[GRASS-SVN] r70201 - in grass/branches/releasebranch_7_2: . raster/r.sim/r.sim.sediment raster/r.sim/r.sim.water raster/r.sim/simlib
svn_grass at osgeo.org
Mon Jan 2 08:13:07 PST 2017
Author: annakrat
Date: 2017-01-02 08:13:07 -0800 (Mon, 02 Jan 2017)
New Revision: 70201
grass/branches/releasebranch_7_2/
grass/branches/releasebranch_7_2/raster/r.sim/r.sim.sediment/main.c
grass/branches/releasebranch_7_2/raster/r.sim/r.sim.water/main.c
grass/branches/releasebranch_7_2/raster/r.sim/simlib/simlib.h
simlib: give more control over seeding of random number generator (merge from trunk, r69620)
Property changes on: grass/branches/releasebranch_7_2
___________________________________________________________________
Added: svn:mergeinfo
+ /grass/trunk:69619-69620
Modified: grass/branches/releasebranch_7_2/raster/r.sim/r.sim.sediment/main.c
--- grass/branches/releasebranch_7_2/raster/r.sim/r.sim.sediment/main.c 2017-01-02 16:11:08 UTC (rev 70200)
+++ grass/branches/releasebranch_7_2/raster/r.sim/r.sim.sediment/main.c 2017-01-02 16:13:07 UTC (rev 70201)
@@ -101,10 +101,11 @@
int ii;
int ret_val;
- static int rand1 = 12345;
struct Cell_head cellhd;
struct WaterParams wp;
struct options parm;
+ struct flags flag;
+ long seed_value;
G_gisinit(argv[0]);
@@ -259,9 +260,42 @@
parm.diffc->description = _("Water diffusion constant");
parm.diffc->guisection = _("Parameters");
+ parm.seed = G_define_option();
+ parm.seed->key = "random_seed";
+ parm.seed->type = TYPE_INTEGER;
+ parm.seed->required = NO;
+ parm.seed->label = _("Seed for random number generator");
+ parm.seed->description =
+ _("The same seed can be used to obtain same results"
+ " or random seed can be generated by other means.");
+ flag.generateSeed = G_define_flag();
+ flag.generateSeed->key = 's';
+ flag.generateSeed->label =
+ _("Generate random seed");
+ flag.generateSeed->description =
+ _("Automatically generates random seed for random number"
+ " generator (use when you don't want to provide the seed option)");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
+ if (flag.generateSeed->answer) {
+ seed_value = G_srand48_auto();
+ G_verbose_message(_("Generated random seed (-s): %ld"), seed_value);
+ else if (parm.seed->answer) {
+ seed_value = atol(parm.seed->answer);
+ G_srand48(seed_value);
+ G_verbose_message(_("Read random seed from %s option: %ld"),
+ parm.seed->key, seed_value);
+ else {
+ /* default as it used to be */
+ G_srand48(12345);
G_get_set_window(&cellhd);
WaterParams_init(&wp);
@@ -365,7 +399,6 @@
alloc_grids_sediment();
- G_srand48(rand1);
grad_check();
init_grids_sediment();
/* treba dat output pre topoerdep */
Modified: grass/branches/releasebranch_7_2/raster/r.sim/r.sim.water/main.c
--- grass/branches/releasebranch_7_2/raster/r.sim/r.sim.water/main.c 2017-01-02 16:11:08 UTC (rev 70200)
+++ grass/branches/releasebranch_7_2/raster/r.sim/r.sim.water/main.c 2017-01-02 16:13:07 UTC (rev 70201)
@@ -100,12 +100,12 @@
int ii;
int ret_val;
double x_orig, y_orig;
struct GModule *module;
struct flags flag;
+ long seed_value;
G_gisinit(argv[0]);
@@ -297,9 +297,41 @@
flag.tserie->description = _("Time-series output");
flag.tserie->guisection = _("Output");
exit(EXIT_FAILURE);
+ else {
+ G_srand48(12345);
@@ -476,8 +508,6 @@
alloc_grids_water();
- G_debug(1, "seeding randoms");
- G_srand48(rand1);
grad_check();
main_loop();
Modified: grass/branches/releasebranch_7_2/raster/r.sim/simlib/simlib.h
--- grass/branches/releasebranch_7_2/raster/r.sim/simlib/simlib.h 2017-01-02 16:11:08 UTC (rev 70200)
+++ grass/branches/releasebranch_7_2/raster/r.sim/simlib/simlib.h 2017-01-02 16:13:07 UTC (rev 70201)
@@ -85,12 +85,12 @@
*observation, *depth, *disch, *err, *outwalk, *nwalk, *niter, *outiter,
*density, *diffc, *hmax, *halpha, *hbeta, *wdepth, *detin, *tranin,
*tauin, *tc, *et, *conc, *flux, *erdep, *rainval, *maninval,
- *infilval, *logfile;
+ *infilval, *logfile, *seed;
struct flags
- struct Flag *mscale, *tserie;
+ struct Flag *mscale, *tserie, *generateSeed;
#endif /* __SIMLIB_H__ */
