[GRASS-SVN] r70588 - in grass/branches/releasebranch_7_2: scripts/v.what.strds temporal/t.create temporal/t.info temporal/t.list temporal/t.merge temporal/t.rast.accdetect temporal/t.rast.accumulate temporal/t.rast.aggregate temporal/t.rast.aggregate.ds temporal/t.rast.algebra temporal/t.rast.colors temporal/t.rast.contour temporal/t.rast.export temporal/t.rast.extract temporal/t.rast.gapfill temporal/t.rast.import temporal/t.rast.list temporal/t.rast.mapcalc temporal/t.rast.neighbors temporal/t.rast.out.vtk temporal/t.rast.series temporal/t.rast.to.rast3 temporal/t.rast.to.vect temporal/t.rast.univar temporal/t.rast.what temporal/t.rast3d.algebra temporal/t.rast3d.extract temporal/t.rast3d.list temporal/t.rast3d.mapcalc temporal/t.rast3d.univar temporal/t.register temporal/t.remove temporal/t.rename temporal/t.sample temporal/t.select temporal/t.shift temporal/t.snap temporal/t.support temporal/t.topology temporal/t.unregister temporal/t.vect.algebra temporal/t.vect.db.select temporal/ t.vect.export temporal/t.vect.extract temporal/t.vect.import temporal/t.vect.list temporal/t.vect.observe.strds temporal/t.vect.univar temporal/t.vect.what.strds
svn_grass at osgeo.org
Wed Feb 15 09:17:52 PST 2017
Author: wenzeslaus
Date: 2017-02-15 09:17:51 -0800 (Wed, 15 Feb 2017)
New Revision: 70588
grass/branches/releasebranch_7_2/scripts/v.what.strds/v.what.strds.py
grass/branches/releasebranch_7_2/temporal/t.create/t.create.py
grass/branches/releasebranch_7_2/temporal/t.info/t.info.py
grass/branches/releasebranch_7_2/temporal/t.list/t.list.py
grass/branches/releasebranch_7_2/temporal/t.merge/t.merge.py
grass/branches/releasebranch_7_2/temporal/t.rast.accdetect/t.rast.accdetect.py
grass/branches/releasebranch_7_2/temporal/t.rast.accumulate/t.rast.accumulate.py
grass/branches/releasebranch_7_2/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py
grass/branches/releasebranch_7_2/temporal/t.rast.aggregate/t.rast.aggregate.py
grass/branches/releasebranch_7_2/temporal/t.rast.algebra/t.rast.algebra.py
grass/branches/releasebranch_7_2/temporal/t.rast.colors/t.rast.colors.py
grass/branches/releasebranch_7_2/temporal/t.rast.contour/t.rast.contour.py
grass/branches/releasebranch_7_2/temporal/t.rast.export/t.rast.export.py
grass/branches/releasebranch_7_2/temporal/t.rast.extract/t.rast.extract.py
grass/branches/releasebranch_7_2/temporal/t.rast.gapfill/t.rast.gapfill.py
grass/branches/releasebranch_7_2/temporal/t.rast.import/t.rast.import.py
grass/branches/releasebranch_7_2/temporal/t.rast.list/t.rast.list.py
grass/branches/releasebranch_7_2/temporal/t.rast.mapcalc/t.rast.mapcalc.py
grass/branches/releasebranch_7_2/temporal/t.rast.neighbors/t.rast.neighbors.py
grass/branches/releasebranch_7_2/temporal/t.rast.out.vtk/t.rast.out.vtk.py
grass/branches/releasebranch_7_2/temporal/t.rast.series/t.rast.series.py
grass/branches/releasebranch_7_2/temporal/t.rast.to.rast3/t.rast.to.rast3.py
grass/branches/releasebranch_7_2/temporal/t.rast.to.vect/t.rast.to.vect.py
grass/branches/releasebranch_7_2/temporal/t.rast.univar/t.rast.univar.py
grass/branches/releasebranch_7_2/temporal/t.rast.what/t.rast.what.py
grass/branches/releasebranch_7_2/temporal/t.rast3d.algebra/t.rast3d.algebra.py
grass/branches/releasebranch_7_2/temporal/t.rast3d.extract/t.rast3d.extract.py
grass/branches/releasebranch_7_2/temporal/t.rast3d.list/t.rast3d.list.py
grass/branches/releasebranch_7_2/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py
grass/branches/releasebranch_7_2/temporal/t.rast3d.univar/t.rast3d.univar.py
grass/branches/releasebranch_7_2/temporal/t.register/t.register.py
grass/branches/releasebranch_7_2/temporal/t.remove/t.remove.py
grass/branches/releasebranch_7_2/temporal/t.rename/t.rename.py
grass/branches/releasebranch_7_2/temporal/t.sample/t.sample.py
grass/branches/releasebranch_7_2/temporal/t.select/t.select.py
grass/branches/releasebranch_7_2/temporal/t.shift/t.shift.py
grass/branches/releasebranch_7_2/temporal/t.snap/t.snap.py
grass/branches/releasebranch_7_2/temporal/t.support/t.support.py
grass/branches/releasebranch_7_2/temporal/t.topology/t.topology.py
grass/branches/releasebranch_7_2/temporal/t.unregister/t.unregister.py
grass/branches/releasebranch_7_2/temporal/t.vect.algebra/t.vect.algebra.py
grass/branches/releasebranch_7_2/temporal/t.vect.db.select/t.vect.db.select.py
grass/branches/releasebranch_7_2/temporal/t.vect.export/t.vect.export.py
grass/branches/releasebranch_7_2/temporal/t.vect.extract/t.vect.extract.py
grass/branches/releasebranch_7_2/temporal/t.vect.import/t.vect.import.py
grass/branches/releasebranch_7_2/temporal/t.vect.list/t.vect.list.py
grass/branches/releasebranch_7_2/temporal/t.vect.observe.strds/t.vect.observe.strds.py
grass/branches/releasebranch_7_2/temporal/t.vect.univar/t.vect.univar.py
grass/branches/releasebranch_7_2/temporal/t.vect.what.strds/t.vect.what.strds.py
use lazy imports for the temporal package (backport r70357, see #3257)
Modified: grass/branches/releasebranch_7_2/scripts/v.what.strds/v.what.strds.py
--- grass/branches/releasebranch_7_2/scripts/v.what.strds/v.what.strds.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/scripts/v.what.strds/v.what.strds.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -50,10 +50,6 @@
#%end
import grass.script as grass
-import grass.temporal as tgis
-from grass.pygrass.utils import copy as gcopy
-from grass.pygrass.messages import Messenger
-from grass.pygrass.vector import Vector
from grass.exceptions import CalledModuleError
@@ -89,6 +85,12 @@
def main():
+ # lazy imports
+ import grass.temporal as tgis
+ from grass.pygrass.utils import copy as gcopy
