[GRASS-SVN] r71965 - grass-addons/grass7/raster/r.modis/r.modis.import
Thu Dec 21 08:38:30 PST 2017
Author: lucadelu
Date: 2017-12-21 08:38:30 -0800 (Thu, 21 Dec 2017)
New Revision: 71965
   grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
r.modis.import: fixed import for mosaics
Modified: grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
--- grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py	2017-12-21 03:25:23 UTC (rev 71964)
+++ grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py	2017-12-21 16:38:30 UTC (rev 71965)
@@ -423,9 +423,9 @@
             listfiles = [os.path.join(basedir, i) for i in listfiles]
             cm = createMosaicGDAL(listfiles, spectr)
             try:
-                cm.write_vrt(outname, quiet=True)
+                cm.write_vrt(os.path.join(basedir,outname), quiet=True)
             except:
-                cm.write_vrt(outname)
+                cm.write_vrt(os.path.join(basedir,outname))
             hdfiles = glob.glob1(basedir, outname + "*.vrt")
         for i in hdfiles:
             # the full path to hdf file
@@ -559,7 +559,8 @@
     # if t.register file is create
     if outfile:
         outfile.close()
-        # one layer only
+        tempdir = grass.tempdir()
+        # one layer only
         if count == 1:
             if flags['g']:
                 grass.message(_("file={name}".format(name=outfile.name)))
@@ -574,12 +575,20 @@
             lines = tfile.readlines()
             # get the codes from only one HDF
             for line in lines[:count]:
-                code = line.split('|')[0].split('.')[-1]
-                outfiles[code] = tempfile.NamedTemporaryFile(delete=False)
+                if flags['m']:
+                    code = '_'.join(line.split('|')[0].split('_')[2:])
+                else:
+                    code = line.split('|')[0].split('.')[-1]
+                outfiles[code] = open(os.path.join(tempdir, "{co}.txt".format(co=code)), 'w')
             # split the lines for each code
             for line in lines:
+                if flags['m']:
+                else:
                 outfiles[code].write(line)
+            for k, v in outfiles.items():
+                v.close()
             if flags['g']:
                 message = ""
             else:
