[GRASS-SVN] r70529 - grass-addons/grass7/raster/r.modis/r.modis.import
Fri Feb 10 06:33:06 PST 2017
Author: lucadelu
Date: 2017-02-10 06:33:06 -0800 (Fri, 10 Feb 2017)
New Revision: 70529
   grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
r.modis.import: added l flag, fix #3268
Modified: grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
--- grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py	2017-02-10 14:22:08 UTC (rev 70528)
+++ grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py	2017-02-10 14:33:06 UTC (rev 70529)
@@ -42,7 +42,10 @@
 #% key: w
 #% description: Create a text file to use into t.register
 #%end
+#%flag
+#% key: l
+#% description: List more info about the supported MODIS products
+#%end
 #%option
 #% key: input
 #% type: string
@@ -471,6 +474,14 @@
     if not gisbase:
         grass.fatal(_('$GISBASE not defined'))
         return 0
+    if flags['l']:
+        try:
+            from rmodislib import product
+        except:
+            grass.fatal("r.modis library is not installed")
+        prod = product()
+        prod.print_prods()
+        return 0
     # return an error if q and spectral are set
     if not flags['q'] and options['spectral'] != '':
         grass.warning(_('If no QA layer chosen in the "spectral" option'