+ from grass.pygrass.messages import Messenger
+ from grass.pygrass.vector import Vector
# Get the options
input = options["input"]
output = options["output"]
Modified: grass/branches/releasebranch_7_2/temporal/t.create/t.create.py
--- grass/branches/releasebranch_7_2/temporal/t.create/t.create.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.create/t.create.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -59,12 +59,13 @@
#%end
def main():
+ # lazy imports
# Get the options
name = options["output"]
Modified: grass/branches/releasebranch_7_2/temporal/t.info/t.info.py
--- grass/branches/releasebranch_7_2/temporal/t.info/t.info.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.info/t.info.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -50,12 +50,13 @@
from __future__ import print_function
def main():
+ # lazy imports
name = options["input"]
type_ = options["type"]
Modified: grass/branches/releasebranch_7_2/temporal/t.list/t.list.py
--- grass/branches/releasebranch_7_2/temporal/t.list/t.list.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.list/t.list.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -80,15 +80,17 @@
#% description: Print the column names as first row
#% guisection: Formatting
#%end
import grass.script as gscript
import sys
def main():
+ # lazy imports
# Get the options
type = options["type"]
Modified: grass/branches/releasebranch_7_2/temporal/t.merge/t.merge.py
--- grass/branches/releasebranch_7_2/temporal/t.merge/t.merge.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.merge/t.merge.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -33,13 +33,15 @@
#% guisection: Required
#%end
grass.set_raise_on_error(True)
def main():
+ # lazy imports
# Get the options
inputs = options["inputs"]
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.accdetect/t.rast.accdetect.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.accdetect/t.rast.accdetect.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.accdetect/t.rast.accdetect.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -130,9 +130,11 @@
#%end
+# lazy imports at the end of the file
range_relations = ["EQUALS", "DURING", "OVERLAPS", "OVERLAPPING", "CONTAINS"]
@@ -585,4 +587,6 @@
if __name__ == "__main__":
options, flags = grass.parser()
+ # lazy imports
main()
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.accumulate/t.rast.accumulate.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.accumulate/t.rast.accumulate.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.accumulate/t.rast.accumulate.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -149,13 +149,15 @@
-from grass.pygrass.modules import Module
from copy import copy
def main():
+ # lazy imports
+ from grass.pygrass.modules import Module
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.aggregate/t.rast.aggregate.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.aggregate/t.rast.aggregate.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.aggregate/t.rast.aggregate.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -106,11 +106,13 @@
#%end
import grass.script as gcore
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -98,12 +98,14 @@
#%end
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.algebra/t.rast.algebra.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.algebra/t.rast.algebra.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.algebra/t.rast.algebra.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -69,10 +69,13 @@
#%end
import grass.script
import sys
def main():
+ # lazy imports
expression = options['expression']
basename = options['basename']
nprocs = options["nprocs"]
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.colors/t.rast.colors.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.colors/t.rast.colors.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.colors/t.rast.colors.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -97,13 +97,14 @@
#%end
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.contour/t.rast.contour.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.contour/t.rast.contour.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.contour/t.rast.contour.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -114,14 +114,15 @@
import sys
import copy
-import grass.pygrass.modules as pymod
from grass.exceptions import FatalError
def main(options, flags):
+ # lazy imports
+ import grass.pygrass.modules as pymod
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.export/t.rast.export.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.export/t.rast.export.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.export/t.rast.export.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -71,11 +71,12 @@
#%end
def main():
+ # lazy imports
# Get the options
_input = options["input"]
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.extract/t.rast.extract.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.extract/t.rast.extract.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.extract/t.rast.extract.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -74,12 +74,14 @@
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.gapfill/t.rast.gapfill.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.gapfill/t.rast.gapfill.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.gapfill/t.rast.gapfill.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -65,15 +65,15 @@
import copy
from multiprocessing import Process
