[GRASS-SVN] r70564 - grass/trunk/locale/po
svn_grass at osgeo.org
Tue Feb 14 08:32:52 PST 2017
Author: marisn
Date: 2017-02-14 08:32:52 -0800 (Tue, 14 Feb 2017)
New Revision: 70564
grass/trunk/locale/po/grasslibs_ko.po
grass/trunk/locale/po/grassmods_ko.po
grass/trunk/locale/po/grasswxpy_ko.po
Fix plural forms for Korean language
Modified: grass/trunk/locale/po/grasslibs_ko.po
--- grass/trunk/locale/po/grasslibs_ko.po 2017-02-14 15:09:50 UTC (rev 70563)
+++ grass/trunk/locale/po/grasslibs_ko.po 2017-02-14 16:32:52 UTC (rev 70564)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasslibs_ko\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2016-11-14 14:55+0100\n"
+"POT-Creation-Date: 2016-11-15 09:19+0200\n"
"PO-Revision-Date: 2013-10-30 22:07-0500\n"
"Last-Translator: Huidae Cho <grass4u at gmail.com>\n"
"Language-Team: Korean <grass-translations at lists.osgeo.org>\n"
@@ -16,1091 +16,904 @@
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
+"Plural-Forms: nplurals=1; plural=0;\n"
-#: ../lib/symbol/read.c:211
-#, c-format
-msgid "Cannot read symbol line coordinates: %s"
-msgstr "심볼의 좌표를 읽을 수 없습니다: %s"
+#: ../lib/cairodriver/text.c:46
+#, fuzzy, c-format
+msgid "Unable to convert from <%s> to UTF-8"
+msgstr "Datum %s 테이블파일을 열 수 없습니다"
-#: ../lib/symbol/read.c:260
-#, c-format
-msgid ""
-"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+#: ../lib/cairodriver/text.c:56
+msgid "Some characters could not be converted to UTF-8"
msgstr ""
-"잘못된 심볼이름: '%s' (group/name 또는 group/name at mapset 중 하나여야 합니다.)"
-#: ../lib/symbol/read.c:284
-#, c-format
-msgid "Cannot find/open symbol: '%s'"
-msgstr "심볼을 찾을 수 없거나 열 수 없습니다: '%s'"
+#: ../lib/cairodriver/raster.c:109
+#, fuzzy
+msgid "Failed to create cairo surface"
-#: ../lib/symbol/read.c:393 ../lib/symbol/read.c:411 ../lib/symbol/read.c:421
-#: ../lib/symbol/read.c:439
-#, c-format
-msgid "Incorrect symbol color: '%s', using default."
-msgstr "잘못된 심볼색상: %s, 기본값을 사용합니다."
-#: ../lib/ogsf/gv3.c:60 ../lib/ogsf/gv3.c:333 ../lib/ogsf/gp3.c:56
-#: ../lib/ogsf/gp3.c:191 ../lib/manage/do_remove.c:57
-#: ../lib/manage/do_rename.c:54 ../lib/vector/Vlib/map.c:263
-#: ../lib/vector/Vlib/legal_vname.c:141 ../lib/vector/Vlib/legal_vname.c:144
-#: ../lib/vector/Vlib/open.c:235
-#, c-format
-msgid "Vector map <%s> not found"
-msgstr "벡터맵 <%s>를 찾을 수 없습니다"
-#: ../lib/ogsf/gv3.c:66 ../lib/ogsf/gv3.c:338 ../lib/ogsf/gp3.c:62
-#: ../lib/ogsf/gp3.c:196 ../lib/python/temporal/c_libraries_interface.py:747
-#: ../lib/vector/Vlib/map.c:192 ../lib/vector/Vlib/map.c:202
-#: ../lib/vector/Vlib/map.c:274 ../lib/vector/Vlib/open.c:301
-#: ../lib/vector/Vlib/open.c:437
-#, fuzzy, c-format, python-format
-msgid "Unable to open vector map <%s>"
+#: ../lib/cairodriver/read_ppm.c:28 ../lib/cairodriver/read_bmp.c:88
+#, fuzzy, c-format
+msgid "Cairo: unable to open input file <%s>"
-#: ../lib/ogsf/gv3.c:269
+#: ../lib/cairodriver/read_ppm.c:32 ../lib/cairodriver/read_bmp.c:92
#, c-format
-msgid "No features from vector map <%s> fall within current region"
-msgstr "벡터맵 <%s>의 어떤 피쳐도 현재 영역 안에 있지 않습니다"
+msgid "Cairo: invalid input file <%s>"
+msgstr ""
-#: ../lib/ogsf/gv3.c:274
+#: ../lib/cairodriver/read_ppm.c:38
#, c-format
-msgid "Vector map <%s> loaded (%d features)"
-msgstr "백터맵 <%s>를 읽었습니다. (%d 피쳐)"
+msgid "Cairo: input file has incorrect dimensions: expected: %dx%d got: %dx%d"
+msgstr ""
-#: ../lib/ogsf/gv3.c:344 ../lib/ogsf/gp3.c:202 ../lib/vector/Vlib/map.c:300
-#: ../lib/vector/Vlib/map.c:436 ../lib/vector/Vlib/copy.c:594
-#: ../lib/vector/Vlib/copy.c:704 ../lib/vector/Vlib/ascii.c:398
-#: ../lib/vector/Vlib/array.c:276 ../lib/vector/Vlib/cats.c:589
-#: ../lib/vector/Vlib/net_build.c:159 ../lib/vector/Vlib/net_build.c:206
-#: ../lib/vector/Vlib/net_build.c:490 ../lib/vector/Vlib/net_build.c:791
-#: ../lib/vector/Vlib/net_build.c:971 ../lib/rst/interp_float/vinput2d.c:100
-#, c-format
-msgid "Database connection not defined for layer %d"
-msgstr "레이어 %d를 위한 데이타베이스 접속이 정의되지 않았습니다"
-#: ../lib/ogsf/gv3.c:350 ../lib/ogsf/gp3.c:208 ../lib/db/dbmi_client/db.c:46
-#: ../lib/db/dbmi_client/copy_tab.c:112 ../lib/db/dbmi_client/copy_tab.c:133
-#: ../lib/vector/neta/timetables.c:133 ../lib/vector/neta/utils.c:119
-#: ../lib/vector/Vlib/write_ogr.c:197 ../lib/vector/Vlib/map.c:341
-#: ../lib/vector/Vlib/write_pg.c:2907 ../lib/vector/Vlib/close_nat.c:160
-#: ../lib/vector/Vlib/ascii.c:410 ../lib/vector/Vlib/array.c:282
-#: ../lib/vector/Vlib/cats.c:597 ../lib/vector/Vlib/net_build.c:165
-#: ../lib/vector/Vlib/net_build.c:211 ../lib/vector/Vlib/net_build.c:496
-#: ../lib/vector/Vlib/net_build.c:797 ../lib/vector/Vlib/net_build.c:976
-#: ../lib/rst/interp_float/vinput2d.c:109
+#: ../lib/cairodriver/read_ppm.c:46
#, fuzzy, c-format
-msgid "Unable to open database <%s> by driver <%s>"
-msgstr "'%s' 디버그파일을 열 수 없습니다"
-#: ../lib/ogsf/gv3.c:353
-#, fuzzy, c-format
-msgid "Loading thematic vector layer <%s>..."
-msgstr "주제 벡터레이어 <%s>를 읽는 중입니다..."
-#: ../lib/ogsf/gv3.c:377 ../lib/ogsf/gp3.c:235
-#, fuzzy, c-format
-msgid "No color rule defined for category %d"
+msgid "Cairo: unable to open input mask file <%s>"
-#: ../lib/ogsf/gv3.c:392 ../lib/ogsf/gp3.c:249
-#, fuzzy, c-format
-msgid "Invalid color definition (%s)"
-msgstr "잘못된 좌표"
-#: ../lib/ogsf/gv3.c:414
+#: ../lib/cairodriver/read_ppm.c:50
#, c-format
-msgid ""
-"%d features without category. Unable to determine color rules for features "
-"without category."
+msgid "Cairo: invalid input mask file <%s>"
msgstr ""
-"%d 피쳐들이 카테고리를 가지고 있지 않습니다. 카테고리 없는 피쳐는 색상규칙을 "
-"정할 수 없습니다."
-#: ../lib/ogsf/gsd_legend.c:239 ../lib/ogsf/gs3.c:125 ../lib/ogsf/gs3.c:189
-#: ../lib/ogsf/gs3.c:264 ../lib/ogsf/gs3.c:336 ../lib/ogsf/gs3.c:442
-#: ../lib/ogsf/gs3.c:529 ../lib/ogsf/gs3.c:588 ../lib/ogsf/gs3.c:645
-#: ../lib/ogsf/gs3.c:716 ../lib/ogsf/gs3.c:786 ../lib/manage/do_remove.c:73
-#: ../lib/manage/do_rename.c:71 ../lib/raster/open.c:178
-#: ../lib/raster/open.c:845 ../lib/raster/open.c:882 ../lib/raster/open.c:934
-#: ../lib/gis/legal_name.c:94 ../lib/gis/legal_name.c:97
-#: ../lib/rst/interp_float/resout2d.c:205
-#: ../lib/rst/interp_float/resout2d.c:253
-#: ../lib/rst/interp_float/resout2d.c:296
-#: ../lib/rst/interp_float/resout2d.c:327
-#: ../lib/rst/interp_float/resout2d.c:377
-#: ../lib/rst/interp_float/resout2d.c:395
-#: ../lib/rst/interp_float/resout2d.c:410
-#: ../lib/rst/interp_float/resout2d.c:426
-#: ../lib/rst/interp_float/output2d.c:247
-#: ../lib/rst/interp_float/output2d.c:328
-#: ../lib/rst/interp_float/output2d.c:397
-#: ../lib/rst/interp_float/output2d.c:447
-#: ../lib/rst/interp_float/output2d.c:461
-#: ../lib/rst/interp_float/output2d.c:475
-#: ../lib/rst/interp_float/output2d.c:491
+#: ../lib/cairodriver/read_ppm.c:56
#, c-format
-msgid "Raster map <%s> not found"
+msgid ""
+"Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
msgstr ""
-#: ../lib/ogsf/gsd_legend.c:246
+#: ../lib/cairodriver/read_xid.c:14
#, fuzzy, c-format
-msgid "Unable to read color file of raster map <%s>"
+msgid "Unable to open input file <%s>"
-#: ../lib/ogsf/gsd_legend.c:252
+#: ../lib/cairodriver/read_xid.c:17
#, fuzzy, c-format
-msgid "Unable to read category file of raster map <%s>"
+msgid "Unable to read input file <%s>"
-#: ../lib/ogsf/gsd_legend.c:269
+#: ../lib/cairodriver/read_xid.c:20
#, fuzzy, c-format
-msgid "Unable to read fp range of raster map <%s>"
+msgid "Unable to parse input file <%s>"
-#: ../lib/ogsf/gsd_legend.c:281
+#: ../lib/cairodriver/write_xid.c:14 ../lib/pngdriver/read_png.c:71
#, fuzzy, c-format
-msgid "Unable to read range of raster map <%s>"
+msgid "Unable to open output file <%s>"
-#: ../lib/ogsf/gsd_legend.c:295
-msgid "Range request error for legend"
-msgstr ""
+#: ../lib/cairodriver/write_xid.c:19
+#, fuzzy, c-format
+msgid "Unable to write output file <%s>"
-#: ../lib/ogsf/gsd_legend.c:385
-#, fuzzy
-msgid "Unable to show discrete FP range (use list)"
-msgstr "자동 MASK파일을 열 수 없습니다"
-#: ../lib/ogsf/gsd_legend.c:501
-msgid "Too many categories to show as discrete!"
+#: ../lib/cairodriver/draw_bitmap.c:47
+msgid "Cairo_Bitmap: Failed to create source"
msgstr ""
-#: ../lib/ogsf/gsd_legend.c:503
-msgid "Try using smaller font!"
-msgstr ""
+#: ../lib/cairodriver/write_bmp.c:72 ../lib/cairodriver/write_ppm.c:27
+#, fuzzy, c-format
+msgid "Cairo: unable to open output file <%s>"
-#: ../lib/ogsf/gsd_img_ppm.c:52 ../lib/ogsf/gsd_img_ppm.c:95
-#: ../lib/ogsf/gsd_img_tif.c:66 ../lib/ogsf/gk2.c:216
+#: ../lib/cairodriver/write_ppm.c:34
#, fuzzy, c-format
-msgid "Unable to open file <%s> for writing"
+msgid "Cairo: unable to open mask file <%s>"
-#: ../lib/ogsf/trans.c:180
-msgid "Out of matrix stack space"
-msgstr "행렬 스택공간이 부족합니다"
+#: ../lib/cairodriver/graph.c:67
+#, fuzzy
+msgid "Unable to open display"
-#: ../lib/ogsf/trans.c:200
-msgid "Tried to pop an empty stack"
-msgstr "빈 스택에서 끄집어 내려고 했습니다"
+#: ../lib/cairodriver/graph.c:85
+#, fuzzy
+msgid "Unable to obtain visual"
-#: ../lib/ogsf/gsd_prim.c:146
+#: ../lib/cairodriver/graph.c:160
#, c-format
-msgid "Color Material: %d"
-msgstr "색상재료: %d"
+msgid "Unknown file extension: %s"
+msgstr ""
-#: ../lib/ogsf/gsd_prim.c:630
+#: ../lib/cairodriver/graph.c:190
+#, fuzzy, c-format
+msgid "cairo: collecting to file '%s'"
+#: ../lib/cairodriver/graph.c:192
#, c-format
-msgid ""
-"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
-"advise GRASS developers of this error"
+msgid "cairo: image size %dx%d"
msgstr ""
-"gsd_rot(): %c는 잘못된 좌표축 지정입니다. 회전을 무시합니다. GRASS 개발자들에"
-"게 조언을 구하세요."
-#: ../lib/ogsf/gs2.c:1211
-#, c-format
-msgid "no category info"
-msgstr "카테고리 정보가 없습니다."
+#: ../lib/cairodriver/graph.c:371
+#, fuzzy
+msgid "Unknown Cairo surface type"
+msgstr "알려지지 않은 벡터타입입니다"
-#: ../lib/ogsf/gs2.c:1230
-#, c-format
-msgid "no data"
-msgstr "자료가 없습니다."
+#: ../lib/cairodriver/graph.c:376
+#, fuzzy
+msgid "Failed to initialize Cairo surface"
-#: ../lib/ogsf/gs2.c:1655
+#: ../lib/cairodriver/read_bmp.c:96
#, c-format
-msgid "Raster map <%s> is outside of current region. Load failed."
-msgstr "라스터맵 <%s>이 현재 영역 바깥입니다. 읽을 수 없습니다."
+msgid "Cairo: Invalid BMP header for <%s>"
+msgstr ""
-#: ../lib/ogsf/gs2.c:1733 ../lib/ogsf/gs2.c:1739 ../lib/ogsf/gs2.c:1747
-#: ../lib/ogsf/gs2.c:1756 ../lib/ogsf/gs2.c:1764 ../lib/ogsf/gs2.c:1774
-#: ../lib/ogsf/gs2.c:1822
-msgid "GS_load_att_map(): Out of memory. Unable to load map"
-msgstr "GS_load_att_map(): 메모리가 모자랍니다. 맵을 읽을 수 없습니다."
-#: ../lib/ogsf/gs2.c:1850
-msgid "Loading failed"
-msgstr "읽을 수 없습니다."
-#: ../lib/ogsf/gs2.c:1854
-msgid "Error finding range"
-msgstr "범위를 찾지 못했습니다."
-#: ../lib/ogsf/gs3.c:132 ../lib/ogsf/gs3.c:196 ../lib/ogsf/gs3.c:348
-#: ../lib/ogsf/gs3.c:454 ../lib/ogsf/gs3.c:540
-#, fuzzy, c-format
-msgid "Loading raster map <%s>..."
-msgstr "라스터맵 <%s>를 읽는 중입니다..."
-#: ../lib/ogsf/gs3.c:596
+#: ../lib/psdriver/graph_set.c:199
#, c-format
-msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
+msgid "ps: truecolor status %s"
msgstr ""
-#: ../lib/ogsf/gs3.c:658 ../lib/ogsf/gs3.c:730
-#, fuzzy, c-format
-msgid "Translating colors from raster map <%s>..."
-msgstr "라스터맵 <%s>로부터 색상을 변환 중입니다..."
+#: ../lib/psdriver/graph_set.c:200 ../lib/pngdriver/graph_set.c:102
+msgid "enabled"
+msgstr ""
-#: ../lib/ogsf/gs3.c:967
-msgid "View not saved by this program,there may be some inconsistancies"
+msgid "disabled"
msgstr ""
-#: ../lib/ogsf/gk.c:320
-msgid "Need at least 3 keyframes for spline"
-msgstr "스플라인을 위해서는 최소 3개의 키프레임이 필요합니다."
-#: ../lib/ogsf/gk.c:622
-msgid "Need at least 2 keyframes for interpolation"
-msgstr "보간을 위해서는 최소 2개의 키프레임이 필요합니다."
-#: ../lib/ogsf/gp3.c:92 ../lib/vector/Vlib/copy.c:168
-#: ../lib/vector/Vlib/copy.c:245
-#, fuzzy, c-format
-msgid "Unable to read vector map <%s>"
-msgstr "Datum %s 테이블파일을 열 수 없습니다"
-#: ../lib/ogsf/gp3.c:148
+#: ../lib/psdriver/graph_set.c:214
#, c-format
-msgid "No points from vector map <%s> fall within current region"
-msgstr "벡터맵 <%s>의 어떤 점도 현재 영역 안에 있지 않습니다"
+msgid "ps: collecting to file '%s'"
+msgstr ""
-#: ../lib/ogsf/gp3.c:153
+#: ../lib/psdriver/graph_set.c:215
#, c-format
-msgid "Vector map <%s> loaded (%d points)"
-msgstr "벡터맵 <%s>를 읽었습니다 (%d 점)"
+msgid "ps: image size %dx%d"
+msgstr ""
-#: ../lib/ogsf/gp3.c:211
-#, fuzzy, c-format
-msgid "Loading thematic points layer <%s>..."
-msgstr "주제 점레이어 <%s>를 읽는 중입니다..."
+#: ../lib/python/exceptions/__init__.py:68
+#, python-format
+msgid "Module run %s %s ended with error"
+msgstr ""
-#: ../lib/ogsf/gp3.c:288
-#, c-format
+#: ../lib/python/exceptions/__init__.py:69
+#, python-format
msgid ""
-"%d points without category. Unable to determine color rules for features "
+"\n"
+"Process ended with non-zero return code %s"
msgstr ""
-"%d 점들이 카테고리를 가지고 있지 않습니다. 카테고리 없는 점은 색상규칙을 정"
-"할 수 없습니다."
-#: ../lib/ogsf/gp2.c:705
-msgid "Unknown icon marker, using \"sphere\""
+#: ../lib/python/exceptions/__init__.py:71
+#, python-format
+msgid ""
+". See the following errors:\n"
+"%s"
msgstr ""
-#: ../lib/ogsf/gsds.c:109
-msgid "Maximum number of datasets exceeded"
+#: ../lib/python/exceptions/__init__.py:75
+msgid ". See errors in the (error) output."
msgstr ""
-#: ../lib/ogsf/gsd_surf.c:1742
-msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
+#: ../lib/python/pygrass/raster/abstract.py:275
+#, python-brace-format
+msgid "Mode type: {0} not supported ('r', 'w')"
msgstr ""
-#: ../lib/ogsf/gvl2.c:267
-#, fuzzy, c-format
-msgid "Loading 3d raster map <%s>..."
+#: ../lib/python/pygrass/raster/abstract.py:286
+msgid "Overwrite type: {0} not supported (True/False)"
+msgstr ""
-#: ../lib/ogsf/gvl3.c:40 ../lib/ogsf/gvl_file.c:427
-#: ../lib/manage/do_remove.c:78 ../lib/manage/do_rename.c:76
-#: ../lib/gpde/n_arrays_io.c:273
-#, c-format
-msgid "3D raster map <%s> not found"
-msgstr "3차원 라스터맵 <%s>를 찾을 수 없습니다"
+#: ../lib/python/pygrass/raster/abstract.py:299
+#: ../lib/python/pygrass/vector/abstract.py:97
+msgid "Map name {0} not valid"
+msgstr ""
-#: ../lib/ogsf/gsd_label.c:58
-msgid "Max. number of labels reached!"
-msgstr "최대 레이블 개수에 도달했습니다!"
+#: ../lib/python/pygrass/raster/category.py:69
+#, fuzzy, python-brace-format
+msgid "Raster type: {0} not supported"
+msgstr "라스터 타입: {0}를 지원하지 않습니다"
-#: ../lib/ogsf/gsdrape.c:207
+#: ../lib/python/pygrass/raster/category.py:156
+msgid "Error executing: Rast_get_ith_cat"
+msgstr ""
+#: ../lib/python/pygrass/raster/category.py:184
+msgid "Null value detected"
+msgstr "널값을 찾았습니다"
+#: ../lib/python/pygrass/raster/category.py:186
#, fuzzy
-msgid "Unable to process vector map - out of memory"
+msgid "Error executing: Rast_set_cat"
-#: ../lib/ogsf/gk2.c:272 ../lib/ogsf/gk2.c:285
-msgid "Check no. of frames requested and keyframes marked"
+#: ../lib/python/pygrass/raster/__init__.py:209
+msgid "The map does not exist, I can't open in 'r' mode"
msgstr ""
-#: ../lib/ogsf/gvl_file.c:103
-msgid "Maximum number of datafiles exceeded"
-msgstr ""
-#: ../lib/ogsf/gvl_file.c:436
-#: ../lib/python/temporal/c_libraries_interface.py:676
-#: ../lib/gpde/n_arrays_io.c:281
-msgid "Unable to open 3D raster map <%s>"
+#: ../lib/python/pygrass/raster/__init__.py:214
+msgid "Raster map <{0}> already exists and will be not overwritten"
-#: ../lib/ogsf/gvl_file.c:442
-#, fuzzy, c-format
-msgid "Unable to read range of 3D raster map <%s>"
+#: ../lib/python/pygrass/raster/__init__.py:218
+#, fuzzy
+msgid "Raster type not defined"
-#: ../lib/ogsf/gvl_file.c:470 ../lib/raster3d/close.c:120
-#: ../lib/raster3d/close.c:130 ../lib/raster3d/close.c:159
-#: ../lib/python/temporal/c_libraries_interface.py:706
-msgid "Unable to close 3D raster map <%s>"
+#: ../lib/python/pygrass/raster/__init__.py:321
+msgid "Mode type: {0} not supported ('r', 'w','rw')"
+msgstr ""
-#: ../lib/ogsf/gs_bm.c:124
-msgid "Bitmap mismatch"
-msgstr "비트맵이 일치하지 않습니다."
+#: ../lib/python/pygrass/raster/__init__.py:341
+#, python-format
+msgid "Index out of range: %r."
+msgstr ""
-#: ../lib/raster3d/header.c:217 ../lib/raster3d/close.c:99
-#: ../lib/raster3d/close.c:105 ../lib/raster3d/close.c:191
-#, fuzzy, c-format
-msgid "Unable to write header for 3D raster map <%s>"
+#: ../lib/python/pygrass/raster/__init__.py:530
+msgid "Raster map <{0}> already exists. Use overwrite."
-#: ../lib/raster3d/range.c:73
-#, fuzzy, c-format
-msgid "Unable to open range file for [%s in %s]"
-#: ../lib/raster3d/range.c:88
-#, fuzzy, c-format
-msgid "Error reading range file for [%s in %s]"
+#: ../lib/python/pygrass/raster/__init__.py:561
+msgid "Raster map <{0}> does not exist"
msgstr "임시파일을 열 수 없습니다"
-#: ../lib/raster3d/range.c:150
-#, fuzzy, c-format
-msgid "Unable to open range file for <%s>"
-#: ../lib/raster3d/open.c:20
-msgid "Rast3d_open_cell_old_no_header: error in Rast3d_mask_open_old"
+#: ../lib/python/pygrass/utils.py:277
+msgid "Vector doesn't contain points"
msgstr ""
-#: ../lib/raster3d/open.c:26
-msgid "Rast3d_open_cell_old_no_header: error in Rast3d_malloc"
-msgstr ""
+#: ../lib/python/pygrass/vector/__init__.py:806
+#, fuzzy, python-format
+msgid "Unable to read line of feature %i"
+msgstr "임시파일을 열 수 없습니다"
-#: ../lib/raster3d/open.c:37
-msgid "Rast3d_open_cell_old_no_header: error in G_open_old"
-msgstr ""
+#: ../lib/python/pygrass/vector/__init__.py:895
+msgid "Unable to read area with id %i"
-#: ../lib/raster3d/open.c:93
-msgid "Rast3d_open_cell_old: error in Rast3d_open_cell_old_no_header"
+#: ../lib/python/pygrass/vector/table.py:1035
+#, python-format
+msgid "Deleting table <%s> which is attached to following map(s):"
msgstr ""
-#: ../lib/raster3d/open.c:98
-msgid "Rast3d_open_cell_old: can't rewind file"
+#: ../lib/python/pygrass/vector/table.py:1039
+msgid "You must use the force flag to actually remove it. Exiting."
msgstr ""
-#: ../lib/raster3d/open.c:111
-msgid "Rast3d_open_cell_old: error in Rast3d_read_header"
+#: ../lib/python/pygrass/modules/grid/grid.py:553
+msgid "Execution of subprocesses was not successful"
msgstr ""
-#: ../lib/raster3d/open.c:119
-msgid "Rast3d_open_cell_old: projection does not match window projection"
+#: ../lib/python/pygrass/errors.py:17
+msgid "The map is close!"
msgstr ""
-#: ../lib/raster3d/open.c:123
-msgid "Rast3d_open_cell_old: zone does not match window zone"
+#: ../lib/python/pygrass/errors.py:28
+msgid "The self.c_mapinfo pointer must be correctly initiated"
msgstr ""
-#: ../lib/raster3d/open.c:135 ../lib/raster3d/open.c:152
-msgid "Rast3d_open_cell_old: can't read header"
+#: ../lib/python/gunittest/gmodules.py:103
+msgid "input='-' must be used when stdin is specified"
msgstr ""
-#: ../lib/raster3d/open.c:141
-msgid "Rast3d_open_cell_old: index does not fit into long"
+#: ../lib/python/gunittest/gmodules.py:105
+msgid "stdin must be string or buffer, not PIPE"
msgstr ""
-#: ../lib/raster3d/open.c:145
-msgid "Rast3d_open_cell_old: error in Rast3d_malloc"
+#: ../lib/python/gunittest/gmodules.py:108
+msgid "stdin must be used when input='-'"
msgstr ""
-#: ../lib/raster3d/open.c:172
-msgid "Rast3d_open_cell_old: error in Rast3d_fill_header"
+#: ../lib/python/gunittest/gmodules.py:110
+msgid "You cannot merge stdout and stderr and not capture them"
msgstr ""
-#: ../lib/raster3d/open.c:219
-msgid "Rast3d_open_cell_new: error in Rast3d_mask_open_old"
+#: ../lib/python/gunittest/gmodules.py:112
+msgid "stdout argument not allowed, it could be overridden"
msgstr ""
-#: ../lib/raster3d/open.c:228
-msgid "Rast3d_open_cell_new: error in Rast3d_malloc"
+#: ../lib/python/gunittest/gmodules.py:114
+msgid "stderr argument not allowed, it could be overridden"
msgstr ""
-#: ../lib/raster3d/open.c:233
-#, fuzzy, c-format
-msgid "map <%s> is not in the current mapset"
-#: ../lib/raster3d/open.c:243
-msgid "Rast3d_open_cell_new: could not open file"
+#: ../lib/python/temporal/datetime_math.py:256
+#: ../lib/python/temporal/datetime_math.py:273
+#, python-format
+msgid "Wrong increment format: %s"
msgstr ""
-#: ../lib/raster3d/open.c:287 ../lib/raster3d/open.c:292
-msgid "Rast3d_open_cell_new: can't write header"
+#: ../lib/python/temporal/datetime_math.py:451
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1616
+#, python-format
+msgid "Wrong granularity format: %s"
msgstr ""
-#: ../lib/raster3d/open.c:314
-msgid "Rast3d_open_cell_new: error in Rast3d_fill_header"
+#: ../lib/python/temporal/datetime_math.py:729
+msgid "Time string seems to specify relative time"
msgstr ""
-#: ../lib/raster3d/close.c:47
-#, fuzzy, c-format
-msgid "Unable to write history for 3D raster map <%s>"
-#: ../lib/raster3d/close.c:62
-#, fuzzy, c-format
-msgid "Unable to move temp raster map <%s> to 3D raster map <%s>"
-#: ../lib/raster3d/close.c:79
+#: ../lib/python/temporal/datetime_math.py:741
#, fuzzy
-msgid "Unable to flush all tiles"
+msgid "Dates Before Christ (BC) are not supported"
-#: ../lib/raster3d/close.c:84
+#: ../lib/python/temporal/datetime_math.py:745
#, fuzzy
-msgid "Unable to flush index"
+msgid "Time zones are not supported"
-#: ../lib/raster3d/close.c:94
-#, fuzzy
-msgid "Unable to position file"
+#: ../lib/python/temporal/datetime_math.py:755
+msgid "Unable to parse time string: %s"
-#: ../lib/raster3d/close.c:110 ../lib/raster3d/close.c:153
-#, fuzzy, c-format
-msgid "Unable to create 3D raster map <%s>"
-#: ../lib/raster3d/close.c:169
-msgid "Error in cache"
+#: ../lib/python/temporal/core.py:604
+msgid ""
+"Unable to initialize the temporal DBMI interface. Please use t.connect to "
+"specify the driver and the database string"
msgstr ""
-#: ../lib/raster3d/test/test_main.c:96
-#, fuzzy
-msgid "raster3d"
-msgstr "라스터"
+#: ../lib/python/temporal/core.py:667
+msgid ""
+"Unable to receive temporal database metadata.\n"
+"Current temporal database info:%(info)s"
-#: ../lib/raster3d/test/test_main.c:97
-msgid "unit test"
-msgstr ""
+#: ../lib/python/temporal/core.py:672
+msgid ""
+"Unsupported temporal database: version mismatch.\n"
+" %(backup)s Supported temporal API version is: %(api)i.\n"
+"Please update your GRASS GIS installation.\n"
-#: ../lib/raster3d/history.c:43
-#, c-format
-msgid "can't get history information for [%s] in mapset [%s]"
-msgstr ""
+#: ../lib/python/temporal/core.py:680
+msgid ""
+" %(backup)sSupported temporal database version is: %(tdb)i\n"
-#: ../lib/raster3d/param.c:84
-msgid "Rast3d_get_standard3d_params: precision value invalid"
-msgstr ""
+#: ../lib/python/temporal/core.py:768
+msgid "Creating temporal database: %s"
-#: ../lib/raster3d/param.c:105
-msgid "Rast3d_get_standard3d_params: tile dimension value invalid"
+#: ../lib/python/temporal/core.py:777
+#, python-format
+msgid ""
+"Unable to create SQLite temporal database\n"
+"Exception: %s\n"
+"Please use t.connect to set a read- and writable temporal database path"
msgstr ""
-#: ../lib/raster3d/param.c:129
-msgid "Window replacing the default"
-msgstr ""
+#: ../lib/python/temporal/core.py:942
+#, fuzzy
+msgid "Unable to mogrify sql statement. "
+msgstr "%s 요소를 지울 수 없습니다"
-#: ../lib/raster3d/color.c:354
-#, c-format
-msgid "mapset <%s> is not the current mapset"
-msgstr ""
+#: ../lib/python/temporal/core.py:964
+#, fuzzy
+msgid "Unable to check table. "
-#: ../lib/raster3d/maskfn.c:77
-#, c-format
-msgid "Adding rule: %lf - %lf"
-msgstr ""
-#: ../lib/raster3d/maskfn.c:95
-#, fuzzy, c-format
-msgid "%s: illegal value spec"
-msgstr "잘못된 row 값"
-#: ../lib/imagery/iscatt_core.c:81
-#, fuzzy, c-format
-msgid "Unable to write header into category raster condition file <%s>."
+#: ../lib/python/temporal/core.py:980
+#, fuzzy
+msgid "Unable to execute sql statement. "
-#: ../lib/imagery/iscatt_core.c:98
-#, fuzzy, c-format
-msgid "Unable to write into category raster condition file <%s>."
-#: ../lib/imagery/iscatt_core.c:255
-#, fuzzy, c-format
-msgid "Unable to open category raster condtions file <%s>."
+#: ../lib/python/temporal/core.py:990
+#, fuzzy
+msgid "Unable to fetch one. "
-#: ../lib/imagery/iscatt_core.c:263
-#, fuzzy, c-format
-msgid "Unable to find patch raster <%s>."
+#: ../lib/python/temporal/core.py:1000
+#, fuzzy
+msgid "Unable to fetch all. "
-#: ../lib/imagery/iscatt_core.c:280
-#, c-format
-msgid "Resolutions of patch <%s> and patched file <%s> are not same."
-msgstr ""
-#: ../lib/imagery/iscatt_core.c:307 ../lib/imagery/iscatt_core.c:349
-#, c-format
-msgid "Corrupted category raster conditions file <%s> (fseek failed)"
-msgstr ""
-#: ../lib/imagery/iscatt_core.c:338
-#, fuzzy, c-format
-msgid "Unable to write into category raster conditions file <%s>"
-#: ../lib/imagery/iscatt_core.c:526
+#: ../lib/python/temporal/core.py:1017
#, fuzzy
-msgid "Unable to read from category raster condtition file."
+msgid "Unable to execute transaction. "
-#: ../lib/imagery/iscatt_core.c:533
-msgid "Invalid size of category raster conditions file."
-msgstr ""
-#: ../lib/imagery/iscatt_core.c:579
+#: ../lib/python/temporal/core.py:1120
+#, python-format
msgid ""
-"Data inconsistent. Value computed for scatter plot is out of initialized "
-"range."
+"Unable to connect to %(db)s database: %(string)s\n"
+"Exception: \"%(ex)s\"\n"
+"Please use t.connect to set a read- and writable temporal database backend"
msgstr ""
-#: ../lib/imagery/iscatt_core.c:745
-#, fuzzy, c-format
-msgid "Unbale to read find raster <%s>"
+#: ../lib/python/temporal/core.py:1277
+msgid ""
+"Unable to execute :\n"
+" %(sql)s"
-#: ../lib/imagery/iscatt_core.c:755
-#, fuzzy, c-format
-msgid "Unbale to open raster <%s>"
+#: ../lib/python/temporal/core.py:1321
+msgid ""
+"Unable to execute transaction:\n"
+" %(sql)s"
-#: ../lib/imagery/iscatt_core.c:761
-#, fuzzy, c-format
-msgid "Raster <%s> type is not <%s>"
+#: ../lib/python/temporal/temporal_vector_algebra.py:386
+#, python-format
+msgid ""
+"Error vector maps with basename %s exist. Use --o flag to overwrite existing "
+"file"
+msgstr ""
-#: ../lib/imagery/iscatt_core.c:775
-#, fuzzy, c-format
-msgid "Unable to read range of raster <%s>"
+#: ../lib/python/temporal/temporal_vector_algebra.py:419
+msgid ""
+"Error starting %s : \n"
+"%s"
-#: ../lib/imagery/iscatt_core.c:803
-#, fuzzy, c-format
-msgid "Unable to open category raster condtition file <%s>"
+#: ../lib/python/temporal/temporal_vector_algebra.py:492
+msgid ""
+"Error vector map %s exist in temporal database. Use overwrite flag. : \n"
+"%s"
-#: ../lib/imagery/iscatt_core.c:817
-msgid "Corrupted category raster conditions file (fseek failed)"
+#: ../lib/python/temporal/extract.py:60
+msgid "You need to specify the base name of new created maps"
msgstr ""
-#: ../lib/imagery/iscatt_core.c:972 ../lib/imagery/iclass_statistics.c:227
-#, c-format
-msgid "prepare_signature: scan line %d has odd number of points."
-msgstr ""
-#: ../lib/imagery/iscatt_core.c:981 ../lib/imagery/iclass_statistics.c:237
-msgid "signature: perimeter points out of order."
-msgstr ""
-#: ../lib/imagery/target.c:38
-#, fuzzy, c-format
-msgid "Unable to read target file for group [%s]"
+#: ../lib/python/temporal/extract.py:131
+#: ../lib/python/temporal/open_stds.py:211
+#: ../lib/python/temporal/mapcalc.py:240
+msgid ""
+"Map <%s> is already in temporal database, use overwrite flag to overwrite"
-#: ../lib/imagery/georef_tps.c:219
-msgid "Calculating forward transformation coefficients"
+#: ../lib/python/temporal/extract.py:138
+#, python-format
+msgid "Applying r.mapcalc expression: \"%s\""
msgstr ""
-#: ../lib/imagery/georef_tps.c:236
-msgid "Calculating backward transformation coefficients"
+#: ../lib/python/temporal/extract.py:143
+#, python-format
+msgid "Applying r3.mapcalc expression: \"%s\""
msgstr ""
-#: ../lib/imagery/georef_tps.c:279 ../lib/imagery/georef_tps.c:282
-#: ../lib/imagery/georef_tps.c:285 ../lib/imagery/georef_tps.c:290
-#: ../lib/imagery/georef_tps.c:293
-#, c-format
-msgid "%s: out of memory"
+#: ../lib/python/temporal/extract.py:148
+#, python-format
+msgid "Applying v.extract where statement: \"%s\""
msgstr ""
-#: ../lib/imagery/iclass_perimeter.c:109
-#, c-format
-msgid "Get area %d failed"
-msgstr ""
+#: ../lib/python/temporal/extract.py:176
+#, fuzzy
+msgid "Error in computation process"
-#: ../lib/imagery/iclass_perimeter.c:116
-msgid "Perimeter computation failed"
-msgstr ""
+#: ../lib/python/temporal/factory.py:51
+msgid "Unknown dataset type: %s"
-#: ../lib/imagery/iclass_perimeter.c:208
-msgid "Absurd polygon."
+#: ../lib/python/temporal/temporal_algebra.py:810
+msgid ""
+"Spatio-temporal topological operators are not supported in granularity "
+"algebra mode"
msgstr ""
-#: ../lib/imagery/iclass_perimeter.c:253
-msgid "Outlined area is too large."
+#: ../lib/python/temporal/temporal_algebra.py:848
+msgid "All input space time datasets must have a valid temporal topology."
msgstr ""
-#: ../lib/imagery/points.c:124
-#, fuzzy, c-format
-msgid "Unable to open control point file for group [%s in %s]"
+#: ../lib/python/temporal/temporal_algebra.py:857
+#, fuzzy
+msgid "All input space time datasets must have the same temporal type."
-#: ../lib/imagery/points.c:132
-#, fuzzy, c-format
-msgid "Bad format in control point file for group [%s in %s]"
+#: ../lib/python/temporal/temporal_algebra.py:1105
+msgid "Removing un-needed or empty %s maps"
-#: ../lib/imagery/points.c:159
-#, fuzzy, c-format
-msgid "Unable to create control point file for group [%s in %s]"
+#: ../lib/python/temporal/temporal_algebra.py:1160
+msgid "Space time %s dataset <%s> not found"
+msgstr "'%s' 디버그파일을 열 수 없습니다"
-#: ../lib/imagery/list_gp.c:34
-#, c-format
-msgid "group <%s> is empty\n"
+#: ../lib/python/temporal/temporal_algebra.py:1188
+#: ../lib/python/temporal/temporal_algebra.py:1192
+#, python-format
+msgid ""
+"Wrong temporal type of space time dataset <"
+"%s> <%s> time is required"
msgstr ""
-#: ../lib/imagery/list_gp.c:44
-#, c-format
-msgid "group <%s> references the following raster maps\n"
-msgstr ""
-#: ../lib/imagery/fopen.c:23
-#, c-format
-msgid "Unable to create file [%s] of group [%s in %s]"
-msgstr ""
-#: ../lib/imagery/fopen.c:36 ../lib/imagery/fopen.c:57
-#, fuzzy, c-format
-msgid "Unable to open file [%s] of group [%s in %s]"
+#: ../lib/python/temporal/temporal_algebra.py:1212
+#, fuzzy
+msgid "Wrong type of input "
-#: ../lib/imagery/fopen.c:49
-#, c-format
-msgid "Unable to find file [%s] of group [%s in %s]"
+#: ../lib/python/temporal/temporal_algebra.py:2104
+#, python-format
+msgid ""
+"The resulting space time dataset type <%(a)s> is different from the "
+"requested type <%(b)s>"
msgstr ""
-#: ../lib/imagery/fopen.c:79
-#, c-format
-msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
+#: ../lib/python/temporal/temporal_algebra.py:2110
+msgid ""
+"Maps that should be registered in the resulting space time dataset have "
+"different types."
msgstr ""
-#: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
-#, c-format
-msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:2313
+#: ../lib/python/temporal/temporal_raster_base_algebra.py:717
+msgid "%s map <%s> not found in GRASS spatial database"
-#: ../lib/imagery/fopen.c:116
-#, c-format
-msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
+#: ../lib/python/temporal/temporal_algebra.py:2319
+msgid ""
+"Wrong map type. TMAP only supports single maps that are registered in the "
+"temporal GRASS database"
msgstr ""
-#: ../lib/imagery/iclass_statistics.c:218
-msgid "prepare_signature: outline has odd number of points."
+#: ../lib/python/temporal/temporal_algebra.py:2347
+msgid "Merging empty map lists"
msgstr ""
-#: ../lib/imagery/iclass_statistics.c:248
-#, c-format
-msgid "Data error preparing signatures: value (%d) > num of cats (%d)"
+#: ../lib/python/temporal/temporal_algebra.py:2350
+msgid "First Map list is empty, can't merge it. Return only last map list"
msgstr ""
-#: ../lib/imagery/iclass_statistics.c:561
-#: ../lib/imagery/iclass_statistics.c:584
-#: ../lib/imagery/iclass_statistics.c:607
-#: ../lib/imagery/iclass_statistics.c:630
-#: ../lib/imagery/iclass_statistics.c:653
-#: ../lib/imagery/iclass_statistics.c:680
-#: ../lib/imagery/iclass_statistics.c:712
-#: ../lib/imagery/iclass_statistics.c:735
-#: ../lib/imagery/iclass_statistics.c:758
-msgid "Band index out of range"
+#: ../lib/python/temporal/temporal_algebra.py:2353
+msgid "Second Map list is empty, can't merge it. Return only first map list"
msgstr ""
-#: ../lib/imagery/iclass_statistics.c:684
-msgid "Cell category value out of range"
-msgstr ""
-#: ../lib/imagery/iclass.c:83
-#, fuzzy, c-format
-msgid "No areas in category %d"
+#: ../lib/python/temporal/temporal_algebra.py:2361
+#, fuzzy
+msgid "Space time datasets to merge must have the same temporal type"
-#: ../lib/imagery/iclass.c:127
-#, fuzzy, c-format
-msgid "Raster map <%s@%s> in subgroup <%s> does not exist"
-msgstr "임시파일을 열 수 없습니다"
-#: ../lib/imagery/iclass.c:131
-#, fuzzy, c-format
-msgid "Raster map <%s@%s> in group <%s> does not exist"
-#: ../lib/imagery/iclass.c:143
-#, c-format
-msgid "Subgroup <%s> does not have enough files (it has %d files)"
+#: ../lib/python/temporal/abstract_dataset.py:386
+#, python-format
+msgid ""
+"Unable to insert dataset <%(ds)s> of type %(type)s in the temporal database. "
+"The mapset of the dataset does not match the current mapset"
msgstr ""
-#: ../lib/imagery/iclass.c:147
-#, c-format
-msgid "Group <%s> does not have enough files (it has %d files)"
-msgstr ""
-#: ../lib/imagery/list_subgp.c:72
-#, c-format
-msgid "subgroup <%s> of group <%s> is empty\n"
-msgstr ""
-#: ../lib/imagery/list_subgp.c:85
-#, c-format
-msgid "subgroup <%s> of group <%s> references the following raster maps\n"
-msgstr ""
-#: ../lib/imagery/sigsetfile.c:41
-#, c-format
+#: ../lib/python/temporal/abstract_dataset.py:426
+#: ../lib/python/temporal/abstract_dataset.py:469
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2285
+#: ../lib/python/temporal/abstract_map_dataset.py:424
+#: ../lib/python/temporal/abstract_map_dataset.py:520
+#, python-format
msgid ""
-"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
-"is not current mapset"
+"Unable to update dataset <%(ds)s> of type %(type)s in the temporal database. "
msgstr ""
-#: ../lib/imagery/sigsetfile.c:57
-#, fuzzy, c-format
-msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
+#: ../lib/python/temporal/stds_export.py:104
+msgid "Unable to export raster map <%s>"
-#: ../lib/imagery/iclass_signatures.c:120
-#, fuzzy, c-format
-msgid "Unable to open output signature file '%s'"
+#: ../lib/python/temporal/stds_export.py:115
+msgid "Unable to export color rules for raster map <%s> r.out.gdal"
-#: ../lib/psdriver/graph_set.c:199
-#, c-format
-msgid "ps: truecolor status %s"
-msgstr ""
-#: ../lib/psdriver/graph_set.c:200 ../lib/pngdriver/graph_set.c:102
-msgid "enabled"
-msgstr ""
-msgid "disabled"
-msgstr ""
-#: ../lib/psdriver/graph_set.c:214
-#, c-format
-msgid "ps: collecting to file '%s'"
-msgstr ""
-#: ../lib/psdriver/graph_set.c:215
-#, c-format
-msgid "ps: image size %dx%d"
-msgstr ""
-#: ../lib/cairodriver/text.c:46
-#, fuzzy, c-format
-msgid "Unable to convert from <%s> to UTF-8"
+#: ../lib/python/temporal/stds_export.py:139
+msgid "Unable to export raster map <%s> with r.pack"
-#: ../lib/cairodriver/text.c:56
-msgid "Some characters could not be converted to UTF-8"
-msgstr ""
-#: ../lib/cairodriver/write_ppm.c:27 ../lib/cairodriver/write_bmp.c:72
-#, fuzzy, c-format
-msgid "Cairo: unable to open output file <%s>"
+#: ../lib/python/temporal/stds_export.py:167
+msgid "Unable to export vector map <%s> as GML with v.out.ogr"
-#: ../lib/cairodriver/write_ppm.c:34
-#, fuzzy, c-format
-msgid "Cairo: unable to open mask file <%s>"
+#: ../lib/python/temporal/stds_export.py:200
+msgid "Unable to export vector map <%s> with v.pack"
-#: ../lib/cairodriver/read_ppm.c:28 ../lib/cairodriver/read_bmp.c:88
-#, fuzzy, c-format
-msgid "Cairo: unable to open input file <%s>"
+#: ../lib/python/temporal/stds_export.py:226
+msgid "Unable to export raster map <%s> with r3.pack"
-#: ../lib/cairodriver/read_ppm.c:32 ../lib/cairodriver/read_bmp.c:92
-#, c-format
-msgid "Cairo: invalid input file <%s>"
-msgstr ""
-#: ../lib/cairodriver/read_ppm.c:38
-#, c-format
-msgid "Cairo: input file has incorrect dimensions: expected: %dx%d got: %dx%d"
-msgstr ""
-#: ../lib/cairodriver/read_ppm.c:46
-#, fuzzy, c-format
-msgid "Cairo: unable to open input mask file <%s>"
+#: ../lib/python/temporal/base.py:380
+#, fuzzy
+msgid "Object not found in the temporal database"
-#: ../lib/cairodriver/read_ppm.c:50
-#, c-format
-msgid "Cairo: invalid input mask file <%s>"
+#: ../lib/python/temporal/base.py:462 ../lib/python/temporal/base.py:513
+msgid "Missing identifier"
msgstr ""
-#: ../lib/cairodriver/read_ppm.c:56
-#, c-format
-msgid ""
-"Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
-msgstr ""
+#: ../lib/python/temporal/base.py:621
+#, fuzzy
+msgid "Wrong identifier, the mapset is missing"
-#: ../lib/cairodriver/read_xid.c:14
-#, fuzzy, c-format
-msgid "Unable to open input file <%s>"
-#: ../lib/cairodriver/read_xid.c:17
-#, fuzzy, c-format
-msgid "Unable to read input file <%s>"
-#: ../lib/cairodriver/read_xid.c:20
-#, fuzzy, c-format
-msgid "Unable to parse input file <%s>"
-#: ../lib/cairodriver/raster.c:109
+#: ../lib/python/temporal/c_libraries_interface.py:596
+#: ../lib/python/temporal/c_libraries_interface.py:613
#, fuzzy
-msgid "Failed to create cairo surface"
+msgid "Unable to read range file"
-#: ../lib/cairodriver/write_xid.c:14 ../lib/pngdriver/read_png.c:71
-#, fuzzy, c-format
-msgid "Unable to open output file <%s>"
+#: ../lib/python/temporal/c_libraries_interface.py:676
+#: ../lib/gpde/n_arrays_io.c:281 ../lib/ogsf/gvl_file.c:436
+#, fuzzy, c-format, python-format
+msgid "Unable to open 3D raster map <%s>"
-#: ../lib/cairodriver/write_xid.c:19
-#, fuzzy, c-format
-msgid "Unable to write output file <%s>"
+#: ../lib/python/temporal/c_libraries_interface.py:691
+msgid "Unable to load range of 3D raster map <%s>"
-#: ../lib/cairodriver/read_bmp.c:96
-#, c-format
-msgid "Cairo: Invalid BMP header for <%s>"
-msgstr ""
-#: ../lib/cairodriver/graph.c:67
-#, fuzzy
-msgid "Unable to open display"
+#: ../lib/python/temporal/c_libraries_interface.py:706
+#: ../lib/raster3d/close.c:120 ../lib/raster3d/close.c:130
+#: ../lib/raster3d/close.c:159 ../lib/ogsf/gvl_file.c:470
+msgid "Unable to close 3D raster map <%s>"
-#: ../lib/cairodriver/graph.c:85
-#, fuzzy
-msgid "Unable to obtain visual"
+#: ../lib/python/temporal/c_libraries_interface.py:747
+#: ../lib/vector/Vlib/map.c:192 ../lib/vector/Vlib/map.c:202
+#: ../lib/vector/Vlib/map.c:274 ../lib/vector/Vlib/open.c:301
+#: ../lib/vector/Vlib/open.c:437 ../lib/ogsf/gp3.c:62 ../lib/ogsf/gp3.c:196
+#: ../lib/ogsf/gv3.c:66 ../lib/ogsf/gv3.c:338
+msgid "Unable to open vector map <%s>"
-#: ../lib/cairodriver/graph.c:160
-#, c-format
-msgid "Unknown file extension: %s"
-msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:167
+#: ../lib/python/temporal/abstract_space_time_dataset.py:301
+msgid "Unknown temporal type \"%s\""
-#: ../lib/cairodriver/graph.c:190
-#, fuzzy, c-format
-msgid "cairo: collecting to file '%s'"
-#: ../lib/cairodriver/graph.c:192
-#, c-format
-msgid "cairo: image size %dx%d"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:294
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1062
+#, python-format
+msgid "Wrong granularity: \"%s\""
msgstr ""
-#: ../lib/cairodriver/graph.c:371
-#, fuzzy
-msgid "Unknown Cairo surface type"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:322
+msgid "Unsupported temporal unit: %s"
-#: ../lib/cairodriver/graph.c:376
-#, fuzzy
-msgid "Failed to initialize Cairo surface"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:372
+msgid "Created register table <%s> for space time %s dataset <%s>"
-#: ../lib/cairodriver/draw_bitmap.c:47
-msgid "Cairo_Bitmap: Failed to create source"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:690
+#: ../lib/python/temporal/abstract_space_time_dataset.py:932
+msgid "The space time datasets must be of the same temporal type"
msgstr ""
-#: ../lib/python/gunittest/gmodules.py:103
-msgid "input='-' must be used when stdin is specified"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:695
+#: ../lib/python/temporal/abstract_space_time_dataset.py:937
+msgid "The temporal map type of the sample dataset must be interval"
msgstr ""
-#: ../lib/python/gunittest/gmodules.py:105
-msgid "stdin must be string or buffer, not PIPE"
-msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1499
+msgid "Unable to get map ids from register table <%s>"
-#: ../lib/python/gunittest/gmodules.py:108
-msgid "stdin must be used when input='-'"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1609
+#, python-format
+msgid ""
+"Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database. "
msgstr ""
-#: ../lib/python/gunittest/gmodules.py:110
-msgid "You cannot merge stdout and stderr and not capture them"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1778
+#, python-format
+msgid ""
+"Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database. "
msgstr ""
-#: ../lib/python/gunittest/gmodules.py:112
-msgid "stdout argument not allowed, it could be overridden"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1880
+#, python-format
+msgid ""
+"Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database. "
msgstr ""
-#: ../lib/python/gunittest/gmodules.py:114
-msgid "stderr argument not allowed, it could be overridden"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1889
+msgid "Renaming of space time datasets is not supported for PostgreSQL."
msgstr ""
-#: ../lib/python/pygrass/utils.py:277
-msgid "Vector doesn't contain points"
-msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1954
+msgid "Delete space time %s dataset <%s> from temporal database"
-#: ../lib/python/pygrass/raster/category.py:69
-#, fuzzy, python-brace-format
-msgid "Raster type: {0} not supported"
-msgstr "라스터 타입: {0}를 지원하지 않습니다"
-#: ../lib/python/pygrass/raster/category.py:156
-msgid "Error executing: Rast_get_ith_cat"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1960
+#: ../lib/python/temporal/abstract_map_dataset.py:841
+#, python-format
+msgid ""
+"Unable to delete dataset <%(ds)s> of type %(type)s from the temporal "
+"database. The mapset of the dataset does not match the current mapset"
msgstr ""
-#: ../lib/python/pygrass/raster/category.py:184
-msgid "Null value detected"
-msgstr "널값을 찾았습니다"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1973
+msgid "Drop map register table: %s"
-#: ../lib/python/pygrass/raster/category.py:186
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2028
#, fuzzy
-msgid "Error executing: Rast_set_cat"
+msgid "Error in register table request"
-#: ../lib/python/pygrass/raster/abstract.py:275
-#, python-brace-format
-msgid "Mode type: {0} not supported ('r', 'w')"
-msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2057
+msgid ""
+"Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of "
+"the dataset does not match the current mapset"
-#: ../lib/python/pygrass/raster/abstract.py:286
-msgid "Overwrite type: {0} not supported (True/False)"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2066
+msgid ""
+"Only a map that was inserted in the temporal database can be registered in a "
+"space time dataset"
msgstr ""
-#: ../lib/python/pygrass/raster/abstract.py:299
-#: ../lib/python/pygrass/vector/abstract.py:97
-msgid "Map name {0} not valid"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2089
+#, python-format
+msgid "Map <%(id)s> with layer %(l)s has invalid time"
msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:209
-msgid "The map does not exist, I can't open in 'r' mode"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2093
+#, python-format
+msgid "Map <%s> has invalid time"
msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:214
-msgid "Raster map <{0}> already exists and will be not overwritten"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2111
+msgid ""
+"Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer "
+"%(l)s are different"
-#: ../lib/python/pygrass/raster/__init__.py:218
-#, fuzzy
-msgid "Raster type not defined"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2117
+msgid ""
+"Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
-#: ../lib/python/pygrass/raster/__init__.py:321
-msgid "Mode type: {0} not supported ('r', 'w','rw')"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2132
+msgid "Set temporal unit for space time %s dataset <%s> to %s"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2142
+#, python-format
+msgid ""
+"Relative time units of space time dataset <%(id)s> and map <%(map)s> with "
+"layer %(l)s are different"
msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:341
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2148
#, python-format
-msgid "Index out of range: %r."
+msgid ""
+"Relative time units of space time dataset <%(id)s> and map <%(map)s> are "
+"different"
msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:530
-msgid "Raster map <{0}> already exists. Use overwrite."
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2154
+msgid "Only maps from the same mapset can be registered"
+msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:561
-msgid "Raster map <{0}> does not exist"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2159
+msgid "Map <%(map)s> with layer %(l)s is already registered."
-#: ../lib/python/pygrass/vector/table.py:1035
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2163
#, python-format
-msgid "Deleting table <%s> which is attached to following map(s):"
+msgid "Map <%s> is already registered."
msgstr ""
-#: ../lib/python/pygrass/vector/table.py:1039
-msgid "You must use the force flag to actually remove it. Exiting."
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2211
+#, python-format
+msgid ""
+"Unable to unregister map from dataset <%(ds)s> of type %(type)s in the "
+"temporal database. The mapset of the dataset does not match the current "
+"mapset"
msgstr ""
-#: ../lib/python/pygrass/vector/__init__.py:806
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2224
-msgid "Unable to read line of feature %i"
+msgid ""
+"Map <%(map)s> with layer %(l)s is not registered in space time dataset <"
+"%(base)s>"
-#: ../lib/python/pygrass/vector/__init__.py:895
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2230
-msgid "Unable to read area with id %i"
+msgid "Map <%(map)s> is not registered in space time dataset <%(base)s>"
-#: ../lib/python/pygrass/modules/grid/grid.py:553
-msgid "Execution of subprocesses was not successful"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2291
+#, python-format
+msgid ""
+"Update metadata, spatial and temporal extent from all registered maps of <%s>"
msgstr ""
-#: ../lib/python/pygrass/errors.py:17
-msgid "The map is close!"
-msgstr ""
+#: ../lib/python/temporal/univar_statistics.py:62
+#: ../lib/python/temporal/univar_statistics.py:178
+msgid "Space time %(sp)s dataset <%(i)s> is empty"
-#: ../lib/python/pygrass/errors.py:28
-msgid "The self.c_mapinfo pointer must be correctly initiated"
-msgstr ""
+#: ../lib/python/temporal/univar_statistics.py:101
+msgid "Unable to get statistics for raster map <%s>"
-#: ../lib/python/temporal/temporal_raster_base_algebra.py:630
+#: ../lib/python/temporal/univar_statistics.py:104
-msgid "Error computing map <%s>"
+msgid "Unable to get statistics for 3d raster map <%s>"
-#: ../lib/python/temporal/temporal_raster_base_algebra.py:717
-#: ../lib/python/temporal/temporal_algebra.py:2313
+#: ../lib/python/temporal/univar_statistics.py:168
-msgid "%s map <%s> not found in GRASS spatial database"
+msgid "Space time %(sp)s dataset <%(i)s> not found"
+#: ../lib/python/temporal/univar_statistics.py:222
+msgid "Unable to get statistics for vector map <%s>"
-#: ../lib/python/temporal/datetime_math.py:256
-#: ../lib/python/temporal/datetime_math.py:273
-#, python-format
-msgid "Wrong increment format: %s"
+#: ../lib/python/temporal/spatial_extent.py:123
+msgid ""
+"Projections are different. Unable to compute overlapping_2d for spatial "
+"extents"
msgstr ""
-#: ../lib/python/temporal/datetime_math.py:451
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1616
-#, python-format
-msgid "Wrong granularity format: %s"
+#: ../lib/python/temporal/spatial_extent.py:529
+msgid ""
+"Projections are different. Unable to compute is_in_2d for spatial extents"
msgstr ""
-#: ../lib/python/temporal/datetime_math.py:729
-msgid "Time string seems to specify relative time"
+#: ../lib/python/temporal/spatial_extent.py:661
+msgid ""
+"Projections are different. Unable to compute equivalent_2d for spatial "
+"extents"
msgstr ""
-#: ../lib/python/temporal/datetime_math.py:741
-#, fuzzy
-msgid "Dates Before Christ (BC) are not supported"
+#: ../lib/python/temporal/spatial_extent.py:766
+msgid ""
+"Projections are different. Unable to compute cover_2d for spatial extents"
+msgstr ""
-#: ../lib/python/temporal/datetime_math.py:745
-#, fuzzy
-msgid "Time zones are not supported"
+#: ../lib/python/temporal/spatial_extent.py:838
+msgid "Projections are different. Unable to compute cover for spatial extents"
+msgstr ""
-#: ../lib/python/temporal/datetime_math.py:755
-#, fuzzy, python-format
-msgid "Unable to parse time string: %s"
+#: ../lib/python/temporal/spatial_extent.py:1690
+msgid "Volume computation is not supported for LL projections"
+msgstr ""
+#: ../lib/python/temporal/spatial_extent.py:1708
+msgid "Area computation is not supported for LL projections"
+msgstr ""
#: ../lib/python/temporal/stds_import.py:85
msgid "Unable to import/link raster map <%s> from file %s."
@@ -1254,238 +1067,179 @@
msgid "Switching to original location failed"
msgstr ""
-#: ../lib/python/temporal/temporal_vector_algebra.py:386
-#, python-format
-msgid ""
-"Error vector maps with basename %s exist. Use --o flag to overwrite existing "
-"file"
-msgstr ""
-#: ../lib/python/temporal/temporal_vector_algebra.py:419
+#: ../lib/python/temporal/aggregation.py:127
-msgid ""
-"Error starting %s : \n"
-"%s"
+msgid "Aggregating %s raster maps"
-#: ../lib/python/temporal/temporal_vector_algebra.py:492
+#: ../lib/python/temporal/aggregation.py:141
msgid ""
-"Error vector map %s exist in temporal database. Use overwrite flag. : \n"
-"%s"
+"Raster map <%(name)s> is already in temporal database, use overwrite flag to "
+"overwrite"
-#: ../lib/python/temporal/core.py:604
-msgid ""
-"Unable to initialize the temporal DBMI interface. Please use t.connect to "
-"specify the driver and the database string"
+#: ../lib/python/temporal/aggregation.py:146
+#, python-format
+msgid "Computing aggregation of maps between %(st)s - %(end)s"
msgstr ""
-#: ../lib/python/temporal/core.py:667
-msgid ""
-"Unable to receive temporal database metadata.\n"
-"Current temporal database info:%(info)s"
+#: ../lib/python/temporal/aggregation.py:171
+#, fuzzy
+msgid "Error occurred in r.series computation"
-#: ../lib/python/temporal/core.py:672
+#: ../lib/python/temporal/aggregation.py:280
-msgid ""
-"Unsupported temporal database: version mismatch.\n"
-" %(backup)s Supported temporal API version is: %(api)i.\n"
-"Please update your GRASS GIS installation.\n"
+msgid "Aggregating %(len)i raster maps from %(start)s to %(end)s"
-#: ../lib/python/temporal/core.py:680
+#: ../lib/python/temporal/aggregation.py:301
+#, python-format
msgid ""
-" %(backup)sSupported temporal database version is: %(tdb)i\n"
+"Unable to perform aggregation. Output raster map <%(name)s> exists and "
+"overwrite flag was not set"
+msgstr ""
-#: ../lib/python/temporal/core.py:768
-msgid "Creating temporal database: %s"
-#: ../lib/python/temporal/core.py:777
+#: ../lib/python/temporal/aggregation.py:319
#, python-format
msgid ""
-"Unable to create SQLite temporal database\n"
-"Exception: %s\n"
-"Please use t.connect to set a read- and writable temporal database path"
+"The limit of open files (%i) was reached (%i). The module r.series will be "
+"run with flag z, to avoid open files limit exceeding."
msgstr ""
-#: ../lib/python/temporal/core.py:942
-#, fuzzy
-msgid "Unable to mogrify sql statement. "
-msgstr "%s 요소를 지울 수 없습니다"
+#: ../lib/python/temporal/open_stds.py:63
+#: ../lib/python/temporal/open_stds.py:119
+msgid "Unknown type: %s"
-#: ../lib/python/temporal/core.py:964
-#, fuzzy
-msgid "Unable to check table. "
+#: ../lib/python/temporal/open_stds.py:69
+msgid "Space time %(sp)s dataset <%(name)s> not found"
-#: ../lib/python/temporal/core.py:980
+#: ../lib/python/temporal/open_stds.py:108
#, fuzzy
-msgid "Unable to execute sql statement. "
+msgid "Space time datasets can only be created in the current mapset"
-#: ../lib/python/temporal/core.py:990
-#, fuzzy
-msgid "Unable to fetch one. "
+#: ../lib/python/temporal/open_stds.py:125
+msgid ""
+"Space time %(sp)s dataset <%(name)s> is already in the database. Use the "
+"overwrite flag."
-#: ../lib/python/temporal/core.py:1000
-#, fuzzy
-msgid "Unable to fetch all. "
+#: ../lib/python/temporal/open_stds.py:160
+msgid ""
+"Overwriting space time %(sp)s dataset <%(name)s> and unregistering all maps"
-#: ../lib/python/temporal/core.py:1017
-#, fuzzy
-msgid "Unable to execute transaction. "
+#: ../lib/python/temporal/open_stds.py:168
+msgid "Creating a new space time %s dataset"
-#: ../lib/python/temporal/core.py:1120
+#: ../lib/python/temporal/gui_support.py:58 ../lib/python/script/core.py:1233
#, python-format
-msgid ""
-"Unable to connect to %(db)s database: %(string)s\n"
-"Exception: \"%(ex)s\"\n"
-"Please use t.connect to set a read- and writable temporal database backend"
+msgid "Invalid element '%s'"
msgstr ""
-#: ../lib/python/temporal/core.py:1277
+#: ../lib/python/temporal/abstract_map_dataset.py:350
msgid ""
-"Unable to execute :\n"
-" %(sql)s"
+"Start time must be of type datetime for %(type)s map <%(id)s> with layer: "
+"%(l)s"
-#: ../lib/python/temporal/core.py:1321
+#: ../lib/python/temporal/abstract_map_dataset.py:357
+msgid "Start time must be of type datetime for %(type)s map <%(id)s>"
+#: ../lib/python/temporal/abstract_map_dataset.py:365
msgid ""
-"Unable to execute transaction:\n"
-" %(sql)s"
+"End time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
-#: ../lib/python/temporal/univar_statistics.py:62
-#: ../lib/python/temporal/univar_statistics.py:178
+#: ../lib/python/temporal/abstract_map_dataset.py:372
-msgid "Space time %(sp)s dataset <%(i)s> is empty"
+msgid "End time must be of type datetime for %(type)s map <%(id)s>"
-#: ../lib/python/temporal/univar_statistics.py:101
+#: ../lib/python/temporal/abstract_map_dataset.py:381
-msgid "Unable to get statistics for raster map <%s>"
+msgid ""
+"End time must be greater than start time for %(type)s map <%(id)s> with "
+"layer: %(l)s"
+msgstr "동쪽경계는 서쪽경계보다 값이 커야합니다"
-#: ../lib/python/temporal/univar_statistics.py:104
+#: ../lib/python/temporal/abstract_map_dataset.py:389
+#: ../lib/python/temporal/abstract_map_dataset.py:482
-msgid "Unable to get statistics for 3d raster map <%s>"
+msgid "End time must be greater than start time for %(type)s map <%(id)s>"
-#: ../lib/python/temporal/univar_statistics.py:168
+#: ../lib/python/temporal/abstract_map_dataset.py:460
-msgid "Space time %(sp)s dataset <%(i)s> not found"
+msgid ""
+"Unsupported relative time unit type for %(type)s map <%(id)s> with layer "
+"%(l)s: %(u)s"
-#: ../lib/python/temporal/univar_statistics.py:222
+#: ../lib/python/temporal/abstract_map_dataset.py:467
-msgid "Unable to get statistics for vector map <%s>"
+msgid "Unsupported relative time unit type for %(type)s map <%(id)s>: %(u)s"
-#: ../lib/python/temporal/abstract_dataset.py:386
-#, python-format
+#: ../lib/python/temporal/abstract_map_dataset.py:476
msgid ""
-"Unable to insert dataset <%(ds)s> of type %(type)s in the temporal database. "
-"The mapset of the dataset does not match the current mapset"
-msgstr ""
+"End time must be greater than start time for %(typ)s map <%(id)s> with layer "
+"%(l)s"
-#: ../lib/python/temporal/abstract_dataset.py:426
-#: ../lib/python/temporal/abstract_dataset.py:469
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2285
-#: ../lib/python/temporal/abstract_map_dataset.py:424
-#: ../lib/python/temporal/abstract_map_dataset.py:520
+#: ../lib/python/temporal/abstract_map_dataset.py:800
#, python-format
msgid ""
-"Unable to update dataset <%(ds)s> of type %(type)s in the temporal database. "
+"Map <%(id)s> with layer %(layer)s has incorrect time interval, start time is "
+"greater than end time"
msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:810
+#: ../lib/python/temporal/abstract_map_dataset.py:806
+#, python-format
msgid ""
-"Spatio-temporal topological operators are not supported in granularity "
-"algebra mode"
+"Map <%s> has incorrect time interval, start time is greater than end time"
msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:848
-msgid "All input space time datasets must have a valid temporal topology."
+#: ../lib/python/temporal/abstract_map_dataset.py:812
+#, python-format
+msgid "Map <%s> has incorrect start time"
msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:857
-#, fuzzy
-msgid "All input space time datasets must have the same temporal type."
-#: ../lib/python/temporal/temporal_algebra.py:1105
+#: ../lib/python/temporal/abstract_map_dataset.py:859
-msgid "Removing un-needed or empty %s maps"
+msgid "Delete %s dataset <%s> from temporal database"
-#: ../lib/python/temporal/temporal_algebra.py:1160
-msgid "Space time %s dataset <%s> not found"
-#: ../lib/python/temporal/temporal_algebra.py:1188
-#: ../lib/python/temporal/temporal_algebra.py:1192
+#: ../lib/python/temporal/abstract_map_dataset.py:909
#, python-format
msgid ""
-"Wrong temporal type of space time dataset <"
-"%s> <%s> time is required"
+"Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal "
msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:1212
-#, fuzzy
-msgid "Wrong type of input "
+#: ../lib/python/temporal/sampling.py:95 ../lib/python/temporal/sampling.py:100
+msgid "Dataset <%s> not found in temporal database"
-#: ../lib/python/temporal/temporal_algebra.py:2104
-#, python-format
-msgid ""
-"The resulting space time dataset type <%(a)s> is different from the "
-"requested type <%(b)s>"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:2110
-msgid ""
-"Maps that should be registered in the resulting space time dataset have "
-"different types."
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:2319
-msgid ""
-"Wrong map type. TMAP only supports single maps that are registered in the "
-"temporal GRASS database"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:2347
-msgid "Merging empty map lists"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:2350
-msgid "First Map list is empty, can't merge it. Return only last map list"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:2353
-msgid "Second Map list is empty, can't merge it. Return only first map list"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:2361
-#, fuzzy
-msgid "Space time datasets to merge must have the same temporal type"
+#: ../lib/python/temporal/temporal_raster_base_algebra.py:630
+msgid "Error computing map <%s>"
#: ../lib/python/temporal/register.py:82 ../lib/python/temporal/register.py:85
@@ -1640,69 +1394,6 @@
msgid "Set relative valid time for map <%s> to %i - %s with unit %s"
-#: ../lib/python/temporal/mapcalc.py:109
-msgid "Starting spatio-temporal sampling..."
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:111
-msgid "Starting temporal sampling..."
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:128
-msgid "No samples found for map calculation"
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:155
-msgid ""
-"Found more than a single map in a sample granule. Only the first map is used "
-"for computation. Use t.rast.aggregate.ds to create synchronous raster "
-"datasets."
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:173
-#, fuzzy
-msgid "No maps registered in input dataset"
-#: ../lib/python/temporal/mapcalc.py:189
-msgid "Starting mapcalc computation..."
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:240
-#: ../lib/python/temporal/open_stds.py:211
-#: ../lib/python/temporal/extract.py:131
-msgid ""
-"Map <%s> is already in temporal database, use overwrite flag to overwrite"
-#: ../lib/python/temporal/mapcalc.py:260
-#, python-format
-msgid "Apply mapcalc expression: \"%s\""
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:279
-msgid "Error while mapcalc computation"
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:285
-#, fuzzy
-msgid "Starting map registration in temporal database..."
-#: ../lib/python/temporal/mapcalc.py:442 ../lib/python/temporal/mapcalc.py:448
-#: ../lib/python/temporal/mapcalc.py:454 ../lib/python/temporal/mapcalc.py:460
-#: ../lib/python/temporal/mapcalc.py:466 ../lib/python/temporal/mapcalc.py:472
-#: ../lib/python/temporal/mapcalc.py:478 ../lib/python/temporal/mapcalc.py:484
-#: ../lib/python/temporal/mapcalc.py:490 ../lib/python/temporal/mapcalc.py:525
-#: ../lib/python/temporal/mapcalc.py:534 ../lib/python/temporal/mapcalc.py:543
-#: ../lib/python/temporal/mapcalc.py:552 ../lib/python/temporal/mapcalc.py:561
-#: ../lib/python/temporal/mapcalc.py:570 ../lib/python/temporal/mapcalc.py:579
-#: ../lib/python/temporal/mapcalc.py:588 ../lib/python/temporal/mapcalc.py:597
-#, python-format
-msgid "The temporal operators <%s> support only absolute time."
-msgstr ""
#: ../lib/python/temporal/list_stds.py:208
msgid "Empty map list"
msgstr ""
@@ -1711,56 +1402,6 @@
msgid "Empty entry in map list, this should not happen"
msgstr ""
-#: ../lib/python/temporal/factory.py:51
-msgid "Unknown dataset type: %s"
-msgstr "알려지지 않은 벡터타입입니다"
-#: ../lib/python/temporal/sampling.py:95
-#: ../lib/python/temporal/sampling.py:100
-msgid "Dataset <%s> not found in temporal database"
-#: ../lib/python/temporal/gui_support.py:58 ../lib/python/script/core.py:1233
-#, python-format
-msgid "Invalid element '%s'"
-msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:123
-msgid ""
-"Projections are different. Unable to compute overlapping_2d for spatial "
-"extents"
-msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:529
-msgid ""
-"Projections are different. Unable to compute is_in_2d for spatial extents"
-msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:661
-msgid ""
-"Projections are different. Unable to compute equivalent_2d for spatial "
-"extents"
-msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:766
-msgid ""
-"Projections are different. Unable to compute cover_2d for spatial extents"
-msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:838
-msgid "Projections are different. Unable to compute cover for spatial extents"
-msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:1690
-msgid "Volume computation is not supported for LL projections"
-msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:1708
-msgid "Area computation is not supported for LL projections"
-msgstr ""
#: ../lib/python/temporal/space_time_datasets.py:250
msgid "Unable to read timestamp file for raster map <%s>"
@@ -1822,810 +1463,871 @@
msgid "Unable to remove timestamp for vector map <%s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:167
-#: ../lib/python/temporal/abstract_space_time_dataset.py:301
-msgid "Unknown temporal type \"%s\""
+#: ../lib/python/temporal/mapcalc.py:109
+msgid "Starting spatio-temporal sampling..."
+msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:294
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1062
-#, python-format
-msgid "Wrong granularity: \"%s\""
+#: ../lib/python/temporal/mapcalc.py:111
+msgid "Starting temporal sampling..."
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:322
-msgid "Unsupported temporal unit: %s"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:372
-msgid "Created register table <%s> for space time %s dataset <%s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:690
-#: ../lib/python/temporal/abstract_space_time_dataset.py:932
-msgid "The space time datasets must be of the same temporal type"
+#: ../lib/python/temporal/mapcalc.py:128
+msgid "No samples found for map calculation"
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:695
-#: ../lib/python/temporal/abstract_space_time_dataset.py:937
-msgid "The temporal map type of the sample dataset must be interval"
+#: ../lib/python/temporal/mapcalc.py:155
+msgid ""
+"Found more than a single map in a sample granule. Only the first map is used "
+"for computation. Use t.rast.aggregate.ds to create synchronous raster "
+"datasets."
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1499
-msgid "Unable to get map ids from register table <%s>"
+#: ../lib/python/temporal/mapcalc.py:173
+#, fuzzy
+msgid "No maps registered in input dataset"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1609
-#, python-format
-msgid ""
-"Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database. "
+#: ../lib/python/temporal/mapcalc.py:189
+msgid "Starting mapcalc computation..."
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1778
+#: ../lib/python/temporal/mapcalc.py:260
#, python-format
-msgid ""
-"Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database. "
+msgid "Apply mapcalc expression: \"%s\""
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1880
-#, python-format
-msgid ""
-"Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database. "
+#: ../lib/python/temporal/mapcalc.py:279
+msgid "Error while mapcalc computation"
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1889
-msgid "Renaming of space time datasets is not supported for PostgreSQL."
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1954
-msgid "Delete space time %s dataset <%s> from temporal database"
+#: ../lib/python/temporal/mapcalc.py:285
+#, fuzzy
+msgid "Starting map registration in temporal database..."
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1960
-#: ../lib/python/temporal/abstract_map_dataset.py:841
+#: ../lib/python/temporal/mapcalc.py:442 ../lib/python/temporal/mapcalc.py:448
+#: ../lib/python/temporal/mapcalc.py:454 ../lib/python/temporal/mapcalc.py:460
+#: ../lib/python/temporal/mapcalc.py:466 ../lib/python/temporal/mapcalc.py:472
+#: ../lib/python/temporal/mapcalc.py:478 ../lib/python/temporal/mapcalc.py:484
+#: ../lib/python/temporal/mapcalc.py:490 ../lib/python/temporal/mapcalc.py:525
+#: ../lib/python/temporal/mapcalc.py:534 ../lib/python/temporal/mapcalc.py:543
+#: ../lib/python/temporal/mapcalc.py:552 ../lib/python/temporal/mapcalc.py:561
+#: ../lib/python/temporal/mapcalc.py:570 ../lib/python/temporal/mapcalc.py:579
+#: ../lib/python/temporal/mapcalc.py:588 ../lib/python/temporal/mapcalc.py:597
#, python-format
-msgid ""
-"Unable to delete dataset <%(ds)s> of type %(type)s from the temporal "
-"database. The mapset of the dataset does not match the current mapset"
+msgid "The temporal operators <%s> support only absolute time."
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1973
+#: ../lib/python/script/raster.py:54
-msgid "Drop map register table: %s"
+msgid ""
+"Unable to write history for <%(map)s>. Raster map <%(map)s> not found in "
+"current mapset."
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2028
+#: ../lib/python/script/raster.py:113
+#, python-format
+msgid "An error occurred while running r.mapcalc with expression: %s"
+msgstr ""
+#: ../lib/python/script/raster.py:192
#, fuzzy
-msgid "Error in register table request"
+msgid "No data"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2057
-msgid ""
-"Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of "
-"the dataset does not match the current mapset"
-msgstr "'%s' 디버그파일을 열 수 없습니다"
+#: ../lib/python/script/raster.py:200
+msgid "value"
+msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2066
-msgid ""
-"Only a map that was inserted in the temporal database can be registered in a "
-"space time dataset"
+msgid "label"
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2089
-#, python-format
-msgid "Map <%(id)s> with layer %(l)s has invalid time"
+msgid "color"
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2093
+#: ../lib/python/script/vector.py:88
#, python-format
-msgid "Map <%s> has invalid time"
+msgid "Database connection not defined for layer %s"
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2111
+#: ../lib/python/script/vector.py:228
-msgid ""
-"Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer "
-"%(l)s are different"
+msgid "Missing layer %(layer)d in vector map <%(map)s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2117
-msgid ""
-"Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
+#: ../lib/python/script/vector.py:243
+msgid "vector_db_select() failed"
+msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2132
-msgid "Set temporal unit for space time %s dataset <%s> to %s"
+#: ../lib/python/script/vector.py:350
+msgid "Number of given vector maps ({m}) differs from number of layers ({l})"
+msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2142
-#, python-format
+#: ../lib/python/script/vector.py:407
msgid ""
-"Relative time units of space time dataset <%(id)s> and map <%(map)s> with "
-"layer %(l)s are different"
+"v.what output is not valid JSON format:\n"
+" {ret}"
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2148
+#: ../lib/python/script/core.py:67
+msgid "Cannot find the executable {}"
+msgstr ""
+#: ../lib/python/script/core.py:304
#, python-format
msgid ""
-"Relative time units of space time dataset <%(id)s> and map <%(map)s> are "
-"different"
+"To run the module <%s> add underscore at the end of the option <%s> to avoid "
+"conflict with Python keywords. Underscore at the beginning is depreciated in "
+"GRASS GIS 7.0 and will be removed in version 7.1."
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2154
-msgid "Only maps from the same mapset can be registered"
+#: ../lib/python/script/core.py:928
+msgid "Mixing value types. Will try to compare after integer conversion"
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2159
-msgid "Map <%(map)s> with layer %(l)s is already registered."
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2163
+#: ../lib/python/script/core.py:1123
#, python-format
-msgid "Map <%s> is already registered."
+msgid "Element type should be \"cell\" and not \"%s\""
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2211
+#: ../lib/python/script/core.py:1152 ../lib/python/script/core.py:1217
#, python-format
-msgid ""
-"Unable to unregister map from dataset <%(ds)s> of type %(type)s in the "
-"temporal database. The mapset of the dataset does not match the current "
-"mapset"
+msgid "Element type should be \"raster\" and not \"%s\""
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2224
-msgid ""
-"Map <%(map)s> with layer %(l)s is not registered in space time dataset <"
-"%(base)s>"
+#: ../lib/python/script/core.py:1372
+#, fuzzy
+msgid "Unable to list mapsets"
+msgstr "Datum %s 테이블파일을 열 수 없습니다"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2230
-msgid "Map <%(map)s> is not registered in space time dataset <%(base)s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2291
+#: ../lib/python/script/core.py:1411
#, python-format
-msgid ""
-"Update metadata, spatial and temporal extent from all registered maps of <%s>"
+msgid "Location <%s> already exists. Operation canceled."
msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:350
+#: ../lib/python/script/core.py:1414
-msgid ""
-"Start time must be of type datetime for %(type)s map <%(id)s> with layer: "
-"%(l)s"
+msgid "Location <%s> already exists and will be overwritten"
-#: ../lib/python/temporal/abstract_map_dataset.py:357
-msgid "Start time must be of type datetime for %(type)s map <%(id)s>"
+#: ../lib/python/script/core.py:1538
+msgid "Debug level {}"
+msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:365
-msgid ""
-"End time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
+#: ../lib/python/script/core.py:1541
+msgid "WARNING: Ignoring unsupported debug level (must be >=0 and <=5). {}\n"
+msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:372
-msgid "End time must be of type datetime for %(type)s map <%(id)s>"
+#: ../lib/python/script/core.py:1557
+#, python-format
+msgid "Illegal filename <%s>. Cannot be 'NULL' or start with '.'."
+msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:381
-msgid ""
-"End time must be greater than start time for %(type)s map <%(id)s> with "
-"layer: %(l)s"
-msgstr "동쪽경계는 서쪽경계보다 값이 커야합니다"
+#: ../lib/python/script/core.py:1566
+#, python-format
+msgid "Illegal filename <%(s)s>. <%(il)s> not allowed.\n"
+msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:389
-#: ../lib/python/temporal/abstract_map_dataset.py:482
-msgid "End time must be greater than start time for %(type)s map <%(id)s>"
+#: ../lib/python/script/raster3d.py:92
+#, python-format
+msgid "An error occurred while running r3.mapcalc with expression: %s"
+msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:460
-msgid ""
-"Unsupported relative time unit type for %(type)s map <%(id)s> with layer "
-"%(l)s: %(u)s"
-msgstr "Datum %s 테이블파일을 열 수 없습니다"
+#: ../lib/python/script/task.py:62
+#, fuzzy
+msgid "unknown"
+msgstr "알려지지 않은 벡터타입입니다"
-#: ../lib/python/temporal/abstract_map_dataset.py:467
-msgid "Unsupported relative time unit type for %(type)s map <%(id)s>: %(u)s"
-#: ../lib/python/temporal/abstract_map_dataset.py:476
-msgid ""
-"End time must be greater than start time for %(typ)s map <%(id)s> with layer "
-"%(l)s"
-#: ../lib/python/temporal/abstract_map_dataset.py:800
+#: ../lib/python/script/task.py:176
#, python-format
-msgid ""
-"Map <%(id)s> with layer %(layer)s has incorrect time interval, start time is "
-"greater than end time"
+msgid "Parameter element '%(element)s' not found: '%(value)s'"
msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:806
+#: ../lib/python/script/task.py:191
#, python-format
-msgid ""
-"Map <%s> has incorrect time interval, start time is greater than end time"
+msgid "Flag not found: %s"
msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:812
+#: ../lib/python/script/task.py:210
#, python-format
-msgid "Map <%s> has incorrect start time"
+msgid "Parameter '%(name)s' (%(desc)s) is missing."
msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:859
-msgid "Delete %s dataset <%s> from temporal database"
+#: ../lib/python/script/task.py:243
+msgid "<required>"
+msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:909
+#: ../lib/python/script/task.py:503 ../lib/python/script/task.py:507
#, python-format
msgid ""
-"Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal "
+"Unable to fetch interface description for command '%(cmd)s'.\n"
+"\n"
+"Details: %(det)s"
msgstr ""
-#: ../lib/python/temporal/stds_export.py:104
-msgid "Unable to export raster map <%s>"
+#: ../lib/python/script/task.py:530
+#, python-brace-format
+msgid "Cannot parse interface description of<{name}> module: {error}"
+msgstr ""
-#: ../lib/python/temporal/stds_export.py:115
+#: ../lib/python/script/array.py:157 ../lib/python/script/array.py:207
+#: ../lib/python/script/array.py:254 ../lib/python/script/array.py:305
+#: ../lib/python/script/array.py:356 ../lib/python/script/array.py:398
-msgid "Unable to export color rules for raster map <%s> r.out.gdal"
+msgid "Invalid kind <%s>"
-#: ../lib/python/temporal/stds_export.py:139
+#: ../lib/python/script/array.py:160 ../lib/python/script/array.py:210
+#: ../lib/python/script/array.py:308 ../lib/python/script/array.py:359
-msgid "Unable to export raster map <%s> with r.pack"
+msgid "Invalid size <%d>"
-#: ../lib/python/temporal/stds_export.py:167
-msgid "Unable to export vector map <%s> as GML with v.out.ogr"
+#: ../lib/python/script/array.py:197
+msgid ""
+"grass.script.array.read is deprecated and does not work on MS Windows, pass "
+"raster name in the constructor"
+msgstr ""
-#: ../lib/python/temporal/stds_export.py:200
+#: ../lib/python/script/array.py:247 ../lib/python/script/array.py:392
-msgid "Unable to export vector map <%s> with v.pack"
+msgid "Invalid FP size <%d>"
-#: ../lib/python/temporal/stds_export.py:226
+#: ../lib/python/script/array.py:251 ../lib/python/script/array.py:395
-msgid "Unable to export raster map <%s> with r3.pack"
+msgid "Invalid integer size <%d>"
-#: ../lib/python/temporal/base.py:380
-#, fuzzy
-msgid "Object not found in the temporal database"
-#: ../lib/python/temporal/base.py:462 ../lib/python/temporal/base.py:513
-msgid "Missing identifier"
+#: ../lib/python/script/array.py:346
+msgid ""
+"grass.script.array3d.read is deprecated and does not work on MS Windows, "
+"pass 3D raster name in the constructor"
msgstr ""
-#: ../lib/python/temporal/base.py:621
-#, fuzzy
-msgid "Wrong identifier, the mapset is missing"
-#: ../lib/python/temporal/aggregation.py:127
-msgid "Aggregating %s raster maps"
+#: ../lib/python/script/db.py:45 ../lib/vector/Vlib/write_pg.c:666
+#: ../lib/vector/Vlib/ascii.c:428 ../lib/db/dbmi_client/column.c:136
+msgid "Unable to describe table <%s>"
-#: ../lib/python/temporal/aggregation.py:141
-msgid ""
-"Raster map <%(name)s> is already in temporal database, use overwrite flag to "
-"overwrite"
-#: ../lib/python/temporal/aggregation.py:146
+#: ../lib/python/script/db.py:153
#, python-format
-msgid "Computing aggregation of maps between %(st)s - %(end)s"
+msgid ""
+"Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
msgstr ""
-#: ../lib/python/temporal/aggregation.py:171
+#: ../lib/python/script/db.py:163
#, fuzzy
-msgid "Error occurred in r.series computation"
+msgid "Fetching data failed"
-#: ../lib/python/temporal/aggregation.py:280
-msgid "Aggregating %(len)i raster maps from %(start)s to %(end)s"
+#: ../lib/rowio/setup.c:61 ../lib/rowio/setup.c:67 ../lib/segment/open.c:98
+#: ../lib/rst/interp_float/interp2d.c:139
+#: ../lib/rst/interp_float/interp2d.c:145
+#: ../lib/rst/interp_float/segmen2d.c:199
+#: ../lib/rst/interp_float/segmen2d.c:205
+#: ../lib/rst/interp_float/segmen2d.c:211
+#: ../lib/rst/interp_float/segmen2d.c:221
+#: ../lib/vector/diglib/struct_alloc.c:491 ../lib/vector/Vlib/line.c:50
+#: ../lib/vector/Vlib/line.c:154 ../lib/vector/Vlib/map.c:48
+#: ../lib/vector/neta/components.c:71 ../lib/vector/neta/components.c:176
+#: ../lib/vector/neta/centrality.c:63 ../lib/vector/neta/centrality.c:145
+#: ../lib/vector/neta/flow.c:66 ../lib/vector/neta/flow.c:190
+#: ../lib/vector/neta/articulation_point.c:60
+#: ../lib/vector/neta/timetables.c:69 ../lib/vector/neta/timetables.c:168
+#: ../lib/vector/neta/timetables.c:178 ../lib/vector/neta/timetables.c:191
+#: ../lib/vector/neta/timetables.c:278 ../lib/vector/neta/timetables.c:413
+#: ../lib/vector/neta/timetables.c:425 ../lib/vector/neta/bridge.c:58
+#: ../lib/vector/neta/spanningtree.c:101 ../lib/vector/neta/path.c:262
+msgid "Out of memory"
+msgstr ""
-#: ../lib/python/temporal/aggregation.py:301
-#, python-format
-msgid ""
-"Unable to perform aggregation. Output raster map <%(name)s> exists and "
-"overwrite flag was not set"
+#: ../lib/proj/get_proj.c:148
+#, c-format
+msgid "Invalid zone %s specified"
msgstr ""
-#: ../lib/python/temporal/aggregation.py:319
-#, python-format
-msgid ""
-"The limit of open files (%i) was reached (%i). The module r.series will be "
-"run with flag z, to avoid open files limit exceeding."
+#: ../lib/proj/get_proj.c:228
+msgid "Unable to initialise PROJ.4 with the following parameter list:"
msgstr ""
-#: ../lib/python/temporal/open_stds.py:63
-#: ../lib/python/temporal/open_stds.py:119
-msgid "Unknown type: %s"
+#: ../lib/proj/get_proj.c:236
+#, c-format
+msgid "The error message: %s"
+msgstr ""
-#: ../lib/python/temporal/open_stds.py:69
-msgid "Space time %(sp)s dataset <%(name)s> not found"
+#: ../lib/proj/get_proj.c:294
+msgid "Option input overflowed option table"
+msgstr ""
-#: ../lib/python/temporal/open_stds.py:108
-#, fuzzy
-msgid "Space time datasets can only be created in the current mapset"
-#: ../lib/python/temporal/open_stds.py:125
-msgid ""
-"Space time %(sp)s dataset <%(name)s> is already in the database. Use the "
-"overwrite flag."
+#: ../lib/proj/get_proj.c:325
+#, fuzzy, c-format
+msgid "Unable to initialize pj cause: %s"
-#: ../lib/python/temporal/open_stds.py:160
-msgid ""
-"Overwriting space time %(sp)s dataset <%(name)s> and unregistering all maps"
+#: ../lib/proj/get_proj.c:401
+msgid "Input Projection Parameters"
+msgstr ""
-#: ../lib/python/temporal/open_stds.py:168
-msgid "Creating a new space time %s dataset"
-#: ../lib/python/temporal/extract.py:60
-msgid "You need to specify the base name of new created maps"
+#: ../lib/proj/get_proj.c:404
+msgid "Input Unit Factor"
msgstr ""
-#: ../lib/python/temporal/extract.py:138
-#, python-format
-msgid "Applying r.mapcalc expression: \"%s\""
+#: ../lib/proj/get_proj.c:414
+msgid "Output Projection Parameters"
msgstr ""
-#: ../lib/python/temporal/extract.py:143
-#, python-format
-msgid "Applying r3.mapcalc expression: \"%s\""
+#: ../lib/proj/get_proj.c:417
+msgid "Output Unit Factor"
msgstr ""
-#: ../lib/python/temporal/extract.py:148
-#, python-format
-msgid "Applying v.extract where statement: \"%s\""
+#: ../lib/proj/datum.c:195
+msgid "Failed to detect nadgrids path, GRASS_PROJSHARE not defined"
msgstr ""
-#: ../lib/python/temporal/extract.py:176
-#, fuzzy
-msgid "Error in computation process"
+#: ../lib/proj/datum.c:278 ../lib/proj/datum.c:358
+#, fuzzy, c-format
+msgid "Unable to open datum table file <%s>"
-#: ../lib/python/temporal/c_libraries_interface.py:596
-#: ../lib/python/temporal/c_libraries_interface.py:613
-#, fuzzy
-msgid "Unable to read range file"
+#: ../lib/proj/datum.c:291 ../lib/proj/datum.c:372
+#, fuzzy, c-format
+msgid "Error in datum table file <%s>, line %d"
+msgstr "Datum 테이블파일의 %d번째 줄에 오류가 있습니다"
-#: ../lib/python/temporal/c_libraries_interface.py:691
-msgid "Unable to load range of 3D raster map <%s>"
+#: ../lib/proj/convert.c:82 ../lib/vector/Vlib/build_sfa.c:711
+#: ../lib/vector/Vlib/simple_features.c:310 ../lib/vector/Vlib/close.c:284
+#: ../lib/vector/Vlib/header_finfo.c:41 ../lib/vector/Vlib/header_finfo.c:80
+#: ../lib/vector/Vlib/header_finfo.c:113 ../lib/vector/Vlib/header_finfo.c:153
+#: ../lib/vector/Vlib/header_finfo.c:254 ../lib/vector/Vlib/write_sfa.c:298
+#: ../lib/vector/Vlib/close_ogr.c:77 ../lib/vector/Vlib/close_ogr.c:111
+#: ../lib/vector/Vlib/write_ogr.c:69 ../lib/vector/Vlib/write_ogr.c:105
+#: ../lib/vector/Vlib/write_ogr.c:145 ../lib/vector/Vlib/build_ogr.c:96
+#: ../lib/vector/Vlib/build_ogr.c:171 ../lib/vector/Vlib/rewind_ogr.c:47
+#: ../lib/vector/Vlib/rewind_ogr.c:71 ../lib/vector/Vlib/open_ogr.c:121
+#: ../lib/vector/Vlib/open_ogr.c:154 ../lib/vector/Vlib/open_ogr.c:231
+#: ../lib/vector/Vlib/read_ogr.c:56 ../lib/vector/Vlib/read_ogr.c:157
+#: ../lib/vector/Vlib/read_ogr.c:242 ../lib/vector/Vlib/field.c:675
+msgid "GRASS is not compiled with OGR support"
+msgstr ""
-#: ../lib/python/script/raster3d.py:92
-#, python-format
-msgid "An error occurred while running r3.mapcalc with expression: %s"
+#: ../lib/proj/convert.c:120
+msgid "Unable parse GRASS PROJ_INFO file"
msgstr ""
-#: ../lib/python/script/core.py:67
-msgid "Cannot find the executable {}"
+#: ../lib/proj/convert.c:125
+msgid "Unable get PROJ.4-style parameter string"
msgstr ""
-#: ../lib/python/script/core.py:304
-#, python-format
+#: ../lib/proj/convert.c:139
+#, c-format
msgid ""
-"To run the module <%s> add underscore at the end of the option <%s> to avoid "
-"conflict with Python keywords. Underscore at the beginning is depreciated in "
-"GRASS GIS 7.0 and will be removed in version 7.1."
+"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
msgstr ""
-#: ../lib/python/script/core.py:928
-msgid "Mixing value types. Will try to compare after integer conversion"
+#: ../lib/proj/convert.c:152
+#, c-format
+msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
msgstr ""
-#: ../lib/python/script/core.py:1123
-#, python-format
-msgid "Element type should be \"cell\" and not \"%s\""
+#: ../lib/proj/convert.c:394
+msgid "No projection name! Projection parameters likely to be meaningless."
msgstr ""
-#: ../lib/python/script/core.py:1152 ../lib/python/script/core.py:1217
-#, python-format
-msgid "Element type should be \"raster\" and not \"%s\""
+#: ../lib/proj/convert.c:457
+#, c-format
+msgid "Datum <%s> not recognised by GRASS and no parameters found"
msgstr ""
-#: ../lib/python/script/core.py:1372
-#, fuzzy
-msgid "Unable to list mapsets"
-#: ../lib/python/script/core.py:1411
-#, python-format
-msgid "Location <%s> already exists. Operation canceled."
+#: ../lib/proj/convert.c:473
+#, c-format
+msgid ""
+"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
+"want to look into this."
msgstr ""
-#: ../lib/python/script/core.py:1414
-msgid "Location <%s> already exists and will be overwritten"
-#: ../lib/python/script/core.py:1538
-msgid "Debug level {}"
+#: ../lib/proj/convert.c:477
+#, c-format
+msgid ""
+"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
+"transform parameters unspecified."
msgstr ""
-#: ../lib/python/script/core.py:1541
-msgid "WARNING: Ignoring unsupported debug level (must be >=0 and <=5). {}\n"
+#: ../lib/proj/ellipse.c:97
+#, c-format
+msgid "Invalid ellipsoid <%s> in file"
msgstr ""
-#: ../lib/python/script/core.py:1557
-#, python-format
-msgid "Illegal filename <%s>. Cannot be 'NULL' or start with '.'."
+#: ../lib/proj/ellipse.c:124
+msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
msgstr ""
-#: ../lib/python/script/core.py:1566
-#, python-format
-msgid "Illegal filename <%(s)s>. <%(il)s> not allowed.\n"
+#: ../lib/proj/ellipse.c:128
+msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
msgstr ""
-#: ../lib/python/script/vector.py:88
-#, python-format
-msgid "Database connection not defined for layer %s"
+#: ../lib/proj/ellipse.c:141
+msgid "No ellipsoid info given in file"
msgstr ""
-#: ../lib/python/script/vector.py:228
-msgid "Missing layer %(layer)d in vector map <%(map)s>"
+#: ../lib/proj/ellipse.c:243 ../lib/gis/get_ellipse.c:263
+#, fuzzy, c-format
+msgid "Unable to open ellipsoid table file <%s>"
-#: ../lib/python/script/vector.py:243
-msgid "vector_db_select() failed"
+#: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
+#, c-format
+msgid "pj_transform() failed: %s"
msgstr ""
-#: ../lib/python/script/vector.py:350
-msgid "Number of given vector maps ({m}) differs from number of layers ({l})"
+#: ../lib/arraystats/class.c:19
+#, fuzzy, c-format
+msgid "Unknown algorithm '%s'"
+#: ../lib/arraystats/class.c:42
+msgid "Discont algorithm currently not available because of bugs"
msgstr ""
-#: ../lib/python/script/vector.py:407
-msgid ""
-"v.what output is not valid JSON format:\n"
-" {ret}"
+#: ../lib/arraystats/class.c:49
+msgid "Classification algorithm failed"
msgstr ""
-#: ../lib/python/script/raster.py:54
+#: ../lib/arraystats/class.c:227
+msgid "Equiprobable classbreaks currently limited to 10 classes"
+msgstr ""
+#: ../lib/arraystats/class.c:242
+#, c-format
msgid ""
-"Unable to write history for <%(map)s>. Raster map <%(map)s> not found in "
-"current mapset."
+"There are classbreaks outside the range min-max. Number of classes reduced "
+"to %i, but using probabilities for %i classes."
+msgstr ""
-#: ../lib/python/script/raster.py:113
-#, python-format
-msgid "An error occurred while running r.mapcalc with expression: %s"
+#: ../lib/manage/option.c:47
+#, c-format
+msgid "%s to be %s"
msgstr ""
-#: ../lib/python/script/raster.py:192
-#, fuzzy
-msgid "No data"
+#: ../lib/manage/option.c:51
+msgid "Raster"
+msgstr "라스터"
-#: ../lib/python/script/raster.py:200
-msgid "value"
-msgstr ""
+#: ../lib/manage/option.c:53
+msgid "Vector"
+msgstr "벡터"
-msgid "label"
+#: ../lib/manage/option.c:55
+msgid "Region"
+msgstr "지역"
+#: ../lib/manage/option.c:57
+msgid "Group"
+msgstr "그룹"
+#: ../lib/manage/do_list.c:30
+#, c-format
+msgid "%s: invalid index %d"
msgstr ""
-msgid "color"
+#: ../lib/manage/read_list.c:73
+#, fuzzy, c-format
+msgid "Unable to open data base element list '%s'"
+msgstr "데이타의 기본요소목록 '%s'를 열 수 없습니다"
+#: ../lib/manage/read_list.c:134
+#, c-format
+msgid "Format error: file ('%s') line (%d) - %s"
msgstr ""
-#: ../lib/python/script/db.py:45 ../lib/db/dbmi_client/column.c:136
-#: ../lib/vector/Vlib/write_pg.c:666 ../lib/vector/Vlib/ascii.c:428
-#, fuzzy, c-format, python-format
-msgid "Unable to describe table <%s>"
+#: ../lib/manage/do_rename.c:42
+#, fuzzy, c-format
+msgid "Rename %s <%s> to <%s>"
+msgstr "<%s>를 <%s>으로 이름을 바꿉니다"
-#: ../lib/python/script/db.py:153
-#, python-format
-msgid ""
-"Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
+#: ../lib/manage/do_rename.c:54 ../lib/manage/do_remove.c:57
+#: ../lib/vector/Vlib/legal_vname.c:141 ../lib/vector/Vlib/legal_vname.c:144
+#: ../lib/vector/Vlib/map.c:263 ../lib/vector/Vlib/open.c:235
+#: ../lib/ogsf/gp3.c:56 ../lib/ogsf/gp3.c:191 ../lib/ogsf/gv3.c:60
+#: ../lib/ogsf/gv3.c:333
+#, c-format
+msgid "Vector map <%s> not found"
+msgstr "벡터맵 <%s>를 찾을 수 없습니다"
+#: ../lib/manage/do_rename.c:62
+#, fuzzy, c-format
+msgid "Unable to rename vector map <%s> to <%s>"
+msgstr "벡터맵 <%s>의 이름을 <%s>으로 바꾸지 못 했습니다"
+#: ../lib/manage/do_rename.c:71 ../lib/manage/do_remove.c:73
+#: ../lib/rst/interp_float/resout2d.c:205
+#: ../lib/rst/interp_float/resout2d.c:253
+#: ../lib/rst/interp_float/resout2d.c:296
+#: ../lib/rst/interp_float/resout2d.c:327
+#: ../lib/rst/interp_float/resout2d.c:377
+#: ../lib/rst/interp_float/resout2d.c:395
+#: ../lib/rst/interp_float/resout2d.c:410
+#: ../lib/rst/interp_float/resout2d.c:426
+#: ../lib/rst/interp_float/output2d.c:247
+#: ../lib/rst/interp_float/output2d.c:328
+#: ../lib/rst/interp_float/output2d.c:397
+#: ../lib/rst/interp_float/output2d.c:447
+#: ../lib/rst/interp_float/output2d.c:461
+#: ../lib/rst/interp_float/output2d.c:475
+#: ../lib/rst/interp_float/output2d.c:491 ../lib/raster/open.c:178
+#: ../lib/raster/open.c:845 ../lib/raster/open.c:882 ../lib/raster/open.c:934
+#: ../lib/gis/legal_name.c:94 ../lib/gis/legal_name.c:97 ../lib/ogsf/gs3.c:125
+#: ../lib/ogsf/gs3.c:189 ../lib/ogsf/gs3.c:264 ../lib/ogsf/gs3.c:336
+#: ../lib/ogsf/gs3.c:442 ../lib/ogsf/gs3.c:529 ../lib/ogsf/gs3.c:588
+#: ../lib/ogsf/gs3.c:645 ../lib/ogsf/gs3.c:716 ../lib/ogsf/gs3.c:786
+#: ../lib/ogsf/gsd_legend.c:239
+#, c-format
+msgid "Raster map <%s> not found"
msgstr ""
-#: ../lib/python/script/db.py:163
+#: ../lib/manage/do_rename.c:76 ../lib/manage/do_remove.c:78
+#: ../lib/gpde/n_arrays_io.c:273 ../lib/ogsf/gvl_file.c:427
+#: ../lib/ogsf/gvl3.c:40
+#, c-format
+msgid "3D raster map <%s> not found"
+msgstr "3차원 라스터맵 <%s>를 찾을 수 없습니다"
+#: ../lib/manage/do_rename.c:83 ../lib/manage/do_rename.c:103
+#, fuzzy, c-format
+msgid "Unable to rename %s"
+msgstr "%s의 이름을 바꾸지 못 했습니다"
+#: ../lib/manage/do_rename.c:87 ../lib/manage/do_rename.c:107
+#: ../lib/manage/do_copy.c:61 ../lib/manage/do_remove.c:89
+#: ../lib/manage/do_remove.c:109
+#, c-format
+msgid "%s is missing"
+msgstr "%s이 없습니다"
+#: ../lib/manage/do_rename.c:90 ../lib/manage/do_rename.c:110
+#, c-format
+msgid "%s renamed"
+msgstr "%s의 이름을 바꾸었습니다"
+#: ../lib/manage/do_rename.c:119
+#, c-format
+msgid "<%s> nothing renamed"
+msgstr "<%s> 어떤 이름도 바꾸지 않았습니다"
+#: ../lib/manage/do_copy.c:43
+#, fuzzy, c-format
+msgid "Copy %s <%s> to current mapset as <%s>"
+msgstr "<%s>를 현재 맵셋의 <%s>으로 복사합니다"
+#: ../lib/manage/do_copy.c:50 ../lib/manage/do_copy.c:67
+#, fuzzy, c-format
+msgid "Unable to copy <%s> to current mapset as <%s>"
+msgstr "<%s>를 현재 맵셋의 <%s>으로 복사 할 수 없습니다"
+#: ../lib/manage/do_copy.c:72
+#, c-format
+msgid "%s copied"
+msgstr "%s를 복사했습니다"
+#: ../lib/manage/do_remove.c:42
+#, c-format
+msgid "Removing %s <%s>"
+msgstr "%s <%s>를 지우는 중입니다"
+#: ../lib/manage/do_remove.c:65
+msgid "Unable to delete vector map"
+msgstr "벡터맵을 지울 수 없습니다"
+#: ../lib/manage/do_remove.c:85
+#, c-format
+msgid "Unable to remove %s element"
+msgstr "%s 요소를 지울 수 없습니다"
+#: ../lib/manage/do_remove.c:92 ../lib/manage/do_remove.c:112
+#, c-format
+msgid "%s removed"
+msgstr "%s를 지웠습니다"
+#: ../lib/manage/do_remove.c:105
+#, c-format
+msgid "Unable to remove %s"
+msgstr "%s를 지울 수 없습니다"
+#: ../lib/manage/do_remove.c:121
+#, c-format
+msgid "<%s> nothing removed"
+msgstr "<%s> 아무 것도 지우지 않았습니다"
+#: ../lib/nviz/position.c:56
#, fuzzy
-msgid "Fetching data failed"
+msgid "Unable to set focus"
-#: ../lib/python/script/array.py:157 ../lib/python/script/array.py:207
-#: ../lib/python/script/array.py:254 ../lib/python/script/array.py:305
-#: ../lib/python/script/array.py:356 ../lib/python/script/array.py:398
-msgid "Invalid kind <%s>"
+#: ../lib/nviz/map_obj.c:59
+msgid "Maximum surfaces loaded!"
+msgstr "최대 표면 개수를 초과했습니다!"
-#: ../lib/python/script/array.py:160 ../lib/python/script/array.py:210
-#: ../lib/python/script/array.py:308 ../lib/python/script/array.py:359
-msgid "Invalid size <%d>"
+#: ../lib/nviz/map_obj.c:88
+msgid "Maximum vector line maps loaded!"
+msgstr "최대 선벡터맵 개수를 초과했습니다!"
+#: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
+#, fuzzy, c-format
+msgid "Error loading vector map <%s>"
-#: ../lib/python/script/array.py:197
-msgid ""
-"grass.script.array.read is deprecated and does not work on MS Windows, pass "
-"raster name in the constructor"
-msgstr ""
+#: ../lib/nviz/map_obj.c:116
+msgid "Maximum vector point maps loaded!"
+msgstr "최대 점벡터지도 개수를 초과했습니다!"
-#: ../lib/python/script/array.py:247 ../lib/python/script/array.py:392
-msgid "Invalid FP size <%d>"
+#: ../lib/nviz/map_obj.c:143
+msgid "Maximum volumes loaded!"
+msgstr "최대 부피를 초과했습니다!"
+#: ../lib/nviz/map_obj.c:152
+#, fuzzy, c-format
+msgid "Error loading 3d raster map <%s>"
-#: ../lib/python/script/array.py:251 ../lib/python/script/array.py:395
-msgid "Invalid integer size <%d>"
+#: ../lib/nviz/map_obj.c:160
+msgid "Nviz_new_map_obj(): unsupported data type"
+msgstr "Nviz_new_map_obj(): 지원하지 않는 자료형입니다."
+#: ../lib/nviz/lights.c:171
+#, fuzzy
+msgid "Unable to define new light"
-#: ../lib/python/script/array.py:346
-msgid ""
-"grass.script.array3d.read is deprecated and does not work on MS Windows, "
-"pass 3D raster name in the constructor"
-msgstr ""
+#: ../lib/nviz/nviz.c:128
+#, c-format
+msgid "Invalid color (%s), using \"white\" as default"
+msgstr "잘못된 색상(%s)입니다. \"white\"를 기본값으로 사용합니다."
-#: ../lib/python/script/task.py:62
+#: ../lib/nviz/render.c:106
+msgid "Bad server connection"
+msgstr "서버접속 오류입니다."
+#: ../lib/nviz/render.c:112
#, fuzzy
-msgid "unknown"
+msgid "Unable to get visual info"
-#: ../lib/python/script/task.py:176
-#, python-format
-msgid "Parameter element '%(element)s' not found: '%(value)s'"
-msgstr ""
+#: ../lib/nviz/render.c:119
+#, fuzzy
+msgid "Unable to create rendering context"
-#: ../lib/python/script/task.py:191
-#, python-format
-msgid "Flag not found: %s"
-msgstr ""
+#: ../lib/lidar/zones.c:473 ../lib/lidar/zones.c:510
+#, fuzzy, c-format
+msgid "<%s> created in database."
-#: ../lib/python/script/task.py:210
-#, python-format
-msgid "Parameter '%(name)s' (%(desc)s) is missing."
+#: ../lib/lidar/zones.c:477 ../lib/lidar/zones.c:514
+#, c-format
+msgid "<%s> has not been created in database."
msgstr ""
-#: ../lib/python/script/task.py:243
-msgid "<required>"
+#: ../lib/lidar/raster.c:74 ../lib/lidar/raster.c:89 ../lib/lidar/raster.c:102
+#: ../lib/lidar/raster.c:119 ../lib/lidar/raster.c:134
+#: ../lib/lidar/raster.c:147 ../lib/lidar/raster.c:162
+#: ../lib/lidar/raster.c:175
+#, fuzzy, c-format
+msgid "Unable to access table <%s>"
+#: ../lib/segment/open.c:53
+msgid "Segment file name is NULL"
msgstr ""
-#: ../lib/python/script/task.py:503 ../lib/python/script/task.py:507
-#, python-format
-msgid ""
-"Unable to fetch interface description for command '%(cmd)s'.\n"
-"\n"
-"Details: %(det)s"
+#: ../lib/segment/open.c:58
+msgid "Segment file exists already"
msgstr ""
-#: ../lib/python/script/task.py:530
-msgid "Cannot parse interface description of<{name}> module: {error}"
+#: ../lib/segment/open.c:66
+#, fuzzy
+msgid "Unable to create segment file"
+msgstr "임시파일을 열 수 없습니다"
+#: ../lib/segment/open.c:74
+#, fuzzy
+msgid "Could not write segment file"
+msgstr "자동 MASK파일을 열 수 없습니다"
+#: ../lib/segment/open.c:78
+msgid "Illegal segment configuration parameter(s)"
msgstr ""
-#: ../lib/python/exceptions/__init__.py:68
-#, python-format
-msgid "Module run %s %s ended with error"
+#: ../lib/segment/open.c:87
+#, fuzzy
+msgid "Unable to re-open segment file"
+#: ../lib/segment/open.c:94
+msgid "Could not read segment file"
msgstr ""
-#: ../lib/python/exceptions/__init__.py:69
-#, python-format
-msgid ""
-"\n"
-"Process ended with non-zero return code %s"
+#: ../lib/segment/format.c:143
+msgid "Segment format: file size too large"
msgstr ""
-#: ../lib/python/exceptions/__init__.py:71
-#, python-format
-msgid ""
-". See the following errors:\n"
-"%s"
+#: ../lib/segment/format.c:144
+msgid "Please recompile with Large File Support (LFS)"
msgstr ""
-#: ../lib/python/exceptions/__init__.py:75
-msgid ". See errors in the (error) output."
+#: ../lib/gpde/test/test_main.c:88
+msgid "Performs unit and integration tests for gpde library"
msgstr ""
-#: ../lib/driver/parse_ftcap.c:84
+#: ../lib/gpde/n_gwflow.c:436 ../lib/gpde/n_gwflow.c:715
#, c-format
-msgid "%s: Unable to read font definition file; use the default"
+msgid "The total sum of the water budget: %g\n"
msgstr ""
-#: ../lib/driver/parse_ftcap.c:90
+#: ../lib/gpde/n_gwflow.c:438 ../lib/gpde/n_gwflow.c:717
#, c-format
-msgid "%s: No font definition file"
+msgid "The total sum of the water budget is significantly larger then 0: %g\n"
msgstr ""
-#: ../lib/gmath/solvers_krylov.c:254 ../lib/gmath/solvers_krylov.c:482
-#: ../lib/gmath/solvers_krylov.c:646 ../lib/gmath/solvers_direct.c:134
-msgid "Unable to solve the linear equation system"
+#: ../lib/gpde/n_parse_options.c:106
+msgid "The calculation time in seconds"
msgstr ""
-#: ../lib/gmath/solvers_krylov.c:262
+#: ../lib/gpde/n_arrays_io.c:93
#, c-format
-msgid "Sparse PCG -- iteration %i error %g\n"
+msgid "Reading raster map <%s> into memory"
msgstr ""
-#: ../lib/gmath/solvers_krylov.c:264
-#, c-format
-msgid "PCG -- iteration %i error %g\n"
+#: ../lib/gpde/n_arrays_io.c:183
+msgid "N_array_2d * array is empty"
msgstr ""
-#: ../lib/gmath/solvers_krylov.c:490
+#: ../lib/gpde/n_arrays_io.c:202
#, c-format
-msgid "Sparse CG -- iteration %i error %g\n"
+msgid "Write 2d array to raster map <%s>"
msgstr ""
-#: ../lib/gmath/solvers_krylov.c:492
+#: ../lib/gpde/n_arrays_io.c:309
#, c-format
-msgid "CG -- iteration %i error %g\n"
+msgid "Read g3d map <%s> into the memory"
msgstr ""
-#: ../lib/gmath/solvers_krylov.c:695
-#, c-format
-msgid "Sparse BiCGStab -- iteration %i error %g\n"
+#: ../lib/gpde/n_arrays_io.c:364 ../lib/gpde/n_arrays_io.c:464
+msgid "Error closing g3d file"
msgstr ""
-#: ../lib/gmath/solvers_krylov.c:698
+#: ../lib/gpde/n_arrays_io.c:420
#, c-format
-msgid "BiCGStab -- iteration %i error %g\n"
+msgid "Error opening g3d map <%s>"
msgstr ""
-#: ../lib/gmath/solvers_direct.c:45
-msgid "Starting direct gauss elimination solver"
+#: ../lib/gpde/n_arrays_io.c:422
+#, c-format
+msgid "Write 3d array to g3d map <%s>"
msgstr ""
-#: ../lib/gmath/solvers_direct.c:73
-msgid "Starting direct lu decomposition solver"
+#: ../lib/driver/parse_ftcap.c:84
+#, c-format
+msgid "%s: Unable to read font definition file; use the default"
msgstr ""
-#: ../lib/gmath/solvers_direct.c:131
-msgid "Starting cholesky decomposition solver"
+#: ../lib/driver/parse_ftcap.c:90
+#, c-format
+msgid "%s: No font definition file"
msgstr ""
-#: ../lib/gmath/solvers_direct_cholesky_band.c:33
+#: ../lib/symbol/read.c:211
#, c-format
-msgid "Decomposition failed at row %i and col %i"
-msgstr ""
+msgid "Cannot read symbol line coordinates: %s"
+msgstr "심볼의 좌표를 읽을 수 없습니다: %s"
-#: ../lib/gmath/test/bench_blas2.c:35
+#: ../lib/symbol/read.c:260
+#, c-format
msgid ""
-"\n"
-"++ Running blas level 2 benchmark ++"
+"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
msgstr ""
+"잘못된 심볼이름: '%s' (group/name 또는 group/name at mapset 중 하나여야 합니다.)"
-#: ../lib/gmath/test/test_blas3.c:38
-msgid ""
-"\n"
-"++ Running blas level 3 unit tests ++"
-msgstr ""
+#: ../lib/symbol/read.c:284
+#, c-format
+msgid "Cannot find/open symbol: '%s'"
+msgstr "심볼을 찾을 수 없거나 열 수 없습니다: '%s'"
-#: ../lib/gmath/test/test_blas3.c:44
-msgid ""
-"\n"
-"-- blas level 3 unit tests failure --"
-msgstr ""
+#: ../lib/symbol/read.c:393 ../lib/symbol/read.c:411 ../lib/symbol/read.c:421
+#: ../lib/symbol/read.c:439
+#, c-format
+msgid "Incorrect symbol color: '%s', using default."
+msgstr "잘못된 심볼색상: %s, 기본값을 사용합니다."
-#: ../lib/gmath/test/test_blas3.c:46
-msgid ""
-"\n"
-"-- blas level 3 unit tests finished successfully --"
+#: ../lib/gmath/del2g.c:50
+msgid " taking FFT of image..."
msgstr ""
-#: ../lib/gmath/test/test_solvers.c:37
-msgid ""
-"\n"
-"++ Running solver unit tests ++"
+#: ../lib/gmath/del2g.c:56
+msgid " computing del**2 g..."
msgstr ""
-#: ../lib/gmath/test/test_solvers.c:42
-msgid ""
-"\n"
-"-- Solver unit tests failure --"
+#: ../lib/gmath/del2g.c:59
+msgid " taking FFT of del**2 g..."
msgstr ""
-#: ../lib/gmath/test/test_solvers.c:44
-msgid ""
-"\n"
-"-- Solver unit tests finished successfully --"
+#: ../lib/gmath/del2g.c:63
+msgid " multiplying transforms..."
msgstr ""
-#: ../lib/gmath/test/test_blas1.c:40
-msgid ""
-"\n"
-"++ Running blas level 1 unit tests ++"
+#: ../lib/gmath/del2g.c:66
+msgid " taking inverse FFT..."
msgstr ""
-#: ../lib/gmath/test/test_blas1.c:47
+#: ../lib/gmath/test/test_matrix_conversion.c:37
msgid ""
"\n"
-"-- blas level 1 unit tests failure --"
+"++ Running matrix conversion unit tests ++"
msgstr ""
-#: ../lib/gmath/test/test_blas1.c:49
+#: ../lib/gmath/test/test_matrix_conversion.c:42
msgid ""
"\n"
-"-- blas level 1 unit tests finished successfully --"
+"-- Matrix conversion unit tests failure --"
msgstr ""
-#: ../lib/gmath/test/bench_solver_direct.c:34
+#: ../lib/gmath/test/test_matrix_conversion.c:44
msgid ""
"\n"
-"++ Running direct solver benchmark ++"
+"-- Matrix conversion unit tests finished successfully --"
msgstr ""
-#: ../lib/gmath/test/bench_blas3.c:34
+#: ../lib/gmath/test/bench_blas2.c:35
msgid ""
"\n"
-"++ Running blas level 3 benchmark ++"
+"++ Running blas level 2 benchmark ++"
msgstr ""
-#: ../lib/gmath/test/test_blas2.c:38
+#: ../lib/gmath/test/test_ccmath_wrapper.c:37
msgid ""
"\n"
-"++ Running blas level 2 unit tests ++"
+"++ Running ccmath wrapper unit tests ++"
msgstr ""
-#: ../lib/gmath/test/test_blas2.c:44
+#: ../lib/gmath/test/test_ccmath_wrapper.c:42
msgid ""
"\n"
-"-- blas level 2 unit tests failure --"
+"-- ccmath wrapper unit tests failure --"
msgstr ""
-#: ../lib/gmath/test/test_blas2.c:46
+#: ../lib/gmath/test/test_ccmath_wrapper.c:44
msgid ""
"\n"
-"-- blas level 2 unit tests finished successfully --"
+"-- ccmath wrapper unit tests finished successfully --"
msgstr ""
-#: ../lib/gmath/test/test_main.c:47 ../lib/db/dbmi_base/test/test_main.c:47
+#: ../lib/gmath/test/test_main.c:47
#: ../lib/vector/rtree/test_suite/test_main.c:44
+#: ../lib/db/dbmi_base/test/test_main.c:47
msgid "Choose the unit tests to run"
msgstr ""
@@ -2667,60 +2369,93 @@
"++ Running krylov solver benchmark ++"
msgstr ""
-#: ../lib/gmath/test/test_ccmath_wrapper.c:37
+#: ../lib/gmath/test/test_blas3.c:38
msgid ""
"\n"
-"++ Running ccmath wrapper unit tests ++"
+"++ Running blas level 3 unit tests ++"
msgstr ""
-#: ../lib/gmath/test/test_ccmath_wrapper.c:42
+#: ../lib/gmath/test/test_blas3.c:44
msgid ""
"\n"
-"-- ccmath wrapper unit tests failure --"
+"-- blas level 3 unit tests failure --"
msgstr ""
-#: ../lib/gmath/test/test_ccmath_wrapper.c:44
+#: ../lib/gmath/test/test_blas3.c:46
msgid ""
"\n"
-"-- ccmath wrapper unit tests finished successfully --"
+"-- blas level 3 unit tests finished successfully --"
msgstr ""
-#: ../lib/gmath/test/test_matrix_conversion.c:37
+#: ../lib/gmath/test/bench_solver_direct.c:34
msgid ""
"\n"
-"++ Running matrix conversion unit tests ++"
+"++ Running direct solver benchmark ++"
msgstr ""
-#: ../lib/gmath/test/test_matrix_conversion.c:42
+#: ../lib/gmath/test/test_blas1.c:40
msgid ""
"\n"
-"-- Matrix conversion unit tests failure --"
+"++ Running blas level 1 unit tests ++"
msgstr ""
-#: ../lib/gmath/test/test_matrix_conversion.c:44
+#: ../lib/gmath/test/test_blas1.c:47
msgid ""
"\n"
-"-- Matrix conversion unit tests finished successfully --"
+"-- blas level 1 unit tests failure --"
msgstr ""
-#: ../lib/gmath/solvers_classic_iter.c:84
-#, c-format
-msgid "sparse Jacobi -- iteration %5i error %g\n"
+#: ../lib/gmath/test/test_blas1.c:49
+msgid ""
+"\n"
+"-- blas level 1 unit tests finished successfully --"
msgstr ""
-#: ../lib/gmath/solvers_classic_iter.c:156
-#, c-format
-msgid "sparse SOR -- iteration %5i error %g\n"
+#: ../lib/gmath/test/test_blas2.c:38
+msgid ""
+"\n"
+"++ Running blas level 2 unit tests ++"
msgstr ""
-#: ../lib/gmath/solvers_classic_iter.c:218
-#, c-format
-msgid "Jacobi -- iteration %5i error %g\n"
+#: ../lib/gmath/test/test_blas2.c:44
+msgid ""
+"\n"
+"-- blas level 2 unit tests failure --"
msgstr ""
-#: ../lib/gmath/solvers_classic_iter.c:275
+#: ../lib/gmath/test/test_blas2.c:46
+msgid ""
+"\n"
+"-- blas level 2 unit tests finished successfully --"
+msgstr ""
+#: ../lib/gmath/test/test_solvers.c:37
+msgid ""
+"\n"
+"++ Running solver unit tests ++"
+msgstr ""
+#: ../lib/gmath/test/test_solvers.c:42
+msgid ""
+"\n"
+"-- Solver unit tests failure --"
+msgstr ""
+#: ../lib/gmath/test/test_solvers.c:44
+msgid ""
+"\n"
+"-- Solver unit tests finished successfully --"
+msgstr ""
+#: ../lib/gmath/test/bench_blas3.c:34
+msgid ""
+"\n"
+"++ Running blas level 3 benchmark ++"
+msgstr ""
+#: ../lib/gmath/solvers_direct_cholesky_band.c:33
#, c-format
-msgid "SOR -- iteration %5i error %g\n"
+msgid "Decomposition failed at row %i and col %i"
msgstr ""
#: ../lib/gmath/la.c:61 ../lib/gmath/la.c:117
@@ -2893,476 +2628,553 @@
msgid "Input format error"
msgstr ""
-#: ../lib/gmath/del2g.c:50
-msgid " taking FFT of image..."
+#: ../lib/gmath/solvers_classic_iter.c:84
+#, c-format
+msgid "sparse Jacobi -- iteration %5i error %g\n"
msgstr ""
-#: ../lib/gmath/del2g.c:56
-msgid " computing del**2 g..."
+#: ../lib/gmath/solvers_classic_iter.c:156
+#, c-format
+msgid "sparse SOR -- iteration %5i error %g\n"
msgstr ""
-#: ../lib/gmath/del2g.c:59
-msgid " taking FFT of del**2 g..."
+#: ../lib/gmath/solvers_classic_iter.c:218
+#, c-format
+msgid "Jacobi -- iteration %5i error %g\n"
msgstr ""
-#: ../lib/gmath/del2g.c:63
-msgid " multiplying transforms..."
+#: ../lib/gmath/solvers_classic_iter.c:275
+#, c-format
+msgid "SOR -- iteration %5i error %g\n"
msgstr ""
-#: ../lib/gmath/del2g.c:66
-msgid " taking inverse FFT..."
+#: ../lib/gmath/solvers_direct.c:45
+msgid "Starting direct gauss elimination solver"
msgstr ""
-#: ../lib/lidar/raster.c:74 ../lib/lidar/raster.c:89 ../lib/lidar/raster.c:102
-#: ../lib/lidar/raster.c:119 ../lib/lidar/raster.c:134
-#: ../lib/lidar/raster.c:147 ../lib/lidar/raster.c:162
-#: ../lib/lidar/raster.c:175
-#, fuzzy, c-format
-msgid "Unable to access table <%s>"
+#: ../lib/gmath/solvers_direct.c:73
+msgid "Starting direct lu decomposition solver"
+msgstr ""
-#: ../lib/lidar/zones.c:473 ../lib/lidar/zones.c:510
-#, fuzzy, c-format
-msgid "<%s> created in database."
+#: ../lib/gmath/solvers_direct.c:131
+msgid "Starting cholesky decomposition solver"
+msgstr ""
-#: ../lib/lidar/zones.c:477 ../lib/lidar/zones.c:514
+#: ../lib/gmath/solvers_direct.c:134 ../lib/gmath/solvers_krylov.c:254
+#: ../lib/gmath/solvers_krylov.c:482 ../lib/gmath/solvers_krylov.c:646
+msgid "Unable to solve the linear equation system"
+msgstr ""
+#: ../lib/gmath/solvers_krylov.c:262
#, c-format
-msgid "<%s> has not been created in database."
+msgid "Sparse PCG -- iteration %i error %g\n"
msgstr ""
-#: ../lib/db/dbmi_base/index.c:180
-msgid "db_set_index_column_name(): invalid column number"
+#: ../lib/gmath/solvers_krylov.c:264
+#, c-format
+msgid "PCG -- iteration %i error %g\n"
msgstr ""
-#: ../lib/db/dbmi_base/index.c:197
-msgid "db_get_index_column_name(): invalid column number"
+#: ../lib/gmath/solvers_krylov.c:490
+#, c-format
+msgid "Sparse CG -- iteration %i error %g\n"
msgstr ""
-#: ../lib/db/dbmi_base/legal_dbname.c:38
+#: ../lib/gmath/solvers_krylov.c:492
#, c-format
-msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'."
+msgid "CG -- iteration %i error %g\n"
msgstr ""
-#: ../lib/db/dbmi_base/legal_dbname.c:45
+#: ../lib/gmath/solvers_krylov.c:695
#, c-format
-msgid "Illegal table map name <%s>. Must start with a letter."
+msgid "Sparse BiCGStab -- iteration %i error %g\n"
msgstr ""
-#: ../lib/db/dbmi_base/legal_dbname.c:54
+#: ../lib/gmath/solvers_krylov.c:698
#, c-format
-msgid "Illegal table map name <%s>. Character <%c> not allowed."
+msgid "BiCGStab -- iteration %i error %g\n"
msgstr ""
-#: ../lib/db/dbmi_base/valuefmt.c:52
-msgid "db_convert_Cstring_to_value(): unrecognized sqltype"
+#: ../lib/rst/interp_float/interp2d.c:232
+#, c-format
+msgid ""
+"Overshoot - increase in tension suggested. Overshoot occurs at (%d,%d) cell. "
+"Z-value %f, zmin %f, zmax %f."
msgstr ""
-#: ../lib/db/dbmi_base/valuefmt.c:91
-msgid "db_convert_value_into_string(): unrecongized sqltype-type"
+#: ../lib/rst/interp_float/input2d.c:58
+#, c-format
+msgid "Mask raster map <%s> not found"
msgstr ""
-#: ../lib/db/dbmi_base/default_name.c:136
-msgid "Programmer error"
+#: ../lib/rst/interp_float/input2d.c:81
+msgid "Bitmap mask created"
msgstr ""
-#: ../lib/db/dbmi_base/login.c:115
-#, fuzzy, c-format
-msgid "Unable to read file '%s'"
+#: ../lib/rst/interp_float/resout2d.c:77
+msgid "Temporarily changing the region to desired resolution..."
+msgstr ""
-#: ../lib/db/dbmi_base/login.c:126
+#: ../lib/rst/interp_float/resout2d.c:103
#, c-format
-msgid "Login file (%s) corrupted (line: %s)"
+msgid "First change your rows number(%d) to %d"
msgstr ""
-#: ../lib/db/dbmi_base/login.c:164
-#, fuzzy, c-format
-msgid "Unable to write file '%s'"
+#: ../lib/rst/interp_float/resout2d.c:110
+#, c-format
+msgid "First change your columns number(%d) to %d"
+msgstr ""
-#: ../lib/db/dbmi_base/login.c:229
-#, fuzzy, c-format
-msgid "DB connection <%s/%s> already exists and will be overwritten"
+#: ../lib/rst/interp_float/resout2d.c:264
+msgid "No color table for input raster map -- will not create color table"
+msgstr ""
-#: ../lib/db/dbmi_base/login.c:232
+#: ../lib/rst/interp_float/resout2d.c:458
+msgid "Changing the region back to initial..."
+msgstr ""
+#: ../lib/rst/interp_float/write2d.c:53 ../lib/rst/interp_float/write2d.c:64
+#: ../lib/rst/interp_float/write2d.c:79 ../lib/rst/interp_float/write2d.c:88
+#: ../lib/rst/interp_float/write2d.c:96 ../lib/rst/interp_float/write2d.c:104
+#, fuzzy
+msgid "Cannot write files"
+#: ../lib/rst/interp_float/vinput2d.c:94
#, fuzzy, c-format
-msgid ""
-"DB connection <%s/%s> already exists. Re-run '%s' with '--%s' flag to "
-"overwrite existing settings."
+msgid "Vector map <%s> is not 3D"
-#: ../lib/db/dbmi_base/test/test_table.c:38
-msgid ""
-"\n"
-"++ Running table unit tests ++"
+#: ../lib/rst/interp_float/vinput2d.c:97
+msgid "Loading data from attribute table ..."
msgstr ""
-#: ../lib/db/dbmi_base/test/test_table.c:43
-msgid ""
-"\n"
-"-- Table unit tests failure --"
-msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:100 ../lib/vector/Vlib/array.c:276
+#: ../lib/vector/Vlib/copy.c:594 ../lib/vector/Vlib/copy.c:704
+#: ../lib/vector/Vlib/map.c:300 ../lib/vector/Vlib/map.c:436
+#: ../lib/vector/Vlib/net_build.c:159 ../lib/vector/Vlib/net_build.c:206
+#: ../lib/vector/Vlib/net_build.c:490 ../lib/vector/Vlib/net_build.c:791
+#: ../lib/vector/Vlib/net_build.c:971 ../lib/vector/Vlib/cats.c:589
+#: ../lib/vector/Vlib/ascii.c:398 ../lib/ogsf/gp3.c:202 ../lib/ogsf/gv3.c:344
+#, c-format
+msgid "Database connection not defined for layer %d"
+msgstr "레이어 %d를 위한 데이타베이스 접속이 정의되지 않았습니다"
-#: ../lib/db/dbmi_base/test/test_table.c:45
-msgid ""
-"\n"
-"-- Table unit tests finished successfully --"
-msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:109 ../lib/vector/Vlib/array.c:282
+#: ../lib/vector/Vlib/close_nat.c:160 ../lib/vector/Vlib/write_pg.c:2907
+#: ../lib/vector/Vlib/map.c:341 ../lib/vector/Vlib/net_build.c:165
+#: ../lib/vector/Vlib/net_build.c:211 ../lib/vector/Vlib/net_build.c:496
+#: ../lib/vector/Vlib/net_build.c:797 ../lib/vector/Vlib/net_build.c:976
+#: ../lib/vector/Vlib/cats.c:597 ../lib/vector/Vlib/ascii.c:410
+#: ../lib/vector/Vlib/write_ogr.c:197 ../lib/vector/neta/timetables.c:133
+#: ../lib/vector/neta/utils.c:119 ../lib/db/dbmi_client/db.c:46
+#: ../lib/db/dbmi_client/copy_tab.c:112 ../lib/db/dbmi_client/copy_tab.c:133
+#: ../lib/ogsf/gp3.c:208 ../lib/ogsf/gv3.c:350
+#, fuzzy, c-format
+msgid "Unable to open database <%s> by driver <%s>"
+msgstr "'%s' 디버그파일을 열 수 없습니다"
-#: ../lib/db/dbmi_base/test/test_main.c:83
-msgid "Performs unit and integration tests for the dbmi base library"
-msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:115
+#: ../lib/rst/interp_float/vinput2d.c:129 ../lib/db/dbmi_client/copy_tab.c:291
+#, fuzzy, c-format
+msgid "Column <%s> not found"
-#: ../lib/db/dbmi_base/test/test_columns.c:37
-msgid ""
-"\n"
-"++ Running column unit tests ++"
+#: ../lib/rst/interp_float/vinput2d.c:118
+#: ../lib/rst/interp_float/vinput2d.c:131
+#, c-format
+msgid "Data type of column <%s> must be numeric"
msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:42
-msgid ""
-"\n"
-"-- column unit tests failure --"
-msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:142
+#, fuzzy
+msgid "Reading features from vector map ..."
-#: ../lib/db/dbmi_base/test/test_columns.c:44
-msgid ""
-"\n"
-"-- column unit tests finished successfully --"
+#: ../lib/rst/interp_float/vinput2d.c:174
+#, c-format
+msgid "Database record for cat %d not found"
msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:57
-msgid ""
-"\n"
-"++ Run test copy column ++"
+#: ../lib/rst/interp_float/vinput2d.c:192
+msgid "Negative value of smoothing detected: sm must be >= 0"
msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:150
-msgid ""
-"\n"
-"++ Test copy column finished ++"
+#: ../lib/rst/interp_float/vinput2d.c:256
+msgid "Strip exists with insufficient data"
msgstr ""
-#: ../lib/db/dbmi_base/xdrvalue.c:82
-msgid "send data: invalid C-type"
+#: ../lib/rst/interp_float/vinput2d.c:270
+#, c-format
+msgid "There are points outside specified 2D/3D region - %d points ignored"
msgstr ""
-#: ../lib/db/dbmi_base/error.c:72
-msgid "<NULL error message>"
+#: ../lib/rst/interp_float/vinput2d.c:273
+#, c-format
+msgid "Ignoring %d points (too dense)"
msgstr ""
-#: ../lib/db/dbmi_base/error.c:91
-msgid "dbmi: Protocol error"
+#: ../lib/rst/interp_float/vinput2d.c:277
+#, c-format
+msgid ""
+"%d points given for interpolation (after thinning) is less than given NPMIN="
+"%d"
msgstr ""
-#: ../lib/db/dbmi_base/error.c:136
-msgid "dbmi: Out of Memory"
+#: ../lib/rst/interp_float/vinput2d.c:282
+msgid "Zero points in the given region"
msgstr ""
-#: ../lib/db/dbmi_base/error.c:149
+#: ../lib/rst/interp_float/vinput2d.c:287
#, c-format
-msgid "dbmi: %s() not implemented"
+msgid ""
+"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
+"smooth connection of segments, npmin > segmax (see manual)"
msgstr ""
-#: ../lib/db/dbmi_base/error.c:163
+#: ../lib/rst/interp_float/vinput2d.c:293
#, c-format
-msgid "dbmi: Invalid procedure %d"
+msgid ""
+"There are less than %d points for interpolation. No segmentation is "
+"necessary, to run the program faster set segmax=%d (see manual)"
msgstr ""
-#: ../lib/db/dbmi_base/xdrtable.c:109
-msgid "fetch: table has wrong number of columns"
-msgstr ""
-#: ../lib/db/dbmi_client/db.c:41 ../lib/db/dbmi_client/copy_tab.c:107
-#: ../lib/db/dbmi_client/copy_tab.c:127 ../lib/vector/Vlib/write_ogr.c:192
-#: ../lib/vector/Vlib/write_pg.c:2902 ../lib/vector/Vlib/ascii.c:404
+#: ../lib/rst/interp_float/vinput2d.c:297
#, fuzzy, c-format
-msgid "Unable to start driver <%s>"
+msgid "Number of points from vector map %d"
-#: ../lib/db/dbmi_client/table.c:46 ../lib/db/dbmi_client/delete_tab.c:40
+#: ../lib/rst/interp_float/vinput2d.c:298
#, fuzzy, c-format
-msgid "Unable open database <%s> by driver <%s>"
+msgid "Number of points outside of 2D/3D region %d"
-#: ../lib/db/dbmi_client/table.c:110 ../lib/db/dbmi_client/copy_tab.c:242
-#: ../lib/db/dbmi_client/copy_tab.c:319 ../lib/vector/Vlib/write_ogr.c:210
+#: ../lib/rst/interp_float/vinput2d.c:300
#, fuzzy, c-format
-msgid "Unable to open select cursor: '%s'"
+msgid "Number of points being used %d"
-#: ../lib/db/dbmi_client/copy_tab.c:91
-#, c-format
-msgid "Array of values to select from column <%s> is empty"
+#: ../lib/rst/interp_float/vinput2d.c:333
+msgid "Some points outside of region (ignored)"
msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:151
-#, fuzzy, c-format
-msgid "Unable to get list tables in database <%s>"
+#: ../lib/rst/interp_float/vinput2d.c:339
+#, fuzzy
+msgid "Unable to allocate memory"
-#: ../lib/db/dbmi_client/copy_tab.c:189
+#: ../lib/rst/interp_float/vinput2d.c:347
#, fuzzy, c-format
-msgid "Table <%s> already exists in database and will be overwritten"
+msgid "Unable to insert %f,%f,%f a = %d"
-#: ../lib/db/dbmi_client/copy_tab.c:194
-#, fuzzy, c-format
-msgid "Table <%s> already exists in database <%s>"
+#: ../lib/rst/interp_float/segmen2d.c:135
+msgid ""
+"Taking too long to find points for interpolation - please change the region "
+"to area where your points are. Continuing calculations..."
+msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:274
-#, fuzzy, c-format
-msgid "Column <%s> is not integer"
+#: ../lib/rst/interp_float/output2d.c:117
+#, c-format
+msgid "First change your rows number to nsizr! %d %d"
+msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:291 ../lib/rst/interp_float/vinput2d.c:115
-#: ../lib/rst/interp_float/vinput2d.c:129
-#, fuzzy, c-format
-msgid "Column <%s> not found"
+#: ../lib/rst/interp_float/output2d.c:124
+#, c-format
+msgid "First change your cols number to nsizc %d %d"
+msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:294
-#, fuzzy, c-format
-msgid "Unable to create table <%s>"
+#: ../lib/htmldriver/graph_set.c:97
+#, c-format
+msgid "html: collecting to file '%s'"
+msgstr "html: '%s' 파일로 모읍니다."
-#: ../lib/db/dbmi_client/copy_tab.c:338 ../lib/vector/Vlib/write_ogr.c:585
-#: ../lib/vector/Vlib/write_pg.c:2009
-#, fuzzy, c-format
-msgid "Unable to fetch data from table <%s>"
+#: ../lib/htmldriver/graph_set.c:98
+#, c-format
+msgid "html: image size %dx%d"
+msgstr "html: 그림크기 %dx%d"
-#: ../lib/db/dbmi_client/copy_tab.c:394
+#: ../lib/htmldriver/graph_set.c:111 ../lib/htmldriver/graph_set.c:115
+#: ../lib/htmldriver/graph_set.c:119
#, c-format
-msgid "Unknown column type (column <%s>)"
+msgid "html: type '%s'"
+msgstr "html: 타입 '%s'"
+#: ../lib/pngdriver/graph_set.c:101
+#, c-format
+msgid "png: truecolor status %s"
msgstr ""
-#: ../lib/db/dbmi_client/delete_tab.c:53
-#, fuzzy, c-format
-msgid "Unable to drop table: '%s'"
-#: ../lib/db/dbmi_client/select.c:119 ../lib/db/dbmi_client/select.c:221
-#: ../lib/db/dbmi_client/select.c:288
-msgid "Missing column name"
+#: ../lib/pngdriver/graph_set.c:149
+#, c-format
+msgid "png: collecting to file '%s'"
msgstr ""
-#: ../lib/db/dbmi_client/select.c:216 ../lib/db/dbmi_client/select.c:283
-msgid "Missing key column name"
+#: ../lib/pngdriver/graph_set.c:150
+#, c-format
+msgid "png: image size %dx%d"
msgstr ""
-#: ../lib/db/dbmi_client/select.c:317 ../lib/vector/Vlib/cats.c:603
-#, fuzzy, c-format
-msgid "Unable select records from table <%s>"
+#: ../lib/pngdriver/read_png.c:42
+#, fuzzy
+msgid "Unable to read PNG"
-#: ../lib/db/dbmi_client/select.c:333
+#: ../lib/pngdriver/read_png.c:60
#, fuzzy
-msgid "Key column type is not integer"
+msgid "Unable allocate PNG structure"
-#: ../lib/db/dbmi_driver/d_error.c:35
-#, c-format
-msgid "DBMI-%s driver error:"
-msgstr ""
-#: ../lib/nviz/lights.c:171
+#: ../lib/pngdriver/read_png.c:64 ../lib/pngdriver/write_png.c:71
+#: ../lib/pngdriver/write_png.c:75
#, fuzzy
-msgid "Unable to define new light"
+msgid "Unable to allocate PNG structure"
-#: ../lib/nviz/position.c:56
+#: ../lib/pngdriver/read_png.c:67
#, fuzzy
-msgid "Unable to set focus"
+msgid "Unable to read PNG file"
-#: ../lib/nviz/nviz.c:128
+#: ../lib/pngdriver/read_png.c:81
+msgid "Input PNG file is not 8-bit"
+msgstr ""
+#: ../lib/pngdriver/read_png.c:85
#, c-format
-msgid "Invalid color (%s), using \"white\" as default"
-msgstr "잘못된 색상(%s)입니다. \"white\"를 기본값으로 사용합니다."
+msgid "Input PNG file has incorrect dimensions: expected: %dx%d got: %lux%lu"
+msgstr ""
-#: ../lib/nviz/render.c:106
-msgid "Bad server connection"
-msgstr "서버접속 오류입니다."
+#: ../lib/pngdriver/read_png.c:90
+msgid "Input PNG file is not RGBA"
+msgstr ""
-#: ../lib/nviz/render.c:112
+#: ../lib/pngdriver/read_png.c:94
+msgid "Input PNG file is not indexed color"
+msgstr ""
+#: ../lib/pngdriver/read_png.c:104
+msgid "Input PNG file has invalid palette"
+msgstr ""
+#: ../lib/pngdriver/write_png.c:39
#, fuzzy
-msgid "Unable to get visual info"
+msgid "Unable to write PNG"
-#: ../lib/nviz/render.c:119
+#: ../lib/pngdriver/write_png.c:78
#, fuzzy
-msgid "Unable to create rendering context"
+msgid "Unable to write PNG file"
-#: ../lib/nviz/map_obj.c:59
-msgid "Maximum surfaces loaded!"
-msgstr "최대 표면 개수를 초과했습니다!"
+#: ../lib/pngdriver/write_png.c:82
+#, fuzzy, c-format
+msgid "Unable to open output PNG file <%s>"
-#: ../lib/nviz/map_obj.c:88
-msgid "Maximum vector line maps loaded!"
-msgstr "최대 선벡터맵 개수를 초과했습니다!"
+#: ../lib/temporal/lib/default_name.c:69
+msgid "Programmer error - only SQLite driver is currently supported"
+msgstr ""
-#: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
+#: ../lib/temporal/lib/connect.c:110
#, fuzzy, c-format
-msgid "Error loading vector map <%s>"
+msgid "Mapset <%s> does not exist."
-#: ../lib/nviz/map_obj.c:116
-msgid "Maximum vector point maps loaded!"
-msgstr "최대 점벡터지도 개수를 초과했습니다!"
+#: ../lib/raster3d/test/test_main.c:96
+#, fuzzy
+msgid "raster3d"
+msgstr "라스터"
-#: ../lib/nviz/map_obj.c:143
-msgid "Maximum volumes loaded!"
-msgstr "최대 부피를 초과했습니다!"
+#: ../lib/raster3d/test/test_main.c:97
+msgid "unit test"
+msgstr ""
-#: ../lib/nviz/map_obj.c:152
+#: ../lib/raster3d/close.c:47
#, fuzzy, c-format
-msgid "Error loading 3d raster map <%s>"
+msgid "Unable to write history for 3D raster map <%s>"
-#: ../lib/nviz/map_obj.c:160
-msgid "Nviz_new_map_obj(): unsupported data type"
-msgstr "Nviz_new_map_obj(): 지원하지 않는 자료형입니다."
+#: ../lib/raster3d/close.c:62
+#, fuzzy, c-format
+msgid "Unable to move temp raster map <%s> to 3D raster map <%s>"
-#: ../lib/manage/do_copy.c:43
+#: ../lib/raster3d/close.c:79
+#, fuzzy
+msgid "Unable to flush all tiles"
+#: ../lib/raster3d/close.c:84
+#, fuzzy
+msgid "Unable to flush index"
+#: ../lib/raster3d/close.c:94
+#, fuzzy
+msgid "Unable to position file"
+#: ../lib/raster3d/close.c:99 ../lib/raster3d/close.c:105
+#: ../lib/raster3d/close.c:191 ../lib/raster3d/header.c:217
#, fuzzy, c-format
-msgid "Copy %s <%s> to current mapset as <%s>"
-msgstr "<%s>를 현재 맵셋의 <%s>으로 복사합니다"
+msgid "Unable to write header for 3D raster map <%s>"
-#: ../lib/manage/do_copy.c:50 ../lib/manage/do_copy.c:67
+#: ../lib/raster3d/close.c:110 ../lib/raster3d/close.c:153
#, fuzzy, c-format
-msgid "Unable to copy <%s> to current mapset as <%s>"
-msgstr "<%s>를 현재 맵셋의 <%s>으로 복사 할 수 없습니다"
+msgid "Unable to create 3D raster map <%s>"
-#: ../lib/manage/do_copy.c:61 ../lib/manage/do_remove.c:89
-#: ../lib/manage/do_remove.c:109 ../lib/manage/do_rename.c:87
-#: ../lib/manage/do_rename.c:107
-#, c-format
-msgid "%s is missing"
-msgstr "%s이 없습니다"
+#: ../lib/raster3d/close.c:169
+msgid "Error in cache"
+msgstr ""
-#: ../lib/manage/do_copy.c:72
+#: ../lib/raster3d/history.c:43
#, c-format
-msgid "%s copied"
-msgstr "%s를 복사했습니다"
+msgid "can't get history information for [%s] in mapset [%s]"
+msgstr ""
-#: ../lib/manage/do_remove.c:42
-#, c-format
-msgid "Removing %s <%s>"
-msgstr "%s <%s>를 지우는 중입니다"
+#: ../lib/raster3d/open.c:20
+msgid "Rast3d_open_cell_old_no_header: error in Rast3d_mask_open_old"
+msgstr ""
-#: ../lib/manage/do_remove.c:65
-msgid "Unable to delete vector map"
-msgstr "벡터맵을 지울 수 없습니다"
+#: ../lib/raster3d/open.c:26
+msgid "Rast3d_open_cell_old_no_header: error in Rast3d_malloc"
+msgstr ""
-#: ../lib/manage/do_remove.c:85
-#, c-format
-msgid "Unable to remove %s element"
-msgstr "%s 요소를 지울 수 없습니다"
+#: ../lib/raster3d/open.c:37
+msgid "Rast3d_open_cell_old_no_header: error in G_open_old"
+msgstr ""
-#: ../lib/manage/do_remove.c:92 ../lib/manage/do_remove.c:112
-#, c-format
-msgid "%s removed"
-msgstr "%s를 지웠습니다"
+#: ../lib/raster3d/open.c:93
+msgid "Rast3d_open_cell_old: error in Rast3d_open_cell_old_no_header"
+msgstr ""
-#: ../lib/manage/do_remove.c:105
-#, c-format
-msgid "Unable to remove %s"
-msgstr "%s를 지울 수 없습니다"
+#: ../lib/raster3d/open.c:98
+msgid "Rast3d_open_cell_old: can't rewind file"
+msgstr ""
-#: ../lib/manage/do_remove.c:121
-#, c-format
-msgid "<%s> nothing removed"
-msgstr "<%s> 아무 것도 지우지 않았습니다"
+#: ../lib/raster3d/open.c:111
+msgid "Rast3d_open_cell_old: error in Rast3d_read_header"
+msgstr ""
-#: ../lib/manage/do_list.c:30
-#, c-format
-msgid "%s: invalid index %d"
+#: ../lib/raster3d/open.c:119
+msgid "Rast3d_open_cell_old: projection does not match window projection"
msgstr ""
-#: ../lib/manage/option.c:47
-#, c-format
-msgid "%s to be %s"
+#: ../lib/raster3d/open.c:123
+msgid "Rast3d_open_cell_old: zone does not match window zone"
msgstr ""
-#: ../lib/manage/option.c:51
-msgid "Raster"
-msgstr "라스터"
+#: ../lib/raster3d/open.c:135 ../lib/raster3d/open.c:152
+msgid "Rast3d_open_cell_old: can't read header"
+msgstr ""
-#: ../lib/manage/option.c:53
-msgid "Vector"
-msgstr "벡터"
+#: ../lib/raster3d/open.c:141
+msgid "Rast3d_open_cell_old: index does not fit into long"
+msgstr ""
-#: ../lib/manage/option.c:55
-msgid "Region"
-msgstr "지역"
+#: ../lib/raster3d/open.c:145
+msgid "Rast3d_open_cell_old: error in Rast3d_malloc"
+msgstr ""
-#: ../lib/manage/option.c:57
-msgid "Group"
-msgstr "그룹"
+#: ../lib/raster3d/open.c:172
+msgid "Rast3d_open_cell_old: error in Rast3d_fill_header"
+msgstr ""
-#: ../lib/manage/read_list.c:73
-#, fuzzy, c-format
-msgid "Unable to open data base element list '%s'"
-msgstr "데이타의 기본요소목록 '%s'를 열 수 없습니다"
+#: ../lib/raster3d/open.c:219
+msgid "Rast3d_open_cell_new: error in Rast3d_mask_open_old"
+msgstr ""
-#: ../lib/manage/read_list.c:134
-#, c-format
-msgid "Format error: file ('%s') line (%d) - %s"
+#: ../lib/raster3d/open.c:228
+msgid "Rast3d_open_cell_new: error in Rast3d_malloc"
msgstr ""
-#: ../lib/manage/do_rename.c:42
+#: ../lib/raster3d/open.c:233
#, fuzzy, c-format
-msgid "Rename %s <%s> to <%s>"
-msgstr "<%s>를 <%s>으로 이름을 바꿉니다"
+msgid "map <%s> is not in the current mapset"
-#: ../lib/manage/do_rename.c:62
-#, fuzzy, c-format
-msgid "Unable to rename vector map <%s> to <%s>"
-msgstr "벡터맵 <%s>의 이름을 <%s>으로 바꾸지 못 했습니다"
+#: ../lib/raster3d/open.c:243
+msgid "Rast3d_open_cell_new: could not open file"
+msgstr ""
-#: ../lib/manage/do_rename.c:83 ../lib/manage/do_rename.c:103
-#, fuzzy, c-format
-msgid "Unable to rename %s"
-msgstr "%s의 이름을 바꾸지 못 했습니다"
+#: ../lib/raster3d/open.c:287 ../lib/raster3d/open.c:292
+msgid "Rast3d_open_cell_new: can't write header"
+msgstr ""
-#: ../lib/manage/do_rename.c:90 ../lib/manage/do_rename.c:110
-#, c-format
-msgid "%s renamed"
-msgstr "%s의 이름을 바꾸었습니다"
+#: ../lib/raster3d/open.c:314
+msgid "Rast3d_open_cell_new: error in Rast3d_fill_header"
+msgstr ""
-#: ../lib/manage/do_rename.c:119
+#: ../lib/raster3d/color.c:354
#, c-format
-msgid "<%s> nothing renamed"
-msgstr "<%s> 어떤 이름도 바꾸지 않았습니다"
+msgid "mapset <%s> is not the current mapset"
+msgstr ""
-#: ../lib/raster/color_write.c:81 ../lib/vector/Vlib/color_write.c:71
+#: ../lib/raster3d/maskfn.c:77
#, c-format
-msgid "Qualified name <%s> doesn't match mapset <%s>"
+msgid "Adding rule: %lf - %lf"
msgstr ""
-#: ../lib/raster/color_write.c:96 ../lib/vector/Vlib/color_write.c:91
+#: ../lib/raster3d/maskfn.c:95
#, fuzzy, c-format
-msgid "Unable to create <%s> file for map <%s>"
+msgid "%s: illegal value spec"
+msgstr "잘못된 row 값"
+#: ../lib/raster3d/range.c:73
+#, fuzzy, c-format
+msgid "Unable to open range file for [%s in %s]"
-#: ../lib/raster/mask_info.c:43
-#, c-format
-msgid "<%s> in mapset <%s>"
+#: ../lib/raster3d/range.c:88
+#, fuzzy, c-format
+msgid "Error reading range file for [%s in %s]"
+#: ../lib/raster3d/range.c:150
+#, fuzzy, c-format
+msgid "Unable to open range file for <%s>"
+#: ../lib/raster3d/param.c:84
+msgid "Rast3d_get_standard3d_params: precision value invalid"
msgstr ""
-#: ../lib/raster/mask_info.c:46
-msgid "none"
+#: ../lib/raster3d/param.c:105
+msgid "Rast3d_get_standard3d_params: tile dimension value invalid"
msgstr ""
-#: ../lib/raster/mask_info.c:49
-msgid "not known"
+#: ../lib/raster3d/param.c:129
+msgid "Window replacing the default"
msgstr ""
+#: ../lib/raster/put_cellhd.c:34
+#, fuzzy, c-format
+msgid "Unable to create header file for <%s>"
+#: ../lib/raster/quant_rw.c:88
+#, fuzzy, c-format
+msgid "Unable to read fp range for raster map <%s>"
+#: ../lib/raster/quant_rw.c:92
+#, fuzzy, c-format
+msgid "Raster map <%s> is empty"
+#: ../lib/raster/quant_rw.c:157
+#, fuzzy, c-format
+msgid "Unable to write quant rules: raster map <%s> is integer"
+#: ../lib/raster/quant_rw.c:166
+#, fuzzy, c-format
+msgid "Unable to write quant rules for raster map <%s>"
#: ../lib/raster/reclass.c:168
#, fuzzy, c-format
msgid "Too many reclass categories for <%s@%s>"
@@ -3391,184 +3203,193 @@
msgid "Unable to create dependency file in <%s@%s>"
-#: ../lib/raster/init.c:61
-msgid "Raster library not initialized. Programmer forgot to call Rast_init()."
-msgstr ""
-#: ../lib/raster/init.c:109
-#, c-format
-msgid "Unknown compression method <%s>, using default ZLIB"
-msgstr ""
-#: ../lib/raster/init.c:113
-msgid ""
-"No compression is not supported for GRASS raster maps, using default ZLIB"
-msgstr ""
-#: ../lib/raster/init.c:118
-#, c-format
-msgid "This GRASS version does not support %s compression, using default ZLIB"
-msgstr ""
-#: ../lib/raster/range.c:102
+#: ../lib/raster/close.c:77 ../lib/raster/close.c:110
#, fuzzy, c-format
-msgid "Unable to read fp range file for <%s>"
-msgstr "'%s' 디버그파일을 열 수 없습니다"
+msgid "Invalid descriptor: %d"
-#: ../lib/raster/range.c:169
+#: ../lib/raster/close.c:391 ../lib/raster/close.c:519
#, fuzzy, c-format
-msgid "Unable to read quant rules for raster map <%s>"
+msgid "Unable to rename null file '%s' to '%s': %s"
-#: ../lib/raster/range.c:206 ../lib/raster/range.c:226
+#: ../lib/raster/close.c:461
#, fuzzy, c-format
-msgid "Unable to read range file for <%s>"
+msgid "Unable to rename cell file '%s' to '%s': %s"
-#: ../lib/raster/range.c:264 ../lib/raster/range.c:270
-#: ../lib/raster/range.c:300 ../lib/raster/range.c:314
-#, fuzzy, c-format
-msgid "Unable to write range file for <%s>"
+#: ../lib/raster/close.c:541
+msgid "unable to write f_format file for CELL maps"
+msgstr ""
-#: ../lib/raster/raster_metadata.c:109
-#, fuzzy, c-format
-msgid "Unable to read <%s> for raster map <%s@%s>"
+#: ../lib/raster/color_write.c:81 ../lib/vector/Vlib/color_write.c:71
+#, c-format
+msgid "Qualified name <%s> doesn't match mapset <%s>"
+msgstr ""
-#: ../lib/raster/raster_metadata.c:119 ../lib/raster/raster_metadata.c:148
+#: ../lib/raster/color_write.c:96 ../lib/vector/Vlib/color_write.c:91
#, fuzzy, c-format
-msgid "Error closing <%s> metadata file for raster map <%s@%s>"
+msgid "Unable to create <%s> file for map <%s>"
-#: ../lib/raster/raster_metadata.c:142
-#, fuzzy, c-format
-msgid "Unable to create <%s> metadata file for raster map <%s@%s>"
+#: ../lib/raster/color_rand.c:33
+#, c-format
+msgid "Rast_make_random_colors: min (%d) > max (%d)"
+msgstr ""
-#: ../lib/raster/put_row.c:121
-#, fuzzy, c-format
-msgid "Error writing uncompressed FP data for row %d of <%s>: %s"
-msgstr "맵 [%s], 맵셑 [%s]을(를) 위한 분류지원: %s"
+#: ../lib/raster/histogram.c:55
+#, c-format
+msgid "Histogram for [%s in %s] missing (run r.support)"
+msgstr ""
-#: ../lib/raster/put_row.c:131
-#, fuzzy, c-format
-msgid "Error writing compressed FP data for row %d of <%s>: %s"
+#: ../lib/raster/histogram.c:62
+#, c-format
+msgid "Can't read histogram for [%s in %s]"
+msgstr ""
-#: ../lib/raster/put_row.c:387 ../lib/raster/put_row.c:393
-#, fuzzy, c-format
-msgid "Error writing compressed data for row %d of <%s>"
+#: ../lib/raster/histogram.c:66 ../lib/raster/histogram.c:73
+#, c-format
+msgid "Invalid histogram file for [%s in %s]"
+msgstr ""
-#: ../lib/raster/put_row.c:403
+#: ../lib/raster/histogram.c:331
#, fuzzy, c-format
-msgid "Error writing uncompressed data for row %d of <%s>"
+msgid "Unable to create histogram file for <%s>"
-#: ../lib/raster/put_row.c:462
-#, fuzzy, c-format
-msgid "Error writing data via GDAL for row %d of <%s>"
-msgstr "임시파일을 열 수 없습니다"
-#: ../lib/raster/put_row.c:486
-msgid "GDAL output doesn't support writing null rows separately"
+#: ../lib/raster/alloc_cell.c:151
+#, c-format
+msgid "Rast__null_bitstream_size: cols (%d) is negative"
msgstr ""
-#: ../lib/raster/put_row.c:489
+#: ../lib/raster/history.c:115 ../lib/raster/history.c:123
#, fuzzy, c-format
-msgid "No null file for <%s>"
+msgid "Unable to get history information for <%s@%s>"
-#: ../lib/raster/put_row.c:513 ../lib/raster/put_row.c:518
+#: ../lib/raster/history.c:162
#, fuzzy, c-format
-msgid "Error writing compressed null data for row %d of <%s>"
+msgid "Unable to write history information for <%s>"
-#: ../lib/raster/put_row.c:552 ../lib/raster/put_row.c:555
+#: ../lib/raster/history.c:235
+#, c-format
+msgid "generated by %s"
+msgstr ""
+#: ../lib/raster/interp.c:211
#, fuzzy, c-format
-msgid "Error writing null row %d of <%s>"
+msgid "Unknown interpolation method: %s"
+msgstr "알려지지 않은 벡터타입입니다"
-#: ../lib/raster/put_row.c:680
-#, c-format
-msgid "put_raster_row: raster map <%s> not open for write - request ignored"
+#: ../lib/raster/color_read.c:103
+msgid "missing"
msgstr ""
-#: ../lib/raster/put_row.c:687
-msgid "put_raster_row: unopened file descriptor - request ignored"
+#: ../lib/raster/color_read.c:106
+msgid "invalid"
msgstr ""
-#: ../lib/raster/get_cellhd.c:66
+#: ../lib/raster/color_read.c:112
#, fuzzy, c-format
+msgid "Color support for <%s@%s> %s"
+msgstr "맵 [%s], 맵셑 [%s]을(를) 위한 색상지원: %s"
+#: ../lib/raster/window.c:31
msgid ""
-"Unable to read header file for raster map <%s@%s>. It is a reclass of raster "
-"map <%s@%s> %s"
-msgstr "Datum %s 테이블파일을 열 수 없습니다"
+"Internal error: Rast_get_window() called with split window. Use "
+"Rast_get_input_window() or Rast_get_output_window() instead."
+msgstr ""
-#: ../lib/raster/get_cellhd.c:70
-msgid "which is missing."
+#: ../lib/raster/window.c:90
+msgid ""
+"Internal error: Rast_window_rows() called with split window. Use "
+"Rast_input_window_rows() or Rast_output_window_rows() instead."
msgstr ""
-#: ../lib/raster/get_cellhd.c:71
-msgid "whose header file can't be opened."
+#: ../lib/raster/window.c:125
+msgid ""
+"Internal error: Rast_window_cols() called with split window. Use "
+"Rast_input_window_cols() or Rast_output_window_cols() instead."
msgstr ""
-#: ../lib/raster/get_cellhd.c:76
+#: ../lib/raster/gdal.c:88
#, fuzzy, c-format
-msgid "Unable to open header file for raster map <%s@%s>"
+msgid "Unable to locate symbol <%s>"
+msgstr "Datum %s 테이블파일을 열 수 없습니다"
+#: ../lib/raster/gdal.c:142
+#, fuzzy
+msgid "Unable to load GDAL library"
-#: ../lib/raster/quant_io.c:43
-#, fuzzy, c-format
-msgid "Floating data range for raster map <%s> is empty"
+#: ../lib/raster/gdal.c:372
+#, fuzzy
+msgid "Unable to open GDAL file"
-#: ../lib/raster/quant_io.c:52
+#: ../lib/raster/gdal.c:476 ../lib/raster/open.c:599
#, fuzzy, c-format
-msgid "Integer data range for raster map <%s> is empty"
+msgid "Invalid map type <%d>"
-#: ../lib/raster/quant_io.c:105
+#: ../lib/raster/gdal.c:482
#, fuzzy, c-format
-msgid "Attempt to open quantization table for CELL raster map <%s>"
+msgid "Unable to get <%s> driver"
-#: ../lib/raster/quant_io.c:135
+#: ../lib/raster/gdal.c:491
#, fuzzy, c-format
-msgid "Quantization file for raster map <%s> is missing"
+msgid "Unable to create <%s> dataset using <%s> driver"
-#: ../lib/raster/quant_io.c:145
-#, fuzzy, c-format
-msgid "Quantization file for raster map <%s> is empty"
-#: ../lib/raster/alloc_cell.c:151
+#: ../lib/raster/gdal.c:499
#, c-format
-msgid "Rast__null_bitstream_size: cols (%d) is negative"
+msgid ""
+"Driver <%s> does not support direct writing. Using MEM driver for "
+"intermediate dataset."
msgstr ""
-#: ../lib/raster/histogram.c:55
-#, c-format
-msgid "Histogram for [%s in %s] missing (run r.support)"
-msgstr ""
+#: ../lib/raster/gdal.c:505
+#, fuzzy
+msgid "Unable to get in-memory raster driver"
-#: ../lib/raster/histogram.c:62
-#, c-format
-msgid "Can't read histogram for [%s in %s]"
-msgstr ""
+#: ../lib/raster/gdal.c:512
+#, fuzzy, c-format
+msgid "Unable to create <%s> dataset using memory driver"
-#: ../lib/raster/histogram.c:66 ../lib/raster/histogram.c:73
+#: ../lib/raster/gdal.c:516
#, c-format
-msgid "Invalid histogram file for [%s in %s]"
+msgid "Driver <%s> does not support creating rasters"
msgstr ""
-#: ../lib/raster/histogram.c:331
+#: ../lib/raster/gdal.c:532
+#, fuzzy
+msgid "Unable to set geo transform"
+#: ../lib/raster/gdal.c:536
+#, fuzzy
+msgid "Unable to set projection"
+#: ../lib/raster/gdal.c:540
#, fuzzy, c-format
-msgid "Unable to create histogram file for <%s>"
+msgid "Unable to create cell_misc/%s/gdal file"
+#: ../lib/raster/gdal.c:556
+#, fuzzy, c-format
+msgid "Error writing cell_misc/%s/gdal file"
+#: ../lib/raster/gdal.c:604
+#, fuzzy, c-format
+msgid "Unable to create output file <%s> using driver <%s>"
#: ../lib/raster/open.c:193
#, c-format
msgid ""
@@ -3634,11 +3455,6 @@
msgid "Unable to create GDAL link"
-#: ../lib/raster/open.c:599 ../lib/raster/gdal.c:476
-#, fuzzy, c-format
-msgid "Invalid map type <%d>"
#: ../lib/raster/open.c:604 ../lib/raster/open.c:759
#, c-format
msgid "Raster map <%s> is not in the current mapset (%s)"
@@ -3695,150 +3511,210 @@
"Rast_set_quant_rules() can be called only for raster maps opened for reading"
msgstr ""
-#: ../lib/raster/color_rand.c:33
+#: ../lib/raster/set_window.c:48
+msgid "Rast_set_window() called while window split"
+msgstr ""
+#: ../lib/raster/set_window.c:131
+msgid ""
+"Rast_set_read_window(): projection/zone differs from that of currently open "
+"raster maps"
+msgstr ""
+#: ../lib/raster/set_window.c:158
#, c-format
-msgid "Rast_make_random_colors: min (%d) > max (%d)"
+msgid "Input window changed while maps are open for read. Map name <%s>"
msgstr ""
-#: ../lib/raster/quant_rw.c:88
+#: ../lib/raster/set_window.c:174
+#, c-format
+msgid "Output window changed while maps are open for write. Map name <%s>"
+msgstr ""
+#: ../lib/raster/cats.c:109
#, fuzzy, c-format
-msgid "Unable to read fp range for raster map <%s>"
+msgid "Category support for <%s@%s> missing"
+msgstr "맵 [%s], 맵셑 [%s]을(를) 위한 분류지원: %s"
-#: ../lib/raster/quant_rw.c:92
+#: ../lib/raster/cats.c:112
#, fuzzy, c-format
-msgid "Raster map <%s> is empty"
+msgid "Category support for <%s@%s> invalid"
+#: ../lib/raster/cats.c:145
+#, fuzzy, c-format
+msgid "Category support for vector map <%s@%s> missing"
+msgstr "벡터맵 [%s], 맵셑 [%s]을(를) 위한 분류지원: %s"
+#: ../lib/raster/cats.c:149
+#, fuzzy, c-format
+msgid "Category support for vector map <%s@%s> invalid"
+#: ../lib/raster/cats.c:968
+#, fuzzy, c-format
+msgid "Unable to open %s file for map <%s>"
-#: ../lib/raster/quant_rw.c:157
+#: ../lib/raster/format.c:162
+#, c-format
+msgid "Fail of initial read of compressed file [%s in %s]"
+msgstr ""
+#: ../lib/raster/format.c:176
+#, c-format
+msgid "Fail of initial read of compressed null file [%s in %s]"
+msgstr ""
+#: ../lib/raster/get_row.c:36 ../lib/raster/get_row.c:898
+#, c-format
+msgid "Reading raster map <%s@%s> request for row %d is outside region"
+msgstr ""
+#: ../lib/raster/get_row.c:95 ../lib/raster/get_row.c:137
+#: ../lib/raster/get_row.c:144 ../lib/raster/get_row.c:187
+#: ../lib/raster/get_row.c:191
#, fuzzy, c-format
-msgid "Unable to write quant rules: raster map <%s> is integer"
+msgid "Error reading raster data for row %d of <%s>"
-#: ../lib/raster/quant_rw.c:166
+#: ../lib/raster/get_row.c:102 ../lib/raster/get_row.c:168
#, fuzzy, c-format
-msgid "Unable to write quant rules for raster map <%s>"
+msgid "Error uncompressing raster data for row %d of <%s>"
-#: ../lib/raster/close.c:77 ../lib/raster/close.c:110
+#: ../lib/raster/get_row.c:227
#, fuzzy, c-format
-msgid "Invalid descriptor: %d"
+msgid "Error reading raster data via GDAL for row %d of <%s>"
-#: ../lib/raster/close.c:391 ../lib/raster/close.c:519
+#: ../lib/raster/get_row.c:827 ../lib/raster/get_row.c:832
+#: ../lib/raster/get_row.c:842
#, fuzzy, c-format
-msgid "Unable to rename null file '%s' to '%s': %s"
+msgid "Error reading null data for row %d of <%s>"
-#: ../lib/raster/close.c:461
+#: ../lib/raster/get_row.c:848
#, fuzzy, c-format
-msgid "Unable to rename cell file '%s' to '%s': %s"
+msgid "Error uncompressing null data for row %d of <%s>"
-#: ../lib/raster/close.c:541
-msgid "unable to write f_format file for CELL maps"
+#: ../lib/raster/get_row.c:882 ../lib/raster/get_row.c:885
+#, fuzzy, c-format
+msgid "Error reading null row %d for <%s>"
+#: ../lib/raster/color_rules.c:120
+msgid "syntax error in the color rule"
msgstr ""
-#: ../lib/raster/interp.c:211
-#, fuzzy, c-format
-msgid "Unknown interpolation method: %s"
-msgstr "알려지지 않은 벡터타입입니다"
+#: ../lib/raster/color_rules.c:122
+msgid "syntax error in the color format"
+msgstr ""
-#: ../lib/raster/color_read.c:103
-msgid "missing"
+#: ../lib/raster/color_rules.c:130
+msgid "percentage not in range 0-100"
msgstr ""
-#: ../lib/raster/color_read.c:106
-msgid "invalid"
+#: ../lib/raster/color_rules.c:132
+msgid "invalid value"
msgstr ""
-#: ../lib/raster/color_read.c:112
-#, fuzzy, c-format
-msgid "Color support for <%s@%s> %s"
-msgstr "맵 [%s], 맵셑 [%s]을(를) 위한 색상지원: %s"
+#: ../lib/raster/color_rules.c:134
+msgid "unknown error"
+msgstr ""
-#: ../lib/raster/gdal.c:88
+#: ../lib/raster/color_rules.c:180
+#, c-format
+msgid "bad rule (%s): [%s]"
+msgstr ""
+#: ../lib/raster/color_rules.c:327
#, fuzzy, c-format
-msgid "Unable to locate symbol <%s>"
+msgid "Unable to load color rules <%s>"
-#: ../lib/raster/gdal.c:142
-#, fuzzy
-msgid "Unable to load GDAL library"
-#: ../lib/raster/gdal.c:372
-#, fuzzy
-msgid "Unable to open GDAL file"
+#: ../lib/raster/raster_metadata.c:109
+#, fuzzy, c-format
+msgid "Unable to read <%s> for raster map <%s@%s>"
-#: ../lib/raster/gdal.c:482
+#: ../lib/raster/raster_metadata.c:119 ../lib/raster/raster_metadata.c:148
#, fuzzy, c-format
-msgid "Unable to get <%s> driver"
+msgid "Error closing <%s> metadata file for raster map <%s@%s>"
-#: ../lib/raster/gdal.c:491
+#: ../lib/raster/raster_metadata.c:142
#, fuzzy, c-format
-msgid "Unable to create <%s> dataset using <%s> driver"
+msgid "Unable to create <%s> metadata file for raster map <%s@%s>"
-#: ../lib/raster/gdal.c:499
-#, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
-msgstr ""
+#: ../lib/raster/put_row.c:121
+#, fuzzy, c-format
+msgid "Error writing uncompressed FP data for row %d of <%s>: %s"
-#: ../lib/raster/gdal.c:505
-#, fuzzy
-msgid "Unable to get in-memory raster driver"
-msgstr "자동 MASK파일을 열 수 없습니다"
+#: ../lib/raster/put_row.c:131
+#, fuzzy, c-format
+msgid "Error writing compressed FP data for row %d of <%s>: %s"
-#: ../lib/raster/gdal.c:512
+#: ../lib/raster/put_row.c:387 ../lib/raster/put_row.c:393
#, fuzzy, c-format
-msgid "Unable to create <%s> dataset using memory driver"
+msgid "Error writing compressed data for row %d of <%s>"
-#: ../lib/raster/gdal.c:516
-#, c-format
-msgid "Driver <%s> does not support creating rasters"
-msgstr ""
+#: ../lib/raster/put_row.c:403
+#, fuzzy, c-format
+msgid "Error writing uncompressed data for row %d of <%s>"
-#: ../lib/raster/gdal.c:532
-#, fuzzy
-msgid "Unable to set geo transform"
+#: ../lib/raster/put_row.c:462
+#, fuzzy, c-format
+msgid "Error writing data via GDAL for row %d of <%s>"
-#: ../lib/raster/gdal.c:536
-#, fuzzy
-msgid "Unable to set projection"
+#: ../lib/raster/put_row.c:486
+msgid "GDAL output doesn't support writing null rows separately"
+msgstr ""
-#: ../lib/raster/gdal.c:540
+#: ../lib/raster/put_row.c:489
#, fuzzy, c-format
-msgid "Unable to create cell_misc/%s/gdal file"
+msgid "No null file for <%s>"
-#: ../lib/raster/gdal.c:556
+#: ../lib/raster/put_row.c:513 ../lib/raster/put_row.c:518
#, fuzzy, c-format
-msgid "Error writing cell_misc/%s/gdal file"
+msgid "Error writing compressed null data for row %d of <%s>"
-#: ../lib/raster/gdal.c:604
+#: ../lib/raster/put_row.c:552 ../lib/raster/put_row.c:555
#, fuzzy, c-format
-msgid "Unable to create output file <%s> using driver <%s>"
+msgid "Error writing null row %d of <%s>"
-#: ../lib/raster/format.c:162
+#: ../lib/raster/put_row.c:680
#, c-format
-msgid "Fail of initial read of compressed file [%s in %s]"
+msgid "put_raster_row: raster map <%s> not open for write - request ignored"
msgstr ""
-#: ../lib/raster/format.c:176
+#: ../lib/raster/put_row.c:687
+msgid "put_raster_row: unopened file descriptor - request ignored"
+msgstr ""
+#: ../lib/raster/mask_info.c:43
#, c-format
-msgid "Fail of initial read of compressed null file [%s in %s]"
+msgid "<%s> in mapset <%s>"
msgstr ""
+#: ../lib/raster/mask_info.c:46
+msgid "none"
+msgstr ""
+#: ../lib/raster/mask_info.c:49
+msgid "not known"
+msgstr ""
#: ../lib/raster/sample.c:70
msgid "Unknown interpolation type"
msgstr ""
@@ -3847,6 +3723,51 @@
msgid "\"no data\" label found; setting to zero"
msgstr ""
+#: ../lib/raster/get_cellhd.c:66
+#, fuzzy, c-format
+msgid ""
+"Unable to read header file for raster map <%s@%s>. It is a reclass of raster "
+"map <%s@%s> %s"
+#: ../lib/raster/get_cellhd.c:70
+msgid "which is missing."
+msgstr ""
+#: ../lib/raster/get_cellhd.c:71
+msgid "whose header file can't be opened."
+msgstr ""
+#: ../lib/raster/get_cellhd.c:76
+#, fuzzy, c-format
+msgid "Unable to open header file for raster map <%s@%s>"
+#: ../lib/raster/range.c:102
+#, fuzzy, c-format
+msgid "Unable to read fp range file for <%s>"
+#: ../lib/raster/range.c:169
+#, fuzzy, c-format
+msgid "Unable to read quant rules for raster map <%s>"
+#: ../lib/raster/range.c:206 ../lib/raster/range.c:226
+#, fuzzy, c-format
+msgid "Unable to read range file for <%s>"
+#: ../lib/raster/range.c:264 ../lib/raster/range.c:270
+#: ../lib/raster/range.c:300 ../lib/raster/range.c:314
+#, fuzzy, c-format
+msgid "Unable to write range file for <%s>"
+#: ../lib/raster/auto_mask.c:69
+msgid "Unable to open automatic MASK file"
+msgstr "자동 MASK 파일을 열 수 없습니다."
#: ../lib/raster/put_title.c:28
#, c-format
msgid "category information for [%s] in [%s] missing or invalid"
@@ -3870,1949 +3791,2949 @@
msgid "can't write category information for [%s] in [%s]"
msgstr ""
-#: ../lib/raster/color_rules.c:120
-msgid "syntax error in the color rule"
+#: ../lib/raster/init.c:61
+msgid "Raster library not initialized. Programmer forgot to call Rast_init()."
msgstr ""
-#: ../lib/raster/color_rules.c:122
-msgid "syntax error in the color format"
+#: ../lib/raster/init.c:109
+#, c-format
+msgid "Unknown compression method <%s>, using default ZLIB"
msgstr ""
-#: ../lib/raster/color_rules.c:130
-msgid "percentage not in range 0-100"
+#: ../lib/raster/init.c:113
+msgid ""
+"No compression is not supported for GRASS raster maps, using default ZLIB"
msgstr ""
-#: ../lib/raster/color_rules.c:132
-msgid "invalid value"
+#: ../lib/raster/init.c:118
+#, c-format
+msgid "This GRASS version does not support %s compression, using default ZLIB"
msgstr ""
-#: ../lib/raster/color_rules.c:134
-msgid "unknown error"
-msgstr ""
+#: ../lib/raster/quant_io.c:43
+#, fuzzy, c-format
+msgid "Floating data range for raster map <%s> is empty"
-#: ../lib/raster/color_rules.c:180
-#, c-format
-msgid "bad rule (%s): [%s]"
-msgstr ""
+#: ../lib/raster/quant_io.c:52
+#, fuzzy, c-format
+msgid "Integer data range for raster map <%s> is empty"
-#: ../lib/raster/color_rules.c:327
+#: ../lib/raster/quant_io.c:105
#, fuzzy, c-format
-msgid "Unable to load color rules <%s>"
+msgid "Attempt to open quantization table for CELL raster map <%s>"
-#: ../lib/raster/history.c:115 ../lib/raster/history.c:123
+#: ../lib/raster/quant_io.c:135
#, fuzzy, c-format
-msgid "Unable to get history information for <%s@%s>"
+msgid "Quantization file for raster map <%s> is missing"
-#: ../lib/raster/history.c:162
+#: ../lib/raster/quant_io.c:145
#, fuzzy, c-format
-msgid "Unable to write history information for <%s>"
+msgid "Quantization file for raster map <%s> is empty"
-#: ../lib/raster/history.c:235
+#: ../lib/raster/null_val.c:64
+msgid "EmbedGivenNulls: wrong data type"
+msgstr ""
+#: ../lib/raster/null_val.c:114
+msgid "Rast_set_null_value: wrong data type!"
+msgstr ""
+#: ../lib/display/tran_colr.c:107 ../lib/display/tran_colr.c:109
#, c-format
-msgid "generated by %s"
+msgid "[%s]: No such color"
msgstr ""
-#: ../lib/raster/cats.c:109
-#, fuzzy, c-format
-msgid "Category support for <%s@%s> missing"
+#: ../lib/display/r_raster.c:98
+#, c-format
+msgid "Both %s and %s are defined. %s will be ignored."
+msgstr ""
-#: ../lib/raster/cats.c:112
+#: ../lib/display/r_raster.c:131
+#, c-format
+msgid ""
+"Neither %s (managed by d.mon command) nor %s (used for direct rendering) "
+"defined"
+msgstr ""
+#: ../lib/display/r_raster.c:150
#, fuzzy, c-format
-msgid "Category support for <%s@%s> invalid"
+msgid "Unknown display driver <%s>"
-#: ../lib/raster/cats.c:145
+#: ../lib/display/r_raster.c:151
#, fuzzy, c-format
-msgid "Category support for vector map <%s@%s> missing"
-msgstr "벡터맵 [%s], 맵셑 [%s]을(를) 위한 분류지원: %s"
+msgid "Using display driver <%s>..."
-#: ../lib/raster/cats.c:149
+#: ../lib/display/icon.c:80
#, fuzzy, c-format
-msgid "Category support for vector map <%s@%s> invalid"
+msgid "Unsupported icon %d"
-#: ../lib/raster/cats.c:968
+#: ../lib/vector/diglib/port_init.c:158
#, fuzzy, c-format
-msgid "Unable to open %s file for map <%s>"
+msgid "Unable to find '%x' in %s"
-#: ../lib/raster/get_row.c:36 ../lib/raster/get_row.c:898
+#: ../lib/vector/diglib/plus_area.c:215 ../lib/vector/diglib/plus_area.c:711
#, c-format
-msgid "Reading raster map <%s@%s> request for row %d is outside region"
+msgid "Line %d already has area/isle %d to left"
msgstr ""
-#: ../lib/raster/get_row.c:95 ../lib/raster/get_row.c:137
-#: ../lib/raster/get_row.c:144 ../lib/raster/get_row.c:187
-#: ../lib/raster/get_row.c:191
+#: ../lib/vector/diglib/plus_area.c:225 ../lib/vector/diglib/plus_area.c:719
+#, c-format
+msgid "Line %d already has area/isle %d to right"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:279
+msgid "Isle already registered in area"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:313
+msgid "Attempt to delete isle from dead area"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:330
+#, c-format
+msgid "Attempt to delete not registered isle %d from area %d"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:369
+msgid "Attempt to delete dead area"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:408
+#, c-format
+msgid "Dead centroid %d registered for area (bug in the vector library)"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:431
#, fuzzy, c-format
-msgid "Error reading raster data for row %d of <%s>"
+msgid "Attempt to delete area %d info from dead isle %d"
-#: ../lib/raster/get_row.c:102 ../lib/raster/get_row.c:168
+#: ../lib/vector/diglib/plus_area.c:777
#, fuzzy, c-format
-msgid "Error uncompressing raster data for row %d of <%s>"
+msgid "Attempt to delete isle %d info from dead area %d"
-#: ../lib/raster/get_row.c:227
+#: ../lib/vector/diglib/file.c:159
+msgid "Writing to file loaded to memory not supported"
+msgstr ""
+#: ../lib/vector/diglib/file.c:197
+#, fuzzy
+msgid "Unable to load file to memory, file not open"
+#: ../lib/vector/diglib/file.c:212
+msgid "Vector memory mode not supported, using 'AUTO'"
+msgstr ""
+#: ../lib/vector/diglib/portable.c:208 ../lib/vector/diglib/portable.c:241
+#: ../lib/vector/diglib/portable.c:683 ../lib/vector/diglib/plus_struct.c:563
+msgid "Vector exceeds supported file size limit"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:222
+#, fuzzy
+msgid "Unable read topology for nodes"
+#: ../lib/vector/diglib/plus.c:227
#, fuzzy, c-format
-msgid "Error reading raster data via GDAL for row %d of <%s>"
+msgid "Unable to read topology for node %d"
-#: ../lib/raster/get_row.c:827 ../lib/raster/get_row.c:832
-#: ../lib/raster/get_row.c:842
+#: ../lib/vector/diglib/plus.c:232
+#, fuzzy
+msgid "Unable read topology for lines"
+#: ../lib/vector/diglib/plus.c:237
#, fuzzy, c-format
-msgid "Error reading null data for row %d of <%s>"
+msgid "Unable to read topology for line %d"
-#: ../lib/raster/get_row.c:848
+#: ../lib/vector/diglib/plus.c:242
+#, fuzzy
+msgid "Unable to read topo for areas"
+#: ../lib/vector/diglib/plus.c:247
#, fuzzy, c-format
-msgid "Error uncompressing null data for row %d of <%s>"
+msgid "Unable read topology for area %d"
-#: ../lib/raster/get_row.c:882 ../lib/raster/get_row.c:885
+#: ../lib/vector/diglib/plus.c:252
+#, fuzzy
+msgid "Unable to read topology for isles"
+#: ../lib/vector/diglib/plus.c:257
#, fuzzy, c-format
-msgid "Error reading null row %d for <%s>"
+msgid "Unable to read topology for isle %d"
-#: ../lib/raster/window.c:31
+#: ../lib/vector/diglib/plus.c:279 ../lib/vector/diglib/plus.c:305
+#, fuzzy
+msgid "Unable to write head to plus file"
+#: ../lib/vector/diglib/plus.c:284
+#, fuzzy
+msgid "Unable to write nodes to plus file"
+#: ../lib/vector/diglib/plus.c:289
+#, fuzzy
+msgid "Unable to write lines to plus file"
+#: ../lib/vector/diglib/plus.c:294
+#, fuzzy
+msgid "Unable to write areas to plus file"
+#: ../lib/vector/diglib/plus.c:299
+#, fuzzy
+msgid "Unable to write isles to plus file"
+#: ../lib/vector/diglib/cindex_rw.c:156
+#, c-format
msgid ""
-"Internal error: Rast_get_window() called with split window. Use "
-"Rast_get_input_window() or Rast_get_output_window() instead."
+"This version of GRASS (%d.%d) is too old to read this category index format. "
+"Try to rebuild topology or upgrade GRASS to at least version %d."
msgstr ""
-#: ../lib/raster/window.c:90
+#: ../lib/vector/diglib/test.c:58
+#, fuzzy
+msgid "Unable to open test.tmp file"
+#: ../lib/vector/diglib/test.c:75
+#, c-format
msgid ""
-"Internal error: Rast_window_rows() called with split window. Use "
-"Rast_input_window_rows() or Rast_output_window_rows() instead."
+"Error in read/write portable double, byte_order = %d Written: %.16e3E Read: "
+"%.16e3E"
msgstr ""
-#: ../lib/raster/window.c:125
+#: ../lib/vector/diglib/test.c:89
+#, c-format
msgid ""
-"Internal error: Rast_window_cols() called with split window. Use "
-"Rast_input_window_cols() or Rast_output_window_cols() instead."
+"Error in read/write portable float, byte_order = %d Written: %.8e3E Read: "
+"%.8e3E"
msgstr ""
-#: ../lib/raster/null_val.c:64
-msgid "EmbedGivenNulls: wrong data type"
+#: ../lib/vector/diglib/test.c:104
+#, c-format
+msgid ""
+"Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
msgstr ""
-#: ../lib/raster/null_val.c:114
-msgid "Rast_set_null_value: wrong data type!"
+#: ../lib/vector/diglib/test.c:119
+#, c-format
+msgid ""
+"Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
msgstr ""
-#: ../lib/raster/auto_mask.c:69
-msgid "Unable to open automatic MASK file"
-msgstr "자동 MASK 파일을 열 수 없습니다."
-#: ../lib/raster/set_window.c:48
-msgid "Rast_set_window() called while window split"
+#: ../lib/vector/diglib/test.c:134
+#, c-format
+msgid "Error in read/write portable int, byte_order = %d Written: %d Read: %d"
msgstr ""
-#: ../lib/raster/set_window.c:131
+#: ../lib/vector/diglib/test.c:150
+#, c-format
msgid ""
-"Rast_set_read_window(): projection/zone differs from that of currently open "
-"raster maps"
+"Error in read/write portable short, byte_order = %d Written: %d Read: %d"
msgstr ""
-#: ../lib/raster/set_window.c:158
+#: ../lib/vector/diglib/test.c:165
#, c-format
-msgid "Input window changed while maps are open for read. Map name <%s>"
+msgid "Error in read/write portable char, byte_order = %d Written: %d Read: %d"
msgstr ""
-#: ../lib/raster/set_window.c:174
+#: ../lib/vector/diglib/spindex_rw.c:98 ../lib/vector/diglib/spindex_rw.c:106
+#, fuzzy
+msgid "Topology file must be written before spatial index file"
+msgstr "임시파일을 열 수 없습니다"
+#: ../lib/vector/diglib/spindex_rw.c:302
#, c-format
-msgid "Output window changed while maps are open for write. Map name <%s>"
+msgid ""
+"This version of GRASS (%d.%d) is too old to read this spatial index format. "
msgstr ""
-#: ../lib/raster/put_cellhd.c:34
-#, fuzzy, c-format
-msgid "Unable to create header file for <%s>"
-#: ../lib/gis/lrand48.c:84
+#: ../lib/vector/diglib/spindex_rw.c:308
#, c-format
-msgid "gettimeofday failed: %s"
+msgid ""
+"Your GRASS version does not fully support spatial index format %d.%d of the "
+"vector. Consider to rebuild topology or upgrade GRASS."
msgstr ""
-#: ../lib/gis/lrand48.c:114
-msgid "Pseudo-random number generator not seeded"
+#: ../lib/vector/diglib/spindex_rw.c:317
+#, c-format
+msgid ""
+"Spatial index format version %d.%d is not supported by this release. Please "
+"rebuild topology."
msgstr ""
-#: ../lib/gis/make_mapset.c:66 ../lib/init/grass.py:841
-#, fuzzy, c-format, python-format
-msgid "Location <%s> doesn't exist"
-#: ../lib/gis/timestamp.c:292
+#: ../lib/vector/diglib/frmt.c:45 ../lib/vector/diglib/frmt.c:70
#, fuzzy, c-format
-msgid "Unable to create timestamp file for %s map <%s@%s>"
+msgid "Vector format not recognized: %s"
-#: ../lib/gis/timestamp.c:301
+#: ../lib/vector/diglib/frmt.c:79 ../lib/vector/diglib/frmt.c:88
#, fuzzy, c-format
-msgid "Invalid timestamp specified for %s map <%s@%s>"
+msgid "Vector format '%s' not supported"
-#: ../lib/gis/timestamp.c:331
-#, fuzzy, c-format
-msgid "Unable to open timestamp file for %s map <%s@%s>"
+#: ../lib/vector/diglib/frmt.c:97
+#, c-format
+msgid "Format definition is not correct: %s"
+msgstr ""
-#: ../lib/gis/timestamp.c:340
+#: ../lib/vector/diglib/spindex.c:450
#, fuzzy, c-format
-msgid "Invalid timestamp file for %s map <%s@%s>"
+msgid "Unable to delete node %d from spatial index"
-#: ../lib/gis/timestamp.c:479
+#: ../lib/vector/diglib/spindex.c:493
#, fuzzy, c-format
-msgid "Unable to open timestamp file for vector map <%s@%s>"
+msgid "Unable to delete line %d from spatial index"
-#: ../lib/gis/timestamp.c:488
-#, fuzzy, c-format
-msgid "Invalid timestamp file for vector map <%s@%s>"
+#: ../lib/vector/diglib/spindex.c:529
+#, fuzzy
+msgid "Attempt to delete sidx for dead area"
-#: ../lib/gis/timestamp.c:524
+#: ../lib/vector/diglib/spindex.c:546
#, fuzzy, c-format
-msgid "Unable to create timestamp file for vector map <%s@%s>"
+msgid "Unable to delete area %d from spatial index"
-#: ../lib/gis/timestamp.c:533
+#: ../lib/vector/diglib/spindex.c:595
#, fuzzy, c-format
-msgid "Invalid timestamp specified for vector map <%s@%s>"
+msgid "Unable to delete isle %d from spatial index"
-#: ../lib/gis/location.c:61
+#: ../lib/vector/diglib/plus_node.c:214
#, c-format
-msgid "LOCATION <%s> not available"
+msgid ""
+"Attempt to read line angle for the line which is not connected to the node: "
+"node %d, line %d"
msgstr ""
-#: ../lib/gis/distance.c:154
+#: ../lib/vector/diglib/plus_struct.c:523
#, c-format
-msgid "%s: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
+msgid ""
+"This version of GRASS (%d.%d) is too old to read this topology format. Try "
+"to rebuild topology or upgrade GRASS to at least version %d."
msgstr ""
-#: ../lib/gis/parser_rest.c:60 ../lib/gis/parser_html.c:57
-msgid "NAME"
+#: ../lib/vector/diglib/plus_struct.c:529
+#, c-format
+msgid ""
+"Your GRASS version does not fully support topology format %d.%d of the "
msgstr ""
-#: ../lib/gis/parser_rest.c:73 ../lib/gis/parser_html.c:70
-msgid "KEYWORDS"
+#: ../lib/vector/diglib/plus_struct.c:539
+#, c-format
+msgid ""
+"Old topology format version %d.%d is not supported by this release. Try to "
+"rebuild topology using v.build or v.build.all module."
msgstr ""
-#: ../lib/gis/parser_rest.c:78 ../lib/gis/parser_html.c:75
-msgid "SYNOPSIS"
+#: ../lib/vector/Vlib/intersect.c:127
+msgid "3D not supported by Vect_segment_intersection()"
msgstr ""
-#: ../lib/gis/parser_rest.c:146 ../lib/gis/parser_html.c:141
-#: ../lib/init/grass.py:333
-msgid "Flags"
+#: ../lib/vector/Vlib/intersect.c:313
+msgid "Vect_segment_intersection() ERROR (collinear vertical segments)"
msgstr ""
-#: ../lib/gis/parser_rest.c:164 ../lib/gis/parser_interface.c:329
-#: ../lib/gis/parser_help.c:215 ../lib/gis/parser_html.c:167
-msgid "Allow output files to overwrite existing files"
+#: ../lib/vector/Vlib/intersect.c:407
+msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
msgstr ""
-#: ../lib/gis/parser_rest.c:168 ../lib/gis/parser_interface.c:344
-#: ../lib/gis/parser_help.c:218 ../lib/gis/parser_html.c:174
-msgid "Verbose module output"
+#: ../lib/vector/Vlib/intersect.c:1157 ../lib/vector/Vlib/intersect.c:1163
+#: ../lib/vector/Vlib/intersect.c:1165 ../lib/vector/Vlib/intersect.c:1219
+#: ../lib/vector/Vlib/intersect.c:1228 ../lib/vector/Vlib/intersect.c:1249
+#: ../lib/vector/Vlib/intersect.c:1266 ../lib/vector/Vlib/intersect2.c:1169
+#: ../lib/vector/Vlib/intersect2.c:1175 ../lib/vector/Vlib/intersect2.c:1177
+#: ../lib/vector/Vlib/intersect2.c:1229 ../lib/vector/Vlib/intersect2.c:1238
+#: ../lib/vector/Vlib/intersect2.c:1259 ../lib/vector/Vlib/intersect2.c:1276
+msgid "Error while adding point to array. Out of memory"
msgstr ""
-#: ../lib/gis/parser_rest.c:171 ../lib/gis/parser_interface.c:351
-#: ../lib/gis/parser_help.c:219 ../lib/gis/parser_html.c:177
-msgid "Quiet module output"
+#: ../lib/vector/Vlib/read.c:25 ../lib/vector/Vlib/write.c:30
+#: ../lib/vector/Vlib/write.c:36 ../lib/vector/Vlib/write.c:42
+#: ../lib/vector/Vlib/write.c:49
+msgid "for this format/level not supported"
msgstr ""
-#: ../lib/gis/parser_rest.c:179 ../lib/gis/parser_html.c:189
-#: ../lib/init/grass.py:347
-msgid "Parameters"
+#: ../lib/vector/Vlib/read.c:32 ../lib/vector/Vlib/rewind.c:29
+#: ../lib/vector/Vlib/close.c:38 ../lib/vector/Vlib/build.c:37
+#: ../lib/vector/Vlib/open.c:59 ../lib/vector/Vlib/write.c:56
+#: ../lib/vector/Vlib/write.c:62
+msgid "Requested format is not compiled in this version"
msgstr ""
-#: ../lib/gis/parser_rest.c:223 ../lib/gis/parser_html.c:233
-msgid "Options"
-msgstr ""
+#: ../lib/vector/Vlib/read.c:93 ../lib/vector/Vlib/read.c:129
+#: ../lib/vector/Vlib/read.c:168
+#, fuzzy
+msgid "Vector map is not open for reading"
-#: ../lib/gis/parser_rest.c:230 ../lib/gis/parser_html.c:239
-msgid "Default"
-msgstr ""
+#: ../lib/vector/Vlib/read.c:136 ../lib/vector/Vlib/read.c:180
+#, fuzzy, c-format
+msgid "Unable to read feature %d from vector map <%s>"
-#: ../lib/gis/compress.c:131 ../lib/gis/compress.c:193
-#: ../lib/gis/compress.c:209
-msgid "Request for unsupported compressor"
-msgstr ""
+#: ../lib/vector/Vlib/read.c:173 ../lib/vector/Vlib/box.c:276
+#: ../lib/vector/Vlib/write_pg.c:236 ../lib/vector/Vlib/write_pg.c:381
+#: ../lib/vector/Vlib/write_pg.c:396 ../lib/vector/Vlib/write_sfa.c:158
+#: ../lib/vector/Vlib/write_sfa.c:207 ../lib/vector/Vlib/write_nat.c:182
+#: ../lib/vector/Vlib/write_nat.c:295 ../lib/vector/Vlib/write_nat.c:651
+#: ../lib/vector/Vlib/read_sfa.c:50 ../lib/vector/Vlib/read_nat.c:144
+#: ../lib/vector/Vlib/read_pg.c:331
+#, fuzzy, c-format
+msgid "Attempt to access feature with invalid id (%d)"
-#: ../lib/gis/cmprbzip.c:82 ../lib/gis/cmprbzip.c:142
-msgid "GRASS needs to be compiled with BZIP2 for BZIP2 compression"
-msgstr ""
+#: ../lib/vector/Vlib/read.c:200
+#, fuzzy
+msgid "Line index is out of range"
+msgstr "카테고리는 정수여야 합니다."
-#: ../lib/gis/proj2.c:63
-msgid "Latitude-Longitude"
-msgstr ""
+#: ../lib/vector/Vlib/read.c:224
+#, fuzzy
+msgid "Node index is out of range"
-#: ../lib/gis/proj2.c:65
-msgid "Other Projection"
-msgstr ""
+#: ../lib/vector/Vlib/read.c:248
+#, fuzzy
+msgid "Area index is out of range"
-#: ../lib/gis/parser_wps.c:490
-msgid "Multiple outputs are not supported by WPS 1.0.0"
-msgstr ""
+#: ../lib/vector/Vlib/read.c:272
+#, fuzzy
+msgid "Isle index is out of range"
-#: ../lib/gis/parser_interface.c:337 ../lib/gis/parser_help.c:217
-#: ../lib/gis/parser_html.c:171
-msgid "Print usage summary"
+#: ../lib/vector/Vlib/remove_areas.c:107 ../lib/vector/Vlib/remove_areas.c:268
+msgid "Area is composed of dead boundary"
msgstr ""
-#: ../lib/gis/done_msg.c:38
+#: ../lib/vector/Vlib/remove_areas.c:194 ../lib/vector/Vlib/remove_areas.c:602
#, c-format
-msgid "%s complete. %s"
+msgid "%d areas of total size %g removed"
msgstr ""
-#: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
+#: ../lib/vector/Vlib/remove_areas.c:395
#, fuzzy
-msgid "Unable to seek"
+msgid "Could not delete line from coor"
-#: ../lib/gis/seek.c:56
-msgid "Seek offset out of range"
+#: ../lib/vector/Vlib/remove_areas.c:458
+#, fuzzy
+msgid "dissolve_neighbour > 0, failed to build new area"
+#: ../lib/vector/Vlib/remove_areas.c:463 ../lib/vector/Vlib/remove_areas.c:501
+msgid "Dissolve with neighbour area: corrupt topology"
msgstr ""
-#: ../lib/gis/ls.c:103
-#, fuzzy, c-format
-msgid "Unable to open directory %s"
+#: ../lib/vector/Vlib/remove_areas.c:497
+#, fuzzy
+msgid "Failed to build new area"
-#: ../lib/gis/env.c:311
-msgid "GISRC - variable not set"
+#: ../lib/vector/Vlib/remove_areas.c:544 ../lib/vector/Vlib/remove_areas.c:571
+#, fuzzy
+msgid "Failed to build new isle"
+#: ../lib/vector/Vlib/remove_areas.c:549 ../lib/vector/Vlib/remove_areas.c:576
+msgid "Dissolve with outer isle: corrupt topology"
msgstr ""
-#: ../lib/gis/env.c:343 ../lib/gis/env.c:369
-#, c-format
-msgid "Variable '%s' not set"
+#: ../lib/vector/Vlib/remove_areas.c:581
+#, fuzzy
+msgid "Area merging failed"
+#: ../lib/vector/Vlib/dgraph.c:432
+msgid ""
+"Trying to add more edges to the planar_graph than the initial allocation "
+"size allows"
msgstr ""
-#: ../lib/gis/find_file.c:114
+#: ../lib/vector/Vlib/array.c:96
#, c-format
-msgid "'%s/%s' was found in more mapsets (also found in <%s>)"
+msgid "%d errors in category string"
msgstr ""
-#: ../lib/gis/find_file.c:127
-#, fuzzy, c-format
-msgid "Using <%s@%s>"
+#: ../lib/vector/Vlib/array.c:142 ../lib/vector/Vlib/array.c:267
+msgid "Mixed area and other type requested for vector array"
+msgstr ""
-#: ../lib/gis/token.c:169
-msgid "parse error"
+#: ../lib/vector/Vlib/array.c:152 ../lib/vector/Vlib/array.c:175
+#: ../lib/vector/Vlib/array.c:304 ../lib/vector/Vlib/array.c:336
+msgid "Not enough space in vector array"
msgstr ""
-#: ../lib/gis/get_ellipse.c:263 ../lib/proj/ellipse.c:243
+#: ../lib/vector/Vlib/array.c:292
#, fuzzy, c-format
-msgid "Unable to open ellipsoid table file <%s>"
+msgid "Unable to select record from table <%s> (key %s, where %s)"
-#: ../lib/gis/get_ellipse.c:344 ../lib/gis/get_ellipse.c:367
+#: ../lib/vector/Vlib/build_sfa.c:279 ../lib/vector/Vlib/build_sfa.c:546
+#, fuzzy, c-format
+msgid "Unable to calculate centroid for area %d"
+#: ../lib/vector/Vlib/build_sfa.c:305
#, c-format
-msgid "Invalid a: field '%s' in file %s in <%s>"
+msgid "Feature type %d not supported"
msgstr ""
-#: ../lib/gis/get_ellipse.c:356
-#, c-format
-msgid "Invalid ellipsoid '%s' in file %s in <%s>"
+#: ../lib/vector/Vlib/build_sfa.c:339 ../lib/vector/Vlib/build_sfa.c:629
+#: ../lib/vector/Vlib/build_nat.c:74
+msgid "Registering primitives..."
msgstr ""
-#: ../lib/gis/get_ellipse.c:370
+#: ../lib/vector/Vlib/build_sfa.c:354 ../lib/vector/Vlib/build_sfa.c:364
+#: ../lib/vector/Vlib/read_pg.c:378
+#, fuzzy, c-format
+msgid "Feature %d without geometry skipped"
+#: ../lib/vector/Vlib/build_sfa.c:385 ../lib/vector/Vlib/build_sfa.c:661
+#: ../lib/vector/Vlib/build_nat.c:117
#, c-format
-msgid "Invalid es: field '%s' in file %s in <%s>"
-msgstr ""
+msgid "One primitive registered"
+msgid_plural "%d primitives registered"
+msgstr[0] ""
-#: ../lib/gis/get_ellipse.c:383
+#: ../lib/vector/Vlib/build_sfa.c:386 ../lib/vector/Vlib/build_sfa.c:662
+#: ../lib/vector/Vlib/build_nat.c:118
#, c-format
-msgid "No ellipsoid info given in file %s in <%s>"
-msgstr ""
+msgid "One vertex registered"
+msgid_plural "%d vertices registered"
+msgstr[0] ""
-#: ../lib/gis/parser_help.c:84
-msgid "Description:"
+#: ../lib/vector/Vlib/build_sfa.c:603 ../lib/vector/Vlib/read_ogr.c:344
+#: ../lib/vector/Vlib/read_ogr.c:578
+#, c-format
+msgid "OGR feature type %d not supported"
msgstr ""
-#: ../lib/gis/parser_help.c:103
-msgid "Keywords:"
-msgstr ""
+#: ../lib/vector/Vlib/build_sfa.c:665
+#, fuzzy, c-format
+msgid "One feature without geometry skipped"
+msgid_plural "%d features without geometry skipped"
+msgstr[0] "Datum %s 테이블파일을 열 수 없습니다"
-#: ../lib/gis/parser_help.c:111
-msgid "Usage:"
+#: ../lib/vector/Vlib/build_sfa.c:718 ../lib/vector/Vlib/simple_features.c:336
+#: ../lib/vector/Vlib/close.c:275 ../lib/vector/Vlib/build_pg.c:117
+#: ../lib/vector/Vlib/rewind_pg.c:56 ../lib/vector/Vlib/rewind_pg.c:81
+#: ../lib/vector/Vlib/header_finfo.c:47 ../lib/vector/Vlib/header_finfo.c:86
+#: ../lib/vector/Vlib/header_finfo.c:123 ../lib/vector/Vlib/header_finfo.c:171
+#: ../lib/vector/Vlib/copy.c:404 ../lib/vector/Vlib/close_pg.c:99
+#: ../lib/vector/Vlib/close_pg.c:146 ../lib/vector/Vlib/area.c:94
+#: ../lib/vector/Vlib/area.c:499 ../lib/vector/Vlib/write_pg.c:123
+#: ../lib/vector/Vlib/write_pg.c:157 ../lib/vector/Vlib/write_pg.c:196
+#: ../lib/vector/Vlib/write_pg.c:294 ../lib/vector/Vlib/write_pg.c:354
+#: ../lib/vector/Vlib/write_pg.c:476 ../lib/vector/Vlib/open_pg.c:143
+#: ../lib/vector/Vlib/open_pg.c:200 ../lib/vector/Vlib/open_pg.c:299
+#: ../lib/vector/Vlib/open_pg.c:349 ../lib/vector/Vlib/write_sfa.c:306
+#: ../lib/vector/Vlib/read_pg.c:91 ../lib/vector/Vlib/read_pg.c:214
+#: ../lib/vector/Vlib/read_pg.c:298 ../lib/vector/Vlib/read_pg.c:416
+msgid "GRASS is not compiled with PostgreSQL support"
msgstr ""
-#: ../lib/gis/parser_help.c:141
-msgid "ERROR: Option key not defined"
+#: ../lib/vector/Vlib/build_sfa.c:722
+#, c-format
+msgid "%s: Native format unsupported"
msgstr ""
-#: ../lib/gis/parser_help.c:191
-msgid "Flags:"
+#: ../lib/vector/Vlib/build_sfa.c:748
+msgid "Feature index is built only for non-native formats. Nothing to dump."
msgstr ""
-#: ../lib/gis/parser_help.c:220
-msgid "Super quiet module output"
+#: ../lib/vector/Vlib/clean_nodes.c:248
+#, c-format
+msgid "Modifications: %d"
msgstr ""
-#: ../lib/gis/parser_help.c:221 ../lib/gis/parser_html.c:180
-msgid "Force launching GUI dialog"
+#: ../lib/vector/Vlib/line.c:184 ../lib/vector/Vlib/line.c:217
+#: ../lib/vector/Vlib/line.c:250
+msgid "Index out of range in"
msgstr ""
-#: ../lib/gis/parser_help.c:230
-msgid "Parameters:"
+#: ../lib/vector/Vlib/line.c:550
+msgid "Segment outside line, no segment created"
msgstr ""
-#: ../lib/gis/parser_help.c:253
-#, c-format
-msgid " %*s default: %s\n"
-msgstr ""
+#: ../lib/vector/Vlib/simple_features.c:225
+#, fuzzy, c-format
+msgid "Unknown Simple Features type (%d)"
-#: ../lib/gis/parser_help.c:279
-#, c-format
-msgid " %*s options: "
+#: ../lib/vector/Vlib/simple_features.c:324 ../lib/vector/Vlib/write_pg.c:321
+#: ../lib/vector/Vlib/write_pg.c:811 ../lib/vector/Vlib/write_pg.c:1212
+#: ../lib/vector/Vlib/write_pg.c:1364
+msgid "No connection defined"
msgstr ""
-#: ../lib/gis/list.c:83
-#, c-format
-msgid "no %s files available in current mapset\n"
-msgstr ""
+#: ../lib/vector/Vlib/simple_features.c:332
+#, fuzzy
+msgid "Unable to get number of simple features"
-#: ../lib/gis/list.c:86
-#, c-format
-msgid "no %s files available in mapset <%s>\n"
-msgstr ""
+#: ../lib/vector/Vlib/simple_features.c:341
+#, fuzzy, c-format
+msgid "Unable to report simple features for vector map <%s>"
-#: ../lib/gis/list.c:132
-#, c-format
-msgid "%s files available in mapset <%s>:\n"
+#: ../lib/vector/Vlib/level.c:34
+msgid "Map structure was never initialized"
msgstr ""
-#: ../lib/gis/list.c:204
-msgid "G_list: Unknown element type"
+#: ../lib/vector/Vlib/level.c:36
+msgid "Map structure has been closed"
msgstr ""
-#: ../lib/gis/proj3.c:121 ../lib/vector/Vlib/header.c:552
-msgid "Unknown projection"
-msgstr ""
-#: ../lib/gis/mapset_msc.c:90
+#: ../lib/vector/Vlib/close.c:91
#, fuzzy, c-format
-msgid "Unable to make mapset element %s (%s): %s"
+msgid "Unable to create vector map <%s>"
-#: ../lib/gis/mapset_msc.c:94
-#, fuzzy, c-format
-msgid "Unable to access mapset element %s (%s): %s"
-#: ../lib/gis/home.c:39
+#: ../lib/vector/Vlib/close.c:108
#, fuzzy
-msgid "Unable to determine user's home directory"
+msgid "Copying features failed"
-#: ../lib/gis/home.c:120
+#: ../lib/vector/Vlib/close.c:141
#, fuzzy, c-format
-msgid "Failed to create directory [%s]"
+msgid "Unable to open %s file"
-#: ../lib/gis/open.c:68
-#, c-format
-msgid "G__open(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr ""
-#: ../lib/gis/open.c:89
+#: ../lib/vector/Vlib/close.c:226
#, fuzzy, c-format
-msgid "G__open(read): Unable to open '%s': %s"
+msgid "Unable to close vector <%s>"
-#: ../lib/gis/open.c:98
+#: ../lib/vector/Vlib/close.c:257
#, c-format
-msgid "G__open(write): xmapset <%s> != G_mapset() <%s>"
+msgid "Invalid request for writing frmt file - map format is %d"
msgstr ""
-#: ../lib/gis/open.c:122
+#: ../lib/vector/Vlib/close.c:289
#, fuzzy, c-format
-msgid "G__open(write): Unable to open '%s': %s"
+msgid "Link to vector map <%s> created"
-#: ../lib/gis/parser_standard_options.c:147
-msgid "SQL SELECT statement"
+#: ../lib/vector/Vlib/build_pg.c:88
+msgid "No DB connection"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:149
-msgid "Example: select * from towns where population > 10000"
+#: ../lib/vector/Vlib/build_pg.c:93 ../lib/vector/Vlib/build_ogr.c:82
+#, c-format
+msgid "Feature table <%s> has no primary key defined"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:156
-msgid "WHERE conditions of SQL statement without 'where' keyword"
+#: ../lib/vector/Vlib/build_pg.c:95
+msgid "Random read is not supported for this layer. Unable to build topology."
msgstr ""
-#: ../lib/gis/parser_standard_options.c:157
-msgid "Example: income < 1000 and population >= 10000"
+#: ../lib/vector/Vlib/build_pg.c:101 ../lib/vector/Vlib/build_ogr.c:90
+#, c-format
+msgid "Using external data format '%s' (feature type '%s')"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:165
+#: ../lib/vector/Vlib/build_pg.c:105
#, fuzzy
-msgid "Name of attribute table"
+msgid "Building pseudo-topology over simple features..."
-#: ../lib/gis/parser_standard_options.c:174
+#: ../lib/vector/Vlib/build_pg.c:107
+#, fuzzy, c-format
+msgid "Building topology from PostGIS topology schema <%s>..."
+#: ../lib/vector/Vlib/build_pg.c:212 ../lib/vector/Vlib/open_pg.c:1485
+#, c-format
+msgid "Inconsistency in topology: number of nodes %d (should be %d)"
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:237
#, fuzzy
-msgid "Name of database driver"
+msgid "Cleaning-up topology schema..."
-#: ../lib/gis/parser_standard_options.c:183
+#: ../lib/vector/Vlib/build_pg.c:282
#, fuzzy
-msgid "Name of database"
+msgid "Updating faces..."
-#: ../lib/gis/parser_standard_options.c:192
-msgid "Database schema"
+#: ../lib/vector/Vlib/build_pg.c:314
+#, fuzzy
+msgid "Updating edges..."
+#: ../lib/vector/Vlib/build_pg.c:323
+msgid "Inconsistency in topology detected. Dead line found."
msgstr ""
-#: ../lib/gis/parser_standard_options.c:193
-msgid ""
-"Do not use this option if schemas are not supported by driver/database server"
+#: ../lib/vector/Vlib/build_pg.c:377
+msgid "Updating TopoGeometry data..."
msgstr ""
-#: ../lib/gis/parser_standard_options.c:202
-msgid "Name of attribute column"
+#: ../lib/vector/Vlib/build_pg.c:411 ../lib/vector/Vlib/write_pg.c:612
+#: ../lib/vector/Vlib/write_pg.c:880 ../lib/vector/Vlib/open.c:1355
+#, fuzzy
+msgid "Unable to open PG file"
+#: ../lib/vector/Vlib/build_pg.c:462
+#, fuzzy, c-format
+msgid "Unsupported topo geometry type %d"
+#: ../lib/vector/Vlib/build_pg.c:491
+#, fuzzy, c-format
+msgid "Unable to create <%s.%s>"
+#: ../lib/vector/Vlib/build_pg.c:642
+#, fuzzy
+msgid "Unable to write nodes, offset array mismatch"
+msgstr "자동 MASK파일을 열 수 없습니다"
+#: ../lib/vector/Vlib/build_pg.c:671
+#, fuzzy
+msgid "Unable to write nodes"
+#: ../lib/vector/Vlib/build_pg.c:716
+#, fuzzy, c-format
+msgid "Inconsistency in topology: number of boundaries %d (should be %d)"
+#: ../lib/vector/Vlib/build_pg.c:739
+#, fuzzy
+msgid "Unable to write lines"
+#: ../lib/vector/Vlib/build_pg.c:790
+#, fuzzy, c-format
+msgid "Topology for centroid %d not available. Area %d skipped"
+#: ../lib/vector/Vlib/build_pg.c:1000
+msgid "Create simple features topology from topogeometry data..."
msgstr ""
-#: ../lib/gis/parser_standard_options.c:211
-msgid "Name of attribute column(s)"
+#: ../lib/vector/Vlib/build_pg.c:1018
+#, c-format
+msgid ""
+"Unable to build simple features from topogeometry data. Unsupported type %d."
msgstr ""
-#: ../lib/gis/parser_standard_options.c:220
-#, fuzzy
-msgid "Name of key column"
+#: ../lib/vector/Vlib/select.c:116
+#, fuzzy, c-format
+msgid "Unable to delete item %d from spatial index"
-#: ../lib/gis/parser_standard_options.c:221
-msgid "Must refer to an integer column"
+#: ../lib/vector/Vlib/build.c:115
+msgid "Area of size = 0.0 (less than 4 vertices) ignored"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:233
-msgid "Name of input imagery group"
+#: ../lib/vector/Vlib/build.c:131
+msgid "Unable to add area (map closed, topo saved)"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:241
-msgid "Name of input imagery subgroup"
+#: ../lib/vector/Vlib/build.c:139
+msgid "Unable to add isle (map closed, topo saved)"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:251
-msgid "Name of input raster map"
+#: ../lib/vector/Vlib/build.c:149
+msgid "Area of size = 0.0 ignored"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:260
-msgid "Name of input raster map(s)"
+#: ../lib/vector/Vlib/build.c:200
+msgid "Request to find area outside nonexistent isle"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:268
-msgid "Name for output raster map"
+#: ../lib/vector/Vlib/build.c:351
+msgid "Larger bbox but smaller area!!!"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:277
-#, fuzzy
-msgid "Name for output raster map(s)"
+#: ../lib/vector/Vlib/build.c:606
+msgid "Checking for topological errors..."
+msgstr ""
+#: ../lib/vector/Vlib/build.c:641
+#, fuzzy, c-format
+msgid "Number of lines of length zero: %d"
-#: ../lib/gis/parser_standard_options.c:285
-#, fuzzy
-msgid "Name of raster map"
+#: ../lib/vector/Vlib/build.c:643
+#, fuzzy, c-format
+msgid "Number of boundaries of length zero: %d"
-#: ../lib/gis/parser_standard_options.c:294
+#: ../lib/vector/Vlib/build.c:652
+#, fuzzy, c-format
+msgid "Number of boundary intersections: %d"
+#: ../lib/vector/Vlib/build.c:676
#, fuzzy
-msgid "Name of raster map(s)"
+msgid "Skipping further checks because of incorrect boundaries"
-#: ../lib/gis/parser_standard_options.c:302
-msgid "Name of base raster map"
-msgstr ""
+#: ../lib/vector/Vlib/build.c:726
+#, fuzzy, c-format
+msgid "Number of redundant holes: %d"
-#: ../lib/gis/parser_standard_options.c:310
-msgid "Name of cover raster map"
+#: ../lib/vector/Vlib/build.c:865 ../lib/vector/Vlib/open.c:367
+#: ../lib/vector/Vlib/open.c:871
+#, fuzzy, c-format
+msgid "Unable to open spatial index file for vector map <%s>"
+#: ../lib/vector/Vlib/build.c:871
+#, fuzzy, c-format
+msgid "Building topology for vector map <%s>..."
+#: ../lib/vector/Vlib/build.c:889
+msgid "Topology was built"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:318
-#, fuzzy
-msgid "Name of input elevation raster map"
+#: ../lib/vector/Vlib/build.c:900
+#, fuzzy, c-format
+msgid "Number of nodes: %d"
-#: ../lib/gis/parser_standard_options.c:327
-#, fuzzy
-msgid "Name of input elevation raster map(s)"
+#: ../lib/vector/Vlib/build.c:901
+#, fuzzy, c-format
+msgid "Number of primitives: %d"
-#: ../lib/gis/parser_standard_options.c:334
-#, fuzzy
-msgid "Type of raster map to be created"
+#: ../lib/vector/Vlib/build.c:902
+#, fuzzy, c-format
+msgid "Number of points: %d"
-#: ../lib/gis/parser_standard_options.c:335
-#, fuzzy
-msgid "Storage type for resultant raster map"
+#: ../lib/vector/Vlib/build.c:903
+#, fuzzy, c-format
+msgid "Number of lines: %d"
-#: ../lib/gis/parser_standard_options.c:339
-msgid "Integer"
-msgstr ""
+#: ../lib/vector/Vlib/build.c:904
+#, fuzzy, c-format
+msgid "Number of boundaries: %d"
-#: ../lib/gis/parser_standard_options.c:340
-msgid "Single precision floating point"
-msgstr ""
+#: ../lib/vector/Vlib/build.c:905
+#, fuzzy, c-format
+msgid "Number of centroids: %d"
-#: ../lib/gis/parser_standard_options.c:341
-msgid "Double precision floating point"
-msgstr ""
+#: ../lib/vector/Vlib/build.c:908
+#, fuzzy, c-format
+msgid "Number of faces: %d"
-#: ../lib/gis/parser_standard_options.c:347
-msgid "Sampling interpolation method"
-msgstr ""
+#: ../lib/vector/Vlib/build.c:911
+#, fuzzy, c-format
+msgid "Number of kernels: %d"
-#: ../lib/gis/parser_standard_options.c:351
-msgid "Nearest-neighbor interpolation"
-msgstr ""
+#: ../lib/vector/Vlib/build.c:957
+#, fuzzy, c-format
+msgid "Number of areas: %d"
-#: ../lib/gis/parser_standard_options.c:352
-msgid "Bilinear interpolation"
-msgstr ""
+#: ../lib/vector/Vlib/build.c:958
+#, fuzzy, c-format
+msgid "Number of isles: %d"
-#: ../lib/gis/parser_standard_options.c:353
-msgid "Bicubic interpolation"
-msgstr ""
+#: ../lib/vector/Vlib/build.c:963
+#, fuzzy, c-format
+msgid "Number of areas without centroid: %d"
-#: ../lib/gis/parser_standard_options.c:362
-#, fuzzy
-msgid "Name of input basename raster map(s)"
+#: ../lib/vector/Vlib/build.c:968
+#, fuzzy, c-format
+msgid "Number of centroids exceeds number of areas: %d > %d"
-#: ../lib/gis/parser_standard_options.c:371
-#, fuzzy
-msgid "Name for output basename raster map(s)"
+#: ../lib/vector/Vlib/build.c:972
+#, fuzzy, c-format
+msgid "Number of incorrect boundaries: %d"
-#: ../lib/gis/parser_standard_options.c:381
-#, fuzzy
-msgid "Name of input 3D raster map"
+#: ../lib/vector/Vlib/build.c:976
+#, fuzzy, c-format
+msgid "Number of centroids outside area: %d"
-#: ../lib/gis/parser_standard_options.c:390
-#, fuzzy
-msgid "Name of input 3D raster map(s)"
+#: ../lib/vector/Vlib/build.c:980
+#, fuzzy, c-format
+msgid "Number of duplicate centroids: %d"
-#: ../lib/gis/parser_standard_options.c:398
+#: ../lib/vector/Vlib/build.c:984
#, fuzzy
-msgid "Name for output 3D raster map"
+msgid "Number of areas: -"
-#: ../lib/gis/parser_standard_options.c:406
+#: ../lib/vector/Vlib/build.c:985
#, fuzzy
-msgid "Name of 3D raster map"
+msgid "Number of isles: -"
-#: ../lib/gis/parser_standard_options.c:415
-#, fuzzy
-msgid "Name of 3D raster map(s)"
+#: ../lib/vector/Vlib/build.c:1013
+#, fuzzy, c-format
+msgid "Unable to create topo file for vector map <%s>"
-#: ../lib/gis/parser_standard_options.c:424
+#: ../lib/vector/Vlib/build.c:1021
#, fuzzy
-msgid "Data type used in the output raster3d map"
+msgid "Error writing out topo file"
-#: ../lib/gis/parser_standard_options.c:433
+#: ../lib/vector/Vlib/build.c:1210
+#, fuzzy
msgid ""
-"Number of digits used as mantissa in the internal map storage, 0 -23 for "
-"float, 0 - 52 for double, max or default"
-msgstr ""
+"Unable to build spatial index from topology, vector map is not opened at "
+"topology level 2"
-#: ../lib/gis/parser_standard_options.c:443
-msgid "The compression method used in the output raster3d map"
+#: ../lib/vector/Vlib/build.c:1233
+#, c-format
+msgid "%s is no longer supported"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:453
-msgid ""
-"The dimensions of the tiles used in the output raster3d map (XxYxZ or "
-"default: 16x16x8)"
+#: ../lib/vector/Vlib/build.c:1256
+msgid "Spatial index not available, can not be saved"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:463
-msgid "Name of input vector map"
-msgstr ""
+#: ../lib/vector/Vlib/build.c:1268
+#, fuzzy, c-format
+msgid "Unable to create spatial index file for vector map <%s>"
-#: ../lib/gis/parser_standard_options.c:464
-#: ../lib/gis/parser_standard_options.c:491
-msgid "Or data source for direct OGR access"
+#: ../lib/vector/Vlib/build.c:1277
+#, fuzzy
+msgid "Error writing out spatial index file"
+#: ../lib/vector/Vlib/bridges.c:213
+#, fuzzy, c-format
+msgid "Removed lines: %d"
+#: ../lib/vector/Vlib/bridges.c:214
+#, fuzzy, c-format
+msgid "Removed bridges: %d"
+#: ../lib/vector/Vlib/legal_vname.c:43
+#, c-format
+msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
msgstr ""
-#: ../lib/gis/parser_standard_options.c:473
-msgid "Name of input vector map(s)"
+#: ../lib/vector/Vlib/legal_vname.c:50
+#, c-format
+msgid "Illegal vector map name <%s>. Must start with a letter."
msgstr ""
-#: ../lib/gis/parser_standard_options.c:474
-msgid "Or data source(s) for direct OGR access"
+#: ../lib/vector/Vlib/legal_vname.c:58
+#, c-format
+msgid "Illegal vector map name <%s>. Character '%c' not allowed."
msgstr ""
-#: ../lib/gis/parser_standard_options.c:482
-msgid "Name for output vector map"
+#: ../lib/vector/Vlib/legal_vname.c:65
+#, c-format
+msgid ""
+"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
msgstr ""
-#: ../lib/gis/parser_standard_options.c:490
-#, fuzzy
-msgid "Name of vector map"
+#: ../lib/vector/Vlib/legal_vname.c:100 ../lib/vector/Vlib/legal_vname.c:104
+#, fuzzy, c-format
+msgid "Output vector map name <%s> is not in the current mapset (%s)"
+msgstr "'%s' 디버그파일을 열 수 없습니다"
+#: ../lib/vector/Vlib/legal_vname.c:117 ../lib/vector/Vlib/legal_vname.c:121
+#, fuzzy, c-format
+msgid "Output vector map name <%s> is not SQL compliant"
-#: ../lib/gis/parser_standard_options.c:500
-#, fuzzy
-msgid "Name of vector map(s)"
+#: ../lib/vector/Vlib/legal_vname.c:159 ../lib/vector/Vlib/legal_vname.c:163
+#, c-format
+msgid "Output vector map <%s> is used as input"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:81
+#, fuzzy, c-format
+msgid "Unable to copy features. Input vector map <%s> is not open"
-#: ../lib/gis/parser_standard_options.c:509
-#: ../lib/gis/parser_standard_options.c:518
-#, fuzzy
-msgid "Input feature type"
+#: ../lib/vector/Vlib/copy.c:100 ../lib/vector/Vlib/write_pg.c:737
+#: ../lib/vector/Vlib/write_pg.c:1175 ../lib/vector/Vlib/write_pg.c:1278
+#: ../lib/vector/Vlib/write_pg.c:1790 ../lib/vector/Vlib/write_pg.c:1967
+#: ../lib/vector/Vlib/write_pg.c:2325 ../lib/vector/Vlib/read_pg.c:884
+#: ../lib/vector/Vlib/read_pg.c:1192 ../lib/vector/Vlib/read_pg.c:1347
+#: ../lib/vector/Vlib/read_pg.c:1440
+#, fuzzy, c-format
+msgid "Unsupported feature type %d"
-#: ../lib/gis/parser_standard_options.c:525
-msgid "Layer number or name"
-msgstr ""
+#: ../lib/vector/Vlib/copy.c:104
+#, fuzzy, c-format
+msgid "Unable to create PostGIS layer <%s>"
-#: ../lib/gis/parser_standard_options.c:527
-msgid ""
-"Vector features can have category values in different layers. This number "
-"determines which layer to use. When used with direct OGR access this is the "
-"layer name."
-msgstr ""
+#: ../lib/vector/Vlib/copy.c:133
+#, fuzzy, c-format
+msgid "Vector map <%s> not open on topological level. Areas will be skipped!"
-#: ../lib/gis/parser_standard_options.c:537
-msgid "Layer number or name ('-1' for all layers)"
+#: ../lib/vector/Vlib/copy.c:168 ../lib/vector/Vlib/copy.c:245
+#: ../lib/ogsf/gp3.c:92
+#, fuzzy, c-format
+msgid "Unable to read vector map <%s>"
+#: ../lib/vector/Vlib/copy.c:229 ../lib/vector/Vlib/copy.c:234
+msgid "Copying features..."
msgstr ""
-#: ../lib/gis/parser_standard_options.c:539
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use. When used with direct OGR access this "
-"is the layer name."
+#: ../lib/vector/Vlib/copy.c:231
+#, c-format
+msgid "Copying features (%s)..."
msgstr ""
-#: ../lib/gis/parser_standard_options.c:548
-msgid "Category value"
+#: ../lib/vector/Vlib/copy.c:334
+msgid "Writing new feature failed"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:556
-msgid "Category values"
+#: ../lib/vector/Vlib/copy.c:340
+#, fuzzy, c-format
+msgid "%d features without category or from different layer skipped"
+#: ../lib/vector/Vlib/copy.c:372
+msgid "Exporting nodes..."
msgstr ""
-#: ../lib/gis/parser_standard_options.c:557
-#: ../lib/gis/parser_standard_options.c:572
-msgid "Example: 1,3,7-9,13"
+#: ../lib/vector/Vlib/copy.c:400
+#, fuzzy, c-format
+msgid "Writing node %d failed"
+#: ../lib/vector/Vlib/copy.c:478
+msgid "Exporting areas..."
msgstr ""
-#: ../lib/gis/parser_standard_options.c:564
-msgid "Feature id"
+#: ../lib/vector/Vlib/copy.c:505
+#, c-format
+msgid "No centroid defined for area %d. Area not exported."
msgstr ""
-#: ../lib/gis/parser_standard_options.c:571
-msgid "Feature ids"
+#: ../lib/vector/Vlib/copy.c:534 ../lib/vector/Vlib/copy.c:542
+#, fuzzy, c-format
+msgid "Writing area %d failed"
+#: ../lib/vector/Vlib/copy.c:550
+#, c-format
+msgid "%d areas without category or from different layer skipped"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:582
-#: ../lib/gis/parser_standard_options.c:590
+#: ../lib/vector/Vlib/copy.c:604
+#, fuzzy, c-format
+msgid "Unable to copy table <%s> for layer %d from <%s> to <%s>"
+#: ../lib/vector/Vlib/copy.c:723
+#, fuzzy, c-format
+msgid "Unable to add database link for vector map <%s>"
+#: ../lib/vector/Vlib/copy.c:738 ../lib/vector/Vlib/close_nat.c:102
+#: ../lib/vector/Vlib/map.c:317
+#, fuzzy, c-format
+msgid "Unable to copy table <%s>"
+#: ../lib/vector/Vlib/copy.c:747
+#, fuzzy, c-format
+msgid "Unable to open database <%s> with driver <%s>"
+#: ../lib/vector/Vlib/copy.c:754
#, fuzzy
-msgid "Name of input file"
+msgid "Unable to create index"
-#: ../lib/gis/parser_standard_options.c:598
-msgid "Name for output file"
-msgstr ""
+#: ../lib/vector/Vlib/copy.c:760
+#, fuzzy, c-format
+msgid "Unable to grant privileges on table <%s>"
-#: ../lib/gis/parser_standard_options.c:607
-msgid "Field separator"
-msgstr ""
+#: ../lib/vector/Vlib/geos.c:52
+#, fuzzy
+msgid "vector map is not opened"
-#: ../lib/gis/parser_standard_options.c:608
-msgid "Special characters: pipe, comma, space, tab, newline"
+#: ../lib/vector/Vlib/geos.c:55
+#, c-format
+msgid ""
+"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
+"vector map <%s>: %d)"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:619
-#: ../lib/gis/parser_standard_options.c:630
-msgid "Color"
+#: ../lib/vector/Vlib/geos.c:60
+msgid "only native format supported"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:621
-msgid "Either a standard color name or R:G:B triplet"
+#: ../lib/vector/Vlib/geos.c:65 ../lib/vector/Vlib/geos.c:258
+#, fuzzy
+msgid "Attempt to read dead line"
+#: ../lib/vector/Vlib/geos.c:90
+#, c-format
+msgid "Vect_read_area_geos(): unable to read area id %d"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:632
-msgid "Either a standard color name, R:G:B triplet, or \"none\""
+#: ../lib/vector/Vlib/geos.c:104
+#, c-format
+msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:643
+#: ../lib/vector/Vlib/geos.c:205
+#, fuzzy, c-format
+msgid "Unable to read line offset %ld"
+#: ../lib/vector/Vlib/geos.c:412
+#, fuzzy, c-format
+msgid "Attempt to read points of nonexistent area id %d"
+#: ../lib/vector/Vlib/geos.c:472
+#, fuzzy, c-format
+msgid "Unable to read feature id %d"
+#: ../lib/vector/Vlib/buffer2.c:361
#, fuzzy
-msgid "Name of input directory"
+msgid "Line is not looped"
-#: ../lib/gis/parser_standard_options.c:653
-msgid "Units"
+#: ../lib/vector/Vlib/buffer2.c:443
+#, c-format
+msgid "Unexpected result of line_intersection() res = %d"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:662
-msgid "Data type(s)"
+#: ../lib/vector/Vlib/buffer2.c:589
+msgid ""
+"Next edge was visited (right) but it is not the first one !!! breaking loop"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:672
-msgid "Name of mapset (default: current search path)"
+#: ../lib/vector/Vlib/buffer2.c:600
+msgid ""
+"Next edge was visited (left) but it is not the first one !!! breaking loop"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:673
-msgid "'.' for current mapset"
+#: ../lib/vector/Vlib/buffer2.c:648
+msgid "side != 0 feature not implemented"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:681
-msgid "Location name"
+#: ../lib/vector/Vlib/buffer2.c:890 ../lib/vector/Vlib/buffer2.c:937
+msgid "zero area size"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:682
-msgid "Location name (not location path)"
-msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:896 ../lib/vector/Vlib/buffer2.c:943
+#, fuzzy
+msgid "Line was not closed"
-#: ../lib/gis/parser_standard_options.c:692
-msgid "GRASS GIS database directory"
+#: ../lib/vector/Vlib/buffer2.c:909 ../lib/vector/Vlib/buffer2.c:960
+msgid "Vect_get_point_in_poly() failed"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:693
-msgid "Default: path to the current GRASS GIS database"
-msgstr ""
+#: ../lib/vector/Vlib/close_pg.c:66 ../lib/vector/Vlib/read_pg.c:1405
+#, fuzzy, c-format
+msgid "Unable to close cursor %s"
-#: ../lib/gis/parser_standard_options.c:705
-#, fuzzy
-msgid "Coordinates"
-msgstr "잘못된 좌표"
+#: ../lib/vector/Vlib/close_pg.c:139 ../lib/vector/Vlib/close_ogr.c:104
+#, fuzzy, c-format
+msgid "Unable to save feature index file for vector map <%s>"
-#: ../lib/gis/parser_standard_options.c:714
-#, fuzzy
-msgid "Name of color table"
+#: ../lib/vector/Vlib/box.c:291
+#, fuzzy, c-format
+msgid "Unable to determine bbox for feature %d"
-#: ../lib/gis/parser_standard_options.c:725
-msgid "String representing NULL value"
-msgstr ""
+#: ../lib/vector/Vlib/box.c:340 ../lib/vector/Vlib/box.c:386
+#, fuzzy, c-format
+msgid "Attempt to access area with invalid id (%d)"
-#: ../lib/gis/parser_standard_options.c:734
-#, fuzzy
-msgid "Name of saved region"
+#: ../lib/vector/Vlib/box.c:352
+#, fuzzy, c-format
+msgid "Unable to determine bbox for area %d"
+#: ../lib/vector/Vlib/box.c:398
+#, fuzzy, c-format
+msgid "Unable to determine bbox for isle %d"
-#: ../lib/gis/parser_standard_options.c:744
+#: ../lib/vector/Vlib/close_nat.c:74
+#, fuzzy, c-format
+msgid "Unable to create '%s': %s"
+#: ../lib/vector/Vlib/close_nat.c:81
+#, fuzzy, c-format
+msgid "Unable to copy '%s': %s"
+#: ../lib/vector/Vlib/close_nat.c:167
+#, fuzzy, c-format
+msgid "Unable to drop table <%s>"
+#: ../lib/vector/Vlib/area.c:50
#, fuzzy
-msgid "Name of the input space time dataset"
-msgstr "'%s' 디버그파일을 열 수 없습니다"
+msgid "Attempt to read points of nonexistent area"
-#: ../lib/gis/parser_standard_options.c:753
+#: ../lib/vector/Vlib/area.c:81
#, fuzzy
-msgid "Name of the input space time datasets"
+msgid "Attempt to read points of nonexistent isle"
-#: ../lib/gis/parser_standard_options.c:761
-msgid "Name of the output space time dataset"
-msgstr ""
+#: ../lib/vector/Vlib/area.c:121 ../lib/vector/Vlib/area.c:153
+#: ../lib/vector/Vlib/area.c:219 ../lib/vector/Vlib/area.c:248
+#, fuzzy, c-format
+msgid "Attempt to read topo for dead area (%d)"
-#: ../lib/gis/parser_standard_options.c:769
+#: ../lib/vector/Vlib/area.c:189 ../lib/vector/Vlib/area.c:275
+#, fuzzy, c-format
+msgid "Attempt to read topo for dead isle (%d)"
+#: ../lib/vector/Vlib/write_pg.c:187 ../lib/vector/Vlib/write_pg.c:255
+#: ../lib/vector/Vlib/write_sfa.c:164 ../lib/vector/Vlib/write_ogr.c:96
#, fuzzy
-msgid "Name of the input space time raster dataset"
+msgid "Unable to rewrite feature (incompatible feature types)"
+#: ../lib/vector/Vlib/write_pg.c:242 ../lib/vector/Vlib/write_pg.c:402
+#: ../lib/vector/Vlib/write_pg.c:2584 ../lib/vector/Vlib/write_pg.c:2681
+#: ../lib/vector/Vlib/write_nat.c:301 ../lib/vector/Vlib/write_nat.c:657
+#: ../lib/vector/Vlib/read_sfa.c:56 ../lib/vector/Vlib/read_nat.c:150
+#: ../lib/vector/Vlib/read_pg.c:337
+#, fuzzy, c-format
+msgid "Attempt to access dead feature %d"
+#: ../lib/vector/Vlib/write_pg.c:285
+#, fuzzy, c-format
+msgid "Unable to rewrite feature %d"
msgstr "Datum %s 테이블파일을 열 수 없습니다"
-#: ../lib/gis/parser_standard_options.c:778
-#, fuzzy
-msgid "Name of the input space time raster datasets"
+#: ../lib/vector/Vlib/write_pg.c:326 ../lib/vector/Vlib/write_ogr.c:134
+#, fuzzy, c-format
+msgid "Invalid offset (%ld)"
-#: ../lib/gis/parser_standard_options.c:786
+#: ../lib/vector/Vlib/write_pg.c:347 ../lib/vector/Vlib/write_ogr.c:140
#, fuzzy
-msgid "Name of the output space time raster dataset"
+msgid "Unable to delete feature"
-#: ../lib/gis/parser_standard_options.c:794
-#, fuzzy
-msgid "Name of the input space time vector dataset"
+#: ../lib/vector/Vlib/write_pg.c:452
+#, fuzzy, c-format
+msgid "Unable to delete feature (%s) %d"
-#: ../lib/gis/parser_standard_options.c:803
-msgid "Name of the input space time vector datasets"
+#: ../lib/vector/Vlib/write_pg.c:554 ../lib/vector/Vlib/write_pg.c:1294
+#: ../lib/vector/Vlib/write_sfa.c:349
+msgid "Boundary is not closed. Skipping."
msgstr ""
-#: ../lib/gis/parser_standard_options.c:811
-msgid "Name of the output space time vector dataset"
+#: ../lib/vector/Vlib/write_pg.c:773
+#, fuzzy, c-format
+msgid "Building spatial index on <%s>..."
+#: ../lib/vector/Vlib/write_pg.c:841
+#, c-format
+msgid "Schema <%s> doesn't exist, created"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:819
-#, fuzzy
-msgid "Name of the input space time raster3d dataset"
-msgstr "Datum %s 테이블파일을 열 수 없습니다"
+#: ../lib/vector/Vlib/write_pg.c:920
+#, fuzzy, c-format
+msgid "Creating topology schema <%s>..."
-#: ../lib/gis/parser_standard_options.c:828
-#, fuzzy
-msgid "Name of the input space time raster3d datasets"
+#: ../lib/vector/Vlib/write_pg.c:934
+#, fuzzy, c-format
+msgid "Adding new topology column <%s>..."
-#: ../lib/gis/parser_standard_options.c:836
+#: ../lib/vector/Vlib/write_pg.c:1072 ../lib/vector/Vlib/open_pg.c:85
+#: ../lib/vector/Vlib/open_pg.c:232
+msgid "Connection string not defined"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1077 ../lib/vector/Vlib/write_pg.c:1216
+#: ../lib/vector/Vlib/write_pg.c:1368 ../lib/vector/Vlib/open_pg.c:90
+#: ../lib/vector/Vlib/open_pg.c:237
#, fuzzy
-msgid "Name of the output space time raster3d dataset"
+msgid "PostGIS feature table not defined"
-#: ../lib/gis/parser_standard_options.c:845
-#, fuzzy
-msgid "Type of the input space time dataset"
+#: ../lib/vector/Vlib/write_pg.c:1104 ../lib/vector/Vlib/write_ogr.c:304
+#, c-format
+msgid "Unsupported geometry type (%d)"
+msgstr ""
-#: ../lib/gis/parser_standard_options.c:853
-#, fuzzy
-msgid "Name of the input map"
+#: ../lib/vector/Vlib/write_pg.c:1117 ../lib/vector/Vlib/write_ogr.c:338
+#, c-format
+msgid "More layers defined, using driver <%s> and database <%s>"
+msgstr ""
-#: ../lib/gis/parser_standard_options.c:862
-#, fuzzy
-msgid "Name of the input maps"
+#: ../lib/vector/Vlib/write_pg.c:1122 ../lib/vector/Vlib/write_ogr.c:344
+msgid "Database connection not defined. Unable to write attributes."
+msgstr ""
-#: ../lib/gis/parser_standard_options.c:871
+#: ../lib/vector/Vlib/write_pg.c:1129
#, fuzzy
-msgid "Type of the input map"
+msgid "Unable to create new PostGIS feature table"
-#: ../lib/gis/parser_standard_options.c:880
+#: ../lib/vector/Vlib/write_pg.c:1143
#, fuzzy
-msgid "The temporal type of the space time dataset"
+msgid "Unable to create new PostGIS topology schema"
+msgstr "Datum %s 테이블파일을 열 수 없습니다"
-#: ../lib/gis/parser_standard_options.c:887
-msgid ""
-"WHERE conditions of SQL statement without 'where' keyword used in the "
-"temporal GIS framework"
+#: ../lib/vector/Vlib/write_pg.c:1237 ../lib/vector/Vlib/write_pg.c:1396
+#: ../lib/vector/Vlib/write_ogr.c:408
+#, c-format
+msgid "No category defined for layer %d"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:888
-msgid "Example: start_time > '2001-01-01 12:30:00'"
+#: ../lib/vector/Vlib/write_pg.c:1239 ../lib/vector/Vlib/write_pg.c:1398
+#: ../lib/vector/Vlib/write_ogr.c:410
+#, c-format
+msgid "Feature has more categories, using category %d (from layer %d)"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:898
-msgid "The method to be used for sampling the input dataset"
+#: ../lib/vector/Vlib/write_pg.c:1250
+#, fuzzy, c-format
+msgid "Point skipped (output feature type: %s)"
+msgstr "알려지지 않은 벡터타입입니다"
+#: ../lib/vector/Vlib/write_pg.c:1257
+#, fuzzy, c-format
+msgid "Line skipped (output feature type: %s)"
+#: ../lib/vector/Vlib/write_pg.c:1264
+#, c-format
+msgid "Boundary/centroid skipped (output feature type: %s)"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:932
+#: ../lib/vector/Vlib/write_pg.c:1266 ../lib/vector/Vlib/write_ogr.c:439
+msgid "Feature is not a polygon. Skipping."
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1272
+#, fuzzy, c-format
+msgid "Face skipped (output feature type: %s)"
+#: ../lib/vector/Vlib/write_pg.c:1358
+#, fuzzy, c-format
+msgid "Invalid feature type (%d) for nodes"
+#: ../lib/vector/Vlib/write_pg.c:1372
#, fuzzy
-msgid "Do not create attribute table"
+msgid "PostGIS topology schema not defined"
-#: ../lib/gis/parser_standard_options.c:936
-msgid "Do not build topology"
+#: ../lib/vector/Vlib/write_pg.c:1872
+msgid "Trying to insert 3D data into feature table which store 2D data only"
msgstr ""
-#: ../lib/gis/parser_standard_options.c:937
-msgid "Advantageous when handling a large number of points"
+#: ../lib/vector/Vlib/write_pg.c:1877
+msgid "Trying to insert 2D data into feature table which store 3D data only"
msgstr ""
-#: ../lib/gis/get_window.c:118
+#: ../lib/vector/Vlib/write_pg.c:1902
+#, fuzzy
+msgid "Unable to insert topological element into PostGIS Topology schema"
+#: ../lib/vector/Vlib/write_pg.c:2005 ../lib/vector/Vlib/write_ogr.c:579
#, fuzzy, c-format
-msgid "Unable to open element file <%s> for <%s@%s>"
+msgid "Unable to select attributes for category %d"
-#: ../lib/gis/get_window.c:123
+#: ../lib/vector/Vlib/write_pg.c:2009 ../lib/vector/Vlib/write_ogr.c:585
+#: ../lib/db/dbmi_client/copy_tab.c:338
+#, fuzzy, c-format
+msgid "Unable to fetch data from table <%s>"
+#: ../lib/vector/Vlib/write_pg.c:2014 ../lib/vector/Vlib/write_ogr.c:591
#, c-format
-msgid "Region file %s/%s/%s is empty"
+msgid "No database record for category %d, no attributes will be written"
msgstr ""
-#: ../lib/gis/debug.c:80
+#: ../lib/vector/Vlib/write_pg.c:2040
#, c-format
-msgid "Cannot open debug file '%s'"
-msgstr "'%s' 디버그파일을 열 수 없습니다."
+msgid "FID column must be integer, column <%s> ignored!"
+msgstr ""
-#: ../lib/gis/alloc.c:44 ../lib/gis/alloc.c:86 ../lib/gis/alloc.c:132
-#, c-format
-msgid "Current region rows: %d, cols: %d"
+#: ../lib/vector/Vlib/write_pg.c:2074 ../lib/vector/Vlib/write_ogr.c:653
+#, fuzzy, c-format
+msgid "Unsupported column type %d"
+#: ../lib/vector/Vlib/write_pg.c:2081
+msgid "Invalid value for FID column: NULL"
msgstr ""
-#: ../lib/gis/alloc.c:47
-#, c-format
-msgid "G_malloc: unable to allocate %lu bytes of memory at %s:%d"
+#: ../lib/vector/Vlib/write_pg.c:2173
+#, fuzzy, c-format
+msgid "Invalid feature %d (max: %d)"
+#: ../lib/vector/Vlib/write_pg.c:2187
+#, fuzzy, c-format
+msgid "Invalid feature type (%d) for node"
+#: ../lib/vector/Vlib/write_pg.c:2191
+#, fuzzy, c-format
+msgid "Invalid node %d (%d)"
+#: ../lib/vector/Vlib/write_pg.c:2269
+#, fuzzy, c-format
+msgid "Unable to determine next left/right edge for edge %d"
+#: ../lib/vector/Vlib/write_pg.c:2274
+#, fuzzy
+msgid "Unable to insert new edge. Topology not available."
+#: ../lib/vector/Vlib/write_pg.c:2373 ../lib/vector/Vlib/write_pg.c:2380
+msgid "Invalid topology"
msgstr ""
-#: ../lib/gis/alloc.c:89
+#: ../lib/vector/Vlib/write_pg.c:2579 ../lib/vector/Vlib/write_pg.c:2676
+#, fuzzy, c-format
+msgid "Attempt to access non-existing feature %d"
+#: ../lib/vector/Vlib/write_pg.c:2610
+#, fuzzy
+msgid "Unable to determine next left/right edge"
+#: ../lib/vector/Vlib/write_pg.c:2696
+#, fuzzy
+msgid "Unable to create new face"
+#: ../lib/vector/Vlib/write_pg.c:2834 ../lib/vector/Vlib/write_pg.c:2846
+#, fuzzy, c-format
+msgid "Unable to delete node %d"
+#: ../lib/vector/Vlib/write_pg.c:2902 ../lib/vector/Vlib/ascii.c:404
+#: ../lib/vector/Vlib/write_ogr.c:192 ../lib/db/dbmi_client/db.c:41
+#: ../lib/db/dbmi_client/copy_tab.c:107 ../lib/db/dbmi_client/copy_tab.c:127
+#, fuzzy, c-format
+msgid "Unable to start driver <%s>"
+#: ../lib/vector/Vlib/net_analyze.c:198 ../lib/vector/Vlib/graph.c:226
#, c-format
-msgid "G_calloc: unable to allocate %lu * %lu bytes of memory at %s:%d"
+msgid "dglShortestPath error: %s"
msgstr ""
-#: ../lib/gis/alloc.c:135
+#: ../lib/vector/Vlib/net_analyze.c:288 ../lib/vector/Vlib/net_analyze.c:329
#, c-format
-msgid "G_realloc: unable to allocate %lu bytes of memory at %s:%d"
+msgid "Unable to find point with defined unique category for node <%d>."
msgstr ""
-#: ../lib/gis/units.c:208
-msgid "square units"
+#: ../lib/vector/Vlib/net_analyze.c:292 ../lib/vector/Vlib/net_analyze.c:333
+#, c-format
+msgid ""
+"There exists more than one point on node <%d> with unique category in field "
+"<%d>.\n"
+"The unique category layer may not be valid."
msgstr ""
-msgid "square unit"
+#: ../lib/vector/Vlib/net_analyze.c:449
+msgid "Wrong line direction in Vect_net_get_line_cost()"
msgstr ""
-#: ../lib/gis/units.c:210
-msgid "units"
+#: ../lib/vector/Vlib/map.c:139 ../lib/vector/Vlib/map.c:245
+msgid "Vector map name is not SQL compliant"
msgstr ""
-msgid "unit"
-msgstr ""
+#: ../lib/vector/Vlib/map.c:143
+#, fuzzy, c-format
+msgid "Unable to find vector map <%s> in <%s>"
-#: ../lib/gis/units.c:215
-msgid "square meters"
+#: ../lib/vector/Vlib/map.c:155 ../lib/vector/Vlib/map.c:249
+#: ../lib/vector/Vlib/open.c:821
+#, c-format
+msgid "Vector map <%s> already exists and will be overwritten"
msgstr ""
-msgid "square meter"
-msgstr ""
+#: ../lib/vector/Vlib/map.c:159 ../lib/vector/Vlib/open.c:813
+#: ../lib/vector/Vlib/open.c:826
+#, fuzzy, c-format
+msgid "Unable to delete vector map <%s>"
-#: ../lib/gis/units.c:217
-msgid "meters"
-msgstr ""
+#: ../lib/vector/Vlib/map.c:179 ../lib/vector/Vlib/map.c:267
+#, fuzzy, c-format
+msgid "Unable to copy vector map <%s> to <%s>"
-msgid "meter"
-msgstr ""
+#: ../lib/vector/Vlib/map.c:331 ../lib/vector/Vlib/map.c:462
+#, fuzzy, c-format
+msgid "Unable to delete table <%s>"
-#: ../lib/gis/units.c:222
-msgid "square kilometers"
+#: ../lib/vector/Vlib/map.c:346
+#, c-format
+msgid "Unable to create index for table <%s>, key <%s>"
msgstr ""
-msgid "square kilometer"
+#: ../lib/vector/Vlib/map.c:402
+#, c-format
+msgid "Ignoring invalid mapset: %s"
msgstr ""
-#: ../lib/gis/units.c:224
-msgid "kilometers"
+#: ../lib/vector/Vlib/map.c:407
+#, fuzzy, c-format
+msgid "Invalid vector map name <%s>"
+#: ../lib/vector/Vlib/map.c:417
+#, fuzzy, c-format
+msgid "Unable to open header file for vector map <%s>"
+#: ../lib/vector/Vlib/map.c:449
+#, fuzzy, c-format
+msgid "Unable to find table <%s> linked to vector map <%s>"
+#: ../lib/vector/Vlib/map.c:472
+#, fuzzy, c-format
+msgid "Table <%s> linked to vector map <%s> does not exist"
+#: ../lib/vector/Vlib/map.c:485
+#, fuzzy, c-format
+msgid "Unable to open directory '%s'"
+#: ../lib/vector/Vlib/map.c:499
+#, fuzzy, c-format
+msgid "Unable to delete file '%s'"
+#: ../lib/vector/Vlib/map.c:519
+#, fuzzy, c-format
+msgid "Unable to rename directory '%s' to '%s'"
+#: ../lib/vector/Vlib/map.c:528
+#, fuzzy, c-format
+msgid "Unable to remove directory '%s': %s"
+#: ../lib/vector/Vlib/dangles.c:148
+msgid "Changed"
msgstr ""
-msgid "kilometer"
+#: ../lib/vector/Vlib/dangles.c:151
+msgid "Removed"
msgstr ""
-#: ../lib/gis/units.c:229
-msgid "acres"
+#: ../lib/vector/Vlib/dangles.c:154
+msgid "Selected"
msgstr ""
-msgid "acre"
+#: ../lib/vector/Vlib/dangles.c:262
+#, fuzzy, c-format
+msgid "%s lines: %d"
+#: ../lib/vector/Vlib/dangles.c:263
+#, c-format
+msgid "%s dangles: %d"
msgstr ""
-#: ../lib/gis/units.c:237
-msgid "hectares"
+#: ../lib/vector/Vlib/net_build.c:101 ../lib/vector/Vlib/net_build.c:727
+msgid "Building graph..."
msgstr ""
-msgid "hectare"
+#: ../lib/vector/Vlib/net_build.c:143 ../lib/vector/Vlib/net_build.c:775
+#, fuzzy
+msgid "Unable to build network graph"
+#: ../lib/vector/Vlib/net_build.c:149 ../lib/vector/Vlib/net_build.c:781
+msgid "Forward costs column not specified"
msgstr ""
-#: ../lib/gis/units.c:245
-msgid "square miles"
+#: ../lib/vector/Vlib/net_build.c:156
+msgid "Turntable field < 1"
msgstr ""
-msgid "square mile"
+#: ../lib/vector/Vlib/net_build.c:172
+#, fuzzy, c-format
+msgid "Turntable column <%s> not found in table <%s>"
+#: ../lib/vector/Vlib/net_build.c:182 ../lib/vector/Vlib/net_build.c:223
+#: ../lib/vector/Vlib/net_build.c:508 ../lib/vector/Vlib/net_build.c:526
+#: ../lib/vector/Vlib/net_build.c:809 ../lib/vector/Vlib/net_build.c:827
+#: ../lib/vector/Vlib/net_build.c:988
+#, c-format
+msgid "Data type of column <%s> not supported (must be numeric)"
msgstr ""
-#: ../lib/gis/units.c:247
-msgid "miles"
+#: ../lib/vector/Vlib/net_build.c:202 ../lib/vector/Vlib/net_build.c:967
+msgid "Setting node costs..."
msgstr ""
-msgid "mile"
+#: ../lib/vector/Vlib/net_build.c:216 ../lib/vector/Vlib/net_build.c:501
+#: ../lib/vector/Vlib/net_build.c:519 ../lib/vector/Vlib/net_build.c:802
+#: ../lib/vector/Vlib/net_build.c:820 ../lib/vector/Vlib/net_build.c:981
+#: ../lib/vector/Vlib/ascii.c:756
+#, fuzzy, c-format
+msgid "Column <%s> not found in table <%s>"
+#: ../lib/vector/Vlib/net_build.c:277 ../lib/vector/Vlib/net_build.c:1032
+#, c-format
+msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
msgstr ""
-#: ../lib/gis/units.c:252
-msgid "square feet"
+#: ../lib/vector/Vlib/net_build.c:332 ../lib/vector/Vlib/net_build.c:352
+#, fuzzy
+msgid "Cannot add network arc for virtual node connection."
+#: ../lib/vector/Vlib/net_build.c:364
+#, c-format
+msgid ""
+"There exists more than one point of node <%d> with unique category field <"
+"%d>.\n"
+"The unique categories layer is not valid therefore you will probably get "
+"incorrect results."
msgstr ""
-msgid "square foot"
+#: ../lib/vector/Vlib/net_build.c:393
+#, c-format
+msgid ""
+"Unable to find point representing intersection <%d> in unique categories "
+"field <%d>.\n"
+"Cost for the intersection was set to 0.\n"
msgstr ""
-#: ../lib/gis/units.c:254
-msgid "feet"
+#: ../lib/vector/Vlib/net_build.c:407
+#, c-format
+msgid ""
+"Unable to find node for point representing intersection <%d> in unique "
+"categories field <%d>.\n"
msgstr ""
-msgid "foot"
+#: ../lib/vector/Vlib/net_build.c:432
+#, c-format
+msgid ""
+"Database record for turn with cat = %d in not found. (The turn was skipped."
msgstr ""
-#: ../lib/gis/units.c:259
-msgid "square US feet"
+#: ../lib/vector/Vlib/net_build.c:465
+#, fuzzy
+msgid "Cannot add network arc representing turn."
+#: ../lib/vector/Vlib/net_build.c:487 ../lib/vector/Vlib/net_build.c:788
+msgid "Arc field < 1"
msgstr ""
-msgid "square US foot"
+#: ../lib/vector/Vlib/net_build.c:539 ../lib/vector/Vlib/net_build.c:840
+msgid "Registering arcs..."
msgstr ""
-#: ../lib/gis/units.c:261
-msgid "US feet"
+#: ../lib/vector/Vlib/net_build.c:558
+#, c-format
+msgid ""
+"Line with id <%d> has more unique categories defined in field <%d>.\n"
msgstr ""
-msgid "US foot"
+#: ../lib/vector/Vlib/net_build.c:579
+#, c-format
+msgid ""
+"Database record for line %d (cat = %d, forward/both direction(s)) not found "
+"(cost was set to 0)"
msgstr ""
-#: ../lib/gis/units.c:266
-msgid "square degrees"
+#: ../lib/vector/Vlib/net_build.c:596
+#, c-format
+msgid ""
+"Database record for line %d (cat = %d, backword direction) not found(cost "
+"was set to 0)"
msgstr ""
-msgid "square degree"
+#: ../lib/vector/Vlib/net_build.c:658 ../lib/vector/Vlib/net_build.c:1064
+msgid "Flattening the graph..."
msgstr ""
-#: ../lib/gis/units.c:268
-msgid "degrees"
+#: ../lib/vector/Vlib/net_build.c:661 ../lib/vector/Vlib/net_build.c:1067
+#: ../lib/vector/Vlib/graph.c:105 ../lib/vector/neta/flow.c:331
+msgid "GngFlatten error"
msgstr ""
-msgid "degree"
+#: ../lib/vector/Vlib/net_build.c:667 ../lib/vector/Vlib/net_build.c:1073
+msgid "Graph was built"
msgstr ""
-#: ../lib/gis/units.c:272
-msgid "years"
+#: ../lib/vector/Vlib/net_build.c:869
+#, c-format
+msgid ""
+"(forward/both direction(s) of line skipped)"
msgstr ""
-msgid "year"
+#: ../lib/vector/Vlib/net_build.c:888
+#, c-format
+msgid ""
+"Database record for line %d (cat = %d, backword direction) not "
+"found(direction of line skipped)"
msgstr ""
-#: ../lib/gis/units.c:276
-msgid "months"
+#: ../lib/vector/Vlib/net_build.c:937
+#, fuzzy
+msgid "Cannot add network arc"
+#: ../lib/vector/Vlib/open.c:138
+#, c-format
+msgid "Programmer requested unknown access level %d"
msgstr ""
-msgid "month"
+#: ../lib/vector/Vlib/open.c:232
+#, fuzzy, c-format
+msgid "Vector map <%s> not found in current mapset"
+#: ../lib/vector/Vlib/open.c:252
+#, fuzzy
+msgid "Temporary vector maps can be accessed only in the current mapset"
+#: ../lib/vector/Vlib/open.c:277
+msgid ""
+"Vector map which is not in the current mapset cannot be opened for update"
msgstr ""
-#: ../lib/gis/units.c:280
-msgid "days"
+#: ../lib/vector/Vlib/open.c:311
+#, fuzzy, c-format
+msgid "Unable to read header file of vector map <%s>"
+#: ../lib/vector/Vlib/open.c:352
+#, fuzzy, c-format
+msgid "Unable to open topology file for vector map <%s>"
+#: ../lib/vector/Vlib/open.c:393 ../lib/vector/Vlib/cindex.c:539
+#, fuzzy, c-format
+msgid "Unable to open category index file for vector map <%s>"
+#: ../lib/vector/Vlib/open.c:419
+#, fuzzy, c-format
+msgid ""
+"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
+"with v.build."
+#: ../lib/vector/Vlib/open.c:445
+#, fuzzy, c-format
+msgid "Building topology for OGR layer <%s> from datasource '%s'..."
+#: ../lib/vector/Vlib/open.c:453
+#, fuzzy, c-format
+msgid "Unable to open vector map <%s> on level %d"
+#: ../lib/vector/Vlib/open.c:507
+#, fuzzy, c-format
+msgid "Unable to open history file for vector map <%s>"
+#: ../lib/vector/Vlib/open.c:777
+#, fuzzy, c-format
+msgid "Unable to create vector map: <%s> is not in the current mapset (%s)"
+#: ../lib/vector/Vlib/open.c:786
+#, fuzzy, c-format
+msgid "Unable to create vector map: <%s> is not SQL compliant"
+#: ../lib/vector/Vlib/open.c:846
+#, fuzzy, c-format
+msgid "Unable to open history file of vector map <%s>"
+#: ../lib/vector/Vlib/open.c:887
+#, c-format
+msgid "Using OGR/%s format"
msgstr ""
-msgid "day"
+#: ../lib/vector/Vlib/open.c:891
+msgid "Using PostGIS Topology format"
msgstr ""
-#: ../lib/gis/units.c:284
-msgid "hours"
+#: ../lib/vector/Vlib/open.c:893
+msgid "Using PostGIS format"
msgstr ""
-msgid "hour"
+#: ../lib/vector/Vlib/open.c:896
+#, fuzzy
+msgid "Using native format"
+msgstr "잘못된 좌표"
+#: ../lib/vector/Vlib/open.c:985
+#, fuzzy, c-format
+msgid "Unable to stat file <%s>"
+#: ../lib/vector/Vlib/open.c:1049
+#, c-format
+msgid "unknown %d (update Vect_maptype_info)"
msgstr ""
-#: ../lib/gis/units.c:288
-msgid "minutes"
+#: ../lib/vector/Vlib/open.c:1138
+msgid "Size of 'coor' file differs from value saved in topology file"
msgstr ""
-msgid "minute"
+#: ../lib/vector/Vlib/open.c:1149 ../lib/vector/Vlib/open.c:1248
+#, fuzzy, c-format
+msgid "Please rebuild topology for vector map <%s@%s>"
+#: ../lib/vector/Vlib/open.c:1237
+msgid "Size of 'coor' file differs from value saved in sidx file"
msgstr ""
-#: ../lib/gis/units.c:292
-msgid "seconds"
+#: ../lib/vector/Vlib/open.c:1317
+#, fuzzy
+msgid "Unable to open OGR file"
+#: ../lib/vector/Vlib/open.c:1343
+msgid "OGR output also detected, using OGR"
msgstr ""
-msgid "second"
+#: ../lib/vector/Vlib/open_pg.c:109 ../lib/vector/Vlib/open_pg.c:267
+#, fuzzy
+msgid "No feature tables found in database."
+#: ../lib/vector/Vlib/open_pg.c:133
+#, fuzzy, c-format
+msgid "Feature table <%s> not found in 'geometry_columns'"
+#: ../lib/vector/Vlib/open_pg.c:181
+msgid "Topology schema not found."
msgstr ""
-#: ../lib/gis/parser.c:355
+#: ../lib/vector/Vlib/open_pg.c:193 ../lib/vector/Vlib/open_ogr.c:145
+#, fuzzy, c-format
+msgid "Unable to open feature index file for vector map <%s>"
+#: ../lib/vector/Vlib/open_pg.c:273
+#, fuzzy, c-format
+msgid "PostGIS layer <%s.%s> already exists and will be overwritten"
+#: ../lib/vector/Vlib/open_pg.c:276
+#, fuzzy, c-format
+msgid "Unable to delete PostGIS layer <%s>"
+#: ../lib/vector/Vlib/open_pg.c:282
+#, fuzzy, c-format
+msgid "PostGIS layer <%s.%s> already exists in database '%s'"
+#: ../lib/vector/Vlib/open_pg.c:390
+#, fuzzy
+msgid "No key column detected."
+#: ../lib/vector/Vlib/open_pg.c:462 ../lib/vector/Vlib/open_pg.c:474
#, c-format
-msgid "BUG in option name, '%s' is not valid"
+msgid "Execution failed: %s"
msgstr ""
-#: ../lib/gis/parser.c:407
+#: ../lib/vector/Vlib/open_pg.c:476
#, c-format
-msgid "BUG in descriptions, option '%s' in <%s> does not exist"
+msgid "PostGIS topology schema <%s> dropped"
msgstr ""
-#: ../lib/gis/parser.c:525
-msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
+#: ../lib/vector/Vlib/open_pg.c:559
+msgid ""
+"Connection to PostgreSQL database failed. Try to set up username/password by "
+"db.login."
msgstr ""
-#: ../lib/gis/parser.c:539
-msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
+#: ../lib/vector/Vlib/open_pg.c:566
+#, fuzzy
+msgid "Unable to get database name"
+msgstr "임시파일을 열 수 없습니다"
+#: ../lib/vector/Vlib/open_pg.c:571
+#, c-format
+msgid "<%s> is not PostGIS database. DB table 'spatial_ref_sys' not found."
msgstr ""
-#: ../lib/gis/parser.c:554
-msgid "Use either --qq or --verbose flag, not both. Assuming --qq."
+#: ../lib/vector/Vlib/open_pg.c:580
+#, fuzzy, c-format
+msgid "PostGIS Topology extension not found in the database <%s>"
+#: ../lib/vector/Vlib/open_pg.c:667
+msgid "Empty bounding box"
msgstr ""
-#: ../lib/gis/parser.c:585
+#: ../lib/vector/Vlib/open_pg.c:768
#, c-format
-msgid "Sorry <%s> is not a valid option"
+msgid "Inconsistency in topology: unable to read node %d"
msgstr ""
-#: ../lib/gis/parser.c:598
-msgid "Your installation doesn't include GUI, exiting."
-msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:834
+#, fuzzy, c-format
+msgid "Inconsistency in topology: node %d - unexpected feature type %d"
-#: ../lib/gis/parser.c:621 ../lib/init/grass.py:187
-msgid "ERROR"
-msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1003
+#, fuzzy, c-format
+msgid "Area %d without boundary detected"
-#: ../lib/gis/parser.c:941
-msgid "Unable to determine program name"
+#: ../lib/vector/Vlib/open_pg.c:1061
+#, c-format
+msgid "Isle %d without boundary detected"
msgstr ""
-#: ../lib/gis/parser.c:963 ../lib/gis/parser.c:980
+#: ../lib/vector/Vlib/open_pg.c:1128
+#, fuzzy
+msgid "Unable to get map bounding box from topology"
+#: ../lib/vector/Vlib/open_pg.c:1135
+#, fuzzy, c-format
+msgid ""
+"Unable to parse map bounding box:\n"
+"%s"
+#: ../lib/vector/Vlib/open_pg.c:1159
#, c-format
-msgid "%s: Sorry, <%c> is not a valid flag"
+msgid "Different number of nodes detected (%d, %d)"
msgstr ""
-#: ../lib/gis/parser.c:1110
+#: ../lib/vector/Vlib/open_pg.c:1187 ../lib/vector/Vlib/open_pg.c:1209
#, c-format
-msgid "%s: Sorry, <%s=> is ambiguous"
+msgid "Different number of areas detected (%d, %d)"
msgstr ""
-#: ../lib/gis/parser.c:1113
-#, c-format
-msgid "Option <%s=> matches"
+#: ../lib/vector/Vlib/open_pg.c:1380
+msgid "To be implemented: isles not attached in Topo-Geo-only mode"
msgstr ""
-#: ../lib/gis/parser.c:1131
+#: ../lib/vector/Vlib/open_pg.c:1569
#, c-format
-msgid "Please update the usage of <%s>: option <%s> has been renamed to <%s>"
+msgid "Inconsistency in topology: number of points %d (should be %d)"
msgstr ""
-#: ../lib/gis/parser.c:1144
+#: ../lib/vector/Vlib/open_pg.c:1614
#, c-format
-msgid "%s: Sorry, <%s> is not a valid parameter"
+msgid "Inconsistency in topology: number of lines %d (should be %d)"
msgstr ""
-#: ../lib/gis/parser.c:1150 ../lib/gis/parser.c:1396
+#: ../lib/vector/Vlib/open_pg.c:1668
#, c-format
-msgid "<%s> is an abbreviation for <%s>"
+msgid "Inconsistency in topology: number of centroids %d (should be %d)"
msgstr ""
-#: ../lib/gis/parser.c:1155
+#: ../lib/vector/Vlib/cats.c:45
+msgid "Vect_new_cats_struct(): Out of memory"
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:127
#, c-format
-msgid "Option <%s> does not accept multiple answers"
+msgid "Too many categories (%d), unable to set cat %d (layer %d)"
msgstr ""
-#: ../lib/gis/parser.c:1227
+#: ../lib/vector/Vlib/cats.c:419
#, c-format
-msgid ""
-"Illegal range syntax for parameter <%s>\n"
-"\tPresented as: %s"
+msgid "Unable to convert category string '%s' (from '%s') to category range"
msgstr ""
-#: ../lib/gis/parser.c:1233
+#: ../lib/vector/Vlib/cats.c:572 ../lib/vector/Vlib/cats.c:668
+msgid "Layer number must be > 0 for category constraints"
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:585
#, c-format
-msgid ""
-"Value <%s> out of range for parameter <%s>\n"
-"\tLegal range: %s"
+msgid "'%s' and '%s' parameters were supplied, cats will be ignored"
msgstr ""
-#: ../lib/gis/parser.c:1239
+#: ../lib/vector/Vlib/cats.c:593
#, fuzzy, c-format
-msgid "Missing value for parameter <%s>"
+msgid "Loading categories from table <%s>..."
-#: ../lib/gis/parser.c:1245
-#, c-format
-msgid ""
-"Value <%s> ambiguous for parameter <%s>\n"
-"\tValid options: %s"
-msgstr ""
+#: ../lib/vector/Vlib/cats.c:603 ../lib/db/dbmi_client/select.c:317
+#, fuzzy, c-format
+msgid "Unable select records from table <%s>"
-#: ../lib/gis/parser.c:1418
-#, c-format
-msgid ""
-"Required parameter <%s> not set:\n"
-"\t(%s)"
-msgstr ""
+#: ../lib/vector/Vlib/cats.c:605
+#, fuzzy, c-format
+msgid "One category loaded"
+msgid_plural "%d categories loaded"
+msgstr[0] "카테고리 정보가 없습니다."
-#: ../lib/gis/parser.c:1510
+#: ../lib/vector/Vlib/cats.c:627
#, c-format
-msgid ""
-"Option <%s> must be provided in multiples of %d\n"
-"\tYou provided %d item(s): %s"
+msgid "No categories selected with '%s' option"
msgstr ""
-#: ../lib/gis/parser.c:1584 ../lib/gis/error.c:362
+#: ../lib/vector/Vlib/cats.c:637
#, c-format
-msgid "ERROR: "
+msgid "%d errors in '%s' option"
msgstr ""
-#: ../lib/gis/parser.c:1586 ../lib/gis/parser.c:1593
-#, c-format
-msgid "option <%s>: <%s> exists. To overwrite, use the --overwrite flag"
-msgstr ""
+#: ../lib/vector/Vlib/header.c:86
+#, fuzzy, c-format
+msgid "Unable to create header file for vector map <%s>"
-#: ../lib/gis/parser.c:1703
+#: ../lib/vector/Vlib/header.c:129
+#, fuzzy, c-format
+msgid "Unable to open header file of vector <%s>"
+#: ../lib/vector/Vlib/header.c:137
#, c-format
-msgid "%s= is not a separator option"
+msgid "Corrupted row in head: %s"
msgstr ""
-#: ../lib/gis/parser.c:1706
+#: ../lib/vector/Vlib/header.c:175
#, c-format
-msgid "No separator given for %s="
+msgid "Unknown keyword '%s' in vector head"
msgstr ""
-#: ../lib/gis/parser.c:1768 ../lib/gis/parser.c:1785
-#, fuzzy, c-format
-msgid "%s= is not a file option"
+#: ../lib/vector/Vlib/header.c:552 ../lib/gis/proj3.c:121
+msgid "Unknown projection"
msgstr ""
-"\n"
-"**<%s> 잘못된 이름 **\n"
-#: ../lib/gis/parser.c:1770
+#: ../lib/vector/Vlib/level_two.c:23
#, fuzzy, c-format
-msgid "Opening multiple files not supported for %s="
+msgid "Vector map <%s> is not open at topological level"
-#: ../lib/gis/parser.c:1776
+#: ../lib/vector/Vlib/level_two.c:284
#, fuzzy, c-format
-msgid "Unable to open %s file <%s>"
+msgid "Invalid node id: %d"
-#: ../lib/gis/parser.c:1782
+#: ../lib/vector/Vlib/level_two.c:316
#, fuzzy, c-format
-msgid "Unable to create %s file <%s>"
+msgid "Nodes not available for line %d"
-#: ../lib/gis/worker.c:84
-msgid "Task already has a worker"
-msgstr ""
+#: ../lib/vector/Vlib/level_two.c:357
+#, fuzzy, c-format
+msgid "Areas not available for line %d"
-#: ../lib/gis/adj_cellhd.c:42
+#: ../lib/vector/Vlib/level_two.c:362
#, fuzzy, c-format
-msgid "Illegal n-s resolution value <%lf>"
-msgstr "잘못된 n-s 해상도값입니다."
+msgid "Line %d is not a boundary"
-#: ../lib/gis/adj_cellhd.c:46 ../lib/gis/adj_cellhd.c:197
-msgid "Illegal row value"
-msgstr "잘못된 row 값입니다."
+#: ../lib/vector/Vlib/level_two.c:445
+#, fuzzy, c-format
+msgid "Topology info not available for feature %d"
-#: ../lib/gis/adj_cellhd.c:50 ../lib/gis/adj_cellhd.c:203
-msgid "Illegal e-w resolution value"
-msgstr "잘못된 e-w 해상도값입니다."
+#: ../lib/vector/Vlib/write_sfa.c:117
+#, fuzzy
+msgid "Unable to calculate centroid for area"
-#: ../lib/gis/adj_cellhd.c:54 ../lib/gis/adj_cellhd.c:209
-msgid "Illegal col value"
-msgstr "잘못된 col 값입니다."
-#: ../lib/gis/adj_cellhd.c:74 ../lib/gis/adj_cellhd.c:239
-#, c-format
-msgid "Fixing subtle input data rounding error of north boundary (%g>%g)"
+#: ../lib/vector/Vlib/write_sfa.c:131 ../lib/vector/Vlib/write_sfa.c:173
+#: ../lib/vector/Vlib/write_sfa.c:273 ../lib/vector/Vlib/read_sfa.c:124
+msgid "GRASS is not compiled with OGR/PostgreSQL support"
msgstr ""
-#: ../lib/gis/adj_cellhd.c:79 ../lib/gis/adj_cellhd.c:244
-msgid "Illegal latitude for North"
-msgstr "북쪽경계를 위한 잘못된 위도입니다."
+#: ../lib/vector/Vlib/write_sfa.c:219
+#, fuzzy
+msgid "Attempt to delete dead feature"
-#: ../lib/gis/adj_cellhd.c:85 ../lib/gis/adj_cellhd.c:250
-#, c-format
-msgid "Fixing subtle input data rounding error of south boundary (%g>%g)"
-msgstr ""
+#: ../lib/vector/Vlib/write_sfa.c:311
+#, fuzzy, c-format
+msgid "Unsupported vector map format (%d)"
-#: ../lib/gis/adj_cellhd.c:90 ../lib/gis/adj_cellhd.c:255
-msgid "Illegal latitude for South"
-msgstr "남쪽경계를 위한 잘못된 위도입니다."
+#: ../lib/vector/Vlib/write.c:194
+#, fuzzy, c-format
+msgid "Unable to write feature in vector map <%s>"
-#: ../lib/gis/adj_cellhd.c:102 ../lib/gis/adj_cellhd.c:267
-#, c-format
-msgid "Fixing subtle input data rounding error of west boundary (%g>%g)"
-msgstr ""
+#: ../lib/vector/Vlib/write.c:234
+#, fuzzy, c-format
+msgid "Unable to rewrite feature/offset %lu in vector map <%s>"
-#: ../lib/gis/adj_cellhd.c:113 ../lib/gis/adj_cellhd.c:278
-#, c-format
-msgid "Fixing subtle input data rounding error of east boundary (%g>%g)"
-msgstr ""
+#: ../lib/vector/Vlib/write.c:266
+#, fuzzy, c-format
+msgid "Unable to delete feature/offset %lu from vector map <%s>"
-#: ../lib/gis/adj_cellhd.c:126 ../lib/gis/adj_cellhd.c:291
-msgid "North must be north of South"
-msgstr "북쪽경계는 남쪽경계보다 위쪽이어야합니다."
+#: ../lib/vector/Vlib/write.c:299
+#, fuzzy
+msgid "Unable to restore feature/offset %"
-#: ../lib/gis/adj_cellhd.c:128 ../lib/gis/adj_cellhd.c:293
-msgid "North must be larger than South"
-msgstr "북쪽경계는 남쪽경계보다 값이 커야합니다."
+#: ../lib/vector/Vlib/write.c:308
+#, fuzzy, c-format
+msgid "Vector map <%s> is not opened"
-#: ../lib/gis/adj_cellhd.c:131 ../lib/gis/adj_cellhd.c:296
-msgid "East must be larger than West"
-msgstr "동쪽경계는 서쪽경계보다 값이 커야합니다."
+#: ../lib/vector/Vlib/write.c:313
+#, fuzzy, c-format
+msgid "Vector map <%s> is not opened in write mode"
-#: ../lib/gis/adj_cellhd.c:150 ../lib/gis/adj_cellhd.c:340
-msgid "Invalid coordinates"
-msgstr "잘못된 좌표입니다."
+#: ../lib/vector/Vlib/ascii.c:84
+#, fuzzy, c-format
+msgid "Error reading ASCII file: (bad type) [%s]"
-#: ../lib/gis/adj_cellhd.c:191
-msgid "Illegal n-s resolution value"
+#: ../lib/vector/Vlib/ascii.c:123
+#, fuzzy, c-format
+msgid "Error reading ASCII file: (unknown type) [%s]"
-#: ../lib/gis/adj_cellhd.c:193
-msgid "Illegal n-s3 resolution value"
-msgstr "잘못된 n-s3 해상도값입니다."
