[GRASS-SVN] r70565 - in grass/branches/releasebranch_7_2/temporal: t.rast.gapfill t.select
Tue Feb 14 13:07:46 PST 2017
Author: neteler
Date: 2017-02-14 13:07:45 -0800 (Tue, 14 Feb 2017)
New Revision: 70565
   grass/branches/releasebranch_7_2/temporal/t.rast.gapfill/t.rast.gapfill.py
   grass/branches/releasebranch_7_2/temporal/t.select/t.select.py
t.rast.gapfill + t.select: Fix overwrite flag (trunk, r70549, r70550)
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.gapfill/t.rast.gapfill.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.gapfill/t.rast.gapfill.py	2017-02-14 16:32:52 UTC (rev 70564)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.gapfill/t.rast.gapfill.py	2017-02-14 21:07:45 UTC (rev 70565)
@@ -184,7 +184,7 @@
             overwrite_flags[new_id] = False
             if new_map.map_exists() or new_map.is_in_db(dbif):
-                if not grass.overwrite:
+                if not grass.overwrite():
                         grass.fatal(_("Map with name <%s> already exists. "
                                       "Please use another base name." % (_id)))
                 else:
Modified: grass/branches/releasebranch_7_2/temporal/t.select/t.select.py
--- grass/branches/releasebranch_7_2/temporal/t.select/t.select.py	2017-02-14 16:32:52 UTC (rev 70564)
+++ grass/branches/releasebranch_7_2/temporal/t.select/t.select.py	2017-02-14 21:07:45 UTC (rev 70565)
@@ -68,7 +68,7 @@
     tgis.init(True)
     p = tgis.TemporalAlgebraParser(run=True, debug=False, spatial=spatial, dry_run=dry_run)
-    pc = p.parse(expression, stdstype,  overwrite=grass.overwrite)
+    pc = p.parse(expression, stdstype,  overwrite=grass.overwrite())
     if dry_run is True:
         import pprint
