[GRASS-SVN] r70241 - grass/trunk/gui/wxpython/lmgr
svn_grass at osgeo.org
Wed Jan 4 04:55:34 PST 2017
Author: martinl
Date: 2017-01-04 04:55:34 -0800 (Wed, 04 Jan 2017)
New Revision: 70241
grass/trunk/gui/wxpython/lmgr/layertree.py
wxGUI/lmgr: OnSetCompRegFromMap() run command from main thread, unused OnSetCompRegFromRaster() removed
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py 2017-01-04 12:38:21 UTC (rev 70240)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py 2017-01-04 12:55:34 UTC (rev 70241)
@@ -898,20 +898,6 @@
# print output to command log area
self._giface.RunCmd(cmd)
- def OnSetCompRegFromRaster(self, event):
- """Set computational region from selected raster map (ignore NULLs).
- Unused, removed item from layer context menu"""
- mapLayer = self.GetLayerInfo(self.layer_selected, key='maplayer')
- cmd = ['g.region', 'raster=%s' % mapLayer.GetName(),
- 'zoom=%s' % mapLayer.GetName()]
- # print output to command log area
- self._giface.RunCmd(cmd, notification=Notification.NO_NOTIFICATION)
- # re-render map display
- self._giface.GetMapWindow().UpdateMap(render=False)
def OnSetCompRegFromMap(self, event):
"""Set computational region from selected raster/vector map
@@ -932,20 +918,20 @@
for rname in mapLayer.GetName().splitlines():
rast.append(rname)
- cmd = ['g.region']
+ kwargs = {}
if rast:
- cmd.append('raster=%s' % ','.join(rast))
+ kwargs['raster'] = ','.join(rast)
if vect:
- cmd.append('vector=%s' % ','.join(vect))
+ kwargs['vector'] = ','.join(vect)
if rast3d:
- cmd.append('raster_3d=%s' % ','.join(rast3d))
+ kwargs['raster_3d'] = ','.join(rast3d)
- if len(cmd) > 1:
- if mltype == 'raster_3d':
- cmd.append('-3')
- self._giface.RunCmd(cmd, compReg=False,
- notification=Notification.NO_NOTIFICATION)
+ if kwargs:
+ # command must run in main thread otherwise it can be
+ # launched after rendering is done (region extent will
+ # remain untouched)
+ RunCommand('g.region', **kwargs)
