[GRASS-SVN] r70202 - grass/branches/releasebranch_7_2/gui/wxpython/lmgr
Mon Jan 2 08:16:31 PST 2017
Author: annakrat
Date: 2017-01-02 08:16:31 -0800 (Mon, 02 Jan 2017)
New Revision: 70202
   grass/branches/releasebranch_7_2/gui/wxpython/lmgr/giface.py
wxGUI: expose more functionality in gui interface to allow programatically remove and check layers in layer manager (merge from trunk, r70079)
Modified: grass/branches/releasebranch_7_2/gui/wxpython/lmgr/giface.py
--- grass/branches/releasebranch_7_2/gui/wxpython/lmgr/giface.py	2017-01-02 16:13:07 UTC (rev 70201)
+++ grass/branches/releasebranch_7_2/gui/wxpython/lmgr/giface.py	2017-01-02 16:16:31 UTC (rev 70202)
@@ -30,7 +30,8 @@
         It only provides all attributes of existing layer as used in lmgr.
-    def __init__(self, pydata):
+    def __init__(self, layer, pydata):
+        self._layer = layer
         self._pydata = pydata
     def __getattr__(self, name):
@@ -56,7 +57,7 @@
         """Iterates over the contents of the list."""
         item = self._tree.GetFirstChild(self._tree.root)[0]
         while item and item.IsOk():
-            yield Layer(self._tree.GetPyData(item))
+            yield Layer(item, self._tree.GetPyData(item))
             item = self._tree.GetNextItem(item)
     def __getitem__(self, index):
@@ -72,7 +73,7 @@
                                             checkedOnly=checkedOnly)
         layers = []
         for item in items:
-            layer = Layer(self._tree.GetPyData(item))
+            layer = Layer(item, self._tree.GetPyData(item))
             layers.append(layer)
         return layers
@@ -85,11 +86,11 @@
             return None
         else:
             data = self._tree.GetPyData(item)
-            return Layer(data)
+            return Layer(item, data)
     def GetLayerInfo(self, layer):
         """For compatibility only, will be removed."""
-        return Layer(self._tree.GetPyData(layer))
+        return Layer(layer, self._tree.GetPyData(layer))
     def AddLayer(self, ltype, name=None, checked=None,
                  opacity=1.0, cmd=None):
@@ -105,7 +106,20 @@
         self._tree.AddLayer(ltype=ltype, lname=name, lchecked=checked,
                             lopacity=opacity, lcmd=cmd)
+    def DeleteLayer(self, layer):
+        """Remove layer from layer list"""
+        self._tree.Delete(layer._layer)
+    def CheckLayer(self, layer, checked=True):
+        """Check or uncheck layer"""
+        self._tree.forceCheck = True
+        self._tree.CheckItem(layer._layer, checked=checked)
+    def IsLayerChecked(self, layer):
+        """Returns True if layer is checked, False otherwise"""
+        return self._tree.IsItemChecked(layer._layer)
     def GetLayersByName(self, name):
         items = self._tree.FindItemByData(key='name', value=name)
         if items is None:
@@ -113,7 +127,7 @@
         else:
             layers = []
             for item in items:
             return layers
@@ -130,7 +144,7 @@
         if item is None:
             return None
         else:
-            return Layer(self._tree.GetPyData(item))
+            return Layer(item, self._tree.GetPyData(item))
 class LayerManagerGrassInterface(object):