+#: ../lib/vector/Vlib/ascii.c:143
+msgid "End of ASCII file reached before end of coordinates"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:199
-msgid "Illegal row3 value"
-msgstr "잘못된 row3 값입니다."
+#: ../lib/vector/Vlib/ascii.c:155
+#, fuzzy, c-format
+msgid "Error reading ASCII file: (bad point) [%s]"
-#: ../lib/gis/adj_cellhd.c:205
-msgid "Illegal e-w3 resolution value"
-msgstr "잘못된 e-w3 해상도값입니다."
+#: ../lib/vector/Vlib/ascii.c:160
+#, fuzzy, c-format
+msgid "Unparsable longitude value: [%s]"
-#: ../lib/gis/adj_cellhd.c:211
-msgid "Illegal col3 value"
-msgstr "잘못된 col3 값입니다."
+#: ../lib/vector/Vlib/ascii.c:165
+#, c-format
+msgid "Unparsable latitude value: [%s]"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:215
-msgid "Illegal t-b3 resolution value"
-msgstr "잘못된 t-b3 해상도값입니다."
+#: ../lib/vector/Vlib/ascii.c:201
+msgid "End of ASCII file reached before end of categories"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:219
-msgid "Illegal depths value"
-msgstr "잘못된 depth 값입니다."
+#: ../lib/vector/Vlib/ascii.c:212
+#, fuzzy, c-format
+msgid "Error reading categories: [%s]"
-#: ../lib/gis/adj_cellhd.c:299
+#: ../lib/vector/Vlib/ascii.c:225
#, fuzzy
-msgid "Top must be larger than Bottom"
-msgstr "북쪽경계는 남쪽경계보다 값이 커야합니다"
+msgid "Unable to copy points"
-#: ../lib/gis/myname.c:46
-msgid "This location has no description."
+#: ../lib/vector/Vlib/ascii.c:238
+#, c-format
+msgid "Vector map <%s> is 2D. %d 3D features (faces or kernels) skipped."
msgstr ""
-#: ../lib/gis/rd_cellhd.c:141 ../lib/gis/rd_cellhd.c:152
-#: ../lib/gis/rd_cellhd.c:162 ../lib/gis/rd_cellhd.c:179
-#: ../lib/gis/rd_cellhd.c:195 ../lib/gis/rd_cellhd.c:203
-#: ../lib/gis/rd_cellhd.c:211 ../lib/gis/rd_cellhd.c:219
-#: ../lib/gis/rd_cellhd.c:227 ../lib/gis/rd_cellhd.c:235
-#: ../lib/gis/rd_cellhd.c:243 ../lib/gis/rd_cellhd.c:245
-#: ../lib/gis/rd_cellhd.c:253 ../lib/gis/rd_cellhd.c:255
-#: ../lib/gis/rd_cellhd.c:263 ../lib/gis/rd_cellhd.c:265
-#: ../lib/gis/rd_cellhd.c:273 ../lib/gis/rd_cellhd.c:275
-#: ../lib/gis/rd_cellhd.c:283 ../lib/gis/rd_cellhd.c:285
-#: ../lib/gis/rd_cellhd.c:293 ../lib/gis/rd_cellhd.c:295
-#: ../lib/gis/rd_cellhd.c:303 ../lib/gis/rd_cellhd.c:305
-#: ../lib/gis/rd_cellhd.c:313 ../lib/gis/rd_cellhd.c:315
-#: ../lib/gis/rd_cellhd.c:323 ../lib/gis/rd_cellhd.c:325
-#: ../lib/gis/rd_cellhd.c:333 ../lib/gis/rd_cellhd.c:335
-#: ../lib/gis/rd_cellhd.c:343 ../lib/gis/rd_cellhd.c:351
-#: ../lib/gis/rd_cellhd.c:355
-msgid "Syntax error in cell header"
+#: ../lib/vector/Vlib/ascii.c:270
+#, c-format
+msgid ""
+"Unexpected data in vector header:\n"
+"[%s]"
msgstr ""
-#: ../lib/gis/rd_cellhd.c:149
-msgid "Duplicate projection field"
+#: ../lib/vector/Vlib/ascii.c:306
+#, c-format
+msgid "Unknown keyword <%s> in vector head"
msgstr ""
-#: ../lib/gis/rd_cellhd.c:159
-msgid "Duplicate zone field"
-msgstr ""
+#: ../lib/vector/Vlib/ascii.c:465
+#, fuzzy, c-format
+msgid "Column <%s> does not exist"
-#: ../lib/gis/rd_cellhd.c:169 ../lib/gis/rd_cellhd.c:171
-#: ../lib/gis/rd_cellhd.c:360 ../lib/gis/rd_cellhd.c:362
-#: ../lib/gis/rd_cellhd.c:364 ../lib/gis/rd_cellhd.c:366
-#: ../lib/gis/rd_cellhd.c:368 ../lib/gis/rd_cellhd.c:370
-#: ../lib/gis/rd_cellhd.c:381 ../lib/gis/rd_cellhd.c:383
-#: ../lib/gis/rd_cellhd.c:385 ../lib/gis/rd_cellhd.c:387
-#, c-format
-msgid "Field <%s> missing"
+#: ../lib/vector/Vlib/ascii.c:467
+msgid "Available columns:"
msgstr ""
-#: ../lib/gis/rd_cellhd.c:193
-msgid "Duplicate north field"
+#: ../lib/vector/Vlib/ascii.c:472
+msgid "Export cancelled"
msgstr ""
-#: ../lib/gis/rd_cellhd.c:201
-msgid "Duplicate south field"
+#: ../lib/vector/Vlib/ascii.c:505
+#, c-format
+msgid "Unknown type of column <%s>, export cancelled"
msgstr ""
-#: ../lib/gis/rd_cellhd.c:209
-msgid "Duplicate east field"
-msgstr ""
+#: ../lib/vector/Vlib/ascii.c:539
+#, fuzzy, c-format
+msgid "Unable to select record from table <%s> (key %s, column %s)"
-#: ../lib/gis/rd_cellhd.c:217
-msgid "Duplicate west field"
-msgstr ""
+#: ../lib/vector/Vlib/ascii.c:661
+#, fuzzy, c-format
+msgid "Unknown feature type %d"
-#: ../lib/gis/rd_cellhd.c:225
-msgid "Duplicate top field"
+#: ../lib/vector/Vlib/ascii.c:701
+#, c-format
+msgid "Feature has more categories. Only one category (%d) is exported."
msgstr ""
-#: ../lib/gis/rd_cellhd.c:233
-msgid "Duplicate bottom field"
-msgstr ""
+#: ../lib/vector/Vlib/ascii.c:718
+#, fuzzy, c-format
+msgid "Cannot select attributes for cat = %d"
-#: ../lib/gis/rd_cellhd.c:241
+#: ../lib/vector/Vlib/ascii.c:724
#, fuzzy
-msgid "Duplicate e-w resolution field"
-msgstr "잘못된 e-w 해상도"
+msgid "Unable to fetch data from table"
-#: ../lib/gis/rd_cellhd.c:251
-#, fuzzy
-msgid "Duplicate 3D e-w resolution field"
+#: ../lib/vector/Vlib/ascii.c:758
+#, fuzzy, c-format
+msgid "Column <%s>: unsupported data type"
-#: ../lib/gis/rd_cellhd.c:261
+#: ../lib/vector/Vlib/ascii.c:840
#, fuzzy
-msgid "Duplicate n-s resolution field"
-msgstr "잘못된 n-s 해상도"
+msgid "Unknown format"
-#: ../lib/gis/rd_cellhd.c:271
-#, fuzzy
-msgid "Duplicate 3D n-s resolution field"
+#: ../lib/vector/Vlib/ascii.c:850
+msgid "Topology not available, unable to process areas"
+msgstr ""
-#: ../lib/gis/rd_cellhd.c:281
-#, fuzzy
-msgid "Duplicate t-b resolution field"
-msgstr "잘못된 t-b3 해상도"
+#: ../lib/vector/Vlib/ascii.c:863
+#, fuzzy, c-format
+msgid "Unable to get boundary of area id %d"
-#: ../lib/gis/rd_cellhd.c:291
-msgid "Duplicate rows field"
-msgstr ""
+#: ../lib/vector/Vlib/ascii.c:875
+#, fuzzy, c-format
+msgid "Unable to get boundary of isle id %d (area id %d)"
-#: ../lib/gis/rd_cellhd.c:301
-msgid "Duplicate 3D rows field"
+#: ../lib/vector/Vlib/ascii.c:889
+#, c-format
+msgid ""
+"%d features without category skipped. To export also features without "
+"category use '%s=-1'."
msgstr ""
-#: ../lib/gis/rd_cellhd.c:311
-msgid "Duplicate cols field"
+#: ../lib/vector/Vlib/write_ogr.c:129 ../lib/vector/Vlib/open_ogr.c:65
+msgid "OGR layer not defined"
msgstr ""
-#: ../lib/gis/rd_cellhd.c:321
-msgid "Duplicate 3D cols field"
+#: ../lib/vector/Vlib/write_ogr.c:210 ../lib/db/dbmi_client/copy_tab.c:242
+#: ../lib/db/dbmi_client/copy_tab.c:319 ../lib/db/dbmi_client/table.c:110
+#, fuzzy, c-format
+msgid "Unable to open select cursor: '%s'"
+#: ../lib/vector/Vlib/write_ogr.c:239
+#, fuzzy, c-format
+msgid "Creating field <%s> failed"
+#: ../lib/vector/Vlib/write_ogr.c:326
+#, fuzzy, c-format
+msgid "Unable to create OGR layer <%s> in '%s'"
+#: ../lib/vector/Vlib/write_ogr.c:424
+msgid "Feature is not a point. Skipping."
msgstr ""
-#: ../lib/gis/rd_cellhd.c:331
-msgid "Duplicate depths field"
+#: ../lib/vector/Vlib/write_ogr.c:432
+msgid "Feature is not a line. Skipping."
msgstr ""
-#: ../lib/gis/rd_cellhd.c:341
-msgid "Duplicate format field"
+#: ../lib/vector/Vlib/write_ogr.c:446
+msgid "Feature is not a face. Skipping."
msgstr ""
-#: ../lib/gis/rd_cellhd.c:349
-msgid "Duplicate compressed field"
+#: ../lib/vector/Vlib/write_ogr.c:452
+#, fuzzy, c-format
+msgid "Unsupported feature type (%d)"
+#: ../lib/vector/Vlib/write_ogr.c:471
+msgid "Boundary is not closed. Feature skipped."
msgstr ""
-#: ../lib/gis/datum.c:160
-#, c-format
-msgid "unable to open datum table file: %s"
-msgstr "데이텀 테이블파일 %s을 열 수 없습니다."
+#: ../lib/vector/Vlib/write_ogr.c:500
+#, fuzzy
+msgid "Unable to writes feature attributes"
-#: ../lib/gis/datum.c:182
+#: ../lib/vector/Vlib/write_ogr.c:565
#, c-format
-msgid "error in datum table file, line %d"
-msgstr "데이텀 테이블파일의 %d번째 줄에 오류가 있습니다."
-#: ../lib/gis/open_misc.c:49
-#, c-format
-msgid "G__open_misc(read): mapset <%s> doesn't match xmapset <%s>"
+msgid "Feature without category of layer %d"
msgstr ""
-#: ../lib/gis/open_misc.c:74
-#, c-format
-msgid "G__open_misc(write): xmapset <%s> != G_mapset() <%s>"
+#: ../lib/vector/Vlib/write_ogr.c:624
+#, fuzzy, c-format
+msgid "Unable to create field <%s>"
+#: ../lib/vector/Vlib/constraint.c:150
+msgid "Layer constraint ignored for non-native vector formats"
msgstr ""
-#: ../lib/gis/mapset.c:38
-msgid "MAPSET is not set"
+#: ../lib/vector/Vlib/snap.c:223 ../lib/vector/Vlib/snap.c:582
+msgid "Snap vertices Pass 1: select points"
msgstr ""
-#: ../lib/gis/mapset.c:80
-#, c-format
-msgid "MAPSET <%s> not available"
+#: ../lib/vector/Vlib/snap.c:271 ../lib/vector/Vlib/snap.c:636
+msgid "Snap vertices Pass 2: assign anchor vertices"
msgstr ""
-#: ../lib/gis/mkstemp.c:132
-#, fuzzy
-msgid "Attempt to create read-only temporary file"
-msgstr "임시파일을 열 수 없습니다"
-#: ../lib/gis/mkstemp.c:138
-#, c-format
-msgid "Unrecognised access mode: %o"
+#: ../lib/vector/Vlib/snap.c:340 ../lib/vector/Vlib/snap.c:705
+msgid "Snap vertices Pass 3: snap to assigned points"
msgstr ""
-#: ../lib/gis/get_projinfo.c:37 ../lib/gis/get_projinfo.c:66
+#: ../lib/vector/Vlib/snap.c:525 ../lib/vector/Vlib/snap.c:887
#, c-format
-msgid "<%s> file not found for location <%s>"
+msgid "Snapped vertices: %d"
msgstr ""
-#: ../lib/gis/color_rules.c:88
+#: ../lib/vector/Vlib/snap.c:526 ../lib/vector/Vlib/snap.c:888
+#, fuzzy, c-format
+msgid "New vertices: %d"
+#: ../lib/vector/Vlib/snap.c:915
#, fuzzy
-msgid "no description"
+msgid "Reading features..."
-#: ../lib/gis/spawn.c:386
-#, c-format
-msgid "CreateProcess() failed: error = %d"
+#: ../lib/vector/Vlib/build_nat.c:84
+#, fuzzy
+msgid "Unable to read vector map"
+#: ../lib/vector/Vlib/build_nat.c:129
+msgid "Building areas..."
msgstr ""
-#: ../lib/gis/spawn.c:421
+#: ../lib/vector/Vlib/build_nat.c:153
#, c-format
-msgid "G_spawn: unable to redirect descriptor %d"
-msgstr ""
+msgid "One area built"
+msgid_plural "%d areas built"
+msgstr[0] ""
-#: ../lib/gis/spawn.c:429 ../lib/gis/spawn.c:619
+#: ../lib/vector/Vlib/build_nat.c:154
#, c-format
-msgid "G_spawn: unable to open file %s"
-msgstr ""
+msgid "One isle built"
+msgid_plural "%d isles built"
+msgstr[0] ""
-#: ../lib/gis/spawn.c:503 ../lib/gis/spawn.c:689
-msgid "Unable to execute command"
+#: ../lib/vector/Vlib/build_nat.c:163
+msgid "Attaching islands..."
msgstr ""
-#: ../lib/gis/spawn.c:528 ../lib/gis/spawn.c:536
-#, c-format
-msgid "G_spawn: unable to restore signal %d"
+#: ../lib/vector/Vlib/build_nat.c:180
+msgid "Attaching centroids..."
msgstr ""
-#: ../lib/gis/spawn.c:567
+#: ../lib/vector/Vlib/write_nat.c:398
+#, fuzzy
+msgid "Attempt to access feature with invalid id (%"
+#: ../lib/vector/Vlib/write_nat.c:404
+#, fuzzy, c-format
+msgid "Attempt to access alive feature %d"
+#: ../lib/vector/Vlib/write_nat.c:566 ../lib/vector/Vlib/write_nat.c:602
#, c-format
-msgid "G_spawn: unable to reset signal %d"
+msgid "%s: Area %d does not exist"
msgstr ""
-#: ../lib/gis/spawn.c:576
-#, c-format
-msgid "G_spawn: unable to ignore signal %d"
+#: ../lib/vector/Vlib/write_nat.c:756
+#, fuzzy, c-format
+msgid "Attempt to access dead area %d"
+#: ../lib/vector/Vlib/build_ogr.c:71
+msgid "Empty OGR layer, nothing to build"
msgstr ""
-#: ../lib/gis/spawn.c:587
-#, c-format
-msgid "G_spawn: unable to block signal %d"
+#: ../lib/vector/Vlib/build_ogr.c:84
+msgid ""
+"Random read is not supported by OGR for this layer. Unable to build topology."
msgstr ""
-#: ../lib/gis/spawn.c:595
-#, c-format
-msgid "G_spawn: unable to unblock signal %d"
+#: ../lib/vector/Vlib/build_ogr.c:134
+#, fuzzy, c-format
+msgid "Unable to open fidx file for write <%s>"
+#: ../lib/vector/Vlib/graph.c:138
+#, fuzzy
+msgid "Unable to add network arc"
+#: ../lib/vector/Vlib/remove_duplicates.c:199
+#, fuzzy, c-format
+msgid "Removed duplicates: %d"
+#: ../lib/vector/Vlib/poly.c:268
+msgid "Unable to find point in polygon"
msgstr ""
-#: ../lib/gis/spawn.c:624 ../lib/gis/spawn.c:633
-#, c-format
-msgid "G_spawn: unable to duplicate descriptor %d to %d"
+#: ../lib/vector/Vlib/poly.c:810
+msgid "conditions failed"
msgstr ""
-#: ../lib/gis/spawn.c:666
-msgid "Unable to create a new process"
+#: ../lib/vector/Vlib/cindex.c:32
+msgid "Category index is not up to date"
msgstr ""
-#: ../lib/gis/spawn.c:681
-#, c-format
-msgid "Unable to change directory to %s"
+#: ../lib/vector/Vlib/cindex.c:38
+msgid "Layer index out of range"
msgstr ""
-#: ../lib/gis/error.c:361
-msgid "WARNING: "
+#: ../lib/vector/Vlib/cindex.c:268
+#, fuzzy
+msgid "Category index out of range"
+msgstr "카테고리는 정수여야 합니다."
+#: ../lib/vector/Vlib/cindex.c:488
+#, fuzzy, c-format
+msgid "Unable to create category index file for vector map <%s>"
+#: ../lib/vector/Vlib/cindex.c:497
+#, fuzzy
+msgid "Error writing out category index file"
+#: ../lib/vector/Vlib/open_ogr.c:60
+msgid "OGR datasource not defined"
msgstr ""
-#: ../lib/gis/key_value3.c:33
+#: ../lib/vector/Vlib/open_ogr.c:77 ../lib/vector/Vlib/field.c:690
#, fuzzy, c-format
-msgid "Unable to open output file <%s>: %s"
+msgid "Unable to open OGR data source '%s'"
-#: ../lib/gis/key_value3.c:36
+#: ../lib/vector/Vlib/open_ogr.c:97
#, fuzzy, c-format
-msgid "Error writing file <%s>: %s"
+msgid "OGR layer <%s> not found"
-#: ../lib/gis/key_value3.c:39
+#: ../lib/vector/Vlib/open_ogr.c:191
#, fuzzy, c-format
-msgid "Error closing output file <%s>: %s"
+msgid "Unable to get OGR driver <%s>"
-#: ../lib/gis/key_value3.c:60
+#: ../lib/vector/Vlib/open_ogr.c:199
#, fuzzy, c-format
-msgid "Unable to open input file <%s>: %s"
+msgid "Unable to create OGR data source '%s'"
-#: ../lib/gis/key_value3.c:64
+#: ../lib/vector/Vlib/open_ogr.c:211
+#, c-format
+msgid "OGR layer <%s> already exists and will be overwritten"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:215
#, fuzzy, c-format
-msgid "Error reading file <%s>: %s"
+msgid "Unable to delete OGR layer <%s>"
-#: ../lib/gis/key_value3.c:67
+#: ../lib/vector/Vlib/open_ogr.c:221
#, fuzzy, c-format
-msgid "Error closing input file <%s>: %s"
+msgid "OGR layer <%s> already exists in datasource '%s'"
-#: ../lib/gis/gisinit.c:53 ../lib/gis/gisinit.c:87
+#: ../lib/vector/Vlib/open_ogr.c:279
#, c-format
msgid ""
-"Module built against version %s but trying to use version %s. You need to "
-"rebuild GRASS GIS or untangle multiple installations."
+"Feature index format version %d.%d is not supported by this release. Try to "
+"rebuild topology or upgrade GRASS."
msgstr ""
-#: ../lib/gis/gisinit.c:65
+#: ../lib/vector/Vlib/open_ogr.c:284
#, c-format
-msgid "MAPSET %s - permission denied"
+msgid ""
+"Your GRASS version does not fully support feature index format %d.%d of the "
+"vector. Consider to rebuild topology or upgrade GRASS."
msgstr ""
-#: ../lib/gis/gisinit.c:68
-#, fuzzy, c-format
-msgid "MAPSET %s not found at %s"
-#: ../lib/gis/gisinit.c:102
-msgid "System not initialized. Programmer forgot to call G_gisinit()."
+#: ../lib/vector/Vlib/break_lines.c:563
+#, c-format
+msgid "Intersections: %d"
msgstr ""
-#: ../lib/gis/legal_name.c:39
+#: ../lib/vector/Vlib/merge_lines.c:240
#, c-format
-msgid "Illegal filename <%s>. Cannot start with '.' or be 'NULL'."
+msgid "%d boundaries merged"
msgstr ""
-#: ../lib/gis/legal_name.c:46
+#: ../lib/vector/Vlib/merge_lines.c:241
#, c-format
-msgid "Illegal filename <%s>. Character <%c> not allowed.\n"
+msgid "%d new boundaries"
msgstr ""
-#: ../lib/gis/legal_name.c:77 ../lib/gis/legal_name.c:81
-#, c-format
-msgid "Output raster map name <%s> is not valid map name"
+#: ../lib/vector/Vlib/read_ogr.c:215 ../lib/vector/Vlib/read_ogr.c:224
+#, fuzzy, c-format
+msgid "Unable to get feature geometry, fid %ld"
+#: ../lib/vector/Vlib/read_ogr.c:382 ../lib/vector/Vlib/read_pg.c:482
+msgid "Feature without geometry. Skipped."
msgstr ""
-#: ../lib/gis/legal_name.c:118 ../lib/gis/legal_name.c:122
+#: ../lib/vector/Vlib/read_ogr.c:390
+msgid "OGR feature without ID"
+msgstr ""
+#: ../lib/vector/Vlib/read_ogr.c:514
#, c-format
-msgid "Output raster map <%s> is used as input"
+msgid "OGR feature type '%s' not supported"
msgstr ""
-#: ../lib/gis/paths.c:201
+#: ../lib/vector/Vlib/read_sfa.c:90
#, fuzzy, c-format
-msgid "Unable to open file <%s> for reading"
+msgid "Unable to construct centroid for area %d. Skipped."
-#: ../lib/gis/paths.c:217
+#: ../lib/vector/Vlib/read_sfa.c:95
+#, c-format
+msgid "Centroid %d: invalid area %d"
+msgstr ""
+#: ../lib/vector/Vlib/read_sfa.c:117 ../lib/vector/Vlib/read_pg.c:192
#, fuzzy, c-format
-msgid "Unable to fetch security info for <%s>"
+msgid "Unexpected feature type (%d) - should be (%d)"
-#: ../lib/gis/parser_dependencies.c:122
-msgid "Internal error: option or flag not found"
+#: ../lib/vector/Vlib/break_polygons.c:102
+msgid "Break polygons: Bug in binary tree!"
msgstr ""
-#: ../lib/gis/parser_dependencies.c:179
-#, fuzzy, c-format
-msgid "<%s> or <%s>"
-msgstr "<%s>를 <%s>으로 이름을 바꿉니다"
+#: ../lib/vector/Vlib/break_polygons.c:156
+#: ../lib/vector/Vlib/break_polygons.c:435
+msgid "Breaking polygons (pass 1: select break points)..."
+msgstr ""
-#, c-format
-msgid "<%s> and <%s>"
+#: ../lib/vector/Vlib/break_polygons.c:286
+#: ../lib/vector/Vlib/break_polygons.c:552
+msgid "Breaking polygons (pass 2: break at selected points)..."
msgstr ""
-#: ../lib/gis/parser_dependencies.c:212
+#: ../lib/vector/Vlib/break_polygons.c:398
+#: ../lib/vector/Vlib/break_polygons.c:650
#, c-format
-msgid "Options %s are mutually exclusive"
+msgid "Breaks: %d"
msgstr ""
-#: ../lib/gis/parser_dependencies.c:236
-#, c-format
-msgid "At least one of the following options is required: %s"
+#: ../lib/vector/Vlib/break_polygons.c:592
+msgid "Point not in search tree!"
msgstr ""
-#: ../lib/gis/parser_dependencies.c:269
-#, c-format
-msgid "Option %s requires at least one of %s"
+#: ../lib/vector/Vlib/overlay.c:72
+msgid "unknown operator"
msgstr ""
-#: ../lib/gis/parser_dependencies.c:301
-#, c-format
-msgid "Option %s requires all of %s"
+#: ../lib/vector/Vlib/overlay.c:124
+msgid "Overlay: line/boundary types not supported by AND operator"
msgstr ""
-#: ../lib/gis/parser_dependencies.c:328
-#, c-format
-msgid "Option %s is mutually exclusive with all of %s"
+#: ../lib/vector/Vlib/overlay.c:127
+msgid "Overlay: area x area types not supported by AND operator"
msgstr ""
-#: ../lib/gis/parser_dependencies.c:354
+#: ../lib/vector/Vlib/open_nat.c:56
+#, fuzzy, c-format
+msgid "Unable to open coor file for vector map <%s>"
+#: ../lib/vector/Vlib/open_nat.c:152
#, c-format
-msgid "Either all or none of %s must be given"
+msgid ""
+"Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
+"excess)"
msgstr ""
-#: ../lib/gis/parser_dependencies.c:387 ../lib/gis/parser_dependencies.c:424
+#: ../lib/vector/Vlib/open_nat.c:156
#, c-format
-msgid "Internal error: invalid rule type: %d"
+msgid ""
+"Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
msgstr ""
-#: ../lib/gis/view.c:176
+#: ../lib/vector/Vlib/read_pg.c:272 ../lib/vector/Vlib/read_pg.c:471
+#, fuzzy, c-format
+msgid "Feature %ld without geometry skipped"
+#: ../lib/vector/Vlib/read_pg.c:365
#, c-format
-msgid "Unable to open %s for writing"
+msgid ""
+"Requesting invalid feature from cache (%d). Number of features in cache: %d"
msgstr ""
-#: ../lib/gis/view.c:262 ../lib/gis/view.c:479
-#, c-format
-msgid "Unable to open %s for reading"
+#: ../lib/vector/Vlib/read_pg.c:368
+#, fuzzy, c-format
+msgid "Feature %d: unexpected type (%d) - should be %d"
+#: ../lib/vector/Vlib/read_pg.c:575
+msgid "No geometry or topo geometry column defined"
msgstr ""
-#: ../lib/gis/view.c:465
-#, c-format
-msgid "GRASS window when view was saved:\n"
+#: ../lib/vector/Vlib/read_pg.c:585
+msgid "Random access not supported. Primary key not defined."
msgstr ""
-#: ../lib/gis/view.c:545
-#, c-format
-msgid " Window saved in \"%s\" is completely outside of current GRASS window."
+#: ../lib/vector/Vlib/read_pg.c:652
+msgid "Inconsistency in topology: detected centroid (should be point)"
msgstr ""
-#: ../lib/gis/view.c:549
-#, c-format
-msgid ""
-" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+#: ../lib/vector/Vlib/read_pg.c:662
+msgid "Inconsistency in topology: detected boundary (should be line)"
msgstr ""
-#: ../lib/gpde/n_gwflow.c:436 ../lib/gpde/n_gwflow.c:715
+#: ../lib/vector/Vlib/read_pg.c:787
#, c-format
-msgid "The total sum of the water budget: %g\n"
+msgid "Invalid WKB content: %d bytes"
msgstr ""
-#: ../lib/gpde/n_gwflow.c:438 ../lib/gpde/n_gwflow.c:717
-#, c-format
-msgid "The total sum of the water budget is significantly larger then 0: %g\n"
+#: ../lib/vector/Vlib/read_pg.c:803
+msgid "Reading EWKB with 4-dimensional coordinates (XYZM) is not supported"
msgstr ""
-#: ../lib/gpde/test/test_main.c:88
-msgid "Performs unit and integration tests for gpde library"
+#: ../lib/vector/Vlib/read_pg.c:996 ../lib/vector/Vlib/read_pg.c:1066
+#: ../lib/vector/Vlib/read_pg.c:1137
+msgid "Length of input WKB is too small"
msgstr ""
-#: ../lib/gpde/n_parse_options.c:106
-msgid "The calculation time in seconds"
+#: ../lib/vector/Vlib/read_pg.c:1077
+#, c-format
+msgid "Invalid cache index %d (max: %d)"
msgstr ""
-#: ../lib/gpde/n_arrays_io.c:93
+#: ../lib/vector/Vlib/read_pg.c:1215
#, c-format
-msgid "Reading raster map <%s> into memory"
+msgid "Corrupted data. %s."
msgstr ""
-#: ../lib/gpde/n_arrays_io.c:183
-msgid "N_array_2d * array is empty"
+#: ../lib/vector/Vlib/read_pg.c:1217
+msgid "Corrupted data"
msgstr ""
-#: ../lib/gpde/n_arrays_io.c:202
-#, c-format
-msgid "Write 2d array to raster map <%s>"
+#: ../lib/vector/Vlib/read_pg.c:1515
+#, fuzzy, c-format
+msgid ""
+"Execution failed: %s (...)\n"
+"Reason: %s"
+#: ../lib/vector/Vlib/read_pg.c:1546
+#, fuzzy, c-format
+msgid ""
+"Execution failed: %s\n"
+"Reason: %s"
+#: ../lib/vector/Vlib/read_pg.c:1675
+#, fuzzy, c-format
+msgid ""
+"Unable to read features. Reason:\n"
+"%s"
+#: ../lib/vector/Vlib/field.c:91
+msgid "Layer number must be 1 or greater"
msgstr ""
-#: ../lib/gpde/n_arrays_io.c:309
-#, c-format
-msgid "Read g3d map <%s> into the memory"
+#: ../lib/vector/Vlib/field.c:96
+#, fuzzy
+msgid "Unable to add attribute link, vector map is not opened in WRITE mode"
+#: ../lib/vector/Vlib/field.c:103
+#, fuzzy
+msgid "Unable to add attribute link"
+#: ../lib/vector/Vlib/field.c:109
+#, fuzzy
+msgid "Unable to write attribute links"
+msgstr "자동 MASK파일을 열 수 없습니다"
+#: ../lib/vector/Vlib/field.c:154
+#, fuzzy
+msgid "Unable to write database links"
+#: ../lib/vector/Vlib/field.c:178
+msgid "Database connection not defined. Skipping."
msgstr ""
-#: ../lib/gpde/n_arrays_io.c:364 ../lib/gpde/n_arrays_io.c:464
-msgid "Error closing g3d file"
+#: ../lib/vector/Vlib/field.c:185
+msgid ""
+"More DB links defined for input vector map. Using only first DB link for "
+"output."
msgstr ""
-#: ../lib/gpde/n_arrays_io.c:420
+#: ../lib/vector/Vlib/field.c:261
#, c-format
-msgid "Error opening g3d map <%s>"
+msgid "Layer number %d or name <%s> already exists"
msgstr ""
-#: ../lib/gpde/n_arrays_io.c:422
+#: ../lib/vector/Vlib/field.c:345
#, c-format
-msgid "Write 3d array to g3d map <%s>"
+msgid ""
+"Default driver / database set to:\n"
+"driver: %s\n"
+"database: %s"
msgstr ""
-#: ../lib/htmldriver/graph_set.c:97
-#, c-format
-msgid "html: collecting to file '%s'"
-msgstr "html: '%s' 파일로 모읍니다."
+#: ../lib/vector/Vlib/field.c:352
+msgid "Default driver is not set"
+msgstr ""
-#: ../lib/htmldriver/graph_set.c:98
-#, c-format
-msgid "html: image size %dx%d"
-msgstr "html: 그림크기 %dx%d"
+#: ../lib/vector/Vlib/field.c:355
+msgid "Default database is not set"
+msgstr ""
-#: ../lib/htmldriver/graph_set.c:111 ../lib/htmldriver/graph_set.c:115
-#: ../lib/htmldriver/graph_set.c:119
+#: ../lib/vector/Vlib/field.c:428
#, c-format
-msgid "html: type '%s'"
-msgstr "html: 타입 '%s'"
-#: ../lib/temporal/lib/default_name.c:69
-msgid "Programmer error - only SQLite driver is currently supported"
+msgid "Requested dblink %d, maximum link number %d"
msgstr ""
-#: ../lib/temporal/lib/connect.c:110
+#: ../lib/vector/Vlib/field.c:614 ../lib/vector/Vlib/field.c:622
#, fuzzy, c-format
-msgid "Mapset <%s> does not exist."
+msgid "Error in rule on row %d in <%s>"
-#: ../lib/arraystats/class.c:19
+#: ../lib/vector/Vlib/field.c:707
#, fuzzy, c-format
-msgid "Unknown algorithm '%s'"
-msgstr "알려지지 않은 벡터타입입니다"
+msgid "Unable to open OGR layer <%s>"
-#: ../lib/arraystats/class.c:42
-msgid "Discont algorithm currently not available because of bugs"
+#: ../lib/vector/Vlib/field.c:734
+#, fuzzy
+msgid "Unable to open OGR DBMI driver"
+#: ../lib/vector/Vlib/field.c:773
+msgid ""
+"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
+"available in OGR DB table"
msgstr ""
-#: ../lib/arraystats/class.c:49
-msgid "Classification algorithm failed"
+#: ../lib/vector/Vlib/field.c:840
+#, c-format
+msgid ""
+"Feature table <%s> has no primary key defined. Unable to define DB links."
msgstr ""
-#: ../lib/arraystats/class.c:227
-msgid "Equiprobable classbreaks currently limited to 10 classes"
+#: ../lib/vector/Vlib/field.c:860
+msgid "GRASS not compiled with PostgreSQL support"
msgstr ""
-#: ../lib/arraystats/class.c:242
-#, c-format
-msgid ""
-"There are classbreaks outside the range min-max. Number of classes reduced "
-"to %i, but using probabilities for %i classes."
+#: ../lib/vector/Vlib/field.c:892
+#, fuzzy
+msgid "Unknown vector map format"
+#: ../lib/vector/Vlib/field.c:925
+#, fuzzy, c-format
+msgid "Unable to create database definition file for vector map <%s>"
+msgstr "'%s' 디버그파일을 열 수 없습니다"
+#: ../lib/vector/Vlib/field.c:1020
+msgid "Bug: attempt to update map which is not in current mapset"
msgstr ""
-#: ../lib/display/icon.c:80
+#: ../lib/vector/vedit/select.c:231
+msgid "Unknown query tool"
+msgstr ""
+#: ../lib/vector/vedit/cats.c:63
#, fuzzy, c-format
-msgid "Unsupported icon %d"
+msgid "Unable to set category %d for (feature id %d)"
-#: ../lib/display/tran_colr.c:107 ../lib/display/tran_colr.c:109
+#: ../lib/vector/vedit/delete.c:40
+#, fuzzy, c-format
+msgid "Attempt to delete dead feature (%d)"
+#: ../lib/vector/vedit/delete.c:72
+#, fuzzy, c-format
+msgid "No area found for centroid %d"
+#: ../lib/vector/vedit/delete.c:76
#, c-format
-msgid "[%s]: No such color"
+msgid "Duplicate centroid %d, unable to delete area"
msgstr ""
-#: ../lib/display/r_raster.c:98
-#, c-format
-msgid "Both %s and %s are defined. %s will be ignored."
+#: ../lib/vector/vedit/delete.c:105
+#, fuzzy, c-format
+msgid "Area %d without centroid"
+#: ../lib/vector/vedit/delete.c:121
+#, fuzzy, c-format
+msgid "Area %d has no boundaries"
+#: ../lib/vector/rtree/test_suite/test_basics.c:40
+msgid ""
+"\n"
+"++ Running basic unit tests ++"
msgstr ""
-#: ../lib/display/r_raster.c:131
-#, c-format
+#: ../lib/vector/rtree/test_suite/test_basics.c:48
msgid ""
-"Neither %s (managed by d.mon command) nor %s (used for direct rendering) "
-"defined"
+"\n"
+"-- Basic rtree unit tests failure --"
msgstr ""
-#: ../lib/display/r_raster.c:150
+#: ../lib/vector/rtree/test_suite/test_basics.c:50
+msgid ""
+"\n"
+"-- Basic rtree unit tests finished successfully --"
+msgstr ""
+#: ../lib/vector/rtree/test_suite/test_main.c:61
+msgid "Unit tests for the vector rtree library"
+msgstr ""
+#: ../lib/vector/neta/timetables.c:46 ../lib/vector/neta/timetables.c:203
+#: ../lib/vector/neta/timetables.c:244 ../lib/vector/neta/timetables.c:286
#, fuzzy, c-format
-msgid "Unknown display driver <%s>"
+msgid "Unable to open select cursor: %s"
-#: ../lib/display/r_raster.c:151
+#: ../lib/vector/neta/utils.c:200
#, fuzzy, c-format
-msgid "Using display driver <%s>..."
+msgid "Point %d is not connected!"
-#: ../lib/cluster/c_exec.c:44
+#: ../lib/vector/neta/utils.c:235
#, c-format
-msgid "Not enough data points (%d) in cluster"
+msgid "'%s' must be > 0"
msgstr ""
-#: ../lib/cluster/c_begin.c:57
-#, c-format
-msgid "produced by i.cluster"
+#: ../lib/vector/neta/utils.c:244
+msgid "'where' and 'cats' parameters were supplied, cat will be ignored"
msgstr ""
+#: ../lib/vector/neta/utils.c:247
+#, fuzzy
+msgid "Unable to load data from database"
+#: ../lib/vector/neta/utils.c:254
+#, fuzzy
+msgid "Problem loading category values"
+#: ../lib/vector/neta/spanningtree.c:106
+msgid "Computing minimum spanning tree..."
+msgstr ""
#: ../lib/init/lock.c:38
#, c-format
msgid "Usage: %s file pid"
@@ -5831,6 +6752,10 @@
msgid "WARNING"
msgstr ""
+#: ../lib/init/grass.py:187 ../lib/gis/parser.c:621
+msgid "ERROR"
+msgstr ""
#: ../lib/init/grass.py:188
msgid "Exiting..."
msgstr ""
@@ -5839,6 +6764,11 @@
msgid "Usage"
msgstr ""
+#: ../lib/init/grass.py:333 ../lib/gis/parser_html.c:141
+#: ../lib/gis/parser_rest.c:146
+msgid "Flags"
+msgstr ""
#: ../lib/init/grass.py:334
msgid "print this help message"
msgstr ""
@@ -5884,6 +6814,11 @@
msgid "options: arch,build,compiler,path,revision"
msgstr ""
+#: ../lib/init/grass.py:347 ../lib/gis/parser_html.c:189
+#: ../lib/gis/parser_rest.c:179
+msgid "Parameters"
+msgstr ""
#: ../lib/init/grass.py:348
msgid "initial GRASS GIS database directory"
msgstr ""
@@ -6007,6 +6942,11 @@
"Hit RETURN to continue.\n"
msgstr ""
+#: ../lib/init/grass.py:841 ../lib/gis/make_mapset.c:66
+#, fuzzy, c-format, python-format
+msgid "Location <%s> doesn't exist"
#: ../lib/init/grass.py:843
#, python-format
msgid "<%s> is not a valid GRASS Location because PERMANENT Mapset is missing"
@@ -6308,3260 +7248,2314 @@
msgid "Failed to start shell '%s'"
-#: ../lib/rowio/setup.c:61 ../lib/rowio/setup.c:67
-#: ../lib/vector/neta/spanningtree.c:101 ../lib/vector/neta/flow.c:66
-#: ../lib/vector/neta/flow.c:190 ../lib/vector/neta/components.c:71
-#: ../lib/vector/neta/components.c:176 ../lib/vector/neta/centrality.c:63
-#: ../lib/vector/neta/centrality.c:145 ../lib/vector/neta/timetables.c:69
-#: ../lib/vector/neta/timetables.c:168 ../lib/vector/neta/timetables.c:178
-#: ../lib/vector/neta/timetables.c:191 ../lib/vector/neta/timetables.c:278
-#: ../lib/vector/neta/timetables.c:413 ../lib/vector/neta/timetables.c:425
-#: ../lib/vector/neta/bridge.c:58 ../lib/vector/neta/articulation_point.c:60
-#: ../lib/vector/neta/path.c:262 ../lib/vector/Vlib/map.c:48
-#: ../lib/vector/Vlib/line.c:50 ../lib/vector/Vlib/line.c:154
-#: ../lib/vector/diglib/struct_alloc.c:491 ../lib/segment/open.c:98
-#: ../lib/rst/interp_float/segmen2d.c:199
-#: ../lib/rst/interp_float/segmen2d.c:205
-#: ../lib/rst/interp_float/segmen2d.c:211
-#: ../lib/rst/interp_float/segmen2d.c:221
-#: ../lib/rst/interp_float/interp2d.c:139
-#: ../lib/rst/interp_float/interp2d.c:145
-msgid "Out of memory"
+#: ../lib/gis/debug.c:80
+#, c-format
+msgid "Cannot open debug file '%s'"
+msgstr "'%s' 디버그파일을 열 수 없습니다."
+#: ../lib/gis/gisinit.c:53 ../lib/gis/gisinit.c:87
+#, c-format
+msgid ""
+"Module built against version %s but trying to use version %s. You need to "
+"rebuild GRASS GIS or untangle multiple installations."
msgstr ""
-#: ../lib/vector/vedit/delete.c:40
-#, fuzzy, c-format
-msgid "Attempt to delete dead feature (%d)"
+#: ../lib/gis/gisinit.c:65
+#, c-format
+msgid "MAPSET %s - permission denied"
+msgstr ""
-#: ../lib/vector/vedit/delete.c:72
+#: ../lib/gis/gisinit.c:68
#, fuzzy, c-format
-msgid "No area found for centroid %d"
-msgstr "Datum %s 테이블파일을 열 수 없습니다"
+msgid "MAPSET %s not found at %s"
-#: ../lib/vector/vedit/delete.c:76
+#: ../lib/gis/gisinit.c:102
+msgid "System not initialized. Programmer forgot to call G_gisinit()."
+msgstr ""
+#: ../lib/gis/distance.c:154
#, c-format
-msgid "Duplicate centroid %d, unable to delete area"
+msgid "%s: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
msgstr ""
-#: ../lib/vector/vedit/delete.c:105
-#, fuzzy, c-format
-msgid "Area %d without centroid"
+#: ../lib/gis/mkstemp.c:132
+#, fuzzy
+msgid "Attempt to create read-only temporary file"
-#: ../lib/vector/vedit/delete.c:121
-#, fuzzy, c-format
-msgid "Area %d has no boundaries"
+#: ../lib/gis/mkstemp.c:138
+#, c-format
+msgid "Unrecognised access mode: %o"
+msgstr ""
-#: ../lib/vector/vedit/cats.c:63
-#, fuzzy, c-format
-msgid "Unable to set category %d for (feature id %d)"
+#: ../lib/gis/parser_html.c:57 ../lib/gis/parser_rest.c:60
+msgid "NAME"
+msgstr ""
-#: ../lib/vector/vedit/select.c:231
-msgid "Unknown query tool"
+#: ../lib/gis/parser_html.c:70 ../lib/gis/parser_rest.c:73
+msgid "KEYWORDS"
msgstr ""
-#: ../lib/vector/rtree/test_suite/test_main.c:61
-msgid "Unit tests for the vector rtree library"
+#: ../lib/gis/parser_html.c:75 ../lib/gis/parser_rest.c:78
+msgid "SYNOPSIS"
msgstr ""
-#: ../lib/vector/rtree/test_suite/test_basics.c:40
-msgid ""
-"\n"
-"++ Running basic unit tests ++"
+#: ../lib/gis/parser_html.c:167 ../lib/gis/parser_interface.c:329
+#: ../lib/gis/parser_help.c:215 ../lib/gis/parser_rest.c:164
+msgid "Allow output files to overwrite existing files"
msgstr ""
-#: ../lib/vector/rtree/test_suite/test_basics.c:48
-msgid ""
-"\n"
-"-- Basic rtree unit tests failure --"
+#: ../lib/gis/parser_html.c:171 ../lib/gis/parser_interface.c:337
+#: ../lib/gis/parser_help.c:217
+msgid "Print usage summary"
msgstr ""
-#: ../lib/vector/rtree/test_suite/test_basics.c:50
-msgid ""
-"\n"
-"-- Basic rtree unit tests finished successfully --"
+#: ../lib/gis/parser_html.c:174 ../lib/gis/parser_interface.c:344
+#: ../lib/gis/parser_help.c:218 ../lib/gis/parser_rest.c:168
+msgid "Verbose module output"
msgstr ""
-#: ../lib/vector/neta/spanningtree.c:106
-msgid "Computing minimum spanning tree..."
+#: ../lib/gis/parser_html.c:177 ../lib/gis/parser_interface.c:351
+#: ../lib/gis/parser_help.c:219 ../lib/gis/parser_rest.c:171
+msgid "Quiet module output"
msgstr ""
-#: ../lib/vector/neta/flow.c:331 ../lib/vector/Vlib/net_build.c:661
-#: ../lib/vector/Vlib/net_build.c:1067 ../lib/vector/Vlib/graph.c:105
-msgid "GngFlatten error"
+#: ../lib/gis/parser_html.c:180 ../lib/gis/parser_help.c:221
+msgid "Force launching GUI dialog"
msgstr ""
-#: ../lib/vector/neta/timetables.c:46 ../lib/vector/neta/timetables.c:203
-#: ../lib/vector/neta/timetables.c:244 ../lib/vector/neta/timetables.c:286
-#, fuzzy, c-format
-msgid "Unable to open select cursor: %s"
+#: ../lib/gis/parser_html.c:233 ../lib/gis/parser_rest.c:223
+msgid "Options"
+msgstr ""
-#: ../lib/vector/neta/utils.c:200
-#, fuzzy, c-format
-msgid "Point %d is not connected!"
+#: ../lib/gis/parser_html.c:239 ../lib/gis/parser_rest.c:230
+msgid "Default"
+msgstr ""
-#: ../lib/vector/neta/utils.c:235
+#: ../lib/gis/spawn.c:386
#, c-format
-msgid "'%s' must be > 0"
+msgid "CreateProcess() failed: error = %d"
msgstr ""
-#: ../lib/vector/neta/utils.c:244
-msgid "'where' and 'cats' parameters were supplied, cat will be ignored"
+#: ../lib/gis/spawn.c:421
+#, c-format
+msgid "G_spawn: unable to redirect descriptor %d"
msgstr ""
-#: ../lib/vector/neta/utils.c:247
-#, fuzzy
-msgid "Unable to load data from database"
-#: ../lib/vector/neta/utils.c:254
-#, fuzzy
-msgid "Problem loading category values"
-#: ../lib/vector/Vlib/write_nat.c:182 ../lib/vector/Vlib/write_nat.c:295
-#: ../lib/vector/Vlib/write_nat.c:651 ../lib/vector/Vlib/read_pg.c:331
-#: ../lib/vector/Vlib/read_sfa.c:50 ../lib/vector/Vlib/write_pg.c:236
-#: ../lib/vector/Vlib/write_pg.c:381 ../lib/vector/Vlib/write_pg.c:396
-#: ../lib/vector/Vlib/read.c:173 ../lib/vector/Vlib/read_nat.c:144
-#: ../lib/vector/Vlib/box.c:249 ../lib/vector/Vlib/write_sfa.c:158
-#: ../lib/vector/Vlib/write_sfa.c:207
-#, fuzzy, c-format
-msgid "Attempt to access feature with invalid id (%d)"
-#: ../lib/vector/Vlib/write_nat.c:301 ../lib/vector/Vlib/write_nat.c:657
-#: ../lib/vector/Vlib/read_pg.c:337 ../lib/vector/Vlib/read_sfa.c:56
-#: ../lib/vector/Vlib/write_pg.c:242 ../lib/vector/Vlib/write_pg.c:402
-#: ../lib/vector/Vlib/write_pg.c:2584 ../lib/vector/Vlib/write_pg.c:2681
-#: ../lib/vector/Vlib/read_nat.c:150
-#, fuzzy, c-format
-msgid "Attempt to access dead feature %d"
-#: ../lib/vector/Vlib/write_nat.c:398
-#, fuzzy
-msgid "Attempt to access feature with invalid id (%"
-#: ../lib/vector/Vlib/write_nat.c:404
-#, fuzzy, c-format
-msgid "Attempt to access alive feature %d"
-#: ../lib/vector/Vlib/write_nat.c:566 ../lib/vector/Vlib/write_nat.c:602
+#: ../lib/gis/spawn.c:429 ../lib/gis/spawn.c:619
#, c-format
-msgid "%s: Area %d does not exist"
+msgid "G_spawn: unable to open file %s"
msgstr ""
-#: ../lib/vector/Vlib/write_nat.c:756
-#, fuzzy, c-format
-msgid "Attempt to access dead area %d"
-#: ../lib/vector/Vlib/write_ogr.c:69 ../lib/vector/Vlib/write_ogr.c:105
-#: ../lib/vector/Vlib/write_ogr.c:145 ../lib/vector/Vlib/field.c:675
-#: ../lib/vector/Vlib/build_sfa.c:711 ../lib/vector/Vlib/open_ogr.c:121
-#: ../lib/vector/Vlib/open_ogr.c:154 ../lib/vector/Vlib/open_ogr.c:231
-#: ../lib/vector/Vlib/rewind_ogr.c:47 ../lib/vector/Vlib/rewind_ogr.c:71
-#: ../lib/vector/Vlib/header_finfo.c:41 ../lib/vector/Vlib/header_finfo.c:80
-#: ../lib/vector/Vlib/header_finfo.c:113 ../lib/vector/Vlib/header_finfo.c:153
-#: ../lib/vector/Vlib/header_finfo.c:254 ../lib/vector/Vlib/close.c:284
-#: ../lib/vector/Vlib/close_ogr.c:77 ../lib/vector/Vlib/close_ogr.c:111
-#: ../lib/vector/Vlib/build_ogr.c:96 ../lib/vector/Vlib/build_ogr.c:171
-#: ../lib/vector/Vlib/simple_features.c:310 ../lib/vector/Vlib/read_ogr.c:56
-#: ../lib/vector/Vlib/read_ogr.c:157 ../lib/vector/Vlib/read_ogr.c:242
-#: ../lib/vector/Vlib/write_sfa.c:298 ../lib/proj/convert.c:82
-msgid "GRASS is not compiled with OGR support"
+#: ../lib/gis/spawn.c:503 ../lib/gis/spawn.c:689
+msgid "Unable to execute command"
msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:96 ../lib/vector/Vlib/write_pg.c:187
-#: ../lib/vector/Vlib/write_pg.c:255 ../lib/vector/Vlib/write_sfa.c:164
-#, fuzzy
-msgid "Unable to rewrite feature (incompatible feature types)"
-msgstr "자동 MASK파일을 열 수 없습니다"
-#: ../lib/vector/Vlib/write_ogr.c:129 ../lib/vector/Vlib/open_ogr.c:65
-msgid "OGR layer not defined"
+#: ../lib/gis/spawn.c:528 ../lib/gis/spawn.c:536
+#, c-format
+msgid "G_spawn: unable to restore signal %d"
msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:134 ../lib/vector/Vlib/write_pg.c:326
-#, fuzzy, c-format
-msgid "Invalid offset (%ld)"
-#: ../lib/vector/Vlib/write_ogr.c:140 ../lib/vector/Vlib/write_pg.c:347
-#, fuzzy
-msgid "Unable to delete feature"
-#: ../lib/vector/Vlib/write_ogr.c:239
-#, fuzzy, c-format
-msgid "Creating field <%s> failed"
-#: ../lib/vector/Vlib/write_ogr.c:304 ../lib/vector/Vlib/write_pg.c:1104
+#: ../lib/gis/spawn.c:567
#, c-format
-msgid "Unsupported geometry type (%d)"
+msgid "G_spawn: unable to reset signal %d"
msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:326
-#, fuzzy, c-format
-msgid "Unable to create OGR layer <%s> in '%s'"
-#: ../lib/vector/Vlib/write_ogr.c:338 ../lib/vector/Vlib/write_pg.c:1117
+#: ../lib/gis/spawn.c:576
#, c-format
-msgid "More layers defined, using driver <%s> and database <%s>"
+msgid "G_spawn: unable to ignore signal %d"
msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:344 ../lib/vector/Vlib/write_pg.c:1122
-msgid "Database connection not defined. Unable to write attributes."
+#: ../lib/gis/spawn.c:587
+#, c-format
+msgid "G_spawn: unable to block signal %d"
msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:408 ../lib/vector/Vlib/write_pg.c:1237
-#: ../lib/vector/Vlib/write_pg.c:1396
+#: ../lib/gis/spawn.c:595
#, c-format
-msgid "No category defined for layer %d"
+msgid "G_spawn: unable to unblock signal %d"
msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:410 ../lib/vector/Vlib/write_pg.c:1239
-#: ../lib/vector/Vlib/write_pg.c:1398
+#: ../lib/gis/spawn.c:624 ../lib/gis/spawn.c:633
#, c-format
-msgid "Feature has more categories, using category %d (from layer %d)"
+msgid "G_spawn: unable to duplicate descriptor %d to %d"
msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:424
-msgid "Feature is not a point. Skipping."
+#: ../lib/gis/spawn.c:666
+msgid "Unable to create a new process"
msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:432
-msgid "Feature is not a line. Skipping."
+#: ../lib/gis/spawn.c:681
+#, c-format
+msgid "Unable to change directory to %s"
msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:439 ../lib/vector/Vlib/write_pg.c:1266
-msgid "Feature is not a polygon. Skipping."
+#: ../lib/gis/proj2.c:63
+msgid "Latitude-Longitude"
msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:446
-msgid "Feature is not a face. Skipping."
+#: ../lib/gis/proj2.c:65
+msgid "Other Projection"
msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:452
-#, fuzzy, c-format
-msgid "Unsupported feature type (%d)"
+#: ../lib/gis/units.c:208
+msgid "square units"
+msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:471
-msgid "Boundary is not closed. Feature skipped."
+msgid "square unit"
msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:500
-#, fuzzy
-msgid "Unable to writes feature attributes"
+#: ../lib/gis/units.c:210
+msgid "units"
+msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:565
-#, c-format
-msgid "Feature without category of layer %d"
+msgid "unit"
msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:579 ../lib/vector/Vlib/write_pg.c:2005
-#, fuzzy, c-format
-msgid "Unable to select attributes for category %d"
+#: ../lib/gis/units.c:215
+msgid "square meters"
+msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:591 ../lib/vector/Vlib/write_pg.c:2014
-#, c-format
-msgid "No database record for category %d, no attributes will be written"
+msgid "square meter"
msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:624
-#, fuzzy, c-format
-msgid "Unable to create field <%s>"
+#: ../lib/gis/units.c:217
+msgid "meters"
+msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:653 ../lib/vector/Vlib/write_pg.c:2074
-#, fuzzy, c-format
-msgid "Unsupported column type %d"
+msgid "meter"
+msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:107 ../lib/vector/Vlib/remove_areas.c:268
-msgid "Area is composed of dead boundary"
+#: ../lib/gis/units.c:222
+msgid "square kilometers"
msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:194 ../lib/vector/Vlib/remove_areas.c:602
-#, c-format
-msgid "%d areas of total size %g removed"
+msgid "square kilometer"
msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:395
-#, fuzzy
-msgid "Could not delete line from coor"
+#: ../lib/gis/units.c:224
+msgid "kilometers"
+msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:458
-#, fuzzy
-msgid "dissolve_neighbour > 0, failed to build new area"
+msgid "kilometer"
+msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:463 ../lib/vector/Vlib/remove_areas.c:501
-msgid "Dissolve with neighbour area: corrupt topology"
+#: ../lib/gis/units.c:229
+msgid "acres"
msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:497
-#, fuzzy
-msgid "Failed to build new area"
+msgid "acre"
+msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:544 ../lib/vector/Vlib/remove_areas.c:571
-#, fuzzy
-msgid "Failed to build new isle"
+#: ../lib/gis/units.c:237
+msgid "hectares"
+msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:549 ../lib/vector/Vlib/remove_areas.c:576
-msgid "Dissolve with outer isle: corrupt topology"
+msgid "hectare"
msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:581
-#, fuzzy
-msgid "Area merging failed"
+#: ../lib/gis/units.c:245
+msgid "square miles"
+msgstr ""
-#: ../lib/vector/Vlib/rewind.c:29 ../lib/vector/Vlib/write.c:56
-#: ../lib/vector/Vlib/write.c:62 ../lib/vector/Vlib/open.c:59
-#: ../lib/vector/Vlib/close.c:38 ../lib/vector/Vlib/read.c:32
-#: ../lib/vector/Vlib/build.c:37
-msgid "Requested format is not compiled in this version"
+msgid "square mile"
msgstr ""
-#: ../lib/vector/Vlib/field.c:91
-msgid "Layer number must be 1 or greater"
+#: ../lib/gis/units.c:247
+msgid "miles"
msgstr ""
-#: ../lib/vector/Vlib/field.c:96
-#, fuzzy
-msgid "Unable to add attribute link, vector map is not opened in WRITE mode"
+msgid "mile"
+msgstr ""
-#: ../lib/vector/Vlib/field.c:103
-#, fuzzy
-msgid "Unable to add attribute link"
+#: ../lib/gis/units.c:252
+msgid "square feet"
+msgstr ""
-#: ../lib/vector/Vlib/field.c:109
-#, fuzzy
-msgid "Unable to write attribute links"
+msgid "square foot"
+msgstr ""
-#: ../lib/vector/Vlib/field.c:154
-#, fuzzy
-msgid "Unable to write database links"
+#: ../lib/gis/units.c:254
+msgid "feet"
+msgstr ""
-#: ../lib/vector/Vlib/field.c:178
-msgid "Database connection not defined. Skipping."
+msgid "foot"
msgstr ""
-#: ../lib/vector/Vlib/field.c:185
-msgid ""
-"More DB links defined for input vector map. Using only first DB link for "
-"output."
+#: ../lib/gis/units.c:259
+msgid "square US feet"
msgstr ""
-#: ../lib/vector/Vlib/field.c:261
-#, c-format
-msgid "Layer number %d or name <%s> already exists"
+msgid "square US foot"
msgstr ""
-#: ../lib/vector/Vlib/field.c:345
-#, c-format
-msgid ""
-"Default driver / database set to:\n"
-"driver: %s\n"
-"database: %s"
+#: ../lib/gis/units.c:261
+msgid "US feet"
msgstr ""
-#: ../lib/vector/Vlib/field.c:352
-msgid "Default driver is not set"
+msgid "US foot"
msgstr ""
-#: ../lib/vector/Vlib/field.c:355
-msgid "Default database is not set"
+#: ../lib/gis/units.c:266
+msgid "square degrees"
msgstr ""
-#: ../lib/vector/Vlib/field.c:428
-#, c-format
-msgid "Requested dblink %d, maximum link number %d"
+msgid "square degree"
msgstr ""
-#: ../lib/vector/Vlib/field.c:614 ../lib/vector/Vlib/field.c:622
-#, fuzzy, c-format
-msgid "Error in rule on row %d in <%s>"
+#: ../lib/gis/units.c:268
+msgid "degrees"
+msgstr ""
-#: ../lib/vector/Vlib/field.c:690 ../lib/vector/Vlib/open_ogr.c:77
-#, fuzzy, c-format
-msgid "Unable to open OGR data source '%s'"
+msgid "degree"
+msgstr ""
-#: ../lib/vector/Vlib/field.c:707
-#, fuzzy, c-format
-msgid "Unable to open OGR layer <%s>"
+#: ../lib/gis/units.c:272
+msgid "years"
+msgstr ""
-#: ../lib/vector/Vlib/field.c:734
-#, fuzzy
-msgid "Unable to open OGR DBMI driver"
+msgid "year"
+msgstr ""
-#: ../lib/vector/Vlib/field.c:773
-msgid ""
-"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
-"available in OGR DB table"
+#: ../lib/gis/units.c:276
+msgid "months"
msgstr ""
-#: ../lib/vector/Vlib/field.c:840
-#, c-format
-msgid ""
-"Feature table <%s> has no primary key defined. Unable to define DB links."
+msgid "month"
msgstr ""
-#: ../lib/vector/Vlib/field.c:860
-msgid "GRASS not compiled with PostgreSQL support"
+#: ../lib/gis/units.c:280
+msgid "days"
msgstr ""
-#: ../lib/vector/Vlib/field.c:892
-#, fuzzy
-msgid "Unknown vector map format"
+msgid "day"
+msgstr ""
-#: ../lib/vector/Vlib/field.c:925
-#, fuzzy, c-format
-msgid "Unable to create database definition file for vector map <%s>"
-msgstr "'%s' 디버그파일을 열 수 없습니다"
+#: ../lib/gis/units.c:284
+msgid "hours"
+msgstr ""
-#: ../lib/vector/Vlib/field.c:1020
-msgid "Bug: attempt to update map which is not in current mapset"
+msgid "hour"
msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:74 ../lib/vector/Vlib/build_sfa.c:339
-#: ../lib/vector/Vlib/build_sfa.c:629
-msgid "Registering primitives..."
+#: ../lib/gis/units.c:288
+msgid "minutes"
msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:84
-#, fuzzy
-msgid "Unable to read vector map"
+msgid "minute"
+msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:117 ../lib/vector/Vlib/build_sfa.c:385
-#: ../lib/vector/Vlib/build_sfa.c:661
-#, c-format
-msgid "One primitive registered"
-msgid_plural "%d primitives registered"
-msgstr[0] ""
-msgstr[1] ""
-#: ../lib/vector/Vlib/build_nat.c:118 ../lib/vector/Vlib/build_sfa.c:386
-#: ../lib/vector/Vlib/build_sfa.c:662
-#, c-format
-msgid "One vertex registered"
-msgid_plural "%d vertices registered"
-msgstr[0] ""
-msgstr[1] ""
-#: ../lib/vector/Vlib/build_nat.c:129
-msgid "Building areas..."
+#: ../lib/gis/units.c:292
+msgid "seconds"
msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:153
-#, c-format
-msgid "One area built"
-msgid_plural "%d areas built"
-msgstr[0] ""
-msgstr[1] ""
-#: ../lib/vector/Vlib/build_nat.c:154
-#, c-format
-msgid "One isle built"
-msgid_plural "%d isles built"
-msgstr[0] ""
-msgstr[1] ""
-#: ../lib/vector/Vlib/build_nat.c:163
-msgid "Attaching islands..."
+msgid "second"
msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:180
-msgid "Attaching centroids..."
+#: ../lib/gis/parser_wps.c:490
+msgid "Multiple outputs are not supported by WPS 1.0.0"
msgstr ""
-#: ../lib/vector/Vlib/open_nat.c:56
+#: ../lib/gis/ls.c:103
#, fuzzy, c-format
-msgid "Unable to open coor file for vector map <%s>"
+msgid "Unable to open directory %s"
+msgstr "Datum %s 테이블파일을 열 수 없습니다"
-#: ../lib/vector/Vlib/open_nat.c:152
+#: ../lib/gis/open_misc.c:49
#, c-format
-msgid ""
-"Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
-"excess)"
+msgid "G__open_misc(read): mapset <%s> doesn't match xmapset <%s>"
msgstr ""
-#: ../lib/vector/Vlib/open_nat.c:156
+#: ../lib/gis/open_misc.c:74
#, c-format
-msgid ""
-"Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+msgid "G__open_misc(write): xmapset <%s> != G_mapset() <%s>"
msgstr ""
-#: ../lib/vector/Vlib/write.c:30 ../lib/vector/Vlib/write.c:36
-#: ../lib/vector/Vlib/write.c:42 ../lib/vector/Vlib/write.c:49
-#: ../lib/vector/Vlib/read.c:25
-msgid "for this format/level not supported"
+#: ../lib/gis/get_projinfo.c:37 ../lib/gis/get_projinfo.c:66
+#, c-format
+msgid "<%s> file not found for location <%s>"
msgstr ""
-#: ../lib/vector/Vlib/write.c:194
-#, fuzzy, c-format
-msgid "Unable to write feature in vector map <%s>"
+#: ../lib/gis/datum.c:160
+#, c-format
+msgid "unable to open datum table file: %s"
+msgstr "데이텀 테이블파일 %s을 열 수 없습니다."
-#: ../lib/vector/Vlib/write.c:234
-#, fuzzy, c-format
-msgid "Unable to rewrite feature/offset %lu in vector map <%s>"
+#: ../lib/gis/datum.c:182
+#, c-format
+msgid "error in datum table file, line %d"
+msgstr "데이텀 테이블파일의 %d번째 줄에 오류가 있습니다."
-#: ../lib/vector/Vlib/write.c:266
+#: ../lib/gis/get_window.c:118
#, fuzzy, c-format
-msgid "Unable to delete feature/offset %lu from vector map <%s>"
-#: ../lib/vector/Vlib/write.c:299
-#, fuzzy
-msgid "Unable to restore feature/offset %"
-#: ../lib/vector/Vlib/write.c:308
-#, fuzzy, c-format
-msgid "Vector map <%s> is not opened"
-#: ../lib/vector/Vlib/write.c:313
-#, fuzzy, c-format
-msgid "Vector map <%s> is not opened in write mode"
+msgid "Unable to open element file <%s> for <%s@%s>"
-#: ../lib/vector/Vlib/clean_nodes.c:248
+#: ../lib/gis/get_window.c:123
#, c-format
-msgid "Modifications: %d"
+msgid "Region file %s/%s/%s is empty"
msgstr ""
-#: ../lib/vector/Vlib/map.c:139 ../lib/vector/Vlib/map.c:245
-msgid "Vector map name is not SQL compliant"
+#: ../lib/gis/parser_standard_options.c:147
+msgid "SQL SELECT statement"
msgstr ""
-#: ../lib/vector/Vlib/map.c:143
-#, fuzzy, c-format
-msgid "Unable to find vector map <%s> in <%s>"
-#: ../lib/vector/Vlib/map.c:155 ../lib/vector/Vlib/map.c:249
-#: ../lib/vector/Vlib/open.c:821
-#, c-format
-msgid "Vector map <%s> already exists and will be overwritten"
+#: ../lib/gis/parser_standard_options.c:149
+msgid "Example: select * from towns where population > 10000"
msgstr ""
-#: ../lib/vector/Vlib/map.c:159 ../lib/vector/Vlib/open.c:813
-#: ../lib/vector/Vlib/open.c:826
-#, fuzzy, c-format
-msgid "Unable to delete vector map <%s>"
-#: ../lib/vector/Vlib/map.c:179 ../lib/vector/Vlib/map.c:267
-#, fuzzy, c-format
-msgid "Unable to copy vector map <%s> to <%s>"
-#: ../lib/vector/Vlib/map.c:317 ../lib/vector/Vlib/copy.c:738
-#: ../lib/vector/Vlib/close_nat.c:102
-#, fuzzy, c-format
-msgid "Unable to copy table <%s>"
-#: ../lib/vector/Vlib/map.c:331 ../lib/vector/Vlib/map.c:462
-#, fuzzy, c-format
-msgid "Unable to delete table <%s>"
-#: ../lib/vector/Vlib/map.c:346
-#, c-format
-msgid "Unable to create index for table <%s>, key <%s>"
+#: ../lib/gis/parser_standard_options.c:156
+msgid "WHERE conditions of SQL statement without 'where' keyword"
msgstr ""
-#: ../lib/vector/Vlib/map.c:402
-#, c-format
-msgid "Ignoring invalid mapset: %s"
+#: ../lib/gis/parser_standard_options.c:157
+msgid "Example: income < 1000 and population >= 10000"
msgstr ""
-#: ../lib/vector/Vlib/map.c:407
-#, fuzzy, c-format
-msgid "Invalid vector map name <%s>"
+#: ../lib/gis/parser_standard_options.c:165
+#, fuzzy
+msgid "Name of attribute table"
-#: ../lib/vector/Vlib/map.c:417
-#, fuzzy, c-format
-msgid "Unable to open header file for vector map <%s>"
+#: ../lib/gis/parser_standard_options.c:174
+#, fuzzy
+msgid "Name of database driver"
-#: ../lib/vector/Vlib/map.c:449
-#, fuzzy, c-format
-msgid "Unable to find table <%s> linked to vector map <%s>"
-#: ../lib/vector/Vlib/map.c:472
-#, fuzzy, c-format
-msgid "Table <%s> linked to vector map <%s> does not exist"
-#: ../lib/vector/Vlib/map.c:485
-#, fuzzy, c-format
-msgid "Unable to open directory '%s'"
+#: ../lib/gis/parser_standard_options.c:183
+#, fuzzy
+msgid "Name of database"
-#: ../lib/vector/Vlib/map.c:499
-#, fuzzy, c-format
-msgid "Unable to delete file '%s'"
-#: ../lib/vector/Vlib/map.c:519
-#, fuzzy, c-format
-msgid "Unable to rename directory '%s' to '%s'"
-#: ../lib/vector/Vlib/map.c:528
-#, fuzzy, c-format
-msgid "Unable to remove directory '%s': %s"
-#: ../lib/vector/Vlib/read_pg.c:91 ../lib/vector/Vlib/read_pg.c:214
-#: ../lib/vector/Vlib/read_pg.c:298 ../lib/vector/Vlib/read_pg.c:416
-#: ../lib/vector/Vlib/write_pg.c:123 ../lib/vector/Vlib/write_pg.c:157
-#: ../lib/vector/Vlib/write_pg.c:196 ../lib/vector/Vlib/write_pg.c:294
-#: ../lib/vector/Vlib/write_pg.c:354 ../lib/vector/Vlib/write_pg.c:476
-#: ../lib/vector/Vlib/build_sfa.c:718 ../lib/vector/Vlib/rewind_pg.c:56
-#: ../lib/vector/Vlib/rewind_pg.c:81 ../lib/vector/Vlib/header_finfo.c:47
-#: ../lib/vector/Vlib/header_finfo.c:86 ../lib/vector/Vlib/header_finfo.c:123
-#: ../lib/vector/Vlib/header_finfo.c:171 ../lib/vector/Vlib/copy.c:404
-#: ../lib/vector/Vlib/close.c:275 ../lib/vector/Vlib/build_pg.c:117
-#: ../lib/vector/Vlib/area.c:94 ../lib/vector/Vlib/area.c:499
-#: ../lib/vector/Vlib/simple_features.c:336 ../lib/vector/Vlib/close_pg.c:99
-#: ../lib/vector/Vlib/close_pg.c:146 ../lib/vector/Vlib/write_sfa.c:306
-#: ../lib/vector/Vlib/open_pg.c:143 ../lib/vector/Vlib/open_pg.c:200
-#: ../lib/vector/Vlib/open_pg.c:299 ../lib/vector/Vlib/open_pg.c:349
-msgid "GRASS is not compiled with PostgreSQL support"
+#: ../lib/gis/parser_standard_options.c:192
+msgid "Database schema"
msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:192 ../lib/vector/Vlib/read_sfa.c:117
-#, fuzzy, c-format
-msgid "Unexpected feature type (%d) - should be (%d)"
-#: ../lib/vector/Vlib/read_pg.c:272 ../lib/vector/Vlib/read_pg.c:471
-#, fuzzy, c-format
-msgid "Feature %ld without geometry skipped"
-#: ../lib/vector/Vlib/read_pg.c:365
-#, c-format
+#: ../lib/gis/parser_standard_options.c:193
msgid ""
-"Requesting invalid feature from cache (%d). Number of features in cache: %d"
+"Do not use this option if schemas are not supported by driver/database server"
msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:368
-#, fuzzy, c-format
-msgid "Feature %d: unexpected type (%d) - should be %d"
-#: ../lib/vector/Vlib/read_pg.c:378 ../lib/vector/Vlib/build_sfa.c:354
-#: ../lib/vector/Vlib/build_sfa.c:364
-#, fuzzy, c-format
-msgid "Feature %d without geometry skipped"
-#: ../lib/vector/Vlib/read_pg.c:482 ../lib/vector/Vlib/read_ogr.c:382
-msgid "Feature without geometry. Skipped."
+#: ../lib/gis/parser_standard_options.c:202
+msgid "Name of attribute column"
msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:575
-msgid "No geometry or topo geometry column defined"
+#: ../lib/gis/parser_standard_options.c:211
+msgid "Name of attribute column(s)"
msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:585
-msgid "Random access not supported. Primary key not defined."
-msgstr ""
+#: ../lib/gis/parser_standard_options.c:220
+#, fuzzy
+msgid "Name of key column"
-#: ../lib/vector/Vlib/read_pg.c:652
-msgid "Inconsistency in topology: detected centroid (should be point)"
+#: ../lib/gis/parser_standard_options.c:221
+msgid "Must refer to an integer column"
msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:662
-msgid "Inconsistency in topology: detected boundary (should be line)"
+#: ../lib/gis/parser_standard_options.c:233
+msgid "Name of input imagery group"
msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:787
-#, c-format
-msgid "Invalid WKB content: %d bytes"
+#: ../lib/gis/parser_standard_options.c:241
+msgid "Name of input imagery subgroup"
msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:803
-msgid "Reading EWKB with 4-dimensional coordinates (XYZM) is not supported"
+#: ../lib/gis/parser_standard_options.c:251
+msgid "Name of input raster map"
msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:884 ../lib/vector/Vlib/read_pg.c:1192
-#: ../lib/vector/Vlib/read_pg.c:1347 ../lib/vector/Vlib/read_pg.c:1440
-#: ../lib/vector/Vlib/write_pg.c:737 ../lib/vector/Vlib/write_pg.c:1175
-#: ../lib/vector/Vlib/write_pg.c:1278 ../lib/vector/Vlib/write_pg.c:1790
-#: ../lib/vector/Vlib/write_pg.c:1967 ../lib/vector/Vlib/write_pg.c:2325
-#: ../lib/vector/Vlib/copy.c:100
-#, fuzzy, c-format
-msgid "Unsupported feature type %d"
-#: ../lib/vector/Vlib/read_pg.c:996 ../lib/vector/Vlib/read_pg.c:1066
-#: ../lib/vector/Vlib/read_pg.c:1137
-msgid "Length of input WKB is too small"
+#: ../lib/gis/parser_standard_options.c:260
+msgid "Name of input raster map(s)"
msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:1077
-#, c-format
-msgid "Invalid cache index %d (max: %d)"
+#: ../lib/gis/parser_standard_options.c:268
+msgid "Name for output raster map"
msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:1215
-#, c-format
-msgid "Corrupted data. %s."
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:1217
-msgid "Corrupted data"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:1405 ../lib/vector/Vlib/close_pg.c:66
-#, fuzzy, c-format
-msgid "Unable to close cursor %s"
+#: ../lib/gis/parser_standard_options.c:277
+#, fuzzy
+msgid "Name for output raster map(s)"
-#: ../lib/vector/Vlib/read_pg.c:1515
-#, fuzzy, c-format
-msgid ""
-"Execution failed: %s (...)\n"
-"Reason: %s"
+#: ../lib/gis/parser_standard_options.c:285
+#, fuzzy
+msgid "Name of raster map"
-#: ../lib/vector/Vlib/read_pg.c:1546
-#, fuzzy, c-format
-msgid ""
-"Execution failed: %s\n"
-"Reason: %s"
+#: ../lib/gis/parser_standard_options.c:294
+#, fuzzy
+msgid "Name of raster map(s)"
-#: ../lib/vector/Vlib/read_pg.c:1675
-#, fuzzy, c-format
-msgid ""
-"Unable to read features. Reason:\n"
-"%s"
-#: ../lib/vector/Vlib/header.c:86
-#, fuzzy, c-format
-msgid "Unable to create header file for vector map <%s>"
-#: ../lib/vector/Vlib/header.c:129
-#, fuzzy, c-format
-msgid "Unable to open header file of vector <%s>"
-#: ../lib/vector/Vlib/header.c:137
-#, c-format
-msgid "Corrupted row in head: %s"
+#: ../lib/gis/parser_standard_options.c:302
+msgid "Name of base raster map"
msgstr ""
-#: ../lib/vector/Vlib/header.c:175
-#, c-format
-msgid "Unknown keyword '%s' in vector head"
+#: ../lib/gis/parser_standard_options.c:310
+msgid "Name of cover raster map"
msgstr ""
-#: ../lib/vector/Vlib/read_sfa.c:90
-#, fuzzy, c-format
-msgid "Unable to construct centroid for area %d. Skipped."
-#: ../lib/vector/Vlib/read_sfa.c:95
-#, c-format
-msgid "Centroid %d: invalid area %d"
-msgstr ""
-#: ../lib/vector/Vlib/read_sfa.c:124 ../lib/vector/Vlib/write_sfa.c:131
-#: ../lib/vector/Vlib/write_sfa.c:173 ../lib/vector/Vlib/write_sfa.c:273
-msgid "GRASS is not compiled with OGR/PostgreSQL support"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:285
-#, fuzzy, c-format
-msgid "Unable to rewrite feature %d"
-#: ../lib/vector/Vlib/write_pg.c:321 ../lib/vector/Vlib/write_pg.c:811
-#: ../lib/vector/Vlib/write_pg.c:1212 ../lib/vector/Vlib/write_pg.c:1364
-#: ../lib/vector/Vlib/simple_features.c:324
-msgid "No connection defined"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:452
-#, fuzzy, c-format
-msgid "Unable to delete feature (%s) %d"
-#: ../lib/vector/Vlib/write_pg.c:554 ../lib/vector/Vlib/write_pg.c:1294
-#: ../lib/vector/Vlib/write_sfa.c:349
-msgid "Boundary is not closed. Skipping."
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:612 ../lib/vector/Vlib/write_pg.c:880
-#: ../lib/vector/Vlib/open.c:1355 ../lib/vector/Vlib/build_pg.c:411
+#: ../lib/gis/parser_standard_options.c:318
#, fuzzy
-msgid "Unable to open PG file"
+msgid "Name of input elevation raster map"
-#: ../lib/vector/Vlib/write_pg.c:773
-#, fuzzy, c-format
-msgid "Building spatial index on <%s>..."
-#: ../lib/vector/Vlib/write_pg.c:841
-#, c-format
-msgid "Schema <%s> doesn't exist, created"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:920
-#, fuzzy, c-format
-msgid "Creating topology schema <%s>..."
-#: ../lib/vector/Vlib/write_pg.c:934
-#, fuzzy, c-format
-msgid "Adding new topology column <%s>..."
-#: ../lib/vector/Vlib/write_pg.c:1072 ../lib/vector/Vlib/open_pg.c:85
-#: ../lib/vector/Vlib/open_pg.c:232
-msgid "Connection string not defined"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1077 ../lib/vector/Vlib/write_pg.c:1216
-#: ../lib/vector/Vlib/write_pg.c:1368 ../lib/vector/Vlib/open_pg.c:90
-#: ../lib/vector/Vlib/open_pg.c:237
+#: ../lib/gis/parser_standard_options.c:327
#, fuzzy
-msgid "PostGIS feature table not defined"
+msgid "Name of input elevation raster map(s)"
-#: ../lib/vector/Vlib/write_pg.c:1129
+#: ../lib/gis/parser_standard_options.c:334
#, fuzzy
-msgid "Unable to create new PostGIS feature table"
+msgid "Type of raster map to be created"
-#: ../lib/vector/Vlib/write_pg.c:1143
+#: ../lib/gis/parser_standard_options.c:335
#, fuzzy
-msgid "Unable to create new PostGIS topology schema"
+msgid "Storage type for resultant raster map"
-#: ../lib/vector/Vlib/write_pg.c:1250
-#, fuzzy, c-format
-msgid "Point skipped (output feature type: %s)"
+#: ../lib/gis/parser_standard_options.c:339
+msgid "Integer"
+msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1257
-#, fuzzy, c-format
-msgid "Line skipped (output feature type: %s)"
+#: ../lib/gis/parser_standard_options.c:340
+msgid "Single precision floating point"
+msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1264
-#, c-format
-msgid "Boundary/centroid skipped (output feature type: %s)"
+#: ../lib/gis/parser_standard_options.c:341
+msgid "Double precision floating point"
msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1272
-#, fuzzy, c-format
-msgid "Face skipped (output feature type: %s)"
+#: ../lib/gis/parser_standard_options.c:347
+msgid "Sampling interpolation method"
+msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1358
-#, fuzzy, c-format
-msgid "Invalid feature type (%d) for nodes"
+#: ../lib/gis/parser_standard_options.c:351
+msgid "Nearest-neighbor interpolation"
+msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1372
-#, fuzzy
-msgid "PostGIS topology schema not defined"
-#: ../lib/vector/Vlib/write_pg.c:1872
-msgid "Trying to insert 3D data into feature table which store 2D data only"
+#: ../lib/gis/parser_standard_options.c:352
+msgid "Bilinear interpolation"
msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1877
-msgid "Trying to insert 2D data into feature table which store 3D data only"
+#: ../lib/gis/parser_standard_options.c:353
+msgid "Bicubic interpolation"
msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1902
+#: ../lib/gis/parser_standard_options.c:362
#, fuzzy
-msgid "Unable to insert topological element into PostGIS Topology schema"
+msgid "Name of input basename raster map(s)"
-#: ../lib/vector/Vlib/write_pg.c:2040
-#, c-format
-msgid "FID column must be integer, column <%s> ignored!"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2081
-msgid "Invalid value for FID column: NULL"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2173
-#, fuzzy, c-format
-msgid "Invalid feature %d (max: %d)"
+#: ../lib/gis/parser_standard_options.c:371
+#, fuzzy
+msgid "Name for output basename raster map(s)"
-#: ../lib/vector/Vlib/write_pg.c:2187
-#, fuzzy, c-format
-msgid "Invalid feature type (%d) for node"
+#: ../lib/gis/parser_standard_options.c:381
+#, fuzzy
+msgid "Name of input 3D raster map"
-#: ../lib/vector/Vlib/write_pg.c:2191
-#, fuzzy, c-format
-msgid "Invalid node %d (%d)"
+#: ../lib/gis/parser_standard_options.c:390
+#, fuzzy
+msgid "Name of input 3D raster map(s)"
-#: ../lib/vector/Vlib/write_pg.c:2269
-#, fuzzy, c-format
-msgid "Unable to determine next left/right edge for edge %d"
+#: ../lib/gis/parser_standard_options.c:398
+#, fuzzy
+msgid "Name for output 3D raster map"
-#: ../lib/vector/Vlib/write_pg.c:2274
+#: ../lib/gis/parser_standard_options.c:406
#, fuzzy
-msgid "Unable to insert new edge. Topology not available."
+msgid "Name of 3D raster map"
-#: ../lib/vector/Vlib/write_pg.c:2373 ../lib/vector/Vlib/write_pg.c:2380
-msgid "Invalid topology"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2579 ../lib/vector/Vlib/write_pg.c:2676
-#, fuzzy, c-format
-msgid "Attempt to access non-existing feature %d"
-#: ../lib/vector/Vlib/write_pg.c:2610
+#: ../lib/gis/parser_standard_options.c:415
#, fuzzy
-msgid "Unable to determine next left/right edge"
+msgid "Name of 3D raster map(s)"
-#: ../lib/vector/Vlib/write_pg.c:2696
+#: ../lib/gis/parser_standard_options.c:424
#, fuzzy
-msgid "Unable to create new face"
+msgid "Data type used in the output raster3d map"
-#: ../lib/vector/Vlib/write_pg.c:2834 ../lib/vector/Vlib/write_pg.c:2846
-#, fuzzy, c-format
-msgid "Unable to delete node %d"
-#: ../lib/vector/Vlib/dangles.c:148
-msgid "Changed"
+#: ../lib/gis/parser_standard_options.c:433
+msgid ""
+"Number of digits used as mantissa in the internal map storage, 0 -23 for "
+"float, 0 - 52 for double, max or default"
msgstr ""
-#: ../lib/vector/Vlib/dangles.c:151
-msgid "Removed"
+#: ../lib/gis/parser_standard_options.c:443
+msgid "The compression method used in the output raster3d map"
msgstr ""
-#: ../lib/vector/Vlib/dangles.c:154
-msgid "Selected"
+#: ../lib/gis/parser_standard_options.c:453
+msgid ""
+"The dimensions of the tiles used in the output raster3d map (XxYxZ or "
+"default: 16x16x8)"
msgstr ""
-#: ../lib/vector/Vlib/dangles.c:262
-#, fuzzy, c-format
-msgid "%s lines: %d"
-#: ../lib/vector/Vlib/dangles.c:263
-#, c-format
-msgid "%s dangles: %d"
+#: ../lib/gis/parser_standard_options.c:463
+msgid "Name of input vector map"
msgstr ""
-#: ../lib/vector/Vlib/build_sfa.c:279 ../lib/vector/Vlib/build_sfa.c:546
-#, fuzzy, c-format
-msgid "Unable to calculate centroid for area %d"
-#: ../lib/vector/Vlib/build_sfa.c:305
-#, c-format
-msgid "Feature type %d not supported"
+#: ../lib/gis/parser_standard_options.c:464
+#: ../lib/gis/parser_standard_options.c:491
+msgid "Or data source for direct OGR access"
msgstr ""
-#: ../lib/vector/Vlib/build_sfa.c:603 ../lib/vector/Vlib/read_ogr.c:344
-#: ../lib/vector/Vlib/read_ogr.c:578
-#, c-format
-msgid "OGR feature type %d not supported"
+#: ../lib/gis/parser_standard_options.c:473
+msgid "Name of input vector map(s)"
msgstr ""
-#: ../lib/vector/Vlib/build_sfa.c:665
-#, fuzzy, c-format
-msgid "One feature without geometry skipped"
-msgid_plural "%d features without geometry skipped"
-msgstr[0] "Datum %s 테이블파일을 열 수 없습니다"
-msgstr[1] "Datum %s 테이블파일을 열 수 없습니다"
-#: ../lib/vector/Vlib/build_sfa.c:722
-#, c-format
-msgid "%s: Native format unsupported"
+#: ../lib/gis/parser_standard_options.c:474
+msgid "Or data source(s) for direct OGR access"
msgstr ""
-#: ../lib/vector/Vlib/build_sfa.c:748
-msgid "Feature index is built only for non-native formats. Nothing to dump."
+#: ../lib/gis/parser_standard_options.c:482
+msgid "Name for output vector map"
msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:361
+#: ../lib/gis/parser_standard_options.c:490
#, fuzzy
-msgid "Line is not looped"
+msgid "Name of vector map"
-#: ../lib/vector/Vlib/buffer2.c:443
-#, c-format
-msgid "Unexpected result of line_intersection() res = %d"
+#: ../lib/gis/parser_standard_options.c:500
+#, fuzzy
+msgid "Name of vector map(s)"
+#: ../lib/gis/parser_standard_options.c:509
+#: ../lib/gis/parser_standard_options.c:518
+#, fuzzy
+msgid "Input feature type"
+msgstr "알려지지 않은 벡터타입입니다"
+#: ../lib/gis/parser_standard_options.c:525
+msgid "Layer number or name"
msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:589
+#: ../lib/gis/parser_standard_options.c:527
msgid ""
-"Next edge was visited (right) but it is not the first one !!! breaking loop"
+"Vector features can have category values in different layers. This number "
+"determines which layer to use. When used with direct OGR access this is the "
+"layer name."
msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:600
+#: ../lib/gis/parser_standard_options.c:537
+msgid "Layer number or name ('-1' for all layers)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:539
msgid ""
-"Next edge was visited (left) but it is not the first one !!! breaking loop"
+"A single vector map can be connected to multiple database tables. This "
+"number determines which table to use. When used with direct OGR access this "
+"is the layer name."
msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:648
-msgid "side != 0 feature not implemented"
+#: ../lib/gis/parser_standard_options.c:548
+msgid "Category value"
msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:890 ../lib/vector/Vlib/buffer2.c:937
-msgid "zero area size"
+#: ../lib/gis/parser_standard_options.c:556
+msgid "Category values"
msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:896 ../lib/vector/Vlib/buffer2.c:943
-#, fuzzy
-msgid "Line was not closed"
+#: ../lib/gis/parser_standard_options.c:557
+#: ../lib/gis/parser_standard_options.c:572
+msgid "Example: 1,3,7-9,13"
+msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:909 ../lib/vector/Vlib/buffer2.c:960
-msgid "Vect_get_point_in_poly() failed"
+#: ../lib/gis/parser_standard_options.c:564
+msgid "Feature id"
msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:60
-msgid "OGR datasource not defined"
+#: ../lib/gis/parser_standard_options.c:571
+msgid "Feature ids"
msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:97
-#, fuzzy, c-format
-msgid "OGR layer <%s> not found"
+#: ../lib/gis/parser_standard_options.c:582
+#: ../lib/gis/parser_standard_options.c:590
+#, fuzzy
+msgid "Name of input file"
-#: ../lib/vector/Vlib/open_ogr.c:145 ../lib/vector/Vlib/open_pg.c:193
-#, fuzzy, c-format
-msgid "Unable to open feature index file for vector map <%s>"
-msgstr "임시파일을 열 수 없습니다"
-#: ../lib/vector/Vlib/open_ogr.c:191
-#, fuzzy, c-format
-msgid "Unable to get OGR driver <%s>"
-#: ../lib/vector/Vlib/open_ogr.c:199
-#, fuzzy, c-format
-msgid "Unable to create OGR data source '%s'"
-#: ../lib/vector/Vlib/open_ogr.c:211
-#, c-format
-msgid "OGR layer <%s> already exists and will be overwritten"
+#: ../lib/gis/parser_standard_options.c:598
+msgid "Name for output file"
msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:215
-#, fuzzy, c-format
-msgid "Unable to delete OGR layer <%s>"
-#: ../lib/vector/Vlib/open_ogr.c:221
-#, fuzzy, c-format
-msgid "OGR layer <%s> already exists in datasource '%s'"
-#: ../lib/vector/Vlib/open_ogr.c:279
-#, c-format
-msgid ""
-"Feature index format version %d.%d is not supported by this release. Try to "
-"rebuild topology or upgrade GRASS."
+#: ../lib/gis/parser_standard_options.c:607
+msgid "Field separator"
msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:284
-#, c-format
-msgid ""
-"Your GRASS version does not fully support feature index format %d.%d of the "
-"vector. Consider to rebuild topology or upgrade GRASS."
+#: ../lib/gis/parser_standard_options.c:608
+msgid "Special characters: pipe, comma, space, tab, newline"
msgstr ""
-#: ../lib/vector/Vlib/overlay.c:72
-msgid "unknown operator"
+#: ../lib/gis/parser_standard_options.c:619
+#: ../lib/gis/parser_standard_options.c:630
+msgid "Color"
msgstr ""
-#: ../lib/vector/Vlib/overlay.c:124
-msgid "Overlay: line/boundary types not supported by AND operator"
+#: ../lib/gis/parser_standard_options.c:621
+msgid "Either a standard color name or R:G:B triplet"
msgstr ""
-#: ../lib/vector/Vlib/overlay.c:127
-msgid "Overlay: area x area types not supported by AND operator"
+#: ../lib/gis/parser_standard_options.c:632
+msgid "Either a standard color name, R:G:B triplet, or \"none\""
msgstr ""
-#: ../lib/vector/Vlib/remove_duplicates.c:199
-#, fuzzy, c-format
-msgid "Removed duplicates: %d"
+#: ../lib/gis/parser_standard_options.c:643
+#, fuzzy
+msgid "Name of input directory"
-#: ../lib/vector/Vlib/break_polygons.c:102
-msgid "Break polygons: Bug in binary tree!"
+#: ../lib/gis/parser_standard_options.c:653
+msgid "Units"
msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:156
-#: ../lib/vector/Vlib/break_polygons.c:435
-msgid "Breaking polygons (pass 1: select break points)..."
+#: ../lib/gis/parser_standard_options.c:662
+msgid "Data type(s)"
msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:286
-#: ../lib/vector/Vlib/break_polygons.c:552
-msgid "Breaking polygons (pass 2: break at selected points)..."
+#: ../lib/gis/parser_standard_options.c:672
+msgid "Name of mapset (default: current search path)"
msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:398
-#: ../lib/vector/Vlib/break_polygons.c:650
-#, c-format
-msgid "Breaks: %d"
+#: ../lib/gis/parser_standard_options.c:673
+msgid "'.' for current mapset"
msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:592
-msgid "Point not in search tree!"
+#: ../lib/gis/parser_standard_options.c:681
+msgid "Location name"
msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:43
-#, c-format
-msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
+#: ../lib/gis/parser_standard_options.c:682
+msgid "Location name (not location path)"
msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:50
-#, c-format
-msgid "Illegal vector map name <%s>. Must start with a letter."
+#: ../lib/gis/parser_standard_options.c:692
+msgid "GRASS GIS database directory"
msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:58
-#, c-format
-msgid "Illegal vector map name <%s>. Character '%c' not allowed."
+#: ../lib/gis/parser_standard_options.c:693
+msgid "Default: path to the current GRASS GIS database"
msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:65
-#, c-format
-msgid ""
-"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
-msgstr ""
+#: ../lib/gis/parser_standard_options.c:705
+#, fuzzy
+msgid "Coordinates"
+msgstr "잘못된 좌표"
-#: ../lib/vector/Vlib/legal_vname.c:100 ../lib/vector/Vlib/legal_vname.c:104
-#, fuzzy, c-format
-msgid "Output vector map name <%s> is not in the current mapset (%s)"
-#: ../lib/vector/Vlib/legal_vname.c:117 ../lib/vector/Vlib/legal_vname.c:121
-#, fuzzy, c-format
-msgid "Output vector map name <%s> is not SQL compliant"
+#: ../lib/gis/parser_standard_options.c:714
+#, fuzzy
+msgid "Name of color table"
-#: ../lib/vector/Vlib/legal_vname.c:159 ../lib/vector/Vlib/legal_vname.c:163
-#, c-format
-msgid "Output vector map <%s> is used as input"
+#: ../lib/gis/parser_standard_options.c:725
+msgid "String representing NULL value"
msgstr ""
-#: ../lib/vector/Vlib/intersect2.c:1169 ../lib/vector/Vlib/intersect2.c:1175
-#: ../lib/vector/Vlib/intersect2.c:1177 ../lib/vector/Vlib/intersect2.c:1229
-#: ../lib/vector/Vlib/intersect2.c:1238 ../lib/vector/Vlib/intersect2.c:1259
-#: ../lib/vector/Vlib/intersect2.c:1276 ../lib/vector/Vlib/intersect.c:1157
-#: ../lib/vector/Vlib/intersect.c:1163 ../lib/vector/Vlib/intersect.c:1165
-#: ../lib/vector/Vlib/intersect.c:1219 ../lib/vector/Vlib/intersect.c:1228
-#: ../lib/vector/Vlib/intersect.c:1249 ../lib/vector/Vlib/intersect.c:1266
-msgid "Error while adding point to array. Out of memory"
-msgstr ""
-#: ../lib/vector/Vlib/copy.c:81
-#, fuzzy, c-format
-msgid "Unable to copy features. Input vector map <%s> is not open"
+#: ../lib/gis/parser_standard_options.c:734
+#, fuzzy
+msgid "Name of saved region"
-#: ../lib/vector/Vlib/copy.c:104
-#, fuzzy, c-format
-msgid "Unable to create PostGIS layer <%s>"
+#: ../lib/gis/parser_standard_options.c:744
+#, fuzzy
+msgid "Name of the input space time dataset"
-#: ../lib/vector/Vlib/copy.c:133
-#, fuzzy, c-format
-msgid "Vector map <%s> not open on topological level. Areas will be skipped!"
+#: ../lib/gis/parser_standard_options.c:753
+#, fuzzy
+msgid "Name of the input space time datasets"
-#: ../lib/vector/Vlib/copy.c:229 ../lib/vector/Vlib/copy.c:234
-msgid "Copying features..."
+#: ../lib/gis/parser_standard_options.c:761
+msgid "Name of the output space time dataset"
msgstr ""
-#: ../lib/vector/Vlib/copy.c:231
-#, c-format
-msgid "Copying features (%s)..."
-msgstr ""
+#: ../lib/gis/parser_standard_options.c:769
+#, fuzzy
+msgid "Name of the input space time raster dataset"
-#: ../lib/vector/Vlib/copy.c:334
-msgid "Writing new feature failed"
-msgstr ""
+#: ../lib/gis/parser_standard_options.c:778
+#, fuzzy
+msgid "Name of the input space time raster datasets"
-#: ../lib/vector/Vlib/copy.c:340
-#, fuzzy, c-format
-msgid "%d features without category or from different layer skipped"
+#: ../lib/gis/parser_standard_options.c:786
+#, fuzzy
+msgid "Name of the output space time raster dataset"
-#: ../lib/vector/Vlib/copy.c:372
-msgid "Exporting nodes..."
-msgstr ""
-#: ../lib/vector/Vlib/copy.c:400
-#, fuzzy, c-format
-msgid "Writing node %d failed"
+#: ../lib/gis/parser_standard_options.c:794
+#, fuzzy
+msgid "Name of the input space time vector dataset"
-#: ../lib/vector/Vlib/copy.c:478
-msgid "Exporting areas..."
+#: ../lib/gis/parser_standard_options.c:803
+msgid "Name of the input space time vector datasets"
msgstr ""
-#: ../lib/vector/Vlib/copy.c:505
-#, c-format
-msgid "No centroid defined for area %d. Area not exported."
+#: ../lib/gis/parser_standard_options.c:811
+msgid "Name of the output space time vector dataset"
msgstr ""
-#: ../lib/vector/Vlib/copy.c:534 ../lib/vector/Vlib/copy.c:542
-#, fuzzy, c-format
-msgid "Writing area %d failed"
+#: ../lib/gis/parser_standard_options.c:819
+#, fuzzy
+msgid "Name of the input space time raster3d dataset"
-#: ../lib/vector/Vlib/copy.c:550
-#, c-format
-msgid "%d areas without category or from different layer skipped"
-msgstr ""
+#: ../lib/gis/parser_standard_options.c:828
+#, fuzzy
+msgid "Name of the input space time raster3d datasets"
-#: ../lib/vector/Vlib/copy.c:604
-#, fuzzy, c-format
-msgid "Unable to copy table <%s> for layer %d from <%s> to <%s>"
+#: ../lib/gis/parser_standard_options.c:836
+#, fuzzy
+msgid "Name of the output space time raster3d dataset"
-#: ../lib/vector/Vlib/copy.c:723
-#, fuzzy, c-format
-msgid "Unable to add database link for vector map <%s>"
-#: ../lib/vector/Vlib/copy.c:747
-#, fuzzy, c-format
-msgid "Unable to open database <%s> with driver <%s>"
+#: ../lib/gis/parser_standard_options.c:845
+#, fuzzy
+msgid "Type of the input space time dataset"
-#: ../lib/vector/Vlib/copy.c:754
+#: ../lib/gis/parser_standard_options.c:853
#, fuzzy
-msgid "Unable to create index"
+msgid "Name of the input map"
-#: ../lib/vector/Vlib/copy.c:760
-#, fuzzy, c-format
-msgid "Unable to grant privileges on table <%s>"
+#: ../lib/gis/parser_standard_options.c:862
+#, fuzzy
+msgid "Name of the input maps"
+#: ../lib/gis/parser_standard_options.c:871
+#, fuzzy
+msgid "Type of the input map"
-#: ../lib/vector/Vlib/open.c:138
-#, c-format
-msgid "Programmer requested unknown access level %d"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:232
-#, fuzzy, c-format
-msgid "Vector map <%s> not found in current mapset"
-#: ../lib/vector/Vlib/open.c:252
+#: ../lib/gis/parser_standard_options.c:880
#, fuzzy
-msgid "Temporary vector maps can be accessed only in the current mapset"
+msgid "The temporal type of the space time dataset"
-#: ../lib/vector/Vlib/open.c:277
+#: ../lib/gis/parser_standard_options.c:887
msgid ""
-"Vector map which is not in the current mapset cannot be opened for update"
+"WHERE conditions of SQL statement without 'where' keyword used in the "
+"temporal GIS framework"
msgstr ""
-#: ../lib/vector/Vlib/open.c:311
-#, fuzzy, c-format
-msgid "Unable to read header file of vector map <%s>"
+#: ../lib/gis/parser_standard_options.c:888
+msgid "Example: start_time > '2001-01-01 12:30:00'"
+msgstr ""
-#: ../lib/vector/Vlib/open.c:352
-#, fuzzy, c-format
-msgid "Unable to open topology file for vector map <%s>"
+#: ../lib/gis/parser_standard_options.c:898
+msgid "The method to be used for sampling the input dataset"
+msgstr ""
-#: ../lib/vector/Vlib/open.c:367 ../lib/vector/Vlib/open.c:871
-#: ../lib/vector/Vlib/build.c:865
-#, fuzzy, c-format
-msgid "Unable to open spatial index file for vector map <%s>"
+#: ../lib/gis/parser_standard_options.c:932
+#, fuzzy
+msgid "Do not create attribute table"
-#: ../lib/vector/Vlib/open.c:393 ../lib/vector/Vlib/cindex.c:539
-#, fuzzy, c-format
-msgid "Unable to open category index file for vector map <%s>"
+#: ../lib/gis/parser_standard_options.c:936
+msgid "Do not build topology"
+msgstr ""
-#: ../lib/vector/Vlib/open.c:419
-#, fuzzy, c-format
-msgid ""
-"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
-"with v.build."
+#: ../lib/gis/parser_standard_options.c:937
+msgid "Advantageous when handling a large number of points"
+msgstr ""
-#: ../lib/vector/Vlib/open.c:445
-#, fuzzy, c-format
-msgid "Building topology for OGR layer <%s> from datasource '%s'..."
+#: ../lib/gis/token.c:169
+msgid "parse error"
+msgstr ""
-#: ../lib/vector/Vlib/open.c:453
-#, fuzzy, c-format
-msgid "Unable to open vector map <%s> on level %d"
+#: ../lib/gis/worker.c:84
+msgid "Task already has a worker"
+msgstr ""
+#: ../lib/gis/home.c:39
+#, fuzzy
+msgid "Unable to determine user's home directory"
-#: ../lib/vector/Vlib/open.c:507
+#: ../lib/gis/home.c:120
#, fuzzy, c-format
-msgid "Unable to open history file for vector map <%s>"
-#: ../lib/vector/Vlib/open.c:777
-#, fuzzy, c-format
-msgid "Unable to create vector map: <%s> is not in the current mapset (%s)"
-#: ../lib/vector/Vlib/open.c:786
-#, fuzzy, c-format
-msgid "Unable to create vector map: <%s> is not SQL compliant"
+msgid "Failed to create directory [%s]"
-#: ../lib/vector/Vlib/open.c:846
-#, fuzzy, c-format
-msgid "Unable to open history file of vector map <%s>"
+#: ../lib/gis/myname.c:46
+msgid "This location has no description."
+msgstr ""
-#: ../lib/vector/Vlib/open.c:887
+#: ../lib/gis/lrand48.c:84
#, c-format
-msgid "Using OGR/%s format"
+msgid "gettimeofday failed: %s"
msgstr ""
-#: ../lib/vector/Vlib/open.c:891
-msgid "Using PostGIS Topology format"
+#: ../lib/gis/lrand48.c:114
+msgid "Pseudo-random number generator not seeded"
msgstr ""
-#: ../lib/vector/Vlib/open.c:893
-msgid "Using PostGIS format"
+#: ../lib/gis/error.c:361
+msgid "WARNING: "
msgstr ""
-#: ../lib/vector/Vlib/open.c:896
-#, fuzzy
-msgid "Using native format"
-msgstr "잘못된 좌표"
-#: ../lib/vector/Vlib/open.c:985
-#, fuzzy, c-format
-msgid "Unable to stat file <%s>"
-#: ../lib/vector/Vlib/open.c:1049
+#: ../lib/gis/error.c:362 ../lib/gis/parser.c:1588
#, c-format
-msgid "unknown %d (update Vect_maptype_info)"
+msgid "ERROR: "
msgstr ""
-#: ../lib/vector/Vlib/open.c:1138
-msgid "Size of 'coor' file differs from value saved in topology file"
+#: ../lib/gis/cmprbzip.c:82 ../lib/gis/cmprbzip.c:142
+msgid "GRASS needs to be compiled with BZIP2 for BZIP2 compression"
msgstr ""
-#: ../lib/vector/Vlib/open.c:1149 ../lib/vector/Vlib/open.c:1248
+#: ../lib/gis/key_value3.c:33
#, fuzzy, c-format
-msgid "Please rebuild topology for vector map <%s@%s>"
-#: ../lib/vector/Vlib/open.c:1237
-msgid "Size of 'coor' file differs from value saved in sidx file"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:1317
-#, fuzzy
-msgid "Unable to open OGR file"
+msgid "Unable to open output file <%s>: %s"
-#: ../lib/vector/Vlib/open.c:1343
-msgid "OGR output also detected, using OGR"
-msgstr ""
+#: ../lib/gis/key_value3.c:36
+#, fuzzy, c-format
+msgid "Error writing file <%s>: %s"
+msgstr "임시파일을 열 수 없습니다"
-#: ../lib/vector/Vlib/close.c:91
+#: ../lib/gis/key_value3.c:39
#, fuzzy, c-format
-msgid "Unable to create vector map <%s>"
+msgid "Error closing output file <%s>: %s"
-#: ../lib/vector/Vlib/close.c:108
-#, fuzzy
-msgid "Copying features failed"
+#: ../lib/gis/key_value3.c:60
+#, fuzzy, c-format
+msgid "Unable to open input file <%s>: %s"
-#: ../lib/vector/Vlib/close.c:141
+#: ../lib/gis/key_value3.c:64
#, fuzzy, c-format
-msgid "Unable to open %s file"
+msgid "Error reading file <%s>: %s"
-#: ../lib/vector/Vlib/close.c:226
+#: ../lib/gis/key_value3.c:67
#, fuzzy, c-format
-msgid "Unable to close vector <%s>"
+msgid "Error closing input file <%s>: %s"
-#: ../lib/vector/Vlib/close.c:257
+#: ../lib/gis/done_msg.c:38
#, c-format
-msgid "Invalid request for writing frmt file - map format is %d"
+msgid "%s complete. %s"
msgstr ""
-#: ../lib/vector/Vlib/close.c:289
+#: ../lib/gis/open.c:68
+#, c-format
+msgid "G__open(read): mapset <%s> doesn't match xmapset <%s>"
+msgstr ""
+#: ../lib/gis/open.c:89
#, fuzzy, c-format
-msgid "Link to vector map <%s> created"
+msgid "G__open(read): Unable to open '%s': %s"
-#: ../lib/vector/Vlib/cindex.c:32
-msgid "Category index is not up to date"
+#: ../lib/gis/open.c:98
+#, c-format
+msgid "G__open(write): xmapset <%s> != G_mapset() <%s>"
msgstr ""
-#: ../lib/vector/Vlib/cindex.c:38
-msgid "Layer index out of range"
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:268
-#, fuzzy
-msgid "Category index out of range"
-msgstr "카테고리는 정수여야 합니다."
-#: ../lib/vector/Vlib/cindex.c:488
+#: ../lib/gis/open.c:122
#, fuzzy, c-format
-msgid "Unable to create category index file for vector map <%s>"
+msgid "G__open(write): Unable to open '%s': %s"
-#: ../lib/vector/Vlib/cindex.c:497
-#, fuzzy
-msgid "Error writing out category index file"
-#: ../lib/vector/Vlib/snap.c:223 ../lib/vector/Vlib/snap.c:582
-msgid "Snap vertices Pass 1: select points"
+#: ../lib/gis/rd_cellhd.c:141 ../lib/gis/rd_cellhd.c:152
+#: ../lib/gis/rd_cellhd.c:162 ../lib/gis/rd_cellhd.c:179
+#: ../lib/gis/rd_cellhd.c:195 ../lib/gis/rd_cellhd.c:203
+#: ../lib/gis/rd_cellhd.c:211 ../lib/gis/rd_cellhd.c:219
+#: ../lib/gis/rd_cellhd.c:227 ../lib/gis/rd_cellhd.c:235
+#: ../lib/gis/rd_cellhd.c:243 ../lib/gis/rd_cellhd.c:245
+#: ../lib/gis/rd_cellhd.c:253 ../lib/gis/rd_cellhd.c:255
+#: ../lib/gis/rd_cellhd.c:263 ../lib/gis/rd_cellhd.c:265
+#: ../lib/gis/rd_cellhd.c:273 ../lib/gis/rd_cellhd.c:275
+#: ../lib/gis/rd_cellhd.c:283 ../lib/gis/rd_cellhd.c:285
+#: ../lib/gis/rd_cellhd.c:293 ../lib/gis/rd_cellhd.c:295
+#: ../lib/gis/rd_cellhd.c:303 ../lib/gis/rd_cellhd.c:305
+#: ../lib/gis/rd_cellhd.c:313 ../lib/gis/rd_cellhd.c:315
+#: ../lib/gis/rd_cellhd.c:323 ../lib/gis/rd_cellhd.c:325
+#: ../lib/gis/rd_cellhd.c:333 ../lib/gis/rd_cellhd.c:335
+#: ../lib/gis/rd_cellhd.c:343 ../lib/gis/rd_cellhd.c:351
+#: ../lib/gis/rd_cellhd.c:355
+msgid "Syntax error in cell header"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:271 ../lib/vector/Vlib/snap.c:636
-msgid "Snap vertices Pass 2: assign anchor vertices"
+#: ../lib/gis/rd_cellhd.c:149
+msgid "Duplicate projection field"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:340 ../lib/vector/Vlib/snap.c:705
-msgid "Snap vertices Pass 3: snap to assigned points"
+#: ../lib/gis/rd_cellhd.c:159
+msgid "Duplicate zone field"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:525 ../lib/vector/Vlib/snap.c:887
+#: ../lib/gis/rd_cellhd.c:169 ../lib/gis/rd_cellhd.c:171
+#: ../lib/gis/rd_cellhd.c:360 ../lib/gis/rd_cellhd.c:362
+#: ../lib/gis/rd_cellhd.c:364 ../lib/gis/rd_cellhd.c:366
+#: ../lib/gis/rd_cellhd.c:368 ../lib/gis/rd_cellhd.c:370
+#: ../lib/gis/rd_cellhd.c:381 ../lib/gis/rd_cellhd.c:383
+#: ../lib/gis/rd_cellhd.c:385 ../lib/gis/rd_cellhd.c:387
#, c-format
-msgid "Snapped vertices: %d"
+msgid "Field <%s> missing"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:526 ../lib/vector/Vlib/snap.c:888
-#, fuzzy, c-format
-msgid "New vertices: %d"
+#: ../lib/gis/rd_cellhd.c:193
+msgid "Duplicate north field"
+msgstr ""
-#: ../lib/vector/Vlib/snap.c:915
-#, fuzzy
-msgid "Reading features..."
+#: ../lib/gis/rd_cellhd.c:201
+msgid "Duplicate south field"
+msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:88
-msgid "No DB connection"
+#: ../lib/gis/rd_cellhd.c:209
+msgid "Duplicate east field"
msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:93 ../lib/vector/Vlib/build_ogr.c:82
-#, c-format
-msgid "Feature table <%s> has no primary key defined"
+#: ../lib/gis/rd_cellhd.c:217
+msgid "Duplicate west field"
msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:95
-msgid "Random read is not supported for this layer. Unable to build topology."
+#: ../lib/gis/rd_cellhd.c:225
+msgid "Duplicate top field"
msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:101 ../lib/vector/Vlib/build_ogr.c:90
-#, c-format
-msgid "Using external data format '%s' (feature type '%s')"
+#: ../lib/gis/rd_cellhd.c:233
+msgid "Duplicate bottom field"
msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:105
+#: ../lib/gis/rd_cellhd.c:241
#, fuzzy
-msgid "Building pseudo-topology over simple features..."
+msgid "Duplicate e-w resolution field"
+msgstr "잘못된 e-w 해상도"
-#: ../lib/vector/Vlib/build_pg.c:107
-#, fuzzy, c-format
-msgid "Building topology from PostGIS topology schema <%s>..."
+#: ../lib/gis/rd_cellhd.c:251
+#, fuzzy
+msgid "Duplicate 3D e-w resolution field"
-#: ../lib/vector/Vlib/build_pg.c:212 ../lib/vector/Vlib/open_pg.c:1485
-#, c-format
-msgid "Inconsistency in topology: number of nodes %d (should be %d)"
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:237
+#: ../lib/gis/rd_cellhd.c:261
#, fuzzy
-msgid "Cleaning-up topology schema..."
+msgid "Duplicate n-s resolution field"
+msgstr "잘못된 n-s 해상도"
-#: ../lib/vector/Vlib/build_pg.c:282
+#: ../lib/gis/rd_cellhd.c:271
#, fuzzy
-msgid "Updating faces..."
+msgid "Duplicate 3D n-s resolution field"
-#: ../lib/vector/Vlib/build_pg.c:314
+#: ../lib/gis/rd_cellhd.c:281
#, fuzzy
-msgid "Updating edges..."
+msgid "Duplicate t-b resolution field"
+msgstr "잘못된 t-b3 해상도"
-#: ../lib/vector/Vlib/build_pg.c:323
-msgid "Inconsistency in topology detected. Dead line found."
+#: ../lib/gis/rd_cellhd.c:291
+msgid "Duplicate rows field"
msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:377
-msgid "Updating TopoGeometry data..."
+#: ../lib/gis/rd_cellhd.c:301
+msgid "Duplicate 3D rows field"
msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:462
-#, fuzzy, c-format
-msgid "Unsupported topo geometry type %d"
-msgstr "알려지지 않은 벡터타입입니다"
+#: ../lib/gis/rd_cellhd.c:311
+msgid "Duplicate cols field"
+msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:491
-#, fuzzy, c-format
-msgid "Unable to create <%s.%s>"
+#: ../lib/gis/rd_cellhd.c:321
+msgid "Duplicate 3D cols field"
+msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:642
-#, fuzzy
-msgid "Unable to write nodes, offset array mismatch"
+#: ../lib/gis/rd_cellhd.c:331
+msgid "Duplicate depths field"
+msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:671
-#, fuzzy
-msgid "Unable to write nodes"
+#: ../lib/gis/rd_cellhd.c:341
+msgid "Duplicate format field"
+msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:716
-#, fuzzy, c-format
-msgid "Inconsistency in topology: number of boundaries %d (should be %d)"
+#: ../lib/gis/rd_cellhd.c:349
+msgid "Duplicate compressed field"
+msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:739
-#, fuzzy
-msgid "Unable to write lines"
+#: ../lib/gis/parser_dependencies.c:122
+msgid "Internal error: option or flag not found"
+msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:790
+#: ../lib/gis/parser_dependencies.c:179
#, fuzzy, c-format
-msgid "Topology for centroid %d not available. Area %d skipped"
+msgid "<%s> or <%s>"
+msgstr "<%s>를 <%s>으로 이름을 바꿉니다"
-#: ../lib/vector/Vlib/build_pg.c:1000
-msgid "Create simple features topology from topogeometry data..."
+#, c-format
+msgid "<%s> and <%s>"
msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:1018
+#: ../lib/gis/parser_dependencies.c:212
#, c-format
-msgid ""
-"Unable to build simple features from topogeometry data. Unsupported type %d."
+msgid "Options %s are mutually exclusive"
msgstr ""
-#: ../lib/vector/Vlib/read.c:93 ../lib/vector/Vlib/read.c:129
-#: ../lib/vector/Vlib/read.c:168
-#, fuzzy
-msgid "Vector map is not open for reading"
+#: ../lib/gis/parser_dependencies.c:236
+#, c-format
+msgid "At least one of the following options is required: %s"
+msgstr ""
-#: ../lib/vector/Vlib/read.c:136 ../lib/vector/Vlib/read.c:180
-#, fuzzy, c-format
-msgid "Unable to read feature %d from vector map <%s>"
-msgstr "Datum %s 테이블파일을 열 수 없습니다"
+#: ../lib/gis/parser_dependencies.c:269
+#, c-format
+msgid "Option %s requires at least one of %s"
+msgstr ""
-#: ../lib/vector/Vlib/read.c:200
-#, fuzzy
-msgid "Line index is out of range"
+#: ../lib/gis/parser_dependencies.c:301
+#, c-format
+msgid "Option %s requires all of %s"
+msgstr ""
-#: ../lib/vector/Vlib/read.c:224
-#, fuzzy
-msgid "Node index is out of range"
+#: ../lib/gis/parser_dependencies.c:328
+#, c-format
+msgid "Option %s is mutually exclusive with all of %s"
+msgstr ""
-#: ../lib/vector/Vlib/read.c:248
-#, fuzzy
-msgid "Area index is out of range"
-#: ../lib/vector/Vlib/read.c:272
-#, fuzzy
-msgid "Isle index is out of range"
-#: ../lib/vector/Vlib/geos.c:52
-#, fuzzy
-msgid "vector map is not opened"
-#: ../lib/vector/Vlib/geos.c:55
+#: ../lib/gis/parser_dependencies.c:354
#, c-format
-msgid ""
-"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
-"vector map <%s>: %d)"
+msgid "Either all or none of %s must be given"
msgstr ""
-#: ../lib/vector/Vlib/geos.c:60
-msgid "only native format supported"
+#: ../lib/gis/parser_dependencies.c:387 ../lib/gis/parser_dependencies.c:424
+#, c-format
+msgid "Internal error: invalid rule type: %d"
msgstr ""
-#: ../lib/vector/Vlib/geos.c:65 ../lib/vector/Vlib/geos.c:258
+#: ../lib/gis/color_rules.c:88
#, fuzzy
-msgid "Attempt to read dead line"
+msgid "no description"
-#: ../lib/vector/Vlib/geos.c:90
-#, c-format
-msgid "Vect_read_area_geos(): unable to read area id %d"
+#: ../lib/gis/env.c:311
+msgid "GISRC - variable not set"
msgstr ""
-#: ../lib/vector/Vlib/geos.c:104
+#: ../lib/gis/env.c:343 ../lib/gis/env.c:369
#, c-format
-msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
+msgid "Variable '%s' not set"
msgstr ""
-#: ../lib/vector/Vlib/geos.c:205
-#, fuzzy, c-format
-msgid "Unable to read line offset %ld"
+#: ../lib/gis/parser_help.c:84
+msgid "Description:"
+msgstr ""
-#: ../lib/vector/Vlib/geos.c:412
-#, fuzzy, c-format
-msgid "Attempt to read points of nonexistent area id %d"
+#: ../lib/gis/parser_help.c:103
+msgid "Keywords:"
+msgstr ""
-#: ../lib/vector/Vlib/geos.c:472
-#, fuzzy, c-format
-msgid "Unable to read feature id %d"
+#: ../lib/gis/parser_help.c:111
+msgid "Usage:"
+msgstr ""
-#: ../lib/vector/Vlib/line.c:184 ../lib/vector/Vlib/line.c:217
-#: ../lib/vector/Vlib/line.c:250
-msgid "Index out of range in"
+#: ../lib/gis/parser_help.c:141
+msgid "ERROR: Option key not defined"
msgstr ""
-#: ../lib/vector/Vlib/line.c:550
-msgid "Segment outside line, no segment created"
+#: ../lib/gis/parser_help.c:191
+msgid "Flags:"
msgstr ""
-#: ../lib/vector/Vlib/close_nat.c:74
-#, fuzzy, c-format
-msgid "Unable to create '%s': %s"
+#: ../lib/gis/parser_help.c:220
+msgid "Super quiet module output"
+msgstr ""
-#: ../lib/vector/Vlib/close_nat.c:81
-#, fuzzy, c-format
-msgid "Unable to copy '%s': %s"
+#: ../lib/gis/parser_help.c:230
+msgid "Parameters:"
+msgstr ""
-#: ../lib/vector/Vlib/close_nat.c:167
-#, fuzzy, c-format
-msgid "Unable to drop table <%s>"
+#: ../lib/gis/parser_help.c:253
+#, c-format
+msgid " %*s default: %s\n"
+msgstr ""
-#: ../lib/vector/Vlib/constraint.c:150
-msgid "Layer constraint ignored for non-native vector formats"
+#: ../lib/gis/parser_help.c:279
+#, c-format
+msgid " %*s options: "
msgstr ""
-#: ../lib/vector/Vlib/ascii.c:84
+#: ../lib/gis/adj_cellhd.c:42
#, fuzzy, c-format
-msgid "Error reading ASCII file: (bad type) [%s]"
+msgid "Illegal n-s resolution value <%lf>"
+msgstr "잘못된 n-s 해상도값입니다."
-#: ../lib/vector/Vlib/ascii.c:123
-#, fuzzy, c-format
-msgid "Error reading ASCII file: (unknown type) [%s]"
+#: ../lib/gis/adj_cellhd.c:46 ../lib/gis/adj_cellhd.c:197
+msgid "Illegal row value"
+msgstr "잘못된 row 값입니다."
-#: ../lib/vector/Vlib/ascii.c:143
-msgid "End of ASCII file reached before end of coordinates"
-msgstr ""
+#: ../lib/gis/adj_cellhd.c:50 ../lib/gis/adj_cellhd.c:203
+msgid "Illegal e-w resolution value"
+msgstr "잘못된 e-w 해상도값입니다."
-#: ../lib/vector/Vlib/ascii.c:155
-#, fuzzy, c-format
-msgid "Error reading ASCII file: (bad point) [%s]"
+#: ../lib/gis/adj_cellhd.c:54 ../lib/gis/adj_cellhd.c:209
+msgid "Illegal col value"
+msgstr "잘못된 col 값입니다."
-#: ../lib/vector/Vlib/ascii.c:160
-#, fuzzy, c-format
-msgid "Unparsable longitude value: [%s]"
-#: ../lib/vector/Vlib/ascii.c:165
+#: ../lib/gis/adj_cellhd.c:74 ../lib/gis/adj_cellhd.c:239
#, c-format
-msgid "Unparsable latitude value: [%s]"
+msgid "Fixing subtle input data rounding error of north boundary (%g>%g)"
msgstr ""
-#: ../lib/vector/Vlib/ascii.c:201
-msgid "End of ASCII file reached before end of categories"
-msgstr ""
+#: ../lib/gis/adj_cellhd.c:79 ../lib/gis/adj_cellhd.c:244
+msgid "Illegal latitude for North"
+msgstr "북쪽경계를 위한 잘못된 위도입니다."
-#: ../lib/vector/Vlib/ascii.c:212
-#, fuzzy, c-format
-msgid "Error reading categories: [%s]"
-#: ../lib/vector/Vlib/ascii.c:225
-#, fuzzy
-msgid "Unable to copy points"
-#: ../lib/vector/Vlib/ascii.c:238
+#: ../lib/gis/adj_cellhd.c:85 ../lib/gis/adj_cellhd.c:250
#, c-format
-msgid "Vector map <%s> is 2D. %d 3D features (faces or kernels) skipped."
+msgid "Fixing subtle input data rounding error of south boundary (%g>%g)"
msgstr ""
-#: ../lib/vector/Vlib/ascii.c:270
+#: ../lib/gis/adj_cellhd.c:90 ../lib/gis/adj_cellhd.c:255
+msgid "Illegal latitude for South"
+msgstr "남쪽경계를 위한 잘못된 위도입니다."
+#: ../lib/gis/adj_cellhd.c:102 ../lib/gis/adj_cellhd.c:267
#, c-format
-msgid ""
-"Unexpected data in vector header:\n"
-"[%s]"
+msgid "Fixing subtle input data rounding error of west boundary (%g>%g)"
msgstr ""
-#: ../lib/vector/Vlib/ascii.c:306
+#: ../lib/gis/adj_cellhd.c:113 ../lib/gis/adj_cellhd.c:278
#, c-format
-msgid "Unknown keyword <%s> in vector head"
+msgid "Fixing subtle input data rounding error of east boundary (%g>%g)"
msgstr ""
-#: ../lib/vector/Vlib/ascii.c:465
-#, fuzzy, c-format
-msgid "Column <%s> does not exist"
+#: ../lib/gis/adj_cellhd.c:126 ../lib/gis/adj_cellhd.c:291
+msgid "North must be north of South"
+msgstr "북쪽경계는 남쪽경계보다 위쪽이어야합니다."
-#: ../lib/vector/Vlib/ascii.c:467
-msgid "Available columns:"
-msgstr ""
+#: ../lib/gis/adj_cellhd.c:128 ../lib/gis/adj_cellhd.c:293
+msgid "North must be larger than South"
+msgstr "북쪽경계는 남쪽경계보다 값이 커야합니다."
-#: ../lib/vector/Vlib/ascii.c:472
-msgid "Export cancelled"
-msgstr ""
+#: ../lib/gis/adj_cellhd.c:131 ../lib/gis/adj_cellhd.c:296
+msgid "East must be larger than West"
+msgstr "동쪽경계는 서쪽경계보다 값이 커야합니다."
-#: ../lib/vector/Vlib/ascii.c:505
-#, c-format
-msgid "Unknown type of column <%s>, export cancelled"
-msgstr ""
+#: ../lib/gis/adj_cellhd.c:150 ../lib/gis/adj_cellhd.c:340
+msgid "Invalid coordinates"
+msgstr "잘못된 좌표입니다."
-#: ../lib/vector/Vlib/ascii.c:539
-#, fuzzy, c-format
-msgid "Unable to select record from table <%s> (key %s, column %s)"
+#: ../lib/gis/adj_cellhd.c:191
+msgid "Illegal n-s resolution value"
-#: ../lib/vector/Vlib/ascii.c:661
-#, fuzzy, c-format
-msgid "Unknown feature type %d"
+#: ../lib/gis/adj_cellhd.c:193
+msgid "Illegal n-s3 resolution value"
+msgstr "잘못된 n-s3 해상도값입니다."
-#: ../lib/vector/Vlib/ascii.c:701
-#, c-format
-msgid "Feature has more categories. Only one category (%d) is exported."
-msgstr ""
+#: ../lib/gis/adj_cellhd.c:199
+msgid "Illegal row3 value"
+msgstr "잘못된 row3 값입니다."
-#: ../lib/vector/Vlib/ascii.c:718
-#, fuzzy, c-format
-msgid "Cannot select attributes for cat = %d"
+#: ../lib/gis/adj_cellhd.c:205
+msgid "Illegal e-w3 resolution value"
+msgstr "잘못된 e-w3 해상도값입니다."
-#: ../lib/vector/Vlib/ascii.c:724
-#, fuzzy
-msgid "Unable to fetch data from table"
+#: ../lib/gis/adj_cellhd.c:211
+msgid "Illegal col3 value"
+msgstr "잘못된 col3 값입니다."
-#: ../lib/vector/Vlib/ascii.c:756 ../lib/vector/Vlib/net_build.c:216
-#: ../lib/vector/Vlib/net_build.c:501 ../lib/vector/Vlib/net_build.c:519
-#: ../lib/vector/Vlib/net_build.c:802 ../lib/vector/Vlib/net_build.c:820
-#: ../lib/vector/Vlib/net_build.c:981
-#, fuzzy, c-format
-msgid "Column <%s> not found in table <%s>"
+#: ../lib/gis/adj_cellhd.c:215
+msgid "Illegal t-b3 resolution value"
+msgstr "잘못된 t-b3 해상도값입니다."
-#: ../lib/vector/Vlib/ascii.c:758
-#, fuzzy, c-format
-msgid "Column <%s>: unsupported data type"
+#: ../lib/gis/adj_cellhd.c:219
+msgid "Illegal depths value"
+msgstr "잘못된 depth 값입니다."
-#: ../lib/vector/Vlib/ascii.c:840
+#: ../lib/gis/adj_cellhd.c:299
#, fuzzy
-msgid "Unknown format"
+msgid "Top must be larger than Bottom"
+msgstr "북쪽경계는 남쪽경계보다 값이 커야합니다"
-#: ../lib/vector/Vlib/ascii.c:850
-msgid "Topology not available, unable to process areas"
+#: ../lib/gis/compress.c:131 ../lib/gis/compress.c:193
+#: ../lib/gis/compress.c:209
+msgid "Request for unsupported compressor"
msgstr ""
-#: ../lib/vector/Vlib/ascii.c:863
-#, fuzzy, c-format
-msgid "Unable to get boundary of area id %d"
-#: ../lib/vector/Vlib/ascii.c:875
-#, fuzzy, c-format
-msgid "Unable to get boundary of isle id %d (area id %d)"
-#: ../lib/vector/Vlib/ascii.c:889
+#: ../lib/gis/location.c:61
#, c-format
-msgid ""
-"%d features without category skipped. To export also features without "
-"category use '%s=-1'."
+msgid "LOCATION <%s> not available"
msgstr ""
-#: ../lib/vector/Vlib/array.c:96
+#: ../lib/gis/view.c:176
#, c-format
-msgid "%d errors in category string"
+msgid "Unable to open %s for writing"
msgstr ""
-#: ../lib/vector/Vlib/array.c:142 ../lib/vector/Vlib/array.c:267
-msgid "Mixed area and other type requested for vector array"
+#: ../lib/gis/view.c:262 ../lib/gis/view.c:479
+#, c-format
+msgid "Unable to open %s for reading"
msgstr ""
-#: ../lib/vector/Vlib/array.c:152 ../lib/vector/Vlib/array.c:175
-#: ../lib/vector/Vlib/array.c:304 ../lib/vector/Vlib/array.c:336
-msgid "Not enough space in vector array"
+#: ../lib/gis/view.c:465
+#, c-format
+msgid "GRASS window when view was saved:\n"
msgstr ""
-#: ../lib/vector/Vlib/array.c:292
-#, fuzzy, c-format
-msgid "Unable to select record from table <%s> (key %s, where %s)"
-#: ../lib/vector/Vlib/close_ogr.c:104 ../lib/vector/Vlib/close_pg.c:139
-#, fuzzy, c-format
-msgid "Unable to save feature index file for vector map <%s>"
-#: ../lib/vector/Vlib/build_ogr.c:71
-msgid "Empty OGR layer, nothing to build"
+#: ../lib/gis/view.c:545
+#, c-format
+msgid " Window saved in \"%s\" is completely outside of current GRASS window."
msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:84
+#: ../lib/gis/view.c:549
+#, c-format
msgid ""
-"Random read is not supported by OGR for this layer. Unable to build topology."
+" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:134
-#, fuzzy, c-format
-msgid "Unable to open fidx file for write <%s>"
-#: ../lib/vector/Vlib/dgraph.c:432
-msgid ""
-"Trying to add more edges to the planar_graph than the initial allocation "
-"size allows"
+#: ../lib/gis/get_ellipse.c:344 ../lib/gis/get_ellipse.c:367
+#, c-format
+msgid "Invalid a: field '%s' in file %s in <%s>"
msgstr ""
-#: ../lib/vector/Vlib/cats.c:45
-msgid "Vect_new_cats_struct(): Out of memory"
+#: ../lib/gis/get_ellipse.c:356
+#, c-format
+msgid "Invalid ellipsoid '%s' in file %s in <%s>"
msgstr ""
-#: ../lib/vector/Vlib/cats.c:127
+#: ../lib/gis/get_ellipse.c:370
#, c-format
-msgid "Too many categories (%d), unable to set cat %d (layer %d)"
+msgid "Invalid es: field '%s' in file %s in <%s>"
msgstr ""
-#: ../lib/vector/Vlib/cats.c:419
+#: ../lib/gis/get_ellipse.c:383
#, c-format
-msgid "Unable to convert category string '%s' (from '%s') to category range"
+msgid "No ellipsoid info given in file %s in <%s>"
msgstr ""
-#: ../lib/vector/Vlib/cats.c:572 ../lib/vector/Vlib/cats.c:668
-msgid "Layer number must be > 0 for category constraints"
+#: ../lib/gis/alloc.c:44 ../lib/gis/alloc.c:86 ../lib/gis/alloc.c:132
+#, c-format
+msgid "Current region rows: %d, cols: %d"
msgstr ""
-#: ../lib/vector/Vlib/cats.c:585
+#: ../lib/gis/alloc.c:47
#, c-format
-msgid "'%s' and '%s' parameters were supplied, cats will be ignored"
+msgid "G_malloc: unable to allocate %lu bytes of memory at %s:%d"
msgstr ""
-#: ../lib/vector/Vlib/cats.c:593
-#, fuzzy, c-format
-msgid "Loading categories from table <%s>..."
-#: ../lib/vector/Vlib/cats.c:605
-#, fuzzy, c-format
-msgid "One category loaded"
-msgid_plural "%d categories loaded"
-msgstr[0] "카테고리 정보가 없습니다."
-msgstr[1] "카테고리 정보가 없습니다."
-#: ../lib/vector/Vlib/cats.c:627
+#: ../lib/gis/alloc.c:89
#, c-format
-msgid "No categories selected with '%s' option"
+msgid "G_calloc: unable to allocate %lu * %lu bytes of memory at %s:%d"
msgstr ""
-#: ../lib/vector/Vlib/cats.c:637
+#: ../lib/gis/alloc.c:135
#, c-format
-msgid "%d errors in '%s' option"
+msgid "G_realloc: unable to allocate %lu bytes of memory at %s:%d"
msgstr ""
-#: ../lib/vector/Vlib/area.c:50
-#, fuzzy
-msgid "Attempt to read points of nonexistent area"
+#: ../lib/gis/mapset.c:38
+msgid "MAPSET is not set"
+msgstr ""
-#: ../lib/vector/Vlib/area.c:81
-#, fuzzy
-msgid "Attempt to read points of nonexistent isle"
+#: ../lib/gis/mapset.c:80
+#, c-format
+msgid "MAPSET <%s> not available"
+msgstr ""
-#: ../lib/vector/Vlib/area.c:121 ../lib/vector/Vlib/area.c:153
-#: ../lib/vector/Vlib/area.c:219 ../lib/vector/Vlib/area.c:248
-#, fuzzy, c-format
-msgid "Attempt to read topo for dead area (%d)"
-#: ../lib/vector/Vlib/area.c:189 ../lib/vector/Vlib/area.c:275
-#, fuzzy, c-format
-msgid "Attempt to read topo for dead isle (%d)"
-#: ../lib/vector/Vlib/merge_lines.c:240
+#: ../lib/gis/parser.c:355
#, c-format
-msgid "%d boundaries merged"
+msgid "BUG in option name, '%s' is not valid"
msgstr ""
-#: ../lib/vector/Vlib/merge_lines.c:241
+#: ../lib/gis/parser.c:407
#, c-format
-msgid "%d new boundaries"
+msgid "BUG in descriptions, option '%s' in <%s> does not exist"
msgstr ""
-#: ../lib/vector/Vlib/box.c:264
-#, fuzzy, c-format
-msgid "Unable to determine bbox for feature %d"
-#: ../lib/vector/Vlib/box.c:313 ../lib/vector/Vlib/box.c:359
-#, fuzzy, c-format
-msgid "Attempt to access area with invalid id (%d)"
-#: ../lib/vector/Vlib/box.c:325
-#, fuzzy, c-format
-msgid "Unable to determine bbox for area %d"
-#: ../lib/vector/Vlib/box.c:371
-#, fuzzy, c-format
-msgid "Unable to determine bbox for isle %d"
-#: ../lib/vector/Vlib/net_build.c:101 ../lib/vector/Vlib/net_build.c:727
-msgid "Building graph..."
+#: ../lib/gis/parser.c:525
+msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
msgstr ""
-#: ../lib/vector/Vlib/net_build.c:143 ../lib/vector/Vlib/net_build.c:775
-#, fuzzy
-msgid "Unable to build network graph"
-#: ../lib/vector/Vlib/net_build.c:149 ../lib/vector/Vlib/net_build.c:781
-msgid "Forward costs column not specified"
+#: ../lib/gis/parser.c:539
+msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
msgstr ""
-#: ../lib/vector/Vlib/net_build.c:156
-msgid "Turntable field < 1"
+#: ../lib/gis/parser.c:554
+msgid "Use either --qq or --verbose flag, not both. Assuming --qq."
msgstr ""
-#: ../lib/vector/Vlib/net_build.c:172
-#, fuzzy, c-format
-msgid "Turntable column <%s> not found in table <%s>"
-#: ../lib/vector/Vlib/net_build.c:182 ../lib/vector/Vlib/net_build.c:223
-#: ../lib/vector/Vlib/net_build.c:508 ../lib/vector/Vlib/net_build.c:526
-#: ../lib/vector/Vlib/net_build.c:809 ../lib/vector/Vlib/net_build.c:827
-#: ../lib/vector/Vlib/net_build.c:988
+#: ../lib/gis/parser.c:585
#, c-format
-msgid "Data type of column <%s> not supported (must be numeric)"
+msgid "Sorry <%s> is not a valid option"
msgstr ""
-#: ../lib/vector/Vlib/net_build.c:202 ../lib/vector/Vlib/net_build.c:967
-msgid "Setting node costs..."
+#: ../lib/gis/parser.c:598
+msgid "Your installation doesn't include GUI, exiting."
msgstr ""
-#: ../lib/vector/Vlib/net_build.c:277 ../lib/vector/Vlib/net_build.c:1032
-#, c-format
-msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
+#: ../lib/gis/parser.c:945
+msgid "Unable to determine program name"
msgstr ""
-#: ../lib/vector/Vlib/net_build.c:332 ../lib/vector/Vlib/net_build.c:352
-#, fuzzy
-msgid "Cannot add network arc for virtual node connection."
-#: ../lib/vector/Vlib/net_build.c:364
+#: ../lib/gis/parser.c:967 ../lib/gis/parser.c:984
#, c-format
-msgid ""
-"There exists more than one point of node <%d> with unique category field <"
-"%d>.\n"
-"The unique categories layer is not valid therefore you will probably get "
-"incorrect results."
+msgid "%s: Sorry, <%c> is not a valid flag"
msgstr ""
-#: ../lib/vector/Vlib/net_build.c:393
+#: ../lib/gis/parser.c:1114
#, c-format
-msgid ""
-"Unable to find point representing intersection <%d> in unique categories "
-"field <%d>.\n"
-"Cost for the intersection was set to 0.\n"
+msgid "%s: Sorry, <%s=> is ambiguous"
msgstr ""
-#: ../lib/vector/Vlib/net_build.c:407
+#: ../lib/gis/parser.c:1117
#, c-format
-msgid ""
-"Unable to find node for point representing intersection <%d> in unique "
-"categories field <%d>.\n"
+msgid "Option <%s=> matches"
msgstr ""
-#: ../lib/vector/Vlib/net_build.c:432
+#: ../lib/gis/parser.c:1135
#, c-format
-msgid ""
-"Database record for turn with cat = %d in not found. (The turn was skipped."
+msgid "Please update the usage of <%s>: option <%s> has been renamed to <%s>"
msgstr ""
-#: ../lib/vector/Vlib/net_build.c:465
-#, fuzzy
-msgid "Cannot add network arc representing turn."
-#: ../lib/vector/Vlib/net_build.c:487 ../lib/vector/Vlib/net_build.c:788
-msgid "Arc field < 1"
+#: ../lib/gis/parser.c:1148
+#, c-format
+msgid "%s: Sorry, <%s> is not a valid parameter"
msgstr ""
-#: ../lib/vector/Vlib/net_build.c:539 ../lib/vector/Vlib/net_build.c:840
-msgid "Registering arcs..."
+#: ../lib/gis/parser.c:1154 ../lib/gis/parser.c:1400
+#, c-format
+msgid "<%s> is an abbreviation for <%s>"
msgstr ""
-#: ../lib/vector/Vlib/net_build.c:558
+#: ../lib/gis/parser.c:1159
#, c-format
-msgid ""
-"Line with id <%d> has more unique categories defined in field <%d>.\n"
+msgid "Option <%s> does not accept multiple answers"
msgstr ""
-#: ../lib/vector/Vlib/net_build.c:579
+#: ../lib/gis/parser.c:1231
#, c-format
msgid ""
-"Database record for line %d (cat = %d, forward/both direction(s)) not found "
-"(cost was set to 0)"
+"Illegal range syntax for parameter <%s>\n"
+"\tPresented as: %s"
msgstr ""
-#: ../lib/vector/Vlib/net_build.c:596
+#: ../lib/gis/parser.c:1237
#, c-format
msgid ""
-"Database record for line %d (cat = %d, backword direction) not found(cost "
-"was set to 0)"
+"Value <%s> out of range for parameter <%s>\n"
+"\tLegal range: %s"
msgstr ""
-#: ../lib/vector/Vlib/net_build.c:658 ../lib/vector/Vlib/net_build.c:1064
-msgid "Flattening the graph..."
-msgstr ""
+#: ../lib/gis/parser.c:1243
+#, fuzzy, c-format
+msgid "Missing value for parameter <%s>"
+msgstr "Datum %s 테이블파일을 열 수 없습니다"
-#: ../lib/vector/Vlib/net_build.c:667 ../lib/vector/Vlib/net_build.c:1073
-msgid "Graph was built"
+#: ../lib/gis/parser.c:1249
+#, c-format
+msgid ""
+"Value <%s> ambiguous for parameter <%s>\n"
+"\tValid options: %s"
msgstr ""
-#: ../lib/vector/Vlib/net_build.c:869
+#: ../lib/gis/parser.c:1422
#, c-format
msgid ""
-"(forward/both direction(s) of line skipped)"
+"Required parameter <%s> not set:\n"
+"\t(%s)"
msgstr ""
-#: ../lib/vector/Vlib/net_build.c:888
+#: ../lib/gis/parser.c:1514
#, c-format
msgid ""
-"Database record for line %d (cat = %d, backword direction) not "
-"found(direction of line skipped)"
+"Option <%s> must be provided in multiples of %d\n"
+"\tYou provided %d item(s): %s"
msgstr ""
-#: ../lib/vector/Vlib/net_build.c:937
-#, fuzzy
-msgid "Cannot add network arc"
-#: ../lib/vector/Vlib/simple_features.c:225
-#, fuzzy, c-format
-msgid "Unknown Simple Features type (%d)"
-#: ../lib/vector/Vlib/simple_features.c:332
-#, fuzzy
-msgid "Unable to get number of simple features"
-#: ../lib/vector/Vlib/simple_features.c:341
-#, fuzzy, c-format
-msgid "Unable to report simple features for vector map <%s>"
-#: ../lib/vector/Vlib/read_ogr.c:215 ../lib/vector/Vlib/read_ogr.c:224
-#, fuzzy, c-format
-msgid "Unable to get feature geometry, fid %ld"
-#: ../lib/vector/Vlib/read_ogr.c:390
-msgid "OGR feature without ID"
+#: ../lib/gis/parser.c:1590 ../lib/gis/parser.c:1597
+#, c-format
+msgid "option <%s>: <%s> exists. To overwrite, use the --overwrite flag"
msgstr ""
-#: ../lib/vector/Vlib/read_ogr.c:514
+#: ../lib/gis/parser.c:1707
#, c-format
-msgid "OGR feature type '%s' not supported"
+msgid "%s= is not a separator option"
msgstr ""
-#: ../lib/vector/Vlib/graph.c:138
-#, fuzzy
-msgid "Unable to add network arc"
-#: ../lib/vector/Vlib/graph.c:226 ../lib/vector/Vlib/net_analyze.c:198
+#: ../lib/gis/parser.c:1710
#, c-format
-msgid "dglShortestPath error: %s"
+msgid "No separator given for %s="
msgstr ""
-#: ../lib/vector/Vlib/level_two.c:23
+#: ../lib/gis/parser.c:1772 ../lib/gis/parser.c:1789
#, fuzzy, c-format
-msgid "Vector map <%s> is not open at topological level"
+msgid "%s= is not a file option"
+msgstr ""
+"\n"
+"**<%s> 잘못된 이름 **\n"
-#: ../lib/vector/Vlib/level_two.c:284
+#: ../lib/gis/parser.c:1774
#, fuzzy, c-format
-msgid "Invalid node id: %d"
+msgid "Opening multiple files not supported for %s="
-#: ../lib/vector/Vlib/level_two.c:316
+#: ../lib/gis/parser.c:1780
#, fuzzy, c-format
-msgid "Nodes not available for line %d"
-#: ../lib/vector/Vlib/level_two.c:357
-#, fuzzy, c-format
-msgid "Areas not available for line %d"
-#: ../lib/vector/Vlib/level_two.c:362
-#, fuzzy, c-format
-msgid "Line %d is not a boundary"
+msgid "Unable to open %s file <%s>"
-#: ../lib/vector/Vlib/level_two.c:445
+#: ../lib/gis/parser.c:1786
#, fuzzy, c-format
-msgid "Topology info not available for feature %d"
-#: ../lib/vector/Vlib/intersect.c:127
-msgid "3D not supported by Vect_segment_intersection()"
-msgstr ""
-#: ../lib/vector/Vlib/intersect.c:313
-msgid "Vect_segment_intersection() ERROR (collinear vertical segments)"
-msgstr ""
-#: ../lib/vector/Vlib/intersect.c:407
-msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
-msgstr ""
-#: ../lib/vector/Vlib/break_lines.c:563
-#, c-format
-msgid "Intersections: %d"
-msgstr ""
-#: ../lib/vector/Vlib/select.c:116
-#, fuzzy, c-format
-msgid "Unable to delete item %d from spatial index"
+msgid "Unable to create %s file <%s>"
-#: ../lib/vector/Vlib/write_sfa.c:117
+#: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
#, fuzzy
-msgid "Unable to calculate centroid for area"
+msgid "Unable to seek"
-#: ../lib/vector/Vlib/write_sfa.c:219
-#, fuzzy
-msgid "Attempt to delete dead feature"
-#: ../lib/vector/Vlib/write_sfa.c:311
-#, fuzzy, c-format
-msgid "Unsupported vector map format (%d)"
-#: ../lib/vector/Vlib/bridges.c:213
-#, fuzzy, c-format
-msgid "Removed lines: %d"
-#: ../lib/vector/Vlib/bridges.c:214
-#, fuzzy, c-format
-msgid "Removed bridges: %d"
-#: ../lib/vector/Vlib/build.c:115
-msgid "Area of size = 0.0 (less than 4 vertices) ignored"
+#: ../lib/gis/seek.c:56
+msgid "Seek offset out of range"
msgstr ""
-#: ../lib/vector/Vlib/build.c:131
-msgid "Unable to add area (map closed, topo saved)"
+#: ../lib/gis/list.c:83
+#, c-format
+msgid "no %s files available in current mapset\n"
msgstr ""
-#: ../lib/vector/Vlib/build.c:139
-msgid "Unable to add isle (map closed, topo saved)"
+#: ../lib/gis/list.c:86
+#, c-format
+msgid "no %s files available in mapset <%s>\n"
msgstr ""
-#: ../lib/vector/Vlib/build.c:149
-msgid "Area of size = 0.0 ignored"
+#: ../lib/gis/list.c:132
+#, c-format
+msgid "%s files available in mapset <%s>:\n"
msgstr ""
-#: ../lib/vector/Vlib/build.c:200
-msgid "Request to find area outside nonexistent isle"
+#: ../lib/gis/list.c:204
+msgid "G_list: Unknown element type"
msgstr ""
-#: ../lib/vector/Vlib/build.c:351
-msgid "Larger bbox but smaller area!!!"
+#: ../lib/gis/find_file.c:114
+#, c-format
+msgid "'%s/%s' was found in more mapsets (also found in <%s>)"
msgstr ""
-#: ../lib/vector/Vlib/build.c:606
-msgid "Checking for topological errors..."
-msgstr ""
-#: ../lib/vector/Vlib/build.c:641
+#: ../lib/gis/find_file.c:127
#, fuzzy, c-format
-msgid "Number of lines of length zero: %d"
+msgid "Using <%s@%s>"
-#: ../lib/vector/Vlib/build.c:643
+#: ../lib/gis/mapset_msc.c:90
#, fuzzy, c-format
-msgid "Number of boundaries of length zero: %d"
+msgid "Unable to make mapset element %s (%s): %s"
-#: ../lib/vector/Vlib/build.c:652
+#: ../lib/gis/mapset_msc.c:94
#, fuzzy, c-format
-msgid "Number of boundary intersections: %d"
+msgid "Unable to access mapset element %s (%s): %s"
-#: ../lib/vector/Vlib/build.c:676
-#, fuzzy
-msgid "Skipping further checks because of incorrect boundaries"
-#: ../lib/vector/Vlib/build.c:726
+#: ../lib/gis/paths.c:201
#, fuzzy, c-format
-msgid "Number of redundant holes: %d"
+msgid "Unable to open file <%s> for reading"
-#: ../lib/vector/Vlib/build.c:871
+#: ../lib/gis/paths.c:217
#, fuzzy, c-format
-msgid "Building topology for vector map <%s>..."
+msgid "Unable to fetch security info for <%s>"
+msgstr "'%s' 디버그파일을 열 수 없습니다"
-#: ../lib/vector/Vlib/build.c:889
-msgid "Topology was built"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:900
+#: ../lib/gis/timestamp.c:292
#, fuzzy, c-format
-msgid "Number of nodes: %d"
+msgid "Unable to create timestamp file for %s map <%s@%s>"
-#: ../lib/vector/Vlib/build.c:901
+#: ../lib/gis/timestamp.c:301
#, fuzzy, c-format
-msgid "Number of primitives: %d"
+msgid "Invalid timestamp specified for %s map <%s@%s>"
-#: ../lib/vector/Vlib/build.c:902
+#: ../lib/gis/timestamp.c:331
#, fuzzy, c-format
-msgid "Number of points: %d"
+msgid "Unable to open timestamp file for %s map <%s@%s>"
-#: ../lib/vector/Vlib/build.c:903
+#: ../lib/gis/timestamp.c:340
#, fuzzy, c-format
-msgid "Number of lines: %d"
+msgid "Invalid timestamp file for %s map <%s@%s>"
-#: ../lib/vector/Vlib/build.c:904
+#: ../lib/gis/timestamp.c:479
#, fuzzy, c-format
-msgid "Number of boundaries: %d"
+msgid "Unable to open timestamp file for vector map <%s@%s>"
-#: ../lib/vector/Vlib/build.c:905
+#: ../lib/gis/timestamp.c:488
#, fuzzy, c-format
-msgid "Number of centroids: %d"
+msgid "Invalid timestamp file for vector map <%s@%s>"
-#: ../lib/vector/Vlib/build.c:908
+#: ../lib/gis/timestamp.c:524
#, fuzzy, c-format
-msgid "Number of faces: %d"
+msgid "Unable to create timestamp file for vector map <%s@%s>"
-#: ../lib/vector/Vlib/build.c:911
+#: ../lib/gis/timestamp.c:533
#, fuzzy, c-format
-msgid "Number of kernels: %d"
+msgid "Invalid timestamp specified for vector map <%s@%s>"
-#: ../lib/vector/Vlib/build.c:957
-#, fuzzy, c-format
-msgid "Number of areas: %d"
+#: ../lib/gis/legal_name.c:39
+#, c-format
+msgid "Illegal filename <%s>. Cannot start with '.' or be 'NULL'."
+msgstr ""
-#: ../lib/vector/Vlib/build.c:958
+#: ../lib/gis/legal_name.c:46
+#, c-format
+msgid "Illegal filename <%s>. Character <%c> not allowed.\n"
+msgstr ""
+#: ../lib/gis/legal_name.c:77 ../lib/gis/legal_name.c:81
+#, c-format
+msgid "Output raster map name <%s> is not valid map name"
+msgstr ""
+#: ../lib/gis/legal_name.c:118 ../lib/gis/legal_name.c:122
+#, c-format
+msgid "Output raster map <%s> is used as input"
+msgstr ""
+#: ../lib/imagery/target.c:38
#, fuzzy, c-format
-msgid "Number of isles: %d"
+msgid "Unable to read target file for group [%s]"
-#: ../lib/vector/Vlib/build.c:963
+#: ../lib/imagery/sigsetfile.c:41
+#, c-format
+msgid ""
+"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
+"is not current mapset"
+msgstr ""
+#: ../lib/imagery/sigsetfile.c:57
#, fuzzy, c-format
-msgid "Number of areas without centroid: %d"
+msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
-#: ../lib/vector/Vlib/build.c:968
+#: ../lib/imagery/points.c:124
#, fuzzy, c-format
-msgid "Number of centroids exceeds number of areas: %d > %d"
+msgid "Unable to open control point file for group [%s in %s]"
-#: ../lib/vector/Vlib/build.c:972
+#: ../lib/imagery/points.c:132
#, fuzzy, c-format
-msgid "Number of incorrect boundaries: %d"
+msgid "Bad format in control point file for group [%s in %s]"
-#: ../lib/vector/Vlib/build.c:976
+#: ../lib/imagery/points.c:159
#, fuzzy, c-format
-msgid "Number of centroids outside area: %d"
+msgid "Unable to create control point file for group [%s in %s]"
-#: ../lib/vector/Vlib/build.c:980
+#: ../lib/imagery/iclass.c:83
#, fuzzy, c-format
-msgid "Number of duplicate centroids: %d"
+msgid "No areas in category %d"
-#: ../lib/vector/Vlib/build.c:984
-#, fuzzy
-msgid "Number of areas: -"
-#: ../lib/vector/Vlib/build.c:985
-#, fuzzy
-msgid "Number of isles: -"
-#: ../lib/vector/Vlib/build.c:1013
+#: ../lib/imagery/iclass.c:127
#, fuzzy, c-format
-msgid "Unable to create topo file for vector map <%s>"
+msgid "Raster map <%s@%s> in subgroup <%s> does not exist"
-#: ../lib/vector/Vlib/build.c:1021
-#, fuzzy
-msgid "Error writing out topo file"
+#: ../lib/imagery/iclass.c:131
+#, fuzzy, c-format
+msgid "Raster map <%s@%s> in group <%s> does not exist"
-#: ../lib/vector/Vlib/build.c:1210
-#, fuzzy
-msgid ""
-"Unable to build spatial index from topology, vector map is not opened at "
-"topology level 2"
+#: ../lib/imagery/iclass.c:143
+#, c-format
+msgid "Subgroup <%s> does not have enough files (it has %d files)"
+msgstr ""
-#: ../lib/vector/Vlib/build.c:1233
+#: ../lib/imagery/iclass.c:147
#, c-format
-msgid "%s is no longer supported"
+msgid "Group <%s> does not have enough files (it has %d files)"
msgstr ""
-#: ../lib/vector/Vlib/build.c:1256
-msgid "Spatial index not available, can not be saved"
+#: ../lib/imagery/fopen.c:23
+#, c-format
+msgid "Unable to create file [%s] of group [%s in %s]"
msgstr ""
-#: ../lib/vector/Vlib/build.c:1268
+#: ../lib/imagery/fopen.c:36 ../lib/imagery/fopen.c:57
#, fuzzy, c-format
-msgid "Unable to create spatial index file for vector map <%s>"
+msgid "Unable to open file [%s] of group [%s in %s]"
-#: ../lib/vector/Vlib/build.c:1277
-#, fuzzy
-msgid "Error writing out spatial index file"
-#: ../lib/vector/Vlib/poly.c:268
-msgid "Unable to find point in polygon"
+#: ../lib/imagery/fopen.c:49
+#, c-format
+msgid "Unable to find file [%s] of group [%s in %s]"
msgstr ""
-#: ../lib/vector/Vlib/poly.c:810
-msgid "conditions failed"
+#: ../lib/imagery/fopen.c:79
+#, c-format
+msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
msgstr ""
-#: ../lib/vector/Vlib/level.c:34
-msgid "Map structure was never initialized"
+#: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
+#, c-format
+msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
msgstr ""
-#: ../lib/vector/Vlib/level.c:36
-msgid "Map structure has been closed"
+#: ../lib/imagery/fopen.c:116
+#, c-format
+msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:109 ../lib/vector/Vlib/open_pg.c:267
-#, fuzzy
-msgid "No feature tables found in database."
+#: ../lib/imagery/iscatt_core.c:81
+#, fuzzy, c-format
+msgid "Unable to write header into category raster condition file <%s>."
-#: ../lib/vector/Vlib/open_pg.c:133
+#: ../lib/imagery/iscatt_core.c:98
#, fuzzy, c-format
-msgid "Feature table <%s> not found in 'geometry_columns'"
+msgid "Unable to write into category raster condition file <%s>."
-#: ../lib/vector/Vlib/open_pg.c:181
-msgid "Topology schema not found."
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:273
+#: ../lib/imagery/iscatt_core.c:255
#, fuzzy, c-format
-msgid "PostGIS layer <%s.%s> already exists and will be overwritten"
+msgid "Unable to open category raster condtions file <%s>."
-#: ../lib/vector/Vlib/open_pg.c:276
+#: ../lib/imagery/iscatt_core.c:263
#, fuzzy, c-format
-msgid "Unable to delete PostGIS layer <%s>"
+msgid "Unable to find patch raster <%s>."
-#: ../lib/vector/Vlib/open_pg.c:282
-#, fuzzy, c-format
-msgid "PostGIS layer <%s.%s> already exists in database '%s'"
-#: ../lib/vector/Vlib/open_pg.c:390
-#, fuzzy
-msgid "No key column detected."
-#: ../lib/vector/Vlib/open_pg.c:462 ../lib/vector/Vlib/open_pg.c:474
+#: ../lib/imagery/iscatt_core.c:280
#, c-format
-msgid "Execution failed: %s"
+msgid "Resolutions of patch <%s> and patched file <%s> are not same."
msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:476
+#: ../lib/imagery/iscatt_core.c:307 ../lib/imagery/iscatt_core.c:349
#, c-format
-msgid "PostGIS topology schema <%s> dropped"
+msgid "Corrupted category raster conditions file <%s> (fseek failed)"
msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:559
-msgid ""
-"Connection to PostgreSQL database failed. Try to set up username/password by "
-"db.login."
-msgstr ""
+#: ../lib/imagery/iscatt_core.c:338
+#, fuzzy, c-format
+msgid "Unable to write into category raster conditions file <%s>"
-#: ../lib/vector/Vlib/open_pg.c:566
+#: ../lib/imagery/iscatt_core.c:526
#, fuzzy
-msgid "Unable to get database name"
-#: ../lib/vector/Vlib/open_pg.c:571
-#, c-format
-msgid "<%s> is not PostGIS database. DB table 'spatial_ref_sys' not found."
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:580
-#, fuzzy, c-format
-msgid "PostGIS Topology extension not found in the database <%s>"
+msgid "Unable to read from category raster condtition file."
-#: ../lib/vector/Vlib/open_pg.c:667
-msgid "Empty bounding box"
+#: ../lib/imagery/iscatt_core.c:533
+msgid "Invalid size of category raster conditions file."
msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:768
-#, c-format
-msgid "Inconsistency in topology: unable to read node %d"
+#: ../lib/imagery/iscatt_core.c:579
+msgid ""
+"Data inconsistent. Value computed for scatter plot is out of initialized "
+"range."
msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:834
+#: ../lib/imagery/iscatt_core.c:745
#, fuzzy, c-format
-msgid "Inconsistency in topology: node %d - unexpected feature type %d"
+msgid "Unbale to read find raster <%s>"
-#: ../lib/vector/Vlib/open_pg.c:1003
+#: ../lib/imagery/iscatt_core.c:755
#, fuzzy, c-format
-msgid "Area %d without boundary detected"
+msgid "Unbale to open raster <%s>"
-#: ../lib/vector/Vlib/open_pg.c:1061
-#, c-format
-msgid "Isle %d without boundary detected"
-msgstr ""
+#: ../lib/imagery/iscatt_core.c:761
+#, fuzzy, c-format
+msgid "Raster <%s> type is not <%s>"
-#: ../lib/vector/Vlib/open_pg.c:1128
-#, fuzzy
-msgid "Unable to get map bounding box from topology"
+#: ../lib/imagery/iscatt_core.c:775
+#, fuzzy, c-format
+msgid "Unable to read range of raster <%s>"
-#: ../lib/vector/Vlib/open_pg.c:1135
+#: ../lib/imagery/iscatt_core.c:803
#, fuzzy, c-format
-msgid ""
-"Unable to parse map bounding box:\n"
-"%s"
+msgid "Unable to open category raster condtition file <%s>"
-#: ../lib/vector/Vlib/open_pg.c:1159
-#, c-format
-msgid "Different number of nodes detected (%d, %d)"
+#: ../lib/imagery/iscatt_core.c:817
+msgid "Corrupted category raster conditions file (fseek failed)"
msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1187 ../lib/vector/Vlib/open_pg.c:1209
+#: ../lib/imagery/iscatt_core.c:972 ../lib/imagery/iclass_statistics.c:227
#, c-format
-msgid "Different number of areas detected (%d, %d)"
+msgid "prepare_signature: scan line %d has odd number of points."
msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1380
-msgid "To be implemented: isles not attached in Topo-Geo-only mode"
+#: ../lib/imagery/iscatt_core.c:981 ../lib/imagery/iclass_statistics.c:237
+msgid "signature: perimeter points out of order."
msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1569
+#: ../lib/imagery/list_subgp.c:72
#, c-format
-msgid "Inconsistency in topology: number of points %d (should be %d)"
+msgid "subgroup <%s> of group <%s> is empty\n"
msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1614
+#: ../lib/imagery/list_subgp.c:85
#, c-format
-msgid "Inconsistency in topology: number of lines %d (should be %d)"
+msgid "subgroup <%s> of group <%s> references the following raster maps\n"
msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1668
+#: ../lib/imagery/list_gp.c:34
#, c-format
-msgid "Inconsistency in topology: number of centroids %d (should be %d)"
+msgid "group <%s> is empty\n"
msgstr ""
-#: ../lib/vector/Vlib/net_analyze.c:288 ../lib/vector/Vlib/net_analyze.c:329
+#: ../lib/imagery/list_gp.c:44
#, c-format
-msgid "Unable to find point with defined unique category for node <%d>."
+msgid "group <%s> references the following raster maps\n"
msgstr ""
-#: ../lib/vector/Vlib/net_analyze.c:292 ../lib/vector/Vlib/net_analyze.c:333
-#, c-format
-msgid ""
-"There exists more than one point on node <%d> with unique category in field "
-"<%d>.\n"
-"The unique category layer may not be valid."
+#: ../lib/imagery/iclass_statistics.c:218
+msgid "prepare_signature: outline has odd number of points."
msgstr ""
-#: ../lib/vector/Vlib/net_analyze.c:449
-msgid "Wrong line direction in Vect_net_get_line_cost()"
-msgstr ""
-#: ../lib/vector/diglib/frmt.c:45 ../lib/vector/diglib/frmt.c:70
-#, fuzzy, c-format
-msgid "Vector format not recognized: %s"
-#: ../lib/vector/diglib/frmt.c:79 ../lib/vector/diglib/frmt.c:88
-#, fuzzy, c-format
-msgid "Vector format '%s' not supported"
-#: ../lib/vector/diglib/frmt.c:97
+#: ../lib/imagery/iclass_statistics.c:248
#, c-format
-msgid "Format definition is not correct: %s"
+msgid "Data error preparing signatures: value (%d) > num of cats (%d)"
msgstr ""
-#: ../lib/vector/diglib/portable.c:208 ../lib/vector/diglib/portable.c:241
-#: ../lib/vector/diglib/portable.c:683 ../lib/vector/diglib/plus_struct.c:563
-msgid "Vector exceeds supported file size limit"
+#: ../lib/imagery/iclass_statistics.c:561
+#: ../lib/imagery/iclass_statistics.c:584
+#: ../lib/imagery/iclass_statistics.c:607
+#: ../lib/imagery/iclass_statistics.c:630
+#: ../lib/imagery/iclass_statistics.c:653
+#: ../lib/imagery/iclass_statistics.c:680
+#: ../lib/imagery/iclass_statistics.c:712
+#: ../lib/imagery/iclass_statistics.c:735
+#: ../lib/imagery/iclass_statistics.c:758
+msgid "Band index out of range"
msgstr ""
-#: ../lib/vector/diglib/plus.c:222
-#, fuzzy
-msgid "Unable read topology for nodes"
-#: ../lib/vector/diglib/plus.c:227
-#, fuzzy, c-format
-msgid "Unable to read topology for node %d"
-#: ../lib/vector/diglib/plus.c:232
-#, fuzzy
-msgid "Unable read topology for lines"
-#: ../lib/vector/diglib/plus.c:237
-#, fuzzy, c-format
-msgid "Unable to read topology for line %d"
-#: ../lib/vector/diglib/plus.c:242
-#, fuzzy
-msgid "Unable to read topo for areas"
-#: ../lib/vector/diglib/plus.c:247
-#, fuzzy, c-format
-msgid "Unable read topology for area %d"
-#: ../lib/vector/diglib/plus.c:252
-#, fuzzy
-msgid "Unable to read topology for isles"
-#: ../lib/vector/diglib/plus.c:257
-#, fuzzy, c-format
-msgid "Unable to read topology for isle %d"
-#: ../lib/vector/diglib/plus.c:279 ../lib/vector/diglib/plus.c:305
-#, fuzzy
-msgid "Unable to write head to plus file"
-msgstr "임시파일을 열 수 없습니다"
-#: ../lib/vector/diglib/plus.c:284
-#, fuzzy
-msgid "Unable to write nodes to plus file"
-msgstr "자동 MASK파일을 열 수 없습니다"
-#: ../lib/vector/diglib/plus.c:289
-#, fuzzy
-msgid "Unable to write lines to plus file"
-#: ../lib/vector/diglib/plus.c:294
-#, fuzzy
-msgid "Unable to write areas to plus file"
-#: ../lib/vector/diglib/plus.c:299
-#, fuzzy
-msgid "Unable to write isles to plus file"
-#: ../lib/vector/diglib/spindex_rw.c:98 ../lib/vector/diglib/spindex_rw.c:106
-#, fuzzy
-msgid "Topology file must be written before spatial index file"
-#: ../lib/vector/diglib/spindex_rw.c:302
-#, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this spatial index format. "
-"Try to rebuild topology or upgrade GRASS to at least version %d."
+#: ../lib/imagery/iclass_statistics.c:684
+msgid "Cell category value out of range"
msgstr ""
-#: ../lib/vector/diglib/spindex_rw.c:308
-#, c-format
-msgid ""
-"Your GRASS version does not fully support spatial index format %d.%d of the "
-"vector. Consider to rebuild topology or upgrade GRASS."
+#: ../lib/imagery/georef_tps.c:219
+msgid "Calculating forward transformation coefficients"
msgstr ""
-#: ../lib/vector/diglib/spindex_rw.c:317
-#, c-format
-msgid ""
-"Spatial index format version %d.%d is not supported by this release. Please "
-"rebuild topology."
+#: ../lib/imagery/georef_tps.c:236
+msgid "Calculating backward transformation coefficients"
msgstr ""
-#: ../lib/vector/diglib/cindex_rw.c:156
+#: ../lib/imagery/georef_tps.c:279 ../lib/imagery/georef_tps.c:282
+#: ../lib/imagery/georef_tps.c:285 ../lib/imagery/georef_tps.c:290
+#: ../lib/imagery/georef_tps.c:293
#, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this category index format. "
+msgid "%s: out of memory"
msgstr ""
-#: ../lib/vector/diglib/plus_area.c:215 ../lib/vector/diglib/plus_area.c:711
+#: ../lib/imagery/iclass_perimeter.c:109
#, c-format
-msgid "Line %d already has area/isle %d to left"
+msgid "Get area %d failed"
msgstr ""
-#: ../lib/vector/diglib/plus_area.c:225 ../lib/vector/diglib/plus_area.c:719
-#, c-format
-msgid "Line %d already has area/isle %d to right"
+#: ../lib/imagery/iclass_perimeter.c:116
+msgid "Perimeter computation failed"
msgstr ""
-#: ../lib/vector/diglib/plus_area.c:279
-msgid "Isle already registered in area"
+#: ../lib/imagery/iclass_perimeter.c:208
+msgid "Absurd polygon."
msgstr ""
-#: ../lib/vector/diglib/plus_area.c:313
-msgid "Attempt to delete isle from dead area"
+#: ../lib/imagery/iclass_perimeter.c:253
+msgid "Outlined area is too large."
msgstr ""
-#: ../lib/vector/diglib/plus_area.c:330
-#, c-format
-msgid "Attempt to delete not registered isle %d from area %d"
-msgstr ""
+#: ../lib/imagery/iclass_signatures.c:120
+#, fuzzy, c-format
+msgid "Unable to open output signature file '%s'"
-#: ../lib/vector/diglib/plus_area.c:369
-msgid "Attempt to delete dead area"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:408
+#: ../lib/cluster/c_exec.c:44
#, c-format
-msgid "Dead centroid %d registered for area (bug in the vector library)"
+msgid "Not enough data points (%d) in cluster"
msgstr ""
-#: ../lib/vector/diglib/plus_area.c:431
-#, fuzzy, c-format
-msgid "Attempt to delete area %d info from dead isle %d"
-#: ../lib/vector/diglib/plus_area.c:777
-#, fuzzy, c-format
-msgid "Attempt to delete isle %d info from dead area %d"
-#: ../lib/vector/diglib/plus_struct.c:523
+#: ../lib/cluster/c_begin.c:57
#, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this topology format. Try "
-"to rebuild topology or upgrade GRASS to at least version %d."
+msgid "produced by i.cluster"
msgstr ""
-#: ../lib/vector/diglib/plus_struct.c:529
+#: ../lib/db/dbmi_driver/d_error.c:35
#, c-format
-msgid ""
-"Your GRASS version does not fully support topology format %d.%d of the "
+msgid "DBMI-%s driver error:"
msgstr ""
-#: ../lib/vector/diglib/plus_struct.c:539
-#, c-format
-msgid ""
-"Old topology format version %d.%d is not supported by this release. Try to "
-"rebuild topology using v.build or v.build.all module."
+#: ../lib/db/dbmi_client/select.c:119 ../lib/db/dbmi_client/select.c:221
+#: ../lib/db/dbmi_client/select.c:288
+msgid "Missing column name"
msgstr ""
-#: ../lib/vector/diglib/file.c:159
-msgid "Writing to file loaded to memory not supported"
+#: ../lib/db/dbmi_client/select.c:216 ../lib/db/dbmi_client/select.c:283
+msgid "Missing key column name"
msgstr ""
-#: ../lib/vector/diglib/file.c:197
+#: ../lib/db/dbmi_client/select.c:333
#, fuzzy
-msgid "Unable to load file to memory, file not open"
+msgid "Key column type is not integer"
-#: ../lib/vector/diglib/file.c:212
-msgid "Vector memory mode not supported, using 'AUTO'"
+#: ../lib/db/dbmi_client/copy_tab.c:91
+#, c-format
+msgid "Array of values to select from column <%s> is empty"
msgstr ""
-#: ../lib/vector/diglib/port_init.c:158
+#: ../lib/db/dbmi_client/copy_tab.c:151
#, fuzzy, c-format
-msgid "Unable to find '%x' in %s"
+msgid "Unable to get list tables in database <%s>"
-#: ../lib/vector/diglib/spindex.c:450
+#: ../lib/db/dbmi_client/copy_tab.c:189
#, fuzzy, c-format
-msgid "Unable to delete node %d from spatial index"
+msgid "Table <%s> already exists in database and will be overwritten"
-#: ../lib/vector/diglib/spindex.c:493
+#: ../lib/db/dbmi_client/copy_tab.c:194
#, fuzzy, c-format
-msgid "Unable to delete line %d from spatial index"
+msgid "Table <%s> already exists in database <%s>"
-#: ../lib/vector/diglib/spindex.c:529
-#, fuzzy
-msgid "Attempt to delete sidx for dead area"
+#: ../lib/db/dbmi_client/copy_tab.c:274
+#, fuzzy, c-format
+msgid "Column <%s> is not integer"
-#: ../lib/vector/diglib/spindex.c:546
+#: ../lib/db/dbmi_client/copy_tab.c:294
#, fuzzy, c-format
-msgid "Unable to delete area %d from spatial index"
+msgid "Unable to create table <%s>"
-#: ../lib/vector/diglib/spindex.c:595
+#: ../lib/db/dbmi_client/copy_tab.c:394
+#, c-format
+msgid "Unknown column type (column <%s>)"
+msgstr ""
+#: ../lib/db/dbmi_client/table.c:46 ../lib/db/dbmi_client/delete_tab.c:40
#, fuzzy, c-format
-msgid "Unable to delete isle %d from spatial index"
+msgid "Unable open database <%s> by driver <%s>"
-#: ../lib/vector/diglib/test.c:58
-#, fuzzy
-msgid "Unable to open test.tmp file"
+#: ../lib/db/dbmi_client/delete_tab.c:53
+#, fuzzy, c-format
+msgid "Unable to drop table: '%s'"
-#: ../lib/vector/diglib/test.c:75
-#, c-format
+#: ../lib/db/dbmi_base/test/test_main.c:83
+msgid "Performs unit and integration tests for the dbmi base library"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_columns.c:37
msgid ""
-"Error in read/write portable double, byte_order = %d Written: %.16e3E Read: "
-"%.16e3E"
+"\n"
+"++ Running column unit tests ++"
msgstr ""
-#: ../lib/vector/diglib/test.c:89
-#, c-format
+#: ../lib/db/dbmi_base/test/test_columns.c:42
msgid ""
-"Error in read/write portable float, byte_order = %d Written: %.8e3E Read: "
-"%.8e3E"
+"\n"
+"-- column unit tests failure --"
msgstr ""
-#: ../lib/vector/diglib/test.c:104
-#, c-format
+#: ../lib/db/dbmi_base/test/test_columns.c:44
msgid ""
-"Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
+"\n"
+"-- column unit tests finished successfully --"
msgstr ""
-#: ../lib/vector/diglib/test.c:119
-#, c-format
+#: ../lib/db/dbmi_base/test/test_columns.c:57
msgid ""
-"Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
+"\n"
+"++ Run test copy column ++"
msgstr ""
-#: ../lib/vector/diglib/test.c:134
-#, c-format
-msgid "Error in read/write portable int, byte_order = %d Written: %d Read: %d"
+#: ../lib/db/dbmi_base/test/test_columns.c:150
+msgid ""
+"\n"
+"++ Test copy column finished ++"
msgstr ""
-#: ../lib/vector/diglib/test.c:150
-#, c-format
+#: ../lib/db/dbmi_base/test/test_table.c:38
msgid ""
-"Error in read/write portable short, byte_order = %d Written: %d Read: %d"
+"\n"
+"++ Running table unit tests ++"
msgstr ""
-#: ../lib/vector/diglib/test.c:165
-#, c-format
-msgid "Error in read/write portable char, byte_order = %d Written: %d Read: %d"
+#: ../lib/db/dbmi_base/test/test_table.c:43
+msgid ""
+"\n"
+"-- Table unit tests failure --"
msgstr ""
-#: ../lib/vector/diglib/plus_node.c:214
-#, c-format
+#: ../lib/db/dbmi_base/test/test_table.c:45
msgid ""
-"Attempt to read line angle for the line which is not connected to the node: "
-"node %d, line %d"
+"\n"
+"-- Table unit tests finished successfully --"
msgstr ""
-#: ../lib/segment/open.c:53
-msgid "Segment file name is NULL"
+#: ../lib/db/dbmi_base/valuefmt.c:52
+msgid "db_convert_Cstring_to_value(): unrecognized sqltype"
msgstr ""
-#: ../lib/segment/open.c:58
-msgid "Segment file exists already"
+#: ../lib/db/dbmi_base/valuefmt.c:91
+msgid "db_convert_value_into_string(): unrecongized sqltype-type"
msgstr ""
-#: ../lib/segment/open.c:66
-#, fuzzy
-msgid "Unable to create segment file"
+#: ../lib/db/dbmi_base/index.c:180
+msgid "db_set_index_column_name(): invalid column number"
+msgstr ""
-#: ../lib/segment/open.c:74
-#, fuzzy
-msgid "Could not write segment file"
-#: ../lib/segment/open.c:78
-msgid "Illegal segment configuration parameter(s)"
+#: ../lib/db/dbmi_base/index.c:197
+msgid "db_get_index_column_name(): invalid column number"
msgstr ""
-#: ../lib/segment/open.c:87
-#, fuzzy
-msgid "Unable to re-open segment file"
+#: ../lib/db/dbmi_base/login.c:115
+#, fuzzy, c-format
+msgid "Unable to read file '%s'"
-#: ../lib/segment/open.c:94
-msgid "Could not read segment file"
+#: ../lib/db/dbmi_base/login.c:126
+#, c-format
+msgid "Login file (%s) corrupted (line: %s)"
msgstr ""
-#: ../lib/segment/format.c:143
-msgid "Segment format: file size too large"
-msgstr ""
+#: ../lib/db/dbmi_base/login.c:164
+#, fuzzy, c-format
+msgid "Unable to write file '%s'"
-#: ../lib/segment/format.c:144
-msgid "Please recompile with Large File Support (LFS)"
-msgstr ""
+#: ../lib/db/dbmi_base/login.c:229
+#, fuzzy, c-format
+msgid "DB connection <%s/%s> already exists and will be overwritten"
-#: ../lib/proj/convert.c:120
-msgid "Unable parse GRASS PROJ_INFO file"
+#: ../lib/db/dbmi_base/login.c:232
+#, fuzzy, c-format
+msgid ""
+"DB connection <%s/%s> already exists. Re-run '%s' with '--%s' flag to "
+"overwrite existing settings."
+#: ../lib/db/dbmi_base/default_name.c:136
+msgid "Programmer error"
msgstr ""
-#: ../lib/proj/convert.c:125
-msgid "Unable get PROJ.4-style parameter string"
+#: ../lib/db/dbmi_base/xdrvalue.c:82
+msgid "send data: invalid C-type"
msgstr ""
-#: ../lib/proj/convert.c:139
-#, c-format
-msgid ""
-"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+#: ../lib/db/dbmi_base/error.c:72
+msgid "<NULL error message>"
msgstr ""
-#: ../lib/proj/convert.c:152
-#, c-format
-msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
+#: ../lib/db/dbmi_base/error.c:91
+msgid "dbmi: Protocol error"
msgstr ""
-#: ../lib/proj/convert.c:394
-msgid "No projection name! Projection parameters likely to be meaningless."
+#: ../lib/db/dbmi_base/error.c:136
+msgid "dbmi: Out of Memory"
msgstr ""
-#: ../lib/proj/convert.c:457
+#: ../lib/db/dbmi_base/error.c:149
#, c-format
-msgid "Datum <%s> not recognised by GRASS and no parameters found"
+msgid "dbmi: %s() not implemented"
msgstr ""
-#: ../lib/proj/convert.c:473
+#: ../lib/db/dbmi_base/error.c:163
#, c-format
-msgid ""
-"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
-"want to look into this."
+msgid "dbmi: Invalid procedure %d"
msgstr ""
-#: ../lib/proj/convert.c:477
+#: ../lib/db/dbmi_base/legal_dbname.c:38
#, c-format
-msgid ""
-"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
-"transform parameters unspecified."
+msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'."
msgstr ""
-#: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
+#: ../lib/db/dbmi_base/legal_dbname.c:45
#, c-format
-msgid "pj_transform() failed: %s"
+msgid "Illegal table map name <%s>. Must start with a letter."
msgstr ""
-#: ../lib/proj/ellipse.c:97
+#: ../lib/db/dbmi_base/legal_dbname.c:54
#, c-format
-msgid "Invalid ellipsoid <%s> in file"
+msgid "Illegal table map name <%s>. Character <%c> not allowed."
msgstr ""
-#: ../lib/proj/ellipse.c:124
-msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
+#: ../lib/db/dbmi_base/xdrtable.c:109
+msgid "fetch: table has wrong number of columns"
msgstr ""
-#: ../lib/proj/ellipse.c:128
-msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
-msgstr ""
+#: ../lib/ogsf/trans.c:180
+msgid "Out of matrix stack space"
+msgstr "행렬 스택공간이 부족합니다"
-#: ../lib/proj/ellipse.c:141
-msgid "No ellipsoid info given in file"
-msgstr ""
+#: ../lib/ogsf/trans.c:200
+msgid "Tried to pop an empty stack"
+msgstr "빈 스택에서 끄집어 내려고 했습니다"
-#: ../lib/proj/get_proj.c:148
-#, c-format
-msgid "Invalid zone %s specified"
-msgstr ""
+#: ../lib/ogsf/gs3.c:132 ../lib/ogsf/gs3.c:196 ../lib/ogsf/gs3.c:348
+#: ../lib/ogsf/gs3.c:454 ../lib/ogsf/gs3.c:540
+#, fuzzy, c-format
+msgid "Loading raster map <%s>..."
+msgstr "라스터맵 <%s>를 읽는 중입니다..."
-#: ../lib/proj/get_proj.c:228
-msgid "Unable to initialise PROJ.4 with the following parameter list:"
-msgstr ""
-#: ../lib/proj/get_proj.c:236
+#: ../lib/ogsf/gs3.c:596
#, c-format
-msgid "The error message: %s"
+msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
msgstr ""
-#: ../lib/proj/get_proj.c:294
-msgid "Option input overflowed option table"
-msgstr ""
-#: ../lib/proj/get_proj.c:325
+#: ../lib/ogsf/gs3.c:658 ../lib/ogsf/gs3.c:730
#, fuzzy, c-format
-msgid "Unable to initialize pj cause: %s"
+msgid "Translating colors from raster map <%s>..."
+msgstr "라스터맵 <%s>로부터 색상을 변환 중입니다..."
-#: ../lib/proj/get_proj.c:401
-msgid "Input Projection Parameters"
+#: ../lib/ogsf/gs3.c:967
+msgid "View not saved by this program,there may be some inconsistancies"
msgstr ""
-#: ../lib/proj/get_proj.c:404
-msgid "Input Unit Factor"
-msgstr ""
+#: ../lib/ogsf/gp3.c:148
+#, c-format
+msgid "No points from vector map <%s> fall within current region"
+msgstr "벡터맵 <%s>의 어떤 점도 현재 영역 안에 있지 않습니다"
-#: ../lib/proj/get_proj.c:414
-msgid "Output Projection Parameters"
-msgstr ""
+#: ../lib/ogsf/gp3.c:153
+#, c-format
+msgid "Vector map <%s> loaded (%d points)"
+msgstr "벡터맵 <%s>를 읽었습니다 (%d 점)"
-#: ../lib/proj/get_proj.c:417
-msgid "Output Unit Factor"
-msgstr ""
+#: ../lib/ogsf/gp3.c:211
+#, fuzzy, c-format
+msgid "Loading thematic points layer <%s>..."
+msgstr "주제 점레이어 <%s>를 읽는 중입니다..."
-#: ../lib/proj/datum.c:195
-msgid "Failed to detect nadgrids path, GRASS_PROJSHARE not defined"
-msgstr ""
-#: ../lib/proj/datum.c:278 ../lib/proj/datum.c:358
+#: ../lib/ogsf/gp3.c:235 ../lib/ogsf/gv3.c:377
#, fuzzy, c-format
-msgid "Unable to open datum table file <%s>"
+msgid "No color rule defined for category %d"
-#: ../lib/proj/datum.c:291 ../lib/proj/datum.c:372
+#: ../lib/ogsf/gp3.c:249 ../lib/ogsf/gv3.c:392
#, fuzzy, c-format
-msgid "Error in datum table file <%s>, line %d"
-msgstr "Datum 테이블파일의 %d번째 줄에 오류가 있습니다"
+msgid "Invalid color definition (%s)"
+msgstr "잘못된 좌표"
-#: ../lib/rst/interp_float/resout2d.c:77
-msgid "Temporarily changing the region to desired resolution..."
-msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:103
+#: ../lib/ogsf/gp3.c:288
#, c-format
-msgid "First change your rows number(%d) to %d"
+msgid ""
+"%d points without category. Unable to determine color rules for features "
+"without category."
msgstr ""
+"%d 점들이 카테고리를 가지고 있지 않습니다. 카테고리 없는 점은 색상규칙을 정"
+"할 수 없습니다."
-#: ../lib/rst/interp_float/resout2d.c:110
-#, c-format
-msgid "First change your columns number(%d) to %d"
-msgstr ""
+#: ../lib/ogsf/gs_bm.c:124
+msgid "Bitmap mismatch"
+msgstr "비트맵이 일치하지 않습니다."
-#: ../lib/rst/interp_float/resout2d.c:264
-msgid "No color table for input raster map -- will not create color table"
-msgstr ""
+#: ../lib/ogsf/gsd_legend.c:246
+#, fuzzy, c-format
+msgid "Unable to read color file of raster map <%s>"
-#: ../lib/rst/interp_float/resout2d.c:458
-msgid "Changing the region back to initial..."
-msgstr ""
+#: ../lib/ogsf/gsd_legend.c:252
+#, fuzzy, c-format
+msgid "Unable to read category file of raster map <%s>"
-#: ../lib/rst/interp_float/vinput2d.c:94
+#: ../lib/ogsf/gsd_legend.c:269
#, fuzzy, c-format
-msgid "Vector map <%s> is not 3D"
+msgid "Unable to read fp range of raster map <%s>"
-#: ../lib/rst/interp_float/vinput2d.c:97
-msgid "Loading data from attribute table ..."
-msgstr ""
+#: ../lib/ogsf/gsd_legend.c:281
+#, fuzzy, c-format
+msgid "Unable to read range of raster map <%s>"
-#: ../lib/rst/interp_float/vinput2d.c:118
-#: ../lib/rst/interp_float/vinput2d.c:131
-#, c-format
-msgid "Data type of column <%s> must be numeric"
+#: ../lib/ogsf/gsd_legend.c:295
+msgid "Range request error for legend"
msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:142
+#: ../lib/ogsf/gsd_legend.c:385
#, fuzzy
-msgid "Reading features from vector map ..."
+msgid "Unable to show discrete FP range (use list)"
+msgstr "자동 MASK파일을 열 수 없습니다"
-#: ../lib/rst/interp_float/vinput2d.c:174
-#, c-format
-msgid "Database record for cat %d not found"
+#: ../lib/ogsf/gsd_legend.c:501
+msgid "Too many categories to show as discrete!"
msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:192
-msgid "Negative value of smoothing detected: sm must be >= 0"
+#: ../lib/ogsf/gsd_legend.c:503
+msgid "Try using smaller font!"
msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:256
-msgid "Strip exists with insufficient data"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:270
+#: ../lib/ogsf/gs2.c:1211
#, c-format
-msgid "There are points outside specified 2D/3D region - %d points ignored"
-msgstr ""
+msgid "no category info"
+msgstr "카테고리 정보가 없습니다."
-#: ../lib/rst/interp_float/vinput2d.c:273
+#: ../lib/ogsf/gs2.c:1230
#, c-format
-msgid "Ignoring %d points (too dense)"
-msgstr ""
+msgid "no data"
+msgstr "자료가 없습니다."
-#: ../lib/rst/interp_float/vinput2d.c:277
+#: ../lib/ogsf/gs2.c:1655
#, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given NPMIN="
-"%d"
-msgstr ""
+msgid "Raster map <%s> is outside of current region. Load failed."
+msgstr "라스터맵 <%s>이 현재 영역 바깥입니다. 읽을 수 없습니다."
-#: ../lib/rst/interp_float/vinput2d.c:282
-msgid "Zero points in the given region"
-msgstr ""
+#: ../lib/ogsf/gs2.c:1733 ../lib/ogsf/gs2.c:1739 ../lib/ogsf/gs2.c:1747
+#: ../lib/ogsf/gs2.c:1756 ../lib/ogsf/gs2.c:1764 ../lib/ogsf/gs2.c:1774
+#: ../lib/ogsf/gs2.c:1822
+msgid "GS_load_att_map(): Out of memory. Unable to load map"
+msgstr "GS_load_att_map(): 메모리가 모자랍니다. 맵을 읽을 수 없습니다."
-#: ../lib/rst/interp_float/vinput2d.c:287
+#: ../lib/ogsf/gs2.c:1850
+msgid "Loading failed"
+msgstr "읽을 수 없습니다."
+#: ../lib/ogsf/gs2.c:1854
+msgid "Error finding range"
+msgstr "범위를 찾지 못했습니다."
+#: ../lib/ogsf/gsd_prim.c:146
#, c-format
-msgid ""
-"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
-"smooth connection of segments, npmin > segmax (see manual)"
-msgstr ""
+msgid "Color Material: %d"
+msgstr "색상재료: %d"
-#: ../lib/rst/interp_float/vinput2d.c:293
+#: ../lib/ogsf/gsd_prim.c:630
#, c-format
msgid ""
-"There are less than %d points for interpolation. No segmentation is "
-"necessary, to run the program faster set segmax=%d (see manual)"
+"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
+"advise GRASS developers of this error"
msgstr ""
+"gsd_rot(): %c는 잘못된 좌표축 지정입니다. 회전을 무시합니다. GRASS 개발자들에"
+"게 조언을 구하세요."
-#: ../lib/rst/interp_float/vinput2d.c:297
-#, fuzzy, c-format
-msgid "Number of points from vector map %d"
+#: ../lib/ogsf/gk.c:320
+msgid "Need at least 3 keyframes for spline"
+msgstr "스플라인을 위해서는 최소 3개의 키프레임이 필요합니다."
-#: ../lib/rst/interp_float/vinput2d.c:298
-#, fuzzy, c-format
-msgid "Number of points outside of 2D/3D region %d"
+#: ../lib/ogsf/gk.c:622
+msgid "Need at least 2 keyframes for interpolation"
+msgstr "보간을 위해서는 최소 2개의 키프레임이 필요합니다."
-#: ../lib/rst/interp_float/vinput2d.c:300
+#: ../lib/ogsf/gvl_file.c:103
+msgid "Maximum number of datafiles exceeded"
+msgstr ""
+#: ../lib/ogsf/gvl_file.c:442
#, fuzzy, c-format
-msgid "Number of points being used %d"
+msgid "Unable to read range of 3D raster map <%s>"
-#: ../lib/rst/interp_float/vinput2d.c:333
-msgid "Some points outside of region (ignored)"
+#: ../lib/ogsf/gsds.c:109
+msgid "Maximum number of datasets exceeded"
msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:339
-#, fuzzy
-msgid "Unable to allocate memory"
+#: ../lib/ogsf/gvl2.c:267
+#, fuzzy, c-format
+msgid "Loading 3d raster map <%s>..."
-#: ../lib/rst/interp_float/vinput2d.c:347
+#: ../lib/ogsf/gsd_label.c:58
+msgid "Max. number of labels reached!"
+msgstr "최대 레이블 개수에 도달했습니다!"
+#: ../lib/ogsf/gsd_img_tif.c:66 ../lib/ogsf/gk2.c:216
+#: ../lib/ogsf/gsd_img_ppm.c:52 ../lib/ogsf/gsd_img_ppm.c:95
#, fuzzy, c-format
-msgid "Unable to insert %f,%f,%f a = %d"
+msgid "Unable to open file <%s> for writing"
-#: ../lib/rst/interp_float/segmen2d.c:135
-msgid ""
-"Taking too long to find points for interpolation - please change the region "
-"to area where your points are. Continuing calculations..."
-msgstr ""
-#: ../lib/rst/interp_float/write2d.c:53 ../lib/rst/interp_float/write2d.c:64
-#: ../lib/rst/interp_float/write2d.c:79 ../lib/rst/interp_float/write2d.c:88
-#: ../lib/rst/interp_float/write2d.c:96 ../lib/rst/interp_float/write2d.c:104
-#, fuzzy
-msgid "Cannot write files"
-#: ../lib/rst/interp_float/input2d.c:58
+#: ../lib/ogsf/gv3.c:269
#, c-format
-msgid "Mask raster map <%s> not found"
-msgstr ""
+msgid "No features from vector map <%s> fall within current region"
+msgstr "벡터맵 <%s>의 어떤 피쳐도 현재 영역 안에 있지 않습니다"
-#: ../lib/rst/interp_float/input2d.c:81
-msgid "Bitmap mask created"
-msgstr ""
-#: ../lib/rst/interp_float/output2d.c:117
+#: ../lib/ogsf/gv3.c:274
#, c-format
-msgid "First change your rows number to nsizr! %d %d"
-msgstr ""
+msgid "Vector map <%s> loaded (%d features)"
+msgstr "백터맵 <%s>를 읽었습니다. (%d 피쳐)"
-#: ../lib/rst/interp_float/output2d.c:124
-#, c-format
-msgid "First change your cols number to nsizc %d %d"
-msgstr ""
+#: ../lib/ogsf/gv3.c:353
+#, fuzzy, c-format
+msgid "Loading thematic vector layer <%s>..."
+msgstr "주제 벡터레이어 <%s>를 읽는 중입니다..."
-#: ../lib/rst/interp_float/interp2d.c:232
+#: ../lib/ogsf/gv3.c:414
#, c-format
msgid ""
-"Overshoot - increase in tension suggested. Overshoot occurs at (%d,%d) cell. "
-"Z-value %f, zmin %f, zmax %f."
+"%d features without category. Unable to determine color rules for features "
msgstr ""
+"%d 피쳐들이 카테고리를 가지고 있지 않습니다. 카테고리 없는 피쳐는 색상규칙을 "
+"정할 수 없습니다."
-#: ../lib/pngdriver/read_png.c:42
-#, fuzzy
-msgid "Unable to read PNG"
-msgstr "%s의 이름을 바꾸지 못 했습니다"
-#: ../lib/pngdriver/read_png.c:60
-#, fuzzy
-msgid "Unable allocate PNG structure"
-msgstr "Datum %s 테이블파일을 열 수 없습니다"
-#: ../lib/pngdriver/read_png.c:64 ../lib/pngdriver/write_png.c:71
-#: ../lib/pngdriver/write_png.c:75
-#, fuzzy
-msgid "Unable to allocate PNG structure"
-#: ../lib/pngdriver/read_png.c:67
-#, fuzzy
-msgid "Unable to read PNG file"
-#: ../lib/pngdriver/read_png.c:81
-msgid "Input PNG file is not 8-bit"
+#: ../lib/ogsf/gp2.c:705
+msgid "Unknown icon marker, using \"sphere\""
msgstr ""
-#: ../lib/pngdriver/read_png.c:85
-#, c-format
-msgid "Input PNG file has incorrect dimensions: expected: %dx%d got: %lux%lu"
+#: ../lib/ogsf/gk2.c:272 ../lib/ogsf/gk2.c:285
+msgid "Check no. of frames requested and keyframes marked"
msgstr ""
-#: ../lib/pngdriver/read_png.c:90
-msgid "Input PNG file is not RGBA"
+#: ../lib/ogsf/gsd_surf.c:1742
+msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
msgstr ""
-#: ../lib/pngdriver/read_png.c:94
-msgid "Input PNG file is not indexed color"
-msgstr ""
-#: ../lib/pngdriver/read_png.c:104
-msgid "Input PNG file has invalid palette"
-msgstr ""
-#: ../lib/pngdriver/write_png.c:39
+#: ../lib/ogsf/gsdrape.c:207
#, fuzzy
-msgid "Unable to write PNG"
-#: ../lib/pngdriver/write_png.c:78
-#, fuzzy
-msgid "Unable to write PNG file"
+msgid "Unable to process vector map - out of memory"
-#: ../lib/pngdriver/write_png.c:82
-#, fuzzy, c-format
-msgid "Unable to open output PNG file <%s>"
-#: ../lib/pngdriver/graph_set.c:101
-#, c-format
-msgid "png: truecolor status %s"
-msgstr ""
-#: ../lib/pngdriver/graph_set.c:149
-#, c-format
-msgid "png: collecting to file '%s'"
-msgstr ""
-#: ../lib/pngdriver/graph_set.c:150
-#, c-format
-msgid "png: image size %dx%d"
-msgstr ""
#, fuzzy
#~ msgid "invalid color name"
#~ msgstr "잘못된 좌표"
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po 2017-02-14 15:09:50 UTC (rev 70563)
+++ grass/trunk/locale/po/grassmods_ko.po 2017-02-14 16:32:52 UTC (rev 70564)
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grassmods_ko\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2016-11-14 14:55+0100\n"
+"POT-Creation-Date: 2016-11-15 09:20+0200\n"
"PO-Revision-Date: 2005-08-09 22:53-0500\n"
"Last-Translator: Huidae Cho <grass4u at gmail.com>\n"
"Language-Team: Korean <grass-translations at lists.osgeo.org>\n"
@@ -15,11418 +15,11835 @@
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
-"Plural-Forms: nplurals=2; plural=0;\n"
+"Plural-Forms: nplurals=1; plural=0;\n"
-#: ../raster3d/r3.out.netcdf/main.c:81
-#, fuzzy, c-format
-msgid "Unable to close 3D raster map while catching error: %s"
-msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.netcdf/main.c:97
-#, fuzzy
-msgid "Name for netCDF output file"
-msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.netcdf/main.c:106
-msgid "The value to be used for null values, default is the netCDF standard"
+#: ../misc/m.nviz.script/main.c:69 ../misc/m.transform/main.c:316
+#: ../misc/m.measure/main.c:46 ../misc/m.cogo/main.c:225
+#: ../misc/m.nviz.image/main.c:50
+#: ../locale/scriptstrings/m.proj_to_translate.c:2
+msgid "miscellaneous"
msgstr ""
-#: ../raster3d/r3.out.netcdf/main.c:111
-#, fuzzy
-msgid "Export projection information as wkt and proj4 parameter"
-msgstr "출력할 격자지도"
+#: ../misc/m.nviz.script/main.c:70 ../misc/m.nviz.image/main.c:52
+#: ../visualization/ximgview/main.c:291
+#: ../locale/scriptstrings/d.redraw_to_translate.c:3
+#: ../locale/scriptstrings/d.frame_to_translate.c:3
+#: ../locale/scriptstrings/wxpyimgview_to_translate.c:3
+#: ../display/d.his/main.c:63 ../display/d.mon/main.c:39
+#: ../display/d.rast/main.c:54 ../display/d.vect/main.c:74
+#: ../display/d.info/main.c:35 ../display/d.erase/main.c:30
+#: ../display/d.rgb/main.c:54
+msgid "graphics"
+msgstr "그래픽스"
-#: ../raster3d/r3.out.netcdf/main.c:116 ../raster3d/r3.to.rast/main.c:128
-#: ../raster3d/r3.out.ascii/main.c:118 ../raster3d/r3.cross.rast/main.c:109
-#: ../raster/r.to.rast3elev/main.c:194
-msgid "Use 3D raster mask (if exists) with input map"
-msgstr ""
+#: ../misc/m.nviz.script/main.c:71 ../misc/m.nviz.image/main.c:53
+#: ../visualization/ximgview/main.c:292
+#: ../locale/scriptstrings/r.pack_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:4
+#: ../locale/scriptstrings/r.blend_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:4
+#: ../locale/scriptstrings/i.spectral_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:4
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:4
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:4
+#: ../locale/scriptstrings/r.import_to_translate.c:2
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:4
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:4
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:2
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
+#: ../locale/scriptstrings/r.rgb_to_translate.c:2
+#: ../locale/scriptstrings/d.correlate_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:4
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:4
+#: ../locale/scriptstrings/r.tileset_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:4
+#: ../locale/scriptstrings/r.plane_to_translate.c:2
+#: ../locale/scriptstrings/r.grow_to_translate.c:2
+#: ../locale/scriptstrings/d.to.rast_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:4
+#: ../locale/scriptstrings/wxpyimgview_to_translate.c:4
+#: ../locale/scriptstrings/r.unpack_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:5
+#: ../locale/scriptstrings/r.mask_to_translate.c:2
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:3
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
+#: ../locale/scriptstrings/r.shade_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:4
+#: ../raster3d/r3.cross.rast/main.c:230 ../raster3d/r3.to.rast/main.c:261
+#: ../raster/r.mode/main.c:54 ../raster/r.thin/main.c:57
+#: ../raster/r.reclass/main.c:50 ../raster/r.in.bin/main.c:257
+#: ../raster/r.out.png/main.c:112 ../raster/r.in.xyz/main.c:158
+#: ../raster/r.univar/r.univar_main.c:104 ../raster/r.surf.area/main.c:76
+#: ../raster/r.in.png/main.c:519 ../raster/r.in.poly/main.c:34
+#: ../raster/r.texture/main.c:101 ../raster/r.external.out/main.c:235
+#: ../raster/r.uslek/main.c:53 ../raster/r.flow/main.c:421
+#: ../raster/r.buffer/main.c:66 ../raster/r.resamp.interp/main.c:76
+#: ../raster/r.clump/main.c:58 ../raster/r.to.vect/main.c:76
+#: ../raster/r.resamp.bspline/main.c:80 ../raster/r.relief/main.c:107
+#: ../raster/r.series.interp/main.c:64 ../raster/r.quantile/main.c:261
+#: ../raster/r.series.accumulate/main.c:80 ../raster/r.topidx/main.c:39
+#: ../raster/r.neighbors/main.c:167 ../raster/r.stats.zonal/main.c:101
+#: ../raster/r.series/main.c:137 ../raster/r.slope.aspect/main.c:151
+#: ../raster/r.report/main.c:67 ../raster/r.his/main.c:67
+#: ../raster/r.category/main.c:52 ../raster/r.composite/main.c:72
+#: ../raster/r.spreadpath/main.c:88 ../raster/r.describe/main.c:54
+#: ../raster/r.surf.contour/main.c:60 ../raster/r.in.mat/main.c:91
+#: ../raster/r.sunhours/main.c:72 ../raster/r.what.color/main.c:88
+#: ../raster/r.resamp.rst/main.c:148 ../raster/r.out.ascii/main.c:59
+#: ../raster/r.distance/main.c:39 ../raster/r.random/main.c:51
+#: ../raster/r.volume/main.c:76 ../raster/r.random.cells/main.c:47
+#: ../raster/r.cross/main.c:69 ../raster/r.li/r.li.cwed/cwed.c:54
+#: ../raster/r.li/r.li.padrange/padrange.c:53
+#: ../raster/r.li/r.li.renyi/renyi.c:47
+#: ../raster/r.li/r.li.dominance/dominance.c:46
+#: ../raster/r.li/r.li.shannon/shannon.c:46
+#: ../raster/r.li/r.li.padcv/padcv.c:53 ../raster/r.li/r.li.mps/mps.c:52
+#: ../raster/r.li/r.li.patchdensity/main.c:51
+#: ../raster/r.li/r.li.shape/main.c:49 ../raster/r.li/r.li.mpa/mpa.c:44
+#: ../raster/r.li/r.li.padsd/padsd.c:53
+#: ../raster/r.li/r.li.simpson/simpson.c:46
+#: ../raster/r.li/r.li.richness/richness.c:43
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:48
+#: ../raster/r.li/r.li.patchnum/main.c:50
+#: ../raster/r.li/r.li.pielou/pielou.c:46 ../raster/r.drain/main.c:109
+#: ../raster/r.tile/main.c:43 ../raster/r.sun/main.c:239
+#: ../raster/r.out.pov/main.c:121 ../raster/r.resamp.filter/main.c:389
+#: ../raster/r.surf.fractal/main.c:38 ../raster/r.spread/main.c:105
+#: ../raster/r.walk/main.c:178 ../raster/r.cost/main.c:140
+#: ../raster/r.lake/main.c:150 ../raster/r.sim/r.sim.sediment/main.c:113
+#: ../raster/r.sim/r.sim.water/main.c:113 ../raster/r.out.mpeg/main.c:102
+#: ../raster/r.support.stats/main.c:38 ../raster/r.grow.distance/main.c:150
+#: ../raster/r.transect/main.c:103 ../raster/r.fill.dir/main.c:86
+#: ../raster/r.stream.extract/main.c:76 ../raster/r.stats.quantile/main.c:516
+#: ../raster/r.resample/main.c:54 ../raster/r.out.gridatb/main.c:67
+#: ../raster/r.horizon/main.c:180 ../raster/r.sunmask/main.c:116
+#: ../raster/r.info/main.c:70 ../raster/r.recode/main.c:48
+#: ../raster/r.null/main.c:60 ../raster/r.param.scale/interface.c:54
+#: ../raster/r.surf.random/main.c:36 ../raster/r.out.ppm3/main.c:57
+#: ../raster/r.surf.idw/main.c:104 ../raster/r.surf.gauss/main.c:38
+#: ../raster/r.contour/main.c:87 ../raster/r.out.mat/main.c:62
+#: ../raster/r.profile/main.c:53 ../raster/r.in.gridatb/main.c:45
+#: ../raster/r.regression.line/main.c:46 ../raster/r.quant/main.c:47
+#: ../raster/r.timestamp/main.c:35 ../raster/r.statistics/main.c:55
+#: ../raster/r.proj/main.c:144 ../raster/r.kappa/main.c:68
+#: ../raster/r.out.bin/main.c:279 ../raster/r.rescale.eq/main.c:52
+#: ../raster/r.ros/main.c:212 ../raster/r.covar/main.c:51
+#: ../raster/r.external/main.c:57 ../raster/r.out.vrml/main.c:47
+#: ../raster/r.what/main.c:98 ../raster/r.out.gdal/main.c:136
+#: ../raster/r.in.gdal/main.c:90 ../raster/r.colors/edit_colors.c:63
+#: ../raster/r.to.rast3/main.c:197 ../raster/r.mfilter/main.c:56
+#: ../raster/r.in.ascii/main.c:69 ../raster/r.mapcalc/main.c:69
+#: ../raster/r.basins.fill/main.c:54 ../raster/r.in.lidar/main.c:108
+#: ../raster/r.to.rast3elev/main.c:361 ../raster/r.circle/main.c:51
+#: ../raster/r.solute.transport/main.c:229 ../raster/r.stats/main.c:106
+#: ../raster/r.compress/main.c:64 ../raster/r.colors.out/raster_main.c:45
+#: ../raster/r.regression.multi/main.c:128 ../raster/r.random.surface/main.c:57
+#: ../raster/r.latlong/main.c:56 ../raster/r.coin/main.c:66
+#: ../raster/r.out.ppm/main.c:54 ../raster/r.support/main.c:54
+#: ../raster/r.region/main.c:51 ../raster/r.carve/main.c:74
+#: ../raster/r.rescale/main.c:48 ../raster/r.gwflow/main.c:208
+#: ../raster/r.topmodel/main.c:51 ../raster/r.out.vtk/main.c:59
+#: ../raster/r.water.outlet/main.c:57 ../raster/r.resamp.stats/main.c:258
+#: ../raster/r.patch/main.c:58 ../raster/r.watershed/front/main.c:73
+#: ../raster/r.usler/main.c:52 ../display/d.colortable/main.c:61
+#: ../display/d.rast.arrow/main.c:99 ../display/d.rast/main.c:55
+#: ../display/d.rast.num/main.c:79 ../display/d.profile/main.c:193
+#: ../display/d.rgb/main.c:55 ../vector/v.what.rast3/main.c:66
+#: ../vector/v.sample/main.c:77 ../vector/v.kriging/main.c:56
+#: ../vector/v.neighbors/main.c:53 ../vector/v.to.rast/main.c:46
+#: ../vector/v.what.rast/main.c:73 ../doc/raster/r.example/main.c:83
+msgid "raster"
+msgstr "격자"
-#: ../raster3d/r3.out.netcdf/main.c:586 ../raster3d/r3.timestamp/main.c:43
-#: ../raster3d/r3.out.v5d/main.c:284 ../raster3d/r3.retile/main.c:96
-#: ../raster3d/r3.stats/main.c:48 ../raster3d/r3.to.rast/main.c:259
-#: ../raster3d/r3.in.bin/main.c:252 ../raster3d/r3.gwflow/main.c:159
-#: ../raster3d/r3.out.ascii/main.c:302 ../raster3d/r3.out.bin/main.c:205
-#: ../raster3d/r3.info/main.c:75 ../raster3d/r3.in.ascii/main.c:354
-#: ../raster3d/r3.support/main.c:49 ../raster3d/r3.null/main.c:186
-#: ../raster3d/r3.in.lidar/main.c:162 ../raster3d/r3.mask/main.c:133
-#: ../raster3d/r3.gradient/main.c:43 ../raster3d/r3.in.v5d/main.c:178
-#: ../raster3d/r3.mkdspf/main.c:79 ../raster3d/r3.cross.rast/main.c:228
-#: ../raster3d/r3.flow/test_main.c:43 ../raster3d/r3.flow/main.c:179
-#: ../raster3d/r3.out.vtk/main.c:376 ../raster3d/r3.neighbors/main.c:208
-#: ../raster/r.to.rast3elev/main.c:363 ../raster/r.colors/edit_colors.c:59
-#: ../raster/r.univar/r3.univar_main.c:98
-#: ../raster/r.colors.out/raster3d_main.c:46
+#: ../misc/m.nviz.script/main.c:72 ../misc/m.nviz.image/main.c:55
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:5
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:4
#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:4
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:4
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:2
#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:4
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:5
#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:5
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:2
#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:4
-#: ../misc/m.nviz.script/main.c:72 ../misc/m.nviz.image/main.c:55
+#: ../raster3d/r3.mkdspf/main.c:79 ../raster3d/r3.gwflow/main.c:159
+#: ../raster3d/r3.gradient/main.c:43 ../raster3d/r3.out.v5d/main.c:284
+#: ../raster3d/r3.in.bin/main.c:252 ../raster3d/r3.out.bin/main.c:205
+#: ../raster3d/r3.neighbors/main.c:208 ../raster3d/r3.out.ascii/main.c:302
+#: ../raster3d/r3.info/main.c:75 ../raster3d/r3.null/main.c:186
+#: ../raster3d/r3.cross.rast/main.c:228 ../raster3d/r3.in.v5d/main.c:178
+#: ../raster3d/r3.stats/main.c:48 ../raster3d/r3.out.netcdf/main.c:586
+#: ../raster3d/r3.flow/test_main.c:43 ../raster3d/r3.flow/main.c:179
+#: ../raster3d/r3.in.ascii/main.c:354 ../raster3d/r3.support/main.c:49
+#: ../raster3d/r3.mask/main.c:133 ../raster3d/r3.to.rast/main.c:259
+#: ../raster3d/r3.timestamp/main.c:43 ../raster3d/r3.retile/main.c:96
+#: ../raster3d/r3.in.lidar/main.c:162 ../raster3d/r3.out.vtk/main.c:376
+#: ../raster/r.univar/r3.univar_main.c:98 ../raster/r.colors/edit_colors.c:59
+#: ../raster/r.to.rast3elev/main.c:363
+#: ../raster/r.colors.out/raster3d_main.c:46
#, fuzzy
msgid "raster3d"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.netcdf/main.c:587 ../raster3d/r3.out.v5d/main.c:285
-#: ../raster3d/r3.out.ascii/main.c:303 ../raster3d/r3.out.bin/main.c:206
-#: ../raster3d/r3.out.vtk/main.c:377 ../raster/r.out.gridatb/main.c:68
-#: ../raster/r.out.png/main.c:113 ../raster/r.out.vtk/main.c:60
-#: ../raster/r.out.pov/main.c:122 ../raster/r.out.ascii/main.c:60
-#: ../raster/r.out.bin/main.c:280 ../raster/r.out.mpeg/main.c:103
-#: ../raster/r.out.ppm/main.c:55 ../raster/r.out.vrml/main.c:48
-#: ../raster/r.colors.out/raster3d_main.c:48
-#: ../raster/r.colors.out/raster_main.c:47 ../raster/r.out.gdal/main.c:137
-#: ../raster/r.out.mat/main.c:63 ../raster/r.external.out/main.c:236
-#: ../raster/r.out.ppm3/main.c:58
-#: ../locale/scriptstrings/r.pack_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:3
-#: ../locale/scriptstrings/d.to.rast_to_translate.c:3
-#: ../locale/scriptstrings/d.out.file_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:3
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:3
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:3
-#: ../locale/scriptstrings/v.pack_to_translate.c:3
-#: ../vector/v.out.lidar/main.c:472 ../vector/v.out.dxf/main.c:57
-#: ../vector/v.out.svg/main.c:78 ../vector/v.out.ogr/main.c:82
-#: ../vector/v.out.pov/main.c:47 ../vector/v.out.ascii/main.c:48
-#: ../vector/v.external.out/main.c:44 ../vector/v.out.postgis/main.c:45
-#: ../vector/v.colors.out/main.c:51 ../vector/v.out.vtk/main.c:48
-msgid "export"
-msgstr "내보내기"
+#: ../misc/m.nviz.script/main.c:73 ../misc/m.nviz.image/main.c:54
+#: ../visualization/ximgview/main.c:293
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:4
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:2
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:2
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:5
+#: ../locale/scriptstrings/v.unpack_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:4
+#: ../locale/scriptstrings/v.db.update_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:4
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:2
+#: ../locale/scriptstrings/v.import_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:4
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:2
+#: ../locale/scriptstrings/d.what.vect_to_translate.c:3
+#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:2
+#: ../locale/scriptstrings/v.build.all_to_translate.c:2
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:2
+#: ../locale/scriptstrings/v.pack_to_translate.c:2
+#: ../locale/scriptstrings/v.db.join_to_translate.c:2
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:2
+#: ../locale/scriptstrings/v.centroids_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:4
+#: ../locale/scriptstrings/v.report_to_translate.c:2
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:5
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:4
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:2
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:2
+#: ../locale/scriptstrings/v.db.droprow_to_translate.c:2
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:2
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:2
+#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:2
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:2
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:4
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:4
+#: ../locale/scriptstrings/d.what.rast_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:4
+#: ../raster/r.random/main.c:53 ../raster/r.contour/main.c:90
+#: ../display/d.vect/main.c:75 ../display/d.extract/main.c:50
+#: ../display/d.legend.vect/main.c:52 ../vector/v.net.spanningtree/main.c:46
+#: ../vector/v.surf.rst/main.c:141 ../vector/v.what.rast3/main.c:64
+#: ../vector/v.category/main.c:75 ../vector/v.extrude/main.c:67
+#: ../vector/v.extract/main.c:77 ../vector/v.lidar.correction/main.c:68
+#: ../vector/v.net.components/main.c:72 ../vector/v.net.distance/main.c:66
+#: ../vector/v.out.pov/main.c:46 ../vector/v.surf.idw/main.c:87
+#: ../vector/v.timestamp/main.c:35 ../vector/v.segment/main.c:60
+#: ../vector/v.out.vtk/main.c:47 ../vector/v.net.flow/main.c:58
+#: ../vector/v.split/main.c:54 ../vector/v.edit/main.c:54
+#: ../vector/v.random/main.c:97 ../vector/v.profile/main.c:98
+#: ../vector/v.voronoi/main.c:123 ../vector/v.lrs/v.lrs.segment/main.c:71
+#: ../vector/v.lrs/v.lrs.label/main.c:102
+#: ../vector/v.lrs/v.lrs.create/main.c:121
+#: ../vector/v.lrs/v.lrs.where/main.c:57 ../vector/v.in.region/main.c:41
+#: ../vector/v.kernel/main.c:109 ../vector/v.to.rast3/main.c:48
+#: ../vector/v.out.ogr/main.c:81 ../vector/v.type/main.c:38
+#: ../vector/v.net.timetable/main.c:260 ../vector/v.label.sa/main.c:38
+#: ../vector/v.in.db/main.c:52 ../vector/v.in.dxf/main.c:64
+#: ../vector/v.sample/main.c:75 ../vector/v.build.polylines/main.c:111
+#: ../vector/v.class/main.c:45 ../vector/v.net.alloc/main.c:57
+#: ../vector/v.external/main.c:50 ../vector/v.in.ascii/main.c:70
+#: ../vector/v.to.3d/main.c:36 ../vector/v.univar/main.c:92
+#: ../vector/v.out.postgis/main.c:44 ../vector/v.qcount/main.c:60
+#: ../vector/v.out.lidar/main.c:471 ../vector/v.mkgrid/main.c:70
+#: ../vector/v.out.ascii/main.c:47 ../vector/v.lidar.growing/main.c:75
+#: ../vector/v.overlay/main.c:63 ../vector/v.in.ogr/main.c:135
+#: ../vector/v.net.allpairs/main.c:61 ../vector/v.decimate/main.c:123
+#: ../vector/v.parallel/main.c:49 ../vector/v.rectify/main.c:70
+#: ../vector/v.to.db/main.c:36 ../vector/v.build/main.c:36
+#: ../vector/v.kcv/main.c:55 ../vector/v.net.connectivity/main.c:52
+#: ../vector/v.vol.rst/main.c:235 ../vector/v.select/main.c:48
+#: ../vector/v.db.select/main.c:54 ../vector/v.to.points/main.c:53
+#: ../vector/v.clean/test/topocheck.c:42 ../vector/v.clean/main.c:51
+#: ../vector/v.lidar.edgedetection/main.c:72 ../vector/v.surf.bspline/main.c:91
+#: ../vector/v.external.out/main.c:43 ../vector/v.outlier/main.c:69
+#: ../vector/v.net.bridge/main.c:47 ../vector/v.net.path/main.c:42
+#: ../vector/v.drape/main.c:56 ../vector/v.perturb/main.c:62
+#: ../vector/v.info/main.c:37 ../vector/v.info/print.c:436
+#: ../vector/v.patch/main.c:69 ../vector/v.proj/main.c:67
+#: ../vector/v.net.steiner/main.c:346 ../vector/v.in.dwg/main.c:82
+#: ../vector/v.cluster/main.c:90 ../vector/v.delaunay/main.c:85
+#: ../vector/v.reclass/main.c:67 ../vector/v.neighbors/main.c:50
+#: ../vector/v.in.lidar/main.c:136 ../vector/v.net.centrality/main.c:96
+#: ../vector/v.out.svg/main.c:77 ../vector/v.net.visibility/main.c:45
+#: ../vector/v.generalize/main.c:76 ../vector/v.net.iso/main.c:72
+#: ../vector/v.support/main.c:39 ../vector/v.net/main.c:47
+#: ../vector/v.out.dxf/main.c:56 ../vector/v.to.rast/main.c:44
+#: ../vector/v.what.rast/main.c:71 ../vector/v.net.salesman/main.c:127
+#: ../vector/v.vect.stats/main.c:124 ../vector/v.transform/main.c:69
+#: ../vector/v.normal/main.c:72 ../vector/v.distance/main.c:90
+#: ../vector/v.hull/main.c:52 ../vector/v.db.connect/main.c:52
+#: ../vector/v.label/main.c:59 ../vector/v.colors/main.c:55
+#: ../vector/v.colors.out/main.c:49 ../vector/v.what/main.c:60
+#: ../vector/v.buffer/main.c:221 ../doc/vector/v.example/main.c:50
+msgid "vector"
+msgstr "벡터"
-#: ../raster3d/r3.out.netcdf/main.c:588
-msgid "netCDF"
+#: ../misc/m.nviz.script/main.c:74 ../misc/m.nviz.image/main.c:51
+#: ../visualization/ximgview/main.c:294
+#: ../locale/scriptstrings/d.shade_to_translate.c:6
+#: ../locale/scriptstrings/r.shade_to_translate.c:6
+msgid "visualization"
+msgstr "시각화"
+#: ../misc/m.nviz.script/main.c:75
+msgid "Creates fly-through script to run in NVIZ."
msgstr ""
-#: ../raster3d/r3.out.netcdf/main.c:589 ../raster3d/r3.timestamp/main.c:47
-#: ../raster3d/r3.out.v5d/main.c:286 ../raster3d/r3.retile/main.c:98
-#: ../raster3d/r3.stats/main.c:50 ../raster3d/r3.to.rast/main.c:262
-#: ../raster3d/r3.in.bin/main.c:254 ../raster3d/r3.gwflow/main.c:161
-#: ../raster3d/r3.out.ascii/main.c:304 ../raster3d/r3.out.bin/main.c:207
-#: ../raster3d/r3.info/main.c:77 ../raster3d/r3.in.ascii/main.c:356
-#: ../raster3d/r3.support/main.c:51 ../raster3d/r3.null/main.c:188
-#: ../raster3d/r3.mask/main.c:135 ../raster3d/r3.gradient/main.c:45
-#: ../raster3d/r3.in.v5d/main.c:180 ../raster3d/r3.mkdspf/main.c:81
-#: ../raster3d/r3.cross.rast/main.c:231 ../raster3d/r3.flow/main.c:181
-#: ../raster3d/r3.out.vtk/main.c:378 ../raster3d/r3.neighbors/main.c:210
-#: ../raster/r.to.rast3/main.c:199 ../raster/r.to.rast3elev/main.c:364
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:5
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:5
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:4
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:5
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:6
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:5
-#: ../vector/v.to.rast3/main.c:50 ../vector/v.vol.rst/main.c:236
-msgid "voxel"
+#: ../misc/m.nviz.script/main.c:80
+msgid "Name of output script"
msgstr ""
-#: ../raster3d/r3.out.netcdf/main.c:590
-#, fuzzy
-msgid "Export a 3D raster map as netCDF file."
-msgstr "출력할 격자지도"
+#: ../misc/m.nviz.script/main.c:86
+msgid "Prefix of output images (default = NVIZ)"
+msgstr ""
-#: ../raster3d/r3.out.netcdf/main.c:600 ../raster3d/r3.timestamp/main.c:73
-#: ../raster3d/r3.out.v5d/main.c:307 ../raster3d/r3.retile/main.c:113
-#: ../raster3d/r3.stats/main.c:96 ../raster3d/r3.to.rast/main.c:275
-#: ../raster3d/r3.out.ascii/main.c:326 ../raster3d/r3.out.bin/main.c:299
-#: ../raster3d/r3.support/main.c:135 ../raster3d/r3.null/main.c:103
-#: ../raster3d/r3.mask/main.c:58 ../raster3d/r3.cross.rast/main.c:245
-#: ../raster3d/r3.flow/main.c:87 ../raster3d/r3.out.vtk/main.c:142
-#: ../raster3d/r3.neighbors/main.c:229 ../raster/r.colors/edit_colors.c:400
-#: ../raster/r.univar/r3.univar_main.c:144
-#: ../raster/r.univar/r3.univar_main.c:182 ../general/g.region/main.c:451
-#: ../vector/v.colors/main.c:319
-#, c-format
-msgid "3D raster map <%s> not found"
+#: ../misc/m.nviz.script/main.c:94
+msgid "Route coordinates (east,north)"
msgstr ""
-#: ../raster3d/r3.out.netcdf/main.c:617 ../raster3d/r3.out.v5d/main.c:312
-#: ../raster3d/r3.retile/main.c:127 ../raster3d/r3.stats/main.c:103
-#: ../raster3d/r3.to.rast/main.c:298 ../raster3d/r3.to.rast/main.c:322
-#: ../raster3d/r3.out.ascii/main.c:339 ../raster3d/r3.out.bin/main.c:314
-#: ../raster3d/r3.info/main.c:110 ../raster3d/r3.null/main.c:110
-#: ../raster3d/r3.mask/main.c:64 ../raster3d/r3.gradient/main.c:113
-#: ../raster3d/r3.gradient/main.c:122 ../raster3d/r3.mkdspf/main.c:168
-#: ../raster3d/r3.cross.rast/main.c:279 ../raster3d/r3.flow/test_main.c:82
-#: ../raster3d/r3.flow/main.c:118 ../raster3d/r3.flow/main.c:132
-#: ../raster3d/r3.flow/main.c:373 ../raster3d/r3.flow/main.c:385
-#: ../raster3d/r3.out.vtk/main.c:207 ../raster3d/r3.out.vtk/main.c:292
-#: ../raster3d/r3.out.vtk/main.c:513 ../raster3d/r3.neighbors/main.c:266
-#: ../raster3d/r3.neighbors/main.c:275 ../raster/r.univar/r3.univar_main.c:151
-#: ../raster/r.univar/r3.univar_main.c:189
-#, fuzzy, c-format
-msgid "Unable to open 3D raster map <%s>"
-msgstr "출력할 격자지도"
+#: ../misc/m.nviz.script/main.c:100
+msgid "Camera layback distance (in map units)"
+msgstr ""
-#: ../raster3d/r3.out.netcdf/main.c:649 ../raster3d/r3.out.v5d/main.c:55
-#: ../raster3d/r3.out.v5d/main.c:326 ../raster3d/r3.to.rast/main.c:75
-#: ../raster3d/r3.to.rast/main.c:445 ../raster3d/r3.in.bin/main.c:471
-#: ../raster3d/r3.gwflow/main.c:412 ../raster3d/r3.out.ascii/main.c:63
-#: ../raster3d/r3.out.ascii/main.c:367 ../raster3d/r3.in.ascii/main.c:393
-#: ../raster3d/r3.in.v5d/main.c:206 ../raster3d/r3.cross.rast/main.c:55
-#: ../raster3d/r3.out.vtk/main.c:252 ../raster3d/r3.out.vtk/main.c:338
-#, fuzzy
-msgid "Unable to close 3D raster map"
-msgstr "출력할 격자지도"
+#: ../misc/m.nviz.script/main.c:106
+msgid "Camera height above terrain"
+msgstr ""
-#: ../raster3d/r3.timestamp/main.c:44 ../raster3d/r3.info/main.c:76
-#: ../raster3d/r3.support/main.c:50 ../raster/r.support/main.c:55
-#: ../raster/r.region/main.c:52 ../raster/r.timestamp/main.c:36
-#: ../raster/r.info/main.c:71 ../raster/r.describe/main.c:55
-#: ../locale/scriptstrings/t.support_to_translate.c:3
-#: ../locale/scriptstrings/t.info_to_translate.c:3
-#: ../locale/scriptstrings/t.select_to_translate.c:3
-#: ../temporal/t.connect/main.c:36 ../vector/v.info/main.c:38
-#: ../vector/v.timestamp/main.c:36 ../vector/v.support/main.c:40
-msgid "metadata"
-msgstr "메타자료"
+#: ../misc/m.nviz.script/main.c:112
+msgid "Number of frames"
+msgstr ""
-#: ../raster3d/r3.timestamp/main.c:45 ../raster/r.timestamp/main.c:37
-#: ../vector/v.timestamp/main.c:37
-msgid "timestamp"
+#: ../misc/m.nviz.script/main.c:118
+msgid "Start frame number (default=0)"
msgstr ""
-#: ../raster3d/r3.timestamp/main.c:46 ../raster/r.timestamp/main.c:38
-#: ../locale/scriptstrings/t.support_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:5
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:5
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:5
-#: ../locale/scriptstrings/t.info_to_translate.c:5
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:5
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:6
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:5
-#: ../locale/scriptstrings/t.shift_to_translate.c:5
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:6
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:6
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:5
-#: ../locale/scriptstrings/t.list_to_translate.c:5
-#: ../locale/scriptstrings/t.register_to_translate.c:5
-#: ../locale/scriptstrings/t.rename_to_translate.c:5
-#: ../locale/scriptstrings/t.snap_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:5
-#: ../locale/scriptstrings/t.unregister_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:6
-#: ../locale/scriptstrings/t.remove_to_translate.c:5
-#: ../locale/scriptstrings/t.topology_to_translate.c:4
-#: ../locale/scriptstrings/t.merge_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:5
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:8
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:7
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:7
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:6
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:7
-#: ../locale/scriptstrings/t.select_to_translate.c:4
-#: ../locale/scriptstrings/t.create_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:5
-#: ../locale/scriptstrings/t.sample_to_translate.c:4
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:5
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:5
-#: ../vector/v.timestamp/main.c:38
-msgid "time"
+#: ../misc/m.nviz.script/main.c:123
+msgid "Full render -- Save images"
msgstr ""
-#: ../raster3d/r3.timestamp/main.c:48
-#, fuzzy
-msgid "Modifies a timestamp for a 3D raster map."
-msgstr "출력할 격자지도"
+#: ../misc/m.nviz.script/main.c:127
+msgid "Fly at constant elevation (ht)"
+msgstr ""
-#: ../raster3d/r3.timestamp/main.c:49
-#, fuzzy
-msgid "Print/add/remove a timestamp for a 3D raster map."
-msgstr "출력할 격자지도"
+#: ../misc/m.nviz.script/main.c:132
+msgid "Include command in the script to output a KeyFrame file"
+msgstr ""
-#: ../raster3d/r3.timestamp/main.c:58
-msgid "Datetime, datetime1/datetime2, or none"
+#: ../misc/m.nviz.script/main.c:136
+msgid "Render images off-screen"
msgstr ""
-#: ../raster3d/r3.timestamp/main.c:91
-msgid "Timestamp format is invalid"
+#: ../misc/m.nviz.script/main.c:140
+msgid "Enable vector and sites drawing"
msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:73
-msgid "3D raster map to be converted to Vis5D (V5D) file"
+#: ../misc/m.nviz.script/main.c:148
+msgid "Either -i flag and/or route parameter must be used"
msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:77
-#, fuzzy
-msgid "Name for V5D output file"
+#: ../misc/m.nviz.script/main.c:172
+msgid "Off-screen only available with full render mode"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:202 ../misc/m.transform/main.c:276
+#: ../general/g.pnmcomp/main.c:242 ../general/g.pnmcomp/main.c:259
+#: ../raster/r.category/main.c:173 ../raster/r.out.ascii/main.c:157
+#: ../raster/r.horizon/main.c:385 ../raster/r.recode/main.c:90
+#: ../raster/r.out.ppm3/main.c:133 ../raster/r.profile/main.c:175
+#: ../raster/r.in.lidar/main.c:644 ../display/d.mon/stop.c:66
+#: ../vector/v.out.vtk/main.c:173 ../vector/v.edit/main.c:79
+#: ../vector/v.profile/main.c:254 ../vector/v.out.ascii/main.c:125
+#: ../vector/v.net/main.c:100
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:348
+#, fuzzy, c-format
+msgid "Unable to open file <%s>"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.v5d/main.c:147
+#: ../misc/m.nviz.script/main.c:250
#, c-format
-msgid "Vis5D allows %d columns, %d columns found"
+msgid "You must provide at least four points %d"
msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:150
+#: ../misc/m.nviz.script/main.c:324
#, c-format
-msgid "Vis5D allows %d rows, %d rows found"
+msgid "Created NVIZ script <%s>."
msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:257
+#: ../misc/m.nviz.script/main.c:439
+msgid ""
+"Skipping this point, selected point is outside region. Perhaps the camera "
+"setback distance puts it beyond the edge?"
+msgstr ""
+#: ../misc/m.transform/main.c:92
+#, c-format
+msgid "Not enough points, %d are required"
+msgstr ""
+#: ../misc/m.transform/main.c:96
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:93
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:136
#, fuzzy, c-format
-msgid "Unable to create V5D file <%s>"
+msgid "Error conducting transform (%d)"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.v5d/main.c:262
-#, fuzzy
-msgid "Failed writing V5D file"
-msgstr "출력할 격자지도"
+#: ../misc/m.transform/main.c:194
+msgid "Poorly placed control points"
+msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:288
-msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
+#: ../misc/m.transform/main.c:196
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:255
+msgid "Insufficient memory"
msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:295
-msgid "Use map coordinates instead of xyz coordinates"
+#: ../misc/m.transform/main.c:198
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:257
+msgid "Parameter error"
msgstr ""
-#: ../raster3d/r3.retile/main.c:49
-#, fuzzy
-msgid "Unable to close the 3D raster map"
-msgstr "출력할 격자지도"
+#: ../misc/m.transform/main.c:200
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:259
+msgid "No active control points"
+msgstr ""
-#: ../raster3d/r3.retile/main.c:71
-#, fuzzy
-msgid "Name of the retiled 3D raster map"
+#: ../misc/m.transform/main.c:295
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:367
+#, fuzzy, c-format
+msgid "Invalid coordinates: [%s]"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.retile/main.c:97 ../raster/r.tile/main.c:44
-#: ../locale/scriptstrings/r.tileset_to_translate.c:3
+#: ../misc/m.transform/main.c:317
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:3
+#: ../locale/scriptstrings/m.proj_to_translate.c:4 ../raster/r.proj/main.c:146
+#: ../vector/v.proj/main.c:69 ../vector/v.transform/main.c:70
+#: ../imagery/i.pca/main.c:73
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:390
+#: ../imagery/i.ifft/main.c:78 ../imagery/i.fft/main.c:79
#, fuzzy
-msgid "tiling"
+msgid "transformation"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.retile/main.c:99
-msgid ""
-"Retiles an existing 3D raster map with user defined x, y and z tile size."
+#: ../misc/m.transform/main.c:320
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:393
+msgid "Computes a coordinate transformation based on the control points."
msgstr ""
-#: ../raster3d/r3.retile/main.c:135
-msgid "Rast3d_get_standard3d_params: tile dimension value invalid"
+#: ../misc/m.transform/main.c:329
+msgid "Rectification polynomial order"
msgstr ""
-#: ../raster3d/r3.retile/main.c:148
+#: ../misc/m.transform/main.c:340
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:406
#, fuzzy
-msgid "Error closing 3D raster map"
+msgid "point index"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.stats/main.c:49 ../raster3d/r3.in.lidar/main.c:165
-#: ../raster3d/r3.neighbors/main.c:211 ../imagery/i.cca/main.c:85
-#: ../raster/r.mfilter/main.c:58 ../raster/r.report/main.c:68
-#: ../raster/r.in.lidar/main.c:111 ../raster/r.support.stats/main.c:39
-#: ../raster/r.stats.quantile/main.c:517 ../raster/r.stats/main.c:107
-#: ../raster/r.kappa/main.c:69 ../raster/r.quantile/main.c:263
-#: ../raster/r.in.xyz/main.c:160 ../raster/r.covar/main.c:52
-#: ../raster/r.surf.area/main.c:78 ../raster/r.stats.zonal/main.c:102
-#: ../raster/r.clump/main.c:59 ../raster/r.univar/r.univar_main.c:105
-#: ../raster/r.univar/r3.univar_main.c:99 ../raster/r.cross/main.c:70
-#: ../raster/r.coin/main.c:67 ../raster/r.statistics/main.c:56
-#: ../raster/r.texture/main.c:103 ../raster/r.regression.multi/main.c:129
-#: ../raster/r.regression.line/main.c:47 ../raster/r.quant/main.c:48
-#: ../raster/r.neighbors/main.c:169 ../raster/r.mode/main.c:55
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:3
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:6
-#: ../locale/scriptstrings/db.univar_to_translate.c:3
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:3
-#: ../locale/scriptstrings/d.correlate_to_translate.c:3
-#: ../locale/scriptstrings/v.report_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:3
-#: ../locale/scriptstrings/i.oif_to_translate.c:4
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:3
-#: ../display/d.histogram/main.c:85 ../vector/v.class/main.c:48
-#: ../vector/v.normal/main.c:73 ../vector/v.perturb/main.c:64
-#: ../vector/v.neighbors/main.c:52 ../vector/v.random/main.c:99
-#: ../vector/v.kcv/main.c:56 ../vector/v.qcount/main.c:61
-#: ../vector/v.univar/main.c:93 ../vector/v.outlier/main.c:70
-msgid "statistics"
-msgstr "통계"
-#: ../raster3d/r3.stats/main.c:51
+#: ../misc/m.transform/main.c:341
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:407
#, fuzzy
-msgid "Generates volume statistics for 3D raster maps."
+msgid "source coordinates"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.stats/main.c:62
+#: ../misc/m.transform/main.c:342
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:408
#, fuzzy
-msgid "Number of subranges to collect stats from"
+msgid "destination coordinates"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.stats/main.c:67
-msgid "Calculate statistics based on equal value groups"
+#: ../misc/m.transform/main.c:343
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:409
+msgid "forward coordinates (destination)"
msgstr ""
-#: ../raster3d/r3.stats/main.c:71
+#: ../misc/m.transform/main.c:344
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:410
#, fuzzy
-msgid "Only print cell counts"
+msgid "reverse coordinates (source)"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.stats/main.c:91
-msgid "The number of subranges has to be equal or greater than 1"
+#: ../misc/m.transform/main.c:345
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:411
+msgid "forward coordinates difference (destination)"
msgstr ""
-#: ../raster3d/r3.stats/main.c:150
-msgid "Sort non-null values"
+#: ../misc/m.transform/main.c:346
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:412
+msgid "reverse coordinates difference (source)"
msgstr ""
-#: ../raster3d/r3.to.rast/main.c:100
-msgid "3D raster map(s) to be converted to 2D raster slices"
+#: ../misc/m.transform/main.c:347
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:413
+#, fuzzy
+msgid "forward error (destination)"
+msgstr "출력할 격자지도"
+#: ../misc/m.transform/main.c:348
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:414
+msgid "reverse error (source)"
msgstr ""
-#: ../raster3d/r3.to.rast/main.c:106
-msgid "Basename for resultant raster slice maps"
+#: ../misc/m.transform/main.c:351 ../vector/v.out.ascii/args.c:55
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:417
+msgid "Output format"
msgstr ""
-#: ../raster3d/r3.to.rast/main.c:116
-#, fuzzy
-msgid "Value to multiply the raster values with"
-msgstr "출력할 격자지도"
-#: ../raster3d/r3.to.rast/main.c:117
-msgid "Coefficient a in the equation y = ax + b"
+#: ../misc/m.transform/main.c:355
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:421
+msgid "Display summary information"
msgstr ""
-#: ../raster3d/r3.to.rast/main.c:123
+#: ../misc/m.transform/main.c:360
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:427
#, fuzzy
-msgid "Value to add to the raster values"
+msgid "File containing coordinates to transform (\"-\" to read from stdin)"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.to.rast/main.c:124
-msgid "Coefficient b in the equation y = ax + b"
+#: ../misc/m.transform/main.c:361
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:428
+msgid "Local x,y coordinates to target east,north"
msgstr ""
-#: ../raster3d/r3.to.rast/main.c:133
-msgid ""
-"Use the same resolution as the input 3D raster map for the 2D output maps, "
-"independent of the current region settings"
+#: ../misc/m.transform/main.c:365
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:432
+msgid "Reverse transform of coords file or coeff. dump"
msgstr ""
-#: ../raster3d/r3.to.rast/main.c:174
-#, fuzzy, c-format
-msgid "Unknown raster type <%d>"
-msgstr "출력할 격자지도"
+#: ../misc/m.transform/main.c:366
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:433
+msgid "Target east,north coordinates to local x,y"
+msgstr ""
-#: ../raster3d/r3.to.rast/main.c:260 ../raster3d/r3.out.ascii/main.c:305
-#: ../raster3d/r3.in.ascii/main.c:357 ../raster3d/r3.in.lidar/main.c:166
-#: ../raster/r.to.rast3/main.c:198 ../raster/r.in.lidar/main.c:112
-#: ../raster/r.to.rast3elev/main.c:362 ../raster/r.to.vect/main.c:77
-#: ../raster/r.in.xyz/main.c:161 ../raster/r.in.ascii/main.c:71
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:3
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:3
-#: ../vector/v.to.rast3/main.c:49 ../vector/v.to.rast/main.c:45
-msgid "conversion"
-msgstr "변환"
+#: ../misc/m.transform/main.c:370
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:437
+msgid "Display transform matrix coefficients"
+msgstr ""
-#: ../raster3d/r3.to.rast/main.c:261 ../raster3d/r3.cross.rast/main.c:230
-#: ../visualization/ximgview/main.c:292 ../doc/raster/r.example/main.c:83
-#: ../raster/r.sim/r.sim.sediment/main.c:113
-#: ../raster/r.sim/r.sim.water/main.c:113 ../raster/r.buffer/main.c:66
-#: ../raster/r.support/main.c:54 ../raster/r.random.cells/main.c:47
-#: ../raster/r.what/main.c:98 ../raster/r.random.surface/main.c:57
-#: ../raster/r.out.gridatb/main.c:67 ../raster/r.surf.random/main.c:36
-#: ../raster/r.tile/main.c:43 ../raster/r.topidx/main.c:39
-#: ../raster/r.rescale/main.c:48 ../raster/r.thin/main.c:57
-#: ../raster/r.sun/main.c:239 ../raster/r.to.rast3/main.c:197
-#: ../raster/r.out.png/main.c:112 ../raster/r.region/main.c:51
-#: ../raster/r.mfilter/main.c:56 ../raster/r.transect/main.c:103
-#: ../raster/r.slope.aspect/main.c:151 ../raster/r.timestamp/main.c:35
-#: ../raster/r.resamp.bspline/main.c:80 ../raster/r.spread/main.c:105
-#: ../raster/r.report/main.c:67 ../raster/r.in.lidar/main.c:108
-#: ../raster/r.usler/main.c:52 ../raster/r.relief/main.c:107
-#: ../raster/r.support.stats/main.c:38 ../raster/r.grow.distance/main.c:150
-#: ../raster/r.stats.quantile/main.c:516 ../raster/r.profile/main.c:53
-#: ../raster/r.horizon/main.c:180 ../raster/r.resample/main.c:54
-#: ../raster/r.uslek/main.c:53 ../raster/r.li/r.li.padcv/padcv.c:53
-#: ../raster/r.li/r.li.mps/mps.c:52 ../raster/r.li/r.li.simpson/simpson.c:46
-#: ../raster/r.li/r.li.shannon/shannon.c:46
-#: ../raster/r.li/r.li.padrange/padrange.c:53
-#: ../raster/r.li/r.li.dominance/dominance.c:46
-#: ../raster/r.li/r.li.cwed/cwed.c:54 ../raster/r.li/r.li.pielou/pielou.c:46
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:48
-#: ../raster/r.li/r.li.patchnum/main.c:50
-#: ../raster/r.li/r.li.patchdensity/main.c:51
-#: ../raster/r.li/r.li.shape/main.c:49 ../raster/r.li/r.li.padsd/padsd.c:53
-#: ../raster/r.li/r.li.mpa/mpa.c:44 ../raster/r.li/r.li.richness/richness.c:43
-#: ../raster/r.li/r.li.renyi/renyi.c:47 ../raster/r.in.mat/main.c:91
-#: ../raster/r.surf.fractal/main.c:38 ../raster/r.circle/main.c:51
-#: ../raster/r.out.vtk/main.c:59 ../raster/r.gwflow/main.c:208
-#: ../raster/r.in.png/main.c:519 ../raster/r.rescale.eq/main.c:52
-#: ../raster/r.stats/main.c:106 ../raster/r.to.rast3elev/main.c:361
-#: ../raster/r.series.accumulate/main.c:80 ../raster/r.proj/main.c:144
-#: ../raster/r.kappa/main.c:68 ../raster/r.out.pov/main.c:121
-#: ../raster/r.cost/main.c:140 ../raster/r.stream.extract/main.c:76
-#: ../raster/r.drain/main.c:109 ../raster/r.to.vect/main.c:76
-#: ../raster/r.quantile/main.c:261 ../raster/r.his/main.c:67
-#: ../raster/r.out.ascii/main.c:59 ../raster/r.latlong/main.c:56
-#: ../raster/r.colors/edit_colors.c:63 ../raster/r.in.xyz/main.c:158
-#: ../raster/r.random/main.c:51 ../raster/r.carve/main.c:74
-#: ../raster/r.in.bin/main.c:257 ../raster/r.external/main.c:57
-#: ../raster/r.contour/main.c:87 ../raster/r.out.bin/main.c:279
-#: ../raster/r.covar/main.c:51 ../raster/r.topmodel/main.c:51
-#: ../raster/r.param.scale/interface.c:54 ../raster/r.resamp.rst/main.c:148
-#: ../raster/r.resamp.filter/main.c:389 ../raster/r.basins.fill/main.c:54
-#: ../raster/r.reclass/main.c:50 ../raster/r.out.mpeg/main.c:102
-#: ../raster/r.fill.dir/main.c:86 ../raster/r.resamp.stats/main.c:258
-#: ../raster/r.info/main.c:70 ../raster/r.compress/main.c:64
-#: ../raster/r.solute.transport/main.c:229 ../raster/r.what.color/main.c:88
-#: ../raster/r.sunhours/main.c:72 ../raster/r.in.poly/main.c:34
-#: ../raster/r.out.ppm/main.c:54 ../raster/r.resamp.interp/main.c:76
-#: ../raster/r.out.vrml/main.c:47 ../raster/r.surf.area/main.c:76
-#: ../raster/r.in.gridatb/main.c:45 ../raster/r.series/main.c:137
-#: ../raster/r.stats.zonal/main.c:101 ../raster/r.clump/main.c:58
-#: ../raster/r.composite/main.c:72 ../raster/r.univar/r.univar_main.c:104
-#: ../raster/r.cross/main.c:69 ../raster/r.coin/main.c:66
-#: ../raster/r.statistics/main.c:55 ../raster/r.series.interp/main.c:64
-#: ../raster/r.texture/main.c:101 ../raster/r.colors.out/raster_main.c:45
-#: ../raster/r.lake/main.c:150 ../raster/r.category/main.c:52
-#: ../raster/r.surf.contour/main.c:60 ../raster/r.describe/main.c:54
-#: ../raster/r.regression.multi/main.c:128 ../raster/r.mapcalc/main.c:69
-#: ../raster/r.watershed/front/main.c:73 ../raster/r.spreadpath/main.c:88
-#: ../raster/r.patch/main.c:58 ../raster/r.out.gdal/main.c:136
-#: ../raster/r.out.mat/main.c:62 ../raster/r.external.out/main.c:235
-#: ../raster/r.volume/main.c:76 ../raster/r.surf.idw/main.c:104
-#: ../raster/r.ros/main.c:212 ../raster/r.flow/main.c:421
-#: ../raster/r.null/main.c:60 ../raster/r.in.gdal/main.c:90
-#: ../raster/r.distance/main.c:39 ../raster/r.water.outlet/main.c:57
-#: ../raster/r.surf.gauss/main.c:38 ../raster/r.out.ppm3/main.c:57
-#: ../raster/r.in.ascii/main.c:69 ../raster/r.regression.line/main.c:46
-#: ../raster/r.recode/main.c:48 ../raster/r.sunmask/main.c:116
-#: ../raster/r.quant/main.c:47 ../raster/r.neighbors/main.c:167
-#: ../raster/r.mode/main.c:54 ../raster/r.walk/main.c:178
-#: ../locale/scriptstrings/r.mask_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:4
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:2
-#: ../locale/scriptstrings/r.pack_to_translate.c:2
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:4
-#: ../locale/scriptstrings/i.spectral_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:4
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:2
-#: ../locale/scriptstrings/d.to.rast_to_translate.c:4
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
-#: ../locale/scriptstrings/r.import_to_translate.c:2
-#: ../locale/scriptstrings/r.grow_to_translate.c:2
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:4
-#: ../locale/scriptstrings/d.correlate_to_translate.c:4
-#: ../locale/scriptstrings/r.blend_to_translate.c:2
-#: ../locale/scriptstrings/r.rgb_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:4
-#: ../locale/scriptstrings/r.plane_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:4
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:3
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
-#: ../locale/scriptstrings/r.tileset_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:4
-#: ../locale/scriptstrings/r.shade_to_translate.c:2
-#: ../locale/scriptstrings/r.unpack_to_translate.c:2
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:2
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:4
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:4
-#: ../display/d.rast.num/main.c:79 ../display/d.rgb/main.c:55
-#: ../display/d.rast.arrow/main.c:99 ../display/d.colortable/main.c:61
-#: ../display/d.rast/main.c:55 ../display/d.profile/main.c:193
-#: ../misc/m.nviz.script/main.c:71 ../misc/m.nviz.image/main.c:53
-#: ../vector/v.what.rast3/main.c:66 ../vector/v.neighbors/main.c:53
-#: ../vector/v.what.rast/main.c:73 ../vector/v.sample/main.c:77
-#: ../vector/v.to.rast/main.c:46
-msgid "raster"
-msgstr "격자"
+#: ../misc/m.measure/main.c:45
+msgid "Measures the lengths and areas of features."
+msgstr ""
-#: ../raster3d/r3.to.rast/main.c:263
-msgid "Converts 3D raster maps to 2D raster maps"
+#: ../misc/m.measure/main.c:47
+msgid "measurement"
msgstr ""
-#: ../raster3d/r3.to.rast/main.c:332 ../raster3d/r3.out.vtk/main.c:451
-msgid ""
-"The 2D and 3D region settings are different. Using the 2D window settings to "
-"adjust the 2D part of the 3D region."
+#: ../misc/m.measure/main.c:48 ../misc/m.cogo/main.c:226
+#: ../locale/scriptstrings/r.grow_to_translate.c:3
+#: ../raster/r.distance/main.c:40 ../raster/r.grow.distance/main.c:151
+#: ../display/d.geodesic/main.c:47 ../display/d.rhumbline/main.c:45
+#: ../vector/v.distance/main.c:91
+msgid "distance"
msgstr ""
-#: ../raster3d/r3.to.rast/main.c:360 ../imagery/i.smap/multialloc.c:115
-#: ../db/drivers/postgres/listtab.c:92 ../db/drivers/postgres/listdb.c:88
-#: ../db/drivers/sqlite/listdb.c:134 ../raster/r.to.rast3/main.c:244
-#: ../raster/r.li/r.li.daemon/list.c:49 ../raster/r.stream.extract/dseg.c:51
-#: ../raster/r.stream.extract/bseg.c:50 ../raster/r.stream.extract/cseg.c:51
-#: ../raster/r.stream.extract/seg.c:55 ../vector/v.net.flow/main.c:232
-#: ../vector/v.net.centrality/main.c:293 ../vector/v.net.centrality/main.c:298
-#: ../vector/v.net.centrality/main.c:304 ../vector/v.net.centrality/main.c:310
-#: ../vector/v.net.centrality/main.c:316 ../vector/v.net.allpairs/main.c:201
-#: ../vector/v.net.timetable/main.c:389 ../vector/v.net.timetable/main.c:399
-#: ../vector/v.generalize/smoothing.c:144
-#: ../vector/v.generalize/smoothing.c:231
-#: ../vector/v.generalize/smoothing.c:374
-#: ../vector/v.generalize/smoothing.c:528
-#: ../vector/v.generalize/smoothing.c:574
-#: ../vector/v.generalize/smoothing.c:578
-#: ../vector/v.generalize/smoothing.c:582
-#: ../vector/v.generalize/smoothing.c:586
-#: ../vector/v.generalize/smoothing.c:590
-#: ../vector/v.generalize/smoothing.c:594
-#: ../vector/v.generalize/smoothing.c:598
-#: ../vector/v.generalize/simplification.c:33
-#: ../vector/v.generalize/simplification.c:40
-#: ../vector/v.generalize/simplification.c:306
-#: ../vector/v.generalize/simplification.c:314
-#: ../vector/v.generalize/simplification.c:338
-#: ../vector/v.generalize/matrix.c:144 ../vector/v.generalize/network.c:96
-#: ../vector/v.generalize/network.c:131 ../vector/v.surf.rst/main.c:800
-#: ../vector/v.net.distance/main.c:228 ../vector/v.mkgrid/write_grid.c:28
-#: ../vector/v.net.components/main.c:170 ../vector/v.kcv/main.c:208
-#: ../vector/v.vol.rst/user1.c:423 ../vector/v.net.connectivity/main.c:186
-#: ../vector/v.net.connectivity/main.c:202
-msgid "Out of memory"
+#: ../misc/m.measure/main.c:49
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:4
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:4
+#: ../locale/scriptstrings/v.centroids_to_translate.c:4
+#: ../vector/v.category/main.c:695 ../vector/v.type/main.c:41
+#: ../vector/v.buffer/main.c:223
+msgid "area"
msgstr ""
-#: ../raster3d/r3.to.rast/main.c:362
-#, c-format
-msgid "Creating %i raster maps"
+#: ../misc/m.measure/main.c:56
+msgid "Units"
msgstr ""
-#: ../raster3d/r3.to.rast/main.c:368
-#, fuzzy, c-format
-msgid "Raster map %i Filename: %s"
-msgstr "출력할 격자지도"
+#: ../misc/m.measure/main.c:57
+msgid "Default: location map units"
+msgstr ""
-#: ../raster3d/r3.to.rast/main.c:373
-#, fuzzy, c-format
-msgid ""
-"Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
-msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.bin/main.c:73
+#: ../misc/m.measure/main.c:61
#, fuzzy
-msgid "Error reading binary data"
+msgid "Shell script style"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.bin/main.c:154
-#, c-format
-msgid "Loading %s data with %i bytes ... (%dx%dx%d)"
+#: ../misc/m.measure/main.c:104
+msgid "Length:"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:202 ../raster3d/r3.neighbors/main.c:311
-#, fuzzy
-msgid "Error flushing tiles"
-msgstr "출력할 격자지도"
+#: ../misc/m.measure/main.c:115
+msgid "Area:"
+msgstr ""
-#: ../raster3d/r3.in.bin/main.c:253 ../raster3d/r3.in.ascii/main.c:355
-#: ../raster3d/r3.in.lidar/main.c:163 ../raster3d/r3.in.v5d/main.c:179
-#: ../raster/r.in.lidar/main.c:109 ../raster/r.in.mat/main.c:92
-#: ../raster/r.in.png/main.c:520 ../raster/r.proj/main.c:147
-#: ../raster/r.in.xyz/main.c:159 ../raster/r.in.bin/main.c:258
-#: ../raster/r.external/main.c:58 ../raster/r.in.poly/main.c:35
-#: ../raster/r.in.gridatb/main.c:46 ../raster/r.in.gdal/main.c:91
-#: ../raster/r.in.ascii/main.c:70
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:3
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:3
-#: ../locale/scriptstrings/v.import_to_translate.c:3
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:3
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:3
-#: ../locale/scriptstrings/v.unpack_to_translate.c:3
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:3
-#: ../locale/scriptstrings/r.import_to_translate.c:3
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:3
-#: ../locale/scriptstrings/r.unpack_to_translate.c:3
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:3
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:3
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:3
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:3
-#: ../vector/v.in.lidar/main.c:137 ../vector/v.in.db/main.c:53
-#: ../vector/v.in.ogr/main.c:136 ../vector/v.external/main.c:51
-#: ../vector/v.in.dwg/main.c:83 ../vector/v.in.dxf/main.c:65
-#: ../vector/v.in.ascii/main.c:71 ../vector/v.proj/main.c:70
-msgid "import"
-msgstr "들여오기"
+#: ../misc/m.cogo/main.c:227
+msgid "polar"
+msgstr ""
-#: ../raster3d/r3.in.bin/main.c:256
-#, fuzzy
-msgid "Imports a binary raster file into a GRASS 3D raster map."
-msgstr "출력할 격자지도"
+#: ../misc/m.cogo/main.c:228
+msgid ""
+"A simple utility for converting bearing and distance measurements to "
+"coordinates and vice versa."
+msgstr ""
-#: ../raster3d/r3.in.bin/main.c:259
-#, fuzzy
-msgid "Name of binary 3D raster file to be imported"
-msgstr "출력할 격자지도"
+#: ../misc/m.cogo/main.c:230
+msgid "It assumes a cartesian coordinate system"
+msgstr ""
-#: ../raster3d/r3.in.bin/main.c:268 ../raster3d/r3.out.bin/main.c:228
-#, fuzzy
-msgid "Number of bytes per cell in binary file"
-msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.bin/main.c:275
-msgid "Byte order in binary file"
+#: ../misc/m.cogo/main.c:234
+msgid "Lines are labelled"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:283 ../raster/r.in.bin/main.c:338
-msgid "Northern limit of geographic region (outer edge)"
+#: ../misc/m.cogo/main.c:239
+msgid "Convert from coordinates to bearing and distance"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:284 ../raster3d/r3.in.bin/main.c:292
-#: ../raster3d/r3.in.bin/main.c:300 ../raster3d/r3.in.bin/main.c:308
-#: ../raster3d/r3.in.bin/main.c:316 ../raster3d/r3.in.bin/main.c:323
-#: ../raster3d/r3.in.bin/main.c:330 ../raster3d/r3.in.bin/main.c:337
-#: ../raster3d/r3.in.bin/main.c:344 ../raster/r.region/main.c:104
-#: ../raster/r.region/main.c:113 ../raster/r.region/main.c:122
-#: ../raster/r.region/main.c:131 ../raster/r.in.bin/main.c:285
-#: ../raster/r.in.bin/main.c:339 ../raster/r.in.bin/main.c:347
-#: ../raster/r.in.bin/main.c:355 ../raster/r.in.bin/main.c:363
-#: ../raster/r.in.bin/main.c:370 ../raster/r.in.bin/main.c:377
-#: ../general/g.region/main.c:156 ../general/g.region/main.c:200
-#: ../general/g.region/main.c:209 ../general/g.region/main.c:218
-#: ../general/g.region/main.c:227 ../general/g.region/main.c:236
-#: ../general/g.region/main.c:245 ../general/g.region/main.c:321
-#: ../general/g.region/main.c:332
-msgid "Bounds"
+#: ../misc/m.cogo/main.c:244
+msgid "Repeat the starting coordinate at the end to close a loop"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:291 ../raster/r.in.bin/main.c:346
-msgid "Southern limit of geographic region (outer edge)"
+#: ../misc/m.cogo/main.c:255
+msgid "Starting coordinate pair"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:299 ../raster/r.in.bin/main.c:354
-msgid "Eastern limit of geographic region (outer edge)"
+#: ../misc/m.cogo/main.c:265
+#, c-format
+msgid "Couldn't open COGO file <%s>"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:307 ../raster/r.in.bin/main.c:362
-msgid "Western limit of geographic region (outer edge)"
+#: ../misc/m.cogo/main.c:274
+#, c-format
+msgid "Couldn't open output file <%s>"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:315
-msgid "Bottom limit of geographic region (outer edge)"
+#: ../misc/m.cogo/main.c:301 ../misc/m.cogo/main.c:304
+msgid "Converting starting coordinate pair"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:322
-msgid "Top limit of geographic region (outer edge)"
+#: ../misc/m.cogo/main.c:319
+#, c-format
+msgid "Input parse error on line %lu"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:329 ../raster/r.in.bin/main.c:369
-msgid "Number of rows"
+#: ../misc/m.nviz.image/surface.c:50 ../misc/m.nviz.image/surface.c:107
+#: ../general/g.region/main.c:425 ../general/g.region/main.c:749
+#: ../general/g.region/main.c:757 ../raster/r.reclass/main.c:79
+#: ../raster/r.univar/r.univar_main.c:234 ../raster/r.flow/io.c:65
+#: ../raster/r.flow/io.c:242 ../raster/r.buffer/main.c:112
+#: ../raster/r.report/parse.c:273 ../raster/r.category/main.c:119
+#: ../raster/r.category/main.c:140 ../raster/r.distance/parse.c:72
+#: ../raster/r.distance/parse.c:81 ../raster/r.cross/main.c:106
+#: ../raster/r.tile/main.c:86 ../raster/r.spread/main.c:439
+#: ../raster/r.spread/main.c:442 ../raster/r.spread/main.c:445
+#: ../raster/r.spread/main.c:449 ../raster/r.spread/main.c:452
+#: ../raster/r.spread/main.c:455 ../raster/r.walk/main.c:435
+#: ../raster/r.walk/main.c:440 ../raster/r.walk/main.c:801
+#: ../raster/r.cost/main.c:350 ../raster/r.cost/main.c:665
+#: ../raster/r.sim/simlib/output.c:363 ../raster/r.sim/simlib/output.c:372
+#: ../raster/r.sim/simlib/output.c:403 ../raster/r.sim/simlib/output.c:412
+#: ../raster/r.sim/simlib/output.c:458 ../raster/r.sim/simlib/output.c:475
+#: ../raster/r.sim/simlib/output.c:497 ../raster/r.sim/simlib/output.c:541
+#: ../raster/r.sim/simlib/output.c:583 ../raster/r.sim/simlib/output.c:755
+#: ../raster/r.stream.extract/main.c:174 ../raster/r.stream.extract/main.c:178
+#: ../raster/r.stream.extract/main.c:183 ../raster/r.info/main.c:104
+#: ../raster/r.null/main.c:128 ../raster/r.kappa/stats.c:33
+#: ../raster/r.kappa/stats.c:38 ../raster/r.kappa/main.c:150
+#: ../raster/r.ros/main.c:368 ../raster/r.ros/main.c:379
+#: ../raster/r.ros/main.c:384 ../raster/r.ros/main.c:389
+#: ../raster/r.ros/main.c:394 ../raster/r.ros/main.c:408
+#: ../raster/r.ros/main.c:412 ../raster/r.ros/main.c:427
+#: ../raster/r.ros/main.c:431 ../raster/r.ros/main.c:442
+#: ../raster/r.colors/edit_colors.c:393 ../raster/r.mapcalc/map.c:517
+#: ../raster/r.compress/main.c:116 ../raster/r.compress/main.c:296
+#: ../raster/r.coin/main.c:121 ../raster/r.coin/main.c:123
+#: ../raster/r.carve/main.c:165 ../vector/v.vol.rst/main.c:615
+#: ../vector/v.colors/main.c:312 ../imagery/i.pca/main.c:139
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:155
+#: ../imagery/i.gensigset/parse.c:44 ../imagery/i.gensig/parse.c:38
+#: ../doc/raster/r.example/main.c:105
+#, c-format
+msgid "Raster map <%s> not found"
+msgstr "격자지도 <%s>를 찾지 못 했습니다"
+#: ../misc/m.nviz.image/surface.c:67
+#, c-format
+msgid "Missing topography attribute for surface %d"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:336 ../raster/r.in.bin/main.c:376
-msgid "Number of columns"
+#: ../misc/m.nviz.image/surface.c:131 ../misc/m.nviz.image/volume.c:159
+#, c-format
+msgid "Color attribute not defined, using default <%s>"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:343
-#, fuzzy
-msgid "Number of depths"
+#: ../misc/m.nviz.image/surface.c:137
+#, fuzzy, c-format
+msgid "Missing color attribute for surface %d"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.bin/main.c:350 ../raster/r.in.bin/main.c:383
-msgid "Set Value to NULL"
-msgstr ""
+#: ../misc/m.nviz.image/surface.c:217
+#, fuzzy, c-format
+msgid "Surface id %d doesn't exist"
+msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.bin/main.c:354 ../raster3d/r3.out.ascii/main.c:106
-#: ../raster3d/r3.out.bin/main.c:240
-msgid "Switch the row order in output from north->south to south->north"
-msgstr ""
+#: ../misc/m.nviz.image/surface.c:264 ../misc/m.nviz.image/surface.c:271
+#, fuzzy, c-format
+msgid "Unable to set draw mode for surface id %d"
+msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.bin/main.c:359 ../raster3d/r3.out.ascii/main.c:110
-#: ../raster3d/r3.out.bin/main.c:245
-msgid "Switch the depth order in output from bottom->top to top->bottom"
+#: ../misc/m.nviz.image/args.c:51
+msgid "Use draw mode for all loaded surfaces"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:365
-msgid "Binary data is of type integer"
+#: ../misc/m.nviz.image/args.c:52 ../misc/m.nviz.image/args.c:133
+#: ../misc/m.nviz.image/args.c:143 ../misc/m.nviz.image/args.c:150
+#: ../misc/m.nviz.image/args.c:156 ../misc/m.nviz.image/args.c:164
+#: ../misc/m.nviz.image/args.c:173 ../misc/m.nviz.image/args.c:183
+#: ../misc/m.nviz.image/args.c:191 ../misc/m.nviz.image/args.c:201
+#: ../misc/m.nviz.image/args.c:209 ../misc/m.nviz.image/args.c:219
+msgid "Surfaces"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:369 ../raster/r.in.bin/main.c:274
-msgid "Signed data (two's complement)"
+#: ../misc/m.nviz.image/args.c:70 ../general/g.pnmcomp/main.c:325
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:32
+#: ../display/d.mon/main.c:90 ../display/d.legend/main.c:246
+#: ../display/d.grid/main.c:113 ../display/d.legend.vect/main.c:101
+#: ../display/d.path/main.c:115 ../display/d.histogram/main.c:108
+#: ../display/d.erase/main.c:37 ../vector/v.lrs/v.lrs.label/main.c:218
+#: ../vector/v.label.sa/main.c:124 ../vector/v.label/main.c:187
+msgid "Background color"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:399
-#, c-format
-msgid "bytes=%d; must be 4 or 8 in case of floating point input"
+#: ../misc/m.nviz.image/args.c:92
+#, fuzzy
+msgid "Name for output image file (without extension)"
+msgstr "출력할 격자지도"
+#: ../misc/m.nviz.image/args.c:93 ../misc/m.nviz.image/args.c:107
+#: ../misc/m.nviz.image/args.c:117
+msgid "Image"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:409
-msgid "Integer input doesn't support size=8 in this build"
+#: ../misc/m.nviz.image/args.c:105
+#: ../locale/scriptstrings/d.out.file_to_translate.c:5
+msgid "Graphics file format"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:413
-msgid "bytes= must be 1, 2, 4 or 8"
+#: ../misc/m.nviz.image/args.c:115
+msgid "Size (width, height) of output image"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:424 ../raster/r.in.bin/main.c:521
-#: ../display/d.grid/main.c:266
-#, c-format
-msgid "Illegal north coordinate <%s>"
+#: ../misc/m.nviz.image/args.c:132
+#, fuzzy
+msgid "Name of raster map(s) for elevation"
+msgstr "출력할 격자지도"
+#: ../misc/m.nviz.image/args.c:142
+msgid "Constant elevation value(s) to use instead of a raster DEM"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:426 ../raster/r.in.bin/main.c:523
-#, fuzzy, c-format
-msgid "Illegal south coordinate <%s>"
+#: ../misc/m.nviz.image/args.c:149
+#, fuzzy
+msgid "Name of raster map(s) for color"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.bin/main.c:428 ../raster/r.in.bin/main.c:525
-#: ../display/d.grid/main.c:259
-#, c-format
-msgid "Illegal east coordinate <%s>"
+#: ../misc/m.nviz.image/args.c:155
+msgid "Color value(s)"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:430 ../raster/r.in.bin/main.c:527
-#, fuzzy, c-format
-msgid "Illegal west coordinate <%s>"
+#: ../misc/m.nviz.image/args.c:163
+#, fuzzy
+msgid "Name of raster map(s) for mask"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.bin/main.c:438 ../raster/r.in.bin/main.c:533
-#, fuzzy, c-format
-msgid "Unable to open <%s>"
+#: ../misc/m.nviz.image/args.c:172
+#, fuzzy
+msgid "Name of raster map(s) for transparency"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.bin/main.c:446
-#, c-format
-msgid "File Size %lld ... Total Bytes %lld"
+#: ../misc/m.nviz.image/args.c:182
+msgid "Transparency value(s)"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:448 ../raster/r.in.bin/main.c:577
-msgid "Bytes do not match file size"
+#: ../misc/m.nviz.image/args.c:190
+#, fuzzy
+msgid "Name of raster map(s) for shininess"
+msgstr "출력할 격자지도"
+#: ../misc/m.nviz.image/args.c:200
+msgid "Shininess value(s)"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:463 ../raster3d/r3.in.ascii/main.c:387
-#: ../raster3d/r3.in.v5d/main.c:201
+#: ../misc/m.nviz.image/args.c:208
#, fuzzy
-msgid "Unable to open 3D raster map"
+msgid "Name of raster map(s) for emission"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.gwflow/main.c:54
-msgid "Input 3D raster map with initial piezometric heads in [m]"
+#: ../misc/m.nviz.image/args.c:218
+msgid "Emission value(s)"
msgstr ""
-#: ../raster3d/r3.gwflow/main.c:60
-msgid ""
-"Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - "
-"active, 2 - dirichlet"
+#: ../misc/m.nviz.image/args.c:230
+msgid "Draw mode"
msgstr ""
-#: ../raster3d/r3.gwflow/main.c:65
-msgid ""
-"Input 3D raster map with the x-part of the hydraulic conductivity tensor in "
-"[m/s]"
+#: ../misc/m.nviz.image/args.c:233 ../misc/m.nviz.image/args.c:244
+#: ../misc/m.nviz.image/args.c:255 ../misc/m.nviz.image/args.c:267
+#: ../misc/m.nviz.image/args.c:279 ../misc/m.nviz.image/args.c:288
+#: ../misc/m.nviz.image/args.c:298 ../misc/m.nviz.image/args.c:608
+#: ../misc/m.nviz.image/args.c:620 ../display/d.grid/main.c:133
+#: ../display/d.grid/main.c:139 ../display/d.grid/main.c:144
+#: ../display/d.grid/main.c:149 ../display/d.grid/main.c:154
+msgid "Draw"
msgstr ""
-#: ../raster3d/r3.gwflow/main.c:70
-msgid ""
-"Input 3D raster map with the y-part of the hydraulic conductivity tensor in "
-"[m/s]"
+#: ../misc/m.nviz.image/args.c:242
+msgid "Fine resolution"
msgstr ""
-#: ../raster3d/r3.gwflow/main.c:75
-msgid ""
-"Input 3D raster map with the z-part of the hydraulic conductivity tensor in "
-"[m/s]"
+#: ../misc/m.nviz.image/args.c:253
+msgid "Coarse resolution"
msgstr ""
-#: ../raster3d/r3.gwflow/main.c:80
-#, fuzzy
-msgid "Input 3D raster map with sources and sinks in [m^3/s]"
-msgstr "출력할 격자지도"
+#: ../misc/m.nviz.image/args.c:264
+msgid "Draw style"
+msgstr ""
-#: ../raster3d/r3.gwflow/main.c:84
+#: ../misc/m.nviz.image/args.c:276
+msgid "Shading"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:285
+msgid "Wire color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:297
#, fuzzy
-msgid "Specific yield [1/m] input 3D raster map"
+msgid "Surface position"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.gwflow/main.c:89
+#: ../misc/m.nviz.image/args.c:309
#, fuzzy
-msgid "Recharge input 3D raster map in m^3/s"
+msgid "Name of line vector overlay map(s)"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.gwflow/main.c:93
+#: ../misc/m.nviz.image/args.c:310 ../misc/m.nviz.image/args.c:318
+#: ../misc/m.nviz.image/args.c:330 ../misc/m.nviz.image/args.c:339
+#: ../misc/m.nviz.image/args.c:348 ../misc/m.nviz.image/args.c:355
+#: ../misc/m.nviz.image/args.c:369 ../misc/m.nviz.image/args.c:379
+#: ../misc/m.nviz.image/args.c:391
#, fuzzy
-msgid ""
-"Output 3D raster map storing the piezometric head result of the numerical "
-"calculation"
+msgid "Vector lines"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.gwflow/main.c:99
+#: ../misc/m.nviz.image/args.c:317 ../misc/m.nviz.image/args.c:410
#, fuzzy
-msgid ""
-"Output 3D raster map storing the groundwater filter velocity vector part in "
-"x direction [m/s]"
+msgid "Layer number or name for thematic mapping"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.gwflow/main.c:105
+#: ../misc/m.nviz.image/args.c:329
#, fuzzy
-msgid ""
-"y direction [m/s]"
+msgid "Vector line width"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.gwflow/main.c:111
+#: ../misc/m.nviz.image/args.c:337 ../misc/m.nviz.image/args.c:449
#, fuzzy
-msgid ""
-"z direction [m/s]"
+msgid "Name of width definition column"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.gwflow/main.c:117
+#: ../misc/m.nviz.image/args.c:345
#, fuzzy
-msgid ""
-"Output 3D raster map storing the groundwater budget for each cell [m^3/s]"
+msgid "Vector line color"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.gwflow/main.c:127
+#: ../misc/m.nviz.image/args.c:353 ../misc/m.nviz.image/args.c:465
#, fuzzy
-msgid "Use 3D raster mask (if exists)"
+msgid "Name of color definition column"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.gwflow/main.c:131 ../raster/r.solute.transport/main.c:192
-msgid ""
-"Use a full filled quadratic linear equation system, default is a sparse "
-"linear equation system."
+#: ../misc/m.nviz.image/args.c:364
+msgid "Vector line display mode"
msgstr ""
-#: ../raster3d/r3.gwflow/main.c:160 ../raster/r.gwflow/main.c:209
-msgid "groundwater flow"
-msgstr "지하수흐름"
-#: ../raster3d/r3.gwflow/main.c:162 ../raster3d/r3.flow/main.c:180
-#: ../raster/r.sim/r.sim.sediment/main.c:114
-#: ../raster/r.sim/r.sim.water/main.c:114 ../raster/r.topidx/main.c:40
-#: ../raster/r.usler/main.c:53 ../raster/r.uslek/main.c:54
-#: ../raster/r.gwflow/main.c:210 ../raster/r.stream.extract/main.c:77
-#: ../raster/r.drain/main.c:110 ../raster/r.carve/main.c:75
-#: ../raster/r.topmodel/main.c:52 ../raster/r.basins.fill/main.c:55
-#: ../raster/r.fill.dir/main.c:87 ../raster/r.solute.transport/main.c:230
-#: ../raster/r.lake/main.c:151 ../raster/r.watershed/front/main.c:74
-#: ../raster/r.flow/main.c:422 ../raster/r.water.outlet/main.c:58
-msgid "hydrology"
-msgstr "수문학"
-#: ../raster3d/r3.gwflow/main.c:163
-msgid ""
-"Numerical calculation program for transient, confined groundwater flow in "
-"three dimensions."
+#: ../misc/m.nviz.image/args.c:366
+msgid "surface;drape on raster surface;flat;draw at constant elevation"
msgstr ""
-#: ../raster3d/r3.gwflow/main.c:180
-msgid ""
-"The cholesky solver does not work with sparse matrices.\n"
-"Consider to choose a full filled quadratic matrix with flag -f "
+#: ../misc/m.nviz.image/args.c:378
+msgid "Vector line height"
msgstr ""
-#: ../raster3d/r3.gwflow/main.c:279 ../raster/r.gwflow/main.c:546
-msgid "Unable to create and solve the linear equation system"
-msgstr ""
+#: ../misc/m.nviz.image/args.c:390
+#, fuzzy
+msgid "Vector lines position"
+msgstr "출력할 격자지도"
-#: ../raster3d/r3.gwflow/main.c:365 ../raster3d/r3.in.lidar/main.c:484
-#: ../raster3d/r3.in.lidar/main.c:493 ../raster3d/r3.in.lidar/main.c:501
-#: ../raster3d/r3.in.lidar/main.c:509 ../raster3d/r3.in.lidar/main.c:517
-#: ../raster3d/r3.in.lidar/main.c:527 ../raster3d/r3.in.lidar/main.c:536
-#, fuzzy, c-format
-msgid "Unable to create 3D raster map <%s>"
+#: ../misc/m.nviz.image/args.c:402
+#, fuzzy
+msgid "Name of point vector overlay map(s)"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.ascii/main.c:82
+#: ../misc/m.nviz.image/args.c:403 ../misc/m.nviz.image/args.c:411
+#: ../misc/m.nviz.image/args.c:423 ../misc/m.nviz.image/args.c:432
+#: ../misc/m.nviz.image/args.c:442 ../misc/m.nviz.image/args.c:451
+#: ../misc/m.nviz.image/args.c:460 ../misc/m.nviz.image/args.c:467
+#: ../misc/m.nviz.image/args.c:480 ../misc/m.nviz.image/args.c:488
+#: ../misc/m.nviz.image/args.c:503 ../misc/m.nviz.image/args.c:513
#, fuzzy
-msgid "3D raster map to be converted to ASCII"
+msgid "Vector points"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.ascii/main.c:86
-msgid "Name for ASCII output file"
+#: ../misc/m.nviz.image/args.c:422
+msgid "Icon size (map units)"
msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:95
-msgid "Number of decimal places for floats"
+#: ../misc/m.nviz.image/args.c:430
+#, fuzzy
+msgid "Name of size definition column"
+msgstr "출력할 격자지도"
+#: ../misc/m.nviz.image/args.c:441
+msgid "Icon width"
msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:102 ../raster/r.out.ascii/main.c:95
-msgid "Suppress printing of header information"
+#: ../misc/m.nviz.image/args.c:457
+msgid "Icon color"
msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:114
-msgid "Print grass6 compatible format. Flags -d and -r are ignored."
+#: ../misc/m.nviz.image/args.c:476
+msgid "Icon marker"
msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:308
+#: ../misc/m.nviz.image/args.c:486
#, fuzzy
-msgid "Converts a 3D raster map layer into a ASCII text file."
+msgid "Name of marker definition column"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.ascii/main.c:371
+#: ../misc/m.nviz.image/args.c:497
#, fuzzy
-msgid "Unable to close new ASCII file"
+msgid "3D vector point display mode"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.bin/main.c:113 ../raster/r.out.bin/main.c:53
-#: ../raster/r.out.bin/main.c:62 ../raster/r.out.bin/main.c:470
-#: ../raster/r.mapcalc/map3.c:128 ../raster/r.mapcalc/map3.c:142
-#: ../raster/r.mapcalc/map3.c:156
-#, fuzzy
-msgid "Error writing data"
-msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.bin/main.c:208
-#, fuzzy
-msgid "Exports a GRASS 3D raster map to a binary array."
-msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.bin/main.c:221 ../raster/r.out.bin/main.c:304
-msgid "Value to write out for null"
+#: ../misc/m.nviz.image/args.c:499
+msgid "surface;drape on raster surface;3D;place at 3D point's z-elevation"
msgstr ""
-#: ../raster3d/r3.out.bin/main.c:235 ../raster/r.in.bin/main.c:330
-#: ../raster/r.out.bin/main.c:318
+#: ../misc/m.nviz.image/args.c:512
#, fuzzy
-msgid "Output byte order"
+msgid "Vector points position"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.bin/main.c:250
-#, fuzzy
-msgid "Write data as integer"
-msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.bin/main.c:256 ../raster/r.out.bin/main.c:347
-msgid "Invalid value for null (integers only)"
+#: ../misc/m.nviz.image/args.c:529
+msgid "Viewpoint position (x,y model coordinates)"
msgstr ""
-#: ../raster3d/r3.out.bin/main.c:269
-msgid "Floating-point output requires bytes=4 or bytes=8"
+#: ../misc/m.nviz.image/args.c:530 ../misc/m.nviz.image/args.c:542
+#: ../misc/m.nviz.image/args.c:552 ../misc/m.nviz.image/args.c:564
+#: ../misc/m.nviz.image/args.c:586
+msgid "Viewpoint"
msgstr ""
-#: ../raster3d/r3.out.bin/main.c:273
-msgid "Integer output doesn't support bytes=8 in this build"
+#: ../misc/m.nviz.image/args.c:541
+msgid "Viewpoint height (in map units)"
msgstr ""
-#: ../raster3d/r3.out.bin/main.c:321 ../raster/r.out.bin/main.c:144
-#: ../raster/r.out.bin/main.c:228 ../raster/r.out.bin/main.c:414
-#: ../display/d.mon/start.c:181 ../display/d.mon/start.c:224
-#, fuzzy, c-format
-msgid "Unable to create file <%s>"
-msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.bin/main.c:323 ../raster/r.out.bin/main.c:454
-msgid "Using the current region settings..."
+#: ../misc/m.nviz.image/args.c:551
+msgid "Viewpoint field of view (in degrees)"
msgstr ""
-#: ../raster3d/r3.out.bin/main.c:324 ../raster/r.out.bin/main.c:455
-#, c-format
-msgid "north=%f"
+#: ../misc/m.nviz.image/args.c:563
+msgid "Viewpoint twist angle (in degrees)"
msgstr ""
-#: ../raster3d/r3.out.bin/main.c:325 ../raster/r.out.bin/main.c:456
-#, c-format
-msgid "south=%f"
+#: ../misc/m.nviz.image/args.c:575 ../raster/r.out.vrml/main.c:65
+msgid "Vertical exaggeration"
msgstr ""
-#: ../raster3d/r3.out.bin/main.c:326 ../raster/r.out.bin/main.c:457
-#, c-format
-msgid "east=%f"
+#: ../misc/m.nviz.image/args.c:585
+msgid "Focus to point on surface (from SW corner in map units)"
msgstr ""
-#: ../raster3d/r3.out.bin/main.c:327 ../raster/r.out.bin/main.c:458
-#, c-format
-msgid "west=%f"
+#: ../misc/m.nviz.image/args.c:595 ../misc/m.nviz.image/args.c:630
+#: ../misc/m.nviz.image/args.c:642 ../misc/m.nviz.image/args.c:652
+#: ../misc/m.nviz.image/args.c:661 ../misc/m.nviz.image/args.c:669
+#: ../misc/m.nviz.image/args.c:678 ../misc/m.nviz.image/args.c:689
+#: ../misc/m.nviz.image/args.c:698 ../misc/m.nviz.image/args.c:709
+#: ../misc/m.nviz.image/args.c:716 ../misc/m.nviz.image/args.c:722
+#: ../misc/m.nviz.image/args.c:734 ../misc/m.nviz.image/args.c:744
+#: ../misc/m.nviz.image/args.c:755
+msgid "Volumes"
msgstr ""
-#: ../raster3d/r3.out.bin/main.c:328
-#, c-format
-msgid "top=%f"
+#: ../misc/m.nviz.image/args.c:605
+msgid "Volume draw mode"
msgstr ""
-#: ../raster3d/r3.out.bin/main.c:329
-#, c-format
-msgid "bottom=%f"
+#: ../misc/m.nviz.image/args.c:617
+msgid "Volume shading"
msgstr ""
-#: ../raster3d/r3.out.bin/main.c:330 ../raster/r.in.mat/main.c:398
-#: ../raster/r.out.mat/main.c:180
-#, c-format
-msgid "rows=%d"
+#: ../misc/m.nviz.image/args.c:629
+msgid "Volume position"
msgstr ""
-#: ../raster3d/r3.out.bin/main.c:331 ../raster/r.in.mat/main.c:399
-#: ../raster/r.out.mat/main.c:181
-#, c-format
-msgid "cols=%d"
+#: ../misc/m.nviz.image/args.c:640
+msgid "Volume resolution"
msgstr ""
-#: ../raster3d/r3.out.bin/main.c:332
-#, c-format
-msgid "depths=%d"
+#: ../misc/m.nviz.image/args.c:651
+msgid "Isosurface level"
msgstr ""
-#: ../raster3d/r3.info/main.c:78 ../raster/r.info/main.c:72
-#: ../locale/scriptstrings/t.info_to_translate.c:4 ../vector/v.info/main.c:40
-msgid "extent"
-msgstr "범위"
+#: ../misc/m.nviz.image/args.c:660
+#, fuzzy
+msgid "Name of volume for isosurface color"
+msgstr "출력할 격자지도"
-#: ../raster3d/r3.info/main.c:80
-msgid "Outputs basic information about a user-specified 3D raster map layer."