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.import/t.rast.import.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.import/t.rast.import.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.import/t.rast.import.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -105,10 +105,11 @@
#%end
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.list/t.rast.list.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.list/t.rast.list.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.list/t.rast.list.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -86,12 +86,14 @@
#%end
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.mapcalc/t.rast.mapcalc.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.mapcalc/t.rast.mapcalc.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.mapcalc/t.rast.mapcalc.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -68,12 +68,14 @@
#%end
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.neighbors/t.rast.neighbors.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.neighbors/t.rast.neighbors.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.neighbors/t.rast.neighbors.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -93,13 +93,14 @@
import copy
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.out.vtk/t.rast.out.vtk.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.out.vtk/t.rast.out.vtk.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.out.vtk/t.rast.out.vtk.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -67,13 +67,14 @@
import os
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.series/t.rast.series.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.series/t.rast.series.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.series/t.rast.series.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -65,13 +65,14 @@
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.to.rast3/t.rast.to.rast3.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.to.rast3/t.rast.to.rast3.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.to.rast3/t.rast.to.rast3.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -33,7 +33,6 @@
import os
from datetime import datetime
@@ -41,6 +40,8 @@
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.to.vect/t.rast.to.vect.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.to.vect/t.rast.to.vect.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.to.vect/t.rast.to.vect.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -113,13 +113,14 @@
import sys
import copy
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.univar/t.rast.univar.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.univar/t.rast.univar.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.univar/t.rast.univar.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -55,12 +55,14 @@
#%end
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.what/t.rast.what.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.what/t.rast.what.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.what/t.rast.what.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -112,13 +112,14 @@
import sys
import copy
+ # lazy imports
# Get the options
points = options["points"]
Modified: grass/branches/releasebranch_7_2/temporal/t.rast3d.algebra/t.rast3d.algebra.py
--- grass/branches/releasebranch_7_2/temporal/t.rast3d.algebra/t.rast3d.algebra.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast3d.algebra/t.rast3d.algebra.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -66,10 +66,13 @@
import grass.script
import sys
def main():
+ # lazy imports
Modified: grass/branches/releasebranch_7_2/temporal/t.rast3d.extract/t.rast3d.extract.py
--- grass/branches/releasebranch_7_2/temporal/t.rast3d.extract/t.rast3d.extract.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast3d.extract/t.rast3d.extract.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -72,12 +72,14 @@
#%end
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.rast3d.list/t.rast3d.list.py
--- grass/branches/releasebranch_7_2/temporal/t.rast3d.list/t.rast3d.list.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast3d.list/t.rast3d.list.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -78,12 +78,14 @@
#%end
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py
--- grass/branches/releasebranch_7_2/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -74,12 +74,14 @@
import copy
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.rast3d.univar/t.rast3d.univar.py
--- grass/branches/releasebranch_7_2/temporal/t.rast3d.univar/t.rast3d.univar.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rast3d.univar/t.rast3d.univar.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -52,12 +52,14 @@
#%end
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.register/t.register.py
--- grass/branches/releasebranch_7_2/temporal/t.register/t.register.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.register/t.register.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -99,13 +99,12 @@
#%end
def main():
# Get the options
maps = options["maps"]
@@ -131,6 +130,9 @@
+ # lazy imports
try:
from builtins import StandardError
except ImportError:
Modified: grass/branches/releasebranch_7_2/temporal/t.remove/t.remove.py
--- grass/branches/releasebranch_7_2/temporal/t.remove/t.remove.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.remove/t.remove.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -56,13 +56,13 @@
#%end
-import grass.pygrass.modules as pyg
def main():
# Get the options
datasets = options["inputs"]
file = options["file"]
@@ -163,5 +163,9 @@
+ # lazy imports
+ import grass.pygrass.modules as pyg
tgis.profile_function(main)
Modified: grass/branches/releasebranch_7_2/temporal/t.rename/t.rename.py
