[GRASS-SVN] r70587 - grass/trunk/lib/vector/vedit
svn_grass at osgeo.org
Wed Feb 15 09:16:18 PST 2017
Author: hcho
Date: 2017-02-15 09:16:18 -0800 (Wed, 15 Feb 2017)
New Revision: 70587
grass/trunk/lib/vector/vedit/extend.c
v.edit: Improve intersection checks
Modified: grass/trunk/lib/vector/vedit/extend.c
--- grass/trunk/lib/vector/vedit/extend.c 2017-02-15 17:10:23 UTC (rev 70586)
+++ grass/trunk/lib/vector/vedit/extend.c 2017-02-15 17:16:18 UTC (rev 70587)
@@ -20,6 +20,8 @@
struct ilist *);
static int find_extended_intersection(double, double, double, double, double,
double, double *, double *);
+static int check_extended_direction(double, double, double, int, double,
+ double);
\brief Extend lines in given threshold
@@ -66,10 +68,8 @@
int Vedit_extend_lines(struct Map_info *Map, struct ilist *List, int nodes,
int parallel, double thresh)
- int nlines_modified, extended;
- int i, j, node[2], first_node, n_nodes;
- int line, found;
- double x, y, z;
+ int nlines_modified;
+ int i, j, first_node, n_nodes;
struct ilist *List_exclude, *List_found;
@@ -92,6 +92,8 @@
/* collect lines to be modified */
for (i = 0; i < List->n_values; i++) {
+ int line, extended, node[2];
line = List->value[i];
if (!Vect_line_alive(Map, line))
@@ -109,10 +111,14 @@
Vect_reset_list(List_exclude);
Vect_list_append(List_exclude, line);
for (j = first_node; j < n_nodes && !extended; j++) {
+ double x, y, z;
/* for each line node find lines in threshold */
Vect_get_node_coor(Map, node[j], &x, &y, &z);
do {
+ int found;
/* find first nearest line */
found = Vect_find_line_list(Map, x, y, z,
GV_LINES, thresh, WITHOUT_Z,
@@ -151,10 +157,6 @@
int line_new;
int type_from, type_to;
- int n_points, seg, is;
- double x, y, px, py, x1, y1;
- double dist, spdist, lpdist, length;
- double angle_t, angle_f;
struct line_pnts *Points_from, *Points_to, *Points_final;
struct line_cats *Cats_from, *Cats_to;
@@ -174,6 +176,11 @@
/* avoid too much indentation */
do {
+ int n_points, seg, is;
+ double x, y, px, py, x1, y1;
+ double dist, spdist, lpdist, length;
+ double angle_t, angle_f;
if (line_new == -1)
break;
@@ -206,10 +213,10 @@
/* extend both lines and find intersection */
if (!find_extended_intersection(x, y, angle_f, px, py, angle_t,
&x1, &y1)) {
+ /* parallel lines */
if (!parallel)
break;
- /* parallel lines */
x1 = px;
y1 = py;
if (first)
@@ -217,14 +224,41 @@
else
Vect_append_point(Points_from, x1, y1, 0.0);
} else {
- /* if intersection point lies on line_from or is beyond threshold,
- * skip */
- /* TODO: Get rid of tolerance */
+ /* skip if extended into the wrong direction */
+ if (!check_extended_direction(x, y, angle_f, first, x1, y1))
+ break;
+ /* skip if extended too far from line_from */
if (!Vect_line_distance(Points_from, x1, y1, 0.0, WITHOUT_Z, NULL,
NULL, NULL, &dist, NULL, NULL) ||
- dist <= TOL || dist > thresh)
+ dist > thresh)
break;
+ Vect_line_distance(Points_to, x1, y1, 0.0, WITHOUT_Z, NULL, NULL,
+ NULL, &dist, NULL, NULL);
+ /* if intersection point is not on line_to */
+ if (dist > TOL) {
+ double x2, y2;
+ /* skip if not extended from a line_to node */
+ if (seg > 1 && seg < Points_to->n_points - 1)
+ break;
+ if (seg == 1) {
+ x2 = Points_to->x[0];
+ y2 = Points_to->y[0];
+ } else {
+ x2 = Points_to->x[Points_to->n_points - 1];
+ y2 = Points_to->y[Points_to->n_points - 1];
+ if (!check_extended_direction(x2, y2, angle_t, seg == 1, x1,
+ y1))
+ break;
+ /* otherwise, split line_to later */
/* lines extended -> extend/split line_to */
/* update line_from */
if (first) {
@@ -329,3 +363,48 @@
return 1;
+static int check_extended_direction(double x, double y, double angle,
+ int start_node, double extx, double exty)
+ double tmp;
+ int xdir, ydir, xext, yext;
+ if (start_node)
+ angle += M_PI;
+ /* expected directions */
+ tmp = cos(angle);
+ xdir = (fabs(tmp) <= TOL ? 0 : (tmp > 0 ? 1 : -1));
+ tmp = sin(angle);
+ ydir = (fabs(tmp) <= TOL ? 0 : (tmp > 0 ? 1 : -1));
+ /* extended directions */
+ tmp = extx - x;
+ xext = (fabs(tmp) <= TOL ? 0 : (tmp > 0 ? 1 : -1));
+ tmp = exty - y;
+ yext = (fabs(tmp) <= TOL ? 0 : (tmp > 0 ? 1 : -1));
+ if (xext != 0 && yext != 0) {
+ /* no if extended into the wrong direction */
+ if (xdir / xext <= 0 || ydir / yext <= 0)
+ return 0;
+ /* otherwise, ok */
+ } else if (xext == 0 && yext == 0) {
+ /* snapped to the node, ok */
+ } else if (xext == 0) {
+ /* vertical extension */
+ /* no if not expected or extended into the wrong direction */
+ if (xdir != 0 || ydir / yext <= 0)
+ return 0;
+ } else {
+ /* horizontal extension */
+ if (ydir != 0 || xdir / xext <= 0)
+ return 0;
+ return 1;