-msgstr ""
-#: ../raster3d/r3.info/main.c:86
+#: ../misc/m.nviz.image/args.c:668
#, fuzzy
-msgid "Print raster3d information in shell style"
+msgid "Isosurface color"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.info/main.c:90
+#: ../misc/m.nviz.image/args.c:677
#, fuzzy
-msgid "Print range in shell style only"
+msgid "Name of 3D raster map(s) for isosurface transparency"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.info/main.c:94 ../raster/r.info/main.c:93
-msgid "Print raster history instead of info"
+#: ../misc/m.nviz.image/args.c:688
+msgid "Transparency value(s)for isosurfaces"
msgstr ""
-#: ../raster3d/r3.info/main.c:103
-#, fuzzy, c-format
-msgid "3D Raster map <%s> not found"
+#: ../misc/m.nviz.image/args.c:697
+#, fuzzy
+msgid "Name of 3D raster map(s) for shininess"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.info/main.c:138 ../raster3d/r3.info/main.c:145
-#: ../raster3d/r3.info/main.c:151 ../raster3d/r3.info/main.c:156
-#: ../raster3d/r3.info/main.c:162 ../raster3d/r3.info/main.c:167
-#: ../raster3d/r3.info/main.c:172 ../raster3d/r3.info/main.c:183
-#: ../raster3d/r3.info/main.c:189 ../raster3d/r3.info/main.c:204
-#: ../raster3d/r3.info/main.c:211 ../raster3d/r3.info/main.c:218
-#: ../raster3d/r3.info/main.c:223 ../raster3d/r3.info/main.c:228
-#: ../raster3d/r3.info/main.c:235 ../raster3d/r3.info/main.c:245
-#: ../raster3d/r3.info/main.c:251 ../raster3d/r3.info/main.c:257
-#: ../raster3d/r3.info/main.c:273 ../raster3d/r3.info/main.c:280
-#: ../raster3d/r3.info/main.c:287 ../raster3d/r3.info/main.c:296
-#: ../raster3d/r3.info/main.c:306 ../raster3d/r3.info/main.c:316
-#: ../raster3d/r3.info/main.c:326 ../raster3d/r3.info/main.c:346
-#: ../raster3d/r3.info/main.c:356 ../raster3d/r3.info/main.c:361
-#: ../raster3d/r3.info/main.c:369 ../raster3d/r3.info/main.c:382
-#: ../raster/r.info/main.c:303 ../raster/r.info/main.c:445
-msgid "Cannot allocate memory for string"
+#: ../misc/m.nviz.image/args.c:708
+msgid "Shininess value(s) for isosurfaces"
msgstr ""
-#: ../raster3d/r3.info/main.c:328 ../raster3d/r3.info/main.c:448
-#: ../raster3d/r3.mkdspf/main.c:171
-#, fuzzy, c-format
-msgid "Unable to read range of 3D raster map <%s>"
-msgstr "출력할 격자지도"
+#: ../misc/m.nviz.image/args.c:715
+msgid "Toggles normal direction of all isosurfaces (changes light effect)"
+msgstr ""
-#: ../raster3d/r3.info/main.c:492
-msgid "Error while reading history file"
+#: ../misc/m.nviz.image/args.c:721
+msgid "Draw volume box"
msgstr ""
-#: ../raster3d/r3.info/main.c:499 ../raster3d/r3.null/main.c:169
-#: ../raster3d/r3.cross.rast/main.c:343
-#: ../raster3d/r3.out.vtk/errorHandling.c:65
-#, fuzzy, c-format
-msgid "Unable to close 3D raster map <%s>"
-msgstr "출력할 격자지도"
+#: ../misc/m.nviz.image/args.c:733
+msgid "Volume slice parallel to given axis (x, y, z)"
+msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:86 ../raster/r.in.ascii/main.c:78
-#: ../vector/v.in.ascii/main.c:78
+#: ../misc/m.nviz.image/args.c:743
#, fuzzy
-msgid "Name of input file to be imported"
+msgid "Volume slice position"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.ascii/main.c:87 ../db/db.execute/main.c:139
-#: ../db/db.select/main.c:208 ../raster/r.reclass/main.c:66
-#: ../raster/r.in.ascii/main.c:79 ../raster/r.recode/main.c:61
-#: ../locale/scriptstrings/m.proj_to_translate.c:8
-#: ../general/g.proj/main.c:141 ../general/g.proj/main.c:150
-#: ../vector/v.segment/main.c:80 ../vector/v.edit/args.c:89
-#: ../vector/v.what/main.c:76
-msgid "'-' for standard input"
-msgstr "표준입력을 위해서는 '-'"
-#: ../raster3d/r3.in.ascii/main.c:94
-msgid "String representing NULL value data cell (use 'none' if no such value)"
+#: ../misc/m.nviz.image/args.c:754
+msgid "Volume slice transparency"
msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:130 ../raster/r.in.ascii/main.c:275
-msgid "Unable to write to file"
+#: ../misc/m.nviz.image/args.c:771
+msgid "Light position (x,y,z model coordinates)"
msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:169 ../raster/r.resamp.rst/main.c:542
-#: ../raster/r.in.ascii/main.c:120 ../raster/r.in.ascii/main.c:150
-#: ../display/d.title/main.c:117 ../general/g.setproj/get_stp.c:162
-#: ../general/g.setproj/get_stp.c:165 ../general/g.setproj/get_stp.c:282
-#: ../general/g.setproj/get_stp.c:286 ../vector/v.surf.rst/main.c:821
-#: ../vector/v.in.ascii/main.c:273
-#, c-format
-msgid "Unable to open temporary file <%s>"
-msgstr "임시파일 <%s>를 열 수 없습니다"
-#: ../raster3d/r3.in.ascii/main.c:172 ../raster/r.in.ascii/main.c:153
-msgid "Unable to read input from stdin"
+#: ../misc/m.nviz.image/args.c:772 ../misc/m.nviz.image/args.c:778
+#: ../misc/m.nviz.image/args.c:787 ../misc/m.nviz.image/args.c:797
+msgid "Lighting"
msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:221
-#, fuzzy, c-format
-msgid "Unsupported GRASS version %s"
-msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.ascii/main.c:265
-#, c-format
-msgid "Loading data ... (%dx%dx%d)"
+#: ../misc/m.nviz.image/args.c:777
+msgid "Light color"
msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:298
-msgid "End of file reached while still loading data."
+#: ../misc/m.nviz.image/args.c:786
+msgid "Light brightness"
msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:310
-#, c-format
-msgid "Invalid value detected (at col=%d row=%d depth=%d): %s"
+#: ../misc/m.nviz.image/args.c:796
+msgid "Light ambient"
msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:322
-#, c-format
-msgid ""
-"Data exists in input file after fully importing expected data. [%.4f ...]"
+#: ../misc/m.nviz.image/args.c:810
+msgid "Cutting plane index (0-5)"
msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:360
+#: ../misc/m.nviz.image/args.c:811 ../misc/m.nviz.image/args.c:820
+#: ../misc/m.nviz.image/args.c:829 ../misc/m.nviz.image/args.c:841
+#: ../misc/m.nviz.image/args.c:852
#, fuzzy
-msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
+msgid "Cutting planes"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.ascii/main.c:403
+#: ../misc/m.nviz.image/args.c:819
#, fuzzy
-msgid "Unable to close ASCII file"
+msgid "Cutting plane x,y,z coordinates"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.support/main.c:52
-msgid ""
-"Allows creation and/or modification of 3D raster map layer support files."
+#: ../misc/m.nviz.image/args.c:831
+msgid "Cutting plane rotation along the vertical axis"
msgstr ""
-#: ../raster3d/r3.support/main.c:62
+#: ../misc/m.nviz.image/args.c:842
#, fuzzy
-msgid "Text to use for map title"
+msgid "Cutting plane tilt"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.support/main.c:70 ../raster/r.support/main.c:74
-msgid "Text to append to the next line of the map's metadata file"
+#: ../misc/m.nviz.image/args.c:854
+msgid "Cutting plane color (between two surfaces)"
msgstr ""
-#: ../raster3d/r3.support/main.c:76
-msgid "The map data unit"
+#: ../misc/m.nviz.image/args.c:870
+msgid "North-West edge"
msgstr ""
-#: ../raster3d/r3.support/main.c:82
-msgid "The vertical unit of the map"
+#: ../misc/m.nviz.image/args.c:871
+msgid "North-East edge"
msgstr ""
-#: ../raster3d/r3.support/main.c:89 ../raster/r.support/main.c:93
-msgid "Text to use for data source, line 1"
+#: ../misc/m.nviz.image/args.c:872
+msgid "South-West edge"
msgstr ""
-#: ../raster3d/r3.support/main.c:96 ../raster/r.support/main.c:100
-msgid "Text to use for data source, line 2"
+msgid "South-East edge"
msgstr ""
-#: ../raster3d/r3.support/main.c:104 ../raster/r.support/main.c:108
-msgid "Text to use for data description or keyword(s)"
+#: ../misc/m.nviz.image/args.c:874
+#, fuzzy
+msgid "Fringe edges"
+msgstr "출력할 격자지도"
+#: ../misc/m.nviz.image/args.c:875 ../misc/m.nviz.image/args.c:881
+#: ../misc/m.nviz.image/args.c:890
+msgid "Fringe"
msgstr ""
-#: ../raster3d/r3.support/main.c:111 ../raster/r.support/main.c:115
-#: ../raster/r.category/main.c:80
+#: ../misc/m.nviz.image/args.c:880
#, fuzzy
-msgid "Raster map from which to copy category table"
+msgid "Fringe color"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.support/main.c:116 ../raster/r.support/main.c:120
-msgid "Text file from which to load history"
+#: ../misc/m.nviz.image/args.c:889
+#, fuzzy
+msgid "Fringe elevation"
+msgstr "출력할 격자지도"
+#: ../misc/m.nviz.image/args.c:903
+msgid ""
+"Place north arrow at given position \t(in screen coordinates from bottom "
+"left corner)"
msgstr ""
-#: ../raster3d/r3.support/main.c:121 ../raster/r.support/main.c:125
-msgid "Text file in which to save history"
+#: ../misc/m.nviz.image/args.c:905 ../misc/m.nviz.image/args.c:915
+#: ../misc/m.nviz.image/args.c:922
+#, fuzzy
+msgid "Decoration"
+msgstr "출력할 격자지도"
+#: ../misc/m.nviz.image/args.c:914
+msgid "North arrow size (in map units)"
msgstr ""
-#: ../raster3d/r3.support/main.c:125
-msgid "Update range"
+#: ../misc/m.nviz.image/args.c:921
+msgid "North arrow color"
msgstr ""
-#: ../raster3d/r3.support/main.c:153 ../raster/r.support/main.c:162
-#: ../raster/r.out.png/main.c:205 ../raster/r.out.pov/main.c:173
-#: ../raster/r.out.vrml/main.c:131 ../raster/r.colors.out/raster3d_main.c:80
-#: ../raster/r.colors.out/raster_main.c:79 ../raster/r.out.mat/main.c:91
-#: ../general/g.cairocomp/main.c:66 ../vector/v.colors.out/main.c:103
+#: ../misc/m.nviz.image/args.c:973
#, c-format
-msgid "Unable to open output file <%s>"
+msgid "At least one <%s> or <%s> required"
msgstr ""
-#: ../raster3d/r3.support/main.c:167 ../raster/r.support/main.c:176
-#: ../raster/r.in.mat/main.c:125 ../raster/r.series.accumulate/main.c:221
-#: ../raster/r.in.xyz/main.c:573 ../raster/r.topmodel/file_io.c:28
-#: ../raster/r.topmodel/file_io.c:136 ../raster/r.topmodel/file_io.c:161
-#: ../raster/r.series/main.c:223 ../raster/r.mapcalc/main.c:48
-#: ../display/d.text/main.c:382 ../display/d.linegraph/main.c:391
-#: ../display/d.linegraph/main.c:407 ../display/d.linegraph/main.c:669
-#: ../display/d.where/main.c:163 ../display/d.legend.vect/main.c:259
-#: ../display/d.legend.vect/main.c:273 ../display/d.legend.vect/draw.c:72
-#: ../general/g.cairocomp/main.c:46 ../vector/v.lrs/v.lrs.segment/main.c:133
-#: ../vector/v.segment/main.c:98 ../vector/v.net.path/path.c:49
+#: ../misc/m.nviz.image/args.c:987 ../misc/m.nviz.image/args.c:1017
+#: ../misc/m.nviz.image/args.c:1023 ../misc/m.nviz.image/args.c:1029
+#: ../misc/m.nviz.image/args.c:1035 ../misc/m.nviz.image/args.c:1041
+#: ../misc/m.nviz.image/args.c:1047
+#, c-format
+msgid "Inconsistent number of attributes (<%s/%s>: %d vs. <%s>: %d)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:1058
+#, c-format
+msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d x 3)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:1064 ../misc/m.nviz.image/args.c:1070
+#: ../misc/m.nviz.image/args.c:1082 ../misc/m.nviz.image/args.c:1089
+#: ../misc/m.nviz.image/args.c:1096 ../misc/m.nviz.image/args.c:1103
+#: ../misc/m.nviz.image/args.c:1110 ../misc/m.nviz.image/args.c:1122
+#: ../misc/m.nviz.image/args.c:1127 ../misc/m.nviz.image/args.c:1164
+#, c-format
+msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:1146 ../misc/m.nviz.image/args.c:1156
+#, c-format
+msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d, <%s>: %d)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:1171
+#, c-format
+msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d x 6)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:1183
+#, c-format
+msgid "Inconsistent number of attributes (<%s/%s>: %d vs. <%s>: %d, <%s>: %d)"
+msgstr ""
+#: ../misc/m.nviz.image/vector.c:84 ../general/g.region/main.c:474
+#: ../raster/r.walk/main.c:410 ../raster/r.cost/main.c:325
+#: ../raster/r.carve/main.c:158 ../display/d.extract/main.c:98
+#: ../vector/v.lidar.correction/main.c:182 ../vector/v.edit/main.c:153
+#: ../vector/v.profile/main.c:283 ../vector/v.profile/main.c:287
+#: ../vector/v.lrs/v.lrs.segment/main.c:140
+#: ../vector/v.lrs/v.lrs.label/main.c:268
+#: ../vector/v.lrs/v.lrs.create/main.c:251
+#: ../vector/v.lrs/v.lrs.create/main.c:260
+#: ../vector/v.lrs/v.lrs.where/main.c:127
+#: ../vector/v.lrs/v.lrs.where/main.c:136 ../vector/v.lidar.growing/main.c:126
+#: ../vector/v.clean/test/topocheck.c:63
+#: ../vector/v.lidar.edgedetection/main.c:213
+#: ../vector/v.surf.bspline/main.c:258 ../vector/v.surf.bspline/main.c:326
+#: ../vector/v.outlier/main.c:171 ../vector/v.vect.stats/main.c:238
+#: ../vector/v.vect.stats/main.c:246 ../vector/v.colors/main.c:238
+#: ../doc/vector/v.example/main.c:75
#, fuzzy, c-format
-msgid "Unable to open input file <%s>"
+msgid "Vector map <%s> not found"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.support/main.c:248 ../raster/r.support/main.c:245
-#: ../raster/r.statistics/main.c:110 ../display/d.title/main.c:110
+#: ../misc/m.nviz.image/vector.c:280 ../general/manage/lister/vector.c:32
+#: ../raster3d/r3.flow/main.c:411 ../raster/r.random/support.c:63
+#: ../raster/r.drain/main.c:268 ../raster/r.walk/main.c:673
+#: ../raster/r.walk/main.c:742 ../raster/r.cost/main.c:533
+#: ../raster/r.cost/main.c:606 ../raster/r.sim/simlib/observation_points.c:41
+#: ../raster/r.what/main.c:236 ../raster/r.region/main.c:170
+#: ../raster/r.carve/main.c:162 ../display/d.extract/main.c:103
+#: ../display/d.path/main.c:185 ../display/d.vect.chart/main.c:246
+#: ../vector/v.net.spanningtree/main.c:101 ../vector/v.surf.rst/main.c:528
+#: ../vector/v.surf.rst/main.c:632 ../vector/v.what.rast3/main.c:114
+#: ../vector/v.extrude/main.c:190 ../vector/v.extract/main.c:191
+#: ../vector/v.lidar.correction/main.c:186
+#: ../vector/v.net.components/main.c:148 ../vector/v.net.distance/main.c:192
+#: ../vector/v.out.pov/main.c:97 ../vector/v.surf.idw/read_sites.c:29
+#: ../vector/v.segment/main.c:108 ../vector/v.net.flow/main.c:143
+#: ../vector/v.split/main.c:172 ../vector/v.edit/main.c:168
+#: ../vector/v.edit/main.c:240 ../vector/v.random/main.c:199
+#: ../vector/v.profile/main.c:294 ../vector/v.profile/main.c:323
+#: ../vector/v.voronoi/main.c:196 ../vector/v.lrs/v.lrs.segment/main.c:144
+#: ../vector/v.lrs/v.lrs.label/main.c:272
+#: ../vector/v.lrs/v.lrs.create/main.c:254
+#: ../vector/v.lrs/v.lrs.create/main.c:263
+#: ../vector/v.lrs/v.lrs.where/main.c:131
+#: ../vector/v.lrs/v.lrs.where/main.c:140 ../vector/v.kernel/main.c:319
+#: ../vector/v.kernel/main.c:332 ../vector/v.to.rast3/main.c:73
+#: ../vector/v.out.ogr/main.c:129 ../vector/v.type/main.c:131
+#: ../vector/v.net.timetable/main.c:353 ../vector/v.label.sa/labels.c:58
+#: ../vector/v.sample/main.c:124 ../vector/v.build.polylines/main.c:152
+#: ../vector/v.class/main.c:102 ../vector/v.net.alloc/main.c:174
+#: ../vector/v.external/main.c:189 ../vector/v.to.3d/main.c:72
+#: ../vector/v.univar/main.c:158 ../vector/v.out.postgis/main.c:100
+#: ../vector/v.qcount/main.c:101 ../vector/v.out.lidar/main.c:609
+#: ../vector/v.out.ascii/main.c:87 ../vector/v.out.ascii/main.c:94
+#: ../vector/v.lidar.growing/main.c:138 ../vector/v.lidar.growing/main.c:142
+#: ../vector/v.overlay/main.c:188 ../vector/v.net.allpairs/main.c:130
+#: ../vector/v.decimate/main.c:270 ../vector/v.parallel/main.c:148
+#: ../vector/v.rectify/main.c:148 ../vector/v.to.db/main.c:59
+#: ../vector/v.build/main.c:118 ../vector/v.build/main.c:128
+#: ../vector/v.net.connectivity/main.c:130 ../vector/v.vol.rst/main.c:560
+#: ../vector/v.select/main.c:108 ../vector/v.db.select/main.c:164
+#: ../vector/v.to.points/main.c:121 ../vector/v.clean/test/topocheck.c:67
+#: ../vector/v.clean/test/topocheck.c:87 ../vector/v.clean/main.c:283
+#: ../vector/v.lidar.edgedetection/main.c:219 ../vector/v.kriging/main.c:387
+#: ../vector/v.net.bridge/main.c:118 ../vector/v.net.path/main.c:158
+#: ../vector/v.drape/main.c:143 ../vector/v.perturb/main.c:147
+#: ../vector/v.perturb/main.c:172 ../vector/v.info/main.c:60
+#: ../vector/v.patch/main.c:127 ../vector/v.patch/main.c:145
+#: ../vector/v.patch/main.c:175 ../vector/v.patch/main.c:272
+#: ../vector/v.patch/main.c:353 ../vector/v.proj/main.c:231
+#: ../vector/v.net.steiner/main.c:432 ../vector/v.cluster/main.c:147
+#: ../vector/v.delaunay/main.c:120 ../vector/v.reclass/main.c:113
+#: ../vector/v.neighbors/main.c:88 ../vector/v.net.centrality/main.c:209
+#: ../vector/v.out.svg/main.c:139 ../vector/v.net.visibility/main.c:73
+#: ../vector/v.net.visibility/main.c:82 ../vector/v.generalize/main.c:325
+#: ../vector/v.net.iso/main.c:211 ../vector/v.support/main.c:130
+#: ../vector/v.net/main.c:68 ../vector/v.net/main.c:92
+#: ../vector/v.out.dxf/main.c:80 ../vector/v.to.rast/support.c:100
+#: ../vector/v.to.rast/support.c:272 ../vector/v.to.rast/support.c:510
+#: ../vector/v.to.rast/vect2rast.c:39 ../vector/v.what.rast/main.c:131
+#: ../vector/v.net.salesman/main.c:250 ../vector/v.vect.stats/main.c:242
+#: ../vector/v.vect.stats/main.c:253 ../vector/v.transform/main.c:178
+#: ../vector/v.normal/main.c:110 ../vector/v.distance/main.c:310
+#: ../vector/v.distance/main.c:332 ../vector/v.hull/main.c:87
+#: ../vector/v.db.connect/main.c:154 ../vector/v.label/main.c:268
+#: ../vector/v.colors/main.c:262 ../vector/v.colors.out/make_colors.c:23
+#: ../vector/v.colors.out/scan_cats.c:20 ../vector/v.buffer/main.c:338
+#: ../doc/vector/v.example/main.c:87
#, fuzzy, c-format
-msgid "Unable to read category file of raster map <%s>"
+msgid "Unable to open vector map <%s>"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.support/main.c:252 ../raster/r.support/main.c:249
-#, c-format
-msgid "cats table for [%s] set to %s"
-msgstr ""
-#: ../raster3d/r3.support/check.c:20
+#: ../misc/m.nviz.image/vector.c:293 ../raster3d/r3.flow/main.c:46
+#: ../raster/r.to.vect/main.c:187 ../raster/r.random/random.c:73
+#: ../raster/r.volume/main.c:243 ../raster/r.contour/main.c:172
+#: ../display/d.vect/shape.c:44 ../display/d.vect/attr.c:43
+#: ../display/d.vect.thematic/plot1.c:111 ../display/d.vect.chart/plot.c:44
+#: ../vector/v.surf.rst/main.c:587 ../vector/v.what.rast3/main.c:126
+#: ../vector/v.extrude/main.c:229 ../vector/v.extract/main.c:263
+#: ../vector/v.net.components/main.c:180 ../vector/v.net.distance/main.c:279
+#: ../vector/v.surf.idw/read_sites.c:55 ../vector/v.out.vtk/writeVTK.c:649
+#: ../vector/v.net.flow/main.c:169 ../vector/v.edit/select.c:516
+#: ../vector/v.random/main.c:238 ../vector/v.profile/main.c:355
+#: ../vector/v.profile/main.c:462 ../vector/v.lrs/v.lrs.create/main.c:296
+#: ../vector/v.lrs/v.lrs.create/main.c:305 ../vector/v.to.rast3/main.c:84
+#: ../vector/v.out.ogr/main.c:635 ../vector/v.net.timetable/main.c:93
+#: ../vector/v.label.sa/labels.c:78 ../vector/v.in.db/main.c:164
+#: ../vector/v.in.db/main.c:302 ../vector/v.in.dxf/write_vect.c:211
+#: ../vector/v.sample/main.c:179 ../vector/v.class/main.c:117
+#: ../vector/v.in.ascii/main.c:346 ../vector/v.to.3d/trans3.c:57
+#: ../vector/v.to.3d/trans2.c:55 ../vector/v.out.postgis/table.c:34
+#: ../vector/v.mkgrid/main.c:278 ../vector/v.overlay/main.c:246
+#: ../vector/v.overlay/main.c:413 ../vector/v.in.ogr/main.c:1143
+#: ../vector/v.net.allpairs/main.c:166 ../vector/v.to.db/update.c:46
+#: ../vector/v.to.db/query.c:89 ../vector/v.kcv/main.c:126
+#: ../vector/v.vol.rst/user1.c:99 ../vector/v.vol.rst/main.c:600
+#: ../vector/v.select/copy_tabs.c:77 ../vector/v.db.select/main.c:177
+#: ../vector/v.to.points/main.c:167 ../vector/v.kriging/getval.c:54
+#: ../vector/v.surf.bspline/main.c:378 ../vector/v.surf.bspline/crosscorr.c:123
+#: ../vector/v.net.path/path.c:96 ../vector/v.info/print.c:147
+#: ../vector/v.patch/main.c:154 ../vector/v.patch/main.c:186
+#: ../vector/v.patch/main.c:307 ../vector/v.patch/main.c:389
+#: ../vector/v.in.dwg/main.c:213 ../vector/v.reclass/main.c:133
+#: ../vector/v.net.centrality/main.c:246 ../vector/v.out.svg/main.c:159
+#: ../vector/v.to.rast/support.c:109 ../vector/v.to.rast/support.c:284
+#: ../vector/v.to.rast/support.c:523 ../vector/v.to.rast/vect2rast.c:60
+#: ../vector/v.what.rast/main.c:144 ../vector/v.transform/trans_digit.c:40
+#: ../vector/v.normal/main.c:122 ../vector/v.distance/main.c:464
+#: ../vector/v.distance/main.c:499 ../vector/v.distance/main.c:545
+#: ../vector/v.distance/main.c:1274 ../vector/v.distance/main.c:1295
+#: ../vector/v.db.connect/main.c:223 ../vector/v.db.connect/main.c:331
+#: ../vector/v.label/main.c:278 ../vector/v.colors/scan_attr.c:29
+#: ../vector/v.colors/read_rgb.c:28 ../vector/v.colors/write_rgb.c:25
+#: ../vector/v.colors.out/make_colors.c:36 ../vector/v.buffer/main.c:417
+#: ../doc/vector/v.example/main.c:131 ../ps/ps.map/catval.c:53
+#: ../ps/ps.map/catval.c:115 ../ps/ps.map/catval.c:181
#, fuzzy, c-format
-msgid "Updating statistics for <%s>"
+msgid "Unable to open database <%s> by driver <%s>"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.support/check.c:36
+#: ../misc/m.nviz.image/vector.c:300 ../misc/m.nviz.image/vector.c:309
+#: ../misc/m.nviz.image/vector.c:319 ../misc/m.nviz.image/vector.c:329
#, fuzzy, c-format
-msgid "Updating the number of categories for <%s>"
+msgid "Column <%s> in table <%s> not found"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.null/main.c:55
+#: ../misc/m.nviz.image/vector.c:304
#, fuzzy
-msgid "3D raster map for which to modify null values"
+msgid "Data type of color column must be character"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.null/main.c:63 ../raster/r.null/main.c:73
-msgid "List of cell values to be set to NULL"
+#: ../misc/m.nviz.image/vector.c:314
+msgid "Data type of size column must be numeric"
msgstr ""
-#: ../raster3d/r3.null/main.c:70 ../raster/r.null/main.c:81
-msgid "The value to replace the null value by"
+#: ../misc/m.nviz.image/vector.c:324
+msgid "Data type of width column must be numeric"
msgstr ""
-#: ../raster3d/r3.null/main.c:85
-msgid "Illegal value for null"
+#: ../misc/m.nviz.image/vector.c:335
+msgid "Data type of marker column must be character"
msgstr ""
-#: ../raster3d/r3.null/main.c:122
-msgid "modifyNull: error opening tmp file"
+#: ../misc/m.nviz.image/main.c:56
+msgid "Creates a 3D rendering of GIS data."
msgstr ""
-#: ../raster3d/r3.null/main.c:156
-msgid "modifyNull: error flushing tiles in cube"
+#: ../misc/m.nviz.image/main.c:57
+msgid ""
+"Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
+"data) in 3D."
msgstr ""
-#: ../raster3d/r3.null/main.c:161
-msgid "modifyNull: error flushing all tiles"
+#: ../misc/m.nviz.image/main.c:83
+#, fuzzy
+msgid "Unable to render data"
+msgstr "출력할 격자지도"
+#: ../misc/m.nviz.image/main.c:142
+#, c-format
+msgid "Vertical exaggeration not given, using calculated value %.0f"
msgstr ""
-#: ../raster3d/r3.null/main.c:171
+#: ../misc/m.nviz.image/main.c:154
+#, c-format
+msgid "Viewpoint height not given, using calculated value %.0f"
+msgstr ""
+#: ../misc/m.nviz.image/main.c:240
#, fuzzy
-msgid "modifyNull: Unable to close tmp file"
+msgid "Unsupported output format"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.null/main.c:187 ../raster/r.null/main.c:61
-#, fuzzy
-msgid "null data"
+#: ../misc/m.nviz.image/main.c:242 ../imagery/i.cluster/main.c:354
+#, fuzzy, c-format
+msgid "File <%s> created."
msgstr "출력할 격자지도"
-#: ../raster3d/r3.null/main.c:190
-msgid "Explicitly create the 3D NULL-value bitmap file."
-msgstr ""
+#: ../misc/m.nviz.image/volume.c:42 ../misc/m.nviz.image/volume.c:133
+#, fuzzy, c-format
+msgid "3d raster map <%s> not found"
+msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/string_list.c:47
-#: ../raster/r.in.lidar/string_list.c:34
+#: ../misc/m.nviz.image/volume.c:96 ../misc/m.nviz.image/volume.c:256
#, fuzzy, c-format
-msgid "Cannot open file %s for reading"
+msgid "Error tokenize '%s'"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/filters.c:27
+#: ../misc/m.nviz.image/volume.c:103 ../misc/m.nviz.image/volume.c:271
#, fuzzy, c-format
-msgid "Invalid range <%s> for option %s"
+msgid "Volume set number %d is not available"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/filters.c:54 ../vector/v.in.pdal/filters.c:95
-#: ../vector/v.in.lidar/filters.c:36
+#: ../misc/m.nviz.image/volume.c:108
#, fuzzy, c-format
-msgid "Unknown return filter value <%s>"
+msgid "Unable to add isosurface (volume set %d)"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:164 ../raster/r.in.lidar/main.c:110
-#: ../raster/r.in.xyz/main.c:165
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:5
-#: ../vector/v.out.lidar/main.c:473 ../vector/v.decimate/main.c:124
-#: ../vector/v.lidar.growing/main.c:76 ../vector/v.in.lidar/main.c:138
-#: ../vector/v.surf.bspline/main.c:94
-#: ../vector/v.lidar.edgedetection/main.c:73 ../vector/v.outlier/main.c:74
-#: ../vector/v.lidar.correction/main.c:69
-msgid "LIDAR"
-msgstr ""
+#: ../misc/m.nviz.image/volume.c:119 ../misc/m.nviz.image/volume.c:140
+#: ../misc/m.nviz.image/volume.c:153 ../misc/m.nviz.image/volume.c:172
+#: ../misc/m.nviz.image/volume.c:182 ../misc/m.nviz.image/volume.c:195
+#: ../misc/m.nviz.image/volume.c:205
+#, fuzzy, c-format
+msgid "Unable to set isosurface (%d) attribute (%d) of volume %d"
+msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:167 ../raster3d/r3.neighbors/main.c:212
-#: ../raster/r.in.lidar/main.c:113 ../raster/r.in.xyz/main.c:162
-#: ../raster/r.series/main.c:138 ../raster/r.neighbors/main.c:170
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:4
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:3
-#: ../vector/v.neighbors/main.c:54
-msgid "aggregation"
-msgstr "합산"
+#: ../misc/m.nviz.image/volume.c:267
+#, fuzzy, c-format
+msgid "Wrong name for axis: %s"
+msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:168 ../raster/r.in.lidar/main.c:114
-#: ../raster/r.in.xyz/main.c:163
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:9
-#, fuzzy
-msgid "binning"
+#: ../misc/m.nviz.image/volume.c:276
+#, fuzzy, c-format
+msgid "Unable to add slice (volume set %d)"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:170
-#, fuzzy
-msgid ""
-"Creates a 3D raster map from LAS LiDAR points using univariate statistics."
+#: ../misc/m.nviz.image/volume.c:288
+#, fuzzy, c-format
+msgid "Unable to set slice (%d) position of volume %d"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:174 ../raster/r.in.lidar/main.c:120
-#: ../vector/v.in.lidar/main.c:142
-#, fuzzy
-msgid "LAS input file"
+#: ../misc/m.nviz.image/volume.c:294
+#, fuzzy, c-format
+msgid "Unable to set slice (%d) transparency of volume %d"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:176
-msgid "LiDAR input file in LAS format (*.las or *.laz)"
-msgstr ""
+#: ../misc/m.nviz.image/cplane.c:40
+#, fuzzy, c-format
+msgid "Cutting plane number <%d> not found"
+msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:177 ../raster3d/r3.in.lidar/main.c:184
-#: ../raster3d/r3.flow/main.c:188 ../raster3d/r3.flow/main.c:195
-#: ../raster3d/r3.flow/main.c:205 ../raster/r.sim/r.sim.sediment/main.c:157
-#: ../raster/r.sim/r.sim.sediment/main.c:165
-#: ../raster/r.sim/r.sim.sediment/main.c:172
-#: ../raster/r.sim/r.sim.water/main.c:138
-#: ../raster/r.sim/r.sim.water/main.c:147
-#: ../raster/r.sim/r.sim.water/main.c:154
-#: ../raster/r.sim/r.sim.water/main.c:163
-#: ../raster/r.sim/r.sim.water/main.c:169
-#: ../raster/r.sim/r.sim.water/main.c:177
-#: ../raster/r.sim/r.sim.water/main.c:184
-#: ../raster/r.sim/r.sim.water/main.c:191 ../raster/r.sun/main.c:260
-#: ../raster/r.sun/main.c:269 ../raster/r.sun/main.c:278
-#: ../raster/r.sun/main.c:287 ../raster/r.sun/main.c:295
-#: ../raster/r.sun/main.c:304 ../raster/r.sun/main.c:313
-#: ../raster/r.sun/main.c:322 ../raster/r.sun/main.c:331
-#: ../raster/r.sun/main.c:340 ../raster/r.sun/main.c:349
-#: ../raster/r.sun/main.c:358 ../raster/r.sun/main.c:367
-#: ../raster/r.sun/main.c:374 ../raster/r.sun/main.c:382
-#: ../raster/r.spread/main.c:125 ../raster/r.spread/main.c:139
-#: ../raster/r.spread/main.c:151 ../raster/r.spread/main.c:164
-#: ../raster/r.spread/main.c:177 ../raster/r.spread/main.c:189
-#: ../raster/r.spread/main.c:201 ../raster/r.in.lidar/main.c:122
-#: ../raster/r.in.lidar/main.c:133 ../raster/r.horizon/main.c:195
-#: ../raster/r.horizon/main.c:204 ../raster/r.horizon/main.c:212
-#: ../raster/r.in.xyz/main.c:217 ../raster/r.in.xyz/main.c:226
-#: ../raster/r.in.xyz/main.c:234 ../raster/r.in.xyz/main.c:245
-#: ../raster/r.in.xyz/main.c:255 ../raster/r.external/main.c:66
-#: ../raster/r.external/main.c:74 ../raster/r.external/main.c:83
-#: ../locale/scriptstrings/v.import_to_translate.c:6
-#: ../locale/scriptstrings/v.import_to_translate.c:8
-#: ../locale/scriptstrings/i.spectral_to_translate.c:6
-#: ../locale/scriptstrings/i.spectral_to_translate.c:7
-#: ../locale/scriptstrings/i.spectral_to_translate.c:8
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:18
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:20
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:22
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:24
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:27
-#: ../locale/scriptstrings/r.import_to_translate.c:6
-#: ../locale/scriptstrings/r.import_to_translate.c:8
-#: ../locale/scriptstrings/t.register_to_translate.c:6
-#: ../locale/scriptstrings/t.register_to_translate.c:7
-#: ../locale/scriptstrings/t.register_to_translate.c:9
-#: ../locale/scriptstrings/t.register_to_translate.c:12
-#: ../locale/scriptstrings/t.register_to_translate.c:26
-#: ../locale/scriptstrings/t.remove_to_translate.c:6
-#: ../locale/scriptstrings/t.remove_to_translate.c:9
-#: ../locale/scriptstrings/t.remove_to_translate.c:11
-#: ../display/d.text/main.c:148 ../display/d.text/main.c:153
-#: ../display/d.legend/main.c:88 ../display/d.legend/main.c:93
-#: ../vector/v.edit/args.c:90 ../vector/v.edit/args.c:209
-#: ../vector/v.in.ogr/main.c:160
-msgid "Input"
-msgstr "입력"
-#: ../raster3d/r3.in.lidar/main.c:181 ../raster/r.in.lidar/main.c:130
+#: ../visualization/ximgview/main.c:64 ../general/g.cairocomp/main.c:89
+#: ../general/g.cairocomp/main.c:256
#, fuzzy
-msgid "File containing names of LAS input files"
+msgid "Unable to open display"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:182 ../raster/r.in.lidar/main.c:121
-#: ../raster/r.in.lidar/main.c:131 ../vector/v.in.lidar/main.c:143
-msgid "LiDAR input files in LAS format (*.las or *.laz)"
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:189
+#: ../visualization/ximgview/main.c:84
#, fuzzy
-msgid "Count of points per cell"
+msgid "Unable to get window attributes"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:190 ../raster3d/r3.in.lidar/main.c:196
-#: ../raster3d/r3.in.lidar/main.c:202 ../raster3d/r3.flow/main.c:211
-#: ../raster3d/r3.flow/main.c:218 ../raster/r.sim/r.sim.sediment/main.c:178
-#: ../raster/r.sim/r.sim.sediment/main.c:185
-#: ../raster/r.sim/r.sim.sediment/main.c:192
-#: ../raster/r.sim/r.sim.sediment/main.c:198
-#: ../raster/r.sim/r.sim.sediment/main.c:205
-#: ../raster/r.sim/r.sim.sediment/main.c:212
-#: ../raster/r.sim/r.sim.sediment/main.c:219
-#: ../raster/r.sim/r.sim.water/main.c:197
-#: ../raster/r.sim/r.sim.water/main.c:203
-#: ../raster/r.sim/r.sim.water/main.c:209
-#: ../raster/r.sim/r.sim.water/main.c:216
-#: ../raster/r.sim/r.sim.water/main.c:223
-#: ../raster/r.sim/r.sim.water/main.c:298 ../raster/r.sun/main.c:391
-#: ../raster/r.sun/main.c:400 ../raster/r.sun/main.c:409
-#: ../raster/r.sun/main.c:418 ../raster/r.sun/main.c:427
-#: ../raster/r.sun/main.c:436 ../raster/r.spread/main.c:277
-#: ../raster/r.spread/main.c:289 ../raster/r.spread/main.c:301
-#: ../raster/r.in.lidar/main.c:126 ../raster/r.in.lidar/main.c:252
-#: ../raster/r.in.lidar/main.c:285 ../raster/r.in.lidar/main.c:294
-#: ../raster/r.grow.distance/main.c:162 ../raster/r.grow.distance/main.c:168
-#: ../raster/r.resamp.rst/main.c:174 ../raster/r.resamp.rst/main.c:180
-#: ../raster/r.resamp.rst/main.c:186 ../raster/r.resamp.rst/main.c:192
-#: ../raster/r.resamp.rst/main.c:198 ../raster/r.resamp.rst/main.c:204
-#: ../raster/r.resamp.rst/main.c:264 ../raster/r.lake/main.c:167
-#: ../raster/r.lake/main.c:195
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:8
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:10
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:13
-#: ../locale/scriptstrings/v.import_to_translate.c:10
-#: ../locale/scriptstrings/v.import_to_translate.c:13
-#: ../locale/scriptstrings/v.import_to_translate.c:16
-#: ../locale/scriptstrings/v.import_to_translate.c:19
-#: ../locale/scriptstrings/i.spectral_to_translate.c:10
-#: ../locale/scriptstrings/i.spectral_to_translate.c:12
-#: ../locale/scriptstrings/m.proj_to_translate.c:11
-#: ../locale/scriptstrings/m.proj_to_translate.c:23
-#: ../locale/scriptstrings/m.proj_to_translate.c:25
-#: ../locale/scriptstrings/m.proj_to_translate.c:27
-#: ../locale/scriptstrings/r.import_to_translate.c:12
-#: ../locale/scriptstrings/r.import_to_translate.c:15
-#: ../locale/scriptstrings/r.import_to_translate.c:18
-#: ../locale/scriptstrings/r.import_to_translate.c:21
-#: ../locale/scriptstrings/r.import_to_translate.c:23
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:7
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:9
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:11
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:14
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:16
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:18
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:20
-#: ../vector/v.in.ogr/main.c:165 ../vector/v.in.ogr/main.c:220
-#: ../vector/v.in.ogr/main.c:270 ../vector/v.in.ogr/main.c:276
-#: ../vector/v.in.ogr/main.c:318 ../vector/v.out.ascii/args.c:35
-#: ../vector/v.out.ascii/args.c:81
-msgid "Output"
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:195
+#: ../visualization/ximgview/main.c:258
#, fuzzy
-msgid "Sum of values of point intensities per cell"
+msgid "Unable to open image file"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:201
-msgid "Mean of point intensities per cell"
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:209
+#: ../visualization/ximgview/main.c:261
#, fuzzy
-msgid "3D raster map of proportional point count"
+msgid "Unable to read BMP header"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:211
-msgid "Point count per 3D cell divided by point count per vertical column"
+#: ../visualization/ximgview/main.c:264
+msgid "Invalid BMP header"
msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:213 ../raster3d/r3.in.lidar/main.c:223
+#: ../visualization/ximgview/main.c:270
#, fuzzy
-msgid "Proportional output"
+msgid "Unable to map image file"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:219
-#, fuzzy
-msgid "3D raster map of proportional sum of values"
-msgstr "출력할 격자지도"
+#: ../visualization/ximgview/main.c:290 ../general/g.cairocomp/main.c:197
+#: ../general/g.pnmcomp/main.c:283 ../general/g.ppmtopng/main.c:118
+#: ../locale/scriptstrings/d.shade_to_translate.c:2
+#: ../locale/scriptstrings/d.redraw_to_translate.c:2
+#: ../locale/scriptstrings/d.frame_to_translate.c:2
+#: ../locale/scriptstrings/d.out.file_to_translate.c:2
+#: ../locale/scriptstrings/d.correlate_to_translate.c:2
+#: ../locale/scriptstrings/d.what.vect_to_translate.c:2
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:2
+#: ../locale/scriptstrings/d.to.rast_to_translate.c:2
+#: ../locale/scriptstrings/d.polar_to_translate.c:2
+#: ../locale/scriptstrings/wxpyimgview_to_translate.c:2
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:2
+#: ../locale/scriptstrings/d.what.rast_to_translate.c:2
+#: ../raster3d/r3.mkdspf/main.c:80 ../display/d.his/main.c:62
+#: ../display/d.colortable/main.c:60 ../display/d.labels/main.c:43
+#: ../display/d.rast.arrow/main.c:97 ../display/d.geodesic/main.c:46
+#: ../display/d.mon/main.c:38 ../display/d.rast/main.c:53
+#: ../display/d.font/main.c:45 ../display/d.vect/main.c:73
+#: ../display/d.graph/main.c:58 ../display/d.extract/main.c:49
+#: ../display/d.rast.num/main.c:77 ../display/d.legend/main.c:78
+#: ../display/d.barscale/main.c:63 ../display/d.colorlist/main.c:35
+#: ../display/d.vect.thematic/main.c:85 ../display/d.rhumbline/main.c:44
+#: ../display/d.grid/main.c:53 ../display/d.legend.vect/main.c:50
+#: ../display/d.profile/main.c:191 ../display/d.path/main.c:48
+#: ../display/d.vect.chart/main.c:63 ../display/d.info/main.c:34
+#: ../display/d.histogram/main.c:83 ../display/d.text/main.c:138
+#: ../display/d.fontlist/main.c:45 ../display/d.erase/main.c:29
+#: ../display/d.where/main.c:43 ../display/d.title/main.c:49
+#: ../display/d.northarrow/main.c:46 ../display/d.linegraph/main.c:229
+#: ../display/d.rgb/main.c:53
+msgid "display"
+msgstr "화면"
-#: ../raster3d/r3.in.lidar/main.c:221
-msgid "Sum of values per 3D cell divided by sum of values per vertical column"
+#: ../visualization/ximgview/main.c:295
+msgid "View BMP images from the PNG driver."
msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:229 ../raster/r.in.lidar/main.c:258
-#: ../vector/v.in.lidar/main.c:201
-msgid "Only import points of selected return type"
+#: ../visualization/ximgview/main.c:301
+msgid "Image file"
msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:230 ../raster/r.in.lidar/main.c:259
-#: ../vector/v.in.lidar/main.c:202
-msgid "If not specified, all points are imported"
+#: ../visualization/ximgview/main.c:308
+#: ../locale/scriptstrings/wxpyimgview_to_translate.c:6
+msgid "Percentage of CPU time to use"
msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:232 ../raster3d/r3.in.lidar/main.c:242
-#: ../raster3d/r3.in.lidar/main.c:272 ../raster3d/r3.in.lidar/main.c:288
-#: ../raster/r.in.lidar/main.c:192 ../raster/r.in.lidar/main.c:208
-#: ../raster/r.in.lidar/main.c:261 ../raster/r.in.lidar/main.c:271
-#: ../raster/r.in.lidar/main.c:339 ../raster/r.category/main.c:62
-#: ../raster/r.category/main.c:71
-#: ../locale/scriptstrings/t.list_to_translate.c:7
-#: ../locale/scriptstrings/t.list_to_translate.c:8
-#: ../locale/scriptstrings/t.list_to_translate.c:14
-#: ../locale/scriptstrings/t.list_to_translate.c:15
-#: ../locale/scriptstrings/v.report_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:6
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:10
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:11
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:10
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:11
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:11
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:7
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:6
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:7
-#: ../display/d.vect.chart/main.c:74 ../display/d.vect.chart/main.c:77
-#: ../display/d.vect.thematic/main.c:98 ../display/d.vect.thematic/main.c:148
-#: ../display/d.vect/main.c:83 ../display/d.vect/main.c:108
-#: ../display/d.vect/main.c:111 ../display/d.vect/main.c:114
-#: ../display/d.vect/main.c:316 ../display/d.rast/main.c:70
-#: ../display/d.rast/main.c:87 ../vector/v.reclass/main.c:77
-#: ../vector/v.reclass/main.c:82 ../vector/v.extract/main.c:98
-#: ../vector/v.extract/main.c:103 ../vector/v.extract/main.c:109
-#: ../vector/v.extract/main.c:112 ../vector/v.extract/main.c:115
-#: ../vector/v.extract/main.c:125 ../vector/v.extract/main.c:135
-#: ../vector/v.out.lidar/main.c:487 ../vector/v.out.lidar/main.c:491
-#: ../vector/v.out.lidar/main.c:588 ../vector/v.net.centrality/main.c:121
-#: ../vector/v.net.centrality/main.c:123 ../vector/v.drape/main.c:67
-#: ../vector/v.drape/main.c:70 ../vector/v.drape/main.c:73
-#: ../vector/v.drape/main.c:78 ../vector/v.decimate/main.c:147
-#: ../vector/v.decimate/main.c:150 ../vector/v.net.allpairs/main.c:75
-#: ../vector/v.net.allpairs/main.c:81 ../vector/v.net.allpairs/main.c:84
-#: ../vector/v.net.allpairs/main.c:87 ../vector/v.generalize/main.c:92
-#: ../vector/v.generalize/main.c:231 ../vector/v.generalize/main.c:234
-#: ../vector/v.in.lidar/main.c:185 ../vector/v.in.lidar/main.c:195
-#: ../vector/v.in.lidar/main.c:204 ../vector/v.in.lidar/main.c:214
-#: ../vector/v.in.lidar/main.c:221 ../vector/v.in.lidar/main.c:226
-#: ../vector/v.in.lidar/main.c:281 ../vector/v.in.lidar/main.c:287
-#: ../vector/v.in.lidar/main.c:295 ../vector/v.surf.rst/main.c:172
-#: ../vector/v.surf.rst/main.c:184 ../vector/v.clean/main.c:61
-#: ../vector/v.clean/main.c:64 ../vector/v.category/main.c:85
-#: ../vector/v.category/main.c:89 ../vector/v.category/main.c:93
-#: ../vector/v.in.db/main.c:94 ../vector/v.edit/args.c:24
-#: ../vector/v.edit/args.c:29 ../vector/v.edit/args.c:112
-#: ../vector/v.edit/args.c:116 ../vector/v.edit/args.c:125
-#: ../vector/v.edit/args.c:134 ../vector/v.edit/args.c:143
-#: ../vector/v.edit/args.c:146 ../vector/v.edit/args.c:164
-#: ../vector/v.edit/args.c:199 ../vector/v.out.ogr/args.c:12
-#: ../vector/v.out.ogr/args.c:22 ../vector/v.out.ogr/args.c:104
-#: ../vector/v.in.ogr/main.c:174 ../vector/v.in.ogr/main.c:179
-#: ../vector/v.in.ogr/main.c:188 ../vector/v.in.ogr/main.c:204
-#: ../vector/v.in.ogr/main.c:252 ../vector/v.in.ogr/main.c:297
-#: ../vector/v.to.points/main.c:67 ../vector/v.to.points/main.c:71
-#: ../vector/v.buffer/main.c:235 ../vector/v.buffer/main.c:238
-#: ../vector/v.buffer/main.c:241 ../vector/v.buffer/main.c:246
-#: ../vector/v.random/main.c:117 ../vector/v.random/main.c:120
-#: ../vector/v.random/main.c:123 ../vector/v.random/main.c:126
-#: ../vector/v.out.ascii/args.c:24 ../vector/v.out.ascii/args.c:28
-#: ../vector/v.out.ascii/args.c:43 ../vector/v.out.ascii/args.c:46
-#: ../vector/v.select/args.c:18 ../vector/v.select/args.c:24
-#: ../vector/v.select/args.c:33 ../vector/v.select/args.c:39
-#: ../vector/v.select/args.c:106 ../vector/v.out.postgis/args.c:15
-#: ../vector/v.out.postgis/args.c:19 ../vector/v.to.rast/main.c:57
-#: ../vector/v.to.rast/main.c:60 ../vector/v.to.rast/main.c:63
-#: ../vector/v.to.db/parse.c:45 ../vector/v.db.select/main.c:64
-#: ../vector/v.db.select/main.c:67 ../vector/v.db.select/main.c:70
-#: ../vector/v.db.select/main.c:76 ../vector/v.db.select/main.c:116
-#: ../vector/v.to.3d/args.c:19 ../vector/v.to.3d/args.c:25
-#: ../vector/v.extrude/main.c:84 ../vector/v.extrude/main.c:87
-#: ../vector/v.extrude/main.c:90 ../vector/v.extrude/main.c:95
-#, fuzzy
-msgid "Selection"
-msgstr "출력할 격자지도"
+#: ../visualization/ximgview/color.c:90 ../visualization/ximgview/color.c:288
+#, c-format
+msgid "Unknown visual class [%d]."
+msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:239 ../raster/r.in.lidar/main.c:268
-#: ../vector/v.in.lidar/main.c:211
-msgid "Only import points of selected class(es)"
+#: ../visualization/ximgview/color.c:239
+msgid "Unable to get sufficient gray shades."
msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:240 ../raster/r.in.lidar/main.c:269
-#: ../vector/v.in.lidar/main.c:212
-msgid ""
-"Input is comma separated integers. If not specified, all points are imported."
+#: ../visualization/ximgview/color.c:256
+msgid "Unable to get sufficient colors."
msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:248
-#, fuzzy
-msgid "Subtract raster values from the z coordinates"
-msgstr "출력할 격자지도"
+#: ../visualization/ximgview/color.c:269
+msgid "Using private colormap for DirectColor visual."
+msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:250
-msgid "The scale for z is applied beforehand, the filter afterwards"
+#: ../general/g.findfile/element.c:7
+msgid "List of available elements:"
msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:251 ../raster3d/r3.in.lidar/main.c:264
-#: ../raster3d/r3.in.lidar/main.c:280 ../raster/r.in.lidar/main.c:184
-#: ../raster/r.in.lidar/main.c:200 ../raster/r.in.lidar/main.c:216
+#: ../general/g.findfile/main.c:38 ../general/g.cairocomp/main.c:196
+#: ../general/g.gui/main.c:39 ../general/g.dirseps/main.c:34
+#: ../general/g.version/main.c:65 ../general/g.remove/main.c:69
+#: ../general/g.mapset/main.c:49 ../general/g.pnmcomp/main.c:282
+#: ../general/g.list/main.c:65 ../general/g.setproj/main.c:78
+#: ../general/g.mapsets/main.c:63 ../general/g.rename/main.c:45
+#: ../general/g.region/main.c:64 ../general/g.proj/main.c:64
+#: ../general/g.mkfontcap/main.c:71 ../general/g.findetc/main.c:28
+#: ../general/g.ppmtopng/main.c:117 ../general/g.filename/main.c:39
+#: ../general/g.tempfile/main.c:38 ../general/g.copy/main.c:41
+#: ../general/g.message/main.c:33 ../general/g.access/main.c:37
+#: ../general/g.gisenv/main.c:43
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:2
+#: ../locale/scriptstrings/g.extension.all_to_translate.c:3
+#: ../locale/scriptstrings/g.extension_to_translate.c:3
+#: ../locale/scriptstrings/g.manual_to_translate.c:2
+msgid "general"
+msgstr "일반"
+#: ../general/g.findfile/main.c:39 ../general/g.dirseps/main.c:35
+#: ../general/g.remove/main.c:70 ../general/g.list/main.c:66
+#: ../general/g.rename/main.c:46 ../general/g.findetc/main.c:29
+#: ../general/g.filename/main.c:40 ../general/g.copy/main.c:42
+#: ../general/g.access/main.c:38
+#: ../locale/scriptstrings/t.rename_to_translate.c:3
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:3
+#: ../locale/scriptstrings/t.list_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:3
+#: ../locale/scriptstrings/t.create_to_translate.c:3
+#: ../locale/scriptstrings/t.unregister_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:3
+#: ../locale/scriptstrings/t.remove_to_translate.c:3
+#: ../locale/scriptstrings/t.register_to_translate.c:3
+#: ../raster/r.compress/main.c:65 ../imagery/i.target/main.c:46
+#: ../imagery/i.group/main.c:53
+msgid "map management"
+msgstr "지도관리"
+#: ../general/g.findfile/main.c:40 ../general/g.dirseps/main.c:36
+#: ../general/g.findetc/main.c:30 ../general/g.filename/main.c:41
+#: ../general/g.tempfile/main.c:40 ../general/g.message/main.c:35
+#: ../general/g.gisenv/main.c:46
#, fuzzy
-msgid "Transform"
+msgid "scripts"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:256
-msgid "Use base raster actual resolution instead of computational region"
+#: ../general/g.findfile/main.c:42
+msgid "Searches for GRASS data base files and sets variables for the shell."
msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:263 ../raster/r.in.lidar/main.c:199
+#: ../general/g.findfile/main.c:53 ../general/g.filename/main.c:50
+msgid "Name of an element"
+msgstr ""
+#: ../general/g.findfile/main.c:59
#, fuzzy
-msgid "Scale to apply to Z data"
+msgid "Name of an existing map"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:271 ../raster/r.in.lidar/main.c:207
-msgid "Filter range for intensity values (min,max)"
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:279 ../raster/r.in.lidar/main.c:215
+#: ../general/g.findfile/main.c:65
#, fuzzy
-msgid "Scale to apply to intensity values"
+msgid "Name of a mapset (default: search path)"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:284 ../raster/r.in.lidar/main.c:335
-#: ../vector/v.in.lidar/main.c:291
+#: ../general/g.findfile/main.c:66
#, fuzzy
-msgid "Use only valid points"
+msgid "'.' for current mapset"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:286 ../raster/r.in.lidar/main.c:337
-#: ../vector/v.in.lidar/main.c:293
-msgid ""
-"Points invalid according to APSRS LAS specification will be filtered out"
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:293 ../raster/r.in.lidar/main.c:299
-#: ../raster/r.external/main.c:102 ../raster/r.in.gdal/main.c:178
-#: ../locale/scriptstrings/v.import_to_translate.c:27
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:17
-#: ../locale/scriptstrings/v.unpack_to_translate.c:9
-#: ../locale/scriptstrings/r.import_to_translate.c:31
-#: ../locale/scriptstrings/r.unpack_to_translate.c:8
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:13
-#: ../vector/v.in.lidar/main.c:319 ../vector/v.in.ogr/main.c:284
-#: ../vector/v.external/args.c:43
-msgid "Override projection check (use current location's projection)"
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:295 ../raster/r.in.lidar/main.c:301
-#: ../raster/r.external/main.c:104 ../raster/r.in.gdal/main.c:180
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:18
-#: ../locale/scriptstrings/v.unpack_to_translate.c:10
-#: ../locale/scriptstrings/r.unpack_to_translate.c:9
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:14
-#: ../vector/v.in.lidar/main.c:321
+#: ../general/g.findfile/main.c:70
#, fuzzy
-msgid "Assume that the dataset has same projection as the current location"
+msgid "Do not add quotes"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:299 ../raster/r.in.lidar/main.c:276
-#: ../vector/v.in.lidar/main.c:276
-msgid "Print LAS file info and exit"
+#: ../general/g.findfile/main.c:74
+msgid "List available elements and exit"
msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:303 ../raster/r.in.lidar/main.c:305
-#: ../raster/r.in.xyz/main.c:327
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:10
-msgid "Scan data file for extent then exit"
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:307 ../raster/r.in.lidar/main.c:310
-#: ../raster/r.in.xyz/main.c:332
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:11
-msgid "In scan mode, print using shell script style"
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:329
+#: ../general/g.findfile/main.c:97
#, c-format
-msgid "%s will not be taken into account during scan"
+msgid ""
+"Parameter 'file' contains reference to <%s> mapset, but mapset parameter <"
+"%s> does not correspond"
msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:340 ../raster/r.in.lidar/main.c:367
+#: ../general/g.cairocomp/main.c:46 ../raster3d/r3.support/main.c:167
+#: ../raster/r.in.xyz/main.c:573 ../raster/r.series.accumulate/main.c:221
+#: ../raster/r.series/main.c:223 ../raster/r.in.mat/main.c:125
+#: ../raster/r.mapcalc/main.c:48 ../raster/r.support/main.c:176
+#: ../raster/r.topmodel/file_io.c:28 ../raster/r.topmodel/file_io.c:136
+#: ../raster/r.topmodel/file_io.c:161 ../display/d.legend.vect/main.c:259
+#: ../display/d.legend.vect/main.c:273 ../display/d.legend.vect/draw.c:72
+#: ../display/d.text/main.c:382 ../display/d.where/main.c:163
+#: ../display/d.linegraph/main.c:391 ../display/d.linegraph/main.c:407
+#: ../display/d.linegraph/main.c:669 ../vector/v.segment/main.c:98
+#: ../vector/v.lrs/v.lrs.segment/main.c:133 ../vector/v.net.path/path.c:49
#, fuzzy, c-format
-msgid "File <%s> does not exist"
+msgid "Unable to open input file <%s>"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:374 ../raster/r.in.lidar/main.c:397
-#: ../vector/v.in.lidar/main.c:347
+#: ../general/g.cairocomp/main.c:49
#, fuzzy, c-format
-msgid "Input file <%s> does not exist"
+msgid "Unable to read input file <%s>"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:378 ../raster/r.in.lidar/main.c:401
-#: ../vector/v.in.lidar/main.c:352
+#: ../general/g.cairocomp/main.c:52
#, fuzzy, c-format
-msgid "Unable to open file <%s> as a LiDAR point cloud"
+msgid "Unable to parse input file <%s>"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:382 ../raster/r.in.lidar/main.c:405
-#: ../vector/v.in.lidar/main.c:356
-#, fuzzy, c-format
-msgid "Unable to read LAS header of <%s>"
-msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:398 ../raster/r.in.lidar/main.c:421
-msgid ""
-"First file's projection checked, checking projection of the other files..."
+#: ../general/g.cairocomp/main.c:66 ../raster3d/r3.support/main.c:153
+#: ../raster/r.out.png/main.c:205 ../raster/r.out.pov/main.c:173
+#: ../raster/r.out.mat/main.c:91 ../raster/r.out.vrml/main.c:131
+#: ../raster/r.colors.out/raster3d_main.c:80
+#: ../raster/r.colors.out/raster_main.c:79 ../raster/r.support/main.c:162
+#: ../vector/v.colors.out/main.c:103
+#, c-format
+msgid "Unable to open output file <%s>"
msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:540
-#, fuzzy
-msgid "Preparing the maps..."
+#: ../general/g.cairocomp/main.c:71
+#, fuzzy, c-format
+msgid "Unable to write output file <%s>"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:574 ../vector/v.sample/main.c:200
+#: ../general/g.cairocomp/main.c:113
#, fuzzy
-msgid "Reading points..."
+msgid "Unable to obtain visual"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:656
+#: ../general/g.cairocomp/main.c:129
#, fuzzy
-msgid "Computing proportional count map..."
+msgid "Failed to initialize output surface"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:661
+#: ../general/g.cairocomp/main.c:150 ../general/g.pnmcomp/main.c:38
+#, c-format
+msgid "Invalid color: %s"
+msgstr ""
+#: ../general/g.cairocomp/main.c:171
#, fuzzy
-msgid "Computing proportional sum map..."
+msgid "Failed to initialize input surface"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:666
+#: ../general/g.cairocomp/main.c:198
#, fuzzy
-msgid "Computing mean map..."
+msgid "Overlays multiple X Pixmaps."
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:671
+#: ../general/g.cairocomp/main.c:203 ../general/g.pnmcomp/main.c:290
#, fuzzy
-msgid "Closing the maps..."
+msgid "Name of input file(s)"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.lidar/main.c:707 ../vector/v.in.lidar/main.c:783
-#, c-format
-msgid "%lu input points were not valid and filtered out"
+#: ../general/g.cairocomp/main.c:212
+msgid "Output Visual XID"
msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:710 ../vector/v.in.lidar/main.c:789
-#, c-format
-msgid "%lu input points were filtered out by return number"
+#: ../general/g.cairocomp/main.c:218
+msgid "Output screen"
msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:712 ../vector/v.in.lidar/main.c:791
-#, c-format
-msgid "%lu input points were filtered out by class number"
+#: ../general/g.cairocomp/main.c:224 ../general/g.pnmcomp/main.c:302
+msgid "Layer opacities"
msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:714
-#, c-format
-msgid "%lu input points had intensity out of range"
+#: ../general/g.cairocomp/main.c:230 ../general/g.pnmcomp/main.c:315
+msgid "Image width"
msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:716 ../vector/v.in.lidar/main.c:811
-#, c-format
-msgid "%lu input points were not valid, use -%c flag to filter them out"
+#: ../general/g.cairocomp/main.c:236 ../general/g.pnmcomp/main.c:321
+msgid "Image height"
msgstr ""
-#: ../raster3d/r3.in.lidar/projection.c:36
-#: ../raster/r.in.lidar/projection.c:34 ../raster/r.external/proj.c:42
-#: ../raster/r.in.gdal/main.c:479 ../vector/v.in.pdal/projection.c:31
-#: ../vector/v.in.lidar/projection.c:32 ../vector/v.in.ogr/main.c:627
-#: ../vector/v.external/proj.c:51
-msgid ""
-"Projection of dataset does not appear to match current location.\n"
-"\n"
+#: ../general/g.cairocomp/main.c:240
+msgid "Background color (R:G:B:A)"
msgstr ""
-#: ../raster3d/r3.in.lidar/projection.c:42
-#: ../raster/r.in.lidar/projection.c:40 ../vector/v.in.pdal/projection.c:37
-#: ../vector/v.in.lidar/projection.c:38 ../vector/v.in.ogr/main.c:633
-#: ../vector/v.external/proj.c:57
-msgid "GRASS LOCATION PROJ_INFO is:\n"
+#: ../general/g.cairocomp/main.c:245
+msgid "Do not composite; just delete input Pixmaps"
msgstr ""
-#: ../raster3d/r3.in.lidar/projection.c:51
-#: ../raster3d/r3.in.lidar/projection.c:57
-#: ../raster/r.in.lidar/projection.c:49 ../raster/r.in.lidar/projection.c:55
-#: ../raster/r.external/proj.c:85 ../raster/r.in.gdal/main.c:531
-#: ../vector/v.in.pdal/projection.c:46 ../vector/v.in.pdal/projection.c:52
-#: ../vector/v.in.lidar/projection.c:47 ../vector/v.in.lidar/projection.c:53
-#: ../vector/v.in.ogr/main.c:643 ../vector/v.in.ogr/main.c:650
-#: ../vector/v.external/proj.c:67 ../vector/v.external/proj.c:74
-msgid "Import dataset PROJ_INFO is:\n"
+#: ../general/g.cairocomp/main.c:277
+msgid "input= and opacity= must have the same number of values"
msgstr ""
-#: ../raster3d/r3.in.lidar/projection.c:93
-#: ../raster/r.in.lidar/projection.c:91 ../raster/r.external/proj.c:107
-#: ../raster/r.in.gdal/main.c:549 ../vector/v.in.pdal/projection.c:88
-#: ../vector/v.in.lidar/projection.c:89 ../vector/v.in.ogr/main.c:689
-#: ../vector/v.external/proj.c:113
-#, c-format
-msgid ""
-"\n"
-"In case of no significant differences in the projection definitions, use the "
-"-o flag to ignore them and use current location definition.\n"
+#: ../general/g.gui/main.c:40
+msgid "GUI"
msgstr ""
-#: ../raster3d/r3.in.lidar/projection.c:97
-#: ../raster/r.in.lidar/projection.c:95 ../vector/v.in.pdal/projection.c:92
-#: ../vector/v.in.lidar/projection.c:93 ../vector/v.in.ogr/main.c:693
-#: ../vector/v.external/proj.c:117
-msgid ""
-"Consider generating a new location with 'location' parameter from input data "
-"set.\n"
-msgstr ""
+#: ../general/g.gui/main.c:41
+msgid "user interface"
+msgstr "사용자 인터페이스"
-#: ../raster3d/r3.in.lidar/projection.c:115
-#: ../raster/r.in.lidar/projection.c:113 ../vector/v.in.pdal/projection.c:110
-#: ../vector/v.in.pdal/projection.c:156 ../vector/v.in.pdal/projection.c:189
-#: ../vector/v.in.lidar/projection.c:111 ../vector/v.in.ogr/main.c:603
-#: ../vector/v.external/proj.c:41
-msgid ""
-"Unable to convert input map projection information to GRASS format for "
-"checking"
-msgstr ""
+#: ../general/g.gui/main.c:44
+msgid "Launches a GRASS graphical user interface (GUI) session."
+msgstr "GRASS 그래픽 사용자 인터페이스(GUI) 세션을 시작합니다."
-#: ../raster3d/r3.in.lidar/projection.c:130
-#: ../raster/r.in.lidar/projection.c:128 ../raster/r.external/proj.c:34
-#: ../raster/r.in.gdal/main.c:469 ../vector/v.in.lidar/projection.c:126
-#: ../vector/v.in.ogr/main.c:618
+#: ../general/g.gui/main.c:45
#, fuzzy
-msgid "Over-riding projection check"
-msgstr "출력할 격자지도"
+msgid "Optionally updates default user interface settings."
+msgstr "그리고 기본 사용자 인터페이스 설정을 갱신합니다."
-#: ../raster3d/r3.in.lidar/projection.c:141
-#: ../raster/r.in.lidar/projection.c:139 ../raster/r.external/proj.c:116
-#: ../raster/r.in.gdal/main.c:569 ../vector/v.in.pdal/projection.c:137
-#: ../vector/v.in.lidar/projection.c:137 ../vector/v.in.ogr/main.c:708
-#: ../vector/v.external/proj.c:122
-msgid "Projection of input dataset and current location appear to match"
-msgstr ""
+#: ../general/g.gui/main.c:50
+msgid "User interface"
+msgstr "사용자 인터페이스"
-#: ../raster3d/r3.in.lidar/rast_segment.c:53
-#: ../raster/r.in.lidar/rast_segment.c:40
+#: ../general/g.gui/main.c:54
+msgid "wxPython based GUI (wxGUI)"
+msgstr "wxPython 기반 GUI(wxGUI)"
+#: ../general/g.gui/main.c:55
+msgid "command line interface only"
+msgstr "명령줄 인터페이스에만 적용"
+#: ../general/g.gui/main.c:56
#, fuzzy
-msgid "Cannot create temporary file with segments of a raster map"
-msgstr "출력할 격자지도"
+msgid "command line interface with GUI startup screen"
-#: ../raster3d/r3.in.lidar/info.c:109 ../raster/r.in.lidar/info.c:108
-#: ../raster/r.in.xyz/main.c:1198
-msgid "Scanning data ..."
-msgstr ""
+#: ../general/g.gui/main.c:60 ../general/g.message/main.c:43
+#: ../general/g.message/main.c:48 ../general/g.message/main.c:53
+#: ../general/g.message/main.c:58
+msgid "Type"
+msgstr "타입"
-#: ../raster3d/r3.in.lidar/info.c:149 ../raster/r.in.lidar/info.c:148
-#: ../raster/r.in.xyz/main.c:1304
-#, c-format
-msgid "Range: min max\n"
-msgstr ""
-#: ../raster3d/r3.mask/main.c:75
+#: ../general/g.gui/main.c:66
#, fuzzy
-msgid "Unable to open 3D raster mask file"
-msgstr "출력할 격자지도"
+msgid "Name of workspace file to load on start-up"
+msgstr "시작할 때 읽어 들일 작업공간 파일의 이름"
-#: ../raster3d/r3.mask/main.c:104
-msgid "makeMask: error flushing tiles in cube"
+#: ../general/g.gui/main.c:67
+msgid "This is valid only for wxGUI (wxpython)"
msgstr ""
-#: ../raster3d/r3.mask/main.c:109
-msgid "makeMask: error flushing all tiles"
+#: ../general/g.gui/main.c:71
+msgid "Start GUI in the foreground"
msgstr ""
-#: ../raster3d/r3.mask/main.c:117
-#, fuzzy
-msgid "Unable to close 3D raster mask file"
-msgstr "출력할 격자지도"
+#: ../general/g.gui/main.c:72
+msgid ""
+"By default the GUI starts in the background and control is immediately "
+"returned to the caller. When GUI runs in foregreound, it blocks the command "
+"line"
+msgstr ""
-#: ../raster3d/r3.mask/main.c:119
-#, fuzzy, c-format
-msgid "Unable to close raster map <%s>"
-msgstr "출력할 격자지도"
+#: ../general/g.gui/main.c:78
+msgid "Update default user interface settings"
+msgstr "기본 사용자설정을 갱신합니다"
-#: ../raster3d/r3.mask/main.c:134
-#: ../locale/scriptstrings/r.mask_to_translate.c:3
-msgid "mask"
+#: ../general/g.gui/main.c:79 ../general/g.gui/main.c:85
+msgid "Default"
+msgstr "기본값"
+#: ../general/g.gui/main.c:84
+msgid "Do not launch GUI after updating the default user interface settings"
+msgstr "기본 사용자설정을 갱신한 뒤에는 GUI를 시작하지 마세요"
+#: ../general/g.gui/main.c:95
+#, c-format
+msgid "<%s> is now the default GUI"
+msgstr "<%s>가 이제 기본 GUI입니다"
+#: ../general/g.gui/main.c:101
+#, c-format
+msgid "Nothing to do. For setting up <%s> as default UI use -%c flag."
msgstr ""
-#: ../raster3d/r3.mask/main.c:137
-msgid "Establishes the current working 3D raster mask."
+#: ../general/g.gui/main.c:108
+msgid "Your installation doesn't include GUI, exiting."
msgstr ""
-#: ../raster3d/r3.mask/main.c:145
-#, fuzzy
-msgid "3D raster map with reference values"
-msgstr "출력할 격자지도"
+#: ../general/g.gui/main.c:111
+#, fuzzy, c-format
+msgid "Launching <%s> GUI, please wait..."
+msgstr "<%s> GUI를 배경프로세스에서 시작합니다. 기다려주세요..."
-#: ../raster3d/r3.mask/main.c:153
-msgid "List of cell values to be masked out"
-msgstr ""
+#: ../general/g.gui/main.c:122
+#, c-format
+msgid "Launching <%s> GUI in the background, please wait..."
-#: ../raster3d/r3.mask/main.c:159
-msgid "Cannot create mask file: RASTER3D_MASK already exists"
+#: ../general/g.dirseps/main.c:38
+msgid "Internal GRASS utility for converting directory separator characters."
msgstr ""
-#: ../raster3d/r3.gradient/main.c:44
-#, fuzzy
-msgid "gradient"
-msgstr "출력할 격자지도"
+#: ../general/g.version/main.c:66 ../general/g.tempfile/main.c:39
+#: ../general/g.message/main.c:34
+msgid "support"
+msgstr "지원"
-#: ../raster3d/r3.gradient/main.c:47
-msgid ""
-"Computes gradient of a 3D raster map and outputs gradient components as "
-"three 3D raster maps."
+#: ../general/g.version/main.c:67
+msgid "citing"
msgstr ""
-#: ../raster3d/r3.gradient/main.c:56
+#: ../general/g.version/main.c:68
+msgid "copyright"
+msgstr ""
+#: ../general/g.version/main.c:69
#, fuzzy
-msgid "Name for output 3D raster map(s)"
-msgstr "출력할 격자지도"
+msgid "version"
+msgstr "변환"
-#: ../raster3d/r3.gradient/main.c:63
-msgid "Size of blocks"
+#: ../general/g.version/main.c:70
+msgid "license"
msgstr ""
-#: ../raster3d/r3.gradient/main.c:130
+#: ../general/g.version/main.c:71
#, fuzzy
-msgid "Failed to allocate memory for blocks"
+msgid "Displays GRASS GIS version info."
msgstr "출력할 격자지도"
-#: ../raster3d/r3.gradient/main.c:292
+#: ../general/g.version/main.c:72
#, fuzzy
-msgid "Writing gradient 3D raster maps..."
+msgid "Optionally also prints build or copyright information."
msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.v5d/main.c:66
-#, fuzzy
-msgid "Name of V5D raster file to be imported"
-msgstr "출력할 격자지도"
-#: ../raster3d/r3.in.v5d/main.c:182
-msgid "Import 3-dimensional Vis5D files."
+#: ../general/g.version/main.c:76
+msgid "Print also the copyright message"
msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:80 ../visualization/ximgview/main.c:290
-#: ../locale/scriptstrings/d.frame_to_translate.c:2
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:2
-#: ../locale/scriptstrings/d.to.rast_to_translate.c:2
-#: ../locale/scriptstrings/d.redraw_to_translate.c:2
-#: ../locale/scriptstrings/d.shade_to_translate.c:2
-#: ../locale/scriptstrings/d.correlate_to_translate.c:2
-#: ../locale/scriptstrings/d.out.file_to_translate.c:2
-#: ../locale/scriptstrings/d.polar_to_translate.c:2
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:2
-#: ../locale/scriptstrings/d.what.vect_to_translate.c:2
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:2
-#: ../locale/scriptstrings/d.what.rast_to_translate.c:2
-#: ../display/d.erase/main.c:29 ../display/d.title/main.c:49
-#: ../display/d.rast.num/main.c:77 ../display/d.info/main.c:34
-#: ../display/d.vect.chart/main.c:63 ../display/d.vect.thematic/main.c:85
-#: ../display/d.barscale/main.c:63 ../display/d.text/main.c:138
-#: ../display/d.rgb/main.c:53 ../display/d.labels/main.c:43
-#: ../display/d.linegraph/main.c:229 ../display/d.rast.arrow/main.c:97
-#: ../display/d.rhumbline/main.c:44 ../display/d.extract/main.c:49
-#: ../display/d.vect/main.c:73 ../display/d.fontlist/main.c:45
-#: ../display/d.where/main.c:43 ../display/d.colortable/main.c:60
-#: ../display/d.mon/main.c:38 ../display/d.rast/main.c:53
-#: ../display/d.histogram/main.c:83 ../display/d.profile/main.c:191
-#: ../display/d.graph/main.c:58 ../display/d.legend.vect/main.c:50
-#: ../display/d.northarrow/main.c:46 ../display/d.geodesic/main.c:46
-#: ../display/d.path/main.c:48 ../display/d.grid/main.c:53
-#: ../display/d.colorlist/main.c:35 ../display/d.legend/main.c:78
-#: ../display/d.font/main.c:45 ../display/d.his/main.c:62
-#: ../general/g.cairocomp/main.c:197 ../general/g.pnmcomp/main.c:283
-#: ../general/g.ppmtopng/main.c:118
-msgid "display"
-msgstr "화면"
-#: ../raster3d/r3.mkdspf/main.c:83
-msgid ""
-"Creates a display file from an existing 3D raster map according to specified "
-"threshold levels."
+#: ../general/g.version/main.c:77 ../general/g.version/main.c:82
+#: ../general/g.version/main.c:87 ../general/g.version/main.c:93
+#: ../general/g.version/main.c:99
+msgid "Additional info"
msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:91
+#: ../general/g.version/main.c:81
#, fuzzy
-msgid "Name of an existing 3D raster map"
+msgid "Print also the citation options"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.mkdspf/main.c:96
+#: ../general/g.version/main.c:86
#, fuzzy
-msgid "Name for output display file"
+msgid "Print also the build information"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.mkdspf/main.c:103
-msgid "List of thresholds for isosurfaces"
+#: ../general/g.version/main.c:92
+msgid "Print also the GIS library revision number and date"
msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:109
-msgid "Minimum isosurface level"
+#: ../general/g.version/main.c:97
+msgid "Print also extended info for additional libraries"
msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:115
-msgid "Maximum isosurface level"
+#: ../general/g.version/main.c:98
+msgid "GDAL/OGR, PROJ.4, GEOS"
msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:121
-msgid "Positive increment between isosurface levels"
-msgstr ""
+#: ../general/g.version/main.c:103
+#, fuzzy
+msgid "Print info in shell script style (including SVN revision number)"
+msgstr "출력할 격자지도"
-#: ../raster3d/r3.mkdspf/main.c:128
-msgid "Number of isosurface threshold levels"
+#: ../general/g.version/main.c:104
+msgid "Shell"
msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:132
-msgid "Suppress progress report & min/max information"
+#: ../general/g.version/main.c:172
+#, c-format
+msgid ""
+"Cannot determine GRASS libgis version and date number. The GRASS build might "
+"be broken. Report this to developers or packagers.\n"
msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:136
-msgid "Use flat shading rather than gradient"
+#: ../general/g.version/main.c:179
+msgid ""
+"GRASS GIS libgis version and date number don't have the expected format. "
+"Trying to print the original strings..."
msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:144
+#: ../general/g.version/main.c:181
#, c-format
-msgid "Region from getWindow: %d %d %d"
+msgid "GIS_H_VERSION=\"%s\""
msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:156
+#: ../general/g.version/main.c:182
#, c-format
-msgid "Not able to find grid3 file for [%s]"
+msgid "GIS_H_DATE=\"%s\""
msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:200
-#, fuzzy, c-format
-msgid "Unable to open display file <%s>"
-msgstr "출력할 격자지도"
-#: ../raster3d/r3.mkdspf/main.c:221
-#, c-format
-msgid "Writing %s from %s..."
+#: ../general/g.version/main.c:212
+msgid "GRASS not compiled with GDAL/OGR support"
msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:90
-#, fuzzy
-msgid "Input 3D raster map for cross section"
-msgstr "출력할 격자지도"
-#: ../raster3d/r3.cross.rast/main.c:97
-msgid "2D elevation map used to create the cross section map"
+#: ../general/g.version/main.c:223
+msgid "GRASS not compiled with GEOS support"
msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:104
-msgid "Resulting cross section 2D raster map"
+#: ../general/g.version/main.c:234
+msgid "GRASS not compiled with SQLite support"
msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:229 ../raster/r.profile/main.c:54
-#: ../display/d.profile/main.c:192
-msgid "profile"
-msgstr ""
+#: ../general/g.remove/check_reclass.c:16
+#, c-format
+msgid "Raster map <%s@%s> is a base map for <%s>. Remove forced."
+msgstr "격자지도 <%s@%s>는 <%s>의 기반지도입니다. 강제로 지웁니다."
-#: ../raster3d/r3.cross.rast/main.c:233
-msgid ""
-"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
-"map"
+#: ../general/g.remove/check_reclass.c:19
+#, c-format
+msgid "Raster map <%s@%s> is a base map. Remove reclassed map <%s> first."
msgstr ""
+"격자지도 <%s@%s>는 기반지도입니다. 재분류된 지도 <%s>를 먼저 삭제하세요."
-#: ../raster3d/r3.cross.rast/main.c:259
+#: ../general/g.remove/check_reclass.c:41
+#: ../general/g.remove/check_reclass.c:54
+#, c-format
+msgid "Removing information about reclassed map from <%s@%s> failed"
+msgstr "<%s@%s>로부터 재분류된 지도에 대한 정보를 지우는데 실패했습니다"
+#: ../general/g.remove/main.c:71
+#: ../locale/scriptstrings/t.remove_to_translate.c:4
+msgid "remove"
+msgstr "삭제"
+#: ../general/g.remove/main.c:73
msgid ""
-"The 2D and 3D region settings are different. Using the 3D raster map "
-"settings to adjust the 2D region."
+"Removes data base element files from the user's current mapset using the "
+"search pattern."
msgstr ""
+"검색패턴을 이용해서 사용자의 현재 지도세트로부터 데이타베이스 요소파일을 지웁"
+"니다."
-#: ../raster3d/r3.cross.rast/main.c:302
-msgid "Output map already exists. Will be overwritten!"
+#: ../general/g.remove/main.c:83 ../general/g.remove/main.c:91
+#: ../general/g.remove/main.c:133
+msgid "Basic"
msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:338
+#: ../general/g.remove/main.c:90
#, fuzzy
-msgid "Wrong 3D raster datatype! Cannot create raster map"
+msgid "Name of file(s) to remove"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.flow/flowline.c:60 ../raster/r.contour/main.c:216
-#: ../vector/v.overlay/line_area.c:410 ../vector/v.overlay/area_area.c:345
-#: ../vector/v.to.points/write.c:52
-#, fuzzy, c-format
-msgid "Unable to insert new record: '%s'"
-msgstr "출력할 격자지도"
+#: ../general/g.remove/main.c:99
+#, fuzzy
+msgid "Name of file(s) to ignore (default: none)"
+msgstr "지도이름 제외패턴 (기본값: 없음)"
-#: ../raster3d/r3.flow/test_main.c:44
-msgid "unit test"
-msgstr ""
+#: ../general/g.remove/main.c:100 ../general/g.remove/main.c:106
+#: ../general/g.remove/main.c:112 ../general/g.remove/main.c:117
+#: ../general/g.remove/main.c:123 ../general/g.remove/main.c:129
+#: ../general/g.list/main.c:87 ../general/g.list/main.c:95
+#: ../general/g.list/main.c:121 ../general/g.list/main.c:127
+#: ../general/g.list/main.c:133
+msgid "Pattern"
+msgstr "패턴"
-#: ../raster3d/r3.flow/test_main.c:45
+#: ../general/g.remove/main.c:105
#, fuzzy
-msgid "Testing flow lines."
-msgstr "출력할 격자지도"
+msgid "File name search pattern"
+msgstr "지도이름 검색패턴"
-#: ../raster3d/r3.flow/main.c:46 ../ps/ps.map/catval.c:53
-#: ../ps/ps.map/catval.c:115 ../ps/ps.map/catval.c:181
-#: ../doc/vector/v.example/main.c:131 ../raster/r.to.vect/main.c:187
-#: ../raster/r.random/random.c:73 ../raster/r.contour/main.c:172
-#: ../raster/r.volume/main.c:243 ../display/d.vect.chart/plot.c:44
-#: ../display/d.vect.thematic/plot1.c:111 ../display/d.vect/shape.c:44
-#: ../display/d.vect/attr.c:43 ../misc/m.nviz.image/vector.c:293
-#: ../vector/v.net.flow/main.c:169 ../vector/v.reclass/main.c:133
-#: ../vector/v.extract/main.c:263 ../vector/v.what.rast3/main.c:126
-#: ../vector/v.label.sa/labels.c:78 ../vector/v.info/print.c:147
-#: ../vector/v.net.centrality/main.c:246
-#: ../vector/v.lrs/v.lrs.create/main.c:296
-#: ../vector/v.lrs/v.lrs.create/main.c:305 ../vector/v.class/main.c:117
-#: ../vector/v.transform/trans_digit.c:40 ../vector/v.overlay/main.c:246
-#: ../vector/v.overlay/main.c:413 ../vector/v.label/main.c:278
-#: ../vector/v.to.rast3/main.c:84 ../vector/v.surf.idw/read_sites.c:55
-#: ../vector/v.normal/main.c:122 ../vector/v.net.allpairs/main.c:166
-#: ../vector/v.colors/write_rgb.c:25 ../vector/v.colors/read_rgb.c:28
-#: ../vector/v.colors/scan_attr.c:29 ../vector/v.net.timetable/main.c:93
-#: ../vector/v.db.connect/main.c:223 ../vector/v.db.connect/main.c:331
-#: ../vector/v.out.svg/main.c:159 ../vector/v.distance/main.c:464
-#: ../vector/v.distance/main.c:499 ../vector/v.distance/main.c:545
-#: ../vector/v.distance/main.c:1274 ../vector/v.distance/main.c:1295
-#: ../vector/v.net.path/path.c:96 ../vector/v.surf.rst/main.c:587
-#: ../vector/v.net.distance/main.c:279 ../vector/v.in.db/main.c:164
-#: ../vector/v.in.db/main.c:302 ../vector/v.edit/select.c:516
-#: ../vector/v.out.ogr/main.c:635 ../vector/v.mkgrid/main.c:278
-#: ../vector/v.net.components/main.c:180 ../vector/v.in.ogr/main.c:1143
-#: ../vector/v.surf.bspline/main.c:378
-#: ../vector/v.surf.bspline/crosscorr.c:123 ../vector/v.in.dwg/main.c:213
-#: ../vector/v.to.points/main.c:167 ../vector/v.buffer/main.c:417
-#: ../vector/v.random/main.c:238 ../vector/v.kcv/main.c:126
-#: ../vector/v.in.dxf/write_vect.c:211 ../vector/v.what.rast/main.c:144
-#: ../vector/v.sample/main.c:179 ../vector/v.select/copy_tabs.c:77
-#: ../vector/v.patch/main.c:154 ../vector/v.patch/main.c:186
-#: ../vector/v.patch/main.c:307 ../vector/v.patch/main.c:389
-#: ../vector/v.in.ascii/main.c:346 ../vector/v.out.postgis/table.c:34
-#: ../vector/v.to.rast/vect2rast.c:60 ../vector/v.to.rast/support.c:109
-#: ../vector/v.to.rast/support.c:284 ../vector/v.to.rast/support.c:523
-#: ../vector/v.colors.out/make_colors.c:36 ../vector/v.to.db/query.c:89
-#: ../vector/v.to.db/update.c:46 ../vector/v.out.vtk/writeVTK.c:649
-#: ../vector/v.db.select/main.c:177 ../vector/v.to.3d/trans2.c:55
-#: ../vector/v.to.3d/trans3.c:57 ../vector/v.extrude/main.c:229
-#: ../vector/v.vol.rst/user1.c:99 ../vector/v.vol.rst/main.c:600
-#, fuzzy, c-format
-msgid "Unable to open database <%s> by driver <%s>"
-msgstr "출력할 격자지도"
-#: ../raster3d/r3.flow/main.c:64 ../raster/r.to.vect/main.c:229
-#: ../raster/r.volume/main.c:260 ../vector/v.lrs/v.lrs.create/main.c:338
-#: ../vector/v.mkgrid/main.c:342 ../vector/v.mkgrid/main.c:400
-#: ../vector/v.random/main.c:252 ../vector/v.in.dxf/write_vect.c:233
-#: ../vector/v.in.ascii/main.c:413
-#, fuzzy, c-format
-msgid "Unable to create table: %s"
-msgstr "출력할 격자지도"
-#: ../raster3d/r3.flow/main.c:67 ../raster/r.contour/main.c:188
-#: ../vector/v.reclass/main.c:322 ../vector/v.in.lidar/attributes.c:139
-#: ../vector/v.in.ogr/main.c:1683 ../vector/v.in.dwg/main.c:244
-#: ../vector/v.to.points/main.c:187 ../vector/v.in.dxf/write_vect.c:241
-#: ../vector/v.in.ascii/main.c:521
-#, fuzzy, c-format
-msgid "Unable to create index for table <%s>, key <%s>"
-msgstr "출력할 격자지도"
-#: ../raster3d/r3.flow/main.c:72 ../raster/r.stream.extract/close.c:196
-#: ../raster/r.to.vect/main.c:238 ../raster/r.random/random.c:257
-#: ../raster/r.contour/main.c:193 ../vector/v.reclass/main.c:327
-#: ../vector/v.extract/copy_tab.c:129 ../vector/v.overlay/main.c:597
-#: ../vector/v.distance/main.c:1361 ../vector/v.in.lidar/attributes.c:144
-#: ../vector/v.mkgrid/main.c:350 ../vector/v.mkgrid/main.c:408
-#: ../vector/v.in.ogr/main.c:1157 ../vector/v.in.dwg/main.c:249
-#: ../vector/v.to.points/main.c:192 ../vector/v.random/main.c:264
-#: ../vector/v.in.dxf/write_vect.c:238 ../vector/v.sample/main.c:197
-#: ../vector/v.select/copy_tabs.c:85 ../vector/v.patch/main.c:331
-#: ../vector/v.in.ascii/main.c:421
-#, fuzzy, c-format
-msgid "Unable to grant privileges on table <%s>"
-msgstr "출력할 격자지도"
-#: ../raster3d/r3.flow/main.c:91
+#: ../general/g.remove/main.c:111
#, fuzzy
-msgid "Please provide three 3D raster maps"
-msgstr "출력할 격자지도"
+msgid "File name exclusion pattern (default: none)"
-#: ../raster3d/r3.flow/main.c:98
-#, fuzzy, c-format
-msgid "Vector seed map <%s> not found"
-msgstr "출력할 격자지도"
-#: ../raster3d/r3.flow/main.c:147
-msgid "init_flowaccum: error in Rast3d_put_float"
+#: ../general/g.remove/main.c:116 ../general/g.list/main.c:120
+msgid "Ignore case"
msgstr ""
-#: ../raster3d/r3.flow/main.c:183
-#, fuzzy
-msgid "Computes 3D flow lines and 3D flow accumulation."
-msgstr "출력할 격자지도"
+#: ../general/g.remove/main.c:122 ../general/g.list/main.c:126
+msgid "Use basic regular expressions instead of wildcards"
+msgstr "와일드카드 대신 기본 정규표현식을 사용합니다"
-#: ../raster3d/r3.flow/main.c:193
-msgid ""
-"Names of three 3D raster maps describing x, y, z components of vector field"
-msgstr ""
+#: ../general/g.remove/main.c:128 ../general/g.list/main.c:132
+msgid "Use extended regular expressions instead of wildcards"
+msgstr "와일드카드 대신 확장 정규표현식을 사용합니다"
-#: ../raster3d/r3.flow/main.c:200
-msgid ""
-"If no map is provided, flow lines are generated from each cell of the input "
-"3D raster"
-msgstr ""
+#: ../general/g.remove/main.c:135
+#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:4
+#: ../locale/scriptstrings/db.droptable_to_translate.c:4
+msgid "Force removal (required for actual deletion of files)"
+msgstr "실제로 파일을 지웁니다"
-#: ../raster3d/r3.flow/main.c:203
-#, fuzzy
-msgid "Name of vector map with points from which flow lines are generated"
-msgstr "출력할 격자지도"
+#: ../general/g.remove/main.c:139
+msgid "Remove base raster maps"
+msgstr "기반 격자지도를 지웁니다"
-#: ../raster3d/r3.flow/main.c:210
-#, fuzzy
-msgid "Name for vector map of flow lines"
-msgstr "출력할 격자지도"
+#: ../general/g.remove/main.c:178 ../general/g.remove/main.c:202
+#: ../general/g.list/main.c:185 ../general/g.list/main.c:212
+#, c-format
+msgid "Unable to compile pattern <%s>"
+msgstr "패턴 <%s>를 컴파일하지 못 했습니다"
-#: ../raster3d/r3.flow/main.c:217
-#, fuzzy
-msgid "Name for output flowaccumulation 3D raster"
-msgstr "출력할 격자지도"
+#: ../general/g.remove/main.c:208
+msgid "The following data base element files would be deleted:"
+msgstr "다음의 데이타베이스 요소파일들이 지워질 것입니다:"
-#: ../raster3d/r3.flow/main.c:224
+#: ../general/g.remove/main.c:259
#, fuzzy
-msgid "Name for 3D raster sampled by flowlines"
+msgid "No data base element files found"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.flow/main.c:226
+#: ../general/g.remove/main.c:267
+#, fuzzy, c-format
msgid ""
-"Values of this 3D raster will be stored as attributes of flowlines segments"
-msgstr ""
+"Nothing removed. You must use the force flag (-%c) to actually remove them. "
+"Exiting."
+msgstr "실제로 삭제하기 위해서는 강제 플래그(-%c)를 써야 합니다. 종료합니다."
-#: ../raster3d/r3.flow/main.c:240
-msgid "elapsed time"
+#: ../general/g.remove/construct_pattern.c:37
+#, fuzzy, c-format
+msgid "%s: Cannot remove or exclude files not in the current mapset."
msgstr ""
+"사용자의 현재지도세트 안에 있는 데이타베이스 요소파일들의 이름을 변경합니다."
-#: ../raster3d/r3.flow/main.c:241
-msgid "length in map units"
+#: ../general/g.remove/construct_pattern.c:57
+msgid "Illegal filenames not allowed in the name or ignore option."
msgstr ""
-msgid "length in cells (voxels)"
-msgstr ""
+#: ../general/g.mapset/main.c:50 ../general/g.mapsets/main.c:64
+#: ../general/g.region/main.c:65 ../general/g.gisenv/main.c:44
+#: ../temporal/t.connect/main.c:35 ../display/d.font/main.c:46
+#: ../display/d.colorlist/main.c:36 ../display/d.fontlist/main.c:46
+msgid "settings"
+msgstr "설정"
-#: ../raster3d/r3.flow/main.c:243
+#: ../general/g.mapset/main.c:51
#, fuzzy
-msgid "Unit of integration step"
+msgid "Changes/reports current mapset."
msgstr "출력할 격자지도"
-#: ../raster3d/r3.flow/main.c:244
-#, fuzzy
-msgid "Default unit is cell"
-msgstr "기본값: 자동축척"
+#: ../general/g.mapset/main.c:52
+msgid ""
+"Optionally create new mapset or list available mapsets in given location."
+msgstr ""
-#: ../raster3d/r3.flow/main.c:245 ../raster3d/r3.flow/main.c:254
-#: ../raster3d/r3.flow/main.c:262 ../raster3d/r3.flow/main.c:272
+#: ../general/g.mapset/main.c:56
#, fuzzy
-msgid "Integration"
+msgid "Name of mapset where to switch"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.flow/main.c:252
-#, fuzzy
-msgid "Integration step in selected unit"
-msgstr "출력할 격자지도"
-#: ../raster3d/r3.flow/main.c:253
-msgid "Default step is 0.25 cell"
+#: ../general/g.mapset/main.c:57 ../general/g.mapset/main.c:61
+#: ../general/g.mapset/main.c:64
+msgid "Mapset"
msgstr ""
-#: ../raster3d/r3.flow/main.c:261
-#, fuzzy
-msgid "Maximum number of steps"
-msgstr "출력할 격자지도"
-#: ../raster3d/r3.flow/main.c:269
-#, fuzzy
-msgid "Maximum error of integration"
-msgstr "출력할 격자지도"
-#: ../raster3d/r3.flow/main.c:270
-msgid "Influences step, increase maximum error to allow bigger steps"
+#: ../general/g.mapset/main.c:68
+msgid "Create mapset if it doesn't exist"
msgstr ""
-#: ../raster3d/r3.flow/main.c:280
-msgid "Number of cells between flow lines in x, y and z direction"
+#: ../general/g.mapset/main.c:70 ../general/g.proj/main.c:201
+#: ../locale/scriptstrings/r.mask_to_translate.c:18
+msgid "Create"
msgstr ""
-#: ../raster3d/r3.flow/main.c:289
-msgid "Compute flowlines upstream, downstream or in both direction."
+#: ../general/g.mapset/main.c:75
+msgid "List available mapsets and exit"
msgstr ""
-#: ../raster3d/r3.flow/main.c:294
+#: ../general/g.mapset/main.c:76 ../general/g.mapset/main.c:82
+#: ../general/g.list/main.c:105 ../general/g.list/main.c:116
+#: ../general/g.list/main.c:138 ../general/g.list/main.c:143
+#: ../general/g.list/main.c:148 ../general/g.list/main.c:153
+#: ../general/g.mapsets/main.c:87 ../general/g.mapsets/main.c:92
+#: ../general/g.mapsets/main.c:98 ../general/g.region/main.c:85
+#: ../general/g.region/main.c:91 ../general/g.region/main.c:96
+#: ../general/g.region/main.c:102 ../general/g.region/main.c:108
+#: ../general/g.region/main.c:114 ../general/g.region/main.c:120
+#: ../general/g.region/main.c:128 ../general/g.region/main.c:133
+#: ../general/g.region/main.c:139 ../general/g.region/main.c:144
+#: ../general/g.region/main.c:149 ../general/g.proj/main.c:80
+#: ../general/g.proj/main.c:86 ../general/g.proj/main.c:92
+#: ../general/g.proj/main.c:98 ../general/g.proj/main.c:104
+#: ../general/g.proj/main.c:115 ../general/g.proj/main.c:120
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:18
+#: ../locale/scriptstrings/g.extension_to_translate.c:16
+#: ../locale/scriptstrings/g.extension_to_translate.c:18
+#: ../locale/scriptstrings/g.extension_to_translate.c:20
+#: ../locale/scriptstrings/g.extension_to_translate.c:22
+#: ../temporal/t.connect/main.c:43 ../raster/r.external.out/main.c:272
+#: ../raster/r.external.out/main.c:283 ../raster/r.sunmask/main.c:232
+#: ../raster/r.sunmask/main.c:238 ../raster/r.proj/main.c:204
+#: ../raster/r.proj/main.c:214 ../raster/r.proj/main.c:220
+#: ../raster/r.external/main.c:96 ../raster/r.external/main.c:124
+#: ../raster/r.what/main.c:120 ../raster/r.what/main.c:128
+#: ../raster/r.what/main.c:142 ../raster/r.what/main.c:147
+#: ../raster/r.what/main.c:152 ../raster/r.what/main.c:157
+#: ../raster/r.out.gdal/main.c:142 ../raster/r.in.gdal/main.c:198
+#: ../raster/r.colors/edit_colors.c:128 ../display/d.mon/main.c:103
+#: ../display/d.mon/main.c:108 ../display/d.mon/main.c:113
+#: ../vector/v.external/args.c:50 ../vector/v.external/args.c:56
+#: ../vector/v.external/args.c:64 ../vector/v.in.ogr/main.c:257
+#: ../vector/v.in.ogr/main.c:263 ../vector/v.to.db/parse.c:116
+#: ../vector/v.to.db/parse.c:121 ../vector/v.to.db/parse.c:127
+#: ../vector/v.to.db/parse.c:133 ../vector/v.external.out/args.c:63
+#: ../vector/v.external.out/args.c:75 ../vector/v.external.out/args.c:81
+#: ../vector/v.info/parse.c:25 ../vector/v.info/parse.c:31
+#: ../vector/v.info/parse.c:36 ../vector/v.info/parse.c:41
+#: ../vector/v.info/parse.c:46 ../vector/v.db.connect/main.c:84
+#: ../vector/v.db.connect/main.c:89 ../vector/v.db.connect/main.c:96
+#: ../vector/v.db.connect/main.c:103 ../vector/v.colors/main.c:133
+#: ../vector/v.what/main.c:89 ../vector/v.what/main.c:94
+#: ../vector/v.what/main.c:99 ../vector/v.what/main.c:104
+#: ../imagery/i.group/main.c:79 ../imagery/i.group/main.c:84
+#: ../imagery/i.group/main.c:89 ../db/db.connect/main.c:53
+#: ../db/db.connect/main.c:58 ../db/db.login/main.c:91
+msgid "Print"
+msgstr "출력"
+#: ../general/g.mapset/main.c:81
#, fuzzy
-msgid "Create and fill attribute table"
+msgid "Print current mapset and exit"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.flow/main.c:349
-msgid "Please provide 3 integer values for skip option."
-msgstr ""
-#: ../raster3d/r3.flow/main.c:396 ../doc/vector/v.example/main.c:98
-#: ../raster/r.sim/simlib/output.c:38 ../raster/r.sim/simlib/output.c:44
-#: ../raster/r.resamp.bspline/main.c:485 ../raster/r.stream.extract/close.c:37
-#: ../raster/r.drain/main.c:197 ../raster/r.to.vect/main.c:155
-#: ../raster/r.random/random.c:63 ../raster/r.carve/vect.c:32
-#: ../raster/r.contour/main.c:156 ../raster/r.volume/main.c:155
-#: ../raster/r.flow/io.c:178 ../display/d.extract/main.c:106
-#: ../vector/v.net.flow/main.c:149 ../vector/v.net.flow/main.c:155
-#: ../vector/v.reclass/main.c:117 ../vector/v.extract/main.c:346
-#: ../vector/v.net.centrality/main.c:215 ../vector/v.cluster/main.c:207
-#: ../vector/v.net.spanningtree/main.c:107
-#: ../vector/v.lrs/v.lrs.segment/main.c:148
-#: ../vector/v.lrs/v.lrs.create/main.c:267
-#: ../vector/v.lrs/v.lrs.create/main.c:273
-#: ../vector/v.lrs/v.lrs.label/main.c:276 ../vector/v.transform/main.c:246
-#: ../vector/v.segment/main.c:114 ../vector/v.overlay/main.c:220
-#: ../vector/v.drape/main.c:158 ../vector/v.decimate/main.c:389
-#: ../vector/v.net.steiner/main.c:607 ../vector/v.net.allpairs/main.c:136
-#: ../vector/v.net.timetable/main.c:359 ../vector/v.hull/main.c:121
-#: ../vector/v.generalize/main.c:336 ../vector/v.distance/main.c:356
-#: ../vector/v.net.path/main.c:167 ../vector/v.perturb/main.c:153
-#: ../vector/v.voronoi/main.c:215 ../vector/v.in.lidar/main.c:553
-#: ../vector/v.surf.rst/main.c:567 ../vector/v.surf.rst/main.c:570
-#: ../vector/v.surf.rst/main.c:726 ../vector/v.clean/main.c:288
-#: ../vector/v.clean/main.c:295 ../vector/v.delaunay/main.c:126
-#: ../vector/v.build.polylines/main.c:157 ../vector/v.net.distance/main.c:198
-#: ../vector/v.in.db/main.c:151 ../vector/v.in.region/main.c:75
-#: ../vector/v.net.alloc/main.c:273 ../vector/v.edit/main.c:105
-#: ../vector/v.edit/main.c:120 ../vector/v.net.bridge/main.c:124
-#: ../vector/v.mkgrid/main.c:264 ../vector/v.net.components/main.c:154
-#: ../vector/v.in.ogr/main.c:920 ../vector/v.kernel/main.c:338
-#: ../vector/v.external/main.c:144 ../vector/v.surf.bspline/main.c:347
-#: ../vector/v.in.dwg/main.c:200 ../vector/v.to.points/main.c:129
-#: ../vector/v.buffer/main.c:391 ../vector/v.random/main.c:227
-#: ../vector/v.in.dxf/main.c:144 ../vector/v.sample/main.c:162
-#: ../vector/v.qcount/main.c:127 ../vector/v.select/main.c:125
-#: ../vector/v.patch/main.c:281 ../vector/v.patch/main.c:286
-#: ../vector/v.lidar.edgedetection/main.c:241 ../vector/v.in.ascii/main.c:249
-#: ../vector/v.build/main.c:154 ../vector/v.split/main.c:177
-#: ../vector/v.proj/main.c:374 ../vector/v.parallel/main.c:153
-#: ../vector/v.net.iso/main.c:374 ../vector/v.rectify/main.c:214
-#: ../vector/v.net.salesman/main.c:551 ../vector/v.to.3d/main.c:87
-#: ../vector/v.extrude/main.c:196 ../vector/v.vol.rst/main.c:580
-#: ../vector/v.vol.rst/main.c:583 ../vector/v.outlier/main.c:224
-#: ../vector/v.outlier/main.c:229 ../vector/v.outlier/main.c:235
-#: ../vector/v.net.visibility/main.c:77
-#: ../vector/v.lidar.correction/main.c:209
-#: ../vector/v.lidar.correction/main.c:215
-#: ../vector/v.net.connectivity/main.c:136
+#: ../general/g.mapset/main.c:136
#, fuzzy, c-format
-msgid "Unable to create vector map <%s>"
+msgid "<%s> is already the current mapset"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.flow/main.c:411 ../doc/vector/v.example/main.c:87
-#: ../raster/r.sim/simlib/observation_points.c:41 ../raster/r.what/main.c:236
-#: ../raster/r.region/main.c:170 ../raster/r.cost/main.c:533
-#: ../raster/r.cost/main.c:606 ../raster/r.drain/main.c:268
-#: ../raster/r.random/support.c:63 ../raster/r.carve/main.c:162
-#: ../raster/r.walk/main.c:673 ../raster/r.walk/main.c:742
-#: ../display/d.vect.chart/main.c:246 ../display/d.extract/main.c:103
-#: ../display/d.path/main.c:185 ../general/manage/lister/vector.c:32
-#: ../misc/m.nviz.image/vector.c:280 ../vector/v.net.flow/main.c:143
-#: ../vector/v.reclass/main.c:113 ../vector/v.extract/main.c:191
-#: ../vector/v.what.rast3/main.c:114 ../vector/v.label.sa/labels.c:58
-#: ../vector/v.info/main.c:60 ../vector/v.out.lidar/main.c:609
-#: ../vector/v.net.centrality/main.c:209 ../vector/v.cluster/main.c:147
-#: ../vector/v.net.spanningtree/main.c:101
-#: ../vector/v.lrs/v.lrs.segment/main.c:144
-#: ../vector/v.lrs/v.lrs.create/main.c:254
-#: ../vector/v.lrs/v.lrs.create/main.c:263
-#: ../vector/v.lrs/v.lrs.where/main.c:131
-#: ../vector/v.lrs/v.lrs.where/main.c:140
-#: ../vector/v.lrs/v.lrs.label/main.c:272 ../vector/v.class/main.c:102
-#: ../vector/v.transform/main.c:178 ../vector/v.segment/main.c:108
-#: ../vector/v.overlay/main.c:188 ../vector/v.label/main.c:268
-#: ../vector/v.to.rast3/main.c:73 ../vector/v.drape/main.c:143
-#: ../vector/v.decimate/main.c:270 ../vector/v.net.steiner/main.c:432
-#: ../vector/v.type/main.c:131 ../vector/v.out.dxf/main.c:80
-#: ../vector/v.surf.idw/read_sites.c:29 ../vector/v.normal/main.c:110
-#: ../vector/v.net.allpairs/main.c:130 ../vector/v.colors/main.c:262
-#: ../vector/v.net.timetable/main.c:353 ../vector/v.hull/main.c:87
-#: ../vector/v.db.connect/main.c:154 ../vector/v.generalize/main.c:325
-#: ../vector/v.vect.stats/main.c:242 ../vector/v.vect.stats/main.c:253
-#: ../vector/v.out.svg/main.c:139 ../vector/v.distance/main.c:310
-#: ../vector/v.distance/main.c:332 ../vector/v.net.path/main.c:158
-#: ../vector/v.perturb/main.c:147 ../vector/v.perturb/main.c:172
-#: ../vector/v.voronoi/main.c:196 ../vector/v.lidar.growing/main.c:138
-#: ../vector/v.lidar.growing/main.c:142 ../vector/v.surf.rst/main.c:528
-#: ../vector/v.surf.rst/main.c:632 ../vector/v.clean/main.c:283
-#: ../vector/v.clean/test/topocheck.c:67 ../vector/v.clean/test/topocheck.c:87
-#: ../vector/v.delaunay/main.c:120 ../vector/v.neighbors/main.c:88
-#: ../vector/v.build.polylines/main.c:152 ../vector/v.net.distance/main.c:192
-#: ../vector/v.net.alloc/main.c:174 ../vector/v.edit/main.c:168
-#: ../vector/v.edit/main.c:240 ../vector/v.out.ogr/main.c:129
-#: ../vector/v.net.bridge/main.c:118 ../vector/v.support/main.c:130
-#: ../vector/v.net.components/main.c:148 ../vector/v.kernel/main.c:319
-#: ../vector/v.kernel/main.c:332 ../vector/v.external/main.c:189
-#: ../vector/v.out.pov/main.c:97 ../vector/v.to.points/main.c:121
-#: ../vector/v.buffer/main.c:338 ../vector/v.random/main.c:199
-#: ../vector/v.what.rast/main.c:131 ../vector/v.sample/main.c:124
-#: ../vector/v.out.ascii/main.c:87 ../vector/v.out.ascii/main.c:94
-#: ../vector/v.qcount/main.c:101 ../vector/v.select/main.c:108
-#: ../vector/v.patch/main.c:127 ../vector/v.patch/main.c:145
-#: ../vector/v.patch/main.c:175 ../vector/v.patch/main.c:272
-#: ../vector/v.patch/main.c:353 ../vector/v.lidar.edgedetection/main.c:219
-#: ../vector/v.net/main.c:68 ../vector/v.net/main.c:92
-#: ../vector/v.out.postgis/main.c:100 ../vector/v.to.rast/vect2rast.c:39
-#: ../vector/v.to.rast/support.c:100 ../vector/v.to.rast/support.c:272
-#: ../vector/v.to.rast/support.c:510 ../vector/v.build/main.c:118
-#: ../vector/v.build/main.c:128 ../vector/v.colors.out/scan_cats.c:20
-#: ../vector/v.colors.out/make_colors.c:23 ../vector/v.split/main.c:172
-#: ../vector/v.proj/main.c:231 ../vector/v.to.db/main.c:59
-#: ../vector/v.parallel/main.c:148 ../vector/v.db.select/main.c:164
-#: ../vector/v.net.iso/main.c:211 ../vector/v.rectify/main.c:148
-#: ../vector/v.net.salesman/main.c:250 ../vector/v.to.3d/main.c:72
-#: ../vector/v.extrude/main.c:190 ../vector/v.vol.rst/main.c:560
-#: ../vector/v.univar/main.c:158 ../vector/v.net.visibility/main.c:73
-#: ../vector/v.net.visibility/main.c:82
-#: ../vector/v.lidar.correction/main.c:186
-#: ../vector/v.net.connectivity/main.c:130
+#: ../general/g.mapset/main.c:145
+#, c-format
+msgid "You don't have permission to use the mapset <%s>"
+msgstr ""
+#: ../general/g.mapset/main.c:153
#, fuzzy, c-format
-msgid "Unable to open vector map <%s>"
+msgid "Unable to create new mapset <%s>"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.flow/main.c:414 ../vector/v.colors/main.c:266
-#: ../vector/v.to.rast/vect2rast.c:48
+#: ../general/g.mapset/main.c:156
#, fuzzy, c-format
-msgid "Vector map <%s> is not 3D"
+msgid "Mapset <%s> does not exist. Use -c flag to create it."
msgstr "출력할 격자지도"
-#: ../raster3d/r3.flow/main.c:441
+#: ../general/g.mapset/main.c:166
#, fuzzy
-msgid "Error during reading seed vector map"
+msgid "Unable to read GIS_LOCK environment variable"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.vtk/parameters.c:30
-#, fuzzy
-msgid "3D raster map(s) to be converted to VTK-ASCII data format"
-msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.vtk/parameters.c:34 ../raster/r.out.vtk/parameters.c:36
-msgid "Name for VTK-ASCII output file"
+#: ../general/g.mapset/main.c:182
+#, c-format
+msgid "Lock file of mapset <%s> cannot be checked"
msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:41
-msgid "Float value to represent no data cell/points"
+#: ../general/g.mapset/main.c:185
+#, c-format
+msgid "There appears to be an active GRASS session in selected mapset <%s>"
msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:47
-msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:56
+#: ../general/g.mapset/main.c:191
#, fuzzy
-msgid "Top surface 2D raster map"
+msgid "Cleaning up temporary files..."
msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.vtk/parameters.c:65
-#, fuzzy
-msgid "Bottom surface 2D raster map"
-msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.vtk/parameters.c:71
+#: ../general/g.mapset/main.c:205
msgid ""
-"Create 3D elevation output with a top and a bottom surface, both raster maps "
-"are required."
+"Mapset switched. Your shell continues to use the history for the old mapset"
msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:80
+#: ../general/g.mapset/main.c:210
+#, c-format
msgid ""
-"Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
+"You can switch the history by commands:\n"
+"history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:88
-msgid "Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]"
+#: ../general/g.mapset/main.c:215
+#, c-format
+msgid ""
+"history -S; history -L %s/.history; setenv histfile=%s/.history"
msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:94 ../raster/r.out.vtk/parameters.c:85
-#: ../vector/v.out.vtk/main.c:76
-msgid "Scale factor for elevation"
+#: ../general/g.mapset/main.c:221
+#, c-format
+msgid "Your current mapset is <%s>"
msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:107 ../raster/r.out.vtk/parameters.c:98
-#: ../raster/r.out.ascii/main.c:79 ../display/d.rast.num/main.c:104
-#: ../vector/v.out.ascii/args.c:75 ../vector/v.out.vtk/main.c:70
-msgid "Number of significant digits (floating point only)"
+#: ../general/g.pnmcomp/main.c:54
+msgid "Error reading PPM file"
msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:112
-msgid "Use 3D raster mask (if exists) with input maps"
+#: ../general/g.pnmcomp/main.c:69 ../general/g.pnmcomp/main.c:74
+#: ../general/g.pnmcomp/main.c:83 ../general/g.pnmcomp/main.c:134
+#: ../general/g.pnmcomp/main.c:147
+msgid "Invalid PPM file"
msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:117
-#, fuzzy
-msgid "Scale factor affects the origin"
+#: ../general/g.pnmcomp/main.c:96
+#, fuzzy, c-format
+msgid "File <%s> not found"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.vtk/parameters.c:123
-#: ../raster/r.out.vtk/parameters.c:128
-msgid "Correct the coordinates to match the VTK-OpenGL precision"
+#: ../general/g.pnmcomp/main.c:104
+msgid "Expecting PPM but got PGM"
msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:129
-msgid ""
-"Do not convert the top-bottom resolution in case of lat long projection to "
-"meters"
+#: ../general/g.pnmcomp/main.c:109
+msgid "Expecting PGM but got PPM"
msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:117
-msgid "Specify top and bottom map"
+#: ../general/g.pnmcomp/main.c:112
+#, c-format
+msgid "Invalid magic number: 'P%c'"
msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:124
-#, c-format
-msgid "Top cell map <%s> not found"
+#: ../general/g.pnmcomp/main.c:125 ../general/g.pnmcomp/main.c:142
+msgid "Invalid PGM file"
msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:133
-#, c-format
-msgid "Bottom cell map <%s> not found"
+#: ../general/g.pnmcomp/main.c:247
+msgid "Error writing PPM file"
msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:152
-#, fuzzy, c-format
-msgid "3D raster map RGB map <%s> not found"
-msgstr "출력할 격자지도"
+#: ../general/g.pnmcomp/main.c:264
+msgid "Error writing PGM file"
+msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:155
+#: ../general/g.pnmcomp/main.c:285
#, fuzzy
-msgid "Please provide three RGB 3D raster maps"
+msgid "Overlays multiple PPM image files."
msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.vtk/main.c:165
-#, fuzzy, c-format
-msgid "3D vector map <%s> not found"
+#: ../general/g.pnmcomp/main.c:296
+#, fuzzy
+msgid "Name of input mask file(s)"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.vtk/main.c:168
+#: ../general/g.pnmcomp/main.c:309
#, fuzzy
-msgid "Please provide three 3D raster maps for the xyz-vector maps [x,y,z]"
+msgid "Name for output mask file"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.vtk/main.c:175
+#: ../general/g.list/main.c:67
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:4
+#: ../locale/scriptstrings/t.list_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:5
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:5
+msgid "list"
+msgstr "목록"
+#: ../general/g.list/main.c:68
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:4
+#, fuzzy
+msgid "search"
+msgstr "검색경로"
+#: ../general/g.list/main.c:70
msgid ""
-"No 3D raster data, RGB or xyz-vector maps are provided! Will only write the "
-"geometry."
+"Lists available GRASS data base files of the user-specified data type "
+"optionally using the search pattern."
msgstr ""
+"선택적인 검색패턴을 이용해서 사용자가 지정한 자료형의 유효한 GRASS 데이타베이"
+"스 파일을 나열합니다."
-#: ../raster3d/r3.out.vtk/main.c:209
-msgid "No RGB Data will be created."
-msgstr ""
+#: ../general/g.list/main.c:86
+msgid "Map name search pattern (default: all)"
+msgstr "지도이름 검색패턴 (기본값: 모두)"
-#: ../raster3d/r3.out.vtk/main.c:294
-msgid "No vector data will be created."
-msgstr ""
+#: ../general/g.list/main.c:94
+msgid "Map name exclusion pattern (default: none)"
-#: ../raster3d/r3.out.vtk/main.c:381
+#: ../general/g.list/main.c:100
+msgid "Name of mapset to list (default: current search path)"
+msgstr "나열할 지도세트의 이름 (기본값: 현재 검색경로)"
+#: ../general/g.list/main.c:102
+msgid "'.' for current mapset; '*' for all mapsets in location"
+msgstr "현재 지도세트 '.'; 로케이션 안의 모든 지도세트 '*'"
+#: ../general/g.list/main.c:108
#, fuzzy
-msgid "Converts 3D raster maps into the VTK-ASCII format."
+msgid "Name of saved region for map search (default: not restricted)"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.vtk/main.c:392
-msgid "failed to interpret dp as an integer"
-msgstr ""
+#: ../general/g.list/main.c:110
+#, fuzzy
+msgid "'.' for current region; '*' for default region"
-#: ../raster3d/r3.out.vtk/main.c:394 ../raster/r.out.ascii/main.c:116
-msgid "dp has to be from 0 to 20"
-msgstr ""
+#: ../general/g.list/main.c:114
+#: ../locale/scriptstrings/d.out.file_to_translate.c:4
+#: ../raster/r.topmodel/main.c:72
+msgid "Name for output file"
+msgstr "출력파일 이름"
-#: ../raster3d/r3.out.vtk/main.c:542
-#, fuzzy
-msgid "Unable to close 3D raster map, the VTK file may be incomplete"
+#: ../general/g.list/main.c:115 ../vector/v.out.ascii/args.c:33
+msgid "If not given or '-' then standard output"
+msgstr "지정하지 않거나 '-'이면 표준출력"
+#: ../general/g.list/main.c:137
+msgid "Print data types"
+msgstr "자료형을 출력합니다"
+#: ../general/g.list/main.c:142
+msgid "Print fully-qualified map names (including mapsets)"
+msgstr "지도세트를 포함한 완전한 지도이름을 출력합니다"
+#: ../general/g.list/main.c:147
+msgid "Pretty printing in human readable format"
+msgstr "사람이 읽기 쉬운 양식으로 출력합니다"
+#: ../general/g.list/main.c:152
+msgid "Verbose listing (also list map titles)"
+msgstr "지도제목을 포함한 상세목록을 나열합니다"
+#: ../general/g.list/main.c:269
+#, fuzzy, c-format
+msgid "Mapset <%s> does not exist"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.vtk/main.c:557
-#, fuzzy
-msgid "Unable to close VTK-ASCII file"
+#: ../general/g.list/list.c:123 ../general/g.region/main.c:454
+#, fuzzy, c-format
+msgid "Unable to read header of 3D raster map <%s@%s>"
msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.vtk/writeVTKData.c:122
-msgid "write_vtk_points: Writing point coordinates"
-msgstr ""
+#: ../general/g.list/list.c:131
+#, fuzzy, c-format
+msgid "Unable to open vector map <%s@%s> on topological level"
+msgstr "출력할 격자지도"
-#: ../raster3d/r3.out.vtk/writeVTKData.c:256
-msgid "write_vtk_unstructured_grid_cells: Writing the cells"
-msgstr ""
+#: ../general/g.setproj/main.c:79 ../general/g.proj/main.c:65
+#: ../locale/scriptstrings/r.import_to_translate.c:4
+#: ../locale/scriptstrings/v.import_to_translate.c:4
+#: ../locale/scriptstrings/m.proj_to_translate.c:3 ../raster/r.proj/main.c:145
+#: ../raster/r.latlong/main.c:59 ../vector/v.proj/main.c:68
+msgid "projection"
+msgstr "투영"
-#: ../raster3d/r3.out.vtk/writeVTKData.c:335
+#: ../general/g.setproj/main.c:81
+msgid "Interactively reset the location's projection settings."
+msgstr "로케이션의 투영설정을 대화식으로 재설정합니다."
+#: ../general/g.setproj/main.c:88
+msgid "You must be in the PERMANENT mapset to run g.setproj"
+msgstr "g.setproj를 실행하기 위해서는 PERMANENT 지도세트 안에 있어야 합니다"
+#: ../general/g.setproj/main.c:101
+msgid "PERMANENT: permission denied"
+msgstr "PERMANENT: 허가되지 않았습니다"
+#: ../general/g.setproj/main.c:105
+msgid "Current region cannot be set"
+msgstr "현재지역을 설정할 수 없습니다"
+#: ../general/g.setproj/main.c:108
+msgid "Retrieving and setting region failed"
+msgstr "지역을 읽고 설정하는데 실패했습니다"
+#: ../general/g.setproj/main.c:135
+msgid "Would you still like to change some of the parameters?"
+msgstr "아직도 일부 매개변수를 바꾸기 원합니까?"
+#: ../general/g.setproj/main.c:137
+msgid "The projection information will not be updated"
+msgstr "투영정보가 갱신되지 않을 겁니다"
+#: ../general/g.setproj/main.c:148
#, c-format
msgid ""
-"write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
-"ascii file"
+"Zone in default geographic region definition: %d\n"
+" is different from zone in PROJ_INFO file: %d"
msgstr ""
+"기본 지리지역정의 내의 구역 %d\n"
+" 이 PROJ_INFO 파일 내의 구역 %d와 다릅니다"
-#: ../raster3d/r3.out.vtk/writeVTKData.c:441
-msgid "Wrong 3D raster map values! Values should in between 0 and 255!"
-msgstr ""
+#: ../general/g.setproj/main.c:158
+msgid "XY-location cannot be projected"
+msgstr "XY-로케이션은 투영할 수 없습니다"
-#: ../raster3d/r3.out.vtk/errorHandling.c:105
-#, fuzzy
-msgid "Unable to close input raster maps"
-msgstr "출력할 격자지도"
+#: ../general/g.setproj/main.c:192
+msgid "Unknown projection"
+msgstr "알려지지 않은 투영"
-#: ../raster3d/r3.neighbors/main.c:94 ../raster/r.resamp.stats/main.c:298
-#: ../raster/r.series/main.c:104 ../raster/r.neighbors/main.c:102
+#: ../general/g.setproj/main.c:198
#, c-format
-msgid "Unknown method <%s>"
-msgstr ""
+msgid "Projection %s is not specified in the file 'proj-parms.table'"
+msgstr "투영 %s이 'proj-parms.table' 파일 안에 정의되지 않았습니다"
-#: ../raster3d/r3.neighbors/main.c:119 ../raster/r.series/main.c:161
-msgid "Aggregate operation"
-msgstr ""
+#: ../general/g.setproj/main.c:205
+msgid "Do you wish to specify a geodetic datum for this location?"
+msgstr "이 로케이션을 위한 측지계를 지정하길 원합니까?"
-#: ../raster3d/r3.neighbors/main.c:127 ../raster/r.resamp.stats/main.c:279
-#: ../raster/r.series/main.c:168 ../raster/r.neighbors/main.c:239
-#, fuzzy
-msgid "Quantile to calculate for method=quantile"
-msgstr "출력할 격자지도"
+#: ../general/g.setproj/main.c:214
+#, c-format
+msgid "The current datum is %s (%s)"
+msgstr "현재 측지계는 %s(%s)입니다"
-#: ../raster3d/r3.neighbors/main.c:137
-msgid ""
-"The size of the window in x, y and z direction, values must be odd integer "
-"numbers, eg: 3,3,3"
-msgstr ""
+#: ../general/g.setproj/main.c:217
+msgid "Do you wish to change the datum (or datum transformation parameters)?"
+msgstr "측지계(또는 측지계 변환매개변수)를 바꾸길 원합니까?"
-#: ../raster3d/r3.neighbors/main.c:209 ../raster/r.mfilter/main.c:57
-#: ../raster/r.quantile/main.c:262 ../raster/r.texture/main.c:102
-#: ../raster/r.mapcalc/main.c:70 ../raster/r.neighbors/main.c:168
-#: ../raster/r.mode/main.c:56
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:3
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:3
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:3
-#: ../vector/v.neighbors/main.c:51
-msgid "algebra"
-msgstr "대수"
+#: ../general/g.setproj/main.c:225
+msgid "The datum information has not been changed"
+msgstr "측지계정보를 바꾸지 않았습니다"
-#: ../raster3d/r3.neighbors/main.c:213 ../raster/r.neighbors/main.c:171
-msgid "neighbor"
-msgstr "이웃"
+#: ../general/g.setproj/main.c:288
+#, c-format
+msgid "The current ellipsoid is %s"
+msgstr "현재 타원체는 %s입니다"
-#: ../raster3d/r3.neighbors/main.c:214 ../raster/r.neighbors/main.c:172
-#, fuzzy
-msgid "focal statistics"
-msgstr "출력할 격자지도"
+#: ../general/g.setproj/main.c:290
+msgid "Do you want to change ellipsoid parameter?"
+msgstr "타원체 매개변수를 바꾸길 원합니까?"
-#: ../raster3d/r3.neighbors/main.c:215 ../raster/r.mfilter/main.c:59
-#: ../raster/r.resamp.filter/main.c:392 ../raster/r.neighbors/main.c:173
-#: ../vector/v.outlier/main.c:73
-msgid "filter"
-msgstr "여과"
+#: ../general/g.setproj/main.c:294
+msgid "The ellipse information has not been changed"
+msgstr "타원정보를 바꾸지 않았습니다"
-#: ../raster3d/r3.neighbors/main.c:218
-msgid ""
-"Makes each voxel value a function of the values assigned to the voxels "
-"around it, and stores new voxel values in an output 3D raster map"
-msgstr ""
+#: ../general/g.setproj/main.c:311
+#, c-format
+msgid "The radius is currently %f"
+msgstr "반경은 현재 %f입니다"
-#: ../raster3d/r3.neighbors/main.c:287
-#, fuzzy
-msgid "Unable to allocate buffer"
-msgstr "출력할 격자지도"
+#: ../general/g.setproj/main.c:312
+msgid "Do you want to change the radius?"
+msgstr "반경을 바꾸길 원합니까?"
-#: ../imagery/i.gensigset/parse.c:13 ../imagery/i.gensig/parse.c:14
-msgid "Ground truth training map"
-msgstr ""
+#: ../general/g.setproj/main.c:314 ../general/g.setproj/main.c:320
+msgid "Enter radius for the sphere in meters"
+msgstr "구체의 반경을 미터로 입력하세요"
-#: ../imagery/i.gensigset/parse.c:25 ../imagery/i.gensig/parse.c:26
-#: ../imagery/i.cluster/main.c:95
-#, fuzzy
-msgid "Name for output file containing result signatures"
-msgstr "출력할 격자지도"
+#: ../general/g.setproj/main.c:336
+msgid "Invalid input ellipsoid"
+msgstr "잘못된 입력 타원체"
-#: ../imagery/i.gensigset/parse.c:29
-msgid "Maximum number of sub-signatures in any class"
-msgstr ""
-#: ../imagery/i.gensigset/parse.c:44 ../imagery/i.pca/main.c:139
-#: ../imagery/i.gensig/parse.c:38
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:155
-#: ../doc/raster/r.example/main.c:105 ../raster/r.sim/simlib/output.c:363
-#: ../raster/r.sim/simlib/output.c:372 ../raster/r.sim/simlib/output.c:403
-#: ../raster/r.sim/simlib/output.c:412 ../raster/r.sim/simlib/output.c:458
-#: ../raster/r.sim/simlib/output.c:475 ../raster/r.sim/simlib/output.c:497
-#: ../raster/r.sim/simlib/output.c:541 ../raster/r.sim/simlib/output.c:583
-#: ../raster/r.sim/simlib/output.c:755 ../raster/r.buffer/main.c:112
-#: ../raster/r.tile/main.c:86 ../raster/r.spread/main.c:439
-#: ../raster/r.spread/main.c:442 ../raster/r.spread/main.c:445
-#: ../raster/r.spread/main.c:449 ../raster/r.spread/main.c:452
-#: ../raster/r.spread/main.c:455 ../raster/r.report/parse.c:273
-#: ../raster/r.kappa/main.c:150 ../raster/r.kappa/stats.c:33
-#: ../raster/r.kappa/stats.c:38 ../raster/r.cost/main.c:350
-#: ../raster/r.cost/main.c:665 ../raster/r.stream.extract/main.c:174
-#: ../raster/r.stream.extract/main.c:178 ../raster/r.stream.extract/main.c:183
-#: ../raster/r.colors/edit_colors.c:393 ../raster/r.carve/main.c:165
-#: ../raster/r.reclass/main.c:79 ../raster/r.info/main.c:104
-#: ../raster/r.compress/main.c:116 ../raster/r.compress/main.c:296
-#: ../raster/r.univar/r.univar_main.c:234 ../raster/r.cross/main.c:106
-#: ../raster/r.coin/main.c:121 ../raster/r.coin/main.c:123
-#: ../raster/r.category/main.c:119 ../raster/r.category/main.c:140
-#: ../raster/r.mapcalc/map.c:517 ../raster/r.ros/main.c:368
-#: ../raster/r.ros/main.c:379 ../raster/r.ros/main.c:384
-#: ../raster/r.ros/main.c:389 ../raster/r.ros/main.c:394
-#: ../raster/r.ros/main.c:408 ../raster/r.ros/main.c:412
-#: ../raster/r.ros/main.c:427 ../raster/r.ros/main.c:431
-#: ../raster/r.ros/main.c:442 ../raster/r.flow/io.c:65
-#: ../raster/r.flow/io.c:242 ../raster/r.null/main.c:128
-#: ../raster/r.distance/parse.c:72 ../raster/r.distance/parse.c:81
-#: ../raster/r.walk/main.c:435 ../raster/r.walk/main.c:440
-#: ../raster/r.walk/main.c:801 ../general/g.region/main.c:425
-#: ../general/g.region/main.c:749 ../general/g.region/main.c:757
-#: ../misc/m.nviz.image/surface.c:50 ../misc/m.nviz.image/surface.c:107
-#: ../vector/v.colors/main.c:312 ../vector/v.vol.rst/main.c:615
+#: ../general/g.setproj/main.c:447
#, c-format
-msgid "Raster map <%s> not found"
-msgstr "격자지도 <%s>를 찾지 못 했습니다"
+msgid "The UTM zone is now set to %d"
+msgstr "UTM 구역이 현재 %d로 설정되었습니다"
-#: ../imagery/i.gensigset/parse.c:47 ../imagery/i.smap/parse.c:61
-#: ../imagery/i.gensig/parse.c:41 ../imagery/i.maxlik/open.c:17
-#: ../imagery/i.cluster/main.c:169
-#, fuzzy, c-format
-msgid "Group <%s> not found in current mapset"
-msgstr "출력할 격자지도"
+#: ../general/g.setproj/main.c:450
+msgid "Do you want to change the UTM zone?"
+msgstr "UTM 구역을 바꾸길 원합니까?"
-#: ../imagery/i.gensigset/parse.c:50 ../imagery/i.smap/parse.c:64
-#: ../imagery/i.gensig/parse.c:44 ../imagery/i.maxlik/open.c:20
-#: ../imagery/i.cluster/main.c:172
-#, fuzzy, c-format
-msgid "Subgroup <%s> in group <%s> not found"
-msgstr "출력할 격자지도"
+#: ../general/g.setproj/main.c:451
+msgid "UTM zone information has not been updated"
+msgstr "UTM 구역정보를 갱신하지 않았습니다"
-#: ../imagery/i.gensigset/parse.c:57 ../imagery/i.gensig/parse.c:50
-#: ../imagery/i.cluster/main.c:179 ../raster/r.proj/main.c:245
-#: ../display/d.mon/start.c:52 ../vector/v.external/main.c:132
-#: ../vector/v.proj/main.c:144
-#, c-format
-msgid "option <%s>: <%s> exists. To overwrite, use the --overwrite flag"
+#: ../general/g.setproj/main.c:456
+msgid ""
+"But if you change zone, all the existing data will be interpreted by "
+"projection software. GRASS will not automatically re-project or even change "
+"the headers for existing maps."
msgstr ""
+"하지만 만약 구역을 바꾼다면 투영소프트웨어가 모든 기존의 자료를 해석할 것입니"
+"다. GRASS는 기존의 지도를 자동으로 재투영하거나 헤더를 바꾸지 않을 것입니다."
-#: ../imagery/i.gensigset/parse.c:63
-#, fuzzy, c-format
-msgid "Illegal number of sub-signatures (%s)"
-msgstr "출력할 격자지도"
+#: ../general/g.setproj/main.c:461
+msgid "Would you still like to change the UTM zone?"
+msgstr "아직도 UTM 구역을 바꾸길 원합니까?"
-#: ../imagery/i.gensigset/subcluster.c:76
+#: ../general/g.setproj/main.c:497
#, c-format
-msgid "Not enough pixels in class %d"
-msgstr ""
+msgid "Error writing PROJ_INFO file <%s>"
+msgstr "PROJ_INFO 파일 <%s>를 쓰는데 오류"
-#: ../imagery/i.gensigset/subcluster.c:86
+#: ../general/g.setproj/main.c:571
#, c-format
-msgid "Too many subclasses for class index %d"
-msgstr ""
+msgid "Enter plural form of units [meters]: "
+msgstr "단위의 복수형을 입력하세요 [meters]: "
-#: ../imagery/i.gensigset/subcluster.c:88
-#, fuzzy, c-format
-msgid "Number of subclasses set to %d"
-msgstr "출력할 격자지도"
+#: ../general/g.setproj/main.c:603
+#, c-format
+msgid "Enter singular for unit: "
+msgstr "단위의 단수형을 입력하세요: "
-#: ../imagery/i.gensigset/subcluster.c:106
+#: ../general/g.setproj/main.c:611
#, c-format
-msgid "Combining subclasses (%d,%d)..."
-msgstr ""
+msgid "Enter conversion factor from %s to meters: "
+msgstr "%s를 미터로 바꾸는 변환계수를 입력하세요: "
-#: ../imagery/i.gensigset/subcluster.c:318
+#: ../general/g.setproj/main.c:636
#, c-format
-msgid "Subsignature %d only contains %.0f pixels"
+msgid "Error writing into UNITS output file <%s>"
+msgstr "UNITS 출력파일 <%s>로 쓰는데 오류"
+#: ../general/g.setproj/main.c:643
+msgid "Unable to write to DEFAULT_WIND region file"
+msgstr "DEFAULT_WIND 지역파일을 쓸 수 없습니다"
+#: ../general/g.setproj/main.c:645
+#, c-format
+msgid ""
+"\n"
+"Projection information has been recorded for this location\n"
+"\n"
msgstr ""
+"\n"
+"이 로케이션을 위한 투영정보를 기록했습니다\n"
+"\n"
-#: ../imagery/i.gensigset/subcluster.c:552
-msgid "Unreliable clustering. Try a smaller initial number of clusters"
+#: ../general/g.setproj/main.c:647
+msgid "The geographic region information in WIND is now obsolete"
+msgstr "WIND 안에 있는 지리지역정보는 이제 쓸모가 없습니다"
+#: ../general/g.setproj/main.c:648
+msgid "Run g.region -d to update it"
+msgstr "이것을 갱신하기 위해서는 g.region -d를 실행하세요"
+#: ../general/g.setproj/get_stp.c:43
+msgid "This should not happen. See your system admin."
msgstr ""
-#: ../imagery/i.gensigset/subcluster.c:561
+#: ../general/g.setproj/get_stp.c:99
+msgid "Unable to open FIPS code file"
+msgstr "FIPS 코드파일을 열 수 없습니다"
+#: ../general/g.setproj/get_stp.c:125
#, c-format
-msgid "Removed a singular subsignature number %d (%d remain)"
+msgid "No match of FIPS state %d county %d"
msgstr ""
-#: ../imagery/i.gensigset/read_data.c:22 ../imagery/i.ifft/main.c:141
-#: ../imagery/i.cluster/main.c:293
-#, fuzzy
-msgid "Reading raster maps..."
-msgstr "출력할 격자지도"
+#: ../general/g.setproj/get_stp.c:162 ../general/g.setproj/get_stp.c:165
+#: ../general/g.setproj/get_stp.c:282 ../general/g.setproj/get_stp.c:286
+#: ../raster3d/r3.in.ascii/main.c:169 ../raster/r.resamp.rst/main.c:542
+#: ../raster/r.in.ascii/main.c:120 ../raster/r.in.ascii/main.c:150
+#: ../display/d.title/main.c:117 ../vector/v.surf.rst/main.c:821
+#: ../vector/v.in.ascii/main.c:273
+#, c-format
+msgid "Unable to open temporary file <%s>"
+msgstr "임시파일 <%s>를 열 수 없습니다"
-#: ../imagery/i.gensigset/write_sig.c:13 ../imagery/i.gensig/write_sig.c:15
-#, fuzzy, c-format
-msgid "Unable to create signature file <%s>"
-msgstr "출력할 격자지도"
+#: ../general/g.setproj/get_stp.c:179
+msgid "Reading sf key_value temp file"
+msgstr "sf key_value 임시파일을 읽습니다"
-#: ../imagery/i.gensigset/write_sig.c:16 ../imagery/i.gensig/write_sig.c:18
-#, fuzzy
-msgid "Writing signatures..."
-msgstr "출력할 격자지도"
+#: ../general/g.setproj/get_stp.c:212
+msgid "Invalid State FIPS code"
+msgstr "잘못된 주 FIPS 코드"
-#: ../imagery/i.gensigset/main.c:40 ../imagery/i.evapo.pt/main.c:66
-#: ../imagery/i.cca/main.c:84 ../imagery/i.evapo.mh/main.c:69
-#: ../imagery/i.zc/main.c:52 ../imagery/i.fft/main.c:78
-#: ../imagery/i.aster.toar/main.c:97 ../imagery/i.landsat.toar/main.c:70
-#: ../imagery/i.rectify/main.c:99 ../imagery/i.his.rgb/main.c:46
-#: ../imagery/i.group/main.c:52 ../imagery/i.biomass/main.c:50
-#: ../imagery/i.evapo.time/main.c:77 ../imagery/i.smap/main.c:38
-#: ../imagery/i.rgb.his/main.c:46 ../imagery/i.pca/main.c:72
-#: ../imagery/i.eb.evapfr/main.c:47 ../imagery/i.ifft/main.c:77
-#: ../imagery/i.gensig/main.c:39 ../imagery/i.segment/main.c:36
-#: ../imagery/i.vi/main.c:89 ../imagery/i.maxlik/main.c:61
-#: ../imagery/i.target/main.c:45 ../imagery/i.modis.qc/main.c:149
-#: ../imagery/i.evapo.pm/main.c:58 ../imagery/i.eb.netrad/main.c:56
-#: ../imagery/i.emissivity/main.c:44 ../imagery/i.albedo/main.c:95
-#: ../imagery/i.landsat.acca/main.c:105 ../imagery/i.eb.eta/main.c:42
-#: ../imagery/i.cluster/main.c:75
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:47
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:88
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:63
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:56
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:388
-#: ../imagery/i.eb.soilheatflux/main.c:49 ../imagery/i.topo.corr/main.c:47
-#: ../imagery/i.eb.hsebal01/main.c:104
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:2
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:4
-#: ../locale/scriptstrings/i.spectral_to_translate.c:2
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:2
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:2
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:2
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
-#: ../locale/scriptstrings/i.oif_to_translate.c:2
-msgid "imagery"
-msgstr ""
+#: ../general/g.setproj/get_stp.c:302
+msgid "Reading cf key_value temp file"
+msgstr "cf key_value 임시파일을 읽습니다"
-#: ../imagery/i.gensigset/main.c:41 ../imagery/i.smap/main.c:39
-#: ../imagery/i.gensig/main.c:40 ../imagery/i.segment/main.c:38
-#: ../imagery/i.maxlik/main.c:62 ../imagery/i.cluster/main.c:76
-#: ../raster/r.kappa/main.c:70 ../vector/v.class/main.c:46
-#, fuzzy
-msgid "classification"
-msgstr "출력할 격자지도"
+#: ../general/g.setproj/get_stp.c:336
+msgid "Invalid County FIPS code"
+msgstr "잘못된 카운티 FIPS 코드"
-#: ../imagery/i.gensigset/main.c:42 ../imagery/i.smap/main.c:40
-#: ../imagery/i.gensig/main.c:41
-#, fuzzy
-msgid "supervised classification"
-msgstr "출력할 격자지도"
+#: ../general/g.setproj/proj.c:168
+#, c-format
+msgid "Unrecognized 'ask' value in parms.table: %s"
+msgstr "parms.table에 잘못된 'ask' 값: %s"
-#: ../imagery/i.gensigset/main.c:43 ../imagery/i.smap/main.c:42
-msgid "SMAP"
+#: ../general/g.setproj/proj.c:178
+#, c-format
+msgid "Unrecognized default value in parms.table: %s"
+msgstr "parms.table에 잘못된 기본값: %s"
+#: ../general/g.parser/main.c:74
+msgid "Usage"
msgstr ""
-#: ../imagery/i.gensigset/main.c:44 ../imagery/i.gensig/main.c:44
-#: ../imagery/i.cluster/main.c:77
+#: ../general/g.parser/main.c:84
#, fuzzy
-msgid "signatures"
+msgid "Unable to open script file"
msgstr "출력할 격자지도"
-#: ../imagery/i.gensigset/main.c:46
+#: ../general/g.parser/main.c:99
+#, c-format
+msgid "Line too long or missing newline at line %d\n"
+msgstr ""
+#: ../general/g.parser/main.c:139
#, fuzzy
-msgid "Generates statistics for i.smap from raster map."
+msgid "Error closing script file"
msgstr "출력할 격자지도"
-#: ../imagery/i.gensigset/main.c:56
+#: ../general/g.parser/rules.c:14
#, fuzzy, c-format
-msgid "Clustering class %d (%d pixels)..."
+msgid "Unknown flag \"-%c\" in rule\n"
msgstr "출력할 격자지도"
-#: ../imagery/i.gensigset/main.c:59
+#: ../general/g.parser/rules.c:26
#, fuzzy, c-format
-msgid "Number of subclasses is %d"
-msgstr "출력할 격자지도"
+msgid "Unknown option \"%s\" in rule\n"
+msgstr "알려지지 않은 작업 '%s'"
-#: ../imagery/i.gensigset/openfiles.c:18 ../imagery/i.smap/openfiles.c:18
-#: ../imagery/i.smap/read_sig.c:13 ../imagery/i.gensig/openfiles.c:19
+#: ../general/g.parser/rules.c:94
#, fuzzy, c-format
-msgid "Unable to read REF file for subgroup <%s> in group <%s>"
+msgid "Unknown rule type \"%s\" at line %d\n"
msgstr "출력할 격자지도"
-#: ../imagery/i.gensigset/openfiles.c:22 ../imagery/i.gensig/openfiles.c:23
+#: ../general/g.parser/revoke.c:63
+msgid "G_spawn() failed"
+msgstr ""
+#: ../general/g.parser/revoke.c:71
+msgid "execl() failed"
+msgstr ""
+#: ../general/g.parser/parse.c:22
+#, c-format
+msgid "Unknown boolean value \"%s\" at line %d\n"
+msgstr ""
+#: ../general/g.parser/parse.c:70
#, fuzzy, c-format
-msgid "Subgroup <%s> in group <%s> contains no raster maps."
+msgid "Unknown command \"%s\" at line %d\n"
msgstr "출력할 격자지도"
-#: ../imagery/i.gensigset/get_train.c:35 ../imagery/i.gensig/get_train.c:32
-#, fuzzy
-msgid "Finding training classes..."
-msgstr "출력할 격자지도"
+#: ../general/g.parser/parse.c:103
+#, c-format
+msgid "Unknown module parameter \"%s\" at line %d\n"
+msgstr ""
-#: ../imagery/i.gensigset/get_train.c:58 ../imagery/i.gensig/get_train.c:55
+#: ../general/g.parser/parse.c:140
#, c-format
-msgid "Training class %d only has one cell - this class will be ignored"
+msgid "Unknown flag parameter \"%s\" at line %d\n"
msgstr ""
-#: ../imagery/i.gensigset/get_train.c:63 ../imagery/i.gensig/get_train.c:60
-#, fuzzy
-msgid "Training map has no classes"
-msgstr "출력할 격자지도"
+#: ../general/g.parser/parse.c:155
+#, c-format
+msgid "Unknown type \"%s\" at line %d\n"
+msgstr ""
-#: ../imagery/i.gensigset/get_train.c:79 ../imagery/i.gensig/get_train.c:75
-#, fuzzy
-msgid "1 class found"
-msgstr "출력할 격자지도"
+#: ../general/g.parser/parse.c:233
+#, c-format
+msgid "Unknown option parameter \"%s\" at line %d\n"
+msgstr ""
-#: ../imagery/i.gensigset/get_train.c:81 ../imagery/i.gensig/get_train.c:77
-#, fuzzy, c-format
-msgid "%d classes found"
-msgstr "출력할 격자지도"
+#: ../general/g.mapsets/main.c:65
+msgid "search path"
+msgstr "검색경로"
-#: ../imagery/i.evapo.pt/main.c:67 ../imagery/i.evapo.mh/main.c:70
-#: ../imagery/i.evapo.time/main.c:78 ../imagery/i.evapo.pm/main.c:59
-#, fuzzy
-msgid "evapotranspiration"
-msgstr "출력할 격자지도"
+#: ../general/g.mapsets/main.c:66
+msgid "Modifies/prints the user's current mapset search path."
+msgstr "사용자의 지도세트 검색경로를 변경하거나 출력합니다."
-#: ../imagery/i.evapo.pt/main.c:69
+#: ../general/g.mapsets/main.c:67
msgid ""
-"Computes evapotranspiration calculation Priestley and Taylor formulation, "
-"1972."
+"Affects the user's access to data existing under the other mapsets in the "
+"current location."
msgstr ""
+"현재로케이션 안에 있는 다른 지도세트에 존재하는 자료에 대한 사용자의 접근에 "
+"영향을 미칩니다."
-#: ../imagery/i.evapo.pt/main.c:75
-#, fuzzy
-msgid "Name of input net radiation raster map [W/m2]"
-msgstr "출력할 격자지도"
+#: ../general/g.mapsets/main.c:73
+msgid "Name(s) of existing mapset(s) to add/remove or set"
+msgstr "추가/삭제 또는 설정하고 싶은 존재하는 지도세트의 이름들"
-#: ../imagery/i.evapo.pt/main.c:79
+#: ../general/g.mapsets/main.c:81
+#: ../locale/scriptstrings/g.extension.all_to_translate.c:6
+#: ../locale/scriptstrings/g.extension_to_translate.c:10
+#: ../vector/v.net/args.c:36
#, fuzzy
-msgid "Name of input soil heat flux raster map [W/m2]"
+msgid "Operation to be performed"
msgstr "출력할 격자지도"
-#: ../imagery/i.evapo.pt/main.c:83
-#, fuzzy
-msgid "Name of input air temperature raster map [K]"
-msgstr "출력할 격자지도"
+#: ../general/g.mapsets/main.c:85
+msgid "Field separator for printing (-l and -p flags)"
+msgstr "출력을 위한 필드구분자(-l과 -p 플래그)"
-#: ../imagery/i.evapo.pt/main.c:87
-#, fuzzy
-msgid "Name of input atmospheric pressure raster map [millibars]"
-msgstr "출력할 격자지도"
+#: ../general/g.mapsets/main.c:91
+msgid "List all available mapsets in alphabetical order"
+msgstr "모든 지도세트을 알파벳순으로 나열합니다"
-#: ../imagery/i.evapo.pt/main.c:93
-msgid "Priestley-Taylor coefficient"
-msgstr ""
+#: ../general/g.mapsets/main.c:97
+msgid "Print mapsets in current search path"
+msgstr "검색경로에 있는 지도세트을 출력합니다"
-#: ../imagery/i.evapo.pt/main.c:97
-#, fuzzy
-msgid "Name of output evapotranspiration raster map [mm/d]"
-msgstr "출력할 격자지도"
+#: ../general/g.mapsets/main.c:103
+msgid "Launch mapset selection GUI dialog"
+msgstr "지도세트선택 GUI 대화창을 시작합니다"
-#: ../imagery/i.evapo.pt/main.c:102 ../imagery/i.evapo.mh/main.c:105
-msgid "Set negative ETa to zero"
-msgstr ""
+#: ../general/g.mapsets/main.c:126
+#, c-format
+msgid "Unknown operation '%s'"
-#: ../imagery/i.cca/transform.c:24
-msgid "Unable to allocate cell buffers."
-msgstr ""
+#: ../general/g.mapsets/main.c:136 ../general/g.mapsets/main.c:138
+#: ../general/g.mapsets/main.c:148 ../display/d.mon/main.c:157
+#, c-format
+msgid "Flag -%c ignored"
+msgstr "-%c 플래그를 무시합니다"
-#: ../imagery/i.cca/transform.c:58
-msgid "Transform completed.\n"
-msgstr ""
+#: ../general/g.mapsets/main.c:140 ../general/g.mapsets/main.c:150
+#: ../general/g.mapsets/main.c:158 ../display/d.mon/main.c:202
+#, c-format
+msgid "Option <%s> ignored"
+msgstr "<%s> 옵션을 무시합니다"
-#: ../imagery/i.cca/main.c:87
-msgid "canonical components analysis"
-msgstr ""
+#: ../general/g.mapsets/main.c:174 ../general/g.mapsets/main.c:208
+#, c-format
+msgid "Mapset <%s> not found"
+msgstr "지도세트 <%s>를 찾지 못 했습니다"
-#: ../imagery/i.cca/main.c:89
-msgid "Canonical components analysis (CCA) program for image processing."
-msgstr ""
+#: ../general/g.mapsets/main.c:181 ../general/g.mapsets/main.c:240
+#, c-format
+msgid "Current mapset (<%s>) must always included in the search path"
+msgstr "현재지도세트(<%s>)이 반드시 검색경로에 포함되어야 합니다"
-#: ../imagery/i.cca/main.c:96
-msgid "Name of input imagery subgroup"
-msgstr ""
+#: ../general/g.mapsets/main.c:203
+#, c-format
+msgid "Mapset <%s> already in the path"
+msgstr "지도세트 <%s>가 경로에 이미 존재합니다"
-#: ../imagery/i.cca/main.c:103
-#, fuzzy
-msgid "File containing spectral signatures"
-msgstr "출력할 격자지도"
+#: ../general/g.mapsets/main.c:210
+#, c-format
+msgid "Mapset <%s> added to search path"
+msgstr "지도세트 <%s>를 검색경로에 추가했습니다"
-#: ../imagery/i.cca/main.c:106
-msgid "Output raster map prefix name"
-msgstr ""
+#: ../general/g.mapsets/main.c:243
+#, c-format
+msgid "Mapset <%s> removed from search path"
+msgstr "지도세트 <%s>를 검색경로에서 제거했습니다"
-#: ../imagery/i.cca/main.c:114
-msgid "Unknown imagery group."
-msgstr ""
+#: ../general/g.mapsets/main.c:255
+msgid "Search path not modified"
+msgstr "검색경로가 변경되지 않았습니다"
-#: ../imagery/i.cca/main.c:117
-msgid "Unable to find subgroup reference information."
-msgstr ""
+#: ../general/g.mapsets/main.c:273
+msgid "Unable to open SEARCH_PATH for write"
+msgstr "SEARCH_PATH를 쓰기를 위해서 열지 못 했습니다"
-#: ../imagery/i.cca/main.c:123
-msgid "Unable to open the signature file"
-msgstr ""
+#: ../general/g.mapsets/list.c:10
+msgid "Available mapsets:"
+msgstr "유효한 지도세트들:"
-#: ../imagery/i.cca/main.c:127
-msgid "Error while reading the signatures file."
-msgstr ""
+#: ../general/g.mapsets/list.c:35
+msgid "Accessible mapsets:"
+msgstr "접근 가능한 지도세트들:"
-#: ../imagery/i.cca/main.c:132
-msgid "Need at least two signatures in signature file."
+#: ../general/g.rename/main.c:47
+#: ../locale/scriptstrings/t.rename_to_translate.c:4
+msgid "rename"
+msgstr "이름변경"
+#: ../general/g.rename/main.c:49
+msgid "Renames data base element files in the user's current mapset."
msgstr ""
-#: ../imagery/i.cca/main.c:226
+#: ../general/g.rename/main.c:55
+msgid "renamed"
+msgstr "이름을 변경"
+#: ../general/g.rename/main.c:76
#, c-format
-msgid "The output cell map <%s.%d> has values outside the 0-255 range."
-msgstr ""
+msgid "%s <%s> not found"
+msgstr "%s <%s>를 찾지 못 했습니다"
-#: ../imagery/i.evapo.mh/main.c:72
-msgid ""
-"Computes evapotranspiration calculation modified or original Hargreaves "
-"formulation, 2001."
-msgstr ""
+#: ../general/g.rename/main.c:80
+#, c-format
+msgid "<%s> already exists in mapset <%s>"
+msgstr "<%s>가 지도세트 <%s> 안에 이미 존재합니다."
-#: ../imagery/i.evapo.mh/main.c:78
-#, fuzzy
-msgid "Name of input diurnal net radiation raster map [W/m2/d]"
-msgstr "출력할 격자지도"
+#: ../general/g.rename/main.c:85 ../general/g.copy/main.c:80
+#: ../raster/r.watershed/shed/com_line.c:231
+#: ../raster/r.watershed/shed/com_line.c:266
+#: ../imagery/i.landsat.toar/main.c:564
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:114
+#: ../imagery/i.landsat.acca/main.c:188
+#, c-format
+msgid "<%s> is an illegal file name"
+msgstr "<%s>는 잘못된 파일이름입니다"
-#: ../imagery/i.evapo.mh/main.c:82
+#: ../general/g.rename/main.c:90
+#, c-format
+msgid "%s=%s,%s: files could be the same, no rename possible"
+msgstr "%s=%s,%s: 같은 파일일 수 있으므로 이름변경이 불가능합니다"
+#: ../general/g.rename/main.c:116
#, fuzzy
-msgid "Name of input average air temperature raster map [C]"
+msgid "Updating reclass maps"
msgstr "출력할 격자지도"
-#: ../imagery/i.evapo.mh/main.c:86
-#, fuzzy
-msgid "Name of input minimum air temperature raster map [C]"
+#: ../general/g.rename/main.c:184
+#, fuzzy, c-format
+msgid "Unable to find reclass information for <%s> in base map <%s@%s>"
msgstr "출력할 격자지도"
-#: ../imagery/i.evapo.mh/main.c:90
-#, fuzzy
-msgid "Name of input maximum air temperature raster map [C]"
+#: ../general/g.rename/main.c:188
+#, fuzzy, c-format
+msgid "Updating base map <%s@%s>"
msgstr "출력할 격자지도"
-#: ../imagery/i.evapo.mh/main.c:96
-#, fuzzy
-msgid "Name of precipitation raster map [mm/month]"
+#: ../general/g.rename/main.c:194
+#, fuzzy, c-format
+msgid "Unable to update dependency file in <%s@%s>"
msgstr "출력할 격자지도"
-#: ../imagery/i.evapo.mh/main.c:97
-msgid "Disabled for original Hargreaves (1985)"
+#: ../general/g.region/printwindow.c:241 ../general/g.region/printwindow.c:497
+#: ../general/g.region/printwindow.c:616 ../raster/r.sun/main.c:745
+#: ../raster/r.horizon/main.c:531 ../display/d.where/main.c:107
+msgid "Can't get projection info of current location"
msgstr ""
-#: ../imagery/i.evapo.mh/main.c:100
-#, fuzzy
-msgid "Name for output raster map [mm/d]"
-msgstr "출력할 격자지도"
+#: ../general/g.region/printwindow.c:244 ../general/g.region/printwindow.c:500
+#: ../general/g.region/printwindow.c:619 ../raster/r.sun/main.c:749
+#: ../raster/r.horizon/main.c:534 ../display/d.where/main.c:110
+msgid "Can't get projection units of current location"
+msgstr ""
-#: ../imagery/i.evapo.mh/main.c:109
-msgid "Use original Hargreaves (1985)"
+#: ../general/g.region/printwindow.c:247 ../general/g.region/printwindow.c:503
+#: ../general/g.region/printwindow.c:622 ../raster/r.sun/main.c:753
+#: ../raster/r.horizon/main.c:538 ../display/d.grid/plot.c:554
+#: ../display/d.where/main.c:113 ../ps/ps.map/do_geogrid.c:272
+msgid "Can't get projection key values of current location"
msgstr ""
-#: ../imagery/i.evapo.mh/main.c:113
-msgid "Use Hargreaves-Samani (1985)"
+#: ../general/g.region/printwindow.c:257 ../general/g.region/printwindow.c:510
+#: ../general/g.region/printwindow.c:641 ../raster/r.sunhours/main.c:232
+msgid "Unable to update lat/long projection parameters"
msgstr ""
-#: ../imagery/i.zc/main.c:53 ../vector/v.lidar.edgedetection/main.c:74
-msgid "edges"
+#: ../general/g.region/printwindow.c:275 ../general/g.region/printwindow.c:283
+#: ../general/g.region/printwindow.c:291 ../general/g.region/printwindow.c:299
+#: ../general/g.region/printwindow.c:528 ../general/g.region/printwindow.c:536
+#: ../general/g.region/printwindow.c:544 ../general/g.region/printwindow.c:552
+#: ../general/g.region/printwindow.c:670 ../general/g.region/printwindow.c:678
+#: ../general/g.region/printwindow.c:686 ../general/g.region/printwindow.c:694
+#: ../raster/r.sunhours/main.c:296 ../raster/r.sunhours/main.c:391
+#: ../raster/r.sunmask/g_solposition.c:127
+msgid "Error in pj_do_proj (projection of input coordinate pair)"
msgstr ""
-#: ../imagery/i.zc/main.c:55
-msgid "Zero-crossing \"edge detection\" raster function for image processing."
+#: ../general/g.region/printwindow.c:404
+msgid "You are already in Lat/Long. Use the -p flag instead."
msgstr ""
-#: ../imagery/i.zc/main.c:65 ../raster/r.random/main.c:60
-#: ../raster/r.out.bin/main.c:290
-msgid "Name of input raster map"
+#: ../general/g.region/printwindow.c:406
+msgid ""
+"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
+"the -p flag instead."
msgstr ""
-#: ../imagery/i.zc/main.c:73
-#, fuzzy
-msgid "Zero crossing raster map"
-msgstr "출력할 격자지도"
+#: ../general/g.region/printwindow.c:631
+msgid ""
+"WGS84 output not possible as this location does not contain datum "
+"transformation parameters. Try running g.setproj."
+msgstr ""
-#: ../imagery/i.zc/main.c:80
-msgid "x-y extent of the Gaussian filter"
+#: ../general/g.region/printwindow.c:777
+msgid "Lat/Long calculations are not possible from a simple XY system"
msgstr ""
-#: ../imagery/i.zc/main.c:88
-msgid "Sensitivity of Gaussian filter"
+#: ../general/g.region/main.c:67
+msgid "Manages the boundary definitions for the geographic region."
msgstr ""
-#: ../imagery/i.zc/main.c:96
-#, fuzzy
-msgid "Number of azimuth directions categorized"
-msgstr "출력할 격자지도"
-#: ../imagery/i.zc/main.c:108
-msgid "Threshold less than or equal to zero not allowed"
+#: ../general/g.region/main.c:73 ../raster/r.region/main.c:65
+msgid "Set from default region"
msgstr ""
-#: ../imagery/i.zc/main.c:114
-msgid "Width less than or equal to zero not allowed"
+#: ../general/g.region/main.c:74 ../general/g.region/main.c:80
+#: ../general/g.region/main.c:167 ../general/g.region/main.c:174
+#: ../general/g.region/main.c:183 ../general/g.region/main.c:191
+#: ../raster/r.region/main.c:61 ../raster/r.region/main.c:66
+#: ../raster/r.region/main.c:81 ../raster/r.region/main.c:88
+#: ../raster/r.region/main.c:95 ../raster/r.region/main.c:138
+msgid "Existing"
msgstr ""
-#: ../imagery/i.zc/main.c:118
-msgid "Fewer than 1 orientation classes not allowed"
+#: ../general/g.region/main.c:78
+msgid "Save as default region"
msgstr ""
-#: ../imagery/i.zc/main.c:132
-#, c-format
-msgid "Power 2 values : %d rows %d columns"
+#: ../general/g.region/main.c:79
+msgid "Only possible from the PERMANENT mapset"
msgstr ""
-#: ../imagery/i.zc/main.c:142
-msgid "Initializing data..."
+#: ../general/g.region/main.c:84
+msgid "Print the current region"
msgstr ""
-#: ../imagery/i.zc/main.c:152 ../raster/r.carve/raster.c:13
-#: ../raster/r.texture/main.c:288
-#, fuzzy
-msgid "Reading raster map..."
-msgstr "출력할 격자지도"
-#: ../imagery/i.zc/main.c:172
-msgid "Writing transformed data to file..."
+#: ../general/g.region/main.c:89
+msgid "Print the current region in lat/long using the current ellipsoid/datum"
msgstr ""
-#: ../imagery/i.zc/main.c:192
-msgid "Transform successful"
+#: ../general/g.region/main.c:95
+msgid "Print the current region extent"
msgstr ""
-#: ../imagery/i.fft/main.c:79 ../imagery/i.pca/main.c:73
-#: ../imagery/i.ifft/main.c:78
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:390
-#: ../raster/r.proj/main.c:146
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:3
-#: ../locale/scriptstrings/m.proj_to_translate.c:4
-#: ../misc/m.transform/main.c:317 ../vector/v.transform/main.c:70
-#: ../vector/v.proj/main.c:69
-#, fuzzy
-msgid "transformation"
-msgstr "출력할 격자지도"
-#: ../imagery/i.fft/main.c:80 ../imagery/i.ifft/main.c:79
-msgid "Fast Fourier Transform"
+#: ../general/g.region/main.c:101
+msgid "Print the current region map center coordinates"
msgstr ""
-#: ../imagery/i.fft/main.c:82
-msgid "Fast Fourier Transform (FFT) for image processing."
+#: ../general/g.region/main.c:107
+msgid "Print the current region in GMT style"
msgstr ""
-#: ../imagery/i.fft/main.c:90
-#, fuzzy
-msgid "Name for output real part arrays stored as raster map"
-msgstr "출력할 격자지도"
-#: ../imagery/i.fft/main.c:94
-#, fuzzy
-msgid "Name for output imaginary part arrays stored as raster map"
-msgstr "출력할 격자지도"
-#: ../imagery/i.fft/main.c:106
-msgid "Raster MASK found, consider to remove (see man-page). Will continue..."
+#: ../general/g.region/main.c:113
+msgid "Print the current region in WMS style"
msgstr ""
-#: ../imagery/i.fft/main.c:129
-#, fuzzy, c-format
-msgid "Reading the raster map <%s>..."
-msgstr "출력할 격자지도"
-#: ../imagery/i.fft/main.c:145
-msgid "Starting FFT..."
+#: ../general/g.region/main.c:119
+msgid "Print region resolution in meters (geodesic)"
msgstr ""
-#: ../imagery/i.fft/main.c:166 ../imagery/i.ifft/main.c:191
-msgid "Rotating data..."
+#: ../general/g.region/main.c:124
+msgid "Print the convergence angle (degrees CCW)"
msgstr ""
-#: ../imagery/i.fft/main.c:174
-#, fuzzy
-msgid "Writing transformed data..."
-msgstr "출력할 격자지도"
-#: ../imagery/i.fft/main.c:200
-msgid " "
+#: ../general/g.region/main.c:126
+msgid ""
+"The difference between the projection's grid north and true north, measured "
+"at the center coordinates of the current region."
msgstr ""
-#: ../imagery/i.find/main.c:63
-#, c-format
-msgid "usage: %s location mapset element file."
+#: ../general/g.region/main.c:132
+msgid "Print also 3D settings"
msgstr ""
-#: ../imagery/i.find/main.c:83
-msgid "Unable to open temp file."
+#: ../general/g.region/main.c:138
+msgid "Print the maximum bounding box in lat/long on WGS84"
msgstr ""
-#: ../imagery/i.aster.toar/main.c:98 ../imagery/i.landsat.toar/main.c:71
-msgid "radiometric conversion"
+#: ../general/g.region/main.c:143
+#: ../locale/scriptstrings/t.info_to_translate.c:9
+#: ../locale/scriptstrings/i.oif_to_translate.c:6
+#: ../raster/r.regression.line/main.c:69
+#: ../raster/r.regression.multi/main.c:161 ../imagery/i.group/main.c:88
+msgid "Print in shell script style"
msgstr ""
-#: ../imagery/i.aster.toar/main.c:99 ../imagery/i.landsat.toar/main.c:72
-#: ../imagery/i.landsat.toar/main.c:578
+#: ../general/g.region/main.c:148
#, fuzzy
-msgid "radiance"
+msgid "Print in shell script style, but in one line (flat)"
msgstr "출력할 격자지도"
-#: ../imagery/i.aster.toar/main.c:100 ../imagery/i.landsat.toar/main.c:73
-#: ../imagery/i.landsat.toar/main.c:580 ../imagery/i.modis.qc/main.c:151
-#: ../imagery/i.albedo/main.c:97
-#, fuzzy
-msgid "reflectance"
-msgstr "출력할 격자지도"
-#: ../imagery/i.aster.toar/main.c:101 ../imagery/i.landsat.toar/main.c:74
-msgid "brightness temperature"
+#: ../general/g.region/main.c:154
+msgid ""
+"Align region to resolution (default = align to bounds, works only for 2D "
+"resolution)"
msgstr ""
-#: ../imagery/i.aster.toar/main.c:102 ../imagery/i.landsat.toar/main.c:76
-#: ../imagery/i.modis.qc/main.c:154 ../imagery/i.albedo/main.c:98
-#: ../imagery/i.landsat.acca/main.c:108
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:4
-msgid "satellite"
+#: ../general/g.region/main.c:156 ../general/g.region/main.c:200
+#: ../general/g.region/main.c:209 ../general/g.region/main.c:218
+#: ../general/g.region/main.c:227 ../general/g.region/main.c:236
+#: ../general/g.region/main.c:245 ../general/g.region/main.c:321
+#: ../general/g.region/main.c:332 ../raster3d/r3.in.bin/main.c:284
+#: ../raster3d/r3.in.bin/main.c:292 ../raster3d/r3.in.bin/main.c:300
+#: ../raster3d/r3.in.bin/main.c:308 ../raster3d/r3.in.bin/main.c:316
+#: ../raster3d/r3.in.bin/main.c:323 ../raster3d/r3.in.bin/main.c:330
+#: ../raster3d/r3.in.bin/main.c:337 ../raster3d/r3.in.bin/main.c:344
+#: ../raster/r.in.bin/main.c:285 ../raster/r.in.bin/main.c:339
+#: ../raster/r.in.bin/main.c:347 ../raster/r.in.bin/main.c:355
+#: ../raster/r.in.bin/main.c:363 ../raster/r.in.bin/main.c:370
+#: ../raster/r.in.bin/main.c:377 ../raster/r.region/main.c:104
+#: ../raster/r.region/main.c:113 ../raster/r.region/main.c:122
+#: ../raster/r.region/main.c:131
+msgid "Bounds"
msgstr ""
-#: ../imagery/i.aster.toar/main.c:103 ../imagery/i.albedo/main.c:100
-msgid "ASTER"
+#: ../general/g.region/main.c:160
+msgid "Do not update the current region"
msgstr ""
-#: ../imagery/i.aster.toar/main.c:105
-msgid ""
-"Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
-"from ASTER DN."
+#: ../general/g.region/main.c:161 ../general/g.region/main.c:343
+#: ../vector/v.label/main.c:90 ../vector/v.label/main.c:95
+#: ../vector/v.label/main.c:170 ../vector/v.label/main.c:183
+msgid "Effects"
msgstr ""
-#: ../imagery/i.aster.toar/main.c:109
-msgid "Names of ASTER DN layers (15 layers)"
+#: ../general/g.region/main.c:166
+msgid "Set current region from named region"
msgstr ""
-#: ../imagery/i.aster.toar/main.c:116
+#: ../general/g.region/main.c:173
#, fuzzy
-msgid "Day of Year of satellite overpass [0-366]"
+msgid "Set region to match raster map(s)"
msgstr "출력할 격자지도"
-#: ../imagery/i.aster.toar/main.c:123
-msgid "Sun elevation angle (degrees, < 90.0)"
+#: ../general/g.region/main.c:181
+msgid "Set region to match 3D raster map(s) (both 2D and 3D values)"
msgstr ""
-#: ../imagery/i.aster.toar/main.c:126
+#: ../general/g.region/main.c:189
#, fuzzy
-msgid "Base name of the output layers (will add .x)"
+msgid "Set region to match vector map(s)"
msgstr "출력할 격자지도"
-#: ../imagery/i.aster.toar/main.c:131
-msgid "Output is radiance (W/m2)"
+#: ../general/g.region/main.c:199 ../raster/r.region/main.c:103
+msgid "Value for the northern edge"
msgstr ""
-#: ../imagery/i.aster.toar/main.c:135
-msgid "VNIR is High Gain"
+#: ../general/g.region/main.c:208 ../raster/r.region/main.c:112
+msgid "Value for the southern edge"
msgstr ""
-#: ../imagery/i.aster.toar/main.c:139
-msgid "SWIR is High Gain"
+#: ../general/g.region/main.c:217 ../raster/r.region/main.c:121
+msgid "Value for the eastern edge"
msgstr ""
-#: ../imagery/i.aster.toar/main.c:143
-msgid "VNIR is Low Gain 1"
+#: ../general/g.region/main.c:226 ../raster/r.region/main.c:130
+msgid "Value for the western edge"
msgstr ""
-#: ../imagery/i.aster.toar/main.c:147
-msgid "SWIR is Low Gain 1"
+#: ../general/g.region/main.c:235
+msgid "Value for the top edge"
msgstr ""
-#: ../imagery/i.aster.toar/main.c:151
-msgid "SWIR is Low Gain 2"
+#: ../general/g.region/main.c:244
+msgid "Value for the bottom edge"
msgstr ""
-#: ../imagery/i.aster.toar/main.c:231 ../imagery/i.albedo/main.c:167
-#, c-format
-msgid "Too many input maps. Only %d allowed."
+#: ../general/g.region/main.c:253
+msgid "Number of rows in the new region"
msgstr ""
-#: ../imagery/i.aster.toar/main.c:246
-msgid "The input band number should be 15"
+#: ../general/g.region/main.c:254 ../general/g.region/main.c:263
+#: ../general/g.region/main.c:273 ../general/g.region/main.c:283
+#: ../general/g.region/main.c:292 ../general/g.region/main.c:301
+#: ../general/g.region/main.c:310
+msgid "Resolution"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:69
-msgid ""
-"Calculates top-of-atmosphere radiance or reflectance and temperature for "
-"Landsat MSS/TM/ETM+/OLI"
+#: ../general/g.region/main.c:262
+msgid "Number of columns in the new region"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:75
-msgid "atmospheric correction"
+#: ../general/g.region/main.c:272
+msgid "2D grid resolution (north-south and east-west)"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:77 ../imagery/i.albedo/main.c:99
-#: ../imagery/i.landsat.acca/main.c:109
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:4
-msgid "Landsat"
+#: ../general/g.region/main.c:282
+msgid "3D grid resolution (north-south, east-west and top-bottom)"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:82 ../imagery/i.landsat.acca/main.c:112
-#, fuzzy
-msgid "Base name of input raster bands"
-msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.toar/main.c:83 ../imagery/i.landsat.acca/main.c:113
-msgid "Example: 'B.' for B.1, B.2, ..."
+#: ../general/g.region/main.c:291
+msgid "North-south 2D grid resolution"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:86
-#, fuzzy
-msgid "Prefix for output raster maps"
-msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.toar/main.c:88
-msgid "Example: 'B.toar.' generates B.toar.1, B.toar.2, ..."
+#: ../general/g.region/main.c:300
+msgid "East-west 2D grid resolution"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:93
-msgid "Name of Landsat metadata file (.met or MTL.txt)"
+#: ../general/g.region/main.c:309
+msgid "Top-bottom 3D grid resolution"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:94 ../imagery/i.landsat.toar/main.c:116
-#: ../imagery/i.landsat.toar/main.c:126 ../imagery/i.landsat.toar/main.c:135
-#: ../imagery/i.landsat.toar/main.c:143 ../imagery/i.landsat.toar/main.c:152
-#: ../raster/r.external/main.c:91 ../raster/r.in.gdal/main.c:134
-#: ../raster/r.in.gdal/main.c:143 ../raster/r.in.gdal/main.c:152
-#: ../raster/r.in.gdal/main.c:158
-#: ../locale/scriptstrings/r.import_to_translate.c:25
-msgid "Metadata"
+#: ../general/g.region/main.c:319
+msgid "Shrink region until it meets non-NULL data from this raster map"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:99
-msgid "Spacecraft sensor"
+#: ../general/g.region/main.c:330
+msgid "Adjust region cells to cleanly align with this raster map"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:100
-msgid "Required only if 'metfile' not given (recommended for sanity)"
+#: ../general/g.region/main.c:341
+msgid "Save current region settings in named region file"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:105
-msgid "Landsat-1 MSS"
+#: ../general/g.region/main.c:410
+#, c-format
+msgid "Region <%s> not found"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:106
-msgid "Landsat-2 MSS"
+#: ../general/g.region/main.c:451 ../raster3d/r3.out.v5d/main.c:307
+#: ../raster3d/r3.out.bin/main.c:299 ../raster3d/r3.neighbors/main.c:229
+#: ../raster3d/r3.out.ascii/main.c:326 ../raster3d/r3.null/main.c:103
+#: ../raster3d/r3.cross.rast/main.c:245 ../raster3d/r3.stats/main.c:96
+#: ../raster3d/r3.out.netcdf/main.c:600 ../raster3d/r3.flow/main.c:87
+#: ../raster3d/r3.support/main.c:135 ../raster3d/r3.mask/main.c:58
+#: ../raster3d/r3.to.rast/main.c:275 ../raster3d/r3.timestamp/main.c:73
+#: ../raster3d/r3.retile/main.c:113 ../raster3d/r3.out.vtk/main.c:142
+#: ../raster/r.univar/r3.univar_main.c:144
+#: ../raster/r.univar/r3.univar_main.c:182 ../raster/r.colors/edit_colors.c:400
+#: ../vector/v.colors/main.c:319
+#, c-format
+msgid "3D raster map <%s> not found"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:107
-msgid "Landsat-3 MSS"
-msgstr ""
+#: ../general/g.region/main.c:480 ../vector/v.out.postgis/main.c:110
+#, fuzzy, c-format
+msgid "Unable to open vector map <%s> on topological level"
+msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.toar/main.c:108
-msgid "Landsat-4 MSS"
-msgstr ""
+#: ../general/g.region/main.c:767
+#, fuzzy, c-format
+msgid "Unable to set region <%s>"
+msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.toar/main.c:109
-msgid "Landsat-5 MSS"
+#: ../general/g.region/main.c:773
+msgid "Unable to update current region"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:110
-msgid "Landsat-4 TM"
+#: ../general/g.region/main.c:781
+msgid "Unable to change default region. The current mapset is not <PERMANENT>."
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:111
-msgid "Landsat-5 TM"
+#: ../general/g.region/main.c:798 ../raster/r.in.lidar/main.c:523
+#, c-format
+msgid "Invalid input <%s=%s>"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:112
-msgid "Landsat-7 ETM+"
-msgstr ""
+#: ../general/g.proj/main.c:66
+#, fuzzy
+msgid "create location"
+msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.toar/main.c:113
-msgid "Landsat_8 OLI/TIRS"
+#: ../general/g.proj/main.c:69
+msgid ""
+"Prints or modifies GRASS projection information files (in various co-"
+"ordinate system descriptions)."
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:123 ../imagery/i.landsat.toar/main.c:124
-msgid "Atmospheric correction method"
+#: ../general/g.proj/main.c:72
+msgid "Can also be used to create new GRASS locations."
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:133
-msgid "Image acquisition date (yyyy-mm-dd)"
+#: ../general/g.proj/main.c:75
+msgid "Prints and manipulates GRASS projection information files."
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:134 ../imagery/i.landsat.toar/main.c:142
-#: ../imagery/i.landsat.toar/main.c:151 ../imagery/i.landsat.toar/main.c:159
-msgid "Required only if 'metfile' not given"
+#: ../general/g.proj/main.c:82
+msgid "Print projection information in conventional GRASS format"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:141
+#: ../general/g.proj/main.c:88
#, fuzzy
-msgid "Sun elevation in degrees"
+msgid "Print projection information in shell script style"
msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.toar/main.c:150
-msgid "Image creation date (yyyy-mm-dd)"
+#: ../general/g.proj/main.c:94
+msgid "Verify datum information and print transformation parameters"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:158
-msgid "Gain (H/L) of all Landsat ETM+ bands (1-5,61,62,7,8)"
+#: ../general/g.proj/main.c:100
+msgid "Print projection information in PROJ.4 format"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:160 ../imagery/i.landsat.toar/main.c:169
-#: ../imagery/i.landsat.toar/main.c:179 ../imagery/i.landsat.toar/main.c:188
-#: ../imagery/i.landsat.toar/main.c:209 ../imagery/i.segment/parse_args.c:68
-#: ../imagery/i.segment/parse_args.c:77 ../imagery/i.segment/parse_args.c:88
-#: ../imagery/i.segment/parse_args.c:99 ../imagery/i.segment/parse_args.c:109
-#: ../imagery/i.segment/parse_args.c:127 ../imagery/i.segment/parse_args.c:135
-#: ../imagery/i.segment/parse_args.c:144 ../imagery/i.segment/parse_args.c:151
-#: ../imagery/i.segment/parse_args.c:157 ../imagery/i.segment/parse_args.c:163
-#: ../imagery/i.segment/parse_args.c:169 ../imagery/i.segment/parse_args.c:176
-#: ../imagery/i.cluster/main.c:103 ../imagery/i.cluster/main.c:120
-#: ../imagery/i.cluster/main.c:128 ../imagery/i.cluster/main.c:137
-#: ../imagery/i.cluster/main.c:145 ../imagery/i.cluster/main.c:153
-#: ../db/db.login/main.c:60 ../db/db.login/main.c:68 ../db/db.login/main.c:77
-#: ../db/db.login/main.c:86 ../raster/r.slope.aspect/main.c:181
-#: ../raster/r.slope.aspect/main.c:189 ../raster/r.slope.aspect/main.c:247
-#: ../raster/r.slope.aspect/main.c:256 ../raster/r.slope.aspect/main.c:262
-#: ../raster/r.resamp.bspline/main.c:108 ../raster/r.resamp.bspline/main.c:116
-#: ../raster/r.resamp.bspline/main.c:122 ../raster/r.resamp.bspline/main.c:134
-#: ../raster/r.resamp.bspline/main.c:139 ../raster/r.in.bin/main.c:275
-#: ../raster/r.in.bin/main.c:280 ../raster/r.in.bin/main.c:306
-#: ../raster/r.in.bin/main.c:314 ../raster/r.in.bin/main.c:323
-#: ../raster/r.in.bin/main.c:384 ../raster/r.in.bin/main.c:398
-#: ../raster/r.resamp.rst/main.c:210 ../raster/r.resamp.rst/main.c:216
-#: ../raster/r.resamp.rst/main.c:224 ../raster/r.resamp.rst/main.c:232
-#: ../raster/r.resamp.rst/main.c:240 ../raster/r.out.mpeg/main.c:132
-#: ../raster/r.walk/main.c:274 ../raster/r.walk/main.c:284
-#: ../raster/r.walk/main.c:294 ../display/d.mon/main.c:70
-#: ../display/d.mon/main.c:78 ../display/d.mon/main.c:86
-#: ../display/d.mon/main.c:92 ../display/d.mon/main.c:98
-#: ../display/d.mon/main.c:133 ../display/d.mon/main.c:139
-#: ../display/d.mon/main.c:145 ../general/g.access/main.c:50
-#: ../general/g.access/main.c:58 ../vector/v.surf.idw/main.c:115
-#: ../vector/v.surf.idw/main.c:124 ../vector/v.surf.idw/main.c:132
-#: ../vector/v.db.connect/main.c:66 ../vector/v.db.connect/main.c:72
-#: ../vector/v.surf.bspline/main.c:113 ../vector/v.surf.bspline/main.c:120
-#: ../vector/v.surf.bspline/main.c:150 ../vector/v.surf.bspline/main.c:159
-#: ../vector/v.surf.bspline/main.c:167 ../vector/v.surf.bspline/main.c:179
-#: ../vector/v.external.out/args.c:20 ../vector/v.external.out/args.c:35
-#: ../vector/v.external.out/args.c:47 ../vector/v.external.out/args.c:53
-#: ../vector/v.lidar.edgedetection/main.c:95
-#: ../vector/v.lidar.edgedetection/main.c:104
-#: ../vector/v.lidar.edgedetection/main.c:113
-#: ../vector/v.lidar.edgedetection/main.c:122
-#: ../vector/v.lidar.edgedetection/main.c:131
-#: ../vector/v.lidar.edgedetection/main.c:139
-#: ../vector/v.lidar.edgedetection/main.c:148 ../vector/v.colors.out/main.c:68
-#: ../vector/v.colors.out/main.c:73 ../vector/v.vol.rst/main.c:268
-#: ../vector/v.vol.rst/main.c:276 ../vector/v.vol.rst/main.c:283
-#: ../vector/v.vol.rst/main.c:311 ../vector/v.vol.rst/main.c:320
-#: ../vector/v.vol.rst/main.c:329 ../vector/v.vol.rst/main.c:337
-#: ../vector/v.vol.rst/main.c:346 ../vector/v.vol.rst/main.c:354
-#: ../vector/v.outlier/main.c:104 ../vector/v.outlier/main.c:113
-#: ../vector/v.outlier/main.c:121 ../vector/v.lidar.correction/main.c:102
-#: ../vector/v.lidar.correction/main.c:111
-msgid "Settings"
-msgstr "설정"
-#: ../imagery/i.landsat.toar/main.c:166
-msgid "Percent of solar radiance in path radiance"
+#: ../general/g.proj/main.c:106
+msgid ""
+"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:167 ../imagery/i.landsat.toar/main.c:177
-msgid "Required only if 'method' is any DOS"
+#: ../general/g.proj/main.c:116
+msgid "Print projection information in WKT format"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:176
-msgid "Minimum pixels to consider digital number as dark object"
+#: ../general/g.proj/main.c:122
+msgid "Use ESRI-style format (applies to WKT output only)"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:185
-msgid "Rayleigh atmosphere (diffuse sky irradiance)"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:186
-msgid "Required only if 'method' is DOS3"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:195
-msgid "return value stored for a given metadata"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:196
-msgid "Required only if 'metfile' and -p given"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:202
-msgid "Landsat Number"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:203
+#: ../general/g.proj/main.c:129 ../general/g.proj/main.c:138
+#: ../general/g.proj/main.c:148 ../general/g.proj/main.c:158
#, fuzzy
-msgid "Creation timestamp"
+msgid "Specification"
msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.toar/main.c:204
-msgid "Date"
+#: ../general/g.proj/main.c:130
+msgid "Name of georeferenced data file to read projection information from"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:205
+#: ../general/g.proj/main.c:139
#, fuzzy
-msgid "Sun Elevation"
+msgid "Name of ASCII file containing a WKT projection description"
msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.toar/main.c:206
-msgid "Sensor"
+#: ../general/g.proj/main.c:141 ../general/g.proj/main.c:150
+#: ../locale/scriptstrings/m.proj_to_translate.c:8
+#: ../raster3d/r3.in.ascii/main.c:87 ../raster/r.reclass/main.c:66
+#: ../raster/r.recode/main.c:61 ../raster/r.in.ascii/main.c:79
+#: ../vector/v.segment/main.c:80 ../vector/v.edit/args.c:89
+#: ../vector/v.what/main.c:76 ../db/db.execute/main.c:139
+#: ../db/db.select/main.c:208
+msgid "'-' for standard input"
+msgstr "표준입력을 위해서는 '-'"
+#: ../general/g.proj/main.c:149
+msgid "PROJ.4 projection description"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:207
-msgid "Bands count"
+#: ../general/g.proj/main.c:159
+#: ../locale/scriptstrings/v.import_to_translate.c:21
+msgid "EPSG projection code"
msgstr ""
-msgid "Sun Azimuth Angle"
+#: ../general/g.proj/main.c:167 ../general/g.proj/main.c:180
+#: ../general/g.proj/main.c:186
+msgid "Datum"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:207 ../raster/r.sun/main.c:444
-#: ../raster/r.sun/main.c:453 ../raster/r.sun/main.c:470
-#: ../raster/r.sun/main.c:508 ../raster/r.sunhours/main.c:103
-#: ../raster/r.sunhours/main.c:112 ../raster/r.sunhours/main.c:120
-#: ../raster/r.sunhours/main.c:129 ../raster/r.sunhours/main.c:138
-#: ../raster/r.sunhours/main.c:147 ../raster/r.sunmask/main.c:153
-#: ../raster/r.sunmask/main.c:161 ../raster/r.sunmask/main.c:169
-#: ../raster/r.sunmask/main.c:177 ../raster/r.sunmask/main.c:185
-#: ../raster/r.sunmask/main.c:194 ../raster/r.sunmask/main.c:203
-msgid "Time"
+#: ../general/g.proj/main.c:169
+msgid "Datum (overrides any datum specified in input co-ordinate system)"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:216
+#: ../general/g.proj/main.c:171
+msgid "Accepts standard GRASS datum codes, or \"list\" to list and exit"
+msgstr ""
+#: ../general/g.proj/main.c:181
+#: ../locale/scriptstrings/v.import_to_translate.c:23
#, fuzzy
-msgid "Scale factor for output"
+msgid "Index number of datum transform parameters"
msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.toar/main.c:222
-msgid "Output at-sensor radiance instead of reflectance for all bands"
+#: ../general/g.proj/main.c:182
+msgid "\"0\" for unspecified or \"-1\" to list and exit"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:227
+#: ../general/g.proj/main.c:188
msgid ""
-"Input raster maps use as extension the number of the band instead the code"
+"Force override of datum transformation information in input co-ordinate "
+"system"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:231
-msgid "Print output metadata info"
+#: ../general/g.proj/main.c:193 ../raster/r.null/main.c:74
+#: ../raster/r.null/main.c:82
+msgid "Modify"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:257 ../imagery/i.landsat.toar/main.c:265
-#, c-format
-msgid "Illegal date format: [%s] (yyyy-mm-dd)"
+#: ../general/g.proj/main.c:194
+msgid "Modify current location projection files"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:287
-msgid "Please use a metadata keyword with -p"
+#: ../general/g.proj/main.c:202
+msgid "Name of new location to create"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:324
-msgid "Failed to identify satellite"
+#: ../general/g.proj/main.c:218
+#, c-format
+msgid "Only one of '%s', '%s', '%s' or '%s' options may be specified"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:338
-#, c-format
-msgid "Lacking '%s' and/or '%s' for this satellite"
+#: ../general/g.proj/main.c:263
+msgid "Projection files missing"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:344
-msgid "Landsat-7 requires band gain with 9 (H/L) characters"
+#: ../general/g.proj/main.c:283
+#, c-format
+msgid "Only one of -%c, -%c, -%c, -%c, -%c or -%c flags may be specified"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:364
+#: ../general/g.proj/main.c:310
#, c-format
-msgid "Unknown satellite type (defined by '%s')"
+msgid "No output format specified, define one of flags -%c, -%c, -%c, or -%c"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:407 ../imagery/i.landsat.toar/main.c:545
-#: ../imagery/i.landsat.acca/main.c:57
-#: ../imagery/i.landsat.acca/algorithm.c:380
-#: ../imagery/i.landsat.acca/tools.c:126 ../raster/r.random/random.c:43
-#: ../raster/r.random/random.c:47 ../raster/r.mapcalc/map3.c:517
+#: ../general/g.proj/main.c:314
#, c-format
-msgid "Unable to open raster map <%s>"
+msgid "No output format specified, define one of flags -%c, -%c, or -%c"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:411 ../imagery/i.landsat.toar/main.c:560
-#, fuzzy, c-format
-msgid "Unable to read data type of raster map <%s>"
-msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.toar/main.c:535 ../raster/r.topidx/topidx.c:41
-#: ../raster/r.flow/main.c:314
+#: ../general/g.proj/output.c:146
#, fuzzy
-msgid "Calculating..."
+msgid "Unable to convert projection information to PROJ.4 format"
msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.toar/main.c:549 ../raster/r.relief/main.c:194
-#: ../raster/r.in.gdal/main.c:346 ../raster/r.in.gdal/main.c:693
-#: ../vector/v.kernel/main.c:236
+#: ../general/g.proj/output.c:190
#, c-format
-msgid "Raster map <%s> already exists and will be overwritten"
-msgstr "격자지도 <%s>가 이미 존재하지만 덮어 씁니다"
+msgid "%s: Unable to convert to WKT"
+msgstr ""
-#: ../imagery/i.landsat.toar/main.c:553
-#, c-format
-msgid "Raster map <%s> exists. Skipping."
-msgstr "격자지도 <%s>가 존재합니다. 넘어갑니다."
-#: ../imagery/i.landsat.toar/main.c:564 ../imagery/i.landsat.acca/main.c:188
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:114
-#: ../raster/r.watershed/shed/com_line.c:231
-#: ../raster/r.watershed/shed/com_line.c:266 ../general/g.copy/main.c:80
-#: ../general/g.rename/main.c:85
-#, c-format
-msgid "<%s> is an illegal file name"
-msgstr "<%s>는 잘못된 파일이름입니다"
-#: ../imagery/i.landsat.toar/main.c:567
-#: ../imagery/i.landsat.acca/algorithm.c:234
-#: ../imagery/i.landsat.acca/algorithm.c:388
-#: ../imagery/i.landsat.acca/tools.c:136 ../raster/r.sunhours/main.c:324
-#: ../raster/r.sunhours/main.c:335 ../raster/r.sunhours/main.c:346
-#: ../raster/r.mapcalc/map3.c:606
-#, c-format
-msgid "Unable to create raster map <%s>"
+#: ../general/g.proj/input.c:91
+msgid "Error reading WKT projection description"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:576
+#: ../general/g.proj/input.c:98
#, fuzzy, c-format
-msgid "Writing %s of <%s> to <%s>..."
+msgid "Unable to open file '%s' for reading"
msgstr "출력할 격자지도"
-msgid "temperature"
+#: ../general/g.proj/input.c:143
+msgid "Can't parse PROJ.4-style parameter string"
msgstr ""
-#: ../imagery/i.landsat.toar/landsat.c:116
-msgid ""
-"The DOS4 method is not applicable here: approximation of atmospheric "
-"transmittance coefficients is unstable. Use another DOS method or use other "
-"sun_elevation parameter"
-msgstr ""
-#: ../imagery/i.landsat.toar/landsat_met.c:117
-#, fuzzy, c-format
-msgid "Metadata file <%s> not found"
+#: ../general/g.proj/input.c:181
+#, fuzzy
+msgid "Unable to translate EPSG code"
msgstr "출력할 격자지도"
-#: ../imagery/i.rectify/rectify.c:41
-#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:42
-#, fuzzy, c-format
-msgid "Rectify <%s@%s> (location <%s>)"
-msgstr "출력할 격자지도"
-#: ../imagery/i.rectify/rectify.c:44
-#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:46
-#, fuzzy, c-format
-msgid "into <%s@%s> (location <%s>) ..."
-msgstr "출력할 격자지도"
-#: ../imagery/i.rectify/rectify.c:108
-#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:126
-#, fuzzy, c-format
-msgid "Raster map <%s@%s>: projection don't match current settings"
-msgstr "출력할 격자지도"
-#: ../imagery/i.rectify/rectify.c:114
-#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:132
-#, fuzzy, c-format
-msgid "Raster map <%s@%s>: zone don't match current settings"
-msgstr "출력할 격자지도"
-#: ../imagery/i.rectify/get_wind.c:124
-#, c-format
-msgid "Region N=%f S=%f E=%f W=%f"
+#: ../general/g.proj/input.c:218
+msgid "Trying to open with OGR..."
msgstr ""
-#: ../imagery/i.rectify/get_wind.c:126
-#, c-format
-msgid "Resolution EW=%f NS=%f"
+#: ../general/g.proj/input.c:226 ../general/g.proj/input.c:245
+msgid "...succeeded."
msgstr ""
-#: ../imagery/i.rectify/report.c:10
-#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:10
-msgid "complete"
+#: ../general/g.proj/input.c:239
+msgid "Trying to open with GDAL..."
msgstr ""
-#: ../db/db.select/main.c:105
-msgid "failed"
-msgstr ""
-#: ../imagery/i.rectify/report.c:20
-#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:20
+#: ../general/g.proj/input.c:254
#, c-format
-msgid "%d rows, %d cols (%ld cells) completed in"
+msgid "Could not read georeferenced file %s using either OGR nor GDAL"
msgstr ""
-#: ../imagery/i.rectify/report.c:23
-#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:23
+#: ../general/g.proj/input.c:259
#, c-format
-msgid "%d:%02d:%02ld hours"
+msgid ""
+"Read of file %s was successful, but it did not contain projection "
+"information. 'XY (unprojected)' will be used"
msgstr ""
-#: ../imagery/i.rectify/report.c:25
-#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:25
-#, c-format
-msgid "%d:%02ld minutes"
-msgstr ""
+#: ../general/g.proj/datumtrans.c:47
+#, fuzzy, c-format
+msgid "Invalid datum code <%s>"
+msgstr "출력할 격자지도"
-#: ../imagery/i.rectify/report.c:27
-#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:27
-#, c-format
-msgid "%.1f cells per minute"
-msgstr ""
-#: ../imagery/i.rectify/target.c:14
-#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:13
-#: ../vector/v.rectify/target.c:18
-#, c-format
-msgid "Target information for group <%s> missing"
-msgstr ""
-#: ../imagery/i.rectify/target.c:20
-#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:19
-#: ../vector/v.rectify/target.c:29
+#: ../general/g.proj/datumtrans.c:77
#, fuzzy, c-format
-msgid "Target location <%s> not found"
+msgid "Datum set to <%s>"
msgstr "출력할 격자지도"
-#: ../imagery/i.rectify/target.c:32
-#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:31
-#: ../raster/r.in.gdal/main.c:947 ../vector/v.rectify/target.c:40
+#: ../general/g.proj/datumtrans.c:79
#, fuzzy, c-format
-msgid "Mapset <%s> in target location <%s> - "
+msgid "Ellipsoid set to <%s>"
msgstr "출력할 격자지도"
-#: ../imagery/i.rectify/target.c:33
-#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:32
-#: ../raster/r.proj/main.c:281 ../raster/r.in.gdal/main.c:949
-#: ../vector/v.rectify/target.c:41
-msgid "permission denied"
+#: ../general/g.proj/create.c:15 ../raster/r.in.gdal/main.c:439
+#: ../raster/r.in.gdal/main.c:849 ../vector/v.in.ogr/main.c:584
+#: ../vector/v.in.lidar/main.c:514
+#, c-format
+msgid "Location <%s> created"
msgstr ""
-#: ../raster/r.proj/main.c:282 ../raster/r.in.gdal/main.c:950
-#, fuzzy
-msgid "not found"
+#: ../general/g.proj/create.c:17
+#, fuzzy, c-format
+msgid "Unable to create location <%s>: %s"
msgstr "출력할 격자지도"
-#: ../imagery/i.rectify/target.c:36
-msgid "Please run i.target for group "
+#: ../general/g.proj/create.c:20
+#, c-format
+msgid "Unable to create projection files: %s"
msgstr ""
-#: ../imagery/i.rectify/cp.c:14 ../vector/v.rectify/cp.c:350
+#: ../general/g.proj/create.c:24
+#, fuzzy, c-format
+msgid "Unable to create location <%s>"
+msgstr "출력할 격자지도"
+#: ../general/g.proj/create.c:30
#, c-format
-msgid "Control Point file for group <%s@%s> - "
+msgid ""
+"You can switch to the new location by\n"
+"`%s=%s`"
msgstr ""
-#: ../imagery/i.rectify/cp.c:21
+#: ../general/g.proj/create.c:40
#, c-format
-msgid "Not enough active control points for thin plate spline."
+msgid ""
+"You must select the PERMANENT mapset before updating the current location's "
+"projection (current mapset is <%s>)"
msgstr ""
-#: ../imagery/i.rectify/cp.c:24 ../imagery/i.rectify/cp.c:51
-#: ../vector/v.rectify/cp.c:363
-msgid "Poorly placed control points."
+#: ../general/g.proj/create.c:66
+msgid ""
+"Default region was updated to the new projection, but if you have multiple "
+"mapsets `g.region -d` should be run in each to update the region from the "
+"default"
msgstr ""
-#: ../imagery/i.rectify/cp.c:25 ../imagery/i.rectify/cp.c:52
-#: ../vector/v.rectify/cp.c:364
+#: ../general/g.proj/create.c:70
#, fuzzy
-msgid " Can not generate the transformation equation."
+msgid "Projection information updated"
msgstr "출력할 격자지도"
-#: ../imagery/i.rectify/cp.c:28 ../imagery/i.rectify/cp.c:55
-#: ../vector/v.rectify/cp.c:367
-#, fuzzy
-msgid "Not enough memory to solve for transformation equation"
+#: ../general/g.proj/create.c:91
+#, fuzzy, c-format
+msgid "Unable to create PROJ_EPSG file: %s"
msgstr "출력할 격자지도"
-#: ../imagery/i.rectify/cp.c:31 ../imagery/i.rectify/cp.c:58
-#: ../vector/v.rectify/cp.c:370
-msgid "Invalid order"
-msgstr ""
-#: ../imagery/i.rectify/cp.c:47 ../vector/v.rectify/cp.c:359
-#, c-format
-msgid "Not enough active control points for current order, %d are required."
-msgstr ""
-#: ../imagery/i.rectify/main.c:100 ../vector/v.rectify/main.c:71
-msgid "rectify"
-msgstr ""
-#: ../imagery/i.rectify/main.c:102
-msgid ""
-"Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points."
-msgstr ""
-#: ../imagery/i.rectify/main.c:116
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:103
+#: ../general/g.mkfontcap/freetype_fonts.c:55
#, fuzzy
-msgid "Output raster map(s) suffix"
+msgid "Unable to initialise Freetype"
msgstr "출력할 격자지도"
-#: ../imagery/i.rectify/main.c:124 ../vector/v.rectify/main.c:102
-msgid "Rectification polynomial order (1-3)"
+#: ../general/g.mkfontcap/main.c:73
+msgid ""
+"Generates the font configuration file by scanning various directories for "
+"fonts."
msgstr ""
-#: ../imagery/i.rectify/main.c:130
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:109
-msgid "Target resolution (ignored if -c flag used)"
+#: ../general/g.mkfontcap/main.c:79
+msgid "Overwrite font configuration file if already existing"
msgstr ""
-#: ../imagery/i.rectify/main.c:138
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:117
-msgid "Amount of memory to use in MB"
+#: ../general/g.mkfontcap/main.c:84
+msgid ""
+"Write font configuration file to standard output instead of $GISBASE/etc"
msgstr ""
-#: ../imagery/i.rectify/main.c:148
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:127
-#: ../raster/r.proj/main.c:182
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
-msgid "Interpolation method to use"
+#: ../general/g.mkfontcap/main.c:91
+msgid "List of extra directories to scan"
msgstr ""
-#: ../imagery/i.rectify/main.c:153
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:137
+#: ../general/g.mkfontcap/main.c:93
msgid ""
-"Use current region settings in target location (def.=calculate smallest area)"
+"Comma-separated list of extra directories to scan for Freetype-compatible "
+"fonts as well as the defaults (see documentation)"
msgstr ""
-#: ../imagery/i.rectify/main.c:157
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:141
-#, fuzzy
-msgid "Rectify all raster maps in group"
-msgstr "출력할 격자지도"
-#: ../imagery/i.rectify/main.c:161
-msgid "Use thin plate spline"
-msgstr ""
-#: ../imagery/i.rectify/main.c:172
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:152
-#: ../raster/r.proj/main.c:237 ../raster/r.stats.zonal/main.c:165
-#: ../raster/r.statistics/main.c:118 ../vector/v.vect.stats/main.c:263
+#: ../general/g.mkfontcap/main.c:110
#, c-format
-msgid "<%s=%s> unknown %s"
+msgid ""
+"Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
msgstr ""
-#: ../imagery/i.rectify/main.c:199 ../vector/v.rectify/main.c:143
-#, c-format
-msgid "Invalid order (%d); please enter 1 to %d"
+#: ../general/g.mkfontcap/main.c:122
+msgid ""
+"This GRASS installation was compiled without Freetype support, extradirs "
+"parameter ignored"
msgstr ""
-#: ../imagery/i.rectify/main.c:206
+#: ../general/g.mkfontcap/main.c:149
#, fuzzy, c-format
-msgid "Location: %s"
+msgid "Cannot open %s for writing: %s"
msgstr "출력할 격자지도"
-#: ../imagery/i.rectify/main.c:207
-#, c-format
-msgid "Mapset: %s"
-msgstr ""
-#: ../imagery/i.rectify/main.c:208
+#: ../general/g.ppmtopng/main.c:34
#, fuzzy, c-format
-msgid "Group <%s> does not exist"
+msgid "Unable to open input file %s"
msgstr "출력할 격자지도"
-#: ../imagery/i.rectify/main.c:212
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:187
-#, c-format
-msgid "Group <%s> contains no raster maps; run i.group"
-msgstr ""
-#: ../imagery/i.rectify/main.c:287
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:281
+#: ../general/g.ppmtopng/main.c:37
#, fuzzy, c-format
-msgid "Extension <%s> is illegal"
+msgid "Invalid input file %s"
msgstr "출력할 격자지도"
-#: ../imagery/i.rectify/main.c:290
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:284
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:293
+#: ../general/g.ppmtopng/main.c:70 ../general/g.ppmtopng/main.c:74
+#: ../raster/r.in.png/main.c:307 ../raster/r.in.png/main.c:311
#, fuzzy
-msgid "The following raster map already exists in"
+msgid "Unable to allocate PNG structure"
msgstr "출력할 격자지도"
-#: ../imagery/i.rectify/main.c:291
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:285
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:294
-#: ../vector/v.rectify/main.c:202
-#, c-format
-msgid "target LOCATION %s, MAPSET %s:"
-msgstr ""
+#: ../general/g.ppmtopng/main.c:77
+#, fuzzy
+msgid "Error writing PNG file"
+msgstr "출력할 격자지도"
-#: ../imagery/i.rectify/main.c:294
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:288
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:297
-msgid "Orthorectification cancelled."
-msgstr ""
-#: ../imagery/i.rectify/main.c:309
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:312
-msgid "Target resolution must be > 0, ignored"
-msgstr ""
-#: ../imagery/i.rectify/main.c:320
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:319
-#, c-format
-msgid "Using region: N=%f S=%f, E=%f W=%f"
-msgstr ""
-#: ../imagery/i.rectify/main.c:335
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:386
+#: ../general/g.ppmtopng/main.c:81
#, fuzzy, c-format
-msgid "Input raster map <%s> does not exist in group <%s>."
+msgid "Unable to open output file %s"
msgstr "출력할 격자지도"
-#: ../imagery/i.rectify/main.c:337
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:388
-msgid "Try:"
+#: ../general/g.ppmtopng/main.c:119
+msgid "Converts between PPM/PGM and PNG image formats."
msgstr ""
-#: ../imagery/i.rectify/main.c:342
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:393
-msgid "Exit!"
+#: ../general/g.filename/main.c:42
+msgid "Prints GRASS data base file names."
msgstr ""
-#: ../imagery/i.rectify/readcell.c:58
-#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:64
-#: ../raster/r.stats.quantile/main.c:427 ../raster/r.proj/readcell.c:59
-#: ../raster/r.proj/readcell.c:129 ../raster/r.stats.zonal/main.c:482
-#, fuzzy
-msgid "Unable to open temporary file"
-msgstr "출력할 격자지도"
+#: ../general/g.filename/main.c:56
+msgid "Name of a database file"
+msgstr ""
-#: ../imagery/i.rectify/readcell.c:64
-#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:72
-msgid "Allocating memory and reading input map..."
+#: ../general/g.filename/main.c:62
+msgid "Name of a mapset (default: current)"
msgstr ""
-#: ../imagery/i.rectify/readcell.c:90 ../imagery/i.rectify/readcell.c:129
-#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:100
-#: ../raster/r.proj/readcell.c:92
-msgid "Error writing segment file"
+#: ../general/g.tempfile/main.c:41
+msgid "Creates a temporary file and prints it's file name."
msgstr ""
-#: ../imagery/i.rectify/readcell.c:117
-#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:130
-#: ../raster/r.proj/readcell.c:125
-msgid "Internal error: cache miss on fully-cached map"
+#: ../general/g.tempfile/main.c:47
+msgid "Process id to use when naming the tempfile"
msgstr ""
-#: ../imagery/i.rectify/readcell.c:126
-#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:139
-#: ../raster/r.proj/readcell.c:138
-msgid "Error seeking on segment file"
+#: ../general/g.tempfile/main.c:51
+msgid "Dry run - don't create a file, just prints it's file name"
msgstr ""
-#: ../imagery/i.his.rgb/main.c:47 ../imagery/i.rgb.his/main.c:47
-#: ../raster/r.his/main.c:68 ../display/d.his/main.c:64
-msgid "color transformation"
-msgstr "색상 변형"
-#: ../imagery/i.his.rgb/main.c:52
+#: ../general/g.copy/main.c:44
msgid ""
-"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
-"RGB (Red-Green-Blue) color space."
+"Copies available data files in the current mapset search path to the user's "
+"current mapset."
msgstr ""
+"지도세트 검색경로에 있는 자료파일을 사용자의 현재지도세트로 복사합니다."
-#: ../imagery/i.his.rgb/main.c:58
-#, fuzzy
-msgid "Name of input raster map (hue)"
-msgstr "출력할 격자지도"
+#: ../general/g.copy/main.c:51
+msgid "copied"
+msgstr "복사"
-#: ../imagery/i.his.rgb/main.c:62
-#, fuzzy
-msgid "Name of input raster map (intensity)"
-msgstr "출력할 격자지도"
+#: ../general/g.copy/main.c:66
+#, c-format
+msgid "<%s> not found"
+msgstr "<%s>를 찾지 못 했습니다"
-#: ../imagery/i.his.rgb/main.c:66
-#, fuzzy
-msgid "Name of input raster map (saturation)"
-msgstr "출력할 격자지도"
+#: ../general/g.copy/main.c:71
+#, c-format
+msgid "%s=%s,%s: files are the same, no copy required"
+msgstr "%s=%s,%s: 파일이 똑같아서 복사할 필요가 없습니다"
-#: ../imagery/i.his.rgb/main.c:70
-#, fuzzy
-msgid "Name for output raster map (red)"
-msgstr "출력할 격자지도"
+#: ../general/g.copy/main.c:76
+#, fuzzy, c-format
+msgid "<%s> already exists. File not copied."
-#: ../imagery/i.his.rgb/main.c:74
-#, fuzzy
-msgid "Name for output raster map (green)"
-msgstr "출력할 격자지도"
+#: ../general/g.message/main.c:37
+msgid ""
+"Prints a message, warning, progress info, or fatal error in the GRASS way."
+msgstr ""
-#: ../imagery/i.his.rgb/main.c:78
-#, fuzzy
-msgid "Name for output raster map (blue)"
-msgstr "출력할 격자지도"
+#: ../general/g.message/main.c:39
+msgid "This module should be used in scripts for messages served to user."
+msgstr ""
-#: ../imagery/i.group/main.c:53 ../imagery/i.target/main.c:46
-#: ../raster/r.compress/main.c:65
-#: ../locale/scriptstrings/t.list_to_translate.c:3
-#: ../locale/scriptstrings/t.register_to_translate.c:3
-#: ../locale/scriptstrings/t.rename_to_translate.c:3
-#: ../locale/scriptstrings/t.unregister_to_translate.c:3
-#: ../locale/scriptstrings/t.remove_to_translate.c:3
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:3
-#: ../locale/scriptstrings/t.create_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:3
-#: ../general/g.access/main.c:38 ../general/g.list/main.c:66
-#: ../general/g.dirseps/main.c:35 ../general/g.copy/main.c:42
-#: ../general/g.remove/main.c:70 ../general/g.findfile/main.c:39
-#: ../general/g.findetc/main.c:29 ../general/g.filename/main.c:40
-#: ../general/g.rename/main.c:46
-msgid "map management"
-msgstr "지도관리"
+#: ../general/g.message/main.c:44
+msgid "Print message as warning"
+msgstr ""
-#: ../imagery/i.group/main.c:55
-msgid "Creates, edits, and lists groups of imagery data."
+#: ../general/g.message/main.c:49
+msgid "Print message as fatal error"
msgstr ""
-#: ../imagery/i.group/main.c:59
-msgid "Name of imagery group"
+#: ../general/g.message/main.c:54
+msgid "Print message as debug message"
msgstr ""
-#: ../imagery/i.group/main.c:63
-#, fuzzy
-msgid "Name of imagery subgroup"
-msgstr "출력할 격자지도"
+#: ../general/g.message/main.c:59
+msgid "Print message as progress info"
+msgstr ""
-#: ../imagery/i.group/main.c:67
-#, fuzzy
-msgid "Name of raster map(s) to include in group"
-msgstr "출력할 격자지도"
-#: ../imagery/i.group/main.c:68 ../imagery/i.group/main.c:74
-msgid "Maps"
+#: ../general/g.message/main.c:63 ../general/g.message/main.c:69
+#: ../general/g.message/main.c:85
+msgid "Level"
msgstr ""
-#: ../imagery/i.group/main.c:73
-msgid "Remove selected files from specified group or subgroup"
+#: ../general/g.message/main.c:64
+msgid "Print message in all modes except of quiet mode"
msgstr ""
-#: ../imagery/i.group/main.c:78
-msgid "List files from specified (sub)group"
+#: ../general/g.message/main.c:65
+msgid "Message is printed on GRASS_VERBOSE>=1"
msgstr ""
-#: ../imagery/i.group/main.c:79 ../imagery/i.group/main.c:84
-#: ../imagery/i.group/main.c:89 ../db/db.connect/main.c:53
-#: ../db/db.connect/main.c:58 ../db/db.login/main.c:91
-#: ../raster/r.what/main.c:120 ../raster/r.what/main.c:128
-#: ../raster/r.what/main.c:142 ../raster/r.what/main.c:147
-#: ../raster/r.what/main.c:152 ../raster/r.what/main.c:157
-#: ../raster/r.proj/main.c:204 ../raster/r.proj/main.c:214
-#: ../raster/r.proj/main.c:220 ../raster/r.colors/edit_colors.c:128
-#: ../raster/r.external/main.c:96 ../raster/r.external/main.c:124
-#: ../raster/r.out.gdal/main.c:142 ../raster/r.external.out/main.c:272
-#: ../raster/r.external.out/main.c:283 ../raster/r.in.gdal/main.c:198
-#: ../raster/r.sunmask/main.c:232 ../raster/r.sunmask/main.c:238
-#: ../locale/scriptstrings/g.extension_to_translate.c:16
-#: ../locale/scriptstrings/g.extension_to_translate.c:18
-#: ../locale/scriptstrings/g.extension_to_translate.c:20
-#: ../locale/scriptstrings/g.extension_to_translate.c:22
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:18
-#: ../temporal/t.connect/main.c:43 ../display/d.mon/main.c:103
-#: ../display/d.mon/main.c:108 ../display/d.mon/main.c:113
-#: ../general/g.mapset/main.c:76 ../general/g.mapset/main.c:82
-#: ../general/g.list/main.c:105 ../general/g.list/main.c:116
-#: ../general/g.list/main.c:138 ../general/g.list/main.c:143
-#: ../general/g.list/main.c:148 ../general/g.list/main.c:153
-#: ../general/g.mapsets/main.c:87 ../general/g.mapsets/main.c:92
-#: ../general/g.mapsets/main.c:98 ../general/g.proj/main.c:80
-#: ../general/g.proj/main.c:86 ../general/g.proj/main.c:92
-#: ../general/g.proj/main.c:98 ../general/g.proj/main.c:104
-#: ../general/g.proj/main.c:115 ../general/g.proj/main.c:120
-#: ../general/g.region/main.c:85 ../general/g.region/main.c:91
-#: ../general/g.region/main.c:96 ../general/g.region/main.c:102
-#: ../general/g.region/main.c:108 ../general/g.region/main.c:114
-#: ../general/g.region/main.c:120 ../general/g.region/main.c:128
-#: ../general/g.region/main.c:133 ../general/g.region/main.c:139
-#: ../general/g.region/main.c:144 ../general/g.region/main.c:149
-#: ../vector/v.info/parse.c:25 ../vector/v.info/parse.c:31
-#: ../vector/v.info/parse.c:36 ../vector/v.info/parse.c:41
-#: ../vector/v.info/parse.c:46 ../vector/v.colors/main.c:133
-#: ../vector/v.db.connect/main.c:84 ../vector/v.db.connect/main.c:89
-#: ../vector/v.db.connect/main.c:96 ../vector/v.db.connect/main.c:103
-#: ../vector/v.in.ogr/main.c:257 ../vector/v.in.ogr/main.c:263
-#: ../vector/v.external/args.c:50 ../vector/v.external/args.c:56
-#: ../vector/v.external/args.c:64 ../vector/v.what/main.c:89
-#: ../vector/v.what/main.c:94 ../vector/v.what/main.c:99
-#: ../vector/v.what/main.c:104 ../vector/v.external.out/args.c:63
-#: ../vector/v.external.out/args.c:75 ../vector/v.external.out/args.c:81
-#: ../vector/v.to.db/parse.c:116 ../vector/v.to.db/parse.c:121
-#: ../vector/v.to.db/parse.c:127 ../vector/v.to.db/parse.c:133
-msgid "Print"
-msgstr "출력"
-#: ../imagery/i.group/main.c:83
-msgid "List subgroups from specified group"
+#: ../general/g.message/main.c:70
+msgid "Print message only in verbose mode"
msgstr ""
-#: ../imagery/i.group/main.c:88 ../raster/r.regression.multi/main.c:161
-#: ../raster/r.regression.line/main.c:69
-#: ../locale/scriptstrings/t.info_to_translate.c:9
-#: ../locale/scriptstrings/i.oif_to_translate.c:6
-#: ../general/g.region/main.c:143
-msgid "Print in shell script style"
+#: ../general/g.message/main.c:71
+msgid "Message is printed only on GRASS_VERBOSE>=3"
msgstr ""
-#: ../imagery/i.group/main.c:109
+#: ../general/g.message/main.c:78
#, fuzzy
-msgid "No input raster map(s) specified"
+msgid "Text of the message to be printed"
msgstr "출력할 격자지도"
-#: ../imagery/i.group/main.c:117 ../imagery/i.target/main.c:80
-#, fuzzy
-msgid "Group must exist in the current mapset"
-msgstr "출력할 격자지도"
+#: ../general/g.message/main.c:79
+msgid "Message is printed on GRASS_VERBOSE>=2"
+msgstr ""
-#: ../imagery/i.group/main.c:128 ../imagery/i.group/main.c:150
-#, fuzzy
-msgid "Specified group does not exist in current mapset"
-msgstr "출력할 격자지도"
+#: ../general/g.message/main.c:88
+msgid "Level to use for debug messages"
+msgstr ""
-#: ../imagery/i.group/main.c:132
-#, fuzzy, c-format
-msgid "Removing raster maps from subgroup <%s>..."
-msgstr "출력할 격자지도"
+#: ../general/g.message/main.c:95
+msgid "Select only one message level"
+msgstr ""
-#: ../imagery/i.group/main.c:137
-#, fuzzy, c-format
-msgid "Removing raster maps from group <%s>..."
+#: ../general/g.message/main.c:108
+#, fuzzy
+msgid "Unable to parse input message"
msgstr "출력할 격자지도"
-#: ../imagery/i.group/main.c:158
-#, fuzzy, c-format
-msgid "Subgroup <%s> of group <%s> references the following raster maps:"
-msgstr "출력할 격자지도"
+#: ../general/g.access/main.c:39
+msgid "permission"
+msgstr "허가"
-#: ../imagery/i.group/main.c:173
-#, fuzzy, c-format
-msgid "Group <%s> references the following raster maps:"
-msgstr "출력할 격자지도"
+#: ../general/g.access/main.c:41
+msgid "Controls access to the current mapset for other users on the system."
+msgstr "현재 지도세트에 대한 시스템에 있는 다른 사용자의 접근을 설정합니다."
-#: ../imagery/i.group/main.c:185
-#, fuzzy, c-format
-msgid "Group <%s> does not yet exist. Creating..."
-msgstr "출력할 격자지도"
+#: ../general/g.access/main.c:42
+msgid "If no option given, prints current status."
+msgstr "옵션이 주어지지 않으면 현재상태를 출력합니다."
-#: ../imagery/i.group/main.c:189 ../imagery/i.group/main.c:198
-#, fuzzy, c-format
-msgid "Adding raster maps to group <%s>..."
-msgstr "출력할 격자지도"
+#: ../general/g.access/main.c:49
+msgid "Access for group"
+msgstr "그룹의 접근"
-#: ../imagery/i.group/main.c:193
-#, fuzzy, c-format
-msgid "Adding raster maps to subgroup <%s>..."
-msgstr "출력할 격자지도"
+#: ../general/g.access/main.c:50 ../general/g.access/main.c:58
+#: ../raster/r.in.bin/main.c:275 ../raster/r.in.bin/main.c:280
+#: ../raster/r.in.bin/main.c:306 ../raster/r.in.bin/main.c:314
+#: ../raster/r.in.bin/main.c:323 ../raster/r.in.bin/main.c:384
+#: ../raster/r.in.bin/main.c:398 ../raster/r.resamp.bspline/main.c:108
+#: ../raster/r.resamp.bspline/main.c:116 ../raster/r.resamp.bspline/main.c:122
+#: ../raster/r.resamp.bspline/main.c:134 ../raster/r.resamp.bspline/main.c:139
+#: ../raster/r.slope.aspect/main.c:181 ../raster/r.slope.aspect/main.c:189
+#: ../raster/r.slope.aspect/main.c:247 ../raster/r.slope.aspect/main.c:256
+#: ../raster/r.slope.aspect/main.c:262 ../raster/r.resamp.rst/main.c:210
+#: ../raster/r.resamp.rst/main.c:216 ../raster/r.resamp.rst/main.c:224
+#: ../raster/r.resamp.rst/main.c:232 ../raster/r.resamp.rst/main.c:240
+#: ../raster/r.walk/main.c:274 ../raster/r.walk/main.c:284
+#: ../raster/r.walk/main.c:294 ../raster/r.out.mpeg/main.c:132
+#: ../display/d.mon/main.c:70 ../display/d.mon/main.c:78
+#: ../display/d.mon/main.c:86 ../display/d.mon/main.c:92
+#: ../display/d.mon/main.c:98 ../display/d.mon/main.c:133
+#: ../display/d.mon/main.c:139 ../display/d.mon/main.c:145
+#: ../vector/v.lidar.correction/main.c:102
+#: ../vector/v.lidar.correction/main.c:111 ../vector/v.surf.idw/main.c:115
+#: ../vector/v.surf.idw/main.c:124 ../vector/v.surf.idw/main.c:132
+#: ../vector/v.vol.rst/main.c:268 ../vector/v.vol.rst/main.c:276
+#: ../vector/v.vol.rst/main.c:283 ../vector/v.vol.rst/main.c:311
+#: ../vector/v.vol.rst/main.c:320 ../vector/v.vol.rst/main.c:329
+#: ../vector/v.vol.rst/main.c:337 ../vector/v.vol.rst/main.c:346
+#: ../vector/v.vol.rst/main.c:354 ../vector/v.lidar.edgedetection/main.c:95
+#: ../vector/v.lidar.edgedetection/main.c:104
+#: ../vector/v.lidar.edgedetection/main.c:113
+#: ../vector/v.lidar.edgedetection/main.c:122
+#: ../vector/v.lidar.edgedetection/main.c:131
+#: ../vector/v.lidar.edgedetection/main.c:139
+#: ../vector/v.lidar.edgedetection/main.c:148
+#: ../vector/v.surf.bspline/main.c:113 ../vector/v.surf.bspline/main.c:120
+#: ../vector/v.surf.bspline/main.c:150 ../vector/v.surf.bspline/main.c:159
+#: ../vector/v.surf.bspline/main.c:167 ../vector/v.surf.bspline/main.c:179
+#: ../vector/v.external.out/args.c:20 ../vector/v.external.out/args.c:35
+#: ../vector/v.external.out/args.c:47 ../vector/v.external.out/args.c:53
+#: ../vector/v.outlier/main.c:104 ../vector/v.outlier/main.c:113
+#: ../vector/v.outlier/main.c:121 ../vector/v.db.connect/main.c:66
+#: ../vector/v.db.connect/main.c:72 ../vector/v.colors.out/main.c:68
+#: ../vector/v.colors.out/main.c:73 ../imagery/i.segment/parse_args.c:68
+#: ../imagery/i.segment/parse_args.c:77 ../imagery/i.segment/parse_args.c:88
+#: ../imagery/i.segment/parse_args.c:99 ../imagery/i.segment/parse_args.c:109
+#: ../imagery/i.segment/parse_args.c:127 ../imagery/i.segment/parse_args.c:135
+#: ../imagery/i.segment/parse_args.c:144 ../imagery/i.segment/parse_args.c:151
+#: ../imagery/i.segment/parse_args.c:157 ../imagery/i.segment/parse_args.c:163
+#: ../imagery/i.segment/parse_args.c:169 ../imagery/i.segment/parse_args.c:176
+#: ../imagery/i.landsat.toar/main.c:160 ../imagery/i.landsat.toar/main.c:169
+#: ../imagery/i.landsat.toar/main.c:179 ../imagery/i.landsat.toar/main.c:188
+#: ../imagery/i.landsat.toar/main.c:209 ../imagery/i.cluster/main.c:103
+#: ../imagery/i.cluster/main.c:120 ../imagery/i.cluster/main.c:128
+#: ../imagery/i.cluster/main.c:137 ../imagery/i.cluster/main.c:145
+#: ../imagery/i.cluster/main.c:153 ../db/db.login/main.c:60
+#: ../db/db.login/main.c:68 ../db/db.login/main.c:77 ../db/db.login/main.c:86
+msgid "Settings"
+msgstr "설정"
-#: ../imagery/i.group/main.c:219
-#, fuzzy
-msgid "No input raster maps defined"
-msgstr "출력할 격자지도"
+#: ../general/g.access/main.c:57
+msgid "Access for others"
+msgstr "다른 사용자의 접근"
-#: ../imagery/i.group/main.c:223 ../imagery/i.group/main.c:265
-#, c-format
-msgid "Raster map <%s> not found. Skipped."
-msgstr "격자지도 <%s>를 찾지 못 했습니다. 넘어갑니다."
+#: ../general/g.access/main.c:64
+msgid "UNIX filesystem access controls are not supported by MS-Windows"
+msgstr "MS 윈도우는 유닉스 파일시스템의 접근제한을 지원하지 않습니다"
-#: ../imagery/i.group/main.c:228
-#, fuzzy, c-format
-msgid "Adding raster map <%s> to group"
-msgstr "출력할 격자지도"
-#: ../imagery/i.group/main.c:234
-#, fuzzy, c-format
-msgid "Raster map <%s> exists in group. Skipped."
-msgstr "출력할 격자지도"
-#: ../imagery/i.group/main.c:271
-#, fuzzy, c-format
-msgid "Adding raster map <%s> to subgroup"
-msgstr "출력할 격자지도"
-#: ../imagery/i.group/main.c:278
-#, c-format
-msgid "Raster map <%s> exists in subgroup. Skipping..."
+#: ../general/g.access/main.c:72
+msgid "Access to the PERMANENT mapset must be open, nothing changed"
msgstr ""
+"PERMANENT 지도세트에 대한 접근은 열려 있어야 합니다. 아무것도 바꾸지 않았습니"
+"다."
-#: ../imagery/i.group/main.c:327
-#, fuzzy, c-format
-msgid "Removing raster map <%s> from group"
-msgstr "출력할 격자지도"
+#: ../general/g.access/main.c:76
+msgid "Unable to determine mapset permissions"
+msgstr "지도세트의 허가를 결정하지 못 했습니다"
-#: ../imagery/i.group/main.c:344 ../imagery/i.group/main.c:403
-#, fuzzy
-msgid "No raster map removed"
-msgstr "출력할 격자지도"
+#: ../general/g.access/set_perms.c:26
+msgid "Unable to change mapset permissions"
+msgstr "지도세트의 허가를 바꿀 수 없습니다"
-#: ../imagery/i.group/main.c:386
-#, fuzzy, c-format
-msgid "Removing raster map <%s> from subgroup"
-msgstr "출력할 격자지도"
+#: ../general/g.access/exp_perms.c:11 ../general/g.access/exp_perms.c:29
+msgid "have"
+msgstr "가질 것입니다"
-#: ../imagery/i.group/main.c:422
-#, fuzzy, c-format
-msgid "Group <%s> does not contain any subgroup.\n"
-msgstr "출력할 격자지도"
+#: ../general/g.access/exp_perms.c:12
+msgid "read "
+msgstr "읽기"
-#: ../imagery/i.group/main.c:433
-#, fuzzy, c-format
-msgid "group <%s> references the following subgroups\n"
-msgstr "출력할 격자지도"
+#: ../general/g.access/exp_perms.c:15
+msgid "Everyone"
+msgstr "모두가"
-#: ../imagery/i.biomass/main.c:51
-msgid "biomass"
-msgstr ""
+#: ../general/g.access/exp_perms.c:16
+msgid "has"
+msgstr "가지고 있습니다"
-#: ../imagery/i.biomass/main.c:53
-msgid "yield"
-msgstr ""
+#: ../general/g.access/exp_perms.c:19
+msgid "Only users in your group"
+msgstr "당신 그룹 내의 사용자만이"
-#: ../imagery/i.biomass/main.c:55
-msgid "Computes biomass growth, precursor of crop yield calculation."
-msgstr ""
+#: ../general/g.access/exp_perms.c:22
+msgid "Only users outside your group"
+msgstr "당신 그룹 외의 사용자만이"
-#: ../imagery/i.biomass/main.c:60
-#, fuzzy
-msgid "Name of fPAR raster map"
-msgstr "출력할 격자지도"
+#: ../general/g.access/exp_perms.c:25
+msgid "Only you"
+msgstr "당신만이"
-#: ../imagery/i.biomass/main.c:65
-#, fuzzy
-msgid "Name of light use efficiency raster map (UZB:cotton=1.9)"
-msgstr "출력할 격자지도"
+#: ../general/g.access/exp_perms.c:31
+#, c-format
+msgid "%s %s %s %saccess to mapset %s"
+msgstr "%1$s 지도세트 %5$s에 대한 %4$s권한을 %2$s %3$s"
-#: ../imagery/i.biomass/main.c:69
-#, fuzzy
-msgid "Name of degree latitude raster map [dd.ddd]"
-msgstr "출력할 격자지도"
+#: ../general/g.access/exp_perms.c:32
+msgid "will"
+msgstr "앞으로"
-#: ../imagery/i.biomass/main.c:73
-#, fuzzy
-msgid "Name of Day of Year raster map [1-366]"
-msgstr "출력할 격자지도"
+msgid "now"
+msgstr "현재"
-#: ../imagery/i.biomass/main.c:78
-#, fuzzy
-msgid "Name of single-way transmissivity raster map [0.0-1.0]"
-msgstr "출력할 격자지도"
+#: ../general/g.gisenv/main.c:45
+msgid "variables"
+msgstr ""
-#: ../imagery/i.biomass/main.c:83
-#, fuzzy
-msgid "Value of water availability raster map [0.0-1.0]"
-msgstr "출력할 격자지도"
+#: ../general/g.gisenv/main.c:48
+msgid "Outputs and modifies the user's current GRASS variable settings."
+msgstr ""
-#: ../imagery/i.biomass/main.c:87
-#, fuzzy
-msgid "Name for output daily biomass growth raster map [kg/ha/d]"
-msgstr "출력할 격자지도"
+#: ../general/g.gisenv/main.c:49
+msgid "Prints all defined GRASS variables if no option is given."
+msgstr ""
-#: ../imagery/i.evapo.time/main.c:79
-msgid ""
-"Computes temporal integration of satellite ET actual (ETa) following the "
-"daily ET reference (ETo) from meteorological station(s)."
+#: ../general/g.gisenv/main.c:54
+msgid "GRASS variable to get"
msgstr ""
-#: ../imagery/i.evapo.time/main.c:86
-#, fuzzy
-msgid "Names of satellite ETa raster maps [mm/d or cm/d]"
-msgstr "출력할 격자지도"
+#: ../general/g.gisenv/main.c:57
+msgid "Get"
+msgstr ""
-#: ../imagery/i.evapo.time/main.c:91
-msgid "Names of satellite ETa Day of Year (DOY) raster maps [0-400] [-]"
+#: ../general/g.gisenv/main.c:63
+msgid "GRASS variable to set"
msgstr ""
-#: ../imagery/i.evapo.time/main.c:96
-msgid "Names of meteorological station ETo raster maps [0-400] [mm/d or cm/d]"
+#: ../general/g.gisenv/main.c:66 ../general/g.gisenv/main.c:74
+#: ../general/g.gisenv/main.c:84 ../temporal/t.connect/main.c:49
+#: ../temporal/t.connect/main.c:55 ../temporal/t.connect/main.c:60
+#: ../temporal/t.connect/main.c:65 ../temporal/t.connect/main.c:69
+#: ../db/db.connect/main.c:64 ../db/db.connect/main.c:70
+#: ../db/db.connect/main.c:75 ../db/db.connect/main.c:79
+#: ../db/db.connect/main.c:83 ../db/db.connect/main.c:93
+msgid "Set"
msgstr ""
-#: ../imagery/i.evapo.time/main.c:102
-msgid "Value of DOY for ETo first day"
+#: ../general/g.gisenv/main.c:71
+msgid "GRASS variable to unset"
msgstr ""
-#: ../imagery/i.evapo.time/main.c:108
-msgid "Value of DOY for the first day of the period studied"
+#: ../general/g.gisenv/main.c:82
+msgid "Where GRASS variable is stored"
msgstr ""
-#: ../imagery/i.evapo.time/main.c:114
-msgid "Value of DOY for the last day of the period studied"
+#: ../general/g.gisenv/main.c:87
+msgid "Separator for multiple GRASS variables"
msgstr ""
-#: ../imagery/i.evapo.time/main.c:142
-msgid "The DOY for end_period can not be smaller than start_period"
+#: ../general/g.gisenv/main.c:92
+msgid "Use shell syntax (for \"eval\")"
msgstr ""
-#: ../imagery/i.evapo.time/main.c:146
-msgid "The DOY for start_period can not be smaller than eto_doy_min"
+#: ../general/g.gisenv/main.c:93 ../general/g.gisenv/main.c:98
+#: ../vector/v.db.select/main.c:85 ../vector/v.db.select/main.c:88
+#: ../vector/v.db.select/main.c:106 ../vector/v.db.select/main.c:111
+#: ../db/db.select/main.c:227 ../db/db.select/main.c:233
+#: ../db/db.select/main.c:236 ../db/db.select/main.c:246
+#: ../db/db.select/main.c:256
+msgid "Format"
msgstr ""
-#: ../imagery/i.evapo.time/main.c:151
-#, c-format
-msgid "Too many ETa files. Only %d allowed."
+#: ../general/g.gisenv/main.c:97
+msgid "Do not use shell syntax"
msgstr ""
-#: ../imagery/i.evapo.time/main.c:162 ../imagery/i.evapo.time/main.c:178
-#: ../imagery/i.evapo.time/main.c:200
-msgid "The min specified input map is two"
+#: ../general/g.gisenv/main.c:171
+#, c-format
+msgid "Variable <%s> is mandatory. No operation performed."
msgstr ""
-#: ../imagery/i.evapo.time/main.c:167
+#: ../general/g.gisenv/main.c:177
#, c-format
-msgid "Too many ETa_doy files. Only %d allowed."
+msgid "Value '%s' ignored when unsetting the GRASS variable"
msgstr ""
-#: ../imagery/i.evapo.time/main.c:183
-msgid "ETa and ETa_DOY file numbers are not equal!"
+#: ../general/g.gisenv/main.c:216
+msgid "GRASS variable not defined"
msgstr ""
-#: ../imagery/i.evapo.time/main.c:189
+#: ../general/g.gisenv/main.c:222
#, c-format
-msgid "Too many ETo files. Only %d allowed."
+msgid "GRASS variable must be uppercase. Using '%s'."
msgstr ""
-#: ../imagery/i.smap/parse.c:20 ../imagery/i.maxlik/main.c:81
+#: ../locale/scriptstrings/r.pack_to_translate.c:1
#, fuzzy
-msgid "Name of input file containing signatures"
+msgid "Exports a raster map as GRASS GIS specific archive file"
msgstr "출력할 격자지도"
-#: ../imagery/i.smap/parse.c:21
-msgid "Generated by i.gensigset"
+#: ../locale/scriptstrings/r.pack_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:3
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:3
+#: ../locale/scriptstrings/d.out.file_to_translate.c:3
+#: ../locale/scriptstrings/v.pack_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:3
+#: ../locale/scriptstrings/d.to.rast_to_translate.c:3
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:3
+#: ../raster3d/r3.out.v5d/main.c:285 ../raster3d/r3.out.bin/main.c:206
+#: ../raster3d/r3.out.ascii/main.c:303 ../raster3d/r3.out.netcdf/main.c:587
+#: ../raster3d/r3.out.vtk/main.c:377 ../raster/r.out.png/main.c:113
+#: ../raster/r.external.out/main.c:236 ../raster/r.out.ascii/main.c:60
+#: ../raster/r.out.pov/main.c:122 ../raster/r.out.mpeg/main.c:103
+#: ../raster/r.out.gridatb/main.c:68 ../raster/r.out.ppm3/main.c:58
+#: ../raster/r.out.mat/main.c:63 ../raster/r.out.bin/main.c:280
+#: ../raster/r.out.vrml/main.c:48 ../raster/r.out.gdal/main.c:137
+#: ../raster/r.colors.out/raster3d_main.c:48
+#: ../raster/r.colors.out/raster_main.c:47 ../raster/r.out.ppm/main.c:55
+#: ../raster/r.out.vtk/main.c:60 ../vector/v.out.pov/main.c:47
+#: ../vector/v.out.vtk/main.c:48 ../vector/v.out.ogr/main.c:82
+#: ../vector/v.out.postgis/main.c:45 ../vector/v.out.lidar/main.c:472
+#: ../vector/v.out.ascii/main.c:48 ../vector/v.external.out/main.c:44
+#: ../vector/v.out.svg/main.c:78 ../vector/v.out.dxf/main.c:57
+#: ../vector/v.colors.out/main.c:51
+msgid "export"
+msgstr "내보내기"
+#: ../locale/scriptstrings/r.pack_to_translate.c:4
+#: ../locale/scriptstrings/v.unpack_to_translate.c:4
+#: ../locale/scriptstrings/v.pack_to_translate.c:4
+#: ../locale/scriptstrings/r.unpack_to_translate.c:4
+msgid "copying"
msgstr ""
-#: ../imagery/i.smap/parse.c:28 ../imagery/i.maxlik/main.c:86
+#: ../locale/scriptstrings/r.pack_to_translate.c:5
#, fuzzy
-msgid "Name for output raster map holding classification results"
+msgid "Name of raster map to pack up"
msgstr "출력할 격자지도"
-#: ../imagery/i.smap/parse.c:33
+#: ../locale/scriptstrings/r.pack_to_translate.c:6
+#: ../locale/scriptstrings/v.pack_to_translate.c:6
#, fuzzy
-msgid "Name for output raster map holding goodness of fit (lower is better)"
+msgid "Name for output file (default is <input>.pack)"
msgstr "출력할 격자지도"
-#: ../imagery/i.smap/parse.c:37
-msgid "Size of submatrix to process at one time"
+#: ../locale/scriptstrings/r.pack_to_translate.c:7
+#: ../locale/scriptstrings/v.pack_to_translate.c:7
+msgid "Switch the compression off"
msgstr ""
-#: ../imagery/i.smap/parse.c:45
-msgid "Use maximum likelihood estimation (instead of smap)"
+#: ../locale/scriptstrings/db.test_to_translate.c:1
+msgid "Test database driver, database must exist and set by db.connect."
msgstr ""
-#: ../imagery/i.smap/segment.c:67
-#, fuzzy
-msgid "Number of classes must be < 256"
-msgstr "출력할 격자지도"
-#: ../imagery/i.smap/segment.c:102
-#, c-format
-msgid "Processing rows %d-%d (of %d)..."
+#: ../locale/scriptstrings/db.test_to_translate.c:2
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:2
+#: ../locale/scriptstrings/db.univar_to_translate.c:2
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:4
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:5
+#: ../locale/scriptstrings/v.db.update_to_translate.c:4
+#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:2
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:2
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:4
+#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:4
+#: ../locale/scriptstrings/db.droptable_to_translate.c:2
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
+#: ../locale/scriptstrings/v.db.join_to_translate.c:4
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:4
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:4
+#: ../locale/scriptstrings/v.db.droprow_to_translate.c:4
+#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:4
+#: ../vector/v.in.db/main.c:54 ../vector/v.to.db/main.c:38
+#: ../vector/v.db.select/main.c:56 ../vector/v.vect.stats/main.c:126
+#: ../vector/v.distance/main.c:92 ../vector/v.db.connect/main.c:54
+#: ../db/db.createdb/main.c:71 ../db/db.describe/main.c:129
+#: ../db/db.drivers/main.c:71 ../db/db.copy/main.c:35
+#: ../db/db.databases/main.c:95 ../db/db.execute/main.c:125
+#: ../db/db.dropdb/main.c:71 ../db/db.tables/main.c:97
+#: ../db/db.select/main.c:265 ../db/db.connect/main.c:43
+#: ../db/db.columns/main.c:99 ../db/db.login/main.c:40
+msgid "database"
msgstr ""
-#: ../imagery/i.smap/main.c:41 ../imagery/i.segment/main.c:37
+#: ../locale/scriptstrings/db.test_to_translate.c:3
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:4
+#: ../locale/scriptstrings/db.univar_to_translate.c:4
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:3
+#: ../locale/scriptstrings/v.db.update_to_translate.c:3
+#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:3
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:4
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:7
+#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:3
+#: ../locale/scriptstrings/db.droptable_to_translate.c:3
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
+#: ../locale/scriptstrings/v.db.join_to_translate.c:3
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:3
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:4
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:3
+#: ../locale/scriptstrings/v.db.droprow_to_translate.c:3
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:7
+#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:3
+#: ../vector/v.what.rast3/main.c:69 ../vector/v.class/main.c:47
+#: ../vector/v.univar/main.c:95 ../vector/v.to.db/main.c:37
+#: ../vector/v.db.select/main.c:55 ../vector/v.what.rast/main.c:76
+#: ../vector/v.vect.stats/main.c:125 ../vector/v.distance/main.c:93
+#: ../vector/v.db.connect/main.c:53 ../db/db.createdb/main.c:72
+#: ../db/db.describe/main.c:130 ../db/db.copy/main.c:36
+#: ../db/db.databases/main.c:96 ../db/db.execute/main.c:126
+#: ../db/db.dropdb/main.c:72 ../db/db.tables/main.c:98
+#: ../db/db.select/main.c:266 ../db/db.connect/main.c:44
+#: ../db/db.columns/main.c:100
#, fuzzy
-msgid "segmentation"
+msgid "attribute table"
msgstr "출력할 격자지도"
-#: ../imagery/i.smap/main.c:44
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
+#: ../locale/scriptstrings/db.test_to_translate.c:4
+msgid "Test name"
msgstr ""
-#: ../imagery/i.smap/write_img.c:15
+#: ../locale/scriptstrings/t.rename_to_translate.c:1
#, fuzzy
-msgid "Writing output raster map(s)..."
+msgid "Renames a space time dataset"
msgstr "출력할 격자지도"
-#: ../imagery/i.smap/interp.c:68 ../raster/r.cost/main.c:673
-#: ../raster/r.stream.extract/load.c:44 ../raster/r.stream.extract/load.c:53
-#: ../raster/r.texture/h_measure.c:594 ../raster/r.walk/main.c:808
-msgid "Unable to allocate memory"
+#: ../locale/scriptstrings/t.rename_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:2
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:2
+#: ../locale/scriptstrings/t.sample_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:2
+#: ../locale/scriptstrings/t.list_to_translate.c:2
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:2
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:2
+#: ../locale/scriptstrings/t.snap_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:2
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:2
+#: ../locale/scriptstrings/t.info_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:2
+#: ../locale/scriptstrings/t.select_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:2
+#: ../locale/scriptstrings/t.support_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:2
+#: ../locale/scriptstrings/t.shift_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:2
+#: ../locale/scriptstrings/t.create_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:2
+#: ../locale/scriptstrings/t.unregister_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:2
+#: ../locale/scriptstrings/t.topology_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:2
+#: ../locale/scriptstrings/t.remove_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:2
+#: ../locale/scriptstrings/t.register_to_translate.c:2
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:2
+#: ../locale/scriptstrings/t.merge_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:2
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:2
+#: ../temporal/t.connect/main.c:34
+msgid "temporal"
msgstr ""
-#: ../imagery/i.smap/interp.c:233
-msgid "Invalid parameter values"
+#: ../locale/scriptstrings/t.rename_to_translate.c:5
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:5
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:5
+#: ../locale/scriptstrings/t.sample_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:6
+#: ../locale/scriptstrings/t.list_to_translate.c:5
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:6
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:6
+#: ../locale/scriptstrings/t.snap_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:6
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:6
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:7
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:5
+#: ../locale/scriptstrings/t.info_to_translate.c:5
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:5
+#: ../locale/scriptstrings/t.select_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:5
+#: ../locale/scriptstrings/t.support_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:5
+#: ../locale/scriptstrings/t.shift_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:5
+#: ../locale/scriptstrings/t.create_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:5
+#: ../locale/scriptstrings/t.unregister_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:5
+#: ../locale/scriptstrings/t.topology_to_translate.c:4
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:6
+#: ../locale/scriptstrings/t.remove_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:6
+#: ../locale/scriptstrings/t.register_to_translate.c:5
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:6
+#: ../locale/scriptstrings/t.merge_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:6
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:5
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:5
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:5
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:5
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:5
+#: ../raster3d/r3.timestamp/main.c:46 ../raster/r.timestamp/main.c:38
+#: ../vector/v.timestamp/main.c:38
+msgid "time"
msgstr ""
-#: ../imagery/i.smap/model.c:43
-#, c-format
-msgid "Nonsymetric covariance for class %d subclass %d"
+#: ../locale/scriptstrings/t.rename_to_translate.c:6
+#: ../locale/scriptstrings/t.snap_to_translate.c:7
+#: ../locale/scriptstrings/t.info_to_translate.c:7
+#: ../locale/scriptstrings/t.select_to_translate.c:5
+#: ../locale/scriptstrings/t.support_to_translate.c:6
+#: ../locale/scriptstrings/t.shift_to_translate.c:7
+#: ../locale/scriptstrings/t.topology_to_translate.c:5
+msgid "input"
msgstr ""
-#: ../imagery/i.smap/model.c:55
-#, c-format
-msgid "Nonpositive eigenvalues for class %d subclass %d"
+#: ../locale/scriptstrings/t.rename_to_translate.c:7
+#: ../locale/scriptstrings/t.sample_to_translate.c:6
+#: ../locale/scriptstrings/t.sample_to_translate.c:7
+#: ../locale/scriptstrings/t.snap_to_translate.c:8
+#: ../locale/scriptstrings/t.info_to_translate.c:8
+#: ../locale/scriptstrings/t.select_to_translate.c:6
+#: ../locale/scriptstrings/t.support_to_translate.c:7
+#: ../locale/scriptstrings/t.shift_to_translate.c:8
+#: ../locale/scriptstrings/t.topology_to_translate.c:6
+#: ../locale/scriptstrings/t.merge_to_translate.c:7
+#: ../vector/v.profile/main.c:104 ../vector/v.profile/main.c:123
+msgid "Required"
msgstr ""
-#: ../imagery/i.smap/openfiles.c:22 ../imagery/i.smap/read_sig.c:17
-#, fuzzy, c-format
-msgid "Subgroup <%s> in group <%s> contains no raster maps"
+#: ../locale/scriptstrings/d.shade_to_translate.c:1
+#: ../locale/scriptstrings/r.shade_to_translate.c:1
+#, fuzzy
+msgid "Drapes a color raster over an shaded relief or aspect map."
msgstr "출력할 격자지도"
-#: ../imagery/i.smap/read_sig.c:23 ../imagery/i.maxlik/open.c:53
-#: ../imagery/i.cluster/open_files.c:60
-#, fuzzy, c-format
-msgid "Unable to read signature file <%s>"
+#: ../locale/scriptstrings/d.shade_to_translate.c:3
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
+#: ../locale/scriptstrings/r.plane_to_translate.c:3
+#: ../locale/scriptstrings/r.shade_to_translate.c:3
+#: ../raster/r.relief/main.c:108 ../raster/r.param.scale/interface.c:57
+#, fuzzy
+msgid "elevation"
msgstr "출력할 격자지도"
-#: ../imagery/i.smap/read_sig.c:27
-#, fuzzy, c-format
-msgid "Signature file <%s> is invalid"
-msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/d.shade_to_translate.c:4
+#: ../locale/scriptstrings/r.shade_to_translate.c:4
+#: ../raster/r.relief/main.c:109
+msgid "relief"
+msgstr ""
-#: ../imagery/i.smap/read_sig.c:30
-#, fuzzy, c-format
-msgid "Signature file <%s> is empty"
-msgstr "출력할 격자지도"
-#: ../imagery/i.rgb.his/main.c:52
-msgid ""
-"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
-"Intensity-Saturation) color space."
+#: ../locale/scriptstrings/d.shade_to_translate.c:5
+#: ../locale/scriptstrings/r.shade_to_translate.c:5
+#: ../raster/r.relief/main.c:111
+msgid "hillshade"
msgstr ""
-#: ../imagery/i.rgb.his/main.c:58
+#: ../locale/scriptstrings/d.shade_to_translate.c:7
+#: ../locale/scriptstrings/r.shade_to_translate.c:7
#, fuzzy
-msgid "Name of input raster map (red)"
+msgid "Name of shaded relief or aspect raster map"
msgstr "출력할 격자지도"
-#: ../imagery/i.rgb.his/main.c:62
+#: ../locale/scriptstrings/d.shade_to_translate.c:8
+#: ../locale/scriptstrings/r.shade_to_translate.c:8
#, fuzzy
-msgid "Name of input raster map (green)"
+msgid "Name of raster to drape over relief raster map"
msgstr "출력할 격자지도"
-#: ../imagery/i.rgb.his/main.c:66
+#: ../locale/scriptstrings/d.shade_to_translate.c:9
+#: ../locale/scriptstrings/r.shade_to_translate.c:9
+msgid "Typically, this raster is elevation or other colorful raster"
+msgstr ""
+#: ../locale/scriptstrings/d.shade_to_translate.c:10
+#: ../locale/scriptstrings/r.shade_to_translate.c:11
+msgid "Percent to brighten"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:1
#, fuzzy
-msgid "Name of input raster map (blue)"
+msgid "Exports a space time vector dataset as GRASS GIS specific archive file."
msgstr "출력할 격자지도"
-#: ../imagery/i.rgb.his/main.c:70
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:6
#, fuzzy
-msgid "Name for output raster map (hue)"
+msgid "Name of a space time vector dataset archive"
msgstr "출력할 격자지도"
-#: ../imagery/i.rgb.his/main.c:74
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:7
+msgid "Path to the work directory, default is /tmp"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:8
#, fuzzy
-msgid "Name for output raster map (intensity)"
+msgid "Compression method of the tar archive"
msgstr "출력할 격자지도"
-#: ../imagery/i.rgb.his/main.c:78
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:9
#, fuzzy
-msgid "Name for output raster map (saturation)"
+msgid "The export format of a single vector map"
msgstr "출력할 격자지도"
-#: ../imagery/i.pca/main.c:74
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:8
-msgid "PCA"
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:10
+msgid "Supported are GML via v.out.ogr and the GRASS package format of v.pack"
msgstr ""
-#: ../imagery/i.pca/main.c:75
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:1
#, fuzzy
-msgid "principal components analysis"
+msgid "Lists registered maps of a space time raster3d dataset."
msgstr "출력할 격자지도"
-#: ../imagery/i.pca/main.c:76
-msgid "Principal components analysis (PCA) for image processing."
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:6
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:5
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:5
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:6
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:4
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:5
+#: ../raster3d/r3.mkdspf/main.c:81 ../raster3d/r3.gwflow/main.c:161
+#: ../raster3d/r3.gradient/main.c:45 ../raster3d/r3.out.v5d/main.c:286
+#: ../raster3d/r3.in.bin/main.c:254 ../raster3d/r3.out.bin/main.c:207
+#: ../raster3d/r3.neighbors/main.c:210 ../raster3d/r3.out.ascii/main.c:304
+#: ../raster3d/r3.info/main.c:77 ../raster3d/r3.null/main.c:188
+#: ../raster3d/r3.cross.rast/main.c:231 ../raster3d/r3.in.v5d/main.c:180
+#: ../raster3d/r3.stats/main.c:50 ../raster3d/r3.out.netcdf/main.c:589
+#: ../raster3d/r3.flow/main.c:181 ../raster3d/r3.in.ascii/main.c:356
+#: ../raster3d/r3.support/main.c:51 ../raster3d/r3.mask/main.c:135
+#: ../raster3d/r3.to.rast/main.c:262 ../raster3d/r3.timestamp/main.c:47
+#: ../raster3d/r3.retile/main.c:98 ../raster3d/r3.out.vtk/main.c:378
+#: ../raster/r.to.rast3/main.c:199 ../raster/r.to.rast3elev/main.c:364
+#: ../vector/v.to.rast3/main.c:50 ../vector/v.vol.rst/main.c:236
+msgid "voxel"
msgstr ""
-#: ../imagery/i.pca/main.c:82
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:8
#, fuzzy
-msgid "Name of two or more input raster maps or imagery group"
+msgid "Order the space time dataset by category"
msgstr "출력할 격자지도"
-#: ../imagery/i.pca/main.c:85
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:8
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:9
+#: ../locale/scriptstrings/t.list_to_translate.c:13
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:9
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:9
#, fuzzy
-msgid "Name for output basename raster map(s)"
+msgid "Columns to be printed to stdout"
msgstr "출력할 격자지도"
-#: ../imagery/i.pca/main.c:87
-msgid "A numerical suffix will be added for each component map"
-msgstr ""
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:10
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:11
+#: ../locale/scriptstrings/t.list_to_translate.c:7
+#: ../locale/scriptstrings/t.list_to_translate.c:8
+#: ../locale/scriptstrings/t.list_to_translate.c:14
+#: ../locale/scriptstrings/t.list_to_translate.c:15
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:11
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:10
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:11
+#: ../locale/scriptstrings/v.report_to_translate.c:5
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:7
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:6
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:7
+#: ../raster3d/r3.in.lidar/main.c:232 ../raster3d/r3.in.lidar/main.c:242
+#: ../raster3d/r3.in.lidar/main.c:272 ../raster3d/r3.in.lidar/main.c:288
+#: ../raster/r.category/main.c:62 ../raster/r.category/main.c:71
+#: ../raster/r.in.lidar/main.c:192 ../raster/r.in.lidar/main.c:208
+#: ../raster/r.in.lidar/main.c:261 ../raster/r.in.lidar/main.c:271
+#: ../raster/r.in.lidar/main.c:339 ../display/d.rast/main.c:70
+#: ../display/d.rast/main.c:87 ../display/d.vect/main.c:83
+#: ../display/d.vect/main.c:108 ../display/d.vect/main.c:111
+#: ../display/d.vect/main.c:114 ../display/d.vect/main.c:316
+#: ../display/d.vect.thematic/main.c:98 ../display/d.vect.thematic/main.c:148
+#: ../display/d.vect.chart/main.c:74 ../display/d.vect.chart/main.c:77
+#: ../vector/v.surf.rst/main.c:172 ../vector/v.surf.rst/main.c:184
+#: ../vector/v.category/main.c:85 ../vector/v.category/main.c:89
+#: ../vector/v.category/main.c:93 ../vector/v.extrude/main.c:84
+#: ../vector/v.extrude/main.c:87 ../vector/v.extrude/main.c:90
+#: ../vector/v.extrude/main.c:95 ../vector/v.extract/main.c:98
+#: ../vector/v.extract/main.c:103 ../vector/v.extract/main.c:109
+#: ../vector/v.extract/main.c:112 ../vector/v.extract/main.c:115
+#: ../vector/v.extract/main.c:125 ../vector/v.extract/main.c:135
+#: ../vector/v.edit/args.c:24 ../vector/v.edit/args.c:29
+#: ../vector/v.edit/args.c:112 ../vector/v.edit/args.c:116
+#: ../vector/v.edit/args.c:125 ../vector/v.edit/args.c:134
+#: ../vector/v.edit/args.c:143 ../vector/v.edit/args.c:146
+#: ../vector/v.edit/args.c:164 ../vector/v.edit/args.c:199
+#: ../vector/v.random/main.c:117 ../vector/v.random/main.c:120
+#: ../vector/v.random/main.c:123 ../vector/v.random/main.c:126
+#: ../vector/v.out.ogr/args.c:12 ../vector/v.out.ogr/args.c:22
+#: ../vector/v.out.ogr/args.c:104 ../vector/v.in.db/main.c:94
+#: ../vector/v.to.3d/args.c:19 ../vector/v.to.3d/args.c:25
+#: ../vector/v.out.postgis/args.c:15 ../vector/v.out.postgis/args.c:19
+#: ../vector/v.out.lidar/main.c:487 ../vector/v.out.lidar/main.c:491
+#: ../vector/v.out.lidar/main.c:588 ../vector/v.out.ascii/args.c:24
+#: ../vector/v.out.ascii/args.c:28 ../vector/v.out.ascii/args.c:43
+#: ../vector/v.out.ascii/args.c:46 ../vector/v.in.ogr/main.c:174
+#: ../vector/v.in.ogr/main.c:179 ../vector/v.in.ogr/main.c:188
+#: ../vector/v.in.ogr/main.c:204 ../vector/v.in.ogr/main.c:252
+#: ../vector/v.in.ogr/main.c:297 ../vector/v.net.allpairs/main.c:75
+#: ../vector/v.net.allpairs/main.c:81 ../vector/v.net.allpairs/main.c:84
+#: ../vector/v.net.allpairs/main.c:87 ../vector/v.decimate/main.c:147
+#: ../vector/v.decimate/main.c:150 ../vector/v.to.db/parse.c:45
+#: ../vector/v.select/args.c:18 ../vector/v.select/args.c:24
+#: ../vector/v.select/args.c:33 ../vector/v.select/args.c:39
+#: ../vector/v.select/args.c:106 ../vector/v.db.select/main.c:64
+#: ../vector/v.db.select/main.c:67 ../vector/v.db.select/main.c:70
+#: ../vector/v.db.select/main.c:76 ../vector/v.db.select/main.c:116
+#: ../vector/v.to.points/main.c:67 ../vector/v.to.points/main.c:71
+#: ../vector/v.clean/main.c:61 ../vector/v.clean/main.c:64
+#: ../vector/v.drape/main.c:67 ../vector/v.drape/main.c:70
+#: ../vector/v.drape/main.c:73 ../vector/v.drape/main.c:78
+#: ../vector/v.reclass/main.c:77 ../vector/v.reclass/main.c:82
+#: ../vector/v.in.lidar/main.c:185 ../vector/v.in.lidar/main.c:195
+#: ../vector/v.in.lidar/main.c:204 ../vector/v.in.lidar/main.c:214
+#: ../vector/v.in.lidar/main.c:221 ../vector/v.in.lidar/main.c:226
+#: ../vector/v.in.lidar/main.c:281 ../vector/v.in.lidar/main.c:287
+#: ../vector/v.in.lidar/main.c:295 ../vector/v.net.centrality/main.c:121
+#: ../vector/v.net.centrality/main.c:123 ../vector/v.generalize/main.c:92
+#: ../vector/v.generalize/main.c:231 ../vector/v.generalize/main.c:234
+#: ../vector/v.to.rast/main.c:57 ../vector/v.to.rast/main.c:60
+#: ../vector/v.to.rast/main.c:63 ../vector/v.buffer/main.c:235
+#: ../vector/v.buffer/main.c:238 ../vector/v.buffer/main.c:241
+#: ../vector/v.buffer/main.c:246
+#, fuzzy
+msgid "Selection"
+msgstr "출력할 격자지도"
-#: ../imagery/i.pca/main.c:96
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:12
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:12
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:12
#, fuzzy
-msgid "Rescaling range for output maps"
+msgid "Method used for data listing"
msgstr "출력할 격자지도"
-#: ../imagery/i.pca/main.c:98
-msgid "For no rescaling use 0,0"
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:13
+#: ../locale/scriptstrings/t.list_to_translate.c:16
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:14
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:13
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:8
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:8
+msgid "Field separator character between the output columns"
msgstr ""
-#: ../imagery/i.pca/main.c:99
-msgid "Rescale"
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:14
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:16
+#: ../locale/scriptstrings/t.list_to_translate.c:11
+#: ../locale/scriptstrings/t.list_to_translate.c:17
+#: ../locale/scriptstrings/t.list_to_translate.c:19
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:12
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:15
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:17
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:8
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:14
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:16
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:9
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:12
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:9
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:12
+#: ../raster/r.univar/r.univar_main.c:56 ../raster/r.univar/r.univar_main.c:62
+#: ../raster/r.univar/r.univar_main.c:72 ../raster/r.report/parse.c:69
+#: ../raster/r.report/parse.c:77 ../raster/r.report/parse.c:85
+#: ../raster/r.report/parse.c:109 ../raster/r.report/parse.c:114
+#: ../raster/r.report/parse.c:119 ../raster/r.report/parse.c:124
+#: ../raster/r.stats.quantile/main.c:557 ../raster/r.kappa/main.c:104
+#: ../raster/r.kappa/main.c:109 ../raster/r.stats/main.c:123
+#: ../raster/r.stats/main.c:127 ../raster/r.stats/main.c:151
+msgid "Formatting"
msgstr ""
-#: ../imagery/i.pca/main.c:108
-msgid "Cumulative percent importance for filtering"
-msgstr ""
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:15
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:16
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:15
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:11
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:11
+#, fuzzy
+msgid "Suppress printing of column names"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.pca/main.c:109 ../imagery/i.pca/main.c:120
-#: ../raster/r.mfilter/main.c:80 ../raster/r.mfilter/main.c:99
-msgid "Filter"
-msgstr ""
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:1
+#, fuzzy
+msgid "Imports SPOT VGT NDVI data into a raster map."
+msgstr "출력할 격자지도"
-#: ../imagery/i.pca/main.c:113
-msgid "Normalize (center and scale) input maps"
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:2
+#: ../locale/scriptstrings/i.spectral_to_translate.c:2
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:4
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:2
+#: ../locale/scriptstrings/i.oif_to_translate.c:2
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:2
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:2
+#: ../imagery/i.segment/main.c:36 ../imagery/i.biomass/main.c:50
+#: ../imagery/i.pca/main.c:72 ../imagery/i.modis.qc/main.c:149
+#: ../imagery/i.landsat.toar/main.c:70 ../imagery/i.eb.hsebal01/main.c:104
+#: ../imagery/i.maxlik/main.c:61 ../imagery/i.albedo/main.c:95
+#: ../imagery/i.eb.netrad/main.c:56 ../imagery/i.eb.evapfr/main.c:47
+#: ../imagery/i.smap/main.c:38 ../imagery/i.aster.toar/main.c:97
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:47
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:388
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:88
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:56
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:63
+#: ../imagery/i.landsat.acca/main.c:105 ../imagery/i.evapo.time/main.c:77
+#: ../imagery/i.zc/main.c:52 ../imagery/i.his.rgb/main.c:46
+#: ../imagery/i.target/main.c:45 ../imagery/i.evapo.pm/main.c:58
+#: ../imagery/i.ifft/main.c:77 ../imagery/i.fft/main.c:78
+#: ../imagery/i.rectify/main.c:99 ../imagery/i.gensigset/main.c:40
+#: ../imagery/i.eb.soilheatflux/main.c:49 ../imagery/i.vi/main.c:89
+#: ../imagery/i.group/main.c:52 ../imagery/i.eb.eta/main.c:42
+#: ../imagery/i.evapo.pt/main.c:66 ../imagery/i.gensig/main.c:39
+#: ../imagery/i.topo.corr/main.c:47 ../imagery/i.evapo.mh/main.c:69
+#: ../imagery/i.cluster/main.c:75 ../imagery/i.emissivity/main.c:44
+#: ../imagery/i.cca/main.c:84 ../imagery/i.rgb.his/main.c:46
+msgid "imagery"
msgstr ""
-#: ../imagery/i.pca/main.c:114
-msgid "Default: center only"
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:3
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:3
+#: ../locale/scriptstrings/v.unpack_to_translate.c:3
+#: ../locale/scriptstrings/r.import_to_translate.c:3
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:3
+#: ../locale/scriptstrings/v.import_to_translate.c:3
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:3
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:3
+#: ../locale/scriptstrings/r.unpack_to_translate.c:3
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:3
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:3
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:3
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:3
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:3
+#: ../raster3d/r3.in.bin/main.c:253 ../raster3d/r3.in.v5d/main.c:179
+#: ../raster3d/r3.in.ascii/main.c:355 ../raster3d/r3.in.lidar/main.c:163
+#: ../raster/r.in.bin/main.c:258 ../raster/r.in.xyz/main.c:159
+#: ../raster/r.in.png/main.c:520 ../raster/r.in.poly/main.c:35
+#: ../raster/r.in.mat/main.c:92 ../raster/r.in.gridatb/main.c:46
+#: ../raster/r.proj/main.c:147 ../raster/r.external/main.c:58
+#: ../raster/r.in.gdal/main.c:91 ../raster/r.in.ascii/main.c:70
+#: ../raster/r.in.lidar/main.c:109 ../vector/v.in.db/main.c:53
+#: ../vector/v.in.dxf/main.c:65 ../vector/v.external/main.c:51
+#: ../vector/v.in.ascii/main.c:71 ../vector/v.in.ogr/main.c:136
+#: ../vector/v.proj/main.c:70 ../vector/v.in.dwg/main.c:83
+#: ../vector/v.in.lidar/main.c:137
+msgid "import"
+msgstr "들여오기"
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
+msgid "Also import quality map (SM status map layer) and filter NDVI map"
msgstr ""
-#: ../imagery/i.pca/main.c:118
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:5
#, fuzzy
-msgid "Output will be filtered input bands"
+msgid "Name of input SPOT VGT NDVI HDF file"
msgstr "출력할 격자지도"
-#: ../imagery/i.pca/main.c:119
-msgid "Apply inverse PCA after PCA"
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:1
+#, fuzzy
+msgid ""
+"Creates/modifies the color table associated with each raster map of the "
+"space time raster dataset."
+msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:3
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:3
+#: ../raster/r.what.color/main.c:90 ../raster/r.colors/edit_colors.c:67
+#: ../raster/r.colors.out/raster3d_main.c:47
+#: ../raster/r.colors.out/raster_main.c:46 ../display/d.colortable/main.c:62
+#: ../vector/v.colors/main.c:56 ../vector/v.colors.out/main.c:50
+msgid "color table"
+msgstr "색상표"
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:6
+#, fuzzy
+msgid "Name of color table (see r.color help)"
+msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:13
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:20
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:22
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:24
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:26
+#: ../raster/r.category/main.c:81 ../raster/r.category/main.c:88
+#: ../raster/r.colors/edit_colors.c:90 ../raster/r.colors/edit_colors.c:97
+#: ../raster/r.colors/edit_colors.c:104 ../raster/r.colors/edit_colors.c:111
+#: ../raster/r.colors/edit_colors.c:122 ../raster/r.colors/edit_colors.c:133
+#: ../raster/r.colors/edit_colors.c:138 ../raster/r.colors/edit_colors.c:143
+#: ../raster/r.colors/edit_colors.c:148 ../display/d.linegraph/main.c:268
+#: ../vector/v.colors/main.c:81 ../vector/v.colors/main.c:92
+#: ../vector/v.colors/main.c:99 ../vector/v.colors/main.c:106
+#: ../vector/v.colors/main.c:112 ../vector/v.colors/main.c:138
+#: ../vector/v.colors/main.c:143 ../vector/v.colors/main.c:148
+msgid "Define"
msgstr ""
-#: ../imagery/i.pca/main.c:148
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:180
-#, fuzzy, c-format
-msgid "Group <%s> not found"
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:8
+#: ../raster/r.colors/edit_colors.c:96 ../vector/v.colors/main.c:98
+#, fuzzy
+msgid "Raster map from which to copy color table"
msgstr "출력할 격자지도"
-#: ../imagery/i.pca/main.c:154
-msgid "Sorry, at least 2 input bands must be provided"
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:10
+#: ../raster/r.colors/edit_colors.c:103 ../vector/v.colors/main.c:105
+#, fuzzy
+msgid "3D raster map from which to copy color table"
+msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:12
+#: ../raster/r.colors/edit_colors.c:109 ../vector/v.colors/main.c:111
+#, fuzzy
+msgid "Path to rules file"
+msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:14
+#: ../raster/r.colors/edit_colors.c:115 ../vector/v.colors/main.c:121
+msgid "Remove existing color table"
msgstr ""
-#: ../imagery/i.pca/main.c:169
-#, c-format
-msgid "'%s' must be positive"
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:15
+#: ../locale/scriptstrings/g.extension_to_translate.c:30
+#: ../locale/scriptstrings/r.mask_to_translate.c:20 ../raster/r.null/main.c:108
+#: ../raster/r.colors/edit_colors.c:116 ../vector/v.colors/main.c:122
+msgid "Remove"
msgstr ""
-#: ../imagery/i.pca/main.c:171
-#, fuzzy, c-format
-msgid "'%s' must be < 100"
-msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:16
+#: ../raster/r.colors/edit_colors.c:121 ../vector/v.colors/main.c:127
+msgid "Only write new color table if it does not already exist"
+msgstr ""
-#: ../imagery/i.pca/main.c:197 ../raster/r.covar/main.c:110
-msgid "No non-null values"
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:17
+#: ../raster/r.colors/edit_colors.c:126 ../vector/v.colors/main.c:131
+msgid "List available rules then exit"
msgstr ""
-#: ../imagery/i.pca/main.c:233
-msgid "Not enough principal components left for filtering"
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:19
+#: ../raster/r.colors/edit_colors.c:132 ../vector/v.colors/main.c:137
+msgid "Invert colors"
msgstr ""
-#: ../imagery/i.pca/main.c:235
-#, c-format
-msgid "Using %d of %d principal components for filtering"
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:21
+#: ../raster/r.colors/edit_colors.c:137 ../vector/v.colors/main.c:142
+msgid "Logarithmic scaling"
msgstr ""
-#: ../imagery/i.pca/main.c:297
-msgid "Scale range length should be > 0. Using default values: 0,255."
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:23
+#: ../raster/r.colors/edit_colors.c:142 ../vector/v.colors/main.c:147
+msgid "Logarithmic-absolute scaling"
msgstr ""
-#: ../imagery/i.pca/main.c:343
-#, fuzzy
-msgid "Computing covariance matrix..."
-msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:25
+#: ../raster/r.colors/edit_colors.c:147
+msgid "Histogram equalization"
+msgstr ""
-#: ../imagery/i.pca/main.c:456
-#, fuzzy, c-format
-msgid "Rescaling to range %d,%d..."
-msgstr "출력할 격자지도"
-#: ../imagery/i.pca/main.c:464
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:1
#, fuzzy
-msgid "Calculating principal components..."
+msgid "Converts vector polygons or points to lines."
msgstr "출력할 격자지도"
-#: ../imagery/i.pca/support.c:50
-msgid "Eigen values, (vectors), and [percent importance]:"
-msgstr ""
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:3
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:3
+#: ../locale/scriptstrings/v.report_to_translate.c:3 ../raster/r.thin/main.c:58
+#: ../raster/r.to.vect/main.c:78 ../raster/r.circle/main.c:53
+#: ../raster/r.patch/main.c:59 ../vector/v.extrude/main.c:68
+#: ../vector/v.segment/main.c:61 ../vector/v.split/main.c:55
+#: ../vector/v.edit/main.c:55 ../vector/v.voronoi/main.c:124
+#: ../vector/v.in.region/main.c:42 ../vector/v.type/main.c:39
+#: ../vector/v.build.polylines/main.c:113 ../vector/v.to.3d/main.c:37
+#: ../vector/v.univar/main.c:96 ../vector/v.mkgrid/main.c:71
+#: ../vector/v.overlay/main.c:64 ../vector/v.parallel/main.c:50
+#: ../vector/v.build/main.c:38 ../vector/v.select/main.c:49
+#: ../vector/v.to.points/main.c:54 ../vector/v.clean/main.c:53
+#: ../vector/v.drape/main.c:57 ../vector/v.perturb/main.c:63
+#: ../vector/v.patch/main.c:70 ../vector/v.delaunay/main.c:86
+#: ../vector/v.transform/main.c:71 ../vector/v.hull/main.c:53
+#: ../vector/v.buffer/main.c:225
+msgid "geometry"
+msgstr "지형"
-#: ../imagery/i.eb.evapfr/main.c:48 ../imagery/i.eb.netrad/main.c:57
-#: ../imagery/i.emissivity/main.c:47 ../imagery/i.eb.eta/main.c:43
-#: ../imagery/i.eb.soilheatflux/main.c:50 ../imagery/i.eb.hsebal01/main.c:105
-msgid "energy balance"
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:5
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:5
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:4
+#: ../vector/v.category/main.c:683 ../vector/v.edit/main.c:57
+#: ../vector/v.type/main.c:42 ../vector/v.build.polylines/main.c:114
+#: ../vector/v.parallel/main.c:52 ../vector/v.to.points/main.c:56
+#: ../vector/v.buffer/main.c:226
+msgid "line"
msgstr ""
-#: ../imagery/i.eb.evapfr/main.c:49 ../imagery/i.eb.hsebal01/main.c:106
-msgid "soil moisture"
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:6
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:5
+#: ../vector/v.category/main.c:679 ../vector/v.segment/main.c:63
+#: ../vector/v.edit/main.c:59 ../vector/v.type/main.c:43
+#: ../vector/v.to.points/main.c:59
+msgid "point"
msgstr ""
-#: ../imagery/i.eb.evapfr/main.c:50 ../imagery/i.eb.hsebal01/main.c:107
-msgid "evaporative fraction"
-msgstr ""
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:7
+#, fuzzy
+msgid "Method used for point interpolation"
+msgstr "출력할 격자지도"
-#: ../imagery/i.eb.evapfr/main.c:51 ../imagery/i.eb.netrad/main.c:59
-#: ../imagery/i.eb.eta/main.c:45 ../imagery/i.eb.soilheatflux/main.c:52
-#: ../imagery/i.eb.hsebal01/main.c:108
-msgid "SEBAL"
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:8
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:6
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:8
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:10
+msgid "Area"
msgstr ""
-#: ../imagery/i.eb.evapfr/main.c:53
-msgid "Computes evaporative fraction and root zone soil moisture."
-msgstr ""
-#: ../imagery/i.eb.evapfr/main.c:58 ../imagery/i.eb.soilheatflux/main.c:71
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
#, fuzzy
-msgid "Name of Net Radiation raster map [W/m2]"
+msgid "Imports attribute tables in various formats."
msgstr "출력할 격자지도"
-#: ../imagery/i.eb.evapfr/main.c:62
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:5
+msgid "Table file to be imported or DB connection string"
+msgstr ""
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:6
#, fuzzy
-msgid "Name of soil heat flux raster map [W/m2]"
+msgid "Name of table from given DB to be imported"
msgstr "출력할 격자지도"
-#: ../imagery/i.eb.evapfr/main.c:66
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:7
#, fuzzy
-msgid "Name of sensible heat flux raster map [W/m2]"
+msgid "Name for output table"
msgstr "출력할 격자지도"
-#: ../imagery/i.eb.evapfr/main.c:71
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:8
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:10
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:13
+#: ../locale/scriptstrings/i.spectral_to_translate.c:10
+#: ../locale/scriptstrings/i.spectral_to_translate.c:12
+#: ../locale/scriptstrings/r.import_to_translate.c:12
+#: ../locale/scriptstrings/r.import_to_translate.c:15
+#: ../locale/scriptstrings/r.import_to_translate.c:18
+#: ../locale/scriptstrings/r.import_to_translate.c:21
+#: ../locale/scriptstrings/r.import_to_translate.c:23
+#: ../locale/scriptstrings/v.import_to_translate.c:10
+#: ../locale/scriptstrings/v.import_to_translate.c:13
+#: ../locale/scriptstrings/v.import_to_translate.c:16
+#: ../locale/scriptstrings/v.import_to_translate.c:19
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:7
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:9
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:11
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:14
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:16
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:18
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:20
+#: ../locale/scriptstrings/m.proj_to_translate.c:11
+#: ../locale/scriptstrings/m.proj_to_translate.c:23
+#: ../locale/scriptstrings/m.proj_to_translate.c:25
+#: ../locale/scriptstrings/m.proj_to_translate.c:27
+#: ../raster3d/r3.flow/main.c:211 ../raster3d/r3.flow/main.c:218
+#: ../raster3d/r3.in.lidar/main.c:190 ../raster3d/r3.in.lidar/main.c:196
+#: ../raster3d/r3.in.lidar/main.c:202 ../raster/r.resamp.rst/main.c:174
+#: ../raster/r.resamp.rst/main.c:180 ../raster/r.resamp.rst/main.c:186
+#: ../raster/r.resamp.rst/main.c:192 ../raster/r.resamp.rst/main.c:198
+#: ../raster/r.resamp.rst/main.c:204 ../raster/r.resamp.rst/main.c:264
+#: ../raster/r.sun/main.c:391 ../raster/r.sun/main.c:400
+#: ../raster/r.sun/main.c:409 ../raster/r.sun/main.c:418
+#: ../raster/r.sun/main.c:427 ../raster/r.sun/main.c:436
+#: ../raster/r.spread/main.c:277 ../raster/r.spread/main.c:289
+#: ../raster/r.spread/main.c:301 ../raster/r.lake/main.c:167
+#: ../raster/r.lake/main.c:195 ../raster/r.sim/r.sim.sediment/main.c:178
+#: ../raster/r.sim/r.sim.sediment/main.c:185
+#: ../raster/r.sim/r.sim.sediment/main.c:192
+#: ../raster/r.sim/r.sim.sediment/main.c:198
+#: ../raster/r.sim/r.sim.sediment/main.c:205
+#: ../raster/r.sim/r.sim.sediment/main.c:212
+#: ../raster/r.sim/r.sim.sediment/main.c:219
+#: ../raster/r.sim/r.sim.water/main.c:197
+#: ../raster/r.sim/r.sim.water/main.c:203
+#: ../raster/r.sim/r.sim.water/main.c:209
+#: ../raster/r.sim/r.sim.water/main.c:216
+#: ../raster/r.sim/r.sim.water/main.c:223
+#: ../raster/r.sim/r.sim.water/main.c:298 ../raster/r.grow.distance/main.c:162
+#: ../raster/r.grow.distance/main.c:168 ../raster/r.in.lidar/main.c:126
+#: ../raster/r.in.lidar/main.c:252 ../raster/r.in.lidar/main.c:285
+#: ../raster/r.in.lidar/main.c:294 ../vector/v.out.ascii/args.c:35
+#: ../vector/v.out.ascii/args.c:81 ../vector/v.in.ogr/main.c:165
+#: ../vector/v.in.ogr/main.c:220 ../vector/v.in.ogr/main.c:270
+#: ../vector/v.in.ogr/main.c:276 ../vector/v.in.ogr/main.c:318
+msgid "Output"
+msgstr ""
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:9
#, fuzzy
-msgid "Name for output evaporative fraction raster map"
+msgid "Name for auto-generated unique key column"
msgstr "출력할 격자지도"
-#: ../imagery/i.eb.evapfr/main.c:77
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:11
+#: ../locale/scriptstrings/v.import_to_translate.c:14
+#: ../vector/v.in.ogr/main.c:233
#, fuzzy
-msgid "Name for output root zone soil moisture raster map"
+msgid "Encoding value for attribute data"
msgstr "출력할 격자지도"
-#: ../imagery/i.eb.evapfr/main.c:82
-msgid "Root zone soil moisture output (Makin, Molden and Bastiaanssen, 2001)"
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:12
+msgid "Overrides encoding interpretation, useful when importing DBF tables"
msgstr ""
-#: ../imagery/i.ifft/main.c:81
-msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
+#: ../locale/scriptstrings/r.blend_to_translate.c:1
+msgid "Blends color components of two raster maps by a given ratio."
msgstr ""
-#: ../imagery/i.ifft/main.c:86
+#: ../locale/scriptstrings/r.blend_to_translate.c:3
+#: ../raster/r.composite/main.c:73
#, fuzzy
-msgid "Name of input raster map (image fft, real part)"
+msgid "composite"
msgstr "출력할 격자지도"
-#: ../imagery/i.ifft/main.c:90
+#: ../locale/scriptstrings/r.blend_to_translate.c:4
#, fuzzy
-msgid "Name of input raster map (image fft, imaginary part"
+msgid "Name of first raster map for blending"
msgstr "출력할 격자지도"
-#: ../imagery/i.ifft/main.c:93
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:14
-#: ../locale/scriptstrings/r.import_to_translate.c:11
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:6
+#: ../locale/scriptstrings/r.blend_to_translate.c:5
#, fuzzy
-msgid "Name for output raster map"
+msgid "Name of second raster map for blending"
msgstr "출력할 격자지도"
-#: ../imagery/i.ifft/main.c:115
-msgid "The real and imaginary original windows did not match"
-msgstr ""
+#: ../locale/scriptstrings/r.blend_to_translate.c:6
+#, fuzzy
+msgid "Basename for red, green and blue output raster maps"
+msgstr "출력할 격자지도"
-#: ../imagery/i.ifft/main.c:157
+#: ../locale/scriptstrings/r.blend_to_translate.c:7
#, fuzzy
-msgid "Masking raster maps..."
+msgid "Percentage weight of first map for color blending"
msgstr "출력할 격자지도"
-#: ../imagery/i.ifft/main.c:200
-msgid "Starting Inverse FFT..."
+#: ../locale/scriptstrings/r.blend_to_translate.c:8
+msgid "Combine resulting R,G,B layers into single output map"
msgstr ""
-#: ../imagery/i.ifft/main.c:207 ../raster/r.random.cells/indep.c:139
-#: ../raster/r.random.surface/save.c:98 ../raster/r.drain/main.c:519
-#: ../raster/r.composite/main.c:191
-#, fuzzy, c-format
-msgid "Writing raster map <%s>..."
-msgstr "출력할 격자지도"
-#: ../imagery/i.gensig/means.c:26
+#: ../locale/scriptstrings/db.univar_to_translate.c:1
#, fuzzy
-msgid "Calculating class means..."
