[GRASS-SVN] r70640 - grass/trunk/display/d.vect
Mon Feb 20 06:06:35 PST 2017
Author: mmetz
Date: 2017-02-20 06:06:34 -0800 (Mon, 20 Feb 2017)
New Revision: 70640
   grass/trunk/display/d.vect/area.c
   grass/trunk/display/d.vect/main.c
d.vect: fix overlap tests
Modified: grass/trunk/display/d.vect/area.c
--- grass/trunk/display/d.vect/area.c	2017-02-20 08:00:39 UTC (rev 70639)
+++ grass/trunk/display/d.vect/area.c	2017-02-20 14:06:34 UTC (rev 70640)
@@ -72,11 +72,9 @@
 	    box.E < window->west || box.W > window->east) {
 	    if (window->proj != PROJECTION_LL)
 		continue;
-	    else { /* out of bounds for -180 to 180, try 0 to 360 as well */
-		if (box.N < window->south || box.S > window->north)
+	    else {
+		if (!G_window_overlap(window, box.N, box.S, box.E, box.W))
 		    continue;
-		if (box.E + 360 < window->west || box.W + 360 > window->east)
-		    continue;
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c	2017-02-20 08:00:39 UTC (rev 70639)
+++ grass/trunk/display/d.vect/main.c	2017-02-20 14:06:34 UTC (rev 70640)
@@ -418,19 +418,19 @@
     G_verbose_message(_("Plotting..."));
-    if (level >= 2)
+    overlap = 1;
+    if (level >= 2 && window.proj != PROJECTION_LL) {
 	Vect_get_map_box(&Map, &box);
+	overlap = G_window_percentage_overlap(&window, box.N, box.S,
+					      box.E, box.W);
+	G_debug(1, "overlap = %f \n", overlap);
-    if (level >= 2 && (window.north < box.S || window.south > box.N ||
-		       window.east < box.W ||
-		       window.west > G_adjust_easting(box.E, &window))) {
+    if (overlap == 0) {
 	G_warning(_("The bounding box of the map is outside the current region, "
 		    "nothing drawn"));
     else {
-	overlap = G_window_percentage_overlap(&window, box.N, box.S,
-					      box.E, box.W);
-	G_debug(1, "overlap = %f \n", overlap);
 	if (overlap < 1)
 	    Vect_set_constraint_region(&Map, window.north, window.south,
 				       window.east, window.west,
