[GRASS-SVN] r70507 - grass/trunk/raster/r.to.vect
svn_grass at osgeo.org
Wed Feb 8 09:58:35 PST 2017
Author: hcho
Date: 2017-02-08 09:58:35 -0800 (Wed, 08 Feb 2017)
New Revision: 70507
grass/trunk/raster/r.to.vect/set_error_handler.c
Remove unnecessary parentheses
Modified: grass/trunk/raster/r.to.vect/set_error_handler.c
--- grass/trunk/raster/r.to.vect/set_error_handler.c 2017-02-08 17:48:13 UTC (rev 70506)
+++ grass/trunk/raster/r.to.vect/set_error_handler.c 2017-02-08 17:58:35 UTC (rev 70507)
@@ -12,7 +12,7 @@
const struct handler_input *input = (const struct handler_input *)p;
if (input->driver && *input->driver)
- db_close_database_shutdown_driver(*(input->driver));
+ db_close_database_shutdown_driver(*input->driver);
if (input->Map) {
if (input->Map->open == VECT_OPEN_CODE)
Vect_close(input->Map);