+msgid "Calculates univariate statistics on selected table column."
msgstr "출력할 격자지도"
-#: ../imagery/i.gensig/main.c:42 ../imagery/i.maxlik/main.c:63
-msgid "Maximum Likelihood Classification"
-msgstr ""
+#: ../locale/scriptstrings/db.univar_to_translate.c:3
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:3
+#: ../locale/scriptstrings/d.correlate_to_translate.c:3
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:6
+#: ../locale/scriptstrings/i.oif_to_translate.c:4
+#: ../locale/scriptstrings/v.report_to_translate.c:4
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:3
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:3
+#: ../raster3d/r3.neighbors/main.c:211 ../raster3d/r3.stats/main.c:49
+#: ../raster3d/r3.in.lidar/main.c:165 ../raster/r.mode/main.c:55
+#: ../raster/r.in.xyz/main.c:160 ../raster/r.univar/r3.univar_main.c:99
+#: ../raster/r.univar/r.univar_main.c:105 ../raster/r.surf.area/main.c:78
+#: ../raster/r.texture/main.c:103 ../raster/r.clump/main.c:59
+#: ../raster/r.quantile/main.c:263 ../raster/r.neighbors/main.c:169
+#: ../raster/r.stats.zonal/main.c:102 ../raster/r.report/main.c:68
+#: ../raster/r.cross/main.c:70 ../raster/r.support.stats/main.c:39
+#: ../raster/r.stats.quantile/main.c:517 ../raster/r.regression.line/main.c:47
+#: ../raster/r.quant/main.c:48 ../raster/r.statistics/main.c:56
+#: ../raster/r.kappa/main.c:69 ../raster/r.covar/main.c:52
+#: ../raster/r.mfilter/main.c:58 ../raster/r.in.lidar/main.c:111
+#: ../raster/r.stats/main.c:107 ../raster/r.regression.multi/main.c:129
+#: ../raster/r.coin/main.c:67 ../display/d.histogram/main.c:85
+#: ../vector/v.random/main.c:99 ../vector/v.class/main.c:48
+#: ../vector/v.univar/main.c:93 ../vector/v.qcount/main.c:61
+#: ../vector/v.kcv/main.c:56 ../vector/v.outlier/main.c:70
+#: ../vector/v.perturb/main.c:64 ../vector/v.neighbors/main.c:52
+#: ../vector/v.normal/main.c:73 ../imagery/i.cca/main.c:85
+msgid "statistics"
+msgstr "통계"
-#: ../imagery/i.gensig/main.c:46
+#: ../locale/scriptstrings/db.univar_to_translate.c:5
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:5
#, fuzzy
-msgid "Generates statistics for i.maxlik from raster map."
+msgid ""
+"Name of attribute column on which to calculate statistics (must be numeric)"
msgstr "출력할 격자지도"
-#: ../imagery/i.gensig/covariance.c:30
-msgid "Calculating class covariance matrices..."
+#: ../locale/scriptstrings/db.univar_to_translate.c:6
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
+#: ../raster/r.univar/r3.univar_main.c:52 ../raster/r.univar/r.univar_main.c:52
+#: ../vector/v.univar/main.c:122
+msgid "Percentile to calculate (requires extended statistics flag)"
msgstr ""
-#: ../imagery/i.gensig/check.c:21
-#, c-format
-msgid "Signature %d not invertible"
+#: ../locale/scriptstrings/db.univar_to_translate.c:7
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
+msgid "Extended statistics (quartiles and 90th percentile)"
msgstr ""
-#: ../imagery/i.gensig/check.c:27
-#, c-format
-msgid "Signature %d unable to get eigen values"
-msgstr ""
+#: ../locale/scriptstrings/db.univar_to_translate.c:8
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
+#, fuzzy
+msgid "Print stats in shell script style"
+msgstr "출력할 격자지도"
-#: ../imagery/i.gensig/check.c:33
-#, c-format
-msgid "Signature %d not positive definite"
-msgstr ""
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:1
+#, fuzzy
+msgid ""
+"Performs spatio-temporal mapcalc expressions on temporally sampled maps of "
+"space time raster datasets."
+msgstr "출력할 격자지도"
-#: ../imagery/i.segment/rclist.c:17 ../raster/r.clump/rclist.c:17
-msgid "rclist out of memory"
-msgstr ""
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:3
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:3
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:3
+#: ../raster3d/r3.neighbors/main.c:209 ../raster/r.mode/main.c:56
+#: ../raster/r.texture/main.c:102 ../raster/r.quantile/main.c:262
+#: ../raster/r.neighbors/main.c:168 ../raster/r.mfilter/main.c:57
+#: ../raster/r.mapcalc/main.c:70 ../vector/v.neighbors/main.c:51
+msgid "algebra"
+msgstr "대수"
-#: ../imagery/i.segment/region_growing.c:93 ../imagery/i.segment/cluster.c:342
-#: ../imagery/i.segment/cluster.c:412
-msgid "Too many objects: integer overflow"
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:6
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:6
+msgid "Spatio-temporal mapcalc expression"
msgstr ""
-#: ../imagery/i.segment/region_growing.c:251
-#: ../imagery/i.segment/mean_shift.c:220
-#, fuzzy, c-format
-msgid "Processing pass %d..."
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:7
+#, fuzzy
+msgid "Basename for output raster maps"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/region_growing.c:529
-#, c-format
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:8
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:8
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:9
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:15
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:14
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:7
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:7
msgid ""
-"Segmentation processes stopped at %d due to reaching max iteration limit, "
-"more merges may be possible"
+"A numerical suffix separated by an underscore will be attached to create a "
+"unique identifier"
msgstr ""
-#: ../imagery/i.segment/region_growing.c:531
-#, c-format
-msgid "Segmentation converged after %d iterations"
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:13
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:10
+msgid "Number of r.mapcalc processes to run in parallel"
msgstr ""
-#: ../imagery/i.segment/region_growing.c:534
-msgid "Assigning region IDs to remaining single-cell regions..."
-msgstr ""
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:10
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:12
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:11
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:14
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:14
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:12
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:11
+#, fuzzy
+msgid "Register Null maps"
+msgstr "출력할 격자지도"
-#: ../imagery/i.segment/region_growing.c:558
-#: ../imagery/i.segment/mean_shift.c:665
-#, c-format
-msgid "Merging segments smaller than %d cells..."
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:11
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:11
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:12
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:10
+msgid ""
+"Check the spatial topology of temporally related maps and process only "
+"spatially related maps"
msgstr ""
-#: ../imagery/i.segment/region_growing.c:972
-#, c-format
-msgid "Region stats should go in tree, %d >= %d"
-msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
+#, fuzzy
+msgid ""
+"Reconnects attribute tables for all vector maps from the current mapset to a "
+"new database."
+msgstr "출력할 격자지도"
-#: ../imagery/i.segment/region_growing.c:979
-msgid "Region ids are different"
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
+msgid "Copy attribute tables to the target database if not exist"
msgstr ""
-#: ../imagery/i.segment/region_growing.c:983
-#, fuzzy, c-format
-msgid "Region id %d is invalid"
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:6
+#, fuzzy
+msgid "Delete attribute tables from the source database"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/region_growing.c:987
-msgid "Region consists of only one cell, nothing to update"
-msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:7
+#, fuzzy
+msgid "Name of source database"
+msgstr "출력할 격자지도"
-#: ../imagery/i.segment/region_growing.c:1031
-#: ../imagery/i.segment/region_growing.c:1485
-#, c-format
-msgid "Region size is larger than 2: %d"
-msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:8
+#, fuzzy
+msgid "Name of source database schema"
+msgstr "출력할 격자지도"
-#: ../imagery/i.segment/region_growing.c:1098
-#, c-format
-msgid "Region size is %d, should be %d"
-msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:9
+#, fuzzy
+msgid "Name for target driver"
+msgstr "출력할 격자지도"
-#: ../imagery/i.segment/region_growing.c:1340
-#, c-format
-msgid "Candidate flag is already %s"
-msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:10
+#, fuzzy
+msgid "Name for target database"
+msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:11
#, fuzzy
-msgid "set"
+msgid "Name for target database schema"
msgstr "출력할 격자지도"
-msgid "unset"
+msgid ""
+"Displays spectral response at user specified locations in group or images."
msgstr ""
-#: ../imagery/i.segment/region_growing.c:1570
-#, c-format
-msgid "Region of size %d should be in search tree"
+#: ../locale/scriptstrings/i.spectral_to_translate.c:3
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:6
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:6
+#: ../raster/r.what.color/main.c:89 ../raster/r.what/main.c:99
+#: ../display/d.where/main.c:46 ../vector/v.what.rast3/main.c:68
+#: ../vector/v.what.rast/main.c:75 ../vector/v.what/main.c:61
+#, fuzzy
+msgid "querying"
+msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/i.spectral_to_translate.c:5
+#: ../locale/scriptstrings/i.oif_to_translate.c:3
+msgid "multispectral"
msgstr ""
-#: ../imagery/i.segment/open_files.c:39
-#, fuzzy, c-format
-msgid "Group <%s> not found in the current mapset"
-msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/i.spectral_to_translate.c:6
+#: ../locale/scriptstrings/i.spectral_to_translate.c:7
+#: ../locale/scriptstrings/i.spectral_to_translate.c:8
+#: ../locale/scriptstrings/r.import_to_translate.c:6
+#: ../locale/scriptstrings/r.import_to_translate.c:8
+#: ../locale/scriptstrings/v.import_to_translate.c:6
+#: ../locale/scriptstrings/v.import_to_translate.c:8
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:18
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:20
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:22
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:24
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:27
+#: ../locale/scriptstrings/t.remove_to_translate.c:6
+#: ../locale/scriptstrings/t.remove_to_translate.c:9
+#: ../locale/scriptstrings/t.remove_to_translate.c:11
+#: ../locale/scriptstrings/t.register_to_translate.c:6
+#: ../locale/scriptstrings/t.register_to_translate.c:7
+#: ../locale/scriptstrings/t.register_to_translate.c:9
+#: ../locale/scriptstrings/t.register_to_translate.c:12
+#: ../locale/scriptstrings/t.register_to_translate.c:26
+#: ../raster3d/r3.flow/main.c:188 ../raster3d/r3.flow/main.c:195
+#: ../raster3d/r3.flow/main.c:205 ../raster3d/r3.in.lidar/main.c:177
+#: ../raster3d/r3.in.lidar/main.c:184 ../raster/r.in.xyz/main.c:217
+#: ../raster/r.in.xyz/main.c:226 ../raster/r.in.xyz/main.c:234
+#: ../raster/r.in.xyz/main.c:245 ../raster/r.in.xyz/main.c:255
+#: ../raster/r.sun/main.c:260 ../raster/r.sun/main.c:269
+#: ../raster/r.sun/main.c:278 ../raster/r.sun/main.c:287
+#: ../raster/r.sun/main.c:295 ../raster/r.sun/main.c:304
+#: ../raster/r.sun/main.c:313 ../raster/r.sun/main.c:322
+#: ../raster/r.sun/main.c:331 ../raster/r.sun/main.c:340
+#: ../raster/r.sun/main.c:349 ../raster/r.sun/main.c:358
+#: ../raster/r.sun/main.c:367 ../raster/r.sun/main.c:374
+#: ../raster/r.sun/main.c:382 ../raster/r.spread/main.c:125
+#: ../raster/r.spread/main.c:139 ../raster/r.spread/main.c:151
+#: ../raster/r.spread/main.c:164 ../raster/r.spread/main.c:177
+#: ../raster/r.spread/main.c:189 ../raster/r.spread/main.c:201
+#: ../raster/r.sim/r.sim.sediment/main.c:157
+#: ../raster/r.sim/r.sim.sediment/main.c:165
+#: ../raster/r.sim/r.sim.sediment/main.c:172
+#: ../raster/r.sim/r.sim.water/main.c:138
+#: ../raster/r.sim/r.sim.water/main.c:147
+#: ../raster/r.sim/r.sim.water/main.c:154
+#: ../raster/r.sim/r.sim.water/main.c:163
+#: ../raster/r.sim/r.sim.water/main.c:169
+#: ../raster/r.sim/r.sim.water/main.c:177
+#: ../raster/r.sim/r.sim.water/main.c:184
+#: ../raster/r.sim/r.sim.water/main.c:191 ../raster/r.horizon/main.c:195
+#: ../raster/r.horizon/main.c:204 ../raster/r.horizon/main.c:212
+#: ../raster/r.external/main.c:66 ../raster/r.external/main.c:74
+#: ../raster/r.external/main.c:83 ../raster/r.in.lidar/main.c:122
+#: ../raster/r.in.lidar/main.c:133 ../display/d.legend/main.c:88
+#: ../display/d.legend/main.c:93 ../display/d.text/main.c:148
+#: ../display/d.text/main.c:153 ../vector/v.edit/args.c:90
+#: ../vector/v.edit/args.c:209 ../vector/v.in.ogr/main.c:160
+msgid "Input"
+msgstr "입력"
-#: ../imagery/i.segment/open_files.c:43
-#, fuzzy, c-format
-msgid "Group <%s> contains no raster maps"
+#: ../locale/scriptstrings/i.spectral_to_translate.c:9
+#, fuzzy
+msgid "Name for output image (or text file for -t)"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/open_files.c:71 ../imagery/i.segment/open_files.c:238
-#: ../imagery/i.segment/open_files.c:246
-#: ../imagery/i.segment/write_output.c:112 ../raster/r.clump/clump.c:449
-#, fuzzy, c-format
-msgid "No min/max found in raster map <%s>"
+#: ../locale/scriptstrings/i.spectral_to_translate.c:11
+#, fuzzy
+msgid "Graphics format for output file"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/open_files.c:120
-msgid "Insufficient number of non-NULL cells in current region"
+#: ../locale/scriptstrings/i.spectral_to_translate.c:13
+msgid "Show sampling coordinates instead of numbering in the legend"
msgstr ""
-#: ../imagery/i.segment/open_files.c:151
+#: ../locale/scriptstrings/i.spectral_to_translate.c:14
#, fuzzy
-msgid "Loading input bands..."
+msgid "Use gnuplot for display"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/open_files.c:153
+#: ../locale/scriptstrings/i.spectral_to_translate.c:15
#, fuzzy
-msgid "Loading input band..."
+msgid "output to text file"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/open_files.c:185 ../imagery/i.segment/open_files.c:190
-#: ../imagery/i.segment/open_files.c:212 ../imagery/i.segment/open_files.c:270
-#: ../imagery/i.segment/open_files.c:358 ../imagery/i.segment/open_files.c:424
-#: ../imagery/i.segment/open_files.c:480
+#: ../locale/scriptstrings/t.sample_to_translate.c:1
#, fuzzy
-msgid "Unable to write to temporary file"
+msgid ""
+"Samples the input space time dataset(s) with a sample space time dataset and "
+"print the result to stdout."
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/open_files.c:277
-#, c-format
-msgid "There are no boundary constraints in '%s'"
+#: ../locale/scriptstrings/t.sample_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:3
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:3
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:4
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:3
+#: ../raster/r.random/main.c:52 ../raster/r.random.cells/main.c:48
+#: ../display/d.where/main.c:44 ../vector/v.what.rast3/main.c:65
+#: ../vector/v.extrude/main.c:69 ../vector/v.random/main.c:98
+#: ../vector/v.sample/main.c:76 ../vector/v.drape/main.c:58
+#: ../vector/v.what.rast/main.c:72
+msgid "sampling"
msgstr ""
-#: ../imagery/i.segment/open_files.c:333
-#, fuzzy, c-format
-msgid "Loading seeds from raster map <%s>..."
+#: ../locale/scriptstrings/t.sample_to_translate.c:5
+#, fuzzy
+msgid "Name of the sample space time dataset"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/open_files.c:363
-#, fuzzy, c-format
-msgid "No seeds found in '%s'!"
+#: ../locale/scriptstrings/t.sample_to_translate.c:8
+#, fuzzy
+msgid "Type of the sample space time dataset"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/open_files.c:383
-msgid "Too many seeds: integer overflow"
+#: ../locale/scriptstrings/t.sample_to_translate.c:9
+msgid "Field separator between output columns, default is tabular \" | \""
msgstr ""
-#: ../imagery/i.segment/open_files.c:500
-#, fuzzy, c-format
-msgid "Segment %d is already registered!"
-msgstr "출력할 격자지도"
-#: ../imagery/i.segment/open_files.c:554
-#, c-format
-msgid "Regions with at least %d cells are stored in memory"
+#: ../locale/scriptstrings/t.sample_to_translate.c:10
+msgid ""
+"Do not use \",\" as this char is reserved to list several map ids in a "
+"sample granule"
msgstr ""
-#: ../imagery/i.segment/open_files.c:594
-#, c-format
-msgid "Number of segments in memory: %d of %d total"
+#: ../locale/scriptstrings/t.sample_to_translate.c:11
+#: ../locale/scriptstrings/t.list_to_translate.c:18
+msgid "Print the column names as first row"
msgstr ""
-#: ../imagery/i.segment/mean_shift.c:93
-#, c-format
-msgid "Estimating spectral bandwidth for spatial bandwidth %g..."
+#: ../locale/scriptstrings/t.sample_to_translate.c:12
+msgid "Check for spatial topological overlap"
msgstr ""
-#: ../imagery/i.segment/mean_shift.c:167
-msgid "Empty moving windows"
-msgstr ""
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:1
+#, fuzzy
+msgid "Exports space time raster dataset as VTK time series."
+msgstr "출력할 격자지도"
-#: ../imagery/i.segment/mean_shift.c:186
-#, c-format
-msgid "Initial range bandwidth: %g"
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:5
+msgid "VTK"
msgstr ""
-#: ../imagery/i.segment/mean_shift.c:188 ../imagery/i.segment/mean_shift.c:192
-#, c-format
-msgid "Estimated range bandwidth: %g"
-msgstr ""
-#: ../imagery/i.segment/mean_shift.c:208 ../imagery/i.segment/mean_shift.c:245
-#, c-format
-msgid "Spatial bandwidth: %g"
-msgstr ""
-#: ../imagery/i.segment/mean_shift.c:209 ../imagery/i.segment/mean_shift.c:246
-#, fuzzy, c-format
-msgid "Range bandwidth: %g"
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:7
+#, fuzzy
+msgid "Path to the export directory"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/mean_shift.c:395
-#, c-format
-msgid "Changes > threshold: %d, largest change: %g"
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:8
+#: ../raster/r.out.vtk/parameters.c:45
+msgid "Value to represent no data cell"
msgstr ""
-#: ../imagery/i.segment/mean_shift.c:398
-#, c-format
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:9
+#: ../raster/r.out.vtk/parameters.c:59
msgid ""
-"Mean shift stopped at %d due to reaching max iteration limit, more changes "
-"may be possible"
+"Create VTK point data instead of VTK cell data (if no elevation map is given)"
msgstr ""
-#: ../imagery/i.segment/mean_shift.c:400
-#, c-format
-msgid "Mean shift converged after %d iterations"
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:10
+#: ../vector/v.out.vtk/main.c:84
+msgid "Correct the coordinates to fit the VTK-OpenGL precision"
msgstr ""
-#: ../imagery/i.segment/mean_shift.c:748
-#, fuzzy, c-format
-msgid "Renumbering remaining %d segments..."
-msgstr "출력할 격자지도"
-#: ../imagery/i.segment/main.c:39
-msgid "object recognition"
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:11
+msgid ""
+"Export files using the space time dataset granularity for equidistant time "
+"between maps, where statement will be ignored"
msgstr ""
-#: ../imagery/i.segment/main.c:41
-msgid "Identifies segments (objects) from imagery data."
-msgstr ""
-#: ../imagery/i.segment/main.c:47
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
#, fuzzy
-msgid "Error in reading data"
+msgid ""
+"Calculates univariate statistics from a raster map based on a vector map and "
+"uploads statistics to new attribute columns."
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/main.c:51
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
+#: ../raster/r.univar/r3.univar_main.c:100
+#: ../raster/r.univar/r.univar_main.c:106 ../vector/v.univar/main.c:94
+#: ../vector/v.vect.stats/main.c:127
#, fuzzy
-msgid "Error in creating segments"
+msgid "univariate statistics"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/main.c:55
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
+#: ../raster/r.univar/r.univar_main.c:107 ../raster/r.stats.zonal/main.c:103
+#: ../raster/r.statistics/main.c:57 ../vector/v.vect.stats/main.c:128
#, fuzzy
-msgid "Error in writing IDs"
+msgid "zonal statistics"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/main.c:59
-#, fuzzy
-msgid "Error in writing goodness of fit"
-msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
+msgid "Continue if upload column(s) already exist"
+msgstr ""
-#: ../imagery/i.segment/main.c:64
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:8
#, fuzzy
-msgid "Error in writing new band values"
+msgid "Name of input raster map to calculate statistics from"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/main.c:70
-#, fuzzy, c-format
-msgid "Number of segments created: %d"
-msgstr "출력할 격자지도"
-#: ../imagery/i.segment/write_output.c:24
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
#, fuzzy
-msgid "Writing out segment IDs..."
+msgid "Column prefix for new attribute columns"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/write_output.c:120
-msgid "Writing out goodness of fit"
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:10
+msgid "The methods to use"
msgstr ""
-#: ../imagery/i.segment/write_output.c:236
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:11
#, fuzzy
-msgid "Writing out shifted band values..."
+msgid "Percentile to calculate"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/cluster.c:66
-#, fuzzy, c-format
-msgid "%d-band clustering with threshold %g"
+#, fuzzy
+msgid "Lists space time datasets and maps registered in the temporal database."
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/cluster.c:121 ../raster/r.clump/minsize.c:373
-#: ../raster/r.clump/clump.c:211 ../raster/r.clump/clump.c:475
+#: ../locale/scriptstrings/t.list_to_translate.c:6
#, fuzzy
-msgid "Unable to open temp file"
+msgid "Type of the space time dataset or map, default is strds"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/cluster.c:135
-msgid "Assigning initial region IDs..."
+#: ../locale/scriptstrings/t.list_to_translate.c:9
+#: ../locale/scriptstrings/t.list_to_translate.c:12
+msgid ""
+"Columns number_of_maps and granularity only available for space time datasets"
msgstr ""
-#: ../imagery/i.segment/cluster.c:363 ../imagery/i.segment/cluster.c:377
-#: ../raster/r.clump/minsize.c:163 ../raster/r.clump/minsize.c:390
-#: ../raster/r.clump/clump.c:113 ../raster/r.clump/clump.c:345
-#: ../raster/r.clump/clump.c:359 ../raster/r.clump/clump.c:646
-#: ../raster/r.clump/clump.c:660
+#: ../locale/scriptstrings/t.list_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:7
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:7
#, fuzzy
-msgid "Unable to write to temp file"
+msgid "Sort the space time dataset by category"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/cluster.c:386 ../raster/r.clump/clump.c:51
-#: ../vector/v.cluster/main.c:404 ../vector/v.cluster/main.c:613
-#: ../vector/v.cluster/main.c:970
#, fuzzy
-msgid "Generating renumbering scheme..."
+msgid ""
+"Apply temporal and spatial operations on space time 3D raster datasets using "
+"temporal 3D raster algebra."
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/cluster.c:425
-msgid "Assigning final region IDs..."
-msgstr ""
-#: ../imagery/i.segment/cluster.c:431 ../raster/r.clump/minsize.c:152
-#: ../raster/r.clump/minsize.c:253 ../raster/r.clump/minsize.c:287
-#: ../raster/r.clump/minsize.c:293 ../raster/r.clump/minsize.c:424
-#: ../raster/r.clump/minsize.c:447 ../raster/r.clump/minsize.c:518
-#: ../raster/r.clump/clump.c:97 ../raster/r.clump/clump.c:149
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:7
#, fuzzy
-msgid "Unable to read from temp file"
+msgid ""
+"Algebraic expression for temporal and spatial analysis of space time 3D "
+"raster datasets"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/cluster.c:455
-#, fuzzy, c-format
-msgid "Found %d clumps"
-msgstr "출력할 격자지도"
-#: ../imagery/i.segment/flag.c:21 ../imagery/i.segment/flag.c:28
-#: ../vector/v.distance/main.c:748 ../vector/v.distance/main.c:825
-#: ../vector/v.distance/main.c:1033
-msgid "Out of memory!"
-msgstr ""
-#: ../imagery/i.segment/watershed.c:19
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:7
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:8
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:14
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:13
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:6
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:6
#, fuzzy
-msgid "Watershed is not yet implemented"
+msgid "Basename of the new generated output maps"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/parse_args.c:30
-msgid "Suffix for output bands with modified band values"
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:10
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:10
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:10
+msgid "Number of r3.mapcalc processes to run in parallel"
msgstr ""
-#: ../imagery/i.segment/parse_args.c:36
-msgid "Difference threshold between 0 and 1"
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:13
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:12
+msgid "Use granularity sampling instead of the temporal topology approach"
msgstr ""
-#: ../imagery/i.segment/parse_args.c:37
-msgid "Threshold = 0 merges only identical segments; threshold = 1 merges all"
-msgstr ""
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:1
+#, fuzzy
+msgid "Imports SRTM HGT files into raster map."
+msgstr "출력할 격자지도"
-#: ../imagery/i.segment/parse_args.c:46
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:4
#, fuzzy
-msgid "Spatial radius in number of cells"
-msgstr "셀 개수"
+msgid "Name of SRTM input tile (file without .hgt.zip extension)"
+msgstr "출력할 격자지도"
-#: ../imagery/i.segment/parse_args.c:47
-msgid ""
-"Must be >= 1, only cells within spatial bandwidth are considered for mean "
-"shift"
-msgstr ""
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:5
+#, fuzzy
+msgid "Name for output raster map (default: input tile)"
+msgstr "출력할 격자지도"
-#: ../imagery/i.segment/parse_args.c:53
-msgid "Range (spectral) bandwidth [0, 1]"
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:6
+msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
msgstr ""
-#: ../imagery/i.segment/parse_args.c:54
-msgid ""
-"Only cells within range (spectral) bandwidth are considered for mean shift. "
-"Range bandwidth is used as conductance parameter for adaptive bandwidth"
+#: ../locale/scriptstrings/d.redraw_to_translate.c:1
+msgid "Redraws the content of currently selected monitor."
msgstr ""
-#: ../imagery/i.segment/parse_args.c:67
+#: ../locale/scriptstrings/d.redraw_to_translate.c:4
+#: ../locale/scriptstrings/d.frame_to_translate.c:4 ../display/d.mon/main.c:40
+#: ../display/d.info/main.c:36 ../display/d.erase/main.c:31
#, fuzzy
-msgid "Segmentation method"
+msgid "monitors"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/parse_args.c:76
-msgid "Similarity calculation method"
-msgstr ""
+#, fuzzy
+msgid "Extracts a subset of a space time 3D raster dataset."
+msgstr "출력할 격자지도"
-#: ../imagery/i.segment/parse_args.c:85
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:3
+#: ../vector/v.extract/main.c:78 ../vector/v.decimate/main.c:127
+#: ../vector/v.outlier/main.c:71
#, fuzzy
-msgid "Minimum number of cells in a segment"
+msgid "extract"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/parse_args.c:87
-msgid "The final step will merge small segments with their best neighbor"
-msgstr ""
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:7
+#, fuzzy
+msgid "The r3.mapcalc expression assigned to all extracted 3D raster maps"
+msgstr "출력할 격자지도"
-#: ../imagery/i.segment/parse_args.c:98
-msgid "Importance of radiometric (input raster) values relative to shape"
-msgstr ""
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:8
+#, fuzzy
+msgid "Basename of the new generated 3D raster maps"
+msgstr "출력할 격자지도"
-#: ../imagery/i.segment/parse_args.c:108
-msgid "Importance of smoothness relative to compactness"
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:15
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:8
+msgid ""
+"Suffix to add at basename: set 'gran' for granularity, 'time' for the full "
+"time format, 'num' for numerical suffix with a specific number of digits "
+"(default %05)"
msgstr ""
-#: ../imagery/i.segment/parse_args.c:117
-msgid "Memory in MB"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:126 ../imagery/i.cluster/main.c:126
-msgid "Maximum number of iterations"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:134
+#: ../locale/scriptstrings/t.snap_to_translate.c:1
#, fuzzy
-msgid "Name for input raster map with starting seeds"
+msgid "Snaps temporally the maps of a space time dataset."
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/parse_args.c:141
+#: ../locale/scriptstrings/t.snap_to_translate.c:3
+#: ../locale/scriptstrings/t.shift_to_translate.c:3
+#: ../locale/scriptstrings/t.merge_to_translate.c:3
#, fuzzy
-msgid "Name of input bounding/constraining raster map"
-msgstr "출력할 격자지도"
+msgid "time management"
+msgstr "지도관리"
-#: ../imagery/i.segment/parse_args.c:143
-msgid ""
-"Must be integer values, each area will be segmented independent of the others"
+#: ../locale/scriptstrings/t.snap_to_translate.c:4 ../vector/v.clean/main.c:54
+msgid "snapping"
msgstr ""
-#: ../imagery/i.segment/parse_args.c:150
+#: ../locale/scriptstrings/t.snap_to_translate.c:6
+#: ../locale/scriptstrings/t.shift_to_translate.c:6
#, fuzzy
-msgid "Name for output goodness of fit estimate map"
+msgid "Name of an existing space time dataset"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/parse_args.c:156
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:1
+#, fuzzy
msgid ""
-"Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for "
-"each pixel"
+"Produces a space time vector dataset of specified contours from a space time "
+"raster dataset."
+msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:3
+msgid "contour"
msgstr ""
-#: ../imagery/i.segment/parse_args.c:162
-msgid "Weighted input, do not perform the default scaling of input raster maps"
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:10
+#: ../raster/r.contour/main.c:101
+msgid "Increment between contour levels"
msgstr ""
-#: ../imagery/i.segment/parse_args.c:167
-msgid "Use adaptive bandwidth for mean shift"
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:11
+#: ../raster/r.contour/main.c:109
+msgid "List of contour levels"
msgstr ""
-#: ../imagery/i.segment/parse_args.c:168
-msgid "Range (spectral) bandwidth is adapted for each moving window"
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:12
+#: ../raster/r.contour/main.c:116
+msgid "Minimum contour level"
msgstr ""
-#: ../imagery/i.segment/parse_args.c:173
-msgid "Use progressive bandwidth for mean shift"
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:13
+#: ../raster/r.contour/main.c:123
+msgid "Maximum contour level"
msgstr ""
-#: ../imagery/i.segment/parse_args.c:175
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:14
+#: ../raster/r.contour/main.c:132
+msgid "Minimum number of points for a contour line (0 -> no limit)"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:15
msgid ""
-"Spatial bandwidth is increased, range (spectral) bandwidth is decreased in "
-"each iteration"
+"Number of r.contour processes to run in parallel, more than 1 process works "
+"only in conjunction with flag -t"
msgstr ""
-#: ../imagery/i.segment/parse_args.c:194
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:16
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:13
#, fuzzy
-msgid "Threshold should be > 0 and < 1"
+msgid "Register empty vector maps"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/parse_args.c:200
-#, fuzzy, c-format
-msgid "Option '%s' must be >= 1"
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:17
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:14
+#, fuzzy
+msgid "Do not create attribute tables"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/parse_args.c:208
-#, c-format
-msgid "Negative value %s for option '%s': disabling"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:213
-#, c-format
-msgid "Value %s for option '%s' is >= 1: disabling"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:235
+#: ../locale/scriptstrings/v.unpack_to_translate.c:1
#, fuzzy
-msgid "Unable to assign segmentation method"
+msgid ""
+"Imports a vector map as GRASS GIS specific archive file (packed with v.pack)"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/parse_args.c:245
-msgid "Invalid similarity method"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:251
-#, fuzzy, c-format
-msgid "Option '%s' must be > 0"
+#: ../locale/scriptstrings/v.unpack_to_translate.c:5
+#: ../locale/scriptstrings/r.unpack_to_translate.c:5
+#, fuzzy
+msgid "Name of input pack file"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/parse_args.c:253 ../imagery/i.segment/parse_args.c:258
-#, fuzzy, c-format
-msgid "Option '%s' must be <= 1"
-msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/v.unpack_to_translate.c:6
+msgid "Name for output vector map"
+msgstr "출력 벡터지도 이름"
-#: ../imagery/i.segment/parse_args.c:256
-#, fuzzy, c-format
-msgid "Option '%s' must be >= 0"
+#: ../locale/scriptstrings/v.unpack_to_translate.c:7
+#, fuzzy
+msgid "Default: taken from input file internals"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/parse_args.c:284
+#: ../locale/scriptstrings/v.unpack_to_translate.c:8
+#: ../locale/scriptstrings/v.unpack_to_translate.c:11
+#: ../locale/scriptstrings/r.unpack_to_translate.c:7
+#: ../locale/scriptstrings/r.unpack_to_translate.c:10
+#: ../raster/r.univar/r.univar_main.c:42 ../raster/r.kappa/main.c:90
+#: ../raster/r.kappa/main.c:98 ../ps/ps.map/main.c:100 ../ps/ps.map/main.c:113
+#: ../ps/ps.map/main.c:135
#, fuzzy
-msgid "Seeds raster map not found"
+msgid "Output settings"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/parse_args.c:288
+#: ../locale/scriptstrings/v.unpack_to_translate.c:9
+#: ../locale/scriptstrings/r.import_to_translate.c:31
+#: ../locale/scriptstrings/v.import_to_translate.c:27
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:17
+#: ../locale/scriptstrings/r.unpack_to_translate.c:8
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:13
+#: ../raster3d/r3.in.lidar/main.c:293 ../raster/r.external/main.c:102
+#: ../raster/r.in.gdal/main.c:178 ../raster/r.in.lidar/main.c:299
+#: ../vector/v.external/args.c:43 ../vector/v.in.ogr/main.c:284
+#: ../vector/v.in.lidar/main.c:319
+msgid "Override projection check (use current location's projection)"
+msgstr ""
+#: ../locale/scriptstrings/v.unpack_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:18
+#: ../locale/scriptstrings/r.unpack_to_translate.c:9
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:14
+#: ../raster3d/r3.in.lidar/main.c:295 ../raster/r.external/main.c:104
+#: ../raster/r.in.gdal/main.c:180 ../raster/r.in.lidar/main.c:301
+#: ../vector/v.in.lidar/main.c:321
#, fuzzy
-msgid "Seeeds raster map must be CELL type (integers)"
+msgid "Assume that the dataset has same projection as the current location"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/parse_args.c:298
#, fuzzy
-msgid "Segmentation constraint/boundary raster map not found"
+msgid ""
+"Performs r3.mapcalc expressions on maps of sampled space time 3D raster "
+"datasets."
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/parse_args.c:302
-msgid "Segmentation constraint raster map must be CELL type (integers)"
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:7
+msgid "r3.mapcalc expression applied to each time step of the sampled data"
msgstr ""
-#: ../imagery/i.segment/parse_args.c:321
-msgid "Integer overflow: too many cells in current region"
-msgstr ""
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:1
+#, fuzzy
+msgid ""
+"Prints attributes of vector maps registered in a space time vector dataset."
+msgstr "출력할 격자지도"
-#: ../imagery/i.segment/parse_args.c:334
-msgid "Invalid output raster name for goodness of fit"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:341
-#, fuzzy, c-format
-msgid "Maximum number of iterations set to %d"
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:6
+#: ../vector/v.extract/main.c:79 ../vector/v.decimate/main.c:128
+#: ../vector/v.outlier/main.c:72
+#, fuzzy
+msgid "select"
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/parse_args.c:351
-#, fuzzy, c-format
-msgid "Invalid number of iterations, %d will be used"
+#: ../locale/scriptstrings/v.db.update_to_translate.c:1
+#, fuzzy
+msgid "Updates a column in the attribute table connected to a vector map."
msgstr "출력할 격자지도"
-#: ../imagery/i.segment/parse_args.c:360
-msgid "Invalid number of MB, 300 will be used"
-msgstr ""
-#: ../imagery/i.vi/main.c:90
+#: ../locale/scriptstrings/v.db.update_to_translate.c:5
#, fuzzy
-msgid "vegetation index"
+msgid "Name of attribute column to update"
msgstr "출력할 격자지도"
-#: ../imagery/i.vi/main.c:91
-msgid "biophysical parameters"
+#: ../locale/scriptstrings/v.db.update_to_translate.c:6
+msgid "Literal value to update the column with"
msgstr ""
-#: ../imagery/i.vi/main.c:93
-msgid "Calculates different types of vegetation indices."
-msgstr ""
-#: ../imagery/i.vi/main.c:94
+#: ../locale/scriptstrings/v.db.update_to_translate.c:7
msgid ""
-"Uses red and nir bands mostly, and some indices require additional bands."
+"Name of other attribute column to query, can be combination of columns (e.g. "
+"co1+col2)"
msgstr ""
-#: ../imagery/i.vi/main.c:101
-#, fuzzy
-msgid "Name of input red channel surface reflectance map"
-msgstr "출력할 격자지도"
-#: ../imagery/i.vi/main.c:102 ../imagery/i.vi/main.c:141
-#: ../imagery/i.vi/main.c:149 ../imagery/i.vi/main.c:157
-#: ../imagery/i.vi/main.c:165 ../imagery/i.vi/main.c:173
-msgid "Range: [0.0;1.0]"
+#: ../locale/scriptstrings/v.db.update_to_translate.c:8
+msgid "Name of SQLite extension file for extra functions (SQLite backend only)"
msgstr ""
-#: ../imagery/i.vi/main.c:110
#, fuzzy
-msgid "Type of vegetation index"
+msgid ""
+"Imports raster data into a GRASS raster map using GDAL library and "
+"reprojects on the fly."
msgstr "출력할 격자지도"
-#: ../imagery/i.vi/main.c:115
+#: ../locale/scriptstrings/r.import_to_translate.c:5
#, fuzzy
-msgid "Atmospherically Resistant Vegetation Index"
+msgid "Name of GDAL dataset to be imported"
msgstr "출력할 격자지도"
-#: ../imagery/i.vi/main.c:116
-#, fuzzy
-msgid "Difference Vegetation Index"
-msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/r.import_to_translate.c:7
+msgid "Input band(s) to select (default is all bands)"
+msgstr ""
-#: ../imagery/i.vi/main.c:117
-#, fuzzy
-msgid "Enhanced Vegetation Index"
-msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/r.import_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:13
+#: ../raster/r.resamp.bspline/main.c:151 ../raster/r.stream.extract/main.c:141
+#: ../raster/r.proj/main.c:191 ../raster/r.in.gdal/main.c:116
+#: ../vector/v.surf.bspline/main.c:194 ../vector/v.to.rast/main.c:116
+msgid "Maximum memory to be used (in MB)"
+msgstr ""
-#: ../imagery/i.vi/main.c:118
-#, fuzzy
-msgid "Enhanced Vegetation Index 2"
-msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/r.import_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:12
+#: ../raster/r.resamp.bspline/main.c:152 ../raster/r.stream.extract/main.c:142
+#: ../raster/r.proj/main.c:192 ../raster/r.in.gdal/main.c:117
+#: ../vector/v.surf.bspline/main.c:195 ../vector/v.to.rast/main.c:117
+msgid "Cache size for raster rows"
+msgstr ""
-#: ../imagery/i.vi/main.c:119
+#: ../locale/scriptstrings/r.import_to_translate.c:11
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:6
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:14
+#: ../imagery/i.ifft/main.c:93
#, fuzzy
-msgid "Green Vegetation Index"
+msgid "Name for output raster map"
msgstr "출력할 격자지도"
-#: ../imagery/i.vi/main.c:120
+#: ../locale/scriptstrings/r.import_to_translate.c:13
#, fuzzy
-msgid "Green Atmospherically Resistant Vegetation Index"
+msgid "Resampling method to use for reprojection"
msgstr "출력할 격자지도"
-#: ../imagery/i.vi/main.c:121
-msgid "Global Environmental Monitoring Index"
+#: ../locale/scriptstrings/r.import_to_translate.c:14
+msgid ""
+"nearest;nearest neighbor;bilinear;bilinear interpolation;bicubic;bicubic "
+"interpolation;lanczos;lanczos filter;bilinear_f;bilinear interpolation with "
+"fallback;bicubic_f;bicubic interpolation with fallback;lanczos_f;lanczos "
+"filter with fallback"
msgstr ""
-#: ../imagery/i.vi/main.c:122
+#: ../locale/scriptstrings/r.import_to_translate.c:16
#, fuzzy
-msgid "Infrared Percentage Vegetation Index"
+msgid "Output raster map extent"
msgstr "출력할 격자지도"
-#: ../imagery/i.vi/main.c:123
-msgid "Modified Soil Adjusted Vegetation Index"
-msgstr ""
-#: ../imagery/i.vi/main.c:124
-msgid "second Modified Soil Adjusted Vegetation Index"
-msgstr ""
-#: ../imagery/i.vi/main.c:125
+#: ../locale/scriptstrings/r.import_to_translate.c:17
#, fuzzy
-msgid "Normalized Difference Vegetation Index"
+msgid "region;extent of current region;input;extent of input map"
msgstr "출력할 격자지도"
-#: ../imagery/i.vi/main.c:126
+#: ../locale/scriptstrings/r.import_to_translate.c:19
#, fuzzy
-msgid "Perpendicular Vegetation Index"
+msgid "Resolution of output raster map (default: estimated)"
msgstr "출력할 격자지도"
-#: ../imagery/i.vi/main.c:127
-#, fuzzy
-msgid "Soil Adjusted Vegetation Index"
-msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/r.import_to_translate.c:20
+msgid ""
+"estimated;estimated resolution;value;user-specified resolution;region;"
+"current region resolution"
+msgstr ""
-#: ../imagery/i.vi/main.c:128
+#: ../locale/scriptstrings/r.import_to_translate.c:22
#, fuzzy
-msgid "Simple Ratio"
+msgid "Resolution of output raster map (use with option resolution=value)"
msgstr "출력할 격자지도"
-#: ../imagery/i.vi/main.c:129
-msgid "Visible Atmospherically Resistant Index"
+#: ../locale/scriptstrings/r.import_to_translate.c:24
+#: ../raster/r.in.bin/main.c:298 ../raster/r.in.poly/main.c:50
+#: ../raster/r.external/main.c:90 ../raster/r.in.gdal/main.c:133
+#: ../raster/r.in.ascii/main.c:92 ../raster/r.support/main.c:66
+msgid "Title for resultant raster map"
msgstr ""
-#: ../imagery/i.vi/main.c:130
-#, fuzzy
-msgid "Weighted Difference Vegetation Index"
-msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/r.import_to_translate.c:25
+#: ../raster/r.external/main.c:91 ../raster/r.in.gdal/main.c:134
+#: ../raster/r.in.gdal/main.c:143 ../raster/r.in.gdal/main.c:152
+#: ../raster/r.in.gdal/main.c:158 ../imagery/i.landsat.toar/main.c:94
+#: ../imagery/i.landsat.toar/main.c:116 ../imagery/i.landsat.toar/main.c:126
+#: ../imagery/i.landsat.toar/main.c:135 ../imagery/i.landsat.toar/main.c:143
+#: ../imagery/i.landsat.toar/main.c:152
+msgid "Metadata"
+msgstr ""
-#: ../imagery/i.vi/main.c:134
+#: ../locale/scriptstrings/r.import_to_translate.c:26
#, fuzzy
-msgid "type"
+msgid "Estimate resolution only"
msgstr "출력할 격자지도"
-#: ../imagery/i.vi/main.c:140
+#: ../locale/scriptstrings/r.import_to_translate.c:27
+#: ../locale/scriptstrings/r.import_to_translate.c:29
+#: ../raster/r.horizon/main.c:278 ../raster/r.horizon/main.c:297
#, fuzzy
-msgid "Name of input nir channel surface reflectance map"
+msgid "Optional"
msgstr "출력할 격자지도"
-#: ../imagery/i.vi/main.c:142 ../imagery/i.vi/main.c:150
-#: ../imagery/i.vi/main.c:158 ../imagery/i.vi/main.c:166
-#: ../imagery/i.vi/main.c:174 ../vector/v.vol.rst/main.c:254
-#: ../vector/v.vol.rst/main.c:303
-#, fuzzy
-msgid "Optional inputs"
-msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/r.import_to_translate.c:28
+#: ../raster/r.proj/main.c:208
+msgid "Do not perform region cropping optimization"
+msgstr ""
-#: ../imagery/i.vi/main.c:148
-#, fuzzy
-msgid "Name of input green channel surface reflectance map"
-msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/r.import_to_translate.c:30
+#: ../raster/r.in.gdal/main.c:204
+msgid "Force Lat/Lon maps to fit into geographic coordinates (90N,S; 180E,W)"
+msgstr ""
-#: ../imagery/i.vi/main.c:156
+#: ../locale/scriptstrings/r.import_to_translate.c:32
+#: ../locale/scriptstrings/v.import_to_translate.c:28
+#: ../vector/v.external/args.c:45 ../vector/v.in.ogr/main.c:286
#, fuzzy
-msgid "Name of input blue channel surface reflectance map"
+msgid "Assume that the dataset has the same projection as the current location"
msgstr "출력할 격자지도"
-#: ../imagery/i.vi/main.c:164
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:1
#, fuzzy
-msgid "Name of input 5th channel surface reflectance map"
+msgid ""
+"Apply temporal and spatial operations on space time vector datasets using "
+"temporal vector algebra."
msgstr "출력할 격자지도"
-#: ../imagery/i.vi/main.c:172
+#: ../locale/scriptstrings/d.frame_to_translate.c:1
#, fuzzy
-msgid "Name of input 7th channel surface reflectance map"
+msgid "Manages display frames on the user's graphics monitor."
msgstr "출력할 격자지도"
-#: ../imagery/i.vi/main.c:180
-msgid "Value of the slope of the soil line (MSAVI only)"
+#: ../locale/scriptstrings/d.frame_to_translate.c:5
+msgid "frame"
msgstr ""
-#: ../imagery/i.vi/main.c:181 ../imagery/i.vi/main.c:188
-#: ../imagery/i.vi/main.c:195
-#, fuzzy
-msgid "MSAVI settings"
-msgstr "출력할 격자지도"
-#: ../imagery/i.vi/main.c:187
-msgid "Value of the intercept of the soil line (MSAVI only)"
+#: ../locale/scriptstrings/d.frame_to_translate.c:6
+msgid "Create a new frame if doesn't exist and select"
msgstr ""
-#: ../imagery/i.vi/main.c:194
-msgid "Value of the factor of reduction of soil noise (MSAVI only)"
+#: ../locale/scriptstrings/d.frame_to_translate.c:7
+msgid "Remove all frames, erase the screen and exit"
msgstr ""
-#: ../imagery/i.vi/main.c:201
-msgid "Maximum bits for digital numbers"
-msgstr ""
-#: ../imagery/i.vi/main.c:202
-msgid ""
-"If data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8 "
-"for Landsat -> [0-255])"
-msgstr ""
-#: ../imagery/i.vi/main.c:225
-#, fuzzy, c-format
-msgid "Calculating %s..."
+#: ../locale/scriptstrings/d.frame_to_translate.c:8
+#, fuzzy
+msgid "Print name of current frame and exit"
msgstr "출력할 격자지도"
-#: ../imagery/i.vi/main.c:228
-msgid "sr index requires red and nir maps"
+#: ../locale/scriptstrings/d.frame_to_translate.c:9
+msgid "Print names of all frames including 'at' position and exit"
msgstr ""
-#: ../imagery/i.vi/main.c:231
-msgid "ndvi index requires red and nir maps"
+#: ../locale/scriptstrings/d.frame_to_translate.c:10
+msgid "Frame to be selected or created (if -c flag is given)"
msgstr ""
-#: ../imagery/i.vi/main.c:234
-msgid "ipvi index requires red and nir maps"
+#: ../locale/scriptstrings/d.frame_to_translate.c:11
+msgid ""
+"Screen coordinates in percent where to place the frame (0,0 is lower-left)"
msgstr ""
-#: ../imagery/i.vi/main.c:237
-msgid "dvi index requires red and nir maps"
+#: ../locale/scriptstrings/d.frame_to_translate.c:12
+msgid "Implies only when -c or --overwrite flag is given"
msgstr ""
-#: ../imagery/i.vi/main.c:240
-msgid "pvi index requires red and nir maps"
+msgid ""
+"Reclasses a raster map greater or less than user specified area size (in "
+"hectares)."
msgstr ""
-#: ../imagery/i.vi/main.c:243
-msgid "wdvi index requires red and nir maps"
-msgstr ""
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:3
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:3
+#: ../raster3d/r3.neighbors/main.c:212 ../raster3d/r3.in.lidar/main.c:167
+#: ../raster/r.in.xyz/main.c:162 ../raster/r.neighbors/main.c:170
+#: ../raster/r.series/main.c:138 ../raster/r.in.lidar/main.c:113
+#: ../vector/v.neighbors/main.c:54
+msgid "aggregation"
+msgstr "합산"
-#: ../imagery/i.vi/main.c:246
-msgid "savi index requires red and nir maps"
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
+msgid "Value option that sets the area size limit (in hectares)"
msgstr ""
-#: ../imagery/i.vi/main.c:251
-msgid ""
-"msavi index requires red and nir maps, and 3 parameters related to soil line"
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:7
+msgid "Lesser or greater than specified value"
msgstr ""
-#: ../imagery/i.vi/main.c:254
-msgid "msavi2 index requires red and nir maps"
-msgstr ""
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:9
+#, fuzzy
+msgid "Method used for reclassification"
+msgstr "출력할 격자지도"
-#: ../imagery/i.vi/main.c:257
-msgid "gemi index requires red and nir maps"
-msgstr ""
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:11
+#, fuzzy
+msgid "Input map is clumped"
+msgstr "출력할 격자지도"
-#: ../imagery/i.vi/main.c:261
-msgid "arvi index requires blue, red and nir maps"
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:12
+msgid "Clumps including diagonal neighbors"
msgstr ""
-#: ../imagery/i.vi/main.c:265
-msgid "evi index requires blue, red and nir maps"
-msgstr ""
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:1
+#, fuzzy
+msgid ""
+"Replaces gaps in a space time raster dataset with interpolated raster maps."
+msgstr "출력할 격자지도"
-#: ../imagery/i.vi/main.c:268
-msgid "evi2 index requires red and nir maps"
-msgstr ""
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:3
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
+#: ../raster/r.resamp.interp/main.c:78 ../raster/r.resamp.bspline/main.c:83
+#: ../raster/r.series.interp/main.c:66 ../raster/r.surf.contour/main.c:62
+#: ../raster/r.surf.idw/main.c:106 ../vector/v.surf.rst/main.c:143
+#: ../vector/v.surf.idw/main.c:89 ../vector/v.vol.rst/main.c:238
+#: ../vector/v.surf.bspline/main.c:93
+#, fuzzy
+msgid "interpolation"
+msgstr "출력할 격자지도"
-#: ../imagery/i.vi/main.c:272
-msgid "vari index requires blue, green and red maps"
-msgstr ""
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:9
+#, fuzzy
+msgid "Number of interpolation processes to run in parallel"
+msgstr "출력할 격자지도"
-#: ../imagery/i.vi/main.c:276
-msgid "gari index requires blue, green, red and nir maps"
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:10
+msgid ""
+"Assign the space time raster dataset start and end time to the output map"
msgstr ""
-#: ../imagery/i.vi/main.c:281
-msgid "gvi index requires blue, green, red, nir, chan5 and chan7 maps"
-msgstr ""
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:1
+#, fuzzy
+msgid "Converts a space time raster dataset into a 3D raster map."
+msgstr "출력할 격자지도"
-#: ../imagery/i.vi/main.c:544 ../raster/r.colors/edit_colors.c:376
-#, c-format
-msgid "Unknown color request '%s'"
-msgstr ""
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:3
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:3
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:5
+#: ../raster3d/r3.out.ascii/main.c:305 ../raster3d/r3.in.ascii/main.c:357
+#: ../raster3d/r3.to.rast/main.c:260 ../raster3d/r3.in.lidar/main.c:166
+#: ../raster/r.in.xyz/main.c:161 ../raster/r.to.vect/main.c:77
+#: ../raster/r.to.rast3/main.c:198 ../raster/r.in.ascii/main.c:71
+#: ../raster/r.in.lidar/main.c:112 ../raster/r.to.rast3elev/main.c:362
+#: ../vector/v.to.rast3/main.c:49 ../vector/v.to.rast/main.c:45
+msgid "conversion"
+msgstr "변환"
-#: ../imagery/i.maxlik/open.c:27
-#, c-format
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:1
msgid ""
-"Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
-"have at least 2 raster maps."
+"Dissolves boundaries between adjacent areas sharing a common category number "
+"or attribute."
msgstr ""
-#: ../imagery/i.maxlik/open.c:30
-#, c-format
-msgid ""
-"Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at "
-"least 2 raster maps."
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:3
+#: ../vector/v.extract/main.c:80
+msgid "dissolve"
msgstr ""
-#: ../imagery/i.maxlik/open.c:47
-#, fuzzy, c-format
-msgid "Unable to open signature file <%s>"
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
+#, fuzzy
+msgid "Layer number or name."
msgstr "출력할 격자지도"
-#: ../imagery/i.maxlik/open.c:57 ../imagery/i.cluster/open_files.c:64
-#, c-format
-msgid "<%s> has too many signatures (limit is 255)"
-msgstr ""
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:7
+#, fuzzy
+msgid "Name of attribute column used to dissolve common boundaries"
+msgstr "출력할 격자지도"
-#: ../imagery/i.maxlik/main.c:66
-msgid "Classifies the cell spectral reflectances in imagery data."
-msgstr ""
+#, fuzzy
+msgid ""
+"Aggregates temporally the maps of a space time raster dataset by a user "
+"defined granularity."
+msgstr "출력할 격자지도"
-#: ../imagery/i.maxlik/main.c:68
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:7
msgid ""
-"Classification is based on the spectral signature information generated by "
-"either i.cluster, g.gui.iclass, or i.gensig."
+"Either a numerical suffix or the start time (s-flag) separated by an "
+"underscore will be attached to create a unique identifier"
msgstr ""
-#: ../imagery/i.maxlik/main.c:82
-msgid "Generated by either i.cluster, g.gui.iclass, or i.gensig"
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:9
+msgid ""
+"Aggregation granularity, format absolute time \"x years, x months, x weeks, "
+"x days, x hours, x minutes, x seconds\" or an integer value for relative time"
msgstr ""
-#: ../imagery/i.maxlik/main.c:92
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:7
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:8
#, fuzzy
-msgid "Name for output raster map holding reject threshold results"
+msgid "Aggregate operation to be performed on the raster maps"
msgstr "출력할 격자지도"
-#: ../imagery/i.maxlik/invert.c:28
-#, c-format
-msgid "Signature %d is not valid (ill-conditioned) - ignored"
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:12
+msgid ""
+"Offset that is used to create the output map ids, output map id is generated "
+"as: basename_ (count + offset)"
msgstr ""
-#: ../imagery/i.maxlik/invert.c:31
-#, c-format
-msgid "Signature %d is not valid (singular) - ignored"
-msgstr ""
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:12
+#, fuzzy
+msgid "Number of r.series processes to run in parallel"
+msgstr "출력할 격자지도"
-#: ../imagery/i.target/main.c:48
-msgid "Targets an imagery group to a GRASS location and mapset."
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:13
+msgid "The maximum number of open files allowed for each r.series process"
msgstr ""
-#: ../imagery/i.target/main.c:57
-msgid "Name of imagery target location"
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
+msgid ""
+"Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
+"using gdalwarp."
msgstr ""
-#: ../imagery/i.target/main.c:63
-msgid "Name of target mapset"
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:5
+msgid "Terra-ASTER"
msgstr ""
-#: ../imagery/i.target/main.c:68
-msgid "Set current location and mapset as target for imagery group"
-msgstr ""
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:6
+#, fuzzy
+msgid "Name of input ASTER image"
+msgstr "출력할 격자지도"
-#: ../imagery/i.target/main.c:90 ../imagery/i.target/main.c:107
-#: ../imagery/i.target/main.c:116
-#, c-format
-msgid "Group <%s> targeted for location [%s], mapset [%s]"
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:7
+msgid "ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)"
msgstr ""
-#: ../imagery/i.target/main.c:93
-#, c-format
-msgid "Group <%s> has no target"
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:8
+msgid ""
+"List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate "
+"all bands"
msgstr ""
-#: ../imagery/i.target/main.c:101
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:9
+#, fuzzy
msgid ""
-"Use either the Current Mapset and Location Flag (-c)\n"
-" OR\n"
-" manually enter the variables"
-msgstr ""
+"Base name for output raster map (band number will be appended to base name)"
+msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:150
-msgid "imagery quality assessment"
-msgstr ""
+#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:1
+#, fuzzy
+msgid "Drops a column from selected attribute table."
+msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:152
+#: ../locale/scriptstrings/v.import_to_translate.c:1
#, fuzzy
-msgid "land surface temperature"
+msgid ""
+"Imports vector data into a GRASS vector map using OGR library and reprojects "
+"on the fly."
msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:153
+#: ../locale/scriptstrings/v.import_to_translate.c:5
+#: ../vector/v.in.ogr/main.c:144
#, fuzzy
-msgid "vegetation"
+msgid "Name of OGR datasource to be imported"
msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:155 ../imagery/i.albedo/main.c:102
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:5
-msgid "MODIS"
+#: ../locale/scriptstrings/v.import_to_translate.c:7
+#: ../vector/v.in.ogr/main.c:156
+msgid "OGR layer name. If not given, all available layers are imported"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:157
-msgid "Extracts quality control parameters from MODIS QC layers."
-msgstr ""
+#: ../locale/scriptstrings/v.import_to_translate.c:9
+#: ../vector/v.proj/main.c:105
+#, fuzzy
+msgid "Name for output vector map (default: input)"
+msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:162
+#: ../locale/scriptstrings/v.import_to_translate.c:11
#, fuzzy
-msgid "Name of input surface reflectance QC layer [bit array]"
+msgid "Output vector map extent"
msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:167
+#: ../locale/scriptstrings/v.import_to_translate.c:12
#, fuzzy
-msgid "Name for output QC type classification layer"
+msgid "input;extent of input map;region;extent of current region"
msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:173
-msgid "Name of MODIS product type"
+#: ../locale/scriptstrings/v.import_to_translate.c:15
+#: ../vector/v.in.ogr/main.c:235
+msgid "Overrides encoding interpretation, useful when importing ESRI Shapefile"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:188
-msgid "surf. refl. 250m 8-days"
+#: ../locale/scriptstrings/v.import_to_translate.c:17
+#: ../vector/v.in.ogr/main.c:211
+msgid "Snapping threshold for boundaries (map units)"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:189
-msgid "surf. refl. 500m 8-days"
+#: ../locale/scriptstrings/v.import_to_translate.c:18
+#: ../vector/v.in.ogr/main.c:212
+msgid "'-1' for no snap"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:190
-msgid "surf. refl. 500m 8-days, State QA"
-msgstr ""
+#: ../locale/scriptstrings/v.import_to_translate.c:20
+#: ../locale/scriptstrings/v.import_to_translate.c:22
+#, fuzzy
+msgid "Input SRS"
+msgstr "입력"
-#: ../imagery/i.modis.qc/main.c:191
-msgid "surf. refl. 5000m daily"
-msgstr ""
+#: ../locale/scriptstrings/v.import_to_translate.c:24
+#, fuzzy
+msgid "-1 to list available datum transform parameters"
+msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:192
-msgid "surf. refl. 5000m daily, State QA"
+#: ../locale/scriptstrings/v.import_to_translate.c:25
+#: ../vector/v.in.ogr/main.c:256
+msgid "List supported OGR formats and exit"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:193
-msgid "surf. refl. 5000m daily, Internal Climatology"
+#: ../locale/scriptstrings/v.import_to_translate.c:26
+#: ../vector/v.in.ogr/main.c:262
+msgid "List available OGR layers in data source and exit"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:194
-msgid "LST 1km daily (Day/Night)"
+msgid ""
+"Aggregates data of an existing space time raster dataset using the time "
+"intervals of a second space time dataset."
msgstr ""
-#: ../imagery/i.modis.qc/main.c:195
-msgid "LST 1km 8-days (Day/Night)"
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:6
+msgid ""
+"Time intervals from this space time dataset (raster, vector or raster3d) are "
+"used for aggregation computation"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:196
-msgid "VI 1km 16-days"
-msgstr ""
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:7
+#, fuzzy
+msgid "Type of the space time dataset from which aggregation will be copied"
+msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:197
-msgid "Brdf-Albedo Quality (Ancillary SDS) 1km 8-days"
+msgid ""
+"Detects accumulation patterns in temporally accumulated space time raster "
+"datasets created by t.rast.accumulate."
msgstr ""
-#: ../imagery/i.modis.qc/main.c:198
-msgid "Brdf-Albedo Quality (BRDF SDS) 1km 8-days"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:199
-msgid "VI 250m 16-days"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:208
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:3
+#: ../raster/r.series.accumulate/main.c:82
#, fuzzy
-msgid "Name of QC type to extract"
+msgid "accumulation"
msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:272
-msgid "mod09: Adjacency Correction"
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:6
+msgid ""
+"Input space time raster dataset that specifies the minimum values to detect "
+"the accumulation pattern"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:273
-msgid "mod09: Atmospheric Correction"
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:7
+msgid ""
+"Input space time raster dataset that specifies the maximum values to detect "
msgstr ""
-#: ../imagery/i.modis.qc/main.c:274
-msgid "mod09: Cloud State"
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:8
+msgid ""
+"The output space time raster dataset that stores the occurrence of the the "
+"accumulation pattern using the provided data range"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:275
-msgid "mod09: Band-Wise Data Quality Flag"
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:9
+msgid ""
+"The output space time raster dataset that stores the indication of the "
+"start, intermediate and end of the specified data range"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:276
-msgid "mod09: 250m Band is at Different Orbit than 500m"
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:8
+msgid "The temporal starting point to begin the accumulation, eg '2001-01-01'"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:277
-msgid "mod09: MODIS Land General Quality Assessment"
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:9
+msgid "The temporal date to stop the accumulation, eg '2009-01-01'"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:278
-msgid "mod11A1: MODIS Land General Quality Assessment"
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:12
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:10
+msgid "The temporal cycle to restart the accumulation, eg '12 months'"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:279
-msgid "mod11A1: Detailed Quality Indications"
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:13
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:11
+msgid "The temporal offset to the begin of the next cycle, eg '6 months'"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:280
-msgid "mod11A1: Average Emissivity Error Classes"
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:16
+msgid ""
+"time format, 'count' for numerical suffix with a specific number of digits "
+"(default %05)"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:281
-msgid "mod11A1: Average LST Error Classes"
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:17
+msgid ""
+"The minimum and maximum value of the occurrence of accumulated values, these "
+"values will be used if the min/max space time raster datasets are not "
+"specified"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:282
-msgid "mod11A2: Detailed Quality Indications"
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:18
+msgid ""
+"The user defined values that indicate start, intermediate and end status in "
+"the indicator output space time raster dataset"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:283
-msgid "mod11A2: Average Emissivity Error Classes"
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:19
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:21
+msgid ""
+"Register empty maps in the output space time raster dataset, otherwise they "
+"will be deleted"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:284
-msgid "mod11A2: MODIS Land General Quality Assessment"
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:20
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:22
+msgid "Reverse time direction in cyclic accumulation"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:285
-msgid "mod11A2: Average LST Error Classes"
-msgstr ""
+#: ../locale/scriptstrings/t.info_to_translate.c:1
+#, fuzzy
+msgid "Lists information about space time datasets and maps."
+msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:286
-msgid "mod09*s: StateQA Aerosol Quantity"
-msgstr ""
+#: ../locale/scriptstrings/t.info_to_translate.c:3
+#: ../locale/scriptstrings/t.select_to_translate.c:3
+#: ../locale/scriptstrings/t.support_to_translate.c:3
+#: ../temporal/t.connect/main.c:36 ../raster3d/r3.info/main.c:76
+#: ../raster3d/r3.support/main.c:50 ../raster3d/r3.timestamp/main.c:44
+#: ../raster/r.describe/main.c:55 ../raster/r.info/main.c:71
+#: ../raster/r.timestamp/main.c:36 ../raster/r.support/main.c:55
+#: ../raster/r.region/main.c:52 ../vector/v.timestamp/main.c:36
+#: ../vector/v.info/main.c:38 ../vector/v.support/main.c:40
+msgid "metadata"
+msgstr "메타자료"
-#: ../imagery/i.modis.qc/main.c:287
-msgid "mod09*s: StateQA BRDF Correction Performed"
-msgstr ""
+#: ../locale/scriptstrings/t.info_to_translate.c:4
+#: ../raster3d/r3.info/main.c:78 ../raster/r.info/main.c:72
+#: ../vector/v.info/main.c:40
+msgid "extent"
+msgstr "범위"
-#: ../imagery/i.modis.qc/main.c:288
-msgid "mod09*s: StateQA Cirrus Detected"
-msgstr ""
+#: ../locale/scriptstrings/t.info_to_translate.c:6
+#, fuzzy
+msgid "Name of an existing space time dataset or map"
+msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:289
-msgid "mod09*s: StateQA Cloud Shadow"
-msgstr ""
+#: ../locale/scriptstrings/t.info_to_translate.c:10
+#, fuzzy
+msgid ""
+"Print history information in human readable shell style for space time "
+"datasets"
+msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:290
-msgid "mod09*s: StateQA Cloud State"
+#: ../locale/scriptstrings/t.info_to_translate.c:11
+msgid "Print information about the temporal DBMI interface and exit"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:291
-msgid "mod09*s: StateQA Internal Cloud Algorithm"
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:1
+msgid ""
+"Observes specific locations in a space time raster dataset over a period of "
+"time using vector points."
msgstr ""
-#: ../imagery/i.modis.qc/main.c:292
-msgid "mod09*s: StateQA Internal Fire Algorithm"
-msgstr ""
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:6
+#, fuzzy
+msgid ""
+"Name of the new created vector map that stores the sampled values in "
+"different layers"
+msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:293
-msgid "mod09*s: StateQA Internal Snow Mask"
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:7
+msgid ""
+"Names of the vector columns to be created and to store sampled raster "
+"values, one name for each STRDS"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:294
-msgid "mod09*s: StateQA Land Water"
+#: ../locale/scriptstrings/t.select_to_translate.c:1
+msgid ""
+"Select maps from space time datasets by topological relationships to other "
+"space time datasets using temporal algebra."
msgstr ""
-#: ../imagery/i.modis.qc/main.c:295
-msgid "mod09*s: StateQA mod35 Snow Ice"
+#: ../locale/scriptstrings/t.select_to_translate.c:7
+msgid "The temporal mapcalc expression"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:296
-msgid "mod09*s: StateQA Pixel Adjacent to Cloud"
+#: ../locale/scriptstrings/t.select_to_translate.c:8
+msgid ""
+"Check the spatial topology of temporally related maps and select only "
+"spatially related maps"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:297
-msgid "mod09*i: Internal CM: Cloudy"
+#: ../locale/scriptstrings/t.select_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:13
+msgid ""
+"Perform a dry run, compute all dependencies and module calls but don't run "
+"them"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:298
-msgid "mod09*i: Internal CM: Clear"
-msgstr ""
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:1
+#, fuzzy
+msgid ""
+"Calculates univariate statistics from the non-null cells for each registered "
+"raster map of a space time raster dataset."
+msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:299
-msgid "mod09*i: Internal CM: High Clouds"
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:9
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:10
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:10
+#: ../raster/r.univar/r3.univar_main.c:63 ../raster/r.univar/r.univar_main.c:66
+#: ../vector/v.univar/main.c:130
+msgid "Calculate extended statistics"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:300
-msgid "mod09*i: Internal CM: Low Clouds"
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:10
+msgid ""
+"Ignore the current region settings and use the raster map regions for univar "
+"statistical calculation"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:301
-msgid "mod09*i: Internal CM: Snow"
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
+msgid "Exports attribute tables into various formats."
msgstr ""
-#: ../imagery/i.modis.qc/main.c:302
-msgid "mod09*i: Internal CM: Fire"
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
+msgid "GRASS table name"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:303
-msgid "mod09*i: Internal CM: Sun Glint"
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
+msgid "Output table file name or DB connection string"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:304
-msgid "mod09*i: Internal CM: Dust"
-msgstr ""
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:7
+#, fuzzy
+msgid "Table format"
+msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:305
-msgid "mod09*i: Internal CM: Cloud Shadow"
-msgstr ""
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:8
+#, fuzzy
+msgid "Name for output table (default: input name)"
+msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:306
-msgid "mod09*i: Internal CM: Pixel is Adjacent to Cloud"
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:1
+msgid "Downloads and imports data from WMS/WMTS/NASA OnEarth server."
msgstr ""
-#: ../imagery/i.modis.qc/main.c:307
-msgid "mod09*i: Internal CM: Cirrus"
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:4
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:4
+msgid "OGC web services"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:308
-msgid "mod09*i: Internal CM: Pan Flag"
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:5
+msgid "Typically starts with \"http://\""
msgstr ""
-#: ../imagery/i.modis.qc/main.c:309
-msgid "mod09*i: Internal CM: Criteria for Aerosol Retrieval"
-msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:7
+#, fuzzy
+msgid "Layer(s) to request from the map server"
+msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:310
-msgid "mod09*i: Internal CM: AOT (aerosol optical depth) has clim. val."
-msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:8
+#, fuzzy
+msgid "Layer style(s) to request from the map server"
+msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:311
-msgid "mod13A2: MODIS Land General Quality Assessment"
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:9
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:34
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:40
+msgid "Map style"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:312
-msgid "mod13A2: Quality estimation of the pixel"
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:10
+msgid "Image format requested from the server"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:313
-msgid "mod13A2: Quantity range of Aerosol"
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:11
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:13
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:18
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:20
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:22
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:24
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:31
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:38
+msgid "Request"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:314
-msgid "mod13A2: if pixel is a cloud neighbour"
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:12
+msgid "EPSG code of requested source projection"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:315
-msgid "mod13A2: if BRDF correction performed"
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:14
+msgid "Driver used to communication with server"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:316
-msgid "mod13A2: if pixel mixed with clouds"
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:15
+msgid ""
+"WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using "
+"native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS "
+"driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:317
-msgid "mod13A2: separate land from various water objects"
-msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:16
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:26
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:28
+#: ../locale/scriptstrings/db.droptable_to_translate.c:7
+#: ../locale/scriptstrings/db.droptable_to_translate.c:10
+#: ../db/db.databases/main.c:80 ../db/db.databases/main.c:91
+#: ../db/db.execute/main.c:144 ../db/db.execute/main.c:149
+#: ../db/db.execute/main.c:154 ../db/db.select/main.c:219
+#: ../db/db.select/main.c:224
+#, fuzzy
+msgid "Connection"
+msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:318
-msgid "mod13A2: if snow/ice present in pixel"
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:17
+msgid "WMS standard version"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:319
-msgid "mod13A2: if shadow is present in pixel"
-msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:19
+#, fuzzy
+msgid "Maximum columns to request at a time"
+msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:320 ../imagery/i.modis.qc/main.c:321
-#: ../imagery/i.modis.qc/main.c:322
-msgid "mcd43B2: Quality of BRDF correction performed"
-msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:21
+#, fuzzy
+msgid "Maximum rows to request at a time"
+msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:323
-msgid "mcd43B2q: Quality of BRDF correction performed"
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:23
+msgid "Additional query parameters to pass to the server"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:324
-msgid "mod13Q1: MODIS Land General Quality Assessment"
-msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:25
+#, fuzzy
+msgid "Username for server connection"
+msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:325
-msgid "mod13Q1: Quality estimation of the pixel"
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:27
+msgid "Password for server connection"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:326
-msgid "mod13Q1: Quantity range of Aerosol"
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:29
+msgid "Interpolation method to use in reprojection"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:327
-msgid "mod13Q1: if pixel is a cloud neighbour"
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:30
+msgid "Request data for this named region instead of the current region bounds"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:328
-msgid "mod13Q1: if BRDF correction performed"
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:33
+msgid "Format: 0xRRGGBB"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:329
-msgid "mod13Q1: if pixel mixed with clouds"
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:35
+msgid ""
+"Capabilities file to parse (input). It is relevant for WMTS_GRASS and "
+"OnEarth_GRASS drivers"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:330
-msgid "mod13Q1: separate land from various water objects"
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:36
+msgid "File where the server capabilities will be saved ('c' flag)"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:331
-msgid "mod13Q1: if snow/ice present in pixel"
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:37
+msgid "Get the server capabilities then exit"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:332
-msgid "mod13Q1: if shadow is present in pixel"
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:39
+msgid "Do not request transparent data"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:342
-msgid ""
-"Band number of MODIS product (mod09Q1=[1,2],mod09A1=[1-7],m[o/"
-"y]d09CMG=[1-7], mcd43B2q=[1-7])"
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:1
+msgid "Uploads vector values at positions of vector points to the table."
msgstr ""
-#: ../imagery/i.modis.qc/main.c:346
-msgid "Band 1: Red"
-msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:5
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:5
+#: ../raster/r.what/main.c:100 ../display/d.where/main.c:45
+#: ../vector/v.what.rast3/main.c:67 ../vector/v.what.rast/main.c:74
+#: ../vector/v.what/main.c:62
+#, fuzzy
+msgid "position"
+msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:347
-msgid "Band 2: NIR"
-msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:8
+#: ../vector/v.what.rast3/main.c:76 ../vector/v.what.rast/main.c:83
+#, fuzzy
+msgid "Name of vector points map for which to edit attributes"
+msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:348
-msgid "Band 3: Blue"
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:9
+#: ../locale/scriptstrings/v.db.join_to_translate.c:6
+msgid "layer,column"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:349
-msgid "Band 4: Green"
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:10
+#: ../locale/scriptstrings/v.db.join_to_translate.c:8
+msgid "column"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:350
-msgid "Band 5: SWIR 1"
-msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:11
+#: ../vector/v.what.rast3/main.c:87 ../vector/v.what.rast/main.c:98
+#, fuzzy
+msgid "Name of attribute column to be updated with the query result"
+msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:351
-msgid "Band 6: SWIR 2"
-msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:12
+#, fuzzy
+msgid "Name of vector map to be queried"
+msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:352
-msgid "Band 7: SWIR 3"
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:13
+msgid "query_layer,query_column"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:371
-msgid "This bit flag is only available for MOD09Q1 @ 250m products"
-msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:14
+#, fuzzy
+msgid "query_column"
+msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:375
-msgid "Band number out of allowed range [1-2]"
-msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:15
+#, fuzzy
+msgid "Name of attribute column to be queried"
+msgstr "출력할 격자지도"
-#: ../imagery/i.modis.qc/main.c:377 ../imagery/i.modis.qc/main.c:379
-#: ../imagery/i.modis.qc/main.c:381 ../imagery/i.modis.qc/main.c:383
-#: ../imagery/i.modis.qc/main.c:385 ../imagery/i.modis.qc/main.c:387
-#: ../imagery/i.modis.qc/main.c:442
-msgid "Band number out of allowed range [1-7]"
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:16
+msgid "Maximum query distance in map units"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:389
-msgid "mod09Q1 product only has 2 bands"
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
+#, fuzzy
+msgid "Fills no-data areas in raster maps using spline interpolation."
+msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
+#: ../raster/r.proj/main.c:182
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:127
+#: ../imagery/i.rectify/main.c:148
+msgid "Interpolation method to use"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:425
-msgid "This bit flag is only available for mod09CMGi @ 5000m products"
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:6
+msgid "Spline tension parameter"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:432
-msgid "This bit flag is only available for MOD13A2 @ 1km products"
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:7
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:9
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:11
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:13
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:15
+#, fuzzy
+msgid "RST options"
+msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:8
+msgid "Spline smoothing parameter"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:438
-msgid "This bit flag is only available for MCD43B2 @ 1km products"
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:10
+msgid "Width of hole edge used for interpolation (in cells)"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:449
-msgid "This bit flag is only available for MOD13Q1 @ 250m products"
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:12
+#: ../vector/v.surf.rst/main.c:292 ../vector/v.vol.rst/main.c:319
+msgid "Minimum number of points for approximation in a segment (>segmax)"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:763
-msgid "Unknown names and/or combination, please check spelling"
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:14
+#: ../vector/v.surf.rst/main.c:283 ../vector/v.vol.rst/main.c:310
+msgid "Maximum number of points in a segment"
msgstr ""
-#: ../imagery/i.evapo.pm/main.c:61
-msgid ""
-"Computes potential evapotranspiration calculation with hourly Penman-"
-"Monteith."
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:16
+#: ../raster/r.resamp.bspline/main.c:132 ../vector/v.surf.bspline/main.c:177
+msgid "Tykhonov regularization parameter (affects smoothing)"
msgstr ""
-#: ../imagery/i.evapo.pm/main.c:65
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:17
#, fuzzy
-msgid "Name of input elevation raster map [m a.s.l.]"
+msgid "Used in bilinear and bicubic spline interpolation"
msgstr "출력할 격자지도"
-#: ../imagery/i.evapo.pm/main.c:69
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:18
#, fuzzy
-msgid "Name of input temperature raster map [C]"
+msgid "Spline options"
msgstr "출력할 격자지도"
-#: ../imagery/i.evapo.pm/main.c:73
+#: ../locale/scriptstrings/r.rgb_to_translate.c:1
#, fuzzy
-msgid "Name of input relative humidity raster map [%]"
+msgid "Splits a raster map into red, green and blue maps."
msgstr "출력할 격자지도"
-#: ../imagery/i.evapo.pm/main.c:77
-#, fuzzy
-msgid "Name of input wind speed raster map [m/s]"
-msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/r.rgb_to_translate.c:3
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:3
+msgid "RGB"
+msgstr ""
-#: ../imagery/i.evapo.pm/main.c:82
+#: ../locale/scriptstrings/r.rgb_to_translate.c:4
#, fuzzy
-msgid "Name of input net solar radiation raster map [MJ/m2/h]"
+msgid "separate"
msgstr "출력할 격자지도"
-#: ../imagery/i.evapo.pm/main.c:86
+#: ../locale/scriptstrings/r.rgb_to_translate.c:5
+msgid "split"
+msgstr ""
+#: ../locale/scriptstrings/r.rgb_to_translate.c:6
#, fuzzy
-msgid "Name of input crop height raster map [m]"
+msgid "Red channel raster map name"
msgstr "출력할 격자지도"
-#: ../imagery/i.evapo.pm/main.c:89
+#: ../locale/scriptstrings/r.rgb_to_translate.c:7
#, fuzzy
-msgid "Name for output raster map [mm/h]"
+msgid "Green channel raster map name"
msgstr "출력할 격자지도"
-#: ../imagery/i.evapo.pm/main.c:93
+#: ../locale/scriptstrings/r.rgb_to_translate.c:8
#, fuzzy
-msgid "Set negative evapotranspiration to zero"
+msgid "Blue channel raster map name"
msgstr "출력할 격자지도"
-#: ../imagery/i.evapo.pm/main.c:97
-msgid "Use Night-time"
+#: ../locale/scriptstrings/d.out.file_to_translate.c:1
+msgid "Saves the contents of the active display monitor to a graphics file."
msgstr ""
-#: ../imagery/i.eb.netrad/main.c:58
+#: ../locale/scriptstrings/d.out.file_to_translate.c:6
#, fuzzy
-msgid "net radiation"
+msgid "Width and height of output image"
msgstr "출력할 격자지도"
-#: ../imagery/i.eb.netrad/main.c:61
-msgid "Net radiation approximation (Bastiaanssen, 1995)."
+#: ../locale/scriptstrings/d.out.file_to_translate.c:7
+msgid "Images"
msgstr ""
-#: ../imagery/i.eb.netrad/main.c:66 ../imagery/i.eb.soilheatflux/main.c:58
-#, fuzzy
-msgid "Name of albedo raster map [0.0;1.0]"
-msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/d.correlate_to_translate.c:1
+msgid "Prints a graph of the correlation between raster maps (in pairs)."
+msgstr ""
-#: ../imagery/i.eb.netrad/main.c:70 ../imagery/i.eb.soilheatflux/main.c:62
-#, fuzzy
-msgid "Name of NDVI raster map [-1.0;+1.0]"
-msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/d.correlate_to_translate.c:5
+#: ../locale/scriptstrings/d.polar_to_translate.c:3
+msgid "diagram"
+msgstr ""
-#: ../imagery/i.eb.netrad/main.c:75
+#: ../locale/scriptstrings/d.correlate_to_translate.c:6
#, fuzzy
-msgid "Name of surface temperature raster map [K]"
+msgid "correlation"
msgstr "출력할 격자지도"
-#: ../imagery/i.eb.netrad/main.c:80 ../imagery/i.eb.soilheatflux/main.c:76
+#: ../locale/scriptstrings/d.what.vect_to_translate.c:1
+msgid ""
+"Allows the user to interactively query vector map layers at user-selected "
+"locations."
+msgstr ""
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:1
+msgid "Search in GRASS modules using keywords"
+msgstr ""
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:3
+msgid "modules"
+msgstr ""
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:5
#, fuzzy
-msgid "Name of time of satellite overpass raster map [local time in UTC]"
+msgid "Keyword to be searched"
msgstr "출력할 격자지도"
-#: ../imagery/i.eb.netrad/main.c:85
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:6
msgid ""
-"Name of the difference map of temperature from surface skin to about 2 m "
-"height [K]"
+"Display only modules where all keywords are available (AND), default: OR"
msgstr ""
-#: ../imagery/i.eb.netrad/main.c:89
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:8
+msgid "Invert selection (logical NOT)"
+msgstr ""
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:10
+msgid "Search in manual pages too (can be slow)"
+msgstr ""
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:12
+msgid "Search only for the exact keyword in module keyword list"
+msgstr ""
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:13
+msgid "Instead of full text search, search only in actual keywords"
+msgstr ""
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:15
+msgid "Use colorized (more readable) output to terminal"
+msgstr ""
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:17
#, fuzzy
-msgid "Name of the emissivity map [-]"
+msgid "Shell script format"
msgstr "출력할 격자지도"
-#: ../imagery/i.eb.netrad/main.c:94
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:19
#, fuzzy
-msgid "Name of the single-way atmospheric transmissivitymap [-]"
+msgid "JSON format"
msgstr "출력할 격자지도"
-#: ../imagery/i.eb.netrad/main.c:98
+#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:1
#, fuzzy
-msgid "Name of the Day Of Year (DOY) map [-]"
+msgid ""
+"Renames a column in the attribute table connected to a given vector map."
msgstr "출력할 격자지도"
-#: ../imagery/i.eb.netrad/main.c:102
+#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:5
+msgid "Old and new name of the column (old,new)"
+msgstr ""
+#: ../locale/scriptstrings/v.build.all_to_translate.c:1
#, fuzzy
-msgid "Name of the sun zenith angle map [degrees]"
+msgid "Rebuilds topology on all vector maps in the current mapset."
msgstr "출력할 격자지도"
-#: ../imagery/i.eb.netrad/main.c:105
+#: ../locale/scriptstrings/v.build.all_to_translate.c:3
+#: ../locale/scriptstrings/t.topology_to_translate.c:3
+#: ../vector/v.build.polylines/main.c:112 ../vector/v.out.postgis/main.c:48
+#: ../vector/v.build/main.c:37 ../vector/v.clean/main.c:52
+#: ../vector/v.info/main.c:39
+msgid "topology"
+msgstr "위상"
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:1
#, fuzzy
-msgid "Name of the output net radiation layer"
+msgid ""
+"Performs a neighborhood analysis for each map in a space time raster dataset."
msgstr "출력할 격자지도"
-#: ../imagery/i.emissivity/main.c:45
-msgid "emissivity"
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:6
+#: ../raster/r.neighbors/main.c:212
+msgid "Neighborhood size"
msgstr ""
-#: ../imagery/i.emissivity/main.c:46
-msgid "land flux"
-msgstr ""
-#: ../imagery/i.emissivity/main.c:49
-msgid "Computes emissivity from NDVI, generic method for sparse land."
-msgstr ""
-#: ../imagery/i.emissivity/main.c:53
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:11
#, fuzzy
-msgid "Name of the NDVI map [-]"
+msgid "Number of r.neighbor processes to run in parallel"
msgstr "출력할 격자지도"
-#: ../imagery/i.emissivity/main.c:56
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:13
#, fuzzy
-msgid "Name of the output emissivity layer"
+msgid "Ignore the current region settings and use the raster map regions"
msgstr "출력할 격자지도"
-#: ../imagery/i.albedo/main.c:96
-msgid "albedo"
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:1
+msgid "Displays a raster map and its legend on a graphics window"
msgstr ""
-#: ../imagery/i.albedo/main.c:101
-msgid "AVHRR"
-msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:3
+#: ../display/d.graph/main.c:59 ../display/d.legend/main.c:79
+#: ../display/d.barscale/main.c:64 ../display/d.vect.thematic/main.c:86
+#: ../display/d.grid/main.c:54 ../display/d.legend.vect/main.c:51
+#: ../display/d.vect.chart/main.c:64 ../display/d.text/main.c:139
+#: ../display/d.title/main.c:50 ../display/d.northarrow/main.c:47
+#: ../display/d.linegraph/main.c:230
+msgid "cartography"
+msgstr "지도제작"
-#: ../imagery/i.albedo/main.c:103
-msgid "Computes broad band albedo from surface reflectance."
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:4
+#: ../display/d.legend/main.c:80 ../display/d.vect.thematic/main.c:88
+#: ../display/d.legend.vect/main.c:53
+msgid "legend"
msgstr ""
-#: ../imagery/i.albedo/main.c:116
-msgid "MODIS (7 input bands:1,2,3,4,5,6,7)"
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:5
+#: ../display/d.legend/main.c:277
+msgid "Flip legend"
msgstr ""
-#: ../imagery/i.albedo/main.c:120
-msgid "NOAA AVHRR (2 input bands:1,2)"
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:6
+msgid "Omit entries with missing label"
msgstr ""
-#: ../imagery/i.albedo/main.c:124
-msgid "Landsat 5+7 (6 input bands:1,2,3,4,5,7)"
-msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:7
+#, fuzzy
+msgid "Name of raster map to display"
+msgstr "출력할 격자지도"
-#: ../imagery/i.albedo/main.c:128
-msgid "Landsat 8 (7 input bands:1,2,3,4,5,6,7)"
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:8
+#: ../display/d.legend/main.c:272
+msgid "Draw smooth gradient"
msgstr ""
-#: ../imagery/i.albedo/main.c:132
-msgid "ASTER (6 input bands:1,3,5,6,8,9)"
-msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:9
+#, fuzzy
+msgid "Number of lines to appear in the legend"
+msgstr "출력할 격자지도"
-#: ../imagery/i.albedo/main.c:136
-msgid "Aggressive mode (Landsat)"
-msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:10
+#, fuzzy
+msgid "Name of input raster map to generate legend from"
+msgstr "출력할 격자지도"
-#: ../imagery/i.albedo/main.c:138 ../imagery/i.albedo/main.c:145
-msgid ""
-"Albedo dry run to calculate some water to beach/sand/desert stretching, a "
-"kind of simple atmospheric correction"
-msgstr ""
+#, fuzzy
+msgid "Drops an attribute table."
+msgstr "출력할 격자지도"
-#: ../imagery/i.albedo/main.c:143
-msgid "Soft mode (MODIS)"
-msgstr ""
-#: ../imagery/i.albedo/main.c:181
+#: ../locale/scriptstrings/db.droptable_to_translate.c:5
#, fuzzy
-msgid "At least two raster maps are required"
+msgid "Name of database driver"
msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.acca/main.c:70
-#, c-format
-msgid ""
-"Input raster map <%s> is not floating point (process DN using i.landsat.toar "
-"to radiance first)"
+#: ../locale/scriptstrings/db.droptable_to_translate.c:6
+msgid "If not given then default driver is used"
msgstr ""
-#: ../imagery/i.landsat.acca/main.c:104
-msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
-msgstr ""
+#: ../locale/scriptstrings/db.droptable_to_translate.c:8
+#, fuzzy
+msgid "Name of database"
+msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.acca/main.c:107
+#: ../locale/scriptstrings/db.droptable_to_translate.c:9
#, fuzzy
-msgid "cloud detection"
+msgid "If not given then default database is used"
msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.acca/main.c:121
-msgid "B56composite (step 6)"
-msgstr ""
+#: ../locale/scriptstrings/db.droptable_to_translate.c:11
+#, fuzzy
+msgid "Name of table to drop"
+msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.acca/main.c:128
-msgid "B45ratio: Desert detection (step 10)"
-msgstr ""
+#: ../locale/scriptstrings/t.support_to_translate.c:1
+#, fuzzy
+msgid "Modifies the metadata of a space time dataset."
+msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.acca/main.c:136
+#: ../locale/scriptstrings/t.support_to_translate.c:5
+#: ../locale/scriptstrings/t.create_to_translate.c:7
#, fuzzy
-msgid "Number of classes in the cloud temperature histogram"
+msgid "Semantic type of the space time dataset"
msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.acca/main.c:138 ../imagery/i.landsat.acca/main.c:153
-#: ../imagery/i.landsat.acca/main.c:159 ../imagery/i.landsat.acca/main.c:164
+#: ../locale/scriptstrings/t.support_to_translate.c:8
#, fuzzy
-msgid "Cloud settings"
+msgid "Title of the space time dataset"
msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.acca/main.c:142
-msgid "Data is Landsat-5 TM"
-msgstr ""
+#: ../locale/scriptstrings/t.support_to_translate.c:9
+#, fuzzy
+msgid "Description of the space time dataset"
+msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.acca/main.c:143
-msgid "I.e. Thermal band is '.6' not '.61')"
-msgstr ""
+#: ../locale/scriptstrings/t.support_to_translate.c:10
+#, fuzzy
+msgid "Aggregation type of the space time raster or 3D raster dataset"
+msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.acca/main.c:148
-msgid "Apply post-processing filter to remove small holes"
+#: ../locale/scriptstrings/t.support_to_translate.c:11
+msgid ""
+"Update the metadata information and spatial extent of registered maps from "
+"the GRASS spatial database"
msgstr ""
-#: ../imagery/i.landsat.acca/main.c:152
-msgid "Always use cloud signature (step 14)"
+#: ../locale/scriptstrings/t.support_to_translate.c:12
+msgid ""
+"Check for removed maps and delete them from the temporal database and all "
+"effected space time datasets"
msgstr ""
-#: ../imagery/i.landsat.acca/main.c:158
+#: ../locale/scriptstrings/t.support_to_translate.c:13
msgid ""
-"Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
+"Update metadata information, temporal and spatial extent from registered "
+"maps based on database entries."
msgstr ""
-#: ../imagery/i.landsat.acca/main.c:163
-msgid "Include a category for cloud shadows"
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:1
+msgid "Sets color rules based on stddev from a raster map's mean value."
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:124
-msgid "Preliminary scene analysis:"
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
+msgid "Color using standard deviation bands"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:125
-#, c-format
-msgid "* Desert index: %.2lf"
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:5
+msgid "Force center at zero"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:126
-#, c-format
-msgid "* Snow cover: %.2lf %%"
+#: ../locale/scriptstrings/g.extension.all_to_translate.c:1
+msgid "Rebuilds or removes all locally installed GRASS Addons extensions."
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:127
-#, c-format
-msgid "* Cloud cover: %.2lf %%"
+#: ../locale/scriptstrings/g.extension.all_to_translate.c:2
+msgid ""
+"By default only extensions built against different GIS Library are rebuilt."
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:128
-msgid "* Temperature of clouds:"
+#: ../locale/scriptstrings/g.extension.all_to_translate.c:4
+#: ../locale/scriptstrings/g.extension_to_translate.c:4
+msgid "installation"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:129
-#, c-format
-msgid "** Maximum: %.2lf K"
+#: ../locale/scriptstrings/g.extension.all_to_translate.c:5
+#: ../locale/scriptstrings/g.extension_to_translate.c:5
+msgid "extensions"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:130
-#, c-format
-msgid "** Mean (%s cloud): %.2lf K"
+#: ../locale/scriptstrings/g.extension.all_to_translate.c:7
+msgid "Force operation (required for removal)"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:132
-#, c-format
-msgid "** Minimum: %.2lf K"
-msgstr ""
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:1
+#, fuzzy
+msgid "Lists registered maps of a space time raster dataset."
+msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.acca/algorithm.c:142
-msgid "Histogram cloud signature:"
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:13
+msgid ""
+"The granule to be used for listing. The granule must be specified as string "
+"eg.: absolute time \"1 months\" or relative time \"1\""
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:148
-#, c-format
-msgid "* Mean temperature: %.2lf K"
+#: ../locale/scriptstrings/r.tileset_to_translate.c:1
+msgid ""
+"Produces tilings of the source projection for use in the destination region "
+"and projection."
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:149
-#, c-format
-msgid "* Standard deviation: %.2lf"
-msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:3
+#: ../raster3d/r3.retile/main.c:97 ../raster/r.tile/main.c:44
+#, fuzzy
+msgid "tiling"
+msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.acca/algorithm.c:150
-#, c-format
-msgid "* Skewness: %.2lf"
+#: ../locale/scriptstrings/r.tileset_to_translate.c:4
+msgid "Produces shell script output"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:151
-#, c-format
-msgid "* Histogram classes: %d"
+#: ../locale/scriptstrings/r.tileset_to_translate.c:5
+msgid "Produces web map server query string output"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:163
-#, c-format
-msgid "* 98.75 percentile: %.2lf K"
+#: ../locale/scriptstrings/r.tileset_to_translate.c:6
+msgid ""
+"Name of region to use instead of current region for bounds and resolution"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:164
-#, c-format
-msgid "* 97.50 percentile: %.2lf K"
-msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:7
+#, fuzzy
+msgid "Source projection"
+msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.acca/algorithm.c:165
-#, c-format
-msgid "* 83.50 percentile: %.2lf K"
+#: ../locale/scriptstrings/r.tileset_to_translate.c:8
+#: ../locale/scriptstrings/r.tileset_to_translate.c:10
+msgid "Conversion factor from units to meters in source projection"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:186
-msgid "Maximum temperature:"
+#: ../locale/scriptstrings/r.tileset_to_translate.c:9
+msgid "Destination projection, defaults to this location's projection"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:187
-#, c-format
-msgid "* Cold cloud: %.2lf K"
-msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:11
+#, fuzzy
+msgid "Maximum number of columns for a tile in the source projection"
+msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.acca/algorithm.c:188
-#, c-format
-msgid "* Warm cloud: %.2lf K"
+#: ../locale/scriptstrings/r.tileset_to_translate.c:12
+msgid "Maximum number of rows for a tile in the source projection"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:193
-msgid "Result: Scene with clouds"
+#: ../locale/scriptstrings/r.tileset_to_translate.c:13
+msgid "Number of cells tiles should overlap in each direction"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:200
-msgid "Result: Scene cloud free"
+#: ../locale/scriptstrings/r.tileset_to_translate.c:14
+msgid "Output field separator"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:237
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
#, fuzzy
-msgid "Processing first pass..."
+msgid ""
+"Creates and connects a new attribute table to a given layer of an existing "
+"vector map."
msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.acca/algorithm.c:391
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
#, fuzzy
-msgid "Removing ambiguous pixels..."
+msgid "Name of new attribute table (default: vector map name)"
msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.acca/algorithm.c:393
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:8
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:9
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:12
#, fuzzy
-msgid "Pass two processing..."
+msgid "Definition"
msgstr "출력할 격자지도"
-#: ../imagery/i.landsat.acca/tools.c:138
-msgid "Filling small holes in clouds..."
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:7
+#, fuzzy
+msgid "Layer number where to add new attribute table"
+msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:10
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:6
+msgid "Name and type of the new column(s) ('name type [,name type, ...]')"
msgstr ""
-#: ../imagery/i.eb.eta/main.c:44
-msgid "actual evapotranspiration"
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:11
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
+msgid ""
+"Types depend on database backend, but all support VARCHAR(), INT, DOUBLE "
+"PRECISION and DATE. Example: 'label varchar(250), value integer'"
msgstr ""
-#: ../imagery/i.eb.eta/main.c:47
-msgid "Actual evapotranspiration for diurnal period (Bastiaanssen, 1995)."
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:1
+msgid ""
+"Sample a space time raster dataset at specific vector point coordinates and "
+"write the output to stdout using different layouts"
msgstr ""
-#: ../imagery/i.eb.eta/main.c:52
-#, fuzzy
-msgid "Name of the diurnal net radiation map [W/m2]"
-msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:6
+msgid "Comma separated list of coordinates"
+msgstr ""
-#: ../imagery/i.eb.eta/main.c:57
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:7
#, fuzzy
-msgid "Name of the evaporative fraction map [-]"
-msgstr "출력할 격자지도"
+msgid "Name for the output file or \"-\" in case stdout should be used"
+msgstr "보고서를 보관할 출력파일의 이름"
-#: ../imagery/i.eb.eta/main.c:62
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:8
#, fuzzy
-msgid "Name of the surface skin temperature [K]"
+msgid "Sort the maps by category"
msgstr "출력할 격자지도"
-#: ../imagery/i.eb.eta/main.c:67
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:9
+msgid ""
+"The layout of the output. One point per row (row), one point per column "
+"(col), all timsteps in one row (timerow)"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:10
#, fuzzy
-msgid "Name of the output actual evapotranspiration layer [mm/d]"
+msgid "Number of r.what processes to run in parallel"
msgstr "출력할 격자지도"
-#: ../imagery/i.cluster/print5.c:15
-#, c-format
-msgid "%sclass separability matrix%s%s"
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:11
+#: ../raster/r.what/main.c:141
+msgid "Output header row"
msgstr ""
-#: ../imagery/i.cluster/print3.c:16
-#, c-format
-msgid "%sinitial means for each band%s%s"
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:12
+msgid "Use stdin as input and ignore coordinates and point option"
msgstr ""
-#: ../imagery/i.cluster/print3.c:20
-#, c-format
-msgid "class %-3d "
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:1
+msgid ""
+"Create a 3D raster map from an assemblage of many coordinates using "
+"univariate statistics"
msgstr ""
-#: ../imagery/i.cluster/open_files.c:24
-#, fuzzy, c-format
-msgid "Raster map <%s> do not exists in subgroup <%s>"
-msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:5
+#: ../raster3d/r3.in.lidar/main.c:164 ../raster/r.in.xyz/main.c:165
+#: ../raster/r.in.lidar/main.c:110 ../vector/v.lidar.correction/main.c:69
+#: ../vector/v.out.lidar/main.c:473 ../vector/v.lidar.growing/main.c:76
+#: ../vector/v.decimate/main.c:124 ../vector/v.lidar.edgedetection/main.c:73
+#: ../vector/v.surf.bspline/main.c:94 ../vector/v.outlier/main.c:74
+#: ../vector/v.in.lidar/main.c:138
+msgid "LIDAR"
+msgstr ""
-#: ../imagery/i.cluster/open_files.c:29
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:9
+#: ../raster3d/r3.in.lidar/main.c:168 ../raster/r.in.xyz/main.c:163
+#: ../raster/r.in.lidar/main.c:114
#, fuzzy
-msgid "No raster maps found"
+msgid "binning"
msgstr "출력할 격자지도"
-#: ../imagery/i.cluster/open_files.c:33
-#, fuzzy, c-format
-msgid "Subgroup <%s> doesn't have any raster maps"
-msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:10
+#: ../raster3d/r3.in.lidar/main.c:303 ../raster/r.in.xyz/main.c:327
+#: ../raster/r.in.lidar/main.c:305
+msgid "Scan data file for extent then exit"
+msgstr ""
-#: ../imagery/i.cluster/open_files.c:36
-#, c-format
-msgid "Subgroup <%s> only has 1 raster map"
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:11
+#: ../raster3d/r3.in.lidar/main.c:307 ../raster/r.in.xyz/main.c:332
+#: ../raster/r.in.lidar/main.c:310
+msgid "In scan mode, print using shell script style"
msgstr ""
-#: ../imagery/i.cluster/open_files.c:37
-msgid "Subgroup must have at least 2 raster maps"
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:12
+#: ../raster/r.in.xyz/main.c:336
+msgid "Ignore broken lines"
msgstr ""
-#: ../imagery/i.cluster/open_files.c:54
-#, fuzzy, c-format
-msgid "Unable to open seed signature file <%s>"
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:13
+#, fuzzy
+msgid "ASCII file containing input data"
msgstr "출력할 격자지도"
-#: ../imagery/i.cluster/checkpt.c:16
-#, c-format
-msgid "using seed means (%d files)%s"
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:15
+#: ../raster/r.in.xyz/main.c:179 ../raster/r.in.lidar/main.c:139
+msgid "Statistic to use for raster values"
msgstr ""
-#: ../imagery/i.cluster/checkpt.c:29
-#, c-format
-msgid "%s######## iteration %d ###########%s"
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:16
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:32
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:34
+#: ../raster/r.in.xyz/main.c:183 ../raster/r.in.xyz/main.c:314
+#: ../raster/r.in.xyz/main.c:323 ../raster/r.in.lidar/main.c:143
+#: ../raster/r.in.lidar/main.c:234 ../raster/r.in.lidar/main.c:244
+msgid "Statistic"
msgstr ""
-#: ../imagery/i.cluster/checkpt.c:31
-#, c-format
-msgid "%d classes, %.2f%% points stable%s"
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:17
+msgid "Storage type for resultant raster map"
msgstr ""
-#: ../imagery/i.cluster/checkpt.c:42
-#, c-format
-msgid "Iteration %.2d: convergence %.2f%% (%s elapsed, %s left)"
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:19
+#: ../raster/r.in.xyz/main.c:225
+msgid "Column number of x coordinates in input file (first column is 1)"
msgstr ""
-#: ../imagery/i.cluster/print4.c:16
-#, c-format
-msgid "class centroids (sum/count=mean)%s"
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:21
+#: ../raster/r.in.xyz/main.c:233
+msgid "Column number of y coordinates in input file"
msgstr ""
-#: ../imagery/i.cluster/print4.c:18
-#, c-format
-msgid "band %d"
-msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:23
+#, fuzzy
+msgid "Column number of z coordinates in input file"
+msgstr "출력할 격자지도"
-#: ../imagery/i.cluster/print1.c:12
-#, c-format
-msgid "means and standard deviations for %d band%s%s%s"
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:25
+#: ../raster/r.in.xyz/main.c:241
+msgid "Column number of data values in input file"
msgstr ""
-#: ../imagery/i.cluster/print1.c:14
-#, c-format
-msgid " means "
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:26
+msgid "If not given or set to 0, the data points' z-values are used"
msgstr ""
-#: ../imagery/i.cluster/print1.c:18
-#, c-format
-msgid " stddev "
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:28
+msgid "Filter range for value column data (min,max)"
msgstr ""
-#: ../imagery/i.cluster/main.c:79
-msgid ""
-"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm."
-msgstr ""
-#: ../imagery/i.cluster/main.c:82
-msgid ""
-"The resulting signature file is used as input for i.maxlik, to generate an "
-"unsupervised image classification."
-msgstr ""
-#: ../imagery/i.cluster/main.c:102
-msgid "Initial number of classes"
-msgstr ""
-#: ../imagery/i.cluster/main.c:111
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:29
#, fuzzy
-msgid "Name of file containing initial signatures"
+msgid "Scaling factor to apply to value column data"
msgstr "출력할 격자지도"
-#: ../imagery/i.cluster/main.c:119
-msgid "Sampling intervals (by row and col); default: ~10,000 pixels"
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:30
+#: ../raster/r.in.xyz/main.c:304 ../raster/r.in.lidar/main.c:224
+msgid "Percent of map to keep in memory"
msgstr ""
-#: ../imagery/i.cluster/main.c:135
-msgid "Percent convergence"
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:31
+#: ../raster/r.in.xyz/main.c:313 ../raster/r.in.lidar/main.c:233
+msgid "pth percentile of the values"
msgstr ""
-#: ../imagery/i.cluster/main.c:143
-msgid "Cluster separation"
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:33
+#: ../raster/r.in.xyz/main.c:322 ../raster/r.in.lidar/main.c:243
+msgid ""
+"Discard <trim> percent of the smallest and <trim> percent of the largest "
+"observations"
msgstr ""
-#: ../imagery/i.cluster/main.c:151
-msgid "Minimum number of pixels in a class"
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:35
+msgid "Number of parallel processes to launch"
msgstr ""
-#: ../imagery/i.cluster/main.c:158
#, fuzzy
-msgid "Name for output file containing final report"
+msgid ""
+"Apply temporal and spatial operations on space time raster datasets using "
+"temporal raster algebra."
msgstr "출력할 격자지도"
-#: ../imagery/i.cluster/main.c:192
-#, fuzzy, c-format
-msgid "Illegal number of initial classes (%s)"
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:6
+#, fuzzy
+msgid ""
+"r.mapcalc expression for temporal and spatial analysis of space time raster "
+"datasets"
msgstr "출력할 격자지도"
-#: ../imagery/i.cluster/main.c:203
-#, c-format
-msgid "Illegal value(s) of sample intervals (%s)"
-msgstr ""
-#: ../imagery/i.cluster/main.c:217
-#, fuzzy, c-format
-msgid "Illegal value of iterations (%s)"
+#: ../locale/scriptstrings/v.pack_to_translate.c:1
+#, fuzzy
+msgid "Exports a vector map as GRASS GIS specific archive file"
msgstr "출력할 격자지도"
-#: ../imagery/i.cluster/main.c:223
-#, fuzzy, c-format
-msgid "Illegal value of convergence (%s)"
+#: ../locale/scriptstrings/v.pack_to_translate.c:5
+#, fuzzy
+msgid "Name of vector map to pack up"
msgstr "출력할 격자지도"
-#: ../imagery/i.cluster/main.c:228
-#, fuzzy, c-format
-msgid "Illegal value of separation (%s)"
+#: ../locale/scriptstrings/t.shift_to_translate.c:1
+#, fuzzy
+msgid "Shifts temporally the maps of a space time dataset."
msgstr "출력할 격자지도"
-#: ../imagery/i.cluster/main.c:233
-#, fuzzy, c-format
-msgid "Illegal value of min_size (%s)"
-msgstr "출력할 격자지도"
-#: ../imagery/i.cluster/main.c:242
-#, fuzzy, c-format
-msgid "Unable to create report file <%s>"
-msgstr "출력할 격자지도"
-#: ../imagery/i.cluster/main.c:250
-#, c-format
-msgid "#################### CLUSTER (%s) ####################%s%s"
+#: ../locale/scriptstrings/t.shift_to_translate.c:4
+msgid "shift"
msgstr ""
-#: ../imagery/i.cluster/main.c:252
-#, fuzzy, c-format
-msgid "Location: %s%s"
-msgstr "출력할 격자지도"
-#: ../imagery/i.cluster/main.c:253
-#, c-format
-msgid "Mapset: %s%s"
+#: ../locale/scriptstrings/t.shift_to_translate.c:9
+msgid "Shift granularity"
msgstr ""
-#: ../imagery/i.cluster/main.c:254
-#, c-format
-msgid "Group: %s%s"
+#: ../locale/scriptstrings/t.shift_to_translate.c:10
+msgid ""
+"Format absolute time: \"x years, x months, x weeks, x days, x hours, x "
+"minutes, x seconds\", relative time is of type integer"
msgstr ""
-#: ../imagery/i.cluster/main.c:255
-#, c-format
-msgid "Subgroup: %s%s"
+#: ../locale/scriptstrings/g.extension_to_translate.c:1
+msgid "Maintains GRASS Addons extensions in local GRASS installation."
msgstr ""
-#: ../imagery/i.cluster/main.c:257
-#, c-format
-msgid " %s%s"
+#: ../locale/scriptstrings/g.extension_to_translate.c:2
+msgid ""
+"Downloads and installs extensions from GRASS Addons repository or other "
+"source into the local GRASS installation or removes installed extensions."
msgstr ""
-#: ../imagery/i.cluster/main.c:260
-#, fuzzy, c-format
-msgid "Result signature file: %s%s"
-msgstr "출력할 격자지도"
-#: ../imagery/i.cluster/main.c:262
-#, fuzzy, c-format
-msgid "Region%s"
-msgstr "출력할 격자지도"
-#: ../imagery/i.cluster/main.c:263
-#, c-format
-msgid " North: %12.2f East: %12.2f%s"
+#: ../locale/scriptstrings/g.extension_to_translate.c:6
+msgid "addons"
msgstr ""
-#: ../imagery/i.cluster/main.c:265
-#, c-format
-msgid " South: %12.2f West: %12.2f%s"
+#: ../locale/scriptstrings/g.extension_to_translate.c:7
+msgid "download"
msgstr ""
-#: ../imagery/i.cluster/main.c:267
-#, c-format
-msgid " Res: %12.2f Res: %12.2f%s"
-msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:8
+#, fuzzy
+msgid "Name of extension to install or remove"
+msgstr "출력할 격자지도"
-#: ../imagery/i.cluster/main.c:269
-#, c-format
-msgid " Rows: %12d Cols: %12d Cells: %d%s"
+#: ../locale/scriptstrings/g.extension_to_translate.c:9
+msgid "Name of toolbox (set of extensions) when -t flag is given"
msgstr ""
-#: ../imagery/i.cluster/main.c:271
-#, c-format
-msgid "Mask: %s%s"
+#: ../locale/scriptstrings/g.extension_to_translate.c:11
+msgid ""
+"URL or directory to get the extension from (supported only on Linux and Mac)"
msgstr ""
-#: ../imagery/i.cluster/main.c:273
-#, c-format
-msgid "Cluster parameters%s"
+#: ../locale/scriptstrings/g.extension_to_translate.c:12
+msgid ""
+"The official repository is used by default. User can specify a ZIP file, "
+"directory or a repository on common hosting services. If not identified, "
+"Subversion repository is assumed. See manual for all options."
msgstr ""
-#: ../imagery/i.cluster/main.c:274
-#, c-format
-msgid " Number of initial classes: %d"
+#: ../locale/scriptstrings/g.extension_to_translate.c:13
+msgid "Prefix where to install extension (ignored when flag -s is given)"
msgstr ""
-#: ../imagery/i.cluster/main.c:276
-#, c-format
-msgid " [from signature file %s]"
+#: ../locale/scriptstrings/g.extension_to_translate.c:14
+msgid "Set the proxy with: \"http=<value>,ftp=<value>\""
msgstr ""
-#: ../imagery/i.cluster/main.c:278
-#, c-format
-msgid " Minimum class size: %d%s"
+#: ../locale/scriptstrings/g.extension_to_translate.c:15
+msgid "List available extensions in the official GRASS GIS Addons repository"
msgstr ""
-#: ../imagery/i.cluster/main.c:279
-#, c-format
-msgid " Minimum class separation: %f%s"
+#: ../locale/scriptstrings/g.extension_to_translate.c:17
+msgid ""
+"List available extensions in the official GRASS GIS Addons repository "
+"including module description"
msgstr ""
-#: ../imagery/i.cluster/main.c:280
-#, c-format
-msgid " Percent convergence: %f%s"
+#: ../locale/scriptstrings/g.extension_to_translate.c:19
+msgid ""
+"List available extensions in the official GRASS GIS Addons repository (shell "
+"script style)"
msgstr ""
-#: ../imagery/i.cluster/main.c:281
-#, fuzzy, c-format
-msgid " Maximum number of iterations: %d%s"
-msgstr "출력할 격자지도"
-#: ../imagery/i.cluster/main.c:283
-#, c-format
-msgid " Row sampling interval: %d%s"
+#: ../locale/scriptstrings/g.extension_to_translate.c:21
+msgid "List locally installed extensions"
msgstr ""
-#: ../imagery/i.cluster/main.c:284
-#, c-format
-msgid " Col sampling interval: %d%s"
+#: ../locale/scriptstrings/g.extension_to_translate.c:23
+msgid "Install system-wide (may need system administrator rights)"
msgstr ""
-#: ../imagery/i.cluster/main.c:303
-msgid "Out of Memory. Please run again and choose a smaller sample size."
+#: ../locale/scriptstrings/g.extension_to_translate.c:24
+#: ../locale/scriptstrings/g.extension_to_translate.c:26
+#: ../locale/scriptstrings/g.extension_to_translate.c:28
+msgid "Install"
msgstr ""
-#: ../imagery/i.cluster/main.c:309
-#, c-format
-msgid "Sample size: %d points%s"
+#: ../locale/scriptstrings/g.extension_to_translate.c:25
+msgid "Download source code and exit"
msgstr ""
-#: ../imagery/i.cluster/main.c:312
-msgid ""
-"Not enough sample points. Please run again and choose a larger sample size."
+#: ../locale/scriptstrings/g.extension_to_translate.c:27
+msgid "Do not install new extension, just compile it"
msgstr ""
-#: ../imagery/i.cluster/main.c:316
-msgid ""
-"Not enough non-zero sample data points. Check your current region (and mask)."
+#: ../locale/scriptstrings/g.extension_to_translate.c:29
+msgid "Force removal when uninstalling extension (operation=remove)"
msgstr ""
-#: ../imagery/i.cluster/main.c:329
-#, c-format
-msgid "%s########## final results #############%s"
+#: ../locale/scriptstrings/g.extension_to_translate.c:31
+msgid "Operate on toolboxes instead of single modules (experimental)"
msgstr ""
-#: ../imagery/i.cluster/main.c:330
-#, c-format
-msgid "%d classes (convergence=%.1f%%)%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:341
-#, fuzzy, c-format
-msgid "Unable to create signature file <%s> for group <%s>, subsgroup <%s>"
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:1
+#, fuzzy
+msgid "Extracts a subset of a space time raster datasets."
msgstr "출력할 격자지도"
-#: ../imagery/i.cluster/main.c:346
-#, c-format
-msgid "%s%s#################### CLASSES ####################%s"
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:6
+msgid "r.mapcalc expression assigned to all extracted raster maps"
msgstr ""
-#: ../imagery/i.cluster/main.c:348
-#, c-format
-msgid "%s%d classes, %.2f%% points stable%s"
-msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:1
+#, fuzzy
+msgid "Joins a database table to a vector map table."
+msgstr "출력할 격자지도"
-#: ../imagery/i.cluster/main.c:350
-#, c-format
-msgid "%s######## CLUSTER END (%s) ########%s"
-msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:5
+#, fuzzy
+msgid "Vector map to which to join other table"
+msgstr "출력할 격자지도"
-#: ../imagery/i.cluster/main.c:354 ../misc/m.nviz.image/main.c:242
-#, fuzzy, c-format
-msgid "File <%s> created."
+#: ../locale/scriptstrings/v.db.join_to_translate.c:7
+#, fuzzy
+msgid "Layer where to join"
msgstr "출력할 격자지도"
-#: ../imagery/i.cluster/print2.c:18
-#, c-format
-msgid "%sclass means/stddev for each band%s%s"
+#: ../locale/scriptstrings/v.db.join_to_translate.c:9
+msgid "Identifier column (e.g.: cat) in the vector table to be used for join"
msgstr ""
-#: ../imagery/i.cluster/print2.c:23
-#, c-format
-msgid "class %d (%d)%s"
+#: ../locale/scriptstrings/v.db.join_to_translate.c:10
+msgid "Other table name"
msgstr ""
-#: ../imagery/i.cluster/print2.c:24
-#, c-format
-msgid " means "
+#: ../locale/scriptstrings/v.db.join_to_translate.c:11
+msgid "ocolumn,scolumns"
msgstr ""
-#: ../imagery/i.cluster/print2.c:29
-#, c-format
-msgid " stddev"
+#: ../locale/scriptstrings/v.db.join_to_translate.c:12
+msgid "Identifier column (e.g.: id) in the other table used for join"
msgstr ""
-#: ../imagery/i.cluster/print6.c:11
-#, c-format
-msgid "class distribution"
-msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:13
+#, fuzzy
+msgid "Subset of columns from the other table"
+msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:48
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:89
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:64
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:57
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:389
-msgid "orthorectify"
-msgstr ""
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
+#, fuzzy
+msgid "Removes existing attribute table of a vector map."
+msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:50
-msgid ""
-"Interactively creates or modifies entries in a camera initial exposure "
-"station file for imagery group referenced by a sub-block."
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
+msgid "Force removal (required for actual deletion of table)"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:57
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:70
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:64
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
#, fuzzy
-msgid "Name of imagery group for ortho-rectification"
+msgid "Table name (default: vector map name)"
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:62
+#: ../locale/scriptstrings/t.create_to_translate.c:1
#, fuzzy
-msgid "Initial Camera Exposure X-coordinate"
+msgid "Creates a space time dataset."
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:67
+#: ../locale/scriptstrings/t.create_to_translate.c:4
#, fuzzy
-msgid "Initial Camera Exposure Y-coordinate"
+msgid "create"
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:72
+#: ../locale/scriptstrings/t.create_to_translate.c:6
#, fuzzy
-msgid "Initial Camera Exposure Z-coordinate"
+msgid "Type of the output space time dataset"
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:77
-msgid "X-coordinate standard deviation"
+#: ../locale/scriptstrings/t.create_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:9
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:9
+msgid "Title of the new space time dataset"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:82
-msgid "Y-coordinate standard deviation"
+#: ../locale/scriptstrings/t.create_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:10
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:10
+msgid "Description of the new space time dataset"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:87
-msgid "Z-coordinate standard deviation"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:92
-msgid "Initial Camera Omega (roll) degrees"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:97
-msgid "Initial Camera Phi (pitch) degrees"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:102
-msgid "Initial Camera Kappa (yaw) degrees"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:107
-msgid "Omega (roll) standard deviation"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:112
-msgid "Phi (pitch) standard deviation"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:117
-msgid "Kappa (yaw) standard deviation"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:121
-msgid "Use initial values at run time"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:125
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:1
#, fuzzy
-msgid "Print initial values"
+msgid "Exports space time raster dataset."
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:137
-#, fuzzy, c-format
-msgid "Group [%s] not found"
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:6
+#, fuzzy
+msgid "Name of a space time raster dataset archive"
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:150
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:154
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:158
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:162
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:166
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:170
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:174
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:178
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:182
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:186
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:190
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:194
-#, fuzzy, c-format
-msgid "Option '%s' is required for new exposure info"
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:9
+#, fuzzy
+msgid "The export format of a single raster map"
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:80
-#, c-format
-msgid "No elevation available at row = %d, col = %d"
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:10
+msgid ""
+"Supported are GTiff, AAIGrid via r.out.gdal and the GRASS package format of "
+"r.pack"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/angle.c:36
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:11
+#: ../raster/r.out.gdal/main.c:198
#, fuzzy
-msgid "Calculating camera angle to local surface..."
+msgid "Data type"
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.rectify/angle.c:50
-#: ../imagery/i.ortho.photo/i.ortho.rectify/exec.c:43
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:12
#, fuzzy
-msgid "Could not open elevation raster"
+msgid "Supported only for GTiff"
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.rectify/angle.c:66
-#, c-format
-msgid "Converting units to meters, factor=%.6f"
+#: ../locale/scriptstrings/t.unregister_to_translate.c:1
+msgid ""
+"Unregisters raster, vector and raster3d maps from the temporal database or a "
+"specific space time dataset."
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:13
-#, c-format
-msgid ""
-"Control Z Point file for group [%s] in [%s] \n"
-" \n"
+#: ../locale/scriptstrings/t.unregister_to_translate.c:4
+msgid "unregister"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:16
+#: ../locale/scriptstrings/t.unregister_to_translate.c:6
+#: ../locale/scriptstrings/t.register_to_translate.c:10
#, fuzzy
-msgid "Computing equations..."
+msgid "Input file with map names, one per line"
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:22
-msgid "Poorly placed Control Points!\n"
-msgstr ""
+#: ../locale/scriptstrings/t.unregister_to_translate.c:7
+#: ../locale/scriptstrings/t.register_to_translate.c:8
+#, fuzzy
+msgid "input,maps"
+msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:23
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:28
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:52
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:58
+#: ../locale/scriptstrings/t.unregister_to_translate.c:8
#, fuzzy
-msgid "Can not generate the transformation equation.\n"
+msgid "Name(s) of existing raster, vector or raster3d map(s) to unregister"
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:24
-msgid "Run OPTION 7 of i.ortho.photo again!\n"
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:1
+msgid "Performs auto-balancing of colors for RGB images."
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:27
-msgid "No active Control Points!\n"
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:4
+#: ../imagery/i.modis.qc/main.c:154 ../imagery/i.landsat.toar/main.c:76
+#: ../imagery/i.albedo/main.c:98 ../imagery/i.aster.toar/main.c:102
+#: ../imagery/i.landsat.acca/main.c:108
+msgid "satellite"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:29
-msgid "Run OPTION 7 of i.ortho.photo!\n"
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:5
+#: ../display/d.colorlist/main.c:37
+msgid "colors"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:45
-#, c-format
-msgid ""
-"Reference Point file for group [%s] in [%s] \n"
-" \n"
-msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:6
+#, fuzzy
+msgid "Name of red channel"
+msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:51
-msgid "Poorly placed Reference Points!\n"
-msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:7
+#, fuzzy
+msgid "Name of green channel"
+msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:53
-msgid "Run OPTION 5 of i.ortho.photo again!\n"
-msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:8
+#, fuzzy
+msgid "Name of blue channel"
+msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:57
-msgid "No active Reference Points!\n"
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:9
+msgid "Cropping intensity (upper brightness level)"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:59
-msgid "Run OPTION 5 of i.ortho.photo!\n"
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:10
+msgid "Extend colors to full range of data on each channel"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:91
-msgid ""
-"Orthorectifies an image by using the image to photo coordinate "
-"transformation matrix."
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:11
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:13
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:15
+#: ../display/d.rast.arrow/main.c:119 ../display/d.rast.arrow/main.c:125
+#: ../display/d.rast.arrow/main.c:131 ../display/d.rast.arrow/main.c:137
+#: ../display/d.vect/main.c:120 ../display/d.vect/main.c:126
+#: ../display/d.vect/main.c:130 ../display/d.vect/main.c:137
+#: ../display/d.vect/main.c:308 ../display/d.rast.num/main.c:89
+#: ../display/d.rast.num/main.c:95 ../display/d.rast.num/main.c:113
+#: ../display/d.barscale/main.c:153 ../display/d.barscale/main.c:159
+#: ../display/d.northarrow/main.c:104 ../display/d.northarrow/main.c:109
+#: ../display/d.northarrow/main.c:115 ../vector/v.label.sa/main.c:103
+#: ../vector/v.label.sa/main.c:113 ../vector/v.label.sa/main.c:120
+#: ../vector/v.label.sa/main.c:130 ../vector/v.label.sa/main.c:140
+#: ../vector/v.label.sa/main.c:150 ../vector/v.label.sa/main.c:157
+#: ../vector/v.label/main.c:152 ../vector/v.label/main.c:176
+#: ../vector/v.label/main.c:189 ../vector/v.label/main.c:195
+#: ../vector/v.label/main.c:205
+msgid "Colors"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:132
-msgid "Raster map with camera angle relative to ground surface"
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:12
+msgid "Preserve relative colors, adjust brightness only"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:184
-#, fuzzy, c-format
-msgid "Could not read REF file for group <%s>"
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:14
+#, fuzzy
+msgid "Reset to standard color range"
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:241
-#, c-format
-msgid "No camera reference file selected for group <%s>"
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:16
+#: ../locale/scriptstrings/i.oif_to_translate.c:7
+msgid "Process bands serially (default: run in parallel)"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:245
-#, fuzzy, c-format
-msgid "Bad format in camera file for group <%s>"
+#: ../locale/scriptstrings/v.centroids_to_translate.c:1
+#, fuzzy
+msgid "Adds missing centroids to closed boundaries."
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:251
-#, fuzzy, c-format
-msgid "Bad format in initial exposure station file for group <%s>"
-msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:327
-#, c-format
-msgid "No target elevation model selected for group <%s>"
+#: ../locale/scriptstrings/v.centroids_to_translate.c:3
+#: ../vector/v.category/main.c:691
+msgid "centroid"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:142
-#: ../raster/r.proj/readcell.c:141
+#: ../locale/scriptstrings/v.centroids_to_translate.c:5
#, fuzzy
-msgid "Error reading segment file"
+msgid "Action to be taken"
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:66
-msgid "Select or modify the target elevation model."
+#: ../locale/scriptstrings/v.centroids_to_translate.c:6
+msgid "Category number starting value"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:75
-#, fuzzy
-msgid "Name of elevation map to use for ortho-rectification"
-msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:80
-msgid "List available raster maps in target mapset and exit"
+#: ../locale/scriptstrings/v.centroids_to_translate.c:7
+#: ../vector/v.category/main.c:134
+msgid "Category increment"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:85
#, fuzzy
-msgid "Print currently selected elevation map and exit"
+msgid "Imports space time raster dataset."
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:108
-#, c-format
-msgid "Please select a target for group [%s] first"
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:8
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:8
+msgid "Path to the extraction directory"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:114
-#, fuzzy, c-format
-msgid "Target location [%s] not found\n"
-msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:147
-#, c-format
-msgid "Elevation map name is missing. Please set '%s' option"
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:11
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:11
+msgid ""
+"Create a new location and import the data into it. Do not run this module in "
+"parallel or interrupt it when a new location should be created"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:162
-#, fuzzy, c-format
-msgid "Elevation for group <%s> is already set to <%s>"
-msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:175
-#, fuzzy, c-format
-msgid "Mapset [%s] in target location [%s] - %s "
-msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:177
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:14
#, fuzzy
-msgid "permission denied\n"
+msgid "Set the current region from the last map that was imported"
msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:15
#, fuzzy
-msgid "not found\n"
+msgid "Link the raster files using r.external"
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:59
-msgid "Select and modify the imagery group camera reference file."
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:16
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:12
+msgid "Extend location extents based on new dataset"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:71
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:19
+msgid ""
+"Create the location specified by the \"location\" parameter and exit. Do not "
+"import the space time raster datasets."
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:1
#, fuzzy
-msgid "Name of camera reference file"
+msgid ""
+"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
+"point."
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:77
-msgid "Camera name"
+#: ../locale/scriptstrings/r.plane_to_translate.c:4
+msgid "Dip of plane in degrees"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:83
-msgid "Camera id"
+#: ../locale/scriptstrings/r.plane_to_translate.c:5
+msgid "Azimuth of the plane in degrees"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:89
-msgid "Calibrated focal length"
+#: ../locale/scriptstrings/r.plane_to_translate.c:6
+msgid "Easting coordinate of a point on the plane"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:94
+#: ../locale/scriptstrings/r.plane_to_translate.c:7
+msgid "Northing coordinate of a point on the plane"
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:8
+msgid "Elevation coordinate of a point on the plane"
+msgstr ""
+#: ../locale/scriptstrings/t.topology_to_translate.c:1
#, fuzzy
-msgid "Principal point coordinates"
+msgid "Lists temporal topology of a space time dataset."
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:100
+#: ../locale/scriptstrings/t.topology_to_translate.c:7
#, fuzzy
-msgid "Fiducial coordinates"
+msgid "Print temporal topological relationships and exit"
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:129
-#, fuzzy, c-format
-msgid "Can not read camera file '%s'"
+#: ../locale/scriptstrings/t.topology_to_translate.c:8
+#, fuzzy
+msgid "Print spatio-temporal topological relationships and exit"
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:132
-#, c-format
-msgid "Replacing camera name '%s' with '%s'"
+#: ../locale/scriptstrings/i.oif_to_translate.c:1
+msgid "Calculates Optimum-Index-Factor table for spectral bands"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:138
-#, c-format
-msgid "Replacing camera cam_id '%s' with '%s'"
+#: ../locale/scriptstrings/i.oif_to_translate.c:5
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:6
+#: ../raster/r.univar/r3.univar_main.c:42 ../raster/r.univar/r.univar_main.c:41
+#: ../raster/r.stats.quantile/main.c:553 ../raster/r.what/main.c:125
+#: ../raster/r.stats/main.c:119 ../vector/v.db.select/main.c:95
+#: ../db/db.select/main.c:241
+msgid "Name for output file (if omitted or \"-\" output to stdout)"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:146
-#, c-format
-msgid "Replacing calibrated focal length '%g' with '%g'"
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:1
+#, fuzzy
+msgid "Lists registered maps of a space time vector dataset."
+msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/r.grow_to_translate.c:1
+msgid "Generates a raster map layer with contiguous areas grown by one cell."
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:153
-#, c-format
-msgid ""
-"Replacing coordinates of principal point '%.17g, %.17g' with '%.17g, %.17g'"
+#: ../locale/scriptstrings/r.grow_to_translate.c:4
+#: ../raster/r.grow.distance/main.c:152
+msgid "proximity"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:164
-msgid "Please provide a camera name for a new camera definition"
+#: ../locale/scriptstrings/r.grow_to_translate.c:5
+msgid "Radius is in map units rather than cells"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:168
-msgid "Please provide a camera ID for a new camera definition"
+#: ../locale/scriptstrings/r.grow_to_translate.c:6
+msgid "Radius of buffer in raster cells"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:172
-msgid "Please provide calibrated focal length for a new camera definition"
+#: ../locale/scriptstrings/r.grow_to_translate.c:7
+#: ../raster/r.grow.distance/main.c:174
+msgid "Metric"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:176
-msgid "Using default coordinates 0.0, 0.0 for the principal point"
+#: ../locale/scriptstrings/r.grow_to_translate.c:8
+msgid "Value to write for input cells which are non-NULL (-1 => NULL)"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:190
-msgid "Too many fiducials!"
+#: ../locale/scriptstrings/r.grow_to_translate.c:9
+msgid "Value to write for \"grown\" cells"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:212
-#, fuzzy, c-format
-msgid "No group '%s' in current mapset"
-msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
+msgid "Mosaics several images and extends colormap."
+msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:217
-#, c-format
-msgid "Group [%s] in location [%s] mapset [%s] now uses camera file [%s]"
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:4
+#: ../raster/r.patch/main.c:60
+msgid "mosaicking"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:93
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:136
-#: ../misc/m.transform/main.c:96
-#, fuzzy, c-format
-msgid "Error conducting transform (%d)"
+#: ../locale/scriptstrings/v.report_to_translate.c:1
+msgid "Reports geometry statistics for vector maps."
+msgstr ""
+#: ../locale/scriptstrings/v.report_to_translate.c:6
+#, fuzzy
+msgid "Value to calculate"
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:251
-msgid "Poorly placed image to photo control points"
+#: ../locale/scriptstrings/v.report_to_translate.c:7
+msgid "Sort the result"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:253
-msgid "Poorly placed image to target control points"
+#: ../locale/scriptstrings/v.report_to_translate.c:8
+msgid "asc;Sort in ascending order;desc;Sort in descending order"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:255
-#: ../misc/m.transform/main.c:196
-msgid "Insufficient memory"
-msgstr ""
+#: ../locale/scriptstrings/t.remove_to_translate.c:1
+#, fuzzy
+msgid "Removes space time datasets from temporal database."
+msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:257
-#: ../misc/m.transform/main.c:198
-msgid "Parameter error"
+#: ../locale/scriptstrings/t.remove_to_translate.c:7
+msgid "Type of the space time dataset, default is strds"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:259
-#: ../misc/m.transform/main.c:200
-msgid "No active control points"
+#: ../locale/scriptstrings/t.remove_to_translate.c:8
+#: ../locale/scriptstrings/t.merge_to_translate.c:6
+msgid "inputs"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:348
-#: ../raster/r.in.lidar/main.c:644 ../raster/r.profile/main.c:175
-#: ../raster/r.horizon/main.c:385 ../raster/r.out.ascii/main.c:157
-#: ../raster/r.category/main.c:173 ../raster/r.out.ppm3/main.c:133
-#: ../raster/r.recode/main.c:90 ../display/d.mon/stop.c:66
-#: ../general/g.pnmcomp/main.c:242 ../general/g.pnmcomp/main.c:259
-#: ../misc/m.nviz.script/main.c:202 ../misc/m.transform/main.c:276
-#: ../vector/v.edit/main.c:79 ../vector/v.out.ascii/main.c:125
-#: ../vector/v.net/main.c:100 ../vector/v.out.vtk/main.c:173
-#, fuzzy, c-format
-msgid "Unable to open file <%s>"
+#: ../locale/scriptstrings/t.remove_to_translate.c:10
+#, fuzzy
+msgid "Input file with dataset names, one per line"
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:367
-#: ../misc/m.transform/main.c:295
-#, fuzzy, c-format
-msgid "Invalid coordinates: [%s]"
+#: ../locale/scriptstrings/t.remove_to_translate.c:12
+#, fuzzy
+msgid ""
+"Remove all registered maps from the temporal and also from the spatial "
+"database"
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:391
-msgid "GCP"
+#: ../locale/scriptstrings/t.remove_to_translate.c:13
+msgid "Force recursive removing"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:393
-#: ../misc/m.transform/main.c:320
-msgid "Computes a coordinate transformation based on the control points."
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:406
-#: ../misc/m.transform/main.c:340
+#: ../locale/scriptstrings/d.to.rast_to_translate.c:1
#, fuzzy
-msgid "point index"
+msgid "Saves the contents of the active display monitor to a raster map."
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:407
-#: ../misc/m.transform/main.c:341
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
#, fuzzy
-msgid "source coordinates"
+msgid ""
+"Calculates univariate statistics on selected table column for a GRASS vector "
+"map."
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:408
-#: ../misc/m.transform/main.c:342
+#: ../locale/scriptstrings/d.polar_to_translate.c:1
+msgid "Draws polar diagram of angle map such as aspect or flow directions"
+msgstr ""
+#: ../locale/scriptstrings/d.polar_to_translate.c:4
#, fuzzy
-msgid "destination coordinates"
+msgid "Name of raster angle map"
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:409
-#: ../misc/m.transform/main.c:343
-msgid "forward coordinates (destination)"
+#: ../locale/scriptstrings/d.polar_to_translate.c:5
+msgid "Pixel value to be interpreted as undefined (different from NULL)"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:410
-#: ../misc/m.transform/main.c:344
+#: ../locale/scriptstrings/d.polar_to_translate.c:6
#, fuzzy
-msgid "reverse coordinates (source)"
+msgid "Name for optional EPS output file"
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:411
-#: ../misc/m.transform/main.c:345
-msgid "forward coordinates difference (destination)"
+#: ../locale/scriptstrings/d.polar_to_translate.c:7
+msgid "Plot using Xgraph"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:412
-#: ../misc/m.transform/main.c:346
-msgid "reverse coordinates difference (source)"
-msgstr ""
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:1
+#, fuzzy
+msgid "Converts a space time raster dataset into a space time vector dataset"
+msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:413
-#: ../misc/m.transform/main.c:347
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:7
+#: ../raster/r.to.vect/main.c:87 ../vector/v.mkgrid/main.c:136
#, fuzzy
-msgid "forward error (destination)"
+msgid "Output feature type"
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:414
-#: ../misc/m.transform/main.c:348
-msgid "reverse error (source)"
-msgstr ""
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:11
+#: ../raster/r.to.vect/main.c:94
+#, fuzzy
+msgid "Name of attribute column to store value"
+msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:417
-#: ../misc/m.transform/main.c:351 ../vector/v.out.ascii/args.c:55
-msgid "Output format"
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:12
+msgid ""
+"Number of r.to.vect processes to run in parallel, more than 1 process works "
+"only in conjunction with flag -t"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:421
-#: ../misc/m.transform/main.c:355
-msgid "Display summary information"
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:15
+#: ../raster/r.to.vect/main.c:100
+msgid "Smooth corners of area features"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:427
-#: ../misc/m.transform/main.c:360
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:16
+#: ../raster/r.to.vect/main.c:110
#, fuzzy
-msgid "File containing coordinates to transform (\"-\" to read from stdin)"
+msgid "Write raster values as z coordinate"
msgstr "출력할 격자지도"
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:428
-#: ../misc/m.transform/main.c:361
-msgid "Local x,y coordinates to target east,north"
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:17
+#: ../raster/r.to.vect/main.c:111
+msgid "Table is not created. Currently supported only for points."
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:432
-#: ../misc/m.transform/main.c:365
-msgid "Reverse transform of coords file or coeff. dump"
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:18
+#: ../raster/r.to.vect/main.c:117
+#, fuzzy
+msgid "Do not build vector topology"
+msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:19
+#: ../raster/r.to.vect/main.c:95
+msgid "Name must be SQL compliant"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:433
-#: ../misc/m.transform/main.c:366
-msgid "Target east,north coordinates to local x,y"
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:20
+#: ../raster/r.to.vect/main.c:105
+msgid "Use raster values as categories instead of unique sequence (CELL only)"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:437
-#: ../misc/m.transform/main.c:370
-msgid "Display transform matrix coefficients"
+#: ../locale/scriptstrings/g.manual_to_translate.c:1
+msgid "Displays the manual pages of GRASS modules."
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:452
-#, fuzzy, c-format
-msgid "Can not read reference points for group <%s>"
-msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/g.manual_to_translate.c:3
+msgid "manual"
+msgstr "사용설명서"
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:456
-#, fuzzy, c-format
-msgid "Can not read control points for group <%s>"
-msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/g.manual_to_translate.c:4
+msgid "help"
+msgstr "도움말"
-#: ../imagery/i.eb.soilheatflux/main.c:51
-msgid "soil heat flux"
+#: ../locale/scriptstrings/g.manual_to_translate.c:5
+msgid "Display index"
msgstr ""
-#: ../imagery/i.eb.soilheatflux/main.c:53
-msgid "Soil heat flux approximation (Bastiaanssen, 1995)."
+#: ../locale/scriptstrings/g.manual_to_translate.c:6
+msgid "Display topics"
msgstr ""
-#: ../imagery/i.eb.soilheatflux/main.c:67
-#, fuzzy
-msgid "Name of Surface temperature raster map [K]"
-msgstr "출력할 격자지도"
-#: ../imagery/i.eb.soilheatflux/main.c:83
-msgid "HAPEX-Sahel empirical correction (Roerink, 1995)"
+#: ../locale/scriptstrings/g.manual_to_translate.c:7
+msgid "Display as MAN text page instead of HTML page in browser"
msgstr ""
-#: ../imagery/i.topo.corr/main.c:48 ../raster/r.slope.aspect/main.c:152
-#: ../raster/r.relief/main.c:110 ../raster/r.param.scale/interface.c:56
-#, fuzzy
-msgid "terrain"
-msgstr "출력할 격자지도"
-#: ../imagery/i.topo.corr/main.c:49
-msgid "topographic correction"
+#: ../locale/scriptstrings/g.manual_to_translate.c:8
+msgid "Display online manuals instead of locally installed"
msgstr ""
-#: ../imagery/i.topo.corr/main.c:50
-msgid "Computes topographic correction of reflectance."
+#: ../locale/scriptstrings/g.manual_to_translate.c:9
+msgid ""
+"Use online manuals available at http://grass.osgeo.org website. This flag "
+"has no effect when displaying MAN text pages."
msgstr ""
-#: ../imagery/i.topo.corr/main.c:58
+#: ../locale/scriptstrings/g.manual_to_translate.c:10
#, fuzzy
-msgid "Name of reflectance raster maps to be corrected topographically"
+msgid "Manual entry to be displayed"
msgstr "출력할 격자지도"
-#: ../imagery/i.topo.corr/main.c:62
#, fuzzy
-msgid "Name (flag -i) or prefix for output raster maps"
+msgid "Registers raster, vector and raster3d maps in a space time datasets."
msgstr "출력할 격자지도"
-#: ../imagery/i.topo.corr/main.c:66
+#: ../locale/scriptstrings/t.register_to_translate.c:4
#, fuzzy
-msgid "Name of input base raster map (elevation or illumination)"
+msgid "register"
msgstr "출력할 격자지도"
-#: ../imagery/i.topo.corr/main.c:72
-msgid "Solar zenith in degrees"
+#: ../locale/scriptstrings/t.register_to_translate.c:11
+msgid "Additionally the start time and the end time can be specified per line"
msgstr ""
-#: ../imagery/i.topo.corr/main.c:78
-msgid "Solar azimuth in degrees (only if flag -i)"
+#: ../locale/scriptstrings/t.register_to_translate.c:13
+msgid "Valid start date and time of the first map"
msgstr ""
-#: ../imagery/i.topo.corr/main.c:85
-msgid "Topographic correction method"
+#: ../locale/scriptstrings/t.register_to_translate.c:14
+#: ../locale/scriptstrings/t.register_to_translate.c:17
+msgid ""
+"Format absolute time: \"yyyy-mm-dd HH:MM:SS +HHMM\", relative time is of "
+"type integer)."
msgstr ""
-#: ../imagery/i.topo.corr/main.c:90
-msgid "Output sun illumination terrain model"
+#: ../locale/scriptstrings/t.register_to_translate.c:15
+#: ../locale/scriptstrings/t.register_to_translate.c:18
+#: ../locale/scriptstrings/t.register_to_translate.c:21
+#: ../locale/scriptstrings/t.register_to_translate.c:24
+#: ../locale/scriptstrings/t.register_to_translate.c:28
+msgid "Time & Date"
msgstr ""
-#: ../imagery/i.topo.corr/main.c:94
-msgid "Scale output to input and copy color rules"
+#: ../locale/scriptstrings/t.register_to_translate.c:16
+msgid "Valid end date and time of all map"
msgstr ""
-#: ../imagery/i.topo.corr/main.c:100
-msgid "Solar azimuth is necessary to calculate illumination terrain model"
+#: ../locale/scriptstrings/t.register_to_translate.c:19
+msgid "Time stamp unit"
msgstr ""
-#: ../imagery/i.topo.corr/main.c:104
-msgid "Reflectance maps are necessary to make topographic correction"
+#: ../locale/scriptstrings/t.register_to_translate.c:20
+msgid "Unit must be set in case of relative time stamps"
msgstr ""
-#: ../imagery/i.topo.corr/main.c:158 ../raster/r.resamp.interp/main.c:102
-#, c-format
-msgid "Invalid method: %s"
+#: ../locale/scriptstrings/t.register_to_translate.c:22
+msgid "Time increment, works only in conjunction with start option"
msgstr ""
-#: ../imagery/i.topo.corr/main.c:164
-msgid "Illumination model is of CELL type"
+#: ../locale/scriptstrings/t.register_to_translate.c:23
+msgid ""
+"Time increment between maps for valid time interval creation (format "
+"absolute: NNN seconds, minutes, hours, days, weeks, months, years; format "
+"relative is integer: 5)"
msgstr ""
-#: ../imagery/i.topo.corr/main.c:167
-#, c-format
-msgid "Band %s: "
-msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:25
+#, fuzzy
+msgid "Field separator character of the input file"
+msgstr "출력할 격자지도"
-#: ../imagery/i.topo.corr/main.c:175
-#, c-format
-msgid "Reflectance of <%s> is not of DCELL type - ignored."
+#: ../locale/scriptstrings/t.register_to_translate.c:27
+msgid ""
+"Create an interval (start and end time) in case an increment and the start "
+"time are provided"
msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:110
-msgid "Computes sensible heat flux iteration SEBAL 01."
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:1
+#, fuzzy
+msgid ""
+"Calculates univariate statistics from the non-null cells for each registered "
+"3D raster map of a space time 3D raster dataset."
+msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/wxpyimgview_to_translate.c:1
+msgid "Views BMP images from the PNG driver."
msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:116
+#: ../locale/scriptstrings/wxpyimgview_to_translate.c:5
#, fuzzy
-msgid "Name of instantaneous net radiation raster map [W/m2]"
+msgid "Name of input image file"
msgstr "출력할 격자지도"
-#: ../imagery/i.eb.hsebal01/main.c:121
+#: ../locale/scriptstrings/r.unpack_to_translate.c:1
#, fuzzy
-msgid "Name of instantaneous soil heat flux raster map [W/m2]"
+msgid ""
+"Imports a raster map as GRASS GIS specific archive file (packed with r.pack)"
msgstr "출력할 격자지도"
-#: ../imagery/i.eb.hsebal01/main.c:126
+#: ../locale/scriptstrings/r.unpack_to_translate.c:6
#, fuzzy
-msgid "Name of aerodynamic resistance to heat momentum raster map [s/m]"
+msgid "Name for output raster map (default: taken from input file internals)"
msgstr "출력할 격자지도"
-#: ../imagery/i.eb.hsebal01/main.c:131
+#: ../locale/scriptstrings/t.merge_to_translate.c:1
#, fuzzy
-msgid "Name of altitude corrected surface temperature raster map [K]"
+msgid "Merges several space time datasets into a single space time dataset."
msgstr "출력할 격자지도"
-#: ../imagery/i.eb.hsebal01/main.c:140
-msgid "Value of the height independent friction velocity (u*) [m/s]"
+#: ../locale/scriptstrings/t.merge_to_translate.c:4 ../raster/r.patch/main.c:61
+msgid "merge"
msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:141 ../imagery/i.eb.hsebal01/main.c:150
-#: ../imagery/i.eb.hsebal01/main.c:157 ../imagery/i.eb.hsebal01/main.c:164
-#: ../imagery/i.eb.hsebal01/main.c:171 ../imagery/i.eb.hsebal01/main.c:178
-#: ../raster/r.sim/r.sim.sediment/main.c:226
-#: ../raster/r.sim/r.sim.sediment/main.c:234
-#: ../raster/r.sim/r.sim.sediment/main.c:243
-#: ../raster/r.sim/r.sim.sediment/main.c:261
-#: ../raster/r.sim/r.sim.water/main.c:231
-#: ../raster/r.sim/r.sim.water/main.c:239
-#: ../raster/r.sim/r.sim.water/main.c:248
-#: ../raster/r.sim/r.sim.water/main.c:266
-#: ../raster/r.sim/r.sim.water/main.c:276
-#: ../raster/r.sim/r.sim.water/main.c:284
-#: ../raster/r.sim/r.sim.water/main.c:293 ../vector/v.surf.rst/main.c:155
-#: ../vector/v.surf.rst/main.c:160 ../vector/v.surf.rst/main.c:181
-#: ../vector/v.surf.rst/main.c:253 ../vector/v.surf.rst/main.c:261
-#: ../vector/v.surf.rst/main.c:268 ../vector/v.surf.rst/main.c:276
-#: ../vector/v.surf.rst/main.c:284 ../vector/v.surf.rst/main.c:293
-#: ../vector/v.surf.rst/main.c:301 ../vector/v.surf.rst/main.c:309
-#: ../vector/v.surf.rst/main.c:318 ../vector/v.surf.rst/main.c:326
-#: ../vector/v.surf.rst/main.c:333
-msgid "Parameters"
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:1
+msgid ""
+"Performs different aggregation algorithms from r.series on all or a subset "
+"of raster maps in a space time raster dataset."
msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:149
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:4
+#: ../raster/r.series.interp/main.c:65 ../raster/r.series.accumulate/main.c:81
+#: ../raster/r.series/main.c:139
+msgid "series"
+msgstr "계열"
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:9
#, fuzzy
-msgid "Value of the actual vapour pressure (e_act) [KPa]"
+msgid ""
+"Do not assign the space time raster dataset start and end time to the output "
+"map"
msgstr "출력할 격자지도"
-#: ../imagery/i.eb.hsebal01/main.c:156
-msgid "Row value of the wet pixel"
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:10
+#: ../raster/r.series.accumulate/main.c:159 ../raster/r.series/main.c:187
+#: ../raster/r.resamp.filter/main.c:431 ../raster/r.resamp.stats/main.c:285
+msgid "Propagate NULLs"
msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:163
-msgid "Column value of the wet pixel"
+#: ../locale/scriptstrings/r.mask_to_translate.c:1
+msgid "Creates a MASK for limiting raster operation."
msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:170
-msgid "Row value of the dry pixel"
+#: ../locale/scriptstrings/r.mask_to_translate.c:3
+#: ../raster3d/r3.mask/main.c:134
+msgid "mask"
msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:177
-msgid "Column value of the dry pixel"
-msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:4
+#, fuzzy
+msgid "Name of raster map to use as mask"
+msgstr "출력할 격자지도"
-#: ../imagery/i.eb.hsebal01/main.c:182
+#: ../locale/scriptstrings/r.mask_to_translate.c:5
+#: ../locale/scriptstrings/r.mask_to_translate.c:8
+msgid "Raster"
+msgstr "격자지도"
+#: ../locale/scriptstrings/r.mask_to_translate.c:6
#, fuzzy
-msgid "Name for output sensible heat flux raster map [W/m2]"
+msgid "Raster values to use for mask"
msgstr "출력할 격자지도"
-#: ../imagery/i.eb.hsebal01/main.c:187
-msgid "Automatic wet/dry pixel (careful!)"
+#: ../locale/scriptstrings/r.mask_to_translate.c:7
+msgid "Format: 1 2 3 thru 7 *"
msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:192
-msgid "Dry/Wet pixels coordinates are in image projection, not row/col"
-msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:9
+#, fuzzy
+msgid "Name of vector map to use as mask"
+msgstr "출력할 격자지도"
-#: ../imagery/i.eb.hsebal01/main.c:210
-msgid "Automatic mode selected"
+#: ../locale/scriptstrings/r.mask_to_translate.c:10
+#: ../locale/scriptstrings/r.mask_to_translate.c:12
+#: ../locale/scriptstrings/r.mask_to_translate.c:14
+#: ../locale/scriptstrings/r.mask_to_translate.c:16
+msgid "Vector"
msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:222
-msgid "Manual wet/dry pixels in image coordinates"
+#: ../locale/scriptstrings/r.mask_to_translate.c:11
+#, fuzzy
+msgid "Layer number or name (vector)"
+msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/r.mask_to_translate.c:13
+#, fuzzy
+msgid "Category values (vector)"
+msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/r.mask_to_translate.c:15
+msgid "WHERE conditions of SQL statement without 'where' keyword (vector)"
msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:223
-#, c-format
-msgid "Wet Pixel=> x:%f y:%f"
+#: ../locale/scriptstrings/r.mask_to_translate.c:17
+#, fuzzy
+msgid "Create inverse mask"
+msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/r.mask_to_translate.c:19
+msgid "Remove existing mask (overrides other options)"
msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:224
-#, c-format
-msgid "Dry Pixel=> x:%f y:%f"
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:1
+#, fuzzy
+msgid ""
+"Calculates univariate statistics of attributes for each registered vector "
+"map of a space time vector dataset"
+msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
+msgid ""
+"Exports a raster map to a text file as x,y,z values based on cell centers."
msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:228
-msgid "Either auto-mode either wet/dry pixels coordinates should be provided!"
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
+msgid "ASCII"
msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:233
-#, fuzzy, c-format
-msgid "<%s> is an illegal name"
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
+#, fuzzy
+msgid ""
+"Adds one or more columns to the attribute table connected to a given vector "
+"map."
msgstr "출력할 격자지도"
-#: ../ps/ps.map/ps_vpoints.c:71 ../ps/ps.map/ps_vareas.c:161
-#: ../ps/ps.map/ps_vlines.c:56
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
#, fuzzy
-msgid "Cannot load data from table"
+msgid "Layer number where to add column(s)"
msgstr "출력할 격자지도"
-#: ../ps/ps.map/ps_vpoints.c:87 ../ps/ps.map/do_plt.c:169
-msgid "Cannot read symbol, using default icon"
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:1
+msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
msgstr ""
-#: ../ps/ps.map/ps_vpoints.c:160 ../ps/ps.map/ps_vpoints.c:171
-#: ../ps/ps.map/ps_vpoints.c:195 ../ps/ps.map/ps_vpoints.c:236
-#: ../ps/ps.map/ps_vpoints.c:246 ../ps/ps.map/ps_vareas.c:102
-#: ../ps/ps.map/ps_vlines.c:119
-#, c-format
-msgid "No record for category [%d]"
-msgstr ""
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
+#, fuzzy
+msgid "Input map is in Matlab format"
+msgstr "출력할 격자지도"
-#: ../ps/ps.map/ps_vpoints.c:177
-#, c-format
-msgid "Attribute is of invalid size [%.3f] for category [%d]"
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
+msgid "Create a 3D vector points map from 3 column Matlab data"
msgstr ""
-#: ../ps/ps.map/ps_vpoints.c:201 ../ps/ps.map/ps_vareas.c:108
-#: ../ps/ps.map/ps_vlines.c:125
-#, c-format
-msgid "Invalid RGB color definition in column <%s> for category [%d]"
-msgstr ""
-#: ../ps/ps.map/ps_outline.c:43
-#, fuzzy, c-format
-msgid "Outlining areas in raster map <%s in %s> ..."
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
+#, fuzzy
+msgid "Name of input file in Mapgen/Matlab format"
msgstr "출력할 격자지도"
-#: ../ps/ps.map/ps_outline.c:87 ../ps/ps.map/getgrid.c:61
-#: ../ps/ps.map/getgrid.c:85 ../ps/ps.map/getgrid.c:171
-#: ../ps/ps.map/getgrid.c:195 ../ps/ps.map/r_info.c:67
-#: ../ps/ps.map/r_header.c:65
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:7
#, fuzzy
-msgid "Unsupported color request"
+msgid "Name for output vector map (omit for display to stdout)"
msgstr "출력할 격자지도"
-#: ../ps/ps.map/ps_outline.c:89 ../ps/ps.map/getgrid.c:63
-#: ../ps/ps.map/getgrid.c:87 ../ps/ps.map/getgrid.c:173
-#: ../ps/ps.map/getgrid.c:197 ../ps/ps.map/r_info.c:69
-#: ../ps/ps.map/r_instructions.c:149 ../ps/ps.map/r_instructions.c:464
-#: ../ps/ps.map/r_header.c:67
-msgid "illegal color request"
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:1
+#: ../raster/r.buffer/main.c:69
+msgid ""
+"Creates a raster map showing buffer zones surrounding cells that contain non-"
+"NULL category values."
msgstr ""
-#: ../ps/ps.map/ps_outline.c:100 ../ps/ps.map/r_colortable.c:73
-#: ../ps/ps.map/r_colortable.c:89
-msgid "illegal width request"
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:2
+msgid "This is the low-memory alternative to the classic r.buffer module."
msgstr ""
-#: ../ps/ps.map/ps_outline.c:107
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:4
+#: ../raster/r.buffer/main.c:67 ../raster/r.circle/main.c:52
+#: ../vector/v.parallel/main.c:51 ../vector/v.buffer/main.c:222
#, fuzzy
-msgid "illegal outline sub-request"
+msgid "buffer"
msgstr "출력할 격자지도"
-#: ../ps/ps.map/ps_vareas.c:67 ../ps/ps.map/ps_vareas.c:78
-#: ../ps/ps.map/ps_vlines.c:84
-msgid "Read error in vector map"
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:5
+#: ../raster/r.buffer/main.c:94
+msgid "Ignore zero (0) data cells instead of NULL cells"
msgstr ""
-#: ../ps/ps.map/ps_fclrtbl.c:46 ../ps/ps.map/ps_clrtbl.c:35
-#, fuzzy, c-format
-msgid "Creating color table for <%s in %s>..."
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:6
+#: ../raster/r.buffer/main.c:81
+msgid "Distance zone(s)"
+msgstr ""
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:7
+#: ../raster/r.buffer/main.c:88
+msgid "Units of distance"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
+#, fuzzy
+msgid "Performs Tasseled Cap (Kauth Thomas) transformation."
msgstr "출력할 격자지도"
-#: ../ps/ps.map/ps_fclrtbl.c:51
-msgid "Range information not available (run r.support)"
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:4
+#: ../imagery/i.landsat.toar/main.c:77 ../imagery/i.albedo/main.c:99
+#: ../imagery/i.landsat.acca/main.c:109
+msgid "Landsat"
msgstr ""
-#: ../ps/ps.map/ps_fclrtbl.c:64
-msgid "A floating point colortable must contain a range of values"
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:5
+#: ../imagery/i.modis.qc/main.c:155 ../imagery/i.albedo/main.c:102
+msgid "MODIS"
msgstr ""
-#: ../ps/ps.map/ps_fclrtbl.c:69 ../ps/ps.map/ps_clrtbl.c:44
-msgid "Unable to read colors for colorbar"
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:6
+#, fuzzy
+msgid "Tasseled Cap transformation"
+msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:7
+msgid ""
+"For Landsat4-7: bands 1, 2, 3, 4, 5, 7; for Landsat8: bands 2, 3, 4, 5, 6, "
+"7; for MODIS: bands 1, 2, 3, 4, 5, 6, 7"
msgstr ""
-#: ../ps/ps.map/ps_fclrtbl.c:97 ../ps/ps.map/ps_fclrtbl.c:102
-#: ../ps/ps.map/ps_clrtbl.c:69
-msgid "Colorbar y location beyond page margins. Adjusting."
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:8
+#: ../imagery/i.pca/main.c:85
+#, fuzzy
+msgid "Name for output basename raster map(s)"
+msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:9
+msgid "Satellite sensor"
msgstr ""
-#: ../ps/ps.map/ps_fclrtbl.c:108 ../ps/ps.map/ps_fclrtbl.c:113
-#: ../ps/ps.map/ps_clrtbl.c:75
-msgid "Colorbar x location beyond page margins. Adjusting."
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:10
+msgid ""
+"landsat4_tm;Use transformation rules for Landsat 4 TM;landsat5_tm;Use "
+"transformation rules for Landsat 5 TM;landsat7_etm;Use transformation rules "
+"for Landsat 7 ETM;landsat8_oli;Use transformation rules for Landsat 8 OLI;"
+"modis;Use transformation rules for MODIS"
msgstr ""
-#: ../ps/ps.map/do_labels.c:44
-#, c-format
-msgid "Can't open label file <%s> in mapset <%s>"
+#: ../locale/scriptstrings/v.db.droprow_to_translate.c:1
+msgid "Removes a vector feature from a vector map through attribute selection."
msgstr ""
-#: ../ps/ps.map/do_labels.c:48
-#, c-format
-msgid "Reading labels file <%s in %s> ..."
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:1
+msgid ""
+"Image fusion algorithms to sharpen multispectral with high-res panchromatic "
+"channels"
msgstr ""
-#: ../ps/ps.map/do_labels.c:66
-#, c-format
-msgid "Can't open temporary label file <%s>"
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:3
+msgid "fusion"
msgstr ""
-#: ../ps/ps.map/do_labels.c:69
-msgid "Reading text file ..."
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:4
+msgid "sharpen"
msgstr ""
-#: ../ps/ps.map/do_labels.c:162
-msgid "Text labels: 'fontsize' given so ignoring 'size'"
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:5
+msgid "Brovey"
msgstr ""
-#: ../ps/ps.map/do_scalebar.c:192
-msgid "meters"
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:6
+msgid "IHS"
msgstr ""
-#: ../ps/ps.map/do_scalebar.c:194
-msgid "kilometers"
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:7
+msgid "HIS"
msgstr ""
-#: ../ps/ps.map/do_scalebar.c:196
-msgid "feet"
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:8
+#: ../imagery/i.pca/main.c:74
+msgid "PCA"
msgstr ""
-#: ../ps/ps.map/do_scalebar.c:198
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:9
#, fuzzy
-msgid "miles"
+msgid "Name of raster map to be used for <red>"
msgstr "출력할 격자지도"
-#: ../ps/ps.map/do_scalebar.c:200
-msgid "nautical miles"
-msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:10
+#, fuzzy
+msgid "Name of raster map to be used for <green>"
+msgstr "출력할 격자지도"
-#: ../ps/ps.map/r_plt.c:173
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:11
#, fuzzy
-msgid "Can't open eps file"
+msgid "Name of raster map to be used for <blue>"
msgstr "출력할 격자지도"
-#: ../ps/ps.map/map_setup.c:82
-#, fuzzy, c-format
-msgid "Scale set to %s"
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:12
+#, fuzzy
+msgid "Name of raster map to be used for high resolution panchromatic channel"
msgstr "출력할 격자지도"
-#: ../ps/ps.map/do_masking.c:23
-msgid "Can't open temporary PostScript mask file."
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:13
+#, fuzzy
+msgid "Method for pan sharpening"
+msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:14
+msgid "Serial processing rather than parallel processing"
msgstr ""
-#: ../ps/ps.map/do_plt.c:38
-msgid "Reading point/line file ..."
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:15
+msgid "Rebalance blue channel for LANDSAT"
msgstr ""
-#: ../ps/ps.map/getgrid.c:95 ../ps/ps.map/getgrid.c:206
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
#, fuzzy
-msgid "illegal numbers request"
+msgid "Imports geonames.org country files into a vector points map."
msgstr "출력할 격자지도"
-#: ../ps/ps.map/getgrid.c:126 ../ps/ps.map/getgrid.c:234
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
+msgid "gazetteer"
+msgstr ""
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:5
#, fuzzy
-msgid "illegal grid width request"
+msgid "Name of uncompressed geonames file (with .txt extension)"
msgstr "출력할 격자지도"
-#: ../ps/ps.map/getgrid.c:132
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:1
#, fuzzy
-msgid "illegal request (grid)"
+msgid ""
+"Uploads space time raster dataset values at positions of vector points to "
+"the table."
msgstr "출력할 격자지도"
-#: ../ps/ps.map/getgrid.c:240
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:9
#, fuzzy
-msgid "illegal request (geogrid)"
+msgid "Update attribute table of input vector map"
msgstr "출력할 격자지도"
-#: ../ps/ps.map/r_info.c:48 ../ps/ps.map/r_vlegend.c:49
-#: ../ps/ps.map/r_colortable.c:65
-msgid "illegal where request"
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:10
+msgid ""
+"Instead of creating a new vector map update the attribute table with value(s)"
msgstr ""
-#: ../ps/ps.map/r_info.c:81
-msgid "illegal bgcolor request"
-msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
+#, fuzzy
+msgid "Edits cell values in a raster map."
+msgstr "출력할 격자지도"
-#: ../ps/ps.map/r_info.c:93 ../ps/ps.map/r_vlegend.c:86
-msgid "illegal border color request"
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:3
+#: ../vector/v.edit/main.c:56 ../vector/v.type/main.c:40
+msgid "editing"
msgstr ""
-#: ../ps/ps.map/r_info.c:103
-msgid "illegal mapinfo sub-request"
-msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
+#: ../raster/r.flow/main.c:434
+#, fuzzy
+msgid "Name of input aspect raster map"
+msgstr "출력할 격자지도"
-#: ../ps/ps.map/ps_clrtbl.c:39 ../display/d.histogram/main.c:174
-#, c-format
-msgid "Category file for <%s> not available"
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:6
+msgid "Width of display canvas"
msgstr ""
-#: ../ps/ps.map/ps_clrtbl.c:54
-msgid ""
-"Your cats/ file is invalid. A cats/ file with categories and labels is "
-"required for 'colortable' when using categorical legends; see the r.category "
-"help page. Colortable creation has been skipped."
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:7
+msgid "Height of display canvas"
msgstr ""
-#: ../ps/ps.map/r_vlegend.c:97
-msgid "illegal vlegend sub-request"
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
+msgid "Minimum size of each cell"
msgstr ""
-#: ../ps/ps.map/r_instructions.c:62
-msgid "Data exist after final 'end' instruction!"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:80
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:9
#, fuzzy
-msgid "no file specified"
+msgid "Maximum number of rows to load"
msgstr "출력할 격자지도"
-#: ../ps/ps.map/r_instructions.c:84
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:10
#, fuzzy
-msgid "unable to open"
+msgid "Maximum number of columns to load"
msgstr "출력할 격자지도"
-#: ../ps/ps.map/r_instructions.c:115
-#, fuzzy
-msgid "illegal maploc request"
-msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:1
+msgid "Imports ASCII x,y[,z] coordinates as a series of lines."
+msgstr ""
-#: ../ps/ps.map/r_instructions.c:129 ../ps/ps.map/main.c:220
-msgid "illegal copies request"
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:6
+msgid "Create a 3D line from 3 column data"
msgstr ""
-#: ../ps/ps.map/r_instructions.c:144 ../ps/ps.map/r_instructions.c:340
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:7
#, fuzzy
-msgid "no raster map selected yet"
+msgid "Name of input file (or \"-\" to read from stdin)"
msgstr "출력할 격자지도"
-#: ../ps/ps.map/r_instructions.c:160
+#: ../locale/scriptstrings/r.shade_to_translate.c:10
#, fuzzy
-msgid "illegal value list"
+msgid "Name of shaded raster map"
msgstr "출력할 격자지도"
-#: ../ps/ps.map/r_instructions.c:196
-msgid "scalebar is not appropriate for this projection"
+#: ../locale/scriptstrings/r.shade_to_translate.c:12 ../raster/r.his/main.c:121
+msgid "Color to use instead of NULL values"
msgstr ""
-#: ../ps/ps.map/r_instructions.c:204
-msgid "Bad scalebar length"
+#: ../locale/scriptstrings/r.shade_to_translate.c:13
+msgid "Either a standard color name, R:G:B triplet, or \"none\""
msgstr ""
-#: ../ps/ps.map/r_instructions.c:220
+#: ../locale/scriptstrings/r.shade_to_translate.c:14 ../raster/r.his/main.c:126
#, fuzzy
-msgid "illegal text request"
+msgid "Use colors from color tables for NULL values"
msgstr "출력할 격자지도"
-#: ../ps/ps.map/r_instructions.c:234
+#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
#, fuzzy
-msgid "illegal point request"
+msgid ""
+"Drops a column from the attribute table connected to a given vector map."
msgstr "출력할 격자지도"
-#: ../ps/ps.map/r_instructions.c:248
+#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
#, fuzzy
-msgid "illegal eps request"
+msgid "Name of attribute column(s) to drop"
msgstr "출력할 격자지도"
-#: ../ps/ps.map/r_instructions.c:265
-#, fuzzy
-msgid "illegal line request"
-msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/m.proj_to_translate.c:1
+msgid "Converts coordinates from one projection to another (cs2cs frontend)."
+msgstr ""
-#: ../ps/ps.map/r_instructions.c:282
+#: ../locale/scriptstrings/m.proj_to_translate.c:5
#, fuzzy
-msgid "illegal rectangle request"
+msgid "Input coordinates to reproject"
msgstr "출력할 격자지도"
-#: ../ps/ps.map/r_instructions.c:293
+#: ../locale/scriptstrings/m.proj_to_translate.c:6
+#: ../locale/scriptstrings/m.proj_to_translate.c:9
+#: ../locale/scriptstrings/m.proj_to_translate.c:13
#, fuzzy
-msgid "illegal comments request"
+msgid "Input coordinates"
msgstr "출력할 격자지도"
-#: ../ps/ps.map/r_instructions.c:309
+#: ../locale/scriptstrings/m.proj_to_translate.c:7
#, fuzzy
-msgid "illegal scale request"
+msgid "Name of input coordinate file"
msgstr "출력할 격자지도"
-#: ../ps/ps.map/r_instructions.c:369
+#: ../locale/scriptstrings/m.proj_to_translate.c:10
#, fuzzy
-msgid "group not found"
+msgid "Name for output coordinate file (omit to send to stdout)"
msgstr "출력할 격자지도"
-#: ../ps/ps.map/r_instructions.c:411
-msgid "illegal grid spacing"
+#: ../locale/scriptstrings/m.proj_to_translate.c:12
+msgid "Field separator (format: input[,output])"
msgstr ""
-#: ../ps/ps.map/r_instructions.c:422
-msgid "geogrid is not available for this projection"
+#: ../locale/scriptstrings/m.proj_to_translate.c:14
+msgid "Input projection parameters (PROJ.4 style)"
msgstr ""
-#: ../ps/ps.map/r_instructions.c:432
-msgid "illegal geo-grid spacing"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:469
+#: ../locale/scriptstrings/m.proj_to_translate.c:15
+#: ../locale/scriptstrings/m.proj_to_translate.c:17
+#: ../locale/scriptstrings/m.proj_to_translate.c:19
+#: ../locale/scriptstrings/m.proj_to_translate.c:21
#, fuzzy
-msgid "illegal request"
+msgid "Projections"
msgstr "출력할 격자지도"
-#: ../ps/ps.map/catval.c:48 ../ps/ps.map/catval.c:110
-#: ../ps/ps.map/catval.c:176 ../vector/v.label.sa/labels.c:75
-#: ../vector/v.class/main.c:111 ../vector/v.label/main.c:274
-#: ../vector/v.vol.rst/user1.c:95
-msgid "Unable to get layer info for vector map"
+#: ../locale/scriptstrings/m.proj_to_translate.c:16
+msgid "Output projection parameters (PROJ.4 style)"
msgstr ""
-#: ../ps/ps.map/catval.c:63
-msgid "Column type not supported (must be string)"
+#: ../locale/scriptstrings/m.proj_to_translate.c:18
+msgid "Use LL WGS84 as input and current location as output projection"
msgstr ""
-#: ../ps/ps.map/catval.c:66 ../ps/ps.map/catval.c:131
-#: ../ps/ps.map/catval.c:198 ../vector/v.out.lidar/main.c:132
-#: ../vector/v.out.lidar/main.c:167 ../vector/v.class/main.c:132
-#: ../vector/v.to.rast3/main.c:95 ../vector/v.surf.idw/read_sites.c:68
-#: ../vector/v.normal/main.c:134 ../vector/v.surf.bspline/main.c:392
-#: ../vector/v.sample/main.c:152 ../vector/v.vol.rst/user1.c:112
-#: ../vector/v.univar/main.c:366
-#, fuzzy
-msgid "Unable to select data from table"
-msgstr "출력할 격자지도"
-#: ../ps/ps.map/catval.c:128
-msgid "Size column type must be numeric"
+#: ../locale/scriptstrings/m.proj_to_translate.c:20
+msgid "Use current location as input and LL WGS84 as output projection"
msgstr ""
-#: ../ps/ps.map/catval.c:195
-msgid "Rotation column type must be numeric"
+#: ../locale/scriptstrings/m.proj_to_translate.c:22
+msgid ""
+"Output long/lat in decimal degrees, or other projections with many decimal "
+"places"
msgstr ""
-#: ../ps/ps.map/do_vectors.c:33
-#, fuzzy, c-format
-msgid "Reading vector map <%s in %s> ..."
-msgstr "출력할 격자지도"
-#: ../ps/ps.map/do_vectors.c:136
-#, c-format
-msgid "Reading vector points file <%s in %s> ..."
+#: ../locale/scriptstrings/m.proj_to_translate.c:24
+msgid "Include input coordinates in output file"
msgstr ""
-#: ../ps/ps.map/do_psfiles.c:20
-#, c-format
-msgid "Reading PostScript include file <%s> ..."
+#: ../locale/scriptstrings/m.proj_to_translate.c:26
+msgid "Include column names in output file"
msgstr ""
-#: ../ps/ps.map/main.c:93
-msgid "postscript"
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
+#, fuzzy
+msgid "Imports GetFeature from a WFS server."
+msgstr "출력할 격자지도"
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:5
+msgid "Base URL starting with 'http' and ending in '?'"
msgstr ""
-#: ../ps/ps.map/main.c:94
-msgid "printing"
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:6
+msgid "Comma separated names of data layers to download"
msgstr ""
-#: ../ps/ps.map/main.c:95
-msgid "Produces hardcopy PostScript map output."
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:7
+msgid "Specify alternate spatial reference system (example: EPSG:4326)"
msgstr ""
-#: ../ps/ps.map/main.c:99
-msgid "Rotate plot 90 degrees"
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:8
+msgid ""
+"The given code must be supported by the server, consult the capabilities file"
msgstr ""
-#: ../ps/ps.map/main.c:100 ../ps/ps.map/main.c:113 ../ps/ps.map/main.c:135
-#: ../raster/r.kappa/main.c:90 ../raster/r.kappa/main.c:98
-#: ../raster/r.univar/r.univar_main.c:42
-#: ../locale/scriptstrings/v.unpack_to_translate.c:8
-#: ../locale/scriptstrings/v.unpack_to_translate.c:11
-#: ../locale/scriptstrings/r.unpack_to_translate.c:7
-#: ../locale/scriptstrings/r.unpack_to_translate.c:10
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:9
#, fuzzy
-msgid "Output settings"
+msgid "Maximum number of features to download"
msgstr "출력할 격자지도"
-#: ../ps/ps.map/main.c:105
-msgid "List paper formats (name width height left right top bottom(margin))"
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:10
+msgid "(default: unlimited)"
msgstr ""
-#: ../ps/ps.map/main.c:107 ../ps/ps.map/main.c:120
-msgid "Utility"
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:11
+msgid "Skip earlier feature IDs and start downloading at this one"
msgstr ""
-#: ../ps/ps.map/main.c:112
-msgid "Create EPS (Encapsulated PostScript) instead of PostScript file"
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:12
+msgid "(default: start with the first feature)"
msgstr ""
-#: ../ps/ps.map/main.c:118
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:13
msgid ""
-"Describe map-box's position on the page and exit (inches from top-left of "
-"paper)"
+"Download server capabilities to 'wms_capabilities.xml' in the current "
+"directory and exit"
msgstr ""
-#: ../ps/ps.map/main.c:123
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:14
+msgid "Restrict fetch to features which touch the current region"
+msgstr ""
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:1
#, fuzzy
-msgid "File containing mapping instructions"
+msgid "Imports E00 file into a vector map."
msgstr "출력할 격자지도"
-#: ../ps/ps.map/main.c:124
-msgid "Use '-' to enter instructions from keyboard)"
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:4
+msgid "E00"
msgstr ""
-#: ../ps/ps.map/main.c:127
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:5
#, fuzzy
-msgid "Name for PostScript output file"
+msgid "Name of input E00 file"
msgstr "출력할 격자지도"
-#: ../ps/ps.map/main.c:133
-msgid "Number of copies to print"
-msgstr ""
-#: ../ps/ps.map/main.c:205
-#, fuzzy, c-format
-msgid "Unable to open file '%s': %s"
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:1
+#, fuzzy
+msgid "Computes cyclic accumulations of a space time raster dataset."
msgstr "출력할 격자지도"
-#: ../ps/ps.map/main.c:213 ../ps/ps.map/main.c:232
-#: ../vector/v.to.db/parse.c:141 ../vector/v.to.db/parse.c:144
-#: ../vector/v.univar/main.c:147
-#, c-format
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:6
msgid ""
-"Required parameter <%s> not set:\n"
-"\t(%s)"
+"Input space time raster dataset that defines the lower threshold, values "
+"lower this threshold are excluded from accumulation"
msgstr ""
-#: ../ps/ps.map/main.c:273
-#, c-format
-msgid "PostScript file '%s' successfully written."
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:7
+msgid ""
+"Input space time raster dataset that defines the upper threshold, values "
+"upper this threshold are excluded from accumulation"
msgstr ""
-#: ../ps/ps.map/scale.c:136
-msgid "PSmap: do_scale(): shouldn't happen"
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:12
+msgid "The granularity for accumulation '1 day'"
msgstr ""
-#: ../ps/ps.map/eps.c:18
-#, fuzzy, c-format
-msgid "Can't open eps file <%s>"
-msgstr "출력할 격자지도"
-#: ../ps/ps.map/eps.c:37
-#, fuzzy, c-format
-msgid "Bounding box in eps file <%s> was not found"
-msgstr "출력할 격자지도"
-#: ../ps/ps.map/makeprocs.c:29
-#, c-format
-msgid "Unable to open prolog <%s>"
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:16
+msgid ""
+"Use these limits in case lower and/or upper input space time raster "
+"datasets are not defined or contain NULL values"
msgstr ""
-#: ../ps/ps.map/r_group.c:29
-msgid "Can't get group information"
-msgstr ""
-#: ../ps/ps.map/ps_raster.c:42
-msgid "Can't create temporary PostScript mask file."
-msgstr ""
-#: ../ps/ps.map/ps_raster.c:102 ../raster/r.grow.distance/main.c:276
-#: ../raster/r.series.accumulate/main.c:248
-#: ../raster/r.series.accumulate/main.c:273
-#: ../raster/r.series.accumulate/main.c:284
-#: ../raster/r.series.accumulate/main.c:292
-#: ../raster/r.series.accumulate/main.c:300 ../raster/r.out.mpeg/main.c:286
-#: ../raster/r.surf.idw/main.c:713
-#, fuzzy, c-format
-msgid "Reading raster map <%s>..."
-msgstr "출력할 격자지도"
-#: ../ps/ps.map/ps_raster.c:105
-#, fuzzy, c-format
-msgid "Reading raster maps in group <%s>..."
-msgstr "출력할 격자지도"
-#: ../ps/ps.map/r_colortable.c:81
-msgid "illegal height request"
-msgstr ""
-#: ../ps/ps.map/r_colortable.c:106
-msgid "illegal range request"
-msgstr ""
-#: ../ps/ps.map/r_colortable.c:122
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:17
#, fuzzy
-msgid "illegal columns request"
+msgid "Scale factor for input space time raster dataset"
msgstr "출력할 격자지도"
-#: ../ps/ps.map/r_colortable.c:141
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:18
#, fuzzy
-msgid "Unsupported color request (colortable)"
+msgid "Shift factor for input space time raster dataset"
msgstr "출력할 격자지도"
-#: ../ps/ps.map/r_colortable.c:143
-msgid "illegal color request (colortable)"
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:19
+msgid ""
+"This method will be applied to compute the accumulative values from the "
+"input maps in a single granule"
msgstr ""
-#: ../ps/ps.map/r_colortable.c:170
-#, fuzzy
-msgid "illegal colortable sub-request"
-msgstr "출력할 격자지도"
-#: ../ps/ps.map/r_colortable.c:181
-#, fuzzy
-msgid "No raster selected for colortable!"
-msgstr "출력할 격자지도"
-#: ../ps/ps.map/do_geogrid.c:86 ../ps/ps.map/do_geogrid.c:91
-#: ../ps/ps.map/do_geogrid.c:115 ../ps/ps.map/do_geogrid.c:120
-#: ../ps/ps.map/do_geogrid.c:189 ../ps/ps.map/do_geogrid.c:230
-#: ../ps/ps.map/do_geogrid.c:306 ../ps/ps.map/do_geogrid.c:322
-#: ../ps/ps.map/do_geogrid.c:339 ../ps/ps.map/do_geogrid.c:356
-#: ../ps/ps.map/do_geogrid.c:412 ../ps/ps.map/do_geogrid.c:418
-#: ../ps/ps.map/do_geogrid.c:422 ../ps/ps.map/do_geogrid.c:430
-#: ../ps/ps.map/do_geogrid.c:434 ../raster/r.horizon/main.c:846
-#: ../raster/r.horizon/main.c:864 ../raster/r.latlong/main.c:133
-#: ../display/d.grid/plot.c:287 ../display/d.grid/plot.c:293
-#: ../display/d.grid/plot.c:334 ../display/d.grid/plot.c:340
-#: ../display/d.grid/plot.c:427 ../display/d.grid/plot.c:433
-#: ../display/d.grid/plot.c:485 ../display/d.grid/plot.c:491
-#: ../display/d.grid/plot.c:635 ../display/d.grid/plot.c:651
-#: ../display/d.grid/plot.c:668 ../display/d.grid/plot.c:685
-msgid "Error in pj_do_proj"
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:20
+msgid ""
+"Growing Degree Days or Winkler indices; Mean: sum(input maps)/(number of "
+"input maps); Biologically Effective Degree Days; Huglin Heliothermal index"
msgstr ""
-#: ../ps/ps.map/do_geogrid.c:272 ../raster/r.sun/main.c:753
-#: ../raster/r.horizon/main.c:538 ../display/d.where/main.c:113
-#: ../display/d.grid/plot.c:554 ../general/g.region/printwindow.c:247
-#: ../general/g.region/printwindow.c:503 ../general/g.region/printwindow.c:622
-msgid "Can't get projection key values of current location"
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:1
+msgid ""
+"Stores raster map values at spatial and temporal positions of vector points "
+"as vector attributes."
msgstr ""
-#: ../ps/ps.map/do_geogrid.c:278 ../raster/r.sun/main.c:763
-#: ../raster/r.horizon/main.c:548 ../raster/r.latlong/main.c:114
-#: ../display/d.where/main.c:120 ../display/d.where/main.c:146
-#: ../display/d.grid/plot.c:561 ../display/d.grid/plot.c:588
-msgid "Unable to set up lat/long projection parameters"
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:6
+msgid ""
+"Name of the vector column to be created and to store sampled raster values"
msgstr ""
-#: ../ps/ps.map/read_cfg.c:64
-#, c-format
-msgid "Paper '%s' not found, using defaults"
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:7
+msgid ""
+"The use of a column name forces t.vect.what.rast to sample only values from "
+"the first map found in an interval. Otherwise the raster map names are used "
+"as column names"
msgstr ""
-#: ../ps/ps.map/r_header.c:77
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:1
#, fuzzy
-msgid "illegal header sub-request"
+msgid "Extracts a subset of a space time vector dataset."
msgstr "출력할 격자지도"
-#: ../db/db.connect/main.c:43 ../db/db.databases/main.c:95
-#: ../db/db.copy/main.c:35 ../db/db.execute/main.c:125
-#: ../db/db.login/main.c:40 ../db/db.select/main.c:265
-#: ../db/db.columns/main.c:99 ../db/db.dropdb/main.c:71
-#: ../db/db.drivers/main.c:71 ../db/db.describe/main.c:129
-#: ../db/db.createdb/main.c:71 ../db/db.tables/main.c:97
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:2
-#: ../locale/scriptstrings/db.test_to_translate.c:2
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
-#: ../locale/scriptstrings/v.db.update_to_translate.c:4
-#: ../locale/scriptstrings/db.univar_to_translate.c:2
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:4
-#: ../locale/scriptstrings/db.droptable_to_translate.c:2
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:4
-#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:2
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:2
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:4
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:4
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:4
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:5
-#: ../locale/scriptstrings/v.db.join_to_translate.c:4
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:4
-#: ../locale/scriptstrings/v.db.droprow_to_translate.c:4
-#: ../vector/v.db.connect/main.c:54 ../vector/v.vect.stats/main.c:126
-#: ../vector/v.distance/main.c:92 ../vector/v.in.db/main.c:54
-#: ../vector/v.to.db/main.c:38 ../vector/v.db.select/main.c:56
-msgid "database"
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:9
+msgid ""
+"The number of v.extract processes to run in parallel. Use only if database "
+"backend is used which supports concurrent writing"
msgstr ""
-#: ../db/db.connect/main.c:44 ../db/db.databases/main.c:96
-#: ../db/db.copy/main.c:36 ../db/db.execute/main.c:126
-#: ../db/db.select/main.c:266 ../db/db.columns/main.c:100
-#: ../db/db.dropdb/main.c:72 ../db/db.describe/main.c:130
-#: ../db/db.createdb/main.c:72 ../db/db.tables/main.c:98
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:4
-#: ../locale/scriptstrings/db.test_to_translate.c:3
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
-#: ../locale/scriptstrings/v.db.update_to_translate.c:3
-#: ../locale/scriptstrings/db.univar_to_translate.c:4
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:4
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:3
-#: ../locale/scriptstrings/db.droptable_to_translate.c:3
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:3
-#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:3
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:4
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:3
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:7
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:3
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:7
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:3
-#: ../locale/scriptstrings/v.db.join_to_translate.c:3
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:3
-#: ../locale/scriptstrings/v.db.droprow_to_translate.c:3
-#: ../vector/v.what.rast3/main.c:69 ../vector/v.class/main.c:47
-#: ../vector/v.db.connect/main.c:53 ../vector/v.vect.stats/main.c:125
-#: ../vector/v.distance/main.c:93 ../vector/v.what.rast/main.c:76
-#: ../vector/v.to.db/main.c:37 ../vector/v.db.select/main.c:55
-#: ../vector/v.univar/main.c:95
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:10
#, fuzzy
-msgid "attribute table"
+msgid "Register empty maps"
msgstr "출력할 격자지도"
-#: ../db/db.connect/main.c:45 ../db/db.login/main.c:41
-#: ../db/db.drivers/main.c:72
+#: ../locale/scriptstrings/d.what.rast_to_translate.c:1
+msgid ""
+"Allows the user to interactively query raster map layers at user-selected "
+"locations."
+msgstr ""
#, fuzzy
-msgid "connection settings"
+msgid ""
+"Imports a space time vector dataset from a GRASS GIS specific archive file."
msgstr "출력할 격자지도"
-#: ../db/db.connect/main.c:47
-msgid "Prints/sets general DB connection for current mapset."
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:15
+msgid ""
+"import the space time vector datasets."
msgstr ""
-#: ../db/db.connect/main.c:51 ../temporal/t.connect/main.c:42
-msgid "Print current connection parameters and exit"
+#: ../temporal/t.connect/main.c:38
+msgid ""
+"Prints/sets general temporal GIS database connection for current mapset."
msgstr ""
-#: ../db/db.connect/main.c:52
-msgid "Substitute variables in database settings"
+#: ../temporal/t.connect/main.c:42 ../db/db.connect/main.c:51
+msgid "Print current connection parameters and exit"
msgstr ""
-#: ../db/db.connect/main.c:57
-#, fuzzy
-msgid "Print current connection parameters using shell style and exit"
-msgstr "출력할 격자지도"
-#: ../db/db.connect/main.c:63 ../temporal/t.connect/main.c:48
+#: ../temporal/t.connect/main.c:48 ../db/db.connect/main.c:63
msgid "Check connection parameters, set if uninitialized, and exit"
msgstr ""
-#: ../db/db.connect/main.c:64 ../db/db.connect/main.c:70
-#: ../db/db.connect/main.c:75 ../db/db.connect/main.c:79
-#: ../db/db.connect/main.c:83 ../db/db.connect/main.c:93
-#: ../temporal/t.connect/main.c:49 ../temporal/t.connect/main.c:55
-#: ../temporal/t.connect/main.c:60 ../temporal/t.connect/main.c:65
-#: ../temporal/t.connect/main.c:69 ../general/g.gisenv/main.c:66
-#: ../general/g.gisenv/main.c:74 ../general/g.gisenv/main.c:84
-msgid "Set"
-msgstr ""
-#: ../db/db.connect/main.c:68 ../temporal/t.connect/main.c:53
+#: ../temporal/t.connect/main.c:53 ../db/db.connect/main.c:68
msgid "Set from default settings and exit"
msgstr ""
-#: ../db/db.connect/main.c:69
+#: ../temporal/t.connect/main.c:54
#, fuzzy
-msgid "Overwrite current settings if already initialized"
+msgid "Overwrite current settings if initialized"
msgstr "출력할 격자지도"
-#: ../db/db.connect/main.c:91
-msgid "Default group of database users to which select privilege is granted"
-msgstr ""
+#: ../temporal/t.connect/main.c:59
+#, fuzzy
+msgid "Print current connection parameter in shell style and exit"
+msgstr "출력할 격자지도"
-#: ../db/db.connect/main.c:141 ../db/db.tables/main.c:41
-msgid "Database connection not defined. Run db.connect."
+#: ../temporal/t.connect/main.c:83 ../temporal/t.connect/main.c:95
+msgid "Temporal GIS database connection not defined. Run t.connect."
msgstr ""
-#: ../db/db.connect/main.c:161 ../db/db.connect/main.c:188
-#: ../temporal/t.connect/main.c:133
+#: ../temporal/t.connect/main.c:111
#, c-format
msgid ""
-"Default driver / database set to:\n"
+"Default TGIS driver / database set to:\n"
"driver: %s\n"
"database: %s"
msgstr ""
-#: ../db/db.connect/main.c:166
-msgid "DB settings already defined, nothing to do"
+#: ../temporal/t.connect/main.c:118
+msgid "Default TGIS driver is not set"
msgstr ""
-#: ../db/db.connect/main.c:172
-msgid "Default driver is not set"
+#: ../temporal/t.connect/main.c:121
+msgid "Default TGIS database is not set"
msgstr ""
-#: ../db/db.connect/main.c:175
-msgid "Default database is not set"
+#: ../temporal/t.connect/main.c:133 ../db/db.connect/main.c:161
+#: ../db/db.connect/main.c:188
+#, c-format
+msgid ""
+"Default driver / database set to:\n"
+"driver: %s\n"
+"database: %s"
msgstr ""
-#: ../db/db.databases/main.c:48 ../db/db.execute/main.c:70
-#: ../db/db.select/main.c:75 ../db/db.columns/main.c:51
-#: ../db/db.dropdb/main.c:42 ../db/db.describe/main.c:56
-#: ../db/db.createdb/main.c:42 ../db/db.tables/main.c:45
-#: ../doc/vector/v.example/main.c:126 ../raster/r.stream.extract/close.c:172
-#: ../display/d.vect.thematic/main.c:294 ../display/d.vect/opt.c:147
-#: ../vector/v.db.connect/main.c:217 ../vector/v.db.connect/main.c:283
-#: ../vector/v.out.svg/main.c:152 ../vector/v.edit/select.c:509
-#: ../vector/v.out.vtk/writeVTK.c:644
-#, fuzzy, c-format
-msgid "Unable to start driver <%s>"
-msgstr "출력할 격자지도"
-#: ../db/db.databases/main.c:53
+#: ../raster3d/r3.mkdspf/main.c:83
msgid ""
-"Unable to list databases. Try to define correct connection settings by db."
-"login."
+"Creates a display file from an existing 3D raster map according to specified "
+"threshold levels."
msgstr ""
-#: ../db/db.databases/main.c:63
+#: ../raster3d/r3.mkdspf/main.c:91
#, fuzzy
-msgid "No databases found"
+msgid "Name of an existing 3D raster map"
msgstr "출력할 격자지도"
-#: ../db/db.databases/main.c:80 ../db/db.databases/main.c:91
-#: ../db/db.execute/main.c:144 ../db/db.execute/main.c:149
-#: ../db/db.execute/main.c:154 ../db/db.select/main.c:219
-#: ../db/db.select/main.c:224
-#: ../locale/scriptstrings/db.droptable_to_translate.c:7
-#: ../locale/scriptstrings/db.droptable_to_translate.c:10
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:16
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:26
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:28
+#: ../raster3d/r3.mkdspf/main.c:96
#, fuzzy
-msgid "Connection"
+msgid "Name for output display file"
msgstr "출력할 격자지도"
-#: ../db/db.databases/main.c:87
-#, fuzzy
-msgid "Location"
-msgstr "출력할 격자지도"
-#: ../db/db.databases/main.c:88
-msgid "Path for SQLite driver, or connection string for PostgreSQL driver"
+#: ../raster3d/r3.mkdspf/main.c:103
+msgid "List of thresholds for isosurfaces"
msgstr ""
-#: ../db/db.databases/main.c:97 ../db/db.copy/main.c:37
-#: ../db/db.execute/main.c:127 ../db/db.execute/main.c:134
-#: ../db/db.execute/main.c:140 ../db/db.select/main.c:267
-#: ../db/db.dropdb/main.c:73 ../db/db.createdb/main.c:73
-#: ../vector/v.db.select/main.c:57
-msgid "SQL"
+#: ../raster3d/r3.mkdspf/main.c:109
+msgid "Minimum isosurface level"
msgstr ""
-#: ../db/db.databases/main.c:99
-msgid "Lists all databases for a given driver and location."
+#: ../raster3d/r3.mkdspf/main.c:115
+msgid "Maximum isosurface level"
msgstr ""
-#: ../db/db.copy/main.c:38
-#, fuzzy
-msgid "Copy a table."
-msgstr "출력할 격자지도"
-#: ../db/db.copy/main.c:40
-msgid ""
-"Either 'from_table' (optionally with 'where') can be used or 'select' "
-"option, but not 'from_table' and 'select' at the same time."
+#: ../raster3d/r3.mkdspf/main.c:121
+msgid "Positive increment between isosurface levels"
msgstr ""
-#: ../db/db.copy/main.c:46
-msgid "Input driver name"
+#: ../raster3d/r3.mkdspf/main.c:128
+msgid "Number of isosurface threshold levels"
msgstr ""
-#: ../db/db.copy/main.c:52
-msgid "Input database name"
+#: ../raster3d/r3.mkdspf/main.c:132
+msgid "Suppress progress report & min/max information"
msgstr ""
-#: ../db/db.copy/main.c:59
-msgid "Input table name (only, if 'select' is not used)"
+#: ../raster3d/r3.mkdspf/main.c:136
+msgid "Use flat shading rather than gradient"
msgstr ""
-#: ../db/db.copy/main.c:65
-msgid "Output driver name"
+#: ../raster3d/r3.mkdspf/main.c:144
+#, c-format
+msgid "Region from getWindow: %d %d %d"
msgstr ""
-#: ../db/db.copy/main.c:71
-msgid "Output database name"
+#: ../raster3d/r3.mkdspf/main.c:156
+#, c-format
+msgid "Not able to find grid3 file for [%s]"
msgstr ""
-#: ../db/db.copy/main.c:78
-msgid "Output table name"
-msgstr ""
-#: ../db/db.copy/main.c:87
-msgid "Full select statement (only, if 'from_table' and 'where' is not used)"
-msgstr ""
-#: ../db/db.copy/main.c:88
-msgid "E.g.: SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
-msgstr ""
-#: ../db/db.copy/main.c:96
-msgid "Cannot combine 'from_table' and 'select' options"
-msgstr ""
-#: ../db/db.copy/main.c:100 ../db/db.select/main.c:53
-#: ../db/db.columns/main.c:44 ../db/db.describe/main.c:50
+#: ../raster3d/r3.mkdspf/main.c:168 ../raster3d/r3.gradient/main.c:113
+#: ../raster3d/r3.gradient/main.c:122 ../raster3d/r3.out.v5d/main.c:312
+#: ../raster3d/r3.out.bin/main.c:314 ../raster3d/r3.neighbors/main.c:266
+#: ../raster3d/r3.neighbors/main.c:275 ../raster3d/r3.out.ascii/main.c:339
+#: ../raster3d/r3.info/main.c:110 ../raster3d/r3.null/main.c:110
+#: ../raster3d/r3.cross.rast/main.c:279 ../raster3d/r3.stats/main.c:103
+#: ../raster3d/r3.out.netcdf/main.c:617 ../raster3d/r3.flow/test_main.c:82
+#: ../raster3d/r3.flow/main.c:118 ../raster3d/r3.flow/main.c:132
+#: ../raster3d/r3.flow/main.c:373 ../raster3d/r3.flow/main.c:385
+#: ../raster3d/r3.mask/main.c:64 ../raster3d/r3.to.rast/main.c:298
+#: ../raster3d/r3.to.rast/main.c:322 ../raster3d/r3.retile/main.c:127
+#: ../raster3d/r3.out.vtk/main.c:207 ../raster3d/r3.out.vtk/main.c:292
+#: ../raster3d/r3.out.vtk/main.c:513 ../raster/r.univar/r3.univar_main.c:151
+#: ../raster/r.univar/r3.univar_main.c:189
#, fuzzy, c-format
-msgid "Table <%s> not found in database <%s> using driver <%s>"
+msgid "Unable to open 3D raster map <%s>"
msgstr "출력할 격자지도"
-#: ../db/db.copy/main.c:122
-msgid "Either 'from_table' or 'select' option must be given."
-msgstr ""
-#: ../db/db.copy/main.c:125
-msgid "Cannot combine 'select' and 'where' options"
-msgstr ""
-#: ../db/db.copy/main.c:135
-msgid "Copy table failed"
-msgstr ""
-#: ../db/db.execute/main.c:57 ../db/db.select/main.c:63
+#: ../raster3d/r3.mkdspf/main.c:171 ../raster3d/r3.info/main.c:328
+#: ../raster3d/r3.info/main.c:448
#, fuzzy, c-format
-msgid "Unable to open file <%s>: %s"
+msgid "Unable to read range of 3D raster map <%s>"
msgstr "출력할 격자지도"
-#: ../db/db.execute/main.c:76 ../db/db.select/main.c:81
-#: ../db/db.columns/main.c:56 ../db/db.describe/main.c:61
-#: ../db/db.tables/main.c:50 ../display/d.vect.thematic/main.c:299
-#: ../display/d.vect/opt.c:152
+#: ../raster3d/r3.mkdspf/main.c:200
#, fuzzy, c-format
-msgid "Unable to open database <%s>"
+msgid "Unable to open display file <%s>"
msgstr "출력할 격자지도"
-#: ../db/db.execute/main.c:94 ../db/db.execute/main.c:99
+#: ../raster3d/r3.mkdspf/main.c:221
#, c-format
-msgid "Error while executing: '%s'"
+msgid "Writing %s from %s..."
msgstr ""
-#: ../db/db.execute/main.c:128
-msgid "Executes any SQL statement."
+#: ../raster3d/r3.gwflow/main.c:54
+msgid "Input 3D raster map with initial piezometric heads in [m]"
msgstr ""
-#: ../db/db.execute/main.c:129
-msgid "For SELECT statements use 'db.select'."
+#: ../raster3d/r3.gwflow/main.c:60
+msgid ""
+"Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - "
+"active, 2 - dirichlet"
msgstr ""
-#: ../db/db.execute/main.c:132
-#, fuzzy
-msgid "SQL statement"
-msgstr "출력할 격자지도"
-#: ../db/db.execute/main.c:133
-msgid "Example: update rybniky set kapri = 'hodne' where kapri = 'malo'"
+#: ../raster3d/r3.gwflow/main.c:65
+msgid ""
+"Input 3D raster map with the x-part of the hydraulic conductivity tensor in "
+"[m/s]"
msgstr ""
-#: ../db/db.execute/main.c:138
-#, fuzzy
-msgid "Name of file containing SQL statement(s)"
-msgstr "출력할 격자지도"
-#: ../db/db.execute/main.c:160
-msgid "Ignore SQL errors and continue"
+#: ../raster3d/r3.gwflow/main.c:70
+msgid ""
+"Input 3D raster map with the y-part of the hydraulic conductivity tensor in "
+"[m/s]"
msgstr ""
-#: ../db/db.execute/main.c:161 ../vector/v.build/main.c:51
-#: ../vector/v.build/main.c:77
-msgid "Errors"
+#: ../raster3d/r3.gwflow/main.c:75
+msgid ""
+"Input 3D raster map with the z-part of the hydraulic conductivity tensor in "
+"[m/s]"
msgstr ""
-#: ../db/db.execute/main.c:167
-#, c-format
-msgid "You must provide <%s> or <%s> option"
-msgstr ""
+#: ../raster3d/r3.gwflow/main.c:80
+#, fuzzy
+msgid "Input 3D raster map with sources and sinks in [m^3/s]"
+msgstr "출력할 격자지도"
-#: ../db/db.login/main.c:42
-msgid "Sets user/password for DB driver/database."
-msgstr ""
+#: ../raster3d/r3.gwflow/main.c:84
+#, fuzzy
+msgid "Specific yield [1/m] input 3D raster map"
+msgstr "출력할 격자지도"
-#: ../db/db.login/main.c:59
+#: ../raster3d/r3.gwflow/main.c:89
#, fuzzy
-msgid "Username"
-msgstr "이름변경"
+msgid "Recharge input 3D raster map in m^3/s"
+msgstr "출력할 격자지도"
-#: ../db/db.login/main.c:67
-msgid "Password"
-msgstr ""
-#: ../db/db.login/main.c:75
+#: ../raster3d/r3.gwflow/main.c:93
#, fuzzy
-msgid "Hostname"
-msgstr "글꼴이름"
+msgid ""
+"Output 3D raster map storing the piezometric head result of the numerical "
+"calculation"
+msgstr "출력할 격자지도"
-#: ../db/db.login/main.c:76 ../db/db.login/main.c:85
-msgid "Relevant only for pg and mysql driver"
-msgstr ""
-#: ../db/db.login/main.c:84
-msgid "Port"
-msgstr ""
-#: ../db/db.login/main.c:90
+#: ../raster3d/r3.gwflow/main.c:99
#, fuzzy
-msgid "Print connection settings and exit"
+msgid ""
+"Output 3D raster map storing the groundwater filter velocity vector part in "
+"x direction [m/s]"
msgstr "출력할 격자지도"
-#: ../db/db.login/main.c:105
+#: ../raster3d/r3.gwflow/main.c:105
#, fuzzy
-msgid "Unable to set user/password"
+msgid ""
+"y direction [m/s]"
msgstr "출력할 격자지도"
-#: ../db/db.login/main.c:109
-#, c-format
-msgid "The password was stored in file (%s%cdblogin)"
-msgstr ""
-#: ../db/db.select/main.c:105
-#, c-format
-msgid "Test %s."
-msgstr ""
-msgid "succeeded"
-msgstr ""
-#: ../db/db.select/main.c:142 ../raster/r.what/main.c:170
-#: ../raster/r.stats.quantile/main.c:319 ../raster/r.stats/main.c:227
-#: ../raster/r.univar/r.univar_main.c:129
-#: ../raster/r.univar/r3.univar_main.c:128
-#: ../raster/r.regression.multi/main.c:169
-#: ../raster/r.regression.line/main.c:77 ../vector/v.db.select/main.c:126
-#, fuzzy, c-format
-msgid "Unable to open file <%s> for writing"
+#: ../raster3d/r3.gwflow/main.c:111
+#, fuzzy
+msgid ""
+"z direction [m/s]"
msgstr "출력할 격자지도"
-#: ../db/db.select/main.c:203 ../db/db.select/main.c:209
-#: ../db/db.select/main.c:213 ../db/db.select/main.c:251
-#: ../db/db.select/main.c:261 ../raster/r.what/main.c:110
-#: ../raster/r.what/main.c:116 ../vector/v.to.db/parse.c:104
-#: ../vector/v.to.db/parse.c:112
-msgid "Query"
-msgstr ""
-#: ../db/db.select/main.c:207
+#: ../raster3d/r3.gwflow/main.c:117
#, fuzzy
-msgid "Name of file containing SQL select statement(s)"
+msgid ""
+"Output 3D raster map storing the groundwater budget for each cell [m^3/s]"
msgstr "출력할 격자지도"
-#: ../db/db.select/main.c:212
+#: ../raster3d/r3.gwflow/main.c:127
#, fuzzy
-msgid "Name of table to query"
+msgid "Use 3D raster mask (if exists)"
msgstr "출력할 격자지도"
-#: ../db/db.select/main.c:227 ../db/db.select/main.c:233
-#: ../db/db.select/main.c:236 ../db/db.select/main.c:246
-#: ../db/db.select/main.c:256 ../general/g.gisenv/main.c:93
-#: ../general/g.gisenv/main.c:98 ../vector/v.db.select/main.c:85
-#: ../vector/v.db.select/main.c:88 ../vector/v.db.select/main.c:106
-#: ../vector/v.db.select/main.c:111
-msgid "Format"
+#: ../raster3d/r3.gwflow/main.c:131 ../raster/r.solute.transport/main.c:192
+msgid ""
+"Use a full filled quadratic linear equation system, default is a sparse "
+"linear equation system."
msgstr ""
-#: ../db/db.select/main.c:231
-msgid "Vertical record separator (requires -v flag)"
-msgstr ""
+#: ../raster3d/r3.gwflow/main.c:160 ../raster/r.gwflow/main.c:209
+msgid "groundwater flow"
+msgstr "지하수흐름"
-#: ../db/db.select/main.c:241 ../raster/r.what/main.c:125
-#: ../raster/r.stats.quantile/main.c:553 ../raster/r.stats/main.c:119
-#: ../raster/r.univar/r.univar_main.c:41
-#: ../raster/r.univar/r3.univar_main.c:42
-#: ../locale/scriptstrings/i.oif_to_translate.c:5
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:6
-#: ../vector/v.db.select/main.c:95
-msgid "Name for output file (if omitted or \"-\" output to stdout)"
-msgstr ""
+#: ../raster3d/r3.gwflow/main.c:162 ../raster3d/r3.flow/main.c:180
+#: ../raster/r.uslek/main.c:54 ../raster/r.flow/main.c:422
+#: ../raster/r.topidx/main.c:40 ../raster/r.drain/main.c:110
+#: ../raster/r.lake/main.c:151 ../raster/r.sim/r.sim.sediment/main.c:114
+#: ../raster/r.sim/r.sim.water/main.c:114 ../raster/r.fill.dir/main.c:87
+#: ../raster/r.stream.extract/main.c:77 ../raster/r.basins.fill/main.c:55
+#: ../raster/r.solute.transport/main.c:230 ../raster/r.carve/main.c:75
+#: ../raster/r.gwflow/main.c:210 ../raster/r.topmodel/main.c:52
+#: ../raster/r.water.outlet/main.c:58 ../raster/r.watershed/front/main.c:74
+#: ../raster/r.usler/main.c:53
+msgid "hydrology"
+msgstr "수문학"
-#: ../db/db.select/main.c:245 ../vector/v.db.select/main.c:105
-msgid "Do not include column names in output"
+#: ../raster3d/r3.gwflow/main.c:163
+msgid ""
+"Numerical calculation program for transient, confined groundwater flow in "
+"three dimensions."
msgstr ""
-#: ../db/db.select/main.c:250
-msgid "Describe query only (don't run it)"
+#: ../raster3d/r3.gwflow/main.c:180
+msgid ""
+"The cholesky solver does not work with sparse matrices.\n"
+"Consider to choose a full filled quadratic matrix with flag -f "
msgstr ""
-#: ../db/db.select/main.c:255 ../vector/v.db.select/main.c:110
-msgid "Vertical output (instead of horizontal)"
+#: ../raster3d/r3.gwflow/main.c:279 ../raster/r.gwflow/main.c:546
+msgid "Unable to create and solve the linear equation system"
msgstr ""
-#: ../db/db.select/main.c:260
-msgid "Only test query, do not execute"
-msgstr ""
+#: ../raster3d/r3.gwflow/main.c:365 ../raster3d/r3.in.lidar/main.c:484
+#: ../raster3d/r3.in.lidar/main.c:493 ../raster3d/r3.in.lidar/main.c:501
+#: ../raster3d/r3.in.lidar/main.c:509 ../raster3d/r3.in.lidar/main.c:517
+#: ../raster3d/r3.in.lidar/main.c:527 ../raster3d/r3.in.lidar/main.c:536
+#, fuzzy, c-format
+msgid "Unable to create 3D raster map <%s>"
+msgstr "출력할 격자지도"
-#: ../db/db.select/main.c:268
+#: ../raster3d/r3.gwflow/main.c:412 ../raster3d/r3.out.v5d/main.c:55
+#: ../raster3d/r3.out.v5d/main.c:326 ../raster3d/r3.in.bin/main.c:471
+#: ../raster3d/r3.out.ascii/main.c:63 ../raster3d/r3.out.ascii/main.c:367
+#: ../raster3d/r3.cross.rast/main.c:55 ../raster3d/r3.in.v5d/main.c:206
+#: ../raster3d/r3.out.netcdf/main.c:649 ../raster3d/r3.in.ascii/main.c:393
+#: ../raster3d/r3.to.rast/main.c:75 ../raster3d/r3.to.rast/main.c:445
+#: ../raster3d/r3.out.vtk/main.c:252 ../raster3d/r3.out.vtk/main.c:338
#, fuzzy
-msgid "Selects data from attribute table."
+msgid "Unable to close 3D raster map"
msgstr "출력할 격자지도"
-#: ../db/db.select/main.c:269
-msgid "Performs SQL query statement(s)."
-msgstr ""
+#: ../raster3d/r3.gradient/main.c:44
+#, fuzzy
+msgid "gradient"
+msgstr "출력할 격자지도"
-#: ../db/db.select/main.c:304
-#, c-format
-msgid "You must provide one of these options: <%s>, <%s>, or <%s>"
+#: ../raster3d/r3.gradient/main.c:47
+msgid ""
+"Computes gradient of a 3D raster map and outputs gradient components as "
+"three 3D raster maps."
msgstr ""
-#: ../db/db.columns/main.c:62 ../db/db.describe/main.c:67
-#: ../doc/vector/v.example/main.c:137 ../vector/v.reclass/main.c:193
-#: ../vector/v.info/print.c:152 ../vector/v.db.connect/main.c:228
-#: ../vector/v.out.svg/main.c:165 ../vector/v.out.ogr/main.c:640
-#: ../vector/v.random/main.c:271 ../vector/v.patch/main.c:162
-#: ../vector/v.patch/main.c:202 ../vector/v.in.ascii/main.c:433
-#: ../vector/v.out.postgis/table.c:41 ../vector/v.out.vtk/writeVTK.c:655
-#, fuzzy, c-format
-msgid "Unable to describe table <%s>"
+#: ../raster3d/r3.gradient/main.c:56
+#, fuzzy
+msgid "Name for output 3D raster map(s)"
msgstr "출력할 격자지도"
-#: ../db/db.columns/main.c:101
-msgid "List all columns for a given table."
+#: ../raster3d/r3.gradient/main.c:63
+msgid "Size of blocks"
msgstr ""
-#: ../db/db.dropdb/main.c:74
+#: ../raster3d/r3.gradient/main.c:130
#, fuzzy
-msgid "Removes an existing database."
+msgid "Failed to allocate memory for blocks"
msgstr "출력할 격자지도"
-#: ../db/db.drivers/main.c:39
+#: ../raster3d/r3.gradient/main.c:292
#, fuzzy
-msgid "Unable to read dbmscap file"
+msgid "Writing gradient 3D raster maps..."
msgstr "출력할 격자지도"
-#: ../db/db.drivers/main.c:63
-msgid "Full output"
+#: ../raster3d/r3.out.v5d/main.c:73
+msgid "3D raster map to be converted to Vis5D (V5D) file"
msgstr ""
-#: ../db/db.drivers/main.c:67
+#: ../raster3d/r3.out.v5d/main.c:77
#, fuzzy
-msgid "Print drivers and exit"
+msgid "Name for V5D output file"
msgstr "출력할 격자지도"
-#: ../db/db.drivers/main.c:73
-msgid "Lists all database drivers."
+#: ../raster3d/r3.out.v5d/main.c:147
+#, c-format
+msgid "Vis5D allows %d columns, %d columns found"
msgstr ""
-#: ../db/db.describe/main.c:108
-msgid "Print column names only instead of full column descriptions"
+#: ../raster3d/r3.out.v5d/main.c:150
+#, c-format
+msgid "Vis5D allows %d rows, %d rows found"
msgstr ""
-#: ../db/db.describe/main.c:113
-msgid "Print table structure"
-msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:257
+#, fuzzy, c-format
+msgid "Unable to create V5D file <%s>"
+msgstr "출력할 격자지도"
-#: ../db/db.describe/main.c:131
-msgid "Describes a table in detail."
+#: ../raster3d/r3.out.v5d/main.c:262
+#, fuzzy
+msgid "Failed writing V5D file"
+msgstr "출력할 격자지도"
+#: ../raster3d/r3.out.v5d/main.c:288
+msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
msgstr ""
-#: ../db/db.createdb/main.c:74
-msgid "Creates an empty database."
+#: ../raster3d/r3.out.v5d/main.c:295
+msgid "Use map coordinates instead of xyz coordinates"
msgstr ""
-#: ../db/drivers/dbf/db.c:94
-#, fuzzy, c-format
-msgid "Unable create DBF database: %s"
+#: ../raster3d/r3.in.bin/main.c:73
+#, fuzzy
+msgid "Error reading binary data"
msgstr "출력할 격자지도"
-#: ../db/drivers/dbf/db.c:102
-#, fuzzy, c-format
-msgid "Cannot open DBF database directory: %s"
-msgstr "출력할 격자지도"
-#: ../db/drivers/dbf/db.c:110
-#, fuzzy, c-format
-msgid "Unable to open DBF database: %s"
-msgstr "출력할 격자지도"
-#: ../db/drivers/dbf/column.c:49
+#: ../raster3d/r3.in.bin/main.c:154
#, c-format
-msgid "Column '%s' already exists (duplicate name)"
+msgid "Loading %s data with %i bytes ... (%dx%dx%d)"
msgstr ""
-#: ../db/drivers/dbf/column.c:99
-#, fuzzy, c-format
-msgid "Column '%s' does not exist"
+#: ../raster3d/r3.in.bin/main.c:202 ../raster3d/r3.neighbors/main.c:311
+#, fuzzy
+msgid "Error flushing tiles"
msgstr "출력할 격자지도"
-#: ../db/drivers/dbf/cursor.c:47
+#: ../raster3d/r3.in.bin/main.c:256
#, fuzzy
-msgid "Unable to allocate new cursor"
+msgid "Imports a binary raster file into a GRASS 3D raster map."
msgstr "출력할 격자지도"
-#: ../db/drivers/dbf/cursor.c:59
+#: ../raster3d/r3.in.bin/main.c:259
#, fuzzy
-msgid "Unable to tokenize new cursor"
+msgid "Name of binary 3D raster file to be imported"
msgstr "출력할 격자지도"
-#: ../db/drivers/dbf/dbfexe.c:72
-msgid "SQL parser error"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:74
+#: ../raster3d/r3.in.bin/main.c:268 ../raster3d/r3.out.bin/main.c:228
#, fuzzy
-msgid "in statement:"
+msgid "Number of bytes per cell in binary file"
msgstr "출력할 격자지도"
-#: ../db/drivers/dbf/dbfexe.c:88
-#, fuzzy, c-format
-msgid "Table '%s' doesn't exist."
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.in.bin/main.c:275
+msgid "Byte order in binary file"
+msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:96
-#, fuzzy
-msgid "Unable to load table head."
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.in.bin/main.c:283 ../raster/r.in.bin/main.c:338
+msgid "Northern limit of geographic region (outer edge)"
+msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:106
-msgid "Unable to modify table, don't have write permission for DBF file."
+#: ../raster3d/r3.in.bin/main.c:291 ../raster/r.in.bin/main.c:346
+msgid "Southern limit of geographic region (outer edge)"
msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:121 ../db/drivers/dbf/dbfexe.c:1023
-#, fuzzy, c-format
-msgid "Column '%s' not found"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.in.bin/main.c:299 ../raster/r.in.bin/main.c:354
+msgid "Eastern limit of geographic region (outer edge)"
+msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:145
-msgid "Incompatible value type."
+#: ../raster3d/r3.in.bin/main.c:307 ../raster/r.in.bin/main.c:362
+msgid "Western limit of geographic region (outer edge)"
msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:161
-#, fuzzy
-msgid "Unable to add column."
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.in.bin/main.c:315
+msgid "Bottom limit of geographic region (outer edge)"
+msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:183
-#, fuzzy
-msgid "Unable to delete column."
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.in.bin/main.c:322
+msgid "Top limit of geographic region (outer edge)"
+msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:191
-#, fuzzy, c-format
-msgid "Table %s already exists"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.in.bin/main.c:329 ../raster/r.in.bin/main.c:369
+msgid "Number of rows"
+msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:206
-#, fuzzy
-msgid "Unable to create table."
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.in.bin/main.c:336 ../raster/r.in.bin/main.c:376
+msgid "Number of columns"
+msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:263 ../db/drivers/dbf/dbfexe.c:273
-#: ../db/drivers/dbf/dbfexe.c:303
+#: ../raster3d/r3.in.bin/main.c:343
#, fuzzy
-msgid "Error in selecting rows"
+msgid "Number of depths"
msgstr "출력할 격자지도"
-#: ../db/drivers/dbf/dbfexe.c:552
-#, fuzzy
-msgid "Cannot load table."
-msgstr "출력할 격자지도"
-#: ../db/drivers/dbf/dbfexe.c:567
-msgid "Incompatible types in WHERE condition."
+#: ../raster3d/r3.in.bin/main.c:350 ../raster/r.in.bin/main.c:383
+msgid "Set Value to NULL"
msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:572
-msgid "Result of WHERE condition is not of type BOOL."
+#: ../raster3d/r3.in.bin/main.c:354 ../raster3d/r3.out.bin/main.c:240
+#: ../raster3d/r3.out.ascii/main.c:106
+msgid "Switch the row order in output from north->south to south->north"
msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:588
-msgid "Error in evaluation of WHERE condition."
+#: ../raster3d/r3.in.bin/main.c:359 ../raster3d/r3.out.bin/main.c:245
+#: ../raster3d/r3.out.ascii/main.c:110
+msgid "Switch the depth order in output from bottom->top to top->bottom"
msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:600
-#, c-format
-msgid "Unknown result (%d) of WHERE evaluation"
+#: ../raster3d/r3.in.bin/main.c:365
+msgid "Binary data is of type integer"
msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:607
-msgid "Unknown WHERE condition type (bug in DBF driver)."
+#: ../raster3d/r3.in.bin/main.c:369 ../raster/r.in.bin/main.c:274
+msgid "Signed data (two's complement)"
msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:633
-#, fuzzy, c-format
-msgid "Unable to find order column '%s'"
-msgstr "출력할 격자지도"
-#: ../db/drivers/dbf/dbfexe.c:778
-msgid "Division by zero"
+#: ../raster3d/r3.in.bin/main.c:399
+#, c-format
+msgid "bytes=%d; must be 4 or 8 in case of floating point input"
msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:917
-msgid "Value operand for AND"
+#: ../raster3d/r3.in.bin/main.c:409
+msgid "Integer input doesn't support size=8 in this build"
msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:931
-msgid "Value operand for OR"
+#: ../raster3d/r3.in.bin/main.c:413
+msgid "bytes= must be 1, 2, 4 or 8"
msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:946
-msgid "Value operand for NOT"
+#: ../raster3d/r3.in.bin/main.c:424 ../raster/r.in.bin/main.c:521
+#: ../display/d.grid/main.c:266
+#, c-format
+msgid "Illegal north coordinate <%s>"
msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:954 ../db/drivers/dbf/dbfexe.c:1151
+#: ../raster3d/r3.in.bin/main.c:426 ../raster/r.in.bin/main.c:523
#, fuzzy, c-format
-msgid "Unknown operator %d"
+msgid "Illegal south coordinate <%s>"
msgstr "출력할 격자지도"
-#: ../db/drivers/dbf/dbfexe.c:1061
-msgid "Arithmetical operation with strings is not allowed"
+#: ../raster3d/r3.in.bin/main.c:428 ../raster/r.in.bin/main.c:525
+#: ../display/d.grid/main.c:259
+#, c-format
+msgid "Illegal east coordinate <%s>"
msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:1083
-msgid "Comparison between string and number is not allowed"
-msgstr ""
+#: ../raster3d/r3.in.bin/main.c:430 ../raster/r.in.bin/main.c:527
+#, fuzzy, c-format
+msgid "Illegal west coordinate <%s>"
+msgstr "출력할 격자지도"
-#: ../db/drivers/dbf/dbfexe.c:1098
+#: ../raster3d/r3.in.bin/main.c:438 ../raster/r.in.bin/main.c:533
#, fuzzy, c-format
-msgid "Comparison '%s' between strings not allowed"
+msgid "Unable to open <%s>"
msgstr "출력할 격자지도"
-#: ../db/drivers/dbf/dbfexe.c:1112
-msgid "Match (~) between numbers not allowed"
+#: ../raster3d/r3.in.bin/main.c:446
+#, c-format
+msgid "File Size %lld ... Total Bytes %lld"
msgstr ""
-#: ../db/drivers/dbf/execute.c:32
-#, fuzzy
-msgid "Unable to execute statement."
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.in.bin/main.c:448 ../raster/r.in.bin/main.c:577
+msgid "Bytes do not match file size"
+msgstr ""
-#: ../db/drivers/dbf/table.c:117 ../db/drivers/dbf/table.c:170
+#: ../raster3d/r3.in.bin/main.c:463 ../raster3d/r3.in.v5d/main.c:201
+#: ../raster3d/r3.in.ascii/main.c:387
#, fuzzy
-msgid "Unable to open DBF file."
+msgid "Unable to open 3D raster map"
msgstr "출력할 격자지도"
-#: ../db/drivers/dbf/table.c:312
-#, fuzzy, c-format
-msgid "Unable to move '%s' to '%s'."
-msgstr "출력할 격자지도"
-#: ../db/drivers/dbf/create_table.c:22
+#: ../raster3d/r3.out.bin/main.c:113 ../raster/r.out.bin/main.c:53
+#: ../raster/r.out.bin/main.c:62 ../raster/r.out.bin/main.c:470
+#: ../raster/r.mapcalc/map3.c:128 ../raster/r.mapcalc/map3.c:142
+#: ../raster/r.mapcalc/map3.c:156
#, fuzzy
-msgid "Unable to create table"
+msgid "Error writing data"
msgstr "출력할 격자지도"
-#: ../db/drivers/dbf/select.c:44
+#: ../raster3d/r3.out.bin/main.c:208
#, fuzzy
-msgid "Unable to open cursor."
+msgid "Exports a GRASS 3D raster map to a binary array."
msgstr "출력할 격자지도"
-#: ../db/drivers/dbf/describe.c:34
-#, fuzzy, c-format
-msgid "Table '%s' doesn't exist"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.out.bin/main.c:221 ../raster/r.out.bin/main.c:304
+msgid "Value to write out for null"
+msgstr ""
-#: ../db/drivers/mysql/index.c:55 ../db/drivers/sqlite/index.c:77
+#: ../raster3d/r3.out.bin/main.c:235 ../raster/r.in.bin/main.c:330
+#: ../raster/r.out.bin/main.c:318
#, fuzzy
-msgid "Unable to create index:"
+msgid "Output byte order"
msgstr "출력할 격자지도"
-#: ../db/drivers/mysql/db.c:61 ../db/drivers/postgres/db.c:71
-#: ../db/drivers/postgres/db.c:250
+#: ../raster3d/r3.out.bin/main.c:250
#, fuzzy
-msgid "Connection failed."
+msgid "Write data as integer"
msgstr "출력할 격자지도"
-#: ../db/drivers/mysql/fetch.c:34 ../db/drivers/mysql/fetch.c:276
-#: ../db/drivers/postgres/fetch.c:33 ../db/drivers/sqlite/fetch.c:265
-#: ../db/drivers/ogr/fetch.c:55 ../db/drivers/ogr/fetch.c:188
-msgid "Cursor not found"
+#: ../raster3d/r3.out.bin/main.c:256 ../raster/r.out.bin/main.c:347
+msgid "Invalid value for null (integers only)"
msgstr ""
-#: ../db/drivers/mysql/fetch.c:52
-msgid "Cursor position is not supported by MySQL driver"
+#: ../raster3d/r3.out.bin/main.c:269
+msgid "Floating-point output requires bytes=4 or bytes=8"
msgstr ""
-#: ../db/drivers/mysql/fetch.c:191
-#, fuzzy
-msgid "Unable to scan timestamp: "
+#: ../raster3d/r3.out.bin/main.c:273
+msgid "Integer output doesn't support bytes=8 in this build"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:321 ../raster/r.out.bin/main.c:144
+#: ../raster/r.out.bin/main.c:228 ../raster/r.out.bin/main.c:414
+#: ../display/d.mon/start.c:181 ../display/d.mon/start.c:224
+#, fuzzy, c-format
+msgid "Unable to create file <%s>"
msgstr "출력할 격자지도"
-#: ../db/drivers/mysql/fetch.c:200
-msgid "Unknown timestamp format: "
+#: ../raster3d/r3.out.bin/main.c:323 ../raster/r.out.bin/main.c:454
+msgid "Using the current region settings..."
msgstr ""
-#: ../db/drivers/mysql/fetch.c:215
-#, fuzzy
-msgid "Unable to scan date: "
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.out.bin/main.c:324 ../raster/r.out.bin/main.c:455
+#, c-format
+msgid "north=%f"
+msgstr ""
-#: ../db/drivers/mysql/fetch.c:229
-#, fuzzy
-msgid "Unable to scan time: "
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.out.bin/main.c:325 ../raster/r.out.bin/main.c:456
+#, c-format
+msgid "south=%f"
+msgstr ""
-#: ../db/drivers/mysql/fetch.c:245
-#, fuzzy
-msgid "Unable to scan datetime:"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.out.bin/main.c:326 ../raster/r.out.bin/main.c:457
+#, c-format
+msgid "east=%f"
+msgstr ""
-#: ../db/drivers/mysql/parse.c:62
-msgid "Wrong port number in MySQL database definition: "
+#: ../raster3d/r3.out.bin/main.c:327 ../raster/r.out.bin/main.c:458
+#, c-format
+msgid "west=%f"
msgstr ""
-#: ../db/drivers/mysql/parse.c:73 ../db/drivers/postgres/parse.c:60
-msgid "'user' in database definition is not supported, use db.login"
+#: ../raster3d/r3.out.bin/main.c:328
+#, c-format
+msgid "top=%f"
msgstr ""
-#: ../db/drivers/mysql/parse.c:77 ../db/drivers/postgres/parse.c:64
-msgid "'password' in database definition is not supported, use db.login"
+#: ../raster3d/r3.out.bin/main.c:329
+#, c-format
+msgid "bottom=%f"
msgstr ""
-#: ../db/drivers/mysql/parse.c:82
-msgid "Unknown option in database definition for MySQL: "
+#: ../raster3d/r3.out.bin/main.c:330 ../raster/r.in.mat/main.c:398
+#: ../raster/r.out.mat/main.c:180
+#, c-format
+msgid "rows=%d"
msgstr ""
-#: ../db/drivers/mysql/dbe.c:45
-msgid "Unable parse MySQL embedded database name"
+#: ../raster3d/r3.out.bin/main.c:331 ../raster/r.in.mat/main.c:399
+#: ../raster/r.out.mat/main.c:181
+#, c-format
+msgid "cols=%d"
msgstr ""
-#: ../db/drivers/mysql/dbe.c:61
-msgid "Cannot initialize MySQL embedded server"
+#: ../raster3d/r3.out.bin/main.c:332
+#, c-format
+msgid "depths=%d"
msgstr ""
-#: ../db/drivers/mysql/dbe.c:80
-msgid "Unable to connect to MySQL embedded server: "
+#: ../raster3d/r3.neighbors/main.c:94 ../raster/r.neighbors/main.c:102
+#: ../raster/r.series/main.c:104 ../raster/r.resamp.stats/main.c:298
+#, c-format
+msgid "Unknown method <%s>"
msgstr ""
-#: ../db/drivers/mysql/listtab.c:37
-#, fuzzy
-msgid "Unable get list of tables:"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.neighbors/main.c:119 ../raster/r.series/main.c:161
+msgid "Aggregate operation"
+msgstr ""
-#: ../db/drivers/mysql/cursor.c:44 ../db/drivers/postgres/cursor.c:41
+#: ../raster3d/r3.neighbors/main.c:127 ../raster/r.neighbors/main.c:239
+#: ../raster/r.series/main.c:168 ../raster/r.resamp.stats/main.c:279
#, fuzzy
-msgid "Unable allocate cursor."
+msgid "Quantile to calculate for method=quantile"
msgstr "출력할 격자지도"
-#: ../db/drivers/mysql/cursor.c:53
-#, fuzzy
-msgid "Unable to add dnew token."
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.neighbors/main.c:137
+msgid ""
+"The size of the window in x, y and z direction, values must be odd integer "
+"numbers, eg: 3,3,3"
+msgstr ""
-#: ../db/drivers/mysql/execute.c:41 ../db/drivers/postgres/execute.c:42
-#, fuzzy
-msgid "Unable to execute:"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.neighbors/main.c:213 ../raster/r.neighbors/main.c:171
+msgid "neighbor"
+msgstr "이웃"
-#: ../db/drivers/mysql/execute.c:62
+#: ../raster3d/r3.neighbors/main.c:214 ../raster/r.neighbors/main.c:172
#, fuzzy
-msgid "Unable to start transaction:"
+msgid "focal statistics"
msgstr "출력할 격자지도"
-#: ../db/drivers/mysql/execute.c:77
-#, fuzzy
-msgid "Unable to commit transaction:"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.neighbors/main.c:215 ../raster/r.neighbors/main.c:173
+#: ../raster/r.resamp.filter/main.c:392 ../raster/r.mfilter/main.c:59
+#: ../vector/v.outlier/main.c:73
+msgid "filter"
+msgstr "여과"
-#: ../db/drivers/mysql/create_table.c:108
-#: ../db/drivers/postgres/create_table.c:103
-#: ../db/drivers/sqlite/create_table.c:122
-#, fuzzy
-msgid "Unable to create table:"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.neighbors/main.c:218
+msgid ""
+"Makes each voxel value a function of the values assigned to the voxels "
+"around it, and stores new voxel values in an output 3D raster map"
+msgstr ""
-#: ../db/drivers/mysql/select.c:42
+#: ../raster3d/r3.neighbors/main.c:287
#, fuzzy
-msgid "Unable to select data:"
+msgid "Unable to allocate buffer"
msgstr "출력할 격자지도"
-#: ../db/drivers/mysql/select.c:64 ../db/drivers/postgres/describe.c:40
+#: ../raster3d/r3.out.ascii/main.c:82
#, fuzzy
-msgid "Unable to describe table."
+msgid "3D raster map to be converted to ASCII"
msgstr "출력할 격자지도"
-#: ../db/drivers/mysql/describe.c:32 ../db/drivers/sqlite/select.c:95
-#: ../db/drivers/sqlite/describe.c:92
-#, fuzzy
-msgid "Unable to describe table:"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.out.ascii/main.c:86
+msgid "Name for ASCII output file"
+msgstr ""
-#: ../db/drivers/mysql/describe.c:50 ../db/drivers/postgres/select.c:69
-#, fuzzy
-msgid "Unable to describe table"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.out.ascii/main.c:95
+msgid "Number of decimal places for floats"
+msgstr ""
-#: ../db/drivers/mysql/describe.c:121
-#, c-format
-msgid "MySQL driver: column '%s', type %d is not supported"
+#: ../raster3d/r3.out.ascii/main.c:102 ../raster/r.out.ascii/main.c:95
+msgid "Suppress printing of header information"
msgstr ""
-#: ../db/drivers/mysql/describe.c:127
-#, c-format
-msgid ""
-"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
-"damaged"
+#: ../raster3d/r3.out.ascii/main.c:114
+msgid "Print grass6 compatible format. Flags -d and -r are ignored."
msgstr ""
-#: ../db/drivers/odbc/listdb.c:29
+#: ../raster3d/r3.out.ascii/main.c:118 ../raster3d/r3.cross.rast/main.c:109
+#: ../raster3d/r3.out.netcdf/main.c:116 ../raster3d/r3.to.rast/main.c:128
+#: ../raster/r.to.rast3elev/main.c:194
+msgid "Use 3D raster mask (if exists) with input map"
+msgstr ""
+#: ../raster3d/r3.out.ascii/main.c:308
#, fuzzy
-msgid "Unable to allocate handle."
+msgid "Converts a 3D raster map layer into a ASCII text file."
msgstr "출력할 격자지도"
-#: ../db/drivers/odbc/listdb.c:40 ../db/drivers/postgres/listdb.c:96
-#: ../db/drivers/sqlite/listdb.c:147
+#: ../raster3d/r3.out.ascii/main.c:371
#, fuzzy
-msgid "Unable to set handle"
+msgid "Unable to close new ASCII file"
msgstr "출력할 격자지도"
-#: ../db/drivers/odbc/cursor.c:36 ../db/drivers/ogr/cursor.c:65
+#: ../raster3d/r3.info/main.c:80
+msgid "Outputs basic information about a user-specified 3D raster map layer."
+msgstr ""
+#: ../raster3d/r3.info/main.c:86
#, fuzzy
-msgid "Unable to allocate cursor"
+msgid "Print raster3d information in shell style"
msgstr "출력할 격자지도"
-#: ../db/drivers/odbc/cursor.c:55 ../db/drivers/postgres/cursor.c:50
-#: ../db/drivers/sqlite/cursor.c:56
+#: ../raster3d/r3.info/main.c:90
#, fuzzy
-msgid "Unable to add new token."
+msgid "Print range in shell style only"
msgstr "출력할 격자지도"
-#: ../db/drivers/odbc/table.c:159
+#: ../raster3d/r3.info/main.c:94 ../raster/r.info/main.c:93
+msgid "Print raster history instead of info"
+msgstr ""
+#: ../raster3d/r3.info/main.c:103
#, fuzzy, c-format
-msgid "Table %s doesn't exist"
+msgid "3D Raster map <%s> not found"
msgstr "출력할 격자지도"
-#: ../db/drivers/odbc/table.c:176
-#, c-format
-msgid "Table %s isn't 'TABLE' or 'VIEW' but %s"
+#: ../raster3d/r3.info/main.c:138 ../raster3d/r3.info/main.c:145
+#: ../raster3d/r3.info/main.c:151 ../raster3d/r3.info/main.c:156
+#: ../raster3d/r3.info/main.c:162 ../raster3d/r3.info/main.c:167
+#: ../raster3d/r3.info/main.c:172 ../raster3d/r3.info/main.c:183
+#: ../raster3d/r3.info/main.c:189 ../raster3d/r3.info/main.c:204
+#: ../raster3d/r3.info/main.c:211 ../raster3d/r3.info/main.c:218
+#: ../raster3d/r3.info/main.c:223 ../raster3d/r3.info/main.c:228
+#: ../raster3d/r3.info/main.c:235 ../raster3d/r3.info/main.c:245
+#: ../raster3d/r3.info/main.c:251 ../raster3d/r3.info/main.c:257
+#: ../raster3d/r3.info/main.c:273 ../raster3d/r3.info/main.c:280
+#: ../raster3d/r3.info/main.c:287 ../raster3d/r3.info/main.c:296
+#: ../raster3d/r3.info/main.c:306 ../raster3d/r3.info/main.c:316
+#: ../raster3d/r3.info/main.c:326 ../raster3d/r3.info/main.c:346
+#: ../raster3d/r3.info/main.c:356 ../raster3d/r3.info/main.c:361
+#: ../raster3d/r3.info/main.c:369 ../raster3d/r3.info/main.c:382
+#: ../raster/r.info/main.c:303 ../raster/r.info/main.c:445
+msgid "Cannot allocate memory for string"
msgstr ""
-#: ../db/drivers/postgres/index.c:59 ../raster/r.to.vect/main.c:233
-#: ../raster/r.random/random.c:253 ../vector/v.extract/copy_tab.c:124
-#: ../vector/v.overlay/main.c:592 ../vector/v.mkgrid/main.c:346
-#: ../vector/v.mkgrid/main.c:404 ../vector/v.random/main.c:258
-#: ../vector/v.select/copy_tabs.c:82 ../vector/v.patch/main.c:326
-#, fuzzy
-msgid "Unable to create index"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.info/main.c:492
+msgid "Error while reading history file"
+msgstr ""
-#: ../db/drivers/postgres/db.c:99
-#, fuzzy
-msgid "Unable to set schema:"
+#: ../raster3d/r3.info/main.c:499 ../raster3d/r3.null/main.c:169
+#: ../raster3d/r3.cross.rast/main.c:343
+#: ../raster3d/r3.out.vtk/errorHandling.c:65
+#, fuzzy, c-format
+msgid "Unable to close 3D raster map <%s>"
msgstr "출력할 격자지도"
-#: ../db/drivers/postgres/db.c:117
+#: ../raster3d/r3.null/main.c:55
#, fuzzy
-msgid "Unable to select data types"
+msgid "3D raster map for which to modify null values"
msgstr "출력할 격자지도"
-#: ../db/drivers/postgres/db.c:269
-#, fuzzy, c-format
-msgid "Unable to create database <%s>"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.null/main.c:63 ../raster/r.null/main.c:73
+msgid "List of cell values to be set to NULL"
+msgstr ""
-#: ../db/drivers/postgres/db.c:271
-#, fuzzy, c-format
-msgid "Unable to drop database <%s>"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.null/main.c:70 ../raster/r.null/main.c:81
+msgid "The value to replace the null value by"
+msgstr ""
-#: ../db/drivers/postgres/fetch.c:129 ../db/drivers/sqlite/fetch.c:171
-#, fuzzy
-msgid "Unable to scan date:"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.null/main.c:85
+msgid "Illegal value for null"
+msgstr ""
-#: ../db/drivers/postgres/fetch.c:147 ../db/drivers/sqlite/fetch.c:188
-#, fuzzy
-msgid "Unable to scan time:"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.null/main.c:122
+msgid "modifyNull: error opening tmp file"
+msgstr ""
-#: ../db/drivers/postgres/fetch.c:166
-msgid "Unable to scan timestamp (no idea how to process time zone):"
+#: ../raster3d/r3.null/main.c:156
+msgid "modifyNull: error flushing tiles in cube"
msgstr ""
-#: ../db/drivers/postgres/fetch.c:174
-msgid "Unable to scan timestamp (not enough arguments):"
+#: ../raster3d/r3.null/main.c:161
+msgid "modifyNull: error flushing all tiles"
msgstr ""
-#: ../db/drivers/postgres/fetch.c:188
+#: ../raster3d/r3.null/main.c:171
#, fuzzy
-msgid "Unable to recognize boolean value"
+msgid "modifyNull: Unable to close tmp file"
msgstr "출력할 격자지도"
-#: ../db/drivers/postgres/fetch.c:206
+#: ../raster3d/r3.null/main.c:187 ../raster/r.null/main.c:61
#, fuzzy
-msgid "Taken not found"
+msgid "null data"
msgstr "출력할 격자지도"
-#: ../db/drivers/postgres/parse.c:69
-msgid "Unknown option in database definition for PostgreSQL: "
+#: ../raster3d/r3.null/main.c:190
+msgid "Explicitly create the 3D NULL-value bitmap file."
msgstr ""
-#: ../db/drivers/postgres/listtab.c:38
+#: ../raster3d/r3.cross.rast/main.c:90
#, fuzzy
-msgid "Unable to select table names."
+msgid "Input 3D raster map for cross section"
msgstr "출력할 격자지도"
-#: ../db/drivers/postgres/listtab.c:65
-#, fuzzy
-msgid "Unable to select view names."
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.cross.rast/main.c:97
+msgid "2D elevation map used to create the cross section map"
+msgstr ""
-#: ../db/drivers/postgres/listdb.c:35 ../db/drivers/sqlite/listdb.c:45
-msgid "No path given"
+#: ../raster3d/r3.cross.rast/main.c:104
+msgid "Resulting cross section 2D raster map"
msgstr ""
-#: ../db/drivers/postgres/listdb.c:65
-#, fuzzy
-msgid "Unable to connect to Postgres:"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.cross.rast/main.c:229 ../raster/r.profile/main.c:54
+#: ../display/d.profile/main.c:192 ../vector/v.profile/main.c:99
+msgid "profile"
+msgstr ""
-#: ../db/drivers/postgres/listdb.c:76
-#, fuzzy
-msgid "Unable to select from Postgres:"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.cross.rast/main.c:233
+msgid ""
+"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
+"map"
+msgstr ""
-#: ../db/drivers/postgres/priv.c:53
-#, fuzzy
-msgid "Unable grant on table:"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.cross.rast/main.c:259
+msgid ""
+"The 2D and 3D region settings are different. Using the 3D raster map "
+"settings to adjust the 2D region."
+msgstr ""
-#: ../db/drivers/postgres/execute.c:68
+#: ../raster3d/r3.cross.rast/main.c:302
+msgid "Output map already exists. Will be overwritten!"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:338
#, fuzzy
-msgid "Unable to 'BEGIN' transaction"
+msgid "Wrong 3D raster datatype! Cannot create raster map"
msgstr "출력할 격자지도"
-#: ../db/drivers/postgres/execute.c:88
+#: ../raster3d/r3.in.v5d/main.c:66
#, fuzzy
-msgid "Unable to 'COMMIT' transaction"
+msgid "Name of V5D raster file to be imported"
msgstr "출력할 격자지도"
-#: ../db/drivers/postgres/table.c:37
+#: ../raster3d/r3.in.v5d/main.c:182
+msgid "Import 3-dimensional Vis5D files."
+msgstr ""
+#: ../raster3d/r3.stats/main.c:51
#, fuzzy
-msgid "Unable to execute():"
+msgid "Generates volume statistics for 3D raster maps."
msgstr "출력할 격자지도"
-#: ../db/drivers/postgres/create_table.c:90
-#, fuzzy, c-format
-msgid "Unknown column type (%s)"
-msgstr "출력할 격자지도"
-#: ../db/drivers/postgres/create_table.c:132
+#: ../raster3d/r3.stats/main.c:62
#, fuzzy
-msgid "Unable to grant select on table:"
+msgid "Number of subranges to collect stats from"
msgstr "출력할 격자지도"
-#: ../db/drivers/postgres/select.c:31
-msgid "Unable set DATESTYLE"
+#: ../raster3d/r3.stats/main.c:67
+msgid "Calculate statistics based on equal value groups"
msgstr ""
-#: ../db/drivers/postgres/select.c:55
+#: ../raster3d/r3.stats/main.c:71
#, fuzzy
-msgid "Unable to select:"
+msgid "Only print cell counts"
msgstr "출력할 격자지도"
-#: ../db/drivers/postgres/describe.c:123
-#, c-format
-msgid "PostgreSQL driver: column '%s', type %d is not supported"
+#: ../raster3d/r3.stats/main.c:91
+msgid "The number of subranges has to be equal or greater than 1"
msgstr ""
-#: ../db/drivers/postgres/describe.c:130
-#, c-format
-msgid ""
-"column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
-"may be damaged"
+#: ../raster3d/r3.stats/main.c:150
+msgid "Sort non-null values"
msgstr ""
-#: ../db/drivers/postgres/describe.c:134
-#, c-format
-msgid ""
-"column '%s' : type character varying is stored as varchar(250) some data may "
-"be lost"
-msgstr ""
+#: ../raster3d/r3.out.netcdf/main.c:81
+#, fuzzy, c-format
+msgid "Unable to close 3D raster map while catching error: %s"
+msgstr "출력할 격자지도"
-#: ../db/drivers/postgres/describe.c:140
-#, c-format
-msgid ""
-"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 "
-"(true)"
-msgstr ""
+#: ../raster3d/r3.out.netcdf/main.c:97
+#, fuzzy
+msgid "Name for netCDF output file"
+msgstr "출력할 격자지도"
-#: ../db/drivers/sqlite/index.c:96 ../db/drivers/sqlite/execute.c:69
-#: ../db/drivers/sqlite/create_table.c:141 ../db/drivers/sqlite/select.c:80
-#: ../db/drivers/sqlite/describe.c:78 ../db/drivers/sqlite/describe.c:132
-msgid "Error in sqlite3_step():"
+#: ../raster3d/r3.out.netcdf/main.c:106
+msgid "The value to be used for null values, default is the netCDF standard"
msgstr ""
-#: ../db/drivers/sqlite/db.c:99
-#, fuzzy, c-format
-msgid "Unable to create directory '%s' for sqlite database"
+#: ../raster3d/r3.out.netcdf/main.c:111
+#, fuzzy
+msgid "Export projection information as wkt and proj4 parameter"
msgstr "출력할 격자지도"
-#: ../db/drivers/sqlite/db.c:107
+#: ../raster3d/r3.out.netcdf/main.c:588
+msgid "netCDF"
+msgstr ""
+#: ../raster3d/r3.out.netcdf/main.c:590
#, fuzzy
-msgid "Unable to open database:"
+msgid "Export a 3D raster map as netCDF file."
msgstr "출력할 격자지도"
-#: ../db/drivers/sqlite/db.c:134
+#: ../raster3d/r3.flow/test_main.c:44
+msgid "unit test"
+msgstr ""
+#: ../raster3d/r3.flow/test_main.c:45
#, fuzzy
-msgid "SQLite database connection is still busy"
+msgid "Testing flow lines."
msgstr "출력할 격자지도"
-#: ../db/drivers/sqlite/db.c:155
+#: ../raster3d/r3.flow/flowline.c:60 ../raster/r.contour/main.c:216
+#: ../vector/v.overlay/line_area.c:410 ../vector/v.overlay/area_area.c:345
+#: ../vector/v.to.points/write.c:52
#, fuzzy, c-format
-msgid "Database <%s> already exists"
+msgid "Unable to insert new record: '%s'"
msgstr "출력할 격자지도"
-#: ../db/drivers/sqlite/db.c:162
-#, fuzzy
-msgid "Unable to create database:"
+#: ../raster3d/r3.flow/main.c:64 ../raster/r.to.vect/main.c:229
+#: ../raster/r.volume/main.c:260 ../vector/v.random/main.c:252
+#: ../vector/v.lrs/v.lrs.create/main.c:338 ../vector/v.in.dxf/write_vect.c:233
+#: ../vector/v.in.ascii/main.c:413 ../vector/v.mkgrid/main.c:342
+#: ../vector/v.mkgrid/main.c:400
+#, fuzzy, c-format
+msgid "Unable to create table: %s"
msgstr "출력할 격자지도"
-#: ../db/drivers/sqlite/db.c:186
+#: ../raster3d/r3.flow/main.c:67 ../raster/r.contour/main.c:188
+#: ../vector/v.in.dxf/write_vect.c:241 ../vector/v.in.ascii/main.c:521
+#: ../vector/v.in.ogr/main.c:1683 ../vector/v.to.points/main.c:187
+#: ../vector/v.in.dwg/main.c:244 ../vector/v.reclass/main.c:322
+#: ../vector/v.in.lidar/attributes.c:139
#, fuzzy, c-format
-msgid "Database <%s> not found"
+msgid "Unable to create index for table <%s>, key <%s>"
msgstr "출력할 격자지도"
-#: ../db/drivers/sqlite/fetch.c:72
-#, fuzzy
-msgid "Unable to fetch:"
+#: ../raster3d/r3.flow/main.c:72 ../raster/r.to.vect/main.c:238
+#: ../raster/r.random/random.c:257 ../raster/r.stream.extract/close.c:196
+#: ../raster/r.contour/main.c:193 ../vector/v.extract/copy_tab.c:129
+#: ../vector/v.random/main.c:264 ../vector/v.in.dxf/write_vect.c:238
+#: ../vector/v.sample/main.c:197 ../vector/v.in.ascii/main.c:421
+#: ../vector/v.mkgrid/main.c:350 ../vector/v.mkgrid/main.c:408
+#: ../vector/v.overlay/main.c:597 ../vector/v.in.ogr/main.c:1157
+#: ../vector/v.select/copy_tabs.c:85 ../vector/v.to.points/main.c:192
+#: ../vector/v.patch/main.c:331 ../vector/v.in.dwg/main.c:249
+#: ../vector/v.reclass/main.c:327 ../vector/v.in.lidar/attributes.c:144
+#: ../vector/v.distance/main.c:1361
+#, fuzzy, c-format
+msgid "Unable to grant privileges on table <%s>"
msgstr "출력할 격자지도"
-#: ../db/drivers/sqlite/fetch.c:87
+#: ../raster3d/r3.flow/main.c:91
#, fuzzy
-msgid "DB_PREVIOUS is not supported"
+msgid "Please provide three 3D raster maps"
msgstr "출력할 격자지도"
-#: ../db/drivers/sqlite/fetch.c:93
-#, fuzzy
-msgid "DB_LAST is not supported"
+#: ../raster3d/r3.flow/main.c:98
+#, fuzzy, c-format
+msgid "Vector seed map <%s> not found"
msgstr "출력할 격자지도"
-#: ../db/drivers/sqlite/fetch.c:203
+#: ../raster3d/r3.flow/main.c:147
+msgid "init_flowaccum: error in Rast3d_put_float"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:183
#, fuzzy
-msgid "Unable to scan timestamp:"
+msgid "Computes 3D flow lines and 3D flow accumulation."
msgstr "출력할 격자지도"
-#: ../db/drivers/sqlite/fetch.c:218
+#: ../raster3d/r3.flow/main.c:193
msgid ""
-"SQLite driver: parsing of interval values not implemented; assuming seconds"
+"Names of three 3D raster maps describing x, y, z components of vector field"
msgstr ""
-#: ../db/drivers/sqlite/fetch.c:223
+#: ../raster3d/r3.flow/main.c:200
+msgid ""
+"If no map is provided, flow lines are generated from each cell of the input "
+"3D raster"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:203
#, fuzzy
-msgid "Unable to scan interval:"
+msgid "Name of vector map with points from which flow lines are generated"
msgstr "출력할 격자지도"
-#: ../db/drivers/sqlite/fetch.c:286
+#: ../raster3d/r3.flow/main.c:210
#, fuzzy
-msgid "Unable to get number of rows:"
+msgid "Name for vector map of flow lines"
msgstr "출력할 격자지도"
-#: ../db/drivers/sqlite/listtab.c:50 ../db/drivers/sqlite/listtab.c:66
+#: ../raster3d/r3.flow/main.c:217
#, fuzzy
-msgid "Unable to list tables:"
+msgid "Name for output flowaccumulation 3D raster"
msgstr "출력할 격자지도"
-#: ../db/drivers/sqlite/listtab.c:78 ../db/drivers/ogr/listtab.c:49
-msgid "Unable to db_alloc_string_array()"
-msgstr ""
-#: ../db/drivers/sqlite/listdb.c:99
-#, fuzzy, c-format
-msgid "Unable to open directory '%s'"
+#: ../raster3d/r3.flow/main.c:224
+#, fuzzy
+msgid "Name for 3D raster sampled by flowlines"
msgstr "출력할 격자지도"
-#: ../db/drivers/sqlite/listdb.c:117
-#, fuzzy, c-format
-msgid "SQLite database connection '%s' is still busy"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.flow/main.c:226
+msgid ""
+"Values of this 3D raster will be stored as attributes of flowlines segments"
+msgstr ""
-#: ../db/drivers/sqlite/cursor.c:47
-#, fuzzy
-msgid "Unable to allocate cursor."
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.flow/main.c:240
+msgid "elapsed time"
+msgstr ""
-#: ../db/drivers/sqlite/main.c:47
-#, c-format
-msgid "Busy SQLITE db, already waiting for %d seconds..."
+#: ../raster3d/r3.flow/main.c:241
+msgid "length in map units"
msgstr ""
-#: ../db/drivers/sqlite/execute.c:53 ../db/drivers/sqlite/select.c:63
-#: ../db/drivers/sqlite/describe.c:60
-msgid "Error in sqlite3_prepare():"
+msgid "length in cells (voxels)"
msgstr ""
-#: ../db/drivers/sqlite/execute.c:83
+#: ../raster3d/r3.flow/main.c:243
#, fuzzy
-msgid "Error in sqlite3_finalize():"
+msgid "Unit of integration step"
msgstr "출력할 격자지도"
-#: ../db/drivers/sqlite/execute.c:111
+#: ../raster3d/r3.flow/main.c:244
#, fuzzy
-msgid "'BEGIN' transaction failed:"
-msgstr "출력할 격자지도"
+msgid "Default unit is cell"
+msgstr "기본값: 자동축척"
-#: ../db/drivers/sqlite/execute.c:139
+#: ../raster3d/r3.flow/main.c:245 ../raster3d/r3.flow/main.c:254
+#: ../raster3d/r3.flow/main.c:262 ../raster3d/r3.flow/main.c:272
#, fuzzy
-msgid "'COMMIT' transaction failed:"
+msgid "Integration"
msgstr "출력할 격자지도"
-#: ../db/drivers/sqlite/table.c:37
+#: ../raster3d/r3.flow/main.c:252
#, fuzzy
-msgid "Error in sqlite3_exec():"
+msgid "Integration step in selected unit"
msgstr "출력할 격자지도"
-#: ../db/drivers/sqlite/describe.c:194
-#, c-format
-msgid "SQLite driver: column '%s', SQLite type %d is not supported"
+#: ../raster3d/r3.flow/main.c:253
+msgid "Default step is 0.25 cell"
msgstr ""
-#: ../db/drivers/ogr/db.c:56
+#: ../raster3d/r3.flow/main.c:261
#, fuzzy
-msgid "Had to open data source read-only"
+msgid "Maximum number of steps"
msgstr "출력할 격자지도"
-#: ../db/drivers/ogr/db.c:60
+#: ../raster3d/r3.flow/main.c:269
#, fuzzy
-msgid "Unable to open OGR data source"
+msgid "Maximum error of integration"
msgstr "출력할 격자지도"
-#: ../db/drivers/ogr/fetch.c:71
-msgid "DB_PREVIOUS not supported"
+#: ../raster3d/r3.flow/main.c:270
+msgid "Influences step, increase maximum error to allow bigger steps"
msgstr ""
-#: ../db/drivers/ogr/fetch.c:82
+#: ../raster3d/r3.flow/main.c:280
+msgid "Number of cells between flow lines in x, y and z direction"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:289
+msgid "Compute flowlines upstream, downstream or in both direction."
+msgstr ""
+#: ../raster3d/r3.flow/main.c:294
#, fuzzy
-msgid "DB_LAST not supported"
+msgid "Create and fill attribute table"
msgstr "출력할 격자지도"
-#: ../db/drivers/ogr/fetch.c:160 ../db/drivers/ogr/describe.c:200
-msgid "Unknown type"
+#: ../raster3d/r3.flow/main.c:349
+msgid "Please provide 3 integer values for skip option."
msgstr ""
-#: ../db/drivers/ogr/cursor.c:74
-#, fuzzy
-msgid "Unable to add new token"
+#: ../raster3d/r3.flow/main.c:396 ../raster/r.flow/io.c:178
+#: ../raster/r.to.vect/main.c:155 ../raster/r.resamp.bspline/main.c:485
+#: ../raster/r.random/random.c:63 ../raster/r.volume/main.c:155
+#: ../raster/r.drain/main.c:197 ../raster/r.sim/simlib/output.c:38
+#: ../raster/r.sim/simlib/output.c:44 ../raster/r.stream.extract/close.c:37
+#: ../raster/r.contour/main.c:156 ../raster/r.carve/vect.c:32
+#: ../display/d.extract/main.c:106 ../vector/v.net.spanningtree/main.c:107
+#: ../vector/v.surf.rst/main.c:567 ../vector/v.surf.rst/main.c:570
+#: ../vector/v.surf.rst/main.c:726 ../vector/v.extrude/main.c:196
+#: ../vector/v.extract/main.c:346 ../vector/v.lidar.correction/main.c:209
+#: ../vector/v.lidar.correction/main.c:215
+#: ../vector/v.net.components/main.c:154 ../vector/v.net.distance/main.c:198
+#: ../vector/v.segment/main.c:114 ../vector/v.net.flow/main.c:149
+#: ../vector/v.net.flow/main.c:155 ../vector/v.split/main.c:177
+#: ../vector/v.edit/main.c:105 ../vector/v.edit/main.c:120
+#: ../vector/v.random/main.c:227 ../vector/v.profile/main.c:426
+#: ../vector/v.voronoi/main.c:215 ../vector/v.lrs/v.lrs.segment/main.c:148
+#: ../vector/v.lrs/v.lrs.label/main.c:276
+#: ../vector/v.lrs/v.lrs.create/main.c:267
+#: ../vector/v.lrs/v.lrs.create/main.c:273 ../vector/v.in.region/main.c:75
+#: ../vector/v.kernel/main.c:338 ../vector/v.net.timetable/main.c:359
+#: ../vector/v.in.db/main.c:151 ../vector/v.in.dxf/main.c:144
+#: ../vector/v.sample/main.c:162 ../vector/v.build.polylines/main.c:157
+#: ../vector/v.net.alloc/main.c:273 ../vector/v.external/main.c:144
+#: ../vector/v.in.ascii/main.c:249 ../vector/v.to.3d/main.c:87
+#: ../vector/v.qcount/main.c:127 ../vector/v.mkgrid/main.c:264
+#: ../vector/v.overlay/main.c:220 ../vector/v.in.ogr/main.c:920
+#: ../vector/v.net.allpairs/main.c:136 ../vector/v.decimate/main.c:389
+#: ../vector/v.parallel/main.c:153 ../vector/v.rectify/main.c:214
+#: ../vector/v.build/main.c:154 ../vector/v.net.connectivity/main.c:136
+#: ../vector/v.vol.rst/main.c:580 ../vector/v.vol.rst/main.c:583
+#: ../vector/v.select/main.c:125 ../vector/v.to.points/main.c:129
+#: ../vector/v.clean/main.c:288 ../vector/v.clean/main.c:295
+#: ../vector/v.lidar.edgedetection/main.c:241
+#: ../vector/v.surf.bspline/main.c:347 ../vector/v.outlier/main.c:224
+#: ../vector/v.outlier/main.c:229 ../vector/v.outlier/main.c:235
+#: ../vector/v.net.bridge/main.c:124 ../vector/v.net.path/main.c:167
+#: ../vector/v.drape/main.c:158 ../vector/v.perturb/main.c:153
+#: ../vector/v.patch/main.c:281 ../vector/v.patch/main.c:286
+#: ../vector/v.proj/main.c:374 ../vector/v.net.steiner/main.c:607
+#: ../vector/v.in.dwg/main.c:200 ../vector/v.cluster/main.c:207
+#: ../vector/v.delaunay/main.c:126 ../vector/v.reclass/main.c:117
+#: ../vector/v.in.lidar/main.c:553 ../vector/v.net.centrality/main.c:215
+#: ../vector/v.net.visibility/main.c:77 ../vector/v.generalize/main.c:336
+#: ../vector/v.net.iso/main.c:374 ../vector/v.net.salesman/main.c:551
+#: ../vector/v.transform/main.c:246 ../vector/v.distance/main.c:356
+#: ../vector/v.hull/main.c:121 ../vector/v.buffer/main.c:391
+#: ../doc/vector/v.example/main.c:98
+#, fuzzy, c-format
+msgid "Unable to create vector map <%s>"
msgstr "출력할 격자지도"
-#: ../db/drivers/ogr/execute.c:56 ../vector/v.out.ogr/main.c:593
+#: ../raster3d/r3.flow/main.c:414 ../vector/v.to.rast/vect2rast.c:48
+#: ../vector/v.colors/main.c:266
#, fuzzy, c-format
-msgid "OGR layer <%s> not found"
+msgid "Vector map <%s> is not 3D"
msgstr "출력할 격자지도"
-#: ../db/drivers/ogr/execute.c:69 ../vector/v.reclass/main.c:145
-#: ../vector/v.out.lidar/main.c:118 ../vector/v.out.lidar/main.c:155
-#: ../vector/v.transform/trans_digit.c:101 ../vector/v.colors/scan_attr.c:35
-#: ../vector/v.db.connect/main.c:289 ../vector/v.vect.stats/main.c:389
-#: ../vector/v.distance/main.c:477 ../vector/v.distance/main.c:518
-#: ../vector/v.in.db/main.c:187 ../vector/v.colors.out/make_colors.c:42
-#: ../vector/v.to.3d/trans2.c:63 ../vector/v.to.3d/trans3.c:65
-#: ../vector/v.univar/main.c:355
-#, c-format
-msgid "Column <%s> not found in table <%s>"
-msgstr ""
-#: ../db/drivers/ogr/select.c:50
+#: ../raster3d/r3.flow/main.c:441
#, fuzzy
-msgid "Unable to select: \n"
+msgid "Error during reading seed vector map"
msgstr "출력할 격자지도"
-#: ../db/drivers/ogr/select.c:58 ../db/drivers/ogr/describe.c:63
+#: ../raster3d/r3.in.ascii/main.c:86 ../raster/r.in.ascii/main.c:78
+#: ../vector/v.in.ascii/main.c:78
#, fuzzy
-msgid "Unable to describe table\n"
+msgid "Name of input file to be imported"
msgstr "출력할 격자지도"
-#: ../db/drivers/ogr/describe.c:55
-#, fuzzy, c-format
-msgid "OGR layer <%s> does not exist\n"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.in.ascii/main.c:94
+msgid "String representing NULL value data cell (use 'none' if no such value)"
+msgstr ""
-#: ../db/drivers/ogr/describe.c:112
-#, c-format
-msgid "OGR driver: column '%s', OGR type %d is not supported"
+#: ../raster3d/r3.in.ascii/main.c:130 ../raster/r.in.ascii/main.c:275
+msgid "Unable to write to file"
msgstr ""
-#: ../db/drivers/ogr/describe.c:192
-#, c-format
-msgid ""
-"column '%s', type 'string': unknown width -> stored as varchar(250) some "
-"data may be lost"
+#: ../raster3d/r3.in.ascii/main.c:172 ../raster/r.in.ascii/main.c:153
+msgid "Unable to read input from stdin"
msgstr ""
-#: ../db/db.tables/main.c:54
+#: ../raster3d/r3.in.ascii/main.c:221
#, fuzzy, c-format
-msgid "Unable to list tables from database <%s>"
+msgid "Unsupported GRASS version %s"
msgstr "출력할 격자지도"
-#: ../db/db.tables/main.c:60
-#, fuzzy
-msgid "No tables found"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.in.ascii/main.c:265
+#, c-format
+msgid "Loading data ... (%dx%dx%d)"
+msgstr ""
-#: ../db/db.tables/main.c:89
-msgid "Print tables and exit"
+#: ../raster3d/r3.in.ascii/main.c:298
+msgid "End of file reached while still loading data."
msgstr ""
-#: ../db/db.tables/main.c:93
-msgid "System tables instead of user tables"
+#: ../raster3d/r3.in.ascii/main.c:310
+#, c-format
+msgid "Invalid value detected (at col=%d row=%d depth=%d): %s"
msgstr ""
-#: ../db/db.tables/main.c:99
-msgid "Lists all tables for a given database."
+#: ../raster3d/r3.in.ascii/main.c:322
+#, c-format
+msgid ""
+"Data exists in input file after fully importing expected data. [%.4f ...]"
msgstr ""
-#: ../visualization/ximgview/main.c:64 ../general/g.cairocomp/main.c:89
-#: ../general/g.cairocomp/main.c:256
+#: ../raster3d/r3.in.ascii/main.c:360
#, fuzzy
-msgid "Unable to open display"
+msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
msgstr "출력할 격자지도"
-#: ../visualization/ximgview/main.c:84
+#: ../raster3d/r3.in.ascii/main.c:403
#, fuzzy
-msgid "Unable to get window attributes"
+msgid "Unable to close ASCII file"
msgstr "출력할 격자지도"
-#: ../visualization/ximgview/main.c:258
-#, fuzzy
-msgid "Unable to open image file"
+#: ../raster3d/r3.support/check.c:20
+#, fuzzy, c-format
+msgid "Updating statistics for <%s>"
msgstr "출력할 격자지도"
-#: ../visualization/ximgview/main.c:261
-#, fuzzy
-msgid "Unable to read BMP header"
+#: ../raster3d/r3.support/check.c:36
+#, fuzzy, c-format
+msgid "Updating the number of categories for <%s>"
msgstr "출력할 격자지도"
-#: ../visualization/ximgview/main.c:264
-msgid "Invalid BMP header"
+#: ../raster3d/r3.support/main.c:52
+msgid ""
+"Allows creation and/or modification of 3D raster map layer support files."
msgstr ""
-#: ../visualization/ximgview/main.c:270
+#: ../raster3d/r3.support/main.c:62
#, fuzzy
-msgid "Unable to map image file"
+msgid "Text to use for map title"
msgstr "출력할 격자지도"
-#: ../visualization/ximgview/main.c:291
-#: ../locale/scriptstrings/d.frame_to_translate.c:3
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:3
-#: ../locale/scriptstrings/d.redraw_to_translate.c:3
-#: ../display/d.erase/main.c:30 ../display/d.info/main.c:35
-#: ../display/d.rgb/main.c:54 ../display/d.vect/main.c:74
-#: ../display/d.mon/main.c:39 ../display/d.rast/main.c:54
-#: ../display/d.his/main.c:63 ../misc/m.nviz.script/main.c:70
-#: ../misc/m.nviz.image/main.c:52
-msgid "graphics"
-msgstr "그래픽스"
-#: ../visualization/ximgview/main.c:293 ../doc/vector/v.example/main.c:50
-#: ../raster/r.random/main.c:53 ../raster/r.contour/main.c:90
-#: ../locale/scriptstrings/v.build.all_to_translate.c:2
-#: ../locale/scriptstrings/v.import_to_translate.c:2
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:4
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:2
-#: ../locale/scriptstrings/v.unpack_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:4
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:2
-#: ../locale/scriptstrings/v.db.update_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:4
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:2
-#: ../locale/scriptstrings/v.centroids_to_translate.c:2
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:5
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:4
-#: ../locale/scriptstrings/v.report_to_translate.c:2
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:2
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:5
-#: ../locale/scriptstrings/d.what.vect_to_translate.c:3
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:2
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:2
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:2
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:2
-#: ../locale/scriptstrings/d.what.rast_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:4
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:4
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:4
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:2
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:2
-#: ../locale/scriptstrings/v.pack_to_translate.c:2
-#: ../locale/scriptstrings/v.db.join_to_translate.c:2
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:2
-#: ../locale/scriptstrings/v.db.droprow_to_translate.c:2
-#: ../locale/scriptstrings/v.to.lines_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:4
-#: ../display/d.extract/main.c:50 ../display/d.vect/main.c:75
-#: ../display/d.legend.vect/main.c:52 ../misc/m.nviz.script/main.c:73
-#: ../misc/m.nviz.image/main.c:54 ../vector/v.net.flow/main.c:58
-#: ../vector/v.reclass/main.c:67 ../vector/v.extract/main.c:77
-#: ../vector/v.what.rast3/main.c:64 ../vector/v.label.sa/main.c:38
-#: ../vector/v.info/print.c:436 ../vector/v.info/main.c:37
-#: ../vector/v.out.lidar/main.c:471 ../vector/v.timestamp/main.c:35
-#: ../vector/v.net.centrality/main.c:96 ../vector/v.cluster/main.c:90
-#: ../vector/v.net.spanningtree/main.c:46
-#: ../vector/v.lrs/v.lrs.segment/main.c:71
-#: ../vector/v.lrs/v.lrs.create/main.c:121
-#: ../vector/v.lrs/v.lrs.where/main.c:57
-#: ../vector/v.lrs/v.lrs.label/main.c:102 ../vector/v.class/main.c:45
-#: ../vector/v.transform/main.c:69 ../vector/v.segment/main.c:60
-#: ../vector/v.overlay/main.c:63 ../vector/v.label/main.c:59
-#: ../vector/v.to.rast3/main.c:48 ../vector/v.drape/main.c:56
-#: ../vector/v.decimate/main.c:123 ../vector/v.net.steiner/main.c:346
-#: ../vector/v.type/main.c:38 ../vector/v.out.dxf/main.c:56
-#: ../vector/v.surf.idw/main.c:87 ../vector/v.normal/main.c:72
-#: ../vector/v.net.allpairs/main.c:61 ../vector/v.colors/main.c:55
-#: ../vector/v.net.timetable/main.c:260 ../vector/v.hull/main.c:52
-#: ../vector/v.db.connect/main.c:52 ../vector/v.generalize/main.c:76
-#: ../vector/v.vect.stats/main.c:124 ../vector/v.out.svg/main.c:77
-#: ../vector/v.distance/main.c:90 ../vector/v.net.path/main.c:42
-#: ../vector/v.perturb/main.c:62 ../vector/v.voronoi/main.c:123
-#: ../vector/v.lidar.growing/main.c:75 ../vector/v.in.lidar/main.c:136
-#: ../vector/v.surf.rst/main.c:141 ../vector/v.clean/main.c:51
-#: ../vector/v.clean/test/topocheck.c:42 ../vector/v.category/main.c:75
-#: ../vector/v.delaunay/main.c:85 ../vector/v.neighbors/main.c:50
-#: ../vector/v.build.polylines/main.c:111 ../vector/v.net.distance/main.c:66
-#: ../vector/v.in.db/main.c:52 ../vector/v.in.region/main.c:41
-#: ../vector/v.net.alloc/main.c:57 ../vector/v.edit/main.c:54
-#: ../vector/v.out.ogr/main.c:81 ../vector/v.net.bridge/main.c:47
-#: ../vector/v.support/main.c:39 ../vector/v.mkgrid/main.c:70
-#: ../vector/v.net.components/main.c:72 ../vector/v.in.ogr/main.c:135
-#: ../vector/v.kernel/main.c:109 ../vector/v.external/main.c:50
-#: ../vector/v.out.pov/main.c:46 ../vector/v.what/main.c:60
-#: ../vector/v.surf.bspline/main.c:91 ../vector/v.in.dwg/main.c:82
-#: ../vector/v.to.points/main.c:53 ../vector/v.buffer/main.c:221
-#: ../vector/v.random/main.c:97 ../vector/v.kcv/main.c:55
-#: ../vector/v.in.dxf/main.c:64 ../vector/v.what.rast/main.c:71
-#: ../vector/v.sample/main.c:75 ../vector/v.out.ascii/main.c:47
-#: ../vector/v.qcount/main.c:60 ../vector/v.select/main.c:48
-#: ../vector/v.external.out/main.c:43 ../vector/v.patch/main.c:69
-#: ../vector/v.lidar.edgedetection/main.c:72 ../vector/v.net/main.c:47
-#: ../vector/v.in.ascii/main.c:70 ../vector/v.out.postgis/main.c:44
-#: ../vector/v.to.rast/main.c:44 ../vector/v.build/main.c:36
-#: ../vector/v.colors.out/main.c:49 ../vector/v.split/main.c:54
-#: ../vector/v.proj/main.c:67 ../vector/v.to.db/main.c:36
-#: ../vector/v.parallel/main.c:49 ../vector/v.out.vtk/main.c:47
-#: ../vector/v.db.select/main.c:54 ../vector/v.net.iso/main.c:72
-#: ../vector/v.rectify/main.c:70 ../vector/v.net.salesman/main.c:127
-#: ../vector/v.to.3d/main.c:36 ../vector/v.extrude/main.c:67
-#: ../vector/v.vol.rst/main.c:235 ../vector/v.univar/main.c:92
-#: ../vector/v.outlier/main.c:69 ../vector/v.net.visibility/main.c:45
-#: ../vector/v.lidar.correction/main.c:68
-#: ../vector/v.net.connectivity/main.c:52
-msgid "vector"
-msgstr "벡터"
-#: ../visualization/ximgview/main.c:294
-#: ../locale/scriptstrings/d.shade_to_translate.c:6
-#: ../locale/scriptstrings/r.shade_to_translate.c:6
-#: ../misc/m.nviz.script/main.c:74 ../misc/m.nviz.image/main.c:51
-msgid "visualization"
-msgstr "시각화"
-#: ../visualization/ximgview/main.c:295
-msgid "View BMP images from the PNG driver."
+#: ../raster3d/r3.support/main.c:70 ../raster/r.support/main.c:74
+msgid "Text to append to the next line of the map's metadata file"
msgstr ""
-#: ../visualization/ximgview/main.c:301
-msgid "Image file"
+#: ../raster3d/r3.support/main.c:76
+msgid "The map data unit"
msgstr ""
-#: ../visualization/ximgview/main.c:308
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:6
-msgid "Percentage of CPU time to use"
+#: ../raster3d/r3.support/main.c:82
+msgid "The vertical unit of the map"
msgstr ""
-#: ../visualization/ximgview/color.c:90 ../visualization/ximgview/color.c:288
-#, c-format
-msgid "Unknown visual class [%d]."
+#: ../raster3d/r3.support/main.c:89 ../raster/r.support/main.c:93
+msgid "Text to use for data source, line 1"
msgstr ""
-#: ../visualization/ximgview/color.c:239
-msgid "Unable to get sufficient gray shades."
+#: ../raster3d/r3.support/main.c:96 ../raster/r.support/main.c:100
+msgid "Text to use for data source, line 2"
msgstr ""
-#: ../visualization/ximgview/color.c:256
-msgid "Unable to get sufficient colors."
+#: ../raster3d/r3.support/main.c:104 ../raster/r.support/main.c:108
+msgid "Text to use for data description or keyword(s)"
msgstr ""
-#: ../visualization/ximgview/color.c:269
-msgid "Using private colormap for DirectColor visual."
-msgstr ""
+#: ../raster3d/r3.support/main.c:111 ../raster/r.category/main.c:80
+#: ../raster/r.support/main.c:115
+#, fuzzy
+msgid "Raster map from which to copy category table"
+msgstr "출력할 격자지도"
-#: ../doc/raster/r.example/main.c:84 ../doc/vector/v.example/main.c:51
-msgid "keyword2"
+#: ../raster3d/r3.support/main.c:116 ../raster/r.support/main.c:120
+msgid "Text file from which to load history"
msgstr ""
-#: ../doc/raster/r.example/main.c:85 ../doc/vector/v.example/main.c:52
-msgid "keyword3"
+#: ../raster3d/r3.support/main.c:121 ../raster/r.support/main.c:125
+msgid "Text file in which to save history"
msgstr ""
-#: ../doc/raster/r.example/main.c:86
-msgid "My first raster module"
+#: ../raster3d/r3.support/main.c:125
+msgid "Update range"
msgstr ""
-#: ../doc/vector/v.example/main.c:53
-msgid "My first vector module"
-msgstr ""
-#: ../doc/vector/v.example/main.c:75 ../raster/r.cost/main.c:325
-#: ../raster/r.carve/main.c:158 ../raster/r.walk/main.c:410
-#: ../display/d.extract/main.c:98 ../general/g.region/main.c:474
-#: ../misc/m.nviz.image/vector.c:84 ../vector/v.lrs/v.lrs.segment/main.c:140
-#: ../vector/v.lrs/v.lrs.create/main.c:251
-#: ../vector/v.lrs/v.lrs.create/main.c:260
-#: ../vector/v.lrs/v.lrs.where/main.c:127
-#: ../vector/v.lrs/v.lrs.where/main.c:136
-#: ../vector/v.lrs/v.lrs.label/main.c:268 ../vector/v.colors/main.c:238
-#: ../vector/v.vect.stats/main.c:238 ../vector/v.vect.stats/main.c:246
-#: ../vector/v.lidar.growing/main.c:126 ../vector/v.clean/test/topocheck.c:63
-#: ../vector/v.edit/main.c:153 ../vector/v.surf.bspline/main.c:258
-#: ../vector/v.surf.bspline/main.c:326
-#: ../vector/v.lidar.edgedetection/main.c:213 ../vector/v.outlier/main.c:171
-#: ../vector/v.lidar.correction/main.c:182
+#: ../raster3d/r3.support/main.c:248 ../raster/r.statistics/main.c:110
+#: ../raster/r.support/main.c:245 ../display/d.title/main.c:110
#, fuzzy, c-format
-msgid "Vector map <%s> not found"
+msgid "Unable to read category file of raster map <%s>"
msgstr "출력할 격자지도"
-#: ../doc/vector/v.example/main.c:81 ../vector/v.cluster/main.c:144
-#, fuzzy
-msgid "Unable to set predetermined vector open level"
-msgstr "출력할 격자지도"
-#: ../doc/vector/v.example/main.c:105 ../display/d.vect.chart/plot.c:38
-#: ../display/d.vect.thematic/plot1.c:105 ../display/d.vect/shape.c:38
-#: ../vector/v.what.rast3/main.c:120 ../vector/v.overlay/main.c:398
-#: ../vector/v.colors/write_rgb.c:20 ../vector/v.colors/read_rgb.c:23
-#: ../vector/v.colors/scan_attr.c:24 ../vector/v.generalize/misc.c:170
-#: ../vector/v.vect.stats/main.c:291 ../vector/v.vect.stats/main.c:365
-#: ../vector/v.distance/main.c:493 ../vector/v.edit/select.c:502
-#: ../vector/v.surf.bspline/crosscorr.c:114 ../vector/v.buffer/main.c:412
-#: ../vector/v.what.rast/main.c:138 ../vector/v.to.rast/support.c:104
-#: ../vector/v.to.rast/support.c:276 ../vector/v.to.rast/support.c:515
-#: ../vector/v.extrude/main.c:224 ../vector/v.univar/main.c:229
+#: ../raster3d/r3.support/main.c:252 ../raster/r.support/main.c:249
#, c-format
-msgid "Database connection not defined for layer %d"
+msgid "cats table for [%s] set to %s"
msgstr ""
-#: ../doc/vector/v.example/main.c:170
-#, fuzzy, c-format
-msgid "Unable to get attribute data for cat %d"
+#: ../raster3d/r3.mask/main.c:75
+#, fuzzy
+msgid "Unable to open 3D raster mask file"
msgstr "출력할 격자지도"
-#: ../doc/vector/v.example/main.c:179
-#, c-format
-msgid "Error while retrieving database record for cat %d"
+#: ../raster3d/r3.mask/main.c:104
+msgid "makeMask: error flushing tiles in cube"
msgstr ""
-#: ../doc/vector/v.example/main.c:212
-#, fuzzy, c-format
-msgid "Unable to copy attribute table to vector map <%s>"
-msgstr "출력할 격자지도"
-#: ../raster/r.sim/simlib/input.c:307
-#, c-format
-msgid ""
-"Raster map <%s> not found, and manin_val undefined, choose one to be allowed "
-"to process"
+#: ../raster3d/r3.mask/main.c:109
+msgid "makeMask: error flushing all tiles"
msgstr ""
-#: ../raster/r.sim/simlib/input.c:420
-msgid "Zero value in Mannings n"
-msgstr ""
+#: ../raster3d/r3.mask/main.c:117
+#, fuzzy
+msgid "Unable to close 3D raster mask file"
+msgstr "출력할 격자지도"
-#: ../raster/r.sim/simlib/input.c:471
-msgid "Infiltration exceeds the rainfall rate everywhere! No overland flow."
-msgstr ""
+#: ../raster3d/r3.mask/main.c:119
+#, fuzzy, c-format
+msgid "Unable to close raster map <%s>"
+msgstr "출력할 격자지도"
-#: ../raster/r.sim/simlib/input.c:495
-#, c-format
-msgid ""
-"Min elevation \t= %.2f m\n"
-"Max elevation \t= %.2f m\n"
+#: ../raster3d/r3.mask/main.c:137
+msgid "Establishes the current working 3D raster mask."
msgstr ""
-#: ../raster/r.sim/simlib/input.c:497
-#, c-format
-msgid "Mean Source Rate (rainf. excess or sediment) \t= %f m/s or kg/m2s \n"
-msgstr ""
+#: ../raster3d/r3.mask/main.c:145
+#, fuzzy
+msgid "3D raster map with reference values"
+msgstr "출력할 격자지도"
-#: ../raster/r.sim/simlib/input.c:499
-#, c-format
-msgid "Mean flow velocity \t= %f m/s\n"
+#: ../raster3d/r3.mask/main.c:153
+msgid "List of cell values to be masked out"
msgstr ""
-#: ../raster/r.sim/simlib/input.c:500
-#, c-format
-msgid "Mean Mannings \t= %f\n"
+#: ../raster3d/r3.mask/main.c:159
+msgid "Cannot create mask file: RASTER3D_MASK already exists"
msgstr ""
-#: ../raster/r.sim/simlib/input.c:504
-#, fuzzy, c-format
-msgid "Number of iterations \t= %d cell\n"
-msgid_plural "Number of iterations \t= %d cells\n"
-msgstr[0] "출력할 격자지도"
-msgstr[1] "출력할 격자지도"
-#: ../raster/r.sim/simlib/input.c:506
-#, c-format
-msgid "Time step \t= %.2f s\n"
+#: ../raster3d/r3.to.rast/main.c:100
+msgid "3D raster map(s) to be converted to 2D raster slices"
msgstr ""
-#: ../raster/r.sim/simlib/input.c:508
-#, c-format
-msgid ""
-"Sigmax \t= %f\n"
-"Max velocity \t= %f m/s\n"
+#: ../raster3d/r3.to.rast/main.c:106
+msgid "Basename for resultant raster slice maps"
msgstr ""
-#: ../raster/r.sim/simlib/input.c:510
-#, c-format
-msgid "Time step used \t= %.2f s\n"
-msgstr ""
-#: ../raster/r.sim/simlib/input.c:562
+#: ../raster3d/r3.to.rast/main.c:116
#, fuzzy
-msgid "Unable to write et file"
+msgid "Value to multiply the raster values with"
msgstr "출력할 격자지도"
-#: ../raster/r.sim/simlib/output.c:321 ../raster/r.sim/simlib/output.c:329
-#, fuzzy, c-format
-msgid "FP raster map <%s> not found"
-msgstr "출력할 격자지도"
-#: ../raster/r.sim/simlib/hydro.c:203
-#, c-format
-msgid "nwalk (%d) > maxw (%d)!"
