.0;
+ if (dir_bin)
+ cur_dir = 3;
break;
case 4:
row = pres_cell->row + 1;
+ col = pres_cell->col;
cur_dir = 90.0;
+ if (dir_bin)
+ cur_dir = 7;
break;
case 5:
cur_dir = 315.0;
+ if (dir_bin)
+ cur_dir = 2;
break;
case 6:
+ row = pres_cell->row - 1;
cur_dir = 225.0;
+ if (dir_bin)
+ cur_dir = 4;
break;
case 7:
+ col = pres_cell->col + 1;
cur_dir = 135.0;
+ if (dir_bin)
+ cur_dir = 6;
break;
case 8:
+ row = pres_cell->row + 1;
cur_dir = 45.0;
+ if (dir_bin)
+ cur_dir = 0;
break;
case 9:
row = pres_cell->row - 2;
cur_dir = 292.5;
+ if (dir_bin)
+ cur_dir = 11;
break;
case 10:
+ row = pres_cell->row - 2;
cur_dir = 247.5;
+ if (dir_bin)
+ cur_dir = 12;
break;
case 11:
row = pres_cell->row + 2;
cur_dir = 112.5;
+ if (dir_bin)
+ cur_dir = 15;
break;
case 12:
+ row = pres_cell->row + 2;
cur_dir = 67.5;
+ if (dir_bin)
+ cur_dir = 8;
break;
case 13:
col = pres_cell->col - 2;
cur_dir = 337.5;
+ if (dir_bin)
+ cur_dir = 10;
break;
case 14:
col = pres_cell->col + 2;
cur_dir = 202.5;
+ if (dir_bin)
+ cur_dir = 13;
break;
case 15:
+ col = pres_cell->col + 2;
cur_dir = 157.5;
+ if (dir_bin)
+ cur_dir = 14;
break;
case 16:
cur_dir = 22.5;
+ if (dir_bin)
+ cur_dir = 9;
break;
@@ -1005,6 +1063,8 @@
Segment_put(&cost_seg, &costs, row, col);
insert(min_cost, row, col);
if (dir == 1) {
+ if (dir_bin)
+ cur_dir = (1 << (int)cur_dir);
Segment_put(&dir_seg, &cur_dir, row, col);
@@ -1015,9 +1075,28 @@
if (dir == 1) {
+ if (dir_bin)
+ else if (dir && dir_bin && old_min_cost == min_cost) {
+ FCELL old_dir;
+ int dir_inv[16] = { 4, 5, 6, 7, 0, 1, 2, 3,
+ 12, 13, 14, 15, 8, 9, 10, 11 };
+ int dir_fwd;
+ /* this can create circular paths:
+ * set only if current cell does not point to neighbor
+ * does not avoid longer circular paths */
+ Segment_get(&dir_seg, &old_dir, pres_cell->row, pres_cell->col);
+ dir_fwd = (1 << dir_inv[(int)cur_dir]);
+ if (!((int)old_dir & dir_fwd)) {
+ Segment_get(&dir_seg, &old_dir, row, col);
+ cur_dir = ((1 << (int)cur_dir) | (int)old_dir);
+ Segment_put(&dir_seg, &cur_dir, row, col);
if (stop_pnts && time_to_stop(pres_cell->row, pres_cell->col))
@@ -1220,17 +1299,14 @@
exit(EXIT_SUCCESS);
-int
-process_start_coords(char **answers, struct start_pt **points,
- struct start_pt **top_start_pt)
+struct start_pt *
+process_start_coords(char **answers, struct start_pt *top_start_pt)
int col, row;
double east, north;
int point_no = 0;
- *points = NULL;
if (!answers)
return (0);
@@ -1255,19 +1331,11 @@
new_start_pt->value = ++point_no;
+ new_start_pt->next = top_start_pt;
+ top_start_pt = new_start_pt;
- if (*points == NULL) {
- *points = new_start_pt;
- *top_start_pt = new_start_pt;
- else {
- (*top_start_pt)->next = new_start_pt;
- return (point_no > 0);
+ return top_start_pt;
int process_stop_coords(char **answers)
Modified: grass/trunk/raster/r.cost/r.cost.html
--- grass/trunk/raster/r.cost/r.cost.html 2017-12-20 22:06:06 UTC (rev 71962)
+++ grass/trunk/raster/r.cost/r.cost.html 2017-12-20 22:09:39 UTC (rev 71963)
@@ -102,21 +102,10 @@
<h2>NOTES</h2>
-Sometimes, when the differences among integer cell category values in the
-<em>r.cost</em> cumulative cost surface output are small, this
-cumulative cost output cannot accurately be used as input to <em><a href="r.drain.html">r.drain</a></em>
-(<em><a href="r.drain.html">r.drain</a></em> will output bad
-results). This problem can be circumvented by making the differences
-between cell category values in the cumulative cost output bigger. It
-is recommended that, if the output from <em>r.cost</em> is to be used
-as input to <em><a href="r.drain.html">r.drain</a></em>, the user
-multiply the input cost surface map to <em>r.cost</em> by the value
-of the map's cell resolution, before running <em>r.cost</em>. This
-can be done using <em><a href="r.mapcalc.html">r.mapcalc</a></em>. The map
-resolution can be found using <em><a href="g.region.html">g.region</a></em>.
