[GRASS-SVN] r70242 - grass/branches/releasebranch_7_2/gui/wxpython/lmgr
Wed Jan 4 04:57:37 PST 2017
Author: martinl
Date: 2017-01-04 04:57:37 -0800 (Wed, 04 Jan 2017)
New Revision: 70242
   grass/branches/releasebranch_7_2/gui/wxpython/lmgr/layertree.py
wxGUI/lmgr: OnSetCompRegFromMap() run command from main thread, unused OnSetCompRegFromRaster() removed (merge r70241 from trunk)
Modified: grass/branches/releasebranch_7_2/gui/wxpython/lmgr/layertree.py
--- grass/branches/releasebranch_7_2/gui/wxpython/lmgr/layertree.py	2017-01-04 12:55:34 UTC (rev 70241)
+++ grass/branches/releasebranch_7_2/gui/wxpython/lmgr/layertree.py	2017-01-04 12:57:37 UTC (rev 70242)
@@ -903,20 +903,6 @@
         # print output to command log area
         self._giface.RunCmd(cmd)
-    def OnSetCompRegFromRaster(self, event):
-        """Set computational region from selected raster map (ignore NULLs).
-        Unused, removed item from layer context menu"""
-        mapLayer = self.GetLayerInfo(self.layer_selected, key='maplayer')
-        cmd = ['g.region', 'raster=%s' % mapLayer.GetName(),
-               'zoom=%s' % mapLayer.GetName()]
-        # print output to command log area
-        self._giface.RunCmd(cmd, notification=Notification.NO_NOTIFICATION)
-        # re-render map display
-        self._giface.GetMapWindow().UpdateMap(render=False)
     def OnSetCompRegFromMap(self, event):
         """Set computational region from selected raster/vector map
@@ -937,20 +923,20 @@
                 for rname in mapLayer.GetName().splitlines():
                     rast.append(rname)
-        cmd = ['g.region']
+        kwargs = {}
         if rast:
-            cmd.append('raster=%s' % ','.join(rast))
+            kwargs['raster'] = ','.join(rast)
         if vect:
-            cmd.append('vector=%s' % ','.join(vect))
+            kwargs['vector'] = ','.join(vect)
         if rast3d:
-            cmd.append('raster_3d=%s' % ','.join(rast3d))
+            kwargs['raster_3d'] = ','.join(rast3d)
-        if len(cmd) > 1:
-            if mltype == 'raster_3d':
-                cmd.append('-3')
-            self._giface.RunCmd(cmd, compReg=False,
-                                notification=Notification.NO_NOTIFICATION)
+        if kwargs:
+            # command must run in main thread otherwise it can be
+            # launched after rendering is done (region extent will
+            # remain untouched)
+            RunCommand('g.region', **kwargs)