+#: ../raster3d/r3.to.rast/main.c:117
+msgid "Coefficient a in the equation y = ax + b"
msgstr ""
-#: ../raster/r.sim/simlib/hydro.c:398
+#: ../raster3d/r3.to.rast/main.c:123
#, fuzzy
-msgid "Unable to write raster maps"
+msgid "Value to add to the raster values"
msgstr "출력할 격자지도"
-#: ../raster/r.sim/simlib/hydro.c:465
-#: ../raster/r.sim/r.sim.sediment/main.c:411
-msgid "Cannot write raster maps"
+#: ../raster3d/r3.to.rast/main.c:124
+msgid "Coefficient b in the equation y = ax + b"
msgstr ""
-#: ../raster/r.sim/simlib/observation_points.c:64
-#, fuzzy, c-format
-msgid "Unable to read points from map %s"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.to.rast/main.c:133
+msgid ""
+"Use the same resolution as the input 3D raster map for the 2D output maps, "
+"independent of the current region settings"
+msgstr ""
-#: ../raster/r.sim/simlib/observation_points.c:85
+#: ../raster3d/r3.to.rast/main.c:174
#, fuzzy, c-format
-msgid "Unable to open observation logfile %s for writing"
+msgid "Unknown raster type <%d>"
msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.sediment/main.c:115
-#: ../raster/r.sim/r.sim.water/main.c:115 ../raster/r.usler/main.c:55
-#: ../raster/r.uslek/main.c:55
-msgid "soil"
+#: ../raster3d/r3.to.rast/main.c:263
+msgid "Converts 3D raster maps to 2D raster maps"
msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:116
-msgid "sediment flow"
+#: ../raster3d/r3.to.rast/main.c:332 ../raster3d/r3.out.vtk/main.c:451
+msgid ""
+"The 2D and 3D region settings are different. Using the 2D window settings to "
+"adjust the 2D part of the 3D region."
msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:117 ../raster/r.usler/main.c:56
-#: ../raster/r.uslek/main.c:56
-msgid "erosion"
+#: ../raster3d/r3.to.rast/main.c:360 ../raster/r.li/r.li.daemon/list.c:49
+#: ../raster/r.stream.extract/bseg.c:50 ../raster/r.stream.extract/seg.c:55
+#: ../raster/r.stream.extract/cseg.c:51 ../raster/r.stream.extract/dseg.c:51
+#: ../raster/r.to.rast3/main.c:244 ../vector/v.surf.rst/main.c:800
+#: ../vector/v.net.components/main.c:170 ../vector/v.net.distance/main.c:228
+#: ../vector/v.net.flow/main.c:232 ../vector/v.profile/main.c:653
+#: ../vector/v.net.timetable/main.c:389 ../vector/v.net.timetable/main.c:399
+#: ../vector/v.mkgrid/write_grid.c:28 ../vector/v.net.allpairs/main.c:201
+#: ../vector/v.kcv/main.c:208 ../vector/v.net.connectivity/main.c:186
+#: ../vector/v.net.connectivity/main.c:202 ../vector/v.vol.rst/user1.c:423
+#: ../vector/v.net.centrality/main.c:293 ../vector/v.net.centrality/main.c:298
+#: ../vector/v.net.centrality/main.c:304 ../vector/v.net.centrality/main.c:310
+#: ../vector/v.net.centrality/main.c:316 ../vector/v.generalize/matrix.c:144
+#: ../vector/v.generalize/simplification.c:33
+#: ../vector/v.generalize/simplification.c:40
+#: ../vector/v.generalize/simplification.c:306
+#: ../vector/v.generalize/simplification.c:314
+#: ../vector/v.generalize/simplification.c:338
+#: ../vector/v.generalize/smoothing.c:144
+#: ../vector/v.generalize/smoothing.c:231
+#: ../vector/v.generalize/smoothing.c:374
+#: ../vector/v.generalize/smoothing.c:528
+#: ../vector/v.generalize/smoothing.c:574
+#: ../vector/v.generalize/smoothing.c:578
+#: ../vector/v.generalize/smoothing.c:582
+#: ../vector/v.generalize/smoothing.c:586
+#: ../vector/v.generalize/smoothing.c:590
+#: ../vector/v.generalize/smoothing.c:594
+#: ../vector/v.generalize/smoothing.c:598 ../vector/v.generalize/network.c:96
+#: ../vector/v.generalize/network.c:131 ../imagery/i.smap/multialloc.c:115
+#: ../db/drivers/postgres/listtab.c:92 ../db/drivers/postgres/listdb.c:88
+#: ../db/drivers/sqlite/listdb.c:134
+msgid "Out of memory"
msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:118
-msgid "deposition"
+#: ../raster3d/r3.to.rast/main.c:362
+#, c-format
+msgid "Creating %i raster maps"
msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:119
-#: ../raster/r.sim/r.sim.water/main.c:118 ../raster/r.spread/main.c:109
-#: ../raster/r.topmodel/main.c:53 ../raster/r.ros/main.c:217
-msgid "model"
-msgstr ""
+#: ../raster3d/r3.to.rast/main.c:368
+#, fuzzy, c-format
+msgid "Raster map %i Filename: %s"
+msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.sediment/main.c:121
+#: ../raster3d/r3.to.rast/main.c:373
+#, fuzzy, c-format
msgid ""
-"Sediment transport and erosion/deposition simulation using path sampling "
-"method (SIMWE)."
+"Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
+msgstr "출력할 격자지도"
+#: ../raster3d/r3.timestamp/main.c:45 ../raster/r.timestamp/main.c:37
+#: ../vector/v.timestamp/main.c:37
+msgid "timestamp"
msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:128
+#: ../raster3d/r3.timestamp/main.c:48
#, fuzzy
-msgid "Name of water depth raster map [m]"
+msgid "Modifies a timestamp for a 3D raster map."
msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.sediment/main.c:132
-#: ../raster/r.sim/r.sim.water/main.c:127
+#: ../raster3d/r3.timestamp/main.c:49
#, fuzzy
-msgid "Name of x-derivatives raster map [m/m]"
+msgid "Print/add/remove a timestamp for a 3D raster map."
msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.sediment/main.c:136
-#: ../raster/r.sim/r.sim.water/main.c:131
-#, fuzzy
-msgid "Name of y-derivatives raster map [m/m]"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.timestamp/main.c:58
+msgid "Datetime, datetime1/datetime2, or none"
+msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:141
-#, fuzzy
-msgid "Name of detachment capacity coefficient raster map [s/m]"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.timestamp/main.c:91
+msgid "Timestamp format is invalid"
+msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:146
+#: ../raster3d/r3.retile/main.c:49
#, fuzzy
-msgid "Name of transport capacity coefficient raster map [s]"
+msgid "Unable to close the 3D raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.sediment/main.c:151
+#: ../raster3d/r3.retile/main.c:71
#, fuzzy
-msgid "Name of critical shear stress raster map [Pa]"
+msgid "Name of the retiled 3D raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.sediment/main.c:156
-#: ../raster/r.sim/r.sim.water/main.c:168
-#, fuzzy
-msgid "Name of Manning's n raster map"
-msgstr "출력할 격자지도"
+#: ../raster3d/r3.retile/main.c:99
+msgid ""
+"Retiles an existing 3D raster map with user defined x, y and z tile size."
+msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:164
-#: ../raster/r.sim/r.sim.water/main.c:176
+#: ../raster3d/r3.retile/main.c:135
+msgid "Rast3d_get_standard3d_params: tile dimension value invalid"
+msgstr ""
+#: ../raster3d/r3.retile/main.c:148
#, fuzzy
-msgid "Manning's n unique value"
+msgid "Error closing 3D raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.sediment/main.c:171
-#: ../raster/r.sim/r.sim.water/main.c:190
+#: ../raster3d/r3.in.lidar/main.c:170
#, fuzzy
-msgid "Name of sampling locations vector points map"
+msgid ""
+"Creates a 3D raster map from LAS LiDAR points using univariate statistics."
msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.sediment/main.c:177
+#: ../raster3d/r3.in.lidar/main.c:174 ../raster/r.in.lidar/main.c:120
+#: ../vector/v.in.lidar/main.c:142
#, fuzzy
-msgid "Name for output transport capacity raster map [kg/ms]"
+msgid "LAS input file"
msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.sediment/main.c:184
+#: ../raster3d/r3.in.lidar/main.c:176
+msgid "LiDAR input file in LAS format (*.las or *.laz)"
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:181 ../raster/r.in.lidar/main.c:130
#, fuzzy
-msgid ""
-"Name for output transport limited erosion-deposition raster map [kg/m2s]"
+msgid "File containing names of LAS input files"
msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.sediment/main.c:191
+#: ../raster3d/r3.in.lidar/main.c:182 ../raster/r.in.lidar/main.c:121
+#: ../raster/r.in.lidar/main.c:131 ../vector/v.in.lidar/main.c:143
+msgid "LiDAR input files in LAS format (*.las or *.laz)"
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:189
#, fuzzy
-msgid "Name for output sediment concentration raster map [particle/m3]"
+msgid "Count of points per cell"
msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.sediment/main.c:197
+#: ../raster3d/r3.in.lidar/main.c:195
#, fuzzy
-msgid "Name for output sediment flux raster map [kg/ms]"
+msgid "Sum of values of point intensities per cell"
msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.sediment/main.c:204
+#: ../raster3d/r3.in.lidar/main.c:201
+msgid "Mean of point intensities per cell"
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:209
#, fuzzy
-msgid "Name for output erosion-deposition raster map [kg/m2s]"
+msgid "3D raster map of proportional point count"
msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.sediment/main.c:211
-#: ../raster/r.sim/r.sim.water/main.c:222
-msgid ""
-"Name for sampling points output text file. For each observation vector point "
-"the time series of sediment transport is stored."
+#: ../raster3d/r3.in.lidar/main.c:211
+msgid "Point count per 3D cell divided by point count per vertical column"
msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:218
-#: ../raster/r.sim/r.sim.water/main.c:215
+#: ../raster3d/r3.in.lidar/main.c:213 ../raster3d/r3.in.lidar/main.c:223
#, fuzzy
-msgid "Base name of the output walkers vector points map"
+msgid "Proportional output"
msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.sediment/main.c:225
-msgid "Number of walkers"
-msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:219
+#, fuzzy
+msgid "3D raster map of proportional sum of values"
+msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.sediment/main.c:233
-#: ../raster/r.sim/r.sim.water/main.c:238
-msgid "Time used for iterations [minutes]"
+#: ../raster3d/r3.in.lidar/main.c:221
+msgid "Sum of values per 3D cell divided by sum of values per vertical column"
msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:242
-#: ../raster/r.sim/r.sim.water/main.c:247
-msgid "Time interval for creating output maps [minutes]"
+#: ../raster3d/r3.in.lidar/main.c:229 ../raster/r.in.lidar/main.c:258
+#: ../vector/v.in.lidar/main.c:201
+msgid "Only import points of selected return type"
msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:260
-#: ../raster/r.sim/r.sim.water/main.c:265
-msgid "Water diffusion constant"
+#: ../raster3d/r3.in.lidar/main.c:230 ../raster/r.in.lidar/main.c:259
+#: ../vector/v.in.lidar/main.c:202
+msgid "If not specified, all points are imported"
msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:268
-#: ../raster/r.sim/r.sim.water/main.c:304
-msgid "Seed for random number generator"
+#: ../raster3d/r3.in.lidar/main.c:239 ../raster/r.in.lidar/main.c:268
+#: ../vector/v.in.lidar/main.c:211
+msgid "Only import points of selected class(es)"
msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:270
-#: ../raster/r.sim/r.sim.water/main.c:306
+#: ../raster3d/r3.in.lidar/main.c:240 ../raster/r.in.lidar/main.c:269
+#: ../vector/v.in.lidar/main.c:212
msgid ""
-"The same seed can be used to obtain same results or random seed can be "
-"generated by other means."
+"Input is comma separated integers. If not specified, all points are imported."
msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:276
-#: ../raster/r.sim/r.sim.water/main.c:312
-msgid "Generate random seed"
-msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:248
+#, fuzzy
+msgid "Subtract raster values from the z coordinates"
+msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.sediment/main.c:278
-#: ../raster/r.sim/r.sim.water/main.c:314
-msgid ""
-"Automatically generates random seed for random number generator (use when "
-"you don't want to provide the seed option)"
+#: ../raster3d/r3.in.lidar/main.c:250
+msgid "The scale for z is applied beforehand, the filter afterwards"
msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:286
-#: ../raster/r.sim/r.sim.water/main.c:322
-#, c-format
-msgid "Generated random seed (-s): %ld"
-msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:251 ../raster3d/r3.in.lidar/main.c:264
+#: ../raster3d/r3.in.lidar/main.c:280 ../raster/r.in.lidar/main.c:184
+#: ../raster/r.in.lidar/main.c:200 ../raster/r.in.lidar/main.c:216
+#, fuzzy
+msgid "Transform"
+msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.sediment/main.c:291
-#: ../raster/r.sim/r.sim.water/main.c:327
-#, c-format
-msgid "Read random seed from %s option: %ld"
+#: ../raster3d/r3.in.lidar/main.c:256
+msgid "Use base raster actual resolution instead of computational region"
msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:373
-#: ../raster/r.sim/r.sim.water/main.c:482
-msgid "More than 100 files are going to be created !!!!!"
-msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:263 ../raster/r.in.lidar/main.c:199
+#, fuzzy
+msgid "Scale to apply to Z data"
+msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.sediment/main.c:379
-#: ../raster/r.sim/r.sim.water/main.c:488
-#, c-format
-msgid "default nwalk=%d, rwalk=%f"
+#: ../raster3d/r3.in.lidar/main.c:271 ../raster/r.in.lidar/main.c:207
+msgid "Filter range for intensity values (min,max)"
msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:388
-#: ../raster/r.sim/r.sim.water/main.c:498
-#, c-format
-msgid "Using metric conversion factor %f, step=%f"
-msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:279 ../raster/r.in.lidar/main.c:215
+#, fuzzy
+msgid "Scale to apply to intensity values"
+msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.sediment/main.c:395
+#: ../raster3d/r3.in.lidar/main.c:284 ../raster/r.in.lidar/main.c:335
+#: ../vector/v.in.lidar/main.c:291
#, fuzzy
-msgid "You are not outputting any raster or site files"
+msgid "Use only valid points"
msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.sediment/main.c:398
-#: ../raster/r.sim/r.sim.water/main.c:507 ../vector/v.surf.rst/main.c:623
-#: ../vector/v.surf.rst/main.c:678 ../vector/v.vol.rst/main.c:914
-msgid "Input failed"
+#: ../raster3d/r3.in.lidar/main.c:286 ../raster/r.in.lidar/main.c:337
+#: ../vector/v.in.lidar/main.c:293
+msgid ""
+"Points invalid according to APSRS LAS specification will be filtered out"
msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:116 ../vector/v.net.flow/main.c:60
-msgid "flow"
+#: ../raster3d/r3.in.lidar/main.c:299 ../raster/r.in.lidar/main.c:276
+#: ../vector/v.in.lidar/main.c:276
+msgid "Print LAS file info and exit"
msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:117
-msgid "overland flow"
+#: ../raster3d/r3.in.lidar/main.c:329
+#, c-format
+msgid "%s will not be taken into account during scan"
msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:120
-msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
-msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:340 ../raster/r.in.lidar/main.c:367
+#, fuzzy, c-format
+msgid "File <%s> does not exist"
+msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.water/main.c:137
-#, fuzzy
-msgid "Name of rainfall excess rate (rain-infilt) raster map [mm/hr]"
+#: ../raster3d/r3.in.lidar/main.c:374 ../raster/r.in.lidar/main.c:397
+#: ../vector/v.in.lidar/main.c:347
+#, fuzzy, c-format
+msgid "Input file <%s> does not exist"
msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.water/main.c:146
-msgid "Rainfall excess rate unique value [mm/hr]"
+#: ../raster3d/r3.in.lidar/main.c:378 ../raster/r.in.lidar/main.c:401
+#: ../vector/v.in.lidar/main.c:352
+#, fuzzy, c-format
+msgid "Unable to open file <%s> as a LiDAR point cloud"
+msgstr "출력할 격자지도"
+#: ../raster3d/r3.in.lidar/main.c:382 ../raster/r.in.lidar/main.c:405
+#: ../vector/v.in.lidar/main.c:356
+#, fuzzy, c-format
+msgid "Unable to read LAS header of <%s>"
+msgstr "출력할 격자지도"
+#: ../raster3d/r3.in.lidar/main.c:398 ../raster/r.in.lidar/main.c:421
+msgid ""
+"First file's projection checked, checking projection of the other files..."
msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:153
+#: ../raster3d/r3.in.lidar/main.c:540
#, fuzzy
-msgid "Name of runoff infiltration rate raster map [mm/hr]"
+msgid "Preparing the maps..."
msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.water/main.c:162
-msgid "Runoff infiltration rate unique value [mm/hr]"
-msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:574 ../vector/v.sample/main.c:200
+#, fuzzy
+msgid "Reading points..."
+msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.water/main.c:183
+#: ../raster3d/r3.in.lidar/main.c:656
#, fuzzy
-msgid "Name of flow controls raster map (permeability ratio 0-1)"
+msgid "Computing proportional count map..."
msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.water/main.c:196
+#: ../raster3d/r3.in.lidar/main.c:661
#, fuzzy
-msgid "Name for output water depth raster map [m]"
+msgid "Computing proportional sum map..."
msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.water/main.c:202
+#: ../raster3d/r3.in.lidar/main.c:666
#, fuzzy
-msgid "Name for output water discharge raster map [m3/s]"
+msgid "Computing mean map..."
msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.water/main.c:208
+#: ../raster3d/r3.in.lidar/main.c:671
#, fuzzy
-msgid "Name for output simulation error raster map [m]"
+msgid "Closing the maps..."
msgstr "출력할 격자지도"
-#: ../raster/r.sim/r.sim.water/main.c:230
-msgid "Number of walkers, default is twice the number of cells"
+#: ../raster3d/r3.in.lidar/main.c:707 ../vector/v.in.lidar/main.c:783
+#, c-format
+msgid "%lu input points were not valid and filtered out"
msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:274
-msgid "Threshold water depth [m]"
+#: ../raster3d/r3.in.lidar/main.c:710 ../vector/v.in.lidar/main.c:789
+#, c-format
+msgid "%lu input points were filtered out by return number"
msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:275
-msgid "Diffusion increases after this water depth is reached"
+#: ../raster3d/r3.in.lidar/main.c:712 ../vector/v.in.lidar/main.c:791
+#, c-format
+msgid "%lu input points were filtered out by class number"
msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:283
-msgid "Diffusion increase constant"
+#: ../raster3d/r3.in.lidar/main.c:714
+#, c-format
+msgid "%lu input points had intensity out of range"
msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:292
-msgid "Weighting factor for water flow velocity vector"
+#: ../raster3d/r3.in.lidar/main.c:716 ../vector/v.in.lidar/main.c:811
+#, c-format
+msgid "%lu input points were not valid, use -%c flag to filter them out"
msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:297
-msgid "Time-series output"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:504
+#: ../raster3d/r3.in.lidar/rast_segment.c:53
+#: ../raster/r.in.lidar/rast_segment.c:40
#, fuzzy
-msgid "You are not outputting any raster maps"
+msgid "Cannot create temporary file with segments of a raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.buffer/parse_dist.c:54
-#, c-format
-msgid "%s: %s - illegal distance specification"
-msgstr ""
+#: ../raster3d/r3.in.lidar/string_list.c:47
+#: ../raster/r.in.lidar/string_list.c:34
+#, fuzzy, c-format
+msgid "Cannot open file %s for reading"
+msgstr "출력할 격자지도"
-#: ../raster/r.buffer/read_map.c:52 ../raster/r.flow/io.c:89
-#: ../raster/r.flow/io.c:107
+#: ../raster3d/r3.in.lidar/filters.c:27
#, fuzzy, c-format
-msgid "Reading input raster map <%s>..."
+msgid "Invalid range <%s> for option %s"
msgstr "출력할 격자지도"
-#: ../raster/r.buffer/main.c:67 ../raster/r.circle/main.c:52
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:4
-#: ../vector/v.buffer/main.c:222 ../vector/v.parallel/main.c:51
-#, fuzzy
-msgid "buffer"
+#: ../raster3d/r3.in.lidar/filters.c:54 ../vector/v.in.pdal/filters.c:95
+#: ../vector/v.in.lidar/filters.c:36
+#, fuzzy, c-format
+msgid "Unknown return filter value <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.buffer/main.c:69
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:1
-msgid ""
-"Creates a raster map showing buffer zones surrounding cells that contain non-"
-"NULL category values."
+#: ../raster3d/r3.in.lidar/info.c:109 ../raster/r.in.xyz/main.c:1198
+#: ../raster/r.in.lidar/info.c:108
+msgid "Scanning data ..."
msgstr ""
-#: ../raster/r.buffer/main.c:81
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:6
-msgid "Distance zone(s)"
+#: ../raster3d/r3.in.lidar/info.c:149 ../raster/r.in.xyz/main.c:1304
+#: ../raster/r.in.lidar/info.c:148
+#, c-format
+msgid "Range: min max\n"
msgstr ""
-#: ../raster/r.buffer/main.c:88
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:7
-msgid "Units of distance"
+#: ../raster3d/r3.in.lidar/projection.c:36 ../raster/r.external/proj.c:42
+#: ../raster/r.in.gdal/main.c:479 ../raster/r.in.lidar/projection.c:34
+#: ../vector/v.in.pdal/projection.c:31 ../vector/v.external/proj.c:51
+#: ../vector/v.in.ogr/main.c:627 ../vector/v.in.lidar/projection.c:32
+msgid ""
+"Projection of dataset does not appear to match current location.\n"
+"\n"
msgstr ""
-#: ../raster/r.buffer/main.c:94
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:5
-msgid "Ignore zero (0) data cells instead of NULL cells"
+#: ../raster3d/r3.in.lidar/projection.c:42 ../raster/r.in.lidar/projection.c:40
+#: ../vector/v.in.pdal/projection.c:37 ../vector/v.external/proj.c:57
+#: ../vector/v.in.ogr/main.c:633 ../vector/v.in.lidar/projection.c:38
+msgid "GRASS LOCATION PROJ_INFO is:\n"
msgstr ""
-#: ../raster/r.buffer/main.c:131
-msgid "Parse distances error"
+#: ../raster3d/r3.in.lidar/projection.c:51
+#: ../raster3d/r3.in.lidar/projection.c:57 ../raster/r.external/proj.c:85
+#: ../raster/r.in.gdal/main.c:531 ../raster/r.in.lidar/projection.c:49
+#: ../raster/r.in.lidar/projection.c:55 ../vector/v.in.pdal/projection.c:46
+#: ../vector/v.in.pdal/projection.c:52 ../vector/v.external/proj.c:67
+#: ../vector/v.external/proj.c:74 ../vector/v.in.ogr/main.c:643
+#: ../vector/v.in.ogr/main.c:650 ../vector/v.in.lidar/projection.c:47
+#: ../vector/v.in.lidar/projection.c:53
+msgid "Import dataset PROJ_INFO is:\n"
msgstr ""
-#: ../raster/r.buffer/main.c:150
+#: ../raster3d/r3.in.lidar/projection.c:93 ../raster/r.external/proj.c:107
+#: ../raster/r.in.gdal/main.c:549 ../raster/r.in.lidar/projection.c:91
+#: ../vector/v.in.pdal/projection.c:88 ../vector/v.external/proj.c:113
+#: ../vector/v.in.ogr/main.c:689 ../vector/v.in.lidar/projection.c:89
#, c-format
-msgid "Pass %d (of %d)"
+msgid ""
+"\n"
+"In case of no significant differences in the projection definitions, use the "
+"-o flag to ignore them and use current location definition.\n"
msgstr ""
-#: ../raster/r.buffer/execute.c:34
-msgid "Finding buffer zones..."
+#: ../raster3d/r3.in.lidar/projection.c:97 ../raster/r.in.lidar/projection.c:95
+#: ../vector/v.in.pdal/projection.c:92 ../vector/v.external/proj.c:117
+#: ../vector/v.in.ogr/main.c:693 ../vector/v.in.lidar/projection.c:93
+msgid ""
+"Consider generating a new location with 'location' parameter from input data "
+"set.\n"
msgstr ""
-#: ../raster/r.buffer/write_map.c:45 ../raster/r.cost/main.c:1034
-#: ../raster/r.flow/io.c:207
-#, fuzzy, c-format
-msgid "Writing output raster map <%s>..."
+#: ../raster3d/r3.in.lidar/projection.c:115
+#: ../raster/r.in.lidar/projection.c:113 ../vector/v.in.pdal/projection.c:110
+#: ../vector/v.in.pdal/projection.c:156 ../vector/v.in.pdal/projection.c:189
+#: ../vector/v.external/proj.c:41 ../vector/v.in.ogr/main.c:603
+#: ../vector/v.in.lidar/projection.c:111
+msgid ""
+"Unable to convert input map projection information to GRASS format for "
+"checking"
+msgstr ""
+#: ../raster3d/r3.in.lidar/projection.c:130 ../raster/r.external/proj.c:34
+#: ../raster/r.in.gdal/main.c:469 ../raster/r.in.lidar/projection.c:128
+#: ../vector/v.in.ogr/main.c:618 ../vector/v.in.lidar/projection.c:126
+#, fuzzy
+msgid "Over-riding projection check"
msgstr "출력할 격자지도"
-#: ../raster/r.support/main.c:56
-msgid "Allows creation and/or modification of raster map layer support files."
+#: ../raster3d/r3.in.lidar/projection.c:141 ../raster/r.external/proj.c:116
+#: ../raster/r.in.gdal/main.c:569 ../raster/r.in.lidar/projection.c:139
+#: ../vector/v.in.pdal/projection.c:137 ../vector/v.external/proj.c:122
+#: ../vector/v.in.ogr/main.c:708 ../vector/v.in.lidar/projection.c:137
+msgid "Projection of input dataset and current location appear to match"
msgstr ""
-#: ../raster/r.support/main.c:66 ../raster/r.in.bin/main.c:298
-#: ../raster/r.external/main.c:90 ../raster/r.in.poly/main.c:50
-#: ../raster/r.in.gdal/main.c:133 ../raster/r.in.ascii/main.c:92
-#: ../locale/scriptstrings/r.import_to_translate.c:24
-msgid "Title for resultant raster map"
+#: ../raster3d/r3.out.vtk/parameters.c:30
+#, fuzzy
+msgid "3D raster map(s) to be converted to VTK-ASCII data format"
+msgstr "출력할 격자지도"
+#: ../raster3d/r3.out.vtk/parameters.c:34 ../raster/r.out.vtk/parameters.c:36
+msgid "Name for VTK-ASCII output file"
msgstr ""
-#: ../raster/r.support/main.c:80
-msgid "Text to use for map data units"
+#: ../raster3d/r3.out.vtk/parameters.c:41
+msgid "Float value to represent no data cell/points"
msgstr ""
-#: ../raster/r.support/main.c:86
-msgid "Text to use for map vertical datum"
+#: ../raster3d/r3.out.vtk/parameters.c:47
+msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
msgstr ""
-#: ../raster/r.support/main.c:129
-msgid "Update statistics (histogram, range)"
+#: ../raster3d/r3.out.vtk/parameters.c:56
+#, fuzzy
+msgid "Top surface 2D raster map"
+msgstr "출력할 격자지도"
+#: ../raster3d/r3.out.vtk/parameters.c:65
+#, fuzzy
+msgid "Bottom surface 2D raster map"
+msgstr "출력할 격자지도"
+#: ../raster3d/r3.out.vtk/parameters.c:71
+msgid ""
+"Create 3D elevation output with a top and a bottom surface, both raster maps "
+"are required."
msgstr ""
-#: ../raster/r.support/main.c:133
-msgid "Create/reset the null file"
+#: ../raster3d/r3.out.vtk/parameters.c:80
+msgid ""
+"Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
msgstr ""
-#: ../raster/r.support/main.c:137
-msgid "Delete the null file"
+#: ../raster3d/r3.out.vtk/parameters.c:88
+msgid "Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]"
msgstr ""
-#: ../raster/r.support/main.c:147 ../raster/r.category/main.c:130
-#, fuzzy, c-format
-msgid "Raster map <%s> not found in current mapset"
+#: ../raster3d/r3.out.vtk/parameters.c:94 ../raster/r.out.vtk/parameters.c:85
+#: ../vector/v.out.vtk/main.c:76
+msgid "Scale factor for elevation"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:107 ../raster/r.out.ascii/main.c:79
+#: ../raster/r.out.vtk/parameters.c:98 ../display/d.rast.num/main.c:104
+#: ../vector/v.out.vtk/main.c:70 ../vector/v.out.ascii/args.c:75
+msgid "Number of significant digits (floating point only)"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:112
+msgid "Use 3D raster mask (if exists) with input maps"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:117
+#, fuzzy
+msgid "Scale factor affects the origin"
msgstr "출력할 격자지도"
-#: ../raster/r.support/main.c:273 ../raster/r.support/main.c:301
-#, c-format
-msgid "[%s] is a reclass of another map. Exiting."
+#: ../raster3d/r3.out.vtk/parameters.c:123 ../raster/r.out.vtk/parameters.c:128
+msgid "Correct the coordinates to match the VTK-OpenGL precision"
msgstr ""
-#: ../raster/r.support/main.c:285
-#, c-format
-msgid "Writing new null file for [%s]... "
+#: ../raster3d/r3.out.vtk/parameters.c:129
+msgid ""
+"Do not convert the top-bottom resolution in case of lat long projection to "
+"meters"
msgstr ""
-#: ../raster/r.support/main.c:305
-#, c-format
-msgid "Removing null file for [%s]...\n"
+#: ../raster3d/r3.out.vtk/writeVTKData.c:122
+msgid "write_vtk_points: Writing point coordinates"
msgstr ""
-#: ../raster/r.support/main.c:312
-msgid "Done."
+#: ../raster3d/r3.out.vtk/writeVTKData.c:256
+msgid "write_vtk_unstructured_grid_cells: Writing the cells"
msgstr ""
-#: ../raster/r.support/check.c:26
+#: ../raster3d/r3.out.vtk/writeVTKData.c:335
#, c-format
msgid ""
-"\n"
-" Updating statistics for [%s]"
+"write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
+"ascii file"
msgstr ""
-#: ../raster/r.support/check.c:69
+#: ../raster3d/r3.out.vtk/writeVTKData.c:441
+msgid "Wrong 3D raster map values! Values should in between 0 and 255!"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:117
+msgid "Specify top and bottom map"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:124
#, c-format
-msgid ""
-" Updating the number of categories for [%s]\n"
-"\n"
+msgid "Top cell map <%s> not found"
msgstr ""
-#: ../raster/r.random.cells/init.c:77
-msgid "Distance must be >= 0.0"
+#: ../raster3d/r3.out.vtk/main.c:133
+#, c-format
+msgid "Bottom cell map <%s> not found"
msgstr ""
-#: ../raster/r.random.cells/init.c:96 ../raster/r.random.surface/main.c:128
+#: ../raster3d/r3.out.vtk/main.c:152
#, fuzzy, c-format
-msgid "Generating raster map <%s>..."
+msgid "3D raster map RGB map <%s> not found"
msgstr "출력할 격자지도"
-#: ../raster/r.random.cells/main.c:48 ../raster/r.random/main.c:52
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:3
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:3
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:4
-#: ../locale/scriptstrings/t.sample_to_translate.c:3
-#: ../display/d.where/main.c:44 ../vector/v.what.rast3/main.c:65
-#: ../vector/v.drape/main.c:58 ../vector/v.random/main.c:98
-#: ../vector/v.what.rast/main.c:72 ../vector/v.sample/main.c:76
-#: ../vector/v.extrude/main.c:69
-msgid "sampling"
-msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:155
+#, fuzzy
+msgid "Please provide three RGB 3D raster maps"
+msgstr "출력할 격자지도"
-#: ../raster/r.random.cells/main.c:49 ../raster/r.random.surface/main.c:59
-#: ../raster/r.surf.random/main.c:38 ../raster/r.random/main.c:54
-#: ../raster/r.surf.gauss/main.c:40 ../vector/v.extract/main.c:81
-#: ../vector/v.perturb/main.c:65 ../vector/v.random/main.c:100
-msgid "random"
-msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:165
+#, fuzzy, c-format
+msgid "3D vector map <%s> not found"
+msgstr "출력할 격자지도"
-#: ../raster/r.random.cells/main.c:50
+#: ../raster3d/r3.out.vtk/main.c:168
#, fuzzy
-msgid "autocorrelation"
+msgid "Please provide three 3D raster maps for the xyz-vector maps [x,y,z]"
msgstr "출력할 격자지도"
-#: ../raster/r.random.cells/main.c:52
-msgid "Generates random cell values with spatial dependence."
+#: ../raster3d/r3.out.vtk/main.c:175
+msgid ""
+"No 3D raster data, RGB or xyz-vector maps are provided! Will only write the "
+"geometry."
msgstr ""
-#: ../raster/r.random.cells/main.c:62 ../raster/r.random.surface/main.c:77
-msgid "Maximum distance of spatial correlation (value >= 0.0)"
+#: ../raster3d/r3.out.vtk/main.c:209
+msgid "No RGB Data will be created."
msgstr ""
-#: ../raster/r.random.cells/main.c:70
+#: ../raster3d/r3.out.vtk/main.c:294
+msgid "No vector data will be created."
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:381
#, fuzzy
-msgid "Maximum number of cells to be created"
+msgid "Converts 3D raster maps into the VTK-ASCII format."
msgstr "출력할 격자지도"
-#: ../raster/r.random.cells/main.c:77
-msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default [random])"
+#: ../raster3d/r3.out.vtk/main.c:392
+msgid "failed to interpret dp as an integer"
msgstr ""
-#: ../raster/r.random.cells/random.c:50
-#, c-format
-msgid "RAN1: j == %d shouldn't happen"
+#: ../raster3d/r3.out.vtk/main.c:394 ../raster/r.out.ascii/main.c:116
+msgid "dp has to be from 0 to 20"
msgstr ""
-#: ../raster/r.what/main.c:99 ../raster/r.what.color/main.c:89
-#: ../locale/scriptstrings/i.spectral_to_translate.c:3
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:6
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:6
-#: ../display/d.where/main.c:46 ../vector/v.what.rast3/main.c:68
-#: ../vector/v.what/main.c:61 ../vector/v.what.rast/main.c:75
+#: ../raster3d/r3.out.vtk/main.c:542
#, fuzzy
-msgid "querying"
+msgid "Unable to close 3D raster map, the VTK file may be incomplete"
msgstr "출력할 격자지도"
-#: ../raster/r.what/main.c:100
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:5
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:5
-#: ../display/d.where/main.c:45 ../vector/v.what.rast3/main.c:67
-#: ../vector/v.what/main.c:62 ../vector/v.what.rast/main.c:74
+#: ../raster3d/r3.out.vtk/main.c:557
#, fuzzy
-msgid "position"
+msgid "Unable to close VTK-ASCII file"
msgstr "출력할 격자지도"
-#: ../raster/r.what/main.c:102
+#: ../raster3d/r3.out.vtk/errorHandling.c:105
#, fuzzy
-msgid "Queries raster maps on their category values and category labels."
+msgid "Unable to close input raster maps"
msgstr "출력할 격자지도"
-#: ../raster/r.what/main.c:106
-msgid "Name of existing raster map(s) to query"
+#: ../raster/r.mode/main.c:58
+msgid ""
+"Finds the mode of values in a cover map within areas assigned the same "
+"category value in a user-specified base map."
msgstr ""
-#: ../raster/r.what/main.c:109 ../vector/v.what/main.c:75
-msgid "Coordinates for query"
+#: ../raster/r.mode/main.c:64
+msgid "Base map to be reclassified"
msgstr ""
-#: ../raster/r.what/main.c:114
-#, fuzzy
-msgid "Name of vector points map for query"
-msgstr "출력할 격자지도"
+#: ../raster/r.mode/main.c:71
+msgid "Coverage map"
+msgstr ""
-#: ../raster/r.what/main.c:135
-msgid "Size of point cache"
+#: ../raster/r.mode/main.c:78
+msgid "Output map"
msgstr ""
-#: ../raster/r.what/main.c:137 ../raster/r.what/main.c:162
-#: ../display/d.legend/main.c:118 ../display/d.legend/main.c:128
-#: ../display/d.legend/main.c:136 ../display/d.legend/main.c:168
-#: ../display/d.legend/main.c:253 ../display/d.legend/main.c:258
-#: ../display/d.legend/main.c:268 ../display/d.legend/main.c:278
-#: ../display/d.legend/main.c:293
-msgid "Advanced"
-msgstr "고급"
+#: ../raster/r.mode/main.c:91
+#, fuzzy, c-format
+msgid "%s: Unable to read category labels"
+msgstr "출력할 격자지도"
-#: ../raster/r.what/main.c:141
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:11
-msgid "Output header row"
+#: ../raster/r.mode/read_stats.c:14
+msgid "reading r.stats output"
msgstr ""
-#: ../raster/r.what/main.c:146
+#: ../raster/r.thin/thin_lines.c:67
#, fuzzy
-msgid "Show the category labels of the grid cell(s)"
+msgid "Unable to find bounding box for lines"
msgstr "출력할 격자지도"
-#: ../raster/r.what/main.c:151
-msgid "Output color values as RRR:GGG:BBB"
+#: ../raster/r.thin/thin_lines.c:69
+#, c-format
+msgid "Bounding box: l = %d, r = %d, t = %d, b = %d"
msgstr ""
-#: ../raster/r.what/main.c:156
-msgid "Output integer category values, not cell values"
+#: ../raster/r.thin/thin_lines.c:116
+#, c-format
+msgid "Pass number %d"
msgstr ""
-#: ../raster/r.what/main.c:161
-msgid "Turn on cache reporting"
+#: ../raster/r.thin/thin_lines.c:167
+#, c-format
+msgid "Deleted %d pixel"
+msgid_plural "Deleted %d pixels"
+msgstr[0] ""
+#: ../raster/r.thin/thin_lines.c:171
+msgid "Thinning completed successfully."
msgstr ""
-#: ../raster/r.what/main.c:201
+#: ../raster/r.thin/thin_lines.c:173
+msgid "Thinning not completed, consider to increase 'iterations' parameter."
+msgstr ""
+#: ../raster/r.thin/main.c:60
+msgid "Thins non-null cells that denote linear features in a raster map layer."
+msgstr ""
+#: ../raster/r.thin/main.c:72
+msgid "Maximal number of iterations"
+msgstr ""
+#: ../raster/r.thin/io.c:98
+#, fuzzy
+msgid "Input raster must be of type CELL."
+msgstr "출력할 격자지도"
+#. GTC Count of raster rows
+#. GTC Count of window rows
+#: ../raster/r.thin/io.c:105 ../raster/r.thin/io.c:172
+#: ../raster/r.thin/io.c:181 ../display/d.rast.num/main.c:199
+#: ../vector/v.surf.idw/main.c:259 ../vector/v.kernel/main.c:303
+#, c-format
+msgid "%d row"
+msgid_plural "%d rows"
+msgstr[0] ""
+#. GTC Count of raster columns
+#. GTC Count of window columns
+#: ../raster/r.thin/io.c:107 ../raster/r.thin/io.c:174
+#: ../raster/r.thin/io.c:183 ../vector/v.surf.idw/main.c:261
+#: ../vector/v.kernel/main.c:304
#, fuzzy, c-format
-msgid "Can only do up to %d raster maps (%d given)"
+msgid "%d column"
+msgid_plural "%d columns"
+msgstr[0] "출력할 격자지도"
+#. GTC First argument is the raster map name, second and third - a string representing number of rows and cols
+#: ../raster/r.thin/io.c:109
+#, fuzzy, c-format
+msgid "Raster map <%s> - %s X %s"
msgstr "출력할 격자지도"
-#: ../raster/r.what/main.c:217
+#: ../raster/r.thin/io.c:122
#, fuzzy, c-format
-msgid "Unable to read category file for <%s>"
+msgid "Unable to create temporary file <%s> -- errno = %d"
msgstr "출력할 격자지도"
-#: ../raster/r.what/main.c:296
+#: ../raster/r.thin/io.c:131 ../raster/r.thin/io.c:138
+#: ../raster/r.thin/io.c:147 ../raster/r.resamp.rst/main.c:547
+#: ../vector/v.surf.rst/main.c:826
#, fuzzy, c-format
-msgid "Unable to read vector map <%s>"
+msgid "Error writing temporary file <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.what/main.c:300
-#, c-format
-msgid "Line %d is not point or centroid, skipped"
-msgstr "선 %d는 점이나 중심점이 아니므로 넘어갑니다"
+#. GTC %s will be replaced with number of rows and columns
+#: ../raster/r.thin/io.c:176
+#, fuzzy, c-format
+msgid "Output map %s X %s"
+msgstr "출력할 격자지도"
-#: ../raster/r.what/main.c:384
+#: ../raster/r.thin/io.c:185
#, c-format
-msgid "%s %s is outside your current region"
-msgstr "%s %s는 현재지역의 바깥입니다"
+msgid "Window %s X %s"
+msgstr ""
-#: ../raster/r.random.surface/init.c:73
-#, c-format
-msgid "High (%d) must be greater than 1"
+#: ../raster/r.reclass/reclass.c:51 ../raster/r.reclass/reclass.c:111
+msgid "Too many categories"
msgstr ""
-#: ../raster/r.random.surface/init.c:82
+#: ../raster/r.reclass/reclass.c:216
#, fuzzy, c-format
-msgid "Rastar map <%s> repeated, maps must be unique"
+msgid "Cannot read header file of <%s@%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.random.surface/init.c:92
+#: ../raster/r.reclass/reclass.c:234
+#, fuzzy, c-format
+msgid "Cannot overwrite existing raster map <%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.reclass/reclass.c:239
+#, fuzzy, c-format
+msgid "Cannot create reclass file of <%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.reclass/reclass.c:247
+#, fuzzy, c-format
+msgid "Cannot create raster map <%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.reclass/main.c:51 ../raster/r.recode/main.c:50
+#: ../vector/v.reclass/main.c:68
#, fuzzy
-msgid "Output raster map required"
+msgid "reclassification"
msgstr "출력할 격자지도"
-#: ../raster/r.random.surface/init.c:108
-#, c-format
-msgid "Seed (%d) larger than maximum (%d)"
+#: ../raster/r.reclass/main.c:52
+#, fuzzy
+msgid "Reclassify raster map based on category values."
+msgstr "출력할 격자지도"
+#: ../raster/r.reclass/main.c:54
+msgid ""
+"Creates a new raster map whose category values are based upon a "
+"reclassification of the categories in an existing raster map."
msgstr ""
-#: ../raster/r.random.surface/init.c:111 ../raster/r.random.surface/init.c:120
+#: ../raster/r.reclass/main.c:59
+#, fuzzy
+msgid "Name of raster map to be reclassified"
+msgstr "출력할 격자지도"
+#: ../raster/r.reclass/main.c:65
+msgid "File containing reclass rules"
+msgstr ""
+#: ../raster/r.reclass/main.c:72 ../raster/r.clump/main.c:75
+#: ../raster/r.neighbors/main.c:221 ../raster/r.recode/main.c:67
+#, fuzzy
+msgid "Title for output raster map"
+msgstr "출력할 격자지도"
+#: ../raster/r.reclass/main.c:83
+msgid "Input map can NOT be the same as output map"
+msgstr ""
+#: ../raster/r.reclass/main.c:89
+#, fuzzy, c-format
+msgid "Cannot open rules file <%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.reclass/main.c:103
#, c-format
-msgid " seed is set to %d"
+msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
msgstr ""
-#: ../raster/r.random.surface/init.c:116
+#: ../raster/r.reclass/main.c:105
#, c-format
-msgid "Seed (%d) smaller than minimum (%d)"
+msgid "FCELL: Data range is %.7g to %.7g\n"
msgstr ""
-#: ../raster/r.random.surface/init.c:159
+#: ../raster/r.reclass/main.c:108
#, c-format
-msgid "Distance value (%d): %lf must be >= 0.0"
+msgid "DCELL: Data range is %.15g to %.15g\n"
msgstr ""
-#: ../raster/r.random.surface/init.c:187
+#: ../raster/r.reclass/main.c:111
+#, fuzzy, c-format
+msgid "CELL: Data range is %ld to %ld\n"
+msgstr "출력할 격자지도"
+#: ../raster/r.reclass/main.c:119
#, c-format
-msgid "Exponent value (%lf) must be > 0.0"
+msgid "Illegal reclass rule -"
msgstr ""
-#: ../raster/r.random.surface/init.c:211
+#: ../raster/r.reclass/main.c:120
#, c-format
-msgid "Flat value (%lf) must be less than distance value (%lf)"
+msgid " ignored\n"
msgstr ""
-#: ../raster/r.random.surface/init.c:232
-msgid "Must have a distance value for each filter"
+#: ../raster/r.reclass/main.c:123
+msgid " - invalid reclass rule"
msgstr ""
-#: ../raster/r.random.surface/init.c:264
-msgid "Must have a exponent value for each filter"
+#: ../raster/r.reclass/main.c:139
+#, c-format
+msgid "No rules specified. Raster map <%s> not created"
msgstr ""
-#: ../raster/r.random.surface/init.c:281
-msgid "Must have a weight value for each filter"
+#: ../raster/r.reclass/main.c:142 ../raster/r.recode/main.c:99
+#: ../raster/r.quant/main.c:183
+msgid "No rules specified"
msgstr ""
-#: ../raster/r.random.surface/main.c:58 ../raster/r.surf.random/main.c:37
-#: ../raster/r.resamp.bspline/main.c:81 ../raster/r.surf.fractal/main.c:39
-#: ../raster/r.contour/main.c:88 ../raster/r.surf.area/main.c:77
-#: ../raster/r.surf.contour/main.c:61 ../raster/r.surf.idw/main.c:105
-#: ../raster/r.surf.gauss/main.c:39 ../vector/v.surf.idw/main.c:88
-#: ../vector/v.surf.rst/main.c:142 ../vector/v.surf.bspline/main.c:92
-#: ../vector/v.vol.rst/main.c:237
-msgid "surface"
+#: ../raster/r.reclass/parse.c:41 ../raster/r.colors/rules.c:104
+#, c-format
+msgid "Enter a rule in one of these formats:\n"
msgstr ""
-#: ../raster/r.random.surface/main.c:61
-msgid "Generates random surface(s) with spatial dependence."
+#: ../raster/r.reclass/parse.c:42
+msgid "poor quality"
msgstr ""
-#: ../raster/r.random.surface/main.c:68
-#, fuzzy
-msgid "Name for output raster map(s)"
-msgstr "출력할 격자지도"
-#: ../raster/r.random.surface/main.c:85
-msgid "Distance decay exponent (value > 0.0)"
+#: ../raster/r.reclass/parse.c:44
+msgid "medium quality"
msgstr ""
-#: ../raster/r.random.surface/main.c:94
-msgid "Distance filter remains flat before beginning exponent"
+#: ../raster/r.reclass/parse.c:59
+msgid "Can't have null on the left-hand side of the rule"
msgstr ""
-#: ../raster/r.random.surface/main.c:102
-msgid "Random seed (SEED_MIN >= value >= SEED_MAX), default [random]"
+#: ../raster/r.reclass/parse.c:88 ../raster/r.reclass/parse.c:100
+msgid "Can't have null on the right-hand side of the rule"
msgstr ""
-#: ../raster/r.random.surface/main.c:108
-msgid "Maximum cell value of distribution"
+#: ../raster/r.reclass/parse.c:196
+#, c-format
+msgid "%f rounded up to %d\n"
msgstr ""
-#: ../raster/r.random.surface/main.c:113
-msgid "Uniformly distributed cell values"
+#: ../raster/r.in.bin/main.c:61 ../raster/r.in.bin/main.c:70
+#: ../raster/r.in.bin/main.c:614
+msgid "Error reading data"
+msgstr "자료를 읽는 중 오류"
+#: ../raster/r.in.bin/main.c:260
+msgid "Import a binary raster file into a GRASS raster map layer."
msgstr ""
-#: ../raster/r.out.gridatb/main.c:70
-msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)."
+#: ../raster/r.in.bin/main.c:265
+msgid "Import as floating-point data (default: integer)"
msgstr ""
-#: ../raster/r.surf.random/main.c:40
-msgid ""
-"Produces a raster surface map of uniform random deviates with defined range."
+#: ../raster/r.in.bin/main.c:270
+msgid "Import as double-precision floating-point data (default: integer)"
msgstr ""
-#: ../raster/r.surf.random/main.c:46
-msgid "Minimum random value"
+#: ../raster/r.in.bin/main.c:279
+msgid "Byte swap the data during import"
msgstr ""
-#: ../raster/r.surf.random/main.c:52
-msgid "Maximum random value"
+#: ../raster/r.in.bin/main.c:284
+msgid "Get region info from GMT style header"
msgstr ""
-#: ../raster/r.surf.random/main.c:58
+#: ../raster/r.in.bin/main.c:288
#, fuzzy
-msgid "Create an integer raster map"
+msgid "Name of binary raster file to be imported"
msgstr "출력할 격자지도"
-#: ../raster/r.surf.random/main.c:66 ../raster/r.li/r.li.daemon/daemon.c:174
-#: ../raster/r.surf.fractal/main.c:85 ../raster/r.circle/main.c:153
-#: ../raster/r.composite/main.c:262
-#, c-format
-msgid "Raster map <%s> created."
-msgstr "격자지도 <%s>를 생성했습니다."
+#: ../raster/r.in.bin/main.c:291
+msgid "Output name or prefix if several bands are imported"
+msgstr ""
-#: ../raster/r.tile/main.c:46
+#: ../raster/r.in.bin/main.c:305 ../raster/r.out.bin/main.c:311
#, fuzzy
-msgid "Splits a raster map into tiles."
+msgid "Number of bytes per cell"
msgstr "출력할 격자지도"
-#: ../raster/r.tile/main.c:55
-#, fuzzy
-msgid "Output base name"
-msgstr "출력할 격자지도"
+#: ../raster/r.in.bin/main.c:313
+msgid "Header size in bytes"
+msgstr ""
-#: ../raster/r.tile/main.c:62
+#: ../raster/r.in.bin/main.c:321
#, fuzzy
-msgid "Width of tiles (columns)"
+msgid "Number of bands in input file"
msgstr "출력할 격자지도"
-#: ../raster/r.tile/main.c:69
-msgid "Height of tiles (rows)"
+#: ../raster/r.in.bin/main.c:322
+msgid "Bands must be in band-sequential order"
msgstr ""
-#: ../raster/r.tile/main.c:76
-#, fuzzy
-msgid "Overlap of tiles"
-msgstr "출력할 격자지도"
+#: ../raster/r.in.bin/main.c:392
+msgid "Flip input horizontal and/or vertical"
+msgstr ""
-#: ../raster/r.tile/main.c:129
+#: ../raster/r.in.bin/main.c:395
+msgid "Flip input horizontal (East - West)"
+msgstr ""
+#: ../raster/r.in.bin/main.c:396
+msgid "Flip input vertical (North - South)"
+msgstr ""
+#: ../raster/r.in.bin/main.c:410
#, fuzzy, c-format
-msgid "Generating %d x %d = %d tiles..."
+msgid "Option %s must be > 0"
msgstr "출력할 격자지도"
-#: ../raster/r.tile/main.c:184
+#: ../raster/r.in.bin/main.c:413
#, fuzzy, c-format
-msgid "Unable to read cats for %s"
+msgid "Option %s must be >= 0"
msgstr "출력할 격자지도"
-#: ../raster/r.tile/main.c:200 ../raster/r.resamp.filter/main.c:579
-#: ../raster/r.resamp.stats/main.c:389 ../raster/r.resamp.interp/main.c:370
+#: ../raster/r.in.bin/main.c:426 ../raster/r.in.bin/main.c:432
+#: ../raster/r.neighbors/main.c:262 ../raster/r.stats.quantile/main.c:588
+#: ../raster/r.out.bin/main.c:369
#, c-format
-msgid "Unable to read color table for %s"
+msgid "-%c and %s= are mutually exclusive"
+msgstr "-%c와 %s=를 같이 지정할 수 없습니다"
+#: ../raster/r.in.bin/main.c:435 ../raster/r.in.bin/main.c:438
+#, fuzzy, c-format
+msgid "Option %s= is ignored if -%c is set"
+msgstr "<%s> 옵션을 무시합니다"
+#: ../raster/r.in.bin/main.c:462 ../raster/r.out.bin/main.c:379
+#: ../vector/v.colors/main.c:225
+#, c-format
+msgid "-%c and -%c are mutually exclusive"
+msgstr "-%c와 -%c를 같이 지정할 수 없습니다"
+#: ../raster/r.in.bin/main.c:467
+#, c-format
+msgid "-%c incompatible with %s=%d; must be 4 or 8"
msgstr ""
-#: ../raster/r.topidx/file_io.c:35
+#: ../raster/r.in.bin/main.c:476
#, c-format
-msgid ""
-"The current region resolution [%s x %s] is finer than the input map's "
-"resolution [%s x %s]. The current region resolution must be identical to, or "
-"coarser than, the input map's resolution."
+msgid "-%c incompatible with %s=%d; must be 8"
msgstr ""
-#: ../raster/r.topidx/file_io.c:42
-#, fuzzy
-msgid "Reading elevation map..."
+#: ../raster/r.in.bin/main.c:484
+#, fuzzy, c-format
+msgid "%s= required for integer data"
msgstr "출력할 격자지도"
-#: ../raster/r.topidx/file_io.c:87
-#, fuzzy
-msgid "Writing topographic index map..."
+#: ../raster/r.in.bin/main.c:488
+#, c-format
+msgid "Integer input doesn't support %s=8 in this build"
+msgstr ""
+#: ../raster/r.in.bin/main.c:493
+#, fuzzy, c-format
+msgid "%s= must be 1, 2, 4 or 8"
msgstr "출력할 격자지도"
-#: ../raster/r.topidx/main.c:41
-msgid "wetness"
-msgstr ""
+#: ../raster/r.in.bin/main.c:506
+#, fuzzy, c-format
+msgid "Either -%c or %s= and %s= must be given"
+msgstr "출력할 격자지도"
-#: ../raster/r.topidx/main.c:43
-#, fuzzy
-msgid ""
-"Creates a topographic index (wetness index) raster map from an elevation "
-"raster map."
-msgstr "고도 격자지도로부터 위상색인 격자지도를 생성합니다."
+#: ../raster/r.in.bin/main.c:512
+#, fuzzy, c-format
+msgid "Either all or none of %s=, %s=, %s= and %s= must be given"
+msgstr "출력할 격자지도"
-#: ../raster/r.topidx/main.c:49
-msgid "Name for output topographic index raster map"
-msgstr "출력 위상색인 격자지도의 이름"
-#: ../raster/r.topidx/main.c:56 ../raster/r.gwflow/main.c:222
-#: ../raster/r.carve/main.c:213 ../raster/r.solute.transport/main.c:244
+#: ../raster/r.in.bin/main.c:554
#, c-format
-msgid "Lat/Long location is not supported by %s. Please reproject map first."
+msgid ""
+"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
+"significantly. Did you assign %s= and %s= correctly?"
msgstr ""
-#: ../raster/r.topidx/topidx.c:272
+#: ../raster/r.in.bin/main.c:575
+msgid "File Size %"
+msgstr ""
+#: ../raster/r.in.bin/main.c:595
#, fuzzy, c-format
-msgid "Number of sinks or boundaries: %d"
+msgid "Importing band %d..."
msgstr "출력할 격자지도"
-#: ../raster/r.rescale/main.c:49 ../raster/r.rescale.eq/main.c:53
+#: ../raster/r.out.png/main.c:116
#, fuzzy
-msgid "rescale"
+msgid "Export a GRASS raster map as a non-georeferenced PNG image."
msgstr "출력할 격자지도"
-#: ../raster/r.rescale/main.c:51
-msgid "Rescales the range of category values in a raster map layer."
-msgstr ""
+#: ../raster/r.out.png/main.c:122
+#, fuzzy
+msgid "Name for new PNG file (use '-' for stdout)"
+msgstr "출력할 격자지도"
-#: ../raster/r.rescale/main.c:56 ../raster/r.rescale.eq/main.c:61
-msgid "The name of the raster map to be rescaled"
-msgstr ""
+#: ../raster/r.out.png/main.c:130
+#, fuzzy
+msgid "Compression level of PNG file"
+msgstr "출력할 격자지도"
-#: ../raster/r.rescale/main.c:64 ../raster/r.rescale.eq/main.c:69
-msgid "The input data range to be rescaled (default: full range of input map)"
+#: ../raster/r.out.png/main.c:131
+msgid "(0 = none, 1 = fastest, 9 = best)"
msgstr ""
-#: ../raster/r.rescale/main.c:67 ../raster/r.rescale.eq/main.c:72
-msgid "The resulting raster map name"
+#: ../raster/r.out.png/main.c:138
+msgid "Make NULL cells transparent"
msgstr ""
-#: ../raster/r.rescale/main.c:74 ../raster/r.rescale.eq/main.c:79
-msgid "The output data range"
+#: ../raster/r.out.png/main.c:142
+msgid "Output world file"
msgstr ""
-#: ../raster/r.rescale/main.c:81 ../raster/r.rescale.eq/main.c:86
-msgid "Title for new raster map"
-msgstr ""
-#: ../raster/r.rescale/main.c:110
+#: ../raster/r.out.png/main.c:175 ../display/d.labels/color.c:68
+#: ../display/d.rast/display.c:27 ../display/d.graph/main.c:104
+#: ../display/d.graph/do_graph.c:105 ../display/d.graph/do_graph.c:355
+#: ../display/d.graph/do_graph.c:370 ../display/d.legend.vect/draw.c:198
+#: ../display/d.legend.vect/draw.c:209
#, c-format
-msgid "Rescale %s[%ld,%ld] to %s[%ld,%ld]"
+msgid "[%s]: No such color"
msgstr ""
-#: ../raster/r.rescale/get_range.c:24 ../raster/r.rescale.eq/get_stats.c:19
-#, c-format
-msgid "Reading %s ..."
-msgstr ""
+#: ../raster/r.out.png/main.c:257
+#, fuzzy, c-format
+msgid "Converting <%s>..."
+msgstr "출력할 격자지도"
-#: ../raster/r.thin/main.c:58 ../raster/r.circle/main.c:53
-#: ../raster/r.to.vect/main.c:78 ../raster/r.patch/main.c:59
-#: ../locale/scriptstrings/v.report_to_translate.c:3
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:3
-#: ../locale/scriptstrings/v.to.lines_to_translate.c:3
-#: ../vector/v.transform/main.c:71 ../vector/v.segment/main.c:61
-#: ../vector/v.overlay/main.c:64 ../vector/v.drape/main.c:57
-#: ../vector/v.type/main.c:39 ../vector/v.hull/main.c:53
-#: ../vector/v.perturb/main.c:63 ../vector/v.voronoi/main.c:124
-#: ../vector/v.clean/main.c:53 ../vector/v.delaunay/main.c:86
-#: ../vector/v.build.polylines/main.c:113 ../vector/v.in.region/main.c:42
-#: ../vector/v.edit/main.c:55 ../vector/v.mkgrid/main.c:71
-#: ../vector/v.to.points/main.c:54 ../vector/v.buffer/main.c:225
-#: ../vector/v.select/main.c:49 ../vector/v.patch/main.c:70
-#: ../vector/v.build/main.c:38 ../vector/v.split/main.c:55
-#: ../vector/v.parallel/main.c:50 ../vector/v.to.3d/main.c:37
-#: ../vector/v.extrude/main.c:68 ../vector/v.univar/main.c:96
-msgid "geometry"
-msgstr "지형"
+#: ../raster/r.out.png/main.c:272 ../raster/r.univar/r.univar_main.c:201
+#, fuzzy, c-format
+msgid "Raster <%s> type mismatch"
+msgstr "출력할 격자지도"
-#: ../raster/r.thin/main.c:60
-msgid "Thins non-null cells that denote linear features in a raster map layer."
+#: ../raster/r.out.png/main.c:422
+#, fuzzy
+msgid "Writing world file"
+msgstr "출력할 격자지도"
+#: ../raster/r.out.png/main.c:425
+msgid "Got null file name"
msgstr ""
-#: ../raster/r.thin/main.c:72
-msgid "Maximal number of iterations"
+#: ../raster/r.out.png/main.c:427
+msgid "Got null region struct"
msgstr ""
-#: ../raster/r.thin/io.c:98
+#: ../raster/r.out.png/main.c:429
#, fuzzy
-msgid "Input raster must be of type CELL."
+msgid "Unable to open world file for writing"
msgstr "출력할 격자지도"
-#. GTC Count of raster rows
-#. GTC Count of window rows
-#: ../raster/r.thin/io.c:105 ../raster/r.thin/io.c:172
-#: ../raster/r.thin/io.c:181 ../display/d.rast.num/main.c:199
-#: ../vector/v.surf.idw/main.c:259 ../vector/v.kernel/main.c:303
-#, c-format
-msgid "%d row"
-msgid_plural "%d rows"
-msgstr[0] ""
-msgstr[1] ""
+#: ../raster/r.in.xyz/main.c:167
+msgid ""
+"Creates a raster map from an assemblage of many coordinates using univariate "
+"statistics."
+msgstr ""
-#. GTC Count of raster columns
-#. GTC Count of window columns
-#: ../raster/r.thin/io.c:107 ../raster/r.thin/io.c:174
-#: ../raster/r.thin/io.c:183 ../vector/v.surf.idw/main.c:261
-#: ../vector/v.kernel/main.c:304
-#, fuzzy, c-format
-msgid "%d column"
-msgid_plural "%d columns"
+#: ../raster/r.in.xyz/main.c:171
+msgid "ASCII file containing input data (or \"-\" to read from stdin)"
+msgstr ""
-#. GTC First argument is the raster map name, second and third - a string representing number of rows and cols
-#: ../raster/r.thin/io.c:109
-#, fuzzy, c-format
-msgid "Raster map <%s> - %s X %s"
+#: ../raster/r.in.xyz/main.c:198 ../raster/r.in.lidar/main.c:158
+#, fuzzy
+msgid "Number of points in cell"
msgstr "출력할 격자지도"
-#: ../raster/r.thin/io.c:122
-#, fuzzy, c-format
-msgid "Unable to create temporary file <%s> -- errno = %d"
+#: ../raster/r.in.xyz/main.c:199 ../raster/r.in.lidar/main.c:159
+#, fuzzy
+msgid "Minimum value of point values in cell"
msgstr "출력할 격자지도"
-#: ../raster/r.thin/io.c:131 ../raster/r.thin/io.c:138
-#: ../raster/r.thin/io.c:147 ../raster/r.resamp.rst/main.c:547
-#: ../vector/v.surf.rst/main.c:826
-#, fuzzy, c-format
-msgid "Error writing temporary file <%s>"
+#: ../raster/r.in.xyz/main.c:200 ../raster/r.in.lidar/main.c:160
+#, fuzzy
+msgid "Maximum value of point values in cell"
msgstr "출력할 격자지도"
-#. GTC %s will be replaced with number of rows and columns
-#: ../raster/r.thin/io.c:176
-#, fuzzy, c-format
-msgid "Output map %s X %s"
+#: ../raster/r.in.xyz/main.c:201 ../raster/r.in.lidar/main.c:161
+#, fuzzy
+msgid "Range of point values in cell"
msgstr "출력할 격자지도"
-#: ../raster/r.thin/io.c:185
-#, c-format
-msgid "Window %s X %s"
-msgstr ""
-#: ../raster/r.thin/thin_lines.c:67
+#: ../raster/r.in.xyz/main.c:202 ../raster/r.in.lidar/main.c:162
#, fuzzy
-msgid "Unable to find bounding box for lines"
+msgid "Sum of point values in cell"
msgstr "출력할 격자지도"
-#: ../raster/r.thin/thin_lines.c:69
-#, c-format
-msgid "Bounding box: l = %d, r = %d, t = %d, b = %d"
+#: ../raster/r.in.xyz/main.c:203 ../raster/r.in.lidar/main.c:163
+msgid "Mean (average) value of point values in cell"
msgstr ""
-#: ../raster/r.thin/thin_lines.c:116
-#, c-format
-msgid "Pass number %d"
+#: ../raster/r.in.xyz/main.c:204 ../raster/r.in.lidar/main.c:164
+msgid "Standard deviation of point values in cell"
msgstr ""
-#: ../raster/r.thin/thin_lines.c:167
-#, c-format
-msgid "Deleted %d pixel"
-msgid_plural "Deleted %d pixels"
-msgstr[0] ""
-msgstr[1] ""
+#: ../raster/r.in.xyz/main.c:205 ../raster/r.in.lidar/main.c:165
+#, fuzzy
+msgid "Variance of point values in cell"
+msgstr "출력할 격자지도"
-#: ../raster/r.thin/thin_lines.c:171
-msgid "Thinning completed successfully."
+#: ../raster/r.in.xyz/main.c:206 ../raster/r.in.lidar/main.c:166
+msgid "Coefficient of variance of point values in cell"
msgstr ""
-#: ../raster/r.thin/thin_lines.c:173
-msgid "Thinning not completed, consider to increase 'iterations' parameter."
-msgstr ""
+#: ../raster/r.in.xyz/main.c:207 ../raster/r.in.lidar/main.c:167
+#, fuzzy
+msgid "Median value of point values in cell"
+msgstr "출력할 격자지도"
-#: ../raster/r.sun/main.c:240 ../raster/r.horizon/main.c:181
-#: ../raster/r.sunhours/main.c:73 ../raster/r.sunmask/main.c:117
-msgid "solar"
+#: ../raster/r.in.xyz/main.c:208 ../raster/r.in.lidar/main.c:168
+msgid "pth (nth) percentile of point values in cell"
msgstr ""
-#: ../raster/r.sun/main.c:241 ../raster/r.sunhours/main.c:74
-msgid "sun energy"
-msgstr ""
+#: ../raster/r.in.xyz/main.c:209 ../raster/r.in.lidar/main.c:169
+#, fuzzy
+msgid "Skewness of point values in cell"
+msgstr "출력할 격자지도"
-#: ../raster/r.sun/main.c:242 ../raster/r.sunmask/main.c:119
-msgid "shadow"
-msgstr ""
+#: ../raster/r.in.xyz/main.c:210 ../raster/r.in.lidar/main.c:170
+#, fuzzy
+msgid "Trimmed mean of point values in cell"
+msgstr "출력할 격자지도"
-#: ../raster/r.sun/main.c:243
-msgid "Solar irradiance and irradiation model."
-msgstr ""
-#: ../raster/r.sun/main.c:245
+#: ../raster/r.in.xyz/main.c:243
msgid ""
-"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
-"for given day, latitude, surface and atmospheric conditions. Solar "
-"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
-"irradiance, daylight length) are saved in the map history file. "
-"Alternatively, a local time can be specified to compute solar incidence "
-"angle and/or irradiance raster maps. The shadowing effect of the topography "
-"is optionally incorporated."
+"If a separate value column is given, this option refers to the z-coordinate "
+"column to be filtered by the zrange option"
msgstr ""
-#: ../raster/r.sun/main.c:259
-msgid "Name of the input elevation raster map [meters]"
+#: ../raster/r.in.xyz/main.c:254
+#, fuzzy
+msgid "Number of header lines to skip at top of input file"
+msgstr "출력할 격자지도"
+#: ../raster/r.in.xyz/main.c:262 ../vector/v.decimate/main.c:146
+#: ../vector/v.in.lidar/main.c:194
+msgid "Filter range for z data (min,max)"
msgstr ""
-#: ../raster/r.sun/main.c:268
-msgid ""
-"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
-"[decimal degrees]"
+#: ../raster/r.in.xyz/main.c:263 ../raster/r.in.xyz/main.c:271
+#: ../raster/r.in.xyz/main.c:280 ../raster/r.in.xyz/main.c:288
+#: ../raster/r.in.xyz/main.c:296
+msgid "Advanced Input"
msgstr ""
-#: ../raster/r.sun/main.c:277
-msgid "A single value of the orientation (aspect), 270 is south"
+#: ../raster/r.in.xyz/main.c:270
+msgid "Scale to apply to z data"
msgstr ""
-#: ../raster/r.sun/main.c:286
-msgid ""
-"Name of the input slope raster map (terrain slope or solar panel "
-"inclination) [decimal degrees]"
+#: ../raster/r.in.xyz/main.c:278
+#, fuzzy
+msgid "Alternate column number of data values in input file"
+msgstr "출력할 격자지도"
+#: ../raster/r.in.xyz/main.c:279
+msgid "If not given (or set to 0) the z-column data is used"
msgstr ""
-#: ../raster/r.sun/main.c:294
-msgid "A single value of inclination (slope)"
+#: ../raster/r.in.xyz/main.c:287
+msgid "Filter range for alternate value column data (min,max)"
msgstr ""
-#: ../raster/r.sun/main.c:303
-msgid ""
-"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
+#: ../raster/r.in.xyz/main.c:295
+msgid "Scale to apply to alternate value column data"
msgstr ""
-#: ../raster/r.sun/main.c:312
-msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
+#: ../raster/r.in.xyz/main.c:357
+msgid "Please specify a reasonable column number."
msgstr ""
-#: ../raster/r.sun/main.c:321
-msgid "Name of the ground albedo coefficient input raster map [-]"
+#: ../raster/r.in.xyz/main.c:369 ../vector/v.in.ascii/main.c:218
+msgid "Please specify reasonable number of lines to skip"
msgstr ""
-#: ../raster/r.sun/main.c:330
-msgid "A single value of the ground albedo coefficient [-]"
+#: ../raster/r.in.xyz/main.c:374 ../raster/r.in.lidar/main.c:477
+msgid "Invalid zrange"
msgstr ""
-#: ../raster/r.sun/main.c:339
+#: ../raster/r.in.xyz/main.c:388
#, fuzzy
-msgid "Name of input raster map containing latitudes [decimal degrees]"
+msgid "Invalid vrange"
msgstr "출력할 격자지도"
-#: ../raster/r.sun/main.c:348
-#, fuzzy
-msgid "Name of input raster map containing longitudes [decimal degrees]"
-msgstr "출력할 격자지도"
-#: ../raster/r.sun/main.c:357
-#, fuzzy
-msgid ""
-"Name of real-sky beam radiation coefficient (thick cloud) input raster map "
-"[0-1]"
-msgstr "출력할 격자지도"
-#: ../raster/r.sun/main.c:366
-#, fuzzy
-msgid ""
-"Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
-msgstr "출력할 격자지도"
-#: ../raster/r.sun/main.c:373
-#, fuzzy
-msgid "The horizon information input map basename"
-msgstr "투영정보가 갱신되지 않을 겁니다"
-#: ../raster/r.sun/main.c:381 ../raster/r.horizon/main.c:211
-msgid "Angle step size for multidirectional horizon [degrees]"
+#: ../raster/r.in.xyz/main.c:474 ../raster/r.in.lidar/point_binning.c:205
+msgid "Unable to calculate percentile without the pth option specified!"
msgstr ""
-#: ../raster/r.sun/main.c:390
-msgid "Output incidence angle raster map (mode 1 only)"
+#: ../raster/r.in.xyz/main.c:486 ../raster/r.in.lidar/point_binning.c:217
+msgid "Unable to calculate trimmed mean without the trim option specified!"
msgstr ""
-#: ../raster/r.sun/main.c:399
+#: ../raster/r.in.xyz/main.c:527
+#, c-format
msgid ""
-"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
+"Unable to process the hole map at once. Please set the %s option to some "
+"value lower than 100."
msgstr ""
-#: ../raster/r.sun/main.c:408
+#: ../raster/r.in.xyz/main.c:580
msgid ""
-"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
+"If input is not from a file it is only possible to perform a single pass."
msgstr ""
-#: ../raster/r.sun/main.c:417
-msgid ""
-"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
-"map [Wh.m-2.day-1] (mode 2)"
+#: ../raster/r.in.xyz/main.c:592
+msgid "Range filters will not be taken into account during scan"
msgstr ""
-#: ../raster/r.sun/main.c:426
-msgid ""
-"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/"
-"irradiation raster map [Wh.m-2.day-1] (mode 2)"
+#: ../raster/r.in.xyz/main.c:629
+#, fuzzy
+msgid "Reading input data..."
+msgstr "출력할 격자지도"
+#: ../raster/r.in.xyz/main.c:636 ../raster/r.in.poly/poly2rast.c:56
+#: ../raster/r.in.lidar/main.c:614
+#, c-format
+msgid "Pass #%d (of %d) ..."
msgstr ""
-#: ../raster/r.sun/main.c:435
-msgid "Output insolation time raster map [h] (mode 2 only)"
+#: ../raster/r.in.xyz/main.c:712 ../raster/r.in.xyz/main.c:720
+#: ../raster/r.in.xyz/main.c:1213 ../raster/r.in.xyz/main.c:1221
+#, c-format
+msgid ""
+"Not enough data columns. Incorrect delimiter or column number? Found the "
+"following character(s) in row %lu:\n"
+"[%s]"
msgstr ""
-#: ../raster/r.sun/main.c:442
-msgid "No. of day of the year (1-365)"
+#: ../raster/r.in.xyz/main.c:716 ../raster/r.in.xyz/main.c:1217
+msgid "Line ignored as requested"
msgstr ""
-#: ../raster/r.sun/main.c:452
-msgid "Time step when computing all-day radiation sums [decimal hours]"
+#: ../raster/r.in.xyz/main.c:735 ../raster/r.in.xyz/main.c:1251
+#, c-format
+msgid "Bad y-coordinate line %lu column %d. <%s>"
msgstr ""
-#: ../raster/r.sun/main.c:460
-msgid "Declination value (overriding the internally computed value) [radians]"
+#: ../raster/r.in.xyz/main.c:742 ../raster/r.in.xyz/main.c:1236
+#, c-format
+msgid "Bad x-coordinate line %lu column %d. <%s>"
msgstr ""
-#: ../raster/r.sun/main.c:468
-msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
+#: ../raster/r.in.xyz/main.c:760 ../raster/r.in.xyz/main.c:1266
+#, c-format
+msgid "Bad z-coordinate line %lu column %d. <%s>"
msgstr ""
-#: ../raster/r.sun/main.c:492 ../raster/r.horizon/main.c:296
-msgid "Sampling distance step coefficient (0.5-1.5)"
+#: ../raster/r.in.xyz/main.c:773 ../raster/r.in.xyz/main.c:1284
+#, fuzzy, c-format
+msgid "Bad data value line %lu column %d. <%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.in.xyz/main.c:829
+#, fuzzy
+msgid "Writing to output raster map..."
+msgstr "출력할 격자지도"
+#: ../raster/r.in.xyz/main.c:1169
+#, fuzzy, c-format
+msgid "%lu points found in region."
+msgstr "출력할 격자지도"
+#: ../raster/r.univar/r3.univar_main.c:37
+msgid "3D Raster map used for zoning, must be of type CELL"
msgstr ""
-#: ../raster/r.sun/main.c:500
-msgid "Read the input files in this number of chunks"
+#: ../raster/r.univar/r3.univar_main.c:59 ../raster/r.univar/r.univar_main.c:61
+#: ../vector/v.univar/main.c:126 ../vector/v.what/main.c:98
+msgid "Print the stats in shell script style"
msgstr ""
-#: ../raster/r.sun/main.c:507
-msgid "Civil time zone value, if none, the time will be local solar time"
+#: ../raster/r.univar/r3.univar_main.c:67 ../raster/r.univar/r.univar_main.c:71
+msgid "Table output format instead of standard output format"
msgstr ""
-#: ../raster/r.sun/main.c:513
-msgid "Do not incorporate the shadowing effect of terrain"
+#: ../raster/r.univar/r3.univar_main.c:103
+#, fuzzy
+msgid ""
+"Calculates univariate statistics from the non-null cells of a 3D raster map."
+msgstr "출력할 격자지도"
+#: ../raster/r.univar/r3.univar_main.c:105
+#: ../raster/r.univar/r.univar_main.c:112
+msgid ""
+"Statistics include number of cells counted, minimum and maximum cell values, "
+"range, arithmetic mean, population variance, standard deviation, coefficient "
+"of variation, and sum."
msgstr ""
-#: ../raster/r.sun/main.c:518
-msgid "Use the low-memory version of the program"
+#: ../raster/r.univar/r3.univar_main.c:128
+#: ../raster/r.univar/r.univar_main.c:129 ../raster/r.stats.quantile/main.c:319
+#: ../raster/r.regression.line/main.c:77 ../raster/r.what/main.c:170
+#: ../raster/r.stats/main.c:227 ../raster/r.regression.multi/main.c:169
+#: ../vector/v.db.select/main.c:126 ../db/db.select/main.c:142
+#, fuzzy, c-format
+msgid "Unable to open file <%s> for writing"
+msgstr "출력할 격자지도"
+#: ../raster/r.univar/r.univar_main.c:36
+msgid "Raster map used for zoning, must be of type CELL"
msgstr ""
-#: ../raster/r.sun/main.c:559
-msgid "You must give the longitude raster if you use civil time"
+#: ../raster/r.univar/r.univar_main.c:53 ../raster/r.univar/r.univar_main.c:67
+msgid "Extended"
msgstr ""
-#: ../raster/r.sun/main.c:562
+#: ../raster/r.univar/r.univar_main.c:76
#, fuzzy
-msgid "Error reading civil time zone value"
+msgid ""
+"Use the native resolution and extent of the raster map, instead of the "
+"current region"
msgstr "출력할 격자지도"
-#: ../raster/r.sun/main.c:565
-msgid "Invalid civil time zone value"
+#: ../raster/r.univar/r.univar_main.c:110
+msgid ""
+"Calculates univariate statistics from the non-null cells of a raster map."
msgstr ""
-#: ../raster/r.sun/main.c:590
-msgid "insol_time and incidout are incompatible options"
+#: ../raster/r.univar/r.univar_main.c:123
+#, fuzzy
+msgid "zones option and region flag -r are mutually exclusive"
+#: ../raster/r.surf.area/main.c:77 ../raster/r.resamp.bspline/main.c:81
+#: ../raster/r.surf.contour/main.c:61 ../raster/r.surf.fractal/main.c:39
+#: ../raster/r.surf.random/main.c:37 ../raster/r.surf.idw/main.c:105
+#: ../raster/r.surf.gauss/main.c:39 ../raster/r.contour/main.c:88
+#: ../raster/r.random.surface/main.c:58 ../vector/v.surf.rst/main.c:142
+#: ../vector/v.surf.idw/main.c:88 ../vector/v.vol.rst/main.c:237
+#: ../vector/v.surf.bspline/main.c:92
+msgid "surface"
msgstr ""
-#: ../raster/r.sun/main.c:595
+#: ../raster/r.surf.area/main.c:79
#, fuzzy
-msgid "Error reading time step size"
+msgid "area estimation"
msgstr "출력할 격자지도"
-#: ../raster/r.sun/main.c:597
+#: ../raster/r.surf.area/main.c:80
#, fuzzy
-msgid "Invalid time step size"
+msgid "Prints estimation of surface area for raster map."
msgstr "출력할 격자지도"
-#: ../raster/r.sun/main.c:601
+#: ../raster/r.surf.area/main.c:89
+msgid "Vertical scale"
+msgstr ""
+#: ../raster/r.surf.area/main.c:93
#, fuzzy
-msgid "Error reading horizon step size"
+msgid "Output units"
msgstr "출력할 격자지도"
-#: ../raster/r.sun/main.c:606
-msgid "The horizon step size must be greater than 0."
+#: ../raster/r.surf.area/main.c:94
+msgid "Default: square map units"
msgstr ""
-#: ../raster/r.sun/main.c:609
-msgid ""
-"If you use the horizon option you must also set the 'horizonstep' parameter."
+#: ../raster/r.surf.area/main.c:102
+#, fuzzy, c-format
+msgid "Output in '%s'"
+msgstr "출력할 격자지도"
+#: ../raster/r.surf.area/main.c:106
+msgid "Output in 'square map units'"
msgstr ""
-#: ../raster/r.sun/main.c:615
-msgid "Time and insol_time are incompatible options"
+#: ../raster/r.surf.area/main.c:153
+msgid "Null value area ignored in calculation:"
msgstr ""
-#: ../raster/r.sun/main.c:617
-msgid ""
-"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
-"time"
+#: ../raster/r.surf.area/main.c:155
+msgid "Plan area used in calculation:"
msgstr ""
-#: ../raster/r.sun/main.c:622
-msgid "incidout requires time parameter to be set"
+#: ../raster/r.surf.area/main.c:158
+msgid "Surface area calculation(low, high, avg):"
msgstr ""
-#: ../raster/r.sun/main.c:624
-msgid "Mode 2: integrated daily irradiation for a given day of the year"
+#: ../raster/r.surf.area/main.c:163
+msgid "Current region plan area:"
msgstr ""
-#: ../raster/r.sun/main.c:647
+#: ../raster/r.surf.area/main.c:165
+msgid "Estimated region Surface Area:"
+msgstr ""
+#: ../raster/r.in.png/main.c:297
#, fuzzy, c-format
-msgid "Using Linke constant: %lf"
+msgid "Unable to open PNG file '%s'"
msgstr "출력할 격자지도"
-#: ../raster/r.sun/main.c:649
-#, fuzzy, c-format
-msgid "Using Linke map <%s>"
+#: ../raster/r.in.png/main.c:300
+msgid "Input file empty or too short"
+msgstr ""
+#: ../raster/r.in.png/main.c:303
+msgid "Input file not a PNG file"
+msgstr ""
+#: ../raster/r.in.png/main.c:314
+msgid "PNG error"
+msgstr ""
+#: ../raster/r.in.png/main.c:485 ../raster/r.cross/main.c:169
+#: ../raster/r.resample/main.c:125 ../raster/r.basins.fill/main.c:146
+#, c-format
+msgid "Creating support files for <%s>..."
+msgstr "<%s>를 위한 지원파일을 생성합니다..."
+#: ../raster/r.in.png/main.c:522
+#, fuzzy
+msgid "Imports non-georeferenced PNG format image."
msgstr "출력할 격자지도"
-#: ../raster/r.sun/main.c:654
-#, c-format
-msgid "Using albedo constant: %lf"
+#: ../raster/r.in.png/main.c:532
+#, fuzzy
+msgid "Title for created raster map"
+msgstr "출력할 격자지도"
+#: ../raster/r.in.png/main.c:538
+#, fuzzy
+msgid "Display gamma"
+msgstr "출력할 격자지도"
+#: ../raster/r.in.png/main.c:544
+msgid "Alpha threshold"
msgstr ""
-#: ../raster/r.sun/main.c:656
-#, fuzzy, c-format
-msgid "Using albedo map <%s>"
+#: ../raster/r.in.png/main.c:548
+#, fuzzy
+msgid "Create floating-point map (0.0 - 1.0)"
msgstr "출력할 격자지도"
-#: ../raster/r.sun/main.c:661
-#, fuzzy, c-format
-msgid "Using slope constant: %lf"
+#: ../raster/r.in.png/main.c:552
+#, fuzzy
+msgid "Output image file header only and exit"
msgstr "출력할 격자지도"
-#: ../raster/r.sun/main.c:664
+#: ../raster/r.in.poly/get_item.c:97
#, fuzzy, c-format
-msgid "Using slope map <%s>"
+msgid "Illegal coordinate <%s, %s>, skipping."
msgstr "출력할 격자지도"
-#: ../raster/r.sun/main.c:669
+#: ../raster/r.in.poly/get_item.c:102
#, fuzzy, c-format
-msgid "Using aspect constant: %lf"
+msgid "Illegal north coordinate <%s>, skipping."
msgstr "출력할 격자지도"
-#: ../raster/r.sun/main.c:672
+#: ../raster/r.in.poly/get_item.c:107
#, fuzzy, c-format
-msgid "Using aspect map <%s>"
+msgid "Illegal east coordinate <%s>, skipping."
msgstr "출력할 격자지도"
-#: ../raster/r.sun/main.c:687
-msgid "If you use -s and no horizon rasters, numpartitions must be =1"
+#: ../raster/r.in.poly/main.c:37
+msgid "Creates raster maps from ASCII polygon/line/point data files."
msgstr ""
-#: ../raster/r.sun/main.c:700
-msgid ""
-"If you want to save memory and to use shadows, you must use pre-calculated "
-"horizons."
-msgstr ""
+#: ../raster/r.in.poly/main.c:41
+#, fuzzy
+msgid "Name of input file; or \"-\" to read from stdin"
+msgstr "출력할 격자지도"
-#: ../raster/r.sun/main.c:745 ../raster/r.horizon/main.c:531
-#: ../display/d.where/main.c:107 ../general/g.region/printwindow.c:241
-#: ../general/g.region/printwindow.c:497 ../general/g.region/printwindow.c:616
-msgid "Can't get projection info of current location"
-msgstr ""
+#: ../raster/r.in.poly/main.c:60
+#, fuzzy
+msgid "Integer representing NULL value data cell"
+msgstr "자료 없는 셀값을 표현할 문자열"
-#: ../raster/r.sun/main.c:749 ../raster/r.horizon/main.c:534
-#: ../display/d.where/main.c:110 ../general/g.region/printwindow.c:244
-#: ../general/g.region/printwindow.c:500 ../general/g.region/printwindow.c:619
-msgid "Can't get projection units of current location"
+#: ../raster/r.in.poly/main.c:66
+msgid "Number of rows to hold in memory"
msgstr ""
-#: ../raster/r.sun/main.c:767
-msgid "latin and longin raster maps have no effect when in a Lat/Lon location"
+#: ../raster/r.in.poly/main.c:74
+msgid "Minimum number of rows to hold in memory is 1"
msgstr ""
-#: ../raster/r.sun/main.c:772
-msgid "Both latin and longin raster maps must be given, or neither"
-msgstr ""
+#: ../raster/r.in.poly/main.c:83
+#, fuzzy
+msgid "Type doesn't exist"
+msgstr "출력할 격자지도"
-#: ../raster/r.to.rast3/main.c:59 ../raster/r.to.rast3elev/main.c:136
-msgid "Could not close the map"
-msgstr ""
+#: ../raster/r.in.poly/poly2rast.c:81 ../raster/r.carve/raster.c:33
+#: ../vector/v.to.rast/vect2rast.c:179
+#, fuzzy
+msgid "Writing raster map..."
+msgstr "출력할 격자지도"
-#: ../raster/r.to.rast3/main.c:79
+#: ../raster/r.texture/main.c:67
+#, fuzzy, c-format
+msgid "Unknown measure <%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.texture/main.c:104
#, fuzzy
-msgid "2D raster maps which represent the slices"
+msgid "texture"
msgstr "출력할 격자지도"
-#: ../raster/r.to.rast3/main.c:84 ../raster/r.to.rast3elev/main.c:175
-msgid "The maximum tile size in kilo bytes. Default is 32KB."
+#: ../raster/r.texture/main.c:106
+msgid "Generate images with textural features from a raster map."
msgstr ""
-#: ../raster/r.to.rast3/main.c:93
-msgid "Use 3D raster mask (if exists) with output map"
+#: ../raster/r.texture/main.c:120
+msgid "The size of moving window (odd and >= 3)"
msgstr ""
-#: ../raster/r.to.rast3/main.c:201
-msgid "Converts 2D raster map slices to one 3D raster volume map."
+#: ../raster/r.texture/main.c:130
+msgid "The distance between two samples (>= 1)"
msgstr ""
-#: ../raster/r.to.rast3/main.c:213
-msgid "No output map"
-msgstr ""
+#: ../raster/r.texture/main.c:146
+#, fuzzy
+msgid "Textural measurement method"
+msgstr "출력할 격자지도"
-#: ../raster/r.to.rast3/main.c:230
-msgid ""
-"The 2D and 3D region settings are different. Using the 3D region settings to "
-"adjust the 2D region."
+#: ../raster/r.texture/main.c:150
+msgid "Separate output for each angle (0, 45, 90, 135)"
msgstr ""
-#: ../raster/r.to.rast3/main.c:262
-#, c-format
-msgid "Open raster map %s - one time for each depth (%d/%d)"
+#: ../raster/r.texture/main.c:154
+#, fuzzy
+msgid "Calculate all textural measurements"
+msgstr "출력할 격자지도"
+#: ../raster/r.texture/main.c:163
+msgid "Size of the moving window must be > 0"
msgstr ""
-#: ../raster/r.to.rast3/main.c:275
-msgid "Input maps have to be from the same type. CELL, FCELL or DCELL!"
+#: ../raster/r.texture/main.c:165
+msgid "Size of the moving window must be odd"
msgstr ""
-#: ../raster/r.to.rast3/main.c:279 ../raster/r.to.rast3elev/main.c:457
-msgid "Creating 3D raster map"
+#: ../raster/r.texture/main.c:168
+msgid "The distance between two samples must be > 0"
msgstr ""
-#: ../raster/r.to.rast3/main.c:291 ../raster/r.to.rast3elev/main.c:443
-#, fuzzy
-msgid "Error opening 3D raster map"
-msgstr "출력할 격자지도"
-#: ../raster/r.to.rast3/main.c:326 ../raster/r.to.rast3elev/main.c:501
-msgid "Error closing 3d raster map"
+#: ../raster/r.texture/main.c:189
+msgid "Nothing to compute. Use at least one textural measure."
msgstr ""
-#: ../raster/r.out.png/main.c:116
+#: ../raster/r.texture/main.c:288 ../raster/r.carve/raster.c:13
+#: ../imagery/i.zc/main.c:152
#, fuzzy
-msgid "Export a GRASS raster map as a non-georeferenced PNG image."
+msgid "Reading raster map..."
msgstr "출력할 격자지도"
-#: ../raster/r.out.png/main.c:122
-#, fuzzy
-msgid "Name for new PNG file (use '-' for stdout)"
-msgstr "출력할 격자지도"
+#: ../raster/r.texture/main.c:327
+#, fuzzy, c-format
+msgid "Calculating %d texture measure"
+msgid_plural "Calculating %d texture measures"
-#: ../raster/r.out.png/main.c:130
-#, fuzzy
-msgid "Compression level of PNG file"
+#: ../raster/r.texture/main.c:330
+#, fuzzy, c-format
+msgid "Calculating %s"
msgstr "출력할 격자지도"
-#: ../raster/r.out.png/main.c:131
-msgid "(0 = none, 1 = fastest, 9 = best)"
+#: ../raster/r.texture/h_measure.c:123
+#, c-format
+msgid ""
+"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
+"map"
msgstr ""
-#: ../raster/r.out.png/main.c:138
-msgid "Make NULL cells transparent"
+#: ../raster/r.texture/h_measure.c:594 ../raster/r.walk/main.c:808
+#: ../raster/r.cost/main.c:673 ../raster/r.stream.extract/load.c:44
+#: ../raster/r.stream.extract/load.c:53 ../imagery/i.smap/interp.c:68
+msgid "Unable to allocate memory"
msgstr ""
-#: ../raster/r.out.png/main.c:142
-msgid "Output world file"
-msgstr ""
-#: ../raster/r.out.png/main.c:175 ../display/d.labels/color.c:68
-#: ../display/d.rast/display.c:27 ../display/d.graph/do_graph.c:105
-#: ../display/d.graph/do_graph.c:355 ../display/d.graph/do_graph.c:370
-#: ../display/d.graph/main.c:104 ../display/d.legend.vect/draw.c:198
-#: ../display/d.legend.vect/draw.c:209
+#: ../raster/r.external.out/main.c:38
#, c-format
-msgid "[%s]: No such color"
+msgid "Supported Formats:\n"
msgstr ""
-#: ../raster/r.out.png/main.c:257
+#: ../raster/r.external.out/main.c:132
+#, fuzzy
+msgid "Unable to open GDAL file"
+msgstr "출력할 격자지도"
+#: ../raster/r.external.out/main.c:156 ../vector/v.external.out/format.c:49
#, fuzzy, c-format
-msgid "Converting <%s>..."
+msgid "Format <%s> not supported"
msgstr "출력할 격자지도"
-#: ../raster/r.out.png/main.c:272 ../raster/r.univar/r.univar_main.c:201
+#: ../raster/r.external.out/main.c:162
+#, c-format
+msgid "Format <%s> does not support direct write"
+msgstr ""
+#: ../raster/r.external.out/main.c:166 ../vector/v.external.out/format.c:52
#, fuzzy, c-format
-msgid "Raster <%s> type mismatch"
+msgid "Format <%s> does not support writing"
msgstr "출력할 격자지도"
-#: ../raster/r.out.png/main.c:422
+#: ../raster/r.external.out/main.c:214
#, fuzzy
-msgid "Writing world file"
+msgid "Unable to create GDAL file"
msgstr "출력할 격자지도"
-#: ../raster/r.out.png/main.c:425
-msgid "Got null file name"
-msgstr ""
-#: ../raster/r.out.png/main.c:427
-msgid "Got null region struct"
-msgstr ""
-#: ../raster/r.out.png/main.c:429
+#: ../raster/r.external.out/main.c:217
#, fuzzy
-msgid "Unable to open world file for writing"
+msgid "Error writing GDAL file"
msgstr "출력할 격자지도"
-#: ../raster/r.region/main.c:54
-msgid "Sets the boundary definitions for a raster map."
+#: ../raster/r.external.out/main.c:237 ../vector/v.external.out/main.c:45
+msgid "output"
msgstr ""
-#: ../raster/r.region/main.c:60
-msgid "Set from current region"
+#: ../raster/r.external.out/main.c:238 ../raster/r.external/main.c:59
+#: ../vector/v.external/main.c:52 ../vector/v.external.out/main.c:46
+msgid "external"
msgstr ""
-#: ../raster/r.region/main.c:61 ../raster/r.region/main.c:66
-#: ../raster/r.region/main.c:81 ../raster/r.region/main.c:88
-#: ../raster/r.region/main.c:95 ../raster/r.region/main.c:138
-#: ../general/g.region/main.c:74 ../general/g.region/main.c:80
-#: ../general/g.region/main.c:167 ../general/g.region/main.c:174
-#: ../general/g.region/main.c:183 ../general/g.region/main.c:191
-msgid "Existing"
+#: ../raster/r.external.out/main.c:240
+msgid "Defines raster output format utilizing GDAL library."
msgstr ""
-#: ../raster/r.region/main.c:65 ../general/g.region/main.c:73
-msgid "Set from default region"
-msgstr ""
+#: ../raster/r.external.out/main.c:244
+#, fuzzy
+msgid "Name of output directory"
+msgstr "출력할 격자지도"
-#: ../raster/r.region/main.c:71
+#: ../raster/r.external.out/main.c:251
#, fuzzy
-msgid "Name of raster map to change"
+msgid "Extension for output files"
msgstr "출력할 격자지도"
-#: ../raster/r.region/main.c:79
-msgid "Set region from named region"
-msgstr ""
+#: ../raster/r.external.out/main.c:257
+#, fuzzy
+msgid "Format of output files"
+msgstr "출력할 격자지도"
-#: ../raster/r.region/main.c:87
-msgid "Set region to match this raster map"
+#: ../raster/r.external.out/main.c:264 ../vector/v.out.postgis/args.c:52
+#: ../vector/v.external.out/args.c:39
+msgid "Creation options"
msgstr ""
-#: ../raster/r.region/main.c:94
-msgid "Set region to match this vector map"
+#: ../raster/r.external.out/main.c:271 ../raster/r.external/main.c:95
+#: ../raster/r.in.gdal/main.c:197 ../vector/v.external/args.c:49
+#: ../vector/v.external.out/args.c:62
+msgid "List supported formats and exit"
msgstr ""
-#: ../raster/r.region/main.c:103 ../general/g.region/main.c:199
-msgid "Value for the northern edge"
+#: ../raster/r.external.out/main.c:277
+msgid "Cease using GDAL and revert to native output"
msgstr ""
-#: ../raster/r.region/main.c:112 ../general/g.region/main.c:208
-msgid "Value for the southern edge"
+#: ../raster/r.external.out/main.c:282 ../vector/v.external.out/args.c:74
+msgid "Print current status"
msgstr ""
-#: ../raster/r.region/main.c:121 ../general/g.region/main.c:217
-msgid "Value for the eastern edge"
+#: ../raster/r.uslek/main.c:55 ../raster/r.sim/r.sim.sediment/main.c:115
+#: ../raster/r.sim/r.sim.water/main.c:115 ../raster/r.usler/main.c:55
+msgid "soil"
msgstr ""
-#: ../raster/r.region/main.c:130 ../general/g.region/main.c:226
-msgid "Value for the western edge"
+#: ../raster/r.uslek/main.c:56 ../raster/r.sim/r.sim.sediment/main.c:117
+#: ../raster/r.usler/main.c:56
+msgid "erosion"
msgstr ""
-#: ../raster/r.region/main.c:137
-msgid "Raster map to align to"
+#: ../raster/r.uslek/main.c:57
+msgid "Computes USLE Soil Erodibility Factor (K)."
msgstr ""
-#: ../raster/r.mfilter/getrow.c:23
+#: ../raster/r.uslek/main.c:62
#, fuzzy
-msgid "Error reading temporary file"
+msgid "Name of soil sand fraction raster map [0.0-1.0]"
msgstr "출력할 격자지도"
-#: ../raster/r.mfilter/perform.c:40 ../raster/r.mfilter/perform.c:51
+#: ../raster/r.uslek/main.c:66
#, fuzzy
-msgid "Unable to create temporary file"
+msgid "Name of soil clay fraction raster map [0.0-1.0]"
msgstr "출력할 격자지도"
-#: ../raster/r.mfilter/perform.c:81
-#, fuzzy, c-format
-msgid "Writing raster map <%s>"
+#: ../raster/r.uslek/main.c:70
+#, fuzzy
+msgid "Name of soil silt fraction raster map [0.0-1.0]"
msgstr "출력할 격자지도"
-#: ../raster/r.mfilter/main.c:60
+#: ../raster/r.uslek/main.c:74
#, fuzzy
-msgid "Performs raster map matrix filter."
+msgid "Name of soil organic matter raster map [0.0-1.0]"
msgstr "출력할 격자지도"
-#: ../raster/r.mfilter/main.c:71
+#: ../raster/r.uslek/main.c:77
#, fuzzy
-msgid "Path to filter file"
+msgid "Name for output USLE K factor raster map [t.ha.hr/ha.MJ.mm]"
msgstr "출력할 격자지도"
-#: ../raster/r.mfilter/main.c:79
-msgid "Number of times to repeat the filter"
+#: ../raster/r.flow/mem.c:40
+#, c-format
+msgid "Unable to write segment file for %s"
msgstr ""
-#: ../raster/r.mfilter/main.c:86
-msgid "Output raster map title"
+#: ../raster/r.flow/main.c:314 ../raster/r.topidx/topidx.c:41
+#: ../imagery/i.landsat.toar/main.c:535
+#, fuzzy
+msgid "Calculating..."
+msgstr "출력할 격자지도"
+#: ../raster/r.flow/main.c:423
+msgid "Constructs flowlines."
msgstr ""
-#: ../raster/r.mfilter/main.c:98
-msgid "Apply filter only to null data values"
+#: ../raster/r.flow/main.c:425
+msgid ""
+"Computes flowlines, flowpath lengths, and flowaccumulation (contributing "
+"areas) from a elevation raster map."
msgstr ""
-#: ../raster/r.mfilter/main.c:125
+#: ../raster/r.flow/main.c:435 ../raster/r.flow/main.c:441
+#: ../raster/r.stream.extract/main.c:89 ../raster/r.stream.extract/main.c:97
#, fuzzy
-msgid "Raster map too small for the size of the filter"
+msgid "Input maps"
msgstr "출력할 격자지도"
-#: ../raster/r.mfilter/getfilt.c:27
-#, fuzzy, c-format
-msgid "Cannot open filter file '%s'"
+#: ../raster/r.flow/main.c:440
+#, fuzzy
+msgid "Name of input barrier raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.mfilter/getfilt.c:47
-msgid "Illegal filter matrix size specified"
+#: ../raster/r.flow/main.c:447
+msgid "Number of cells between flowlines"
msgstr ""
-#: ../raster/r.mfilter/getfilt.c:50
-msgid "Even filter matrix size specified"
+#: ../raster/r.flow/main.c:453
+msgid "Maximum number of segments per flowline"
msgstr ""
-#: ../raster/r.mfilter/getfilt.c:72
-msgid "Illegal filter matrix"
+#: ../raster/r.flow/main.c:458
+#, fuzzy
+msgid "Name for output flow line vector map"
+msgstr "출력할 격자지도"
+#: ../raster/r.flow/main.c:459 ../raster/r.flow/main.c:465
+#: ../raster/r.flow/main.c:471 ../raster/r.stream.extract/main.c:149
+#: ../raster/r.stream.extract/main.c:156 ../raster/r.stream.extract/main.c:163
+#, fuzzy
+msgid "Output maps"
+msgstr "출력할 격자지도"
+#: ../raster/r.flow/main.c:464
+#, fuzzy
+msgid "Name for output flow path length raster map"
+msgstr "출력할 격자지도"
+#: ../raster/r.flow/main.c:470
+#, fuzzy
+msgid "Name for output flow accumulation raster map"
+msgstr "출력할 격자지도"
+#: ../raster/r.flow/main.c:476
+msgid "Compute upslope flowlines instead of default downhill flowlines"
msgstr ""
-#: ../raster/r.mfilter/getfilt.c:80 ../raster/r.mfilter/getfilt.c:107
-#: ../raster/r.mfilter/getfilt.c:124
-msgid "Filter file format error"
+#: ../raster/r.flow/main.c:480
+msgid "3D lengths instead of 2D"
msgstr ""
-#: ../raster/r.mfilter/getfilt.c:83
-msgid "Duplicate filter divisor specified"
+#: ../raster/r.flow/main.c:484
+msgid "Use less memory, at a performance penalty"
msgstr ""
-#: ../raster/r.mfilter/getfilt.c:101
-msgid "Illegal divisor matrix"
+#: ../raster/r.flow/main.c:539
+msgid "You must select one or more output maps (flout, lgout, dsout)"
msgstr ""
-#: ../raster/r.mfilter/getfilt.c:110
-msgid "Duplicate filter type specified"
+#: ../raster/r.flow/main.c:555
+msgid ""
+"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
+"calculating flow accumulation."
msgstr ""
-#: ../raster/r.mfilter/getfilt.c:117
-msgid "Illegal filter type specified"
+#: ../raster/r.flow/io.c:87
+msgid "Elevation raster map resolution differs from current region resolution"
msgstr ""
-#: ../raster/r.mfilter/getfilt.c:127
-msgid "Duplicate filter start specified"
+#: ../raster/r.flow/io.c:89 ../raster/r.flow/io.c:107
+#: ../raster/r.buffer/read_map.c:52
+#, fuzzy, c-format
+msgid "Reading input raster map <%s>..."
+msgstr "출력할 격자지도"
+#: ../raster/r.flow/io.c:104
+msgid "Resolution of aspect file differs from current region resolution"
msgstr ""
-#: ../raster/r.mfilter/getfilt.c:135
+#: ../raster/r.flow/io.c:121
+msgid "Reading input files: barrier"
+msgstr ""
+#: ../raster/r.flow/io.c:149
#, c-format
-msgid "Filter start %s ignored, using UL"
+msgid "Cannot create segment file %s"
msgstr ""
-#: ../raster/r.mfilter/getfilt.c:157
-msgid "Illegal filter file format"
+#: ../raster/r.flow/io.c:154
+#, c-format
+msgid "Cannot format segment file %s"
msgstr ""
-#: ../raster/r.transect/main.c:84
+#: ../raster/r.flow/io.c:160
#, c-format
-msgid "End coordinate: %.15g, %.15g"
+msgid "Cannot open segment file %s"
msgstr ""
-#: ../raster/r.transect/main.c:104
-#, fuzzy
-msgid "transect"
+#: ../raster/r.flow/io.c:207 ../raster/r.buffer/write_map.c:45
+#: ../raster/r.cost/main.c:1034
+#, fuzzy, c-format
+msgid "Writing output raster map <%s>..."
msgstr "출력할 격자지도"
-#: ../raster/r.transect/main.c:106
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
+#: ../raster/r.flow/precomp.c:48
+msgid "Precomputing e/w distances..."
msgstr ""
-#: ../raster/r.transect/main.c:110
-msgid "Raster map to be queried"
+#: ../raster/r.flow/precomp.c:50
+#, fuzzy
+msgid "Precomputing quantization tolerances..."
+msgstr "출력할 격자지도"
+#: ../raster/r.flow/precomp.c:53
+msgid "Precomputing inverted elevations..."
msgstr ""
-#: ../raster/r.transect/main.c:116
-msgid "Transect definition"
+#: ../raster/r.flow/precomp.c:57
+msgid "Precomputing interpolated border elevations..."
msgstr ""
-#: ../raster/r.transect/main.c:126 ../raster/r.profile/main.c:93
-msgid "Output easting and northing in first two columns of four column output"
+#: ../raster/r.flow/precomp.c:63
+#, fuzzy
+msgid "Precomputing re-oriented aspects..."
+msgstr "출력할 격자지도"
+#: ../raster/r.flow/precomp.c:67
+#, fuzzy
+msgid "Precomputing aspects..."
+msgstr "출력할 격자지도"
+#: ../raster/r.flow/precomp.c:111
+#, c-format
+msgid ""
+"Resolution too unbalanced:\n"
+"atan2(%f deg, %f deg) =%f < %f tolerance\n"
+"please resample input map"
msgstr ""
-#: ../raster/r.slope.aspect/main.c:153
-msgid "aspect"
+#: ../raster/r.flow/precomp.c:116
+#, c-format
+msgid "Resolution too unbalanced (%f x %f); please resample input map"
msgstr ""
-#: ../raster/r.slope.aspect/main.c:154
-msgid "slope"
+#: ../raster/r.buffer/execute.c:34
+msgid "Finding buffer zones..."
msgstr ""
-#: ../raster/r.slope.aspect/main.c:155
-msgid "curvature"
+#: ../raster/r.buffer/parse_dist.c:54
+#, c-format
+msgid "%s: %s - illegal distance specification"
msgstr ""
-#: ../raster/r.slope.aspect/main.c:156
-msgid ""
-"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from an elevation raster map."
+#: ../raster/r.buffer/main.c:131
+msgid "Parse distances error"
msgstr ""
-#: ../raster/r.slope.aspect/main.c:158
-msgid "Aspect is calculated counterclockwise from east."
+#: ../raster/r.buffer/main.c:150
+#, c-format
+msgid "Pass %d (of %d)"
msgstr ""
-#: ../raster/r.slope.aspect/main.c:165 ../vector/v.surf.rst/main.c:195
+#: ../raster/r.resamp.interp/main.c:77 ../raster/r.resamp.bspline/main.c:82
+#: ../raster/r.resamp.rst/main.c:149 ../raster/r.resamp.filter/main.c:390
+#: ../raster/r.resample/main.c:55 ../raster/r.resamp.stats/main.c:259
#, fuzzy
-msgid "Name for output slope raster map"
+msgid "resample"
msgstr "출력할 격자지도"
-#: ../raster/r.slope.aspect/main.c:166 ../raster/r.slope.aspect/main.c:172
-#: ../raster/r.slope.aspect/main.c:196 ../raster/r.slope.aspect/main.c:203
-#: ../raster/r.slope.aspect/main.c:210 ../raster/r.slope.aspect/main.c:217
-#: ../raster/r.slope.aspect/main.c:224 ../raster/r.slope.aspect/main.c:231
-#: ../raster/r.slope.aspect/main.c:238 ../raster/r.watershed/front/main.c:134
-#: ../raster/r.watershed/front/main.c:141
-#: ../raster/r.watershed/front/main.c:148
-#: ../raster/r.watershed/front/main.c:154
-#: ../raster/r.watershed/front/main.c:160
-#: ../raster/r.watershed/front/main.c:166
-#: ../raster/r.watershed/front/main.c:174
-#: ../raster/r.watershed/front/main.c:182
-#: ../raster/r.watershed/front/main.c:189 ../vector/v.surf.rst/main.c:166
-#: ../vector/v.surf.rst/main.c:190 ../vector/v.surf.rst/main.c:196
-#: ../vector/v.surf.rst/main.c:202 ../vector/v.surf.rst/main.c:208
-#: ../vector/v.surf.rst/main.c:214 ../vector/v.surf.rst/main.c:220
-#: ../vector/v.surf.rst/main.c:226 ../vector/v.surf.rst/main.c:233
-#: ../vector/v.surf.rst/main.c:240 ../vector/v.surf.rst/main.c:247
-#: ../vector/v.surf.bspline/main.c:130 ../vector/v.surf.bspline/main.c:135
-#: ../vector/v.vol.rst/main.c:291 ../vector/v.vol.rst/main.c:297
-#: ../vector/v.vol.rst/main.c:360 ../vector/v.vol.rst/main.c:366
-#: ../vector/v.vol.rst/main.c:372 ../vector/v.vol.rst/main.c:379
-#: ../vector/v.vol.rst/main.c:385 ../vector/v.vol.rst/main.c:391
-#: ../vector/v.vol.rst/main.c:397 ../vector/v.vol.rst/main.c:403
-msgid "Outputs"
+#: ../raster/r.resamp.interp/main.c:80
+#, fuzzy
+msgid "Resamples raster map to a finer grid using interpolation."
+msgstr "출력할 격자지도"
+#: ../raster/r.resamp.interp/main.c:88
+msgid "Method"
msgstr ""
-#: ../raster/r.slope.aspect/main.c:171 ../vector/v.surf.rst/main.c:201
+#: ../raster/r.resamp.interp/main.c:102 ../imagery/i.topo.corr/main.c:158
+#, c-format
+msgid "Invalid method: %s"
+msgstr ""
+#: ../raster/r.resamp.interp/main.c:370 ../raster/r.tile/main.c:200
+#: ../raster/r.resamp.filter/main.c:579 ../raster/r.resamp.stats/main.c:389
+#, c-format
+msgid "Unable to read color table for %s"
+msgstr ""
+#: ../raster/r.clump/clump.c:51 ../vector/v.cluster/main.c:404
+#: ../vector/v.cluster/main.c:613 ../vector/v.cluster/main.c:970
+#: ../imagery/i.segment/cluster.c:386
#, fuzzy
-msgid "Name for output aspect raster map"
+msgid "Generating renumbering scheme..."
msgstr "출력할 격자지도"
-#: ../raster/r.slope.aspect/main.c:180
-msgid "Format for reporting the slope"
+#: ../raster/r.clump/clump.c:81
+msgid "Pass 2 of 2..."
msgstr ""
-#: ../raster/r.slope.aspect/main.c:187
-msgid "Type of output aspect and slope maps"
-msgstr ""
+#: ../raster/r.clump/clump.c:97 ../raster/r.clump/clump.c:149
+#: ../raster/r.clump/minsize.c:152 ../raster/r.clump/minsize.c:253
+#: ../raster/r.clump/minsize.c:287 ../raster/r.clump/minsize.c:293
+#: ../raster/r.clump/minsize.c:424 ../raster/r.clump/minsize.c:447
+#: ../raster/r.clump/minsize.c:518 ../imagery/i.segment/cluster.c:431
+#, fuzzy
+msgid "Unable to read from temp file"
+msgstr "출력할 격자지도"
-#: ../raster/r.slope.aspect/main.c:195 ../vector/v.surf.rst/main.c:207
+#: ../raster/r.clump/clump.c:113 ../raster/r.clump/clump.c:345
+#: ../raster/r.clump/clump.c:359 ../raster/r.clump/clump.c:646
+#: ../raster/r.clump/clump.c:660 ../raster/r.clump/minsize.c:163
+#: ../raster/r.clump/minsize.c:390 ../imagery/i.segment/cluster.c:363
+#: ../imagery/i.segment/cluster.c:377
#, fuzzy
-msgid "Name for output profile curvature raster map"
+msgid "Unable to write to temp file"
msgstr "출력할 격자지도"
-#: ../raster/r.slope.aspect/main.c:202 ../vector/v.surf.rst/main.c:213
+#: ../raster/r.clump/clump.c:122
+#, fuzzy, c-format
+msgid "%d initial clumps"
+msgstr "출력할 격자지도"
+#: ../raster/r.clump/clump.c:211 ../raster/r.clump/clump.c:475
+#: ../raster/r.clump/minsize.c:373 ../imagery/i.segment/cluster.c:121
#, fuzzy
-msgid "Name for output tangential curvature raster map"
+msgid "Unable to open temp file"
msgstr "출력할 격자지도"
-#: ../raster/r.slope.aspect/main.c:209
-msgid ""
-"Name for output first order partial derivative dx (E-W slope) raster map"
+#: ../raster/r.clump/clump.c:233 ../raster/r.clump/clump.c:490
+msgid "Pass 1 of 2..."
msgstr ""
-#: ../raster/r.slope.aspect/main.c:216
-msgid ""
-"Name for output first order partial derivative dy (N-S slope) raster map"
-msgstr ""
+#: ../raster/r.clump/clump.c:425
+#, fuzzy, c-format
+msgid "%d-band clumping with threshold %g"
+msgstr "출력할 격자지도"
-#: ../raster/r.slope.aspect/main.c:223
-msgid "Name for output second order partial derivative dxx raster map"
-msgstr ""
+#: ../raster/r.clump/clump.c:449 ../imagery/i.segment/open_files.c:71
+#: ../imagery/i.segment/open_files.c:238 ../imagery/i.segment/open_files.c:246
+#: ../imagery/i.segment/write_output.c:112
+#, fuzzy, c-format
+msgid "No min/max found in raster map <%s>"
+msgstr "출력할 격자지도"
-#: ../raster/r.slope.aspect/main.c:230
-msgid "Name for output second order partial derivative dyy raster map"
+#: ../raster/r.clump/main.c:60
+msgid "reclass"
msgstr ""
-#: ../raster/r.slope.aspect/main.c:237
-msgid "Name for output second order partial derivative dxy raster map"
+#: ../raster/r.clump/main.c:61 ../raster/r.volume/main.c:78
+#, fuzzy
+msgid "clumps"
+msgstr "출력할 격자지도"
+#: ../raster/r.clump/main.c:63
+msgid ""
+"Recategorizes data in a raster map by grouping cells that form physically "
+"discrete areas into unique categories."
msgstr ""
-#: ../raster/r.slope.aspect/main.c:243
-msgid "Multiplicative factor to convert elevation units to horizontal units"
+#: ../raster/r.clump/main.c:82
+msgid "Threshold to identify similar cells"
msgstr ""
-#: ../raster/r.slope.aspect/main.c:252
-msgid "Minimum slope value (in percent) for which aspect is computed"
+#: ../raster/r.clump/main.c:83
+msgid "Valid range: 0 = identical to < 1 = maximal difference"
msgstr ""
-#: ../raster/r.slope.aspect/main.c:261
+#: ../raster/r.clump/main.c:90
#, fuzzy
-msgid "Do not align the current region to the raster elevation map"
+msgid "Minimum clump size in cells"
msgstr "출력할 격자지도"
-#: ../raster/r.slope.aspect/main.c:315 ../raster/r.relief/main.c:220
-#, c-format
-msgid "%s=%s - must be a positive number"
+#: ../raster/r.clump/main.c:91
+msgid "Clumps smaller than minsize will be merged to form larger clumps"
msgstr ""
-#: ../raster/r.slope.aspect/main.c:321 ../raster/r.relief/main.c:201
-#: ../raster/r.relief/main.c:207
-#, c-format
-msgid "%s=%s - must be a non-negative number"
+#: ../raster/r.clump/main.c:95
+msgid "Clump also diagonal cells"
msgstr ""
-#: ../raster/r.slope.aspect/main.c:336
+#: ../raster/r.clump/main.c:96
+msgid "Clumps are also traced along diagonal neighboring cells"
+msgstr ""
+#: ../raster/r.clump/main.c:100
+#, fuzzy
+msgid "Print only the number of clumps in shell script style"
+msgstr "위상정보를 셸스크립트 형식으로 출력합니다"
+#: ../raster/r.clump/main.c:122
#, c-format
-msgid ""
-"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <"
-"%s>, <%s>, <%s>, <%s> or <%s>"
+msgid "Valid range for option <%s> is 0 <= value < 1"
msgstr ""
-#: ../raster/r.slope.aspect/main.c:358
+#: ../raster/r.clump/main.c:180
#, fuzzy, c-format
-msgid "Wrong raster type: %s"
+msgid "%d clump."
+msgid_plural "%d clumps."
+msgstr[0] "출력할 격자지도"
+#: ../raster/r.clump/minsize.c:357
+#, fuzzy
+msgid "Minimum size must be larger than 1"
msgstr "출력할 격자지도"
-#: ../raster/r.slope.aspect/main.c:387
-msgid ""
-"r.slope.aspect does not convert horizontal units to meters in this version, "
-"see manual page."
-msgstr ""
+#: ../raster/r.clump/minsize.c:368
+#, fuzzy
+msgid "Loading input ..."
+msgstr "출력할 격자지도"
-#: ../raster/r.slope.aspect/main.c:544 ../raster/r.relief/main.c:316
-#: ../raster/r.series.accumulate/main.c:318 ../raster/r.series/main.c:386
-#: ../raster/r.series.interp/main.c:339 ../raster/r.patch/main.c:138
-msgid "Percent complete..."
+#: ../raster/r.clump/minsize.c:418
+#, c-format
+msgid "Merging clumps smaller than %d cells..."
msgstr ""
-#: ../raster/r.slope.aspect/main.c:968
+#: ../raster/r.clump/minsize.c:509
#, fuzzy, c-format
-msgid "Elevation products for mapset <%s> in <%s>"
+msgid "Renumbering remaining %d clumps..."
msgstr "출력할 격자지도"
-#: ../raster/r.slope.aspect/main.c:987
+#: ../raster/r.clump/rclist.c:17 ../imagery/i.segment/rclist.c:17
+msgid "rclist out of memory"
+msgstr ""
+#: ../raster/r.to.vect/points.c:36
+msgid "Extracting points..."
+msgstr "점을 추출하는 중..."
+#: ../raster/r.to.vect/areas_io.c:154
#, c-format
-msgid "Min computed aspect %.4f, max computed aspect %.4f"
+msgid ""
+"write_bnd: line terminated unexpectedly\n"
+"previous (%d) point %p (%d,%d,%d) %p %p"
msgstr ""
-#: ../raster/r.slope.aspect/main.c:1051
-#, fuzzy, c-format
-msgid "Aspect raster map <%s> complete"
-msgstr "출력할 격자지도"
+#: ../raster/r.to.vect/areas_io.c:287
+msgid "Writing areas..."
+msgstr "면을 쓰는 중..."
-#: ../raster/r.slope.aspect/main.c:1108
+#: ../raster/r.to.vect/areas_io.c:359 ../raster/r.to.vect/util.c:157
+#: ../raster/r.volume/main.c:296 ../vector/v.random/main.c:469
+#: ../vector/v.random/main.c:589 ../vector/v.in.ogr/main.c:1292
+#: ../vector/v.vol.rst/vector.c:80 ../vector/v.in.lidar/attributes.c:240
#, c-format
-msgid "Min computed slope %.4f, max computed slope %.4f"
+msgid "Cannot insert new row: %s"
msgstr ""
-#: ../raster/r.slope.aspect/main.c:1161
-#, fuzzy, c-format
-msgid "Slope raster map <%s> complete"
-msgstr "출력할 격자지도"
+#: ../raster/r.to.vect/areas.c:122
+msgid "Extracting areas..."
+msgstr "면을 추출하는 중..."
-#: ../raster/r.slope.aspect/main.c:1233
-#, fuzzy, c-format
-msgid "Profile curve raster map <%s> complete"
+#: ../raster/r.to.vect/main.c:79
+#, fuzzy
+msgid "vectorization"
msgstr "출력할 격자지도"
-#: ../raster/r.slope.aspect/main.c:1260
-#, fuzzy, c-format
-msgid "Tangential curve raster map <%s> complete"
+#: ../raster/r.to.vect/main.c:80
+#, fuzzy
+msgid "Converts a raster map into a vector map."
msgstr "출력할 격자지도"
-#: ../raster/r.slope.aspect/main.c:1285
-#, fuzzy, c-format
-msgid "E-W slope raster map <%s> complete"
+#: ../raster/r.to.vect/main.c:106 ../raster/r.to.vect/main.c:113
+#: ../vector/v.extract/main.c:93 ../vector/v.extract/main.c:145
+#: ../vector/v.overlay/main.c:135 ../vector/v.overlay/main.c:145
+#: ../vector/v.in.ogr/main.c:226 ../vector/v.in.ogr/main.c:236
+#: ../vector/v.in.ogr/main.c:246 ../vector/v.in.ogr/main.c:279
+#: ../vector/v.in.ogr/main.c:311 ../vector/v.generalize/main.c:243
+#: ../vector/v.to.rast/main.c:88 ../vector/v.to.rast/main.c:94
+#: ../vector/v.to.rast/main.c:100 ../vector/v.buffer/main.c:307
+#, fuzzy
+msgid "Attributes"
msgstr "출력할 격자지도"
-#: ../raster/r.slope.aspect/main.c:1310
-#, fuzzy, c-format
-msgid "N-S slope raster map <%s> complete"
+#: ../raster/r.to.vect/main.c:118
+msgid "Recommended for massive point conversion"
+msgstr ""
+#: ../raster/r.to.vect/main.c:131
+msgid "z flag is supported only for points"
+msgstr ""
+#: ../raster/r.to.vect/main.c:142
+msgid ""
+"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
+"table."
+msgstr ""
+#: ../raster/r.to.vect/main.c:144
+msgid ""
+"Raster is not CELL, '-v' flag ignored, raster values will be z coordinate."
+msgstr ""
+#: ../raster/r.to.vect/main.c:146
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be lost."
+msgstr ""
+#: ../raster/r.to.vect/main.c:151
+msgid "Categories will be unique sequence, raster values will be lost."
+msgstr ""
+#: ../raster/r.to.vect/main.c:233 ../raster/r.random/random.c:253
+#: ../vector/v.extract/copy_tab.c:124 ../vector/v.random/main.c:258
+#: ../vector/v.mkgrid/main.c:346 ../vector/v.mkgrid/main.c:404
+#: ../vector/v.overlay/main.c:592 ../vector/v.select/copy_tabs.c:82
+#: ../vector/v.patch/main.c:326 ../db/drivers/postgres/index.c:59
+#, fuzzy
+msgid "Unable to create index"
msgstr "출력할 격자지도"
-#: ../raster/r.slope.aspect/main.c:1335
-#, fuzzy, c-format
-msgid "Dxx raster map <%s> complete"
+#: ../raster/r.to.vect/main.c:289 ../raster/r.drain/main.c:283
+#: ../raster/r.walk/main.c:688 ../raster/r.walk/main.c:754
+#: ../raster/r.cost/main.c:548 ../raster/r.cost/main.c:618
+#: ../display/d.vect/topo.c:52 ../display/d.vect/dir.c:30
+#: ../display/d.vect/lines.c:143 ../display/d.vect/vert.c:27
+#: ../display/d.vect/label.c:44 ../display/d.vect/attr.c:51
+#: ../display/d.vect.thematic/display.c:75 ../vector/v.label.sa/labels.c:141
+#: ../vector/v.to.3d/trans3.c:85 ../vector/v.to.3d/trans2.c:84
+#: ../vector/v.out.lidar/main.c:732 ../vector/v.decimate/main.c:404
+#: ../vector/v.vol.rst/user1.c:140 ../vector/v.kriging/getval.c:244
+#: ../vector/v.perturb/main.c:181 ../vector/v.info/level1.c:37
+#: ../vector/v.label/main.c:293 ../vector/v.colors/scan_z.c:36
+#: ../vector/v.colors/scan_cats.c:24 ../vector/v.colors.out/scan_cats.c:32
+#, fuzzy
+msgid "Unable to read vector map"
msgstr "출력할 격자지도"
-#: ../raster/r.slope.aspect/main.c:1360
-#, fuzzy, c-format
-msgid "Dyy raster map <%s> complete"
+#: ../raster/r.to.vect/main.c:312
+#, fuzzy
+msgid "Updating attributes..."
msgstr "출력할 격자지도"
-#: ../raster/r.slope.aspect/main.c:1385
+#: ../raster/r.to.vect/main.c:335
#, fuzzy, c-format
-msgid "Dxy raster map <%s> complete"
+msgid "Unable to insert into table: %s"
msgstr "출력할 격자지도"
-#: ../raster/r.timestamp/main.c:39
-#, fuzzy
-msgid "Modifies a timestamp for a raster map."
-msgstr "출력할 격자지도"
+#: ../raster/r.to.vect/lines.c:71
+msgid "Extracting lines..."
+msgstr "선을 추출하는 중..."
-#: ../raster/r.timestamp/main.c:40
-msgid "Print/add/remove a timestamp for a raster map."
+#: ../raster/r.to.vect/lines.c:504
+#, c-format
+msgid "Crowded cell at (%f, %f): row %d, col %d, count %d"
msgstr ""
-#: ../raster/r.timestamp/main.c:49 ../vector/v.timestamp/main.c:50
-msgid "Datetime, datetime1/datetime2, or 'none' to remove"
+#: ../raster/r.to.vect/lines.c:508
+msgid ""
+"Raster map is not thinned properly.\n"
+"Please run r.thin."
msgstr ""
-#: ../raster/r.timestamp/main.c:50 ../vector/v.timestamp/main.c:51
-msgid "Format: '15 jan 1994' (absolute) or '2 years' (relative)"
+#: ../raster/r.to.vect/lines.c:582
+msgid "join_lines: p front pointer not NULL!"
msgstr ""
-#: ../raster/r.timestamp/main.c:65
-#, fuzzy, c-format
-msgid "Raster map <%s> not found %s"
-msgstr "출력할 격자지도"
+#: ../raster/r.to.vect/lines.c:588
+msgid "join_lines: q front pointer not NULL!"
+msgstr ""
-#: ../raster/r.resamp.bspline/main.c:82 ../raster/r.resample/main.c:55
-#: ../raster/r.resamp.rst/main.c:149 ../raster/r.resamp.filter/main.c:390
-#: ../raster/r.resamp.stats/main.c:259 ../raster/r.resamp.interp/main.c:77
-#, fuzzy
-msgid "resample"
-msgstr "출력할 격자지도"
+#: ../raster/r.to.vect/lines.c:606
+msgid "extend line: p is NULL"
+msgstr ""
-#: ../raster/r.resamp.bspline/main.c:83 ../raster/r.resamp.interp/main.c:78
-#: ../raster/r.series.interp/main.c:66 ../raster/r.surf.contour/main.c:62
-#: ../raster/r.surf.idw/main.c:106
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:3
-#: ../vector/v.surf.idw/main.c:89 ../vector/v.surf.rst/main.c:143
-#: ../vector/v.surf.bspline/main.c:93 ../vector/v.vol.rst/main.c:238
-#, fuzzy
-msgid "interpolation"
-msgstr "출력할 격자지도"
+#: ../raster/r.to.vect/lines.c:632
+msgid "extend_lines: p front pointer not NULL!"
+msgstr ""
+#: ../raster/r.to.vect/lines.c:639
+msgid "extend_lines: q back pointer not NULL!"
+msgstr ""
+#: ../raster/r.to.vect/lines_io.c:76
+msgid "write_line: found half a loop!"
+msgstr ""
+#: ../raster/r.to.vect/lines_io.c:177
+#, c-format
+msgid ""
+"write_line: line terminated unexpectedly\n"
+" previous (%d) point %p (%d,%d,%d) %p %p"
+msgstr ""
#: ../raster/r.resamp.bspline/main.c:85
msgid ""
"Performs bilinear or bicubic spline interpolation with Tykhonov "
@@ -11462,23 +11879,19 @@
msgid "Spline interpolation algorithm"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:125 ../vector/v.surf.bspline/main.c:170
-#: ../vector/v.lidar.edgedetection/main.c:414 ../vector/v.outlier/main.c:416
+#: ../raster/r.resamp.bspline/main.c:125
#: ../vector/v.lidar.correction/main.c:402
+#: ../vector/v.lidar.edgedetection/main.c:414
+#: ../vector/v.surf.bspline/main.c:170 ../vector/v.outlier/main.c:416
msgid "Bilinear interpolation"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:126 ../vector/v.surf.bspline/main.c:171
+#: ../raster/r.resamp.bspline/main.c:126
#: ../vector/v.lidar.edgedetection/main.c:431
+#: ../vector/v.surf.bspline/main.c:171
msgid "Bicubic interpolation"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:132
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:16
-#: ../vector/v.surf.bspline/main.c:177
-msgid "Tykhonov regularization parameter (affects smoothing)"
-msgstr ""
#: ../raster/r.resamp.bspline/main.c:138
#, fuzzy
msgid "Only interpolate null cells in input raster map"
@@ -11490,22 +11903,6 @@
"cross validation method"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:151 ../raster/r.proj/main.c:191
-#: ../raster/r.stream.extract/main.c:141 ../raster/r.in.gdal/main.c:116
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:13
-#: ../locale/scriptstrings/r.import_to_translate.c:9
-#: ../vector/v.surf.bspline/main.c:194 ../vector/v.to.rast/main.c:116
-msgid "Maximum memory to be used (in MB)"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:152 ../raster/r.proj/main.c:192
-#: ../raster/r.stream.extract/main.c:142 ../raster/r.in.gdal/main.c:117
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:12
-#: ../locale/scriptstrings/r.import_to_translate.c:10
-#: ../vector/v.surf.bspline/main.c:195 ../vector/v.to.rast/main.c:117
-msgid "Cache size for raster rows"
-msgstr ""
#: ../raster/r.resamp.bspline/main.c:187
#, fuzzy
msgid "ew_step must be positive"
@@ -11543,9 +11940,9 @@
msgstr ""
#: ../raster/r.resamp.bspline/main.c:308 ../raster/r.resamp.bspline/main.c:394
-#: ../raster/r.resamp.bspline/main.c:465 ../raster/r.cost/main.c:435
-#: ../raster/r.cost/main.c:440 ../raster/r.walk/main.c:549
-#: ../raster/r.walk/main.c:554 ../vector/v.surf.bspline/main.c:470
+#: ../raster/r.resamp.bspline/main.c:465 ../raster/r.walk/main.c:549
+#: ../raster/r.walk/main.c:554 ../raster/r.cost/main.c:435
+#: ../raster/r.cost/main.c:440 ../vector/v.surf.bspline/main.c:470
#: ../vector/v.surf.bspline/main.c:498
#, fuzzy
msgid "Can not create temporary file"
@@ -11591,9 +11988,9 @@
msgid "Initializing output..."
msgstr "출력할 격자지도"
-#: ../raster/r.resamp.bspline/main.c:546 ../vector/v.lidar.growing/main.c:246
+#: ../raster/r.resamp.bspline/main.c:546
+#: ../vector/v.lidar.correction/main.c:333 ../vector/v.lidar.growing/main.c:246
#: ../vector/v.lidar.edgedetection/main.c:351
-#: ../vector/v.lidar.correction/main.c:333
#, c-format
msgid "subregion %d of %d"
msgstr ""
@@ -11620,7 +12017,6 @@
msgid "%d point read in region"
msgid_plural "%d points read in region"
-msgstr[1] "출력할 격자지도"
#: ../raster/r.resamp.bspline/crosscorr.c:174
msgid "Maybe it takes too long. Consider reducing the region extents."
@@ -11684,252 +12080,793 @@
msgid "No point lies into the current region"
msgstr "출력할 격자지도"
-#: ../raster/r.spread/main.c:106 ../raster/r.spreadpath/main.c:89
-#: ../raster/r.ros/main.c:213
-msgid "fire"
+#: ../raster/r.relief/main.c:110 ../raster/r.slope.aspect/main.c:152
+#: ../raster/r.param.scale/interface.c:56 ../imagery/i.topo.corr/main.c:48
+#, fuzzy
+msgid "terrain"
+msgstr "출력할 격자지도"
+#: ../raster/r.relief/main.c:112
+msgid "Creates shaded relief map from an elevation map (DEM)."
msgstr ""
-#: ../raster/r.spread/main.c:107 ../raster/r.ros/main.c:214
-msgid "spread"
+#: ../raster/r.relief/main.c:117
+#, fuzzy
+msgid "Name for output shaded relief map"
+msgstr "출력할 격자지도"
+#: ../raster/r.relief/main.c:125
+msgid "Altitude of the sun in degrees above the horizon"
msgstr ""
-#: ../raster/r.spread/main.c:108 ../raster/r.lake/main.c:152
-#: ../raster/r.ros/main.c:216
-msgid "hazard"
+#: ../raster/r.relief/main.c:126 ../raster/r.relief/main.c:136
+#, fuzzy
+msgid "Sun position"
+msgstr "출력할 격자지도"
+#: ../raster/r.relief/main.c:135
+msgid "Azimuth of the sun in degrees to the east of north"
msgstr ""
-#: ../raster/r.spread/main.c:111
-msgid "Simulates elliptically anisotropic spread."
+#: ../raster/r.relief/main.c:143
+msgid "Factor for exaggerating relief"
msgstr ""
-#: ../raster/r.spread/main.c:113
-msgid ""
-"Generates a raster map of the cumulative time of spread, given raster maps "
-"containing the rates of spread (ROS), the ROS directions and the spread "
-"origins. It optionally produces raster maps to contain backlink UTM "
-"coordinates for tracing spread paths. Usable for fire spread simulations."
+#: ../raster/r.relief/main.c:151
+msgid "Scale factor for converting meters to elevation units"
msgstr ""
-#: ../raster/r.spread/main.c:127
-msgid "Raster map containing base ROS (cm/min)"
+#: ../raster/r.relief/main.c:158
+msgid "Elevation units (overrides scale factor)"
msgstr ""
-#: ../raster/r.spread/main.c:129
-msgid ""
-"Name of an existing raster map layer in the user's current mapset search "
-"path containing the ROS values in the directions perpendicular to maximum "
-"ROSes' (cm/minute). These ROSes are also the ones without the effect of "
-"directional factors."
+#: ../raster/r.relief/main.c:163
+#, fuzzy
+msgid "international feet"
+msgstr "출력할 격자지도"
+#: ../raster/r.relief/main.c:164
+msgid "survey feet"
msgstr ""
-#: ../raster/r.spread/main.c:141
-msgid "Raster map containing maximal ROS (cm/min)"
+#: ../raster/r.relief/main.c:194 ../raster/r.in.gdal/main.c:346
+#: ../raster/r.in.gdal/main.c:693 ../vector/v.kernel/main.c:236
+#: ../imagery/i.landsat.toar/main.c:549
+#, c-format
+msgid "Raster map <%s> already exists and will be overwritten"
+msgstr "격자지도 <%s>가 이미 존재하지만 덮어 씁니다"
+#: ../raster/r.relief/main.c:197 ../raster/r.in.gdal/main.c:349
+#: ../raster/r.in.gdal/main.c:696 ../vector/v.kernel/main.c:239
+#, c-format
+msgid "Raster map <%s> already exists"
+msgstr "격자지도 <%s>가 이미 존재합니다"
+#: ../raster/r.relief/main.c:201 ../raster/r.relief/main.c:207
+#: ../raster/r.slope.aspect/main.c:321
+#, c-format
+msgid "%s=%s - must be a non-negative number"
msgstr ""
-#: ../raster/r.spread/main.c:143
+#: ../raster/r.relief/main.c:215
+#, c-format
+msgid "%s=%s - must not be zero"
+msgstr ""
+#: ../raster/r.relief/main.c:220 ../raster/r.slope.aspect/main.c:315
+#, c-format
+msgid "%s=%s - must be a positive number"
+msgstr ""
+#: ../raster/r.relief/main.c:316 ../raster/r.series.interp/main.c:339
+#: ../raster/r.series.accumulate/main.c:318 ../raster/r.series/main.c:386
+#: ../raster/r.slope.aspect/main.c:544 ../raster/r.patch/main.c:138
+msgid "Percent complete..."
+msgstr ""
+#: ../raster/r.relief/main.c:474
+#, fuzzy, c-format
+msgid "Shaded relief raster map <%s> complete"
+msgstr "출력할 격자지도"
+#: ../raster/r.series.interp/main.c:69
msgid ""
-"path containing the maximum ROS values (cm/minute)."
+"Interpolates raster maps located (temporal or spatial) in between input "
+"raster maps at specific sampling positions."
msgstr ""
-#: ../raster/r.spread/main.c:153
+#: ../raster/r.series.interp/main.c:79
#, fuzzy
-msgid "Raster map containing directions of maximal ROS (degree)"
+msgid "Data point position for each input map"
msgstr "출력할 격자지도"
-#: ../raster/r.spread/main.c:155
+#: ../raster/r.series.interp/main.c:84
msgid ""
-"path containing directions of the maximum ROSes, clockwise from north "
-"(degree)."
+"Input file with one input raster map name and data point position per line, "
+"field separator between name and sample point is |"
msgstr ""
-#: ../raster/r.spread/main.c:166
+#: ../raster/r.series.interp/main.c:97
#, fuzzy
-msgid "Raster map containing starting sources"
+msgid "Sampling point position for each output map"
msgstr "출력할 격자지도"
-#: ../raster/r.spread/main.c:168
+#: ../raster/r.series.interp/main.c:101
msgid ""
-"path containing starting locations of the spread phenomenon. Any positive "
-"integers in this map are recognized as starting sources (seeds)."
+"Input file with one output raster map name and sample point position per "
+"line, field separator between name and sample point is |"
msgstr ""
-#: ../raster/r.spread/main.c:179
-msgid "Raster map containing maximal spotting distance (m, required with -s)"
+#: ../raster/r.series.interp/main.c:111
+msgid "Interpolation method, currently only linear interpolation is supported"
msgstr ""
-#: ../raster/r.spread/main.c:181
+#: ../raster/r.series.interp/main.c:118 ../raster/r.series.interp/main.c:122
+#: ../raster/r.series.interp/main.c:134 ../raster/r.series.interp/main.c:138
+#: ../raster/r.series.accumulate/main.c:206 ../raster/r.neighbors/main.c:266
+#: ../raster/r.series/main.c:204 ../raster/r.external/main.c:159
+#: ../raster/r.mapcalc/main.c:117 ../vector/v.colors/main.c:206
+#, c-format
+msgid "%s= and %s= are mutually exclusive"
+msgstr "%s=와 %s=를 같이 지정할 수 없습니다"
+#: ../raster/r.series.interp/main.c:126 ../raster/r.series.interp/main.c:142
+#: ../raster/r.series.accumulate/main.c:210 ../raster/r.series/main.c:208
+#, fuzzy, c-format
+msgid "Please specify %s= or %s="
+msgstr "출력할 격자지도"
+#: ../raster/r.series.interp/main.c:130 ../raster/r.series.interp/main.c:146
+#, fuzzy, c-format
+msgid "Please specify %s= and %s="
+msgstr "출력할 격자지도"
+#: ../raster/r.series.interp/main.c:180 ../raster/r.colors/edit_colors.c:186
+#, fuzzy, c-format
+msgid "Unable to open %s file <%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.series.interp/main.c:213
+#, c-format
+msgid "Missing point position for %s map <%s> in file <%s> near line %i"
+msgstr ""
+#: ../raster/r.series.interp/main.c:228 ../raster/r.series.interp/main.c:262
+#, fuzzy, c-format
+msgid "Preparing %s map <%s> at position %g"
+msgstr "출력할 격자지도"
+#: ../raster/r.series.interp/main.c:232
+#, fuzzy, c-format
+msgid "No raster map name found in %s file <%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.series.interp/main.c:243
+#, fuzzy, c-format
+msgid "No %s raster map not found"
+msgstr "출력할 격자지도"
+#: ../raster/r.series.interp/main.c:250
+#, c-format
+msgid "The number of %s maps and %s point positions must be equal"
+msgstr ""
+#: ../raster/r.series.interp/main.c:279
+#, c-format
+msgid "Start interpolation run with %i input maps and %i output maps"
+msgstr ""
+#: ../raster/r.series.interp/main.c:299
+#, c-format
msgid ""
-"path containing the maximum potential spotting distances (meters)."
+"map <%s> at position %g was not interpolated. Check the interpolation "
+"interval."
msgstr ""
-#: ../raster/r.spread/main.c:191
-msgid "Raster map containing midflame wind speed (ft/min, required with -s)"
+#: ../raster/r.series.interp/main.c:319
+#, fuzzy
+msgid "At least 2 input maps are required for linear interpolation"
+msgstr "출력할 격자지도"
+#: ../raster/r.series.interp/main.c:337
+#, c-format
+msgid "Interpolate map <%s> at position %g in interval (%g;%g)"
msgstr ""
-#: ../raster/r.spread/main.c:193 ../raster/r.ros/main.c:279
+#: ../raster/r.quantile/main.c:66
+msgid "Computing histogram"
+msgstr ""
+#: ../raster/r.quantile/main.c:100 ../raster/r.stats.quantile/main.c:174
+#, fuzzy
+msgid "Computing bins"
+msgstr "출력할 격자지도"
+#: ../raster/r.quantile/main.c:138 ../raster/r.stats.quantile/main.c:231
+#, fuzzy
+msgid "Binning data"
+msgstr "출력할 격자지도"
+#: ../raster/r.quantile/main.c:183 ../raster/r.stats.quantile/main.c:287
+#, fuzzy
+msgid "Sorting bins"
+msgstr "출력할 격자지도"
+#: ../raster/r.quantile/main.c:193 ../raster/r.stats.quantile/main.c:360
+#, fuzzy
+msgid "Computing quantiles"
+msgstr "출력할 격자지도"
+#: ../raster/r.quantile/main.c:264
+msgid "Compute quantiles using two passes."
+msgstr ""
+#: ../raster/r.quantile/main.c:272 ../raster/r.stats.quantile/main.c:528
+#, fuzzy
+msgid "Number of quantiles"
+msgstr "출력할 격자지도"
+#: ../raster/r.quantile/main.c:280 ../raster/r.stats.quantile/main.c:534
+msgid "List of percentiles"
+msgstr ""
+#: ../raster/r.quantile/main.c:286 ../raster/r.stats.quantile/main.c:541
+#, fuzzy
+msgid "Number of bins to use"
+msgstr "출력할 격자지도"
+#: ../raster/r.quantile/main.c:291
+msgid "Generate recode rules based on quantile-defined intervals"
+msgstr ""
+#: ../raster/r.quantile/main.c:319
+#, fuzzy
+msgid "Too many quantiles"
+msgstr "출력할 격자지도"
+#: ../raster/r.series.accumulate/main.c:84
msgid ""
-"path containing wind velocities at half of the average flame height (feet/"
-"minute)."
+"Makes each output cell value a accumulationfunction of the values assigned "
+"to the corresponding cells in the input raster map layers."
msgstr ""
-#: ../raster/r.spread/main.c:203
+#: ../raster/r.series.accumulate/main.c:90
+msgid "Existing map to be added to output"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:98
+#, fuzzy
+msgid "Input file with raster map names, one per line"
+msgstr "출력할 격자지도"
+#: ../raster/r.series.accumulate/main.c:109
+#, fuzzy
+msgid "Scale factor for input"
+msgstr "출력할 격자지도"
+#: ../raster/r.series.accumulate/main.c:116
+msgid "Shift factor for input"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:121
msgid ""
-"Raster map containing fine fuel moisture of the cell receiving a spotting "
-"firebrand (%, required with -s)"
+"The raster map specifying the lower accumulation limit, also called baseline"
msgstr ""
-#: ../raster/r.spread/main.c:205 ../raster/r.ros/main.c:240
+#: ../raster/r.series.accumulate/main.c:126
msgid ""
-"path containing the 1-hour (<.25\") fuel moisture (percentage content "
-"multiplied by 100)."
+"The raster map specifying the upper accumulation limit, also called cutoff. "
+"Only applied to BEDD computation."
msgstr ""
-#: ../raster/r.spread/main.c:215
-msgid "Basic sampling window size needed to meet certain accuracy (3)"
+#: ../raster/r.series.accumulate/main.c:132 ../raster/r.series/main.c:183
+msgid "Ignore values outside this range"
msgstr ""
-#: ../raster/r.spread/main.c:217
-msgid ""
-"An odd integer ranging 3 - 15 indicating the basic sampling window size "
-"within which all cells will be considered to see whether they will be "
-"reached by the current spread cell. The default number is 3 which means a "
-"3x3 window."
+#: ../raster/r.series.accumulate/main.c:139
+msgid "Use these limits in case lower and/or upper input maps are not defined"
msgstr ""
-#: ../raster/r.spread/main.c:227
-msgid "Sampling density for additional computing (range: 0.0 - 1.0 (0.5))"
+#: ../raster/r.series.accumulate/main.c:151
+msgid "Growing Degree Days or Winkler indices"
msgstr ""
-#: ../raster/r.spread/main.c:229
+#: ../raster/r.series.accumulate/main.c:152
+msgid "Mean: sum(input maps)/(number of input maps)"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:153
+msgid "Biologically Effective Degree Days"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:154
+msgid "Huglin Heliothermal index"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:163 ../raster/r.series/main.c:191
+#, fuzzy
+msgid "Do not keep files open"
+msgstr "출력할 격자지도"
+#: ../raster/r.series.accumulate/main.c:167
+msgid "Create a FCELL map (floating point single precision) as output"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:248
+#: ../raster/r.series.accumulate/main.c:273
+#: ../raster/r.series.accumulate/main.c:284
+#: ../raster/r.series.accumulate/main.c:292
+#: ../raster/r.series.accumulate/main.c:300 ../raster/r.out.mpeg/main.c:286
+#: ../raster/r.grow.distance/main.c:276 ../raster/r.surf.idw/main.c:713
+#: ../ps/ps.map/ps_raster.c:102
+#, fuzzy, c-format
+msgid "Reading raster map <%s>..."
+msgstr "출력할 격자지도"
+#: ../raster/r.series.accumulate/main.c:255 ../raster/r.series/main.c:275
+#, fuzzy
+msgid "No raster map name found in input file"
+msgstr "출력할 격자지도"
+#: ../raster/r.series.accumulate/main.c:265 ../raster/r.series/main.c:287
+#: ../raster/r.stats/main.c:285
+#, fuzzy
+msgid "Raster map not found"
+msgstr "출력할 격자지도"
+#: ../raster/r.series.accumulate/main.c:354
+#, fuzzy, c-format
+msgid "'%s'=%f must be > '%s'=%f"
+msgstr "출력할 격자지도"
+#: ../raster/r.topidx/file_io.c:35
+#, c-format
msgid ""
-"A decimal number ranging 0.0 - 1.0 indicating additional sampling cells will "
-"be considered to see whether they will be reached by the current spread "
-"cell. The closer to 1.0 the decimal number is, the longer the program will "
-"run and the higher the simulation accuracy will be. The default number is "
-"0.5."
+"The current region resolution [%s x %s] is finer than the input map's "
+"resolution [%s x %s]. The current region resolution must be identical to, or "
+"coarser than, the input map's resolution."
msgstr ""
-#: ../raster/r.spread/main.c:241
-msgid "Initial time for current simulation (0) (min)"
+#: ../raster/r.topidx/file_io.c:42
+#, fuzzy
+msgid "Reading elevation map..."
+msgstr "출력할 격자지도"
+#: ../raster/r.topidx/file_io.c:87
+#, fuzzy
+msgid "Writing topographic index map..."
+msgstr "출력할 격자지도"
+#: ../raster/r.topidx/main.c:41
+msgid "wetness"
msgstr ""
-#: ../raster/r.spread/main.c:243
+#: ../raster/r.topidx/main.c:43
+#, fuzzy
msgid ""
-"A non-negative number specifying the initial time for the current spread "
-"simulation (minutes). This is useful when multiple phase simulation is "
-"conducted. The default time is 0."
+"Creates a topographic index (wetness index) raster map from an elevation "
+"raster map."
+msgstr "고도 격자지도로부터 위상색인 격자지도를 생성합니다."
+#: ../raster/r.topidx/main.c:49
+msgid "Name for output topographic index raster map"
+msgstr "출력 위상색인 격자지도의 이름"
+#: ../raster/r.topidx/main.c:56 ../raster/r.solute.transport/main.c:244
+#: ../raster/r.carve/main.c:213 ../raster/r.gwflow/main.c:222
+#, c-format
+msgid "Lat/Long location is not supported by %s. Please reproject map first."
msgstr ""
-#: ../raster/r.spread/main.c:252
-msgid "Simulating time duration LAG (fill the region) (min)"
+#: ../raster/r.topidx/topidx.c:272
+#, fuzzy, c-format
+msgid "Number of sinks or boundaries: %d"
+msgstr "출력할 격자지도"
+#: ../raster/r.neighbors/readweights.c:18
+#, fuzzy, c-format
+msgid "Unable to open weights file %s"
+msgstr "출력할 격자지도"
+#: ../raster/r.neighbors/readweights.c:23
+#, fuzzy, c-format
+msgid "Error reading weights file %s"
+msgstr "출력할 격자지도"
+#: ../raster/r.neighbors/main.c:121
+#, c-format
+msgid "Invalid out_type enumeration: %d"
msgstr ""
-#: ../raster/r.spread/main.c:254
+#: ../raster/r.neighbors/main.c:175
msgid ""
-"A non-negative integer specifying the simulating duration time lag "
-"(minutes). The default is infinite, but the program will terminate when the "
-"current geographic region/mask has been filled. It also controls the "
-"computational time, the shorter the time lag, the faster the program will "
-"run."
+"Makes each cell category value a function of the category values assigned to "
+"the cells around it, and stores new cell values in an output raster map "
+"layer."
msgstr ""
-#: ../raster/r.spread/main.c:266
-msgid "Name of raster map as a display backdrop"
+#: ../raster/r.neighbors/main.c:185
+#, fuzzy
+msgid ""
+"Name of an input raster map to select the cells which should be processed"
+msgstr "출력할 격자지도"
+#: ../raster/r.neighbors/main.c:204 ../vector/v.neighbors/main.c:72
+msgid "Neighborhood operation"
msgstr ""
-#: ../raster/r.spread/main.c:268
+#: ../raster/r.neighbors/main.c:206 ../raster/r.neighbors/main.c:214
+#: ../raster/r.neighbors/main.c:249
+msgid "Neighborhood"
+msgstr ""
+#: ../raster/r.neighbors/main.c:226
+#, fuzzy
+msgid "Text file containing weights"
+msgstr "출력할 격자지도"
+#: ../raster/r.neighbors/main.c:232
+msgid "Sigma (in cells) for Gaussian filter"
+msgstr ""
+#: ../raster/r.neighbors/main.c:244
+msgid "Do not align output with the input"
+msgstr ""
+#: ../raster/r.neighbors/main.c:248
+msgid "Use circular neighborhood"
+msgstr ""
+#: ../raster/r.neighbors/main.c:256
+msgid "Neighborhood size must be positive"
+msgstr ""
+#: ../raster/r.neighbors/main.c:258
+msgid "Neighborhood size must be odd"
+msgstr ""
+#: ../raster/r.neighbors/main.c:293
+#, c-format
+msgid "%s= and %s= must have the same number of values"
+msgstr ""
+#: ../raster/r.neighbors/main.c:329
+#, c-format
msgid ""
-"path to be used as the background on which the \"live\" movement will be "
-"shown."
+"Method %s not compatible with weighing window, using weight mask instead"
msgstr ""
-#: ../raster/r.spread/main.c:279
-msgid "Raster map to contain output spread time (min)"
+#: ../raster/r.neighbors/main.c:337
+#, c-format
+msgid ""
+"Method %s not compatible with Gaussian filter, using unweighed version "
+"instead"
msgstr ""
-#: ../raster/r.spread/main.c:281
+#: ../raster/r.neighbors/main.c:386
+#, fuzzy, c-format
+msgid "Opening selection map <%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.stats.zonal/main.c:105
msgid ""
-"Name of the new raster map layer to contain the results of the cumulative "
-"spread time needed for a phenomenon to reach each cell from the starting "
-"sources (minutes)."
+"Calculates category or object oriented statistics (accumulator-based "
+"statistics)."
msgstr ""
-#: ../raster/r.spread/main.c:291
+#: ../raster/r.stats.zonal/main.c:115 ../raster/r.statistics/main.c:69
+msgid "Method of object-based statistic"
+msgstr ""
+#: ../raster/r.stats.zonal/main.c:138 ../raster/r.statistics/main.c:92
#, fuzzy
-msgid "Name of raster map to contain X back coordinates"
+msgid "Resultant raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.spread/main.c:293
-msgid ""
-"Name of the new raster map layer to contain the results of backlink "
-"information in UTM easting coordinates for each cell."
+#: ../raster/r.stats.zonal/main.c:144 ../raster/r.statistics/main.c:98
+msgid "Cover values extracted from the category labels of the cover map"
msgstr ""
-#: ../raster/r.spread/main.c:303
+#: ../raster/r.stats.zonal/main.c:149 ../raster/r.stats.quantile/main.c:562
+msgid "Create reclass map with statistics as category labels"
+msgstr ""
+#: ../raster/r.stats.zonal/main.c:165 ../raster/r.statistics/main.c:118
+#: ../raster/r.proj/main.c:237 ../vector/v.vect.stats/main.c:263
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:152
+#: ../imagery/i.rectify/main.c:172
+#, c-format
+msgid "<%s=%s> unknown %s"
+msgstr ""
+#: ../raster/r.stats.zonal/main.c:178
+#, fuzzy, c-format
+msgid "Unable to read category file of cover map <%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.stats.zonal/main.c:181 ../raster/r.stats.quantile/main.c:622
#, fuzzy
-msgid "Name of raster map to contain Y back coordinates"
+msgid "The base map must be an integer (CELL) map"
msgstr "출력할 격자지도"
-#: ../raster/r.spread/main.c:305
+#: ../raster/r.stats.zonal/main.c:184 ../raster/r.stats.quantile/main.c:625
+#, fuzzy, c-format
+msgid "Unable to read range of base map <%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.stats.zonal/main.c:248
+msgid "First pass"
+msgstr ""
+#: ../raster/r.stats.zonal/main.c:327
+msgid "Second pass"
+msgstr ""
+#: ../raster/r.stats.zonal/main.c:474
+#, fuzzy
+msgid "Generating reclass map"
+msgstr "출력할 격자지도"
+#: ../raster/r.stats.zonal/main.c:482 ../raster/r.stats.quantile/main.c:427
+#: ../raster/r.proj/readcell.c:59 ../raster/r.proj/readcell.c:129
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:64
+#: ../imagery/i.rectify/readcell.c:58
+#, fuzzy
+msgid "Unable to open temporary file"
+msgstr "출력할 격자지도"
+#: ../raster/r.stats.zonal/main.c:496
+#, fuzzy
+msgid "Writing output map"
+msgstr "출력할 격자지도"
+#: ../raster/r.series/main.c:141
msgid ""
-"information in UTM northing coordinates for each cell."
+"Makes each output cell value a function of the values assigned to the "
+"corresponding cells in the input raster map layers."
msgstr ""
-#: ../raster/r.spread/main.c:312
-msgid "DISPLAY 'live' spread process on screen"
+#: ../raster/r.series/main.c:150
+msgid ""
+"Input file with one raster map name and optional one weight per line, field "
+"separator between name and weight is |"
msgstr ""
-#: ../raster/r.spread/main.c:314
+#: ../raster/r.series/main.c:176
msgid ""
-"Display the 'live' simulation on screen. A graphics window must be opened "
-"and selected before using this option."
+"Weighting factor for each input map, default value is 1.0 for each input map"
msgstr ""
-#: ../raster/r.spread/main.c:320
-msgid "Consider spotting effect (for wildfires)"
+#: ../raster/r.series/main.c:250 ../raster/r.series/main.c:312
+#, fuzzy
+msgid "Weights must be positive"
+msgstr "출력할 격자지도"
+#: ../raster/r.series/main.c:268 ../raster/r.series/main.c:318
+#, fuzzy, c-format
+msgid "Reading raster map <%s> using weight %f..."
+msgstr "출력할 격자지도"
+#: ../raster/r.series/main.c:298
+msgid "input= and weights= must have the same number of values"
msgstr ""
-#: ../raster/r.spread/main.c:324
+#: ../raster/r.series/main.c:333
+msgid "output= and method= must have the same number of values"
+msgstr ""
+#: ../raster/r.series/main.c:351
+#, c-format
+msgid "Method %s not compatible with weights, using unweighed version instead"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:153
+msgid "aspect"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:154
+msgid "slope"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:155
+msgid "curvature"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:156
+msgid ""
+"Generates raster maps of slope, aspect, curvatures and partial derivatives "
+"from an elevation raster map."
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:158
+msgid "Aspect is calculated counterclockwise from east."
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:165 ../vector/v.surf.rst/main.c:195
#, fuzzy
-msgid "Use start raster map values in output spread time raster map"
+msgid "Name for output slope raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.spread/main.c:326
+#: ../raster/r.slope.aspect/main.c:166 ../raster/r.slope.aspect/main.c:172
+#: ../raster/r.slope.aspect/main.c:196 ../raster/r.slope.aspect/main.c:203
+#: ../raster/r.slope.aspect/main.c:210 ../raster/r.slope.aspect/main.c:217
+#: ../raster/r.slope.aspect/main.c:224 ../raster/r.slope.aspect/main.c:231
+#: ../raster/r.slope.aspect/main.c:238 ../raster/r.watershed/front/main.c:134
+#: ../raster/r.watershed/front/main.c:141
+#: ../raster/r.watershed/front/main.c:148
+#: ../raster/r.watershed/front/main.c:154
+#: ../raster/r.watershed/front/main.c:160
+#: ../raster/r.watershed/front/main.c:166
+#: ../raster/r.watershed/front/main.c:174
+#: ../raster/r.watershed/front/main.c:182
+#: ../raster/r.watershed/front/main.c:189 ../vector/v.surf.rst/main.c:166
+#: ../vector/v.surf.rst/main.c:190 ../vector/v.surf.rst/main.c:196
+#: ../vector/v.surf.rst/main.c:202 ../vector/v.surf.rst/main.c:208
+#: ../vector/v.surf.rst/main.c:214 ../vector/v.surf.rst/main.c:220
+#: ../vector/v.surf.rst/main.c:226 ../vector/v.surf.rst/main.c:233
+#: ../vector/v.surf.rst/main.c:240 ../vector/v.surf.rst/main.c:247
+#: ../vector/v.vol.rst/main.c:291 ../vector/v.vol.rst/main.c:297
+#: ../vector/v.vol.rst/main.c:360 ../vector/v.vol.rst/main.c:366
+#: ../vector/v.vol.rst/main.c:372 ../vector/v.vol.rst/main.c:379
+#: ../vector/v.vol.rst/main.c:385 ../vector/v.vol.rst/main.c:391
+#: ../vector/v.vol.rst/main.c:397 ../vector/v.vol.rst/main.c:403
+#: ../vector/v.surf.bspline/main.c:130 ../vector/v.surf.bspline/main.c:135
+msgid "Outputs"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:171 ../vector/v.surf.rst/main.c:201
+#, fuzzy
+msgid "Name for output aspect raster map"
+msgstr "출력할 격자지도"
+#: ../raster/r.slope.aspect/main.c:180
+msgid "Format for reporting the slope"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:187
+msgid "Type of output aspect and slope maps"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:195 ../vector/v.surf.rst/main.c:207
+#, fuzzy
+msgid "Name for output profile curvature raster map"
+msgstr "출력할 격자지도"
+#: ../raster/r.slope.aspect/main.c:202 ../vector/v.surf.rst/main.c:213
+#, fuzzy
+msgid "Name for output tangential curvature raster map"
+msgstr "출력할 격자지도"
+#: ../raster/r.slope.aspect/main.c:209
msgid ""
-"Designed to be used with output of previous run of r.spread when computing "
-"spread iteratively. The values in start raster map are considered as time. "
-"Allowed values in raster map are from zero to the value of init_time option. "
-"If not enabled, init_time is used in the area of start raster map"
+"Name for output first order partial derivative dx (E-W slope) raster map"
msgstr ""
-#: ../raster/r.spread/main.c:502
+#: ../raster/r.slope.aspect/main.c:216
+msgid ""
+"Name for output first order partial derivative dy (N-S slope) raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:223
+msgid "Name for output second order partial derivative dxx raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:230
+msgid "Name for output second order partial derivative dyy raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:237
+msgid "Name for output second order partial derivative dxy raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:243
+msgid "Multiplicative factor to convert elevation units to horizontal units"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:252
+msgid "Minimum slope value (in percent) for which aspect is computed"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:261
#, fuzzy
-msgid "Reading inputs..."
+msgid "Do not align the current region to the raster elevation map"
msgstr "출력할 격자지도"
-#: ../raster/r.spread/main.c:543
+#: ../raster/r.slope.aspect/main.c:336
#, c-format
-msgid "Maximum of start raster map is grater than init_time (%d > %d)"
+msgid ""
+"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <"
+"%s>, <%s>, <%s>, <%s> or <%s>"
msgstr ""
-#: ../raster/r.spread/main.c:547
+#: ../raster/r.slope.aspect/main.c:358
+#, fuzzy, c-format
+msgid "Wrong raster type: %s"
+msgstr "출력할 격자지도"
+#: ../raster/r.slope.aspect/main.c:387
+msgid ""
+"r.slope.aspect does not convert horizontal units to meters in this version, "
+"see manual page."
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:968
+#, fuzzy, c-format
+msgid "Elevation products for mapset <%s> in <%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.slope.aspect/main.c:987
#, c-format
-msgid "Minimum of start raster map is less than zero (%d < 0)"
+msgid "Min computed aspect %.4f, max computed aspect %.4f"
msgstr ""
-#: ../raster/r.spread/main.c:555
+#: ../raster/r.slope.aspect/main.c:1051
+#, fuzzy, c-format
+msgid "Aspect raster map <%s> complete"
+msgstr "출력할 격자지도"
+#: ../raster/r.slope.aspect/main.c:1108
#, c-format
-msgid "Reading %s..."
+msgid "Min computed slope %.4f, max computed slope %.4f"
msgstr ""
+#: ../raster/r.slope.aspect/main.c:1161
+#, fuzzy, c-format
+msgid "Slope raster map <%s> complete"
+msgstr "출력할 격자지도"
+#: ../raster/r.slope.aspect/main.c:1233
+#, fuzzy, c-format
+msgid "Profile curve raster map <%s> complete"
+msgstr "출력할 격자지도"
+#: ../raster/r.slope.aspect/main.c:1260
+#, fuzzy, c-format
+msgid "Tangential curve raster map <%s> complete"
+msgstr "출력할 격자지도"
+#: ../raster/r.slope.aspect/main.c:1285
+#, fuzzy, c-format
+msgid "E-W slope raster map <%s> complete"
+msgstr "출력할 격자지도"
+#: ../raster/r.slope.aspect/main.c:1310
+#, fuzzy, c-format
+msgid "N-S slope raster map <%s> complete"
+msgstr "출력할 격자지도"
+#: ../raster/r.slope.aspect/main.c:1335
+#, fuzzy, c-format
+msgid "Dxx raster map <%s> complete"
+msgstr "출력할 격자지도"
+#: ../raster/r.slope.aspect/main.c:1360
+#, fuzzy, c-format
+msgid "Dyy raster map <%s> complete"
+msgstr "출력할 격자지도"
+#: ../raster/r.slope.aspect/main.c:1385
+#, fuzzy, c-format
+msgid "Dxy raster map <%s> complete"
+msgstr "출력할 격자지도"
+#: ../raster/r.report/stats.c:93
+#, fuzzy, c-format
+msgid "Unable to open result file <%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.report/stats.c:128 ../raster/r.kappa/stats.c:14
+msgid "Problem reading r.stats output"
+msgstr ""
+#: ../raster/r.report/main.c:69
+msgid "Reports statistics for raster maps."
+msgstr "격자지도의 통계를 보고합니다"
+#: ../raster/r.report/label.c:13
+msgid "Page width is too small"
+msgstr ""
#: ../raster/r.report/parse.c:38 ../raster/r.stats/main.c:114
msgid "Name of raster map(s) to report on"
msgstr "보고에 쓰일 격자지도의 이름"
@@ -11980,34 +12917,6 @@
msgid "If no output file given report is printed to standard output"
msgstr "출력파일을 지정하지 않으면 표준출력으로 출력합니다"
-#: ../raster/r.report/parse.c:69 ../raster/r.report/parse.c:77
-#: ../raster/r.report/parse.c:85 ../raster/r.report/parse.c:109
-#: ../raster/r.report/parse.c:114 ../raster/r.report/parse.c:119
-#: ../raster/r.report/parse.c:124 ../raster/r.stats.quantile/main.c:557
-#: ../raster/r.stats/main.c:123 ../raster/r.stats/main.c:127
-#: ../raster/r.stats/main.c:151 ../raster/r.kappa/main.c:104
-#: ../raster/r.kappa/main.c:109 ../raster/r.univar/r.univar_main.c:56
-#: ../raster/r.univar/r.univar_main.c:62 ../raster/r.univar/r.univar_main.c:72
-#: ../locale/scriptstrings/t.list_to_translate.c:11
-#: ../locale/scriptstrings/t.list_to_translate.c:17
-#: ../locale/scriptstrings/t.list_to_translate.c:19
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:12
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:14
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:16
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:8
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:14
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:16
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:15
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:17
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:9
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:12
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:9
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:12
-msgid "Formatting"
-msgstr ""
#: ../raster/r.report/parse.c:75
msgid "Page length"
msgstr ""
@@ -12107,1061 +13016,1422 @@
msgid "Unable to read category file of raster map <%s@%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.report/main.c:69
-msgid "Reports statistics for raster maps."
-msgstr "격자지도의 통계를 보고합니다"
+#: ../raster/r.his/main.c:68 ../display/d.his/main.c:64
+#: ../imagery/i.his.rgb/main.c:47 ../imagery/i.rgb.his/main.c:47
+msgid "color transformation"
+msgstr "색상 변형"
-#: ../raster/r.report/stats.c:93
-#, fuzzy, c-format
-msgid "Unable to open result file <%s>"
-msgstr "출력할 격자지도"
-#: ../raster/r.report/stats.c:128 ../raster/r.kappa/stats.c:14
-msgid "Problem reading r.stats output"
+#: ../raster/r.his/main.c:73
+msgid ""
+"Generates red, green and blue (RGB) raster map layers combining hue, "
+"intensity and saturation (HIS) values from user-specified input raster map "
+"layers."
msgstr ""
-#: ../raster/r.report/label.c:13
-msgid "Page width is too small"
-msgstr ""
+#: ../raster/r.his/main.c:82 ../display/d.his/main.c:78
+#, fuzzy
+msgid "Name of layer to be used for hue"
+msgstr "출력할 격자지도"
-#: ../raster/r.in.lidar/main.c:116
-msgid "Creates a raster map from LAS LiDAR points using univariate statistics."
-msgstr ""
-#: ../raster/r.in.lidar/main.c:139 ../raster/r.in.xyz/main.c:179
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:15
-msgid "Statistic to use for raster values"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:143 ../raster/r.in.lidar/main.c:234
-#: ../raster/r.in.lidar/main.c:244 ../raster/r.in.xyz/main.c:183
-#: ../raster/r.in.xyz/main.c:314 ../raster/r.in.xyz/main.c:323
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:16
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:32
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:34
-msgid "Statistic"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:158 ../raster/r.in.xyz/main.c:198
+#: ../raster/r.his/main.c:89 ../display/d.his/main.c:85
#, fuzzy
-msgid "Number of points in cell"
+msgid "Name of layer to be used for intensity"
msgstr "출력할 격자지도"
-#: ../raster/r.in.lidar/main.c:159 ../raster/r.in.xyz/main.c:199
+#: ../raster/r.his/main.c:96 ../display/d.his/main.c:92
#, fuzzy
-msgid "Minimum value of point values in cell"
+msgid "Name of layer to be used for saturation"
msgstr "출력할 격자지도"
-#: ../raster/r.in.lidar/main.c:160 ../raster/r.in.xyz/main.c:200
+#: ../raster/r.his/main.c:103
#, fuzzy
-msgid "Maximum value of point values in cell"
+msgid "Name of output layer to be used for red"
msgstr "출력할 격자지도"
-#: ../raster/r.in.lidar/main.c:161 ../raster/r.in.xyz/main.c:201
+#: ../raster/r.his/main.c:110
#, fuzzy
-msgid "Range of point values in cell"
+msgid "Name of output layer to be used for green"
msgstr "출력할 격자지도"
-#: ../raster/r.in.lidar/main.c:162 ../raster/r.in.xyz/main.c:202
+#: ../raster/r.his/main.c:117
#, fuzzy
-msgid "Sum of point values in cell"
+msgid "Name of output layer to be used for blue"
msgstr "출력할 격자지도"
-#: ../raster/r.in.lidar/main.c:163 ../raster/r.in.xyz/main.c:203
-msgid "Mean (average) value of point values in cell"
+#: ../raster/r.his/main.c:145
+#, c-format
+msgid "No such color <%s>"
msgstr ""
-#: ../raster/r.in.lidar/main.c:164 ../raster/r.in.xyz/main.c:204
-msgid "Standard deviation of point values in cell"
+#: ../raster/r.his/main.c:167 ../raster/r.his/main.c:183
+#: ../raster/r.his/main.c:201 ../raster/r.out.ppm3/main.c:115
+#: ../display/d.his/main.c:139 ../display/d.his/main.c:156
+#: ../display/d.his/main.c:174 ../display/d.colortable/main.c:135
+#: ../display/d.rast/display.c:23 ../display/d.rast.num/main.c:253
+#: ../display/d.legend/main.c:409 ../display/d.legend/main.c:417
+#: ../display/d.histogram/main.c:171 ../display/d.rgb/main.c:99
+#, c-format
+msgid "Color file for <%s> not available"
msgstr ""
-#: ../raster/r.in.lidar/main.c:165 ../raster/r.in.xyz/main.c:205
+#: ../raster/r.category/main.c:53 ../vector/v.category/main.c:76
#, fuzzy
-msgid "Variance of point values in cell"
+msgid "category"
msgstr "출력할 격자지도"
-#: ../raster/r.in.lidar/main.c:166 ../raster/r.in.xyz/main.c:206
-msgid "Coefficient of variance of point values in cell"
+#: ../raster/r.category/main.c:55
+msgid ""
+"Manages category values and labels associated with user-specified raster map "
+"layers."
msgstr ""
-#: ../raster/r.in.lidar/main.c:167 ../raster/r.in.xyz/main.c:207
-#, fuzzy
-msgid "Median value of point values in cell"
-msgstr "출력할 격자지도"
+#: ../raster/r.category/main.c:69
+msgid "Comma separated value list"
+msgstr ""
-#: ../raster/r.in.lidar/main.c:168 ../raster/r.in.xyz/main.c:208
-msgid "pth (nth) percentile of point values in cell"
+#: ../raster/r.category/main.c:70
+msgid "Example: 1.4,3.8,13"
msgstr ""
-#: ../raster/r.in.lidar/main.c:169 ../raster/r.in.xyz/main.c:209
-#, fuzzy
-msgid "Skewness of point values in cell"
-msgstr "출력할 격자지도"
+#: ../raster/r.category/main.c:87
+msgid "File containing category label rules (or \"-\" to read from stdin)"
+msgstr ""
-#: ../raster/r.in.lidar/main.c:170 ../raster/r.in.xyz/main.c:210
-#, fuzzy
-msgid "Trimmed mean of point values in cell"
+#: ../raster/r.category/main.c:95
+msgid "Default label or format string for dynamic labeling"
+msgstr ""
+#: ../raster/r.category/main.c:97
+msgid "Used when no explicit label exists for the category"
+msgstr ""
+#: ../raster/r.category/main.c:105
+msgid "Dynamic label coefficients"
+msgstr ""
+#: ../raster/r.category/main.c:107
+msgid "Two pairs of category multiplier and offsets, for $1 and $2"
+msgstr ""
+#: ../raster/r.category/main.c:130 ../raster/r.support/main.c:147
+#, fuzzy, c-format
+msgid "Raster map <%s> not found in current mapset"
msgstr "출력할 격자지도"
-#: ../raster/r.in.lidar/main.c:180
-#, fuzzy
-msgid "Subtract raster values from the Z coordinates"
+#: ../raster/r.category/main.c:152
+#, fuzzy, c-format
+msgid "Category table for <%s> set from <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.in.lidar/main.c:182
+#: ../raster/r.category/main.c:211
+#, c-format
msgid ""
-"The scale for Z is applied beforehand, the range filter for Z afterwards"
+"Incorrect format of input rules. Check separators. Invalid line is:\n"
+"%s"
msgstr ""
-#: ../raster/r.in.lidar/main.c:191
-#, fuzzy
-msgid "Filter range for Z data (min,max)"
+#: ../raster/r.category/main.c:267
+#, fuzzy, c-format
+msgid "Unable to read category file of raster map <%s> in <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.in.lidar/main.c:224 ../raster/r.in.xyz/main.c:304
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:30
-msgid "Percent of map to keep in memory"
+#: ../raster/r.category/main.c:283
+msgid "The map is floating point! Ignoring cats list, using vals list"
msgstr ""
-#: ../raster/r.in.lidar/main.c:233 ../raster/r.in.xyz/main.c:313
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:31
-msgid "pth percentile of the values"
+#: ../raster/r.category/main.c:300
+msgid "vals argument is required for floating point map!"
msgstr ""
-#: ../raster/r.in.lidar/main.c:241
-msgid "Discard given percentage of the smallest and largest values"
-msgstr ""
+#: ../raster/r.category/cats.c:47
+#, fuzzy, c-format
+msgid "Reading <%s> in <%s>"
+msgstr "출력할 격자지도"
-#: ../raster/r.in.lidar/main.c:243 ../raster/r.in.xyz/main.c:322
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:33
+#: ../raster/r.composite/main.c:76
msgid ""
-"Discard <trim> percent of the smallest and <trim> percent of the largest "
-"observations"
+"Combines red, green and blue raster maps into a single composite raster map."
msgstr ""
-#: ../raster/r.in.lidar/main.c:251
-#, fuzzy
-msgid "Output raster resolution"
-msgstr "출력할 격자지도"
+#: ../raster/r.composite/main.c:90 ../raster/r.out.ppm3/main.c:64
+#: ../display/d.rgb/main.c:69
+#, c-format
+msgid "Name of raster map to be used for <%s>"
+msgstr ""
-#: ../raster/r.in.lidar/main.c:281
-msgid "Use the extent of the input for the raster extent"
+#: ../raster/r.composite/main.c:102
+msgid "Number of levels to be used for each component"
msgstr ""
-#: ../raster/r.in.lidar/main.c:283
-msgid "Set internally computational region extents based on the point cloud"
+#: ../raster/r.composite/main.c:103 ../raster/r.composite/main.c:121
+msgid "Levels"
msgstr ""
-#: ../raster/r.in.lidar/main.c:290
-#, fuzzy
-msgid "Set computation region to match the new raster map"
-msgstr "출력할 격자지도"
+#: ../raster/r.composite/main.c:118
+#, c-format
+msgid "Number of levels to be used for <%s>"
+msgstr ""
-#: ../raster/r.in.lidar/main.c:292
-msgid ""
-"Set computation region to match the 2D extent and resolution of the newly "
-"created new raster map"
+#: ../raster/r.composite/main.c:128
+msgid "Dither"
msgstr ""
-#: ../raster/r.in.lidar/main.c:315
-msgid "Use intensity values rather than Z values"
+#: ../raster/r.composite/main.c:132
+msgid "Use closest color"
msgstr ""
-#: ../raster/r.in.lidar/main.c:317
-msgid "Uses intensity values everywhere as if they would be Z coordinates"
+#: ../raster/r.composite/main.c:164
+#, fuzzy, c-format
+msgid "Unable to read color file of raster map <%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.composite/main.c:191 ../raster/r.random.cells/indep.c:139
+#: ../raster/r.drain/main.c:519 ../raster/r.random.surface/save.c:98
+#: ../imagery/i.ifft/main.c:207
+#, fuzzy, c-format
+msgid "Writing raster map <%s>..."
+msgstr "출력할 격자지도"
+#: ../raster/r.composite/main.c:262 ../raster/r.li/r.li.daemon/daemon.c:174
+#: ../raster/r.surf.fractal/main.c:85 ../raster/r.surf.random/main.c:66
+#: ../raster/r.circle/main.c:153
+#, c-format
+msgid "Raster map <%s> created."
+msgstr "격자지도 <%s>를 생성했습니다."
+#: ../raster/r.composite/main.c:286
+#, fuzzy
+msgid "Creating color table for output raster map..."
+msgstr "출력할 격자지도"
+#: ../raster/r.spreadpath/main.c:89 ../raster/r.spread/main.c:106
+#: ../raster/r.ros/main.c:213
+msgid "fire"
msgstr ""
-#: ../raster/r.in.lidar/main.c:323
-msgid "Use Z values for filtering, but intensity values for statistics"
+#: ../raster/r.spreadpath/main.c:90 ../raster/r.walk/main.c:180
+#: ../raster/r.cost/main.c:142
+msgid "cumulative costs"
msgstr ""
-#: ../raster/r.in.lidar/main.c:328
-#, fuzzy
-msgid "Use base raster resolution instead of computational region"
-msgstr "와일드카드 대신 기본 정규표현식을 사용합니다"
-#: ../raster/r.in.lidar/main.c:330
+#: ../raster/r.spreadpath/main.c:92
msgid ""
-"For getting values from base raster, use its actual resolution instead of "
-"computational region resolution"
+"Recursively traces the least cost path backwards to cells from which the "
+"cumulative cost was determined."
msgstr ""
-#: ../raster/r.in.lidar/main.c:357
-#, c-format
-msgid "Flag %c makes sense only with %s option or -%c flag"
+#: ../raster/r.spreadpath/main.c:98
+msgid "Name of raster map containing back-path easting information"
msgstr ""
-#: ../raster/r.in.lidar/main.c:384
-msgid "zrange will not be taken into account during scan"
+#: ../raster/r.spreadpath/main.c:103
+#, fuzzy
+msgid "Name of raster map containing back-path northing information"
+msgstr "출력할 격자지도"
+#: ../raster/r.spreadpath/main.c:108
+msgid "The map E and N grid coordinates of starting points"
msgstr ""
-#: ../raster/r.in.lidar/main.c:459
+#: ../raster/r.spreadpath/main.c:161
#, fuzzy, c-format
-msgid "Unknown filter option <%s>"
+msgid "eading the input map -%s- and -%s- and creating some temporary files..."
msgstr "출력할 격자지도"
-#: ../raster/r.in.lidar/main.c:477 ../raster/r.in.xyz/main.c:374
-msgid "Invalid zrange"
-msgstr ""
+#: ../raster/r.spreadpath/main.c:281
+#, fuzzy
+msgid "Finding the least cost paths ..."
+msgstr "출력할 격자지도"
-#: ../raster/r.in.lidar/main.c:491
+#: ../raster/r.spreadpath/main.c:296
#, fuzzy, c-format
-msgid "Invalid %s"
+msgid "Writing the output map -%s-..."
msgstr "출력할 격자지도"
-#: ../raster/r.in.lidar/main.c:523 ../general/g.region/main.c:798
+#: ../raster/r.describe/main.c:57
+msgid "Prints terse list of category values found in a raster map layer."
+msgstr ""
+#: ../raster/r.describe/main.c:71
+msgid "Number of quantization steps"
+msgstr ""
+#: ../raster/r.describe/main.c:77
+msgid "Print the output one value per line"
+msgstr ""
+#: ../raster/r.describe/main.c:81
+msgid "Only print the range of the data"
+msgstr ""
+#: ../raster/r.describe/main.c:85
+msgid "Suppress reporting of any NULLs"
+msgstr ""
+#: ../raster/r.describe/main.c:89
+msgid "Use the current region"
+msgstr ""
+#: ../raster/r.describe/main.c:93
+#, fuzzy
+msgid "Read floating-point map as integer"
+msgstr "부동소수점 지도를 지도의 퀀트 규칙을 이용해서 정수로 읽습니다"
+#: ../raster/r.describe/main.c:105
#, c-format
-msgid "Invalid input <%s=%s>"
+msgid "%s = %s -- must be greater than zero"
msgstr ""
-#: ../raster/r.in.lidar/main.c:526
+#: ../raster/r.describe/describe.c:94
#, fuzzy, c-format
-msgid "Option '%s' must be > 0.0"
+msgid "Reading <%s> ..."
msgstr "출력할 격자지도"
-#: ../raster/r.in.lidar/main.c:594
-#, c-format
-msgid ""
-"Unable to process the hole map at once. Please set the '%s' option to some "
-"value lower than 100."
+#: ../raster/r.surf.contour/main.c:64
+#, fuzzy
+msgid "Generates surface raster map from rasterized contours."
+msgstr "출력할 격자지도"
+#: ../raster/r.surf.contour/main.c:67
+#, fuzzy
+msgid "Name of input raster map containing contours"
+msgstr "출력할 격자지도"
+#: ../raster/r.in.mat/main.c:94
+msgid "Imports a binary MAT-File(v4) to a GRASS raster."
msgstr ""
-#: ../raster/r.in.lidar/main.c:606
+#: ../raster/r.in.mat/main.c:101
#, fuzzy
-msgid "Reading data ..."
+msgid "Name of input MAT-File(v4)"
msgstr "출력할 격자지도"
-#: ../raster/r.in.lidar/main.c:614 ../raster/r.in.xyz/main.c:636
-#: ../raster/r.in.poly/poly2rast.c:56
-#, c-format
-msgid "Pass #%d (of %d) ..."
+#: ../raster/r.in.mat/main.c:105
+#, fuzzy
+msgid "Name for output raster map (override)"
+msgstr "출력할 격자지도"
+#: ../raster/r.in.mat/main.c:149
+#, fuzzy
+msgid "Reading MAT-File..."
+msgstr "출력할 격자지도"
+#: ../raster/r.in.mat/main.c:175
+msgid "Array contains no data"
msgstr ""
-#: ../raster/r.in.lidar/main.c:753
-msgid "Writing to map ..."
+#: ../raster/r.in.mat/main.c:180
+msgid "Array contains imaginary data"
msgstr ""
-#: ../raster/r.in.lidar/main.c:791
+#: ../raster/r.in.mat/main.c:186
+msgid "Invalid array name"
+msgstr ""
+#: ../raster/r.in.mat/main.c:206
+msgid "Invalid 'map_name' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:216
+msgid "Error reading 'map_name' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:227
+msgid "Invalid 'map_northern_edge' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:236
+msgid "Invalid 'map_southern_edge' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:245
+msgid "Invalid 'map_eastern_edge' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:254
+msgid "Invalid 'map_western_edge' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:262
+msgid "Invalid 'map_title' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:272
+msgid "Error reading 'map_title' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:285
+msgid "Invalid 'map_data' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:311 ../raster/r.in.mat/main.c:443
+#: ../raster/r.in.mat/main.c:522
+msgid "Please contact the GRASS development team"
+msgstr ""
+#: ../raster/r.in.mat/main.c:316
#, c-format
-msgid "%lu input points were invalid and filtered out"
+msgid "Skipping unknown array '%s'"
msgstr ""
-#: ../raster/r.in.lidar/main.c:794
+#: ../raster/r.in.mat/main.c:344
#, c-format
-msgid "%lu input points were invalid, use -%c flag to filter them out"
+msgid "No 'map_data' array found in <%s>"
msgstr ""
-#: ../raster/r.in.lidar/main.c:797
+#: ../raster/r.in.mat/main.c:351
#, c-format
-msgid "Raster map <%s> created. %lu points from %d files found in region."
+msgid "Setting map name to <%s> which overrides <%s>"
msgstr ""
-#: ../raster/r.in.lidar/main.c:802
-#, fuzzy, c-format
-msgid "Raster map <%s> created. %lu points found in region."
-msgstr "출력할 격자지도"
+#: ../raster/r.in.mat/main.c:358
+#, c-format
+msgid "Setting map name to <%s>"
+msgstr ""
-#: ../raster/r.in.lidar/point_binning.c:205 ../raster/r.in.xyz/main.c:474
-msgid "Unable to calculate percentile without the pth option specified!"
+#: ../raster/r.in.mat/main.c:362
+msgid "No 'map_name' array found; using <MatFile>"
msgstr ""
-#: ../raster/r.in.lidar/point_binning.c:217 ../raster/r.in.xyz/main.c:486
-msgid "Unable to calculate trimmed mean without the trim option specified!"
+#: ../raster/r.in.mat/main.c:373
+msgid "Missing bound"
msgstr ""
-#: ../raster/r.usler/main.c:54
-msgid "rainfall"
+#: ../raster/r.in.mat/main.c:377
+msgid "Using default bounds"
msgstr ""
-#: ../raster/r.usler/main.c:57
-msgid "Computes USLE R factor, Rainfall erosivity index."
+#: ../raster/r.in.mat/main.c:391
+#, c-format
+msgid "Map <%s> bounds set to:"
msgstr ""
-#: ../raster/r.usler/main.c:60
-#, fuzzy
-msgid "Name of annual precipitation raster map [mm/year]"
-msgstr "출력할 격자지도"
+#: ../raster/r.in.mat/main.c:392 ../raster/r.out.mat/main.c:174
+#, c-format
+msgid "northern edge=%f"
+msgstr ""
-#: ../raster/r.usler/main.c:63
-#, fuzzy
-msgid "Name for output USLE R raster map [MJ.mm/ha.hr.year]"
-msgstr "출력할 격자지도"
+#: ../raster/r.in.mat/main.c:393 ../raster/r.out.mat/main.c:175
+#, c-format
+msgid "southern edge=%f"
+msgstr ""
-#: ../raster/r.usler/main.c:70
-#, fuzzy
-msgid "Name of USLE R equation"
-msgstr "출력할 격자지도"
-#: ../raster/r.usler/main.c:75
-msgid "Roosle (1975)"
+#: ../raster/r.in.mat/main.c:394 ../raster/r.out.mat/main.c:176
+#, c-format
+msgid "eastern edge=%f"
msgstr ""
-#: ../raster/r.usler/main.c:76
-msgid "Morgan (1974)"
+#: ../raster/r.in.mat/main.c:395 ../raster/r.out.mat/main.c:177
+#, c-format
+msgid "western edge=%f"
msgstr ""
-#: ../raster/r.usler/main.c:77
-msgid "Foster (1981)"
+#: ../raster/r.in.mat/main.c:396 ../raster/r.out.mat/main.c:178
+#, c-format
+msgid "nsres=%f"
msgstr ""
-#: ../raster/r.usler/main.c:78
-msgid "El-Swaify (1985)"
+#: ../raster/r.in.mat/main.c:397 ../raster/r.out.mat/main.c:179
+#, c-format
+msgid "ewres=%f"
msgstr ""
-#: ../raster/r.relief/main.c:108 ../raster/r.param.scale/interface.c:57
-#: ../locale/scriptstrings/d.shade_to_translate.c:3
-#: ../locale/scriptstrings/r.plane_to_translate.c:3
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
-#: ../locale/scriptstrings/r.shade_to_translate.c:3
+#: ../raster/r.in.mat/main.c:408
#, fuzzy
-msgid "elevation"
+msgid "Writing new raster map..."
msgstr "출력할 격자지도"
-#: ../raster/r.relief/main.c:109
-#: ../locale/scriptstrings/d.shade_to_translate.c:4
-#: ../locale/scriptstrings/r.shade_to_translate.c:4
-msgid "relief"
+#: ../raster/r.sunhours/solpos00.c:994 ../raster/r.sunmask/solpos00.c:950
+#, c-format
+msgid "S_decode ==> Please fix the year: %d [1950-2050]"
msgstr ""
-#: ../raster/r.relief/main.c:111
-#: ../locale/scriptstrings/d.shade_to_translate.c:5
-#: ../locale/scriptstrings/r.shade_to_translate.c:5
-msgid "hillshade"
+#: ../raster/r.sunhours/solpos00.c:997 ../raster/r.sunmask/solpos00.c:953
+#, c-format
+msgid "S_decode ==> Please fix the month: %d"
msgstr ""
-#: ../raster/r.relief/main.c:112
-msgid "Creates shaded relief map from an elevation map (DEM)."
+#: ../raster/r.sunhours/solpos00.c:999 ../raster/r.sunmask/solpos00.c:955
+#, c-format
+msgid "S_decode ==> Please fix the day-of-month: %d"
msgstr ""
-#: ../raster/r.relief/main.c:117
-#, fuzzy
-msgid "Name for output shaded relief map"
-msgstr "출력할 격자지도"
+#: ../raster/r.sunhours/solpos00.c:1002 ../raster/r.sunmask/solpos00.c:958
+#, c-format
+msgid "S_decode ==> Please fix the day-of-year: %d"
+msgstr ""
-#: ../raster/r.relief/main.c:125
-msgid "Altitude of the sun in degrees above the horizon"
+#: ../raster/r.sunhours/solpos00.c:1005 ../raster/r.sunmask/solpos00.c:961
+#, c-format
+msgid "S_decode ==> Please fix the hour: %d"
msgstr ""
-#: ../raster/r.relief/main.c:126 ../raster/r.relief/main.c:136
-#, fuzzy
-msgid "Sun position"
-msgstr "출력할 격자지도"
+#: ../raster/r.sunhours/solpos00.c:1007 ../raster/r.sunmask/solpos00.c:963
+#, c-format
+msgid "S_decode ==> Please fix the minute: %d"
+msgstr ""
-#: ../raster/r.relief/main.c:135
-msgid "Azimuth of the sun in degrees to the east of north"
+#: ../raster/r.sunhours/solpos00.c:1009 ../raster/r.sunmask/solpos00.c:965
+#, c-format
+msgid "S_decode ==> Please fix the second: %d"
msgstr ""
-#: ../raster/r.relief/main.c:143
-msgid "Factor for exaggerating relief"
+#: ../raster/r.sunhours/solpos00.c:1011 ../raster/r.sunmask/solpos00.c:967
+#, c-format
+msgid "S_decode ==> Please fix the time zone: %f"
msgstr ""
-#: ../raster/r.relief/main.c:151
-msgid "Scale factor for converting meters to elevation units"
+#: ../raster/r.sunhours/solpos00.c:1014 ../raster/r.sunmask/solpos00.c:970
+#, c-format
+msgid "S_decode ==> Please fix the interval: %d"
msgstr ""
-#: ../raster/r.relief/main.c:158
-msgid "Elevation units (overrides scale factor)"
+#: ../raster/r.sunhours/solpos00.c:1017 ../raster/r.sunmask/solpos00.c:973
+#, c-format
+msgid "S_decode ==> Please fix the latitude: %f"
msgstr ""
-#: ../raster/r.relief/main.c:163
-#, fuzzy
-msgid "international feet"
-msgstr "출력할 격자지도"
+#: ../raster/r.sunhours/solpos00.c:1020 ../raster/r.sunmask/solpos00.c:976
+#, c-format
+msgid "S_decode ==> Please fix the longitude: %f"
+msgstr ""
-#: ../raster/r.relief/main.c:164
-msgid "survey feet"
+#: ../raster/r.sunhours/solpos00.c:1023 ../raster/r.sunmask/solpos00.c:979
+#, c-format
+msgid "S_decode ==> Please fix the temperature: %f"
msgstr ""
-#: ../raster/r.relief/main.c:197 ../raster/r.in.gdal/main.c:349
-#: ../raster/r.in.gdal/main.c:696 ../vector/v.kernel/main.c:239
+#: ../raster/r.sunhours/solpos00.c:1026 ../raster/r.sunmask/solpos00.c:982
#, c-format
-msgid "Raster map <%s> already exists"
-msgstr "격자지도 <%s>가 이미 존재합니다"
+msgid "S_decode ==> Please fix the pressure: %f"
+msgstr ""
-#: ../raster/r.relief/main.c:215
+#: ../raster/r.sunhours/solpos00.c:1028 ../raster/r.sunmask/solpos00.c:984
#, c-format
-msgid "%s=%s - must not be zero"
+msgid "S_decode ==> Please fix the tilt: %f"
msgstr ""
-#: ../raster/r.relief/main.c:474
-#, fuzzy, c-format
-msgid "Shaded relief raster map <%s> complete"
-msgstr "출력할 격자지도"
+#: ../raster/r.sunhours/solpos00.c:1030 ../raster/r.sunmask/solpos00.c:986
+#, c-format
+msgid "S_decode ==> Please fix the aspect: %f"
+msgstr ""
-#: ../raster/r.support.stats/main.c:37
-msgid "Update raster map statistics"
+#: ../raster/r.sunhours/solpos00.c:1032 ../raster/r.sunmask/solpos00.c:988
+#, c-format
+msgid "S_decode ==> Please fix the shadowband width: %f"
msgstr ""
-#: ../raster/r.support.stats/main.c:49
-#, fuzzy, c-format
-msgid "Statistics for <%s> updated"
-msgstr "출력할 격자지도"
+#: ../raster/r.sunhours/solpos00.c:1035 ../raster/r.sunmask/solpos00.c:991
+#, c-format
+msgid "S_decode ==> Please fix the shadowband radius: %f"
+msgstr ""
-#: ../raster/r.support.stats/check.c:43
+#: ../raster/r.sunhours/solpos00.c:1038 ../raster/r.sunmask/solpos00.c:994
#, c-format
-msgid "Updating statistics for [%s]..."
+msgid "S_decode ==> Please fix the shadowband sky factor: %f"
msgstr ""
-#: ../raster/r.support.stats/check.c:56
-msgid "Updating histogram range..."
+#: ../raster/r.sunhours/main.c:73 ../raster/r.sun/main.c:240
+#: ../raster/r.horizon/main.c:181 ../raster/r.sunmask/main.c:117
+msgid "solar"
msgstr ""
-#: ../raster/r.support.stats/check.c:88
-#, c-format
-msgid "Updating the number of categories for [%s]..."
+#: ../raster/r.sunhours/main.c:74 ../raster/r.sun/main.c:241
+msgid "sun energy"
msgstr ""
-#: ../raster/r.grow.distance/main.c:151 ../raster/r.distance/main.c:40
-#: ../locale/scriptstrings/r.grow_to_translate.c:3
-#: ../display/d.rhumbline/main.c:45 ../display/d.geodesic/main.c:47
-#: ../misc/m.measure/main.c:48 ../misc/m.cogo/main.c:226
-#: ../vector/v.distance/main.c:91
-msgid "distance"
+#: ../raster/r.sunhours/main.c:75 ../raster/r.horizon/main.c:182
+#: ../raster/r.sunmask/main.c:118
+msgid "sun position"
msgstr ""
-#: ../raster/r.grow.distance/main.c:152
-#: ../locale/scriptstrings/r.grow_to_translate.c:4
-msgid "proximity"
+#: ../raster/r.sunhours/main.c:76
+msgid "Calculates solar elevation, solar azimuth, and sun hours."
msgstr ""
-#: ../raster/r.grow.distance/main.c:154
+#: ../raster/r.sunhours/main.c:77
+msgid ""
+"Solar elevation: the angle between the direction of the geometric center of "
+"the sun's apparent disk and the (idealized) horizon. Solar azimuth: the "
+"angle from due north in clockwise direction."
+msgstr ""
+#: ../raster/r.sunhours/main.c:83
#, fuzzy
-msgid "Generates a raster map containing distances to nearest raster features."
+msgid "Output raster map with solar elevation angle"
msgstr "출력할 격자지도"
-#: ../raster/r.grow.distance/main.c:161
+#: ../raster/r.sunhours/main.c:88
#, fuzzy
-msgid "Name for distance output raster map"
+msgid "Output raster map with solar azimuth angle"
msgstr "출력할 격자지도"
-#: ../raster/r.grow.distance/main.c:167
+#: ../raster/r.sunhours/main.c:93
#, fuzzy
-msgid "Name for value output raster map"
+msgid "Output raster map with sunshine hours"
msgstr "출력할 격자지도"
-#: ../raster/r.grow.distance/main.c:174
-#: ../locale/scriptstrings/r.grow_to_translate.c:7
-msgid "Metric"
+#: ../raster/r.sunhours/main.c:94
+msgid "Sunshine hours require SOLPOS use and Greenwich standard time"
msgstr ""
-#: ../raster/r.grow.distance/main.c:180
-msgid "Output distances in meters instead of map units"
+#: ../raster/r.sunhours/main.c:101
+msgid "Year"
msgstr ""
-#: ../raster/r.grow.distance/main.c:184
-#, fuzzy
-msgid "Calculate distance to nearest NULL cell"
-msgstr "출력할 격자지도"
+#: ../raster/r.sunhours/main.c:103 ../raster/r.sunhours/main.c:112
+#: ../raster/r.sunhours/main.c:120 ../raster/r.sunhours/main.c:129
+#: ../raster/r.sunhours/main.c:138 ../raster/r.sunhours/main.c:147
+#: ../raster/r.sun/main.c:444 ../raster/r.sun/main.c:453
+#: ../raster/r.sun/main.c:470 ../raster/r.sun/main.c:508
+#: ../raster/r.sunmask/main.c:153 ../raster/r.sunmask/main.c:161
+#: ../raster/r.sunmask/main.c:169 ../raster/r.sunmask/main.c:177
+#: ../raster/r.sunmask/main.c:185 ../raster/r.sunmask/main.c:194
+#: ../raster/r.sunmask/main.c:203 ../imagery/i.landsat.toar/main.c:207
+msgid "Time"
+msgstr ""
-#: ../raster/r.grow.distance/main.c:195
-msgid "Distance output is required for distance to NULL cells"
+#: ../raster/r.sunhours/main.c:109
+msgid "Month"
msgstr ""
-#: ../raster/r.grow.distance/main.c:197
-msgid "Value output is meaningless for distance to NULL cells"
+#: ../raster/r.sunhours/main.c:110
+msgid "If not given, day is interpreted as day of the year"
msgstr ""
-#: ../raster/r.grow.distance/main.c:203
-#, fuzzy
-msgid "At least one of distance= and value= must be given"
-msgstr "출력할 격자지도"
+#: ../raster/r.sunhours/main.c:118
+msgid "Day"
+msgstr ""
-#: ../raster/r.grow.distance/main.c:218
-msgid "metric=geodesic is only valid for lat/lon"
+#: ../raster/r.sunhours/main.c:126
+msgid "Hour"
msgstr ""
-#: ../raster/r.grow.distance/main.c:224
-#, c-format
-msgid "Unknown metric: '%s'"
+#: ../raster/r.sunhours/main.c:135
+msgid "Minutes"
msgstr ""
-#: ../raster/r.grow.distance/main.c:229
-#, c-format
-msgid "Output distance in meters for lat/lon is only possible with '%s=%s'"
+#: ../raster/r.sunhours/main.c:144
+msgid "Seconds"
msgstr ""
-#: ../raster/r.grow.distance/main.c:249
-#, fuzzy, c-format
-msgid "Unable to create temporary file <%s>"
-msgstr "출력할 격자지도"
+#: ../raster/r.sunhours/main.c:151
+msgid "Time is local sidereal time, not Greenwich standard time"
+msgstr ""
-#: ../raster/r.grow.distance/main.c:325 ../raster/r.stream.extract/close.c:248
-#: ../raster/r.fill.dir/main.c:253
-#, fuzzy
-msgid "Writing output raster maps..."
-msgstr "출력할 격자지도"
+#: ../raster/r.sunhours/main.c:155
+msgid "Do not use SOLPOS algorithm of NREL"
+msgstr ""
-#: ../raster/r.grow.distance/main.c:382 ../raster/r.colors/edit_colors.c:396
-#: ../raster/r.fill.dir/main.c:153 ../raster/r.colors.out/raster_main.c:69
-#: ../vector/v.colors/main.c:315
-#, fuzzy, c-format
-msgid "Unable to read color table for raster map <%s>"
-msgstr "출력할 격자지도"
+#: ../raster/r.sunhours/main.c:167
+msgid "No output requested, exiting."
+msgstr ""
-#: ../raster/r.stats.quantile/main.c:86
-#, fuzzy
-msgid "Computing histograms"
-msgstr "출력할 격자지도"
+#: ../raster/r.sunhours/main.c:193
+msgid "NREL SOLPOS algorithm uses Greenwich standard time."
+msgstr ""
-#: ../raster/r.stats.quantile/main.c:123
-msgid "No cells found where both base and cover are not NULL"
+#: ../raster/r.sunhours/main.c:194 ../raster/r.sunhours/main.c:202
+msgid "Time will be interpreted as Greenwich standard time."
msgstr ""
-#: ../raster/r.stats.quantile/main.c:174 ../raster/r.quantile/main.c:100
-#, fuzzy
-msgid "Computing bins"
-msgstr "출력할 격자지도"
+#: ../raster/r.sunhours/main.c:200
+msgid "Time will be interpreted as local sidereal time."
+msgstr ""
-#: ../raster/r.stats.quantile/main.c:231 ../raster/r.quantile/main.c:138
+#: ../raster/r.sunhours/main.c:205
+msgid "Sunshine hours require NREL SOLPOS."
+msgstr ""
+#: ../raster/r.sunhours/main.c:210
+msgid "Current projection is x,y (undefined)."
+msgstr ""
+#: ../raster/r.sunhours/main.c:216
#, fuzzy
-msgid "Binning data"
+msgid "Cannot get projection info of current location"
msgstr "출력할 격자지도"
-#: ../raster/r.stats.quantile/main.c:287 ../raster/r.quantile/main.c:183
+#: ../raster/r.sunhours/main.c:219
#, fuzzy
-msgid "Sorting bins"
+msgid "Cannot get projection units of current location"
msgstr "출력할 격자지도"
-#: ../raster/r.stats.quantile/main.c:315
+#: ../raster/r.sunhours/main.c:222
#, fuzzy
-msgid "Printing quantiles"
+msgid "Cannot get projection key values of current location"
msgstr "출력할 격자지도"
-#: ../raster/r.stats.quantile/main.c:360 ../raster/r.quantile/main.c:193
+#: ../raster/r.sunhours/main.c:324 ../raster/r.sunhours/main.c:335
+#: ../raster/r.sunhours/main.c:346 ../raster/r.mapcalc/map3.c:606
+#: ../imagery/i.landsat.toar/main.c:567
+#: ../imagery/i.landsat.acca/algorithm.c:234
+#: ../imagery/i.landsat.acca/algorithm.c:388
+#: ../imagery/i.landsat.acca/tools.c:136
+#, c-format
+msgid "Unable to create raster map <%s>"
+msgstr ""
+#: ../raster/r.sunhours/main.c:356
#, fuzzy
-msgid "Computing quantiles"
+msgid "Calculating solar elevation and azimuth..."
msgstr "출력할 격자지도"
-#: ../raster/r.stats.quantile/main.c:412
+#: ../raster/r.sunhours/main.c:359
#, fuzzy
-msgid "Generating reclass maps"
+msgid "Calculating solar elevation..."
msgstr "출력할 격자지도"
-#: ../raster/r.stats.quantile/main.c:454
+#: ../raster/r.sunhours/main.c:362
#, fuzzy
-msgid "Writing output maps"
+msgid "Calculating solar azimuth..."
msgstr "출력할 격자지도"
-#: ../raster/r.stats.quantile/main.c:518
-msgid "Compute category quantiles using two passes."
+#: ../raster/r.what.color/main.c:91
+msgid "Queries colors for a raster map layer."
msgstr ""
-#: ../raster/r.stats.quantile/main.c:528 ../raster/r.quantile/main.c:272
+#: ../raster/r.what.color/main.c:99
#, fuzzy
-msgid "Number of quantiles"
+msgid "Name of existing raster map to query colors"
msgstr "출력할 격자지도"
-#: ../raster/r.stats.quantile/main.c:534 ../raster/r.quantile/main.c:280
-msgid "List of percentiles"
+#: ../raster/r.what.color/main.c:106
+msgid "Values to query colors for"
msgstr ""
-#: ../raster/r.stats.quantile/main.c:541 ../raster/r.quantile/main.c:286
+#: ../raster/r.what.color/main.c:113
+msgid "Output format (printf-style)"
+msgstr ""
+#: ../raster/r.what.color/main.c:117
+msgid "Read values from stdin"
+msgstr ""
+#: ../raster/r.what.color/main.c:123
+msgid "Either \"-i\" or \"value=\" must be given"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:151
+msgid ""
+"Reinterpolates and optionally computes topographic analysis from input "
+"raster map to a new raster map (possibly with different resolution) using "
+"regularized spline with tension and smoothing."
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:162
+msgid "Desired east-west resolution"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:168
+msgid "Desired north-south resolution"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:173
#, fuzzy
-msgid "Number of bins to use"
+msgid "Name for output elevation raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.stats.quantile/main.c:545
+#: ../raster/r.resamp.rst/main.c:179
#, fuzzy
-msgid "Resultant raster map(s)"
+msgid "Name for output slope map (or fx)"
msgstr "출력할 격자지도"
-#: ../raster/r.stats.quantile/main.c:562 ../raster/r.stats.zonal/main.c:149
-msgid "Create reclass map with statistics as category labels"
-msgstr ""
+#: ../raster/r.resamp.rst/main.c:185
+#, fuzzy
+msgid "Name for output aspect map (or fy)"
+msgstr "출력할 격자지도"
-#: ../raster/r.stats.quantile/main.c:567
+#: ../raster/r.resamp.rst/main.c:191
#, fuzzy
-msgid "Do not create output maps; just print statistics"
+msgid "Name for output profile curvature map (or fxx)"
msgstr "출력할 격자지도"
-#: ../raster/r.stats.quantile/main.c:572
+#: ../raster/r.resamp.rst/main.c:197
#, fuzzy
-msgid "Print statistics in table format"
+msgid "Name for output tangential curvature map (or fyy)"
msgstr "출력할 격자지도"
-#: ../raster/r.stats.quantile/main.c:584
-#, fuzzy, c-format
-msgid "Either -%c or %s= must be given"
+#: ../raster/r.resamp.rst/main.c:203
+#, fuzzy
+msgid "Name for output mean curvature map (or fxy)"
msgstr "출력할 격자지도"
-#: ../raster/r.stats.quantile/main.c:588 ../raster/r.in.bin/main.c:426
-#: ../raster/r.in.bin/main.c:432 ../raster/r.out.bin/main.c:369
-#: ../raster/r.neighbors/main.c:262
-#, c-format
-msgid "-%c and %s= are mutually exclusive"
-msgstr "-%c와 %s=를 같이 지정할 수 없습니다"
-#: ../raster/r.stats.quantile/main.c:613
-#, c-format
-msgid "Number of quantiles (%d) does not match number of output maps (%d)"
-msgstr ""
-#: ../raster/r.stats.quantile/main.c:622 ../raster/r.stats.zonal/main.c:181
+#: ../raster/r.resamp.rst/main.c:209
#, fuzzy
-msgid "The base map must be an integer (CELL) map"
+msgid "Name of input raster map containing smoothing"
msgstr "출력할 격자지도"
-#: ../raster/r.stats.quantile/main.c:625 ../raster/r.stats.zonal/main.c:184
-#, fuzzy, c-format
-msgid "Unable to read range of base map <%s>"
+#: ../raster/r.resamp.rst/main.c:215
+#, fuzzy
+msgid "Name of input raster map to be used as mask"
msgstr "출력할 격자지도"
-#: ../raster/r.stats.quantile/main.c:630
-#, c-format
-msgid ""
-"Base map <%s> has many categories (%d), computation might be slow and might "
-"need a lot of memory"
+#: ../raster/r.resamp.rst/main.c:223
+msgid "Rows/columns overlap for segmentation"
msgstr ""
-#: ../raster/r.profile/input.c:30 ../raster/r.profile/input.c:47
-#: ../raster/r.profile/input.c:60
-msgid "One coordinate pair per line, please"
+#: ../raster/r.resamp.rst/main.c:231
+msgid "Multiplier for z-values"
msgstr ""
-#: ../raster/r.profile/main.c:56
-msgid "Outputs the raster map layer values lying on user-defined line(s)."
+#: ../raster/r.resamp.rst/main.c:239
+msgid "Spline tension value"
msgstr ""
-#: ../raster/r.profile/main.c:64 ../raster/r.horizon/main.c:304
-msgid "Name of file for output (use output=- for stdout)"
+#: ../raster/r.resamp.rst/main.c:246 ../vector/v.surf.rst/main.c:325
+msgid "Anisotropy angle (in degrees counterclockwise from East)"
msgstr ""
-#: ../raster/r.profile/main.c:69 ../display/d.profile/main.c:203
-msgid "Profile coordinate pairs"
+#: ../raster/r.resamp.rst/main.c:247 ../raster/r.resamp.rst/main.c:254
+msgid "Anisotropy"
msgstr ""
-#: ../raster/r.profile/main.c:75
+#: ../raster/r.resamp.rst/main.c:253 ../vector/v.surf.rst/main.c:332
+msgid "Anisotropy scaling factor"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:258
+msgid "Use dnorm independent tension"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:263 ../vector/v.surf.rst/main.c:165
+msgid "Output partial derivatives instead of topographic parameters"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:297
#, fuzzy
-msgid "Name of input file containing coordinate pairs"
+msgid "Unable to read ew_res value"
msgstr "출력할 격자지도"
-#: ../raster/r.profile/main.c:77
+#: ../raster/r.resamp.rst/main.c:300
#, fuzzy
-msgid "Use instead of the 'coordinates' option. \"-\" reads from stdin."
+msgid "Unable to read ns_res value"
msgstr "출력할 격자지도"
-#: ../raster/r.profile/main.c:85
-msgid "Resolution along profile (default = current region resolution)"
+#: ../raster/r.resamp.rst/main.c:303
+msgid "Invalid value for tension"
msgstr ""
-#: ../raster/r.profile/main.c:98
-msgid "Output RRR:GGG:BBB color values for each profile point"
+#: ../raster/r.resamp.rst/main.c:306
+msgid "Invalid value for zmult"
msgstr ""
-#: ../raster/r.profile/main.c:103
-msgid ""
-"If units are not specified, current location units are used. Meters are used "
-"by default in geographic (latlon) locations."
+#: ../raster/r.resamp.rst/main.c:309
+msgid "Invalid value for overlap"
msgstr ""
-#: ../raster/r.profile/main.c:117
-msgid "Either use profile option or coordinate_file option, but not both"
+#: ../raster/r.resamp.rst/main.c:313
+msgid "Invalid value for theta"
msgstr ""
-#: ../raster/r.profile/main.c:144
-#, fuzzy, c-format
-msgid "Illegal resolution %g [%s]"
-msgstr "출력할 격자지도"
+#: ../raster/r.resamp.rst/main.c:317
+msgid "Invalid value for scalex"
+msgstr ""
-#: ../raster/r.profile/main.c:151
+#: ../raster/r.resamp.rst/main.c:319
+msgid "When using anisotropy both theta and scalex must be specified"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:357
#, c-format
-msgid "Using resolution: %g [%s]"
+msgid "Map <%s> is the wrong resolution"
msgstr ""
-#: ../raster/r.profile/main.c:182
-#, fuzzy
-msgid "Output columns:"
-msgstr "출력할 격자지도"
+#: ../raster/r.resamp.rst/main.c:365
+msgid "Smoothing values can not be negative or NULL"
+msgstr ""
-#: ../raster/r.profile/main.c:185
+#: ../raster/r.resamp.rst/main.c:371
+msgid "Input map resolution differs from current region resolution!"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:387
+msgid "Processing all selected output files will require"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:391
#, c-format
-msgid "Easting, Northing, Along track dist. [%s], Elevation"
+msgid "%.2f GB of disk space for temp files."
msgstr ""
-#: ../raster/r.profile/main.c:187
+#: ../raster/r.resamp.rst/main.c:394
#, c-format
-msgid "Along track dist. [%s], Elevation"
+msgid "%.2f MB of disk space for temp files."
msgstr ""
-#: ../raster/r.profile/main.c:189
-#, fuzzy
-msgid " RGB color"
-msgstr "문자색상"
-#: ../raster/r.profile/main.c:200
-#, fuzzy, c-format
-msgid "Could not open <%s>"
-msgstr "출력할 격자지도"
-#: ../raster/r.profile/main.c:207
+#: ../raster/r.resamp.rst/main.c:397
#, c-format
-msgid "Invalid coordinates %s %s"
+msgid "%.2f KB of disk space for temp files."
msgstr ""
-#: ../raster/r.profile/main.c:278
+#: ../raster/r.resamp.rst/main.c:400
#, c-format
-msgid "Approx. transect length: %f [%s]"
+msgid "%d byte of disk space for temp files."
+msgid_plural "%d bytes of disk space for temp files."
+msgstr[0] ""
+#: ../raster/r.resamp.rst/main.c:436
+msgid "Maximum value of a raster map is NULL."
msgstr ""
-#: ../raster/r.profile/main.c:281
-msgid "Endpoint coordinates are outside of current region settings"
+#: ../raster/r.resamp.rst/main.c:464
+msgid "Temporarily changing the region to desired resolution ..."
msgstr ""
-#: ../raster/r.horizon/main.c:182 ../raster/r.sunhours/main.c:75
-#: ../raster/r.sunmask/main.c:118
-msgid "sun position"
+#: ../raster/r.resamp.rst/main.c:469
+msgid "Changing back to the original region ..."
msgstr ""
-#: ../raster/r.horizon/main.c:184
-msgid "Computes horizon angle height from a digital elevation model."
+#: ../raster/r.resamp.rst/main.c:478 ../raster/r.resample/main.c:112
+msgid "Percent complete: "
msgstr ""
-#: ../raster/r.horizon/main.c:186
-msgid ""
-"The module has two different modes of operation: 1. Computes the entire "
-"horizon around a single point whose coordinates are given with the 'coord' "
-"option. The horizon height (in radians). 2. Computes one or more raster maps "
-"of the horizon height in a single direction. The input for this is the angle "
-"(in degrees), which is measured counterclockwise with east=0, north=90 etc. "
-"The output is the horizon height in radians."
+#: ../raster/r.resamp.rst/main.c:490
+#, c-format
+msgid "dnorm in mainc after grid before out1= %f"
msgstr ""
-#: ../raster/r.horizon/main.c:203
-msgid "Direction in which you want to know the horizon height"
+#: ../raster/r.resamp.rst/main.c:494
+msgid "split_and_interpolate() failed"
msgstr ""
-#: ../raster/r.horizon/main.c:220
-msgid "Start angle for multidirectional horizon [degrees]"
+#: ../raster/r.resamp.rst/main.c:509
+#, c-format
+msgid "dnorm in mainc after grid before out2= %f"
msgstr ""
-#: ../raster/r.horizon/main.c:221 ../raster/r.horizon/main.c:230
-#: ../raster/r.horizon/main.c:238 ../raster/r.horizon/main.c:246
-#: ../raster/r.horizon/main.c:254 ../raster/r.horizon/main.c:262
-#: ../raster/r.horizon/main.c:270 ../raster/r.horizon/main.c:283
+#: ../raster/r.resamp.rst/main.c:515
#, fuzzy
-msgid "Raster mode"
-msgstr "격자지도"
+msgid "Unable to write raster maps -- try increasing cell size"
+msgstr "출력할 격자지도"
-#: ../raster/r.horizon/main.c:229
-msgid "End angle for multidirectional horizon [degrees]"
+#: ../raster/r.out.ascii/main.c:63
+#, fuzzy
+msgid "Converts a raster map layer into a GRASS ASCII text file."
+msgstr "출력할 격자지도"
+#: ../raster/r.out.ascii/main.c:72
+msgid "Name for output ASCII grid map (use out=- for stdout)"
msgstr ""
-#: ../raster/r.horizon/main.c:237
+#: ../raster/r.out.ascii/main.c:86
msgid ""
-"For horizon rasters, read from the DEM an extra buffer around the present "
-"region"
+"Number of values printed before wrapping a line (only SURFER or MODFLOW "
+"format)"
msgstr ""
-#: ../raster/r.horizon/main.c:245
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer eastward the present "
-"region"
+#: ../raster/r.out.ascii/main.c:91
+msgid "String to represent null cell (GRASS grid only)"
msgstr ""
-#: ../raster/r.horizon/main.c:253
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer westward the present "
-"region"
+#: ../raster/r.out.ascii/main.c:99
+msgid "Write SURFER (Golden Software) ASCII grid"
msgstr ""
-#: ../raster/r.horizon/main.c:261
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer northward the present "
-"region"
+#: ../raster/r.out.ascii/main.c:103
+msgid "Write MODFLOW (USGS) ASCII array"
msgstr ""
-#: ../raster/r.horizon/main.c:269
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer southward the present "
-"region"
+#: ../raster/r.out.ascii/main.c:107
+msgid "Force output of integer values"
msgstr ""
-#: ../raster/r.horizon/main.c:277
-msgid "The maximum distance to consider when finding the horizon height"
+#: ../raster/r.out.ascii/main.c:114
+msgid "Failed to interpret dp as an integer"
msgstr ""
-#: ../raster/r.horizon/main.c:278 ../raster/r.horizon/main.c:297
-#: ../locale/scriptstrings/r.import_to_translate.c:27
-#: ../locale/scriptstrings/r.import_to_translate.c:29
-#, fuzzy
-msgid "Optional"
-msgstr "출력할 격자지도"
+#: ../raster/r.out.ascii/main.c:122
+msgid "Failed to interpret width as an integer"
+msgstr ""
-#: ../raster/r.horizon/main.c:288
-msgid "Coordinate for which you want to calculate the horizon"
+#: ../raster/r.out.ascii/main.c:128
+msgid "Both -s and -h doesn't make sense"
msgstr ""
-#: ../raster/r.horizon/main.c:289 ../raster/r.horizon/main.c:305
-#, fuzzy
-msgid "Point mode"
+#: ../raster/r.out.ascii/main.c:131
+msgid "Use -M or -s, not both"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:166
+#, fuzzy, c-format
+msgid "Unable to read fp range for <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.horizon/main.c:310
-msgid "Write output in degrees (default is radians)"
+#: ../raster/r.out.ascii/main.c:182
+#, fuzzy, c-format
+msgid "Read failed at row %d"
+msgstr "출력할 격자지도"
+#: ../raster/r.distance/distance.c:102
+#, c-format
+msgid "Reading maps <%s,%s> while finding 0 distance ..."
msgstr ""
-#: ../raster/r.horizon/main.c:315
-msgid "Write output in compass orientation (default is CCW, East=0)"
+#: ../raster/r.distance/report.c:61
+msgid "Processing..."
msgstr ""
-#: ../raster/r.horizon/main.c:355
-msgid ""
-"Note: In latitude-longitude coordinate system specify buffers in degree unit"
+#: ../raster/r.distance/main.c:42
+msgid "Locates the closest points between objects in two raster maps."
msgstr ""
-#: ../raster/r.horizon/main.c:368
-msgid "Can't read the coordinates from the \"coordinate\" option."
+#: ../raster/r.distance/edges.c:47
+#, c-format
+msgid "Reading map %s ..."
msgstr ""
-#: ../raster/r.horizon/main.c:395
-msgid "You didn't specify a direction value or step size. Aborting."
+#: ../raster/r.distance/parse.c:35
+#, fuzzy
+msgid "Name of two input raster maps for computing inter-class distances"
+msgstr "출력할 격자지도"
+#: ../raster/r.distance/parse.c:45
+msgid "Sort output by distance"
msgstr ""
-#: ../raster/r.horizon/main.c:400
-msgid "You didn't specify a horizon raster name. Aborting."
+#: ../raster/r.distance/parse.c:46
+#, fuzzy
+msgid "Default: sorted by categories"
+msgstr "기본값: 범주 또는 간격으로 정렬"
+#: ../raster/r.distance/parse.c:50
+#, fuzzy
+msgid "Sort by distance in ascending order"
+msgstr "셀의 개수로 오름차순 정렬"
+#: ../raster/r.distance/parse.c:51
+#, fuzzy
+msgid "Sort by distance in descending order"
+msgstr "셀의 개수로 내림차순 정렬"
+#: ../raster/r.distance/parse.c:55
+msgid "Include category labels in the output"
msgstr ""
-#: ../raster/r.horizon/main.c:415
-msgid "Negative values of start angle are not allowed. Aborting."
+#: ../raster/r.distance/parse.c:60
+msgid "Report zero distance if rasters are overlapping"
msgstr ""
-#: ../raster/r.horizon/main.c:419
-msgid "End angle is not between 0 and 360. Aborting."
+#: ../raster/r.distance/parse.c:64
+msgid "Report null objects as *"
msgstr ""
-#: ../raster/r.horizon/main.c:423
-msgid "You specify a start grater than the end angle. Aborting."
+#: ../raster/r.distance/parse.c:74 ../raster/r.distance/parse.c:83
+#, fuzzy, c-format
+msgid "Raster map <%s> is not CELL"
+msgstr "격자지도 <%s>를 찾지 못 했습니다"
+#: ../raster/r.random/main.c:54 ../raster/r.random.cells/main.c:49
+#: ../raster/r.surf.random/main.c:38 ../raster/r.surf.gauss/main.c:40
+#: ../raster/r.random.surface/main.c:59 ../vector/v.extract/main.c:81
+#: ../vector/v.random/main.c:100 ../vector/v.perturb/main.c:65
+msgid "random"
msgstr ""
-#: ../raster/r.horizon/main.c:431
-msgid "You didn't specify an angle step size. Aborting."
+#: ../raster/r.random/main.c:56
+#, fuzzy
+msgid ""
+"Creates a raster map layer and vector point map containing randomly located "
+"points."
+msgstr "출력할 격자지도"
+#: ../raster/r.random/main.c:60 ../raster/r.out.bin/main.c:290
+#: ../imagery/i.zc/main.c:65
+msgid "Name of input raster map"
msgstr ""
-#: ../raster/r.horizon/main.c:442
+#: ../raster/r.random/main.c:65
#, fuzzy
-msgid "Could not read bufferzone size. Aborting."
+msgid "Name of cover raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.horizon/main.c:447 ../raster/r.horizon/main.c:453
-#: ../raster/r.horizon/main.c:460 ../raster/r.horizon/main.c:467
-#, c-format
-msgid "Could not read %s bufferzone size. Aborting."
+#: ../raster/r.random/main.c:72
+msgid "The number of points to allocate"
msgstr ""
-#: ../raster/r.horizon/main.c:448
-msgid "east"
+#: ../raster/r.random/main.c:84
+msgid "Generate points also for NULL category"
msgstr ""
-#: ../raster/r.horizon/main.c:454
-msgid "west"
+#: ../raster/r.random/main.c:89
+msgid "Report information about input raster and exit"
msgstr ""
-#: ../raster/r.horizon/main.c:461
-msgid "south"
+#: ../raster/r.random/main.c:93
+msgid "Generate vector points as 3D points"
msgstr ""
-#: ../raster/r.horizon/main.c:468
-msgid "north"
+#: ../raster/r.random/main.c:96 ../vector/v.in.ascii/main.c:193
+msgid "Do not build topology in points mode"
msgstr ""
-#: ../raster/r.horizon/main.c:473
-msgid "Could not read maximum distance. Aborting."
+#: ../raster/r.random/main.c:97 ../display/d.linegraph/main.c:330
+#: ../display/d.linegraph/main.c:339 ../display/d.linegraph/main.c:348
+#: ../display/d.linegraph/main.c:363 ../vector/v.in.ascii/main.c:117
+#: ../vector/v.in.ascii/main.c:124 ../vector/v.in.ascii/main.c:136
+#: ../vector/v.in.ascii/main.c:146 ../vector/v.in.ascii/main.c:156
+#: ../vector/v.in.ascii/main.c:166 ../vector/v.in.ascii/main.c:190
+#: ../vector/v.in.ascii/main.c:194 ../vector/v.in.ascii/main.c:200
+#: ../vector/v.in.ascii/main.c:205 ../vector/v.out.ascii/args.c:40
+#: ../vector/v.out.ascii/args.c:66 ../vector/v.out.ascii/args.c:76
+#: ../vector/v.out.ascii/args.c:86 ../vector/v.out.ascii/args.c:92
+msgid "Points"
msgstr ""
-#: ../raster/r.horizon/main.c:484
-msgid "The distance value must be 0.5-1.5. Aborting."
+#: ../raster/r.random/main.c:133
+#, c-format
+msgid "Note: one (or both) of %s and %s must be specified"
msgstr ""
-#: ../raster/r.horizon/main.c:654 ../raster/r.in.ascii/main.c:187
+#: ../raster/r.random/main.c:141
#, c-format
-msgid "OOPS: rows changed from %d to %d"
+msgid "<%s=%s> invalid percentage"
msgstr ""
-#: ../raster/r.horizon/main.c:658 ../raster/r.in.ascii/main.c:190
+#: ../raster/r.random/main.c:148
#, c-format
-msgid "OOPS: cols changed from %d to %d"
+msgid "<%s=%s> invalid number of points"
msgstr ""
-#: ../raster/r.horizon/main.c:1174
-#, fuzzy, c-format
-msgid "Calculating map %01d of %01d (angle %.2f, raster map <%s>)"
-msgstr "출력할 격자지도"
+#: ../raster/r.random/main.c:161
+#, c-format
+msgid "There aren't [%ld] cells in the current region"
+msgstr ""
-#: ../raster/r.resample/main.c:57
-msgid "GRASS raster map layer data resampling capability."
+#: ../raster/r.random/main.c:164
+#, c-format
+msgid "There aren't [%ld] non-NULL cells in the current region"
msgstr ""
-#: ../raster/r.resample/main.c:66
-msgid "Name of an input layer"
+#: ../raster/r.random/main.c:169
+msgid "There are no valid locations in the current region"
msgstr ""
-#: ../raster/r.resample/main.c:73
-msgid "Name of an output layer"
+#: ../raster/r.random/random.c:43 ../raster/r.random/random.c:47
+#: ../raster/r.mapcalc/map3.c:517 ../imagery/i.landsat.toar/main.c:407
+#: ../imagery/i.landsat.toar/main.c:545 ../imagery/i.landsat.acca/main.c:57
+#: ../imagery/i.landsat.acca/algorithm.c:380
+#: ../imagery/i.landsat.acca/tools.c:126
+#, c-format
+msgid "Unable to open raster map <%s>"
msgstr ""
-#: ../raster/r.resample/main.c:112 ../raster/r.resamp.rst/main.c:478
-msgid "Percent complete: "
+#: ../raster/r.random/random.c:100
+msgid "Cannot create new table"
msgstr ""
-#: ../raster/r.resample/main.c:125 ../raster/r.in.png/main.c:485
-#: ../raster/r.basins.fill/main.c:146 ../raster/r.cross/main.c:169
+#: ../raster/r.random/random.c:110
+#, fuzzy, c-format
+msgid "Writing raster map <%s> and vector map <%s> ..."
+msgstr "출력할 격자지도"
+#: ../raster/r.random/random.c:113
+#, fuzzy, c-format
+msgid "Writing raster map <%s> ..."
+msgstr "출력할 격자지도"
+#: ../raster/r.random/random.c:115
+#, fuzzy, c-format
+msgid "Writing vector map <%s> ..."
+msgstr "출력할 격자지도"
+#: ../raster/r.random/random.c:190 ../vector/v.net.components/main.c:39
+#: ../vector/v.net.distance/main.c:363 ../vector/v.net.flow/main.c:262
+#: ../vector/v.net.timetable/main.c:134 ../vector/v.net.timetable/main.c:156
+#: ../vector/v.net.allpairs/main.c:271 ../vector/v.net.path/path.c:334
+#: ../vector/v.net.centrality/main.c:69
+#, fuzzy, c-format
+msgid "Cannot insert new record: %s"
+msgstr "출력할 격자지도"
+#: ../raster/r.random/random.c:243
#, c-format
-msgid "Creating support files for <%s>..."
-msgstr "<%s>를 위한 지원파일을 생성합니다..."
+msgid "Only [%ld] random points created"
+msgstr ""
-#: ../raster/r.resample/main.c:138
+#: ../raster/r.random/count.c:68
#, fuzzy
-msgid "Creating new cats file..."
+msgid "Collecting Stats..."
msgstr "출력할 격자지도"
-#: ../raster/r.uslek/main.c:57
-msgid "Computes USLE Soil Erodibility Factor (K)."
+#: ../raster/r.random/count.c:123
+msgid "Programmer error in get_stats/switch"
msgstr ""
-#: ../raster/r.uslek/main.c:62
+#: ../raster/r.volume/main.c:77
+msgid "volume"
+msgstr ""
+#: ../raster/r.volume/main.c:80
+msgid "Calculates the volume of data \"clumps\"."
+msgstr ""
+#: ../raster/r.volume/main.c:81
+msgid ""
+"Optionally produces a GRASS vector points map containing the calculated "
+"centroids of these clumps."
+msgstr ""
+#: ../raster/r.volume/main.c:86
#, fuzzy
-msgid "Name of soil sand fraction raster map [0.0-1.0]"
+msgid ""
+"Name of input raster map representing data that will be summed within clumps"
msgstr "출력할 격자지도"
-#: ../raster/r.uslek/main.c:66
+#: ../raster/r.volume/main.c:92
#, fuzzy
-msgid "Name of soil clay fraction raster map [0.0-1.0]"
+msgid "Name of input clump raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.uslek/main.c:70
+#: ../raster/r.volume/main.c:93
+msgid ""
+"Preferably the output of r.clump. If no clump map is given than MASK is used."
+msgstr ""
+#: ../raster/r.volume/main.c:99
#, fuzzy
-msgid "Name of soil silt fraction raster map [0.0-1.0]"
+msgid "Name for output vector points map to contain clump centroids"
msgstr "출력할 격자지도"
-#: ../raster/r.uslek/main.c:74
+#: ../raster/r.volume/main.c:110
+msgid "Generate unformatted report (items separated by colon)"
+msgstr ""
+#: ../raster/r.volume/main.c:143
+msgid ""
+"No MASK found. If no clump map is given than the MASK is required. You need "
+"to define a clump raster map or create a MASK by r.mask command."
+msgstr ""
+#: ../raster/r.volume/main.c:145
+msgid "No clump map given, using MASK"
+msgstr ""
+#: ../raster/r.volume/main.c:198
+#, c-format
+msgid "Invalid category value %d (max=%d): row=%d col=%d"
+msgstr ""
+#: ../raster/r.volume/main.c:231
+#, fuzzy, c-format
+msgid "Creating vector point map <%s>..."
+msgstr "출력할 격자지도"
+#: ../raster/r.volume/main.c:233
+#, fuzzy, c-format
+msgid "From '%s' on raster map <%s> using clumps from <%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.volume/main.c:266
+#, c-format
+msgid ""
+"\n"
+"Volume report on data from <%s> using clumps on <%s> raster map"
+msgstr ""
+#: ../raster/r.volume/main.c:270
+#, c-format
+msgid "Category Average Data # Cells Centroid Total\n"
+msgstr ""
+#: ../raster/r.volume/main.c:272
+#, c-format
+msgid "Number in clump Total in clump Easting Northing Volume"
+msgstr ""
+#: ../raster/r.volume/main.c:318
+msgid "Total Volume"
+msgstr ""
+#: ../raster/r.random.cells/main.c:50
#, fuzzy
-msgid "Name of soil organic matter raster map [0.0-1.0]"
+msgid "autocorrelation"
msgstr "출력할 격자지도"
-#: ../raster/r.uslek/main.c:77
+#: ../raster/r.random.cells/main.c:52
+msgid "Generates random cell values with spatial dependence."
+msgstr ""
+#: ../raster/r.random.cells/main.c:62 ../raster/r.random.surface/main.c:77
+msgid "Maximum distance of spatial correlation (value >= 0.0)"
+msgstr ""
+#: ../raster/r.random.cells/main.c:70
#, fuzzy
-msgid "Name for output USLE K factor raster map [t.ha.hr/ha.MJ.mm]"
+msgid "Maximum number of cells to be created"
msgstr "출력할 격자지도"
-#: ../raster/r.li/r.li.padcv/padcv.c:52
-msgid "Calculates coefficient of variation of patch area on a raster map"
+#: ../raster/r.random.cells/main.c:77
+msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default [random])"
msgstr ""
+#: ../raster/r.random.cells/random.c:50
+#, c-format
+msgid "RAN1: j == %d shouldn't happen"
+msgstr ""
+#: ../raster/r.random.cells/init.c:77
+msgid "Distance must be >= 0.0"
+msgstr ""
+#: ../raster/r.random.cells/init.c:96 ../raster/r.random.surface/main.c:128
+#, fuzzy, c-format
+msgid "Generating raster map <%s>..."
+msgstr "출력할 격자지도"
+#: ../raster/r.cross/renumber.c:33
+#, c-format
+msgid "%s: STEP 3 ... "
+msgstr ""
+#: ../raster/r.cross/cross.c:65
+#, c-format
+msgid "%s: STEP 1 ... "
+msgstr ""
+#: ../raster/r.cross/main.c:72
+msgid ""
+"Creates a cross product of the category values from multiple raster map "
+"layers."
+msgstr ""
+#: ../raster/r.cross/main.c:81
+#, c-format
+msgid "Names of 2-%d input raster maps"
+msgstr ""
+#: ../raster/r.cross/main.c:90
+msgid "Non-zero data only"
+msgstr ""
+#: ../raster/r.cross/main.c:103
+#, c-format
+msgid "More than %d files not allowed"
+msgstr ""
+#: ../raster/r.cross/main.c:119
+msgid "Must specify 2 or more input maps"
+msgstr ""
+#: ../raster/r.cross/main.c:136
+#, c-format
+msgid "%s: STEP 2 ..."
+msgstr ""
+#: ../raster/r.cross/main.c:179
+#, c-format
+msgid "%ld categories"
+msgstr ""
+#: ../raster/r.li/r.li.cwed/cwed.c:53
+msgid "Calculates contrast weighted edge density index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.cwed/cwed.c:55
+#: ../raster/r.li/r.li.padrange/padrange.c:54
+#: ../raster/r.li/r.li.renyi/renyi.c:48
+#: ../raster/r.li/r.li.dominance/dominance.c:47
+#: ../raster/r.li/r.li.shannon/shannon.c:47
#: ../raster/r.li/r.li.padcv/padcv.c:54 ../raster/r.li/r.li.mps/mps.c:53
+#: ../raster/r.li/r.li.patchdensity/main.c:52
+#: ../raster/r.li/r.li.shape/main.c:50 ../raster/r.li/r.li.mpa/mpa.c:45
+#: ../raster/r.li/r.li.padsd/padsd.c:54
#: ../raster/r.li/r.li.simpson/simpson.c:47
-#: ../raster/r.li/r.li.shannon/shannon.c:47
-#: ../raster/r.li/r.li.padrange/padrange.c:54
-#: ../raster/r.li/r.li.dominance/dominance.c:47
-#: ../raster/r.li/r.li.cwed/cwed.c:55 ../raster/r.li/r.li.pielou/pielou.c:47
+#: ../raster/r.li/r.li.richness/richness.c:44
#: ../raster/r.li/r.li.edgedensity/edgedensity.c:49
#: ../raster/r.li/r.li.patchnum/main.c:51
-#: ../raster/r.li/r.li.patchdensity/main.c:52
-#: ../raster/r.li/r.li.shape/main.c:50 ../raster/r.li/r.li.padsd/padsd.c:54
-#: ../raster/r.li/r.li.mpa/mpa.c:45 ../raster/r.li/r.li.richness/richness.c:44
-#: ../raster/r.li/r.li.renyi/renyi.c:48
+#: ../raster/r.li/r.li.pielou/pielou.c:47
#, fuzzy
msgid "landscape structure analysis"
msgstr "출력할 격자지도"
+#: ../raster/r.li/r.li.cwed/cwed.c:56
+#: ../raster/r.li/r.li.padrange/padrange.c:55
#: ../raster/r.li/r.li.padcv/padcv.c:55 ../raster/r.li/r.li.mps/mps.c:54
-#: ../raster/r.li/r.li.padrange/padrange.c:55
-#: ../raster/r.li/r.li.cwed/cwed.c:56
+#: ../raster/r.li/r.li.patchdensity/main.c:53
+#: ../raster/r.li/r.li.shape/main.c:51 ../raster/r.li/r.li.mpa/mpa.c:46
+#: ../raster/r.li/r.li.padsd/padsd.c:55
#: ../raster/r.li/r.li.edgedensity/edgedensity.c:50
#: ../raster/r.li/r.li.patchnum/main.c:52
-#: ../raster/r.li/r.li.patchdensity/main.c:53
-#: ../raster/r.li/r.li.shape/main.c:51 ../raster/r.li/r.li.padsd/padsd.c:55
-#: ../raster/r.li/r.li.mpa/mpa.c:46
msgid "patch index"
msgstr ""
+#: ../raster/r.li/r.li.cwed/cwed.c:64
+#: ../raster/r.li/r.li.padrange/padrange.c:62
+#: ../raster/r.li/r.li.renyi/renyi.c:57
+#: ../raster/r.li/r.li.dominance/dominance.c:56
+#: ../raster/r.li/r.li.shannon/shannon.c:56
#: ../raster/r.li/r.li.padcv/padcv.c:62 ../raster/r.li/r.li.mps/mps.c:62
+#: ../raster/r.li/r.li.patchdensity/main.c:61
+#: ../raster/r.li/r.li.shape/main.c:59 ../raster/r.li/r.li.mpa/mpa.c:53
+#: ../raster/r.li/r.li.padsd/padsd.c:62
#: ../raster/r.li/r.li.simpson/simpson.c:56
-#: ../raster/r.li/r.li.shannon/shannon.c:56
-#: ../raster/r.li/r.li.padrange/padrange.c:62
-#: ../raster/r.li/r.li.dominance/dominance.c:56
-#: ../raster/r.li/r.li.cwed/cwed.c:64 ../raster/r.li/r.li.pielou/pielou.c:56
+#: ../raster/r.li/r.li.richness/richness.c:53
#: ../raster/r.li/r.li.edgedensity/edgedensity.c:58
#: ../raster/r.li/r.li.patchnum/main.c:59
-#: ../raster/r.li/r.li.patchdensity/main.c:61
-#: ../raster/r.li/r.li.shape/main.c:59 ../raster/r.li/r.li.padsd/padsd.c:62
-#: ../raster/r.li/r.li.mpa/mpa.c:53 ../raster/r.li/r.li.richness/richness.c:53
-#: ../raster/r.li/r.li.renyi/renyi.c:57
+#: ../raster/r.li/r.li.pielou/pielou.c:56
msgid "Configuration file"
msgstr ""
-#: ../raster/r.li/r.li.mps/mps.c:51
-msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
+#: ../raster/r.li/r.li.cwed/cwed.c:70
+msgid "Name of file that contains the weight to calculate the index"
msgstr ""
-#: ../raster/r.li/r.li.simpson/simpson.c:45
-msgid "Calculates Simpson's diversity index on a raster map"
+#: ../raster/r.li/r.li.cwed/cwed.c:306 ../raster/r.li/r.li.cwed/cwed.c:453
+#: ../raster/r.li/r.li.cwed/cwed.c:599
+msgid "Row cache is too small"
msgstr ""
+#: ../raster/r.li/r.li.padrange/padrange.c:52
+msgid "Calculates range of patch area size on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.renyi/renyi.c:46
+#, fuzzy
+msgid "Calculates Renyi's diversity index on a raster map"
+msgstr "출력할 격자지도"
+#: ../raster/r.li/r.li.renyi/renyi.c:49
+#: ../raster/r.li/r.li.dominance/dominance.c:48
+#: ../raster/r.li/r.li.shannon/shannon.c:48
#: ../raster/r.li/r.li.simpson/simpson.c:48
-#: ../raster/r.li/r.li.shannon/shannon.c:48
-#: ../raster/r.li/r.li.dominance/dominance.c:48
+#: ../raster/r.li/r.li.richness/richness.c:45
#: ../raster/r.li/r.li.pielou/pielou.c:48
-#: ../raster/r.li/r.li.richness/richness.c:45
-#: ../raster/r.li/r.li.renyi/renyi.c:49
msgid "diversity index"
msgstr ""
-#: ../raster/r.li/r.li.shannon/shannon.c:45
-msgid "Calculates Shannon's diversity index on a raster map"
+#: ../raster/r.li/r.li.renyi/renyi.c:63
+msgid "Alpha value is the order of the generalized entropy"
msgstr ""
-#: ../raster/r.li/r.li.padrange/padrange.c:52
-msgid "Calculates range of patch area size on a raster map"
-msgstr ""
#: ../raster/r.li/r.li.dominance/dominance.c:45
msgid "Calculates dominance's diversity index on a raster map"
msgstr ""
-#: ../raster/r.li/r.li.cwed/cwed.c:53
-msgid "Calculates contrast weighted edge density index on a raster map"
+#: ../raster/r.li/r.li.shannon/shannon.c:45
+msgid "Calculates Shannon's diversity index on a raster map"
msgstr ""
-#: ../raster/r.li/r.li.cwed/cwed.c:70
-msgid "Name of file that contains the weight to calculate the index"
+#: ../raster/r.li/r.li.padcv/padcv.c:52
+msgid "Calculates coefficient of variation of patch area on a raster map"
msgstr ""
-#: ../raster/r.li/r.li.cwed/cwed.c:306 ../raster/r.li/r.li.cwed/cwed.c:453
-#: ../raster/r.li/r.li.cwed/cwed.c:599
-msgid "Row cache is too small"
-msgstr ""
-#: ../raster/r.li/r.li.pielou/pielou.c:45
-#, fuzzy
-msgid "Calculates Pielou's diversity index on a raster map"
-msgstr "출력할 격자지도"
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:47
+#: ../raster/r.li/r.li.mps/mps.c:51
msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+"Calculates mean patch size index on a raster map, using a 4 neighbour "
+"algorithm"
msgstr ""
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:68
-msgid "The value of the patch type"
-msgstr ""
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:69
+#: ../raster/r.li/r.li.patchdensity/main.c:50
msgid ""
-"It can be integer, double or float; it will be changed in function of map "
-"type"
+"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
msgstr ""
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:74
-msgid "Exclude border edges"
+#: ../raster/r.li/r.li.shape/main.c:48
+msgid "Calculates shape index on a raster map"
msgstr ""
-#: ../raster/r.li/r.li.daemon/worker.c:135
-#, c-format
-msgid "unable to open <%s> mask ... continuing without!"
-msgstr ""
#: ../raster/r.li/r.li.daemon/daemon.c:97
msgid "Cannot create random access file"
msgstr ""
@@ -13219,26 +14489,21 @@
msgid "Cannot make lseek"
msgstr ""
-#: ../raster/r.li/r.li.patchnum/main.c:49
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+#: ../raster/r.li/r.li.daemon/worker.c:135
+#, c-format
+msgid "unable to open <%s> mask ... continuing without!"
msgstr ""
-#: ../raster/r.li/r.li.patchdensity/main.c:50
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+#: ../raster/r.li/r.li.mpa/mpa.c:43
+msgid "Calculates mean pixel attribute index on a raster map"
msgstr ""
-#: ../raster/r.li/r.li.shape/main.c:48
-msgid "Calculates shape index on a raster map"
-msgstr ""
#: ../raster/r.li/r.li.padsd/padsd.c:52
msgid "Calculates standard deviation of patch area a raster map"
msgstr ""
-#: ../raster/r.li/r.li.mpa/mpa.c:43
-msgid "Calculates mean pixel attribute index on a raster map"
+#: ../raster/r.li/r.li.simpson/simpson.c:45
+msgid "Calculates Simpson's diversity index on a raster map"
msgstr ""
#: ../raster/r.li/r.li.richness/richness.c:42
@@ -13246,1475 +14511,1954 @@
msgid "Calculates richness index on a raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.li/r.li.renyi/renyi.c:46
-#, fuzzy
-msgid "Calculates Renyi's diversity index on a raster map"
-msgstr "출력할 격자지도"
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:47
+msgid ""
+"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
-#: ../raster/r.li/r.li.renyi/renyi.c:63
-msgid "Alpha value is the order of the generalized entropy"
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:68
+msgid "The value of the patch type"
msgstr ""
-#: ../raster/r.in.mat/main.c:94
-msgid "Imports a binary MAT-File(v4) to a GRASS raster."
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:69
+msgid ""
+"It can be integer, double or float; it will be changed in function of map "
+"type"
msgstr ""
-#: ../raster/r.in.mat/main.c:101
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:74
+msgid "Exclude border edges"
+msgstr ""
+#: ../raster/r.li/r.li.patchnum/main.c:49
+msgid ""
+"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgstr ""
+#: ../raster/r.li/r.li.pielou/pielou.c:45
#, fuzzy
-msgid "Name of input MAT-File(v4)"
+msgid "Calculates Pielou's diversity index on a raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.in.mat/main.c:105
+#: ../raster/r.drain/main.c:111 ../raster/r.walk/main.c:179
+#: ../raster/r.cost/main.c:141
+msgid "cost surface"
+msgstr ""
+#: ../raster/r.drain/main.c:113
#, fuzzy
-msgid "Name for output raster map (override)"
+msgid ""
+"Traces a flow through an elevation model or cost surface on a raster map."
msgstr "출력할 격자지도"
-#: ../raster/r.in.mat/main.c:149
+#: ../raster/r.drain/main.c:116
#, fuzzy
-msgid "Reading MAT-File..."
+msgid "Name of input elevation or cost surface raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.in.mat/main.c:175
-msgid "Array contains no data"
+#: ../raster/r.drain/main.c:121
+msgid "Name of input movement direction map associated with the cost surface"
msgstr ""
-#: ../raster/r.in.mat/main.c:180
-msgid "Array contains imaginary data"
+#: ../raster/r.drain/main.c:123 ../raster/r.drain/main.c:164
+msgid "Cost surface"
msgstr ""
-#: ../raster/r.in.mat/main.c:186
-msgid "Invalid array name"
-msgstr ""
+#: ../raster/r.drain/main.c:131
+#, fuzzy
+msgid "Name for output drain vector map"
+msgstr "출력할 격자지도"
-#: ../raster/r.in.mat/main.c:206
-msgid "Invalid 'map_name' array"
+#: ../raster/r.drain/main.c:132
+msgid "Recommended for cost surface made using knight's move"
msgstr ""
-#: ../raster/r.in.mat/main.c:216
-msgid "Error reading 'map_name' array"
-msgstr ""
+#: ../raster/r.drain/main.c:136 ../raster/r.walk/main.c:227
+#: ../raster/r.cost/main.c:192
+#, fuzzy
+msgid "Coordinates of starting point(s) (E,N)"
+msgstr "출력할 격자지도"
-#: ../raster/r.in.mat/main.c:227
-msgid "Invalid 'map_northern_edge' array"
+#: ../raster/r.drain/main.c:137 ../raster/r.drain/main.c:144
+#: ../raster/r.walk/main.c:209 ../raster/r.walk/main.c:221
+#: ../raster/r.walk/main.c:228 ../raster/r.walk/main.c:309
+#: ../raster/r.cost/main.c:174 ../raster/r.cost/main.c:186
+#: ../raster/r.cost/main.c:193 ../raster/r.cost/main.c:243
+msgid "Start"
msgstr ""
-#: ../raster/r.in.mat/main.c:236
-msgid "Invalid 'map_southern_edge' array"
-msgstr ""
+#: ../raster/r.drain/main.c:142
+#, fuzzy
+msgid "Name of starting vector points map(s)"
+msgstr "출력할 격자지도"
-#: ../raster/r.in.mat/main.c:245
-msgid "Invalid 'map_eastern_edge' array"
+#: ../raster/r.drain/main.c:148
+msgid "Copy input cell values on output"
msgstr ""
-#: ../raster/r.in.mat/main.c:254
-msgid "Invalid 'map_western_edge' array"
+#: ../raster/r.drain/main.c:152
+msgid "Accumulate input values along the path"
msgstr ""
-#: ../raster/r.in.mat/main.c:262
-msgid "Invalid 'map_title' array"
+#: ../raster/r.drain/main.c:153 ../raster/r.drain/main.c:158
+#, fuzzy
+msgid "Path settings"
+msgstr "출력할 격자지도"
+#: ../raster/r.drain/main.c:157
+msgid "Count cell numbers along the path"
msgstr ""
-#: ../raster/r.in.mat/main.c:272
-msgid "Error reading 'map_title' array"
+#: ../raster/r.drain/main.c:163
+msgid ""
+"The input raster map is a cost surface (direction surface must also be "
+"specified)"
msgstr ""
-#: ../raster/r.in.mat/main.c:285
-msgid "Invalid 'map_data' array"
+#: ../raster/r.drain/main.c:175
+msgid "Directional drain selected... checking for direction raster map"
msgstr ""
-#: ../raster/r.in.mat/main.c:311 ../raster/r.in.mat/main.c:443
-#: ../raster/r.in.mat/main.c:522
-msgid "Please contact the GRASS development team"
+#: ../raster/r.drain/main.c:178
+msgid "Surface/Hydrology drain selected"
msgstr ""
-#: ../raster/r.in.mat/main.c:316
+#: ../raster/r.drain/main.c:183
#, c-format
-msgid "Skipping unknown array '%s'"
+msgid ""
+"Direction raster map <%s> not specified, if direction flag is on, a "
+"direction raster must be given"
msgstr ""
-#: ../raster/r.in.mat/main.c:344
+#: ../raster/r.drain/main.c:190
#, c-format
-msgid "No 'map_data' array found in <%s>"
+msgid ""
+"Direction raster map <%s> should not be specified for Surface/Hydrology "
+"drains"
msgstr ""
-#: ../raster/r.in.mat/main.c:351
-#, c-format
-msgid "Setting map name to <%s> which overrides <%s>"
+#: ../raster/r.drain/main.c:209
+msgid "Specify just one of the -c, -a and -n flags"
msgstr ""
-#: ../raster/r.in.mat/main.c:358
+#: ../raster/r.drain/main.c:240
#, c-format
-msgid "Setting map name to <%s>"
+msgid "Starting point %d is outside the current region"
msgstr ""
-#: ../raster/r.in.mat/main.c:362
-msgid "No 'map_name' array found; using <MatFile>"
-msgstr ""
+#: ../raster/r.drain/main.c:270 ../raster/r.walk/main.c:675
+#: ../raster/r.cost/main.c:535
+#, fuzzy, c-format
+msgid "Reading vector map <%s> with start points..."
+msgstr "출력할 격자지도"
-#: ../raster/r.in.mat/main.c:373
-msgid "Missing bound"
-msgstr ""
+#: ../raster/r.drain/main.c:315
+#, fuzzy, c-format
+msgid "Starting vector map <%s> contains no points in the current region"
+msgstr "출력할 격자지도"
-#: ../raster/r.in.mat/main.c:377
-msgid "Using default bounds"
+#: ../raster/r.drain/main.c:323
+msgid "No start/stop point(s) specified"
msgstr ""
-#: ../raster/r.in.mat/main.c:391
-#, c-format
-msgid "Map <%s> bounds set to:"
-msgstr ""
+#: ../raster/r.drain/main.c:398
+#, fuzzy
+msgid "Calculating flow directions..."
+msgstr "출력할 격자지도"
-#: ../raster/r.in.mat/main.c:392 ../raster/r.out.mat/main.c:174
-#, c-format
-msgid "northern edge=%f"
-msgstr ""
+#: ../raster/r.drain/main.c:467
+#, fuzzy
+msgid "Writing output raster map..."
+msgstr "출력할 격자지도"
-#: ../raster/r.in.mat/main.c:393 ../raster/r.out.mat/main.c:175
+#: ../raster/r.drain/main.c:689
#, c-format
-msgid "southern edge=%f"
+msgid "direction read: %lf, neighbour found: %i"
msgstr ""
-#: ../raster/r.in.mat/main.c:394 ../raster/r.out.mat/main.c:176
-#, c-format
-msgid "eastern edge=%f"
-msgstr ""
+#: ../raster/r.tile/main.c:46
+#, fuzzy
+msgid "Splits a raster map into tiles."
+msgstr "출력할 격자지도"
-#: ../raster/r.in.mat/main.c:395 ../raster/r.out.mat/main.c:177
-#, c-format
-msgid "western edge=%f"
-msgstr ""
+#: ../raster/r.tile/main.c:55
+#, fuzzy
+msgid "Output base name"
+msgstr "출력할 격자지도"
-#: ../raster/r.in.mat/main.c:396 ../raster/r.out.mat/main.c:178
-#, c-format
-msgid "nsres=%f"
-msgstr ""
+#: ../raster/r.tile/main.c:62
+#, fuzzy
+msgid "Width of tiles (columns)"
+msgstr "출력할 격자지도"
-#: ../raster/r.in.mat/main.c:397 ../raster/r.out.mat/main.c:179
-#, c-format
-msgid "ewres=%f"
+#: ../raster/r.tile/main.c:69
+msgid "Height of tiles (rows)"
msgstr ""
-#: ../raster/r.in.mat/main.c:408
+#: ../raster/r.tile/main.c:76
#, fuzzy
-msgid "Writing new raster map..."
+msgid "Overlap of tiles"
msgstr "출력할 격자지도"
-#: ../raster/r.surf.fractal/spec_syn.c:60
-msgid "Preliminary surface calculations..."
-msgstr ""
+#: ../raster/r.tile/main.c:129
+#, fuzzy, c-format
+msgid "Generating %d x %d = %d tiles..."
+msgstr "출력할 격자지도"
-#: ../raster/r.surf.fractal/spec_syn.c:119
+#: ../raster/r.tile/main.c:184
#, fuzzy, c-format
-msgid "Calculating surface %d (of %d)..."
+msgid "Unable to read cats for %s"
msgstr "출력할 격자지도"
-#: ../raster/r.surf.fractal/main.c:40
-msgid "fractal"
+#: ../raster/r.sun/main.c:242 ../raster/r.sunmask/main.c:119
+msgid "shadow"
msgstr ""
-#: ../raster/r.surf.fractal/main.c:42
-msgid "Creates a fractal surface of a given fractal dimension."
+#: ../raster/r.sun/main.c:243
+msgid "Solar irradiance and irradiation model."
msgstr ""
-#: ../raster/r.surf.fractal/main.c:48
-msgid "Fractal dimension of surface (2 < D < 3)"
+#: ../raster/r.sun/main.c:245
+msgid ""
+"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
+"for given day, latitude, surface and atmospheric conditions. Solar "
+"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
+"irradiance, daylight length) are saved in the map history file. "
+"Alternatively, a local time can be specified to compute solar incidence "
+"angle and/or irradiance raster maps. The shadowing effect of the topography "
+"is optionally incorporated."
msgstr ""
-#: ../raster/r.surf.fractal/main.c:55
-msgid "Number of intermediate images to produce"
+#: ../raster/r.sun/main.c:259
+msgid "Name of the input elevation raster map [meters]"
msgstr ""
-#: ../raster/r.surf.fractal/main.c:79
-#, c-format
-msgid "Fractal dimension of %.2lf must be between 2 and 3."
+#: ../raster/r.sun/main.c:268
+msgid ""
+"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
+"[decimal degrees]"
msgstr ""
-#: ../raster/r.surf.fractal/process.c:54
-#, fuzzy
-msgid "Unable to allocate data buffer. Check current region with g.region."
-msgstr "출력할 격자지도"
-#: ../raster/r.circle/main.c:54 ../vector/v.buffer/main.c:224
-msgid "circle"
+#: ../raster/r.sun/main.c:277
+msgid "A single value of the orientation (aspect), 270 is south"
msgstr ""
-#: ../raster/r.circle/main.c:56
-msgid "Creates a raster map containing concentric rings around a given point."
+#: ../raster/r.sun/main.c:286
+msgid ""
+"Name of the input slope raster map (terrain slope or solar panel "
+"inclination) [decimal degrees]"
msgstr ""
-#: ../raster/r.circle/main.c:63
-msgid "The coordinate of the center (east,north)"
+#: ../raster/r.sun/main.c:294
+msgid "A single value of inclination (slope)"
msgstr ""
-#: ../raster/r.circle/main.c:69
-msgid "Minimum radius for ring/circle map (in meters)"
+#: ../raster/r.sun/main.c:303
+msgid ""
+"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
msgstr ""
-#: ../raster/r.circle/main.c:75
-msgid "Maximum radius for ring/circle map (in meters)"
+#: ../raster/r.sun/main.c:312
+msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
msgstr ""
-#: ../raster/r.circle/main.c:81
-msgid "Data value multiplier"
+#: ../raster/r.sun/main.c:321
+msgid "Name of the ground albedo coefficient input raster map [-]"
msgstr ""
-#: ../raster/r.circle/main.c:85
-msgid "Generate binary raster map"
+#: ../raster/r.sun/main.c:330
+msgid "A single value of the ground albedo coefficient [-]"
msgstr ""
-#: ../raster/r.circle/main.c:108
-msgid "Please specify a radius in which min < max"
-msgstr ""
-#: ../raster/r.circle/main.c:116
-msgid "Please specify min and/or max radius when using the binary flag"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:32
+#: ../raster/r.sun/main.c:339
#, fuzzy
-msgid "Raster map(s) to be converted to VTK-ASCII data format"
+msgid "Name of input raster map containing latitudes [decimal degrees]"
msgstr "출력할 격자지도"
-#: ../raster/r.out.vtk/parameters.c:45
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:8
-msgid "Value to represent no data cell"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:53
+#: ../raster/r.sun/main.c:348
#, fuzzy
-msgid "Constant elevation (if no elevation map is specified)"
+msgid "Name of input raster map containing longitudes [decimal degrees]"
msgstr "출력할 격자지도"
-#: ../raster/r.out.vtk/parameters.c:59
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:9
+#: ../raster/r.sun/main.c:357
+#, fuzzy
msgid ""
-"Create VTK point data instead of VTK cell data (if no elevation map is given)"
-msgstr ""
+"Name of real-sky beam radiation coefficient (thick cloud) input raster map "
+"[0-1]"
+msgstr "출력할 격자지도"
-#: ../raster/r.out.vtk/parameters.c:69
+#: ../raster/r.sun/main.c:366
+#, fuzzy
msgid ""
-"Three (r,g,b) raster maps to create RGB values [redmap,greenmap,bluemap]"
-msgstr ""
+"Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
+msgstr "출력할 격자지도"
-#: ../raster/r.out.vtk/parameters.c:79
-msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
-msgstr ""
+#: ../raster/r.sun/main.c:373
+#, fuzzy
+msgid "The horizon information input map basename"
+msgstr "투영정보가 갱신되지 않을 겁니다"
-#: ../raster/r.out.vtk/parameters.c:104
-msgid "Use structured grid for elevation (not recommended)"
+#: ../raster/r.sun/main.c:381 ../raster/r.horizon/main.c:211
+msgid "Angle step size for multidirectional horizon [degrees]"
msgstr ""
-#: ../raster/r.out.vtk/parameters.c:110
-msgid "Use polydata-trianglestrips for elevation grid creation"
+#: ../raster/r.sun/main.c:390
+msgid "Output incidence angle raster map (mode 1 only)"
msgstr ""
-#: ../raster/r.out.vtk/parameters.c:116
+#: ../raster/r.sun/main.c:399
msgid ""
-"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
+"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
+"day-1] (mode 2)"
msgstr ""
-#: ../raster/r.out.vtk/parameters.c:122
-msgid "Scale factor affects the origin (if no elevation map is given)"
+#: ../raster/r.sun/main.c:408
+msgid ""
+"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
+"day-1] (mode 2)"
msgstr ""
-#: ../raster/r.out.vtk/main.c:62
-#, fuzzy
-msgid "Converts raster maps into the VTK-ASCII format."
-msgstr "출력할 격자지도"
-#: ../raster/r.out.vtk/main.c:73
+#: ../raster/r.sun/main.c:417
msgid ""
-"No input maps specified. You need to specify at least one input map or three "
-"vector maps or three rgb maps."
+"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
+"map [Wh.m-2.day-1] (mode 2)"
msgstr ""
-#: ../raster/r.out.vtk/main.c:131 ../raster/r.out.vtk/main.c:191
-#: ../raster/r.out.vtk/main.c:212 ../raster/r.out.vtk/main.c:251
-#, c-format
-msgid "Open Raster file %s"
+#: ../raster/r.sun/main.c:426
+msgid ""
+"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/"
+"irradiation raster map [Wh.m-2.day-1] (mode 2)"
msgstr ""
-#: ../raster/r.out.vtk/main.c:222
-msgid "Writing VTK ImageData\n"
+#: ../raster/r.sun/main.c:435
+msgid "Output insolation time raster map [h] (mode 2 only)"
msgstr ""
-#: ../raster/r.out.vtk/main.c:232
-msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
+#: ../raster/r.sun/main.c:442
+msgid "No. of day of the year (1-365)"
msgstr ""
-#: ../raster/r.out.vtk/main.c:261
-msgid "Writing VTK Vector Data\n"
+#: ../raster/r.sun/main.c:452
+msgid "Time step when computing all-day radiation sums [decimal hours]"
msgstr ""
-#: ../raster/r.out.vtk/main.c:271
-msgid ""
-"Wrong vector maps. Maps should have the same type! Vector output not added!"
+#: ../raster/r.sun/main.c:460
+msgid "Declination value (overriding the internally computed value) [radians]"
msgstr ""
-#: ../raster/r.out.vtk/main.c:283
-msgid "Error closing VTK-ASCII file"
+#: ../raster/r.sun/main.c:468
+msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:75
-msgid "write_vtk_normal_header: Writing VTK-Header"
+#: ../raster/r.sun/main.c:492 ../raster/r.horizon/main.c:296
+msgid "Sampling distance step coefficient (0.5-1.5)"
msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:108
-msgid "write_vtk_structured_elevation_header: Writing VTK-Header"
+#: ../raster/r.sun/main.c:500
+msgid "Read the input files in this number of chunks"
msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:124
-msgid "write_vtk_polygonal_elevation_header: Writing VTK-Header"
+#: ../raster/r.sun/main.c:507
+msgid "Civil time zone value, if none, the time will be local solar time"
msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:139
-msgid "write_vtk_celldata_header: Writing VTK-DataHeader"
+#: ../raster/r.sun/main.c:513
+msgid "Do not incorporate the shadowing effect of terrain"
msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:148
-msgid "writeVTKPointHeader: Writing VTK-DataHeader"
+#: ../raster/r.sun/main.c:518
+msgid "Use the low-memory version of the program"
msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:169
-msgid "write_vtk_structured_coordinates: Writing Coordinates"
+#: ../raster/r.sun/main.c:559
+msgid "You must give the longitude raster if you use civil time"
msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:225
-msgid "write_vtk_polygonal_coordinates: Writing VTK Polygonal data"
-msgstr ""
+#: ../raster/r.sun/main.c:562
+#, fuzzy
+msgid "Error reading civil time zone value"
+msgstr "출력할 격자지도"
-#: ../raster/r.out.vtk/writeascii.c:334
-msgid "write_vtk_data: Writing VTK-Data"
+#: ../raster/r.sun/main.c:565
+msgid "Invalid civil time zone value"
msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:384
-msgid "write_vtk_rgb_image_data: Writing VTK-ImageData"
+#: ../raster/r.sun/main.c:590
+msgid "insol_time and incidout are incompatible options"
msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:412
-msgid "Wrong map values! Values should in between 0 and 255!\n"
-msgstr ""
+#: ../raster/r.sun/main.c:595
+#, fuzzy
+msgid "Error reading time step size"
+msgstr "출력할 격자지도"
-#: ../raster/r.out.vtk/writeascii.c:442
-msgid "write_vtk_vector_data: Writing VTK-vector data"
-msgstr ""
+#: ../raster/r.sun/main.c:597
+#, fuzzy
+msgid "Invalid time step size"
+msgstr "출력할 격자지도"
-#: ../raster/r.gwflow/main.c:57
+#: ../raster/r.sun/main.c:601
#, fuzzy
-msgid "Name of input raster map with initial piezometric head in [m]"
+msgid "Error reading horizon step size"
msgstr "출력할 격자지도"
-#: ../raster/r.gwflow/main.c:62
-msgid ""
-"Name of input raster map providing boundary condition status: 0-inactive, 1-"
-"active, 2-dirichlet"
+#: ../raster/r.sun/main.c:606
+msgid "The horizon step size must be greater than 0."
msgstr ""
-#: ../raster/r.gwflow/main.c:67
+#: ../raster/r.sun/main.c:609
msgid ""
-"Name of input raster map with x-part of the hydraulic conductivity tensor in "
-"[m/s]"
+"If you use the horizon option you must also set the 'horizonstep' parameter."
msgstr ""
-#: ../raster/r.gwflow/main.c:72
-msgid ""
-"Name of input raster map with y-part of the hydraulic conductivity tensor in "
-"[m/s]"
+#: ../raster/r.sun/main.c:615
+msgid "Time and insol_time are incompatible options"
msgstr ""
-#: ../raster/r.gwflow/main.c:77
-#, fuzzy
-msgid "Name of input raster map with water sources and sinks in [m^3/s]"
-msgstr "출력할 격자지도"
-#: ../raster/r.gwflow/main.c:81
+#: ../raster/r.sun/main.c:617
msgid ""
-"Name of input raster map with storativity for confined or effective porosity "
-"for unconfined groundwater flow booth in [-] "
+"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
+"time"
msgstr ""
-#: ../raster/r.gwflow/main.c:86
-msgid "Recharge"
+#: ../raster/r.sun/main.c:622
+msgid "incidout requires time parameter to be set"
msgstr ""
-#: ../raster/r.gwflow/main.c:88
-#, fuzzy
-msgid "Recharge input raster map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
+#: ../raster/r.sun/main.c:624
+msgid "Mode 2: integrated daily irradiation for a given day of the year"
+msgstr ""
+#: ../raster/r.sun/main.c:647
+#, fuzzy, c-format
+msgid "Using Linke constant: %lf"
msgstr "출력할 격자지도"
-#: ../raster/r.gwflow/main.c:92
-#, fuzzy
-msgid ""
-"Name of input raster map describing the top surface of the aquifer in [m]"
+#: ../raster/r.sun/main.c:649
+#, fuzzy, c-format
+msgid "Using Linke map <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.gwflow/main.c:96
-#, fuzzy
-msgid ""
-"Name of input raster map describing the bottom surface of the aquifer in [m]"
+#: ../raster/r.sun/main.c:654
+#, c-format
+msgid "Using albedo constant: %lf"
+msgstr ""
+#: ../raster/r.sun/main.c:656
+#, fuzzy, c-format
+msgid "Using albedo map <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.gwflow/main.c:100
-#, fuzzy
-msgid "Output raster map storing the numerical result [m]"
+#: ../raster/r.sun/main.c:661
+#, fuzzy, c-format
+msgid "Using slope constant: %lf"
msgstr "출력할 격자지도"
-#: ../raster/r.gwflow/main.c:106
-#, fuzzy
-msgid ""
-"Output raster map to store the groundwater filter velocity vector part in x "
-"direction [m/s]"
+#: ../raster/r.sun/main.c:664
+#, fuzzy, c-format
+msgid "Using slope map <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.gwflow/main.c:112
-#, fuzzy
-msgid ""
-"Output raster map to store the groundwater filter velocity vector part in y "
-"direction [m/s]"
+#: ../raster/r.sun/main.c:669
+#, fuzzy, c-format
+msgid "Using aspect constant: %lf"
msgstr "출력할 격자지도"
-#: ../raster/r.gwflow/main.c:118
-#, fuzzy
-msgid "Output raster map to store the groundwater budget for each cell [m^3/s]"
+#: ../raster/r.sun/main.c:672
+#, fuzzy, c-format
+msgid "Using aspect map <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.gwflow/main.c:126
-msgid "The type of groundwater flow"
+#: ../raster/r.sun/main.c:687
+msgid "If you use -s and no horizon rasters, numpartitions must be =1"
msgstr ""
-#: ../raster/r.gwflow/main.c:132
-#, fuzzy
-msgid "Name of input raster map providing the height of the river bed in [m]"
-msgstr "출력할 격자지도"
-#: ../raster/r.gwflow/main.c:140
+#: ../raster/r.sun/main.c:700
msgid ""
-"Name of input raster map providing the water level (head) of the river with "
-"leakage connection in [m]"
+"If you want to save memory and to use shadows, you must use pre-calculated "
+"horizons."
msgstr ""
-#: ../raster/r.gwflow/main.c:147
-#, fuzzy
-msgid ""
-"Name of input raster map providing the leakage coefficient of the river bed "
-"in [1/s]."
-msgstr "출력할 격자지도"
+#: ../raster/r.sun/main.c:763 ../raster/r.horizon/main.c:548
+#: ../raster/r.latlong/main.c:114 ../display/d.grid/plot.c:561
+#: ../display/d.grid/plot.c:588 ../display/d.where/main.c:120
+#: ../display/d.where/main.c:146 ../ps/ps.map/do_geogrid.c:278
+msgid "Unable to set up lat/long projection parameters"
+msgstr ""
-#: ../raster/r.gwflow/main.c:155
-#, fuzzy
-msgid ""
-"Name of input raster map providing the height of the drainage bed in [m]"
-msgstr "출력할 격자지도"
+#: ../raster/r.sun/main.c:767
+msgid "latin and longin raster maps have no effect when in a Lat/Lon location"
+msgstr ""
-#: ../raster/r.gwflow/main.c:162
+#: ../raster/r.sun/main.c:772
+msgid "Both latin and longin raster maps must be given, or neither"
+msgstr ""
+#: ../raster/r.out.pov/main.c:124
#, fuzzy
-msgid ""
-"Name of input raster map providing the leakage coefficient of the drainage "
-"bed in [1/s]"
+msgid "Converts a raster map layer into a height-field file for POV-Ray."
msgstr "출력할 격자지도"
-#: ../raster/r.gwflow/main.c:167
-msgid "The maximum number of iterations in the linearization approach"
+#: ../raster/r.out.pov/main.c:131
+msgid "Name of output povray file (TGA height field file)"
msgstr ""
-#: ../raster/r.gwflow/main.c:176
-msgid ""
-"Allocate a full quadratic linear equation system, default is a sparse linear "
-"equation system."
+#: ../raster/r.out.pov/main.c:138
+msgid "Height-field type (0=actual heights 1=normalized)"
msgstr ""
-#: ../raster/r.gwflow/main.c:212
-msgid ""
-"Numerical calculation program for transient, confined and unconfined "
-"groundwater flow in two dimensions."
+#: ../raster/r.out.pov/main.c:144
+msgid "Elevation bias"
msgstr ""
-#: ../raster/r.gwflow/main.c:237
-msgid "Please provide river_head, river_leak and river_bed maps"
+#: ../raster/r.out.pov/main.c:150 ../raster/r.param.scale/interface.c:118
+msgid "Vertical scaling factor"
msgstr ""
-#: ../raster/r.gwflow/main.c:249
-msgid "Please provide drain_head and drain_leak maps"
+#: ../raster/r.out.pov/main.c:170
+#, c-format
+msgid "Invalid output filename <%s>"
msgstr ""
-#: ../raster/r.gwflow/main.c:263
-msgid ""
-"The cholesky solver dos not work with sparse matrices. You may choose a full "
-"filled quadratic matrix, flag -f."
+#: ../raster/r.out.pov/main.c:180
+#, c-format
+msgid "Raster map is too big! Exceeds %d columns or %d rows"
msgstr ""
-#: ../raster/r.gwflow/main.c:293
+#: ../raster/r.out.pov/main.c:201
+msgid "Negative elevation values in input"
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:142
#, fuzzy, c-format
-msgid "Calculation time: %g"
+msgid "Filter <%s> not found"
msgstr "출력할 격자지도"
-#: ../raster/r.gwflow/main.c:380
-#, c-format
-msgid "Calculation of unconfined groundwater flow loop %i"
+#: ../raster/r.resamp.filter/main.c:391
+#, fuzzy
+msgid "kernel filter"
+msgstr "여과"
+#: ../raster/r.resamp.filter/main.c:394
+#, fuzzy
+msgid "Resamples raster map layers using an analytic kernel."
+msgstr "출력할 격자지도"
+#: ../raster/r.resamp.filter/main.c:405
+msgid "Filter kernel(s)"
msgstr ""
-#: ../raster/r.gwflow/main.c:403
-#, c-format
-msgid "Maximum difference between this and last increment: %g"
+#: ../raster/r.resamp.filter/main.c:413
+msgid "Filter radius"
msgstr ""
-#: ../raster/r.in.png/main.c:297
+#: ../raster/r.resamp.filter/main.c:420
+msgid "Filter radius (horizontal)"
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:427
+msgid "Filter radius (vertical)"
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:438 ../vector/v.external.out/args.c:90
#, fuzzy, c-format
-msgid "Unable to open PNG file '%s'"
+msgid "%s= and %s=/%s= are mutually exclusive"
+msgstr "%s=와 %s=를 같이 지정할 수 없습니다"
+#: ../raster/r.resamp.filter/main.c:443
+#, fuzzy, c-format
+msgid "Either %s= or %s=/%s= required"
msgstr "출력할 격자지도"
-#: ../raster/r.in.png/main.c:300
-msgid "Input file empty or too short"
+#: ../raster/r.resamp.filter/main.c:446
+#, fuzzy, c-format
+msgid "Both %s= and %s= required"
+msgstr "출력할 격자지도"
+#: ../raster/r.resamp.filter/main.c:469
+msgid "Differing number of values for filter= and [xy_]radius="
msgstr ""
-#: ../raster/r.in.png/main.c:303
-msgid "Input file not a PNG file"
+#: ../raster/r.resamp.filter/main.c:472
+#, c-format
+msgid "Too many filters (max: %d)"
msgstr ""
-#: ../raster/r.in.png/main.c:307 ../raster/r.in.png/main.c:311
-#: ../general/g.ppmtopng/main.c:70 ../general/g.ppmtopng/main.c:74
+#: ../raster/r.resamp.filter/main.c:490
#, fuzzy
-msgid "Unable to allocate PNG structure"
+msgid "At least one filter must be finite"
msgstr "출력할 격자지도"
-#: ../raster/r.in.png/main.c:314
-msgid "PNG error"
+#: ../raster/r.surf.fractal/spec_syn.c:60
+msgid "Preliminary surface calculations..."
msgstr ""
-#: ../raster/r.in.png/main.c:522
-#, fuzzy
-msgid "Imports non-georeferenced PNG format image."
+#: ../raster/r.surf.fractal/spec_syn.c:119
+#, fuzzy, c-format
+msgid "Calculating surface %d (of %d)..."
msgstr "출력할 격자지도"
-#: ../raster/r.in.png/main.c:532
+#: ../raster/r.surf.fractal/process.c:54
#, fuzzy
-msgid "Title for created raster map"
+msgid "Unable to allocate data buffer. Check current region with g.region."
msgstr "출력할 격자지도"
-#: ../raster/r.in.png/main.c:538
-#, fuzzy
-msgid "Display gamma"
-msgstr "출력할 격자지도"
+#: ../raster/r.surf.fractal/main.c:40
+msgid "fractal"
+msgstr ""
-#: ../raster/r.in.png/main.c:544
-msgid "Alpha threshold"
+#: ../raster/r.surf.fractal/main.c:42
+msgid "Creates a fractal surface of a given fractal dimension."
msgstr ""
-#: ../raster/r.in.png/main.c:548
-#, fuzzy
-msgid "Create floating-point map (0.0 - 1.0)"
-msgstr "출력할 격자지도"
+#: ../raster/r.surf.fractal/main.c:48
+msgid "Fractal dimension of surface (2 < D < 3)"
+msgstr ""
-#: ../raster/r.in.png/main.c:552
-#, fuzzy
-msgid "Output image file header only and exit"
-msgstr "출력할 격자지도"
+#: ../raster/r.surf.fractal/main.c:55
+msgid "Number of intermediate images to produce"
+msgstr ""
-#: ../raster/r.rescale.eq/main.c:55
+#: ../raster/r.surf.fractal/main.c:79
+#, c-format
+msgid "Fractal dimension of %.2lf must be between 2 and 3."
+msgstr ""
+#: ../raster/r.spread/main.c:107 ../raster/r.ros/main.c:214
+msgid "spread"
+msgstr ""
+#: ../raster/r.spread/main.c:108 ../raster/r.lake/main.c:152
+#: ../raster/r.ros/main.c:216
+msgid "hazard"
+msgstr ""
+#: ../raster/r.spread/main.c:109 ../raster/r.sim/r.sim.sediment/main.c:119
+#: ../raster/r.sim/r.sim.water/main.c:118 ../raster/r.ros/main.c:217
+#: ../raster/r.topmodel/main.c:53
+msgid "model"
+msgstr ""
+#: ../raster/r.spread/main.c:111
+msgid "Simulates elliptically anisotropic spread."
+msgstr ""
+#: ../raster/r.spread/main.c:113
msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
+"Generates a raster map of the cumulative time of spread, given raster maps "
+"containing the rates of spread (ROS), the ROS directions and the spread "
+"origins. It optionally produces raster maps to contain backlink UTM "
+"coordinates for tracing spread paths. Usable for fire spread simulations."
msgstr ""
-#: ../raster/r.rescale.eq/main.c:115
-#, c-format
-msgid "Rescale %s[%d,%d] to %s[%d,%d]"
+#: ../raster/r.spread/main.c:127
+msgid "Raster map containing base ROS (cm/min)"
msgstr ""
-#: ../raster/r.stats/raw_stats.c:118
+#: ../raster/r.spread/main.c:129
+msgid ""
+"Name of an existing raster map layer in the user's current mapset search "
+"path containing the ROS values in the directions perpendicular to maximum "
+"ROSes' (cm/minute). These ROSes are also the ones without the effect of "
+"directional factors."
+msgstr ""
+#: ../raster/r.spread/main.c:141
+msgid "Raster map containing maximal ROS (cm/min)"
+msgstr ""
+#: ../raster/r.spread/main.c:143
+msgid ""
+"path containing the maximum ROS values (cm/minute)."
+msgstr ""
+#: ../raster/r.spread/main.c:153
#, fuzzy
-msgid "Invalid map type"
+msgid "Raster map containing directions of maximal ROS (degree)"
msgstr "출력할 격자지도"
-#: ../raster/r.stats/main.c:109
+#: ../raster/r.spread/main.c:155
+msgid ""
+"path containing directions of the maximum ROSes, clockwise from north "
+"(degree)."
+msgstr ""
+#: ../raster/r.spread/main.c:166
#, fuzzy
-msgid "Generates area statistics for raster map."
+msgid "Raster map containing starting sources"
msgstr "출력할 격자지도"
-#: ../raster/r.stats/main.c:157
-msgid "Print area totals in square meters"
+#: ../raster/r.spread/main.c:168
+msgid ""
+"path containing starting locations of the spread phenomenon. Any positive "
+"integers in this map are recognized as starting sources (seeds)."
msgstr ""
-#: ../raster/r.stats/main.c:162
-msgid "Print cell counts (sortable)"
+#: ../raster/r.spread/main.c:179
+msgid "Raster map containing maximal spotting distance (m, required with -s)"
msgstr ""
-#: ../raster/r.stats/main.c:168
-msgid "Print approximate (total percent may not be 100%) percents"
+#: ../raster/r.spread/main.c:181
+msgid ""
+"path containing the maximum potential spotting distances (meters)."
msgstr ""
-#: ../raster/r.stats/main.c:173
-msgid "Print category labels"
+#: ../raster/r.spread/main.c:191
+msgid "Raster map containing midflame wind speed (ft/min, required with -s)"
msgstr ""
-#: ../raster/r.stats/main.c:177
-msgid "One cell (range) per line"
+#: ../raster/r.spread/main.c:193 ../raster/r.ros/main.c:279
+msgid ""
+"path containing wind velocities at half of the average flame height (feet/"
+"minute)."
msgstr ""
-#: ../raster/r.stats/main.c:181
-msgid "Print grid coordinates (east and north)"
+#: ../raster/r.spread/main.c:203
+msgid ""
+"Raster map containing fine fuel moisture of the cell receiving a spotting "
+"firebrand (%, required with -s)"
msgstr ""
-#: ../raster/r.stats/main.c:182 ../raster/r.stats/main.c:187
-#, fuzzy
-msgid "Coordinates"
-msgstr "출력할 격자지도"
+#: ../raster/r.spread/main.c:205 ../raster/r.ros/main.c:240
+msgid ""
+"path containing the 1-hour (<.25\") fuel moisture (percentage content "
+"multiplied by 100)."
+msgstr ""
-#: ../raster/r.stats/main.c:186
-msgid "Print x and y (column and row)"
+#: ../raster/r.spread/main.c:215
+msgid "Basic sampling window size needed to meet certain accuracy (3)"
msgstr ""
-#: ../raster/r.stats/main.c:191
-msgid "Print averaged values instead of intervals (floating-point maps only)"
+#: ../raster/r.spread/main.c:217
+msgid ""
+"An odd integer ranging 3 - 15 indicating the basic sampling window size "
+"within which all cells will be considered to see whether they will be "
+"reached by the current spread cell. The default number is 3 which means a "
+"3x3 window."
msgstr ""
-#: ../raster/r.stats/main.c:196
-msgid "Print raw indexes of floating-point ranges (floating-point maps only)"
+#: ../raster/r.spread/main.c:227
+msgid "Sampling density for additional computing (range: 0.0 - 1.0 (0.5))"
msgstr ""
-#: ../raster/r.stats/main.c:233
-#, c-format
-msgid "'%s' must be greater than zero; using %s=255"
+#: ../raster/r.spread/main.c:229
+msgid ""
+"A decimal number ranging 0.0 - 1.0 indicating additional sampling cells will "
+"be considered to see whether they will be reached by the current spread "
+"cell. The closer to 1.0 the decimal number is, the longer the program will "
+"run and the higher the simulation accuracy will be. The default number is "
+"0.5."
msgstr ""
-#: ../raster/r.stats/main.c:285 ../raster/r.series.accumulate/main.c:265
-#: ../raster/r.series/main.c:287
-#, fuzzy
-msgid "Raster map not found"
-msgstr "출력할 격자지도"
+#: ../raster/r.spread/main.c:241
+msgid "Initial time for current simulation (0) (min)"
+msgstr ""
-#: ../raster/r.stats/main.c:303
-#, c-format
+#: ../raster/r.spread/main.c:243
msgid ""
-"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
-"will be ignored."
+"A non-negative number specifying the initial time for the current spread "
+"simulation (minutes). This is useful when multiple phase simulation is "
+"conducted. The default time is 0."
msgstr ""
-#: ../raster/r.stats/main.c:319
-#, c-format
+#: ../raster/r.spread/main.c:252
+msgid "Simulating time duration LAG (fill the region) (min)"
+msgstr ""
+#: ../raster/r.spread/main.c:254
msgid ""
-"Cats for raster map <%s> are either missing or have no explicit labels. "
-"Using %s=%d."
+"A non-negative integer specifying the simulating duration time lag "
+"(minutes). The default is infinite, but the program will terminate when the "
+"current geographic region/mask has been filled. It also controls the "
+"computational time, the shorter the time lag, the faster the program will "
+"run."
msgstr ""
-#: ../raster/r.stats/main.c:325
-#, c-format
+#: ../raster/r.spread/main.c:266
+msgid "Name of raster map as a display backdrop"
+msgstr ""
+#: ../raster/r.spread/main.c:268
msgid ""
-"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' "
-"option"
+"path to be used as the background on which the \"live\" movement will be "
+"shown."
msgstr ""
-#: ../raster/r.stats/main.c:331 ../raster/r.contour/main.c:149
-#, fuzzy, c-format
-msgid "Unable to read fp range of raster map <%s>"
-msgstr "출력할 격자지도"
+#: ../raster/r.spread/main.c:279
+msgid "Raster map to contain output spread time (min)"
+msgstr ""
-#: ../raster/r.stats/main.c:358 ../raster/r.recode/read_rules.c:35
-#, fuzzy, c-format
-msgid "Unable to read range for map <%s>"
+#: ../raster/r.spread/main.c:281
+msgid ""
+"Name of the new raster map layer to contain the results of the cumulative "
+"spread time needed for a phenomenon to reach each cell from the starting "
+"sources (minutes)."