--- grass/branches/releasebranch_7_2/temporal/t.rename/t.rename.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.rename/t.rename.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -33,13 +33,14 @@
#%end
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.sample/t.sample.py
--- grass/branches/releasebranch_7_2/temporal/t.sample/t.sample.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.sample/t.sample.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -61,11 +61,13 @@
#%end
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.select/t.select.py
--- grass/branches/releasebranch_7_2/temporal/t.select/t.select.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.select/t.select.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -47,12 +47,13 @@
import sys
def main():
+ # lazy imports
spatial = flags["s"]
Modified: grass/branches/releasebranch_7_2/temporal/t.shift/t.shift.py
--- grass/branches/releasebranch_7_2/temporal/t.shift/t.shift.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.shift/t.shift.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -41,12 +41,14 @@
#%end
def main():
+ # lazy imports
Modified: grass/branches/releasebranch_7_2/temporal/t.snap/t.snap.py
--- grass/branches/releasebranch_7_2/temporal/t.snap/t.snap.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.snap/t.snap.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -32,12 +32,14 @@
#%end
def main():
+ # lazy imports
Modified: grass/branches/releasebranch_7_2/temporal/t.support/t.support.py
--- grass/branches/releasebranch_7_2/temporal/t.support/t.support.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.support/t.support.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -76,11 +76,13 @@
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.topology/t.topology.py
--- grass/branches/releasebranch_7_2/temporal/t.topology/t.topology.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.topology/t.topology.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -44,12 +44,14 @@
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.unregister/t.unregister.py
--- grass/branches/releasebranch_7_2/temporal/t.unregister/t.unregister.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.unregister/t.unregister.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -43,13 +43,14 @@
#%end
def main():
# Get the options
@@ -175,5 +176,8 @@
+ # lazy imports
Modified: grass/branches/releasebranch_7_2/temporal/t.vect.algebra/t.vect.algebra.py
--- grass/branches/releasebranch_7_2/temporal/t.vect.algebra/t.vect.algebra.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.vect.algebra/t.vect.algebra.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -47,10 +47,12 @@
#%end
import grass.script
import sys
def main():
+ # lazy imports
Modified: grass/branches/releasebranch_7_2/temporal/t.vect.db.select/t.vect.db.select.py
--- grass/branches/releasebranch_7_2/temporal/t.vect.db.select/t.vect.db.select.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.vect.db.select/t.vect.db.select.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -46,12 +46,14 @@
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.vect.export/t.vect.export.py
--- grass/branches/releasebranch_7_2/temporal/t.vect.export/t.vect.export.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.vect.export/t.vect.export.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -61,11 +61,12 @@
#%end
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.vect.extract/t.vect.extract.py
--- grass/branches/releasebranch_7_2/temporal/t.vect.extract/t.vect.extract.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.vect.extract/t.vect.extract.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -75,12 +75,14 @@
#%end
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.vect.import/t.vect.import.py
--- grass/branches/releasebranch_7_2/temporal/t.vect.import/t.vect.import.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.vect.import/t.vect.import.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -83,10 +83,11 @@
#%end
def main():
+ # lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.vect.list/t.vect.list.py
--- grass/branches/releasebranch_7_2/temporal/t.vect.list/t.vect.list.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.vect.list/t.vect.list.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -78,12 +78,14 @@
#%end
def main():
+ #lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.vect.observe.strds/t.vect.observe.strds.py
--- grass/branches/releasebranch_7_2/temporal/t.vect.observe.strds/t.vect.observe.strds.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.vect.observe.strds/t.vect.observe.strds.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -49,7 +49,6 @@
#%end
import grass.script.raster as raster
@@ -70,6 +69,8 @@
def main():
+ #lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.vect.univar/t.vect.univar.py
--- grass/branches/releasebranch_7_2/temporal/t.vect.univar/t.vect.univar.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.vect.univar/t.vect.univar.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -68,11 +68,13 @@
#%end
def main():
+ #lazy imports
# Get the options
Modified: grass/branches/releasebranch_7_2/temporal/t.vect.what.strds/t.vect.what.strds.py
--- grass/branches/releasebranch_7_2/temporal/t.vect.what.strds/t.vect.what.strds.py 2017-02-15 17:16:18 UTC (rev 70587)
+++ grass/branches/releasebranch_7_2/temporal/t.vect.what.strds/t.vect.what.strds.py 2017-02-15 17:17:51 UTC (rev 70588)
@@ -60,7 +60,6 @@
import os
@@ -68,6 +67,8 @@
def main():
+ # lazy imports
# Get the options
