[GRASS-SVN] r71964 - grass/trunk/raster/r.path
svn_grass at osgeo.org
Wed Dec 20 19:25:23 PST 2017
Author: wenzeslaus
Date: 2017-12-20 19:25:23 -0800 (Wed, 20 Dec 2017)
New Revision: 71964
Added:
grass/trunk/raster/r.path/r_path_with_bitmask.png
grass/trunk/raster/r.path/r.path.html
r.path: add image to doc, add single dir, fix other img URL
Modified: grass/trunk/raster/r.path/r.path.html
--- grass/trunk/raster/r.path/r.path.html 2017-12-20 22:09:39 UTC (rev 71963)
+++ grass/trunk/raster/r.path/r.path.html 2017-12-21 03:25:23 UTC (rev 71964)
@@ -130,7 +130,7 @@
</pre></div>
<div align="center">
-<a href="r_drain_with_r_watershed_direction.png"><img src="r_drain_with_r_watershed_direction.png" alt="drainage using r.watershed" width="300" height="280"></a>
+<a href="r_path_with_r_watershed_direction.png"><img src="r_path_with_r_watershed_direction.png" alt="drainage using r.watershed" width="300" height="280"></a>
<br>
<i>Figure: Drainage paths from two points where directions from
r.watershed were used</i>
@@ -143,7 +143,7 @@
g.region swwake_30m -p
# create friction map based on land cover
-r.recode landclass96 out=friction << EOF
+r.recode input=landclass96 output=friction rules=- << EOF
1:3:0.1:0.1
4:5:10.:10.
6:6:1000.0:1000.0
@@ -163,14 +163,36 @@
r.path -b input=walkdir_k start_coordinates=640206,222795 \
raster_path=walkpath_k vector_path=walkpath_k
+# without Knight's move and without bitmask encoding (single direction)
+r.walk elevation=elev_ned_30m friction=friction output=walkcost_s \
+ outdir=walkdir_s start_coordinates=635576,216485
+r.path input=walkdir_s start_coordinates=640206,222795 \
+ raster_path=walkpath_s vector_path=walkpath_s
</pre></div>
+d.vect map=walkpath_s color=243:66:53 width=10 legend_label="Single direction"
+d.vect map=walkpath color=254:192:6 width=4 legend_label=Bitmask
+d.vect map=walkpath_k color=62:80:180 width=2 legend_label="Bitmask + knight's"
The extracted least-cost path splits and merges on the way from
the start point to the stop point (start point for r.walk). Note the
gaps in the raster path when using the Knight's move.
<div class="code"><pre>
</pre></div>
+<div align="center">
+<a href="r_path_with_bitmask.png">
+ <img src="r_path_with_bitmask.png" alt="least cost path using bitmask" width="129" height="300">
+</a>
+<br>
+<i>Figure: Comparison of shortest path computed using single directional
+angles and bitmask direction encoding with and without Knight's move</i>
+</div>
<h2>SEE ALSO</h2>
<em>
Added: grass/trunk/raster/r.path/r_path_with_bitmask.png
(Binary files differ)
Property changes on: grass/trunk/raster/r.path/r_path_with_bitmask.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