+msgstr ""
+#: ../raster/r.spread/main.c:291
+#, fuzzy
+msgid "Name of raster map to contain X back coordinates"
msgstr "출력할 격자지도"
-#: ../raster/r.to.rast3elev/main.c:99
-msgid "The number of input and elevation maps is not equal"
+#: ../raster/r.spread/main.c:293
+msgid ""
+"Name of the new raster map layer to contain the results of backlink "
+"information in UTM easting coordinates for each cell."
msgstr ""
-#: ../raster/r.to.rast3elev/main.c:165
-msgid "The value to fill the upper cells, default is null"
+#: ../raster/r.spread/main.c:303
+#, fuzzy
+msgid "Name of raster map to contain Y back coordinates"
+msgstr "출력할 격자지도"
+#: ../raster/r.spread/main.c:305
+msgid ""
+"information in UTM northing coordinates for each cell."
msgstr ""
-#: ../raster/r.to.rast3elev/main.c:172
-msgid "The value to fill the lower cells, default is null"
+#: ../raster/r.spread/main.c:312
+msgid "DISPLAY 'live' spread process on screen"
msgstr ""
-#: ../raster/r.to.rast3elev/main.c:185
-msgid "Use the input map values to fill the upper cells"
+#: ../raster/r.spread/main.c:314
+msgid ""
+"Display the 'live' simulation on screen. A graphics window must be opened "
+"and selected before using this option."
msgstr ""
-#: ../raster/r.to.rast3elev/main.c:190
-msgid "Use the input map values to fill the lower cells"
+#: ../raster/r.spread/main.c:320
+msgid "Consider spotting effect (for wildfires)"
msgstr ""
-#: ../raster/r.to.rast3elev/main.c:287 ../raster/r.to.rast3elev/main.c:320
+#: ../raster/r.spread/main.c:324
#, fuzzy
-msgid "Error writing 3D raster double data"
+msgid "Use start raster map values in output spread time raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.to.rast3elev/main.c:366
-msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
+#: ../raster/r.spread/main.c:326
+msgid ""
+"Designed to be used with output of previous run of r.spread when computing "
+"spread iteratively. The values in start raster map are considered as time. "
+"Allowed values in raster map are from zero to the value of init_time option. "
+"If not enabled, init_time is used in the area of start raster map"
msgstr ""
-#: ../raster/r.to.rast3elev/main.c:400
-msgid "The upper value is not valid"
+#: ../raster/r.spread/main.c:502
+#, fuzzy
+msgid "Reading inputs..."
+msgstr "출력할 격자지도"
+#: ../raster/r.spread/main.c:543
+#, c-format
+msgid "Maximum of start raster map is grater than init_time (%d > %d)"
msgstr ""
-#: ../raster/r.to.rast3elev/main.c:410
-msgid "The lower value is not valid"
+#: ../raster/r.spread/main.c:547
+#, c-format
+msgid "Minimum of start raster map is less than zero (%d < 0)"
msgstr ""
-#: ../raster/r.to.rast3elev/main.c:427
-msgid ""
-"The 2D and 3D region settings are different. I will use the 3D region "
-"settings to adjust the 2D region."
+#: ../raster/r.spread/main.c:555
+#, c-format
+msgid "Reading %s..."
msgstr ""
-#: ../raster/r.series.accumulate/main.c:81 ../raster/r.series/main.c:139
-#: ../raster/r.series.interp/main.c:65
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:4
-msgid "series"
-msgstr "계열"
-#: ../raster/r.series.accumulate/main.c:82
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:3
+#: ../raster/r.walk/main.c:181 ../raster/r.cost/main.c:143
+#: ../vector/v.net.alloc/main.c:59
#, fuzzy
-msgid "accumulation"
+msgid "cost allocation"
msgstr "출력할 격자지도"
-#: ../raster/r.series.accumulate/main.c:84
+#: ../raster/r.walk/main.c:183
msgid ""
-"Makes each output cell value a accumulationfunction of the values assigned "
-"to the corresponding cells in the input raster map layers."
+"Creates a raster map showing the anisotropic cumulative cost of moving "
+"between different geographic locations on an input raster map whose cell "
+"category values represent cost."
msgstr ""
-#: ../raster/r.series.accumulate/main.c:90
-msgid "Existing map to be added to output"
+#: ../raster/r.walk/main.c:193
+msgid "Name of input raster map containing friction costs"
msgstr ""
-#: ../raster/r.series.accumulate/main.c:98
+#: ../raster/r.walk/main.c:196
#, fuzzy
-msgid "Input file with raster map names, one per line"
+msgid "Name for output raster map to contain walking costs"
msgstr "출력할 격자지도"
-#: ../raster/r.series.accumulate/main.c:109
+#: ../raster/r.walk/main.c:202 ../raster/r.cost/main.c:167
#, fuzzy
-msgid "Scale factor for input"
+msgid "Name for output raster map to contain movement directions"
msgstr "출력할 격자지도"
-#: ../raster/r.series.accumulate/main.c:116
-msgid "Shift factor for input"
+#: ../raster/r.walk/main.c:203 ../raster/r.cost/main.c:161
+#: ../raster/r.cost/main.c:168
+#, fuzzy
+msgid "Optional outputs"
+msgstr "출력할 격자지도"
+#: ../raster/r.walk/main.c:208 ../raster/r.cost/main.c:173
+#, fuzzy
+msgid "Name of starting vector points map"
+msgstr "출력할 격자지도"
+#: ../raster/r.walk/main.c:214 ../raster/r.cost/main.c:179
+#, fuzzy
+msgid "Name of stopping vector points map"
+msgstr "출력할 격자지도"
+#: ../raster/r.walk/main.c:215 ../raster/r.walk/main.c:235
+#: ../raster/r.cost/main.c:180 ../raster/r.cost/main.c:200
+msgid "Stop"
msgstr ""
-#: ../raster/r.series.accumulate/main.c:121
-msgid ""
-"The raster map specifying the lower accumulation limit, also called baseline"
+#: ../raster/r.walk/main.c:220 ../raster/r.cost/main.c:185
+#, fuzzy
+msgid "Name of starting raster points map"
+msgstr "출력할 격자지도"
+#: ../raster/r.walk/main.c:234 ../raster/r.cost/main.c:199
+msgid "Coordinates of stopping point(s) (E,N)"
msgstr ""
-#: ../raster/r.series.accumulate/main.c:126
-msgid ""
-"The raster map specifying the upper accumulation limit, also called cutoff. "
-"Only applied to BEDD computation."
+#: ../raster/r.walk/main.c:244 ../raster/r.cost/main.c:209
+msgid "Maximum cumulative cost"
msgstr ""
-#: ../raster/r.series.accumulate/main.c:132 ../raster/r.series/main.c:183
-msgid "Ignore values outside this range"
+#: ../raster/r.walk/main.c:253 ../raster/r.cost/main.c:218
+msgid "Cost assigned to null cells. By default, null cells are excluded"
msgstr ""
-#: ../raster/r.series.accumulate/main.c:139
-msgid "Use these limits in case lower and/or upper input maps are not defined"
+#: ../raster/r.walk/main.c:254 ../raster/r.walk/main.c:304
+#: ../raster/r.cost/main.c:219 ../raster/r.cost/main.c:238
+msgid "NULL cells"
msgstr ""
-#: ../raster/r.series.accumulate/main.c:151
-msgid "Growing Degree Days or Winkler indices"
+#: ../raster/r.walk/main.c:263 ../raster/r.cost/main.c:228
+msgid "Maximum memory to be used in MB"
msgstr ""
-#: ../raster/r.series.accumulate/main.c:152
-msgid "Mean: sum(input maps)/(number of input maps)"
+#: ../raster/r.walk/main.c:273
+msgid "Coefficients for walking energy formula parameters a,b,c,d"
msgstr ""
-#: ../raster/r.series.accumulate/main.c:153
-msgid "Biologically Effective Degree Days"
+#: ../raster/r.walk/main.c:283
+msgid "Lambda coefficients for combining walking energy and friction cost"
msgstr ""
-#: ../raster/r.series.accumulate/main.c:154
-msgid "Huglin Heliothermal index"
+#: ../raster/r.walk/main.c:293
+msgid "Slope factor determines travel energy cost per height step"
msgstr ""
-#: ../raster/r.series.accumulate/main.c:159
-#: ../raster/r.resamp.filter/main.c:431 ../raster/r.resamp.stats/main.c:285
-#: ../raster/r.series/main.c:187
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:10
-msgid "Propagate NULLs"
+#: ../raster/r.walk/main.c:299 ../raster/r.cost/main.c:233
+msgid "Use the 'Knight's move'; slower, but more accurate"
msgstr ""
-#: ../raster/r.series.accumulate/main.c:163 ../raster/r.series/main.c:191
+#: ../raster/r.walk/main.c:303 ../raster/r.cost/main.c:237
#, fuzzy
-msgid "Do not keep files open"
+msgid "Keep null values in output raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.series.accumulate/main.c:167
-msgid "Create a FCELL map (floating point single precision) as output"
+#: ../raster/r.walk/main.c:308 ../raster/r.cost/main.c:242
+msgid "Start with values in raster map"
msgstr ""
-#: ../raster/r.series.accumulate/main.c:206 ../raster/r.external/main.c:159
-#: ../raster/r.series/main.c:204 ../raster/r.series.interp/main.c:118
-#: ../raster/r.series.interp/main.c:122 ../raster/r.series.interp/main.c:134
-#: ../raster/r.series.interp/main.c:138 ../raster/r.mapcalc/main.c:117
-#: ../raster/r.neighbors/main.c:266 ../vector/v.colors/main.c:206
+#: ../raster/r.walk/main.c:313 ../raster/r.cost/main.c:247
+msgid "Print info about disk space and memory requirements and exit"
+msgstr ""
+#: ../raster/r.walk/main.c:357 ../raster/r.cost/main.c:297
+msgid "Must specify exactly one of start_points, start_rast or coordinate"
+msgstr ""
+#: ../raster/r.walk/main.c:362 ../raster/r.walk/main.c:845
+#: ../raster/r.cost/main.c:302 ../raster/r.cost/main.c:712
+msgid "No start points"
+msgstr ""
+#: ../raster/r.walk/main.c:369 ../raster/r.cost/main.c:309
#, c-format
-msgid "%s= and %s= are mutually exclusive"
-msgstr "%s=와 %s=를 같이 지정할 수 없습니다"
+msgid "Inappropriate maximum cost: %d"
+msgstr ""
-#: ../raster/r.series.accumulate/main.c:210 ../raster/r.series/main.c:208
-#: ../raster/r.series.interp/main.c:126 ../raster/r.series.interp/main.c:142
+#: ../raster/r.walk/main.c:372 ../raster/r.cost/main.c:312
+#, c-format
+msgid "Inappropriate amount of memory: %d"
+msgstr ""
+#: ../raster/r.walk/main.c:377
+#, c-format
+msgid "Missing required value: got %d instead of 4"
+msgstr ""
+#: ../raster/r.walk/main.c:380
+#, c-format
+msgid "Walking costs are a=%g b=%g c=%g d=%g"
+msgstr ""
+#: ../raster/r.walk/main.c:385 ../raster/r.walk/main.c:393
+#, c-format
+msgid "Missing required value: %d"
+msgstr ""
+#: ../raster/r.walk/main.c:388
+#, c-format
+msgid "Lambda is %g"
+msgstr ""
+#: ../raster/r.walk/main.c:396
+#, c-format
+msgid "Slope_factor is %g"
+msgstr ""
+#: ../raster/r.walk/main.c:415 ../raster/r.cost/main.c:330
+msgid "Assigning negative cost to null cell. Null cells excluded."
+msgstr ""
+#: ../raster/r.walk/main.c:525 ../raster/r.walk/main.c:538
+#: ../raster/r.cost/main.c:412 ../raster/r.cost/main.c:424
+#, c-format
+msgid "Will need at least %.2f MB of disk space"
+msgstr ""
+#: ../raster/r.walk/main.c:527 ../raster/r.walk/main.c:539
+#: ../raster/r.cost/main.c:414 ../raster/r.cost/main.c:425
+#, c-format
+msgid "Will need at least %.2f MB of memory"
+msgstr ""
+#: ../raster/r.walk/main.c:529 ../raster/r.walk/main.c:540
+#: ../raster/r.cost/main.c:416 ../raster/r.cost/main.c:426
+#, c-format
+msgid "%d of %d segments are kept in memory"
+msgstr ""
+#: ../raster/r.walk/main.c:545 ../raster/r.cost/main.c:431
+#, fuzzy
+msgid "Creating some temporary files..."
+msgstr "출력할 격자지도"
+#: ../raster/r.walk/main.c:558
#, fuzzy, c-format
-msgid "Please specify %s= or %s="
+msgid "Reading raster maps <%s> and <%s>, initializing output..."
msgstr "출력할 격자지도"
-#: ../raster/r.series.accumulate/main.c:255 ../raster/r.series/main.c:275
+#: ../raster/r.walk/main.c:643 ../raster/r.cost/main.c:504
#, fuzzy
-msgid "No raster map name found in input file"
+msgid "Initializing directional output..."
msgstr "출력할 격자지도"
-#: ../raster/r.series.accumulate/main.c:354
+#: ../raster/r.walk/main.c:722
#, fuzzy, c-format
-msgid "'%s'=%f must be > '%s'=%f"
+msgid "No start points found in vector <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.proj/bordwalk.c:216
-msgid "Input raster map is outside current region"
-msgstr ""
+#: ../raster/r.walk/main.c:734 ../raster/r.cost/main.c:598
+#, fuzzy, c-format
+msgid "Reading vector map <%s> with stop points..."
+msgstr "출력할 격자지도"
-#: ../raster/r.proj/bordwalk.c:242
-#, fuzzy
-msgid "Unable to reproject map center"
+#: ../raster/r.walk/main.c:788 ../raster/r.cost/main.c:652
+#, fuzzy, c-format
+msgid "No stop points found in vector <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.proj/main.c:145 ../raster/r.latlong/main.c:59
-#: ../locale/scriptstrings/v.import_to_translate.c:4
-#: ../locale/scriptstrings/m.proj_to_translate.c:3
-#: ../locale/scriptstrings/r.import_to_translate.c:4
-#: ../general/g.setproj/main.c:79 ../general/g.proj/main.c:65
-#: ../vector/v.proj/main.c:68
-msgid "projection"
-msgstr "투영"
+#: ../raster/r.walk/main.c:810 ../raster/r.cost/main.c:675
+#, fuzzy, c-format
+msgid "Reading raster map <%s> with start points..."
+msgstr "출력할 격자지도"
-#: ../raster/r.proj/main.c:149
+#: ../raster/r.walk/main.c:859 ../raster/r.cost/main.c:726
+msgid "Specified starting location outside database window"
+msgstr ""
+#: ../raster/r.walk/main.c:879 ../raster/r.cost/main.c:748
#, fuzzy
-msgid "Re-projects a raster map from given location to the current location."
+msgid "Finding cost path..."
msgstr "출력할 격자지도"
-#: ../raster/r.proj/main.c:153
-#, fuzzy
-msgid "Location containing input raster map"
+#: ../raster/r.walk/main.c:1356 ../raster/r.cost/main.c:1011
+msgid "Error, ct == pres_cell"
+msgstr ""
+#: ../raster/r.walk/main.c:1368
+#, fuzzy, c-format
+msgid "Writing output raster map <%s>... "
msgstr "출력할 격자지도"
-#: ../raster/r.proj/main.c:154 ../raster/r.proj/main.c:159
-#: ../raster/r.proj/main.c:164 ../vector/v.net.flow/main.c:108
-#: ../vector/v.net.flow/main.c:114 ../vector/v.proj/main.c:78
-#: ../vector/v.proj/main.c:83 ../vector/v.proj/main.c:89
-#, fuzzy
-msgid "Source"
+#: ../raster/r.walk/main.c:1432 ../raster/r.cost/main.c:1131
+#, fuzzy, c-format
+msgid "Writing output movement direction raster map <%s>..."
msgstr "출력할 격자지도"
-#: ../raster/r.proj/main.c:157
+#: ../raster/r.walk/main.c:1477 ../raster/r.cost/main.c:1197
+#, c-format
+msgid "Peak cost value: %g"
+msgstr ""
+#: ../raster/r.walk/main.c:1498 ../raster/r.cost/main.c:1219
+#, c-format
+msgid "Illegal x coordinate <%s>"
+msgstr ""
+#: ../raster/r.walk/main.c:1500 ../raster/r.cost/main.c:1221
+#, c-format
+msgid "Illegal y coordinate <%s>"
+msgstr ""
+#: ../raster/r.walk/main.c:1504 ../raster/r.cost/main.c:1225
+#, c-format
+msgid "Warning, ignoring point outside window: %g, %g"
+msgstr ""
+#: ../raster/r.cost/main.c:145
+msgid ""
+"Creates a raster map showing the cumulative cost of moving between different "
+"geographic locations on an input raster map whose cell category values "
+"represent cost."
+msgstr ""
+#: ../raster/r.cost/main.c:152
#, fuzzy
-msgid "Mapset containing input raster map"
+msgid "Name of input raster map containing grid cell cost information"
msgstr "출력할 격자지도"
-#: ../raster/r.proj/main.c:158 ../vector/v.proj/main.c:82
+#: ../raster/r.cost/main.c:160
#, fuzzy
-msgid "Default: name of current mapset"
+msgid "Name for output raster map with nearest start point"
msgstr "출력할 격자지도"
-#: ../raster/r.proj/main.c:162
-#, fuzzy
-msgid "Name of input raster map to re-project"
+#: ../raster/r.cost/main.c:444
+#, fuzzy, c-format
+msgid "Reading raster map <%s>, initializing output..."
msgstr "출력할 격자지도"
-#: ../raster/r.proj/main.c:167 ../vector/v.proj/main.c:92
-msgid "Path to GRASS database of input location"
+#: ../raster/r.cost/main.c:489
+#, c-format
+msgid ""
+"Negative cell value found at row %d, col %d. Setting negative value to "
+"null_cost value"
msgstr ""
-#: ../raster/r.proj/main.c:171
-#, fuzzy
-msgid "Name for output raster map (default: same as 'input')"
+#: ../raster/r.cost/main.c:582
+#, fuzzy, c-format
+msgid "No start points found in vector map <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.proj/main.c:172 ../raster/r.proj/main.c:183
-#: ../raster/r.proj/main.c:199 ../vector/v.proj/main.c:101
-#: ../vector/v.proj/main.c:106 ../vector/v.proj/main.c:118
-#: ../vector/v.proj/main.c:125
+#: ../raster/r.cost/main.c:584
+#, fuzzy, c-format
+msgid "%d point found"
+msgid_plural "%d points found"
+msgstr[0] "출력할 격자지도"
+#: ../raster/r.cost/main.c:1036
+#, fuzzy, c-format
+msgid "Writing raster map with nearest start point <%s>..."
+msgstr "출력할 격자지도"
+#: ../raster/r.lake/main.c:153
+msgid "flood"
+msgstr ""
+#: ../raster/r.lake/main.c:154
+msgid "Fills lake at given point to given level."
+msgstr ""
+#: ../raster/r.lake/main.c:160
+msgid "Water level"
+msgstr ""
+#: ../raster/r.lake/main.c:170
+msgid "Seed point coordinates"
+msgstr ""
+#: ../raster/r.lake/main.c:171
#, fuzzy
-msgid "Target"
+msgid "Either this coordinates pair or a seed map have to be specified"
msgstr "출력할 격자지도"
-#: ../raster/r.proj/main.c:198
+#: ../raster/r.lake/main.c:175 ../raster/r.lake/main.c:184
+msgid "Seed"
+msgstr ""
+#: ../raster/r.lake/main.c:180
#, fuzzy
-msgid "Resolution of output raster map"
+msgid "Input raster map with given starting point(s) (at least 1 cell > 0)"
msgstr "출력할 격자지도"
-#: ../raster/r.proj/main.c:203
+#: ../raster/r.lake/main.c:182
#, fuzzy
-msgid "List raster maps in input mapset and exit"
+msgid "Either this parameter or a coordinates pair have to be specified"
msgstr "출력할 격자지도"
-#: ../raster/r.proj/main.c:208
-#: ../locale/scriptstrings/r.import_to_translate.c:28
-msgid "Do not perform region cropping optimization"
+#: ../raster/r.lake/main.c:189
+msgid "Use negative depth values for lake raster map"
msgstr ""
-#: ../raster/r.proj/main.c:213
-msgid "Print input map's bounds in the current projection and exit"
+#: ../raster/r.lake/main.c:194
+msgid "Overwrite seed map with result (lake) map"
msgstr ""
-#: ../raster/r.proj/main.c:219
-msgid ""
-"Print input map's bounds in the current projection and exit (shell style)"
+#: ../raster/r.lake/main.c:201
+msgid "Both seed map and coordinates cannot be specified"
msgstr ""
-#: ../raster/r.proj/main.c:252 ../vector/v.proj/main.c:159
-msgid "Input and output locations can not be the same"
+#: ../raster/r.lake/main.c:204
+msgid "Seed map or seed coordinates must be set!"
msgstr ""
-#: ../raster/r.proj/main.c:254
-msgid "Input and output locations are the same"
+#: ../raster/r.lake/main.c:207
+msgid "Seed coordinates and output map lake= must be set!"
msgstr ""
-#: ../raster/r.proj/main.c:264
-#, fuzzy
-msgid "Unable to get projection info of output raster map"
-msgstr "출력할 격자지도"
+#: ../raster/r.lake/main.c:210
+msgid "Both lake and overwrite cannot be specified"
+msgstr ""
-#: ../raster/r.proj/main.c:267
+#: ../raster/r.lake/main.c:213
+msgid "Output lake map or overwrite flag must be set!"
+msgstr ""
+#: ../raster/r.lake/main.c:240
#, fuzzy
-msgid "Unable to get projection units of output raster map"
+msgid "Seed point outside the current region"
msgstr "출력할 격자지도"
-#: ../raster/r.proj/main.c:270
-msgid "Unable to get projection key values of output raster map"
+#: ../raster/r.lake/main.c:254
+msgid "G_malloc: out of memory"
msgstr ""
-#: ../raster/r.proj/main.c:279
-#, fuzzy, c-format
-msgid "Mapset <%s> in input location <%s> - %s"
-msgstr "출력할 격자지도"
+#: ../raster/r.lake/main.c:276
+msgid ""
+"Given water level at seed point is below earth surface. Increase water level "
+"or move seed point."
+msgstr ""
-#: ../raster/r.proj/main.c:288 ../vector/v.proj/main.c:183
-#, fuzzy, c-format
-msgid "Checking location <%s> mapset <%s>"
-msgstr "출력할 격자지도"
+#: ../raster/r.lake/main.c:355
+#, c-format
+msgid "Lake depth from %f to %f (specified water level is taken as zero)"
+msgstr ""
-#: ../raster/r.proj/main.c:300 ../vector/v.edit/main.c:87
-#: ../vector/v.in.ogr/main.c:353 ../vector/v.external/main.c:105
-#: ../vector/v.what.rast/main.c:121 ../vector/v.select/main.c:89
-#: ../vector/v.net/args.c:152 ../vector/v.net/args.c:159
-#: ../vector/v.net/args.c:165 ../vector/v.net/args.c:169
-#: ../vector/v.net/args.c:179 ../vector/v.proj/main.c:200
+#: ../raster/r.lake/main.c:356
#, c-format
-msgid "Required parameter <%s> not set"
+msgid "Lake area %f square meters"
msgstr ""
-#: ../raster/r.proj/main.c:303
-#, fuzzy, c-format
-msgid "Raster map <%s> in location <%s> in mapset <%s> not found"
-msgstr "출력할 격자지도"
-#: ../raster/r.proj/main.c:311
-msgid "Unable to get projection info of input map"
+#: ../raster/r.lake/main.c:357
+#, c-format
+msgid "Lake volume %f cubic meters"
msgstr ""
-#: ../raster/r.proj/main.c:314
-msgid "Unable to get projection units of input map"
+#: ../raster/r.lake/main.c:358
+msgid "Volume is correct only if lake depth (terrain raster map) is in meters"
msgstr ""
-#: ../raster/r.proj/main.c:317
-msgid "Unable to get projection key values of input map"
+#: ../raster/r.sim/simlib/hydro.c:203
+#, c-format
+msgid "nwalk (%d) > maxw (%d)!"
msgstr ""
-#: ../raster/r.proj/main.c:332
-msgid "Unable to work with unprojected data (xy location)"
+#: ../raster/r.sim/simlib/hydro.c:398
+#, fuzzy
+msgid "Unable to write raster maps"
+msgstr "출력할 격자지도"
+#: ../raster/r.sim/simlib/hydro.c:465 ../raster/r.sim/r.sim.sediment/main.c:411
+msgid "Cannot write raster maps"
msgstr ""
-#: ../raster/r.proj/main.c:351
+#: ../raster/r.sim/simlib/observation_points.c:64
#, fuzzy, c-format
-msgid "Input map <%s@%s> in location <%s>:"
+msgid "Unable to read points from map %s"
msgstr "출력할 격자지도"
-#: ../raster/r.proj/main.c:443
-msgid "Input:"
-msgstr ""
+#: ../raster/r.sim/simlib/observation_points.c:85
+#, fuzzy, c-format
+msgid "Unable to open observation logfile %s for writing"
+msgstr "출력할 격자지도"
-#: ../raster/r.proj/main.c:444 ../raster/r.proj/main.c:455
+#: ../raster/r.sim/simlib/output.c:321 ../raster/r.sim/simlib/output.c:329
+#, fuzzy, c-format
+msgid "FP raster map <%s> not found"
+msgstr "출력할 격자지도"
+#: ../raster/r.sim/simlib/input.c:307
#, c-format
-msgid "Cols: %d (%d)"
+msgid ""
+"Raster map <%s> not found, and manin_val undefined, choose one to be allowed "
+"to process"
msgstr ""
-#: ../raster/r.proj/main.c:445 ../raster/r.proj/main.c:456
+#: ../raster/r.sim/simlib/input.c:420
+msgid "Zero value in Mannings n"
+msgstr ""
+#: ../raster/r.sim/simlib/input.c:471
+msgid "Infiltration exceeds the rainfall rate everywhere! No overland flow."
+msgstr ""
+#: ../raster/r.sim/simlib/input.c:495
#, c-format
-msgid "Rows: %d (%d)"
+msgid ""
+"Min elevation \t= %.2f m\n"
+"Max elevation \t= %.2f m\n"
msgstr ""
-#: ../raster/r.proj/main.c:446 ../raster/r.proj/main.c:457
+#: ../raster/r.sim/simlib/input.c:497
#, c-format
-msgid "North: %f (%f)"
+msgid "Mean Source Rate (rainf. excess or sediment) \t= %f m/s or kg/m2s \n"
msgstr ""
-#: ../raster/r.proj/main.c:447 ../raster/r.proj/main.c:458
+#: ../raster/r.sim/simlib/input.c:499
#, c-format
-msgid "South: %f (%f)"
+msgid "Mean flow velocity \t= %f m/s\n"
msgstr ""
-#: ../raster/r.proj/main.c:448 ../raster/r.proj/main.c:459
+#: ../raster/r.sim/simlib/input.c:500
#, c-format
-msgid "West: %f (%f)"
+msgid "Mean Mannings \t= %f\n"
msgstr ""
-#: ../raster/r.proj/main.c:449 ../raster/r.proj/main.c:460
+#: ../raster/r.sim/simlib/input.c:504
+#, fuzzy, c-format
+msgid "Number of iterations \t= %d cell\n"
+msgid_plural "Number of iterations \t= %d cells\n"
+#: ../raster/r.sim/simlib/input.c:506
#, c-format
-msgid "East: %f (%f)"
+msgid "Time step \t= %.2f s\n"
msgstr ""
-#: ../raster/r.proj/main.c:450 ../raster/r.proj/main.c:461
+#: ../raster/r.sim/simlib/input.c:508
#, c-format
-msgid "EW-res: %f"
+msgid ""
+"Sigmax \t= %f\n"
+"Max velocity \t= %f m/s\n"
msgstr ""
-#: ../raster/r.proj/main.c:451 ../raster/r.proj/main.c:462
+#: ../raster/r.sim/simlib/input.c:510
#, c-format
-msgid "NS-res: %f"
+msgid "Time step used \t= %.2f s\n"
msgstr ""
-#: ../raster/r.proj/main.c:454
-msgid "Output:"
+#: ../raster/r.sim/simlib/input.c:562
+#, fuzzy
+msgid "Unable to write et file"
+msgstr "출력할 격자지도"
+#: ../raster/r.sim/r.sim.sediment/main.c:116
+msgid "sediment flow"
msgstr ""
-#: ../raster/r.proj/main.c:491
+#: ../raster/r.sim/r.sim.sediment/main.c:118
+msgid "deposition"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:121
+msgid ""
+"Sediment transport and erosion/deposition simulation using path sampling "
+"method (SIMWE)."
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:128
#, fuzzy
-msgid "Projecting..."
+msgid "Name of water depth raster map [m]"
msgstr "출력할 격자지도"
-#: ../raster/r.proj/readcell.c:67
+#: ../raster/r.sim/r.sim.sediment/main.c:132
+#: ../raster/r.sim/r.sim.water/main.c:127
#, fuzzy
-msgid "Allocating memory and reading input raster map..."
+msgid "Name of x-derivatives raster map [m/m]"
msgstr "출력할 격자지도"
-#: ../raster/r.kappa/calc_kappa.c:32
-#, c-format
-msgid "Cannot open file <%s> to write kappa and relevant parameters"
-msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:136
+#: ../raster/r.sim/r.sim.water/main.c:131
+#, fuzzy
+msgid "Name of y-derivatives raster map [m/m]"
+msgstr "출력할 격자지도"
-#: ../raster/r.kappa/prt_mat.c:39
-#, c-format
-msgid "Cannot open file <%s> to write cats and counts (error matrix)"
-msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:141
+#, fuzzy
+msgid "Name of detachment capacity coefficient raster map [s/m]"
+msgstr "출력할 격자지도"
-#: ../raster/r.kappa/main.c:72
+#: ../raster/r.sim/r.sim.sediment/main.c:146
+#, fuzzy
+msgid "Name of transport capacity coefficient raster map [s]"
+msgstr "출력할 격자지도"
+#: ../raster/r.sim/r.sim.sediment/main.c:151
+#, fuzzy
+msgid "Name of critical shear stress raster map [Pa]"
+msgstr "출력할 격자지도"
+#: ../raster/r.sim/r.sim.sediment/main.c:156
+#: ../raster/r.sim/r.sim.water/main.c:168
+#, fuzzy
+msgid "Name of Manning's n raster map"
+msgstr "출력할 격자지도"
+#: ../raster/r.sim/r.sim.sediment/main.c:164
+#: ../raster/r.sim/r.sim.water/main.c:176
+#, fuzzy
+msgid "Manning's n unique value"
+msgstr "출력할 격자지도"
+#: ../raster/r.sim/r.sim.sediment/main.c:171
+#: ../raster/r.sim/r.sim.water/main.c:190
+#, fuzzy
+msgid "Name of sampling locations vector points map"
+msgstr "출력할 격자지도"
+#: ../raster/r.sim/r.sim.sediment/main.c:177
+#, fuzzy
+msgid "Name for output transport capacity raster map [kg/ms]"
+msgstr "출력할 격자지도"
+#: ../raster/r.sim/r.sim.sediment/main.c:184
+#, fuzzy
msgid ""
-"Calculates error matrix and kappa parameter for accuracy assessment of "
-"classification result."
-msgstr ""
+"Name for output transport limited erosion-deposition raster map [kg/m2s]"
+msgstr "출력할 격자지도"
-#: ../raster/r.kappa/main.c:78
+#: ../raster/r.sim/r.sim.sediment/main.c:191
#, fuzzy
-msgid "Name of raster map containing classification result"
+msgid "Name for output sediment concentration raster map [particle/m3]"
msgstr "출력할 격자지도"
-#: ../raster/r.kappa/main.c:83
+#: ../raster/r.sim/r.sim.sediment/main.c:197
#, fuzzy
-msgid "Name of raster map containing reference classes"
+msgid "Name for output sediment flux raster map [kg/ms]"
msgstr "출력할 격자지도"
-#: ../raster/r.kappa/main.c:88
+#: ../raster/r.sim/r.sim.sediment/main.c:204
#, fuzzy
-msgid "Name for output file containing error matrix and kappa"
+msgid "Name for output erosion-deposition raster map [kg/m2s]"
msgstr "출력할 격자지도"
-#: ../raster/r.kappa/main.c:89 ../raster/r.colors.out/raster3d_main.c:57
-#: ../raster/r.colors.out/raster_main.c:56 ../vector/v.colors.out/main.c:62
+#: ../raster/r.sim/r.sim.sediment/main.c:211
+#: ../raster/r.sim/r.sim.water/main.c:222
+msgid ""
+"Name for sampling points output text file. For each observation vector point "
+"the time series of sediment transport is stored."
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:218
+#: ../raster/r.sim/r.sim.water/main.c:215
#, fuzzy
-msgid "If not given write to standard output"
+msgid "Base name of the output walkers vector points map"
msgstr "출력할 격자지도"
-#: ../raster/r.kappa/main.c:96
-msgid "Title for error matrix and kappa"
+#: ../raster/r.sim/r.sim.sediment/main.c:225
+msgid "Number of walkers"
msgstr ""
-#: ../raster/r.kappa/main.c:102
-msgid "Wide report"
+#: ../raster/r.sim/r.sim.sediment/main.c:226
+#: ../raster/r.sim/r.sim.sediment/main.c:234
+#: ../raster/r.sim/r.sim.sediment/main.c:243
+#: ../raster/r.sim/r.sim.sediment/main.c:261
+#: ../raster/r.sim/r.sim.water/main.c:231
+#: ../raster/r.sim/r.sim.water/main.c:239
+#: ../raster/r.sim/r.sim.water/main.c:248
+#: ../raster/r.sim/r.sim.water/main.c:266
+#: ../raster/r.sim/r.sim.water/main.c:276
+#: ../raster/r.sim/r.sim.water/main.c:284
+#: ../raster/r.sim/r.sim.water/main.c:293 ../vector/v.surf.rst/main.c:155
+#: ../vector/v.surf.rst/main.c:160 ../vector/v.surf.rst/main.c:181
+#: ../vector/v.surf.rst/main.c:253 ../vector/v.surf.rst/main.c:261
+#: ../vector/v.surf.rst/main.c:268 ../vector/v.surf.rst/main.c:276
+#: ../vector/v.surf.rst/main.c:284 ../vector/v.surf.rst/main.c:293
+#: ../vector/v.surf.rst/main.c:301 ../vector/v.surf.rst/main.c:309
+#: ../vector/v.surf.rst/main.c:318 ../vector/v.surf.rst/main.c:326
+#: ../vector/v.surf.rst/main.c:333 ../imagery/i.eb.hsebal01/main.c:141
+#: ../imagery/i.eb.hsebal01/main.c:150 ../imagery/i.eb.hsebal01/main.c:157
+#: ../imagery/i.eb.hsebal01/main.c:164 ../imagery/i.eb.hsebal01/main.c:171
+#: ../imagery/i.eb.hsebal01/main.c:178
+msgid "Parameters"
msgstr ""
-#: ../raster/r.kappa/main.c:103
-msgid "132 columns (default: 80)"
+#: ../raster/r.sim/r.sim.sediment/main.c:233
+#: ../raster/r.sim/r.sim.water/main.c:238
+msgid "Time used for iterations [minutes]"
msgstr ""
-#: ../raster/r.kappa/main.c:108
-msgid "No header in the report"
+#: ../raster/r.sim/r.sim.sediment/main.c:242
+#: ../raster/r.sim/r.sim.water/main.c:247
+msgid "Time interval for creating output maps [minutes]"
msgstr ""
-#: ../raster/r.kappa/prt_hdr.c:18
-#, fuzzy, c-format
-msgid "Cannot open file <%s> to write header"
-msgstr "출력할 격자지도"
+#: ../raster/r.sim/r.sim.sediment/main.c:260
+#: ../raster/r.sim/r.sim.water/main.c:265
+msgid "Water diffusion constant"
+msgstr ""
-#: ../raster/r.kappa/prt_label.c:17
-#, fuzzy, c-format
-msgid "Can't open file <%s> to write label"
-msgstr "출력할 격자지도"
+#: ../raster/r.sim/r.sim.sediment/main.c:268
+#: ../raster/r.sim/r.sim.water/main.c:304
+msgid "Seed for random number generator"
+msgstr ""
-#: ../raster/r.out.pov/main.c:124
-#, fuzzy
-msgid "Converts a raster map layer into a height-field file for POV-Ray."
-msgstr "출력할 격자지도"
+#: ../raster/r.sim/r.sim.sediment/main.c:270
+#: ../raster/r.sim/r.sim.water/main.c:306
+msgid ""
+"The same seed can be used to obtain same results or random seed can be "
+"generated by other means."
+msgstr ""
-#: ../raster/r.out.pov/main.c:131
-msgid "Name of output povray file (TGA height field file)"
+#: ../raster/r.sim/r.sim.sediment/main.c:276
+#: ../raster/r.sim/r.sim.water/main.c:312
+msgid "Generate random seed"
msgstr ""
-#: ../raster/r.out.pov/main.c:138
-msgid "Height-field type (0=actual heights 1=normalized)"
+#: ../raster/r.sim/r.sim.sediment/main.c:278
+#: ../raster/r.sim/r.sim.water/main.c:314
+msgid ""
+"Automatically generates random seed for random number generator (use when "
+"you don't want to provide the seed option)"
msgstr ""
-#: ../raster/r.out.pov/main.c:144
-msgid "Elevation bias"
+#: ../raster/r.sim/r.sim.sediment/main.c:286
+#: ../raster/r.sim/r.sim.water/main.c:322
+#, c-format
+msgid "Generated random seed (-s): %ld"
msgstr ""
-#: ../raster/r.out.pov/main.c:150 ../raster/r.param.scale/interface.c:118
-msgid "Vertical scaling factor"
+#: ../raster/r.sim/r.sim.sediment/main.c:291
+#: ../raster/r.sim/r.sim.water/main.c:327
+#, c-format
+msgid "Read random seed from %s option: %ld"
msgstr ""
-#: ../raster/r.out.pov/main.c:170
+#: ../raster/r.sim/r.sim.sediment/main.c:373
+#: ../raster/r.sim/r.sim.water/main.c:482
+msgid "More than 100 files are going to be created !!!!!"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:379
+#: ../raster/r.sim/r.sim.water/main.c:488
#, c-format
-msgid "Invalid output filename <%s>"
+msgid "default nwalk=%d, rwalk=%f"
msgstr ""
-#: ../raster/r.out.pov/main.c:180
+#: ../raster/r.sim/r.sim.sediment/main.c:388
+#: ../raster/r.sim/r.sim.water/main.c:498
#, c-format
-msgid "Raster map is too big! Exceeds %d columns or %d rows"
+msgid "Using metric conversion factor %f, step=%f"
msgstr ""
-#: ../raster/r.out.pov/main.c:201
-msgid "Negative elevation values in input"
+#: ../raster/r.sim/r.sim.sediment/main.c:395
+#, fuzzy
+msgid "You are not outputting any raster or site files"
+msgstr "출력할 격자지도"
+#: ../raster/r.sim/r.sim.sediment/main.c:398
+#: ../raster/r.sim/r.sim.water/main.c:507 ../vector/v.surf.rst/main.c:623
+#: ../vector/v.surf.rst/main.c:678 ../vector/v.vol.rst/main.c:914
+msgid "Input failed"
msgstr ""
-#: ../raster/r.cost/main.c:141 ../raster/r.drain/main.c:111
-#: ../raster/r.walk/main.c:179
-msgid "cost surface"
+#: ../raster/r.sim/r.sim.water/main.c:116 ../vector/v.net.flow/main.c:60
+msgid "flow"
msgstr ""
-#: ../raster/r.cost/main.c:142 ../raster/r.spreadpath/main.c:90
-#: ../raster/r.walk/main.c:180
-msgid "cumulative costs"
+#: ../raster/r.sim/r.sim.water/main.c:117
+msgid "overland flow"
msgstr ""
-#: ../raster/r.cost/main.c:143 ../raster/r.walk/main.c:181
-#: ../vector/v.net.alloc/main.c:59
+#: ../raster/r.sim/r.sim.water/main.c:120
+msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:137
#, fuzzy
-msgid "cost allocation"
+msgid "Name of rainfall excess rate (rain-infilt) raster map [mm/hr]"
msgstr "출력할 격자지도"
-#: ../raster/r.cost/main.c:145
-msgid ""
-"Creates a raster map showing the cumulative cost of moving between different "
-"geographic locations on an input raster map whose cell category values "
-"represent cost."
+#: ../raster/r.sim/r.sim.water/main.c:146
+msgid "Rainfall excess rate unique value [mm/hr]"
msgstr ""
-#: ../raster/r.cost/main.c:152
+#: ../raster/r.sim/r.sim.water/main.c:153
#, fuzzy
-msgid "Name of input raster map containing grid cell cost information"
+msgid "Name of runoff infiltration rate raster map [mm/hr]"
msgstr "출력할 격자지도"
-#: ../raster/r.cost/main.c:160
+#: ../raster/r.sim/r.sim.water/main.c:162
+msgid "Runoff infiltration rate unique value [mm/hr]"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:183
#, fuzzy
-msgid "Name for output raster map with nearest start point"
+msgid "Name of flow controls raster map (permeability ratio 0-1)"
msgstr "출력할 격자지도"
-#: ../raster/r.cost/main.c:161 ../raster/r.cost/main.c:168
-#: ../raster/r.walk/main.c:203
+#: ../raster/r.sim/r.sim.water/main.c:196
#, fuzzy
-msgid "Optional outputs"
+msgid "Name for output water depth raster map [m]"
msgstr "출력할 격자지도"
-#: ../raster/r.cost/main.c:167 ../raster/r.walk/main.c:202
+#: ../raster/r.sim/r.sim.water/main.c:202
#, fuzzy
-msgid "Name for output raster map to contain movement directions"
+msgid "Name for output water discharge raster map [m3/s]"
msgstr "출력할 격자지도"
-#: ../raster/r.cost/main.c:173 ../raster/r.walk/main.c:208
+#: ../raster/r.sim/r.sim.water/main.c:208
#, fuzzy
-msgid "Name of starting vector points map"
+msgid "Name for output simulation error raster map [m]"
msgstr "출력할 격자지도"
-#: ../raster/r.cost/main.c:174 ../raster/r.cost/main.c:186
-#: ../raster/r.cost/main.c:193 ../raster/r.cost/main.c:243
-#: ../raster/r.drain/main.c:137 ../raster/r.drain/main.c:144
-#: ../raster/r.walk/main.c:209 ../raster/r.walk/main.c:221
-#: ../raster/r.walk/main.c:228 ../raster/r.walk/main.c:309
-msgid "Start"
+#: ../raster/r.sim/r.sim.water/main.c:230
+msgid "Number of walkers, default is twice the number of cells"
msgstr ""
-#: ../raster/r.cost/main.c:179 ../raster/r.walk/main.c:214
-#, fuzzy
-msgid "Name of stopping vector points map"
-msgstr "출력할 격자지도"
+#: ../raster/r.sim/r.sim.water/main.c:274
+msgid "Threshold water depth [m]"
+msgstr ""
-#: ../raster/r.cost/main.c:180 ../raster/r.cost/main.c:200
-#: ../raster/r.walk/main.c:215 ../raster/r.walk/main.c:235
-msgid "Stop"
+#: ../raster/r.sim/r.sim.water/main.c:275
+msgid "Diffusion increases after this water depth is reached"
msgstr ""
-#: ../raster/r.cost/main.c:185 ../raster/r.walk/main.c:220
+#: ../raster/r.sim/r.sim.water/main.c:283
+msgid "Diffusion increase constant"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:292
+msgid "Weighting factor for water flow velocity vector"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:297
+msgid "Time-series output"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:504
#, fuzzy
-msgid "Name of starting raster points map"
+msgid "You are not outputting any raster maps"
msgstr "출력할 격자지도"
-#: ../raster/r.cost/main.c:192 ../raster/r.drain/main.c:136
-#: ../raster/r.walk/main.c:227
+#: ../raster/r.out.mpeg/main.c:104
#, fuzzy
-msgid "Coordinates of starting point(s) (E,N)"
+msgid "animation"
msgstr "출력할 격자지도"
-#: ../raster/r.cost/main.c:199 ../raster/r.walk/main.c:234
-msgid "Coordinates of stopping point(s) (E,N)"
-msgstr ""
+#: ../raster/r.out.mpeg/main.c:107
+#, fuzzy
+msgid "Converts raster map series to MPEG movie."
+msgstr "출력할 격자지도"
-#: ../raster/r.cost/main.c:209 ../raster/r.walk/main.c:244
-msgid "Maximum cumulative cost"
+#: ../raster/r.out.mpeg/main.c:115
+#, fuzzy, c-format
+msgid "Name of input raster map(s) for view no.%d"
+msgstr "출력할 격자지도"
+#: ../raster/r.out.mpeg/main.c:117
+msgid "Views"
msgstr ""
-#: ../raster/r.cost/main.c:218 ../raster/r.walk/main.c:253
-msgid "Cost assigned to null cells. By default, null cells are excluded"
+#: ../raster/r.out.mpeg/main.c:131
+msgid "Quality factor (1 = highest quality, lowest compression)"
msgstr ""
-#: ../raster/r.cost/main.c:219 ../raster/r.cost/main.c:238
-#: ../raster/r.walk/main.c:254 ../raster/r.walk/main.c:304
-msgid "NULL cells"
+#: ../raster/r.out.mpeg/main.c:136
+msgid "Convert on the fly, uses less disk space"
msgstr ""
-#: ../raster/r.cost/main.c:228 ../raster/r.walk/main.c:263
-msgid "Maximum memory to be used in MB"
+#: ../raster/r.out.mpeg/main.c:137
+msgid "Requires r.out.ppm with stdout option"
msgstr ""
-#: ../raster/r.cost/main.c:233 ../raster/r.walk/main.c:299
-msgid "Use the 'Knight's move'; slower, but more accurate"
+#: ../raster/r.out.mpeg/main.c:160
+msgid "Either mpeg_encode or ppmtompeg must be installed"
msgstr ""
-#: ../raster/r.cost/main.c:237 ../raster/r.walk/main.c:303
-#, fuzzy
-msgid "Keep null values in output raster map"
+#: ../raster/r.out.mpeg/main.c:291
+#, fuzzy, c-format
+msgid "Unable to read color table for <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.cost/main.c:242 ../raster/r.walk/main.c:308
-msgid "Start with values in raster map"
+#: ../raster/r.out.mpeg/main.c:341 ../raster/r.out.mpeg/main.c:374
+msgid "mpeg_encode ERROR"
msgstr ""
-#: ../raster/r.cost/main.c:247 ../raster/r.walk/main.c:313
-msgid "Print info about disk space and memory requirements and exit"
+#: ../raster/r.out.mpeg/main.c:417
+msgid "Error reading wildcard"
msgstr ""
-#: ../raster/r.cost/main.c:297 ../raster/r.walk/main.c:357
-msgid "Must specify exactly one of start_points, start_rast or coordinate"
+#: ../raster/r.out.mpeg/write.c:81 ../raster/r.out.mpeg/write.c:178
+msgid "Size mismatch error!"
msgstr ""
-#: ../raster/r.cost/main.c:302 ../raster/r.cost/main.c:712
-#: ../raster/r.walk/main.c:362 ../raster/r.walk/main.c:845
-msgid "No start points"
+#: ../raster/r.out.mpeg/write.c:139 ../raster/r.out.mpeg/write.c:181
+msgid "Unable to open output file"
msgstr ""
-#: ../raster/r.cost/main.c:309 ../raster/r.walk/main.c:369
-#, c-format
-msgid "Inappropriate maximum cost: %d"
+#: ../raster/r.out.mpeg/write.c:215
+msgid "Unable to create temporary files."
msgstr ""
-#: ../raster/r.cost/main.c:312 ../raster/r.walk/main.c:372
+#: ../raster/r.support.stats/check.c:43
#, c-format
-msgid "Inappropriate amount of memory: %d"
+msgid "Updating statistics for [%s]..."
msgstr ""
-#: ../raster/r.cost/main.c:330 ../raster/r.walk/main.c:415
-msgid "Assigning negative cost to null cell. Null cells excluded."
+#: ../raster/r.support.stats/check.c:56
+msgid "Updating histogram range..."
msgstr ""
-#: ../raster/r.cost/main.c:412 ../raster/r.cost/main.c:424
-#: ../raster/r.walk/main.c:525 ../raster/r.walk/main.c:538
+#: ../raster/r.support.stats/check.c:88
#, c-format
-msgid "Will need at least %.2f MB of disk space"
+msgid "Updating the number of categories for [%s]..."
msgstr ""
-#: ../raster/r.cost/main.c:414 ../raster/r.cost/main.c:425
-#: ../raster/r.walk/main.c:527 ../raster/r.walk/main.c:539
-#, c-format
-msgid "Will need at least %.2f MB of memory"
+#: ../raster/r.support.stats/main.c:37
+msgid "Update raster map statistics"
msgstr ""
-#: ../raster/r.cost/main.c:416 ../raster/r.cost/main.c:426
-#: ../raster/r.walk/main.c:529 ../raster/r.walk/main.c:540
-#, c-format
-msgid "%d of %d segments are kept in memory"
-msgstr ""
+#: ../raster/r.support.stats/main.c:49
+#, fuzzy, c-format
+msgid "Statistics for <%s> updated"
+msgstr "출력할 격자지도"
-#: ../raster/r.cost/main.c:431 ../raster/r.walk/main.c:545
+#: ../raster/r.grow.distance/main.c:154
#, fuzzy
-msgid "Creating some temporary files..."
+msgid "Generates a raster map containing distances to nearest raster features."
msgstr "출력할 격자지도"
-#: ../raster/r.cost/main.c:444
-#, fuzzy, c-format
-msgid "Reading raster map <%s>, initializing output..."
+#: ../raster/r.grow.distance/main.c:161
+#, fuzzy
+msgid "Name for distance output raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.cost/main.c:489
-#, c-format
-msgid ""
-"Negative cell value found at row %d, col %d. Setting negative value to "
-"null_cost value"
+#: ../raster/r.grow.distance/main.c:167
+#, fuzzy
+msgid "Name for value output raster map"
+msgstr "출력할 격자지도"
+#: ../raster/r.grow.distance/main.c:180
+msgid "Output distances in meters instead of map units"
msgstr ""
-#: ../raster/r.cost/main.c:504 ../raster/r.walk/main.c:643
+#: ../raster/r.grow.distance/main.c:184
#, fuzzy
-msgid "Initializing directional output..."
+msgid "Calculate distance to nearest NULL cell"
msgstr "출력할 격자지도"
-#: ../raster/r.cost/main.c:535 ../raster/r.drain/main.c:270
-#: ../raster/r.walk/main.c:675
-#, fuzzy, c-format
-msgid "Reading vector map <%s> with start points..."
-msgstr "출력할 격자지도"
+#: ../raster/r.grow.distance/main.c:195
+msgid "Distance output is required for distance to NULL cells"
+msgstr ""
-#: ../raster/r.cost/main.c:548 ../raster/r.cost/main.c:618
-#: ../raster/r.drain/main.c:283 ../raster/r.to.vect/main.c:289
-#: ../raster/r.walk/main.c:688 ../raster/r.walk/main.c:754
-#: ../display/d.vect.thematic/display.c:75 ../display/d.vect/topo.c:52
-#: ../display/d.vect/vert.c:27 ../display/d.vect/dir.c:30
-#: ../display/d.vect/attr.c:51 ../display/d.vect/lines.c:143
-#: ../display/d.vect/label.c:44 ../vector/v.label.sa/labels.c:141
-#: ../vector/v.info/level1.c:37 ../vector/v.out.lidar/main.c:732
-#: ../vector/v.label/main.c:293 ../vector/v.decimate/main.c:404
-#: ../vector/v.colors/scan_cats.c:24 ../vector/v.colors/scan_z.c:36
-#: ../vector/v.perturb/main.c:181 ../vector/v.colors.out/scan_cats.c:32
-#: ../vector/v.to.3d/trans2.c:84 ../vector/v.to.3d/trans3.c:85
-#: ../vector/v.vol.rst/user1.c:140
+#: ../raster/r.grow.distance/main.c:197
+msgid "Value output is meaningless for distance to NULL cells"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:203
#, fuzzy
-msgid "Unable to read vector map"
+msgid "At least one of distance= and value= must be given"
msgstr "출력할 격자지도"
-#: ../raster/r.cost/main.c:582
+#: ../raster/r.grow.distance/main.c:218
+msgid "metric=geodesic is only valid for lat/lon"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:224
+#, c-format
+msgid "Unknown metric: '%s'"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:229
+#, c-format
+msgid "Output distance in meters for lat/lon is only possible with '%s=%s'"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:249
#, fuzzy, c-format
-msgid "No start points found in vector map <%s>"
+msgid "Unable to create temporary file <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.cost/main.c:584
-#, fuzzy, c-format
-msgid "%d point found"
-msgid_plural "%d points found"
-msgstr[0] "출력할 격자지도"
-msgstr[1] "출력할 격자지도"
+#: ../raster/r.grow.distance/main.c:325 ../raster/r.fill.dir/main.c:253
+#: ../raster/r.stream.extract/close.c:248
+#, fuzzy
+msgid "Writing output raster maps..."
+msgstr "출력할 격자지도"
-#: ../raster/r.cost/main.c:598 ../raster/r.walk/main.c:734
+#: ../raster/r.grow.distance/main.c:382 ../raster/r.fill.dir/main.c:153
+#: ../raster/r.colors/edit_colors.c:396 ../raster/r.colors.out/raster_main.c:69
+#: ../vector/v.colors/main.c:315
#, fuzzy, c-format
-msgid "Reading vector map <%s> with stop points..."
+msgid "Unable to read color table for raster map <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.cost/main.c:652 ../raster/r.walk/main.c:788
-#, fuzzy, c-format
-msgid "No stop points found in vector <%s>"
+#: ../raster/r.transect/main.c:84
+#, c-format
+msgid "End coordinate: %.15g, %.15g"
+msgstr ""
+#: ../raster/r.transect/main.c:104 ../vector/v.profile/main.c:100
+#, fuzzy
+msgid "transect"
msgstr "출력할 격자지도"
-#: ../raster/r.cost/main.c:675 ../raster/r.walk/main.c:810
-#, fuzzy, c-format
-msgid "Reading raster map <%s> with start points..."
+#: ../raster/r.transect/main.c:106
+msgid ""
+"Outputs raster map layer values lying along user defined transect line(s)."
+msgstr ""
+#: ../raster/r.transect/main.c:110
+msgid "Raster map to be queried"
+msgstr ""
+#: ../raster/r.transect/main.c:116
+msgid "Transect definition"
+msgstr ""
+#: ../raster/r.transect/main.c:126 ../raster/r.profile/main.c:93
+msgid "Output easting and northing in first two columns of four column output"
+msgstr ""
+#: ../raster/r.fill.dir/dopolys.c:84
+#, c-format
+msgid "Found %d unresolved area"
+msgid_plural "Found %d unresolved areas"
+msgstr[0] ""
+#: ../raster/r.fill.dir/main.c:88
+msgid "sink"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:89
+msgid "fill sinks"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:90
+#, fuzzy
+msgid "depressions"
msgstr "출력할 격자지도"
-#: ../raster/r.cost/main.c:726 ../raster/r.walk/main.c:859
-msgid "Specified starting location outside database window"
+#: ../raster/r.fill.dir/main.c:92
+msgid ""
+"Filters and generates a depressionless elevation map and a flow direction "
+"map from a given elevation raster map."
msgstr ""
-#: ../raster/r.cost/main.c:748 ../raster/r.walk/main.c:879
+#: ../raster/r.fill.dir/main.c:99
#, fuzzy
-msgid "Finding cost path..."
+msgid "Name for output depressionless elevation raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.cost/main.c:1011 ../raster/r.walk/main.c:1356
-msgid "Error, ct == pres_cell"
+#: ../raster/r.fill.dir/main.c:103
+#, fuzzy
+msgid ""
+"Name for output flow direction map for depressionless elevation raster map"
+msgstr "출력할 격자지도"
+#: ../raster/r.fill.dir/main.c:108
+#, fuzzy
+msgid "Name for output raster map of problem areas"
+msgstr "출력할 격자지도"
+#: ../raster/r.fill.dir/main.c:115
+msgid "Aspect direction format"
msgstr ""
-#: ../raster/r.cost/main.c:1036
+#: ../raster/r.fill.dir/main.c:121
+msgid "Find unresolved areas only"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:127
#, fuzzy, c-format
-msgid "Writing raster map with nearest start point <%s>..."
+msgid "The '%c' flag requires '%s'to be specified"
msgstr "출력할 격자지도"
-#: ../raster/r.cost/main.c:1131 ../raster/r.walk/main.c:1432
-#, fuzzy, c-format
-msgid "Writing output movement direction raster map <%s>..."
+#: ../raster/r.fill.dir/main.c:148
+msgid "Direction map is D8 resolution, i.e. 45 degrees"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:190
+#, fuzzy
+msgid "Reading input elevation raster map..."
msgstr "출력할 격자지도"
-#: ../raster/r.cost/main.c:1197 ../raster/r.walk/main.c:1477
-#, c-format
-msgid "Peak cost value: %g"
+#: ../raster/r.fill.dir/main.c:200
+msgid "Filling sinks..."
msgstr ""
-#: ../raster/r.cost/main.c:1219 ../raster/r.walk/main.c:1498
-#, c-format
-msgid "Illegal x coordinate <%s>"
+#: ../raster/r.fill.dir/main.c:204
+msgid "Determining flow directions for ambiguous cases..."
msgstr ""
-#: ../raster/r.cost/main.c:1221 ../raster/r.walk/main.c:1500
-#, c-format
-msgid "Illegal y coordinate <%s>"
+#: ../raster/r.fill.dir/main.c:217
+msgid "Repeat to get the final directions..."
msgstr ""
-#: ../raster/r.cost/main.c:1225 ../raster/r.walk/main.c:1504
+#: ../raster/r.fill.dir/wtrshed.c:95
#, c-format
-msgid "Warning, ignoring point outside window: %g, %g"
+msgid "Watershed pass %d"
msgstr ""
-#: ../raster/r.stream.extract/do_astar.c:40
-msgid "A* Search..."
-msgstr ""
-#: ../raster/r.stream.extract/do_astar.c:62
+#: ../raster/r.fill.dir/resolve.c:136
#, c-format
-msgid "%lld surplus points"
+msgid "Downward pass %d"
msgstr ""
-#: ../raster/r.stream.extract/do_astar.c:67
+#: ../raster/r.fill.dir/resolve.c:173
#, c-format
-msgid "Too many points in heap %lld, should be %lld"
+msgid "Upward pass %d"
msgstr ""
-#: ../raster/r.stream.extract/dseg.c:19
+#: ../raster/r.stream.extract/bseg.c:19 ../raster/r.stream.extract/seg.c:19
+#: ../raster/r.stream.extract/cseg.c:19
#, fuzzy
-msgid "dseg_open(): unable to create segment file"
+msgid "Unable to create segment file"
msgstr "출력할 격자지도"
+#: ../raster/r.stream.extract/bseg.c:28 ../raster/r.stream.extract/bseg.c:78
+#: ../raster/r.stream.extract/bseg.c:87 ../raster/r.stream.extract/seg.c:33
+#: ../raster/r.stream.extract/seg.c:75 ../raster/r.stream.extract/cseg.c:29
+#: ../raster/r.stream.extract/cseg.c:79 ../raster/r.stream.extract/cseg.c:88
#: ../raster/r.stream.extract/dseg.c:29 ../raster/r.stream.extract/dseg.c:79
-#: ../raster/r.stream.extract/dseg.c:88 ../raster/r.stream.extract/bseg.c:28
-#: ../raster/r.stream.extract/bseg.c:78 ../raster/r.stream.extract/bseg.c:87
-#: ../raster/r.stream.extract/cseg.c:29 ../raster/r.stream.extract/cseg.c:79
-#: ../raster/r.stream.extract/cseg.c:88 ../raster/r.stream.extract/seg.c:33
-#: ../raster/r.stream.extract/seg.c:75
+#: ../raster/r.stream.extract/dseg.c:88
#, fuzzy
msgid "Unable to write segment file"
msgstr "출력할 격자지도"
-#: ../raster/r.stream.extract/dseg.c:33
+#: ../raster/r.stream.extract/bseg.c:32 ../raster/r.stream.extract/seg.c:37
+#: ../raster/r.stream.extract/cseg.c:33
#, fuzzy
-msgid "Iillegal configuration parameter(s)"
+msgid "Illegal configuration parameter(s)"
msgstr "출력할 격자지도"
-#: ../raster/r.stream.extract/dseg.c:40 ../raster/r.stream.extract/bseg.c:39
-#: ../raster/r.stream.extract/cseg.c:40
+#: ../raster/r.stream.extract/bseg.c:39 ../raster/r.stream.extract/cseg.c:40
+#: ../raster/r.stream.extract/dseg.c:40
#, fuzzy
msgid "Unable to re-open segment file"
msgstr "출력할 격자지도"
+#: ../raster/r.stream.extract/bseg.c:46 ../raster/r.stream.extract/bseg.c:96
+#: ../raster/r.stream.extract/seg.c:51 ../raster/r.stream.extract/seg.c:93
+#: ../raster/r.stream.extract/seg.c:102 ../raster/r.stream.extract/cseg.c:47
#: ../raster/r.stream.extract/dseg.c:47 ../raster/r.stream.extract/dseg.c:97
-#: ../raster/r.stream.extract/bseg.c:46 ../raster/r.stream.extract/bseg.c:96
-#: ../raster/r.stream.extract/cseg.c:47 ../raster/r.stream.extract/seg.c:51
-#: ../raster/r.stream.extract/seg.c:93 ../raster/r.stream.extract/seg.c:102
#, fuzzy
msgid "Unable to read segment file"
msgstr "출력할 격자지도"
-#: ../raster/r.stream.extract/dseg.c:120
-#, fuzzy, c-format
-msgid "Inable to segment put row %d for raster <%s>"
-msgstr "출력할 격자지도"
+#: ../raster/r.stream.extract/del_streams.c:130
+#, c-format
+msgid "Deleting stream segments shorter than %d cell..."
+msgid_plural "Deleting stream segments shorter than %d cells..."
+msgstr[0] ""
-#: ../raster/r.stream.extract/init_search.c:24
-#, fuzzy
-msgid "Initializing A* search..."
-msgstr "출력할 격자지도"
+#: ../raster/r.stream.extract/del_streams.c:193
+#, c-format
+msgid "%d stream segment deleted"
+msgid_plural "%d stream segments deleted"
+msgstr[0] ""
#: ../raster/r.stream.extract/close.c:34
#, fuzzy, c-format
@@ -14735,14 +16479,28 @@
msgid "Writing attribute data..."
msgstr "출력할 격자지도"
+#: ../raster/r.stream.extract/close.c:172 ../display/d.vect/opt.c:147
+#: ../display/d.vect.thematic/main.c:294 ../vector/v.out.vtk/writeVTK.c:644
+#: ../vector/v.edit/select.c:509 ../vector/v.profile/main.c:349
+#: ../vector/v.profile/main.c:457 ../vector/v.out.svg/main.c:152
+#: ../vector/v.db.connect/main.c:217 ../vector/v.db.connect/main.c:283
+#: ../doc/vector/v.example/main.c:126 ../db/db.createdb/main.c:42
+#: ../db/db.describe/main.c:56 ../db/db.databases/main.c:48
+#: ../db/db.execute/main.c:70 ../db/db.dropdb/main.c:42
+#: ../db/db.tables/main.c:45 ../db/db.select/main.c:75
+#: ../db/db.columns/main.c:51
+#, fuzzy, c-format
+msgid "Unable to start driver <%s>"
+msgstr "출력할 격자지도"
#: ../raster/r.stream.extract/close.c:188 ../raster/r.contour/main.c:183
-#: ../vector/v.net.flow/main.c:181 ../vector/v.net.centrality/main.c:266
-#: ../vector/v.overlay/main.c:587 ../vector/v.net.allpairs/main.c:179
-#: ../vector/v.net.timetable/main.c:103 ../vector/v.distance/main.c:1356
-#: ../vector/v.net.path/path.c:109 ../vector/v.in.lidar/attributes.c:135
-#: ../vector/v.net.distance/main.c:291 ../vector/v.net.components/main.c:190
-#: ../vector/v.in.ogr/main.c:1150 ../vector/v.in.dwg/main.c:240
-#: ../vector/v.to.points/main.c:182
+#: ../vector/v.net.components/main.c:190 ../vector/v.net.distance/main.c:291
+#: ../vector/v.net.flow/main.c:181 ../vector/v.net.timetable/main.c:103
+#: ../vector/v.overlay/main.c:587 ../vector/v.in.ogr/main.c:1150
+#: ../vector/v.net.allpairs/main.c:179 ../vector/v.to.points/main.c:182
+#: ../vector/v.net.path/path.c:109 ../vector/v.in.dwg/main.c:240
+#: ../vector/v.in.lidar/attributes.c:135 ../vector/v.net.centrality/main.c:266
+#: ../vector/v.distance/main.c:1356
#, fuzzy, c-format
msgid "Unable to create table: '%s'"
msgstr "출력할 격자지도"
@@ -14762,6 +16520,29 @@
msgid "Unable to write vector map <%s>"
msgstr "출력할 격자지도"
+#: ../raster/r.stream.extract/init_search.c:24
+#, fuzzy
+msgid "Initializing A* search..."
+msgstr "출력할 격자지도"
+#: ../raster/r.stream.extract/load.c:33
+#, fuzzy
+msgid "Loading elevation raster map..."
+msgstr "출력할 격자지도"
+#: ../raster/r.stream.extract/load.c:35
+#, fuzzy
+msgid "Loading input raster maps..."
+msgstr "출력할 격자지도"
+#: ../raster/r.stream.extract/load.c:95
+msgid "Elevation raster map is NULL but accumulation map is not NULL"
+msgstr ""
+#: ../raster/r.stream.extract/load.c:120
+msgid "Accumulation raster map is NULL but elevation map is not NULL"
+msgstr ""
#: ../raster/r.stream.extract/main.c:78
msgid "stream network"
msgstr ""
@@ -14782,12 +16563,6 @@
"anew"
msgstr ""
-#: ../raster/r.stream.extract/main.c:89 ../raster/r.stream.extract/main.c:97
-#: ../raster/r.flow/main.c:435 ../raster/r.flow/main.c:441
-#, fuzzy
-msgid "Input maps"
-msgstr "출력할 격자지도"
#: ../raster/r.stream.extract/main.c:93
#, fuzzy
msgid "Name of input raster map with real depressions"
@@ -14840,13 +16615,6 @@
msgid "Name for output raster map with unique stream ids"
msgstr "출력할 격자지도"
-#: ../raster/r.stream.extract/main.c:149 ../raster/r.stream.extract/main.c:156
-#: ../raster/r.stream.extract/main.c:163 ../raster/r.flow/main.c:459
-#: ../raster/r.flow/main.c:465 ../raster/r.flow/main.c:471
-#, fuzzy
-msgid "Output maps"
-msgstr "출력할 격자지도"
#: ../raster/r.stream.extract/main.c:154
#, fuzzy
msgid "Name for output vector map with unique stream ids"
@@ -14959,50 +16727,27 @@
msgid "Unable to write output raster maps"
msgstr "출력할 격자지도"
-#: ../raster/r.stream.extract/bseg.c:19 ../raster/r.stream.extract/cseg.c:19
-#: ../raster/r.stream.extract/seg.c:19
-#, fuzzy
-msgid "Unable to create segment file"
-msgstr "출력할 격자지도"
+#: ../raster/r.stream.extract/do_astar.c:40
+msgid "A* Search..."
+msgstr ""
-#: ../raster/r.stream.extract/bseg.c:32 ../raster/r.stream.extract/cseg.c:33
-#: ../raster/r.stream.extract/seg.c:37
-#, fuzzy
-msgid "Illegal configuration parameter(s)"
-msgstr "출력할 격자지도"
-#: ../raster/r.stream.extract/cseg.c:97
-#, fuzzy
-msgid "Unabel to read segment file"
-msgstr "출력할 격자지도"
-#: ../raster/r.stream.extract/cseg.c:120
-#, fuzzy, c-format
-msgid "Unable to segment put row %d for raster map <%s>"
-msgstr "출력할 격자지도"
-#: ../raster/r.stream.extract/del_streams.c:130
+#: ../raster/r.stream.extract/do_astar.c:62
#, c-format
-msgid "Deleting stream segments shorter than %d cell..."
-msgid_plural "Deleting stream segments shorter than %d cells..."
-msgstr[0] ""
-msgstr[1] ""
+msgid "%lld surplus points"
+msgstr ""
-#: ../raster/r.stream.extract/del_streams.c:193
+#: ../raster/r.stream.extract/do_astar.c:67
#, c-format
-msgid "%d stream segment deleted"
-msgid_plural "%d stream segments deleted"
-msgstr[0] ""
-msgstr[1] ""
+msgid "Too many points in heap %lld, should be %lld"
+msgstr ""
-#: ../raster/r.stream.extract/thin.c:83
-#, fuzzy
-msgid "Thinning stream segments..."
+#: ../raster/r.stream.extract/seg.c:44
+#, fuzzy, c-format
+msgid "Unable to re-open file '%s'"
msgstr "출력할 격자지도"
-#: ../raster/r.stream.extract/thin.c:169
-#, c-format
-msgid "%d of %lld stream segments were thinned"
+#: ../raster/r.stream.extract/seg.c:84
+msgid "seg_put_row(): could not write segment file"
msgstr ""
#: ../raster/r.stream.extract/streams.c:72
@@ -15022,8 +16767,8 @@
msgstr "출력할 격자지도"
#: ../raster/r.stream.extract/streams.c:336
+#: ../raster/r.watershed/ram/do_cum.c:443
#: ../raster/r.watershed/seg/do_cum.c:487
-#: ../raster/r.watershed/ram/do_cum.c:443
#, c-format
msgid "MFD: cumulative proportion of flow distribution not 1.0 but %f"
msgstr ""
@@ -15048,1546 +16793,1664 @@
"%lld cells"
msgstr ""
-#: ../raster/r.stream.extract/load.c:33
+#: ../raster/r.stream.extract/cseg.c:97
#, fuzzy
-msgid "Loading elevation raster map..."
+msgid "Unabel to read segment file"
msgstr "출력할 격자지도"
-#: ../raster/r.stream.extract/load.c:35
+#: ../raster/r.stream.extract/cseg.c:120
+#, fuzzy, c-format
+msgid "Unable to segment put row %d for raster map <%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.stream.extract/thin.c:83
#, fuzzy
-msgid "Loading input raster maps..."
+msgid "Thinning stream segments..."
msgstr "출력할 격자지도"
-#: ../raster/r.stream.extract/load.c:95
-msgid "Elevation raster map is NULL but accumulation map is not NULL"
+#: ../raster/r.stream.extract/thin.c:169
+#, c-format
+msgid "%d of %lld stream segments were thinned"
msgstr ""
-#: ../raster/r.stream.extract/load.c:120
-msgid "Accumulation raster map is NULL but elevation map is not NULL"
-msgstr ""
+#: ../raster/r.stream.extract/dseg.c:19
+#, fuzzy
+msgid "dseg_open(): unable to create segment file"
+msgstr "출력할 격자지도"
-#: ../raster/r.stream.extract/seg.c:44
+#: ../raster/r.stream.extract/dseg.c:33
+#, fuzzy
+msgid "Iillegal configuration parameter(s)"
+msgstr "출력할 격자지도"
+#: ../raster/r.stream.extract/dseg.c:120
#, fuzzy, c-format
-msgid "Unable to re-open file '%s'"
+msgid "Inable to segment put row %d for raster <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.stream.extract/seg.c:84
-msgid "seg_put_row(): could not write segment file"
+#: ../raster/r.stats.quantile/main.c:86
+#, fuzzy
+msgid "Computing histograms"
+msgstr "출력할 격자지도"
+#: ../raster/r.stats.quantile/main.c:123
+msgid "No cells found where both base and cover are not NULL"
msgstr ""
-#: ../raster/r.drain/main.c:113
+#: ../raster/r.stats.quantile/main.c:315
#, fuzzy
-msgid ""
-"Traces a flow through an elevation model or cost surface on a raster map."
+msgid "Printing quantiles"
msgstr "출력할 격자지도"
-#: ../raster/r.drain/main.c:116
+#: ../raster/r.stats.quantile/main.c:412
#, fuzzy
-msgid "Name of input elevation or cost surface raster map"
+msgid "Generating reclass maps"
msgstr "출력할 격자지도"
-#: ../raster/r.drain/main.c:121
-msgid "Name of input movement direction map associated with the cost surface"
-msgstr ""
+#: ../raster/r.stats.quantile/main.c:454
+#, fuzzy
+msgid "Writing output maps"
+msgstr "출력할 격자지도"
-#: ../raster/r.drain/main.c:123 ../raster/r.drain/main.c:164
-msgid "Cost surface"
+#: ../raster/r.stats.quantile/main.c:518
+msgid "Compute category quantiles using two passes."
msgstr ""
-#: ../raster/r.drain/main.c:131
+#: ../raster/r.stats.quantile/main.c:545
#, fuzzy
-msgid "Name for output drain vector map"
+msgid "Resultant raster map(s)"
msgstr "출력할 격자지도"
-#: ../raster/r.drain/main.c:132
-msgid "Recommended for cost surface made using knight's move"
-msgstr ""
+#: ../raster/r.stats.quantile/main.c:567
+#, fuzzy
+msgid "Do not create output maps; just print statistics"
+msgstr "출력할 격자지도"
-#: ../raster/r.drain/main.c:142
+#: ../raster/r.stats.quantile/main.c:572
#, fuzzy
-msgid "Name of starting vector points map(s)"
+msgid "Print statistics in table format"
msgstr "출력할 격자지도"
-#: ../raster/r.drain/main.c:148
-msgid "Copy input cell values on output"
+#: ../raster/r.stats.quantile/main.c:584
+#, fuzzy, c-format
+msgid "Either -%c or %s= must be given"
+msgstr "출력할 격자지도"
+#: ../raster/r.stats.quantile/main.c:613
+#, c-format
+msgid "Number of quantiles (%d) does not match number of output maps (%d)"
msgstr ""
-#: ../raster/r.drain/main.c:152
-msgid "Accumulate input values along the path"
+#: ../raster/r.stats.quantile/main.c:630
+#, c-format
+msgid ""
+"Base map <%s> has many categories (%d), computation might be slow and might "
+"need a lot of memory"
msgstr ""
-#: ../raster/r.drain/main.c:153 ../raster/r.drain/main.c:158
+#: ../raster/r.resample/main.c:57
+msgid "GRASS raster map layer data resampling capability."
+msgstr ""
+#: ../raster/r.resample/main.c:66
+msgid "Name of an input layer"
+msgstr ""
+#: ../raster/r.resample/main.c:73
+msgid "Name of an output layer"
+msgstr ""
+#: ../raster/r.resample/main.c:138
#, fuzzy
-msgid "Path settings"
+msgid "Creating new cats file..."
msgstr "출력할 격자지도"
-#: ../raster/r.drain/main.c:157
-msgid "Count cell numbers along the path"
+#: ../raster/r.out.gridatb/main.c:70
+msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)."
msgstr ""
-#: ../raster/r.drain/main.c:163
+#: ../raster/r.horizon/main.c:184
+msgid "Computes horizon angle height from a digital elevation model."
+msgstr ""
+#: ../raster/r.horizon/main.c:186
msgid ""
-"The input raster map is a cost surface (direction surface must also be "
-"specified)"
+"The module has two different modes of operation: 1. Computes the entire "
+"horizon around a single point whose coordinates are given with the 'coord' "
+"option. The horizon height (in radians). 2. Computes one or more raster maps "
+"of the horizon height in a single direction. The input for this is the angle "
+"(in degrees), which is measured counterclockwise with east=0, north=90 etc. "
+"The output is the horizon height in radians."
msgstr ""
-#: ../raster/r.drain/main.c:175
-msgid "Directional drain selected... checking for direction raster map"
+#: ../raster/r.horizon/main.c:203
+msgid "Direction in which you want to know the horizon height"
msgstr ""
-#: ../raster/r.drain/main.c:178
-msgid "Surface/Hydrology drain selected"
+#: ../raster/r.horizon/main.c:220
+msgid "Start angle for multidirectional horizon [degrees]"
msgstr ""
-#: ../raster/r.drain/main.c:183
-#, c-format
+#: ../raster/r.horizon/main.c:221 ../raster/r.horizon/main.c:230
+#: ../raster/r.horizon/main.c:238 ../raster/r.horizon/main.c:246
+#: ../raster/r.horizon/main.c:254 ../raster/r.horizon/main.c:262
+#: ../raster/r.horizon/main.c:270 ../raster/r.horizon/main.c:283
+#, fuzzy
+msgid "Raster mode"
+msgstr "격자지도"
+#: ../raster/r.horizon/main.c:229
+msgid "End angle for multidirectional horizon [degrees]"
+msgstr ""
+#: ../raster/r.horizon/main.c:237
msgid ""
-"Direction raster map <%s> not specified, if direction flag is on, a "
-"direction raster must be given"
+"For horizon rasters, read from the DEM an extra buffer around the present "
+"region"
msgstr ""
-#: ../raster/r.drain/main.c:190
-#, c-format
+#: ../raster/r.horizon/main.c:245
msgid ""
-"Direction raster map <%s> should not be specified for Surface/Hydrology "
-"drains"
+"For horizon rasters, read from the DEM an extra buffer eastward the present "
+"region"
msgstr ""
-#: ../raster/r.drain/main.c:209
-msgid "Specify just one of the -c, -a and -n flags"
+#: ../raster/r.horizon/main.c:253
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer westward the present "
+"region"
msgstr ""
-#: ../raster/r.drain/main.c:240
-#, c-format
-msgid "Starting point %d is outside the current region"
+#: ../raster/r.horizon/main.c:261
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer northward the present "
+"region"
msgstr ""
-#: ../raster/r.drain/main.c:315
-#, fuzzy, c-format
-msgid "Starting vector map <%s> contains no points in the current region"
-msgstr "출력할 격자지도"
+#: ../raster/r.horizon/main.c:269
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer southward the present "
+"region"
+msgstr ""
-#: ../raster/r.drain/main.c:323
-msgid "No start/stop point(s) specified"
+#: ../raster/r.horizon/main.c:277
+msgid "The maximum distance to consider when finding the horizon height"
msgstr ""
-#: ../raster/r.drain/main.c:398
-#, fuzzy
-msgid "Calculating flow directions..."
-msgstr "출력할 격자지도"
+#: ../raster/r.horizon/main.c:288
+msgid "Coordinate for which you want to calculate the horizon"
+msgstr ""
-#: ../raster/r.drain/main.c:467
+#: ../raster/r.horizon/main.c:289 ../raster/r.horizon/main.c:305
#, fuzzy
-msgid "Writing output raster map..."
+msgid "Point mode"
msgstr "출력할 격자지도"
-#: ../raster/r.drain/main.c:689
-#, c-format
-msgid "direction read: %lf, neighbour found: %i"
+#: ../raster/r.horizon/main.c:304 ../raster/r.profile/main.c:64
+msgid "Name of file for output (use output=- for stdout)"
msgstr ""
-#: ../raster/r.to.vect/lines_io.c:76
-msgid "write_line: found half a loop!"
+#: ../raster/r.horizon/main.c:310
+msgid "Write output in degrees (default is radians)"
msgstr ""
-#: ../raster/r.to.vect/lines_io.c:177
-#, c-format
+#: ../raster/r.horizon/main.c:315
+msgid "Write output in compass orientation (default is CCW, East=0)"
+msgstr ""
+#: ../raster/r.horizon/main.c:355
msgid ""
-"write_line: line terminated unexpectedly\n"
-" previous (%d) point %p (%d,%d,%d) %p %p"
+"Note: In latitude-longitude coordinate system specify buffers in degree unit"
msgstr ""
-#: ../raster/r.to.vect/util.c:157 ../raster/r.to.vect/areas_io.c:359
-#: ../raster/r.volume/main.c:296 ../vector/v.in.lidar/attributes.c:240
-#: ../vector/v.in.ogr/main.c:1292 ../vector/v.random/main.c:469
-#: ../vector/v.random/main.c:589 ../vector/v.vol.rst/vector.c:80
-#, c-format
-msgid "Cannot insert new row: %s"
+#: ../raster/r.horizon/main.c:368
+msgid "Can't read the coordinates from the \"coordinate\" option."
msgstr ""
-#: ../raster/r.to.vect/points.c:36
-msgid "Extracting points..."
-msgstr "점을 추출하는 중..."
+#: ../raster/r.horizon/main.c:395
+msgid "You didn't specify a direction value or step size. Aborting."
+msgstr ""
-#: ../raster/r.to.vect/main.c:79
-#, fuzzy
-msgid "vectorization"
-msgstr "출력할 격자지도"
+#: ../raster/r.horizon/main.c:400
+msgid "You didn't specify a horizon raster name. Aborting."
+msgstr ""
-#: ../raster/r.to.vect/main.c:80
-#, fuzzy
-msgid "Converts a raster map into a vector map."
-msgstr "출력할 격자지도"
+#: ../raster/r.horizon/main.c:415
+msgid "Negative values of start angle are not allowed. Aborting."
+msgstr ""
-#: ../raster/r.to.vect/main.c:87
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:7
-#: ../vector/v.mkgrid/main.c:136
-#, fuzzy
-msgid "Output feature type"
-msgstr "출력할 격자지도"
-#: ../raster/r.to.vect/main.c:94
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:11
-#, fuzzy
-msgid "Name of attribute column to store value"
-msgstr "출력할 격자지도"
-#: ../raster/r.to.vect/main.c:95
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:19
-msgid "Name must be SQL compliant"
+#: ../raster/r.horizon/main.c:419
+msgid "End angle is not between 0 and 360. Aborting."
msgstr ""
-#: ../raster/r.to.vect/main.c:100
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:15
-msgid "Smooth corners of area features"
+#: ../raster/r.horizon/main.c:423
+msgid "You specify a start grater than the end angle. Aborting."
msgstr ""
-#: ../raster/r.to.vect/main.c:105
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:20
-msgid "Use raster values as categories instead of unique sequence (CELL only)"
+#: ../raster/r.horizon/main.c:431
+msgid "You didn't specify an angle step size. Aborting."
msgstr ""
-#: ../raster/r.to.vect/main.c:106 ../raster/r.to.vect/main.c:113
-#: ../vector/v.extract/main.c:93 ../vector/v.extract/main.c:145
-#: ../vector/v.overlay/main.c:135 ../vector/v.overlay/main.c:145
-#: ../vector/v.generalize/main.c:243 ../vector/v.in.ogr/main.c:226
-#: ../vector/v.in.ogr/main.c:236 ../vector/v.in.ogr/main.c:246
-#: ../vector/v.in.ogr/main.c:279 ../vector/v.in.ogr/main.c:311
-#: ../vector/v.buffer/main.c:307 ../vector/v.to.rast/main.c:88
-#: ../vector/v.to.rast/main.c:94 ../vector/v.to.rast/main.c:100
+#: ../raster/r.horizon/main.c:442
#, fuzzy
-msgid "Attributes"
+msgid "Could not read bufferzone size. Aborting."
msgstr "출력할 격자지도"
-#: ../raster/r.to.vect/main.c:110
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:16
-#, fuzzy
-msgid "Write raster values as z coordinate"
-msgstr "출력할 격자지도"
+#: ../raster/r.horizon/main.c:447 ../raster/r.horizon/main.c:453
+#: ../raster/r.horizon/main.c:460 ../raster/r.horizon/main.c:467
+#, c-format
+msgid "Could not read %s bufferzone size. Aborting."
+msgstr ""
-#: ../raster/r.to.vect/main.c:111
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:17
-msgid "Table is not created. Currently supported only for points."
+#: ../raster/r.horizon/main.c:448
+msgid "east"
msgstr ""
-#: ../raster/r.to.vect/main.c:117
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:18
-#, fuzzy
-msgid "Do not build vector topology"
-msgstr "출력할 격자지도"
+#: ../raster/r.horizon/main.c:454
+msgid "west"
+msgstr ""
-#: ../raster/r.to.vect/main.c:118
-msgid "Recommended for massive point conversion"
+#: ../raster/r.horizon/main.c:461
+msgid "south"
msgstr ""
-#: ../raster/r.to.vect/main.c:131
-msgid "z flag is supported only for points"
+#: ../raster/r.horizon/main.c:468
+msgid "north"
msgstr ""
-#: ../raster/r.to.vect/main.c:142
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
-"table."
+#: ../raster/r.horizon/main.c:473
+msgid "Could not read maximum distance. Aborting."
msgstr ""
-#: ../raster/r.to.vect/main.c:144
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be z coordinate."
+#: ../raster/r.horizon/main.c:484
+msgid "The distance value must be 0.5-1.5. Aborting."
msgstr ""
-#: ../raster/r.to.vect/main.c:146
-msgid "Raster is not CELL, '-v' flag ignored, raster values will be lost."
+#: ../raster/r.horizon/main.c:654 ../raster/r.in.ascii/main.c:187
+#, c-format
+msgid "OOPS: rows changed from %d to %d"
msgstr ""
-#: ../raster/r.to.vect/main.c:151
-msgid "Categories will be unique sequence, raster values will be lost."
+#: ../raster/r.horizon/main.c:658 ../raster/r.in.ascii/main.c:190
+#, c-format
+msgid "OOPS: cols changed from %d to %d"
msgstr ""
-#: ../raster/r.to.vect/main.c:312
-#, fuzzy
-msgid "Updating attributes..."
-msgstr "출력할 격자지도"
+#: ../raster/r.horizon/main.c:846 ../raster/r.horizon/main.c:864
+#: ../raster/r.latlong/main.c:133 ../display/d.grid/plot.c:287
+#: ../display/d.grid/plot.c:293 ../display/d.grid/plot.c:334
+#: ../display/d.grid/plot.c:340 ../display/d.grid/plot.c:427
+#: ../display/d.grid/plot.c:433 ../display/d.grid/plot.c:485
+#: ../display/d.grid/plot.c:491 ../display/d.grid/plot.c:635
+#: ../display/d.grid/plot.c:651 ../display/d.grid/plot.c:668
+#: ../display/d.grid/plot.c:685 ../ps/ps.map/do_geogrid.c:86
+#: ../ps/ps.map/do_geogrid.c:91 ../ps/ps.map/do_geogrid.c:115
+#: ../ps/ps.map/do_geogrid.c:120 ../ps/ps.map/do_geogrid.c:189
+#: ../ps/ps.map/do_geogrid.c:230 ../ps/ps.map/do_geogrid.c:306
+#: ../ps/ps.map/do_geogrid.c:322 ../ps/ps.map/do_geogrid.c:339
+#: ../ps/ps.map/do_geogrid.c:356 ../ps/ps.map/do_geogrid.c:412
+#: ../ps/ps.map/do_geogrid.c:418 ../ps/ps.map/do_geogrid.c:422
+#: ../ps/ps.map/do_geogrid.c:430 ../ps/ps.map/do_geogrid.c:434
+msgid "Error in pj_do_proj"
+msgstr ""
-#: ../raster/r.to.vect/main.c:335
+#: ../raster/r.horizon/main.c:1174
#, fuzzy, c-format
-msgid "Unable to insert into table: %s"
+msgid "Calculating map %01d of %01d (angle %.2f, raster map <%s>)"
msgstr "출력할 격자지도"
-#: ../raster/r.to.vect/areas.c:122
-msgid "Extracting areas..."
-msgstr "면을 추출하는 중..."
+#: ../raster/r.sunmask/main.c:120
+msgid ""
+"Calculates cast shadow areas from sun position and elevation raster map."
+msgstr ""
-#: ../raster/r.to.vect/lines.c:71
-msgid "Extracting lines..."
-msgstr "선을 추출하는 중..."
+#: ../raster/r.sunmask/main.c:121
+msgid ""
+"Either exact sun position (A) is specified, or date/time to calculate the "
+"sun position (B) by r.sunmask itself."
+msgstr ""
-#: ../raster/r.to.vect/lines.c:504
-#, c-format
-msgid "Crowded cell at (%f, %f): row %d, col %d, count %d"
+#: ../raster/r.sunmask/main.c:135
+msgid "Altitude of the sun in degrees above the horizon (A)"
msgstr ""
-#: ../raster/r.to.vect/lines.c:508
-msgid ""
-"Raster map is not thinned properly.\n"
-"Please run r.thin."
+#: ../raster/r.sunmask/main.c:136 ../raster/r.sunmask/main.c:145
+#: ../raster/r.sunmask/main.c:213 ../raster/r.sunmask/main.c:223
+#: ../display/d.text/main.c:198 ../display/d.text/main.c:207
+#: ../display/d.text/main.c:216 ../display/d.text/main.c:253
+#: ../display/d.text/main.c:258
+msgid "Position"
msgstr ""
-#: ../raster/r.to.vect/lines.c:582
-msgid "join_lines: p front pointer not NULL!"
+#: ../raster/r.sunmask/main.c:144
+msgid "Azimuth of the sun in degrees from north (A)"
msgstr ""
-#: ../raster/r.to.vect/lines.c:588
-msgid "join_lines: q front pointer not NULL!"
+#: ../raster/r.sunmask/main.c:151
+msgid "Year (B)"
msgstr ""
-#: ../raster/r.to.vect/lines.c:606
-msgid "extend line: p is NULL"
+#: ../raster/r.sunmask/main.c:159
+msgid "Month (B)"
msgstr ""
-#: ../raster/r.to.vect/lines.c:632
-msgid "extend_lines: p front pointer not NULL!"
+#: ../raster/r.sunmask/main.c:167
+msgid "Day (B)"
msgstr ""
-#: ../raster/r.to.vect/lines.c:639
-msgid "extend_lines: q back pointer not NULL!"
+#: ../raster/r.sunmask/main.c:175
+msgid "Hour (B)"
msgstr ""
-#: ../raster/r.to.vect/areas_io.c:154
-#, c-format
-msgid ""
-"write_bnd: line terminated unexpectedly\n"
-"previous (%d) point %p (%d,%d,%d) %p %p"
+#: ../raster/r.sunmask/main.c:183
+msgid "Minutes (B)"
msgstr ""
-#: ../raster/r.to.vect/areas_io.c:287
-msgid "Writing areas..."
-msgstr "면을 쓰는 중..."
+#: ../raster/r.sunmask/main.c:191
+msgid "Seconds (B)"
+msgstr ""
-#: ../raster/r.quantile/main.c:66
-msgid "Computing histogram"
+#: ../raster/r.sunmask/main.c:201
+msgid "Timezone"
msgstr ""
-#: ../raster/r.quantile/main.c:264
-msgid "Compute quantiles using two passes."
+#: ../raster/r.sunmask/main.c:202
+msgid "East positive, offset from GMT, also use to adjust daylight savings"
msgstr ""
-#: ../raster/r.quantile/main.c:291
-msgid "Generate recode rules based on quantile-defined intervals"
+#: ../raster/r.sunmask/main.c:211
+msgid "Easting coordinate (point of interest)"
msgstr ""
-#: ../raster/r.quantile/main.c:319
-#, fuzzy
-msgid "Too many quantiles"
-msgstr "출력할 격자지도"
+#: ../raster/r.sunmask/main.c:212 ../raster/r.sunmask/main.c:222
+msgid "Default: map center"
+msgstr ""
-#: ../raster/r.his/main.c:73
-msgid ""
-"Generates red, green and blue (RGB) raster map layers combining hue, "
-"intensity and saturation (HIS) values from user-specified input raster map "
-"layers."
+#: ../raster/r.sunmask/main.c:221
+msgid "Northing coordinate (point of interest)"
msgstr ""
-#: ../raster/r.his/main.c:82 ../display/d.his/main.c:78
+#: ../raster/r.sunmask/main.c:227
#, fuzzy
-msgid "Name of layer to be used for hue"
-msgstr "출력할 격자지도"
+msgid "Do not ignore zero elevation"
+msgstr "출력할 래스터맵"
-#: ../raster/r.his/main.c:89 ../display/d.his/main.c:85
-#, fuzzy
-msgid "Name of layer to be used for intensity"
-msgstr "출력할 격자지도"
+#: ../raster/r.sunmask/main.c:231
+msgid "Calculate sun position only and exit"
+msgstr ""
-#: ../raster/r.his/main.c:96 ../display/d.his/main.c:92
-#, fuzzy
-msgid "Name of layer to be used for saturation"
-msgstr "출력할 격자지도"
+#: ../raster/r.sunmask/main.c:237
+msgid "Print the sun position output in shell script style"
+msgstr ""
-#: ../raster/r.his/main.c:103
-#, fuzzy
-msgid "Name of output layer to be used for red"
+#: ../raster/r.sunmask/main.c:251
+#, fuzzy, c-format
+msgid "Using map center coordinates: %f %f"
msgstr "출력할 격자지도"
-#: ../raster/r.his/main.c:110
+#: ../raster/r.sunmask/main.c:258
#, fuzzy
-msgid "Name of output layer to be used for green"
+msgid "Empty east coordinate specified"
msgstr "출력할 격자지도"
-#: ../raster/r.his/main.c:117
-#, fuzzy
-msgid "Name of output layer to be used for blue"
-msgstr "출력할 격자지도"
+#: ../raster/r.sunmask/main.c:260
+msgid "Empty north coordinate specified"
+msgstr ""
-#: ../raster/r.his/main.c:121
-#: ../locale/scriptstrings/r.shade_to_translate.c:12
-msgid "Color to use instead of NULL values"
+#: ../raster/r.sunmask/main.c:279
+msgid "Either define sun position or location/date/time parameters"
msgstr ""
-#: ../raster/r.his/main.c:126
-#: ../locale/scriptstrings/r.shade_to_translate.c:14
-#, fuzzy
-msgid "Use colors from color tables for NULL values"
-msgstr "출력할 격자지도"
+#: ../raster/r.sunmask/main.c:282
+msgid ""
+"Neither sun position nor east/north, date/time/timezone definition are "
+"complete"
+msgstr ""
-#: ../raster/r.his/main.c:145
+#: ../raster/r.sunmask/main.c:286
#, c-format
-msgid "No such color <%s>"
+msgid "Calculating sun position... (using solpos (V. %s) from NREL)"
msgstr ""
-#: ../raster/r.his/main.c:167 ../raster/r.his/main.c:183
-#: ../raster/r.his/main.c:201 ../raster/r.out.ppm3/main.c:115
-#: ../display/d.rast.num/main.c:253 ../display/d.rgb/main.c:99
-#: ../display/d.colortable/main.c:135 ../display/d.rast/display.c:23
-#: ../display/d.histogram/main.c:171 ../display/d.legend/main.c:409
-#: ../display/d.legend/main.c:417 ../display/d.his/main.c:139
-#: ../display/d.his/main.c:156 ../display/d.his/main.c:174
-#, c-format
-msgid "Color file for <%s> not available"
+#: ../raster/r.sunmask/main.c:291
+msgid ""
+"Using user defined sun azimuth, altitude settings (ignoring eventual other "
+"values)"
msgstr ""
-#: ../raster/r.out.ascii/main.c:63
+#: ../raster/r.sunmask/main.c:399
#, fuzzy
-msgid "Converts a raster map layer into a GRASS ASCII text file."
+msgid "Please correct settings"
msgstr "출력할 격자지도"
-#: ../raster/r.out.ascii/main.c:72
-msgid "Name for output ASCII grid map (use out=- for stdout)"
+#: ../raster/r.sunmask/main.c:413
+#, c-format
+msgid "Time (%02i:%02i:%02i) is before sunrise (%02d:%02d:%02d)"
msgstr ""
-#: ../raster/r.out.ascii/main.c:86
-msgid ""
-"Number of values printed before wrapping a line (only SURFER or MODFLOW "
-"format)"
+#: ../raster/r.sunmask/main.c:417
+#, c-format
+msgid "Time (%02i:%02i:%02i) is before sunrise"
msgstr ""
-#: ../raster/r.out.ascii/main.c:91
-msgid "String to represent null cell (GRASS grid only)"
+#: ../raster/r.sunmask/main.c:420 ../raster/r.sunmask/main.c:430
+msgid "Nothing to calculate. Please verify settings."
msgstr ""
-#: ../raster/r.out.ascii/main.c:99
-msgid "Write SURFER (Golden Software) ASCII grid"
+#: ../raster/r.sunmask/main.c:424
+#, c-format
+msgid "Time (%02i:%02i:%02i) is after sunset (%02d:%02d:%02d)"
msgstr ""
-#: ../raster/r.out.ascii/main.c:103
-msgid "Write MODFLOW (USGS) ASCII array"
+#: ../raster/r.sunmask/main.c:428
+#, c-format
+msgid "Time (%02i:%02i:%02i) is after sunset"
msgstr ""
-#: ../raster/r.out.ascii/main.c:107
-msgid "Force output of integer values"
+#: ../raster/r.sunmask/main.c:439
+msgid "You already know the sun position"
msgstr ""
-#: ../raster/r.out.ascii/main.c:114
-msgid "Failed to interpret dp as an integer"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:122
-msgid "Failed to interpret width as an integer"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:128
-msgid "Both -s and -h doesn't make sense"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:131
-msgid "Use -M or -s, not both"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:166
+#: ../raster/r.sunmask/main.c:444 ../vector/v.colors/main.c:199
#, fuzzy, c-format
-msgid "Unable to read fp range for <%s>"
+msgid "Option <%s> required"
msgstr "출력할 격자지도"
-#: ../raster/r.out.ascii/main.c:182
+#: ../raster/r.sunmask/main.c:456
#, fuzzy, c-format
-msgid "Read failed at row %d"
+msgid "Unable to open range file for raster map <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.latlong/main.c:57
-msgid "latitude"
+#: ../raster/r.sunmask/main.c:472
+msgid "Calculating shadows from DEM..."
msgstr ""
-#: ../raster/r.latlong/main.c:58
-msgid "longitude"
+#: ../raster/r.sunmask/g_solposition.c:66
+msgid ""
+"Unable to calculate sun position in un-projected locations. Specify "
+"sunposition directly."
msgstr ""
-#: ../raster/r.latlong/main.c:60
-#, fuzzy
-msgid "Creates a latitude/longitude raster map."
-msgstr "출력할 격자지도"
-#: ../raster/r.latlong/main.c:66
-#, fuzzy
-msgid "Name for output latitude or longitude raster map"
-msgstr "출력할 격자지도"
-#: ../raster/r.latlong/main.c:70
-msgid "Longitude output"
+#: ../raster/r.sunmask/g_solposition.c:88
+#, c-format
+msgid ""
+"Specified point %f, %f outside of current region, is that intended? Anyway, "
+"it will be used."
msgstr ""
-#: ../raster/r.latlong/main.c:101 ../raster/r.sunmask/g_solposition.c:98
+#: ../raster/r.sunmask/g_solposition.c:98 ../raster/r.latlong/main.c:101
#, fuzzy
msgid "Unable to get projection info of current location"
msgstr "출력할 격자지도"
-#: ../raster/r.latlong/main.c:103 ../raster/r.sunmask/g_solposition.c:101
+#: ../raster/r.sunmask/g_solposition.c:101 ../raster/r.latlong/main.c:103
#, fuzzy
msgid "Unable to get projection units of current location"
msgstr "출력할 격자지도"
-#: ../raster/r.latlong/main.c:105 ../raster/r.sunmask/g_solposition.c:104
+#: ../raster/r.sunmask/g_solposition.c:104 ../raster/r.latlong/main.c:105
#, fuzzy
msgid "Unable to get projection key values of current location"
msgstr "출력할 격자지도"
-#: ../raster/r.colors/edit_colors.c:61
+#: ../raster/r.info/main.c:73 ../vector/v.info/main.c:41
+msgid "history"
+msgstr "이력"
+#: ../raster/r.info/main.c:75
+msgid "Outputs basic information about a raster map."
+msgstr "격자지도에 대한 기본적인 정보를 출력합니다."
+#: ../raster/r.info/main.c:81
#, fuzzy
-msgid "Creates/modifies the color table associated with a 3D raster map."
+msgid "Print raster array information in shell script style"
msgstr "출력할 격자지도"
-#: ../raster/r.colors/edit_colors.c:65
+#: ../raster/r.info/main.c:85
#, fuzzy
-msgid "Creates/modifies the color table associated with a raster map."
+msgid "Print range in shell script style"
msgstr "출력할 격자지도"
-#: ../raster/r.colors/edit_colors.c:67 ../raster/r.what.color/main.c:90
-#: ../raster/r.colors.out/raster3d_main.c:47
-#: ../raster/r.colors.out/raster_main.c:46
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:3
-#: ../display/d.colortable/main.c:62 ../vector/v.colors/main.c:56
-#: ../vector/v.colors.out/main.c:50
-msgid "color table"
-msgstr "색상표"
+#: ../raster/r.info/main.c:89
+#, fuzzy
+msgid "Print extended metadata information in shell script style"
+msgstr "확장 메타자료를 셸스크립트 형식으로 출력합니다"
-#: ../raster/r.colors/edit_colors.c:75 ../raster/r.colors/edit_colors.c:87
-msgid "Map"
-msgstr ""
+#: ../raster/r.info/main.c:99
+#, fuzzy, c-format
+msgid "Flags -%c and -%c/%c/%c are mutually exclusive"
+msgstr "-%c와 -%c를 같이 지정할 수 없습니다"
-#: ../raster/r.colors/edit_colors.c:81
+#: ../raster/r.info/main.c:127
#, fuzzy
-msgid "Input file with one map name per line"
+msgid "Unable to read range file"
msgstr "출력할 격자지도"
-#: ../raster/r.colors/edit_colors.c:83
-msgid ""
-"Input map names can be defined in an input file in case a large amount of "
-"maps must be specified. This option is mutual exclusive to the map option."
+#: ../raster/r.recode/read_rules.c:20
+#, fuzzy, c-format
+msgid "Unable to read f_range for map %s"
+msgstr "출력할 격자지도"
+#: ../raster/r.recode/read_rules.c:24 ../display/d.colortable/main.c:146
+msgid "Data range is empty"
+msgstr "자료범위가 비어 있습니다"
+#: ../raster/r.recode/read_rules.c:30
+#, fuzzy, c-format
+msgid "Data range of %s is %s to %s (entire map)"
+msgstr "출력할 격자지도"
+#: ../raster/r.recode/read_rules.c:35 ../raster/r.stats/main.c:358
+#, fuzzy, c-format
+msgid "Unable to read range for map <%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.recode/read_rules.c:39
+#, fuzzy, c-format
+msgid "Integer data range of %s is empty"
+msgstr "출력할 격자지도"
+#: ../raster/r.recode/read_rules.c:41
+#, fuzzy, c-format
+msgid "Integer data range of %s is %d to %d"
+msgstr "출력할 격자지도"
+#: ../raster/r.recode/read_rules.c:61
+msgid "Enter the rule or 'help' for the format description"
msgstr ""
-#: ../raster/r.colors/edit_colors.c:90 ../raster/r.colors/edit_colors.c:97
-#: ../raster/r.colors/edit_colors.c:104 ../raster/r.colors/edit_colors.c:111
-#: ../raster/r.colors/edit_colors.c:122 ../raster/r.colors/edit_colors.c:133
-#: ../raster/r.colors/edit_colors.c:138 ../raster/r.colors/edit_colors.c:143
-#: ../raster/r.colors/edit_colors.c:148 ../raster/r.category/main.c:81
-#: ../raster/r.category/main.c:88
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:11
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:13
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:20
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:22
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:24
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:26
-#: ../display/d.linegraph/main.c:268 ../vector/v.colors/main.c:81
-#: ../vector/v.colors/main.c:92 ../vector/v.colors/main.c:99
-#: ../vector/v.colors/main.c:106 ../vector/v.colors/main.c:112
-#: ../vector/v.colors/main.c:138 ../vector/v.colors/main.c:143
-#: ../vector/v.colors/main.c:148
-msgid "Define"
+#: ../raster/r.recode/read_rules.c:85
+msgid "Enter a rule in one of these formats:"
msgstr ""
-#: ../raster/r.colors/edit_colors.c:96
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:8
-#: ../vector/v.colors/main.c:98
+#: ../raster/r.recode/read_rules.c:87
+msgid "old_low:old_high:new_low:new_high"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:88
+msgid "old_low:old_high:new_val (i.e. new_high == new_low)"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:89
+msgid "*:old_val:new_val (interval [inf, old_val])"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:90
+msgid "old_val:*:new_val (interval [old_val, inf])"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:92
+msgid "When finished type \"end\"."
+msgstr ""
+#: ../raster/r.recode/read_rules.c:126 ../raster/r.quant/read_rules.c:158
+#, c-format
+msgid "%s is not a valid rule"
+msgstr ""
+#: ../raster/r.recode/main.c:49
#, fuzzy
-msgid "Raster map from which to copy color table"
+msgid "recode categories"
msgstr "출력할 격자지도"
-#: ../raster/r.colors/edit_colors.c:103
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:10
-#: ../vector/v.colors/main.c:105
+#: ../raster/r.recode/main.c:51
#, fuzzy
-msgid "3D raster map from which to copy color table"
+msgid "Recodes categorical raster maps."
msgstr "출력할 격자지도"
-#: ../raster/r.colors/edit_colors.c:109
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:12
-#: ../vector/v.colors/main.c:111
+#: ../raster/r.recode/main.c:54
#, fuzzy
-msgid "Path to rules file"
+msgid "Name of raster map to be recoded"
msgstr "출력할 격자지도"
-#: ../raster/r.colors/edit_colors.c:110
+#: ../raster/r.recode/main.c:60
+msgid "File containing recode rules"
+msgstr ""
+#: ../raster/r.recode/main.c:71
#, fuzzy
-msgid "\"-\" to read rules from stdin"
+msgid "Align the current region to the input raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.colors/edit_colors.c:115
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:14
-#: ../vector/v.colors/main.c:121
-msgid "Remove existing color table"
+#: ../raster/r.recode/main.c:75
+msgid "Force output to 'double' raster map type (DCELL)"
msgstr ""
-#: ../raster/r.colors/edit_colors.c:116 ../raster/r.null/main.c:108
-#: ../locale/scriptstrings/r.mask_to_translate.c:20
-#: ../locale/scriptstrings/g.extension_to_translate.c:30
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:15
-#: ../vector/v.colors/main.c:122
-msgid "Remove"
+#: ../raster/r.recode/main.c:96
+#, c-format
+msgid "No rules specified. Raster map <%s> not created."
msgstr ""
-#: ../raster/r.colors/edit_colors.c:121
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:16
-#: ../vector/v.colors/main.c:127
-msgid "Only write new color table if it does not already exist"
+#: ../raster/r.null/main.c:62
+#, fuzzy
+msgid "Manages NULL-values of given raster map."
+msgstr "출력할 격자지도"
+#: ../raster/r.null/main.c:65
+#, fuzzy
+msgid "Name of raster map for which to edit null values"
+msgstr "출력할 격자지도"
+#: ../raster/r.null/main.c:86
+msgid "Only do the work if the map is floating-point"
msgstr ""
-#: ../raster/r.colors/edit_colors.c:126
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:17
-#: ../vector/v.colors/main.c:131
-msgid "List available rules then exit"
+#: ../raster/r.null/main.c:87 ../raster/r.null/main.c:92
+#: ../raster/r.null/main.c:98
+msgid "Check"
msgstr ""
-#: ../raster/r.colors/edit_colors.c:132
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:19
-#: ../vector/v.colors/main.c:137
-msgid "Invert colors"
+#: ../raster/r.null/main.c:91
+msgid "Only do the work if the map is integer"
msgstr ""
-#: ../raster/r.colors/edit_colors.c:137
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:21
-#: ../vector/v.colors/main.c:142
-msgid "Logarithmic scaling"
+#: ../raster/r.null/main.c:97
+msgid "Only do the work if the map doesn't have a NULL-value bitmap file"
msgstr ""
-#: ../raster/r.colors/edit_colors.c:142
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:23
-#: ../vector/v.colors/main.c:147
-msgid "Logarithmic-absolute scaling"
+#: ../raster/r.null/main.c:103
+msgid "Create NULL-value bitmap file validating all data cells"
msgstr ""
-#: ../raster/r.colors/edit_colors.c:147
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:25
-msgid "Histogram equalization"
+#: ../raster/r.null/main.c:107
+msgid "Remove NULL-value bitmap file"
msgstr ""
-#: ../raster/r.colors/edit_colors.c:186 ../raster/r.series.interp/main.c:180
-#, fuzzy, c-format
-msgid "Unable to open %s file <%s>"
-msgstr "출력할 격자지도"
+#: ../raster/r.null/main.c:113
+msgid "Re-create NULL-value bitmap file (to compress or uncompress)"
+msgstr ""
-#: ../raster/r.colors/edit_colors.c:229 ../raster/r.colors/edit_colors.c:262
+#: ../raster/r.null/main.c:132
#, c-format
-msgid "%s map <%s> not found"
-msgstr "%s지도 <%s>를 찾지 못 했습니다"
+msgid ""
+"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
+"with r.mapcalc. Exiting."
+msgstr ""
-#: ../raster/r.colors/edit_colors.c:235
-#, c-format
-msgid "No %s map name found in input file <%s>"
-msgstr "입력파일 <%s> 안에 지도이름 %s를 찾지 못 했습니다"
-#: ../raster/r.colors/edit_colors.c:278
+#: ../raster/r.null/main.c:138
#, fuzzy, c-format
-msgid "Unable to remove color table of %s map <%s>"
+msgid "Raster map <%s> is not in your mapset <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.colors/edit_colors.c:280
+#: ../raster/r.null/main.c:145
#, c-format
-msgid "Color table of %s map <%s> not found"
-msgstr "%s지도 <%s>의 색상표를 찾지 못 했습니다"
+msgid "%s is illegal entry for null"
+msgstr ""
-#: ../raster/r.colors/edit_colors.c:302
+#: ../raster/r.null/main.c:152
#, fuzzy, c-format
-msgid "Color table exists for %s map <%s>. Exiting."
+msgid "Raster map <%s> already has a null bitmap file"
msgstr "출력할 격자지도"
-#: ../raster/r.colors/edit_colors.c:358
+#: ../raster/r.null/main.c:156
#, fuzzy, c-format
-msgid "Color table 'random' is not supported for floating point %s map"
+msgid "<%s> is integer raster map (CELL)"
msgstr "출력할 격자지도"
-#: ../raster/r.colors/edit_colors.c:362
+#: ../raster/r.null/main.c:160
#, fuzzy, c-format
-msgid "Color table 'grey.eq' is not supported for floating point %s map"
+msgid "<%s> is integer raster map (CELL). Using null=%d."
msgstr "출력할 격자지도"
-#: ../raster/r.colors/edit_colors.c:368
+#: ../raster/r.null/main.c:166
#, fuzzy, c-format
-msgid "Color table 'grey.log' is not supported for floating point %s map"
+msgid "<%s> is floating pointing raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.colors/edit_colors.c:386 ../vector/v.colors/make_colors.c:51
+#: ../raster/r.null/main.c:183 ../raster/r.null/main.c:208
#, fuzzy, c-format
-msgid "Unable to load rules file <%s>"
+msgid "Writing new null file for raster map <%s>..."
msgstr "출력할 격자지도"
-#: ../raster/r.colors/edit_colors.c:403 ../vector/v.colors/main.c:322
+#: ../raster/r.null/main.c:193 ../raster/r.null/main.c:220
+#: ../raster/r.null/main.c:234
#, fuzzy, c-format
-msgid "Unable to read color table for 3D raster map <%s>"
+msgid "Raster map <%s> modified."
msgstr "출력할 격자지도"
-#: ../raster/r.colors/edit_colors.c:447
-#, c-format
-msgid "Color table for %s map <%s> set to '%s'"
-msgstr "%s지도 <%s>를 위한 색상표가 '%s'로 설정되었습니다"
+#: ../raster/r.null/main.c:227
+#, fuzzy, c-format
+msgid "Removing null file for raster map <%s>..."
+msgstr "출력할 격자지도"
-#: ../raster/r.colors/stats.c:39
+#: ../raster/r.null/main.c:298
#, fuzzy, c-format
-msgid "(%i/%i) Reading raster map <%s>..."
+msgid "%s: %s: illegal value spec"
msgstr "출력할 격자지도"
-#: ../raster/r.colors/stats.c:73
-msgid "Unable to use logarithmic scaling if range includes zero"
+#: ../raster/r.null/main.c:300
+#, c-format
+msgid "%s: illegal value spec"
msgstr ""
-#: ../raster/r.colors/stats.c:118
-msgid "Error opening 3d raster map"
-msgstr ""
-#: ../raster/r.colors/stats.c:125
+#: ../raster/r.null/main.c:361
#, fuzzy, c-format
-msgid "(%i/%i) Reading map <%s>..."
+msgid "Writing new data for raster map <%s>..."
msgstr "출력할 격자지도"
-#: ../raster/r.colors/rules.c:40
-#, c-format
-msgid "Enter rules, \"end\" when done, \"help\" if you need it.\n"
+#: ../raster/r.param.scale/process.c:75
+msgid "E-W and N-S grid resolutions are different. Taking average."
msgstr ""
-#: ../raster/r.colors/rules.c:49
-#, c-format
-msgid "fp: Data range is %s to %s\n"
+#: ../raster/r.param.scale/interface.c:55
+#, fuzzy
+msgid "geomorphology"
+msgstr "출력할 격자지도"
+#: ../raster/r.param.scale/interface.c:58
+msgid "landform"
msgstr ""
-#: ../raster/r.colors/rules.c:53
-#, c-format
-msgid "Data range is %ld to %ld\n"
+#: ../raster/r.param.scale/interface.c:59
+msgid "Extracts terrain parameters from a DEM."
msgstr ""
-#: ../raster/r.colors/rules.c:64
-#, c-format
+#: ../raster/r.param.scale/interface.c:60
msgid ""
-"Your color rules do not cover the whole range of data!\n"
-" (rules %f to %f but data %f to %f)"
+"Uses a multi-scale approach by taking fitting quadratic parameters to any "
+"size window (via least squares)."
msgstr ""
-#: ../raster/r.colors/rules.c:104 ../raster/r.reclass/parse.c:41
-#, c-format
-msgid "Enter a rule in one of these formats:\n"
+#: ../raster/r.param.scale/interface.c:78
+#, fuzzy
+msgid "Name for output raster map containing morphometric parameter"
+msgstr "출력할 격자지도"
+#: ../raster/r.param.scale/interface.c:82
+msgid "Slope tolerance that defines a 'flat' surface (degrees)"
msgstr ""
-#: ../raster/r.colors/rules.c:105
-#, c-format
-msgid " val color\n"
+#: ../raster/r.param.scale/interface.c:89
+msgid "Curvature tolerance that defines 'planar' surface"
msgstr ""
-#: ../raster/r.colors/rules.c:106
-#, c-format
-msgid " n%% color\n"
+#: ../raster/r.param.scale/interface.c:96
+msgid "Size of processing window (odd number only)"
msgstr ""
-#: ../raster/r.colors/rules.c:107
-#, c-format
-msgid " nv color\n"
+#: ../raster/r.param.scale/interface.c:104
+msgid "Morphometric parameter in 'size' window to calculate"
msgstr ""
-#: ../raster/r.colors/rules.c:108
-#, c-format
-msgid " default color\n"
+#: ../raster/r.param.scale/interface.c:112
+msgid "Exponent for distance weighting (0.0-4.0)"
msgstr ""
-#: ../raster/r.colors/rules.c:109
-#, c-format
-msgid "color can be one of:\n"
+#: ../raster/r.param.scale/interface.c:124
+msgid "Constrain model through central window cell"
msgstr ""
-#: ../raster/r.colors/rules.c:111
-#, c-format
-msgid "or an R:G:B triplet, e.g.: 0:127:255\n"
+#: ../raster/r.param.scale/interface.c:167
+msgid "Morphometric parameter not recognised. Assuming 'Elevation'"
msgstr ""
-#: ../raster/r.colors/rules.c:132
-#, c-format
-msgid "bad rule (%s); rule not added"
+#: ../raster/r.param.scale/interface.c:175
+msgid "Inappropriate window size (too big or even)"
msgstr ""
-#: ../raster/r.colors/rules.c:134
-#, c-format
-msgid "bad rule (%s): [%s]"
+#: ../raster/r.param.scale/main.c:42
+msgid "Lat/Long locations are not supported by this module"
msgstr ""
-#: ../raster/r.in.xyz/main.c:167
+#: ../raster/r.surf.random/main.c:40
msgid ""
-"Creates a raster map from an assemblage of many coordinates using univariate "
-"statistics."
+"Produces a raster surface map of uniform random deviates with defined range."
msgstr ""
-#: ../raster/r.in.xyz/main.c:171
-msgid "ASCII file containing input data (or \"-\" to read from stdin)"
+#: ../raster/r.surf.random/main.c:46
+msgid "Minimum random value"
msgstr ""
-#: ../raster/r.in.xyz/main.c:225
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:19
-msgid "Column number of x coordinates in input file (first column is 1)"
+#: ../raster/r.surf.random/main.c:52
+msgid "Maximum random value"
msgstr ""
-#: ../raster/r.in.xyz/main.c:233
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:21
-msgid "Column number of y coordinates in input file"
-msgstr ""
+#: ../raster/r.surf.random/main.c:58
+#, fuzzy
+msgid "Create an integer raster map"
+msgstr "출력할 격자지도"
-#: ../raster/r.in.xyz/main.c:241
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:25
-msgid "Column number of data values in input file"
+#: ../raster/r.out.ppm3/main.c:59
+msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
msgstr ""
-#: ../raster/r.in.xyz/main.c:243
-msgid ""
-"If a separate value column is given, this option refers to the z-coordinate "
-"column to be filtered by the zrange option"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:254
+#: ../raster/r.out.ppm3/main.c:84
#, fuzzy
-msgid "Number of header lines to skip at top of input file"
+msgid "Name for new PPM file. (use '-' for stdout)"
msgstr "출력할 격자지도"
-#: ../raster/r.in.xyz/main.c:262 ../vector/v.decimate/main.c:146
-#: ../vector/v.in.lidar/main.c:194
-msgid "Filter range for z data (min,max)"
+#: ../raster/r.out.ppm3/main.c:88
+msgid "Add comments to describe the region"
msgstr ""
-#: ../raster/r.in.xyz/main.c:263 ../raster/r.in.xyz/main.c:271
-#: ../raster/r.in.xyz/main.c:280 ../raster/r.in.xyz/main.c:288
-#: ../raster/r.in.xyz/main.c:296
-msgid "Advanced Input"
-msgstr ""
+#: ../raster/r.out.ppm3/main.c:95 ../raster/r.out.ppm/main.c:101
+#, c-format
+msgid "row = %d"
+msgid_plural "rows = %d"
+msgstr[0] ""
-#: ../raster/r.in.xyz/main.c:270
-msgid "Scale to apply to z data"
+#. GTC Raster columns
+#: ../raster/r.out.ppm3/main.c:97 ../raster/r.out.ppm/main.c:102
+#, fuzzy, c-format
+msgid "column = %d"
+msgid_plural "columns = %d"
+msgstr[0] "출력할 격자지도"
+#: ../raster/r.out.ppm3/main.c:160
+msgid "Converting ... "
msgstr ""
-#: ../raster/r.in.xyz/main.c:278
-#, fuzzy
-msgid "Alternate column number of data values in input file"
-msgstr "출력할 격자지도"
-#: ../raster/r.in.xyz/main.c:279
-msgid "If not given (or set to 0) the z-column data is used"
+#: ../raster/r.surf.idw/main.c:107 ../vector/v.surf.idw/main.c:90
+msgid "IDW"
msgstr ""
-#: ../raster/r.in.xyz/main.c:287
-msgid "Filter range for alternate value column data (min,max)"
+#: ../raster/r.surf.idw/main.c:109
+msgid ""
+"Provides surface interpolation from raster point data by Inverse Distance "
+"Squared Weighting."
msgstr ""
-#: ../raster/r.in.xyz/main.c:295
-msgid "Scale to apply to alternate value column data"
+#: ../raster/r.surf.idw/main.c:119 ../vector/v.surf.idw/main.c:113
+msgid "Number of interpolation points"
msgstr ""
-#: ../raster/r.in.xyz/main.c:336
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:12
-msgid "Ignore broken lines"
+#: ../raster/r.surf.idw/main.c:124
+msgid "Output is the interpolation error"
msgstr ""
-#: ../raster/r.in.xyz/main.c:357
-msgid "Please specify a reasonable column number."
+#: ../raster/r.surf.idw/main.c:130
+#, c-format
+msgid "Illegal value for '%s' (%s)"
msgstr ""
-#: ../raster/r.in.xyz/main.c:369 ../vector/v.in.ascii/main.c:218
-msgid "Please specify reasonable number of lines to skip"
+#: ../raster/r.surf.idw/main.c:164 ../raster/r.statistics/main.c:104
+#: ../raster/r.statistics/main.c:107
+msgid "This module currently only works for integer (CELL) maps"
msgstr ""
-#: ../raster/r.in.xyz/main.c:388
+#: ../raster/r.surf.idw/main.c:260
+#, fuzzy, c-format
+msgid "Interpolating raster map <%s> (%d row)..."
+msgid_plural "Interpolating raster map <%s> (%d rows)..."
+#: ../raster/r.surf.gauss/main.c:42
#, fuzzy
-msgid "Invalid vrange"
+msgid "Generates a raster map using gaussian random number generator."
msgstr "출력할 격자지도"
-#: ../raster/r.in.xyz/main.c:527
-#, c-format
+#: ../raster/r.surf.gauss/main.c:44
msgid ""
-"Unable to process the hole map at once. Please set the %s option to some "
-"value lower than 100."
+"Mean and standard deviation of gaussian deviates can be expressed by the "
+"user."
msgstr ""
-#: ../raster/r.in.xyz/main.c:580
-msgid ""
-"If input is not from a file it is only possible to perform a single pass."
+#: ../raster/r.surf.gauss/main.c:51
+msgid "Distribution mean"
msgstr ""
-#: ../raster/r.in.xyz/main.c:592
-msgid "Range filters will not be taken into account during scan"
+#: ../raster/r.surf.gauss/main.c:57
+msgid "Standard deviation"
msgstr ""
-#: ../raster/r.in.xyz/main.c:629
-#, fuzzy
-msgid "Reading input data..."
-msgstr "출력할 격자지도"
+#: ../raster/r.contour/cont.c:82
+#, fuzzy, c-format
+msgid "Writing vector contour (one level)..."
+msgid_plural "Writing vector contours (total levels %d)..."
-#: ../raster/r.in.xyz/main.c:712 ../raster/r.in.xyz/main.c:720
-#: ../raster/r.in.xyz/main.c:1213 ../raster/r.in.xyz/main.c:1221
-#, c-format
-msgid ""
-"Not enough data columns. Incorrect delimiter or column number? Found the "
-"following character(s) in row %lu:\n"
-"[%s]"
+#: ../raster/r.contour/cont.c:213
+#, fuzzy, c-format
+msgid "%d crossing found"
+msgid_plural "%d crossings found"
+#: ../raster/r.contour/cont.c:266
+msgid "Illegal edge number"
msgstr ""
-#: ../raster/r.in.xyz/main.c:716 ../raster/r.in.xyz/main.c:1217
-msgid "Line ignored as requested"
+#: ../raster/r.contour/cont.c:374
+msgid "Edge number out of range"
msgstr ""
-#: ../raster/r.in.xyz/main.c:735 ../raster/r.in.xyz/main.c:1251
-#, c-format
-msgid "Bad y-coordinate line %lu column %d. <%s>"
+#: ../raster/r.contour/main.c:89
+msgid "contours"
msgstr ""
-#: ../raster/r.in.xyz/main.c:742 ../raster/r.in.xyz/main.c:1236
-#, c-format
-msgid "Bad x-coordinate line %lu column %d. <%s>"
+#: ../raster/r.contour/main.c:91
+msgid "Produces a vector map of specified contours from a raster map."
msgstr ""
-#: ../raster/r.in.xyz/main.c:760 ../raster/r.in.xyz/main.c:1266
-#, c-format
-msgid "Bad z-coordinate line %lu column %d. <%s>"
+#: ../raster/r.contour/main.c:102 ../raster/r.contour/main.c:110
+#: ../raster/r.contour/main.c:117 ../raster/r.contour/main.c:124
+msgid "Contour levels"
msgstr ""
-#: ../raster/r.in.xyz/main.c:773 ../raster/r.in.xyz/main.c:1284
+#: ../raster/r.contour/main.c:140
#, fuzzy, c-format
-msgid "Bad data value line %lu column %d. <%s>"
+msgid "Neither <%s> nor <%s> option must be specified"
msgstr "출력할 격자지도"
-#: ../raster/r.in.xyz/main.c:829
+#: ../raster/r.contour/main.c:149 ../raster/r.stats/main.c:331
+#, fuzzy, c-format
+msgid "Unable to read fp range of raster map <%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.contour/main.c:203 ../vector/v.extract/copy_tab.c:57
+#: ../vector/v.voronoi/main.c:384 ../vector/v.select/copy_tabs.c:17
+#: ../vector/v.generalize/misc.c:134
+msgid "Writing attributes..."
+msgstr "특성을 쓰고 있습니다..."
+#: ../raster/r.contour/main.c:237 ../vector/v.generalize/displacement.c:78
#, fuzzy
-msgid "Writing to output raster map..."
+msgid "Reading data..."
msgstr "출력할 격자지도"
-#: ../raster/r.in.xyz/main.c:1169
+#: ../raster/r.contour/main.c:263
#, fuzzy, c-format
-msgid "%lu points found in region."
+msgid "Range of data: min=%f, max=%f"
msgstr "출력할 격자지도"
-#: ../raster/r.random/main.c:56
+#: ../raster/r.contour/main.c:265
#, fuzzy
-msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
+msgid "Range of data: empty"
msgstr "출력할 격자지도"
-#: ../raster/r.random/main.c:65
+#: ../raster/r.contour/main.c:293 ../raster/r.contour/main.c:296
#, fuzzy
-msgid "Name of cover raster map"
+msgid "This step value is not allowed"
msgstr "출력할 격자지도"
-#: ../raster/r.random/main.c:72
-msgid "The number of points to allocate"
+#: ../raster/r.contour/main.c:321
+#, c-format
+msgid "Range of levels: min = %f, max = %f"
msgstr ""
-#: ../raster/r.random/main.c:84
-msgid "Generate points also for NULL category"
-msgstr ""
+#: ../raster/r.contour/main.c:350
+#, fuzzy
+msgid "Displacing data..."
+msgstr "출력할 격자지도"
-#: ../raster/r.random/main.c:89
-msgid "Report information about input raster and exit"
+#: ../raster/r.out.mat/main.c:64
+msgid "Exports a GRASS raster to a binary MAT-File."
msgstr ""
-#: ../raster/r.random/main.c:93
-msgid "Generate vector points as 3D points"
-msgstr ""
+#: ../raster/r.out.mat/main.c:73
+#, fuzzy
+msgid "Name for output binary MAT file"
+msgstr "출력할 격자지도"
-#: ../raster/r.random/main.c:96 ../vector/v.in.ascii/main.c:193
-msgid "Do not build topology in points mode"
+#: ../raster/r.out.mat/main.c:113
+#, c-format
+msgid "Exporting <%s>"
msgstr ""
-#: ../raster/r.random/main.c:97 ../display/d.linegraph/main.c:330
-#: ../display/d.linegraph/main.c:339 ../display/d.linegraph/main.c:348
-#: ../display/d.linegraph/main.c:363 ../vector/v.out.ascii/args.c:40
-#: ../vector/v.out.ascii/args.c:66 ../vector/v.out.ascii/args.c:76
-#: ../vector/v.out.ascii/args.c:86 ../vector/v.out.ascii/args.c:92
-#: ../vector/v.in.ascii/main.c:117 ../vector/v.in.ascii/main.c:124
-#: ../vector/v.in.ascii/main.c:136 ../vector/v.in.ascii/main.c:146
-#: ../vector/v.in.ascii/main.c:156 ../vector/v.in.ascii/main.c:166
-#: ../vector/v.in.ascii/main.c:190 ../vector/v.in.ascii/main.c:194
-#: ../vector/v.in.ascii/main.c:200 ../vector/v.in.ascii/main.c:205
-msgid "Points"
+#: ../raster/r.out.mat/main.c:173
+msgid "Using the Current Region settings:"
msgstr ""
-#: ../raster/r.random/main.c:133
-#, c-format
-msgid "Note: one (or both) of %s and %s must be specified"
+#: ../raster/r.out.mat/main.c:248
+msgid "Exporting raster as integer values"
msgstr ""
-#: ../raster/r.random/main.c:141
-#, c-format
-msgid "<%s=%s> invalid percentage"
+#: ../raster/r.out.mat/main.c:253
+msgid "Exporting raster as floating point values"
msgstr ""
-#: ../raster/r.random/main.c:148
-#, c-format
-msgid "<%s=%s> invalid number of points"
+#: ../raster/r.out.mat/main.c:258
+msgid "Exporting raster as double FP values"
msgstr ""
-#: ../raster/r.random/main.c:161
-#, c-format
-msgid "There aren't [%ld] cells in the current region"
+#: ../raster/r.out.mat/main.c:301
+msgid "Reading in map ... "
msgstr ""
-#: ../raster/r.random/main.c:164
-#, c-format
-msgid "There aren't [%ld] non-NULL cells in the current region"
+#: ../raster/r.out.mat/main.c:314
+#, fuzzy
+msgid "Writing out map..."
+msgstr "출력할 격자지도"
+#: ../raster/r.out.mat/main.c:374
+#, fuzzy, c-format
+msgid "%ld bytes written to '%s'"
+msgstr "출력할 격자지도"
+#: ../raster/r.profile/main.c:56
+msgid "Outputs the raster map layer values lying on user-defined line(s)."
msgstr ""
-#: ../raster/r.random/main.c:169
-msgid "There are no valid locations in the current region"
+#: ../raster/r.profile/main.c:69 ../display/d.profile/main.c:203
+msgid "Profile coordinate pairs"
msgstr ""
-#: ../raster/r.random/count.c:68
+#: ../raster/r.profile/main.c:75
#, fuzzy
-msgid "Collecting Stats..."
+msgid "Name of input file containing coordinate pairs"
msgstr "출력할 격자지도"
-#: ../raster/r.random/count.c:123
-msgid "Programmer error in get_stats/switch"
+#: ../raster/r.profile/main.c:77
+#, fuzzy
+msgid "Use instead of the 'coordinates' option. \"-\" reads from stdin."
+msgstr "출력할 격자지도"
+#: ../raster/r.profile/main.c:85
+msgid "Resolution along profile (default = current region resolution)"
msgstr ""
-#: ../raster/r.random/random.c:100
-msgid "Cannot create new table"
+#: ../raster/r.profile/main.c:98
+msgid "Output RRR:GGG:BBB color values for each profile point"
msgstr ""
-#: ../raster/r.random/random.c:110
-#, fuzzy, c-format
-msgid "Writing raster map <%s> and vector map <%s> ..."
-msgstr "출력할 격자지도"
+#: ../raster/r.profile/main.c:103
+msgid ""
+"If units are not specified, current location units are used. Meters are used "
+"by default in geographic (latlon) locations."
+msgstr ""
-#: ../raster/r.random/random.c:113
+#: ../raster/r.profile/main.c:117
+msgid "Either use profile option or coordinate_file option, but not both"
+msgstr ""
+#: ../raster/r.profile/main.c:144
#, fuzzy, c-format
-msgid "Writing raster map <%s> ..."
+msgid "Illegal resolution %g [%s]"
msgstr "출력할 격자지도"
-#: ../raster/r.random/random.c:115
-#, fuzzy, c-format
-msgid "Writing vector map <%s> ..."
+#: ../raster/r.profile/main.c:151
+#, c-format
+msgid "Using resolution: %g [%s]"
+msgstr ""
+#: ../raster/r.profile/main.c:182
+#, fuzzy
+msgid "Output columns:"
msgstr "출력할 격자지도"
-#: ../raster/r.random/random.c:190 ../vector/v.net.flow/main.c:262
-#: ../vector/v.net.centrality/main.c:69 ../vector/v.net.allpairs/main.c:271
-#: ../vector/v.net.timetable/main.c:134 ../vector/v.net.timetable/main.c:156
-#: ../vector/v.net.path/path.c:334 ../vector/v.net.distance/main.c:363
-#: ../vector/v.net.components/main.c:39
+#: ../raster/r.profile/main.c:185
+#, c-format
+msgid "Easting, Northing, Along track dist. [%s], Elevation"
+msgstr ""
+#: ../raster/r.profile/main.c:187
+#, c-format
+msgid "Along track dist. [%s], Elevation"
+msgstr ""
+#: ../raster/r.profile/main.c:189
+#, fuzzy
+msgid " RGB color"
+msgstr "문자색상"
+#: ../raster/r.profile/main.c:200
#, fuzzy, c-format
-msgid "Cannot insert new record: %s"
+msgid "Could not open <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.random/random.c:243
+#: ../raster/r.profile/main.c:207
#, c-format
-msgid "Only [%ld] random points created"
+msgid "Invalid coordinates %s %s"
msgstr ""
-#: ../raster/r.carve/enforce_ds.c:83
-msgid "Processing lines... "
+#: ../raster/r.profile/main.c:278
+#, c-format
+msgid "Approx. transect length: %f [%s]"
msgstr ""
-#: ../raster/r.carve/enforce_ds.c:175
-msgid ""
-"Vect runs out of region and re-enters - this case is not yet implemented."
+#: ../raster/r.profile/main.c:281
+msgid "Endpoint coordinates are outside of current region settings"
msgstr ""
-#: ../raster/r.carve/main.c:76
-msgid "Generates stream channels."
+#: ../raster/r.profile/input.c:30 ../raster/r.profile/input.c:47
+#: ../raster/r.profile/input.c:60
+msgid "One coordinate pair per line, please"
msgstr ""
-#: ../raster/r.carve/main.c:77
-msgid ""
-"Takes vector stream data, transforms it to raster and subtracts depth from "
-"the output DEM."
+#: ../raster/r.in.gridatb/file_io.c:35
+msgid "Setting window header failed"
msgstr ""
-#: ../raster/r.carve/main.c:82
-msgid "Name of input raster elevation map"
+#: ../raster/r.in.gridatb/file_io.c:38
+msgid "Rows changed"
msgstr ""
-#: ../raster/r.carve/main.c:87
-#, fuzzy
-msgid "Name of input vector map containing stream(s)"
-msgstr "출력할 격자지도"
+#: ../raster/r.in.gridatb/file_io.c:41
+msgid "Cols changed"
+msgstr ""
-#: ../raster/r.carve/main.c:95
+#: ../raster/r.in.gridatb/main.c:48
#, fuzzy
-msgid "Name for output vector map for adjusted stream points"
+msgid "Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map."
msgstr "출력할 격자지도"
-#: ../raster/r.carve/main.c:100
-msgid "Stream width (in meters)"
+#: ../raster/r.in.gridatb/main.c:51
+msgid "GRIDATB i/o map file"
msgstr ""
-#: ../raster/r.carve/main.c:101
-msgid "Default is raster cell width"
+#: ../raster/r.in.gridatb/main.c:68
+#, c-format
+msgid "File not found: %s"
msgstr ""
-#: ../raster/r.carve/main.c:106
-msgid "Additional stream depth (in meters)"
+#: ../raster/r.regression.line/main.c:48
+#: ../raster/r.regression.multi/main.c:130
+#, fuzzy
+msgid "regression"
+msgstr "변환"
+#: ../raster/r.regression.line/main.c:50
+msgid "Calculates linear regression from two raster maps: y = a + b*x."
msgstr ""
-#: ../raster/r.carve/main.c:110
-msgid "No flat areas allowed in flow direction"
+#: ../raster/r.regression.line/main.c:55
+#: ../raster/r.regression.multi/main.c:137
+msgid "Map for x coefficient"
msgstr ""
-#: ../raster/r.carve/main.c:134
-#, c-format
-msgid "Invalid width value '%s' - using default."
+#: ../raster/r.regression.line/main.c:59
+#: ../raster/r.regression.multi/main.c:141
+msgid "Map for y coefficient"
msgstr ""
-#: ../raster/r.carve/main.c:148
-#, c-format
-msgid "Invalid depth value '%s' - using default."
+#: ../raster/r.regression.line/main.c:65
+#: ../raster/r.regression.multi/main.c:157
+msgid ""
+"ASCII file for storing regression coefficients (output to screen if file not "
+"specified)."
msgstr ""
-#: ../raster/r.carve/raster.c:33 ../raster/r.in.poly/poly2rast.c:81
-#: ../vector/v.to.rast/vect2rast.c:179
-#, fuzzy
-msgid "Writing raster map..."
-msgstr "출력할 격자지도"
-#: ../raster/r.carve/lobf.c:74
-msgid "trying to divide by zero...no unique solution for system...skipping..."
+#: ../raster/r.quant/read_rules.c:50
+msgid "Old data range is empty"
msgstr ""
-#: ../raster/r.in.bin/main.c:61 ../raster/r.in.bin/main.c:70
-#: ../raster/r.in.bin/main.c:614
-msgid "Error reading data"
-msgstr "자료를 읽는 중 오류"
-#: ../raster/r.in.bin/main.c:260
-msgid "Import a binary raster file into a GRASS raster map layer."
+#: ../raster/r.quant/read_rules.c:56
+#, c-format
+msgid "Old data range is %s to %s"
msgstr ""
-#: ../raster/r.in.bin/main.c:265
-msgid "Import as floating-point data (default: integer)"
+#: ../raster/r.quant/read_rules.c:59
+msgid "Old integer data range is empty"
msgstr ""
-#: ../raster/r.in.bin/main.c:270
-msgid "Import as double-precision floating-point data (default: integer)"
+#: ../raster/r.quant/read_rules.c:61
+#, c-format
+msgid "Old integer data range is %d to %d"
msgstr ""
-#: ../raster/r.in.bin/main.c:279
-msgid "Byte swap the data during import"
+#: ../raster/r.quant/read_rules.c:83
+#, fuzzy, c-format
+msgid "unable to open input file <%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.quant/read_rules.c:89
+#, c-format
+msgid ""
+"\n"
+"Enter the rule or 'help' for the format description or 'end' to exit:\n"
msgstr ""
-#: ../raster/r.in.bin/main.c:284
-msgid "Get region info from GMT style header"
+#: ../raster/r.quant/read_rules.c:112
+msgid "quant rules do not cover the whole range map"
msgstr ""
-#: ../raster/r.in.bin/main.c:288
+#: ../raster/r.quant/main.c:49
#, fuzzy
-msgid "Name of binary raster file to be imported"
+msgid "quantization"
msgstr "출력할 격자지도"
-#: ../raster/r.in.bin/main.c:291
-msgid "Output name or prefix if several bands are imported"
+#: ../raster/r.quant/main.c:51
+msgid "Produces the quantization file for a floating-point map."
msgstr ""
-#: ../raster/r.in.bin/main.c:305 ../raster/r.out.bin/main.c:311
-#, fuzzy
-msgid "Number of bytes per cell"
-msgstr "출력할 격자지도"
-#: ../raster/r.in.bin/main.c:313
-msgid "Header size in bytes"
+#: ../raster/r.quant/main.c:59
+msgid "Raster map(s) to be quantized"
msgstr ""
-#: ../raster/r.in.bin/main.c:321
+#: ../raster/r.quant/main.c:64
#, fuzzy
-msgid "Number of bands in input file"
+msgid "Path to rules file (\"-\" to read from stdin)"
msgstr "출력할 격자지도"
-#: ../raster/r.in.bin/main.c:322
-msgid "Bands must be in band-sequential order"
+#: ../raster/r.quant/main.c:70
+msgid "Base map to take quant rules from"
msgstr ""
-#: ../raster/r.in.bin/main.c:392
-msgid "Flip input horizontal and/or vertical"
+#: ../raster/r.quant/main.c:75
+msgid "Floating point range: dmin,dmax"
msgstr ""
-#: ../raster/r.in.bin/main.c:395
-msgid "Flip input horizontal (East - West)"
+#: ../raster/r.quant/main.c:81
+msgid "Integer range: min,max"
msgstr ""
-#: ../raster/r.in.bin/main.c:396
-msgid "Flip input vertical (North - South)"
+#: ../raster/r.quant/main.c:86
+msgid "Truncate floating point data"
msgstr ""
-#: ../raster/r.in.bin/main.c:410
+#: ../raster/r.quant/main.c:90
+msgid "Round floating point data"
+msgstr ""
+#: ../raster/r.quant/main.c:111
#, fuzzy, c-format
-msgid "Option %s must be > 0"
-msgstr "출력할 격자지도"
+msgid "-%c, -%c, %s=, %s= and %s= are mutually exclusive"
+msgstr "-%c/-%c와 %s=를 같이 지정할 수 없습니다"
-#: ../raster/r.in.bin/main.c:413
+#: ../raster/r.quant/main.c:120
#, fuzzy, c-format
-msgid "Option %s must be >= 0"
+msgid "%s= and %s= must be used together"
msgstr "출력할 격자지도"
-#: ../raster/r.in.bin/main.c:435 ../raster/r.in.bin/main.c:438
-#, fuzzy, c-format
-msgid "Option %s= is ignored if -%c is set"
-msgstr "<%s> 옵션을 무시합니다"
-#: ../raster/r.in.bin/main.c:462 ../raster/r.out.bin/main.c:379
-#: ../vector/v.colors/main.c:225
+#: ../raster/r.quant/main.c:131
#, c-format
-msgid "-%c and -%c are mutually exclusive"
-msgstr "-%c와 -%c를 같이 지정할 수 없습니다"
+msgid "%s is integer map, it can't be quantized"
+msgstr ""
-#: ../raster/r.in.bin/main.c:467
-#, c-format
-msgid "-%c incompatible with %s=%d; must be 4 or 8"
+#: ../raster/r.quant/main.c:139
+msgid "Truncating..."
msgstr ""
-#: ../raster/r.in.bin/main.c:476
-#, c-format
-msgid "-%c incompatible with %s=%d; must be 8"
+#: ../raster/r.quant/main.c:144
+msgid "Rounding..."
msgstr ""
-#: ../raster/r.in.bin/main.c:484
-#, fuzzy, c-format
-msgid "%s= required for integer data"
-msgstr "출력할 격자지도"
-#: ../raster/r.in.bin/main.c:488
+#: ../raster/r.quant/main.c:152
#, c-format
-msgid "Integer input doesn't support %s=8 in this build"
+msgid "%s is integer map, it can't be used as basemap"
msgstr ""
-#: ../raster/r.in.bin/main.c:493
+#: ../raster/r.quant/main.c:156
#, fuzzy, c-format
-msgid "%s= must be 1, 2, 4 or 8"
+msgid "unable to read quant rules for basemap <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.in.bin/main.c:506
+#: ../raster/r.quant/main.c:163 ../raster/r.quant/main.c:166
#, fuzzy, c-format
-msgid "Either -%c or %s= and %s= must be given"
-msgstr "출력할 격자지도"
+msgid "invalid value for %s= <%s>"
+msgstr "출력할 래스터맵"
-#: ../raster/r.in.bin/main.c:512
-#, fuzzy, c-format
-msgid "Either all or none of %s=, %s=, %s= and %s= must be given"
-msgstr "출력할 격자지도"
-#: ../raster/r.in.bin/main.c:554
+#: ../raster/r.quant/main.c:168
#, c-format
-msgid ""
-"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
-"significantly. Did you assign %s= and %s= correctly?"
+msgid "Setting quant rules for input map(s) to (%f,%f) -> (%d,%d)"
msgstr ""
-#: ../raster/r.in.bin/main.c:575
-msgid "File Size %"
+#: ../raster/r.quant/main.c:181
+msgid "No rules specified. Quant table(s) not changed."
msgstr ""
-#: ../raster/r.in.bin/main.c:595
-#, fuzzy, c-format
-msgid "Importing band %d..."
-msgstr "출력할 격자지도"
+#: ../raster/r.quant/main.c:189
+#, c-format
+msgid "New quant table created for %s"
+msgstr ""
-#: ../raster/r.external/list.c:23 ../raster/r.in.gdal/main.c:288
-#: ../vector/v.in.ogr/main.c:334 ../vector/v.external/list.c:94
-#: ../vector/v.external.out/list.c:102
+#: ../raster/r.timestamp/main.c:39
#, fuzzy
-msgid "Supported formats:"
+msgid "Modifies a timestamp for a raster map."
msgstr "출력할 격자지도"
-#: ../raster/r.external/main.c:59 ../raster/r.external.out/main.c:238
-#: ../vector/v.external/main.c:52 ../vector/v.external.out/main.c:46
-msgid "external"
+#: ../raster/r.timestamp/main.c:40
+msgid "Print/add/remove a timestamp for a raster map."
msgstr ""
-#: ../raster/r.external/main.c:61
-#, fuzzy
-msgid "Links GDAL supported raster data as a pseudo GRASS raster map."
-msgstr "출력할 격자지도"
+#: ../raster/r.timestamp/main.c:49 ../vector/v.timestamp/main.c:50
+msgid "Datetime, datetime1/datetime2, or 'none' to remove"
+msgstr ""
-#: ../raster/r.external/main.c:64
-#, fuzzy
-msgid "Name of raster file to be linked"
-msgstr "출력할 격자지도"
+#: ../raster/r.timestamp/main.c:50 ../vector/v.timestamp/main.c:51
+msgid "Format: '15 jan 1994' (absolute) or '2 years' (relative)"
+msgstr ""
-#: ../raster/r.external/main.c:70
-#, fuzzy
-msgid "Name of non-file GDAL data source"
+#: ../raster/r.timestamp/main.c:65
+#, fuzzy, c-format
+msgid "Raster map <%s> not found %s"
msgstr "출력할 격자지도"
-#: ../raster/r.external/main.c:82
-msgid "Band to select (default is all bands)"
+#: ../raster/r.statistics/o_skew.c:91
+msgid "o_skew: No data in array"
msgstr ""
-#: ../raster/r.external/main.c:95 ../raster/r.external.out/main.c:271
-#: ../raster/r.in.gdal/main.c:197 ../vector/v.external/args.c:49
-#: ../vector/v.external.out/args.c:62
-msgid "List supported formats and exit"
+#: ../raster/r.statistics/main.c:59
+msgid "Calculates category or object oriented statistics."
msgstr ""
-#: ../raster/r.external/main.c:108 ../raster/r.in.gdal/main.c:191
-#: ../vector/v.in.lidar/main.c:300 ../vector/v.in.ogr/main.c:303
-msgid "Extend region extents based on new dataset"
+#: ../raster/r.statistics/read_stats.c:20
+msgid "Reading r.stats output"
msgstr ""
-#: ../raster/r.external/main.c:109 ../raster/r.in.gdal/main.c:193
-#: ../vector/v.in.ogr/main.c:305
-msgid "Also updates the default region if in the PERMANENT mapset"
+#: ../raster/r.statistics/o_sdev.c:94 ../raster/r.statistics/o_var.c:95
+msgid "o_var: No data in array"
msgstr ""
-#: ../raster/r.external/main.c:113
-msgid "Flip horizontally"
+#: ../raster/r.statistics/o_adev.c:93
+msgid "o_adev: No data in array"
msgstr ""
-#: ../raster/r.external/main.c:117
-msgid "Flip vertically"
+#: ../raster/r.statistics/o_kurt.c:91
+msgid "o_kurto: No data in array"
msgstr ""
-#: ../raster/r.external/main.c:122
-msgid "List available bands including band type in dataset and exit"
+#: ../raster/r.proj/bordwalk.c:216
+msgid "Input raster map is outside current region"
msgstr ""
-#: ../raster/r.external/main.c:123
-msgid "Format: band number,type,projection check"
-msgstr ""
+#: ../raster/r.proj/bordwalk.c:242
+#, fuzzy
+msgid "Unable to reproject map center"
+msgstr "출력할 격자지도"
-#: ../raster/r.external/main.c:155
-#, fuzzy, c-format
-msgid "%s= or %s= must be given"
+#: ../raster/r.proj/main.c:149
+#, fuzzy
+msgid "Re-projects a raster map from given location to the current location."
msgstr "출력할 격자지도"
-#: ../raster/r.external/main.c:166 ../display/d.mon/start.c:86
+#: ../raster/r.proj/main.c:153
#, fuzzy
-msgid "Unable to get current working directory"
+msgid "Location containing input raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.external/main.c:198
-msgid "Proceeding with import..."
-msgstr ""
+#: ../raster/r.proj/main.c:154 ../raster/r.proj/main.c:159
+#: ../raster/r.proj/main.c:164 ../vector/v.net.flow/main.c:108
+#: ../vector/v.net.flow/main.c:114 ../vector/v.proj/main.c:78
+#: ../vector/v.proj/main.c:83 ../vector/v.proj/main.c:89
+#, fuzzy
+msgid "Source"
+msgstr "출력할 격자지도"
-#: ../raster/r.external/main.c:202
-#, fuzzy, c-format
-msgid "Imagery group <%s> already exists and will be overwritten."
+#: ../raster/r.proj/main.c:157
+#, fuzzy
+msgid "Mapset containing input raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.external/main.c:209
-#, fuzzy, c-format
-msgid "Reading band %d of %d..."
+#: ../raster/r.proj/main.c:158 ../vector/v.proj/main.c:82
+#, fuzzy
+msgid "Default: name of current mapset"
msgstr "출력할 격자지도"
-#: ../raster/r.external/main.c:214 ../raster/r.in.gdal/main.c:609
-#, c-format
-msgid "Selected band (%d) does not exist"
+#: ../raster/r.proj/main.c:162
+#, fuzzy
+msgid "Name of input raster map to re-project"
+msgstr "출력할 격자지도"
+#: ../raster/r.proj/main.c:167 ../vector/v.proj/main.c:92
+msgid "Path to GRASS database of input location"
msgstr ""
-#: ../raster/r.external/main.c:246
-#, fuzzy, c-format
-msgid "Imagery group <%s> created"
+#: ../raster/r.proj/main.c:171
+#, fuzzy
+msgid "Name for output raster map (default: same as 'input')"
msgstr "출력할 격자지도"
-#: ../raster/r.external/proj.c:18 ../raster/r.in.gdal/main.c:451
-msgid ""
-"Unable to convert input raster map projection information to GRASS format "
-"for checking"
-msgstr ""
+#: ../raster/r.proj/main.c:172 ../raster/r.proj/main.c:183
+#: ../raster/r.proj/main.c:199 ../vector/v.proj/main.c:101
+#: ../vector/v.proj/main.c:106 ../vector/v.proj/main.c:118
+#: ../vector/v.proj/main.c:125
+#, fuzzy
+msgid "Target"
+msgstr "출력할 격자지도"
-#: ../raster/r.external/proj.c:47 ../raster/r.in.gdal/main.c:484
-msgid "Location PROJ_INFO is:\n"
-msgstr ""
+#: ../raster/r.proj/main.c:198
+#, fuzzy
+msgid "Resolution of output raster map"
+msgstr "출력할 격자지도"
-#: ../raster/r.external/proj.c:58 ../raster/r.in.gdal/main.c:495
-msgid "Dataset PROJ_INFO is:\n"
-msgstr ""
+#: ../raster/r.proj/main.c:203
+#, fuzzy
+msgid "List raster maps in input mapset and exit"
+msgstr "출력할 격자지도"
-#: ../raster/r.external/proj.c:111 ../raster/r.in.gdal/main.c:553
-msgid ""
-"Consider generating a new location from the input dataset using the "
-"'location' parameter.\n"
+#: ../raster/r.proj/main.c:213
+msgid "Print input map's bounds in the current projection and exit"
msgstr ""
-#: ../raster/r.external/window.c:23
+#: ../raster/r.proj/main.c:219
msgid ""
-"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
-"transform the map to North-up."
+"Print input map's bounds in the current projection and exit (shell style)"
msgstr ""
-#: ../raster/r.external/window.c:26
-msgid "Applying horizontal flip"
+#: ../raster/r.proj/main.c:245 ../display/d.mon/start.c:52
+#: ../vector/v.external/main.c:132 ../vector/v.proj/main.c:144
+#: ../imagery/i.gensigset/parse.c:57 ../imagery/i.gensig/parse.c:50
+#: ../imagery/i.cluster/main.c:179
+#, c-format
+msgid "option <%s>: <%s> exists. To overwrite, use the --overwrite flag"
msgstr ""
-#: ../raster/r.external/window.c:30
-msgid "Applying vertical flip"
+#: ../raster/r.proj/main.c:252 ../vector/v.proj/main.c:159
+msgid "Input and output locations can not be the same"
msgstr ""
-#: ../raster/r.external/window.c:93 ../raster/r.in.gdal/main.c:892
-#: ../vector/v.in.ogr/main.c:1725
-msgid "Default region for this location updated"
+#: ../raster/r.proj/main.c:254
+msgid "Input and output locations are the same"
msgstr ""
-#: ../raster/r.external/window.c:96 ../raster/r.in.gdal/main.c:895
-#: ../vector/v.in.ogr/main.c:1728
+#: ../raster/r.proj/main.c:264
#, fuzzy
-msgid "Region for the current mapset updated"
+msgid "Unable to get projection info of output raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.external/link.c:48
-msgid "Complex types not supported"
+#: ../raster/r.proj/main.c:267
+#, fuzzy
+msgid "Unable to get projection units of output raster map"
+msgstr "출력할 격자지도"
+#: ../raster/r.proj/main.c:270
+msgid "Unable to get projection key values of output raster map"
msgstr ""
-#: ../raster/r.external/link.c:63
+#: ../raster/r.proj/main.c:279
#, fuzzy, c-format
-msgid "Copying color table for %s"
+msgid "Mapset <%s> in input location <%s> - %s"
msgstr "출력할 격자지도"
-#: ../raster/r.external/link.c:81
-#, fuzzy, c-format
-msgid "Setting grey color table for <%s> (full 8bit range)"
-msgstr "출력할 격자지도"
+#: ../raster/r.proj/main.c:281 ../raster/r.in.gdal/main.c:949
+#: ../vector/v.rectify/target.c:41
+#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:32
+#: ../imagery/i.rectify/target.c:33
+msgid "permission denied"
+msgstr ""
-#: ../raster/r.external/link.c:87
-#, fuzzy, c-format
-msgid "Setting grey color table for <%s> (data range)"
+#: ../raster/r.proj/main.c:282 ../raster/r.in.gdal/main.c:950
+#, fuzzy
+msgid "not found"
msgstr "출력할 격자지도"
-#: ../raster/r.external/link.c:101
+#: ../raster/r.proj/main.c:288 ../vector/v.proj/main.c:183
#, fuzzy, c-format
-msgid "Unable to create cell/%s file"
+msgid "Checking location <%s> mapset <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.external/link.c:110
-#, fuzzy, c-format
-msgid "Unable to create fcell/%s file"
-msgstr "출력할 격자지도"
+#: ../raster/r.proj/main.c:300 ../vector/v.edit/main.c:87
+#: ../vector/v.external/main.c:105 ../vector/v.in.ogr/main.c:353
+#: ../vector/v.select/main.c:89 ../vector/v.proj/main.c:200
+#: ../vector/v.net/args.c:152 ../vector/v.net/args.c:159
+#: ../vector/v.net/args.c:165 ../vector/v.net/args.c:169
+#: ../vector/v.net/args.c:179 ../vector/v.what.rast/main.c:121
+#, c-format
+msgid "Required parameter <%s> not set"
+msgstr ""
-#: ../raster/r.external/link.c:146
+#: ../raster/r.proj/main.c:303
#, fuzzy, c-format
-msgid "Unable to create cell_misc/%s/gdal file"
+msgid "Raster map <%s> in location <%s> in mapset <%s> not found"
msgstr "출력할 격자지도"
-#: ../raster/r.external/link.c:149
-#, fuzzy, c-format
-msgid "Error writing cell_misc/%s/gdal file"
-msgstr "출력할 격자지도"
+#: ../raster/r.proj/main.c:311
+msgid "Unable to get projection info of input map"
+msgstr ""
-#: ../raster/r.external/link.c:174
-#, fuzzy, c-format
-msgid "Unable to create cell_misc/%s/f_format file"
-msgstr "출력할 격자지도"
+#: ../raster/r.proj/main.c:314
+msgid "Unable to get projection units of input map"
+msgstr ""
-#: ../raster/r.external/link.c:177
-#, fuzzy, c-format
-msgid "Error writing cell_misc/%s/f_format file"
-msgstr "출력할 격자지도"
+#: ../raster/r.proj/main.c:317
+msgid "Unable to get projection key values of input map"
+msgstr ""
-#: ../raster/r.external/link.c:224
-#, c-format
-msgid "Creating support files for %s"
-msgstr "%s를 위한 지원파일을 생성합니다"
+#: ../raster/r.proj/main.c:332
+msgid "Unable to work with unprojected data (xy location)"
+msgstr ""
-#: ../raster/r.external/link.c:236
+#: ../raster/r.proj/main.c:351
#, fuzzy, c-format
-msgid "Link to raster map <%s> created."
+msgid "Input map <%s@%s> in location <%s>:"
msgstr "출력할 격자지도"
-#: ../raster/r.contour/cont.c:82
-#, fuzzy, c-format
-msgid "Writing vector contour (one level)..."
-msgid_plural "Writing vector contours (total levels %d)..."
-msgstr[0] "출력할 격자지도"
-msgstr[1] "출력할 격자지도"
+#: ../raster/r.proj/main.c:443
+msgid "Input:"
+msgstr ""
-#: ../raster/r.contour/cont.c:213
-#, fuzzy, c-format
-msgid "%d crossing found"
-msgid_plural "%d crossings found"
+#: ../raster/r.proj/main.c:444 ../raster/r.proj/main.c:455
+#, c-format
+msgid "Cols: %d (%d)"
+msgstr ""
-#: ../raster/r.contour/cont.c:266
-msgid "Illegal edge number"
+#: ../raster/r.proj/main.c:445 ../raster/r.proj/main.c:456
+#, c-format
+msgid "Rows: %d (%d)"
msgstr ""
-#: ../raster/r.contour/cont.c:374
-msgid "Edge number out of range"
+#: ../raster/r.proj/main.c:446 ../raster/r.proj/main.c:457
+#, c-format
+msgid "North: %f (%f)"
msgstr ""
-#: ../raster/r.contour/main.c:89
-msgid "contours"
+#: ../raster/r.proj/main.c:447 ../raster/r.proj/main.c:458
+#, c-format
+msgid "South: %f (%f)"
msgstr ""
-#: ../raster/r.contour/main.c:91
-msgid "Produces a vector map of specified contours from a raster map."
+#: ../raster/r.proj/main.c:448 ../raster/r.proj/main.c:459
+#, c-format
+msgid "West: %f (%f)"
msgstr ""
-#: ../raster/r.contour/main.c:101
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:10
-msgid "Increment between contour levels"
+#: ../raster/r.proj/main.c:449 ../raster/r.proj/main.c:460
+#, c-format
+msgid "East: %f (%f)"
msgstr ""
-#: ../raster/r.contour/main.c:102 ../raster/r.contour/main.c:110
-#: ../raster/r.contour/main.c:117 ../raster/r.contour/main.c:124
-msgid "Contour levels"
+#: ../raster/r.proj/main.c:450 ../raster/r.proj/main.c:461
+#, c-format
+msgid "EW-res: %f"
msgstr ""
-#: ../raster/r.contour/main.c:109
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:11
-msgid "List of contour levels"
+#: ../raster/r.proj/main.c:451 ../raster/r.proj/main.c:462
+#, c-format
+msgid "NS-res: %f"
msgstr ""
-#: ../raster/r.contour/main.c:116
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:12
-msgid "Minimum contour level"
+#: ../raster/r.proj/main.c:454
+msgid "Output:"
msgstr ""
-#: ../raster/r.contour/main.c:123
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:13
-msgid "Maximum contour level"
+#: ../raster/r.proj/main.c:491
+#, fuzzy
+msgid "Projecting..."
+msgstr "출력할 격자지도"
+#: ../raster/r.proj/readcell.c:67
+#, fuzzy
+msgid "Allocating memory and reading input raster map..."
+msgstr "출력할 격자지도"
+#: ../raster/r.proj/readcell.c:92
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:100
+#: ../imagery/i.rectify/readcell.c:90 ../imagery/i.rectify/readcell.c:129
+msgid "Error writing segment file"
msgstr ""
-#: ../raster/r.contour/main.c:132
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:14
-msgid "Minimum number of points for a contour line (0 -> no limit)"
+#: ../raster/r.proj/readcell.c:125
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:130
+#: ../imagery/i.rectify/readcell.c:117
+msgid "Internal error: cache miss on fully-cached map"
msgstr ""
-#: ../raster/r.contour/main.c:140
+#: ../raster/r.proj/readcell.c:138
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:139
+#: ../imagery/i.rectify/readcell.c:126
+msgid "Error seeking on segment file"
+msgstr ""
+#: ../raster/r.proj/readcell.c:141
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:142
+#, fuzzy
+msgid "Error reading segment file"
+msgstr "출력할 격자지도"
+#: ../raster/r.kappa/prt_hdr.c:18
#, fuzzy, c-format
-msgid "Neither <%s> nor <%s> option must be specified"
+msgid "Cannot open file <%s> to write header"
msgstr "출력할 격자지도"
-#: ../raster/r.contour/main.c:203 ../vector/v.extract/copy_tab.c:57
-#: ../vector/v.generalize/misc.c:134 ../vector/v.voronoi/main.c:384
-#: ../vector/v.select/copy_tabs.c:17
-msgid "Writing attributes..."
-msgstr "특성을 쓰고 있습니다..."
+#: ../raster/r.kappa/main.c:70 ../vector/v.class/main.c:46
+#: ../imagery/i.segment/main.c:38 ../imagery/i.maxlik/main.c:62
+#: ../imagery/i.smap/main.c:39 ../imagery/i.gensigset/main.c:41
+#: ../imagery/i.gensig/main.c:40 ../imagery/i.cluster/main.c:76
+#, fuzzy
+msgid "classification"
+msgstr "출력할 격자지도"
-#: ../raster/r.contour/main.c:237 ../vector/v.generalize/displacement.c:78
+#: ../raster/r.kappa/main.c:72
+msgid ""
+"Calculates error matrix and kappa parameter for accuracy assessment of "
+"classification result."
+msgstr ""
+#: ../raster/r.kappa/main.c:78
#, fuzzy
-msgid "Reading data..."
+msgid "Name of raster map containing classification result"
msgstr "출력할 격자지도"
-#: ../raster/r.contour/main.c:263
-#, fuzzy, c-format
-msgid "Range of data: min=%f, max=%f"
+#: ../raster/r.kappa/main.c:83
+#, fuzzy
+msgid "Name of raster map containing reference classes"
msgstr "출력할 격자지도"
-#: ../raster/r.contour/main.c:265
+#: ../raster/r.kappa/main.c:88
#, fuzzy
-msgid "Range of data: empty"
+msgid "Name for output file containing error matrix and kappa"
msgstr "출력할 격자지도"
-#: ../raster/r.contour/main.c:293 ../raster/r.contour/main.c:296
+#: ../raster/r.kappa/main.c:89 ../raster/r.colors.out/raster3d_main.c:57
+#: ../raster/r.colors.out/raster_main.c:56 ../vector/v.colors.out/main.c:62
#, fuzzy
-msgid "This step value is not allowed"
+msgid "If not given write to standard output"
msgstr "출력할 격자지도"
-#: ../raster/r.contour/main.c:321
+#: ../raster/r.kappa/main.c:96
+msgid "Title for error matrix and kappa"
+msgstr ""
+#: ../raster/r.kappa/main.c:102
+msgid "Wide report"
+msgstr ""
+#: ../raster/r.kappa/main.c:103
+msgid "132 columns (default: 80)"
+msgstr ""
+#: ../raster/r.kappa/main.c:108
+msgid "No header in the report"
+msgstr ""
+#: ../raster/r.kappa/prt_mat.c:39
#, c-format
-msgid "Range of levels: min = %f, max = %f"
+msgid "Cannot open file <%s> to write cats and counts (error matrix)"
msgstr ""
-#: ../raster/r.contour/main.c:350
-#, fuzzy
-msgid "Displacing data..."
+#: ../raster/r.kappa/prt_label.c:17
+#, fuzzy, c-format
+msgid "Can't open file <%s> to write label"
msgstr "출력할 격자지도"
+#: ../raster/r.kappa/calc_kappa.c:32
+#, c-format
+msgid "Cannot open file <%s> to write kappa and relevant parameters"
+msgstr ""
#: ../raster/r.out.bin/main.c:139
#, c-format
msgid "Header File = %s"
@@ -16674,2149 +18537,2396 @@
msgid "c=%d"
msgstr ""
-#: ../raster/r.covar/main.c:54
+#: ../raster/r.rescale.eq/get_stats.c:19 ../raster/r.rescale/get_range.c:24
+#, c-format
+msgid "Reading %s ..."
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:53 ../raster/r.rescale/main.c:49
+#, fuzzy
+msgid "rescale"
+msgstr "출력할 격자지도"
+#: ../raster/r.rescale.eq/main.c:55
msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map "
-"layer(s)."
+"Rescales histogram equalized the range of category values in a raster map "
+"layer."
msgstr ""
-#: ../raster/r.covar/main.c:61
-msgid "Print correlation matrix"
+#: ../raster/r.rescale.eq/main.c:61 ../raster/r.rescale/main.c:56
+msgid "The name of the raster map to be rescaled"
msgstr ""
-#: ../raster/r.covar/main.c:86
-#, c-format
-msgid "%s: complete ... "
+#: ../raster/r.rescale.eq/main.c:69 ../raster/r.rescale/main.c:64
+msgid "The input data range to be rescaled (default: full range of input map)"
msgstr ""
-#: ../raster/r.topmodel/file_io.c:56
-#, fuzzy, c-format
-msgid "%s cannot be 0"
-msgstr "출력할 격자지도"
+#: ../raster/r.rescale.eq/main.c:72 ../raster/r.rescale/main.c:67
+msgid "The resulting raster map name"
+msgstr ""
-#: ../raster/r.topmodel/file_io.c:209 ../raster/r.topmodel/topmodel.c:75
-#: ../vector/v.out.pov/main.c:104
-#, fuzzy, c-format
-msgid "Unable to create output file <%s>"
-msgstr "출력할 격자지도"
+#: ../raster/r.rescale.eq/main.c:79 ../raster/r.rescale/main.c:74
+msgid "The output data range"
+msgstr ""
-#: ../raster/r.topmodel/main.c:55
-msgid "Simulates TOPMODEL which is a physically based hydrologic model."
+#: ../raster/r.rescale.eq/main.c:86 ../raster/r.rescale/main.c:81
+msgid "Title for new raster map"
msgstr ""
-#: ../raster/r.topmodel/main.c:60
-#, fuzzy
-msgid "Name of input TOPMODEL parameters file"
-msgstr "출력할 격자지도"
+#: ../raster/r.rescale.eq/main.c:115
+#, c-format
+msgid "Rescale %s[%d,%d] to %s[%d,%d]"
+msgstr ""
-#: ../raster/r.topmodel/main.c:65
+#: ../raster/r.ros/main.c:215
#, fuzzy
-msgid "Name of input topographic index statistics file"
+msgid "rate of spread"
msgstr "출력할 격자지도"
-#: ../raster/r.topmodel/main.c:69
+#: ../raster/r.ros/main.c:218
#, fuzzy
-msgid "Name of input rainfall and potential evapotranspiration data file"
+msgid "Generates rate of spread raster maps."
msgstr "출력할 격자지도"
-#: ../raster/r.topmodel/main.c:72
-#: ../locale/scriptstrings/d.out.file_to_translate.c:4
-#: ../general/g.list/main.c:114
-msgid "Name for output file"
-msgstr "출력파일 이름"
-#: ../raster/r.topmodel/main.c:76
-msgid "Time step"
+#: ../raster/r.ros/main.c:220
+msgid ""
+"Generates three, or four raster map layers showing the base (perpendicular) "
+"rate of spread (ROS), the maximum (forward) ROS, the direction of the "
+"maximum ROS, and optionally the maximum potential spotting distance for fire "
+"spread simulation."
msgstr ""
-#: ../raster/r.topmodel/main.c:77
+#: ../raster/r.ros/main.c:227
#, fuzzy
-msgid "Generate output for this time step"
+msgid "Raster map containing fuel models"
msgstr "출력할 격자지도"
-#: ../raster/r.topmodel/main.c:83
-#, fuzzy
-msgid "Topographic index class"
-msgstr "출력할 격자지도"
-#: ../raster/r.topmodel/main.c:85
-#, fuzzy
-msgid "Generate output for this topographic index class"
-msgstr "출력할 격자지도"
-#: ../raster/r.topmodel/main.c:92
-msgid "Name of input topographic index raster map"
-msgstr "입력 위상색인 격자지도의 이름"
-#: ../raster/r.topmodel/main.c:94
+#: ../raster/r.ros/main.c:229
msgid ""
-"Must be clipped to the catchment boundary. Used for generating outtopidxstats"
+"Name of an existing raster map layer in the user's current mapset search "
+"path containing the standard fuel models defined by the USDA Forest Service. "
+"Valid values are 1-13; other numbers are recognized as barriers by r.ros."
msgstr ""
-#: ../raster/r.topmodel/main.c:96 ../raster/r.topmodel/main.c:106
-#: ../raster/r.topmodel/main.c:115
-msgid "Preprocess"
+#: ../raster/r.ros/main.c:238
+msgid "Raster map containing the 1-hour fuel moisture (%)"
msgstr ""
-#: ../raster/r.topmodel/main.c:100
-#, fuzzy
-msgid "Number of topographic index classes"
-msgstr "출력할 격자지도"
+#: ../raster/r.ros/main.c:248
+msgid "Raster map containing the 10-hour fuel moisture (%)"
+msgstr ""
-#: ../raster/r.topmodel/main.c:102
-msgid "Used for generating outtopidxstats"
+#: ../raster/r.ros/main.c:250
+msgid ""
+"path containing the 10-hour (.25-1\") fuel moisture (percentage content "
+"multiplied by 100)."
msgstr ""
-#: ../raster/r.topmodel/main.c:111
-#, fuzzy
-msgid "Name for output topographic index statistics file"
-msgstr "출력할 격자지도"
+#: ../raster/r.ros/main.c:258
+msgid "Raster map containing the 100-hour fuel moisture (%)"
+msgstr ""
-#: ../raster/r.topmodel/main.c:113
-msgid "Requires topidx and ntopidxclasses"
+#: ../raster/r.ros/main.c:260
+msgid ""
+"path containing the 100-hour (1-3\") fuel moisture (percentage content "
msgstr ""
-#: ../raster/r.topmodel/main.c:120
-msgid "Preprocess only and stop after generating outtopidxstats"
+#: ../raster/r.ros/main.c:267
+msgid "Raster map containing live fuel moisture (%)"
msgstr ""
-#: ../raster/r.topmodel/main.c:150
-#, fuzzy, c-format
-msgid "%s must be greater than 1"
-msgstr "출력할 격자지도"
-#: ../raster/r.topmodel/main.c:154 ../raster/r.topmodel/main.c:157
-#, c-format
-msgid "Ignoring %s because %s is not specified"
+#: ../raster/r.ros/main.c:269
+msgid ""
+"path containing live (herbaceous) fuel moisture (percentage content "
msgstr ""
-#: ../raster/r.topmodel/infiltration.c:69
-#: ../raster/r.topmodel/infiltration.c:108
-#, fuzzy, c-format
-msgid "Maximum number of iterations exceeded at timestep %d"
+#: ../raster/r.ros/main.c:277
+#, fuzzy
+msgid "Raster map containing midflame wind velocities (ft/min)"
msgstr "출력할 격자지도"
-#: ../raster/r.topmodel/topmodel.c:30
-#, fuzzy, c-format
-msgid "Unable to run %s"
+#: ../raster/r.ros/main.c:287
+#, fuzzy
+msgid "Name of raster map containing wind directions (degree)"
msgstr "출력할 격자지도"
-#: ../raster/r.topmodel/topmodel.c:72
-#, fuzzy, c-format
-msgid "Invalid %s output"
-msgstr "출력할 격자지도"
+#: ../raster/r.ros/main.c:289
+msgid ""
+"path containing wind direction, clockwise from north (degree)."
+msgstr ""
-#: ../raster/r.param.scale/interface.c:55
+#: ../raster/r.ros/main.c:297
#, fuzzy
-msgid "geomorphology"
+msgid "Name of raster map containing slope (degree)"
msgstr "출력할 격자지도"
-#: ../raster/r.param.scale/interface.c:58
-msgid "landform"
+#: ../raster/r.ros/main.c:299
+msgid ""
+"path containing topographic slope (degree)."
msgstr ""
-#: ../raster/r.param.scale/interface.c:59
-msgid "Extracts terrain parameters from a DEM."
+#: ../raster/r.ros/main.c:307
+msgid "Raster map containing aspect (degree, CCW from E)"
msgstr ""
-#: ../raster/r.param.scale/interface.c:60
+#: ../raster/r.ros/main.c:309
msgid ""
-"Uses a multi-scale approach by taking fitting quadratic parameters to any "
-"size window (via least squares)."
+"path containing topographic aspect, counterclockwise from east (GRASS "
+"convention) in degrees."
msgstr ""
-#: ../raster/r.param.scale/interface.c:78
+#: ../raster/r.ros/main.c:317
#, fuzzy
-msgid "Name for output raster map containing morphometric parameter"
+msgid "Raster map containing elevation (m, required for spotting)"
msgstr "출력할 격자지도"
-#: ../raster/r.param.scale/interface.c:82
-msgid "Slope tolerance that defines a 'flat' surface (degrees)"
+#: ../raster/r.ros/main.c:319
+msgid ""
+"path containing elevation (meters). Option is required from spotting "
+"distance computation (when spotting_distance option is provided)"
msgstr ""
-#: ../raster/r.param.scale/interface.c:89
-msgid "Curvature tolerance that defines 'planar' surface"
-msgstr ""
+#: ../raster/r.ros/main.c:328
+#, fuzzy
+msgid "Output raster map containing base ROS (cm/min)"
+msgstr "출력할 격자지도"
-#: ../raster/r.param.scale/interface.c:96
-msgid "Size of processing window (odd number only)"
+#: ../raster/r.ros/main.c:330
+msgid "Base (perpendicular) rate of spread (ROS)"
msgstr ""
-#: ../raster/r.param.scale/interface.c:104
-msgid "Morphometric parameter in 'size' window to calculate"
-msgstr ""
+#: ../raster/r.ros/main.c:336
+#, fuzzy
+msgid "Output raster map containing maximal ROS (cm/min)"
+msgstr "출력할 격자지도"
-#: ../raster/r.param.scale/interface.c:112
-msgid "Exponent for distance weighting (0.0-4.0)"
+#: ../raster/r.ros/main.c:338
+msgid "The maximum (forward) rate of spread (ROS)"
msgstr ""
-#: ../raster/r.param.scale/interface.c:124
-msgid "Constrain model through central window cell"
-msgstr ""
+#: ../raster/r.ros/main.c:344
+#, fuzzy
+msgid "Output raster map containing directions of maximal ROS (degree)"
+msgstr "출력할 격자지도"
-#: ../raster/r.param.scale/interface.c:167
-msgid "Morphometric parameter not recognised. Assuming 'Elevation'"
+#: ../raster/r.ros/main.c:346
+msgid "The direction of the maximal (forward) rate of spread (ROS)"
msgstr ""
-#: ../raster/r.param.scale/interface.c:175
-msgid "Inappropriate window size (too big or even)"
+#: ../raster/r.ros/main.c:352
+#, fuzzy
+msgid "Output raster map containing maximal spotting distance (m)"
+msgstr "출력할 격자지도"
+#: ../raster/r.ros/main.c:354
+msgid ""
+"The maximal potential spotting distance (requires elevation raster map to be "
+"provided)."
msgstr ""
-#: ../raster/r.param.scale/main.c:42
-msgid "Lat/Long locations are not supported by this module"
+#: ../raster/r.ros/main.c:373
+msgid ""
+"No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h "
+"moisture layers is required."
msgstr ""
-#: ../raster/r.param.scale/process.c:75
-msgid "E-W and N-S grid resolutions are different. Taking average."
+#: ../raster/r.ros/main.c:397
+#, c-format
+msgid ""
+"A wind direction layer should be given if the wind velocity layer <%s> has "
+"been given"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:151
+#: ../raster/r.ros/main.c:402
+#, c-format
msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
+"A wind velocity layer should be given if the wind direction layer <%s> has "
+"been given"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:162
-msgid "Desired east-west resolution"
+#: ../raster/r.ros/main.c:416
+#, c-format
+msgid "An aspect layer should be given if the slope layer <%s> has been given"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:168
-msgid "Desired north-south resolution"
+#: ../raster/r.ros/main.c:421
+#, c-format
+msgid "A slope layer should be given if the aspect layer <%s> has been given"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:173
-#, fuzzy
-msgid "Name for output elevation raster map"
-msgstr "출력할 격자지도"
+#: ../raster/r.ros/main.c:437
+msgid "An elevation layer should be given if considering spotting"
+msgstr ""
-#: ../raster/r.resamp.rst/main.c:179
-#, fuzzy
-msgid "Name for output slope map (or fx)"
+#: ../raster/r.ros/main.c:873
+#, fuzzy, c-format
+msgid "Raster maps <%s>, <%s> and <%s> created."
msgstr "출력할 격자지도"
-#: ../raster/r.resamp.rst/main.c:185
-#, fuzzy
-msgid "Name for output aspect map (or fy)"
-msgstr "출력할 격자지도"
+#: ../raster/r.covar/main.c:54
+msgid ""
+"Outputs a covariance/correlation matrix for user-specified raster map "
+"layer(s)."
+msgstr ""
-#: ../raster/r.resamp.rst/main.c:191
-#, fuzzy
-msgid "Name for output profile curvature map (or fxx)"
-msgstr "출력할 격자지도"
+#: ../raster/r.covar/main.c:61
+msgid "Print correlation matrix"
+msgstr ""
-#: ../raster/r.resamp.rst/main.c:197
-#, fuzzy
-msgid "Name for output tangential curvature map (or fyy)"
-msgstr "출력할 격자지도"
+#: ../raster/r.covar/main.c:86
+#, c-format
+msgid "%s: complete ... "
+msgstr ""
-#: ../raster/r.resamp.rst/main.c:203
+#: ../raster/r.covar/main.c:110 ../imagery/i.pca/main.c:197
+msgid "No non-null values"
+msgstr ""
+#: ../raster/r.external/main.c:61
#, fuzzy
-msgid "Name for output mean curvature map (or fxy)"
+msgid "Links GDAL supported raster data as a pseudo GRASS raster map."
msgstr "출력할 격자지도"
-#: ../raster/r.resamp.rst/main.c:209
+#: ../raster/r.external/main.c:64
#, fuzzy
-msgid "Name of input raster map containing smoothing"
+msgid "Name of raster file to be linked"
msgstr "출력할 격자지도"
-#: ../raster/r.resamp.rst/main.c:215
+#: ../raster/r.external/main.c:70
#, fuzzy
-msgid "Name of input raster map to be used as mask"
+msgid "Name of non-file GDAL data source"
msgstr "출력할 격자지도"
-#: ../raster/r.resamp.rst/main.c:223
-msgid "Rows/columns overlap for segmentation"
+#: ../raster/r.external/main.c:82
+msgid "Band to select (default is all bands)"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:231
-msgid "Multiplier for z-values"
+#: ../raster/r.external/main.c:108 ../raster/r.in.gdal/main.c:191
+#: ../vector/v.in.ogr/main.c:303 ../vector/v.in.lidar/main.c:300
+msgid "Extend region extents based on new dataset"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:239
-msgid "Spline tension value"
+#: ../raster/r.external/main.c:109 ../raster/r.in.gdal/main.c:193
+#: ../vector/v.in.ogr/main.c:305
+msgid "Also updates the default region if in the PERMANENT mapset"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:246 ../vector/v.surf.rst/main.c:325
-msgid "Anisotropy angle (in degrees counterclockwise from East)"
+#: ../raster/r.external/main.c:113
+msgid "Flip horizontally"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:247 ../raster/r.resamp.rst/main.c:254
-msgid "Anisotropy"
+#: ../raster/r.external/main.c:117
+msgid "Flip vertically"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:253 ../vector/v.surf.rst/main.c:332
-msgid "Anisotropy scaling factor"
+#: ../raster/r.external/main.c:122
+msgid "List available bands including band type in dataset and exit"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:258
-msgid "Use dnorm independent tension"
+#: ../raster/r.external/main.c:123
+msgid "Format: band number,type,projection check"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:263 ../vector/v.surf.rst/main.c:165
-msgid "Output partial derivatives instead of topographic parameters"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:297
-#, fuzzy
-msgid "Unable to read ew_res value"
+#: ../raster/r.external/main.c:155
+#, fuzzy, c-format
+msgid "%s= or %s= must be given"
msgstr "출력할 격자지도"
-#: ../raster/r.resamp.rst/main.c:300
+#: ../raster/r.external/main.c:166 ../display/d.mon/start.c:86
#, fuzzy
-msgid "Unable to read ns_res value"
+msgid "Unable to get current working directory"
msgstr "출력할 격자지도"
-#: ../raster/r.resamp.rst/main.c:303
-msgid "Invalid value for tension"
+#: ../raster/r.external/main.c:198
+msgid "Proceeding with import..."
msgstr ""
-#: ../raster/r.resamp.rst/main.c:306
-msgid "Invalid value for zmult"
-msgstr ""
+#: ../raster/r.external/main.c:202
+#, fuzzy, c-format
+msgid "Imagery group <%s> already exists and will be overwritten."
+msgstr "출력할 격자지도"
-#: ../raster/r.resamp.rst/main.c:309
-msgid "Invalid value for overlap"
-msgstr ""
+#: ../raster/r.external/main.c:209
+#, fuzzy, c-format
+msgid "Reading band %d of %d..."
+msgstr "출력할 격자지도"
-#: ../raster/r.resamp.rst/main.c:313
-msgid "Invalid value for theta"
+#: ../raster/r.external/main.c:214 ../raster/r.in.gdal/main.c:609
+#, c-format
+msgid "Selected band (%d) does not exist"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:317
-msgid "Invalid value for scalex"
-msgstr ""
+#: ../raster/r.external/main.c:246
+#, fuzzy, c-format
+msgid "Imagery group <%s> created"
+msgstr "출력할 격자지도"
-#: ../raster/r.resamp.rst/main.c:319
-msgid "When using anisotropy both theta and scalex must be specified"
+#: ../raster/r.external/window.c:23
+msgid ""
+"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
+"transform the map to North-up."
msgstr ""
-#: ../raster/r.resamp.rst/main.c:357
-#, c-format
-msgid "Map <%s> is the wrong resolution"
+#: ../raster/r.external/window.c:26
+msgid "Applying horizontal flip"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:365
-msgid "Smoothing values can not be negative or NULL"
+#: ../raster/r.external/window.c:30
+msgid "Applying vertical flip"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:371
-msgid "Input map resolution differs from current region resolution!"
+#: ../raster/r.external/window.c:93 ../raster/r.in.gdal/main.c:892
+#: ../vector/v.in.ogr/main.c:1725
+msgid "Default region for this location updated"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:387
-msgid "Processing all selected output files will require"
-msgstr ""
+#: ../raster/r.external/window.c:96 ../raster/r.in.gdal/main.c:895
+#: ../vector/v.in.ogr/main.c:1728
+#, fuzzy
+msgid "Region for the current mapset updated"
+msgstr "출력할 격자지도"
-#: ../raster/r.resamp.rst/main.c:391
-#, c-format
-msgid "%.2f GB of disk space for temp files."
+#: ../raster/r.external/link.c:48
+msgid "Complex types not supported"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:394
-#, c-format
-msgid "%.2f MB of disk space for temp files."
-msgstr ""
+#: ../raster/r.external/link.c:63
+#, fuzzy, c-format
+msgid "Copying color table for %s"
+msgstr "출력할 격자지도"
-#: ../raster/r.resamp.rst/main.c:397
-#, c-format
-msgid "%.2f KB of disk space for temp files."
-msgstr ""
+#: ../raster/r.external/link.c:81
+#, fuzzy, c-format
+msgid "Setting grey color table for <%s> (full 8bit range)"
+msgstr "출력할 격자지도"
-#: ../raster/r.resamp.rst/main.c:400
-#, c-format
-msgid "%d byte of disk space for temp files."
-msgid_plural "%d bytes of disk space for temp files."
-msgstr[0] ""
-msgstr[1] ""
+#: ../raster/r.external/link.c:87
+#, fuzzy, c-format
+msgid "Setting grey color table for <%s> (data range)"
+msgstr "출력할 격자지도"
-#: ../raster/r.resamp.rst/main.c:436
-msgid "Maximum value of a raster map is NULL."
-msgstr ""
+#: ../raster/r.external/link.c:101
+#, fuzzy, c-format
+msgid "Unable to create cell/%s file"
+msgstr "출력할 격자지도"
-#: ../raster/r.resamp.rst/main.c:464
-msgid "Temporarily changing the region to desired resolution ..."
-msgstr ""
+#: ../raster/r.external/link.c:110
+#, fuzzy, c-format
+msgid "Unable to create fcell/%s file"
+msgstr "출력할 격자지도"
-#: ../raster/r.resamp.rst/main.c:469
-msgid "Changing back to the original region ..."
-msgstr ""
+#: ../raster/r.external/link.c:146
+#, fuzzy, c-format
+msgid "Unable to create cell_misc/%s/gdal file"
+msgstr "출력할 격자지도"
-#: ../raster/r.resamp.rst/main.c:490
-#, c-format
-msgid "dnorm in mainc after grid before out1= %f"
-msgstr ""
+#: ../raster/r.external/link.c:149
+#, fuzzy, c-format
+msgid "Error writing cell_misc/%s/gdal file"
+msgstr "출력할 격자지도"
-#: ../raster/r.resamp.rst/main.c:494
-msgid "split_and_interpolate() failed"
-msgstr ""
+#: ../raster/r.external/link.c:174
+#, fuzzy, c-format
+msgid "Unable to create cell_misc/%s/f_format file"
+msgstr "출력할 격자지도"
-#: ../raster/r.resamp.rst/main.c:509
+#: ../raster/r.external/link.c:177
+#, fuzzy, c-format
+msgid "Error writing cell_misc/%s/f_format file"
+msgstr "출력할 격자지도"
+#: ../raster/r.external/link.c:224
#, c-format
-msgid "dnorm in mainc after grid before out2= %f"
-msgstr ""
+msgid "Creating support files for %s"
+msgstr "%s를 위한 지원파일을 생성합니다"
-#: ../raster/r.resamp.rst/main.c:515
-#, fuzzy
-msgid "Unable to write raster maps -- try increasing cell size"
-msgstr "출력할 격자지도"
-#: ../raster/r.resamp.filter/main.c:142
+#: ../raster/r.external/link.c:236
#, fuzzy, c-format
-msgid "Filter <%s> not found"
+msgid "Link to raster map <%s> created."
msgstr "출력할 격자지도"
-#: ../raster/r.resamp.filter/main.c:391
+#: ../raster/r.external/list.c:23 ../raster/r.in.gdal/main.c:288
+#: ../vector/v.external/list.c:94 ../vector/v.in.ogr/main.c:334
+#: ../vector/v.external.out/list.c:102
#, fuzzy
-msgid "kernel filter"
-msgstr "여과"
-#: ../raster/r.resamp.filter/main.c:394
-#, fuzzy
-msgid "Resamples raster map layers using an analytic kernel."
+msgid "Supported formats:"
msgstr "출력할 격자지도"
-#: ../raster/r.resamp.filter/main.c:405
-msgid "Filter kernel(s)"
+#: ../raster/r.external/proj.c:18 ../raster/r.in.gdal/main.c:451
+msgid ""
+"Unable to convert input raster map projection information to GRASS format "
+"for checking"
msgstr ""
-#: ../raster/r.resamp.filter/main.c:413
-msgid "Filter radius"
+#: ../raster/r.external/proj.c:47 ../raster/r.in.gdal/main.c:484
+msgid "Location PROJ_INFO is:\n"
msgstr ""
-#: ../raster/r.resamp.filter/main.c:420
-msgid "Filter radius (horizontal)"
+#: ../raster/r.external/proj.c:58 ../raster/r.in.gdal/main.c:495
+msgid "Dataset PROJ_INFO is:\n"
msgstr ""
-#: ../raster/r.resamp.filter/main.c:427
-msgid "Filter radius (vertical)"
+#: ../raster/r.external/proj.c:111 ../raster/r.in.gdal/main.c:553
+msgid ""
+"Consider generating a new location from the input dataset using the "
+"'location' parameter.\n"
msgstr ""
-#: ../raster/r.resamp.filter/main.c:438 ../vector/v.external.out/args.c:90
-#, fuzzy, c-format
-msgid "%s= and %s=/%s= are mutually exclusive"
-msgstr "%s=와 %s=를 같이 지정할 수 없습니다"
+#: ../raster/r.out.vrml/main.c:49
+msgid "VRML"
+msgstr ""
-#: ../raster/r.resamp.filter/main.c:443
-#, fuzzy, c-format
-msgid "Either %s= or %s=/%s= required"
+#: ../raster/r.out.vrml/main.c:51
+msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
+msgstr ""
+#: ../raster/r.out.vrml/main.c:58
+#, fuzzy
+msgid "Name of input color map"
+msgstr "벡터지도 이름"
+#: ../raster/r.out.vrml/main.c:69
+#, fuzzy
+msgid "Name for output VRML file"
msgstr "출력할 격자지도"
-#: ../raster/r.resamp.filter/main.c:446
+#: ../raster/r.out.vrml/main.c:88
+#, c-format
+msgid "Range info for [%s] not available (run r.support)"
+msgstr ""
+#: ../raster/r.out.vrml/main.c:97
#, fuzzy, c-format
-msgid "Both %s= and %s= required"
+msgid "Range info for <%s> not available (run r.support)"
msgstr "출력할 격자지도"
-#: ../raster/r.resamp.filter/main.c:469
-msgid "Differing number of values for filter= and [xy_]radius="
+#: ../raster/r.out.vrml/main.c:129
+#, c-format
+msgid "Opening %s for writing... "
msgstr ""
-#: ../raster/r.resamp.filter/main.c:472
-#, c-format
-msgid "Too many filters (max: %d)"
+#: ../raster/r.out.vrml/put_grid.c:38
+msgid "Writing vertices..."
msgstr ""
-#: ../raster/r.resamp.filter/main.c:490
+#: ../raster/r.out.vrml/put_grid.c:83
+msgid "Writing color file..."
+msgstr ""
+#: ../raster/r.what/main.c:102
#, fuzzy
-msgid "At least one filter must be finite"
+msgid "Queries raster maps on their category values and category labels."
msgstr "출력할 격자지도"
-#: ../raster/r.basins.fill/read_map.c:39
-#, fuzzy, c-format
-msgid "Reading <%s> ... "
-msgstr "출력할 격자지도"
+#: ../raster/r.what/main.c:106
+msgid "Name of existing raster map(s) to query"
+msgstr ""
-#: ../raster/r.basins.fill/main.c:56 ../raster/r.watershed/front/main.c:75
-#: ../raster/r.water.outlet/main.c:59
-msgid "watershed"
+#: ../raster/r.what/main.c:109 ../vector/v.what/main.c:75
+msgid "Coordinates for query"
msgstr ""
-#: ../raster/r.basins.fill/main.c:58
-#, fuzzy
-msgid "Generates watershed subbasins raster map."
-msgstr "출력할 격자지도"
+#: ../raster/r.what/main.c:110 ../raster/r.what/main.c:116
+#: ../vector/v.to.db/parse.c:104 ../vector/v.to.db/parse.c:112
+#: ../db/db.select/main.c:203 ../db/db.select/main.c:209
+#: ../db/db.select/main.c:213 ../db/db.select/main.c:251
+#: ../db/db.select/main.c:261
+msgid "Query"
+msgstr ""
-#: ../raster/r.basins.fill/main.c:62
+#: ../raster/r.what/main.c:114
#, fuzzy
-msgid "Name of input coded stream network raster map"
+msgid "Name of vector points map for query"
msgstr "출력할 격자지도"
-#: ../raster/r.basins.fill/main.c:66
+#: ../raster/r.what/main.c:135
+msgid "Size of point cache"
+msgstr ""
+#: ../raster/r.what/main.c:137 ../raster/r.what/main.c:162
+#: ../display/d.legend/main.c:118 ../display/d.legend/main.c:128
+#: ../display/d.legend/main.c:136 ../display/d.legend/main.c:168
+#: ../display/d.legend/main.c:253 ../display/d.legend/main.c:258
+#: ../display/d.legend/main.c:268 ../display/d.legend/main.c:278
+#: ../display/d.legend/main.c:293
+msgid "Advanced"
+msgstr "고급"
+#: ../raster/r.what/main.c:146
#, fuzzy
-msgid "Name of input thinned ridge network raster map"
+msgid "Show the category labels of the grid cell(s)"
msgstr "출력할 격자지도"
-#: ../raster/r.basins.fill/main.c:74
-msgid "Number of passes through the dataset"
+#: ../raster/r.what/main.c:151
+msgid "Output color values as RRR:GGG:BBB"
msgstr ""
-#: ../raster/r.basins.fill/main.c:122
-msgid "Forward sweep complete"
+#: ../raster/r.what/main.c:156
+msgid "Output integer category values, not cell values"
msgstr ""
-#: ../raster/r.basins.fill/main.c:139
-msgid "Reverse sweep complete"
+#: ../raster/r.what/main.c:161
+msgid "Turn on cache reporting"
msgstr ""
-#: ../raster/r.reclass/reclass.c:51 ../raster/r.reclass/reclass.c:111
-msgid "Too many categories"
-msgstr ""
-#: ../raster/r.reclass/reclass.c:216
+#: ../raster/r.what/main.c:201
#, fuzzy, c-format
-msgid "Cannot read header file of <%s@%s>"
+msgid "Can only do up to %d raster maps (%d given)"
msgstr "출력할 격자지도"
-#: ../raster/r.reclass/reclass.c:234
+#: ../raster/r.what/main.c:217
#, fuzzy, c-format
-msgid "Cannot overwrite existing raster map <%s>"
+msgid "Unable to read category file for <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.reclass/reclass.c:239
+#: ../raster/r.what/main.c:296
#, fuzzy, c-format
-msgid "Cannot create reclass file of <%s>"
+msgid "Unable to read vector map <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.reclass/reclass.c:247
-#, fuzzy, c-format
-msgid "Cannot create raster map <%s>"
+#: ../raster/r.what/main.c:300
+#, c-format
+msgid "Line %d is not point or centroid, skipped"
+msgstr "선 %d는 점이나 중심점이 아니므로 넘어갑니다"
+#: ../raster/r.what/main.c:384
+#, c-format
+msgid "%s %s is outside your current region"
+msgstr "%s %s는 현재지역의 바깥입니다"
+#: ../raster/r.out.gdal/export_band.c:52 ../raster/r.out.gdal/export_band.c:344
+#, fuzzy
+msgid "Unable to allocate buffer for reading raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.reclass/parse.c:42
-msgid "poor quality"
-msgstr ""
+#: ../raster/r.out.gdal/export_band.c:156
+#, fuzzy, c-format
+msgid "Using GDAL data type <%s>"
+msgstr "자료형을 출력합니다"
-#: ../raster/r.reclass/parse.c:44
-msgid "medium quality"
+#: ../raster/r.out.gdal/export_band.c:161
+#, c-format
+msgid ""
+"Input raster map contains cells with NULL-value (no-data). The value %d will "
+"be used to represent no-data values in the input map. You can specify a "
+"nodata value with the %s option."
msgstr ""
-#: ../raster/r.reclass/parse.c:59
-msgid "Can't have null on the left-hand side of the rule"
+#: ../raster/r.out.gdal/export_band.c:166
+#, c-format
+msgid ""
+"Input raster map contains cells with NULL-value (no-data). The value %g will "
msgstr ""
-#: ../raster/r.reclass/parse.c:88 ../raster/r.reclass/parse.c:100
-msgid "Can't have null on the right-hand side of the rule"
+#: ../raster/r.out.gdal/export_band.c:176
+#, c-format
+msgid ""
+"The default nodata value is present in rasterband <%s> and would lead to "
+"data loss. Please specify a custom nodata value with the %s parameter."
msgstr ""
-#: ../raster/r.reclass/parse.c:196
+#: ../raster/r.out.gdal/export_band.c:183
#, c-format
-msgid "%f rounded up to %d\n"
-msgstr ""
-#: ../raster/r.reclass/main.c:51 ../raster/r.recode/main.c:50
-#: ../vector/v.reclass/main.c:68
-#, fuzzy
-msgid "reclassification"
-msgstr "출력할 격자지도"
-#: ../raster/r.reclass/main.c:52
-#, fuzzy
-msgid "Reclassify raster map based on category values."
-msgstr "출력할 격자지도"
-#: ../raster/r.reclass/main.c:54
msgid ""
-"Creates a new raster map whose category values are based upon a "
-"reclassification of the categories in an existing raster map."
+"The user given nodata value %g is present in rasterband <%s> and would lead "
+"to data loss. Please specify a different nodata value with the %s parameter."
msgstr ""
-#: ../raster/r.reclass/main.c:59
+#: ../raster/r.out.gdal/export_band.c:228
#, fuzzy
-msgid "Name of raster map to be reclassified"
+msgid "Unable to get raster band"
msgstr "출력할 격자지도"
-#: ../raster/r.reclass/main.c:65
-msgid "File containing reclass rules"
-msgstr ""
-#: ../raster/r.reclass/main.c:72 ../raster/r.clump/main.c:75
-#: ../raster/r.recode/main.c:67 ../raster/r.neighbors/main.c:221
+#: ../raster/r.out.gdal/export_band.c:381
+#: ../raster/r.out.gdal/export_band.c:410
+#: ../raster/r.out.gdal/export_band.c:439
#, fuzzy
-msgid "Title for output raster map"
+msgid "Unable to write GDAL raster file"
msgstr "출력할 격자지도"
-#: ../raster/r.reclass/main.c:83
-msgid "Input map can NOT be the same as output map"
+#: ../raster/r.out.gdal/export_band.c:462
+#: ../raster/r.out.gdal/export_band.c:474
+#: ../raster/r.out.gdal/export_band.c:487
+#: ../raster/r.out.gdal/export_band.c:500
+#: ../raster/r.out.gdal/export_band.c:512
+#: ../raster/r.out.gdal/export_band.c:525
+#: ../raster/r.out.gdal/export_band.c:539 ../raster/r.out.gdal/main.c:673
+#: ../raster/r.out.gdal/main.c:685 ../raster/r.out.gdal/main.c:698
+#: ../raster/r.out.gdal/main.c:711 ../raster/r.out.gdal/main.c:723
+#: ../raster/r.out.gdal/main.c:736
+msgid "Selected GDAL datatype does not cover data range."
msgstr ""
-#: ../raster/r.reclass/main.c:89
-#, fuzzy, c-format
-msgid "Cannot open rules file <%s>"
-msgstr "출력할 격자지도"
-#: ../raster/r.reclass/main.c:103
+#: ../raster/r.out.gdal/export_band.c:463
+#: ../raster/r.out.gdal/export_band.c:475
+#: ../raster/r.out.gdal/export_band.c:488
+#: ../raster/r.out.gdal/export_band.c:501 ../raster/r.out.gdal/main.c:674
+#: ../raster/r.out.gdal/main.c:686 ../raster/r.out.gdal/main.c:699
+#: ../raster/r.out.gdal/main.c:712
#, c-format
-msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
+msgid "GDAL datatype: %s, range: %d - %d"
msgstr ""
-#: ../raster/r.reclass/main.c:105
-#, c-format
-msgid "FCELL: Data range is %.7g to %.7g\n"
-msgstr ""
-#: ../raster/r.reclass/main.c:108
-#, c-format
-msgid "DCELL: Data range is %.15g to %.15g\n"
-msgstr ""
-#: ../raster/r.reclass/main.c:111
+#: ../raster/r.out.gdal/export_band.c:466
+#: ../raster/r.out.gdal/export_band.c:478
+#: ../raster/r.out.gdal/export_band.c:491
+#: ../raster/r.out.gdal/export_band.c:504
+#: ../raster/r.out.gdal/export_band.c:516
+#: ../raster/r.out.gdal/export_band.c:529
+#: ../raster/r.out.gdal/export_band.c:543
#, fuzzy, c-format
-msgid "CELL: Data range is %ld to %ld\n"
+msgid "Raster map <%s> range: %g - %g"
msgstr "출력할 격자지도"
-#: ../raster/r.reclass/main.c:119
+#: ../raster/r.out.gdal/export_band.c:513 ../raster/r.out.gdal/main.c:724
#, c-format
-msgid "Illegal reclass rule -"
+msgid "GDAL datatype: %s, range: %u - %u"
msgstr ""
-#: ../raster/r.reclass/main.c:120
+#: ../raster/r.out.gdal/export_band.c:526
+#: ../raster/r.out.gdal/export_band.c:540 ../raster/r.out.gdal/main.c:737
#, c-format
-msgid " ignored\n"
+msgid "GDAL datatype: %s, range: %g - %g"
msgstr ""
-#: ../raster/r.reclass/main.c:123
-msgid " - invalid reclass rule"
-msgstr ""
-#: ../raster/r.reclass/main.c:139
+#: ../raster/r.out.gdal/main.c:50
#, c-format
-msgid "No rules specified. Raster map <%s> not created"
+msgid "Supported formats:\n"
msgstr ""
-#: ../raster/r.reclass/main.c:142 ../raster/r.recode/main.c:99
-#: ../raster/r.quant/main.c:183
-msgid "No rules specified"
+#: ../raster/r.out.gdal/main.c:135
+msgid "Exports GRASS raster maps into GDAL supported formats."
msgstr ""
-#: ../raster/r.out.mpeg/write.c:81 ../raster/r.out.mpeg/write.c:178
-msgid "Size mismatch error!"
+#: ../raster/r.out.gdal/main.c:141
+msgid "List supported output formats"
msgstr ""
-#: ../raster/r.out.mpeg/write.c:139 ../raster/r.out.mpeg/write.c:181
-msgid "Unable to open output file"
-msgstr ""
-#: ../raster/r.out.mpeg/write.c:215
-msgid "Unable to create temporary files."
-msgstr ""
-#: ../raster/r.out.mpeg/main.c:104
+#: ../raster/r.out.gdal/main.c:147
#, fuzzy
-msgid "animation"
+msgid "Do not write GDAL standard colortable"
msgstr "출력할 격자지도"
-#: ../raster/r.out.mpeg/main.c:107
+#: ../raster/r.out.gdal/main.c:148
#, fuzzy
-msgid "Converts raster map series to MPEG movie."
+msgid "Only applicable to Byte or UInt16 data types"
msgstr "출력할 격자지도"
-#: ../raster/r.out.mpeg/main.c:115
-#, fuzzy, c-format
-msgid "Name of input raster map(s) for view no.%d"
+#: ../raster/r.out.gdal/main.c:149 ../raster/r.out.gdal/main.c:155
+#: ../raster/r.out.gdal/main.c:202 ../raster/r.out.gdal/main.c:213
+#: ../raster/r.out.gdal/main.c:224 ../raster/r.out.gdal/main.c:237
+#: ../vector/v.out.ogr/args.c:51 ../vector/v.out.ogr/args.c:62
+#: ../vector/v.out.ogr/args.c:72 ../vector/v.out.ogr/args.c:82
+#: ../vector/v.out.ogr/args.c:97 ../vector/v.out.ogr/args.c:110
+#: ../vector/v.out.ogr/args.c:117 ../vector/v.out.ogr/args.c:123
+#: ../vector/v.out.ogr/args.c:130 ../vector/v.out.postgis/args.c:38
+#: ../vector/v.out.postgis/args.c:48 ../vector/v.out.postgis/args.c:61
+#: ../vector/v.out.postgis/args.c:67 ../vector/v.out.postgis/args.c:73
+#: ../vector/v.out.postgis/args.c:79
+msgid "Creation"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:153
+#, fuzzy
+msgid "Do not write non-standard metadata"
msgstr "출력할 격자지도"
-#: ../raster/r.out.mpeg/main.c:117
-msgid "Views"
+#: ../raster/r.out.gdal/main.c:154
+msgid "Enhances compatibility with other GIS software"
msgstr ""
-#: ../raster/r.out.mpeg/main.c:131
-msgid "Quality factor (1 = highest quality, lowest compression)"
-msgstr ""
+#: ../raster/r.out.gdal/main.c:159
+#, fuzzy
+msgid "Write raster attribute table"
+msgstr "출력할 격자지도"
-#: ../raster/r.out.mpeg/main.c:136
-msgid "Convert on the fly, uses less disk space"
-msgstr ""
+#: ../raster/r.out.gdal/main.c:160
+#, fuzzy
+msgid "Some export formats may not be supported"
+msgstr "출력할 격자지도"
-#: ../raster/r.out.mpeg/main.c:137
-msgid "Requires r.out.ppm with stdout option"
+#: ../raster/r.out.gdal/main.c:164
+msgid "Force raster export despite any warnings of data loss"
msgstr ""
-#: ../raster/r.out.mpeg/main.c:160
-msgid "Either mpeg_encode or ppmtompeg must be installed"
+#: ../raster/r.out.gdal/main.c:165
+msgid "Overrides nodata safety check"
msgstr ""
-#: ../raster/r.out.mpeg/main.c:291
-#, fuzzy, c-format
-msgid "Unable to read color table for <%s>"
+#: ../raster/r.out.gdal/main.c:168
+#, fuzzy
+msgid "Name of raster map (or group) to export"
msgstr "출력할 격자지도"
-#: ../raster/r.out.mpeg/main.c:341 ../raster/r.out.mpeg/main.c:374
-msgid "mpeg_encode ERROR"
+#: ../raster/r.out.gdal/main.c:171
+#, fuzzy
+msgid "Name for output raster file"
+msgstr "출력할 격자지도"
+#: ../raster/r.out.gdal/main.c:177
+msgid "Raster data format to write (case sensitive, see also -l flag)"
msgstr ""
-#: ../raster/r.out.mpeg/main.c:417
-msgid "Error reading wildcard"
+#: ../raster/r.out.gdal/main.c:208
+msgid "Creation option(s) to pass to the output format driver"
msgstr ""
-#: ../raster/r.fill.dir/resolve.c:136
-#, c-format
-msgid "Downward pass %d"
+#: ../raster/r.out.gdal/main.c:210
+msgid "In the form of \"NAME=VALUE\", separate multiple entries with a comma"
msgstr ""
-#: ../raster/r.fill.dir/resolve.c:173
-#, c-format
-msgid "Upward pass %d"
+#: ../raster/r.out.gdal/main.c:218
+msgid "Metadata key(s) and value(s) to include"
msgstr ""
-#: ../raster/r.fill.dir/main.c:88
-msgid "sink"
+#: ../raster/r.out.gdal/main.c:220
+msgid ""
+"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
+"Not supported by all output format drivers."
msgstr ""
-#: ../raster/r.fill.dir/main.c:89
-msgid "fill sinks"
+#: ../raster/r.out.gdal/main.c:230
+msgid "Assign a specified nodata value to output bands"
msgstr ""
-#: ../raster/r.fill.dir/main.c:90
-#, fuzzy
-msgid "depressions"
-msgstr "출력할 격자지도"
-#: ../raster/r.fill.dir/main.c:92
+#: ../raster/r.out.gdal/main.c:232
msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation raster map."
+"If given, the nodata value is always written to metadata even if there are "
+"no NULL cells in the input band (enhances output compatibility)."
msgstr ""
-#: ../raster/r.fill.dir/main.c:99
-#, fuzzy
-msgid "Name for output depressionless elevation raster map"
+#: ../raster/r.out.gdal/main.c:264
+#, fuzzy, c-format
+msgid "Raster map or group <%s> not found"
msgstr "출력할 격자지도"
-#: ../raster/r.fill.dir/main.c:103
-#, fuzzy
-msgid ""
-"Name for output flow direction map for depressionless elevation raster map"
+#: ../raster/r.out.gdal/main.c:268
+#, fuzzy, c-format
+msgid "No raster maps in group <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.fill.dir/main.c:108
-#, fuzzy
-msgid "Name for output raster map of problem areas"
+#: ../raster/r.out.gdal/main.c:282
+#, fuzzy, c-format
+msgid "Unable to get <%s> driver"
msgstr "출력할 격자지도"
-#: ../raster/r.fill.dir/main.c:115
-msgid "Aspect direction format"
+#: ../raster/r.out.gdal/main.c:288
+#, c-format
+msgid ""
+"Driver <%s> does not support direct writing. Using MEM driver for "
+"intermediate dataset."
msgstr ""
-#: ../raster/r.fill.dir/main.c:121
-msgid "Find unresolved areas only"
-msgstr ""
-#: ../raster/r.fill.dir/main.c:127
-#, fuzzy, c-format
-msgid "The '%c' flag requires '%s'to be specified"
+#: ../raster/r.out.gdal/main.c:293
+#, fuzzy
+msgid "Unable to get in-memory raster driver"
msgstr "출력할 격자지도"
-#: ../raster/r.fill.dir/main.c:148
-msgid "Direction map is D8 resolution, i.e. 45 degrees"
+#: ../raster/r.out.gdal/main.c:297
+#, c-format
+msgid "Driver <%s> does not support creating rasters"
msgstr ""
-#: ../raster/r.fill.dir/main.c:190
-#, fuzzy
-msgid "Reading input elevation raster map..."
+#: ../raster/r.out.gdal/main.c:372
+#, fuzzy, c-format
+msgid "Could not read data range of raster <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.fill.dir/main.c:200
-msgid "Filling sinks..."
+#: ../raster/r.out.gdal/main.c:429
+#, c-format
+msgid "Exporting to GDAL data type: %s"
msgstr ""
-#: ../raster/r.fill.dir/main.c:204
-msgid "Determining flow directions for ambiguous cases..."
+#: ../raster/r.out.gdal/main.c:444
+msgid "Raster export would result in complete data loss, aborting."
msgstr ""
-#: ../raster/r.fill.dir/main.c:217
-msgid "Repeat to get the final directions..."
+#: ../raster/r.out.gdal/main.c:455
+#, c-format
+msgid ""
+"Precision loss: Raster map <%s> of type %s to be exported as %s. This can be "
+"avoided by using %s."
msgstr ""
-#: ../raster/r.fill.dir/wtrshed.c:95
+#: ../raster/r.out.gdal/main.c:466
#, c-format
-msgid "Watershed pass %d"
+msgid ""
+"Precision loss: The range of <%s> can not be accurately preserved with GDAL "
+"datatype Float32. This can be avoided by exporting to Int32 or Float64."
msgstr ""
-#: ../raster/r.fill.dir/dopolys.c:84
+#: ../raster/r.out.gdal/main.c:474
#, c-format
-msgid "Found %d unresolved area"
-msgid_plural "Found %d unresolved areas"
-msgstr[0] ""
-msgstr[1] ""
+msgid ""
+"Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. "
+"This can be avoided by using Float64"
+msgstr ""
-#: ../raster/r.resamp.stats/main.c:261
+#: ../raster/r.out.gdal/main.c:483
#, fuzzy
-msgid "Resamples raster map layers to a coarser grid using aggregation."
+msgid "Forcing raster export"
msgstr "출력할 격자지도"
-#: ../raster/r.resamp.stats/main.c:271
-msgid "Aggregation method"
+#: ../raster/r.out.gdal/main.c:485
+#, c-format
+msgid "Raster export aborted. To override data loss check, use the -%c flag"
msgstr ""
-#: ../raster/r.resamp.stats/main.c:289
-msgid "Weight according to area (slower)"
+#: ../raster/r.out.gdal/main.c:500 ../raster/r.out.gdal/main.c:529
+#: ../raster/r.out.gdal/main.c:533
+#, fuzzy
+msgid "Raster export aborted."
+msgstr "출력할 격자지도"
+#: ../raster/r.out.gdal/main.c:510
+msgid "Checking GDAL data type and nodata value..."
msgstr ""
-#: ../raster/r.info/main.c:73 ../vector/v.info/main.c:41
-msgid "history"
-msgstr "이력"
+#: ../raster/r.out.gdal/main.c:513
+#, fuzzy, c-format
+msgid "Checking options for raster map <%s> (band %d)..."
+msgstr "출력할 격자지도"
-#: ../raster/r.info/main.c:75
-msgid "Outputs basic information about a raster map."
-msgstr "격자지도에 대한 기본적인 정보를 출력합니다."
-#: ../raster/r.info/main.c:81
+#: ../raster/r.out.gdal/main.c:527
#, fuzzy
-msgid "Print raster array information in shell script style"
+msgid "Forcing raster export."
msgstr "출력할 격자지도"
-#: ../raster/r.info/main.c:85
+#: ../raster/r.out.gdal/main.c:558
#, fuzzy
-msgid "Print range in shell script style"
+msgid "Unable to create dataset using memory raster driver"
msgstr "출력할 격자지도"
-#: ../raster/r.info/main.c:89
-#, fuzzy
-msgid "Print extended metadata information in shell script style"
-msgstr "확장 메타자료를 셸스크립트 형식으로 출력합니다"
-#: ../raster/r.info/main.c:99
+#: ../raster/r.out.gdal/main.c:567
#, fuzzy, c-format
-msgid "Flags -%c and -%c/%c/%c are mutually exclusive"
+msgid "Unable to create <%s> dataset using <%s> driver"
+msgstr "출력할 격자지도"
-#: ../raster/r.info/main.c:127
+#: ../raster/r.out.gdal/main.c:582
#, fuzzy
-msgid "Unable to read range file"
+msgid "Unable to set geo transform"
msgstr "출력할 격자지도"
-#: ../raster/r.compress/main.c:66
+#: ../raster/r.out.gdal/main.c:590
#, fuzzy
-msgid "compression"
+msgid "Unable to set projection"
msgstr "출력할 격자지도"
-#: ../raster/r.compress/main.c:67
-msgid "Compresses and decompresses raster maps."
-msgstr ""
+#: ../raster/r.out.gdal/main.c:618
+#, fuzzy, c-format
+msgid "Exporting raster data to %s format..."
+msgstr "출력할 격자지도"
-#: ../raster/r.compress/main.c:70
-msgid "Name of existing raster map(s)"
-msgstr ""
+#: ../raster/r.out.gdal/main.c:621
+#, fuzzy, c-format
+msgid "Exporting raster map <%s> (band %d)..."
+msgstr "출력할 격자지도"
-#: ../raster/r.compress/main.c:74
-msgid "Uncompress the map"
-msgstr ""
+#: ../raster/r.out.gdal/main.c:634
+#, fuzzy, c-format
+msgid "Unable to export raster map <%s>"
+msgstr "출력할 격자지도"
-#: ../raster/r.compress/main.c:78
-#, fuzzy
-msgid "Print compression information and data type of input map(s)"
+#: ../raster/r.out.gdal/main.c:650
+#, fuzzy, c-format
+msgid "Unable to create raster map <%s> using driver <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.compress/main.c:120 ../raster/r.compress/main.c:300
+#: ../raster/r.out.gdal/main.c:677 ../raster/r.out.gdal/main.c:689
+#: ../raster/r.out.gdal/main.c:702 ../raster/r.out.gdal/main.c:715
+#: ../raster/r.out.gdal/main.c:727 ../raster/r.out.gdal/main.c:740
#, fuzzy, c-format
-msgid "Raster map <%s> is not in the current mapset"
+msgid "Range to be exported: %g - %g"
msgstr "출력할 격자지도"
-#: ../raster/r.compress/main.c:126
+#: ../raster/r.out.gdal/main.c:764 ../raster/r.out.gdal/main.c:777
+#: ../raster/r.out.gdal/main.c:791 ../raster/r.out.gdal/main.c:804
+#: ../raster/r.out.gdal/main.c:819
#, c-format
-msgid "<%s> is a reclass file of map <%s> in mapset <%s> - can't uncompress"
+msgid ""
+"Mismatch between metadata nodata value and actual nodata value in exported "
+"raster: specified nodata value %g gets converted to %d by selected GDAL "
+"datatype."
msgstr ""
-#: ../raster/r.compress/main.c:128
+#: ../raster/r.out.gdal/main.c:767 ../raster/r.out.gdal/main.c:794
+#: ../raster/r.out.gdal/main.c:822
#, c-format
-msgid "<%s> is a reclass file of map <%s> in mapset <%s> - can't compress"
+msgid "GDAL datatype: %s, valid range: %d - %d"
msgstr ""
-#: ../raster/r.compress/main.c:133
+#: ../raster/r.out.gdal/main.c:780 ../raster/r.out.gdal/main.c:807
#, c-format
-msgid "<%s> is a GDAL-linked map - can't (un)compress"
+msgid "GDAL datatype: %s, valid range: %u - %u"
msgstr ""
-#: ../raster/r.compress/main.c:207
-msgid "DONE: uncompressed file is %lu %s (%.2f%) smaller"
+#: ../raster/r.out.gdal/main.c:833
+#, c-format
+msgid ""
+"raster: specified nodata value %g gets converted to %g by selected GDAL "
+"datatype."
msgstr ""
-#: ../raster/r.compress/main.c:208
-msgid "DONE: compressed file is %lu %s (%.2f%) smaller"
+#: ../raster/r.out.gdal/main.c:836
+#, c-format
+msgid "GDAL datatype: %s, valid range: %g - %g"
msgstr ""
-#: ../raster/r.compress/main.c:212
-msgid "DONE: uncompressed file is %lu %s (%.2f%) larger"
-msgstr ""
-#: ../raster/r.compress/main.c:213
-msgid "DONE: compressed file is %lu %s (%.2f%) larger"
-msgstr ""
-#: ../raster/r.compress/main.c:216
+#: ../raster/r.out.gdal/attr.c:140 ../raster/r.out.gdal/attr.c:178
#, fuzzy
-msgid "same size"
-msgstr "계열"
-#: ../raster/r.compress/main.c:232
-#, fuzzy, c-format
-msgid "<%s> already uncompressed"
-msgstr "<%s>가 이미 존재합니다"
-#: ../raster/r.compress/main.c:235
-#, fuzzy, c-format
-msgid "Uncompressing <%s>"
+msgid "Failed to set raster attribute table"
msgstr "출력할 격자지도"
-#: ../raster/r.compress/main.c:243
-#, fuzzy, c-format
-msgid "Re-compressing <%s>"
+#: ../raster/r.in.gdal/main.c:93
+#, fuzzy
+msgid "Imports raster data into a GRASS raster map using GDAL library."
msgstr "출력할 격자지도"
-#: ../raster/r.compress/main.c:246
-#, fuzzy, c-format
-msgid "Compressing <%s>"
+#: ../raster/r.in.gdal/main.c:99
+#, fuzzy
+msgid "Name of raster file to be imported"
msgstr "출력할 격자지도"
-#: ../raster/r.compress/main.c:304
-#, c-format
-msgid "<%s> is a GDAL-linked map"
+#: ../raster/r.in.gdal/main.c:108
+msgid "Band(s) to select (default is all bands)"
msgstr ""
-#: ../raster/r.compress/main.c:308
-#, fuzzy, c-format
-msgid "<%s> is a reclass file of map <%s> in mapset <%s>"
-msgstr "<%s>가 지도세트 <%s> 안에 이미 존재합니다."
+#: ../raster/r.in.gdal/main.c:123
+#, fuzzy
+msgid "Name of GCPs target location"
+msgstr "출력할 격자지도"
-#: ../raster/r.compress/main.c:327
-#, c-format
-msgid "<%s> is uncompressed (method %i: %s). Data type: %s"
+#: ../raster/r.in.gdal/main.c:125
+msgid ""
+"Name of location to create or to read projection from for GCPs transformation"
msgstr ""
-#: ../raster/r.compress/main.c:334
-#, c-format
-msgid "<%s> is compressed (method %i: %s). Data type: %s"
-msgstr ""
+#: ../raster/r.in.gdal/main.c:141
+#, fuzzy
+msgid "Offset to be added to band numbers"
+msgstr "출력할 격자지도"
-#: ../raster/r.solute.transport/main.c:59
-msgid "The initial concentration in [kg/m^3]"
+#: ../raster/r.in.gdal/main.c:142
+msgid "If 0, no offset is added and the first band is 1"
msgstr ""
-#: ../raster/r.solute.transport/main.c:63
-msgid "The piezometric head in [m]"
+#: ../raster/r.in.gdal/main.c:150
+msgid ""
+"Zero-padding of band number by filling with leading zeros up to given number"
msgstr ""
-#: ../raster/r.solute.transport/main.c:68
-msgid "The x-part of the hydraulic conductivity tensor in [m/s]"
+#: ../raster/r.in.gdal/main.c:151
+msgid "If 0, length will be adjusted to 'offset' number without leading zeros"
msgstr ""
-#: ../raster/r.solute.transport/main.c:73
-msgid "The y-part of the hydraulic conductivity tensor in [m/s]"
-msgstr ""
+#: ../raster/r.in.gdal/main.c:157
+#, fuzzy
+msgid "Name of the output file that contains the imported map names"
+msgstr "출력할 격자지도"
-#: ../raster/r.solute.transport/main.c:79
-msgid ""
-"The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - "
-"dirichlet- and 3 - transfer boundary condition"
+#: ../raster/r.in.gdal/main.c:164 ../vector/v.in.ogr/main.c:218
+#: ../vector/v.in.lidar/main.c:270
+msgid "Name for new location to create"
msgstr ""
-#: ../raster/r.solute.transport/main.c:85
-msgid "The x-part of the diffusion tensor in [m^2/s]"
-msgstr ""
+#: ../raster/r.in.gdal/main.c:171
+#, fuzzy
+msgid "File prefix for raster attribute tables"
+msgstr "출력할 격자지도"
-#: ../raster/r.solute.transport/main.c:90
-msgid "The y-part of the diffusion tensor in [m^2/s]"
+#: ../raster/r.in.gdal/main.c:172
+msgid "The band number and \".csv\" will be appended to the file prefix"
msgstr ""
-#: ../raster/r.solute.transport/main.c:94
-#: ../raster/r.solute.transport/main.c:102
-#: ../raster/r.solute.transport/main.c:138
-#: ../raster/r.solute.transport/main.c:145
-msgid "Water flow"
-msgstr ""
+#: ../raster/r.in.gdal/main.c:185 ../vector/v.in.ogr/main.c:291
+#, fuzzy
+msgid "Perform projection check only and exit"
+msgstr "출력할 격자지도"
-#: ../raster/r.solute.transport/main.c:96
-msgid "Groundwater sources and sinks in [m^3/s]"
+#: ../raster/r.in.gdal/main.c:209
+msgid "Keep band numbers instead of using band color names"
msgstr ""
-#: ../raster/r.solute.transport/main.c:103
+#: ../raster/r.in.gdal/main.c:214
msgid ""
-"Concentration sources and sinks bounded to a water source or sink in [kg/s]"
+"Create the location specified by the \"location\" parameter and exit. Do not "
+"import the raster file."
msgstr ""
-#: ../raster/r.solute.transport/main.c:112
-msgid ""
-"Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical "
-"reaction)"
+#: ../raster/r.in.gdal/main.c:219
+#, fuzzy
+msgid "Print number of bands and exit"
+msgstr "출력할 격자지도"
+#: ../raster/r.in.gdal/main.c:247
+msgid "You have to specify a target location different from output location"
msgstr ""
-#: ../raster/r.solute.transport/main.c:117
-msgid "Retardation factor [-]"
+#: ../raster/r.in.gdal/main.c:251
+msgid "You need to specify valid location name."
msgstr ""
-#: ../raster/r.solute.transport/main.c:121
-msgid "Effective porosity [-]"
+#: ../raster/r.in.gdal/main.c:255
+msgid "The '-l' flag only works in Lat/Lon locations"
msgstr ""
-#: ../raster/r.solute.transport/main.c:125
-msgid "Top surface of the aquifer in [m]"
+#: ../raster/r.in.gdal/main.c:258
+msgid "The number of digits for band numbering must be equal or greater than 0"
msgstr ""
-#: ../raster/r.solute.transport/main.c:129
-msgid "Bottom surface of the aquifer in [m]"
+#: ../raster/r.in.gdal/main.c:277
+#, c-format
+msgid "Using memory cache size: %.1f MiB"
msgstr ""
-#: ../raster/r.solute.transport/main.c:132
+#: ../raster/r.in.gdal/main.c:319
+#, fuzzy, c-format
+msgid "Unable to open datasource <%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.in.gdal/main.c:330
+#, c-format
msgid ""
-"The resulting concentration of the numerical solute transport calculation "
-"will be written to this map. [kg/m^3]"
+"Input seems to be NOAA/AVHRR data which needs to be georeferenced with thin "
+"plate spline transformation (%s or %s)."
msgstr ""
-#: ../raster/r.solute.transport/main.c:140
+#: ../raster/r.in.gdal/main.c:369
msgid ""
-"Calculate and store the groundwater filter velocity vector part in x "
-"direction [m/s]\n"
+"Input raster map is flipped or rotated - cannot import. You may use "
+"'gdalwarp' to transform the map to North-up."
msgstr ""
-#: ../raster/r.solute.transport/main.c:147
+#: ../raster/r.in.gdal/main.c:410
msgid ""
-"Calculate and store the groundwater filter velocity vector part in y "
+"Map bounds have been constrained to geographic coordinates. You will almost "
+"certainly want to check map bounds and resolution with r.info and reset them "
+"with r.region before going any further."
msgstr ""
-#: ../raster/r.solute.transport/main.c:161
-msgid "The longditudinal dispersivity length. [m]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:169
-msgid "The transversal dispersivity length. [m]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:177
+#: ../raster/r.in.gdal/main.c:430 ../raster/r.in.gdal/main.c:819
+#: ../vector/v.in.ogr/main.c:575 ../vector/v.in.lidar/main.c:505
msgid ""
-"Use this number of time loops if the CFL flag is off. The timestep will "
-"become dt/loops."
+"Unable to convert input map projection to GRASS format; cannot create new "
+"location."
msgstr ""
-#: ../raster/r.solute.transport/main.c:187
-msgid "Set the flow stabilizing scheme (full or exponential upwinding)."
-msgstr ""
+#: ../raster/r.in.gdal/main.c:436 ../raster/r.in.gdal/main.c:843
+#: ../vector/v.in.ogr/main.c:581 ../vector/v.in.lidar/main.c:511
+#, fuzzy, c-format
+msgid "Unable to create new location <%s>"
+msgstr "출력할 격자지도"
-#: ../raster/r.solute.transport/main.c:199
-msgid "Use the Courant-Friedrichs-Lewy criteria for time step calculation"
-msgstr ""
+#: ../raster/r.in.gdal/main.c:577
+#, fuzzy, c-format
+msgid "Proceeding with import of %d raster bands..."
+msgstr "출력할 격자지도"
-#: ../raster/r.solute.transport/main.c:231
+#: ../raster/r.in.gdal/main.c:634
#, fuzzy
-msgid "solute transport"
+msgid "Unable to open the map names output text file"
msgstr "출력할 격자지도"
-#: ../raster/r.solute.transport/main.c:233
-msgid ""
-"Numerical calculation program for transient, confined and unconfined solute "
-"transport in two dimensions"
-msgstr ""
+#: ../raster/r.in.gdal/main.c:665
+#, fuzzy, c-format
+msgid "Unable to get raster band number %d"
+msgstr "출력할 격자지도"
-#: ../raster/r.solute.transport/main.c:258
-msgid "The direct LU solver do not work with sparse matrices"
-msgstr ""
+#: ../raster/r.in.gdal/main.c:742
+#, fuzzy, c-format
+msgid "Copying %d GCPS in points file for <%s>"
+msgstr "출력할 격자지도"
-#: ../raster/r.solute.transport/main.c:260
-msgid "The direct Gauss solver do not work with sparse matrices"
+#: ../raster/r.in.gdal/main.c:750
+msgid "GCPs have the following OpenGIS WKT Coordinate System:"
msgstr ""
-#: ../raster/r.solute.transport/main.c:370
+#: ../raster/r.in.gdal/main.c:773
+#, fuzzy
+msgid "Re-projecting GCPs table:"
+msgstr "출력할 격자지도"
+#: ../raster/r.in.gdal/main.c:774
#, c-format
-msgid "The Courant-Friedrichs-Lewy criteria is %g it should be within [0:1]"
+msgid "* Input projection for GCP table: %s"
msgstr ""
-#: ../raster/r.solute.transport/main.c:371
+#: ../raster/r.in.gdal/main.c:776
#, c-format
-msgid "The largest stable time step is %g"
+msgid "* Output projection for GCP table: %s"
msgstr ""
-#: ../raster/r.solute.transport/main.c:380
-#, fuzzy, c-format
-msgid "Number of inner loops is %g"
-msgstr "출력할 격자지도"
-#: ../raster/r.solute.transport/main.c:381
+#: ../raster/r.in.gdal/main.c:797
#, c-format
-msgid "Time step for each loop %g"
+msgid "Error in pj_do_proj (can't re-projection GCP %i)"
msgstr ""
-#: ../raster/r.solute.transport/main.c:385
+#: ../raster/r.in.gdal/main.c:852
#, c-format
msgid ""
-"The time step is to large: %gs. The largest time step should be of size %gs."
+"The target for the output group <%s> has been set to location <%s>, mapset "
+"<PERMANENT>."
msgstr ""
-#: ../raster/r.solute.transport/main.c:397
-#, c-format
-msgid "Time step %i with time sum %g"
-msgstr ""
+#: ../raster/r.in.gdal/main.c:923
+#, fuzzy
+msgid "Unable to translate projection key values of input GCPs"
+msgstr "출력할 격자지도"
-#: ../raster/r.solute.transport/main.c:543
-msgid "Could not create and solve the linear equation system"
-msgstr ""
+#: ../raster/r.in.gdal/main.c:939
+#, fuzzy
+msgid "Unable to get projection info of target location"
+msgstr "출력할 격자지도"
-#: ../raster/r.what.color/main.c:91
-msgid "Queries colors for a raster map layer."
-msgstr ""
+#: ../raster/r.in.gdal/main.c:941
+#, fuzzy
+msgid "Unable to get projection units of target location"
+msgstr "출력할 격자지도"
-#: ../raster/r.what.color/main.c:99
+#: ../raster/r.in.gdal/main.c:943
#, fuzzy
-msgid "Name of existing raster map to query colors"
+msgid "Unable to get projection key values of target location"
msgstr "출력할 격자지도"
-#: ../raster/r.what.color/main.c:106
-msgid "Values to query colors for"
-msgstr ""
+#: ../raster/r.in.gdal/main.c:947 ../vector/v.rectify/target.c:40
+#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:31
+#: ../imagery/i.rectify/target.c:32
+#, fuzzy, c-format
+msgid "Mapset <%s> in target location <%s> - "
+msgstr "출력할 격자지도"
-#: ../raster/r.what.color/main.c:113
-msgid "Output format (printf-style)"
-msgstr ""
+#: ../raster/r.in.gdal/main.c:982
+#, fuzzy, c-format
+msgid "Importing raster map <%s>..."
+msgstr "출력할 격자지도"
-#: ../raster/r.what.color/main.c:117
-msgid "Read values from stdin"
+#: ../raster/r.in.gdal/main.c:1377 ../raster/r.in.gdal/main.c:1434
+msgid "Inconsistent color rules in RAT"
msgstr ""
-#: ../raster/r.what.color/main.c:123
-msgid "Either \"-i\" or \"value=\" must be given"
-msgstr ""
+#: ../raster/r.in.gdal/main.c:1491
+#, fuzzy, c-format
+msgid "Setting grey color table for <%s> (8bit, full range)"
+msgstr "출력할 격자지도"
-#: ../raster/r.sunhours/solpos00.c:994 ../raster/r.sunmask/solpos00.c:950
-#, c-format
-msgid "S_decode ==> Please fix the year: %d [1950-2050]"
-msgstr ""
+#: ../raster/r.in.gdal/main.c:1505
+#, fuzzy, c-format
+msgid "Setting grey color table for <%s> (16bit, image range)"
+msgstr "출력할 격자지도"
-#: ../raster/r.sunhours/solpos00.c:997 ../raster/r.sunmask/solpos00.c:953
-#, c-format
-msgid "S_decode ==> Please fix the month: %d"
-msgstr ""
+#: ../raster/r.in.gdal/main.c:1607
+#, fuzzy, c-format
+msgid "Unable to open file <%s>: %s."
+msgstr "출력할 격자지도"
-#: ../raster/r.sunhours/solpos00.c:999 ../raster/r.sunmask/solpos00.c:955
-#, c-format
-msgid "S_decode ==> Please fix the day-of-month: %d"
-msgstr ""
+#: ../raster/r.colors/stats.c:39
+#, fuzzy, c-format
+msgid "(%i/%i) Reading raster map <%s>..."
+msgstr "출력할 격자지도"
-#: ../raster/r.sunhours/solpos00.c:1002 ../raster/r.sunmask/solpos00.c:958
-#, c-format
-msgid "S_decode ==> Please fix the day-of-year: %d"
+#: ../raster/r.colors/stats.c:73
+msgid "Unable to use logarithmic scaling if range includes zero"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1005 ../raster/r.sunmask/solpos00.c:961
-#, c-format
-msgid "S_decode ==> Please fix the hour: %d"
+#: ../raster/r.colors/stats.c:118
+msgid "Error opening 3d raster map"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1007 ../raster/r.sunmask/solpos00.c:963
-#, c-format
-msgid "S_decode ==> Please fix the minute: %d"
-msgstr ""
+#: ../raster/r.colors/stats.c:125
+#, fuzzy, c-format
+msgid "(%i/%i) Reading map <%s>..."
+msgstr "출력할 격자지도"
-#: ../raster/r.sunhours/solpos00.c:1009 ../raster/r.sunmask/solpos00.c:965
+#: ../raster/r.colors/rules.c:40
#, c-format
-msgid "S_decode ==> Please fix the second: %d"
+msgid "Enter rules, \"end\" when done, \"help\" if you need it.\n"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1011 ../raster/r.sunmask/solpos00.c:967
+#: ../raster/r.colors/rules.c:49
#, c-format
-msgid "S_decode ==> Please fix the time zone: %f"
+msgid "fp: Data range is %s to %s\n"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1014 ../raster/r.sunmask/solpos00.c:970
+#: ../raster/r.colors/rules.c:53
#, c-format
-msgid "S_decode ==> Please fix the interval: %d"
+msgid "Data range is %ld to %ld\n"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1017 ../raster/r.sunmask/solpos00.c:973
+#: ../raster/r.colors/rules.c:64
#, c-format
-msgid "S_decode ==> Please fix the latitude: %f"
+msgid ""
+"Your color rules do not cover the whole range of data!\n"
+" (rules %f to %f but data %f to %f)"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1020 ../raster/r.sunmask/solpos00.c:976
+#: ../raster/r.colors/rules.c:105
#, c-format
-msgid "S_decode ==> Please fix the longitude: %f"
+msgid " val color\n"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1023 ../raster/r.sunmask/solpos00.c:979
+#: ../raster/r.colors/rules.c:106
#, c-format
-msgid "S_decode ==> Please fix the temperature: %f"
+msgid " n%% color\n"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1026 ../raster/r.sunmask/solpos00.c:982
+#: ../raster/r.colors/rules.c:107
#, c-format
-msgid "S_decode ==> Please fix the pressure: %f"
+msgid " nv color\n"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1028 ../raster/r.sunmask/solpos00.c:984
+#: ../raster/r.colors/rules.c:108
#, c-format
-msgid "S_decode ==> Please fix the tilt: %f"
+msgid " default color\n"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1030 ../raster/r.sunmask/solpos00.c:986
+#: ../raster/r.colors/rules.c:109
#, c-format
-msgid "S_decode ==> Please fix the aspect: %f"
+msgid "color can be one of:\n"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1032 ../raster/r.sunmask/solpos00.c:988
+#: ../raster/r.colors/rules.c:111
#, c-format
-msgid "S_decode ==> Please fix the shadowband width: %f"
+msgid "or an R:G:B triplet, e.g.: 0:127:255\n"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1035 ../raster/r.sunmask/solpos00.c:991
+#: ../raster/r.colors/rules.c:132
#, c-format
-msgid "S_decode ==> Please fix the shadowband radius: %f"
+msgid "bad rule (%s); rule not added"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1038 ../raster/r.sunmask/solpos00.c:994
+#: ../raster/r.colors/rules.c:134
#, c-format
-msgid "S_decode ==> Please fix the shadowband sky factor: %f"
+msgid "bad rule (%s): [%s]"
msgstr ""
-#: ../raster/r.sunhours/main.c:76
-msgid "Calculates solar elevation, solar azimuth, and sun hours."
+#: ../raster/r.colors/edit_colors.c:61
+#, fuzzy
+msgid "Creates/modifies the color table associated with a 3D raster map."
+msgstr "출력할 격자지도"
+#: ../raster/r.colors/edit_colors.c:65
+#, fuzzy
+msgid "Creates/modifies the color table associated with a raster map."
+msgstr "출력할 격자지도"
+#: ../raster/r.colors/edit_colors.c:75 ../raster/r.colors/edit_colors.c:87
+msgid "Map"
msgstr ""
-#: ../raster/r.sunhours/main.c:77
+#: ../raster/r.colors/edit_colors.c:81
+#, fuzzy
+msgid "Input file with one map name per line"
+msgstr "출력할 격자지도"
+#: ../raster/r.colors/edit_colors.c:83
msgid ""
-"Solar elevation: the angle between the direction of the geometric center of "
-"the sun's apparent disk and the (idealized) horizon. Solar azimuth: the "
-"angle from due north in clockwise direction."
+"Input map names can be defined in an input file in case a large amount of "
+"maps must be specified. This option is mutual exclusive to the map option."
msgstr ""
-#: ../raster/r.sunhours/main.c:83
+#: ../raster/r.colors/edit_colors.c:110
#, fuzzy
-msgid "Output raster map with solar elevation angle"
+msgid "\"-\" to read rules from stdin"
msgstr "출력할 격자지도"
-#: ../raster/r.sunhours/main.c:88
-#, fuzzy
-msgid "Output raster map with solar azimuth angle"
+#: ../raster/r.colors/edit_colors.c:229 ../raster/r.colors/edit_colors.c:262
+#, c-format
+msgid "%s map <%s> not found"
+msgstr "%s지도 <%s>를 찾지 못 했습니다"
+#: ../raster/r.colors/edit_colors.c:235
+#, c-format
+msgid "No %s map name found in input file <%s>"
+msgstr "입력파일 <%s> 안에 지도이름 %s를 찾지 못 했습니다"
+#: ../raster/r.colors/edit_colors.c:278
+#, fuzzy, c-format
+msgid "Unable to remove color table of %s map <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.sunhours/main.c:93
-#, fuzzy
-msgid "Output raster map with sunshine hours"
+#: ../raster/r.colors/edit_colors.c:280
+#, c-format
+msgid "Color table of %s map <%s> not found"
+msgstr "%s지도 <%s>의 색상표를 찾지 못 했습니다"
+#: ../raster/r.colors/edit_colors.c:302
+#, fuzzy, c-format
+msgid "Color table exists for %s map <%s>. Exiting."
msgstr "출력할 격자지도"
-#: ../raster/r.sunhours/main.c:94
-msgid "Sunshine hours require SOLPOS use and Greenwich standard time"
-msgstr ""
+#: ../raster/r.colors/edit_colors.c:358
+#, fuzzy, c-format
+msgid "Color table 'random' is not supported for floating point %s map"
+msgstr "출력할 격자지도"
-#: ../raster/r.sunhours/main.c:101
-msgid "Year"
-msgstr ""
+#: ../raster/r.colors/edit_colors.c:362
+#, fuzzy, c-format
+msgid "Color table 'grey.eq' is not supported for floating point %s map"
+msgstr "출력할 격자지도"
-#: ../raster/r.sunhours/main.c:109
-msgid "Month"
-msgstr ""
+#: ../raster/r.colors/edit_colors.c:368
+#, fuzzy, c-format
+msgid "Color table 'grey.log' is not supported for floating point %s map"
+msgstr "출력할 격자지도"
-#: ../raster/r.sunhours/main.c:110
-msgid "If not given, day is interpreted as day of the year"
+#: ../raster/r.colors/edit_colors.c:376 ../imagery/i.vi/main.c:544
+#, c-format
+msgid "Unknown color request '%s'"
msgstr ""
-#: ../raster/r.sunhours/main.c:118
-msgid "Day"
-msgstr ""
+#: ../raster/r.colors/edit_colors.c:386 ../vector/v.colors/make_colors.c:51
+#, fuzzy, c-format
+msgid "Unable to load rules file <%s>"
+msgstr "출력할 격자지도"
-#: ../raster/r.sunhours/main.c:126
-msgid "Hour"
-msgstr ""
+#: ../raster/r.colors/edit_colors.c:403 ../vector/v.colors/main.c:322
+#, fuzzy, c-format
+msgid "Unable to read color table for 3D raster map <%s>"
+msgstr "출력할 격자지도"
-#: ../raster/r.sunhours/main.c:135
-msgid "Minutes"
+#: ../raster/r.colors/edit_colors.c:447
+#, c-format
+msgid "Color table for %s map <%s> set to '%s'"
+msgstr "%s지도 <%s>를 위한 색상표가 '%s'로 설정되었습니다"
+#: ../raster/r.to.rast3/main.c:59 ../raster/r.to.rast3elev/main.c:136
+msgid "Could not close the map"
msgstr ""
-#: ../raster/r.sunhours/main.c:144
-msgid "Seconds"
+#: ../raster/r.to.rast3/main.c:79
+#, fuzzy
+msgid "2D raster maps which represent the slices"
+msgstr "출력할 격자지도"
+#: ../raster/r.to.rast3/main.c:84 ../raster/r.to.rast3elev/main.c:175
+msgid "The maximum tile size in kilo bytes. Default is 32KB."
msgstr ""
-#: ../raster/r.sunhours/main.c:151
-msgid "Time is local sidereal time, not Greenwich standard time"
+#: ../raster/r.to.rast3/main.c:93
+msgid "Use 3D raster mask (if exists) with output map"
msgstr ""
-#: ../raster/r.sunhours/main.c:155
-msgid "Do not use SOLPOS algorithm of NREL"
+#: ../raster/r.to.rast3/main.c:201
+msgid "Converts 2D raster map slices to one 3D raster volume map."
msgstr ""
-#: ../raster/r.sunhours/main.c:167
-msgid "No output requested, exiting."
+#: ../raster/r.to.rast3/main.c:213
+msgid "No output map"
msgstr ""
-#: ../raster/r.sunhours/main.c:193
-msgid "NREL SOLPOS algorithm uses Greenwich standard time."
+#: ../raster/r.to.rast3/main.c:230
+msgid ""
+"The 2D and 3D region settings are different. Using the 3D region settings to "
+"adjust the 2D region."
msgstr ""
-#: ../raster/r.sunhours/main.c:194 ../raster/r.sunhours/main.c:202
-msgid "Time will be interpreted as Greenwich standard time."
+#: ../raster/r.to.rast3/main.c:262
+#, c-format
+msgid "Open raster map %s - one time for each depth (%d/%d)"
msgstr ""
-#: ../raster/r.sunhours/main.c:200
-msgid "Time will be interpreted as local sidereal time."
+#: ../raster/r.to.rast3/main.c:275
+msgid "Input maps have to be from the same type. CELL, FCELL or DCELL!"
msgstr ""
-#: ../raster/r.sunhours/main.c:205
-msgid "Sunshine hours require NREL SOLPOS."
+#: ../raster/r.to.rast3/main.c:279 ../raster/r.to.rast3elev/main.c:457
+msgid "Creating 3D raster map"
msgstr ""
-#: ../raster/r.sunhours/main.c:210
-msgid "Current projection is x,y (undefined)."
+#: ../raster/r.to.rast3/main.c:291 ../raster/r.to.rast3elev/main.c:443
+#, fuzzy
+msgid "Error opening 3D raster map"
+msgstr "출력할 격자지도"
+#: ../raster/r.to.rast3/main.c:326 ../raster/r.to.rast3elev/main.c:501
+msgid "Error closing 3d raster map"
msgstr ""
-#: ../raster/r.sunhours/main.c:216
+#: ../raster/r.mfilter/getrow.c:23
#, fuzzy
-msgid "Cannot get projection info of current location"
+msgid "Error reading temporary file"
msgstr "출력할 격자지도"
-#: ../raster/r.sunhours/main.c:219
+#: ../raster/r.mfilter/main.c:60
#, fuzzy
-msgid "Cannot get projection units of current location"
+msgid "Performs raster map matrix filter."
msgstr "출력할 격자지도"
-#: ../raster/r.sunhours/main.c:222
+#: ../raster/r.mfilter/main.c:71
#, fuzzy
-msgid "Cannot get projection key values of current location"
+msgid "Path to filter file"
msgstr "출력할 격자지도"
-#: ../raster/r.sunhours/main.c:232 ../general/g.region/printwindow.c:257
-#: ../general/g.region/printwindow.c:510 ../general/g.region/printwindow.c:641
-msgid "Unable to update lat/long projection parameters"
+#: ../raster/r.mfilter/main.c:79
+msgid "Number of times to repeat the filter"
msgstr ""
-#: ../raster/r.sunhours/main.c:296 ../raster/r.sunhours/main.c:391
-#: ../raster/r.sunmask/g_solposition.c:127
-#: ../general/g.region/printwindow.c:275 ../general/g.region/printwindow.c:283
-#: ../general/g.region/printwindow.c:291 ../general/g.region/printwindow.c:299
-#: ../general/g.region/printwindow.c:528 ../general/g.region/printwindow.c:536
-#: ../general/g.region/printwindow.c:544 ../general/g.region/printwindow.c:552
-#: ../general/g.region/printwindow.c:670 ../general/g.region/printwindow.c:678
-#: ../general/g.region/printwindow.c:686 ../general/g.region/printwindow.c:694
-msgid "Error in pj_do_proj (projection of input coordinate pair)"
+#: ../raster/r.mfilter/main.c:80 ../raster/r.mfilter/main.c:99
+#: ../imagery/i.pca/main.c:109 ../imagery/i.pca/main.c:120
+msgid "Filter"
msgstr ""
-#: ../raster/r.sunhours/main.c:356
-#, fuzzy
-msgid "Calculating solar elevation and azimuth..."
-msgstr "출력할 격자지도"
+#: ../raster/r.mfilter/main.c:86
+msgid "Output raster map title"
+msgstr ""
-#: ../raster/r.sunhours/main.c:359
-#, fuzzy
-msgid "Calculating solar elevation..."
-msgstr "출력할 격자지도"
+#: ../raster/r.mfilter/main.c:98
+msgid "Apply filter only to null data values"
+msgstr ""
-#: ../raster/r.sunhours/main.c:362
+#: ../raster/r.mfilter/main.c:125
#, fuzzy
-msgid "Calculating solar azimuth..."
+msgid "Raster map too small for the size of the filter"
msgstr "출력할 격자지도"
-#: ../raster/r.in.poly/get_item.c:97
+#: ../raster/r.mfilter/getfilt.c:27
#, fuzzy, c-format
-msgid "Illegal coordinate <%s, %s>, skipping."
+msgid "Cannot open filter file '%s'"
msgstr "출력할 격자지도"
-#: ../raster/r.in.poly/get_item.c:102
-#, fuzzy, c-format
-msgid "Illegal north coordinate <%s>, skipping."
-msgstr "출력할 격자지도"
+#: ../raster/r.mfilter/getfilt.c:47
+msgid "Illegal filter matrix size specified"
+msgstr ""
-#: ../raster/r.in.poly/get_item.c:107
-#, fuzzy, c-format
-msgid "Illegal east coordinate <%s>, skipping."
-msgstr "출력할 격자지도"
+#: ../raster/r.mfilter/getfilt.c:50
+msgid "Even filter matrix size specified"
+msgstr ""
-#: ../raster/r.in.poly/main.c:37
-msgid "Creates raster maps from ASCII polygon/line/point data files."
+#: ../raster/r.mfilter/getfilt.c:72
+msgid "Illegal filter matrix"
msgstr ""
-#: ../raster/r.in.poly/main.c:41
-#, fuzzy
-msgid "Name of input file; or \"-\" to read from stdin"
-msgstr "출력할 격자지도"
+#: ../raster/r.mfilter/getfilt.c:80 ../raster/r.mfilter/getfilt.c:107
+#: ../raster/r.mfilter/getfilt.c:124
+msgid "Filter file format error"
+msgstr ""
-#: ../raster/r.in.poly/main.c:60
-#, fuzzy
-msgid "Integer representing NULL value data cell"
-msgstr "자료 없는 셀값을 표현할 문자열"
+#: ../raster/r.mfilter/getfilt.c:83
+msgid "Duplicate filter divisor specified"
+msgstr ""
-#: ../raster/r.in.poly/main.c:66
-msgid "Number of rows to hold in memory"
+#: ../raster/r.mfilter/getfilt.c:101
+msgid "Illegal divisor matrix"
msgstr ""
-#: ../raster/r.in.poly/main.c:74
-msgid "Minimum number of rows to hold in memory is 1"
+#: ../raster/r.mfilter/getfilt.c:110
+msgid "Duplicate filter type specified"
msgstr ""
-#: ../raster/r.in.poly/main.c:83
+#: ../raster/r.mfilter/getfilt.c:117
+msgid "Illegal filter type specified"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:127
+msgid "Duplicate filter start specified"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:135
+#, c-format
+msgid "Filter start %s ignored, using UL"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:157
+msgid "Illegal filter file format"
+msgstr ""
+#: ../raster/r.mfilter/perform.c:40 ../raster/r.mfilter/perform.c:51
#, fuzzy
-msgid "Type doesn't exist"
+msgid "Unable to create temporary file"
msgstr "출력할 격자지도"
-#: ../raster/r.out.ppm/main.c:56
+#: ../raster/r.mfilter/perform.c:81
+#, fuzzy, c-format
+msgid "Writing raster map <%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.in.ascii/main.c:74
#, fuzzy
-msgid "Converts a GRASS raster map to a PPM image file."
+msgid "Converts a GRASS ASCII raster file to binary raster map."
msgstr "출력할 격자지도"
-#: ../raster/r.out.ppm/main.c:64
-msgid "Name for new PPM file (use '-' for stdout)"
+#: ../raster/r.in.ascii/main.c:85
+msgid "Default: CELL for integer values, DCELL for floating-point values"
msgstr ""
-#: ../raster/r.out.ppm/main.c:68
-msgid "Output greyscale instead of color"
+#: ../raster/r.in.ascii/main.c:97 ../raster/r.in.ascii/main.c:102
+#, fuzzy
+msgid "Default: read from header"
+msgstr "출력할 격자지도"
+#: ../raster/r.in.ascii/main.c:99
+msgid "Multiplier for ASCII data"
msgstr ""
-#: ../raster/r.out.ppm/main.c:72
-msgid "Suppress printing of PPM header"
+#: ../raster/r.in.ascii/main.c:103
+msgid "String representing NULL value data cell"
msgstr ""
-#: ../raster/r.out.ppm/main.c:101 ../raster/r.out.ppm3/main.c:95
-#, c-format
-msgid "row = %d"
-msgid_plural "rows = %d"
-msgstr[0] ""
-msgstr[1] ""
+#: ../raster/r.in.ascii/main.c:104
+msgid "NULL data"
+msgstr ""
-#. GTC Raster columns
-#: ../raster/r.out.ppm/main.c:102 ../raster/r.out.ppm3/main.c:97
-#, fuzzy, c-format
-msgid "column = %d"
-msgid_plural "columns = %d"
-msgstr[0] "출력할 격자지도"
-msgstr[1] "출력할 격자지도"
+#: ../raster/r.in.ascii/main.c:109
+msgid "SURFER (Golden Software) ASCII file will be imported"
+msgstr ""
-#: ../raster/r.out.ppm/main.c:124
-#, fuzzy, c-format
-msgid "Unable to open file <%s> for write"
-msgstr "출력할 격자지도"
+#: ../raster/r.in.ascii/main.c:128
+#, c-format
+msgid "Wrong entry for multiplier: %s"
+msgstr ""
-#: ../raster/r.out.ppm/main.c:154
-msgid "Converting..."
+#: ../raster/r.in.ascii/main.c:160
+#, c-format
+msgid "Unable to read input from <%s>"
msgstr ""
-#: ../raster/r.out.ppm/main.c:234
+#: ../raster/r.in.ascii/main.c:180
+msgid "Can't get cell header"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:202
#, c-format
-msgid "File <%s> created"
+msgid "Data conversion failed at row %d, col %d"
msgstr ""
-#: ../raster/r.resamp.interp/main.c:80
-#, fuzzy
-msgid "Resamples raster map to a finer grid using interpolation."
-msgstr "출력할 격자지도"
+#: ../raster/r.in.ascii/gethead.c:35
+msgid "input file is not a Surfer ascii grid file"
+msgstr ""
-#: ../raster/r.resamp.interp/main.c:88
-msgid "Method"
+#: ../raster/r.in.ascii/gethead.c:41
+msgid "error reading the column and row dimension from the Surfer grid file"
msgstr ""
-#: ../raster/r.out.vrml/put_grid.c:38
-msgid "Writing vertices..."
+#: ../raster/r.in.ascii/gethead.c:47
+msgid "error reading the X range from the Surfer grid file"
msgstr ""
-#: ../raster/r.out.vrml/put_grid.c:83
-msgid "Writing color file..."
+#: ../raster/r.in.ascii/gethead.c:53
+msgid "error reading the Y range from the Surfer grid file"
msgstr ""
-#: ../raster/r.out.vrml/main.c:49
-msgid "VRML"
+#: ../raster/r.in.ascii/gethead.c:59
+msgid "error reading the Z range from the Surfer grid file"
msgstr ""
-#: ../raster/r.out.vrml/main.c:51
-msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
+#: ../raster/r.in.ascii/gethead.c:105
+msgid "error getting file position"
msgstr ""
-#: ../raster/r.out.vrml/main.c:58
-#, fuzzy
-msgid "Name of input color map"
-msgstr "벡터지도 이름"
+#: ../raster/r.in.ascii/gethead.c:164
+msgid "illegal type field: using type int"
+msgstr ""
-#: ../raster/r.out.vrml/main.c:65 ../misc/m.nviz.image/args.c:575
-msgid "Vertical exaggeration"
+#: ../raster/r.in.ascii/gethead.c:169
+msgid "ignoring type filed in header, type is set on command line"
msgstr ""
-#: ../raster/r.out.vrml/main.c:69
-#, fuzzy
-msgid "Name for output VRML file"
-msgstr "출력할 격자지도"
+#: ../raster/r.in.ascii/gethead.c:176
+msgid "illegal multiplier field: using 1.0"
+msgstr ""
-#: ../raster/r.out.vrml/main.c:88
+#: ../raster/r.in.ascii/gethead.c:181
+msgid "ignoring multiplier filed in header, multiplier is set on command line"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:189
+msgid "ignoring null filed in header, null string is set on command line"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:218
+msgid "error in ascii data format"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:248
#, c-format
-msgid "Range info for [%s] not available (run r.support)"
+msgid "Duplicate \"%s\" field in header"
msgstr ""
-#: ../raster/r.out.vrml/main.c:97
+#: ../raster/r.in.ascii/gethead.c:253
+#, c-format
+msgid "Illegal \"%s\" value in header: %s"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:261
+#, c-format
+msgid "\"%s\" field missing from header"
+msgstr ""
+#: ../raster/r.mapcalc/map3.c:181 ../raster/r.mapcalc/map.c:224
#, fuzzy, c-format
-msgid "Range info for <%s> not available (run r.support)"
+msgid "Unable to read color file for raster map <%s@%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.out.vrml/main.c:129
+#: ../raster/r.mapcalc/map3.c:194 ../raster/r.mapcalc/map.c:237
+#, fuzzy, c-format
+msgid "Unable to create btree for raster map <%s@%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.mapcalc/map3.c:239 ../raster/r.mapcalc/map3.c:423
+#: ../raster/r.mapcalc/map3.c:468 ../raster/r.mapcalc/map3.c:565
+#: ../raster/r.mapcalc/map.c:286 ../raster/r.mapcalc/map.c:493
+#: ../raster/r.mapcalc/map.c:534 ../raster/r.mapcalc/map.c:632
+#: ../raster/r.mapcalc/expression.c:357
#, c-format
-msgid "Opening %s for writing... "
+msgid "Invalid map modifier: '%c'"
msgstr ""
-#: ../raster/r.surf.area/main.c:79
+#: ../raster/r.mapcalc/map3.c:353 ../raster/r.mapcalc/map.c:424
+#: ../raster/r.mapcalc/evaluate.c:94 ../raster/r.mapcalc/evaluate.c:234
+#, c-format
+msgid "Unknown type: %d"
+msgstr ""
+#: ../raster/r.mapcalc/map3.c:372
+#, fuzzy, c-format
+msgid "Unable to close raster map <%s@%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.mapcalc/map3.c:631
#, fuzzy
-msgid "area estimation"
+msgid "Unable to close output raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.surf.area/main.c:80
+#: ../raster/r.mapcalc/main.c:71
#, fuzzy
-msgid "Prints estimation of surface area for raster map."
+msgid "Raster map calculator."
msgstr "출력할 격자지도"
-#: ../raster/r.surf.area/main.c:89
-msgid "Vertical scale"
+#: ../raster/r.mapcalc/main.c:78
+msgid "Expression to evaluate"
msgstr ""
-#: ../raster/r.surf.area/main.c:93
+#: ../raster/r.mapcalc/main.c:79 ../raster/r.mapcalc/main.c:85
#, fuzzy
-msgid "Output units"
+msgid "Expression"
msgstr "출력할 격자지도"
-#: ../raster/r.surf.area/main.c:94
-msgid "Default: square map units"
+#: ../raster/r.mapcalc/main.c:84
+#, fuzzy
+msgid "File containing expression(s) to evaluate"
+msgstr "출력할 격자지도"
+#: ../raster/r.mapcalc/main.c:91
+msgid "Seed for rand() function"
msgstr ""
-#: ../raster/r.surf.area/main.c:102
-#, fuzzy, c-format
-msgid "Output in '%s'"
+#: ../raster/r.mapcalc/main.c:95
+msgid "Generate random seed (result is non-deterministic)"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:99
+#, fuzzy
+msgid "List input and output maps"
msgstr "출력할 격자지도"
-#: ../raster/r.surf.area/main.c:106
-msgid "Output in 'square map units'"
+#: ../raster/r.mapcalc/main.c:121
+#, fuzzy, c-format
+msgid "%s= and -%c are mutually exclusive"
+msgstr "-%c와 -%c를 같이 지정할 수 없습니다"
+#: ../raster/r.mapcalc/main.c:132
+msgid "parse error"
msgstr ""
-#: ../raster/r.surf.area/main.c:153
-msgid "Null value area ignored in calculation:"
+#: ../raster/r.mapcalc/main.c:159
+msgid "Floating point error(s) occurred in the calculation"
msgstr ""
-#: ../raster/r.surf.area/main.c:155
-msgid "Plan area used in calculation:"
+#: ../raster/r.mapcalc/function.c:33
+#, c-format
+msgid "Known functions:"
msgstr ""
-#: ../raster/r.surf.area/main.c:158
-msgid "Surface area calculation(low, high, avg):"
+#: ../raster/r.mapcalc/evaluate.c:140
+#, c-format
+msgid "Invalid type: %d"
msgstr ""
-#: ../raster/r.surf.area/main.c:163
-msgid "Current region plan area:"
+#: ../raster/r.mapcalc/evaluate.c:179
+#, c-format
+msgid "Too few arguments for function '%s'"
msgstr ""
-#: ../raster/r.surf.area/main.c:165
-msgid "Estimated region Surface Area:"
+#: ../raster/r.mapcalc/evaluate.c:183
+#, c-format
+msgid "Too many arguments for function '%s'"
msgstr ""
-#: ../raster/r.in.gridatb/file_io.c:35
-msgid "Setting window header failed"
+#: ../raster/r.mapcalc/evaluate.c:187
+#, c-format
+msgid "Invalid argument type for function '%s'"
msgstr ""
-#: ../raster/r.in.gridatb/file_io.c:38
-msgid "Rows changed"
+#: ../raster/r.mapcalc/evaluate.c:191
+#, c-format
+msgid "Invalid return type for function '%s'"
msgstr ""
-#: ../raster/r.in.gridatb/file_io.c:41
-msgid "Cols changed"
+#: ../raster/r.mapcalc/evaluate.c:195
+#, c-format
+msgid "Unknown type for function '%s'"
msgstr ""
-#: ../raster/r.in.gridatb/main.c:48
-#, fuzzy
-msgid "Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map."
-msgstr "출력할 격자지도"
+#: ../raster/r.mapcalc/evaluate.c:198
+#, c-format
+msgid "Number of arguments for function '%s'"
+msgstr ""
-#: ../raster/r.in.gridatb/main.c:51
-msgid "GRIDATB i/o map file"
+#: ../raster/r.mapcalc/evaluate.c:202
+#, c-format
+msgid "Unknown error for function '%s'"
msgstr ""
-#: ../raster/r.in.gridatb/main.c:68
+#: ../raster/r.mapcalc/evaluate.c:282
#, c-format
-msgid "File not found: %s"
+msgid "output map <%s> exists. To overwrite, use the --overwrite flag"
msgstr ""
-#: ../raster/r.series/main.c:141
-msgid ""
-"Makes each output cell value a function of the values assigned to the "
-"corresponding cells in the input raster map layers."
+#: ../raster/r.mapcalc/expression.c:206
+#, c-format
+msgid "Undefined variable '%s'"
msgstr ""
-#: ../raster/r.series/main.c:150
-msgid ""
-"Input file with one raster map name and optional one weight per line, field "
-"separator between name and weight is |"
+#: ../raster/r.mapcalc/expression.c:221
+#, c-format
+msgid "Invalid map <%s>"
msgstr ""
-#: ../raster/r.series/main.c:176
-msgid ""
-"Weighting factor for each input map, default value is 1.0 for each input map"
+#: ../raster/r.mapcalc/expression.c:262
+#, c-format
+msgid "Undefined function '%s'"
msgstr ""
-#: ../raster/r.series/main.c:250 ../raster/r.series/main.c:312
-#, fuzzy
-msgid "Weights must be positive"
-msgstr "출력할 격자지도"
-#: ../raster/r.series/main.c:268 ../raster/r.series/main.c:318
-#, fuzzy, c-format
-msgid "Reading raster map <%s> using weight %f..."
-msgstr "출력할 격자지도"
-#: ../raster/r.series/main.c:298
-msgid "input= and weights= must have the same number of values"
+#: ../raster/r.mapcalc/expression.c:267
+#, c-format
+msgid "Too few arguments (%d) to function %s()"
msgstr ""
-#: ../raster/r.series/main.c:333
-msgid "output= and method= must have the same number of values"
+#: ../raster/r.mapcalc/expression.c:271
+#, c-format
+msgid "Too many arguments (%d) to function %s()"
msgstr ""
-#: ../raster/r.series/main.c:351
+#: ../raster/r.mapcalc/expression.c:275
#, c-format
-msgid "Method %s not compatible with weights, using unweighed version instead"
+msgid "Incorrect argument types to function %s()"
msgstr ""
-#: ../raster/r.stats.zonal/main.c:103 ../raster/r.univar/r.univar_main.c:107
-#: ../raster/r.statistics/main.c:57
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
-#: ../vector/v.vect.stats/main.c:128
-#, fuzzy
-msgid "zonal statistics"
-msgstr "출력할 격자지도"
-#: ../raster/r.stats.zonal/main.c:105
-msgid ""
-"Calculates category or object oriented statistics (accumulator-based "
-"statistics)."
+#: ../raster/r.mapcalc/expression.c:278
+#, c-format
+msgid "Internal error for function %s()"
msgstr ""
-#: ../raster/r.stats.zonal/main.c:115 ../raster/r.statistics/main.c:69
-msgid "Method of object-based statistic"
+#: ../raster/r.mapcalc/expression.c:453
+#, c-format
+msgid "Illegal number of arguments (%d) for operator '%s'"
msgstr ""
-#: ../raster/r.stats.zonal/main.c:138 ../raster/r.statistics/main.c:92
-#, fuzzy
-msgid "Resultant raster map"
-msgstr "출력할 격자지도"
-#: ../raster/r.stats.zonal/main.c:144 ../raster/r.statistics/main.c:98
-msgid "Cover values extracted from the category labels of the cover map"
+#: ../raster/r.mapcalc/expression.c:493
+#, c-format
+msgid "Format_expression_prec: unknown type: %d"
msgstr ""
-#: ../raster/r.stats.zonal/main.c:178
+#: ../raster/r.basins.fill/read_map.c:39
#, fuzzy, c-format
-msgid "Unable to read category file of cover map <%s>"
+msgid "Reading <%s> ... "
msgstr "출력할 격자지도"
-#: ../raster/r.stats.zonal/main.c:248
-msgid "First pass"
+#: ../raster/r.basins.fill/main.c:56 ../raster/r.water.outlet/main.c:59
+#: ../raster/r.watershed/front/main.c:75
+msgid "watershed"
msgstr ""
-#: ../raster/r.stats.zonal/main.c:327
-msgid "Second pass"
-msgstr ""
-#: ../raster/r.stats.zonal/main.c:474
+#: ../raster/r.basins.fill/main.c:58
#, fuzzy
-msgid "Generating reclass map"
+msgid "Generates watershed subbasins raster map."
msgstr "출력할 격자지도"
-#: ../raster/r.stats.zonal/main.c:496
+#: ../raster/r.basins.fill/main.c:62
#, fuzzy
-msgid "Writing output map"
+msgid "Name of input coded stream network raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.clump/minsize.c:357
+#: ../raster/r.basins.fill/main.c:66
#, fuzzy
-msgid "Minimum size must be larger than 1"
+msgid "Name of input thinned ridge network raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.clump/minsize.c:368
+#: ../raster/r.basins.fill/main.c:74
+msgid "Number of passes through the dataset"
+msgstr ""
+#: ../raster/r.basins.fill/main.c:122
+msgid "Forward sweep complete"
+msgstr ""
+#: ../raster/r.basins.fill/main.c:139
+msgid "Reverse sweep complete"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:116
+msgid "Creates a raster map from LAS LiDAR points using univariate statistics."
+msgstr ""
+#: ../raster/r.in.lidar/main.c:180
#, fuzzy
-msgid "Loading input ..."
+msgid "Subtract raster values from the Z coordinates"
msgstr "출력할 격자지도"
-#: ../raster/r.clump/minsize.c:418
-#, c-format
-msgid "Merging clumps smaller than %d cells..."
+#: ../raster/r.in.lidar/main.c:182
+msgid ""
+"The scale for Z is applied beforehand, the range filter for Z afterwards"
msgstr ""
-#: ../raster/r.clump/minsize.c:509
-#, fuzzy, c-format
-msgid "Renumbering remaining %d clumps..."
+#: ../raster/r.in.lidar/main.c:191
+#, fuzzy
+msgid "Filter range for Z data (min,max)"
msgstr "출력할 격자지도"
-#: ../raster/r.clump/main.c:60
-msgid "reclass"
+#: ../raster/r.in.lidar/main.c:241
+msgid "Discard given percentage of the smallest and largest values"
msgstr ""
-#: ../raster/r.clump/main.c:61 ../raster/r.volume/main.c:78
+#: ../raster/r.in.lidar/main.c:251
#, fuzzy
-msgid "clumps"
+msgid "Output raster resolution"
msgstr "출력할 격자지도"
-#: ../raster/r.clump/main.c:63
-msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
+#: ../raster/r.in.lidar/main.c:281
+msgid "Use the extent of the input for the raster extent"
msgstr ""
-#: ../raster/r.clump/main.c:82
-msgid "Threshold to identify similar cells"
+#: ../raster/r.in.lidar/main.c:283
+msgid "Set internally computational region extents based on the point cloud"
msgstr ""
-#: ../raster/r.clump/main.c:83
-msgid "Valid range: 0 = identical to < 1 = maximal difference"
-msgstr ""
-#: ../raster/r.clump/main.c:90
+#: ../raster/r.in.lidar/main.c:290
#, fuzzy
-msgid "Minimum clump size in cells"
+msgid "Set computation region to match the new raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.clump/main.c:91
-msgid "Clumps smaller than minsize will be merged to form larger clumps"
+#: ../raster/r.in.lidar/main.c:292
+msgid ""
+"Set computation region to match the 2D extent and resolution of the newly "
+"created new raster map"
msgstr ""
-#: ../raster/r.clump/main.c:95
-msgid "Clump also diagonal cells"
+#: ../raster/r.in.lidar/main.c:315
+msgid "Use intensity values rather than Z values"
msgstr ""
-#: ../raster/r.clump/main.c:96
-msgid "Clumps are also traced along diagonal neighboring cells"
+#: ../raster/r.in.lidar/main.c:317
+msgid "Uses intensity values everywhere as if they would be Z coordinates"
msgstr ""
-#: ../raster/r.clump/main.c:100
+#: ../raster/r.in.lidar/main.c:323
+msgid "Use Z values for filtering, but intensity values for statistics"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:328
#, fuzzy
-msgid "Print only the number of clumps in shell script style"
-msgstr "위상정보를 셸스크립트 형식으로 출력합니다"
+msgid "Use base raster resolution instead of computational region"
+msgstr "와일드카드 대신 기본 정규표현식을 사용합니다"
-#: ../raster/r.clump/main.c:122
+#: ../raster/r.in.lidar/main.c:330
+msgid ""
+"For getting values from base raster, use its actual resolution instead of "
+"computational region resolution"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:357
#, c-format
-msgid "Valid range for option <%s> is 0 <= value < 1"
+msgid "Flag %c makes sense only with %s option or -%c flag"
msgstr ""
-#: ../raster/r.clump/main.c:180
-#, fuzzy, c-format
-msgid "%d clump."
-msgid_plural "%d clumps."
-#: ../raster/r.clump/clump.c:81
-msgid "Pass 2 of 2..."
+#: ../raster/r.in.lidar/main.c:384
+msgid "zrange will not be taken into account during scan"
msgstr ""
-#: ../raster/r.clump/clump.c:122
+#: ../raster/r.in.lidar/main.c:459
#, fuzzy, c-format
-msgid "%d initial clumps"
+msgid "Unknown filter option <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.clump/clump.c:233 ../raster/r.clump/clump.c:490
-msgid "Pass 1 of 2..."
-msgstr ""
+#: ../raster/r.in.lidar/main.c:491
+#, fuzzy, c-format
+msgid "Invalid %s"
+msgstr "출력할 격자지도"
-#: ../raster/r.clump/clump.c:425
+#: ../raster/r.in.lidar/main.c:526
#, fuzzy, c-format
-msgid "%d-band clumping with threshold %g"
+msgid "Option '%s' must be > 0.0"
msgstr "출력할 격자지도"
-#: ../raster/r.composite/main.c:73
-#: ../locale/scriptstrings/r.blend_to_translate.c:3
+#: ../raster/r.in.lidar/main.c:594
+#, c-format
+msgid ""
+"Unable to process the hole map at once. Please set the '%s' option to some "
+"value lower than 100."
+msgstr ""
+#: ../raster/r.in.lidar/main.c:606
#, fuzzy
-msgid "composite"
+msgid "Reading data ..."
msgstr "출력할 격자지도"
-#: ../raster/r.composite/main.c:76
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
+#: ../raster/r.in.lidar/main.c:753
+msgid "Writing to map ..."
msgstr ""
-#: ../raster/r.composite/main.c:90 ../raster/r.out.ppm3/main.c:64
-#: ../display/d.rgb/main.c:69
+#: ../raster/r.in.lidar/main.c:791
#, c-format
-msgid "Name of raster map to be used for <%s>"
+msgid "%lu input points were invalid and filtered out"
msgstr ""
-#: ../raster/r.composite/main.c:102
-msgid "Number of levels to be used for each component"
+#: ../raster/r.in.lidar/main.c:794
+#, c-format
+msgid "%lu input points were invalid, use -%c flag to filter them out"
msgstr ""
-#: ../raster/r.composite/main.c:103 ../raster/r.composite/main.c:121
-msgid "Levels"
+#: ../raster/r.in.lidar/main.c:797
+#, c-format
+msgid "Raster map <%s> created. %lu points from %d files found in region."
msgstr ""
-#: ../raster/r.composite/main.c:118
-#, c-format
-msgid "Number of levels to be used for <%s>"
+#: ../raster/r.in.lidar/main.c:802
+#, fuzzy, c-format
+msgid "Raster map <%s> created. %lu points found in region."
+msgstr "출력할 격자지도"
+#: ../raster/r.to.rast3elev/main.c:99
+msgid "The number of input and elevation maps is not equal"
msgstr ""
-#: ../raster/r.composite/main.c:128
-msgid "Dither"
+#: ../raster/r.to.rast3elev/main.c:165
+msgid "The value to fill the upper cells, default is null"
msgstr ""
-#: ../raster/r.composite/main.c:132
-msgid "Use closest color"
+#: ../raster/r.to.rast3elev/main.c:172
+msgid "The value to fill the lower cells, default is null"
msgstr ""
-#: ../raster/r.composite/main.c:164
-#, fuzzy, c-format
-msgid "Unable to read color file of raster map <%s>"
-msgstr "출력할 격자지도"
+#: ../raster/r.to.rast3elev/main.c:185
+msgid "Use the input map values to fill the upper cells"
+msgstr ""
-#: ../raster/r.composite/main.c:286
+#: ../raster/r.to.rast3elev/main.c:190
+msgid "Use the input map values to fill the lower cells"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:287 ../raster/r.to.rast3elev/main.c:320
#, fuzzy
-msgid "Creating color table for output raster map..."
+msgid "Error writing 3D raster double data"
msgstr "출력할 격자지도"
-#: ../raster/r.univar/r.univar_main.c:36
-msgid "Raster map used for zoning, must be of type CELL"
+#: ../raster/r.to.rast3elev/main.c:366
+msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
msgstr ""
-#: ../raster/r.univar/r.univar_main.c:52
-#: ../raster/r.univar/r3.univar_main.c:52
-#: ../locale/scriptstrings/db.univar_to_translate.c:6
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
-#: ../vector/v.univar/main.c:122
-msgid "Percentile to calculate (requires extended statistics flag)"
+#: ../raster/r.to.rast3elev/main.c:400
+msgid "The upper value is not valid"
msgstr ""
-#: ../raster/r.univar/r.univar_main.c:53 ../raster/r.univar/r.univar_main.c:67
-msgid "Extended"
+#: ../raster/r.to.rast3elev/main.c:410
+msgid "The lower value is not valid"
msgstr ""
-#: ../raster/r.univar/r.univar_main.c:61
-#: ../raster/r.univar/r3.univar_main.c:59 ../vector/v.what/main.c:98
-#: ../vector/v.univar/main.c:126
-msgid "Print the stats in shell script style"
+#: ../raster/r.to.rast3elev/main.c:427
+msgid ""
+"The 2D and 3D region settings are different. I will use the 3D region "
+"settings to adjust the 2D region."
msgstr ""
-#: ../raster/r.univar/r.univar_main.c:66
-#: ../raster/r.univar/r3.univar_main.c:63
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:9
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:10
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:10
-#: ../vector/v.univar/main.c:130
-msgid "Calculate extended statistics"
+#: ../raster/r.circle/main.c:54 ../vector/v.buffer/main.c:224
+msgid "circle"
msgstr ""
-#: ../raster/r.univar/r.univar_main.c:71
-#: ../raster/r.univar/r3.univar_main.c:67
-msgid "Table output format instead of standard output format"
+#: ../raster/r.circle/main.c:56
+msgid "Creates a raster map containing concentric rings around a given point."
msgstr ""
-#: ../raster/r.univar/r.univar_main.c:76
-#, fuzzy
-msgid ""
-"Use the native resolution and extent of the raster map, instead of the "
-"current region"
-msgstr "출력할 격자지도"
+#: ../raster/r.circle/main.c:63
+msgid "The coordinate of the center (east,north)"
+msgstr ""
-#: ../raster/r.univar/r.univar_main.c:106
-#: ../raster/r.univar/r3.univar_main.c:100
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
-#: ../vector/v.vect.stats/main.c:127 ../vector/v.univar/main.c:94
-#, fuzzy
-msgid "univariate statistics"
-msgstr "출력할 격자지도"
+#: ../raster/r.circle/main.c:69
+msgid "Minimum radius for ring/circle map (in meters)"
+msgstr ""
-#: ../raster/r.univar/r.univar_main.c:110
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map."
+#: ../raster/r.circle/main.c:75
+msgid "Maximum radius for ring/circle map (in meters)"
msgstr ""
-#: ../raster/r.univar/r.univar_main.c:112
-#: ../raster/r.univar/r3.univar_main.c:105
-msgid ""
-"Statistics include number of cells counted, minimum and maximum cell values, "
-"range, arithmetic mean, population variance, standard deviation, coefficient "
-"of variation, and sum."
+#: ../raster/r.circle/main.c:81
+msgid "Data value multiplier"
msgstr ""
-#: ../raster/r.univar/r.univar_main.c:123
-#, fuzzy
-msgid "zones option and region flag -r are mutually exclusive"
-msgstr "-%c와 -%c를 같이 지정할 수 없습니다"
+#: ../raster/r.circle/main.c:85
+msgid "Generate binary raster map"
+msgstr ""
-#: ../raster/r.univar/r3.univar_main.c:37
-msgid "3D Raster map used for zoning, must be of type CELL"
+#: ../raster/r.circle/main.c:108
+msgid "Please specify a radius in which min < max"
msgstr ""
-#: ../raster/r.univar/r3.univar_main.c:103
-#, fuzzy
-msgid ""
-"Calculates univariate statistics from the non-null cells of a 3D raster map."
-msgstr "출력할 격자지도"
+#: ../raster/r.circle/main.c:116
+msgid "Please specify min and/or max radius when using the binary flag"
+msgstr ""
-#: ../raster/r.cross/renumber.c:33
-#, c-format
-msgid "%s: STEP 3 ... "
+#: ../raster/r.solute.transport/main.c:59
+msgid "The initial concentration in [kg/m^3]"
msgstr ""
-#: ../raster/r.cross/main.c:72
-msgid ""
-"Creates a cross product of the category values from multiple raster map "
-"layers."
+#: ../raster/r.solute.transport/main.c:63
+msgid "The piezometric head in [m]"
msgstr ""
-#: ../raster/r.cross/main.c:81
-#, c-format
-msgid "Names of 2-%d input raster maps"
+#: ../raster/r.solute.transport/main.c:68
+msgid "The x-part of the hydraulic conductivity tensor in [m/s]"
msgstr ""
-#: ../raster/r.cross/main.c:90
-msgid "Non-zero data only"
+#: ../raster/r.solute.transport/main.c:73
+msgid "The y-part of the hydraulic conductivity tensor in [m/s]"
msgstr ""
-#: ../raster/r.cross/main.c:103
-#, c-format
-msgid "More than %d files not allowed"
+#: ../raster/r.solute.transport/main.c:79
+msgid ""
+"The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - "
+"dirichlet- and 3 - transfer boundary condition"
msgstr ""
-#: ../raster/r.cross/main.c:119
-msgid "Must specify 2 or more input maps"
+#: ../raster/r.solute.transport/main.c:85
+msgid "The x-part of the diffusion tensor in [m^2/s]"
msgstr ""
-#: ../raster/r.cross/main.c:136
-#, c-format
-msgid "%s: STEP 2 ..."
+#: ../raster/r.solute.transport/main.c:90
+msgid "The y-part of the diffusion tensor in [m^2/s]"
msgstr ""
-#: ../raster/r.cross/main.c:179
-#, c-format
-msgid "%ld categories"
+#: ../raster/r.solute.transport/main.c:94
+#: ../raster/r.solute.transport/main.c:102
+#: ../raster/r.solute.transport/main.c:138
+#: ../raster/r.solute.transport/main.c:145
+msgid "Water flow"
msgstr ""
-#: ../raster/r.cross/cross.c:65
-#, c-format
-msgid "%s: STEP 1 ... "
+#: ../raster/r.solute.transport/main.c:96
+msgid "Groundwater sources and sinks in [m^3/s]"
msgstr ""
-#: ../raster/r.coin/print_coin.c:44
-#, c-format
-msgid "Preparing report ..."
