[GRASS-SVN] r70658 - grass-addons/grass7/raster/r.findtheriver
svn_grass at osgeo.org
Wed Feb 22 03:01:05 PST 2017
Author: hcho
Date: 2017-02-22 03:01:05 -0800 (Wed, 22 Feb 2017)
New Revision: 70658
Added:
grass-addons/grass7/raster/r.findtheriver/find_stream.c
r.findtheriver: separate file for find_stream; standardized options
Added: grass-addons/grass7/raster/r.findtheriver/find_stream.c
--- grass-addons/grass7/raster/r.findtheriver/find_stream.c (rev 0)
+++ grass-addons/grass7/raster/r.findtheriver/find_stream.c 2017-02-22 11:01:05 UTC (rev 70658)
@@ -0,0 +1,162 @@
+#include <math.h>
+#include <grass/raster.h>
+#include <grass/glocale.h>
+#include "global.h"
+\brief Find stream pixels in a given window of the UAA raster
+\param[in] fd UAA raster file descriptor
+\param[in] name Name of UAA raster map
+\param[in] mapset Name of the GRASS mapset from which UAA raster should be read
+\param[in] dataType Data type of UAA raster
+\param[in] windowSize Size of the search window, must be an odd integer >= 3
+\param[in] threshold to use for distinguishing stream pixels by comparing log(UAA) values
+\param[in] nrows_less_one Number of rows in the current window, minus 1
+\param[in] ncols_less_one Number of columns in the current window, minus 1
+\param[in] currRow, Row of pixel that will be compared to pixels in the window
+\param[in] currCol, Column of pixel that will be compared to pixels in the window
+\return Pointer to PointList_t representing a list of stream pixels found in the window
+PointList_t *find_stream_pixels_in_window(int fd, char *name,
+ const char *mapset,
+ RASTER_MAP_TYPE dataType,
+ int windowSize, double threshold,
+ int nrows_less_one,
+ int ncols_less_one, int currRow,
+ int currCol)
+ PointList_t *streamPixels = NULL;
+ DCELL centralValue;
+ double logCentralValue;
+ void *tmpRow;
+ int windowOffset, minCol, maxCol, minRow, maxRow, row, col;
+ /* Get value of central cell */
+ tmpRow = Rast_allocate_buf(dataType);
+ Rast_get_row(fd, tmpRow, currRow, dataType);
+ switch (dataType) {
+ case FCELL_TYPE:
+ centralValue = (double)((FCELL *) tmpRow)[currCol];
+ break;
+ case DCELL_TYPE:
+ centralValue = (double)((DCELL *) tmpRow)[currCol];
+ break;
+ default:
+ centralValue = (double)((CELL *) tmpRow)[currCol];
+ break;
+ if (centralValue <= 0)
+ centralValue = 1;
+ logCentralValue = log10(centralValue);
+ G_debug(1, "logCentralValue: %f", logCentralValue);
+ /* Determine threshold if need be */
+ if (-1.0 == threshold) {
+ struct FPRange *range;
+ double max, logMax;
+ range = (struct FPRange *)G_malloc(sizeof(struct FPRange));
+ if (Rast_read_fp_range(name, mapset, range) < 0) {
+ G_fatal_error(_("Unable to determine range of raster map <%s>"),
+ name);
+ max = range->max;
+ G_free(range); // eggs or is it chicken?
+ if (max == centralValue)
+ return streamPixels;
+ logMax = log10(max);
+ threshold = floor(logMax - logCentralValue);
+ if (threshold <= 0.0) {
+ threshold = 1.0;
+ else if (threshold > 2.0) {
+ threshold = 2.0;
+ G_debug(1, "logMax: %f", logMax);
+ G_verbose_message(_("Threshold: %f\n"), threshold);
+ /* Define window bounds */
+ windowOffset = (windowSize - 1) / 2;
+ minCol = currCol - windowOffset;
+ if (minCol < 0)
+ minCol = 0;
+ maxCol = currCol + windowOffset;
+ if (maxCol > ncols_less_one)
+ maxCol = ncols_less_one;
+ minRow = currRow - windowOffset;
+ if (minRow < 0)
+ minRow = 0;
+ maxRow = currRow + windowOffset;
+ if (maxRow > nrows_less_one)
+ maxRow = nrows_less_one;
+ G_debug(1, "currCol: %d, currRow: %d", currCol, currRow);
+ G_debug(1, "min. col: %d, max. col: %d", minCol, maxCol);
+ G_debug(1, "min. row: %d, max. row: %d", minRow, maxRow);
+ /* Search for stream pixels within the window */
+ for (row = minRow; row <= maxRow; row++) {
+ G_debug(1, "row: %d", row);
+ /* Get the current row */
+ Rast_get_row(fd, tmpRow, row, dataType);
+ for (col = minCol; col <= maxCol; col++) {
+ DCELL tmpValue;
+ double logTmpValue;
+ G_debug(1, " col: %d", col);
+ case FCELL_TYPE:
+ tmpValue = (double)((FCELL *) tmpRow)[col];
+ break;
+ case DCELL_TYPE:
+ tmpValue = (double)((DCELL *) tmpRow)[col];
+ break;
+ default:
+ tmpValue = (double)((CELL *) tmpRow)[col];
+ break;
+ logTmpValue = log10(tmpValue);
+ /* Test for nearby pixels that are stream pixels when compared to the central pixel */
+ G_debug(1, " tmpValue: %f, centralValue: %f",
+ tmpValue, centralValue);
+ G_debug(1, " logTmpValue: %f, logCentralValue: %f",
+ logTmpValue, logCentralValue);
+ if (logTmpValue - logCentralValue > threshold) {
+ /* Add to list of stream pixels if the nearby pixel is a stream
+ * pixel */
+ if (NULL == streamPixels)
+ streamPixels = create_list(col, row);
+ else
+ append_point(streamPixels, col, row);
+ else if (logCentralValue - logTmpValue > threshold) {
+ /* Add to list of stream pixels if the given pixel itself is a
+ * stream pixel; don't try to find streams somewhere else */
+ streamPixels = create_list(currCol, currRow);
+ else
+ append_point(streamPixels, currCol, currRow);
+ G_free(tmpRow);
