[GRASS-SVN] r70566 - grass/branches/releasebranch_7_2/raster/r.reclass
svn_grass at osgeo.org
Tue Feb 14 13:37:59 PST 2017
Author: neteler
Date: 2017-02-14 13:37:59 -0800 (Tue, 14 Feb 2017)
New Revision: 70566
grass/branches/releasebranch_7_2/raster/r.reclass/r.reclass.html
r.reclass: remove invalid use of dl tag (trunk, r70355)
Modified: grass/branches/releasebranch_7_2/raster/r.reclass/r.reclass.html
--- grass/branches/releasebranch_7_2/raster/r.reclass/r.reclass.html 2017-02-14 21:07:45 UTC (rev 70565)
+++ grass/branches/releasebranch_7_2/raster/r.reclass/r.reclass.html 2017-02-14 21:37:59 UTC (rev 70566)
@@ -117,9 +117,9 @@
<h3>Reclass rules examples</h3>
The following examples may help clarify the reclass rules.
-<p><dl>
-<dt>
-<dd>1. This example reclassifies categories 1, 2 and 3 in the input raster
+<p>
+The first example reclassifies categories 1, 2 and 3 in the input raster
map layer "roads" to category 1 with category label "good quality" in the output map
layer, and reclassifies input raster map layer categories 4 and 5 to
category 2 with the label "poor quality" in the output map layer.
@@ -129,8 +129,8 @@
4 5 = 2 poor quality
</pre></div>
-<p><dd>2. This example reclassifies categories 1, 3 and 5 in the input raster
+<p>
+The following example reclassifies categories 1, 3 and 5 in the input raster
map layer to category 1 with category label "poor quality" in the output
map layer, and reclassifies input raster map layer categories 2, 4, and 6
to category 2 with the label "good quality" in the output map layer.
@@ -141,7 +141,9 @@
* = NULL
</pre></div>
-<p><dd>3. This example reclassifies input raster map layer categories 1 thru 10 to output
+<p>
+The following example reclassifies input raster map layer categories
+1 thru 10 to output
map layer category 1, input map layer categories 11 thru 20 to output map layer
category 2, and input map layer categories 21 thru 30 to output map layer
category 3, all without labels. The range from 30 to 40 is reclassified as
@@ -153,7 +155,9 @@
30 thru 40 = NULL
</pre></div>
-<p><dd>4. Subsequent rules override previous rules. Therefore, the below example
+<p>
+The following example shows overlapping rules. Subsequent rules override
+previous rules. Therefore, the below example
reclassifies input raster map layer categories 1 thru 19 and 51 thru 100
to category 1 in the output map layer,
input raster map layer categories 20 thru 24 and 26 thru 50 to
@@ -165,7 +169,8 @@
25 = 3 good quality
</pre></div>
-<p><dd>5. The previous example could also have been entered as:
+<p>
+The previous example could also have been entered as:
<div class="code"><pre>
1 thru 19 51 thru 100 = 1 poor quality
20 thru 24 26 thru 50 = 2 medium quality
@@ -179,8 +184,7 @@
25 = 3 good quality
</pre></div>
-</dd>
-</dl>
<p>
The final example was given to show how the labels are handled. If a new
category value appears in more than one rule (as is the case with new
@@ -188,6 +192,7 @@
the last label which was specified becomes the label for that category.
In this case the labels are assigned exactly as in the two previous examples.
<h3>Usage example</h3>
In this example, the 21 classes of the landuse map (North Carolina sample
