[GRASS-SVN] r70378 - grass-addons/grass7/raster/r.resamp.tps
svn_grass at osgeo.org
Sun Jan 15 14:12:29 PST 2017
Author: mmetz
Date: 2017-01-15 14:12:29 -0800 (Sun, 15 Jan 2017)
New Revision: 70378
grass-addons/grass7/raster/r.resamp.tps/r.resamp.tps.html
r.resamp.tps: update manual
Modified: grass-addons/grass7/raster/r.resamp.tps/r.resamp.tps.html
--- grass-addons/grass7/raster/r.resamp.tps/r.resamp.tps.html 2017-01-15 21:41:43 UTC (rev 70377)
+++ grass-addons/grass7/raster/r.resamp.tps/r.resamp.tps.html 2017-01-15 22:12:29 UTC (rev 70378)
@@ -43,6 +43,21 @@
different method).
<p>
+When using covariables, outliers might be created if the values of the
+covariables of the current output cell are far outside the observed
+range of covariables, or if the linear regression component of the TPS
+interpolation for the covariables does not provide a good solution. Two
+methods are provided to avoid outliers caused by covariables. The first
+method (<em>lmfilter</em>) will discard covariables if R squared is
+larger than the value provided with the <em>lmfilter</em> option. The
+second method (<em>epfilter</em>) will discard covariables if the
+current value of a covariable is outside the observed range of
+covariables by a factor of (<em>epfilter</em>). The <em>epfilter</em>
+option typically results in more interpolations using the supplied
+covariables than the <em>lmfilter</em> option when both are adjusted to
+reject the same outliers.
+<p>
The <b>memory</b> option controls only how much memory should be used
for the covariables and the intermediate output. The data needed for
TPS interpolation are always completely loaded to memory.
