[GRASS-SVN] r70657 - grass-addons/grass7/raster/r.findtheriver
svn_grass at osgeo.org
Wed Feb 22 03:00:56 PST 2017
Author: hcho
Date: 2017-02-22 03:00:56 -0800 (Wed, 22 Feb 2017)
New Revision: 70657
grass-addons/grass7/raster/r.findtheriver/main.c
grass-addons/grass7/raster/r.findtheriver/point_list.c
r.findtheriver: separate file for find_stream; standardized options
Modified: grass-addons/grass7/raster/r.findtheriver/main.c
--- grass-addons/grass7/raster/r.findtheriver/main.c 2017-02-22 09:02:27 UTC (rev 70656)
+++ grass-addons/grass7/raster/r.findtheriver/main.c 2017-02-22 11:00:56 UTC (rev 70657)
@@ -20,41 +20,10 @@
#include <stdlib.h>
#include <string.h>
-#include <math.h>
#include <grass/raster.h>
#include <grass/glocale.h>
-#include "point_list.h"
+#include "global.h"
-#define THRESHOLD_DISTANCE 100
- * global function declaration
-\brief Find stream pixels in a given window of the UAA raster
-\param[in] fd UAA raster file descriptor
-\param[in] name Name of UAA raster map
-\param[in] mapset Name of the GRASS mapset from which UAA raster should be read
-\param[in] dataType Data type of UAA raster
-\param[in] windowSize Size of the search window, must be an odd integer >= 3
-\param[in] threshold to use for distinguishing stream pixels by comparing log(UAA) values
-\param[in] nrows_less_one Number of rows in the current window, minus 1
-\param[in] ncols_less_one Number of columns in the current window, minus 1
-\param[in] currRow, Row of pixel that will be compared to pixels in the window
-\param[in] currCol, Column of pixel that will be compared to pixels in the window
-\return Pointer to PointList_t representing a list of stream pixels found in the window
-PointList_t *find_stream_pixels_in_window(int fd, char *name,
- const char *mapset,
- RASTER_MAP_TYPE dataType,
- int windowSize, double threshold,
- int nrows_less_one,
- int ncols_less_one, int currRow,
- int currCol);
int main(int argc, char *argv[])
struct GModule *module; /* GRASS module for parsing arguments */
@@ -78,7 +47,7 @@
struct Cell_head window;
int windowSize;
double threshold;
- char sep;
+ char *sep;
int debug;
/* initialize GIS environment */
@@ -92,11 +61,7 @@
_("Find the stream pixel nearest the input coordinate");
/* Define command options */
- opt.input = G_define_option();
- opt.input->key = "accumulation";
- opt.input->type = TYPE_STRING;
- opt.input->required = YES;
- opt.input->gisprompt = "old,cell,raster";
+ opt.input = G_define_standard_option(G_OPT_R_MAP);
opt.input->description =
_("Name of input upstream accumulation area raster map");
@@ -191,16 +156,7 @@
G_verbose_message(_("Input coordinates, easting %f, northing %f\n"), E,
N);
- if (strcmp(opt.separator->answer, "newline") == 0)
- sep = '\n';
- else if (strcmp(opt.separator->answer, "comma") == 0)
- sep = ',';
- else if (strcmp(opt.separator->answer, "space") == 0)
- sep = ' ';
- else if (strcmp(opt.separator->answer, "tab") == 0)
- sep = '\t';
- else
- sep = opt.separator->answer[0];
+ sep = G_option_to_separator(opt.separator);
/* Open the raster - returns file descriptor (>0) */
if ((infd = Rast_open_old(name, mapset)) < 0)
@@ -228,6 +184,8 @@
find_nearest_point(streamPixels, colIdx, rowIdx);
if (NULL != nearestStreamPixel) {
+ double nearestEasting, nearestNorthing;
if (debug) {
double nearestValue;
void *tmpRow = Rast_allocate_buf(data_type);
@@ -256,13 +214,13 @@
/* Get center of each column */
- double nearestEasting =
+ nearestEasting =
Rast_col_to_easting(nearestStreamPixel->col + 0.5, &window);
- double nearestNorthing =
+ nearestNorthing =
Rast_row_to_northing(nearestStreamPixel->row + 0.5, &window);
/* Print snapped coordinates */