+#: ../raster/r.solute.transport/main.c:103
+msgid ""
+"Concentration sources and sinks bounded to a water source or sink in [kg/s]"
msgstr ""
-#: ../raster/r.coin/main.c:69
+#: ../raster/r.solute.transport/main.c:112
msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
+"Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical "
+"reaction)"
msgstr ""
-#: ../raster/r.coin/main.c:74
-#, fuzzy
-msgid "Name of first input raster map"
-msgstr "출력할 격자지도"
+#: ../raster/r.solute.transport/main.c:117
+msgid "Retardation factor [-]"
+msgstr ""
-#: ../raster/r.coin/main.c:78
-#, fuzzy
-msgid "Name of second input raster map"
-msgstr "출력할 격자지도"
+#: ../raster/r.solute.transport/main.c:121
+msgid "Effective porosity [-]"
+msgstr ""
-#: ../raster/r.coin/main.c:84
-msgid "Unit of measure"
+#: ../raster/r.solute.transport/main.c:125
+msgid "Top surface of the aquifer in [m]"
msgstr ""
-#: ../raster/r.coin/main.c:86
+#: ../raster/r.solute.transport/main.c:129
+msgid "Bottom surface of the aquifer in [m]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:132
msgid ""
-"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
-"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
+"The resulting concentration of the numerical solute transport calculation "
+"will be written to this map. [kg/m^3]"
msgstr ""
-#: ../raster/r.coin/main.c:93
-msgid "Wide report, 132 columns (default: 80)"
+#: ../raster/r.solute.transport/main.c:140
+msgid ""
+"Calculate and store the groundwater filter velocity vector part in x "
+"direction [m/s]\n"
msgstr ""
-#: ../raster/r.coin/make_coin.c:48
-#, c-format
-msgid "Tabulating Coincidence between '%s' and '%s'"
+#: ../raster/r.solute.transport/main.c:147
+msgid ""
+"Calculate and store the groundwater filter velocity vector part in y "
msgstr ""
-#: ../raster/r.coin/make_coin.c:61
-msgid "Unable to create any tempfiles"
+#: ../raster/r.solute.transport/main.c:161
+msgid "The longditudinal dispersivity length. [m]"
msgstr ""
-#: ../raster/r.coin/make_coin.c:65
-msgid "Unable to run r.stats"
+#: ../raster/r.solute.transport/main.c:169
+msgid "The transversal dispersivity length. [m]"
msgstr ""
-#: ../raster/r.coin/make_coin.c:72
-msgid "Unexpected output from r.stats"
+#: ../raster/r.solute.transport/main.c:177
+msgid ""
+"Use this number of time loops if the CFL flag is off. The timestep will "
+"become dt/loops."
msgstr ""
-#: ../raster/r.coin/make_coin.c:84
-msgid "Unable to open tempfile"
+#: ../raster/r.solute.transport/main.c:187
+msgid "Set the flow stabilizing scheme (full or exponential upwinding)."
msgstr ""
-#: ../raster/r.statistics/o_var.c:95 ../raster/r.statistics/o_sdev.c:94
-msgid "o_var: No data in array"
+#: ../raster/r.solute.transport/main.c:199
+msgid "Use the Courant-Friedrichs-Lewy criteria for time step calculation"
msgstr ""
-#: ../raster/r.statistics/o_skew.c:91
-msgid "o_skew: No data in array"
+#: ../raster/r.solute.transport/main.c:231
+#, fuzzy
+msgid "solute transport"
+msgstr "출력할 격자지도"
+#: ../raster/r.solute.transport/main.c:233
+msgid ""
+"Numerical calculation program for transient, confined and unconfined solute "
+"transport in two dimensions"
msgstr ""
-#: ../raster/r.statistics/main.c:59
-msgid "Calculates category or object oriented statistics."
+#: ../raster/r.solute.transport/main.c:258
+msgid "The direct LU solver do not work with sparse matrices"
msgstr ""
-#: ../raster/r.statistics/main.c:104 ../raster/r.statistics/main.c:107
-#: ../raster/r.surf.idw/main.c:164
-msgid "This module currently only works for integer (CELL) maps"
+#: ../raster/r.solute.transport/main.c:260
+msgid "The direct Gauss solver do not work with sparse matrices"
msgstr ""
-#: ../raster/r.statistics/o_kurt.c:91
-msgid "o_kurto: No data in array"
+#: ../raster/r.solute.transport/main.c:370
+#, c-format
+msgid "The Courant-Friedrichs-Lewy criteria is %g it should be within [0:1]"
msgstr ""
-#: ../raster/r.statistics/o_adev.c:93
-msgid "o_adev: No data in array"
+#: ../raster/r.solute.transport/main.c:371
+#, c-format
+msgid "The largest stable time step is %g"
msgstr ""
-#: ../raster/r.statistics/read_stats.c:20
-msgid "Reading r.stats output"
+#: ../raster/r.solute.transport/main.c:380
+#, fuzzy, c-format
+msgid "Number of inner loops is %g"
+msgstr "출력할 격자지도"
+#: ../raster/r.solute.transport/main.c:381
+#, c-format
+msgid "Time step for each loop %g"
msgstr ""
-#: ../raster/r.series.interp/main.c:69
+#: ../raster/r.solute.transport/main.c:385
+#, c-format
msgid ""
-"Interpolates raster maps located (temporal or spatial) in between input "
-"raster maps at specific sampling positions."
+"The time step is to large: %gs. The largest time step should be of size %gs."
msgstr ""
-#: ../raster/r.series.interp/main.c:79
-#, fuzzy
-msgid "Data point position for each input map"
-msgstr "출력할 격자지도"
+#: ../raster/r.solute.transport/main.c:397
+#, c-format
+msgid "Time step %i with time sum %g"
+msgstr ""
-#: ../raster/r.series.interp/main.c:84
-msgid ""
-"Input file with one input raster map name and data point position per line, "
-"field separator between name and sample point is |"
+#: ../raster/r.solute.transport/main.c:543
+msgid "Could not create and solve the linear equation system"
msgstr ""
-#: ../raster/r.series.interp/main.c:97
+#: ../raster/r.stats/main.c:109
#, fuzzy
-msgid "Sampling point position for each output map"
+msgid "Generates area statistics for raster map."
msgstr "출력할 격자지도"
-#: ../raster/r.series.interp/main.c:101
-msgid ""
-"Input file with one output raster map name and sample point position per "
-"line, field separator between name and sample point is |"
+#: ../raster/r.stats/main.c:157
+msgid "Print area totals in square meters"
msgstr ""
-#: ../raster/r.series.interp/main.c:111
-msgid "Interpolation method, currently only linear interpolation is supported"
+#: ../raster/r.stats/main.c:162
+msgid "Print cell counts (sortable)"
msgstr ""
-#: ../raster/r.series.interp/main.c:130 ../raster/r.series.interp/main.c:146
-#, fuzzy, c-format
-msgid "Please specify %s= and %s="
-msgstr "출력할 격자지도"
+#: ../raster/r.stats/main.c:168
+msgid "Print approximate (total percent may not be 100%) percents"
+msgstr ""
-#: ../raster/r.series.interp/main.c:213
-#, c-format
-msgid "Missing point position for %s map <%s> in file <%s> near line %i"
+#: ../raster/r.stats/main.c:173
+msgid "Print category labels"
msgstr ""
-#: ../raster/r.series.interp/main.c:228 ../raster/r.series.interp/main.c:262
-#, fuzzy, c-format
-msgid "Preparing %s map <%s> at position %g"
-msgstr "출력할 격자지도"
+#: ../raster/r.stats/main.c:177
+msgid "One cell (range) per line"
+msgstr ""
-#: ../raster/r.series.interp/main.c:232
-#, fuzzy, c-format
-msgid "No raster map name found in %s file <%s>"
-msgstr "출력할 격자지도"
+#: ../raster/r.stats/main.c:181
+msgid "Print grid coordinates (east and north)"
+msgstr ""
-#: ../raster/r.series.interp/main.c:243
-#, fuzzy, c-format
-msgid "No %s raster map not found"
+#: ../raster/r.stats/main.c:182 ../raster/r.stats/main.c:187
+#, fuzzy
+msgid "Coordinates"
msgstr "출력할 격자지도"
-#: ../raster/r.series.interp/main.c:250
+#: ../raster/r.stats/main.c:186
+msgid "Print x and y (column and row)"
+msgstr ""
+#: ../raster/r.stats/main.c:191
+msgid "Print averaged values instead of intervals (floating-point maps only)"
+msgstr ""
+#: ../raster/r.stats/main.c:196
+msgid "Print raw indexes of floating-point ranges (floating-point maps only)"
+msgstr ""
+#: ../raster/r.stats/main.c:233
#, c-format
-msgid "The number of %s maps and %s point positions must be equal"
+msgid "'%s' must be greater than zero; using %s=255"
msgstr ""
-#: ../raster/r.series.interp/main.c:279
+#: ../raster/r.stats/main.c:303
#, c-format
-msgid "Start interpolation run with %i input maps and %i output maps"
+msgid ""
+"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
+"will be ignored."
msgstr ""
-#: ../raster/r.series.interp/main.c:299
+#: ../raster/r.stats/main.c:319
#, c-format
msgid ""
-"map <%s> at position %g was not interpolated. Check the interpolation "
-"interval."
+"Cats for raster map <%s> are either missing or have no explicit labels. "
+"Using %s=%d."
msgstr ""
-#: ../raster/r.series.interp/main.c:319
-#, fuzzy
-msgid "At least 2 input maps are required for linear interpolation"
-msgstr "출력할 격자지도"
-#: ../raster/r.series.interp/main.c:337
+#: ../raster/r.stats/main.c:325
#, c-format
-msgid "Interpolate map <%s> at position %g in interval (%g;%g)"
+msgid ""
+"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' "
+"option"
msgstr ""
-#: ../raster/r.texture/main.c:67
-#, fuzzy, c-format
-msgid "Unknown measure <%s>"
+#: ../raster/r.stats/raw_stats.c:118
+#, fuzzy
+msgid "Invalid map type"
msgstr "출력할 격자지도"
-#: ../raster/r.texture/main.c:104
+#: ../raster/r.compress/main.c:66
#, fuzzy
-msgid "texture"
+msgid "compression"
msgstr "출력할 격자지도"
-#: ../raster/r.texture/main.c:106
-msgid "Generate images with textural features from a raster map."
+#: ../raster/r.compress/main.c:67
+msgid "Compresses and decompresses raster maps."
msgstr ""
-#: ../raster/r.texture/main.c:120
-msgid "The size of moving window (odd and >= 3)"
+#: ../raster/r.compress/main.c:70
+msgid "Name of existing raster map(s)"
msgstr ""
-#: ../raster/r.texture/main.c:130
-msgid "The distance between two samples (>= 1)"
+#: ../raster/r.compress/main.c:74
+msgid "Uncompress the map"
msgstr ""
-#: ../raster/r.texture/main.c:146
+#: ../raster/r.compress/main.c:78
#, fuzzy
-msgid "Textural measurement method"
+msgid "Print compression information and data type of input map(s)"
msgstr "출력할 격자지도"
-#: ../raster/r.texture/main.c:150
-msgid "Separate output for each angle (0, 45, 90, 135)"
+#: ../raster/r.compress/main.c:120 ../raster/r.compress/main.c:300
+#, fuzzy, c-format
+msgid "Raster map <%s> is not in the current mapset"
+msgstr "출력할 격자지도"
+#: ../raster/r.compress/main.c:126
+#, c-format
+msgid "<%s> is a reclass file of map <%s> in mapset <%s> - can't uncompress"
msgstr ""
-#: ../raster/r.texture/main.c:154
-#, fuzzy
-msgid "Calculate all textural measurements"
-msgstr "출력할 격자지도"
+#: ../raster/r.compress/main.c:128
+#, c-format
+msgid "<%s> is a reclass file of map <%s> in mapset <%s> - can't compress"
+msgstr ""
-#: ../raster/r.texture/main.c:163
-msgid "Size of the moving window must be > 0"
+#: ../raster/r.compress/main.c:133
+#, c-format
+msgid "<%s> is a GDAL-linked map - can't (un)compress"
msgstr ""
-#: ../raster/r.texture/main.c:165
-msgid "Size of the moving window must be odd"
+#: ../raster/r.compress/main.c:207
+msgid "DONE: uncompressed file is %lu %s (%.2f%) smaller"
msgstr ""
-#: ../raster/r.texture/main.c:168
-msgid "The distance between two samples must be > 0"
+#: ../raster/r.compress/main.c:208
+msgid "DONE: compressed file is %lu %s (%.2f%) smaller"
msgstr ""
-#: ../raster/r.texture/main.c:189
-msgid "Nothing to compute. Use at least one textural measure."
+#: ../raster/r.compress/main.c:212
+msgid "DONE: uncompressed file is %lu %s (%.2f%) larger"
msgstr ""
-#: ../raster/r.texture/main.c:327
+#: ../raster/r.compress/main.c:213
+msgid "DONE: compressed file is %lu %s (%.2f%) larger"
+msgstr ""
+#: ../raster/r.compress/main.c:216
+#, fuzzy
+msgid "same size"
+msgstr "계열"
+#: ../raster/r.compress/main.c:232
#, fuzzy, c-format
-msgid "Calculating %d texture measure"
-msgid_plural "Calculating %d texture measures"
+msgid "<%s> already uncompressed"
+msgstr "<%s>가 이미 존재합니다"
-#: ../raster/r.texture/main.c:330
+#: ../raster/r.compress/main.c:235
#, fuzzy, c-format
-msgid "Calculating %s"
+msgid "Uncompressing <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.texture/h_measure.c:123
+#: ../raster/r.compress/main.c:243
+#, fuzzy, c-format
+msgid "Re-compressing <%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.compress/main.c:246
+#, fuzzy, c-format
+msgid "Compressing <%s>"
+msgstr "출력할 격자지도"
+#: ../raster/r.compress/main.c:304
#, c-format
-msgid ""
-"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
-"map"
+msgid "<%s> is a GDAL-linked map"
msgstr ""
+#: ../raster/r.compress/main.c:308
+#, fuzzy, c-format
+msgid "<%s> is a reclass file of map <%s> in mapset <%s>"
+msgstr "<%s>가 지도세트 <%s> 안에 이미 존재합니다."
+#: ../raster/r.compress/main.c:327
+#, c-format
+msgid "<%s> is uncompressed (method %i: %s). Data type: %s"
+msgstr ""
+#: ../raster/r.compress/main.c:334
+#, c-format
+msgid "<%s> is compressed (method %i: %s). Data type: %s"
+msgstr ""
#: ../raster/r.colors.out/raster3d_main.c:50
#, fuzzy
msgid "Exports the color table associated with a 3D raster map."
@@ -18844,782 +20954,916 @@
msgid "Exports the color table associated with a raster map."
msgstr "출력할 격자지도"
-#: ../raster/r.lake/main.c:153
-msgid "flood"
+#: ../raster/r.regression.multi/main.c:61
+msgid "Matrix is unsolvable"
msgstr ""
-#: ../raster/r.lake/main.c:154
-msgid "Fills lake at given point to given level."
-msgstr ""
+#: ../raster/r.regression.multi/main.c:132
+#, fuzzy
+msgid "Calculates multiple linear regression from raster maps."
+msgstr "출력할 격자지도"
-#: ../raster/r.lake/main.c:160
-msgid "Water level"
+#: ../raster/r.regression.multi/main.c:146
+msgid "Map to store residuals"
msgstr ""
-#: ../raster/r.lake/main.c:170
-msgid "Seed point coordinates"
+#: ../raster/r.regression.multi/main.c:151
+msgid "Map to store estimates"
msgstr ""
-#: ../raster/r.lake/main.c:171
+#: ../raster/r.regression.multi/main.c:249
#, fuzzy
-msgid "Either this coordinates pair or a seed map have to be specified"
+msgid "First pass..."
msgstr "출력할 격자지도"
-#: ../raster/r.lake/main.c:175 ../raster/r.lake/main.c:184
-msgid "Seed"
-msgstr ""
-#: ../raster/r.lake/main.c:180
+#: ../raster/r.regression.multi/main.c:322
#, fuzzy
-msgid "Input raster map with given starting point(s) (at least 1 cell > 0)"
+msgid "Not enough valid cells available"
msgstr "출력할 격자지도"
-#: ../raster/r.lake/main.c:182
+#: ../raster/r.regression.multi/main.c:336
+msgid "Multiple regression failed"
+msgstr ""
+#: ../raster/r.regression.multi/main.c:341
+msgid "Second pass..."
+msgstr ""
+#: ../raster/r.random.surface/main.c:61
+msgid "Generates random surface(s) with spatial dependence."
+msgstr ""
+#: ../raster/r.random.surface/main.c:68
#, fuzzy
-msgid "Either this parameter or a coordinates pair have to be specified"
+msgid "Name for output raster map(s)"
msgstr "출력할 격자지도"
-#: ../raster/r.lake/main.c:189
-msgid "Use negative depth values for lake raster map"
+#: ../raster/r.random.surface/main.c:85
+msgid "Distance decay exponent (value > 0.0)"
msgstr ""
-#: ../raster/r.lake/main.c:194
-msgid "Overwrite seed map with result (lake) map"
+#: ../raster/r.random.surface/main.c:94
+msgid "Distance filter remains flat before beginning exponent"
msgstr ""
-#: ../raster/r.lake/main.c:201
-msgid "Both seed map and coordinates cannot be specified"
+#: ../raster/r.random.surface/main.c:102
+msgid "Random seed (SEED_MIN >= value >= SEED_MAX), default [random]"
msgstr ""
-#: ../raster/r.lake/main.c:204
-msgid "Seed map or seed coordinates must be set!"
+#: ../raster/r.random.surface/main.c:108
+msgid "Maximum cell value of distribution"
msgstr ""
-#: ../raster/r.lake/main.c:207
-msgid "Seed coordinates and output map lake= must be set!"
+#: ../raster/r.random.surface/main.c:113
+msgid "Uniformly distributed cell values"
msgstr ""
-#: ../raster/r.lake/main.c:210
-msgid "Both lake and overwrite cannot be specified"
+#: ../raster/r.random.surface/init.c:73
+#, c-format
+msgid "High (%d) must be greater than 1"
msgstr ""
-#: ../raster/r.lake/main.c:213
-msgid "Output lake map or overwrite flag must be set!"
-msgstr ""
+#: ../raster/r.random.surface/init.c:82
+#, fuzzy, c-format
+msgid "Rastar map <%s> repeated, maps must be unique"
+msgstr "출력할 격자지도"
-#: ../raster/r.lake/main.c:240
+#: ../raster/r.random.surface/init.c:92
#, fuzzy
-msgid "Seed point outside the current region"
+msgid "Output raster map required"
msgstr "출력할 격자지도"
-#: ../raster/r.lake/main.c:254
-msgid "G_malloc: out of memory"
+#: ../raster/r.random.surface/init.c:108
+#, c-format
+msgid "Seed (%d) larger than maximum (%d)"
msgstr ""
-#: ../raster/r.lake/main.c:276
-msgid ""
-"Given water level at seed point is below earth surface. Increase water level "
-"or move seed point."
+#: ../raster/r.random.surface/init.c:111 ../raster/r.random.surface/init.c:120
+#, c-format
+msgid " seed is set to %d"
msgstr ""
-#: ../raster/r.lake/main.c:355
+#: ../raster/r.random.surface/init.c:116
#, c-format
-msgid "Lake depth from %f to %f (specified water level is taken as zero)"
+msgid "Seed (%d) smaller than minimum (%d)"
msgstr ""
-#: ../raster/r.lake/main.c:356
+#: ../raster/r.random.surface/init.c:159
#, c-format
-msgid "Lake area %f square meters"
+msgid "Distance value (%d): %lf must be >= 0.0"
msgstr ""
-#: ../raster/r.lake/main.c:357
+#: ../raster/r.random.surface/init.c:187
#, c-format
-msgid "Lake volume %f cubic meters"
+msgid "Exponent value (%lf) must be > 0.0"
msgstr ""
-#: ../raster/r.lake/main.c:358
-msgid "Volume is correct only if lake depth (terrain raster map) is in meters"
+#: ../raster/r.random.surface/init.c:211
+#, c-format
+msgid "Flat value (%lf) must be less than distance value (%lf)"
msgstr ""
-#: ../raster/r.category/main.c:53 ../vector/v.category/main.c:76
+#: ../raster/r.random.surface/init.c:232
+msgid "Must have a distance value for each filter"
+msgstr ""
+#: ../raster/r.random.surface/init.c:264
+msgid "Must have a exponent value for each filter"
+msgstr ""
+#: ../raster/r.random.surface/init.c:281
+msgid "Must have a weight value for each filter"
+msgstr ""
+#: ../raster/r.latlong/main.c:57
+msgid "latitude"
+msgstr ""
+#: ../raster/r.latlong/main.c:58
+msgid "longitude"
+msgstr ""
+#: ../raster/r.latlong/main.c:60
#, fuzzy
-msgid "category"
+msgid "Creates a latitude/longitude raster map."
msgstr "출력할 격자지도"
-#: ../raster/r.category/main.c:55
+#: ../raster/r.latlong/main.c:66
+#, fuzzy
+msgid "Name for output latitude or longitude raster map"
+msgstr "출력할 격자지도"
+#: ../raster/r.latlong/main.c:70
+msgid "Longitude output"
+msgstr ""
+#: ../raster/r.coin/main.c:69
msgid ""
-"Manages category values and labels associated with user-specified raster map "
-"layers."
+"Tabulates the mutual occurrence (coincidence) of categories for two raster "
+"map layers."
msgstr ""
-#: ../raster/r.category/main.c:69
-msgid "Comma separated value list"
+#: ../raster/r.coin/main.c:74
+#, fuzzy
+msgid "Name of first input raster map"
+msgstr "출력할 격자지도"
+#: ../raster/r.coin/main.c:78
+#, fuzzy
+msgid "Name of second input raster map"
+msgstr "출력할 격자지도"
+#: ../raster/r.coin/main.c:84
+msgid "Unit of measure"
msgstr ""
-#: ../raster/r.category/main.c:70
-msgid "Example: 1.4,3.8,13"
+#: ../raster/r.coin/main.c:86
+msgid ""
+"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
+"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
msgstr ""
-#: ../raster/r.category/main.c:87
-msgid "File containing category label rules (or \"-\" to read from stdin)"
+#: ../raster/r.coin/main.c:93
+msgid "Wide report, 132 columns (default: 80)"
msgstr ""
-#: ../raster/r.category/main.c:95
-msgid "Default label or format string for dynamic labeling"
+#: ../raster/r.coin/make_coin.c:48
+#, c-format
+msgid "Tabulating Coincidence between '%s' and '%s'"
msgstr ""
-#: ../raster/r.category/main.c:97
-msgid "Used when no explicit label exists for the category"
+#: ../raster/r.coin/make_coin.c:61
+msgid "Unable to create any tempfiles"
msgstr ""
-#: ../raster/r.category/main.c:105
-msgid "Dynamic label coefficients"
+#: ../raster/r.coin/make_coin.c:65
+msgid "Unable to run r.stats"
msgstr ""
-#: ../raster/r.category/main.c:107
-msgid "Two pairs of category multiplier and offsets, for $1 and $2"
+#: ../raster/r.coin/make_coin.c:72
+msgid "Unexpected output from r.stats"
msgstr ""
-#: ../raster/r.category/main.c:152
-#, fuzzy, c-format
-msgid "Category table for <%s> set from <%s>"
-msgstr "출력할 격자지도"
+#: ../raster/r.coin/make_coin.c:84
+msgid "Unable to open tempfile"
+msgstr ""
-#: ../raster/r.category/main.c:211
+#: ../raster/r.coin/print_coin.c:44
#, c-format
-msgid ""
-"Incorrect format of input rules. Check separators. Invalid line is:\n"
-"%s"
+msgid "Preparing report ..."
msgstr ""
-#: ../raster/r.category/main.c:267
-#, fuzzy, c-format
-msgid "Unable to read category file of raster map <%s> in <%s>"
+#: ../raster/r.out.ppm/main.c:56
+#, fuzzy
+msgid "Converts a GRASS raster map to a PPM image file."
msgstr "출력할 격자지도"
-#: ../raster/r.category/main.c:283
-msgid "The map is floating point! Ignoring cats list, using vals list"
+#: ../raster/r.out.ppm/main.c:64
+msgid "Name for new PPM file (use '-' for stdout)"
msgstr ""
-#: ../raster/r.category/main.c:300
-msgid "vals argument is required for floating point map!"
+#: ../raster/r.out.ppm/main.c:68
+msgid "Output greyscale instead of color"
msgstr ""
-#: ../raster/r.category/cats.c:47
+#: ../raster/r.out.ppm/main.c:72
+msgid "Suppress printing of PPM header"
+msgstr ""
+#: ../raster/r.out.ppm/main.c:124
#, fuzzy, c-format
-msgid "Reading <%s> in <%s>"
+msgid "Unable to open file <%s> for write"
msgstr "출력할 격자지도"
-#: ../raster/r.surf.contour/main.c:64
-#, fuzzy
-msgid "Generates surface raster map from rasterized contours."
-msgstr "출력할 격자지도"
+#: ../raster/r.out.ppm/main.c:154
+msgid "Converting..."
+msgstr ""
-#: ../raster/r.surf.contour/main.c:67
-#, fuzzy
-msgid "Name of input raster map containing contours"
-msgstr "출력할 격자지도"
+#: ../raster/r.out.ppm/main.c:234
+#, c-format
+msgid "File <%s> created"
+msgstr ""
-#: ../raster/r.describe/main.c:57
-msgid "Prints terse list of category values found in a raster map layer."
+#: ../raster/r.support/check.c:26
+#, c-format
+msgid ""
+"\n"
+" Updating statistics for [%s]"
msgstr ""
-#: ../raster/r.describe/main.c:71
-msgid "Number of quantization steps"
+#: ../raster/r.support/check.c:69
+#, c-format
+msgid ""
+" Updating the number of categories for [%s]\n"
+"\n"
msgstr ""
-#: ../raster/r.describe/main.c:77
-msgid "Print the output one value per line"
+#: ../raster/r.support/main.c:56
+msgid "Allows creation and/or modification of raster map layer support files."
msgstr ""
-#: ../raster/r.describe/main.c:81
-msgid "Only print the range of the data"
+#: ../raster/r.support/main.c:80
+msgid "Text to use for map data units"
msgstr ""
-#: ../raster/r.describe/main.c:85
-msgid "Suppress reporting of any NULLs"
+#: ../raster/r.support/main.c:86
+msgid "Text to use for map vertical datum"
msgstr ""
-#: ../raster/r.describe/main.c:89
-msgid "Use the current region"
+#: ../raster/r.support/main.c:129
+msgid "Update statistics (histogram, range)"
msgstr ""
-#: ../raster/r.describe/main.c:93
-#, fuzzy
-msgid "Read floating-point map as integer"
-msgstr "부동소수점 지도를 지도의 퀀트 규칙을 이용해서 정수로 읽습니다"
+#: ../raster/r.support/main.c:133
+msgid "Create/reset the null file"
+msgstr ""
-#: ../raster/r.describe/main.c:105
+#: ../raster/r.support/main.c:137
+msgid "Delete the null file"
+msgstr ""
+#: ../raster/r.support/main.c:273 ../raster/r.support/main.c:301
#, c-format
-msgid "%s = %s -- must be greater than zero"
+msgid "[%s] is a reclass of another map. Exiting."
msgstr ""
-#: ../raster/r.describe/describe.c:94
-#, fuzzy, c-format
-msgid "Reading <%s> ..."
-msgstr "출력할 격자지도"
+#: ../raster/r.support/main.c:285
+#, c-format
+msgid "Writing new null file for [%s]... "
+msgstr ""
-#: ../raster/r.regression.multi/main.c:61
-msgid "Matrix is unsolvable"
+#: ../raster/r.support/main.c:305
+#, c-format
+msgid "Removing null file for [%s]...\n"
msgstr ""
-#: ../raster/r.regression.multi/main.c:130
-#: ../raster/r.regression.line/main.c:48
-#, fuzzy
-msgid "regression"
-msgstr "변환"
+#: ../raster/r.support/main.c:312
+msgid "Done."
+msgstr ""
-#: ../raster/r.regression.multi/main.c:132
+#: ../raster/r.region/main.c:54
+msgid "Sets the boundary definitions for a raster map."
+msgstr ""
+#: ../raster/r.region/main.c:60
+msgid "Set from current region"
+msgstr ""
+#: ../raster/r.region/main.c:71
#, fuzzy
-msgid "Calculates multiple linear regression from raster maps."
+msgid "Name of raster map to change"
msgstr "출력할 격자지도"
-#: ../raster/r.regression.multi/main.c:137
-#: ../raster/r.regression.line/main.c:55
-msgid "Map for x coefficient"
+#: ../raster/r.region/main.c:79
+msgid "Set region from named region"
msgstr ""
-#: ../raster/r.regression.multi/main.c:141
-#: ../raster/r.regression.line/main.c:59
-msgid "Map for y coefficient"
+#: ../raster/r.region/main.c:87
+msgid "Set region to match this raster map"
msgstr ""
-#: ../raster/r.regression.multi/main.c:146
-msgid "Map to store residuals"
+#: ../raster/r.region/main.c:94
+msgid "Set region to match this vector map"
msgstr ""
-#: ../raster/r.regression.multi/main.c:151
-msgid "Map to store estimates"
+#: ../raster/r.region/main.c:137
+msgid "Raster map to align to"
msgstr ""
-#: ../raster/r.regression.multi/main.c:157
-#: ../raster/r.regression.line/main.c:65
+#: ../raster/r.carve/main.c:76
+msgid "Generates stream channels."
+msgstr ""
+#: ../raster/r.carve/main.c:77
msgid ""
-"ASCII file for storing regression coefficients (output to screen if file not "
-"specified)."
+"Takes vector stream data, transforms it to raster and subtracts depth from "
+"the output DEM."
msgstr ""
-#: ../raster/r.regression.multi/main.c:249
+#: ../raster/r.carve/main.c:82
+msgid "Name of input raster elevation map"
+msgstr ""
+#: ../raster/r.carve/main.c:87
#, fuzzy
-msgid "First pass..."
+msgid "Name of input vector map containing stream(s)"
msgstr "출력할 격자지도"
-#: ../raster/r.regression.multi/main.c:322
+#: ../raster/r.carve/main.c:95
#, fuzzy
-msgid "Not enough valid cells available"
+msgid "Name for output vector map for adjusted stream points"
msgstr "출력할 격자지도"
-#: ../raster/r.regression.multi/main.c:336
-msgid "Multiple regression failed"
+#: ../raster/r.carve/main.c:100
+msgid "Stream width (in meters)"
msgstr ""
-#: ../raster/r.regression.multi/main.c:341
-msgid "Second pass..."
+#: ../raster/r.carve/main.c:101
+msgid "Default is raster cell width"
msgstr ""
-#: ../raster/r.mapcalc/map3.c:181 ../raster/r.mapcalc/map.c:224
-#, fuzzy, c-format
-msgid "Unable to read color file for raster map <%s@%s>"
-msgstr "출력할 격자지도"
+#: ../raster/r.carve/main.c:106
+msgid "Additional stream depth (in meters)"
+msgstr ""
-#: ../raster/r.mapcalc/map3.c:194 ../raster/r.mapcalc/map.c:237
-#, fuzzy, c-format
-msgid "Unable to create btree for raster map <%s@%s>"
-msgstr "출력할 격자지도"
+#: ../raster/r.carve/main.c:110
+msgid "No flat areas allowed in flow direction"
+msgstr ""
-#: ../raster/r.mapcalc/map3.c:239 ../raster/r.mapcalc/map3.c:423
-#: ../raster/r.mapcalc/map3.c:468 ../raster/r.mapcalc/map3.c:565
-#: ../raster/r.mapcalc/map.c:286 ../raster/r.mapcalc/map.c:493
-#: ../raster/r.mapcalc/map.c:534 ../raster/r.mapcalc/map.c:632
-#: ../raster/r.mapcalc/expression.c:357
+#: ../raster/r.carve/main.c:134
#, c-format
-msgid "Invalid map modifier: '%c'"
+msgid "Invalid width value '%s' - using default."
msgstr ""
-#: ../raster/r.mapcalc/map3.c:353 ../raster/r.mapcalc/map.c:424
-#: ../raster/r.mapcalc/evaluate.c:94 ../raster/r.mapcalc/evaluate.c:234
+#: ../raster/r.carve/main.c:148
#, c-format
-msgid "Unknown type: %d"
+msgid "Invalid depth value '%s' - using default."
msgstr ""
-#: ../raster/r.mapcalc/map3.c:372
-#, fuzzy, c-format
-msgid "Unable to close raster map <%s@%s>"
-msgstr "출력할 격자지도"
+#: ../raster/r.carve/lobf.c:74
+msgid "trying to divide by zero...no unique solution for system...skipping..."
+msgstr ""
-#: ../raster/r.mapcalc/map3.c:631
-#, fuzzy
-msgid "Unable to close output raster map"
-msgstr "출력할 격자지도"
-#: ../raster/r.mapcalc/expression.c:206
-#, c-format
-msgid "Undefined variable '%s'"
+#: ../raster/r.carve/enforce_ds.c:83
+msgid "Processing lines... "
msgstr ""
-#: ../raster/r.mapcalc/expression.c:221
-#, c-format
-msgid "Invalid map <%s>"
+#: ../raster/r.carve/enforce_ds.c:175
+msgid ""
+"Vect runs out of region and re-enters - this case is not yet implemented."
msgstr ""
-#: ../raster/r.mapcalc/expression.c:262
-#, c-format
-msgid "Undefined function '%s'"
+#: ../raster/r.rescale/main.c:51
+msgid "Rescales the range of category values in a raster map layer."
msgstr ""
-#: ../raster/r.mapcalc/expression.c:267
+#: ../raster/r.rescale/main.c:110
#, c-format
-msgid "Too few arguments (%d) to function %s()"
+msgid "Rescale %s[%ld,%ld] to %s[%ld,%ld]"
msgstr ""
-#: ../raster/r.mapcalc/expression.c:271
-#, c-format
-msgid "Too many arguments (%d) to function %s()"
+#: ../raster/r.gwflow/main.c:57
+#, fuzzy
+msgid "Name of input raster map with initial piezometric head in [m]"
+msgstr "출력할 격자지도"
+#: ../raster/r.gwflow/main.c:62
+msgid ""
+"Name of input raster map providing boundary condition status: 0-inactive, 1-"
+"active, 2-dirichlet"
msgstr ""
-#: ../raster/r.mapcalc/expression.c:275
-#, c-format
-msgid "Incorrect argument types to function %s()"
+#: ../raster/r.gwflow/main.c:67
+msgid ""
+"Name of input raster map with x-part of the hydraulic conductivity tensor in "
+"[m/s]"
msgstr ""
-#: ../raster/r.mapcalc/expression.c:278
-#, c-format
-msgid "Internal error for function %s()"
+#: ../raster/r.gwflow/main.c:72
+msgid ""
+"Name of input raster map with y-part of the hydraulic conductivity tensor in "
+"[m/s]"
msgstr ""
-#: ../raster/r.mapcalc/expression.c:453
-#, c-format
-msgid "Illegal number of arguments (%d) for operator '%s'"
+#: ../raster/r.gwflow/main.c:77
+#, fuzzy
+msgid "Name of input raster map with water sources and sinks in [m^3/s]"
+msgstr "출력할 격자지도"
+#: ../raster/r.gwflow/main.c:81
+msgid ""
+"Name of input raster map with storativity for confined or effective porosity "
+"for unconfined groundwater flow booth in [-] "
msgstr ""
-#: ../raster/r.mapcalc/expression.c:493
-#, c-format
-msgid "Format_expression_prec: unknown type: %d"
+#: ../raster/r.gwflow/main.c:86
+msgid "Recharge"
msgstr ""
-#: ../raster/r.mapcalc/main.c:71
+#: ../raster/r.gwflow/main.c:88
#, fuzzy
-msgid "Raster map calculator."
+msgid "Recharge input raster map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
msgstr "출력할 격자지도"
-#: ../raster/r.mapcalc/main.c:78
-msgid "Expression to evaluate"
-msgstr ""
+#: ../raster/r.gwflow/main.c:92
+#, fuzzy
+msgid ""
+"Name of input raster map describing the top surface of the aquifer in [m]"
+msgstr "출력할 격자지도"
-#: ../raster/r.mapcalc/main.c:79 ../raster/r.mapcalc/main.c:85
+#: ../raster/r.gwflow/main.c:96
#, fuzzy
-msgid "Expression"
+msgid ""
+"Name of input raster map describing the bottom surface of the aquifer in [m]"
msgstr "출력할 격자지도"
-#: ../raster/r.mapcalc/main.c:84
+#: ../raster/r.gwflow/main.c:100
#, fuzzy
-msgid "File containing expression(s) to evaluate"
+msgid "Output raster map storing the numerical result [m]"
msgstr "출력할 격자지도"
-#: ../raster/r.mapcalc/main.c:91
-msgid "Seed for rand() function"
+#: ../raster/r.gwflow/main.c:106
+#, fuzzy
+msgid ""
+"Output raster map to store the groundwater filter velocity vector part in x "
+"direction [m/s]"
+msgstr "출력할 격자지도"
+#: ../raster/r.gwflow/main.c:112
+#, fuzzy
+msgid ""
+"Output raster map to store the groundwater filter velocity vector part in y "
+"direction [m/s]"
+msgstr "출력할 격자지도"
+#: ../raster/r.gwflow/main.c:118
+#, fuzzy
+msgid "Output raster map to store the groundwater budget for each cell [m^3/s]"
+msgstr "출력할 격자지도"
+#: ../raster/r.gwflow/main.c:126
+msgid "The type of groundwater flow"
msgstr ""
-#: ../raster/r.mapcalc/main.c:95
-msgid "Generate random seed (result is non-deterministic)"
+#: ../raster/r.gwflow/main.c:132
+#, fuzzy
+msgid "Name of input raster map providing the height of the river bed in [m]"
+msgstr "출력할 격자지도"
+#: ../raster/r.gwflow/main.c:140
+msgid ""
+"Name of input raster map providing the water level (head) of the river with "
+"leakage connection in [m]"
msgstr ""
-#: ../raster/r.mapcalc/main.c:99
+#: ../raster/r.gwflow/main.c:147
#, fuzzy
-msgid "List input and output maps"
+msgid ""
+"Name of input raster map providing the leakage coefficient of the river bed "
+"in [1/s]."
msgstr "출력할 격자지도"
-#: ../raster/r.mapcalc/main.c:121
-#, fuzzy, c-format
-msgid "%s= and -%c are mutually exclusive"
+#: ../raster/r.gwflow/main.c:155
+#, fuzzy
+msgid ""
+"Name of input raster map providing the height of the drainage bed in [m]"
+msgstr "출력할 격자지도"
-#: ../raster/r.mapcalc/main.c:132
-msgid "parse error"
-msgstr ""
+#: ../raster/r.gwflow/main.c:162
+#, fuzzy
+msgid ""
+"Name of input raster map providing the leakage coefficient of the drainage "
+"bed in [1/s]"
+msgstr "출력할 격자지도"
-#: ../raster/r.mapcalc/main.c:159
-msgid "Floating point error(s) occurred in the calculation"
+#: ../raster/r.gwflow/main.c:167
+msgid "The maximum number of iterations in the linearization approach"
msgstr ""
-#: ../raster/r.mapcalc/function.c:33
-#, c-format
-msgid "Known functions:"
+#: ../raster/r.gwflow/main.c:176
+msgid ""
+"Allocate a full quadratic linear equation system, default is a sparse linear "
+"equation system."
msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:140
-#, c-format
-msgid "Invalid type: %d"
+#: ../raster/r.gwflow/main.c:212
+msgid ""
+"Numerical calculation program for transient, confined and unconfined "
+"groundwater flow in two dimensions."
msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:179
-#, c-format
-msgid "Too few arguments for function '%s'"
+#: ../raster/r.gwflow/main.c:237
+msgid "Please provide river_head, river_leak and river_bed maps"
msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:183
-#, c-format
-msgid "Too many arguments for function '%s'"
+#: ../raster/r.gwflow/main.c:249
+msgid "Please provide drain_head and drain_leak maps"
msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:187
-#, c-format
-msgid "Invalid argument type for function '%s'"
+#: ../raster/r.gwflow/main.c:263
+msgid ""
+"The cholesky solver dos not work with sparse matrices. You may choose a full "
+"filled quadratic matrix, flag -f."
msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:191
-#, c-format
-msgid "Invalid return type for function '%s'"
-msgstr ""
+#: ../raster/r.gwflow/main.c:293
+#, fuzzy, c-format
+msgid "Calculation time: %g"
+msgstr "출력할 격자지도"
-#: ../raster/r.mapcalc/evaluate.c:195
+#: ../raster/r.gwflow/main.c:380
#, c-format
-msgid "Unknown type for function '%s'"
+msgid "Calculation of unconfined groundwater flow loop %i"
msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:198
+#: ../raster/r.gwflow/main.c:403
#, c-format
-msgid "Number of arguments for function '%s'"
+msgid "Maximum difference between this and last increment: %g"
msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:202
-#, c-format
-msgid "Unknown error for function '%s'"
-msgstr ""
+#: ../raster/r.topmodel/file_io.c:56
+#, fuzzy, c-format
+msgid "%s cannot be 0"
+msgstr "출력할 격자지도"
-#: ../raster/r.mapcalc/evaluate.c:282
-#, c-format
-msgid "output map <%s> exists. To overwrite, use the --overwrite flag"
-msgstr ""
+#: ../raster/r.topmodel/file_io.c:209 ../raster/r.topmodel/topmodel.c:75
+#: ../vector/v.out.pov/main.c:104
+#, fuzzy, c-format
+msgid "Unable to create output file <%s>"
+msgstr "출력할 격자지도"
-#: ../raster/r.watershed/seg/do_astar.c:30
-#: ../raster/r.watershed/ram/do_astar.c:27
-msgid "SECTION 2: A* Search."
+#: ../raster/r.topmodel/main.c:55
+msgid "Simulates TOPMODEL which is a physically based hydrologic model."
msgstr ""
-#: ../raster/r.watershed/seg/do_astar.c:48
-msgid "No seeds for A* Search"
-msgstr ""
+#: ../raster/r.topmodel/main.c:60
+#, fuzzy
+msgid "Name of input TOPMODEL parameters file"
+msgstr "출력할 격자지도"
-#: ../raster/r.watershed/seg/do_astar.c:146
-msgid "bug in A* Search: doer %"
+#: ../raster/r.topmodel/main.c:65
+#, fuzzy
+msgid "Name of input topographic index statistics file"
+msgstr "출력할 격자지도"
+#: ../raster/r.topmodel/main.c:69
+#, fuzzy
+msgid "Name of input rainfall and potential evapotranspiration data file"
+msgstr "출력할 격자지도"
+#: ../raster/r.topmodel/main.c:76
+msgid "Time step"
msgstr ""
-#: ../raster/r.watershed/seg/sg_factor.c:14
-msgid "SECTION 5: RUSLE LS and/or S factor determination."
+#: ../raster/r.topmodel/main.c:77
+#, fuzzy
+msgid "Generate output for this time step"
+msgstr "출력할 격자지도"
+#: ../raster/r.topmodel/main.c:83
+#, fuzzy
+msgid "Topographic index class"
+msgstr "출력할 격자지도"
+#: ../raster/r.topmodel/main.c:85
+#, fuzzy
+msgid "Generate output for this topographic index class"
+msgstr "출력할 격자지도"
+#: ../raster/r.topmodel/main.c:92
+msgid "Name of input topographic index raster map"
+msgstr "입력 위상색인 격자지도의 이름"
+#: ../raster/r.topmodel/main.c:94
+msgid ""
+"Must be clipped to the catchment boundary. Used for generating outtopidxstats"
msgstr ""
-#: ../raster/r.watershed/seg/close_maps2.c:38
-#: ../raster/r.watershed/ram/close_maps2.c:34
-msgid "No basins were created. Verify threshold and region settings."
+#: ../raster/r.topmodel/main.c:96 ../raster/r.topmodel/main.c:106
+#: ../raster/r.topmodel/main.c:115
+msgid "Preprocess"
msgstr ""
-#: ../raster/r.watershed/seg/close_maps2.c:86
-msgid "Closing stream segments map"
+#: ../raster/r.topmodel/main.c:100
+#, fuzzy
+msgid "Number of topographic index classes"
+msgstr "출력할 격자지도"
+#: ../raster/r.topmodel/main.c:102
+msgid "Used for generating outtopidxstats"
msgstr ""
-#: ../raster/r.watershed/seg/close_maps2.c:109
+#: ../raster/r.topmodel/main.c:111
#, fuzzy
-msgid "Closing basins map"
+msgid "Name for output topographic index statistics file"
msgstr "출력할 격자지도"
-#: ../raster/r.watershed/seg/close_maps2.c:116
-msgid "Closing half basins map"
+#: ../raster/r.topmodel/main.c:113
+msgid "Requires topidx and ntopidxclasses"
msgstr ""
-#: ../raster/r.watershed/seg/main.c:92 ../raster/r.watershed/seg/main.c:107
-#: ../raster/r.watershed/ram/main.c:82 ../raster/r.watershed/ram/main.c:98
-#, c-format
-msgid "SECTION %d: Closing Maps."
+#: ../raster/r.topmodel/main.c:120
+msgid "Preprocess only and stop after generating outtopidxstats"
msgstr ""
-#: ../raster/r.watershed/seg/main.c:105 ../raster/r.watershed/ram/main.c:96
+#: ../raster/r.topmodel/main.c:150
+#, fuzzy, c-format
+msgid "%s must be greater than 1"
+msgstr "출력할 격자지도"
+#: ../raster/r.topmodel/main.c:154 ../raster/r.topmodel/main.c:157
#, c-format
-msgid "SECTION %d: Watershed determination."
+msgid "Ignoring %s because %s is not specified"
msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:20
-msgid "Closing accumulation map"
-msgstr ""
+#: ../raster/r.topmodel/topmodel.c:30
+#, fuzzy, c-format
+msgid "Unable to run %s"
+msgstr "출력할 격자지도"
-#: ../raster/r.watershed/seg/close_maps.c:136
-#, fuzzy
-msgid "Closing TCI and SPI maps"
+#: ../raster/r.topmodel/topmodel.c:72
+#, fuzzy, c-format
+msgid "Invalid %s output"
msgstr "출력할 격자지도"
-#: ../raster/r.watershed/seg/close_maps.c:138
+#: ../raster/r.topmodel/infiltration.c:69
+#: ../raster/r.topmodel/infiltration.c:108
+#, fuzzy, c-format
+msgid "Maximum number of iterations exceeded at timestep %d"
+msgstr "출력할 격자지도"
+#: ../raster/r.out.vtk/parameters.c:32
#, fuzzy
-msgid "Closing TCI map"
+msgid "Raster map(s) to be converted to VTK-ASCII data format"
msgstr "출력할 격자지도"
-#: ../raster/r.watershed/seg/close_maps.c:140
+#: ../raster/r.out.vtk/parameters.c:53
#, fuzzy
-msgid "Closing SPI map"
+msgid "Constant elevation (if no elevation map is specified)"
msgstr "출력할 격자지도"
-#: ../raster/r.watershed/seg/close_maps.c:300
-msgid "Closing flow direction map"
+#: ../raster/r.out.vtk/parameters.c:69
+msgid ""
+"Three (r,g,b) raster maps to create RGB values [redmap,greenmap,bluemap]"
msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:327
-msgid "Closing LS map"
+#: ../raster/r.out.vtk/parameters.c:79
+msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:332
-msgid "Closing SL map"
+#: ../raster/r.out.vtk/parameters.c:104
+msgid "Use structured grid for elevation (not recommended)"
msgstr ""
-#: ../raster/r.watershed/seg/usage.c:9 ../raster/r.watershed/ram/usage.c:9
-#, c-format
+#: ../raster/r.out.vtk/parameters.c:110
+msgid "Use polydata-trianglestrips for elevation grid creation"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:116
msgid ""
-"USAGE for basin delineation:\n"
-"%s -4 elevation=elevation_map threshold=swale_threshold "
-"[flow=overland_flow_map] [drainage=drain_direction_map] "
-"[depression=depression_map] [accumulation=accumulation_map] "
-"[basin=watershed_basin_map] [stream=stream_segment_map]\n"
-"\n"
-"USAGE for slope length determination:\n"
-"%s [-4] elevation=elevation_map threshold=swale_threshold "
-"[drainage=drain_direction_map] [depression=depression_map] "
-"[accumulation=accumulation_map] [max_slope_length=max_slope_length] "
-"[blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] "
-"length_slope=length_slope_map [disturbed_land=rill_erosion_map] "
-"[slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE "
-"creation:\n"
-"[basin=watershed_basin_map] [stream=stream_segment_map] "
-"[half_basin=half_basin_map] ar=ARMSED_file_name\n"
-"\n"
+"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
msgstr ""
-#: ../raster/r.watershed/seg/do_cum.c:119
-#: ../raster/r.watershed/ram/do_cum.c:114
-msgid "SECTION 3: Accumulating Surface Flow with SFD."
+#: ../raster/r.out.vtk/parameters.c:122
+msgid "Scale factor affects the origin (if no elevation map is given)"
msgstr ""
-#: ../raster/r.watershed/seg/do_cum.c:293
-#: ../raster/r.watershed/ram/do_cum.c:276
-msgid "SECTION 3a: Accumulating Surface Flow with MFD."
+#: ../raster/r.out.vtk/writeascii.c:75
+msgid "write_vtk_normal_header: Writing VTK-Header"
msgstr ""
-#: ../raster/r.watershed/seg/do_cum.c:529
-msgid "MFD: A * path already processed when distributing flow: %d of %"
+#: ../raster/r.out.vtk/writeascii.c:108
+msgid "write_vtk_structured_elevation_header: Writing VTK-Header"
msgstr ""
-#: ../raster/r.watershed/seg/do_cum.c:533
-#: ../raster/r.watershed/ram/do_cum.c:486
-msgid "SECTION 3b: Adjusting drainage directions."
+#: ../raster/r.out.vtk/writeascii.c:124
+msgid "write_vtk_polygonal_elevation_header: Writing VTK-Header"
msgstr ""
-#: ../raster/r.watershed/seg/init_vars.c:139
-#, c-format
-msgid "SECTION 1 beginning: Initiating Variables. %d section total."
-msgid_plural "SECTION 1 beginning: Initiating Variables. %d sections total."
-msgstr[0] ""
-msgstr[1] ""
+#: ../raster/r.out.vtk/writeascii.c:139
+msgid "write_vtk_celldata_header: Writing VTK-DataHeader"
+msgstr ""
-#: ../raster/r.watershed/seg/init_vars.c:175
-msgid "Maximum memory to be used was smaller than 3 MB, set to 3 MB."
+#: ../raster/r.out.vtk/writeascii.c:148
+msgid "writeVTKPointHeader: Writing VTK-DataHeader"
msgstr ""
-#: ../raster/r.watershed/seg/init_vars.c:470
-msgid "SECTION 1b: Determining Offmap Flow."
+#: ../raster/r.out.vtk/writeascii.c:169
+msgid "write_vtk_structured_coordinates: Writing Coordinates"
msgstr ""
-#: ../raster/r.watershed/front/main.c:76
-msgid "Calculates hydrological parameters and RUSLE factors."
+#: ../raster/r.out.vtk/writeascii.c:225
+msgid "write_vtk_polygonal_coordinates: Writing VTK Polygonal data"
msgstr ""
-#: ../raster/r.watershed/front/main.c:79 ../raster/r.watershed/front/main.c:86
-#: ../raster/r.watershed/front/main.c:92 ../raster/r.watershed/front/main.c:99
-#: ../raster/r.watershed/front/main.c:108
-#: ../raster/r.watershed/front/main.c:116
-#: ../raster/r.watershed/front/main.c:125
-msgid "Inputs"
+#: ../raster/r.out.vtk/writeascii.c:334
+msgid "write_vtk_data: Writing VTK-Data"
msgstr ""
-#: ../raster/r.watershed/front/main.c:83
-#, fuzzy
-msgid "Name of input depressions raster map"
-msgstr "출력할 격자지도"
+#: ../raster/r.out.vtk/writeascii.c:384
+msgid "write_vtk_rgb_image_data: Writing VTK-ImageData"
+msgstr ""
-#: ../raster/r.watershed/front/main.c:84
-msgid "All non-NULL and non-zero cells are considered as real depressions"
+#: ../raster/r.out.vtk/writeascii.c:412
+msgid "Wrong map values! Values should in between 0 and 255!\n"
msgstr ""
-#: ../raster/r.watershed/front/main.c:90
-#, fuzzy
-msgid "Name of input raster representing amount of overland flow per cell"
-msgstr "출력할 격자지도"
+#: ../raster/r.out.vtk/writeascii.c:442
+msgid "write_vtk_vector_data: Writing VTK-vector data"
+msgstr ""
-#: ../raster/r.watershed/front/main.c:96
+#: ../raster/r.out.vtk/main.c:62
#, fuzzy
-msgid "Name of input raster map percent of disturbed land"
+msgid "Converts raster maps into the VTK-ASCII format."
msgstr "출력할 격자지도"
-#: ../raster/r.watershed/front/main.c:97
-#: ../raster/r.watershed/front/main.c:122
-msgid "For USLE"
+#: ../raster/r.out.vtk/main.c:73
+msgid ""
+"No input maps specified. You need to specify at least one input map or three "
+"vector maps or three rgb maps."
msgstr ""
-#: ../raster/r.watershed/front/main.c:104
-#, fuzzy
-msgid "Name of input raster map blocking overland surface flow"
-msgstr "출력할 격자지도"
+#: ../raster/r.out.vtk/main.c:131 ../raster/r.out.vtk/main.c:191
+#: ../raster/r.out.vtk/main.c:212 ../raster/r.out.vtk/main.c:251
+#, c-format
+msgid "Open Raster file %s"
+msgstr ""
-#: ../raster/r.watershed/front/main.c:106
-msgid ""
-"For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
+#: ../raster/r.out.vtk/main.c:222
+msgid "Writing VTK ImageData\n"
msgstr ""
-#: ../raster/r.watershed/front/main.c:113
-msgid "Minimum size of exterior watershed basin"
+#: ../raster/r.out.vtk/main.c:232
+msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
msgstr ""
-#: ../raster/r.watershed/front/main.c:121
-msgid "Maximum length of surface flow in map units"
+#: ../raster/r.out.vtk/main.c:261
+msgid "Writing VTK Vector Data\n"
msgstr ""
-#: ../raster/r.watershed/front/main.c:130
-#, fuzzy
-msgid "Name for output accumulation raster map"
-msgstr "출력할 격자지도"
+#: ../raster/r.out.vtk/main.c:271
+msgid ""
+"Wrong vector maps. Maps should have the same type! Vector output not added!"
+msgstr ""
-#: ../raster/r.watershed/front/main.c:132
-#, fuzzy
-msgid "Number of cells that drain through each cell"
-msgstr "출력할 격자지도"
+#: ../raster/r.out.vtk/main.c:283
+msgid "Error closing VTK-ASCII file"
+msgstr ""
-#: ../raster/r.watershed/front/main.c:139
+#: ../raster/r.water.outlet/main.c:56
#, fuzzy
-msgid "Name for output topographic index ln(a / tan(b)) map"
-msgstr "출력 위상색인 격자지도의 이름"
-#: ../raster/r.watershed/front/main.c:146
-#, fuzzy
-msgid "Stream power index a * tan(b)"
+msgid "Creates watershed basins from a drainage direction map."
msgstr "출력할 격자지도"
-#: ../raster/r.watershed/front/main.c:152
+#: ../raster/r.water.outlet/main.c:62
#, fuzzy
-msgid "Name for output drainage direction raster map"
+msgid "Name of input drainage direction map"
msgstr "출력할 격자지도"
-#: ../raster/r.watershed/front/main.c:158
+#: ../raster/r.water.outlet/main.c:65
#, fuzzy
-msgid "Name for output basins raster map"
+msgid "Name for output watershed basin map"
msgstr "출력할 격자지도"
-#: ../raster/r.watershed/front/main.c:164
+#: ../raster/r.water.outlet/main.c:68
#, fuzzy
-msgid "Name for output stream segments raster map"
+msgid "Coordinates of outlet point"
msgstr "출력할 격자지도"
-#: ../raster/r.watershed/front/main.c:170
-#, fuzzy
-msgid "Name for output half basins raster map"
+#: ../raster/r.water.outlet/main.c:81
+#, fuzzy, c-format
+msgid "Illegal east coordinate '%s'"
msgstr "출력할 격자지도"
-#: ../raster/r.watershed/front/main.c:172
-msgid "Each half-basin is given a unique value"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:178
-#, fuzzy
-msgid "Name for output slope length raster map"
+#: ../raster/r.water.outlet/main.c:83
+#, fuzzy, c-format
+msgid "Illegal north coordinate '%s'"
msgstr "출력할 격자지도"
-#: ../raster/r.watershed/front/main.c:180
-msgid "Slope length and steepness (LS) factor for USLE"
+#: ../raster/r.water.outlet/main.c:88
+#, c-format
+msgid "Ignoring point outside computation region: %.4f,%.4f"
msgstr ""
-#: ../raster/r.watershed/front/main.c:186
+#: ../raster/r.resamp.stats/main.c:261
#, fuzzy
-msgid "Name for output slope steepness raster map"
+msgid "Resamples raster map layers to a coarser grid using aggregation."
msgstr "출력할 격자지도"
-#: ../raster/r.watershed/front/main.c:187
-msgid "Slope steepness (S) factor for USLE"
+#: ../raster/r.resamp.stats/main.c:271
+msgid "Aggregation method"
msgstr ""
-#: ../raster/r.watershed/front/main.c:196
-msgid "Convergence factor for MFD (1-10)"
+#: ../raster/r.resamp.stats/main.c:289
+msgid "Weight according to area (slower)"
msgstr ""
-#: ../raster/r.watershed/front/main.c:198
-msgid "1 = most diverging flow, 10 = most converging flow. Recommended: 5"
+#: ../raster/r.patch/main.c:62
+msgid "patching"
msgstr ""
-#: ../raster/r.watershed/front/main.c:205
-msgid "Maximum memory to be used with -m flag (in MB)"
+#: ../raster/r.patch/main.c:64
+msgid ""
+"Creates a composite raster map layer by using known category values from one "
+"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
msgstr ""
-#: ../raster/r.watershed/front/main.c:209
-msgid "SFD (D8) flow (default is MFD)"
+#: ../raster/r.patch/main.c:71
+msgid "Name of raster maps to be patched together"
msgstr ""
-#: ../raster/r.watershed/front/main.c:211
-msgid "SFD: single flow direction, MFD: multiple flow direction"
-msgstr ""
+#: ../raster/r.patch/main.c:74
+#, fuzzy
+msgid "Name for resultant raster map"
+msgstr "출력할 격자지도"
-#: ../raster/r.watershed/front/main.c:216
-msgid "Allow only horizontal and vertical flow of water"
+#: ../raster/r.patch/main.c:81
+msgid "Use zero (0) for transparency instead of NULL"
msgstr ""
-#: ../raster/r.watershed/front/main.c:221
-msgid "Enable disk swap memory option: Operation is slow"
+#: ../raster/r.patch/main.c:86
+#, fuzzy
+msgid "Do not create color and category files"
+msgstr "출력할 격자지도"
+#: ../raster/r.patch/main.c:101
+msgid "The minimum number of input raster maps is two"
msgstr ""
-#: ../raster/r.watershed/front/main.c:223
-msgid ""
-"Only needed if memory requirements exceed available RAM; see manual on how "
-"to calculate memory requirements"
+#: ../raster/r.patch/main.c:178
+#, fuzzy, c-format
+msgid "Creating support files for raster map <%s>..."
+msgstr "격자지도 <%s>를 위한 지원파일을 생성합니다"
+#: ../raster/r.watershed/shed/read.c:23
+msgid "unable to open basin/half basin map"
msgstr ""
-#: ../raster/r.watershed/front/main.c:228
-msgid "Use positive flow accumulation even for likely underestimates"
+#: ../raster/r.watershed/shed/main.c:41
+msgid "Slow version of water analysis program starting now"
msgstr ""
-#: ../raster/r.watershed/front/main.c:230
-msgid "See manual for a detailed description of flow accumulation output"
+#: ../raster/r.watershed/shed/main.c:46 ../raster/r.watershed/shed/main.c:55
+#, c-format
+msgid "<<%s>> command line failed"
msgstr ""
-#: ../raster/r.watershed/front/main.c:235
-msgid "Beautify flat areas"
+#: ../raster/r.watershed/shed/main.c:72
+msgid "unable to open output file"
msgstr ""
-#: ../raster/r.watershed/front/main.c:237
-msgid "Flow direction in flat areas is modified to look prettier"
+#: ../raster/r.watershed/shed/valid.c:24
+msgid "accum file missing in valid_basins()"
msgstr ""
-#: ../raster/r.watershed/front/main.c:253
-msgid "Sorry, you must choose an output map."
+#: ../raster/r.watershed/shed/intro.c:8
+#, c-format
+msgid "%s provides a text-based user-interface to the %s program."
msgstr ""
-#: ../raster/r.watershed/front/main.c:259
-msgid "The basin threshold must be a positive number."
+#: ../raster/r.watershed/shed/intro.c:10
+#, c-format
+msgid "%s also allows the user to prepare a report of map layers for each"
msgstr ""
-#: ../raster/r.watershed/front/main.c:275
-msgid ""
-"Sorry, if any of the following options are set:\n"
-" basin, stream, half_basin, length_slope, or slope_steepness\n"
-" you MUST provide a value for the basin threshold parameter."
+#: ../raster/r.watershed/shed/intro.c:12
+#, c-format
+msgid "watershed basin determined in %s.\n"
msgstr ""
-#: ../raster/r.watershed/front/main.c:302
-msgid "Beautify flat areas is not yet supported for disk swap mode"
+#: ../raster/r.watershed/shed/intro.c:14
+#, c-format
+msgid "%s will help the user determine which options to use for the"
msgstr ""
-#: ../raster/r.watershed/front/main.c:332
+#: ../raster/r.watershed/shed/intro.c:16
#, c-format
-msgid "Subprocess failed with exit code %d"
+msgid "%s program. %s will then ask for map layers that will be"
msgstr ""
-#: ../raster/r.watershed/shed/valid.c:24
-msgid "accum file missing in valid_basins()"
+#: ../raster/r.watershed/shed/intro.c:18
+#, c-format
+msgid "divided by basin. %s will then run %s and create the report."
msgstr ""
#: ../raster/r.watershed/shed/basin_maps.c:12
@@ -19698,23 +21942,10 @@
"%s"
msgstr ""
-#: ../raster/r.watershed/shed/main.c:41
-msgid "Slow version of water analysis program starting now"
+#: ../raster/r.watershed/shed/file_in.c:15
+msgid "unable to open ARMSED file"
msgstr ""
-#: ../raster/r.watershed/shed/main.c:46 ../raster/r.watershed/shed/main.c:55
-#, c-format
-msgid "<<%s>> command line failed"
-msgstr ""
-#: ../raster/r.watershed/shed/main.c:72
-msgid "unable to open output file"
-msgstr ""
-#: ../raster/r.watershed/shed/read.c:23
-msgid "unable to open basin/half basin map"
-msgstr ""
#: ../raster/r.watershed/shed/com_line.c:23
msgid ""
"\n"
@@ -20072,38 +22303,86 @@
"Hit <return> by itself for the next question if there is no blocking map."
msgstr ""
-#: ../raster/r.watershed/shed/intro.c:8
+#: ../raster/r.watershed/ram/sg_factor.c:14
+msgid "SECTION 4: RUSLE LS and/or S factor determination."
+msgstr ""
+#: ../raster/r.watershed/ram/usage.c:9 ../raster/r.watershed/seg/usage.c:9
#, c-format
-msgid "%s provides a text-based user-interface to the %s program."
+msgid ""
+"USAGE for basin delineation:\n"
+"%s -4 elevation=elevation_map threshold=swale_threshold "
+"[flow=overland_flow_map] [drainage=drain_direction_map] "
+"[depression=depression_map] [accumulation=accumulation_map] "
+"[basin=watershed_basin_map] [stream=stream_segment_map]\n"
+"\n"
+"USAGE for slope length determination:\n"
+"%s [-4] elevation=elevation_map threshold=swale_threshold "
+"[drainage=drain_direction_map] [depression=depression_map] "
+"[accumulation=accumulation_map] [max_slope_length=max_slope_length] "
+"[blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] "
+"length_slope=length_slope_map [disturbed_land=rill_erosion_map] "
+"[slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE "
+"creation:\n"
+"[basin=watershed_basin_map] [stream=stream_segment_map] "
+"[half_basin=half_basin_map] ar=ARMSED_file_name\n"
+"\n"
msgstr ""
-#: ../raster/r.watershed/shed/intro.c:10
+#: ../raster/r.watershed/ram/do_cum.c:114
+#: ../raster/r.watershed/seg/do_cum.c:119
+msgid "SECTION 3: Accumulating Surface Flow with SFD."
+msgstr ""
+#: ../raster/r.watershed/ram/do_cum.c:276
+#: ../raster/r.watershed/seg/do_cum.c:293
+msgid "SECTION 3a: Accumulating Surface Flow with MFD."
+msgstr ""
+#: ../raster/r.watershed/ram/do_cum.c:480
#, c-format
-msgid "%s also allows the user to prepare a report of map layers for each"
+msgid "MFD: A * path already processed when distributing flow: %d of %d cell"
+msgid_plural ""
+"MFD: A * path already processed when distributing flow: %d of %d cells"
+msgstr[0] ""
+#: ../raster/r.watershed/ram/do_cum.c:486
+#: ../raster/r.watershed/seg/do_cum.c:533
+msgid "SECTION 3b: Adjusting drainage directions."
msgstr ""
-#: ../raster/r.watershed/shed/intro.c:12
+#: ../raster/r.watershed/ram/close_maps2.c:34
+#: ../raster/r.watershed/seg/close_maps2.c:38
+msgid "No basins were created. Verify threshold and region settings."
+msgstr ""
+#: ../raster/r.watershed/ram/main.c:82 ../raster/r.watershed/ram/main.c:98
+#: ../raster/r.watershed/seg/main.c:92 ../raster/r.watershed/seg/main.c:107
#, c-format
-msgid "watershed basin determined in %s.\n"
+msgid "SECTION %d: Closing Maps."
msgstr ""
-#: ../raster/r.watershed/shed/intro.c:14
+#: ../raster/r.watershed/ram/main.c:96 ../raster/r.watershed/seg/main.c:105
#, c-format
-msgid "%s will help the user determine which options to use for the"
+msgid "SECTION %d: Watershed determination."
msgstr ""
-#: ../raster/r.watershed/shed/intro.c:16
+#: ../raster/r.watershed/ram/init_vars.c:121
#, c-format
-msgid "%s program. %s will then ask for map layers that will be"
+msgid "SECTION 1a (of %1d): Initiating Memory."
msgstr ""
-#: ../raster/r.watershed/shed/intro.c:18
+#: ../raster/r.watershed/ram/init_vars.c:311
#, c-format
-msgid "divided by basin. %s will then run %s and create the report."
+msgid "SECTION 1b (of %1d): Determining Offmap Flow."
msgstr ""
-#: ../raster/r.watershed/shed/file_in.c:15
-msgid "unable to open ARMSED file"
+#: ../raster/r.watershed/ram/do_astar.c:27
+#: ../raster/r.watershed/seg/do_astar.c:30
+msgid "SECTION 2: A* Search."
msgstr ""
#: ../raster/r.watershed/ram/do_astar.c:256
@@ -20168,11703 +22447,11850 @@
msgid "flat cell escaped in adjustment"
msgstr ""
-#: ../raster/r.watershed/ram/sg_factor.c:14
-msgid "SECTION 4: RUSLE LS and/or S factor determination."
+#: ../raster/r.watershed/seg/sg_factor.c:14
+msgid "SECTION 5: RUSLE LS and/or S factor determination."
msgstr ""
-#: ../raster/r.watershed/ram/do_cum.c:480
+#: ../raster/r.watershed/seg/do_cum.c:529
+msgid "MFD: A * path already processed when distributing flow: %d of %"
+msgstr ""
+#: ../raster/r.watershed/seg/close_maps2.c:86
+msgid "Closing stream segments map"
+msgstr ""
+#: ../raster/r.watershed/seg/close_maps2.c:109
+#, fuzzy
+msgid "Closing basins map"
+msgstr "출력할 격자지도"
+#: ../raster/r.watershed/seg/close_maps2.c:116
+msgid "Closing half basins map"
+msgstr ""
+#: ../raster/r.watershed/seg/init_vars.c:139
#, c-format
-msgid "MFD: A * path already processed when distributing flow: %d of %d cell"
-msgid_plural ""
-"MFD: A * path already processed when distributing flow: %d of %d cells"
+msgid "SECTION 1 beginning: Initiating Variables. %d section total."
+msgid_plural "SECTION 1 beginning: Initiating Variables. %d sections total."
msgstr[0] ""
-msgstr[1] ""
-#: ../raster/r.watershed/ram/init_vars.c:121
-#, c-format
-msgid "SECTION 1a (of %1d): Initiating Memory."
+#: ../raster/r.watershed/seg/init_vars.c:175
+msgid "Maximum memory to be used was smaller than 3 MB, set to 3 MB."
msgstr ""
-#: ../raster/r.watershed/ram/init_vars.c:311
-#, c-format
-msgid "SECTION 1b (of %1d): Determining Offmap Flow."
+#: ../raster/r.watershed/seg/init_vars.c:470
+msgid "SECTION 1b: Determining Offmap Flow."
msgstr ""
-#: ../raster/r.spreadpath/main.c:92
-msgid ""
-"Recursively traces the least cost path backwards to cells from which the "
-"cumulative cost was determined."
+#: ../raster/r.watershed/seg/do_astar.c:48
+msgid "No seeds for A* Search"
msgstr ""
-#: ../raster/r.spreadpath/main.c:98
-msgid "Name of raster map containing back-path easting information"
+#: ../raster/r.watershed/seg/do_astar.c:146
+msgid "bug in A* Search: doer %"
msgstr ""
-#: ../raster/r.spreadpath/main.c:103
-#, fuzzy
-msgid "Name of raster map containing back-path northing information"
-msgstr "출력할 격자지도"
-#: ../raster/r.spreadpath/main.c:108
-msgid "The map E and N grid coordinates of starting points"
+#: ../raster/r.watershed/seg/close_maps.c:20
+msgid "Closing accumulation map"
msgstr ""
-#: ../raster/r.spreadpath/main.c:161
-#, fuzzy, c-format
-msgid ""
-"\\eading the input map -%s- and -%s- and creating some temporary files..."
+#: ../raster/r.watershed/seg/close_maps.c:136
+#, fuzzy
+msgid "Closing TCI and SPI maps"
msgstr "출력할 격자지도"
-#: ../raster/r.spreadpath/main.c:281
+#: ../raster/r.watershed/seg/close_maps.c:138
#, fuzzy
-msgid "Finding the least cost paths ..."
+msgid "Closing TCI map"
msgstr "출력할 격자지도"
-#: ../raster/r.spreadpath/main.c:296
-#, fuzzy, c-format
-msgid "Writing the output map -%s-..."
+#: ../raster/r.watershed/seg/close_maps.c:140
+#, fuzzy
+msgid "Closing SPI map"
msgstr "출력할 격자지도"
-#: ../raster/r.patch/main.c:60
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:4
-msgid "mosaicking"
+#: ../raster/r.watershed/seg/close_maps.c:300
+msgid "Closing flow direction map"
msgstr ""
-#: ../raster/r.patch/main.c:61
-#: ../locale/scriptstrings/t.merge_to_translate.c:4
-msgid "merge"
+#: ../raster/r.watershed/seg/close_maps.c:327
+msgid "Closing LS map"
msgstr ""
-#: ../raster/r.patch/main.c:62
-msgid "patching"
+#: ../raster/r.watershed/seg/close_maps.c:332
+msgid "Closing SL map"
msgstr ""
-#: ../raster/r.patch/main.c:64
-msgid ""
-"Creates a composite raster map layer by using known category values from one "
-"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+#: ../raster/r.watershed/front/main.c:76
+msgid "Calculates hydrological parameters and RUSLE factors."
msgstr ""
-#: ../raster/r.patch/main.c:71
-msgid "Name of raster maps to be patched together"
+#: ../raster/r.watershed/front/main.c:79 ../raster/r.watershed/front/main.c:86
+#: ../raster/r.watershed/front/main.c:92 ../raster/r.watershed/front/main.c:99
+#: ../raster/r.watershed/front/main.c:108
+#: ../raster/r.watershed/front/main.c:116
+#: ../raster/r.watershed/front/main.c:125
+msgid "Inputs"
msgstr ""
-#: ../raster/r.patch/main.c:74
+#: ../raster/r.watershed/front/main.c:83
#, fuzzy
-msgid "Name for resultant raster map"
+msgid "Name of input depressions raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.patch/main.c:81
-msgid "Use zero (0) for transparency instead of NULL"
+#: ../raster/r.watershed/front/main.c:84
+msgid "All non-NULL and non-zero cells are considered as real depressions"
msgstr ""
-#: ../raster/r.patch/main.c:86
+#: ../raster/r.watershed/front/main.c:90
#, fuzzy
-msgid "Do not create color and category files"
+msgid "Name of input raster representing amount of overland flow per cell"
msgstr "출력할 격자지도"
-#: ../raster/r.patch/main.c:101
-msgid "The minimum number of input raster maps is two"
+#: ../raster/r.watershed/front/main.c:96
+#, fuzzy
+msgid "Name of input raster map percent of disturbed land"
+msgstr "출력할 격자지도"
+#: ../raster/r.watershed/front/main.c:97 ../raster/r.watershed/front/main.c:122
+msgid "For USLE"
msgstr ""
-#: ../raster/r.patch/main.c:178
-#, fuzzy, c-format
-msgid "Creating support files for raster map <%s>..."
-msgstr "격자지도 <%s>를 위한 지원파일을 생성합니다"
+#: ../raster/r.watershed/front/main.c:104
+#, fuzzy
+msgid "Name of input raster map blocking overland surface flow"
+msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/main.c:50
-#, c-format
-msgid "Supported formats:\n"
+#: ../raster/r.watershed/front/main.c:106
+msgid ""
+"For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
msgstr ""
-#: ../raster/r.out.gdal/main.c:135
-msgid "Exports GRASS raster maps into GDAL supported formats."
+#: ../raster/r.watershed/front/main.c:113
+msgid "Minimum size of exterior watershed basin"
msgstr ""
-#: ../raster/r.out.gdal/main.c:141
-msgid "List supported output formats"
+#: ../raster/r.watershed/front/main.c:121
+msgid "Maximum length of surface flow in map units"
msgstr ""
-#: ../raster/r.out.gdal/main.c:147
+#: ../raster/r.watershed/front/main.c:130
#, fuzzy
-msgid "Do not write GDAL standard colortable"
+msgid "Name for output accumulation raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/main.c:148
+#: ../raster/r.watershed/front/main.c:132
#, fuzzy
-msgid "Only applicable to Byte or UInt16 data types"
+msgid "Number of cells that drain through each cell"
msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/main.c:149 ../raster/r.out.gdal/main.c:155
-#: ../raster/r.out.gdal/main.c:202 ../raster/r.out.gdal/main.c:213
-#: ../raster/r.out.gdal/main.c:224 ../raster/r.out.gdal/main.c:237
-#: ../vector/v.out.ogr/args.c:51 ../vector/v.out.ogr/args.c:62
-#: ../vector/v.out.ogr/args.c:72 ../vector/v.out.ogr/args.c:82
-#: ../vector/v.out.ogr/args.c:97 ../vector/v.out.ogr/args.c:110
-#: ../vector/v.out.ogr/args.c:117 ../vector/v.out.ogr/args.c:123
-#: ../vector/v.out.ogr/args.c:130 ../vector/v.out.postgis/args.c:38
-#: ../vector/v.out.postgis/args.c:48 ../vector/v.out.postgis/args.c:61
-#: ../vector/v.out.postgis/args.c:67 ../vector/v.out.postgis/args.c:73
-#: ../vector/v.out.postgis/args.c:79
-msgid "Creation"
-msgstr ""
+#: ../raster/r.watershed/front/main.c:139
+#, fuzzy
+msgid "Name for output topographic index ln(a / tan(b)) map"
+msgstr "출력 위상색인 격자지도의 이름"
-#: ../raster/r.out.gdal/main.c:153
+#: ../raster/r.watershed/front/main.c:146
#, fuzzy
-msgid "Do not write non-standard metadata"
+msgid "Stream power index a * tan(b)"
msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/main.c:154
-msgid "Enhances compatibility with other GIS software"
-msgstr ""
+#: ../raster/r.watershed/front/main.c:152
+#, fuzzy
+msgid "Name for output drainage direction raster map"
+msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/main.c:159
+#: ../raster/r.watershed/front/main.c:158
#, fuzzy
-msgid "Write raster attribute table"
+msgid "Name for output basins raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/main.c:160
+#: ../raster/r.watershed/front/main.c:164
#, fuzzy
-msgid "Some export formats may not be supported"
+msgid "Name for output stream segments raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/main.c:164
-msgid "Force raster export despite any warnings of data loss"
-msgstr ""
+#: ../raster/r.watershed/front/main.c:170
+#, fuzzy
+msgid "Name for output half basins raster map"
+msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/main.c:165
-msgid "Overrides nodata safety check"
+#: ../raster/r.watershed/front/main.c:172
+msgid "Each half-basin is given a unique value"
msgstr ""
-#: ../raster/r.out.gdal/main.c:168
+#: ../raster/r.watershed/front/main.c:178
#, fuzzy
-msgid "Name of raster map (or group) to export"
+msgid "Name for output slope length raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/main.c:171
-#, fuzzy
-msgid "Name for output raster file"
-msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/main.c:177
-msgid "Raster data format to write (case sensitive, see also -l flag)"
+#: ../raster/r.watershed/front/main.c:180
+msgid "Slope length and steepness (LS) factor for USLE"
msgstr ""
-#: ../raster/r.out.gdal/main.c:198
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:11
+#: ../raster/r.watershed/front/main.c:186
#, fuzzy
-msgid "Data type"
+msgid "Name for output slope steepness raster map"
msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/main.c:208
-msgid "Creation option(s) to pass to the output format driver"
+#: ../raster/r.watershed/front/main.c:187
+msgid "Slope steepness (S) factor for USLE"
msgstr ""
-#: ../raster/r.out.gdal/main.c:210
-msgid "In the form of \"NAME=VALUE\", separate multiple entries with a comma"
+#: ../raster/r.watershed/front/main.c:196
+msgid "Convergence factor for MFD (1-10)"
msgstr ""
-#: ../raster/r.out.gdal/main.c:218
-msgid "Metadata key(s) and value(s) to include"
+#: ../raster/r.watershed/front/main.c:198
+msgid "1 = most diverging flow, 10 = most converging flow. Recommended: 5"
msgstr ""
-#: ../raster/r.out.gdal/main.c:220
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
-"Not supported by all output format drivers."
+#: ../raster/r.watershed/front/main.c:205
+msgid "Maximum memory to be used with -m flag (in MB)"
msgstr ""
-#: ../raster/r.out.gdal/main.c:230
-msgid "Assign a specified nodata value to output bands"
+#: ../raster/r.watershed/front/main.c:209
+msgid "SFD (D8) flow (default is MFD)"
msgstr ""
-#: ../raster/r.out.gdal/main.c:232
-msgid ""
-"If given, the nodata value is always written to metadata even if there are "
-"no NULL cells in the input band (enhances output compatibility)."
+#: ../raster/r.watershed/front/main.c:211
+msgid "SFD: single flow direction, MFD: multiple flow direction"
msgstr ""
-#: ../raster/r.out.gdal/main.c:264
-#, fuzzy, c-format
-msgid "Raster map or group <%s> not found"
-msgstr "출력할 격자지도"
+#: ../raster/r.watershed/front/main.c:216
+msgid "Allow only horizontal and vertical flow of water"
+msgstr ""
-#: ../raster/r.out.gdal/main.c:268
-#, fuzzy, c-format
-msgid "No raster maps in group <%s>"
-msgstr "출력할 격자지도"
+#: ../raster/r.watershed/front/main.c:221
+msgid "Enable disk swap memory option: Operation is slow"
+msgstr ""
-#: ../raster/r.out.gdal/main.c:282
-#, fuzzy, c-format
-msgid "Unable to get <%s> driver"
-msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/main.c:288
-#, c-format
+#: ../raster/r.watershed/front/main.c:223
msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
+"Only needed if memory requirements exceed available RAM; see manual on how "
+"to calculate memory requirements"
msgstr ""
-#: ../raster/r.out.gdal/main.c:293
-#, fuzzy
-msgid "Unable to get in-memory raster driver"
-msgstr "출력할 격자지도"
+#: ../raster/r.watershed/front/main.c:228
+msgid "Use positive flow accumulation even for likely underestimates"
+msgstr ""
-#: ../raster/r.out.gdal/main.c:297
-#, c-format
-msgid "Driver <%s> does not support creating rasters"
+#: ../raster/r.watershed/front/main.c:230
+msgid "See manual for a detailed description of flow accumulation output"
msgstr ""
-#: ../raster/r.out.gdal/main.c:372
-#, fuzzy, c-format
-msgid "Could not read data range of raster <%s>"
-msgstr "출력할 격자지도"
+#: ../raster/r.watershed/front/main.c:235
+msgid "Beautify flat areas"
+msgstr ""
-#: ../raster/r.out.gdal/main.c:429
-#, c-format
-msgid "Exporting to GDAL data type: %s"
+#: ../raster/r.watershed/front/main.c:237
+msgid "Flow direction in flat areas is modified to look prettier"
msgstr ""
-#: ../raster/r.out.gdal/main.c:444
-msgid "Raster export would result in complete data loss, aborting."
+#: ../raster/r.watershed/front/main.c:253
+msgid "Sorry, you must choose an output map."
msgstr ""
-#: ../raster/r.out.gdal/main.c:455
-#, c-format
-msgid ""
-"Precision loss: Raster map <%s> of type %s to be exported as %s. This can be "
-"avoided by using %s."
+#: ../raster/r.watershed/front/main.c:259
+msgid "The basin threshold must be a positive number."
msgstr ""
-#: ../raster/r.out.gdal/main.c:466
-#, c-format
+#: ../raster/r.watershed/front/main.c:275
msgid ""
-"Precision loss: The range of <%s> can not be accurately preserved with GDAL "
-"datatype Float32. This can be avoided by exporting to Int32 or Float64."
+"Sorry, if any of the following options are set:\n"
+" basin, stream, half_basin, length_slope, or slope_steepness\n"
+" you MUST provide a value for the basin threshold parameter."
msgstr ""
-#: ../raster/r.out.gdal/main.c:474
-#, c-format
-msgid ""
-"Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. "
-"This can be avoided by using Float64"
+#: ../raster/r.watershed/front/main.c:302
+msgid "Beautify flat areas is not yet supported for disk swap mode"
msgstr ""
-#: ../raster/r.out.gdal/main.c:483
-#, fuzzy
-msgid "Forcing raster export"
-msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/main.c:485
+#: ../raster/r.watershed/front/main.c:332
#, c-format
-msgid "Raster export aborted. To override data loss check, use the -%c flag"
+msgid "Subprocess failed with exit code %d"
msgstr ""
-#: ../raster/r.out.gdal/main.c:500 ../raster/r.out.gdal/main.c:529
-#: ../raster/r.out.gdal/main.c:533
-#, fuzzy
-msgid "Raster export aborted."
-msgstr "출력할 격자지도"
+#: ../raster/r.usler/main.c:54
+msgid "rainfall"
+msgstr ""
-#: ../raster/r.out.gdal/main.c:510
-msgid "Checking GDAL data type and nodata value..."
+#: ../raster/r.usler/main.c:57
+msgid "Computes USLE R factor, Rainfall erosivity index."
msgstr ""
-#: ../raster/r.out.gdal/main.c:513
-#, fuzzy, c-format
-msgid "Checking options for raster map <%s> (band %d)..."
-msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/main.c:527
+#: ../raster/r.usler/main.c:60
#, fuzzy
-msgid "Forcing raster export."
+msgid "Name of annual precipitation raster map [mm/year]"
msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/main.c:558
+#: ../raster/r.usler/main.c:63
#, fuzzy
-msgid "Unable to create dataset using memory raster driver"
+msgid "Name for output USLE R raster map [MJ.mm/ha.hr.year]"
msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/main.c:567
-#, fuzzy, c-format
-msgid "Unable to create <%s> dataset using <%s> driver"
-msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/main.c:582
+#: ../raster/r.usler/main.c:70
#, fuzzy
-msgid "Unable to set geo transform"
+msgid "Name of USLE R equation"
msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/main.c:590
-#, fuzzy
-msgid "Unable to set projection"
-msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/main.c:618
-#, fuzzy, c-format
-msgid "Exporting raster data to %s format..."
-msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/main.c:621
-#, fuzzy, c-format
-msgid "Exporting raster map <%s> (band %d)..."
-msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/main.c:634
-#, fuzzy, c-format
-msgid "Unable to export raster map <%s>"
-msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/main.c:650
-#, fuzzy, c-format
-msgid "Unable to create raster map <%s> using driver <%s>"
-msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/main.c:673 ../raster/r.out.gdal/main.c:685
-#: ../raster/r.out.gdal/main.c:698 ../raster/r.out.gdal/main.c:711
-#: ../raster/r.out.gdal/main.c:723 ../raster/r.out.gdal/main.c:736
-#: ../raster/r.out.gdal/export_band.c:462
-#: ../raster/r.out.gdal/export_band.c:474
-#: ../raster/r.out.gdal/export_band.c:487
-#: ../raster/r.out.gdal/export_band.c:500
-#: ../raster/r.out.gdal/export_band.c:512
-#: ../raster/r.out.gdal/export_band.c:525
-#: ../raster/r.out.gdal/export_band.c:539
-msgid "Selected GDAL datatype does not cover data range."
+#: ../raster/r.usler/main.c:75
+msgid "Roosle (1975)"
msgstr ""
-#: ../raster/r.out.gdal/main.c:674 ../raster/r.out.gdal/main.c:686
-#: ../raster/r.out.gdal/main.c:699 ../raster/r.out.gdal/main.c:712
-#: ../raster/r.out.gdal/export_band.c:463
-#: ../raster/r.out.gdal/export_band.c:475
-#: ../raster/r.out.gdal/export_band.c:488
-#: ../raster/r.out.gdal/export_band.c:501
-#, c-format
-msgid "GDAL datatype: %s, range: %d - %d"
+#: ../raster/r.usler/main.c:76
+msgid "Morgan (1974)"
msgstr ""
-#: ../raster/r.out.gdal/main.c:677 ../raster/r.out.gdal/main.c:689
-#: ../raster/r.out.gdal/main.c:702 ../raster/r.out.gdal/main.c:715
-#: ../raster/r.out.gdal/main.c:727 ../raster/r.out.gdal/main.c:740
-#, fuzzy, c-format
-msgid "Range to be exported: %g - %g"
-msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/main.c:724 ../raster/r.out.gdal/export_band.c:513
-#, c-format
-msgid "GDAL datatype: %s, range: %u - %u"
+#: ../raster/r.usler/main.c:77
+msgid "Foster (1981)"
msgstr ""
-#: ../raster/r.out.gdal/main.c:737 ../raster/r.out.gdal/export_band.c:526
-#: ../raster/r.out.gdal/export_band.c:540
-#, c-format
-msgid "GDAL datatype: %s, range: %g - %g"
+#: ../raster/r.usler/main.c:78
+msgid "El-Swaify (1985)"
msgstr ""
-#: ../raster/r.out.gdal/main.c:764 ../raster/r.out.gdal/main.c:777
-#: ../raster/r.out.gdal/main.c:791 ../raster/r.out.gdal/main.c:804
-#: ../raster/r.out.gdal/main.c:819
-#, c-format
+#: ../display/d.his/main.c:69
msgid ""
-"Mismatch between metadata nodata value and actual nodata value in exported "
-"raster: specified nodata value %g gets converted to %d by selected GDAL "
-"datatype."
+"Displays the result obtained by combining hue, intensity, and saturation "
+"(HIS) values from user-specified input raster map layers."
msgstr ""
-#: ../raster/r.out.gdal/main.c:767 ../raster/r.out.gdal/main.c:794
-#: ../raster/r.out.gdal/main.c:822
-#, c-format
-msgid "GDAL datatype: %s, valid range: %d - %d"
+#: ../display/d.his/main.c:97
+msgid "Percent to brighten intensity channel"
msgstr ""
-#: ../raster/r.out.gdal/main.c:780 ../raster/r.out.gdal/main.c:807
-#, c-format
-msgid "GDAL datatype: %s, valid range: %u - %u"
+#: ../display/d.his/main.c:103
+msgid "Respect NULL values while drawing"
msgstr ""
-#: ../raster/r.out.gdal/main.c:833
-#, c-format
-msgid ""
-"raster: specified nodata value %g gets converted to %g by selected GDAL "
-"datatype."
+#: ../display/d.colortable/main.c:64
+msgid "Displays the color table associated with a raster map layer."
msgstr ""
-#: ../raster/r.out.gdal/main.c:836
-#, c-format
-msgid "GDAL datatype: %s, valid range: %g - %g"
+#: ../display/d.colortable/main.c:68
+#, fuzzy
+msgid "Name of raster map whose color table is to be displayed"
+msgstr "출력할 격자지도"
+#: ../display/d.colortable/main.c:73
+msgid "Color of lines separating the colors of the color table"
msgstr ""
-#: ../raster/r.out.gdal/export_band.c:344
+#: ../display/d.colortable/main.c:79
#, fuzzy
-msgid "Unable to allocate buffer for reading raster map"
+msgid "Number of lines to appear in the color table"
msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/export_band.c:156
-#, fuzzy, c-format
-msgid "Using GDAL data type <%s>"
-msgstr "자료형을 출력합니다"
+#: ../display/d.colortable/main.c:85
+#, fuzzy
+msgid "Number of columns to appear in the color table"
+msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/export_band.c:161
-#, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %d will "
-"be used to represent no-data values in the input map. You can specify a "
-"nodata value with the %s option."
+#: ../display/d.colortable/main.c:90
+msgid "Do not draw a collar showing the NULL color in FP maps"
msgstr ""
-#: ../raster/r.out.gdal/export_band.c:166
+#: ../display/d.colortable/main.c:112
#, c-format
msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %g will "
+"<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
msgstr ""
-#: ../raster/r.out.gdal/export_band.c:176
+#: ../display/d.colortable/main.c:126
#, c-format
msgid ""
-"The default nodata value is present in rasterband <%s> and would lead to "
-"data loss. Please specify a custom nodata value with the %s parameter."
+"<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
msgstr ""
-#: ../raster/r.out.gdal/export_band.c:183
-#, c-format
-msgid ""
-"The user given nodata value %g is present in rasterband <%s> and would lead "
-"to data loss. Please specify a different nodata value with the %s parameter."
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:228
-#, fuzzy
-msgid "Unable to get raster band"
-msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/export_band.c:381
-#: ../raster/r.out.gdal/export_band.c:410
-#: ../raster/r.out.gdal/export_band.c:439
-#, fuzzy
-msgid "Unable to write GDAL raster file"
-msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/export_band.c:466
-#: ../raster/r.out.gdal/export_band.c:478
-#: ../raster/r.out.gdal/export_band.c:491
-#: ../raster/r.out.gdal/export_band.c:504
-#: ../raster/r.out.gdal/export_band.c:516
-#: ../raster/r.out.gdal/export_band.c:529
-#: ../raster/r.out.gdal/export_band.c:543
+#: ../display/d.colortable/main.c:137
#, fuzzy, c-format
-msgid "Raster map <%s> range: %g - %g"
+msgid "Range file for <%s> not available"
msgstr "출력할 격자지도"
-#: ../raster/r.out.gdal/attr.c:140 ../raster/r.out.gdal/attr.c:178
-#, fuzzy
-msgid "Failed to set raster attribute table"
-msgstr "출력할 격자지도"
-#: ../raster/r.out.mat/main.c:64
-msgid "Exports a GRASS raster to a binary MAT-File."
+#: ../display/d.labels/do_labels.c:142
+#, c-format
+msgid "Error: %s\n"
msgstr ""
-#: ../raster/r.out.mat/main.c:73
-#, fuzzy
-msgid "Name for output binary MAT file"
-msgstr "출력할 격자지도"
-#: ../raster/r.out.mat/main.c:113
-#, c-format
-msgid "Exporting <%s>"
+#: ../display/d.labels/main.c:44 ../vector/v.label.sa/main.c:39
+#: ../vector/v.label/main.c:60
+msgid "paint labels"
msgstr ""
-#: ../raster/r.out.mat/main.c:173
-msgid "Using the Current Region settings:"
+#: ../display/d.labels/main.c:46
+msgid ""
+"Displays text labels (created with v.label) to the active frame on the "
+"graphics monitor."
msgstr ""
-#: ../raster/r.out.mat/main.c:248
-msgid "Exporting raster as integer values"
+#: ../display/d.labels/main.c:52
+msgid "Ignore rotation setting and draw horizontally"
msgstr ""
-#: ../raster/r.out.mat/main.c:253
-msgid "Exporting raster as floating point values"
+#: ../display/d.labels/main.c:59
+msgid "Name of label file"
msgstr ""
-#: ../raster/r.out.mat/main.c:258
-msgid "Exporting raster as double FP values"
+#: ../display/d.labels/main.c:66
+msgid "Minimum region size (diagonal) when labels are displayed"
msgstr ""
-#: ../raster/r.out.mat/main.c:301
-msgid "Reading in map ... "
+#: ../display/d.labels/main.c:73
+msgid "Maximum region size (diagonal) when labels are displayed"
msgstr ""
-#: ../raster/r.out.mat/main.c:314
-#, fuzzy
-msgid "Writing out map..."
-msgstr "출력할 격자지도"
-#: ../raster/r.out.mat/main.c:374
+#: ../display/d.labels/main.c:85
#, fuzzy, c-format
-msgid "%ld bytes written to '%s'"
+msgid "Label file <%s> not found"
msgstr "출력할 격자지도"
-#: ../raster/r.external.out/main.c:38
-#, c-format
-msgid "Supported Formats:\n"
+#: ../display/d.labels/main.c:97
+msgid "Region size is lower than minreg, nothing displayed."
msgstr ""
-#: ../raster/r.external.out/main.c:132
-#, fuzzy
-msgid "Unable to open GDAL file"
-msgstr "출력할 격자지도"
-#: ../raster/r.external.out/main.c:156 ../vector/v.external.out/format.c:49
-#, fuzzy, c-format
-msgid "Format <%s> not supported"
-msgstr "출력할 격자지도"
-#: ../raster/r.external.out/main.c:162
-#, c-format
-msgid "Format <%s> does not support direct write"
+#: ../display/d.labels/main.c:105
+msgid "Region size is greater than maxreg, nothing displayed."
msgstr ""
-#: ../raster/r.external.out/main.c:166 ../vector/v.external.out/format.c:52
+#: ../display/d.labels/main.c:114 ../vector/v.lrs/v.lrs.label/main.c:283
#, fuzzy, c-format
-msgid "Format <%s> does not support writing"
+msgid "Unable to open label file <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.external.out/main.c:214
+#: ../display/d.rast.arrow/main.c:98 ../display/d.rast.num/main.c:78
#, fuzzy
-msgid "Unable to create GDAL file"
+msgid "map annotations"
msgstr "출력할 격자지도"
-#: ../raster/r.external.out/main.c:217
-#, fuzzy
-msgid "Error writing GDAL file"
-msgstr "출력할 격자지도"
+#: ../display/d.rast.arrow/main.c:101
+msgid ""
+"Draws arrows representing cell aspect direction for a raster map containing "
+"aspect data."
+msgstr ""
-#: ../raster/r.external.out/main.c:237 ../vector/v.external.out/main.c:45
-msgid "output"
+#: ../display/d.rast.arrow/main.c:105
+msgid "Name of raster aspect map to be displayed"
msgstr ""
-#: ../raster/r.external.out/main.c:240
-msgid "Defines raster output format utilizing GDAL library."
+#: ../display/d.rast.arrow/main.c:113
+msgid "Type of existing raster aspect map"
msgstr ""
-#: ../raster/r.external.out/main.c:244
-#, fuzzy
-msgid "Name of output directory"
-msgstr "출력할 격자지도"
+#: ../display/d.rast.arrow/main.c:118
+msgid "Color for drawing arrows"
+msgstr ""
-#: ../raster/r.external.out/main.c:251
-#, fuzzy
-msgid "Extension for output files"
-msgstr "출력할 격자지도"
-#: ../raster/r.external.out/main.c:257
-#, fuzzy
-msgid "Format of output files"
-msgstr "출력할 격자지도"
-#: ../raster/r.external.out/main.c:264 ../vector/v.external.out/args.c:39
-#: ../vector/v.out.postgis/args.c:52
-msgid "Creation options"
+#: ../display/d.rast.arrow/main.c:124
+msgid "Color for drawing drawing grid"
msgstr ""
-#: ../raster/r.external.out/main.c:277
-msgid "Cease using GDAL and revert to native output"
+#: ../display/d.rast.arrow/main.c:130
+msgid "Color for drawing null values (X symbol)"
msgstr ""
-#: ../raster/r.external.out/main.c:282 ../vector/v.external.out/args.c:74
-msgid "Print current status"
+#: ../display/d.rast.arrow/main.c:136
+msgid "Color for showing unknown information (? symbol)"
msgstr ""
-#: ../raster/r.volume/main.c:77
-msgid "volume"
+#: ../display/d.rast.arrow/main.c:144
+msgid "Draw arrow every Nth grid cell"
msgstr ""
-#: ../raster/r.volume/main.c:80
-msgid "Calculates the volume of data \"clumps\"."
+#: ../display/d.rast.arrow/main.c:153
+msgid "Raster map containing values used for arrow length"
msgstr ""
-#: ../raster/r.volume/main.c:81
-msgid ""
-"Optionally produces a GRASS vector points map containing the calculated "
-"centroids of these clumps."
+#: ../display/d.rast.arrow/main.c:160
+msgid "Scale factor for arrows (magnitude map)"
msgstr ""
-#: ../raster/r.volume/main.c:86
-#, fuzzy
-msgid ""
-"Name of input raster map representing data that will be summed within clumps"
-msgstr "출력할 격자지도"
-#: ../raster/r.volume/main.c:92
-#, fuzzy
-msgid "Name of input clump raster map"
-msgstr "출력할 격자지도"
-#: ../raster/r.volume/main.c:93
-msgid ""
-"Preferably the output of r.clump. If no clump map is given than MASK is used."
+#: ../display/d.rast.arrow/main.c:164 ../display/d.rast.num/main.c:108
+msgid "Align grids with raster cells"
msgstr ""
-#: ../raster/r.volume/main.c:99
-#, fuzzy
-msgid "Name for output vector points map to contain clump centroids"
-msgstr "출력할 격자지도"
-#: ../raster/r.volume/main.c:110
-msgid "Generate unformatted report (items separated by colon)"
+#: ../display/d.rast.arrow/main.c:210
+msgid "Illegal value for scale factor"
msgstr ""
-#: ../raster/r.volume/main.c:143
-msgid ""
-"No MASK found. If no clump map is given than the MASK is required. You need "
-"to define a clump raster map or create a MASK by r.mask command."
+#: ../display/d.rast.arrow/main.c:214
+msgid "Illegal value for skip factor"
msgstr ""
-#: ../raster/r.volume/main.c:145
-msgid "No clump map given, using MASK"
+#: ../display/d.rast.arrow/main.c:219
+msgid "Magnitude is only supported for GRASS and compass aspect maps."
msgstr ""
-#: ../raster/r.volume/main.c:198
-#, c-format
-msgid "Invalid category value %d (max=%d): row=%d col=%d"
+#: ../display/d.rast.arrow/main.c:224
+msgid "Scale option requires magnitude_map"
msgstr ""
-#: ../raster/r.volume/main.c:231
-#, fuzzy, c-format
-msgid "Creating vector point map <%s>..."
+#: ../display/d.rast.arrow/main.c:275
+#, fuzzy
+msgid "Problem reading range file"
msgstr "출력할 격자지도"
-#: ../raster/r.volume/main.c:233
-#, fuzzy, c-format
-msgid "From '%s' on raster map <%s> using clumps from <%s>"
-msgstr "출력할 격자지도"
-#: ../raster/r.volume/main.c:266
-#, c-format
-msgid ""
-"\n"
-"Volume report on data from <%s> using clumps on <%s> raster map"
+#: ../display/d.geodesic/main.c:48
+msgid "great circle"
msgstr ""
-#: ../raster/r.volume/main.c:270
-#, c-format
-msgid "Category Average Data # Cells Centroid Total\n"
+#: ../display/d.geodesic/main.c:49 ../display/d.path/main.c:50
+#: ../vector/v.net.distance/main.c:68 ../vector/v.net.timetable/main.c:262
+#: ../vector/v.net.allpairs/main.c:63 ../vector/v.net.path/main.c:44
+#: ../vector/v.net.visibility/main.c:47
+msgid "shortest path"
msgstr ""
-#: ../raster/r.volume/main.c:272
-#, c-format
-msgid "Number in clump Total in clump Easting Northing Volume"
+#: ../display/d.geodesic/main.c:51
+msgid ""
+"Displays a geodesic line, tracing the shortest distance between two "
+"geographic points along a great circle, in a longitude/latitude data set."
msgstr ""
-#: ../raster/r.volume/main.c:318
-msgid "Total Volume"
+#: ../display/d.geodesic/main.c:58 ../display/d.rhumbline/main.c:53
+#: ../display/d.path/main.c:65
+msgid "Starting and ending coordinates"
msgstr ""
-#: ../raster/r.surf.idw/main.c:107 ../vector/v.surf.idw/main.c:90
-msgid "IDW"
+#: ../display/d.geodesic/main.c:62 ../display/d.rhumbline/main.c:57
+#: ../display/d.northarrow/main.c:103
+msgid "Line color"
msgstr ""
-#: ../raster/r.surf.idw/main.c:109
-msgid ""
-"Provides surface interpolation from raster point data by Inverse Distance "
-"Squared Weighting."
-msgstr ""
+#: ../display/d.geodesic/main.c:66 ../display/d.rast.num/main.c:88
+#: ../display/d.legend/main.c:203 ../display/d.rhumbline/main.c:62
+#: ../display/d.grid/main.c:107 ../display/d.northarrow/main.c:113
+#: ../vector/v.lrs/v.lrs.label/main.c:193 ../vector/v.label.sa/main.c:98
+#: ../vector/v.label/main.c:151
+msgid "Text color"
+msgstr "문자색상"
-#: ../raster/r.surf.idw/main.c:119 ../vector/v.surf.idw/main.c:113
-msgid "Number of interpolation points"
-msgstr ""
+#: ../display/d.geodesic/main.c:78 ../display/d.rhumbline/main.c:75
+#, fuzzy, c-format
+msgid "Location is not %s"
+msgstr "출력할 격자지도"
-#: ../raster/r.surf.idw/main.c:124
-msgid "Output is the interpolation error"
+#: ../display/d.geodesic/main.c:87 ../display/d.rhumbline/main.c:86
+#: ../display/d.path/main.c:140
+msgid "No coordinates given"
msgstr ""
-#: ../raster/r.surf.idw/main.c:130
-#, c-format
-msgid "Illegal value for '%s' (%s)"
-msgstr ""
+#: ../display/d.geodesic/main.c:90 ../display/d.geodesic/main.c:93
+#: ../display/d.geodesic/main.c:96 ../display/d.geodesic/main.c:99
+#: ../display/d.rhumbline/main.c:89 ../display/d.rhumbline/main.c:92
+#: ../display/d.rhumbline/main.c:95 ../display/d.rhumbline/main.c:98
+#, fuzzy, c-format
+msgid "%s - illegal longitude"
+msgstr "출력할 격자지도"
-#: ../raster/r.surf.idw/main.c:260
+#: ../display/d.mon/select.c:14
#, fuzzy, c-format
-msgid "Interpolating raster map <%s> (%d row)..."
-msgid_plural "Interpolating raster map <%s> (%d rows)..."
-msgstr[0] "출력할 격자지도"
-msgstr[1] "출력할 격자지도"
+msgid "Monitor <%s> is already selected"
+msgstr "출력할 격자지도"
-#: ../raster/r.ros/main.c:215
-#, fuzzy
-msgid "rate of spread"
+#: ../display/d.mon/select.c:30 ../display/d.mon/stop.c:18
+#, fuzzy, c-format
+msgid "Monitor <%s> is not running"
msgstr "출력할 격자지도"
-#: ../raster/r.ros/main.c:218
+#: ../display/d.mon/main.c:41
+msgid "Controls graphics display monitors from the command line."
+msgstr ""
+#: ../display/d.mon/main.c:46
#, fuzzy
-msgid "Generates rate of spread raster maps."
+msgid "Name of monitor to start"
msgstr "출력할 격자지도"
-#: ../raster/r.ros/main.c:220
-msgid ""
-"Generates three, or four raster map layers showing the base (perpendicular) "
-"rate of spread (ROS), the maximum (forward) ROS, the direction of the "
-"maximum ROS, and optionally the maximum potential spotting distance for fire "
-"spread simulation."
+#: ../display/d.mon/main.c:48 ../display/d.mon/main.c:55
+#: ../display/d.mon/main.c:62 ../display/d.mon/main.c:123
+#: ../display/d.mon/main.c:128
+msgid "Manage"
msgstr ""
-#: ../raster/r.ros/main.c:227
+#: ../display/d.mon/main.c:53
#, fuzzy
-msgid "Raster map containing fuel models"
+msgid "Name of monitor to stop"
msgstr "출력할 격자지도"
-#: ../raster/r.ros/main.c:229
-msgid ""
-"Name of an existing raster map layer in the user's current mapset search "
-"path containing the standard fuel models defined by the USDA Forest Service. "
-"Valid values are 1-13; other numbers are recognized as barriers by r.ros."
-msgstr ""
+#: ../display/d.mon/main.c:60
+#, fuzzy
+msgid "Name of monitor to select"
+msgstr "출력할 격자지도"
-#: ../raster/r.ros/main.c:238
-msgid "Raster map containing the 1-hour fuel moisture (%)"
+#: ../display/d.mon/main.c:66
+msgid "Width for display monitor if not set by GRASS_RENDER_WIDTH"
msgstr ""
-#: ../raster/r.ros/main.c:248
-msgid "Raster map containing the 10-hour fuel moisture (%)"
+#: ../display/d.mon/main.c:67
+msgid "Default value: 720"
msgstr ""
-#: ../raster/r.ros/main.c:250
-msgid ""
-"path containing the 10-hour (.25-1\") fuel moisture (percentage content "
-"multiplied by 100)."
+#: ../display/d.mon/main.c:74
+msgid "Height for display monitor if not set by GRASS_RENDER_HEIGHT"
msgstr ""
-#: ../raster/r.ros/main.c:258
-msgid "Raster map containing the 100-hour fuel moisture (%)"
+#: ../display/d.mon/main.c:75
+msgid "Default value: 480"
msgstr ""
-#: ../raster/r.ros/main.c:260
-msgid ""
-"path containing the 100-hour (1-3\") fuel moisture (percentage content "
+#: ../display/d.mon/main.c:82
+msgid "Dimensions of display monitor versus current size"
msgstr ""
-#: ../raster/r.ros/main.c:267
-msgid "Raster map containing live fuel moisture (%)"
+#: ../display/d.mon/main.c:83
+msgid "Example: resolution=2 enlarge display monitor twice to 1280x960"
msgstr ""
-#: ../raster/r.ros/main.c:269
-msgid ""
-"path containing live (herbaceous) fuel moisture (percentage content "
-msgstr ""
-#: ../raster/r.ros/main.c:277
+#: ../display/d.mon/main.c:96
#, fuzzy
-msgid "Raster map containing midflame wind velocities (ft/min)"
+msgid "Name for output file (when starting new monitor)"
msgstr "출력할 격자지도"
-#: ../raster/r.ros/main.c:287
-#, fuzzy
-msgid "Name of raster map containing wind directions (degree)"
-msgstr "출력할 격자지도"
-#: ../raster/r.ros/main.c:289
-msgid ""
-"path containing wind direction, clockwise from north (degree)."
+#: ../display/d.mon/main.c:97
+msgid "Ignored for 'wx' monitors"
msgstr ""
-#: ../raster/r.ros/main.c:297
-#, fuzzy
-msgid "Name of raster map containing slope (degree)"
-msgstr "출력할 격자지도"
-#: ../raster/r.ros/main.c:299
-msgid ""
-"path containing topographic slope (degree)."
+#: ../display/d.mon/main.c:102
+msgid "List running monitors and exit"
msgstr ""
-#: ../raster/r.ros/main.c:307
-msgid "Raster map containing aspect (degree, CCW from E)"
+#: ../display/d.mon/main.c:107
+msgid "Print name of currently selected monitor and exit"
msgstr ""
-#: ../raster/r.ros/main.c:309
-msgid ""
-"path containing topographic aspect, counterclockwise from east (GRASS "
-"convention) in degrees."
+#: ../display/d.mon/main.c:112
+msgid "Print commands for currently selected monitor and exit"
msgstr ""
-#: ../raster/r.ros/main.c:317
+#: ../display/d.mon/main.c:118
#, fuzzy
-msgid "Raster map containing elevation (m, required for spotting)"
+msgid "Print path to support files of currently selected monitor and exit"
msgstr "출력할 격자지도"
-#: ../raster/r.ros/main.c:319
-msgid ""
-"path containing elevation (meters). Option is required from spotting "
-"distance computation (when spotting_distance option is provided)"
+#: ../display/d.mon/main.c:122
+msgid "Do not automatically select when starting"
msgstr ""
-#: ../raster/r.ros/main.c:328
+#: ../display/d.mon/main.c:127
#, fuzzy
-msgid "Output raster map containing base ROS (cm/min)"
+msgid "Release and stop currently selected monitor and exit"
msgstr "출력할 격자지도"
-#: ../raster/r.ros/main.c:330
-msgid "Base (perpendicular) rate of spread (ROS)"
-msgstr ""
-#: ../raster/r.ros/main.c:336
+#: ../display/d.mon/main.c:132
#, fuzzy
-msgid "Output raster map containing maximal ROS (cm/min)"
+msgid "Disable true colors"
msgstr "출력할 격자지도"
-#: ../raster/r.ros/main.c:338
-msgid "The maximum (forward) rate of spread (ROS)"
+#: ../display/d.mon/main.c:137
+msgid "Open output file in update mode"
msgstr ""
-#: ../raster/r.ros/main.c:344
-#, fuzzy
-msgid "Output raster map containing directions of maximal ROS (degree)"
-msgstr "출력할 격자지도"
-#: ../raster/r.ros/main.c:346
-msgid "The direction of the maximal (forward) rate of spread (ROS)"
+#: ../display/d.mon/main.c:138
+msgid "Requires --overwrite flag"
msgstr ""
-#: ../raster/r.ros/main.c:352
-#, fuzzy
-msgid "Output raster map containing maximal spotting distance (m)"
-msgstr "출력할 격자지도"
-#: ../raster/r.ros/main.c:354
-msgid ""
-"The maximal potential spotting distance (requires elevation raster map to be "
-"provided)."
+#: ../display/d.mon/main.c:143
+msgid "Launch light-weight wx monitor without toolbars and statusbar"
msgstr ""
-#: ../raster/r.ros/main.c:373
-msgid ""
-"No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h "
-"moisture layers is required."
+#: ../display/d.mon/main.c:144
+msgid "Requires 'start=wx0-7'"
msgstr ""
-#: ../raster/r.ros/main.c:397
+#: ../display/d.mon/main.c:151
#, c-format
-msgid ""
-"A wind direction layer should be given if the wind velocity layer <%s> has "
-"been given"
+msgid "Flag -%c has effect only for wx monitors (%s=wx0-7)"
msgstr ""
-#: ../raster/r.ros/main.c:402
-#, c-format
-msgid ""
-"A wind velocity layer should be given if the wind direction layer <%s> has "
-"been given"
+#: ../display/d.mon/main.c:161
+msgid "Currently selected monitor:"
msgstr ""
-#: ../raster/r.ros/main.c:416
+#: ../display/d.mon/main.c:165
#, c-format
-msgid "An aspect layer should be given if the slope layer <%s> has been given"
+msgid "List of commands for monitor <%s>:"
msgstr ""
-#: ../raster/r.ros/main.c:421
+#: ../display/d.mon/main.c:173
#, c-format
-msgid "A slope layer should be given if the aspect layer <%s> has been given"
+msgid "Monitor <%s> released"
msgstr ""
-#: ../raster/r.ros/main.c:437
-msgid "An elevation layer should be given if considering spotting"
+#: ../display/d.mon/main.c:178
+msgid "No monitor selected"
msgstr ""
-#: ../raster/r.ros/main.c:873
+#: ../display/d.mon/main.c:197
#, fuzzy, c-format
-msgid "Raster maps <%s>, <%s> and <%s> created."
+msgid "Either <%s>, <%s> or <%s> must be given"
msgstr "출력할 격자지도"
-#: ../raster/r.flow/main.c:423
-msgid "Constructs flowlines."
-msgstr ""
+#: ../display/d.mon/stop.c:41
+#, fuzzy, c-format
+msgid "Unable to delete file <%s>"
+msgstr "출력할 격자지도"
-#: ../raster/r.flow/main.c:425
-msgid ""
-"Computes flowlines, flowpath lengths, and flowaccumulation (contributing "
-"areas) from a elevation raster map."
-msgstr ""
+#: ../display/d.mon/stop.c:46
+#, fuzzy, c-format
+msgid "Unable to delete directory <%s>"
+msgstr "출력할 격자지도"
-#: ../raster/r.flow/main.c:434
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
-#, fuzzy
-msgid "Name of input aspect raster map"
+#: ../display/d.mon/stop.c:75
+#, fuzzy, c-format
+msgid "Unable to read file <%s>"
msgstr "출력할 격자지도"
-#: ../raster/r.flow/main.c:440
+#: ../display/d.mon/start.c:46 ../display/d.mon/start.c:74
+#, fuzzy, c-format
+msgid "File <%s> already exists and will be overwritten"
+msgstr "출력할 격자지도"
+#: ../display/d.mon/start.c:67
+#, fuzzy, c-format
+msgid "Unable to start monitor, don't have write permission for <%s>"
+msgstr "지도세트의 허가를 결정하지 못 했습니다"
+#: ../display/d.mon/start.c:76
+#, fuzzy, c-format
+msgid "Unable to delete <%s>"
+msgstr "출력할 격자지도"
+#: ../display/d.mon/start.c:93
+#, fuzzy, c-format
+msgid "Output file: %s"
+msgstr "출력할 격자지도"
+#: ../display/d.mon/start.c:148
+#, fuzzy, c-format
+msgid "Monitor <%s> already running"
+msgstr "출력할 격자지도"
+#: ../display/d.mon/start.c:151
+#, fuzzy, c-format
+msgid "Starting monitor <%s>..."
+msgstr "출력할 격자지도"
+#: ../display/d.mon/start.c:169
#, fuzzy
-msgid "Name of input barrier raster map"
+msgid "Unable to copy render command file"
msgstr "출력할 격자지도"
-#: ../raster/r.flow/main.c:447
-msgid "Number of cells between flowlines"
+#: ../display/d.mon/list.c:80
+msgid "List of running monitors:"
msgstr ""
-#: ../raster/r.flow/main.c:453
-msgid "Maximum number of segments per flowline"
+#: ../display/d.mon/list.c:82
+msgid "No monitors running"
msgstr ""
-#: ../raster/r.flow/main.c:458
-#, fuzzy
-msgid "Name for output flow line vector map"
+#: ../display/d.mon/list.c:116
+#, fuzzy, c-format
+msgid "Unable to open file '%s'"
msgstr "출력할 격자지도"
-#: ../raster/r.flow/main.c:464
+#: ../display/d.mon/list.c:145
+#, fuzzy, c-format
+msgid "No support files found for monitor <%s>"
+msgstr "출력할 격자지도"
+#: ../display/d.rast/main.c:56
+msgid "Displays user-specified raster map in the active graphics frame."
+msgstr ""
+#: ../display/d.rast/main.c:61
#, fuzzy
-msgid "Name for output flow path length raster map"
+msgid "Name of raster map to be displayed"
msgstr "출력할 격자지도"
-#: ../raster/r.flow/main.c:470
+#: ../display/d.rast/main.c:69
#, fuzzy
-msgid "Name for output flow accumulation raster map"
+msgid "List of categories or values to be displayed"
msgstr "출력할 격자지도"
-#: ../raster/r.flow/main.c:476
-msgid "Compute upslope flowlines instead of default downhill flowlines"
+#: ../display/d.rast/main.c:76
+msgid "Background color (for null)"
msgstr ""
-#: ../raster/r.flow/main.c:480
-msgid "3D lengths instead of 2D"
+#: ../display/d.rast/main.c:77 ../display/d.rast/main.c:82
+#: ../display/d.rgb/main.c:64
+msgid "Null cells"
msgstr ""
-#: ../raster/r.flow/main.c:484
-msgid "Use less memory, at a performance penalty"
+#: ../display/d.rast/main.c:81 ../display/d.rgb/main.c:63
+msgid "Make null cells opaque"
msgstr ""
-#: ../raster/r.flow/main.c:539
-msgid "You must select one or more output maps (flout, lgout, dsout)"
+#: ../display/d.rast/main.c:86
+msgid "Invert value list"
msgstr ""
-#: ../raster/r.flow/main.c:555
+#: ../display/d.rast/main.c:204
+#, fuzzy, c-format
+msgid "[%s]: illegal category specified"
+msgstr "출력할 격자지도"
+#: ../display/d.rast/main.c:235
+#, fuzzy, c-format
+msgid "[%s]: illegal value specified"
+msgstr "출력할 격자지도"
+#: ../display/d.font/main.c:48
msgid ""
-"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
-"calculating flow accumulation."
+"Selects the font in which text will be displayed on the user's graphics "
+"monitor."
msgstr ""
-#: ../raster/r.flow/io.c:87
-msgid "Elevation raster map resolution differs from current region resolution"
+#: ../display/d.font/main.c:56
+msgid "Choose new current font"
msgstr ""
-#: ../raster/r.flow/io.c:104
-msgid "Resolution of aspect file differs from current region resolution"
+#: ../display/d.font/main.c:62
+msgid "Path to Freetype-compatible font including file name"
msgstr ""
-#: ../raster/r.flow/io.c:121
-msgid "Reading input files: barrier"
+#: ../display/d.font/main.c:70
+msgid "Character encoding"
msgstr ""
-#: ../raster/r.flow/io.c:149
-#, c-format
-msgid "Cannot create segment file %s"
+#: ../display/d.font/main.c:74
+msgid "List fonts"
msgstr ""
-#: ../raster/r.flow/io.c:154
-#, c-format
-msgid "Cannot format segment file %s"
+#: ../display/d.font/main.c:78 ../display/d.fontlist/main.c:55
+msgid "List fonts verbosely"
msgstr ""
-#: ../raster/r.flow/io.c:160
+#: ../display/d.font/main.c:103
+#, fuzzy, c-format
+msgid "Unable to access font path %s: %s"
+msgstr "출력할 격자지도"
+#: ../display/d.font/main.c:107
#, c-format
-msgid "Cannot open segment file %s"
+msgid "Font path %s is not a file"
msgstr ""
-#: ../raster/r.flow/mem.c:40
+#: ../display/d.font/main.c:124
#, c-format
-msgid "Unable to write segment file for %s"
+msgid ""
+"Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
msgstr ""
-#: ../raster/r.flow/precomp.c:48
-msgid "Precomputing e/w distances..."
-msgstr ""
-#: ../raster/r.flow/precomp.c:50
+#: ../display/d.vect/zcoor.c:19
#, fuzzy
-msgid "Precomputing quantization tolerances..."
+msgid "Vector map is not 3D. Unable to display z-coordinates."
msgstr "출력할 격자지도"
-#: ../raster/r.flow/precomp.c:53
-msgid "Precomputing inverted elevations..."
+#: ../display/d.vect/topo.c:18
+msgid ""
+"Unable to display topology, not available.Please try to rebuild topology "
+"using v.build or v.build.all."
msgstr ""
-#: ../raster/r.flow/precomp.c:57
-msgid "Precomputing interpolated border elevations..."
+#: ../display/d.vect/main.c:76
+msgid "Displays user-specified vector map in the active graphics frame."
msgstr ""
-#: ../raster/r.flow/precomp.c:63
+#: ../display/d.vect/main.c:92
+msgid "Display"
+msgstr ""
+#: ../display/d.vect/main.c:96
#, fuzzy
-msgid "Precomputing re-oriented aspects..."
+msgid "Display geometry of features"
msgstr "출력할 격자지도"
-#: ../raster/r.flow/precomp.c:67
+#: ../display/d.vect/main.c:97
+msgid "Display category numbers of features"
+msgstr ""
+#: ../display/d.vect/main.c:98
+msgid "Display topology information (nodes, edges)"
+msgstr ""
+#: ../display/d.vect/main.c:99
#, fuzzy
-msgid "Precomputing aspects..."
+msgid "Display vertices of features"
msgstr "출력할 격자지도"
-#: ../raster/r.flow/precomp.c:111
-#, c-format
-msgid ""
-"Resolution too unbalanced:\n"
-"atan2(%f deg, %f deg) =%f < %f tolerance\n"
-"please resample input map"
+#: ../display/d.vect/main.c:100
+msgid "Display direction of linear features"
msgstr ""
-#: ../raster/r.flow/precomp.c:116
-#, c-format
-msgid "Resolution too unbalanced (%f x %f); please resample input map"
+#: ../display/d.vect/main.c:101
+msgid "Display z-coordinate of features (only for 3D vector maps)"
msgstr ""
-#: ../raster/r.null/main.c:62
+#: ../display/d.vect/main.c:119
#, fuzzy
-msgid "Manages NULL-values of given raster map."
+msgid "Feature color"
msgstr "출력할 격자지도"
-#: ../raster/r.null/main.c:65
+#: ../display/d.vect/main.c:125
+msgid "Area fill color"
+msgstr ""
+#: ../display/d.vect/main.c:131
#, fuzzy
-msgid "Name of raster map for which to edit null values"
+msgid "Colorize features according color definition column"
msgstr "출력할 격자지도"
-#: ../raster/r.null/main.c:74 ../raster/r.null/main.c:82
-#: ../general/g.proj/main.c:193
-msgid "Modify"
-msgstr ""
+#: ../display/d.vect/main.c:132 ../vector/v.out.lidar/main.c:544
+#, fuzzy
+msgid "Color definition in R:G:B form"
+msgstr "출력할 격자지도"
-#: ../raster/r.null/main.c:86
-msgid "Only do the work if the map is floating-point"
+#: ../display/d.vect/main.c:136
+msgid "Colorize point or area features according to z-coordinate"
msgstr ""
-#: ../raster/r.null/main.c:87 ../raster/r.null/main.c:92
-#: ../raster/r.null/main.c:98
-msgid "Check"
+#: ../display/d.vect/main.c:144 ../display/d.vect/main.c:149
+#: ../display/d.vect/main.c:157
+msgid "Lines"
msgstr ""
-#: ../raster/r.null/main.c:91
-msgid "Only do the work if the map is integer"
+#: ../display/d.vect/main.c:145 ../display/d.northarrow/main.c:121
+msgid "Line width"
msgstr ""
-#: ../raster/r.null/main.c:97
-msgid "Only do the work if the map doesn't have a NULL-value bitmap file"
-msgstr ""
+#: ../display/d.vect/main.c:150
+#, fuzzy
+msgid "Name of numeric column containing line width"
+msgstr "출력할 격자지도"
-#: ../raster/r.null/main.c:103
-msgid "Create NULL-value bitmap file validating all data cells"
+#: ../display/d.vect/main.c:151
+msgid "These values will be scaled by width_scale"
msgstr ""
-#: ../raster/r.null/main.c:107
-msgid "Remove NULL-value bitmap file"
+#: ../display/d.vect/main.c:158
+msgid "Scale factor for width_column"
msgstr ""
-#: ../raster/r.null/main.c:113
-msgid "Re-create NULL-value bitmap file (to compress or uncompress)"
+#: ../display/d.vect/main.c:166 ../display/d.vect/main.c:176
+#: ../display/d.vect/main.c:183 ../display/d.vect/main.c:189
+#: ../display/d.vect/main.c:325 ../display/d.vect.thematic/main.c:168
+#: ../display/d.vect.thematic/main.c:178
+msgid "Symbols"
msgstr ""
-#: ../raster/r.null/main.c:132
-#, c-format
-msgid ""
-"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
-"with r.mapcalc. Exiting."
+#: ../display/d.vect/main.c:170 ../display/d.vect.thematic/main.c:172
+msgid "Point and centroid symbol"
msgstr ""
-#: ../raster/r.null/main.c:138
-#, fuzzy, c-format
-msgid "Raster map <%s> is not in your mapset <%s>"
-msgstr "출력할 격자지도"
-#: ../raster/r.null/main.c:145
-#, c-format
-msgid "%s is illegal entry for null"
+#: ../display/d.vect/main.c:177 ../display/d.vect.thematic/main.c:179
+#: ../display/d.legend.vect/main.c:88
+msgid "Symbol size"
msgstr ""
-#: ../raster/r.null/main.c:152
-#, fuzzy, c-format
-msgid "Raster map <%s> already has a null bitmap file"
-msgstr "출력할 격자지도"
-#: ../raster/r.null/main.c:156
-#, fuzzy, c-format
-msgid "<%s> is integer raster map (CELL)"
-msgstr "출력할 격자지도"
-#: ../raster/r.null/main.c:160
-#, fuzzy, c-format
-msgid "<%s> is integer raster map (CELL). Using null=%d."
-msgstr "출력할 격자지도"
-#: ../raster/r.null/main.c:166
-#, fuzzy, c-format
-msgid "<%s> is floating pointing raster map"
-msgstr "출력할 격자지도"
-#: ../raster/r.null/main.c:183 ../raster/r.null/main.c:208
-#, fuzzy, c-format
-msgid "Writing new null file for raster map <%s>..."
-msgstr "출력할 격자지도"
-#: ../raster/r.null/main.c:193 ../raster/r.null/main.c:220
-#: ../raster/r.null/main.c:234
-#, fuzzy, c-format
-msgid "Raster map <%s> modified."
-msgstr "출력할 격자지도"
-#: ../raster/r.null/main.c:227
-#, fuzzy, c-format
-msgid "Removing null file for raster map <%s>..."
-msgstr "출력할 격자지도"
-#: ../raster/r.null/main.c:298
-#, fuzzy, c-format
-msgid "%s: %s: illegal value spec"
-msgstr "출력할 격자지도"
-#: ../raster/r.null/main.c:300
-#, c-format
-msgid "%s: illegal value spec"
+#: ../display/d.vect/main.c:179
+msgid "When used with the size_column option this becomes the scale factor"
msgstr ""
-#: ../raster/r.null/main.c:361
-#, fuzzy, c-format
-msgid "Writing new data for raster map <%s>..."
-msgstr "출력할 격자지도"
-#: ../raster/r.in.gdal/main.c:93
+#: ../display/d.vect/main.c:185
#, fuzzy
-msgid "Imports raster data into a GRASS raster map using GDAL library."
+msgid "Name of numeric column containing symbol size"
msgstr "출력할 격자지도"
-#: ../raster/r.in.gdal/main.c:99
+#: ../display/d.vect/main.c:191
#, fuzzy
-msgid "Name of raster file to be imported"
+msgid "Name of numeric column containing symbol rotation angle"
msgstr "출력할 격자지도"
-#: ../raster/r.in.gdal/main.c:108
-msgid "Band(s) to select (default is all bands)"
+#: ../display/d.vect/main.c:193
+msgid "Measured in degrees CCW from east"
msgstr ""
-#: ../raster/r.in.gdal/main.c:123
-#, fuzzy
-msgid "Name of GCPs target location"
-msgstr "출력할 격자지도"
-#: ../raster/r.in.gdal/main.c:125
-msgid ""
-"Name of location to create or to read projection from for GCPs transformation"
+#: ../display/d.vect/main.c:200 ../display/d.vect/main.c:210
+#: ../display/d.vect/main.c:218 ../display/d.vect/main.c:330
+#: ../display/d.vect.thematic/main.c:186 ../display/d.vect.thematic/main.c:197
+#: ../display/d.vect.thematic/main.c:206 ../display/d.vect.thematic/main.c:218
+#: ../display/d.vect.thematic/main.c:224 ../display/d.vect.thematic/main.c:229
+#: ../display/d.vect.thematic/main.c:239 ../display/d.vect.thematic/main.c:244
+msgid "Legend"
msgstr ""
-#: ../raster/r.in.gdal/main.c:141
-#, fuzzy
-msgid "Offset to be added to band numbers"
-msgstr "출력할 격자지도"
-#: ../raster/r.in.gdal/main.c:142
-msgid "If 0, no offset is added and the first band is 1"
+#: ../display/d.vect/main.c:203
+msgid "Area/boundary symbol for legend"
msgstr ""
-#: ../raster/r.in.gdal/main.c:150
-msgid ""
-"Zero-padding of band number by filling with leading zeros up to given number"
+#: ../display/d.vect/main.c:213
+msgid "Line symbol for legend"
msgstr ""
-#: ../raster/r.in.gdal/main.c:151
-msgid "If 0, length will be adjusted to 'offset' number without leading zeros"
+#: ../display/d.vect/main.c:219
+msgid "Label to display after symbol in vector legend"
msgstr ""
-#: ../raster/r.in.gdal/main.c:157
-#, fuzzy
-msgid "Name of the output file that contains the imported map names"
-msgstr "출력할 격자지도"
-#: ../raster/r.in.gdal/main.c:164 ../vector/v.in.lidar/main.c:270
-#: ../vector/v.in.ogr/main.c:218
-msgid "Name for new location to create"
+#: ../display/d.vect/main.c:225 ../display/d.vect/main.c:232
+#: ../display/d.vect/main.c:239 ../display/d.vect/main.c:244
+#: ../display/d.vect/main.c:251 ../display/d.vect/main.c:258
+#: ../display/d.vect/main.c:264 ../display/d.vect/main.c:270
+#: ../display/d.vect/main.c:276 ../display/d.vect/main.c:284
+msgid "Labels"
msgstr ""
-#: ../raster/r.in.gdal/main.c:171
-#, fuzzy
-msgid "File prefix for raster attribute tables"
-msgstr "출력할 격자지도"
-#: ../raster/r.in.gdal/main.c:172
-msgid "The band number and \".csv\" will be appended to the file prefix"
+#: ../display/d.vect/main.c:227
+msgid "Layer number for labels (default: the given layer number)"
msgstr ""
-#: ../raster/r.in.gdal/main.c:185 ../vector/v.in.ogr/main.c:291
+#: ../display/d.vect/main.c:233
#, fuzzy
-msgid "Perform projection check only and exit"
+msgid "Name of column to be displayed as a label"
msgstr "출력할 격자지도"
-#: ../raster/r.in.gdal/main.c:204
-#: ../locale/scriptstrings/r.import_to_translate.c:30
-msgid "Force Lat/Lon maps to fit into geographic coordinates (90N,S; 180E,W)"
+#: ../display/d.vect/main.c:238
+msgid "Label color"
msgstr ""
-#: ../raster/r.in.gdal/main.c:209
-msgid "Keep band numbers instead of using band color names"
+#: ../display/d.vect/main.c:245
+msgid "Label background color"
msgstr ""
-#: ../raster/r.in.gdal/main.c:214
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not "
-"import the raster file."
+#: ../display/d.vect/main.c:252
+msgid "Label border color"
msgstr ""
-#: ../raster/r.in.gdal/main.c:219
-#, fuzzy
-msgid "Print number of bands and exit"
-msgstr "출력할 격자지도"
-#: ../raster/r.in.gdal/main.c:247
-msgid "You have to specify a target location different from output location"
+#: ../display/d.vect/main.c:259
+msgid "Label size (pixels)"
msgstr ""
-#: ../raster/r.in.gdal/main.c:251
-msgid "You need to specify valid location name."
-msgstr ""
+#: ../display/d.vect/main.c:265 ../display/d.rast.num/main.c:119
+#: ../display/d.legend/main.c:210 ../display/d.legend.vect/main.c:115
+#: ../display/d.text/main.c:222 ../vector/v.label/main.c:122
+msgid "Font name"
+msgstr "글꼴이름"
-#: ../raster/r.in.gdal/main.c:255
-msgid "The '-l' flag only works in Lat/Lon locations"
+#: ../display/d.vect/main.c:271
+msgid "Text encoding"
msgstr ""
-#: ../raster/r.in.gdal/main.c:258
-msgid "The number of digits for band numbering must be equal or greater than 0"
+#: ../display/d.vect/main.c:279
+msgid "Label horizontal justification"
msgstr ""
-#: ../raster/r.in.gdal/main.c:277
-#, c-format
-msgid "Using memory cache size: %.1f MiB"
+#: ../display/d.vect/main.c:287
+msgid "Label vertical justification"
msgstr ""
-#: ../raster/r.in.gdal/main.c:319
-#, fuzzy, c-format
-msgid "Unable to open datasource <%s>"
-msgstr "출력할 격자지도"
-#: ../raster/r.in.gdal/main.c:330
-#, c-format
+#: ../display/d.vect/main.c:294
msgid ""
-"Input seems to be NOAA/AVHRR data which needs to be georeferenced with thin "
-"plate spline transformation (%s or %s)."
+"Minimum region size (average from height and width) when map is displayed"
msgstr ""
-#: ../raster/r.in.gdal/main.c:369
+#: ../display/d.vect/main.c:302
msgid ""
-"Input raster map is flipped or rotated - cannot import. You may use "
-"'gdalwarp' to transform the map to North-up."
+"Maximum region size (average from height and width) when map is displayed"
msgstr ""
-#: ../raster/r.in.gdal/main.c:410
+#: ../display/d.vect/main.c:310
msgid ""
-"Map bounds have been constrained to geographic coordinates. You will almost "
-"certainly want to check map bounds and resolution with r.info and reset them "
-"with r.region before going any further."
+"Random colors according to category number (or layer number if 'layer=-1' is "
+"given)"
msgstr ""
-#: ../raster/r.in.gdal/main.c:430 ../raster/r.in.gdal/main.c:819
-#: ../vector/v.in.lidar/main.c:505 ../vector/v.in.ogr/main.c:575
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location."
+#: ../display/d.vect/main.c:317
+msgid "Use values from 'cats' option as feature id"
msgstr ""
-#: ../raster/r.in.gdal/main.c:436 ../raster/r.in.gdal/main.c:843
-#: ../vector/v.in.lidar/main.c:511 ../vector/v.in.ogr/main.c:581
-#, fuzzy, c-format
-msgid "Unable to create new location <%s>"
-msgstr "출력할 격자지도"
-#: ../raster/r.in.gdal/main.c:439 ../raster/r.in.gdal/main.c:849
-#: ../general/g.proj/create.c:15 ../vector/v.in.lidar/main.c:514
-#: ../vector/v.in.ogr/main.c:584
-#, c-format
-msgid "Location <%s> created"
+#: ../display/d.vect/main.c:321
+msgid "Use square root of the value of size_column"
msgstr ""
-#: ../raster/r.in.gdal/main.c:577
-#, fuzzy, c-format
-msgid "Proceeding with import of %d raster bands..."
-msgstr "출력할 격자지도"
-#: ../raster/r.in.gdal/main.c:634
-#, fuzzy
-msgid "Unable to open the map names output text file"
-msgstr "출력할 격자지도"
-#: ../raster/r.in.gdal/main.c:665
-#, fuzzy, c-format
-msgid "Unable to get raster band number %d"
-msgstr "출력할 격자지도"
-#: ../raster/r.in.gdal/main.c:742
-#, fuzzy, c-format
-msgid "Copying %d GCPS in points file for <%s>"
-msgstr "출력할 격자지도"
-#: ../raster/r.in.gdal/main.c:750
-msgid "GCPs have the following OpenGIS WKT Coordinate System:"
+#: ../display/d.vect/main.c:323
+msgid ""
+"This makes circle areas proportionate to the size_column values instead of "
+"circle radius"
msgstr ""
-#: ../raster/r.in.gdal/main.c:773
-#, fuzzy
-msgid "Re-projecting GCPs table:"
-msgstr "출력할 격자지도"
-#: ../raster/r.in.gdal/main.c:774
-#, c-format
-msgid "* Input projection for GCP table: %s"
+#: ../display/d.vect/main.c:329 ../display/d.vect.thematic/main.c:243
+msgid "Do not show this layer in vector legend"
msgstr ""
-#: ../raster/r.in.gdal/main.c:776
-#, c-format
-msgid "* Output projection for GCP table: %s"
+#: ../display/d.vect/main.c:346
+msgid "Region size is lower than minreg, nothing displayed"
msgstr ""
-#: ../raster/r.in.gdal/main.c:797
-#, c-format
-msgid "Error in pj_do_proj (can't re-projection GCP %i)"
+#: ../display/d.vect/main.c:354
+msgid "Region size is greater than maxreg, nothing displayed"
msgstr ""
-#: ../raster/r.in.gdal/main.c:852
+#: ../display/d.vect/main.c:367
#, c-format
msgid ""
-"The target for the output group <%s> has been set to location <%s>, mapset "
-"<PERMANENT>."
+"The -%c flag and <%s> option cannot be used together, the -%c flag will be "
+"ignored!"
msgstr ""
-#: ../raster/r.in.gdal/main.c:923
-#, fuzzy
-msgid "Unable to translate projection key values of input GCPs"
+#: ../display/d.vect/main.c:391 ../display/d.vect/main.c:397
+#, fuzzy, c-format
+msgid "Option <%s> must be > 0"
msgstr "출력할 격자지도"
-#: ../raster/r.in.gdal/main.c:939
+#: ../display/d.vect/main.c:401
+#, fuzzy, c-format
+msgid "%d error in cat option"
+msgid_plural "%d errors in cat option"
+msgstr[0] "출력할 격자지도"
+#: ../display/d.vect/main.c:417
#, fuzzy
-msgid "Unable to get projection info of target location"
+msgid "Plotting..."
msgstr "출력할 격자지도"
-#: ../raster/r.in.gdal/main.c:941
+#: ../display/d.vect/main.c:425
#, fuzzy
-msgid "Unable to get projection units of target location"
+msgid ""
+"The bounding box of the map is outside the current region, nothing drawn"
msgstr "출력할 격자지도"
-#: ../raster/r.in.gdal/main.c:943
+#: ../display/d.vect/main.c:499
#, fuzzy
-msgid "Unable to get projection key values of target location"
+msgid "Rendering failed"
msgstr "출력할 격자지도"
-#: ../raster/r.in.gdal/main.c:982
-#, fuzzy, c-format
-msgid "Importing raster map <%s>..."
+#: ../display/d.vect/area.c:37
+#, fuzzy
+msgid ""
+"Unable to display areas, topology not available. Please try to rebuild "
+"topology using v.build or v.build.all."
msgstr "출력할 격자지도"
-#: ../raster/r.in.gdal/main.c:1377 ../raster/r.in.gdal/main.c:1434
-msgid "Inconsistent color rules in RAT"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:1491
+#: ../display/d.vect/area.c:137
#, fuzzy, c-format
-msgid "Setting grey color table for <%s> (8bit, full range)"
+msgid "Invalid area %d skipped (not enough points)"
msgstr "출력할 격자지도"
-#: ../raster/r.in.gdal/main.c:1505
+#: ../display/d.vect/area.c:236
#, fuzzy, c-format
-msgid "Setting grey color table for <%s> (16bit, image range)"
-msgstr "출력할 격자지도"
+msgid "%d invalid color rule for areas skipped"
+msgid_plural "%d invalid color rules for areas skipped"
-#: ../raster/r.in.gdal/main.c:1607
+#: ../display/d.vect/lines.c:107 ../display/d.vect/lines.c:335
+#: ../display/d.vect.thematic/display.c:51
#, fuzzy, c-format
-msgid "Unable to open file <%s>: %s."
+msgid "Unable to read symbol <%s>, unable to display points"
msgstr "출력할 격자지도"
-#: ../raster/r.distance/distance.c:102
-#, c-format
-msgid "Reading maps <%s,%s> while finding 0 distance ..."
-msgstr ""
-#: ../raster/r.distance/parse.c:35
+#: ../display/d.vect/lines.c:121
#, fuzzy
-msgid "Name of two input raster maps for computing inter-class distances"
+msgid ""
+"Unable to display features by id, topology not available. Please try to "
+"rebuild topology using v.build or v.build.all."
msgstr "출력할 격자지도"
-#: ../raster/r.distance/parse.c:45
-msgid "Sort output by distance"
-msgstr ""
+#: ../display/d.vect/lines.c:169
+#, fuzzy, c-format
+msgid "%d invalid color rule for lines skipped"
+msgid_plural "%d invalid color rules for lines skipped"
-#: ../raster/r.distance/parse.c:46
-#, fuzzy
-msgid "Default: sorted by categories"
-msgstr "기본값: 범주 또는 간격으로 정렬"
+#: ../display/d.vect/lines.c:175 ../display/d.vect.thematic/display.c:118
+#, fuzzy, c-format
+msgid "%d point plotted"
+msgid_plural "%d points plotted"
-#: ../raster/r.distance/parse.c:50
-#, fuzzy
-msgid "Sort by distance in ascending order"
-msgstr "셀의 개수로 오름차순 정렬"
+#: ../display/d.vect/lines.c:177 ../display/d.vect.thematic/display.c:121
+#, fuzzy, c-format
+msgid "%d line plotted"
+msgid_plural "%d lines plotted"
-#: ../raster/r.distance/parse.c:51
-#, fuzzy
-msgid "Sort by distance in descending order"
-msgstr "셀의 개수로 내림차순 정렬"
+#: ../display/d.vect/lines.c:179 ../display/d.vect.thematic/display.c:125
+#, fuzzy, c-format
+msgid "%d centroid plotted"
+msgid_plural "%d centroids plotted"
-#: ../raster/r.distance/parse.c:55
-msgid "Include category labels in the output"
-msgstr ""
+#: ../display/d.vect/lines.c:181 ../display/d.vect.thematic/display.c:129
+#, fuzzy, c-format
+msgid "%d boundary plotted"
+msgid_plural "%d boundaries plotted"
-#: ../raster/r.distance/parse.c:60
-msgid "Report zero distance if rasters are overlapping"
-msgstr ""
-#: ../raster/r.distance/parse.c:64
-msgid "Report null objects as *"
-msgstr ""
-#: ../raster/r.distance/parse.c:74 ../raster/r.distance/parse.c:83
+#: ../display/d.vect/lines.c:183 ../display/d.vect.thematic/display.c:132
#, fuzzy, c-format
-msgid "Raster map <%s> is not CELL"
-msgstr "격자지도 <%s>를 찾지 못 했습니다"
+msgid "%d face plotted"
+msgid_plural "%d faces plotted"
-#: ../raster/r.distance/report.c:61
-msgid "Processing..."
+#: ../display/d.vect/shape.c:38 ../display/d.vect.thematic/plot1.c:105
+#: ../display/d.vect.chart/plot.c:38 ../vector/v.what.rast3/main.c:120
+#: ../vector/v.extrude/main.c:224 ../vector/v.edit/select.c:502
+#: ../vector/v.univar/main.c:229 ../vector/v.overlay/main.c:398
+#: ../vector/v.kriging/getval.c:43 ../vector/v.surf.bspline/crosscorr.c:114
+#: ../vector/v.generalize/misc.c:170 ../vector/v.to.rast/support.c:104
+#: ../vector/v.to.rast/support.c:276 ../vector/v.to.rast/support.c:515
+#: ../vector/v.what.rast/main.c:138 ../vector/v.vect.stats/main.c:291
+#: ../vector/v.vect.stats/main.c:365 ../vector/v.distance/main.c:493
+#: ../vector/v.colors/scan_attr.c:24 ../vector/v.colors/read_rgb.c:23
+#: ../vector/v.colors/write_rgb.c:20 ../vector/v.buffer/main.c:412
+#: ../doc/vector/v.example/main.c:105
+#, c-format
+msgid "Database connection not defined for layer %d"
msgstr ""
-#: ../raster/r.distance/main.c:42
-msgid "Locates the closest points between objects in two raster maps."
+#: ../display/d.vect/shape.c:53
+#, c-format
+msgid "Both color table and <%s> option detected. Color table will ignored."
msgstr ""
-#: ../raster/r.distance/edges.c:47
+#: ../display/d.vect/shape.c:68
#, c-format
-msgid "Reading map %s ..."
+msgid ""
+"Color definition column ('%s') not a string. Column must be of form 'RRR:GGG:"
+"BBB' where RGB values range 0-255. You can use '%s' module to define color "
+"rules. Unable to colorize features."
msgstr ""
-#: ../raster/r.water.outlet/main.c:56
-#, fuzzy
-msgid "Creates watershed basins from a drainage direction map."
+#: ../display/d.vect/shape.c:77 ../display/d.vect/shape.c:100
+#: ../display/d.vect/shape.c:131 ../display/d.vect/shape.c:162
+#, fuzzy, c-format
+msgid "Unable to select data ('%s') from table"
msgstr "출력할 격자지도"
-#: ../raster/r.water.outlet/main.c:62
+#: ../display/d.vect/shape.c:85
#, fuzzy
-msgid "Name of input drainage direction map"
+msgid "Line width column not specified"
msgstr "출력할 격자지도"
-#: ../raster/r.water.outlet/main.c:65
-#, fuzzy
-msgid "Name for output watershed basin map"
+#: ../display/d.vect/shape.c:96
+#, fuzzy, c-format
+msgid "Line width column ('%s') not a number"
msgstr "출력할 격자지도"
-#: ../raster/r.water.outlet/main.c:68
+#: ../display/d.vect/shape.c:116
#, fuzzy
-msgid "Coordinates of outlet point"
+msgid "Symbol size column not specified"
msgstr "출력할 격자지도"
-#: ../raster/r.water.outlet/main.c:81
+#: ../display/d.vect/shape.c:127
#, fuzzy, c-format
-msgid "Illegal east coordinate '%s'"
+msgid "Symbol size column ('%s') is not numeric"
msgstr "출력할 격자지도"
-#: ../raster/r.water.outlet/main.c:83
+#: ../display/d.vect/shape.c:147
+#, fuzzy
+msgid "Symbol rotation column not specified"
+msgstr "출력할 격자지도"
+#: ../display/d.vect/shape.c:158
#, fuzzy, c-format
-msgid "Illegal north coordinate '%s'"
+msgid "Symbol rotation column ('%s') is not numeric"
msgstr "출력할 격자지도"
-#: ../raster/r.water.outlet/main.c:88
-#, c-format
-msgid "Ignoring point outside computation region: %.4f,%.4f"
+#: ../display/d.vect/shape.c:182
+msgid ""
+"Vector map is not 3D. Unable to colorize features based on z-coordinates."
msgstr ""
-#: ../raster/r.surf.gauss/main.c:42
-#, fuzzy
-msgid "Generates a raster map using gaussian random number generator."
+#: ../display/d.vect/shape.c:186
+#, fuzzy, c-format
+msgid "%s= and %s= are mutually exclusive. %s= will be ignored."
+msgstr "%s=와 %s=를 같이 지정할 수 없습니다"
+#: ../display/d.vect/shape.c:329
+#, fuzzy, c-format
+msgid "Invalid negative value - feature %d with category %d"
msgstr "출력할 격자지도"
-#: ../raster/r.surf.gauss/main.c:44
-msgid ""
-"Mean and standard deviation of gaussian deviates can be expressed by the "
-"user."
+#: ../display/d.vect/opt.c:126
+#, c-format
+msgid "Unknown color: '%s'"
msgstr ""
-#: ../raster/r.surf.gauss/main.c:51
-msgid "Distribution mean"
+#: ../display/d.vect/opt.c:143 ../display/d.vect.thematic/main.c:290
+#: ../vector/v.db.connect/main.c:180
+msgid "Database connection not defined"
msgstr ""
-#: ../raster/r.surf.gauss/main.c:57
-msgid "Standard deviation"
-msgstr ""
+#: ../display/d.vect/opt.c:152 ../display/d.vect.thematic/main.c:299
+#: ../db/db.describe/main.c:61 ../db/db.execute/main.c:76
+#: ../db/db.tables/main.c:50 ../db/db.select/main.c:81
+#: ../db/db.columns/main.c:56
+#, fuzzy, c-format
+msgid "Unable to open database <%s>"
+msgstr "출력할 격자지도"
-#: ../raster/r.out.ppm3/main.c:59
-msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
-msgstr ""
-#: ../raster/r.out.ppm3/main.c:84
+#: ../display/d.vect/label.c:33
#, fuzzy
-msgid "Name for new PPM file. (use '-' for stdout)"
+msgid "Topology level required for drawing centroids for OGR layers"
msgstr "출력할 격자지도"
-#: ../raster/r.out.ppm3/main.c:88
-msgid "Add comments to describe the region"
+#: ../display/d.vect/attr.c:28
+msgid "attrcol not specified, cannot display attributes"
msgstr ""
-#: ../raster/r.out.ppm3/main.c:160
-msgid "Converting ... "
-msgstr ""
-#: ../raster/r.in.ascii/main.c:74
-#, fuzzy
-msgid "Converts a GRASS ASCII raster file to binary raster map."
+#: ../display/d.vect/attr.c:110 ../display/d.vect.chart/plot.c:86
+#: ../vector/v.in.db/main.c:225
+#, fuzzy, c-format
+msgid "Unable to open select cursor: '%s'"
msgstr "출력할 격자지도"
-#: ../raster/r.in.ascii/main.c:85
-msgid "Default: CELL for integer values, DCELL for floating-point values"
+#: ../display/d.vect/attr.c:129
+#, c-format
+msgid "No attribute found for cat %d: %s"
msgstr ""
-#: ../raster/r.in.ascii/main.c:97 ../raster/r.in.ascii/main.c:102
-#, fuzzy
-msgid "Default: read from header"
-msgstr "출력할 격자지도"
+#: ../display/d.graph/graphics.c:60 ../display/d.graph/do_graph.c:129
+#: ../display/d.graph/do_graph.c:195 ../display/d.graph/do_graph.c:216
+#: ../display/d.graph/do_graph.c:267 ../display/d.graph/do_graph.c:334
+#, c-format
+msgid "Problem parsing command [%s]"
+msgstr ""
-#: ../raster/r.in.ascii/main.c:99
-msgid "Multiplier for ASCII data"
+#: ../display/d.graph/main.c:61
+msgid ""
+"Program for generating and displaying simple graphics on the display monitor."
msgstr ""
-#: ../raster/r.in.ascii/main.c:103
-msgid "String representing NULL value data cell"
+#: ../display/d.graph/main.c:66
+msgid ""
+"Name of file containing graphics commands, if not given reads from standard "
+"input"
msgstr ""
-#: ../raster/r.in.ascii/main.c:104
-msgid "NULL data"
+#: ../display/d.graph/main.c:73
+msgid "Color to draw with, either a standard GRASS color or R:G:B triplet"
msgstr ""
-#: ../raster/r.in.ascii/main.c:109
-msgid "SURFER (Golden Software) ASCII file will be imported"
+#: ../display/d.graph/main.c:80
+msgid "Coordinates are given in map units"
msgstr ""
-#: ../raster/r.in.ascii/main.c:128
+#: ../display/d.graph/main.c:91
#, c-format
-msgid "Wrong entry for multiplier: %s"
+msgid "Graph file <%s> not found"
msgstr ""
-#: ../raster/r.in.ascii/main.c:160
+#: ../display/d.graph/do_graph.c:65 ../display/d.graph/do_graph.c:81
#, c-format
-msgid "Unable to read input from <%s>"
+msgid "Problem parsing coordinates [%s]"
msgstr ""
-#: ../raster/r.in.ascii/main.c:180
-msgid "Can't get cell header"
+#: ../display/d.graph/do_graph.c:98
+msgid "Unable to read color"
msgstr ""
-#: ../raster/r.in.ascii/main.c:202
-#, c-format
-msgid "Data conversion failed at row %d, col %d"
+#: ../display/d.graph/do_graph.c:377
+msgid "Cannot read symbol, cannot display points"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:35
-msgid "input file is not a Surfer ascii grid file"
+#: ../display/d.extract/main.c:52
+msgid "Selects and extracts vectors with mouse into new vector map."
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:41
-msgid "error reading the column and row dimension from the Surfer grid file"
+#: ../display/d.extract/main.c:65 ../display/d.path/main.c:99
+msgid "Original line color"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:47
-msgid "error reading the X range from the Surfer grid file"
+#: ../display/d.extract/main.c:71 ../display/d.path/main.c:107
+msgid "Highlight color"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:53
-msgid "error reading the Y range from the Surfer grid file"
+#: ../display/d.extract/main.c:79 ../vector/v.label/main.c:233
+msgid "No graphics device selected"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:59
-msgid "error reading the Z range from the Surfer grid file"
+#: ../display/d.extract/main.c:122
+#, fuzzy
+msgid "Copying tables..."
+msgstr "출력할 격자지도"
+#: ../display/d.extract/main.c:130
+msgid "Cannot get db link info -> cannot copy table."
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:105
-msgid "error getting file position"
+#: ../display/d.extract/extract.c:43
+msgid "Select vector(s) with mouse"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:164
-msgid "illegal type field: using type int"
+#: ../display/d.extract/extract.c:44
+msgid " - L: draw box with left mouse button to select"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:169
-msgid "ignoring type filed in header, type is set on command line"
+#: ../display/d.extract/extract.c:45
+msgid " - M: draw box with middle mouse button to remove from display"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:176
-msgid "illegal multiplier field: using 1.0"
+#: ../display/d.extract/extract.c:46
+msgid " - R: quit and save selected vectors to new map\n"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:181
-msgid "ignoring multiplier filed in header, multiplier is set on command line"
+#: ../display/d.extract/extract.c:48
+msgid "L: add M: remove R: quit and save\n"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:189
-msgid "ignoring null filed in header, null string is set on command line"
+#: ../display/d.rast.num/main.c:81
+msgid ""
+"Overlays cell category values on a raster map displayed in the active "
+"graphics frame."
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:218
-msgid "error in ascii data format"
+#: ../display/d.rast.num/main.c:94 ../display/d.grid/main.c:96
+msgid "Grid color"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:248
-#, c-format
-msgid "Duplicate \"%s\" field in header"
+#: ../display/d.rast.num/main.c:112
+msgid "Get text color from cell color value"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:253
-#, c-format
-msgid "Illegal \"%s\" value in header: %s"
+#: ../display/d.rast.num/main.c:120 ../display/d.rast.num/main.c:127
+#: ../display/d.rast.num/main.c:135 ../display/d.legend/main.c:204
+#: ../display/d.legend/main.c:211 ../display/d.legend/main.c:220
+#: ../display/d.legend/main.c:227 ../display/d.legend/main.c:235
+#: ../display/d.legend.vect/main.c:116 ../display/d.legend.vect/main.c:125
+#: ../display/d.legend.vect/main.c:132 ../display/d.legend.vect/main.c:148
+#: ../display/d.legend.vect/main.c:157 ../display/d.legend.vect/main.c:163
+#: ../display/d.text/main.c:223 ../display/d.text/main.c:233
+#: ../display/d.text/main.c:240 ../display/d.text/main.c:248
+#: ../display/d.text/main.c:273
+msgid "Font settings"
+msgstr "글꼴설정"
+#: ../display/d.rast.num/main.c:125 ../display/d.legend/main.c:225
+#: ../display/d.text/main.c:238
+msgid "Path to font file"
+msgstr "글꼴파일의 경로"
+#: ../display/d.rast.num/main.c:134 ../display/d.legend/main.c:234
+#: ../display/d.text/main.c:247
+msgid "Text encoding (only applicable to TrueType fonts)"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:261
+#: ../display/d.rast.num/main.c:200
+#, fuzzy, c-format
+msgid "%d col"
+msgid_plural "%d cols"
+#. GTC %s will be replaced by strings "X rows" and "Y cols"
+#: ../display/d.rast.num/main.c:202
#, c-format
-msgid "\"%s\" field missing from header"
+msgid ""
+"Current region size: %s X %s\n"
+"Your current region setting may be too large. Cells displayed on your "
+"graphics window may be too small for cell category number to be visible."
msgstr ""
-#: ../raster/r.regression.line/main.c:50
-msgid "Calculates linear regression from two raster maps: y = a + b*x."
+#: ../display/d.rast.num/main.c:212
+msgid "Aborting (region larger then 200 rows X 200 cols is not allowed)"
msgstr ""
-#: ../raster/r.recode/main.c:49
+#: ../display/d.legend/histogram.c:115
+msgid ""
+"Histogram constrained by range not yet implemented for categorical rasters"
+msgstr ""
+#: ../display/d.legend/main.c:82
#, fuzzy
-msgid "recode categories"
+msgid ""
+"Displays a legend for a 2D or 3D raster map in the active frame of the "
msgstr "출력할 격자지도"
-#: ../raster/r.recode/main.c:51
+#: ../display/d.legend/main.c:99 ../display/d.legend.vect/main.c:81
+msgid "Legend title"
+msgstr ""
+#: ../display/d.legend/main.c:100 ../display/d.legend/main.c:109
+#: ../display/d.legend.vect/main.c:82 ../display/d.legend.vect/main.c:141
+msgid "Title"
+msgstr ""
+#: ../display/d.legend/main.c:107 ../display/d.legend.vect/main.c:139
#, fuzzy
-msgid "Recodes categorical raster maps."
-msgstr "출력할 격자지도"
+msgid "Title font size"
+msgstr "글꼴크기"
-#: ../raster/r.recode/main.c:54
+#: ../display/d.legend/main.c:108
#, fuzzy
-msgid "Name of raster map to be recoded"
+msgid "Default: Same as fontsize"
msgstr "출력할 격자지도"
-#: ../raster/r.recode/main.c:60
-msgid "File containing recode rules"
+#: ../display/d.legend/main.c:117
+msgid "Number of text lines (useful for truncating long legends)"
msgstr ""
-#: ../raster/r.recode/main.c:71
-#, fuzzy
-msgid "Align the current region to the input raster map"
-msgstr "출력할 격자지도"
+#: ../display/d.legend/main.c:127
+msgid "Thinning factor (thin=10 gives cats 0,10,20...)"
+msgstr ""
-#: ../raster/r.recode/main.c:75
-msgid "Force output to 'double' raster map type (DCELL)"
+#: ../display/d.legend/main.c:135
+msgid "Units to display after labels (e.g. meters)"
msgstr ""
-#: ../raster/r.recode/main.c:96
-#, c-format
-msgid "No rules specified. Raster map <%s> not created."
+#: ../display/d.legend/main.c:144
+msgid "Number of text labels for smooth gradient legend"
msgstr ""
-#: ../raster/r.recode/read_rules.c:20
-#, fuzzy, c-format
-msgid "Unable to read f_range for map %s"
+#: ../display/d.legend/main.c:145 ../display/d.legend/main.c:154
+#: ../display/d.legend/main.c:161 ../display/d.legend/main.c:263
+#: ../display/d.legend/main.c:273 ../display/d.legend/main.c:283
+#, fuzzy
+msgid "Gradient"
msgstr "출력할 격자지도"
-#: ../raster/r.recode/read_rules.c:24 ../display/d.colortable/main.c:146
-msgid "Data range is empty"
-msgstr "자료범위가 비어 있습니다"
+#: ../display/d.legend/main.c:151
+msgid "Specific values to draw ticks"
+msgstr ""
-#: ../raster/r.recode/read_rules.c:30
-#, fuzzy, c-format
-msgid "Data range of %s is %s to %s (entire map)"
-msgstr "출력할 격자지도"
+#: ../display/d.legend/main.c:160
+msgid "Display label every step"
+msgstr ""
-#: ../raster/r.recode/read_rules.c:39
-#, fuzzy, c-format
-msgid "Integer data range of %s is empty"
+#: ../display/d.legend/main.c:167
+#, fuzzy
+msgid "Number of digits after decimal point"
msgstr "출력할 격자지도"
-#: ../raster/r.recode/read_rules.c:41
-#, fuzzy, c-format
-msgid "Integer data range of %s is %d to %d"
-msgstr "출력할 격자지도"
-#: ../raster/r.recode/read_rules.c:61
-msgid "Enter the rule or 'help' for the format description"
+#: ../display/d.legend/main.c:179
+msgid ""
+"Size and placement as percentage of screen coordinates (0,0 is lower left)"
msgstr ""
-#: ../raster/r.recode/read_rules.c:85
-msgid "Enter a rule in one of these formats:"
+#: ../display/d.legend/main.c:189
+msgid "List of discrete category numbers/values for legend"
msgstr ""
-#: ../raster/r.recode/read_rules.c:87
-msgid "old_low:old_high:new_low:new_high"
-msgstr ""
+#: ../display/d.legend/main.c:191 ../display/d.legend/main.c:200
+msgid "Subset"
+msgstr "부분집합"
-#: ../raster/r.recode/read_rules.c:88
-msgid "old_low:old_high:new_val (i.e. new_high == new_low)"
+#: ../display/d.legend/main.c:199
+msgid "Use a subset of the map range for the legend (min,max)"
msgstr ""
-#: ../raster/r.recode/read_rules.c:89
-msgid "*:old_val:new_val (interval [inf, old_val])"
-msgstr ""
+#: ../display/d.legend/main.c:218 ../display/d.barscale/main.c:182
+#: ../display/d.legend.vect/main.c:123 ../display/d.northarrow/main.c:129
+msgid "Font size"
+msgstr "글꼴크기"
-#: ../raster/r.recode/read_rules.c:90
-msgid "old_val:*:new_val (interval [old_val, inf])"
-msgstr ""
+#: ../display/d.legend/main.c:219
+msgid "Default: Auto-scaled"
+msgstr "기본값: 자동축척"
-#: ../raster/r.recode/read_rules.c:92
-msgid "When finished type \"end\"."
+#: ../display/d.legend/main.c:240 ../display/d.grid/main.c:101
+#: ../display/d.legend.vect/main.c:95 ../vector/v.lrs/v.lrs.label/main.c:223
+#: ../vector/v.label.sa/main.c:144 ../vector/v.label/main.c:193
+msgid "Border color"
msgstr ""
-#: ../raster/r.recode/read_rules.c:126 ../raster/r.quant/read_rules.c:158
-#, c-format
-msgid "%s is not a valid rule"
+#: ../display/d.legend/main.c:241 ../display/d.legend/main.c:247
+#: ../display/d.legend/main.c:288 ../display/d.legend.vect/main.c:96
+#: ../display/d.legend.vect/main.c:102 ../display/d.legend.vect/main.c:109
+#: ../display/d.legend.vect/main.c:168
+msgid "Background"
msgstr ""
-#: ../raster/r.sunmask/main.c:120
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map."
+#: ../display/d.legend/main.c:252
+msgid "Do not show category labels"
msgstr ""
-#: ../raster/r.sunmask/main.c:121
-msgid ""
-"Either exact sun position (A) is specified, or date/time to calculate the "
-"sun position (B) by r.sunmask itself."
+#: ../display/d.legend/main.c:257
+msgid "Do not show category numbers"
msgstr ""
-#: ../raster/r.sunmask/main.c:135
-msgid "Altitude of the sun in degrees above the horizon (A)"
+#: ../display/d.legend/main.c:262
+msgid "Draw legend ticks for labels"
msgstr ""
-#: ../raster/r.sunmask/main.c:136 ../raster/r.sunmask/main.c:145
-#: ../raster/r.sunmask/main.c:213 ../raster/r.sunmask/main.c:223
-#: ../display/d.text/main.c:198 ../display/d.text/main.c:207
-#: ../display/d.text/main.c:216 ../display/d.text/main.c:253
-#: ../display/d.text/main.c:258
-msgid "Position"
+#: ../display/d.legend/main.c:267
+msgid "Skip categories with no label"
msgstr ""
-#: ../raster/r.sunmask/main.c:144
-msgid "Azimuth of the sun in degrees from north (A)"
+#: ../display/d.legend/main.c:282
+msgid "Add histogram to smoothed legend"
msgstr ""
-#: ../raster/r.sunmask/main.c:151
-msgid "Year (B)"
+#: ../display/d.legend/main.c:287
+msgid "Show background"
msgstr ""
-#: ../raster/r.sunmask/main.c:159
-msgid "Month (B)"
+#: ../display/d.legend/main.c:292
+msgid "Use logarithmic scale"
msgstr ""
-#: ../raster/r.sunmask/main.c:167
-msgid "Day (B)"
+#: ../display/d.legend/draw.c:109
+msgid "Legend box lies outside of frame. Text may not display properly."
msgstr ""
-#: ../raster/r.sunmask/main.c:175
-msgid "Hour (B)"
+#: ../display/d.legend/draw.c:114
+msgid "Drawing horizontal legend as box width exceeds height"
msgstr ""
-#: ../raster/r.sunmask/main.c:183
-msgid "Minutes (B)"
+#: ../display/d.legend/draw.c:126
+#, c-format
+msgid "Range information for <%s> not available (run r.support)"
msgstr ""
-#: ../raster/r.sunmask/main.c:191
-msgid "Seconds (B)"
-msgstr ""
+#: ../display/d.legend/draw.c:131
+#, fuzzy
+msgid "Input map contains no data"
+msgstr "출력할 격자지도"
-#: ../raster/r.sunmask/main.c:201
-msgid "Timezone"
+#: ../display/d.legend/draw.c:145
+msgid "Requested range exceeds lower limit of actual data"
msgstr ""
-#: ../raster/r.sunmask/main.c:202
-msgid "East positive, offset from GMT, also use to adjust daylight savings"
+#: ../display/d.legend/draw.c:152
+msgid "Requested range exceeds upper limit of actual data"
msgstr ""
-#: ../raster/r.sunmask/main.c:211
-msgid "Easting coordinate (point of interest)"
+#: ../display/d.legend/draw.c:214
+#, c-format
+msgid "use=%s out of range [%d,%d] (extend with range= ?)"
msgstr ""
-#: ../raster/r.sunmask/main.c:212 ../raster/r.sunmask/main.c:222
-msgid "Default: map center"
+#: ../display/d.legend/draw.c:239
+msgid "Nothing to draw! (no categories with labels? out of range?)"
msgstr ""
-#: ../raster/r.sunmask/main.c:221
-msgid "Northing coordinate (point of interest)"
+#: ../display/d.legend/draw.c:250
+msgid "Forcing a smooth legend: too many categories for current window height"
msgstr ""
-#: ../raster/r.sunmask/main.c:227
-#, fuzzy
-msgid "Do not ignore zero elevation"
-msgstr "출력할 래스터맵"
-#: ../raster/r.sunmask/main.c:231
-msgid "Calculate sun position only and exit"
+#: ../display/d.legend/draw.c:282 ../display/d.legend/draw.c:287
+#: ../display/d.histogram/main.c:177
+#, c-format
+msgid "Range information for <%s> not available"
msgstr ""
-#: ../raster/r.sunmask/main.c:237
-msgid "Print the sun position output in shell script style"
+#: ../display/d.legend/draw.c:301
+msgid "Color range exceeds lower limit of actual data"
msgstr ""
-#: ../raster/r.sunmask/main.c:251
-#, fuzzy, c-format
-msgid "Using map center coordinates: %f %f"
-msgstr "출력할 격자지도"
-#: ../raster/r.sunmask/main.c:258
-#, fuzzy
-msgid "Empty east coordinate specified"
-msgstr "출력할 격자지도"
-#: ../raster/r.sunmask/main.c:260
-msgid "Empty north coordinate specified"
+#: ../display/d.legend/draw.c:305
+msgid "Color range exceeds upper limit of actual data"
msgstr ""
-#: ../raster/r.sunmask/main.c:279
-msgid "Either define sun position or location/date/time parameters"
+#: ../display/d.legend/draw.c:312
+#, c-format
+msgid "Range [%.3f, %.3f] out of the logarithm domain."
msgstr ""
-#: ../raster/r.sunmask/main.c:282
-msgid ""
-"Neither sun position nor east/north, date/time/timezone definition are "
-"complete"
+#: ../display/d.legend/draw.c:319
+#, c-format
+msgid "use=%s out of range [%.3f, %.3f] (extend with range= ?)"
msgstr ""
-#: ../raster/r.sunmask/main.c:286
+#: ../display/d.legend/draw.c:613
#, c-format
-msgid "Calculating sun position... (using solpos (V. %s) from NREL)"
+msgid "tick_value=%.3f out of range [%.3f, %.3f]"
msgstr ""
-#: ../raster/r.sunmask/main.c:291
+#: ../display/d.legend/draw.c:1029
msgid ""
-"Using user defined sun azimuth, altitude settings (ignoring eventual other "
-"values)"
+"Histogram plotting not implemented for categorical legends. Use the '-s' flag"
msgstr ""
-#: ../raster/r.sunmask/main.c:399
-#, fuzzy
-msgid "Please correct settings"
-msgstr "출력할 격자지도"
+#: ../display/d.legend/draw.c:1286
+msgid "Nothing to draw! (no categories with labels?)"
+msgstr ""
-#: ../raster/r.sunmask/main.c:413
-#, c-format
-msgid "Time (%02i:%02i:%02i) is before sunrise (%02d:%02d:%02d)"
+#: ../display/d.barscale/draw_scale.c:220 ../display/d.barscale/main.c:237
+#: ../display/d.barscale/main.c:254
+msgid "Programmer error"
msgstr ""
-#: ../raster/r.sunmask/main.c:417
+#: ../display/d.barscale/draw_scale.c:611
+#: ../display/d.northarrow/draw_n_arrow.c:200
#, c-format
-msgid "Time (%02i:%02i:%02i) is before sunrise"
+msgid "Could not read symbol \"%s\""
msgstr ""
-#: ../raster/r.sunmask/main.c:420 ../raster/r.sunmask/main.c:430
-msgid "Nothing to calculate. Please verify settings."
-msgstr ""
+#: ../display/d.barscale/main.c:65
+#, fuzzy
+msgid "Displays a barscale on the graphics monitor."
+msgstr "출력할 격자지도"
-#: ../raster/r.sunmask/main.c:424
-#, c-format
-msgid "Time (%02i:%02i:%02i) is after sunset (%02d:%02d:%02d)"
+#: ../display/d.barscale/main.c:69
+msgid "Use feet/miles instead of meters"
msgstr ""
-#: ../raster/r.sunmask/main.c:428
-#, c-format
-msgid "Time (%02i:%02i:%02i) is after sunset"
+#: ../display/d.barscale/main.c:73
+msgid "Draw the scale bar without text"
msgstr ""
-#: ../raster/r.sunmask/main.c:439
-msgid "You already know the sun position"
+#: ../display/d.barscale/main.c:74 ../display/d.barscale/main.c:141
+#: ../display/d.barscale/main.c:166 ../display/d.barscale/main.c:183
+#: ../display/d.text/main.c:163 ../display/d.text/main.c:172
+#: ../display/d.text/main.c:181 ../display/d.text/main.c:189
+#: ../display/d.text/main.c:263 ../display/d.text/main.c:268
+#: ../display/d.northarrow/main.c:100 ../display/d.northarrow/main.c:130
+#: ../display/d.northarrow/main.c:135 ../display/d.northarrow/main.c:140
+msgid "Text"
msgstr ""
-#: ../raster/r.sunmask/main.c:444 ../vector/v.colors/main.c:199
-#, fuzzy, c-format
-msgid "Option <%s> required"
+#: ../display/d.barscale/main.c:78
+#, fuzzy
+msgid "Display north-arrow symbol."
msgstr "출력할 격자지도"
-#: ../raster/r.sunmask/main.c:456
-#, fuzzy, c-format
-msgid "Unable to open range file for raster map <%s>"
+#: ../display/d.barscale/main.c:79 ../display/d.barscale/main.c:88
+#: ../display/d.barscale/main.c:149 ../display/d.northarrow/main.c:73
+msgid "Style"
+msgstr ""
+#: ../display/d.barscale/main.c:83
+#, fuzzy
+msgid "Type of barscale to draw"
msgstr "출력할 격자지도"
-#: ../raster/r.sunmask/main.c:472
-msgid "Calculating shadows from DEM..."
+#: ../display/d.barscale/main.c:102
+msgid "Classic style"
msgstr ""
-#: ../raster/r.sunmask/g_solposition.c:66
-msgid ""
-"Unable to calculate sun position in un-projected locations. Specify "
-"sunposition directly."
+#: ../display/d.barscale/main.c:103
+msgid "Line style"
msgstr ""
-#: ../raster/r.sunmask/g_solposition.c:88
-#, c-format
-msgid ""
-"Specified point %f, %f outside of current region, is that intended? Anyway, "
-"it will be used."
+#: ../display/d.barscale/main.c:104
+#, fuzzy
+msgid "Solid style"
+msgstr "출력할 격자지도"
+#: ../display/d.barscale/main.c:105
+msgid "Hollow style"
msgstr ""
-#: ../raster/r.quant/main.c:49
+#: ../display/d.barscale/main.c:106
#, fuzzy
-msgid "quantization"
+msgid "Full checker style"
msgstr "출력할 격자지도"
-#: ../raster/r.quant/main.c:51
-msgid "Produces the quantization file for a floating-point map."
+#: ../display/d.barscale/main.c:107
+msgid "Part checker style"
msgstr ""
-#: ../raster/r.quant/main.c:59
-msgid "Raster map(s) to be quantized"
+#: ../display/d.barscale/main.c:108
+msgid "Mixed checker style"
msgstr ""
-#: ../raster/r.quant/main.c:64
-#, fuzzy
-msgid "Path to rules file (\"-\" to read from stdin)"
-msgstr "출력할 격자지도"
+#: ../display/d.barscale/main.c:109
+msgid "Tail checker style"
+msgstr ""
-#: ../raster/r.quant/main.c:70
-msgid "Base map to take quant rules from"
+#: ../display/d.barscale/main.c:110
+msgid "Up ticks style"
msgstr ""
-#: ../raster/r.quant/main.c:75
-msgid "Floating point range: dmin,dmax"
+#: ../display/d.barscale/main.c:111
+msgid "Down ticks style"
msgstr ""
-#: ../raster/r.quant/main.c:81
-msgid "Integer range: min,max"
+#: ../display/d.barscale/main.c:112
+msgid "Both ticks style"
msgstr ""
-#: ../raster/r.quant/main.c:86
-msgid "Truncate floating point data"
+msgid "Arrow ends style"
msgstr ""
-#: ../raster/r.quant/main.c:90
-msgid "Round floating point data"
+#: ../display/d.barscale/main.c:121 ../display/d.northarrow/main.c:83
+msgid "Screen coordinates of the rectangle's top-left corner"
msgstr ""
-#: ../raster/r.quant/main.c:111
-#, fuzzy, c-format
-msgid "-%c, -%c, %s=, %s= and %s= are mutually exclusive"
-msgstr "-%c/-%c와 %s=를 같이 지정할 수 없습니다"
+#: ../display/d.barscale/main.c:122 ../display/d.northarrow/main.c:84
+msgid "(0,0) is lower-left of the display frame"
+msgstr ""
-#: ../raster/r.quant/main.c:120
-#, fuzzy, c-format
-msgid "%s= and %s= must be used together"
+#: ../display/d.barscale/main.c:130
+msgid "Length of barscale in map units"
+msgstr ""
+#: ../display/d.barscale/main.c:134
+#, fuzzy
+msgid "Barscale units to display"
msgstr "출력할 격자지도"
-#: ../raster/r.quant/main.c:131
-#, c-format
-msgid "%s is integer map, it can't be quantized"
+#: ../display/d.barscale/main.c:139
+msgid "Custom label of unit"
msgstr ""
-#: ../raster/r.quant/main.c:139
-msgid "Truncating..."
-msgstr ""
+#: ../display/d.barscale/main.c:148
+#, fuzzy
+msgid "Number of segments"
+msgstr "출력할 격자지도"
-#: ../raster/r.quant/main.c:144
-msgid "Rounding..."
-msgstr ""
+#: ../display/d.barscale/main.c:152
+#, fuzzy
+msgid "Bar scale and text color"
+msgstr "출력할 격자지도"
-#: ../raster/r.quant/main.c:152
-#, c-format
-msgid "%s is integer map, it can't be used as basemap"
+#: ../display/d.barscale/main.c:158
+msgid "Background color (drawn behind the bar)"
msgstr ""
-#: ../raster/r.quant/main.c:156
-#, fuzzy, c-format
-msgid "unable to read quant rules for basemap <%s>"
+#: ../display/d.barscale/main.c:163
+#, fuzzy
+msgid "Text position"
msgstr "출력할 격자지도"
-#: ../raster/r.quant/main.c:163 ../raster/r.quant/main.c:166
-#, fuzzy, c-format
-msgid "invalid value for %s= <%s>"
-msgstr "출력할 래스터맵"
+#: ../display/d.barscale/main.c:174
+#, fuzzy
+msgid "Scale factor to change bar width"
+msgstr "출력할 격자지도"
-#: ../raster/r.quant/main.c:168
+#: ../display/d.barscale/main.c:193
#, c-format
-msgid "Setting quant rules for input map(s) to (%f,%f) -> (%d,%d)"
+msgid "%s does not work with a latitude-longitude location"
msgstr ""
-#: ../raster/r.quant/main.c:181
-msgid "No rules specified. Quant table(s) not changed."
+#: ../display/d.colorlist/main.c:39
+msgid "Outputs a list of all available display colors."
msgstr ""
-#: ../raster/r.quant/main.c:189
-#, c-format
-msgid "New quant table created for %s"
+#: ../display/d.vect.thematic/main.c:87
+msgid "choropleth map"
msgstr ""
-#: ../raster/r.quant/read_rules.c:50
-msgid "Old data range is empty"
+#: ../display/d.vect.thematic/main.c:90
+#, fuzzy
+msgid "Displays a thematic vector map in the active graphics frame."
+msgstr "출력할 격자지도"
+#: ../display/d.vect.thematic/main.c:97
+msgid "Layer number. If -1, all layers are displayed."
msgstr ""
-#: ../raster/r.quant/read_rules.c:56
-#, c-format
-msgid "Old data range is %s to %s"
+#: ../display/d.vect.thematic/main.c:103
+#, fuzzy
+msgid "Name of attribute column to be classified"
+msgstr "출력할 격자지도"
+#: ../display/d.vect.thematic/main.c:110
+msgid "Class breaks, without minimum and maximum"
msgstr ""
-#: ../raster/r.quant/read_rules.c:59
-msgid "Old integer data range is empty"
+#: ../display/d.vect.thematic/main.c:111 ../display/d.vect.thematic/main.c:129
+#: ../display/d.vect.thematic/main.c:137
+msgid "Classes"
msgstr ""
-#: ../raster/r.quant/read_rules.c:61
-#, c-format
-msgid "Old integer data range is %d to %d"
+#: ../display/d.vect.thematic/main.c:119 ../vector/v.class/main.c:68
+msgid "Algorithm to use for classification"
msgstr ""
-#: ../raster/r.quant/read_rules.c:83
-#, fuzzy, c-format
-msgid "unable to open input file <%s>"
+#: ../display/d.vect.thematic/main.c:123 ../vector/v.class/main.c:76
+msgid "simple intervals"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:124 ../vector/v.class/main.c:77
+msgid "standard deviations"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:125 ../vector/v.class/main.c:78
+#, fuzzy
+msgid "quantiles"
msgstr "출력할 격자지도"
-#: ../raster/r.quant/read_rules.c:89
-#, c-format
-msgid ""
-"\n"
-"Enter the rule or 'help' for the format description or 'end' to exit:\n"
+#: ../display/d.vect.thematic/main.c:126 ../vector/v.class/main.c:79
+msgid "equiprobable (normal distribution)"
msgstr ""
-#: ../raster/r.quant/read_rules.c:112
-msgid "quant rules do not cover the whole range map"
+#: ../display/d.vect.thematic/main.c:136 ../vector/v.class/main.c:88
+msgid "Number of classes to define"
msgstr ""
-#: ../raster/r.neighbors/readweights.c:18
-#, fuzzy, c-format
-msgid "Unable to open weights file %s"
-msgstr "출력할 격자지도"
+#: ../display/d.vect.thematic/main.c:144
+msgid "Colors (one per class)"
+msgstr ""
-#: ../raster/r.neighbors/readweights.c:23
-#, fuzzy, c-format
-msgid "Error reading weights file %s"
+#: ../display/d.vect.thematic/main.c:154 ../display/d.vect.thematic/main.c:160
+#, fuzzy
+msgid "Boundaries"
msgstr "출력할 격자지도"
-#: ../raster/r.neighbors/main.c:121
-#, c-format
-msgid "Invalid out_type enumeration: %d"
+#: ../display/d.vect.thematic/main.c:155
+msgid "Boundary width"
msgstr ""
-#: ../raster/r.neighbors/main.c:175
-msgid ""
-"Makes each cell category value a function of the category values assigned to "
-"the cells around it, and stores new cell values in an output raster map "
-"layer."
+#: ../display/d.vect.thematic/main.c:159
+msgid "Boundary color"
msgstr ""
-#: ../raster/r.neighbors/main.c:185
+#: ../display/d.vect.thematic/main.c:190
#, fuzzy
-msgid ""
-"Name of an input raster map to select the cells which should be processed"
+msgid "Legend symbol for lines"
msgstr "출력할 격자지도"
-#: ../raster/r.neighbors/main.c:204 ../vector/v.neighbors/main.c:72
-msgid "Neighborhood operation"
+#: ../display/d.vect.thematic/main.c:201
+msgid "Legend symbol for areas"
msgstr ""
-#: ../raster/r.neighbors/main.c:206 ../raster/r.neighbors/main.c:214
-#: ../raster/r.neighbors/main.c:249
-msgid "Neighborhood"
+#: ../display/d.vect.thematic/main.c:207
+#, fuzzy
+msgid "Thematic map title"
+msgstr "출력할 격자지도"
+#: ../display/d.vect.thematic/main.c:214 ../display/d.vect.thematic/main.c:236
+msgid "DEPRECATED"
msgstr ""
-#: ../raster/r.neighbors/main.c:212
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:6
-msgid "Neighborhood size"
+#: ../display/d.vect.thematic/main.c:215
+#, fuzzy
+msgid "Output legend file"
+msgstr "출력할 격자지도"
+#: ../display/d.vect.thematic/main.c:223 ../display/d.vect.chart/main.c:142
+msgid "Create legend information and send to stdout"
msgstr ""
-#: ../raster/r.neighbors/main.c:226
+#: ../display/d.vect.thematic/main.c:228
#, fuzzy
-msgid "Text file containing weights"
+msgid "Do not draw map, only output the legend information"
msgstr "출력할 격자지도"
-#: ../raster/r.neighbors/main.c:232
-msgid "Sigma (in cells) for Gaussian filter"
+#: ../display/d.vect.thematic/main.c:237
+msgid ""
+"When printing legend info, include extended statistical info from "
+"classification algorithm"
msgstr ""
-#: ../raster/r.neighbors/main.c:244
-msgid "Do not align output with the input"
+#: ../display/d.vect.thematic/main.c:255
+msgid ""
+"Flag -e is deprecated, set verbose mode with --v to get the extended "
+"statistical info."
msgstr ""
-#: ../raster/r.neighbors/main.c:248
-msgid "Use circular neighborhood"
+#: ../display/d.vect.thematic/main.c:258
+msgid ""
+"Option legendfile is deprecated, either use flag -l to print legend to "
+"standard output, or set GRASS_LEGEND_FILE environment variable (see d.legend."
+"vect for details)."
msgstr ""
-#: ../raster/r.neighbors/main.c:256
-msgid "Neighborhood size must be positive"
+#: ../display/d.vect.thematic/main.c:277
+#, fuzzy, c-format
+msgid "%s: You must build topology on vector map. Run v.build."
+msgstr "출력할 격자지도"
+#: ../display/d.vect.thematic/main.c:288
+msgid "'layer' must be > 0"
msgstr ""
-#: ../raster/r.neighbors/main.c:258
-msgid "Neighborhood size must be odd"
+#: ../display/d.vect.thematic/main.c:312
+#, c-format
+msgid "Data (%s) not numeric. Column must be numeric."
msgstr ""
-#: ../raster/r.neighbors/main.c:293
+#: ../display/d.vect.thematic/main.c:316 ../display/d.vect.thematic/plot1.c:135
+#: ../display/d.vect.thematic/plot1.c:163
#, c-format
-msgid "%s= and %s= must have the same number of values"
+msgid "Cannot select data (%s) from table"
msgstr ""
-#: ../raster/r.neighbors/main.c:329
+#: ../display/d.vect.thematic/main.c:379
#, c-format
+msgid "Unknown color: [%s]"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:390
msgid ""
-"Method %s not compatible with weighing window, using weight mask instead"
+"You gave both manual breaks and a classification algorithm or a number of "
+"classes. The manual breaks have precedence and will thus be used."
msgstr ""
-#: ../raster/r.neighbors/main.c:337
+#: ../display/d.vect.thematic/main.c:427
+msgid "You must either give classbreaks or a classification algorithm"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:440
#, c-format
msgid ""
-"Method %s not compatible with Gaussian filter, using unweighed version "
-"instead"
+"Not enough colors or error in color specifications.\n"
+"Need %i entries for 'colors' parameter"
msgstr ""
-#: ../raster/r.neighbors/main.c:386
+#: ../display/d.vect.thematic/main.c:445
#, fuzzy, c-format
-msgid "Opening selection map <%s>"
+msgid "Error interpreting color %s"
msgstr "출력할 격자지도"
-#: ../raster/r.mode/main.c:58
+#: ../display/d.vect.thematic/main.c:462
+msgid "Plotting ..."
+msgstr ""
+#: ../display/d.vect.thematic/main.c:469
msgid ""
-"Finds the mode of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
+"The bounding box of the map is outside the current region, nothing drawn."
msgstr ""
-#: ../raster/r.mode/main.c:64
-msgid "Base map to be reclassified"
+#: ../display/d.vect.thematic/main.c:522
+#, c-format
+msgid ""
+"\n"
+"Total number of records: %.0f\n"
msgstr ""
-#: ../raster/r.mode/main.c:71
-msgid "Coverage map"
+#: ../display/d.vect.thematic/main.c:524
+#, c-format
+msgid "Classification of %s into %i classes\n"
msgstr ""
-#: ../raster/r.mode/main.c:78
-msgid "Output map"
+#: ../display/d.vect.thematic/main.c:526 ../vector/v.class/main.c:203
+#, c-format
+msgid "Using algorithm: *** %s ***\n"
msgstr ""
-#: ../raster/r.mode/main.c:91
-#, fuzzy, c-format
-msgid "%s: Unable to read category labels"
-msgstr "출력할 격자지도"
-#: ../raster/r.mode/read_stats.c:14
-msgid "reading r.stats output"
+#: ../display/d.vect.thematic/main.c:528 ../vector/v.class/main.c:204
+#, c-format
+msgid "Mean: %f\tStandard deviation = %f\n"
msgstr ""
-#: ../raster/r.walk/main.c:183
-msgid ""
-"Creates a raster map showing the anisotropic cumulative cost of moving "
-"between different geographic locations on an input raster map whose cell "
-"category values represent cost."
+#: ../display/d.vect.thematic/main.c:532
+#, c-format
+msgid "Last chi2 = %f\n"
msgstr ""
-#: ../raster/r.walk/main.c:193
-msgid "Name of input raster map containing friction costs"
+#: ../display/d.vect.thematic/main.c:534 ../vector/v.class/main.c:211
+#, c-format
+msgid "Stdev multiplied by %.4f to define step\n"
msgstr ""
-#: ../raster/r.walk/main.c:196
+#: ../display/d.vect.thematic/plot1.c:120
#, fuzzy
-msgid "Name for output raster map to contain walking costs"
+msgid "Color definition column not specified"
msgstr "출력할 격자지도"
-#: ../raster/r.walk/main.c:273
-msgid "Coefficients for walking energy formula parameters a,b,c,d"
+#: ../display/d.vect.thematic/plot1.c:130
+#, c-format
+msgid ""
+"Color definition column (%s) not a string. Column must be of form RRR:GGG:"
+"BBB where RGB values range 0-255."
msgstr ""
-#: ../raster/r.walk/main.c:283
-msgid "Lambda coefficients for combining walking energy and friction cost"
+#: ../display/d.vect.thematic/plot1.c:148
+msgid "Line width column not specified."
msgstr ""
-#: ../raster/r.walk/main.c:293
-msgid "Slope factor determines travel energy cost per height step"
+#: ../display/d.vect.thematic/plot1.c:159
+#, c-format
+msgid "Line width column (%s) not a number."
msgstr ""
-#: ../raster/r.walk/main.c:377
+#: ../display/d.vect.thematic/plot1.c:204
#, c-format
-msgid "Missing required value: got %d instead of 4"
+msgid ""
+"\n"
+"ERROR: vector map - can't read\n"
msgstr ""
-#: ../raster/r.walk/main.c:380
+#: ../display/d.vect.thematic/plot1.c:279
#, c-format
-msgid "Walking costs are a=%g b=%g c=%g d=%g"
+msgid ""
+"Error in color definition column (%s), element %d with cat %d: colorstring "
+"[%s]"
msgstr ""
-#: ../raster/r.walk/main.c:385 ../raster/r.walk/main.c:393
+#: ../display/d.vect.thematic/plot1.c:286
#, c-format
-msgid "Missing required value: %d"
+msgid "Error in color definition column (%s), element %d with cat %d"
msgstr ""
-#: ../raster/r.walk/main.c:388
+#: ../display/d.vect.thematic/plot1.c:354
#, c-format
-msgid "Lambda is %g"
+msgid ""
+"Error in line width column (%s), element %d with cat %d: line width [%d]"
msgstr ""
-#: ../raster/r.walk/main.c:396
-#, c-format
-msgid "Slope_factor is %g"
+#: ../display/d.rhumbline/main.c:46
+msgid "rhumbline"
msgstr ""
-#: ../raster/r.walk/main.c:558
-#, fuzzy, c-format
-msgid "Reading raster maps <%s> and <%s>, initializing output..."
-msgstr "출력할 격자지도"
+#: ../display/d.rhumbline/main.c:48
+msgid "Displays the rhumbline joining two longitude/latitude coordinates."
+msgstr ""
-#: ../raster/r.walk/main.c:722
-#, fuzzy, c-format
-msgid "No start points found in vector <%s>"
-msgstr "출력할 격자지도"
+#: ../display/d.grid/plot.c:373
+msgid "Geo-grid option only available for LL projection, use without -g/-w"
+msgstr ""
-#: ../raster/r.walk/main.c:1368
-#, fuzzy, c-format
-msgid "Writing output raster map <%s>... "
-msgstr "출력할 격자지도"
+#: ../display/d.grid/plot.c:575
+msgid ""
+"WGS84 grid output not possible as this location does not contain\n"
+"datum transformation parameters. Try running g.setproj."
+msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:1
-msgid "Creates a MASK for limiting raster operation."
+#: ../display/d.grid/plot.c:743
+msgid "Error in pj_do_proj1"
msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:4
-#, fuzzy
-msgid "Name of raster map to use as mask"
-msgstr "출력할 격자지도"
+#: ../display/d.grid/plot.c:749
+msgid "Error in pj_do_proj2"
+msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:5
-#: ../locale/scriptstrings/r.mask_to_translate.c:8
-msgid "Raster"
-msgstr "격자지도"
+#: ../display/d.grid/plot.c:753
+msgid "Error in pj_do_proj3"
+msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:6
-#, fuzzy
-msgid "Raster values to use for mask"
-msgstr "출력할 격자지도"
+#: ../display/d.grid/plot.c:761
+msgid "Error in pj_do_proj5"
+msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:7
-msgid "Format: 1 2 3 thru 7 *"
+#: ../display/d.grid/plot.c:765
+msgid "Error in pj_do_proj6"
msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:9
-#, fuzzy
-msgid "Name of vector map to use as mask"
-msgstr "출력할 격자지도"
+#: ../display/d.grid/main.c:55
+msgid "graticule"
+msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:10
-#: ../locale/scriptstrings/r.mask_to_translate.c:12
-#: ../locale/scriptstrings/r.mask_to_translate.c:14
-#: ../locale/scriptstrings/r.mask_to_translate.c:16
-msgid "Vector"
+#: ../display/d.grid/main.c:56 ../vector/v.mkgrid/main.c:72
+msgid "grid"
msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:11
-#, fuzzy
-msgid "Layer number or name (vector)"
-msgstr "출력할 격자지도"
+#: ../display/d.grid/main.c:58
+msgid ""
+"Overlays a user-specified grid in the active display frame on the graphics "
+"monitor."
+msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:13
-#, fuzzy
-msgid "Category values (vector)"
-msgstr "출력할 격자지도"
+#: ../display/d.grid/main.c:66
+msgid "Size of grid to be drawn (in map units)"
+msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:15
-msgid "WHERE conditions of SQL statement without 'where' keyword (vector)"
+#: ../display/d.grid/main.c:68
+msgid ""
+"0 for north-south resolution of the current region. In map units or DDD:MM:"
+"SS format. Example: \"1000\" or \"0:10\""
msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:17
-#, fuzzy
-msgid "Create inverse mask"
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.mask_to_translate.c:18
-#: ../general/g.mapset/main.c:70 ../general/g.proj/main.c:201
-msgid "Create"
+#: ../display/d.grid/main.c:76
+msgid "Lines of the grid pass through this coordinate"
msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:19
-msgid "Remove existing mask (overrides other options)"
+#: ../display/d.grid/main.c:85
+msgid "Draw only east-west lines, north-south lines, or both "
msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:1
-#, fuzzy
-msgid "Modifies the metadata of a space time dataset."
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.support_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:2
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:2
-#: ../locale/scriptstrings/t.info_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:2
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:2
-#: ../locale/scriptstrings/t.shift_to_translate.c:2
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:2
-#: ../locale/scriptstrings/t.list_to_translate.c:2
-#: ../locale/scriptstrings/t.register_to_translate.c:2
-#: ../locale/scriptstrings/t.rename_to_translate.c:2
-#: ../locale/scriptstrings/t.snap_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:2
-#: ../locale/scriptstrings/t.unregister_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:2
-#: ../locale/scriptstrings/t.remove_to_translate.c:2
-#: ../locale/scriptstrings/t.topology_to_translate.c:2
-#: ../locale/scriptstrings/t.merge_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:2
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:2
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:2
-#: ../locale/scriptstrings/t.select_to_translate.c:2
-#: ../locale/scriptstrings/t.create_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:2
-#: ../locale/scriptstrings/t.sample_to_translate.c:2
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:2
-#: ../temporal/t.connect/main.c:34
-msgid "temporal"
+#: ../display/d.grid/main.c:86 ../display/d.grid/main.c:159
+#: ../display/d.grid/main.c:164 ../display/d.grid/main.c:169
+msgid "Disable"
msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:5
-#: ../locale/scriptstrings/t.create_to_translate.c:7
+#: ../display/d.grid/main.c:92
#, fuzzy
-msgid "Semantic type of the space time dataset"
+msgid "Grid line width"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.support_to_translate.c:6
-#: ../locale/scriptstrings/t.info_to_translate.c:7
-#: ../locale/scriptstrings/t.shift_to_translate.c:7
-#: ../locale/scriptstrings/t.rename_to_translate.c:6
-#: ../locale/scriptstrings/t.snap_to_translate.c:7
-#: ../locale/scriptstrings/t.topology_to_translate.c:5
-#: ../locale/scriptstrings/t.select_to_translate.c:5
-msgid "input"
+#: ../display/d.grid/main.c:97 ../display/d.grid/main.c:102
+#: ../display/d.grid/main.c:108 ../display/d.grid/main.c:114
+msgid "Color"
msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:7
-#: ../locale/scriptstrings/t.info_to_translate.c:8
-#: ../locale/scriptstrings/t.shift_to_translate.c:8
-#: ../locale/scriptstrings/t.rename_to_translate.c:7
-#: ../locale/scriptstrings/t.snap_to_translate.c:8
-#: ../locale/scriptstrings/t.topology_to_translate.c:6
-#: ../locale/scriptstrings/t.merge_to_translate.c:7
-#: ../locale/scriptstrings/t.select_to_translate.c:6
-#: ../locale/scriptstrings/t.sample_to_translate.c:6
-#: ../locale/scriptstrings/t.sample_to_translate.c:7
-msgid "Required"
+#: ../display/d.grid/main.c:122
+msgid "Font size for gridline coordinate labels"
msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:8
+#: ../display/d.grid/main.c:127
#, fuzzy
-msgid "Title of the space time dataset"
+msgid "Align the origin to the east-north corner of the current region"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.support_to_translate.c:9
-#, fuzzy
-msgid "Description of the space time dataset"
-msgstr "출력할 격자지도"
+#: ../display/d.grid/main.c:132
+msgid "Draw geographic grid (referenced to current ellipsoid)"
+msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:10
-#, fuzzy
-msgid "Aggregation type of the space time raster or 3D raster dataset"
-msgstr "출력할 격자지도"
+#: ../display/d.grid/main.c:138
+msgid "Draw geographic grid (referenced to WGS84 ellipsoid)"
+msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:11
-msgid ""
-"Update the metadata information and spatial extent of registered maps from "
-"the GRASS spatial database"
+#: ../display/d.grid/main.c:143
+msgid "Draw '+' marks instead of grid lines"
msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:12
-msgid ""
-"Check for removed maps and delete them from the temporal database and all "
-"effected space time datasets"
+#: ../display/d.grid/main.c:148
+msgid "Draw '.' marks instead of grid lines"
msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:13
-msgid ""
-"Update metadata information, temporal and spatial extent from registered "
-"maps based on database entries."
+#: ../display/d.grid/main.c:153
+msgid "Draw fiducial marks instead of grid lines"
msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:1
-msgid "Displays the manual pages of GRASS modules."
+#: ../display/d.grid/main.c:158
+msgid "Disable grid drawing"
msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:2
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:3
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:2
-#: ../locale/scriptstrings/g.extension_to_translate.c:3
-#: ../general/g.mkfontcap/main.c:71 ../general/g.mapset/main.c:49
-#: ../general/g.cairocomp/main.c:196 ../general/g.version/main.c:65
-#: ../general/g.access/main.c:37 ../general/g.setproj/main.c:78
-#: ../general/g.gui/main.c:39 ../general/g.gisenv/main.c:43
-#: ../general/g.list/main.c:65 ../general/g.pnmcomp/main.c:282
-#: ../general/g.dirseps/main.c:34 ../general/g.ppmtopng/main.c:117
-#: ../general/g.tempfile/main.c:38 ../general/g.copy/main.c:41
-#: ../general/g.remove/main.c:69 ../general/g.findfile/main.c:38
-#: ../general/g.findetc/main.c:28 ../general/g.filename/main.c:39
-#: ../general/g.mapsets/main.c:63 ../general/g.proj/main.c:64
-#: ../general/g.message/main.c:33 ../general/g.region/main.c:64
-#: ../general/g.rename/main.c:45
-msgid "general"
-msgstr "일반"
+#: ../display/d.grid/main.c:163
+msgid "Disable border drawing"
+msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:3
-msgid "manual"
-msgstr "사용설명서"
-#: ../locale/scriptstrings/g.manual_to_translate.c:4
-msgid "help"
-msgstr "도움말"
-#: ../locale/scriptstrings/g.manual_to_translate.c:5
-msgid "Display index"
+#: ../display/d.grid/main.c:168
+msgid "Disable text drawing"
msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:6
-msgid "Display topics"
+#: ../display/d.grid/main.c:178
+msgid "Both grid and border drawing are disabled"
msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:7
-msgid "Display as MAN text page instead of HTML page in browser"
+#: ../display/d.grid/main.c:182
+msgid "Geo-grid option not available for LL projection, use without -g/-w"
msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:8
-msgid "Display online manuals instead of locally installed"
+#: ../display/d.grid/main.c:184
+msgid "Geo-grid option not available for XY projection, use without -g/-w"
msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:9
-msgid ""
-"Use online manuals available at http://grass.osgeo.org website. This flag "
-"has no effect when displaying MAN text pages."
+#: ../display/d.grid/main.c:203
+msgid "Choose a single mark style"
msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:10
-#, fuzzy
-msgid "Manual entry to be displayed"
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:1
-msgid ""
-"Sample a space time raster dataset at specific vector point coordinates and "
-"write the output to stdout using different layouts"
+#: ../display/d.grid/main.c:234
+#, c-format
+msgid "Invalid geo-grid size <%s>"
msgstr ""
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:6
-msgid "Comma separated list of coordinates"
+#: ../display/d.grid/main.c:239
+#, c-format
+msgid "Invalid grid size <%s>"
msgstr ""
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:7
+#: ../display/d.grid/fiducial.c:61
#, fuzzy
-msgid "Name for the output file or \"-\" in case stdout should be used"
-msgstr "보고서를 보관할 출력파일의 이름"
+msgid "Reading symbol"
+msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:8
+#: ../display/d.legend.vect/main.c:55
#, fuzzy
-msgid "Sort the maps by category"
+msgid "Displays a vector legend in the active graphics frame."
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:9
-msgid ""
-"The layout of the output. One point per row (row), one point per column "
-"(col), all timsteps in one row (timerow)"
+#: ../display/d.legend.vect/main.c:66
+msgid "Screen position of legend to be drawn (percentage, [0,0] is lower left)"
msgstr ""
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:10
+#: ../display/d.legend.vect/main.c:74
#, fuzzy
-msgid "Number of r.what processes to run in parallel"
+msgid "Number of legend columns"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:12
-msgid "Use stdin as input and ignore coordinates and point option"
+#: ../display/d.legend.vect/main.c:75 ../display/d.legend.vect/main.c:90
+msgid "Layout"
msgstr ""
-#: ../locale/scriptstrings/v.build.all_to_translate.c:1
+#: ../display/d.legend.vect/main.c:108
+msgid "Background border width"
+msgstr ""
+#: ../display/d.legend.vect/main.c:124
#, fuzzy
-msgid "Rebuilds topology on all vector maps in the current mapset."
-msgstr "출력할 격자지도"
+msgid "Default: 12"
+msgstr "기본값"
-#: ../locale/scriptstrings/v.build.all_to_translate.c:3
-#: ../locale/scriptstrings/t.topology_to_translate.c:3
-#: ../vector/v.info/main.c:39 ../vector/v.clean/main.c:52
-#: ../vector/v.build.polylines/main.c:112 ../vector/v.out.postgis/main.c:48
-#: ../vector/v.build/main.c:37
-msgid "topology"
-msgstr "위상"
+#: ../display/d.legend.vect/main.c:131
+#, fuzzy
+msgid "Title font name"
+msgstr "글꼴크기"
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
+#: ../display/d.legend.vect/main.c:140
#, fuzzy
-msgid "Imports attribute tables in various formats."
-msgstr "출력할 격자지도"
+msgid "Default: 18"
+msgstr "기본값"
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:5
-msgid "Table file to be imported or DB connection string"
-msgstr ""
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:6
+#: ../display/d.legend.vect/main.c:147
#, fuzzy
-msgid "Name of table from given DB to be imported"
-msgstr "출력할 격자지도"
+msgid "Subtitle font name"
+msgstr "글꼴크기"
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:7
+#: ../display/d.legend.vect/main.c:155
#, fuzzy
-msgid "Name for output table"
-msgstr "출력할 격자지도"
+msgid "Subtitle font size"
+msgstr "글꼴크기"
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:9
+#: ../display/d.legend.vect/main.c:156
#, fuzzy
-msgid "Name for auto-generated unique key column"
-msgstr "출력할 격자지도"
+msgid "Default: 14"
+msgstr "기본값"
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:11
-#: ../locale/scriptstrings/v.import_to_translate.c:14
-#: ../vector/v.in.ogr/main.c:233
+#: ../display/d.legend.vect/main.c:162
#, fuzzy
-msgid "Encoding value for attribute data"
+msgid "Font color"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:12
-msgid "Overrides encoding interpretation, useful when importing DBF tables"
+#: ../display/d.legend.vect/main.c:167
+msgid "Display legend background"
msgstr ""
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:1
-#, fuzzy
-msgid "Extracts a subset of a space time 3D raster dataset."
-msgstr "출력할 격자지도"
+#: ../display/d.legend.vect/main.c:171 ../display/d.legend.vect/main.c:178
+#: ../display/d.legend.vect/main.c:185
+msgid "In/Out"
+msgstr ""
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:3
-#: ../vector/v.extract/main.c:78 ../vector/v.decimate/main.c:127
-#: ../vector/v.outlier/main.c:71
+#: ../display/d.legend.vect/main.c:172
#, fuzzy
-msgid "extract"
+msgid "Field separator for input file"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:7
+#: ../display/d.legend.vect/main.c:175
#, fuzzy
-msgid "The r3.mapcalc expression assigned to all extracted 3D raster maps"
-msgstr "출력할 격자지도"
+msgid "Input legend file"
+msgstr "입력파일"
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:8
+#: ../display/d.legend.vect/main.c:176
#, fuzzy
-msgid "Basename of the new generated 3D raster maps"
+msgid "Path to legend file "
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:15
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:10
-msgid ""
-"Suffix to add at basename: set 'gran' for granularity, 'time' for the full "
-"time format, 'num' for numerical suffix with a specific number of digits "
-"(default %05)"
-msgstr ""
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:10
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:10
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:10
-msgid "Number of r3.mapcalc processes to run in parallel"
-msgstr ""
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:11
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:11
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:12
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:11
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:14
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:11
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:14
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:12
+#: ../display/d.legend.vect/main.c:181
#, fuzzy
-msgid "Register Null maps"
+msgid "Output csv file"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
+#: ../display/d.legend.vect/main.c:182
#, fuzzy
-msgid "Performs Tasseled Cap (Kauth Thomas) transformation."
-msgstr "출력할 격자지도"
+msgid "Path to output file or '-' for standard output"
+msgstr "지정하지 않거나 '-'이면 표준출력"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:6
+#: ../display/d.legend.vect/draw.c:95 ../display/d.legend.vect/draw.c:183
#, fuzzy
-msgid "Tasseled Cap transformation"
+msgid "Cannot read symbol"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:7
-msgid ""
-"For Landsat4-7: bands 1, 2, 3, 4, 5, 7; for Landsat8: bands 2, 3, 4, 5, 6, "
-"7; for MODIS: bands 1, 2, 3, 4, 5, 6, 7"
+#: ../display/d.legend.vect/draw.c:244
+msgid "Invalid value for color type in legend file. Use one of 'lf' or 'ps'."
msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:9
-msgid "Satellite sensor"
-msgstr ""
+#: ../display/d.profile/main.c:68
+#, fuzzy, c-format
+msgid "Unable to read range for %s"
+msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:10
-msgid ""
-"landsat4_tm;Use transformation rules for Landsat 4 TM;landsat5_tm;Use "
-"transformation rules for Landsat 5 TM;landsat7_etm;Use transformation rules "
-"for Landsat 7 ETM;landsat8_oli;Use transformation rules for Landsat 8 OLI;"
-"modis;Use transformation rules for MODIS"
+#: ../display/d.profile/main.c:79
+#, fuzzy, c-format
+msgid "Unable to read FP range for %s"
+msgstr "출력할 격자지도"
+#: ../display/d.profile/main.c:194
+msgid "Plots profile of a transect."
msgstr ""
-#: ../locale/scriptstrings/d.frame_to_translate.c:1
+#: ../display/d.profile/main.c:198
#, fuzzy
-msgid "Manages display frames on the user's graphics monitor."
+msgid "Raster map to be profiled"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/d.frame_to_translate.c:4
-#: ../locale/scriptstrings/d.redraw_to_translate.c:4
-#: ../display/d.erase/main.c:31 ../display/d.info/main.c:36
-#: ../display/d.mon/main.c:40
+#: ../display/d.profile/main.c:207
+msgid "Use map's range recorded range"
+msgstr ""
+#: ../display/d.profile/main.c:256
#, fuzzy
-msgid "monitors"
+msgid "At least two points are required"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/d.frame_to_translate.c:5
-msgid "frame"
+#: ../display/d.path/select.c:84 ../display/d.path/select.c:101
+#, c-format
+msgid "Node %d: %f %f\n"
msgstr ""
-#: ../locale/scriptstrings/d.frame_to_translate.c:6
-msgid "Create a new frame if doesn't exist and select"
+#: ../display/d.path/select.c:122
+#, c-format
+msgid "Destination unreachable\n"
msgstr ""
-#: ../locale/scriptstrings/d.frame_to_translate.c:7
-msgid "Remove all frames, erase the screen and exit"
+#: ../display/d.path/select.c:125
+#, c-format
+msgid "Costs on the network = %f\n"
msgstr ""
-#: ../locale/scriptstrings/d.frame_to_translate.c:8
-#, fuzzy
-msgid "Print name of current frame and exit"
-msgstr "출력할 격자지도"
+#: ../display/d.path/select.c:126
+#, c-format
+msgid ""
+" Distance to the network = %f, distance from the network = %f\n"
+"\n"
+msgstr ""
-#: ../locale/scriptstrings/d.frame_to_translate.c:9
-msgid "Print names of all frames including 'at' position and exit"
+#: ../display/d.path/main.c:49 ../vector/v.net.spanningtree/main.c:47
+#: ../vector/v.net.components/main.c:73 ../vector/v.net.distance/main.c:67
+#: ../vector/v.net.flow/main.c:59 ../vector/v.lrs/v.lrs.segment/main.c:73
+#: ../vector/v.lrs/v.lrs.label/main.c:104
+#: ../vector/v.lrs/v.lrs.create/main.c:123
+#: ../vector/v.lrs/v.lrs.where/main.c:59 ../vector/v.net.timetable/main.c:261
+#: ../vector/v.net.alloc/main.c:58 ../vector/v.net.allpairs/main.c:62
+#: ../vector/v.net.connectivity/main.c:53 ../vector/v.net.bridge/main.c:48
+#: ../vector/v.net.path/main.c:43 ../vector/v.net.steiner/main.c:347
+#: ../vector/v.net.centrality/main.c:97 ../vector/v.net.visibility/main.c:46
+#: ../vector/v.net.iso/main.c:73 ../vector/v.net/main.c:48
+#: ../vector/v.net.salesman/main.c:128
+msgid "network"
msgstr ""
-#: ../locale/scriptstrings/d.frame_to_translate.c:10
-msgid "Frame to be selected or created (if -c flag is given)"
+#: ../display/d.path/main.c:52
+msgid "Finds shortest path for selected starting and ending node."
msgstr ""
-#: ../locale/scriptstrings/d.frame_to_translate.c:11
-msgid ""
-"Screen coordinates in percent where to place the frame (0,0 is lower-left)"
+#: ../display/d.path/main.c:60 ../vector/v.net.distance/main.c:89
+#: ../vector/v.net.alloc/main.c:98 ../vector/v.net.path/main.c:61
+#: ../vector/v.net.steiner/main.c:363 ../vector/v.net.iso/main.c:111
+#: ../vector/v.net/args.c:63 ../vector/v.net.salesman/main.c:156
+msgid "Arc type"
msgstr ""
-#: ../locale/scriptstrings/d.frame_to_translate.c:12
-msgid "Implies only when -c or --overwrite flag is given"
+#: ../display/d.path/main.c:70 ../vector/v.net.spanningtree/main.c:59
+#: ../vector/v.net.components/main.c:84 ../vector/v.net.distance/main.c:82
+#: ../vector/v.net.flow/main.c:70 ../vector/v.net.timetable/main.c:274
+#: ../vector/v.net.alloc/main.c:91 ../vector/v.net.allpairs/main.c:74
+#: ../vector/v.net.connectivity/main.c:64 ../vector/v.net.bridge/main.c:60
+#: ../vector/v.net.path/main.c:54 ../vector/v.net.steiner/main.c:368
+#: ../vector/v.net.centrality/main.c:109 ../vector/v.net.iso/main.c:104
+#: ../vector/v.net/args.c:56 ../vector/v.net.salesman/main.c:149
+msgid "Arc layer"
msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:1
-msgid ""
-"Detects accumulation patterns in temporally accumulated space time raster "
-"datasets created by t.rast.accumulate."
+#: ../display/d.path/main.c:75 ../vector/v.net.spanningtree/main.c:65
+#: ../vector/v.net.components/main.c:90 ../vector/v.net.distance/main.c:95
+#: ../vector/v.net.flow/main.c:76 ../vector/v.net.timetable/main.c:280
+#: ../vector/v.net.alloc/main.c:104 ../vector/v.net.allpairs/main.c:80
+#: ../vector/v.net.connectivity/main.c:70 ../vector/v.net.bridge/main.c:66
+#: ../vector/v.net.path/main.c:67 ../vector/v.net.centrality/main.c:115
+#: ../vector/v.net.iso/main.c:117 ../vector/v.net/args.c:70
+msgid "Node layer"
msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:6
-msgid ""
-"Input space time raster dataset that specifies the minimum values to detect "
-"the accumulation pattern"
+#: ../display/d.path/main.c:81 ../vector/v.net.spanningtree/main.c:72
+#: ../vector/v.net.components/main.c:97 ../vector/v.net.distance/main.c:141
+#: ../vector/v.net.flow/main.c:90 ../vector/v.net.timetable/main.c:288
+#: ../vector/v.net.alloc/main.c:110 ../vector/v.net.allpairs/main.c:93
+#: ../vector/v.net.connectivity/main.c:77 ../vector/v.net.bridge/main.c:73
+#: ../vector/v.net.path/main.c:79 ../vector/v.net.centrality/main.c:129
+#: ../vector/v.net.iso/main.c:122 ../vector/v.net.salesman/main.c:168
+msgid "Arc forward/both direction(s) cost column (number)"
msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:7
-msgid ""
-"Input space time raster dataset that specifies the maximum values to detect "
+#: ../display/d.path/main.c:87 ../vector/v.net.components/main.c:103
+#: ../vector/v.net.distance/main.c:147 ../vector/v.net.flow/main.c:96
+#: ../vector/v.net.timetable/main.c:295 ../vector/v.net.alloc/main.c:117
+#: ../vector/v.net.allpairs/main.c:99 ../vector/v.net.connectivity/main.c:83
+#: ../vector/v.net.bridge/main.c:79 ../vector/v.net.path/main.c:86
+#: ../vector/v.net.centrality/main.c:135 ../vector/v.net.iso/main.c:127
+msgid "Arc backward direction cost column (number)"
msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:8
-msgid ""
-"The output space time raster dataset that stores the occurrence of the the "
-"accumulation pattern using the provided data range"
+#: ../display/d.path/main.c:93
+msgid "Node cost column"
msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:9
-msgid ""
-"The output space time raster dataset that stores the indication of the "
-"start, intermediate and end of the specified data range"
+#: ../display/d.path/main.c:101 ../display/d.path/main.c:109
+#: ../display/d.path/main.c:117 ../display/d.path/main.c:127
+msgid "Rendering"
msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:8
-msgid "The temporal starting point to begin the accumulation, eg '2001-01-01'"
+#: ../display/d.path/main.c:122 ../vector/v.net.spanningtree/main.c:84
+#: ../vector/v.net.distance/main.c:159 ../vector/v.net.alloc/main.c:151
+#: ../vector/v.net.allpairs/main.c:112 ../vector/v.net.path/main.c:132
+#: ../vector/v.net.steiner/main.c:398 ../vector/v.net.centrality/main.c:188
+#: ../vector/v.net.iso/main.c:159 ../vector/v.net.salesman/main.c:208
+msgid "Use geodesic calculation for longitude-latitude locations"
msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:11
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:9
-msgid "The temporal date to stop the accumulation, eg '2009-01-01'"
+#: ../display/d.path/main.c:126
+msgid "Render bold lines"
msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:12
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:10
-msgid "The temporal cycle to restart the accumulation, eg '12 months'"
+#: ../display/d.path/main.c:143 ../display/d.path/main.c:147
+#, c-format
+msgid "%s - illegal x value"
msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:13
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:11
-msgid "The temporal offset to the begin of the next cycle, eg '6 months'"
+#: ../display/d.path/main.c:145 ../display/d.path/main.c:149
+#, c-format
+msgid "%s - illegal y value"
msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:14
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:13
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:7
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:8
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:6
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:7
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:8
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:8
+#: ../display/d.path/main.c:178 ../vector/v.net.spanningtree/main.c:113
+#: ../vector/v.net.distance/main.c:205 ../vector/v.net.allpairs/main.c:142
+#: ../vector/v.net.path/main.c:148 ../vector/v.net.centrality/main.c:222
+msgid "The current projection is not longitude-latitude"
+msgstr ""
+#: ../display/d.vect.chart/main.c:65
#, fuzzy
-msgid "Basename of the new generated output maps"
+msgid "chart maps"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:15
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:14
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:8
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:9
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:7
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:8
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:9
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:9
+#: ../display/d.vect.chart/main.c:67
msgid ""
-"A numerical suffix separated by an underscore will be attached to create a "
-"unique identifier"
+"Displays charts of vector data in the active frame on the graphics monitor."
msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:16
-msgid ""
-"time format, 'count' for numerical suffix with a specific number of digits "
-"(default %05)"
+#: ../display/d.vect.chart/main.c:86
+msgid "Chart type"
msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:17
-msgid ""
-"The minimum and maximum value of the occurrence of accumulated values, these "
-"values will be used if the min/max space time raster datasets are not "
-"specified"
+#: ../display/d.vect.chart/main.c:87 ../display/d.vect.chart/main.c:97
+#: ../display/d.vect.chart/main.c:105 ../display/d.vect.chart/main.c:112
+#: ../display/d.vect.chart/main.c:117 ../display/d.vect.chart/main.c:123
+#: ../display/d.vect.chart/main.c:129 ../display/d.vect.chart/main.c:148
+msgid "Chart properties"
msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:18
-msgid ""
-"The user defined values that indicate start, intermediate and end status in "
-"the indicator output space time raster dataset"
+#: ../display/d.vect.chart/main.c:91
+msgid "Attribute columns containing data"
msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:19
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:21
-msgid ""
-"Register empty maps in the output space time raster dataset, otherwise they "
-"will be deleted"
+#: ../display/d.vect.chart/main.c:96
+msgid "Column used for pie chart size"
msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:20
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:22
-msgid "Reverse time direction in cyclic accumulation"
+#: ../display/d.vect.chart/main.c:104
+msgid "Size of chart (diameter for pie, total width for bar)"
msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
-msgid ""
-"Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
-"using gdalwarp."
+#: ../display/d.vect.chart/main.c:111
+msgid "Scale for size (to get size in pixels)"
msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:5
-msgid "Terra-ASTER"
+#: ../display/d.vect.chart/main.c:116
+msgid "Outline color"
msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:6
-#, fuzzy
-msgid "Name of input ASTER image"
-msgstr "출력할 격자지도"
+#: ../display/d.vect.chart/main.c:122
+msgid "Colors used to fill charts"
+msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:7
-msgid "ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)"
+#: ../display/d.vect.chart/main.c:128
+msgid "Center the bar chart around a data point"
msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:8
-msgid ""
-"List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate "
-"all bands"
+#: ../display/d.vect.chart/main.c:137
+msgid "Maximum value used for bar plot reference"
msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:9
+#: ../display/d.vect.chart/main.c:147
#, fuzzy
-msgid ""
-"Base name for output raster map (band number will be appended to base name)"
+msgid "Create 3D charts"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/db.test_to_translate.c:1
-msgid "Test database driver, database must exist and set by db.connect."
+#: ../display/d.info/main.c:38
+#, fuzzy
+msgid "Displays information about the active display monitor."
+msgstr "출력할 격자지도"
+#: ../display/d.info/main.c:40
+msgid "Display monitors are maintained by d.mon."
msgstr ""
-#: ../locale/scriptstrings/db.test_to_translate.c:4
-msgid "Test name"
+#: ../display/d.info/main.c:45
+msgid "Display screen rectangle (left, right, top, bottom)"
msgstr ""
-#, fuzzy
-msgid ""
-"Imports vector data into a GRASS vector map using OGR library and reprojects "
-"on the fly."
-msgstr "출력할 격자지도"
+#: ../display/d.info/main.c:49
+msgid "Display screen dimensions (width, height)"
+msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:5
-#: ../vector/v.in.ogr/main.c:144
-#, fuzzy
-msgid "Name of OGR datasource to be imported"
-msgstr "출력할 격자지도"
+#: ../display/d.info/main.c:53
+msgid "Display active frame rectangle"
+msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:7
-#: ../vector/v.in.ogr/main.c:156
-msgid "OGR layer name. If not given, all available layers are imported"
+#: ../display/d.info/main.c:57
+msgid "Display frame dimensions (width, height)"
msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:9
-#: ../vector/v.proj/main.c:105
-#, fuzzy
-msgid "Name for output vector map (default: input)"
-msgstr "출력할 격자지도"
+#: ../display/d.info/main.c:61
+msgid "Display screen rectangle of current region"
+msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:11
+#: ../display/d.info/main.c:66
+msgid "Display geographic coordinates and resolution of entire frame"
+msgstr ""
+#: ../display/d.histogram/main.c:84
#, fuzzy
-msgid "Output vector map extent"
+msgid "histogram"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.import_to_translate.c:12
+#: ../display/d.histogram/main.c:87
+msgid ""
+"Displays a histogram in the form of a pie or bar chart for a user-specified "
+"raster map."
+msgstr ""
+#: ../display/d.histogram/main.c:91
#, fuzzy
-msgid "input;extent of input map;region;extent of current region"
+msgid "Raster map for which histogram will be displayed"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.import_to_translate.c:15
-#: ../vector/v.in.ogr/main.c:235
-msgid "Overrides encoding interpretation, useful when importing ESRI Shapefile"
+#: ../display/d.histogram/main.c:95
+msgid "Indicate if a pie or bar chart is desired"
msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:17
-#: ../vector/v.in.ogr/main.c:211
-msgid "Snapping threshold for boundaries (map units)"
+#: ../display/d.histogram/main.c:104
+msgid "Color for text and axes"
msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:18
-#: ../vector/v.in.ogr/main.c:212
-msgid "'-1' for no snap"
+#: ../display/d.histogram/main.c:115
+msgid "Indicate if cell counts or map areas should be displayed"
msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:20
-#: ../locale/scriptstrings/v.import_to_translate.c:22
-#, fuzzy
-msgid "Input SRS"
-msgstr "입력"
+#: ../display/d.histogram/main.c:125
+msgid "Number of steps to divide the data range into (fp maps only)"
+msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:21
-#: ../general/g.proj/main.c:159
-msgid "EPSG projection code"
+#: ../display/d.histogram/main.c:132
+msgid "Display information for null cells"
msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:23
-#: ../general/g.proj/main.c:181
-#, fuzzy
-msgid "Index number of datum transform parameters"
-msgstr "출력할 격자지도"
+#: ../display/d.histogram/main.c:137
+msgid "Report for ranges defined in cats file (fp maps only)"
+msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:24
-#, fuzzy
-msgid "-1 to list available datum transform parameters"
-msgstr "출력할 격자지도"
+#: ../display/d.histogram/main.c:161
+#, c-format
+msgid "Invalid number of steps: %s"
+msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:25
-#: ../vector/v.in.ogr/main.c:256
-msgid "List supported OGR formats and exit"
+#: ../display/d.histogram/main.c:166
+msgid "When -C flag is set, the nsteps argument is ignored"
msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:26
-#: ../vector/v.in.ogr/main.c:262
-msgid "List available OGR layers in data source and exit"
+#: ../display/d.histogram/main.c:174 ../ps/ps.map/ps_clrtbl.c:39
+#, c-format
+msgid "Category file for <%s> not available"
msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:28
-#: ../locale/scriptstrings/r.import_to_translate.c:32
-#: ../vector/v.in.ogr/main.c:286 ../vector/v.external/args.c:45
-#, fuzzy
-msgid "Assume that the dataset has the same projection as the current location"
-msgstr "출력할 격자지도"
+#: ../display/d.text/main.c:141
+msgid ""
+"Draws text in the active display frame on the graphics monitor using the "
+"current font."
+msgstr ""
-#: ../locale/scriptstrings/r.pack_to_translate.c:1
-#, fuzzy
-msgid "Exports a raster map as GRASS GIS specific archive file"
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.pack_to_translate.c:4
-#: ../locale/scriptstrings/v.unpack_to_translate.c:4
-#: ../locale/scriptstrings/r.unpack_to_translate.c:4
-#: ../locale/scriptstrings/v.pack_to_translate.c:4
-msgid "copying"
+#: ../display/d.text/main.c:147
+msgid "Text to display"
msgstr ""
-#: ../locale/scriptstrings/r.pack_to_translate.c:5
-#, fuzzy
-msgid "Name of raster map to pack up"
-msgstr "출력할 격자지도"
+#: ../display/d.text/main.c:152
+msgid "Input file"
+msgstr "입력파일"
-#: ../locale/scriptstrings/r.pack_to_translate.c:6
-#: ../locale/scriptstrings/v.pack_to_translate.c:6
-#, fuzzy
-msgid "Name for output file (default is <input>.pack)"
-msgstr "출력할 격자지도"
+#: ../display/d.text/main.c:161
+msgid "Text color, either a standard GRASS color or R:G:B triplet"
+msgstr ""
-#: ../locale/scriptstrings/r.pack_to_translate.c:7
-#: ../locale/scriptstrings/v.pack_to_translate.c:7
-msgid "Switch the compression off"
+#: ../display/d.text/main.c:170
+msgid "Text background color, either a standard GRASS color or R:G:B triplet"
msgstr ""
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:1
-msgid "Views BMP images from the PNG driver."
+#: ../display/d.text/main.c:180 ../display/d.northarrow/main.c:92
+#: ../vector/v.label/main.c:156
+msgid "Rotation angle in degrees (counter-clockwise)"
msgstr ""
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:5
-#, fuzzy
-msgid "Name of input image file"
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:1
-msgid "Rebuilds or removes all locally installed GRASS Addons extensions."
+#: ../display/d.text/main.c:188
+msgid "Line spacing"
msgstr ""
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:2
+#: ../display/d.text/main.c:197
msgid ""
-"By default only extensions built against different GIS Library are rebuilt."
+"Screen position at which text will begin to be drawn (percentage, [0,0] is "
+"lower left)"
msgstr ""
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:4
-#: ../locale/scriptstrings/g.extension_to_translate.c:4
-msgid "installation"
+#: ../display/d.text/main.c:206
+msgid "The screen line number on which text will begin to be drawn"
msgstr ""
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:5
-#: ../locale/scriptstrings/g.extension_to_translate.c:5
-msgid "extensions"
+#: ../display/d.text/main.c:215
+msgid "Text alignment"
msgstr ""
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:6
-#: ../locale/scriptstrings/g.extension_to_translate.c:10
-#: ../general/g.mapsets/main.c:81 ../vector/v.net/args.c:36
-#, fuzzy
-msgid "Operation to be performed"
-msgstr "출력할 격자지도"
+#: ../display/d.text/main.c:232
+msgid "Height of letters in percentage of available frame height"
+msgstr ""
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:7
-msgid "Force operation (required for removal)"
+#: ../display/d.text/main.c:252
+msgid "Screen position in pixels ([0,0] is top left)"
msgstr ""
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:1
-msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
+#: ../display/d.text/main.c:257
+msgid "Screen position in geographic coordinates"
msgstr ""
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
-#, fuzzy
-msgid "Input map is in Matlab format"
-msgstr "출력할 격자지도"
+#: ../display/d.text/main.c:262
+msgid "Use bold text"
+msgstr "굵은 글꼴을 씁니다"
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
-msgid "Create a 3D vector points map from 3 column Matlab data"
+#: ../display/d.text/main.c:267 ../display/d.northarrow/main.c:144
+msgid "Use radians instead of degrees for rotation"
msgstr ""
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
-#, fuzzy
-msgid "Name of input file in Mapgen/Matlab format"
-msgstr "출력할 격자지도"
+#: ../display/d.text/main.c:272
+msgid "Font size is height in pixels"
+msgstr ""
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:7
-#, fuzzy
-msgid "Name for output vector map (omit for display to stdout)"
-msgstr "출력할 격자지도"
+#: ../display/d.text/main.c:284
+msgid "Please choose only one placement method"
+msgstr ""
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:1
-msgid ""
-"Observes specific locations in a space time raster dataset over a period of "
-"time using vector points."
+#: ../display/d.text/main.c:343
+msgid "Invalid coordinates"
msgstr ""
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:6
-#, fuzzy
+#: ../display/d.text/main.c:387
+#, c-format
msgid ""
-"Name of the new created vector map that stores the sampled values in "
-"different layers"
-msgstr "출력할 격자지도"
+"\n"
+"Please enter text instructions. Enter EOF (ctrl-d) on last line to quit\n"
+msgstr ""
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:7
-msgid ""
-"Names of the vector columns to be created and to store sampled raster "
-"values, one name for each STRDS"
+#: ../display/d.text/main.c:578
+#, c-format
+msgid "[%s]: No such color. Use '%s'"
msgstr ""
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:1
-#, fuzzy
-msgid "Imports space time raster dataset."
-msgstr "출력할 격자지도"
+#: ../display/d.fontlist/main.c:47
+msgid "Lists the available fonts."
+msgstr ""
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:8
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:8
-msgid "Path to the extraction directory"
+#: ../display/d.fontlist/main.c:51
+msgid "List fonts (default; provided for compatibility with d.font)"
msgstr ""
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:9
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:9
-#: ../locale/scriptstrings/t.create_to_translate.c:8
-msgid "Title of the new space time dataset"
+#: ../display/d.erase/main.c:33
+msgid ""
+"Erases the contents of the active graphics display frame with user defined "
+"color."
msgstr ""
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:10
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:10
-#: ../locale/scriptstrings/t.create_to_translate.c:9
-msgid "Description of the new space time dataset"
+#: ../display/d.erase/main.c:42
+msgid "Remove all frames and erase the screen"
msgstr ""
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:11
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:11
+#: ../display/d.where/main.c:48
msgid ""
-"Create a new location and import the data into it. Do not run this module in "
-"parallel or interrupt it when a new location should be created"
+"Identifies the geographic coordinates associated with point locations given "
+"in display coordinates."
msgstr ""
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:14
-#, fuzzy
-msgid "Set the current region from the last map that was imported"
-msgstr "출력할 격자지도"
+#: ../display/d.where/main.c:58
+msgid "Display coordinates to convert"
+msgstr ""
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:15
+#: ../display/d.where/main.c:63
#, fuzzy
-msgid "Link the raster files using r.external"
+msgid "File from which to read coordinates (\"-\" to read from stdin)"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:16
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:12
-msgid "Extend location extents based on new dataset"
+#: ../display/d.where/main.c:67
+msgid "Output lat/long in decimal degree"
msgstr ""
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:19
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not "
-"import the space time raster datasets."
+#: ../display/d.where/main.c:72
+msgid "Output lat/long referenced to current ellipsoid"
msgstr ""
-#, fuzzy
+#: ../display/d.where/main.c:77
msgid ""
-"Performs spatio-temporal mapcalc expressions on temporally sampled maps of "
-"space time raster datasets."
-msgstr "출력할 격자지도"
+"Output lat/long referenced to WGS84 ellipsoid using datum transformation "
+"parameters defined in current location (if available)"
+msgstr ""
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:6
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:6
-msgid "Spatio-temporal mapcalc expression"
+#: ../display/d.where/main.c:83
+msgid "Output frame coordinates of current display monitor (percentage)"
msgstr ""
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:7
-#, fuzzy
-msgid "Basename for output raster maps"
-msgstr "출력할 격자지도"
+#: ../display/d.where/main.c:91
+msgid "Ambiguous request for lat/long ellipsoids"
+msgstr ""
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:13
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:10
-msgid "Number of r.mapcalc processes to run in parallel"
+#: ../display/d.where/main.c:94
+msgid "Please specify a lat/long ellipsoid with -l or -w"
msgstr ""
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:11
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:10
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:11
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:12
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:9
+#: ../display/d.where/main.c:136
msgid ""
-"Check the spatial topology of temporally related maps and process only "
-"spatially related maps"
+"WGS84 output not possible as this location does not contain\n"
msgstr ""
-#, fuzzy
-msgid "Computes cyclic accumulations of a space time raster dataset."
+#: ../display/d.where/where.c:29
+#, fuzzy, c-format
+msgid "Invalid coordinates <%s,%s>"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:6
+#: ../display/d.title/main.c:52
msgid ""
-"Input space time raster dataset that defines the lower threshold, values "
-"lower this threshold are excluded from accumulation"
+"Create a TITLE for a raster map in a form suitable for display with d.text."
msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:7
-msgid ""
-"Input space time raster dataset that defines the upper threshold, values "
-"upper this threshold are excluded from accumulation"
+#: ../display/d.title/main.c:63
+msgid "Sets the text color"
msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:12
-msgid "The granularity for accumulation '1 day'"
+#: ../display/d.title/main.c:71
+msgid "Sets the text size as percentage of the frame's height"
msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:16
-msgid ""
-"Use these limits in case lower and/or upper input space time raster "
-"datasets are not defined or contain NULL values"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:17
+#: ../display/d.title/main.c:75
#, fuzzy
-msgid "Scale factor for input space time raster dataset"
+msgid "Draw title on current display"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:18
-#, fuzzy
-msgid "Shift factor for input space time raster dataset"
-msgstr "출력할 격자지도"
+#: ../display/d.title/main.c:79
+msgid "Do a fancier title"
+msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:19
-msgid ""
-"This method will be applied to compute the accumulative values from the "
-"input maps in a single granule"
+#: ../display/d.title/main.c:84
+msgid "Do a simple title"
msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:20
-msgid ""
-"Growing Degree Days or Winkler indices; Mean: sum(input maps)/(number of "
-"input maps); Biologically Effective Degree Days; Huglin Heliothermal index"
+#: ../display/d.title/main.c:102
+msgid "Title can be fancy or simple, not both"
msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:1
-msgid ""
-"Displays spectral response at user specified locations in group or images."
+#: ../display/d.title/main.c:105
+msgid "No map name given"
msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:5
-#: ../locale/scriptstrings/i.oif_to_translate.c:3
-msgid "multispectral"
+#: ../display/d.northarrow/draw_n_arrow.c:108
+#: ../display/d.northarrow/draw_n_arrow.c:174
+msgid "Could not parse symbol"
msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:9
+#: ../display/d.northarrow/main.c:49
#, fuzzy
-msgid "Name for output image (or text file for -t)"
+msgid "Displays a north arrow on the graphics monitor."
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:11
-#, fuzzy
-msgid "Graphics format for output file"
-msgstr "출력할 격자지도"
+#: ../display/d.northarrow/main.c:53
+msgid "North arrow style"
+msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:13
-msgid "Show sampling coordinates instead of numbering in the legend"
+#: ../display/d.northarrow/main.c:61
+msgid "Two color arrowhead"
msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:14
-#, fuzzy
-msgid "Use gnuplot for display"
-msgstr "출력할 격자지도"
+#: ../display/d.northarrow/main.c:62
+msgid "Two color arrowhead with circle"
+msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:15
-#, fuzzy
-msgid "output to text file"
-msgstr "출력할 격자지도"
+#: ../display/d.northarrow/main.c:63
+msgid "Narrow with blending N"
+msgstr ""
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:1
-msgid "Imports ASCII x,y[,z] coordinates as a series of lines."
+msgid "Long with small arrowhead"
msgstr ""
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:4
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:5
-#: ../locale/scriptstrings/v.to.lines_to_translate.c:5
-#: ../vector/v.type/main.c:42 ../vector/v.category/main.c:683
-#: ../vector/v.build.polylines/main.c:114 ../vector/v.edit/main.c:57
-#: ../vector/v.to.points/main.c:56 ../vector/v.buffer/main.c:226
-#: ../vector/v.parallel/main.c:52
-msgid "line"
+#: ../display/d.northarrow/main.c:64
+msgid "Inverted narrow inside a circle"
msgstr ""
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:5
-#: ../locale/scriptstrings/v.to.lines_to_translate.c:6
-#: ../vector/v.segment/main.c:63 ../vector/v.type/main.c:43
-#: ../vector/v.category/main.c:679 ../vector/v.edit/main.c:59
-#: ../vector/v.to.points/main.c:59
-msgid "point"
+#: ../display/d.northarrow/main.c:65
+msgid "Triangle and N inside a circle"
msgstr ""
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:6
-msgid "Create a 3D line from 3 column data"
+#: ../display/d.northarrow/main.c:66
+msgid "Arrowhead and N inside a circle"
msgstr ""
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:7
-#, fuzzy
-msgid "Name of input file (or \"-\" to read from stdin)"
-msgstr "출력할 격자지도"
+#: ../display/d.northarrow/main.c:67
+msgid "Tall half convex arrowhead"
+msgstr ""
-#: ../locale/scriptstrings/v.unpack_to_translate.c:1
-#, fuzzy
-msgid ""
-"Imports a vector map as GRASS GIS specific archive file (packed with v.pack)"
-msgstr "출력할 격자지도"
+#: ../display/d.northarrow/main.c:68
+msgid "Tall half concave arrowhead"
+msgstr ""
-#: ../locale/scriptstrings/v.unpack_to_translate.c:5
-#: ../locale/scriptstrings/r.unpack_to_translate.c:5
-#, fuzzy
-msgid "Name of input pack file"
-msgstr "출력할 격자지도"
+msgid "Thin arrow in a circle"
+msgstr ""
-#: ../locale/scriptstrings/v.unpack_to_translate.c:6
-msgid "Name for output vector map"
-msgstr "출력 벡터지도 이름"
+#: ../display/d.northarrow/main.c:69
+msgid "Fat arrow in a circle"
+msgstr ""
-#: ../locale/scriptstrings/v.unpack_to_translate.c:7
+msgid "One color arrowhead"
+msgstr ""
+#: ../display/d.northarrow/main.c:70
+msgid "Fancy compass"
+msgstr ""
+msgid "Basic compass"
+msgstr ""
#, fuzzy
-msgid "Default: taken from input file internals"
+msgid "Simple arrow"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/m.proj_to_translate.c:1
-msgid "Converts coordinates from one projection to another (cs2cs frontend)."
+#: ../display/d.northarrow/main.c:71
+msgid "Thin arrow"
msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:2
-#: ../misc/m.nviz.script/main.c:69 ../misc/m.measure/main.c:46
-#: ../misc/m.cogo/main.c:225 ../misc/m.transform/main.c:316
-#: ../misc/m.nviz.image/main.c:50
-msgid "miscellaneous"
+msgid "Fat arrow"
msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:5
#, fuzzy
-msgid "Input coordinates to reproject"
+msgid "4-point star"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/m.proj_to_translate.c:6
-#: ../locale/scriptstrings/m.proj_to_translate.c:9
-#: ../locale/scriptstrings/m.proj_to_translate.c:13
+#: ../display/d.northarrow/main.c:99
+msgid "Displayed letter on the top of arrow"
+msgstr ""
+#: ../display/d.northarrow/main.c:108
#, fuzzy
-msgid "Input coordinates"
+msgid "Fill color"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/m.proj_to_translate.c:7
+#: ../display/d.northarrow/main.c:134
+msgid "Draw the symbol without text"
+msgstr ""
+#: ../display/d.northarrow/main.c:139
#, fuzzy
-msgid "Name of input coordinate file"
+msgid "Do not rotate text with symbol"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/m.proj_to_translate.c:10
+#: ../display/d.linegraph/main.c:232
+msgid ""
+"Generates and displays simple line graphs in the active graphics monitor "
+"display frame."
+msgstr ""
+#: ../display/d.linegraph/main.c:236
+msgid "Name of data file for X axis of graph"
+msgstr ""
+#: ../display/d.linegraph/main.c:242
+msgid "Name of data file(s) for Y axis of graph"
+msgstr ""
+#: ../display/d.linegraph/main.c:249
#, fuzzy
-msgid "Name for output coordinate file (omit to send to stdout)"
-msgstr "출력할 격자지도"
+msgid "Path to files"
+msgstr "글꼴파일의 경로"
-#: ../locale/scriptstrings/m.proj_to_translate.c:12
-msgid "Field separator (format: input[,output])"
+#: ../display/d.linegraph/main.c:251
+msgid "Path to the directory where the input files are located"
msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:14
-msgid "Input projection parameters (PROJ.4 style)"
+#: ../display/d.linegraph/main.c:259
+msgid "Color for Y data"
msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:15
-#: ../locale/scriptstrings/m.proj_to_translate.c:17
-#: ../locale/scriptstrings/m.proj_to_translate.c:19
-#: ../locale/scriptstrings/m.proj_to_translate.c:21
+#: ../display/d.linegraph/main.c:272
#, fuzzy
-msgid "Projections"
+msgid "Width of the lines"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/m.proj_to_translate.c:16
-msgid "Output projection parameters (PROJ.4 style)"
+#: ../display/d.linegraph/main.c:279
+msgid "Color for axis, tics, numbers, and title"
msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:18
-msgid "Use LL WGS84 as input and current location as output projection"
+#: ../display/d.linegraph/main.c:287
+msgid "Title for X data"
msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:20
-msgid "Use current location as input and LL WGS84 as output projection"
+#: ../display/d.linegraph/main.c:294
+msgid "Title for Y data"
msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:22
-msgid ""
-"Output long/lat in decimal degrees, or other projections with many decimal "
-"places"
+#: ../display/d.linegraph/main.c:301
+msgid "Title for Graph"
msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:24
-msgid "Include input coordinates in output file"
+#: ../display/d.linegraph/main.c:308
+msgid "Minimum and maximun value for Y axis (min,max)"
msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:26
-msgid "Include column names in output file"
+#: ../display/d.linegraph/main.c:315
+msgid "Tic values for the Y axis"
msgstr ""
+#: ../display/d.linegraph/main.c:329
#, fuzzy
-msgid ""
-"Apply temporal and spatial operations on space time raster datasets using "
-"temporal raster algebra."
+msgid "Symbol for point"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:6
+#: ../display/d.linegraph/main.c:338
#, fuzzy
-msgid ""
-"r.mapcalc expression for temporal and spatial analysis of space time raster "
-"datasets"
-msgstr "출력할 격자지도"
+msgid "Point size"
+msgstr "글꼴크기"
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:12
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:13
-msgid "Use granularity sampling instead of the temporal topology approach"
+#: ../display/d.linegraph/main.c:347
+msgid "Color for point symbol edge color"
msgstr ""
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:13
-#: ../locale/scriptstrings/t.select_to_translate.c:9
-msgid ""
-"Perform a dry run, compute all dependencies and module calls but don't run "
-"them"
+#: ../display/d.linegraph/main.c:353
+msgid "Width of point symbol lines"
msgstr ""
-#: ../locale/scriptstrings/t.info_to_translate.c:1
-#, fuzzy
-msgid "Lists information about space time datasets and maps."
-msgstr "출력할 격자지도"
+#: ../display/d.linegraph/main.c:412
+msgid "Maximum of 10 Y data files exceeded"
+msgstr ""
-#: ../locale/scriptstrings/t.info_to_translate.c:6
-#, fuzzy
-msgid "Name of an existing space time dataset or map"
+#: ../display/d.linegraph/main.c:445
+#, fuzzy, c-format
+msgid "Cannot find/open symbol: '%s'"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.info_to_translate.c:10
-#, fuzzy
-msgid ""
-"Print history information in human readable shell style for space time "
-"datasets"
-msgstr "출력할 격자지도"
+#: ../display/d.linegraph/main.c:458
+#, c-format
+msgid "Color <%s> cannot for option %s be parsed"
+msgstr ""
-#: ../locale/scriptstrings/t.info_to_translate.c:11
-msgid "Print information about the temporal DBMI interface and exit"
+#: ../display/d.linegraph/main.c:495
+#, c-format
+msgid "Only <%d> colors given for <%d> lines"
msgstr ""
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:1
-#, fuzzy
-msgid "Exports a space time vector dataset as GRASS GIS specific archive file."
-msgstr "출력할 격자지도"
+#: ../display/d.linegraph/main.c:538
+#, c-format
+msgid "Number of widths (%d) is higher then the number of files (%d)"
+msgstr ""
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:6
-#, fuzzy
-msgid "Name of a space time vector dataset archive"
-msgstr "출력할 격자지도"
+#: ../display/d.linegraph/main.c:550
+#, c-format
+msgid "Number of widths (%d) is lower then the number of files (%d)"
+msgstr ""
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:7
-msgid "Path to the work directory, default is /tmp"
+#: ../display/d.linegraph/main.c:601
+#, c-format
+msgid "Y input file <%s> contains fewer data points than the X input file"
msgstr ""
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:8
-#, fuzzy
-msgid "Compression method of the tar archive"
-msgstr "출력할 격자지도"
+#: ../display/d.linegraph/main.c:605
+#, c-format
+msgid "Y input file <%s> contains more data points than the X input file"
+msgstr ""
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:9
-#, fuzzy
-msgid "The export format of a single vector map"
-msgstr "출력할 격자지도"
+#: ../display/d.linegraph/main.c:610
+#, c-format
+msgid "The last point will be ignored"
+msgid_plural "The last %d points will be ignored"
+msgstr[0] ""
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:10
-msgid "Supported are GML via v.out.ogr and the GRASS package format of v.pack"
+#: ../display/d.linegraph/main.c:688
+#, c-format
+msgid "Problem reading X data file at line %d"
msgstr ""
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:1
-msgid "Sets color rules based on stddev from a raster map's mean value."
+#: ../display/d.linegraph/main.c:698
+#, c-format
+msgid "Problem reading <%s> data file at line %d"
msgstr ""
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
-msgid "Color using standard deviation bands"
+#: ../display/d.rgb/main.c:58
+msgid ""
+"Displays three user-specified raster maps as red, green, and blue overlays "
+"in the active graphics frame."
msgstr ""
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:5
-msgid "Force center at zero"
+#: ../vector/v.net.spanningtree/main.c:48
+msgid "spanning tree"
msgstr ""
-#: ../locale/scriptstrings/d.to.rast_to_translate.c:1
-#, fuzzy
-msgid "Saves the contents of the active display monitor to a raster map."
-msgstr "출력할 격자지도"
+#: ../vector/v.net.spanningtree/main.c:50
+msgid "Computes minimum spanning tree for the network."
+msgstr ""
-#: ../locale/scriptstrings/d.redraw_to_translate.c:1
-msgid "Redraws the content of currently selected monitor."
+#: ../vector/v.net.spanningtree/main.c:60
+#: ../vector/v.net.spanningtree/main.c:66
+#: ../vector/v.net.spanningtree/main.c:73
+#: ../vector/v.net.spanningtree/main.c:79 ../vector/v.net.components/main.c:85
+#: ../vector/v.net.components/main.c:91 ../vector/v.net.components/main.c:98
+#: ../vector/v.net.components/main.c:104 ../vector/v.net.components/main.c:111
+#: ../vector/v.net.distance/main.c:83 ../vector/v.net.distance/main.c:90
+#: ../vector/v.net.distance/main.c:96 ../vector/v.net.distance/main.c:142
+#: ../vector/v.net.distance/main.c:148 ../vector/v.net.distance/main.c:154
+#: ../vector/v.net.flow/main.c:71 ../vector/v.net.flow/main.c:77
+#: ../vector/v.net.flow/main.c:91 ../vector/v.net.flow/main.c:97
+#: ../vector/v.net.flow/main.c:103 ../vector/v.net.timetable/main.c:275
+#: ../vector/v.net.timetable/main.c:281 ../vector/v.net.timetable/main.c:289
+#: ../vector/v.net.timetable/main.c:296 ../vector/v.net.timetable/main.c:303
+#: ../vector/v.net.alloc/main.c:77 ../vector/v.net.alloc/main.c:111
+#: ../vector/v.net.alloc/main.c:118 ../vector/v.net.alloc/main.c:125
+#: ../vector/v.net.allpairs/main.c:94 ../vector/v.net.allpairs/main.c:100
+#: ../vector/v.net.allpairs/main.c:107 ../vector/v.net.connectivity/main.c:65
+#: ../vector/v.net.connectivity/main.c:71
+#: ../vector/v.net.connectivity/main.c:78
+#: ../vector/v.net.connectivity/main.c:84
+#: ../vector/v.net.connectivity/main.c:92 ../vector/v.net.bridge/main.c:61
+#: ../vector/v.net.bridge/main.c:67 ../vector/v.net.bridge/main.c:74
+#: ../vector/v.net.bridge/main.c:80 ../vector/v.net.bridge/main.c:87
+#: ../vector/v.net.path/main.c:80 ../vector/v.net.path/main.c:87
+#: ../vector/v.net.path/main.c:94 ../vector/v.net.centrality/main.c:110
+#: ../vector/v.net.centrality/main.c:116 ../vector/v.net.centrality/main.c:130
+#: ../vector/v.net.centrality/main.c:136 ../vector/v.net.centrality/main.c:143
+#: ../vector/v.net.iso/main.c:123 ../vector/v.net.iso/main.c:128
+#: ../vector/v.net.iso/main.c:133 ../vector/v.net.salesman/main.c:169
+#: ../vector/v.net.salesman/main.c:177
+msgid "Cost"
msgstr ""
-#, fuzzy
-msgid ""
-"Apply temporal and spatial operations on space time 3D raster datasets using "
-"temporal 3D raster algebra."
-msgstr "출력할 격자지도"
+#: ../vector/v.net.spanningtree/main.c:78 ../vector/v.net.components/main.c:110
+#: ../vector/v.net.distance/main.c:153 ../vector/v.net.flow/main.c:102
+#: ../vector/v.net.timetable/main.c:302 ../vector/v.net.alloc/main.c:124
+#: ../vector/v.net.allpairs/main.c:106 ../vector/v.net.connectivity/main.c:91
+#: ../vector/v.net.bridge/main.c:86 ../vector/v.net.path/main.c:93
+#: ../vector/v.net.centrality/main.c:142 ../vector/v.net.iso/main.c:132
+msgid "Node cost column (number)"
+msgstr ""
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:7
-#, fuzzy
-msgid ""
-"Algebraic expression for temporal and spatial analysis of space time 3D "
-"raster datasets"
+#: ../vector/v.net.spanningtree/main.c:124
+#: ../vector/v.net.components/main.c:163 ../vector/v.net.distance/main.c:264
+#: ../vector/v.net.flow/main.c:226 ../vector/v.net.timetable/main.c:405
+#: ../vector/v.net.connectivity/main.c:178 ../vector/v.net.bridge/main.c:134
+#: ../vector/v.net.centrality/main.c:284 ../vector/v.generalize/network.c:89
+#, fuzzy, c-format
+msgid "Unable to build graph for vector map <%s>"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
+#: ../vector/v.surf.rst/main.c:144 ../vector/v.extrude/main.c:70
+#: ../vector/v.to.3d/main.c:38 ../vector/v.out.postgis/main.c:49
+#: ../vector/v.kriging/main.c:69 ../vector/v.kriging/main.c:163
+#: ../vector/v.drape/main.c:59 ../vector/v.hull/main.c:54
+msgid "3D"
msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
-msgid "Value option that sets the area size limit (in hectares)"
+#: ../vector/v.surf.rst/main.c:145
+msgid "Performs surface interpolation from vector points map by splines."
msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:6
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:8
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:10
-#: ../locale/scriptstrings/v.to.lines_to_translate.c:8
-msgid "Area"
+#: ../vector/v.surf.rst/main.c:147
+msgid ""
+"Spatial approximation and topographic analysis from given point or isoline "
+"data in vector format to floating point raster format using regularized "
+"spline with tension."
msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:7
-msgid "Lesser or greater than specified value"
+#: ../vector/v.surf.rst/main.c:154
+msgid "Perform cross-validation procedure without raster approximation"
msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:9
-#, fuzzy
-msgid "Method used for reclassification"
-msgstr "출력할 격자지도"
+#: ../vector/v.surf.rst/main.c:159
+msgid "Use scale dependent tension"
+msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:11
-#, fuzzy
-msgid "Input map is clumped"
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:12
-msgid "Clumps including diagonal neighbors"
+#: ../vector/v.surf.rst/main.c:178 ../vector/v.surf.bspline/main.c:118
+msgid "Name of the attribute column with values to be used for approximation"
msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:1
+#: ../vector/v.surf.rst/main.c:179 ../vector/v.surf.idw/main.c:102
msgid ""
-"Create a 3D raster map from an assemblage of many coordinates using "
-"univariate statistics"
+"If not given and input is 2D vector map then category values are used. If "
+"input is 3D vector map then z-coordinates are used."
msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:13
+#: ../vector/v.surf.rst/main.c:189
#, fuzzy
-msgid "ASCII file containing input data"
+msgid "Name for output surface elevation raster map"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:17
-msgid "Storage type for resultant raster map"
-msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:23
+#: ../vector/v.surf.rst/main.c:219
#, fuzzy
-msgid "Column number of z coordinates in input file"
+msgid "Name for output mean curvature raster map"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:26
-msgid "If not given or set to 0, the data points' z-values are used"
-msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:28
-msgid "Filter range for value column data (min,max)"
-msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:29
+#: ../vector/v.surf.rst/main.c:225 ../vector/v.vol.rst/main.c:290
#, fuzzy
-msgid "Scaling factor to apply to value column data"
+msgid "Name for output deviations vector point map"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:35
-msgid "Number of parallel processes to launch"
-msgstr ""
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
+#: ../vector/v.surf.rst/main.c:232 ../vector/v.vol.rst/main.c:296
#, fuzzy
-msgid ""
-"Creates and connects a new attribute table to a given layer of an existing "
-"vector map."
+msgid "Name for output cross-validation errors vector point map"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
+#: ../vector/v.surf.rst/main.c:239
#, fuzzy
-msgid "Name of new attribute table (default: vector map name)"
+msgid "Name for output vector map showing quadtree segmentation"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:8
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:9
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:12
+#: ../vector/v.surf.rst/main.c:246
#, fuzzy
-msgid "Definition"
+msgid "Name for output vector map showing overlapping windows"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:7
+#: ../vector/v.surf.rst/main.c:252
#, fuzzy
-msgid "Layer number where to add new attribute table"
+msgid "Name of raster map used as mask"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:10
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:6
-msgid "Name and type of the new column(s) ('name type [,name type, ...]')"
+#: ../vector/v.surf.rst/main.c:260 ../vector/v.vol.rst/main.c:267
+msgid "Tension parameter"
msgstr ""
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:11
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
+#: ../vector/v.surf.rst/main.c:267 ../vector/v.vol.rst/main.c:275
+msgid "Smoothing parameter"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:275
+msgid "Name of the attribute column with smoothing parameters"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:300 ../vector/v.vol.rst/main.c:336
+msgid "Minimum distance between points (to remove almost identical points)"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:308
msgid ""
-"Types depend on database backend, but all support VARCHAR(), INT, DOUBLE "
-"PRECISION and DATE. Example: 'label varchar(250), value integer'"
+"Maximum distance between points on isoline (to insert additional points)"
msgstr ""
-#: ../locale/scriptstrings/v.db.update_to_translate.c:1
-#, fuzzy
-msgid "Updates a column in the attribute table connected to a vector map."
+#: ../vector/v.surf.rst/main.c:317
+msgid "Conversion factor for values used for approximation"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:388 ../vector/v.surf.rst/main.c:393
+#: ../vector/v.surf.rst/main.c:398 ../vector/v.surf.rst/main.c:403
+#, fuzzy, c-format
+msgid "Output vector map name <%s> is not valid map name"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:5
+#: ../vector/v.surf.rst/main.c:416
#, fuzzy
-msgid "Name of attribute column to update"
+msgid "You are not outputting any raster or vector maps"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:6
-msgid "Literal value to update the column with"
+#: ../vector/v.surf.rst/main.c:425
+msgid ""
+"Both cross-validation options (-c flag and cvdev vector output) must be "
+"specified"
msgstr ""
-#: ../locale/scriptstrings/v.db.update_to_translate.c:7
+#: ../vector/v.surf.rst/main.c:428
msgid ""
-"Name of other attribute column to query, can be combination of columns (e.g. "
-"co1+col2)"
+"The cross-validation cannot be computed simultaneously with output raster or "
+"devi file"
msgstr ""
-#: ../locale/scriptstrings/v.db.update_to_translate.c:8
-msgid "Name of SQLite extension file for extra functions (SQLite backend only)"
+#: ../vector/v.surf.rst/main.c:446
+msgid "Using anisotropy - both theta and scalex have to be specified"
msgstr ""
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:1
-#, fuzzy
-msgid "Extracts a subset of a space time vector dataset."
-msgstr "출력할 격자지도"
+#: ../vector/v.surf.rst/main.c:454
+msgid "Both smatt and smooth options specified - using constant"
+msgstr ""
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:9
-msgid ""
-"The number of v.extract processes to run in parallel. Use only if database "
-"backend is used which supports concurrent writing"
+#: ../vector/v.surf.rst/main.c:464
+msgid "The computation will last too long - lower npmin is suggested"
msgstr ""
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:10
-#, fuzzy
-msgid "Register empty maps"
-msgstr "출력할 격자지도"
+#: ../vector/v.surf.rst/main.c:482 ../vector/v.surf.rst/main.c:487
+#: ../vector/v.surf.rst/main.c:491 ../vector/v.surf.rst/main.c:496
+#: ../vector/v.surf.rst/main.c:500 ../vector/v.surf.rst/main.c:504
+#: ../vector/v.vol.rst/main.c:507 ../vector/v.vol.rst/main.c:510
+#: ../vector/v.vol.rst/main.c:513 ../vector/v.vol.rst/main.c:516
+#: ../vector/v.vol.rst/main.c:519 ../vector/v.vol.rst/main.c:522
+#: ../vector/v.vol.rst/main.c:525 ../vector/v.vol.rst/main.c:528
+#: ../vector/v.vol.rst/main.c:531 ../vector/v.vol.rst/main.c:534
+#: ../vector/v.vol.rst/main.c:621 ../vector/v.vol.rst/main.c:652
+#: ../vector/v.vol.rst/main.c:674 ../vector/v.vol.rst/main.c:696
+#: ../vector/v.vol.rst/main.c:718 ../vector/v.vol.rst/main.c:740
+#: ../vector/v.vol.rst/main.c:762 ../vector/v.vol.rst/main.c:784
+#: ../vector/v.vol.rst/user3.c:273 ../vector/v.vol.rst/user3.c:279
+#: ../vector/v.vol.rst/user3.c:285 ../vector/v.vol.rst/user2.c:122
+#: ../vector/v.vol.rst/user2.c:232
+#, c-format
+msgid "Not enough memory for %s"
+msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:1
-#, fuzzy
-msgid ""
-"Imports raster data into a GRASS raster map using GDAL library and "
-"reprojects on the fly."
+#: ../vector/v.surf.rst/main.c:511 ../vector/v.surf.rst/main.c:517
+#: ../vector/v.surf.rst/main.c:520 ../vector/v.surf.rst/main.c:524
+#: ../vector/v.vol.rst/main.c:539 ../vector/v.vol.rst/main.c:544
+#: ../vector/v.vol.rst/main.c:546
+#, fuzzy, c-format
+msgid "Unable to create %s"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.import_to_translate.c:5
-#, fuzzy
-msgid "Name of GDAL dataset to be imported"
+#: ../vector/v.surf.rst/main.c:537 ../vector/v.out.ascii/main.c:104
+#: ../vector/v.colors/main.c:270 ../vector/v.colors.out/make_colors.c:27
+#: ../vector/v.colors.out/scan_cats.c:24
+#, fuzzy, c-format
+msgid "Layer <%s> not found"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.import_to_translate.c:7
-msgid "Input band(s) to select (default is all bands)"
+#: ../vector/v.surf.rst/main.c:541 ../vector/v.surf.bspline/main.c:272
+msgid ""
+"Input is 3D: using attribute values instead of z-coordinates for "
+"approximation"
msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:13
-#, fuzzy
-msgid "Resampling method to use for reprojection"
-msgstr "출력할 격자지도"
+#: ../vector/v.surf.rst/main.c:543 ../vector/v.surf.bspline/main.c:274
+msgid "Input is 3D: using z-coordinates for approximation"
+msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:14
-msgid ""
-"nearest;nearest neighbor;bilinear;bilinear interpolation;bicubic;bicubic "
-"interpolation;lanczos;lanczos filter;bilinear_f;bilinear interpolation with "
-"fallback;bicubic_f;bicubic interpolation with fallback;lanczos_f;lanczos "
-"filter with fallback"
+#: ../vector/v.surf.rst/main.c:547
+msgid "Input is 2D: using attribute values for approximation"
msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:16
-#, fuzzy
-msgid "Output raster map extent"
-msgstr "출력할 격자지도"
+#: ../vector/v.surf.rst/main.c:549
+msgid "Input is 2D: using category values for approximation"
+msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:17
-#, fuzzy
-msgid "region;extent of current region;input;extent of input map"
+#: ../vector/v.surf.rst/main.c:592 ../vector/v.vol.rst/main.c:605
+#, fuzzy, c-format
+msgid "Unable to create table '%s'"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.import_to_translate.c:19
+#: ../vector/v.surf.rst/main.c:662
+#, c-format
+msgid ""
+"Processing all selected output files will require %d bytes of disk space for "
+"temp files"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:682
#, fuzzy
-msgid "Resolution of output raster map (default: estimated)"
+msgid "Processing segments..."
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.import_to_translate.c:20
-msgid ""
-"estimated;estimated resolution;value;user-specified resolution;region;"
-"current region resolution"
+#: ../vector/v.surf.rst/main.c:688
+msgid "Interp_segmets failed"
msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:22
+#: ../vector/v.surf.rst/main.c:706
#, fuzzy
-msgid "Resolution of output raster map (use with option resolution=value)"
+msgid "Unable to write raster maps - try to increase resolution"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.import_to_translate.c:26
+#: ../vector/v.what.rast3/main.c:70 ../vector/v.drape/main.c:60
+#: ../vector/v.what.rast/main.c:77
#, fuzzy
-msgid "Estimate resolution only"
+msgid "surface information"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.shift_to_translate.c:1
+#: ../vector/v.what.rast3/main.c:72
+msgid "Uploads 3D raster values at positions of vector points to the table."
+msgstr ""
+#: ../vector/v.what.rast3/main.c:82
#, fuzzy
-msgid "Shifts temporally the maps of a space time dataset."
+msgid "Name of existing 3D raster map to be queried"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.shift_to_translate.c:3
-#: ../locale/scriptstrings/t.snap_to_translate.c:3
-#: ../locale/scriptstrings/t.merge_to_translate.c:3
-#, fuzzy
-msgid "time management"
-msgstr "지도관리"
+#: ../vector/v.what.rast3/main.c:135
+#, fuzzy, c-format
+msgid "Error opening 3D raster map <%s>"
+msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.shift_to_translate.c:4
-msgid "shift"
+#: ../vector/v.what.rast3/main.c:141 ../vector/v.to.rast/support.c:308
+#: ../vector/v.to.rast/support.c:547 ../vector/v.to.rast/vect2rast.c:69
+#, c-format
+msgid "Column <%s> not found"
msgstr ""
-#: ../locale/scriptstrings/t.shift_to_translate.c:6
-#: ../locale/scriptstrings/t.snap_to_translate.c:6
+#: ../vector/v.what.rast3/main.c:144
+msgid "Column type not supported, please use a column with double type"
+msgstr ""
+#: ../vector/v.what.rast3/main.c:158 ../vector/v.what.rast/main.c:206
#, fuzzy
-msgid "Name of an existing space time dataset"
+msgid "Reading features from vector map..."
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.shift_to_translate.c:9
-msgid "Shift granularity"
-msgstr ""
+#: ../vector/v.what.rast3/main.c:215
+#, fuzzy, c-format
+msgid "%d point outside current region was skipped"
+msgid_plural "%d points outside current region were skipped"
+msgstr[0] "출력할 격자지도"
-#: ../locale/scriptstrings/t.shift_to_translate.c:10
-msgid ""
-"Format absolute time: \"x years, x months, x weeks, x days, x hours, x "
-"minutes, x seconds\", relative time is of type integer"
-msgstr ""
+#: ../vector/v.what.rast3/main.c:220
+#, fuzzy, c-format
+msgid "%d point without category was skipped"
+msgid_plural "%d points without category were skipped"
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:1
-msgid "Search in GRASS modules using keywords"
+#: ../vector/v.what.rast3/main.c:259
+#, c-format
+msgid "More points (%d) of category %d, value set to 'NULL'"
msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:3
-msgid "modules"
-msgstr ""
+#: ../vector/v.what.rast3/main.c:272 ../vector/v.label.sa/labels.c:166
+#: ../vector/v.sample/main.c:226 ../vector/v.sample/main.c:234
+#: ../vector/v.vol.rst/user1.c:172 ../vector/v.what.rast/main.c:609
+#: ../vector/v.label/main.c:325 ../vector/v.buffer/main.c:526
+#: ../vector/v.buffer/main.c:628
+#, fuzzy, c-format
+msgid "No record for category %d in table <%s>"
+msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:4
-#: ../general/g.list/main.c:68
-#, fuzzy
-msgid "search"
-msgstr "검색경로"
+#: ../vector/v.what.rast3/main.c:329
+#, fuzzy, c-format
+msgid "%d category loaded from table"
+msgid_plural "%d categories loaded from table"
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:5
-#, fuzzy
-msgid "Keyword to be searched"
-msgstr "출력할 격자지도"
+#: ../vector/v.what.rast3/main.c:332
+#, fuzzy, c-format
+msgid "%d category loaded from vector"
+msgid_plural "%d categories loaded from vector"
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:6
-msgid ""
-"Display only modules where all keywords are available (AND), default: OR"
-msgstr ""
+#: ../vector/v.what.rast3/main.c:335
+#, fuzzy, c-format
+msgid "%d category from vector missing in table"
+msgid_plural "%d categories from vector missing in table"
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:8
-msgid "Invert selection (logical NOT)"
-msgstr ""
+#: ../vector/v.what.rast3/main.c:339
+#, c-format
+msgid "%d duplicate category in vector"
+msgid_plural "%d duplicate categories in vector"
+msgstr[0] ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:10
-msgid "Search in manual pages too (can be slow)"
-msgstr ""
+#: ../vector/v.what.rast3/main.c:343
+#, fuzzy, c-format
+msgid "%d update error"
+msgid_plural "%d update errors"
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:12
-msgid "Search only for the exact keyword in module keyword list"
+#: ../vector/v.what.rast3/main.c:347
+#, fuzzy, c-format
+msgid "%d record updated."
+msgid_plural "%d records updated."
+#: ../vector/v.category/main.c:77 ../vector/v.db.connect/main.c:55
+msgid "layer"
msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:13
-msgid "Instead of full text search, search only in actual keywords"
+#: ../vector/v.category/main.c:79
+msgid "Attaches, deletes or reports vector categories to map geometry."
msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:15
-msgid "Use colorized (more readable) output to terminal"
+#: ../vector/v.category/main.c:92
+msgid "Feature ids (by default all features are processed)"
msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:17
+#: ../vector/v.category/main.c:104
#, fuzzy
-msgid "Shell script format"
+msgid "Action to be done"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:19
+#: ../vector/v.category/main.c:115
#, fuzzy
-msgid "JSON format"
+msgid "add a category to features without category in the given layer"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/db.univar_to_translate.c:1
-#, fuzzy
-msgid "Calculates univariate statistics on selected table column."
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/db.univar_to_translate.c:5
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:5
-#, fuzzy
-msgid ""
-"Name of attribute column on which to calculate statistics (must be numeric)"
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/db.univar_to_translate.c:7
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
-msgid "Extended statistics (quartiles and 90th percentile)"
+#: ../vector/v.category/main.c:116
+msgid "delete category (cat=-1 to delete all categories of given layer)"
msgstr ""
-#: ../locale/scriptstrings/db.univar_to_translate.c:8
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
-#, fuzzy
-msgid "Print stats in shell script style"
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.grow_to_translate.c:1
-msgid "Generates a raster map layer with contiguous areas grown by one cell."
+#: ../vector/v.category/main.c:117
+msgid "change layer number (e.g. layer=3,1 changes layer 3 to layer 1)"
msgstr ""
-#: ../locale/scriptstrings/r.grow_to_translate.c:5
-msgid "Radius is in map units rather than cells"
+#: ../vector/v.category/main.c:118
+msgid "add the value specified by cat option to the current category value"
msgstr ""
-#: ../locale/scriptstrings/r.grow_to_translate.c:6
-msgid "Radius of buffer in raster cells"
+#: ../vector/v.category/main.c:119
+msgid ""
+"copy values from one layer to another (e.g. layer=1,2,3 copies values from "
+"layer 1 to layer 2 and 3)"
msgstr ""
-#: ../locale/scriptstrings/r.grow_to_translate.c:8
-msgid "Value to write for input cells which are non-NULL (-1 => NULL)"
+#: ../vector/v.category/main.c:120
+msgid "print report (statistics), in shell style: layer type count min max"
msgstr ""
-#: ../locale/scriptstrings/r.grow_to_translate.c:9
-msgid "Value to write for \"grown\" cells"
+#: ../vector/v.category/main.c:121
+msgid ""
+"print category values, layers are separated by '|', more cats in the same "
+"layer are separated by '/'"
msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
+#: ../vector/v.category/main.c:122
#, fuzzy
-msgid ""
-"Calculates univariate statistics from a raster map based on a vector map and "
-"uploads statistics to new attribute columns."
+msgid "print only layer numbers"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
-msgid "Continue if upload column(s) already exist"
+#: ../vector/v.category/main.c:138
+msgid "Shell script style, currently only for report"
msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:8
-#, fuzzy
-msgid "Name of input raster map to calculate statistics from"
-msgstr "출력할 격자지도"
+#: ../vector/v.category/main.c:139
+msgid "Format: layer type count min max"
+msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
+#: ../vector/v.category/main.c:142
#, fuzzy
-msgid "Column prefix for new attribute columns"
+msgid "Do not copy attribute table(s)"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:10
-msgid "The methods to use"
+#: ../vector/v.category/main.c:160
+msgid ""
+"Database connection and attribute tables for concerned layers are not changed"
msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:11
-#, fuzzy
-msgid "Percentile to calculate"
+#: ../vector/v.category/main.c:186 ../vector/v.category/main.c:250
+#: ../vector/v.category/main.c:258 ../vector/v.kcv/main.c:96
+#: ../vector/v.kcv/main.c:186
+#, fuzzy, c-format
+msgid "Unable to open vector map <%s> at topological level %d"
msgstr "출력할 격자지도"
-#, fuzzy
+#: ../vector/v.category/main.c:208
msgid ""
-"Performs r3.mapcalc expressions on maps of sampled space time 3D raster "
-"datasets."
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:7
-msgid "r3.mapcalc expression applied to each time step of the sampled data"
+"Invalid category number (must be equal to or greater than 0). Normally "
+"category number starts at 1."
msgstr ""
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
+#: ../vector/v.category/main.c:217
+#, fuzzy, c-format
+msgid "%d error in id option"
+msgid_plural "%d errors in id option"
+#: ../vector/v.category/main.c:228
#, fuzzy
-msgid "Imports geonames.org country files into a vector points map."
+msgid "Output vector wasn't entered"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
-msgid "gazetteer"
+#: ../vector/v.category/main.c:275
+msgid "Too many layers for this operation"
msgstr ""
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:5
-#, fuzzy
-msgid "Name of uncompressed geonames file (with .txt extension)"
-msgstr "출력할 격자지도"
+#: ../vector/v.category/main.c:278 ../vector/v.category/main.c:281
+msgid "2 layers must be specified"
+msgstr ""
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
-#, fuzzy
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector "
-"map."
+#: ../vector/v.category/main.c:289
+#, fuzzy, c-format
+msgid "Categories already exist in layer %d"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:1
+#: ../vector/v.category/main.c:332 ../vector/v.select/select.c:40
+#: ../vector/v.drape/main.c:177
#, fuzzy
-msgid "Adds missing centroids to closed boundaries."
+msgid "Processing features..."
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:3
-#: ../vector/v.category/main.c:691
-msgid "centroid"
+#: ../vector/v.category/main.c:364 ../vector/v.in.ogr/main.c:1428
+#: ../vector/v.delaunay/main.c:172
+msgid "Unable to calculate area centroid"
+msgstr "면의 중심점을 계산하지 못 했습니다"
+#: ../vector/v.category/main.c:378
+#, fuzzy, c-format
+msgid "%d new centroid placed in output map"
+msgid_plural "%d new centroids placed in output map"
+#: ../vector/v.category/main.c:672
+msgid "Layer/table"
msgstr ""
-#: ../locale/scriptstrings/v.centroids_to_translate.c:4
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:4
-#: ../locale/scriptstrings/v.to.lines_to_translate.c:4
-#: ../misc/m.measure/main.c:49 ../vector/v.type/main.c:41
-#: ../vector/v.category/main.c:695 ../vector/v.buffer/main.c:223
-msgid "area"
+#: ../vector/v.category/main.c:676
+msgid "Layer"
msgstr ""
-#: ../locale/scriptstrings/v.centroids_to_translate.c:5
+#: ../vector/v.category/main.c:678
+#, c-format
+msgid "type count min max\n"
+msgstr ""
+#: ../vector/v.category/main.c:687
#, fuzzy
-msgid "Action to be taken"
+msgid "boundary"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:6
-msgid "Category number starting value"
+#: ../vector/v.category/main.c:699
+msgid "face"
msgstr ""
-#: ../locale/scriptstrings/v.centroids_to_translate.c:7
-#: ../vector/v.category/main.c:134
-msgid "Category increment"
+#: ../vector/v.category/main.c:703
+msgid "kernel"
msgstr ""
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
+#: ../vector/v.category/main.c:707
+msgid "all"
+msgstr ""
+#: ../vector/v.category/main.c:761 ../vector/v.rectify/main.c:274
#, fuzzy
-msgid "Removes existing attribute table of a vector map."
+msgid "Copying attribute table(s)..."
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
-msgid "Force removal (required for actual deletion of table)"
-msgstr ""
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
+#: ../vector/v.category/main.c:763 ../vector/v.type/main.c:155
+#: ../vector/v.build.polylines/main.c:243 ../vector/v.rectify/main.c:276
+#: ../vector/v.proj/main.c:497 ../vector/v.net/main.c:158
+#: ../vector/v.transform/main.c:284
#, fuzzy
-msgid "Table name (default: vector map name)"
+msgid "Failed to copy attribute table to output map"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:1
+#: ../vector/v.category/main.c:771
+#, fuzzy, c-format
+msgid "Categories copied from layer %d to layer %d"
+msgstr "출력할 격자지도"
+#: ../vector/v.category/main.c:775
+#, fuzzy, c-format
+msgid "%d feature modified."
+msgid_plural "%d features modified."
+#: ../vector/v.extrude/db.c:27
+#, fuzzy, c-format
+msgid "Unable to select attributes category %d"
+msgstr "출력할 격자지도"
+#: ../vector/v.extrude/main.c:72
msgid ""
-"Stores raster map values at spatial and temporal positions of vector points "
-"as vector attributes."
+"Extrudes flat vector features to 3D vector features with defined height."
msgstr ""
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:6
+#: ../vector/v.extrude/main.c:74
msgid ""
-"Name of the vector column to be created and to store sampled raster values"
+"Optionally the height can be derived from sampling of elevation raster map."
msgstr ""
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:7
-msgid ""
-"The use of a column name forces t.vect.what.rast to sample only values from "
-"the first map found in an interval. Otherwise the raster map names are used "
-"as column names"
+#: ../vector/v.extrude/main.c:78
+msgid "Trace elevation"
msgstr ""
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:11
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:7
+#: ../vector/v.extrude/main.c:79 ../vector/v.extrude/main.c:125
+#: ../vector/v.extrude/main.c:129 ../vector/v.extrude/main.c:136
+#: ../vector/v.extrude/main.c:143 ../vector/v.drape/main.c:87
+#: ../vector/v.drape/main.c:94 ../vector/v.drape/main.c:101
#, fuzzy
-msgid "Aggregate operation to be performed on the raster maps"
+msgid "Elevation"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:1
-msgid ""
-"Image fusion algorithms to sharpen multispectral with high-res panchromatic "
-"channels"
+#: ../vector/v.extrude/main.c:101 ../vector/v.transform/main.c:120
+msgid "Shifting value for z coordinates"
msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:3
-msgid "fusion"
+#: ../vector/v.extrude/main.c:105 ../vector/v.extrude/main.c:113
+#: ../vector/v.extrude/main.c:119 ../vector/v.to.3d/args.c:33
+#: ../vector/v.to.3d/args.c:41
+msgid "Height"
msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:4
-msgid "sharpen"
+#: ../vector/v.extrude/main.c:112 ../vector/v.to.3d/args.c:40
+msgid "Fixed height for 3D vector features"
msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:5
-msgid "Brovey"
-msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:6
-msgid "IHS"
-msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:7
-msgid "HIS"
-msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:9
+#: ../vector/v.extrude/main.c:118
#, fuzzy
-msgid "Name of raster map to be used for <red>"
+msgid "Name of attribute column with feature height"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:10
+#: ../vector/v.extrude/main.c:124 ../vector/v.drape/main.c:83
#, fuzzy
-msgid "Name of raster map to be used for <green>"
+msgid "Elevation raster map for height extraction"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:11
+#: ../vector/v.extrude/main.c:134 ../vector/v.drape/main.c:92
#, fuzzy
-msgid "Name of raster map to be used for <blue>"
+msgid "Scale factor sampled raster values"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:12
-#, fuzzy
-msgid "Name of raster map to be used for high resolution panchromatic channel"
-msgstr "출력할 격자지도"
+#: ../vector/v.extrude/main.c:142 ../vector/v.drape/main.c:100
+msgid "Height for sampled raster NULL values"
+msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:13
-#, fuzzy
-msgid "Method for pan sharpening"
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:14
-msgid "Serial processing rather than parallel processing"
+#: ../vector/v.extrude/main.c:151
+#, c-format
+msgid "One of '%s' or '%s' parameters must be set"
msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:15
-msgid "Rebalance blue channel for LANDSAT"
+#: ../vector/v.extrude/main.c:202
+#, c-format
+msgid ""
+"Invalid layer number (%d). Parameter '%s', '%s' or '%s' specified, assuming "
+"layer '1'."
msgstr ""
-#: ../locale/scriptstrings/d.shade_to_translate.c:1
-#: ../locale/scriptstrings/r.shade_to_translate.c:1
-#, fuzzy
-msgid "Drapes a color raster over an shaded relief or aspect map."
+#: ../vector/v.extrude/main.c:234
+#, fuzzy, c-format
+msgid "Column <%s> does not exist"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/d.shade_to_translate.c:7
-#: ../locale/scriptstrings/r.shade_to_translate.c:7
-#, fuzzy
-msgid "Name of shaded relief or aspect raster map"
-msgstr "출력할 격자지도"
+#: ../vector/v.extrude/main.c:243
+#, c-format
+msgid "Column <%s>: invalid data type"
+msgstr ""
-#: ../locale/scriptstrings/d.shade_to_translate.c:8
-#: ../locale/scriptstrings/r.shade_to_translate.c:8
+#: ../vector/v.extrude/main.c:265
#, fuzzy
-msgid "Name of raster to drape over relief raster map"
+msgid "Extruding areas..."
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/d.shade_to_translate.c:9
-#: ../locale/scriptstrings/r.shade_to_translate.c:9
-msgid "Typically, this raster is elevation or other colorful raster"
+#: ../vector/v.extrude/main.c:275 ../vector/v.out.svg/main.c:233
+#, c-format
+msgid "Skipping area %d without centroid"
msgstr ""
-#: ../locale/scriptstrings/d.shade_to_translate.c:10
-#: ../locale/scriptstrings/r.shade_to_translate.c:11
-msgid "Percent to brighten"
+#: ../vector/v.extrude/main.c:287
+#, c-format
+msgid "No category defined for area %d. Using default fixed height %f."
msgstr ""
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:1
+#: ../vector/v.extrude/main.c:293
+#, c-format
+msgid ""
+"Unable to fetch height from DB for area %d. Using default fixed height %f."
+msgstr ""
+#: ../vector/v.extrude/main.c:319
#, fuzzy
-msgid ""
-"Produces a space time vector dataset of specified contours from a space time "
-"raster dataset."
+msgid "Extruding features..."
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:3
-msgid "contour"
+#: ../vector/v.extrude/main.c:340
+#, c-format
+msgid "No category defined for feature %d. Using default fixed height %f."
msgstr ""
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:15
+#: ../vector/v.extrude/main.c:346
+#, c-format
msgid ""
-"Number of r.contour processes to run in parallel, more than 1 process works "
-"only in conjunction with flag -t"
+"Unable to fetch height from DB for line %d. Using default fixed height %f."
msgstr ""
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:16
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:13
+#: ../vector/v.extrude/main.c:364
#, fuzzy
-msgid "Register empty vector maps"
+msgid "Copying attribute table..."