-This problem doesn't arise with floating point maps.
+Paths from any point to the nearest starting point of <em>r.cost</em>
+can be extracted with <em><a href="r.path.html">r.path</a></em> by
+using the direction output map of <em>r.cost</em>.
<h3>Algorithm notes</h3>
The fundamental approach to calculating minimum travel cost is as
@@ -202,9 +191,9 @@
<h3>Output analysis</h3>
The output map can be viewed, for example, as an elevation model in which
-the starting location(s) is/are the lowest point(s). Outputs from <em>r.cost</em>
-can be used as inputs to <em><a href="r.drain.html">r.drain</a></em> with
-the direction flag <b>-d</b>, in order to trace the least-cost path given by this
+the starting location(s) is/are the lowest point(s). Outputs from <em>r.cost</em>
+can be used as inputs to <em><a href="r.path.html">r.path</a></em> ,
+in order to trace the least-cost path given by this
model between any given cell and the <em>r.cost</em> starting location(s). The
two programs, when used together, generate least-cost paths or corridors between any
two map locations (cells).
@@ -231,10 +220,11 @@
<a name="move"></a>
<h2>Movement Direction</h2>
The movement direction surface is created to record the sequence of
-movements that created the cost accumulation surface. Without it
-<em><a href="r.drain.html">r.drain</a></em> would not correctly create a path from an end point
-back to the start point. The direction of each cell points towards
-the next cell. The directions are recorded as degrees CCW from East:
+movements that created the cost accumulation surface. This movement
+direction surface can be used by <em><a href="r.path.html">r.path</a></em>
+to recover a path from an end point back to the start point.
+The direction of each cell points towards the next cell.
+The directions are recorded as degrees CCW from East:
<div class="code"><pre>
112.5 67.5 i.e. a cell with the value 135
@@ -256,26 +246,26 @@
<h3>Find the minimum cost path</h3>
-Once <em>r.cost</em> computes the cumulative cost map, <em><a href="r.drain.html">r.drain</a></em>
-can be used to find the minimum cost path. Make sure to use the <b>-d</b> flag
-and the movement direction raster map when running r.drain to ensure
-the path is computed according to the proper movement directions.
+Once <em>r.cost</em> computes the cumulative cost map and an associated
+movement direction map, <em><a href="r.path.html">r.path</a></em>
+can be used to find the minimum cost path.
<h2>SEE ALSO</h2>
<em>
-<a href="r.drain.html">r.drain</a>,
<a href="r.walk.html">r.walk</a>,
+<a href="r.path.html">r.path</a>,
<a href="r.in.ascii.html">r.in.ascii</a>,
<a href="r.mapcalc.html">r.mapcalc</a>,
<a href="r.out.ascii.html">r.out.ascii</a>
</em>
-<h2>AUTHOR</h2>
+<h2>AUTHORS</h2>
Antony Awaida, Intelligent Engineering Systems Laboratory, M.I.T.<br>
James Westervelt, U.S.Army Construction Engineering Research Laboratory<br>
Updated for Grass 5 by Pierre de Mouveaux (pmx at audiovu.com)
+Markus Metz
<p>
<i>Last changed: $Date$</i>
Modified: grass/trunk/raster/r.cost/stash.h
--- grass/trunk/raster/r.cost/stash.h 2017-12-20 22:06:06 UTC (rev 71962)
+++ grass/trunk/raster/r.cost/stash.h 2017-12-20 22:09:39 UTC (rev 71963)
@@ -28,7 +28,7 @@
struct start_pt *next;
-int process_start_coords(char **, struct start_pt **, struct start_pt **);
+struct start_pt *process_start_coords(char **, struct start_pt *);
int process_stop_coords(char **answers);
int time_to_stop(int, int);
Modified: grass/trunk/raster/r.walk/main.c
--- grass/trunk/raster/r.walk/main.c 2017-12-20 22:06:06 UTC (rev 71962)
+++ grass/trunk/raster/r.walk/main.c 2017-12-20 22:09:39 UTC (rev 71963)
@@ -36,7 +36,7 @@
* License (>=v2). Read the file COPYING that comes with GRASS
* for details.
@@ -113,8 +113,6 @@
struct rc
int r;
@@ -168,11 +166,12 @@
long total_cells;
struct Option *opt9, *opt10, *opt11, *opt12, *opt13, *opt14, *opt15;
struct cc {
double dtm; /* elevation model */
double cost_in; /* friction costs */
@@ -186,6 +185,7 @@
double peak = 0.0;
int dtm_dsize, cost_dsize;
+ int dir_bin;
/* Definition for dimension and region check */
struct Cell_head dtm_cellhd, cost_cellhd;
@@ -330,6 +330,11 @@
flag5->key = 'i';
+ flag6->key = 'b';
/* Parse options */
exit(EXIT_FAILURE);
@@ -361,6 +366,8 @@
int count = 0;
@@ -376,7 +383,8 @@
@@ -660,17 +668,19 @@
if (dir == 1) {
+ FCELL fnullval;
G_percent(1, 1, 1);
- /* Scan the existing cum_cost_layer searching for starting points.