- fprintf(stdout, "%f%c%f\n", nearestEasting, sep, nearestNorthing);
+ fprintf(stdout, "%f%s%f\n", nearestEasting, sep, nearestNorthing);
fflush(stdout);
@@ -274,141 +232,3 @@
exit(EXIT_SUCCESS);
- * function definitions
- int currCol)
- PointList_t *streamPixels = NULL;
- DCELL centralValue, tmpValue;
- double logCentralValue, logTmpValue;
- void *tmpRow = Rast_allocate_buf(dataType);
- /* Get value of central cell */
- Rast_get_row(fd, tmpRow, currRow, dataType);
- switch (dataType) {
- case FCELL_TYPE:
- centralValue = (double)((FCELL *) tmpRow)[currCol];
- break;
- case DCELL_TYPE:
- centralValue = (double)((DCELL *) tmpRow)[currCol];
- break;
- default:
- centralValue = (double)((CELL *) tmpRow)[currCol];
- break;
- if (centralValue <= 0)
- centralValue = 1;
- logCentralValue = log10(centralValue);
- G_debug(1, "logCentralValue: %f", logCentralValue);
- /* Determine threshold if need be */
- if (-1.0 == threshold) {
- struct FPRange *range =
- (struct FPRange *)G_malloc(sizeof(struct FPRange));
- if (Rast_read_fp_range(name, mapset, range) < 0) {
- G_fatal_error(_("Unable to determine range of raster map <%s>"),
- name);
- double max = range->max;
- G_free(range); // eggs or is it chicken?
- if (max == centralValue)
- return streamPixels;
- double logMax = log10(max);
- threshold = floor(logMax - logCentralValue);
- if (threshold <= 0.0) {
- threshold = 1.0;
- else if (threshold > 2.0) {
- threshold = 2.0;
- G_debug(1, "logMax: %f", logMax);
- G_verbose_message(_("Threshold: %f\n"), threshold);
- /* Define window bounds */
- int windowOffset = (windowSize - 1) / 2;
- int minCol = currCol - windowOffset;
- if (minCol < 0)
- minCol = 0;
- int maxCol = currCol + windowOffset;
- if (maxCol > ncols_less_one)
- maxCol = ncols_less_one;
- int minRow = currRow - windowOffset;
- if (minRow < 0)
- minRow = 0;
- int maxRow = currRow + windowOffset;
- if (maxRow > nrows_less_one)
- maxRow = nrows_less_one;
- G_debug(1, "currCol: %d, currRow: %d", currCol, currRow);
- G_debug(1, "min. col: %d, max. col: %d", minCol, maxCol);
- G_debug(1, "min. row: %d, max. row: %d", minRow, maxRow);
- /* Search for stream pixels within the window */
- int row, col;
- for (row = minRow; row <= maxRow; row++) {
- G_debug(1, "row: %d", row);
- /* Get the current row */
- Rast_get_row(fd, tmpRow, row, dataType);
- for (col = minCol; col <= maxCol; col++) {
- G_debug(1, " col: %d", col);
- case FCELL_TYPE:
- tmpValue = (double)((FCELL *) tmpRow)[col];
- break;
- case DCELL_TYPE:
- tmpValue = (double)((DCELL *) tmpRow)[col];
- break;
- default:
- tmpValue = (double)((CELL *) tmpRow)[col];
- break;
- logTmpValue = log10(tmpValue);
- /* Test for nearby pixels that are stream pixels when compared to the central pixel */
- G_debug(1, " tmpValue: %f, centralValue: %f",
- tmpValue, centralValue);
- G_debug(1, " logTmpValue: %f, logCentralValue: %f",
- logTmpValue, logCentralValue);
- if (logTmpValue - logCentralValue > threshold) {
- /* Add to list of stream pixels */
- if (NULL == streamPixels)
- streamPixels = create_list(col, row);
- else
- append_point(streamPixels, col, row);
- else if (logCentralValue - logTmpValue > threshold) {
- streamPixels = create_list(currCol, currRow);
- else
- append_point(streamPixels, currCol, currRow);
- G_free(tmpRow);
Modified: grass-addons/grass7/raster/r.findtheriver/point_list.c
--- grass-addons/grass7/raster/r.findtheriver/point_list.c 2017-02-22 09:02:27 UTC (rev 70656)
+++ grass-addons/grass7/raster/r.findtheriver/point_list.c 2017-02-22 11:00:56 UTC (rev 70657)
@@ -18,7 +18,7 @@
#include <stdlib.h>
#include <math.h>
#include <grass/gis.h>
PointList_t *create_list(int col, int row)
