[GRASS-SVN] r70506 - grass/trunk/raster/r.to.vect
svn_grass at osgeo.org
Wed Feb 8 09:48:13 PST 2017
Author: hcho
Date: 2017-02-08 09:48:13 -0800 (Wed, 08 Feb 2017)
New Revision: 70506
Added:
grass/trunk/raster/r.to.vect/set_error_handler.c
grass/trunk/raster/r.to.vect/main.c
Call the DB error handler before the vector handler to avoid busy database warnings
Reproduce this issue in the North Carolina sample dataset:
r.to.vect input=aspect output=aspect type=line
Any unthinned input raster will produce the same issue.
Modified: grass/trunk/raster/r.to.vect/main.c
--- grass/trunk/raster/r.to.vect/main.c 2017-02-08 17:37:18 UTC (rev 70505)
+++ grass/trunk/raster/r.to.vect/main.c 2017-02-08 17:48:13 UTC (rev 70506)
@@ -151,10 +151,11 @@
G_warning(_("Categories will be unique sequence, raster values will be lost."));
+ set_error_handler(&Map, &driver);
if (Vect_open_new(&Map, out_opt->answer, z_flg->answer) < 0)
G_fatal_error(_("Unable to create vector map <%s>"), out_opt->answer);
- Vect_set_error_handler_io(NULL, &Map);
Vect_hist_command(&Map);
Cats = Vect_new_cats_struct();
@@ -186,7 +187,6 @@
if (driver == NULL)
G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
Fi->database, Fi->driver);
- db_set_error_handler_driver(driver);
/* Create new table */
db_zero_string(&sql);
Added: grass/trunk/raster/r.to.vect/set_error_handler.c
--- grass/trunk/raster/r.to.vect/set_error_handler.c (rev 0)
+++ grass/trunk/raster/r.to.vect/set_error_handler.c 2017-02-08 17:48:13 UTC (rev 70506)
@@ -0,0 +1,31 @@
+#include <grass/gis.h>
+#include <grass/vector.h>
+struct handler_input
+ struct Map_info *Map;
+ dbDriver **driver;
+static void error_handler(void *p)
+ const struct handler_input *input = (const struct handler_input *)p;
+ if (input->driver && *input->driver)
+ db_close_database_shutdown_driver(*(input->driver));
+ if (input->Map) {
+ if (input->Map->open == VECT_OPEN_CODE)
+ Vect_close(input->Map);
+ Vect_delete(input->Map->name);
+void set_error_handler(struct Map_info *Map, dbDriver **driver)
+ struct handler_input *input = G_malloc(sizeof(struct handler_input));
+ input->Map = Map;
+ input->driver = driver;
+ G_add_error_handler(error_handler, input);