+ /* Scan the start_points layer searching for starting points.
* Create a heap of starting points ordered by increasing costs.
init_heap();
@@ -681,7 +691,6 @@
@@ -718,24 +727,15 @@
- new_start_pt =
+ next_start_pt =
- else {
if (npoints < 1)
@@ -826,9 +826,9 @@
Segment_get(&cost_seg, &costs, row, col);
+ cellval = Rast_get_d_value(ptr2, data_type2);
if (start_with_raster_vals == 1) {
- cellval = Rast_get_d_value(ptr2, data_type2);
- insert(cellval, row, col);
+ insert(cellval, row, col);
costs.cost_out = cellval;
@@ -852,24 +852,22 @@
value = &zero;
@@ -973,7 +971,7 @@
* 247.5 292.5
* 292.5 247.5
@@ -982,75 +980,134 @@
* 67.5 112.5
+ * 15 8 11 12
+ * 5 X 1 1 X 5
+ * 12 11 8 15
switch (neighbor) {
case 1:
cur_dir = 360.0;
+ if (dir_bin)
+ cur_dir = 1;
break;
case 2:
cur_dir = 180.0;
+ if (dir_bin)
+ cur_dir = 5;
break;
case 3:
cur_dir = 270.0;
+ if (dir_bin)
+ cur_dir = 3;
break;
case 4:
cur_dir = 90.0;
+ if (dir_bin)
+ cur_dir = 7;
break;
case 5:
cur_dir = 315.0;
+ if (dir_bin)
+ cur_dir = 2;
break;
case 6:
cur_dir = 225.0;
+ if (dir_bin)
+ cur_dir = 4;
break;
case 7:
cur_dir = 135.0;
+ if (dir_bin)
+ cur_dir = 6;
break;
case 8:
cur_dir = 45.0;
+ if (dir_bin)
+ cur_dir = 0;
break;
case 9:
cur_dir = 292.5;
+ if (dir_bin)
+ cur_dir = 11;
break;
case 10:
cur_dir = 247.5;
+ if (dir_bin)
+ cur_dir = 12;
break;
case 11:
cur_dir = 112.5;
+ if (dir_bin)
+ cur_dir = 15;
break;
case 12:
cur_dir = 67.5;
+ if (dir_bin)
+ cur_dir = 8;
break;
case 13:
cur_dir = 337.5;
+ if (dir_bin)
+ cur_dir = 10;
break;
case 14:
cur_dir = 202.5;
+ if (dir_bin)
+ cur_dir = 13;
break;
case 15:
cur_dir = 157.5;
+ if (dir_bin)
+ cur_dir = 14;
break;
case 16:
cur_dir = 22.5;
+ if (dir_bin)
+ cur_dir = 9;
break;
@@ -1358,6 +1415,8 @@
if (dir == 1) {
+ if (dir_bin)
@@ -1367,9 +1426,28 @@
if (dir == 1) {
+ if (dir_bin)
+ FCELL old_dir;
+ int dir_fwd;
@@ -1506,17 +1584,14 @@
exit(EXIT_SUCCESS);
-int
+struct start_pt *
int col, row;
double east, north;
int point_no = 0;
- *points = NULL;
if (!answers)
return (0);
@@ -1541,19 +1616,11 @@
- else {
Modified: grass/trunk/raster/r.walk/r.walk.html
--- grass/trunk/raster/r.walk/r.walk.html 2017-12-20 22:06:06 UTC (rev 71962)
+++ grass/trunk/raster/r.walk/r.walk.html 2017-12-20 22:09:39 UTC (rev 71963)
@@ -92,11 +92,14 @@
<a name="move"></a>
-<p>The movement direction surface is created to record the sequence of
+<p>
+The movement direction surface is created to record the sequence of
157.5 135 90 45 22.5 means the next cell is to the north-west
@@ -108,12 +111,9 @@
<p>
Once <em>r.walk</em> computes the cumulative cost map as a linear
combination of friction cost (from friction map) and the altitude and
-distance covered (from the digital elevation
-model), <em><a href="r.drain.html">r.drain</a></em> can be used to
-find the minimum cost path. Make sure to use the <b>-d</b> flag and
-the movement direction raster map when
-running <em><a href="r.drain.html">r.drain</a></em> to ensure the path
-is computed according to the proper movement directions.
+distance covered (from the digital elevation model), the associated
+movement direction map can be used by <em><a href="r.path.html">r.path</a></em>
+to find the minimum cost path.
<p>
<em>r.walk</em>, like most all GRASS raster programs, is also made to
@@ -167,7 +167,7 @@
<em>
<a href="r.cost.html">r.cost</a>,
Modified: grass/trunk/raster/r.walk/stash.h
--- grass/trunk/raster/r.walk/stash.h 2017-12-20 22:06:06 UTC (rev 71962)
+++ grass/trunk/raster/r.walk/stash.h 2017-12-20 22:09:39 UTC (rev 71963)
@@ -28,7 +28,7 @@
