[GRASS-SVN] r70377 - grass-addons/grass7/raster/r.resamp.tps
svn_grass at osgeo.org
Sun Jan 15 13:41:43 PST 2017
Author: mmetz
Date: 2017-01-15 13:41:43 -0800 (Sun, 15 Jan 2017)
New Revision: 70377
grass-addons/grass7/raster/r.resamp.tps/main.c
grass-addons/grass7/raster/r.resamp.tps/tps.c
r.resamp.tps: fix option to avoid extrapolation when using covariables
Modified: grass-addons/grass7/raster/r.resamp.tps/main.c
--- grass-addons/grass7/raster/r.resamp.tps/main.c 2017-01-15 15:03:06 UTC (rev 70376)
+++ grass-addons/grass7/raster/r.resamp.tps/main.c 2017-01-15 21:41:43 UTC (rev 70377)
@@ -134,7 +134,7 @@
lm_opt->label =
_("Threshold to avoid interpolation outliers when using covariables");
lm_opt->description =
- _("Disabled when set to zero, larger values will cause more outliers");
+ _("Disabled when set to zero, must be within [0, 1], larger values will cause more outliers");
lm_opt->guisection = _("Settings");
ep_opt = G_define_option();
@@ -145,7 +145,7 @@
ep_opt->label =
_("Threshold to avoid extrapolation when using covariables");
ep_opt->description =
- _("Disabled when set to zero, smaller values will cause more outliers");
+ _("Disabled when set to zero, must be > 0, smaller values will cause more outliers");
ep_opt->guisection = _("Settings");
out_opt = G_define_standard_option(G_OPT_R_OUTPUT);
@@ -155,7 +155,7 @@
mask_opt = G_define_standard_option(G_OPT_R_INPUT);
mask_opt->key = "mask";
mask_opt->label = _("Raster map to use for masking");
- mask_opt->description = _("Only cells that are not NULL and not zero are interpolated");
+ mask_opt->description = _("Only cells where the mask map is not NULL and not zero are interpolated");
mask_opt->required = NO;
mem_opt = G_define_option();
Modified: grass-addons/grass7/raster/r.resamp.tps/tps.c
--- grass-addons/grass7/raster/r.resamp.tps/tps.c 2017-01-15 15:03:06 UTC (rev 70376)
+++ grass-addons/grass7/raster/r.resamp.tps/tps.c 2017-01-15 21:41:43 UTC (rev 70377)
@@ -1029,8 +1029,6 @@
vmin[i] -= diff;
vmax[i] += diff;
- solved_tps = solvemat(mpnts, apnts, Bpnts, pfound + 1);
if (!solved_tps_lm) {
@@ -1038,8 +1036,8 @@
m = mpnts;
a = apnts;
B = Bpnts;
- if (efac == 0)
- solved_tps = solvemat(m, a, B, pfound + 1);
+ solved_tps = solvemat(m, a, B, pfound + 1);
else {
@@ -1180,12 +1178,16 @@
continue;
- if (efac && solved_tps) {
+ if (efac) {
for (i = 0; i < n_vars_i; i++) {
if (varbuf[i] < vmin[i] || varbuf[i] > vmax[i]) {
- n_vars_ic = 0;
- cnt_efac++;
- Bc = Bpnts;
+ if (!solved_tps)
+ solved_tps = solvemat(mpnts, apnts, Bpnts, pfound + 1);
+ if (solved_tps) {
+ n_vars_ic = 0;
+ Bc = Bpnts;
+ cnt_efac++;
break;
@@ -1211,7 +1213,7 @@
dist = 0;
if (dist2 > 0) {
dist = dist2 * log(dist2) * 0.5;
- result += Bc[1 + n_vars_i + i] * dist;
+ result += Bc[1 + n_vars_ic + i] * dist;
