[GRASS-SVN] r70530 - grass/branches/releasebranch_7_2/locale/po
svn_grass at osgeo.org
Fri Feb 10 08:44:16 PST 2017
Author: martinl
Date: 2017-02-10 08:44:16 -0800 (Fri, 10 Feb 2017)
New Revision: 70530
grass/branches/releasebranch_7_2/locale/po/grasslibs_cs.po
Czech translation (libs): add missing plural forms
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_cs.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_cs.po 2017-02-10 14:33:06 UTC (rev 70529)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_cs.po 2017-02-10 16:44:16 UTC (rev 70530)
@@ -3931,7 +3931,8 @@
msgid "One primitive registered"
msgid_plural "%d primitives registered"
msgstr[0] "Jedno primitivum zaregistrováno"
-msgstr[1] "%d primitiv zaregistrováno"
+msgstr[1] "%d primitiva zaregistrována"
+msgstr[2] "%d primitiv zaregistrováno"
#: ../lib/vector/Vlib/build_sfa.c:386 ../lib/vector/Vlib/build_sfa.c:662
#: ../lib/vector/Vlib/build_nat.c:118
@@ -3939,7 +3940,8 @@
msgid "One vertex registered"
msgid_plural "%d vertices registered"
msgstr[0] "Jeden opěrný bod zaregistrován"
-msgstr[1] "%d opěrných bodů zaregistrováno"
+msgstr[1] "%d opěrné body zaregistrovány"
+msgstr[2] "%d opěrných bodů zaregistrováno"
#: ../lib/vector/Vlib/build_sfa.c:603 ../lib/vector/Vlib/read_ogr.c:344
#: ../lib/vector/Vlib/read_ogr.c:578
@@ -3952,7 +3954,8 @@
msgid "One feature without geometry skipped"
msgid_plural "%d features without geometry skipped"
msgstr[0] "Jeden prvek bez geometrie ignorován"
-msgstr[1] "%d prvků bez geometrie ignorováno"
+msgstr[1] "%d prvky bez geometrie ignorovány"
+msgstr[2] "%d prvků bez geometrie ignorováno"
#: ../lib/vector/Vlib/build_sfa.c:711 ../lib/vector/Vlib/header_finfo.c:41
#: ../lib/vector/Vlib/header_finfo.c:80 ../lib/vector/Vlib/header_finfo.c:113
@@ -4080,7 +4083,8 @@
msgid "One category loaded"
msgid_plural "%d categories loaded"
msgstr[0] "Jedna kategorie načtena"
-msgstr[1] "%d kategorií načteno"
+msgstr[1] "%d kategorie načteny"
+msgstr[2] "%d kategorií načteno"
#: ../lib/vector/Vlib/cats.c:627
#, c-format
@@ -5238,14 +5242,16 @@
msgid "One area built"
msgid_plural "%d areas built"
msgstr[0] "Jedna plocha vytvořena"
-msgstr[1] "%d ploch vytvořeno"
+msgstr[1] "%d plochy vytvořeny"
+msgstr[2] "%d ploch vytvořeno"
#: ../lib/vector/Vlib/build_nat.c:154
#, c-format
msgid "One isle built"
msgid_plural "%d isles built"
msgstr[0] "Jeden ostrov vytvořen"
-msgstr[1] "%d ostrovů vytvořeno"
+msgstr[1] "%d ostrovy vytvořeny"
+msgstr[2] "%d ostrovů vytvořeno"
#: ../lib/vector/Vlib/build_nat.c:163
msgid "Attaching islands..."
