[GRASS-SVN] r70563 - grass-addons/grass7/imagery/i.superpixels.slic
Tue Feb 14 07:09:51 PST 2017
Author: mlennert
Date: 2017-02-14 07:09:50 -0800 (Tue, 14 Feb 2017)
New Revision: 70563
   grass-addons/grass7/imagery/i.superpixels.slic/i.superpixels.slic.html
i.superpixels.slic: added hint about memory parameter and memory vs disk cache
Modified: grass-addons/grass7/imagery/i.superpixels.slic/i.superpixels.slic.html
--- grass-addons/grass7/imagery/i.superpixels.slic/i.superpixels.slic.html	2017-02-14 12:19:30 UTC (rev 70562)
+++ grass-addons/grass7/imagery/i.superpixels.slic/i.superpixels.slic.html	2017-02-14 15:09:50 UTC (rev 70563)
@@ -91,6 +91,16 @@
 distance such that no two superpixel centers can obtain the same
 position.
+<h4>Memory vs disk cache</h4>
+<em>i.superpixels.slic</em> can handle very large amounts of data. Depending
+on the amount of data and the available RAM memory, as defined by the
+<em>memory</em> parameter, the module will either work with memory cache,
+storing everything in memory, or with a disk cache, storing elements on disk
+and only retrieving the data when necessary. Disk cache is slower, but the data
+can be much larger than the RAM memory can hold. By default, the
+<em>memory</em> parameter is set fairly low for modern computer systems
+(500MB). Users should thus make sure to adjust the value to their system.
 <h2>EXAMPLES</h2>
 <h3>Segmentation of Landsat images and NDVI</h3>
