[GRASS-SVN] r70393 - grass/branches/releasebranch_7_2/vector/v.to.rast
svn_grass at osgeo.org
Tue Jan 17 14:32:30 PST 2017
Author: mmetz
Date: 2017-01-17 14:32:30 -0800 (Tue, 17 Jan 2017)
New Revision: 70393
grass/branches/releasebranch_7_2/vector/v.to.rast/local.h
grass/branches/releasebranch_7_2/vector/v.to.rast/support.c
grass/branches/releasebranch_7_2/vector/v.to.rast/vect2rast.c
v.to.rast: backport trunk r69326, 69357
Modified: grass/branches/releasebranch_7_2/vector/v.to.rast/local.h
--- grass/branches/releasebranch_7_2/vector/v.to.rast/local.h 2017-01-17 22:11:49 UTC (rev 70392)
+++ grass/branches/releasebranch_7_2/vector/v.to.rast/local.h 2017-01-17 22:32:30 UTC (rev 70393)
@@ -43,11 +43,9 @@
/* support.c */
int update_hist(const char *, const char *, long);
-int update_colors(const char *);
int update_dbcolors(const char *, const char *, int, const char *, int, const char *);
int update_labels(const char *, const char *, int, const char *, int, int, const char *);
int update_cats(const char *);
-int update_fcolors(const char *);
/* vect2rast.c */
int vect_to_rast(const char *, const char *, const char *, const char *, int, int,
Modified: grass/branches/releasebranch_7_2/vector/v.to.rast/support.c
--- grass/branches/releasebranch_7_2/vector/v.to.rast/support.c 2017-01-17 22:11:49 UTC (rev 70392)
+++ grass/branches/releasebranch_7_2/vector/v.to.rast/support.c 2017-01-17 22:32:30 UTC (rev 70393)
@@ -5,6 +5,7 @@
* -1 - error
+#include <stdlib.h>
#include <string.h>
#include <stdio.h>
#include <grass/gis.h>
@@ -15,7 +16,14 @@
#include <grass/glocale.h>
#include "local.h"
+struct My_labels_rule
+ dbString label;
+ double d;
+ int i;
int update_hist(const char *raster_name, const char *vector_name, long scale)
struct History hist;
@@ -39,37 +47,6 @@
return 0;
-int update_colors(const char *raster_name)
- struct Range range;
- struct Colors colors;
- CELL min, max;
- Rast_read_range(raster_name, G_mapset(), &range);
- Rast_get_range_min_max(&range, &min, &max);
- Rast_make_rainbow_colors(&colors, min, max);
- Rast_write_colors(raster_name, G_mapset(), &colors);
- return 0;
-int update_fcolors(const char *raster_name)
- struct FPRange range;
- DCELL min, max;
- Rast_read_fp_range(raster_name, G_mapset(), &range);
- Rast_get_fp_range_min_max(&range, &min, &max);
- Rast_make_rainbow_colors(&colors, (CELL) min, (CELL) max);
- return 0;
int update_cats(const char *raster_name)
/* TODO: maybe attribute transfer from vector map?
@@ -233,13 +210,31 @@
return 1;
+static int cmp_labels_d(const void *a, const void *b)
+ struct My_labels_rule *al = (struct My_labels_rule *) a;
+ struct My_labels_rule *bl = (struct My_labels_rule *) b;
+ if (al->d < bl->d)
+ return -1;
+ return (al->d > bl->d);
+static int cmp_labels_i(const void *a, const void *b)
+ return (al->i - bl->i);
/* add labels to raster cells */
int update_labels(const char *rast_name, const char *vector_map, int field,
const char *label_column, int use, int val,
const char *attr_column)
- int i;
+ int i, j;
/* Map */
struct Map_info Map;
@@ -254,12 +249,7 @@
/* labels */
struct Categories rast_cats;
int labels_n_values = 0;
- struct My_labels_rule
- dbString label;
- double d;
- int i;
- } *my_labels_rules;
+ struct My_labels_rule *my_labels_rules;
/* init raster categories */
Rast_init_cats("Categories", &rast_cats);
@@ -364,21 +354,107 @@
/* close the database driver */
db_close_database_shutdown_driver(Driver);
- /* set the color rules: for each rule */
- if (is_fp) {
- /* add label */
- for (i = 0; i < labels_n_values - 1; i++)
- Rast_set_cat(&my_labels_rules[i].d,
- &my_labels_rules[i + 1].d,
- db_get_string(&my_labels_rules[i].label),
- &rast_cats, DCELL_TYPE);
+ /* set the labels */
+ if (labels_n_values > 0) {
+ char *lblstr;
+ /* remove values without labels */
+ j = 0;
+ for (i = 0; i < labels_n_values; i++) {
+ lblstr = db_get_string(&my_labels_rules[i].label);
+ if (lblstr && *lblstr) {
+ my_labels_rules[j] = my_labels_rules[i];
+ j++;
+ labels_n_values = j;
- else {
- for (i = 0; i < labels_n_values; i++)
- Rast_set_c_cat(&(my_labels_rules[i].i),
- &(my_labels_rules[i].i),
- &rast_cats);
+ char *lblstr;
+ if (is_fp) {
+ DCELL val1, val2;
+ qsort(my_labels_rules, labels_n_values,
+ sizeof(struct My_labels_rule), cmp_labels_d);
+ /* remove duplicate values */
+ j = 1;
+ for (i = 1; i < labels_n_values; i++) {
+ if (my_labels_rules[i - 1].d != my_labels_rules[i].d) {
+ j++;
+ else {
+ if (strcmp(db_get_string(&my_labels_rules[i].label),
+ db_get_string(&my_labels_rules[i - 1].label)) != 0) {
+ G_warning(_("Different labels for the same value are not supported"));
+ /* add labels */
+ i = 0;
+ val1 = val2 = my_labels_rules[i].d;
+ if (strcmp(lblstr, db_get_string(&my_labels_rules[i].label)) == 0) {
+ val2 = my_labels_rules[i].d;
+ else {
+ Rast_set_d_cat(&val1, &val2, lblstr,
+ &rast_cats);
+ Rast_set_d_cat(&val1, &val2, lblstr, &rast_cats);
+ else {
+ CELL val1, val2;
+ sizeof(struct My_labels_rule), cmp_labels_i);
+ j = 1;
+ if (my_labels_rules[i - 1].i != my_labels_rules[i].i) {
+ j++;
+ else {
+ /* add labels */
+ i = 0;
+ val1 = val2 = my_labels_rules[i].i;
+ val2 = my_labels_rules[i].i;
+ else {
+ Rast_set_c_cat(&val1, &val2, lblstr,
+ &rast_cats);
+ Rast_set_c_cat(&val1, &val2, lblstr, &rast_cats);
break;
Modified: grass/branches/releasebranch_7_2/vector/v.to.rast/vect2rast.c
--- grass/branches/releasebranch_7_2/vector/v.to.rast/vect2rast.c 2017-01-17 22:11:49 UTC (rev 70392)
+++ grass/branches/releasebranch_7_2/vector/v.to.rast/vect2rast.c 2017-01-17 22:32:30 UTC (rev 70393)
@@ -202,17 +202,12 @@
if (rgbcolumn) {
if (use != USE_ATTR && use != USE_CAT) {
G_warning(_("Color can be updated from database only if use=attr"));
- update_colors(raster_map);
else {
update_dbcolors(raster_map, vector_map, field, rgbcolumn, is_fp,
column);
- else if (use == USE_D)
- update_fcolors(raster_map);
- else
update_cats(raster_map);
