[GRASS-SVN] r70641 - grass/trunk/display/d.vect.thematic
svn_grass at osgeo.org
Mon Feb 20 06:07:33 PST 2017
Author: mmetz
Date: 2017-02-20 06:07:33 -0800 (Mon, 20 Feb 2017)
New Revision: 70641
grass/trunk/display/d.vect.thematic/area.c
grass/trunk/display/d.vect.thematic/main.c
d.vect.thematic: fix overlap tests
Modified: grass/trunk/display/d.vect.thematic/area.c
--- grass/trunk/display/d.vect.thematic/area.c 2017-02-20 14:06:34 UTC (rev 70640)
+++ grass/trunk/display/d.vect.thematic/area.c 2017-02-20 14:07:33 UTC (rev 70641)
@@ -52,11 +52,9 @@
if (window->proj != PROJECTION_LL)
continue;
- else { /* out of bounds for -180 to 180, try 0 to 360 as well */
- if (box.N < window->south || box.S > window->north)
+ else {
+ if (!G_window_overlap(window, box.N, box.S, box.E, box.W))
continue;
- if (box.E + 360 < window->west || box.W + 360 > window->east)
- continue;
Modified: grass/trunk/display/d.vect.thematic/main.c
--- grass/trunk/display/d.vect.thematic/main.c 2017-02-20 14:06:34 UTC (rev 70640)
+++ grass/trunk/display/d.vect.thematic/main.c 2017-02-20 14:07:33 UTC (rev 70641)
@@ -461,20 +461,21 @@
if (verbose)
G_message(_("Plotting ..."));
+ overlap = 1;
Vect_get_map_box(&Map, &box);
+ if (window.proj != PROJECTION_LL) {
+ overlap =
+ G_window_percentage_overlap(&window, box.N, box.S,
+ box.E, box.W);
+ G_debug(1, "overlap = %f \n", overlap);
- if (window.north < box.S || window.south > box.N ||
- window.east < box.W ||
- window.west > G_adjust_easting(box.E, &window)) {
+ if (overlap == 0) {
G_message(_("The bounding box of the map is outside the current region, "
"nothing drawn."));
stat = 0;
else {
- overlap =
- G_window_percentage_overlap(&window, box.N, box.S, box.E,
- box.W);
- G_debug(1, "overlap = %f \n", overlap);
if (overlap < 1)
Vect_set_constraint_region(&Map, window.north, window.south,
window.east, window.west,
@@ -483,18 +484,18 @@
/* default line width */
D_line_width(default_width);
- if (Vect_get_num_primitives(&Map, GV_BOUNDARY) > 0)
- stat =
- dareatheme(&Map, Clist, &cvarr, breakpoints, nbreaks, colors,
- has_color ? &bcolor : NULL, chcat, &window,
- default_width);
+ if (Vect_get_num_primitives(&Map, GV_BOUNDARY) > 0)
+ stat =
+ dareatheme(&Map, Clist, &cvarr, breakpoints, nbreaks, colors,
+ has_color ? &bcolor : NULL, chcat, &window,
+ default_width);
- else if ((Vect_get_num_primitives(&Map, GV_POINT) > 0) ||
- (Vect_get_num_primitives(&Map, GV_LINE) > 0)){
- stat = display_lines(&Map, Clist, chcat, icon_opt->answer, size,
- default_width, &cvarr, breakpoints, nbreaks, colors,
- has_color ? &bcolor : NULL);
+ else if ((Vect_get_num_primitives(&Map, GV_POINT) > 0) ||
+ (Vect_get_num_primitives(&Map, GV_LINE) > 0)){
+ stat = display_lines(&Map, Clist, chcat, icon_opt->answer, size,
+ default_width, &cvarr, breakpoints, nbreaks, colors,
+ has_color ? &bcolor : NULL);
/* reset line width: Do we need to get line width from display