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:17
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:14
-#, fuzzy
-msgid "Do not create attribute tables"
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:1
-#, fuzzy
+#: ../vector/v.extract/main.c:83
msgid ""
-"Apply temporal and spatial operations on space time vector datasets using "
-"temporal vector algebra."
-msgstr "출력할 격자지도"
+"Selects vector features from an existing vector map and creates a new vector "
+"map containing only the selected features."
+msgstr ""
-#: ../locale/scriptstrings/d.correlate_to_translate.c:1
-msgid "Prints a graph of the correlation between raster maps (in pairs)."
+#: ../vector/v.extract/main.c:88
+msgid "Dissolve common boundaries (default is no)"
msgstr ""
-#: ../locale/scriptstrings/d.correlate_to_translate.c:5
-#: ../locale/scriptstrings/d.polar_to_translate.c:3
-msgid "diagram"
+#: ../vector/v.extract/main.c:92
+msgid "Do not copy attributes (see also 'new' parameter)"
msgstr ""
-#: ../locale/scriptstrings/d.correlate_to_translate.c:6
+#: ../vector/v.extract/main.c:97 ../vector/v.edit/args.c:198
+#: ../vector/v.select/args.c:105
+msgid "Reverse selection"
+msgstr ""
+#: ../vector/v.extract/main.c:108
#, fuzzy
-msgid "correlation"
+msgid "Types to be extracted"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:1
-msgid "Saves the contents of the active display monitor to a graphics file."
+#: ../vector/v.extract/main.c:123
+msgid "Input text file with category numbers/number ranges to be extracted"
msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:5
-#: ../misc/m.nviz.image/args.c:105
-msgid "Graphics file format"
+#: ../vector/v.extract/main.c:124
+msgid "If '-' given reads from standard input"
msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:6
-#, fuzzy
-msgid "Width and height of output image"
-msgstr "출력할 격자지도"
+#: ../vector/v.extract/main.c:132
+msgid "Number of random categories matching vector objects to extract"
+msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:7
-msgid "Images"
+#: ../vector/v.extract/main.c:134
+msgid "Number must be smaller than unique cat count in layer"
msgstr ""
-#: ../locale/scriptstrings/t.list_to_translate.c:1
-#, fuzzy
-msgid "Lists space time datasets and maps registered in the temporal database."
-msgstr "출력할 격자지도"
+#: ../vector/v.extract/main.c:142
+msgid "Desired new category value (enter -1 to keep original categories)"
+msgstr ""
-#: ../locale/scriptstrings/t.list_to_translate.c:4
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:4
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:5
-#: ../general/g.list/main.c:67
-msgid "list"
-msgstr "목록"
+#: ../vector/v.extract/main.c:144
+msgid "If new >= 0, attributes is not copied"
+msgstr ""
-#: ../locale/scriptstrings/t.list_to_translate.c:6
-#, fuzzy
-msgid "Type of the space time dataset or map, default is strds"
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.list_to_translate.c:9
-#: ../locale/scriptstrings/t.list_to_translate.c:12
+#: ../vector/v.extract/main.c:161
+#, c-format
msgid ""
-"Columns number_of_maps and granularity only available for space time datasets"
+"Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only "
+"one of them."
msgstr ""
-#: ../locale/scriptstrings/t.list_to_translate.c:10
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:7
-#, fuzzy
-msgid "Sort the space time dataset by category"
+#: ../vector/v.extract/main.c:208
+#, fuzzy, c-format
+msgid "Category value in '%s' not valid"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.list_to_translate.c:13
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:9
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:9
-#, fuzzy
-msgid "Columns to be printed to stdout"
+#: ../vector/v.extract/main.c:224
+#, c-format
+msgid "Process file <%s> for category numbers..."
+msgstr ""
+#: ../vector/v.extract/main.c:229
+#, fuzzy, c-format
+msgid "Unable to open specified file <%s>"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.list_to_translate.c:16
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:7
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:8
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:13
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:13
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:14
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:8
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:8
-msgid "Field separator character between the output columns"
+#: ../vector/v.extract/main.c:240
+#, c-format
+msgid "Ignored text entry: %s"
msgstr ""
-#: ../locale/scriptstrings/t.list_to_translate.c:18
-#: ../locale/scriptstrings/t.sample_to_translate.c:11
-msgid "Print the column names as first row"
-msgstr ""
+#: ../vector/v.extract/main.c:255 ../vector/v.to.rast3/main.c:80
+#: ../vector/v.to.3d/trans3.c:51 ../vector/v.to.3d/trans2.c:49
+#: ../vector/v.db.select/main.c:171 ../vector/v.info/print.c:138
+#: ../vector/v.to.rast/vect2rast.c:55 ../vector/v.distance/main.c:459
+#: ../vector/v.distance/main.c:540 ../vector/v.db.connect/main.c:213
+#: ../vector/v.colors.out/make_colors.c:31
+#, c-format
+msgid "Database connection not defined for layer <%s>"
+msgstr "레이어 <%s>를 위한 데이타베이스 연결이 정의되지 않았습니다"
-#: ../locale/scriptstrings/t.register_to_translate.c:1
-#, fuzzy
-msgid "Registers raster, vector and raster3d maps in a space time datasets."
+#: ../vector/v.extract/main.c:259
+#, fuzzy, c-format
+msgid "Loading categories from table <%s>..."
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.register_to_translate.c:4
-#, fuzzy
-msgid "register"
+#: ../vector/v.extract/main.c:269
+#, fuzzy, c-format
+msgid "Unable select records from table <%s>"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.register_to_translate.c:8
-#: ../locale/scriptstrings/t.unregister_to_translate.c:7
-#, fuzzy
-msgid "input,maps"
-msgstr "출력할 격자지도"
+#: ../vector/v.extract/main.c:271
+#, fuzzy, c-format
+msgid "%d category loaded"
+msgid_plural "%d categories loaded"
-#: ../locale/scriptstrings/t.register_to_translate.c:10
-#: ../locale/scriptstrings/t.unregister_to_translate.c:6
-#, fuzzy
-msgid "Input file with map names, one per line"
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.register_to_translate.c:11
-msgid "Additionally the start time and the end time can be specified per line"
+#: ../vector/v.extract/main.c:286
+msgid ""
+"This map has no categories attached. Use v.category to attach categories to "
+"this vector map."
msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:13
-msgid "Valid start date and time of the first map"
+#: ../vector/v.extract/main.c:293
+msgid "Please specify random number larger than 0"
msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:14
-#: ../locale/scriptstrings/t.register_to_translate.c:17
+#: ../vector/v.extract/main.c:297
+#, c-format
msgid ""
-"Format absolute time: \"yyyy-mm-dd HH:MM:SS +HHMM\", relative time is of "
-"type integer)."
+"Random category count must be smaller than feature count. There are only %d "
+"features of type(s): %s"
msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:15
-#: ../locale/scriptstrings/t.register_to_translate.c:18
-#: ../locale/scriptstrings/t.register_to_translate.c:21
-#: ../locale/scriptstrings/t.register_to_translate.c:24
-#: ../locale/scriptstrings/t.register_to_translate.c:28
-msgid "Time & Date"
+#: ../vector/v.extract/main.c:320
+#, c-format
+msgid ""
+"Random category count is larger or equal to uniq <%s> feature category count "
+"%d"
msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:16
-msgid "Valid end date and time of all map"
-msgstr ""
+#: ../vector/v.extract/main.c:354
+msgid "Extracting features..."
+msgstr "피쳐를 추출하고 있습니다..."
-#: ../locale/scriptstrings/t.register_to_translate.c:19
-msgid "Time stamp unit"
+#: ../vector/v.extract/main.c:378
+msgid "Removing duplicate centroids..."
msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:20
-msgid "Unit must be set in case of relative time stamps"
+#: ../vector/v.extract/extract.c:171
+#, c-format
+msgid "No category found for area %d. Skipping."
msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:22
-msgid "Time increment, works only in conjunction with start option"
+#: ../vector/v.extract/extract.c:175
+#, c-format
+msgid "More categories (%d) found for area %d. Using first found category %d"
msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:23
+#: ../vector/v.extract/extract.c:228
+#, fuzzy
msgid ""
-"Time increment between maps for valid time interval creation (format "
-"absolute: NNN seconds, minutes, hours, days, weeks, months, years; format "
-"relative is integer: 5)"
-msgstr ""
+"Topology level required for extracting areas for OGR layers. Areas will be "
+"not processed."
+msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.register_to_translate.c:25
-#, fuzzy
-msgid "Field separator character of the input file"
+#: ../vector/v.extract/copy_tab.c:90
+#, fuzzy, c-format
+msgid "Writing attributes for layer %d"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.register_to_translate.c:27
+#: ../vector/v.extract/copy_tab.c:95
+#, fuzzy, c-format
+msgid "No attribute table for layer %d"
+msgstr "출력할 격자지도"
+#: ../vector/v.extract/copy_tab.c:108 ../vector/v.to.points/main.c:155
+#: ../vector/v.generalize/misc.c:184
+#, fuzzy, c-format
+msgid "Unable to copy table <%s>"
+msgstr "출력할 격자지도"
+#: ../vector/v.extract/copy_tab.c:117 ../vector/v.vect.stats/main.c:296
+#: ../vector/v.vect.stats/main.c:378
+#, fuzzy, c-format
+msgid "Unable to open database <%s> with driver <%s>"
+msgstr "출력할 격자지도"
+#: ../vector/v.lidar.correction/main.c:71
msgid ""
-"Create an interval (start and end time) in case an increment and the start "
-"time are provided"
+"Corrects the v.lidar.growing output. It is the last of the three algorithms "
+"for LIDAR filtering."
msgstr ""
-#: ../locale/scriptstrings/v.report_to_translate.c:1
-msgid "Reports geometry statistics for vector maps."
+#: ../vector/v.lidar.correction/main.c:75
+#: ../vector/v.lidar.edgedetection/main.c:80
+#: ../vector/v.surf.bspline/main.c:105 ../vector/v.outlier/main.c:79
+msgid "Estimate point density and distance"
msgstr ""
-#: ../locale/scriptstrings/v.report_to_translate.c:6
-#, fuzzy
-msgid "Value to calculate"
-msgstr "출력할 격자지도"
+#: ../vector/v.lidar.correction/main.c:77
+#: ../vector/v.lidar.edgedetection/main.c:82
+#: ../vector/v.surf.bspline/main.c:107 ../vector/v.outlier/main.c:81
+msgid ""
+"Estimate point density and distance for the input vector points within the "
+"current region extends and quit"
+msgstr ""
-#: ../locale/scriptstrings/v.report_to_translate.c:7
-msgid "Sort the result"
+#: ../vector/v.lidar.correction/main.c:81
+msgid "Input observation vector map name (v.lidar.growing output)"
msgstr ""
-#: ../locale/scriptstrings/v.report_to_translate.c:8
-msgid "asc;Sort in ascending order;desc;Sort in descending order"
+#: ../vector/v.lidar.correction/main.c:84
+msgid "Output classified vector map name"
msgstr ""
-#: ../locale/scriptstrings/t.rename_to_translate.c:1
+#: ../vector/v.lidar.correction/main.c:93
#, fuzzy
-msgid "Renames a space time dataset"
+msgid "Only 'terrain' points output vector map"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rename_to_translate.c:4
-#: ../general/g.rename/main.c:47
-msgid "rename"
-msgstr "이름변경"
+#: ../vector/v.lidar.correction/main.c:101
+#: ../vector/v.lidar.edgedetection/main.c:94
+#: ../vector/v.surf.bspline/main.c:149 ../vector/v.outlier/main.c:103
+msgid "Length of each spline step in the east-west direction"
+msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:1
-msgid "Maintains GRASS Addons extensions in local GRASS installation."
+#: ../vector/v.lidar.correction/main.c:110
+#: ../vector/v.lidar.edgedetection/main.c:103
+#: ../vector/v.surf.bspline/main.c:158 ../vector/v.outlier/main.c:112
+msgid "Length of each spline step in the north-south direction"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:2
-msgid ""
-"Downloads and installs extensions from GRASS Addons repository or other "
-"source into the local GRASS installation or removes installed extensions."
+#: ../vector/v.lidar.correction/main.c:118
+msgid "Regularization weight in reclassification evaluation"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:6
-msgid "addons"
+#: ../vector/v.lidar.correction/main.c:126
+msgid "High threshold for object to terrain reclassification"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:7
-msgid "download"
+#: ../vector/v.lidar.correction/main.c:134
+msgid "Low threshold for terrain to object reclassification"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:8
+#: ../vector/v.lidar.correction/main.c:150
+#: ../vector/v.lidar.edgedetection/main.c:169 ../vector/v.outlier/main.c:146
#, fuzzy
-msgid "Name of extension to install or remove"
+msgid "Unable to read name of database"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/g.extension_to_translate.c:9
-msgid "Name of toolbox (set of extensions) when -t flag is given"
-msgstr ""
+#: ../vector/v.lidar.correction/main.c:153
+#: ../vector/v.lidar.edgedetection/main.c:172 ../vector/v.outlier/main.c:149
+#, fuzzy
+msgid "Unable to read name of driver"
+msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/g.extension_to_translate.c:11
-msgid ""
-"URL or directory to get the extension from (supported only on Linux and Mac)"
+#: ../vector/v.lidar.correction/main.c:167
+#: ../vector/v.lidar.correction/main.c:229 ../vector/v.lidar.growing/main.c:163
+#: ../vector/v.lidar.edgedetection/main.c:189
+#: ../vector/v.lidar.edgedetection/main.c:201
+#: ../vector/v.lidar.edgedetection/main.c:251
+#: ../vector/v.surf.bspline/main.c:247 ../vector/v.surf.bspline/main.c:406
+#: ../vector/v.outlier/main.c:188 ../vector/v.outlier/main.c:256
+#, c-format
+msgid "No database connection for driver <%s> is defined. Run db.connect."
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:12
-msgid ""
-"The official repository is used by default. User can specify a ZIP file, "
-"directory or a repository on common hosting services. If not identified, "
-"Subversion repository is assumed. See manual for all options."
+#: ../vector/v.lidar.correction/main.c:172
+#: ../vector/v.lidar.edgedetection/main.c:192
+#: ../vector/v.lidar.edgedetection/main.c:204
+#: ../vector/v.surf.bspline/main.c:252 ../vector/v.outlier/main.c:193
+msgid "Old auxiliary table could not be dropped"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:13
-msgid "Prefix where to install extension (ignored when flag -s is given)"
-msgstr ""
+#: ../vector/v.lidar.correction/main.c:190
+#: ../vector/v.lidar.edgedetection/main.c:223 ../vector/v.outlier/main.c:205
+#, fuzzy, c-format
+msgid "Input vector map <%s> is not 3D!"
+msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/g.extension_to_translate.c:14
-msgid "Set the proxy with: \"http=<value>,ftp=<value>\""
+#: ../vector/v.lidar.correction/main.c:200
+#: ../vector/v.lidar.edgedetection/main.c:233 ../vector/v.outlier/main.c:215
+#, fuzzy
+msgid "No points in current region!"
+msgstr "출력할 격자지도"
+#: ../vector/v.lidar.correction/main.c:273
+#, c-format
+msgid "adjusted EW spline %d"
+msgid_plural "adjusted EW splines %d"
+msgstr[0] ""
+#: ../vector/v.lidar.correction/main.c:276
+#, c-format
+msgid "adjusted NS spline %d"
+msgid_plural "adjusted NS splines %d"
+msgstr[0] ""
+#: ../vector/v.lidar.correction/main.c:324
+#, c-format
+msgid "nsply = %d"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:15
-msgid "List available extensions in the official GRASS GIS Addons repository"
+#: ../vector/v.lidar.correction/main.c:357
+#, c-format
+msgid "nsplx = %d"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:17
-msgid ""
-"List available extensions in the official GRASS GIS Addons repository "
-"including module description"
+#: ../vector/v.lidar.correction/main.c:360
+msgid "read vector region map"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:19
-msgid ""
-"List available extensions in the official GRASS GIS Addons repository (shell "
-"script style)"
+#: ../vector/v.lidar.correction/main.c:365
+#, c-format
+msgid "npoints = %d, nterrain = %d"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:21
-msgid "List locally installed extensions"
+#: ../vector/v.lidar.correction/main.c:371
+msgid "Mean calculation"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:23
-msgid "Install system-wide (may need system administrator rights)"
+#: ../vector/v.lidar.correction/main.c:385
+msgid "Only TERRAIN points"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:24
-#: ../locale/scriptstrings/g.extension_to_translate.c:26
-#: ../locale/scriptstrings/g.extension_to_translate.c:28
-msgid "Install"
+#: ../vector/v.lidar.correction/main.c:415
+msgid "Correction and creation of terrain vector"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:25
-msgid "Download source code and exit"
+#: ../vector/v.lidar.correction/main.c:428
+#: ../vector/v.lidar.edgedetection/main.c:457
+msgid "No data within this subregion. Consider changing the spline step."
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:27
-msgid "Do not install new extension, just compile it"
+#: ../vector/v.lidar.correction/main.c:437
+#: ../vector/v.lidar.edgedetection/main.c:465
+#, c-format
+msgid "Dropping <%s>"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:29
-msgid "Force removal when uninstalling extension (operation=remove)"
+#: ../vector/v.lidar.correction/main.c:439
+#: ../vector/v.lidar.edgedetection/main.c:467
+#: ../vector/v.surf.bspline/main.c:942 ../vector/v.outlier/main.c:458
+msgid "Auxiliary table could not be dropped"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:31
-msgid "Operate on toolboxes instead of single modules (experimental)"
+#: ../vector/v.lidar.correction/correction.c:93
+#: ../vector/v.lidar.correction/correction.c:127
+#: ../vector/v.lidar.correction/correction.c:151
+#: ../vector/v.lidar.correction/correction.c:163
+#: ../vector/v.lidar.correction/correction.c:187
+#: ../vector/v.outlier/outlier.c:86 ../vector/v.outlier/outlier.c:123
+#: ../vector/v.outlier/outlier.c:148 ../vector/v.outlier/outlier.c:161
+#: ../vector/v.outlier/outlier.c:185
+msgid "Impossible to read the database"
msgstr ""
-#: ../locale/scriptstrings/t.snap_to_translate.c:1
-#, fuzzy
-msgid "Snaps temporally the maps of a space time dataset."
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.snap_to_translate.c:4 ../vector/v.clean/main.c:54
-msgid "snapping"
+#: ../vector/v.lidar.correction/correction.c:97
+#: ../vector/v.lidar.correction/correction.c:155
+#: ../vector/v.outlier/outlier.c:90 ../vector/v.outlier/outlier.c:152
+msgid "Impossible to update the database"
msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:1
-msgid "Blends color components of two raster maps by a given ratio."
+#: ../vector/v.lidar.correction/correction.c:107
+#: ../vector/v.lidar.correction/correction.c:115
+#: ../vector/v.lidar.correction/correction.c:210
+#: ../vector/v.outlier/outlier.c:101 ../vector/v.outlier/outlier.c:110
+#: ../vector/v.outlier/outlier.c:207
+msgid "Impossible to write in the database"
msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:4
+#: ../vector/v.net.components/main.c:74
#, fuzzy
-msgid "Name of first raster map for blending"
+msgid "components"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.blend_to_translate.c:5
-#, fuzzy
-msgid "Name of second raster map for blending"
-msgstr "출력할 격자지도"
+#: ../vector/v.net.components/main.c:76
+msgid "Computes strongly and weakly connected components in the network."
+msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:6
+#: ../vector/v.net.components/main.c:124
#, fuzzy
-msgid "Basename for red, green and blue output raster maps"
+msgid "Weakly connected components"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.blend_to_translate.c:7
-#, fuzzy
-msgid "Percentage weight of first map for color blending"
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.blend_to_translate.c:8
-msgid "Combine resulting R,G,B layers into single output map"
+#: ../vector/v.net.components/main.c:125
+msgid "Strongly connected components"
msgstr ""
-#: ../locale/scriptstrings/r.rgb_to_translate.c:1
+#: ../vector/v.net.components/main.c:127
#, fuzzy
-msgid "Splits a raster map into red, green and blue maps."
+msgid "Type of components"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.rgb_to_translate.c:3
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:3
-msgid "RGB"
-msgstr ""
-#: ../locale/scriptstrings/r.rgb_to_translate.c:4
+#: ../vector/v.net.components/main.c:131 ../vector/v.net.centrality/main.c:192
#, fuzzy
-msgid "separate"
+msgid "Add points on nodes"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.rgb_to_translate.c:5
-msgid "split"
+#: ../vector/v.net.components/main.c:194 ../vector/v.net.distance/main.c:295
+#: ../vector/v.net.flow/main.c:185 ../vector/v.net.timetable/main.c:107
+#: ../vector/v.sample/main.c:193 ../vector/v.net.allpairs/main.c:183
+#: ../vector/v.kcv/main.c:175 ../vector/v.net.path/path.c:113
+#: ../vector/v.net.centrality/main.c:270 ../vector/v.db.connect/main.c:336
+msgid "Cannot create index"
msgstr ""
-#: ../locale/scriptstrings/r.rgb_to_translate.c:6
-#, fuzzy
-msgid "Red channel raster map name"
-msgstr "출력할 격자지도"
+#: ../vector/v.net.components/main.c:198 ../vector/v.net.distance/main.c:299
+#: ../vector/v.net.flow/main.c:189 ../vector/v.net.timetable/main.c:112
+#: ../vector/v.net.allpairs/main.c:187 ../vector/v.net.path/path.c:117
+#: ../vector/v.net.centrality/main.c:274
+#, c-format
+msgid "Cannot grant privileges on table <%s>"
+msgstr ""
-#: ../locale/scriptstrings/r.rgb_to_translate.c:7
+#: ../vector/v.net.components/main.c:203
#, fuzzy
-msgid "Green channel raster map name"
+msgid "Computing weakly connected components..."
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.rgb_to_translate.c:8
+#: ../vector/v.net.components/main.c:207
#, fuzzy
-msgid "Blue channel raster map name"
+msgid "Computing strongly connected components..."
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/db.droptable_to_translate.c:1
-#, fuzzy
-msgid "Drops an attribute table."
+#: ../vector/v.net.components/main.c:279
+#, fuzzy, c-format
+msgid "Found %d components."
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/db.droptable_to_translate.c:4
-#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:4
-#: ../general/g.remove/main.c:135
-msgid "Force removal (required for actual deletion of files)"
-msgstr "실제로 파일을 지웁니다"
+#: ../vector/v.net.distance/main.c:69
+msgid ""
+"Computes shortest distance via the network between the given sets of "
+"features."
+msgstr ""
-#: ../locale/scriptstrings/db.droptable_to_translate.c:5
-#, fuzzy
-msgid "Name of database driver"
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/db.droptable_to_translate.c:6
-msgid "If not given then default driver is used"
+#: ../vector/v.net.distance/main.c:72
+msgid ""
+"Finds the shortest paths from each 'from' point to the nearest 'to' feature "
+"and various information about this relation are uploaded to the attribute "
+"table."
msgstr ""
-#: ../locale/scriptstrings/db.droptable_to_translate.c:8
+#: ../vector/v.net.distance/main.c:100
#, fuzzy
-msgid "Name of database"
+msgid "From layer number or name"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/db.droptable_to_translate.c:9
-#, fuzzy
-msgid "If not given then default database is used"
-msgstr "출력할 격자지도"
+#: ../vector/v.net.distance/main.c:101 ../vector/v.net.distance/main.c:106
+#: ../vector/v.net.distance/main.c:112 ../vector/v.distance/main.c:100
+#: ../vector/v.distance/main.c:105 ../vector/v.distance/main.c:112
+#: ../vector/v.distance/main.c:156 ../vector/v.distance/main.c:192
+msgid "From"
+msgstr ""
-#: ../locale/scriptstrings/db.droptable_to_translate.c:11
+#: ../vector/v.net.distance/main.c:105
#, fuzzy
-msgid "Name of table to drop"
+msgid "From category values"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:1
-#, fuzzy
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:5
-msgid "Old and new name of the column (old,new)"
+#: ../vector/v.net.distance/main.c:111
+msgid "From WHERE conditions of SQL statement without 'where' keyword"
msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:1
-msgid "Draws polar diagram of angle map such as aspect or flow directions"
-msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:4
+#: ../vector/v.net.distance/main.c:116
#, fuzzy
-msgid "Name of raster angle map"
+msgid "To layer number or name"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/d.polar_to_translate.c:5
-msgid "Pixel value to be interpreted as undefined (different from NULL)"
+#: ../vector/v.net.distance/main.c:117 ../vector/v.net.distance/main.c:124
+#: ../vector/v.net.distance/main.c:129 ../vector/v.net.distance/main.c:135
+#: ../vector/v.distance/main.c:117 ../vector/v.distance/main.c:122
+#: ../vector/v.distance/main.c:129 ../vector/v.distance/main.c:198
+msgid "To"
msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:6
+#: ../vector/v.net.distance/main.c:123
#, fuzzy
-msgid "Name for optional EPS output file"
+msgid "To feature type"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/d.polar_to_translate.c:7
-msgid "Plot using Xgraph"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:1
+#: ../vector/v.net.distance/main.c:128
#, fuzzy
-msgid ""
-"Calculates univariate statistics from the non-null cells for each registered "
-"raster map of a space time raster dataset."
+msgid "To category values"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:10
-msgid ""
-"Ignore the current region settings and use the raster map regions for univar "
-"statistical calculation"
+#: ../vector/v.net.distance/main.c:134
+msgid "To WHERE conditions of SQL statement without 'where' keyword"
msgstr ""
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:11
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:15
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:15
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:16
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:11
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:11
-#, fuzzy
-msgid "Suppress printing of column names"
-msgstr "출력할 래스터맵"
+#: ../vector/v.net.distance/main.c:165 ../vector/v.net.path/main.c:136
+msgid "Write output as original input segments, not each path as one line."
+msgstr ""
-#: ../locale/scriptstrings/t.unregister_to_translate.c:1
-msgid ""
-"Unregisters raster, vector and raster3d maps from the temporal database or a "
-"specific space time dataset."
+#: ../vector/v.net.distance/main.c:169
+msgid "Write each output path as one line, not as original input segments."
msgstr ""
-#: ../locale/scriptstrings/t.unregister_to_translate.c:4
-msgid "unregister"
+#: ../vector/v.net.distance/main.c:244
+#, c-format
+msgid "No 'from' features selected. Please check options '%s', '%s', '%s'."
msgstr ""
-#: ../locale/scriptstrings/t.unregister_to_translate.c:8
-#, fuzzy
-msgid "Name(s) of existing raster, vector or raster3d map(s) to unregister"
-msgstr "출력할 격자지도"
+#: ../vector/v.net.distance/main.c:251
+#, c-format
+msgid "No 'to' features selected. Please check options '%s', '%s', '%s'."
+msgstr ""
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:1
+#: ../vector/v.net.distance/main.c:260
#, fuzzy
-msgid "Exports space time raster dataset."
+msgid "No 'to' features"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:6
+#: ../vector/v.net.distance/main.c:268
#, fuzzy
-msgid "Name of a space time raster dataset archive"
+msgid "Distances to 'to' features ..."
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:9
+#: ../vector/v.net.distance/main.c:307
#, fuzzy
-msgid "The export format of a single raster map"
+msgid "Tracing paths from 'from' features ..."
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:10
-msgid ""
-"Supported are GTiff, AAIGrid via r.out.gdal and the GRASS package format of "
-"r.pack"
+#: ../vector/v.net.distance/main.c:423
+#, c-format
+msgid "%d 'from' feature was not reachable"
+msgid_plural "%d 'from' features were not reachable"
+msgstr[0] ""
+#: ../vector/v.out.pov/main.c:49
+msgid "Converts GRASS x,y,z points to POV-Ray x,z,y format."
msgstr ""
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:12
+#: ../vector/v.out.pov/main.c:60
#, fuzzy
-msgid "Supported only for GTiff"
+msgid "Name for output POV file"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:1
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number "
-"or attribute."
+#: ../vector/v.out.pov/main.c:67
+msgid "Radius of sphere for points and tube for lines"
msgstr ""
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:3
-#: ../vector/v.extract/main.c:80
-msgid "dissolve"
+#: ../vector/v.out.pov/main.c:68
+msgid "May be also variable, e.g. grass_r."
msgstr ""
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
+#: ../vector/v.out.pov/main.c:74
#, fuzzy
-msgid "Layer number or name."
+msgid "Modifier for z coordinates"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:7
-#, fuzzy
-msgid "Name of attribute column used to dissolve common boundaries"
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.plane_to_translate.c:1
-#, fuzzy
+#: ../vector/v.out.pov/main.c:75
msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.plane_to_translate.c:4
-msgid "Dip of plane in degrees"
+"This string is appended to each z coordinate. Examples: '*10', '+1000', "
+"'*10+100', '*exaggeration'"
msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:5
-msgid "Azimuth of the plane in degrees"
+#: ../vector/v.out.pov/main.c:82
+msgid "Object modifier (OBJECT_MODIFIER in POV-Ray documentation)"
msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:6
-msgid "Easting coordinate of a point on the plane"
+#: ../vector/v.out.pov/main.c:83
+msgid "Example: \"pigment { color red 0 green 1 blue 0 }\""
msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:7
-msgid "Northing coordinate of a point on the plane"
-msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:8
-msgid "Elevation coordinate of a point on the plane"
-msgstr ""
+#: ../vector/v.out.pov/main.c:175 ../vector/v.select/select.c:167
#, fuzzy
-msgid "Converts a space time raster dataset into a space time vector dataset"
+msgid "Processing areas..."
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:12
+#: ../vector/v.out.pov/main.c:218
+#, c-format
+msgid "%d feature written."
+msgid_plural "%d features written."
+msgstr[0] "%d개의 피쳐를 썼습니다."
+#: ../vector/v.surf.idw/main.c:92
msgid ""
-"Number of r.to.vect processes to run in parallel, more than 1 process works "
+"Provides surface interpolation from vector point data by Inverse Distance "
+"Squared Weighting."
msgstr ""
-#: ../locale/scriptstrings/t.remove_to_translate.c:1
+#: ../vector/v.surf.idw/main.c:101
#, fuzzy
-msgid "Removes space time datasets from temporal database."
+msgid "Name of attribute column with values to interpolate"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.remove_to_translate.c:4
-#: ../general/g.remove/main.c:71
-msgid "remove"
-msgstr "삭제"
+#: ../vector/v.surf.idw/main.c:104
+msgid "Values"
+msgstr ""
-#: ../locale/scriptstrings/t.remove_to_translate.c:7
-msgid "Type of the space time dataset, default is strds"
+#: ../vector/v.surf.idw/main.c:121
+msgid "Power parameter"
msgstr ""
-#: ../locale/scriptstrings/t.remove_to_translate.c:8
-#: ../locale/scriptstrings/t.merge_to_translate.c:6
-msgid "inputs"
+#: ../vector/v.surf.idw/main.c:123
+msgid "Greater values assign greater influence to closer points"
msgstr ""
-#: ../locale/scriptstrings/t.remove_to_translate.c:10
-#, fuzzy
-msgid "Input file with dataset names, one per line"
-msgstr "출력할 격자지도"
+#: ../vector/v.surf.idw/main.c:128
+msgid "Don't index points by raster cell"
+msgstr ""
-#: ../locale/scriptstrings/t.remove_to_translate.c:12
-#, fuzzy
+#: ../vector/v.surf.idw/main.c:129
msgid ""
-"Remove all registered maps from the temporal and also from the spatial "
-"database"
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.remove_to_translate.c:13
-msgid "Force recursive removing"
+"Slower but uses less memory and includes points from outside region in the "
+"interpolation"
msgstr ""
-#: ../locale/scriptstrings/t.topology_to_translate.c:1
-#, fuzzy
-msgid "Lists temporal topology of a space time dataset."
+#: ../vector/v.surf.idw/main.c:139
+#, fuzzy, c-format
+msgid "Illegal number (%s) of interpolation points"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.topology_to_translate.c:7
+#: ../vector/v.surf.idw/main.c:176 ../vector/v.neighbors/main.c:175
+#: ../vector/v.normal/main.c:195
#, fuzzy
-msgid "Print temporal topological relationships and exit"
+msgid "No points found"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.topology_to_translate.c:8
-#, fuzzy
-msgid "Print spatio-temporal topological relationships and exit"
+#. GTC First argument is map name, second - message about number of rows, third - columns.
+#: ../vector/v.surf.idw/main.c:263
+#, fuzzy, c-format
+msgid "Interpolating raster map <%s> (%s, %s)..."
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:2
-msgid "This is the low-memory alternative to the classic r.buffer module."
-msgstr ""
+#: ../vector/v.surf.idw/read_sites.c:37
+#, fuzzy, c-format
+msgid "Input vector map <%s> is 2D - using categories to interpolate"
+msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
-#, fuzzy
-msgid "Edits cell values in a raster map."
+#: ../vector/v.surf.idw/read_sites.c:40
+#, fuzzy, c-format
+msgid "Input vector map <%s> is 3D - using z-coordinates to interpolate"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:3
-#: ../vector/v.type/main.c:40 ../vector/v.edit/main.c:56
-msgid "editing"
+#: ../vector/v.surf.idw/read_sites.c:50 ../vector/v.sample/main.c:133
+#: ../vector/v.reclass/main.c:128
+#, c-format
+msgid "Database connection not defined for layer %s"
msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:6
-msgid "Width of display canvas"
+#: ../vector/v.surf.idw/read_sites.c:65 ../vector/v.to.rast3/main.c:99
+#: ../vector/v.sample/main.c:240 ../vector/v.class/main.c:129
+#: ../vector/v.surf.bspline/main.c:389 ../vector/v.surf.bspline/crosscorr.c:133
+#: ../vector/v.what.rast/main.c:183 ../vector/v.buffer/main.c:434
+msgid "Column type not supported"
msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:7
-msgid "Height of display canvas"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
-msgid "Minimum size of each cell"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:9
+#: ../vector/v.surf.idw/read_sites.c:68 ../vector/v.to.rast3/main.c:95
+#: ../vector/v.sample/main.c:152 ../vector/v.class/main.c:132
+#: ../vector/v.univar/main.c:366 ../vector/v.out.lidar/main.c:132
+#: ../vector/v.out.lidar/main.c:167 ../vector/v.vol.rst/user1.c:112
+#: ../vector/v.surf.bspline/main.c:392 ../vector/v.normal/main.c:134
+#: ../ps/ps.map/catval.c:66 ../ps/ps.map/catval.c:131 ../ps/ps.map/catval.c:198
#, fuzzy
-msgid "Maximum number of rows to load"
+msgid "Unable to select data from table"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:10
-#, fuzzy
-msgid "Maximum number of columns to load"
-msgstr "출력할 격자지도"
+#: ../vector/v.surf.idw/read_sites.c:70
+#, fuzzy, c-format
+msgid "One record selected from table"
+msgid_plural "%d records selected from table"
-#: ../locale/scriptstrings/d.what.vect_to_translate.c:1
-msgid ""
-"Allows the user to interactively query vector map layers at user-selected "
-"locations."
+#: ../vector/v.surf.idw/read_sites.c:107
+#: ../vector/v.surf.bspline/crosscorr.c:220
+#, c-format
+msgid "No record for point (cat = %d)"
msgstr ""
-#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:1
+#: ../vector/v.surf.idw/read_sites.c:123
+#, fuzzy, c-format
+msgid "%ld point loaded"
+msgid_plural "%ld points loaded"
+#: ../vector/v.timestamp/main.c:39
#, fuzzy
-msgid "Drops a column from selected attribute table."
+msgid "Modifies a timestamp for a vector map."
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
+#: ../vector/v.timestamp/main.c:40
#, fuzzy
-msgid "Fills no-data areas in raster maps using spline interpolation."
+msgid "Print/add/remove a timestamp for a vector map."
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:6
-msgid "Spline tension parameter"
+#: ../vector/v.timestamp/main.c:66
+#, fuzzy, c-format
+msgid "Vector map <%s> not found %s"
+msgstr "출력할 격자지도"
+#: ../vector/v.segment/main.c:62 ../vector/v.split/main.c:57
+#: ../vector/v.edit/main.c:58 ../vector/v.build.polylines/main.c:115
+#: ../vector/v.to.points/main.c:57
+msgid "node"
msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:7
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:9
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:11
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:13
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:15
+#: ../vector/v.segment/main.c:64 ../vector/v.split/main.c:58
#, fuzzy
-msgid "RST options"
+msgid "segment"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:8
-msgid "Spline smoothing parameter"
+#: ../vector/v.segment/main.c:65 ../vector/v.split/main.c:59
+#: ../vector/v.edit/main.c:60 ../vector/v.build.polylines/main.c:116
+#: ../vector/v.to.points/main.c:58
+msgid "vertex"
msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:10
-msgid "Width of hole edge used for interpolation (in cells)"
-msgstr ""
+#: ../vector/v.segment/main.c:67
+msgid "Creates points/segments from input vector lines and positions."
+msgstr "입력 벡터선과 위치를 이용해서 점 또는 선조각을 생성합니다."
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:12
-#: ../vector/v.surf.rst/main.c:292 ../vector/v.vol.rst/main.c:319
-msgid "Minimum number of points for approximation in a segment (>segmax)"
-msgstr ""
+#: ../vector/v.segment/main.c:70
+msgid "Name of input vector lines map"
+msgstr "입력 벡터선 지도의 이름"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:14
-#: ../vector/v.surf.rst/main.c:283 ../vector/v.vol.rst/main.c:310
-msgid "Maximum number of points in a segment"
-msgstr ""
+#: ../vector/v.segment/main.c:79
+msgid "Name of file containing segment rules"
+msgstr "단편화 규칙을 설명하는 파일의 이름"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:17
-#, fuzzy
-msgid "Used in bilinear and bicubic spline interpolation"
+#: ../vector/v.segment/main.c:146 ../vector/v.segment/main.c:190
+#, fuzzy, c-format
+msgid "Unable to read input: %s"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:18
-#, fuzzy
-msgid "Spline options"
+#: ../vector/v.segment/main.c:157 ../vector/v.segment/main.c:201
+#, fuzzy, c-format
+msgid "Unable to find line of cat %d"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
-msgid "Exports attribute tables into various formats."
+#: ../vector/v.segment/main.c:172
+#, c-format
+msgid ""
+"Unable to get point on line: cat = %d offset = %f (line length = %.15g)\n"
+"%s"
msgstr ""
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
-msgid "GRASS table name"
+#: ../vector/v.segment/main.c:226
+msgid "End of segment > line length -> cut"
msgstr ""
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
-msgid "Output table file name or DB connection string"
+#: ../vector/v.segment/main.c:232
+#, c-format
+msgid ""
+"Unable to make line segment: cat = %d : %f - %f (line length = %.15g)\n"
+"%s"
msgstr ""
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:7
-#, fuzzy
-msgid "Table format"
-msgstr "출력할 격자지도"
+#: ../vector/v.segment/main.c:254 ../vector/v.lrs/v.lrs.segment/main.c:336
+#, c-format
+msgid "Incorrect segment type: %s"
+msgstr ""
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:8
-#, fuzzy
-msgid "Name for output table (default: input name)"
-msgstr "출력할 격자지도"
+#: ../vector/v.segment/main.c:261
+#, c-format
+msgid "%d point read from input"
+msgid_plural "%d points read from input"
+msgstr[0] "입력으로부터 %d개의 점을 읽었습니다"
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
-#, fuzzy
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
-msgstr "출력할 격자지도"
+#. GTC Number of lost points
+#. GTC Number of lost lines
+#: ../vector/v.segment/main.c:265 ../vector/v.segment/main.c:276
+#: ../vector/v.lrs/v.lrs.segment/main.c:359
+#: ../vector/v.lrs/v.lrs.segment/main.c:371
+#, c-format
+msgid "%d lost"
+msgid_plural "%d lost"
+msgstr[0] "%d개를 잃어 버렸습니다"
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
-#, fuzzy
-msgid "Layer number where to add column(s)"
-msgstr "출력할 격자지도"
+#. GTC %s is replaced with message indicating number of lost points.
+#: ../vector/v.segment/main.c:267
+#, c-format
+msgid "%d point written to output map (%s)"
+msgid_plural "%d points written to output map (%s)"
+msgstr[0] "%d개의 점을 출력지도로 썼습니다 (%s)"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:1
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
-msgstr ""
+#: ../vector/v.segment/main.c:272
+#, c-format
+msgid "%d line read from input"
+msgid_plural "%d lines read from input"
+msgstr[0] "입력으로부터 %d개의 선을 읽었습니다"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:4
-msgid "Produces shell script output"
-msgstr ""
+#. GTC %s is replaced with message indicating number of lost lines.
+#: ../vector/v.segment/main.c:278
+#, c-format
+msgid "%d line written to output map (%s)"
+msgid_plural "%d lines written to output map (%s)"
+msgstr[0] "%d개의 선을 출력지도로 썼습니다 (%s)"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:5
-msgid "Produces web map server query string output"
-msgstr ""
+#: ../vector/v.in.pdal/filters.c:46
+#, fuzzy, c-format
+msgid "4 values required for '%s' option"
+msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:6
-msgid ""
-"Name of region to use instead of current region for bounds and resolution"
-msgstr ""
+#: ../vector/v.in.pdal/filters.c:68 ../vector/v.decimate/main.c:292
+#: ../vector/v.in.lidar/main.c:433
+#, fuzzy, c-format
+msgid "Invalid zrange <%s>"
+msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:7
+#: ../vector/v.in.pdal/projection.c:125
#, fuzzy
-msgid "Source projection"
+msgid "Overriding projection check"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:8
-#: ../locale/scriptstrings/r.tileset_to_translate.c:10
-msgid "Conversion factor from units to meters in source projection"
+#: ../vector/v.out.vtk/head.c:27
+msgid "writeVTKHeader: Writing VTK-Header"
msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:9
-msgid "Destination projection, defaults to this location's projection"
-msgstr ""
+#: ../vector/v.out.vtk/main.c:51
+#, fuzzy
+msgid "Converts a vector map to VTK ASCII output."
+msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:11
+#: ../vector/v.out.vtk/main.c:59
#, fuzzy
-msgid "Maximum number of columns for a tile in the source projection"
+msgid "Name for output VTK file"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:12
-msgid "Maximum number of rows for a tile in the source projection"
+#: ../vector/v.out.vtk/main.c:89
+msgid "Export numeric attribute table fields as VTK scalar variables"
msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:13
-msgid "Number of cells tiles should overlap in each direction"
+#: ../vector/v.out.vtk/main.c:153 ../vector/v.out.ascii/args.c:109
+msgid "Failed to interpret 'dp' parameter as an integer"
msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:14
-msgid "Output field separator"
+#: ../vector/v.out.vtk/main.c:155
+msgid "dp has to be from 0 to 8"
msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:1
-msgid "Uploads vector values at positions of vector points to the table."
+#: ../vector/v.out.vtk/main.c:164
+msgid "Failed to interpret 'layer' parameter as an integer"
msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:8
-#: ../vector/v.what.rast3/main.c:76 ../vector/v.what.rast/main.c:83
-#, fuzzy
-msgid "Name of vector points map for which to edit attributes"
-msgstr "출력할 격자지도"
+#: ../vector/v.out.vtk/main.c:183
+#, c-format
+msgid ""
+"Export of areas requires topology. Please adjust '%s' option or rebuild "
+"topology."
+msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:9
-#: ../locale/scriptstrings/v.db.join_to_translate.c:6
-msgid "layer,column"
+#: ../vector/v.out.vtk/writeVTK.c:196
+msgid ""
+"No coordinates to generate the output! Maybe an empty vector type chosen?"
msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:10
-#: ../locale/scriptstrings/v.db.join_to_translate.c:8
-msgid "column"
+#: ../vector/v.out.vtk/writeVTK.c:585 ../vector/v.out.ogr/attrb.c:48
+#, c-format
+msgid "Cannot select attributes for cat = %d"
msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:11
-#: ../vector/v.what.rast3/main.c:87 ../vector/v.what.rast/main.c:98
+#: ../vector/v.out.vtk/writeVTK.c:589 ../vector/v.lrs/v.lrs.label/main.c:331
+#: ../vector/v.out.ogr/attrb.c:53 ../vector/v.overlay/main.c:487
+#: ../vector/v.out.svg/main.c:400
#, fuzzy
-msgid "Name of attribute column to be updated with the query result"
+msgid "Unable to fetch data from table"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:12
-#, fuzzy
-msgid "Name of vector map to be queried"
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:13
-msgid "query_layer,query_column"
+#: ../vector/v.out.vtk/writeVTK.c:632
+msgid "Cannot export attribute table fields for layer < 1. Skipping export"
msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:14
+#: ../vector/v.out.vtk/writeVTK.c:640
#, fuzzy
-msgid "query_column"
+msgid "No attribute table found"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:15
-#, fuzzy
-msgid "Name of attribute column to be queried"
+#: ../vector/v.out.vtk/writeVTK.c:655 ../vector/v.random/main.c:271
+#: ../vector/v.profile/main.c:362 ../vector/v.profile/main.c:468
+#: ../vector/v.out.ogr/main.c:640 ../vector/v.in.ascii/main.c:433
+#: ../vector/v.out.postgis/table.c:41 ../vector/v.info/print.c:152
+#: ../vector/v.patch/main.c:162 ../vector/v.patch/main.c:202
+#: ../vector/v.reclass/main.c:193 ../vector/v.out.svg/main.c:165
+#: ../vector/v.db.connect/main.c:228 ../doc/vector/v.example/main.c:137
+#: ../db/db.describe/main.c:67 ../db/db.columns/main.c:62
+#, fuzzy, c-format
+msgid "Unable to describe table <%s>"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:16
-msgid "Maximum query distance in map units"
+#: ../vector/v.out.vtk/writeVTK.c:673
+msgid "No numerical attributes found. Skipping export"
msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
-#, fuzzy
-msgid ""
-"Reconnects attribute tables for all vector maps from the current mapset to a "
-"new database."
+#: ../vector/v.out.vtk/writeVTK.c:732 ../vector/v.out.vtk/writeVTK.c:763
+#: ../vector/v.out.vtk/writeVTK.c:794 ../vector/v.out.vtk/writeVTK.c:823
+#, fuzzy, c-format
+msgid "Error reading value of attribute '%s'"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
-msgid "Copy attribute tables to the target database if not exist"
+#: ../vector/v.net.flow/main.c:62
+msgid "Computes the maximum flow between two sets of nodes in the network."
msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:6
+#: ../vector/v.net.flow/main.c:84
#, fuzzy
-msgid "Delete attribute tables from the source database"
+msgid "Name for output vector map containing a minimum cut"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:7
+#: ../vector/v.net.flow/main.c:107
#, fuzzy
-msgid "Name of source database"
+msgid "Source category values"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:8
-#, fuzzy
-msgid "Name of source database schema"
-msgstr "출력할 격자지도"
+#: ../vector/v.net.flow/main.c:113
+msgid "Source WHERE conditions of SQL statement without 'where' keyword"
+msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:9
+#: ../vector/v.net.flow/main.c:118
#, fuzzy
-msgid "Name for target driver"
+msgid "Sink category values"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:10
-#, fuzzy
-msgid "Name for target database"
-msgstr "출력할 격자지도"
+#: ../vector/v.net.flow/main.c:119 ../vector/v.net.flow/main.c:125
+msgid "Sink"
+msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:11
-#, fuzzy
-msgid "Name for target database schema"
-msgstr "출력할 격자지도"
+#: ../vector/v.net.flow/main.c:124
+msgid "Sink WHERE conditions of SQL statement without 'where' keyword"
+msgstr ""
-#: ../locale/scriptstrings/t.merge_to_translate.c:1
-#, fuzzy
-msgid "Merges several space time datasets into a single space time dataset."
-msgstr "출력할 격자지도"
-msgid ""
-"Aggregates data of an existing space time raster dataset using the time "
-"intervals of a second space time dataset."
+#: ../vector/v.net.flow/main.c:199
+#, c-format
+msgid "No source features selected. Please check options '%s', '%s'."
msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:6
-msgid ""
-"Time intervals from this space time dataset (raster, vector or raster3d) are "
-"used for aggregation computation"
+#: ../vector/v.net.flow/main.c:206
+#, c-format
+msgid "No sink features selected. Please check options '%s', '%s'."
msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:7
+#: ../vector/v.net.flow/main.c:215
#, fuzzy
-msgid "Type of the space time dataset from which aggregation will be copied"
+msgid "No sources"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:12
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:11
-msgid ""
-"Offset that is used to create the output map ids, output map id is generated "
-"as: basename_ (count + offset)"
+#: ../vector/v.net.flow/main.c:218
+msgid "No sinks"
msgstr ""
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:1
+#: ../vector/v.net.flow/main.c:242
#, fuzzy
-msgid ""
-"Uploads space time raster dataset values at positions of vector points to "
-"the table."
+msgid "Writing the output..."
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:9
+#: ../vector/v.split/main.c:56
#, fuzzy
-msgid "Update attribute table of input vector map"
+msgid "densification"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:10
-msgid ""
-"Instead of creating a new vector map update the attribute table with value(s)"
+#: ../vector/v.split/main.c:60
+msgid "Splits vector lines to shorter segments."
msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:1
-msgid "Displays a raster map and its legend on a graphics window"
+#: ../vector/v.split/main.c:73
+msgid "Maximum segment length"
msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:3
-#: ../display/d.title/main.c:50 ../display/d.vect.chart/main.c:64
-#: ../display/d.vect.thematic/main.c:86 ../display/d.barscale/main.c:64
-#: ../display/d.text/main.c:139 ../display/d.linegraph/main.c:230
-#: ../display/d.graph/main.c:59 ../display/d.legend.vect/main.c:51
-#: ../display/d.northarrow/main.c:47 ../display/d.grid/main.c:54
-#: ../display/d.legend/main.c:79
-msgid "cartography"
-msgstr "지도제작"
+#: ../vector/v.split/main.c:82
+msgid "Length units"
+msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:4
-#: ../display/d.vect.thematic/main.c:88 ../display/d.legend.vect/main.c:53
-#: ../display/d.legend/main.c:80
-msgid "legend"
+#: ../vector/v.split/main.c:89
+msgid "Maximum number of vertices in segment"
msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:5
-#: ../display/d.legend/main.c:277
-msgid "Flip legend"
+#: ../vector/v.split/main.c:93
+msgid "Add new vertices, but do not split"
msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:6
-msgid "Omit entries with missing label"
+#: ../vector/v.split/main.c:94 ../vector/v.split/main.c:99
+msgid "Applies only to 'length' option"
msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:7
-#, fuzzy
-msgid "Name of raster map to display"
-msgstr "출력할 격자지도"
+#: ../vector/v.split/main.c:98
+msgid "Force segments to be exactly of given length, except for last one"
+msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:8
-#: ../display/d.legend/main.c:272
-msgid "Draw smooth gradient"
+#: ../vector/v.split/main.c:108
+msgid "Use either length or vertices"
msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:9
-#, fuzzy
-msgid "Number of lines to appear in the legend"
+#: ../vector/v.split/main.c:115
+#, c-format
+msgid "Length must be positive but is %g"
+msgstr ""
+#: ../vector/v.split/main.c:131
+#, fuzzy, c-format
+msgid "Unknown unit %s"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:10
+#: ../vector/v.split/main.c:149
#, fuzzy
-msgid "Name of input raster map to generate legend from"
+msgid "Can not get projection units"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/d.what.rast_to_translate.c:1
-msgid ""
-"Allows the user to interactively query raster map layers at user-selected "
-"locations."
+#: ../vector/v.split/main.c:156
+#, c-format
+msgid "Length in map units: %g"
msgstr ""
-#: ../locale/scriptstrings/r.shade_to_translate.c:10
+#: ../vector/v.split/main.c:158
+#, c-format
+msgid "Length in meters: %g"
+msgstr ""
+#: ../vector/v.split/main.c:164
#, fuzzy
-msgid "Name of shaded raster map"
+msgid "Number of vertices must be at least 2"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.shade_to_translate.c:13
-msgid "Either a standard color name, R:G:B triplet, or \"none\""
+#: ../vector/v.split/main.c:250
+#, c-format
+msgid "Unable to make line segment: %f - %f (line length = %f)"
msgstr ""
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:1
-#, fuzzy
-msgid ""
-"Prints attributes of vector maps registered in a space time vector dataset."
+#: ../vector/v.edit/close.c:56 ../vector/v.edit/snap.c:111
+#, fuzzy, c-format
+msgid "Unable to rewrite line %d"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:6
-#: ../vector/v.extract/main.c:79 ../vector/v.decimate/main.c:128
-#: ../vector/v.outlier/main.c:72
+#: ../vector/v.edit/args.c:20
#, fuzzy
-msgid "select"
+msgid "Name of vector map to edit"
msgstr "출력할 격자지도"
-#, fuzzy
-msgid "Lists registered maps of a space time raster3d dataset."
-msgstr "출력할 격자지도"
+#: ../vector/v.edit/args.c:36
+msgid "Tool"
+msgstr ""
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:8
+#: ../vector/v.edit/args.c:58
#, fuzzy
-msgid "Order the space time dataset by category"
+msgid "Create new (empty) vector map"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:12
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:12
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:12
+#: ../vector/v.edit/args.c:59
#, fuzzy
-msgid "Method used for data listing"
+msgid "Add new features to existing vector map"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.unpack_to_translate.c:1
+#: ../vector/v.edit/args.c:60
#, fuzzy
-msgid ""
-"Imports a raster map as GRASS GIS specific archive file (packed with r.pack)"
+msgid "Delete selected features from vector map"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.unpack_to_translate.c:6
+#: ../vector/v.edit/args.c:61
#, fuzzy
-msgid "Name for output raster map (default: taken from input file internals)"
+msgid "Move selected features in vector map"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:1
+#: ../vector/v.edit/args.c:62
+msgid "Move vertex of selected vector lines"
+msgstr ""
+#: ../vector/v.edit/args.c:63
#, fuzzy
-msgid "Imports SPOT VGT NDVI data into a raster map."
+msgid "Remove vertex from selected vector lines"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
-msgid "Also import quality map (SM status map layer) and filter NDVI map"
+#: ../vector/v.edit/args.c:64
+msgid "Add new vertex to selected vector lines"
msgstr ""
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:5
+#: ../vector/v.edit/args.c:65
#, fuzzy
-msgid "Name of input SPOT VGT NDVI HDF file"
+msgid "Merge selected vector lines"
msgstr "출력할 격자지도"
+#: ../vector/v.edit/args.c:66
#, fuzzy
-msgid "Lists registered maps of a space time vector dataset."
+msgid "Break/split vector lines"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:1
-msgid "Downloads and imports data from WMS/WMTS/NASA OnEarth server."
+#: ../vector/v.edit/args.c:67
+msgid "Select lines and print their ID's"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:4
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:4
-msgid "OGC web services"
+#: ../vector/v.edit/args.c:68
+msgid "Set new categories to selected vector features for defined layer"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:5
-msgid "Typically starts with \"http://\""
+#: ../vector/v.edit/args.c:70
+msgid "Delete categories from selected vector features for defined layer"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:7
+#: ../vector/v.edit/args.c:72
#, fuzzy
-msgid "Layer(s) to request from the map server"
+msgid "Copy selected features"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:8
-#, fuzzy
-msgid "Layer style(s) to request from the map server"
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:9
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:34
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:40
-msgid "Map style"
+#: ../vector/v.edit/args.c:73
+msgid "Snap vector features in given threshold"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:10
-msgid "Image format requested from the server"
+#: ../vector/v.edit/args.c:74
+msgid "Flip direction of selected vector lines"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:11
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:13
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:18
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:20
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:22
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:24
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:31
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:38
-msgid "Request"
-msgstr ""
+#: ../vector/v.edit/args.c:75
+#, fuzzy
+msgid "Connect two lines"
+msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:12
-msgid "EPSG code of requested source projection"
+#: ../vector/v.edit/args.c:76
+msgid "Z bulk-labeling (automated assignment of z coordinate to vector lines)"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:14
-msgid "Driver used to communication with server"
+#: ../vector/v.edit/args.c:78
+msgid "Change feature type (point<->centroid, line<->boundary)"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:15
-msgid ""
-"WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using "
-"native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS "
-"driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;"
+#: ../vector/v.edit/args.c:79
+msgid "Delete selected areas from vector map (based on selected centroids)"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:17
-msgid "WMS standard version"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:19
+#: ../vector/v.edit/args.c:87
#, fuzzy
-msgid "Maximum columns to request at a time"
+msgid "Name of file containing data in GRASS ASCII vector format"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:21
-#, fuzzy
-msgid "Maximum rows to request at a time"
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:23
-msgid "Additional query parameters to pass to the server"
+#: ../vector/v.edit/args.c:99
+msgid "Difference in x,y,z direction for moving feature or vertex"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:25
-#, fuzzy
-msgid "Username for server connection"
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:27
-msgid "Password for server connection"
+#: ../vector/v.edit/args.c:106
+msgid "Threshold distance (coords,snap,query)"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:29
-msgid "Interpolation method to use in reprojection"
+#: ../vector/v.edit/args.c:108
+msgid "'-1' for threshold based on the current resolution settings"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:30
-msgid "Request data for this named region instead of the current region bounds"
+#: ../vector/v.edit/args.c:124
+msgid "List of point coordinates"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:32
-#: ../display/d.erase/main.c:37 ../display/d.mon/main.c:90
-#: ../display/d.histogram/main.c:108 ../display/d.legend.vect/main.c:101
-#: ../display/d.path/main.c:115 ../display/d.grid/main.c:113
-#: ../display/d.legend/main.c:246 ../general/g.pnmcomp/main.c:325
-#: ../misc/m.nviz.image/args.c:70 ../vector/v.label.sa/main.c:124
-#: ../vector/v.lrs/v.lrs.label/main.c:218 ../vector/v.label/main.c:187
-msgid "Background color"
+#: ../vector/v.edit/args.c:133
+msgid "Bounding box for selecting features"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:33
-msgid "Format: 0xRRGGBB"
+#: ../vector/v.edit/args.c:142
+msgid "Polygon for selecting features"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:35
-msgid ""
-"Capabilities file to parse (input). It is relevant for WMTS_GRASS and "
-"OnEarth_GRASS drivers"
+#: ../vector/v.edit/args.c:152
+msgid "Query tool"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:36
-msgid "File where the server capabilities will be saved ('c' flag)"
+#: ../vector/v.edit/args.c:154
+msgid "For 'shorter' use negative threshold value, positive value for 'longer'"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:37
-msgid "Get the server capabilities then exit"
+#: ../vector/v.edit/args.c:160
+msgid "Select only lines or boundaries shorter/longer than threshold distance"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:39
-msgid "Do not request transparent data"
+#: ../vector/v.edit/args.c:162
+msgid "Select dangles shorter/longer than threshold distance"
msgstr ""
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:1
+#: ../vector/v.edit/args.c:169
#, fuzzy
-msgid ""
-"Imports a space time vector dataset from a GRASS GIS specific archive file."
+msgid "Name of background vector map(s)"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:15
+#: ../vector/v.edit/args.c:176
msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not "
-"import the space time vector datasets."
+"Snap added or modified features in the given threshold to the nearest "
+"existing feature"
msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:1
-msgid "Performs auto-balancing of colors for RGB images."
+#: ../vector/v.edit/args.c:182
+msgid "Not apply snapping"
msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:5
-#: ../display/d.colorlist/main.c:37
-msgid "colors"
+#: ../vector/v.edit/args.c:183
+msgid "Snap only to node"
msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:6
-#, fuzzy
-msgid "Name of red channel"
-msgstr "출력할 격자지도"
+#: ../vector/v.edit/args.c:184
+msgid "Allow snapping also to vertex"
+msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:7
-#, fuzzy
-msgid "Name of green channel"
-msgstr "출력할 격자지도"
+#: ../vector/v.edit/args.c:192
+msgid "Starting value and step for z bulk-labeling"
+msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:8
-#, fuzzy
-msgid "Name of blue channel"
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:9
-msgid "Cropping intensity (upper brightness level)"
+#: ../vector/v.edit/args.c:193
+msgid "Pair: value,step (e.g. 1100,10)"
msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:10
-msgid "Extend colors to full range of data on each channel"
+#: ../vector/v.edit/args.c:204
+msgid "Close added boundaries (using threshold distance)"
msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:11
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:13
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:15
-#: ../display/d.rast.num/main.c:89 ../display/d.rast.num/main.c:95
-#: ../display/d.rast.num/main.c:113 ../display/d.barscale/main.c:153
-#: ../display/d.barscale/main.c:159 ../display/d.rast.arrow/main.c:119
-#: ../display/d.rast.arrow/main.c:125 ../display/d.rast.arrow/main.c:131
-#: ../display/d.rast.arrow/main.c:137 ../display/d.vect/main.c:120
-#: ../display/d.vect/main.c:126 ../display/d.vect/main.c:130
-#: ../display/d.vect/main.c:137 ../display/d.vect/main.c:308
-#: ../display/d.northarrow/main.c:104 ../display/d.northarrow/main.c:109
-#: ../display/d.northarrow/main.c:115 ../vector/v.label.sa/main.c:103
-#: ../vector/v.label.sa/main.c:113 ../vector/v.label.sa/main.c:120
-#: ../vector/v.label.sa/main.c:130 ../vector/v.label.sa/main.c:140
-#: ../vector/v.label.sa/main.c:150 ../vector/v.label.sa/main.c:157
-#: ../vector/v.label/main.c:152 ../vector/v.label/main.c:176
-#: ../vector/v.label/main.c:189 ../vector/v.label/main.c:195
-#: ../vector/v.label/main.c:205
-msgid "Colors"
+#: ../vector/v.edit/args.c:208
+msgid "Do not expect header of input data"
msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:12
-msgid "Preserve relative colors, adjust brightness only"
+#: ../vector/v.edit/args.c:216
+msgid "Modify only first found feature in bounding box"
msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:14
-#, fuzzy
-msgid "Reset to standard color range"
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:16
-#: ../locale/scriptstrings/i.oif_to_translate.c:7
-msgid "Process bands serially (default: run in parallel)"
+#: ../vector/v.edit/args.c:228
+msgid "Polygon must have at least 3 coordinate pairs"
msgstr ""
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:1
-#, fuzzy
-msgid "Imports SRTM HGT files into raster map."
+#: ../vector/v.edit/args.c:292
+#, fuzzy, c-format
+msgid "Operation '%s' not implemented"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:4
-#, fuzzy
-msgid "Name of SRTM input tile (file without .hgt.zip extension)"
+#: ../vector/v.edit/args.c:301
+#, fuzzy, c-format
+msgid "At least one option from %s must be specified"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:5
-#, fuzzy
-msgid "Name for output raster map (default: input tile)"
-msgstr "출력할 격자지도"
+#: ../vector/v.edit/args.c:307 ../vector/v.edit/args.c:316
+#: ../vector/v.edit/args.c:323 ../vector/v.edit/args.c:330
+#: ../vector/v.edit/args.c:334
+#, c-format
+msgid "Tool %s requires option %s"
+msgstr ""
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:6
-msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
+#: ../vector/v.edit/select.c:73
+#, c-format
+msgid "Threshold value for coordinates is %.2f"
msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
-#, fuzzy
-msgid "Imports GetFeature from a WFS server."
-msgstr "출력할 격자지도"
+#: ../vector/v.edit/select.c:160
+#, c-format
+msgid "Threshold value for querying is %.2f"
+msgstr "질의를 위한 임계값은 %.2f입니다"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:5
-msgid "Base URL starting with 'http' and ending in '?'"
-msgstr ""
+#: ../vector/v.edit/select.c:176
+#, c-format
+msgid "%d of %d feature selected from vector map <%s>"
+msgid_plural "%d of %d features selected from vector map <%s>"
+msgstr[0] "벡터지도 <%3$s>에서 %2$d개 중 %1$d개의 피쳐를 선택했습니다"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:6
-msgid "Comma separated names of data layers to download"
+#: ../vector/v.edit/select.c:496
+msgid "Layer must be > 0 for 'where'"
msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:7
-msgid "Specify alternate spatial reference system (example: EPSG:4326)"
-msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:8
+#: ../vector/v.edit/main.c:61
msgid ""
-"The given code must be supported by the server, consult the capabilities file"
+"Edits a vector map, allows adding, deleting and modifying selected vector "
+"features."
msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:9
-#, fuzzy
-msgid "Maximum number of features to download"
+#: ../vector/v.edit/main.c:70
+#, fuzzy, c-format
+msgid "Unable to get category list <%s>"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:10
-msgid "(default: unlimited)"
-msgstr ""
+#: ../vector/v.edit/main.c:97 ../vector/v.kernel/main.c:230
+#: ../vector/v.in.ogr/main.c:503 ../vector/v.in.lidar/main.c:543
+#, fuzzy, c-format
+msgid "Vector map <%s> already exists"
+msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:11
-msgid "Skip earlier feature IDs and start downloading at this one"
+#: ../vector/v.edit/main.c:117
+msgid "Supported feature types for non-native formats:"
msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:12
-msgid "(default: start with the first feature)"
-msgstr ""
+#: ../vector/v.edit/main.c:138
+#, fuzzy, c-format
+msgid ""
+"Unable to open vector map <%s> on topological level. Try to rebuild vector "
+"topology by v.build."
+msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:13
+#: ../vector/v.edit/main.c:158
+#, fuzzy, c-format
msgid ""
-"Download server capabilities to 'wms_capabilities.xml' in the current "
-"directory and exit"
-msgstr ""
+"Unable to open vector map <%s> as the background map. It is given as vector "
+"map to be edited."
+msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:14
-msgid "Restrict fetch to features which touch the current region"
+#: ../vector/v.edit/main.c:169
+#, c-format
+msgid "Background vector map <%s> registered"
msgstr ""
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
-msgid "Mosaics several images and extends colormap."
+#: ../vector/v.edit/main.c:205
+msgid "Threshold for snapping must be > 0. No snapping applied."
msgstr ""
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:1
+#: ../vector/v.edit/main.c:212
+msgid "Selecting features..."
+msgstr "피쳐를 선택하는 중..."
+#: ../vector/v.edit/main.c:224
+msgid "No features selected, nothing to edit"
+msgstr "어떤 피쳐도 선택하지 않았으므로 수정할 것이 없습니다"
+#: ../vector/v.edit/main.c:232
+#, c-format
msgid ""
-"Performs different aggregation algorithms from r.series on all or a subset "
-"of raster maps in a space time raster dataset."
+"Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert "
+"the vector map to 3D using e.g. %s."
msgstr ""
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:9
-#, fuzzy
-msgid ""
-"Do not assign the space time raster dataset start and end time to the output "
-"map"
+#: ../vector/v.edit/main.c:274
+#, fuzzy, c-format
+msgid "%d feature added"
+msgid_plural "%d features added"
+msgstr[0] "출력할 격자지도"
+#: ../vector/v.edit/main.c:282 ../vector/v.edit/main.c:311
+#: ../vector/v.edit/main.c:322 ../vector/v.edit/main.c:354
+#: ../vector/v.edit/main.c:400
+#, fuzzy, c-format
+msgid "Threshold value for snapping is %.2f"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/i.oif_to_translate.c:1
-msgid "Calculates Optimum-Index-Factor table for spectral bands"
-msgstr ""
+#: ../vector/v.edit/main.c:294
+#, fuzzy, c-format
+msgid "%d boundary closed"
+msgid_plural "%d boundaries closed"
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:1
-#, fuzzy
-msgid "Exports space time raster dataset as VTK time series."
-msgstr "출력할 격자지도"
+#: ../vector/v.edit/main.c:303
+#, c-format
+msgid "%d feature deleted"
+msgid_plural "%d features deleted"
+msgstr[0] "%d개의 피쳐를 지웠습니다"
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:5
-msgid "VTK"
+#: ../vector/v.edit/main.c:314
+#, fuzzy, c-format
+msgid "%d feature moved"
+msgid_plural "%d features moved"
+#: ../vector/v.edit/main.c:325
+#, fuzzy, c-format
+msgid "%d vertex moved"
+msgid_plural "%d vertices moved"
+#: ../vector/v.edit/main.c:331
+#, fuzzy, c-format
+msgid "%d vertex added"
+msgid_plural "%d vertices added"
+#: ../vector/v.edit/main.c:337
+#, fuzzy, c-format
+msgid "%d vertex removed"
+msgid_plural "%d vertices removed"
+#: ../vector/v.edit/main.c:349
+#, fuzzy, c-format
+msgid "%d line broken"
+msgid_plural "%d lines broken"
+#: ../vector/v.edit/main.c:357
+#, fuzzy, c-format
+msgid "%d line connected"
+msgid_plural "%d lines connected"
+#: ../vector/v.edit/main.c:363
+#, fuzzy, c-format
+msgid "%d line merged"
+msgid_plural "%d lines merged"
+#: ../vector/v.edit/main.c:372 ../vector/v.edit/main.c:378
+#, fuzzy, c-format
+msgid "%d feature modified"
+msgid_plural "%d features modified"
+#: ../vector/v.edit/main.c:385
+#, c-format
+msgid ""
+"Multiple background maps were given. Selected features will be copied only "
+"from vector map <%s>."
msgstr ""
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:7
+#: ../vector/v.edit/main.c:395
+#, fuzzy, c-format
+msgid "%d feature copied"
+msgid_plural "%d features copied"
+#: ../vector/v.edit/main.c:406
+#, fuzzy, c-format
+msgid "%d line flipped"
+msgid_plural "%d lines flipped"
+#: ../vector/v.edit/main.c:427
+#, fuzzy, c-format
+msgid "%d line labeled"
+msgid_plural "%d lines labeled"
+#: ../vector/v.edit/main.c:436
+#, fuzzy, c-format
+msgid "%d feature converted"
+msgid_plural "%d features converted"
+#: ../vector/v.edit/main.c:441
#, fuzzy
-msgid "Path to the export directory"
+msgid "No feature modified"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:10
-#: ../vector/v.out.vtk/main.c:84
-msgid "Correct the coordinates to fit the VTK-OpenGL precision"
+#: ../vector/v.edit/main.c:448
+#, c-format
+msgid "Select feature %d is not centroid, ignoring..."
msgstr ""
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:11
-msgid ""
-"Export files using the space time dataset granularity for equidistant time "
-"between maps, where statement will be ignored"
-msgstr ""
+#: ../vector/v.edit/main.c:455
+#, fuzzy, c-format
+msgid "%d area removed"
+msgid_plural "%d areas removed"
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
-msgid ""
-"Exports a raster map to a text file as x,y,z values based on cell centers."
+#: ../vector/v.edit/main.c:461
+msgid "Operation not implemented"
msgstr ""
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
-msgid "ASCII"
-msgstr ""
+#: ../vector/v.random/main.c:101 ../vector/v.qcount/main.c:62
+#: ../vector/v.mkgrid/main.c:73 ../vector/v.kcv/main.c:58
+#: ../vector/v.perturb/main.c:66 ../vector/v.normal/main.c:75
+#, fuzzy
+msgid "point pattern"
+msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:1
+#: ../vector/v.random/main.c:102
#, fuzzy
-msgid "Extracts a subset of a space time raster datasets."
+msgid "stratified random sampling"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:6
-msgid "r.mapcalc expression assigned to all extracted raster maps"
-msgstr ""
+#: ../vector/v.random/main.c:103
+#, fuzzy
+msgid "Generates random 2D/3D vector points."
+msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:1
+#: ../vector/v.random/main.c:111
#, fuzzy
-msgid "Converts a space time raster dataset into a 3D raster map."
+msgid "Number of points to be created"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.select_to_translate.c:1
-msgid ""
-"Select maps from space time datasets by topological relationships to other "
-"space time datasets using temporal algebra."
+#: ../vector/v.random/main.c:116
+#, fuzzy
+msgid "Restrict points to areas in input vector"
+msgstr "출력할 격자지도"
+#: ../vector/v.random/main.c:133
+msgid "Minimum z height (needs -z flag or column name)"
msgstr ""
-#: ../locale/scriptstrings/t.select_to_translate.c:7
-msgid "The temporal mapcalc expression"
+#: ../vector/v.random/main.c:135 ../vector/v.random/main.c:144
+#: ../vector/v.random/main.c:157 ../vector/v.random/main.c:167
+#: ../vector/v.random/main.c:172 ../vector/v.in.db/main.c:85
+msgid "3D output"
msgstr ""
-#: ../locale/scriptstrings/t.select_to_translate.c:8
+#: ../vector/v.random/main.c:142
+msgid "Maximum z height (needs -z flag or column name)"
+msgstr ""
+#: ../vector/v.random/main.c:151
msgid ""
-"Check the spatial topology of temporally related maps and select only "
-"spatially related maps"
+"The seed to initialize the random generator. If not set the process ID is "
+"used"
msgstr ""
-#: ../locale/scriptstrings/t.create_to_translate.c:1
+#: ../vector/v.random/main.c:154
#, fuzzy
-msgid "Creates a space time dataset."
+msgid "Name of column for z values"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.create_to_translate.c:4
+#: ../vector/v.random/main.c:156
#, fuzzy
-msgid "create"
+msgid "Writes z values to column"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.create_to_translate.c:6
+#: ../vector/v.random/main.c:164
#, fuzzy
-msgid "Type of the output space time dataset"
+msgid "Type of column for z values"
msgstr "출력할 격자지도"
+#: ../vector/v.random/main.c:171
+msgid "Create 3D output"
+msgstr ""
+#: ../vector/v.random/main.c:176
#, fuzzy
-msgid "Lists registered maps of a space time raster dataset."
+msgid "Generate n points for each individual area"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:13
+#: ../vector/v.random/main.c:190
+#, fuzzy, c-format
+msgid "Number of points must be > 0 (%d given)"
+msgstr "출력할 격자지도"
+#: ../vector/v.random/main.c:206 ../vector/v.drape/main.c:150
+#: ../vector/v.buffer/main.c:348
+#, c-format
msgid ""
-"The granule to be used for listing. The granule must be specified as string "
-"eg.: absolute time \"1 months\" or relative time \"1\""
+"Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer "
+"'1'."
msgstr ""
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:1
-#, fuzzy
-msgid ""
-"Creates/modifies the color table associated with each raster map of the "
-"space time raster dataset."
+#: ../vector/v.random/main.c:216
+#, fuzzy, c-format
+msgid "No areas in vector map <%s>"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:6
-#, fuzzy
-msgid "Name of color table (see r.color help)"
+#: ../vector/v.random/main.c:221
+#, fuzzy, c-format
+msgid "The <-%c> flag requires an input vector with areas"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:1
-#, fuzzy
-msgid "Imports E00 file into a vector map."
-msgstr "출력할 격자지도"
+#: ../vector/v.random/main.c:275
+msgid "Table should contain only two columns"
+msgstr ""
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:4
-msgid "E00"
+#: ../vector/v.random/main.c:284
+msgid ""
+"You have created unsupported column type. This module supports only INTEGER "
+"and DOUBLE PRECISION column types."
msgstr ""
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:5
-#, fuzzy
-msgid "Name of input E00 file"
+#: ../vector/v.random/main.c:347
+#, fuzzy, c-format
+msgid ""
+"Selected areas in input vector <%s> do not overlap with the current region"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.pack_to_translate.c:1
-#, fuzzy
-msgid "Exports a vector map as GRASS GIS specific archive file"
+#: ../vector/v.random/main.c:359
+#, fuzzy, c-format
+msgid "Input vector <%s> does not overlap with the current region"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.pack_to_translate.c:5
+#: ../vector/v.random/main.c:384
#, fuzzy
-msgid "Name of vector map to pack up"
+msgid "Generating points..."
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:1
+#: ../vector/v.profile/main.c:101
#, fuzzy
-msgid "Joins a database table to a vector map table."
+msgid "Vector map profiling tool"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:5
+#: ../vector/v.profile/main.c:109 ../vector/v.profile/main.c:143
+#: ../vector/v.profile/main.c:148
#, fuzzy
-msgid "Vector map to which to join other table"
-msgstr "출력할 격자지도"
+msgid "Input filter"
+msgstr "입력파일"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:7
+#: ../vector/v.profile/main.c:113
#, fuzzy
-msgid "Layer where to join"
+msgid "Coordinates for profiling line nodes"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:9
-msgid "Identifier column (e.g.: cat) in the vector table to be used for join"
-msgstr ""
+#: ../vector/v.profile/main.c:114 ../vector/v.profile/main.c:183
+#: ../vector/v.profile/main.c:194 ../vector/v.profile/main.c:202
+#, fuzzy
+msgid "Profiling line"
+msgstr "선을 합치는 중..."
-#: ../locale/scriptstrings/v.db.join_to_translate.c:10
-msgid "Other table name"
+#: ../vector/v.profile/main.c:121
+msgid "Buffer (tolerance) for points in map units"
msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:11
-msgid "ocolumn,scolumns"
+#: ../vector/v.profile/main.c:122
+msgid "How far points can be from sampling line"
msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:12
-msgid "Identifier column (e.g.: id) in the other table used for join"
-msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:13
+#: ../vector/v.profile/main.c:128 ../vector/v.profile/main.c:131
+#: ../vector/v.profile/main.c:140 ../vector/v.profile/main.c:160
+#: ../vector/v.profile/main.c:165 ../vector/v.profile/main.c:171
#, fuzzy
-msgid "Subset of columns from the other table"
+msgid "Output formating"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.sample_to_translate.c:1
+#: ../vector/v.profile/main.c:139
#, fuzzy
-msgid ""
-"Samples the input space time dataset(s) with a sample space time dataset and "
-"print the result to stdout."
+msgid "Number of significant digits"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.sample_to_translate.c:5
+#: ../vector/v.profile/main.c:147
+msgid "Use features only from specified layer"
+msgstr ""
+#: ../vector/v.profile/main.c:157
#, fuzzy
-msgid "Name of the sample space time dataset"
+msgid "Name for profile line and buffer output map"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.sample_to_translate.c:8
+#: ../vector/v.profile/main.c:159
#, fuzzy
-msgid "Type of the sample space time dataset"
+msgid "Profile line and buffer around it will be written"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.sample_to_translate.c:9
-msgid "Field separator between output columns, default is tabular \" | \""
-msgstr ""
+#: ../vector/v.profile/main.c:164
+#, fuzzy
+msgid "Do not print column names"
+msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.sample_to_translate.c:10
-msgid ""
-"Do not use \",\" as this char is reserved to list several map ids in a "
-"sample granule"
-msgstr ""
+#: ../vector/v.profile/main.c:169
+#, fuzzy
+msgid "Do not print 3D vector data (z values)"
+msgstr "값이 없는 자료는 보고하지 않습니다"
-#: ../locale/scriptstrings/t.sample_to_translate.c:12
-msgid "Check for spatial topological overlap"
+#: ../vector/v.profile/main.c:170
+msgid "Only affects 3D vectors"
msgstr ""
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
+#: ../vector/v.profile/main.c:181
#, fuzzy
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
+msgid "Profiling line map"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
+#: ../vector/v.profile/main.c:182
#, fuzzy
-msgid "Name of attribute column(s) to drop"
+msgid "Vector map containing profiling line"
msgstr "출력할 격자지도"
-#, fuzzy
-msgid ""
-"3D raster map of a space time 3D raster dataset."
-msgstr "출력할 격자지도"
+#: ../vector/v.profile/main.c:191
+msgid "WHERE conditions for input profile line map"
+msgstr ""
-#: ../locale/scriptstrings/v.db.droprow_to_translate.c:1
-msgid "Removes a vector feature from a vector map through attribute selection."
+#: ../vector/v.profile/main.c:193
+msgid "Use to select only one line from profiling line map"
msgstr ""
+#: ../vector/v.profile/main.c:201
#, fuzzy
-msgid ""
-"Aggregates temporally the maps of a space time raster dataset by a user "
-"defined granularity."
+msgid "Profiling line map layer"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:7
-msgid ""
-"Either a numerical suffix or the start time (s-flag) separated by an "
-"underscore will be attached to create a unique identifier"
+#: ../vector/v.profile/main.c:212
+#, fuzzy
+msgid "Layer 0 not supported"
+msgstr "출력할 격자지도"
+#: ../vector/v.profile/main.c:217
+msgid "Failed to interpreter 'dp' parameter as an integer"
msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:9
-msgid ""
-"Aggregation granularity, format absolute time \"x years, x months, x weeks, "
-"x days, x hours, x minutes, x seconds\" or an integer value for relative time"
+#: ../vector/v.profile/main.c:223
+msgid "Tolerance value can not be less than 0"
msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:12
-#, fuzzy
-msgid "Number of r.series processes to run in parallel"
+#: ../vector/v.profile/main.c:228
+#, fuzzy, c-format
+msgid "<%s> is not a valid vector map name"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:13
-msgid "The maximum number of open files allowed for each r.series process"
+#: ../vector/v.profile/main.c:233
+msgid ""
+"No input profile map name provided, but WHERE conditions for it have been set"
msgstr ""
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:1
-#, fuzzy
+#: ../vector/v.profile/main.c:237
msgid ""
-"Replaces gaps in a space time raster dataset with interpolated raster maps."
-msgstr "출력할 격자지도"
+"Profile input coordinates and vector map are provided. Please provide only "
+"one of them"
+msgstr ""
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:9
-#, fuzzy
-msgid "Number of interpolation processes to run in parallel"
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:10
+#: ../vector/v.profile/main.c:241
msgid ""
-"Assign the space time raster dataset start and end time to the output map"
+"No profile input coordinates nor vector map are provided. Please provide one "
+"of them"
msgstr ""
-#: ../locale/scriptstrings/v.to.lines_to_translate.c:1
+#: ../vector/v.profile/main.c:278
#, fuzzy
-msgid "Converts vector polygons or points to lines."
+msgid "At least profile start and end coordinates are required!"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/v.to.lines_to_translate.c:7
+#: ../vector/v.profile/main.c:290 ../vector/v.cluster/main.c:144
+#: ../doc/vector/v.example/main.c:81
#, fuzzy
-msgid "Method used for point interpolation"
+msgid "Unable to set predetermined vector open level"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:1
-#, fuzzy
+#: ../vector/v.profile/main.c:315 ../vector/v.profile/main.c:330
+#, fuzzy, c-format
msgid ""
-"Performs a neighborhood analysis for each map in a space time raster dataset."
-msgstr "출력할 격자지도"
+"No database connection defined for map <%s> layer %d, but WHERE condition is "
+"provided"
+msgstr "지도 <%s>를 위한 데이타베이스 연결이 DB 파일 안에 정의되지 않았습니다"
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:11
+#: ../vector/v.profile/main.c:373 ../vector/v.profile/main.c:478
#, fuzzy
-msgid "Number of r.neighbor processes to run in parallel"
+msgid "No features match Your query"
msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:13
-#, fuzzy
-msgid "Ignore the current region settings and use the raster map regions"
-msgstr "출력할 격자지도"
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:1
-#, fuzzy
+#: ../vector/v.profile/main.c:378 ../vector/v.profile/main.c:391
msgid ""
-"Calculates univariate statistics of attributes for each registered vector "
-"map of a space time vector dataset"
-msgstr "출력할 격자지도"
+"Your query matches more than one record in input profiling map. Currently "
+"it's not supported. Enhance WHERE conditions to get only one line."
+msgstr ""
-#: ../temporal/t.connect/main.c:35 ../display/d.fontlist/main.c:46
-#: ../display/d.colorlist/main.c:36 ../display/d.font/main.c:46
-#: ../general/g.mapset/main.c:50 ../general/g.gisenv/main.c:44
-#: ../general/g.mapsets/main.c:64 ../general/g.region/main.c:65
-msgid "settings"
-msgstr "설정"
+#: ../vector/v.profile/main.c:384
+msgid "Error while initialising line list"
+msgstr ""
-#: ../temporal/t.connect/main.c:38
+#: ../vector/v.profile/main.c:396
+msgid "Error while reading vector feature from profile line map"
+msgstr ""
+#: ../vector/v.profile/main.c:410
msgid ""
-"Prints/sets general temporal GIS database connection for current mapset."
+"Your input profile map contains more than one line. Currently it's not "
+"supported. Provide WHERE conditions to get only one line."
msgstr ""
-#: ../temporal/t.connect/main.c:54
-#, fuzzy
-msgid "Overwrite current settings if initialized"
+#: ../vector/v.profile/main.c:557
+#, fuzzy, c-format
+msgid "Unabale to get attribute data for cat %d"
msgstr "출력할 격자지도"
-#: ../temporal/t.connect/main.c:59
-#, fuzzy
-msgid "Print current connection parameter in shell style and exit"
-msgstr "출력할 격자지도"
+#: ../vector/v.profile/main.c:566
+#, c-format
+msgid "Error while retreiving database record for cat %d"
+msgstr ""
-#: ../temporal/t.connect/main.c:83 ../temporal/t.connect/main.c:95
-msgid "Temporal GIS database connection not defined. Run t.connect."
+#: ../vector/v.profile/main.c:604
+msgid "Can not write data portion to provided output"
msgstr ""
-#: ../temporal/t.connect/main.c:111
+#: ../vector/v.voronoi/sw_main.c:188
#, c-format
-msgid ""
-"Default TGIS driver / database set to:\n"
-"driver: %s\n"
-"database: %s"
+msgid "Found %d point/centroid in <%s>, but at least 2 are needed"
+msgid_plural "Found %d points/centroids in <%s>, but at least 2 are needed"
+msgstr[0] ""
+#: ../vector/v.voronoi/sw_main.c:410 ../vector/v.voronoi/sw_main.c:436
+msgid "All boundaries in the list should be valid"
msgstr ""
-#: ../temporal/t.connect/main.c:118
-msgid "Default TGIS driver is not set"
+#: ../vector/v.voronoi/sw_main.c:416 ../vector/v.voronoi/sw_main.c:442
+msgid "Boundary is degenerate"
msgstr ""
-#: ../temporal/t.connect/main.c:121
-msgid "Default TGIS database is not set"
+#: ../vector/v.voronoi/sw_main.c:468
+#, c-format
+msgid "Found %d vertex in <%s>, but at least 2 are needed"
+msgid_plural "Found %d vertices in <%s>, but at least 2 are needed"
+msgstr[0] ""
+#: ../vector/v.voronoi/main.c:125 ../vector/v.delaunay/main.c:87
+msgid "triangulation"
+msgstr "삼각분할"
+#: ../vector/v.voronoi/main.c:126
+msgid "skeleton"
msgstr ""
-#: ../display/d.erase/main.c:33
+#: ../vector/v.voronoi/main.c:127
msgid ""
-"Erases the contents of the active graphics display frame with user defined "
-"color."
+"Creates a Voronoi diagram in current region from an input vector map "
+"containing points or centroids."
msgstr ""
+"현재지역 안에 점이나 중심점을 포함한 입력 벡터지도로부터 보로노이 다이어그램"
+"을 생성합니다."
-#: ../display/d.erase/main.c:42
-msgid "Remove all frames and erase the screen"
-msgstr ""
+#: ../vector/v.voronoi/main.c:131 ../vector/v.sample/main.c:82
+#: ../vector/v.surf.bspline/main.c:110
+msgid "Name of input vector point map"
+msgstr "입력 벡터점 지도의 이름"
-#: ../display/d.title/main.c:52
+#: ../vector/v.voronoi/main.c:141
+msgid "Factor for output smoothness"
+msgstr "출력 평활도 계수"
+#: ../vector/v.voronoi/main.c:142
msgid ""
-"Create a TITLE for a raster map in a form suitable for display with d.text."
+"Applies to input areas only. Smaller values produce smoother output but can "
+"cause numerical instability."
msgstr ""
+"입력 면에만 적용됩니다. 값이 작을 수록 평평한 출력을 생성하지만 수치계산이 불"
+"안정해질 수 있습니다."
-#: ../display/d.title/main.c:63
-msgid "Sets the text color"
-msgstr ""
+#: ../vector/v.voronoi/main.c:149
+msgid "Maximum dangle length of skeletons"
+msgstr "스켈리턴의 최대 댕글길이"
-#: ../display/d.title/main.c:71
-msgid "Sets the text size as percentage of the frame's height"
-msgstr ""
+#: ../vector/v.voronoi/main.c:150
+msgid ""
+"Applies only to skeleton extraction. Default = -1 will extract the center "
+"line."
+msgstr "스켈리턴 추출에만 적용됩니다. 기본값 -1은 중심선을 추출합니다."
-#: ../display/d.title/main.c:75
-#, fuzzy
-msgid "Draw title on current display"
+#: ../vector/v.voronoi/main.c:156
+msgid "Create Voronoi diagram for input areas"
+msgstr "입력면을 위한 보로노이 다이어그램을 생성합니다"
+#: ../vector/v.voronoi/main.c:161
+msgid "Extract skeletons for input areas"
+msgstr "입력면을 위한 스켈리턴을 추출합니다"
+#: ../vector/v.voronoi/main.c:166
+msgid "Output tessellation as a graph (lines), not areas"
+msgstr "테셀레이션을 면이 아니라 선그래프로 출력합니다"
+#: ../vector/v.voronoi/main.c:182
+#, fuzzy, c-format
+msgid "Option '%s' is too small, set to %g"
msgstr "출력할 격자지도"
-#: ../display/d.title/main.c:79
-msgid "Do a fancier title"
-msgstr ""
+#: ../vector/v.voronoi/main.c:208 ../vector/v.to.db/lines.c:75
+#: ../vector/v.to.db/query.c:23 ../vector/v.to.rast/do_lines.c:36
+#: ../vector/v.colors/scan_z.c:31 ../vector/v.colors/scan_cats.c:19
+#: ../vector/v.colors.out/scan_cats.c:28
+msgid "Reading features..."
+msgstr "피쳐를 읽는 중..."
-#: ../display/d.title/main.c:84
-msgid "Do a simple title"
-msgstr ""
+#: ../vector/v.voronoi/main.c:226
+#, c-format
+msgid "Voronoi triangulation for %d point..."
+msgid_plural "Voronoi triangulation for %d points..."
+msgstr[0] "%d개의 점을 위해 보로노이 삼각분할 중..."
-#: ../display/d.title/main.c:102
-msgid "Title can be fancy or simple, not both"
-msgstr ""
+#: ../vector/v.voronoi/main.c:230 ../vector/v.delaunay/in_out.c:93
+msgid "Writing edges..."
+msgstr "가장자리를 쓰는 중..."
-#: ../display/d.title/main.c:105
-msgid "No map name given"
+#: ../vector/v.voronoi/main.c:239
+msgid "Thin skeletons ..."
msgstr ""
-#: ../display/d.rast.num/main.c:78 ../display/d.rast.arrow/main.c:98
+#: ../vector/v.voronoi/main.c:322 ../vector/v.in.db/main.c:235
+msgid "Writing features..."
+msgstr "피쳐를 쓰고 있습니다..."
+#: ../vector/v.voronoi/main.c:396
#, fuzzy
-msgid "map annotations"
+msgid "No table"
msgstr "출력할 격자지도"
-#: ../display/d.rast.num/main.c:81
-msgid ""
-"Overlays cell category values on a raster map displayed in the active "
-"graphics frame."
+#: ../vector/v.voronoi/main.c:411
+msgid "Cannot copy table"
msgstr ""
-#: ../display/d.rast.num/main.c:88 ../display/d.rhumbline/main.c:62
-#: ../display/d.northarrow/main.c:113 ../display/d.geodesic/main.c:66
-#: ../display/d.grid/main.c:107 ../display/d.legend/main.c:203
-#: ../vector/v.label.sa/main.c:98 ../vector/v.lrs/v.lrs.label/main.c:193
-#: ../vector/v.label/main.c:151
-msgid "Text color"
-msgstr "문자색상"
-#: ../display/d.rast.num/main.c:94 ../display/d.grid/main.c:96
-msgid "Grid color"
+#: ../vector/v.voronoi/skeleton.c:293 ../vector/v.voronoi/skeleton.c:400
+#, c-format
+msgid "Pass %d"
msgstr ""
-#: ../display/d.rast.num/main.c:108 ../display/d.rast.arrow/main.c:164
-msgid "Align grids with raster cells"
+#: ../vector/v.voronoi/skeleton.c:509
+msgid "Node is outside any input area"
msgstr ""
-#: ../display/d.rast.num/main.c:112
-msgid "Get text color from cell color value"
-msgstr ""
+#: ../vector/v.voronoi/clean_topo.c:20
+msgid "Searching for topology errors..."
+msgstr "위상오류를 찾는 중..."
-#: ../display/d.rast.num/main.c:119 ../display/d.text/main.c:222
-#: ../display/d.vect/main.c:265 ../display/d.legend.vect/main.c:115
-#: ../display/d.legend/main.c:210 ../vector/v.label/main.c:122
-msgid "Font name"
-msgstr "글꼴이름"
+#: ../vector/v.voronoi/clean_topo.c:78
+msgid "Cleaning output topology"
+msgstr "출력 위상을 정리하는 중"
-#: ../display/d.rast.num/main.c:120 ../display/d.rast.num/main.c:127
-#: ../display/d.rast.num/main.c:135 ../display/d.text/main.c:223
-#: ../display/d.text/main.c:233 ../display/d.text/main.c:240
-#: ../display/d.text/main.c:248 ../display/d.text/main.c:273
-#: ../display/d.legend.vect/main.c:116 ../display/d.legend.vect/main.c:125
-#: ../display/d.legend.vect/main.c:132 ../display/d.legend.vect/main.c:148
-#: ../display/d.legend.vect/main.c:157 ../display/d.legend.vect/main.c:163
-#: ../display/d.legend/main.c:204 ../display/d.legend/main.c:211
-#: ../display/d.legend/main.c:220 ../display/d.legend/main.c:227
-#: ../display/d.legend/main.c:235
-msgid "Font settings"
-msgstr "글꼴설정"
+#: ../vector/v.voronoi/clean_topo.c:87 ../vector/v.in.ogr/main.c:1391
+#: ../vector/v.buffer/main.c:759
+msgid "Removing dangles..."
+msgstr "댕글을 지우는 중..."
-#: ../display/d.rast.num/main.c:125 ../display/d.text/main.c:238
-#: ../display/d.legend/main.c:225
-msgid "Path to font file"
-msgstr "글꼴파일의 경로"
+#: ../vector/v.voronoi/clean_topo.c:89 ../vector/v.in.ogr/main.c:1406
+#: ../vector/v.buffer/main.c:762
+msgid "Removing bridges..."
+msgstr "다리를 지우는 중..."
-#: ../display/d.rast.num/main.c:134 ../display/d.text/main.c:247
-#: ../display/d.legend/main.c:234
-msgid "Text encoding (only applicable to TrueType fonts)"
+#: ../vector/v.voronoi/clean_topo.c:115
+#, fuzzy
+msgid "Removing incorrect boundaries from output"
+msgstr "출력할 격자지도"
+#: ../vector/v.lrs/v.lrs.segment/main.c:72
+#: ../vector/v.lrs/v.lrs.label/main.c:103
+#: ../vector/v.lrs/v.lrs.create/main.c:122
+#: ../vector/v.lrs/v.lrs.where/main.c:58
+msgid "linear reference system"
msgstr ""
-#: ../display/d.rast.num/main.c:200
-#, fuzzy, c-format
-msgid "%d col"
-msgid_plural "%d cols"
-msgstr[0] "출력할 격자지도"
-msgstr[1] "출력할 격자지도"
-#. GTC %s will be replaced by strings "X rows" and "Y cols"
-#: ../display/d.rast.num/main.c:202
-#, c-format
+#: ../vector/v.lrs/v.lrs.segment/main.c:75
msgid ""
-"Current region size: %s X %s\n"
-"Your current region setting may be too large. Cells displayed on your "
-"graphics window may be too small for cell category number to be visible."
+"Creates points/segments from input lines, linear reference system and "
+"positions read from stdin or a file."
msgstr ""
-#: ../display/d.rast.num/main.c:212
-msgid "Aborting (region larger then 200 rows X 200 cols is not allowed)"
-msgstr ""
-#: ../display/d.info/main.c:38
+#: ../vector/v.lrs/v.lrs.segment/main.c:79
+#: ../vector/v.lrs/v.lrs.label/main.c:109
+#: ../vector/v.lrs/v.lrs.create/main.c:128
+#: ../vector/v.lrs/v.lrs.where/main.c:66
#, fuzzy
-msgid "Displays information about the active display monitor."
+msgid "Input vector map containing lines"
msgstr "출력할 격자지도"
-#: ../display/d.info/main.c:40
-msgid "Display monitors are maintained by d.mon."
+#: ../vector/v.lrs/v.lrs.segment/main.c:83
+msgid "Output vector map where segments will be written"
msgstr ""
-#: ../display/d.info/main.c:45
-msgid "Display screen rectangle (left, right, top, bottom)"
+#: ../vector/v.lrs/v.lrs.segment/main.c:88
+#: ../vector/v.lrs/v.lrs.label/main.c:118
+#: ../vector/v.lrs/v.lrs.create/main.c:147
+#: ../vector/v.lrs/v.lrs.where/main.c:75
+msgid "Line layer"
msgstr ""
-#: ../display/d.info/main.c:49
-msgid "Display screen dimensions (width, height)"
+#: ../vector/v.lrs/v.lrs.segment/main.c:94
+#: ../vector/v.lrs/v.lrs.label/main.c:124
+#: ../vector/v.lrs/v.lrs.create/main.c:207
+#: ../vector/v.lrs/v.lrs.where/main.c:86
+msgid "Driver name for reference system table"
msgstr ""
-#: ../display/d.info/main.c:53
-msgid "Display active frame rectangle"
+#: ../vector/v.lrs/v.lrs.segment/main.c:102
+#: ../vector/v.lrs/v.lrs.label/main.c:132
+#: ../vector/v.lrs/v.lrs.create/main.c:215
+#: ../vector/v.lrs/v.lrs.where/main.c:94
+msgid "Database name for reference system table"
msgstr ""
-#: ../display/d.info/main.c:57
-msgid "Display frame dimensions (width, height)"
+#: ../vector/v.lrs/v.lrs.segment/main.c:109
+#: ../vector/v.lrs/v.lrs.label/main.c:139
+#: ../vector/v.lrs/v.lrs.where/main.c:101
+msgid "Name of the reference system table"
msgstr ""
-#: ../display/d.info/main.c:61
-msgid "Display screen rectangle of current region"
+#: ../vector/v.lrs/v.lrs.segment/main.c:114
+msgid "Name of file containing segment rules. If not given, read from stdin."
msgstr ""
-#: ../display/d.info/main.c:66
-msgid "Display geographic coordinates and resolution of entire frame"
-msgstr ""
-#: ../display/d.vect.chart/plot.c:86 ../display/d.vect/attr.c:110
-#: ../vector/v.in.db/main.c:225
-#, fuzzy, c-format
-msgid "Unable to open select cursor: '%s'"
-msgstr "출력할 격자지도"
-#: ../display/d.vect.chart/main.c:65
+#: ../vector/v.lrs/v.lrs.segment/main.c:155
+#: ../vector/v.lrs/v.lrs.label/main.c:292
+#: ../vector/v.lrs/v.lrs.create/main.c:315
+#: ../vector/v.lrs/v.lrs.where/main.c:147
#, fuzzy
-msgid "chart maps"
+msgid "Unable to open database for reference table"
msgstr "출력할 격자지도"
-#: ../display/d.vect.chart/main.c:67
-msgid ""
-"Displays charts of vector data in the active frame on the graphics monitor."
+#: ../vector/v.lrs/v.lrs.segment/main.c:184
+#: ../vector/v.lrs/v.lrs.segment/main.c:238
+#, c-format
+msgid "Cannot read input: %s"
msgstr ""
-#: ../display/d.vect.chart/main.c:86
-msgid "Chart type"
+#: ../vector/v.lrs/v.lrs.segment/main.c:196
+#, c-format
+msgid "No record in LR table for: %s"
msgstr ""
-#: ../display/d.vect.chart/main.c:87 ../display/d.vect.chart/main.c:97
-#: ../display/d.vect.chart/main.c:105 ../display/d.vect.chart/main.c:112
-#: ../display/d.vect.chart/main.c:117 ../display/d.vect.chart/main.c:123
-#: ../display/d.vect.chart/main.c:129 ../display/d.vect.chart/main.c:148
-msgid "Chart properties"
+#: ../vector/v.lrs/v.lrs.segment/main.c:200
+#, c-format
+msgid "More than one record in LR table for: %s"
msgstr ""
-#: ../display/d.vect.chart/main.c:91
-msgid "Attribute columns containing data"
+#: ../vector/v.lrs/v.lrs.segment/main.c:207
+#: ../vector/v.lrs/v.lrs.segment/main.c:294
+#, fuzzy, c-format
+msgid "Unable to find line of cat [%d]"
+msgstr "출력할 격자지도"
+#: ../vector/v.lrs/v.lrs.segment/main.c:217
+#, c-format
+msgid ""
+"Cannot get point on line: cat = [%d] distance = [%f] (line length = %f)\n"
+"%s"
msgstr ""
-#: ../display/d.vect.chart/main.c:96
-msgid "Column used for pie chart size"
+#: ../vector/v.lrs/v.lrs.segment/main.c:253
+#, c-format
+msgid ""
+"No record in LRS table for 1. point of:\n"
+" %s"
msgstr ""
-#: ../display/d.vect.chart/main.c:104
-msgid "Size of chart (diameter for pie, total width for bar)"
+#: ../vector/v.lrs/v.lrs.segment/main.c:258
+#, c-format
+msgid ""
+"Using last from more offsets found for 1. point of:\n"
+" %s"
msgstr ""
-#: ../display/d.vect.chart/main.c:111
-msgid "Scale for size (to get size in pixels)"
+#: ../vector/v.lrs/v.lrs.segment/main.c:262
+#, c-format
+msgid ""
+"Requested offset for the 1. point not found, using nearest found:\n"
+" %s"
msgstr ""
-#: ../display/d.vect.chart/main.c:116
-msgid "Outline color"
+#: ../vector/v.lrs/v.lrs.segment/main.c:273
+#, c-format
+msgid ""
+"No record in LRS table for 2. point of:\n"
+" %s"
msgstr ""
-#: ../display/d.vect.chart/main.c:122
-msgid "Colors used to fill charts"
+#: ../vector/v.lrs/v.lrs.segment/main.c:278
+#, c-format
+msgid ""
+"Requested offset for the 2. point not found, using nearest found:\n"
+" %s"
msgstr ""
-#: ../display/d.vect.chart/main.c:128
-msgid "Center the bar chart around a data point"
+#: ../vector/v.lrs/v.lrs.segment/main.c:282
+#, c-format
+msgid ""
+"Using first from more offsets found for 2. point of:\n"
+" %s"
msgstr ""
-#: ../display/d.vect.chart/main.c:137
-msgid "Maximum value used for bar plot reference"
+#: ../vector/v.lrs/v.lrs.segment/main.c:287
+msgid "Segment over 2 (or more) segments, not yet supported"
msgstr ""
-#: ../display/d.vect.chart/main.c:142 ../display/d.vect.thematic/main.c:223
-msgid "Create legend information and send to stdout"
+#: ../vector/v.lrs/v.lrs.segment/main.c:304
+#, c-format
+msgid "End of segment > line length (%e) -> cut"
msgstr ""
-#: ../display/d.vect.chart/main.c:147
-#, fuzzy
-msgid "Create 3D charts"
-msgstr "출력할 격자지도"
-#: ../display/d.vect.thematic/main.c:87
-msgid "choropleth map"
+#: ../vector/v.lrs/v.lrs.segment/main.c:313
+#, c-format
+msgid ""
+"Cannot make line segment: cat = %d : %f - %f (line length = %f)\n"
+"%s"
msgstr ""
-#: ../display/d.vect.thematic/main.c:90
-#, fuzzy
-msgid "Displays a thematic vector map in the active graphics frame."
-msgstr "출력할 격자지도"
+#: ../vector/v.lrs/v.lrs.segment/main.c:356
+#: ../vector/v.lrs/v.lrs.where/main.c:222
+#, fuzzy, c-format
+msgid "[%d] point read from input"
+msgid_plural "[%d] points read from input"
-#: ../display/d.vect.thematic/main.c:97
-msgid "Layer number. If -1, all layers are displayed."
-msgstr ""
+#. GTC %s will be replaced with a message about lost points.
+#: ../vector/v.lrs/v.lrs.segment/main.c:363
+#, fuzzy, c-format
+msgid "[%d] point written to output map (%s)"
+msgid_plural "[%d] points written to output map (%s)"
-#: ../display/d.vect.thematic/main.c:103
-#, fuzzy
-msgid "Name of attribute column to be classified"
-msgstr "출력할 격자지도"
+#: ../vector/v.lrs/v.lrs.segment/main.c:368
+#, fuzzy, c-format
+msgid "[%d] line read from input"
+msgid_plural "[%d] lines read from input"
-#: ../display/d.vect.thematic/main.c:110
-msgid "Class breaks, without minimum and maximum"
+#. GTC %s will be replaced with a message about lost lines.
+#: ../vector/v.lrs/v.lrs.segment/main.c:375
+#, fuzzy, c-format
+msgid "[%d] line written to output map (%s)"
+msgid_plural "[%d] lines written to output map (%s)"
+#: ../vector/v.lrs/v.lrs.label/main.c:105
+msgid "Creates stationing from input lines, and linear reference system."
msgstr ""
-#: ../display/d.vect.thematic/main.c:111 ../display/d.vect.thematic/main.c:129
-#: ../display/d.vect.thematic/main.c:137
-msgid "Classes"
+#: ../vector/v.lrs/v.lrs.label/main.c:113
+msgid "Output vector map where stationing will be written"
msgstr ""
-#: ../display/d.vect.thematic/main.c:119 ../vector/v.class/main.c:68
-msgid "Algorithm to use for classification"
+#: ../vector/v.lrs/v.lrs.label/main.c:147
+msgid "Label file"
msgstr ""
-#: ../display/d.vect.thematic/main.c:123 ../vector/v.class/main.c:76
-msgid "simple intervals"
+#: ../vector/v.lrs/v.lrs.label/main.c:156
+msgid "PM left, MP right, stationing left, stationing right offset"
msgstr ""
-#: ../display/d.vect.thematic/main.c:124 ../vector/v.class/main.c:77
-msgid "standard deviations"
+#: ../vector/v.lrs/v.lrs.label/main.c:161
+msgid "Offset label in label x-direction in map units"
msgstr ""
-#: ../display/d.vect.thematic/main.c:125 ../vector/v.class/main.c:78
-#, fuzzy
-msgid "quantiles"
-msgstr "출력할 격자지도"
+#: ../vector/v.lrs/v.lrs.label/main.c:168
+msgid "Offset label in label y-direction in map units"
+msgstr ""
-#: ../display/d.vect.thematic/main.c:126 ../vector/v.class/main.c:79
-msgid "equiprobable (normal distribution)"
+#: ../vector/v.lrs/v.lrs.label/main.c:174 ../vector/v.label/main.c:113
+msgid "Reference position"
msgstr ""
-#: ../display/d.vect.thematic/main.c:136 ../vector/v.class/main.c:88
-msgid "Number of classes to define"
+#: ../vector/v.lrs/v.lrs.label/main.c:181 ../vector/v.label.sa/main.c:72
+#: ../vector/v.label.sa/main.c:80 ../vector/v.label/main.c:125
+#: ../vector/v.label/main.c:132 ../vector/v.label/main.c:140
+#: ../vector/v.label/main.c:148
+msgid "Font"
msgstr ""
-#: ../display/d.vect.thematic/main.c:144
-msgid "Colors (one per class)"
+#: ../vector/v.lrs/v.lrs.label/main.c:187 ../vector/v.label.sa/main.c:77
+#: ../vector/v.label/main.c:129
+msgid "Label size (in map-units)"
msgstr ""
-#: ../display/d.vect.thematic/main.c:154 ../display/d.vect.thematic/main.c:160
-#, fuzzy
-msgid "Boundaries"
-msgstr "출력할 격자지도"
-#: ../display/d.vect.thematic/main.c:155
-msgid "Boundary width"
+#: ../vector/v.lrs/v.lrs.label/main.c:197
+msgid "Line width of text"
msgstr ""
-#: ../display/d.vect.thematic/main.c:159
-msgid "Boundary color"
+#: ../vector/v.lrs/v.lrs.label/main.c:198
+#: ../vector/v.lrs/v.lrs.label/main.c:211
+msgid "Only for d.label output"
msgstr ""
-#: ../display/d.vect.thematic/main.c:168 ../display/d.vect.thematic/main.c:178
-#: ../display/d.vect/main.c:166 ../display/d.vect/main.c:176
-#: ../display/d.vect/main.c:183 ../display/d.vect/main.c:189
-#: ../display/d.vect/main.c:325
-msgid "Symbols"
+#: ../vector/v.lrs/v.lrs.label/main.c:205 ../vector/v.label.sa/main.c:107
+#: ../vector/v.label/main.c:174
+msgid "Highlight color for text"
msgstr ""
-#: ../display/d.vect.thematic/main.c:172 ../display/d.vect/main.c:170
-msgid "Point and centroid symbol"
+#: ../vector/v.lrs/v.lrs.label/main.c:210
+msgid "Line width of highlight color"
msgstr ""
-#: ../display/d.vect.thematic/main.c:179 ../display/d.vect/main.c:177
-#: ../display/d.legend.vect/main.c:88
-msgid "Symbol size"
+#: ../vector/v.lrs/v.lrs.label/main.c:228
+msgid "Opaque to vector"
msgstr ""
-#: ../display/d.vect.thematic/main.c:186 ../display/d.vect.thematic/main.c:197
-#: ../display/d.vect.thematic/main.c:206 ../display/d.vect.thematic/main.c:218
-#: ../display/d.vect.thematic/main.c:224 ../display/d.vect.thematic/main.c:229
-#: ../display/d.vect.thematic/main.c:239 ../display/d.vect.thematic/main.c:244
-#: ../display/d.vect/main.c:200 ../display/d.vect/main.c:210
-#: ../display/d.vect/main.c:218 ../display/d.vect/main.c:330
-msgid "Legend"
+#: ../vector/v.lrs/v.lrs.label/main.c:229
+msgid "Only relevant if background color is selected"
msgstr ""
-#: ../display/d.vect.thematic/main.c:190
-#, fuzzy
-msgid "Legend symbol for lines"
+#: ../vector/v.lrs/v.lrs.label/main.c:322
+#, fuzzy, c-format
+msgid "Unable to select records from LRS table: %s"
msgstr "출력할 격자지도"
-#: ../display/d.vect.thematic/main.c:201
-msgid "Legend symbol for areas"
+#: ../vector/v.lrs/v.lrs.label/main.c:412
+msgid "No record in LR table"
msgstr ""
-#: ../display/d.vect.thematic/main.c:207
+#: ../vector/v.lrs/v.lrs.label/main.c:416
+msgid "More than one record in LR table"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:124
#, fuzzy
-msgid "Thematic map title"
+msgid "Creates a linear reference system."
msgstr "출력할 격자지도"
-#: ../display/d.vect.thematic/main.c:214 ../display/d.vect.thematic/main.c:236
-msgid "DEPRECATED"
+#: ../vector/v.lrs/v.lrs.create/main.c:133
+msgid "Output vector map where oriented lines are written"
msgstr ""
-#: ../display/d.vect.thematic/main.c:215
+#: ../vector/v.lrs/v.lrs.create/main.c:138
#, fuzzy
-msgid "Output legend file"
+msgid "Output vector map of errors"
msgstr "출력할 격자지도"
-#: ../display/d.vect.thematic/main.c:228
+#: ../vector/v.lrs/v.lrs.create/main.c:143
#, fuzzy
-msgid "Do not draw map, only output the legend information"
+msgid "Input vector map containing reference points"
msgstr "출력할 격자지도"
-#: ../display/d.vect.thematic/main.c:237
-msgid ""
-"When printing legend info, include extended statistical info from "
-"classification algorithm"
+#: ../vector/v.lrs/v.lrs.create/main.c:151
+#: ../vector/v.lrs/v.lrs.where/main.c:80
+msgid "Point layer"
msgstr ""
-#: ../display/d.vect.thematic/main.c:243 ../display/d.vect/main.c:329
-msgid "Do not show this layer in vector legend"
+#: ../vector/v.lrs/v.lrs.create/main.c:158
+msgid "Column containing line identifiers for lines"
msgstr ""
-#: ../display/d.vect.thematic/main.c:255
-msgid ""
-"Flag -e is deprecated, set verbose mode with --v to get the extended "
-"statistical info."
+#: ../vector/v.lrs/v.lrs.create/main.c:165
+msgid "Column containing line identifiers for points"
msgstr ""
-#: ../display/d.vect.thematic/main.c:258
-msgid ""
-"Option legendfile is deprecated, either use flag -l to print legend to "
-"standard output, or set GRASS_LEGEND_FILE environment variable (see d.legend."
-"vect for details)."
+#: ../vector/v.lrs/v.lrs.create/main.c:173
+msgid "Column containing milepost position for the beginning of next segment"
msgstr ""
-#: ../display/d.vect.thematic/main.c:277
-#, fuzzy, c-format
-msgid "%s: You must build topology on vector map. Run v.build."
-msgstr "출력할 격자지도"
-#: ../display/d.vect.thematic/main.c:288
-msgid "'layer' must be > 0"
+#: ../vector/v.lrs/v.lrs.create/main.c:182
+msgid ""
+"Column containing offset from milepost for the beginning of next segment"
msgstr ""
-#: ../display/d.vect.thematic/main.c:290 ../display/d.vect/opt.c:143
-#: ../vector/v.db.connect/main.c:180
-msgid "Database connection not defined"
+#: ../vector/v.lrs/v.lrs.create/main.c:191
+msgid "Column containing milepost position for the end of previous segment"
msgstr ""
-#: ../display/d.vect.thematic/main.c:312
-#, c-format
-msgid "Data (%s) not numeric. Column must be numeric."
+#: ../vector/v.lrs/v.lrs.create/main.c:200
+msgid "Column containing offset from milepost for the end of previous segment"
msgstr ""
-#: ../display/d.vect.thematic/main.c:316
-#: ../display/d.vect.thematic/plot1.c:135
-#: ../display/d.vect.thematic/plot1.c:163
-#, c-format
-msgid "Cannot select data (%s) from table"
+#: ../vector/v.lrs/v.lrs.create/main.c:223
+msgid "Name of table where the reference system will be written"
msgstr ""
-#: ../display/d.vect.thematic/main.c:379
-#, c-format
-msgid "Unknown color: [%s]"
+#: ../vector/v.lrs/v.lrs.create/main.c:224
+msgid "New table is created by this module"
msgstr ""
-#: ../display/d.vect.thematic/main.c:390
-msgid ""
-"You gave both manual breaks and a classification algorithm or a number of "
-"classes. The manual breaks have precedence and will thus be used."
+#: ../vector/v.lrs/v.lrs.create/main.c:231
+msgid "Maximum distance of point to line allowed"
msgstr ""
-#: ../display/d.vect.thematic/main.c:427
-msgid "You must either give classbreaks or a classification algorithm"
+#: ../vector/v.lrs/v.lrs.create/main.c:286
+msgid "Cannot get layer info for lines"
msgstr ""
-#: ../display/d.vect.thematic/main.c:440
-#, c-format
-msgid ""
-"Not enough colors or error in color specifications.\n"
-"Need %i entries for 'colors' parameter"
+#: ../vector/v.lrs/v.lrs.create/main.c:289
+msgid "Cannot get layer info for points"
msgstr ""
-#: ../display/d.vect.thematic/main.c:445
+#: ../vector/v.lrs/v.lrs.create/main.c:327
#, fuzzy, c-format
-msgid "Error interpreting color %s"
+msgid "Unable to drop table: %s"
msgstr "출력할 격자지도"
-#: ../display/d.vect.thematic/main.c:462
-msgid "Plotting ..."
-msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:346
+#, fuzzy, c-format
+msgid "Unable to select line id values from %s.%s."
+msgstr "출력할 격자지도"
-#: ../display/d.vect.thematic/main.c:469
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn."
+#: ../vector/v.lrs/v.lrs.create/main.c:356
+msgid "Line id column must be integer"
msgstr ""
-#: ../display/d.vect.thematic/main.c:522
+#: ../vector/v.lrs/v.lrs.create/main.c:367
+#: ../vector/v.lrs/v.lrs.create/main.c:469
+#, fuzzy
+msgid "Unable to fetch line id from line table"
+msgstr "출력할 격자지도"
+#: ../vector/v.lrs/v.lrs.create/main.c:419
#, c-format
-msgid ""
-"\n"
-"Total number of records: %.0f\n"
+msgid "Line [%d] without category (layer [%d])"
msgstr ""
-#: ../display/d.vect.thematic/main.c:524
+#: ../vector/v.lrs/v.lrs.create/main.c:439
#, c-format
-msgid "Classification of %s into %i classes\n"
+msgid "No lines selected for line id [%d]"
msgstr ""
-#: ../display/d.vect.thematic/main.c:526 ../vector/v.class/main.c:203
+#: ../vector/v.lrs/v.lrs.create/main.c:459
+#, fuzzy, c-format
+msgid "Unable to select point attributes from <%s>"
+msgstr "출력할 격자지도"
+#: ../vector/v.lrs/v.lrs.create/main.c:490
#, c-format
-msgid "Using algorithm: *** %s ***\n"
+msgid "Milepost (start) %f+%f used as %f+%f (change MP to integer)"
msgstr ""
-#: ../display/d.vect.thematic/main.c:528 ../vector/v.class/main.c:204
+#: ../vector/v.lrs/v.lrs.create/main.c:512
#, c-format
-msgid "Mean: %f\tStandard deviation = %f\n"
+msgid "Milepost (end) %f+%f used as %f+%f (change MP to integer)"
msgstr ""
-#: ../display/d.vect.thematic/main.c:532
+#: ../vector/v.lrs/v.lrs.create/main.c:538
#, c-format
-msgid "Last chi2 = %f\n"
+msgid "Point [%d] without category (layer [%d])"
msgstr ""
-#: ../display/d.vect.thematic/main.c:534 ../vector/v.class/main.c:211
+#: ../vector/v.lrs/v.lrs.create/main.c:585
#, c-format
-msgid "Stdev multiplied by %.4f to define step\n"
+msgid "Point [%d] cat [%d] is out of threshold (distance = %f)"
msgstr ""
-#: ../display/d.vect.thematic/plot1.c:120
-#, fuzzy
-msgid "Color definition column not specified"
-msgstr "출력할 격자지도"
-#: ../display/d.vect.thematic/plot1.c:130
+#: ../vector/v.lrs/v.lrs.create/main.c:717
#, c-format
-msgid ""
-"Color definition column (%s) not a string. Column must be of form RRR:GGG:"
-"BBB where RGB values range 0-255."
+msgid "End > start for point cat [%d]"
msgstr ""
-#: ../display/d.vect.thematic/plot1.c:148
-msgid "Line width column not specified."
+#: ../vector/v.lrs/v.lrs.create/main.c:734
+msgid "Start of 1. MP >= end of 2. MP for points' cats %[d], [%d]"
msgstr ""
-#: ../display/d.vect.thematic/plot1.c:159
+#: ../vector/v.lrs/v.lrs.create/main.c:751
#, c-format
-msgid "Line width column (%s) not a number."
+msgid "Start of 1. MP >= start of 2. MP for points' cats [%d], [%d]"
msgstr ""
-#: ../display/d.vect.thematic/plot1.c:204
+#: ../vector/v.lrs/v.lrs.create/main.c:761
#, c-format
-msgid ""
-"\n"
-"ERROR: vector map - can't read\n"
+msgid "Distance along line identical for points' cats [%d], [%d]"
msgstr ""
-#: ../display/d.vect.thematic/plot1.c:279
+#: ../vector/v.lrs/v.lrs.create/main.c:775
#, c-format
-msgid ""
-"Error in color definition column (%s), element %d with cat %d: colorstring "
-"[%s]"
+msgid "Not enough points (%d) attached to the line (cat %d), line skip."
msgstr ""
-#: ../display/d.vect.thematic/plot1.c:286
+#: ../vector/v.lrs/v.lrs.create/main.c:780
#, c-format
-msgid "Error in color definition column (%s), element %d with cat %d"
+msgid "Unable to guess direction for the line (cat %d), line skip."
msgstr ""
-#: ../display/d.vect.thematic/plot1.c:354
+#: ../vector/v.lrs/v.lrs.create/main.c:784
#, c-format
-msgid ""
-"Error in line width column (%s), element %d with cat %d: line width [%d]"
+msgid "Incorrect order of points along line cat [%d]"
msgstr ""
-#: ../display/d.vect.thematic/display.c:51 ../display/d.vect/lines.c:107
-#: ../display/d.vect/lines.c:335
+#: ../vector/v.lrs/v.lrs.create/main.c:834
#, fuzzy, c-format
-msgid "Unable to read symbol <%s>, unable to display points"
+msgid "Unable to insert reference records: %s"
msgstr "출력할 격자지도"
-#: ../display/d.vect.thematic/display.c:118 ../display/d.vect/lines.c:175
-#, fuzzy, c-format
-msgid "%d point plotted"
-msgid_plural "%d points plotted"
+#: ../vector/v.lrs/v.lrs.create/main.c:875
+msgid "Building topology for output (out_lines) map..."
+msgstr "출력지도(out_lines)를 위한 위상을 생성하고 있습니다..."
-#: ../display/d.vect.thematic/display.c:121 ../display/d.vect/lines.c:177
-#, fuzzy, c-format
-msgid "%d line plotted"
-msgid_plural "%d lines plotted"
+#: ../vector/v.lrs/v.lrs.create/main.c:886
+msgid "Building topology for error (err) map..."
+msgstr "오류지도(err)를 위한 위상을 생성하고 있습니다..."
-#: ../display/d.vect.thematic/display.c:125 ../display/d.vect/lines.c:179
+#: ../vector/v.lrs/v.lrs.where/main.c:61
+msgid ""
+"Finds line id and real km+offset for given points in vector map using linear "
+"reference system."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:70
+#, fuzzy
+msgid "Input vector map containing points"
+msgstr "출력할 격자지도"
+#: ../vector/v.lrs/v.lrs.where/main.c:108
+msgid "Maximum distance to nearest line"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:225
#, fuzzy, c-format
-msgid "%d centroid plotted"
-msgid_plural "%d centroids plotted"
+msgid "[%d] position found"
+msgid_plural "[%d] positions found"
-#: ../display/d.vect.thematic/display.c:129 ../display/d.vect/lines.c:181
+#: ../vector/v.lrs/v.lrs.where/main.c:229
#, fuzzy, c-format
-msgid "%d boundary plotted"
-msgid_plural "%d boundaries plotted"
+msgid "[%d] point outside threshold"
+msgid_plural "[%d] points outside threshold"
-#: ../display/d.vect.thematic/display.c:132 ../display/d.vect/lines.c:183
+#: ../vector/v.lrs/v.lrs.where/main.c:233
#, fuzzy, c-format
-msgid "%d face plotted"
-msgid_plural "%d faces plotted"
+msgid "[%d] point - no record found"
+msgid_plural "[%d] points - no record found"
-#: ../display/d.barscale/main.c:65
-#, fuzzy
-msgid "Displays a barscale on the graphics monitor."
-msgstr "출력할 격자지도"
+#: ../vector/v.lrs/v.lrs.where/main.c:237
+#, c-format
+msgid "[%d] point - too many records found"
+msgid_plural "[%d] points - too many records found"
+msgstr[0] ""
-#: ../display/d.barscale/main.c:69
-msgid "Use feet/miles instead of meters"
+#: ../vector/v.in.region/main.c:43
+msgid "Creates a vector polygon from the current region extent."
msgstr ""
-#: ../display/d.barscale/main.c:73
-msgid "Draw the scale bar without text"
+#: ../vector/v.in.region/main.c:51
+msgid "Select type: line or area"
msgstr ""
-#: ../display/d.barscale/main.c:74 ../display/d.barscale/main.c:141
-#: ../display/d.barscale/main.c:166 ../display/d.barscale/main.c:183
-#: ../display/d.text/main.c:163 ../display/d.text/main.c:172
-#: ../display/d.text/main.c:181 ../display/d.text/main.c:189
-#: ../display/d.text/main.c:263 ../display/d.text/main.c:268
-#: ../display/d.northarrow/main.c:100 ../display/d.northarrow/main.c:130
-#: ../display/d.northarrow/main.c:135 ../display/d.northarrow/main.c:140
-msgid "Text"
+#: ../vector/v.in.region/main.c:58
+msgid "Densify lines using region resolution"
msgstr ""
-#: ../display/d.barscale/main.c:78
-#, fuzzy
-msgid "Display north-arrow symbol."
-msgstr "출력할 격자지도"
+#: ../vector/v.kernel/main.c:68
+#, c-format
+msgid "\tScore Value=%f\tsmoothing parameter (standard deviation)=%f"
+msgstr ""
-#: ../display/d.barscale/main.c:79 ../display/d.barscale/main.c:88
-#: ../display/d.barscale/main.c:149 ../display/d.northarrow/main.c:73
-msgid "Style"
+#: ../vector/v.kernel/main.c:110
+msgid "kernel density"
msgstr ""
-#: ../display/d.barscale/main.c:83
+#: ../vector/v.kernel/main.c:111
#, fuzzy
-msgid "Type of barscale to draw"
+msgid "point density"
msgstr "출력할 격자지도"
-#: ../display/d.barscale/main.c:102
-msgid "Classic style"
+#: ../vector/v.kernel/main.c:112
+msgid "heatmap"
msgstr ""
-#: ../display/d.barscale/main.c:103
-msgid "Line style"
+#: ../vector/v.kernel/main.c:113
+msgid "hotspot"
msgstr ""
-#: ../display/d.barscale/main.c:104
+#: ../vector/v.kernel/main.c:115
#, fuzzy
-msgid "Solid style"
+msgid "Generates a raster density map from vector points map."
msgstr "출력할 격자지도"
-#: ../display/d.barscale/main.c:105
-msgid "Hollow style"
+#: ../vector/v.kernel/main.c:116
+msgid ""
+"Density is computed using a moving kernel. Optionally generates a vector "
+"density map on a vector network."
msgstr ""
-#: ../display/d.barscale/main.c:106
+#: ../vector/v.kernel/main.c:120
#, fuzzy
-msgid "Full checker style"
+msgid "Name of input vector map with training points"
msgstr "출력할 격자지도"
-#: ../display/d.barscale/main.c:107
-msgid "Part checker style"
-msgstr ""
+#: ../vector/v.kernel/main.c:125
+#, fuzzy
+msgid "Name of input network vector map"
+msgstr "출력할 격자지도"
-#: ../display/d.barscale/main.c:108
-msgid "Mixed checker style"
+#: ../vector/v.kernel/main.c:128 ../vector/v.kernel/main.c:157
+#: ../vector/v.kernel/main.c:165 ../vector/v.kernel/main.c:187
+#: ../vector/v.kernel/main.c:212 ../vector/v.kernel/main.c:218
+msgid "Network"
msgstr ""
-#: ../display/d.barscale/main.c:109
-msgid "Tail checker style"
-msgstr ""
+#: ../vector/v.kernel/main.c:135
+#, fuzzy
+msgid "Name for output raster/vector map"
+msgstr "출력할 격자지도"
-#: ../display/d.barscale/main.c:110
-msgid "Up ticks style"
-msgstr ""
+#: ../vector/v.kernel/main.c:136
+#, fuzzy
+msgid "Outputs vector map if network map is given, otherwise raster map"
+msgstr "출력할 격자지도"
-#: ../display/d.barscale/main.c:111
-msgid "Down ticks style"
+#: ../vector/v.kernel/main.c:142
+msgid "Kernel radius in map units"
msgstr ""
-#: ../display/d.barscale/main.c:112
-msgid "Both ticks style"
+#: ../vector/v.kernel/main.c:148
+msgid "Discretization error in map units"
msgstr ""
-msgid "Arrow ends style"
+#: ../vector/v.kernel/main.c:155
+msgid "Maximum length of segment on network"
msgstr ""
-#: ../display/d.barscale/main.c:121 ../display/d.northarrow/main.c:83
-msgid "Screen coordinates of the rectangle's top-left corner"
+#: ../vector/v.kernel/main.c:163
+msgid "Maximum distance from point to network"
msgstr ""
-#: ../display/d.barscale/main.c:122 ../display/d.northarrow/main.c:84
-msgid "(0,0) is lower-left of the display frame"
+#: ../vector/v.kernel/main.c:171
+msgid "Multiply the density result by this number"
msgstr ""
-#: ../display/d.barscale/main.c:130
-msgid "Length of barscale in map units"
+#: ../vector/v.kernel/main.c:178
+msgid "Node method"
msgstr ""
-#: ../display/d.barscale/main.c:134
-#, fuzzy
-msgid "Barscale units to display"
-msgstr "출력할 격자지도"
-#: ../display/d.barscale/main.c:139
-msgid "Custom label of unit"
+#: ../vector/v.kernel/main.c:184
+msgid "No method applied at nodes with more than 2 arcs"
msgstr ""
-#: ../display/d.barscale/main.c:148
-#, fuzzy
-msgid "Number of segments"
-msgstr "출력할 격자지도"
-#: ../display/d.barscale/main.c:152
-#, fuzzy
-msgid "Bar scale and text color"
-msgstr "출력할 격자지도"
-#: ../display/d.barscale/main.c:158
-msgid "Background color (drawn behind the bar)"
+#: ../vector/v.kernel/main.c:185
+msgid "Equal split (Okabe 2009) applied at nodes"
msgstr ""
-#: ../display/d.barscale/main.c:163
-#, fuzzy
-msgid "Text position"
-msgstr "출력할 격자지도"
-#: ../display/d.barscale/main.c:174
-#, fuzzy
-msgid "Scale factor to change bar width"
-msgstr "출력할 격자지도"
-#: ../display/d.barscale/main.c:182 ../display/d.legend.vect/main.c:123
-#: ../display/d.northarrow/main.c:129 ../display/d.legend/main.c:218
-msgid "Font size"
-msgstr "글꼴크기"
-#: ../display/d.barscale/main.c:193
-#, c-format
-msgid "%s does not work with a latitude-longitude location"
+#: ../vector/v.kernel/main.c:193
+msgid "Kernel function"
msgstr ""
-#: ../display/d.barscale/main.c:237 ../display/d.barscale/main.c:254
-#: ../display/d.barscale/draw_scale.c:220
-msgid "Programmer error"
+#: ../vector/v.kernel/main.c:201
+msgid ""
+"Try to calculate an optimal radius with given 'radius' taken as maximum "
+"(experimental)"
msgstr ""
-#: ../display/d.barscale/draw_scale.c:611
-#: ../display/d.northarrow/draw_n_arrow.c:200
-#, c-format
-msgid "Could not read symbol \"%s\""
+#: ../vector/v.kernel/main.c:206
+msgid "Only calculate optimal radius and exit (no map is written)"
msgstr ""
-#: ../display/d.text/main.c:141
+#: ../vector/v.kernel/main.c:211
msgid ""
-"Draws text in the active display frame on the graphics monitor using the "
-"current font."
+"In network mode, normalize values by sum of density multiplied by length of "
+"each segment. Integral over the output map then gives 1.0 * mult"
msgstr ""
-#: ../display/d.text/main.c:147
-msgid "Text to display"
+#: ../vector/v.kernel/main.c:217
+msgid "In network mode, multiply the result by number of input points"
msgstr ""
-#: ../display/d.text/main.c:152
-msgid "Input file"
-msgstr "입력파일"
-#: ../display/d.text/main.c:161
-msgid "Text color, either a standard GRASS color or R:G:B triplet"
+#: ../vector/v.kernel/main.c:227 ../vector/v.in.lidar/main.c:540
+#, c-format
+msgid "Vector map <%s> already exists and will be overwritten"
msgstr ""
-#: ../display/d.text/main.c:170
-msgid "Text background color, either a standard GRASS color or R:G:B triplet"
+#: ../vector/v.kernel/main.c:257
+msgid "Unknown node method"
msgstr ""
-#: ../display/d.text/main.c:180 ../display/d.northarrow/main.c:92
-#: ../vector/v.label/main.c:156
-msgid "Rotation angle in degrees (counter-clockwise)"
+#: ../vector/v.kernel/main.c:275
+msgid "Unknown kernel function"
msgstr ""
-#: ../display/d.text/main.c:188
-msgid "Line spacing"
+#: ../vector/v.kernel/main.c:281
+msgid ""
+"Optimal standard deviation calculation is supported only for node method "
+"'none' and kernel function 'gaussian'."
msgstr ""
-#: ../display/d.text/main.c:197
+#: ../vector/v.kernel/main.c:285
msgid ""
-"Screen position at which text will begin to be drawn (percentage, [0,0] is "
-"lower left)"
+"Optimal standard deviation calculation is supported only for kernel function "
+"'gaussian'."
msgstr ""
-#: ../display/d.text/main.c:206
-msgid "The screen line number on which text will begin to be drawn"
+#: ../vector/v.kernel/main.c:302
+#, c-format
+msgid "Standard deviation: %f"
msgstr ""
-#: ../display/d.text/main.c:215
-msgid "Text alignment"
-msgstr ""
+#: ../vector/v.kernel/main.c:307
+#, fuzzy, c-format
+msgid "Output raster map: resolution: %f\t%s\t%s"
+msgstr "출력할 격자지도"
-#: ../display/d.text/main.c:232
-msgid "Height of letters in percentage of available frame height"
-msgstr ""
+#: ../vector/v.kernel/main.c:310
+#, fuzzy, c-format
+msgid "Output raster map resolution: %f"
+msgstr "출력할 격자지도"
-#: ../display/d.text/main.c:252
-msgid "Screen position in pixels ([0,0] is top left)"
-msgstr ""
+#: ../vector/v.kernel/main.c:358
+#, fuzzy, c-format
+msgid "%d point outside threshold"
+msgid_plural "%d points outside threshold"
-#: ../display/d.text/main.c:257
-msgid "Screen position in geographic coordinates"
+#: ../vector/v.kernel/main.c:381
+#, c-format
+msgid ""
+"Automatic choice of smoothing parameter (radius), maximum possible value of "
+"radius is set to %f"
msgstr ""
-#: ../display/d.text/main.c:262
-msgid "Use bold text"
-msgstr "굵은 글꼴을 씁니다"
-#: ../display/d.text/main.c:267 ../display/d.northarrow/main.c:144
-msgid "Use radians instead of degrees for rotation"
+#: ../vector/v.kernel/main.c:388
+#, c-format
+msgid "Using maximum distance between points: %f"
msgstr ""
-#: ../display/d.text/main.c:272
-msgid "Font size is height in pixels"
+#: ../vector/v.kernel/main.c:402
+#, c-format
+msgid "Number of input points: %d."
msgstr ""
-#: ../display/d.text/main.c:284
-msgid "Please choose only one placement method"
-msgstr ""
+#: ../vector/v.kernel/main.c:403
+#, fuzzy, c-format
+msgid "%d distance read from the map."
+msgid_plural "%d distances read from the map."
-#: ../display/d.text/main.c:343
-msgid "Invalid coordinates"
-msgstr ""
-#: ../display/d.text/main.c:387
+#: ../vector/v.kernel/main.c:408
#, c-format
msgid ""
-"\n"
-"Please enter text instructions. Enter EOF (ctrl-d) on last line to quit\n"
+"Distances between all points are beyond %e (4 * standard deviation), unable "
+"to calculate optimal value."
msgstr ""
-#: ../display/d.text/main.c:578
+#: ../vector/v.kernel/main.c:419
#, c-format
-msgid "[%s]: No such color. Use '%s'"
+msgid "Optimal smoothing parameter (standard deviation): %f."
msgstr ""
-#: ../display/d.rgb/main.c:58
-msgid ""
-"Displays three user-specified raster maps as red, green, and blue overlays "
-"in the active graphics frame."
+#: ../vector/v.kernel/main.c:450
+#, c-format
+msgid "Writing output vector map using smooth parameter %f"
msgstr ""
-#: ../display/d.rgb/main.c:63 ../display/d.rast/main.c:81
-msgid "Make null cells opaque"
+#: ../vector/v.kernel/main.c:452 ../vector/v.kernel/main.c:562
+#, c-format
+msgid "Normalising factor %f"
msgstr ""
-#: ../display/d.rgb/main.c:64 ../display/d.rast/main.c:77
-#: ../display/d.rast/main.c:82
-msgid "Null cells"
-msgstr ""
+#: ../vector/v.kernel/main.c:560
+#, fuzzy, c-format
+msgid "Writing output raster map using smooth parameter %f"
+msgstr "출력할 격자지도"
-#: ../display/d.labels/do_labels.c:142
+#: ../vector/v.kernel/main.c:612
#, c-format
-msgid "Error: %s\n"
+msgid "Maximum value in output: %e."
msgstr ""
-#: ../display/d.labels/main.c:44 ../vector/v.label.sa/main.c:39
-#: ../vector/v.label/main.c:60
-msgid "paint labels"
-msgstr ""
+#: ../vector/v.to.rast3/main.c:51
+#, fuzzy
+msgid "Converts a vector map (only points) into a 3D raster map."
+msgstr "출력할 격자지도"
-#: ../display/d.labels/main.c:46
-msgid ""
-"Displays text labels (created with v.label) to the active frame on the "
-"graphics monitor."
-msgstr ""
+#: ../vector/v.to.rast3/main.c:62
+#, fuzzy
+msgid "Name of attribute column (data type must be numeric)"
+msgstr "출력할 격자지도"
-#: ../display/d.labels/main.c:52
-msgid "Ignore rotation setting and draw horizontally"
-msgstr ""
+#: ../vector/v.to.rast3/main.c:107
+#, fuzzy
+msgid "Unable to create output map"
+msgstr "출력할 격자지도"
-#: ../display/d.labels/main.c:59
-msgid "Name of label file"
+#: ../vector/v.to.rast3/main.c:145 ../vector/v.to.rast/do_lines.c:59
+#: ../vector/v.to.rast/do_lines.c:67
+#, c-format
+msgid "No record for line (cat = %d)"
msgstr ""
-#: ../display/d.labels/main.c:66
-msgid "Minimum region size (diagonal) when labels are displayed"
-msgstr ""
+#: ../vector/v.to.rast3/main.c:157
+#, fuzzy
+msgid "Unable to close new 3d raster map"
+msgstr "출력할 격자지도"
-#: ../display/d.labels/main.c:73
-msgid "Maximum region size (diagonal) when labels are displayed"
+#: ../vector/v.out.ogr/attrb.c:65
+#, c-format
+msgid "No database record for cat = %d and export of 'cat' disabled"
msgstr ""
-#: ../display/d.labels/main.c:85
-#, fuzzy, c-format
-msgid "Label file <%s> not found"
+#: ../vector/v.out.ogr/args.c:9
+#, fuzzy
+msgid "Name of input vector map to export"
msgstr "출력할 격자지도"
-#: ../display/d.labels/main.c:97
-msgid "Region size is lower than minreg, nothing displayed."
-msgstr ""
+#: ../vector/v.out.ogr/args.c:18
+#, fuzzy
+msgid "Feature type(s)"
+msgstr "출력할 격자지도"
-#: ../display/d.labels/main.c:105
-msgid "Region size is greater than maxreg, nothing displayed."
+#: ../vector/v.out.ogr/args.c:20
+msgid ""
+"Combination of types is not supported by all output formats. Default is to "
+"use first type found in input vector map."
msgstr ""
-#: ../display/d.labels/main.c:114 ../vector/v.lrs/v.lrs.label/main.c:283
-#, fuzzy, c-format
-msgid "Unable to open label file <%s>"
+#: ../vector/v.out.ogr/args.c:28
+#, fuzzy
+msgid "Name of output OGR datasource"
msgstr "출력할 격자지도"
-#: ../display/d.linegraph/main.c:232
+#: ../vector/v.out.ogr/args.c:30
msgid ""
-"Generates and displays simple line graphs in the active graphics monitor "
-"display frame."
+"For example: ESRI Shapefile: filename or directory for storage\n"
+"\t\t\tPostGIS database: connection string"
msgstr ""
-#: ../display/d.linegraph/main.c:236
-msgid "Name of data file for X axis of graph"
+#: ../vector/v.out.ogr/args.c:40
+#, fuzzy
+msgid "Data format to write"
+msgstr "출력할 격자지도"
+#: ../vector/v.out.ogr/args.c:47
+msgid "Name for output OGR layer. If not specified, input name is used"
msgstr ""
-#: ../display/d.linegraph/main.c:242
-msgid "Name of data file(s) for Y axis of graph"
+#: ../vector/v.out.ogr/args.c:49
+msgid ""
+"For example: ESRI Shapefile: shapefile name\n"
+"\t\t\tPostGIS database: table name"
msgstr ""
-#: ../display/d.linegraph/main.c:249
+#: ../vector/v.out.ogr/args.c:57
+msgid "Optionally change default output type"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:60
#, fuzzy
-msgid "Path to files"
-msgstr "글꼴파일의 경로"
+msgid "export area boundaries as linestrings"
+msgstr "출력할 격자지도"
-#: ../display/d.linegraph/main.c:251
-msgid "Path to the directory where the input files are located"
+#: ../vector/v.out.ogr/args.c:61
+#, fuzzy
+msgid "export lines as polygons"
+msgstr "출력할 격자지도"
+#: ../vector/v.out.ogr/args.c:71
+msgid "OGR dataset creation option (format specific, NAME=VALUE)"
msgstr ""
-#: ../display/d.linegraph/main.c:259
-msgid "Color for Y data"
+#: ../vector/v.out.ogr/args.c:81
+msgid "OGR layer creation option (format specific, NAME=VALUE)"
msgstr ""
-#: ../display/d.linegraph/main.c:272
+#: ../vector/v.out.ogr/args.c:86
+msgid "Open an existing OGR datasource for update"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:90
+msgid "Append to existing layer"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:91
#, fuzzy
-msgid "Width of the lines"
+msgid "A new OGR layer is created if it does not exist"
msgstr "출력할 격자지도"
-#: ../display/d.linegraph/main.c:279
-msgid "Color for axis, tics, numbers, and title"
+#: ../vector/v.out.ogr/args.c:96
+msgid "Skip export of GRASS category ID ('cat') attribute"
msgstr ""
-#: ../display/d.linegraph/main.c:287
-msgid "Title for X data"
+#: ../vector/v.out.ogr/args.c:102
+msgid ""
+"Also export features without category (not labeled). Otherwise only features "
+"with category are exported."
msgstr ""
-#: ../display/d.linegraph/main.c:294
-msgid "Title for Y data"
+#: ../vector/v.out.ogr/args.c:108
+msgid "Use ESRI-style .prj file format (applies to Shapefile output only)"
msgstr ""
-#: ../display/d.linegraph/main.c:301
-msgid "Title for Graph"
+#: ../vector/v.out.ogr/args.c:114
+msgid "Force 2D output even if input is 3D (applies to Shapefile output only)"
msgstr ""
-#: ../display/d.linegraph/main.c:308
-msgid "Minimum and maximun value for Y axis (min,max)"
+#: ../vector/v.out.ogr/args.c:116 ../vector/v.out.postgis/args.c:78
+#: ../vector/v.in.ogr/main.c:275
+msgid "Useful if input is 3D but all z coordinates are identical"
msgstr ""
-#: ../display/d.linegraph/main.c:315
-msgid "Tic values for the Y axis"
+#: ../vector/v.out.ogr/args.c:122
+msgid "Export vector data as multi-features"
msgstr ""
-#: ../display/d.linegraph/main.c:329
+#: ../vector/v.out.ogr/args.c:128
+msgid ""
+"Create a new empty layer in defined OGR datasource and exit. Nothing is read "
+"from input."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:86
#, fuzzy
-msgid "Symbol for point"
+msgid "Exports a vector map layer to any of the supported OGR vector formats."
msgstr "출력할 격자지도"
-#: ../display/d.linegraph/main.c:338
-#, fuzzy
-msgid "Point size"
-msgstr "글꼴크기"
-#: ../display/d.linegraph/main.c:347
-msgid "Color for point symbol edge color"
+#: ../vector/v.out.ogr/main.c:87
+msgid "By default a vector map layer is exported to Esri Shapefile format."
msgstr ""
-#: ../display/d.linegraph/main.c:353
-msgid "Width of point symbol lines"
+#: ../vector/v.out.ogr/main.c:96 ../vector/v.external.out/link.c:26
+#, c-format
+msgid ""
+"Data source starts with \"PG:\" prefix, expecting \"PostgreSQL\" format (\"%s"
+"\" given)"
msgstr ""
-#: ../display/d.linegraph/main.c:412
-msgid "Maximum of 10 Y data files exceeded"
+#: ../vector/v.out.ogr/main.c:164
+msgid "Volumes will be exported as sets of faces"
msgstr ""
-#: ../display/d.linegraph/main.c:445
-#, fuzzy, c-format
-msgid "Cannot find/open symbol: '%s'"
+#: ../vector/v.out.ogr/main.c:182
+#, fuzzy
+msgid "Unable to determine input map's vector feature type(s)."
msgstr "출력할 격자지도"
-#: ../display/d.linegraph/main.c:458
+#: ../vector/v.out.ogr/main.c:197
#, c-format
-msgid "Color <%s> cannot for option %s be parsed"
+msgid "Appending to OGR layer requires option '%s'"
msgstr ""
-#: ../display/d.linegraph/main.c:495
-#, c-format
-msgid "Only <%d> colors given for <%d> lines"
+#: ../vector/v.out.ogr/main.c:252
+msgid "The combination of types is not supported by all formats."
msgstr ""
-#: ../display/d.linegraph/main.c:538
+#: ../vector/v.out.ogr/main.c:276
+#, fuzzy, c-format
+msgid "Unknown EPSG code %s"
+msgstr "출력할 격자지도"
+#: ../vector/v.out.ogr/main.c:294
#, c-format
-msgid "Number of widths (%d) is higher then the number of files (%d)"
+msgid "OGR layer <%s> created in datasource <%s> (format '%s')"
msgstr ""
-#: ../display/d.linegraph/main.c:550
-#, c-format
-msgid "Number of widths (%d) is lower then the number of files (%d)"
+#: ../vector/v.out.ogr/main.c:306
+msgid ""
+"The map contains islands. With the -c flag, islands will appear as filled "
+"areas, not holes in the output map."
msgstr ""
-#: ../display/d.linegraph/main.c:601
+#: ../vector/v.out.ogr/main.c:312
#, c-format
-msgid "Y input file <%s> contains fewer data points than the X input file"
-msgstr ""
+msgid ""
+"%d point found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d points found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
-#: ../display/d.linegraph/main.c:605
+#: ../vector/v.out.ogr/main.c:320
#, c-format
-msgid "Y input file <%s> contains more data points than the X input file"
-msgstr ""
+msgid ""
+"%d line found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
-#: ../display/d.linegraph/main.c:610
+#: ../vector/v.out.ogr/main.c:329
#, c-format
-msgid "The last point will be ignored"
-msgid_plural "The last %d points will be ignored"
+msgid ""
+"%d boundary found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d boundaries found, but not requested to be exported. Verify 'type' "
+"parameter."
msgstr[0] ""
-msgstr[1] ""
-#: ../display/d.linegraph/main.c:688
+#: ../vector/v.out.ogr/main.c:338
#, c-format
-msgid "Problem reading X data file at line %d"
-msgstr ""
+msgid ""
+"%d centroid found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d centroids found, but not requested to be exported. Verify 'type' "
+"parameter."
+msgstr[0] ""
-#: ../display/d.linegraph/main.c:698
+#: ../vector/v.out.ogr/main.c:346
#, c-format
-msgid "Problem reading <%s> data file at line %d"
-msgstr ""
+msgid ""
+"%d area found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d areas found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
-#: ../display/d.rast.arrow/main.c:101
+#: ../vector/v.out.ogr/main.c:354
+#, c-format
msgid ""
-"Draws arrows representing cell aspect direction for a raster map containing "
-"aspect data."
-msgstr ""
+"%d face found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d faces found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
-#: ../display/d.rast.arrow/main.c:105
-msgid "Name of raster aspect map to be displayed"
-msgstr ""
+#: ../vector/v.out.ogr/main.c:362
+#, c-format
+msgid ""
+"%d volume found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d volumes found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
-#: ../display/d.rast.arrow/main.c:113
-msgid "Type of existing raster aspect map"
+#: ../vector/v.out.ogr/main.c:372
+msgid ""
+"No points found, but requested to be exported. Will skip this feature type."
msgstr ""
-#: ../display/d.rast.arrow/main.c:118
-msgid "Color for drawing arrows"
+#: ../vector/v.out.ogr/main.c:381
+msgid ""
+"No lines found, but requested to be exported. Will skip this feature type."
msgstr ""
-#: ../display/d.rast.arrow/main.c:124
-msgid "Color for drawing drawing grid"
+#: ../vector/v.out.ogr/main.c:391
+msgid ""
+"No boundaries found, but requested to be exported. Will skip this feature "
+"type."
msgstr ""
-#: ../display/d.rast.arrow/main.c:130
-msgid "Color for drawing null values (X symbol)"
+#: ../vector/v.out.ogr/main.c:400
+msgid ""
+"No areas found, but requested to be exported. Will skip this feature type."
msgstr ""
-#: ../display/d.rast.arrow/main.c:136
-msgid "Color for showing unknown information (? symbol)"
+#: ../vector/v.out.ogr/main.c:410
+msgid ""
+"No centroids found, but requested to be exported. Will skip this feature "
+"type."
msgstr ""
-#: ../display/d.rast.arrow/main.c:144
-msgid "Draw arrow every Nth grid cell"
+#: ../vector/v.out.ogr/main.c:419
+msgid ""
+"No faces found, but requested to be exported. Will skip this feature type."
msgstr ""
-#: ../display/d.rast.arrow/main.c:153
-msgid "Raster map containing values used for arrow length"
+#: ../vector/v.out.ogr/main.c:428
+msgid ""
+"No kernels found, but requested to be exported. Will skip this feature type."
msgstr ""
-#: ../display/d.rast.arrow/main.c:160
-msgid "Scale factor for arrows (magnitude map)"
+#: ../vector/v.out.ogr/main.c:437
+msgid ""
+"No volumes found, but requested to be exported. Will skip this feature type."
msgstr ""
-#: ../display/d.rast.arrow/main.c:210
-msgid "Illegal value for scale factor"
-msgstr ""
+#: ../vector/v.out.ogr/main.c:462
+#, fuzzy, c-format
+msgid "OGR driver <%s> not found"
+msgstr "출력할 격자지도"
-#: ../display/d.rast.arrow/main.c:214
-msgid "Illegal value for skip factor"
-msgstr ""
+#: ../vector/v.out.ogr/main.c:489
+#, fuzzy, c-format
+msgid "Unable to open OGR data source '%s'"
+msgstr "출력할 격자지도"
-#: ../display/d.rast.arrow/main.c:219
-msgid "Magnitude is only supported for GRASS and compass aspect maps."
-msgstr ""
+#: ../vector/v.out.ogr/main.c:503
+#, fuzzy, c-format
+msgid "Layer <%s> already exists in OGR data source '%s'"
+msgstr "출력할 격자지도"
-#: ../display/d.rast.arrow/main.c:224
-msgid "Scale option requires magnitude_map"
-msgstr ""
+#: ../vector/v.out.ogr/main.c:507
+#, fuzzy, c-format
+msgid "OGR layer <%s> already exists and will be overwritten"
+msgstr "출력할 격자지도"
-#: ../display/d.rast.arrow/main.c:275
-#, fuzzy
-msgid "Problem reading range file"
+#: ../vector/v.out.ogr/main.c:514
+#, fuzzy, c-format
+msgid "OGR layer <%s> doesn't exists, creating new OGR layer instead"
msgstr "출력할 격자지도"
-#: ../display/d.rhumbline/main.c:46
-msgid "rhumbline"
+#: ../vector/v.out.ogr/main.c:542
+msgid "Overriding existing user-defined 'SHPT=' LCO."
msgstr ""
-#: ../display/d.rhumbline/main.c:48
-msgid "Displays the rhumbline joining two longitude/latitude coordinates."
+#: ../vector/v.out.ogr/main.c:557
+#, c-format
+msgid ""
+"Vector map <%s> is 3D. Use format specific layer creation options SHPT "
+"(parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
msgstr ""
-#: ../display/d.rhumbline/main.c:53 ../display/d.geodesic/main.c:58
-#: ../display/d.path/main.c:65
-msgid "Starting and ending coordinates"
+#: ../vector/v.out.ogr/main.c:569
+#, c-format
+msgid ""
+"Vector map <%s> is 3D. Use format specific layer creation options DIM "
+"(parameter 'lco') to export in 3D rather than 2D (default)."
msgstr ""
-#: ../display/d.rhumbline/main.c:57 ../display/d.northarrow/main.c:103
-#: ../display/d.geodesic/main.c:62
-msgid "Line color"
+#: ../vector/v.out.ogr/main.c:576
+#, c-format
+msgid ""
+"Vector map <%s> is 3D. Use format specific layer creation options (parameter "
+"'lco') to export <in 3D rather than 2D (default)."
msgstr ""
-#: ../display/d.rhumbline/main.c:75 ../display/d.geodesic/main.c:78
+#: ../vector/v.out.ogr/main.c:593 ../db/drivers/ogr/execute.c:56
#, fuzzy, c-format
-msgid "Location is not %s"
+msgid "OGR layer <%s> not found"
msgstr "출력할 격자지도"
-#: ../display/d.rhumbline/main.c:86 ../display/d.geodesic/main.c:87
-#: ../display/d.path/main.c:140
-msgid "No coordinates given"
-msgstr ""
-#: ../display/d.rhumbline/main.c:89 ../display/d.rhumbline/main.c:92
-#: ../display/d.rhumbline/main.c:95 ../display/d.rhumbline/main.c:98
-#: ../display/d.geodesic/main.c:90 ../display/d.geodesic/main.c:93
-#: ../display/d.geodesic/main.c:96 ../display/d.geodesic/main.c:99
-#, fuzzy, c-format
-msgid "%s - illegal longitude"
+#: ../vector/v.out.ogr/main.c:595
+#, fuzzy
+msgid "Unable to create OGR layer"
msgstr "출력할 격자지도"
-#: ../display/d.extract/extract.c:43
-msgid "Select vector(s) with mouse"
+#: ../vector/v.out.ogr/main.c:607
+msgid "No attribute table found -> using only category numbers as attributes"
msgstr ""
-#: ../display/d.extract/extract.c:44
-msgid " - L: draw box with left mouse button to select"
+#: ../vector/v.out.ogr/main.c:611
+msgid "Exporting 'cat' anyway, as it is the only attribute table field"
msgstr ""
-#: ../display/d.extract/extract.c:45
-msgid " - M: draw box with middle mouse button to remove from display"
-msgstr ""
+#: ../vector/v.out.ogr/main.c:620 ../vector/v.out.ogr/main.c:692
+#, fuzzy, c-format
+msgid "New attribute column <%s> added to the table"
+msgstr "출력할 격자지도"
-#: ../display/d.extract/extract.c:46
-msgid " - R: quit and save selected vectors to new map\n"
-msgstr ""
+#: ../vector/v.out.ogr/main.c:704
+#, fuzzy, c-format
+msgid "Key column <%s> not found"
+msgstr "출력할 격자지도"
-#: ../display/d.extract/extract.c:48
-msgid "L: add M: remove R: quit and save\n"
-msgstr ""
+#: ../vector/v.out.ogr/main.c:717
+#, fuzzy, c-format
+msgid "Exporting %d feature..."
+msgid_plural "Exporting %d features..."
+msgstr[0] "출력할 격자지도"
-#: ../display/d.extract/main.c:52
-msgid "Selects and extracts vectors with mouse into new vector map."
-msgstr ""
+#: ../vector/v.out.ogr/main.c:732
+#, fuzzy, c-format
+msgid "Exporting %d area (may take some time)..."
+msgid_plural "Exporting %d areas (may take some time)..."
-#: ../display/d.extract/main.c:65 ../display/d.path/main.c:99
-msgid "Original line color"
-msgstr ""
+#: ../vector/v.out.ogr/main.c:751
+#, fuzzy, c-format
+msgid "Exporting %d volume..."
+msgid_plural "Exporting %d volumes..."
-#: ../display/d.extract/main.c:71 ../display/d.path/main.c:107
-msgid "Highlight color"
+#: ../vector/v.out.ogr/main.c:755
+msgid "Export of volumes not implemented yet. Skipping."
msgstr ""
-#: ../display/d.extract/main.c:79 ../vector/v.label/main.c:233
-msgid "No graphics device selected"
-msgstr ""
+#: ../vector/v.out.ogr/main.c:772
+#, fuzzy, c-format
+msgid "%d feature without attributes was written"
+msgid_plural "%d features without attributes were written"
-#: ../display/d.extract/main.c:122
-#, fuzzy
-msgid "Copying tables..."
-msgstr "출력할 격자지도"
+#: ../vector/v.out.ogr/main.c:778
+#, fuzzy, c-format
+msgid "%d feature without category was written"
+msgid_plural "%d features without category were written"
-#: ../display/d.extract/main.c:130
-msgid "Cannot get db link info -> cannot copy table."
-msgstr ""
-#: ../display/d.vect/zcoor.c:19
-#, fuzzy
-msgid "Vector map is not 3D. Unable to display z-coordinates."
-msgstr "출력할 격자지도"
-#: ../display/d.vect/topo.c:18
+#: ../vector/v.out.ogr/main.c:782
+#, c-format
msgid ""
-"Unable to display topology, not available.Please try to rebuild topology "
-"using v.build or v.build.all."
-msgstr ""
+"%d feature without category was skipped. Features without category are "
+"written only when -%c flag is given."
+msgid_plural ""
+"%d features without category were skipped. Features without category are "
+msgstr[0] ""
-#: ../display/d.vect/shape.c:53
-#, c-format
-msgid "Both color table and <%s> option detected. Color table will ignored."
+#: ../vector/v.out.ogr/main.c:798
+msgid "Output layer is empty, no features written"
msgstr ""
-#: ../display/d.vect/shape.c:68
-#, c-format
-msgid ""
-"Color definition column ('%s') not a string. Column must be of form 'RRR:GGG:"
-"BBB' where RGB values range 0-255. You can use '%s' module to define color "
-"rules. Unable to colorize features."
-msgstr ""
+#: ../vector/v.out.ogr/main.c:799
+#, fuzzy, c-format
+msgid "%d feature (%s type) written to <%s> (%s format)."
+msgid_plural "%d features (%s type) written to <%s> (%s format)."
-#: ../display/d.vect/shape.c:77 ../display/d.vect/shape.c:100
-#: ../display/d.vect/shape.c:131 ../display/d.vect/shape.c:162
+#: ../vector/v.out.ogr/export_areas.c:143
+#: ../vector/v.out.ogr/export_lines.c:178
#, fuzzy, c-format
-msgid "Unable to select data ('%s') from table"
+msgid "Unable to export multi-features. No category index for layer %d."
msgstr "출력할 격자지도"
-#: ../display/d.vect/shape.c:85
+#: ../vector/v.out.ogr/export_areas.c:154
#, fuzzy
-msgid "Line width column not specified"
+msgid "Exporting features with category..."
msgstr "출력할 격자지도"
-#: ../display/d.vect/shape.c:96
+#: ../vector/v.out.ogr/export_areas.c:176
+#: ../vector/v.out.ogr/export_lines.c:212
#, fuzzy, c-format
-msgid "Line width column ('%s') not a number"
+msgid ""
+"Unable to create multi-feature. Category %d not found in line %d, field %d"
msgstr "출력할 격자지도"
-#: ../display/d.vect/shape.c:116
+#: ../vector/v.out.ogr/export_areas.c:214
#, fuzzy
-msgid "Symbol size column not specified"
+msgid "Exporting features without category..."
msgstr "출력할 격자지도"
-#: ../display/d.vect/shape.c:127
+#: ../vector/v.out.ogr/create.c:20
#, fuzzy, c-format
-msgid "Symbol size column ('%s') is not numeric"
+msgid "OGR driver <%s> not available"
msgstr "출력할 격자지도"
-#: ../display/d.vect/shape.c:147
-#, fuzzy
-msgid "Symbol rotation column not specified"
-msgstr "출력할 격자지도"
-#: ../display/d.vect/shape.c:158
+#: ../vector/v.out.ogr/create.c:26
#, fuzzy, c-format
-msgid "Symbol rotation column ('%s') is not numeric"
+msgid "Creation of output OGR datasource <%s> failed"
msgstr "출력할 격자지도"
-#: ../display/d.vect/shape.c:182
-msgid ""
-"Vector map is not 3D. Unable to colorize features based on z-coordinates."
+#: ../vector/v.out.ogr/create.c:36
+#, c-format
+msgid "Creation of OGR layer <%s> failed"
msgstr ""
-#: ../display/d.vect/shape.c:186
-#, fuzzy, c-format
-msgid "%s= and %s= are mutually exclusive. %s= will be ignored."
-msgstr "%s=와 %s=를 같이 지정할 수 없습니다"
+#: ../vector/v.type/main.c:44
+msgid "Changes type of vector features."
+msgstr ""
-#: ../display/d.vect/shape.c:329
-#, fuzzy, c-format
-msgid "Invalid negative value - feature %d with category %d"
-msgstr "출력할 격자지도"
+#: ../vector/v.type/main.c:57
+msgid "Feature type to convert from"
+msgstr ""
-#: ../display/d.vect/main.c:76
-msgid "Displays user-specified vector map in the active graphics frame."
+#: ../vector/v.type/main.c:65
+msgid "Feature type to convert to"
msgstr ""
-#: ../display/d.vect/main.c:92
-msgid "Display"
+#: ../vector/v.type/main.c:120
+msgid "Incompatible types"
msgstr ""
-#: ../display/d.vect/main.c:96
-#, fuzzy
-msgid "Display geometry of features"
-msgstr "출력할 격자지도"
+#: ../vector/v.net.timetable/main.c:218
+#, c-format
+msgid "Could not find a path between stops %d and %d"
+msgstr ""
-#: ../display/d.vect/main.c:97
-msgid "Display category numbers of features"
+#: ../vector/v.net.timetable/main.c:263
+msgid "Finds shortest path using timetables."
msgstr ""
-#: ../display/d.vect/main.c:98
-msgid "Display topology information (nodes, edges)"
+#: ../vector/v.net.timetable/main.c:309
+msgid "Layer number or name with walking connections or -1"
msgstr ""
-#: ../display/d.vect/main.c:99
+#: ../vector/v.net.timetable/main.c:315
#, fuzzy
-msgid "Display vertices of features"
+msgid "Name of column with route ids"
msgstr "출력할 격자지도"
-#: ../display/d.vect/main.c:100
-msgid "Display direction of linear features"
-msgstr ""
-#: ../display/d.vect/main.c:101
-msgid "Display z-coordinate of features (only for 3D vector maps)"
-msgstr ""
-#: ../display/d.vect/main.c:119
+#: ../vector/v.net.timetable/main.c:322
#, fuzzy
-msgid "Feature color"
+msgid "Name of column with stop timestamps"
msgstr "출력할 격자지도"
-#: ../display/d.vect/main.c:125
-msgid "Area fill color"
-msgstr ""
-#: ../display/d.vect/main.c:131
+#: ../vector/v.net.timetable/main.c:328
#, fuzzy
-msgid "Colorize features according color definition column"
+msgid "Name of column with stop ids"
msgstr "출력할 격자지도"
-#: ../display/d.vect/main.c:132 ../vector/v.out.lidar/main.c:544
+#: ../vector/v.net.timetable/main.c:334
#, fuzzy
-msgid "Color definition in R:G:B form"
+msgid "Name of column with walk lengths"
msgstr "출력할 격자지도"
-#: ../display/d.vect/main.c:136
-msgid "Colorize point or area features according to z-coordinate"
+#: ../vector/v.net.timetable/main.c:381
+msgid "Could not initialize the timetables"
msgstr ""
-#: ../display/d.vect/main.c:144 ../display/d.vect/main.c:149
-#: ../display/d.vect/main.c:157
-msgid "Lines"
+#: ../vector/v.net.timetable/main.c:459 ../vector/v.net.timetable/main.c:490
+#: ../vector/v.net.timetable/main.c:498
+#, c-format
+msgid "No stop with category: %d"
msgstr ""
-#: ../display/d.vect/main.c:145 ../display/d.northarrow/main.c:121
-msgid "Line width"
+#: ../vector/v.net.timetable/main.c:482 ../vector/v.net.path/path.c:149
+#, c-format
+msgid "Wrong input format: %s"
msgstr ""
-#: ../display/d.vect/main.c:150
-#, fuzzy
-msgid "Name of numeric column containing line width"
-msgstr "출력할 격자지도"
+#: ../vector/v.net.timetable/main.c:505
+msgid "'From' and 'To' stops are the same"
+msgstr ""
-#: ../display/d.vect/main.c:151
-msgid "These values will be scaled by width_scale"
+#: ../vector/v.net.timetable/main.c:514
+msgid "No path between the stops"
msgstr ""
-#: ../display/d.vect/main.c:158
-msgid "Scale factor for width_column"
+#: ../vector/v.label.sa/main.c:41
+msgid "Create optimally placed labels for vector map(s)"
msgstr ""
-#: ../display/d.vect/main.c:179
-msgid "When used with the size_column option this becomes the scale factor"
+#: ../vector/v.label.sa/main.c:57 ../vector/v.label/main.c:78
+msgid "Name of attribute column to be used for labels"
msgstr ""
-#: ../display/d.vect/main.c:185
-#, fuzzy
-msgid "Name of numeric column containing symbol size"
-msgstr "출력할 격자지도"
+#: ../vector/v.label.sa/main.c:61 ../vector/v.label/main.c:67
+msgid "Name for new paint-label file"
+msgstr ""
-#: ../display/d.vect/main.c:191
-#, fuzzy
-msgid "Name of numeric column containing symbol rotation angle"
-msgstr "출력할 격자지도"
+#: ../vector/v.label.sa/main.c:71
+msgid "Name of TrueType font (as listed in the fontcap)"
+msgstr ""
-#: ../display/d.vect/main.c:193
-msgid "Measured in degrees CCW from east"
+#: ../vector/v.label.sa/main.c:84
+msgid "Icon size of point features (in map-units)"
msgstr ""
-#: ../display/d.vect/main.c:203
-msgid "Area/boundary symbol for legend"
+#: ../vector/v.label.sa/main.c:117 ../vector/v.label/main.c:180
+msgid "Width of highlight coloring"
msgstr ""
-#: ../display/d.vect/main.c:213
-msgid "Line symbol for legend"
+#: ../vector/v.label.sa/main.c:135 ../vector/v.label/main.c:200
+msgid "Opaque to vector (only relevant if background color is selected)"
msgstr ""
-#: ../display/d.vect/main.c:219
-msgid "Label to display after symbol in vector legend"
+#: ../vector/v.label.sa/main.c:154
+msgid "Border width (only for ps.map output)"
msgstr ""
-#: ../display/d.vect/main.c:225 ../display/d.vect/main.c:232
-#: ../display/d.vect/main.c:239 ../display/d.vect/main.c:244
-#: ../display/d.vect/main.c:251 ../display/d.vect/main.c:258
-#: ../display/d.vect/main.c:264 ../display/d.vect/main.c:270
-#: ../display/d.vect/main.c:276 ../display/d.vect/main.c:284
-msgid "Labels"
+#: ../vector/v.label.sa/labels.c:68
+#, c-format
+msgid "Cannot allocate %lu bytes of memory"
msgstr ""
-#: ../display/d.vect/main.c:227
-msgid "Layer number for labels (default: the given layer number)"
+#: ../vector/v.label.sa/labels.c:75 ../vector/v.class/main.c:111
+#: ../vector/v.vol.rst/user1.c:95 ../vector/v.label/main.c:274
+#: ../ps/ps.map/catval.c:48 ../ps/ps.map/catval.c:110 ../ps/ps.map/catval.c:176
+msgid "Unable to get layer info for vector map"
msgstr ""
-#: ../display/d.vect/main.c:233
-#, fuzzy
-msgid "Name of column to be displayed as a label"
+#: ../vector/v.label.sa/labels.c:87
+msgid "Unable to initialise FreeType"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:90
+#, fuzzy, c-format
+msgid "Unable to find font '%s'\n"
msgstr "출력할 격자지도"
-#: ../display/d.vect/main.c:238
-msgid "Label color"
+#: ../vector/v.label.sa/labels.c:92
+#, c-format
+msgid "Font '%s' is not a FreeType font\n"
msgstr ""
-#: ../display/d.vect/main.c:245
-msgid "Label background color"
+#: ../vector/v.label.sa/labels.c:96
+msgid "Font file format is not supported by FreeType"
msgstr ""
-#: ../display/d.vect/main.c:252
-msgid "Label border color"
+#: ../vector/v.label.sa/labels.c:98
+msgid "Font file can not be loaded"
msgstr ""
-#: ../display/d.vect/main.c:259
-msgid "Label size (pixels)"
+#: ../vector/v.label.sa/labels.c:107
+msgid "Unable to set font size"
msgstr ""
-#: ../display/d.vect/main.c:271
-msgid "Text encoding"
+#: ../vector/v.label.sa/labels.c:128
+msgid "Cannot allocate more memory"
msgstr ""
-#: ../display/d.vect/main.c:279
-msgid "Label horizontal justification"
-msgstr ""
+#: ../vector/v.label.sa/labels.c:162 ../vector/v.overlay/main.c:423
+#: ../vector/v.label/main.c:319
+#, fuzzy
+msgid "Unable to select attributes"
+msgstr "출력할 격자지도"
-#: ../display/d.vect/main.c:287
-msgid "Label vertical justification"
+#: ../vector/v.label.sa/labels.c:244
+#, c-format
+msgid "Cannot load glyph for '%c'"
msgstr ""
-#: ../display/d.vect/main.c:294
+#: ../vector/v.in.db/main.c:55 ../vector/v.out.lidar/main.c:474
+#: ../vector/v.decimate/main.c:129 ../vector/v.kcv/main.c:57
+#: ../vector/v.normal/main.c:74
+#, fuzzy
+msgid "points"
+msgstr "출력할 격자지도"
+#: ../vector/v.in.db/main.c:57
msgid ""
-"Minimum region size (average from height and width) when map is displayed"
+"Creates new vector (points) map from database table containing coordinates."
msgstr ""
-#: ../display/d.vect/main.c:302
-msgid ""
-"Maximum region size (average from height and width) when map is displayed"
+#: ../vector/v.in.db/main.c:61
+msgid "Input table name"
msgstr ""
-#: ../display/d.vect/main.c:310
-msgid ""
-"Random colors according to category number (or layer number if 'layer=-1' is "
-"given)"
+#: ../vector/v.in.db/main.c:66 ../vector/v.in.db/main.c:70
+#, fuzzy
+msgid "Input DB"
+msgstr "출력할 격자지도"
+#: ../vector/v.in.db/main.c:75
+msgid "Name of column containing x coordinate"
msgstr ""
-#: ../display/d.vect/main.c:317
-msgid "Use values from 'cats' option as feature id"
+#: ../vector/v.in.db/main.c:80
+msgid "Name of column containing y coordinate"
msgstr ""
-#: ../display/d.vect/main.c:321
-msgid "Use square root of the value of size_column"
+#: ../vector/v.in.db/main.c:84
+msgid "Name of column containing z coordinate"
msgstr ""
-#: ../display/d.vect/main.c:323
-msgid ""
-"This makes circle areas proportionate to the size_column values instead of "
-"circle radius"
+#: ../vector/v.in.db/main.c:90
+msgid "Name of column containing category number"
msgstr ""
-#: ../display/d.vect/main.c:346
-msgid "Region size is lower than minreg, nothing displayed"
+#: ../vector/v.in.db/main.c:91
+msgid "Must refer to an integer column"
msgstr ""
-#: ../display/d.vect/main.c:354
-msgid "Region size is greater than maxreg, nothing displayed"
+#: ../vector/v.in.db/main.c:101
+#, fuzzy
+msgid "Use imported table as attribute table for new map"
+msgstr "출력할 격자지도"
+#: ../vector/v.in.db/main.c:141
+#, c-format
+msgid ""
+"Vector map <%s> cannot be overwritten because input table <%s> is linked to "
+"this map."
msgstr ""
-#: ../display/d.vect/main.c:367
+#: ../vector/v.in.db/main.c:177
#, c-format
msgid ""
-"The -%c flag and <%s> option cannot be used together, the -%c flag will be "
-"ignored!"
+"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
msgstr ""
-#: ../display/d.vect/main.c:391 ../display/d.vect/main.c:397
+#: ../vector/v.in.db/main.c:187 ../vector/v.to.3d/trans3.c:65
+#: ../vector/v.to.3d/trans2.c:63 ../vector/v.univar/main.c:355
+#: ../vector/v.out.lidar/main.c:118 ../vector/v.out.lidar/main.c:155
+#: ../vector/v.reclass/main.c:145 ../vector/v.vect.stats/main.c:389
+#: ../vector/v.transform/trans_digit.c:101 ../vector/v.distance/main.c:477
+#: ../vector/v.distance/main.c:518 ../vector/v.db.connect/main.c:289
+#: ../vector/v.colors/scan_attr.c:35 ../vector/v.colors.out/make_colors.c:42
+#: ../db/drivers/ogr/execute.c:69
+#, c-format
+msgid "Column <%s> not found in table <%s>"
+msgstr ""
+#: ../vector/v.in.db/main.c:190 ../vector/v.db.connect/main.c:295
+msgid "Data type of key column must be integer"
+msgstr ""
+#: ../vector/v.in.db/main.c:194
#, fuzzy, c-format
-msgid "Option <%s> must be > 0"
+msgid "Option <%s> must be specified when -%c flag is given"
msgstr "출력할 격자지도"
-#: ../display/d.vect/main.c:401
-#, fuzzy, c-format
-msgid "%d error in cat option"
-msgid_plural "%d errors in cat option"
-msgstr[0] "출력할 격자지도"
-msgstr[1] "출력할 격자지도"
+#: ../vector/v.in.db/main.c:199
+#, c-format
+msgid ""
+"Unable to define key column. This operation is not supported by <%s> driver. "
+"You need to define <%s> option."
+msgstr ""
-#: ../display/d.vect/main.c:417
+#: ../vector/v.in.db/main.c:243
+msgid "Key column must be integer"
+msgstr ""
+#: ../vector/v.in.db/main.c:256
+msgid "x/y/z column must be integer or double"
+msgstr ""
+#: ../vector/v.in.db/main.c:282 ../vector/v.to.3d/main.c:96
+#: ../vector/v.to.3d/main.c:117 ../vector/v.net/main.c:156
+#: ../vector/v.transform/main.c:282
#, fuzzy
-msgid "Plotting..."
+msgid "Copying attributes..."
msgstr "출력할 격자지도"
-#: ../display/d.vect/main.c:425
+#: ../vector/v.in.db/main.c:288
#, fuzzy
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn"
+msgid "Unable to copy table"
msgstr "출력할 격자지도"
-#: ../display/d.vect/main.c:499
-#, fuzzy
-msgid "Rendering failed"
+#: ../vector/v.in.db/main.c:313
+#, fuzzy, c-format
+msgid "Unable to add key column <%s>: SERIAL type is not supported by <%s>"
msgstr "출력할 격자지도"
-#: ../display/d.vect/attr.c:28
-msgid "attrcol not specified, cannot display attributes"
-msgstr ""
+#: ../vector/v.in.db/main.c:324
+#, fuzzy, c-format
+msgid "Failed to update key column <%s>"
+msgstr "출력할 격자지도"
-#: ../display/d.vect/attr.c:129
+#: ../vector/v.in.db/main.c:340
#, c-format
-msgid "No attribute found for cat %d: %s"
-msgstr ""
+msgid "%d point written to vector map."
+msgid_plural "%d points written to vector map."
+msgstr[0] "점 %d개를 벡터지도에 저장했습니다. "
-#: ../display/d.vect/opt.c:126
+#: ../vector/v.in.dxf/layer_list.c:16
#, c-format
-msgid "Unknown color: '%s'"
+msgid "Layer %d: %s\n"
msgstr ""
-#: ../display/d.vect/area.c:37
-#, fuzzy
-msgid ""
-"Unable to display areas, topology not available. Please try to rebuild "
-"topology using v.build or v.build.all."
-msgstr "출력할 격자지도"
+#: ../vector/v.in.dxf/write_vect.c:52
+msgid "Entity handle truncated to 16 characters."
+msgstr ""
-#: ../display/d.vect/area.c:137
+#: ../vector/v.in.dxf/write_vect.c:70 ../vector/v.in.ascii/points.c:452
+#: ../vector/v.mkgrid/main.c:365 ../vector/v.mkgrid/main.c:463
#, fuzzy, c-format
-msgid "Invalid area %d skipped (not enough points)"
+msgid "Unable to insert new record: %s"
msgstr "출력할 격자지도"
-#: ../display/d.vect/area.c:236
-#, fuzzy, c-format
-msgid "%d invalid color rule for areas skipped"
-msgid_plural "%d invalid color rules for areas skipped"
+#: ../vector/v.in.dxf/write_vect.c:91
+msgid "No DXF layers found!"
+msgstr ""
-#: ../display/d.vect/lines.c:121
-#, fuzzy
-msgid ""
-"Unable to display features by id, topology not available. Please try to "
-"rebuild topology using v.build or v.build.all."
-msgstr "출력할 격자지도"
+#: ../vector/v.in.dxf/write_vect.c:100
+msgid "Following DXF layers found:"
+msgstr ""
-#: ../display/d.vect/lines.c:169
+#: ../vector/v.in.dxf/write_vect.c:104
+#, c-format
+msgid "Layer %d: %s"
+msgstr ""
+#: ../vector/v.in.dxf/write_vect.c:246
#, fuzzy, c-format
-msgid "%d invalid color rule for lines skipped"
-msgid_plural "%d invalid color rules for lines skipped"
+msgid "Unable to add database link for vector map <%s>"
+msgstr "출력할 격자지도"
-#: ../display/d.vect/label.c:33
+#: ../vector/v.in.dxf/main.c:68
#, fuzzy
-msgid "Topology level required for drawing centroids for OGR layers"
+msgid "Converts file in DXF format to GRASS vector map."
msgstr "출력할 격자지도"
-#: ../display/d.fontlist/main.c:47
-msgid "Lists the available fonts."
+#: ../vector/v.in.dxf/main.c:72
+msgid "Ignore the map extent of DXF file"
msgstr ""
-#: ../display/d.fontlist/main.c:51
-msgid "List fonts (default; provided for compatibility with d.font)"
+#: ../vector/v.in.dxf/main.c:80
+msgid "Import polyface meshes as 3D wire frame"
msgstr ""
-#: ../display/d.fontlist/main.c:55 ../display/d.font/main.c:78
-msgid "List fonts verbosely"
+#: ../vector/v.in.dxf/main.c:84
+msgid "List available DXF layers and exit"
msgstr ""
-#: ../display/d.where/main.c:48
-msgid ""
-"Identifies the geographic coordinates associated with point locations given "
-"in display coordinates."
+#: ../vector/v.in.dxf/main.c:85 ../vector/v.in.dxf/main.c:92
+#: ../vector/v.in.dxf/main.c:97 ../vector/v.in.dxf/main.c:110
+msgid "DXF layers"
msgstr ""
-#: ../display/d.where/main.c:58
-msgid "Display coordinates to convert"
+#: ../vector/v.in.dxf/main.c:91
+msgid "Invert selection by DXF layers (don't import layers in list)"
msgstr ""
-#: ../display/d.where/main.c:63
+#: ../vector/v.in.dxf/main.c:96
+msgid "Import all objects into one layer"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:100
#, fuzzy
-msgid "File from which to read coordinates (\"-\" to read from stdin)"
+msgid "Path to input DXF file"
msgstr "출력할 격자지도"
-#: ../display/d.where/main.c:67
-msgid "Output lat/long in decimal degree"
+#: ../vector/v.in.dxf/main.c:109
+msgid "List of DXF layers to import (default: all)"
msgstr ""
-#: ../display/d.where/main.c:72
-msgid "Output lat/long referenced to current ellipsoid"
+#: ../vector/v.in.dxf/main.c:124
+msgid "Please specify list of DXF layers to exclude"
msgstr ""
-#: ../display/d.where/main.c:77
-msgid ""
-"Output lat/long referenced to WGS84 ellipsoid using datum transformation "
-"parameters defined in current location (if available)"
-msgstr ""
+#: ../vector/v.in.dxf/main.c:128
+#, fuzzy, c-format
+msgid "Unable to open DXF file <%s>"
+msgstr "출력할 격자지도"
-#: ../display/d.where/main.c:83
-msgid "Output frame coordinates of current display monitor (percentage)"
+#: ../vector/v.in.dxf/main.c:131
+msgid "Layer number: layer name / GRASS compliant name"
msgstr ""
-#: ../display/d.where/main.c:91
-msgid "Ambiguous request for lat/long ellipsoids"
+#: ../vector/v.in.dxf/main.c:165
+msgid "Building topology failed"
+msgstr "위상을 생성하는데 실패했습니다"
+#: ../vector/v.in.dxf/main.c:171
+msgid "Failed to import DXF file!"
msgstr ""
-#: ../display/d.where/main.c:94
-msgid "Please specify a lat/long ellipsoid with -l or -w"
+#: ../vector/v.in.dxf/add_polyline.c:47
+msgid "vertices following flag missing"
msgstr ""
-#: ../display/d.where/main.c:136
-msgid ""
-"WGS84 output not possible as this location does not contain\n"
-"datum transformation parameters. Try running g.setproj."
+#: ../vector/v.in.dxf/read_dxf.c:57
+msgid "end of file while looking for HEADER"
msgstr ""
-#: ../display/d.where/where.c:29
-#, fuzzy, c-format
-msgid "Invalid coordinates <%s,%s>"
+#: ../vector/v.sample/main.c:79
+#, fuzzy
+msgid "Samples a raster map at vector point locations."
msgstr "출력할 격자지도"
-#: ../display/d.colortable/main.c:64
-msgid "Displays the color table associated with a raster map layer."
-msgstr ""
+#: ../vector/v.sample/main.c:89
+#, fuzzy
+msgid "Name of attribute column to use for comparison"
+msgstr "출력할 격자지도"
-#: ../display/d.colortable/main.c:68
+#: ../vector/v.sample/main.c:92
#, fuzzy
-msgid "Name of raster map whose color table is to be displayed"
+msgid "Name for output vector map to store differences"
msgstr "출력할 격자지도"
-#: ../display/d.colortable/main.c:73
-msgid "Color of lines separating the colors of the color table"
-msgstr ""
-#: ../display/d.colortable/main.c:79
+#: ../vector/v.sample/main.c:96
#, fuzzy
-msgid "Number of lines to appear in the color table"
+msgid "Name of raster map to be sampled"
msgstr "출력할 격자지도"
-#: ../display/d.colortable/main.c:85
+#: ../vector/v.sample/main.c:107
#, fuzzy
-msgid "Number of columns to appear in the color table"
+msgid "Scaling factor for values read from raster map"
msgstr "출력할 격자지도"
-#: ../display/d.colortable/main.c:90
-msgid "Do not draw a collar showing the NULL color in FP maps"
+#: ../vector/v.sample/main.c:109
+msgid "Sampled values will be multiplied by this factor"
msgstr ""
-#: ../display/d.colortable/main.c:112
+#: ../vector/v.sample/main.c:148
#, c-format
-msgid ""
-"<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
+msgid "Column type <%s> not supported (must be integer or double precision)"
msgstr ""
-#: ../display/d.colortable/main.c:126
-#, c-format
-msgid ""
-"<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
-msgstr ""
-#: ../display/d.colortable/main.c:137
+#: ../vector/v.sample/main.c:154
#, fuzzy, c-format
-msgid "Range file for <%s> not available"
-msgstr "출력할 격자지도"
+msgid "%d record selected from table"
+msgid_plural "%d records selected from table"
-#: ../display/d.mon/start.c:46 ../display/d.mon/start.c:74
+#: ../vector/v.sample/main.c:190 ../vector/v.patch/main.c:320
#, fuzzy, c-format
-msgid "File <%s> already exists and will be overwritten"
+msgid "Unable to create table <%s>"
msgstr "출력할 격자지도"
-#: ../display/d.mon/start.c:67
+#: ../vector/v.sample/main.c:263 ../vector/v.kcv/main.c:284
#, fuzzy, c-format
-msgid "Unable to start monitor, don't have write permission for <%s>"
-msgstr "지도세트의 허가를 결정하지 못 했습니다"
-#: ../display/d.mon/start.c:76
-#, fuzzy, c-format
-msgid "Unable to delete <%s>"
+msgid "Unable to insert row: %s"
msgstr "출력할 격자지도"
-#: ../display/d.mon/start.c:93
-#, fuzzy, c-format
-msgid "Output file: %s"
-msgstr "출력할 격자지도"
+#: ../vector/v.build.polylines/main.c:117
+msgid "Builds polylines from lines or boundaries."
+msgstr ""
-#: ../display/d.mon/start.c:148
-#, fuzzy, c-format
-msgid "Monitor <%s> already running"
-msgstr "출력할 격자지도"
+#: ../vector/v.build.polylines/main.c:127
+msgid "Category number mode"
+msgstr ""
-#: ../display/d.mon/start.c:151
-#, fuzzy, c-format
-msgid "Starting monitor <%s>..."
-msgstr "출력할 격자지도"
+#: ../vector/v.build.polylines/main.c:132
+msgid "Do not assign any category number to polyline"
+msgstr ""
-#: ../display/d.mon/start.c:169
-#, fuzzy
-msgid "Unable to copy render command file"
-msgstr "출력할 격자지도"
+#: ../vector/v.build.polylines/main.c:133
+msgid "Assign category number of first line to polyline"
+msgstr ""
-#: ../display/d.mon/list.c:80
-msgid "List of running monitors:"
+#: ../vector/v.build.polylines/main.c:134
+msgid "Assign multiple category numbers to polyline"
msgstr ""
-#: ../display/d.mon/list.c:82
-msgid "No monitors running"
+#: ../vector/v.build.polylines/main.c:135
+msgid "Create polyline from lines with same categories"
msgstr ""
-#: ../display/d.mon/list.c:116
+#: ../vector/v.build.polylines/main.c:231
#, fuzzy, c-format
-msgid "Unable to open file '%s'"
-msgstr "출력할 격자지도"
+msgid "%d line or boundaries found in input vector map"
+msgid_plural "%d lines or boundaries found in input vector map"
-#: ../display/d.mon/list.c:145
+#: ../vector/v.build.polylines/main.c:235
#, fuzzy, c-format
-msgid "No support files found for monitor <%s>"
-msgstr "출력할 격자지도"
+msgid "%d polyline stored in output vector map"
+msgid_plural "%d polylines stored in output vector map"
-#: ../display/d.mon/stop.c:18 ../display/d.mon/select.c:30
-#, fuzzy, c-format
-msgid "Monitor <%s> is not running"
-msgstr "출력할 격자지도"
+#: ../vector/v.class/main.c:50
+msgid "Classifies attribute data, e.g. for thematic mapping"
+msgstr ""
-#: ../display/d.mon/stop.c:41
-#, fuzzy, c-format
-msgid "Unable to delete file <%s>"
-msgstr "출력할 격자지도"
+#: ../vector/v.class/main.c:58
+msgid "Column name or expression"
+msgstr ""
-#: ../display/d.mon/stop.c:46
-#, fuzzy, c-format
-msgid "Unable to delete directory <%s>"
-msgstr "출력할 격자지도"
-#: ../display/d.mon/stop.c:75
-#, fuzzy, c-format
-msgid "Unable to read file <%s>"
-msgstr "출력할 격자지도"
-#: ../display/d.mon/main.c:41
-msgid "Controls graphics display monitors from the command line."
+#: ../vector/v.class/main.c:93
+msgid "Print only class breaks (without min and max)"
msgstr ""
-#: ../display/d.mon/main.c:46
+#: ../vector/v.class/main.c:138
#, fuzzy
-msgid "Name of monitor to start"
+msgid "Unable to sort array of values"
msgstr "출력할 격자지도"
-#: ../display/d.mon/main.c:48 ../display/d.mon/main.c:55
-#: ../display/d.mon/main.c:62 ../display/d.mon/main.c:123
-#: ../display/d.mon/main.c:128
-msgid "Manage"
+#: ../vector/v.class/main.c:173
+msgid ""
+"The discontinuities algorithm indicates that some class breaks are not "
+"statistically significant at alpha=0.05. You are advised to reduce the "
+"number of classes."
msgstr ""
-#: ../display/d.mon/main.c:53
-#, fuzzy
-msgid "Name of monitor to stop"
-msgstr "출력할 격자지도"
+#: ../vector/v.class/main.c:201
+#, c-format
+msgid ""
+"\n"
+"Classification of %s into %i classes\n"
+msgstr ""
-#: ../display/d.mon/main.c:60
-#, fuzzy
-msgid "Name of monitor to select"
-msgstr "출력할 격자지도"
+#: ../vector/v.class/main.c:208
+#, c-format
+msgid "Lowest chi2 = %f\n"
+msgstr ""
-#: ../display/d.mon/main.c:66
-msgid "Width for display monitor if not set by GRASS_RENDER_WIDTH"
+#: ../vector/v.class/main.c:214
+#, c-format
+msgid ""
+"%15s%15s%15s\n"
+"\n"
msgstr ""
-#: ../display/d.mon/main.c:67
-msgid "Default value: 720"
+#: ../vector/v.class/main.c:226
+#, c-format
+msgid ""
+"\n"
+"Note: Minimum of first class is including\n"
+"\n"
msgstr ""
-#: ../display/d.mon/main.c:74
-msgid "Height for display monitor if not set by GRASS_RENDER_HEIGHT"
+#: ../vector/v.net.alloc/main.c:61
+msgid "Allocates subnets for nearest centers (direction from center)."
msgstr ""
-#: ../display/d.mon/main.c:75
-msgid "Default value: 480"
+#: ../vector/v.net.alloc/main.c:63
+msgid ""
+"center node must be opened (costs >= 0). Costs of center node are used in "
+"calculation"
msgstr ""
-#: ../display/d.mon/main.c:82
-msgid "Dimensions of display monitor versus current size"
+#: ../vector/v.net.alloc/main.c:76
+msgid "Use costs from centers or costs to centers"
msgstr ""
-#: ../display/d.mon/main.c:83
-msgid "Example: resolution=2 enlarge display monitor twice to 1280x960"
+#: ../vector/v.net.alloc/main.c:83 ../vector/v.net.iso/main.c:89
+msgid ""
+"Categories of centers (points on nodes) to which net will be allocated, "
+"layer for this categories is given by nlayer option"
msgstr ""
-#: ../display/d.mon/main.c:96
+#: ../vector/v.net.alloc/main.c:129 ../vector/v.net.path/main.c:110
+#: ../vector/v.net.iso/main.c:137 ../vector/v.net.salesman/main.c:181
+msgid "Use turntable"
+msgstr ""
+#: ../vector/v.net.alloc/main.c:130 ../vector/v.net.alloc/main.c:138
+#: ../vector/v.net.alloc/main.c:146 ../vector/v.net.path/main.c:111
+#: ../vector/v.net.path/main.c:119 ../vector/v.net.path/main.c:127
+#: ../vector/v.net.iso/main.c:138 ../vector/v.net.iso/main.c:146
+#: ../vector/v.net.iso/main.c:154 ../vector/v.net/args.c:64
+#: ../vector/v.net/args.c:111 ../vector/v.net/args.c:123
+#: ../vector/v.net.salesman/main.c:182 ../vector/v.net.salesman/main.c:189
+#: ../vector/v.net.salesman/main.c:196
#, fuzzy
-msgid "Name for output file (when starting new monitor)"
-msgstr "출력할 격자지도"
+msgid "Turntable"
+msgstr "색상표"
-#: ../display/d.mon/main.c:97
-msgid "Ignored for 'wx' monitors"
+#: ../vector/v.net.alloc/main.c:135 ../vector/v.net.path/main.c:116
+#: ../vector/v.net.iso/main.c:143 ../vector/v.net.salesman/main.c:187
+msgid "Layer with turntable"
msgstr ""
-#: ../display/d.mon/main.c:102
-msgid "List running monitors and exit"
+#: ../vector/v.net.alloc/main.c:137 ../vector/v.net.alloc/main.c:145
+#: ../vector/v.net.path/main.c:118 ../vector/v.net.path/main.c:126
+#: ../vector/v.net.iso/main.c:145 ../vector/v.net.iso/main.c:153
+#: ../vector/v.net.salesman/main.c:188 ../vector/v.net.salesman/main.c:195
+msgid "Relevant only with -t flag"
msgstr ""
-#: ../display/d.mon/main.c:107
-msgid "Print name of currently selected monitor and exit"
+#: ../vector/v.net.alloc/main.c:143 ../vector/v.net.path/main.c:124
+#: ../vector/v.net.iso/main.c:151 ../vector/v.net/args.c:114
+#: ../vector/v.net.salesman/main.c:194
+msgid "Layer with unique categories used in turntable"
msgstr ""
-#: ../display/d.mon/main.c:112
-msgid "Print commands for currently selected monitor and exit"
+#: ../vector/v.net.alloc/main.c:212 ../vector/v.net.iso/main.c:241
+#: ../vector/v.net.salesman/main.c:277
+#, fuzzy
+msgid "Point is not connected to the network"
+msgstr "출력할 격자지도"
+#: ../vector/v.net.alloc/main.c:238
+#, c-format
+msgid "Number of centers: [%d] (nlayer: [%d])"
msgstr ""
-#: ../display/d.mon/main.c:118
+#: ../vector/v.net.alloc/main.c:241
+msgid "Not enough centers for selected nlayer. Nothing will be allocated."
+msgstr ""
+#: ../vector/v.net.alloc/main.c:256 ../vector/v.net.alloc/main.c:262
#, fuzzy
-msgid "Print path to support files of currently selected monitor and exit"
+msgid "Calculating costs from centers ..."
msgstr "출력할 격자지도"
-#: ../display/d.mon/main.c:122
-msgid "Do not automatically select when starting"
+#: ../vector/v.net.alloc/main.c:266
+#, fuzzy
+msgid "Calculating costs to centers ..."
+msgstr "출력할 격자지도"
+#: ../vector/v.net.alloc/main.c:394 ../vector/v.net.alloc/main.c:406
+#: ../vector/v.net.iso/main.c:618
+msgid "Cannot get line segment, segment out of line"
msgstr ""
-#: ../display/d.mon/main.c:127
+#: ../vector/v.external/args.c:14
#, fuzzy
-msgid "Release and stop currently selected monitor and exit"
+msgid "Name of input OGR or PostGIS data source"
msgstr "출력할 격자지도"
-#: ../display/d.mon/main.c:132
+#: ../vector/v.external/args.c:15 ../vector/v.external.out/args.c:15
+msgid ""
+"Examples:\n"
+"\t\tESRI Shapefile: directory containing a shapefile\n"
+"\t\tMapInfo File: directory containing a mapinfo file\n"
+"\t\tPostGIS database: connection string, eg. 'PG:dbname=db user=grass'"
+msgstr ""
+#: ../vector/v.external/args.c:27
#, fuzzy
-msgid "Disable true colors"
+msgid "Name of OGR layer or PostGIS feature table to be linked"
msgstr "출력할 격자지도"
-#: ../display/d.mon/main.c:137
-msgid "Open output file in update mode"
+#: ../vector/v.external/args.c:28
+msgid ""
+"Examples:\n"
+"\t\tESRI Shapefile: shapefile name\n"
+"\t\tMapInfo File: mapinfo file name\n"
+"\t\tPostGIS database: table name"
msgstr ""
-#: ../display/d.mon/main.c:138
-msgid "Requires --overwrite flag"
-msgstr ""
+#: ../vector/v.external/args.c:38
+#, fuzzy
+msgid "Name for output GRASS vector map (default: input layer)"
+msgstr "출력할 격자지도"
-#: ../display/d.mon/main.c:143
-msgid "Launch light-weight wx monitor without toolbars and statusbar"
+#: ../vector/v.external/args.c:55
+msgid "List available layers in data source and exit"
msgstr ""
-#: ../display/d.mon/main.c:144
-msgid "Requires 'start=wx0-7'"
+#: ../vector/v.external/args.c:61
+msgid "List available layers including feature type in data source and exit"
msgstr ""
-#: ../display/d.mon/main.c:151
-#, c-format
-msgid "Flag -%c has effect only for wx monitors (%s=wx0-7)"
+#: ../vector/v.external/args.c:63
+msgid "Format: layer name,type,projection check,geometry"
msgstr ""
-#: ../display/d.mon/main.c:157 ../general/g.mapsets/main.c:136
-#: ../general/g.mapsets/main.c:138 ../general/g.mapsets/main.c:148
-#, c-format
-msgid "Flag -%c ignored"
-msgstr "-%c 플래그를 무시합니다"
-#: ../display/d.mon/main.c:161
-msgid "Currently selected monitor:"
+#: ../vector/v.external/dsn.c:21 ../vector/v.in.ogr/dsn.c:21
+msgid "Invalid connection string (dbname missing)"
msgstr ""
-#: ../display/d.mon/main.c:165
-#, c-format
-msgid "List of commands for monitor <%s>:"
+#: ../vector/v.external/main.c:55
+msgid ""
+"Creates a new pseudo-vector map as a link to an OGR-supported layer or a "
+"PostGIS feature table."
msgstr ""
-#: ../display/d.mon/main.c:173
-#, c-format
-msgid "Monitor <%s> released"
+#: ../vector/v.external/main.c:74 ../vector/v.external.out/format.c:22
+msgid ""
+"Environment variable GRASS_VECTOR_OGR defined, but GRASS is compiled with "
+"OGR support. Using GRASS-PostGIS data driver instead."
msgstr ""
-#: ../display/d.mon/main.c:178
-msgid "No monitor selected"
+#: ../vector/v.external/main.c:79 ../vector/v.external.out/format.c:27
+msgid ""
+"GRASS is not compiled with PostgreSQL support. Using OGR-PostgreSQL driver "
+"instead of native GRASS-PostGIS data driver."
msgstr ""
-#: ../display/d.mon/main.c:197
+#: ../vector/v.external/main.c:119 ../vector/v.in.ogr/main.c:479
#, fuzzy, c-format
-msgid "Either <%s>, <%s> or <%s> must be given"
+msgid "Layer <%s> not available"
msgstr "출력할 격자지도"
-#: ../display/d.mon/main.c:202 ../general/g.mapsets/main.c:140
-#: ../general/g.mapsets/main.c:150 ../general/g.mapsets/main.c:158
-#, c-format
-msgid "Option <%s> ignored"
-msgstr "<%s> 옵션을 무시합니다"
+#: ../vector/v.external/main.c:121
+#, fuzzy
+msgid "No layer defined"
+msgstr "글꼴설정"
-#: ../display/d.mon/select.c:14
+#: ../vector/v.external/main.c:156
#, fuzzy, c-format
-msgid "Monitor <%s> is already selected"
+msgid "Unable to delete '%s'"
msgstr "출력할 격자지도"
-#: ../display/d.rast/main.c:56
-msgid "Displays user-specified raster map in the active graphics frame."
+#: ../vector/v.external/main.c:163
+#, fuzzy, c-format
+msgid "Unable to create file '%s/%s'"
+msgstr "출력할 격자지도"
+#: ../vector/v.external/main.c:194
+#, fuzzy, c-format
+msgid "Link to vector map <%s> created."
+msgstr "출력할 격자지도"
+#: ../vector/v.external/list.c:111
+msgid "GRASS is not compiled with PostgreSQL support"
msgstr ""
-#: ../display/d.rast/main.c:61
+#: ../vector/v.external/list.c:117
+msgid "GRASS is not compiled with OGR support"
+msgstr ""
+#: ../vector/v.external/list.c:158
#, fuzzy
-msgid "Name of raster map to be displayed"
+msgid "Connection to PostgreSQL database failed."
msgstr "출력할 격자지도"
-#: ../display/d.rast/main.c:69
+#: ../vector/v.external/list.c:168
#, fuzzy
-msgid "List of categories or values to be displayed"
+msgid "No feature tables found in database."
msgstr "출력할 격자지도"
-#: ../display/d.rast/main.c:76
-msgid "Background color (for null)"
-msgstr ""
+#: ../vector/v.external/list.c:179
+#, c-format
+msgid "PostGIS database <%s> contains %d feature table:"
+msgid_plural "PostGIS database <%s> contains %d feature tables:"
+msgstr[0] ""
-#: ../display/d.rast/main.c:86
-msgid "Invert value list"
-msgstr ""
-#: ../display/d.rast/main.c:204
+#: ../vector/v.external/list.c:260 ../vector/v.external/proj.c:32
#, fuzzy, c-format
-msgid "[%s]: illegal category specified"
+msgid "Unable to open data source '%s'"
msgstr "출력할 격자지도"
-#: ../display/d.rast/main.c:235
+#: ../vector/v.external/list.c:267
+#, c-format
+msgid "Data source <%s> (format '%s') contains %d layer:"
+msgid_plural "Data source <%s> (format '%s') contains %d layers:"
+msgstr[0] ""
+#: ../vector/v.external/list.c:310
+#, c-format
+msgid ""
+"Unable to convert input map projection to GRASS format. Projection check "
+"cannot be provided for OGR layer <%s>"
+msgstr ""
+#: ../vector/v.external/list.c:326
#, fuzzy, c-format
-msgid "[%s]: illegal value specified"
+msgid "Invalid geometry column %d"
msgstr "출력할 격자지도"
-#: ../display/d.histogram/main.c:84
+#: ../vector/v.in.ascii/points.c:82
#, fuzzy
-msgid "histogram"
+msgid "Scanning input for column types..."
msgstr "출력할 격자지도"
-#: ../display/d.histogram/main.c:87
+#: ../vector/v.in.ascii/points.c:130
+#, fuzzy, c-format
+msgid "Row %d: '%s' can not be imported into the attribute table"
+msgstr "출력할 격자지도"
+#: ../vector/v.in.ascii/points.c:134 ../vector/v.in.ascii/points.c:144
+#, c-format
+msgid "Broken row %d: '%s'"
+msgstr ""
+#: ../vector/v.in.ascii/points.c:188 ../vector/v.in.ascii/points.c:207
+#, c-format
msgid ""
-"Displays a histogram in the form of a pie or bar chart for a user-specified "
-"raster map."
+"Current row %d:\n"
+"%s\n"
msgstr ""
-#: ../display/d.histogram/main.c:91
+#: ../vector/v.in.ascii/points.c:189 ../vector/v.in.ascii/points.c:217
+#, fuzzy, c-format
+msgid "Unparsable longitude value in column %d: %s"
+msgstr "출력할 격자지도"
+#: ../vector/v.in.ascii/points.c:208 ../vector/v.in.ascii/points.c:221
+#, fuzzy, c-format
+msgid "Unparsable latitude value in column %d: %s"
+msgstr "출력할 격자지도"
+#: ../vector/v.in.ascii/points.c:298
+#, fuzzy, c-format
+msgid "Skipping %d of %d row falling outside of current region"
+msgid_plural "Skipping %d of %d rows falling outside of current region"
+#: ../vector/v.in.ascii/points.c:328
#, fuzzy
-msgid "Raster map for which histogram will be displayed"
+msgid "Importing points..."
msgstr "출력할 격자지도"
-#: ../display/d.histogram/main.c:95
-msgid "Indicate if a pie or bar chart is desired"
+#: ../vector/v.in.ascii/main.c:74
+msgid "Creates a vector map from an ASCII points file or ASCII vector file."
msgstr ""
-#: ../display/d.histogram/main.c:104
-msgid "Color for text and axes"
+#: ../vector/v.in.ascii/main.c:92
+msgid "simple x,y[,z] list"
msgstr ""
-#: ../display/d.histogram/main.c:115
-msgid "Indicate if cell counts or map areas should be displayed"
+#: ../vector/v.in.ascii/main.c:93
+msgid "GRASS vector ASCII format"
msgstr ""
-#: ../display/d.histogram/main.c:125
-msgid "Number of steps to divide the data range into (fp maps only)"
+#: ../vector/v.in.ascii/main.c:96
+msgid "Input file format"
msgstr ""
-#: ../display/d.histogram/main.c:132
-msgid "Display information for null cells"
+#: ../vector/v.in.ascii/main.c:97 ../vector/v.in.ascii/main.c:100
+#: ../vector/v.in.ascii/main.c:107 ../vector/v.in.ascii/main.c:185
+msgid "Input format"
msgstr ""
-#: ../display/d.histogram/main.c:137
-msgid "Report for ranges defined in cats file (fp maps only)"
+#: ../vector/v.in.ascii/main.c:106
+msgid "Special characters: doublequote, singlequote, none"
msgstr ""
-#: ../display/d.histogram/main.c:161
-#, c-format
-msgid "Invalid number of steps: %s"
+#: ../vector/v.in.ascii/main.c:116
+msgid "Number of header lines to skip at top of input file (points mode)"
msgstr ""
-#: ../display/d.histogram/main.c:166
-msgid "When -C flag is set, the nsteps argument is ignored"
+#: ../vector/v.in.ascii/main.c:125
+msgid "Column definition in SQL style (points mode)"
msgstr ""
-#: ../display/d.histogram/main.c:177 ../display/d.legend/draw.c:282
-#: ../display/d.legend/draw.c:287
-#, c-format
-msgid "Range information for <%s> not available"
+#: ../vector/v.in.ascii/main.c:126
+msgid ""
+"For example: 'x double precision, y double precision, cat int, name "
+"varchar(10)'"
msgstr ""
-#: ../display/d.profile/main.c:68
-#, fuzzy, c-format
-msgid "Unable to read range for %s"
+#: ../vector/v.in.ascii/main.c:138 ../vector/v.in.ascii/main.c:148
+msgid "First column is 1"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:147
+#, fuzzy
+msgid "Number of column used as y coordinate (points mode)"
msgstr "출력할 격자지도"
-#: ../display/d.profile/main.c:79
-#, fuzzy, c-format
-msgid "Unable to read FP range for %s"
+#: ../vector/v.in.ascii/main.c:157
+#, fuzzy
+msgid "Number of column used as z coordinate (points mode)"
msgstr "출력할 격자지도"
-#: ../display/d.profile/main.c:194
-msgid "Plots profile of a transect."
+#: ../vector/v.in.ascii/main.c:158
+msgid "First column is 1. If 0, z coordinate is not used"
msgstr ""
-#: ../display/d.profile/main.c:198
+#: ../vector/v.in.ascii/main.c:168
#, fuzzy
-msgid "Raster map to be profiled"
+msgid "Number of column used as category (points mode)"
msgstr "출력할 격자지도"
-#: ../display/d.profile/main.c:207
-msgid "Use map's range recorded range"
+#: ../vector/v.in.ascii/main.c:170
+msgid ""
+"First column is 1. If 0, unique category is assigned to each row and written "
+"to new column 'cat'"
msgstr ""
-#: ../display/d.profile/main.c:256
+#: ../vector/v.in.ascii/main.c:174 ../vector/v.in.dwg/main.c:106
#, fuzzy
-msgid "At least two points are required"
+msgid "Create 3D vector map"
msgstr "출력할 격자지도"
-#: ../display/d.graph/do_graph.c:65 ../display/d.graph/do_graph.c:81
-#, c-format
-msgid "Problem parsing coordinates [%s]"
+#: ../vector/v.in.ascii/main.c:179
+msgid "Create a new empty vector map and exit. Nothing is read from input."
msgstr ""
-#: ../display/d.graph/do_graph.c:98
-msgid "Unable to read color"
+#: ../vector/v.in.ascii/main.c:184
+msgid "Do not expect a header when reading in standard format"
msgstr ""
-#: ../display/d.graph/do_graph.c:129 ../display/d.graph/do_graph.c:195
-#: ../display/d.graph/do_graph.c:216 ../display/d.graph/do_graph.c:267
-#: ../display/d.graph/do_graph.c:334 ../display/d.graph/graphics.c:60
-#, c-format
-msgid "Problem parsing command [%s]"
+#: ../vector/v.in.ascii/main.c:189
+msgid "Do not create table in points mode"
msgstr ""
-#: ../display/d.graph/do_graph.c:377
-msgid "Cannot read symbol, cannot display points"
+#: ../vector/v.in.ascii/main.c:199
+msgid "Only import points falling within current region (points mode)"
msgstr ""
-#: ../display/d.graph/main.c:61
-msgid ""
-"Program for generating and displaying simple graphics on the display monitor."
+#: ../vector/v.in.ascii/main.c:204
+msgid "Ignore broken line(s) in points mode"
msgstr ""
-#: ../display/d.graph/main.c:66
-msgid ""
-"Name of file containing graphics commands, if not given reads from standard "
-"input"
+#: ../vector/v.in.ascii/main.c:221
+msgid "Please specify z column"
msgstr ""
-#: ../display/d.graph/main.c:73
-msgid "Color to draw with, either a standard GRASS color or R:G:B triplet"
+#: ../vector/v.in.ascii/main.c:232
+msgid "Please specify reasonable z column"
msgstr ""
-#: ../display/d.graph/main.c:80
-msgid "Coordinates are given in map units"
+#: ../vector/v.in.ascii/main.c:237
+msgid "Column numbers must not be negative"
msgstr ""
-#: ../display/d.graph/main.c:91
+#: ../vector/v.in.ascii/main.c:281
#, c-format
-msgid "Graph file <%s> not found"
+msgid "Maximum input row length: %d"
msgstr ""
-#: ../display/d.legend.vect/main.c:55
-#, fuzzy
-msgid "Displays a vector legend in the active graphics frame."
+#: ../vector/v.in.ascii/main.c:283
+#, c-format
+msgid "Maximum number of columns: %d"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:284
+#, c-format
+msgid "Minimum number of columns: %d"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:287
+#, fuzzy, c-format
+msgid "Number of columns: %d"
msgstr "출력할 격자지도"
-#: ../display/d.legend.vect/main.c:66
-msgid "Screen position of legend to be drawn (percentage, [0,0] is lower left)"
+#: ../vector/v.in.ascii/main.c:290
+#, fuzzy, c-format
+msgid "Number of rows: %d"
+msgstr "출력할 격자지도"
+#: ../vector/v.in.ascii/main.c:294 ../vector/v.in.ascii/main.c:298
+#: ../vector/v.in.ascii/main.c:303 ../vector/v.in.ascii/main.c:308
+#, c-format
+msgid ""
+"'%s' column number > minimum last column number (incorrect field separator "
+"or format?)"
msgstr ""
-#: ../display/d.legend.vect/main.c:74
-#, fuzzy
-msgid "Number of legend columns"
+#: ../vector/v.in.ascii/main.c:313 ../vector/v.in.ascii/main.c:316
+#: ../vector/v.in.ascii/main.c:319 ../vector/v.in.ascii/main.c:322
+#, fuzzy, c-format
+msgid "'%s' column is not of number type"
msgstr "출력할 격자지도"
-#: ../display/d.legend.vect/main.c:75 ../display/d.legend.vect/main.c:90
-msgid "Layout"
+#: ../vector/v.in.ascii/main.c:364
+msgid "Category column is not of integer type"
msgstr ""
-#: ../display/d.legend.vect/main.c:81 ../display/d.legend/main.c:99
-msgid "Legend title"
+#: ../vector/v.in.ascii/main.c:441
+#, c-format
+msgid ""
+"Number of columns defined (%d) does not match number of columns (%d) in input"
msgstr ""
-#: ../display/d.legend.vect/main.c:82 ../display/d.legend.vect/main.c:141
-#: ../display/d.legend/main.c:100 ../display/d.legend/main.c:109
-msgid "Title"
+#: ../vector/v.in.ascii/main.c:469
+#, c-format
+msgid "Column number %d <%s> defined as double has only integer values"
msgstr ""
-#: ../display/d.legend.vect/main.c:95 ../display/d.grid/main.c:101
-#: ../display/d.legend/main.c:240 ../vector/v.label.sa/main.c:144
-#: ../vector/v.lrs/v.lrs.label/main.c:223 ../vector/v.label/main.c:193
-msgid "Border color"
+#: ../vector/v.in.ascii/main.c:474
+#, c-format
+msgid "Column number %d <%s> defined as string has only integer values"
msgstr ""
-#: ../display/d.legend.vect/main.c:96 ../display/d.legend.vect/main.c:102
-#: ../display/d.legend.vect/main.c:109 ../display/d.legend.vect/main.c:168
-#: ../display/d.legend/main.c:241 ../display/d.legend/main.c:247
-#: ../display/d.legend/main.c:288
-msgid "Background"
+#: ../vector/v.in.ascii/main.c:481
+#, c-format
+msgid "Column number %d <%s> defined as integer has double values"
msgstr ""
-#: ../display/d.legend.vect/main.c:108
-msgid "Background border width"
+#: ../vector/v.in.ascii/main.c:486
+#, c-format
+msgid "Column number %d <%s> defined as string has double values"
msgstr ""
-#: ../display/d.legend.vect/main.c:124
-#, fuzzy
-msgid "Default: 12"
-msgstr "기본값"
+#: ../vector/v.in.ascii/main.c:493
+#, c-format
+msgid "Column number %d <%s> defined as integer has string values"
+msgstr ""
-#: ../display/d.legend.vect/main.c:131
-#, fuzzy
-msgid "Title font name"
-msgstr "글꼴크기"
+#: ../vector/v.in.ascii/main.c:498
+#, c-format
+msgid "Column number %d <%s> defined as double has string values"
+msgstr ""
-#: ../display/d.legend.vect/main.c:139 ../display/d.legend/main.c:107
-#, fuzzy
-msgid "Title font size"
-msgstr "글꼴크기"
+#: ../vector/v.in.ascii/main.c:503
+#, c-format
+msgid "Length of column %d <%s> (%d) is less than maximum value length (%d)"
+msgstr ""
-#: ../display/d.legend.vect/main.c:140
-#, fuzzy
-msgid "Default: 18"
-msgstr "기본값"
+#: ../vector/v.in.ascii/main.c:539
+msgid "Populating table..."
+msgstr ""
-#: ../display/d.legend.vect/main.c:147
-#, fuzzy
-msgid "Subtitle font name"
-msgstr "글꼴크기"
+#: ../vector/v.in.ascii/main.c:542
+msgid ""
+"Unable to close attribute table. The DBMI driver did not accept all "
+"attributes"
+msgstr ""
-#: ../display/d.legend.vect/main.c:155
+#: ../vector/v.in.ascii/main.c:550 ../vector/v.in.ascii/main.c:553
+#: ../vector/v.in.ogr/main.c:1678
#, fuzzy
-msgid "Subtitle font size"
-msgstr "글꼴크기"
+msgid "Import failed"
+msgstr "출력할 격자지도"
-#: ../display/d.legend.vect/main.c:156
-#, fuzzy
-msgid "Default: 14"
-msgstr "기본값"
+#: ../vector/v.to.3d/args.c:11
+msgid "Reverse transformation; 3D vector features to 2D"
+msgstr ""
-#: ../display/d.legend.vect/main.c:162
+#: ../vector/v.to.3d/args.c:14
#, fuzzy
-msgid "Font color"
+msgid "Do not copy attribute table"
msgstr "출력할 격자지도"
-#: ../display/d.legend.vect/main.c:167
-msgid "Display legend background"
+#: ../vector/v.to.3d/args.c:30
+msgid "Name of attribute column used for height"
msgstr ""
-#: ../display/d.legend.vect/main.c:171 ../display/d.legend.vect/main.c:178
-#: ../display/d.legend.vect/main.c:185
-msgid "In/Out"
+#: ../vector/v.to.3d/args.c:32
+msgid "Can be used for reverse transformation, to store height of points"
msgstr ""
-#: ../display/d.legend.vect/main.c:172
-#, fuzzy
-msgid "Field separator for input file"
+#: ../vector/v.to.3d/main.c:40
+msgid "Performs transformation of 2D vector features to 3D."
+msgstr ""
+#: ../vector/v.to.3d/main.c:52
+#, fuzzy, c-format
+msgid "Either '%s' or '%s' parameter have to be used"
msgstr "출력할 격자지도"
-#: ../display/d.legend.vect/main.c:175
-#, fuzzy
-msgid "Input legend file"
-msgstr "입력파일"
+#: ../vector/v.to.3d/main.c:58
+#, fuzzy, c-format
+msgid "Parameters '%s' ignored"
+msgstr "출력할 격자지도"
-#: ../display/d.legend.vect/main.c:176
+#: ../vector/v.to.3d/main.c:63
#, fuzzy
-msgid "Path to legend file "
+msgid "Attribute table required"
msgstr "출력할 격자지도"
-#: ../display/d.legend.vect/main.c:181
-#, fuzzy
-msgid "Output csv file"
+#: ../vector/v.to.3d/main.c:76
+#, fuzzy, c-format
+msgid "Vector map <%s> is 2D"
msgstr "출력할 격자지도"
-#: ../display/d.legend.vect/main.c:182
-#, fuzzy
-msgid "Path to output file or '-' for standard output"
-msgstr "지정하지 않거나 '-'이면 표준출력"
+#: ../vector/v.to.3d/main.c:80
+#, fuzzy, c-format
+msgid "Vector map <%s> is 3D"
+msgstr "출력할 격자지도"
-#: ../display/d.legend.vect/draw.c:95 ../display/d.legend.vect/draw.c:183
+#: ../vector/v.to.3d/main.c:98 ../vector/v.to.3d/main.c:119
#, fuzzy
-msgid "Cannot read symbol"
+msgid "Unable to copy attributes"
msgstr "출력할 격자지도"
-#: ../display/d.legend.vect/draw.c:244
-msgid "Invalid value for color type in legend file. Use one of 'lf' or 'ps'."
+#: ../vector/v.to.3d/main.c:128
+#, c-format
+msgid "Vertical extent of vector map <%s>: B: %f T: %f"
msgstr ""
-#: ../display/d.northarrow/main.c:49
+#: ../vector/v.to.3d/trans3.c:45 ../vector/v.to.3d/trans2.c:43
+#, c-format
+msgid "Invalid layer number %d, assuming 1"
+msgstr ""
+#: ../vector/v.to.3d/trans3.c:69 ../vector/v.to.3d/trans2.c:67
+#: ../vector/v.kriging/getval.c:82
+msgid "Column must be numeric"
+msgstr ""
+#: ../vector/v.to.3d/trans3.c:75
#, fuzzy
-msgid "Displays a north arrow on the graphics monitor."
+msgid "Reading categories..."
msgstr "출력할 격자지도"
-#: ../display/d.northarrow/main.c:53
-msgid "North arrow style"
-msgstr ""
+#: ../vector/v.to.3d/trans3.c:80 ../vector/v.to.3d/trans2.c:79
+#: ../vector/v.transform/main.c:277
+#, fuzzy
+msgid "Transforming features..."
+msgstr "출력할 격자지도"
-#: ../display/d.northarrow/main.c:61
-msgid "Two color arrowhead"
-msgstr ""
+#: ../vector/v.to.3d/trans3.c:101
+#, fuzzy, c-format
+msgid "Feature id %d has no category - skipping"
+msgstr "출력할 격자지도"
-#: ../display/d.northarrow/main.c:62
-msgid "Two color arrowhead with circle"
+#: ../vector/v.to.3d/trans3.c:104
+#, c-format
+msgid "Feature id %d has more categories. Using category %d."
msgstr ""
-#: ../display/d.northarrow/main.c:63
-msgid "Narrow with blending N"
+#: ../vector/v.to.3d/trans3.c:130 ../vector/v.to.db/update.c:222
+#, c-format
+msgid "Record (cat %d) does not exist (not updated)"
msgstr ""
-msgid "Long with small arrowhead"
-msgstr ""
+#: ../vector/v.to.3d/trans2.c:70
+#, fuzzy, c-format
+msgid "Fetching height from <%s> column..."
+msgstr "출력할 격자지도"
-#: ../display/d.northarrow/main.c:64
-msgid "Inverted narrow inside a circle"
-msgstr ""
+#: ../vector/v.to.3d/trans2.c:101
+#, fuzzy
+msgid "Skipping feature without category"
+msgstr "출력할 격자지도"
-#: ../display/d.northarrow/main.c:65
-msgid "Triangle and N inside a circle"
-msgstr ""
+#: ../vector/v.to.3d/trans2.c:116
+#, fuzzy, c-format
+msgid "Unable to get height for feature category %d"
+msgstr "출력할 격자지도"
-#: ../display/d.northarrow/main.c:66
-msgid "Arrowhead and N inside a circle"
+#: ../vector/v.univar/main.c:98
+#, fuzzy
+msgid "Calculates univariate statistics of vector map features."
+msgstr "출력할 격자지도"
+#: ../vector/v.univar/main.c:99
+msgid ""
+"Variance and standard deviation is calculated only for points if specified."
msgstr ""
-#: ../display/d.northarrow/main.c:67
-msgid "Tall half convex arrowhead"
+#: ../vector/v.univar/main.c:134
+msgid "Weigh by line length or area size"
msgstr ""
-#: ../display/d.northarrow/main.c:68
-msgid "Tall half concave arrowhead"
+#: ../vector/v.univar/main.c:138
+msgid "Calculate geometric distances instead of attribute statistics"
msgstr ""
-msgid "Thin arrow in a circle"
+#: ../vector/v.univar/main.c:147 ../vector/v.to.db/parse.c:141
+#: ../vector/v.to.db/parse.c:144 ../ps/ps.map/main.c:213
+#: ../ps/ps.map/main.c:232
+#, c-format
+msgid ""
+"Required parameter <%s> not set:\n"
+"\t(%s)"
msgstr ""
-#: ../display/d.northarrow/main.c:69
-msgid "Fat arrow in a circle"
+#: ../vector/v.univar/main.c:192
+#, c-format
+msgid "Geometry distances are not supported for areas. Use '%s' instead."
msgstr ""
-msgid "One color arrowhead"
+#: ../vector/v.univar/main.c:195
+msgid ""
+"Incompatible vector type(s) specified, only number of features, minimum, "
+"maximum and range can be calculated"
msgstr ""
-#: ../display/d.northarrow/main.c:70
-msgid "Fancy compass"
+#: ../vector/v.univar/main.c:200
+msgid "Extended statistics is currently supported only for points/centroids"
msgstr ""
-msgid "Basic compass"
+#: ../vector/v.univar/main.c:225
+msgid "'layer' must be > 0 for 'where'."
msgstr ""
-#, fuzzy
-msgid "Simple arrow"
+#: ../vector/v.univar/main.c:242
+#, fuzzy, c-format
+msgid "Unable select categories from table <%s>"
msgstr "출력할 격자지도"
-#: ../display/d.northarrow/main.c:71
-msgid "Thin arrow"
+#: ../vector/v.univar/main.c:253
+#, c-format
+msgid "Calculating geometric distances between %d primitives..."
msgstr ""
-msgid "Fat arrow"
+#: ../vector/v.univar/main.c:343
+#, c-format
+msgid " Database connection not defined for layer <%s>"
msgstr ""
-#, fuzzy
-msgid "4-point star"
-msgstr "출력할 격자지도"
+#: ../vector/v.univar/main.c:358 ../vector/v.out.lidar/main.c:121
+#: ../vector/v.out.lidar/main.c:158
+msgid "Only numeric column type is supported"
+msgstr ""
-#: ../display/d.northarrow/main.c:99
-msgid "Displayed letter on the top of arrow"
+#: ../vector/v.univar/main.c:652
+msgid "Cannot sort the key/value array"
msgstr ""
-#: ../display/d.northarrow/main.c:108
+#: ../vector/v.out.postgis/args.c:25
#, fuzzy
-msgid "Fill color"
+msgid "Name for output PostGIS datasource"
msgstr "출력할 격자지도"
-#: ../display/d.northarrow/main.c:134
-msgid "Draw the symbol without text"
+#: ../vector/v.out.postgis/args.c:27
+msgid "Starts with 'PG' prefix, eg. 'PG:dbname=grass'"
msgstr ""
-#: ../display/d.northarrow/main.c:139
+#: ../vector/v.out.postgis/args.c:35
#, fuzzy
-msgid "Do not rotate text with symbol"
+msgid "Name for output PostGIS layer"
msgstr "출력할 격자지도"
-#: ../display/d.northarrow/draw_n_arrow.c:108
-#: ../display/d.northarrow/draw_n_arrow.c:174
-msgid "Could not parse symbol"
+#: ../vector/v.out.postgis/args.c:37
+msgid "If not specified, input name is used"
msgstr ""
-#: ../display/d.geodesic/main.c:48
-msgid "great circle"
-msgstr ""
+#: ../vector/v.out.postgis/args.c:44
+#, fuzzy
+msgid ""
+"Name for output vector map defined as a link to the PostGIS feature table"
+msgstr "출력할 격자지도"
-#: ../display/d.geodesic/main.c:49 ../display/d.path/main.c:50
-#: ../vector/v.net.allpairs/main.c:63 ../vector/v.net.timetable/main.c:262
-#: ../vector/v.net.path/main.c:44 ../vector/v.net.distance/main.c:68
-#: ../vector/v.net.visibility/main.c:47
-msgid "shortest path"
+#: ../vector/v.out.postgis/args.c:46
+msgid ""
+"If not specified, the vector link is not created. The link can be also "
+"manually created by 'v.external' module."
msgstr ""
-#: ../display/d.geodesic/main.c:51
+#: ../vector/v.out.postgis/args.c:53
msgid ""
-"Displays a geodesic line, tracing the shortest distance between two "
-"geographic points along a great circle, in a longitude/latitude data set."
+"Examples:\n"
+"\t\t'FID=cat': define feature id column 'cat'\n"
+"\t\t'GEOMETRY_NAME=wkb_geometry': define geometry column 'wkb_geometry'\n"
+"\t\t'SPATIAL_INDEX=NO': do not create spatial index on geometry column"
msgstr ""
-#: ../display/d.path/main.c:49 ../vector/v.net.flow/main.c:59
-#: ../vector/v.net.centrality/main.c:97 ../vector/v.net.spanningtree/main.c:47
-#: ../vector/v.lrs/v.lrs.segment/main.c:73
-#: ../vector/v.lrs/v.lrs.create/main.c:123
-#: ../vector/v.lrs/v.lrs.where/main.c:59
-#: ../vector/v.lrs/v.lrs.label/main.c:104 ../vector/v.net.steiner/main.c:347
-#: ../vector/v.net.allpairs/main.c:62 ../vector/v.net.timetable/main.c:261
-#: ../vector/v.net.path/main.c:43 ../vector/v.net.distance/main.c:67
-#: ../vector/v.net.alloc/main.c:58 ../vector/v.net.bridge/main.c:48
-#: ../vector/v.net.components/main.c:73 ../vector/v.net/main.c:48
-#: ../vector/v.net.iso/main.c:73 ../vector/v.net.salesman/main.c:128
-#: ../vector/v.net.visibility/main.c:46 ../vector/v.net.connectivity/main.c:53
-msgid "network"
-msgstr ""
+#: ../vector/v.out.postgis/args.c:66
+#, fuzzy
+msgid "Do not export attribute table"
+msgstr "출력할 격자지도"
-#: ../display/d.path/main.c:52
-msgid "Finds shortest path for selected starting and ending node."
+#: ../vector/v.out.postgis/args.c:72
+msgid "Export PostGIS topology instead of simple features"
msgstr ""
-#: ../display/d.path/main.c:60 ../vector/v.net.steiner/main.c:363
-#: ../vector/v.net.path/main.c:61 ../vector/v.net.distance/main.c:89
-#: ../vector/v.net.alloc/main.c:98 ../vector/v.net/args.c:63
-#: ../vector/v.net.iso/main.c:111 ../vector/v.net.salesman/main.c:156
-msgid "Arc type"
+#: ../vector/v.out.postgis/args.c:77
+msgid "Force 2D output even if input is 3D "
msgstr ""
-#: ../display/d.path/main.c:70 ../vector/v.net.flow/main.c:70
-#: ../vector/v.net.centrality/main.c:109
-#: ../vector/v.net.spanningtree/main.c:59 ../vector/v.net.steiner/main.c:368
-#: ../vector/v.net.allpairs/main.c:74 ../vector/v.net.timetable/main.c:274
-#: ../vector/v.net.path/main.c:54 ../vector/v.net.distance/main.c:82
-#: ../vector/v.net.alloc/main.c:91 ../vector/v.net.bridge/main.c:60
-#: ../vector/v.net.components/main.c:84 ../vector/v.net/args.c:56
-#: ../vector/v.net.iso/main.c:104 ../vector/v.net.salesman/main.c:149
-#: ../vector/v.net.connectivity/main.c:64
-msgid "Arc layer"
+#: ../vector/v.out.postgis/main.c:46
+msgid "PostGIS"
msgstr ""
-#: ../display/d.path/main.c:75 ../vector/v.net.flow/main.c:76
-#: ../vector/v.net.centrality/main.c:115
-#: ../vector/v.net.spanningtree/main.c:65 ../vector/v.net.allpairs/main.c:80
-#: ../vector/v.net.timetable/main.c:280 ../vector/v.net.path/main.c:67
-#: ../vector/v.net.distance/main.c:95 ../vector/v.net.alloc/main.c:104
-#: ../vector/v.net.bridge/main.c:66 ../vector/v.net.components/main.c:90
-#: ../vector/v.net/args.c:70 ../vector/v.net.iso/main.c:117
-#: ../vector/v.net.connectivity/main.c:70
-msgid "Node layer"
-msgstr ""
+#: ../vector/v.out.postgis/main.c:47
+#, fuzzy
+msgid "simple features"
+msgstr "출력할 격자지도"
-#: ../display/d.path/main.c:81 ../vector/v.net.flow/main.c:90
-#: ../vector/v.net.centrality/main.c:129
-#: ../vector/v.net.spanningtree/main.c:72 ../vector/v.net.allpairs/main.c:93
-#: ../vector/v.net.timetable/main.c:288 ../vector/v.net.path/main.c:79
-#: ../vector/v.net.distance/main.c:141 ../vector/v.net.alloc/main.c:110
-#: ../vector/v.net.bridge/main.c:73 ../vector/v.net.components/main.c:97
-#: ../vector/v.net.iso/main.c:122 ../vector/v.net.salesman/main.c:168
-#: ../vector/v.net.connectivity/main.c:77
-msgid "Arc forward/both direction(s) cost column (number)"
-msgstr ""
+#: ../vector/v.out.postgis/main.c:52
+#, fuzzy
+msgid "Exports a vector map layer to PostGIS feature table."
+msgstr "출력할 격자지도"
-#: ../display/d.path/main.c:87 ../vector/v.net.flow/main.c:96
-#: ../vector/v.net.centrality/main.c:135 ../vector/v.net.allpairs/main.c:99
-#: ../vector/v.net.timetable/main.c:295 ../vector/v.net.path/main.c:86
-#: ../vector/v.net.distance/main.c:147 ../vector/v.net.alloc/main.c:117
-#: ../vector/v.net.bridge/main.c:79 ../vector/v.net.components/main.c:103
-#: ../vector/v.net.iso/main.c:127 ../vector/v.net.connectivity/main.c:83
-msgid "Arc backward direction cost column (number)"
-msgstr ""
+#: ../vector/v.out.postgis/main.c:103
+#, fuzzy, c-format
+msgid "Vector map <%s> is not in native format. Export cancelled."
+msgstr "출력할 격자지도"
-#: ../display/d.path/main.c:93
-msgid "Node cost column"
-msgstr ""
+#: ../vector/v.out.postgis/main.c:134
+#, fuzzy, c-format
+msgid "Unable to create PostGIS layer <%s>"
+msgstr "출력할 격자지도"
-#: ../display/d.path/main.c:101 ../display/d.path/main.c:109
-#: ../display/d.path/main.c:117 ../display/d.path/main.c:127
-msgid "Rendering"
-msgstr ""
+#: ../vector/v.out.postgis/main.c:147
+#, fuzzy, c-format
+msgid "Feature type %d is not supported"
+msgstr "출력할 격자지도"
-#: ../display/d.path/main.c:122 ../vector/v.net.centrality/main.c:188
-#: ../vector/v.net.spanningtree/main.c:84 ../vector/v.net.steiner/main.c:398
-#: ../vector/v.net.allpairs/main.c:112 ../vector/v.net.path/main.c:132
-#: ../vector/v.net.distance/main.c:159 ../vector/v.net.alloc/main.c:151
-#: ../vector/v.net.iso/main.c:159 ../vector/v.net.salesman/main.c:208
-msgid "Use geodesic calculation for longitude-latitude locations"
-msgstr ""
+#: ../vector/v.out.postgis/main.c:152
+#, fuzzy
+msgid "Copying features failed"
+msgstr "출력할 격자지도"
-#: ../display/d.path/main.c:126
-msgid "Render bold lines"
-msgstr ""
-#: ../display/d.path/main.c:143 ../display/d.path/main.c:147
+#: ../vector/v.out.postgis/main.c:160
#, c-format
-msgid "%s - illegal x value"
-msgstr ""
+msgid "Building %s topology failed"
+msgstr "%s 위상을 생성하는데 실패했습니다"
-#: ../display/d.path/main.c:145 ../display/d.path/main.c:149
+#: ../vector/v.out.postgis/main.c:164
#, c-format
-msgid "%s - illegal y value"
+msgid "No features exported. PostGIS layer <%s> not created."
msgstr ""
-#: ../display/d.path/main.c:178 ../vector/v.net.centrality/main.c:222
-#: ../vector/v.net.spanningtree/main.c:113 ../vector/v.net.allpairs/main.c:142
-#: ../vector/v.net.path/main.c:148 ../vector/v.net.distance/main.c:205
-msgid "The current projection is not longitude-latitude"
-msgstr ""
+#: ../vector/v.out.postgis/main.c:168
+#, fuzzy, c-format
+msgid "%d feature (%s type) written to <%s>."
+msgid_plural "%d features (%s type) written to <%s>."
+msgstr[0] "출력할 격자지도"
-#: ../display/d.path/select.c:84 ../display/d.path/select.c:101
-#, c-format
-msgid "Node %d: %f %f\n"
-msgstr ""
+#: ../vector/v.out.postgis/main.c:174
+#, fuzzy, c-format
+msgid "%d primitive written to <%s>."
+msgid_plural "%d primitives written to <%s>."
-#: ../display/d.path/select.c:122
-#, c-format
-msgid "Destination unreachable\n"
-msgstr ""
+#: ../vector/v.out.postgis/main.c:213
+#, fuzzy, c-format
+msgid "Unable to drop table <%s.%s>"
+msgstr "출력할 격자지도"
-#: ../display/d.path/select.c:125
-#, c-format
-msgid "Costs on the network = %f\n"
-msgstr ""
+#: ../vector/v.out.postgis/main.c:221
+#, fuzzy, c-format
+msgid "Unable to drop topology schema <%s>"
+msgstr "출력할 격자지도"
-#: ../display/d.path/select.c:126
+#: ../vector/v.out.postgis/table.c:27
+#, fuzzy, c-format
+msgid "No database connection for layer <%s>"
+msgstr "출력할 격자지도"
+#: ../vector/v.out.postgis/table.c:50
#, c-format
msgid ""
-" Distance to the network = %f, distance from the network = %f\n"
-"\n"
+"Invalid FID column (%s). FID column must be integer. Please specify "
+"different FID column by 'options=\"FID=<name>\"'."
msgstr ""
-#: ../display/d.grid/plot.c:373
-msgid "Geo-grid option only available for LL projection, use without -g/-w"
-msgstr ""
-#: ../display/d.grid/plot.c:575
+#: ../vector/v.out.postgis/table.c:57
+#, c-format
msgid ""
-"WGS84 grid output not possible as this location does not contain\n"
+"Column (%s) already exists in the table. Please specify different geometry "
+"column by 'options=\"GEOMETRY_NAME=<name>\"'."
msgstr ""
-#: ../display/d.grid/plot.c:743
-msgid "Error in pj_do_proj1"
-msgstr ""
+#: ../vector/v.out.postgis/create.c:28
+#, fuzzy, c-format
+msgid "Unable to create <%s> file"
+msgstr "출력할 격자지도"
-#: ../display/d.grid/plot.c:749
-msgid "Error in pj_do_proj2"
-msgstr ""
+#: ../vector/v.out.postgis/create.c:66
+#, fuzzy, c-format
+msgid "Invalid option skipped: %s"
+msgstr "출력할 격자지도"
-#: ../display/d.grid/plot.c:753
-msgid "Error in pj_do_proj3"
+#: ../vector/v.out.postgis/create.c:77
+#, c-format
+msgid "EPSG code defined for current location (%s) is overridden by %s"
msgstr ""
-#: ../display/d.grid/plot.c:761
-msgid "Error in pj_do_proj5"
-msgstr ""
+#: ../vector/v.out.postgis/create.c:105
+#, fuzzy, c-format
+msgid "Error writing <%s> file"
+msgstr "출력할 격자지도"
-#: ../display/d.grid/plot.c:765
-msgid "Error in pj_do_proj6"
-msgstr ""
+#: ../vector/v.qcount/main.c:63
+#, fuzzy
+msgid "Indices for quadrat counts of vector point lists."
+msgstr "출력할 격자지도"
-#: ../display/d.grid/main.c:55
-msgid "graticule"
-msgstr ""
+#: ../vector/v.qcount/main.c:72
+#, fuzzy
+msgid ""
+"Name for output quadrat centers map (number of points is written as category)"
+msgstr "출력할 격자지도"
-#: ../display/d.grid/main.c:56 ../vector/v.mkgrid/main.c:72
-msgid "grid"
+#: ../vector/v.qcount/main.c:78
+msgid "Number of quadrats"
msgstr ""
-#: ../display/d.grid/main.c:58
-msgid ""
-"Overlays a user-specified grid in the active display frame on the graphics "
-"monitor."
+#: ../vector/v.qcount/main.c:84
+msgid "Quadrat radius"
msgstr ""
-#: ../display/d.grid/main.c:66
-msgid "Size of grid to be drawn (in map units)"
+#: ../vector/v.qcount/main.c:88
+msgid "Print results in shell script style"
msgstr ""
-#: ../display/d.grid/main.c:68
-msgid ""
-"0 for north-south resolution of the current region. In map units or DDD:MM:"
-"SS format. Example: \"1000\" or \"0:10\""
-msgstr ""
+#: ../vector/v.qcount/main.c:104
+#, fuzzy
+msgid "Finding quadrats..."
+msgstr "출력할 격자지도"
-#: ../display/d.grid/main.c:76
-msgid "Lines of the grid pass through this coordinate"
-msgstr ""
+#: ../vector/v.qcount/main.c:109
+#, fuzzy
+msgid "Counting points quadrats..."
+msgstr "출력할 격자지도"
-#: ../display/d.grid/main.c:85
-msgid "Draw only east-west lines, north-south lines, or both "
-msgstr ""
+#: ../vector/v.out.lidar/main.c:77
+#, fuzzy, c-format
+msgid "Database connection not defined for layer <%d>"
+msgstr "레이어 <%s>를 위한 데이타베이스 연결이 정의되지 않았습니다"
-#: ../display/d.grid/main.c:86 ../display/d.grid/main.c:159
-#: ../display/d.grid/main.c:164 ../display/d.grid/main.c:169
-msgid "Disable"
+#: ../vector/v.out.lidar/main.c:123
+msgid "Double values will be converted to integers"
msgstr ""
-#: ../display/d.grid/main.c:92
-#, fuzzy
-msgid "Grid line width"
+#: ../vector/v.out.lidar/main.c:184
+#, fuzzy, c-format
+msgid "No record for cat = %d"
msgstr "출력할 격자지도"
-#: ../display/d.grid/main.c:97 ../display/d.grid/main.c:102
-#: ../display/d.grid/main.c:108 ../display/d.grid/main.c:114
-msgid "Color"
-msgstr ""
+#: ../vector/v.out.lidar/main.c:187
+#, fuzzy, c-format
+msgid "NULL value for cat = %d"
+msgstr "출력할 격자지도"
-#: ../display/d.grid/main.c:122
-msgid "Font size for gridline coordinate labels"
-msgstr ""
+#: ../vector/v.out.lidar/main.c:196
+#, fuzzy, c-format
+msgid "Column type is not numeric (type = %d, cat = %d"
+msgstr "출력할 격자지도"
-#: ../display/d.grid/main.c:127
+#: ../vector/v.out.lidar/main.c:475
#, fuzzy
-msgid "Align the origin to the east-north corner of the current region"
+msgid "Exports vector points as LAS point cloud"
msgstr "출력할 격자지도"
-#: ../display/d.grid/main.c:132
-msgid "Draw geographic grid (referenced to current ellipsoid)"
-msgstr ""
+#: ../vector/v.out.lidar/main.c:476
+#, fuzzy
+msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS"
+msgstr "출력할 격자지도"
-#: ../display/d.grid/main.c:133 ../display/d.grid/main.c:139
-#: ../display/d.grid/main.c:144 ../display/d.grid/main.c:149
-#: ../display/d.grid/main.c:154 ../misc/m.nviz.image/args.c:233
-#: ../misc/m.nviz.image/args.c:244 ../misc/m.nviz.image/args.c:255
-#: ../misc/m.nviz.image/args.c:267 ../misc/m.nviz.image/args.c:279
-#: ../misc/m.nviz.image/args.c:288 ../misc/m.nviz.image/args.c:298
-#: ../misc/m.nviz.image/args.c:608 ../misc/m.nviz.image/args.c:620
-msgid "Draw"
-msgstr ""
+#: ../vector/v.out.lidar/main.c:496 ../vector/v.in.lidar/main.c:149
+#, fuzzy
+msgid "Layer number to store generated point ID as category"
+msgstr "출력할 격자지도"
-#: ../display/d.grid/main.c:138
-msgid "Draw geographic grid (referenced to WGS84 ellipsoid)"
-msgstr ""
+#: ../vector/v.out.lidar/main.c:498 ../vector/v.out.lidar/main.c:505
+#: ../vector/v.out.lidar/main.c:512 ../vector/v.out.lidar/main.c:519
+#: ../vector/v.in.lidar/main.c:152 ../vector/v.in.lidar/main.c:160
+#: ../vector/v.in.lidar/main.c:168 ../vector/v.in.lidar/main.c:176
+#, fuzzy
+msgid "Categories"
+msgstr "출력할 격자지도"
-#: ../display/d.grid/main.c:143
-msgid "Draw '+' marks instead of grid lines"
-msgstr ""
+#: ../vector/v.out.lidar/main.c:503
+#, fuzzy
+msgid "Layer number to store return number as category"
+msgstr "출력할 격자지도"
-#: ../display/d.grid/main.c:148
-msgid "Draw '.' marks instead of grid lines"
-msgstr ""
+#: ../vector/v.out.lidar/main.c:510 ../vector/v.in.lidar/main.c:165
+#, fuzzy
+msgid "Layer number to store class number as category"
+msgstr "출력할 격자지도"
-#: ../display/d.grid/main.c:153
-msgid "Draw fiducial marks instead of grid lines"
-msgstr ""
+#: ../vector/v.out.lidar/main.c:517
+#, fuzzy
+msgid "Layer number where RGB color is stored as category"
+msgstr "출력할 격자지도"
-#: ../display/d.grid/main.c:158
-msgid "Disable grid drawing"
-msgstr ""
+#: ../vector/v.out.lidar/main.c:525 ../vector/v.out.lidar/main.c:531
+#: ../vector/v.out.lidar/main.c:537
+#, fuzzy
+msgid "Column with return number"
+msgstr "출력할 격자지도"
-#: ../display/d.grid/main.c:163
-msgid "Disable border drawing"
+#: ../vector/v.out.lidar/main.c:527 ../vector/v.out.lidar/main.c:533
+#: ../vector/v.out.lidar/main.c:539 ../vector/v.out.lidar/main.c:546
+#: ../vector/v.out.lidar/main.c:552 ../vector/v.out.lidar/main.c:558
+#: ../vector/v.out.lidar/main.c:564 ../vector/v.net.centrality/main.c:149
+#: ../vector/v.net.centrality/main.c:155 ../vector/v.net.centrality/main.c:161
+#: ../vector/v.net.centrality/main.c:167
+msgid "Columns"
msgstr ""
-#: ../display/d.grid/main.c:168
-msgid "Disable text drawing"
-msgstr ""
+#: ../vector/v.out.lidar/main.c:543
+#, fuzzy
+msgid "RGB color definition column"
+msgstr "출력할 격자지도"
-#: ../display/d.grid/main.c:178
-msgid "Both grid and border drawing are disabled"
+#: ../vector/v.out.lidar/main.c:550
+msgid "Column with red color"
msgstr ""
-#: ../display/d.grid/main.c:182
-msgid "Geo-grid option not available for LL projection, use without -g/-w"
+#: ../vector/v.out.lidar/main.c:556
+msgid "Column with green color"
msgstr ""
-#: ../display/d.grid/main.c:184
-msgid "Geo-grid option not available for XY projection, use without -g/-w"
+#: ../vector/v.out.lidar/main.c:562
+msgid "Column with blue color"
msgstr ""
-#: ../display/d.grid/main.c:203
-msgid "Choose a single mark style"
+#: ../vector/v.out.lidar/main.c:571
+msgid "Internal scale to apply to X and Y values"
msgstr ""
-#: ../display/d.grid/main.c:234
-#, c-format
-msgid "Invalid geo-grid size <%s>"
+#: ../vector/v.out.lidar/main.c:572 ../vector/v.out.lidar/main.c:582
+msgid ""
+"This scale does not change the values itself but only how precisely they are "
+"stored, for example 0.01 will preserve two decimal places"
msgstr ""
-#: ../display/d.grid/main.c:239
-#, c-format
-msgid "Invalid grid size <%s>"
+#: ../vector/v.out.lidar/main.c:581
+msgid "Internal scale to apply to z values"
msgstr ""
-#: ../display/d.grid/fiducial.c:61
+#: ../vector/v.out.lidar/main.c:589
#, fuzzy
-msgid "Reading symbol"
+msgid "Limit export to the current region"
msgstr "출력할 격자지도"
-#: ../display/d.colorlist/main.c:39
-msgid "Outputs a list of all available display colors."
-msgstr ""
+#: ../vector/v.out.lidar/main.c:593
+#, fuzzy
+msgid "Ignore color table"
+msgstr "색상표"
-#: ../display/d.legend/histogram.c:115
-msgid ""
-"Histogram constrained by range not yet implemented for categorical rasters"
+#: ../vector/v.out.lidar/main.c:595
+msgid "Ignore color table even when set and not other options are present"
msgstr ""
-#: ../display/d.legend/main.c:82
+#: ../vector/v.mkgrid/hexgrid.c:86
#, fuzzy
-msgid ""
-"Displays a legend for a 2D or 3D raster map in the active frame of the "
-"graphics monitor."
+msgid "Writing out hexagon grid..."
msgstr "출력할 격자지도"
-#: ../display/d.legend/main.c:108
+#: ../vector/v.mkgrid/write_grid.c:68
#, fuzzy
-msgid "Default: Same as fontsize"
+msgid "Writing out vector rows..."
msgstr "출력할 격자지도"
-#: ../display/d.legend/main.c:117
-msgid "Number of text lines (useful for truncating long legends)"
+#: ../vector/v.mkgrid/write_grid.c:107
+#, fuzzy
+msgid "Writing out vector columns..."
+msgstr "출력할 격자지도"
+#: ../vector/v.mkgrid/main.c:74
+msgid "hexagon"
msgstr ""
-#: ../display/d.legend/main.c:127
-msgid "Thinning factor (thin=10 gives cats 0,10,20...)"
+#: ../vector/v.mkgrid/main.c:75
+msgid "Creates a vector map of a user-defined grid."
msgstr ""
-#: ../display/d.legend/main.c:135
-msgid "Units to display after labels (e.g. meters)"
+#: ../vector/v.mkgrid/main.c:82
+msgid "rows,columns"
msgstr ""
-#: ../display/d.legend/main.c:144
-msgid "Number of text labels for smooth gradient legend"
+#: ../vector/v.mkgrid/main.c:86
+msgid "Number of rows and columns in grid"
msgstr ""
-#: ../display/d.legend/main.c:145 ../display/d.legend/main.c:154
-#: ../display/d.legend/main.c:161 ../display/d.legend/main.c:263
-#: ../display/d.legend/main.c:273 ../display/d.legend/main.c:283
+#: ../vector/v.mkgrid/main.c:95
+msgid "Where to place the grid"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:99
#, fuzzy
-msgid "Gradient"
+msgid "current region"
msgstr "출력할 격자지도"
-#: ../display/d.legend/main.c:151
-msgid "Specific values to draw ticks"
+#: ../vector/v.mkgrid/main.c:100
+msgid "use 'coor' and 'box' options"
msgstr ""
-#: ../display/d.legend/main.c:160
-msgid "Display label every step"
+#: ../vector/v.mkgrid/main.c:105
+msgid "Lower left easting and northing coordinates of map"
msgstr ""
-#: ../display/d.legend/main.c:167
+#: ../vector/v.mkgrid/main.c:109
+msgid "width,height"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:113
+msgid "Width and height of boxes in grid"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:120
+msgid "Angle of rotation (in degrees counter-clockwise)"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:128
#, fuzzy
-msgid "Number of digits after decimal point"
+msgid "Number of vertex points per grid cell"
msgstr "출력할 격자지도"
-#: ../display/d.legend/main.c:179
-msgid ""
-"Size and placement as percentage of screen coordinates (0,0 is lower left)"
+#: ../vector/v.mkgrid/main.c:141
+msgid "Create hexagons (default: rectangles)"
msgstr ""
-#: ../display/d.legend/main.c:189
-msgid "List of discrete category numbers/values for legend"
+#: ../vector/v.mkgrid/main.c:146
+msgid "Allow asymmetric hexagons"
msgstr ""
-#: ../display/d.legend/main.c:191 ../display/d.legend/main.c:200
-msgid "Subset"
-msgstr "부분집합"
+#: ../vector/v.mkgrid/main.c:186
+msgid "'coor' and 'position=region' are exclusive options"
+msgstr ""
-#: ../display/d.legend/main.c:199
-msgid "Use a subset of the map range for the legend (min,max)"
+#: ../vector/v.mkgrid/main.c:189
+msgid "'box' and 'grid' are exclusive options for 'position=region'"
msgstr ""
-#: ../display/d.legend/main.c:219
-msgid "Default: Auto-scaled"
-msgstr "기본값: 자동축척"
+#: ../vector/v.mkgrid/main.c:212 ../vector/v.mkgrid/main.c:248
+#, fuzzy
+msgid "Invalid width"
+msgstr "출력할 격자지도"
-#: ../display/d.legend/main.c:252
-msgid "Do not show category labels"
-msgstr ""
+#: ../vector/v.mkgrid/main.c:215 ../vector/v.mkgrid/main.c:251
+#, fuzzy
+msgid "Invalid height"
+msgstr "출력할 격자지도"
-#: ../display/d.legend/main.c:257
-msgid "Do not show category numbers"
+#: ../vector/v.mkgrid/main.c:231
+msgid "'grid' option missing"
msgstr ""
-#: ../display/d.legend/main.c:262
-msgid "Draw legend ticks for labels"
+#: ../vector/v.mkgrid/main.c:234
+msgid "'coor' option missing"
msgstr ""
-#: ../display/d.legend/main.c:267
-msgid "Skip categories with no label"
+#: ../vector/v.mkgrid/main.c:237
+msgid "'box' option missing"
msgstr ""
-#: ../display/d.legend/main.c:282
-msgid "Add histogram to smoothed legend"
+#: ../vector/v.mkgrid/main.c:241
+msgid "Invalid easting"
msgstr ""
-#: ../display/d.legend/main.c:287
-msgid "Show background"
+#: ../vector/v.mkgrid/main.c:244
+msgid "Invalid northing"
msgstr ""
-#: ../display/d.legend/main.c:292
-msgid "Use logarithmic scale"
+#: ../vector/v.mkgrid/main.c:309
+msgid "The hexagons will be asymmetrical."
msgstr ""
-#: ../display/d.legend/draw.c:109
-msgid "Legend box lies outside of frame. Text may not display properly."
+#: ../vector/v.mkgrid/main.c:322 ../vector/v.mkgrid/main.c:325
+msgid "Please use a higher resolution or a larger region"
msgstr ""
-#: ../display/d.legend/draw.c:114
-msgid "Drawing horizontal legend as box width exceeds height"
+#: ../vector/v.mkgrid/main.c:329
+#, c-format
+msgid "The number of rows has been adjusted from %d to %d"
msgstr ""
-#: ../display/d.legend/draw.c:126
+#: ../vector/v.mkgrid/main.c:332
#, c-format
-msgid "Range information for <%s> not available (run r.support)"
+msgid "The number of columns has been adjusted from %d to %d"
msgstr ""
-#: ../display/d.legend/draw.c:131
+#: ../vector/v.mkgrid/main.c:361 ../vector/v.mkgrid/main.c:446
+#: ../vector/v.mkgrid/main.c:458
#, fuzzy
-msgid "Input map contains no data"
+msgid "Unable to fill attribute table"
msgstr "출력할 격자지도"
-#: ../display/d.legend/draw.c:145
-msgid "Requested range exceeds lower limit of actual data"
+#: ../vector/v.mkgrid/main.c:372
+msgid "The rectangles will be asymmetrical."
msgstr ""
-#: ../display/d.legend/draw.c:152
-msgid "Requested range exceeds upper limit of actual data"
-msgstr ""
+#: ../vector/v.mkgrid/main.c:417
+#, fuzzy
+msgid "Creating centroids..."
+msgstr "출력할 격자지도"
-#: ../display/d.legend/draw.c:214
-#, c-format
-msgid "use=%s out of range [%d,%d] (extend with range= ?)"
-msgstr ""
+#: ../vector/v.out.ascii/args.c:31
+#, fuzzy
+msgid "Name for output ASCII file or ASCII vector name if '-o' is defined"
+msgstr "출력할 격자지도"
-#: ../display/d.legend/draw.c:239
-msgid "Nothing to draw! (no categories with labels? out of range?)"
+#: ../vector/v.out.ascii/args.c:38
+msgid "Name of attribute column(s) to be exported (point mode)"
msgstr ""
-#: ../display/d.legend/draw.c:250
-msgid "Forcing a smooth legend: too many categories for current window height"
+#: ../vector/v.out.ascii/args.c:39
+msgid "\"*\" for all columns"
msgstr ""
-#: ../display/d.legend/draw.c:301
-msgid "Color range exceeds lower limit of actual data"
+#: ../vector/v.out.ascii/args.c:59
+msgid "Simple point format (point per row)"
msgstr ""
-#: ../display/d.legend/draw.c:305
-msgid "Color range exceeds upper limit of actual data"
+#: ../vector/v.out.ascii/args.c:60
+#, fuzzy
+msgid "GRASS ASCII vector format"
+msgstr "출력할 격자지도"
+#: ../vector/v.out.ascii/args.c:61
+msgid "OGC well-known text"
msgstr ""
-#: ../display/d.legend/draw.c:312
-#, c-format
-msgid "Range [%.3f, %.3f] out of the logarithm domain."
+#: ../vector/v.out.ascii/args.c:65
+msgid "Field separator (points mode)"
msgstr ""
-#: ../display/d.legend/draw.c:319
-#, c-format
-msgid "use=%s out of range [%.3f, %.3f] (extend with range= ?)"
+#: ../vector/v.out.ascii/args.c:80
+msgid "Create old (version 4) ASCII file"
msgstr ""
-#: ../display/d.legend/draw.c:613
-#, c-format
-msgid "tick_value=%.3f out of range [%.3f, %.3f]"
+#: ../vector/v.out.ascii/args.c:85
+msgid "Include column names in output (points mode)"
msgstr ""
-#: ../display/d.legend/draw.c:1029
-msgid ""
-"Histogram plotting not implemented for categorical legends. Use the '-s' flag"
+#: ../vector/v.out.ascii/args.c:91
+msgid "Only export points falling within current 3D region (points mode)"
msgstr ""
-#: ../display/d.legend/draw.c:1286
-msgid "Nothing to draw! (no categories with labels?)"
+#: ../vector/v.out.ascii/main.c:51
+msgid "Exports a vector map to a GRASS ASCII vector representation."
msgstr ""
-#: ../display/d.font/main.c:48
+#: ../vector/v.out.ascii/main.c:52
msgid ""
-"Selects the font in which text will be displayed on the user's graphics "
-"monitor."
+"By default only features with category are exported. To export all features "
+"use 'layer=-1'."
msgstr ""
-#: ../display/d.font/main.c:56
-msgid "Choose new current font"
-msgstr ""
+#: ../vector/v.out.ascii/main.c:60
+#, fuzzy, c-format
+msgid "Parameter '%s' ignored in standard mode"
+msgstr "출력할 격자지도"
-#: ../display/d.font/main.c:62
-msgid "Path to Freetype-compatible font including file name"
-msgstr ""
+#: ../vector/v.out.ascii/main.c:69
+#, fuzzy, c-format
+msgid "Format '%s' is not supported for old version"
+msgstr "출력할 격자지도"
-#: ../display/d.font/main.c:70
-msgid "Character encoding"
+#: ../vector/v.out.ascii/main.c:73
+#, c-format
+msgid "Parameter '%s' must be given for old version"
msgstr ""
-#: ../display/d.font/main.c:74
-msgid "List fonts"
+#: ../vector/v.out.ascii/main.c:80
+#, fuzzy, c-format
+msgid ""
+"Unable to open vector map <%s> at topology level. Areas will not be "
+"processed."
+msgstr "출력할 격자지도"
+#: ../vector/v.out.ascii/main.c:107
+#, fuzzy, c-format
+msgid "%d error in <%s> option"
+msgid_plural "%d errors in <%s> option"
+#: ../vector/v.out.ascii/main.c:141
+msgid "dig_att file already exist"
msgstr ""
-#: ../display/d.font/main.c:103
+#: ../vector/v.out.ascii/main.c:144
#, fuzzy, c-format
-msgid "Unable to access font path %s: %s"
+msgid "Unable to open dig_att file <%s>"
msgstr "출력할 격자지도"
-#: ../display/d.font/main.c:107
-#, c-format
-msgid "Font path %s is not a file"
-msgstr ""
+#: ../vector/v.out.ascii/main.c:149
+#, fuzzy
+msgid "Fetching data..."
+msgstr "출력할 격자지도"
-#: ../display/d.font/main.c:124
-#, c-format
-msgid ""
-"Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
+#: ../vector/v.out.ascii/main.c:156
+msgid "No points found, nothing to be exported"
msgstr ""
-#: ../display/d.his/main.c:69
-msgid ""
-"Displays the result obtained by combining hue, intensity, and saturation "
-"(HIS) values from user-specified input raster map layers."
+#: ../vector/v.out.ascii/main.c:159
+msgid "No features found, nothing to be exported"
msgstr ""
-#: ../display/d.his/main.c:97
-msgid "Percent to brighten intensity channel"
+#: ../vector/v.out.ascii/main.c:163
+msgid "An error occurred, nothing to be exported"
msgstr ""
-#: ../display/d.his/main.c:103
-msgid "Respect NULL values while drawing"
+#: ../vector/v.lidar.growing/main.c:78
+msgid ""
+"Building contour determination and Region Growing algorithm for determining "
+"the building inside"
msgstr ""
-#: ../general/g.mkfontcap/main.c:73
-msgid ""
-"Generates the font configuration file by scanning various directories for "
-"fonts."
+#: ../vector/v.lidar.growing/main.c:83
+msgid "Input vector (v.lidar.edgedetection output)"
msgstr ""
-#: ../general/g.mkfontcap/main.c:79
-msgid "Overwrite font configuration file if already existing"
+#: ../vector/v.lidar.growing/main.c:93
+msgid "Name of the first pulse vector map"
msgstr ""
-#: ../general/g.mkfontcap/main.c:84
-msgid ""
-"Write font configuration file to standard output instead of $GISBASE/etc"
+#: ../vector/v.lidar.growing/main.c:100
+msgid "Threshold for cell object frequency in region growing"
msgstr ""
-#: ../general/g.mkfontcap/main.c:91
-msgid "List of extra directories to scan"
+#: ../vector/v.lidar.growing/main.c:108
+msgid "Threshold for double pulse in region growing"
msgstr ""
-#: ../general/g.mkfontcap/main.c:93
-msgid ""
-"Comma-separated list of extra directories to scan for Freetype-compatible "
-"fonts as well as the defaults (see documentation)"
+#: ../vector/v.lidar.growing/main.c:176
+#, fuzzy, c-format
+msgid "Unable to open table <%s>"
+msgstr "출력할 격자지도"
+#: ../vector/v.lidar.growing/main.c:201
+msgid "Setting regions and boxes"
msgstr ""
-#: ../general/g.mkfontcap/main.c:110
+#: ../vector/v.lidar.growing/main.c:267
#, c-format
-msgid ""
-"Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
+msgid "Rows = %d"
msgstr ""
-#: ../general/g.mkfontcap/main.c:122
-msgid ""
-"This GRASS installation was compiled without Freetype support, extradirs "
-"parameter ignored"
+#: ../vector/v.lidar.growing/main.c:268
+#, c-format
+msgid "Columns = %d"
msgstr ""
-#: ../general/g.mkfontcap/main.c:149
-#, fuzzy, c-format
-msgid "Cannot open %s for writing: %s"
-msgstr "출력할 격자지도"
-#: ../general/g.mkfontcap/freetype_fonts.c:55
+#: ../vector/v.lidar.growing/main.c:288
#, fuzzy
-msgid "Unable to initialise Freetype"
+msgid "read points in input vector"
msgstr "출력할 격자지도"
-#: ../general/g.mapset/main.c:51
+#: ../vector/v.lidar.growing/main.c:437
#, fuzzy
-msgid "Changes/reports current mapset."
+msgid "Region Growing"
msgstr "출력할 격자지도"
-#: ../general/g.mapset/main.c:52
-msgid ""
-"Optionally create new mapset or list available mapsets in given location."
+#: ../vector/v.lidar.growing/ConvexHull.c:269
+msgid "...now exiting to system..."
msgstr ""
-#: ../general/g.mapset/main.c:56
+#: ../vector/v.overlay/main.c:65 ../vector/v.select/main.c:50
+msgid "spatial query"
+msgstr ""
+#: ../vector/v.overlay/main.c:66
+msgid "clip"
+msgstr ""
+#: ../vector/v.overlay/main.c:67
+msgid "difference"
+msgstr ""
+#: ../vector/v.overlay/main.c:68
#, fuzzy
-msgid "Name of mapset where to switch"
+msgid "intersection"
msgstr "출력할 격자지도"
-#: ../general/g.mapset/main.c:57 ../general/g.mapset/main.c:61
-#: ../general/g.mapset/main.c:64
-msgid "Mapset"
+#: ../vector/v.overlay/main.c:69
+msgid "union"
msgstr ""
-#: ../general/g.mapset/main.c:68
-msgid "Create mapset if it doesn't exist"
+#: ../vector/v.overlay/main.c:70
+msgid ""
+"Overlays two vector maps offering clip, intersection, difference, "
+"symmetrical difference, union operators."
msgstr ""
-#: ../general/g.mapset/main.c:75
-msgid "List available mapsets and exit"
-msgstr ""
+#: ../vector/v.overlay/main.c:73
+#, fuzzy
+msgid "Name of input vector map (A)"
+msgstr "출력할 격자지도"
-#: ../general/g.mapset/main.c:81
+#: ../vector/v.overlay/main.c:77
#, fuzzy
-msgid "Print current mapset and exit"
+msgid "Layer number or name (vector map A)"
msgstr "출력할 격자지도"
-#: ../general/g.mapset/main.c:136
-#, fuzzy, c-format
-msgid "<%s> is already the current mapset"
+#: ../vector/v.overlay/main.c:81 ../vector/v.select/args.c:21
+#, fuzzy
+msgid "Feature type (vector map A)"
msgstr "출력할 격자지도"
-#: ../general/g.mapset/main.c:145
-#, c-format
-msgid "You don't have permission to use the mapset <%s>"
-msgstr ""
+#: ../vector/v.overlay/main.c:87
+#, fuzzy
+msgid "Name of input vector map (B)"
+msgstr "출력할 격자지도"
-#: ../general/g.mapset/main.c:153
-#, fuzzy, c-format
-msgid "Unable to create new mapset <%s>"
+#: ../vector/v.overlay/main.c:91
+#, fuzzy
+msgid "Layer number or name (vector map B)"
msgstr "출력할 격자지도"
-#: ../general/g.mapset/main.c:156
-#, fuzzy, c-format
-msgid "Mapset <%s> does not exist. Use -c flag to create it."
+#: ../vector/v.overlay/main.c:95 ../vector/v.select/args.c:36
+#, fuzzy
+msgid "Feature type (vector map B)"
msgstr "출력할 격자지도"
-#: ../general/g.mapset/main.c:166
+#: ../vector/v.overlay/main.c:106
#, fuzzy
-msgid "Unable to read GIS_LOCK environment variable"
+msgid "Operator defines features written to output vector map"
msgstr "출력할 격자지도"
-#: ../general/g.mapset/main.c:182
-#, c-format
-msgid "Lock file of mapset <%s> cannot be checked"
+#: ../vector/v.overlay/main.c:109
+msgid ""
+"Feature is written to output if the result of operation 'ainput operator "
+"binput' is true. Input feature is considered to be true, if category of "
+"given layer is defined."
msgstr ""
-#: ../general/g.mapset/main.c:185
-#, c-format
-msgid "There appears to be an active GRASS session in selected mapset <%s>"
+#: ../vector/v.overlay/main.c:116
+msgid "also known as 'intersection' in GIS"
msgstr ""
-#: ../general/g.mapset/main.c:191
-#, fuzzy
-msgid "Cleaning up temporary files..."
-msgstr "출력할 격자지도"
+#: ../vector/v.overlay/main.c:117
+msgid "also known as 'union' in GIS (only for atype=area)"
+msgstr ""
-#: ../general/g.mapset/main.c:205
+#: ../vector/v.overlay/main.c:118
msgid ""
-"Mapset switched. Your shell continues to use the history for the old mapset"
+"also known as 'difference' (features from ainput not overlayed by features "
+"from binput)"
msgstr ""
-#: ../general/g.mapset/main.c:210
-#, c-format
+#: ../vector/v.overlay/main.c:120
msgid ""
-"You can switch the history by commands:\n"
-"history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
+"also known as 'symmetrical difference' (features from either ainput or "
+"binput but not those from ainput overlayed by binput (only for atype=area)"
msgstr ""
-#: ../general/g.mapset/main.c:215
-#, c-format
-msgid ""
-"history -S; history -L %s/.history; setenv histfile=%s/.history"
+#: ../vector/v.overlay/main.c:131
+msgid "Output layer for new category, ainput and binput"
msgstr ""
-#: ../general/g.mapset/main.c:221
-#, c-format
-msgid "Your current mapset is <%s>"
+#: ../vector/v.overlay/main.c:132
+msgid "If 0 or not given, the category is not written"
msgstr ""
-#: ../general/g.cairocomp/main.c:49
+#: ../vector/v.overlay/main.c:139
+msgid "Snapping threshold for boundaries"
+msgstr ""
+#: ../vector/v.overlay/main.c:140
+msgid "Disable snapping with snap <= 0"
+msgstr ""
+#: ../vector/v.overlay/main.c:178 ../vector/v.select/main.c:85
#, fuzzy, c-format
-msgid "Unable to read input file <%s>"
+msgid "Unknown operator '%s'"
msgstr "출력할 격자지도"
-#: ../general/g.cairocomp/main.c:52
+#: ../vector/v.overlay/main.c:195
#, fuzzy, c-format
-msgid "Unable to parse input file <%s>"
+msgid "Unable to determine feature type for <%s>"
msgstr "출력할 격자지도"
-#: ../general/g.cairocomp/main.c:71
+#: ../vector/v.overlay/main.c:201
#, fuzzy, c-format
-msgid "Unable to write output file <%s>"
+msgid "Invalid feature type (%d) for <%s>. Only '%s' or '%s' supported."
msgstr "출력할 격자지도"
-#: ../general/g.cairocomp/main.c:113
+#: ../vector/v.overlay/main.c:209
+#, c-format
+msgid "Operator '%s' is not supported for type line"
+msgstr ""
+#: ../vector/v.overlay/main.c:227 ../vector/v.in.ogr/main.c:931
+#: ../vector/v.buffer/main.c:400
#, fuzzy
-msgid "Unable to obtain visual"
+msgid "Unable to create temporary vector map"
msgstr "출력할 격자지도"
-#: ../general/g.cairocomp/main.c:129
+#: ../vector/v.overlay/main.c:264
+#, c-format
+msgid "Copying vector features from <%s>..."
+msgstr "<%s>로부터 벡터피쳐를 복사하는 중..."
+#: ../vector/v.overlay/main.c:345
+#, c-format
+msgid "No %s features found in vector map <%s>. Verify '%s' parameter."
+msgstr ""
+#: ../vector/v.overlay/main.c:394
#, fuzzy
-msgid "Failed to initialize output surface"
+msgid "Collecting input attributes..."
msgstr "출력할 격자지도"
-#: ../general/g.cairocomp/main.c:150 ../general/g.pnmcomp/main.c:38
+#: ../vector/v.overlay/main.c:474
+#, fuzzy, c-format
+msgid "Unknown column type '%s' of column '%s'"
+msgstr "출력할 격자지도"
+#: ../vector/v.overlay/main.c:539
#, c-format
-msgid "Invalid color: %s"
+msgid "Unknown column type '%s' of column '%s', values lost"
msgstr ""
-#: ../general/g.cairocomp/main.c:171
+#: ../vector/v.overlay/line_area.c:255 ../vector/v.overlay/area_area.c:109
+msgid "Breaking lines..."
+msgstr "선을 분해하는 중..."
+#: ../vector/v.overlay/line_area.c:272
#, fuzzy
-msgid "Failed to initialize input surface"
+msgid "Selecting lines..."
msgstr "출력할 격자지도"
-#: ../general/g.cairocomp/main.c:198
+#: ../vector/v.overlay/line_area.c:354 ../vector/v.overlay/line_area.c:382
+#: ../vector/v.overlay/area_area.c:208 ../vector/v.overlay/area_area.c:290
+#: ../vector/v.overlay/area_area.c:318
#, fuzzy
-msgid "Overlays multiple X Pixmaps."
+msgid "Attribute not found"
msgstr "출력할 격자지도"
-#: ../general/g.cairocomp/main.c:203 ../general/g.pnmcomp/main.c:290
+#: ../vector/v.overlay/area_area.c:51
+#, c-format
+msgid "Snapping boundaries with %g ..."
+msgstr "%g 임계치로 경계를 끌어붙이는 중..."
+#: ../vector/v.overlay/area_area.c:99
+#, fuzzy, c-format
+msgid "%d boundary snapped"
+msgid_plural "%d boundaries snapped"
+#: ../vector/v.overlay/area_area.c:113 ../vector/v.in.ogr/main.c:1357
+#: ../vector/v.in.ogr/main.c:1371 ../vector/v.delaunay/main.c:144
+#: ../vector/v.buffer/main.c:741 ../vector/v.buffer/main.c:748
+msgid "Removing duplicates..."
+msgstr "중복을 지우는 중..."
+#: ../vector/v.overlay/area_area.c:116 ../vector/v.in.ogr/main.c:1375
+msgid "Cleaning boundaries at nodes..."
+msgstr "정점에 있는 경계를 정리하는 중..."
+#: ../vector/v.overlay/area_area.c:154
+msgid "Merging lines..."
+msgstr "선을 합치는 중..."
+#: ../vector/v.overlay/area_area.c:158 ../vector/v.buffer/main.c:765
+msgid "Attaching islands..."
+msgstr "섬을 붙이는 중..."
+#: ../vector/v.overlay/area_area.c:171 ../vector/v.buffer/main.c:786
+msgid "Cannot calculate area centroid"
+msgstr ""
+#: ../vector/v.overlay/area_area.c:181
+#, c-format
+msgid "Querying vector map <%s>..."
+msgstr "벡터지도 <%s>를 검색하는 중..."
+#: ../vector/v.overlay/area_area.c:218 ../vector/v.in.ogr/main.c:1492
+msgid "Writing centroids..."
+msgstr "중심점을 쓰는 중..."
+#: ../vector/v.in.ogr/geom.c:76 ../vector/v.in.ogr/geom.c:261
+#: ../vector/v.in.ogr/geom.c:275 ../vector/v.in.ogr/geom.c:304
+#: ../vector/v.in.ogr/geom.c:352
+#, fuzzy, c-format
+msgid "Skipping empty geometry feature %d"
+msgstr "출력할 격자지도"
+#: ../vector/v.in.ogr/geom.c:199 ../vector/v.in.ogr/geom.c:220
#, fuzzy
-msgid "Name of input file(s)"
+msgid "Unable to read part of geometry"
msgstr "출력할 격자지도"
-#: ../general/g.cairocomp/main.c:212
-msgid "Output Visual XID"
+#: ../vector/v.in.ogr/geom.c:320
+#, c-format
+msgid "Feature (cat %d): degenerated polygon (%d vertices)"
msgstr ""
-#: ../general/g.cairocomp/main.c:218
-msgid "Output screen"
+#: ../vector/v.in.ogr/geom.c:366
+#, c-format
+msgid "Degenerate island (%d vertices)"
msgstr ""
-#: ../general/g.cairocomp/main.c:224 ../general/g.pnmcomp/main.c:302
-msgid "Layer opacities"
+#: ../vector/v.in.ogr/geom.c:400
+#, fuzzy
+msgid "Unable calculate centroid"
+msgstr "출력할 격자지도"
+#: ../vector/v.in.ogr/geom.c:431
+msgid "No centroid written for polygon with 0 vertices"
msgstr ""
-#: ../general/g.cairocomp/main.c:230 ../general/g.pnmcomp/main.c:315
-msgid "Image width"
+#: ../vector/v.in.ogr/geom.c:452
+#, fuzzy
+msgid "Unable to write part of geometry"
+msgstr "출력할 격자지도"
+#: ../vector/v.in.ogr/geom.c:458
+msgid "Unknown geometry type"
msgstr ""
-#: ../general/g.cairocomp/main.c:236 ../general/g.pnmcomp/main.c:321
-msgid "Image height"
+#: ../vector/v.in.ogr/main.c:138
+#, fuzzy
+msgid "Imports vector data into a GRASS vector map using OGR library."
+msgstr "출력할 격자지도"
+#: ../vector/v.in.ogr/main.c:145
+msgid ""
+"Examples:\n"
+"\t\tESRI Shapefile: directory containing shapefiles\n"
+"\t\tMapInfo File: directory containing mapinfo files"
msgstr ""
-#: ../general/g.cairocomp/main.c:240
-msgid "Background color (R:G:B:A)"
+#: ../vector/v.in.ogr/main.c:158
+msgid ""
+"Examples:\n"
+"\t\tESRI Shapefile: shapefile name\n"
+"\t\tMapInfo File: mapinfo file name"
msgstr ""
-#: ../general/g.cairocomp/main.c:245
-msgid "Do not composite; just delete input Pixmaps"
+#: ../vector/v.in.ogr/main.c:173 ../vector/v.in.lidar/main.c:184
+msgid "Import subregion only"
msgstr ""
-#: ../general/g.cairocomp/main.c:277
-msgid "input= and opacity= must have the same number of values"
+#: ../vector/v.in.ogr/main.c:176 ../vector/v.in.lidar/main.c:187
+msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
msgstr ""
-#: ../general/g.version/main.c:66 ../general/g.tempfile/main.c:39
-#: ../general/g.message/main.c:34
-msgid "support"
-msgstr "지원"
+#: ../vector/v.in.ogr/main.c:187
+msgid "Minimum size of area to be imported (square meters)"
+msgstr ""
-#: ../general/g.version/main.c:67
-msgid "citing"
+#: ../vector/v.in.ogr/main.c:189
+msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
msgstr ""
-#: ../general/g.version/main.c:68
-msgid "copyright"
+#: ../vector/v.in.ogr/main.c:195
+msgid "Optionally change default input type"
msgstr ""
-#: ../general/g.version/main.c:69
+#: ../vector/v.in.ogr/main.c:199
#, fuzzy
-msgid "version"
-msgstr "변환"
+msgid "import area centroids as points"
+msgstr "출력할 격자지도"
-#: ../general/g.version/main.c:70
-msgid "license"
-msgstr ""
+#: ../vector/v.in.ogr/main.c:200
+#, fuzzy
+msgid "import area boundaries as lines"
+msgstr "출력할 격자지도"
-#: ../general/g.version/main.c:71
+#: ../vector/v.in.ogr/main.c:201
#, fuzzy
-msgid "Displays GRASS GIS version info."
+msgid "import lines as area boundaries"
msgstr "출력할 격자지도"
-#: ../general/g.version/main.c:72
+#: ../vector/v.in.ogr/main.c:202
#, fuzzy
-msgid "Optionally also prints build or copyright information."
+msgid "import points as centroids"
msgstr "출력할 격자지도"
-#: ../general/g.version/main.c:76
-msgid "Print also the copyright message"
+#: ../vector/v.in.ogr/main.c:224
+msgid ""
+"List of column names to be used instead of original names, first is used for "
+"category column"
msgstr ""
-#: ../general/g.version/main.c:77 ../general/g.version/main.c:82
-#: ../general/g.version/main.c:87 ../general/g.version/main.c:93
-#: ../general/g.version/main.c:99
-msgid "Additional info"
-msgstr ""
-#: ../general/g.version/main.c:81
+#: ../vector/v.in.ogr/main.c:243
#, fuzzy
-msgid "Print also the citation options"
+msgid "Name of column used for categories"
msgstr "출력할 격자지도"
-#: ../general/g.version/main.c:86
+#: ../vector/v.in.ogr/main.c:245
+msgid ""
+"If not given, categories are generated as unique values and stored in 'cat' "
+"column"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:250
#, fuzzy
-msgid "Print also the build information"
+msgid "Name of geometry column"
msgstr "출력할 격자지도"
-#: ../general/g.version/main.c:92
-msgid "Print also the GIS library revision number and date"
+#: ../vector/v.in.ogr/main.c:251
+msgid "If not given, all geometry columns from the input are used"
msgstr ""
-#: ../general/g.version/main.c:97
-msgid "Print also extended info for additional libraries"
+#: ../vector/v.in.ogr/main.c:269
+msgid "Do not clean polygons (not recommended)"
msgstr ""
-#: ../general/g.version/main.c:98
-msgid "GDAL/OGR, PROJ.4, GEOS"
+#: ../vector/v.in.ogr/main.c:274
+msgid "Force 2D output even if input is 3D"
msgstr ""
-#: ../general/g.version/main.c:103
-#, fuzzy
-msgid "Print info in shell script style (including SVN revision number)"
-msgstr "출력할 격자지도"
+#: ../vector/v.in.ogr/main.c:298 ../vector/v.in.lidar/main.c:282
+msgid "Limit import to the current region"
+msgstr ""
-#: ../general/g.version/main.c:104
-msgid "Shell"
+#: ../vector/v.in.ogr/main.c:310
+msgid "Change column names to lowercase characters"
msgstr ""
-#: ../general/g.version/main.c:172
+#: ../vector/v.in.ogr/main.c:316 ../vector/v.in.lidar/main.c:326
+msgid ""
+"Create the location specified by the \"location\" parameter and exit. Do not "
+"import the vector data."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:408
+#, fuzzy, c-format
+msgid "Unable to open data source <%s>"
+msgstr "출력할 격자지도"
+#: ../vector/v.in.ogr/main.c:413
#, c-format
msgid ""
-"Cannot determine GRASS libgis version and date number. The GRASS build might "
-"be broken. Report this to developers or packagers.\n"
+"Option <%s> will be ignored. OGR doesn't support it for selected format (%s)."
msgstr ""
-#: ../general/g.version/main.c:179
+#: ../vector/v.in.ogr/main.c:418
+#, c-format
msgid ""
-"GRASS GIS libgis version and date number don't have the expected format. "
-"Trying to print the original strings..."
+"Option <%s> will be ignored. Multiple geometry fields are supported by GDAL "
+">= 1.11"
msgstr ""
-#: ../general/g.version/main.c:181
+#: ../vector/v.in.ogr/main.c:431
#, c-format
-msgid "GIS_H_VERSION=\"%s\""
+msgid "Encoding value not supported by OGR driver <%s>"
msgstr ""
-#: ../general/g.version/main.c:182
+#: ../vector/v.in.ogr/main.c:440
#, c-format
-msgid "GIS_H_DATE=\"%s\""
+msgid "Data source <%s> (format '%s') contains %d layers:"
msgstr ""
-#: ../general/g.version/main.c:212
-msgid "GRASS not compiled with GDAL/OGR support"
+#: ../vector/v.in.ogr/main.c:495
+#, fuzzy
+msgid "No OGR layers available"
+msgstr "출력할 격자지도"
+#: ../vector/v.in.ogr/main.c:498
+#, fuzzy, c-format
+msgid "All available OGR layers will be imported into vector map <%s>"
+msgstr "출력할 격자지도"
+#: ../vector/v.in.ogr/main.c:521 ../vector/v.in.ogr/main.c:857
+#, fuzzy, c-format
+msgid "Geometry column <%s> not found in OGR layer <%s>"
+msgstr "출력할 격자지도"
+#: ../vector/v.in.ogr/main.c:720 ../vector/v.in.lidar/main.c:448
+msgid "Select either the current region flag or the spatial option, not both"
msgstr ""
-#: ../general/g.version/main.c:223
-msgid "GRASS not compiled with GEO
